#include "config.h"
#include "config.h"
#include MBEDTLS_CONFIG_FILE
#include "x509.h"
#include "x509.h"
#include "x509_crl.h"
#define MBEDTLS_X509_CRT_H
#define MBEDTLS_X509_ID_FLAG( id ) ( 1 << ( (id) - 1 ) )
/** * Build flag from an algorithm/curve identifier (pk, md, ecp) * Since 0 is always XXX_NONE, ignore it. */
#define MBEDTLS_X509_CRT_VERSION_1 0
#define MBEDTLS_X509_CRT_VERSION_2 1
#define MBEDTLS_X509_CRT_VERSION_3 2
#define MBEDTLS_X509_RFC5280_MAX_SERIAL_LEN 32
#define MBEDTLS_X509_RFC5280_UTC_TIME_LEN 15
#define MBEDTLS_X509_MAX_FILE_PATH_LEN 512
#define MBEDTLS_X509_MAX_VERIFY_CHAIN_SIZE ( MBEDTLS_X509_MAX_INTERMEDIATE_CA + 2 )
/** * Max size of verification chain: end-entity + intermediates + trusted root */
int mbedtls_x509_crt_parse_der( mbedtls_x509_crt *chain, const unsigned char *buf,
size_t buflen );
/** * \brief Parse a single DER formatted certificate and add it * to the chained list. * * \param chain points to the start of the chain * \param buf buffer holding the certificate DER data * \param buflen size of the buffer * * \return 0 if successful, or a specific X509 or PEM error code */
int mbedtls_x509_crt_parse( mbedtls_x509_crt *chain, const unsigned char *buf, size_t buflen );
* \brief Parse one DER-encoded or one or more concatenated PEM-encoded
* certificates and add them to the chained list.
* For CRTs in PEM encoding, the function parses permissively:
* if at least one certificate can be parsed, the function
* returns the number of certificates for which parsing failed
* (hence \c 0 if all certificates were parsed successfully).
* If no certificate could be parsed, the function returns
* the first (negative) error encountered during parsing.
* PEM encoded certificates may be interleaved by other data
* such as human readable descriptions of their content, as
* long as the certificates are enclosed in the PEM specific
* '-----{BEGIN/END} CERTIFICATE-----' delimiters.
* \param chain The chain to which to add the parsed certificates.
* \param buf The buffer holding the certificate data in PEM or DER format.
* For certificates in PEM encoding, this may be a concatenation
* of multiple certificates; for DER encoding, the buffer must
* comprise exactly one certificate.
* \param buflen The size of \p buf, including the terminating \c NULL byte
* in case of PEM encoded data.
* \return \c 0 if all certificates were parsed successfully.
* \return The (positive) number of certificates that couldn't
* be parsed if parsing was partly successful (see above).
* \return A negative X509 or PEM error code otherwise.
int mbedtls_x509_crt_parse_file( mbedtls_x509_crt *chain, const char *path );
/** * \brief Load one or more certificates and add them * to the chained list. Parses permissively. If some * certificates can be parsed, the result is the number * of failed certificates it encountered. If none complete * correctly, the first error is returned. * * \param chain points to the start of the chain * \param path filename to read the certificates from * * \return 0 if all certificates parsed successfully, a positive number * if partly successful or a specific X509 or PEM error code */
int mbedtls_x509_crt_parse_path( mbedtls_x509_crt *chain, const char *path );
/** * \brief Load one or more certificate files from a path and add them * to the chained list. Parses permissively. If some * certificates can be parsed, the result is the number * of failed certificates it encountered. If none complete * correctly, the first error is returned. * * \param chain points to the start of the chain * \param path directory / folder to read the certificate files from * * \return 0 if all certificates parsed successfully, a positive number * if partly successful or a specific X509 or PEM error code */
int mbedtls_x509_crt_info( char *buf, size_t size, const char *prefix,
const mbedtls_x509_crt *crt );
