#include <assert.h>
#include
#include
#include
#include <sys/time.h>
#include
#include <time.h>
#include
#include <lwip/ip_addr.h>
#include
#include "coap_io.h"
#include "coap_dtls.h"
#include "coap_event.h"
#include "coap_time.h"
#include "option.h"
#include "option.h"
#include "pdu.h"
#include "pdu.h"
#include "prng.h"
#include "prng.h"
#include "coap_session.h"
#define COAP_NET_H_
int coap_insert_node(coap_queue_t **queue, coap_queue_t *node);
/** * Adds @p node to given @p queue, ordered by variable t in @p node. * * @param queue Queue to add to. * @param node Node entry to add to Queue. * * @return @c 1 added to queue, @c 0 failure. */
int coap_delete_node(coap_queue_t *node);
/** * Destroys specified @p node. * * @param node Node entry to remove. * * @return @c 1 node deleted from queue, @c 0 failure. */
void coap_delete_all(coap_queue_t *queue);
/** * Removes all items from given @p queue and frees the allocated storage. * * @param queue The queue to delete. */
unsigned int coap_adjust_basetime(coap_context_t *ctx, coap_tick_t now);
/** * Set sendqueue_basetime in the given context object @p ctx to @p now. This * function returns the number of elements in the queue head that have timed * out. */
int coap_context_set_psk( coap_context_t *context, const char *hint,
const uint8_t *key, size_t key_len );
/** * Set the context's default PSK hint and/or key for a server. * * @param context The current coap_context_t object. * @param hint The default PSK server hint sent to a client. If @p NULL, PSK * authentication is disabled. Empty string is a valid hint. * @param key The default PSK key. If @p NULL, PSK authentication will fail. * @param key_len The default PSK key's length. If @p 0, PSK authentication will * fail. * * @return @c 1 if successful, else @c 0. */
int
coap_context_set_pki(coap_context_t *context,
coap_dtls_pki_t *setup_data);
/** * Set the context's default PKI information for a server. * * @param context The current coap_context_t object. * @param setup_data If @p NULL, PKI authentication will fail. Certificate * information required. * * @return @c 1 if successful, else @c 0. */
int
coap_context_set_pki_root_cas(coap_context_t *context,
const char *ca_file,
const char *ca_dir);
/** * Set the context's default Root CA information for a client or server. * * @param context The current coap_context_t object. * @param ca_file If not @p NULL, is the full path name of a PEM encoded * file containing all the Root CAs to be used. * @param ca_dir If not @p NULL, points to a directory containing PEM * encoded files containing all the Root CAs to be used. * * @return @c 1 if successful, else @c 0. */
void coap_context_set_keepalive(coap_context_t *context, unsigned int seconds);
/** * Set the context keepalive timer for sessions. * A keepalive message will be sent after if a session has been inactive, * i.e. no packet sent or received, for the given number of seconds. * For reliable protocols, a PING message will be sent. If a PONG has not * been received before the next PING is due to be sent, the session will * considered as disconnected. * * @param context The coap_context_t object. * @param seconds Number of seconds for the inactivity timer, or zero * to disable CoAP-level keepalive messages. * * @return 1 if successful, else 0 */
void coap_free_context(coap_context_t *context);
/** * CoAP stack context must be released with coap_free_context(). This function * clears all entries from the receive queue and send queue and deletes the * resources that have been registered with @p context, and frees the attached * endpoints. * * @param context The current coap_context_t object to free off. */
void coap_set_app_data(coap_context_t *context, void *data);
/** * Stores @p data with the given CoAP context. This function * overwrites any value that has previously been stored with @p * context. * * @param context The CoAP context. * @param data The data to store with wih the context. Note that this data * must be valid during the lifetime of @p context. */
void *coap_get_app_data(const coap_context_t *context);
/** * Returns any application-specific data that has been stored with @p * context using the function coap_set_app_data(). This function will * return @c NULL if no data has been stored. * * @param context The CoAP context. * * @return The data previously stored or @c NULL if not data stored. */
coap_tid_t coap_send_error(coap_session_t *session,
coap_pdu_t *request,
unsigned char code,
coap_opt_filter_t opts);
/** * Sends an error response with code @p code for request @p request to @p dst. * @p opts will be passed to coap_new_error_response() to copy marked options * from the request. This function returns the transaction id if the message was * sent, or @c COAP_INVALID_TID otherwise. * * @param session The CoAP session. * @param request The original request to respond to. * @param code The response code. * @param opts A filter that specifies the options to copy from the * @p request. * * @return The transaction id if the message was sent, or @c * COAP_INVALID_TID otherwise. */
coap_tid_t
coap_send_message_type(coap_session_t *session, coap_pdu_t *request, unsigned char type);
