#define MBEDTLS_CONFIG_H_CAT1_ONLY
#define MBEDTLS_SSL_HANDSHAKE_FORCED_QUIT
#define TUYA_TLS_DEBUG_THRDSHOLD 5 //TLS 调试等级
#define MBEDTLS_AES_ALT
/** * \def MBEDTLS_AES_ALT * * MBEDTLS__MODULE_NAME__ALT: Uncomment a macro to let mbed TLS use your * alternate core implementation of a symmetric crypto, an arithmetic or hash * module (e.g. platform specific assembly optimized implementations). Keep * in mind that the function prototypes should remain the same. * * This replaces the whole module. If you only want to replace one of the * functions, use one of the MBEDTLS__FUNCTION_NAME__ALT flags. * * Example: In case you uncomment MBEDTLS_AES_ALT, mbed TLS will no longer * provide the "struct mbedtls_aes_context" definition and omit the base * function declarations and implementations. "aes_alt.h" will be included from * "aes.h" to include the new function definitions. * * Uncomment a macro to enable alternate implementation of the corresponding * module. * * \warning MD2, MD4, MD5, ARC4, DES and SHA-1 are considered weak and their * use constitutes a security risk. If possible, we recommend * avoiding dependencies on them, and considering stronger message * digests and ciphers instead. * */
#define MBEDTLS_CAMELLIA_SMALL_MEMORY
/** * \def MBEDTLS_CAMELLIA_SMALL_MEMORY * * Use less ROM for the Camellia implementation (saves about 768 bytes). * * Uncomment this macro to use less memory for Camellia. */
#define MBEDTLS_ECP_DP_SECP192R1_ENABLED
/** * \def MBEDTLS_ECP_DP_SECP192R1_ENABLED * * MBEDTLS_ECP_XXXX_ENABLED: Enables specific curves within the Elliptic Curve * module. By default all supported curves are enabled. * * Comment macros to disable the curve and functions for it */
#define MBEDTLS_ECP_DP_SECP224R1_ENABLED
#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
#define MBEDTLS_ECP_DP_SECP521R1_ENABLED
#define MBEDTLS_ECP_DP_SECP192K1_ENABLED
#define MBEDTLS_ECP_DP_SECP224K1_ENABLED
#define MBEDTLS_ECP_DP_SECP256K1_ENABLED
#define MBEDTLS_ECP_DP_BP256R1_ENABLED
#define MBEDTLS_ECP_DP_BP384R1_ENABLED
#define MBEDTLS_ECP_DP_BP512R1_ENABLED
#define MBEDTLS_ECP_DP_CURVE25519_ENABLED
#define MBEDTLS_ECP_DP_CURVE448_ENABLED
#define MBEDTLS_KEY_EXCHANGE_PSK_ENABLED
/** * \def MBEDTLS_KEY_EXCHANGE_PSK_ENABLED * * Enable the PSK based ciphersuite modes in SSL / TLS. * * This enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_3DES_EDE_CBC_SHA * MBEDTLS_TLS_PSK_WITH_RC4_128_SHA */
#define MBEDTLS_PK_PARSE_EC_EXTENDED
/** * \def MBEDTLS_PK_PARSE_EC_EXTENDED * * Enhance support for reading EC keys using variants of SEC1 not allowed by * RFC 5915 and RFC 5480. * * Currently this means parsing the SpecifiedECDomain choice of EC * parameters (only known groups are supported, not arbitrary domains, to * avoid validation issues). * * Disable if you only need to support RFC 5915 + 5480 key formats. */
#define MBEDTLS_GENPRIME
/** * \def MBEDTLS_GENPRIME * * Enable the prime-number generation code. * * Requires: MBEDTLS_BIGNUM_C */
#define MBEDTLS_PK_RSA_ALT_SUPPORT
/** * \def MBEDTLS_PK_RSA_ALT_SUPPORT * * Support external private RSA keys (eg from a HSM) in the PK layer. * * Comment this macro to disable support for external private RSA keys. */
#define MBEDTLS_PKCS1_V15
#define MBEDTLS_PKCS1_V21
#define MBEDTLS_SSL_FALLBACK_SCSV
