#include "config.h"
#include "config.h"
#include MBEDTLS_CONFIG_FILE
#include "bignum.h"
#include "bignum.h"
#include "ecp_alt.h"
#define MBEDTLS_ECP_H
#define MBEDTLS_ERR_ECP_BAD_INPUT_DATA -20352 /**< Bad input parameters to function. */
/* * ECP error codes */
#define MBEDTLS_ERR_ECP_BUFFER_TOO_SMALL -20224 /**< The buffer is too small to write to. */
#define MBEDTLS_ERR_ECP_FEATURE_UNAVAILABLE -4E80 /**< The requested feature is not available, for example, the requested curve is not supported. */
#define MBEDTLS_ERR_ECP_VERIFY_FAILED -4E00 /**< The signature is not valid. */
#define MBEDTLS_ERR_ECP_ALLOC_FAILED -4D80 /**< Memory allocation failed. */
#define MBEDTLS_ERR_ECP_RANDOM_FAILED -4D00 /**< Generation of random value, such as ephemeral key, failed. */
#define MBEDTLS_ERR_ECP_INVALID_KEY -4C80 /**< Invalid private or public key. */
#define MBEDTLS_ERR_ECP_SIG_LEN_MISMATCH -4C00 /**< The buffer contains a valid signature followed by more data. */
#define MBEDTLS_ERR_ECP_HW_ACCEL_FAILED -4B80 /**< The ECP hardware accelerator failed. */
/* MBEDTLS_ERR_ECP_HW_ACCEL_FAILED is deprecated and should not be used. */
#define MBEDTLS_ERR_ECP_IN_PROGRESS -4B00 /**< Operation in progress, call again with the same parameters to continue. */
#define MBEDTLS_ECP_DP_MAX 12
/** * The number of supported curves, plus one for #MBEDTLS_ECP_DP_NONE. * * \note Montgomery curves are currently excluded. */
#define MBEDTLS_ECP_MAX_BITS 521 /**< The maximum size of groups, in bits. */
/** * The maximum size of the groups, that is, of \c N and \c P. */
#define MBEDTLS_ECP_MAX_BYTES ( ( MBEDTLS_ECP_MAX_BITS + 7 ) / 8 )
#define MBEDTLS_ECP_MAX_PT_LEN ( 2 * MBEDTLS_ECP_MAX_BYTES + 1 )
#define MBEDTLS_ECP_WINDOW_SIZE 6 /**< The maximum window size used. */
/* * Maximum "window" size used for point multiplication. * Default: 6. * Minimum value: 2. Maximum value: 7. * * Result is an array of at most ( 1 << ( MBEDTLS_ECP_WINDOW_SIZE - 1 ) ) * points used for point multiplication. This value is directly tied to EC * peak memory usage, so decreasing it by one should roughly cut memory usage * by two (if large curves are in use). * * Reduction in size may reduce speed, but larger curves are impacted first. * Sample performances (in ECDHE handshakes/s, with FIXED_POINT_OPTIM = 1): * w-size: 6 5 4 3 2 * 521 145 141 135 120 97 * 384 214 209 198 177 146 * 256 320 320 303 262 226 * 224 475 475 453 398 342 * 192 640 640 633 587 476 */
#define MBEDTLS_ECP_FIXED_POINT_OPTIM 1 /**< Enable fixed-point speed-up. */
/* * Trade memory for speed on fixed-point multiplication. * * This speeds up repeated multiplication of the generator (that is, the * multiplication in ECDSA signatures, and half of the multiplications in * ECDSA verification and ECDHE) by a factor roughly 3 to 4. * * The cost is increasing EC peak memory usage by a factor roughly 2. * * Change this value to 0 to reduce peak memory usage. */
#define MBEDTLS_ECP_OPS_CHK 3 /*!< basic ops count for ecp_check_pubkey() */
/* * Operation counts for restartable functions */
#define MBEDTLS_ECP_OPS_DBL 8 /*!< basic ops count for ecp_double_jac() */
#define MBEDTLS_ECP_OPS_ADD 11 /*!< basic ops count for see ecp_add_mixed() */
#define MBEDTLS_ECP_OPS_INV 120 /*!< empirical equivalent for mpi_mod_inv() */
#define MBEDTLS_ECP_BUDGET( ops ) \
MBEDTLS_MPI_CHK( mbedtls_ecp_check_budget( grp, rs_ctx, \
(unsigned) (ops) ) );
/* Utility macro for checking and updating ops budget */
#define MBEDTLS_ECP_BUDGET( ops ) /* no-op; for compatibility */
#define MBEDTLS_ECP_PF_UNCOMPRESSED 0 /**< Uncompressed point format. */
/* * Point formats, from RFC 4492's enum ECPointFormat */
#define MBEDTLS_ECP_PF_COMPRESSED 1 /**< Compressed point format. */
#define MBEDTLS_ECP_TLS_NAMED_CURVE 3 /**< The named_curve of ECCurveType. */
/* * Some other constants from RFC 4492 */
int mbedtls_ecp_check_budget( const mbedtls_ecp_group *grp,
mbedtls_ecp_restart_ctx *rs_ctx,
unsigned ops );
/** * \brief Internal; for restartable functions in other modules. * Check and update basic ops budget. * * \param grp Group structure * \param rs_ctx Restart context * \param ops Number of basic ops to do * * \return \c 0 if doing \p ops basic ops is still allowed, * \return #MBEDTLS_ERR_ECP_IN_PROGRESS otherwise. */
void mbedtls_ecp_set_max_ops( unsigned max_ops );
