#include "config.h"
#include "config.h"
#include MBEDTLS_CONFIG_FILE
#include "bignum.h"
#include "bignum.h"
#include "md.h"
#include "md.h"
#include "threading.h"
#include "rsa_alt.h"
#define MBEDTLS_RSA_H
#define MBEDTLS_ERR_RSA_BAD_INPUT_DATA -16512 /**< Bad input parameters to function. */
/* * RSA Error codes */
#define MBEDTLS_ERR_RSA_INVALID_PADDING -16640 /**< Input data contains invalid padding and is rejected. */
#define MBEDTLS_ERR_RSA_KEY_GEN_FAILED -16768 /**< Something failed during generation of a key. */
#define MBEDTLS_ERR_RSA_KEY_CHECK_FAILED -16896 /**< Key failed to pass the validity check of the library. */
#define MBEDTLS_ERR_RSA_PUBLIC_FAILED -17024 /**< The public key operation failed. */
#define MBEDTLS_ERR_RSA_PRIVATE_FAILED -17152 /**< The private key operation failed. */
#define MBEDTLS_ERR_RSA_VERIFY_FAILED -17280 /**< The PKCS#1 verification failed. */
#define MBEDTLS_ERR_RSA_OUTPUT_TOO_LARGE -17408 /**< The output buffer for decryption is not large enough. */
#define MBEDTLS_ERR_RSA_RNG_FAILED -17536 /**< The random generator failed to generate non-zeros. */
#define MBEDTLS_ERR_RSA_UNSUPPORTED_OPERATION -17664 /**< The implementation does not offer the requested operation, for example, because of security violations or lack of functionality. */
/* MBEDTLS_ERR_RSA_UNSUPPORTED_OPERATION is deprecated and should not be used. */
#define MBEDTLS_ERR_RSA_HW_ACCEL_FAILED -17792 /**< RSA hardware accelerator failed. */
/* MBEDTLS_ERR_RSA_HW_ACCEL_FAILED is deprecated and should not be used. */
#define MBEDTLS_RSA_PUBLIC 0 /**< Request private key operation. */
/* * RSA constants */
#define MBEDTLS_RSA_PRIVATE 1 /**< Request public key operation. */
#define MBEDTLS_RSA_PKCS_V15 0 /**< Use PKCS#1 v1.5 encoding. */
#define MBEDTLS_RSA_PKCS_V21 1 /**< Use PKCS#1 v2.1 encoding. */
#define MBEDTLS_RSA_SIGN 1 /**< Identifier for RSA signature operations. */
#define MBEDTLS_RSA_CRYPT 2 /**< Identifier for RSA encryption and decryption operations. */
#define MBEDTLS_RSA_SALT_LEN_ANY -1
void mbedtls_rsa_init( mbedtls_rsa_context *ctx,
int padding,
int hash_id );
/** * \brief This function initializes an RSA context. * * \note Set padding to #MBEDTLS_RSA_PKCS_V21 for the RSAES-OAEP * encryption scheme and the RSASSA-PSS signature scheme. * * \note The \p hash_id parameter is ignored when using * #MBEDTLS_RSA_PKCS_V15 padding. * * \note The choice of padding mode is strictly enforced for private key * operations, since there might be security concerns in * mixing padding modes. For public key operations it is * a default value, which can be overriden by calling specific * \c rsa_rsaes_xxx or \c rsa_rsassa_xxx functions. * * \note The hash selected in \p hash_id is always used for OEAP * encryption. For PSS signatures, it is always used for * making signatures, but can be overriden for verifying them. * If set to #MBEDTLS_MD_NONE, it is always overriden. * * \param ctx The RSA context to initialize. This must not be \c NULL. * \param padding The padding mode to use. This must be either * #MBEDTLS_RSA_PKCS_V15 or #MBEDTLS_RSA_PKCS_V21. * \param hash_id The hash identifier of ::mbedtls_md_type_t type, if * \p padding is #MBEDTLS_RSA_PKCS_V21. It is unused * otherwise. */
int mbedtls_rsa_import( mbedtls_rsa_context *ctx,
const mbedtls_mpi *N,
const mbedtls_mpi *P, const mbedtls_mpi *Q,
const mbedtls_mpi *D, const mbedtls_mpi *E );
/** * \brief This function imports a set of core parameters into an * RSA context. * * \note This function can be called multiple times for successive * imports, if the parameters are not simultaneously present. * * Any sequence of calls to this function should be followed * by a call to mbedtls_rsa_complete(), which checks and * completes the provided information to a ready-for-use * public or private RSA key. * * \note See mbedtls_rsa_complete() for more information on which * parameters are necessary to set up a private or public * RSA key. * * \note The imported parameters are copied and need not be preserved * for the lifetime of the RSA context being set up. * * \param ctx The initialized RSA context to store the parameters in. * \param N The RSA modulus. This may be \c NULL. * \param P The first prime factor of \p N. This may be \c NULL. * \param Q The second prime factor of \p N. This may be \c NULL. * \param D The private exponent. This may be \c NULL. * \param E The public exponent. This may be \c NULL. * * \return \c 0 on success. * \return A non-zero error code on failure. */
int mbedtls_rsa_import_raw( mbedtls_rsa_context *ctx,
unsigned char const *N, size_t N_len,
unsigned char const *P, size_t P_len,
unsigned char const *Q, size_t Q_len,
unsigned char const *D, size_t D_len,
unsigned char const *E, size_t E_len );
