#include "tuya_iot_config.h"
#define MBEDTLS_CONFIG_H_TY_ECC_ONLY
#define TUYA_ECP_MUL_COMB_ROM_TABLES 1 //使用ROM代替RAM
//#define TUYA_ECP_MUL_COMB_OPTIM 1 //打开ECP点乘优化
#define TUYA_TLS_DEBUG_THRDSHOLD 1 //TLS 调试等级
//#define MBEDTLS_ECP_FIXED_POINT_OPTIM 0 //调试性能使用
#define MBEDTLS_HAVE_ASM
#define MBEDTLS_AES_ALT
/** * \def MBEDTLS_AES_ALT * * MBEDTLS__MODULE_NAME__ALT: Uncomment a macro to let mbed TLS use your * alternate core implementation of a symmetric crypto, an arithmetic or hash * module (e.g. platform specific assembly optimized implementations). Keep * in mind that the function prototypes should remain the same. * * This replaces the whole module. If you only want to replace one of the * functions, use one of the MBEDTLS__FUNCTION_NAME__ALT flags. * * Example: In case you uncomment MBEDTLS_AES_ALT, mbed TLS will no longer * provide the "struct mbedtls_aes_context" definition and omit the base * function declarations and implementations. "aes_alt.h" will be included from * "aes.h" to include the new function definitions. * * Uncomment a macro to enable alternate implementation of the corresponding * module. * * \warning MD2, MD4, MD5, ARC4, DES and SHA-1 are considered weak and their * use constitutes a security risk. If possible, we recommend * avoiding dependencies on them, and considering stronger message * digests and ciphers instead. * */
#define MBEDTLS_CIPHER_MODE_CTR
/** * \def MBEDTLS_CIPHER_MODE_CTR * * Enable Counter Block Cipher mode (CTR) for symmetric ciphers. */
//#define MBEDTLS_ECP_DP_SECP224R1_ENABLED
#define MBEDTLS_ECP_DP_CURVE25519_ENABLED
//#define MBEDTLS_ECP_DP_BP512R1_ENABLED
#define MBEDTLS_PKCS1_V15
#define MBEDTLS_PKCS1_V21
#define MBEDTLS_SSL_SESSION_TICKETS
#define MBEDTLS_AES_C
/** * \def MBEDTLS_AES_C * * Enable the AES block cipher. * * Module: library/aes.c * Caller: library/cipher.c * library/pem.c * library/ctr_drbg.c * * This module enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * * PEM_PARSE uses AES for decrypting encrypted keys. */
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_BASE64_C
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CHACHA20_C
/** * \def MBEDTLS_CHACHA20_C * * Enable the ChaCha20 stream cipher. * * Module: library/chacha20.c */
#define MBEDTLS_CHACHAPOLY_C
/** * \def MBEDTLS_CHACHAPOLY_C * * Enable the ChaCha20-Poly1305 AEAD algorithm. * * Module: library/chachapoly.c * * This module requires: MBEDTLS_CHACHA20_C, MBEDTLS_POLY1305_C */
#define MBEDTLS_CIPHER_C
#define MBEDTLS_ECDH_C
#define MBEDTLS_ECP_C
#define MBEDTLS_GCM_C
/** * \def MBEDTLS_GCM_C * * Enable the Galois/Counter Mode (GCM) for AES. * * Module: library/gcm.c * * Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C * * This module enables the AES-GCM and CAMELLIA-GCM ciphersuites, if other * requisites are enabled as well. */
#define MBEDTLS_HKDF_C
/** * \def MBEDTLS_HKDF_C * * Enable the HKDF algorithm (RFC 5869). * * Module: library/hkdf.c * Caller: * * Requires: MBEDTLS_MD_C * * This module adds support for the Hashed Message Authentication Code * (HMAC)-based key derivation function (HKDF). */
#define MBEDTLS_MD_C
#define MBEDTLS_MD5_C
#define MBEDTLS_OID_C
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_PKCS5_C
#define MBEDTLS_PKCS12_C
#define MBEDTLS_PLATFORM_C
#define MBEDTLS_POLY1305_C
/** * \def MBEDTLS_POLY1305_C * * Enable the Poly1305 MAC algorithm. * * Module: library/poly1305.c * Caller: library/chachapoly.c */
#define MBEDTLS_RSA_C
#define MBEDTLS_SHA1_C
/** * \def MBEDTLS_SHA1_C * * Enable the SHA1 cryptographic hash algorithm. * * Module: library/sha1.c * Caller: library/md.c * library/ssl_cli.c * library/ssl_srv.c * library/ssl_tls.c * library/x509write_crt.c * * This module is required for SSL/TLS up to version 1.1, for TLS 1.2 * depending on the handshake parameters, and for SHA1-signed certificates. * * \warning SHA-1 is considered a weak message digest and its use constitutes * a security risk. If possible, we recommend avoiding dependencies * on it, and considering stronger message digests instead. * */
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_VERSION_C
#define MBEDTLS_X509_USE_C
#define MBEDTLS_MPI_WINDOW_SIZE 1 /**< Maximum windows size used. */
/* MPI / BIGNUM options */
#define MBEDTLS_MPI_MAX_SIZE 256 /**< Maximum number of bytes for usable MPIs. */
#define MBEDTLS_ECP_MAX_BITS 256 /**< Maximum bit size of groups */
/* ECP options */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384 /**< Maxium fragment length in bytes, determines the size of each of the two internal I/O buffers */
