#include "config.h"
#include "config.h"
#include MBEDTLS_CONFIG_FILE
#include "md.h"
#include "md.h"
#define MBEDTLS_HKDF_H
#define MBEDTLS_ERR_HKDF_BAD_INPUT_DATA -24448 /**< Bad input parameters to function. */
* \name HKDF Error codes
int mbedtls_hkdf( const mbedtls_md_info_t *md, const unsigned char *salt,
size_t salt_len, const unsigned char *ikm, size_t ikm_len,
const unsigned char *info, size_t info_len,
unsigned char *okm, size_t okm_len );
/** * \brief This is the HMAC-based Extract-and-Expand Key Derivation Function * (HKDF). * * \param md A hash function; md.size denotes the length of the hash * function output in bytes. * \param salt An optional salt value (a non-secret random value); * if the salt is not provided, a string of all zeros of * md.size length is used as the salt. * \param salt_len The length in bytes of the optional \p salt. * \param ikm The input keying material. * \param ikm_len The length in bytes of \p ikm. * \param info An optional context and application specific information * string. This can be a zero-length string. * \param info_len The length of \p info in bytes. * \param okm The output keying material of \p okm_len bytes. * \param okm_len The length of the output keying material in bytes. This * must be less than or equal to 255 * md.size bytes. * * \return 0 on success. * \return #MBEDTLS_ERR_HKDF_BAD_INPUT_DATA when the parameters are invalid. * \return An MBEDTLS_ERR_MD_* error for errors returned from the underlying * MD layer. */
int mbedtls_hkdf_extract( const mbedtls_md_info_t *md,
const unsigned char *salt, size_t salt_len,
unsigned char *prk );
/** * \brief Take the input keying material \p ikm and extract from it a * fixed-length pseudorandom key \p prk. * * \warning This function should only be used if the security of it has been * studied and established in that particular context (eg. TLS 1.3 * key schedule). For standard HKDF security guarantees use * \c mbedtls_hkdf instead. * * \param md A hash function; md.size denotes the length of the * hash function output in bytes. * \param salt An optional salt value (a non-secret random value); * if the salt is not provided, a string of all zeros * of md.size length is used as the salt. * \param salt_len The length in bytes of the optional \p salt. * \param ikm The input keying material. * \param ikm_len The length in bytes of \p ikm. * \param[out] prk A pseudorandom key of at least md.size bytes. * * \return 0 on success. * \return #MBEDTLS_ERR_HKDF_BAD_INPUT_DATA when the parameters are invalid. * \return An MBEDTLS_ERR_MD_* error for errors returned from the underlying * MD layer. */
int mbedtls_hkdf_expand( const mbedtls_md_info_t *md, const unsigned char *prk,
size_t prk_len, const unsigned char *info,
size_t info_len, unsigned char *okm, size_t okm_len );
/** * \brief Expand the supplied \p prk into several additional pseudorandom * keys, which is the output of the HKDF. * * \warning This function should only be used if the security of it has been * studied and established in that particular context (eg. TLS 1.3 * key schedule). For standard HKDF security guarantees use * \c mbedtls_hkdf instead. * * \param md A hash function; md.size denotes the length of the hash * function output in bytes. * \param prk A pseudorandom key of at least md.size bytes. \p prk is * usually the output from the HKDF extract step. * \param prk_len The length in bytes of \p prk. * \param info An optional context and application specific information * string. This can be a zero-length string. * \param info_len The length of \p info in bytes. * \param okm The output keying material of \p okm_len bytes. * \param okm_len The length of the output keying material in bytes. This * must be less than or equal to 255 * md.size bytes. * * \return 0 on success. * \return #MBEDTLS_ERR_HKDF_BAD_INPUT_DATA when the parameters are invalid. * \return An MBEDTLS_ERR_MD_* error for errors returned from the underlying * MD layer. */
