[07-18 17:56:28:1 TUYA Debug][tuya_ipc_log.c:44] ---tuya_ipc_log_setting end--- [07-18 17:56:28:1 TUYA Debug][tuya_ipc_webrtc.c:718] begin___ [07-18 17:56:28:1 TUYA Debug][tuya_ipc_webrtc.c:725] --audio-:8000,format:101 [07-18 17:56:28:1 TUYA Debug][tuya_ipc_webrtc.c:726] end___ audiocbk_hdl(0x4979f8) [07-18 17:56:28:1 TUYA Debug][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5443] gw actived [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5452] p2p max_client_num[10] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5453] p2p init media info: [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5103] video codec[18] fps[30] gop[30] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5104] height[360] width[640] bitrate[1024] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5103] video codec[18] fps[30] gop[30] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5104] height[360] width[640] bitrate[512] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5114] video codec[18] fps[30] gop[30] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5115] height[360] width[640] bitrate[1024] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5114] video codec[18] fps[30] gop[30] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5115] height[360] width[640] bitrate[512] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5114] video codec[0] fps[0] gop[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5115] height[0] width[0] bitrate[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5114] video codec[0] fps[0] gop[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5115] height[0] width[0] bitrate[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5114] video codec[0] fps[0] gop[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5115] height[0] width[0] bitrate[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5114] video codec[0] fps[0] gop[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5115] height[0] width[0] bitrate[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5114] video codec[0] fps[0] gop[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5115] height[0] width[0] bitrate[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5114] video codec[0] fps[0] gop[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5115] height[0] width[0] bitrate[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5117] audio codec[129] sample[0] [07-18 17:56:28:1 TUYA Debug][tuya_ipc_p2p.c:5118] databits[1] channel[0] [07-18 17:56:28:1 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:28:1 TUYA Trace][iot_httpc.c:940] api[tuya.device.ability.get] hash[0x74865230] [07-18 17:56:28:1 TUYA Debug][iot_httpc.c:984] Post Data: {"t":1689674188} [07-18 17:56:28:1 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ability.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=fa520655843bf1cf45050bcabadd17e3 [07-18 17:56:28:1 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:28:1 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:28:1 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.ability.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=fa520655843bf1cf45050bcabadd17e3 [07-18 17:56:28:1 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 17:56:28:1 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 17:56:28:1 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 17:56:28:1 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 17:56:28:1 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 17:56:28:1 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 17:56:28:1 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 17:56:28:19 TUYA Trace][httpc.c:560] Connected .. sockfd: 53 [07-18 17:56:28:19 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 17:56:28:19 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 17:56:28:19 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 17:56:28:20 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 17:56:28:20 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 17:56:28:20 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 17:56:28:35 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 17:56:28:35 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 17:56:28:35 TUYA Trace][httpc.c:952] Have to extract [07-18 17:56:28:35 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:28:35 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:28:35 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.ability.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=fa520655843bf1cf45050bcabadd17e3 [07-18 17:56:28:35 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 17:56:28:35 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.ability.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=fa520655843bf1cf45050bcabadd17e3 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 69 [07-18 17:56:28:35 TUYA Trace][httpc.c:996] content len:69 [07-18 17:56:28:35 TUYA Trace][httpc.c:343] Start header read [07-18 17:56:28:69 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:28:69 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:83 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 17:56:28:83 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: 37561cfdcfc048218c0127e753e31223 content-type: application/json;charset=UTF-8 content-length: 163 date: Tue, 18 Jul 2023 09:56:27 GMT server: https {"result":"k7CoOL2p4eJ5cBguHv7a+yAli2q6qO4UMngbPUAKMTjC5R23r8ltkmrz0Mt1C3j3T4Jrfsk5g0RMCL+fnt38C8rI2rR7UtbCLXnGExyY+bs=","sign":"869b43e57074bdd7","t":1689674188} [07-18 17:56:28:83 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 17:56:28:83 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 349 bytes header [07-18 17:56:28:83 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:164 [07-18 17:56:28:83 TUYA Trace][httpc.c:1748] contentlen:163 size_remain:163 size_to_read:163 [07-18 17:56:28:83 TUYA Trace][httpc.c:425] Using prefetch: 186 163 163 163 [07-18 17:56:28:83 TUYA Trace][iot_httpc.c:807] RESP:{"result":"k7CoOL2p4eJ5cBguHv7a+yAli2q6qO4UMngbPUAKMTjC5R23r8ltkmrz0Mt1C3j3T4Jrfsk5g0RMCL+fnt38C8rI2rR7UtbCLXnGExyY+bs=","sign":"869b43e57074bdd7","t":1689674188} [07-18 17:56:28:83 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 17:56:28:83 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":{"video":1,"audio":1,"map":1},"t":1689674188,"success":true} [07-18 17:56:28:84 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 17:56:28:84 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 17:56:28:84 TUYA Info][tuya_ipc_p2p.c:2697] http_device_ability_get OK! [07-18 17:56:28:84 TUYA Debug][tuya_ipc_p2p.c:5479] need speaker audio codec[131] sample[7] databits[1] channel[0] defLiveMode[0] [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[0]=0x0x7f7c00fe30 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[1]=0x0x7f7c00feb0 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[2]=0x0x7f7c00ff30 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[3]=0x0x7f7c00ffb0 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[4]=0x0x7f7c010030 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[5]=0x0x7f7c0100b0 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[6]=0x0x7f7c010130 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[7]=0x0x7f7c0101b0 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[8]=0x0x7f7c010230 [07-18 17:56:28:84 TUYA Err][tuya_ipc_p2p.c:5496] av_mutex[9]=0x0x7f7c0102b0 [07-18 17:56:28:84 TUYA Debug][simplekv.c:1188] read key:p2p_pwd isFuzzy:0 skipCnt:0 [07-18 17:56:28:84 TUYA Debug][simplekv.c:1228] find key:5 p2p_pwd [07-18 17:56:28:84 TUYA Debug][simplekv.c:1257] key:p2p_pwd find value.Len:16 [07-18 17:56:28:84 TUYA Debug][tuya_ipc_p2p_common.c:264] get p2p passwd = adb63309 [07-18 17:56:28:84 TUYA Debug][tuya_ipc_p2p_common.c:387] check p2p auth update or not [07-18 17:56:28:84 TUYA Debug][simplekv.c:1188] read key:p2p_auth_info isFuzzy:0 skipCnt:0 [07-18 17:56:28:84 TUYA Debug][simplekv.c:1228] find key:4 p2p_auth_info [07-18 17:56:28:84 TUYA Debug][simplekv.c:1257] key:p2p_auth_info find value.Len:32 [07-18 17:56:28:84 TUYA Debug][simplekv.c:1188] read key:p2p_type isFuzzy:0 skipCnt:0 [07-18 17:56:28:84 TUYA Debug][simplekv.c:1228] find key:6 p2p_type [07-18 17:56:28:84 TUYA Debug][simplekv.c:1257] key:p2p_type find value.Len:16 [07-18 17:56:28:84 TUYA Debug][tuya_ipc_p2p_common.c:458] no need update p2p_auth_info from service [07-18 17:56:28:84 TUYA Debug][simplekv.c:1188] read key:p2p_auth_info isFuzzy:0 skipCnt:0 [07-18 17:56:28:84 TUYA Debug][simplekv.c:1228] find key:4 p2p_auth_info [07-18 17:56:28:84 TUYA Debug][simplekv.c:1257] key:p2p_auth_info find value.Len:32 [07-18 17:56:28:84 TUYA Debug][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4} [07-18 17:56:28:84 TUYA Debug][tuya_ipc_p2p.c:5536] p2p did[] apiLicense[] initString[] [07-18 17:56:28:84 TUYA Debug][tuya_ipc_p2p.c:5539] support p2p type = 4 [07-18 17:56:28:84 TUYA Debug][tuya_ipc_p2p.c:5294] no encrypt [07-18 17:56:28:128 TUYA Debug][tuya_ipc_p2p.c:5345] _mqtt_p2p_listen_sessions create [07-18 17:56:28:128 TUYA Err][tuya_ipc_p2p.c:5547] p2p v3 init ok [07-18 17:56:28:128 TUYA Debug][tuya_ipc_p2p.c:5587] speaker task create success [07-18 17:56:28:128 TUYA Debug][tuya_ipc_p2p.c:5630] __p2p_session_detech create [07-18 17:56:28:128 TUYA Debug][tuya_ipc_p2p.c:4974] Begin to session detech [07-18 17:56:28:128 TUYA Debug][tuya_ipc_p2p.c:5647] __p2p_video_send_proc create ok [07-18 17:56:28:128 TUYA Debug][tuya_ipc_p2p.c:4432] Begin to Listen mqtt p2p client connects In Thread [07-18 17:56:28:128 TUYA Debug][tuya_ipc_p2p.c:4445] mqtt p2p LISTEN session........ [07-18 17:56:28:129 TUYA Err][tuya_ipc_streamer.c:1553] tstream init start [07-18 17:56:28:129 TUYA Debug][tuya_ipc_packager.c:62] get packager instance [07-18 17:56:28:129 TUYA Debug][tuya_ipc_packager.c:72] get packager instance done [07-18 17:56:28:129 TUYA Debug][tuya_ipc_p2p.c:4060] into p2p video send [07-18 17:56:28:129 TUYA Debug][simplekv.c:1188] read key:cloud_enc_key isFuzzy:0 skipCnt:0 [07-18 17:56:28:129 TUYA Debug][simplekv.c:1228] find key:3 cloud_enc_key [07-18 17:56:28:129 TUYA Debug][simplekv.c:1257] key:cloud_enc_key find value.Len:32 [07-18 17:56:28:129 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [0] [07-18 17:56:28:129 TUYA Debug][tuya_ipc_encrypt.c:187] use key :1f64db62aad74b6a [07-18 17:56:28:129 TUYA Err][tuya_ring_buffer.c:1201] RingBuffer ch0st0tr0 Not Inited [07-18 17:56:28:129 TUYA Info][uni_thread.c:220] thread_create name:streamer,stackDepth:8192,totalstackDepth:29184,priority:3 [07-18 17:56:28:129 TUYA Err][tuya_ipc_streamer.c:1621] tstream init done [07-18 17:56:28:129 TUYA Debug][uni_thread.c:247] Thread:streamer Exec Start. Set to Running Stat [07-18 17:56:28:129 TUYA Debug][tuya_ipc_streamer.c:1338] ThreadStreaming thread start [07-18 17:56:28:129 TUYA Debug][tuya_ipc_streamer.c:1349] local key Mro9dY$MHLv!DTHz [07-18 17:56:28:129 TUYA Debug][tuya_ipc_moto_mqtt.c:59] topic already booked! [07-18 17:56:28:129 TUYA Debug][tuya_ipc_streamer.c:1508] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":2,\"sampleRate\":90000,\"profileId\":\"\",\"width\":640,\"height\":360},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}] [07-18 17:56:28:129 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:28:129 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:28:129 TUYA Trace][iot_httpc.c:940] api[tuya.device.skill.update] hash[0x78018f3c] [07-18 17:56:28:129 TUYA Debug][iot_httpc.c:984] Post Data: {"skill":"{\"sdk_version\":\"1.0.6\",\"cloudGW\":1,\"webrtc\":51,\"p2p\":35,\"video_num\":0,\"videos\":[{\"streamType\":2,\"codecType\":2,\"sampleRate\":90000,\"profileId\":\"\",\"width\":640,\"height\":360},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]}","t":1689674188} [07-18 17:56:28:129 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=539188133793f00ea81f2ab00bc29f92 [07-18 17:56:28:129 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:28:129 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:28:129 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.skill.update&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=539188133793f00ea81f2ab00bc29f92 [07-18 17:56:28:129 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 17:56:28:129 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 17:56:28:129 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 17:56:28:129 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 17:56:28:130 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 17:56:28:130 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 17:56:28:130 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 17:56:28:130 TUYA Debug][tuya_ipc_p2p.c:3732] New Thread To proc, init source [07-18 17:56:28:130 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [0] num[0] [07-18 17:56:28:147 TUYA Trace][httpc.c:560] Connected .. sockfd: 54 [07-18 17:56:28:147 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 17:56:28:147 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 17:56:28:147 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 17:56:28:147 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 17:56:28:148 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 17:56:28:148 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 17:56:28:163 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 17:56:28:163 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 17:56:28:163 TUYA Trace][httpc.c:952] Have to extract [07-18 17:56:28:163 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:28:163 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:28:163 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.skill.update&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=539188133793f00ea81f2ab00bc29f92 [07-18 17:56:28:169 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:28:169 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:28:169 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 17:56:28:169 TUYA Trace][iot_httpc.c:940] api[tuya.device.log.report] hash[0x9f81e2a5] [07-18 17:56:28:169 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.skill.update&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=539188133793f00ea81f2ab00bc29f92 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 805 [07-18 17:56:28:170 TUYA Debug][iot_httpc.c:984] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.3, Jul 11 2023 14:10:31\"}","t":1689674188} [07-18 17:56:28:170 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=72c2b1a2284a1b14a4e5ee2f5dd90583 [07-18 17:56:28:170 TUYA Trace][httpc.c:996] content len:805 [07-18 17:56:28:170 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:28:170 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:28:170 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=72c2b1a2284a1b14a4e5ee2f5dd90583 [07-18 17:56:28:170 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 17:56:28:170 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 17:56:28:170 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 17:56:28:170 TUYA Trace][httpc.c:343] Start header read [07-18 17:56:28:170 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 17:56:28:170 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 17:56:28:170 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 17:56:28:170 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 17:56:28:185 TUYA Trace][httpc.c:560] Connected .. sockfd: 55 [07-18 17:56:28:185 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 17:56:28:185 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 17:56:28:185 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 17:56:28:185 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 17:56:28:185 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 17:56:28:186 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 17:56:28:202 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 17:56:28:202 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 17:56:28:202 TUYA Trace][httpc.c:952] Have to extract [07-18 17:56:28:202 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:28:202 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:28:202 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=72c2b1a2284a1b14a4e5ee2f5dd90583 [07-18 17:56:28:202 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 17:56:28:202 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674188&v=1.0&sign=72c2b1a2284a1b14a4e5ee2f5dd90583 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 261 [07-18 17:56:28:202 TUYA Trace][httpc.c:996] content len:261 [07-18 17:56:28:202 TUYA Trace][httpc.c:343] Start header read [07-18 17:56:28:207 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 17:56:28:207 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: edeb5688d6014f609fb536993e88e3e4 content-type: application/json;charset=UTF-8 content-length: 99 date: Tue, 18 Jul 2023 09:56:28 GMT server: https {"result":"TE3Lxz3TBxABeD791UxGAeSh3elIWzIetYdBV37pmfo=","sign":"6bf32cbbb9214ed4","t":1689674188} [07-18 17:56:28:207 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 17:56:28:207 TUYA Trace][httpc.c:1516] Header has used up 185 bytes from the 284 bytes header [07-18 17:56:28:207 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:100 [07-18 17:56:28:207 TUYA Trace][httpc.c:1748] contentlen:99 size_remain:99 size_to_read:99 [07-18 17:56:28:207 TUYA Trace][httpc.c:425] Using prefetch: 185 99 99 99 [07-18 17:56:28:207 TUYA Trace][iot_httpc.c:807] RESP:{"result":"TE3Lxz3TBxABeD791UxGAeSh3elIWzIetYdBV37pmfo=","sign":"6bf32cbbb9214ed4","t":1689674188} [07-18 17:56:28:207 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 17:56:28:207 TUYA Debug][iot_httpc.c:663] Decode Rev:{"t":1689674188,"success":true} [07-18 17:56:28:207 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 17:56:28:207 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 17:56:28:207 TUYA Debug][tuya_ipc_skill.c:201] upload data: {\"sdk_version\":\"1.0.6\",\"cloudGW\":1,\"webrtc\":51,\"p2p\":35,\"video_num\":0,\"videos\":[{\"streamType\":2,\"codecType\":2,\"sampleRate\":90000,\"profileId\":\"\",\"width\":640,\"height\":360},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]} [07-18 17:56:28:207 TUYA Debug][tuya_ring_buffer.c:437] Init Ring Buffer. ch0st0tr0 bitrate:1024 fps:30 [07-18 17:56:28:207 TUYA Debug][tuya_ring_buffer.c:462] Ring buffer malloc 1310720 bytes for ch0st0tr0, max frame size 196608 [07-18 17:56:28:209 TUYA Info][tuya_ring_buffer.c:481] Init Ring Buffer success: ch0st0tr0 size:1310720 nodes:300 [07-18 17:56:28:209 TUYA Debug][tuya_ring_buffer.c:437] Init Ring Buffer. ch0st0tr1 bitrate:512 fps:30 [07-18 17:56:28:209 TUYA Debug][tuya_ring_buffer.c:462] Ring buffer malloc 655360 bytes for ch0st0tr1, max frame size 98304 [07-18 17:56:28:210 TUYA Info][tuya_ring_buffer.c:481] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:300 [07-18 17:56:28:210 TUYA Debug][tuya_ring_buffer.c:437] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25 [07-18 17:56:28:210 TUYA Debug][tuya_ring_buffer.c:462] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936 [07-18 17:56:28:210 TUYA Info][tuya_ring_buffer.c:481] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250 [07-18 17:56:28:241 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 17:56:28:241 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: 685b3b091fff4fed9dd0c3b2fe6f2887 content-type: application/json;charset=UTF-8 content-length: 119 date: Tue, 18 Jul 2023 09:56:28 GMT server: https {"result":"ZeQSvBEdHjHl1j5RF4jn6N38CxN5ipmNn0hCNXxQZe8EQif8+0oQ6avZeQooIEYp","sign":"a06ace2626c1bc04","t":1689674188} [07-18 17:56:28:241 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 17:56:28:241 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 305 bytes header [07-18 17:56:28:241 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:120 [07-18 17:56:28:241 TUYA Trace][httpc.c:1748] contentlen:119 size_remain:119 size_to_read:119 [07-18 17:56:28:241 TUYA Trace][httpc.c:425] Using prefetch: 186 119 119 119 [07-18 17:56:28:241 TUYA Trace][iot_httpc.c:807] RESP:{"result":"ZeQSvBEdHjHl1j5RF4jn6N38CxN5ipmNn0hCNXxQZe8EQif8+0oQ6avZeQooIEYp","sign":"a06ace2626c1bc04","t":1689674188} [07-18 17:56:28:242 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 17:56:28:242 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":true,"t":1689674188,"success":true} [07-18 17:56:28:242 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 17:56:28:242 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 17:56:28:613 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:613 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:613 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:613 TUYA Debug][smart_frame.c:353] dp<28> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:613 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:613 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"28":0} [07-18 17:56:28:614 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:614 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:614 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:620 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:620 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 17:56:28:620 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 17:56:28:637 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58339 Q:1 Data:{"dps":{"28":0}} [07-18 17:56:28:637 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:638 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:638 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:638 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:638 TUYA Debug][smart_frame.c:353] dp<4> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:638 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:638 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"4":"standy_mode"} [07-18 17:56:28:645 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58340 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 17:56:28:645 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:660 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:660 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:660 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:660 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:28:660 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"28":0}}, mqtt async dp cb:0 [07-18 17:56:28:660 TUYA Trace][smart_frame.c:2512] DP ID 28 Set To 3 [07-18 17:56:28:660 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:28, curr_t:1689674188, rept_cnt:1. [07-18 17:56:28:660 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:28, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:660 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:28, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:667 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58341 Q:1 Data:{"dps":{"4":"standy_mode"}} [07-18 17:56:28:667 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:668 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:668 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:668 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:668 TUYA Debug][smart_frame.c:353] dp<5> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:668 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:668 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"5":"standby"} [07-18 17:56:28:685 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:685 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:685 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:685 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:693 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 17:56:28:693 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:1. [07-18 17:56:28:693 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:693 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:693 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58342 Q:1 Data:{"dps":{"5":"standby"}} [07-18 17:56:28:694 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:694 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:694 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:694 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:694 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:694 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 17:56:28:694 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 17:56:28:694 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:694 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:694 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:694 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:694 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qwAAAAAHMwAXAAYAAA=="}, retrans:1 [07-18 17:56:28:694 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qwAAAAAHMwAXAAYAAA=="} [07-18 17:56:28:719 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:719 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:719 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:719 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:719 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:28:719 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"4":"standy_mode"}}, mqtt async dp cb:0 [07-18 17:56:28:719 TUYA Trace][smart_frame.c:2512] DP ID 4 Set To 3 [07-18 17:56:28:719 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:4, curr_t:1689674188, rept_cnt:1. [07-18 17:56:28:719 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:4, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:719 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:4, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:727 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58343 Q:1 Data:{"dps":{"15":"qwAAAAAHMwAXAAYAAA=="}} [07-18 17:56:28:727 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:737 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58344 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 17:56:28:738 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:745 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:745 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:745 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:745 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:745 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:28:745 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"5":"standby"}}, mqtt async dp cb:0 [07-18 17:56:28:746 TUYA Trace][smart_frame.c:2512] DP ID 5 Set To 3 [07-18 17:56:28:746 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:5, curr_t:1689674188, rept_cnt:1. [07-18 17:56:28:746 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:5, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:746 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:5, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:770 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:770 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:770 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:771 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:771 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 17:56:28:771 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:2. [07-18 17:56:28:771 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:771 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:796 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:796 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:796 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:796 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:803 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 17:56:28:803 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:3. [07-18 17:56:28:803 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:803 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:821 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:821 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:821 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:821 TUYA Debug][smart_frame.c:353] dp<27> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:821 TUYA Debug][smart_frame.c:357] dp_cntl bool:0, dp_data bool:0 [07-18 17:56:28:821 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:822 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"27":false} [07-18 17:56:28:831 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:850 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58345 Q:1 Data:{"dps":{"27":false}} [07-18 17:56:28:850 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:851 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:851 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:851 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:851 TUYA Debug][smart_frame.c:353] dp<9> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:851 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:851 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"9":"normal"} [07-18 17:56:28:871 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:871 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:871 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:871 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:28:871 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"27":false}}, mqtt async dp cb:0 [07-18 17:56:28:871 TUYA Trace][smart_frame.c:2512] DP ID 27 Set To 3 [07-18 17:56:28:871 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:27, curr_t:1689674188, rept_cnt:1. [07-18 17:56:28:871 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:27, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:871 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:27, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:879 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58346 Q:1 Data:{"dps":{"9":"normal"}} [07-18 17:56:28:879 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:879 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:879 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:880 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:880 TUYA Debug][smart_frame.c:353] dp<10> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:880 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:880 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"10":"low"} [07-18 17:56:28:901 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:901 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:901 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:901 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:901 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:28:901 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"9":"normal"}}, mqtt async dp cb:0 [07-18 17:56:28:901 TUYA Trace][smart_frame.c:2512] DP ID 9 Set To 3 [07-18 17:56:28:901 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:9, curr_t:1689674188, rept_cnt:1. [07-18 17:56:28:901 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:9, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:901 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:9, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:915 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58347 Q:1 Data:{"dps":{"10":"low"}} [07-18 17:56:28:915 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:915 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:915 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:915 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:915 TUYA Debug][smart_frame.c:353] dp<8> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:915 TUYA Debug][smart_frame.c:369] dp_cntl value:0, dp_data value:83 [07-18 17:56:28:915 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:915 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"8":83} [07-18 17:56:28:927 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:939 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:939 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:939 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:939 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:28:939 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"10":"low"}}, mqtt async dp cb:0 [07-18 17:56:28:939 TUYA Trace][smart_frame.c:2512] DP ID 10 Set To 3 [07-18 17:56:28:939 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:10, curr_t:1689674188, rept_cnt:1. [07-18 17:56:28:939 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:10, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:939 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:10, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:946 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58348 Q:1 Data:{"dps":{"8":83}} [07-18 17:56:28:946 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:947 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:947 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:947 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:947 TUYA Debug][smart_frame.c:353] dp<21> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:947 TUYA Debug][smart_frame.c:369] dp_cntl value:0, dp_data value:8938 [07-18 17:56:28:947 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:947 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"21":8938} [07-18 17:56:28:967 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:973 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58349 Q:1 Data:{"dps":{"21":8938}} [07-18 17:56:28:973 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:28:974 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:974 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:28:974 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:28:974 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:28:974 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:28:974 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:28:974 TUYA Debug][smart_frame.c:353] dp<19> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:28:974 TUYA Debug][smart_frame.c:369] dp_cntl value:0, dp_data value:17938 [07-18 17:56:28:974 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:28:974 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"19":17938} [07-18 17:56:28:974 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:28:974 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"8":83}}, mqtt async dp cb:0 [07-18 17:56:28:974 TUYA Trace][smart_frame.c:2512] DP ID 8 Set To 3 [07-18 17:56:28:974 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:8, curr_t:1689674188, rept_cnt:1. [07-18 17:56:28:974 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:8, curr_t:1689674188, rept_cnt:0. [07-18 17:56:28:974 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:8, curr_t:1689674188, rept_cnt:0. [07-18 17:56:29:1 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58350 Q:1 Data:{"dps":{"19":17938}} [07-18 17:56:29:1 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:1 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:1 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:1 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:1 TUYA Debug][smart_frame.c:353] dp<17> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:1 TUYA Debug][smart_frame.c:369] dp_cntl value:0, dp_data value:8882 [07-18 17:56:29:1 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:1 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"17":8882} [07-18 17:56:29:19 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:19 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:19 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:19 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:19 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:19 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"21":8938}}, mqtt async dp cb:0 [07-18 17:56:29:19 TUYA Trace][smart_frame.c:2512] DP ID 21 Set To 3 [07-18 17:56:29:19 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:21, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:19 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:21, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:19 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:21, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:30 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58351 Q:1 Data:{"dps":{"17":8882}} [07-18 17:56:29:30 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:32 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:32 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:32 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:32 TUYA Debug][smart_frame.c:353] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:32 TUYA Debug][smart_frame.c:357] dp_cntl bool:0, dp_data bool:0 [07-18 17:56:29:33 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:33 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"106":false} [07-18 17:56:29:45 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:45 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:45 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:45 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:45 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:45 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"19":17938}}, mqtt async dp cb:0 [07-18 17:56:29:45 TUYA Trace][smart_frame.c:2512] DP ID 19 Set To 3 [07-18 17:56:29:45 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:19, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:45 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:19, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:45 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:19, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:60 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58352 Q:1 Data:{"dps":{"106":false}} [07-18 17:56:29:60 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:60 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:61 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:61 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:61 TUYA Debug][smart_frame.c:353] dp<107> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:61 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:61 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"107":"1"} [07-18 17:56:29:73 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:73 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:73 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:73 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:73 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:73 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"17":8882}}, mqtt async dp cb:0 [07-18 17:56:29:73 TUYA Trace][smart_frame.c:2512] DP ID 17 Set To 3 [07-18 17:56:29:73 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:17, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:73 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:17, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:73 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:17, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:86 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58353 Q:1 Data:{"dps":{"107":"1"}} [07-18 17:56:29:87 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:87 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:87 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:87 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:87 TUYA Debug][smart_frame.c:353] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:87 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:87 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"109":"2"} [07-18 17:56:29:107 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:107 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:107 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:107 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:107 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:107 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"106":false}}, mqtt async dp cb:0 [07-18 17:56:29:107 TUYA Trace][smart_frame.c:2512] DP ID 106 Set To 3 [07-18 17:56:29:107 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:106, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:107 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:106, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:107 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:106, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:120 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58354 Q:1 Data:{"dps":{"109":"2"}} [07-18 17:56:29:120 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:121 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:121 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:121 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:121 TUYA Debug][smart_frame.c:353] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:121 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:121 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"110":"2"} [07-18 17:56:29:135 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:136 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:136 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:136 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:136 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:136 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"107":"1"}}, mqtt async dp cb:0 [07-18 17:56:29:136 TUYA Trace][smart_frame.c:2512] DP ID 107 Set To 3 [07-18 17:56:29:136 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:107, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:136 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:107, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:136 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:107, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:150 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58355 Q:1 Data:{"dps":{"110":"2"}} [07-18 17:56:29:150 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:151 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:151 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:151 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:151 TUYA Debug][smart_frame.c:353] dp<111> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:151 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:151 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"111":"4"} [07-18 17:56:29:163 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:163 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:163 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:164 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:164 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:164 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"109":"2"}}, mqtt async dp cb:0 [07-18 17:56:29:164 TUYA Trace][smart_frame.c:2512] DP ID 109 Set To 3 [07-18 17:56:29:164 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:109, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:164 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:109, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:164 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:109, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:179 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58356 Q:1 Data:{"dps":{"111":"4"}} [07-18 17:56:29:179 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:199 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:199 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:199 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:199 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:199 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:199 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"110":"2"}}, mqtt async dp cb:0 [07-18 17:56:29:199 TUYA Trace][smart_frame.c:2512] DP ID 110 Set To 3 [07-18 17:56:29:199 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:110, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:199 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:110, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:199 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:110, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:200 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:200 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:200 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:200 TUYA Debug][smart_frame.c:353] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:200 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:207 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"120":"1"} [07-18 17:56:29:228 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:228 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:229 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:229 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:229 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:229 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"111":"4"}}, mqtt async dp cb:0 [07-18 17:56:29:229 TUYA Trace][smart_frame.c:2512] DP ID 111 Set To 3 [07-18 17:56:29:229 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:111, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:229 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:111, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:229 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:111, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:240 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58357 Q:1 Data:{"dps":{"120":"1"}} [07-18 17:56:29:240 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:240 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:240 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:240 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:240 TUYA Debug][smart_frame.c:353] dp<6> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:240 TUYA Debug][smart_frame.c:369] dp_cntl value:0, dp_data value:0 [07-18 17:56:29:240 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:240 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"6":0} [07-18 17:56:29:258 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:261 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:261 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:261 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:261 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:261 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"120":"1"}}, mqtt async dp cb:0 [07-18 17:56:29:261 TUYA Trace][smart_frame.c:2512] DP ID 120 Set To 3 [07-18 17:56:29:261 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:120, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:261 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:120, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:261 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:120, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:274 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58358 Q:1 Data:{"dps":{"6":0}} [07-18 17:56:29:274 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:274 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:274 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:274 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:274 TUYA Debug][smart_frame.c:353] dp<7> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 17:56:29:274 TUYA Debug][smart_frame.c:369] dp_cntl value:0, dp_data value:0 [07-18 17:56:29:274 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:274 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"7":0} [07-18 17:56:29:288 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:296 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:296 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:296 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:296 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:296 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"6":0}}, mqtt async dp cb:0 [07-18 17:56:29:296 TUYA Trace][smart_frame.c:2512] DP ID 6 Set To 3 [07-18 17:56:29:296 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:6, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:297 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:6, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:297 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:6, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:307 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58359 Q:1 Data:{"dps":{"7":0}} [07-18 17:56:29:307 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:307 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:307 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:307 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:307 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:307 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgADKQAAKQ=="}, retrans:1 [07-18 17:56:29:307 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgADKQAAKQ=="} [07-18 17:56:29:332 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:332 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58360 Q:1 Data:{"dps":{"15":"qgADKQAAKQ=="}} [07-18 17:56:29:335 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:335 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:335 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:335 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:335 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 17:56:29:335 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"7":0}}, mqtt async dp cb:0 [07-18 17:56:29:335 TUYA Trace][smart_frame.c:2512] DP ID 7 Set To 3 [07-18 17:56:29:335 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:7, curr_t:1689674189, rept_cnt:1. [07-18 17:56:29:335 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:7, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:335 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:7, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:358 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:359 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:359 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:359 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:359 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 17:56:29:359 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674189, rept_cnt:4. [07-18 17:56:29:359 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:359 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:359 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:29:359 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:29:359 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 17:56:29:365 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 17:56:29:365 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgABFxc="}, retrans:1 [07-18 17:56:29:366 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgABFxc="} [07-18 17:56:29:384 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:392 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58361 Q:1 Data:{"dps":{"15":"qgABFxc="}} [07-18 17:56:29:392 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 17:56:29:413 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:413 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:29:413 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:29:413 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 17:56:29:413 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674189, rept_cnt:5. [07-18 17:56:29:413 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:413 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674189, rept_cnt:0. [07-18 17:56:29:436 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:30:446 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:30:446 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:31:414 TUYA Debug][tuya_iot_wifi_api.c:372] wifi netstat changed to:7 <<-- [07-18 17:56:31:447 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:31:447 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:31:460 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:31:460 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:31:460 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:56:31:460 TUYA Debug][mqc_app.c:1494] custom async cb op_ret: 0 [07-18 17:56:31:460 TUYA Debug][mqc_app.c:1547] pub finish:0 [07-18 17:56:31:460 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:56:31:460 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:31:474 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c00db00 [07-18 17:56:31:475 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:31:489 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:31:496 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:31:496 TUYA Trace][iot_httpc.c:940] api[atop.online.debug.log] hash[0xf13b7e53] [07-18 17:56:31:496 TUYA Debug][iot_httpc.c:984] Post Data: {"data":"255","t":1689674191} [07-18 17:56:31:496 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6c9127b907229c12a5bqfi&et=1&t=1689674191&sign=303756d5b13129199a2e0e577407a2be [07-18 17:56:31:496 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:31:496 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:31:496 TUYA Trace][httpc.c:689] Resource: /d.json?a=atop.online.debug.log&devId=6c9127b907229c12a5bqfi&et=1&t=1689674191&sign=303756d5b13129199a2e0e577407a2be [07-18 17:56:31:496 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 17:56:31:508 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 17:56:31:508 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 17:56:31:508 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 17:56:31:508 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 17:56:31:508 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 17:56:31:508 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 17:56:31:522 TUYA Trace][httpc.c:560] Connected .. sockfd: 56 [07-18 17:56:31:522 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 17:56:31:522 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 17:56:31:522 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 17:56:31:522 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 17:56:31:522 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 17:56:31:522 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 17:56:31:533 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 17:56:31:533 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 17:56:31:533 TUYA Debug][smart_frame.c:2033] Start To Sync Dev:6c9127b907229c12a5bqfi, dp_rept_chan:1 [07-18 17:56:31:533 TUYA Debug][smart_frame.c:2357] Pack local dp, reset_flow_ctl:1,dpnum:31. [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 1:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 1 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 2:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 2 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 3:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 3 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 4:0:0:0:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 4 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 5:0:0:2:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 5 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 6:0:0:2:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 6 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 7:0:0:2:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 7 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 8:0:0:2:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 8 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 9:0:0:0:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 9 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 10:0:0:0:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 10 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 11:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 11 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 12:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 12 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 13:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 13 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 14:0:0:0:1:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 14 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 15:0:0:0:1:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 15 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 16:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 16 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 17:0:0:0:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 17 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 18:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 18 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 19:0:0:0:0:0:3: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 19 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 20:0:0:0:0:0:0: [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2375] Skip DP ID 20 [07-18 17:56:31:533 TUYA Trace][smart_frame.c:2366] 21:0:0:2:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 21 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 22:0:0:0:0:0:0: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 22 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 27:0:0:0:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 27 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 28:0:0:0:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 28 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 106:0:0:0:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 106 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 107:0:0:0:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 107 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 109:0:0:0:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 109 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 110:0:0:0:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 110 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 111:0:0:0:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 111 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 112:0:0:1:0:0:0: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 112 [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2366] 120:0:0:0:0:0:3: [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2375] Skip DP ID 120 [07-18 17:56:31:534 TUYA Debug][smart_frame.c:2445] Nothing To Pack [07-18 17:56:31:534 TUYA Trace][smart_frame.c:2042] OUT IS NULL [07-18 17:56:31:534 TUYA Debug][smart_frame.c:2085] Sync Finish [07-18 17:56:31:541 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 17:56:31:541 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 17:56:31:542 TUYA Trace][httpc.c:952] Have to extract [07-18 17:56:31:542 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:31:542 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:31:542 TUYA Trace][httpc.c:689] Resource: /d.json?a=atop.online.debug.log&devId=6c9127b907229c12a5bqfi&et=1&t=1689674191&sign=303756d5b13129199a2e0e577407a2be [07-18 17:56:31:542 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 17:56:31:542 TUYA Trace][httpc.c:972] send header:POST /d.json?a=atop.online.debug.log&devId=6c9127b907229c12a5bqfi&et=1&t=1689674191&sign=303756d5b13129199a2e0e577407a2be HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 69 [07-18 17:56:31:542 TUYA Trace][httpc.c:996] content len:69 [07-18 17:56:31:542 TUYA Trace][httpc.c:343] Start header read [07-18 17:56:31:578 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 17:56:31:578 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: adcce972ebcd4ff5a1857b58140c0cf5 content-type: application/json;charset=UTF-8 content-length: 119 date: Tue, 18 Jul 2023 09:56:32 GMT server: https {"result":"ZeQSvBEdHjHl1j5RF4jn6GjWGeaSgiw0G/eCNc68rc4EQif8+0oQ6avZeQooIEYp","sign":"9de0a7ba08f02594","t":1689674192} [07-18 17:56:31:578 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 17:56:31:578 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 305 bytes header [07-18 17:56:31:578 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:120 [07-18 17:56:31:578 TUYA Trace][httpc.c:1748] contentlen:119 size_remain:119 size_to_read:119 [07-18 17:56:31:578 TUYA Trace][httpc.c:425] Using prefetch: 186 119 119 119 [07-18 17:56:31:578 TUYA Trace][iot_httpc.c:807] RESP:{"result":"ZeQSvBEdHjHl1j5RF4jn6GjWGeaSgiw0G/eCNc68rc4EQif8+0oQ6avZeQooIEYp","sign":"9de0a7ba08f02594","t":1689674192} [07-18 17:56:31:578 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 17:56:31:579 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":true,"t":1689674192,"success":true} [07-18 17:56:32:0 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 17:56:32:0 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 17:56:32:0 TUYA Debug][tuya_devos_entry.c:406] put rst log finish [07-18 17:56:32:24 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:32:24 TUYA Trace][iot_httpc.c:940] api[tuya.device.dynamic.config.get] hash[0x3a6a2f8a] [07-18 17:56:32:24 TUYA Debug][iot_httpc.c:984] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1689674192} [07-18 17:56:32:24 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674192&v=2.0&sign=34fc7b3a8f9844455d035266a5367ce1 [07-18 17:56:32:24 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:32:24 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:32:24 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.dynamic.config.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674192&v=2.0&sign=34fc7b3a8f9844455d035266a5367ce1 [07-18 17:56:32:33 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 17:56:32:33 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 17:56:32:33 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 17:56:32:33 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 17:56:32:33 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 17:56:32:33 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 17:56:32:33 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 17:56:32:50 TUYA Trace][httpc.c:560] Connected .. sockfd: 56 [07-18 17:56:32:50 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 17:56:32:50 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 17:56:32:50 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 17:56:32:50 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 17:56:32:50 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 17:56:32:51 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 17:56:32:73 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 17:56:32:73 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 17:56:32:73 TUYA Trace][httpc.c:952] Have to extract [07-18 17:56:32:73 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:32:73 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:32:73 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.dynamic.config.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674192&v=2.0&sign=34fc7b3a8f9844455d035266a5367ce1 [07-18 17:56:32:73 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 17:56:32:74 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.dynamic.config.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674192&v=2.0&sign=34fc7b3a8f9844455d035266a5367ce1 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 133 [07-18 17:56:32:74 TUYA Trace][httpc.c:996] content len:133 [07-18 17:56:32:74 TUYA Trace][httpc.c:343] Start header read [07-18 17:56:32:128 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 17:56:32:128 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: 6ddbf8312dcb4ffd8133e8e81346efa4 content-type: application/json;charset=UTF-8 content-length: 207 date: Tue, 18 Jul 2023 09:56:32 GMT server: https {"result":"Dlxi87bFKleMVZGNe5XNa4Sov5+TuQPAkJgIMXE4fanpwQYsSX+8M4Izcpc5U7VkD/j9BQyfbCTJ5grVXJzIHk3GLVZwAO+SpaWTkgCGp1BvjntEpxaSAdwh9cV/v4QMysjatHtS1sItecYTHJj5uw==","sign":"44c2f766493ea3b7","t":1689674192} [07-18 17:56:32:128 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 17:56:32:128 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 393 bytes header [07-18 17:56:32:128 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:208 [07-18 17:56:32:128 TUYA Trace][httpc.c:1748] contentlen:207 size_remain:207 size_to_read:207 [07-18 17:56:32:128 TUYA Trace][httpc.c:425] Using prefetch: 186 207 207 207 [07-18 17:56:32:128 TUYA Trace][iot_httpc.c:807] RESP:{"result":"Dlxi87bFKleMVZGNe5XNa4Sov5+TuQPAkJgIMXE4fanpwQYsSX+8M4Izcpc5U7VkD/j9BQyfbCTJ5grVXJzIHk3GLVZwAO+SpaWTkgCGp1BvjntEpxaSAdwh9cV/v4QMysjatHtS1sItecYTHJj5uw==","sign":"44c2f766493ea3b7","t":1689674192} [07-18 17:56:32:128 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 17:56:32:129 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":{"timezone":{"validTime":1800,"time":1689674192,"config":{}}},"t":1689674192,"success":true} [07-18 17:56:32:129 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 17:56:32:129 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 17:56:32:129 TUYA Debug][iot_httpc.c:3348] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1689674192}, ret:0. [07-18 17:56:32:129 TUYA Debug][tuya_ws_db.c:303] write buf:{"key":"cTtC>*KlO'RTxi9]","lckey":"Mro9dY$MHLv!DTHz","h_url":"http://a.tuyacn.com/d.json","h_ip":"42.192.25.216","hs_url":"https://a2.tuyacn.com/d.json","hs_ip":"42.192.31.36","hs_psk":null,"hs_psk_ip":null,"mqs_url":"m2.tuyacn.com:8883","mqs_ip":"42.192.31.85","mq_url":"m2.tuyacn.com:1883","mq_ip":"42.192.31.85","ai_sp":null,"ai_sp_ip":null,"mq_psk":null,"mq_psk_ip":null,"lp_url":null,"lp_ip":null,"time_z":"+08:00","s_time_z":"[]","wx_app_id":null,"wx_uuid":null,"dy_tls_m":4,"cloud_cap":1,"psk21_key":null } [07-18 17:56:32:129 TUYA Debug][simplekv.c:1188] read key:gw_ai isFuzzy:0 skipCnt:0 [07-18 17:56:32:129 TUYA Debug][simplekv.c:1228] find key:11 gw_ai [07-18 17:56:32:129 TUYA Debug][simplekv.c:1257] key:gw_ai find value.Len:528 [07-18 17:56:32:129 TUYA Debug][simplekv.c:355] write key:gw_ai And Value Len:528 [07-18 17:56:32:129 TUYA Debug][simplekv.c:378] 11 key same AND size old 596 >= new 528 [07-18 17:56:32:129 TUYA Debug][simplekv.c:411] find 11 available space [07-18 17:56:32:129 TUYA Debug][simplekv.c:455] reuse available space 36056 [07-18 17:56:32:129 TUYA Debug][simplekv.c:184] update crc 3500003012 [07-18 17:56:32:224 TUYA Debug][simplekv.c:340] write head to normal file success [07-18 17:56:32:224 TUYA Debug][simplekv.c:501] write success [07-18 17:56:32:224 TUYA Debug][ws_db_gw.c:520] gw_ai write success [07-18 17:56:32:224 TUYA Debug][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"validTime":1800,"time":1689674192,"config":{}}}. [07-18 17:56:32:224 TUYA Debug][tuya_devos_utils.c:94] reset dp rate rule finish. [07-18 17:56:32:224 TUYA Debug][iot_httpc.c:2443] NO ackId [07-18 17:56:32:848 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:56:32:848 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:32:871 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 17:56:32:871 TUYA Debug][simplekv.c:1188] read key:e9n6c8_ver isFuzzy:0 skipCnt:0 [07-18 17:56:32:871 TUYA Debug][simplekv.c:1224] no key find [07-18 17:56:32:871 TUYA Debug][simplekv.c:1271] __read_kv_raw fail. -3 [07-18 17:56:32:871 TUYA Debug][simplekv.c:1305] __read_kv_with_decode fail. -3 [07-18 17:56:32:871 TUYA Debug][tuya_svc_schema_upgrade.c:223] schema[e9n6c8] not updated since activated [07-18 17:56:32:911 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:32:911 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:33:169 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:56:33:770 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [1000] [07-18 17:56:33:851 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 17:56:33:851 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:56:33:851 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:33:851 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c00db00 [07-18 17:56:33:851 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:33:852 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:33:852 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:33:852 TUYA Trace][iot_httpc.c:940] api[tuya.device.upgrade.silent.get] hash[0x8d91d69d] [07-18 17:56:33:852 TUYA Debug][iot_httpc.c:984] Post Data: {"subId":null,"t":1689674193} [07-18 17:56:33:852 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upgrade.silent.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674193&v=4.4&sign=553ec49f99968afc6d5fd3e30c4c8466 [07-18 17:56:33:852 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:33:852 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:33:852 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.upgrade.silent.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674193&v=4.4&sign=553ec49f99968afc6d5fd3e30c4c8466 [07-18 17:56:33:852 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 17:56:33:852 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 17:56:33:852 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 17:56:33:852 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 17:56:33:852 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 17:56:33:852 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 17:56:33:852 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 17:56:33:869 TUYA Trace][httpc.c:560] Connected .. sockfd: 56 [07-18 17:56:33:869 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 17:56:33:869 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 17:56:33:869 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 17:56:33:869 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 17:56:33:869 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 17:56:33:869 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 17:56:33:893 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 17:56:33:893 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 17:56:33:893 TUYA Trace][httpc.c:952] Have to extract [07-18 17:56:33:893 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:33:893 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:33:893 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.upgrade.silent.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674193&v=4.4&sign=553ec49f99968afc6d5fd3e30c4c8466 [07-18 17:56:33:893 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 17:56:33:893 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.upgrade.silent.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674193&v=4.4&sign=553ec49f99968afc6d5fd3e30c4c8466 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 69 [07-18 17:56:33:893 TUYA Trace][httpc.c:996] content len:69 [07-18 17:56:33:893 TUYA Trace][httpc.c:343] Start header read [07-18 17:56:33:911 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:33:912 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:33:931 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 17:56:33:931 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: fc731c009755447cb071684ec194c1d4 content-type: application/json;charset=UTF-8 content-length: 99 date: Tue, 18 Jul 2023 09:56:33 GMT server: https {"result":"6FGaq0HtcSoR641IRaV/K+Sh3elIWzIetYdBV37pmfo=","sign":"ff9fe5be0c5d59b9","t":1689674194} [07-18 17:56:33:931 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 17:56:33:932 TUYA Trace][httpc.c:1516] Header has used up 185 bytes from the 284 bytes header [07-18 17:56:33:932 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:100 [07-18 17:56:33:932 TUYA Trace][httpc.c:1748] contentlen:99 size_remain:99 size_to_read:99 [07-18 17:56:33:932 TUYA Trace][httpc.c:425] Using prefetch: 185 99 99 99 [07-18 17:56:33:932 TUYA Trace][iot_httpc.c:807] RESP:{"result":"6FGaq0HtcSoR641IRaV/K+Sh3elIWzIetYdBV37pmfo=","sign":"ff9fe5be0c5d59b9","t":1689674194} [07-18 17:56:33:932 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 17:56:33:932 TUYA Debug][iot_httpc.c:663] Decode Rev:{"t":1689674194,"success":true} [07-18 17:56:34:0 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 17:56:34:0 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 17:56:34:0 TUYA Err][tuya_svc_upgrade.c:431] result null [07-18 17:56:34:0 TUYA Debug][tuya_svc_upgrade.c:506] silent get firmware fail [07-18 17:56:34:0 TUYA Debug][tuya_svc_upgrade.c:202] next detect timer: 21600s [07-18 17:56:34:0 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:0 [07-18 17:56:34:23 TUYA Notice][tuya_svc_timer_task.c:759] Update Timer from cloud [07-18 17:56:34:23 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:34:23 TUYA Trace][iot_httpc.c:940] api[tuya.device.timer.count] hash[0x2c067662] [07-18 17:56:34:23 TUYA Debug][iot_httpc.c:984] Post Data: {"devId":"6c9127b907229c12a5bqfi","lastFetchTime":"0","t":1689674194} [07-18 17:56:34:23 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.timer.count&devId=6c9127b907229c12a5bqfi&et=1&t=1689674194&v=4.0&sign=aab837d6171058cc6aa7378d743b1133 [07-18 17:56:34:23 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:34:23 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:34:23 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.timer.count&devId=6c9127b907229c12a5bqfi&et=1&t=1689674194&v=4.0&sign=aab837d6171058cc6aa7378d743b1133 [07-18 17:56:34:23 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 17:56:34:23 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 17:56:34:23 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 17:56:34:23 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 17:56:34:23 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 17:56:34:23 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 17:56:34:23 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 17:56:34:49 TUYA Trace][httpc.c:560] Connected .. sockfd: 56 [07-18 17:56:34:49 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 17:56:34:49 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 17:56:34:49 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 17:56:34:49 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 17:56:34:49 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 17:56:34:49 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 17:56:34:70 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 17:56:34:70 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 17:56:34:70 TUYA Trace][httpc.c:952] Have to extract [07-18 17:56:34:70 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:34:70 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:34:70 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.timer.count&devId=6c9127b907229c12a5bqfi&et=1&t=1689674194&v=4.0&sign=aab837d6171058cc6aa7378d743b1133 [07-18 17:56:34:70 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 17:56:34:70 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.timer.count&devId=6c9127b907229c12a5bqfi&et=1&t=1689674194&v=4.0&sign=aab837d6171058cc6aa7378d743b1133 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 165 [07-18 17:56:34:71 TUYA Trace][httpc.c:996] content len:165 [07-18 17:56:34:71 TUYA Trace][httpc.c:343] Start header read [07-18 17:56:34:110 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 17:56:34:110 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: d3133d27dcc94918885e36055ebe7ffe content-type: application/json;charset=UTF-8 content-length: 207 date: Tue, 18 Jul 2023 09:56:34 GMT server: https {"result":"R5JXpBqaepcF07xm7+9z35lJdPmp+XRNHWq+45x7NWgXtYE2MR+IudbOu/PI5T13+0nfB04PIj9X6WL59G8yZ3LUZZNC76sDsShvosOAwKFB4tOUDTkeFUE7IQE76Ou0pCihGhFKR1h+wELzDYFP7A==","sign":"40dfeb15f5d34580","t":1689674194} [07-18 17:56:34:110 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 17:56:34:110 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 393 bytes header [07-18 17:56:34:110 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:208 [07-18 17:56:34:110 TUYA Trace][httpc.c:1748] contentlen:207 size_remain:207 size_to_read:207 [07-18 17:56:34:110 TUYA Trace][httpc.c:425] Using prefetch: 186 207 207 207 [07-18 17:56:34:110 TUYA Trace][iot_httpc.c:807] RESP:{"result":"R5JXpBqaepcF07xm7+9z35lJdPmp+XRNHWq+45x7NWgXtYE2MR+IudbOu/PI5T13+0nfB04PIj9X6WL59G8yZ3LUZZNC76sDsShvosOAwKFB4tOUDTkeFUE7IQE76Ou0pCihGhFKR1h+wELzDYFP7A==","sign":"40dfeb15f5d34580","t":1689674194} [07-18 17:56:34:110 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 17:56:34:110 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":{"devId":"6c9127b907229c12a5bqfi","count":0,"lastFetchTime":0},"t":1689674194,"success":true} [07-18 17:56:34:110 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 17:56:34:110 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 17:56:34:110 TUYA Debug][tuya_svc_timer_task.c:434] time eq skip:0 [07-18 17:56:34:981 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:34:981 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:35:981 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:35:981 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:36:981 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:36:982 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:37:982 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:37:982 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:38:126 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:56:38:921 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [2000] [07-18 17:56:38:983 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:38:983 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:39:51 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [1000] num[0] [07-18 17:56:39:947 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:56:39:947 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:39:984 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:39:985 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:40:986 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:40:986 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:41:987 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:41:987 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:42:988 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:42:988 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:43:989 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:43:989 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:44:14 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [3000] [07-18 17:56:44:990 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:44:990 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:45:990 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:45:990 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:46:949 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:56:46:949 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:46:971 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 17:56:46:971 TUYA Debug][simplekv.c:1188] read key:e9n6c8_ver isFuzzy:0 skipCnt:0 [07-18 17:56:46:971 TUYA Debug][simplekv.c:1224] no key find [07-18 17:56:46:971 TUYA Debug][simplekv.c:1271] __read_kv_raw fail. -3 [07-18 17:56:46:971 TUYA Debug][simplekv.c:1305] __read_kv_with_decode fail. -3 [07-18 17:56:46:971 TUYA Debug][tuya_svc_upgrade_http.c:125] schema get:{"schemaId":"e9n6c8","version":""} [07-18 17:56:46:971 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:46:971 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 17:56:46:971 TUYA Trace][iot_httpc.c:940] api[tuya.device.schema.newest.get] hash[0x9f860f95] [07-18 17:56:46:971 TUYA Debug][iot_httpc.c:984] Post Data: {"schemaId":"e9n6c8","version":"","t":1689674206} [07-18 17:56:46:971 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.schema.newest.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674206&v=1.0&sign=d9bf502d519ef0b3f557537f2f18dae2 [07-18 17:56:46:971 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:46:971 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:46:971 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.schema.newest.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674206&v=1.0&sign=d9bf502d519ef0b3f557537f2f18dae2 [07-18 17:56:46:971 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 17:56:46:971 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 17:56:46:971 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 17:56:46:971 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 17:56:46:971 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 17:56:46:971 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 17:56:46:971 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 17:56:46:989 TUYA Trace][httpc.c:560] Connected .. sockfd: 57 [07-18 17:56:46:989 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 17:56:46:989 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 17:56:46:989 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 17:56:46:989 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 17:56:46:989 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 17:56:46:989 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 17:56:46:991 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:46:992 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:47:8 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 17:56:47:8 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 17:56:47:8 TUYA Trace][httpc.c:952] Have to extract [07-18 17:56:47:8 TUYA Trace][httpc.c:615] Scheme: https [07-18 17:56:47:8 TUYA Trace][httpc.c:663] No port number given [07-18 17:56:47:8 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.schema.newest.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674206&v=1.0&sign=d9bf502d519ef0b3f557537f2f18dae2 [07-18 17:56:47:8 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 17:56:47:8 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.schema.newest.get&devId=6c9127b907229c12a5bqfi&et=1&t=1689674206&v=1.0&sign=d9bf502d519ef0b3f557537f2f18dae2 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 133 [07-18 17:56:47:8 TUYA Trace][httpc.c:996] content len:133 [07-18 17:56:47:8 TUYA Trace][httpc.c:343] Start header read [07-18 17:56:47:77 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 17:56:47:77 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: 563fc152c75046c8932cccf86e3bd7b1 content-type: application/json;charset=UTF-8 content-length: 163 date: Tue, 18 Jul 2023 09:56:47 GMT server: https {"result":"Rhy5AYh1La3FoiT2UMn0Yd6PCmRR6CScyDq1ptDp6X6zYdSUPEJsDVlhgOWtZJPIS5XoKbL+b3FwhSnGh/WVGPfsThKV8b7pvdM+jwtArg4=","sign":"50a6fa62b6e091cd","t":1689674207} [07-18 17:56:47:77 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 17:56:47:77 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 349 bytes header [07-18 17:56:47:77 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:164 [07-18 17:56:47:77 TUYA Trace][httpc.c:1748] contentlen:163 size_remain:163 size_to_read:163 [07-18 17:56:47:77 TUYA Trace][httpc.c:425] Using prefetch: 186 163 163 163 [07-18 17:56:47:77 TUYA Trace][iot_httpc.c:807] RESP:{"result":"Rhy5AYh1La3FoiT2UMn0Yd6PCmRR6CScyDq1ptDp6X6zYdSUPEJsDVlhgOWtZJPIS5XoKbL+b3FwhSnGh/WVGPfsThKV8b7pvdM+jwtArg4=","sign":"50a6fa62b6e091cd","t":1689674207} [07-18 17:56:47:77 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 17:56:47:77 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":{"schema":"","schemaId":"e9n6c8"},"t":1689674207,"success":true} [07-18 17:56:47:78 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 17:56:47:78 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 17:56:47:78 TUYA Debug][tuya_svc_upgrade_http.c:133] schema get result:{"schema":"","schemaId":"e9n6c8"} [07-18 17:56:47:78 TUYA Debug][tuya_svc_schema_upgrade.c:130] schema[e9n6c8] ver not update [07-18 17:56:47:993 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:47:993 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:48:135 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:56:48:895 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:56:48:895 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:48:895 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:0 [07-18 17:56:48:994 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:48:994 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:49:99 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [4000] [07-18 17:56:49:233 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [2000] num[0] [07-18 17:56:49:995 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:49:995 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:50:996 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:50:996 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:51:997 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:51:997 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:52:998 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:52:998 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:53:237 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:56:53:999 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:54:0 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:54:78 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:56:54:78 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:56:54:78 TUYA Debug][tuya_svc_schema_upgrade.c:170] next schema get slot 54050. [07-18 17:56:54:188 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [5000] [07-18 17:56:55:1 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:55:1 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:56:2 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:56:2 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:57:3 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:57:3 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:58:4 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:58:4 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:58:142 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:56:59:5 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:56:59:5 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:56:59:269 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [6000] [07-18 17:56:59:401 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [3000] num[0] [07-18 17:57:00:6 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:00:6 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:01:7 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:01:8 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:02:9 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:02:9 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:03:10 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:03:10 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:03:899 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:57:03:899 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:57:03:899 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:1 [07-18 17:57:04:11 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:04:11 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:04:350 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [7000] [07-18 17:57:05:11 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:05:12 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:06:13 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:06:13 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:07:14 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:07:14 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:08:15 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:08:15 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:08:147 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:57:09:16 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:09:16 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:09:429 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [8000] [07-18 17:57:09:580 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [4000] num[0] [07-18 17:57:10:16 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:10:17 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:11:18 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:11:18 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:12:18 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:12:18 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:13:19 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:13:19 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:13:238 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:57:14:21 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:14:21 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:14:503 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [9000] [07-18 17:57:15:21 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:15:21 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:16:21 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:16:22 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:17:23 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:17:23 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:18:23 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:18:23 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:18:157 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:57:18:908 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:57:18:908 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:57:18:908 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:2 [07-18 17:57:19:23 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:19:23 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:19:582 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [10000] [07-18 17:57:19:756 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [5000] num[0] [07-18 17:57:20:24 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:20:24 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:21:25 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:21:25 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:22:26 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:22:26 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:23:28 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:23:28 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:24:29 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:24:29 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:24:665 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [11000] [07-18 17:57:25:30 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:25:30 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:26:31 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:26:31 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:27:32 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:27:32 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:27:519 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 17:57:27:519 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 17:57:27:552 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:57:27:552 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:27:552 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:57:27:552 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 17:57:27:574 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:28:166 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:57:28:574 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:28:575 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:29:576 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:29:576 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:29:743 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [12000] [07-18 17:57:29:925 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [6000] num[0] [07-18 17:57:30:576 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:30:576 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:31:577 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:31:578 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:32:579 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:32:579 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:33:238 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:57:33:579 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:33:580 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:33:917 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:57:33:917 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:57:33:917 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:3 [07-18 17:57:34:581 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:34:581 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:34:822 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [13000] [07-18 17:57:35:581 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:35:581 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:36:582 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:36:582 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:37:583 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:37:583 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:38:176 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:57:38:584 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:38:584 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:39:585 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:39:585 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:39:897 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [14000] [07-18 17:57:40:94 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [7000] num[0] [07-18 17:57:40:586 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:40:586 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:41:587 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:41:587 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:42:588 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:42:588 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:43:589 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:43:589 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:44:590 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:44:590 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:44:973 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [15000] [07-18 17:57:45:591 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:45:591 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:46:593 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:46:593 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:47:594 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:47:594 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:48:185 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:57:48:595 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:48:595 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:48:918 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:57:48:918 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:57:48:918 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:4 [07-18 17:57:49:596 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:49:596 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:50:47 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [16000] [07-18 17:57:50:275 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [8000] num[0] [07-18 17:57:50:597 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:50:597 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:51:598 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:51:598 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:52:599 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:52:599 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:53:238 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:57:53:600 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:53:600 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:54:601 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:54:601 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:55:123 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [17000] [07-18 17:57:55:602 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:55:602 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:56:603 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:56:603 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:57:603 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:57:603 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:58:190 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:57:58:604 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:58:604 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:57:59:605 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:57:59:605 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:00:202 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [18000] [07-18 17:58:00:440 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [9000] num[0] [07-18 17:58:00:605 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:00:605 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:01:606 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:01:606 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:02:606 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:02:607 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:03:608 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:03:608 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:03:923 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:58:03:923 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:58:03:923 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:5 [07-18 17:58:04:609 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:04:609 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:05:281 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [19000] [07-18 17:58:05:610 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:05:610 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:06:611 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:06:611 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:07:611 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:07:612 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:08:196 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:58:08:613 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:08:613 