/** * \brief Set the maximum number of basic operations done in a row. * * If more operations are needed to complete a computation, * #MBEDTLS_ERR_ECP_IN_PROGRESS will be returned by the * function performing the computation. It is then the * caller's responsibility to either call again with the same * parameters until it returns 0 or an error code; or to free * the restart context if the operation is to be aborted. * * It is strictly required that all input parameters and the * restart context be the same on successive calls for the * same operation, but output parameters need not be the * same; they must not be used until the function finally * returns 0. * * This only applies to functions whose documentation * mentions they may return #MBEDTLS_ERR_ECP_IN_PROGRESS (or * #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS for functions in the * SSL module). For functions that accept a "restart context" * argument, passing NULL disables restart and makes the * function equivalent to the function with the same name * with \c _restartable removed. For functions in the ECDH * module, restart is disabled unless the function accepts * an "ECDH context" argument and * mbedtls_ecdh_enable_restart() was previously called on * that context. For function in the SSL module, restart is * only enabled for specific sides and key exchanges * (currently only for clients and ECDHE-ECDSA). * * \param max_ops Maximum number of basic operations done in a row. * Default: 0 (unlimited). * Lower (non-zero) values mean ECC functions will block for * a lesser maximum amount of time. * * \note A "basic operation" is defined as a rough equivalent of a * multiplication in GF(p) for the NIST P-256 curve. * As an indication, with default settings, a scalar * multiplication (full run of \c mbedtls_ecp_mul()) is: * - about 3300 basic operations for P-256 * - about 9400 basic operations for P-384 * * \note Very low values are not always respected: sometimes * functions need to block for a minimum number of * operations, and will do so even if max_ops is set to a * lower value. That minimum depends on the curve size, and * can be made lower by decreasing the value of * \c MBEDTLS_ECP_WINDOW_SIZE. As an indication, here is the * lowest effective value for various curves and values of * that parameter (w for short): * w=6 w=5 w=4 w=3 w=2 * P-256 208 208 160 136 124 * P-384 682 416 320 272 248 * P-521 1364 832 640 544 496 * * \note This setting is currently ignored by Curve25519. */
int mbedtls_ecp_restart_is_enabled( void );
/** * \brief Check if restart is enabled (max_ops != 0) * * \return \c 0 if \c max_ops == 0 (restart disabled) * \return \c 1 otherwise (restart enabled) */
void mbedtls_ecp_point_init( mbedtls_ecp_point *pt );
/** * \brief This function initializes a point as zero. * * \param pt The point to initialize. */
void mbedtls_ecp_group_init( mbedtls_ecp_group *grp );
/** * \brief This function initializes an ECP group context * without loading any domain parameters. * * \note After this function is called, domain parameters * for various ECP groups can be loaded through the * mbedtls_ecp_group_load() or mbedtls_ecp_tls_read_group() * functions. */
void mbedtls_ecp_keypair_init( mbedtls_ecp_keypair *key );
/** * \brief This function initializes a key pair as an invalid one. * * \param key The key pair to initialize. */
void mbedtls_ecp_point_free( mbedtls_ecp_point *pt );
/** * \brief This function frees the components of a point. * * \param pt The point to free. */
void mbedtls_ecp_group_free( mbedtls_ecp_group *grp );
/** * \brief This function frees the components of an ECP group. * * \param grp The group to free. This may be \c NULL, in which * case this function returns immediately. If it is not * \c NULL, it must point to an initialized ECP group. */
void mbedtls_ecp_keypair_free( mbedtls_ecp_keypair *key );
/** * \brief This function frees the components of a key pair. * * \param key The key pair to free. This may be \c NULL, in which * case this function returns immediately. If it is not * \c NULL, it must point to an initialized ECP key pair. */
void mbedtls_ecp_restart_init( mbedtls_ecp_restart_ctx *ctx );
/** * \brief Initialize a restart context. * * \param ctx The restart context to initialize. This must * not be \c NULL. */
void mbedtls_ecp_restart_free( mbedtls_ecp_restart_ctx *ctx );
/** * \brief Free the components of a restart context. * * \param ctx The restart context to free. This may be \c NULL, in which * case this function returns immediately. If it is not * \c NULL, it must point to an initialized restart context. */
int mbedtls_ecp_copy( mbedtls_ecp_point *P, const mbedtls_ecp_point *Q );
/** * \brief This function copies the contents of point \p Q into * point \p P. * * \param P The destination point. This must be initialized. * \param Q The source point. This must be initialized. * * \return \c 0 on success. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory-allocation failure. * \return Another negative error code for other kinds of failure. */
int mbedtls_ecp_group_copy( mbedtls_ecp_group *dst,
const mbedtls_ecp_group *src );