/** * Helper funktion to create and send a message with @p type (usually ACK or * RST). This function returns @c COAP_INVALID_TID when the message was not * sent, a valid transaction id otherwise. * * @param session The CoAP session. * @param request The request that should be responded to. * @param type Which type to set. * @return transaction id on success or @c COAP_INVALID_TID * otherwise. */
coap_tid_t coap_send_ack(coap_session_t *session, coap_pdu_t *request);
/** * Sends an ACK message with code @c 0 for the specified @p request to @p dst. * This function returns the corresponding transaction id if the message was * sent or @c COAP_INVALID_TID on error. * * @param session The CoAP session. * @param request The request to be acknowledged. * * @return The transaction id if ACK was sent or @c * COAP_INVALID_TID on error. */
coap_tid_t coap_send( coap_session_t *session, coap_pdu_t *pdu );
/** * Sends a CoAP message to given peer. The memory that is * allocated by pdu will be released by coap_send(). * The caller must not use the pdu after calling coap_send(). * * @param session The CoAP session. * @param pdu The CoAP PDU to send. * * @return The message id of the sent message or @c * COAP_INVALID_TID on error. */
coap_tid_t coap_retransmit(coap_context_t *context, coap_queue_t *node);
/** * Handles retransmissions of confirmable messages * * @param context The CoAP context. * @param node The node to retransmit. * * @return The message id of the sent message or @c * COAP_INVALID_TID on error. */
unsigned int
coap_write(coap_context_t *ctx,
coap_socket_t *sockets[],
unsigned int max_sockets,
unsigned int *num_sockets,
coap_tick_t now
void coap_read(coap_context_t *ctx, coap_tick_t now);
/** * For applications with their own message loop, reads all data from the network. * * @param ctx The CoAP context * @param now Current time */
int coap_run_once( coap_context_t *ctx, unsigned int timeout_ms );
int coap_handle_dgram(coap_context_t *ctx, coap_session_t *session, uint8_t *data, size_t data_len);
/** * Parses and interprets a CoAP datagram with context @p ctx. This function * returns @c 0 if the datagram was handled, or a value less than zero on * error. * * @param ctx The current CoAP context. * @param session The current CoAP session. * @param data The received packet'd data. * @param data_len The received packet'd data length. * * @return @c 0 if message was handled successfully, or less than zero on * error. */
int coap_handle_event(coap_context_t *context,
coap_event_t event,
coap_session_t *session);
/** * Invokes the event handler of @p context for the given @p event and * @p data. * * @param context The CoAP context whose event handler is to be called. * @param event The event to deliver. * @param session The session related to @p event. * @return The result from the associated event handler or 0 if none was * registered. */
int coap_remove_from_queue(coap_queue_t **queue,
coap_tid_t id,
coap_queue_t **node);
/** * This function removes the element with given @p id from the list given list. * If @p id was found, @p node is updated to point to the removed element. Note * that the storage allocated by @p node is @b not released. The caller must do * this manually using coap_delete_node(). This function returns @c 1 if the * element with id @p id was found, @c 0 otherwise. For a return value of @c 0, * the contents of @p node is undefined. * * @param queue The queue to search for @p id. * @param session The session to look for. * @param id The transaction id to look for. * @param node If found, @p node is updated to point to the removed node. You * must release the storage pointed to by @p node manually. * * @return @c 1 if @p id was found, @c 0 otherwise. */
coap_tid_t
coap_wait_ack( coap_context_t *context, coap_session_t *session,
void coap_cancel_all_messages(coap_context_t *context,
const uint8_t *token,
size_t token_length);
/** * Cancels all outstanding messages for session @p session that have the specified * token. * * @param context The context in use. * @param session Session of the messages to remove. * @param token Message token. * @param token_length Actual length of @p token. */
void
coap_cancel_session_messages(coap_context_t *context,
coap_nack_reason_t reason);
/** * Cancels all outstanding messages for session @p session. * * @param context The context in use. * @param session Session of the messages to remove. * @param reason The reasion for the session cancellation */
void coap_dispatch(coap_context_t *context, coap_session_t *session,
coap_pdu_t *pdu);
/** * Dispatches the PDUs from the receive queue in given context. */
int coap_can_exit(coap_context_t *context);
/** * Returns 1 if there are no messages to send or to dispatch in the context's * queues. */
void coap_ticks(coap_tick_t *);
/** * Returns the current value of an internal tick counter. The counter counts \c * COAP_TICKS_PER_SECOND ticks every second. */
int coap_option_check_critical(coap_context_t *ctx,
coap_pdu_t *pdu,
coap_opt_filter_t unknown);
* Verifies that @p pdu contains no unknown critical options. Options must be
* registered at @p ctx, using the function coap_register_option(). A basic set
* of options is registered automatically by coap_new_context(). This function
* returns @c 1 if @p pdu is ok, @c 0 otherwise. The given filter object @p
* unknown will be updated with the unknown options. As only @c COAP_MAX_OPT
* options can be signalled this way, remaining options must be examined
* manually.