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:09:613 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:09:613 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:10:353 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [20000] [07-18 17:58:10:605 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [10000] num[0] [07-18 17:58:10:614 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:10:614 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:11:615 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:11:615 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:12:617 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:12:617 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:13:239 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:58:13:618 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:13:618 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:14:619 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:14:619 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:15:427 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [21000] [07-18 17:58:15:619 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:15:619 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:16:620 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:16:620 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:17:620 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:17:620 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:18:205 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:58:18:622 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:18:622 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:18:928 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:58:18:928 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:58:18:928 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:6 [07-18 17:58:19:622 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:19:622 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:20:504 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [22000] [07-18 17:58:20:623 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:20:624 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:20:776 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [11000] num[0] [07-18 17:58:21:625 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:21:625 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:22:626 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:22:626 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:23:626 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:23:626 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:24:627 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:24:627 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:25:590 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [23000] [07-18 17:58:25:628 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:25:628 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:26:629 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:26:629 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:27:557 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 17:58:27:557 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 17:58:27:576 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:58:27:576 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:27:576 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:58:27:576 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 17:58:27:598 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:28:212 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:58:28:600 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:28:600 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:29:601 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:29:601 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:30:601 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:30:601 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:30:672 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [24000] [07-18 17:58:30:963 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [12000] num[0] [07-18 17:58:31:602 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:31:602 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:32:200 TUYA Trace][uni_work_queue.c:154] work_queue add task:500008c0 [07-18 17:58:32:200 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:58:32:200 TUYA Debug][simplekv.c:105] <__tmm_backup_work> backup file start...time: 158, MsTime: 815 [07-18 17:58:32:202 TUYA Debug][simplekv.c:221] backup normal file to bak success [07-18 17:58:32:202 TUYA Debug][simplekv.c:108] <__tmm_backup_work> backup file end...time: 158, MsTime: 817 [07-18 17:58:32:603 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:32:603 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:33:243 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:58:33:604 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:33:604 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:33:936 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:58:33:936 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:58:33:936 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:7 [07-18 17:58:34:605 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:34:606 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:35:607 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:35:607 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:35:754 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [25000] [07-18 17:58:36:608 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:36:608 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:37:609 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:37:609 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:38:222 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:58:38:610 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:38:610 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:39:611 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:39:611 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:40:612 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:40:612 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:40:831 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [26000] [07-18 17:58:41:130 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [13000] num[0] [07-18 17:58:41:613 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:41:613 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:42:614 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:42:614 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:43:614 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:43:614 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:44:615 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:44:615 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:45:617 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:45:617 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:45:919 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [27000] [07-18 17:58:46:618 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:46:618 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:47:618 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:47:618 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:48:232 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:58:48:619 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:48:619 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:48:939 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:58:48:939 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:58:48:939 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:8 [07-18 17:58:49:620 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:49:620 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:50:621 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:50:621 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:50:998 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [28000] [07-18 17:58:51:318 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [14000] num[0] [07-18 17:58:51:622 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:51:622 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:52:623 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:52:623 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:53:244 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:58:53:624 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:53:624 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:54:625 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:54:625 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:55:626 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:55:626 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:56:76 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [29000] [07-18 17:58:56:627 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:56:627 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:57:627 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:57:627 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:58:240 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:58:58:628 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:58:628 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:58:59:629 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:58:59:629 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:00:630 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:00:630 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:01:160 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [30000] [07-18 17:59:01:478 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [15000] num[0] [07-18 17:59:01:631 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:01:632 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:02:633 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:02:633 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:03:634 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:03:634 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:03:945 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:59:03:945 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:59:03:945 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:9 [07-18 17:59:04:635 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:04:635 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:05:636 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:05:636 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:06:238 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [31000] [07-18 17:59:06:636 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:06:636 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:07:637 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:07:637 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:08:249 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:59:08:638 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:08:638 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:09:639 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:09:639 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:10:641 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:10:641 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:11:320 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [32000] [07-18 17:59:11:642 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:11:642 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:11:651 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [16000] num[0] [07-18 17:59:12:643 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:12:643 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:13:244 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:59:13:644 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:13:644 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:14:645 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:14:645 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:15:645 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:15:645 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:16:399 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [33000] [07-18 17:59:16:646 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:16:646 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:17:647 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:17:647 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:18:258 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:59:18:649 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:18:649 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:18:950 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:59:18:950 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:59:18:950 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:10 [07-18 17:59:19:650 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:19:650 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:20:651 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:20:651 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:21:473 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [34000] [07-18 17:59:21:652 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:21:652 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:21:823 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [17000] num[0] [07-18 17:59:22:653 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:22:653 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:23:653 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:23:653 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:24:654 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:24:654 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:25:655 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:25:655 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:26:549 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [35000] [07-18 17:59:26:655 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:26:656 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:27:582 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 17:59:27:582 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 17:59:27:609 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:59:27:609 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:27:609 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 17:59:27:609 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 17:59:27:632 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:28:269 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:59:28:633 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:28:633 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:29:634 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:29:634 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:30:635 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:30:635 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:31:634 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [36000] [07-18 17:59:31:636 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:31:636 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:31:994 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [18000] num[0] [07-18 17:59:32:637 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:32:637 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:33:245 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:59:33:638 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:33:638 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:33:959 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:59:33:959 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:59:33:959 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:11 [07-18 17:59:34:639 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:34:639 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:35:640 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:35:640 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:36:641 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:36:641 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:36:711 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [37000] [07-18 17:59:37:642 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:37:642 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:38:279 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:59:38:643 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:38:643 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:39:644 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:39:644 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:40:645 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:40:645 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:41:646 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:41:646 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:41:786 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [38000] [07-18 17:59:42:151 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [19000] num[0] [07-18 17:59:42:647 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:42:647 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:43:648 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:43:648 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:44:649 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:44:649 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:45:650 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:45:650 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:46:651 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:46:651 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:46:862 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [39000] [07-18 17:59:47:652 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:47:652 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:48:289 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:59:48:653 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:48:653 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:48:963 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 17:59:48:963 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 17:59:48:963 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:12 [07-18 17:59:49:654 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:49:654 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:50:655 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:50:655 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:51:656 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:51:656 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:51:938 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [40000] [07-18 17:59:52:323 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [20000] num[0] [07-18 17:59:52:657 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:52:657 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:53:245 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 17:59:53:658 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:53:658 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:54:659 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:54:659 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:55:660 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:55:660 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:56:661 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:56:661 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:57:13 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [41000] [07-18 17:59:57:662 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:57:662 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:58:295 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 17:59:58:663 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:58:663 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 17:59:59:664 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 17:59:59:664 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:00:665 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:00:665 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:01:666 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:01:666 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:02:91 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [42000] [07-18 18:00:02:492 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [21000] num[0] [07-18 18:00:02:667 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:02:667 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:03:667 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:03:667 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:03:966 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:00:03:966 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:00:03:966 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:13 [07-18 18:00:04:668 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:04:668 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:05:669 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:05:669 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:06:669 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:06:669 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:07:166 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [43000] [07-18 18:00:07:670 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:07:670 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:08:301 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:00:08:671 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:08:671 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:09:672 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:09:672 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:10:673 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:10:673 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:11:674 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:11:674 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:12:238 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [44000] [07-18 18:00:12:658 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [22000] num[0] [07-18 18:00:12:675 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:12:675 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:13:246 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:00:13:676 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:13:676 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:14:677 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:14:677 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:15:678 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:15:678 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:16:679 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:16:679 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:17:312 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [45000] [07-18 18:00:17:680 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:17:680 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:18:305 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:00:18:681 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:18:681 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:18:973 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:00:18:973 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:00:18:973 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:14 [07-18 18:00:19:682 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:19:682 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:20:682 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:20:682 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:21:683 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:21:683 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:22:388 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [46000] [07-18 18:00:22:684 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:22:684 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:22:834 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [23000] num[0] [07-18 18:00:23:685 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:23:685 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:24:686 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:24:686 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:25:686 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:25:686 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:26:687 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:26:687 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:27:461 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [47000] [07-18 18:00:27:613 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 18:00:27:613 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 18:00:27:663 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:00:27:663 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:27:663 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:00:27:663 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 18:00:27:686 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:28:311 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:00:28:686 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:28:686 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:29:687 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:29:687 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:30:688 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:30:688 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:31:689 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:31:690 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:32:539 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [48000] [07-18 18:00:32:690 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:32:690 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:33:5 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [24000] num[0] [07-18 18:00:33:246 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:00:33:690 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:33:690 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:33:978 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:00:33:978 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:00:33:978 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:15 [07-18 18:00:34:691 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:34:691 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:35:692 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:35:692 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:36:693 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:36:693 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:37:611 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [49000] [07-18 18:00:37:694 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:37:694 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:38:319 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:00:38:696 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:38:696 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:39:697 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:39:697 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:40:698 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:40:698 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:41:699 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:41:699 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:42:691 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [50000] [07-18 18:00:42:700 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:42:700 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:43:172 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [25000] num[0] [07-18 18:00:43:701 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:43:701 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:44:702 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:44:702 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:45:703 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:45:703 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:46:704 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:46:704 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:47:704 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:47:705 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:47:763 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [51000] [07-18 18:00:48:327 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:00:48:706 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:48:706 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:48:985 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:00:48:985 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:00:48:985 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:16 [07-18 18:00:49:707 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:49:707 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:50:708 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:50:708 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:51:709 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:51:709 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:52:709 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:52:709 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:52:840 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [52000] [07-18 18:00:53:246 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:00:53:350 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [26000] num[0] [07-18 18:00:53:710 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:53:710 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:54:711 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:54:711 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:55:712 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:55:712 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:56:713 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:56:713 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:57:714 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:57:714 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:57:914 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [53000] [07-18 18:00:58:337 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:00:58:714 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:58:715 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:00:59:716 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:00:59:716 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:00:717 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:00:717 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:01:717 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:01:717 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:02:718 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:02:718 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:02:991 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [54000] [07-18 18:01:03:521 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [27000] num[0] [07-18 18:01:03:719 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:03:719 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:03:994 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:01:03:994 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:01:03:994 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:17 [07-18 18:01:04:720 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:04:720 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:05:721 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:05:722 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:06:723 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:06:723 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:07:723 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:07:723 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:08:73 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [55000] [07-18 18:01:08:341 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:01:08:724 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:08:724 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:09:725 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:09:725 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:10:726 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:10:726 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:11:727 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:11:727 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:12:728 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:12:728 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:13:154 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [56000] [07-18 18:01:13:247 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:01:13:699 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [28000] num[0] [07-18 18:01:13:729 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:13:729 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:14:730 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:14:730 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:15:731 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:15:732 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:16:733 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:16:733 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:17:734 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:17:734 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:18:228 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [57000] [07-18 18:01:18:348 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:01:18:735 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:18:735 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:18:999 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:01:18:999 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:01:18:999 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:18 [07-18 18:01:19:736 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:19:736 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:20:737 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:20:737 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:21:738 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:21:738 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:22:739 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:22:740 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:23:304 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [58000] [07-18 18:01:23:741 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:23:741 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:23:875 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [29000] num[0] [07-18 18:01:24:742 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:24:742 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:25:743 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:25:743 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:26:744 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:26:744 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:27:671 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 18:01:27:671 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 18:01:27:692 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:01:27:692 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:27:692 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:01:27:692 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 18:01:27:714 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:28:352 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:01:28:388 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [59000] [07-18 18:01:28:715 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:28:715 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:29:715 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:29:715 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:30:717 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:30:717 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:31:717 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:31:717 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:32:718 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:32:718 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:33:247 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:01:33:466 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [60000] [07-18 18:01:33:719 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:33:719 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:34:4 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:01:34:4 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:01:34:4 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:19 [07-18 18:01:34:56 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [30000] num[0] [07-18 18:01:34:719 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:34:719 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:35:720 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:35:720 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:36:721 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:36:721 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:37:722 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:37:722 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:38:362 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:01:38:547 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [61000] [07-18 18:01:38:723 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:38:723 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:39:724 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:39:724 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:40:725 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:40:725 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:41:726 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:41:726 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:42:727 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:42:727 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:43:624 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [62000] [07-18 18:01:43:728 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:43:728 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:44:226 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [31000] num[0] [07-18 18:01:44:729 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:44:729 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:45:732 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:45:732 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:46:733 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:46:733 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:47:734 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:47:734 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:48:369 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:01:48:702 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [63000] [07-18 18:01:48:735 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:48:735 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:49:4 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:01:49:4 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:01:49:4 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:20 [07-18 18:01:49:736 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:49:736 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:50:737 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:50:737 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:51:737 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:51:737 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:52:738 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:52:738 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:53:248 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:01:53:739 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:53:739 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:53:780 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [64000] [07-18 18:01:54:416 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [32000] num[0] [07-18 18:01:54:740 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:54:740 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:55:741 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:55:741 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:56:742 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:56:742 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:57:743 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:57:743 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:58:378 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:01:58:744 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:58:744 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:01:58:856 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [65000] [07-18 18:01:59:745 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:01:59:745 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:00:745 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:00:745 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:01:746 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:01:746 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:02:748 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:02:748 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:03:748 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:03:748 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:03:935 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [66000] [07-18 18:02:04:5 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:02:04:5 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:02:04:5 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:21 [07-18 18:02:04:587 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [33000] num[0] [07-18 18:02:04:749 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:04:750 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:05:750 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:05:751 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:06:751 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:06:752 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:07:753 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:07:753 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:08:385 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:02:08:753 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:08:753 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:09:12 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [67000] [07-18 18:02:09:754 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:09:754 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:10:755 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:10:755 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:11:756 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:11:756 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:12:757 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:12:757 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:13:248 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:02:13:758 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:13:758 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:14:88 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [68000] [07-18 18:02:14:746 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [34000] num[0] [07-18 18:02:14:759 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:14:759 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:15:759 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:15:759 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:16:760 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:16:760 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:17:761 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:17:761 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:18:394 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:02:18:762 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:18:762 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:19:12 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:02:19:12 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:02:19:12 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:22 [07-18 18:02:19:176 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [69000] [07-18 18:02:19:763 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:19:763 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:20:764 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:20:764 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:21:764 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:21:764 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:22:765 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:22:765 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:23:766 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:23:766 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:24:260 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [70000] [07-18 18:02:24:767 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:24:767 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:24:935 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [35000] num[0] [07-18 18:02:25:768 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:25:768 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:26:769 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:26:769 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:27:695 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 18:02:27:695 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 18:02:27:715 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:02:27:715 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:27:715 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:02:27:715 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 18:02:27:738 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:28:404 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:02:28:739 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:28:739 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:29:339 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [71000] [07-18 18:02:29:740 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:29:740 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:30:741 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:30:741 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:31:742 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:31:742 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:32:743 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:32:743 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:33:249 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:02:33:744 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:33:744 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:34:19 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:02:34:19 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:02:34:19 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:23 [07-18 18:02:34:416 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [72000] [07-18 18:02:34:745 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:34:745 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:35:118 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [36000] num[0] [07-18 18:02:35:746 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:35:746 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:36:747 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:36:747 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:37:748 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:37:748 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:38:414 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:02:38:749 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:38:749 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:39:491 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [73000] [07-18 18:02:39:750 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:39:750 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:40:751 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:40:751 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:41:752 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:41:752 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:42:752 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:42:752 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:43:753 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:43:753 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:44:571 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [74000] [07-18 18:02:44:754 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:44:754 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:45:295 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [37000] num[0] [07-18 18:02:45:754 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:45:754 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:46:755 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:46:755 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:47:756 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:47:756 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:48:422 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:02:48:758 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:48:758 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:49:25 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:02:49:25 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:02:49:25 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:24 [07-18 18:02:49:651 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [75000] [07-18 18:02:49:759 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:49:759 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:50:760 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:50:760 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:51:760 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:51:760 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:52:762 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:52:762 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:53:249 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:02:53:763 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:53:763 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:54:725 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [76000] [07-18 18:02:54:764 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:54:764 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:55:460 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [38000] num[0] [07-18 18:02:55:765 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:55:765 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:56:766 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:56:766 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:57:767 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:57:767 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:58:431 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:02:58:768 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:58:768 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:59:769 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:02:59:769 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:02:59:798 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [77000] [07-18 18:03:00:771 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:00:771 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:01:771 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:01:771 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:02:772 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:02:772 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:03:773 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:03:773 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:04:34 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:03:04:34 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:03:04:34 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:25 [07-18 18:03:04:774 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:04:774 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:04:875 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [78000] [07-18 18:03:05:633 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [39000] num[0] [07-18 18:03:05:775 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:05:775 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:06:776 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:06:776 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:07:777 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:07:777 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:08:441 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:03:08:778 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:08:778 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:09:779 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:09:779 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:09:956 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [79000] [07-18 18:03:10:780 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:10:780 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:11:781 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:11:781 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:12:782 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:12:782 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:13:249 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:03:13:783 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:13:783 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:14:784 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:14:784 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:15:34 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [80000] [07-18 18:03:15:785 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:15:785 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:15:799 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [40000] num[0] [07-18 18:03:16:786 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:16:786 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:17:786 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:17:786 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:18:446 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:03:18:787 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:18:787 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:19:41 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:03:19:41 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:03:19:41 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:26 [07-18 18:03:19:788 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:19:788 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:20:113 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [81000] [07-18 18:03:20:789 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:20:789 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:21:790 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:21:790 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:22:791 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:22:791 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:23:791 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:23:791 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:24:792 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:24:793 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:25:187 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [82000] [07-18 18:03:25:793 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:25:793 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:25:960 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [41000] num[0] [07-18 18:03:26:794 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:26:794 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:27:721 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 18:03:27:721 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 18:03:27:745 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:03:27:745 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:27:745 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:03:27:745 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 18:03:27:768 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:28:455 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:03:28:769 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:28:769 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:29:770 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:29:770 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:30:270 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [83000] [07-18 18:03:30:771 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:30:771 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:31:772 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:31:772 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:32:773 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:32:773 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:33:250 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:03:33:774 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:33:775 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:34:47 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:03:34:47 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:03:34:47 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:27 [07-18 18:03:34:776 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:34:776 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:35:347 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [84000] [07-18 18:03:35:777 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:35:777 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:36:127 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [42000] num[0] [07-18 18:03:36:777 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:36:777 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:37:778 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:37:778 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:38:457 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:03:38:779 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:38:779 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:39:780 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:39:780 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:40:426 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [85000] [07-18 18:03:40:781 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:40:781 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:41:782 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:41:782 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:42:783 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:42:783 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:43:784 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:43:784 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:44:785 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:44:785 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:45:507 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [86000] [07-18 18:03:45:786 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:45:786 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:46:296 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [43000] num[0] [07-18 18:03:46:787 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:46:787 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:47:788 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:47:788 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:48:465 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:03:48:789 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:48:789 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:49:53 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:03:49:53 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:03:49:53 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:28 [07-18 18:03:49:789 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:49:789 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:50:591 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [87000] [07-18 18:03:50:790 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:50:790 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:51:791 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:51:791 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:52:792 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:52:792 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:53:250 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:03:53:793 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:53:793 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:54:794 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:54:794 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:55:671 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [88000] [07-18 18:03:55:795 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:55:795 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:56:476 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [44000] num[0] [07-18 18:03:56:796 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:56:796 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:57:797 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:57:797 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:58:470 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:03:58:798 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:58:798 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:03:59:800 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:03:59:800 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:00:747 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [89000] [07-18 18:04:00:801 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:00:801 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:01:802 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:01:802 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:02:802 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:02:802 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:03:803 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:03:803 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:04:62 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:04:04:62 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:04:62 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:29 [07-18 18:04:04:805 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:04:805 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:05:806 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:05:806 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:05:823 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [90000] [07-18 18:04:06:649 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [45000] num[0] [07-18 18:04:06:807 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:06:807 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:07:808 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:07:808 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:08:479 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:04:08:809 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:08:809 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:09:809 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:09:809 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:10:810 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:10:810 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:10:895 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [91000] [07-18 18:04:11:811 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:11:811 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:12:812 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:12:812 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:13:250 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:04:13:813 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:13:813 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:14:814 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:14:814 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:15:815 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:15:815 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:15:974 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [92000] [07-18 18:04:16:815 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [46000] num[0] [07-18 18:04:16:816 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:16:816 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:17:817 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:17:817 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:18:489 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:04:18:818 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:18:818 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:19:69 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:04:19:69 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:19:69 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:30 [07-18 18:04:19:819 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:19:819 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:20:820 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:20:820 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:21:51 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [93000] [07-18 18:04:21:821 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:21:821 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:22:822 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:22:822 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:23:822 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:23:822 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:24:823 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:24:823 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:25:824 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:25:824 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:26:129 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [94000] [07-18 18:04:26:825 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:26:825 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:26:976 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [47000] num[0] [07-18 18:04:27:750 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 18:04:27:751 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 18:04:27:770 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:27:770 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:27:770 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:27:770 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 18:04:27:793 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:28:498 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:04:28:794 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:28:794 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:29:795 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:29:795 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:30:796 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:30:796 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:31:210 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [95000] [07-18 18:04:31:797 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:31:797 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:32:798 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:32:798 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:33:251 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:04:33:799 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:33:799 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:34:76 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:04:34:76 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:34:76 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:31 [07-18 18:04:34:800 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:34:800 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:35:801 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:35:801 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:36:287 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [96000] [07-18 18:04:36:802 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:36:802 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:37:154 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [48000] num[0] [07-18 18:04:37:802 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:37:802 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:508 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:04:38:696 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:697 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:697 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:697 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:697 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:697 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:697 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:697 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:38:697 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:38:697 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 55 [07-18 18:04:38:697 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674678,"protocol":302,"data":{"msg":{"log":{"size":1024,"tcp":{"address":"124.221.79.86","key":"6e9d446e4a2d2cdc","domain":"wework-1-cn.stream.iot-11.com","port":9092},"interval":60,"level":2,"topic":"\/av\/moto\/log","api":"thing.m.rtc.log"},"sdp":"v=0\r\no=- 1689674678 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9127b907229c12a5bqfi1689674678SjKMLgf7\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:JzDA\r\na=ice-pwd:enCwHVLMsAOzFCmnwQNXnfe8\r\na=ice-options:trickle\r\na=aes-key:a000c000000f0a50000002d00000bb00\r\na=mid:imm0\r\na=rtpmap:6001 AES\/KCP 330\r\na=ssrc:0 cname:ay1689142558741Q9RvD\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"username":"1689678278:6c9127b907229c12a5bqfi","ttl":3600,"urls":"turn:47.103.29.37:3478","credential":"OMGzWVoLTdcxYseccPXFiwCec4k="}],"tcp_token":{"username":"1689710678:6c9127b907229c12a5bqfi","sessionId" [07-18 18:04:38:697 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:38:697 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:38:697 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:38:697 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c002f90 [07-18 18:04:38:697 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:38:706 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58362 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"answer","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","is_pre":0,"p2p_skill":35,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1689674678 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9127b907229c12a5bqfi1689674678SjKMLgf7\r\nm=application 9 tuya 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:2fSV\r\na=ice-pwd:pvs1DDIf6veI6WYgjRuwgRt5\r\na=ice-options:trickle\r\na=aes-key:a000c000000f0a50000002d00000bb00\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 3\r\na=ssrc:0 cname:6c9127b907229c12a5bqfi\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"username":"1689678278:6c9127b907229c12a5bqfi","ttl":3600,"urls":"turn:47.103.29.37:3478","credential":"OMGzWVoLTdcxYseccPXFiwCec4k="}],"tcp_token":{"username":"16897 [07-18 18:04:38:706 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:38:707 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58363 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"candidate":"a=candidate:1980663216 1 UDP 2130706431 192.168.2.111 45848 typ host\r\n"}} [07-18 18:04:38:707 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:38:707 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58364 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"candidate":"a=candidate:1177208996 1 UDP 2130706431 192.250.250.1 45848 typ host\r\n"}} [07-18 18:04:38:707 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:38:720 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:720 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:720 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:720 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:720 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:38:720 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:38:720 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 56 [07-18 18:04:38:720 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674678,"protocol":302,"data":{"msg":{"candidate":"a=candidate:2113184408 1 UDP 2130706431 10.94.71.231 54234 typ host\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:38:720 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:38:720 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:38:720 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:38:720 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c002f90 [07-18 18:04:38:720 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:38:734 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58365 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"candidate":"a=candidate:1503628293 1 UDP 1694498815 49.73.254.50 44951 typ srflx\r\n"}} [07-18 18:04:38:735 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:38:743 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:743 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:743 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:743 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:743 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:38:743 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:38:743 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 57 [07-18 18:04:38:743 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674678,"protocol":302,"data":{"msg":{"candidate":"a=candidate:498855261 1 UDP 2130706431 192.168.2.74 54234 typ host\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:38:743 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:38:743 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:38:743 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:38:743 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00dcc0 [07-18 18:04:38:743 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:38:756 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58366 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"candidate":"a=candidate:1871364773 1 UDP 16777215 47.103.29.37 49376 typ relay\r\n"}} [07-18 18:04:38:756 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:38:756 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58367 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"candidate":""}} [07-18 18:04:38:757 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:38:768 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:768 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:768 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:768 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:768 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:38:768 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:38:768 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 58 [07-18 18:04:38:768 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674678,"protocol":302,"data":{"msg":{"candidate":"a=candidate:1310919200 1 UDP 1694498815 49.73.254.50 44946 typ srflx\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:38:768 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:38:768 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:38:768 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:38:768 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00dcc0 [07-18 18:04:38:768 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:38:776 TUYA Debug][tuya_ipc_p2p.c:4512] listen ok session[65537] [07-18 18:04:38:791 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:791 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:791 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:791 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:791 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:38:791 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:38:791 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 59 [07-18 18:04:38:791 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674678,"protocol":302,"data":{"msg":{"candidate":"a=candidate:1641264257 1 UDP 16777215 47.103.29.37 55947 typ relay\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:38:791 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:38:791 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:38:791 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:38:791 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00dcc0 [07-18 18:04:38:791 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:38:808 TUYA Debug][tuya_ipc_p2p.c:3987] compare passwd [07-18 18:04:38:808 TUYA Debug][tuya_ipc_p2p.c:3988] get ipc auth gw_local_key[Mro9dY$MHLv!DTHz]p2p_passwd[adb63309] [07-18 18:04:38:808 TUYA Debug][tuya_ipc_p2p.c:4006] Client Auth admin efa628a6c8b8f6f591f69df58cfba471 <-> admin adb63309 [07-18 18:04:38:808 TUYA Debug][tuya_ipc_p2p.c:4007] localkey:Mro9dY$MHLv!DTHz final:efa628a6c8b8f6f591f69df58cfba471 [07-18 18:04:38:808 TUYA Debug][tuya_ipc_p2p.c:4010] auth success [07-18 18:04:38:808 TUYA Debug][tuya_ipc_p2p.c:592] __p2p_get_idle_session begin [07-18 18:04:38:808 TUYA Debug][tuya_ipc_p2p.c:4624] create p2p sessions. cur online session num = 1 [07-18 18:04:38:808 TUYA Debug][tuya_ipc_p2p.c:4445] mqtt p2p LISTEN session........ [07-18 18:04:38:815 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:815 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:815 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:815 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:38:815 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:38:815 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:38:815 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 60 [07-18 18:04:38:815 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674678,"protocol":302,"data":{"msg":{"candidate":""},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:38:815 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:38:815 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:38:815 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:38:815 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00dcc0 [07-18 18:04:38:815 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:38:839 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:38:869 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [10] low cmd[0] [07-18 18:04:38:960 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [2] low cmd[0] [07-18 18:04:39:52 TUYA Debug][tuya_ipc_p2p.c:5031] session[65537] detech staticCnt[1]lstCnt[0]vIFrameCnt[0] [07-18 18:04:39:52 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [9] low cmd[0] [07-18 18:04:39:147 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [9] low cmd[0] [07-18 18:04:39:244 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [6] low cmd[0] [07-18 18:04:39:244 TUYA Debug][tuya_ipc_p2p.c:1911] open ringbuff handle[(nil)] stream[0] [07-18 18:04:39:245 TUYA Debug][tuya_ipc_p2p.c:1946] session[65537]video video_start wait_concurr_idle [07-18 18:04:39:245 TUYA Debug][tuya_ipc_p2p.c:5134] session[65537] __p2p_wait_concurr_idle start [07-18 18:04:39:275 TUYA Debug][tuya_ipc_p2p.c:5151] session[65537] concurr idle[2][2] [07-18 18:04:39:275 TUYA Debug][tuya_ipc_p2p.c:5157] session[65537] __p2p_wait_concurr_idle end [07-18 18:04:39:275 TUYA Debug][tuya_ipc_p2p.c:1978] session[65537] [0] send video start to dev [07-18 18:04:39:275 TUYA Debug][tuya_ipc_p2p.c:1984] session video start[65537] [07-18 18:04:39:275 TUYA Debug][linkbey_sdk_v11.cpp:573] start live video using /oem/ros_file/demo7_video.264 [07-18 18:04:39:278 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:39:278 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr0 [07-18 18:04:39:278 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:33333 ts:0 [07-18 18:04:39:278 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:33333 [07-18 18:04:39:278 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:0 dataSize:12088 [07-18 18:04:39:278 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:1 timestamp:1689674679278 [07-18 18:04:39:278 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:33333 ts:0 [07-18 18:04:39:278 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:33333 [07-18 18:04:39:278 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:0 dataSize:12088 [07-18 18:04:39:278 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:1 timestamp:1689674679278 [07-18 18:04:39:311 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:66666 ts:0 [07-18 18:04:39:311 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:66666 [07-18 18:04:39:311 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:12088 dataSize:1051 [07-18 18:04:39:311 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:2 timestamp:1689674679311 [07-18 18:04:39:311 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:66666 ts:0 [07-18 18:04:39:311 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:66666 [07-18 18:04:39:311 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:12088 dataSize:1051 [07-18 18:04:39:312 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:2 timestamp:1689674679312 [07-18 18:04:39:345 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:99999 ts:0 [07-18 18:04:39:345 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:99999 [07-18 18:04:39:345 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:13139 dataSize:209 [07-18 18:04:39:345 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:3 timestamp:1689674679345 [07-18 18:04:39:345 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:99999 ts:0 [07-18 18:04:39:345 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:99999 [07-18 18:04:39:345 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:13139 dataSize:209 [07-18 18:04:39:345 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:3 timestamp:1689674679345 [07-18 18:04:39:366 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [6] low cmd[4] [07-18 18:04:39:367 TUYA Debug][tuya_ipc_p2p.c:2041] session[65537] [0] send audio start to dev [07-18 18:04:39:379 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:133332 ts:0 [07-18 18:04:39:379 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:133332 [07-18 18:04:39:379 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:13348 dataSize:118 [07-18 18:04:39:379 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:4 timestamp:1689674679379 [07-18 18:04:39:379 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:133332 ts:0 [07-18 18:04:39:379 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:133332 [07-18 18:04:39:379 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:13348 dataSize:118 [07-18 18:04:39:379 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:4 timestamp:1689674679379 [07-18 18:04:39:388 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:39:388 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 0 node index 0, head index 4 [07-18 18:04:39:388 TUYA Trace][tuya_ring_buffer.c:800] get latest frame node type 0 [07-18 18:04:39:388 TUYA Debug][tuya_ipc_p2p.c:4169] session[65537] I Frame Send ok len[12088] pts[33333] count[1]timestamp[1689674679278] [07-18 18:04:39:388 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:39:412 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:166665 ts:0 [07-18 18:04:39:412 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:166665 [07-18 18:04:39:412 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:13466 dataSize:110 [07-18 18:04:39:412 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:5 timestamp:1689674679412 [07-18 18:04:39:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:166665 ts:0 [07-18 18:04:39:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:166665 [07-18 18:04:39:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:13466 dataSize:110 [07-18 18:04:39:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:5 timestamp:1689674679413 [07-18 18:04:39:446 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:199998 ts:0 [07-18 18:04:39:446 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:199998 [07-18 18:04:39:446 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:13576 dataSize:695 [07-18 18:04:39:446 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:6 timestamp:1689674679446 [07-18 18:04:39:446 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:199998 ts:0 [07-18 18:04:39:446 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:199998 [07-18 18:04:39:446 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:13576 dataSize:695 [07-18 18:04:39:446 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:6 timestamp:1689674679446 [07-18 18:04:39:480 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:233331 ts:0 [07-18 18:04:39:480 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:233331 [07-18 18:04:39:480 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:14271 dataSize:1146 [07-18 18:04:39:480 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:7 timestamp:1689674679480 [07-18 18:04:39:480 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:233331 ts:0 [07-18 18:04:39:480 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:233331 [07-18 18:04:39:480 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:14271 dataSize:1146 [07-18 18:04:39:480 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:7 timestamp:1689674679480 [07-18 18:04:39:498 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:39:498 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 1, head index 7 [07-18 18:04:39:498 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 2, seqNo 2, timestamp 1689674679311 [07-18 18:04:39:499 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:39:513 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:266664 ts:0 [07-18 18:04:39:513 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:266664 [07-18 18:04:39:513 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:15417 dataSize:276 [07-18 18:04:39:513 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:8 timestamp:1689674679513 [07-18 18:04:39:513 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:266664 ts:0 [07-18 18:04:39:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:266664 [07-18 18:04:39:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:15417 dataSize:276 [07-18 18:04:39:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:8 timestamp:1689674679514 [07-18 18:04:39:544 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [5] low cmd[0] [07-18 18:04:39:547 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:299997 ts:0 [07-18 18:04:39:547 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:299997 [07-18 18:04:39:547 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:15693 dataSize:152 [07-18 18:04:39:547 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:9 timestamp:1689674679547 [07-18 18:04:39:548 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:299997 ts:0 [07-18 18:04:39:548 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:299997 [07-18 18:04:39:548 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:15693 dataSize:152 [07-18 18:04:39:548 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:9 timestamp:1689674679548 [07-18 18:04:39:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:333330 ts:0 [07-18 18:04:39:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:333330 [07-18 18:04:39:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:15845 dataSize:136 [07-18 18:04:39:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:10 timestamp:1689674679581 [07-18 18:04:39:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:333330 ts:0 [07-18 18:04:39:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:333330 [07-18 18:04:39:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:15845 dataSize:136 [07-18 18:04:39:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:10 timestamp:1689674679581 [07-18 18:04:39:609 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:39:609 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 2, head index 10 [07-18 18:04:39:609 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 3, seqNo 3, timestamp 1689674679345 [07-18 18:04:39:609 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:39:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:366663 ts:0 [07-18 18:04:39:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:366663 [07-18 18:04:39:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:15981 dataSize:725 [07-18 18:04:39:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:11 timestamp:1689674679615 [07-18 18:04:39:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:366663 ts:0 [07-18 18:04:39:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:366663 [07-18 18:04:39:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:15981 dataSize:725 [07-18 18:04:39:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:11 timestamp:1689674679615 [07-18 18:04:39:648 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:399996 ts:0 [07-18 18:04:39:648 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:399996 [07-18 18:04:39:648 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:16706 dataSize:1369 [07-18 18:04:39:648 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:12 timestamp:1689674679648 [07-18 18:04:39:648 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:399996 ts:0 [07-18 18:04:39:649 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:399996 [07-18 18:04:39:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:16706 dataSize:1369 [07-18 18:04:39:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:12 timestamp:1689674679649 [07-18 18:04:39:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:433329 ts:0 [07-18 18:04:39:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:433329 [07-18 18:04:39:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:18075 dataSize:367 [07-18 18:04:39:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:13 timestamp:1689674679682 [07-18 18:04:39:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:433329 ts:0 [07-18 18:04:39:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:433329 [07-18 18:04:39:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18075 dataSize:367 [07-18 18:04:39:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:13 timestamp:1689674679682 [07-18 18:04:39:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:466662 ts:0 [07-18 18:04:39:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:466662 [07-18 18:04:39:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:18442 dataSize:141 [07-18 18:04:39:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:14 timestamp:1689674679716 [07-18 18:04:39:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:466662 ts:0 [07-18 18:04:39:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:466662 [07-18 18:04:39:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18442 dataSize:141 [07-18 18:04:39:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:14 timestamp:1689674679716 [07-18 18:04:39:719 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:39:719 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 3, head index 14 [07-18 18:04:39:719 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 4, seqNo 4, timestamp 1689674679379 [07-18 18:04:39:719 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:39:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:499995 ts:0 [07-18 18:04:39:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:499995 [07-18 18:04:39:749 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:18583 dataSize:160 [07-18 18:04:39:749 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:15 timestamp:1689674679749 [07-18 18:04:39:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:499995 ts:0 [07-18 18:04:39:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:499995 [07-18 18:04:39:750 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18583 dataSize:160 [07-18 18:04:39:750 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:15 timestamp:1689674679750 [07-18 18:04:39:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:533328 ts:0 [07-18 18:04:39:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:533328 [07-18 18:04:39:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:18743 dataSize:756 [07-18 18:04:39:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:16 timestamp:1689674679783 [07-18 18:04:39:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:533328 ts:0 [07-18 18:04:39:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:533328 [07-18 18:04:39:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18743 dataSize:756 [07-18 18:04:39:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:16 timestamp:1689674679783 [07-18 18:04:39:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:566661 ts:0 [07-18 18:04:39:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:566661 [07-18 18:04:39:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:19499 dataSize:1610 [07-18 18:04:39:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:17 timestamp:1689674679817 [07-18 18:04:39:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:566661 ts:0 [07-18 18:04:39:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:566661 [07-18 18:04:39:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:19499 dataSize:1610 [07-18 18:04:39:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:17 timestamp:1689674679817 [07-18 18:04:39:829 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:39:829 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 4, head index 17 [07-18 18:04:39:829 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 5, seqNo 5, timestamp 1689674679412 [07-18 18:04:39:829 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:39:839 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:39:839 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:39:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:599994 ts:0 [07-18 18:04:39:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:599994 [07-18 18:04:39:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:21109 dataSize:516 [07-18 18:04:39:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:18 timestamp:1689674679850 [07-18 18:04:39:851 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:599994 ts:0 [07-18 18:04:39:851 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:599994 [07-18 18:04:39:851 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:21109 dataSize:516 [07-18 18:04:39:851 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:18 timestamp:1689674679851 [07-18 18:04:39:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:633327 ts:0 [07-18 18:04:39:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:633327 [07-18 18:04:39:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:21625 dataSize:231 [07-18 18:04:39:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:19 timestamp:1689674679884 [07-18 18:04:39:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:633327 ts:0 [07-18 18:04:39:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:633327 [07-18 18:04:39:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:21625 dataSize:231 [07-18 18:04:39:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:19 timestamp:1689674679884 [07-18 18:04:39:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:666660 ts:0 [07-18 18:04:39:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:666660 [07-18 18:04:39:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:21856 dataSize:250 [07-18 18:04:39:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:20 timestamp:1689674679918 [07-18 18:04:39:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:666660 ts:0 [07-18 18:04:39:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:666660 [07-18 18:04:39:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:21856 dataSize:250 [07-18 18:04:39:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:20 timestamp:1689674679918 [07-18 18:04:39:940 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:39:940 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 5, head index 20 [07-18 18:04:39:940 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 6, seqNo 6, timestamp 1689674679446 [07-18 18:04:39:940 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:39:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:699993 ts:0 [07-18 18:04:39:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:699993 [07-18 18:04:39:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:22106 dataSize:1143 [07-18 18:04:39:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:21 timestamp:1689674679951 [07-18 18:04:39:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:699993 ts:0 [07-18 18:04:39:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:699993 [07-18 18:04:39:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:22106 dataSize:1143 [07-18 18:04:39:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:21 timestamp:1689674679951 [07-18 18:04:39:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:733326 ts:0 [07-18 18:04:39:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:733326 [07-18 18:04:39:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:23249 dataSize:383 [07-18 