| No. | Name | Value | message |
| 1 | OPRT_OK | (-0x0000) | 0, 执行成功 |
| 2 | OPRT_COM_ERROR | (-0x0001) | -1, 通用错误 |
| 3 | OPRT_INVALID_PARM | (-0x0002) | -2, 无效的入参 |
| 4 | OPRT_MALLOC_FAILED | (-0x0003) | -3, 内存分配失败 |
| 5 | OPRT_NOT_SUPPORTED | (-0x0004) | -4, 不支持 |
| 6 | OPRT_NETWORK_ERROR | (-0x0005) | -5, 网络错误 |
| 7 | OPRT_NOT_FOUND | (-0x0006) | -6, 没有找到对象 |
| 8 | OPRT_CR_CJSON_ERR | (-0x0007) | -7, 创建json对象失败 |
| 9 | OPRT_CJSON_PARSE_ERR | (-0x0008) | -8, json解析失败 |
| 10 | OPRT_CJSON_GET_ERR | (-0x0009) | -9, 获取json对象失败 |
| 11 | OPRT_CR_MUTEX_ERR | (-0x000a) | -10, 创建信号量失败 |
| 12 | OPRT_SOCK_ERR | (-0x000b) | -11, 创建socket失败 |
| 13 | OPRT_SET_SOCK_ERR | (-0x000c) | -12, socket设置失败 |
| 14 | OPRT_SOCK_CONN_ERR | (-0x000d) | -13, socket连接失败 |
| 15 | OPRT_SEND_ERR | (-0x000e) | -14, 发送失败 |
| 16 | OPRT_RECV_ERR | (-0x000f) | -15, 接收失败 |
| 17 | OPRT_RECV_DA_NOT_ENOUGH | (-0x0010) | -16, 接收数据不完整 |
| 18 | OPRT_KVS_WR_FAIL | (-0x0011) | -17, KV写失败 |
| 19 | OPRT_KVS_RD_FAIL | (-0x0012) | -18, KV读失败 |
| 20 | OPRT_CRC32_FAILED | (-0x0013) | -19, CRC校验失败 |
| 21 | OPRT_TIMEOUT | (-0x0014) | -20, 超时 |
| 22 | OPRT_INIT_MORE_THAN_ONCE | (-0x0015) | -21, 初始化超过一次 |
| 23 | OPRT_INDEX_OUT_OF_BOUND | (-0x0016) | -22, 索引越界 |
| 24 | OPRT_RESOURCE_NOT_READY | (-0x0017) | -23, 资源未完善 |
| 25 | OPRT_EXCEED_UPPER_LIMIT | (-0x0018) | -24, 超过上限 |
| 26 | OPRT_FILE_NOT_FIND | (-0x0019) | -25, 文件未找到 |
| 1 | OPRT_BASE_OS_ADAPTER_REG_NULL_ERROR | (-0x0100) | -256, 系统适配注册失败 |
| 2 | OPRT_BASE_OS_ADAPTER_INIT_MUTEX_ATTR_FAILED | (-0x0101) | -257, 初始化同步属性失败 |
| 3 | OPRT_BASE_OS_ADAPTER_SET_MUTEX_ATTR_FAILED | (-0x0102) | -258, 设置同步属性失败 |
| 4 | OPRT_BASE_OS_ADAPTER_DESTROY_MUTEX_ATTR_FAILED | (-0x0103) | -259, 销毁同步属性失败 |
| 5 | OPRT_BASE_OS_ADAPTER_INIT_MUTEX_FAILED | (-0x0104) | -260, 初始化互斥量失败 |
| 6 | OPRT_BASE_OS_ADAPTER_MUTEX_LOCK_FAILED | (-0x0105) | -261, 互斥量加锁失败 |
| 7 | OPRT_BASE_OS_ADAPTER_MUTEX_TRYLOCK_FAILED | (-0x0106) | -262, 互斥量尝试加锁失败 |
| 8 | OPRT_BASE_OS_ADAPTER_MUTEX_LOCK_BUSY | (-0x0107) | -263, 互斥量忙 |