/** * \brief This function copies the contents of group \p src into * group \p dst. * * \param dst The destination group. This must be initialized. * \param src The source group. This must be initialized. * * \return \c 0 on success. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory-allocation failure. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_set_zero( mbedtls_ecp_point *pt );
/** * \brief This function sets a point to the point at infinity. * * \param pt The point to set. This must be initialized. * * \return \c 0 on success. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory-allocation failure. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_is_zero( mbedtls_ecp_point *pt );
/** * \brief This function checks if a point is the point at infinity. * * \param pt The point to test. This must be initialized. * * \return \c 1 if the point is zero. * \return \c 0 if the point is non-zero. * \return A negative error code on failure. */
int mbedtls_ecp_point_cmp( const mbedtls_ecp_point *P,
/** * \brief This function compares two points. * * \note This assumes that the points are normalized. Otherwise, * they may compare as "not equal" even if they are. * * \param P The first point to compare. This must be initialized. * \param Q The second point to compare. This must be initialized. * * \return \c 0 if the points are equal. * \return #MBEDTLS_ERR_ECP_BAD_INPUT_DATA if the points are not equal. */
int mbedtls_ecp_point_read_string( mbedtls_ecp_point *P, int radix,
const char *x, const char *y );
/** * \brief This function imports a non-zero point from two ASCII * strings. * * \param P The destination point. This must be initialized. * \param radix The numeric base of the input. * \param x The first affine coordinate, as a null-terminated string. * \param y The second affine coordinate, as a null-terminated string. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_MPI_XXX error code on failure. */
int mbedtls_ecp_point_write_binary( const mbedtls_ecp_group *grp, const mbedtls_ecp_point *P,
int format, size_t *olen,
unsigned char *buf, size_t buflen );
/** * \brief This function exports a point into unsigned binary data. * * \param grp The group to which the point should belong. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param P The point to export. This must be initialized. * \param format The point format. This must be either * #MBEDTLS_ECP_PF_COMPRESSED or #MBEDTLS_ECP_PF_UNCOMPRESSED. * \param olen The address at which to store the length of * the output in Bytes. This must not be \c NULL. * \param buf The output buffer. This must be a writable buffer * of length \p buflen Bytes. * \param buflen The length of the output buffer \p buf in Bytes. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_BUFFER_TOO_SMALL if the output buffer * is too small to hold the point. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_point_read_binary( const mbedtls_ecp_group *grp,
const unsigned char *buf, size_t ilen );
/** * \brief This function imports a point from unsigned binary data. * * \note This function does not check that the point actually * belongs to the given group, see mbedtls_ecp_check_pubkey() * for that. * * \param grp The group to which the point should belong. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param P The destination context to import the point to. * This must be initialized. * \param buf The input buffer. This must be a readable buffer * of length \p ilen Bytes. * \param ilen The length of the input buffer \p buf in Bytes. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_BAD_INPUT_DATA if the input is invalid. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory-allocation failure. * \return #MBEDTLS_ERR_ECP_FEATURE_UNAVAILABLE if the point format * is not implemented. */
int mbedtls_ecp_tls_read_point( const mbedtls_ecp_group *grp,
mbedtls_ecp_point *pt,
const unsigned char **buf, size_t len );
/** * \brief This function imports a point from a TLS ECPoint record. * * \note On function return, \p *buf is updated to point immediately * after the ECPoint record. * * \param grp The ECP group to use. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param pt The destination point. * \param buf The address of the pointer to the start of the input buffer. * \param len The length of the buffer. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_MPI_XXX error code on initialization * failure. * \return #MBEDTLS_ERR_ECP_BAD_INPUT_DATA if input is invalid. */
int mbedtls_ecp_tls_write_point( const mbedtls_ecp_group *grp,
const mbedtls_ecp_point *pt,
unsigned char *buf, size_t blen );