/** * \brief This function imports core RSA parameters, in raw big-endian * binary format, into an RSA context. * * \note This function can be called multiple times for successive * imports, if the parameters are not simultaneously present. * * Any sequence of calls to this function should be followed * by a call to mbedtls_rsa_complete(), which checks and * completes the provided information to a ready-for-use * public or private RSA key. * * \note See mbedtls_rsa_complete() for more information on which * parameters are necessary to set up a private or public * RSA key. * * \note The imported parameters are copied and need not be preserved * for the lifetime of the RSA context being set up. * * \param ctx The initialized RSA context to store the parameters in. * \param N The RSA modulus. This may be \c NULL. * \param N_len The Byte length of \p N; it is ignored if \p N == NULL. * \param P The first prime factor of \p N. This may be \c NULL. * \param P_len The Byte length of \p P; it ns ignored if \p P == NULL. * \param Q The second prime factor of \p N. This may be \c NULL. * \param Q_len The Byte length of \p Q; it is ignored if \p Q == NULL. * \param D The private exponent. This may be \c NULL. * \param D_len The Byte length of \p D; it is ignored if \p D == NULL. * \param E The public exponent. This may be \c NULL. * \param E_len The Byte length of \p E; it is ignored if \p E == NULL. * * \return \c 0 on success. * \return A non-zero error code on failure. */
int mbedtls_rsa_complete( mbedtls_rsa_context *ctx );
/** * \brief This function completes an RSA context from * a set of imported core parameters. * * To setup an RSA public key, precisely \p N and \p E * must have been imported. * * To setup an RSA private key, sufficient information must * be present for the other parameters to be derivable. * * The default implementation supports the following: *
int mbedtls_rsa_export( const mbedtls_rsa_context *ctx,
mbedtls_mpi *N, mbedtls_mpi *P, mbedtls_mpi *Q,
mbedtls_mpi *D, mbedtls_mpi *E );
/** * \brief This function exports the core parameters of an RSA key. * * If this function runs successfully, the non-NULL buffers * pointed to by \p N, \p P, \p Q, \p D, and \p E are fully * written, with additional unused space filled leading by * zero Bytes. * * Possible reasons for returning * #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED:
int mbedtls_rsa_export_raw( const mbedtls_rsa_context *ctx,
unsigned char *N, size_t N_len,
unsigned char *P, size_t P_len,
unsigned char *Q, size_t Q_len,
unsigned char *D, size_t D_len,
unsigned char *E, size_t E_len );
/** * \brief This function exports core parameters of an RSA key * in raw big-endian binary format. * * If this function runs successfully, the non-NULL buffers * pointed to by \p N, \p P, \p Q, \p D, and \p E are fully * written, with additional unused space filled leading by * zero Bytes. * * Possible reasons for returning * #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED:
int mbedtls_rsa_export_crt( const mbedtls_rsa_context *ctx,
mbedtls_mpi *DP, mbedtls_mpi *DQ, mbedtls_mpi *QP );
/** * \brief This function exports CRT parameters of a private RSA key. * * \note Alternative RSA implementations not using CRT-parameters * internally can implement this function based on * mbedtls_rsa_deduce_opt(). * * \param ctx The initialized RSA context. * \param DP The MPI to hold \c D modulo `P-1`, * or \c NULL if it need not be exported. * \param DQ The MPI to hold \c D modulo `Q-1`, * or \c NULL if it need not be exported. * \param QP The MPI to hold modular inverse of \c Q modulo \c P, * or \c NULL if it need not be exported. * * \return \c 0 on success. * \return A non-zero error code on failure. * */
void mbedtls_rsa_set_padding( mbedtls_rsa_context *ctx, int padding,
int hash_id );
/** * \brief This function sets padding for an already initialized RSA * context. See mbedtls_rsa_init() for details. * * \param ctx The initialized RSA context to be configured. * \param padding The padding mode to use. This must be either * #MBEDTLS_RSA_PKCS_V15 or #MBEDTLS_RSA_PKCS_V21. * \param hash_id The #MBEDTLS_RSA_PKCS_V21 hash identifier. */
size_t mbedtls_rsa_get_len( const mbedtls_rsa_context *ctx );
/** * \brief This function retrieves the length of RSA modulus in Bytes. * * \param ctx The initialized RSA context. * * \return The length of the RSA modulus in Bytes. * */
int mbedtls_rsa_gen_key( mbedtls_rsa_context *ctx,
int (*f_rng)(void *, unsigned char *, size_t),
void *p_rng,
unsigned int nbits, int exponent );
