[2023/2/15 10:41:24] ----TuyaCloudInit [2023/2/15 10:41:24] para.version = 1.3.4 [2023/2/15 10:41:24] para.DbPath = /data/cloud [2023/2/15 10:41:24] gTuyaCloudInitConfig->DbPath = /data/cloud/ [2023/2/15 10:41:24] TUYA_Init [2023/2/15 10:41:24] mode = 0 [2023/2/15 10:41:24] --mode = 1 [2023/2/15 10:41:24] ---mode = 1 [2023/2/15 10:41:24] Dbg:SDK Version:< TUYA IOT SDK V:5.3.33 BS:40.00_PT:2.2_LAN:3.4_CAD:1.0.4_CD:1.0.0 > [2023/2/15 10:41:24] < BUILD AT:2023_02_14_11_50_44 BY ci_manage FOR ty_ipc_wr_wl_linux_sdk AT arm-anykav500-linux-gnueabi > [2023/2/15 10:41:24] IOT DEFS < WIFI_GW:1 DEBUG:1 KV_FILE:1 SHUTDOWN_MODE:1 LITTLE_END:1 TLS_MODE:4 ENABLE_CLOUD_OPERATION:1 OPERATING_SYSTEM:100 ENABLE_SYS_RPC:0 RELIABLE_TRANSFER:0 ENABLE_LAN_ENCRYPTION:1 ENABLE_LAN_LINKAGE:0 ENABLE_LAN_DEV:0 > [2023/2/15 10:41:24] [2023/2/15 10:41:24] [2023/2/15 10:41:24] ---tuya_ipc_app_start [2023/2/15 10:41:24] Dbg:channel_enable:1 1 0 [2023/2/15 10:41:24] Dbg:fps:25 [2023/2/15 10:41:24] Dbg:gop:30 [2023/2/15 10:41:24] Dbg:bitrate:1536 kbps [2023/2/15 10:41:24] Dbg:video_main_width:640 [2023/2/15 10:41:24] Dbg:video_main_height:280 [2023/2/15 10:41:24] Dbg:video_freq:90000 [2023/2/15 10:41:24] Dbg:video_codec:2 [2023/2/15 10:41:24] Dbg:audio_codec:106 [2023/2/15 10:41:24] Dbg:audio_sample:8000 [2023/2/15 10:41:24] Dbg:audio_databits:16 [2023/2/15 10:41:24] Dbg:audio_channel:0 [2023/2/15 10:41:24] ---tuya_ipc_init_sdk [2023/2/15 10:41:24] Dbg:tuya_ipc_sdk_mqtt_online_proc thread start success [2023/2/15 10:41:24] [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /data/cloud [2023/2/15 10:41:24] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/data/cloud [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/data/cloud [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[¡ê¡éUS??kR? [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1012] both file exist [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:555] head check success [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:155] key tls_ca0 is invaild, don't crc check [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:155] key tls_ca_cnt is invaild, don't crc check [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success [2023/2/15 10:41:24] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success. [2023/2/15 10:41:24] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ... [2023/2/15 10:41:24] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success [2023/2/15 10:41:24] [01-01 18:12:15 TUYA E][log_seq.c:863] open err [2023/2/15 10:41:24] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat [2023/2/15 10:41:24] ---pRunInfo->debug_info.log_level = 4 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][uni_log.c:197] SetLogManageAttr 4 [2023/2/15 10:41:24] ---TUYA_APP_Init_Ring_Buffer [2023/2/15 10:41:24] Dbg:init ring buffer Channel:0 Enable:1 [2023/2/15 10:41:24] Dbg:video_bitrate 1536, video_fps 25 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr0 bitrate:1536 fps:25 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 1966080 bytes for ch0st0tr0, max frame size 294912 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr0 size:1966080 nodes:250 [2023/2/15 10:41:24] Dbg:init ring buffer success. channel:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:1 Enable:1 [2023/2/15 10:41:24] Dbg:video_bitrate 512, video_fps 25 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr1 bitrate:512 fps:25 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 655360 bytes for ch0st0tr1, max frame size 98304 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:250 [2023/2/15 10:41:24] Dbg:init ring buffer success. channel:1 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:2 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:3 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:4 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:5 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:6 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:7 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:8 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:9 Enable:1 [2023/2/15 10:41:24] Dbg:audio_sample 8000, audio_databits 16, audio_fps 25 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:536] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:568] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:588] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250 [2023/2/15 10:41:24] Dbg:init ring buffer success. channel:9 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:10 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:11 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:12 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:13 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:14 Enable:0 [2023/2/15 10:41:24] Dbg:init ring buffer Channel:15 Enable:0 [2023/2/15 10:41:24] pRunInfo->net_info.connect_mode = 1 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:224 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success! [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1758] Last reset reason: 255 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:224 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db [2023/2/15 10:41:24] ifconfig: wlan0: error fetching interface information: Device not found [2023/2/15 10:41:24] WIFI Get MAC 64-E9-9A-BE-70-FE [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1122] serial_no:64e99abe70fe [2023/2/15 10:41:24] Set Country