#define MBEDTLS_CONFIG_H_TY_ECC_ONLY
#define TUYA_ECP_MUL_COMB_ROM_TABLES 1 //使用ROM代替RAM
//#define TUYA_ECP_MUL_COMB_OPTIM 1 //打开ECP点乘优化
#define MBEDTLS_CAMELLIA_SMALL_MEMORY
/** * \def MBEDTLS_CAMELLIA_SMALL_MEMORY * * Use less ROM for the Camellia implementation (saves about 768 bytes). * * Uncomment this macro to use less memory for Camellia. */
#define MBEDTLS_ECP_DP_SECP192R1_ENABLED
/** * \def MBEDTLS_ECP_DP_SECP192R1_ENABLED * * MBEDTLS_ECP_XXXX_ENABLED: Enables specific curves within the Elliptic Curve * module. By default all supported curves are enabled. * * Comment macros to disable the curve and functions for it */
#define MBEDTLS_ECP_DP_SECP224R1_ENABLED
#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
#define MBEDTLS_ECP_DP_SECP521R1_ENABLED
#define MBEDTLS_ECP_DP_SECP192K1_ENABLED
#define MBEDTLS_ECP_DP_SECP224K1_ENABLED
#define MBEDTLS_ECP_DP_SECP256K1_ENABLED
#define MBEDTLS_ECP_DP_BP256R1_ENABLED
#define MBEDTLS_ECP_DP_BP384R1_ENABLED
#define MBEDTLS_ECP_DP_BP512R1_ENABLED
#define MBEDTLS_ECP_DP_CURVE25519_ENABLED
#define MBEDTLS_ECP_DP_CURVE448_ENABLED
#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
/** * \def MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED * * Enable the ECDHE-ECDSA based ciphersuite modes in SSL / TLS. * * Requires: MBEDTLS_ECDH_C, MBEDTLS_ECDSA_C, MBEDTLS_X509_CRT_PARSE_C, * * This enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_RC4_128_SHA */
#define MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED
/** * \def MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED * * Enable the ECDH-ECDSA based ciphersuite modes in SSL / TLS. * * Requires: MBEDTLS_ECDH_C, MBEDTLS_X509_CRT_PARSE_C * * This enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_256_GCM_SHA384 */
#define MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED
/** * \def MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED * * Enable the ECDH-RSA based ciphersuite modes in SSL / TLS. * * Requires: MBEDTLS_ECDH_C, MBEDTLS_X509_CRT_PARSE_C * * This enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_RSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_256_GCM_SHA384 */
#define MBEDTLS_PK_PARSE_EC_EXTENDED
/** * \def MBEDTLS_PK_PARSE_EC_EXTENDED * * Enhance support for reading EC keys using variants of SEC1 not allowed by * RFC 5915 and RFC 5480. * * Currently this means parsing the SpecifiedECDomain choice of EC * parameters (only known groups are supported, not arbitrary domains, to * avoid validation issues). * * Disable if you only need to support RFC 5915 + 5480 key formats. */
#define MBEDTLS_GENPRIME
/** * \def MBEDTLS_GENPRIME * * Enable the prime-number generation code. * * Requires: MBEDTLS_BIGNUM_C */
#define MBEDTLS_PK_RSA_ALT_SUPPORT
/** * \def MBEDTLS_PK_RSA_ALT_SUPPORT * * Support external private RSA keys (eg from a HSM) in the PK layer. * * Comment this macro to disable support for external private RSA keys. */
#define MBEDTLS_PKCS1_V15
#define MBEDTLS_PKCS1_V21
#define MBEDTLS_SSL_FALLBACK_SCSV
/** * \def MBEDTLS_SSL_FALLBACK_SCSV * * Enable support for FALLBACK_SCSV (draft-ietf-tls-downgrade-scsv-00). * * For servers, it is recommended to always enable this, unless you support * only one version of TLS, or know for sure that none of your clients * implements a fallback strategy. * * For clients, you only need this if you're using a fallback strategy, which * is not recommended in the first place, unless you absolutely need it to * interoperate with buggy (version-intolerant) servers. * * Comment this macro to disable support for FALLBACK_SCSV */
#define MBEDTLS_SSL_PROTO_TLS1
/** * \def MBEDTLS_SSL_PROTO_TLS1 * * Enable support for TLS 1.0. * * Requires: MBEDTLS_MD5_C * MBEDTLS_SHA1_C * * Comment this macro to disable support for TLS 1.0 */
#define MBEDTLS_SSL_PROTO_TLS1_1
/** * \def MBEDTLS_SSL_PROTO_TLS1_1 * * Enable support for TLS 1.1 (and DTLS 1.0 if DTLS is enabled). * * Requires: MBEDTLS_MD5_C * MBEDTLS_SHA1_C * * Comment this macro to disable support for TLS 1.1 / DTLS 1.0 */