18:04:39:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:22 timestamp:1689674679985 [07-18 18:04:39:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:733326 ts:0 [07-18 18:04:39:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:733326 [07-18 18:04:39:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23249 dataSize:383 [07-18 18:04:39:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:22 timestamp:1689674679985 [07-18 18:04:40:19 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:766659 ts:0 [07-18 18:04:40:19 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:766659 [07-18 18:04:40:19 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:23632 dataSize:235 [07-18 18:04:40:19 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:23 timestamp:1689674680019 [07-18 18:04:40:19 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:766659 ts:0 [07-18 18:04:40:19 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:766659 [07-18 18:04:40:19 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23632 dataSize:235 [07-18 18:04:40:19 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:23 timestamp:1689674680019 [07-18 18:04:40:50 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:50 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 6, head index 23 [07-18 18:04:40:50 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 7, seqNo 7, timestamp 1689674679480 [07-18 18:04:40:50 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:799992 ts:0 [07-18 18:04:40:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:799992 [07-18 18:04:40:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:23867 dataSize:165 [07-18 18:04:40:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:24 timestamp:1689674680052 [07-18 18:04:40:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:799992 ts:0 [07-18 18:04:40:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:799992 [07-18 18:04:40:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23867 dataSize:165 [07-18 18:04:40:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:24 timestamp:1689674680052 [07-18 18:04:40:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:833325 ts:0 [07-18 18:04:40:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:833325 [07-18 18:04:40:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:24032 dataSize:457 [07-18 18:04:40:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:25 timestamp:1689674680086 [07-18 18:04:40:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:833325 ts:0 [07-18 18:04:40:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:833325 [07-18 18:04:40:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:24032 dataSize:457 [07-18 18:04:40:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:25 timestamp:1689674680086 [07-18 18:04:40:120 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:866658 ts:0 [07-18 18:04:40:120 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:866658 [07-18 18:04:40:120 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:24489 dataSize:673 [07-18 18:04:40:120 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:26 timestamp:1689674680120 [07-18 18:04:40:120 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:866658 ts:0 [07-18 18:04:40:120 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:866658 [07-18 18:04:40:120 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:24489 dataSize:673 [07-18 18:04:40:120 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:26 timestamp:1689674680120 [07-18 18:04:40:153 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:899991 ts:0 [07-18 18:04:40:153 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:899991 [07-18 18:04:40:153 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:25162 dataSize:465 [07-18 18:04:40:153 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:27 timestamp:1689674680153 [07-18 18:04:40:153 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:899991 ts:0 [07-18 18:04:40:153 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:899991 [07-18 18:04:40:153 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:25162 dataSize:465 [07-18 18:04:40:153 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:27 timestamp:1689674680153 [07-18 18:04:40:160 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:160 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 7, head index 27 [07-18 18:04:40:160 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 8, seqNo 8, timestamp 1689674679513 [07-18 18:04:40:160 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:187 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:933324 ts:0 [07-18 18:04:40:187 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:933324 [07-18 18:04:40:187 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:25627 dataSize:248 [07-18 18:04:40:187 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:28 timestamp:1689674680187 [07-18 18:04:40:187 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:933324 ts:0 [07-18 18:04:40:187 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:933324 [07-18 18:04:40:187 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:25627 dataSize:248 [07-18 18:04:40:187 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:28 timestamp:1689674680187 [07-18 18:04:40:220 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:966657 ts:0 [07-18 18:04:40:220 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:966657 [07-18 18:04:40:220 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:25875 dataSize:217 [07-18 18:04:40:221 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:29 timestamp:1689674680221 [07-18 18:04:40:221 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:966657 ts:0 [07-18 18:04:40:221 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:966657 [07-18 18:04:40:221 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:25875 dataSize:217 [07-18 18:04:40:221 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:29 timestamp:1689674680221 [07-18 18:04:40:254 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:999990 ts:0 [07-18 18:04:40:254 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:999990 [07-18 18:04:40:254 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:26092 dataSize:280 [07-18 18:04:40:254 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:30 timestamp:1689674680254 [07-18 18:04:40:254 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:999990 ts:0 [07-18 18:04:40:254 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:999990 [07-18 18:04:40:254 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:26092 dataSize:280 [07-18 18:04:40:254 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:30 timestamp:1689674680254 [07-18 18:04:40:271 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:271 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 8, head index 30 [07-18 18:04:40:271 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 9, seqNo 9, timestamp 1689674679547 [07-18 18:04:40:271 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:288 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:1033323 ts:0 [07-18 18:04:40:288 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:1033323 [07-18 18:04:40:288 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:26372 dataSize:12088 [07-18 18:04:40:288 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:31 timestamp:1689674680288 [07-18 18:04:40:288 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:1033323 ts:0 [07-18 18:04:40:288 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:1033323 [07-18 18:04:40:288 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:26372 dataSize:12088 [07-18 18:04:40:288 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:31 timestamp:1689674680288 [07-18 18:04:40:321 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:1066656 ts:0 [07-18 18:04:40:321 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:1066656 [07-18 18:04:40:321 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:38460 dataSize:1051 [07-18 18:04:40:321 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:32 timestamp:1689674680321 [07-18 18:04:40:321 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:1066656 ts:0 [07-18 18:04:40:321 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:1066656 [07-18 18:04:40:322 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:38460 dataSize:1051 [07-18 18:04:40:322 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:32 timestamp:1689674680322 [07-18 18:04:40:355 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:1099989 ts:0 [07-18 18:04:40:355 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:1099989 [07-18 18:04:40:355 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:39511 dataSize:209 [07-18 18:04:40:355 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:33 timestamp:1689674680355 [07-18 18:04:40:355 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:1099989 ts:0 [07-18 18:04:40:355 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:1099989 [07-18 18:04:40:355 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:39511 dataSize:209 [07-18 18:04:40:355 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:33 timestamp:1689674680355 [07-18 18:04:40:381 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:381 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 9, head index 33 [07-18 18:04:40:381 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 10, seqNo 10, timestamp 1689674679581 [07-18 18:04:40:381 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:389 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:1133322 ts:0 [07-18 18:04:40:389 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:1133322 [07-18 18:04:40:389 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:39720 dataSize:118 [07-18 18:04:40:389 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:34 timestamp:1689674680389 [07-18 18:04:40:389 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:1133322 ts:0 [07-18 18:04:40:389 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:1133322 [07-18 18:04:40:389 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:39720 dataSize:118 [07-18 18:04:40:389 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:34 timestamp:1689674680389 [07-18 18:04:40:422 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:1166655 ts:0 [07-18 18:04:40:422 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:1166655 [07-18 18:04:40:422 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:39838 dataSize:110 [07-18 18:04:40:422 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:35 timestamp:1689674680422 [07-18 18:04:40:422 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:1166655 ts:0 [07-18 18:04:40:422 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:1166655 [07-18 18:04:40:422 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:39838 dataSize:110 [07-18 18:04:40:422 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:35 timestamp:1689674680422 [07-18 18:04:40:456 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:1199988 ts:0 [07-18 18:04:40:456 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:1199988 [07-18 18:04:40:456 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:39948 dataSize:695 [07-18 18:04:40:456 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:36 timestamp:1689674680456 [07-18 18:04:40:456 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:1199988 ts:0 [07-18 18:04:40:456 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:1199988 [07-18 18:04:40:456 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:39948 dataSize:695 [07-18 18:04:40:456 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:36 timestamp:1689674680456 [07-18 18:04:40:489 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:1233321 ts:0 [07-18 18:04:40:489 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:1233321 [07-18 18:04:40:490 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:40643 dataSize:1146 [07-18 18:04:40:490 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:37 timestamp:1689674680490 [07-18 18:04:40:490 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:1233321 ts:0 [07-18 18:04:40:490 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:1233321 [07-18 18:04:40:490 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:40643 dataSize:1146 [07-18 18:04:40:490 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:37 timestamp:1689674680490 [07-18 18:04:40:491 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:491 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 10, head index 37 [07-18 18:04:40:491 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 11, seqNo 11, timestamp 1689674679615 [07-18 18:04:40:491 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:523 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:1266654 ts:0 [07-18 18:04:40:523 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:1266654 [07-18 18:04:40:523 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:41789 dataSize:276 [07-18 18:04:40:523 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:38 timestamp:1689674680523 [07-18 18:04:40:523 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:1266654 ts:0 [07-18 18:04:40:523 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:1266654 [07-18 18:04:40:523 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:41789 dataSize:276 [07-18 18:04:40:523 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:38 timestamp:1689674680523 [07-18 18:04:40:557 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:1299987 ts:0 [07-18 18:04:40:557 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:1299987 [07-18 18:04:40:557 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:42065 dataSize:152 [07-18 18:04:40:557 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:39 timestamp:1689674680557 [07-18 18:04:40:557 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:1299987 ts:0 [07-18 18:04:40:557 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:1299987 [07-18 18:04:40:557 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:42065 dataSize:152 [07-18 18:04:40:557 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:39 timestamp:1689674680557 [07-18 18:04:40:590 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:1333320 ts:0 [07-18 18:04:40:590 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:1333320 [07-18 18:04:40:590 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:42217 dataSize:136 [07-18 18:04:40:590 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:40 timestamp:1689674680590 [07-18 18:04:40:590 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:1333320 ts:0 [07-18 18:04:40:590 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:1333320 [07-18 18:04:40:590 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:42217 dataSize:136 [07-18 18:04:40:590 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:40 timestamp:1689674680590 [07-18 18:04:40:602 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:602 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 11, head index 40 [07-18 18:04:40:602 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 12, seqNo 12, timestamp 1689674679648 [07-18 18:04:40:602 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:624 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:1366653 ts:0 [07-18 18:04:40:624 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:1366653 [07-18 18:04:40:624 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:42353 dataSize:725 [07-18 18:04:40:624 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:41 timestamp:1689674680624 [07-18 18:04:40:624 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:1366653 ts:0 [07-18 18:04:40:624 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:1366653 [07-18 18:04:40:624 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:42353 dataSize:725 [07-18 18:04:40:624 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:41 timestamp:1689674680624 [07-18 18:04:40:657 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:1399986 ts:0 [07-18 18:04:40:658 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:1399986 [07-18 18:04:40:658 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:43078 dataSize:1369 [07-18 18:04:40:658 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:42 timestamp:1689674680658 [07-18 18:04:40:658 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:1399986 ts:0 [07-18 18:04:40:658 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:1399986 [07-18 18:04:40:658 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:43078 dataSize:1369 [07-18 18:04:40:658 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:42 timestamp:1689674680658 [07-18 18:04:40:691 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:1433319 ts:0 [07-18 18:04:40:691 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:1433319 [07-18 18:04:40:691 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:44447 dataSize:367 [07-18 18:04:40:691 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:43 timestamp:1689674680691 [07-18 18:04:40:691 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:1433319 ts:0 [07-18 18:04:40:691 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:1433319 [07-18 18:04:40:691 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44447 dataSize:367 [07-18 18:04:40:691 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:43 timestamp:1689674680691 [07-18 18:04:40:712 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:712 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 12, head index 43 [07-18 18:04:40:712 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 13, seqNo 13, timestamp 1689674679682 [07-18 18:04:40:712 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:725 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:1466652 ts:0 [07-18 18:04:40:725 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:1466652 [07-18 18:04:40:725 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:44814 dataSize:141 [07-18 18:04:40:725 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:44 timestamp:1689674680725 [07-18 18:04:40:725 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:1466652 ts:0 [07-18 18:04:40:725 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:1466652 [07-18 18:04:40:725 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44814 dataSize:141 [07-18 18:04:40:725 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:44 timestamp:1689674680725 [07-18 18:04:40:758 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:1499985 ts:0 [07-18 18:04:40:758 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:1499985 [07-18 18:04:40:758 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:44955 dataSize:160 [07-18 18:04:40:758 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:45 timestamp:1689674680758 [07-18 18:04:40:758 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:1499985 ts:0 [07-18 18:04:40:758 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:1499985 [07-18 18:04:40:758 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44955 dataSize:160 [07-18 18:04:40:758 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:45 timestamp:1689674680758 [07-18 18:04:40:792 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:1533318 ts:0 [07-18 18:04:40:792 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:1533318 [07-18 18:04:40:792 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:45115 dataSize:756 [07-18 18:04:40:792 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:46 timestamp:1689674680792 [07-18 18:04:40:792 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:1533318 ts:0 [07-18 18:04:40:792 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:1533318 [07-18 18:04:40:792 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:45115 dataSize:756 [07-18 18:04:40:792 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:46 timestamp:1689674680792 [07-18 18:04:40:822 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:822 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 13, head index 46 [07-18 18:04:40:822 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 14, seqNo 14, timestamp 1689674679716 [07-18 18:04:40:823 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:826 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:1566651 ts:0 [07-18 18:04:40:826 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:1566651 [07-18 18:04:40:826 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:45871 dataSize:1610 [07-18 18:04:40:826 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:47 timestamp:1689674680826 [07-18 18:04:40:826 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:1566651 ts:0 [07-18 18:04:40:826 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:1566651 [07-18 18:04:40:826 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:45871 dataSize:1610 [07-18 18:04:40:826 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:47 timestamp:1689674680826 [07-18 18:04:40:840 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:40:841 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:40:859 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:1599984 ts:0 [07-18 18:04:40:859 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:1599984 [07-18 18:04:40:859 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:47481 dataSize:516 [07-18 18:04:40:859 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:48 timestamp:1689674680859 [07-18 18:04:40:859 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:1599984 ts:0 [07-18 18:04:40:859 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:1599984 [07-18 18:04:40:859 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:47481 dataSize:516 [07-18 18:04:40:859 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:48 timestamp:1689674680859 [07-18 18:04:40:893 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:1633317 ts:0 [07-18 18:04:40:893 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:1633317 [07-18 18:04:40:893 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:47997 dataSize:231 [07-18 18:04:40:893 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:49 timestamp:1689674680893 [07-18 18:04:40:893 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:1633317 ts:0 [07-18 18:04:40:893 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:1633317 [07-18 18:04:40:893 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:47997 dataSize:231 [07-18 18:04:40:893 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:49 timestamp:1689674680893 [07-18 18:04:40:926 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:1666650 ts:0 [07-18 18:04:40:926 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:1666650 [07-18 18:04:40:926 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:48228 dataSize:250 [07-18 18:04:40:926 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:50 timestamp:1689674680926 [07-18 18:04:40:926 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:1666650 ts:0 [07-18 18:04:40:926 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:1666650 [07-18 18:04:40:926 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:48228 dataSize:250 [07-18 18:04:40:926 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:50 timestamp:1689674680926 [07-18 18:04:40:933 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:40:933 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 14, head index 50 [07-18 18:04:40:933 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 15, seqNo 15, timestamp 1689674679749 [07-18 18:04:40:933 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:40:960 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:1699983 ts:0 [07-18 18:04:40:960 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:1699983 [07-18 18:04:40:960 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:48478 dataSize:1143 [07-18 18:04:40:960 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:51 timestamp:1689674680960 [07-18 18:04:40:960 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:1699983 ts:0 [07-18 18:04:40:960 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:1699983 [07-18 18:04:40:960 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:48478 dataSize:1143 [07-18 18:04:40:960 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:51 timestamp:1689674680960 [07-18 18:04:40:993 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:1733316 ts:0 [07-18 18:04:40:994 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:1733316 [07-18 18:04:40:994 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:49621 dataSize:383 [07-18 18:04:40:994 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:52 timestamp:1689674680994 [07-18 18:04:40:994 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:1733316 ts:0 [07-18 18:04:40:994 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:1733316 [07-18 18:04:40:994 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:49621 dataSize:383 [07-18 18:04:40:994 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:52 timestamp:1689674680994 [07-18 18:04:41:27 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:1766649 ts:0 [07-18 18:04:41:27 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:1766649 [07-18 18:04:41:27 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:50004 dataSize:235 [07-18 18:04:41:27 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:53 timestamp:1689674681027 [07-18 18:04:41:27 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:1766649 ts:0 [07-18 18:04:41:27 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:1766649 [07-18 18:04:41:27 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50004 dataSize:235 [07-18 18:04:41:27 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:53 timestamp:1689674681027 [07-18 18:04:41:43 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:43 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 15, head index 53 [07-18 18:04:41:43 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 16, seqNo 16, timestamp 1689674679783 [07-18 18:04:41:43 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:61 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:1799982 ts:0 [07-18 18:04:41:61 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:1799982 [07-18 18:04:41:61 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:50239 dataSize:165 [07-18 18:04:41:61 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:54 timestamp:1689674681061 [07-18 18:04:41:61 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:1799982 ts:0 [07-18 18:04:41:61 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:1799982 [07-18 18:04:41:61 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50239 dataSize:165 [07-18 18:04:41:61 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:54 timestamp:1689674681061 [07-18 18:04:41:94 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:1833315 ts:0 [07-18 18:04:41:94 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:1833315 [07-18 18:04:41:95 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:50404 dataSize:457 [07-18 18:04:41:95 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:55 timestamp:1689674681095 [07-18 18:04:41:95 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:1833315 ts:0 [07-18 18:04:41:95 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:1833315 [07-18 18:04:41:95 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50404 dataSize:457 [07-18 18:04:41:95 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:55 timestamp:1689674681095 [07-18 18:04:41:128 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:1866648 ts:0 [07-18 18:04:41:128 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:1866648 [07-18 18:04:41:128 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:50861 dataSize:673 [07-18 18:04:41:128 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:56 timestamp:1689674681128 [07-18 18:04:41:128 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:1866648 ts:0 [07-18 18:04:41:128 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:1866648 [07-18 18:04:41:128 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50861 dataSize:673 [07-18 18:04:41:128 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:56 timestamp:1689674681128 [07-18 18:04:41:154 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:154 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 16, head index 56 [07-18 18:04:41:154 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 17, seqNo 17, timestamp 1689674679817 [07-18 18:04:41:154 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:162 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:1899981 ts:0 [07-18 18:04:41:162 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:1899981 [07-18 18:04:41:162 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:51534 dataSize:465 [07-18 18:04:41:162 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:57 timestamp:1689674681162 [07-18 18:04:41:162 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:1899981 ts:0 [07-18 18:04:41:162 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:1899981 [07-18 18:04:41:162 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:51534 dataSize:465 [07-18 18:04:41:162 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:57 timestamp:1689674681162 [07-18 18:04:41:195 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:1933314 ts:0 [07-18 18:04:41:195 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:1933314 [07-18 18:04:41:195 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:51999 dataSize:248 [07-18 18:04:41:195 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:58 timestamp:1689674681195 [07-18 18:04:41:195 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:1933314 ts:0 [07-18 18:04:41:195 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:1933314 [07-18 18:04:41:195 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:51999 dataSize:248 [07-18 18:04:41:195 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:58 timestamp:1689674681195 [07-18 18:04:41:229 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:1966647 ts:0 [07-18 18:04:41:229 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:1966647 [07-18 18:04:41:229 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:52247 dataSize:217 [07-18 18:04:41:229 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:59 timestamp:1689674681229 [07-18 18:04:41:229 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:1966647 ts:0 [07-18 18:04:41:229 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:1966647 [07-18 18:04:41:229 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52247 dataSize:217 [07-18 18:04:41:229 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:59 timestamp:1689674681229 [07-18 18:04:41:262 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:1999980 ts:0 [07-18 18:04:41:263 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:1999980 [07-18 18:04:41:263 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:52464 dataSize:280 [07-18 18:04:41:263 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:60 timestamp:1689674681263 [07-18 18:04:41:263 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:1999980 ts:0 [07-18 18:04:41:263 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:1999980 [07-18 18:04:41:263 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52464 dataSize:280 [07-18 18:04:41:263 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:60 timestamp:1689674681263 [07-18 18:04:41:264 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:264 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 17, head index 60 [07-18 18:04:41:264 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 18, seqNo 18, timestamp 1689674679850 [07-18 18:04:41:264 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:296 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:2033313 ts:0 [07-18 18:04:41:296 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:2033313 [07-18 18:04:41:296 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:52744 dataSize:12088 [07-18 18:04:41:296 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:61 timestamp:1689674681296 [07-18 18:04:41:296 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:2033313 ts:0 [07-18 18:04:41:296 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:2033313 [07-18 18:04:41:296 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52744 dataSize:12088 [07-18 18:04:41:296 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:61 timestamp:1689674681296 [07-18 18:04:41:330 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:2066646 ts:0 [07-18 18:04:41:330 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:2066646 [07-18 18:04:41:330 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:64832 dataSize:1051 [07-18 18:04:41:330 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:62 timestamp:1689674681330 [07-18 18:04:41:330 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:2066646 ts:0 [07-18 18:04:41:330 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:2066646 [07-18 18:04:41:330 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:64832 dataSize:1051 [07-18 18:04:41:330 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:62 timestamp:1689674681330 [07-18 18:04:41:363 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:2099979 ts:0 [07-18 18:04:41:364 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:2099979 [07-18 18:04:41:364 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:65883 dataSize:209 [07-18 18:04:41:364 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:63 timestamp:1689674681364 [07-18 18:04:41:364 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:2099979 ts:0 [07-18 18:04:41:364 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:2099979 [07-18 18:04:41:364 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:65883 dataSize:209 [07-18 18:04:41:364 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:63 timestamp:1689674681364 [07-18 18:04:41:375 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:375 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 18, head index 63 [07-18 18:04:41:375 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 19, seqNo 19, timestamp 1689674679884 [07-18 18:04:41:375 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:397 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:2133312 ts:0 [07-18 18:04:41:397 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:2133312 [07-18 18:04:41:397 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:66092 dataSize:118 [07-18 18:04:41:397 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:64 timestamp:1689674681397 [07-18 18:04:41:397 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:2133312 ts:0 [07-18 18:04:41:397 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:2133312 [07-18 18:04:41:397 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:66092 dataSize:118 [07-18 18:04:41:397 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:64 timestamp:1689674681397 [07-18 18:04:41:431 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:2166645 ts:0 [07-18 18:04:41:431 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:2166645 [07-18 18:04:41:431 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:66210 dataSize:110 [07-18 18:04:41:431 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:65 timestamp:1689674681431 [07-18 18:04:41:431 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:2166645 ts:0 [07-18 18:04:41:431 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:2166645 [07-18 18:04:41:431 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:66210 dataSize:110 [07-18 18:04:41:431 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:65 timestamp:1689674681431 [07-18 18:04:41:464 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:2199978 ts:0 [07-18 18:04:41:464 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:2199978 [07-18 18:04:41:464 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:66320 dataSize:695 [07-18 18:04:41:464 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:66 timestamp:1689674681464 [07-18 18:04:41:465 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:2199978 ts:0 [07-18 18:04:41:465 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:2199978 [07-18 18:04:41:465 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:66320 dataSize:695 [07-18 18:04:41:465 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:66 timestamp:1689674681465 [07-18 18:04:41:485 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:485 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 19, head index 66 [07-18 18:04:41:485 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 20, seqNo 20, timestamp 1689674679918 [07-18 18:04:41:485 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:498 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:2233311 ts:0 [07-18 18:04:41:498 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:2233311 [07-18 18:04:41:498 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:67015 dataSize:1146 [07-18 18:04:41:498 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:67 timestamp:1689674681498 [07-18 18:04:41:498 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:2233311 ts:0 [07-18 18:04:41:498 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:2233311 [07-18 18:04:41:498 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:67015 dataSize:1146 [07-18 18:04:41:498 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:67 timestamp:1689674681498 [07-18 18:04:41:532 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:2266644 ts:0 [07-18 18:04:41:532 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:2266644 [07-18 18:04:41:532 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:68161 dataSize:276 [07-18 18:04:41:532 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:68 timestamp:1689674681532 [07-18 18:04:41:532 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:2266644 ts:0 [07-18 18:04:41:532 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:2266644 [07-18 18:04:41:532 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:68161 dataSize:276 [07-18 18:04:41:532 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:68 timestamp:1689674681532 [07-18 18:04:41:565 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:2299977 ts:0 [07-18 18:04:41:565 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:2299977 [07-18 18:04:41:565 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:68437 dataSize:152 [07-18 18:04:41:565 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:69 timestamp:1689674681565 [07-18 18:04:41:566 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:2299977 ts:0 [07-18 18:04:41:566 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:2299977 [07-18 18:04:41:566 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:68437 dataSize:152 [07-18 18:04:41:566 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:69 timestamp:1689674681566 [07-18 18:04:41:595 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:595 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 20, head index 69 [07-18 18:04:41:595 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 21, seqNo 21, timestamp 1689674679951 [07-18 18:04:41:595 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:599 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:2333310 ts:0 [07-18 18:04:41:599 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:2333310 [07-18 18:04:41:599 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:68589 dataSize:136 [07-18 18:04:41:599 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:70 timestamp:1689674681599 [07-18 18:04:41:599 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:2333310 ts:0 [07-18 18:04:41:599 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:2333310 [07-18 18:04:41:599 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:68589 dataSize:136 [07-18 18:04:41:599 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:70 timestamp:1689674681599 [07-18 18:04:41:633 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:2366643 ts:0 [07-18 18:04:41:633 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:2366643 [07-18 18:04:41:633 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:68725 dataSize:725 [07-18 18:04:41:633 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:71 timestamp:1689674681633 [07-18 18:04:41:633 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:2366643 ts:0 [07-18 18:04:41:633 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:2366643 [07-18 18:04:41:633 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:68725 dataSize:725 [07-18 18:04:41:633 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:71 timestamp:1689674681633 [07-18 18:04:41:666 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:2399976 ts:0 [07-18 18:04:41:666 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:2399976 [07-18 18:04:41:666 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:69450 dataSize:1369 [07-18 18:04:41:666 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:72 timestamp:1689674681666 [07-18 18:04:41:666 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:2399976 ts:0 [07-18 18:04:41:666 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:2399976 [07-18 18:04:41:666 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:69450 dataSize:1369 [07-18 18:04:41:666 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:72 timestamp:1689674681666 [07-18 18:04:41:700 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:2433309 ts:0 [07-18 18:04:41:700 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:2433309 [07-18 18:04:41:700 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:70819 dataSize:367 [07-18 18:04:41:700 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:73 timestamp:1689674681700 [07-18 18:04:41:700 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:2433309 ts:0 [07-18 18:04:41:700 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:2433309 [07-18 18:04:41:700 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:70819 dataSize:367 [07-18 18:04:41:700 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:73 timestamp:1689674681700 [07-18 18:04:41:705 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:706 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 21, head index 73 [07-18 18:04:41:706 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 22, seqNo 22, timestamp 1689674679985 [07-18 18:04:41:706 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:734 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:2466642 ts:0 [07-18 18:04:41:734 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:2466642 [07-18 18:04:41:734 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:71186 dataSize:141 [07-18 18:04:41:734 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:74 timestamp:1689674681734 [07-18 18:04:41:734 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:2466642 ts:0 [07-18 18:04:41:734 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:2466642 [07-18 18:04:41:734 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:71186 dataSize:141 [07-18 18:04:41:734 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:74 timestamp:1689674681734 [07-18 18:04:41:767 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:2499975 ts:0 [07-18 18:04:41:767 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:2499975 [07-18 18:04:41:767 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:71327 dataSize:160 [07-18 18:04:41:767 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:75 timestamp:1689674681767 [07-18 18:04:41:767 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:2499975 ts:0 [07-18 18:04:41:767 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:2499975 [07-18 18:04:41:767 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:71327 dataSize:160 [07-18 18:04:41:767 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:75 timestamp:1689674681767 [07-18 18:04:41:801 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:2533308 ts:0 [07-18 18:04:41:801 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:2533308 [07-18 18:04:41:801 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:71487 dataSize:756 [07-18 18:04:41:801 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:76 timestamp:1689674681801 [07-18 18:04:41:801 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:2533308 ts:0 [07-18 18:04:41:801 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:2533308 [07-18 18:04:41:801 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:71487 dataSize:756 [07-18 18:04:41:801 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:76 timestamp:1689674681801 [07-18 18:04:41:816 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:816 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 22, head index 76 [07-18 18:04:41:816 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 23, seqNo 23, timestamp 1689674680019 [07-18 18:04:41:816 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:835 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:2566641 ts:0 [07-18 18:04:41:835 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:2566641 [07-18 18:04:41:835 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:72243 dataSize:1610 [07-18 18:04:41:835 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:77 timestamp:1689674681835 [07-18 18:04:41:835 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:2566641 ts:0 [07-18 18:04:41:835 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:2566641 [07-18 18:04:41:835 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:72243 dataSize:1610 [07-18 18:04:41:835 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:77 timestamp:1689674681835 [07-18 18:04:41:842 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:41:842 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:41:868 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:2599974 ts:0 [07-18 18:04:41:868 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:2599974 [07-18 18:04:41:868 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:73853 dataSize:516 [07-18 18:04:41:868 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:78 timestamp:1689674681868 [07-18 18:04:41:868 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:2599974 ts:0 [07-18 18:04:41:868 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:2599974 [07-18 18:04:41:868 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:73853 dataSize:516 [07-18 18:04:41:868 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:78 timestamp:1689674681868 [07-18 18:04:41:902 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:2633307 ts:0 [07-18 18:04:41:902 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:2633307 [07-18 18:04:41:902 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:74369 dataSize:231 [07-18 18:04:41:902 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:79 timestamp:1689674681902 [07-18 18:04:41:902 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:2633307 ts:0 [07-18 18:04:41:902 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:2633307 [07-18 18:04:41:902 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:74369 dataSize:231 [07-18 18:04:41:902 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:79 timestamp:1689674681902 [07-18 18:04:41:926 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:41:926 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 23, head index 79 [07-18 18:04:41:926 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 24, seqNo 24, timestamp 1689674680052 [07-18 18:04:41:926 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:41:935 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:2666640 ts:0 [07-18 18:04:41:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:2666640 [07-18 18:04:41:936 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:74600 dataSize:250 [07-18 18:04:41:936 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:80 timestamp:1689674681936 [07-18 18:04:41:936 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:2666640 ts:0 [07-18 18:04:41:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:2666640 [07-18 18:04:41:936 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:74600 dataSize:250 [07-18 18:04:41:936 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:80 timestamp:1689674681936 [07-18 18:04:41:969 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:2699973 ts:0 [07-18 18:04:41:969 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:2699973 [07-18 18:04:41:969 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:74850 dataSize:1143 [07-18 18:04:41:969 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:81 timestamp:1689674681969 [07-18 18:04:41:969 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:2699973 ts:0 [07-18 18:04:41:969 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:2699973 [07-18 18:04:41:969 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:74850 dataSize:1143 [07-18 18:04:41:969 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:81 timestamp:1689674681969 [07-18 18:04:42:3 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:2733306 ts:0 [07-18 18:04:42:3 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:2733306 [07-18 18:04:42:3 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:75993 dataSize:383 [07-18 18:04:42:3 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:82 timestamp:1689674682003 [07-18 18:04:42:3 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:2733306 ts:0 [07-18 18:04:42:3 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:2733306 [07-18 18:04:42:3 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:75993 dataSize:383 [07-18 18:04:42:3 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:82 timestamp:1689674682003 [07-18 18:04:42:36 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:36 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 24, head index 82 [07-18 18:04:42:36 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 25, seqNo 25, timestamp 1689674680086 [07-18 18:04:42:36 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:2766639 ts:0 [07-18 18:04:42:36 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:2766639 [07-18 18:04:42:36 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:76376 dataSize:235 [07-18 18:04:42:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:83 timestamp:1689674682037 [07-18 18:04:42:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:2766639 ts:0 [07-18 18:04:42:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:2766639 [07-18 18:04:42:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:76376 dataSize:235 [07-18 18:04:42:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:83 timestamp:1689674682037 [07-18 18:04:42:37 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:70 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:2799972 ts:0 [07-18 18:04:42:70 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:2799972 [07-18 18:04:42:70 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:76611 dataSize:165 [07-18 18:04:42:70 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:84 timestamp:1689674682070 [07-18 18:04:42:70 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:2799972 ts:0 [07-18 18:04:42:70 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:2799972 [07-18 18:04:42:70 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:76611 dataSize:165 [07-18 18:04:42:70 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:84 timestamp:1689674682070 [07-18 18:04:42:104 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:2833305 ts:0 [07-18 18:04:42:104 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:2833305 [07-18 18:04:42:104 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:76776 dataSize:457 [07-18 18:04:42:104 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:85 timestamp:1689674682104 [07-18 18:04:42:104 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:2833305 ts:0 [07-18 18:04:42:104 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:2833305 [07-18 18:04:42:104 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:76776 dataSize:457 [07-18 18:04:42:104 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:85 timestamp:1689674682104 [07-18 18:04:42:137 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:2866638 ts:0 [07-18 18:04:42:137 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:2866638 [07-18 18:04:42:137 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:77233 dataSize:673 [07-18 18:04:42:137 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:86 timestamp:1689674682137 [07-18 18:04:42:137 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:2866638 ts:0 [07-18 18:04:42:137 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:2866638 [07-18 18:04:42:138 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:77233 dataSize:673 [07-18 18:04:42:138 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:86 timestamp:1689674682138 [07-18 18:04:42:147 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:147 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 25, head index 86 [07-18 18:04:42:147 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 26, seqNo 26, timestamp 1689674680120 [07-18 18:04:42:147 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:171 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:2899971 ts:0 [07-18 18:04:42:171 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:2899971 [07-18 18:04:42:171 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:77906 dataSize:465 [07-18 18:04:42:171 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:87 timestamp:1689674682171 [07-18 18:04:42:171 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:2899971 ts:0 [07-18 18:04:42:171 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:2899971 [07-18 18:04:42:171 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:77906 dataSize:465 [07-18 18:04:42:171 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:87 timestamp:1689674682171 [07-18 18:04:42:205 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:2933304 ts:0 [07-18 18:04:42:205 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:2933304 [07-18 18:04:42:205 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:78371 dataSize:248 [07-18 18:04:42:205 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:88 timestamp:1689674682205 [07-18 18:04:42:205 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:2933304 ts:0 [07-18 18:04:42:205 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:2933304 [07-18 18:04:42:205 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:78371 dataSize:248 [07-18 18:04:42:205 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:88 timestamp:1689674682205 [07-18 18:04:42:238 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:2966637 ts:0 [07-18 18:04:42:238 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:2966637 [07-18 18:04:42:238 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:78619 dataSize:217 [07-18 18:04:42:238 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:89 timestamp:1689674682238 [07-18 18:04:42:238 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:2966637 ts:0 [07-18 18:04:42:238 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:2966637 [07-18 18:04:42:239 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:78619 dataSize:217 [07-18 18:04:42:239 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:89 timestamp:1689674682239 [07-18 18:04:42:257 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:257 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 26, head index 89 [07-18 18:04:42:257 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 27, seqNo 27, timestamp 1689674680153 [07-18 18:04:42:257 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:272 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:2999970 ts:0 [07-18 18:04:42:272 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:2999970 [07-18 18:04:42:272 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:78836 dataSize:280 [07-18 18:04:42:272 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:90 timestamp:1689674682272 [07-18 18:04:42:272 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:2999970 ts:0 [07-18 18:04:42:272 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:2999970 [07-18 18:04:42:272 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:78836 dataSize:280 [07-18 18:04:42:272 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:90 timestamp:1689674682272 [07-18 18:04:42:306 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:3033303 ts:0 [07-18 18:04:42:306 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:3033303 [07-18 18:04:42:306 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:79116 dataSize:12088 [07-18 18:04:42:306 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:91 timestamp:1689674682306 [07-18 18:04:42:306 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:3033303 ts:0 [07-18 18:04:42:306 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:3033303 [07-18 18:04:42:306 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:79116 dataSize:12088 [07-18 18:04:42:306 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:91 timestamp:1689674682306 [07-18 18:04:42:339 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:3066636 ts:0 [07-18 18:04:42:339 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:3066636 [07-18 18:04:42:339 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:91204 dataSize:1051 [07-18 18:04:42:339 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:92 timestamp:1689674682339 [07-18 18:04:42:339 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:3066636 ts:0 [07-18 18:04:42:339 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:3066636 [07-18 18:04:42:340 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:91204 dataSize:1051 [07-18 18:04:42:340 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:92 timestamp:1689674682340 [07-18 18:04:42:367 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:367 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 27, head index 92 [07-18 18:04:42:367 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 28, seqNo 28, timestamp 1689674680187 [07-18 18:04:42:368 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:373 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:3099969 ts:0 [07-18 18:04:42:373 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:3099969 [07-18 18:04:42:373 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:92255 dataSize:209 [07-18 18:04:42:373 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:93 timestamp:1689674682373 [07-18 18:04:42:373 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:3099969 ts:0 [07-18 18:04:42:373 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:3099969 [07-18 18:04:42:373 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:92255 dataSize:209 [07-18 18:04:42:373 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:93 timestamp:1689674682373 [07-18 18:04:42:407 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:3133302 ts:0 [07-18 18:04:42:407 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:3133302 [07-18 18:04:42:407 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:92464 dataSize:118 [07-18 18:04:42:407 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:94 timestamp:1689674682407 [07-18 18:04:42:407 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:3133302 ts:0 [07-18 18:04:42:407 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:3133302 [07-18 18:04:42:407 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:92464 dataSize:118 [07-18 18:04:42:407 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:94 timestamp:1689674682407 [07-18 18:04:42:440 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:3166635 ts:0 [07-18 18:04:42:440 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:3166635 [07-18 18:04:42:440 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:92582 dataSize:110 [07-18 18:04:42:440 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:95 timestamp:1689674682440 [07-18 18:04:42:440 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:3166635 ts:0 [07-18 18:04:42:440 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:3166635 [07-18 18:04:42:440 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:92582 dataSize:110 [07-18 18:04:42:441 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:95 timestamp:1689674682441 [07-18 18:04:42:474 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:3199968 ts:0 [07-18 18:04:42:474 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:3199968 [07-18 18:04:42:474 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:92692 dataSize:695 [07-18 18:04:42:474 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:96 timestamp:1689674682474 [07-18 18:04:42:474 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:3199968 ts:0 [07-18 18:04:42:474 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:3199968 [07-18 18:04:42:474 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:92692 dataSize:695 [07-18 18:04:42:474 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:96 timestamp:1689674682474 [07-18 18:04:42:478 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:478 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 28, head index 96 [07-18 18:04:42:478 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 29, seqNo 29, timestamp 1689674680221 [07-18 18:04:42:478 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:508 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:3233301 ts:0 [07-18 18:04:42:508 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:3233301 [07-18 18:04:42:508 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:93387 dataSize:1146 [07-18 18:04:42:508 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:97 timestamp:1689674682508 [07-18 18:04:42:508 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:3233301 ts:0 [07-18 18:04:42:508 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:3233301 [07-18 18:04:42:508 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:93387 dataSize:1146 [07-18 18:04:42:508 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:97 timestamp:1689674682508 [07-18 18:04:42:541 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:3266634 ts:0 [07-18 18:04:42:541 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:3266634 [07-18 18:04:42:541 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:94533 dataSize:276 [07-18 18:04:42:541 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:98 timestamp:1689674682541 [07-18 18:04:42:541 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:3266634 ts:0 [07-18 18:04:42:541 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:3266634 [07-18 18:04:42:541 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:94533 dataSize:276 [07-18 18:04:42:542 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:98 timestamp:1689674682542 [07-18 18:04:42:575 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:3299967 ts:0 [07-18 18:04:42:575 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:3299967 [07-18 18:04:42:575 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:94809 dataSize:152 [07-18 18:04:42:575 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:99 timestamp:1689674682575 [07-18 18:04:42:575 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:3299967 ts:0 [07-18 18:04:42:575 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:3299967 [07-18 18:04:42:575 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:94809 dataSize:152 [07-18 18:04:42:575 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:99 timestamp:1689674682575 [07-18 18:04:42:588 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:588 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 29, head index 99 [07-18 18:04:42:588 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 30, seqNo 30, timestamp 1689674680254 [07-18 18:04:42:588 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:609 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:3333300 ts:0 [07-18 18:04:42:609 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:3333300 [07-18 18:04:42:609 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:94961 dataSize:136 [07-18 18:04:42:609 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:100 timestamp:1689674682609 [07-18 18:04:42:609 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:3333300 ts:0 [07-18 18:04:42:609 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:3333300 [07-18 18:04:42:609 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:94961 dataSize:136 [07-18 18:04:42:609 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:100 timestamp:1689674682609 [07-18 18:04:42:642 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:3366633 ts:0 [07-18 18:04:42:642 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:3366633 [07-18 18:04:42:642 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:95097 dataSize:725 [07-18 18:04:42:642 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:101 timestamp:1689674682642 [07-18 18:04:42:642 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:3366633 ts:0 [07-18 18:04:42:642 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:3366633 [07-18 18:04:42:642 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:95097 dataSize:725 [07-18 18:04:42:642 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:101 timestamp:1689674682642 [07-18 18:04:42:676 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:3399966 ts:0 [07-18 18:04:42:676 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:3399966 [07-18 18:04:42:676 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:95822 dataSize:1369 [07-18 18:04:42:676 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:102 timestamp:1689674682676 [07-18 18:04:42:676 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:3399966 ts:0 [07-18 18:04:42:676 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:3399966 [07-18 18:04:42:676 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:95822 dataSize:1369 [07-18 18:04:42:676 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:102 timestamp:1689674682676 [07-18 18:04:42:698 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:698 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 30, head index 102 [07-18 18:04:42:698 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 31, seqNo 31, timestamp 1689674680288 [07-18 18:04:42:699 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:710 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:3433299 ts:0 [07-18 18:04:42:710 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:3433299 [07-18 18:04:42:710 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:97191 dataSize:367 [07-18 18:04:42:710 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:103 timestamp:1689674682710 [07-18 18:04:42:710 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:3433299 ts:0 [07-18 18:04:42:710 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:3433299 [07-18 18:04:42:710 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97191 dataSize:367 [07-18 18:04:42:710 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:103 timestamp:1689674682710 [07-18 18:04:42:743 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:3466632 ts:0 [07-18 18:04:42:743 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:3466632 [07-18 18:04:42:743 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:97558 dataSize:141 [07-18 18:04:42:743 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:104 timestamp:1689674682743 [07-18 18:04:42:743 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:3466632 ts:0 [07-18 18:04:42:743 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:3466632 [07-18 18:04:42:743 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97558 dataSize:141 [07-18 18:04:42:743 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:104 timestamp:1689674682743 [07-18 18:04:42:777 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:3499965 ts:0 [07-18 18:04:42:777 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:3499965 [07-18 18:04:42:777 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:97699 dataSize:160 [07-18 18:04:42:777 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:105 timestamp:1689674682777 [07-18 18:04:42:777 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:3499965 ts:0 [07-18 18:04:42:777 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:3499965 [07-18 18:04:42:777 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97699 dataSize:160 [07-18 18:04:42:777 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:105 timestamp:1689674682777 [07-18 18:04:42:809 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:809 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 31, head index 105 [07-18 18:04:42:809 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 32, seqNo 32, timestamp 1689674680321 [07-18 18:04:42:809 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:810 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:3533298 ts:0 [07-18 18:04:42:810 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:3533298 [07-18 18:04:42:810 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:97859 dataSize:756 [07-18 18:04:42:810 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:106 timestamp:1689674682810 [07-18 18:04:42:810 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:3533298 ts:0 [07-18 18:04:42:811 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:3533298 [07-18 18:04:42:811 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97859 dataSize:756 [07-18 18:04:42:811 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:106 timestamp:1689674682811 [07-18 18:04:42:843 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:42:843 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:42:844 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:3566631 ts:0 [07-18 18:04:42:844 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:3566631 [07-18 18:04:42:844 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:98615 dataSize:1610 [07-18 18:04:42:844 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:107 timestamp:1689674682844 [07-18 18:04:42:844 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:3566631 ts:0 [07-18 18:04:42:844 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:3566631 [07-18 18:04:42:844 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:98615 dataSize:1610 [07-18 18:04:42:844 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:107 timestamp:1689674682844 [07-18 18:04:42:878 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:3599964 ts:0 [07-18 18:04:42:878 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:3599964 [07-18 18:04:42:878 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:100225 dataSize:516 [07-18 18:04:42:878 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:108 timestamp:1689674682878 [07-18 18:04:42:878 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:3599964 ts:0 [07-18 18:04:42:878 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:3599964 [07-18 18:04:42:878 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:100225 dataSize:516 [07-18 18:04:42:878 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:108 timestamp:1689674682878 [07-18 18:04:42:911 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:3633297 ts:0 [07-18 18:04:42:911 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:3633297 [07-18 18:04:42:911 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:100741 dataSize:231 [07-18 18:04:42:911 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:109 timestamp:1689674682911 [07-18 18:04:42:911 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:3633297 ts:0 [07-18 18:04:42:911 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:3633297 [07-18 18:04:42:911 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:100741 dataSize:231 [07-18 18:04:42:911 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:109 timestamp:1689674682911 [07-18 18:04:42:919 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:42:919 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 32, head index 109 [07-18 18:04:42:919 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 33, seqNo 33, timestamp 1689674680355 [07-18 18:04:42:919 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:42:945 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:3666630 ts:0 [07-18 18:04:42:945 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:3666630 [07-18 18:04:42:945 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:100972 dataSize:250 [07-18 18:04:42:945 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:110 timestamp:1689674682945 [07-18 18:04:42:945 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:3666630 ts:0 [07-18 18:04:42:945 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:3666630 [07-18 18:04:42:945 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:100972 dataSize:250 [07-18 18:04:42:945 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:110 timestamp:1689674682945 [07-18 18:04:42:979 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:3699963 ts:0 [07-18 18:04:42:979 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:3699963 [07-18 18:04:42:979 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:101222 dataSize:1143 [07-18 18:04:42:979 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:111 timestamp:1689674682979 [07-18 18:04:42:979 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:3699963 ts:0 [07-18 18:04:42:979 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:3699963 [07-18 18:04:42:979 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:101222 dataSize:1143 [07-18 18:04:42:979 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:111 timestamp:1689674682979 [07-18 18:04:43:12 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:3733296 ts:0 [07-18 18:04:43:12 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:3733296 [07-18 18:04:43:12 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:102365 dataSize:383 [07-18 18:04:43:12 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:112 timestamp:1689674683012 [07-18 18:04:43:12 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:3733296 ts:0 [07-18 18:04:43:12 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:3733296 [07-18 18:04:43:12 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:102365 dataSize:383 [07-18 18:04:43:12 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:112 timestamp:1689674683012 [07-18 18:04:43:29 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:30 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 33, head index 112 [07-18 18:04:43:30 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 34, seqNo 34, timestamp 1689674680389 [07-18 18:04:43:30 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:46 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:3766629 ts:0 [07-18 18:04:43:46 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:3766629 [07-18 18:04:43:46 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:102748 dataSize:235 [07-18 18:04:43:46 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:113 timestamp:1689674683046 [07-18 18:04:43:46 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:3766629 ts:0 [07-18 18:04:43:46 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:3766629 [07-18 18:04:43:46 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:102748 dataSize:235 [07-18 18:04:43:46 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:113 timestamp:1689674683046 [07-18 18:04:43:80 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:3799962 ts:0 [07-18 18:04:43:80 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:3799962 [07-18 18:04:43:80 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:102983 dataSize:165 [07-18 18:04:43:80 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:114 timestamp:1689674683080 [07-18 18:04:43:80 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:3799962 ts:0 [07-18 18:04:43:80 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:3799962 [07-18 18:04:43:80 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:102983 dataSize:165 [07-18 18:04:43:80 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:114 timestamp:1689674683080 [07-18 18:04:43:114 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:3833295 ts:0 [07-18 18:04:43:114 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:3833295 [07-18 18:04:43:114 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:103148 dataSize:457 [07-18 18:04:43:114 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:115 timestamp:1689674683114 [07-18 18:04:43:114 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:3833295 ts:0 [07-18 18:04:43:114 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:3833295 [07-18 18:04:43:114 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:103148 dataSize:457 [07-18 18:04:43:114 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:115 timestamp:1689674683114 [07-18 18:04:43:140 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:140 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 34, head index 115 [07-18 18:04:43:140 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 35, seqNo 35, timestamp 1689674680422 [07-18 18:04:43:140 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:148 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:3866628 ts:0 [07-18 18:04:43:148 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:3866628 [07-18 18:04:43:148 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:103605 dataSize:673 [07-18 18:04:43:148 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:116 timestamp:1689674683148 [07-18 18:04:43:148 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:3866628 ts:0 [07-18 18:04:43:148 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:3866628 [07-18 18:04:43:148 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:103605 dataSize:673 [07-18 18:04:43:148 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:116 timestamp:1689674683148 [07-18 18:04:43:181 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:3899961 ts:0 [07-18 18:04:43:181 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:3899961 [07-18 18:04:43:181 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:104278 dataSize:465 [07-18 18:04:43:181 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:117 timestamp:1689674683181 [07-18 18:04:43:181 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:3899961 ts:0 [07-18 18:04:43:181 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:3899961 [07-18 18:04:43:181 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:104278 dataSize:465 [07-18 18:04:43:181 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:117 timestamp:1689674683181 [07-18 18:04:43:215 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:3933294 ts:0 [07-18 18:04:43:215 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:3933294 [07-18 18:04:43:215 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:104743 dataSize:248 [07-18 18:04:43:215 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:118 timestamp:1689674683215 [07-18 18:04:43:215 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:3933294 ts:0 [07-18 18:04:43:215 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:3933294 [07-18 18:04:43:215 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:104743 dataSize:248 [07-18 18:04:43:215 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:118 timestamp:1689674683215 [07-18 18:04:43:249 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:3966627 ts:0 [07-18 18:04:43:249 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:3966627 [07-18 18:04:43:249 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:104991 dataSize:217 [07-18 18:04:43:249 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:119 timestamp:1689674683249 [07-18 18:04:43:249 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:3966627 ts:0 [07-18 18:04:43:249 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:3966627 [07-18 18:04:43:249 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:104991 dataSize:217 [07-18 18:04:43:249 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:119 timestamp:1689674683249 [07-18 18:04:43:250 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:250 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 35, head index 119 [07-18 18:04:43:250 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 36, seqNo 36, timestamp 1689674680456 [07-18 18:04:43:250 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:282 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:3999960 ts:0 [07-18 18:04:43:282 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:3999960 [07-18 18:04:43:282 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:105208 dataSize:280 [07-18 18:04:43:282 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:120 timestamp:1689674683282 [07-18 18:04:43:282 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:3999960 ts:0 [07-18 18:04:43:282 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:3999960 [07-18 18:04:43:282 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:105208 dataSize:280 [07-18 18:04:43:282 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:120 timestamp:1689674683282 [07-18 18:04:43:316 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:4033293 ts:0 [07-18 18:04:43:316 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:4033293 [07-18 18:04:43:316 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:105488 dataSize:12088 [07-18 18:04:43:316 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:121 timestamp:1689674683316 [07-18 18:04:43:316 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:4033293 ts:0 [07-18 18:04:43:316 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:4033293 [07-18 18:04:43:316 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:105488 dataSize:12088 [07-18 18:04:43:316 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:121 timestamp:1689674683316 [07-18 18:04:43:349 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:4066626 ts:0 [07-18 18:04:43:349 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:4066626 [07-18 18:04:43:349 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:117576 dataSize:1051 [07-18 18:04:43:349 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:122 timestamp:1689674683349 [07-18 18:04:43:349 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:4066626 ts:0 [07-18 18:04:43:349 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:4066626 [07-18 18:04:43:349 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:117576 dataSize:1051 [07-18 18:04:43:350 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:122 timestamp:1689674683349 [07-18 18:04:43:360 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:361 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 36, head index 122 [07-18 18:04:43:361 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 37, seqNo 37, timestamp 1689674680490 [07-18 18:04:43:361 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:383 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:4099959 ts:0 [07-18 18:04:43:383 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:4099959 [07-18 18:04:43:383 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:118627 dataSize:209 [07-18 18:04:43:383 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:123 timestamp:1689674683383 [07-18 18:04:43:383 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:4099959 ts:0 [07-18 18:04:43:383 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:4099959 [07-18 18:04:43:383 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:118627 dataSize:209 [07-18 18:04:43:383 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:123 timestamp:1689674683383 [07-18 18:04:43:417 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:4133292 ts:0 [07-18 18:04:43:417 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:4133292 [07-18 18:04:43:417 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:118836 dataSize:118 [07-18 18:04:43:417 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:124 timestamp:1689674683417 [07-18 18:04:43:417 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:4133292 ts:0 [07-18 18:04:43:417 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:4133292 [07-18 18:04:43:417 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:118836 dataSize:118 [07-18 18:04:43:417 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:124 timestamp:1689674683417 [07-18 18:04:43:450 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:4166625 ts:0 [07-18 18:04:43:450 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:4166625 [07-18 18:04:43:450 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:118954 dataSize:110 [07-18 18:04:43:450 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:125 timestamp:1689674683450 [07-18 18:04:43:450 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:4166625 ts:0 [07-18 18:04:43:451 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:4166625 [07-18 18:04:43:451 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:118954 dataSize:110 [07-18 18:04:43:451 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:125 timestamp:1689674683451 [07-18 18:04:43:471 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:471 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 37, head index 125 [07-18 18:04:43:471 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 38, seqNo 38, timestamp 1689674680523 [07-18 18:04:43:471 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:484 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:4199958 ts:0 [07-18 18:04:43:484 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:4199958 [07-18 18:04:43:484 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:119064 dataSize:695 [07-18 18:04:43:484 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:126 timestamp:1689674683484 [07-18 18:04:43:484 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:4199958 ts:0 [07-18 18:04:43:484 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:4199958 [07-18 18:04:43:484 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:119064 dataSize:695 [07-18 18:04:43:484 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:126 timestamp:1689674683484 [07-18 18:04:43:518 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:4233291 ts:0 [07-18 18:04:43:518 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:4233291 [07-18 18:04:43:518 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:119759 dataSize:1146 [07-18 18:04:43:518 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:127 timestamp:1689674683518 [07-18 18:04:43:518 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:4233291 ts:0 [07-18 18:04:43:518 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:4233291 [07-18 18:04:43:518 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:119759 dataSize:1146 [07-18 18:04:43:518 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:127 timestamp:1689674683518 [07-18 18:04:43:551 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:4266624 ts:0 [07-18 18:04:43:551 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:4266624 [07-18 18:04:43:551 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:120905 dataSize:276 [07-18 18:04:43:551 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:128 timestamp:1689674683551 [07-18 18:04:43:551 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:4266624 ts:0 [07-18 18:04:43:551 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:4266624 [07-18 18:04:43:551 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:120905 dataSize:276 [07-18 18:04:43:551 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:128 timestamp:1689674683551 [07-18 18:04:43:581 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:581 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 38, head index 128 [07-18 18:04:43:581 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 39, seqNo 39, timestamp 1689674680557 [07-18 18:04:43:582 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:585 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:4299957 ts:0 [07-18 18:04:43:585 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:4299957 [07-18 18:04:43:585 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:121181 dataSize:152 [07-18 18:04:43:585 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:129 timestamp:1689674683585 [07-18 18:04:43:585 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:4299957 ts:0 [07-18 18:04:43:585 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:4299957 [07-18 18:04:43:585 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:121181 dataSize:152 [07-18 18:04:43:585 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:129 timestamp:1689674683585 [07-18 18:04:43:618 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:4333290 ts:0 [07-18 18:04:43:619 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:4333290 [07-18 18:04:43:619 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:121333 dataSize:136 [07-18 18:04:43:619 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:130 timestamp:1689674683619 [07-18 18:04:43:619 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:4333290 ts:0 [07-18 18:04:43:619 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:4333290 [07-18 18:04:43:619 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:121333 dataSize:136 [07-18 18:04:43:619 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:130 timestamp:1689674683619 [07-18 18:04:43:652 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:4366623 ts:0 [07-18 18:04:43:652 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:4366623 [07-18 18:04:43:652 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:121469 dataSize:725 [07-18 18:04:43:652 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:131 timestamp:1689674683652 [07-18 18:04:43:652 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:4366623 ts:0 [07-18 18:04:43:653 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:4366623 [07-18 18:04:43:653 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:121469 dataSize:725 [07-18 18:04:43:653 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:131 timestamp:1689674683653 [07-18 18:04:43:686 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:4399956 ts:0 [07-18 18:04:43:686 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:4399956 [07-18 18:04:43:686 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:122194 dataSize:1369 [07-18 18:04:43:686 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:132 timestamp:1689674683686 [07-18 18:04:43:686 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:4399956 ts:0 [07-18 18:04:43:686 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:4399956 [07-18 18:04:43:686 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:122194 dataSize:1369 [07-18 18:04:43:686 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:132 timestamp:1689674683686 [07-18 18:04:43:692 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:692 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 39, head index 132 [07-18 18:04:43:692 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 40, seqNo 40, timestamp 1689674680590 [07-18 18:04:43:692 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:720 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:4433289 ts:0 [07-18 18:04:43:720 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:4433289 [07-18 18:04:43:720 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:123563 dataSize:367 [07-18 18:04:43:720 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:133 timestamp:1689674683720 [07-18 18:04:43:720 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:4433289 ts:0 [07-18 18:04:43:720 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:4433289 [07-18 18:04:43:720 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:123563 dataSize:367 [07-18 18:04:43:720 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:133 timestamp:1689674683720 [07-18 18:04:43:753 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:4466622 ts:0 [07-18 18:04:43:753 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:4466622 [07-18 18:04:43:753 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:123930 dataSize:141 [07-18 18:04:43:753 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:134 timestamp:1689674683753 [07-18 18:04:43:753 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:4466622 ts:0 [07-18 18:04:43:753 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:4466622 [07-18 18:04:43:753 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:123930 dataSize:141 [07-18 18:04:43:753 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:134 timestamp:1689674683753 [07-18 18:04:43:787 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:4499955 ts:0 [07-18 18:04:43:787 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:4499955 [07-18 18:04:43:787 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:124071 dataSize:160 [07-18 18:04:43:787 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:135 timestamp:1689674683787 [07-18 18:04:43:787 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:4499955 ts:0 [07-18 18:04:43:787 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:4499955 [07-18 18:04:43:787 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:124071 dataSize:160 [07-18 18:04:43:787 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:135 timestamp:1689674683787 [07-18 18:04:43:802 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:802 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 40, head index 135 [07-18 18:04:43:802 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 41, seqNo 41, timestamp 1689674680624 [07-18 18:04:43:802 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:821 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:4533288 ts:0 [07-18 18:04:43:821 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:4533288 [07-18 18:04:43:821 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:124231 dataSize:756 [07-18 18:04:43:821 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:136 timestamp:1689674683821 [07-18 18:04:43:821 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:4533288 ts:0 [07-18 18:04:43:821 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:4533288 [07-18 18:04:43:821 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:124231 dataSize:756 [07-18 18:04:43:821 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:136 timestamp:1689674683821 [07-18 18:04:43:844 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:43:844 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:43:854 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:4566621 ts:0 [07-18 18:04:43:854 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:4566621 [07-18 18:04:43:854 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:124987 dataSize:1610 [07-18 18:04:43:854 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:137 timestamp:1689674683854 [07-18 18:04:43:854 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:4566621 ts:0 [07-18 18:04:43:854 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:4566621 [07-18 18:04:43:854 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:124987 dataSize:1610 [07-18 18:04:43:854 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:137 timestamp:1689674683854 [07-18 18:04:43:888 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:4599954 ts:0 [07-18 18:04:43:888 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:4599954 [07-18 18:04:43:888 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:126597 dataSize:516 [07-18 18:04:43:888 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:138 timestamp:1689674683888 [07-18 18:04:43:888 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:4599954 ts:0 [07-18 18:04:43:888 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:4599954 [07-18 18:04:43:888 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:126597 dataSize:516 [07-18 18:04:43:888 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:138 timestamp:1689674683888 [07-18 18:04:43:912 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:43:913 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 41, head index 138 [07-18 18:04:43:913 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 42, seqNo 42, timestamp 1689674680658 [07-18 18:04:43:913 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:43:921 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:4633287 ts:0 [07-18 18:04:43:921 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:4633287 [07-18 18:04:43:921 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:127113 dataSize:231 [07-18 18:04:43:921 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:139 timestamp:1689674683921 [07-18 18:04:43:921 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:4633287 ts:0 [07-18 18:04:43:921 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:4633287 [07-18 18:04:43:922 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:127113 dataSize:231 [07-18 18:04:43:922 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:139 timestamp:1689674683922 [07-18 18:04:43:955 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:4666620 ts:0 [07-18 18:04:43:955 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:4666620 [07-18 18:04:43:955 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:127344 dataSize:250 [07-18 18:04:43:955 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:140 timestamp:1689674683955 [07-18 18:04:43:955 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:4666620 ts:0 [07-18 18:04:43:955 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:4666620 [07-18 18:04:43:955 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:127344 