/** * \brief This function generates an RSA keypair. * * \note mbedtls_rsa_init() must be called before this function, * to set up the RSA context. * * \param ctx The initialized RSA context used to hold the key. * \param f_rng The RNG function to be used for key generation. * This must not be \c NULL. * \param p_rng The RNG context to be passed to \p f_rng. * This may be \c NULL if \p f_rng doesn't need a context. * \param nbits The size of the public key in bits. * \param exponent The public exponent to use. For example, \c 65537. * This must be odd and greater than \c 1. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_check_pubkey( const mbedtls_rsa_context *ctx );
/** * \brief This function checks if a context contains at least an RSA * public key. * * If the function runs successfully, it is guaranteed that * enough information is present to perform an RSA public key * operation using mbedtls_rsa_public(). * * \param ctx The initialized RSA context to check. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. * */
int mbedtls_rsa_check_privkey( const mbedtls_rsa_context *ctx );
/** * \brief This function checks if a context contains an RSA private key * and perform basic consistency checks. * * \note The consistency checks performed by this function not only * ensure that mbedtls_rsa_private() can be called successfully * on the given context, but that the various parameters are * mutually consistent with high probability, in the sense that * mbedtls_rsa_public() and mbedtls_rsa_private() are inverses. * * \warning This function should catch accidental misconfigurations * like swapping of parameters, but it cannot establish full * trust in neither the quality nor the consistency of the key * material that was used to setup the given RSA context: *
int mbedtls_rsa_check_pub_priv( const mbedtls_rsa_context *pub,
const mbedtls_rsa_context *prv );
/** * \brief This function checks a public-private RSA key pair. * * It checks each of the contexts, and makes sure they match. * * \param pub The initialized RSA context holding the public key. * \param prv The initialized RSA context holding the private key. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_public( mbedtls_rsa_context *ctx,
const unsigned char *input,
unsigned char *output );
/** * \brief This function performs an RSA public key operation. * * \param ctx The initialized RSA context to use. * \param input The input buffer. This must be a readable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * \param output The output buffer. This must be a writable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \note This function does not handle message padding. * * \note Make sure to set \p input[0] = 0 or ensure that * input is smaller than \p N. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_private( mbedtls_rsa_context *ctx,
void *p_rng,
/** * \brief This function performs an RSA private key operation. * * \note Blinding is used if and only if a PRNG is provided. * * \note If blinding is used, both the base of exponentation * and the exponent are blinded, providing protection * against some side-channel attacks. * * \warning It is deprecated and a security risk to not provide * a PRNG here and thereby prevent the use of blinding. * Future versions of the library may enforce the presence * of a PRNG. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG function, used for blinding. It is discouraged * and deprecated to pass \c NULL here, in which case * blinding will be omitted. * \param p_rng The RNG context to pass to \p f_rng. This may be \c NULL * if \p f_rng is \c NULL or if \p f_rng doesn't need a context. * \param input The input buffer. This must be a readable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * \param output The output buffer. This must be a writable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. * */
int mbedtls_rsa_pkcs1_encrypt( mbedtls_rsa_context *ctx,
void *p_rng,
int mode, size_t ilen,
/** * \brief This function adds the message padding, then performs an RSA * operation. * * It is the generic wrapper for performing a PKCS#1 encryption * operation using the \p mode from the context. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PRIVATE mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PUBLIC. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PRIVATE and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG to use. It is mandatory for PKCS#1 v2.1 padding * encoding, and for PKCS#1 v1.5 padding encoding when used * with \p mode set to #MBEDTLS_RSA_PUBLIC. For PKCS#1 v1.5 * padding encoding and \p mode set to #MBEDTLS_RSA_PRIVATE, * it is used for blinding and should be provided in this * case; see mbedtls_rsa_private() for more. * \param p_rng The RNG context to be passed to \p f_rng. May be * \c NULL if \p f_rng is \c NULL or if \p f_rng doesn't * need a context argument. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PUBLIC or #MBEDTLS_RSA_PRIVATE (deprecated). * \param ilen The length of the plaintext in Bytes. * \param input The input data to encrypt. This must be a readable * buffer of size \p ilen Bytes. This must not be \c NULL. * \param output The output buffer. This must be a writable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_rsaes_pkcs1_v15_encrypt( mbedtls_rsa_context *ctx,