Code:(null) [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1153] gw_cntl.gw_wsm.stat:1 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:3 wf_start_md [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:648] <__gw_upd_nc_type> bcustom_mode:0, old_wf_start_mode: 0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1345] gw_cntl->gw_wsm.nc_tp:2 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1346] gw_cntl->gw_wsm.md:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:416 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][ws_db_gw.c:515] gw_di read success [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:10 is_stride [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:is_stride find value.Len:16 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:770] stride from flash: 0. [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:777] no actived, no upgrade:1 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1212] gw_cntl.gw_if.abi:0 input:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1213] gw_cntl.gw_if.product_key:nfkr4o148myon57c, input:nfkr4o148myon57c [2023/2/15 10:41:24] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1214] gw_cntl.gw_if.tp:0, input:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:12 gw_ai [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][ws_db_gw.c:640] gw_ai read success [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_network.c:417] set_dns_region:0 [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216] [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36] [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165] [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[42.192.30.165] [2023/2/15 10:41:24] [01-01 18:12:15 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108] [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1780] enter success_proc [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat [2023/2/15 10:41:25] ifconfig: wlan0: error fetching interface information: Device not found [2023/2/15 10:41:25] WIFI Get MAC 00-00-00-00-00-00 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1064] nc_tp:2, md:0 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_iot_wifi_api.c:415] register wifi network monitor. interval:1 [2023/2/15 10:41:25] Dbg:tuya ipc sdk start is complete [2023/2/15 10:41:25] [2023/2/15 10:41:25] @@@@@@@@@@@@@@@@ TUYA_APP_Init_Stream_Storage [2023/2/15 10:41:25] Dbg:Init Stream_Storage SD:/mnt/ [2023/2/15 10:41:25] Init tuya_ipc_ss_init [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1976] Init stream_storage.base_path:/mnt/ v:2 a:106, max event per day 500 skills 0 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:2117] stream storage task init success [2023/2/15 10:41:25] [01-01 18:12:15 TUYA E][tuya_ipc_stream_storage.c:2188] the ss mgr not inited [2023/2/15 10:41:25] Dbg:local storage init result is 0 [2023/2/15 10:41:25] [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init [2023/2/15 10:41:25] [2023/2/15 10:41:25] [2023/2/15 10:41:25] Web_Init222222 23 [2023/2/15 10:41:25] [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1 [2023/2/15 10:41:25] Exec Cmd:ifconfig wlan0 up [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1547] SD task begin___ [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1561] report sd status 0 -> 1 [2023/2/15 10:41:25] [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][smart_frame.c:3473] dp filtered, dev no act [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][uni_fs.c:35] mkdir_all:/mnt/DCIM [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:776] stream storage seize 1275648 bytes memory for media data, slice duration 10 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1532] stream storage with SD init success [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1890] write_mode set 0 -> 1 [2023/2/15 10:41:25] [01-01 18:12:15 TUYA D][tuya_ipc_stream_storage.c:1282] stream_storage thread start [2023/2/15 10:41:25] ifconfig: SIOCGIFFLAGS: No such device [2023/2/15 10:41:25] Exec Cmd:ifconfig wlan0 down [2023/2/15 10:41:25] ifconfig: SIOCGIFFLAGS: No such device [2023/2/15 10:41:25] Exec Cmd:ifconfig wlan0 up [2023/2/15 10:41:25] ifconfig: SIOCGIFFLAGS: No such device [2023/2/15 10:41:25] WIFI Set Mode 3 [2023/2/15 10:41:25] IDS_Wifi_StartApMode ssid =SmartLife-0000,password = [2023/2/15 10:41:25] ---Start AP SSID:SmartLife-0000,PASSWORD: [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-0000 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:18432,priority:5 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0 [2023/2/15 10:41:25] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat [2023/2/15 10:41:25] [Lua] ########## lua start [2023/2/15 10:41:25] IDS_Wifi_DoStartAp:ssid = SmartLife-0000,password = 12345678 [2023/2/15 10:41:25] Wifi_AP_Init:ssid = SmartLife-0000,psk = 12345678 [2023/2/15 10:41:25] system sed -ri 's/ssid=.*/ssid=SmartLife-0000/' /data/cloud/hostapd.conf ok ! [2023/2/15 10:41:25] system sed -ri 's/wpa_passphrase=.