/** * \brief This function exports a point as a TLS ECPoint record * defined in RFC 4492, Section 5.4. * * \param grp The ECP group to use. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param pt The point to be exported. This must be initialized. * \param format The point format to use. This must be either * #MBEDTLS_ECP_PF_COMPRESSED or #MBEDTLS_ECP_PF_UNCOMPRESSED. * \param olen The address at which to store the length in Bytes * of the data written. * \param buf The target buffer. This must be a writable buffer of * length \p blen Bytes. * \param blen The length of the target buffer \p buf in Bytes. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_BAD_INPUT_DATA if the input is invalid. * \return #MBEDTLS_ERR_ECP_BUFFER_TOO_SMALL if the target buffer * is too small to hold the exported point. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_group_load( mbedtls_ecp_group *grp, mbedtls_ecp_group_id id );
/** * \brief This function sets up an ECP group context * from a standardized set of domain parameters. * * \note The index should be a value of the NamedCurve enum, * as defined in RFC-4492: Elliptic Curve Cryptography * (ECC) Cipher Suites for Transport Layer Security (TLS), * usually in the form of an \c MBEDTLS_ECP_DP_XXX macro. * * \param grp The group context to setup. This must be initialized. * \param id The identifier of the domain parameter set to load. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_FEATURE_UNAVAILABLE if \p id doesn't * correspond to a known group. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_tls_read_group( mbedtls_ecp_group *grp,
/** * \brief This function sets up an ECP group context from a TLS * ECParameters record as defined in RFC 4492, Section 5.4. * * \note The read pointer \p buf is updated to point right after * the ECParameters record on exit. * * \param grp The group context to setup. This must be initialized. * \param buf The address of the pointer to the start of the input buffer. * \param len The length of the input buffer \c *buf in Bytes. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_BAD_INPUT_DATA if input is invalid. * \return #MBEDTLS_ERR_ECP_FEATURE_UNAVAILABLE if the group is not * recognized. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_tls_read_group_id( mbedtls_ecp_group_id *grp,
size_t len );
/** * \brief This function extracts an elliptic curve group ID from a * TLS ECParameters record as defined in RFC 4492, Section 5.4. * * \note The read pointer \p buf is updated to point right after * the ECParameters record on exit. * * \param grp The address at which to store the group id. * This must not be \c NULL. * \param buf The address of the pointer to the start of the input buffer. * \param len The length of the input buffer \c *buf in Bytes. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_BAD_INPUT_DATA if input is invalid. * \return #MBEDTLS_ERR_ECP_FEATURE_UNAVAILABLE if the group is not * recognized. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_tls_write_group( const mbedtls_ecp_group *grp,
size_t *olen,
/** * \brief This function exports an elliptic curve as a TLS * ECParameters record as defined in RFC 4492, Section 5.4. * * \param grp The ECP group to be exported. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param olen The address at which to store the number of Bytes written. * This must not be \c NULL. * \param buf The buffer to write to. This must be a writable buffer * of length \p blen Bytes. * \param blen The length of the output buffer \p buf in Bytes. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_BUFFER_TOO_SMALL if the output * buffer is too small to hold the exported group. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_mul( mbedtls_ecp_group *grp, mbedtls_ecp_point *R,
const mbedtls_mpi *m, const mbedtls_ecp_point *P,
int (*f_rng)(void *, unsigned char *, size_t), void *p_rng );
/** * \brief This function performs a scalar multiplication of a point * by an integer: \p R = \p m * \p P. * * It is not thread-safe to use same group in multiple threads. * * \note To prevent timing attacks, this function * executes the exact same sequence of base-field * operations for any valid \p m. It avoids any if-branch or * array index depending on the value of \p m. * * \note If \p f_rng is not NULL, it is used to randomize * intermediate results to prevent potential timing attacks * targeting these results. We recommend always providing * a non-NULL \p f_rng. The overhead is negligible. * * \param grp The ECP group to use. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param R The point in which to store the result of the calculation. * This must be initialized. * \param m The integer by which to multiply. This must be initialized. * \param P The point to multiply. This must be initialized. * \param f_rng The RNG function. This may be \c NULL if randomization * of intermediate results isn't desired (discouraged). * \param p_rng The RNG context to be passed to \p p_rng. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_INVALID_KEY if \p m is not a valid private * key, or \p P is not a valid public key. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory-allocation failure. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_mul_restartable( mbedtls_ecp_group *grp, mbedtls_ecp_point *R,
