[BEGIN] 2023/5/12 16:20:28 Tuya login: vm.overcommit_memory = 0 vm.overcommit_ratio = 50 vm.min_free_kbytes = 1024 vm.dirty_background_ratio = 2 vm.dirty_expire_centisecs = 500 vm.dirty_ratio = 2 vm.dirty_writeback_centisecs = 100 vm.admin_reserve_kbytes = 0 vm.user_reserve_kbytes = 0 status: active CC: [main, 73] May 12 2023,15:31:53 [1970-1-1 0:0:14.448 ty_sys.c ty_sys_start(1273) Debug] start [1970-1-1 0:0:14.589 ty_sys.c __sys_get_reboot_reason(179) Debug] cfg:[] [1970-1-1 0:0:14.706 ty_sys.c __sys_msg_start(1102) Debug] __begin [1970-1-1 0:0:14.707 ty_sys_cfg.c ty_sys_cfg_init(207) Debug] fopen file_path[/tuya/data//tuya_cfg.bin] [1970-1-1 0:0:14.708 ty_sys_cfg.c ty_sys_cfg_init(266) Debug] crc32[3772269967] version[1] num[47] len[2120] [1970-1-1 0:0:14.708 ty_sys_cfg.c ty_sys_cfg_init(326) Debug] cfg info ver[1] num[47] len[2120] [1970-1-1 0:0:14.709 ty_wifi.c ty_hwl_wifi_init(964) Debug] bigin___ [1970-1-1 0:0:14.709 ty_wifi.c ty_hwl_wifi_init(978) Debug] end___ [1970-1-1 0:0:14.723 ty_sys.c __sys_msg_proc(1072) Debug] msg proc begin [1970-1-1 0:0:14.724 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [0] run_step [0] tkl_venc_set_osd is dls:0, enable:1 rts3917_osd_enable 0 start rts3917_osd_enable 0 info null, wait osd init rts3917_osd_enable 1 start rts3917_osd_enable 1 info null, wait osd init [1970-1-1 0:0:15.130 ty_sys.c __set_default_cfg_before(506) Info] led_switch:1 ty_sys_led_mode_set[429] status[0] switch:1 ty_sys_led_mode_set[442] status[0] switch:1 ty_sys_led_mode_set[448] status[0] switch:1 1970-01-01 00:00:15 tkl_file ERROR: 51,tkl_file_write: Failed to open /sys/class/gpio/gpio80/value 1970-01-01 00:00:15 tkl_gpio ERROR: 175,tkl_gpio_write: Failed to set gpio(80) level 1970-01-01 00:00:15 tkl_file ERROR: 51,tkl_file_write: Failed to open /sys/class/gpio/gpio81/value 1970-01-01 00:00:15 tkl_gpio ERROR: 175,tkl_gpio_write: Failed to set gpio(81) level 1970-01-01 00:00:15 tkl_file ERROR: 51,tkl_file_write: Failed to open /sys/class/gpio/gpio43/value 1970-01-01 00:00:15 tkl_gpio ERROR: 175,tkl_gpio_write: Failed to set gpio(43) level [1970-1-1 0:0:15.275 ty_sys_av.c ty_sys_av_start(348) Debug] __begin [1970-1-1 0:0:15.275 ty_sys_av.c ty_sys_av_start(387) Debug] pvi->isp.isp_fig_style_day brightness 50 saturation 50 contrast 50 sharpness 50 gamma 50 tkl_vi_isp_show_fw_version i:0, w,h:2560 1440 i:1, w,h:640 360 i:2, w,h:640 360 i:3, w,h:0 0 i:3, type:0 enable:0,continue i:4, w,h:640 360 i:5, w,h:160 90 i:6, w,h:256 160 i:7, w,h:640 360 [1970-1-1 0:0:15.281 ty_sys_av.c __video_task(271) Debug] __begin type = 0 [1970-1-1 0:0:15.281 ty_sys_av.c __video_task(280) Info] wait time sync start,type:0... [1970-1-1 0:0:15.282 ty_sys_av.c __video_task(271) Debug] __begin type = 1 [1970-1-1 0:0:15.282 ty_sys_av.c __video_task(280) Info] wait time sync start,type:1... [1970-1-1 0:0:15.282 ty_sys_av.c __audio_task(188) Debug] __begin type = 0 [1970-1-1 0:0:15.283 ty_sys_av.c __audio_task(195) Info] ty_time_wait_sync wait start,type:0... vin_mode 1, vin_id 0, vin_buf_num 2, video_index = 0, vpu_chn_id = 0 width = 2560, height = 1440, denominator = 20 h265 venc_chn_id=8, tier = 0, rotation 0, mirror 0, venc_chn_id 50 h265 gop 40, min_bitrate 786432, max_bitrate 1572864 vpu_chn_id = 0, venc_chn_id = 50, ret = 0 tkl_venc_start vpu_chn_id=0, venc_chn_id=50 vin_mode 0, vin_id 1, vin_buf_num 2, video_index = 1, vpu_chn_id = 1 width = 640, height = 360, denominator = 20 h264 venc_chn_id=20 h264 gop 40, min_bitrate 262144, max_bitrate 524288 vpu_chn_id = 1, venc_chn_id = 20, ret = 0 tkl_venc_start vpu_chn_id=1, venc_chn_id=20 vin_mode 0, vin_id 2, vin_buf_num 2, video_index = 2, vpu_chn_id = 2 width = 640, height = 360, denominator = 15 tkl_venc_start TKL_VENC_2 vpu_chn_id=2 ty_rts3917_osd_init start rts3917_osd_init 0 start rts3917_osd_init 0 succeed rts3917_osd_init 1 start rts3917_osd_init 1 succeed ty_rts3917_osd_init succeed tkl_ai_init ai_param sample 8000, bit_width 16, channels 1, period_size 320, fps 25, mic_volume 80 sh: 30: unknown operand audio capture chn : 210 tkl_ai_set_vol card:0 chn:0 vol:80 [rts camera] : default preset file number: 1 tkl_ai_init success tkl_ao_init ao_param sample 8000, bit_width 16, channels 1, period_size 320, fps 25, spk_volume 80 audio mix chn : 230 wait for time sync audio playback chn : 200 tkl_ao_set_vol card:0 chn:0 vol:80 >>>>>>>>>>start audio playback tkl_ao_init success tkl_ai_start card:0 chn:0 tkl_ai_start card:0 chn:0 success [1970-1-1 0:0:16.743 ty_sys_av.c ty_sys_av_start(468) Debug] __end [1970-1-1 0:0:17.064 ty_com_adapter.c ty_com_adpt_get_mtd_cfg(103) Debug] mtd cfg [zwlarqxkjsqcuycp-uuid4d5da458a1312434-vK6UCR5fqsM6Bhxo5k1BaaK0Z0Z8g78u] [01-01 00:00:00 TUYA I][kv_storge.c:45] Init Kvs With File:/tuya/data/ [01-01 00:00:00 TUYA I][tal_thread.c:184] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 00:00:00 TUYA N][tuya_iot_com_api.c:318] uni_random_init... [01-01 00:00:00 TUYA N][tuya_tls.c:358] tuya_tls_rand_init ok! [01-01 00:00:00 TUYA I][mqc_app.c:326] mqc app init ... [01-01 00:00:00 TUYA I][tal_thread.c:184] thread_create name:wq_system,stackDepth:5120,totalstackDepth:9216,priority:3 [01-01 00:00:00 TUYA I][tal_thread.c:184] thread_create name:wq_highpri,stackDepth:4096,totalstackDepth:13312,priority:4 [01-01 00:00:00 TUYA E][log_seq.c:860] logseq empty [01-01 00:00:00 TUYA I][tuya_ring_buffer.c:685] Init Ring Buffer success: ch0st0tr0 size:1966080 nodes:200 [01-01 00:00:00 TUYA I][tuya_ring_buffer.c:685] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:200 [01-01 00:00:00 TUYA I][tuya_ring_buffer.c:685] Init Ring Buffer success: ch0st0tr2 size:655360 nodes:150 [01-01 00:00:00 TUYA I][tuya_ring_buffer.c:685] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:1 gw_bi [01-01 00:00:17 TUYA D][simplekv.c:1183] key:gw_bi find value.Len:224 [01-01 00:00:17 TUYA D][tuya_ws_db.c:651] sync to protected len[213] [01-01 00:00:17 TUYA D][ws_db_gw.c:145] gw_bi read ret:0 [01-01 00:00:17 TUYA D][tuya_wifi_link.c:616] tuya wifi link init mthd:0,wifi start mode:0 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:2 gw_wsm [01-01 00:00:17 TUYA D][simplekv.c:1183] key:gw_wsm find value.Len:160 [01-01 00:00:17 TUYA D][tuya_ws_db.c:651] sync to protected len[151] [01-01 00:00:17 TUYA D][ws_db_gw.c:253] gw_wsm read ret:0 [01-01 00:00:17 TUYA N][tuya_wifi_link.c:82] start wifi link params validate, nc_tp:4 md:0 [01-01 00:00:17 TUYA N][tuya_wifi_link.c:108] gw_wsm.nc_tp:4 [01-01 00:00:17 TUYA N][tuya_wifi_link.c:109] gw_wsm.md:0 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:2 gw_wsm [01-01 00:00:17 TUYA D][simplekv.c:1183] key:gw_wsm find value.Len:160 [01-01 00:00:17 TUYA D][tuya_ws_db.c:651] sync to protected len[151] [01-01 00:00:17 TUYA D][ws_db_gw.c:253] gw_wsm read ret:0 [01-01 00:00:17 TUYA N][tuya_svc_devos.c:483] Last reset reason: 7 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:1 gw_bi [01-01 00:00:17 TUYA D][simplekv.c:1183] key:gw_bi find value.Len:224 [01-01 00:00:17 TUYA D][tuya_ws_db.c:651] sync to protected len[213] [01-01 00:00:17 TUYA D][ws_db_gw.c:145] gw_bi read ret:0 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:6 tls_ca_cnt [01-01 00:00:17 TUYA D][simplekv.c:1183] key:tls_ca_cnt find value.Len:16 [01-01 00:00:17 TUYA D][tuya_tls.c:552] tls_ca_cnt:1 and parse:1 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:tls_ca0 isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:5 tls_ca0 [01-01 00:00:17 TUYA D][simplekv.c:1183] key:tls_ca0 find value.Len:2688 [01-01 00:00:17 TUYA D][tuya_tls.c:582] Parse DER tls_ca0:2002 success [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:2 gw_wsm [01-01 00:00:17 TUYA D][simplekv.c:1183] key:gw_wsm find value.Len:160 [01-01 00:00:17 TUYA D][tuya_ws_db.c:651] sync to protected len[151] [01-01 00:00:17 TUYA D][ws_db_gw.c:253] gw_wsm read ret:0 [01-01 00:00:17 TUYA N][tuya_svc_devos.c:283] gw_cntl->gw_wsm.stat:2 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:3 gw_di [01-01 00:00:17 TUYA D][simplekv.c:1183] key:gw_di find value.Len:704 [01-01 00:00:17 TUYA D][ws_db_gw.c:370] gw_di read ret:0 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:is_stride isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:8 is_stride [01-01 00:00:17 TUYA D][simplekv.c:1183] key:is_stride find value.Len:16 [01-01 00:00:17 TUYA D][tuya_devos_stride.c:54] stride from flash: 0. [01-01 00:00:17 TUYA D][tuya_devos_stride.c:82] ver no change. [01-01 00:00:17 TUYA N][tuya_svc_devos.c:331] gw_cntl->gw_if.abi:0 input:0 [01-01 00:00:17 TUYA N][tuya_svc_devos.c:332] gw_cntl->gw_if.product_key:zwlarqxkjsqcuycp, input:zwlarqxkjsqcuycp [01-01 00:00:17 TUYA N][tuya_svc_devos.c:333] gw_cntl->gw_if.tp:0, input:0 [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:9 gw_ai [01-01 00:00:17 TUYA D][simplekv.c:1183] key:gw_ai find value.Len:544 wait for time sync [01-01 00:00:17 TUYA D][ws_db_gw.c:453] gw_ai read ret:0 [01-01 00:00:17 TUYA D][uni_network.c:418] set_dns_region:1 [01-01 00:00:17 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216] [01-01 00:00:17 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36] [01-01 00:00:17 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165] [01-01 00:00:17 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[42.192.30.165] [01-01 00:00:17 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108] [01-01 00:00:17 TUYA D][simplekv.c:1126] read key:dzoojw isFuzzy:0 skipCnt:0 [01-01 00:00:17 TUYA D][simplekv.c:1157] find key:18 dzoojw [01-01 00:00:17 TUYA D][simplekv.c:1183] key:dzoojw find value.Len:3280 [01-01 00:00:17 TUYA D][ws_db_gw.c:530] schema dzoojw read success [01-01 00:00:17 TUYA D][tuya_devos_utils.c:1108] create dev_cntl Success [01-01 00:00:17 TUYA N][tuya_svc_devos.c:512] enter success_proc [1970-1-1 0:0:17.899 ty_wifi.c tkl_wifi_get_mac(579) Debug] tkl_wifi_get_mac[579] called [1970-1-1 0:0:17.904 ty_wifi.c tkl_wifi_get_mac(599) Debug] WIFI Get MAC(1) 54-EF-33-80-1A-5D [01-01 00:00:17 TUYA N][tuya_svc_devos.c:515] serial_no:54ef33801a5d [01-01 00:00:17 TUYA D][tuya_devos_utils.c:293] timer ID:3945368 [01-01 00:00:17 TUYA D][tuya_devos_health.c:57] init watchdog, interval: 60 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:0 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:1 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:2 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:3 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:4 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:5 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:6 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:7 [01-01 00:00:17 TUYA D][tuya_devos_health.c:114] add new node,type:8 [01-01 00:00:17 TUYA D][tuya_devos_health.c:441] watch_dog_interval:60, monitor_detect_interval:600 [01-01 00:00:17 TUYA I][tal_thread.c:184] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5 [01-01 00:00:17 TUYA D][tuya_svc_upgrade.c:1043] tuya svc upgrade init success! [01-01 00:00:17 TUYA D][com_mmod.c:256] reg msgID:0 [01-01 00:00:17 TUYA D][mqc_app.c:134] mq_pro:300 cnt:3 [01-01 00:00:17 TUYA D][mqc_app.c:134] mq_pro:302 cnt:4 [01-01 00:00:17 TUYA D][mqc_app.c:134] mq_pro:304 cnt:5 [01-01 00:00:17 TUYA D][mqc_app.c:134] mq_pro:307 cnt:6 [01-01 00:00:17 TUYA D][mqc_app.c:134] mq_pro:308 cnt:7 [01-01 00:00:17 TUYA D][mqc_app.c:134] mq_pro:312 cnt:8 [01-01 00:00:17 TUYA D][tuya_ipc_mqtt_subscribe.c:291] iot_register_extra_mqt_cb done [01-01 00:00:17 TUYA D][tuya_svc_devos.c:749] state change from 0 to 3 [1970-1-1 0:0:17.912 ty_wifi.c tkl_wifi_set_country_code(865) Debug] Set Country Code:0 [01-01 00:00:17 TUYA D][tuya_wifi_reset.c:564] reset init mthd:0, short timer:0 long timer:0 [01-01 00:00:17 TUYA I][tal_thread.c:184] thread_create name:lpc_task,stackDepth:4096,totalstackDepth:18944,priority:3 [01-01 00:00:17 TUYA N][tuya_svc_devos.c:206] __devos_init_evt success [01-01 00:00:17 TUYA N][tuya_svc_devos.c:50] already bind [01-01 00:00:17 TUYA E][tuya_ipc_sdk_init.c:296] gw status changed to [3], but not notify [01-01 00:00:17 TUYA I][mqc_app.c:573] mqc app start ... [01-01 00:00:17 TUYA D][mqc_app.c:621] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883 [01-01 00:00:18 TUYA D][mqc_app.c:634] TLS disable mqtt time check [01-01 00:00:18 TUYA D][mqtt_client.c:628] domain<0> mqtts://m2.tuyacn.com:8883 HAVE PORT [01-01 00:00:18 TUYA D][mqtt_client.c:631] PARSE mqtts://m2.tuyacn.com:8883 [01-01 00:00:18 TUYA D][tuya_iot_wifi_api.c:436] register wifi network monitor. interval:1 white_light_mode:0 fast:250,slow:1500 [01-01 00:00:18 TUYA D][tal_thread.c:203] Thread:lpc_task Exec Start. Set to Running Stat [01-01 00:00:18 TUYA E][tuya_wifi_link.c:433] get wf stat err:-23 [01-01 00:00:18 TUYA D][tal_thread.c:203] Thread:health_monitor Exec Start. Set to Running Stat [01-01 00:00:18 TUYA D][tuya_devos_health.c:70] feed watchdog [01-01 00:00:18 TUYA D][mqtt_client.c:353] set url mqtts://m2.tuyacn.com [01-01 00:00:18 TUYA D][mqtt_client.c:378] scheme:mqtts [01-01 00:00:18 TUYA E][tuya_wifi_link.c:433] get wf stat err:-23 [01-01 00:00:18 TUYA E][mqtt_client.c:318] mqtt Get IP Fails [01-01 00:00:18 TUYA D][mqc_app.c:678] mqtt send topic:smart/device/out/6ca27cadb2e9df92edwr0a [01-01 00:00:18 TUYA D][mqc_app.c:680] mqtt-media send topic:d/m/o/6ca27cadb2e9df92edwr0a [01-01 00:00:18 TUYA I][tal_thread.c:184] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:23040,priority:4 [01-01 00:00:18 TUYA D][mqc_app.c:134] mq_pro:64 cnt:9 [01-01 00:00:18 TUYA D][mqc_app.c:134] mq_pro:22 cnt:10 [01-01 00:00:18 TUYA D][mqc_app.c:134] mq_pro:55 cnt:11 [01-01 00:00:18 TUYA D][simplekv.c:1126] read key:timer_arr isFuzzy:0 skipCnt:0 [01-01 00:00:18 TUYA D][simplekv.c:1157] find key:7 timer_arr [01-01 00:00:18 TUYA D][simplekv.c:1183] key:timer_arr find value.Len:32 [01-01 00:00:18 TUYA D][tuya_svc_timer_task.c:382] timer:{"lastFetchTime":0,"cnt":0} [01-01 00:00:18 TUYA D][mqc_app.c:134] mq_pro:13 cnt:12 [01-01 00:00:18 TUYA D][mqc_app.c:134] mq_pro:15 cnt:13 [01-01 00:00:18 TUYA D][tuya_svc_upgrade.c:1064] upgrade active success [01-01 00:00:18 TUYA D][tuya_svc_online_log.c:189] mqtt log topic init log/realtime/6ca27cadb2e9df92edwr0a [01-01 00:00:18 TUYA D][tuya_svc_online_log.c:190] mqtt log topic init log/runstat/6ca27cadb2e9df92edwr0a [01-01 00:00:18 TUYA D][tuya_svc_online_log.c:245] svc online log active success [01-01 00:00:18 TUYA D][mqc_app.c:134] mq_pro:11 cnt:14 [01-01 00:00:18 TUYA D][mqc_app.c:134] mq_pro:41 cnt:15 [01-01 00:00:18 TUYA D][mqc_app.c:134] mq_pro:27 cnt:16 [01-01 08:00:18 TUYA D][simplekv.c:1126] read key:wf_pt isFuzzy:0 skipCnt:0 [01-01 08:00:18 TUYA D][simplekv.c:1154] no key find [01-01 08:00:18 TUYA D][simplekv.c:1196] __read_kv_raw fail. -3 [01-01 08:00:18 TUYA D][simplekv.c:1234] __read_kv_with_decode fail. -3 [01-01 08:00:18 TUYA D][wf_protect.c:1594] wifi protect ap info init [01-01 08:00:18 TUYA D][tuya_wifi_connect.c:285] __wifi_net_conn. [01-01 08:00:18 TUYA D][tuya_wifi_connect.c:264] status:0,mode:5 [01-01 08:00:18 TUYA D][tuya_wifi_connect.c:293] set station. [1970-1-1 0:0:18.595 ty_wifi.c tkl_wifi_set_work_mode(458) Debug] tkl_wifi_set_work_mode[458] called [1970-1-1 0:0:18.598 ty_sys_av.c ty_sys_av_set_sei(532) Debug] set sei onoff = 1 [1970-1-1 0:0:18.599 ty_sys_av.c ty_sys_av_set_face_framing(547) Debug] set face framing onoff = 1 [1970-1-1 0:0:18.599 ty_sys.c __set_default_cfg(807) Info] flip[0] alarm_switch[1]human_switch[1]secret_mode [0] dn_mode[0] alarm_deb_switch[0] alarm_during_max[15]alarm_trigger_intv[0] anti_flicker[1]uart_baud[0] [1970-1-1 0:0:18.599 ty_sys.c __set_default_cfg(809) Info] alarm_zone_switch[0] alarm_zone num[1] alarm_zone.x[0] alarm_zone.y[0] alarm_zone.w[100] alarm_zone.h[100] [1970-1-1 0:0:18.600 ty_sys.c __set_default_cfg(816) Info] night_vision[0] [1970-1-1 0:0:18.612 ty_sys_led.c __led_task(366) Debug] begin___ [1970-1-1 0:0:18.614 ty_sys_panel.c __key_monitor_task(241) Debug] begin___ [01-01 08:00:18 TUYA D][tal_thread.c:203] Thread:mq_cntl_task Exec Start. Set to Running Stat [01-01 08:00:18 TUYA D][simplekv.c:1126] read key:p2p_pwd isFuzzy:0 skipCnt:0 [01-01 08:00:19 TUYA D][simplekv.c:1157] find key:4 p2p_pwd [01-01 08:00:19 TUYA D][simplekv.c:1183] key:p2p_pwd find value.Len:16 [1970-1-1 0:0:19.128 ty_adpt_net.c ty_adpt_net_iface_set_mode(511) Error] socket ioctl err : Inappropriate ioctl for device [1970-1-1 0:0:19.287 ty_wifi.c tkl_wifi_set_work_mode(511) Debug] WIFI Set Mode 2 rts isp ctrl set mirror/flip, flag 0 ret 0............... wait for time sync [1970-1-1 0:0:19.294 ty_user_audio_detect.c ty_user_audio_detect_start(162) Debug] begin__ [1970-1-1 0:0:19.294 ty_user_audio_detect.c ty_user_audio_detect_start(195) Debug] end__ [1970-1-1 0:0:19.294 ty_user_cry_detect.c ty_user_cry_detect_start(133) Debug] begin__ tkl_ai_detect_start, type 5 tkl_ai_detect_cry_start cry sample:8000, channel:1, format:16 Type: 2, managed [1970-1-1 0:0:19.323 ty_user_dn.c ty_sys_dn_switch_task(314) Debug] on/off:1 mode:0 [1970-1-1 0:0:19.323 ty_user_dn.c ty_sys_dn_switch_task(320) Debug] enable dn switch Type: 2, managed tkl_ai_detect_start, type 6 tkl_ai_detect_db_start begin___ end___ tkl_ai_detect_db_start [01-01 08:00:19 TUYA D][tuya_wifi_connect.c:264] status:5,mode:2 [01-01 08:00:19 TUYA D][simplekv.c:1126] read key:ap_info_v2 isFuzzy:0 skipCnt:0 [01-01 08:00:19 TUYA D][simplekv.c:1154] no key find [01-01 08:00:19 TUYA D][simplekv.c:1196] __read_kv_raw fail. -3 [01-01 08:00:19 TUYA D][simplekv.c:1234] __read_kv_with_decode fail. -3 [01-01 08:00:19 TUYA E][tuya_wifi_connect.c:80] ap_info_v2 read fail:-6 [1970-1-1 0:0:19.336 ty_user_dn.c ty_sys_dn_alternate(83) Debug] alternate mode is 1 Type: 2, managed Type: 2, managed [01-01 08:00:19 TUYA D][tuya_wifi_connect.c:264] status:5,mode:2 [1970-1-1 0:0:19.343 ty_wifi.c tkl_wifi_station_connect(872) Debug] tkl_wifi_station_connect[872] called [1970-1-1 0:0:19.344 ty_sys.c __sys_msg_proc(1087) Debug] recv msg type = 105 ifconfig: SIOCSIFADDR: No such device Type: 2, managed wait for time sync [1970-1-1 0:0:20.594 ty_user_cry_detect.c ty_user_cry_detect_start(175) Debug] end__ tkl_ao_set_vol card:0 chn:0 vol:80 tkl_venc_set_osd is dls:0, enable:1 rts3917_osd_enable 0 start osd_param [0]: left 96 top 54 ch_h 32 ch_w 64 rts3917_osd_enable 0 succeed rts3917_osd_enable 1 start osd_param [1]: left 32 top 18 ch_h 16 ch_w 32 rts3917_osd_enable 1 succeed [1970-1-1 0:0:20.611 ty_user_event.c __sdk_event_init(949) Debug] max event [3] [01-01 08:00:20 TUYA D][tuya_ipc_event.c:1770] init with max:3 [01-01 08:00:20 TUYA I][tal_thread.c:184] thread_create name:event,stackDepth:24576,totalstackDepth:47616,priority:3 [01-01 08:00:20 TUYA D][tal_thread.c:203] Thread:event Exec Start. Set to Running Stat [01-01 08:00:20 TUYA D][simplekv.c:1126] read key:event_spec_info isFuzzy:0 skipCnt:0 [01-01 08:00:20 TUYA D][simplekv.c:1157] find key:11 event_spec_info [01-01 08:00:20 TUYA D][simplekv.c:1183] key:event_spec_info find value.Len:1808 [01-01 08:00:20 TUYA E][tuya_ipc_event.c:244] get type array cnt:53 [1970-1-1 0:0:20.612 ty_user_event.c ty_user_event_init(4070) Error] read key failed [1970-1-1 0:0:20.621 ty_user_event.c ty_user_event_init(4089) Error] read key failed [1970-1-1 0:0:20.622 ty_user_event.c ty_user_event_init(4101) Debug] alarm[1-2-0-15] human[1] pet[0] secret[0] dn_color_mode[0] audio_detect[1] baby_cry[1] [1970-1-1 0:0:20.622 ty_timer.c ty_timer_create(46) Debug] begin___, name(siren_timer) [1970-1-1 0:0:20.623 ty_timer.c ty_timer_create(70) Debug] end___ [1970-1-1 0:0:20.624 ty_user_onvif_server_app.c ty_user_onvif_msg_start(687) Debug] __begin [1970-1-1 0:0:20.624 ty_onvif_server.c ty_onvif_server_init(1313) Debug] init onvif server begin [1970-1-1 0:0:20.630 soap_socket.c soap_socket_create(28) Debug] create soap udp socket successfully [1970-1-1 0:0:20.631 soap_socket.c soap_socket_create(28) Debug] create soap tcp socket successfully [1970-1-1 0:0:20.632 soap_server_event.c event_service_init(582) Info] event_handling thread start [1970-1-1 0:0:20.632 soap_server_event.c event_service_init(588) Debug] [1970-1-1 0:0:20.630 ty_user_event.c __event_task(3951) Debug] __begin [1970-1-1 0:0:20.636 ty_user_event.c __event_task(3972) Debug] recv_msg type:100 [1970-1-1 0:0:20.636 ty_user_event.c __event_msg_proc(3281) Debug] ########recv startup cmd [1970-1-1 0:0:20.629 ty_user_onvif_server_app.c __onvif_msg_process_task(660) Debug] onvif msg proc begin [1970-1-1 0:0:20.636 ty_user_event.c __do_status_action(564) Debug] type [100] do led_status [0] ty_sys_led_mode_set[429] status[0] switch:1 ty_sys_led_mode_set[442] status[0] switch:1 ty_sys_led_mode_set[448] status[0] switch:1 [1970-1-1 0:0:20.638 ty_user_event.c __event_task(3972) Debug] recv_msg type:8 [1970-1-1 0:0:20.639 ty_user_event.c __event_msg_proc(3265) Debug] recv dn_mode[1] [1970-1-1 0:0:20.639 ty_user_event.c __do_dn_alternate(633) Debug] init irled [1970-1-1 0:0:20.639 ty_user_event.c __do_dn_alternate(638) Debug] dn_cur_mode -1,mode 1 [1970-1-1 0:0:20.640 ty_user_event.c __do_md_pause_ctrl(485) Debug] pause motion detect [1970-1-1 0:0:20.640 ty_user_md.c ty_user_md_pause(454) Debug] pause ty_sys_led_mode_set[429] status[11] switch:1 ty_sys_led_mode_set[442] status[11] switch:1 ty_sys_led_mode_set[448] status[11] switch:1 [1970-1-1 0:0:20.633 soap_server_event.c __event_handling_task(460) Debug] event handling task start onvifserverevent: sink event malloc size: [128] [1970-1-1 0:0:20.641 soap_server_event.c event_service_init(599) Debug] onvifserverevent: subscription manager malloc size: [2112] [1970-1-1 0:0:20.642 ty_onvif_server.c ty_onvif_server_init(1364) Info] onvif discover task thread start [1970-1-1 0:0:20.642 ty_onvif_server.c ty_onvif_server_init(1389) Info] onvif service task thread start [01-01 08:00:20 TUYA I][tal_thread.c:184] thread_create name:rtsp_server,stackDepth:4096,totalstackDepth:51712,priority:3 [1970-1-1 0:0:20.643 ty_onvif_server.c ty_onvif_server_init(1397) Debug] init onvif server success [1970-1-1 0:0:20.653 ty_onvif_server.c __onvif_discover_task(1212) Debug] onvif discover start [1970-1-1 0:0:21.319 soap_socket.c soap_udp_add_multicast(102) Error] socket set multicast failed, errno[19] [01-01 08:00:20 TUYA D][tal_thread.c:203] Thread:rtsp_server Exec Start. Set to Running Stat [1970-1-1 0:0:20.654 ty_onvif_server.c __onvif_service_task(1258) Debug] onvif service start Thu Jan 1 00:00:21 1970 set ir to mode 0 [rts camera] : tkl_vi_isp_set_color_to_gray night switch to day [1970-1-1 0:0:20.757 ty_sys.c __ty_sys_loop(1455) Debug] wait for mqtt online [1970-1-1 0:0:21.323 ty_user_event.c __do_dn_alternate(678) Debug] dn_cur_mode 1,mode 1 [1970-1-1 0:0:21.323 ty_user_event.c __event_task(3972) Debug] recv_msg type:105 [1970-1-1 0:0:21.323 ty_user_event.c __do_status_action(564) Debug] type [105] do led_status [17] ty_sys_led_mode_set[429] status[17] switch:1 ty_sys_led_mode_set[442] status[17] switch:1 ty_sys_led_mode_set[448] status[17] switch:1 [01-01 08:00:21 TUYA D][sock_util.c:54] Socket successfully created.. [01-01 08:00:21 TUYA D][sock_util.c:65] Socket successfully binded.. [01-01 08:00:21 TUYA D][sock_util.c:73] Server listening.. wait for time sync Type: 2, managed udhcpc: started, v1.31.1 sh: write error: Broken pipe grep: /etc/resolv.conf: No such file or directory udhcpc: sending discover [1970-1-1 0:0:22.429 soap_socket.c soap_udp_add_multicast(102) Error] socket set multicast failed, errno[19] wait for time sync Type: 2, managed Type: 2, managed [1970-1-1 0:0:23.401 ty_sys.c __ty_sys_loop(1455) Debug] wait for mqtt online wait for time sync [1970-1-1 0:0:23.537 soap_socket.c soap_udp_add_multicast(102) Error] socket set multicast failed, errno[19] [01-01 08:00:23 TUYA D][tuya_devos_health.c:70] feed watchdog wait for time sync Type: 2, managed [1970-1-1 0:0:24.645 soap_socket.c soap_udp_add_multicast(102) Error] socket set multicast failed, errno[19] udhcpc: sending discover udhcpc: sending select for 192.168.1.190 udhcpc: lease of 192.168.1.190 obtained, lease time 7200 sh: write error: Broken pipe sh: write error: Broken pipe route: SIOCDELRT: No such process sh: write error: Broken pipe sh: write error: Broken pipe sh: write error: Broken pipe [1970-1-1 0:0:24.930 ty_wifi.c __linux_wf_station_connect(292) Debug] do connect wifi finish got ip, connect finish [1970-1-1 0:0:24.930 ty_wifi.c __linux_wf_station_connect(296) Debug] connect wifi success,count 0 [1970-1-1 0:0:24.931 ty_wifi.c __linux_wf_station_connect(298) Debug] set wifi event cb to iot zhazha [1970-1-1 0:0:24.931 ty_wifi.c __linux_wf_station_connect(329) Debug] connect_cnt 0 [1970-1-1 0:0:24.931 ty_wifi.c tkl_wifi_station_connect(914) Debug] ssid: TP-LINK_0154, passwd: [12345678] [01-01 08:00:24 TUYA D][tuya_wifi_connect.c:356] wf connect success! [1970-1-1 0:0:24.933 ty_user_event.c __event_task(3972) Debug] recv_msg type:106 [1970-1-1 0:0:24.933 ty_user_event.c __do_status_action(564) Debug] type [106] do led_status [16] ty_sys_led_mode_set[429] status[16] switch:1 ty_sys_led_mode_set[442] status[16] switch:1 ty_sys_led_mode_set[448] status[16] switch:1 Type: 2, managed [01-01 08:00:24 TUYA N][tuya_wifi_status.c:170] cur stat:6 0x660c4 -->> [01-01 08:00:24 TUYA N][tuya_wifi_status.c:173] wifi netstat changed to:6 -->> [01-01 08:00:24 TUYA N][tuya_wifi_status.c:177] report wifi netstat[6] to callback -->> [1970-1-1 0:0:24.943 ty_sdk_adapter.c ty_sdk_net_status_change_cb(74) Debug] IPC status change to changed_group[2] status[11] [01-01 08:00:24 TUYA N][tuya_wifi_link.c:202] wifi status changed to 0 [01-01 08:00:24 TUYA D][tuya_svc_netmgr_linkage.c:115] link[1] is_up[1] active_link[1] status[0] Type: 2, managed [01-01 08:00:24 TUYA N][tuya_wifi_status.c:170] cur stat:6 0x660c4 -->> [01-01 08:00:24 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:10 [01-01 08:00:24 TUYA D][mqtt_client.c:353] set url mqtts://m2.tuyacn.com [01-01 08:00:24 TUYA D][mqtt_client.c:378] scheme:mqtts Type: 2, managed [1970-1-1 0:0:25.034 ty_wifi.c tkl_wifi_get_ip(542) Debug] strlen(saved_ip.ip):0 saved_ip.ip: strlen(local_ip) 13, local_ip 192.168.1.190 [1970-1-1 0:0:25.045 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [01-01 08:00:24 TUYA N][mqtt_client.c:322] mqtt ip:192.168.1.190 0xc0a801be [01-01 08:00:24 TUYA D][uni_network.c:315] unw_gethostbyname m2.tuyacn.com, prio 2 [01-01 08:00:24 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.30.165 for domain:m2.tuyacn.com [01-01 08:00:24 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:52008 ok [1970-1-1 0:0:25.073 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [100] run_step [1051] [01-01 08:00:24 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:24 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect m2.tuyacn.com:8883 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:24 TUYA D][tuya_tls.c:1487] load tuya cert. [01-01 08:00:24 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [01-01 08:00:24 TUYA D][tuya_iot_com_api.c:254] tuya public url [01-01 08:00:24 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [01-01 08:00:25 TUYA D][tuya_tls.c:1664] handshake finish for m2.tuyacn.com. set send/recv to user set [01-01 08:00:25 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect m2.tuyacn.com:8883 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:25 TUYA N][mqtt_client.c:1567] transporter connect host[m2.tuyacn.com] success, begin to mqtt connect [01-01 08:00:25 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:2 [01-01 08:00:25 TUYA N][mqtt_client.c:1602] mqtt connect success [01-01 08:00:25 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:3 [01-01 08:00:25 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:4 [01-01 08:00:25 TUYA D][mqtt_client.c:1451] cnt 1 [01-01 08:00:25 TUYA N][mqtt_client.c:1650] mqtt subcribe success [01-01 08:00:25 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:6 [01-01 08:00:25 TUYA D][mqtt_client.c:1157] mqtt subscribe success [01-01 08:00:25 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [01-01 08:00:25 TUYA D][mqc_app.c:483] mqtt connect success [01-01 08:00:25 TUYA D][tuya_ipc_moto_mqtt.c:68] book topic start [01-01 08:00:25 TUYA D][mqtt_client.c:2045] subscribe new topic /av/d/6ca27cadb2e9df92edwr0a ret:1 [01-01 08:00:25 TUYA D][tuya_ipc_moto_mqtt.c:74] book topic done, ret:0 [1970-1-1 0:0:25.411 ty_sdk_adapter.c ty_sdk_net_status_change_cb(74) Debug] IPC status change to changed_group[4] status[30] [1970-1-1 0:0:25.412 ty_sdk_adapter.c ty_sdk_net_status_change_cb(79) Info] online : network status MQTT connected [01-01 08:00:25 TUYA D][tuya_ipc_sdk_info.c:325] ipc sdk info: mqstat change to :1 Type: 2, managed [01-01 08:00:25 TUYA N][tuya_wifi_status.c:170] cur stat:7 0x660c4 -->> [01-01 08:00:25 TUYA N][tuya_wifi_status.c:173] wifi netstat changed to:7 -->> [01-01 08:00:25 TUYA N][tuya_wifi_status.c:177] report