#define MBEDTLS_SSL_PROTO_DTLS
/** * \def MBEDTLS_SSL_PROTO_DTLS * * Enable support for DTLS (all available versions). * * Enable this and MBEDTLS_SSL_PROTO_TLS1_1 to enable DTLS 1.0, * and/or this and MBEDTLS_SSL_PROTO_TLS1_2 to enable DTLS 1.2. * * Requires: MBEDTLS_SSL_PROTO_TLS1_1 * or MBEDTLS_SSL_PROTO_TLS1_2 * * Comment this macro to disable support for DTLS */
#define MBEDTLS_SSL_DTLS_HELLO_VERIFY
/** * \def MBEDTLS_SSL_DTLS_HELLO_VERIFY * * Enable support for HelloVerifyRequest on DTLS servers. * * This feature is highly recommended to prevent DTLS servers being used as * amplifiers in DoS attacks against other hosts. It should always be enabled * unless you know for sure amplification cannot be a problem in the * environment in which your server operates. * * \warning Disabling this can ba a security risk! (see above) * * Requires: MBEDTLS_SSL_PROTO_DTLS * * Comment this to disable support for HelloVerifyRequest. */
#define MBEDTLS_SSL_DTLS_SRTP
/** * \def MBEDTLS_SSL_DTLS_SRTP * * Enable support for DTLS-SRTP, RFC5764 * * Requires: MBEDTLS_SSL_PROTO_DTLS * * Comment this to disable support for DTLS-SRTP. */
#define MBEDTLS_SSL_SESSION_TICKETS
#define MBEDTLS_AES_C
/** * \def MBEDTLS_AES_C * * Enable the AES block cipher. * * Module: library/aes.c * Caller: library/cipher.c * library/pem.c * library/ctr_drbg.c * * This module enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_ECDHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_DHE_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384 * MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA * MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256 * MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA * * PEM_PARSE uses AES for decrypting encrypted keys. */
#define MBEDTLS_ARC4_C
/** * \def MBEDTLS_ARC4_C * * Enable the ARCFOUR stream cipher. * * Module: library/arc4.c * Caller: library/cipher.c * * This module enables the following ciphersuites (if other requisites are * enabled as well): * MBEDTLS_TLS_ECDH_ECDSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDH_RSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDHE_ECDSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDHE_RSA_WITH_RC4_128_SHA * MBEDTLS_TLS_ECDHE_PSK_WITH_RC4_128_SHA * MBEDTLS_TLS_DHE_PSK_WITH_RC4_128_SHA * MBEDTLS_TLS_RSA_WITH_RC4_128_SHA * MBEDTLS_TLS_RSA_WITH_RC4_128_MD5 * MBEDTLS_TLS_RSA_PSK_WITH_RC4_128_SHA * MBEDTLS_TLS_PSK_WITH_RC4_128_SHA * * \warning ARC4 is considered a weak cipher and its use constitutes a * security risk. If possible, we recommend avoidng dependencies on * it, and considering stronger ciphers instead. * */
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_ASN1_WRITE_C
/** * \def MBEDTLS_ASN1_WRITE_C * * Enable the generic ASN1 writer. * * Module: library/asn1write.c * Caller: library/ecdsa.c * library/pkwrite.c * library/x509_create.c * library/x509write_crt.c * library/x509write_csr.c */
#define MBEDTLS_BASE64_C
#define MBEDTLS_BIGNUM_C
#define MBEDTLS_CCM_C
/** * \def MBEDTLS_CCM_C * * Enable the Counter with CBC-MAC (CCM) mode for 128-bit block cipher. * * Module: library/ccm.c * * Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C * * This module enables the AES-CCM ciphersuites, if other requisites are * enabled as well. */
#define MBEDTLS_CIPHER_C
#define MBEDTLS_CTR_DRBG_C
#define MBEDTLS_DHM_C
/** * \def MBEDTLS_DHM_C * * Enable the Diffie-Hellman-Merkle module. * * Module: library/dhm.c * Caller: library/ssl_cli.c * library/ssl_srv.c * * This module is used by the following key exchanges: * DHE-RSA, DHE-PSK * * \warning Using DHE constitutes a security risk as it * is not possible to validate custom DH parameters. * If possible, it is recommended users should consider * preferring other methods of key exchange. * See dhm.h for more details. * */
#define MBEDTLS_ECDH_C
#define MBEDTLS_ECDSA_C
