#include "coap_net.h"
#define COAP_ASYNC_H_
#define COAP_ASYNC_CONFIRM 1 /**< send confirmable response */
/* Definitions for Async Status Flags These flags can be used to control the * behaviour of asynchronous response generation. */
#define COAP_ASYNC_SEPARATE 2 /**< send separate response */
#define COAP_ASYNC_OBSERVED 4 /**< the resource is being observed */
#define COAP_ASYNC_RELEASE_DATA 8
/** release application data on destruction */
int coap_remove_async(coap_context_t *context,
coap_session_t *session,
coap_tid_t id,
coap_async_state_t **s);
/** * Removes the state object identified by @p id from @p context. The removed * object is returned in @p s, if found. Otherwise, @p s is undefined. This * function returns @c 1 if the object was removed, @c 0 otherwise. Note that * the storage allocated for the stored object is not released by this * functions. You will have to call coap_free_async() to do so. * * @param context The context where the async object is registered. * @param session The session that is used for asynchronous transmissions. * @param id The identifier of the asynchronous transaction. * @param s Will be set to the object identified by @p id after removal. * * @return @c 1 if object was removed and @p s updated, or @c 0 if no * object was found with the given id. @p s is valid only if the * return value is @c 1. */
void
coap_free_async(coap_async_state_t *state);
/** * Releases the memory that was allocated by coap_async_state_init() for the * object @p s. The registered application data will be released automatically * if COAP_ASYNC_RELEASE_DATA is set. * * @param state The object to delete. */
coap_register_async(coap_context_t *context,
coap_pdu_t *request,
unsigned char flags,
void *data);
/** * Allocates a new coap_async_state_t object and fills its fields according to * the given @p request. The @p flags are used to control generation of empty * ACK responses to stop retransmissions and to release registered @p data when * the resource is deleted by coap_free_async(). This function returns a pointer * to the registered coap_async_t object or @c NULL on error. Note that this * function will return @c NULL in case that an object with the same identifier * is already registered. * * @param context The context to use. * @param session The session that is used for asynchronous transmissions. * @param request The request that is handled asynchronously. * @param flags Flags to control state management. * @param data Opaque application data to register. Note that the * storage occupied by @p data is released on destruction * only if flag COAP_ASYNC_RELEASE_DATA is set. * * @return A pointer to the registered coap_async_state_t object or @c * NULL in case of an error. */
coap_async_state_t *coap_find_async(coap_context_t *context, coap_session_t *session, coap_tid_t id);
/** * Retrieves the object identified by @p id from the list of asynchronous * transactions that are registered with @p context. This function returns a * pointer to that object or @c NULL if not found. * * @param context The context where the asynchronous objects are registered * with. * @param session The session that is used for asynchronous transmissions. * @param id The id of the object to retrieve. * * @return A pointer to the object identified by @p id or @c NULL if * not found. */
typedef struct coap_async_state_t {
unsigned char flags; /**< holds the flags to control behaviour */
* Holds the internal time when the object was registered with a
* resource. This field will be updated whenever
* coap_register_async() is called for a specific resource.
coap_tick_t created;
* This field can be used to register opaque application data with the
* asynchronous state object.
void *appdata;
uint16_t message_id; /**< id of last message seen */
coap_session_t *session; /**< transaction session */
coap_tid_t id; /**< transaction id */
struct coap_async_state_t *next; /**< internally used for linking */
size_t tokenlen; /**< length of the token */
uint8_t token[8]; /**< the token to use in a response */
} coap_async_state_t;
* @defgroup coap_async Asynchronous Messaging
* Structure for managing asynchronous state of CoAP resources. A
* coap_resource_t object holds a list of coap_async_state_t objects that can be
* used to generate a separate response in case a result of an operation cannot
* be delivered in time, or the resource has been explicitly subscribed to with
* the option @c observe.