*/wpa_passphrase=12345678/' /data/cloud/hostapd.conf ok ! [2023/2/15 10:41:25] killall: wpa_supplicant: no process killed [2023/2/15 10:41:25] killall: udhcpc: no process killed [2023/2/15 10:41:26] [01-01 18:12:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:26] [01-01 18:12:16 TUYA D][tuya_iot_wifi_api.c:381] wifi netstat changed to:2 -->> [2023/2/15 10:41:26] Dbg:Net status change to:2 [2023/2/15 10:41:26] [01-01 18:12:16 TUYA D][tuya_iot_wifi_api.c:384] wifi netstat changed to:2 <<-- [2023/2/15 10:41:26] killall: udhcpd: no process killed [2023/2/15 10:41:26] killall: hostapd: no process killed [2023/2/15 10:41:26] ifconfig: SIOCGIFFLAGS: No such device [2023/2/15 10:41:26] rmmod: can't unload module 'rtl8188ftv': No such file or directory [2023/2/15 10:41:26] rmmod: can't unload module 'ak_hcd': No such file or directory [2023/2/15 10:41:26] [01-01 18:12:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:27] [01-01 18:12:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:27] Fail to get key mask bitmap. [2023/2/15 10:41:27] Fail to get tr keyboard back ground bitmap. [2023/2/15 10:41:27] Fail to get span keyboard back ground bitmap. [2023/2/15 10:41:27] [01-01 18:12:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:27] softkeyboard/softkeywindow.c:441 IME_LANGUAGE_UNKNOWN 2 [2023/2/15 10:41:27] [2023/2/15 10:41:27] [2023/2/15 10:41:27] Web_Init 4 [2023/2/15 10:41:27] [2023/2/15 10:41:28] [01-01 18:12:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:28] [01-01 18:12:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:28] load img welcome.png [2023/2/15 10:41:29] [01-01 18:12:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:29] [Lua] wificfg.MODE.get() = 1 [2023/2/15 10:41:29] [2023/2/15 10:41:29] uart_write:[fe 04 04 08 ] [2023/2/15 10:41:29] [uart Send head[1]:0xfe, len[2]:4, cmd[3]:0x4, chksum[4]:0x8] [2023/2/15 10:41:29] [2023/2/15 10:41:29] uart_write:[fe 05 05 10 1a ] [2023/2/15 10:41:29] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x10, chksum[5]:0x1a] [2023/2/15 10:41:29] [2023/2/15 10:41:29] uart_write:[fe 05 05 01 0b ] [2023/2/15 10:41:29] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x1, chksum[5]:0xb] [2023/2/15 10:41:29] [2023/2/15 10:41:29] uart_write:[fe 05 05 02 0c ] [2023/2/15 10:41:29] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x2, chksum[5]:0xc] [2023/2/15 10:41:29] OnNewFileChange true true false [2023/2/15 10:41:29] [2023/2/15 10:41:29] uart_write:[fe 05 05 13 1d ] [2023/2/15 10:41:29] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x13, chksum[5]:0x1d] [2023/2/15 10:41:29] [2023/2/15 10:41:29] uart_write:[fe 05 00 01 06 ] [2023/2/15 10:41:29] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x0, data[4]:0x1, chksum[5]:0x6] [2023/2/15 10:41:29] [2023/2/15 10:41:29] uart_write:[fe 08 06 02 02 02 02 16 ] [2023/2/15 10:41:29] [uart Send head[1]:0xfe, len[2]:8, cmd[3]:0x6, data[4]:0x2, data[5]:0x2, data[6]:0x2, data[7]:0x2, chksum[8]:0x16] [2023/2/15 10:41:29] [Lua] @@@@@@@@@@ welcome open [2023/2/15 10:41:29] uart.OnRcv 254.0 7.0 4.0 23.0 17.0 [2023/2/15 10:41:29] TotalLen = 7 [2023/2/15 10:41:29] cmd:data = 4.0 table: 0x2d50ba0 [2023/2/15 10:41:29] -----cmd:data = 4.0 table: 0x2d50ba0 [2023/2/15 10:41:29] [Lua] mcu ver: 20230109 [2023/2/15 10:41:29] [01-01 18:12:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:30] [01-01 18:12:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:30] [01-01 18:12:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:30] [01-01 18:12:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:31] [01-01 18:12:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:31] [01-01 18:12:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:31] [2023/2/15 10:41:32] vdpids login: [01-01 18:12:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:32] Configuration file: /data/cloud/hostapd.conf [2023/2/15 10:41:32] rfkill: Cannot open RFKILL control device [2023/2/15 10:41:32] Using interface wlan0 with hwaddr c8:02:8f:d5:ab:12 and ssid "SmartLife-0000" [2023/2/15 10:41:32] [01-01 18:12:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:32] random: Only 15/20 bytes of strong random data available [2023/2/15 10:41:32] random: Not enough entropy pool available for secure operations [2023/2/15 10:41:32] WPA: Not enough entropy in random pool for secure operations - update keys later when the first station connects [2023/2/15 10:41:33] rwlan0: interface state UNINITIALIZED->ENABLED [2023/2/15 10:41:33] wlan0: AP-ENABLED [2023/2/15 10:41:33] osystem wifi_install.sh rtl8188 ap ok ! [2023/2/15 10:41:33] [01-01 18:12:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:33] ot[01-01 18:12:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:33] [2023/2/15 10:41:34] Password: [01-01 18:12:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:34] [01-01 18:12:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:35] [01-01 18:12:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:35] [2023/2/15 10:41:35] login[605]: root login on 'ttySAK0' [2023/2/15 10:41:35] welcome to file system [2023/2/15 10:41:35] [root@vdpids ~]$ [01-01 18:12:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:35] [01-01 18:12:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:36] [01-01 18:12:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:36] [01-01 18:12:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:37] [01-01 18:12:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:37] [01-01 18:12:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:38] [01-01 18:12:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:38] [Lua] [lua] page.Open desk/desk [2023/2/15 10:41:38] [2023/2/15 10:41:38] uart_write:[fe 05 05 13 1d ] [2023/2/15 10:41:38] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x5, data[4]:0x13, chksum[5]:0x1d] [2023/2/15 10:41:38] [Lua] GetUnReadCnt 25 4 [2023/2/15 10:41:38] [2023/2/15 10:41:38] uart_write:[fe 05 03 01 09 ] [2023/2/15 