[2023/2/14 15:33:44] ----TuyaCloudInit [2023/2/14 15:33:44] para.version = 1.3.4 [2023/2/14 15:33:44] para.DbPath = /data/cloud [2023/2/14 15:33:44] gTuyaCloudInitConfig->DbPath = /data/cloud/ [2023/2/14 15:33:44] TUYA_Init [2023/2/14 15:33:44] mode = 0 [2023/2/14 15:33:44] --mode = 1 [2023/2/14 15:33:44] ---mode = 1 [2023/2/14 15:33:44] Dbg:SDK Version:< TUYA IOT SDK V:5.3.33 BS:40.00_PT:2.2_LAN:3.4_CAD:1.0.4_CD:1.0.0 > [2023/2/14 15:33:44] < BUILD AT:2023_02_14_11_50_44 BY ci_manage FOR ty_ipc_wr_wl_linux_sdk AT arm-anykav500-linux-gnueabi > [2023/2/14 15:33:44] IOT DEFS < WIFI_GW:1 DEBUG:1 KV_FILE:1 SHUTDOWN_MODE:1 LITTLE_END:1 TLS_MODE:4 ENABLE_CLOUD_OPERATION:1 OPERATING_SYSTEM:100 ENABLE_SYS_RPC:0 RELIABLE_TRANSFER:0 ENABLE_LAN_ENCRYPTION:1 ENABLE_LAN_LINKAGE:0 ENABLE_LAN_DEV:0 > [2023/2/14 15:33:44] [2023/2/14 15:33:44] [2023/2/14 15:33:44] ---tuya_ipc_app_start [2023/2/14 15:33:44] Dbg:channel_enable:1 1 0 [2023/2/14 15:33:44] Dbg:fps:25 [2023/2/14 15:33:44] Dbg:gop:30 [2023/2/14 15:33:44] Dbg:bitrate:1536 kbps [2023/2/14 15:33:44] Dbg:video_main_width:640 [2023/2/14 15:33:44] Dbg:video_main_height:280 [2023/2/14 15:33:44] Dbg:video_freq:90000 [2023/2/14 15:33:44] Dbg:video_codec:2 [2023/2/14 15:33:44] Dbg:audio_codec:106 [2023/2/14 15:33:44] Dbg:audio_sample:8000 [2023/2/14 15:33:44] Dbg:audio_databits:16 [2023/2/14 15:33:44] Dbg:audio_channel:0 [2023/2/14 15:33:44] ---tuya_ipc_init_sdk [2023/2/14 15:33:44] Dbg:tuya_ipc_sdk_mqtt_online_proc thread start success [2023/2/14 15:33:44] [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /data/cloud [2023/2/14 15:33:45] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/data/cloud [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/data/cloud [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[¡ê¡éUS??kR? [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:1012] both file exist [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512 [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:555] head check success [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:155] key tls_ca0 is invaild, don't crc check [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:155] key tls_ca_cnt is invaild, don't crc check [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success [2023/2/14 15:33:45] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success. [2023/2/14 15:33:45] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ... [2023/2/14 15:33:45] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4 [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1 [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2 [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success [2023/2/14 15:33:45] [01-01 18:12:15 TUYA E][log_seq.c:863] open err [2023/2/14 15:33:45] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3 [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat [2023/2/14 15:33:45] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat [2023/2/14 15:33:45] ---TUYA_APP_Init_Ring_Buffer [2023/2/14 15:33:45] Dbg:init ring buffer Channel:0 Enable:1 [2023/2/14 15:33:45] Dbg:video_bitrate 1536, video_fps 25 [2023/2/14 15:33:45] Dbg:init ring buffer success. channel:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:1 Enable:1 [2023/2/14 15:33:45] Dbg:video_bitrate 512, video_fps 25 [2023/2/14 15:33:45] Dbg:init ring buffer success. channel:1 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:2 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:3 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:4 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:5 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:6 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:7 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:8 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:9 Enable:1 [2023/2/14 15:33:45] Dbg:audio_sample 8000, audio_databits 16, audio_fps 25 [2023/2/14 15:33:45] Dbg:init ring buffer success. channel:9 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:10 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:11 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:12 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:13 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:14 Enable:0 [2023/2/14 15:33:45] Dbg:init ring buffer Channel:15 Enable:0 [2023/2/14 15:33:45] pRunInfo->net_info.connect_mode = 1 [2023/2/14 15:33:45] eifconfig: wlan0: error fetching interface information: Device not found [2023/2/14 15:33:45] WIFI Get MAC 64-09-F5-BE-70-FE [2023/2/14 15:33:45] Set Country Code:(null) [2023/2/14 15:33:45] ifconfig: wlan0: error fetching interface information: Device not found [2023/2/14 15:33:45] WIFI Get MAC 00-00-00-00-00-00 [2023/2/14 15:33:45] Dbg:tuya ipc sdk start is complete [2023/2/14 15:33:45] [2023/2/14 15:33:45] @@@@@@@@@@@@@@@@ TUYA_APP_Init_Stream_Storage [2023/2/14 15:33:45] Dbg:Init Stream_Storage SD:/mnt/ [2023/2/14 15:33:45] Init tuya_ipc_ss_init [2023/2/14 15:33:45] Exec Cmd:ifconfig wlan0 up [2023/2/14 15:33:45] [01-01 18:12:15 TUYA E][tuya_ipc_stream_storage.c:2188] the ss mgr not inited [2023/2/14 15:33:45] Dbg:local storage init result is 0 [2023/2/14 15:33:45] [2023/2/14 15:33:45] [2023/2/14 15:33:45] [2023/2/14 15:33:45] Web_Init222222 23 [2023/2/14 15:33:45] [2023/2/14 15:33:45] tifconfig: SIOCGIFFLAGS: No such device [2023/2/14 15:33:45] Exec Cmd:ifconfig