dataSize:250 [07-18 18:04:43:955 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:140 timestamp:1689674683955 [07-18 18:04:43:989 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:4699953 ts:0 [07-18 18:04:43:989 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:4699953 [07-18 18:04:43:989 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:127594 dataSize:1143 [07-18 18:04:43:989 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:141 timestamp:1689674683989 [07-18 18:04:43:989 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:4699953 ts:0 [07-18 18:04:43:989 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:4699953 [07-18 18:04:43:989 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:127594 dataSize:1143 [07-18 18:04:43:989 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:141 timestamp:1689674683989 [07-18 18:04:44:22 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:4733286 ts:0 [07-18 18:04:44:22 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:4733286 [07-18 18:04:44:22 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:128737 dataSize:383 [07-18 18:04:44:22 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:142 timestamp:1689674684022 [07-18 18:04:44:22 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:4733286 ts:0 [07-18 18:04:44:22 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:4733286 [07-18 18:04:44:22 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:128737 dataSize:383 [07-18 18:04:44:22 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:142 timestamp:1689674684022 [07-18 18:04:44:23 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:23 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 42, head index 142 [07-18 18:04:44:23 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 43, seqNo 43, timestamp 1689674680691 [07-18 18:04:44:23 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:56 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:4766619 ts:0 [07-18 18:04:44:56 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:4766619 [07-18 18:04:44:56 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:129120 dataSize:235 [07-18 18:04:44:56 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:143 timestamp:1689674684056 [07-18 18:04:44:56 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:4766619 ts:0 [07-18 18:04:44:56 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:4766619 [07-18 18:04:44:56 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:129120 dataSize:235 [07-18 18:04:44:56 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:143 timestamp:1689674684056 [07-18 18:04:44:89 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:4799952 ts:0 [07-18 18:04:44:89 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:4799952 [07-18 18:04:44:90 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:129355 dataSize:165 [07-18 18:04:44:90 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:144 timestamp:1689674684090 [07-18 18:04:44:90 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:4799952 ts:0 [07-18 18:04:44:90 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:4799952 [07-18 18:04:44:90 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:129355 dataSize:165 [07-18 18:04:44:90 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:144 timestamp:1689674684090 [07-18 18:04:44:123 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:4833285 ts:0 [07-18 18:04:44:123 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:4833285 [07-18 18:04:44:123 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:129520 dataSize:457 [07-18 18:04:44:123 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:145 timestamp:1689674684123 [07-18 18:04:44:123 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:4833285 ts:0 [07-18 18:04:44:123 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:4833285 [07-18 18:04:44:123 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:129520 dataSize:457 [07-18 18:04:44:123 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:145 timestamp:1689674684123 [07-18 18:04:44:133 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:133 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 43, head index 145 [07-18 18:04:44:133 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 44, seqNo 44, timestamp 1689674680725 [07-18 18:04:44:134 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:157 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:4866618 ts:0 [07-18 18:04:44:157 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:4866618 [07-18 18:04:44:157 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:129977 dataSize:673 [07-18 18:04:44:157 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:146 timestamp:1689674684157 [07-18 18:04:44:157 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:4866618 ts:0 [07-18 18:04:44:157 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:4866618 [07-18 18:04:44:157 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:129977 dataSize:673 [07-18 18:04:44:157 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:146 timestamp:1689674684157 [07-18 18:04:44:190 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:4899951 ts:0 [07-18 18:04:44:190 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:4899951 [07-18 18:04:44:190 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:130650 dataSize:465 [07-18 18:04:44:190 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:147 timestamp:1689674684190 [07-18 18:04:44:190 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:4899951 ts:0 [07-18 18:04:44:190 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:4899951 [07-18 18:04:44:190 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:130650 dataSize:465 [07-18 18:04:44:190 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:147 timestamp:1689674684190 [07-18 18:04:44:228 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:4933284 ts:0 [07-18 18:04:44:228 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:4933284 [07-18 18:04:44:228 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:131115 dataSize:248 [07-18 18:04:44:228 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:148 timestamp:1689674684228 [07-18 18:04:44:228 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:4933284 ts:0 [07-18 18:04:44:229 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:4933284 [07-18 18:04:44:229 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:131115 dataSize:248 [07-18 18:04:44:229 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:148 timestamp:1689674684229 [07-18 18:04:44:244 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:244 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 44, head index 148 [07-18 18:04:44:244 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 45, seqNo 45, timestamp 1689674680758 [07-18 18:04:44:244 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:262 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:4966617 ts:0 [07-18 18:04:44:262 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:4966617 [07-18 18:04:44:262 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:131363 dataSize:217 [07-18 18:04:44:262 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:149 timestamp:1689674684262 [07-18 18:04:44:262 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:4966617 ts:0 [07-18 18:04:44:262 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:4966617 [07-18 18:04:44:262 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:131363 dataSize:217 [07-18 18:04:44:262 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:149 timestamp:1689674684262 [07-18 18:04:44:296 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:4999950 ts:0 [07-18 18:04:44:296 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:4999950 [07-18 18:04:44:296 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:131580 dataSize:280 [07-18 18:04:44:296 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:150 timestamp:1689674684296 [07-18 18:04:44:296 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:4999950 ts:0 [07-18 18:04:44:296 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:4999950 [07-18 18:04:44:296 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:131580 dataSize:280 [07-18 18:04:44:296 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:150 timestamp:1689674684296 [07-18 18:04:44:329 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:5033283 ts:0 [07-18 18:04:44:330 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:5033283 [07-18 18:04:44:330 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:131860 dataSize:12088 [07-18 18:04:44:330 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:151 timestamp:1689674684330 [07-18 18:04:44:330 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:5033283 ts:0 [07-18 18:04:44:330 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:5033283 [07-18 18:04:44:330 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:131860 dataSize:12088 [07-18 18:04:44:330 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:151 timestamp:1689674684330 [07-18 18:04:44:354 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:354 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 45, head index 151 [07-18 18:04:44:354 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 46, seqNo 46, timestamp 1689674680792 [07-18 18:04:44:354 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:363 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:5066616 ts:0 [07-18 18:04:44:363 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:5066616 [07-18 18:04:44:363 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:143948 dataSize:1051 [07-18 18:04:44:363 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:152 timestamp:1689674684363 [07-18 18:04:44:363 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:5066616 ts:0 [07-18 18:04:44:363 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:5066616 [07-18 18:04:44:363 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:143948 dataSize:1051 [07-18 18:04:44:363 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:152 timestamp:1689674684363 [07-18 18:04:44:397 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:5099949 ts:0 [07-18 18:04:44:397 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:5099949 [07-18 18:04:44:397 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:144999 dataSize:209 [07-18 18:04:44:397 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:153 timestamp:1689674684397 [07-18 18:04:44:397 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:5099949 ts:0 [07-18 18:04:44:397 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:5099949 [07-18 18:04:44:397 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:144999 dataSize:209 [07-18 18:04:44:397 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:153 timestamp:1689674684397 [07-18 18:04:44:430 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:5133282 ts:0 [07-18 18:04:44:430 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:5133282 [07-18 18:04:44:430 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:145208 dataSize:118 [07-18 18:04:44:430 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:154 timestamp:1689674684430 [07-18 18:04:44:430 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:5133282 ts:0 [07-18 18:04:44:430 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:5133282 [07-18 18:04:44:430 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:145208 dataSize:118 [07-18 18:04:44:430 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:154 timestamp:1689674684430 [07-18 18:04:44:464 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:5166615 ts:0 [07-18 18:04:44:464 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:5166615 [07-18 18:04:44:464 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:145326 dataSize:110 [07-18 18:04:44:464 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:155 timestamp:1689674684464 [07-18 18:04:44:464 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:5166615 ts:0 [07-18 18:04:44:464 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:5166615 [07-18 18:04:44:464 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:145326 dataSize:110 [07-18 18:04:44:464 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:155 timestamp:1689674684464 [07-18 18:04:44:465 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:465 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 46, head index 155 [07-18 18:04:44:465 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 47, seqNo 47, timestamp 1689674680826 [07-18 18:04:44:465 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:498 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:5199948 ts:0 [07-18 18:04:44:498 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:5199948 [07-18 18:04:44:498 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:145436 dataSize:695 [07-18 18:04:44:498 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:156 timestamp:1689674684498 [07-18 18:04:44:498 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:5199948 ts:0 [07-18 18:04:44:498 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:5199948 [07-18 18:04:44:498 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:145436 dataSize:695 [07-18 18:04:44:498 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:156 timestamp:1689674684498 [07-18 18:04:44:531 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:5233281 ts:0 [07-18 18:04:44:531 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:5233281 [07-18 18:04:44:531 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:146131 dataSize:1146 [07-18 18:04:44:531 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:157 timestamp:1689674684531 [07-18 18:04:44:531 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:5233281 ts:0 [07-18 18:04:44:531 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:5233281 [07-18 18:04:44:531 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:146131 dataSize:1146 [07-18 18:04:44:531 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:157 timestamp:1689674684531 [07-18 18:04:44:565 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:5266614 ts:0 [07-18 18:04:44:565 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:5266614 [07-18 18:04:44:565 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:147277 dataSize:276 [07-18 18:04:44:565 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:158 timestamp:1689674684565 [07-18 18:04:44:565 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:5266614 ts:0 [07-18 18:04:44:565 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:5266614 [07-18 18:04:44:565 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:147277 dataSize:276 [07-18 18:04:44:565 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:158 timestamp:1689674684565 [07-18 18:04:44:575 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:575 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 47, head index 158 [07-18 18:04:44:575 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 48, seqNo 48, timestamp 1689674680859 [07-18 18:04:44:575 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:598 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:5299947 ts:0 [07-18 18:04:44:598 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:5299947 [07-18 18:04:44:598 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:147553 dataSize:152 [07-18 18:04:44:598 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:159 timestamp:1689674684598 [07-18 18:04:44:598 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:5299947 ts:0 [07-18 18:04:44:598 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:5299947 [07-18 18:04:44:598 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:147553 dataSize:152 [07-18 18:04:44:598 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:159 timestamp:1689674684598 [07-18 18:04:44:632 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:5333280 ts:0 [07-18 18:04:44:632 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:5333280 [07-18 18:04:44:632 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:147705 dataSize:136 [07-18 18:04:44:632 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:160 timestamp:1689674684632 [07-18 18:04:44:632 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:5333280 ts:0 [07-18 18:04:44:632 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:5333280 [07-18 18:04:44:632 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:147705 dataSize:136 [07-18 18:04:44:632 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:160 timestamp:1689674684632 [07-18 18:04:44:665 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:5366613 ts:0 [07-18 18:04:44:666 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:5366613 [07-18 18:04:44:666 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:147841 dataSize:725 [07-18 18:04:44:666 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:161 timestamp:1689674684666 [07-18 18:04:44:666 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:5366613 ts:0 [07-18 18:04:44:666 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:5366613 [07-18 18:04:44:666 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:147841 dataSize:725 [07-18 18:04:44:666 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:161 timestamp:1689674684666 [07-18 18:04:44:685 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:685 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 48, head index 161 [07-18 18:04:44:685 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 49, seqNo 49, timestamp 1689674680893 [07-18 18:04:44:685 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:699 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:5399946 ts:0 [07-18 18:04:44:699 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:5399946 [07-18 18:04:44:699 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:148566 dataSize:1369 [07-18 18:04:44:699 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:162 timestamp:1689674684699 [07-18 18:04:44:699 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:5399946 ts:0 [07-18 18:04:44:699 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:5399946 [07-18 18:04:44:699 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:148566 dataSize:1369 [07-18 18:04:44:699 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:162 timestamp:1689674684699 [07-18 18:04:44:733 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:5433279 ts:0 [07-18 18:04:44:733 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:5433279 [07-18 18:04:44:733 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:149935 dataSize:367 [07-18 18:04:44:733 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:163 timestamp:1689674684733 [07-18 18:04:44:733 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:5433279 ts:0 [07-18 18:04:44:733 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:5433279 [07-18 18:04:44:733 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:149935 dataSize:367 [07-18 18:04:44:733 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:163 timestamp:1689674684733 [07-18 18:04:44:766 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:5466612 ts:0 [07-18 18:04:44:766 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:5466612 [07-18 18:04:44:767 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:150302 dataSize:141 [07-18 18:04:44:767 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:164 timestamp:1689674684767 [07-18 18:04:44:767 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:5466612 ts:0 [07-18 18:04:44:767 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:5466612 [07-18 18:04:44:767 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:150302 dataSize:141 [07-18 18:04:44:767 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:164 timestamp:1689674684767 [07-18 18:04:44:796 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:796 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 49, head index 164 [07-18 18:04:44:796 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 50, seqNo 50, timestamp 1689674680926 [07-18 18:04:44:796 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:800 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:5499945 ts:0 [07-18 18:04:44:800 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:5499945 [07-18 18:04:44:800 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:150443 dataSize:160 [07-18 18:04:44:800 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:165 timestamp:1689674684800 [07-18 18:04:44:800 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:5499945 ts:0 [07-18 18:04:44:800 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:5499945 [07-18 18:04:44:800 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:150443 dataSize:160 [07-18 18:04:44:800 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:165 timestamp:1689674684800 [07-18 18:04:44:834 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:5533278 ts:0 [07-18 18:04:44:834 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:5533278 [07-18 18:04:44:834 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:150603 dataSize:756 [07-18 18:04:44:834 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:166 timestamp:1689674684834 [07-18 18:04:44:834 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:5533278 ts:0 [07-18 18:04:44:834 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:5533278 [07-18 18:04:44:834 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:150603 dataSize:756 [07-18 18:04:44:834 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:166 timestamp:1689674684834 [07-18 18:04:44:845 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:44:845 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:44:867 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:5566611 ts:0 [07-18 18:04:44:869 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:5566611 [07-18 18:04:44:869 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:151359 dataSize:1610 [07-18 18:04:44:869 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:167 timestamp:1689674684869 [07-18 18:04:44:869 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:5566611 ts:0 [07-18 18:04:44:869 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:5566611 [07-18 18:04:44:869 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:151359 dataSize:1610 [07-18 18:04:44:869 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:167 timestamp:1689674684869 [07-18 18:04:44:902 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:5599944 ts:0 [07-18 18:04:44:903 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:5599944 [07-18 18:04:44:903 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:152969 dataSize:516 [07-18 18:04:44:903 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:168 timestamp:1689674684903 [07-18 18:04:44:903 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:5599944 ts:0 [07-18 18:04:44:903 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:5599944 [07-18 18:04:44:903 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:152969 dataSize:516 [07-18 18:04:44:903 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:168 timestamp:1689674684903 [07-18 18:04:44:906 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:44:906 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 50, head index 168 [07-18 18:04:44:906 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 51, seqNo 51, timestamp 1689674680960 [07-18 18:04:44:906 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:44:936 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:5633277 ts:0 [07-18 18:04:44:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:5633277 [07-18 18:04:44:936 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:153485 dataSize:231 [07-18 18:04:44:936 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:169 timestamp:1689674684936 [07-18 18:04:44:936 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:5633277 ts:0 [07-18 18:04:44:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:5633277 [07-18 18:04:44:936 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:153485 dataSize:231 [07-18 18:04:44:936 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:169 timestamp:1689674684936 [07-18 18:04:44:970 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:5666610 ts:0 [07-18 18:04:44:970 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:5666610 [07-18 18:04:44:970 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:153716 dataSize:250 [07-18 18:04:44:970 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:170 timestamp:1689674684970 [07-18 18:04:44:970 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:5666610 ts:0 [07-18 18:04:44:970 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:5666610 [07-18 18:04:44:970 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:153716 dataSize:250 [07-18 18:04:44:970 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:170 timestamp:1689674684970 [07-18 18:04:45:3 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:5699943 ts:0 [07-18 18:04:45:3 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:5699943 [07-18 18:04:45:4 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:153966 dataSize:1143 [07-18 18:04:45:4 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:171 timestamp:1689674685004 [07-18 18:04:45:4 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:5699943 ts:0 [07-18 18:04:45:4 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:5699943 [07-18 18:04:45:4 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:153966 dataSize:1143 [07-18 18:04:45:4 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:171 timestamp:1689674685004 [07-18 18:04:45:17 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:17 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 51, head index 171 [07-18 18:04:45:17 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 52, seqNo 52, timestamp 1689674680994 [07-18 18:04:45:17 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:5733276 ts:0 [07-18 18:04:45:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:5733276 [07-18 18:04:45:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:155109 dataSize:383 [07-18 18:04:45:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:172 timestamp:1689674685037 [07-18 18:04:45:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:5733276 ts:0 [07-18 18:04:45:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:5733276 [07-18 18:04:45:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:155109 dataSize:383 [07-18 18:04:45:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:172 timestamp:1689674685037 [07-18 18:04:45:71 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:5766609 ts:0 [07-18 18:04:45:71 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:5766609 [07-18 18:04:45:71 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:155492 dataSize:235 [07-18 18:04:45:71 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:173 timestamp:1689674685071 [07-18 18:04:45:71 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:5766609 ts:0 [07-18 18:04:45:71 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:5766609 [07-18 18:04:45:71 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:155492 dataSize:235 [07-18 18:04:45:71 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:173 timestamp:1689674685071 [07-18 18:04:45:104 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:5799942 ts:0 [07-18 18:04:45:104 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:5799942 [07-18 18:04:45:104 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:155727 dataSize:165 [07-18 18:04:45:104 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:174 timestamp:1689674685104 [07-18 18:04:45:104 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:5799942 ts:0 [07-18 18:04:45:104 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:5799942 [07-18 18:04:45:104 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:155727 dataSize:165 [07-18 18:04:45:104 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:174 timestamp:1689674685104 [07-18 18:04:45:127 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:127 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 52, head index 174 [07-18 18:04:45:127 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 53, seqNo 53, timestamp 1689674681027 [07-18 18:04:45:127 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:138 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:5833275 ts:0 [07-18 18:04:45:138 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:5833275 [07-18 18:04:45:138 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:155892 dataSize:457 [07-18 18:04:45:138 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:175 timestamp:1689674685138 [07-18 18:04:45:138 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:5833275 ts:0 [07-18 18:04:45:138 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:5833275 [07-18 18:04:45:138 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:155892 dataSize:457 [07-18 18:04:45:138 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:175 timestamp:1689674685138 [07-18 18:04:45:171 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:5866608 ts:0 [07-18 18:04:45:172 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:5866608 [07-18 18:04:45:172 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:156349 dataSize:673 [07-18 18:04:45:172 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:176 timestamp:1689674685172 [07-18 18:04:45:172 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:5866608 ts:0 [07-18 18:04:45:172 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:5866608 [07-18 18:04:45:172 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:156349 dataSize:673 [07-18 18:04:45:172 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:176 timestamp:1689674685172 [07-18 18:04:45:205 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:5899941 ts:0 [07-18 18:04:45:205 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:5899941 [07-18 18:04:45:205 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:157022 dataSize:465 [07-18 18:04:45:205 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:177 timestamp:1689674685205 [07-18 18:04:45:205 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:5899941 ts:0 [07-18 18:04:45:205 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:5899941 [07-18 18:04:45:205 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:157022 dataSize:465 [07-18 18:04:45:205 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:177 timestamp:1689674685205 [07-18 18:04:45:238 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:238 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 53, head index 177 [07-18 18:04:45:238 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 54, seqNo 54, timestamp 1689674681061 [07-18 18:04:45:238 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:239 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:5933274 ts:0 [07-18 18:04:45:239 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:5933274 [07-18 18:04:45:239 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:157487 dataSize:248 [07-18 18:04:45:239 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:178 timestamp:1689674685239 [07-18 18:04:45:239 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:5933274 ts:0 [07-18 18:04:45:239 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:5933274 [07-18 18:04:45:239 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:157487 dataSize:248 [07-18 18:04:45:239 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:178 timestamp:1689674685239 [07-18 18:04:45:272 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:5966607 ts:0 [07-18 18:04:45:272 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:5966607 [07-18 18:04:45:272 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:157735 dataSize:217 [07-18 18:04:45:272 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:179 timestamp:1689674685272 [07-18 18:04:45:272 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:5966607 ts:0 [07-18 18:04:45:272 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:5966607 [07-18 18:04:45:273 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:157735 dataSize:217 [07-18 18:04:45:273 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:179 timestamp:1689674685273 [07-18 18:04:45:306 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:5999940 ts:0 [07-18 18:04:45:306 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:5999940 [07-18 18:04:45:306 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:157952 dataSize:280 [07-18 18:04:45:306 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:180 timestamp:1689674685306 [07-18 18:04:45:306 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:5999940 ts:0 [07-18 18:04:45:306 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:5999940 [07-18 18:04:45:306 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:157952 dataSize:280 [07-18 18:04:45:306 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:180 timestamp:1689674685306 [07-18 18:04:45:340 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:6033273 ts:0 [07-18 18:04:45:340 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:6033273 [07-18 18:04:45:340 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:158232 dataSize:12088 [07-18 18:04:45:340 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:181 timestamp:1689674685340 [07-18 18:04:45:340 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:6033273 ts:0 [07-18 18:04:45:340 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:6033273 [07-18 18:04:45:340 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:158232 dataSize:12088 [07-18 18:04:45:340 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:181 timestamp:1689674685340 [07-18 18:04:45:348 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:348 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 54, head index 181 [07-18 18:04:45:348 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 55, seqNo 55, timestamp 1689674681095 [07-18 18:04:45:348 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:373 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:6066606 ts:0 [07-18 18:04:45:373 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:6066606 [07-18 18:04:45:373 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:170320 dataSize:1051 [07-18 18:04:45:373 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:182 timestamp:1689674685373 [07-18 18:04:45:373 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:6066606 ts:0 [07-18 18:04:45:373 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:6066606 [07-18 18:04:45:373 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:170320 dataSize:1051 [07-18 18:04:45:373 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:182 timestamp:1689674685373 [07-18 18:04:45:407 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:6099939 ts:0 [07-18 18:04:45:407 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:6099939 [07-18 18:04:45:407 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:171371 dataSize:209 [07-18 18:04:45:407 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:183 timestamp:1689674685407 [07-18 18:04:45:407 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:6099939 ts:0 [07-18 18:04:45:407 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:6099939 [07-18 18:04:45:407 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:171371 dataSize:209 [07-18 18:04:45:407 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:183 timestamp:1689674685407 [07-18 18:04:45:441 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:6133272 ts:0 [07-18 18:04:45:441 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:6133272 [07-18 18:04:45:441 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:171580 dataSize:118 [07-18 18:04:45:441 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:184 timestamp:1689674685441 [07-18 18:04:45:441 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:6133272 ts:0 [07-18 18:04:45:441 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:6133272 [07-18 18:04:45:441 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:171580 dataSize:118 [07-18 18:04:45:441 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:184 timestamp:1689674685441 [07-18 18:04:45:458 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:458 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 55, head index 184 [07-18 18:04:45:458 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 56, seqNo 56, timestamp 1689674681128 [07-18 18:04:45:458 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:474 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:6166605 ts:0 [07-18 18:04:45:474 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:6166605 [07-18 18:04:45:474 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:171698 dataSize:110 [07-18 18:04:45:474 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:185 timestamp:1689674685474 [07-18 18:04:45:474 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:6166605 ts:0 [07-18 18:04:45:474 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:6166605 [07-18 18:04:45:474 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:171698 dataSize:110 [07-18 18:04:45:474 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:185 timestamp:1689674685474 [07-18 18:04:45:508 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:6199938 ts:0 [07-18 18:04:45:508 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:6199938 [07-18 18:04:45:508 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:171808 dataSize:695 [07-18 18:04:45:508 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:186 timestamp:1689674685508 [07-18 18:04:45:508 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:6199938 ts:0 [07-18 18:04:45:508 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:6199938 [07-18 18:04:45:508 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:171808 dataSize:695 [07-18 18:04:45:508 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:186 timestamp:1689674685508 [07-18 18:04:45:529 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:04:45:529 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:04:45:529 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:04:45:529 TUYA Debug][smart_frame.c:353] dp<8> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:04:45:529 TUYA Debug][smart_frame.c:369] dp_cntl value:83, dp_data value:82 [07-18 18:04:45:530 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:04:45:530 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"8":82} [07-18 18:04:45:541 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:6233271 ts:0 [07-18 18:04:45:542 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:6233271 [07-18 18:04:45:542 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:172503 dataSize:1146 [07-18 18:04:45:542 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:187 timestamp:1689674685542 [07-18 18:04:45:542 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:6233271 ts:0 [07-18 18:04:45:542 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:6233271 [07-18 18:04:45:542 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:172503 dataSize:1146 [07-18 18:04:45:542 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:187 timestamp:1689674685542 [07-18 18:04:45:552 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58368 Q:1 Data:{"dps":{"8":82}} [07-18 18:04:45:552 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:45:569 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:569 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 56, head index 187 [07-18 18:04:45:569 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 57, seqNo 57, timestamp 1689674681162 [07-18 18:04:45:569 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:574 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:45:574 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:45:574 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:45:574 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 18:04:45:574 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"8":82}}, mqtt async dp cb:0 [07-18 18:04:45:574 TUYA Trace][smart_frame.c:2512] DP ID 8 Set To 3 [07-18 18:04:45:574 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:8, curr_t:1689674685, rept_cnt:1. [07-18 18:04:45:574 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:8, curr_t:1689674685, rept_cnt:0. [07-18 18:04:45:574 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:8, curr_t:1689674685, rept_cnt:0. [07-18 18:04:45:580 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:6266604 ts:0 [07-18 18:04:45:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:6266604 [07-18 18:04:45:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:173649 dataSize:276 [07-18 18:04:45:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:188 timestamp:1689674685581 [07-18 18:04:45:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:6266604 ts:0 [07-18 18:04:45:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:6266604 [07-18 18:04:45:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:173649 dataSize:276 [07-18 18:04:45:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:188 timestamp:1689674685581 [07-18 18:04:45:596 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:45:614 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:6299937 ts:0 [07-18 18:04:45:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:6299937 [07-18 18:04:45:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:173925 dataSize:152 [07-18 18:04:45:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:189 timestamp:1689674685615 [07-18 18:04:45:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:6299937 ts:0 [07-18 18:04:45:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:6299937 [07-18 18:04:45:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:173925 dataSize:152 [07-18 18:04:45:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:189 timestamp:1689674685615 [07-18 18:04:45:648 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:6333270 ts:0 [07-18 18:04:45:648 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:6333270 [07-18 18:04:45:648 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:174077 dataSize:136 [07-18 18:04:45:648 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:190 timestamp:1689674685648 [07-18 18:04:45:648 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:6333270 ts:0 [07-18 18:04:45:648 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:6333270 [07-18 18:04:45:648 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:174077 dataSize:136 [07-18 18:04:45:648 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:190 timestamp:1689674685648 [07-18 18:04:45:679 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:679 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 57, head index 190 [07-18 18:04:45:679 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 58, seqNo 58, timestamp 1689674681195 [07-18 18:04:45:679 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:6366603 ts:0 [07-18 18:04:45:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:6366603 [07-18 18:04:45:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:174213 dataSize:725 [07-18 18:04:45:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:191 timestamp:1689674685682 [07-18 18:04:45:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:6366603 ts:0 [07-18 18:04:45:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:6366603 [07-18 18:04:45:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:174213 dataSize:725 [07-18 18:04:45:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:191 timestamp:1689674685682 [07-18 18:04:45:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:6399936 ts:0 [07-18 18:04:45:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:6399936 [07-18 18:04:45:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:174938 dataSize:1369 [07-18 18:04:45:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:192 timestamp:1689674685716 [07-18 18:04:45:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:6399936 ts:0 [07-18 18:04:45:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:6399936 [07-18 18:04:45:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:174938 dataSize:1369 [07-18 18:04:45:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:192 timestamp:1689674685716 [07-18 18:04:45:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:6433269 ts:0 [07-18 18:04:45:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:6433269 [07-18 18:04:45:749 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:176307 dataSize:367 [07-18 18:04:45:749 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:193 timestamp:1689674685749 [07-18 18:04:45:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:6433269 ts:0 [07-18 18:04:45:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:6433269 [07-18 18:04:45:749 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:176307 dataSize:367 [07-18 18:04:45:749 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:193 timestamp:1689674685749 [07-18 18:04:45:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:6466602 ts:0 [07-18 18:04:45:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:6466602 [07-18 18:04:45:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:176674 dataSize:141 [07-18 18:04:45:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:194 timestamp:1689674685783 [07-18 18:04:45:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:6466602 ts:0 [07-18 18:04:45:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:6466602 [07-18 18:04:45:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:176674 dataSize:141 [07-18 18:04:45:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:194 timestamp:1689674685783 [07-18 18:04:45:790 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:790 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 58, head index 194 [07-18 18:04:45:790 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 59, seqNo 59, timestamp 1689674681229 [07-18 18:04:45:790 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:816 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:6499935 ts:0 [07-18 18:04:45:816 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:6499935 [07-18 18:04:45:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:176815 dataSize:160 [07-18 18:04:45:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:195 timestamp:1689674685817 [07-18 18:04:45:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:6499935 ts:0 [07-18 18:04:45:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:6499935 [07-18 18:04:45:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:176815 dataSize:160 [07-18 18:04:45:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:195 timestamp:1689674685817 [07-18 18:04:45:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:6533268 ts:0 [07-18 18:04:45:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:6533268 [07-18 18:04:45:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:176975 dataSize:756 [07-18 18:04:45:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:196 timestamp:1689674685850 [07-18 18:04:45:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:6533268 ts:0 [07-18 18:04:45:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:6533268 [07-18 18:04:45:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:176975 dataSize:756 [07-18 18:04:45:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:196 timestamp:1689674685850 [07-18 18:04:45:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:6566601 ts:0 [07-18 18:04:45:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:6566601 [07-18 18:04:45:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:177731 dataSize:1610 [07-18 18:04:45:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:197 timestamp:1689674685884 [07-18 18:04:45:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:6566601 ts:0 [07-18 18:04:45:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:6566601 [07-18 18:04:45:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:177731 dataSize:1610 [07-18 18:04:45:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:197 timestamp:1689674685884 [07-18 18:04:45:900 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:45:900 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 59, head index 197 [07-18 18:04:45:900 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 60, seqNo 60, timestamp 1689674681263 [07-18 18:04:45:900 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:45:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:6599934 ts:0 [07-18 18:04:45:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:6599934 [07-18 18:04:45:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:179341 dataSize:516 [07-18 18:04:45:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:198 timestamp:1689674685918 [07-18 18:04:45:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:6599934 ts:0 [07-18 18:04:45:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:6599934 [07-18 18:04:45:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:179341 dataSize:516 [07-18 18:04:45:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:198 timestamp:1689674685918 [07-18 18:04:45:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:6633267 ts:0 [07-18 18:04:45:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:6633267 [07-18 18:04:45:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:179857 dataSize:231 [07-18 18:04:45:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:199 timestamp:1689674685951 [07-18 18:04:45:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:6633267 ts:0 [07-18 18:04:45:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:6633267 [07-18 18:04:45:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:179857 dataSize:231 [07-18 18:04:45:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:199 timestamp:1689674685951 [07-18 18:04:45:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:6666600 ts:0 [07-18 18:04:45:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:6666600 [07-18 18:04:45:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:180088 dataSize:250 [07-18 18:04:45:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:200 timestamp:1689674685985 [07-18 18:04:45:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:6666600 ts:0 [07-18 18:04:45:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:6666600 [07-18 18:04:45:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:180088 dataSize:250 [07-18 18:04:45:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:200 timestamp:1689674685985 [07-18 18:04:46:10 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:10 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 60, head index 200 [07-18 18:04:46:10 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 61, seqNo 61, timestamp 1689674681296 [07-18 18:04:46:11 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:18 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:6699933 ts:0 [07-18 18:04:46:19 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:6699933 [07-18 18:04:46:19 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:180338 dataSize:1143 [07-18 18:04:46:19 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:201 timestamp:1689674686019 [07-18 18:04:46:19 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:6699933 ts:0 [07-18 18:04:46:19 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:6699933 [07-18 18:04:46:19 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:180338 dataSize:1143 [07-18 18:04:46:19 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:201 timestamp:1689674686019 [07-18 18:04:46:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:6733266 ts:0 [07-18 18:04:46:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:6733266 [07-18 18:04:46:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:181481 dataSize:383 [07-18 18:04:46:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:202 timestamp:1689674686052 [07-18 18:04:46:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:6733266 ts:0 [07-18 18:04:46:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:6733266 [07-18 18:04:46:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:181481 dataSize:383 [07-18 18:04:46:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:202 timestamp:1689674686052 [07-18 18:04:46:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:6766599 ts:0 [07-18 18:04:46:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:6766599 [07-18 18:04:46:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:181864 dataSize:235 [07-18 18:04:46:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:203 timestamp:1689674686086 [07-18 18:04:46:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:6766599 ts:0 [07-18 18:04:46:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:6766599 [07-18 18:04:46:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:181864 dataSize:235 [07-18 18:04:46:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:203 timestamp:1689674686086 [07-18 18:04:46:123 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:124 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 61, head index 203 [07-18 18:04:46:124 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 62, seqNo 62, timestamp 1689674681330 [07-18 18:04:46:124 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:6799932 ts:0 [07-18 18:04:46:124 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:6799932 [07-18 18:04:46:124 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:182099 dataSize:165 [07-18 18:04:46:124 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:204 timestamp:1689674686124 [07-18 18:04:46:124 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:6799932 ts:0 [07-18 18:04:46:124 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:6799932 [07-18 18:04:46:124 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:182099 dataSize:165 [07-18 18:04:46:124 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:124 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:204 timestamp:1689674686124 [07-18 18:04:46:158 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:6833265 ts:0 [07-18 18:04:46:158 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:6833265 [07-18 18:04:46:158 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:182264 dataSize:457 [07-18 18:04:46:158 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:205 timestamp:1689674686158 [07-18 18:04:46:158 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:6833265 ts:0 [07-18 18:04:46:158 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:6833265 [07-18 18:04:46:158 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:182264 dataSize:457 [07-18 18:04:46:158 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:205 timestamp:1689674686158 [07-18 18:04:46:191 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:6866598 ts:0 [07-18 18:04:46:191 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:6866598 [07-18 18:04:46:191 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:182721 dataSize:673 [07-18 18:04:46:191 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:206 timestamp:1689674686191 [07-18 18:04:46:191 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:6866598 ts:0 [07-18 18:04:46:191 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:6866598 [07-18 18:04:46:191 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:182721 dataSize:673 [07-18 18:04:46:192 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:206 timestamp:1689674686192 [07-18 18:04:46:225 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:6899931 ts:0 [07-18 18:04:46:225 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:6899931 [07-18 18:04:46:225 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:183394 dataSize:465 [07-18 18:04:46:225 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:207 timestamp:1689674686225 [07-18 18:04:46:225 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:6899931 ts:0 [07-18 18:04:46:225 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:6899931 [07-18 18:04:46:225 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:183394 dataSize:465 [07-18 18:04:46:225 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:207 timestamp:1689674686225 [07-18 18:04:46:234 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:235 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 62, head index 207 [07-18 18:04:46:235 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 63, seqNo 63, timestamp 1689674681364 [07-18 18:04:46:235 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:259 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:6933264 ts:0 [07-18 18:04:46:259 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:6933264 [07-18 18:04:46:259 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:183859 dataSize:248 [07-18 18:04:46:259 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:208 timestamp:1689674686259 [07-18 18:04:46:259 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:6933264 ts:0 [07-18 18:04:46:259 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:6933264 [07-18 18:04:46:259 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:183859 dataSize:248 [07-18 18:04:46:259 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:208 timestamp:1689674686259 [07-18 18:04:46:292 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:6966597 ts:0 [07-18 18:04:46:292 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:6966597 [07-18 18:04:46:292 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:184107 dataSize:217 [07-18 18:04:46:292 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:209 timestamp:1689674686292 [07-18 18:04:46:292 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:6966597 ts:0 [07-18 18:04:46:292 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:6966597 [07-18 18:04:46:292 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:184107 dataSize:217 [07-18 18:04:46:292 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:209 timestamp:1689674686292 [07-18 18:04:46:326 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:6999930 ts:0 [07-18 18:04:46:326 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:6999930 [07-18 18:04:46:326 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:184324 dataSize:280 [07-18 18:04:46:326 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:210 timestamp:1689674686326 [07-18 18:04:46:326 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:6999930 ts:0 [07-18 18:04:46:326 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:6999930 [07-18 18:04:46:326 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:184324 dataSize:280 [07-18 18:04:46:326 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:210 timestamp:1689674686326 [07-18 18:04:46:345 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:345 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 63, head index 210 [07-18 18:04:46:345 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 64, seqNo 64, timestamp 1689674681397 [07-18 18:04:46:345 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:360 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:7033263 ts:0 [07-18 18:04:46:360 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:7033263 [07-18 18:04:46:360 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:184604 dataSize:12088 [07-18 18:04:46:360 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:211 timestamp:1689674686360 [07-18 18:04:46:360 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:7033263 ts:0 [07-18 18:04:46:360 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:7033263 [07-18 18:04:46:360 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:184604 dataSize:12088 [07-18 18:04:46:360 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:211 timestamp:1689674686360 [07-18 18:04:46:393 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:7066596 ts:0 [07-18 18:04:46:393 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:7066596 [07-18 18:04:46:393 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:196692 dataSize:1051 [07-18 18:04:46:393 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:212 timestamp:1689674686393 [07-18 18:04:46:393 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:7066596 ts:0 [07-18 18:04:46:393 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:7066596 [07-18 18:04:46:393 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:196692 dataSize:1051 [07-18 18:04:46:393 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:212 timestamp:1689674686393 [07-18 18:04:46:427 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:7099929 ts:0 [07-18 18:04:46:427 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:7099929 [07-18 18:04:46:427 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:197743 dataSize:209 [07-18 18:04:46:427 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:213 timestamp:1689674686427 [07-18 18:04:46:427 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:7099929 ts:0 [07-18 18:04:46:427 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:7099929 [07-18 18:04:46:427 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:197743 dataSize:209 [07-18 18:04:46:427 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:213 timestamp:1689674686427 [07-18 18:04:46:455 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:455 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 64, head index 213 [07-18 18:04:46:455 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 65, seqNo 65, timestamp 1689674681431 [07-18 18:04:46:456 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:461 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:7133262 ts:0 [07-18 18:04:46:461 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:7133262 [07-18 18:04:46:461 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:197952 dataSize:118 [07-18 18:04:46:461 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:214 timestamp:1689674686461 [07-18 18:04:46:461 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:7133262 ts:0 [07-18 18:04:46:461 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:7133262 [07-18 18:04:46:461 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:197952 dataSize:118 [07-18 18:04:46:461 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:214 timestamp:1689674686461 [07-18 18:04:46:494 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:7166595 ts:0 [07-18 18:04:46:494 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:7166595 [07-18 18:04:46:494 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:198070 dataSize:110 [07-18 18:04:46:494 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:215 timestamp:1689674686494 [07-18 18:04:46:494 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:7166595 ts:0 [07-18 18:04:46:494 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:7166595 [07-18 18:04:46:494 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:198070 dataSize:110 [07-18 18:04:46:494 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:215 timestamp:1689674686494 [07-18 18:04:46:528 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:7199928 ts:0 [07-18 18:04:46:528 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:7199928 [07-18 18:04:46:528 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:198180 dataSize:695 [07-18 18:04:46:528 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:216 timestamp:1689674686528 [07-18 18:04:46:528 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:7199928 ts:0 [07-18 18:04:46:528 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:7199928 [07-18 18:04:46:528 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:198180 dataSize:695 [07-18 18:04:46:528 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:216 timestamp:1689674686528 [07-18 18:04:46:561 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:7233261 ts:0 [07-18 18:04:46:562 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:7233261 [07-18 18:04:46:562 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:198875 dataSize:1146 [07-18 18:04:46:562 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:217 timestamp:1689674686562 [07-18 18:04:46:562 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:7233261 ts:0 [07-18 18:04:46:562 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:7233261 [07-18 18:04:46:562 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:198875 dataSize:1146 [07-18 18:04:46:562 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:217 timestamp:1689674686562 [07-18 18:04:46:566 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:566 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 65, head index 217 [07-18 18:04:46:566 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 66, seqNo 66, timestamp 1689674681464 [07-18 18:04:46:566 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:595 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:7266594 ts:0 [07-18 18:04:46:595 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:7266594 [07-18 18:04:46:595 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:200021 dataSize:276 [07-18 18:04:46:595 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:218 timestamp:1689674686595 [07-18 18:04:46:595 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:7266594 ts:0 [07-18 18:04:46:595 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:7266594 [07-18 18:04:46:595 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:200021 dataSize:276 [07-18 18:04:46:595 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:218 timestamp:1689674686595 [07-18 18:04:46:597 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:46:597 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:46:629 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:7299927 ts:0 [07-18 18:04:46:629 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:7299927 [07-18 18:04:46:629 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:200297 dataSize:152 [07-18 18:04:46:629 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:219 timestamp:1689674686629 [07-18 18:04:46:629 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:7299927 ts:0 [07-18 18:04:46:629 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:7299927 [07-18 18:04:46:629 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:200297 dataSize:152 [07-18 18:04:46:629 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:219 timestamp:1689674686629 [07-18 18:04:46:662 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:7333260 ts:0 [07-18 18:04:46:662 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:7333260 [07-18 18:04:46:662 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:200449 dataSize:136 [07-18 18:04:46:662 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:220 timestamp:1689674686662 [07-18 18:04:46:662 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:7333260 ts:0 [07-18 18:04:46:662 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:7333260 [07-18 18:04:46:663 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:200449 dataSize:136 [07-18 18:04:46:663 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:220 timestamp:1689674686663 [07-18 18:04:46:676 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:676 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 66, head index 220 [07-18 18:04:46:676 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 67, seqNo 67, timestamp 1689674681498 [07-18 18:04:46:676 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:696 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:7366593 ts:0 [07-18 18:04:46:696 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:7366593 [07-18 18:04:46:696 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:200585 dataSize:725 [07-18 18:04:46:696 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:221 timestamp:1689674686696 [07-18 18:04:46:696 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:7366593 ts:0 [07-18 18:04:46:696 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:7366593 [07-18 18:04:46:696 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:200585 dataSize:725 [07-18 18:04:46:696 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:221 timestamp:1689674686696 [07-18 18:04:46:730 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:7399926 ts:0 [07-18 18:04:46:730 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:7399926 [07-18 18:04:46:730 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:201310 dataSize:1369 [07-18 18:04:46:730 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:222 timestamp:1689674686730 [07-18 18:04:46:730 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:7399926 ts:0 [07-18 18:04:46:730 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:7399926 [07-18 18:04:46:730 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:201310 dataSize:1369 [07-18 18:04:46:730 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:222 timestamp:1689674686730 [07-18 18:04:46:763 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:7433259 ts:0 [07-18 18:04:46:763 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:7433259 [07-18 18:04:46:763 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:202679 dataSize:367 [07-18 18:04:46:763 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:223 timestamp:1689674686763 [07-18 18:04:46:763 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:7433259 ts:0 [07-18 18:04:46:763 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:7433259 [07-18 18:04:46:763 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:202679 dataSize:367 [07-18 18:04:46:763 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:223 timestamp:1689674686763 [07-18 18:04:46:786 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:787 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 67, head index 223 [07-18 18:04:46:787 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 68, seqNo 68, timestamp 1689674681532 [07-18 18:04:46:787 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:797 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:7466592 ts:0 [07-18 18:04:46:797 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:7466592 [07-18 18:04:46:797 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:203046 dataSize:141 [07-18 18:04:46:797 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:224 timestamp:1689674686797 [07-18 18:04:46:797 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:7466592 ts:0 [07-18 18:04:46:797 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:7466592 [07-18 18:04:46:797 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:203046 dataSize:141 [07-18 18:04:46:797 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:224 timestamp:1689674686797 [07-18 18:04:46:830 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:7499925 ts:0 [07-18 18:04:46:831 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:7499925 [07-18 18:04:46:831 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:203187 dataSize:160 [07-18 18:04:46:831 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:225 timestamp:1689674686831 [07-18 18:04:46:831 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:7499925 ts:0 [07-18 18:04:46:831 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:7499925 [07-18 18:04:46:831 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:203187 dataSize:160 [07-18 18:04:46:831 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:225 timestamp:1689674686831 [07-18 18:04:46:864 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:7533258 ts:0 [07-18 18:04:46:864 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:7533258 [07-18 18:04:46:864 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:203347 dataSize:756 [07-18 18:04:46:864 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:226 timestamp:1689674686864 [07-18 18:04:46:864 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:7533258 ts:0 [07-18 18:04:46:864 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:7533258 [07-18 18:04:46:864 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:203347 dataSize:756 [07-18 18:04:46:864 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:226 timestamp:1689674686864 [07-18 18:04:46:897 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:46:897 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 68, head index 226 [07-18 18:04:46:897 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 69, seqNo 69, timestamp 1689674681565 [07-18 18:04:46:897 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:46:898 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:7566591 ts:0 [07-18 18:04:46:898 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:7566591 [07-18 18:04:46:898 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:204103 dataSize:1610 [07-18 18:04:46:898 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:227 timestamp:1689674686898 [07-18 18:04:46:898 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:7566591 ts:0 [07-18 18:04:46:898 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:7566591 [07-18 18:04:46:898 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:204103 dataSize:1610 [07-18 18:04:46:898 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:227 timestamp:1689674686898 [07-18 18:04:46:931 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:7599924 ts:0 [07-18 18:04:46:931 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:7599924 [07-18 18:04:46:931 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:205713 dataSize:516 [07-18 18:04:46:931 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:228 timestamp:1689674686931 [07-18 18:04:46:931 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:7599924 ts:0 [07-18 18:04:46:931 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:7599924 [07-18 18:04:46:931 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:205713 dataSize:516 [07-18 18:04:46:931 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:228 timestamp:1689674686931 [07-18 18:04:46:965 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:7633257 ts:0 [07-18 18:04:46:965 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:7633257 [07-18 18:04:46:965 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:206229 dataSize:231 [07-18 18:04:46:965 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:229 timestamp:1689674686965 [07-18 18:04:46:965 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:7633257 ts:0 [07-18 18:04:46:965 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:7633257 [07-18 18:04:46:965 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:206229 dataSize:231 [07-18 18:04:46:965 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:229 timestamp:1689674686965 [07-18 18:04:46:998 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:7666590 ts:0 [07-18 18:04:46:999 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:7666590 [07-18 18:04:46:999 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:206460 dataSize:250 [07-18 18:04:46:999 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:230 timestamp:1689674686999 [07-18 18:04:46:999 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:7666590 ts:0 [07-18 18:04:46:999 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:7666590 [07-18 18:04:46:999 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:206460 dataSize:250 [07-18 18:04:46:999 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:230 timestamp:1689674686999 [07-18 18:04:47:7 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:7 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 69, head index 230 [07-18 18:04:47:7 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 70, seqNo 70, timestamp 1689674681599 [07-18 18:04:47:7 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:32 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:7699923 ts:0 [07-18 18:04:47:32 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:7699923 [07-18 18:04:47:32 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:206710 dataSize:1143 [07-18 18:04:47:32 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:231 timestamp:1689674687032 [07-18 18:04:47:32 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:7699923 ts:0 [07-18 18:04:47:32 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:7699923 [07-18 18:04:47:32 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:206710 dataSize:1143 [07-18 18:04:47:32 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:231 timestamp:1689674687032 [07-18 18:04:47:66 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:7733256 ts:0 [07-18 18:04:47:66 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:7733256 [07-18 18:04:47:66 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:207853 dataSize:383 [07-18 18:04:47:66 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:232 timestamp:1689674687066 [07-18 18:04:47:66 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:7733256 ts:0 [07-18 18:04:47:66 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:7733256 [07-18 18:04:47:66 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:207853 dataSize:383 [07-18 18:04:47:66 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:232 timestamp:1689674687066 [07-18 18:04:47:99 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:7766589 ts:0 [07-18 18:04:47:99 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:7766589 [07-18 18:04:47:99 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:208236 dataSize:235 [07-18 18:04:47:100 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:233 timestamp:1689674687100 [07-18 18:04:47:100 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:7766589 ts:0 [07-18 18:04:47:100 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:7766589 [07-18 18:04:47:100 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:208236 dataSize:235 [07-18 18:04:47:100 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:233 timestamp:1689674687100 [07-18 18:04:47:118 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:118 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 70, head index 233 [07-18 18:04:47:118 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 71, seqNo 71, timestamp 1689674681633 [07-18 18:04:47:118 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:133 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:7799922 ts:0 [07-18 18:04:47:133 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:7799922 [07-18 18:04:47:133 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:208471 dataSize:165 [07-18 18:04:47:133 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:234 timestamp:1689674687133 [07-18 18:04:47:133 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:7799922 ts:0 [07-18 18:04:47:133 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:7799922 [07-18 18:04:47:133 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:208471 dataSize:165 [07-18 18:04:47:133 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:234 timestamp:1689674687133 [07-18 18:04:47:167 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:7833255 ts:0 [07-18 18:04:47:167 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:7833255 [07-18 18:04:47:167 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:208636 dataSize:457 [07-18 18:04:47:167 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:235 timestamp:1689674687167 [07-18 18:04:47:167 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:7833255 ts:0 [07-18 18:04:47:167 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:7833255 [07-18 18:04:47:167 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:208636 dataSize:457 [07-18 18:04:47:167 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:235 timestamp:1689674687167 [07-18 18:04:47:200 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:7866588 ts:0 [07-18 18:04:47:201 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:7866588 [07-18 18:04:47:201 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:209093 dataSize:673 [07-18 18:04:47:201 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:236 timestamp:1689674687201 [07-18 18:04:47:201 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:7866588 ts:0 [07-18 18:04:47:201 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:7866588 [07-18 18:04:47:201 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:209093 dataSize:673 [07-18 18:04:47:201 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:236 timestamp:1689674687201 [07-18 18:04:47:228 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:228 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 71, head index 236 [07-18 18:04:47:228 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 72, seqNo 72, timestamp 1689674681666 [07-18 18:04:47:228 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:234 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:7899921 ts:0 [07-18 18:04:47:234 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:7899921 [07-18 18:04:47:234 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:209766 dataSize:465 [07-18 18:04:47:234 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:237 timestamp:1689674687234 [07-18 18:04:47:234 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:7899921 ts:0 [07-18 18:04:47:234 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:7899921 [07-18 18:04:47:234 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:209766 dataSize:465 [07-18 18:04:47:234 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:237 timestamp:1689674687234 [07-18 18:04:47:268 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:7933254 ts:0 [07-18 18:04:47:268 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:7933254 [07-18 18:04:47:268 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:210231 dataSize:248 [07-18 18:04:47:268 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:238 timestamp:1689674687268 [07-18 18:04:47:268 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:7933254 ts:0 [07-18 18:04:47:268 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:7933254 [07-18 18:04:47:268 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:210231 dataSize:248 [07-18 18:04:47:268 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:238 timestamp:1689674687268 [07-18 18:04:47:301 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:7966587 ts:0 [07-18 18:04:47:301 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:7966587 [07-18 18:04:47:301 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:210479 dataSize:217 [07-18 18:04:47:301 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:239 timestamp:1689674687301 [07-18 18:04:47:302 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:7966587 ts:0 [07-18 18:04:47:302 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:7966587 [07-18 18:04:47:302 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:210479 dataSize:217 [07-18 18:04:47:302 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:239 timestamp:1689674687302 [07-18 18:04:47:335 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:7999920 ts:0 [07-18 18:04:47:335 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:7999920 [07-18 18:04:47:335 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:210696 dataSize:280 [07-18 18:04:47:335 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:240 timestamp:1689674687335 [07-18 18:04:47:335 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:7999920 ts:0 [07-18 18:04:47:335 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:7999920 [07-18 18:04:47:335 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:210696 dataSize:280 [07-18 18:04:47:335 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:240 timestamp:1689674687335 [07-18 18:04:47:338 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:339 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 72, head index 240 [07-18 18:04:47:339 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 73, seqNo 73, timestamp 1689674681700 [07-18 18:04:47:339 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:369 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:8033253 ts:0 [07-18 18:04:47:369 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:8033253 [07-18 18:04:47:369 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:210976 dataSize:12088 [07-18 18:04:47:369 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:241 timestamp:1689674687369 [07-18 18:04:47:369 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:8033253 ts:0 [07-18 18:04:47:369 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:8033253 [07-18 18:04:47:369 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:210976 dataSize:12088 [07-18 18:04:47:369 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:241 timestamp:1689674687369 [07-18 18:04:47:402 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:8066586 ts:0 [07-18 18:04:47:402 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:8066586 [07-18 18:04:47:402 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:223064 dataSize:1051 [07-18 18:04:47:402 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:242 timestamp:1689674687402 [07-18 18:04:47:402 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:8066586 ts:0 [07-18 18:04:47:402 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:8066586 [07-18 18:04:47:402 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:223064 dataSize:1051 [07-18 18:04:47:402 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:242 timestamp:1689674687402 [07-18 18:04:47:436 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:8099919 ts:0 [07-18 18:04:47:436 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:8099919 [07-18 18:04:47:436 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:224115 dataSize:209 [07-18 18:04:47:436 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:243 timestamp:1689674687436 [07-18 18:04:47:436 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:8099919 ts:0 [07-18 18:04:47:436 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:8099919 [07-18 18:04:47:436 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:224115 dataSize:209 [07-18 18:04:47:436 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:243 timestamp:1689674687436 [07-18 18:04:47:449 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:449 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 73, head index 243 [07-18 18:04:47:449 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 74, seqNo 74, timestamp 1689674681734 [07-18 18:04:47:449 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:470 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:8133252 ts:0 [07-18 18:04:47:470 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:8133252 [07-18 18:04:47:470 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:224324 dataSize:118 [07-18 18:04:47:470 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:244 timestamp:1689674687470 [07-18 18:04:47:470 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:8133252 ts:0 [07-18 18:04:47:470 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:8133252 [07-18 18:04:47:470 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:224324 dataSize:118 [07-18 18:04:47:470 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:244 timestamp:1689674687470 [07-18 18:04:47:503 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:8166585 ts:0 [07-18 18:04:47:503 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:8166585 [07-18 18:04:47:503 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:224442 dataSize:110 [07-18 18:04:47:503 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:245 timestamp:1689674687503 [07-18 18:04:47:503 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:8166585 ts:0 [07-18 18:04:47:503 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:8166585 [07-18 18:04:47:503 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:224442 dataSize:110 [07-18 18:04:47:503 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:245 timestamp:1689674687503 [07-18 18:04:47:537 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:8199918 ts:0 [07-18 18:04:47:537 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:8199918 [07-18 18:04:47:537 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:224552 dataSize:695 [07-18 18:04:47:537 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:246 timestamp:1689674687537 [07-18 18:04:47:537 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:8199918 ts:0 [07-18 18:04:47:537 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:8199918 [07-18 18:04:47:537 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:224552 dataSize:695 [07-18 18:04:47:537 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:246 timestamp:1689674687537 [07-18 18:04:47:559 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:559 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 74, head index 246 [07-18 18:04:47:559 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 75, seqNo 75, timestamp 1689674681767 [07-18 18:04:47:559 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:571 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:8233251 ts:0 [07-18 18:04:47:571 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:8233251 [07-18 18:04:47:571 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:225247 dataSize:1146 [07-18 18:04:47:571 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:247 timestamp:1689674687571 [07-18 18:04:47:571 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:8233251 ts:0 [07-18 18:04:47:571 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:8233251 [07-18 18:04:47:571 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:225247 dataSize:1146 [07-18 18:04:47:571 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:247 timestamp:1689674687571 [07-18 18:04:47:598 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:47:598 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:47:604 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:8266584 ts:0 [07-18 18:04:47:604 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:8266584 [07-18 18:04:47:604 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:226393 dataSize:276 [07-18 18:04:47:604 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:248 timestamp:1689674687604 [07-18 18:04:47:604 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:8266584 ts:0 [07-18 18:04:47:604 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:8266584 [07-18 18:04:47:604 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:226393 dataSize:276 [07-18 18:04:47:604 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:248 timestamp:1689674687604 [07-18 18:04:47:638 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:8299917 ts:0 [07-18 18:04:47:638 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:8299917 [07-18 18:04:47:638 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:226669 dataSize:152 [07-18 18:04:47:638 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:249 timestamp:1689674687638 [07-18 18:04:47:638 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:8299917 ts:0 [07-18 18:04:47:638 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:8299917 [07-18 18:04:47:638 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:226669 dataSize:152 [07-18 18:04:47:638 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:249 timestamp:1689674687638 [07-18 18:04:47:670 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:670 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 75, head index 249 [07-18 18:04:47:670 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 76, seqNo 76, timestamp 1689674681801 [07-18 18:04:47:670 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:671 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:8333250 ts:0 [07-18 18:04:47:671 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:8333250 [07-18 18:04:47:671 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:226821 dataSize:136 [07-18 18:04:47:671 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:250 timestamp:1689674687671 [07-18 18:04:47:671 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:8333250 ts:0 [07-18 18:04:47:671 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:8333250 [07-18 18:04:47:671 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:226821 dataSize:136 [07-18 18:04:47:671 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:250 timestamp:1689674687671 [07-18 18:04:47:705 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:8366583 ts:0 [07-18 18:04:47:705 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:8366583 [07-18 18:04:47:705 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:226957 dataSize:725 [07-18 18:04:47:705 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:251 timestamp:1689674687705 [07-18 18:04:47:705 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:8366583 ts:0 [07-18 18:04:47:705 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:8366583 [07-18 18:04:47:705 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:226957 dataSize:725 [07-18 18:04:47:705 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:251 timestamp:1689674687705 [07-18 18:04:47:739 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:8399916 ts:0 [07-18 18:04:47:739 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:8399916 [07-18 18:04:47:739 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:227682 dataSize:1369 [07-18 18:04:47:739 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:252 timestamp:1689674687739 [07-18 18:04:47:739 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:8399916 ts:0 [07-18 18:04:47:739 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:8399916 [07-18 18:04:47:739 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:227682 dataSize:1369 [07-18 18:04:47:739 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:252 timestamp:1689674687739 [07-18 18:04:47:772 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:8433249 ts:0 [07-18 18:04:47:772 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:8433249 [07-18 18:04:47:772 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:229051 dataSize:367 [07-18 18:04:47:772 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:253 timestamp:1689674687772 [07-18 18:04:47:772 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:8433249 ts:0 [07-18 18:04:47:772 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:8433249 [07-18 18:04:47:772 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:229051 dataSize:367 [07-18 18:04:47:772 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:253 timestamp:1689674687772 [07-18 18:04:47:780 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:780 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 76, head index 253 [07-18 18:04:47:780 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 77, seqNo 77, timestamp 1689674681835 [07-18 18:04:47:780 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:806 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:8466582 ts:0 [07-18 18:04:47:806 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:8466582 [07-18 18:04:47:806 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:229418 dataSize:141 [07-18 18:04:47:806 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:254 timestamp:1689674687806 [07-18 18:04:47:806 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:8466582 ts:0 [07-18 18:04:47:806 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:8466582 [07-18 18:04:47:806 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:229418 dataSize:141 [07-18 18:04:47:806 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:254 timestamp:1689674687806 [07-18 18:04:47:839 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:8499915 ts:0 [07-18 18:04:47:839 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:8499915 [07-18 18:04:47:839 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:229559 dataSize:160 [07-18 18:04:47:840 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:255 timestamp:1689674687840 [07-18 18:04:47:840 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:8499915 ts:0 [07-18 18:04:47:840 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:8499915 [07-18 18:04:47:840 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:229559 dataSize:160 [07-18 18:04:47:840 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:255 timestamp:1689674687840 [07-18 18:04:47:873 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:8533248 ts:0 [07-18 18:04:47:873 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:8533248 [07-18 18:04:47:873 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:229719 dataSize:756 [07-18 18:04:47:873 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:256 timestamp:1689674687873 [07-18 18:04:47:873 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:8533248 ts:0 [07-18 18:04:47:873 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:8533248 [07-18 18:04:47:873 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:229719 dataSize:756 [07-18 18:04:47:873 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:256 timestamp:1689674687873 [07-18 18:04:47:891 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:47:891 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 77, head index 256 [07-18 18:04:47:891 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 78, seqNo 78, timestamp 1689674681868 [07-18 18:04:47:891 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:47:907 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:8566581 ts:0 [07-18 18:04:47:907 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:8566581 [07-18 18:04:47:907 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:230475 dataSize:1610 [07-18 