void *p_rng,
/** * \brief This function performs a PKCS#1 v1.5 encryption operation * (RSAES-PKCS1-v1_5-ENCRYPT). * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PRIVATE mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PUBLIC. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PRIVATE and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG function to use. It is needed for padding generation * if \p mode is #MBEDTLS_RSA_PUBLIC. If \p mode is * #MBEDTLS_RSA_PRIVATE (discouraged), it is used for * blinding and should be provided; see mbedtls_rsa_private(). * \param p_rng The RNG context to be passed to \p f_rng. This may * be \c NULL if \p f_rng is \c NULL or if \p f_rng * doesn't need a context argument. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PUBLIC or #MBEDTLS_RSA_PRIVATE (deprecated). * \param ilen The length of the plaintext in Bytes. * \param input The input data to encrypt. This must be a readable * buffer of size \p ilen Bytes. This must not be \c NULL. * \param output The output buffer. This must be a writable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_rsaes_oaep_encrypt( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
const unsigned char *label, size_t label_len,
size_t ilen,
/** * \brief This function performs a PKCS#1 v2.1 OAEP encryption * operation (RSAES-OAEP-ENCRYPT). * * \note The output buffer must be as large as the size * of ctx->N. For example, 128 Bytes if RSA-1024 is used. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PRIVATE mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PUBLIC. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PRIVATE and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initnialized RSA context to use. * \param f_rng The RNG function to use. This is needed for padding * generation and must be provided. * \param p_rng The RNG context to be passed to \p f_rng. This may * be \c NULL if \p f_rng doesn't need a context argument. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PUBLIC or #MBEDTLS_RSA_PRIVATE (deprecated). * \param label The buffer holding the custom label to use. * This must be a readable buffer of length \p label_len * Bytes. It may be \c NULL if \p label_len is \c 0. * \param label_len The length of the label in Bytes. * \param ilen The length of the plaintext buffer \p input in Bytes. * \param input The input data to encrypt. This must be a readable * buffer of size \p ilen Bytes. This must not be \c NULL. * \param output The output buffer. This must be a writable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_pkcs1_decrypt( mbedtls_rsa_context *ctx,
void *p_rng,
int mode, size_t *olen,
unsigned char *output,
size_t output_max_len );
/** * \brief This function performs an RSA operation, then removes the * message padding. * * It is the generic wrapper for performing a PKCS#1 decryption * operation using the \p mode from the context. * * \note The output buffer length \c output_max_len should be * as large as the size \p ctx->len of \p ctx->N (for example, * 128 Bytes if RSA-1024 is used) to be able to hold an * arbitrary decrypted message. If it is not large enough to * hold the decryption of the particular ciphertext provided, * the function returns \c MBEDTLS_ERR_RSA_OUTPUT_TOO_LARGE. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PUBLIC mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PRIVATE. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PUBLIC and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG function. If \p mode is #MBEDTLS_RSA_PRIVATE, * this is used for blinding and should be provided; see * mbedtls_rsa_private() for more. If \p mode is * #MBEDTLS_RSA_PUBLIC, it is ignored. * \param p_rng The RNG context to be passed to \p f_rng. This may be * \c NULL if \p f_rng is \c NULL or doesn't need a context. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PRIVATE or #MBEDTLS_RSA_PUBLIC (deprecated). * \param olen The address at which to store the length of * the plaintext. This must not be \c NULL. * \param input The ciphertext buffer. This must be a readable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * \param output The buffer used to hold the plaintext. This must * be a writable buffer of length \p output_max_len Bytes. * \param output_max_len The length in Bytes of the output buffer \p output. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_rsaes_pkcs1_v15_decrypt( mbedtls_rsa_context *ctx,
void *p_rng,
