#include "config.h"
#include "config.h"
#include MBEDTLS_CONFIG_FILE
#include "bignum.h"
#include "bignum.h"
#include "ecp.h"
#include "ecp.h"
#include "ssl_ciphersuites.h"
#include "x509_crt.h"
#include "x509_crl.h"
#include "dhm.h"
#include "dhm.h"
#include "ecdh.h"
#include "ecdh.h"
#include "zlib.h"
#include "zlib.h"
#include "platform_time.h"
#define MBEDTLS_SSL_H
#define MBEDTLS_ERR_SSL_FEATURE_UNAVAILABLE -28800 /**< The requested feature is not available. */
/* * SSL Error codes */
#define MBEDTLS_ERR_SSL_BAD_INPUT_DATA -28928 /**< Bad input parameters to function. */
#define MBEDTLS_ERR_SSL_INVALID_MAC -29056 /**< Verification of the message MAC failed. */
#define MBEDTLS_ERR_SSL_INVALID_RECORD -29184 /**< An invalid SSL record was received. */
#define MBEDTLS_ERR_SSL_CONN_EOF -29312 /**< The connection indicated an EOF. */
#define MBEDTLS_ERR_SSL_UNKNOWN_CIPHER -29440 /**< An unknown cipher was received. */
#define MBEDTLS_ERR_SSL_NO_CIPHER_CHOSEN -29568 /**< The server has no ciphersuites in common with the client. */
#define MBEDTLS_ERR_SSL_NO_RNG -29696 /**< No RNG was provided to the SSL module. */
#define MBEDTLS_ERR_SSL_NO_CLIENT_CERTIFICATE -29824 /**< No client certification received from the client, but required by the authentication mode. */
#define MBEDTLS_ERR_SSL_CERTIFICATE_TOO_LARGE -29952 /**< Our own certificate(s) is/are too large to send in an SSL message. */
#define MBEDTLS_ERR_SSL_CERTIFICATE_REQUIRED -30080 /**< The own certificate is not set, but needed by the server. */
#define MBEDTLS_ERR_SSL_PRIVATE_KEY_REQUIRED -30208 /**< The own private key or pre-shared key is not set, but needed. */
#define MBEDTLS_ERR_SSL_CA_CHAIN_REQUIRED -30336 /**< No CA Chain is set, but required to operate. */
#define MBEDTLS_ERR_SSL_UNEXPECTED_MESSAGE -30464 /**< An unexpected message was received from our peer. */
#define MBEDTLS_ERR_SSL_FATAL_ALERT_MESSAGE -30592 /**< A fatal alert message was received from our peer. */
#define MBEDTLS_ERR_SSL_PEER_VERIFY_FAILED -30720 /**< Verification of our peer failed. */
#define MBEDTLS_ERR_SSL_PEER_CLOSE_NOTIFY -30848 /**< The peer notified us that the connection is going to be closed. */
#define MBEDTLS_ERR_SSL_BAD_HS_CLIENT_HELLO -30976 /**< Processing of the ClientHello handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_SERVER_HELLO -31104 /**< Processing of the ServerHello handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_CERTIFICATE -7A00 /**< Processing of the Certificate handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_CERTIFICATE_REQUEST -7A80 /**< Processing of the CertificateRequest handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_SERVER_KEY_EXCHANGE -7B00 /**< Processing of the ServerKeyExchange handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_SERVER_HELLO_DONE -7B80 /**< Processing of the ServerHelloDone handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_CLIENT_KEY_EXCHANGE -7C00 /**< Processing of the ClientKeyExchange handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_CLIENT_KEY_EXCHANGE_RP -7C80 /**< Processing of the ClientKeyExchange handshake message failed in DHM / ECDH Read Public. */
#define MBEDTLS_ERR_SSL_BAD_HS_CLIENT_KEY_EXCHANGE_CS -7D00 /**< Processing of the ClientKeyExchange handshake message failed in DHM / ECDH Calculate Secret. */
#define MBEDTLS_ERR_SSL_BAD_HS_CERTIFICATE_VERIFY -7D80 /**< Processing of the CertificateVerify handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_CHANGE_CIPHER_SPEC -7E00 /**< Processing of the ChangeCipherSpec handshake message failed. */
#define MBEDTLS_ERR_SSL_BAD_HS_FINISHED -7E80 /**< Processing of the Finished handshake message failed. */
#define MBEDTLS_ERR_SSL_ALLOC_FAILED -32512 /**< Memory allocation failed */
#define MBEDTLS_ERR_SSL_HW_ACCEL_FAILED -32640 /**< Hardware acceleration function returned with error */
#define MBEDTLS_ERR_SSL_HW_ACCEL_FALLTHROUGH -28544 /**< Hardware acceleration function skipped / left alone data */
#define MBEDTLS_ERR_SSL_COMPRESSION_FAILED -28416 /**< Processing of the compression / decompression failed */
#define MBEDTLS_ERR_SSL_BAD_HS_PROTOCOL_VERSION -6E80 /**< Handshake protocol not within min/max boundaries */
#define MBEDTLS_ERR_SSL_BAD_HS_NEW_SESSION_TICKET -6E00 /**< Processing of the NewSessionTicket handshake message failed. */
#define MBEDTLS_ERR_SSL_SESSION_TICKET_EXPIRED -6D80 /**< Session ticket has expired. */
#define MBEDTLS_ERR_SSL_PK_TYPE_MISMATCH -6D00 /**< Public key type mismatch (eg, asked for RSA key exchange and presented EC key) */
#define MBEDTLS_ERR_SSL_UNKNOWN_IDENTITY -6C80 /**< Unknown identity received (eg, PSK identity) */
#define MBEDTLS_ERR_SSL_INTERNAL_ERROR -6C00 /**< Internal error (eg, unexpected failure in lower-level module) */
#define MBEDTLS_ERR_SSL_COUNTER_WRAPPING -6B80 /**< A counter would wrap (eg, too many messages exchanged). */
#define MBEDTLS_ERR_SSL_WAITING_SERVER_HELLO_RENEGO -6B00 /**< Unexpected message at ServerHello in renegotiation. */
#define MBEDTLS_ERR_SSL_HELLO_VERIFY_REQUIRED -6A80 /**< DTLS client must retry for hello verification */
#define MBEDTLS_ERR_SSL_BUFFER_TOO_SMALL -6A00 /**< A buffer is too small to receive or write a message */
#define MBEDTLS_ERR_SSL_NO_USABLE_CIPHERSUITE -27008 /**< None of the common ciphersuites is usable (eg, no suitable certificate, see debug messages). */
#define MBEDTLS_ERR_SSL_WANT_READ -26880 /**< No data of requested type currently available on underlying transport. */
#define MBEDTLS_ERR_SSL_WANT_WRITE -26752 /**< Connection requires a write call. */
#define MBEDTLS_ERR_SSL_TIMEOUT -26624 /**< The operation timed out. */
#define MBEDTLS_ERR_SSL_CLIENT_RECONNECT -26496 /**< The client initiated a reconnect from the same port. */
#define MBEDTLS_ERR_SSL_UNEXPECTED_RECORD -26368 /**< Record header looks valid but is not expected. */
#define MBEDTLS_ERR_SSL_NON_FATAL -26240 /**< The alert message received indicates a non-fatal error. */
#define MBEDTLS_ERR_SSL_INVALID_VERIFY_HASH -26112 /**< Couldn't set the hash for verifying CertificateVerify */
#define MBEDTLS_ERR_SSL_CONTINUE_PROCESSING -25984 /**< Internal-only message signaling that further message-processing should be done */
#define MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS -25856 /**< The asynchronous operation is not completed yet. */
#define MBEDTLS_ERR_SSL_EARLY_MESSAGE -25728 /**< Internal-only message signaling that a message arrived early. */
#define MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS -28672 /**< A cryptographic operation is in progress. Try again later. */
#define MBEDTLS_ERR_SSL_QUIT_FORCED -22784
#define MBEDTLS_SSL_MAJOR_VERSION_3 3
/* * Various constants */
#define MBEDTLS_SSL_MINOR_VERSION_0 0 /*!< SSL v3.0 */
#define MBEDTLS_SSL_MINOR_VERSION_1 1 /*!< TLS v1.0 */
#define MBEDTLS_SSL_MINOR_VERSION_2 2 /*!< TLS v1.1 */
#define MBEDTLS_SSL_MINOR_VERSION_3 3 /*!< TLS v1.2 */
#define MBEDTLS_SSL_TRANSPORT_STREAM 0 /*!< TLS */
#define MBEDTLS_SSL_TRANSPORT_DATAGRAM 1 /*!< DTLS */
#define MBEDTLS_SSL_MAX_HOST_NAME_LEN 255 /*!< Maximum host name defined in RFC 1035 */
#define MBEDTLS_SSL_MAX_FRAG_LEN_NONE 0 /*!< don't use this extension */
/* RFC 6066 section 4, see also mfl_code_to_length in ssl_tls.c * NONE must be zero so that memset()ing structure to zero works */
#define MBEDTLS_SSL_MAX_FRAG_LEN_512 1 /*!< MaxFragmentLength 2^9 */
#define MBEDTLS_SSL_MAX_FRAG_LEN_1024 2 /*!< MaxFragmentLength 2^10 */
#define MBEDTLS_SSL_MAX_FRAG_LEN_2048 3 /*!< MaxFragmentLength 2^11 */
#define MBEDTLS_SSL_MAX_FRAG_LEN_4096 4 /*!< MaxFragmentLength 2^12 */
#define MBEDTLS_SSL_MAX_FRAG_LEN_INVALID 5 /*!< first invalid value */
#define MBEDTLS_SSL_IS_CLIENT 0
#define MBEDTLS_SSL_IS_SERVER 1
#define MBEDTLS_SSL_IS_NOT_FALLBACK 0
#define MBEDTLS_SSL_IS_FALLBACK 1
#define MBEDTLS_SSL_EXTENDED_MS_DISABLED 0
#define MBEDTLS_SSL_EXTENDED_MS_ENABLED 1
#define MBEDTLS_SSL_ETM_DISABLED 0
#define MBEDTLS_SSL_ETM_ENABLED 1
#define MBEDTLS_SSL_COMPRESS_NULL 0
#define MBEDTLS_SSL_COMPRESS_DEFLATE 1
#define MBEDTLS_SSL_VERIFY_NONE 0
#define MBEDTLS_SSL_VERIFY_OPTIONAL 1
#define MBEDTLS_SSL_VERIFY_REQUIRED 2