int (*f_rng)(void *, unsigned char *, size_t), void *p_rng,
mbedtls_ecp_restart_ctx *rs_ctx );
/** * \brief This function performs multiplication of a point by * an integer: \p R = \p m * \p P in a restartable way. * * \see mbedtls_ecp_mul() * * \note This function does the same as \c mbedtls_ecp_mul(), but * it can return early and restart according to the limit set * with \c mbedtls_ecp_set_max_ops() to reduce blocking. * * \param grp The ECP group to use. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param R The point in which to store the result of the calculation. * This must be initialized. * \param m The integer by which to multiply. This must be initialized. * \param P The point to multiply. This must be initialized. * \param f_rng The RNG function. This may be \c NULL if randomization * of intermediate results isn't desired (discouraged). * \param p_rng The RNG context to be passed to \p p_rng. * \param rs_ctx The restart context (NULL disables restart). * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_INVALID_KEY if \p m is not a valid private * key, or \p P is not a valid public key. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory-allocation failure. * \return #MBEDTLS_ERR_ECP_IN_PROGRESS if maximum number of * operations was reached: see \c mbedtls_ecp_set_max_ops(). * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_muladd( mbedtls_ecp_group *grp, mbedtls_ecp_point *R,
const mbedtls_mpi *n, const mbedtls_ecp_point *Q );
/** * \brief This function performs multiplication and addition of two * points by integers: \p R = \p m * \p P + \p n * \p Q * * It is not thread-safe to use same group in multiple threads. * * \note In contrast to mbedtls_ecp_mul(), this function does not * guarantee a constant execution flow and timing. * * \param grp The ECP group to use. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param R The point in which to store the result of the calculation. * This must be initialized. * \param m The integer by which to multiply \p P. * This must be initialized. * \param P The point to multiply by \p m. This must be initialized. * \param n The integer by which to multiply \p Q. * This must be initialized. * \param Q The point to be multiplied by \p n. * This must be initialized. * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_INVALID_KEY if \p m or \p n are not * valid private keys, or \p P or \p Q are not valid public * keys. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory-allocation failure. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_muladd_restartable(
const mbedtls_mpi *n, const mbedtls_ecp_point *Q,
/** * \brief This function performs multiplication and addition of two * points by integers: \p R = \p m * \p P + \p n * \p Q in a * restartable way. * * \see \c mbedtls_ecp_muladd() * * \note This function works the same as \c mbedtls_ecp_muladd(), * but it can return early and restart according to the limit * set with \c mbedtls_ecp_set_max_ops() to reduce blocking. * * \param grp The ECP group to use. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param R The point in which to store the result of the calculation. * This must be initialized. * \param m The integer by which to multiply \p P. * This must be initialized. * \param P The point to multiply by \p m. This must be initialized. * \param n The integer by which to multiply \p Q. * This must be initialized. * \param Q The point to be multiplied by \p n. * This must be initialized. * \param rs_ctx The restart context (NULL disables restart). * * \return \c 0 on success. * \return #MBEDTLS_ERR_ECP_INVALID_KEY if \p m or \p n are not * valid private keys, or \p P or \p Q are not valid public * keys. * \return #MBEDTLS_ERR_MPI_ALLOC_FAILED on memory-allocation failure. * \return #MBEDTLS_ERR_ECP_IN_PROGRESS if maximum number of * operations was reached: see \c mbedtls_ecp_set_max_ops(). * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_check_pubkey( const mbedtls_ecp_group *grp,
const mbedtls_ecp_point *pt );
/** * \brief This function checks that a point is a valid public key * on this curve. * * It only checks that the point is non-zero, has * valid coordinates and lies on the curve. It does not verify * that it is indeed a multiple of \p G. This additional * check is computationally more expensive, is not required * by standards, and should not be necessary if the group * used has a small cofactor. In particular, it is useless for * the NIST groups which all have a cofactor of 1. * * \note This function uses bare components rather than an * ::mbedtls_ecp_keypair structure, to ease use with other * structures, such as ::mbedtls_ecdh_context or * ::mbedtls_ecdsa_context. * * \param grp The ECP group the point should belong to. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param pt The point to check. This must be initialized. * * \return \c 0 if the point is a valid public key. * \return #MBEDTLS_ERR_ECP_INVALID_KEY if the point is not * a valid public key for the given curve. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_check_privkey( const mbedtls_ecp_group *grp,