/** * \brief Returns an informational string about the * certificate. * * \param buf Buffer to write to * \param size Maximum size of buffer * \param prefix A line prefix * \param crt The X509 certificate to represent * * \return The length of the string written (not including the * terminated nul byte), or a negative error code. */
int mbedtls_x509_crt_verify_info( char *buf, size_t size, const char *prefix,
uint32_t flags );
/** * \brief Returns an informational string about the * verification status of a certificate. * * \param buf Buffer to write to * \param size Maximum size of buffer * \param prefix A line prefix * \param flags Verification flags created by mbedtls_x509_crt_verify() * * \return The length of the string written (not including the * terminated nul byte), or a negative error code. */
int mbedtls_x509_crt_verify( mbedtls_x509_crt *crt,
mbedtls_x509_crt *trust_ca,
mbedtls_x509_crl *ca_crl,
const char *cn, uint32_t *flags,
int (*f_vrfy)(void *, mbedtls_x509_crt *, int, uint32_t *),
void *p_vrfy );
/** * \brief Verify the certificate signature * * The verify callback is a user-supplied callback that * can clear / modify / add flags for a certificate. If set, * the verification callback is called for each * certificate in the chain (from the trust-ca down to the * presented crt). The parameters for the callback are: * (void *parameter, mbedtls_x509_crt *crt, int certificate_depth, * int *flags). With the flags representing current flags for * that specific certificate and the certificate depth from * the bottom (Peer cert depth = 0). * * All flags left after returning from the callback * are also returned to the application. The function should * return 0 for anything (including invalid certificates) * other than fatal error, as a non-zero return code * immediately aborts the verification process. For fatal * errors, a specific error code should be used (different * from MBEDTLS_ERR_X509_CERT_VERIFY_FAILED which should not * be returned at this point), or MBEDTLS_ERR_X509_FATAL_ERROR * can be used if no better code is available. * * \note In case verification failed, the results can be displayed * using \c mbedtls_x509_crt_verify_info() * * \note Same as \c mbedtls_x509_crt_verify_with_profile() with the * default security profile. * * \note It is your responsibility to provide up-to-date CRLs for * all trusted CAs. If no CRL is provided for the CA that was * used to sign the certificate, CRL verification is skipped * silently, that is *without* setting any flag. * * \note The \c trust_ca list can contain two types of certificates: * (1) those of trusted root CAs, so that certificates * chaining up to those CAs will be trusted, and (2) * self-signed end-entity certificates to be trusted (for * specific peers you know) - in that case, the self-signed * certificate doesn't need to have the CA bit set. * * \param crt a certificate (chain) to be verified * \param trust_ca the list of trusted CAs (see note above) * \param ca_crl the list of CRLs for trusted CAs (see note above) * \param cn expected Common Name (can be set to * NULL if the CN must not be verified) * \param flags result of the verification * \param f_vrfy verification function * \param p_vrfy verification parameter * * \return 0 (and flags set to 0) if the chain was verified and valid, * MBEDTLS_ERR_X509_CERT_VERIFY_FAILED if the chain was verified * but found to be invalid, in which case *flags will have one * or more MBEDTLS_X509_BADCERT_XXX or MBEDTLS_X509_BADCRL_XXX * flags set, or another error (and flags set to 0xffffffff) * in case of a fatal error encountered during the * verification process. */
int mbedtls_x509_crt_verify_with_profile( mbedtls_x509_crt *crt,
const mbedtls_x509_crt_profile *profile,
void *p_vrfy );