#define MBEDTLS_SSL_VERIFY_UNSET 3 /* Used only for sni_authmode */
#define MBEDTLS_SSL_LEGACY_RENEGOTIATION 0
#define MBEDTLS_SSL_SECURE_RENEGOTIATION 1
#define MBEDTLS_SSL_RENEGOTIATION_DISABLED 0
#define MBEDTLS_SSL_RENEGOTIATION_ENABLED 1
#define MBEDTLS_SSL_ANTI_REPLAY_DISABLED 0
#define MBEDTLS_SSL_ANTI_REPLAY_ENABLED 1
#define MBEDTLS_SSL_RENEGOTIATION_NOT_ENFORCED -1
#define MBEDTLS_SSL_RENEGO_MAX_RECORDS_DEFAULT 16
#define MBEDTLS_SSL_LEGACY_NO_RENEGOTIATION 0
#define MBEDTLS_SSL_LEGACY_ALLOW_RENEGOTIATION 1
#define MBEDTLS_SSL_LEGACY_BREAK_HANDSHAKE 2
#define MBEDTLS_SSL_TRUNC_HMAC_DISABLED 0
#define MBEDTLS_SSL_TRUNC_HMAC_ENABLED 1
#define MBEDTLS_SSL_TRUNCATED_HMAC_LEN 10 /* 80 bits, rfc 6066 section 7 */
#define MBEDTLS_SSL_SESSION_TICKETS_DISABLED 0
#define MBEDTLS_SSL_SESSION_TICKETS_ENABLED 1
#define MBEDTLS_SSL_CBC_RECORD_SPLITTING_DISABLED 0
#define MBEDTLS_SSL_CBC_RECORD_SPLITTING_ENABLED 1
#define MBEDTLS_SSL_ARC4_ENABLED 0
#define MBEDTLS_SSL_ARC4_DISABLED 1
#define MBEDTLS_SSL_PRESET_DEFAULT 0
#define MBEDTLS_SSL_PRESET_SUITEB 2
#define MBEDTLS_SSL_CERT_REQ_CA_LIST_ENABLED 1
#define MBEDTLS_SSL_CERT_REQ_CA_LIST_DISABLED 0
#define MBEDTLS_SSL_DTLS_SRTP_MKI_UNSUPPORTED 0
#define MBEDTLS_SSL_DTLS_SRTP_MKI_SUPPORTED 1
#define MBEDTLS_SSL_DTLS_TIMEOUT_DFL_MIN 1000
/* * Default range for DTLS retransmission timer value, in milliseconds. * RFC 6347 4.2.4.1 says from 1 second to 60 seconds. */
#define MBEDTLS_SSL_DTLS_TIMEOUT_DFL_MAX 60000
#define MBEDTLS_SSL_DEFAULT_TICKET_LIFETIME 86400 /**< Lifetime of session tickets (if enabled) */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384 /**< Size of the input / output buffer */
#define MBEDTLS_SSL_IN_CONTENT_LEN MBEDTLS_SSL_MAX_CONTENT_LEN
#define MBEDTLS_SSL_OUT_CONTENT_LEN MBEDTLS_SSL_MAX_CONTENT_LEN
#define MBEDTLS_SSL_DTLS_MAX_BUFFERING 32768
#define MBEDTLS_SSL_VERIFY_DATA_MAX_LEN 36
#define MBEDTLS_SSL_VERIFY_DATA_MAX_LEN 12
#define MBEDTLS_SSL_EMPTY_RENEGOTIATION_INFO 255 /**< renegotiation info ext */
/* * Signaling ciphersuite values (SCSV) */
#define MBEDTLS_SSL_FALLBACK_SCSV_VALUE 22016 /**< RFC 7507 section 2 */
#define MBEDTLS_SSL_HASH_NONE 0
/* * Supported Signature and Hash algorithms (For TLS 1.2) * RFC 5246 section 7.4.1.4.1 */
#define MBEDTLS_SSL_HASH_MD5 1
#define MBEDTLS_SSL_HASH_SHA1 2
#define MBEDTLS_SSL_HASH_SHA224 3
#define MBEDTLS_SSL_HASH_SHA256 4
#define MBEDTLS_SSL_HASH_SHA384 5
#define MBEDTLS_SSL_HASH_SHA512 6
#define MBEDTLS_SSL_SIG_ANON 0
#define MBEDTLS_SSL_SIG_RSA 1
#define MBEDTLS_SSL_SIG_ECDSA 3
#define MBEDTLS_SSL_CERT_TYPE_RSA_SIGN 1
/* * Client Certificate Types * RFC 5246 section 7.4.4 plus RFC 4492 section 5.5 */
#define MBEDTLS_SSL_CERT_TYPE_ECDSA_SIGN 64
#define MBEDTLS_SSL_MSG_CHANGE_CIPHER_SPEC 20
/* * Message, alert and handshake types */
#define MBEDTLS_SSL_MSG_ALERT 21
#define MBEDTLS_SSL_MSG_HANDSHAKE 22
#define MBEDTLS_SSL_MSG_APPLICATION_DATA 23
#define MBEDTLS_SSL_ALERT_LEVEL_WARNING 1
#define MBEDTLS_SSL_ALERT_LEVEL_FATAL 2
#define MBEDTLS_SSL_ALERT_MSG_CLOSE_NOTIFY 0 /* 0x00 */
#define MBEDTLS_SSL_ALERT_MSG_UNEXPECTED_MESSAGE 10 /* 0x0A */
#define MBEDTLS_SSL_ALERT_MSG_BAD_RECORD_MAC 20 /* 0x14 */
#define MBEDTLS_SSL_ALERT_MSG_DECRYPTION_FAILED 21 /* 0x15 */
#define MBEDTLS_SSL_ALERT_MSG_RECORD_OVERFLOW 22 /* 0x16 */
#define MBEDTLS_SSL_ALERT_MSG_DECOMPRESSION_FAILURE 30 /* 0x1E */
#define MBEDTLS_SSL_ALERT_MSG_HANDSHAKE_FAILURE 40 /* 0x28 */
#define MBEDTLS_SSL_ALERT_MSG_NO_CERT 41 /* 0x29 */
#define MBEDTLS_SSL_ALERT_MSG_BAD_CERT 42 /* 0x2A */
#define MBEDTLS_SSL_ALERT_MSG_UNSUPPORTED_CERT 43 /* 0x2B */
#define MBEDTLS_SSL_ALERT_MSG_CERT_REVOKED 44 /* 0x2C */
#define MBEDTLS_SSL_ALERT_MSG_CERT_EXPIRED 45 /* 0x2D */
#define MBEDTLS_SSL_ALERT_MSG_CERT_UNKNOWN 46 /* 0x2E */
#define MBEDTLS_SSL_ALERT_MSG_ILLEGAL_PARAMETER 47 /* 0x2F */
#define MBEDTLS_SSL_ALERT_MSG_UNKNOWN_CA 48 /* 0x30 */
#define MBEDTLS_SSL_ALERT_MSG_ACCESS_DENIED 49 /* 0x31 */
#define MBEDTLS_SSL_ALERT_MSG_DECODE_ERROR 50 /* 0x32 */
#define MBEDTLS_SSL_ALERT_MSG_DECRYPT_ERROR 51 /* 0x33 */
#define MBEDTLS_SSL_ALERT_MSG_EXPORT_RESTRICTION 60 /* 0x3C */
#define MBEDTLS_SSL_ALERT_MSG_PROTOCOL_VERSION 70 /* 0x46 */
#define MBEDTLS_SSL_ALERT_MSG_INSUFFICIENT_SECURITY 71 /* 0x47 */
#define MBEDTLS_SSL_ALERT_MSG_INTERNAL_ERROR 80 /* 0x50 */
#define MBEDTLS_SSL_ALERT_MSG_INAPROPRIATE_FALLBACK 86 /* 0x56 */
#define MBEDTLS_SSL_ALERT_MSG_USER_CANCELED 90 /* 0x5A */
#define MBEDTLS_SSL_ALERT_MSG_NO_RENEGOTIATION 100 /* 0x64 */
#define MBEDTLS_SSL_ALERT_MSG_UNSUPPORTED_EXT 110 /* 0x6E */
#define MBEDTLS_SSL_ALERT_MSG_UNRECOGNIZED_NAME 112 /* 0x70 */
#define MBEDTLS_SSL_ALERT_MSG_UNKNOWN_PSK_IDENTITY 115 /* 0x73 */
#define MBEDTLS_SSL_ALERT_MSG_NO_APPLICATION_PROTOCOL 120 /* 0x78 */
#define MBEDTLS_SSL_HS_HELLO_REQUEST 0
#define MBEDTLS_SSL_HS_CLIENT_HELLO 1
#define MBEDTLS_SSL_HS_SERVER_HELLO 2
#define MBEDTLS_SSL_HS_HELLO_VERIFY_REQUEST 3
#define MBEDTLS_SSL_HS_NEW_SESSION_TICKET 4
#define MBEDTLS_SSL_HS_CERTIFICATE 11
#define MBEDTLS_SSL_HS_SERVER_KEY_EXCHANGE 12
#define MBEDTLS_SSL_HS_CERTIFICATE_REQUEST 13
#define MBEDTLS_SSL_HS_SERVER_HELLO_DONE 14
#define MBEDTLS_SSL_HS_CERTIFICATE_VERIFY 15
#define MBEDTLS_SSL_HS_CLIENT_KEY_EXCHANGE 16
#define MBEDTLS_SSL_HS_FINISHED 20
#define MBEDTLS_TLS_EXT_SERVERNAME 0
/* * TLS extensions */
#define MBEDTLS_TLS_EXT_SERVERNAME_HOSTNAME 0
#define MBEDTLS_TLS_EXT_MAX_FRAGMENT_LENGTH 1
#define MBEDTLS_TLS_EXT_TRUNCATED_HMAC 4
#define MBEDTLS_TLS_EXT_SUPPORTED_ELLIPTIC_CURVES 10
#define MBEDTLS_TLS_EXT_SUPPORTED_POINT_FORMATS 11
#define MBEDTLS_TLS_EXT_SIG_ALG 13
#define MBEDTLS_TLS_EXT_USE_SRTP 14
#define MBEDTLS_TLS_EXT_ALPN 16
#define MBEDTLS_TLS_EXT_ENCRYPT_THEN_MAC 22 /* 0x16 */
#define MBEDTLS_TLS_EXT_EXTENDED_MASTER_SECRET 23 /* 23 */
#define MBEDTLS_TLS_EXT_SESSION_TICKET 35
#define MBEDTLS_TLS_EXT_ECJPAKE_KKPP 256 /* experimental */
#define MBEDTLS_TLS_EXT_RENEGOTIATION_INFO 65281
#define MBEDTLS_SRTP_AES128_CM_HMAC_SHA1_80_IANA_VALUE 1
/* * use_srtp extension protection profiles values as defined in http://www.iana.org/assignments/srtp-protection/srtp-protection.xhtml */
#define MBEDTLS_SRTP_AES128_CM_HMAC_SHA1_32_IANA_VALUE 2
#define MBEDTLS_SRTP_NULL_HMAC_SHA1_80_IANA_VALUE 5
#define MBEDTLS_SRTP_NULL_HMAC_SHA1_32_IANA_VALUE 6
#define MBEDTLS_PSK_MAX_LEN 64 /* 256 bits */
//#define MBEDTLS_PSK_MAX_LEN 32 /* 256 bits */
#define MBEDTLS_PREMASTER_SIZE sizeof( union mbedtls_ssl_premaster_secret )
#define MBEDTLS_DTLS_SRTP_MAX_KEY_MATERIAL_LENGTH 60
#define MBEDTLS_DTLS_SRTP_MAX_MKI_LENGTH 255
#define MBEDTLS_SSL_CHANNEL_OUTBOUND 0
#define MBEDTLS_SSL_CHANNEL_INBOUND 1
#define MBEDTLS_DEPRECATED __attribute__((deprecated))
int mbedtls_ssl_get_ciphersuite_id( const char *ciphersuite_name );
/** * \brief Return the ID of the ciphersuite associated with the * given name * * \param ciphersuite_name SSL ciphersuite name * * \return the ID with the ciphersuite or 0 if not found */
void mbedtls_ssl_init( mbedtls_ssl_context *ssl );
/** * \brief Initialize an SSL context * Just makes the context ready for mbedtls_ssl_setup() or * mbedtls_ssl_free() * * \param ssl SSL context */
void mbed_tls_reset_in_buf_len(mbedtls_ssl_context *ssl, unsigned int new_len);
void mbed_tls_reset_out_buf_len(mbedtls_ssl_context *ssl, unsigned int new_len);
int mbedtls_ssl_setup( mbedtls_ssl_context *ssl,
const mbedtls_ssl_config *conf );
/** * \brief Set up an SSL context for use * * \note No copy of the configuration context is made, it can be * shared by many mbedtls_ssl_context structures. * * \warning The conf structure will be accessed during the session. * It must not be modified or freed as long as the session * is active. * * \warning This function must be called exactly once per context. * Calling mbedtls_ssl_setup again is not supported, even * if no session is active. * * \param ssl SSL context * \param conf SSL configuration to use * * \return 0 if successful, or MBEDTLS_ERR_SSL_ALLOC_FAILED if * memory allocation failed */
int mbedtls_ssl_session_reset( mbedtls_ssl_context *ssl );
* \brief Reset an already initialized SSL context for re-use
* while retaining application-set variables, function
* pointers and data.