| 9 | OPRT_BASE_OS_ADAPTER_MUTEX_UNLOCK_FAILED | (-0x0108) | -264, 互斥量解锁失败 |
| 10 | OPRT_BASE_OS_ADAPTER_MUTEX_RELEASE_FAILED | (-0x0109) | -265, 互斥量释放失败 |
| 11 | OPRT_BASE_OS_ADAPTER_CR_MUTEX_ERR | (-0x010a) | -266, 互斥量创建失败 |
| 12 | OPRT_BASE_OS_ADAPTER_MEM_PARTITION_EMPTY | (-0x010b) | -267, 内存分区空 |
| 13 | OPRT_BASE_OS_ADAPTER_MEM_PARTITION_FULL | (-0x010c) | -268, 内存分区满 |
| 14 | OPRT_BASE_OS_ADAPTER_MEM_PARTITION_NOT_FOUND | (-0x010d) | -269, 内存分区不存在 |
| 15 | OPRT_BASE_OS_ADAPTER_INIT_SEM_FAILED | (-0x010e) | -270, 初始化信号量失败 |
| 16 | OPRT_BASE_OS_ADAPTER_WAIT_SEM_FAILED | (-0x010f) | -271, 等待信号量失败 |
| 17 | OPRT_BASE_OS_ADAPTER_POST_SEM_FAILED | (-0x0110) | -272, 释放信号量失败 |
| 18 | OPRT_BASE_OS_ADAPTER_THRD_STA_UNVALID | (-0x0111) | -273, 线程状态非法 |
| 19 | OPRT_BASE_OS_ADAPTER_THRD_CR_FAILED | (-0x0112) | -274, 线程创建失败 |
| 20 | OPRT_BASE_OS_ADAPTER_THRD_JOIN_FAILED | (-0x0113) | -275, 线程JOIN函数调用失败 |
| 21 | OPRT_BASE_OS_ADAPTER_THRD_SELF_CAN_NOT_JOIN | (-0x0114) | -276, 自身线程不能调用JOIN函数 |
| 1 | OPRT_BASE_UTILITIES_PARTITION_EMPTY | (-0x0200) | -512, 无空闲链表 |
| 2 | OPRT_BASE_UTILITIES_PARTITION_FULL | (-0x0201) | -513, 链表已满 |
| 3 | OPRT_BASE_UTILITIES_PARTITION_NOT_FOUND | (-0x0202) | -514, 链表未遍历到 |
| 1 | OPRT_BASE_SECURITY_CRC32_FAILED | (-0x0300) | -768, CRC32错误 |
| 1 | OPRT_BASE_LOG_MNG_DONOT_FOUND_MODULE | (-0x0400) | -1024, 未发现log模块 |
| 2 | OPRT_BASE_LOG_MNG_PRINT_LOG_LEVEL_HIGHER | (-0x0401) | -1025, log级别低 |
| 3 | OPRT_BASE_LOG_MNG_FORMAT_STRING_FAILED | (-0x0402) | -1026, log字符串格式化失败 |
| 4 | OPRT_BASE_LOG_MNG_LOG_SEQ_OPEN_FILE_FAIL | (-0x0403) | -1027, 打开日志序文件失败 |
| 5 | OPRT_BASE_LOG_MNG_LOG_SEQ_WRITE_FILE_FAIL | (-0x0404) | -1028, 写日志序文件失败 |
| 6 | OPRT_BASE_LOG_MNG_LOG_SEQ_FILE_FULL | (-0x0405) | -1029, 日志序文件满 |
| 7 | OPRT_BASE_LOG_MNG_LOG_SEQ_FILE_NOT_EXIST | (-0x0406) | -1030, 日志序文件不存在 |
| 8 | OPRT_BASE_LOG_MNG_LOG_SEQ_NAME_INVALIDE | (-0x0407) | -1031, 日志序名称无效 |
| 9 | OPRT_BASE_LOG_MNG_LOG_SEQ_CREATE_FAIL | (-0x0408) | -1032, 日志序创建失败 |