/** * \brief This function performs a PKCS#1 v1.5 decryption * operation (RSAES-PKCS1-v1_5-DECRYPT). * * \note The output buffer length \c output_max_len should be * as large as the size \p ctx->len of \p ctx->N, for example, * 128 Bytes if RSA-1024 is used, to be able to hold an * arbitrary decrypted message. If it is not large enough to * hold the decryption of the particular ciphertext provided, * the function returns #MBEDTLS_ERR_RSA_OUTPUT_TOO_LARGE. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PUBLIC mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PRIVATE. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PUBLIC and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG function. If \p mode is #MBEDTLS_RSA_PRIVATE, * this is used for blinding and should be provided; see * mbedtls_rsa_private() for more. If \p mode is * #MBEDTLS_RSA_PUBLIC, it is ignored. * \param p_rng The RNG context to be passed to \p f_rng. This may be * \c NULL if \p f_rng is \c NULL or doesn't need a context. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PRIVATE or #MBEDTLS_RSA_PUBLIC (deprecated). * \param olen The address at which to store the length of * the plaintext. This must not be \c NULL. * \param input The ciphertext buffer. This must be a readable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * \param output The buffer used to hold the plaintext. This must * be a writable buffer of length \p output_max_len Bytes. * \param output_max_len The length in Bytes of the output buffer \p output. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. * */
int mbedtls_rsa_rsaes_oaep_decrypt( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
size_t *olen,
/** * \brief This function performs a PKCS#1 v2.1 OAEP decryption * operation (RSAES-OAEP-DECRYPT). * * \note The output buffer length \c output_max_len should be * as large as the size \p ctx->len of \p ctx->N, for * example, 128 Bytes if RSA-1024 is used, to be able to * hold an arbitrary decrypted message. If it is not * large enough to hold the decryption of the particular * ciphertext provided, the function returns * #MBEDTLS_ERR_RSA_OUTPUT_TOO_LARGE. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PUBLIC mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PRIVATE. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PUBLIC and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG function. If \p mode is #MBEDTLS_RSA_PRIVATE, * this is used for blinding and should be provided; see * mbedtls_rsa_private() for more. If \p mode is * #MBEDTLS_RSA_PUBLIC, it is ignored. * \param p_rng The RNG context to be passed to \p f_rng. This may be * \c NULL if \p f_rng is \c NULL or doesn't need a context. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PRIVATE or #MBEDTLS_RSA_PUBLIC (deprecated). * \param label The buffer holding the custom label to use. * This must be a readable buffer of length \p label_len * Bytes. It may be \c NULL if \p label_len is \c 0. * \param label_len The length of the label in Bytes. * \param olen The address at which to store the length of * the plaintext. This must not be \c NULL. * \param input The ciphertext buffer. This must be a readable buffer * of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * \param output The buffer used to hold the plaintext. This must * be a writable buffer of length \p output_max_len Bytes. * \param output_max_len The length in Bytes of the output buffer \p output. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_pkcs1_sign( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
mbedtls_md_type_t md_alg,
unsigned int hashlen,
const unsigned char *hash,
unsigned char *sig );
/** * \brief This function performs a private RSA operation to sign * a message digest using PKCS#1. * * It is the generic wrapper for performing a PKCS#1 * signature using the \p mode from the context. * * \note The \p sig buffer must be as large as the size * of \p ctx->N. For example, 128 Bytes if RSA-1024 is used. * * \note For PKCS#1 v2.1 encoding, see comments on * mbedtls_rsa_rsassa_pss_sign() for details on * \p md_alg and \p hash_id. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PUBLIC mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PRIVATE. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PUBLIC and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG function to use. If the padding mode is PKCS#1 v2.1, * this must be provided. If the padding mode is PKCS#1 v1.5 and * \p mode is #MBEDTLS_RSA_PRIVATE, it is used for blinding * and should be provided; see mbedtls_rsa_private() for more * more. It is ignored otherwise. * \param p_rng The RNG context to be passed to \p f_rng. This may be \c NULL * if \p f_rng is \c NULL or doesn't need a context argument. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PRIVATE or #MBEDTLS_RSA_PUBLIC (deprecated). * \param md_alg The message-digest algorithm used to hash the original data. * Use #MBEDTLS_MD_NONE for signing raw data. * \param hashlen The length of the message digest. * Ths is only used if \p md_alg is #MBEDTLS_MD_NONE. * \param hash The buffer holding the message digest or raw data. * If \p md_alg is #MBEDTLS_MD_NONE, this must be a readable * buffer of length \p hashlen Bytes. If \p md_alg is not * #MBEDTLS_MD_NONE, it must be a readable buffer of length * the size of the hash corresponding to \p md_alg. * \param sig The buffer to hold the signature. This must be a writable * buffer of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 if the signing operation was successful. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_rsassa_pkcs1_v15_sign( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