* \return 0 if successful, or MBEDTLS_ERR_SSL_ALLOC_FAILED,
MBEDTLS_ERR_SSL_HW_ACCEL_FAILED or
* MBEDTLS_ERR_SSL_COMPRESSION_FAILED
void mbedtls_ssl_conf_endpoint( mbedtls_ssl_config *conf, int endpoint );
/** * \brief Set the current endpoint type * * \param conf SSL configuration * \param endpoint must be MBEDTLS_SSL_IS_CLIENT or MBEDTLS_SSL_IS_SERVER */
void mbedtls_ssl_conf_transport( mbedtls_ssl_config *conf, int transport );
/** * \brief Set the transport type (TLS or DTLS). * Default: TLS * * \note For DTLS, you must either provide a recv callback that * doesn't block, or one that handles timeouts, see * \c mbedtls_ssl_set_bio(). You also need to provide timer * callbacks with \c mbedtls_ssl_set_timer_cb(). * * \param conf SSL configuration * \param transport transport type: * MBEDTLS_SSL_TRANSPORT_STREAM for TLS, * MBEDTLS_SSL_TRANSPORT_DATAGRAM for DTLS. */
void mbedtls_ssl_conf_authmode( mbedtls_ssl_config *conf, int authmode );
/** * \brief Set the certificate verification mode * Default: NONE on server, REQUIRED on client * * \param conf SSL configuration * \param authmode can be: * * MBEDTLS_SSL_VERIFY_NONE: peer certificate is not checked * (default on server) * (insecure on client) * * MBEDTLS_SSL_VERIFY_OPTIONAL: peer certificate is checked, however the * handshake continues even if verification failed; * mbedtls_ssl_get_verify_result() can be called after the * handshake is complete. * * MBEDTLS_SSL_VERIFY_REQUIRED: peer *must* present a valid certificate, * handshake is aborted if verification failed. * (default on client) * * \note On client, MBEDTLS_SSL_VERIFY_REQUIRED is the recommended mode. * With MBEDTLS_SSL_VERIFY_OPTIONAL, the user needs to call mbedtls_ssl_get_verify_result() at * the right time(s), which may not be obvious, while REQUIRED always perform * the verification as soon as possible. For example, REQUIRED was protecting * against the "triple handshake" attack even before it was found. */
void mbedtls_ssl_conf_verify( mbedtls_ssl_config *conf,
int (*f_vrfy)(void *, mbedtls_x509_crt *, int, uint32_t *),
void *p_vrfy );
/** * \brief Set the verification callback (Optional). * * If set, the verify callback is called for each * certificate in the chain. For implementation * information, please see \c mbedtls_x509_crt_verify() * * \param conf SSL configuration * \param f_vrfy verification function * \param p_vrfy verification parameter */
void mbedtls_ssl_conf_rng( mbedtls_ssl_config *conf,
int (*f_rng)(void *, unsigned char *, size_t),
void *p_rng );
/** * \brief Set the random number generator callback * * \param conf SSL configuration * \param f_rng RNG function * \param p_rng RNG parameter */
void mbedtls_ssl_conf_dbg( mbedtls_ssl_config *conf,
void (*f_dbg)(void *, int, const char *, int, const char *),
void *p_dbg );
/** * \brief Set the debug callback * * The callback has the following argument: * void * opaque context for the callback * int debug level * const char * file name * int line number * const char * message * * \param conf SSL configuration * \param f_dbg debug function * \param p_dbg debug parameter */
void mbedtls_ssl_set_bio( mbedtls_ssl_context *ssl,
void *p_bio,
mbedtls_ssl_send_t *f_send,
mbedtls_ssl_recv_t *f_recv,
mbedtls_ssl_recv_timeout_t *f_recv_timeout );
/** * \brief Set the underlying BIO callbacks for write, read and * read-with-timeout. * * \param ssl SSL context * \param p_bio parameter (context) shared by BIO callbacks * \param f_send write callback * \param f_recv read callback * \param f_recv_timeout blocking read callback with timeout. * * \note One of f_recv or f_recv_timeout can be NULL, in which case * the other is used. If both are non-NULL, f_recv_timeout is * used and f_recv is ignored (as if it were NULL). * * \note The two most common use cases are: * - non-blocking I/O, f_recv != NULL, f_recv_timeout == NULL * - blocking I/O, f_recv == NULL, f_recv_timout != NULL * * \note For DTLS, you need to provide either a non-NULL * f_recv_timeout callback, or a f_recv that doesn't block. * * \note See the documentations of \c mbedtls_ssl_sent_t, * \c mbedtls_ssl_recv_t and \c mbedtls_ssl_recv_timeout_t for * the conventions those callbacks must follow. * * \note On some platforms, net_sockets.c provides * \c mbedtls_net_send(), \c mbedtls_net_recv() and * \c mbedtls_net_recv_timeout() that are suitable to be used * here. */
void mbedtls_ssl_set_mtu( mbedtls_ssl_context *ssl, uint16_t mtu );
/** * \brief Set the Maximum Tranport Unit (MTU). * Special value: 0 means unset (no limit). * This represents the maximum size of a datagram payload * handled by the transport layer (usually UDP) as determined * by the network link and stack. In practice, this controls * the maximum size datagram the DTLS layer will pass to the * \c f_send() callback set using \c mbedtls_ssl_set_bio(). * * \note The limit on datagram size is converted to a limit on * record payload by subtracting the current overhead of * encapsulation and encryption/authentication if any. * * \note This can be called at any point during the connection, for * example when a Path Maximum Transfer Unit (PMTU) * estimate becomes available from other sources, * such as lower (or higher) protocol layers. * * \note This setting only controls the size of the packets we send, * and does not restrict the size of the datagrams we're * willing to receive. Client-side, you can request the * server to use smaller records with \c * mbedtls_ssl_conf_max_frag_len(). * * \note If both a MTU and a maximum fragment length have been * configured (or negotiated with the peer), the resulting * lower limit on record payload (see first note) is used. * * \note This can only be used to decrease the maximum size * of datagrams (hence records, see first note) sent. It * cannot be used to increase the maximum size of records over * the limit set by #MBEDTLS_SSL_OUT_CONTENT_LEN. * * \note Values lower than the current record layer expansion will * result in an error when trying to send data. * * \note Using record compression together with a non-zero MTU value * will result in an error when trying to send data. * * \param ssl SSL context * \param mtu Value of the path MTU in bytes */
void mbedtls_ssl_conf_read_timeout( mbedtls_ssl_config *conf, uint32_t timeout );
/** * \brief Set the timeout period for mbedtls_ssl_read() * (Default: no timeout.) * * \param conf SSL configuration context * \param timeout Timeout value in milliseconds. * Use 0 for no timeout (default). * * \note With blocking I/O, this will only work if a non-NULL * \c f_recv_timeout was set with \c mbedtls_ssl_set_bio(). * With non-blocking I/O, this will only work if timer * callbacks were set with \c mbedtls_ssl_set_timer_cb(). * * \note With non-blocking I/O, you may also skip this function * altogether and handle timeouts at the application layer. */
void mbedtls_ssl_set_timer_cb( mbedtls_ssl_context *ssl,
void *p_timer,
mbedtls_ssl_set_timer_t *f_set_timer,
mbedtls_ssl_get_timer_t *f_get_timer );
/** * \brief Set the timer callbacks (Mandatory for DTLS.) * * \param ssl SSL context * \param p_timer parameter (context) shared by timer callbacks * \param f_set_timer set timer callback * \param f_get_timer get timer callback. Must return: * * \note See the documentation of \c mbedtls_ssl_set_timer_t and * \c mbedtls_ssl_get_timer_t for the conventions this pair of * callbacks must follow. * * \note On some platforms, timing.c provides * \c mbedtls_timing_set_delay() and * \c mbedtls_timing_get_delay() that are suitable for using * here, except if using an event-driven style. * * \note See also the "DTLS tutorial" article in our knowledge base. * https://tls.mbed.org/kb/how-to/dtls-tutorial */
void mbedtls_ssl_conf_session_tickets_cb( mbedtls_ssl_config *conf,
mbedtls_ssl_ticket_write_t *f_ticket_write,
mbedtls_ssl_ticket_parse_t *f_ticket_parse,
void *p_ticket );
/** * \brief Configure SSL session ticket callbacks (server only). * (Default: none.) * * \note On server, session tickets are enabled by providing * non-NULL callbacks. * * \note On client, use \c mbedtls_ssl_conf_session_tickets(). * * \param conf SSL configuration context * \param f_ticket_write Callback for writing a ticket * \param f_ticket_parse Callback for parsing a ticket * \param p_ticket Context shared by the two callbacks */
void mbedtls_ssl_conf_export_keys_cb( mbedtls_ssl_config *conf,
mbedtls_ssl_export_keys_t *f_export_keys,
void *p_export_keys );
/** * \brief Configure key export callback. * (Default: none.) * * \note See \c mbedtls_ssl_export_keys_t. * * \param conf SSL configuration context * \param f_export_keys Callback for exporting keys * \param p_export_keys Context for the callback */
void mbedtls_ssl_conf_async_private_cb( mbedtls_ssl_config *conf,
mbedtls_ssl_async_sign_t *f_async_sign,
mbedtls_ssl_async_decrypt_t *f_async_decrypt,
mbedtls_ssl_async_resume_t *f_async_resume,
mbedtls_ssl_async_cancel_t *f_async_cancel,
void *config_data );
/** * \brief Configure asynchronous private key operation callbacks. * * \param conf SSL configuration context * \param f_async_sign Callback to start a signature operation. See * the description of ::mbedtls_ssl_async_sign_t * for more information. This may be \c NULL if the * external processor does not support any signature * operation; in this case the private key object * associated with the certificate will be used. * \param f_async_decrypt Callback to start a decryption operation. See * the description of ::mbedtls_ssl_async_decrypt_t * for more information. This may be \c NULL if the * external processor does not support any decryption * operation; in this case the private key object * associated with the certificate will be used. * \param f_async_resume Callback to resume an asynchronous operation. See * the description of ::mbedtls_ssl_async_resume_t * for more information. This may not be \c NULL unless * \p f_async_sign and \p f_async_decrypt are both * \c NULL. * \param f_async_cancel Callback to cancel an asynchronous operation. See * the description of ::mbedtls_ssl_async_cancel_t * for more information. This may be \c NULL if * no cleanup is needed. * \param config_data A pointer to configuration data which can be * retrieved with * mbedtls_ssl_conf_get_async_config_data(). The * library stores this value without dereferencing it. */
void *mbedtls_ssl_conf_get_async_config_data( const mbedtls_ssl_config *conf );
/** * \brief Retrieve the configuration data set by * mbedtls_ssl_conf_async_private_cb(). * * \param conf SSL configuration context * \return The configuration data set by * mbedtls_ssl_conf_async_private_cb(). */
void *mbedtls_ssl_get_async_operation_data( const mbedtls_ssl_context *ssl );
/** * \brief Retrieve the asynchronous operation user context. * * \note This function may only be called while a handshake * is in progress. * * \param ssl The SSL context to access. * * \return The asynchronous operation user context that was last * set during the current handshake. If * mbedtls_ssl_set_async_operation_data() has not yet been * called during the current handshake, this function returns * \c NULL. */
void mbedtls_ssl_set_async_operation_data( mbedtls_ssl_context *ssl,
void *ctx );
/** * \brief Retrieve the asynchronous operation user context. * * \note This function may only be called while a handshake * is in progress. * * \param ssl The SSL context to access. * \param ctx The new value of the asynchronous operation user context. * Call mbedtls_ssl_get_async_operation_data() later during the * same handshake to retrieve this value. */
void mbedtls_ssl_conf_dtls_cookies( mbedtls_ssl_config *conf,
mbedtls_ssl_cookie_write_t *f_cookie_write,
mbedtls_ssl_cookie_check_t *f_cookie_check,
void *p_cookie );
/** * \brief Register callbacks for DTLS cookies * (Server only. DTLS only.) * * Default: dummy callbacks that fail, in order to force you to * register working callbacks (and initialize their context). * * To disable HelloVerifyRequest, register NULL callbacks. * * \warning Disabling hello verification allows your server to be used * for amplification in DoS attacks against other hosts. * Only disable if you known this can't happen in your * particular environment. * * \note See comments on \c mbedtls_ssl_handshake() about handling * the MBEDTLS_ERR_SSL_HELLO_VERIFY_REQUIRED that is expected * on the first handshake attempt when this is enabled. * * \note This is also necessary to handle client reconnection from * the same port as described in RFC 6347 section 4.2.8 (only * the variant with cookies is supported currently). See * comments on \c mbedtls_ssl_read() for details. * * \param conf SSL configuration * \param f_cookie_write Cookie write callback * \param f_cookie_check Cookie check callback * \param p_cookie Context for both callbacks */
int mbedtls_ssl_set_client_transport_id( mbedtls_ssl_context *ssl,
const unsigned char *info,
size_t ilen );
/** * \brief Set client's transport-level identification info. * (Server only. DTLS only.) * * This is usually the IP address (and port), but could be * anything identify the client depending on the underlying * network stack. Used for HelloVerifyRequest with DTLS. * This is *not* used to route the actual packets. * * \param ssl SSL context * \param info Transport-level info identifying the client (eg IP + port) * \param ilen Length of info in bytes * * \note An internal copy is made, so the info buffer can be reused. * * \return 0 on success, * MBEDTLS_ERR_SSL_BAD_INPUT_DATA if used on client, * MBEDTLS_ERR_SSL_ALLOC_FAILED if out of memory. */
void mbedtls_ssl_conf_dtls_anti_replay( mbedtls_ssl_config *conf, char mode );
/** * \brief Enable or disable anti-replay protection for DTLS. * (DTLS only, no effect on TLS.) * Default: enabled. * * \param conf SSL configuration * \param mode MBEDTLS_SSL_ANTI_REPLAY_ENABLED or MBEDTLS_SSL_ANTI_REPLAY_DISABLED. * * \warning Disabling this is a security risk unless the application * protocol handles duplicated packets in a safe way. You * should not disable this without careful consideration. * However, if your application already detects duplicated * packets and needs information about them to adjust its * transmission strategy, then you'll want to disable this. */
void mbedtls_ssl_conf_dtls_badmac_limit( mbedtls_ssl_config *conf, unsigned limit );