| 1 | OPRT_BASE_TIMEQ_TIMERID_EXIST | (-0x0600) | -1536, 定时器ID已存在 |
| 2 | OPRT_BASE_TIMEQ_TIMERID_NOT_FOUND | (-0x0601) | -1537, 未找到指定定时器ID |
| 3 | OPRT_BASE_TIMEQ_TIMERID_UNVALID | (-0x0602) | -1538, 定时器ID非法 |
| 4 | OPRT_BASE_TIMEQ_GET_IDLE_TIMERID_ERROR | (-0x0603) | -1539, 获取空闲定时器ID错误 |
| 1 | OPRT_BASE_MSGQ_NOT_FOUND | (-0x0700) | -1792, 消息未找到 |
| 2 | OPRT_BASE_MSGQ_LIST_EMPTY | (-0x0701) | -1793, 列表为空 |
| 1 | OPRT_MID_HTTP_BUF_NOT_ENOUGH | (-0x0800) | -2048, 缓冲区长度不足 |
| 2 | OPRT_MID_HTTP_URL_PARAM_OUT_LIMIT | (-0x0801) | -2049, URL长度超出限制 |
| 3 | OPRT_MID_HTTP_OS_ERROR | (-0x0802) | -2050, 系统错误 |
| 4 | OPRT_MID_HTTP_PR_REQ_ERROR | (-0x0803) | -2051, 准备请求错误 |
| 5 | OPRT_MID_HTTP_SD_REQ_ERROR | (-0x0804) | -2052, 发送请求错误 |
| 6 | OPRT_MID_HTTP_RD_ERROR | (-0x0805) | -2053, 读取错误 |
| 7 | OPRT_MID_HTTP_AD_HD_ERROR | (-0x0806) | -2054, 添加头错误 |
| 8 | OPRT_MID_HTTP_GET_RESP_ERROR | (-0x0807) | -2055, 获取应答错误 |
| 9 | OPRT_MID_HTTP_AES_INIT_ERR | (-0x0808) | -2056, AES初始化错误 |
| 10 | OPRT_MID_HTTP_AES_OPEN_ERR | (-0x0809) | -2057, AES打开错误 |
| 11 | OPRT_MID_HTTP_AES_SET_KEY_ERR | (-0x080a) | -2058, AES设置KEY错误 |
| 12 | OPRT_MID_HTTP_AES_ENCRYPT_ERR | (-0x080b) | -2059, AES加密错误 |
| 13 | OPRT_MID_HTTP_CR_HTTP_URL_H_ERR | (-0x080c) | -2060, 创建HTTP URL头错误 |
| 14 | OPRT_MID_HTTP_HTTPS_HANDLE_FAIL | (-0x080d) | -2061, HTTPS句柄错误 |
| 15 | OPRT_MID_HTTP_HTTPS_RESP_UNVALID | (-0x080e) | -2062, HTTPS无效应答 |
| 16 | OPRT_MID_HTTP_NO_SUPPORT_RANGE | (-0x080f) | -2063, 不支持断点续传 |
| 1 | OPRT_MID_MQTT_DEF_ERR | (-0x0900) | -2304, 定义失败 |
| 2 | OPRT_MID_MQTT_INVALID_PARM | (-0x0901) | -2305, 参数无效 |
| 3 | OPRT_MID_MQTT_MALLOC_FAILED | (-0x0902) | -2306, 内存申请失败 |
| 4 | OPRT_MID_MQTT_DNS_PARSED_FAILED | (-0x0903) | -2307, DNS解析失败 |
| 5 | OPRT_MID_MQTT_SOCK_CREAT_FAILED | (-0x0904) | -2308, socket创建失败 |
| 6 | OPRT_MID_MQTT_SOCK_SET_FAILED | (-0x0905) | -2309, socket set失败 |
| 7 | OPRT_MID_MQTT_TCP_CONNECD_FAILED | (-0x0906) | -2310, tcp连接失败 |
| 8 | OPRT_MID_MQTT_TCP_TLS_CONNECD_FAILED | (-0x0907) | -2311, tcp tls连接失败 |