wlan0 down [2023/2/14 15:33:45] ifconfig: SIOCGIFFLAGS: No such device [2023/2/14 15:33:45] Exec Cmd:ifconfig wlan0 up [2023/2/14 15:33:46] hifconfig: SIOCGIFFLAGS: No such device [2023/2/14 15:33:46] WIFI Set Mode 3 [2023/2/14 15:33:46] IDS_Wifi_StartApMode ssid =SmartLife-0000,password = [2023/2/14 15:33:46] ---Start AP SSID:SmartLife-0000,PASSWORD: [2023/2/14 15:33:46] [01-01 18:12:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:46] [01-01 18:12:15 TUYA E][log_seq.c:152] ret:-1027 [2023/2/14 15:33:46] [01-01 18:12:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:46] [01-01 18:12:15 TUYA E][log_seq.c:152] ret:-1027 [2023/2/14 15:33:46] [Lua] ########## lua start [2023/2/14 15:33:46] IDS_Wifi_DoStartAp:ssid = SmartLife-0000,password = 12345678 [2023/2/14 15:33:46] Wifi_AP_Init:ssid = SmartLife-0000,psk = 12345678 [2023/2/14 15:33:46] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:46] 0system sed -ri 's/ssid=.*/ssid=SmartLife-0000/' /data/cloud/hostapd.conf ok ! [2023/2/14 15:33:46] system sed -ri 's/wpa_passphrase=.*/wpa_passphrase=12345678/' /data/cloud/hostapd.conf ok ! [2023/2/14 15:33:46] killall: wpa_supplicant: no process killed [2023/2/14 15:33:46] killall: udhcpc: no process killed [2023/2/14 15:33:46] killall: udhcpd: no process killed [2023/2/14 15:33:46] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:46] Dbg:Net status change to:2 [2023/2/14 15:33:46] killall: hostapd: no process killed [2023/2/14 15:33:46] ifconfig: SIOCGIFFLAGS: No such device [2023/2/14 15:33:46] rmmod: can't unload module 'rtl8188ftv': No such file or directory [2023/2/14 15:33:46] rmmod: can't unload module 'ak_hcd': No such file or directory [2023/2/14 15:33:47] [01-01 18:12:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:47] [01-01 18:12:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:47] doFail to get key mask bitmap. [2023/2/14 15:33:47] Fail to get tr keyboard back ground bitmap. [2023/2/14 15:33:47] Fail to get span keyboard back ground bitmap. [2023/2/14 15:33:48] w[01-01 18:12:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:48] nsoftkeyboard/softkeywindow.c:441 IME_LANGUAGE_UNKNOWN 2 [2023/2/14 15:33:48] [2023/2/14 15:33:48] [2023/2/14 15:33:48] Web_Init 4 [2023/2/14 15:33:48] [2023/2/14 15:33:48] [2023/2/14 15:33:48] [root@vdpids ~]$ [01-01 18:12:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:49] [01-01 18:12:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:49] load img welcome.png [2023/2/14 15:33:49] [01-01 18:12:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:49] [Lua] wificfg.MODE.get() = 1 [2023/2/14 15:33:49] [2023/2/14 15:33:49] uart_write:[fe 04 04 08 ] [2023/2/14 15:33:49] [uart Send head[1]:0xfe, len[2]:4, cmd[3]:0x4, chksum[4]:0x8] [2023/2/14 15:33:49] [2023/2/14 15:33:49] uart_write:[fe 05 05 10 1a ] [2023/2/14 15:33:49] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x10, chksum[5]:0x1a] [2023/2/14 15:33:49] [2023/2/14 15:33:49] uart_write:[fe 05 05 01 0b ] [2023/2/14 15:33:49] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x1, chksum[5]:0xb] [2023/2/14 15:33:49] [2023/2/14 15:33:49] uart_write:[fe 05 05 02 0c ] [2023/2/14 15:33:49] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x2, chksum[5]:0xc] [2023/2/14 15:33:49] OnNewFileChange true true false [2023/2/14 15:33:49] [2023/2/14 15:33:49] uart_write:[fe 05 05 13 1d ] [2023/2/14 15:33:49] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x13, chksum[5]:0x1d] [2023/2/14 15:33:49] [2023/2/14 15:33:49] uart_write:[fe 05 00 01 06 ] [2023/2/14 15:33:49] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x0, data[4]:0x1, chksum[5]:0x6] [2023/2/14 15:33:49] [2023/2/14 15:33:49] uart_write:[fe 08 06 02 02 02 02 16 ] [2023/2/14 15:33:49] [uart Send head[1]:0xfe, len[2]:8, cmd[3]:0x6, data[4]:0x2, data[5]:0x2, data[6]:0x2, data[7]:0x2, chksum[8]:0x16] [2023/2/14 15:33:49] [Lua] @@@@@@@@@@ welcome open [2023/2/14 15:33:49] uart.OnRcv 254.0 7.0 4.0 23.0 17.0 [2023/2/14 15:33:49] TotalLen = 7 [2023/2/14 15:33:49] cmd:data = 4.0 table: 0x28a2650 [2023/2/14 15:33:49] -----cmd:data = 4.0 table: 0x28a2650 [2023/2/14 15:33:49] [Lua] mcu ver: 20230109 [2023/2/14 15:33:50] [01-01 18:12:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:50] [01-01 18:12:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:50] [01-01 18:12:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:51] [01-01 18:12:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:51] [01-01 18:12:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:52] if[01-01 18:12:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:52] [01-01 18:12:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:52] cConfiguration file: /data/cloud/hostapd.conf [2023/2/14 15:33:53] rfkill: Cannot open RFKILL control device [2023/2/14 15:33:53] Using interface wlan0 with hwaddr c8:02:8f:d5:ab:12 and ssid "SmartLife-0000" [2023/2/14 15:33:53] [01-01 18:12:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:53] random: Only 15/20 bytes of strong random data available [2023/2/14 15:33:53] random: Not enough entropy pool available for secure operations [2023/2/14 15:33:53] WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects [2023/2/14 15:33:53] [01-01 18:12:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:53] wlan0: interface state UNINITIALIZED->ENABLED [2023/2/14 15:33:53] wlan0: AP-ENABLED [2023/2/14 