wifi netstat[7] to callback -->> [01-01 08:00:25 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [1970-1-1 0:0:25.453 ty_user_event.c __event_task(4016) Debug] ######mqtt online [1970-1-1 0:0:25.453 ty_user_event.c __event_task(3972) Debug] recv_msg type:102 [1970-1-1 0:0:25.453 ty_user_event.c __do_status_action(564) Debug] type [102] do led_status [4] [1970-1-1 0:0:25.454 ty_user_event.c __do_manage_led_status(514) Debug] [1970-1-1 0:0:25.454 ty_sys.c __sys_msg_proc(1087) Debug] recv msg type = 102 [1970-1-1 0:0:25.455 ty_sys.c __sys_msg_parse(1040) Debug] recv online save pre led status:102, pHandle->secret_enable=0 ty_sys_led_mode_set[429] status[4] switch:1 ty_sys_led_mode_set[442] status[4] switch:1 ty_sys_led_mode_set[448] status[4] switch:1 [1970-1-1 0:0:25.481 ty_sys.c __ty_sys_loop(1455) Debug] wait for mqtt online [01-01 08:00:25 TUYA D][tuya_ipc_media_stream.c:56] P2P API Version: 244.3.4.32 [01-01 08:00:25 TUYA D][tuya_ipc_media_stream.c:381] gw actived [01-01 08:00:25 TUYA D][tuya_ipc_mqtt_subscribe.c:83] __mqtt_subscribe_init 25480 INFO /root/workspace_temp/cde/ci_ipc_baseline/tuyaos-ipc/components/base_ice/src/tuya_media_service_rtc.c:7160: tuya p2p rtc sdk version: 0xf4030420, Mar 27 2023 16:07:23 tuya liteos uv [01-01 08:00:25 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:25 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:25 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:25 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:25 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:25 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:25 TUYA D][simplekv.c:369] write key:tuya_seed And Value Len:80 [01-01 08:00:25 TUYA D][simplekv.c:387] 0 key same AND size old 148 >= new 80 [01-01 08:00:25 TUYA D][simplekv.c:415] find 0 available space [01-01 08:00:25 TUYA D][simplekv.c:452] reuse available space 28700 [01-01 08:00:25 TUYA D][simplekv.c:207] update crc 3000587010 [01-01 08:00:25 TUYA D][simplekv.c:356] write head to normal file success [01-01 08:00:25 TUYA D][simplekv.c:492] write success [01-01 08:00:25 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:25 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:25 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [1970-1-1 0:0:25.753 soap_socket.c soap_udp_add_multicast(113) Debug] socket set multicast success wait for time sync [01-01 08:00:25 TUYA D][simplekv.c:1126] read key:dzoojw_ver isFuzzy:0 skipCnt:0 [01-01 08:00:25 TUYA D][simplekv.c:1154] no key find [01-01 08:00:25 TUYA D][simplekv.c:1196] __read_kv_raw fail. -3 [01-01 08:00:25 TUYA D][simplekv.c:1234] __read_kv_with_decode fail. -3 [01-01 08:00:25 TUYA D][tuya_svc_schema_upgrade.c:218] schema[dzoojw] not updated since activated Type: 2, managed [01-01 08:00:25 TUYA D][simplekv.c:1126] read key:ap_info_v2 isFuzzy:0 skipCnt:0 [01-01 08:00:25 TUYA D][simplekv.c:1154] no key find [01-01 08:00:25 TUYA D][simplekv.c:1196] __read_kv_raw fail. -3 [01-01 08:00:25 TUYA D][simplekv.c:1234] __read_kv_with_decode fail. -3 [01-01 08:00:25 TUYA E][tuya_wifi_connect.c:80] ap_info_v2 read fail:-6 [01-01 08:00:25 TUYA E][tuya_wifi_connect.c:131] ws_db_connect_ap_info_read fail:-6 [01-01 08:00:25 TUYA E][tuya_wifi_connect.c:48] para null [01-01 08:00:25 TUYA E][tuya_wifi_connect.c:134] ws_db_connect_ap_info_v2_write fail:-2 [01-01 08:00:25 TUYA D][simplekv.c:1126] read key:em_sys_env isFuzzy:0 skipCnt:0 [01-01 08:00:25 TUYA D][simplekv.c:1157] find key:10 em_sys_env [01-01 08:00:25 TUYA D][simplekv.c:1183] key:em_sys_env find value.Len:32 [01-01 08:00:25 TUYA D][tuya_svc_online_log.c:145] load env success rts3917 [01-01 08:00:25 TUYA D][tuya_svc_online_log.c:148] env rts3917 same. need not to update Type: 2, managed [1970-1-1 0:0:26.180 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [01-01 08:00:25 TUYA D][tuya_svc_lan.c:1556] Setup TCP Server On Port:6668 [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA D][simplekv.c:369] write key:tuya_seed And Value Len:80 [01-01 08:00:26 TUYA D][simplekv.c:387] 0 key same AND size old 148 >= new 80 [01-01 08:00:26 TUYA D][simplekv.c:415] find 0 available space [01-01 08:00:26 TUYA D][simplekv.c:452] reuse available space 28700 [01-01 08:00:26 TUYA D][simplekv.c:207] update crc 234873512 [01-01 08:00:26 TUYA D][simplekv.c:356] write head to normal file success [01-01 08:00:26 TUYA D][simplekv.c:492] write success [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA D][simplekv.c:369] write key:tuya_seed And Value Len:80 [01-01 08:00:26 TUYA D][simplekv.c:387] 0 key same AND size old 148 >= new 80 [01-01 08:00:26 TUYA D][simplekv.c:415] find 0 available space [01-01 08:00:26 TUYA D][simplekv.c:452] reuse available space 28700 [01-01 08:00:26 TUYA D][simplekv.c:207] update crc 2132656931 [01-01 08:00:26 TUYA D][simplekv.c:356] write head to normal file success [01-01 08:00:26 TUYA D][simplekv.c:492] write success [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA I][tal_thread.c:184] thread_create name:tuya_p2p_listen_task,stackDepth:131072,totalstackDepth:182784,priority:2 [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4306] video codec[20] fps[20] gop[40] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4307] height[1440] width[2560] bitrate[1536] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4306] video codec[18] fps[20] gop[40] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4307] height[360] width[640] bitrate[512] [01-01 08:00:26 TUYA E][tuya_ipc_p2p.c:931] video type error[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4306] video codec[18] fps[15] gop[30] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4307] height[360] width[640] bitrate[512] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4318] video codec[20] fps[20] gop[40] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4319] height[1440] width[2560] bitrate[1536] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4318] video codec[18] fps[20] gop[40] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4319] height[360] width[640] bitrate[512] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4318] video codec[18] fps[15] gop[30] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4319] height[360] width[640] bitrate[512] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4318] video codec[0] fps[0] gop[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4319] height[0] width[0] bitrate[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4318] video codec[0] fps[0] gop[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4319] height[0] width[0] bitrate[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4318] video codec[0] fps[0] gop[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4319] height[0] width[0] bitrate[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4318] video codec[0] fps[0] gop[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4319] height[0] width[0] bitrate[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4318] video codec[0] fps[0] gop[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4319] height[0] width[0] bitrate[0] Type: 2, managed [01-01 08:00:26 TUYA D][tal_thread.c:203] Thread:tuya_p2p_listen Exec Start. Set to Running Stat [01-01 08:00:26 TUYA D][tuya_ipc_p2p_wrapper.c:16] listen task start 27160 INFO /root/workspace_temp/cde/ci_ipc_baseline/tuyaos-ipc/components/base_ice/src/tuya_media_service_rtc.c:7536: try listen [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA D][simplekv.c:369] write key:tuya_seed And Value Len:80 [01-01 08:00:26 TUYA D][simplekv.c:387] 0 key same AND size old 148 >= new 80 [01-01 08:00:26 TUYA D][simplekv.c:415] find 0 available space [01-01 08:00:26 TUYA D][simplekv.c:452] reuse available space 28700 [01-01 08:00:26 TUYA D][simplekv.c:207] update crc 3876818313 [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4321] audio codec[133] sample[0] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4322] databits[1] channel[1] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4327] videoNum[3] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4531] p2p max_client_num[3] [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4550] need speaker audio codec[133] sample[0] databits[1] channel[0] def_live_mode[0] [01-01 08:00:26 TUYA D][simplekv.c:356] write head to normal file success [01-01 08:00:26 TUYA D][simplekv.c:492] write success [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:p2p_pwd isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:4 p2p_pwd [01-01 08:00:26 TUYA D][simplekv.c:1183] key:p2p_pwd find value.Len:16 [01-01 08:00:26 TUYA D][tuya_ipc_p2p_common.c:413] check p2p auth update or not [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:p2p_auth_info isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:12 p2p_auth_info [01-01 08:00:26 TUYA D][simplekv.c:1183] key:p2p_auth_info find value.Len:32 [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:p2p_type isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:13 p2p_type [01-01 08:00:26 TUYA D][simplekv.c:1183] key:p2p_type find value.Len:16 [01-01 08:00:26 TUYA D][tuya_ipc_p2p_common.c:476] no need update p2p_auth_info from service [01-01 08:00:26 TUYA D][tuya_ipc_media_adapter.c:496] attach media info success! device:[0] channel:[0] cb:[0xad90c] [01-01 08:00:26 TUYA I][tal_thread.c:184] thread_create name:p2p_meida_recv,stackDepth:1048576,totalstackDepth:1231360,priority:4 [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4612] speaker task create success [01-01 08:00:26 TUYA I][tal_thread.c:184] thread_create name:p2p_session_detect,stackDepth:1048576,totalstackDepth:2279936,priority:4 [01-01 08:00:26 TUYA D][tuya_ipc_p2p.c:4625] session detect create success [01-01 08:00:26 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:26 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:26 TUYA I][tal_thread.c:184] thread_create name:p2p_media_send,stackDepth:1048576,totalstackDepth:3328512,priority:4 [01-01 08:00:26 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:26 TUYA I][tal_thread.c:184] thread_create name:p2p_cmd_recv,stackDepth:1048576,totalstackDepth:4377088,priority:4 [01-01 08:00:26 TUYA D][tuya_ipc_webrtc.c:1633] begin___ [01-01 08:00:27 TUYA D][tuya_ipc_media_adapter.c:496] attach media info success! device:[0] channel:[0] cb:[0x62b50] [01-01 08:00:27 TUYA D][tuya_ipc_webrtc.c:1585] webrtc playback start_id 3 [01-01 08:00:27 TUYA E][tuya_ipc_streamer.c:1699] tstream init start [01-01 08:00:27 TUYA D][tuya_ipc_packager.c:72] get packager instance [01-01 08:00:27 TUYA D][tuya_ipc_packager.c:81] get packager instance done wait for time sync [01-01 08:00:27 TUYA D][tal_thread.c:203] Thread:p2p_session_det Exec Start. Set to Running Stat [01-01 08:00:27 TUYA D][tuya_ipc_p2p.c:4202] Begin to session detect [01-01 08:00:27 TUYA D][tal_thread.c:203] Thread:p2p_media_send Exec Start. Set to Running Stat [01-01 08:00:27 TUYA D][tuya_ipc_p2p.c:3861] into p2p video send [01-01 08:00:27 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [0] [01-01 08:00:27 TUYA D][tal_thread.c:203] Thread:p2p_meida_recv Exec Start. Set to Running Stat [01-01 08:00:27 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [0] [01-01 08:00:27 TUYA D][tal_thread.c:203] Thread:p2p_cmd_recv Exec Start. Set to Running Stat [01-01 08:00:27 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [0] num[0] [01-01 08:00:27 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:27 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:27 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:27 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:27 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:27 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 [01-01 08:00:27 TUYA D][simplekv.c:369] write key:tuya_seed And Value Len:80 [01-01 08:00:27 TUYA D][simplekv.c:387] 0 key same AND size old 148 >= new 80 [01-01 08:00:27 TUYA D][simplekv.c:415] find 0 available space [01-01 08:00:27 TUYA D][simplekv.c:452] reuse available space 28700 [01-01 08:00:27 TUYA D][simplekv.c:207] update crc 532041865 [01-01 08:00:27 TUYA D][smart_frame.c:2192] Start To Sync Dev:6ca27cadb2e9df92edwr0a, dp_rept_chan:1 [01-01 08:00:27 TUYA D][smart_frame.c:2505] Pack local dp, reset_flow_ctl:1,dpnum:44. [01-01 08:00:27 TUYA D][smart_frame.c:2586] Nothing To Pack [01-01 08:00:27 TUYA D][smart_frame.c:2243] Sync Finish [01-01 08:00:27 TUYA D][simplekv.c:356] write head to normal file success [01-01 08:00:27 TUYA D][simplekv.c:492] write success [01-01 08:00:27 TUYA D][simplekv.c:1126] read key:cloud_enc_key isFuzzy:0 skipCnt:0 [01-01 08:00:27 TUYA D][simplekv.c:1157] find key:14 cloud_enc_key [01-01 08:00:27 TUYA D][simplekv.c:1183] key:cloud_enc_key find value.Len:32 [01-01 08:00:27 TUYA D][tuya_ipc_media_adapter.c:150] alloc resource success: user handle [0x45ec50][0 KB], user num [1] res[3000] [01-01 08:00:27 TUYA I][tal_thread.c:184] thread_create name:streamer,stackDepth:8192,totalstackDepth:4385280,priority:3 [01-01 08:00:27 TUYA E][tuya_ipc_streamer.c:1771] tstream init done [01-01 08:00:27 TUYA D][tuya_ipc_streamer.c:1667] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":0,\"profileId\":\"\",\"width\":2560,\"height\":1440},{\"streamType\":4,\"codecType\":2,\"sampleRate\":0,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":105,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}] [01-01 08:00:27 TUYA D][tuya_ipc_media_adapter.c:496] attach media info success! device:[0] channel:[0] cb:[0xb21b0] [01-01 08:00:27 TUYA D][tuya_ipc_upnp.c:436] tuya_ipc_upnp_init start [01-01 08:00:27 TUYA I][tal_thread.c:184] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:4450816,priority:2 [01-01 08:00:27 TUYA D][tuya_ipc_upnp.c:457] tuya_ipc_upnp_init success [1970-1-1 0:0:27.864 ty_sdk_adapter.c ty_sdk_media_stream_init(890) Debug] ty sdk media stream init result is 0 [01-01 08:00:27 TUYA D][simplekv.c:1126] read key:tuya_seed isFuzzy:0 skipCnt:0 [01-01 08:00:28 TUYA D][simplekv.c:1157] find key:0 tuya_seed [01-01 08:00:28 TUYA D][simplekv.c:1183] key:tuya_seed find value.Len:80 net cnt is 0..MQ_ONLINE is 0.. mq_status is 0.. recnt is 0 Type: 2, managed [1970-1-1 0:0:28.534 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [01-01 08:00:28 TUYA D][tuya_svc_lan.c:866] udp ip: 192.168.1.190 [01-01 08:00:28 TUYA D][tal_thread.c:203] Thread:ipc_upnp Exec Start. Set to Running Stat [01-01 08:00:28 TUYA D][iot_httpc.c:889] Post Data: {"version":"1.0","t":28} [01-01 08:00:28 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6ca27cadb2e9df92edwr0a&et=3&t=28&v=1.0&sign=c68b67b94bc5d999578bc571d2d4a083 [01-01 08:00:28 TUYA D][tal_thread.c:203] Thread:streamer Exec Start. Set to Running Stat [01-01 08:00:28 TUYA D][tuya_ipc_streamer.c:1475] __thread_streaming thread start [01-01 08:00:28 TUYA D][tuya_ipc_moto_mqtt.c:58] topic already booked! [01-01 08:00:28 TUYA D][mqtt_client.c:1932] packet id: 3 Type: 2, managed [1970-1-1 0:0:28.548 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [01-01 08:00:28 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [01-01 08:00:28 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [01-01 08:00:28 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [01-01 08:00:28 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [01-01 08:00:28 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [01-01 08:00:28 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [01-01 08:00:28 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [01-01 08:00:28 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:28 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:28 TUYA D][tuya_tls.c:1487] load tuya cert. [01-01 08:00:28 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [01-01 08:00:28 TUYA D][tuya_iot_com_api.c:254] tuya public url [01-01 08:00:28 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [01-01 08:00:28 TUYA D][tuya_devos_health.c:70] feed watchdog [01-01 08:00:28 TUYA D][iot_httpc.c:889] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.20, Mar 27 2023 16:07:23\"}","t":28} [01-01 08:00:28 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6ca27cadb2e9df92edwr0a&et=3&t=28&v=1.0&sign=dee535db1859953481904ef64bc744f0 Type: 2, managed [1970-1-1 0:0:28.826 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [01-01 08:00:28 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [01-01 08:00:28 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [01-01 08:00:28 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [01-01 08:00:28 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [01-01 08:00:28 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [01-01 08:00:28 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [01-01 08:00:28 TUYA D][tuya_tls.c:1487] load tuya cert. [01-01 08:00:28 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [01-01 08:00:28 TUYA D][tuya_iot_com_api.c:254] tuya public url [01-01 08:00:28 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake wait for time sync [1970-1-1 0:0:29.093 ty_user_event.c __event_task(4010) Debug] md_pause stop pre_md is:0 [1970-1-1 0:0:29.093 ty_user_md.c ty_user_md_clear_event(464) Debug] begin__! [1970-1-1 0:0:29.093 ty_user_md.c ty_user_md_clear_event(473) Debug] ty_user_md_clear_event !!! [1970-1-1 0:0:29.094 ty_user_event.c __event_task(3972) Debug] recv_msg type:1 [1970-1-1 0:0:29.094 ty_user_event.c __event_msg_proc(3066) Debug] >>>>>>>>>>> E_TY_MSG_MD_STOP [1970-1-1 0:0:29.094 ty_user_event.c __sdk_event_stop(1118) Debug] stop event type[0] eventId[0] [01-01 08:00:28 TUYA E][tuya_ipc_event.c:1135] event is already stopped [01-01 08:00:28 TUYA E][tuya_ipc_event.c:1441] stop event fail [1970-1-1 0:0:29.101 ty_user_hd.c ty_user_set_hd_upload_flag(530) Debug] begin__ [1970-1-1 0:0:29.102 ty_user_hd.c ty_user_set_hd_upload_flag(535) Debug] phdl->msg_upload_flag = 0 tkl_vi_detect_stop 0 0 [01-01 08:00:28 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [01-01 08:00:28 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-01 08:00:28 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [01-01 08:00:29 TUYA D][iot_httpc.c:590] Decode Rev:{"result":{"unitList":[{"protocol":"TCP","port":7000},{"protocol":"TCP","port":8080},{"protocol":"UDP","port":5000},{"protocol":"UDP","port":8000}]},"t":1683879654,"success":true} [05-12 16:20:54 TUYA D][tls_transporter.c:88] tls transporter close socket fd:35 [05-12 16:20:54 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:35 [05-12 16:20:54 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x47a198 [05-12 16:20:54 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:20:54 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:20:54 TUYA D][tuya_ipc_upnp.c:170] upnp get config success result:{ "unitList": [{ "protocol": "TCP", "port": 7000 }, { "protocol": "TCP", "port": 8080 }, { "protocol": "UDP", "port": 5000 }, { "protocol": "UDP", "port": 8000 }] } [05-12 16:20:54 TUYA D][tuya_ipc_upnp.c:292] tuya_ipc_upnp_start start [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10. [05-12 16:20:54 TUYA I][tal_thread.c:184] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:4516352,priority:3 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:7836 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 7836, in_port 7836 protocol:UDP, status:0 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:2912 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 2912, in_port 2912 protocol:UDP, status:0 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:6633 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 6633, in_port 6633 protocol:UDP, status:0 [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5! [05-12 16:20:54 TUYA D][tuya_ipc_upnp.c:313] tuya_ipc_upnp_start success [05-12 16:20:54 TUYA D][tuya_ipc_upnp.c:420] start upnp module success, exit thread [05-12 16:20:54 TUYA D][tal_thread.c:244] Del Thrd:ipc_upnp [05-12 16:20:54 TUYA D][tal_thread.c:95] del list not empty...deleting 0x4154cc, next 0x348e60 [05-12 16:20:54 TUYA D][tal_thread.c:98] Thread:ipc_upnp is still running.. [05-12 16:20:54 TUYA D][tal_thread.c:203] Thread:UPnP_PROC Exec Start. Set to Running Stat [1970-1-1 0:0:29.265 ty_wifi.c tkl_wifi_get_mac(579) Debug] tkl_wifi_get_mac[579] called [05-12 16:20:54 TUYA D][tal_thread.c:219] Thread:ipc_upnp Exec Finish. Set to Del Stat [05-12 16:20:54 TUYA D][tal_thread.c:95] del list not empty...deleting 0x4154cc, next 0x348e60 [05-12 16:20:54 TUYA D][tal_thread.c:103] Final Free Thread:ipc_upnp, is_self:1 [05-12 16:20:54 TUYA D][tal_thread.c:107] delay to delete thread self [05-12 16:20:54 TUYA D][tal_thread.c:118] finally delete thread self [05-12 16:20:54 TUYA D][tal_thread.c:73] real delete thread:0x0x4154d8 [1970-1-1 0:0:29.281 ty_wifi.c tkl_wifi_get_mac(599) Debug] WIFI Get MAC(1) 54-EF-33-80-1A-5D [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 54ef33801a5d [05-12 16:20:54 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [05-12 16:20:54 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:20:54 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:20:54 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [05-12 16:20:54 TUYA D][tuya_ipc_sdk_info.c:120] ipc get service time 1683879654 28800 [1970-1-1 0:0:29.942 ty_sys.c __ty_sys_loop(1483) Debug] get service time [1683879654-28800] [1970-1-1 0:0:29.943 ty_sys.c __ty_sys_loop(1485) Debug] set utc_time [1683879654],ty_utc [29] [2023-5-12 8:20:54.001 ty_sys_cfg.c __flush_file(128) Debug] totol len [2120 - 2120] crc[76715483] wait for time sync [2023-5-12 8:20:54.006 ty_sys_av.c __video_task(290) Info] ty_time_wait_sync end,type:1... [05-12 16:20:54 TUYA D][tuya_ring_buffer.c:770] ch0st0tr1 open with type 1 [2023-5-12 8:20:54.010 ty_sys_av.c __video_task(290) Info] ty_time_wait_sync end,type:0... [05-12 16:20:54 TUYA D][tuya_ring_buffer.c:770] ch0st0tr0 open with type 1 [2023-5-12 8:20:54.015 ty_sys_cfg.c __flush_file(153) Debug] update backup file [0-1683879654] [2023-5-12 16:20:54.025 ty_sys.c __ty_sys_loop(1499) Debug] set timezone [28800] dls [0] [2023-5-12 16:20:54.026 app_user_ptz.c ty_user_ptz_start(58) Debug] Start ptz init [2023-5-12 16:20:54.026 app_sys_ptz.c ty_sys_ptz_init(1904) Debug] patrol:1,track:0 [2023-5-12 16:20:54.027 app_sys_ptz.c ty_sys_ptz_init(1929) Debug] read preset info failed [2023-5-12 16:20:54.027 app_sys_ptz.c ty_sys_ptz_init(1955) Debug] read pre sleep pan failed [2023-5-12 16:20:54.027 app_sys_ptz.c ty_sys_ptz_init(1959) Debug] read pre sleep tilt failed [2023-5-12 16:20:54.028 hal_sys_ptz.c ty_bsp_motor_init(139) Debug] begin___ [2023-5-12 16:20:54.028 hal_sys_ptz.c ty_bsp_motor_init(151) Debug] end___ [2023-5-12 16:20:54.028 app_sys_ptz.c ty_sys_ptz_msg_start(1852) Debug] __begin [2023-5-12 16:20:54.029 app_sys_ptz.c ty_sys_ptz_move_sch_start(1511) Debug] __begin [2023-5-12 16:20:54.030 ty_user_event.c __event_task(3972) Debug] recv_msg type:208 [05-12 16:20:54 TUYA D][preset_operation.c:249] get preset config from cloud [05-12 16:20:54 TUYA D][preset_operation.c:96] interface tuya.device.ipc.memory.point.list, message {"v":2,"devId":"6ca27cadb2e9df92edwr0a"} [05-12 16:20:54 TUYA D][iot_httpc.c:889] Post Data: {"v":2,"devId":"6ca27cadb2e9df92edwr0a","t":1683879654} [05-12 16:20:54 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.memory.point.list&devId=6ca27cadb2e9df92edwr0a&et=3&t=1683879654&v=1.0&sign=45c1b36d9f0be0489014de926c84deb6 [2023-5-12 16:20:54.033 ty_sdk_adapter.c ty_sdk_start_stream_stor(849) Debug] local storage skills 201 Init tuya_ipc_ss_init [05-12 16:20:54 TUYA D][tuya_ipc_stream_storage.c:2191] Init stream_storage.base_path:/mnt/sdcard/ v:4 a:105, max event per day 2000 [05-12 16:20:54 TUYA D][tuya_ipc_stream_storage.c:480] p 0x2b1f30 video max 0 av max [05-12 16:20:54 TUYA D][tuya_ipc_stream_storage.c:482] stream_enable:1 1 1 [05-12 16:20:54 TUYA D][tuya_ipc_stream_storage.c:483] fps:20 [05-12 16:20:54 TUYA D][tuya_ipc_stream_storage.c:484] gop:40 [05-12 16:20:54 TUYA D][tuya_ipc_stream_storage.c:485] bitrate:1536 kbps [05-12 16:20:54 TUYA D][tuya_ipc_stream_storage.c:486] video_main_width:2560 [2023-5-12 16:20:54.035 app_sys_ptz.c __sys_move_proc(1477) Debug] move sch proc begin Type: 2, managed [2023-5-12 16:20:54.703 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [2023-5-12 16:20:54.035 app_sys_ptz.c __sys_msg_proc(1828) Debug] msg proc begin Type: 2, managed [2023-5-12 16:20:54.036 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16503 [2023-5-12 16:20:54.506 ty_sys_av.c __audio_task(197) Info] ty_time_wait_sync end,type:0... [rts camera] : <__recycle_audio_buffer, 260>Audio buffer use 13800ms [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:487] video_main_height:1440 [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:488] video_freq:0 [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:489] video_codec:4 [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:491] audio_codec:105 [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:492] audio_sample:8000 [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:493] audio_databits:16 [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:494] audio_channel:1 [05-12 16:20:55 TUYA D][tuya_ipc_media_adapter.c:496] attach media info success! device:[0] channel:[0] cb:[0x42660] [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:2216] to start disk monitor [05-12 16:20:55 TUYA I][tal_thread.c:184] thread_create name:disk_monitor,stackDepth:8192,totalstackDepth:4524544,priority:3 [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:2291] __album init [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:2312] __album ok [05-12 16:20:55 TUYA D][mqtt_client.c:1932] packet id: 4 [05-12 16:20:55 TUYA D][iot_httpc.c:590] Decode Rev:{"result":true,"t":1683879655,"success":true} [05-12 16:20:55 TUYA D][tls_transporter.c:88] tls transporter close socket fd:36 [05-12 16:20:55 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:36 [05-12 16:20:55 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x48a3b8 [05-12 16:20:55 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:20:55 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:20:55 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [05-12 16:20:55 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [05-12 16:20:55 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [05-12 16:20:55 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [05-12 16:20:55 TUYA D][tuya_ring_buffer.c:770] ch0st0tr9 open with type 1 [05-12 16:20:55 TUYA D][tuya_ipc_stream_storage.c:2336] stream storage task init success [05-12 16:20:55 TUYA E][tuya_ipc_stream_storage.c:2062] the ss mgr not inited, but msg buffered: set mode 2 [2023-5-12 16:20:54.711 ty_sdk_adapter.c ty_sdk_start_stream_stor(865) Debug] local storage init result is 0 mode:2 on:1 [05-12 16:20:55 TUYA D][tuya_ipc_cloud_storage.c:2358] init ipc cloud storage begin [05-12 16:20:55 TUYA D][simplekv.c:1126] read key:md5_encrypt_key isFuzzy:0 skipCnt:0 [05-12 16:20:55 TUYA D][simplekv.c:1154] no key find [05-12 16:20:55 TUYA D][simplekv.c:1196] __read_kv_raw fail. -3 [05-12 16:20:55 TUYA D][simplekv.c:1234] __read_kv_with_decode fail. -3 [05-12 16:20:55 TUYA E][tuya_ipc_cloud_storage.c:503] iot_wd_common_read fails md5_encrypt_key -6 [05-12 16:20:55 TUYA E][tuya_ipc_cloud_storage.c:582] read key_key file failed. [05-12 16:20:55 TUYA D][tuya_ipc_cloud_storage.c:2218] __check_md5_encrypt_key fail, need update from server [05-12 16:20:55 TUYA D][simplekv.c:1126] read key:restriction_cfg isFuzzy:0 skipCnt:0 [05-12 16:20:55 TUYA D][simplekv.c:1157] find key:15 restriction_cfg [05-12 16:20:55 TUYA D][simplekv.c:1183] key:restriction_cfg find value.Len:112 [05-12 16:20:55 TUYA D][cloud_operation.c:2032] cloud get spec: [0] [05-12 16:20:55 TUYA D][tuya_ipc_cloud_storage.c:1089] case 1 get slice duration from cloud or db 10 [05-12 16:20:56 TUYA D][tuya_ipc_cloud_storage.c:1140] cloud storage seize 2338688 bytes memory for media data, each slice 10 seconds [05-12 16:20:56 TUYA I][tal_thread.c:184] thread_create name:cloud_storage0,stackDepth:65536,totalstackDepth:4590080,priority:3 [05-12 16:20:56 TUYA D][tuya_ipc_media_adapter.c:496] attach media info success! device:[0] channel:[0] cb:[0x40ed4] [05-12 16:20:56 TUYA D][tuya_ipc_cloud_storage.c:2398] init cloud storage success [2023-5-12 16:20:54.806 app_sys_ptz.c __do_self_check(1259) Debug] pan_check [rts camera] : <__recycle_audio_buffer, 260>Audio buffer use 13791ms [05-12 16:20:56 TUYA D][tal_thread.c:203] Thread:disk_monitor Exec Start. Set to Running Stat [05-12 16:20:56 TUYA D][tuya_ipc_stream_storage.c:1736] SD task begin___ [05-12 16:20:56 TUYA D][tuya_ipc_stream_storage.c:1745] report sd status 0 -> 5 [2023-5-12 16:20:55.380 ty_sys_sdcard.c ty_sys_sdcard_status_changed(267) Debug] sdcard_status_changed to status 5[05-12 16:20:56 