10:41:38] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x3, data[4]:0x1, chksum[5]:0x9] [2023/2/15 10:41:38] [2023/2/15 10:41:38] uart_write:[fe 08 35 02 02 02 02 45 ] [2023/2/15 10:41:38] [uart Send head[1]:0xfe, len[2]:8, cmd[3]:0x35, data[4]:0x2, data[5]:0x2, data[6]:0x2, data[7]:0x2, chksum[8]:0x45] [2023/2/15 10:41:38] Cloud_SetTimeZone [2023/2/15 10:41:38] [2023/2/15 10:41:38] uart_write:[fe 05 66 01 6c ] [2023/2/15 10:41:38] [uart Send head[1]:0xfe, len[2]:5, cmd[3]:0x66, data[4]:0x1, chksum[5]:0x6c] [2023/2/15 10:41:38] [2023/2/15 10:41:38] uart_write:[fe 06 67 00 00 6d ] [2023/2/15 10:41:38] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x67, data[4]:0x0, data[5]:0x0, chksum[6]:0x6d] [2023/2/15 10:41:38] [2023/2/15 10:41:38] uart_write:[fe 06 36 01 00 3d ] [2023/2/15 10:41:38] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x36, data[4]:0x1, data[5]:0x0, chksum[6]:0x3d] [2023/2/15 10:41:38] [2023/2/15 10:41:38] uart_write:[fe 06 37 01 00 3e ] [2023/2/15 10:41:38] [uart Send head[1]:0xfe, len[2]:6, cmd[3]:0x37, data[4]:0x1, data[5]:0x0, chksum[6]:0x3e] [2023/2/15 10:41:38] [01-01 18:12:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:39] [01-01 18:12:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:39] CurPage.name desk/desk [2023/2/15 10:41:39] [01-01 18:12:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:39] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 10:41:40] [01-01 18:12:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:40] [01-01 18:12:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:40] [01-01 18:12:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:40] ifconfig eth0 down [2023/2/15 10:41:41] [root@vdpids ~]$ [01-01 18:12:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:41] [01-01 18:12:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:42] [01-01 18:12:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:42] [01-01 18:12:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:43] ifc[01-01 18:12:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:43] onfi[01-01 18:12:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:43] g [2023/2/15 10:41:43] lo Link encap:Local Loopback [2023/2/15 10:41:43] inet addr:127.0.0.1 Mask:255.0.0.0 [2023/2/15 10:41:43] UP LOOPBACK RUNNING MTU:65536 Metric:1 [2023/2/15 10:41:43] RX packets:0 errors:0 dropped:0 overruns:0 frame:0 [2023/2/15 10:41:43] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/15 10:41:43] collisions:0 txqueuelen:1 [2023/2/15 10:41:43] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) [2023/2/15 10:41:43] [2023/2/15 10:41:43] wlan0 Link encap:Ethernet HWaddr C8:02:8F:D5:AB:12 [2023/2/15 10:41:43] inet addr:192.168.231.1 Bcast:192.168.231.255 Mask:255.255.255.0 [2023/2/15 10:41:43] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 [2023/2/15 10:41:43] RX packets:19 errors:0 dropped:5 overruns:0 frame:0 [2023/2/15 10:41:43] TX packets:13 errors:0 dropped:0 overruns:0 carrier:0 [2023/2/15 10:41:43] collisions:0 txqueuelen:1000 [2023/2/15 10:41:43] RX bytes:2659 (2.5 KiB) TX bytes:2999 (2.9 KiB) [2023/2/15 10:41:43] [2023/2/15 10:41:44] [root@vdpids ~]$ [01-01 18:12:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:44] [01-01 18:12:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:45] [01-01 18:12:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:45] [01-01 18:12:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:45] [01-01 18:12:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:46] [01-01 18:12:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:46] [01-01 18:12:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:47] [01-01 18:12:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:47] [01-01 18:12:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:48] [01-01 18:12:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:48] [01-01 18:12:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:49] [01-01 18:12:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:49] [01-01 18:12:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:50] [01-01 18:12:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:50] [01-01 18:12:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:50] [01-01 18:12:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:51] [01-01 18:12:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:51] [01-01 18:12:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:52] [01-01 18:12:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:52] [01-01 18:12:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:53] [01-01 18:12:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:53] [01-01 18:12:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:54] [01-01 18:12:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:54] [01-01 18:12:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:55] [01-01 18:12:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:55] [01-01 18:12:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:55] [01-01 18:12:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:56] [01-01 18:12:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:56] [01-01 18:12:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:57] [01-01 18:12:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:57] [01-01 18:12:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:58] [01-01 18:12:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:58] [01-01 18:12:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:59] [01-01 18:12:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:59] [01-01 