/** * \def MBEDTLS_ECDSA_C * * Enable the elliptic curve DSA library. * * Module: library/ecdsa.c * Caller: * * This module is used by the following key exchanges: * ECDHE-ECDSA * * Requires: MBEDTLS_ECP_C, MBEDTLS_ASN1_WRITE_C, MBEDTLS_ASN1_PARSE_C */
#define MBEDTLS_ECP_C
#define MBEDTLS_ENTROPY_C
/** * \def MBEDTLS_ENTROPY_C * * Enable the platform-specific entropy code. * * Module: library/entropy.c * Caller: * * Requires: MBEDTLS_SHA512_C or MBEDTLS_SHA256_C * * This module provides a generic entropy pool */
#define MBEDTLS_ERROR_C
/** * \def MBEDTLS_ERROR_C * * Enable error code to error string conversion. * * Module: library/error.c * Caller: * * This module enables mbedtls_strerror(). */
#define MBEDTLS_HAVEGE_C
#define MBEDTLS_MD_C
#define MBEDTLS_MD5_C
#define MBEDTLS_OID_C
#define MBEDTLS_PEM_PARSE_C
/** * \def MBEDTLS_PEM_PARSE_C * * Enable PEM decoding / parsing. * * Module: library/pem.c * Caller: library/dhm.c * library/pkparse.c * library/x509_crl.c * library/x509_crt.c * library/x509_csr.c * * Requires: MBEDTLS_BASE64_C * * This modules adds support for decoding / parsing PEM files. */
#define MBEDTLS_PEM_WRITE_C
/** * \def MBEDTLS_PEM_WRITE_C * * Enable PEM encoding / writing. * * Module: library/pem.c * Caller: library/pkwrite.c * library/x509write_crt.c * library/x509write_csr.c * * Requires: MBEDTLS_BASE64_C * * This modules adds support for encoding / writing PEM files. */
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_PK_WRITE_C
/** * \def MBEDTLS_PK_WRITE_C * * Enable the generic public (asymetric) key writer. * * Module: library/pkwrite.c * Caller: library/x509write.c * * Requires: MBEDTLS_PK_C * * Uncomment to enable generic public key write functions. */
#define MBEDTLS_PKCS5_C
#define MBEDTLS_PKCS12_C
#define MBEDTLS_PLATFORM_C
#define MBEDTLS_RSA_C
#define MBEDTLS_SHA1_C
//#if ((ENABLE_ECHO_SHOW ==1) || (ENABLE_CHROMECAST==1) || (TUYA_OPERATOR_TYPE == TUYA_OPERATOR_CMCC_ANDLINK) )
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_SRV_C
/** * \def MBEDTLS_SSL_SRV_C * * Enable the SSL/TLS server code. * * Module: library/ssl_srv.c * Caller: * * Requires: MBEDTLS_SSL_TLS_C * * This module is required for SSL/TLS server support. */
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_TIMING_C
#define MBEDTLS_VERSION_C
#define MBEDTLS_X509_USE_C
#define MBEDTLS_X509_CSR_PARSE_C
/** * \def MBEDTLS_X509_CSR_PARSE_C * * Enable X.509 Certificate Signing Request (CSR) parsing. * * Module: library/x509_csr.c * Caller: library/x509_crt_write.c * * Requires: MBEDTLS_X509_USE_C * * This module is used for reading X.509 certificate request. */
#define MBEDTLS_X509_CREATE_C
/** * \def MBEDTLS_X509_CREATE_C * * Enable X.509 core for creating certificates. * * Module: library/x509_create.c * * Requires: MBEDTLS_BIGNUM_C, MBEDTLS_OID_C, MBEDTLS_PK_WRITE_C * * This module is the basis for creating X.509 certificates and CSRs. */
#define MBEDTLS_X509_CRT_WRITE_C
/** * \def MBEDTLS_X509_CRT_WRITE_C * * Enable creating X.509 certificates. * * Module: library/x509_crt_write.c * * Requires: MBEDTLS_X509_CREATE_C * * This module is required for X.509 certificate creation. */
#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384 /**< Maxium fragment length in bytes, determines the size of each of the two internal I/O buffers */
#define MBEDTLS_TLS_DEFAULT_ALLOW_SHA1_IN_KEY_EXCHANGE
/** * Allow SHA-1 in the default TLS configuration for TLS 1.2 handshake * signature and ciphersuite selection. Without this build-time option, SHA-1 * support must be activated explicitly through mbedtls_ssl_conf_sig_hashes. * The use of SHA-1 in TLS <= 1.1 and in HMAC-SHA-1 is always allowed by * default. At the time of writing, there is no practical attack on the use * of SHA-1 in handshake signatures, hence this option is turned on by default * to preserve compatibility with existing peers, but the general * warning applies nonetheless: * * \warning SHA-1 is considered a weak message digest and its use constitutes * a security risk. If possible, we recommend avoiding dependencies * on it, and considering stronger message digests instead. * */