15:33:53] system wifi_install.sh rtl8188 ap ok ! [2023/2/14 15:33:54] i[01-01 18:12:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:54] n[01-01 18:12:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:55] fig [2023/2/14 15:33:55] -sh: ifcinfig: not found [2023/2/14 15:33:55] [root@vdpids ~]$ [01-01 18:12:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:55] [01-01 18:12:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:55] [01-01 18:12:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:56] [01-01 18:12:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:56] [01-01 18:12:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:57] [01-01 18:12:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:57] [2023/2/14 15:33:57] [root@vdpids ~]$ [01-01 18:12:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:58] [01-01 18:12:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:58] i[01-01 18:12:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:58] [Lua] [lua] page.Open desk/desk [2023/2/14 15:33:58] [2023/2/14 15:33:58] uart_write:[fe 05 05 13 1d ] [2023/2/14 15:33:58] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x13, chksum[5]:0x1d] [2023/2/14 15:33:58] [Lua] GetUnReadCnt 25 4 [2023/2/14 15:33:58] [2023/2/14 15:33:58] uart_write:[fe 05 03 01 09 ] [2023/2/14 15:33:58] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x3, data[4]:0x1, chksum[5]:0x9] [2023/2/14 15:33:58] [2023/2/14 15:33:58] uart_write:[fe 08 35 02 02 02 02 45 ] [2023/2/14 15:33:58] [uart Send head[1]:0xfe, len[2]:8, cmd[3]:0x35, data[4]:0x2, data[5]:0x2, data[6]:0x2, data[7]:0x2, chksum[8]:0x45] [2023/2/14 15:33:58] Cloud_SetTimeZone [2023/2/14 15:33:58] [2023/2/14 15:33:58] uart_write:[fe 05 66 01 6c ] [2023/2/14 15:33:58] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x66, data[4]:0x1, chksum[5]:0x6c] [2023/2/14 15:33:58] [2023/2/14 15:33:58] uart_write:[fe 06 67 00 00 6d ] [2023/2/14 15:33:58] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x67, data[4]:0x0, data[5]:0x0, chksum[6]:0x6d] [2023/2/14 15:33:58] [2023/2/14 15:33:58] uart_write:[fe 06 36 01 00 3d ] [2023/2/14 15:33:58] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x36, data[4]:0x1, data[5]:0x0, chksum[6]:0x3d] [2023/2/14 15:33:58] [2023/2/14 15:33:58] uart_write:[fe 06 37 01 00 3e ] [2023/2/14 15:33:58] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x37, data[4]:0x1, data[5]:0x0, chksum[6]:0x3e] [2023/2/14 15:33:59] fc[01-01 18:12:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:59] onf[01-01 18:12:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:33:59] iCurPage.name desk/desk [2023/2/14 15:34:00] g [2023/2/14 15:34:00] lo Link encap:Local Loopback [2023/2/14 15:34:00] inet addr:127.0.0.1 Mask:255.0.0.0 [2023/2/14 15:34:00] UP LOOPBACK RUNNING MTU:65536 Metric:1 [2023/2/14 15:34:00] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/14 15:34:00] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/14 15:34:00] collisions:0 txqueuelen:1 [2023/2/14 15:34:00] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/14 15:34:00] [2023/2/14 15:34:00] wlan0 Link encap:Ethernet HWaddr C8:02:8F:D5:AB:12 [2023/2/14 15:34:00] inet addr:192.168.231.1 Bcast:192.168.231.255 Mask:255.255.255.0 [2023/2/14 15:34:00] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 [2023/2/14 15:34:00] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/14 15:34:00] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/14 15:34:00] collisions:0 txqueuelen:1000 [2023/2/14 15:34:00] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/14 15:34:00] [2023/2/14 15:34:00] [root@vdpids ~]$ [01-01 18:12:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:00] [01-01 18:12:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:01] [01-01 18:12:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:01] [01-01 18:12:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:01] [01-01 18:12:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:02] [01-01 18:12:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:02] [01-01 18:12:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:03] [01-01 18:12:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:03] [01-01 18:12:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:04] [01-01 18:12:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:04] [01-01 18:12:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:05] [01-01 18:12:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:05] [01-01 18:12:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:06] [01-01 18:12:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:06] [01-01 18:12:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:06] [01-01 18:12:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:07] [01-01 18:12:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:07] [01-01 18:12:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:08] [01-01 18:12:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:08] [01-01 18:12:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:09] [01-01 18:12:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:09] [01-01 18:12:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:10] [01-01 18:12:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:10] [01-01 18:12:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:11] [01-01 18:12:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:11] [01-01 