ļб
/qt.conf
/Qt3Support4.dll
/QtCore4.dll
/QtGui4.dll
/QtNetwork4.dll
/QtOpenGL4.dll
/QtSerialPort.dll
/QtSql4.dll
/QtXml4.dll
/QtSvg4.dll
/plugins/imageformats/qgif4.dll
/plugins/imageformats/qico4.dll
/plugins/imageformats/qjpeg4.dll
/plugins/imageformats/qmng4.dll
/plugins/imageformats/qsvg4.dll
/plugins/imageformats/qtga4.dll
/plugins/imageformats/qtiff4.dll
/plugins/iconengines/qsvgicon4.dll
/msvcp100.dll
/msvcr100.dll
/coolhost_library.dll
/libelf.dll
/libusb0.dll
/msvcr100-ruby18.dll
/romulib.dll
/cooltrace.dll
/coolat.exe
/coolgdb.exe
/coolgdb2.exe
/coolhost.exe
/coolpkg.exe
/coolprofile.exe
/coolwatcher.exe
/coolwatcher_usb.exe
/coolxml.exe
/FLAMulator.exe
/srecmap.exe
/srecmapbin.exe
/xcp2h.exe
/multitrace.exe
/mem_bridge_rom_CHIP_drom.lod
/mem_bridge_rom_CHIP_irom.lod
/DOC/Coolwatcher_User_Guide.pdf
/DOC/CoolAT_User_Guide.pdf
/DOC/release_notes_custom.txt
/DOC/coolwatcher.html
/docpool/*.png
/docpool/*.gif
/drivers/
/lib/
/resources/*.png
/resources/*.wav
/resources/*.mid
/chipgen/Modem2G/toolpool/changelog.txt
/chipgen/Modem2G/toolpool/deliv.yaml
/chipgen/Modem2G/toolpool/findglobals.rb
/chipgen/Modem2G/toolpool/makepublicpool.rb
/chipgen/Modem2G/toolpool/map/2gTraceDB/traceDb.yaml
/chipgen/Modem2G/toolpool/map/8809/8809_hard.xml
/chipgen/Modem2G/toolpool/map/8809/8809_soft_pkg.xmd
/chipgen/Modem2G/toolpool/map/8809/8809_soft_pkg_with_voc.xmd
/chipgen/Modem2G/toolpool/map/8809/8809_soft_root.xmd
/chipgen/Modem2G/toolpool/map/8809/8809_soft_root_with_voc.xmd
/chipgen/Modem2G/toolpool/map/8809/8955_hard.xml
/chipgen/Modem2G/toolpool/map/8809/8955_soft_pkg.xmd
/chipgen/Modem2G/toolpool/map/8809/traceDb.yaml
/chipgen/Modem2G/toolpool/map/8909/*.xmd
/chipgen/Modem2G/toolpool/map/8909/*.xml
/chipgen/Modem2G/toolpool/map/8909L/*.xmd
/chipgen/Modem2G/toolpool/map/8909L/*.xml
/chipgen/Modem2G/toolpool/map/8909L_fpga/*.xmd
/chipgen/Modem2G/toolpool/map/8909L_fpga/*.xml
/chipgen/Modem2G/toolpool/map/8910/*.xmd
/chipgen/Modem2G/toolpool/map/8910/*.xml
/chipgen/Modem2G/toolpool/map/ChipStd/*.xmd
/chipgen/Modem2G/toolpool/map/elfdump/*.xml
/chipgen/Modem2G/toolpool/map/Gallite/*.xml
/chipgen/Modem2G/toolpool/map/Gallite/*.xmd
/chipgen/Modem2G/toolpool/plugins/Calib/*.rb
/chipgen/Modem2G/toolpool/plugins/cwmodem2ggui/*.rb
/chipgen/Modem2G/toolpool/plugins/fastpf/*.rb
/chipgen/Modem2G/toolpool/plugins/fastpf/flash_programmers/*_ramrun.lod
/chipgen/Modem2G/toolpool/plugins/romburn
/chipgen/Modem2G/toolpool/scripts/8809/*.rb
/chipgen/Modem2G/toolpool/scripts/8909/*.rb
/chipgen/Modem2G/toolpool/scripts/8909L/*.rb
/chipgen/Modem2G/toolpool/scripts/8909L_fpga/*.rb
/chipgen/Modem2G/toolpool/scripts/ChipStd/*.rb
/chipgen/Modem2G/toolpool/scripts/Gallite/*.rb
/chipgen/Modem2G/toolpool/gdbfeatures/*.xml
/profiles/8910.cwp
/profiles/8909L.cwp
/profiles/8909L_fpga.cwp
/profiles/Blank.cwp
/rbbase/common/abfs.rb
/rbbase/common/base.rb
/rbbase/common/ber.rb
/rbbase/common/cmu.rb
/rbbase/common/coolhost.rb
/rbbase/common/coolhost_connections.rb
/rbbase/common/csmail.rb
/rbbase/common/eventsniffer.rb
/rbbase/common/gpib.rb
/rbbase/common/help.rb
/rbbase/common/lod.rb
/rbbase/common/netutils.rb
/rbbase/common/plugins/BufferProfile/*.rb
/rbbase/common/plugins/disassembly/*.rb
/rbbase/common/plugins/disassembly/disassemblyplugin.dll
/rbbase/common/plugins/flamulator/*.rb
/rbbase/common/plugins/keypad/keypad.dll
/rbbase/common/plugins/keypad/*.rb
/rbbase/common/plugins/tracer/*.ini
/rbbase/common/plugins/tracer/*.rb
/rbbase/common/plugins/tracer/tracerplugin.dll
/rbbase/common/setenv.rb
/rbbase/common/sxs.rb
/rbbase/common/wavetool.rb
/rbbase/CoolWatcher/
/xcp/8808_8809.xcp
/xcp/8809.xcp
/xcp/8909.xcp
/xcp/8910.xcp
/xcp/defaultconfig.xcp
/xcp/gallite.xcp
notice.txt
Notices for file(s):