18:04:47:907 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:257 timestamp:1689674687907 [07-18 18:04:47:907 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:8566581 ts:0 [07-18 18:04:47:907 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:8566581 [07-18 18:04:47:907 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:230475 dataSize:1610 [07-18 18:04:47:907 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:257 timestamp:1689674687907 [07-18 18:04:47:940 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:8599914 ts:0 [07-18 18:04:47:940 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:8599914 [07-18 18:04:47:940 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:232085 dataSize:516 [07-18 18:04:47:940 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:258 timestamp:1689674687940 [07-18 18:04:47:940 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:8599914 ts:0 [07-18 18:04:47:940 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:8599914 [07-18 18:04:47:940 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:232085 dataSize:516 [07-18 18:04:47:940 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:258 timestamp:1689674687940 [07-18 18:04:47:974 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:8633247 ts:0 [07-18 18:04:47:974 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:8633247 [07-18 18:04:47:974 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:232601 dataSize:231 [07-18 18:04:47:974 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:259 timestamp:1689674687974 [07-18 18:04:47:974 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:8633247 ts:0 [07-18 18:04:47:974 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:8633247 [07-18 18:04:47:974 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:232601 dataSize:231 [07-18 18:04:47:974 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:259 timestamp:1689674687974 [07-18 18:04:48:1 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:48:1 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 78, head index 259 [07-18 18:04:48:1 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 79, seqNo 79, timestamp 1689674681902 [07-18 18:04:48:1 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:48:7 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:8666580 ts:0 [07-18 18:04:48:7 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:8666580 [07-18 18:04:48:7 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:232832 dataSize:250 [07-18 18:04:48:7 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:260 timestamp:1689674688007 [07-18 18:04:48:7 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:8666580 ts:0 [07-18 18:04:48:7 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:8666580 [07-18 18:04:48:7 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:232832 dataSize:250 [07-18 18:04:48:7 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:260 timestamp:1689674688007 [07-18 18:04:48:41 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:8699913 ts:0 [07-18 18:04:48:41 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:8699913 [07-18 18:04:48:41 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:233082 dataSize:1143 [07-18 18:04:48:41 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:261 timestamp:1689674688041 [07-18 18:04:48:41 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:8699913 ts:0 [07-18 18:04:48:41 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:8699913 [07-18 18:04:48:41 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:233082 dataSize:1143 [07-18 18:04:48:41 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:261 timestamp:1689674688041 [07-18 18:04:48:75 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:8733246 ts:0 [07-18 18:04:48:75 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:8733246 [07-18 18:04:48:75 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:234225 dataSize:383 [07-18 18:04:48:75 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:262 timestamp:1689674688075 [07-18 18:04:48:75 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:8733246 ts:0 [07-18 18:04:48:75 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:8733246 [07-18 18:04:48:75 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:234225 dataSize:383 [07-18 18:04:48:75 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:262 timestamp:1689674688075 [07-18 18:04:48:108 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:8766579 ts:0 [07-18 18:04:48:108 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:8766579 [07-18 18:04:48:108 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:234608 dataSize:235 [07-18 18:04:48:108 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:263 timestamp:1689674688108 [07-18 18:04:48:108 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:8766579 ts:0 [07-18 18:04:48:108 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:8766579 [07-18 18:04:48:108 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:234608 dataSize:235 [07-18 18:04:48:108 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:263 timestamp:1689674688108 [07-18 18:04:48:111 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:48:111 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 79, head index 263 [07-18 18:04:48:111 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 80, seqNo 80, timestamp 1689674681936 [07-18 18:04:48:111 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:48:142 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:8799912 ts:0 [07-18 18:04:48:142 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:8799912 [07-18 18:04:48:142 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:234843 dataSize:165 [07-18 18:04:48:142 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:264 timestamp:1689674688142 [07-18 18:04:48:142 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:8799912 ts:0 [07-18 18:04:48:142 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:8799912 [07-18 18:04:48:142 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:234843 dataSize:165 [07-18 18:04:48:142 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:264 timestamp:1689674688142 [07-18 18:04:48:176 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:8833245 ts:0 [07-18 18:04:48:176 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:8833245 [07-18 18:04:48:176 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:235008 dataSize:457 [07-18 18:04:48:176 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:265 timestamp:1689674688176 [07-18 18:04:48:176 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:8833245 ts:0 [07-18 18:04:48:176 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:8833245 [07-18 18:04:48:176 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:235008 dataSize:457 [07-18 18:04:48:176 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:265 timestamp:1689674688176 [07-18 18:04:48:210 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:8866578 ts:0 [07-18 18:04:48:210 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:8866578 [07-18 18:04:48:210 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:235465 dataSize:673 [07-18 18:04:48:210 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:266 timestamp:1689674688210 [07-18 18:04:48:210 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:8866578 ts:0 [07-18 18:04:48:210 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:8866578 [07-18 18:04:48:210 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:235465 dataSize:673 [07-18 18:04:48:210 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:266 timestamp:1689674688210 [07-18 18:04:48:222 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:48:222 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 80, head index 266 [07-18 18:04:48:222 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 81, seqNo 81, timestamp 1689674681969 [07-18 18:04:48:222 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:48:243 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:8899911 ts:0 [07-18 18:04:48:243 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:8899911 [07-18 18:04:48:243 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:236138 dataSize:465 [07-18 18:04:48:243 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:267 timestamp:1689674688243 [07-18 18:04:48:243 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:8899911 ts:0 [07-18 18:04:48:243 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:8899911 [07-18 18:04:48:243 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:236138 dataSize:465 [07-18 18:04:48:243 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:267 timestamp:1689674688243 [07-18 18:04:48:277 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:8933244 ts:0 [07-18 18:04:48:277 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:8933244 [07-18 18:04:48:277 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:236603 dataSize:248 [07-18 18:04:48:277 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:268 timestamp:1689674688277 [07-18 18:04:48:277 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:8933244 ts:0 [07-18 18:04:48:277 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:8933244 [07-18 18:04:48:277 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:236603 dataSize:248 [07-18 18:04:48:277 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:268 timestamp:1689674688277 [07-18 18:04:48:311 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:8966577 ts:0 [07-18 18:04:48:311 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:8966577 [07-18 18:04:48:311 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:236851 dataSize:217 [07-18 18:04:48:311 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:269 timestamp:1689674688311 [07-18 18:04:48:311 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:8966577 ts:0 [07-18 18:04:48:311 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:8966577 [07-18 18:04:48:311 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:236851 dataSize:217 [07-18 18:04:48:311 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:269 timestamp:1689674688311 [07-18 18:04:48:332 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:48:332 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 81, head index 269 [07-18 18:04:48:332 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 82, seqNo 82, timestamp 1689674682003 [07-18 18:04:48:332 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:48:344 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:8999910 ts:0 [07-18 18:04:48:344 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:8999910 [07-18 18:04:48:344 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:237068 dataSize:280 [07-18 18:04:48:344 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:270 timestamp:1689674688344 [07-18 18:04:48:344 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:8999910 ts:0 [07-18 18:04:48:344 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:8999910 [07-18 18:04:48:344 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:237068 dataSize:280 [07-18 18:04:48:344 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:270 timestamp:1689674688344 [07-18 18:04:48:378 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:9033243 ts:0 [07-18 18:04:48:378 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:9033243 [07-18 18:04:48:378 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:237348 dataSize:12088 [07-18 18:04:48:378 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:271 timestamp:1689674688378 [07-18 18:04:48:378 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:9033243 ts:0 [07-18 18:04:48:378 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:9033243 [07-18 18:04:48:378 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:237348 dataSize:12088 [07-18 18:04:48:378 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:271 timestamp:1689674688378 [07-18 18:04:48:412 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:9066576 ts:0 [07-18 18:04:48:412 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:9066576 [07-18 18:04:48:412 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:249436 dataSize:1051 [07-18 18:04:48:412 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:272 timestamp:1689674688412 [07-18 18:04:48:412 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:9066576 ts:0 [07-18 18:04:48:412 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:9066576 [07-18 18:04:48:412 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:249436 dataSize:1051 [07-18 18:04:48:412 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:272 timestamp:1689674688412 [07-18 18:04:48:442 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00fe30 [07-18 18:04:48:442 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 82, head index 272 [07-18 18:04:48:442 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 83, seqNo 83, timestamp 1689674682037 [07-18 18:04:48:442 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:48:445 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:9099909 ts:0 [07-18 18:04:48:445 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:9099909 [07-18 18:04:48:445 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:250487 dataSize:209 [07-18 18:04:48:445 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:273 timestamp:1689674688445 [07-18 18:04:48:445 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:9099909 ts:0 [07-18 18:04:48:445 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:9099909 [07-18 18:04:48:445 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:250487 dataSize:209 [07-18 18:04:48:446 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:273 timestamp:1689674688445 [07-18 18:04:48:461 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [6] low cmd[3] [07-18 18:04:48:461 TUYA Debug][tuya_ipc_p2p.c:2006] session[65537] [0] send video stop to dev [07-18 18:04:48:461 TUYA Debug][tuya_ipc_p2p.c:2013] session[65537] video stop [07-18 18:04:48:518 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:04:48:553 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:04:48:598 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:48:598 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:48:634 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [6] low cmd[5] [07-18 18:04:48:634 TUYA Debug][tuya_ipc_p2p.c:2100] session[65537] [0] send audio stop to dev [07-18 18:04:49:59 TUYA Debug][tuya_ipc_p2p.c:5031] session[65537] detech staticCnt[0]lstCnt[3]vIFrameCnt[3] [07-18 18:04:49:83 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:04:49:83 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:49:83 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:32 [07-18 18:04:49:599 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:49:599 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:50:341 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [97000] [07-18 18:04:50:601 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:50:601 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:51:602 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:51:602 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:52:581 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:52:581 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:52:581 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:52:581 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:52:581 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:52:581 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 61 [07-18 18:04:52:581 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674692,"protocol":302,"data":{"msg":{"close_reason_local":0,"close_reason":4},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689671163zF8Iuete","path":"mqtt","sub_dev_id":"","type":"disconnect","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689671163143"}}} [07-18 18:04:52:581 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:52:581 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:52:581 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:52:581 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c650 [07-18 18:04:52:581 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:52:605 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:52:653 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65537] higcmd [100] low cmd[7] [07-18 18:04:52:653 TUYA Debug][tuya_ipc_p2p.c:3082] CTRL PLAY BACK session[65537] high[100] low[7] [07-18 18:04:52:654 TUYA Debug][tuya_ipc_p2p.c:3085] CTRL PLAY BACK session[65537] chn[0] speed[1] [07-18 18:04:52:654 TUYA Err][tuya_ipc_p2p.c:3092] err CTRL PLAY BACK session[65537] chn[0] speed[1] [07-18 18:04:52:702 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:52:702 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:52:702 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:52:702 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:52:702 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:52:702 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 62 [07-18 18:04:52:702 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674692,"protocol":302,"data":{"msg":{"handle":1,"seq":1,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:52:702 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:52:702 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:52:702 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:52:702 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c650 [07-18 18:04:52:702 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:52:710 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58369 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":1,"error":0,"seq":1}} [07-18 18:04:52:710 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:52:725 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:52:749 TUYA Err][tuya_ipc_p2p.c:3667] session[65537] was close by client ret[-11] [07-18 18:04:52:749 TUYA Err][tuya_ipc_p2p.c:3778] session[65537] read cmd failed [-1] [07-18 18:04:52:749 TUYA Debug][tuya_ipc_p2p.c:3547] close session[65537] [07-18 18:04:52:749 TUYA Debug][tuya_ipc_p2p.c:2179] session[65537] cmd[0] status[7] [07-18 18:04:52:749 TUYA Err][tuya_ipc_p2p.c:2534] speaker not start [07-18 18:04:52:754 TUYA Err][tuya_ipc_p2p.c:3628] session[65537] is try to releasing [07-18 18:04:52:754 TUYA Debug][tuya_ipc_p2p.c:5134] session[65537] __p2p_wait_concurr_idle start [07-18 18:04:52:783 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:04:52:783 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:04:52:783 TUYA Trace][iot_httpc.c:940] api[tuya.device.log.report] hash[0x9f81e2a5] [07-18 18:04:52:783 TUYA Debug][iot_httpc.c:984] Post Data: {"type":"tuya_p2p_log","data":"{\"type\":\"connection\",\"connection_type\":\"kcp\",\"session_id\":\"6c9127b907229c12a5bqfi1689674678SjKMLgf7\",\"trace_id\":\"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552\",\"moto_id\":\"\",\"session_handle\":1,\"active_handle\":1,\"role\":\"callee\",\"local_id\":\"6c9127b907229c12a5bqfi\",\"remote_id\":\"ay1689142558741Q9RvD\",\"dev_id\":\"\",\"local_p2p_skill\":35,\"remote_p2p_skill\":99,\"preconnect\":true,\"sdk_version\":\"tuya_p2p_sdk_v3.4.3\",\"activate\":{\"channel_info\":{\"write_bytes\":[296,81636,0,0,0,0,2756],\"read_bytes\":[520,0,0,0,0,0,2976],\"send_bytes\":[248,81636,0,0,0,0,2756],\"recv_bytes\":[568,0,0,0,0,0,2976],\"socket_send_bytes\":[952,90140,0,0,0,0,3236],\"socket_recv_bytes\":[1728,3124,0,0,0,0,3580],\"first_send_time_ms\":[525490,526013,-1,-1,-1,-1,525391],\"first_write_time_ms\":[525484,526003,-1,-1,-1,-1,525320],\"first_read_time_ms\":[525423,-1,-1,-1,-1,-1,525401],\"first_read_try_time [07-18 18:04:52:783 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674692&v=1.0&sign=3b11f1418ecfd100ab19e7bd6ca23984 [07-18 18:04:52:783 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:04:52:784 TUYA Trace][httpc.c:663] No port number given [07-18 18:04:52:784 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674692&v=1.0&sign=3b11f1418ecfd100ab19e7bd6ca23984 [07-18 18:04:52:784 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 18:04:52:784 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 18:04:52:784 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 18:04:52:784 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 18:04:52:784 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 18:04:52:784 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 18:04:52:784 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 18:04:52:784 TUYA Debug][tuya_ipc_p2p.c:5151] session[65537] concurr idle[2][2] [07-18 18:04:52:784 TUYA Debug][tuya_ipc_p2p.c:5157] session[65537] __p2p_wait_concurr_idle end [07-18 18:04:52:784 TUYA Debug][tuya_ipc_p2p.c:4100] session[65537] playback_send_video start release [07-18 18:04:52:784 TUYA Debug][tuya_ipc_p2p.c:3576] release source [65537] [07-18 18:04:52:784 TUYA Debug][tuya_ipc_p2p.c:3616] release va session[65537] [07-18 18:04:52:784 TUYA Debug][tuya_ipc_p2p.c:4102] session[0] closed [07-18 18:04:52:804 TUYA Trace][httpc.c:560] Connected .. sockfd: 45 [07-18 18:04:52:804 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 18:04:52:804 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 18:04:52:804 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 18:04:52:804 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 18:04:52:804 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 18:04:52:804 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 18:04:52:926 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 18:04:52:926 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 18:04:52:926 TUYA Trace][httpc.c:952] Have to extract [07-18 18:04:52:926 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:04:52:926 TUYA Trace][httpc.c:663] No port number given [07-18 18:04:52:926 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674692&v=1.0&sign=3b11f1418ecfd100ab19e7bd6ca23984 [07-18 18:04:52:926 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 18:04:52:926 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674692&v=1.0&sign=3b11f1418ecfd100ab19e7bd6ca23984 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 2341 [07-18 18:04:52:926 TUYA Trace][httpc.c:996] content len:2341 [07-18 18:04:52:926 TUYA Trace][httpc.c:343] Start header read [07-18 18:04:52:986 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 18:04:52:986 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: 9178f58c086e4bffa69fe78d36909c14 content-type: application/json;charset=UTF-8 content-length: 119 date: Tue, 18 Jul 2023 10:04:52 GMT server: https {"result":"ZeQSvBEdHjHl1j5RF4jn6NCtksHuHlubTp8fvkeLk+gEQif8+0oQ6avZeQooIEYp","sign":"e54ead19de9b1027","t":1689674693} [07-18 18:04:52:986 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 18:04:52:986 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 305 bytes header [07-18 18:04:52:986 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:120 [07-18 18:04:52:986 TUYA Trace][httpc.c:1748] contentlen:119 size_remain:119 size_to_read:119 [07-18 18:04:52:986 TUYA Trace][httpc.c:425] Using prefetch: 186 119 119 119 [07-18 18:04:52:986 TUYA Trace][iot_httpc.c:807] RESP:{"result":"ZeQSvBEdHjHl1j5RF4jn6NCtksHuHlubTp8fvkeLk+gEQif8+0oQ6avZeQooIEYp","sign":"e54ead19de9b1027","t":1689674693} [07-18 18:04:52:986 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 18:04:52:986 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":true,"t":1689674693,"success":true} [07-18 18:04:53:1 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 18:04:53:1 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 18:04:53:21 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:21 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:21 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:21 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:21 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:21 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 63 [07-18 18:04:53:21 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":302,"data":{"msg":{"handle":1,"seq":2,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:53:21 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:21 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:21 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:21 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c600 [07-18 18:04:53:22 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:29 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58370 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":1,"error":0,"seq":2}} [07-18 18:04:53:29 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:45 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:265 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:04:53:322 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:322 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:322 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:322 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:322 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:322 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 64 [07-18 18:04:53:323 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":302,"data":{"msg":{"handle":1,"seq":3,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:53:323 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:323 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:323 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:323 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c600 [07-18 18:04:53:323 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:331 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58371 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":1,"error":0,"seq":3}} [07-18 18:04:53:332 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:347 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:514 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:514 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:515 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:515 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:515 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:515 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 65 [07-18 18:04:53:515 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":22,"data":{"reqType":"sigQry"}} [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:2 mq_pro:304 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:3 mq_pro:307 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:4 mq_pro:308 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:5 mq_pro:312 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:6 mq_pro:5 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:7 mq_pro:31 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:8 mq_pro:11 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:9 mq_pro:41 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:10 mq_pro:100 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:11 mq_pro:27 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:12 mq_pro:64 [07-18 18:04:53:515 TUYA Trace][mqc_app.c:719] index:13 mq_pro:22 [07-18 18:04:53:515 TUYA Debug][gw_mqc_cb.c:184] Rev sigQry Req [07-18 18:04:53:538 TUYA Debug][tuya_devos_netlink.c:1221] Get Rssi:98 [07-18 18:04:53:538 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:23 N:58372 Q:0 Data:{"reqType":"sigQry","data":{"signal":98}} [07-18 18:04:53:538 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:561 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:662 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:662 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:662 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:662 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:662 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:663 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:663 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:663 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 66 [07-18 18:04:53:663 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":302,"data":{"msg":{"log":{"size":1024,"tcp":{"address":"124.221.79.86","key":"6e9d446e4a2d2cdc","domain":"wework-1-cn.stream.iot-11.com","port":9092},"interval":60,"level":2,"topic":"\/av\/moto\/log","api":"thing.m.rtc.log"},"sdp":"v=0\r\no=- 1689674693 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9127b907229c12a5bqfi1689674693VjWbLDLw\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:ePY9\r\na=ice-pwd:RVKU2PAPvQzH6VtbZOffmk2K\r\na=ice-options:trickle\r\na=aes-key:0f0001a0f0e5eb000002050000a0000c\r\na=mid:imm0\r\na=rtpmap:6001 AES\/KCP 330\r\na=ssrc:0 cname:ay1689142558741Q9RvD\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"username":"1689678293:6c9127b907229c12a5bqfi","ttl":3600,"urls":"turn:47.103.17.244:3478","credential":"bVvdpohx4iS99rIl5TfdK5\/EU4U="}],"tcp_token":{"username":"1689710693:6c9127b907229c12a5bqfi","sessionI [07-18 18:04:53:663 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:663 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:663 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:663 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c002fc0 [07-18 18:04:53:663 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:673 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58373 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","moto_id":"","type":"answer","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723","is_pre":0,"p2p_skill":35,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1689674693 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9127b907229c12a5bqfi1689674693VjWbLDLw\r\nm=application 9 tuya 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:gflZ\r\na=ice-pwd:Pb9eu6NyFTxweyZyF81Kt7Uf\r\na=ice-options:trickle\r\na=aes-key:0f0001a0f0e5eb000002050000a0000c\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 3\r\na=ssrc:0 cname:6c9127b907229c12a5bqfi\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"username":"1689678293:6c9127b907229c12a5bqfi","ttl":3600,"urls":"turn:47.103.17.244:3478","credential":"bVvdpohx4iS99rIl5TfdK5/EU4U="}],"tcp_token":{"username":"1689 [07-18 18:04:53:673 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:674 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58374 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723","path":"mqtt"},"msg":{"candidate":"a=candidate:1908692123 1 UDP 2130706431 192.168.2.111 55778 typ host\r\n"}} [07-18 18:04:53:674 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:674 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58375 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723","path":"mqtt"},"msg":{"candidate":"a=candidate:645776352 1 UDP 2130706431 192.250.250.1 55778 typ host\r\n"}} [07-18 18:04:53:674 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:687 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:687 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:687 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:687 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:687 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:687 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:687 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 67 [07-18 18:04:53:687 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":302,"data":{"msg":{"candidate":"a=candidate:757387534 1 UDP 2130706431 10.94.71.231 54680 typ host\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723"}}} [07-18 18:04:53:687 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:687 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:687 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:687 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c002fc0 [07-18 18:04:53:687 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:710 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:710 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:710 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:710 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:710 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:710 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:710 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 68 [07-18 18:04:53:710 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":302,"data":{"msg":{"candidate":"a=candidate:1772634399 1 UDP 2130706431 192.168.2.74 54680 typ host\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723"}}} [07-18 18:04:53:710 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:710 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:710 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:710 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c510 [07-18 18:04:53:710 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:718 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58376 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723","path":"mqtt"},"msg":{"candidate":"a=candidate:499511454 1 UDP 1694498815 49.73.254.50 45125 typ srflx\r\n"}} [07-18 18:04:53:718 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:734 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58377 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723","path":"mqtt"},"msg":{"candidate":""}} [07-18 18:04:53:734 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:734 TUYA Debug][tuya_ipc_p2p.c:4512] listen ok session[65538] [07-18 18:04:53:735 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:735 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:735 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:735 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:735 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:735 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:735 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 69 [07-18 18:04:53:736 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":302,"data":{"msg":{"candidate":"a=candidate:1985514339 1 UDP 1694498815 49.73.254.50 45122 typ srflx\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723"}}} [07-18 18:04:53:736 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:736 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:736 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:736 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c510 [07-18 18:04:53:736 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:744 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58378 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723","path":"mqtt"},"msg":{"candidate":"a=candidate:1166029854 1 UDP 16777215 47.103.17.244 57143 typ relay\r\n"}} [07-18 18:04:53:744 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:745 TUYA Debug][tuya_ipc_p2p.c:3987] compare passwd [07-18 18:04:53:745 TUYA Debug][tuya_ipc_p2p.c:3988] get ipc auth gw_local_key[Mro9dY$MHLv!DTHz]p2p_passwd[adb63309] [07-18 18:04:53:745 TUYA Debug][tuya_ipc_p2p.c:4006] Client Auth admin efa628a6c8b8f6f591f69df58cfba471 <-> admin adb63309 [07-18 18:04:53:745 TUYA Debug][tuya_ipc_p2p.c:4007] localkey:Mro9dY$MHLv!DTHz final:efa628a6c8b8f6f591f69df58cfba471 [07-18 18:04:53:745 TUYA Debug][tuya_ipc_p2p.c:4010] auth success [07-18 18:04:53:745 TUYA Debug][tuya_ipc_p2p.c:592] __p2p_get_idle_session begin [07-18 18:04:53:745 TUYA Debug][tuya_ipc_p2p.c:4624] create p2p sessions. cur online session num = 1 [07-18 18:04:53:745 TUYA Debug][tuya_ipc_p2p.c:4445] mqtt p2p LISTEN session........ [07-18 18:04:53:760 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:760 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:760 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:760 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:760 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:760 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:760 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 70 [07-18 18:04:53:760 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":302,"data":{"msg":{"candidate":"a=candidate:2077429438 1 UDP 16777215 47.103.17.244 56406 typ relay\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723"}}} [07-18 18:04:53:760 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:760 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:760 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:760 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c510 [07-18 18:04:53:760 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:783 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:783 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:783 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:783 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:783 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:783 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:783 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 71 [07-18 18:04:53:783 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674693,"protocol":302,"data":{"msg":{"candidate":""},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723"}}} [07-18 18:04:53:783 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:783 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:783 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:784 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c470 [07-18 18:04:53:784 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:806 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:882 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65538] higcmd [100] low cmd[12] [07-18 18:04:53:882 TUYA Debug][tuya_ipc_p2p.c:3082] CTRL PLAY BACK session[65538] high[100] low[12] [07-18 18:04:53:882 TUYA Debug][tuya_ipc_p2p.c:5366] album ipc_sweeper_robot [07-18 18:04:53:882 TUYA Debug][tuya_ipc_p2p.c:3307] query file ok [07-18 18:04:53:921 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:921 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:921 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:53:921 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:53:921 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:53:921 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 72 [07-18 18:04:53:921 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674694,"protocol":302,"data":{"msg":{"handle":1,"seq":4,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552"}}} [07-18 18:04:53:921 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:53:921 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:53:921 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:04:53:921 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c470 [07-18 18:04:53:921 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:04:53:929 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58379 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":1,"error":0,"seq":4}} [07-18 18:04:53:929 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:53:945 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:53:974 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65538] higcmd [100] low cmd[13] [07-18 18:04:53:974 TUYA Debug][tuya_ipc_p2p.c:3082] CTRL PLAY BACK session[65538] high[100] low[13] [07-18 18:04:53:974 TUYA Debug][tuya_ipc_p2p.c:3338] album download info: [07-18 18:04:53:974 TUYA Debug][tuya_ipc_p2p.c:3339] album name:ipc_sweeper_robot [07-18 18:04:53:974 TUYA Debug][tuya_ipc_p2p.c:3342] file map.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_p2p.c:3342] file cleanPath.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_p2p.c:3342] file navPath.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:43] 5 map.bin.stream navPath.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:43] 4 map.bin.stream cleanPath.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:43] 3 map.bin.stream map.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:72] ##fileArrBit 3 set [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:43] 5 cleanPath.bin.stream navPath.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:43] 4 cleanPath.bin.stream cleanPath.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:72] ##fileArrBit 4 set [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:43] 5 navPath.bin.stream navPath.bin.stream [07-18 18:04:53:974 TUYA Debug][tuya_ipc_album_sweeper.c:72] ##fileArrBit 5 set [07-18 18:04:53:975 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:04:53:975 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:04:53:975 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:04:53:975 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:04:53:975 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:04:53:975 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:04:53:999 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58380 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:04:53:999 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:54:18 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:18 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:18 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:18 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:04:54:18 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:1. [07-18 18:04:54:19 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:0. [07-18 18:04:54:19 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:0. [07-18 18:04:54:26 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:04:54:26 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:04:54:26 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:04:54:26 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:04:54:26 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:04:54:26 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:04:54:44 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:51 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58381 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:04:54:51 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:54:82 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:82 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:82 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:82 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:04:54:82 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:2. [07-18 18:04:54:82 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:0. [07-18 18:04:54:82 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:0. [07-18 18:04:54:104 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:108 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:04:54:515 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:515 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:515 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:515 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:04:54:515 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:04:54:515 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 73 [07-18 18:04:54:515 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674694,"protocol":5,"data":{"dps":{"16":"get_both"}}} [07-18 18:04:54:515 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:04:54:515 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:04:54:515 TUYA Trace][mqc_app.c:719] index:2 mq_pro:304 [07-18 18:04:54:515 TUYA Trace][mqc_app.c:719] index:3 mq_pro:307 [07-18 18:04:54:515 TUYA Trace][mqc_app.c:719] index:4 mq_pro:308 [07-18 18:04:54:515 TUYA Trace][mqc_app.c:719] index:5 mq_pro:312 [07-18 18:04:54:515 TUYA Trace][mqc_app.c:719] index:6 mq_pro:5 [07-18 18:04:54:515 TUYA Debug][sf_mqc_cb.c:11] Rev DP Cmd [07-18 18:04:54:515 TUYA Debug][smart_frame.c:1067] Rev Cmd 1, data:0x4c00dbe0 [07-18 18:04:54:523 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f947fe908] len[13] [07-18 18:04:54:523 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:04:54:523 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:04:54:523 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:04:54:523 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:04:54:523 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:04:54:523 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:04:54:541 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:551 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58382 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:04:54:551 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:54:572 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:572 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:572 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:572 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:04:54:572 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:3. [07-18 18:04:54:572 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:0. [07-18 18:04:54:572 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:0. [07-18 18:04:54:572 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:04:54:572 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:04:54:572 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:04:54:579 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:04:54:579 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:04:54:579 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:04:54:597 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:604 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58383 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:04:54:604 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:54:624 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:624 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:624 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:54:624 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:04:54:624 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:4. [07-18 18:04:54:624 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:0. [07-18 18:04:54:624 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674694, rept_cnt:0. [07-18 18:04:54:646 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:54:652 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:04:55:527 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [98000] [07-18 18:04:55:647 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:55:647 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:56:647 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:56:647 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:56:975 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f947fe908] len[13] [07-18 18:04:56:975 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:04:56:975 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:04:56:975 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:04:56:975 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:04:56:975 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:04:56:975 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:04:57:0 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58384 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:04:57:0 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:57:23 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:57:23 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:57:23 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:57:24 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:04:57:24 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674697, rept_cnt:5. [07-18 18:04:57:24 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674697, rept_cnt:0. [07-18 18:04:57:24 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674697, rept_cnt:0. [07-18 18:04:57:24 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:04:57:24 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:04:57:24 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:04:57:30 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:04:57:30 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:04:57:31 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:04:57:49 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:57:57 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58385 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:04:57:57 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:04:57:76 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:57:76 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:57:76 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:04:57:76 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:04:57:76 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674697, rept_cnt:6. [07-18 18:04:57:76 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674697, rept_cnt:0. [07-18 18:04:57:76 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674697, rept_cnt:0. [07-18 18:04:57:99 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:57:105 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:04:58:101 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:58:101 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:58:536 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:04:59:95 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[0]lstCnt[86]vIFrameCnt[86] [07-18 18:04:59:102 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:04:59:102 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:04:59:975 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:04:59:975 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:04:59:975 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:04:59:975 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:04:59:975 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:04:59:976 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:04:59:976 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f947fe908] len[13] [07-18 18:04:59:999 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58386 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:04:59:999 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:00:23 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:00:23 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:00:23 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:00:23 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:05:00:23 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674700, rept_cnt:7. [07-18 18:05:00:23 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674700, rept_cnt:0. [07-18 18:05:00:23 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674700, rept_cnt:0. [07-18 18:05:00:24 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:00:24 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:00:24 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:00:31 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:00:31 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:05:00:31 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:05:00:48 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:00:56 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58387 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:05:00:56 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:00:75 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:00:76 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:00:76 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:00:76 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:05:00:76 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674700, rept_cnt:8. [07-18 18:05:00:76 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674700, rept_cnt:0. [07-18 18:05:00:76 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674700, rept_cnt:0. [07-18 18:05:00:98 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:00:105 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:05:00:641 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [99000] [07-18 18:05:01:99 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:01:99 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:01:389 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:01:389 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:01:389 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:01:389 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:05:01:389 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:05:01:389 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 74 [07-18 18:05:01:389 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674701,"protocol":5,"data":{"dps":{"4":"select_room"}}} [07-18 18:05:01:389 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:05:01:389 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:05:01:389 TUYA Trace][mqc_app.c:719] index:2 mq_pro:304 [07-18 18:05:01:389 TUYA Trace][mqc_app.c:719] index:3 mq_pro:307 [07-18 18:05:01:389 TUYA Trace][mqc_app.c:719] index:4 mq_pro:308 [07-18 18:05:01:389 TUYA Trace][mqc_app.c:719] index:5 mq_pro:312 [07-18 18:05:01:389 TUYA Trace][mqc_app.c:719] index:6 mq_pro:5 [07-18 18:05:01:389 TUYA Debug][sf_mqc_cb.c:11] Rev DP Cmd [07-18 18:05:01:389 TUYA Debug][smart_frame.c:1067] Rev Cmd 1, data:0x4c00dbe0 [07-18 18:05:01:413 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:01:413 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:01:413 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:01:413 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:01:413 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:05:01:413 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:05:01:413 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 75 [07-18 18:05:01:413 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674701,"protocol":5,"data":{"dps":{"15":"qgAEFAEBFiw="}}} [07-18 18:05:01:413 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:05:01:413 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:05:01:413 TUYA Trace][mqc_app.c:719] index:2 mq_pro:304 [07-18 18:05:01:413 TUYA Trace][mqc_app.c:719] index:3 mq_pro:307 [07-18 18:05:01:413 TUYA Trace][mqc_app.c:719] index:4 mq_pro:308 [07-18 18:05:01:413 TUYA Trace][mqc_app.c:719] index:5 mq_pro:312 [07-18 18:05:01:414 TUYA Trace][mqc_app.c:719] index:6 mq_pro:5 [07-18 18:05:01:414 TUYA Debug][sf_mqc_cb.c:11] Rev DP Cmd [07-18 18:05:01:414 TUYA Debug][smart_frame.c:1067] Rev Cmd 1, data:0x4c00dbe0 [07-18 18:05:01:421 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:01:421 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:353] dp<7> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:369] dp_cntl value:0, dp_data value:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:450] is_need_update:0, is_dp_passive:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:507] obj dp rept filtered:7 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:552] no vaild dp to rept [07-18 18:05:01:421 TUYA Debug][smart_frame.c:3421] dp compose null, ret:-3585 [07-18 18:05:01:421 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:01:421 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:353] dp<6> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:369] dp_cntl value:0, dp_data value:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:450] is_need_update:0, is_dp_passive:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:507] obj dp rept filtered:6 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:552] no vaild dp to rept [07-18 18:05:01:421 TUYA Debug][smart_frame.c:3421] dp compose null, ret:-3585 [07-18 18:05:01:421 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:01:421 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:01:421 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgAEFQEBFi0="}, retrans:1 [07-18 18:05:01:422 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgAEFQEBFi0="} [07-18 18:05:01:438 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:01:448 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58388 Q:1 Data:{"dps":{"15":"qgAEFQEBFi0="}} [07-18 18:05:01:448 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:01:475 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:01:475 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:01:475 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:01:475 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:05:01:475 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674701, rept_cnt:9. [07-18 18:05:01:475 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674701, rept_cnt:0. [07-18 18:05:01:475 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674701, rept_cnt:0. [07-18 18:05:01:497 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:02:498 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:02:498 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:02:975 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f947fe908] len[13] [07-18 18:05:03:499 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:03:499 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:04:105 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:05:04:106 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:05:04:106 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:33 [07-18 18:05:04:499 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:04:499 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:05:146 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:05:146 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:05:146 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:05:146 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:05:05:146 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:05:05:146 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 76 [07-18 18:05:05:146 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674705,"protocol":5,"data":{"dps":{"4":"smart","1":true}}} [07-18 18:05:05:146 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:05:05:146 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:05:05:146 TUYA Trace][mqc_app.c:719] index:2 mq_pro:304 [07-18 18:05:05:146 TUYA Trace][mqc_app.c:719] index:3 mq_pro:307 [07-18 18:05:05:146 TUYA Trace][mqc_app.c:719] index:4 mq_pro:308 [07-18 18:05:05:146 TUYA Trace][mqc_app.c:719] index:5 mq_pro:312 [07-18 18:05:05:146 TUYA Trace][mqc_app.c:719] index:6 mq_pro:5 [07-18 18:05:05:146 TUYA Debug][sf_mqc_cb.c:11] Rev DP Cmd [07-18 18:05:05:147 TUYA Debug][smart_frame.c:1067] Rev Cmd 1, data:0x4c00dbe0 [07-18 18:05:05:170 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:05:753 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [100000] [07-18 18:05:05:873 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:05:873 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:05:873 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:05:873 TUYA Debug][smart_frame.c:353] dp<1> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:05:873 TUYA Debug][smart_frame.c:357] dp_cntl bool:0, dp_data bool:1 [07-18 18:05:05:873 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:05:873 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"1":true} [07-18 18:05:05:897 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58389 Q:1 Data:{"dps":{"1":true}} [07-18 18:05:05:897 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:05:897 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:05:897 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:05:897 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:05:897 TUYA Debug][smart_frame.c:353] dp<4> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:05:897 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:05:897 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"4":"smart"} [07-18 18:05:05:916 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:05:916 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:05:916 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:05:916 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 18:05:05:916 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"1":true}}, mqtt async dp cb:0 [07-18 18:05:05:916 TUYA Trace][smart_frame.c:2512] DP ID 1 Set To 3 [07-18 18:05:05:916 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:1, curr_t:1689674705, rept_cnt:1. [07-18 18:05:05:917 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:1, curr_t:1689674705, rept_cnt:0. [07-18 18:05:05:917 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:1, curr_t:1689674705, rept_cnt:0. [07-18 18:05:05:955 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58390 Q:1 Data:{"dps":{"4":"smart"}} [07-18 18:05:05:955 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:05:956 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:05:956 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:05:956 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:05:956 TUYA Debug][smart_frame.c:353] dp<5> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:05:956 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:05:956 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"5":"smart"} [07-18 18:05:05:965 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:05:978 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:05:978 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:05:978 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:05:978 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 18:05:05:978 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"4":"smart"}}, mqtt async dp cb:0 [07-18 18:05:05:978 TUYA Trace][smart_frame.c:2512] DP ID 4 Set To 3 [07-18 18:05:05:978 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:4, curr_t:1689674705, rept_cnt:1. [07-18 18:05:05:978 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:4, curr_t:1689674705, rept_cnt:0. [07-18 18:05:05:978 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:4, curr_t:1689674705, rept_cnt:0. [07-18 18:05:05:990 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58391 Q:1 Data:{"dps":{"5":"smart"}} [07-18 18:05:05:990 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:05:992 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:05:992 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:05:992 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:05:992 TUYA Debug][smart_frame.c:353] dp<28> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:05:992 TUYA Debug][smart_frame.c:450] is_need_update:0, is_dp_passive:0 [07-18 18:05:05:992 TUYA Debug][smart_frame.c:507] obj dp rept filtered:28 [07-18 18:05:05:992 TUYA Debug][smart_frame.c:552] no vaild dp to rept [07-18 18:05:05:992 TUYA Debug][smart_frame.c:3421] dp compose null, ret:-3585 [07-18 18:05:05:992 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:05:992 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:05:992 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:05:992 TUYA Err][smart_frame.c:498] dparr[0] type not match:3 0 [07-18 18:05:05:992 TUYA Debug][smart_frame.c:3421] dp compose null, ret:-3586 [07-18 18:05:05:992 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:05:993 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:05:993 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:05:993 TUYA Err][smart_frame.c:498] dparr[0] type not match:3 0 [07-18 18:05:05:993 TUYA Debug][smart_frame.c:3421] dp compose null, ret:-3586 [07-18 18:05:05:993 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:05:994 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:05:994 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:05:994 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:05:994 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:05:05:994 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:05:06:8 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:06:24 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58392 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:05:06:24 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:06:27 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:06:27 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:06:27 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:06:27 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 18:05:06:27 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"5":"smart"}}, mqtt async dp cb:0 [07-18 18:05:06:27 TUYA Trace][smart_frame.c:2512] DP ID 5 Set To 3 [07-18 18:05:06:27 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:5, curr_t:1689674706, rept_cnt:1. [07-18 18:05:06:27 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:5, curr_t:1689674706, rept_cnt:0. [07-18 18:05:06:27 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:5, curr_t:1689674706, rept_cnt:0. [07-18 18:05:06:51 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:06:51 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:06:51 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:06:51 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:06:52 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:05:06:52 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674706, rept_cnt:10. [07-18 18:05:06:52 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674706, rept_cnt:0. [07-18 18:05:06:52 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674706, rept_cnt:0. [07-18 18:05:06:52 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:06:52 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:06:52 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:06:59 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:06:59 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:05:06:59 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:05:06:78 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:06:84 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58393 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:05:06:84 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:06:107 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:06:107 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:06:107 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:06:107 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:05:06:107 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674706, rept_cnt:11. [07-18 18:05:06:107 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674706, rept_cnt:0. [07-18 18:05:06:107 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674706, rept_cnt:0. [07-18 18:05:06:128 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:05:06:128 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f947fe908] len[13] [07-18 18:05:06:130 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:06:576 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:06:576 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:353] dp<4> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:450] is_need_update:0, is_dp_passive:0 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:507] obj dp rept filtered:4 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:552] no vaild dp to rept [07-18 18:05:06:576 TUYA Debug][smart_frame.c:3421] dp compose null, ret:-3585 [07-18 18:05:06:576 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:06:576 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:353] dp<5> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:06:576 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"5":"22"} [07-18 18:05:06:600 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58394 Q:1 Data:{"dps":{"5":"22"}} [07-18 18:05:06:600 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:06:601 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:06:601 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:06:601 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:06:601 TUYA Debug][smart_frame.c:353] dp<28> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:06:601 TUYA Debug][smart_frame.c:450] is_need_update:0, is_dp_passive:0 [07-18 18:05:06:601 TUYA Debug][smart_frame.c:507] obj dp rept filtered:28 [07-18 18:05:06:601 TUYA Debug][smart_frame.c:552] no vaild dp to rept [07-18 18:05:06:601 TUYA Debug][smart_frame.c:3421] dp compose null, ret:-3585 [07-18 18:05:06:620 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:06:620 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:06:620 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:06:620 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 18:05:06:620 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"5":"22"}}, mqtt async dp cb:0 [07-18 18:05:06:621 TUYA Trace][smart_frame.c:2512] DP ID 5 Set To 3 [07-18 18:05:06:621 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:5, curr_t:1689674706, rept_cnt:2. [07-18 18:05:06:621 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:5, curr_t:1689674706, rept_cnt:0. [07-18 18:05:06:621 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:5, curr_t:1689674706, rept_cnt:0. [07-18 18:05:06:644 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:07:645 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:07:645 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:08:542 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:05:08:646 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:08:646 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:09:108 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[0]lstCnt[145]vIFrameCnt[145] [07-18 18:05:09:647 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:09:647 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:09:931 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:09:931 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:09:931 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:09:932 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:05:09:932 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:05:09:932 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 77 [07-18 18:05:09:932 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674710,"protocol":302,"data":{"msg":{"handle":2,"seq":5},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"activate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674710077"}}} [07-18 18:05:09:932 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:05:09:932 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:05:09:932 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:05:09:932 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c500 [07-18 18:05:09:932 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:05:09:940 TUYA Debug][tuya_ipc_p2p.c:4512] listen ok session[131073] [07-18 18:05:09:940 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58395 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"activate_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":2,"error":0,"seq":5}} [07-18 18:05:09:942 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:09:956 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:09:970 TUYA Debug][tuya_ipc_p2p.c:3987] compare passwd [07-18 18:05:09:970 TUYA Debug][tuya_ipc_p2p.c:3988] get ipc auth gw_local_key[Mro9dY$MHLv!DTHz]p2p_passwd[adb63309] [07-18 18:05:09:970 TUYA Debug][tuya_ipc_p2p.c:4006] Client Auth admin efa628a6c8b8f6f591f69df58cfba471 <-> admin adb63309 [07-18 18:05:09:970 TUYA Debug][tuya_ipc_p2p.c:4007] localkey:Mro9dY$MHLv!DTHz final:efa628a6c8b8f6f591f69df58cfba471 [07-18 18:05:09:970 TUYA Debug][tuya_ipc_p2p.c:4010] auth success [07-18 18:05:09:970 TUYA Debug][tuya_ipc_p2p.c:592] __p2p_get_idle_session begin [07-18 18:05:09:970 TUYA Debug][tuya_ipc_p2p.c:4624] create p2p sessions. cur online session num = 2 [07-18 18:05:09:970 TUYA Debug][tuya_ipc_p2p.c:4445] mqtt p2p LISTEN session........ [07-18 18:05:10:9 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [10] low cmd[0] [07-18 18:05:10:69 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [2] low cmd[0] [07-18 18:05:10:130 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [9] low cmd[0] [07-18 18:05:10:190 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [9] low cmd[0] [07-18 18:05:10:251 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [6] low cmd[0] [07-18 18:05:10:251 TUYA Debug][tuya_ipc_p2p.c:1911] open ringbuff handle[(nil)] stream[0] [07-18 18:05:10:251 TUYA Debug][tuya_ipc_p2p.c:1946] session[131073]video video_start wait_concurr_idle [07-18 18:05:10:251 TUYA Debug][tuya_ipc_p2p.c:5134] session[131073] __p2p_wait_concurr_idle start [07-18 18:05:10:281 TUYA Debug][tuya_ipc_p2p.c:5151] session[131073] concurr idle[2][2] [07-18 18:05:10:281 TUYA Debug][tuya_ipc_p2p.c:5157] session[131073] __p2p_wait_concurr_idle end [07-18 18:05:10:281 TUYA Debug][tuya_ipc_p2p.c:1978] session[131073] [1] send video start to dev [07-18 18:05:10:282 TUYA Debug][tuya_ipc_p2p.c:1984] session video start[131073] [07-18 18:05:10:282 TUYA Debug][linkbey_sdk_v11.cpp:573] start live video using /oem/ros_file/demo7_video.264 [07-18 18:05:10:282 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:9133242 ts:0 [07-18 18:05:10:282 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:9133242 [07-18 18:05:10:282 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:250696 dataSize:12088 [07-18 18:05:10:282 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:274 timestamp:1689674710282 [07-18 18:05:10:282 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:9133242 ts:0 [07-18 18:05:10:282 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:9133242 [07-18 18:05:10:282 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:250696 dataSize:12088 [07-18 18:05:10:282 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:274 timestamp:1689674710282 [07-18 18:05:10:284 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:284 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 0 node index 0, head index 274 [07-18 18:05:10:284 TUYA Trace][tuya_ring_buffer.c:800] get latest frame node type 1 [07-18 18:05:10:284 TUYA Debug][tuya_ring_buffer.c:806] get latest I frame success, node 274 seqNo 274 ch0st0tr0 [07-18 18:05:10:284 TUYA Debug][tuya_ipc_p2p.c:4169] session[131073] I Frame Send ok len[12088] pts[9133242] count[1]timestamp[1689674710282] [07-18 18:05:10:284 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:284 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 274, head index 274 [07-18 18:05:10:294 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:294 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 274, head index 274 [07-18 18:05:10:305 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:305 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 274, head index 274 [07-18 18:05:10:315 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:315 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 274, head index 274 [07-18 18:05:10:315 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:9166575 ts:0 [07-18 18:05:10:315 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:9166575 [07-18 18:05:10:315 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:262784 dataSize:1051 [07-18 18:05:10:315 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:275 timestamp:1689674710315 [07-18 18:05:10:315 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:9166575 ts:0 [07-18 18:05:10:316 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:9166575 [07-18 18:05:10:316 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:262784 dataSize:1051 [07-18 18:05:10:316 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:275 timestamp:1689674710316 [07-18 18:05:10:325 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:325 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 274, head index 275 [07-18 18:05:10:325 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 275, seqNo 275, timestamp 1689674710315 [07-18 18:05:10:325 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:325 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 275, head index 275 [07-18 18:05:10:335 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:335 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 275, head index 275 [07-18 18:05:10:342 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [6] low cmd[4] [07-18 18:05:10:342 TUYA Debug][tuya_ipc_p2p.c:2041] session[131073] [1] send audio start to dev [07-18 18:05:10:345 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:345 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 275, head index 275 [07-18 18:05:10:349 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:9199908 ts:0 [07-18 18:05:10:349 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:9199908 [07-18 18:05:10:349 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:263835 dataSize:209 [07-18 18:05:10:349 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:276 timestamp:1689674710349 [07-18 18:05:10:349 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:9199908 ts:0 [07-18 18:05:10:349 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:9199908 [07-18 18:05:10:349 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:263835 dataSize:209 [07-18 18:05:10:349 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:276 timestamp:1689674710349 [07-18 18:05:10:356 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:10:383 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:9233241 ts:0 [07-18 18:05:10:383 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:9233241 [07-18 18:05:10:383 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:264044 dataSize:118 [07-18 18:05:10:383 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:277 timestamp:1689674710383 [07-18 18:05:10:383 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:9233241 ts:0 [07-18 18:05:10:383 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:9233241 [07-18 18:05:10:383 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:264044 dataSize:118 [07-18 18:05:10:383 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:277 timestamp:1689674710383 [07-18 18:05:10:403 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [5] low cmd[0] [07-18 18:05:10:416 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:9266574 ts:0 [07-18 18:05:10:416 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:9266574 [07-18 18:05:10:416 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:264162 dataSize:110 [07-18 18:05:10:416 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:278 timestamp:1689674710416 [07-18 18:05:10:416 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:9266574 ts:0 [07-18 18:05:10:417 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:9266574 [07-18 18:05:10:417 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:264162 dataSize:110 [07-18 18:05:10:417 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:278 timestamp:1689674710417 [07-18 18:05:10:450 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:9299907 ts:0 [07-18 18:05:10:450 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:9299907 [07-18 18:05:10:450 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:264272 dataSize:695 [07-18 18:05:10:450 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:279 timestamp:1689674710450 [07-18 18:05:10:450 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:9299907 ts:0 [07-18 18:05:10:450 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:9299907 [07-18 18:05:10:450 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:264272 dataSize:695 [07-18 18:05:10:450 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:279 timestamp:1689674710450 [07-18 18:05:10:466 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:466 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 275, head index 279 [07-18 18:05:10:466 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 276, seqNo 276, timestamp 1689674710349 [07-18 18:05:10:466 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:10:484 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:9333240 ts:0 [07-18 18:05:10:484 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:9333240 [07-18 18:05:10:484 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:264967 dataSize:1146 [07-18 18:05:10:484 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:280 timestamp:1689674710484 [07-18 18:05:10:484 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:9333240 ts:0 [07-18 18:05:10:484 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:9333240 [07-18 18:05:10:484 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:264967 dataSize:1146 [07-18 18:05:10:484 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:280 timestamp:1689674710484 [07-18 18:05:10:517 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:9366573 ts:0 [07-18 18:05:10:517 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:9366573 [07-18 18:05:10:517 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:266113 dataSize:276 [07-18 18:05:10:517 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:281 timestamp:1689674710517 [07-18 18:05:10:517 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:9366573 ts:0 [07-18 18:05:10:517 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:9366573 [07-18 18:05:10:517 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:266113 dataSize:276 [07-18 18:05:10:517 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:281 timestamp:1689674710517 [07-18 18:05:10:551 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:9399906 ts:0 [07-18 18:05:10:551 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:9399906 [07-18 18:05:10:551 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:266389 dataSize:152 [07-18 18:05:10:551 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:282 timestamp:1689674710551 [07-18 18:05:10:551 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:9399906 ts:0 [07-18 18:05:10:551 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:9399906 [07-18 18:05:10:551 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:266389 dataSize:152 [07-18 18:05:10:551 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:282 timestamp:1689674710551 [07-18 18:05:10:576 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:576 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 276, head index 282 [07-18 18:05:10:576 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 277, seqNo 277, timestamp 1689674710383 [07-18 18:05:10:576 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:10:585 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:9433239 ts:0 [07-18 18:05:10:585 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:9433239 [07-18 18:05:10:585 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:266541 dataSize:136 [07-18 18:05:10:585 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:283 timestamp:1689674710585 [07-18 18:05:10:585 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:9433239 ts:0 [07-18 18:05:10:585 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:9433239 [07-18 18:05:10:585 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:266541 dataSize:136 [07-18 18:05:10:585 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:283 timestamp:1689674710585 [07-18 18:05:10:618 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:9466572 ts:0 [07-18 18:05:10:618 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:9466572 [07-18 18:05:10:618 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:266677 dataSize:725 [07-18 18:05:10:618 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:284 timestamp:1689674710618 [07-18 18:05:10:618 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:9466572 ts:0 [07-18 18:05:10:618 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:9466572 [07-18 18:05:10:618 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:266677 dataSize:725 [07-18 18:05:10:618 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:284 timestamp:1689674710618 [07-18 18:05:10:652 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:9499905 ts:0 [07-18 18:05:10:652 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:9499905 [07-18 18:05:10:652 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:267402 dataSize:1369 [07-18 18:05:10:652 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:285 timestamp:1689674710652 [07-18 18:05:10:652 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:9499905 ts:0 [07-18 18:05:10:652 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:9499905 [07-18 18:05:10:652 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:267402 dataSize:1369 [07-18 18:05:10:652 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:285 timestamp:1689674710652 [07-18 18:05:10:685 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:9533238 ts:0 [07-18 18:05:10:686 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:9533238 [07-18 18:05:10:686 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:268771 dataSize:367 [07-18 18:05:10:686 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:286 timestamp:1689674710686 [07-18 18:05:10:686 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:9533238 ts:0 [07-18 18:05:10:686 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:9533238 [07-18 18:05:10:686 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:268771 dataSize:367 [07-18 18:05:10:686 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:286 timestamp:1689674710686 [07-18 18:05:10:686 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:686 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 277, head index 286 [07-18 18:05:10:686 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 278, seqNo 278, timestamp 1689674710416 [07-18 18:05:10:686 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:10:719 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:9566571 ts:0 [07-18 18:05:10:719 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:9566571 [07-18 18:05:10:719 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:269138 dataSize:141 [07-18 18:05:10:719 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:287 timestamp:1689674710719 [07-18 18:05:10:719 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:9566571 ts:0 [07-18 18:05:10:719 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:9566571 [07-18 18:05:10:719 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:269138 dataSize:141 [07-18 18:05:10:719 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:287 timestamp:1689674710719 [07-18 18:05:10:753 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:9599904 ts:0 [07-18 18:05:10:753 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:9599904 [07-18 18:05:10:753 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:269279 dataSize:160 [07-18 18:05:10:753 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:288 timestamp:1689674710753 [07-18 18:05:10:753 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:9599904 ts:0 [07-18 18:05:10:753 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:9599904 [07-18 18:05:10:753 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:269279 dataSize:160 [07-18 18:05:10:753 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:288 timestamp:1689674710753 [07-18 18:05:10:786 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:9633237 ts:0 [07-18 18:05:10:786 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:9633237 [07-18 18:05:10:786 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:269439 dataSize:756 [07-18 18:05:10:786 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:289 timestamp:1689674710786 [07-18 18:05:10:786 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:9633237 ts:0 [07-18 18:05:10:786 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:9633237 [07-18 18:05:10:786 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:269439 dataSize:756 [07-18 18:05:10:786 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:289 timestamp:1689674710786 [07-18 18:05:10:797 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:797 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 278, head index 289 [07-18 18:05:10:797 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 279, seqNo 279, timestamp 1689674710450 [07-18 18:05:10:797 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:10:820 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:9666570 ts:0 [07-18 18:05:10:820 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:9666570 [07-18 18:05:10:820 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:270195 dataSize:1610 [07-18 18:05:10:820 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:290 timestamp:1689674710820 [07-18 18:05:10:820 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:9666570 ts:0 [07-18 18:05:10:820 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:9666570 [07-18 18:05:10:820 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:270195 dataSize:1610 [07-18 18:05:10:820 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:290 timestamp:1689674710820 [07-18 18:05:10:854 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:9699903 ts:0 [07-18 18:05:10:854 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:9699903 [07-18 18:05:10:854 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:271805 dataSize:516 [07-18 18:05:10:854 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:291 timestamp:1689674710854 [07-18 18:05:10:854 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:9699903 ts:0 [07-18 18:05:10:854 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:9699903 [07-18 18:05:10:854 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:271805 dataSize:516 [07-18 18:05:10:854 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:291 timestamp:1689674710854 [07-18 18:05:10:887 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:9733236 ts:0 [07-18 18:05:10:887 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:9733236 [07-18 18:05:10:887 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:272321 dataSize:231 [07-18 18:05:10:887 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:292 timestamp:1689674710887 [07-18 18:05:10:887 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:9733236 ts:0 [07-18 18:05:10:888 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:9733236 [07-18 18:05:10:888 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:272321 dataSize:231 [07-18 18:05:10:888 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:292 timestamp:1689674710888 [07-18 18:05:10:907 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:10:907 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 279, head index 292 [07-18 18:05:10:907 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 280, seqNo 280, timestamp 1689674710484 [07-18 18:05:10:907 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:10:921 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:9766569 ts:0 [07-18 18:05:10:921 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:9766569 [07-18 18:05:10:921 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:272552 dataSize:250 [07-18 18:05:10:921 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:293 timestamp:1689674710921 [07-18 18:05:10:921 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:9766569 ts:0 [07-18 18:05:10:921 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:9766569 [07-18 18:05:10:921 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:272552 dataSize:250 [07-18 18:05:10:921 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:293 timestamp:1689674710921 [07-18 18:05:10:955 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:9799902 ts:0 [07-18 18:05:10:955 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:9799902 [07-18 18:05:10:955 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:272802 dataSize:1143 [07-18 18:05:10:955 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:294 timestamp:1689674710955 [07-18 18:05:10:955 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:9799902 ts:0 [07-18 18:05:10:955 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:9799902 [07-18 18:05:10:955 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:272802 dataSize:1143 [07-18 18:05:10:955 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:294 timestamp:1689674710955 [07-18 18:05:10:956 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:10:956 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:10:988 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:9833235 ts:0 [07-18 18:05:10:988 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:9833235 [07-18 18:05:10:988 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:273945 dataSize:383 [07-18 18:05:10:989 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:295 timestamp:1689674710989 [07-18 18:05:10:989 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:9833235 ts:0 [07-18 18:05:10:989 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:9833235 [07-18 18:05:10:989 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:273945 dataSize:383 [07-18 18:05:10:989 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:295 timestamp:1689674710989 [07-18 18:05:11:17 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:17 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 280, head index 295 [07-18 18:05:11:17 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 281, seqNo 281, timestamp 1689674710517 [07-18 18:05:11:17 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:22 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:9866568 ts:0 [07-18 18:05:11:22 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:9866568 [07-18 18:05:11:22 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:274328 dataSize:235 [07-18 18:05:11:22 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:296 timestamp:1689674711022 [07-18 18:05:11:22 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:9866568 ts:0 [07-18 18:05:11:22 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:9866568 [07-18 18:05:11:22 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:274328 dataSize:235 [07-18 18:05:11:22 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:296 timestamp:1689674711022 [07-18 18:05:11:56 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:9899901 ts:0 [07-18 18:05:11:56 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:9899901 [07-18 18:05:11:56 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:274563 dataSize:165 [07-18 18:05:11:56 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:297 timestamp:1689674711056 [07-18 18:05:11:56 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:9899901 ts:0 [07-18 18:05:11:56 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:9899901 [07-18 18:05:11:56 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:274563 dataSize:165 [07-18 18:05:11:56 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:297 timestamp:1689674711056 [07-18 18:05:11:89 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:9933234 ts:0 [07-18 18:05:11:89 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:9933234 [07-18 18:05:11:89 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:274728 dataSize:457 [07-18 18:05:11:89 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:298 timestamp:1689674711089 [07-18 18:05:11:89 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:9933234 ts:0 [07-18 18:05:11:90 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:9933234 [07-18 18:05:11:90 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:274728 dataSize:457 [07-18 18:05:11:90 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:298 timestamp:1689674711090 [07-18 18:05:11:123 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:9966567 ts:0 [07-18 18:05:11:123 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:9966567 [07-18 18:05:11:123 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:275185 dataSize:673 [07-18 18:05:11:123 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:299 timestamp:1689674711123 [07-18 18:05:11:123 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:9966567 ts:0 [07-18 18:05:11:123 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:9966567 [07-18 18:05:11:123 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:275185 dataSize:673 [07-18 18:05:11:123 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:299 timestamp:1689674711123 [07-18 18:05:11:127 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:127 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 281, head index 299 [07-18 18:05:11:127 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 282, seqNo 282, timestamp 1689674710551 [07-18 18:05:11:128 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:157 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:9999900 ts:0 [07-18 18:05:11:157 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:9999900 [07-18 18:05:11:157 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:275858 dataSize:465 [07-18 18:05:11:157 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:0 timestamp:1689674711157 [07-18 18:05:11:157 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:9999900 ts:0 [07-18 18:05:11:157 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:9999900 [07-18 18:05:11:157 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:275858 dataSize:465 [07-18 18:05:11:157 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:0 timestamp:1689674711157 [07-18 18:05:11:190 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:10033233 ts:0 [07-18 18:05:11:190 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:10033233 [07-18 18:05:11:190 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:276323 dataSize:248 [07-18 18:05:11:190 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:1 timestamp:1689674711190 [07-18 18:05:11:190 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:10033233 ts:0 [07-18 18:05:11:190 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:10033233 [07-18 18:05:11:190 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:276323 dataSize:248 [07-18 18:05:11:191 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:1 timestamp:1689674711191 [07-18 18:05:11:224 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:10066566 ts:0 [07-18 18:05:11:224 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:10066566 [07-18 18:05:11:224 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:276571 dataSize:217 [07-18 18:05:11:224 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:2 timestamp:1689674711224 [07-18 18:05:11:224 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:10066566 ts:0 [07-18 18:05:11:224 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:10066566 [07-18 18:05:11:224 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:276571 dataSize:217 [07-18 18:05:11:224 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:2 timestamp:1689674711224 [07-18 18:05:11:238 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:238 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 282, head index 2 [07-18 18:05:11:238 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 283, seqNo 283, timestamp 1689674710585 [07-18 18:05:11:238 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:258 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:10099899 ts:0 [07-18 18:05:11:258 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:10099899 [07-18 18:05:11:258 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:276788 dataSize:280 [07-18 18:05:11:258 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:3 timestamp:1689674711258 [07-18 18:05:11:258 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:10099899 ts:0 [07-18 18:05:11:258 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:10099899 [07-18 18:05:11:258 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:276788 dataSize:280 [07-18 18:05:11:258 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:3 timestamp:1689674711258 [07-18 18:05:11:292 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:10133232 ts:0 [07-18 18:05:11:292 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:10133232 [07-18 18:05:11:292 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:277068 dataSize:12088 [07-18 18:05:11:292 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:4 timestamp:1689674711292 [07-18 18:05:11:292 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:10133232 ts:0 [07-18 18:05:11:292 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:10133232 [07-18 18:05:11:292 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:277068 dataSize:12088 [07-18 18:05:11:292 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:4 timestamp:1689674711292 [07-18 18:05:11:325 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:10166565 ts:0 [07-18 18:05:11:325 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:10166565 [07-18 18:05:11:325 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:289156 dataSize:1051 [07-18 18:05:11:325 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:5 timestamp:1689674711325 [07-18 18:05:11:325 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:10166565 ts:0 [07-18 18:05:11:325 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:10166565 [07-18 18:05:11:325 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:289156 dataSize:1051 [07-18 18:05:11:325 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:5 timestamp:1689674711325 [07-18 18:05:11:348 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:348 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 283, head index 5 [07-18 18:05:11:348 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 284, seqNo 284, timestamp 1689674710618 [07-18 18:05:11:348 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:359 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:10199898 ts:0 [07-18 18:05:11:359 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:10199898 [07-18 18:05:11:359 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:290207 dataSize:209 [07-18 18:05:11:359 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:6 timestamp:1689674711359 [07-18 18:05:11:359 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:10199898 ts:0 [07-18 18:05:11:359 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:10199898 [07-18 18:05:11:359 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:290207 dataSize:209 [07-18 18:05:11:359 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:6 timestamp:1689674711359 [07-18 18:05:11:393 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:10233231 ts:0 [07-18 18:05:11:393 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:10233231 [07-18 18:05:11:393 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:290416 dataSize:118 [07-18 18:05:11:393 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:7 timestamp:1689674711393 [07-18 18:05:11:393 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:10233231 ts:0 [07-18 18:05:11:393 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:10233231 [07-18 18:05:11:393 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:290416 dataSize:118 [07-18 18:05:11:393 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:7 timestamp:1689674711393 [07-18 18:05:11:426 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:10266564 ts:0 [07-18 18:05:11:426 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:10266564 [07-18 18:05:11:426 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:290534 dataSize:110 [07-18 18:05:11:426 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:8 timestamp:1689674711426 [07-18 18:05:11:426 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:10266564 ts:0 [07-18 18:05:11:426 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:10266564 [07-18 18:05:11:426 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:290534 dataSize:110 [07-18 18:05:11:426 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:8 timestamp:1689674711426 [07-18 18:05:11:458 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:458 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 284, head index 8 [07-18 18:05:11:458 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 285, seqNo 285, timestamp 1689674710652 [07-18 18:05:11:458 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:460 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:10299897 ts:0 [07-18 18:05:11:460 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:10299897 [07-18 18:05:11:460 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:290644 dataSize:695 [07-18 18:05:11:460 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:9 timestamp:1689674711460 [07-18 18:05:11:460 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:10299897 ts:0 [07-18 18:05:11:460 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:10299897 [07-18 18:05:11:460 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:290644 dataSize:695 [07-18 18:05:11:460 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:9 timestamp:1689674711460 [07-18 18:05:11:493 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:10333230 ts:0 [07-18 18:05:11:494 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:10333230 [07-18 18:05:11:494 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:291339 dataSize:1146 [07-18 18:05:11:494 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:10 timestamp:1689674711494 [07-18 18:05:11:494 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:10333230 ts:0 [07-18 18:05:11:494 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:10333230 [07-18 18:05:11:494 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:291339 dataSize:1146 [07-18 18:05:11:494 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:10 timestamp:1689674711494 [07-18 18:05:11:527 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:10366563 ts:0 [07-18 18:05:11:527 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:10366563 [07-18 18:05:11:527 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:292485 dataSize:276 [07-18 18:05:11:527 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:11 timestamp:1689674711527 [07-18 18:05:11:527 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:10366563 ts:0 [07-18 18:05:11:527 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:10366563 [07-18 18:05:11:527 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:292485 dataSize:276 [07-18 18:05:11:527 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:11 timestamp:1689674711527 [07-18 18:05:11:561 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:10399896 ts:0 [07-18 18:05:11:561 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:10399896 [07-18 18:05:11:561 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:292761 dataSize:152 [07-18 18:05:11:561 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:12 timestamp:1689674711561 [07-18 18:05:11:561 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:10399896 ts:0 [07-18 18:05:11:561 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:10399896 [07-18 18:05:11:561 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:292761 dataSize:152 [07-18 18:05:11:561 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:12 timestamp:1689674711561 [07-18 18:05:11:569 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:569 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 285, head index 12 [07-18 18:05:11:569 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 286, seqNo 286, timestamp 1689674710686 [07-18 18:05:11:569 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:594 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:10433229 ts:0 [07-18 18:05:11:594 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:10433229 [07-18 18:05:11:594 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:292913 dataSize:136 [07-18 18:05:11:594 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:13 timestamp:1689674711594 [07-18 18:05:11:594 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:10433229 ts:0 [07-18 18:05:11:594 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:10433229 [07-18 18:05:11:595 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:292913 dataSize:136 [07-18 18:05:11:595 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:13 timestamp:1689674711595 [07-18 18:05:11:628 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:10466562 ts:0 [07-18 18:05:11:628 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:10466562 [07-18 18:05:11:628 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:293049 dataSize:725 [07-18 18:05:11:628 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:14 timestamp:1689674711628 [07-18 18:05:11:628 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:10466562 ts:0 [07-18 18:05:11:628 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:10466562 [07-18 18:05:11:628 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:293049 dataSize:725 [07-18 18:05:11:628 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:14 timestamp:1689674711628 [07-18 18:05:11:662 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:10499895 ts:0 [07-18 18:05:11:662 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:10499895 [07-18 18:05:11:662 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:293774 dataSize:1369 [07-18 18:05:11:662 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:15 timestamp:1689674711662 [07-18 18:05:11:662 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:10499895 ts:0 [07-18 18:05:11:662 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:10499895 [07-18 18:05:11:662 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:293774 dataSize:1369 [07-18 18:05:11:662 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:15 timestamp:1689674711662 [07-18 18:05:11:679 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:679 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 286, head index 15 [07-18 18:05:11:679 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 287, seqNo 287, timestamp 1689674710719 [07-18 18:05:11:679 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:695 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:10533228 ts:0 [07-18 18:05:11:695 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:10533228 [07-18 18:05:11:695 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:295143 dataSize:367 [07-18 18:05:11:695 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:16 timestamp:1689674711695 [07-18 18:05:11:695 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:10533228 ts:0 [07-18 18:05:11:695 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:10533228 [07-18 18:05:11:695 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:295143 dataSize:367 [07-18 18:05:11:695 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:16 timestamp:1689674711695 [07-18 18:05:11:729 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:10566561 ts:0 [07-18 18:05:11:729 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:10566561 [07-18 18:05:11:729 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:295510 dataSize:141 [07-18 18:05:11:729 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:17 timestamp:1689674711729 [07-18 18:05:11:729 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:10566561 ts:0 [07-18 18:05:11:729 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:10566561 [07-18 18:05:11:729 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:295510 dataSize:141 [07-18 18:05:11:729 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:17 timestamp:1689674711729 [07-18 18:05:11:762 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:10599894 ts:0 [07-18 18:05:11:763 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:10599894 [07-18 18:05:11:763 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:295651 dataSize:160 [07-18 18:05:11:763 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:18 timestamp:1689674711763 [07-18 18:05:11:763 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:10599894 ts:0 [07-18 18:05:11:763 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:10599894 [07-18 18:05:11:763 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:295651 dataSize:160 [07-18 18:05:11:763 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:18 timestamp:1689674711763 [07-18 18:05:11:789 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:790 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 287, head index 18 [07-18 18:05:11:790 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 288, seqNo 288, timestamp 1689674710753 [07-18 18:05:11:790 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:796 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:10633227 ts:0 [07-18 18:05:11:796 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:10633227 [07-18 18:05:11:796 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:295811 dataSize:756 [07-18 18:05:11:796 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:19 timestamp:1689674711796 [07-18 18:05:11:796 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:10633227 ts:0 [07-18 18:05:11:796 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:10633227 [07-18 18:05:11:796 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:295811 dataSize:756 [07-18 18:05:11:796 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:19 timestamp:1689674711796 [07-18 18:05:11:830 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:10666560 ts:0 [07-18 18:05:11:830 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:10666560 [07-18 18:05:11:830 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:296567 dataSize:1610 [07-18 18:05:11:830 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:20 timestamp:1689674711830 [07-18 18:05:11:830 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:10666560 ts:0 [07-18 18:05:11:830 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:10666560 [07-18 18:05:11:830 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:296567 dataSize:1610 [07-18 18:05:11:830 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:20 timestamp:1689674711830 [07-18 18:05:11:863 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:10699893 ts:0 [07-18 18:05:11:863 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:10699893 [07-18 18:05:11:863 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:298177 dataSize:516 [07-18 18:05:11:863 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:21 timestamp:1689674711863 [07-18 18:05:11:863 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:10699893 ts:0 [07-18 18:05:11:863 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:10699893 [07-18 18:05:11:863 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:298177 dataSize:516 [07-18 18:05:11:863 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:21 timestamp:1689674711863 [07-18 18:05:11:897 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:10733226 ts:0 [07-18 18:05:11:897 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:10733226 [07-18 18:05:11:897 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:298693 dataSize:231 [07-18 18:05:11:897 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:22 timestamp:1689674711897 [07-18 18:05:11:897 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:10733226 ts:0 [07-18 18:05:11:897 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:10733226 [07-18 18:05:11:897 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:298693 dataSize:231 [07-18 18:05:11:897 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:22 timestamp:1689674711897 [07-18 18:05:11:900 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:11:900 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 288, head index 22 [07-18 18:05:11:900 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 289, seqNo 289, timestamp 1689674710786 [07-18 18:05:11:900 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:11:931 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:10766559 ts:0 [07-18 18:05:11:931 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:10766559 [07-18 18:05:11:931 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:298924 dataSize:250 [07-18 18:05:11:931 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:23 timestamp:1689674711931 [07-18 18:05:11:931 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:10766559 ts:0 [07-18 18:05:11:931 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:10766559 [07-18 18:05:11:931 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:298924 dataSize:250 [07-18 18:05:11:931 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:23 timestamp:1689674711931 [07-18 18:05:11:957 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:11:957 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:11:964 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:10799892 ts:0 [07-18 18:05:11:964 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:10799892 [07-18 18:05:11:964 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:299174 dataSize:1143 [07-18 18:05:11:964 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:24 timestamp:1689674711964 [07-18 18:05:11:964 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:10799892 ts:0 [07-18 18:05:11:964 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:10799892 [07-18 18:05:11:964 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:299174 dataSize:1143 [07-18 18:05:11:965 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:24 timestamp:1689674711965 [07-18 18:05:11:998 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:10833225 ts:0 [07-18 18:05:11:998 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:10833225 [07-18 18:05:11:998 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:300317 dataSize:383 [07-18 18:05:11:998 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:25 timestamp:1689674711998 [07-18 18:05:11:998 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:10833225 ts:0 [07-18 18:05:11:998 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:10833225 [07-18 18:05:11:998 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:300317 dataSize:383 [07-18 18:05:11:998 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:25 timestamp:1689674711998 [07-18 18:05:12:10 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:10 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 289, head index 25 [07-18 18:05:12:10 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 290, seqNo 290, timestamp 1689674710820 [07-18 18:05:12:10 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:32 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:10866558 ts:0 [07-18 18:05:12:32 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:10866558 [07-18 18:05:12:32 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:300700 dataSize:235 [07-18 18:05:12:32 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:26 timestamp:1689674712032 [07-18 18:05:12:32 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:10866558 ts:0 [07-18 18:05:12:32 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:10866558 [07-18 18:05:12:32 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:300700 dataSize:235 [07-18 18:05:12:32 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:26 timestamp:1689674712032 [07-18 18:05:12:65 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:10899891 ts:0 [07-18 18:05:12:65 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:10899891 [07-18 18:05:12:65 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:300935 dataSize:165 [07-18 18:05:12:65 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:27 timestamp:1689674712065 [07-18 18:05:12:65 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:10899891 ts:0 [07-18 18:05:12:65 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:10899891 [07-18 18:05:12:65 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:300935 dataSize:165 [07-18 18:05:12:65 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:27 timestamp:1689674712065 [07-18 18:05:12:99 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:10933224 ts:0 [07-18 18:05:12:99 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:10933224 [07-18 18:05:12:99 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:301100 dataSize:457 [07-18 18:05:12:99 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:28 timestamp:1689674712099 [07-18 18:05:12:99 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:10933224 ts:0 [07-18 18:05:12:99 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:10933224 [07-18 18:05:12:99 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:301100 dataSize:457 [07-18 18:05:12:99 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:28 timestamp:1689674712099 [07-18 18:05:12:121 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:121 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 290, head index 28 [07-18 18:05:12:121 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 291, seqNo 291, timestamp 1689674710854 [07-18 18:05:12:121 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:132 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:10966557 ts:0 [07-18 18:05:12:132 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:10966557 [07-18 18:05:12:132 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:301557 dataSize:673 [07-18 18:05:12:133 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:29 timestamp:1689674712133 [07-18 18:05:12:133 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:10966557 ts:0 [07-18 18:05:12:133 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:10966557 [07-18 18:05:12:133 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:301557 dataSize:673 [07-18 18:05:12:133 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:29 timestamp:1689674712133 [07-18 18:05:12:166 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:10999890 ts:0 [07-18 18:05:12:166 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:10999890 [07-18 18:05:12:166 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:302230 dataSize:465 [07-18 18:05:12:166 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:30 timestamp:1689674712166 [07-18 18:05:12:166 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:10999890 ts:0 [07-18 18:05:12:166 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:10999890 [07-18 18:05:12:166 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:302230 dataSize:465 [07-18 18:05:12:166 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:30 timestamp:1689674712166 [07-18 18:05:12:200 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:11033223 ts:0 [07-18 18:05:12:200 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:11033223 [07-18 18:05:12:200 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:302695 dataSize:248 [07-18 18:05:12:200 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:31 timestamp:1689674712200 [07-18 18:05:12:200 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:11033223 ts:0 [07-18 18:05:12:200 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:11033223 [07-18 18:05:12:200 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:302695 dataSize:248 [07-18 18:05:12:200 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:31 timestamp:1689674712200 [07-18 18:05:12:231 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:231 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 291, head index 31 [07-18 18:05:12:231 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 292, seqNo 292, timestamp 1689674710887 [07-18 18:05:12:231 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:233 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:11066556 ts:0 [07-18 18:05:12:233 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:11066556 [07-18 18:05:12:233 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:302943 dataSize:217 [07-18 18:05:12:233 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:32 timestamp:1689674712233 [07-18 18:05:12:233 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:11066556 ts:0 [07-18 18:05:12:233 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:11066556 [07-18 18:05:12:234 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:302943 dataSize:217 [07-18 18:05:12:234 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:32 timestamp:1689674712234 [07-18 18:05:12:267 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:11099889 ts:0 [07-18 18:05:12:267 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:11099889 [07-18 18:05:12:267 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:303160 dataSize:280 [07-18 18:05:12:267 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:33 timestamp:1689674712267 [07-18 18:05:12:267 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:11099889 ts:0 [07-18 18:05:12:267 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:11099889 [07-18 18:05:12:267 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:303160 dataSize:280 [07-18 18:05:12:267 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:33 timestamp:1689674712267 [07-18 18:05:12:301 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:11133222 ts:0 [07-18 18:05:12:301 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:11133222 [07-18 18:05:12:301 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:303440 dataSize:12088 [07-18 18:05:12:301 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:34 timestamp:1689674712301 [07-18 18:05:12:301 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:11133222 ts:0 [07-18 18:05:12:301 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:11133222 [07-18 18:05:12:301 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:303440 dataSize:12088 [07-18 18:05:12:301 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:34 timestamp:1689674712301 [07-18 18:05:12:334 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:11166555 ts:0 [07-18 18:05:12:334 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:11166555 [07-18 18:05:12:334 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:315528 dataSize:1051 [07-18 18:05:12:334 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:35 timestamp:1689674712334 [07-18 18:05:12:334 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:11166555 ts:0 [07-18 18:05:12:334 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:11166555 [07-18 18:05:12:334 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:315528 dataSize:1051 [07-18 18:05:12:334 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:35 timestamp:1689674712334 [07-18 18:05:12:341 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:341 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 292, head index 35 [07-18 18:05:12:341 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 293, seqNo 293, timestamp 1689674710921 [07-18 18:05:12:341 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:368 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:11199888 ts:0 [07-18 18:05:12:368 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:11199888 [07-18 18:05:12:368 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:316579 dataSize:209 [07-18 18:05:12:368 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:36 timestamp:1689674712368 [07-18 18:05:12:368 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:11199888 ts:0 [07-18 18:05:12:368 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:11199888 [07-18 18:05:12:368 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:316579 dataSize:209 [07-18 18:05:12:368 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:36 timestamp:1689674712368 [07-18 18:05:12:402 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:11233221 ts:0 [07-18 18:05:12:402 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:11233221 [07-18 18:05:12:402 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:316788 dataSize:118 [07-18 18:05:12:402 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:37 timestamp:1689674712402 [07-18 18:05:12:402 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:11233221 ts:0 [07-18 18:05:12:402 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:11233221 [07-18 18:05:12:402 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:316788 dataSize:118 [07-18 18:05:12:402 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:37 timestamp:1689674712402 [07-18 18:05:12:435 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:11266554 ts:0 [07-18 18:05:12:435 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:11266554 [07-18 18:05:12:435 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:316906 dataSize:110 [07-18 18:05:12:435 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:38 timestamp:1689674712435 [07-18 18:05:12:435 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:11266554 ts:0 [07-18 18:05:12:435 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:11266554 [07-18 18:05:12:435 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:316906 dataSize:110 [07-18 18:05:12:435 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:38 timestamp:1689674712435 [07-18 18:05:12:452 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:452 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 293, head index 38 [07-18 18:05:12:452 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 294, seqNo 294, timestamp 1689674710955 [07-18 18:05:12:452 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:469 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:11299887 ts:0 [07-18 18:05:12:469 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:11299887 [07-18 18:05:12:469 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:317016 dataSize:695 [07-18 18:05:12:469 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:39 timestamp:1689674712469 [07-18 18:05:12:469 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:11299887 ts:0 [07-18 18:05:12:469 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:11299887 [07-18 18:05:12:469 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:317016 dataSize:695 [07-18 18:05:12:469 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:39 timestamp:1689674712469 [07-18 18:05:12:502 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:11333220 ts:0 [07-18 18:05:12:502 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:11333220 [07-18 18:05:12:502 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:317711 dataSize:1146 [07-18 18:05:12:502 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:40 timestamp:1689674712502 [07-18 18:05:12:502 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:11333220 ts:0 [07-18 18:05:12:502 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:11333220 [07-18 18:05:12:502 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:317711 dataSize:1146 [07-18 18:05:12:502 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:40 timestamp:1689674712502 [07-18 18:05:12:536 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:11366553 ts:0 [07-18 18:05:12:536 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:11366553 [07-18 18:05:12:536 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:318857 dataSize:276 [07-18 18:05:12:536 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:41 timestamp:1689674712536 [07-18 18:05:12:536 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:11366553 ts:0 [07-18 18:05:12:536 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:11366553 [07-18 18:05:12:536 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:318857 dataSize:276 [07-18 18:05:12:536 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:41 timestamp:1689674712536 [07-18 18:05:12:562 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:562 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 294, head index 41 [07-18 18:05:12:562 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 295, seqNo 295, timestamp 1689674710989 [07-18 18:05:12:562 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:570 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:11399886 ts:0 [07-18 18:05:12:570 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:11399886 [07-18 18:05:12:570 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:319133 dataSize:152 [07-18 18:05:12:570 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:42 timestamp:1689674712570 [07-18 18:05:12:570 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:11399886 ts:0 [07-18 18:05:12:570 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:11399886 [07-18 18:05:12:570 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:319133 dataSize:152 [07-18 18:05:12:570 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:42 timestamp:1689674712570 [07-18 18:05:12:603 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:11433219 ts:0 [07-18 18:05:12:603 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:11433219 [07-18 18:05:12:603 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:319285 dataSize:136 [07-18 18:05:12:603 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:43 timestamp:1689674712603 [07-18 18:05:12:603 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:11433219 ts:0 [07-18 18:05:12:603 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:11433219 [07-18 18:05:12:603 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:319285 dataSize:136 [07-18 18:05:12:603 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:43 timestamp:1689674712603 [07-18 18:05:12:637 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:11466552 ts:0 [07-18 18:05:12:637 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:11466552 [07-18 18:05:12:637 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:319421 dataSize:725 [07-18 18:05:12:637 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:44 timestamp:1689674712637 [07-18 18:05:12:637 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:11466552 ts:0 [07-18 18:05:12:637 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:11466552 [07-18 18:05:12:637 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:319421 dataSize:725 [07-18 18:05:12:637 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:44 timestamp:1689674712637 [07-18 18:05:12:670 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:11499885 ts:0 [07-18 18:05:12:671 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:11499885 [07-18 18:05:12:671 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:320146 dataSize:1369 [07-18 18:05:12:671 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:45 timestamp:1689674712671 [07-18 18:05:12:671 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:11499885 ts:0 [07-18 18:05:12:671 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:11499885 [07-18 18:05:12:671 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:320146 dataSize:1369 [07-18 18:05:12:671 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:45 timestamp:1689674712671 [07-18 18:05:12:673 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:673 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 295, head index 45 [07-18 18:05:12:673 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 296, seqNo 296, timestamp 1689674711022 [07-18 18:05:12:673 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:704 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:11533218 ts:0 [07-18 18:05:12:704 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:11533218 [07-18 18:05:12:704 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:321515 dataSize:367 [07-18 18:05:12:704 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:46 timestamp:1689674712704 [07-18 18:05:12:704 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:11533218 ts:0 [07-18 18:05:12:704 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:11533218 [07-18 18:05:12:704 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:321515 dataSize:367 [07-18 18:05:12:704 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:46 timestamp:1689674712704 [07-18 18:05:12:738 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:11566551 ts:0 [07-18 18:05:12:738 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:11566551 [07-18 18:05:12:738 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:321882 dataSize:141 [07-18 18:05:12:738 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:47 timestamp:1689674712738 [07-18 18:05:12:738 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:11566551 ts:0 [07-18 18:05:12:738 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:11566551 [07-18 18:05:12:738 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:321882 dataSize:141 [07-18 18:05:12:738 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:47 timestamp:1689674712738 [07-18 18:05:12:771 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:11599884 ts:0 [07-18 18:05:12:771 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:11599884 [07-18 18:05:12:771 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:322023 dataSize:160 [07-18 18:05:12:771 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:48 timestamp:1689674712771 [07-18 18:05:12:771 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:11599884 ts:0 [07-18 18:05:12:771 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:11599884 [07-18 18:05:12:772 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:322023 dataSize:160 [07-18 18:05:12:772 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:48 timestamp:1689674712772 [07-18 18:05:12:783 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:783 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 296, head index 48 [07-18 18:05:12:783 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 297, seqNo 297, timestamp 1689674711056 [07-18 18:05:12:783 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:805 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:11633217 ts:0 [07-18 18:05:12:805 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:11633217 [07-18 18:05:12:805 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:322183 dataSize:756 [07-18 18:05:12:805 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:49 timestamp:1689674712805 [07-18 18:05:12:805 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:11633217 ts:0 [07-18 18:05:12:805 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:11633217 [07-18 18:05:12:805 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:322183 dataSize:756 [07-18 18:05:12:805 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:49 timestamp:1689674712805 [07-18 18:05:12:839 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:11666550 ts:0 [07-18 18:05:12:839 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:11666550 [07-18 18:05:12:839 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:322939 dataSize:1610 [07-18 18:05:12:839 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:50 timestamp:1689674712839 [07-18 18:05:12:839 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:11666550 ts:0 [07-18 18:05:12:839 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:11666550 [07-18 18:05:12:839 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:322939 dataSize:1610 [07-18 18:05:12:839 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:50 timestamp:1689674712839 [07-18 18:05:12:872 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:11699883 ts:0 [07-18 18:05:12:872 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:11699883 [07-18 18:05:12:872 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:324549 dataSize:516 [07-18 18:05:12:872 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:51 timestamp:1689674712872 [07-18 18:05:12:872 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:11699883 ts:0 [07-18 18:05:12:872 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:11699883 [07-18 18:05:12:872 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:324549 dataSize:516 [07-18 18:05:12:872 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:51 timestamp:1689674712872 [07-18 18:05:12:893 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:12:893 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 297, head index 51 [07-18 18:05:12:893 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 298, seqNo 298, timestamp 1689674711089 [07-18 18:05:12:893 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:12:906 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:11733216 ts:0 [07-18 18:05:12:906 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:11733216 [07-18 18:05:12:906 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:325065 dataSize:231 [07-18 18:05:12:906 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:52 timestamp:1689674712906 [07-18 18:05:12:906 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:11733216 ts:0 [07-18 18:05:12:906 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:11733216 [07-18 18:05:12:906 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:325065 dataSize:231 [07-18 18:05:12:906 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:52 timestamp:1689674712906 [07-18 18:05:12:939 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:11766549 ts:0 [07-18 18:05:12:939 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:11766549 [07-18 18:05:12:939 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:325296 dataSize:250 [07-18 18:05:12:939 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:53 timestamp:1689674712939 [07-18 18:05:12:939 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:11766549 ts:0 [07-18 18:05:12:939 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:11766549 [07-18 18:05:12:939 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:325296 dataSize:250 [07-18 18:05:12:939 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:53 timestamp:1689674712939 [07-18 18:05:12:958 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:12:958 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:12:973 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:11799882 ts:0 [07-18 18:05:12:973 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:11799882 [07-18 18:05:12:973 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:325546 dataSize:1143 [07-18 18:05:12:973 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:54 timestamp:1689674712973 [07-18 18:05:12:973 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:11799882 ts:0 [07-18 18:05:12:973 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:11799882 [07-18 18:05:12:973 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:325546 dataSize:1143 [07-18 18:05:12:973 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:54 timestamp:1689674712973 [07-18 18:05:13:4 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:4 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 298, head index 54 [07-18 18:05:13:4 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 299, seqNo 299, timestamp 1689674711123 [07-18 18:05:13:4 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:6 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:11833215 ts:0 [07-18 18:05:13:6 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:11833215 [07-18 18:05:13:6 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:326689 dataSize:383 [07-18 18:05:13:6 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:55 timestamp:1689674713006 [07-18 18:05:13:7 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:11833215 ts:0 [07-18 18:05:13:7 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:11833215 [07-18 18:05:13:7 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:326689 dataSize:383 [07-18 18:05:13:7 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:55 timestamp:1689674713007 [07-18 18:05:13:40 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:11866548 ts:0 [07-18 18:05:13:40 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:11866548 [07-18 18:05:13:40 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:327072 dataSize:235 [07-18 18:05:13:40 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:56 timestamp:1689674713040 [07-18 18:05:13:40 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:11866548 ts:0 [07-18 18:05:13:40 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:11866548 [07-18 18:05:13:40 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:327072 dataSize:235 [07-18 18:05:13:40 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:56 timestamp:1689674713040 [07-18 18:05:13:74 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:11899881 ts:0 [07-18 18:05:13:74 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:11899881 [07-18 18:05:13:74 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:327307 dataSize:165 [07-18 18:05:13:74 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:57 timestamp:1689674713074 [07-18 18:05:13:74 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:11899881 ts:0 [07-18 18:05:13:74 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:11899881 [07-18 18:05:13:74 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:327307 dataSize:165 [07-18 18:05:13:74 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:57 timestamp:1689674713074 [07-18 18:05:13:107 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:11933214 ts:0 [07-18 18:05:13:107 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:11933214 [07-18 18:05:13:107 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:327472 dataSize:457 [07-18 18:05:13:107 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:58 timestamp:1689674713107 [07-18 18:05:13:107 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:11933214 ts:0 [07-18 18:05:13:107 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:11933214 [07-18 18:05:13:107 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:327472 dataSize:457 [07-18 18:05:13:107 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:58 timestamp:1689674713107 [07-18 18:05:13:114 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:114 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 299, head index 58 [07-18 18:05:13:114 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 0, seqNo 300, timestamp 1689674711157 [07-18 18:05:13:114 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:141 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:11966547 ts:0 [07-18 18:05:13:141 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:11966547 [07-18 18:05:13:141 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:327929 dataSize:673 [07-18 18:05:13:141 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:59 timestamp:1689674713141 [07-18 18:05:13:141 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:11966547 ts:0 [07-18 18:05:13:141 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:11966547 [07-18 18:05:13:141 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:327929 dataSize:673 [07-18 18:05:13:141 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:59 timestamp:1689674713141 [07-18 18:05:13:175 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:11999880 ts:0 [07-18 18:05:13:175 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:11999880 [07-18 18:05:13:175 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:328602 dataSize:465 [07-18 18:05:13:175 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:60 timestamp:1689674713175 [07-18 18:05:13:175 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:11999880 ts:0 [07-18 18:05:13:175 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:11999880 [07-18 18:05:13:175 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:328602 dataSize:465 [07-18 18:05:13:175 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:60 timestamp:1689674713175 [07-18 18:05:13:208 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:12033213 ts:0 [07-18 18:05:13:208 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:12033213 [07-18 18:05:13:208 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:329067 dataSize:248 [07-18 18:05:13:208 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:61 timestamp:1689674713208 [07-18 18:05:13:208 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:12033213 ts:0 [07-18 18:05:13:208 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:12033213 [07-18 18:05:13:208 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:329067 dataSize:248 [07-18 18:05:13:208 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:61 timestamp:1689674713208 [07-18 18:05:13:224 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:224 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 0, head index 61 [07-18 18:05:13:225 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 1, seqNo 301, timestamp 1689674711190 [07-18 18:05:13:225 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:242 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:12066546 ts:0 [07-18 18:05:13:242 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:12066546 [07-18 18:05:13:242 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:329315 dataSize:217 [07-18 18:05:13:242 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:62 timestamp:1689674713242 [07-18 18:05:13:242 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:12066546 ts:0 [07-18 18:05:13:242 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:12066546 [07-18 18:05:13:242 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:329315 dataSize:217 [07-18 18:05:13:242 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:62 timestamp:1689674713242 [07-18 18:05:13:266 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:05:13:275 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:12099879 ts:0 [07-18 18:05:13:275 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:12099879 [07-18 18:05:13:275 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:329532 dataSize:280 [07-18 18:05:13:275 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:63 timestamp:1689674713275 [07-18 18:05:13:275 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:12099879 ts:0 [07-18 18:05:13:275 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:12099879 [07-18 18:05:13:275 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:329532 dataSize:280 [07-18 18:05:13:275 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:63 timestamp:1689674713275 [07-18 18:05:13:309 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:12133212 ts:0 [07-18 18:05:13:309 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:12133212 [07-18 18:05:13:309 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:329812 dataSize:12088 [07-18 18:05:13:309 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:64 timestamp:1689674713309 [07-18 18:05:13:309 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:12133212 ts:0 [07-18 18:05:13:309 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:12133212 [07-18 18:05:13:309 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:329812 dataSize:12088 [07-18 18:05:13:309 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:64 timestamp:1689674713309 [07-18 18:05:13:335 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:335 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 1, head index 64 [07-18 18:05:13:335 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 2, seqNo 302, timestamp 1689674711224 [07-18 18:05:13:335 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:343 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:12166545 ts:0 [07-18 18:05:13:343 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:12166545 [07-18 18:05:13:343 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:341900 dataSize:1051 [07-18 18:05:13:343 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:65 timestamp:1689674713343 [07-18 18:05:13:343 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:12166545 ts:0 [07-18 18:05:13:343 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:12166545 [07-18 18:05:13:343 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:341900 dataSize:1051 [07-18 18:05:13:343 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:65 timestamp:1689674713343 [07-18 18:05:13:376 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:12199878 ts:0 [07-18 18:05:13:376 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:12199878 [07-18 18:05:13:376 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:342951 dataSize:209 [07-18 18:05:13:376 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:66 timestamp:1689674713376 [07-18 18:05:13:376 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:12199878 ts:0 [07-18 18:05:13:376 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:12199878 [07-18 18:05:13:376 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:342951 dataSize:209 [07-18 18:05:13:376 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:66 timestamp:1689674713376 [07-18 18:05:13:410 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:12233211 ts:0 [07-18 18:05:13:410 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:12233211 [07-18 18:05:13:410 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:343160 dataSize:118 [07-18 18:05:13:410 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:67 timestamp:1689674713410 [07-18 18:05:13:410 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:12233211 ts:0 [07-18 18:05:13:410 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:12233211 [07-18 18:05:13:410 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:343160 dataSize:118 [07-18 18:05:13:410 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:67 timestamp:1689674713410 [07-18 18:05:13:443 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:12266544 ts:0 [07-18 18:05:13:443 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:12266544 [07-18 18:05:13:444 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:343278 dataSize:110 [07-18 18:05:13:444 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:68 timestamp:1689674713444 [07-18 18:05:13:444 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:12266544 ts:0 [07-18 18:05:13:444 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:12266544 [07-18 18:05:13:444 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:343278 dataSize:110 [07-18 18:05:13:444 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:68 timestamp:1689674713444 [07-18 18:05:13:445 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:445 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 2, head index 68 [07-18 18:05:13:445 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 3, seqNo 303, timestamp 1689674711258 [07-18 18:05:13:445 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:477 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:12299877 ts:0 [07-18 18:05:13:477 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:12299877 [07-18 18:05:13:477 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:343388 dataSize:695 [07-18 18:05:13:477 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:69 timestamp:1689674713477 [07-18 18:05:13:477 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:12299877 ts:0 [07-18 18:05:13:477 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:12299877 [07-18 18:05:13:477 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:343388 dataSize:695 [07-18 18:05:13:477 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:69 timestamp:1689674713477 [07-18 18:05:13:511 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:12333210 ts:0 [07-18 18:05:13:511 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:12333210 [07-18 18:05:13:511 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:344083 dataSize:1146 [07-18 18:05:13:511 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:70 timestamp:1689674713511 [07-18 18:05:13:511 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:12333210 ts:0 [07-18 18:05:13:511 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:12333210 [07-18 18:05:13:511 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:344083 dataSize:1146 [07-18 18:05:13:511 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:70 timestamp:1689674713511 [07-18 18:05:13:544 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:12366543 ts:0 [07-18 18:05:13:545 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:12366543 [07-18 18:05:13:545 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:345229 dataSize:276 [07-18 18:05:13:545 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:71 timestamp:1689674713545 [07-18 18:05:13:545 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:12366543 ts:0 [07-18 18:05:13:545 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:12366543 [07-18 18:05:13:545 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:345229 dataSize:276 [07-18 18:05:13:545 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:71 timestamp:1689674713545 [07-18 18:05:13:556 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:556 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 3, head index 71 [07-18 18:05:13:556 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 4, seqNo 304, timestamp 1689674711292 [07-18 18:05:13:556 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:578 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:12399876 ts:0 [07-18 18:05:13:578 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:12399876 [07-18 18:05:13:578 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:345505 dataSize:152 [07-18 18:05:13:578 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:72 timestamp:1689674713578 [07-18 18:05:13:578 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:12399876 ts:0 [07-18 18:05:13:578 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:12399876 [07-18 18:05:13:578 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:345505 dataSize:152 [07-18 18:05:13:578 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:72 timestamp:1689674713578 [07-18 18:05:13:612 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:12433209 ts:0 [07-18 18:05:13:612 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:12433209 [07-18 18:05:13:612 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:345657 dataSize:136 [07-18 18:05:13:612 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:73 timestamp:1689674713612 [07-18 18:05:13:612 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:12433209 ts:0 [07-18 18:05:13:612 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:12433209 [07-18 18:05:13:612 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:345657 dataSize:136 [07-18 18:05:13:612 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:73 timestamp:1689674713612 [07-18 18:05:13:645 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:12466542 ts:0 [07-18 18:05:13:645 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:12466542 [07-18 18:05:13:645 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:345793 dataSize:725 [07-18 18:05:13:645 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:74 timestamp:1689674713645 [07-18 18:05:13:645 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:12466542 ts:0 [07-18 18:05:13:645 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:12466542 [07-18 18:05:13:645 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:345793 dataSize:725 [07-18 18:05:13:645 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:74 timestamp:1689674713645 [07-18 18:05:13:666 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:666 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 4, head index 74 [07-18 18:05:13:666 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 5, seqNo 305, timestamp 1689674711325 [07-18 18:05:13:667 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:679 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:12499875 ts:0 [07-18 18:05:13:679 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:12499875 [07-18 18:05:13:679 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:346518 dataSize:1369 [07-18 18:05:13:679 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:75 timestamp:1689674713679 [07-18 18:05:13:679 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:12499875 ts:0 [07-18 18:05:13:679 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:12499875 [07-18 18:05:13:679 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:346518 dataSize:1369 [07-18 18:05:13:679 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:75 timestamp:1689674713679 [07-18 18:05:13:713 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:12533208 ts:0 [07-18 18:05:13:713 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:12533208 [07-18 18:05:13:713 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:347887 dataSize:367 [07-18 18:05:13:713 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:76 timestamp:1689674713713 [07-18 18:05:13:713 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:12533208 ts:0 [07-18 18:05:13:713 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:12533208 [07-18 18:05:13:713 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:347887 dataSize:367 [07-18 18:05:13:713 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:76 timestamp:1689674713713 [07-18 18:05:13:746 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:12566541 ts:0 [07-18 18:05:13:746 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:12566541 [07-18 18:05:13:746 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:348254 dataSize:141 [07-18 18:05:13:746 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:77 timestamp:1689674713746 [07-18 18:05:13:746 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:12566541 ts:0 [07-18 18:05:13:746 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:12566541 [07-18 18:05:13:746 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:348254 dataSize:141 [07-18 18:05:13:746 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:77 timestamp:1689674713746 [07-18 18:05:13:777 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:777 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 5, head index 77 [07-18 18:05:13:777 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 6, seqNo 306, timestamp 1689674711359 [07-18 18:05:13:777 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:780 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:12599874 ts:0 [07-18 18:05:13:780 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:12599874 [07-18 18:05:13:780 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:348395 dataSize:160 [07-18 18:05:13:780 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:78 timestamp:1689674713780 [07-18 18:05:13:780 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:12599874 ts:0 [07-18 18:05:13:780 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:12599874 [07-18 18:05:13:780 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:348395 dataSize:160 [07-18 18:05:13:780 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:78 timestamp:1689674713780 [07-18 18:05:13:813 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:12633207 ts:0 [07-18 18:05:13:813 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:12633207 [07-18 18:05:13:813 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:348555 dataSize:756 [07-18 18:05:13:813 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:79 timestamp:1689674713813 [07-18 18:05:13:813 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:12633207 ts:0 [07-18 18:05:13:813 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:12633207 [07-18 18:05:13:813 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:348555 dataSize:756 [07-18 18:05:13:813 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:79 timestamp:1689674713813 [07-18 18:05:13:847 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:12666540 ts:0 [07-18 18:05:13:847 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:12666540 [07-18 18:05:13:847 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:349311 dataSize:1610 [07-18 18:05:13:847 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:80 timestamp:1689674713847 [07-18 18:05:13:847 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:12666540 ts:0 [07-18 18:05:13:847 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:12666540 [07-18 18:05:13:847 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:349311 dataSize:1610 [07-18 18:05:13:847 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:80 timestamp:1689674713847 [07-18 18:05:13:880 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:12699873 ts:0 [07-18 18:05:13:880 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:12699873 [07-18 18:05:13:881 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:350921 dataSize:516 [07-18 18:05:13:881 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:81 timestamp:1689674713881 [07-18 18:05:13:881 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:12699873 ts:0 [07-18 18:05:13:881 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:12699873 [07-18 18:05:13:881 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:350921 dataSize:516 [07-18 18:05:13:881 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:81 timestamp:1689674713881 [07-18 18:05:13:887 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:887 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 6, head index 81 [07-18 18:05:13:887 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 7, seqNo 307, timestamp 1689674711393 [07-18 18:05:13:887 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:13:914 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:12733206 ts:0 [07-18 18:05:13:914 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:12733206 [07-18 18:05:13:914 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:351437 dataSize:231 [07-18 18:05:13:914 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:82 timestamp:1689674713914 [07-18 18:05:13:914 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:12733206 ts:0 [07-18 18:05:13:914 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:12733206 [07-18 18:05:13:914 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:351437 dataSize:231 [07-18 18:05:13:914 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:82 timestamp:1689674713914 [07-18 18:05:13:948 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:12766539 ts:0 [07-18 18:05:13:948 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:12766539 [07-18 18:05:13:948 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:351668 dataSize:250 [07-18 18:05:13:948 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:83 timestamp:1689674713948 [07-18 18:05:13:948 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:12766539 ts:0 [07-18 18:05:13:948 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:12766539 [07-18 18:05:13:948 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:351668 dataSize:250 [07-18 18:05:13:948 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:83 timestamp:1689674713948 [07-18 18:05:13:959 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:13:959 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:13:981 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:12799872 ts:0 [07-18 18:05:13:981 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:12799872 [07-18 18:05:13:981 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:351918 dataSize:1143 [07-18 18:05:13:981 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:84 timestamp:1689674713981 [07-18 18:05:13:981 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:12799872 ts:0 [07-18 18:05:13:981 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:12799872 [07-18 18:05:13:981 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:351918 dataSize:1143 [07-18 18:05:13:981 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:84 timestamp:1689674713981 [07-18 18:05:13:998 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:13:998 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 7, head index 84 [07-18 18:05:13:998 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 8, seqNo 308, timestamp 1689674711426 [07-18 18:05:13:998 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:15 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:12833205 ts:0 [07-18 18:05:14:15 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:12833205 [07-18 18:05:14:15 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:353061 dataSize:383 [07-18 18:05:14:15 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:85 timestamp:1689674714015 [07-18 18:05:14:15 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:12833205 ts:0 [07-18 18:05:14:15 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:12833205 [07-18 18:05:14:15 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:353061 dataSize:383 [07-18 18:05:14:15 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:85 timestamp:1689674714015 [07-18 18:05:14:49 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:12866538 ts:0 [07-18 18:05:14:49 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:12866538 [07-18 18:05:14:49 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:353444 dataSize:235 [07-18 18:05:14:49 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:86 timestamp:1689674714049 [07-18 18:05:14:49 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:12866538 ts:0 [07-18 18:05:14:49 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:12866538 [07-18 18:05:14:49 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:353444 dataSize:235 [07-18 18:05:14:49 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:86 timestamp:1689674714049 [07-18 18:05:14:82 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:12899871 ts:0 [07-18 18:05:14:82 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:12899871 [07-18 18:05:14:82 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:353679 dataSize:165 [07-18 18:05:14:82 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:87 timestamp:1689674714082 [07-18 18:05:14:82 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:12899871 ts:0 [07-18 18:05:14:82 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:12899871 [07-18 18:05:14:82 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:353679 dataSize:165 [07-18 18:05:14:82 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:87 timestamp:1689674714082 [07-18 18:05:14:108 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:108 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 8, head index 87 [07-18 18:05:14:108 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 9, seqNo 309, timestamp 1689674711460 [07-18 18:05:14:108 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:116 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:12933204 ts:0 [07-18 18:05:14:116 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:12933204 [07-18 18:05:14:116 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:353844 dataSize:457 [07-18 18:05:14:116 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:88 timestamp:1689674714116 [07-18 18:05:14:116 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:12933204 ts:0 [07-18 18:05:14:116 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:12933204 [07-18 18:05:14:116 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:353844 dataSize:457 [07-18 18:05:14:116 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:88 timestamp:1689674714116 [07-18 18:05:14:149 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:12966537 ts:0 [07-18 18:05:14:149 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:12966537 [07-18 18:05:14:149 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:354301 dataSize:673 [07-18 18:05:14:149 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:89 timestamp:1689674714149 [07-18 18:05:14:149 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:12966537 ts:0 [07-18 18:05:14:149 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:12966537 [07-18 18:05:14:149 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:354301 dataSize:673 [07-18 18:05:14:149 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:89 timestamp:1689674714149 [07-18 18:05:14:183 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:12999870 ts:0 [07-18 18:05:14:183 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:12999870 [07-18 18:05:14:183 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:354974 dataSize:465 [07-18 18:05:14:183 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:90 timestamp:1689674714183 [07-18 18:05:14:183 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:12999870 ts:0 [07-18 18:05:14:183 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:12999870 [07-18 18:05:14:183 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:354974 dataSize:465 [07-18 18:05:14:183 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:90 timestamp:1689674714183 [07-18 18:05:14:216 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:13033203 ts:0 [07-18 18:05:14:217 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:13033203 [07-18 18:05:14:217 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:355439 dataSize:248 [07-18 18:05:14:217 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:91 timestamp:1689674714217 [07-18 18:05:14:217 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:13033203 ts:0 [07-18 18:05:14:217 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:13033203 [07-18 18:05:14:217 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:355439 dataSize:248 [07-18 18:05:14:217 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:91 timestamp:1689674714217 [07-18 18:05:14:218 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:219 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 9, head index 91 [07-18 18:05:14:219 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 10, seqNo 310, timestamp 1689674711494 [07-18 18:05:14:219 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:250 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:13066536 ts:0 [07-18 18:05:14:250 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:13066536 [07-18 18:05:14:250 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:355687 dataSize:217 [07-18 18:05:14:250 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:92 timestamp:1689674714250 [07-18 18:05:14:250 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:13066536 ts:0 [07-18 18:05:14:250 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:13066536 [07-18 18:05:14:250 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:355687 dataSize:217 [07-18 18:05:14:250 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:92 timestamp:1689674714250 [07-18 18:05:14:284 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:13099869 ts:0 [07-18 18:05:14:284 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:13099869 [07-18 18:05:14:284 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:355904 dataSize:280 [07-18 18:05:14:284 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:93 timestamp:1689674714284 [07-18 18:05:14:284 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:13099869 ts:0 [07-18 18:05:14:284 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:13099869 [07-18 18:05:14:284 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:355904 dataSize:280 [07-18 18:05:14:284 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:93 timestamp:1689674714284 [07-18 18:05:14:318 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:13133202 ts:0 [07-18 18:05:14:318 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:13133202 [07-18 18:05:14:318 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:356184 dataSize:12088 [07-18 18:05:14:318 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:94 timestamp:1689674714318 [07-18 18:05:14:318 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:13133202 ts:0 [07-18 18:05:14:318 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:13133202 [07-18 18:05:14:318 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:356184 dataSize:12088 [07-18 18:05:14:318 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:94 timestamp:1689674714318 [07-18 18:05:14:329 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:329 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 10, head index 94 [07-18 18:05:14:329 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 11, seqNo 311, timestamp 1689674711527 [07-18 18:05:14:329 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:352 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:13166535 ts:0 [07-18 18:05:14:352 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:13166535 [07-18 18:05:14:352 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:368272 dataSize:1051 [07-18 18:05:14:352 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:95 timestamp:1689674714352 [07-18 18:05:14:352 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:13166535 ts:0 [07-18 18:05:14:352 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:13166535 [07-18 18:05:14:352 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:368272 dataSize:1051 [07-18 18:05:14:352 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:95 timestamp:1689674714352 [07-18 18:05:14:385 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:13199868 ts:0 [07-18 18:05:14:385 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:13199868 [07-18 18:05:14:386 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:369323 dataSize:209 [07-18 18:05:14:386 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:96 timestamp:1689674714386 [07-18 18:05:14:386 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:13199868 ts:0 [07-18 18:05:14:386 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:13199868 [07-18 18:05:14:386 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:369323 dataSize:209 [07-18 18:05:14:386 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:96 timestamp:1689674714386 [07-18 18:05:14:419 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:13233201 ts:0 [07-18 18:05:14:419 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:13233201 [07-18 18:05:14:419 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:369532 dataSize:118 [07-18 18:05:14:419 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:97 timestamp:1689674714419 [07-18 18:05:14:419 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:13233201 ts:0 [07-18 18:05:14:419 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:13233201 [07-18 18:05:14:419 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:369532 dataSize:118 [07-18 18:05:14:419 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:97 timestamp:1689674714419 [07-18 18:05:14:439 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:439 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 11, head index 97 [07-18 18:05:14:439 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 12, seqNo 312, timestamp 1689674711561 [07-18 18:05:14:439 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:453 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:13266534 ts:0 [07-18 18:05:14:453 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:13266534 [07-18 18:05:14:453 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:369650 dataSize:110 [07-18 18:05:14:453 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:98 timestamp:1689674714453 [07-18 18:05:14:453 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:13266534 ts:0 [07-18 18:05:14:453 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:13266534 [07-18 18:05:14:453 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:369650 dataSize:110 [07-18 18:05:14:453 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:98 timestamp:1689674714453 [07-18 18:05:14:486 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:13299867 ts:0 [07-18 18:05:14:486 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:13299867 [07-18 18:05:14:486 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:369760 dataSize:695 [07-18 18:05:14:486 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:99 timestamp:1689674714486 [07-18 18:05:14:486 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:13299867 ts:0 [07-18 18:05:14:486 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:13299867 [07-18 18:05:14:486 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:369760 dataSize:695 [07-18 18:05:14:486 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:99 timestamp:1689674714486 [07-18 18:05:14:520 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:13333200 ts:0 [07-18 18:05:14:520 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:13333200 [07-18 18:05:14:520 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:370455 dataSize:1146 [07-18 18:05:14:520 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:100 timestamp:1689674714520 [07-18 18:05:14:520 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:13333200 ts:0 [07-18 18:05:14:520 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:13333200 [07-18 18:05:14:520 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:370455 dataSize:1146 [07-18 18:05:14:520 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:100 timestamp:1689674714520 [07-18 18:05:14:550 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:550 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 12, head index 100 [07-18 18:05:14:550 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 13, seqNo 313, timestamp 1689674711594 [07-18 18:05:14:550 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:553 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:13366533 ts:0 [07-18 18:05:14:553 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:13366533 [07-18 18:05:14:553 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:371601 dataSize:276 [07-18 18:05:14:554 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:101 timestamp:1689674714554 [07-18 18:05:14:554 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:13366533 ts:0 [07-18 18:05:14:554 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:13366533 [07-18 18:05:14:554 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:371601 dataSize:276 [07-18 18:05:14:554 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:101 timestamp:1689674714554 [07-18 18:05:14:587 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:13399866 ts:0 [07-18 18:05:14:587 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:13399866 [07-18 18:05:14:587 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:371877 dataSize:152 [07-18 18:05:14:587 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:102 timestamp:1689674714587 [07-18 18:05:14:587 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:13399866 ts:0 [07-18 18:05:14:587 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:13399866 [07-18 18:05:14:587 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:371877 dataSize:152 [07-18 18:05:14:587 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:102 timestamp:1689674714587 [07-18 18:05:14:621 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:13433199 ts:0 [07-18 18:05:14:621 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:13433199 [07-18 18:05:14:621 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:372029 dataSize:136 [07-18 18:05:14:621 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:103 timestamp:1689674714621 [07-18 18:05:14:621 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:13433199 ts:0 [07-18 18:05:14:621 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:13433199 [07-18 18:05:14:621 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:372029 dataSize:136 [07-18 18:05:14:621 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:103 timestamp:1689674714621 [07-18 18:05:14:654 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:13466532 ts:0 [07-18 18:05:14:654 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:13466532 [07-18 18:05:14:654 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:372165 dataSize:725 [07-18 18:05:14:654 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:104 timestamp:1689674714654 [07-18 18:05:14:654 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:13466532 ts:0 [07-18 18:05:14:654 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:13466532 [07-18 18:05:14:654 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:372165 dataSize:725 [07-18 18:05:14:654 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:104 timestamp:1689674714654 [07-18 18:05:14:660 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:660 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 13, head index 104 [07-18 18:05:14:660 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 14, seqNo 314, timestamp 1689674711628 [07-18 18:05:14:660 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:688 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:13499865 ts:0 [07-18 18:05:14:688 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:13499865 [07-18 18:05:14:688 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:372890 dataSize:1369 [07-18 18:05:14:688 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:105 timestamp:1689674714688 [07-18 18:05:14:688 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:13499865 ts:0 [07-18 18:05:14:688 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:13499865 [07-18 18:05:14:688 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:372890 dataSize:1369 [07-18 18:05:14:688 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:105 timestamp:1689674714688 [07-18 18:05:14:722 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:13533198 ts:0 [07-18 18:05:14:722 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:13533198 [07-18 18:05:14:722 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:374259 dataSize:367 [07-18 18:05:14:722 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:106 timestamp:1689674714722 [07-18 18:05:14:722 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:13533198 ts:0 [07-18 18:05:14:722 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:13533198 [07-18 18:05:14:722 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:374259 dataSize:367 [07-18 18:05:14:722 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:106 timestamp:1689674714722 [07-18 18:05:14:755 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:13566531 ts:0 [07-18 18:05:14:755 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:13566531 [07-18 18:05:14:755 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:374626 dataSize:141 [07-18 18:05:14:755 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:107 timestamp:1689674714755 [07-18 18:05:14:755 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:13566531 ts:0 [07-18 18:05:14:755 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:13566531 [07-18 18:05:14:755 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:374626 dataSize:141 [07-18 18:05:14:755 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:107 timestamp:1689674714755 [07-18 18:05:14:770 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:770 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 14, head index 107 [07-18 18:05:14:771 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 15, seqNo 315, timestamp 1689674711662 [07-18 18:05:14:771 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:789 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:13599864 ts:0 [07-18 18:05:14:789 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:13599864 [07-18 18:05:14:789 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:374767 dataSize:160 [07-18 18:05:14:789 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:108 timestamp:1689674714789 [07-18 18:05:14:789 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:13599864 ts:0 [07-18 18:05:14:789 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:13599864 [07-18 18:05:14:789 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:374767 dataSize:160 [07-18 18:05:14:789 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:108 timestamp:1689674714789 [07-18 18:05:14:822 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:13633197 ts:0 [07-18 18:05:14:822 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:13633197 [07-18 18:05:14:823 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:374927 dataSize:756 [07-18 18:05:14:823 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:109 timestamp:1689674714823 [07-18 18:05:14:823 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:13633197 ts:0 [07-18 18:05:14:823 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:13633197 [07-18 18:05:14:823 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:374927 dataSize:756 [07-18 18:05:14:823 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:109 timestamp:1689674714823 [07-18 18:05:14:856 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:13666530 ts:0 [07-18 18:05:14:856 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:13666530 [07-18 18:05:14:856 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:375683 dataSize:1610 [07-18 18:05:14:856 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:110 timestamp:1689674714856 [07-18 18:05:14:856 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:13666530 ts:0 [07-18 18:05:14:856 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:13666530 [07-18 18:05:14:856 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:375683 dataSize:1610 [07-18 18:05:14:856 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:110 timestamp:1689674714856 [07-18 18:05:14:881 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:881 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 15, head index 110 [07-18 18:05:14:881 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 16, seqNo 316, timestamp 1689674711695 [07-18 18:05:14:881 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:14:890 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:13699863 ts:0 [07-18 18:05:14:890 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:13699863 [07-18 18:05:14:890 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:377293 dataSize:516 [07-18 18:05:14:890 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:111 timestamp:1689674714890 [07-18 18:05:14:890 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:13699863 ts:0 [07-18 18:05:14:890 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:13699863 [07-18 18:05:14:890 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:377293 dataSize:516 [07-18 18:05:14:890 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:111 timestamp:1689674714890 [07-18 18:05:14:923 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:13733196 ts:0 [07-18 18:05:14:923 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:13733196 [07-18 18:05:14:923 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:377809 dataSize:231 [07-18 18:05:14:923 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:112 timestamp:1689674714923 [07-18 18:05:14:923 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:13733196 ts:0 [07-18 18:05:14:923 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:13733196 [07-18 18:05:14:923 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:377809 dataSize:231 [07-18 18:05:14:923 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:112 timestamp:1689674714923 [07-18 18:05:14:957 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:13766529 ts:0 [07-18 18:05:14:957 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:13766529 [07-18 18:05:14:957 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:378040 dataSize:250 [07-18 18:05:14:957 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:113 timestamp:1689674714957 [07-18 18:05:14:957 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:13766529 ts:0 [07-18 18:05:14:957 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:13766529 [07-18 18:05:14:957 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:378040 dataSize:250 [07-18 18:05:14:957 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:113 timestamp:1689674714957 [07-18 18:05:14:961 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:14:961 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:14:991 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:13799862 ts:0 [07-18 18:05:14:991 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:13799862 [07-18 18:05:14:991 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:378290 dataSize:1143 [07-18 18:05:14:991 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:114 timestamp:1689674714991 [07-18 18:05:14:991 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:13799862 ts:0 [07-18 18:05:14:991 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:13799862 [07-18 18:05:14:991 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:378290 dataSize:1143 [07-18 18:05:14:991 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:114 timestamp:1689674714991 [07-18 18:05:14:991 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:14:991 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 16, head index 114 [07-18 18:05:14:991 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 17, seqNo 317, timestamp 1689674711729 [07-18 18:05:14:991 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:24 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:13833195 ts:0 [07-18 18:05:15:24 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:13833195 [07-18 18:05:15:24 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:379433 dataSize:383 [07-18 18:05:15:24 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:115 timestamp:1689674715024 [07-18 18:05:15:24 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:13833195 ts:0 [07-18 18:05:15:24 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:13833195 [07-18 18:05:15:24 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:379433 dataSize:383 [07-18 18:05:15:24 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:115 timestamp:1689674715024 [07-18 18:05:15:58 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:13866528 ts:0 [07-18 18:05:15:58 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:13866528 [07-18 18:05:15:58 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:379816 dataSize:235 [07-18 18:05:15:58 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:116 timestamp:1689674715058 [07-18 18:05:15:58 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:13866528 ts:0 [07-18 18:05:15:58 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:13866528 [07-18 18:05:15:58 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:379816 dataSize:235 [07-18 18:05:15:58 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:116 timestamp:1689674715058 [07-18 18:05:15:91 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:13899861 ts:0 [07-18 18:05:15:91 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:13899861 [07-18 18:05:15:91 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:380051 dataSize:165 [07-18 18:05:15:92 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:117 timestamp:1689674715092 [07-18 18:05:15:92 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:13899861 ts:0 [07-18 18:05:15:92 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:13899861 [07-18 18:05:15:92 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:380051 dataSize:165 [07-18 18:05:15:92 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:117 timestamp:1689674715092 [07-18 18:05:15:102 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:102 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 17, head index 117 [07-18 18:05:15:102 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 18, seqNo 318, timestamp 1689674711763 [07-18 18:05:15:102 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:125 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:13933194 ts:0 [07-18 18:05:15:125 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:13933194 [07-18 18:05:15:125 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:380216 dataSize:457 [07-18 18:05:15:125 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:118 timestamp:1689674715125 [07-18 18:05:15:125 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:13933194 ts:0 [07-18 18:05:15:125 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:13933194 [07-18 18:05:15:125 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:380216 dataSize:457 [07-18 18:05:15:125 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:118 timestamp:1689674715125 [07-18 18:05:15:159 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:13966527 ts:0 [07-18 18:05:15:159 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:13966527 [07-18 18:05:15:159 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:380673 dataSize:673 [07-18 18:05:15:159 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:119 timestamp:1689674715159 [07-18 18:05:15:159 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:13966527 ts:0 [07-18 18:05:15:159 