/** * \brief Set a limit on the number of records with a bad MAC * before terminating the connection. * (DTLS only, no effect on TLS.) * Default: 0 (disabled). * * \param conf SSL configuration * \param limit Limit, or 0 to disable. * * \note If the limit is N, then the connection is terminated when * the Nth non-authentic record is seen. * * \note Records with an invalid header are not counted, only the * ones going through the authentication-decryption phase. * * \note This is a security trade-off related to the fact that it's * often relatively easy for an active attacker ot inject UDP * datagrams. On one hand, setting a low limit here makes it * easier for such an attacker to forcibly terminated a * connection. On the other hand, a high limit or no limit * might make us waste resources checking authentication on * many bogus packets. */
void mbedtls_ssl_set_datagram_packing( mbedtls_ssl_context *ssl,
unsigned allow_packing );
/** * \brief Allow or disallow packing of multiple handshake records * within a single datagram. * * \param ssl The SSL context to configure. * \param allow_packing This determines whether datagram packing may * be used or not. A value of \c 0 means that every * record will be sent in a separate datagram; a * value of \c 1 means that, if space permits, * multiple handshake messages (including CCS) belonging to * a single flight may be packed within a single datagram. * * \note This is enabled by default and should only be disabled * for test purposes, or if datagram packing causes * interoperability issues with peers that don't support it. * * \note Allowing datagram packing reduces the network load since * there's less overhead if multiple messages share the same * datagram. Also, it increases the handshake efficiency * since messages belonging to a single datagram will not * be reordered in transit, and so future message buffering * or flight retransmission (if no buffering is used) as * means to deal with reordering are needed less frequently. * * \note Application records are not affected by this option and * are currently always sent in separate datagrams. * */
void mbedtls_ssl_conf_handshake_timeout( mbedtls_ssl_config *conf, uint32_t min, uint32_t max );
/** * \brief Set retransmit timeout values for the DTLS handshake. * (DTLS only, no effect on TLS.) * * \param conf SSL configuration * \param min Initial timeout value in milliseconds. * Default: 1000 (1 second). * \param max Maximum timeout value in milliseconds. * Default: 60000 (60 seconds). * * \note Default values are from RFC 6347 section 4.2.4.1. * * \note The 'min' value should typically be slightly above the * expected round-trip time to your peer, plus whatever time * it takes for the peer to process the message. For example, * if your RTT is about 600ms and you peer needs up to 1s to * do the cryptographic operations in the handshake, then you * should set 'min' slightly above 1600. Lower values of 'min' * might cause spurious resends which waste network resources, * while larger value of 'min' will increase overall latency * on unreliable network links. * * \note The more unreliable your network connection is, the larger * your max / min ratio needs to be in order to achieve * reliable handshakes. * * \note Messages are retransmitted up to log2(ceil(max/min)) times. * For example, if min = 1s and max = 5s, the retransmit plan * goes: send ... 1s -> resend ... 2s -> resend ... 4s -> * resend ... 5s -> give up and return a timeout error. */
void mbedtls_ssl_conf_session_cache( mbedtls_ssl_config *conf,
void *p_cache,
int (*f_get_cache)(void *, mbedtls_ssl_session *),
int (*f_set_cache)(void *, const mbedtls_ssl_session *) );
/** * \brief Set the session cache callbacks (server-side only) * If not set, no session resuming is done (except if session * tickets are enabled too). * * The session cache has the responsibility to check for stale * entries based on timeout. See RFC 5246 for recommendations. * * Warning: session.peer_cert is cleared by the SSL/TLS layer on * connection shutdown, so do not cache the pointer! Either set * it to NULL or make a full copy of the certificate. * * The get callback is called once during the initial handshake * to enable session resuming. The get function has the * following parameters: (void *parameter, mbedtls_ssl_session *session) * If a valid entry is found, it should fill the master of * the session object with the cached values and return 0, * return 1 otherwise. Optionally peer_cert can be set as well * if it is properly present in cache entry. * * The set callback is called once during the initial handshake * to enable session resuming after the entire handshake has * been finished. The set function has the following parameters: * (void *parameter, const mbedtls_ssl_session *session). The function * should create a cache entry for future retrieval based on * the data in the session structure and should keep in mind * that the mbedtls_ssl_session object presented (and all its referenced * data) is cleared by the SSL/TLS layer when the connection is * terminated. It is recommended to add metadata to determine if * an entry is still valid in the future. Return 0 if * successfully cached, return 1 otherwise. * * \param conf SSL configuration * \param p_cache parmater (context) for both callbacks * \param f_get_cache session get callback * \param f_set_cache session set callback */
int mbedtls_ssl_set_session( mbedtls_ssl_context *ssl, const mbedtls_ssl_session *session );
/** * \brief Request resumption of session (client-side only) * Session data is copied from presented session structure. * * \param ssl SSL context * \param session session context * * \return 0 if successful, * MBEDTLS_ERR_SSL_ALLOC_FAILED if memory allocation failed, * MBEDTLS_ERR_SSL_BAD_INPUT_DATA if used server-side or * arguments are otherwise invalid * * \sa mbedtls_ssl_get_session() */
void mbedtls_ssl_conf_ciphersuites( mbedtls_ssl_config *conf,
const int *ciphersuites );
/** * \brief Set the list of allowed ciphersuites and the preference * order. First in the list has the highest preference. * (Overrides all version-specific lists) * * The ciphersuites array is not copied, and must remain * valid for the lifetime of the ssl_config. * * Note: The server uses its own preferences * over the preference of the client unless * MBEDTLS_SSL_SRV_RESPECT_CLIENT_PREFERENCE is defined! * * \param conf SSL configuration * \param ciphersuites 0-terminated list of allowed ciphersuites */
void mbedtls_ssl_conf_ciphersuites_for_version( mbedtls_ssl_config *conf,
const int *ciphersuites,
int major, int minor );
/** * \brief Set the list of allowed ciphersuites and the * preference order for a specific version of the protocol. * (Only useful on the server side) * * The ciphersuites array is not copied, and must remain * valid for the lifetime of the ssl_config. * * \param conf SSL configuration * \param ciphersuites 0-terminated list of allowed ciphersuites * \param major Major version number (only MBEDTLS_SSL_MAJOR_VERSION_3 * supported) * \param minor Minor version number (MBEDTLS_SSL_MINOR_VERSION_0, * MBEDTLS_SSL_MINOR_VERSION_1 and MBEDTLS_SSL_MINOR_VERSION_2, * MBEDTLS_SSL_MINOR_VERSION_3 supported) * * \note With DTLS, use MBEDTLS_SSL_MINOR_VERSION_2 for DTLS 1.0 * and MBEDTLS_SSL_MINOR_VERSION_3 for DTLS 1.2 */
void mbedtls_ssl_conf_cert_profile( mbedtls_ssl_config *conf,
const mbedtls_x509_crt_profile *profile );
/** * \brief Set the X.509 security profile used for verification * * \note The restrictions are enforced for all certificates in the * chain. However, signatures in the handshake are not covered * by this setting but by \b mbedtls_ssl_conf_sig_hashes(). * * \param conf SSL configuration * \param profile Profile to use */
void mbedtls_ssl_conf_ca_chain( mbedtls_ssl_config *conf,
mbedtls_x509_crt *ca_chain,
mbedtls_x509_crl *ca_crl );
/** * \brief Set the data required to verify peer certificate * * \note See \c mbedtls_x509_crt_verify() for notes regarding the * parameters ca_chain (maps to trust_ca for that function) * and ca_crl. * * \param conf SSL configuration * \param ca_chain trusted CA chain (meaning all fully trusted top-level CAs) * \param ca_crl trusted CA CRLs */
int mbedtls_ssl_conf_own_cert( mbedtls_ssl_config *conf,
mbedtls_x509_crt *own_cert,
mbedtls_pk_context *pk_key );
/** * \brief Set own certificate chain and private key * * \note own_cert should contain in order from the bottom up your * certificate chain. The top certificate (self-signed) * can be omitted. * * \note On server, this function can be called multiple times to * provision more than one cert/key pair (eg one ECDSA, one * RSA with SHA-256, one RSA with SHA-1). An adequate * certificate will be selected according to the client's * advertised capabilities. In case mutliple certificates are * adequate, preference is given to the one set by the first * call to this function, then second, etc. * * \note On client, only the first call has any effect. That is, * only one client certificate can be provisioned. The * server's preferences in its CertficateRequest message will * be ignored and our only cert will be sent regardless of * whether it matches those preferences - the server can then * decide what it wants to do with it. * * \note The provided \p pk_key needs to match the public key in the * first certificate in \p own_cert, or all handshakes using * that certificate will fail. It is your responsibility * to ensure that; this function will not perform any check. * You may use mbedtls_pk_check_pair() in order to perform * this check yourself, but be aware that this function can * be computationally expensive on some key types. * * \param conf SSL configuration * \param own_cert own public certificate chain * \param pk_key own private key * * \return 0 on success or MBEDTLS_ERR_SSL_ALLOC_FAILED */
int mbedtls_ssl_conf_psk( mbedtls_ssl_config *conf,
const unsigned char *psk, size_t psk_len,
const unsigned char *psk_identity, size_t psk_identity_len );
/** * \brief Set the Pre Shared Key (PSK) and the expected identity name * * \note This is mainly useful for clients. Servers will usually * want to use \c mbedtls_ssl_conf_psk_cb() instead. * * \note Currently clients can only register one pre-shared key. * In other words, the servers' identity hint is ignored. * Support for setting multiple PSKs on clients and selecting * one based on the identity hint is not a planned feature but * feedback is welcomed. * * \param conf SSL configuration * \param psk pointer to the pre-shared key * \param psk_len pre-shared key length * \param psk_identity pointer to the pre-shared key identity * \param psk_identity_len identity key length * * \return 0 if successful or MBEDTLS_ERR_SSL_ALLOC_FAILED */
int mbedtls_ssl_set_hs_psk( mbedtls_ssl_context *ssl,
const unsigned char *psk, size_t psk_len );
/** * \brief Set the Pre Shared Key (PSK) for the current handshake * * \note This should only be called inside the PSK callback, * ie the function passed to \c mbedtls_ssl_conf_psk_cb(). * * \param ssl SSL context * \param psk pointer to the pre-shared key * \param psk_len pre-shared key length * * \return 0 if successful or MBEDTLS_ERR_SSL_ALLOC_FAILED */
void mbedtls_ssl_conf_psk_cb( mbedtls_ssl_config *conf,
int (*f_psk)(void *, mbedtls_ssl_context *, const unsigned char *,
size_t),
void *p_psk );
/** * \brief Set the PSK callback (server-side only). * * If set, the PSK callback is called for each * handshake where a PSK ciphersuite was negotiated. * The caller provides the identity received and wants to * receive the actual PSK data and length. * * The callback has the following parameters: (void *parameter, * mbedtls_ssl_context *ssl, const unsigned char *psk_identity, * size_t identity_len) * If a valid PSK identity is found, the callback should use * \c mbedtls_ssl_set_hs_psk() on the ssl context to set the * correct PSK and return 0. * Any other return value will result in a denied PSK identity. * * \note If you set a PSK callback using this function, then you * don't need to set a PSK key and identity using * \c mbedtls_ssl_conf_psk(). * * \param conf SSL configuration * \param f_psk PSK identity function * \param p_psk PSK identity parameter */
int mbedtls_ssl_conf_dh_param_bin( mbedtls_ssl_config *conf,
const unsigned char *dhm_P, size_t P_len,
const unsigned char *dhm_G, size_t G_len );
/** * \brief Set the Diffie-Hellman public P and G values * from big-endian binary presentations. * (Default values: MBEDTLS_DHM_RFC3526_MODP_2048_[PG]_BIN) * * \param conf SSL configuration * \param dhm_P Diffie-Hellman-Merkle modulus in big-endian binary form * \param P_len Length of DHM modulus * \param dhm_G Diffie-Hellman-Merkle generator in big-endian binary form * \param G_len Length of DHM generator * * \return 0 if successful */
int mbedtls_ssl_conf_dh_param_ctx( mbedtls_ssl_config *conf, mbedtls_dhm_context *dhm_ctx );
/** * \brief Set the Diffie-Hellman public P and G values, * read from existing context (server-side only) * * \param conf SSL configuration * \param dhm_ctx Diffie-Hellman-Merkle context * * \return 0 if successful */
void mbedtls_ssl_conf_dhm_min_bitlen( mbedtls_ssl_config *conf,
unsigned int bitlen );
/** * \brief Set the minimum length for Diffie-Hellman parameters. * (Client-side only.) * (Default: 1024 bits.) * * \param conf SSL configuration * \param bitlen Minimum bit length of the DHM prime */
void mbedtls_ssl_conf_curves( mbedtls_ssl_config *conf,
const mbedtls_ecp_group_id *curves );
/** * \brief Set the allowed curves in order of preference. * (Default: all defined curves.) * * On server: this only affects selection of the ECDHE curve; * the curves used for ECDH and ECDSA are determined by the * list of available certificates instead. * * On client: this affects the list of curves offered for any * use. The server can override our preference order. * * Both sides: limits the set of curves accepted for use in * ECDHE and in the peer's end-entity certificate. * * \note This has no influence on which curves are allowed inside the * certificate chains, see \c mbedtls_ssl_conf_cert_profile() * for that. For the end-entity certificate however, the key * will be accepted only if it is allowed both by this list * and by the cert profile. * * \note This list should be ordered by decreasing preference * (preferred curve first). * * \param conf SSL configuration * \param curves Ordered list of allowed curves, * terminated by MBEDTLS_ECP_DP_NONE. */
void mbedtls_ssl_conf_sig_hashes( mbedtls_ssl_config *conf,
const int *hashes );
/** * \brief Set the allowed hashes for signatures during the handshake. * (Default: all available hashes except MD5.) * * \note This only affects which hashes are offered and can be used * for signatures during the handshake. Hashes for message * authentication and the TLS PRF are controlled by the * ciphersuite, see \c mbedtls_ssl_conf_ciphersuites(). Hashes * used for certificate signature are controlled by the * verification profile, see \c mbedtls_ssl_conf_cert_profile(). * * \note This list should be ordered by decreasing preference * (preferred hash first). * * \param conf SSL configuration * \param hashes Ordered list of allowed signature hashes, * terminated by \c MBEDTLS_MD_NONE. */