/QtSerialPort.dll
/Qt3Support4.dll
/QtCore4.dll
/QtGui4.dll
/QtNetwork4.dll
/QtOpenGL4.dll
/QtSql4.dll
/QtXml4.dll
/QtSvg4.dll
/libelf.dll
/libusb0.dll
/QtSerialPort.dll
** Copyright (C) 2012 Denis Shienkov <denis.shienkov@gmail.com>
** Copyright (C) 2013 Laszlo Papp <lpapp@kde.org>
** Contact: http://www.qt-project.org/legal
** This file is part of the QtSerialPort module of the Qt Toolkit.
** $QT_BEGIN_LICENSE:LGPL$
** Commercial License Usage
** Licensees holding valid commercial Qt licenses may use this file in
** accordance with the commercial license agreement provided with the
** Software or, alternatively, in accordance with the terms contained in
** a written agreement between you and Digia.  For licensing terms and
** conditions see http://qt.digia.com/licensing.  For further information
** use the contact form at http://qt.digia.com/contact-us.
** GNU Lesser General Public License Usage
** Alternatively, this file may be used under the terms of the GNU Lesser
** General Public License version 2.1 as published by the Free Software
** Foundation and appearing in the file LICENSE.LGPL included in the
** packaging of this file.  Please review the following information to
** ensure the GNU Lesser General Public License version 2.1 requirements
** will be met: http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html.
** In addition, as a special exception, Digia gives you certain additional
** rights.  These rights are described in the Digia Qt LGPL Exception
** version 1.1, included in the file LGPL_EXCEPTION.txt in this package.
** GNU General Public License Usage
** General Public License version 3.0 as published by the Free Software
** Foundation and appearing in the file LICENSE.GPL included in the
** ensure the GNU General Public License version 3.0 requirements will be
** met: http://www.gnu.org/copyleft/gpl.html.
** $QT_END_LICENSE$
/libelf.dll
**Copyright (C) 1995 - 2001 Michael Riepe
**This library is free software; you can redistribute it and/or
**modify it under the terms of the GNU Library General Public
**License as published by the Free Software Foundation; either
**version 2 of the License, or (at your option) any later version.
**This library is distributed in the hope that it will be useful,
**but WITHOUT ANY WARRANTY; without even the implied warranty of
**MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
**Library General Public License for more details.
**You should have received a copy of the GNU Library General Public
**License along with this library; if not, write to the Free Software
**Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA
/Qt3Support4.dll
** Copyright (C) 2015 The Qt Company Ltd.
** Contact: http://www.qt.io/licensing/
** This file is part of the Qt3Support module of the Qt Toolkit.
** a written agreement between you and The Qt Company. For licensing terms
** and conditions see http://www.qt.io/terms-conditions. For further
** information use the contact form at http://www.qt.io/contact-us.
** General Public License version 2.1 or version 3 as published by the Free
** Software Foundation and appearing in the file LICENSE.LGPLv21 and
** LICENSE.LGPLv3 included in the packaging of this file. Please review the
** following information to ensure the GNU Lesser General Public License
** requirements will be met: https://www.gnu.org/licenses/lgpl.html and
** http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html.
** As a special exception, The Qt Company gives you certain additional
** rights. These rights are described in The Qt Company LGPL Exception
** $QT_END_LICENSE$
/QtCore4.dll