const mbedtls_mpi *d );
/** * \brief This function checks that an \p mbedtls_mpi is a * valid private key for this curve. * * \note This function uses bare components rather than an * ::mbedtls_ecp_keypair structure to ease use with other * structures, such as ::mbedtls_ecdh_context or * ::mbedtls_ecdsa_context. * * \param grp The ECP group the private key should belong to. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param d The integer to check. This must be initialized. * * \return \c 0 if the point is a valid private key. * \return #MBEDTLS_ERR_ECP_INVALID_KEY if the point is not a valid * private key for the given curve. * \return Another negative error code on other kinds of failure. */
int mbedtls_ecp_gen_privkey( const mbedtls_ecp_group *grp,
mbedtls_mpi *d,
void *p_rng );
/** * \brief This function generates a private key. * * \param grp The ECP group to generate a private key for. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param d The destination MPI (secret part). This must be initialized. * \param f_rng The RNG function. This must not be \c NULL. * \param p_rng The RNG parameter to be passed to \p f_rng. This may be * \c NULL if \p f_rng doesn't need a context argument. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_ECP_XXX or \c MBEDTLS_MPI_XXX error code * on failure. */
int mbedtls_ecp_gen_keypair_base( mbedtls_ecp_group *grp,
const mbedtls_ecp_point *G,
mbedtls_mpi *d, mbedtls_ecp_point *Q,
void *p_rng );
/** * \brief This function generates a keypair with a configurable base * point. * * \note This function uses bare components rather than an * ::mbedtls_ecp_keypair structure to ease use with other * structures, such as ::mbedtls_ecdh_context or * ::mbedtls_ecdsa_context. * * \param grp The ECP group to generate a key pair for. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param G The base point to use. This must be initialized * and belong to \p grp. It replaces the default base * point \c grp->G used by mbedtls_ecp_gen_keypair(). * \param d The destination MPI (secret part). * This must be initialized. * \param Q The destination point (public part). * This must be initialized. * \param f_rng The RNG function. This must not be \c NULL. * \param p_rng The RNG context to be passed to \p f_rng. This may * be \c NULL if \p f_rng doesn't need a context argument. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_ECP_XXX or \c MBEDTLS_MPI_XXX error code * on failure. */
int mbedtls_ecp_gen_keypair( mbedtls_ecp_group *grp, mbedtls_mpi *d,
void *p_rng );
/** * \brief This function generates an ECP keypair. * * \note This function uses bare components rather than an * ::mbedtls_ecp_keypair structure to ease use with other * structures, such as ::mbedtls_ecdh_context or * ::mbedtls_ecdsa_context. * * \param grp The ECP group to generate a key pair for. * This must be initialized and have group parameters * set, for example through mbedtls_ecp_group_load(). * \param d The destination MPI (secret part). * This must be initialized. * \param Q The destination point (public part). * This must be initialized. * \param f_rng The RNG function. This must not be \c NULL. * \param p_rng The RNG context to be passed to \p f_rng. This may * be \c NULL if \p f_rng doesn't need a context argument. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_ECP_XXX or \c MBEDTLS_MPI_XXX error code * on failure. */
int mbedtls_ecp_gen_key( mbedtls_ecp_group_id grp_id, mbedtls_ecp_keypair *key,
void *p_rng );
/** * \brief This function generates an ECP key. * * \param grp_id The ECP group identifier. * \param key The destination key. This must be initialized. * \param f_rng The RNG function to use. This must not be \c NULL. * \param p_rng The RNG context to be passed to \p f_rng. This may * be \c NULL if \p f_rng doesn't need a context argument. * * \return \c 0 on success. * \return An \c MBEDTLS_ERR_ECP_XXX or \c MBEDTLS_MPI_XXX error code * on failure. */
int mbedtls_ecp_check_pub_priv( const mbedtls_ecp_keypair *pub,
const mbedtls_ecp_keypair *prv );