18:12:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:41:59] [01-01 18:12:50 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 10:42:00] [01-01 18:12:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:00] [01-01 18:12:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:00] [01-01 18:12:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:01] [01-01 18:12:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:01] [01-01 18:12:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:02] [01-01 18:12:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:02] [01-01 18:12:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:03] [01-01 18:12:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:03] [01-01 18:12:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:04] [01-01 18:12:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:04] [01-01 18:12:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:05] [01-01 18:12:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:05] [01-01 18:12:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:05] [01-01 18:12:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:06] [01-01 18:12:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:06] [01-01 18:12:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:07] [01-01 18:12:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:07] [01-01 18:12:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:08] [01-01 18:12:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:08] [01-01 18:12:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:09] [01-01 18:13:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:09] [01-01 18:13:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:10] [01-01 18:13:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:10] [01-01 18:13:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:10] [01-01 18:13:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:11] [01-01 18:13:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:11] [01-01 18:13:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:12] [01-01 18:13:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:12] [01-01 18:13:03 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:13] [01-01 18:13:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:13] [01-01 18:13:04 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:13] [01-01 18:13:04 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:13] [01-01 18:13:04 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:14] [01-01 18:13:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:14] [01-01 18:13:05 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:15] [01-01 18:13:06 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:15] [01-01 18:13:06 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:15] [01-01 18:13:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:15] [01-01 18:13:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:15] [01-01 18:13:06 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:16] [01-01 18:13:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:16] [01-01 18:13:07 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:17] [01-01 18:13:08 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:17] [01-01 18:13:08 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:17] [01-01 18:13:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:17] [01-01 18:13:08 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:18] [01-01 18:13:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:18] [01-01 18:13:09 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:19] [01-01 18:13:10 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:19] [01-01 18:13:10 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:19] [01-01 18:13:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:19] [01-01 18:13:10 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:19] [01-01 18:13:10 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 10:42:20] [01-01 18:13:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:20] [01-01 18:13:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:20] [01-01 18:13:11 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:21] [01-01 18:13:12 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:21] [01-01 18:13:12 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:21] [01-01 18:13:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:21] [01-01 18:13:12 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:22] [01-01 18:13:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:22] [01-01 18:13:13 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:23] [01-01 18:13:14 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:23] [01-01 18:13:14 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:23] [01-01 18:13:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:23] [01-01 18:13:14 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:24] [01-01 18:13:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:24] [01-01 18:13:15 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:25] [01-01 18:13:16 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:25] [01-01 18:13:16 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:25] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:25] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:25] [01-01 18:13:16 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:26] [01-01 18:13:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:26] [01-01 18:13:17 