int mbedtls_ssl_set_hostname( mbedtls_ssl_context *ssl, const char *hostname );
/** * \brief Set or reset the hostname to check against the received * server certificate. It sets the ServerName TLS extension, * too, if that extension is enabled. (client-side only) * * \param ssl SSL context * \param hostname the server hostname, may be NULL to clear hostname * \note Maximum hostname length MBEDTLS_SSL_MAX_HOST_NAME_LEN. * * \return 0 if successful, MBEDTLS_ERR_SSL_ALLOC_FAILED on * allocation failure, MBEDTLS_ERR_SSL_BAD_INPUT_DATA on * too long input hostname. * * Hostname set to the one provided on success (cleared * when NULL). On allocation failure hostname is cleared. * On too long input failure, old hostname is unchanged. */
int mbedtls_ssl_set_hs_own_cert( mbedtls_ssl_context *ssl,
/** * \brief Set own certificate and key for the current handshake * * \note Same as \c mbedtls_ssl_conf_own_cert() but for use within * the SNI callback. * * \param ssl SSL context * \param own_cert own public certificate chain * \param pk_key own private key * * \return 0 on success or MBEDTLS_ERR_SSL_ALLOC_FAILED */
void mbedtls_ssl_set_hs_ca_chain( mbedtls_ssl_context *ssl,
/** * \brief Set the data required to verify peer certificate for the * current handshake * * \note Same as \c mbedtls_ssl_conf_ca_chain() but for use within * the SNI callback. * * \param ssl SSL context * \param ca_chain trusted CA chain (meaning all fully trusted top-level CAs) * \param ca_crl trusted CA CRLs */
void mbedtls_ssl_set_hs_authmode( mbedtls_ssl_context *ssl,
int authmode );
/** * \brief Set authmode for the current handshake. * * \note Same as \c mbedtls_ssl_conf_authmode() but for use within * the SNI callback. * * \param ssl SSL context * \param authmode MBEDTLS_SSL_VERIFY_NONE, MBEDTLS_SSL_VERIFY_OPTIONAL or * MBEDTLS_SSL_VERIFY_REQUIRED */
void mbedtls_ssl_conf_sni( mbedtls_ssl_config *conf,
int (*f_sni)(void *, mbedtls_ssl_context *, const unsigned char *,
size_t),
void *p_sni );
/** * \brief Set server side ServerName TLS extension callback * (optional, server-side only). * * If set, the ServerName callback is called whenever the * server receives a ServerName TLS extension from the client * during a handshake. The ServerName callback has the * following parameters: (void *parameter, mbedtls_ssl_context *ssl, * const unsigned char *hostname, size_t len). If a suitable * certificate is found, the callback must set the * certificate(s) and key(s) to use with \c * mbedtls_ssl_set_hs_own_cert() (can be called repeatedly), * and may optionally adjust the CA and associated CRL with \c * mbedtls_ssl_set_hs_ca_chain() as well as the client * authentication mode with \c mbedtls_ssl_set_hs_authmode(), * then must return 0. If no matching name is found, the * callback must either set a default cert, or * return non-zero to abort the handshake at this point. * * \param conf SSL configuration * \param f_sni verification function * \param p_sni verification parameter */
int mbedtls_ssl_set_hs_ecjpake_password( mbedtls_ssl_context *ssl,
const unsigned char *pw,
size_t pw_len );
/** * \brief Set the EC J-PAKE password for current handshake. * * \note An internal copy is made, and destroyed as soon as the * handshake is completed, or when the SSL context is reset or * freed. * * \note The SSL context needs to be already set up. The right place * to call this function is between \c mbedtls_ssl_setup() or * \c mbedtls_ssl_reset() and \c mbedtls_ssl_handshake(). * * \param ssl SSL context * \param pw EC J-PAKE password (pre-shared secret) * \param pw_len length of pw in bytes * * \return 0 on success, or a negative error code. */
int mbedtls_ssl_conf_alpn_protocols( mbedtls_ssl_config *conf, const char **protos );
/** * \brief Set the supported Application Layer Protocols. * * \param conf SSL configuration * \param protos Pointer to a NULL-terminated list of supported protocols, * in decreasing preference order. The pointer to the list is * recorded by the library for later reference as required, so * the lifetime of the table must be atleast as long as the * lifetime of the SSL configuration structure. * * \return 0 on success, or MBEDTLS_ERR_SSL_BAD_INPUT_DATA. */
void mbedtls_ssl_conf_srtp_mki_value_supported( mbedtls_ssl_config *conf,
int support_mki_value );
/** * \brief Add support for mki value in use_srtp extension * (Default: MBEDTLS_SSL_DTLS_SRTP_MKI_UNSUPPORTED) * * \param conf SSL configuration * \param support_mki_value Enable or disable (MBEDTLS_SSL_DTLS_SRTP_MKI_UNSUPPORTED * or MBEDTLS_SSL_DTLS_SRTP_MKI_SUPPORTED) */
int mbedtls_ssl_conf_dtls_srtp_protection_profiles( mbedtls_ssl_config *conf,
const mbedtls_ssl_srtp_profile *profiles,
size_t profiles_number );
/** * \brief Set the supported DTLS-SRTP protection profiles. * * \param conf SSL configuration * \param profiles List of supported protection profiles, * in decreasing preference order. * \param profiles_number Number of supported profiles. * * \return 0 on success, or MBEDTLS_ERR_SSL_BAD_INPUT_DATA. */
int mbedtls_ssl_dtls_srtp_set_mki_value( mbedtls_ssl_context *ssl,
unsigned char *mki_value,
size_t mki_len );
/** * \brief Set the mki_value for the current dtls session. * * \param ssl SSL context * \param mki_value MKI value to set * \param mki_len MKI length * * \return 0 on success, MBEDTLS_ERR_SSL_BAD_INPUT_DATA * or MBEDTLS_ERR_SSL_FEATURE_UNAVAILABLE on failure */
int mbedtls_ssl_get_dtls_srtp_key_material( const mbedtls_ssl_context *ssl,
unsigned char *key,
size_t *key_len );
/** * \brief Get the generated DTLS-SRTP key material. * This function should be called after the handshake is * completed. It shall returns 80 bytes of key material * generated according to RFC5764 * * \param ssl SSL context * \param key Buffer to hold the generated key material * \param key_len [in/out] key buffer size. outputs the actual number * of bytes written * * \return 0 on succes, MBEDTLS_ERR_SSL_BUFFER_TOO_SMALL if the key buffer * is too small to hold the generated key */
void mbedtls_ssl_conf_max_version( mbedtls_ssl_config *conf, int major, int minor );
/** * \brief Set the maximum supported version sent from the client side * and/or accepted at the server side * (Default: MBEDTLS_SSL_MAX_MAJOR_VERSION, MBEDTLS_SSL_MAX_MINOR_VERSION) * * \note This ignores ciphersuites from higher versions. * * \note With DTLS, use MBEDTLS_SSL_MINOR_VERSION_2 for DTLS 1.0 and * MBEDTLS_SSL_MINOR_VERSION_3 for DTLS 1.2 * * \param conf SSL configuration * \param major Major version number (only MBEDTLS_SSL_MAJOR_VERSION_3 supported) * \param minor Minor version number (MBEDTLS_SSL_MINOR_VERSION_0, * MBEDTLS_SSL_MINOR_VERSION_1 and MBEDTLS_SSL_MINOR_VERSION_2, * MBEDTLS_SSL_MINOR_VERSION_3 supported) */
void mbedtls_ssl_conf_min_version( mbedtls_ssl_config *conf, int major, int minor );
/** * \brief Set the minimum accepted SSL/TLS protocol version * (Default: TLS 1.0) * * \note Input outside of the SSL_MAX_XXXXX_VERSION and * SSL_MIN_XXXXX_VERSION range is ignored. * * \note MBEDTLS_SSL_MINOR_VERSION_0 (SSL v3) should be avoided. * * \note With DTLS, use MBEDTLS_SSL_MINOR_VERSION_2 for DTLS 1.0 and * MBEDTLS_SSL_MINOR_VERSION_3 for DTLS 1.2 * * \param conf SSL configuration * \param major Major version number (only MBEDTLS_SSL_MAJOR_VERSION_3 supported) * \param minor Minor version number (MBEDTLS_SSL_MINOR_VERSION_0, * MBEDTLS_SSL_MINOR_VERSION_1 and MBEDTLS_SSL_MINOR_VERSION_2, * MBEDTLS_SSL_MINOR_VERSION_3 supported) */
void mbedtls_ssl_conf_fallback( mbedtls_ssl_config *conf, char fallback );
/** * \brief Set the fallback flag (client-side only). * (Default: MBEDTLS_SSL_IS_NOT_FALLBACK). * * \note Set to MBEDTLS_SSL_IS_FALLBACK when preparing a fallback * connection, that is a connection with max_version set to a * lower value than the value you're willing to use. Such * fallback connections are not recommended but are sometimes * necessary to interoperate with buggy (version-intolerant) * servers. * * \warning You should NOT set this to MBEDTLS_SSL_IS_FALLBACK for * non-fallback connections! This would appear to work for a * while, then cause failures when the server is upgraded to * support a newer TLS version. * * \param conf SSL configuration * \param fallback MBEDTLS_SSL_IS_NOT_FALLBACK or MBEDTLS_SSL_IS_FALLBACK */
void mbedtls_ssl_conf_encrypt_then_mac( mbedtls_ssl_config *conf, char etm );
/** * \brief Enable or disable Encrypt-then-MAC * (Default: MBEDTLS_SSL_ETM_ENABLED) * * \note This should always be enabled, it is a security * improvement, and should not cause any interoperability * issue (used only if the peer supports it too). * * \param conf SSL configuration * \param etm MBEDTLS_SSL_ETM_ENABLED or MBEDTLS_SSL_ETM_DISABLED */
void mbedtls_ssl_conf_extended_master_secret( mbedtls_ssl_config *conf, char ems );
/** * \brief Enable or disable Extended Master Secret negotiation. * (Default: MBEDTLS_SSL_EXTENDED_MS_ENABLED) * * \note This should always be enabled, it is a security fix to the * protocol, and should not cause any interoperability issue * (used only if the peer supports it too). * * \param conf SSL configuration * \param ems MBEDTLS_SSL_EXTENDED_MS_ENABLED or MBEDTLS_SSL_EXTENDED_MS_DISABLED */
void mbedtls_ssl_conf_arc4_support( mbedtls_ssl_config *conf, char arc4 );
/** * \brief Disable or enable support for RC4 * (Default: MBEDTLS_SSL_ARC4_DISABLED) * * \warning Use of RC4 in DTLS/TLS has been prohibited by RFC 7465 * for security reasons. Use at your own risk. * * \note This function is deprecated and will likely be removed in * a future version of the library. * RC4 is disabled by default at compile time and needs to be * actively enabled for use with legacy systems. * * \param conf SSL configuration * \param arc4 MBEDTLS_SSL_ARC4_ENABLED or MBEDTLS_SSL_ARC4_DISABLED */
void mbedtls_ssl_conf_cert_req_ca_list( mbedtls_ssl_config *conf,
char cert_req_ca_list );
/** * \brief Whether to send a list of acceptable CAs in * CertificateRequest messages. * (Default: do send) * * \param conf SSL configuration * \param cert_req_ca_list MBEDTLS_SSL_CERT_REQ_CA_LIST_ENABLED or * MBEDTLS_SSL_CERT_REQ_CA_LIST_DISABLED */
int mbedtls_ssl_conf_max_frag_len( mbedtls_ssl_config *conf, unsigned char mfl_code );
/** * \brief Set the maximum fragment length to emit and/or negotiate. * (Typical: the smaller of #MBEDTLS_SSL_IN_CONTENT_LEN and * #MBEDTLS_SSL_OUT_CONTENT_LEN, usually `2^14` bytes) * (Server: set maximum fragment length to emit, * usually negotiated by the client during handshake) * (Client: set maximum fragment length to emit *and* * negotiate with the server during handshake) * (Default: #MBEDTLS_SSL_MAX_FRAG_LEN_NONE) * * \note On the client side, the maximum fragment length extension * *will not* be used, unless the maximum fragment length has * been set via this function to a value different than * #MBEDTLS_SSL_MAX_FRAG_LEN_NONE. * * \note This sets the maximum length for a record's payload, * excluding record overhead that will be added to it, see * \c mbedtls_ssl_get_record_expansion(). * * \note With TLS, this currently only affects ApplicationData (sent * with \c mbedtls_ssl_read()), not handshake messages. * With DTLS, this affects both ApplicationData and handshake. * * \note For DTLS, it is also possible to set a limit for the total * size of daragrams passed to the transport layer, including * record overhead, see \c mbedtls_ssl_set_mtu(). * * \param conf SSL configuration * \param mfl_code Code for maximum fragment length (allowed values: * MBEDTLS_SSL_MAX_FRAG_LEN_512, MBEDTLS_SSL_MAX_FRAG_LEN_1024, * MBEDTLS_SSL_MAX_FRAG_LEN_2048, MBEDTLS_SSL_MAX_FRAG_LEN_4096) * * \return 0 if successful or MBEDTLS_ERR_SSL_BAD_INPUT_DATA */
void mbedtls_ssl_conf_truncated_hmac( mbedtls_ssl_config *conf, int truncate );
/** * \brief Activate negotiation of truncated HMAC * (Default: MBEDTLS_SSL_TRUNC_HMAC_DISABLED) * * \param conf SSL configuration * \param truncate Enable or disable (MBEDTLS_SSL_TRUNC_HMAC_ENABLED or * MBEDTLS_SSL_TRUNC_HMAC_DISABLED) */
void mbedtls_ssl_conf_cbc_record_splitting( mbedtls_ssl_config *conf, char split );
/** * \brief Enable / Disable 1/n-1 record splitting * (Default: MBEDTLS_SSL_CBC_RECORD_SPLITTING_ENABLED) * * \note Only affects SSLv3 and TLS 1.0, not higher versions. * Does not affect non-CBC ciphersuites in any version. * * \param conf SSL configuration * \param split MBEDTLS_SSL_CBC_RECORD_SPLITTING_ENABLED or * MBEDTLS_SSL_CBC_RECORD_SPLITTING_DISABLED */
void mbedtls_ssl_conf_session_tickets( mbedtls_ssl_config *conf, int use_tickets );
/** * \brief Enable / Disable session tickets (client only). * (Default: MBEDTLS_SSL_SESSION_TICKETS_ENABLED.) * * \note On server, use \c mbedtls_ssl_conf_session_tickets_cb(). * * \param conf SSL configuration * \param use_tickets Enable or disable (MBEDTLS_SSL_SESSION_TICKETS_ENABLED or * MBEDTLS_SSL_SESSION_TICKETS_DISABLED) */
void mbedtls_ssl_conf_renegotiation( mbedtls_ssl_config *conf, int renegotiation );
/** * \brief Enable / Disable renegotiation support for connection when * initiated by peer * (Default: MBEDTLS_SSL_RENEGOTIATION_DISABLED) * * \warning It is recommended to always disable renegotation unless you * know you need it and you know what you're doing. In the * past, there have been several issues associated with * renegotiation or a poor understanding of its properties. * * \note Server-side, enabling renegotiation also makes the server * susceptible to a resource DoS by a malicious client. * * \param conf SSL configuration * \param renegotiation Enable or disable (MBEDTLS_SSL_RENEGOTIATION_ENABLED or * MBEDTLS_SSL_RENEGOTIATION_DISABLED) */
void mbedtls_ssl_conf_legacy_renegotiation( mbedtls_ssl_config *conf, int allow_legacy );
/** * \brief Prevent or allow legacy renegotiation. * (Default: MBEDTLS_SSL_LEGACY_NO_RENEGOTIATION) * * MBEDTLS_SSL_LEGACY_NO_RENEGOTIATION allows connections to * be established even if the peer does not support * secure renegotiation, but does not allow renegotiation * to take place if not secure. * (Interoperable and secure option) * * MBEDTLS_SSL_LEGACY_ALLOW_RENEGOTIATION allows renegotiations * with non-upgraded peers. Allowing legacy renegotiation * makes the connection vulnerable to specific man in the * middle attacks. (See RFC 5746) * (Most interoperable and least secure option) * * MBEDTLS_SSL_LEGACY_BREAK_HANDSHAKE breaks off connections * if peer does not support secure renegotiation. Results * in interoperability issues with non-upgraded peers * that do not support renegotiation altogether. * (Most secure option, interoperability issues) * * \param conf SSL configuration * \param allow_legacy Prevent or allow (SSL_NO_LEGACY_RENEGOTIATION, * SSL_ALLOW_LEGACY_RENEGOTIATION or * MBEDTLS_SSL_LEGACY_BREAK_HANDSHAKE) */