/** * \brief This function checks that the keypair objects * \p pub and \p prv have the same group and the * same public point, and that the private key in * \p prv is consistent with the public key. * * \param pub The keypair structure holding the public key. This * must be initialized. If it contains a private key, that * part is ignored. * \param prv The keypair structure holding the full keypair. * This must be initialized. * * \return \c 0 on success, meaning that the keys are valid and match. * \return #MBEDTLS_ERR_ECP_BAD_INPUT_DATA if the keys are invalid or do not match. * \return An \c MBEDTLS_ERR_ECP_XXX or an \c MBEDTLS_ERR_MPI_XXX * error code on calculation failure. */
int mbedtls_ecp_self_test( int verbose );
/** * \brief The ECP checkup routine. * * \return \c 0 on success. * \return \c 1 on failure. */
const mbedtls_ecp_curve_info *mbedtls_ecp_curve_list( void );
/** * \brief This function retrieves the information defined in * mbedtls_ecp_curve_info() for all supported curves in order * of preference. * * \return A statically allocated array. The last entry is 0. */
const mbedtls_ecp_group_id *mbedtls_ecp_grp_id_list( void );
/** * \brief This function retrieves the list of internal group * identifiers of all supported curves in the order of * preference. * * \return A statically allocated array, * terminated with MBEDTLS_ECP_DP_NONE. */
const mbedtls_ecp_curve_info *mbedtls_ecp_curve_info_from_grp_id( mbedtls_ecp_group_id grp_id );
/** * \brief This function retrieves curve information from an internal * group identifier. * * \param grp_id An \c MBEDTLS_ECP_DP_XXX value. * * \return The associated curve information on success. * \return NULL on failure. */
const mbedtls_ecp_curve_info *mbedtls_ecp_curve_info_from_tls_id( uint16_t tls_id );
/** * \brief This function retrieves curve information from a TLS * NamedCurve value. * * \param tls_id An \c MBEDTLS_ECP_DP_XXX value. * * \return The associated curve information on success. * \return NULL on failure. */
const mbedtls_ecp_curve_info *mbedtls_ecp_curve_info_from_name( const char *name );
/** * \brief This function retrieves curve information from a * human-readable name. * * \param name The human-readable name. * * \return The associated curve information on success. * \return NULL on failure. */
typedef enum
MBEDTLS_ECP_DP_NONE = 0, /*!< Curve not defined. */
MBEDTLS_ECP_DP_SECP192R1, /*!< Domain parameters for the 192-bit curve defined by FIPS 186-4 and SEC1. */
MBEDTLS_ECP_DP_SECP224R1, /*!< Domain parameters for the 224-bit curve defined by FIPS 186-4 and SEC1. */
MBEDTLS_ECP_DP_SECP256R1, /*!< Domain parameters for the 256-bit curve defined by FIPS 186-4 and SEC1. */
MBEDTLS_ECP_DP_SECP384R1, /*!< Domain parameters for the 384-bit curve defined by FIPS 186-4 and SEC1. */
MBEDTLS_ECP_DP_SECP521R1, /*!< Domain parameters for the 521-bit curve defined by FIPS 186-4 and SEC1. */
MBEDTLS_ECP_DP_BP256R1, /*!< Domain parameters for 256-bit Brainpool curve. */
MBEDTLS_ECP_DP_BP384R1, /*!< Domain parameters for 384-bit Brainpool curve. */
MBEDTLS_ECP_DP_BP512R1, /*!< Domain parameters for 512-bit Brainpool curve. */
MBEDTLS_ECP_DP_CURVE25519, /*!< Domain parameters for Curve25519. */
MBEDTLS_ECP_DP_SECP192K1, /*!< Domain parameters for 192-bit "Koblitz" curve. */
MBEDTLS_ECP_DP_SECP224K1, /*!< Domain parameters for 224-bit "Koblitz" curve. */
MBEDTLS_ECP_DP_SECP256K1, /*!< Domain parameters for 256-bit "Koblitz" curve. */
MBEDTLS_ECP_DP_CURVE448, /*!< Domain parameters for Curve448. */
} mbedtls_ecp_group_id;
/** * Domain-parameter identifiers: curve, subgroup, and generator. * * \note Only curves over prime fields are supported. * * \warning This library does not support validation of arbitrary domain * parameters. Therefore, only standardized domain parameters from trusted * sources should be used. See mbedtls_ecp_group_load(). */
typedef struct mbedtls_ecp_curve_info
mbedtls_ecp_group_id grp_id; /*!< An internal identifier. */
uint16_t tls_id; /*!< The TLS NamedCurve identifier. */
uint16_t bit_size; /*!< The curve size in bits. */
const char *name; /*!< A human-friendly name. */
} mbedtls_ecp_curve_info;
/** * Curve information, for use by other modules. */
typedef struct mbedtls_ecp_point
mbedtls_mpi X; /*!< The X coordinate of the ECP point. */
mbedtls_mpi Y; /*!< The Y coordinate of the ECP point. */
mbedtls_mpi Z; /*!< The Z coordinate of the ECP point. */
mbedtls_ecp_point;
/** * \brief The ECP point structure, in Jacobian coordinates. * * \note All functions expect and return points satisfying * the following condition:Z == 0or *Z == 1. Other values of \p Z are * used only by internal functions. * The point is zero, or "at infinity", ifZ == 0. * Otherwise, \p X and \p Y are its standard (affine) * coordinates. */
typedef struct mbedtls_ecp_group
mbedtls_ecp_group_id id; /*!< An internal group identifier. */
mbedtls_mpi P; /*!< The prime modulus of the base field. */
mbedtls_mpi A; /*!< For Short Weierstrass: \p A in the equation. For
Montgomery curves: (A + 2) / 4. */
mbedtls_mpi B; /*!< For Short Weierstrass: \p B in the equation.