TUYA E][tuya_ipc_stream_storage.c:2064] storage not inited [05-12 16:20:56 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [05-12 16:20:56 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [05-12 16:20:56 TUYA D][tuya_tls.c:1487] load tuya cert. [05-12 16:20:56 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [05-12 16:20:56 TUYA D][tuya_iot_com_api.c:254] tuya public url [05-12 16:20:56 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [05-12 16:20:56 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:20:56 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:20:56 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:20:56 TUYA D][mqtt_client.c:1932] packet id: 5 [2023-5-12 16:20:55.379 ty_user_cmd_api.c ty_cmd_sync_to_cloud(53) Debug] update dp to cloud [2023-5-12 16:20:55.385 ty_user_cmd_dp_handler.c IPC_APP_get_sleep_mode(121) Debug] curr sleep_mode:0 [05-12 16:20:56 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:56 TUYA D][smart_frame.c:407] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:20:56 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:0 [05-12 16:20:56 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:56 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"105":false} [05-12 16:20:56 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:677 Q:1 Data:{"dps":{"105":false}} [05-12 16:20:56 TUYA D][mqtt_client.c:1932] packet id: 6 [2023-5-12 16:20:55.388 ty_user_cmd_dp_handler.c IPC_APP_get_alarm_function_onoff(423) Debug] curr alarm_on_off:1 [05-12 16:20:56 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:56 TUYA D][smart_frame.c:407] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:20:56 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:20:56 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:56 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"134":true} [05-12 16:20:56 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:678 Q:1 Data:{"dps":{"134":true}} [05-12 16:20:56 TUYA D][mqtt_client.c:1932] packet id: 7 [05-12 16:20:56 TUYA D][smart_frame.c:3546] rept chan:1 [rts camera] : <__recycle_audio_buffer, 260>Audio buffer use 14425ms [05-12 16:20:56 TUYA D][tal_thread.c:203] Thread:cloud_storage0 Exec Start. Set to Running Stat [05-12 16:20:56 TUYA D][tuya_ipc_cloud_storage.c:1793] [] cloud storage task start [05-12 16:20:56 TUYA D][tuya_ring_buffer.c:770] ch0st0tr0 open with type 0 [05-12 16:20:56 TUYA D][tuya_ring_buffer.c:770] ch0st0tr9 open with type 0 [05-12 16:20:56 TUYA D][iot_httpc.c:889] Post Data: {"type":"MediaStor","t":1683879656} [05-12 16:20:56 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6ca27cadb2e9df92edwr0a&et=3&t=1683879656&v=3.0&sign=3a312d4db5830b2157a07649645c855e [rts camera] : timestamp: 33261350, pre_timestamp: 33379522 [rts camera] : timestamp: 33091720, pre_timestamp: 33419522 [rts camera] : timestamp: 32781205, pre_timestamp: 33459522 [rts camera] : timestamp: 32440995, pre_timestamp: 33499522 [rts camera] : timestamp: 32133704, pre_timestamp: 33539522 [05-12 16:20:56 TUYA D][smart_frame.c:407] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:3 [05-12 16:20:56 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:56 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"106":"2"} [05-12 16:20:56 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:679 Q:1 Data:{"dps":{"106":"2"}} [tkl_ai_get_frame][198] rts_av_recv_block -37 [05-12 16:20:56 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:20:56 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:20:56 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [05-12 16:20:56 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:20:56 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:20:56 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:20:56 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:20:56 TUYA D][mqtt_client.c:1932] packet id: 8 [2023-5-12 16:20:56.065 ty_user_cmd_dp_handler.c IPC_APP_get_night_mode(402) Debug] curr dn mode:0 [05-12 16:20:56 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:56 TUYA D][smart_frame.c:407] dp<108> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:3 [05-12 16:20:56 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:56 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"108":"0"} [05-12 16:20:56 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:680 Q:1 Data:{"dps":{"108":"0"}} [05-12 16:20:56 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0 [05-12 16:20:56 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:105, curr_t:1683879656, rept_cnt:1. [05-12 16:20:56 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:105, curr_t:1683879656, rept_cnt:0. [05-12 16:20:56 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:105, curr_t:1683879656, rept_cnt:0. [05-12 16:20:56 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:20:56 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0 [05-12 16:20:56 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:134, curr_t:1683879656, rept_cnt:1. [05-12 16:20:56 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:134, curr_t:1683879656, rept_cnt:0. [05-12 16:20:56 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:134, curr_t:1683879656, rept_cnt:0. [05-12 16:20:56 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:20:56 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:20:56 TUYA D][miniwget.c:482] send ok,get response [05-12 16:20:56 TUYA D][mqtt_client.c:1932] packet id: 9 Type: 2, managed [rts camera] : timestamp: 31892336, pre_timestamp: 33579522 Type: 2, managed [2023-5-12 16:20:56.085 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:20:56 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [05-12 16:20:56 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [05-12 16:20:56 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [05-12 16:20:57 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [rts camera] : timestamp: 31726582, pre_timestamp: 33619522 [rts camera] : timestamp: 31828616, pre_timestamp: 33659522 [rts camera] : timestamp: 31937090, pre_timestamp: 33699522 [rts camera] : timestamp: 32046991, pre_timestamp: 33739522 [rts camera] : timestamp: 32148491, pre_timestamp: 33779522 [05-12 16:20:57 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"106":"2"}}, mqtt async dp cb:0 [05-12 16:20:57 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:106, curr_t:1683879657, rept_cnt:1. [05-12 16:20:57 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:106, curr_t:1683879657, rept_cnt:0. [05-12 16:20:57 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:106, curr_t:1683879657, rept_cnt:0. [05-12 16:20:57 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:20:57 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"108":"0"}}, mqtt async dp cb:0 [05-12 16:20:57 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:108, curr_t:1683879657, rept_cnt:1. [05-12 16:20:57 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:108, curr_t:1683879657, rept_cnt:0. [05-12 16:20:57 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:108, curr_t:1683879657, rept_cnt:0. [05-12 16:20:57 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [tkl_ai_get_frame][198] rts_av_recv_block -37 [05-12 16:20:57 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:20:57 TUYA D][iot_httpc.c:590] Decode Rev:{"result":[],"t":1683879657,"success":true} [05-12 16:20:57 TUYA D][tls_transporter.c:88] tls transporter close socket fd:36 [05-12 16:20:57 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:36 [05-12 16:20:57 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x45e0c0 [05-12 16:20:57 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:20:57 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:20:57 TUYA D][preset_operation.c:301] total preset num:0 [2023-5-12 16:20:56.761 ty_user_event.c __event_task(3972) Debug] recv_msg type:411 [2023-5-12 16:20:56.761 ty_user_event.c __event_msg_proc(3628) Debug] report sd status[5] [05-12 16:20:57 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:20:57 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [05-12 16:20:57 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [05-12 16:20:57 TUYA D][tuya_tls.c:1487] load tuya cert. [05-12 16:20:57 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [05-12 16:20:57 TUYA D][tuya_iot_com_api.c:254] tuya public url [05-12 16:20:57 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake Type: 2, managed [2023-5-12 16:20:56.782 app_sys_ptz.c __sys_msg_proc(1836) Debug] recv msg type = 208 [2023-5-12 16:20:56.783 app_sys_ptz.c __do_ptz_preset_sync(1366) Debug] sync finish [rts camera] : timestamp: 32237023, pre_timestamp: 33819522 [05-12 16:20:57 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [rts camera] : timestamp: 32311171, pre_timestamp: 33859522 [05-12 16:20:57 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:20:57 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:20:57 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [05-12 16:20:57 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [rts camera] : timestamp: 32372427, pre_timestamp: 33899522 [rts camera] : timestamp: 32423685, pre_timestamp: 33939522 [05-12 16:20:57 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [2023-5-12 16:20:57.282 ty_user_event.c __event_task(4036) Debug] sd card report dp [5][05-12 16:20:58 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:58 TUYA D][smart_frame.c:407] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:1 [05-12 16:20:58 TUYA D][smart_frame.c:425] dp_cntl value:0, dp_data value:5 [05-12 16:20:58 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:58 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"110":5} [05-12 16:20:58 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:681 Q:1 Data:{"dps":{"110":5}} [05-12 16:20:58 TUYA D][mqtt_client.c:1932] packet id: 10 [rts camera] : timestamp: 32467036, pre_timestamp: 33979522 [rts camera] : timestamp: 32669373, pre_timestamp: 34019522 [rts camera] : timestamp: 32822719, pre_timestamp: 34059522 [rts camera] : timestamp: 32938955, pre_timestamp: 34099522 [rts camera] : timestamp: 33023304, pre_timestamp: 34139522 [05-12 16:20:58 TUYA D][iot_httpc.c:590] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1683879657,"success":true} [05-12 16:20:58 TUYA D][tls_transporter.c:88] tls transporter close socket fd:37 [05-12 16:20:58 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:37 [05-12 16:20:58 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x45e0c0 [05-12 16:20:58 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER Type: 2, managed [2023-5-12 16:20:57.490 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [tkl_ai_get_frame][198] rts_av_recv_block -37 [05-12 16:20:58 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:20:58 TUYA E][cloud_operation.c:510] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED [05-12 16:20:58 TUYA D][tuya_ipc_cloud_storage.c:665] order expire or remote server error [05-12 16:20:58 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:20:58 TUYA D][mqtt_client.c:1932] packet id: 11 [rts camera] : timestamp: 33082724, pre_timestamp: 34179522 [05-12 16:20:58 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [rts camera] : timestamp: 33125155, pre_timestamp: 34219522 [05-12 16:20:58 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:20:58 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0 [05-12 16:20:58 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:110, curr_t:1683879658, rept_cnt:1. [05-12 16:20:58 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:110, curr_t:1683879658, rept_cnt:0. [05-12 16:20:58 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:110, curr_t:1683879658, rept_cnt:0. [05-12 16:20:58 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:20:58 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:20:58 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:20:58 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [rts camera] : timestamp: 33157219, pre_timestamp: 34259522 [05-12 16:20:58 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [rts camera] : timestamp: 33184303, pre_timestamp: 34299522 [05-12 16:20:58 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [rts camera] : timestamp: 33210043, pre_timestamp: 34339522 [05-12 16:20:58 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [rts camera] : timestamp: 33236982, pre_timestamp: 34379522 [rts camera] : timestamp: 33266379, pre_timestamp: 34419522 [rts camera] : timestamp: 33298502, pre_timestamp: 34459522 [rts camera] : timestamp: 33333286, pre_timestamp: 34499522 [rts camera] : timestamp: 33370371, pre_timestamp: 34539522 [rts camera] : timestamp: 33409158, pre_timestamp: 34579522 [rts camera] : timestamp: 33449241, pre_timestamp: 34619522 [rts camera] : timestamp: 33489867, pre_timestamp: 34659522 [05-12 16:20:58 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:20:58 TUYA N][tuya_svc_timer_task.c:888] Update Timer from cloud [05-12 16:20:58 TUYA D][iot_httpc.c:889] Post Data: {"devId":"6ca27cadb2e9df92edwr0a","lastFetchTime":"0","t":1683879658} [05-12 16:20:58 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.timer.count&devId=6ca27cadb2e9df92edwr0a&et=3&t=1683879658&v=4.2&sign=69612593dbef0c3c71ba9f2c3dc5e3bd [2023-5-12 16:20:57.898 ty_user_event.c __event_task(3963) Debug] loop_cnt = 100 step = 3067 p2p num = 0 [rts camera] : timestamp: 33531377, pre_timestamp: 34699522 [rts camera] : timestamp: 33631736, pre_timestamp: 34739522 [rts camera] : timestamp: 33708949, pre_timestamp: 34779522 [rts camera] : timestamp: 33774361, pre_timestamp: 34819522 [rts camera] : timestamp: 33829490, pre_timestamp: 34859522 [05-12 16:20:59 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:59 TUYA D][smart_frame.c:407] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:20:59 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:20:59 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:59 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"104":true} [05-12 16:20:59 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:682 Q:1 Data:{"dps":{"104":true}} Type: 2, managed [tkl_ai_get_frame][198] rts_av_recv_block -37 [05-12 16:20:59 TUYA D][mqtt_client.c:1932] packet id: 12 [05-12 16:20:59 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:59 TUYA D][smart_frame.c:407] dp<198> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:20:59 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:20:59 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:59 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"198":true} [05-12 16:20:59 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:683 Q:1 Data:{"dps":{"198":true}} [05-12 16:20:59 TUYA D][mqtt_client.c:1932] packet id: 13 [2023-5-12 16:20:58.333 ty_user_cmd_dp_handler.c IPC_APP_get_face_framing_onoff(325) Info] get face_framing_on_off:1 [05-12 16:20:59 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:59 TUYA E][smart_frame.c:554] devid:(null) dparr[0]:189 not find [05-12 16:20:59 TUYA D][smart_frame.c:613] no vaild dp to rept [05-12 16:20:59 TUYA D][smart_frame.c:3559] dp compose null, ret:-3585 [05-12 16:20:59 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:59 TUYA D][smart_frame.c:407] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:20:59 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:0 [05-12 16:20:59 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:59 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"103":false} [05-12 16:20:59 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:684 Q:1 Data:{"dps":{"103":false}} Type: 2, managed [2023-5-12 16:20:58.339 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:20:59 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [05-12 16:20:59 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [05-12 16:20:59 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [05-12 16:20:59 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [05-12 16:20:59 TUYA D][mqtt_client.c:1932] packet id: 14 [2023-5-12 16:20:58.348 ty_user_cmd_dp_handler.c IPC_APP_get_sd_record_onoff(760) Debug] curr sd_record_on_off:1 [05-12 16:20:59 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:59 TUYA D][smart_frame.c:407] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:20:59 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:20:59 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:59 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"150":true} [05-12 16:20:59 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:685 Q:1 Data:{"dps":{"150":true}} net cnt is 1..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [rts camera] : timestamp: 33876922, pre_timestamp: 34899522 [rts camera] : timestamp: 34129412, pre_timestamp: 34939522 [rts camera] : timestamp: 34321493, pre_timestamp: 34979522 [rts camera] : timestamp: 34464620, pre_timestamp: 35019522 [rts camera] : timestamp: 34565316, pre_timestamp: 35059522 [05-12 16:20:59 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [05-12 16:20:59 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [05-12 16:20:59 TUYA D][tuya_tls.c:1487] load tuya cert. [05-12 16:20:59 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [05-12 16:20:59 TUYA D][tuya_iot_com_api.c:254] tuya public url [05-12 16:20:59 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [tkl_ai_get_frame][198] rts_av_recv_block -37 [05-12 16:20:59 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0 [05-12 16:20:59 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:104, curr_t:1683879659, rept_cnt:1. [05-12 16:20:59 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:104, curr_t:1683879659, rept_cnt:0. [05-12 16:20:59 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:104, curr_t:1683879659, rept_cnt:0. [05-12 16:20:59 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:20:59 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"198":true}}, mqtt async dp cb:0 [05-12 16:20:59 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:198, curr_t:1683879659, rept_cnt:1. [05-12 16:20:59 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:198, curr_t:1683879659, rept_cnt:0. [05-12 16:20:59 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:198, curr_t:1683879659, rept_cnt:0. [05-12 16:20:59 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:20:59 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0 [05-12 16:20:59 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:103, curr_t:1683879659, rept_cnt:1. [05-12 16:20:59 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:103, curr_t:1683879659, rept_cnt:0. [05-12 16:20:59 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:103, curr_t:1683879659, rept_cnt:0. [05-12 16:20:59 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 Type: 2, managed [05-12 16:20:59 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:20:59 TUYA D][mqtt_client.c:1932] packet id: 15 [2023-5-12 16:20:59.024 ty_user_cmd_dp_handler.c IPC_APP_get_sd_record_mode(802) Debug] get curr sd_record_mode:1 [05-12 16:20:59 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:59 TUYA D][smart_frame.c:407] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:3 [05-12 16:20:59 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:59 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"151":"2"} [05-12 16:20:59 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:686 Q:1 Data:{"dps":{"151":"2"}} [05-12 16:20:59 TUYA D][mqtt_client.c:1932] packet id: 16 [2023-5-12 16:20:59.028 ty_user_cmd_dp_handler.c IPC_APP_get_light_onoff(165) Debug] get light_on_off:1 [05-12 16:20:59 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:20:59 TUYA D][smart_frame.c:407] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:20:59 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:20:59 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:20:59 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"101":true} [05-12 16:20:59 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:687 Q:1 Data:{"dps":{"101":true}} [2023-5-12 16:20:59.495 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [200] run_step [1039] [rts camera] : timestamp: 34632882, pre_timestamp: 35099522 [rts camera] : timestamp: 34884624, pre_timestamp: 35139522 [rts camera] : timestamp: 35066209, pre_timestamp: 35179522 [rts camera] : timestamp: 35194502, pre_timestamp: 35219522 [05-12 16:21:00 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [tkl_ai_get_frame][198] rts_av_recv_block -37 [05-12 16:21:00 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:21:00 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:21:00 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [05-12 16:21:00 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0 [05-12 16:21:00 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:150, curr_t:1683879660, rept_cnt:1. [05-12 16:21:00 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:150, curr_t:1683879660, rept_cnt:0. [05-12 16:21:00 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:150, curr_t:1683879660, rept_cnt:0. [05-12 16:21:00 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:00 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"151":"2"}}, mqtt async dp cb:0 [05-12 16:21:00 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:151, curr_t:1683879660, rept_cnt:1. [05-12 16:21:00 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:151, curr_t:1683879660, rept_cnt:0. [05-12 16:21:00 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:151, curr_t:1683879660, rept_cnt:0. [05-12 16:21:00 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:00 TUYA D][mqtt_client.c:1932] packet id: 17 [05-12 16:21:00 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:00 TUYA D][smart_frame.c:407] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:00 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:0 [05-12 16:21:00 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:00 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"159":false} [05-12 16:21:00 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:688 Q:1 Data:{"dps":{"159":false}} [05-12 16:21:00 TUYA D][mqtt_client.c:1932] packet id: 18 [2023-5-12 16:20:59.705 ty_user_cmd_dp_handler.c IPC_APP_get_alarm_zone_onoff(468) Debug] #####get alarm_zone_on_off [2023-5-12 16:20:59.705 ty_user_cmd_dp_handler.c IPC_APP_get_alarm_zone_onoff(470) Debug] IPC_APP_get_alarm_zone_onoff 470 step [2023-5-12 16:20:59.706 ty_user_cmd_dp_handler.c IPC_APP_get_alarm_zone_onoff(472) Debug] IPC_APP_get_alarm_zone_onoff 472 step [05-12 16:21:00 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:00 TUYA D][smart_frame.c:407] dp<168> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:00 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:0 [05-12 16:21:00 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:00 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"168":false} [05-12 16:21:00 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:689 Q:1 Data:{"dps":{"168":false}} [05-12 16:21:00 TUYA D][mqtt_client.c:1932] packet id: 19 [2023-5-12 16:20:59.710 ty_user_cmd_dp_handler.c IPC_APP_get_alarm_zone_draw(567) Debug] [IPC_APP_get_alarm_zone_draw][567] alarm zone[{"num":1,"region0":{"x":0,"y":0,"xlen":100,"ylen":100}}] [05-12 16:21:00 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:00 TUYA D][smart_frame.c:407] dp<169> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:2 [05-12 16:21:01 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:01 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"169":"{\"num\":1,\"region0\":{\"x\":0,\"y\":0,\"xlen\":100,\"ylen\":100}}"} [05-12 16:21:01 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:690 Q:1 Data:{"dps":{"169":"{\"num\":1,\"region0\":{\"x\":0,\"y\":0,\"xlen\":100,\"ylen\":100}}"}} Type: 2, managed [05-12 16:21:01 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:01 TUYA D][iot_httpc.c:590] Decode Rev:{"result":{"devId":"6ca27cadb2e9df92edwr0a","code":"200","count":0,"lastFetchTime":0},"t":1683879660,"success":true} [05-12 16:21:01 TUYA D][tls_transporter.c:88] tls transporter close socket fd:37 [05-12 16:21:01 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:37 [05-12 16:21:01 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x45e0c0 [05-12 16:21:01 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:21:01 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0 [05-12 16:21:01 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:101, curr_t:1683879661, rept_cnt:1. [05-12 16:21:01 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:101, curr_t:1683879661, rept_cnt:0. [05-12 16:21:01 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:101, curr_t:1683879661, rept_cnt:0. [05-12 16:21:01 TUYA D][mqtt_client.c:1932] packet id: 20 [2023-5-12 16:21:0.386 ty_user_cmd_dp_handler.c IPC_APP_get_alarm_multi_zone_draw(683) Debug] ZoneNum = 1 [05-12 16:21:01 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:01 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0 [05-12 16:21:01 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:159, curr_t:1683879661, rept_cnt:1. [05-12 16:21:01 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:159, curr_t:1683879661, rept_cnt:0. [05-12 16:21:01 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:159, curr_t:1683879661, rept_cnt:0. [05-12 16:21:01 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:01 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"168":false}}, mqtt async dp cb:0 [05-12 16:21:01 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:168, curr_t:1683879661, rept_cnt:1. [05-12 16:21:01 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:168, curr_t:1683879661, rept_cnt:0. [05-12 16:21:01 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:168, curr_t:1683879661, rept_cnt:0. [2023-5-12 16:21:0.386 ty_user_cmd_dp_handler.c IPC_APP_get_alarm_multi_zone_draw(715) Debug] alarm zone[[{"ispoly":0,"points":[0,0,100,0,100,100,0,100]}]] [05-12 16:21:01 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:01 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:01 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:21:01 TUYA D][tuya_svc_timer_task.c:506] time eq skip:0 [05-12 16:21:01 TUYA D][iot_httpc.c:889] Post Data: {"subId":null,"t":1683879661} [05-12 16:21:01 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upgrade.silent.get&devId=6ca27cadb2e9df92edwr0a&et=3&t=1683879661&v=4.4&sign=5d055d4ad64a5d79f4328eb94a8e3670 [05-12 16:21:01 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:01 TUYA D][smart_frame.c:747] para err:255 [05-12 16:21:01 TUYA D][smart_frame.c:3559] dp compose null, ret:-6 [2023-5-12 16:21:0.398 ty_user_cmd_dp_utils.c ty_cmd_respone_dp_raw(295) Debug] report dp 255 raw failed, ret= -6 [05-12 16:21:01 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:01 TUYA D][smart_frame.c:407] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:01 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:21:01 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:01 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"170":true} [05-12 16:21:01 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:691 Q:1 Data:{"dps":{"170":true}} Type: 2, managed [2023-5-12 16:21:1.066 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [05-12 16:21:01 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:01 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"169":"{\"num\":1,\"region0\":{\"x\":0,\"y\":0,\"xlen\":100,\"ylen\":100}}"}}, mqtt async dp cb:0 [05-12 16:21:01 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:169, curr_t:1683879661, rept_cnt:1. [05-12 16:21:01 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:169, curr_t:1683879661, rept_cnt:0. [05-12 16:21:01 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:169, curr_t:1683879661, rept_cnt:0. [05-12 16:21:01 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:01 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [05-12 16:21:01 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [05-12 16:21:01 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [05-12 16:21:01 TUYA D][mqtt_client.c:1932] packet id: 21 [2023-5-12 16:21:1.072 ty_user_cmd_dp_handler.c IPC_APP_get_track_enable(1229) Debug] track_enable 0 [05-12 16:21:01 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:01 TUYA D][smart_frame.c:407] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:01 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:0 [05-12 16:21:01 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:01 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"161":false} [05-12 16:21:01 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:692 Q:1 Data:{"dps":{"161":false}} [05-12 16:21:01 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:01 