#include "tuya_iot_config.h"
#define MBEDTLS_CONFIG_H_TY_ECC_PSK
#define TUYA_ECP_MUL_COMB_OPTIM 1 //打开ECP点乘优化
//#define TUYA_ECP_COMB_DEBUG 1 //打印预处理数据,新增曲线时需要
#define TUYA_ECP_MUL_COMB_ROM_TABLES 1 //使用ROM代替RAM
#define TUYA_TLS_DEBUG_THRDSHOLD 5 //TLS 调试等级
//#define MBEDTLS_ECP_FIXED_POINT_OPTIM 0 //调试性能使用
#define TUYA_TLS_DYNAMIC_MEMORY_ALLOCATION 1 //允许连接单独设置BUFF大小
#define MBEDTLS_AES_ALT
/** * \def MBEDTLS_AES_ALT * * MBEDTLS__MODULE_NAME__ALT: Uncomment a macro to let mbed TLS use your * alternate core implementation of a symmetric crypto, an arithmetic or hash * module (e.g. platform specific assembly optimized implementations). Keep * in mind that the function prototypes should remain the same. * * This replaces the whole module. If you only want to replace one of the * functions, use one of the MBEDTLS__FUNCTION_NAME__ALT flags. * * Example: In case you uncomment MBEDTLS_AES_ALT, mbed TLS will no longer * provide the "struct mbedtls_aes_context" definition and omit the base * function declarations and implementations. "aes_alt.h" will be included from * "aes.h" to include the new function definitions. * * Uncomment a macro to enable alternate implementation of the corresponding * module. * * \warning MD2, MD4, MD5, ARC4, DES and SHA-1 are considered weak and their * use constitutes a security risk. If possible, we recommend * avoiding dependencies on them, and considering stronger message * digests and ciphers instead. * */
#define MBEDTLS_CAMELLIA_SMALL_MEMORY
/** * \def MBEDTLS_CAMELLIA_SMALL_MEMORY * * Use less ROM for the Camellia implementation (saves about 768 bytes). * * Uncomment this macro to use less memory for Camellia. */
#define MBEDTLS_ECP_DP_SECP192R1_ENABLED
/** * \def MBEDTLS_ECP_DP_SECP192R1_ENABLED * * MBEDTLS_ECP_XXXX_ENABLED: Enables specific curves within the Elliptic Curve * module. By default all supported curves are enabled. * * Comment macros to disable the curve and functions for it */
#define MBEDTLS_ECP_DP_SECP224R1_ENABLED
#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
#define MBEDTLS_ECP_DP_SECP521R1_ENABLED
#define MBEDTLS_ECP_DP_SECP192K1_ENABLED
#define MBEDTLS_ECP_DP_SECP224K1_ENABLED
#define MBEDTLS_ECP_DP_SECP256K1_ENABLED
#define MBEDTLS_ECP_DP_BP256R1_ENABLED
#define MBEDTLS_ECP_DP_BP384R1_ENABLED
#define MBEDTLS_ECP_DP_BP512R1_ENABLED
#define MBEDTLS_ECP_DP_CURVE25519_ENABLED
#define MBEDTLS_ECP_DP_CURVE448_ENABLED
#define MBEDTLS_KEY_EXCHANGE_PSK_ENABLED
/** * \def MBEDTLS_KEY_EXCHANGE_PSK_ENABLED * * Enable the PSK based ciphersuite modes in SSL / TLS. * * This enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_3DES_EDE_CBC_SHA * MBEDTLS_TLS_PSK_WITH_RC4_128_SHA */
#define MBEDTLS_PK_PARSE_EC_EXTENDED
/** * \def MBEDTLS_PK_PARSE_EC_EXTENDED * * Enhance support for reading EC keys using variants of SEC1 not allowed by * RFC 5915 and RFC 5480. * * Currently this means parsing the SpecifiedECDomain choice of EC * parameters (only known groups are supported, not arbitrary domains, to * avoid validation issues). * * Disable if you only need to support RFC 5915 + 5480 key formats. */
#define MBEDTLS_GENPRIME
/** * \def MBEDTLS_GENPRIME * * Enable the prime-number generation code. * * Requires: MBEDTLS_BIGNUM_C */
#define MBEDTLS_PK_RSA_ALT_SUPPORT
/** * \def MBEDTLS_PK_RSA_ALT_SUPPORT * * Support external private RSA keys (eg from a HSM) in the PK layer. * * Comment this macro to disable support for external private RSA keys. */
#define MBEDTLS_PKCS1_V15
#define MBEDTLS_PKCS1_V21
#define MBEDTLS_SSL_FALLBACK_SCSV
/** * \def MBEDTLS_SSL_FALLBACK_SCSV * * Enable support for FALLBACK_SCSV (draft-ietf-tls-downgrade-scsv-00). * * For servers, it is recommended to always enable this, unless you support * only one version of TLS, or know for sure that none of your clients * implements a fallback strategy. * * For clients, you only need this if you're using a fallback strategy, which * is not recommended in the first place, unless you absolutely need it to * interoperate with buggy (version-intolerant) servers. * * Comment this macro to disable support for FALLBACK_SCSV */
#define MBEDTLS_AES_C