/** * \brief This function performs a PKCS#1 v1.5 signature * operation (RSASSA-PKCS1-v1_5-SIGN). * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PUBLIC mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PRIVATE. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PUBLIC and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG function. If \p mode is #MBEDTLS_RSA_PRIVATE, * this is used for blinding and should be provided; see * mbedtls_rsa_private() for more. If \p mode is * #MBEDTLS_RSA_PUBLIC, it is ignored. * \param p_rng The RNG context to be passed to \p f_rng. This may be \c NULL * if \p f_rng is \c NULL or doesn't need a context argument. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PRIVATE or #MBEDTLS_RSA_PUBLIC (deprecated). * \param md_alg The message-digest algorithm used to hash the original data. * Use #MBEDTLS_MD_NONE for signing raw data. * \param hashlen The length of the message digest. * Ths is only used if \p md_alg is #MBEDTLS_MD_NONE. * \param hash The buffer holding the message digest or raw data. * If \p md_alg is #MBEDTLS_MD_NONE, this must be a readable * buffer of length \p hashlen Bytes. If \p md_alg is not * #MBEDTLS_MD_NONE, it must be a readable buffer of length * the size of the hash corresponding to \p md_alg. * \param sig The buffer to hold the signature. This must be a writable * buffer of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 if the signing operation was successful. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_rsassa_pss_sign( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
/** * \brief This function performs a PKCS#1 v2.1 PSS signature * operation (RSASSA-PSS-SIGN). * * \note The \p hash_id in the RSA context is the one used for the * encoding. \p md_alg in the function call is the type of hash * that is encoded. According to RFC-3447: Public-Key * Cryptography Standards (PKCS) #1 v2.1: RSA Cryptography * Specifications it is advised to keep both hashes the * same. * * \note This function always uses the maximum possible salt size, * up to the length of the payload hash. This choice of salt * size complies with FIPS 186-4 §5.5 (e) and RFC 8017 (PKCS#1 * v2.2) §9.1.1 step 3. Furthermore this function enforces a * minimum salt size which is the hash size minus 2 bytes. If * this minimum size is too large given the key size (the salt * size, plus the hash size, plus 2 bytes must be no more than * the key size in bytes), this function returns * #MBEDTLS_ERR_RSA_BAD_INPUT_DATA. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PUBLIC mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PRIVATE. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PUBLIC and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA context to use. * \param f_rng The RNG function. It must not be \c NULL. * \param p_rng The RNG context to be passed to \p f_rng. This may be \c NULL * if \p f_rng doesn't need a context argument. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PRIVATE or #MBEDTLS_RSA_PUBLIC (deprecated). * \param md_alg The message-digest algorithm used to hash the original data. * Use #MBEDTLS_MD_NONE for signing raw data. * \param hashlen The length of the message digest. * Ths is only used if \p md_alg is #MBEDTLS_MD_NONE. * \param hash The buffer holding the message digest or raw data. * If \p md_alg is #MBEDTLS_MD_NONE, this must be a readable * buffer of length \p hashlen Bytes. If \p md_alg is not * #MBEDTLS_MD_NONE, it must be a readable buffer of length * the size of the hash corresponding to \p md_alg. * \param sig The buffer to hold the signature. This must be a writable * buffer of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 if the signing operation was successful. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_pkcs1_verify( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
const unsigned char *sig );