/** * \def MBEDTLS_SSL_FALLBACK_SCSV * * Enable support for FALLBACK_SCSV (draft-ietf-tls-downgrade-scsv-00). * * For servers, it is recommended to always enable this, unless you support * only one version of TLS, or know for sure that none of your clients * implements a fallback strategy. * * For clients, you only need this if you're using a fallback strategy, which * is not recommended in the first place, unless you absolutely need it to * interoperate with buggy (version-intolerant) servers. * * Comment this macro to disable support for FALLBACK_SCSV */
#define MBEDTLS_SSL_RENEGOTIATION
/** * \def MBEDTLS_SSL_RENEGOTIATION * * Enable support for TLS renegotiation. * * The two main uses of renegotiation are (1) refresh keys on long-lived * connections and (2) client authentication after the initial handshake. * If you don't need renegotiation, it's probably better to disable it, since * it has been associated with security issues in the past and is easy to * misuse/misunderstand. * * Comment this to disable support for renegotiation. * * \note Even if this option is disabled, both client and server are aware * of the Renegotiation Indication Extension (RFC 5746) used to * prevent the SSL renegotiation attack (see RFC 5746 Sect. 1). * (See \c mbedtls_ssl_conf_legacy_renegotiation for the * configuration of this extension). * */
#define MBEDTLS_SSL_MAX_FRAGMENT_LENGTH
/** * \def MBEDTLS_SSL_MAX_FRAGMENT_LENGTH * * Enable support for RFC 6066 max_fragment_length extension in SSL. * * Comment this macro to disable support for the max_fragment_length extension */
#define MBEDTLS_SSL_SESSION_TICKETS
/** * \def MBEDTLS_SSL_SESSION_TICKETS * * Enable support for RFC 5077 session tickets in SSL. * Client-side, provides full support for session tickets (maintainance of a * session store remains the responsibility of the application, though). * Server-side, you also need to provide callbacks for writing and parsing * tickets, including authenticated encryption and key management. Example * callbacks are provided by MBEDTLS_SSL_TICKET_C. * * Comment this macro to disable support for SSL session tickets */
#define MBEDTLS_AES_C
/** * \def MBEDTLS_AES_C * * Enable the AES block cipher. * * Module: library/aes.c * Caller: library/cipher.c * library/pem.c * library/ctr_drbg.c * * This module enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * * PEM_PARSE uses AES for decrypting encrypted keys. */
#define MBEDTLS_ARC4_C
/** * \def MBEDTLS_ARC4_C * * Enable the ARCFOUR stream cipher. * * Module: library/arc4.c * Caller: library/cipher.c * * This module enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDHE_PSK_WITH_RC4_128_SHA * MBEDTLS_TLS_DHE_PSK_WITH_RC4_128_SHA * MBEDTLS_TLS_RSA_WITH_RC4_128_SHA * MBEDTLS_TLS_RSA_WITH_RC4_128_MD5 * MBEDTLS_TLS_RSA_PSK_WITH_RC4_128_SHA * MBEDTLS_TLS_PSK_WITH_RC4_128_SHA * * \warning ARC4 is considered a weak cipher and its use constitutes a * security risk. If possible, we recommend avoidng dependencies on * it, and considering stronger ciphers instead. * */
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_ASN1_WRITE_C
/** * \def MBEDTLS_ASN1_WRITE_C * * Enable the generic ASN1 writer. * * Module: library/asn1write.c * Caller: library/ecdsa.c * library/pkwrite.c * library/x509_create.c * library/x509write_crt.c * library/x509write_csr.c */
#define MBEDTLS_BASE64_C
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CIPHER_C
#define MBEDTLS_CTR_DRBG_C
#define MBEDTLS_DEBUG_C
#define MBEDTLS_ECDH_C
#define MBEDTLS_ECDSA_C