For Montgomery curves: unused. */
mbedtls_ecp_point G; /*!< The generator of the subgroup used. */
mbedtls_mpi N; /*!< The order of \p G. */
size_t pbits; /*!< The number of bits in \p P.*/
size_t nbits; /*!< For Short Weierstrass: The number of bits in \p P.
For Montgomery curves: the number of bits in the
private keys. */
unsigned int h; /*!< \internal 1 if the constants are static. */
int (*modp)(mbedtls_mpi *); /*!< The function for fast pseudo-reduction
mod \p P (see above).*/
int (*t_pre)(mbedtls_ecp_point *, void *); /*!< Unused. */
int (*t_post)(mbedtls_ecp_point *, void *); /*!< Unused. */
void *t_data; /*!< Unused. */
mbedtls_ecp_point *T; /*!< Pre-computed points for ecp_mul_comb(). */
size_t T_size; /*!< The number of pre-computed points. */
mbedtls_ecp_group;
/** * \brief The ECP group structure. * * We consider two types of curve equations: *
y^2 = x^3 + A x + B mod P
* (SEC1 + RFC-4492)y^2 = x^3 + A x^2 + x mod P (Curve25519,
* Curve448)(A + 2) / 4,
* which is the quantity used in the formulas. Additionally, \p nbits is
* not the size of \p N but the required size for private keys.
* If \p modp is NULL, reduction modulo \p P is done using a generic algorithm.
* Otherwise, \p modp must point to a function that takes an \p mbedtls_mpi in the
* range of 0..2^(2*pbits)-1, and transforms it in-place to an integer
* which is congruent mod \p P to the given MPI, and is close enough to \p pbits
* in size, so that it may be efficiently brought in the 0..P-1 range by a few
* additions or subtractions. Therefore, it is only an approximative modular
* reduction. It must return 0 on success and non-zero on failure.
* \note Alternative implementations must keep the group IDs distinct. If
* two group structures have the same ID, then they must be
* identical.
typedef struct mbedtls_ecp_restart_mul mbedtls_ecp_restart_mul_ctx;
/** * \brief Internal restart context for multiplication * * \note Opaque struct */
typedef struct mbedtls_ecp_restart_muladd mbedtls_ecp_restart_muladd_ctx;
/** * \brief Internal restart context for ecp_muladd() * * \note Opaque struct */
typedef struct
unsigned ops_done; /*!< current ops count */
unsigned depth; /*!< call depth (0 = top-level) */
mbedtls_ecp_restart_mul_ctx *rsm; /*!< ecp_mul_comb() sub-context */
mbedtls_ecp_restart_muladd_ctx *ma; /*!< ecp_muladd() sub-context */
} mbedtls_ecp_restart_ctx;
/** * \brief General context for resuming ECC operations */
typedef void mbedtls_ecp_restart_ctx;
/* We want to declare restartable versions of existing functions anyway */
typedef struct mbedtls_ecp_keypair
mbedtls_ecp_group grp; /*!< Elliptic curve and base point */
mbedtls_mpi d; /*!< our secret value */
mbedtls_ecp_point Q; /*!< our public value */
mbedtls_ecp_keypair;
/** * \brief The ECP key-pair structure. * * A generic key-pair that may be used for ECDSA and fixed ECDH, for example. * * \note Members are deliberately in the same order as in the * ::mbedtls_ecdsa_context structure. */