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [05-12 16:21:01 TUYA D][mqtt_client.c:1932] packet id: 22 [2023-5-12 16:21:1.082 ty_user_cmd_dp_handler.c IPC_APP_get_patrol_switch(1268) Debug] patrol_switch 1 [05-12 16:21:01 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:01 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:01 TUYA D][smart_frame.c:407] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:01 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:21:01 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:01 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"174":true} [05-12 16:21:01 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:693 Q:1 Data:{"dps":{"174":true}} [05-12 16:21:01 TUYA D][mqtt_client.c:1932] packet id: 23 [05-12 16:21:01 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:01 TUYA D][smart_frame.c:407] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:3 [05-12 16:21:01 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:01 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"175":"0"} [05-12 16:21:01 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:01 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:694 Q:1 Data:{"dps":{"175":"0"}} [05-12 16:21:01 TUYA D][mqtt_client.c:1932] packet id: 24 [05-12 16:21:01 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [05-12 16:21:01 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [05-12 16:21:01 TUYA D][tuya_tls.c:1487] load tuya cert. [05-12 16:21:02 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [05-12 16:21:02 TUYA D][tuya_iot_com_api.c:254] tuya public url [05-12 16:21:02 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [05-12 16:21:02 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"170":true}}, mqtt async dp cb:0 [05-12 16:21:02 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:170, curr_t:1683879662, rept_cnt:1. [05-12 16:21:02 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:170, curr_t:1683879662, rept_cnt:0. [05-12 16:21:02 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:170, curr_t:1683879662, rept_cnt:0. [05-12 16:21:02 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:02 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"161":false}}, mqtt async dp cb:0 [05-12 16:21:02 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:161, curr_t:1683879662, rept_cnt:1. [05-12 16:21:02 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:161, curr_t:1683879662, rept_cnt:0. [05-12 16:21:02 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:161, curr_t:1683879662, rept_cnt:0. [05-12 16:21:02 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:02 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"174":true}}, mqtt async dp cb:0 [05-12 16:21:02 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:174, curr_t:1683879662, rept_cnt:1. [05-12 16:21:02 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:174, curr_t:1683879662, rept_cnt:0. [05-12 16:21:02 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:174, curr_t:1683879662, rept_cnt:0. [05-12 16:21:02 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:02 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:02 TUYA D][smart_frame.c:407] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:3 [05-12 16:21:02 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:02 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"176":"1"} [05-12 16:21:02 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:695 Q:1 Data:{"dps":{"176":"1"}} [05-12 16:21:02 TUYA D][mqtt_client.c:1932] packet id: 25 [2023-5-12 16:21:1.780 ty_user_cmd_dp_handler.c IPC_APP_get_patrol_time(1338) Debug] lenth =100 [05-12 16:21:02 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:02 TUYA D][smart_frame.c:407] dp<177> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:2 [05-12 16:21:02 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:02 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"177":"{\"t_start\":\"00:00\",\"t_end\":\"01:00\"}"} [05-12 16:21:02 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:696 Q:1 Data:{"dps":{"177":"{\"t_start\":\"00:00\",\"t_end\":\"01:00\"}"}} [05-12 16:21:02 TUYA D][mqtt_client.c:1932] packet id: 26 [05-12 16:21:02 TUYA D][smart_frame.c:3546] rept chan:1 Type: 2, managed [05-12 16:21:02 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:02 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"175":"0"}}, mqtt async dp cb:0 [05-12 16:21:02 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:175, curr_t:1683879662, rept_cnt:1. [05-12 16:21:02 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:175, curr_t:1683879662, rept_cnt:0. [05-12 16:21:02 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:175, curr_t:1683879662, rept_cnt:0. [05-12 16:21:02 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:02 TUYA D][smart_frame.c:407] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:02 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:21:02 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:03 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"139":true} [05-12 16:21:03 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:697 Q:1 Data:{"dps":{"139":true}} Type: 2, managed [2023-5-12 16:21:2.457 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:03 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:03 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:21:03 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:21:03 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [05-12 16:21:03 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"176":"1"}}, mqtt async dp cb:0 [05-12 16:21:03 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:176, curr_t:1683879663, rept_cnt:1. [05-12 16:21:03 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:176, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:176, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][tuya_ipc_p2p.c:4274] session detect run [05-12 16:21:03 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:03 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"177":"{\"t_start\":\"00:00\",\"t_end\":\"01:00\"}"}}, mqtt async dp cb:0 [05-12 16:21:03 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:177, curr_t:1683879663, rept_cnt:1. [05-12 16:21:03 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:177, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:177, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:03 TUYA D][mqtt_client.c:1932] packet id: 27 [05-12 16:21:03 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:03 TUYA D][smart_frame.c:407] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:3 [05-12 16:21:03 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:03 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"140":"0"} [05-12 16:21:03 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:698 Q:1 Data:{"dps":{"140":"0"}} [05-12 16:21:03 TUYA D][mqtt_client.c:1932] packet id: 28 [05-12 16:21:03 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:03 TUYA D][smart_frame.c:407] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:1 [05-12 16:21:03 TUYA D][smart_frame.c:425] dp_cntl value:0, dp_data value:8 [05-12 16:21:03 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:03 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"160":8} [05-12 16:21:03 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:699 Q:1 Data:{"dps":{"160":8}} [05-12 16:21:03 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:03 TUYA D][mqtt_client.c:1932] packet id: 29 [2023-5-12 16:21:2.480 ty_user_cmd_dp_handler.c IPC_APP_get_onvif_switch(2218) Debug] curr onvif_switch:1 [05-12 16:21:03 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:03 TUYA D][smart_frame.c:407] dp<237> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:03 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:21:03 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:03 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"237":true} [05-12 16:21:03 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:700 Q:1 Data:{"dps":{"237":true}} [05-12 16:21:03 TUYA D][mqtt_client.c:1932] packet id: 30 [05-12 16:21:03 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:03 TUYA D][smart_frame.c:407] dp<239> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:03 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:21:03 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:03 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"239":true} [05-12 16:21:03 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:701 Q:1 Data:{"dps":{"239":true}} Type: 2, managed [05-12 16:21:03 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"139":true}}, mqtt async dp cb:0 [05-12 16:21:03 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:139, curr_t:1683879663, rept_cnt:1. [05-12 16:21:03 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:139, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:139, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:03 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"140":"0"}}, mqtt async dp cb:0 [05-12 16:21:03 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:140, curr_t:1683879663, rept_cnt:1. [05-12 16:21:03 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:140, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:140, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:03 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"160":8}}, mqtt async dp cb:0 [05-12 16:21:03 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:160, curr_t:1683879663, rept_cnt:1. [05-12 16:21:03 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:160, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:160, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:03 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"237":true}}, mqtt async dp cb:0 [05-12 16:21:03 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:237, curr_t:1683879663, rept_cnt:1. [05-12 16:21:03 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:237, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:237, curr_t:1683879663, rept_cnt:0. [05-12 16:21:03 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:03 TUYA D][iot_httpc.c:590] Decode Rev:{"t":1683879663,"success":true} [05-12 16:21:03 TUYA D][tls_transporter.c:88] tls transporter close socket fd:37 [05-12 16:21:03 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:37 [05-12 16:21:03 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x45e0c0 [05-12 16:21:03 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:21:03 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:21:03 TUYA E][tuya_svc_upgrade.c:653] result null [05-12 16:21:03 TUYA D][tuya_svc_upgrade.c:728] silent get firmware fail [05-12 16:21:03 TUYA D][tuya_svc_upgrade.c:228] next detect timer: 21600s [05-12 16:21:03 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:21:03 TUYA D][mqtt_client.c:1932] packet id: 31 [2023-5-12 16:21:3.160 ty_user_cmd_dp_handler.c IPC_APP_get_siren_duration(1664) Debug] siren_duration:60! [05-12 16:21:03 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:03 TUYA D][smart_frame.c:407] dp<194> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:1 [05-12 16:21:03 TUYA D][smart_frame.c:425] dp_cntl value:0, dp_data value:60 [05-12 16:21:03 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:03 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"194":60} [05-12 16:21:03 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:702 Q:1 Data:{"dps":{"194":60}} [05-12 16:21:03 TUYA D][mqtt_client.c:1932] packet id: 32 [05-12 16:21:03 TUYA D][iot_httpc.c:889] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1683879663} [05-12 16:21:04 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6ca27cadb2e9df92edwr0a&et=3&t=1683879663&v=2.0&sign=896e94c41d86c71129953eb8b00f0d07 [2023-5-12 16:21:3.167 ty_user_cmd_dp_handler.c IPC_APP_get_siren_auto_onoff(1701) Debug] get siren_auto_onoff [05-12 16:21:04 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:04 TUYA E][smart_frame.c:559] dparr[0] type not match:1 0 [05-12 16:21:04 TUYA D][smart_frame.c:3559] dp compose null, ret:-3586 [05-12 16:21:04 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:04 TUYA D][smart_frame.c:407] dp<188> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:3 [05-12 16:21:04 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:04 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"188":"1"} [05-12 16:21:04 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:703 Q:1 Data:{"dps":{"188":"1"}} [05-12 16:21:04 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"239":true}}, mqtt async dp cb:0 [05-12 16:21:04 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:239, curr_t:1683879664, rept_cnt:1. [05-12 16:21:04 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:239, curr_t:1683879664, rept_cnt:0. [05-12 16:21:04 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:239, curr_t:1683879664, rept_cnt:0. [05-12 16:21:04 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:04 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"194":60}}, mqtt async dp cb:0 [05-12 16:21:04 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:194, curr_t:1683879664, rept_cnt:1. [05-12 16:21:04 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:194, curr_t:1683879664, rept_cnt:0. [05-12 16:21:04 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:194, curr_t:1683879664, rept_cnt:0. [05-12 16:21:04 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:04 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 Type: 2, managed Type: 2, managed [2023-5-12 16:21:3.852 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:04 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:04 TUYA D][mqtt_client.c:1932] packet id: 33 [2023-5-12 16:21:3.855 ty_user_cmd_dp_handler.c IPC_APP_get_pet_filter(1576) Debug] IPC_APP_get_pet_filter 0 [05-12 16:21:04 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:04 TUYA E][smart_frame.c:554] devid:(null) dparr[0]:187 not find [05-12 16:21:04 TUYA D][smart_frame.c:613] no vaild dp to rept [05-12 16:21:04 TUYA D][smart_frame.c:3559] dp compose null, ret:-3585 [05-12 16:21:04 TUYA D][smart_frame.c:3546] rept chan:1 [05-12 16:21:04 TUYA D][smart_frame.c:407] dp<167> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1 prop_tp:0 [05-12 16:21:04 TUYA D][smart_frame.c:413] dp_cntl bool:0, dp_data bool:1 [05-12 16:21:04 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [05-12 16:21:04 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [05-12 16:21:04 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [05-12 16:21:04 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [05-12 16:21:04 TUYA D][smart_frame.c:511] is_need_update:1, is_dp_passive:0 [05-12 16:21:04 TUYA D][smart_frame.c:2302] dp rept_type:0, data:{"167":true} [05-12 16:21:04 TUYA D][mqc_app.c:881] Send MQTT Msg.P:4 N:704 Q:1 Data:{"dps":{"167":true}} [05-12 16:21:04 TUYA D][mqtt_client.c:1932] packet id: 34 [05-12 16:21:04 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:04 TUYA D][iot_httpc.c:889] Post Data: {"skill":"{\"v\":2,\"sdk_version\":\"5.6.28\",\"channel_num\":1,\"cloudGW\":1,\"cloudStorage\":1,\"localStorage\":513,\"webrtc\":115,\"p2p\":99,\"upnp\":11,\"video_num\":3,\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":0,\"profileId\":\"\",\"width\":2560,\"height\":1440},{\"streamType\":4,\"codecType\":2,\"sampleRate\":0,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":105,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]}","t":1683879664} [05-12 16:21:05 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6ca27cadb2e9df92edwr0a&et=3&t=1683879664&v=1.0&sign=7588c90858219a9901e780d800d6f05b [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:05 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [05-12 16:21:05 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [05-12 16:21:05 TUYA D][tuya_tls.c:1487] load tuya cert. [05-12 16:21:05 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [05-12 16:21:05 TUYA D][tuya_iot_com_api.c:254] tuya public url [05-12 16:21:05 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [05-12 16:21:05 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"188":"1"}}, mqtt async dp cb:0 [05-12 16:21:05 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:188, curr_t:1683879665, rept_cnt:1. [05-12 16:21:05 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:188, curr_t:1683879665, rept_cnt:0. [05-12 16:21:05 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:188, curr_t:1683879665, rept_cnt:0. [05-12 16:21:05 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:05 TUYA D][smart_frame.c:2054] msg_data:{"dps":{"167":true}}, mqtt async dp cb:0 [05-12 16:21:05 TUYA D][smart_frame.c:225] set short dp rate rule, dpID:167, curr_t:1683879665, rept_cnt:1. [05-12 16:21:05 TUYA D][smart_frame.c:233] set long dp rate rule, dpID:167, curr_t:1683879665, rept_cnt:0. [05-12 16:21:05 TUYA D][smart_frame.c:242] set all dp rate rule, dpID:167, curr_t:1683879665, rept_cnt:0. [05-12 16:21:05 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 Type: 2, managed [2023-5-12 16:21:4.550 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:05 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [05-12 16:21:05 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [05-12 16:21:05 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [05-12 16:21:05 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:05 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:21:05 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:21:05 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:05 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [05-12 16:21:05 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [05-12 16:21:05 TUYA D][tuya_tls.c:1487] load tuya cert. [05-12 16:21:05 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [05-12 16:21:05 TUYA D][tuya_iot_com_api.c:254] tuya public url [05-12 16:21:05 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:05 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:21:05 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:21:05 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 net cnt is 2..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:05 TUYA D][iot_httpc.c:590] Decode Rev:{"result":{"timezone":{"validTime":1800,"time":1683879665,"config":{}}},"t":1683879665,"success":true} [05-12 16:21:05 TUYA D][tls_transporter.c:88] tls transporter close socket fd:37 [05-12 16:21:05 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:37 [05-12 16:21:05 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x482a68 [05-12 16:21:05 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:21:05 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:21:05 TUYA D][tuya_devos_utils.c:212] set dp rate_rule:{"timezone":{"validTime":1800,"time":1683879665,"config":{}}}. [05-12 16:21:05 TUYA D][tuya_devos_utils.c:101] reset dp rate rule finish. [05-12 16:21:05 TUYA D][iot_httpc.c:2296] NO ackId [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:05 TUYA D][iot_httpc.c:889] Post Data: {"data":"7","t":1683879665} [05-12 16:21:05 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6ca27cadb2e9df92edwr0a&et=3&t=1683879665&sign=9c1ae7c8ee17b2cc588e3b449eecb8d0 Type: 2, managed [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [2023-5-12 16:21:5.300 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:05 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [05-12 16:21:05 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [05-12 16:21:05 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [05-12 16:21:05 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [05-12 16:21:05 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:06 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:06 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [05-12 16:21:06 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [05-12 16:21:06 TUYA D][tuya_tls.c:1487] load tuya cert. [05-12 16:21:06 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [05-12 16:21:06 TUYA D][tuya_iot_com_api.c:254] tuya public url [05-12 16:21:06 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [05-12 16:21:06 TUYA D][iot_httpc.c:590] Decode Rev:{"t":1683879666,"success":true} [05-12 16:21:06 TUYA D][tls_transporter.c:88] tls transporter close socket fd:38 [05-12 16:21:06 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:38 [05-12 16:21:06 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x4838c8 [05-12 16:21:06 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:21:06 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:21:06 TUYA D][tuya_ipc_skill.c:247] upload data: {\"v\":2,\"sdk_version\":\"5.6.28\",\"channel_num\":1,\"cloudGW\":1,\"cloudStorage\":1,\"localStorage\":513,\"webrtc\":115,\"p2p\":99,\"upnp\":11,\"video_num\":3,\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":0,\"profileId\":\"\",\"width\":2560,\"height\":1440},{\"streamType\":4,\"codecType\":2,\"sampleRate\":0,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":105,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]} [05-12 16:21:06 TUYA D][tuya_ipc_skill.c:278] upload finish [2023-5-12 16:21:5.328 ty_user_hd.c ty_user_hd_start(419) Debug] begin__ [2023-5-12 16:21:5.329 ty_user_hd.c ty_user_hd_start(478) Debug] end__ [2023-5-12 16:21:5.329 ty_sys.c ty_md_param_init(401) Debug] isAlarmZoneEnable = 0 [2023-5-12 16:21:5.996 ty_sys.c ty_md_param_init(426) Debug] region0[0,0,100,100] [2023-5-12 16:21:5.996 ty_sys.c ty_md_param_init(440) Debug] mt_cfg.sensitivity = 7 [2023-5-12 16:21:5.996 ty_user_md.c ty_user_md_start(257) Debug] begin__ [2023-5-12 16:21:5.996 ty_user_md.c ty_user_md_init(227) Debug] begin__ [2023-5-12 16:21:5.997 ty_user_video_capturer.c ty_user_video_capturer_start(99) Debug] begin___ [2023-5-12 16:21:5.997 ty_user_video_capturer.c ty_user_video_capturer_init_channel(65) Debug] begin___ [2023-5-12 16:21:5.997 ty_user_video_capturer.c ty_user_video_capturer_init_channel(93) Info] end___, cfg:0x2f6248, tid:2975020320 [2023-5-12 16:21:5.997 ty_user_video_capturer.c ty_user_video_capturer_start(115) Debug] end___ [2023-5-12 16:21:5.998 ty_user_md.c ty_user_md_start(296) Debug] end__ [05-12 16:21:06 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [2023-5-12 16:21:5.330 ty_user_hd.c ty_user_hd_dsp_proc(309) Debug] begin___ [2023-5-12 16:21:5.1000 ty_user_hd.c ty_user_hd_init_dsp_device(61) Debug] begin___ [2023-5-12 16:21:5.1000 ty_user_hd.c ty_user_hd_init_dsp_device(71) Debug] isAlarmZoneEnable [0] [2023-5-12 16:21:5.1000 ty_user_hd.c ty_user_hd_init_dsp_device(81) Debug] new alarm num[1] [2023-5-12 16:21:6.001 ty_user_hd.c ty_user_hd_init_dsp_device(85) Debug] region[0][0,0,100,100] tkl_vi_detect_start 0 0 Type: 2, managed [05-12 16:21:06 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:21:06 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:21:06 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [2023-5-12 16:21:6.004 ty_user_video_capturer.c ty_user_video_capturer_proc(28) Debug] begin___ [2023-5-12 16:21:6.005 ty_user_video_capturer.c ty_user_video_capturer_proc(31) Debug] cfg->phdl.start == 1 [2023-5-12 16:21:6.007 ty_user_md.c ty_user_md_init_device(55) Debug] begin__ [2023-5-12 16:21:6.007 ty_user_md.c ty_user_md_init_device(69) Debug] phdl->s_mt_cfg.frame_w = 160 phdl->s_mt_cfg.frame_h = 90 [05-12 16:21:06 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:21:06 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:06 TUYA D][iot_httpc.c:590] Decode Rev:{"result":true,"t":1683879667,"success":true} [05-12 16:21:07 TUYA D][tls_transporter.c:88] tls transporter close socket fd:37 [05-12 16:21:07 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:37 [05-12 16:21:07 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x482a68 [05-12 16:21:07 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:21:07 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:21:07 TUYA D][tuya_svc_devos_daemons.c:52] put rst log finish [05-12 16:21:07 TUYA D][simplekv.c:1126] read key:dzoojw_ver isFuzzy:0 skipCnt:0 [05-12 16:21:07 TUYA D][simplekv.c:1154] no key find [05-12 16:21:07 TUYA D][simplekv.c:1196] __read_kv_raw fail. -3 [05-12 16:21:07 TUYA D][simplekv.c:1234] __read_kv_with_decode fail. -3 [05-12 16:21:07 TUYA D][tuya_svc_upgrade_http.c:125] schema get:{"schemaId":"dzoojw","version":""} [05-12 16:21:07 TUYA D][iot_httpc.c:889] Post Data: {"schemaId":"dzoojw","version":"","t":1683879667} [05-12 16:21:07 TUYA D][iot_httpc.c:901] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.schema.newest.get&devId=6ca27cadb2e9df92edwr0a&et=3&t=1683879667&v=1.1&sign=53ff5b6010bec7c1029d2abeb5dfe47f Type: 2, managed [2023-5-12 16:21:6.072 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:07 TUYA D][httpc.c:648] Connect: a2.tuyacn.com Port: 443 -->> [05-12 16:21:07 TUYA D][uni_network.c:315] unw_gethostbyname a2.tuyacn.com, prio 2 [05-12 16:21:07 TUYA D][uni_network.c:354] use dynamic dns ip:42.192.31.36 for domain:a2.tuyacn.com [05-12 16:21:07 TUYA D][tcp_transporter.c:79] bind ip:c0a801be port:0 ok [2023-5-12 16:21:6.357 soap_common.c soap_recv(220) Debug] multiaddr udp recv len:787 [05-12 16:21:07 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [2023-5-12 16:21:6.744 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:6.745 soap_request_parser.c soap_check_wsdd_probe(185) Debug] Types: tds:Device [05-12 16:21:07 TUYA D][simplekv.c:1126] read key:onvif_uuid isFuzzy:0 skipCnt:0 [05-12 16:21:07 TUYA D][simplekv.c:1157] find key:17 onvif_uuid [05-12 16:21:07 TUYA D][simplekv.c:1183] key:onvif_uuid find value.Len:48 [2023-5-12 16:21:6.745 soap_uuid.c soap_get_uuid(75) Debug] uuid:e7333c1a-1787-4e6a-b2d2-1459778b524d [05-12 16:21:07 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 Type: 2, managed [2023-5-12 16:21:6.759 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:07 TUYA D][tuya_tls.c:1380] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [05-12 16:21:07 TUYA D][tuya_tls.c:1417] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [05-12 16:21:07 TUYA D][tuya_tls.c:1487] load tuya cert. [05-12 16:21:07 TUYA D][tuya_tls.c:1492] parse crt <0> len <2002> ret <0> [05-12 16:21:07 TUYA D][tuya_iot_com_api.c:254] tuya public url [05-12 16:21:07 TUYA D][tuya_tls.c:1604] socket fd is set. set to inner send/recv to handshake [05-12 16:21:07 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:07 TUYA D][tuya_tls.c:1664] handshake finish for a2.tuyacn.com. set send/recv to user set [05-12 16:21:07 TUYA D][tuya_tls.c:1671] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [05-12 16:21:07 TUYA D][httpc.c:650] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 Type: 2, managed [2023-5-12 16:21:6.863 soap_common.c soap_recv(220) Debug] multiaddr udp recv len:803 [2023-5-12 16:21:6.863 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:6.865 soap_request_parser.c soap_check_wsdd_probe(185) Debug] Types: tdn:NetworkVideoTransmitter [05-12 16:21:07 TUYA D][simplekv.c:1126] read key:onvif_uuid isFuzzy:0 skipCnt:0 [05-12 16:21:07 TUYA D][simplekv.c:1157] find key:17 onvif_uuid [05-12 16:21:07 TUYA D][simplekv.c:1183] key:onvif_uuid find value.Len:48 [2023-5-12 16:21:6.866 soap_uuid.c soap_get_uuid(75) Debug] uuid:e7333c1a-1787-4e6a-b2d2-1459778b524d Type: 2, managed [2023-5-12 16:21:6.873 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:07 TUYA D][iot_httpc.c:590] Decode Rev:{"result":{"schema":"","schemaId":"dzoojw"},"t":1683879667,"success":true} [05-12 16:21:07 TUYA D][tls_transporter.c:88] tls transporter close socket fd:36 [05-12 16:21:07 TUYA D][tcp_transporter.c:177] tcp transporter close socket fd:36 [05-12 16:21:07 TUYA D][tls_transporter.c:96] tls transporter close tls handler:0x481a60 [05-12 16:21:07 TUYA D][tuya_tls.c:1783] TUYA_TLS Disconnect ENTER [05-12 16:21:07 TUYA D][tuya_tls.c:1833] TUYA_TLS Disconnect Success [05-12 16:21:07 TUYA D][tuya_svc_upgrade_http.c:133] schema get result:{"schema":"","schemaId":"dzoojw"} [05-12 16:21:07 TUYA D][tuya_svc_schema_upgrade.c:131] schema[dzoojw] ver not update Type: 2, managed [2023-5-12 16:21:6.996 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:07 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:07 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6906 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6906, 6906, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7385 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:08 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7385, 7385, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:08 TUYA D][mqtt_client.c:1932] packet id: 35 [05-12 16:21:08 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:08 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:08 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:21:09 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:21:09 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [2000] [05-12 16:21:09 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:21:09 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [2000] num[0] [05-12 16:21:09 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [2000] [2023-5-12 16:21:8.726 ty_user_event.c __event_task(3963) Debug] loop_cnt = 200 step = 3067 p2p num = 0 Type: 2, managed Type: 2, managed [2023-5-12 16:21:10.098 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [300] run_step [1039] [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:11 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:11 TUYA D][miniwget.c:482] send ok,get response [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [2023-5-12 16:21:10.542 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:21:10.548 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16504 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:11 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 Type: 2, managed net cnt is 3..