#include "uthash.h"
#include "uthash.h"
#include "async.h"
#include "async.h"
#include "str.h"
#include "str.h"
#include "pdu.h"
#include "pdu.h"
#include "coap_net.h"
#include "subscribe.h"
#define COAP_RESOURCE_H_
#define COAP_RESOURCE_CHECK_TIME 2
/** The interval in seconds to check if resources have changed. */
#define COAP_ATTR_FLAGS_RELEASE_NAME 1
#define COAP_ATTR_FLAGS_RELEASE_VALUE 2
#define COAP_RESOURCE_FLAGS_RELEASE_URI 1
/** The URI passed to coap_resource_init() is free'd by coap_delete_resource(). */
#define COAP_RESOURCE_FLAGS_NOTIFY_NON 0
/** * Notifications will be sent non-confirmable by default. RFC 7641 Section 4.5 * https://tools.ietf.org/html/rfc7641#section-4.5 */
#define COAP_RESOURCE_FLAGS_NOTIFY_CON 2
/** * Notifications will be sent confirmable by default. RFC 7641 Section 4.5 * https://tools.ietf.org/html/rfc7641#section-4.5 */
#define COAP_PRINT_STATUS_MASK 4026531840u
#define COAP_PRINT_OUTPUT_LENGTH(v) ((v) & ~COAP_PRINT_STATUS_MASK)
#define COAP_PRINT_STATUS_ERROR 2147483648u
#define COAP_PRINT_STATUS_TRUNC 1073741824u
#define RESOURCES_ADD(r, obj) \
HASH_ADD(hh, (r), uri_path->s[0], (obj)->uri_path->length, (obj))
#define RESOURCES_DELETE(r, obj) \
HASH_DELETE(hh, (r), (obj))
#define RESOURCES_ITER(r,tmp) \
coap_resource_t *tmp, *rtmp; \
HASH_ITER(hh, (r), tmp, rtmp)
#define RESOURCES_FIND(r, k, res) { \
HASH_FIND(hh, (r), (k)->s, (k)->length, (res)); \
void coap_add_resource(coap_context_t *context, coap_resource_t *resource);
/** * Registers the given @p resource for @p context. The resource must have been * created by coap_resource_init() or coap_resource_unknown_init(), the * storage allocated for the resource will be released by coap_delete_resource(). * * @param context The context to use. * @param resource The resource to store. */
int coap_delete_resource(coap_context_t *context, coap_resource_t *resource);
/** * Deletes a resource identified by @p resource. The storage allocated for that * resource is freed, and removed from the context. * * @param context The context where the resources are stored. * @param resource The resource to delete. * * @return @c 1 if the resource was found (and destroyed), * @c 0 otherwise. */
void coap_delete_all_resources(coap_context_t *context);
/** * Deletes all resources from given @p context and frees their storage. * * @param context The CoAP context with the resources to be deleted. */
void coap_delete_attr(coap_attr_t *attr);
/** * Deletes an attribute. * Note: This is for internal use only, as it is not deleted from its chain. * * @param attr Pointer to a previously created attribute. * */
coap_print_status_t coap_print_link(const coap_resource_t *resource,
unsigned char *buf,
size_t *len,
size_t *offset);
/** * Writes a description of this resource in link-format to given text buffer. @p * len must be initialized to the maximum length of @p buf and will be set to * the number of characters actually written if successful. This function * returns @c 1 on success or @c 0 on error. * * @param resource The resource to describe. * @param buf The output buffer to write the description to. * @param len Must be initialized to the length of @p buf and * will be set to the length of the printed link description. * @param offset The offset within the resource description where to * start writing into @p buf. This is useful for dealing * with the Block2 option. @p offset is updated during * output as it is consumed. * * @return If COAP_PRINT_STATUS_ERROR is set, an error occured. Otherwise, * the lower 28 bits will indicate the number of characters that * have actually been output into @p buffer. The flag * COAP_PRINT_STATUS_TRUNC indicates that the output has been * truncated. */
void coap_register_handler(coap_resource_t *resource,
unsigned char method,
coap_method_handler_t handler);
/** * Registers the specified @p handler as message handler for the request type @p * method * * @param resource The resource for which the handler shall be registered. * @param method The CoAP request method to handle. * @param handler The handler to register with @p resource. */
void coap_touch_observer(coap_context_t *context,
coap_session_t *session,
const coap_binary_t *token);
/** * Marks an observer as alive. * * @param context The CoAP context to use. * @param session The observer's session * @param token The corresponding token that has been used for the * subscription. */
int coap_delete_observer(coap_resource_t *resource,