/** * \def MBEDTLS_ECDSA_C * * Enable the elliptic curve DSA library. * * Module: library/ecdsa.c * Caller: * * This module is used by the following key exchanges: * ECDHE-ECDSA * * Requires: MBEDTLS_ECP_C, MBEDTLS_ASN1_WRITE_C, MBEDTLS_ASN1_PARSE_C */
#define MBEDTLS_ECP_C
#define MBEDTLS_ENTROPY_C
/** * \def MBEDTLS_ENTROPY_C * * Enable the platform-specific entropy code. * * Module: library/entropy.c * Caller: * * Requires: MBEDTLS_SHA512_C or MBEDTLS_SHA256_C * * This module provides a generic entropy pool */
#define MBEDTLS_ERROR_C
/** * \def MBEDTLS_ERROR_C * * Enable error code to error string conversion. * * Module: library/error.c * Caller: * * This module enables mbedtls_strerror(). */
#define MBEDTLS_MD_C
#define MBEDTLS_MD5_C
#define MBEDTLS_NET_C
/** * \def MBEDTLS_NET_C * * Enable the TCP and UDP over IPv6/IPv4 networking routines. * * \note This module only works on POSIX/Unix (including Linux, BSD and OS X) * and Windows. For other platforms, you'll want to disable it, and write your * own networking callbacks to be passed to \c mbedtls_ssl_set_bio(). * * \note See also our Knowledge Base article about porting to a new * environment: * https://tls.mbed.org/kb/how-to/how-do-i-port-mbed-tls-to-a-new-environment-OS * * Module: library/net_sockets.c * * This module provides networking routines. */
#define MBEDTLS_OID_C
#define MBEDTLS_PEM_PARSE_C
/** * \def MBEDTLS_PEM_PARSE_C * * Enable PEM decoding / parsing. * * Module: library/pem.c * Caller: library/dhm.c * library/pkparse.c * library/x509_crl.c * library/x509_crt.c * library/x509_csr.c * * Requires: MBEDTLS_BASE64_C * * This modules adds support for decoding / parsing PEM files. */
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_PK_WRITE_C
/** * \def MBEDTLS_PK_WRITE_C * * Enable the generic public (asymetric) key writer. * * Module: library/pkwrite.c * Caller: library/x509write.c * * Requires: MBEDTLS_PK_C * * Uncomment to enable generic public key write functions. */
#define MBEDTLS_PKCS5_C
#define MBEDTLS_PKCS12_C
#define MBEDTLS_PLATFORM_C
#define MBEDTLS_RSA_C
#define MBEDTLS_SHA1_C
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_TIMING_C
#define MBEDTLS_VERSION_C
#define MBEDTLS_X509_USE_C
#define MBEDTLS_X509_CSR_PARSE_C
/** * \def MBEDTLS_X509_CSR_PARSE_C * * Enable X.509 Certificate Signing Request (CSR) parsing. * * Module: library/x509_csr.c * Caller: library/x509_crt_write.c * * Requires: MBEDTLS_X509_USE_C * * This module is used for reading X.509 certificate request. */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 5200 /**< Maxium fragment length in bytes, determines the size of each of the two internal I/O buffers */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384
#define MBEDTLS_TLS_DEFAULT_ALLOW_SHA1_IN_KEY_EXCHANGE
/** * Allow SHA-1 in the default TLS configuration for TLS 1.2 handshake * signature and ciphersuite selection. Without this build-time option, SHA-1 * support must be activated explicitly through mbedtls_ssl_conf_sig_hashes. * The use of SHA-1 in TLS <= 1.1 and in HMAC-SHA-1 is always allowed by * default. At the time of writing, there is no practical attack on the use * of SHA-1 in handshake signatures, hence this option is turned on by default * to preserve compatibility with existing peers, but the general * warning applies nonetheless: * * \warning SHA-1 is considered a weak message digest and its use constitutes * a security risk. If possible, we recommend avoiding dependencies * on it, and considering stronger message digests instead. * */