/** * \brief Verify the certificate signature according to profile * * \note Same as \c mbedtls_x509_crt_verify(), but with explicit * security profile. * * \note The restrictions on keys (RSA minimum size, allowed curves * for ECDSA) apply to all certificates: trusted root, * intermediate CAs if any, and end entity certificate. * * \param crt a certificate (chain) to be verified * \param trust_ca the list of trusted CAs * \param ca_crl the list of CRLs for trusted CAs * \param profile security profile for verification * \param cn expected Common Name (can be set to * NULL if the CN must not be verified) * \param flags result of the verification * \param f_vrfy verification function * \param p_vrfy verification parameter * * \return 0 if successful or MBEDTLS_ERR_X509_CERT_VERIFY_FAILED * in which case *flags will have one or more * MBEDTLS_X509_BADCERT_XXX or MBEDTLS_X509_BADCRL_XXX flags * set, * or another error in case of a fatal error encountered * during the verification process. */
int mbedtls_x509_crt_verify_restartable( mbedtls_x509_crt *crt,
void *p_vrfy,
mbedtls_x509_crt_restart_ctx *rs_ctx );
/** * \brief Restartable version of \c mbedtls_crt_verify_with_profile() * * \note Performs the same job as \c mbedtls_crt_verify_with_profile() * but can return early and restart according to the limit * set with \c mbedtls_ecp_set_max_ops() to reduce blocking. * * \param crt a certificate (chain) to be verified * \param trust_ca the list of trusted CAs * \param ca_crl the list of CRLs for trusted CAs * \param profile security profile for verification * \param cn expected Common Name (can be set to * NULL if the CN must not be verified) * \param flags result of the verification * \param f_vrfy verification function * \param p_vrfy verification parameter * \param rs_ctx restart context (NULL to disable restart) * * \return See \c mbedtls_crt_verify_with_profile(), or * \return #MBEDTLS_ERR_ECP_IN_PROGRESS if maximum number of * operations was reached: see \c mbedtls_ecp_set_max_ops(). */
int mbedtls_x509_crt_check_key_usage( const mbedtls_x509_crt *crt,
unsigned int usage );
/** * \brief Check usage of certificate against keyUsage extension. * * \param crt Leaf certificate used. * \param usage Intended usage(s) (eg MBEDTLS_X509_KU_KEY_ENCIPHERMENT * before using the certificate to perform an RSA key * exchange). * * \note Except for decipherOnly and encipherOnly, a bit set in the * usage argument means this bit MUST be set in the * certificate. For decipherOnly and encipherOnly, it means * that bit MAY be set. * * \return 0 is these uses of the certificate are allowed, * MBEDTLS_ERR_X509_BAD_INPUT_DATA if the keyUsage extension * is present but does not match the usage argument. * * \note You should only call this function on leaf certificates, on * (intermediate) CAs the keyUsage extension is automatically * checked by \c mbedtls_x509_crt_verify(). */
int mbedtls_x509_crt_check_extended_key_usage( const mbedtls_x509_crt *crt,
const char *usage_oid,
size_t usage_len );
/** * \brief Check usage of certificate against extendedKeyUsage. * * \param crt Leaf certificate used. * \param usage_oid Intended usage (eg MBEDTLS_OID_SERVER_AUTH or * MBEDTLS_OID_CLIENT_AUTH). * \param usage_len Length of usage_oid (eg given by MBEDTLS_OID_SIZE()). * * \return 0 if this use of the certificate is allowed, * MBEDTLS_ERR_X509_BAD_INPUT_DATA if not. * * \note Usually only makes sense on leaf certificates. */
int mbedtls_x509_crt_is_revoked( const mbedtls_x509_crt *crt, const mbedtls_x509_crl *crl );
/** * \brief Verify the certificate revocation status * * \param crt a certificate to be verified * \param crl the CRL to verify against * * \return 1 if the certificate is revoked, 0 otherwise * */
void mbedtls_x509_crt_init( mbedtls_x509_crt *crt );
/** * \brief Initialize a certificate (chain) * * \param crt Certificate chain to initialize */
void mbedtls_x509_crt_free( mbedtls_x509_crt *crt );
/** * \brief Unallocate all certificate data * * \param crt Certificate chain to free */