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:27] [01-01 18:13:18 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:27] [01-01 18:13:18 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:27] [01-01 18:13:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:27] [01-01 18:13:18 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:28] [01-01 18:13:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:28] [01-01 18:13:19 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:29] [01-01 18:13:20 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:29] [01-01 18:13:20 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:29] [01-01 18:13:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:29] [01-01 18:13:20 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:30] [01-01 18:13:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:30] [01-01 18:13:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:30] [01-01 18:13:21 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:31] [01-01 18:13:22 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:31] [01-01 18:13:22 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:31] [01-01 18:13:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:31] [01-01 18:13:22 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:32] [01-01 18:13:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:32] [01-01 18:13:23 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:33] [01-01 18:13:24 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:33] [01-01 18:13:24 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:33] [01-01 18:13:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:33] [01-01 18:13:24 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:34] [01-01 18:13:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:34] [01-01 18:13:25 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:35] [01-01 18:13:26 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:35] [01-01 18:13:26 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:35] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:35] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:35] [01-01 18:13:26 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:36] [01-01 18:13:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:37] [01-01 18:13:27 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:37] [01-01 18:13:28 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:37] [01-01 18:13:28 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:37] [01-01 18:13:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:38] [01-01 18:13:28 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:38] systimeout.c 83: Time Out[sysinfo]! [2023/2/15 10:42:38] [Lua] [lua] page.Open timeout/timeout [2023/2/15 10:42:38] desk page.OnPause [2023/2/15 10:42:38] Year,Month,Day,Hour: 2000 1 17 18 [2023/2/15 10:42:38] Autidelfile...open [2023/2/15 10:42:38] [01-01 18:13:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:39] [01-01 18:13:29 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:39] [01-01 18:13:30 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:39] [01-01 18:13:30 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:39] [01-01 18:13:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:39] [01-01 18:13:30 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 10:42:40] [01-01 18:13:30 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:40] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:40] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:41] [01-01 18:13:31 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:41] [01-01 18:13:32 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:41] [01-01 18:13:32 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:41] [01-01 18:13:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:42] [01-01 18:13:32 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:42] [01-01 18:13:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:43] [01-01 18:13:33 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:43] [01-01 18:13:34 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:43] [01-01 18:13:34 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:43] [01-01 18:13:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:44] [01-01 18:13:34 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:44] [01-01 18:13:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:45] [01-01 18:13:35 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:45] [01-01 18:13:36 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:45] [01-01 18:13:36 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:45] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:45] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:46] [01-01 18:13:36 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:46] [01-01 18:13:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:47] [01-01 18:13:37 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:47] [01-01 18:13:38 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:47] [01-01 18:13:38 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:47] [01-01 18:13:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:48] [01-01 18:13:38 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:48] [01-01 18:13:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:49] [01-01 18:13:39 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:49] [01-01 18:13:40 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:49] [01-01 18:13:40 