18:12:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:11] [01-01 18:12:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:12] [01-01 18:12:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:12] [01-01 18:12:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:13] [01-01 18:12:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:13] [01-01 18:12:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:14] [01-01 18:12:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:14] [01-01 18:12:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:15] [01-01 18:12:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:15] [01-01 18:12:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:16] [01-01 18:12:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:16] [01-01 18:12:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:16] [01-01 18:12:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:17] [01-01 18:12:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:17] [01-01 18:12:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:18] [01-01 18:12:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:18] [01-01 18:12:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:19] [01-01 18:12:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:19] [01-01 18:12:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:20] [01-01 18:12:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:20] [01-01 18:12:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:21] [01-01 18:12:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:21] [01-01 18:12:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:21] [01-01 18:12:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:22] [01-01 18:12:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:22] [01-01 18:12:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:23] [01-01 18:12:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:23] [01-01 18:12:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:24] [01-01 18:12:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:24] [01-01 18:12:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:25] [01-01 18:12:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:25] [01-01 18:12:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:26] [01-01 18:12:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:26] [01-01 18:12:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:26] [01-01 18:12:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:27] [01-01 18:12:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:27] [01-01 18:12:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:28] [01-01 18:12:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:28] [01-01 18:12:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:29] [01-01 18:12:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:29] [01-01 18:12:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:30] [01-01 18:13:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:30] [01-01 18:13:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:31] [01-01 18:13:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:31] [01-01 18:13:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:31] [01-01 18:13:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:32] [01-01 18:13:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:32] [01-01 18:13:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:33] [01-01 18:13:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:33] [01-01 18:13:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:34] [01-01 18:13:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:34] [01-01 18:13:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:35] [01-01 18:13:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:35] [01-01 18:13:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:36] [01-01 18:13:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:36] [01-01 18:13:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:36] [01-01 18:13:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:37] [01-01 18:13:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:37] [01-01 18:13:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:38] [01-01 18:13:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:38] [01-01 18:13:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:39] [01-01 18:13:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:39] [01-01 18:13:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:40] [01-01 18:13:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:41] [01-01 18:13:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:41] [01-01 18:13:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:41] i[01-01 18:13:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:42] fc[01-01 18:13:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:42] onfi[01-01 18:13:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:42] g [2023/2/14 15:34:42] lo Link encap:Local Loopback [2023/2/14 15:34:42] inet addr:127.0.0.1 Mask:255.0.0.0 [2023/2/14 15:34:42] UP LOOPBACK RUNNING MTU:65536 Metric:1 [2023/2/14 15:34:42] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/14 15:34:42] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/14 15:34:42] collisions:0 txqueuelen:1 [2023/2/14 15:34:42] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/14 15:34:42] [2023/2/14 15:34:42] wlan0 Link encap:Ethernet