void mbedtls_x509_crt_restart_init( mbedtls_x509_crt_restart_ctx *ctx );
/** * \brief Initialize a restart context */
void mbedtls_x509_crt_restart_free( mbedtls_x509_crt_restart_ctx *ctx );
/** * \brief Free the components of a restart context */
void mbedtls_x509write_crt_init( mbedtls_x509write_cert *ctx );
/** * \brief Initialize a CRT writing context * * \param ctx CRT context to initialize */
void mbedtls_x509write_crt_set_version( mbedtls_x509write_cert *ctx, int version );
/** * \brief Set the verion for a Certificate * Default: MBEDTLS_X509_CRT_VERSION_3 * * \param ctx CRT context to use * \param version version to set (MBEDTLS_X509_CRT_VERSION_1, MBEDTLS_X509_CRT_VERSION_2 or * MBEDTLS_X509_CRT_VERSION_3) */
int mbedtls_x509write_crt_set_serial( mbedtls_x509write_cert *ctx, const mbedtls_mpi *serial );
/** * \brief Set the serial number for a Certificate. * * \param ctx CRT context to use * \param serial serial number to set * * \return 0 if successful */
int mbedtls_x509write_crt_set_validity( mbedtls_x509write_cert *ctx, const char *not_before,
const char *not_after );
/** * \brief Set the validity period for a Certificate * Timestamps should be in string format for UTC timezone * i.e. "YYYYMMDDhhmmss" * e.g. "20131231235959" for December 31st 2013 * at 23:59:59 * * \param ctx CRT context to use * \param not_before not_before timestamp * \param not_after not_after timestamp * * \return 0 if timestamp was parsed successfully, or * a specific error code */
int mbedtls_x509write_crt_set_issuer_name( mbedtls_x509write_cert *ctx,
const char *issuer_name );
/** * \brief Set the issuer name for a Certificate * Issuer names should contain a comma-separated list * of OID types and values: * e.g. "C=UK,O=ARM,CN=mbed TLS CA" * * \param ctx CRT context to use * \param issuer_name issuer name to set * * \return 0 if issuer name was parsed successfully, or * a specific error code */
int mbedtls_x509write_crt_set_subject_name( mbedtls_x509write_cert *ctx,
const char *subject_name );
/** * \brief Set the subject name for a Certificate * Subject names should contain a comma-separated list * of OID types and values: * e.g. "C=UK,O=ARM,CN=mbed TLS Server 1" * * \param ctx CRT context to use * \param subject_name subject name to set * * \return 0 if subject name was parsed successfully, or * a specific error code */
void mbedtls_x509write_crt_set_subject_key( mbedtls_x509write_cert *ctx, mbedtls_pk_context *key );
/** * \brief Set the subject public key for the certificate * * \param ctx CRT context to use * \param key public key to include */
void mbedtls_x509write_crt_set_issuer_key( mbedtls_x509write_cert *ctx, mbedtls_pk_context *key );
/** * \brief Set the issuer key used for signing the certificate * * \param ctx CRT context to use * \param key private key to sign with */
void mbedtls_x509write_crt_set_md_alg( mbedtls_x509write_cert *ctx, mbedtls_md_type_t md_alg );
/** * \brief Set the MD algorithm to use for the signature * (e.g. MBEDTLS_MD_SHA1) * * \param ctx CRT context to use * \param md_alg MD algorithm to use */
int mbedtls_x509write_crt_set_extension( mbedtls_x509write_cert *ctx,
const char *oid, size_t oid_len,
int critical,
const unsigned char *val, size_t val_len );
/** * \brief Generic function to add to or replace an extension in the * CRT * * \param ctx CRT context to use * \param oid OID of the extension * \param oid_len length of the OID * \param critical if the extension is critical (per the RFC's definition) * \param val value of the extension OCTET STRING * \param val_len length of the value data * * \return 0 if successful, or a MBEDTLS_ERR_X509_ALLOC_FAILED */
int mbedtls_x509write_crt_set_basic_constraints( mbedtls_x509write_cert *ctx,
int is_ca, int max_pathlen );