void mbedtls_ssl_conf_renegotiation_enforced( mbedtls_ssl_config *conf, int max_records );
/** * \brief Enforce renegotiation requests. * (Default: enforced, max_records = 16) * * When we request a renegotiation, the peer can comply or * ignore the request. This function allows us to decide * whether to enforce our renegotiation requests by closing * the connection if the peer doesn't comply. * * However, records could already be in transit from the peer * when the request is emitted. In order to increase * reliability, we can accept a number of records before the * expected handshake records. * * The optimal value is highly dependent on the specific usage * scenario. * * \note With DTLS and server-initiated renegotiation, the * HelloRequest is retransmited every time mbedtls_ssl_read() times * out or receives Application Data, until: * - max_records records have beens seen, if it is >= 0, or * - the number of retransmits that would happen during an * actual handshake has been reached. * Please remember the request might be lost a few times * if you consider setting max_records to a really low value. * * \warning On client, the grace period can only happen during * mbedtls_ssl_read(), as opposed to mbedtls_ssl_write() and mbedtls_ssl_renegotiate() * which always behave as if max_record was 0. The reason is, * if we receive application data from the server, we need a * place to write it, which only happens during mbedtls_ssl_read(). * * \param conf SSL configuration * \param max_records Use MBEDTLS_SSL_RENEGOTIATION_NOT_ENFORCED if you don't want to * enforce renegotiation, or a non-negative value to enforce * it but allow for a grace period of max_records records. */
void mbedtls_ssl_conf_renegotiation_period( mbedtls_ssl_config *conf,
const unsigned char period[8] );
/** * \brief Set record counter threshold for periodic renegotiation. * (Default: 2^48 - 1) * * Renegotiation is automatically triggered when a record * counter (outgoing or ingoing) crosses the defined * threshold. The default value is meant to prevent the * connection from being closed when the counter is about to * reached its maximal value (it is not allowed to wrap). * * Lower values can be used to enforce policies such as "keys * must be refreshed every N packets with cipher X". * * The renegotiation period can be disabled by setting * conf->disable_renegotiation to * MBEDTLS_SSL_RENEGOTIATION_DISABLED. * * \note When the configured transport is * MBEDTLS_SSL_TRANSPORT_DATAGRAM the maximum renegotiation * period is 2^48 - 1, and for MBEDTLS_SSL_TRANSPORT_STREAM, * the maximum renegotiation period is 2^64 - 1. * * \param conf SSL configuration * \param period The threshold value: a big-endian 64-bit number. */
int mbedtls_ssl_check_pending( const mbedtls_ssl_context *ssl );
/** * \brief Check if there is data already read from the * underlying transport but not yet processed. * * \param ssl SSL context * * \return 0 if nothing's pending, 1 otherwise. * * \note This is different in purpose and behaviour from * \c mbedtls_ssl_get_bytes_avail in that it considers * any kind of unprocessed data, not only unread * application data. If \c mbedtls_ssl_get_bytes * returns a non-zero value, this function will * also signal pending data, but the converse does * not hold. For example, in DTLS there might be * further records waiting to be processed from * the current underlying transport's datagram. * * \note If this function returns 1 (data pending), this * does not imply that a subsequent call to * \c mbedtls_ssl_read will provide any data; * e.g., the unprocessed data might turn out * to be an alert or a handshake message. * * \note This function is useful in the following situation: * If the SSL/TLS module successfully returns from an * operation - e.g. a handshake or an application record * read - and you're awaiting incoming data next, you * must not immediately idle on the underlying transport * to have data ready, but you need to check the value * of this function first. The reason is that the desired * data might already be read but not yet processed. * If, in contrast, a previous call to the SSL/TLS module * returned MBEDTLS_ERR_SSL_WANT_READ, it is not necessary * to call this function, as the latter error code entails * that all internal data has been processed. * */
size_t mbedtls_ssl_get_bytes_avail( const mbedtls_ssl_context *ssl );
/** * \brief Return the number of application data bytes * remaining to be read from the current record. * * \param ssl SSL context * * \return How many bytes are available in the application * data record read buffer. * * \note When working over a datagram transport, this is * useful to detect the current datagram's boundary * in case \c mbedtls_ssl_read has written the maximal * amount of data fitting into the input buffer. * */
uint32_t mbedtls_ssl_get_verify_result( const mbedtls_ssl_context *ssl );
/** * \brief Return the result of the certificate verification * * \param ssl The SSL context to use. * * \return \c 0 if the certificate verification was successful. * \return \c -1u if the result is not available. This may happen * e.g. if the handshake aborts early, or a verification * callback returned a fatal error. * \return A bitwise combination of \c MBEDTLS_X509_BADCERT_XXX * and \c MBEDTLS_X509_BADCRL_XXX failure flags; see x509.h. */
int mbedtls_ssl_get_record_expansion( const mbedtls_ssl_context *ssl );
/** * \brief Return the (maximum) number of bytes added by the record * layer: header + encryption/MAC overhead (inc. padding) * * \note This function is not available (always returns an error) * when record compression is enabled. * * \param ssl SSL context * * \return Current maximum record expansion in bytes, or * MBEDTLS_ERR_SSL_FEATURE_UNAVAILABLE if compression is * enabled, which makes expansion much less predictable */
size_t mbedtls_ssl_get_max_frag_len( const mbedtls_ssl_context *ssl );
/** * \brief Return the maximum fragment length (payload, in bytes). * This is the value negotiated with peer if any, * or the locally configured value. * * \sa mbedtls_ssl_conf_max_frag_len() * \sa mbedtls_ssl_get_max_record_payload() * * \param ssl SSL context * * \return Current maximum fragment length. */
int mbedtls_ssl_get_max_out_record_payload( const mbedtls_ssl_context *ssl );
/** * \brief Return the current maximum outgoing record payload in bytes. * This takes into account the config.h setting \c * MBEDTLS_SSL_OUT_CONTENT_LEN, the configured and negotiated * max fragment length extension if used, and for DTLS the * path MTU as configured and current record expansion. * * \note With DTLS, \c mbedtls_ssl_write() will return an error if * called with a larger length value. * With TLS, \c mbedtls_ssl_write() will fragment the input if * necessary and return the number of bytes written; it is up * to the caller to call \c mbedtls_ssl_write() again in * order to send the remaining bytes if any. * * \note This function is not available (always returns an error) * when record compression is enabled. * * \sa mbedtls_ssl_set_mtu() * \sa mbedtls_ssl_get_max_frag_len() * \sa mbedtls_ssl_get_record_expansion() * * \param ssl SSL context * * \return Current maximum payload for an outgoing record, * or a negative error code. */
int mbedtls_ssl_get_session( const mbedtls_ssl_context *ssl, mbedtls_ssl_session *session );
/** * \brief Save session in order to resume it later (client-side only) * Session data is copied to presented session structure. * * * \param ssl SSL context * \param session session context * * \return 0 if successful, * MBEDTLS_ERR_SSL_ALLOC_FAILED if memory allocation failed, * MBEDTLS_ERR_SSL_BAD_INPUT_DATA if used server-side or * arguments are otherwise invalid. * * \note Only the server certificate is copied, and not the full chain, * so you should not attempt to validate the certificate again * by calling \c mbedtls_x509_crt_verify() on it. * Instead, you should use the results from the verification * in the original handshake by calling \c mbedtls_ssl_get_verify_result() * after loading the session again into a new SSL context * using \c mbedtls_ssl_set_session(). * * \note Once the session object is not needed anymore, you should * free it by calling \c mbedtls_ssl_session_free(). * * \sa mbedtls_ssl_set_session() */
int mbedtls_ssl_handshake( mbedtls_ssl_context *ssl );
/** * \brief Perform the SSL handshake * * \param ssl SSL context * * \return \c 0 if successful. * \return #MBEDTLS_ERR_SSL_WANT_READ or #MBEDTLS_ERR_SSL_WANT_WRITE * if the handshake is incomplete and waiting for data to * be available for reading from or writing to the underlying * transport - in this case you must call this function again * when the underlying transport is ready for the operation. * \return #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS if an asynchronous * operation is in progress (see * mbedtls_ssl_conf_async_private_cb()) - in this case you * must call this function again when the operation is ready. * \return #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS if a cryptographic * operation is in progress (see mbedtls_ecp_set_max_ops()) - * in this case you must call this function again to complete * the handshake when you're done attending other tasks. * \return #MBEDTLS_ERR_SSL_HELLO_VERIFY_REQUIRED if DTLS is in use * and the client did not demonstrate reachability yet - in * this case you must stop using the context (see below). * \return Another SSL error code - in this case you must stop using * the context (see below). * * \warning If this function returns something other than * \c 0, * #MBEDTLS_ERR_SSL_WANT_READ, * #MBEDTLS_ERR_SSL_WANT_WRITE, * #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS or * #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS, * you must stop using the SSL context for reading or writing, * and either free it or call \c mbedtls_ssl_session_reset() * on it before re-using it for a new connection; the current * connection must be closed. * * \note If DTLS is in use, then you may choose to handle * #MBEDTLS_ERR_SSL_HELLO_VERIFY_REQUIRED specially for logging * purposes, as it is an expected return value rather than an * actual error, but you still need to reset/free the context. * * \note Remarks regarding event-driven DTLS: * If the function returns #MBEDTLS_ERR_SSL_WANT_READ, no datagram * from the underlying transport layer is currently being processed, * and it is safe to idle until the timer or the underlying transport * signal a new event. This is not true for a successful handshake, * in which case the datagram of the underlying transport that is * currently being processed might or might not contain further * DTLS records. */
int mbedtls_ssl_handshake_step( mbedtls_ssl_context *ssl );
/** * \brief Perform a single step of the SSL handshake * * \note The state of the context (ssl->state) will be at * the next state after this function returns \c 0. Do not * call this function if state is MBEDTLS_SSL_HANDSHAKE_OVER. * * \param ssl SSL context * * \return See mbedtls_ssl_handshake(). * * \warning If this function returns something other than \c 0, * #MBEDTLS_ERR_SSL_WANT_READ, #MBEDTLS_ERR_SSL_WANT_WRITE, * #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS or * #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS, you must stop using * the SSL context for reading or writing, and either free it * or call \c mbedtls_ssl_session_reset() on it before * re-using it for a new connection; the current connection * must be closed. */
int mbedtls_ssl_renegotiate( mbedtls_ssl_context *ssl );
/** * \brief Initiate an SSL renegotiation on the running connection. * Client: perform the renegotiation right now. * Server: request renegotiation, which will be performed * during the next call to mbedtls_ssl_read() if honored by * client. * * \param ssl SSL context * * \return 0 if successful, or any mbedtls_ssl_handshake() return * value except #MBEDTLS_ERR_SSL_CLIENT_RECONNECT that can't * happen during a renegotiation. * * \warning If this function returns something other than \c 0, * #MBEDTLS_ERR_SSL_WANT_READ, #MBEDTLS_ERR_SSL_WANT_WRITE, * #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS or * #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS, you must stop using * the SSL context for reading or writing, and either free it * or call \c mbedtls_ssl_session_reset() on it before * re-using it for a new connection; the current connection * must be closed. * */
int mbedtls_ssl_read( mbedtls_ssl_context *ssl, unsigned char *buf, size_t len );