| 9 | OPRT_MID_MQTT_PACK_SEND_FAILED | (-0x0908) | -2312, 包发送失败 |
| 10 | OPRT_MID_MQTT_RECV_DATA_FORMAT_WRONG | (-0x0909) | -2313, 接收数据格式错误 |
| 11 | OPRT_MID_MQTT_MSGID_NOT_MATCH | (-0x090a) | -2314, 接收数据msgid未找到 |
| 12 | OPRT_MID_MQTT_START_TM_MSG_ERR | (-0x090b) | -2315, 开始事件msg错误 |
| 13 | OPRT_MID_MQTT_OVER_MAX_MESSAGE_LEN | (-0x090c) | -2316, 超过消息最大长度 |
| 14 | OPRT_MID_MQTT_PING_SEND_ERR | (-0x090d) | -2317, ping发送失败 |
| 15 | OPRT_MID_MQTT_PUBLISH_TIMEOUT | (-0x090e) | -2318, 发布超时 |
| 1 | OPRT_MID_TLS_NET_SOCKET_ERROR | (-0x0a00) | -2560, Failed to open a socket |
| 2 | OPRT_MID_TLS_NET_CONNECT_ERROR | (-0x0a01) | -2561, The connection to the given server / port failed. |
| 3 | OPRT_MID_TLS_UNKNOWN_HOST_ERROR | (-0x0a02) | -2562, Failed to get an IP address for the given hostname. |
| 4 | OPRT_MID_TLS_CONNECTION_ERROR | (-0x0a03) | -2563, TLS连接失败 |
| 5 | OPRT_MID_TLS_DRBG_ENTROPY_ERROR | (-0x0a04) | -2564, mbedtls随机种子生成失败 |
| 6 | OPRT_MID_TLS_X509_ROOT_CRT_PARSE_ERROR | (-0x0a05) | -2565, X509根证书解析失败 |
| 7 | OPRT_MID_TLS_X509_DEVICE_CRT_PARSE_ERROR | (-0x0a06) | -2566, X509设备证书解析失败 |
| 8 | OPRT_MID_TLS_CTR_DRBG_ENTROPY_SOURCE_ERROR | (-0x0a07) | -2567, The entropy source failed |
| 9 | OPRT_MID_TLS_PK_PRIVATE_KEY_PARSE_ERROR | (-0x0a08) | -2568, 秘钥解析失败 |
| 1 | OPRT_SVC_WIFI_NETCFG_RECV_CONTINUE | (-0x0b00) | -2816, 继续接收配网包 |
| 1 | OPRT_SVC_MF_TEST_UPDATE_DATA_LEN_EXECED | (-0x0d00) | -3328, 升级数据长度超过处理上限 |
| 2 | OPRT_SVC_MF_TEST_UPDATE_CRC_ERROR | (-0x0d01) | -3329, 升级crc校验失败 |
| 1 | OPRT_SVC_DP_ALREADY_PROCESS | (-0x0e00) | -3584, DP已经处理 |
| 2 | OPRT_SVC_DP_ID_NOT_FOUND | (-0x0e01) | -3585, DP ID没有发现 |
| 3 | OPRT_SVC_DP_TP_NOT_MATCH | (-0x0e02) | -3586, DP 类型未匹配 |
| 4 | OPRT_SVC_DP_DEVICE_NOT_BINDED | (-0x0e03) | -3587, 设备未绑定 |
| 5 | OPRT_SVC_DP_TYPE_PROP_ILLEGAL | (-0x0e04) | -3588, 类型属性不合法 |
| 6 | OPRT_SVC_DP_NW_INVALID | (-0x0e05) | -3589, 网络无效 |
| 7 | OPRT_SVC_DP_SECURITY_VERIFY_ERR | (-0x0e06) | -3590, 安全校验失败 |
| 8 | OPRT_SVC_DP_REPORT_FINISH | (-0x0e07) | -3591, DP上报已结束 |