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:13966527 [07-18 18:05:15:159 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:380673 dataSize:673 [07-18 18:05:15:159 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:119 timestamp:1689674715159 [07-18 18:05:15:192 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:13999860 ts:0 [07-18 18:05:15:192 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:13999860 [07-18 18:05:15:192 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:381346 dataSize:465 [07-18 18:05:15:192 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:120 timestamp:1689674715192 [07-18 18:05:15:192 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:13999860 ts:0 [07-18 18:05:15:192 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:13999860 [07-18 18:05:15:192 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:381346 dataSize:465 [07-18 18:05:15:192 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:120 timestamp:1689674715192 [07-18 18:05:15:212 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:212 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 18, head index 120 [07-18 18:05:15:212 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 19, seqNo 319, timestamp 1689674711796 [07-18 18:05:15:212 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:226 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:14033193 ts:0 [07-18 18:05:15:226 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:14033193 [07-18 18:05:15:226 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:381811 dataSize:248 [07-18 18:05:15:226 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:121 timestamp:1689674715226 [07-18 18:05:15:226 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:14033193 ts:0 [07-18 18:05:15:226 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:14033193 [07-18 18:05:15:226 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:381811 dataSize:248 [07-18 18:05:15:226 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:121 timestamp:1689674715226 [07-18 18:05:15:259 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:14066526 ts:0 [07-18 18:05:15:260 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:14066526 [07-18 18:05:15:260 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:382059 dataSize:217 [07-18 18:05:15:260 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:122 timestamp:1689674715260 [07-18 18:05:15:260 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:14066526 ts:0 [07-18 18:05:15:260 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:14066526 [07-18 18:05:15:260 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:382059 dataSize:217 [07-18 18:05:15:260 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:122 timestamp:1689674715260 [07-18 18:05:15:293 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:14099859 ts:0 [07-18 18:05:15:293 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:14099859 [07-18 18:05:15:293 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:382276 dataSize:280 [07-18 18:05:15:293 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:123 timestamp:1689674715293 [07-18 18:05:15:293 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:14099859 ts:0 [07-18 18:05:15:293 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:14099859 [07-18 18:05:15:293 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:382276 dataSize:280 [07-18 18:05:15:293 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:123 timestamp:1689674715293 [07-18 18:05:15:323 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:323 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 19, head index 123 [07-18 18:05:15:323 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 20, seqNo 320, timestamp 1689674711830 [07-18 18:05:15:323 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:327 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:14133192 ts:0 [07-18 18:05:15:327 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:14133192 [07-18 18:05:15:327 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:382556 dataSize:12088 [07-18 18:05:15:327 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:124 timestamp:1689674715327 [07-18 18:05:15:327 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:14133192 ts:0 [07-18 18:05:15:327 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:14133192 [07-18 18:05:15:327 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:382556 dataSize:12088 [07-18 18:05:15:327 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:124 timestamp:1689674715327 [07-18 18:05:15:360 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:14166525 ts:0 [07-18 18:05:15:360 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:14166525 [07-18 18:05:15:360 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:394644 dataSize:1051 [07-18 18:05:15:360 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:125 timestamp:1689674715360 [07-18 18:05:15:360 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:14166525 ts:0 [07-18 18:05:15:360 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:14166525 [07-18 18:05:15:360 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:394644 dataSize:1051 [07-18 18:05:15:360 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:125 timestamp:1689674715360 [07-18 18:05:15:394 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:14199858 ts:0 [07-18 18:05:15:394 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:14199858 [07-18 18:05:15:394 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:395695 dataSize:209 [07-18 18:05:15:394 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:126 timestamp:1689674715394 [07-18 18:05:15:394 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:14199858 ts:0 [07-18 18:05:15:394 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:14199858 [07-18 18:05:15:394 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:395695 dataSize:209 [07-18 18:05:15:394 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:126 timestamp:1689674715394 [07-18 18:05:15:428 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:14233191 ts:0 [07-18 18:05:15:428 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:14233191 [07-18 18:05:15:428 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:395904 dataSize:118 [07-18 18:05:15:428 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:127 timestamp:1689674715428 [07-18 18:05:15:428 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:14233191 ts:0 [07-18 18:05:15:428 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:14233191 [07-18 18:05:15:428 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:395904 dataSize:118 [07-18 18:05:15:428 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:127 timestamp:1689674715428 [07-18 18:05:15:433 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:433 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 20, head index 127 [07-18 18:05:15:433 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 21, seqNo 321, timestamp 1689674711863 [07-18 18:05:15:433 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:461 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:14266524 ts:0 [07-18 18:05:15:461 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:14266524 [07-18 18:05:15:461 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:396022 dataSize:110 [07-18 18:05:15:461 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:128 timestamp:1689674715461 [07-18 18:05:15:461 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:14266524 ts:0 [07-18 18:05:15:461 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:14266524 [07-18 18:05:15:461 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:396022 dataSize:110 [07-18 18:05:15:461 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:128 timestamp:1689674715461 [07-18 18:05:15:495 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:14299857 ts:0 [07-18 18:05:15:495 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:14299857 [07-18 18:05:15:495 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:396132 dataSize:695 [07-18 18:05:15:495 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:129 timestamp:1689674715495 [07-18 18:05:15:495 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:14299857 ts:0 [07-18 18:05:15:495 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:14299857 [07-18 18:05:15:495 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:396132 dataSize:695 [07-18 18:05:15:495 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:129 timestamp:1689674715495 [07-18 18:05:15:528 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:14333190 ts:0 [07-18 18:05:15:529 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:14333190 [07-18 18:05:15:529 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:396827 dataSize:1146 [07-18 18:05:15:529 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:130 timestamp:1689674715529 [07-18 18:05:15:529 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:14333190 ts:0 [07-18 18:05:15:529 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:14333190 [07-18 18:05:15:529 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:396827 dataSize:1146 [07-18 18:05:15:529 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:130 timestamp:1689674715529 [07-18 18:05:15:544 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:544 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 21, head index 130 [07-18 18:05:15:544 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 22, seqNo 322, timestamp 1689674711897 [07-18 18:05:15:544 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:562 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:14366523 ts:0 [07-18 18:05:15:562 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:14366523 [07-18 18:05:15:562 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:397973 dataSize:276 [07-18 18:05:15:562 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:131 timestamp:1689674715562 [07-18 18:05:15:562 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:14366523 ts:0 [07-18 18:05:15:562 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:14366523 [07-18 18:05:15:562 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:397973 dataSize:276 [07-18 18:05:15:562 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:131 timestamp:1689674715562 [07-18 18:05:15:596 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:14399856 ts:0 [07-18 18:05:15:596 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:14399856 [07-18 18:05:15:596 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:398249 dataSize:152 [07-18 18:05:15:596 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:132 timestamp:1689674715596 [07-18 18:05:15:596 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:14399856 ts:0 [07-18 18:05:15:596 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:14399856 [07-18 18:05:15:596 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:398249 dataSize:152 [07-18 18:05:15:596 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:132 timestamp:1689674715596 [07-18 18:05:15:629 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:14433189 ts:0 [07-18 18:05:15:629 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:14433189 [07-18 18:05:15:629 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:398401 dataSize:136 [07-18 18:05:15:630 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:133 timestamp:1689674715630 [07-18 18:05:15:630 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:14433189 ts:0 [07-18 18:05:15:630 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:14433189 [07-18 18:05:15:630 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:398401 dataSize:136 [07-18 18:05:15:630 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:133 timestamp:1689674715630 [07-18 18:05:15:654 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:654 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 22, head index 133 [07-18 18:05:15:654 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 23, seqNo 323, timestamp 1689674711931 [07-18 18:05:15:654 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:663 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:14466522 ts:0 [07-18 18:05:15:663 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:14466522 [07-18 18:05:15:663 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:398537 dataSize:725 [07-18 18:05:15:663 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:134 timestamp:1689674715663 [07-18 18:05:15:663 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:14466522 ts:0 [07-18 18:05:15:663 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:14466522 [07-18 18:05:15:663 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:398537 dataSize:725 [07-18 18:05:15:663 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:134 timestamp:1689674715663 [07-18 18:05:15:697 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:14499855 ts:0 [07-18 18:05:15:697 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:14499855 [07-18 18:05:15:697 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:399262 dataSize:1369 [07-18 18:05:15:697 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:135 timestamp:1689674715697 [07-18 18:05:15:697 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:14499855 ts:0 [07-18 18:05:15:697 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:14499855 [07-18 18:05:15:697 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:399262 dataSize:1369 [07-18 18:05:15:697 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:135 timestamp:1689674715697 [07-18 18:05:15:730 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:14533188 ts:0 [07-18 18:05:15:730 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:14533188 [07-18 18:05:15:730 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:400631 dataSize:367 [07-18 18:05:15:731 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:136 timestamp:1689674715731 [07-18 18:05:15:731 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:14533188 ts:0 [07-18 18:05:15:731 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:14533188 [07-18 18:05:15:731 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:400631 dataSize:367 [07-18 18:05:15:731 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:136 timestamp:1689674715731 [07-18 18:05:15:764 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:764 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 23, head index 136 [07-18 18:05:15:764 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 24, seqNo 324, timestamp 1689674711964 [07-18 18:05:15:764 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:14566521 ts:0 [07-18 18:05:15:764 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:14566521 [07-18 18:05:15:764 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:400998 dataSize:141 [07-18 18:05:15:764 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:137 timestamp:1689674715764 [07-18 18:05:15:764 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:14566521 ts:0 [07-18 18:05:15:764 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:14566521 [07-18 18:05:15:764 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:400998 dataSize:141 [07-18 18:05:15:764 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:137 timestamp:1689674715764 [07-18 18:05:15:764 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:798 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:14599854 ts:0 [07-18 18:05:15:798 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:14599854 [07-18 18:05:15:798 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:401139 dataSize:160 [07-18 18:05:15:798 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:138 timestamp:1689674715798 [07-18 18:05:15:798 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:14599854 ts:0 [07-18 18:05:15:798 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:14599854 [07-18 18:05:15:798 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:401139 dataSize:160 [07-18 18:05:15:798 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:138 timestamp:1689674715798 [07-18 18:05:15:831 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:14633187 ts:0 [07-18 18:05:15:831 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:14633187 [07-18 18:05:15:832 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:401299 dataSize:756 [07-18 18:05:15:832 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:139 timestamp:1689674715832 [07-18 18:05:15:832 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:14633187 ts:0 [07-18 18:05:15:832 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:14633187 [07-18 18:05:15:832 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:401299 dataSize:756 [07-18 18:05:15:832 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:139 timestamp:1689674715832 [07-18 18:05:15:865 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:14666520 ts:0 [07-18 18:05:15:865 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:14666520 [07-18 18:05:15:865 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:402055 dataSize:1610 [07-18 18:05:15:865 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:140 timestamp:1689674715865 [07-18 18:05:15:865 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:14666520 ts:0 [07-18 18:05:15:865 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:14666520 [07-18 18:05:15:865 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:402055 dataSize:1610 [07-18 18:05:15:865 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:140 timestamp:1689674715865 [07-18 18:05:15:875 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:875 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 24, head index 140 [07-18 18:05:15:875 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 25, seqNo 325, timestamp 1689674711998 [07-18 18:05:15:875 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:15:899 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:14699853 ts:0 [07-18 18:05:15:899 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:14699853 [07-18 18:05:15:899 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:403665 dataSize:516 [07-18 18:05:15:899 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:141 timestamp:1689674715899 [07-18 18:05:15:899 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:14699853 ts:0 [07-18 18:05:15:899 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:14699853 [07-18 18:05:15:899 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:403665 dataSize:516 [07-18 18:05:15:899 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:141 timestamp:1689674715899 [07-18 18:05:15:932 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:14733186 ts:0 [07-18 18:05:15:932 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:14733186 [07-18 18:05:15:932 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:404181 dataSize:231 [07-18 18:05:15:933 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:142 timestamp:1689674715933 [07-18 18:05:15:933 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:14733186 ts:0 [07-18 18:05:15:933 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:14733186 [07-18 18:05:15:933 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:404181 dataSize:231 [07-18 18:05:15:933 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:142 timestamp:1689674715933 [07-18 18:05:15:961 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:15:961 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:15:966 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:14766519 ts:0 [07-18 18:05:15:966 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:14766519 [07-18 18:05:15:966 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:404412 dataSize:250 [07-18 18:05:15:966 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:143 timestamp:1689674715966 [07-18 18:05:15:966 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:14766519 ts:0 [07-18 18:05:15:966 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:14766519 [07-18 18:05:15:966 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:404412 dataSize:250 [07-18 18:05:15:966 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:143 timestamp:1689674715966 [07-18 18:05:15:985 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:15:985 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 25, head index 143 [07-18 18:05:15:985 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 26, seqNo 326, timestamp 1689674712032 [07-18 18:05:15:985 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:0 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:14799852 ts:0 [07-18 18:05:16:0 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:14799852 [07-18 18:05:16:0 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:404662 dataSize:1143 [07-18 18:05:16:0 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:144 timestamp:1689674716000 [07-18 18:05:16:0 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:14799852 ts:0 [07-18 18:05:16:0 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:14799852 [07-18 18:05:16:0 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:404662 dataSize:1143 [07-18 18:05:16:0 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:144 timestamp:1689674716000 [07-18 18:05:16:33 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:14833185 ts:0 [07-18 18:05:16:33 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:14833185 [07-18 18:05:16:33 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:405805 dataSize:383 [07-18 18:05:16:33 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:145 timestamp:1689674716033 [07-18 18:05:16:33 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:14833185 ts:0 [07-18 18:05:16:33 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:14833185 [07-18 18:05:16:33 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:405805 dataSize:383 [07-18 18:05:16:34 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:145 timestamp:1689674716034 [07-18 18:05:16:67 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:14866518 ts:0 [07-18 18:05:16:67 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:14866518 [07-18 18:05:16:67 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:406188 dataSize:235 [07-18 18:05:16:67 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:146 timestamp:1689674716067 [07-18 18:05:16:67 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:14866518 ts:0 [07-18 18:05:16:67 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:14866518 [07-18 18:05:16:67 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:406188 dataSize:235 [07-18 18:05:16:67 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:146 timestamp:1689674716067 [07-18 18:05:16:95 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:95 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 26, head index 146 [07-18 18:05:16:95 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 27, seqNo 327, timestamp 1689674712065 [07-18 18:05:16:95 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:101 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:14899851 ts:0 [07-18 18:05:16:101 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:14899851 [07-18 18:05:16:101 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:406423 dataSize:165 [07-18 18:05:16:101 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:147 timestamp:1689674716101 [07-18 18:05:16:101 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:14899851 ts:0 [07-18 18:05:16:101 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:14899851 [07-18 18:05:16:101 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:406423 dataSize:165 [07-18 18:05:16:101 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:147 timestamp:1689674716101 [07-18 18:05:16:134 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:14933184 ts:0 [07-18 18:05:16:134 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:14933184 [07-18 18:05:16:134 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:406588 dataSize:457 [07-18 18:05:16:134 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:148 timestamp:1689674716134 [07-18 18:05:16:134 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:14933184 ts:0 [07-18 18:05:16:134 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:14933184 [07-18 18:05:16:134 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:406588 dataSize:457 [07-18 18:05:16:134 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:148 timestamp:1689674716134 [07-18 18:05:16:168 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:14966517 ts:0 [07-18 18:05:16:168 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:14966517 [07-18 18:05:16:168 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:407045 dataSize:673 [07-18 18:05:16:168 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:149 timestamp:1689674716168 [07-18 18:05:16:168 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:14966517 ts:0 [07-18 18:05:16:168 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:14966517 [07-18 18:05:16:168 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:407045 dataSize:673 [07-18 18:05:16:168 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:149 timestamp:1689674716168 [07-18 18:05:16:201 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:14999850 ts:0 [07-18 18:05:16:201 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:14999850 [07-18 18:05:16:201 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:407718 dataSize:465 [07-18 18:05:16:201 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:150 timestamp:1689674716201 [07-18 18:05:16:202 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:14999850 ts:0 [07-18 18:05:16:202 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:14999850 [07-18 18:05:16:202 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:407718 dataSize:465 [07-18 18:05:16:202 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:150 timestamp:1689674716202 [07-18 18:05:16:206 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:206 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 27, head index 150 [07-18 18:05:16:206 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 28, seqNo 328, timestamp 1689674712099 [07-18 18:05:16:206 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:235 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:15033183 ts:0 [07-18 18:05:16:235 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:15033183 [07-18 18:05:16:235 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:408183 dataSize:248 [07-18 18:05:16:235 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:151 timestamp:1689674716235 [07-18 18:05:16:235 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:15033183 ts:0 [07-18 18:05:16:235 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:15033183 [07-18 18:05:16:235 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:408183 dataSize:248 [07-18 18:05:16:235 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:151 timestamp:1689674716235 [07-18 18:05:16:269 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:15066516 ts:0 [07-18 18:05:16:269 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:15066516 [07-18 18:05:16:269 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:408431 dataSize:217 [07-18 18:05:16:269 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:152 timestamp:1689674716269 [07-18 18:05:16:269 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:15066516 ts:0 [07-18 18:05:16:269 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:15066516 [07-18 18:05:16:269 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:408431 dataSize:217 [07-18 18:05:16:269 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:152 timestamp:1689674716269 [07-18 18:05:16:302 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:15099849 ts:0 [07-18 18:05:16:302 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:15099849 [07-18 18:05:16:302 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:408648 dataSize:280 [07-18 18:05:16:302 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:153 timestamp:1689674716302 [07-18 18:05:16:302 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:15099849 ts:0 [07-18 18:05:16:303 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:15099849 [07-18 18:05:16:303 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:408648 dataSize:280 [07-18 18:05:16:303 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:153 timestamp:1689674716303 [07-18 18:05:16:316 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:316 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 28, head index 153 [07-18 18:05:16:316 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 29, seqNo 329, timestamp 1689674712133 [07-18 18:05:16:316 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:336 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:15133182 ts:0 [07-18 18:05:16:336 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:15133182 [07-18 18:05:16:336 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:408928 dataSize:12088 [07-18 18:05:16:336 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:154 timestamp:1689674716336 [07-18 18:05:16:336 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:15133182 ts:0 [07-18 18:05:16:336 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:15133182 [07-18 18:05:16:336 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:408928 dataSize:12088 [07-18 18:05:16:336 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:154 timestamp:1689674716336 [07-18 18:05:16:370 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:15166515 ts:0 [07-18 18:05:16:370 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:15166515 [07-18 18:05:16:370 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:421016 dataSize:1051 [07-18 18:05:16:370 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:155 timestamp:1689674716370 [07-18 18:05:16:370 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:15166515 ts:0 [07-18 18:05:16:370 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:15166515 [07-18 18:05:16:370 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:421016 dataSize:1051 [07-18 18:05:16:370 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:155 timestamp:1689674716370 [07-18 18:05:16:403 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:15199848 ts:0 [07-18 18:05:16:403 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:15199848 [07-18 18:05:16:403 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:422067 dataSize:209 [07-18 18:05:16:403 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:156 timestamp:1689674716403 [07-18 18:05:16:404 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:15199848 ts:0 [07-18 18:05:16:404 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:15199848 [07-18 18:05:16:404 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:422067 dataSize:209 [07-18 18:05:16:404 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:156 timestamp:1689674716404 [07-18 18:05:16:429 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:429 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 29, head index 156 [07-18 18:05:16:429 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 30, seqNo 330, timestamp 1689674712166 [07-18 18:05:16:429 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:437 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:15233181 ts:0 [07-18 18:05:16:437 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:15233181 [07-18 18:05:16:437 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:422276 dataSize:118 [07-18 18:05:16:437 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:157 timestamp:1689674716437 [07-18 18:05:16:437 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:15233181 ts:0 [07-18 18:05:16:437 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:15233181 [07-18 18:05:16:437 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:422276 dataSize:118 [07-18 18:05:16:437 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:157 timestamp:1689674716437 [07-18 18:05:16:471 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:15266514 ts:0 [07-18 18:05:16:471 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:15266514 [07-18 18:05:16:471 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:422394 dataSize:110 [07-18 18:05:16:471 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:158 timestamp:1689674716471 [07-18 18:05:16:471 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:15266514 ts:0 [07-18 18:05:16:471 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:15266514 [07-18 18:05:16:471 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:422394 dataSize:110 [07-18 18:05:16:471 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:158 timestamp:1689674716471 [07-18 18:05:16:505 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:15299847 ts:0 [07-18 18:05:16:505 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:15299847 [07-18 18:05:16:505 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:422504 dataSize:695 [07-18 18:05:16:505 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:159 timestamp:1689674716505 [07-18 18:05:16:505 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:15299847 ts:0 [07-18 18:05:16:505 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:15299847 [07-18 18:05:16:505 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:422504 dataSize:695 [07-18 18:05:16:505 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:159 timestamp:1689674716505 [07-18 18:05:16:538 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:15333180 ts:0 [07-18 18:05:16:538 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:15333180 [07-18 18:05:16:538 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:423199 dataSize:1146 [07-18 18:05:16:538 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:160 timestamp:1689674716538 [07-18 18:05:16:538 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:15333180 ts:0 [07-18 18:05:16:538 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:15333180 [07-18 18:05:16:538 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:423199 dataSize:1146 [07-18 18:05:16:538 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:160 timestamp:1689674716538 [07-18 18:05:16:539 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:539 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 30, head index 160 [07-18 18:05:16:539 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 31, seqNo 331, timestamp 1689674712200 [07-18 18:05:16:539 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:572 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:15366513 ts:0 [07-18 18:05:16:572 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:15366513 [07-18 18:05:16:572 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:424345 dataSize:276 [07-18 18:05:16:572 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:161 timestamp:1689674716572 [07-18 18:05:16:572 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:15366513 ts:0 [07-18 18:05:16:572 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:15366513 [07-18 18:05:16:572 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:424345 dataSize:276 [07-18 18:05:16:572 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:161 timestamp:1689674716572 [07-18 18:05:16:605 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:15399846 ts:0 [07-18 18:05:16:605 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:15399846 [07-18 18:05:16:605 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:424621 dataSize:152 [07-18 18:05:16:606 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:162 timestamp:1689674716606 [07-18 18:05:16:606 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:15399846 ts:0 [07-18 18:05:16:606 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:15399846 [07-18 18:05:16:606 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:424621 dataSize:152 [07-18 18:05:16:606 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:162 timestamp:1689674716606 [07-18 18:05:16:639 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:15433179 ts:0 [07-18 18:05:16:639 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:15433179 [07-18 18:05:16:639 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:424773 dataSize:136 [07-18 18:05:16:639 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:163 timestamp:1689674716639 [07-18 18:05:16:639 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:15433179 ts:0 [07-18 18:05:16:639 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:15433179 [07-18 18:05:16:639 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:424773 dataSize:136 [07-18 18:05:16:639 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:163 timestamp:1689674716639 [07-18 18:05:16:649 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:649 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 31, head index 163 [07-18 18:05:16:649 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 32, seqNo 332, timestamp 1689674712233 [07-18 18:05:16:649 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:673 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:15466512 ts:0 [07-18 18:05:16:673 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:15466512 [07-18 18:05:16:673 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:424909 dataSize:725 [07-18 18:05:16:673 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:164 timestamp:1689674716673 [07-18 18:05:16:673 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:15466512 ts:0 [07-18 18:05:16:673 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:15466512 [07-18 18:05:16:673 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:424909 dataSize:725 [07-18 18:05:16:673 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:164 timestamp:1689674716673 [07-18 18:05:16:706 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:15499845 ts:0 [07-18 18:05:16:706 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:15499845 [07-18 18:05:16:706 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:425634 dataSize:1369 [07-18 18:05:16:707 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:165 timestamp:1689674716707 [07-18 18:05:16:707 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:15499845 ts:0 [07-18 18:05:16:707 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:15499845 [07-18 18:05:16:707 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:425634 dataSize:1369 [07-18 18:05:16:707 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:165 timestamp:1689674716707 [07-18 18:05:16:740 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:15533178 ts:0 [07-18 18:05:16:740 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:15533178 [07-18 18:05:16:740 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:427003 dataSize:367 [07-18 18:05:16:740 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:166 timestamp:1689674716740 [07-18 18:05:16:740 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:15533178 ts:0 [07-18 18:05:16:740 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:15533178 [07-18 18:05:16:740 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:427003 dataSize:367 [07-18 18:05:16:740 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:166 timestamp:1689674716740 [07-18 18:05:16:759 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:759 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 32, head index 166 [07-18 18:05:16:759 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 33, seqNo 333, timestamp 1689674712267 [07-18 18:05:16:759 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:774 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:15566511 ts:0 [07-18 18:05:16:774 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:15566511 [07-18 18:05:16:774 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:427370 dataSize:141 [07-18 18:05:16:774 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:167 timestamp:1689674716774 [07-18 18:05:16:774 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:15566511 ts:0 [07-18 18:05:16:774 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:15566511 [07-18 18:05:16:774 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:427370 dataSize:141 [07-18 18:05:16:774 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:167 timestamp:1689674716774 [07-18 18:05:16:807 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:15599844 ts:0 [07-18 18:05:16:807 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:15599844 [07-18 18:05:16:807 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:427511 dataSize:160 [07-18 18:05:16:807 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:168 timestamp:1689674716807 [07-18 18:05:16:807 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:15599844 ts:0 [07-18 18:05:16:807 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:15599844 [07-18 18:05:16:808 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:427511 dataSize:160 [07-18 18:05:16:808 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:168 timestamp:1689674716808 [07-18 18:05:16:841 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:15633177 ts:0 [07-18 18:05:16:841 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:15633177 [07-18 18:05:16:841 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:427671 dataSize:756 [07-18 18:05:16:841 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:169 timestamp:1689674716841 [07-18 18:05:16:841 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:15633177 ts:0 [07-18 18:05:16:841 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:15633177 [07-18 18:05:16:841 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:427671 dataSize:756 [07-18 18:05:16:841 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:169 timestamp:1689674716841 [07-18 18:05:16:870 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:870 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 33, head index 169 [07-18 18:05:16:870 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 34, seqNo 334, timestamp 1689674712301 [07-18 18:05:16:870 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:16:875 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:15666510 ts:0 [07-18 18:05:16:875 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:15666510 [07-18 18:05:16:875 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:428427 dataSize:1610 [07-18 18:05:16:875 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:170 timestamp:1689674716875 [07-18 18:05:16:875 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:15666510 ts:0 [07-18 18:05:16:875 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:15666510 [07-18 18:05:16:875 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:428427 dataSize:1610 [07-18 18:05:16:875 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:170 timestamp:1689674716875 [07-18 18:05:16:908 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:15699843 ts:0 [07-18 18:05:16:908 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:15699843 [07-18 18:05:16:908 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:430037 dataSize:516 [07-18 18:05:16:908 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:171 timestamp:1689674716908 [07-18 18:05:16:908 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:15699843 ts:0 [07-18 18:05:16:908 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:15699843 [07-18 18:05:16:908 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:430037 dataSize:516 [07-18 18:05:16:908 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:171 timestamp:1689674716908 [07-18 18:05:16:942 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:15733176 ts:0 [07-18 18:05:16:942 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:15733176 [07-18 18:05:16:942 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:430553 dataSize:231 [07-18 18:05:16:942 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:172 timestamp:1689674716942 [07-18 18:05:16:942 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:15733176 ts:0 [07-18 18:05:16:942 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:15733176 [07-18 18:05:16:942 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:430553 dataSize:231 [07-18 18:05:16:942 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:172 timestamp:1689674716942 [07-18 18:05:16:962 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:16:962 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:16:976 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:15766509 ts:0 [07-18 18:05:16:976 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:15766509 [07-18 18:05:16:976 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:430784 dataSize:250 [07-18 18:05:16:976 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:173 timestamp:1689674716976 [07-18 18:05:16:976 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:15766509 ts:0 [07-18 18:05:16:976 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:15766509 [07-18 18:05:16:976 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:430784 dataSize:250 [07-18 18:05:16:976 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:173 timestamp:1689674716976 [07-18 18:05:16:980 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:16:980 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 34, head index 173 [07-18 18:05:16:980 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 35, seqNo 335, timestamp 1689674712334 [07-18 18:05:16:980 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:9 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:15799842 ts:0 [07-18 18:05:17:9 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:15799842 [07-18 18:05:17:9 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:431034 dataSize:1143 [07-18 18:05:17:9 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:174 timestamp:1689674717009 [07-18 18:05:17:9 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:15799842 ts:0 [07-18 18:05:17:9 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:15799842 [07-18 18:05:17:9 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:431034 dataSize:1143 [07-18 18:05:17:9 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:174 timestamp:1689674717009 [07-18 18:05:17:43 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:15833175 ts:0 [07-18 18:05:17:43 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:15833175 [07-18 18:05:17:43 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:432177 dataSize:383 [07-18 18:05:17:43 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:175 timestamp:1689674717043 [07-18 18:05:17:43 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:15833175 ts:0 [07-18 18:05:17:43 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:15833175 [07-18 18:05:17:43 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:432177 dataSize:383 [07-18 18:05:17:43 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:175 timestamp:1689674717043 [07-18 18:05:17:76 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:15866508 ts:0 [07-18 18:05:17:76 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:15866508 [07-18 18:05:17:77 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:432560 dataSize:235 [07-18 18:05:17:77 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:176 timestamp:1689674717077 [07-18 18:05:17:77 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:15866508 ts:0 [07-18 18:05:17:77 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:15866508 [07-18 18:05:17:77 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:432560 dataSize:235 [07-18 18:05:17:77 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:176 timestamp:1689674717077 [07-18 18:05:17:91 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:91 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 35, head index 176 [07-18 18:05:17:91 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 36, seqNo 336, timestamp 1689674712368 [07-18 18:05:17:91 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:110 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:15899841 ts:0 [07-18 18:05:17:110 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:15899841 [07-18 18:05:17:110 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:432795 dataSize:165 [07-18 18:05:17:110 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:177 timestamp:1689674717110 [07-18 18:05:17:110 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:15899841 ts:0 [07-18 18:05:17:110 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:15899841 [07-18 18:05:17:110 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:432795 dataSize:165 [07-18 18:05:17:110 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:177 timestamp:1689674717110 [07-18 18:05:17:144 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:15933174 ts:0 [07-18 18:05:17:144 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:15933174 [07-18 18:05:17:144 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:432960 dataSize:457 [07-18 18:05:17:144 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:178 timestamp:1689674717144 [07-18 18:05:17:144 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:15933174 ts:0 [07-18 18:05:17:144 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:15933174 [07-18 18:05:17:144 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:432960 dataSize:457 [07-18 18:05:17:144 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:178 timestamp:1689674717144 [07-18 18:05:17:177 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:15966507 ts:0 [07-18 18:05:17:177 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:15966507 [07-18 18:05:17:177 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:433417 dataSize:673 [07-18 18:05:17:177 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:179 timestamp:1689674717177 [07-18 18:05:17:178 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:15966507 ts:0 [07-18 18:05:17:178 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:15966507 [07-18 18:05:17:178 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:433417 dataSize:673 [07-18 18:05:17:178 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:179 timestamp:1689674717178 [07-18 18:05:17:201 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:201 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 36, head index 179 [07-18 18:05:17:201 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 37, seqNo 337, timestamp 1689674712402 [07-18 18:05:17:201 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:211 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:15999840 ts:0 [07-18 18:05:17:211 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:15999840 [07-18 18:05:17:211 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:434090 dataSize:465 [07-18 18:05:17:211 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:180 timestamp:1689674717211 [07-18 18:05:17:211 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:15999840 ts:0 [07-18 18:05:17:211 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:15999840 [07-18 18:05:17:211 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:434090 dataSize:465 [07-18 18:05:17:211 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:180 timestamp:1689674717211 [07-18 18:05:17:245 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:16033173 ts:0 [07-18 18:05:17:245 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:16033173 [07-18 18:05:17:245 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:434555 dataSize:248 [07-18 18:05:17:245 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:181 timestamp:1689674717245 [07-18 18:05:17:245 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:16033173 ts:0 [07-18 18:05:17:245 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:16033173 [07-18 18:05:17:245 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:434555 dataSize:248 [07-18 18:05:17:245 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:181 timestamp:1689674717245 [07-18 18:05:17:278 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:16066506 ts:0 [07-18 18:05:17:278 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:16066506 [07-18 18:05:17:278 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:434803 dataSize:217 [07-18 18:05:17:278 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:182 timestamp:1689674717278 [07-18 18:05:17:279 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:16066506 ts:0 [07-18 18:05:17:279 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:16066506 [07-18 18:05:17:279 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:434803 dataSize:217 [07-18 18:05:17:279 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:182 timestamp:1689674717279 [07-18 18:05:17:311 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:311 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 37, head index 182 [07-18 18:05:17:311 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 38, seqNo 338, timestamp 1689674712435 [07-18 18:05:17:311 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:312 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:16099839 ts:0 [07-18 18:05:17:312 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:16099839 [07-18 18:05:17:312 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:435020 dataSize:280 [07-18 18:05:17:312 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:183 timestamp:1689674717312 [07-18 18:05:17:312 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:16099839 ts:0 [07-18 18:05:17:312 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:16099839 [07-18 18:05:17:312 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:435020 dataSize:280 [07-18 18:05:17:312 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:183 timestamp:1689674717312 [07-18 18:05:17:346 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:16133172 ts:0 [07-18 18:05:17:346 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:16133172 [07-18 18:05:17:346 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:435300 dataSize:12088 [07-18 18:05:17:346 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:184 timestamp:1689674717346 [07-18 18:05:17:346 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:16133172 ts:0 [07-18 18:05:17:346 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:16133172 [07-18 18:05:17:346 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:435300 dataSize:12088 [07-18 18:05:17:346 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:184 timestamp:1689674717346 [07-18 18:05:17:379 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:16166505 ts:0 [07-18 18:05:17:379 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:16166505 [07-18 18:05:17:379 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:447388 dataSize:1051 [07-18 18:05:17:379 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:185 timestamp:1689674717379 [07-18 18:05:17:380 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:16166505 ts:0 [07-18 18:05:17:380 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:16166505 [07-18 18:05:17:380 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:447388 dataSize:1051 [07-18 18:05:17:380 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:185 timestamp:1689674717380 [07-18 18:05:17:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:16199838 ts:0 [07-18 18:05:17:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:16199838 [07-18 18:05:17:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:448439 dataSize:209 [07-18 18:05:17:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:186 timestamp:1689674717413 [07-18 18:05:17:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:16199838 ts:0 [07-18 18:05:17:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:16199838 [07-18 18:05:17:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:448439 dataSize:209 [07-18 18:05:17:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:186 timestamp:1689674717413 [07-18 18:05:17:422 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:422 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 38, head index 186 [07-18 18:05:17:422 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 39, seqNo 339, timestamp 1689674712469 [07-18 18:05:17:422 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:447 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:16233171 ts:0 [07-18 18:05:17:447 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:16233171 [07-18 18:05:17:447 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:448648 dataSize:118 [07-18 18:05:17:447 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:187 timestamp:1689674717447 [07-18 18:05:17:447 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:16233171 ts:0 [07-18 18:05:17:447 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:16233171 [07-18 18:05:17:447 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:448648 dataSize:118 [07-18 18:05:17:447 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:187 timestamp:1689674717447 [07-18 18:05:17:480 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:16266504 ts:0 [07-18 18:05:17:480 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:16266504 [07-18 18:05:17:480 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:448766 dataSize:110 [07-18 18:05:17:480 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:188 timestamp:1689674717480 [07-18 18:05:17:481 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:16266504 ts:0 [07-18 18:05:17:481 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:16266504 [07-18 18:05:17:481 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:448766 dataSize:110 [07-18 18:05:17:481 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:188 timestamp:1689674717481 [07-18 18:05:17:514 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:16299837 ts:0 [07-18 18:05:17:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:16299837 [07-18 18:05:17:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:448876 dataSize:695 [07-18 18:05:17:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:189 timestamp:1689674717514 [07-18 18:05:17:514 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:16299837 ts:0 [07-18 18:05:17:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:16299837 [07-18 18:05:17:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:448876 dataSize:695 [07-18 18:05:17:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:189 timestamp:1689674717514 [07-18 18:05:17:532 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:532 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 39, head index 189 [07-18 18:05:17:532 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 40, seqNo 340, timestamp 1689674712502 [07-18 18:05:17:532 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:548 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:16333170 ts:0 [07-18 18:05:17:548 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:16333170 [07-18 18:05:17:548 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:449571 dataSize:1146 [07-18 18:05:17:548 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:190 timestamp:1689674717548 [07-18 18:05:17:548 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:16333170 ts:0 [07-18 18:05:17:548 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:16333170 [07-18 18:05:17:548 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:449571 dataSize:1146 [07-18 18:05:17:548 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:190 timestamp:1689674717548 [07-18 18:05:17:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:16366503 ts:0 [07-18 18:05:17:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:16366503 [07-18 18:05:17:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:450717 dataSize:276 [07-18 18:05:17:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:191 timestamp:1689674717581 [07-18 18:05:17:582 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:16366503 ts:0 [07-18 18:05:17:582 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:16366503 [07-18 18:05:17:582 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:450717 dataSize:276 [07-18 18:05:17:582 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:191 timestamp:1689674717582 [07-18 18:05:17:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:16399836 ts:0 [07-18 18:05:17:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:16399836 [07-18 18:05:17:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:450993 dataSize:152 [07-18 18:05:17:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:192 timestamp:1689674717615 [07-18 18:05:17:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:16399836 ts:0 [07-18 18:05:17:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:16399836 [07-18 18:05:17:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:450993 dataSize:152 [07-18 18:05:17:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:192 timestamp:1689674717615 [07-18 18:05:17:642 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:642 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 40, head index 192 [07-18 18:05:17:642 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 41, seqNo 341, timestamp 1689674712536 [07-18 18:05:17:642 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:649 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:16433169 ts:0 [07-18 18:05:17:649 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:16433169 [07-18 18:05:17:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:451145 dataSize:136 [07-18 18:05:17:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:193 timestamp:1689674717649 [07-18 18:05:17:649 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:16433169 ts:0 [07-18 18:05:17:649 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:16433169 [07-18 18:05:17:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:451145 dataSize:136 [07-18 18:05:17:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:193 timestamp:1689674717649 [07-18 18:05:17:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:16466502 ts:0 [07-18 18:05:17:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:16466502 [07-18 18:05:17:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:451281 dataSize:725 [07-18 18:05:17:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:194 timestamp:1689674717682 [07-18 18:05:17:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:16466502 ts:0 [07-18 18:05:17:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:16466502 [07-18 18:05:17:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:451281 dataSize:725 [07-18 18:05:17:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:194 timestamp:1689674717682 [07-18 18:05:17:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:16499835 ts:0 [07-18 18:05:17:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:16499835 [07-18 18:05:17:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:452006 dataSize:1369 [07-18 18:05:17:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:195 timestamp:1689674717716 [07-18 18:05:17:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:16499835 ts:0 [07-18 18:05:17:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:16499835 [07-18 18:05:17:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:452006 dataSize:1369 [07-18 18:05:17:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:195 timestamp:1689674717716 [07-18 18:05:17:750 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:16533168 ts:0 [07-18 18:05:17:750 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:16533168 [07-18 18:05:17:750 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:453375 dataSize:367 [07-18 18:05:17:750 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:196 timestamp:1689674717750 [07-18 18:05:17:750 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:16533168 ts:0 [07-18 18:05:17:750 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:16533168 [07-18 18:05:17:750 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:453375 dataSize:367 [07-18 18:05:17:750 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:196 timestamp:1689674717750 [07-18 18:05:17:752 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:752 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 41, head index 196 [07-18 18:05:17:753 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 42, seqNo 342, timestamp 1689674712570 [07-18 18:05:17:753 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:16566501 ts:0 [07-18 18:05:17:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:16566501 [07-18 18:05:17:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:453742 dataSize:141 [07-18 18:05:17:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:197 timestamp:1689674717783 [07-18 18:05:17:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:16566501 ts:0 [07-18 18:05:17:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:16566501 [07-18 18:05:17:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:453742 dataSize:141 [07-18 18:05:17:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:197 timestamp:1689674717783 [07-18 18:05:17:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:16599834 ts:0 [07-18 18:05:17:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:16599834 [07-18 18:05:17:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:453883 dataSize:160 [07-18 18:05:17:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:198 timestamp:1689674717817 [07-18 18:05:17:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:16599834 ts:0 [07-18 18:05:17:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:16599834 [07-18 18:05:17:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:453883 dataSize:160 [07-18 18:05:17:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:198 timestamp:1689674717817 [07-18 18:05:17:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:16633167 ts:0 [07-18 18:05:17:851 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:16633167 [07-18 18:05:17:851 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:454043 dataSize:756 [07-18 18:05:17:851 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:199 timestamp:1689674717851 [07-18 18:05:17:851 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:16633167 ts:0 [07-18 18:05:17:851 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:16633167 [07-18 18:05:17:851 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:454043 dataSize:756 [07-18 18:05:17:851 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:199 timestamp:1689674717851 [07-18 18:05:17:863 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:863 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 42, head index 199 [07-18 18:05:17:863 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 43, seqNo 343, timestamp 1689674712603 [07-18 18:05:17:863 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:16666500 ts:0 [07-18 18:05:17:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:16666500 [07-18 18:05:17:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:454799 dataSize:1610 [07-18 18:05:17:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:200 timestamp:1689674717884 [07-18 18:05:17:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:16666500 ts:0 [07-18 18:05:17:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:16666500 [07-18 18:05:17:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:454799 dataSize:1610 [07-18 18:05:17:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:200 timestamp:1689674717884 [07-18 18:05:17:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:16699833 ts:0 [07-18 18:05:17:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:16699833 [07-18 18:05:17:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:456409 dataSize:516 [07-18 18:05:17:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:201 timestamp:1689674717918 [07-18 18:05:17:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:16699833 ts:0 [07-18 18:05:17:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:16699833 [07-18 18:05:17:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:456409 dataSize:516 [07-18 18:05:17:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:201 timestamp:1689674717918 [07-18 18:05:17:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:16733166 ts:0 [07-18 18:05:17:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:16733166 [07-18 18:05:17:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:456925 dataSize:231 [07-18 18:05:17:952 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:202 timestamp:1689674717952 [07-18 18:05:17:952 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:16733166 ts:0 [07-18 18:05:17:952 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:16733166 [07-18 18:05:17:952 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:456925 dataSize:231 [07-18 18:05:17:952 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:202 timestamp:1689674717952 [07-18 18:05:17:963 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:17:963 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:17:973 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:17:973 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 43, head index 202 [07-18 18:05:17:973 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 44, seqNo 344, timestamp 1689674712637 [07-18 18:05:17:973 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:17:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:16766499 ts:0 [07-18 18:05:17:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:16766499 [07-18 18:05:17:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:457156 dataSize:250 [07-18 18:05:17:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:203 timestamp:1689674717985 [07-18 18:05:17:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:16766499 ts:0 [07-18 18:05:17:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:16766499 [07-18 18:05:17:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:457156 dataSize:250 [07-18 18:05:17:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:203 timestamp:1689674717985 [07-18 18:05:18:19 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:16799832 ts:0 [07-18 18:05:18:19 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:16799832 [07-18 18:05:18:19 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:457406 dataSize:1143 [07-18 18:05:18:19 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:204 timestamp:1689674718019 [07-18 18:05:18:19 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:16799832 ts:0 [07-18 18:05:18:19 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:16799832 [07-18 18:05:18:19 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:457406 dataSize:1143 [07-18 18:05:18:19 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:204 timestamp:1689674718019 [07-18 18:05:18:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:16833165 ts:0 [07-18 18:05:18:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:16833165 [07-18 18:05:18:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:458549 dataSize:383 [07-18 18:05:18:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:205 timestamp:1689674718052 [07-18 18:05:18:53 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:16833165 ts:0 [07-18 18:05:18:53 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:16833165 [07-18 18:05:18:53 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:458549 dataSize:383 [07-18 18:05:18:53 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:205 timestamp:1689674718053 [07-18 18:05:18:83 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:83 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 44, head index 205 [07-18 18:05:18:83 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 45, seqNo 345, timestamp 1689674712671 [07-18 18:05:18:83 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:16866498 ts:0 [07-18 18:05:18:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:16866498 [07-18 18:05:18:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:458932 dataSize:235 [07-18 18:05:18:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:206 timestamp:1689674718086 [07-18 18:05:18:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:16866498 ts:0 [07-18 18:05:18:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:16866498 [07-18 18:05:18:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:458932 dataSize:235 [07-18 18:05:18:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:206 timestamp:1689674718086 [07-18 18:05:18:120 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:16899831 ts:0 [07-18 18:05:18:120 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:16899831 [07-18 18:05:18:120 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:459167 dataSize:165 [07-18 18:05:18:120 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:207 timestamp:1689674718120 [07-18 18:05:18:120 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:16899831 ts:0 [07-18 18:05:18:120 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:16899831 [07-18 18:05:18:120 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:459167 dataSize:165 [07-18 18:05:18:120 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:207 timestamp:1689674718120 [07-18 18:05:18:153 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:16933164 ts:0 [07-18 18:05:18:153 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:16933164 [07-18 18:05:18:153 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:459332 dataSize:457 [07-18 18:05:18:153 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:208 timestamp:1689674718153 [07-18 18:05:18:154 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:16933164 ts:0 [07-18 18:05:18:154 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:16933164 [07-18 18:05:18:154 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:459332 dataSize:457 [07-18 18:05:18:154 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:208 timestamp:1689674718154 [07-18 18:05:18:187 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:16966497 ts:0 [07-18 18:05:18:187 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:16966497 [07-18 18:05:18:187 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:459789 dataSize:673 [07-18 18:05:18:187 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:209 timestamp:1689674718187 [07-18 18:05:18:187 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:16966497 ts:0 [07-18 18:05:18:187 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:16966497 [07-18 18:05:18:187 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:459789 dataSize:673 [07-18 18:05:18:187 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:209 timestamp:1689674718187 [07-18 18:05:18:194 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:194 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 45, head index 209 [07-18 18:05:18:194 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 46, seqNo 346, timestamp 1689674712704 [07-18 18:05:18:194 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:221 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:16999830 ts:0 [07-18 18:05:18:221 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:16999830 [07-18 18:05:18:221 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:460462 dataSize:465 [07-18 18:05:18:221 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:210 timestamp:1689674718221 [07-18 18:05:18:221 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:16999830 ts:0 [07-18 18:05:18:221 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:16999830 [07-18 18:05:18:221 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:460462 dataSize:465 [07-18 18:05:18:221 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:210 timestamp:1689674718221 [07-18 18:05:18:254 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:17033163 ts:0 [07-18 18:05:18:254 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:17033163 [07-18 18:05:18:254 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:460927 dataSize:248 [07-18 18:05:18:254 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:211 timestamp:1689674718254 [07-18 18:05:18:254 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:17033163 ts:0 [07-18 18:05:18:254 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:17033163 [07-18 18:05:18:254 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:460927 dataSize:248 [07-18 18:05:18:254 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:211 timestamp:1689674718254 [07-18 18:05:18:288 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:17066496 ts:0 [07-18 18:05:18:288 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:17066496 [07-18 18:05:18:288 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:461175 dataSize:217 [07-18 18:05:18:288 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:212 timestamp:1689674718288 [07-18 18:05:18:288 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:17066496 ts:0 [07-18 18:05:18:288 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:17066496 [07-18 18:05:18:288 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:461175 dataSize:217 [07-18 18:05:18:288 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:212 timestamp:1689674718288 [07-18 18:05:18:304 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:304 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 46, head index 212 [07-18 18:05:18:304 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 47, seqNo 347, timestamp 1689674712738 [07-18 18:05:18:304 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:322 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:17099829 ts:0 [07-18 18:05:18:322 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:17099829 [07-18 18:05:18:322 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:461392 dataSize:280 [07-18 18:05:18:322 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:213 timestamp:1689674718322 [07-18 18:05:18:322 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:17099829 ts:0 [07-18 18:05:18:322 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:17099829 [07-18 18:05:18:322 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:461392 dataSize:280 [07-18 18:05:18:322 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:213 timestamp:1689674718322 [07-18 18:05:18:355 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:17133162 ts:0 [07-18 18:05:18:355 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:17133162 [07-18 18:05:18:355 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:461672 dataSize:12088 [07-18 18:05:18:355 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:214 timestamp:1689674718355 [07-18 18:05:18:355 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:17133162 ts:0 [07-18 18:05:18:355 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:17133162 [07-18 18:05:18:355 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:461672 dataSize:12088 [07-18 18:05:18:355 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:214 timestamp:1689674718355 [07-18 18:05:18:389 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:17166495 ts:0 [07-18 18:05:18:389 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:17166495 [07-18 18:05:18:389 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:473760 dataSize:1051 [07-18 18:05:18:389 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:215 timestamp:1689674718389 [07-18 18:05:18:389 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:17166495 ts:0 [07-18 18:05:18:389 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:17166495 [07-18 18:05:18:389 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:473760 dataSize:1051 [07-18 18:05:18:389 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:215 timestamp:1689674718389 [07-18 18:05:18:414 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:414 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 47, head index 215 [07-18 18:05:18:414 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 48, seqNo 348, timestamp 1689674712771 [07-18 18:05:18:414 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:423 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:17199828 ts:0 [07-18 18:05:18:423 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:17199828 [07-18 18:05:18:423 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:474811 dataSize:209 [07-18 18:05:18:423 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:216 timestamp:1689674718423 [07-18 18:05:18:423 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:17199828 ts:0 [07-18 18:05:18:423 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:17199828 [07-18 18:05:18:423 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:474811 dataSize:209 [07-18 18:05:18:423 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:216 timestamp:1689674718423 [07-18 18:05:18:456 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:17233161 ts:0 [07-18 18:05:18:456 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:17233161 [07-18 18:05:18:456 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:475020 dataSize:118 [07-18 18:05:18:456 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:217 timestamp:1689674718456 [07-18 18:05:18:456 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:17233161 ts:0 [07-18 18:05:18:456 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:17233161 [07-18 18:05:18:456 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:475020 dataSize:118 [07-18 18:05:18:456 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:217 timestamp:1689674718456 [07-18 18:05:18:490 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:17266494 ts:0 [07-18 18:05:18:490 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:17266494 [07-18 18:05:18:490 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:475138 dataSize:110 [07-18 18:05:18:490 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:218 timestamp:1689674718490 [07-18 18:05:18:490 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:17266494 ts:0 [07-18 18:05:18:490 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:17266494 [07-18 18:05:18:490 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:475138 dataSize:110 [07-18 18:05:18:490 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:218 timestamp:1689674718490 [07-18 18:05:18:524 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:17299827 ts:0 [07-18 18:05:18:524 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:17299827 [07-18 18:05:18:524 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:475248 dataSize:695 [07-18 18:05:18:524 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:219 timestamp:1689674718524 [07-18 18:05:18:524 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:17299827 ts:0 [07-18 18:05:18:524 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:17299827 [07-18 18:05:18:524 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:475248 dataSize:695 [07-18 18:05:18:524 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:219 timestamp:1689674718524 [07-18 18:05:18:524 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:524 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 48, head index 219 [07-18 18:05:18:524 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 49, seqNo 349, timestamp 1689674712805 [07-18 18:05:18:525 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:551 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:05:18:558 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:17333160 ts:0 [07-18 18:05:18:558 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:17333160 [07-18 18:05:18:558 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:475943 dataSize:1146 [07-18 18:05:18:558 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:220 timestamp:1689674718558 [07-18 18:05:18:558 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:17333160 ts:0 [07-18 18:05:18:558 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:17333160 [07-18 18:05:18:558 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:475943 dataSize:1146 [07-18 18:05:18:558 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:220 timestamp:1689674718558 [07-18 18:05:18:591 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:17366493 ts:0 [07-18 18:05:18:591 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:17366493 [07-18 18:05:18:591 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:477089 dataSize:276 [07-18 18:05:18:591 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:221 timestamp:1689674718591 [07-18 18:05:18:591 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:17366493 ts:0 [07-18 18:05:18:591 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:17366493 [07-18 18:05:18:591 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:477089 dataSize:276 [07-18 18:05:18:591 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:221 timestamp:1689674718591 [07-18 18:05:18:625 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:17399826 ts:0 [07-18 18:05:18:625 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:17399826 [07-18 18:05:18:625 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:477365 dataSize:152 [07-18 18:05:18:625 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:222 timestamp:1689674718625 [07-18 18:05:18:625 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:17399826 ts:0 [07-18 18:05:18:625 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:17399826 [07-18 18:05:18:625 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:477365 dataSize:152 [07-18 18:05:18:625 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:222 timestamp:1689674718625 [07-18 18:05:18:635 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:635 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 49, head index 222 [07-18 18:05:18:635 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 50, seqNo 350, timestamp 1689674712839 [07-18 18:05:18:635 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:658 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:17433159 ts:0 [07-18 18:05:18:659 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:17433159 [07-18 18:05:18:659 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:477517 dataSize:136 [07-18 18:05:18:659 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:223 timestamp:1689674718659 [07-18 18:05:18:659 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:17433159 ts:0 [07-18 18:05:18:659 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:17433159 [07-18 18:05:18:659 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:477517 dataSize:136 [07-18 18:05:18:659 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:223 timestamp:1689674718659 [07-18 18:05:18:692 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:17466492 ts:0 [07-18 18:05:18:692 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:17466492 [07-18 18:05:18:692 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:477653 dataSize:725 [07-18 18:05:18:692 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:224 timestamp:1689674718692 [07-18 18:05:18:692 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:17466492 ts:0 [07-18 18:05:18:692 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:17466492 [07-18 18:05:18:692 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:477653 dataSize:725 [07-18 18:05:18:692 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:224 timestamp:1689674718692 [07-18 18:05:18:726 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:17499825 ts:0 [07-18 18:05:18:726 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:17499825 [07-18 18:05:18:726 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:478378 dataSize:1369 [07-18 18:05:18:726 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:225 timestamp:1689674718726 [07-18 18:05:18:726 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:17499825 ts:0 [07-18 18:05:18:726 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:17499825 [07-18 18:05:18:726 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:478378 dataSize:1369 [07-18 18:05:18:726 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:225 timestamp:1689674718726 [07-18 18:05:18:745 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:745 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 50, head index 225 [07-18 18:05:18:745 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 51, seqNo 351, timestamp 1689674712872 [07-18 18:05:18:745 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:759 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:17533158 ts:0 [07-18 18:05:18:760 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:17533158 [07-18 18:05:18:760 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:479747 dataSize:367 [07-18 18:05:18:760 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:226 timestamp:1689674718760 [07-18 18:05:18:760 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:17533158 ts:0 [07-18 18:05:18:760 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:17533158 [07-18 18:05:18:760 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:479747 dataSize:367 [07-18 18:05:18:760 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:226 timestamp:1689674718760 [07-18 18:05:18:793 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:17566491 ts:0 [07-18 18:05:18:793 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:17566491 [07-18 18:05:18:793 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:480114 dataSize:141 [07-18 18:05:18:793 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:227 timestamp:1689674718793 [07-18 18:05:18:793 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:17566491 ts:0 [07-18 18:05:18:793 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:17566491 [07-18 18:05:18:793 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:480114 dataSize:141 [07-18 18:05:18:793 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:227 timestamp:1689674718793 [07-18 18:05:18:827 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:17599824 ts:0 [07-18 18:05:18:827 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:17599824 [07-18 18:05:18:827 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:480255 dataSize:160 [07-18 18:05:18:827 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:228 timestamp:1689674718827 [07-18 18:05:18:827 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:17599824 ts:0 [07-18 18:05:18:827 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:17599824 [07-18 18:05:18:827 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:480255 dataSize:160 [07-18 18:05:18:827 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:228 timestamp:1689674718827 [07-18 18:05:18:855 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:855 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 51, head index 228 [07-18 18:05:18:855 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 52, seqNo 352, timestamp 1689674712906 [07-18 18:05:18:855 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:860 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:17633157 ts:0 [07-18 18:05:18:860 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:17633157 [07-18 18:05:18:860 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:480415 dataSize:756 [07-18 18:05:18:861 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:229 timestamp:1689674718861 [07-18 18:05:18:861 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:17633157 ts:0 [07-18 18:05:18:861 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:17633157 [07-18 18:05:18:861 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:480415 dataSize:756 [07-18 18:05:18:861 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:229 timestamp:1689674718861 [07-18 18:05:18:894 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:17666490 ts:0 [07-18 18:05:18:894 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:17666490 [07-18 18:05:18:894 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:481171 dataSize:1610 [07-18 18:05:18:894 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:230 timestamp:1689674718894 [07-18 18:05:18:894 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:17666490 ts:0 [07-18 18:05:18:894 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:17666490 [07-18 18:05:18:894 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:481171 dataSize:1610 [07-18 18:05:18:894 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:230 timestamp:1689674718894 [07-18 18:05:18:928 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:17699823 ts:0 [07-18 18:05:18:928 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:17699823 [07-18 18:05:18:928 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:482781 dataSize:516 [07-18 18:05:18:928 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:231 timestamp:1689674718928 [07-18 18:05:18:928 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:17699823 ts:0 [07-18 18:05:18:928 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:17699823 [07-18 18:05:18:928 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:482781 dataSize:516 [07-18 18:05:18:928 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:231 timestamp:1689674718928 [07-18 18:05:18:961 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:17733156 ts:0 [07-18 18:05:18:961 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:17733156 [07-18 18:05:18:961 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:483297 dataSize:231 [07-18 18:05:18:961 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:232 timestamp:1689674718961 [07-18 18:05:18:961 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:17733156 ts:0 [07-18 18:05:18:961 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:17733156 [07-18 18:05:18:961 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:483297 dataSize:231 [07-18 18:05:18:961 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:232 timestamp:1689674718961 [07-18 18:05:18:964 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:18:965 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:18:966 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:18:966 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 52, head index 232 [07-18 18:05:18:966 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 53, seqNo 353, timestamp 1689674712939 [07-18 18:05:18:966 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:18:995 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:17766489 ts:0 [07-18 18:05:18:995 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:17766489 [07-18 18:05:18:995 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:483528 dataSize:250 [07-18 18:05:18:995 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:233 timestamp:1689674718995 [07-18 18:05:18:995 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:17766489 ts:0 [07-18 18:05:18:995 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:17766489 [07-18 18:05:18:995 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:483528 dataSize:250 [07-18 18:05:18:995 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:233 timestamp:1689674718995 [07-18 18:05:19:29 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:17799822 ts:0 [07-18 18:05:19:29 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:17799822 [07-18 18:05:19:29 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:483778 dataSize:1143 [07-18 18:05:19:29 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:234 timestamp:1689674719029 [07-18 18:05:19:29 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:17799822 ts:0 [07-18 18:05:19:29 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:17799822 [07-18 18:05:19:29 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:483778 dataSize:1143 [07-18 18:05:19:29 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:234 timestamp:1689674719029 [07-18 18:05:19:62 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:17833155 ts:0 [07-18 18:05:19:62 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:17833155 [07-18 18:05:19:62 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:484921 dataSize:383 [07-18 18:05:19:62 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:235 timestamp:1689674719062 [07-18 18:05:19:62 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:17833155 ts:0 [07-18 18:05:19:62 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:17833155 [07-18 18:05:19:62 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:484921 dataSize:383 [07-18 18:05:19:62 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:235 timestamp:1689674719062 [07-18 18:05:19:76 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:76 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 53, head index 235 [07-18 18:05:19:76 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 54, seqNo 354, timestamp 1689674712973 [07-18 18:05:19:76 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:96 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:17866488 ts:0 [07-18 18:05:19:96 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:17866488 [07-18 18:05:19:96 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:485304 dataSize:235 [07-18 18:05:19:96 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:236 timestamp:1689674719096 [07-18 18:05:19:96 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:17866488 ts:0 [07-18 18:05:19:96 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:17866488 [07-18 18:05:19:96 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:485304 dataSize:235 [07-18 18:05:19:96 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:236 timestamp:1689674719096 [07-18 18:05:19:105 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:05:19:105 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:05:19:105 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:34 [07-18 18:05:19:116 