/** * \brief Set the basicConstraints extension for a CRT * * \param ctx CRT context to use * \param is_ca is this a CA certificate * \param max_pathlen maximum length of certificate chains below this * certificate (only for CA certificates, -1 is * inlimited) * * \return 0 if successful, or a MBEDTLS_ERR_X509_ALLOC_FAILED */
int mbedtls_x509write_crt_set_subject_key_identifier( mbedtls_x509write_cert *ctx );
/** * \brief Set the subjectKeyIdentifier extension for a CRT * Requires that mbedtls_x509write_crt_set_subject_key() has been * called before * * \param ctx CRT context to use * * \return 0 if successful, or a MBEDTLS_ERR_X509_ALLOC_FAILED */
int mbedtls_x509write_crt_set_authority_key_identifier( mbedtls_x509write_cert *ctx );
/** * \brief Set the authorityKeyIdentifier extension for a CRT * Requires that mbedtls_x509write_crt_set_issuer_key() has been * called before * * \param ctx CRT context to use * * \return 0 if successful, or a MBEDTLS_ERR_X509_ALLOC_FAILED */
int mbedtls_x509write_crt_set_key_usage( mbedtls_x509write_cert *ctx,
unsigned int key_usage );
/** * \brief Set the Key Usage Extension flags * (e.g. MBEDTLS_X509_KU_DIGITAL_SIGNATURE | MBEDTLS_X509_KU_KEY_CERT_SIGN) * * \param ctx CRT context to use * \param key_usage key usage flags to set * * \return 0 if successful, or MBEDTLS_ERR_X509_ALLOC_FAILED */
int mbedtls_x509write_crt_set_ns_cert_type( mbedtls_x509write_cert *ctx,
unsigned char ns_cert_type );
/** * \brief Set the Netscape Cert Type flags * (e.g. MBEDTLS_X509_NS_CERT_TYPE_SSL_CLIENT | MBEDTLS_X509_NS_CERT_TYPE_EMAIL) * * \param ctx CRT context to use * \param ns_cert_type Netscape Cert Type flags to set * * \return 0 if successful, or MBEDTLS_ERR_X509_ALLOC_FAILED */
void mbedtls_x509write_crt_free( mbedtls_x509write_cert *ctx );
/** * \brief Free the contents of a CRT write context * * \param ctx CRT context to free */
int mbedtls_x509write_crt_der( mbedtls_x509write_cert *ctx, unsigned char *buf, size_t size,
int (*f_rng)(void *, unsigned char *, size_t),
void *p_rng );
/** * \brief Write a built up certificate to a X509 DER structure * Note: data is written at the end of the buffer! Use the * return value to determine where you should start * using the buffer * * \param ctx certificate to write away * \param buf buffer to write to * \param size size of the buffer * \param f_rng RNG function (for signature, see note) * \param p_rng RNG parameter * * \return length of data written if successful, or a specific * error code * * \note f_rng may be NULL if RSA is used for signature and the * signature is made offline (otherwise f_rng is desirable * for countermeasures against timing attacks). * ECDSA signatures always require a non-NULL f_rng. */
int mbedtls_x509write_crt_pem( mbedtls_x509write_cert *ctx, unsigned char *buf, size_t size,
void *p_rng );
/** * \brief Write a built up certificate to a X509 PEM string * * \param ctx certificate to write away * \param buf buffer to write to * \param size size of the buffer * \param f_rng RNG function (for signature, see note) * \param p_rng RNG parameter * * \return 0 if successful, or a specific error code * * \note f_rng may be NULL if RSA is used for signature and the * signature is made offline (otherwise f_rng is desirable * for countermeasures against timing attacks). * ECDSA signatures always require a non-NULL f_rng. */
mbedtls_x509_crt_verify_chain ver_chain;
typedef struct mbedtls_x509_crt
mbedtls_x509_buf raw; /**< The raw certificate data (DER). */
mbedtls_x509_buf tbs; /**< The raw certificate body (DER). The part that is To Be Signed. */
int version; /**< The X.509 version. (1=v1, 2=v2, 3=v3) */
mbedtls_x509_buf serial; /**< Unique id for certificate issued by a specific CA. */
mbedtls_x509_buf sig_oid; /**< Signature algorithm, e.g. sha1RSA */
mbedtls_x509_buf issuer_raw; /**< The raw issuer data (DER). Used for quick comparison. */
mbedtls_x509_buf subject_raw; /**< The raw subject data (DER). Used for quick comparison. */