HWaddr C8:02:8F:D5:AB:12 [2023/2/14 15:34:42] inet addr:192.168.231.1 Bcast:192.168.231.255 Mask:255.255.255.0 [2023/2/14 15:34:42] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 [2023/2/14 15:34:42] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/14 15:34:42] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/14 15:34:42] collisions:0 txqueuelen:1000 [2023/2/14 15:34:42] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/14 15:34:42] [2023/2/14 15:34:43] [root@vdpids ~]$ [01-01 18:13:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:43] [01-01 18:13:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:44] [01-01 18:13:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:44] [01-01 18:13:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:45] [01-01 18:13:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:45] [01-01 18:13:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:46] [01-01 18:13:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:46] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:46] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:47] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:47] [01-01 18:13:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:48] [01-01 18:13:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:48] [01-01 18:13:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:49] [01-01 18:13:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:49] [01-01 18:13:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:50] [01-01 18:13:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:50] [01-01 18:13:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:51] [01-01 18:13:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:51] [01-01 18:13:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:51] [01-01 18:13:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:52] [01-01 18:13:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:52] [01-01 18:13:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:53] [01-01 18:13:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:53] [01-01 18:13:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:54] [01-01 18:13:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:54] [01-01 18:13:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:55] [01-01 18:13:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:55] [01-01 18:13:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:56] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:56] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:56] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:57] [01-01 18:13:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:57] [01-01 18:13:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:58] [01-01 18:13:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:58] [01-01 18:13:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:58] systimeout.c 83: Time Out[sysinfo]! [2023/2/14 15:34:58] [Lua] [lua] page.Open timeout/timeout [2023/2/14 15:34:58] desk page.OnPause [2023/2/14 15:34:58] Year,Month,Day,Hour: 2000 1 16 23 [2023/2/14 15:34:58] Autidelfile...open [2023/2/14 15:34:59] [01-01 18:13:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:34:59] [01-01 18:13:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:00] [01-01 18:13:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:00] [01-01 18:13:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:01] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:01] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:01] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:02] [01-01 18:13:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:02] [01-01 18:13:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:03] [01-01 18:13:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:03] [01-01 18:13:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:04] [01-01 18:13:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:04] [01-01 18:13:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:05] [01-01 18:13:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:05] [01-01 18:13:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:06] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:06] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:06] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:07] [01-01 18:13:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:07] [01-01 18:13:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:08] [01-01 18:13:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:08] [01-01 18:13:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:09] [01-01 18:13:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:09] [01-01 18:13:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:10] [01-01 18:13:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:10] [01-01 18:13:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:11] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:11] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:11] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:12] [01-01 18:13:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:12] [01-01 18:13:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:13] [01-01 18:13:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:13] [01-01 18:13:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:14] [01-01 