/** * Removes any subscription for @p observer from @p resource and releases the * allocated storage. The result is @c 1 if an observation relationship with @p * observer and @p token existed, @c 0 otherwise. * * @param resource The observed resource. * @param session The observer's session. * @param token The token that identifies this subscription or @c NULL for * any token. * @return @c 1 if the observer has been deleted, @c 0 otherwise. */
void coap_delete_observers(coap_context_t *context, coap_session_t *session);
/** * Removes any subscription for @p session and releases the allocated storage. * * @param context The CoAP context to use. * @param session The observer's session. */
void coap_check_notify(coap_context_t *context);
/** * Checks for all known resources, if they are dirty and notifies subscribed * observers. */
coap_print_status_t coap_print_wellknown(coap_context_t *,
unsigned char *,
size_t *, size_t,
coap_opt_t *);
void
coap_handle_failed_notify(coap_context_t *,
coap_session_t *,
const coap_binary_t *);
int
coap_resource_notify_observers(coap_resource_t *resource,
const coap_string_t *query);
/** * Initiate the sending of an Observe packet for all observers of @p resource, * optionally matching @p query if not NULL * * @param resource The CoAP resource to use. * @param query The Query to match against or NULL * * @return @c 1 if the Observe has been triggered, @c 0 otherwise. */
coap_resource_t *coap_resource_init(coap_str_const_t *uri_path,
int flags);
/** * Creates a new resource object and initializes the link field to the string * @p uri_path. This function returns the new coap_resource_t object. * * If the string is going to be freed off by coap_delete_resource() when * COAP_RESOURCE_FLAGS_RELEASE_URI is set in @p flags, then either the 's' * variable of coap_str_const_t has to point to constant text, or point to data * within the allocated coap_str_const_t parameter. * * @param uri_path The string URI path of the new resource. * @param flags Flags for memory management (in particular release of * memory). Possible values:@n * * COAP_RESOURCE_FLAGS_RELEASE_URI * If this flag is set, the URI passed to * coap_resource_init() is free'd by * coap_delete_resource()@n * * COAP_RESOURCE_FLAGS_NOTIFY_CON * If this flag is set, coap-observe notifications * will be sent confirmable by default.@n * * COAP_RESOURCE_FLAGS_NOTIFY_NON (default) * If this flag is set, coap-observe notifications * will be sent non-confirmable by default.@n * * If flags is set to 0 then the * COAP_RESOURCE_FLAGS_NOTIFY_NON is considered. * * @return A pointer to the new object or @c NULL on error. */
coap_resource_t *coap_resource_unknown_init(coap_method_handler_t put_handler);
/** * Creates a new resource object for the unknown resource handler with support * for PUT. * * In the same way that additional handlers can be added to the resource * created by coap_resource_init() by using coap_register_handler(), POST, * GET, DELETE etc. handlers can be added to this resource. It is the * responsibility of the application to manage the unknown resources by either * creating new resources with coap_resource_init() (which should have a * DELETE handler specified for the resource removal) or by maintaining an * active resource list. * * Note: There can only be one unknown resource handler per context - attaching * a new one overrides the previous definition. * * Note: It is not possible to observe the unknown resource with a GET request * - a separate resource needs to be reated by the PUT (or POST) handler, * and make that resource observable. * * This function returns the new coap_resource_t object. * * @param put_handler The PUT handler to register with @p resource for * unknown Uri-Path. * * @return A pointer to the new object or @c NULL on error. */
coap_attr_t *coap_add_attr(coap_resource_t *resource,
coap_str_const_t *name,
coap_str_const_t *value,
int flags);
/** * Registers a new attribute with the given @p resource. As the * attribute's coap_str_const_ fields will point to @p name and @p value the * caller must ensure that these pointers are valid during the * attribute's lifetime. * If the @p name and/or @p value string is going to be freed off at attribute * removal time by the setting of COAP_ATTR_FLAGS_RELEASE_NAME or * COAP_ATTR_FLAGS_RELEASE_VALUE in @p flags, then either the 's' * variable of coap_str_const_t has to point to constant text, or point to data * within the allocated coap_str_const_t parameter. * * @param resource The resource to register the attribute with. * @param name The attribute's name as a string. * @param value The attribute's value as a string or @c NULL if none. * @param flags Flags for memory management (in particular release of * memory). Possible values:@n * * COAP_ATTR_FLAGS_RELEASE_NAME * If this flag is set, the name passed to * coap_add_attr_release() is free'd * when the attribute is deleted@n * * COAP_ATTR_FLAGS_RELEASE_VALUE * If this flag is set, the value passed to * coap_add_attr_release() is free'd * when the attribute is deleted@n * * @return A pointer to the new attribute or @c NULL on error. */
