    CONSOLE APPLICATION : CodeTest Project Overview
AppWizard has created this CodeTest application for you.
This file contains a summary of what you will find in each of the files that
make up your CodeTest application.
CodeTest.vcproj
    This is the main project file for VC++ projects generated using an Application Wizard.
    It contains information about the version of Visual C++ that generated the file, and
    information about the platforms, configurations, and project features selected with the
    Application Wizard.
CodeTest.cpp
    This is the main application source file.
Other standard files:
StdAfx.h, StdAfx.cpp
    These files are used to build a precompiled header (PCH) file
    named CodeTest.pch and a precompiled types file named StdAfx.obj.
Other notes:
AppWizard uses "TODO:" comments to indicate parts of the source code you
should add to or customize.