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:49] [01-01 18:13:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:50] [01-01 18:13:40 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:50] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:50] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:51] [01-01 18:13:41 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:51] [01-01 18:13:42 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:51] [01-01 18:13:42 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:51] [01-01 18:13:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:52] [01-01 18:13:42 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:52] [01-01 18:13:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:53] [01-01 18:13:43 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:53] [01-01 18:13:44 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:53] [01-01 18:13:44 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:53] [01-01 18:13:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:54] [01-01 18:13:44 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:54] [01-01 18:13:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:55] [01-01 18:13:45 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:55] [01-01 18:13:46 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:55] [01-01 18:13:46 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:55] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:55] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:56] [01-01 18:13:46 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:56] [01-01 18:13:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:57] [01-01 18:13:47 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:57] [01-01 18:13:48 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:57] [01-01 18:13:48 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:57] [01-01 18:13:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:58] [01-01 18:13:48 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:58] [01-01 18:13:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:59] [01-01 18:13:49 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:42:59] [01-01 18:13:50 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:42:59] [01-01 18:13:50 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:42:59] [01-01 18:13:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:00] [01-01 18:13:50 TUYA D][tuya_devos_health.c:30] feed watchdog [2023/2/15 10:43:00] [01-01 18:13:50 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:00] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:00] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:01] [01-01 18:13:51 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:01] [01-01 18:13:52 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:43:01] [01-01 18:13:52 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:43:01] [01-01 18:13:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:02] [01-01 18:13:52 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:02] [01-01 18:13:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:03] [01-01 18:13:53 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:03] [01-01 18:13:54 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:43:03] [01-01 18:13:54 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:43:03] [01-01 18:13:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:04] [01-01 18:13:54 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:04] [01-01 18:13:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:05] [01-01 18:13:55 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:05] [01-01 18:13:56 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:43:05] [01-01 18:13:56 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:43:05] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:05] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:06] [01-01 18:13:56 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:06] [01-01 18:13:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:07] [01-01 18:13:57 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:07] [01-01 18:13:58 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:43:07] [01-01 18:13:58 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:43:07] [01-01 18:13:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:08] [01-01 18:13:58 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:08] [01-01 18:13:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:09] [01-01 18:13:59 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:09] [01-01 18:14:00 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:43:09] [01-01 18:14:00 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:43:09] [01-01 18:14:00 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:10] [01-01 18:14:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:10] [01-01 18:14:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:10] [01-01 18:14:01 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:11] [01-01 18:14:02 TUYA E][tuya_devos_netlink.c:788] ======get_wf_gw_nw_status, mode:3, nc_tp:2 [2023/2/15 10:43:11] [01-01 18:14:02 TUYA D][ap_netcfg.c:191] recv_data 97 [2023/2/15 10:43:11] [01-01 18:14:02 TUYA D][ap_netcfg.c:372] Frame Type Cannot Parse:1 [2023/2/15 10:43:11] [2023/2/15 10:43:11] Connection closed. [2023/2/15 10:43:11] [2023/2/15 10:43:11] Disconnected from remote host(43) at 10:43:11. [2023/2/15 10:43:11] [2023/2/15 10:43:11] Type `help' to learn how to use Xshell prompt.