18:13:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:14] [01-01 18:13:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:15] [01-01 18:13:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:15] [01-01 18:13:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:16] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:16] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:16] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:17] [01-01 18:13:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:17] [01-01 18:13:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:18] [01-01 18:13:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:18] [01-01 18:13:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:19] [01-01 18:13:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:19] [01-01 18:13:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:20] [01-01 18:13:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:20] [01-01 18:13:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:21] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:21] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:21] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:22] [01-01 18:13:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:22] [01-01 18:13:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:23] [01-01 18:13:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:23] [01-01 18:13:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:24] [01-01 18:13:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:24] [01-01 18:13:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:25] [01-01 18:13:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:25] [01-01 18:13:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:26] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:26] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:26] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:27] [01-01 18:13:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:27] [01-01 18:13:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:28] [01-01 18:13:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:28] [01-01 18:13:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:29] [01-01 18:13:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:29] [01-01 18:13:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:30] [01-01 18:14:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:30] [01-01 18:14:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:31] [01-01 18:14:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:31] [01-01 18:14:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:31] [01-01 18:14:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:32] [01-01 18:14:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:32] [01-01 18:14:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:33] [01-01 18:14:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:33] [01-01 18:14:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:34] [01-01 18:14:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:34] [01-01 18:14:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:35] [01-01 18:14:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:35] [01-01 18:14:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:36] [01-01 18:14:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:36] [01-01 18:14:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:36] [01-01 18:14:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:37] [01-01 18:14:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:37] [01-01 18:14:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:38] [01-01 18:14:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:38] [01-01 18:14:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:39] [01-01 18:14:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:39] [01-01 18:14:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:40] [01-01 18:14:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:40] [01-01 18:14:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:41] [01-01 18:14:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:41] [01-01 18:14:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:41] [01-01 18:14:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:42] [01-01 18:14:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:42] [01-01 18:14:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:43] [01-01 18:14:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:43] [01-01 18:14:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:44] [01-01 18:14:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:44] [01-01 18:14:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:45] [01-01 18:14:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:45] [01-01 18:14:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:46] [01-01 18:14:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:46] [01-01 18:14:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:46] [01-01 18:14:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:47] [01-01 18:14:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:47] [01-01 18:14:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:48] [01-01 18:14:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:48] [01-01 18:14:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:49] [01-01 18:14:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:49] [01-01 