#include <stdint.h>
#include
#include "str.h"
#include "str.h"
#define COAP_URI_H_
#define COAP_URI_SCHEME_SECURE_MASK 1
/** This mask can be used to check if a parsed URI scheme is secure. */
int coap_split_uri(const uint8_t *str_var, size_t len, coap_uri_t *uri);
* Parses a given string into URI components. The identified syntactic
* components are stored in the result parameter @p uri. Optional URI
* components that are not specified will be set to { 0, 0 }, except for the
* port which is set to @c COAP_DEFAULT_PORT. This function returns @p 0 if
* parsing succeeded, a value less than zero otherwise.
* @param str_var The string to split up.
* @param len The actual length of @p str_var
* @param uri The coap_uri_t object to store the result.
* @return @c 0 on success, or < 0 on error.
int coap_split_path(const uint8_t *s,
size_t length,
unsigned char *buf,
size_t *buflen);
/** * Splits the given URI path into segments. Each segment is preceded * by an option pseudo-header with delta-value 0 and the actual length * of the respective segment after percent-decoding. * * @param s The path string to split. * @param length The actual length of @p s. * @param buf Result buffer for parsed segments. * @param buflen Maximum length of @p buf. Will be set to the actual number * of bytes written into buf on success. * * @return The number of segments created or @c -1 on error. */
int coap_split_query(const uint8_t *s,
size_t length,
unsigned char *buf,
size_t *buflen);
/** * Splits the given URI query into segments. Each segment is preceded * by an option pseudo-header with delta-value 0 and the actual length * of the respective query term. * * @param s The query string to split. * @param length The actual length of @p s. * @param buf Result buffer for parsed segments. * @param buflen Maximum length of @p buf. Will be set to the actual number * of bytes written into buf on success. * * @return The number of segments created or @c -1 on error. * * @bug This function does not reserve additional space for delta > 12. */
struct coap_pdu_t;
coap_uri_t *coap_new_uri(const uint8_t *uri, unsigned int length);
/** * Creates a new coap_uri_t object from the specified URI. Returns the new * object or NULL on error. The memory allocated by the new coap_uri_t * must be released using coap_free(). * * @param uri The URI path to copy. * @param length The length of uri. * * @return New URI object or NULL on error. */
coap_uri_t *coap_clone_uri(const coap_uri_t *uri);
/** * Clones the specified coap_uri_t object. Thie function allocates sufficient * memory to hold the coap_uri_t structure and its contents. The object must * be released with coap_free(). */
coap_string_t *coap_get_query(const struct coap_pdu_t *request);
/** * Extract query string from request PDU according to escape rules in 6.5.8. * @param request Request PDU. * @return Reconstructed and escaped query string part. */
coap_string_t *coap_get_uri_path(const struct coap_pdu_t *request);
/** * Extract uri_path string from request PDU * @param request Request PDU. * @return Reconstructed and escaped uri path string part. */
coap_str_const_t host; /**< host part of the URI */
uint16_t port; /**< The port in host byte order */
coap_str_const_t path; /**< Beginning of the first path segment.
Use coap_split_path() to create Uri-Path options */
coap_str_const_t query; /**< The query part if present */
/** The parsed scheme specifier. */
enum coap_uri_scheme_t scheme;
} coap_uri_t;
/** * Representation of parsed URI. Components may be filled from a string with * coap_split_uri() and can be used as input for option-creation functions. */