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [2023-5-12 16:21:11.498 app_sys_ptz.c __do_self_check(1277) Debug] tilt_check [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 Type: 2, managed [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:12 TUYA D][tuya_devos_utils.c:275] set time by rtc [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 Type: 2, managed [2023-5-12 16:21:12.001 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:12 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7510 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7510, 7510, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 8216 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(8216, 8216, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:13 TUYA D][mqtt_client.c:1932] packet id: 36 [05-12 16:21:13 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:13 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:13 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:21:13 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:21:13 TUYA D][tuya_ipc_p2p.c:4274] session detect run Type: 2, managed [05-12 16:21:14 TUYA D][tuya_devos_health.c:70] feed watchdog Type: 2, managed [2023-5-12 16:21:14.446 soap_common.c soap_recv(220) Debug] multiaddr udp recv len:787 [2023-5-12 16:21:14.446 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:14.446 soap_request_parser.c soap_check_wsdd_probe(185) Debug] Types: tds:Device [05-12 16:21:15 TUYA D][simplekv.c:1126] read key:onvif_uuid isFuzzy:0 skipCnt:0 [05-12 16:21:15 TUYA D][simplekv.c:1157] find key:17 onvif_uuid [05-12 16:21:15 TUYA D][simplekv.c:1183] key:onvif_uuid find value.Len:48 [2023-5-12 16:21:14.447 soap_uuid.c soap_get_uuid(75) Debug] uuid:e7333c1a-1787-4e6a-b2d2-1459778b524d Type: 2, managed [2023-5-12 16:21:14.456 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [2023-5-12 16:21:14.558 soap_common.c soap_recv(220) Debug] multiaddr udp recv len:803 [2023-5-12 16:21:14.559 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:14.559 soap_request_parser.c soap_check_wsdd_probe(185) Debug] Types: tdn:NetworkVideoTransmitter [05-12 16:21:15 TUYA D][simplekv.c:1126] read key:onvif_uuid isFuzzy:0 skipCnt:0 [05-12 16:21:15 TUYA D][simplekv.c:1157] find key:17 onvif_uuid [05-12 16:21:15 TUYA D][simplekv.c:1183] key:onvif_uuid find value.Len:48 [2023-5-12 16:21:14.560 soap_uuid.c soap_get_uuid(75) Debug] uuid:e7333c1a-1787-4e6a-b2d2-1459778b524d Type: 2, managed [2023-5-12 16:21:14.562 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:15 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:15 TUYA D][miniwget.c:482] send ok,get response [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 Type: 2, managed [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:15 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6711 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6711, 6711, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7243 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7243, 7243, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:16 TUYA D][mqtt_client.c:1932] packet id: 37 [05-12 16:21:16 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:16 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:16 TUYA D][mqc_app.c:1483] pub finish:0 [2023-5-12 16:21:15.658 app_sys_ptz.c __do_ptz_go_back_pos(602) Debug] -----type:2 [2023-5-12 16:21:15.762 app_sys_ptz.c __do_preset_point(525) Debug] start time is :51704 [05-12 16:21:16 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [05-12 16:21:16 TUYA D][tuya_svc_schema_upgrade.c:170] next schema get slot 63724. [2023-5-12 16:21:15.999 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed [2023-5-12 16:21:16.914 ty_sys_av.c __audio_task(205) Info] loop_cnt = 500 type = 0 Type: 2, managed [2023-5-12 16:21:17.001 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 net cnt is 4..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:18 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:18 TUYA D][miniwget.c:482] send ok,get response Type: 2, managed [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:21:18 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:19 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7179 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7179, 7179, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:19 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7552 [2023-5-12 16:21:18.895 ty_sys_av.c __video_task(296) Info] loop_cnt = 500 type = 1 Type: 2, managed [2023-5-12 16:21:18.895 ty_sys_av.c __video_task(296) Info] loop_cnt = 500 type = 0 [2023-5-12 16:21:19.126 ty_user_event.c __event_task(3963) Debug] loop_cnt = 300 step = 3067 p2p num = 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:20 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7552, 7552, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:20 TUYA D][mqtt_client.c:1932] packet id: 38 [05-12 16:21:20 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:20 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:20 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:21:20 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [2023-5-12 16:21:20.498 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [400] run_step [1039] [2023-5-12 16:21:20.595 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:20.596 soap_server.c soap_server_process(279) Error] soap process[GetDeviceInformation]error[12] [2023-5-12 16:21:20.597 soap_common.c soap_send_err_response(1817) Debug] send err success [2023-5-12 16:21:20.698 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:20.699 soap_server.c soap_server_process(279) Error] soap process[GetDeviceInformation]error[12] [2023-5-12 16:21:20.700 soap_common.c soap_send_err_response(1817) Debug] send err success Type: 2, managed [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:22 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:22 TUYA D][miniwget.c:482] send ok,get response [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 Type: 2, managed [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 Type: 2, managed [2023-5-12 16:21:22.011 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:22 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:23 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 Type: 2, managed [05-12 16:21:24 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:24 TUYA D][tuya_ipc_p2p.c:4274] session detect run [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7218 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7218, 7218, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7730 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7730, 7730, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:24 TUYA D][mqtt_client.c:1932] packet id: 39 [05-12 16:21:24 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:24 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:24 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:21:24 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... net cnt is 5..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [05-12 16:21:25 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [4000] num[0] [05-12 16:21:25 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [4000] [05-12 16:21:25 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [4000] Type: 2, managed [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:26 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:26 TUYA D][miniwget.c:482] send ok,get response [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 Type: 2, managed [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [2023-5-12 16:21:26.002 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:26 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 Type: 2, managed [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 Type: 2, managed [2023-5-12 16:21:27.010 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:27 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 [2023-5-12 16:21:27.054 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:21:27.055 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16509 [2023-5-12 16:21:27.137 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:27.138 soap_request_parser.c soap_check_tds_get_capabilities(294) Debug] Category: 5 Type: 2, managed [2023-5-12 16:21:27.149 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:28 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:28 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7125 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:28 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7125, 7125, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:28 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7795 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:28 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7795, 7795, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:28 TUYA D][mqtt_client.c:1932] packet id: 40 [05-12 16:21:28 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:28 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:28 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:21:28 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [05-12 16:21:29 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:21:28.242 app_sys_ptz.c __do_preset_point(541) Debug] stop time is :64184 [2023-5-12 16:21:28.450 app_sys_ptz.c __do_ptz_set_back_pos(569) Debug] -----pre_pos do not need update !!! ----- [2023-5-12 16:21:28.451 app_sys_ptz.c __do_patrol(1036) Debug] __do_patrol_point __drv_get_pos 199 [2023-5-12 16:21:28.554 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [0] Type: 2, managed [2023-5-12 16:21:28.987 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:28.987 soap_server.c soap_server_process(279) Error] soap process[GetProfiles]error[12] [2023-5-12 16:21:28.990 soap_common.c soap_send_err_response(1817) Debug] send err success [2023-5-12 16:21:29.111 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.111 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.111 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.112 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.112 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.112 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.112 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.112 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.112 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.113 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.113 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.113 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.113 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.113 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.113 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.114 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.114 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.114 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.114 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.119 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.120 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.120 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.120 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.120 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.120 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.120 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.121 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.121 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.121 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.121 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.121 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.121 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.122 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.122 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.122 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.122 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.123 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.789 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.789 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.789 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.790 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.790 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.790 soap_mem_pool.c soap_mem_pool_malloc(61) Error] [2023-5-12 16:21:29.694 ty_user_event.c __event_task(3963) Debug] loop_cnt = 400 step = 3067 p2p num = 0 soap malloc failed[2023-5-12 16:21:29.792 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.792 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.792 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.792 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.797 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.797 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.797 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.797 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.797 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.797 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.798 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.798 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.798 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.807 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.807 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.807 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.807 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.807 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.807 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.815 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.816 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.816 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.816 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.816 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.816 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.817 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.817 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:29.817 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:29.817 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.483 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.483 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.484 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.484 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.484 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.484 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.484 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.485 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.485 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.485 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.485 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.485 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.486 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.486 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16net cnt is 6..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:21:30 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success Type: 2, managed [05-12 16:21:31 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:31 TUYA D][miniwget.c:482] send ok,get response :21:30.486 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.492 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.493 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.503 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.503 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.503 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.504 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.509 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.509 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.509 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.516 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.516 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.517 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.517 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.517 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.517 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:30.517 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:30.517 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.183 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.184 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.184 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.184 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.184 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.184 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.185 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.185 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.185 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.185 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.185 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.186 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.186 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16[05-12 16:21:31 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 Type: 2, managed :21:31.186 soap_common.c soap_append_string_to_send_buf(1429) Error] [2023-5-12 16:21:30.898 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [500] run_step [1039] soap malloc buf list failed [2023-5-12 16:21:31.189 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.189 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.189 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.189 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.189 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.190 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.190 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.191 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.192 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.192 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.192 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.192 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.192 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.193 soap_common.c soap_append_string_to_send_buf(1429) Error] [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 soap malloc buf list failed [2023-5-12 16:21:31.200 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.200 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.200 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.202 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.868 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.868 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.868 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.868 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.868 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.869 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.869 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.869 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.869 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.869 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.870 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.870 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.870[05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.878 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.883 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.883 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.884 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.884 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:21:31.884 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:21:31.884 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 Type: 2, managed [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 Type: 2, managed [2023-5-12 16:21:32.013 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:32 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 Type: 2, managed [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:33 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:34 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:34 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:34 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7461 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:34 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7461, 7461, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:34 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7561 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:34 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7561, 7561, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:34 TUYA D][mqtt_client.c:1932] packet id: 41 [05-12 16:21:34 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:34 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:34 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:21:34 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:21:34 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:21:34 TUYA D][tuya_ipc_p2p.c:4274] session detect run Type: 2, managed Type: 2, managed [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:36 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:36 TUYA D][miniwget.c:482] send ok,get response [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 Type: 2, managed [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [2023-5-12 16:21:36.007 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:36 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6671 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6671, 6671, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6913 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6913, 6913, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:37 TUYA D][mqtt_client.c:1932] packet id: 42 [2023-5-12 16:21:36.503 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:36.893 soap_request_parser.c soap_check_tds_get_capabilities(294) Debug] Category: 5 net cnt is 7..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:21:37 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [2023-5-12 16:21:36.902 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [2023-5-12 16:21:36.915 ty_sys_av.c __audio_task(205) Info] loop_cnt = 1000 type = 0 [05-12 16:21:37 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:37 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:37 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed Type: 2, managed [2023-5-12 16:21:37.017 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed LTuya login: [05-12 16:21:39 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:21:39 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:39 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:39 TUYA D][miniwget.c:482] send ok,get response Type: 2, managed [05-12 16:21:39 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:39 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:21:39 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:39 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:39 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6672 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6672, 6672, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6752 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6752, 6752, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:40 TUYA D][mqtt_client.c:1932] packet id: 43 [05-12 16:21:40 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:40 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:40 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:21:40 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [2023-5-12 16:21:40.190 ty_user_event.c __event_task(3963) Debug] loop_cnt = 500 step = 3067 p2p num = 0 [05-12 16:21:41 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [6000] num[0] [05-12 16:21:41 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [6000] [05-12 16:21:41 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [6000] Type: 2, managed [2023-5-12 16:21:41.586 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [600] run_step [1039] [05-12 16:21:42 TUYA D][tuya_devos_utils.c:275] set time by rtc Type: 2, managed Type: 2, managed [2023-5-12 16:21:42.023 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:43 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:43 TUYA D][miniwget.c:482] send ok,get response [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [2023-5-12 16:21:42.598 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [1] [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:43 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 Type: 2, managed net cnt is 8..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:21:44 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:21:43.566 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:21:43.567 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16509 [05-12 16:21:44 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:44 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:44 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 Type: 2, managed [05-12 16:21:45 TUYA D][tuya_ipc_p2p.c:4274] session detect run [2023-5-12 16:21:44.244 ty_sys_av.c __video_task(296) Info] loop_cnt = 1000 type = 1 [2023-5-12 16:21:44.245 ty_sys_av.c __video_task(296) Info] loop_cnt = 1000 type = 0 Type: 2, managed Type: 2, managed [2023-5-12 16:21:46.010 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed Type: 2, managed [2023-5-12 16:21:47.025 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [05-12 16:21:49 TUYA D][tuya_devos_health.c:70] feed watchdog Type: 2, managed net cnt is 9..