* @code
coap_opt_filter_t f = COAP_OPT_NONE;
coap_opt_iterator_t opt_iter;
if (coap_option_check_critical(ctx, pdu, f) == 0) {
coap_option_iterator_init(pdu, &opt_iter, f);
while (coap_option_next(&opt_iter)) {
if (opt_iter.type & 0x01) {
... handle unknown critical option in opt_iter ...
@endcode
* @param ctx The context where all known options are registered.
* @param pdu The PDU to check.
* @param unknown The output filter that will be updated to indicate the
* unknown critical options found in @p pdu.
* @return @c 1 if everything was ok, @c 0 otherwise.
unsigned int coap_calc_timeout(coap_session_t *session, unsigned char r);
* Calculates the initial timeout based on the session CoAP transmission
* parameters 'ack_timeout', 'ack_random_factor', and COAP_TICKS_PER_SECOND.
* The calculation requires 'ack_timeout' and 'ack_random_factor' to be in
* Qx.FRAC_BITS fixed point notation, whereas the passed parameter @p r
* is interpreted as the fractional part of a Q0.MAX_BITS random value.
* @param session session timeout is associated with
* @param r random value as fractional part of a Q0.MAX_BITS fixed point
* value
* @return COAP_TICKS_PER_SECOND * 'ack_timeout' *
* (1 + ('ack_random_factor' - 1) * r)
struct coap_queue_t;
coap_queue_t *coap_new_node(void);
/** * Creates a new node suitable for adding to the CoAP sendqueue. * * @return New node entry, or @c NULL if failure. */
struct coap_resource_t;
struct coap_context_t;
struct coap_async_state_t;
coap_queue_t *coap_peek_next( coap_context_t *context );
/** * Returns the next pdu to send without removing from sendqeue. */
coap_queue_t *coap_pop_next( coap_context_t *context );
/** * Returns the next pdu to send and removes it from the sendqeue. */
coap_context_t *coap_new_context(const coap_address_t *listen_addr);
/** * Creates a new coap_context_t object that will hold the CoAP stack status. */
coap_pdu_t *coap_new_error_response(coap_pdu_t *request,
unsigned char code,
/** * Creates a new ACK PDU with specified error @p code. The options specified by * the filter expression @p opts will be copied from the original request * contained in @p request. Unless @c SHORT_ERROR_RESPONSE was defined at build * time, the textual reason phrase for @p code will be added as payload, with * Content-Type @c 0. * This function returns a pointer to the new response message, or @c NULL on * error. The storage allocated for the new message must be relased with * coap_free(). * * @param request Specification of the received (confirmable) request. * @param code The error code to set. * @param opts An option filter that specifies which options to copy from * the original request in @p node. * * @return A pointer to the new message or @c NULL on error. */
coap_queue_t *coap_find_transaction(coap_queue_t *queue, coap_session_t *session, coap_tid_t id);
/** * Retrieves transaction from the queue. * * @param queue The transaction queue to be searched. * @param session The session to find. * @param id The transaction id to find. * * @return A pointer to the transaction object or @c NULL if not found. */
coap_pdu_t *coap_wellknown_response(coap_context_t *context,
/** * Creates a new response for given @p request with the contents of @c * .well-known/core. The result is NULL on error or a newly allocated PDU that * must be either sent with coap_sent() or released by coap_delete_pdu(). * * @param context The current coap context to use. * @param session The CoAP session. * @param request The request for @c .well-known/core . * * @return A new 2.05 response for @c .well-known/core or NULL on error. */
typedef struct coap_queue_t {
struct coap_queue_t *next;
coap_tick_t t; /**< when to send PDU for the next time */
unsigned char retransmit_cnt; /**< retransmission counter, will be removed
* when zero */
unsigned int timeout; /**< the randomized timeout value */
coap_session_t *session; /**< the CoAP session */
coap_tid_t id; /**< CoAP transaction id */
coap_pdu_t *pdu; /**< the CoAP PDU to send */
} coap_queue_t;
/** * Queue entry */
typedef void (*coap_response_handler_t)(struct coap_context_t *context,
coap_pdu_t *sent,
coap_pdu_t *received,
const coap_tid_t id);