** This file is part of the QtCore module of the Qt Toolkit.
** $QT_END_LICENSE$
/QtGui4.dll
** This file is part of the QtGui module of the Qt Toolkit.
** $QT_END_LICENSE$
/QtNetwork4.dll
** This file is part of the QtNetwork module of the Qt Toolkit.
** $QT_END_LICENSE$
/QtOpenGL4.dll
** This file is part of the QtOpenGL module of the Qt Toolkit.
** $QT_END_LICENSE$
/QtSql4.dll
** This file is part of the QtSql module of the Qt Toolkit.
** $QT_END_LICENSE$
/QtXml4.dll
** This file is part of the QtXml module of the Qt Toolkit.
** $QT_END_LICENSE$
/QtSvg4.dll
** This file is part of the QtSvg module of the Qt Toolkit.
** $QT_END_LICENSE$
Qt   plugins/imageformats
** This file is part of the plugins of the Qt Toolkit.
** $QT_END_LICENSE$
**Ruby is copyrighted free software by Yukihiro Matsumoto <matz@netlab.jp>.
**You can redistribute it and/or modify it under either the terms of the
**2-clause BSDL (see the file BSDL), or the conditions below:
**  1. You may make and give away verbatim copies of the source form of the
**     software without restriction, provided that you duplicate all of the
**     original copyright notices and associated disclaimers.
**  2. You may modify your copy of the software in any way, provided that
**    you do at least ONE of the following:
**       a) place your modifications in the Public Domain or otherwise
**          make them Freely Available, such as by posting said
**	  modifications to Usenet or an equivalent medium, or by allowing
**	  the author to include your modifications in the software.
**      b) use the modified software only within your corporation or
**         organization.
**       c) give non-standard binaries non-standard names, with
**          instructions on where to get the original software distribution.
**       d) make other distribution arrangements with the author.
**  3. You may distribute the software in object code or binary form,
**     provided that you do at least ONE of the following:
**       a) distribute the binaries and library files of the software,
**	  together with instructions (in the manual page or equivalent)
**	  on where to get the original distribution.
**       b) accompany the distribution with the machine-readable source of
**	  the software.
**  4. You may modify and include the part of the software into any other
**     software (possibly commercial).  But some files in the distribution
**     are not written by the author, so that they are not under these terms.
**     For the list of those files and their copying conditions, see the
**     file LEGAL.
**  5. The scripts and library files supplied as input to or produced as
**     output from the software do not automatically fall under the
**     copyright of the software, but belong to whomever generated them,
**     and may be sold commercially, and may be aggregated with this
**     software.
**  6. THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
**     IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
**     WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
**     PURPOSE.
/libusb0.dll
**This software is distributed under the following licenses:
**Driver:      GNU General Public License (GPL)
**Library, Test Files, Installer:    GNU Lesser General Public License (LGPL)
 **                   GNU GENERAL PUBLIC LICENSE
 **                      Version 3, 29 June 2007
** Copyright (C) 2007 Free Software Foundation, Inc. <http://fsf.org/>
**Everyone is permitted to copy and distribute verbatim copies
**of this license document, but changing it is not allowed.