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 total used free shared buff/cache available Mem: 35568 18104 5080 56 12384 15260 Swap: 0 0 0 wlan0 no wireless extensions. ip_addr: inet addr:192.168.1.190 Bcast:192.168.1.255 Mask:255.255.255.0 wifi_ssid: route_info:default 192.168.1.1 0.0.0.0 UG 0 0 0 wlan0 192.168.1.0 bin config dev drv etc home lib linuxrc mnt opt proc root run sbin sys tmp tuya usr var 255.255.255.0 U 0 0 0 wlan0 reconnect wifi [05-12 16:21:50 TUYA D][mqtt_client.c:238] host[m2.tuyacn.com] mqtt_ping -->> [05-12 16:21:50 TUYA D][mqtt_client.c:256] host[m2.tuyacn.com] mqtt_ping <<-- [05-12 16:21:50 TUYA D][mqtt_client.c:1346] host[m2.tuyacn.com] ping respond. update fail_cnt:0 [05-12 16:21:50 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 Type: 2, managed [2023-5-12 16:21:50.590 ty_user_event.c __event_task(3963) Debug] loop_cnt = 600 step = 3067 p2p num = 0 Type: 2, managed [2023-5-12 16:21:51.986 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [700] run_step [1039] Type: 2, managed Type: 2, managed [2023-5-12 16:21:52.032 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [05-12 16:21:54 TUYA D][tuya_devos_health.c:70] feed watchdog Type: 2, managed [05-12 16:21:55 TUYA E][uni_network.c:465] tcp connect failed 192.168.1.1:1900 errno=115 [05-12 16:21:55 TUYA E][connecthostport.c:35] fail to connect to server192.168.1.1 port1900, ret -5 failed to connect hostname 192.168.1.1,port 1900 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:55 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:55 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7496 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:55 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7496, 7496, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:55 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7760 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:55 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7760, 7760, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:55 TUYA D][mqtt_client.c:1932] packet id: 44 [05-12 16:21:55 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:55 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:55 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:21:55 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:21:55 TUYA D][tuya_ipc_p2p.c:4274] session detect run Type: 2, managed [2023-5-12 16:21:55.540 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:21:55.541 soap_request_parser.c soap_check_tds_get_services(226) Debug] IncludeCapability: 0 Type: 2, managed [2023-5-12 16:21:55.550 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 net cnt is 0..MQ_ONLINE is 1.. mq_status is 1.. recnt is 1 [2023-5-12 16:21:55.598 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [2] [2023-5-12 16:21:56.014 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:21:57 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:21:57 TUYA D][miniwget.c:482] send ok,get response [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [2023-5-12 16:21:56.914 ty_sys_av.c __audio_task(205) Info] loop_cnt = 1500 type = 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:21:57 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 Type: 2, managed [2023-5-12 16:21:57.052 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [05-12 16:21:58 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [8000] num[0] [05-12 16:21:58 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [8000] [05-12 16:21:58 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [8000] [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7628 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7628, 7628, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7976 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:21:58 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7976, 7976, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:21:58 TUYA D][mqtt_client.c:1932] packet id: 45 [05-12 16:21:58 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:21:58 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:21:58 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:21:59 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:21:59 TUYA D][tuya_devos_health.c:70] feed watchdog Type: 2, managed Type: 2, managed [2023-5-12 16:22:0.078 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:22:0.079 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16509 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:01 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:01 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 [2023-5-12 16:22:0.991 ty_user_event.c __event_task(3963) Debug] loop_cnt = 700 step = 3067 p2p num = 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7158 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7158, 7158, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 8032 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:01 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(8032, 8032, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:01 TUYA D][mqtt_client.c:1932] packet id: 46 [05-12 16:22:01 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:01 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:01 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:22:02 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... net cnt is 1..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [2023-5-12 16:22:2.048 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [2023-5-12 16:22:2.386 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [800] run_step [1039] Type: 2, managed [05-12 16:22:04 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:04 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:04 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:04 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:05 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:05 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 Type: 2, managed UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:05 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:05 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7417 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:05 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7417, 7417, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:05 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7645 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:05 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7645, 7645, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:05 TUYA D][mqtt_client.c:1932] packet id: 47 [05-12 16:22:05 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:05 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:05 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:22:05 TUYA D][tuya_ipc_p2p.c:4274] session detect run [05-12 16:22:05 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [2023-5-12 16:22:6.018 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed [2023-5-12 16:22:7.017 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:22:7.018 soap_server.c soap_server_process(279) Error] soap process[GetProfiles]error[12] [2023-5-12 16:22:7.019 soap_common.c soap_send_err_response(1817) Debug] send err success Type: 2, managed [2023-5-12 16:22:7.053 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:22:08 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:08 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:08 TUYA D][miniwget.c:482] send ok,get response Type: 2, managed [2023-5-12 16:22:7.134 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.134 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.148 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.148 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.149 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.149 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.149 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.149 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.150 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.150 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.150 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.150 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.151 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.151 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.151 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.151 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.151 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.151 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.152 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.152 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.152 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.152 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.153 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.153 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.153 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.153 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.153 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.153 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.154 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.154 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.154 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.154 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.155 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.155 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.155 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.155 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.155 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.155 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.821 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.822 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.822 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.822 [05-12 16:22:08 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.824 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.824 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.825 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.825 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.825 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.825 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.825 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.826 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.826 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.826 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.826 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.832 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.832 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.832 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.833 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.833 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.833 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.833 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.833 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.833 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.834 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.834 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.834 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[[05-12 16:22:08 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 2023-5-12 16:22:7.834 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.857 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.858 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.858 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.858 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:7.862 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:7.863 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.529 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.530 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.530 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.530 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.530 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.531 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.531 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.531 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.531 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.531 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.532 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.532 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.532 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.532 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.532 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.533 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.533 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.533 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.533 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.533 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8[05-12 16:22:08 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 net cnt is 2..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [05-12 16:22:09 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:22:09 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:09 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 .534 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.556 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.557 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.557 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.557 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.557 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.557 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.557 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.558 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.558 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:8.558 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:8.563 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.229 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.229 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.229 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.229 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.229 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.230 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.230 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.230 soap_common.c soap_append_string_to_send_buf(1429) Error[05-12 16:22:09 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 Type: 2, managed ] [2023-5-12 16:22:8.602 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [3] soap malloc buf list failed [2023-5-12 16:22:9.233 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.233 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.233 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.233 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.233 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.233 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.234 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.234 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.234 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.235 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.235 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.235 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.235 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.235 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.236 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.236 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.236 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.236 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.236 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.236 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.237 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.237 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.237 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.237 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.903 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.903 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.903 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.904 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.904 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.904 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.904 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.904 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.905 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.905 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.905 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.905 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.905 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.906 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.906 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12[05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 16:22:9.906 soap_common.c soap_append_string_to_send_buf(1429) Error] [2023-5-12 16:22:9.245 ty_sys_av.c __video_task(296) Info] loop_cnt = 1500 type = 1 [2023-5-12 16:22:9.245 ty_sys_av.c __video_task(296) Info] loop_cnt = 1500 type = 0 soap malloc buf list failed [2023-5-12 16:22:9.913 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.913 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:9.915 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:9.916 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:10 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 Type: 2, managed [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:11 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 Type: 2, managed [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7082 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7082, 7082, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7583 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7583, 7583, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:12 TUYA D][mqtt_client.c:1932] packet id: 48 [05-12 16:22:12 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:12 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:12 TUYA D][mqc_app.c:1483] pub finish:0 [2023-5-12 16:22:11.390 ty_user_event.c __event_task(3963) Debug] loop_cnt = 800 step = 3067 p2p num = 0 [05-12 16:22:12 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:22:12 TUYA D][tuya_devos_utils.c:275] set time by rtc Type: 2, managed [2023-5-12 16:22:12.056 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [2023-5-12 16:22:12.786 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [900] run_step [1039] [2023-5-12 16:22:12.894 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:22:12.895 soap_request_parser.c soap_check_tds_get_services(226) Debug] IncludeCapability: 0 Type: 2, managed [2023-5-12 16:22:12.908 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [05-12 16:22:14 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:22:14 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [10000] num[0] [05-12 16:22:14 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [10000] [05-12 16:22:14 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [10000] [05-12 16:22:14 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:14 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:14 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:14 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:14 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 Type: 2, managed [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [2023-5-12 16:22:14.564 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:22:14.564 soap_server.c soap_server_process(279) Error] soap process[GetProfiles]error[12] [2023-5-12 16:22:14.566 soap_common.c soap_send_err_response(1817) Debug] send err success [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [2023-5-12 16:22:14.708 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:14.708 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:14.708 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:14.708 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:14.709 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:14.709 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:14.709 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:14.709 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:14.709 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:14.709 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:14.710 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:14.710 soap_common.c soap_append_string_to_send_buf(1429)[05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 Error] soap malloc buf list failed [2023-5-12 16:22:14.720 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:14.720 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.386 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.386 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.386 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.386 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.387 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.387 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.387 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.387 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.387 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.388 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.388 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.388 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.388 soap_mem_pool.c soap_mem_pool_malloc(61) [05-12 16:22:15 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 net cnt is 3..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [05-12 16:22:16 TUYA D][tuya_ipc_p2p.c:4274] session detect run Error] soap malloc failed[2023-5-12 16:22:15.392 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.397 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.398 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.398 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.398 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.401 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.401 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.403 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.403 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.404 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.404 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.404 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.404 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.405 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.405 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.405 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:15.405 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:15.405 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[05-12 16:22:16 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [2023-5-12 16:22:15.406 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.077 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.077 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.077 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.078 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.078 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.078 soap_common.c soap_append_string_to_send_buf(1429) Error] [2023-5-12 16:22:16.022 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run soap malloc buf list failed [2023-5-12 16:22:16.079 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.082 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.082 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.082 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.082 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.083 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.083 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.083 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5[05-12 16:22:17 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 -12 16:22:16.083 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.087 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.087 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.087 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.087 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.087 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.089 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.089 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.089 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.090 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.090 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.090 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.091 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.091 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.091 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.092 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.092 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.0[05-12 16:22:17 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 92 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.760 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.760 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.761 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.761 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.761 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.761 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.761 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.762 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.762 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failedType: 2, managed [2023-5-12 16:22:16.762 soap_common.c soap_append_string_to_send_buf(1429) Error] [2023-5-12 16:22:16.590 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:22:16.763 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16337 soap malloc buf list failed [2023-5-12 16:22:16.763 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.764 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.764 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.764 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.764 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.764 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.764 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.765 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.765 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.765 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.765 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.765 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.765 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.766 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.766 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.766 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.766 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.777 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.778 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.778 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:16.778 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:16.778 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.445 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.445 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.445 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.445 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.445 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.446 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.446 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:[05-12 16:22:17 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 Type: 2, managed 17.446 soap_common.c soap_append_string_to_send_buf(1429) Error] [2023-5-12 16:22:16.919 ty_sys_av.c __audio_task(205) Info] loop_cnt = 2000 type = 0 [rts camera] : <__recycle_audio_buffer, 260>Audio buffer use 517ms [2023-5-12 16:22:17.449 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 soap malloc buf list failed [2023-5-12 16:22:17.459 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.459 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.459 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.459 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.459 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.459 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.460 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.460 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.460 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.460 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023[05-12 16:22:18 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 -5-12 16:22:17.460 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.475 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.475 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.475 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.475 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17Type: 2, managed .475 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.488 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.489 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.489 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.489 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.489 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.489 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:17.489 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:17.490 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:18.155 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:18.156 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:18.156 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:18.156 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:18.156 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:18.156 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:18.157 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:18.157 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:18.157 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:18.157 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:18.157 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:18.158 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [2023-5-12 16:22:18.158 soap_mem_pool.c soap_mem_pool_malloc(61) Error] soap malloc failed[2023-5-12 16:22:18.