mbedtls_x509_name issuer; /**< The parsed issuer data (named information object). */
mbedtls_x509_name subject; /**< The parsed subject data (named information object). */
mbedtls_x509_time valid_from; /**< Start time of certificate validity. */
mbedtls_x509_time valid_to; /**< End time of certificate validity. */
mbedtls_pk_context pk; /**< Container for the public key context. */
mbedtls_x509_buf issuer_id; /**< Optional X.509 v2/v3 issuer unique identifier. */
mbedtls_x509_buf subject_id; /**< Optional X.509 v2/v3 subject unique identifier. */
mbedtls_x509_buf v3_ext; /**< Optional X.509 v3 extensions. */
mbedtls_x509_sequence subject_alt_names; /**< Optional list of Subject Alternative Names (Only dNSName supported). */
int ext_types; /**< Bit string containing detected and parsed extensions */
int ca_istrue; /**< Optional Basic Constraint extension value: 1 if this certificate belongs to a CA, 0 otherwise. */
int max_pathlen; /**< Optional Basic Constraint extension value: The maximum path length to the root certificate. Path length is 1 higher than RFC 5280 'meaning', so 1+ */
unsigned int key_usage; /**< Optional key usage extension value: See the values in x509.h */
mbedtls_x509_sequence ext_key_usage; /**< Optional list of extended key usage OIDs. */
unsigned char ns_cert_type; /**< Optional Netscape certificate type extension value: See the values in x509.h */
mbedtls_x509_buf sig; /**< Signature: hash of the tbs part signed with the private key. */
mbedtls_md_type_t sig_md; /**< Internal representation of the MD algorithm of the signature algorithm, e.g. MBEDTLS_MD_SHA256 */
mbedtls_pk_type_t sig_pk; /**< Internal representation of the Public Key algorithm of the signature algorithm, e.g. MBEDTLS_PK_RSA */
void *sig_opts; /**< Signature options to be passed to mbedtls_pk_verify_ext(), e.g. for RSASSA-PSS */
struct mbedtls_x509_crt *next; /**< Next certificate in the CA-chain. */
mbedtls_x509_crt;
/** * Container for an X.509 certificate. The certificate may be chained. */
typedef struct mbedtls_x509_crt_profile
uint32_t allowed_mds; /**< MDs for signatures */
uint32_t allowed_pks; /**< PK algs for signatures */
uint32_t allowed_curves; /**< Elliptic curves for ECDSA */
uint32_t rsa_min_bitlen; /**< Minimum size for RSA keys */
mbedtls_x509_crt_profile;
/** * Security profile for certificate verification. * * All lists are bitfields, built by ORing flags from MBEDTLS_X509_ID_FLAG(). */
typedef struct mbedtls_x509write_cert
int version;
mbedtls_mpi serial;
mbedtls_pk_context *subject_key;
mbedtls_pk_context *issuer_key;
mbedtls_asn1_named_data *subject;
mbedtls_asn1_named_data *issuer;
mbedtls_md_type_t md_alg;
char not_before[MBEDTLS_X509_RFC5280_UTC_TIME_LEN + 1];
char not_after[MBEDTLS_X509_RFC5280_UTC_TIME_LEN + 1];
mbedtls_asn1_named_data *extensions;
mbedtls_x509write_cert;
/** * Container for writing a certificate (CRT) */
mbedtls_x509_crt *crt;
uint32_t flags;
} mbedtls_x509_crt_verify_chain_item;
/** * Item in a verification chain: cert and flags for it */
typedef struct
mbedtls_x509_crt_verify_chain_item items[MBEDTLS_X509_MAX_VERIFY_CHAIN_SIZE];
unsigned len;
} mbedtls_x509_crt_verify_chain;
/** * Verification chain as built by \c mbedtls_crt_verify_chain() */
typedef struct
/* for check_signature() */
mbedtls_pk_restart_ctx pk;
/* for find_parent_in() */
mbedtls_x509_crt *parent; /* non-null iff parent_in in progress */
mbedtls_x509_crt *fallback_parent;
int fallback_signature_is_good;
/* for find_parent() */
int parent_is_trusted; /* -1 if find_parent is not in progress */
/* for verify_chain() */
enum {
x509_crt_rs_none,
x509_crt_rs_find_parent,
} in_progress; /* none if no operation is in progress */
int self_cnt;
/** * \brief Context for resuming X.509 verify operations */
typedef void mbedtls_x509_crt_restart_ctx;
/* Now we can declare functions that take a pointer to that */
