#include "tuya_iot_config.h"
#define MBEDTLS_CONFIG_H_TY_ECC_ONLY
#define TUYA_ECP_MUL_COMB_ROM_TABLES 1 //使用ROM代替RAM
//#define TUYA_ECP_MUL_COMB_OPTIM 1 //打开ECP点乘优化
#define MBEDTLS_DEPRECATED_REMOVED
/** * \def MBEDTLS_DEPRECATED_REMOVED * * Remove deprecated functions so that they generate an error if used. * Functions deprecated in one version will usually be removed in the next * version. You can enable this to help you prepare the transition to a new * major version by making sure your code is not using these functions. * * Uncomment to get errors on using deprecated functions. */
//#define MBEDTLS_ECP_DP_SECP224R1_ENABLED
#define MBEDTLS_PKCS1_V15
#define MBEDTLS_PKCS1_V21
#define MBEDTLS_THREADING_PTHREAD
#define MBEDTLS_AES_C
/** * \def MBEDTLS_AES_C * * Enable the AES block cipher. * * Module: library/aes.c * Caller: library/cipher.c * library/pem.c * library/ctr_drbg.c * * This module enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * * PEM_PARSE uses AES for decrypting encrypted keys. */
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_BASE64_C
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CCM_C
/** * \def MBEDTLS_CCM_C * * Enable the Counter with CBC-MAC (CCM) mode for 128-bit block cipher. * * Module: library/ccm.c * * Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C * * This module enables the AES-CCM ciphersuites, if other requisites are * enabled as well. */
#define MBEDTLS_CIPHER_C
#define MBEDTLS_ECDH_C
#define MBEDTLS_ECP_C
#define MBEDTLS_GCM_C
/** * \def MBEDTLS_GCM_C * * Enable the Galois/Counter Mode (GCM) for AES. * * Module: library/gcm.c * * Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C * * This module enables the AES-GCM and CAMELLIA-GCM ciphersuites, if other * requisites are enabled as well. */
#define MBEDTLS_MD_C
#define MBEDTLS_MD5_C
#define MBEDTLS_NET_C
/** * \def MBEDTLS_NET_C * * Enable the TCP and UDP over IPv6/IPv4 networking routines. * * \note This module only works on POSIX/Unix (including Linux, BSD and OS X) * and Windows. For other platforms, you'll want to disable it, and write your * own networking callbacks to be passed to \c mbedtls_ssl_set_bio(). * * \note See also our Knowledge Base article about porting to a new * environment: * https://tls.mbed.org/kb/how-to/how-do-i-port-mbed-tls-to-a-new-environment-OS * * Module: library/net_sockets.c * * This module provides networking routines. */
#define MBEDTLS_OID_C
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_PKCS5_C
#define MBEDTLS_PKCS12_C
#define MBEDTLS_PLATFORM_C
#define MBEDTLS_RSA_C
#define MBEDTLS_SHA1_C
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_THREADING_C
#define MBEDTLS_VERSION_C
#define MBEDTLS_X509_USE_C
#define MBEDTLS_MPI_WINDOW_SIZE 1 /**< Maximum windows size used. */
/* MPI / BIGNUM options */
#define MBEDTLS_MPI_MAX_SIZE 1024 /**< Maximum number of bytes for usable MPIs. */
#define MBEDTLS_ECP_MAX_BITS 256 /**< Maximum bit size of groups */
/* ECP options */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 1024 /**< Maxium fragment length in bytes, determines the size of each of the two internal I/O buffers */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384
