#include "config.h"
#include "config.h"
#include MBEDTLS_CONFIG_FILE
#define MBEDTLS_VERSION_H
#define MBEDTLS_VERSION_MAJOR 2
/** * The version number x.y.z is split into three parts. * Major, Minor, Patchlevel */
#define MBEDTLS_VERSION_MINOR 16
#define MBEDTLS_VERSION_PATCH 2
#define MBEDTLS_VERSION_NUMBER 34603520
/** * The single version number has the following structure: * MMNNPP00 * Major version | Minor version | Patch version */
#define MBEDTLS_VERSION_STRING "2.16.2"
#define MBEDTLS_VERSION_STRING_FULL "mbed TLS 2.16.2"
unsigned int mbedtls_version_get_number( void );
/** * Get the version number. * * \return The constructed version number in the format * MMNNPP00 (Major, Minor, Patch). */
void mbedtls_version_get_string( char *string );
* Get the version string ("x.y.z").
* \param string The string that will receive the value.
* (Should be at least 9 bytes in size)
void mbedtls_version_get_string_full( char *string );
* Get the full version string ("mbed TLS x.y.z").
* \param string The string that will receive the value. The mbed TLS version
* string will use 18 bytes AT MOST including a terminating
* null byte.
* (So the buffer should be at least 18 bytes to receive this
* version string).
int mbedtls_version_check_feature( const char *feature );
/** * \brief Check if support for a feature was compiled into this * mbed TLS binary. This allows you to see at runtime if the * library was for instance compiled with or without * Multi-threading support. * * \note only checks against defines in the sections "System * support", "mbed TLS modules" and "mbed TLS feature * support" in config.h * * \param feature The string for the define to check (e.g. "MBEDTLS_AES_C") * * \return 0 if the feature is present, * -1 if the feature is not present and * -2 if support for feature checking as a whole was not * compiled in. */