/** * \brief Read at most 'len' application data bytes * * \param ssl SSL context * \param buf buffer that will hold the data * \param len maximum number of bytes to read * * \return The (positive) number of bytes read if successful. * \return \c 0 if the read end of the underlying transport was closed * - in this case you must stop using the context (see below). * \return #MBEDTLS_ERR_SSL_WANT_READ or #MBEDTLS_ERR_SSL_WANT_WRITE * if the handshake is incomplete and waiting for data to * be available for reading from or writing to the underlying * transport - in this case you must call this function again * when the underlying transport is ready for the operation. * \return #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS if an asynchronous * operation is in progress (see * mbedtls_ssl_conf_async_private_cb()) - in this case you * must call this function again when the operation is ready. * \return #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS if a cryptographic * operation is in progress (see mbedtls_ecp_set_max_ops()) - * in this case you must call this function again to complete * the handshake when you're done attending other tasks. * \return #MBEDTLS_ERR_SSL_CLIENT_RECONNECT if we're at the server * side of a DTLS connection and the client is initiating a * new connection using the same source port. See below. * \return Another SSL error code - in this case you must stop using * the context (see below). * * \warning If this function returns something other than * a positive value, * #MBEDTLS_ERR_SSL_WANT_READ, * #MBEDTLS_ERR_SSL_WANT_WRITE, * #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS, * #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS or * #MBEDTLS_ERR_SSL_CLIENT_RECONNECT, * you must stop using the SSL context for reading or writing, * and either free it or call \c mbedtls_ssl_session_reset() * on it before re-using it for a new connection; the current * connection must be closed. * * \note When this function returns #MBEDTLS_ERR_SSL_CLIENT_RECONNECT * (which can only happen server-side), it means that a client * is initiating a new connection using the same source port. * You can either treat that as a connection close and wait * for the client to resend a ClientHello, or directly * continue with \c mbedtls_ssl_handshake() with the same * context (as it has been reset internally). Either way, you * must make sure this is seen by the application as a new * connection: application state, if any, should be reset, and * most importantly the identity of the client must be checked * again. WARNING: not validating the identity of the client * again, or not transmitting the new identity to the * application layer, would allow authentication bypass! * * \note Remarks regarding event-driven DTLS: * - If the function returns #MBEDTLS_ERR_SSL_WANT_READ, no datagram * from the underlying transport layer is currently being processed, * and it is safe to idle until the timer or the underlying transport * signal a new event. * - This function may return MBEDTLS_ERR_SSL_WANT_READ even if data was * initially available on the underlying transport, as this data may have * been only e.g. duplicated messages or a renegotiation request. * Therefore, you must be prepared to receive MBEDTLS_ERR_SSL_WANT_READ even * when reacting to an incoming-data event from the underlying transport. * - On success, the datagram of the underlying transport that is currently * being processed may contain further DTLS records. You should call * \c mbedtls_ssl_check_pending to check for remaining records. * */
int mbedtls_ssl_write( mbedtls_ssl_context *ssl, const unsigned char *buf, size_t len );
/** * \brief Try to write exactly 'len' application data bytes * * \warning This function will do partial writes in some cases. If the * return value is non-negative but less than length, the * function must be called again with updated arguments: * buf + ret, len - ret (if ret is the return value) until * it returns a value equal to the last 'len' argument. * * \param ssl SSL context * \param buf buffer holding the data * \param len how many bytes must be written * * \return The (non-negative) number of bytes actually written if * successful (may be less than \p len). * \return #MBEDTLS_ERR_SSL_WANT_READ or #MBEDTLS_ERR_SSL_WANT_WRITE * if the handshake is incomplete and waiting for data to * be available for reading from or writing to the underlying * transport - in this case you must call this function again * when the underlying transport is ready for the operation. * \return #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS if an asynchronous * operation is in progress (see * mbedtls_ssl_conf_async_private_cb()) - in this case you * must call this function again when the operation is ready. * \return #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS if a cryptographic * operation is in progress (see mbedtls_ecp_set_max_ops()) - * in this case you must call this function again to complete * the handshake when you're done attending other tasks. * \return Another SSL error code - in this case you must stop using * the context (see below). * * \warning If this function returns something other than * a non-negative value, * #MBEDTLS_ERR_SSL_WANT_READ, * #MBEDTLS_ERR_SSL_WANT_WRITE, * #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS or * #MBEDTLS_ERR_SSL_CRYPTO_IN_PROGRESS, * you must stop using the SSL context for reading or writing, * and either free it or call \c mbedtls_ssl_session_reset() * on it before re-using it for a new connection; the current * connection must be closed. * * \note When this function returns #MBEDTLS_ERR_SSL_WANT_WRITE/READ, * it must be called later with the *same* arguments, * until it returns a value greater that or equal to 0. When * the function returns #MBEDTLS_ERR_SSL_WANT_WRITE there may be * some partial data in the output buffer, however this is not * yet sent. * * \note If the requested length is greater than the maximum * fragment length (either the built-in limit or the one set * or negotiated with the peer), then: * - with TLS, less bytes than requested are written. * - with DTLS, MBEDTLS_ERR_SSL_BAD_INPUT_DATA is returned. * \c mbedtls_ssl_get_max_frag_len() may be used to query the * active maximum fragment length. * * \note Attempting to write 0 bytes will result in an empty TLS * application record being sent. */
int mbedtls_ssl_send_alert_message( mbedtls_ssl_context *ssl,
unsigned char level,
unsigned char message );
/** * \brief Send an alert message * * \param ssl SSL context * \param level The alert level of the message * (MBEDTLS_SSL_ALERT_LEVEL_WARNING or MBEDTLS_SSL_ALERT_LEVEL_FATAL) * \param message The alert message (SSL_ALERT_MSG_*) * * \return 0 if successful, or a specific SSL error code. * * \note If this function returns something other than 0 or * MBEDTLS_ERR_SSL_WANT_READ/WRITE, you must stop using * the SSL context for reading or writing, and either free it or * call \c mbedtls_ssl_session_reset() on it before re-using it * for a new connection; the current connection must be closed. */
int mbedtls_ssl_close_notify( mbedtls_ssl_context *ssl );
/** * \brief Notify the peer that the connection is being closed * * \param ssl SSL context * * \return 0 if successful, or a specific SSL error code. * * \note If this function returns something other than 0 or * MBEDTLS_ERR_SSL_WANT_READ/WRITE, you must stop using * the SSL context for reading or writing, and either free it or * call \c mbedtls_ssl_session_reset() on it before re-using it * for a new connection; the current connection must be closed. */
void mbedtls_ssl_free( mbedtls_ssl_context *ssl );
/** * \brief Free referenced items in an SSL context and clear memory * * \param ssl SSL context */
void mbedtls_ssl_free_session_negotiate_peer_cert( mbedtls_ssl_context *ssl );
void mbedtls_ssl_config_init( mbedtls_ssl_config *conf );
/** * \brief Initialize an SSL configuration context * Just makes the context ready for * mbedtls_ssl_config_defaults() or mbedtls_ssl_config_free(). * * \note You need to call mbedtls_ssl_config_defaults() unless you * manually set all of the relevent fields yourself. * * \param conf SSL configuration context */
int mbedtls_ssl_config_defaults( mbedtls_ssl_config *conf,
int endpoint, int transport, int preset );
/** * \brief Load reasonnable default SSL configuration values. * (You need to call mbedtls_ssl_config_init() first.) * * \param conf SSL configuration context * \param endpoint MBEDTLS_SSL_IS_CLIENT or MBEDTLS_SSL_IS_SERVER * \param transport MBEDTLS_SSL_TRANSPORT_STREAM for TLS, or * MBEDTLS_SSL_TRANSPORT_DATAGRAM for DTLS * \param preset a MBEDTLS_SSL_PRESET_XXX value * * \note See \c mbedtls_ssl_conf_transport() for notes on DTLS. * * \return 0 if successful, or * MBEDTLS_ERR_XXX_ALLOC_FAILED on memory allocation error. */
void mbedtls_ssl_config_free( mbedtls_ssl_config *conf );
/** * \brief Free an SSL configuration context * * \param conf SSL configuration context */
void mbedtls_ssl_session_init( mbedtls_ssl_session *session );
/** * \brief Initialize SSL session structure * * \param session SSL session */
void mbedtls_ssl_session_free( mbedtls_ssl_session *session );
/** * \brief Free referenced items in an SSL session including the * peer certificate and clear memory * * \note A session object can be freed even if the SSL context * that was used to retrieve the session is still in use. * * \param session SSL session */
void mbedtls_ssl_session_free_peer_cert( mbedtls_ssl_session *session );
MBEDTLS_DEPRECATED int mbedtls_ssl_conf_dh_param( mbedtls_ssl_config *conf,
const char *dhm_P,
const char *dhm_G );
/** * \brief Set the Diffie-Hellman public P and G values, * read as hexadecimal strings (server-side only) * (Default values: MBEDTLS_DHM_RFC3526_MODP_2048_[PG]) * * \param conf SSL configuration * \param dhm_P Diffie-Hellman-Merkle modulus * \param dhm_G Diffie-Hellman-Merkle generator * * \deprecated Superseded by \c mbedtls_ssl_conf_dh_param_bin. * * \return 0 if successful */
mbedtls_ssl_srtp_profile mbedtls_ssl_get_dtls_srtp_protection_profile( const mbedtls_ssl_context *ssl );
/** * \brief Get the negotiated DTLS-SRTP Protection Profile. * This function should be called after the handshake is * completed. * * \param ssl SSL context * * \return Protection Profile enum member, * MBEDTLS_SRTP_UNSET_PROFILE if no protocol was negotiated. */
const unsigned char *key_enc, const unsigned char *key_dec,
size_t keylen,
const unsigned char *iv_enc, const unsigned char *iv_dec,
size_t ivlen,
const unsigned char *mac_enc, const unsigned char *mac_dec,
size_t maclen);
const char *mbedtls_ssl_get_ciphersuite_name( const int ciphersuite_id );
/** * \brief Return the name of the ciphersuite associated with the * given ID * * \param ciphersuite_id SSL ciphersuite ID * * \return a string containing the ciphersuite name */
const char *mbedtls_ssl_get_alpn_protocol( const mbedtls_ssl_context *ssl );
/** * \brief Get the name of the negotiated Application Layer Protocol. * This function should be called after the handshake is * completed. * * \param ssl SSL context * * \return Protcol name, or NULL if no protocol was negotiated. */
const mbedtls_ssl_srtp_profile_info *mbedtls_ssl_dtls_srtp_profile_info_from_id( mbedtls_ssl_srtp_profile profile );
/** * \brief Utility function to get information on dtls srtp profile. * * \param profile The dtls-srtp profile id to get info on. * * \return mbedtls_ssl_srtp_profile_info* on success, NULL if not found */
const char *mbedtls_ssl_get_ciphersuite( const mbedtls_ssl_context *ssl );
/** * \brief Return the name of the current ciphersuite * * \param ssl SSL context * * \return a string containing the ciphersuite name */
const char *mbedtls_ssl_get_version( const mbedtls_ssl_context *ssl );
/** * \brief Return the current SSL version (SSLv3/TLSv1/etc) * * \param ssl SSL context * * \return a string containing the SSL version */
const mbedtls_x509_crt *mbedtls_ssl_get_peer_cert( const mbedtls_ssl_context *ssl );
/** * \brief Return the peer certificate from the current connection * * Note: Can be NULL in case no certificate was sent during * the handshake. Different calls for the same connection can * return the same or different pointers for the same * certificate and even a different certificate altogether. * The peer cert CAN change in a single connection if * renegotiation is performed. * * \param ssl SSL context * * \return the current peer certificate */
typedef enum
MBEDTLS_SSL_HELLO_REQUEST,
MBEDTLS_SSL_CLIENT_HELLO,
MBEDTLS_SSL_SERVER_HELLO,
MBEDTLS_SSL_SERVER_CERTIFICATE,
MBEDTLS_SSL_SERVER_KEY_EXCHANGE,
MBEDTLS_SSL_CERTIFICATE_REQUEST,
MBEDTLS_SSL_SERVER_HELLO_DONE,
MBEDTLS_SSL_CLIENT_CERTIFICATE,
MBEDTLS_SSL_CLIENT_KEY_EXCHANGE,
MBEDTLS_SSL_CERTIFICATE_VERIFY,
MBEDTLS_SSL_CLIENT_CHANGE_CIPHER_SPEC,
MBEDTLS_SSL_CLIENT_FINISHED,
MBEDTLS_SSL_SERVER_CHANGE_CIPHER_SPEC,
MBEDTLS_SSL_SERVER_FINISHED,
MBEDTLS_SSL_FLUSH_BUFFERS,
MBEDTLS_SSL_HANDSHAKE_WRAPUP,
MBEDTLS_SSL_HANDSHAKE_OVER,
MBEDTLS_SSL_SERVER_NEW_SESSION_TICKET,
MBEDTLS_SSL_SERVER_HELLO_VERIFY_REQUEST_SENT,
mbedtls_ssl_states;
/* * SSL state machine */
typedef int mbedtls_ssl_send_t( void *ctx,
size_t len );
/** * \brief Callback type: send data on the network. * * \note That callback may be either blocking or non-blocking. * * \param ctx Context for the send callback (typically a file descriptor) * \param buf Buffer holding the data to send * \param len Length of the data to send * * \return The callback must return the number of bytes sent if any, * or a non-zero error code. * If performing non-blocking I/O, \c MBEDTLS_ERR_SSL_WANT_WRITE * must be returned when the operation would block. * * \note The callback is allowed to send fewer bytes than requested. * It must always return the number of bytes actually sent. */
typedef int mbedtls_ssl_recv_t( void *ctx,
unsigned char *buf,
size_t len );
/** * \brief Callback type: receive data from the network. * * \note That callback may be either blocking or non-blocking. * * \param ctx Context for the receive callback (typically a file * descriptor) * \param buf Buffer to write the received data to * \param len Length of the receive buffer * * \return The callback must return the number of bytes received, * or a non-zero error code. * If performing non-blocking I/O, \c MBEDTLS_ERR_SSL_WANT_READ * must be returned when the operation would block. * * \note The callback may receive fewer bytes than the length of the * buffer. It must always return the number of bytes actually * received and written to the buffer. */
typedef int mbedtls_ssl_recv_timeout_t( void *ctx,
unsigned char *buf,
size_t len,
uint32_t timeout );
/** * \brief Callback type: receive data from the network, with timeout * * \note That callback must block until data is received, or the * timeout delay expires, or the operation is interrupted by a * signal. * * \param ctx Context for the receive callback (typically a file descriptor) * \param buf Buffer to write the received data to * \param len Length of the receive buffer * \param timeout Maximum nomber of millisecondes to wait for data * 0 means no timeout (potentially waiting forever) * * \return The callback must return the number of bytes received, * or a non-zero error code: * \c MBEDTLS_ERR_SSL_TIMEOUT if the operation timed out, * \c MBEDTLS_ERR_SSL_WANT_READ if interrupted by a signal. * * \note The callback may receive fewer bytes than the length of the * buffer. It must always return the number of bytes actually * received and written to the buffer. */
typedef void mbedtls_ssl_set_timer_t( void * ctx,
uint32_t int_ms,
uint32_t fin_ms );
/** * \brief Callback type: set a pair of timers/delays to watch * * \param ctx Context pointer * \param int_ms Intermediate delay in milliseconds * \param fin_ms Final delay in milliseconds * 0 cancels the current timer. * * \note This callback must at least store the necessary information * for the associated \c mbedtls_ssl_get_timer_t callback to * return correct information. * * \note If using a event-driven style of programming, an event must * be generated when the final delay is passed. The event must * cause a call to \c mbedtls_ssl_handshake() with the proper * SSL context to be scheduled. Care must be taken to ensure * that at most one such call happens at a time. * * \note Only one timer at a time must be running. Calling this * function while a timer is running must cancel it. Cancelled * timers must not generate any event. */