[rts camera] : <__recycle_audio_buffer, 260>Audio buffer use 504ms [05-12 16:22:18 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 158 soap_common.c soap_append_string_to_send_buf(1429) Error] soap malloc buf list failed [rts camera] : <__recycle_audio_buffer, 260>Audio buffer use 1146ms [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6844 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6844, 6844, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6960 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6960, 6960, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:19 TUYA D][mqtt_client.c:1932] packet id: 49 [05-12 16:22:19 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:19 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:19 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:22:19 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:22:19 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed Type: 2, managed [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:21 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:21 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:21 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:22 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 Type: 2, managed net cnt is 4..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [2023-5-12 16:22:21.790 ty_user_event.c __event_task(3963) Debug] loop_cnt = 900 step = 3067 p2p num = 0 Type: 2, managed [2023-5-12 16:22:22.069 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [2023-5-12 16:22:22.230 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [4] Type: 2, managed [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7275 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7275, 7275, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7633 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7633, 7633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:23 TUYA D][mqtt_client.c:1932] packet id: 50 [05-12 16:22:23 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:23 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:23 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:22:23 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [2023-5-12 16:22:23.187 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1000] run_step [1039] Type: 2, managed [05-12 16:22:24 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:22:23.879 soap_http.c soap_http_authenticate(592) Error] check auth failed [2023-5-12 16:22:23.879 soap_request_parser.c soap_check_tds_get_services(226) Debug] IncludeCapability: 0 Type: 2, managed [2023-5-12 16:22:23.888 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:25 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:25 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:25 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 Type: 2, managed [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:26 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:26 TUYA D][tuya_ipc_p2p.c:4274] session detect run [2023-5-12 16:22:26.082 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7102 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7102, 7102, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7598 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7598, 7598, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:27 TUYA D][mqtt_client.c:1932] packet id: 51 [05-12 16:22:27 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:27 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:27 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:22:27 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [2023-5-12 16:22:27.075 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed net cnt is 5..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [05-12 16:22:29 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:30 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:30 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 Type: 2, managed [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6674 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6674, 6674, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7093 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:30 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7093, 7093, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:30 TUYA D][mqtt_client.c:1932] packet id: 52 [05-12 16:22:30 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [12000] num[0] [05-12 16:22:30 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:30 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:30 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:22:30 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [12000] [05-12 16:22:30 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [12000] [05-12 16:22:31 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed Type: 2, managed Type: 2, managed [2023-5-12 16:22:32.077 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [2023-5-12 16:22:32.190 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1000 step = 3067 p2p num = 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:33 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:33 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 Type: 2, managed [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:33 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6638 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:34 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6638, 6638, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:34 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7098 [2023-5-12 16:22:33.102 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:22:33.733 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 15878 Type: 2, managed [05-12 16:22:34 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:22:33.586 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1100] run_step [1039] UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:34 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7098, 7098, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:34 TUYA D][mqtt_client.c:1932] packet id: 53 [05-12 16:22:34 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:34 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:34 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:22:34 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... net cnt is 6..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [2023-5-12 16:22:34.895 ty_sys_av.c __video_task(296) Info] loop_cnt = 2000 type = 0 [2023-5-12 16:22:34.895 ty_sys_av.c __video_task(296) Info] loop_cnt = 2000 type = 1 [2023-5-12 16:22:35.230 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [5] Type: 2, managed [05-12 16:22:36 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:37 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:37 TUYA D][miniwget.c:482] send ok,get response [2023-5-12 16:22:36.086 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:37 TUYA D][tuya_ipc_p2p.c:4274] session detect run [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 Type: 2, managed [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:37 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 Type: 2, managed [2023-5-12 16:22:37.101 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7426 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7426, 7426, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7888 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7888, 7888, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:38 TUYA D][mqtt_client.c:1932] packet id: 54 [05-12 16:22:38 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:38 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:38 TUYA D][mqc_app.c:1483] pub finish:0 [2023-5-12 16:22:37.395 ty_sys_av.c __audio_task(205) Info] loop_cnt = 2500 type = 0 [05-12 16:22:38 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed Login timed out after 60 seconds Tuya login: Type: 2, managed [05-12 16:22:39 TUYA D][tuya_devos_health.c:70] feed watchdog Type: 2, managed [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:40 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:40 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:40 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 net cnt is 7..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7478 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7478, 7478, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7611 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7611, 7611, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:41 TUYA D][mqtt_client.c:1932] packet id: 55 [05-12 16:22:41 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:41 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:41 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:22:41 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:22:42 TUYA D][simplekv.c:129] <__tmm_backup_work> backup file start...time: 137, MsTime: 161 [05-12 16:22:42 TUYA D][simplekv.c:241] backup normal file to bak success [05-12 16:22:42 TUYA D][simplekv.c:132] <__tmm_backup_work> backup file end...time: 137, MsTime: 291 Type: 2, managed [05-12 16:22:42 TUYA D][tuya_devos_utils.c:275] set time by rtc Type: 2, managed [2023-5-12 16:22:42.096 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [2023-5-12 16:22:42.590 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1100 step = 3067 p2p num = 0 [05-12 16:22:43 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:43 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:43 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:43 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 Type: 2, managed [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:44 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:44 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:22:44.134 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1200] run_step [1039] [2023-5-12 16:22:44.188 ty_user_event.c __event_task(3972) Debug] recv_msg type:0 [2023-5-12 16:22:44.188 ty_user_event.c __event_msg_proc(3022) Debug] >>>>>>>>>>> E_TY_MSG_MD_START s_mjpeg_qualit=60 [2023-5-12 16:22:44.198 ty_user_md.c ty_user_md_video_capturer_cb_func(193) Debug] phdl->msg_upload_triggered == 1 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 Capture JPEG OK, size=17603 [2023-5-12 16:22:44.315 ty_user_event.c __sdk_event_start(967) Debug] start event type[0] pic size[17603] [2023-5-12 16:22:44.316 ty_user_event.c __sdk_event_start(1089) Debug] md alarm enable[1] ivp enable[1] pet enable[0] db[1] babycry[1] type[0] notify-wait[0-512] [05-12 16:22:45 TUYA D][tuya_ipc_event.c:1122] START alarm[0], refer cnt:1... tuya_ipc_ss_start_event:2438 :start new event [05-12 16:22:45 TUYA E][tuya_ipc_stream_storage.c:2444] the ss mgr not inited, but msg buffed [05-12 16:22:45 TUYA E][tuya_ipc_event.c:1350] start sd storage event fail ret:-1 [05-12 16:22:45 TUYA D][tuya_ipc_cloud_storage.c:1443] new event index 0, id: 1, added: type 0,notify type 2[1683879765-1683879765] [05-12 16:22:45 TUYA D][tuya_ipc_cloud_storage.c:2468] new event added to list, time 1683879765 [05-12 16:22:45 TUYA D][tuya_ipc_event.c:1367] start cloud storage event success [05-12 16:22:45 TUYA D][tuya_ipc_event.c:1634] get match event, index:0 [05-12 16:22:45 TUYA D][tuya_ipc_event.c:564] alarm update ok [05-12 16:22:45 TUYA D][tuya_ipc_event.c:1653] alarm event ok! [2023-5-12 16:22:44.318 ty_user_hd.c ty_user_set_hd_upload_flag(530) Debug] begin__ [2023-5-12 16:22:44.323 ty_user_hd.c ty_user_set_hd_upload_flag(535) Debug] phdl->msg_upload_flag = 1 tkl_vi_detect_start 0 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:45 TUYA D][tuya_ipc_cloud_storage.c:1402] force event 0 stop done [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6742 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6742, 6742, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7391 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7391, 7391, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:45 TUYA D][mqtt_client.c:1932] packet id: 56 [05-12 16:22:45 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:45 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:45 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:22:45 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [2023-5-12 16:22:46.090 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [05-12 16:22:47 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [14000] num[0] [05-12 16:22:47 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [14000] [05-12 16:22:47 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [14000] net cnt is 8..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [05-12 16:22:47 TUYA D][tuya_ipc_p2p.c:4274] session detect run [05-12 16:22:47 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:47 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:47 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:47 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 Type: 2, managed [2023-5-12 16:22:47.097 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 Type: 2, managed [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:48 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [2023-5-12 16:22:48.231 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [4] [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6738 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6738, 6738, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6886 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6886, 6886, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:49 TUYA D][mqtt_client.c:1932] packet id: 57 [05-12 16:22:49 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:49 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:49 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:22:49 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:22:49 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:22:50 TUYA D][mqtt_client.c:238] host[m2.tuyacn.com] mqtt_ping -->> [05-12 16:22:50 TUYA D][mqtt_client.c:256] host[m2.tuyacn.com] mqtt_ping <<-- [05-12 16:22:50 TUYA D][mqtt_client.c:1346] host[m2.tuyacn.com] ping respond. update fail_cnt:0 [05-12 16:22:50 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 Type: 2, managed [2023-5-12 16:22:49.614 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:22:49.615 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16509 Type: 2, managed [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:51 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:51 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:51 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 Type: 2, managed [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7526 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7526, 7526, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7542 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:52 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7542, 7542, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:52 TUYA D][mqtt_client.c:1932] packet id: 58 [05-12 16:22:53 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:53 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:53 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [2023-5-12 16:22:52.101 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:22:53 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed net cnt is 9..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 total used free shared buff/cache available Mem: 35568 18324 4824 56 12420 15048 Swap: 0 0 0 wlan0 no wireless extensions. ip_addr: inet addr:192.168.1.190 Bcast:192.168.1.255 Mask:255.255.255.0 wifi_ssid: route_info:default 192.168.1.1 0.0.0.0 UG 0 0 0 wlan0 192.168.1.0 bin config dev drv etc home lib linuxrc mnt opt proc root run sbin sys tmp tuya usr var 255.255.255.0 U 0 0 0 wlan0 reconnect wifi [2023-5-12 16:22:53.058 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1200 step = 3023 p2p num = 0 Type: 2, managed [05-12 16:22:54 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:55 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:55 TUYA D][miniwget.c:482] send ok,get response [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [2023-5-12 16:22:54.535 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1300] run_step [1039] [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 Type: 2, managed [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:55 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6734 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6734, 6734, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7339 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7339, 7339, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:56 TUYA D][mqtt_client.c:1932] packet id: 59 [05-12 16:22:56 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:56 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:56 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:22:56 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [2023-5-12 16:22:56.094 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed [05-12 16:22:58 TUYA D][tuya_ipc_p2p.c:4274] session detect run Type: 2, managed [2023-5-12 16:22:57.104 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [2023-5-12 16:22:57.390 ty_sys_av.c __audio_task(205) Info] loop_cnt = 3000 type = 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:22:58 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:22:58 TUYA D][miniwget.c:482] send ok,get response Type: 2, managed [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:22:58 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 Type: 2, managed [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6915 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6915, 6915, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7884 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7884, 7884, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:22:59 TUYA D][mqtt_client.c:1932] packet id: 60 [05-12 16:22:59 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:22:59 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:22:59 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:22:59 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:22:59 TUYA D][mqc_app.c:1483] pub finish:0 net cnt is 0..MQ_ONLINE is 1.. mq_status is 1.. recnt is 1 Type: 2, managed [2023-5-12 16:22:59.894 ty_sys_av.c __video_task(296) Info] loop_cnt = 2500 type = 1 [2023-5-12 16:22:59.894 ty_sys_av.c __video_task(296) Info] loop_cnt = 2500 type = 0 Type: 2, managed [05-12 16:23:01 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:01 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:01 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [2023-5-12 16:23:1.232 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [3] [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:02 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 Type: 2, managed Type: 2, managed [2023-5-12 16:23:2.108 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 Type: 2, managed [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:03 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [16000] [05-12 16:23:03 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [16000] num[0] [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:03 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [16000] [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7459 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7459, 7459, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 8138 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:03 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(8138, 8138, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:03 TUYA D][mqtt_client.c:1932] packet id: 61 [05-12 16:23:03 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:03 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:03 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:23:04 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [2023-5-12 16:23:3.459 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1300 step = 3023 p2p num = 0 Type: 2, managed [05-12 16:23:04 TUYA D][tuya_devos_health.c:70] feed watchdog Type: 2, managed [2023-5-12 16:23:4.934 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1400] run_step [1039] net cnt is 1..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:06 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:06 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 Type: 2, managed [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:06 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [2023-5-12 16:23:6.098 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [2023-5-12 16:23:6.127 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:23:6.127 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16509 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7454 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7454, 7454, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 8041 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(8041, 8041, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:07 TUYA D][mqtt_client.c:1932] packet id: 62 [05-12 16:23:07 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:07 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:07 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:23:07 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed Type: 2, managed [2023-5-12 16:23:7.112 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:08 TUYA D][tuya_ipc_p2p.c:4274] session detect run Type: 2, managed [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success Type: 2, managed [05-12 16:23:09 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:09 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:09 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:09 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 Type: 2, managed [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:10 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:11 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:11 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 Type: 2, managed [05-12 16:23:12 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:12 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:12 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7540 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:12 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7540, 7540, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:12 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7659 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:12 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7659, 7659, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:12 TUYA D][mqtt_client.c:1932] packet id: 63 [05-12 16:23:12 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:12 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:12 TUYA D][mqc_app.c:1483] pub finish:0 net cnt is 2..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:23:12 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [05-12 16:23:12 TUYA D][tuya_devos_utils.c:275] set time by rtc Type: 2, managed [2023-5-12 16:23:12.117 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [05-12 16:23:14 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:14 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:14 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:14 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:14 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:14 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:14 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:14 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 Type: 2, managed [05-12 16:23:14 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:23:13.860 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1400 step = 3023 p2p num = 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [2023-5-12 16:23:14.230 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [2] [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 Type: 2, managed [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:15 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7593 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:16 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7593, 7593, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:16 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7688 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:16 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7688, 7688, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:16 TUYA D][mqtt_client.c:1932] packet id: 64 [05-12 16:23:16 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:16 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:16 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:23:16 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [2023-5-12 16:23:15.334 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1500] run_step [1039] Type: 2, managed [2023-5-12 16:23:16.102 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed Type: 2, managed [2023-5-12 16:23:17.123 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:18 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [2023-5-12 16:23:17.391 ty_sys_av.c __audio_task(205) Info] loop_cnt = 3500 type = 0 [05-12 16:23:18 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 Type: 2, managed [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 net cnt is 3..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:18 TUYA D][tuya_ipc_p2p.c:4274] session detect run [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:18 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6740 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6740, 6740, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7319 Type: 2, managed [05-12 16:23:19 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:23:19 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [18000] num[0] [05-12 16:23:19 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [18000] UPNP_AddPortMapping 409 clear all n_ret:718 . [05-12 16:23:19 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7319, 7319, 192.168.1.190) failed with code 718 (ConflictInMappingEntry) [05-12 16:23:19 TUYA D][mqtt_client.c:1932] packet id: 65 [05-12 16:23:19 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [18000] [05-12 16:23:19 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:19 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:19 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:23:20 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed Type: 2, managed [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:22 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:22 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:22 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 Type: 2, managed Type: 2, managed [2023-5-12 16:23:22.125 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [2023-5-12 16:23:22.639 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:23:22.639 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16508 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:23 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 Type: 2, managed [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:24 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 Type: 2, managed net cnt is 4..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:23:24 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:23:24.259 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1500 step = 3023 p2p num = 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6958 Type: 2, managed UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6958, 6958, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7534 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7534, 7534, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:25 TUYA D][mqtt_client.c:1932] packet id: 66 [05-12 16:23:25 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:25 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:25 TUYA D][mqc_app.c:1483] pub finish:0 [2023-5-12 16:23:24.893 ty_sys_av.c __video_task(296) Info] loop_cnt = 3000 type = 1 [2023-5-12 16:23:24.894 ty_sys_av.c __video_task(296) Info] loop_cnt = 3000 type = 0 [05-12 16:23:25 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [2023-5-12 16:23:25.734 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1600] run_step [1039] Type: 2, managed [2023-5-12 16:23:26.106 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:28 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:28 TUYA D][miniwget.c:482] send ok,get response Type: 2, managed [2023-5-12 16:23:27.146 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [2023-5-12 16:23:27.230 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [1] [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 Type: 2, managed [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:28 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:29 TUYA D][tuya_ipc_p2p.c:4274] session detect run [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7580 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7580, 7580, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7819 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7819, 7819, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:29 TUYA D][mqtt_client.c:1932] packet id: 67 [05-12 16:23:29 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:29 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:29 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:23:29 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:23:29 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed net cnt is 5..