/** * Response handler that is used as call-back in coap_context_t. * * @param context CoAP session. * @param session CoAP session. * @param sent The PDU that was transmitted. * @param received The PDU that was received. * @param id CoAP transaction ID. */
typedef void (*coap_nack_handler_t)(struct coap_context_t *context,
coap_pdu_t *sent,
coap_nack_reason_t reason,
/** * Negative Acknowedge handler that is used as call-back in coap_context_t. * * @param context CoAP session. * @param session CoAP session. * @param sent The PDU that was transmitted. * @param reason The reason for the NACK. * @param id CoAP transaction ID. */
typedef void (*coap_ping_handler_t)(struct coap_context_t *context,
/** * Recieved Ping handler that is used as call-back in coap_context_t. * * @param context CoAP session. * @param session CoAP session. * @param received The PDU that was received. * @param id CoAP transaction ID. */
typedef void (*coap_pong_handler_t)(struct coap_context_t *context,
/** * Recieved Pong handler that is used as call-back in coap_context_t. * * @param context CoAP session. * @param session CoAP session. * @param received The PDU that was received. * @param id CoAP transaction ID. */
typedef struct coap_context_t {
coap_opt_filter_t known_options;
struct coap_resource_t *resources; /**< hash table or list of known
resources */
struct coap_resource_t *unknown_resource; /**< can be used for handling
unknown resources */
#ifndef WITHOUT_ASYNC
* list of asynchronous transactions */
struct coap_async_state_t *async_state;
#endif /* WITHOUT_ASYNC */
* The time stamp in the first element of the sendqeue is relative
* to sendqueue_basetime. */
coap_tick_t sendqueue_basetime;
coap_queue_t *sendqueue;
coap_endpoint_t *endpoint; /**< the endpoints used for listening */
coap_session_t *sessions; /**< client sessions */
#ifdef WITH_CONTIKI
struct uip_udp_conn *conn; /**< uIP connection object */
struct etimer retransmit_timer; /**< fires when the next packet must be sent */
struct etimer notify_timer; /**< used to check resources periodically */
#endif /* WITH_CONTIKI */
#ifdef WITH_LWIP
uint8_t timer_configured; /**< Set to 1 when a retransmission is
* scheduled using lwIP timers for this
* context, otherwise 0. */
#endif /* WITH_LWIP */
* The last message id that was used is stored in this field. The initial
* value is set by coap_new_context() and is usually a random value. A new
* message id can be created with coap_new_message_id().
uint16_t message_id;
coap_response_handler_t response_handler;
coap_nack_handler_t nack_handler;
coap_ping_handler_t ping_handler;
coap_pong_handler_t pong_handler;
* Callback function that is used to signal events to the
* application. This field is set by coap_set_event_handler().
coap_event_handler_t handle_event;
ssize_t (*network_send)(coap_socket_t *sock, const coap_session_t *session, const uint8_t *data, size_t datalen);
ssize_t (*network_read)(coap_socket_t *sock, struct coap_packet_t *packet);
size_t(*get_client_psk)(const coap_session_t *session, const uint8_t *hint, size_t hint_len, uint8_t *identity, size_t *identity_len, size_t max_identity_len, uint8_t *psk, size_t max_psk_len);
size_t(*get_server_psk)(const coap_session_t *session, const uint8_t *identity, size_t identity_len, uint8_t *psk, size_t max_psk_len);
size_t(*get_server_hint)(const coap_session_t *session, uint8_t *hint, size_t max_hint_len);
void *dtls_context;
uint8_t *psk_hint;
size_t psk_hint_len;
uint8_t *psk_key;
size_t psk_key_len;
unsigned int session_timeout; /**< Number of seconds of inactivity after which an unused session will be closed. 0 means use default. */
unsigned int max_idle_sessions; /**< Maximum number of simultaneous unused sessions per endpoint. 0 means no maximum. */
unsigned int max_handshake_sessions; /**< Maximum number of simultaneous negotating sessions per endpoint. 0 means use default. */
unsigned int ping_timeout; /**< Minimum inactivity time before sending a ping message. 0 means disabled. */
unsigned int csm_timeout; /**< Timeout for waiting for a CSM from the remote side. 0 means disabled. */
void *app; /**< application-specific data */
} coap_context_t;
/** * The CoAP stack's global state is stored in a coap_context_t object. */