| 1 | OPRT_BASE_EVENT_INVALID_EVENT_NAME | (-0x0f00) | -3840, 无效的事件名 |
| 2 | OPRT_BASE_EVENT_INVALID_EVENT_DESC | (-0x0f01) | -3841, 无效的事件描述 |
| 1 | OPRT_SVC_TIMER_TASK_LOAD_INVALID_CJSON | (-0x1000) | -4096, K/V中保存的数据JSON格式错误 |
| 2 | OPRT_SVC_TIMER_TASK_LOAD_INVALID_DATA | (-0x1001) | -4097, K/V中保存的数据缺少cnt字段 |
| 3 | OPRT_SVC_TIMER_TASK_UPDATE_LAST_FETCH_INVALID | (-0x1002) | -4098, 云端返回的数据缺少lastFetchTime字段 |
| 4 | OPRT_SVC_TIMER_TASK_UPDATE_TIMER_CNT_INVALID | (-0x1003) | -4099, 云端返回的数据缺少count字段 |
| 5 | OPRT_SVC_TIMER_TASK_UPDATE_TIMER_CNT_EXCEED | (-0x1004) | -4100, 云端返回的定时任务数量超过30个 |
| 1 | OPRT_SVC_HTTP_NOT_ENCRYPT_RET | (-0x1100) | -4352, 结果未加密 |
| 2 | OPRT_SVC_HTTP_FILL_URL_H_ERR | (-0x1101) | -4353, 构造header错误 |
| 3 | OPRT_SVC_HTTP_FILL_URL_FULL_ERR | (-0x1102) | -4354, 构造整个URL错误 |
| 4 | OPRT_SVC_HTTP_FILL_DATA_ERR | (-0x1103) | -4355, 构造data错误 |
| 5 | OPRT_SVC_HTTP_URL_CFG_AI_SPEAKER_ERR | (-0x1104) | -4356, 音响配置失败 |
| 6 | OPRT_SVC_HTTP_URL_CFG_URL_ERR | (-0x1105) | -4357, httpUrl/mqttUrl字段缺失 |
| 7 | OPRT_SVC_HTTP_URL_CFG_URL2IP_ERR | (-0x1106) | -4358, httpUrl/mqttUrl解析错误 |
| 8 | OPRT_SVC_HTTP_URL_CFG_URL2IP_SELF_ERR | (-0x1107) | -4359, httpsSelfUrl/mqttsSelfUrl解析错误 |
| 9 | OPRT_SVC_HTTP_URL_CFG_URL2IP_VERIFY_ERR | (-0x1108) | -4360, httpsVerifyUrl/mqttsVerifyUrl解析错误 |
| 10 | OPRT_SVC_HTTP_URL_CFG_URL2IP_PSK_ERR | (-0x1109) | -4361, httpsPSKUrl/mqttsPSKUrl解析错误 |
| 11 | OPRT_SVC_HTTP_RECV_ERR | (-0x110a) | -4362, 接收数据错误 |
| 12 | OPRT_SVC_HTTP_RECV_DA_NOT_ENOUGH | (-0x110b) | -4363, 接收数据不足 |
| 13 | OPRT_SVC_HTTP_API_VERIFY_FAILED | (-0x110c) | -4364, 数据校验错误 |
| 14 | OPRT_SVC_HTTP_GW_NOT_EXIST | (-0x110d) | -4365, 网关信息不存在 |
| 15 | OPRT_SVC_HTTP_API_TOKEN_EXPIRE | (-0x110e) | -4366, TOKEN过期 |
| 16 | OPRT_SVC_HTTP_DEV_RESET_FACTORY | (-0x110f) | -4367, 设备需要恢复出厂 |
| 17 | OPRT_SVC_HTTP_DEV_NEED_REGISTER | (-0x1110) | -4368, 设备未注册 |
| 18 | OPRT_SVC_HTTP_ORDER_EXPIRE | (-0x1111) | -4369, 订单已过期 |
| 19 | OPRT_SVC_HTTP_NOT_EXISTS | (-0x1112) | -4370, 不存在 |