/** * \brief This function performs a public RSA operation and checks * the message digest. * * This is the generic wrapper for performing a PKCS#1 * verification using the mode from the context. * * \note For PKCS#1 v2.1 encoding, see comments on * mbedtls_rsa_rsassa_pss_verify() about \p md_alg and * \p hash_id. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PRIVATE mode. Future versions of the library * are likely to remove the \p mode argument and have it * set to #MBEDTLS_RSA_PUBLIC. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PRIVATE and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA public key context to use. * \param f_rng The RNG function to use. If \p mode is #MBEDTLS_RSA_PRIVATE, * this is used for blinding and should be provided; see * mbedtls_rsa_private() for more. Otherwise, it is ignored. * \param p_rng The RNG context to be passed to \p f_rng. This may be * \c NULL if \p f_rng is \c NULL or doesn't need a context. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PUBLIC or #MBEDTLS_RSA_PRIVATE (deprecated). * \param md_alg The message-digest algorithm used to hash the original data. * Use #MBEDTLS_MD_NONE for signing raw data. * \param hashlen The length of the message digest. * This is only used if \p md_alg is #MBEDTLS_MD_NONE. * \param hash The buffer holding the message digest or raw data. * If \p md_alg is #MBEDTLS_MD_NONE, this must be a readable * buffer of length \p hashlen Bytes. If \p md_alg is not * #MBEDTLS_MD_NONE, it must be a readable buffer of length * the size of the hash corresponding to \p md_alg. * \param sig The buffer holding the signature. This must be a readable * buffer of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 if the verify operation was successful. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_rsassa_pkcs1_v15_verify( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
/** * \brief This function performs a PKCS#1 v1.5 verification * operation (RSASSA-PKCS1-v1_5-VERIFY). * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PRIVATE mode. Future versions of the library * are likely to remove the \p mode argument and have it * set to #MBEDTLS_RSA_PUBLIC. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PRIVATE and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA public key context to use. * \param f_rng The RNG function to use. If \p mode is #MBEDTLS_RSA_PRIVATE, * this is used for blinding and should be provided; see * mbedtls_rsa_private() for more. Otherwise, it is ignored. * \param p_rng The RNG context to be passed to \p f_rng. This may be * \c NULL if \p f_rng is \c NULL or doesn't need a context. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PUBLIC or #MBEDTLS_RSA_PRIVATE (deprecated). * \param md_alg The message-digest algorithm used to hash the original data. * Use #MBEDTLS_MD_NONE for signing raw data. * \param hashlen The length of the message digest. * This is only used if \p md_alg is #MBEDTLS_MD_NONE. * \param hash The buffer holding the message digest or raw data. * If \p md_alg is #MBEDTLS_MD_NONE, this must be a readable * buffer of length \p hashlen Bytes. If \p md_alg is not * #MBEDTLS_MD_NONE, it must be a readable buffer of length * the size of the hash corresponding to \p md_alg. * \param sig The buffer holding the signature. This must be a readable * buffer of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 if the verify operation was successful. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_rsassa_pss_verify( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
/** * \brief This function performs a PKCS#1 v2.1 PSS verification * operation (RSASSA-PSS-VERIFY). * * The hash function for the MGF mask generating function * is that specified in the RSA context. * * \note The \p hash_id in the RSA context is the one used for the * verification. \p md_alg in the function call is the type of * hash that is verified. According to RFC-3447: Public-Key * Cryptography Standards (PKCS) #1 v2.1: RSA Cryptography * Specifications it is advised to keep both hashes the * same. If \p hash_id in the RSA context is unset, * the \p md_alg from the function call is used. * * \deprecated It is deprecated and discouraged to call this function * in #MBEDTLS_RSA_PRIVATE mode. Future versions of the library * are likely to remove the \p mode argument and have it * implicitly set to #MBEDTLS_RSA_PUBLIC. * * \note Alternative implementations of RSA need not support * mode being set to #MBEDTLS_RSA_PRIVATE and might instead * return #MBEDTLS_ERR_PLATFORM_FEATURE_UNSUPPORTED. * * \param ctx The initialized RSA public key context to use. * \param f_rng The RNG function to use. If \p mode is #MBEDTLS_RSA_PRIVATE, * this is used for blinding and should be provided; see * mbedtls_rsa_private() for more. Otherwise, it is ignored. * \param p_rng The RNG context to be passed to \p f_rng. This may be * \c NULL if \p f_rng is \c NULL or doesn't need a context. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PUBLIC or #MBEDTLS_RSA_PRIVATE (deprecated). * \param md_alg The message-digest algorithm used to hash the original data. * Use #MBEDTLS_MD_NONE for signing raw data. * \param hashlen The length of the message digest. * This is only used if \p md_alg is #MBEDTLS_MD_NONE. * \param hash The buffer holding the message digest or raw data. * If \p md_alg is #MBEDTLS_MD_NONE, this must be a readable * buffer of length \p hashlen Bytes. If \p md_alg is not * #MBEDTLS_MD_NONE, it must be a readable buffer of length * the size of the hash corresponding to \p md_alg. * \param sig The buffer holding the signature. This must be a readable * buffer of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 if the verify operation was successful. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_rsassa_pss_verify_ext( mbedtls_rsa_context *ctx,
void *p_rng,
int mode,
mbedtls_md_type_t mgf1_hash_id,
int expected_salt_len,
/** * \brief This function performs a PKCS#1 v2.1 PSS verification * operation (RSASSA-PSS-VERIFY). * * The hash function for the MGF mask generating function * is that specified in \p mgf1_hash_id. * * \note The \p sig buffer must be as large as the size * of \p ctx->N. For example, 128 Bytes if RSA-1024 is used. * * \note The \p hash_id in the RSA context is ignored. * * \param ctx The initialized RSA public key context to use. * \param f_rng The RNG function to use. If \p mode is #MBEDTLS_RSA_PRIVATE, * this is used for blinding and should be provided; see * mbedtls_rsa_private() for more. Otherwise, it is ignored. * \param p_rng The RNG context to be passed to \p f_rng. This may be * \c NULL if \p f_rng is \c NULL or doesn't need a context. * \param mode The mode of operation. This must be either * #MBEDTLS_RSA_PUBLIC or #MBEDTLS_RSA_PRIVATE. * \param md_alg The message-digest algorithm used to hash the original data. * Use #MBEDTLS_MD_NONE for signing raw data. * \param hashlen The length of the message digest. * This is only used if \p md_alg is #MBEDTLS_MD_NONE. * \param hash The buffer holding the message digest or raw data. * If \p md_alg is #MBEDTLS_MD_NONE, this must be a readable * buffer of length \p hashlen Bytes. If \p md_alg is not * #MBEDTLS_MD_NONE, it must be a readable buffer of length * the size of the hash corresponding to \p md_alg. * \param mgf1_hash_id The message digest used for mask generation. * \param expected_salt_len The length of the salt used in padding. Use * #MBEDTLS_RSA_SALT_LEN_ANY to accept any salt length. * \param sig The buffer holding the signature. This must be a readable * buffer of length \c ctx->len Bytes. For example, \c 256 Bytes * for an 2048-bit RSA modulus. * * \return \c 0 if the verify operation was successful. * \return An \c MBEDTLS_ERR_RSA_XXX error code on failure. */
int mbedtls_rsa_copy( mbedtls_rsa_context *dst, const mbedtls_rsa_context *src );
/** * \brief This function copies the components of an RSA context. * * \param dst The destination context. This must be initialized. * \param src The source context. This must be initialized. * * \return \c 0 on success. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory allocation failure. */
void mbedtls_rsa_free( mbedtls_rsa_context *ctx );
/** * \brief This function frees the components of an RSA key. * * \param ctx The RSA context to free. May be \c NULL, in which case * this function is a no-op. If it is not \c NULL, it must * point to an initialized RSA context. */
int mbedtls_rsa_self_test( int verbose );
/** * \brief The RSA checkup routine. * * \return \c 0 on success. * \return \c 1 on failure. */
typedef struct mbedtls_rsa_context
int ver; /*!< Always 0.*/
size_t len; /*!< The size of \p N in Bytes. */
mbedtls_mpi N; /*!< The public modulus. */
mbedtls_mpi E; /*!< The public exponent. */
mbedtls_mpi D; /*!< The private exponent. */
mbedtls_mpi P; /*!< The first prime factor. */
mbedtls_mpi Q; /*!< The second prime factor. */
mbedtls_mpi DP; /*!< D % (P - 1). */
mbedtls_mpi DQ; /*!< D % (Q - 1). */
mbedtls_mpi QP; /*!< 1 / (Q % P). */
mbedtls_mpi RN; /*!< cached R^2 mod N. */
mbedtls_mpi RP; /*!< cached R^2 mod P. */
mbedtls_mpi RQ; /*!< cached R^2 mod Q. */
mbedtls_mpi Vi; /*!< The cached blinding value. */
mbedtls_mpi Vf; /*!< The cached un-blinding value. */
int padding; /*!< Selects padding mode:
#MBEDTLS_RSA_PKCS_V15 for 1.5 padding and
#MBEDTLS_RSA_PKCS_V21 for OAEP or PSS. */
int hash_id; /*!< Hash identifier of mbedtls_md_type_t type,
as specified in md.h for use in the MGF
mask generating function used in the
EME-OAEP and EMSA-PSS encodings. */
#if defined(MBEDTLS_THREADING_C)
mbedtls_threading_mutex_t mutex; /*!< Thread-safety mutex. */
mbedtls_rsa_context;
/** * \brief The RSA context structure. * * \note Direct manipulation of the members of this structure * is deprecated. All manipulation should instead be done through * the public interface functions. */