/** * \def MBEDTLS_AES_C * * Enable the AES block cipher. * * Module: library/aes.c * Caller: library/cipher.c * library/pem.c * library/ctr_drbg.c * * This module enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * * PEM_PARSE uses AES for decrypting encrypted keys. */
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_ASN1_WRITE_C
/** * \def MBEDTLS_ASN1_WRITE_C * * Enable the generic ASN1 writer. * * Module: library/asn1write.c * Caller: library/ecdsa.c * library/pkwrite.c * library/x509_create.c * library/x509write_crt.c * library/x509write_csr.c */
#define MBEDTLS_BASE64_C
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CCM_C
/** * \def MBEDTLS_CCM_C * * Enable the Counter with CBC-MAC (CCM) mode for 128-bit block cipher. * * Module: library/ccm.c * * Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C * * This module enables the AES-CCM ciphersuites, if other requisites are * enabled as well. */
#define MBEDTLS_CIPHER_C
#define MBEDTLS_DHM_C
/** * \def MBEDTLS_DHM_C * * Enable the Diffie-Hellman-Merkle module. * * Module: library/dhm.c * Caller: library/ssl_cli.c * library/ssl_srv.c * * This module is used by the following key exchanges: * DHE-RSA, DHE-PSK * * \warning Using DHE constitutes a security risk as it * is not possible to validate custom DH parameters. * If possible, it is recommended users should consider * preferring other methods of key exchange. * See dhm.h for more details. * */
#define MBEDTLS_ECDH_C
#define MBEDTLS_ECDSA_C
/** * \def MBEDTLS_ECDSA_C * * Enable the elliptic curve DSA library. * * Module: library/ecdsa.c * Caller: * * This module is used by the following key exchanges: * ECDHE-ECDSA * * Requires: MBEDTLS_ECP_C, MBEDTLS_ASN1_WRITE_C, MBEDTLS_ASN1_PARSE_C */
#define MBEDTLS_ECP_C
#define MBEDTLS_MD_C
#define MBEDTLS_MD5_C
#define MBEDTLS_OID_C
#define MBEDTLS_PEM_PARSE_C
/** * \def MBEDTLS_PEM_PARSE_C * * Enable PEM decoding / parsing. * * Module: library/pem.c * Caller: library/dhm.c * library/pkparse.c * library/x509_crl.c * library/x509_crt.c * library/x509_csr.c * * Requires: MBEDTLS_BASE64_C * * This modules adds support for decoding / parsing PEM files. */
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_PK_WRITE_C
/** * \def MBEDTLS_PK_WRITE_C * * Enable the generic public (asymetric) key writer. * * Module: library/pkwrite.c * Caller: library/x509write.c * * Requires: MBEDTLS_PK_C * * Uncomment to enable generic public key write functions. */
#define MBEDTLS_PKCS5_C
#define MBEDTLS_PKCS12_C
#define MBEDTLS_PLATFORM_C
#define MBEDTLS_RSA_C
#define MBEDTLS_SHA1_C
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_VERSION_C
#define MBEDTLS_X509_USE_C
#define MBEDTLS_X509_CSR_PARSE_C
/** * \def MBEDTLS_X509_CSR_PARSE_C * * Enable X.509 Certificate Signing Request (CSR) parsing. * * Module: library/x509_csr.c * Caller: library/x509_crt_write.c * * Requires: MBEDTLS_X509_USE_C * * This module is used for reading X.509 certificate request. */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 1024 /**< Maxium fragment length in bytes, determines the size of each of the two internal I/O buffers */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384
#define MBEDTLS_SSL_IN_CONTENT_LEN (ssl->in_content_len)
#define MBEDTLS_SSL_OUT_CONTENT_LEN (ssl->out_content_len)
#define MBEDTLS_TLS_DEFAULT_ALLOW_SHA1_IN_KEY_EXCHANGE
/** * Allow SHA-1 in the default TLS configuration for TLS 1.2 handshake * signature and ciphersuite selection. Without this build-time option, SHA-1 * support must be activated explicitly through mbedtls_ssl_conf_sig_hashes. * The use of SHA-1 in TLS <= 1.1 and in HMAC-SHA-1 is always allowed by * default. At the time of writing, there is no practical attack on the use * of SHA-1 in handshake signatures, hence this option is turned on by default * to preserve compatibility with existing peers, but the general * warning applies nonetheless: * * \warning SHA-1 is considered a weak message digest and its use constitutes * a security risk. If possible, we recommend avoiding dependencies * on it, and considering stronger message digests instead. * */
