#include "config.h"
#include "config.h"
#include MBEDTLS_CONFIG_FILE
#include <stdint.h>
#include
#include "timing_alt.h"
#define MBEDTLS_TIMING_H
unsigned long mbedtls_timing_hardclock( void );
/** * \brief Return the CPU cycle counter value * * \warning This is only a best effort! Do not rely on this! * In particular, it is known to be unreliable on virtual * machines. * * \note This value starts at an unspecified origin and * may wrap around. */
unsigned long mbedtls_timing_get_timer( struct mbedtls_timing_hr_time *val, int reset );
* \brief Return the elapsed time in milliseconds
* \param val points to a timer structure
* \param reset If 0, query the elapsed time. Otherwise (re)start the timer.
* \return Elapsed time since the previous reset in ms. When
* restarting, this is always 0.
* \note To initialize a timer, call this function with reset=1.
* Determining the elapsed time and resetting the timer is not
* atomic on all platforms, so after the sequence
* `{ get_timer(1); ...; time1 = get_timer(1); ...; time2 =
* get_timer(0) }` the value time1+time2 is only approximately
* the delay since the first reset.
void mbedtls_set_alarm( int seconds );
/** * \brief Setup an alarm clock * * \param seconds delay before the "mbedtls_timing_alarmed" flag is set * (must be >=0) * * \warning Only one alarm at a time is supported. In a threaded * context, this means one for the whole process, not one per * thread. */
void mbedtls_timing_set_delay( void *data, uint32_t int_ms, uint32_t fin_ms );
/** * \brief Set a pair of delays to watch * (See \c mbedtls_timing_get_delay().) * * \param data Pointer to timing data. * Must point to a valid \c mbedtls_timing_delay_context struct. * \param int_ms First (intermediate) delay in milliseconds. * The effect if int_ms > fin_ms is unspecified. * \param fin_ms Second (final) delay in milliseconds. * Pass 0 to cancel the current delay. * * \note To set a single delay, either use \c mbedtls_timing_set_timer * directly or use this function with int_ms == fin_ms. */
int mbedtls_timing_get_delay( void *data );
/** * \brief Get the status of delays * (Memory helper: number of delays passed.) * * \param data Pointer to timing data * Must point to a valid \c mbedtls_timing_delay_context struct. * * \return -1 if cancelled (fin_ms = 0), * 0 if none of the delays are passed, * 1 if only the intermediate delay is passed, * 2 if the final delay is passed. */
int mbedtls_timing_self_test( int verbose );
/** * \brief Checkup routine * * \return 0 if successful, or 1 if a test failed */
typedef struct mbedtls_timing_delay_context
struct mbedtls_timing_hr_time timer;
uint32_t int_ms;
uint32_t fin_ms;
} mbedtls_timing_delay_context;
/** * \brief Context for mbedtls_timing_set/get_delay() */