18:14:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:50] [01-01 18:14:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:50] [01-01 18:14:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:51] [01-01 18:14:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:51] [01-01 18:14:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:51] [01-01 18:14:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:52] [01-01 18:14:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:52] [01-01 18:14:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:53] [01-01 18:14:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:53] [01-01 18:14:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:54] [01-01 18:14:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:54] [01-01 18:14:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:55] [01-01 18:14:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:56] [01-01 18:14:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:56] [01-01 18:14:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:56] [01-01 18:14:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:57] [01-01 18:14:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:57] [01-01 18:14:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:58] [01-01 18:14:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:58] [01-01 18:14:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:59] [01-01 18:14:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:35:59] [01-01 18:14:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:00] [01-01 18:14:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:00] [01-01 18:14:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:01] [01-01 18:14:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:01] [01-01 18:14:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:01] [01-01 18:14:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:02] [01-01 18:14:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:02] [01-01 18:14:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:03] [01-01 18:14:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:03] [01-01 18:14:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:04] [01-01 18:14:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:04] [01-01 18:14:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:05] [01-01 18:14:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:05] [01-01 18:14:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:06] [01-01 18:14:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:06] [01-01 18:14:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:06] [01-01 18:14:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:07] [01-01 18:14:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:07] [01-01 18:14:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:08] [01-01 18:14:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:08] [01-01 18:14:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:09] [01-01 18:14:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:09] [01-01 18:14:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:10] [01-01 18:14:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:10] [01-01 18:14:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:11] [01-01 18:14:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:11] [01-01 18:14:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:11] [01-01 18:14:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:12] [01-01 18:14:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:12] [01-01 18:14:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:13] [01-01 18:14:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:13] [01-01 18:14:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:14] [01-01 18:14:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:14] [01-01 18:14:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:15] [01-01 18:14:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:15] [01-01 18:14:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:16] [01-01 18:14:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:16] [01-01 18:14:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:16] [01-01 18:14:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:17] [01-01 18:14:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:17] [01-01 18:14:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:18] [01-01 18:14:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:18] [01-01 18:14:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:19] [01-01 18:14:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:19] [01-01 18:14:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:20] [01-01 18:14:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:20] [01-01 18:14:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:21] [01-01 18:14:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:21] [01-01 18:14:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:21] [01-01 18:14:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:22] [01-01 18:14:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:22] [01-01 18:14:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:23] [01-01 18:14:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/14 15:36:23] [01-01 18:14:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [END] 2023/2/14 15:36:23