| 20 | OPRT_SVC_HTTP_SIGNATURE_ERROR | (-0x1113) | -4371, 签名错误 |
| 21 | OPRT_SVC_HTTP_API_VERSION_WRONG | (-0x1114) | -4372, API版本错误 |
| 22 | OPRT_SVC_HTTP_DEVICE_REMOVED | (-0x1115) | -4373, 设备已移除 |
| 23 | OPRT_SVC_HTTP_DEV_ALREADY_BIND | (-0x1116) | -4374, 设备已经绑定 |
| 24 | OPRT_SVC_HTTP_REMOTE_API_RUN_UNKNOW_FAILED | (-0x1117) | -4375, 无法识别API |
| 25 | OPRT_SVC_HTTP_FORMAT_STRING_FAILED | (-0x1118) | -4376, 字符串格式化错误 |
| 26 | OPRT_SVC_HTTP_API_DECODE_FAILED | (-0x1119) | -4377, 数据解密失败 |
| 27 | OPRT_SVC_HTTP_SERV_VRFY_FAIL | (-0x111a) | -4378, 服务端校验失败 |
| 1 | OPRT_SVC_LAN_SOCKET_FAULT | (-0x1500) | -5376, socket错误 |
| 2 | OPRT_SVC_LAN_SEND_ERR | (-0x1501) | -5377, socket发送错误 |
| 3 | OPRT_SVC_LAN_NO_CLIENT_CONNECTED | (-0x1502) | -5378, 没有可以上报的局域网设备连接 |
| 1 | OPRT_SVC_MQTT_CMD_NOT_EXEC | (-0x1700) | -5888, 命令未执行 |
| 2 | OPRT_SVC_MQTT_CMD_OUT_OF_TIME | (-0x1701) | -5889, 命令未在规定时间内执行 |
| 3 | OPRT_SVC_MQTT_GW_MQ_OFFLILNE | (-0x1702) | -5890, MQTT离线 |
| 1 | OPRT_SVC_PEGASUS_DECODE_FAILED | (-0x1800) | -6144, 解码失败 |
| 2 | OPRT_SVC_PEGASUS_DONOT_FOUND_MODULE | (-0x1801) | -6145, 模块未找到 |
| 1 | OPRT_SVC_UPGRADE_APP_NOT_READY | (-0x1900) | -6400, 应用尚未就绪 |
| 2 | OPRT_SVC_UPGRADE_NO_VALID_FIRMWARE | (-0x1901) | -6401, 升级信息字段校验失败 |
| 1 | OPRT_SVC_API_IOT_DISCONNECTED_WITH_ROUTER | (-0x1a00) | -6656, 路由器断开 |
| 2 | OPRT_SVC_API_IOT_DEV_NOT_BIND | (-0x1a01) | -6657, 设备未绑定 |
| 1 | OPRT_SVC_DEVOS_NOT_EXISTS | (-0x1c00) | -7168, 不存在 |
| 2 | OPRT_SVC_DEVOS_SCMA_INVALID | (-0x1c01) | -7169, SCMA无效 |
| 3 | OPRT_SVC_DEVOS_DEV_DP_CNT_INVALID | (-0x1c02) | -7170, 设备DP数量无效 |
| 4 | OPRT_SVC_DEVOS_NO_AUTHENTICATION | (-0x1c03) | -7171, 无授权 |
| 5 | OPRT_SVC_DEVOS_ROUTER_NOT_FIND | (-0x1c04) | -7172, 路由器未找到 |
| 1 | OPRT_BASE_DB_FLASH_NOT_ENOUGH_PAGE | (-0x1d00) | -7424, flash页不够 |
| 1 | OPRT_SVC_BT_API_TRSMITR_CONTINUE | (-0x1f00) | -7936, 传输未结束 |
| 2 | OPRT_SVC_BT_API_TRSMITR_ERROR | (-0x1f01) | -7937, 传输错误 |
| 3 | OPRT_SVC_BT_NETCFG_ERROR_ACK | (-0x1f02) | -7938, bt命令出错,给app发送ack |