coap_attr_t *coap_find_attr(coap_resource_t *resource,
coap_str_const_t *name);
/** * Returns @p resource's coap_attr_t object with given @p name if found, @c NULL * otherwise. * * @param resource The resource to search for attribute @p name. * @param name Name of the requested attribute as a string. * @return The first attribute with specified @p name or @c NULL if none * was found. */
coap_resource_t *coap_get_resource_from_uri_path(coap_context_t *context,
coap_str_const_t *uri_path);
/** * Returns the resource identified by the unique string @p uri_path. If no * resource was found, this function returns @c NULL. * * @param context The context to look for this resource. * @param uri_path The unique string uri of the resource. * * @return A pointer to the resource or @c NULL if not found. */
coap_subscription_t *coap_add_observer(coap_resource_t *resource,
const coap_binary_t *token,
coap_string_t *query,
int has_block2,
coap_block_t block2);
* Adds the specified peer as observer for @p resource. The subscription is
* identified by the given @p token. This function returns the registered
* subscription information if the @p observer has been added, or @c NULL on
* error.
* @param token The token that identifies this subscription.
* @param query The query string, if any. subscription will
take ownership of the string.
* @param has_block2 If Option Block2 defined.
* @param block2 Contents of Block2 if Block 2 defined.
* @return A pointer to the added/updated subscription
* information or @c NULL on error.
coap_subscription_t *coap_find_observer(coap_resource_t *resource,
/** * Returns a subscription object for given @p peer. * * @param resource The observed resource. * @param session The observer's session * @param token The token that identifies this subscription or @c NULL for * any token. * @return A valid subscription if exists or @c NULL otherwise. */
COAP_DEPRECATED int
coap_resource_set_dirty(coap_resource_t *r,
/** * @deprecated use coap_resource_notify_observers() instead. */
typedef void (*coap_method_handler_t)
(coap_context_t *,
struct coap_resource_t *,
coap_session_t *,
coap_pdu_t *,
coap_binary_t * /* token */,
coap_string_t * /* query string */,
coap_pdu_t * /* response */);
/** * Definition of message handler function (@sa coap_resource_t). */
typedef struct coap_attr_t {
struct coap_attr_t *next;
coap_str_const_t *name;
coap_str_const_t *value;
int flags;
} coap_attr_t;
typedef struct coap_resource_t {
unsigned int dirty:1; /**< set to 1 if resource has changed */
unsigned int partiallydirty:1; /**< set to 1 if some subscribers have not yet
* been notified of the last change */
unsigned int observable:1; /**< can be observed */
unsigned int cacheable:1; /**< can be cached */
unsigned int is_unknown:1; /**< resource created for unknown handler */
* Used to store handlers for the seven coap methods @c GET, @c POST, @c PUT,
* @c DELETE, @c FETCH, @c PATCH and @c IPATCH.
* coap_dispatch() will pass incoming requests to the handler
* that corresponds to its request method or generate a 4.05 response if no
* handler is available.
coap_method_handler_t handler[7];
UT_hash_handle hh;
coap_attr_t *link_attr; /**< attributes to be included with the link format */
coap_subscription_t *subscribers; /**< list of observers for this resource */
* Request URI Path for this resource. This field will point into static
* or allocated memory which must remain there for the duration of the
* resource.
coap_str_const_t *uri_path; /**< the key used for hash lookup for this resource */
int flags;
* The next value for the Observe option. This field must be increased each
* time the resource changes. Only the lower 24 bits are sent.
unsigned int observe;
* This pointer is under user control. It can be used to store context for
* the coap handler.
void *user_data;
} coap_resource_t;
typedef unsigned int coap_print_status_t;
/** * Status word to encode the result of conditional print or copy operations such * as coap_print_link(). The lower 28 bits of coap_print_status_t are used to * encode the number of characters that has actually been printed, bits 28 to 31 * encode the status. When COAP_PRINT_STATUS_ERROR is set, an error occurred * during output. In this case, the other bits are undefined. * COAP_PRINT_STATUS_TRUNC indicates that the output is truncated, i.e. the * printing would have exceeded the current buffer. */