typedef int mbedtls_ssl_get_timer_t( void * ctx );
/** * \brief Callback type: get status of timers/delays * * \param ctx Context pointer * * \return This callback must return: * -1 if cancelled (fin_ms == 0), * 0 if none of the delays have passed, * 1 if only the intermediate delay has passed, * 2 if the final delay has passed. */
typedef struct mbedtls_ssl_session mbedtls_ssl_session;
/* Defined below */
typedef struct mbedtls_ssl_context mbedtls_ssl_context;
typedef struct mbedtls_ssl_config mbedtls_ssl_config;
typedef struct mbedtls_ssl_transform mbedtls_ssl_transform;
/* Defined in ssl_internal.h */
typedef struct mbedtls_ssl_handshake_params mbedtls_ssl_handshake_params;
typedef struct mbedtls_ssl_sig_hash_set_t mbedtls_ssl_sig_hash_set_t;
#if defined(MBEDTLS_X509_CRT_PARSE_C)
typedef struct mbedtls_ssl_key_cert mbedtls_ssl_key_cert;
typedef struct mbedtls_ssl_flight_item mbedtls_ssl_flight_item;
typedef int mbedtls_ssl_async_sign_t( mbedtls_ssl_context *ssl,
mbedtls_x509_crt *cert,
mbedtls_md_type_t md_alg,
const unsigned char *hash,
size_t hash_len );
/** * \brief Callback type: start fal signature operation. * * This callback is called during an SSL handshake to start * a signature decryption operation using an * external processor. The parameter \p cert contains * the public key; it is up to the callback function to * determine how to access the associated private key. * * This function typically sends or enqueues a request, and * does not wait for the operation to complete. This allows * the handshake step to be non-blocking. * * The parameters \p ssl and \p cert are guaranteed to remain * valid throughout the handshake. On the other hand, this * function must save the contents of \p hash if the value * is needed for later processing, because the \p hash buffer * is no longer valid after this function returns. * * This function may call mbedtls_ssl_set_async_operation_data() * to store an operation context for later retrieval * by the resume or cancel callback. * * \note For RSA signatures, this function must produce output * that is consistent with PKCS#1 v1.5 in the same way as * mbedtls_rsa_pkcs1_sign(). Before the private key operation, * apply the padding steps described in RFC 8017, section 9.2 * "EMSA-PKCS1-v1_5" as follows. * - If \p md_alg is #MBEDTLS_MD_NONE, apply the PKCS#1 v1.5 * encoding, treating \p hash as the DigestInfo to be * padded. In other words, apply EMSA-PKCS1-v1_5 starting * from step 3, with `T = hash` and `tLen = hash_len`. * - If `md_alg != MBEDTLS_MD_NONE`, apply the PKCS#1 v1.5 * encoding, treating \p hash as the hash to be encoded and * padded. In other words, apply EMSA-PKCS1-v1_5 starting * from step 2, with `digestAlgorithm` obtained by calling * mbedtls_oid_get_oid_by_md() on \p md_alg. * * \note For ECDSA signatures, the output format is the DER encoding * `Ecdsa-Sig-Value` defined in * [RFC 4492 section 5.4](https://tools.ietf.org/html/rfc4492#section-5.4). * * \param ssl The SSL connection instance. It should not be * modified other than via * mbedtls_ssl_set_async_operation_data(). * \param cert Certificate containing the public key. * In simple cases, this is one of the pointers passed to * mbedtls_ssl_conf_own_cert() when configuring the SSL * connection. However, if other callbacks are used, this * property may not hold. For example, if an SNI callback * is registered with mbedtls_ssl_conf_sni(), then * this callback determines what certificate is used. * \param md_alg Hash algorithm. * \param hash Buffer containing the hash. This buffer is * no longer valid when the function returns. * \param hash_len Size of the \c hash buffer in bytes. * * \return 0 if the operation was started successfully and the SSL * stack should call the resume callback immediately. * \return #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS if the operation * was started successfully and the SSL stack should return * immediately without calling the resume callback yet. * \return #MBEDTLS_ERR_SSL_HW_ACCEL_FALLTHROUGH if the external * processor does not support this key. The SSL stack will * use the private key object instead. * \return Any other error indicates a fatal failure and is * propagated up the call chain. The callback should * use \c MBEDTLS_ERR_PK_xxx error codes, and must not * use \c MBEDTLS_ERR_SSL_xxx error codes except as * directed in the documentation of this callback. */
typedef int mbedtls_ssl_async_decrypt_t( mbedtls_ssl_context *ssl,
const unsigned char *input,
size_t input_len );
/** * \brief Callback type: start external decryption operation. * * This callback is called during an SSL handshake to start * an RSA decryption operation using an * external processor. The parameter \p cert contains * the public key; it is up to the callback function to * determine how to access the associated private key. * * This function typically sends or enqueues a request, and * does not wait for the operation to complete. This allows * the handshake step to be non-blocking. * * The parameters \p ssl and \p cert are guaranteed to remain * valid throughout the handshake. On the other hand, this * function must save the contents of \p input if the value * is needed for later processing, because the \p input buffer * is no longer valid after this function returns. * * This function may call mbedtls_ssl_set_async_operation_data() * to store an operation context for later retrieval * by the resume or cancel callback. * * \warning RSA decryption as used in TLS is subject to a potential * timing side channel attack first discovered by Bleichenbacher * in 1998. This attack can be remotely exploitable * in practice. To avoid this attack, you must ensure that * if the callback performs an RSA decryption, the time it * takes to execute and return the result does not depend * on whether the RSA decryption succeeded or reported * invalid padding. * * \param ssl The SSL connection instance. It should not be * modified other than via * mbedtls_ssl_set_async_operation_data(). * \param cert Certificate containing the public key. * In simple cases, this is one of the pointers passed to * mbedtls_ssl_conf_own_cert() when configuring the SSL * connection. However, if other callbacks are used, this * property may not hold. For example, if an SNI callback * is registered with mbedtls_ssl_conf_sni(), then * this callback determines what certificate is used. * \param input Buffer containing the input ciphertext. This buffer * is no longer valid when the function returns. * \param input_len Size of the \p input buffer in bytes. * * \return 0 if the operation was started successfully and the SSL * stack should call the resume callback immediately. * \return #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS if the operation * was started successfully and the SSL stack should return * immediately without calling the resume callback yet. * \return #MBEDTLS_ERR_SSL_HW_ACCEL_FALLTHROUGH if the external * processor does not support this key. The SSL stack will * use the private key object instead. * \return Any other error indicates a fatal failure and is * propagated up the call chain. The callback should * use \c MBEDTLS_ERR_PK_xxx error codes, and must not * use \c MBEDTLS_ERR_SSL_xxx error codes except as * directed in the documentation of this callback. */
typedef int mbedtls_ssl_async_resume_t( mbedtls_ssl_context *ssl,
unsigned char *output,
size_t *output_len,
size_t output_size );
/** * \brief Callback type: resume external operation. * * This callback is called during an SSL handshake to resume * an external operation started by the * ::mbedtls_ssl_async_sign_t or * ::mbedtls_ssl_async_decrypt_t callback. * * This function typically checks the status of a pending * request or causes the request queue to make progress, and * does not wait for the operation to complete. This allows * the handshake step to be non-blocking. * * This function may call mbedtls_ssl_get_async_operation_data() * to retrieve an operation context set by the start callback. * It may call mbedtls_ssl_set_async_operation_data() to modify * this context. * * Note that when this function returns a status other than * #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS, it must free any * resources associated with the operation. * * \param ssl The SSL connection instance. It should not be * modified other than via * mbedtls_ssl_set_async_operation_data(). * \param output Buffer containing the output (signature or decrypted * data) on success. * \param output_len On success, number of bytes written to \p output. * \param output_size Size of the \p output buffer in bytes. * * \return 0 if output of the operation is available in the * \p output buffer. * \return #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS if the operation * is still in progress. Subsequent requests for progress * on the SSL connection will call the resume callback * again. * \return Any other error means that the operation is aborted. * The SSL handshake is aborted. The callback should * use \c MBEDTLS_ERR_PK_xxx error codes, and must not * use \c MBEDTLS_ERR_SSL_xxx error codes except as * directed in the documentation of this callback. */
typedef void mbedtls_ssl_async_cancel_t( mbedtls_ssl_context *ssl );
/** * \brief Callback type: cancel external operation. * * This callback is called if an SSL connection is closed * while an asynchronous operation is in progress. Note that * this callback is not called if the * ::mbedtls_ssl_async_resume_t callback has run and has * returned a value other than * #MBEDTLS_ERR_SSL_ASYNC_IN_PROGRESS, since in that case * the asynchronous operation has already completed. * * This function may call mbedtls_ssl_get_async_operation_data() * to retrieve an operation context set by the start callback. * * \param ssl The SSL connection instance. It should not be * modified. */
typedef enum
MBEDTLS_SRTP_UNSET_PROFILE,
MBEDTLS_SRTP_AES128_CM_HMAC_SHA1_80,
MBEDTLS_SRTP_AES128_CM_HMAC_SHA1_32,
MBEDTLS_SRTP_NULL_HMAC_SHA1_80,
MBEDTLS_SRTP_NULL_HMAC_SHA1_32,
mbedtls_ssl_srtp_profile;
/* * List of SRTP profiles for DTLS-SRTP */
typedef struct
const mbedtls_ssl_srtp_profile profile;
const char *name;
mbedtls_ssl_srtp_profile_info;
typedef struct mbedtls_dtls_srtp_info_t
mbedtls_ssl_srtp_profile chosen_dtls_srtp_profile; /*!< negotiated SRTP profile */
unsigned char dtls_srtp_keys[MBEDTLS_DTLS_SRTP_MAX_KEY_MATERIAL_LENGTH]; /*!< master keys and master salt for SRTP generated during handshake */
size_t dtls_srtp_keys_len; /*!< length in bytes of master keys and master salt for SRTP generated during handshake */
unsigned char mki_value[MBEDTLS_DTLS_SRTP_MAX_MKI_LENGTH]; /* opaque srtp_mki<0..255> */
size_t mki_len;
mbedtls_dtls_srtp_info;
typedef void (*psk_func_cb)(void *ctx);
typedef int mbedtls_ssl_ticket_write_t( void *p_ticket,
const mbedtls_ssl_session *session,
unsigned char *start,
const unsigned char *end,
size_t *tlen,
uint32_t *lifetime );
/** * \brief Callback type: generate and write session ticket * * \note This describes what a callback implementation should do. * This callback should generate an encrypted and * authenticated ticket for the session and write it to the * output buffer. Here, ticket means the opaque ticket part * of the NewSessionTicket structure of RFC 5077. * * \param p_ticket Context for the callback * \param session SSL session to be written in the ticket * \param start Start of the output buffer * \param end End of the output buffer * \param tlen On exit, holds the length written * \param lifetime On exit, holds the lifetime of the ticket in seconds * * \return 0 if successful, or * a specific MBEDTLS_ERR_XXX code. */
typedef int mbedtls_ssl_export_keys_t( void *p_expkey,
const unsigned char *ms,
const unsigned char *kb,
size_t maclen,
size_t keylen,
size_t ivlen );
/** * \brief Callback type: Export key block and master secret * * \note This is required for certain uses of TLS, e.g. EAP-TLS * (RFC 5216) and Thread. The key pointers are ephemeral and * therefore must not be stored. The master secret and keys * should not be used directly except as an input to a key * derivation function. * * \param p_expkey Context for the callback * \param ms Pointer to master secret (fixed length: 48 bytes) * \param kb Pointer to key block, see RFC 5246 section 6.3 * (variable length: 2 * maclen + 2 * keylen + 2 * ivlen). * \param maclen MAC length * \param keylen Key length * \param ivlen IV length * * \return 0 if successful, or * a specific MBEDTLS_ERR_XXX code. */
typedef int mbedtls_ssl_ticket_parse_t( void *p_ticket,
unsigned char *buf,
size_t len );
/** * \brief Callback type: parse and load session ticket * * \note This describes what a callback implementation should do. * This callback should parse a session ticket as generated * by the corresponding mbedtls_ssl_ticket_write_t function, * and, if the ticket is authentic and valid, load the * session. * * \note The implementation is allowed to modify the first len * bytes of the input buffer, eg to use it as a temporary * area for the decrypted ticket contents. * * \param p_ticket Context for the callback * \param session SSL session to be loaded * \param buf Start of the buffer containing the ticket * \param len Length of the ticket. * * \return 0 if successful, or * MBEDTLS_ERR_SSL_INVALID_MAC if not authentic, or * MBEDTLS_ERR_SSL_SESSION_TICKET_EXPIRED if expired, or * any other non-zero code for other failures. */
typedef int mbedtls_ssl_cookie_write_t( void *ctx,
unsigned char **p, unsigned char *end,
const unsigned char *info, size_t ilen );
/** * \brief Callback type: generate a cookie * * \param ctx Context for the callback * \param p Buffer to write to, * must be updated to point right after the cookie * \param end Pointer to one past the end of the output buffer * \param info Client ID info that was passed to * \c mbedtls_ssl_set_client_transport_id() * \param ilen Length of info in bytes * * \return The callback must return 0 on success, * or a negative error code. */
typedef int mbedtls_ssl_cookie_check_t( void *ctx,
const unsigned char *cookie, size_t clen,
/** * \brief Callback type: verify a cookie * * \param ctx Context for the callback * \param cookie Cookie to verify * \param clen Length of cookie * \param info Client ID info that was passed to * \c mbedtls_ssl_set_client_transport_id() * \param ilen Length of info in bytes * * \return The callback must return 0 if cookie is valid, * or a negative error code. */
