#include "tuya_iot_config.h"
#define MBEDTLS_CONFIG_H_TY_PSK_ONLY
#define TUYA_TLS_DYNAMIC_MEMORY_ALLOCATION 1 //开启TLS动态内存
#define TLS_MEM_DEBUG 0 //开启TLS内存调试
//#define TLS_SESSION 1 //开启TLS_SESSION
#define TUYA_TLS_DEBUG_THRDSHOLD 5 //TLS 调试等级
#define MBEDTLS_AES_ALT
//#define MBEDTLS_ECP_DP_SECP224R1_ENABLED
#define MBEDTLS_KEY_EXCHANGE_PSK_ENABLED
/** * \def MBEDTLS_KEY_EXCHANGE_PSK_ENABLED * * Enable the PSK based ciphersuite modes in SSL / TLS. * * This enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_3DES_EDE_CBC_SHA * MBEDTLS_TLS_PSK_WITH_RC4_128_SHA */
#define MBEDTLS_SSL_MAX_FRAGMENT_LENGTH
/** * \def MBEDTLS_SSL_MAX_FRAGMENT_LENGTH * * Enable support for RFC 6066 max_fragment_length extension in SSL. * * Comment this macro to disable support for the max_fragment_length extension */
#define MBEDTLS_SSL_SESSION_TICKETS
#define MBEDTLS_AES_C
/** * \def MBEDTLS_AES_C * * Enable the AES block cipher. * * Module: library/aes.c * Caller: library/cipher.c * library/pem.c * library/ctr_drbg.c * * This module enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * * PEM_PARSE uses AES for decrypting encrypted keys. */
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CCM_C
/** * \def MBEDTLS_CCM_C * * Enable the Counter with CBC-MAC (CCM) mode for 128-bit block cipher. * * Module: library/ccm.c * * Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C * * This module enables the AES-CCM ciphersuites, if other requisites are * enabled as well. */
#define MBEDTLS_CIPHER_C
#define MBEDTLS_DHM_C
#define MBEDTLS_ECDH_C
#define MBEDTLS_ECP_C
#define MBEDTLS_MD_C
#define MBEDTLS_MD5_C
#define MBEDTLS_PLATFORM_C
#define MBEDTLS_SHA1_C
/** * \def MBEDTLS_SHA1_C * * Enable the SHA1 cryptographic hash algorithm. * * Module: library/sha1.c * Caller: library/md.c * library/ssl_cli.c * library/ssl_srv.c * library/ssl_tls.c * library/x509write_crt.c * * This module is required for SSL/TLS up to version 1.1, for TLS 1.2 * depending on the handshake parameters, and for SHA1-signed certificates. * * \warning SHA-1 is considered a weak message digest and its use constitutes * a security risk. If possible, we recommend avoiding dependencies * on it, and considering stronger message digests instead. * */
#define MBEDTLS_SHA256_C
#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_SSL_MAX_CONTENT_LEN 1024 /**< Maxium fragment length in bytes, determines the size of each of the two internal I/O buffers */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384
#define MBEDTLS_SSL_IN_CONTENT_LEN (ssl->in_content_len)
#define MBEDTLS_SSL_OUT_CONTENT_LEN (ssl->out_content_len)