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [05-12 16:23:31 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:31 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:31 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 Type: 2, managed [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:32 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 Type: 2, managed [2023-5-12 16:23:32.165 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 Type: 2, managed [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:33 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:34 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:34 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:34 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:34 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7628 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:34 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7628, 7628, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:34 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 8453 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:34 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(8453, 8453, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:34 TUYA D][mqtt_client.c:1932] packet id: 68 [05-12 16:23:34 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:34 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:34 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:23:34 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [05-12 16:23:34 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:23:34.659 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1600 step = 3023 p2p num = 0 Type: 2, managed [05-12 16:23:36 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [20000] [05-12 16:23:36 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [20000] num[0] [05-12 16:23:36 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [20000] [05-12 16:23:36 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:36 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:36 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:36 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 Type: 2, managed [2023-5-12 16:23:36.110 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [2023-5-12 16:23:36.135 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1700] run_step [1039] net cnt is 6..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 Type: 2, managed [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:37 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 Type: 2, managed [2023-5-12 16:23:37.181 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [2023-5-12 16:23:37.395 ty_sys_av.c __audio_task(205) Info] loop_cnt = 4000 type = 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7332 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7332, 7332, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7968 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7968, 7968, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:38 TUYA D][mqtt_client.c:1932] packet id: 69 [05-12 16:23:38 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:38 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:38 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:23:38 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Login timed out after 60 seconds Tuya login: [05-12 16:23:39 TUYA D][tuya_ipc_p2p.c:4274] session detect run Type: 2, managed [05-12 16:23:39 TUYA D][tuya_devos_health.c:70] feed watchdog [2023-5-12 16:23:39.150 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:23:39.150 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16509 Type: 2, managed [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:40 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:40 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:40 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [2023-5-12 16:23:40.230 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [0] [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:41 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 Type: 2, managed [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6769 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6769, 6769, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7290 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7290, 7290, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:42 TUYA D][mqtt_client.c:1932] packet id: 70 [05-12 16:23:42 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:42 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:42 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:23:42 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [05-12 16:23:42 TUYA D][tuya_devos_utils.c:275] set time by rtc Type: 2, managed [2023-5-12 16:23:42.183 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 net cnt is 7..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 Type: 2, managed [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:44 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:44 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 Type: 2, managed [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:44 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:44 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7403 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7403, 7403, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7649 Type: 2, managed UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:45 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7649, 7649, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:45 TUYA D][mqtt_client.c:1932] packet id: 71 [05-12 16:23:45 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:45 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:45 TUYA D][mqc_app.c:1483] pub finish:0 [2023-5-12 16:23:45.060 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1700 step = 3023 p2p num = 0 [05-12 16:23:46 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [2023-5-12 16:23:46.114 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [2023-5-12 16:23:46.538 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1800] run_step [1039] Type: 2, managed [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:48 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:48 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 Type: 2, managed [2023-5-12 16:23:47.192 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 Type: 2, managed [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:48 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6652 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6652, 6652, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7401 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7401, 7401, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:49 TUYA D][mqtt_client.c:1932] packet id: 72 [05-12 16:23:49 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:49 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:49 TUYA D][mqc_app.c:1483] pub finish:0 net cnt is 8..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 MemTotal: 35568 kB MemFree: 4716 kB MemAvailable: 14956 kB Buffers: 3776 kB Cached: 8656 kB SwapCached: 0 kB Active: 15108 kB Inactive: 6460 kB Active(anon): 9160 kB Inactive(anon): 32 kB Active(file): 5948 kB Inactive(file): 6428 kB Unevictable: 0 kB Mlocked: 0 kB SwapTotal: 0 kB SwapFree: 0 kB Dirty: 0 kB Writeback: 0 kB AnonPages: 9168 kB Mapped: 7536 kB Shmem: 56 kB KReclaimable: 1360 kB Slab: 5616 kB SReclaimable: 1360 kB SUnreclaim: 4256 kB KernelStack: 800 kB PageTables: 320 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 17784 kB Committed_AS: 95832 kB VmallocTotal: 974848 kB VmallocUsed: 1312 kB VmallocChunk: 0 kB Percpu: 32 kB CmaTotal: 0 kB CmaFree: 0 kB [05-12 16:23:49 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [05-12 16:23:49 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:23:50 TUYA D][tuya_ipc_p2p.c:4274] session detect run [05-12 16:23:50 TUYA D][mqtt_client.c:238] host[m2.tuyacn.com] mqtt_ping -->> [05-12 16:23:50 TUYA D][mqtt_client.c:256] host[m2.tuyacn.com] mqtt_ping <<-- [05-12 16:23:50 TUYA D][mqtt_client.c:1346] host[m2.tuyacn.com] ping respond. update fail_cnt:0 [05-12 16:23:50 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 Type: 2, managed [2023-5-12 16:23:49.893 ty_sys_av.c __video_task(296) Info] loop_cnt = 3500 type = 1 [2023-5-12 16:23:49.893 ty_sys_av.c __video_task(296) Info] loop_cnt = 3500 type = 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:51 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:51 TUYA D][miniwget.c:482] send ok,get response Type: 2, managed [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:51 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:52 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [22000] [05-12 16:23:52 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [22000] num[0] [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:52 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [22000] [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6900 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6900, 6900, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7684 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7684, 7684, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:52 TUYA D][mqtt_client.c:1932] packet id: 73 [05-12 16:23:52 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:52 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:52 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:23:52 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [2023-5-12 16:23:52.197 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [2023-5-12 16:23:53.234 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [1] Type: 2, managed [05-12 16:23:54 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:23:54 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:54 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:54 TUYA D][miniwget.c:482] send ok,get response [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 Type: 2, managed [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 net cnt is 9..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 total used free shared buff/cache available Mem: 35568 18356 4792 56 12420 15016 Swap: 0 0 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7398 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7398, 7398, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7638 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:55 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7638, 7638, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:55 TUYA D][mqtt_client.c:1932] packet id: 74 wlan0 no wireless extensions. [05-12 16:23:56 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:56 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:56 TUYA D][mqc_app.c:1483] pub finish:0 ip_addr: inet addr:192.168.1.190 Bcast:192.168.1.255 Mask:255.255.255.0 wifi_ssid: route_info:default 192.168.1.1 0.0.0.0 UG 0 0 0 wlan0 192.168.1.0 bin config dev drv etc home lib linuxrc mnt opt proc root run sbin sys tmp tuya usr var 255.255.255.0 U 0 0 0 wlan0 reconnect wifi [05-12 16:23:56 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [2023-5-12 16:23:55.460 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1800 step = 3023 p2p num = 0 [2023-5-12 16:23:55.662 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:23:55.663 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16509 Type: 2, managed [2023-5-12 16:23:56.118 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run Type: 2, managed [2023-5-12 16:23:56.938 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [1900] run_step [1039] Type: 2, managed [2023-5-12 16:23:57.204 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:23:58 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:23:58 TUYA D][miniwget.c:482] send ok,get response [2023-5-12 16:23:57.395 ty_sys_av.c __audio_task(205) Info] loop_cnt = 4500 type = 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 Type: 2, managed [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:23:58 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6999 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6999, 6999, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7918 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7918, 7918, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:23:59 TUYA D][mqtt_client.c:1932] packet id: 75 [05-12 16:23:59 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:23:59 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:23:59 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:23:59 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed [05-12 16:23:59 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:24:00 TUYA D][tuya_ipc_p2p.c:4274] session detect run Type: 2, managed [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:24:01 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:24:01 TUYA D][miniwget.c:482] send ok,get response [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 Type: 2, managed [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:24:01 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6819 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6819, 6819, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6987 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6987, 6987, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:02 TUYA D][mqtt_client.c:1932] packet id: 76 [05-12 16:24:02 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:24:02 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:24:02 TUYA D][mqc_app.c:1483] pub finish:0 net cnt is 0..MQ_ONLINE is 1.. mq_status is 1.. recnt is 1 [05-12 16:24:02 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... Type: 2, managed Type: 2, managed [2023-5-12 16:24:2.201 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 Type: 2, managed [05-12 16:24:04 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:24:04 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:24:04 TUYA D][miniwget.c:482] send ok,get response Type: 2, managed [05-12 16:24:04 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 Type: 2, managed [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:24:05 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7208 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7208, 7208, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 8215 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(8215, 8215, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:06 TUYA D][mqtt_client.c:1932] packet id: 77 [05-12 16:24:06 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:24:06 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:24:06 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:24:06 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [2023-5-12 16:24:5.858 ty_user_event.c __event_task(3963) Debug] loop_cnt = 1900 step = 3023 p2p num = 0 Type: 2, managed [2023-5-12 16:24:6.122 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [2023-5-12 16:24:6.234 app_sys_ptz.c __do_patrol_point(922) Debug] patrol index: [2] Type: 2, managed Type: 2, managed [2023-5-12 16:24:7.204 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [2023-5-12 16:24:7.338 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [2000] run_step [1039] [05-12 16:24:08 TUYA D][tuya_ipc_p2p.c:3512] session cmd recv proc alive [24000] num[0] [05-12 16:24:08 TUYA D][tuya_ipc_p2p.c:3868] media send proc alive [24000] [05-12 16:24:08 TUYA D][tuya_ipc_p2p.c:2049] media recv proc alive [24000] net cnt is 1..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:24:08 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:24:08 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:24:08 TUYA D][miniwget.c:482] send ok,get response Type: 2, managed [05-12 16:24:08 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:24:08 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:24:08 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:24:08 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:24:08 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:24:09 TUYA D][tuya_devos_health.c:70] feed watchdog [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 Type: 2, managed [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:24:09 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:10 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:10 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7261 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:10 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7261, 7261, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:10 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7719 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:10 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7719, 7719, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:10 TUYA D][mqtt_client.c:1932] packet id: 78 [05-12 16:24:10 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:24:10 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:24:10 TUYA D][mqc_app.c:1483] pub finish:0 [05-12 16:24:10 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:24:10 TUYA D][tuya_ipc_p2p.c:4274] session detect run Type: 2, managed Type: 2, managed [05-12 16:24:12 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:24:12 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:24:12 TUYA D][miniwget.c:482] send ok,get response [05-12 16:24:12 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 Type: 2, managed [05-12 16:24:12 TUYA D][tuya_devos_utils.c:275] set time by rtc [05-12 16:24:12 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:24:12 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:24:12 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:24:12 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:24:12 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [2023-5-12 16:24:12.175 ty_wheel_timer.c __execute_expired_timeouts(263) Debug] [2023-5-12 16:24:12.175 ty_wheel_timer.c __wait_for_next_tick(357) Debug] sleep 16508 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 Type: 2, managed [2023-5-12 16:24:12.219 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 6736 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6736, 6736, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7173 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7173, 7173, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:13 TUYA D][mqtt_client.c:1932] packet id: 79 [05-12 16:24:13 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:24:13 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:24:13 TUYA D][mqc_app.c:1483] pub finish:0 Type: 2, managed [05-12 16:24:13 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... net cnt is 2..MQ_ONLINE is 1.. mq_status is 1.. recnt is 0 [05-12 16:24:14 TUYA D][tuya_devos_health.c:70] feed watchdog Type: 2, managed [2023-5-12 16:24:14.894 ty_sys_av.c __video_task(296) Info] loop_cnt = 4000 type = 0 [2023-5-12 16:24:14.894 ty_sys_av.c __video_task(296) Info] loop_cnt = 4000 type = 1 Type: 2, managed [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1438] [UPnP]upnpDiscover success [05-12 16:24:16 TUYA D][miniwget.c:422] get socket ip 192.168.1.190,len 13 [05-12 16:24:16 TUYA D][miniwget.c:482] send ok,get response [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 0 UDP 1588->192.168.1.102:1588 'Ty-UDP-1588-000000000000' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 1 UDP 1957->192.168.1.102:1957 'Ty-UDP-1957-000000000000' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 2 UDP 5938->192.168.1.102:5938 'Ty-UDP-5938-000000000000' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 3 UDP 8000->192.168.1.102:8000 'Ty-UDP-8000-000000000000' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 4 UDP 5000->192.168.1.102:5000 'Ty-UDP-5000-000000000000' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 5 UDP 5557->192.168.1.102:5557 'Ty-UDP-5557-00e04ca8df27' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 6 UDP 8847->192.168.1.102:8847 'Ty-UDP-8847-00e04ca8df27' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 7 UDP 5508->192.168.1.102:5508 'Ty-UDP-5508-00e04ca8df27' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 8 UDP 8515->192.168.1.102:8515 'Ty-UDP-8515-00e04ca8df27' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 9 UDP 5047->192.168.1.102:5047 'Ty-UDP-5047-00e04ca8df27' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 10 UDP 6266->192.168.1.104:6266 'Ty-UDP-6266-00e04c679e1c' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 11 UDP 7507->192.168.1.104:7507 'Ty-UDP-7507-00e04c679e1c' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 12 UDP 8180->192.168.1.104:8180 'Ty-UDP-8180-00e04c679e1c' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 13 UDP 8637->192.168.1.104:8637 'Ty-UDP-8637-00e04c679e1c' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 14 UDP 5098->192.168.1.104:5098 'Ty-UDP-5098-00e04c679e1c' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 15 UDP 3377->192.168.1.105:3377 'Ty-UDP-3377-00e04cf58d38' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 16 UDP 2093->192.168.1.105:2093 'Ty-UDP-2093-00e04cf58d38' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 17 UDP 1309->192.168.1.105:1309 'Ty-UDP-1309-00e04cf58d38' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 18 UDP 8566->192.168.1.105:8566 'Ty-UDP-8566-00e04cf58d38' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 19 UDP 5540->192.168.1.105:5540 'Ty-UDP-5540-00e04cf58d38' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 20 UDP 3878->192.168.1.107:3878 'Ty-UDP-3878-ec3dfd3477af' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 21 UDP 8332->192.168.1.107:8332 'Ty-UDP-8332-ec3dfd3477af' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 22 UDP 9079->192.168.1.107:9079 'Ty-UDP-9079-ec3dfd3477af' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 23 UDP 8840->192.168.1.107:8840 'Ty-UDP-8840-ec3dfd3477af' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 24 UDP 5079->192.168.1.107:5079 'Ty-UDP-5079-ec3dfd3477af' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 25 UDP 1138->192.168.1.109:1138 'Ty-UDP-1138-00e04c9d8463' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 26 UDP 1791->192.168.1.109:1791 'Ty-UDP-1791-00e04c9d8463' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 27 UDP 6731->192.168.1.109:6731 'Ty-UDP-6731-00e04c9d8463' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 28 UDP 8015->192.168.1.109:8015 'Ty-UDP-8015-00e04c9d8463' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 29 UDP 5376->192.168.1.109:5376 'Ty-UDP-5376-00e04c9d8463' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 30 UDP 7142->192.168.1.110:7142 'Ty-UDP-7142-00e04c9453d0' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 31 UDP 7319->192.168.1.110:7319 'Ty-UDP-7319-00e04c9453d0' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 32 UDP 2406->192.168.1.110:2406 'Ty-UDP-2406-00e04c9453d0' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 33 UDP 8061->192.168.1.110:8061 'Ty-UDP-8061-00e04c9453d0' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 34 UDP 5384->192.168.1.110:5384 'Ty-UDP-5384-00e04c9453d0' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 35 UDP 3432->192.168.1.111:3432 'Ty-UDP-3432-00e04cfd3ed1' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 36 UDP 5325->192.168.1.111:5325 'Ty-UDP-5325-00e04cfd3ed1' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 37 UDP 1485->192.168.1.111:1485 'Ty-UDP-1485-00e04cfd3ed1' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 38 UDP 8816->192.168.1.111:8816 'Ty-UDP-8816-00e04cfd3ed1' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 39 UDP 5316->192.168.1.111:5316 'Ty-UDP-5316-00e04cfd3ed1' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 40 UDP 5125->192.168.1.112:5125 'Ty-UDP-5125-00e04cc736f3' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 41 UDP 4816->192.168.1.112:4816 'Ty-UDP-4816-00e04cc736f3' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 42 UDP 5939->192.168.1.112:5939 'Ty-UDP-5939-00e04cc736f3' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 43 UDP 8470->192.168.1.112:8470 'Ty-UDP-8470-00e04cc736f3' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 44 UDP 5793->192.168.1.112:5793 'Ty-UDP-5793-00e04cc736f3' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 45 UDP 8387->192.168.1.113:8387 'Ty-UDP-8387-00e04c4df13b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 46 UDP 4129->192.168.1.113:4129 'Ty-UDP-4129-00e04c4df13b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 47 UDP 9199->192.168.1.113:9199 'Ty-UDP-9199-00e04c4df13b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 48 UDP 8479->192.168.1.113:8479 'Ty-UDP-8479-00e04c4df13b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 49 UDP 5854->192.168.1.113:5854 'Ty-UDP-5854-00e04c4df13b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 50 UDP 4758->192.168.1.114:4758 'Ty-UDP-4758-00e04c26ab74' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 51 UDP 6036->192.168.1.114:6036 'Ty-UDP-6036-00e04c26ab74' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 52 UDP 1939->192.168.1.114:1939 'Ty-UDP-1939-00e04c26ab74' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 53 UDP 8930->192.168.1.114:8930 'Ty-UDP-8930-00e04c26ab74' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 54 UDP 5234->192.168.1.114:5234 'Ty-UDP-5234-00e04c26ab74' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 55 UDP 6389->192.168.1.115:6389 'Ty-UDP-6389-00e04cc0c59d' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 56 UDP 7731->192.168.1.115:7731 'Ty-UDP-7731-00e04cc0c59d' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 57 UDP 8137->192.168.1.115:8137 'Ty-UDP-8137-00e04cc0c59d' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 58 UDP 5258->192.168.1.115:5258 'Ty-UDP-5258-00e04cc0c59d' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 59 UDP 7802->192.168.1.116:7802 'Ty-UDP-7802-00e04c2cfa7b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 60 UDP 6029->192.168.1.116:6029 'Ty-UDP-6029-00e04c2cfa7b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 61 UDP 8219->192.168.1.116:8219 'Ty-UDP-8219-00e04c2cfa7b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 62 UDP 8998->192.168.1.116:8998 'Ty-UDP-8998-00e04c2cfa7b' '' 0 [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1126] 63 UDP 5475->192.168.1.116:5475 'Ty-UDP-5475-00e04c2cfa7b' '' 0 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(6633, 6633, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7059 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7059, 7059, 192.168.1.190) failed with code 501 (Action Failed) [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1322] [UPnP]try another port: 7269 UPNP_AddPortMapping 409 clear all n_ret:501 . [05-12 16:24:16 TUYA D][tuya_upnp_module_mg.c:1315] [UPnP]AddPortMapping(7269, 7269, 192.168.1.190) failed with code 501 (Action Failed) Type: 2, managed [05-12 16:24:16 TUYA D][mqtt_client.c:1932] packet id: 80 [2023-5-12 16:24:16.126 ty_sys.c __ty_sys_loop(1566) Debug] sys loop run [05-12 16:24:17 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING... [05-12 16:24:17 TUYA D][mqc_app.c:1440] custom async cb op_ret: 0 [05-12 16:24:17 TUYA D][mqtt_client.c:1510] mqtt[m2.tuyacn.com] status:7 [05-12 16:24:17 TUYA D][mqc_app.c:1483] pub finish:0 [2023-5-12 16:24:16.259 ty_user_event.c __event_task(3963) Debug] loop_cnt = 2000 step = 3023 p2p num = 0 Type: 2, managed Type: 2, managed [2023-5-12 16:24:17.223 ty_wifi.c tkl_wifi_get_ip(557) Debug] WIFI[0] Get IP:192.168.1.190 [2023-5-12 16:24:17.394 ty_sys_av.c __audio_task(205) Info] loop_cnt = 5000 type = 0 [2023-5-12 16:24:17.738 ty_sys.c __sys_msg_proc(1080) Debug] main msg loop [2100] run_step [1039] Type: 2, managed [05-1