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[1]lstCnt[145]vIFrameCnt[145] [07-18 18:05:19:116 TUYA Debug][tuya_ipc_p2p.c:5031] session[131073] detech staticCnt[0]lstCnt[3]vIFrameCnt[3] [07-18 18:05:19:130 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:17899821 ts:0 [07-18 18:05:19:130 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:17899821 [07-18 18:05:19:130 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:485539 dataSize:165 [07-18 18:05:19:130 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:237 timestamp:1689674719130 [07-18 18:05:19:130 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:17899821 ts:0 [07-18 18:05:19:130 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:17899821 [07-18 18:05:19:130 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:485539 dataSize:165 [07-18 18:05:19:130 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:237 timestamp:1689674719130 [07-18 18:05:19:163 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:17933154 ts:0 [07-18 18:05:19:163 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:17933154 [07-18 18:05:19:163 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:485704 dataSize:457 [07-18 18:05:19:163 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:238 timestamp:1689674719163 [07-18 18:05:19:163 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:17933154 ts:0 [07-18 18:05:19:163 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:17933154 [07-18 18:05:19:163 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:485704 dataSize:457 [07-18 18:05:19:163 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:238 timestamp:1689674719163 [07-18 18:05:19:186 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:186 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 54, head index 238 [07-18 18:05:19:187 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 55, seqNo 355, timestamp 1689674713006 [07-18 18:05:19:187 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:197 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:17966487 ts:0 [07-18 18:05:19:197 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:17966487 [07-18 18:05:19:197 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:486161 dataSize:673 [07-18 18:05:19:197 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:239 timestamp:1689674719197 [07-18 18:05:19:197 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:17966487 ts:0 [07-18 18:05:19:197 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:17966487 [07-18 18:05:19:197 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:486161 dataSize:673 [07-18 18:05:19:197 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:239 timestamp:1689674719197 [07-18 18:05:19:230 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:17999820 ts:0 [07-18 18:05:19:230 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:17999820 [07-18 18:05:19:230 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:486834 dataSize:465 [07-18 18:05:19:230 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:240 timestamp:1689674719230 [07-18 18:05:19:230 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:17999820 ts:0 [07-18 18:05:19:230 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:17999820 [07-18 18:05:19:230 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:486834 dataSize:465 [07-18 18:05:19:230 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:240 timestamp:1689674719230 [07-18 18:05:19:264 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:18033153 ts:0 [07-18 18:05:19:264 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:18033153 [07-18 18:05:19:264 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:487299 dataSize:248 [07-18 18:05:19:264 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:241 timestamp:1689674719264 [07-18 18:05:19:264 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:18033153 ts:0 [07-18 18:05:19:264 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:18033153 [07-18 18:05:19:264 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:487299 dataSize:248 [07-18 18:05:19:264 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:241 timestamp:1689674719264 [07-18 18:05:19:297 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:297 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 55, head index 241 [07-18 18:05:19:297 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 56, seqNo 356, timestamp 1689674713040 [07-18 18:05:19:297 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:298 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:18066486 ts:0 [07-18 18:05:19:298 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:18066486 [07-18 18:05:19:298 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:487547 dataSize:217 [07-18 18:05:19:298 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:242 timestamp:1689674719298 [07-18 18:05:19:298 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:18066486 ts:0 [07-18 18:05:19:298 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:18066486 [07-18 18:05:19:298 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:487547 dataSize:217 [07-18 18:05:19:298 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:242 timestamp:1689674719298 [07-18 18:05:19:331 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:18099819 ts:0 [07-18 18:05:19:331 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:18099819 [07-18 18:05:19:331 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:487764 dataSize:280 [07-18 18:05:19:331 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:243 timestamp:1689674719331 [07-18 18:05:19:331 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:18099819 ts:0 [07-18 18:05:19:331 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:18099819 [07-18 18:05:19:331 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:487764 dataSize:280 [07-18 18:05:19:331 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:243 timestamp:1689674719331 [07-18 18:05:19:365 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:18133152 ts:0 [07-18 18:05:19:365 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:18133152 [07-18 18:05:19:365 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:488044 dataSize:12088 [07-18 18:05:19:365 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:244 timestamp:1689674719365 [07-18 18:05:19:365 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:18133152 ts:0 [07-18 18:05:19:365 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:18133152 [07-18 18:05:19:365 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:488044 dataSize:12088 [07-18 18:05:19:365 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:244 timestamp:1689674719365 [07-18 18:05:19:399 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:18166485 ts:0 [07-18 18:05:19:399 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:18166485 [07-18 18:05:19:399 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:500132 dataSize:1051 [07-18 18:05:19:399 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:245 timestamp:1689674719399 [07-18 18:05:19:399 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:18166485 ts:0 [07-18 18:05:19:399 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:18166485 [07-18 18:05:19:399 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:500132 dataSize:1051 [07-18 18:05:19:399 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:245 timestamp:1689674719399 [07-18 18:05:19:407 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:407 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 56, head index 245 [07-18 18:05:19:407 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 57, seqNo 357, timestamp 1689674713074 [07-18 18:05:19:408 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:432 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:18199818 ts:0 [07-18 18:05:19:432 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:18199818 [07-18 18:05:19:432 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:501183 dataSize:209 [07-18 18:05:19:432 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:246 timestamp:1689674719432 [07-18 18:05:19:432 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:18199818 ts:0 [07-18 18:05:19:432 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:18199818 [07-18 18:05:19:432 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:501183 dataSize:209 [07-18 18:05:19:432 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:246 timestamp:1689674719432 [07-18 18:05:19:466 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:18233151 ts:0 [07-18 18:05:19:466 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:18233151 [07-18 18:05:19:466 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:501392 dataSize:118 [07-18 18:05:19:466 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:247 timestamp:1689674719466 [07-18 18:05:19:466 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:18233151 ts:0 [07-18 18:05:19:466 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:18233151 [07-18 18:05:19:466 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:501392 dataSize:118 [07-18 18:05:19:466 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:247 timestamp:1689674719466 [07-18 18:05:19:499 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:18266484 ts:0 [07-18 18:05:19:500 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:18266484 [07-18 18:05:19:500 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:501510 dataSize:110 [07-18 18:05:19:500 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:248 timestamp:1689674719500 [07-18 18:05:19:500 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:18266484 ts:0 [07-18 18:05:19:500 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:18266484 [07-18 18:05:19:500 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:501510 dataSize:110 [07-18 18:05:19:500 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:248 timestamp:1689674719500 [07-18 18:05:19:518 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:518 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 57, head index 248 [07-18 18:05:19:518 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 58, seqNo 358, timestamp 1689674713107 [07-18 18:05:19:518 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:533 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:18299817 ts:0 [07-18 18:05:19:533 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:18299817 [07-18 18:05:19:533 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:501620 dataSize:695 [07-18 18:05:19:533 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:249 timestamp:1689674719533 [07-18 18:05:19:533 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:18299817 ts:0 [07-18 18:05:19:533 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:18299817 [07-18 18:05:19:533 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:501620 dataSize:695 [07-18 18:05:19:533 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:249 timestamp:1689674719533 [07-18 18:05:19:567 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:18333150 ts:0 [07-18 18:05:19:567 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:18333150 [07-18 18:05:19:567 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:502315 dataSize:1146 [07-18 18:05:19:567 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:250 timestamp:1689674719567 [07-18 18:05:19:567 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:18333150 ts:0 [07-18 18:05:19:567 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:18333150 [07-18 18:05:19:567 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:502315 dataSize:1146 [07-18 18:05:19:567 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:250 timestamp:1689674719567 [07-18 18:05:19:600 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:18366483 ts:0 [07-18 18:05:19:600 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:18366483 [07-18 18:05:19:600 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:503461 dataSize:276 [07-18 18:05:19:600 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:251 timestamp:1689674719600 [07-18 18:05:19:600 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:18366483 ts:0 [07-18 18:05:19:600 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:18366483 [07-18 18:05:19:600 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:503461 dataSize:276 [07-18 18:05:19:600 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:251 timestamp:1689674719600 [07-18 18:05:19:629 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:629 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 58, head index 251 [07-18 18:05:19:629 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 59, seqNo 359, timestamp 1689674713141 [07-18 18:05:19:629 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:634 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:18399816 ts:0 [07-18 18:05:19:634 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:18399816 [07-18 18:05:19:634 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:503737 dataSize:152 [07-18 18:05:19:634 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:252 timestamp:1689674719634 [07-18 18:05:19:634 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:18399816 ts:0 [07-18 18:05:19:634 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:18399816 [07-18 18:05:19:634 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:503737 dataSize:152 [07-18 18:05:19:634 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:252 timestamp:1689674719634 [07-18 18:05:19:668 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:18433149 ts:0 [07-18 18:05:19:668 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:18433149 [07-18 18:05:19:668 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:503889 dataSize:136 [07-18 18:05:19:668 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:253 timestamp:1689674719668 [07-18 18:05:19:668 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:18433149 ts:0 [07-18 18:05:19:668 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:18433149 [07-18 18:05:19:668 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:503889 dataSize:136 [07-18 18:05:19:668 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:253 timestamp:1689674719668 [07-18 18:05:19:701 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:18466482 ts:0 [07-18 18:05:19:701 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:18466482 [07-18 18:05:19:701 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:504025 dataSize:725 [07-18 18:05:19:701 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:254 timestamp:1689674719701 [07-18 18:05:19:701 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:18466482 ts:0 [07-18 18:05:19:701 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:18466482 [07-18 18:05:19:701 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:504025 dataSize:725 [07-18 18:05:19:701 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:254 timestamp:1689674719701 [07-18 18:05:19:735 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:18499815 ts:0 [07-18 18:05:19:735 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:18499815 [07-18 18:05:19:735 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:504750 dataSize:1369 [07-18 18:05:19:735 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:255 timestamp:1689674719735 [07-18 18:05:19:735 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:18499815 ts:0 [07-18 18:05:19:735 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:18499815 [07-18 18:05:19:735 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:504750 dataSize:1369 [07-18 18:05:19:735 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:255 timestamp:1689674719735 [07-18 18:05:19:739 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:739 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 59, head index 255 [07-18 18:05:19:739 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 60, seqNo 360, timestamp 1689674713175 [07-18 18:05:19:739 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:768 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:18533148 ts:0 [07-18 18:05:19:768 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:18533148 [07-18 18:05:19:768 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:506119 dataSize:367 [07-18 18:05:19:768 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:256 timestamp:1689674719768 [07-18 18:05:19:768 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:18533148 ts:0 [07-18 18:05:19:768 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:18533148 [07-18 18:05:19:768 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:506119 dataSize:367 [07-18 18:05:19:768 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:256 timestamp:1689674719768 [07-18 18:05:19:802 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:18566481 ts:0 [07-18 18:05:19:802 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:18566481 [07-18 18:05:19:802 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:506486 dataSize:141 [07-18 18:05:19:802 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:257 timestamp:1689674719802 [07-18 18:05:19:802 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:18566481 ts:0 [07-18 18:05:19:802 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:18566481 [07-18 18:05:19:802 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:506486 dataSize:141 [07-18 18:05:19:802 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:257 timestamp:1689674719802 [07-18 18:05:19:835 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:18599814 ts:0 [07-18 18:05:19:836 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:18599814 [07-18 18:05:19:836 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:506627 dataSize:160 [07-18 18:05:19:836 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:258 timestamp:1689674719836 [07-18 18:05:19:836 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:18599814 ts:0 [07-18 18:05:19:836 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:18599814 [07-18 18:05:19:836 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:506627 dataSize:160 [07-18 18:05:19:836 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:258 timestamp:1689674719836 [07-18 18:05:19:849 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:849 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 60, head index 258 [07-18 18:05:19:849 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 61, seqNo 361, timestamp 1689674713208 [07-18 18:05:19:849 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:869 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:18633147 ts:0 [07-18 18:05:19:869 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:18633147 [07-18 18:05:19:869 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:506787 dataSize:756 [07-18 18:05:19:869 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:259 timestamp:1689674719869 [07-18 18:05:19:869 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:18633147 ts:0 [07-18 18:05:19:869 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:18633147 [07-18 18:05:19:869 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:506787 dataSize:756 [07-18 18:05:19:869 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:259 timestamp:1689674719869 [07-18 18:05:19:903 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:18666480 ts:0 [07-18 18:05:19:903 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:18666480 [07-18 18:05:19:903 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:507543 dataSize:1610 [07-18 18:05:19:903 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:260 timestamp:1689674719903 [07-18 18:05:19:903 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:18666480 ts:0 [07-18 18:05:19:903 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:18666480 [07-18 18:05:19:903 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:507543 dataSize:1610 [07-18 18:05:19:903 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:260 timestamp:1689674719903 [07-18 18:05:19:936 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:18699813 ts:0 [07-18 18:05:19:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:18699813 [07-18 18:05:19:937 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:509153 dataSize:516 [07-18 18:05:19:937 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:261 timestamp:1689674719937 [07-18 18:05:19:937 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:18699813 ts:0 [07-18 18:05:19:937 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:18699813 [07-18 18:05:19:937 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:509153 dataSize:516 [07-18 18:05:19:937 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:261 timestamp:1689674719937 [07-18 18:05:19:960 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:19:960 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 61, head index 261 [07-18 18:05:19:960 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 62, seqNo 362, timestamp 1689674713242 [07-18 18:05:19:960 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:19:966 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:19:966 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:19:970 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:18733146 ts:0 [07-18 18:05:19:970 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:18733146 [07-18 18:05:19:970 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:509669 dataSize:231 [07-18 18:05:19:970 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:262 timestamp:1689674719970 [07-18 18:05:19:970 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:18733146 ts:0 [07-18 18:05:19:970 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:18733146 [07-18 18:05:19:970 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:509669 dataSize:231 [07-18 18:05:19:970 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:262 timestamp:1689674719970 [07-18 18:05:20:4 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:18766479 ts:0 [07-18 18:05:20:4 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:18766479 [07-18 18:05:20:4 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:509900 dataSize:250 [07-18 18:05:20:4 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:263 timestamp:1689674720004 [07-18 18:05:20:4 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:18766479 ts:0 [07-18 18:05:20:4 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:18766479 [07-18 18:05:20:4 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:509900 dataSize:250 [07-18 18:05:20:4 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:263 timestamp:1689674720004 [07-18 18:05:20:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:18799812 ts:0 [07-18 18:05:20:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:18799812 [07-18 18:05:20:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:510150 dataSize:1143 [07-18 18:05:20:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:264 timestamp:1689674720037 [07-18 18:05:20:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:18799812 ts:0 [07-18 18:05:20:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:18799812 [07-18 18:05:20:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:510150 dataSize:1143 [07-18 18:05:20:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:264 timestamp:1689674720037 [07-18 18:05:20:70 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:70 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 62, head index 264 [07-18 18:05:20:70 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 63, seqNo 363, timestamp 1689674713275 [07-18 18:05:20:70 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:71 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:18833145 ts:0 [07-18 18:05:20:71 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:18833145 [07-18 18:05:20:71 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:511293 dataSize:383 [07-18 18:05:20:71 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:265 timestamp:1689674720071 [07-18 18:05:20:71 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:18833145 ts:0 [07-18 18:05:20:71 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:18833145 [07-18 18:05:20:71 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:511293 dataSize:383 [07-18 18:05:20:71 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:265 timestamp:1689674720071 [07-18 18:05:20:104 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:18866478 ts:0 [07-18 18:05:20:105 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:18866478 [07-18 18:05:20:105 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:511676 dataSize:235 [07-18 18:05:20:105 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:266 timestamp:1689674720105 [07-18 18:05:20:105 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:18866478 ts:0 [07-18 18:05:20:105 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:18866478 [07-18 18:05:20:105 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:511676 dataSize:235 [07-18 18:05:20:105 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:266 timestamp:1689674720105 [07-18 18:05:20:138 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:18899811 ts:0 [07-18 18:05:20:138 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:18899811 [07-18 18:05:20:138 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:511911 dataSize:165 [07-18 18:05:20:138 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:267 timestamp:1689674720138 [07-18 18:05:20:138 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:18899811 ts:0 [07-18 18:05:20:138 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:18899811 [07-18 18:05:20:138 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:511911 dataSize:165 [07-18 18:05:20:138 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:267 timestamp:1689674720138 [07-18 18:05:20:172 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:18933144 ts:0 [07-18 18:05:20:172 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:18933144 [07-18 18:05:20:172 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:512076 dataSize:457 [07-18 18:05:20:172 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:268 timestamp:1689674720172 [07-18 18:05:20:172 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:18933144 ts:0 [07-18 18:05:20:172 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:18933144 [07-18 18:05:20:172 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:512076 dataSize:457 [07-18 18:05:20:172 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:268 timestamp:1689674720172 [07-18 18:05:20:180 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:180 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 63, head index 268 [07-18 18:05:20:180 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 64, seqNo 364, timestamp 1689674713309 [07-18 18:05:20:181 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:205 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:18966477 ts:0 [07-18 18:05:20:205 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:18966477 [07-18 18:05:20:205 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:512533 dataSize:673 [07-18 18:05:20:205 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:269 timestamp:1689674720205 [07-18 18:05:20:205 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:18966477 ts:0 [07-18 18:05:20:205 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:18966477 [07-18 18:05:20:205 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:512533 dataSize:673 [07-18 18:05:20:205 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:269 timestamp:1689674720205 [07-18 18:05:20:239 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:18999810 ts:0 [07-18 18:05:20:239 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:18999810 [07-18 18:05:20:239 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:513206 dataSize:465 [07-18 18:05:20:239 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:270 timestamp:1689674720239 [07-18 18:05:20:239 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:18999810 ts:0 [07-18 18:05:20:239 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:18999810 [07-18 18:05:20:239 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:513206 dataSize:465 [07-18 18:05:20:239 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:270 timestamp:1689674720239 [07-18 18:05:20:273 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:19033143 ts:0 [07-18 18:05:20:273 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:19033143 [07-18 18:05:20:273 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:513671 dataSize:248 [07-18 18:05:20:273 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:271 timestamp:1689674720273 [07-18 18:05:20:273 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:19033143 ts:0 [07-18 18:05:20:273 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:19033143 [07-18 18:05:20:273 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:513671 dataSize:248 [07-18 18:05:20:273 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:271 timestamp:1689674720273 [07-18 18:05:20:291 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:291 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 64, head index 271 [07-18 18:05:20:291 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 65, seqNo 365, timestamp 1689674713343 [07-18 18:05:20:291 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:306 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:19066476 ts:0 [07-18 18:05:20:306 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:19066476 [07-18 18:05:20:306 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:513919 dataSize:217 [07-18 18:05:20:306 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:272 timestamp:1689674720306 [07-18 18:05:20:306 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:19066476 ts:0 [07-18 18:05:20:306 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:19066476 [07-18 18:05:20:306 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:513919 dataSize:217 [07-18 18:05:20:306 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:272 timestamp:1689674720306 [07-18 18:05:20:340 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:19099809 ts:0 [07-18 18:05:20:340 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:19099809 [07-18 18:05:20:340 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:514136 dataSize:280 [07-18 18:05:20:340 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:273 timestamp:1689674720340 [07-18 18:05:20:340 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:19099809 ts:0 [07-18 18:05:20:340 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:19099809 [07-18 18:05:20:340 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:514136 dataSize:280 [07-18 18:05:20:340 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:273 timestamp:1689674720340 [07-18 18:05:20:373 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:19133142 ts:0 [07-18 18:05:20:373 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:19133142 [07-18 18:05:20:374 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:514416 dataSize:12088 [07-18 18:05:20:374 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:274 timestamp:1689674720374 [07-18 18:05:20:374 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:19133142 ts:0 [07-18 18:05:20:374 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:19133142 [07-18 18:05:20:374 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:514416 dataSize:12088 [07-18 18:05:20:374 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:274 timestamp:1689674720374 [07-18 18:05:20:402 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:402 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 65, head index 274 [07-18 18:05:20:402 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 66, seqNo 366, timestamp 1689674713376 [07-18 18:05:20:402 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:407 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:19166475 ts:0 [07-18 18:05:20:407 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:19166475 [07-18 18:05:20:407 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:526504 dataSize:1051 [07-18 18:05:20:407 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:275 timestamp:1689674720407 [07-18 18:05:20:407 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:19166475 ts:0 [07-18 18:05:20:407 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:19166475 [07-18 18:05:20:407 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:526504 dataSize:1051 [07-18 18:05:20:407 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:275 timestamp:1689674720407 [07-18 18:05:20:441 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:19199808 ts:0 [07-18 18:05:20:441 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:19199808 [07-18 18:05:20:441 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:527555 dataSize:209 [07-18 18:05:20:441 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:276 timestamp:1689674720441 [07-18 18:05:20:441 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:19199808 ts:0 [07-18 18:05:20:441 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:19199808 [07-18 18:05:20:441 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:527555 dataSize:209 [07-18 18:05:20:441 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:276 timestamp:1689674720441 [07-18 18:05:20:474 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:19233141 ts:0 [07-18 18:05:20:474 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:19233141 [07-18 18:05:20:474 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:527764 dataSize:118 [07-18 18:05:20:474 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:277 timestamp:1689674720474 [07-18 18:05:20:474 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:19233141 ts:0 [07-18 18:05:20:474 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:19233141 [07-18 18:05:20:474 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:527764 dataSize:118 [07-18 18:05:20:474 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:277 timestamp:1689674720474 [07-18 18:05:20:508 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:19266474 ts:0 [07-18 18:05:20:508 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:19266474 [07-18 18:05:20:508 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:527882 dataSize:110 [07-18 18:05:20:508 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:278 timestamp:1689674720508 [07-18 18:05:20:508 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:19266474 ts:0 [07-18 18:05:20:508 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:19266474 [07-18 18:05:20:508 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:527882 dataSize:110 [07-18 18:05:20:508 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:278 timestamp:1689674720508 [07-18 18:05:20:512 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:512 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 66, head index 278 [07-18 18:05:20:512 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 67, seqNo 367, timestamp 1689674713410 [07-18 18:05:20:512 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:542 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:19299807 ts:0 [07-18 18:05:20:542 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:19299807 [07-18 18:05:20:542 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:527992 dataSize:695 [07-18 18:05:20:542 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:279 timestamp:1689674720542 [07-18 18:05:20:542 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:19299807 ts:0 [07-18 18:05:20:542 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:19299807 [07-18 18:05:20:542 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:527992 dataSize:695 [07-18 18:05:20:542 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:279 timestamp:1689674720542 [07-18 18:05:20:575 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:19333140 ts:0 [07-18 18:05:20:575 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:19333140 [07-18 18:05:20:575 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:528687 dataSize:1146 [07-18 18:05:20:575 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:280 timestamp:1689674720575 [07-18 18:05:20:575 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:19333140 ts:0 [07-18 18:05:20:575 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:19333140 [07-18 18:05:20:575 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:528687 dataSize:1146 [07-18 18:05:20:575 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:280 timestamp:1689674720575 [07-18 18:05:20:609 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:19366473 ts:0 [07-18 18:05:20:609 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:19366473 [07-18 18:05:20:609 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:529833 dataSize:276 [07-18 18:05:20:609 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:281 timestamp:1689674720609 [07-18 18:05:20:609 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:19366473 ts:0 [07-18 18:05:20:609 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:19366473 [07-18 18:05:20:609 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:529833 dataSize:276 [07-18 18:05:20:609 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:281 timestamp:1689674720609 [07-18 18:05:20:622 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:622 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 67, head index 281 [07-18 18:05:20:622 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 68, seqNo 368, timestamp 1689674713444 [07-18 18:05:20:623 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:643 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:19399806 ts:0 [07-18 18:05:20:643 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:19399806 [07-18 18:05:20:643 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:530109 dataSize:152 [07-18 18:05:20:643 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:282 timestamp:1689674720643 [07-18 18:05:20:643 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:19399806 ts:0 [07-18 18:05:20:643 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:19399806 [07-18 18:05:20:643 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:530109 dataSize:152 [07-18 18:05:20:643 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:282 timestamp:1689674720643 [07-18 18:05:20:676 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:19433139 ts:0 [07-18 18:05:20:676 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:19433139 [07-18 18:05:20:676 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:530261 dataSize:136 [07-18 18:05:20:676 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:283 timestamp:1689674720676 [07-18 18:05:20:676 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:19433139 ts:0 [07-18 18:05:20:676 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:19433139 [07-18 18:05:20:676 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:530261 dataSize:136 [07-18 18:05:20:676 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:283 timestamp:1689674720676 [07-18 18:05:20:710 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:19466472 ts:0 [07-18 18:05:20:710 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:19466472 [07-18 18:05:20:710 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:530397 dataSize:725 [07-18 18:05:20:710 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:284 timestamp:1689674720710 [07-18 18:05:20:710 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:19466472 ts:0 [07-18 18:05:20:710 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:19466472 [07-18 18:05:20:710 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:530397 dataSize:725 [07-18 18:05:20:710 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:284 timestamp:1689674720710 [07-18 18:05:20:733 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:733 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 68, head index 284 [07-18 18:05:20:733 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 69, seqNo 369, timestamp 1689674713477 [07-18 18:05:20:733 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:743 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:19499805 ts:0 [07-18 18:05:20:743 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:19499805 [07-18 18:05:20:743 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:531122 dataSize:1369 [07-18 18:05:20:743 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:285 timestamp:1689674720743 [07-18 18:05:20:743 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:19499805 ts:0 [07-18 18:05:20:743 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:19499805 [07-18 18:05:20:743 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:531122 dataSize:1369 [07-18 18:05:20:743 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:285 timestamp:1689674720743 [07-18 18:05:20:777 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:19533138 ts:0 [07-18 18:05:20:777 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:19533138 [07-18 18:05:20:777 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:532491 dataSize:367 [07-18 18:05:20:777 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:286 timestamp:1689674720777 [07-18 18:05:20:777 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:19533138 ts:0 [07-18 18:05:20:777 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:19533138 [07-18 18:05:20:777 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:532491 dataSize:367 [07-18 18:05:20:777 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:286 timestamp:1689674720777 [07-18 18:05:20:811 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:19566471 ts:0 [07-18 18:05:20:811 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:19566471 [07-18 18:05:20:811 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:532858 dataSize:141 [07-18 18:05:20:811 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:287 timestamp:1689674720811 [07-18 18:05:20:811 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:19566471 ts:0 [07-18 18:05:20:811 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:19566471 [07-18 18:05:20:811 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:532858 dataSize:141 [07-18 18:05:20:811 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:287 timestamp:1689674720811 [07-18 18:05:20:843 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:843 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 69, head index 287 [07-18 18:05:20:843 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 70, seqNo 370, timestamp 1689674713511 [07-18 18:05:20:843 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:844 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:19599804 ts:0 [07-18 18:05:20:844 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:19599804 [07-18 18:05:20:844 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:532999 dataSize:160 [07-18 18:05:20:844 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:288 timestamp:1689674720844 [07-18 18:05:20:844 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:19599804 ts:0 [07-18 18:05:20:844 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:19599804 [07-18 18:05:20:844 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:532999 dataSize:160 [07-18 18:05:20:845 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:288 timestamp:1689674720845 [07-18 18:05:20:878 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:19633137 ts:0 [07-18 18:05:20:878 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:19633137 [07-18 18:05:20:878 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:533159 dataSize:756 [07-18 18:05:20:878 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:289 timestamp:1689674720878 [07-18 18:05:20:878 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:19633137 ts:0 [07-18 18:05:20:878 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:19633137 [07-18 18:05:20:878 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:533159 dataSize:756 [07-18 18:05:20:878 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:289 timestamp:1689674720878 [07-18 18:05:20:912 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:19666470 ts:0 [07-18 18:05:20:912 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:19666470 [07-18 18:05:20:912 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:533915 dataSize:1610 [07-18 18:05:20:912 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:290 timestamp:1689674720912 [07-18 18:05:20:912 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:19666470 ts:0 [07-18 18:05:20:912 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:19666470 [07-18 18:05:20:912 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:533915 dataSize:1610 [07-18 18:05:20:912 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:290 timestamp:1689674720912 [07-18 18:05:20:945 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:19699803 ts:0 [07-18 18:05:20:945 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:19699803 [07-18 18:05:20:945 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:535525 dataSize:516 [07-18 18:05:20:945 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:291 timestamp:1689674720945 [07-18 18:05:20:945 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:19699803 ts:0 [07-18 18:05:20:945 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:19699803 [07-18 18:05:20:945 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:535525 dataSize:516 [07-18 18:05:20:945 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:291 timestamp:1689674720945 [07-18 18:05:20:954 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:20:954 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 70, head index 291 [07-18 18:05:20:954 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 71, seqNo 371, timestamp 1689674713545 [07-18 18:05:20:954 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:20:967 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:20:967 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:20:979 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:19733136 ts:0 [07-18 18:05:20:979 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:19733136 [07-18 18:05:20:979 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:536041 dataSize:231 [07-18 18:05:20:979 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:292 timestamp:1689674720979 [07-18 18:05:20:979 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:19733136 ts:0 [07-18 18:05:20:979 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:19733136 [07-18 18:05:20:979 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:536041 dataSize:231 [07-18 18:05:20:979 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:292 timestamp:1689674720979 [07-18 18:05:21:13 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:19766469 ts:0 [07-18 18:05:21:13 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:19766469 [07-18 18:05:21:13 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:536272 dataSize:250 [07-18 18:05:21:13 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:293 timestamp:1689674721013 [07-18 18:05:21:13 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:19766469 ts:0 [07-18 18:05:21:13 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:19766469 [07-18 18:05:21:13 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:536272 dataSize:250 [07-18 18:05:21:13 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:293 timestamp:1689674721013 [07-18 18:05:21:46 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:19799802 ts:0 [07-18 18:05:21:46 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:19799802 [07-18 18:05:21:46 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:536522 dataSize:1143 [07-18 18:05:21:46 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:294 timestamp:1689674721046 [07-18 18:05:21:46 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:19799802 ts:0 [07-18 18:05:21:46 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:19799802 [07-18 18:05:21:46 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:536522 dataSize:1143 [07-18 18:05:21:46 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:294 timestamp:1689674721046 [07-18 18:05:21:64 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:64 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 71, head index 294 [07-18 18:05:21:64 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 72, seqNo 372, timestamp 1689674713578 [07-18 18:05:21:64 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:80 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:19833135 ts:0 [07-18 18:05:21:80 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:19833135 [07-18 18:05:21:80 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:537665 dataSize:383 [07-18 18:05:21:80 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:295 timestamp:1689674721080 [07-18 18:05:21:80 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:19833135 ts:0 [07-18 18:05:21:80 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:19833135 [07-18 18:05:21:80 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:537665 dataSize:383 [07-18 18:05:21:80 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:295 timestamp:1689674721080 [07-18 18:05:21:113 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:19866468 ts:0 [07-18 18:05:21:113 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:19866468 [07-18 18:05:21:114 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:538048 dataSize:235 [07-18 18:05:21:114 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:296 timestamp:1689674721114 [07-18 18:05:21:114 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:19866468 ts:0 [07-18 18:05:21:114 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:19866468 [07-18 18:05:21:114 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:538048 dataSize:235 [07-18 18:05:21:114 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:296 timestamp:1689674721114 [07-18 18:05:21:147 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:19899801 ts:0 [07-18 18:05:21:147 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:19899801 [07-18 18:05:21:147 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:538283 dataSize:165 [07-18 18:05:21:147 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:297 timestamp:1689674721147 [07-18 18:05:21:147 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:19899801 ts:0 [07-18 18:05:21:147 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:19899801 [07-18 18:05:21:147 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:538283 dataSize:165 [07-18 18:05:21:147 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:297 timestamp:1689674721147 [07-18 18:05:21:174 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:174 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 72, head index 297 [07-18 18:05:21:174 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 73, seqNo 373, timestamp 1689674713612 [07-18 18:05:21:175 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:181 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:19933134 ts:0 [07-18 18:05:21:181 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:19933134 [07-18 18:05:21:181 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:538448 dataSize:457 [07-18 18:05:21:181 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:298 timestamp:1689674721181 [07-18 18:05:21:181 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:19933134 ts:0 [07-18 18:05:21:181 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:19933134 [07-18 18:05:21:181 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:538448 dataSize:457 [07-18 18:05:21:181 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:298 timestamp:1689674721181 [07-18 18:05:21:214 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:19966467 ts:0 [07-18 18:05:21:214 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:19966467 [07-18 18:05:21:214 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:538905 dataSize:673 [07-18 18:05:21:214 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:299 timestamp:1689674721214 [07-18 18:05:21:214 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:19966467 ts:0 [07-18 18:05:21:214 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:19966467 [07-18 18:05:21:214 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:538905 dataSize:673 [07-18 18:05:21:214 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:299 timestamp:1689674721214 [07-18 18:05:21:248 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:19999800 ts:0 [07-18 18:05:21:248 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:19999800 [07-18 18:05:21:248 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:539578 dataSize:465 [07-18 18:05:21:248 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:0 timestamp:1689674721248 [07-18 18:05:21:248 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:19999800 ts:0 [07-18 18:05:21:248 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:19999800 [07-18 18:05:21:248 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:539578 dataSize:465 [07-18 18:05:21:248 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:0 timestamp:1689674721248 [07-18 18:05:21:281 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:20033133 ts:0 [07-18 18:05:21:281 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:20033133 [07-18 18:05:21:281 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:540043 dataSize:248 [07-18 18:05:21:282 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:1 timestamp:1689674721282 [07-18 18:05:21:282 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:20033133 ts:0 [07-18 18:05:21:282 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:20033133 [07-18 18:05:21:282 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:540043 dataSize:248 [07-18 18:05:21:282 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:1 timestamp:1689674721282 [07-18 18:05:21:285 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:285 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 73, head index 1 [07-18 18:05:21:285 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 74, seqNo 374, timestamp 1689674713645 [07-18 18:05:21:285 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:315 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:20066466 ts:0 [07-18 18:05:21:315 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:20066466 [07-18 18:05:21:315 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:540291 dataSize:217 [07-18 18:05:21:315 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:2 timestamp:1689674721315 [07-18 18:05:21:315 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:20066466 ts:0 [07-18 18:05:21:315 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:20066466 [07-18 18:05:21:315 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:540291 dataSize:217 [07-18 18:05:21:315 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:2 timestamp:1689674721315 [07-18 18:05:21:349 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:20099799 ts:0 [07-18 18:05:21:349 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:20099799 [07-18 18:05:21:349 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:540508 dataSize:280 [07-18 18:05:21:349 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:3 timestamp:1689674721349 [07-18 18:05:21:349 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:20099799 ts:0 [07-18 18:05:21:349 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:20099799 [07-18 18:05:21:349 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:540508 dataSize:280 [07-18 18:05:21:349 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:3 timestamp:1689674721349 [07-18 18:05:21:382 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:20133132 ts:0 [07-18 18:05:21:382 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:20133132 [07-18 18:05:21:382 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:540788 dataSize:12088 [07-18 18:05:21:382 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:4 timestamp:1689674721382 [07-18 18:05:21:382 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:20133132 ts:0 [07-18 18:05:21:382 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:20133132 [07-18 18:05:21:382 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:540788 dataSize:12088 [07-18 18:05:21:382 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:4 timestamp:1689674721382 [07-18 18:05:21:396 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:396 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 74, head index 4 [07-18 18:05:21:396 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 75, seqNo 375, timestamp 1689674713679 [07-18 18:05:21:396 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:416 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:20166465 ts:0 [07-18 18:05:21:416 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:20166465 [07-18 18:05:21:416 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:552876 dataSize:1051 [07-18 18:05:21:416 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:5 timestamp:1689674721416 [07-18 18:05:21:416 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:20166465 ts:0 [07-18 18:05:21:416 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:20166465 [07-18 18:05:21:416 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:552876 dataSize:1051 [07-18 18:05:21:416 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:5 timestamp:1689674721416 [07-18 18:05:21:453 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:20199798 ts:0 [07-18 18:05:21:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:20199798 [07-18 18:05:21:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:553927 dataSize:209 [07-18 18:05:21:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:6 timestamp:1689674721454 [07-18 18:05:21:454 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:20199798 ts:0 [07-18 18:05:21:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:20199798 [07-18 18:05:21:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:553927 dataSize:209 [07-18 18:05:21:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:6 timestamp:1689674721454 [07-18 18:05:21:488 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:20233131 ts:0 [07-18 18:05:21:488 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:20233131 [07-18 18:05:21:488 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:554136 dataSize:118 [07-18 18:05:21:488 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:7 timestamp:1689674721488 [07-18 18:05:21:488 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:20233131 ts:0 [07-18 18:05:21:488 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:20233131 [07-18 18:05:21:488 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:554136 dataSize:118 [07-18 18:05:21:488 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:7 timestamp:1689674721488 [07-18 18:05:21:506 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:506 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 75, head index 7 [07-18 18:05:21:506 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 76, seqNo 376, timestamp 1689674713713 [07-18 18:05:21:506 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:521 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:20266464 ts:0 [07-18 18:05:21:521 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:20266464 [07-18 18:05:21:521 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:554254 dataSize:110 [07-18 18:05:21:521 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:8 timestamp:1689674721521 [07-18 18:05:21:521 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:20266464 ts:0 [07-18 18:05:21:521 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:20266464 [07-18 18:05:21:521 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:554254 dataSize:110 [07-18 18:05:21:521 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:8 timestamp:1689674721521 [07-18 18:05:21:555 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:20299797 ts:0 [07-18 18:05:21:555 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:20299797 [07-18 18:05:21:555 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:554364 dataSize:695 [07-18 18:05:21:555 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:9 timestamp:1689674721555 [07-18 18:05:21:555 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:20299797 ts:0 [07-18 18:05:21:555 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:20299797 [07-18 18:05:21:555 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:554364 dataSize:695 [07-18 18:05:21:555 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:9 timestamp:1689674721555 [07-18 18:05:21:588 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:20333130 ts:0 [07-18 18:05:21:588 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:20333130 [07-18 18:05:21:588 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:555059 dataSize:1146 [07-18 18:05:21:589 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:10 timestamp:1689674721589 [07-18 18:05:21:589 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:20333130 ts:0 [07-18 18:05:21:589 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:20333130 [07-18 18:05:21:589 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:555059 dataSize:1146 [07-18 18:05:21:589 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:10 timestamp:1689674721589 [07-18 18:05:21:616 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:616 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 76, head index 10 [07-18 18:05:21:616 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 77, seqNo 377, timestamp 1689674713746 [07-18 18:05:21:617 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:622 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:20366463 ts:0 [07-18 18:05:21:622 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:20366463 [07-18 18:05:21:622 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:556205 dataSize:276 [07-18 18:05:21:622 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:11 timestamp:1689674721622 [07-18 18:05:21:622 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:20366463 ts:0 [07-18 18:05:21:622 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:20366463 [07-18 18:05:21:622 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:556205 dataSize:276 [07-18 18:05:21:622 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:11 timestamp:1689674721622 [07-18 18:05:21:656 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:20399796 ts:0 [07-18 18:05:21:656 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:20399796 [07-18 18:05:21:656 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:556481 dataSize:152 [07-18 18:05:21:656 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:12 timestamp:1689674721656 [07-18 18:05:21:656 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:20399796 ts:0 [07-18 18:05:21:656 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:20399796 [07-18 18:05:21:656 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:556481 dataSize:152 [07-18 18:05:21:656 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:12 timestamp:1689674721656 [07-18 18:05:21:689 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:20433129 ts:0 [07-18 18:05:21:689 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:20433129 [07-18 18:05:21:689 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:556633 dataSize:136 [07-18 18:05:21:689 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:13 timestamp:1689674721689 [07-18 18:05:21:690 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:20433129 ts:0 [07-18 18:05:21:690 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:20433129 [07-18 18:05:21:690 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:556633 dataSize:136 [07-18 18:05:21:690 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:13 timestamp:1689674721690 [07-18 18:05:21:723 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:20466462 ts:0 [07-18 18:05:21:723 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:20466462 [07-18 18:05:21:723 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:556769 dataSize:725 [07-18 18:05:21:723 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:14 timestamp:1689674721723 [07-18 18:05:21:723 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:20466462 ts:0 [07-18 18:05:21:723 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:20466462 [07-18 18:05:21:723 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:556769 dataSize:725 [07-18 18:05:21:723 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:14 timestamp:1689674721723 [07-18 18:05:21:727 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:727 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 77, head index 14 [07-18 18:05:21:727 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 78, seqNo 378, timestamp 1689674713780 [07-18 18:05:21:727 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:757 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:20499795 ts:0 [07-18 18:05:21:757 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:20499795 [07-18 18:05:21:757 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:557494 dataSize:1369 [07-18 18:05:21:757 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:15 timestamp:1689674721757 [07-18 18:05:21:757 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:20499795 ts:0 [07-18 18:05:21:757 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:20499795 [07-18 18:05:21:757 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:557494 dataSize:1369 [07-18 18:05:21:757 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:15 timestamp:1689674721757 [07-18 18:05:21:790 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:20533128 ts:0 [07-18 18:05:21:790 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:20533128 [07-18 18:05:21:790 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:558863 dataSize:367 [07-18 18:05:21:790 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:16 timestamp:1689674721790 [07-18 18:05:21:790 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:20533128 ts:0 [07-18 18:05:21:790 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:20533128 [07-18 18:05:21:790 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:558863 dataSize:367 [07-18 18:05:21:790 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:16 timestamp:1689674721790 [07-18 18:05:21:824 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:20566461 ts:0 [07-18 18:05:21:824 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:20566461 [07-18 18:05:21:824 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:559230 dataSize:141 [07-18 18:05:21:824 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:17 timestamp:1689674721824 [07-18 18:05:21:824 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:20566461 ts:0 [07-18 18:05:21:824 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:20566461 [07-18 18:05:21:824 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:559230 dataSize:141 [07-18 18:05:21:824 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:17 timestamp:1689674721824 [07-18 18:05:21:837 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:837 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 78, head index 17 [07-18 18:05:21:837 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 79, seqNo 379, timestamp 1689674713813 [07-18 18:05:21:837 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:858 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:20599794 ts:0 [07-18 18:05:21:858 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:20599794 [07-18 18:05:21:858 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:559371 dataSize:160 [07-18 18:05:21:858 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:18 timestamp:1689674721858 [07-18 18:05:21:858 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:20599794 ts:0 [07-18 18:05:21:858 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:20599794 [07-18 18:05:21:858 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:559371 dataSize:160 [07-18 18:05:21:858 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:18 timestamp:1689674721858 [07-18 18:05:21:891 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:20633127 ts:0 [07-18 18:05:21:891 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:20633127 [07-18 18:05:21:891 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:559531 dataSize:756 [07-18 18:05:21:891 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:19 timestamp:1689674721891 [07-18 18:05:21:891 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:20633127 ts:0 [07-18 18:05:21:891 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:20633127 [07-18 18:05:21:891 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:559531 dataSize:756 [07-18 18:05:21:891 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:19 timestamp:1689674721891 [07-18 18:05:21:925 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:20666460 ts:0 [07-18 18:05:21:925 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:20666460 [07-18 18:05:21:925 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:560287 dataSize:1610 [07-18 18:05:21:925 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:20 timestamp:1689674721925 [07-18 18:05:21:925 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:20666460 ts:0 [07-18 18:05:21:925 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:20666460 [07-18 18:05:21:925 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:560287 dataSize:1610 [07-18 18:05:21:925 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:20 timestamp:1689674721925 [07-18 18:05:21:947 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:21:947 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 79, head index 20 [07-18 18:05:21:947 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 80, seqNo 380, timestamp 1689674713847 [07-18 18:05:21:948 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:21:959 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:20699793 ts:0 [07-18 18:05:21:959 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:20699793 [07-18 18:05:21:959 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:561897 dataSize:516 [07-18 18:05:21:959 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:21 timestamp:1689674721959 [07-18 18:05:21:959 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:20699793 ts:0 [07-18 18:05:21:959 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:20699793 [07-18 18:05:21:959 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:561897 dataSize:516 [07-18 18:05:21:959 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:21 timestamp:1689674721959 [07-18 18:05:21:968 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:21:968 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:21:992 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:20733126 ts:0 [07-18 18:05:21:992 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:20733126 [07-18 18:05:21:992 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:562413 dataSize:231 [07-18 18:05:21:992 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:22 timestamp:1689674721992 [07-18 18:05:21:992 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:20733126 ts:0 [07-18 18:05:21:992 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:20733126 [07-18 18:05:21:992 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:562413 dataSize:231 [07-18 18:05:21:992 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:22 timestamp:1689674721992 [07-18 18:05:22:26 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:20766459 ts:0 [07-18 18:05:22:26 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:20766459 [07-18 18:05:22:26 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:562644 dataSize:250 [07-18 18:05:22:26 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:23 timestamp:1689674722026 [07-18 18:05:22:26 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:20766459 ts:0 [07-18 18:05:22:26 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:20766459 [07-18 18:05:22:26 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:562644 dataSize:250 [07-18 18:05:22:26 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:23 timestamp:1689674722026 [07-18 18:05:22:58 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:58 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 80, head index 23 [07-18 18:05:22:58 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 81, seqNo 381, timestamp 1689674713881 [07-18 18:05:22:58 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:59 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:20799792 ts:0 [07-18 18:05:22:60 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:20799792 [07-18 18:05:22:60 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:562894 dataSize:1143 [07-18 18:05:22:60 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:24 timestamp:1689674722060 [07-18 18:05:22:60 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:20799792 ts:0 [07-18 18:05:22:60 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:20799792 [07-18 18:05:22:60 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:562894 dataSize:1143 [07-18 18:05:22:60 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:24 timestamp:1689674722060 [07-18 18:05:22:93 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:20833125 ts:0 [07-18 18:05:22:93 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:20833125 [07-18 18:05:22:93 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:564037 dataSize:383 [07-18 18:05:22:93 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:25 timestamp:1689674722093 [07-18 18:05:22:93 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:20833125 ts:0 [07-18 18:05:22:93 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:20833125 [07-18 18:05:22:93 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:564037 dataSize:383 [07-18 18:05:22:93 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:25 timestamp:1689674722093 [07-18 18:05:22:127 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:20866458 ts:0 [07-18 18:05:22:127 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:20866458 [07-18 18:05:22:127 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:564420 dataSize:235 [07-18 18:05:22:127 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:26 timestamp:1689674722127 [07-18 18:05:22:127 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:20866458 ts:0 [07-18 18:05:22:127 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:20866458 [07-18 18:05:22:127 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:564420 dataSize:235 [07-18 18:05:22:127 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:26 timestamp:1689674722127 [07-18 18:05:22:160 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:20899791 ts:0 [07-18 18:05:22:160 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:20899791 [07-18 18:05:22:160 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:564655 dataSize:165 [07-18 18:05:22:160 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:27 timestamp:1689674722160 [07-18 18:05:22:160 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:20899791 ts:0 [07-18 18:05:22:161 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:20899791 [07-18 18:05:22:161 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:564655 dataSize:165 [07-18 18:05:22:161 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:27 timestamp:1689674722161 [07-18 18:05:22:168 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:168 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 81, head index 27 [07-18 18:05:22:168 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 82, seqNo 382, timestamp 1689674713914 [07-18 18:05:22:168 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:194 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:20933124 ts:0 [07-18 18:05:22:194 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:20933124 [07-18 18:05:22:194 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:564820 dataSize:457 [07-18 18:05:22:194 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:28 timestamp:1689674722194 [07-18 18:05:22:194 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:20933124 ts:0 [07-18 18:05:22:194 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:20933124 [07-18 18:05:22:194 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:564820 dataSize:457 [07-18 18:05:22:194 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:28 timestamp:1689674722194 [07-18 18:05:22:228 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:20966457 ts:0 [07-18 18:05:22:228 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:20966457 [07-18 18:05:22:228 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:565277 dataSize:673 [07-18 18:05:22:228 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:29 timestamp:1689674722228 [07-18 18:05:22:228 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:20966457 ts:0 [07-18 18:05:22:228 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:20966457 [07-18 18:05:22:228 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:565277 dataSize:673 [07-18 18:05:22:228 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:29 timestamp:1689674722228 [07-18 18:05:22:261 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:20999790 ts:0 [07-18 18:05:22:261 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:20999790 [07-18 18:05:22:261 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:565950 dataSize:465 [07-18 18:05:22:261 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:30 timestamp:1689674722261 [07-18 18:05:22:261 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:20999790 ts:0 [07-18 18:05:22:262 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:20999790 [07-18 18:05:22:262 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:565950 dataSize:465 [07-18 18:05:22:262 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:30 timestamp:1689674722262 [07-18 18:05:22:278 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:278 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 82, head index 30 [07-18 18:05:22:278 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 83, seqNo 383, timestamp 1689674713948 [07-18 18:05:22:279 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:295 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:21033123 ts:0 [07-18 18:05:22:295 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:21033123 [07-18 18:05:22:295 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:566415 dataSize:248 [07-18 18:05:22:295 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:31 timestamp:1689674722295 [07-18 18:05:22:295 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:21033123 ts:0 [07-18 18:05:22:295 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:21033123 [07-18 18:05:22:295 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:566415 dataSize:248 [07-18 18:05:22:295 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:31 timestamp:1689674722295 [07-18 18:05:22:329 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:21066456 ts:0 [07-18 18:05:22:329 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:21066456 [07-18 18:05:22:329 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:566663 dataSize:217 [07-18 18:05:22:329 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:32 timestamp:1689674722329 [07-18 18:05:22:329 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:21066456 ts:0 [07-18 18:05:22:329 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:21066456 [07-18 18:05:22:329 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:566663 dataSize:217 [07-18 18:05:22:329 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:32 timestamp:1689674722329 [07-18 18:05:22:362 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:21099789 ts:0 [07-18 18:05:22:362 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:21099789 [07-18 18:05:22:362 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:566880 dataSize:280 [07-18 18:05:22:362 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:33 timestamp:1689674722362 [07-18 18:05:22:362 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:21099789 ts:0 [07-18 18:05:22:362 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:21099789 [07-18 18:05:22:362 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:566880 dataSize:280 [07-18 18:05:22:362 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:33 timestamp:1689674722362 [07-18 18:05:22:389 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [101000] [07-18 18:05:22:389 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:389 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 83, head index 33 [07-18 18:05:22:389 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 84, seqNo 384, timestamp 1689674713981 [07-18 18:05:22:389 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:396 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:21133122 ts:0 [07-18 18:05:22:396 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:21133122 [07-18 18:05:22:396 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:567160 dataSize:12088 [07-18 18:05:22:396 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:34 timestamp:1689674722396 [07-18 18:05:22:396 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:21133122 ts:0 [07-18 18:05:22:396 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:21133122 [07-18 18:05:22:396 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:567160 dataSize:12088 [07-18 18:05:22:396 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:34 timestamp:1689674722396 [07-18 18:05:22:429 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:21166455 ts:0 [07-18 18:05:22:429 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:21166455 [07-18 18:05:22:430 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:579248 dataSize:1051 [07-18 18:05:22:430 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:35 timestamp:1689674722430 [07-18 18:05:22:430 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:21166455 ts:0 [07-18 18:05:22:430 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:21166455 [07-18 18:05:22:430 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:579248 dataSize:1051 [07-18 18:05:22:430 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:35 timestamp:1689674722430 [07-18 18:05:22:463 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:21199788 ts:0 [07-18 18:05:22:463 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:21199788 [07-18 18:05:22:463 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:580299 dataSize:209 [07-18 18:05:22:463 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:36 timestamp:1689674722463 [07-18 18:05:22:463 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:21199788 ts:0 [07-18 18:05:22:463 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:21199788 [07-18 18:05:22:463 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:580299 dataSize:209 [07-18 18:05:22:463 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:36 timestamp:1689674722463 [07-18 18:05:22:497 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:21233121 ts:0 [07-18 18:05:22:497 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:21233121 [07-18 18:05:22:497 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:580508 dataSize:118 [07-18 18:05:22:497 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:37 timestamp:1689674722497 [07-18 18:05:22:497 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:21233121 ts:0 [07-18 18:05:22:497 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:21233121 [07-18 18:05:22:497 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:580508 dataSize:118 [07-18 18:05:22:497 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:37 timestamp:1689674722497 [07-18 18:05:22:499 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:499 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 84, head index 37 [07-18 18:05:22:499 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 85, seqNo 385, timestamp 1689674714015 [07-18 18:05:22:499 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:531 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:21266454 ts:0 [07-18 18:05:22:531 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:21266454 [07-18 18:05:22:531 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:580626 dataSize:110 [07-18 18:05:22:531 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:38 timestamp:1689674722531 [07-18 18:05:22:531 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:21266454 ts:0 [07-18 18:05:22:531 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:21266454 [07-18 18:05:22:531 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:580626 dataSize:110 [07-18 18:05:22:531 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:38 timestamp:1689674722531 [07-18 18:05:22:564 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:21299787 ts:0 [07-18 18:05:22:564 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:21299787 [07-18 18:05:22:564 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:580736 dataSize:695 [07-18 18:05:22:564 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:39 timestamp:1689674722564 [07-18 18:05:22:565 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:21299787 ts:0 [07-18 18:05:22:565 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:21299787 [07-18 18:05:22:565 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:580736 dataSize:695 [07-18 18:05:22:565 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:39 timestamp:1689674722565 [07-18 18:05:22:598 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:21333120 ts:0 [07-18 18:05:22:598 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:21333120 [07-18 18:05:22:598 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:581431 dataSize:1146 [07-18 18:05:22:598 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:40 timestamp:1689674722598 [07-18 18:05:22:598 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:21333120 ts:0 [07-18 18:05:22:598 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:21333120 [07-18 18:05:22:598 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:581431 dataSize:1146 [07-18 18:05:22:598 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:40 timestamp:1689674722598 [07-18 18:05:22:609 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:610 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 85, head index 40 [07-18 18:05:22:610 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 86, seqNo 386, timestamp 1689674714049 [07-18 18:05:22:610 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:632 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:21366453 ts:0 [07-18 18:05:22:632 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:21366453 [07-18 18:05:22:632 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:582577 dataSize:276 [07-18 18:05:22:632 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:41 timestamp:1689674722632 [07-18 18:05:22:632 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:21366453 ts:0 [07-18 18:05:22:632 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:21366453 [07-18 18:05:22:632 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:582577 dataSize:276 [07-18 18:05:22:632 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:41 timestamp:1689674722632 [07-18 18:05:22:665 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:21399786 ts:0 [07-18 18:05:22:665 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:21399786 [07-18 18:05:22:665 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:582853 dataSize:152 [07-18 18:05:22:665 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:42 timestamp:1689674722665 [07-18 18:05:22:665 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:21399786 ts:0 [07-18 18:05:22:665 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:21399786 [07-18 18:05:22:665 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:582853 dataSize:152 [07-18 18:05:22:666 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:42 timestamp:1689674722666 [07-18 18:05:22:699 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:21433119 ts:0 [07-18 18:05:22:699 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:21433119 [07-18 18:05:22:699 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:583005 dataSize:136 [07-18 18:05:22:699 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:43 timestamp:1689674722699 [07-18 18:05:22:699 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:21433119 ts:0 [07-18 18:05:22:699 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:21433119 [07-18 18:05:22:699 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:583005 dataSize:136 [07-18 18:05:22:699 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:43 timestamp:1689674722699 [07-18 18:05:22:720 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:720 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 86, head index 43 [07-18 18:05:22:720 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 87, seqNo 387, timestamp 1689674714082 [07-18 18:05:22:720 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:733 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:21466452 ts:0 [07-18 18:05:22:733 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:21466452 [07-18 18:05:22:733 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:583141 dataSize:725 [07-18 18:05:22:733 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:44 timestamp:1689674722733 [07-18 18:05:22:733 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:21466452 ts:0 [07-18 18:05:22:733 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:21466452 [07-18 18:05:22:733 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:583141 dataSize:725 [07-18 18:05:22:733 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:44 timestamp:1689674722733 [07-18 18:05:22:766 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:21499785 ts:0 [07-18 18:05:22:766 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:21499785 [07-18 18:05:22:766 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:583866 dataSize:1369 [07-18 18:05:22:766 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:45 timestamp:1689674722766 [07-18 18:05:22:766 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:21499785 ts:0 [07-18 18:05:22:766 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:21499785 [07-18 18:05:22:766 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:583866 dataSize:1369 [07-18 18:05:22:766 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:45 timestamp:1689674722766 [07-18 18:05:22:800 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:21533118 ts:0 [07-18 18:05:22:800 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:21533118 [07-18 18:05:22:800 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:585235 dataSize:367 [07-18 18:05:22:800 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:46 timestamp:1689674722800 [07-18 18:05:22:800 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:21533118 ts:0 [07-18 18:05:22:800 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:21533118 [07-18 18:05:22:800 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:585235 dataSize:367 [07-18 18:05:22:800 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:46 timestamp:1689674722800 [07-18 18:05:22:830 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:830 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 87, head index 46 [07-18 18:05:22:830 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 88, seqNo 388, timestamp 1689674714116 [07-18 18:05:22:830 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:834 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:21566451 ts:0 [07-18 18:05:22:834 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:21566451 [07-18 18:05:22:834 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:585602 dataSize:141 [07-18 18:05:22:834 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:47 timestamp:1689674722834 [07-18 18:05:22:834 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:21566451 ts:0 [07-18 18:05:22:834 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:21566451 [07-18 18:05:22:834 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:585602 dataSize:141 [07-18 18:05:22:834 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:47 timestamp:1689674722834 [07-18 18:05:22:867 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:21599784 ts:0 [07-18 18:05:22:867 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:21599784 [07-18 18:05:22:867 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:585743 dataSize:160 [07-18 18:05:22:867 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:48 timestamp:1689674722867 [07-18 18:05:22:867 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:21599784 ts:0 [07-18 18:05:22:867 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:21599784 [07-18 18:05:22:867 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:585743 dataSize:160 [07-18 18:05:22:867 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:48 timestamp:1689674722867 [07-18 18:05:22:901 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:21633117 ts:0 [07-18 18:05:22:901 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:21633117 [07-18 18:05:22:901 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:585903 dataSize:756 [07-18 18:05:22:901 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:49 timestamp:1689674722901 [07-18 18:05:22:901 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:21633117 ts:0 [07-18 18:05:22:901 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:21633117 [07-18 18:05:22:901 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:585903 dataSize:756 [07-18 18:05:22:901 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:49 timestamp:1689674722901 [07-18 18:05:22:934 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:21666450 ts:0 [07-18 18:05:22:934 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:21666450 [07-18 18:05:22:934 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:586659 dataSize:1610 [07-18 18:05:22:934 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:50 timestamp:1689674722934 [07-18 18:05:22:934 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:21666450 ts:0 [07-18 18:05:22:935 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:21666450 [07-18 18:05:22:935 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:586659 dataSize:1610 [07-18 18:05:22:935 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:50 timestamp:1689674722935 [07-18 18:05:22:940 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:22:940 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 88, head index 50 [07-18 18:05:22:940 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 89, seqNo 389, timestamp 1689674714149 [07-18 18:05:22:940 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:22:968 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:21699783 ts:0 [07-18 18:05:22:968 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:21699783 [07-18 18:05:22:968 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:588269 dataSize:516 [07-18 18:05:22:968 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:51 timestamp:1689674722968 [07-18 18:05:22:968 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:21699783 ts:0 [07-18 18:05:22:968 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:21699783 [07-18 18:05:22:968 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:588269 dataSize:516 [07-18 18:05:22:968 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:51 timestamp:1689674722968 [07-18 18:05:22:969 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:22:969 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:23:2 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:21733116 ts:0 [07-18 18:05:23:2 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:21733116 [07-18 18:05:23:2 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:588785 dataSize:231 [07-18 18:05:23:2 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:52 timestamp:1689674723002 [07-18 18:05:23:2 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:21733116 ts:0 [07-18 18:05:23:2 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:21733116 [07-18 18:05:23:2 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:588785 dataSize:231 [07-18 18:05:23:2 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:52 timestamp:1689674723002 [07-18 18:05:23:35 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:21766449 ts:0 [07-18 18:05:23:35 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:21766449 [07-18 18:05:23:35 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:589016 dataSize:250 [07-18 18:05:23:35 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:53 timestamp:1689674723035 [07-18 18:05:23:35 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:21766449 ts:0 [07-18 18:05:23:35 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:21766449 [07-18 18:05:23:35 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:589016 dataSize:250 [07-18 18:05:23:36 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:53 timestamp:1689674723036 [07-18 18:05:23:51 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:51 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 89, head index 53 [07-18 18:05:23:51 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 90, seqNo 390, timestamp 1689674714183 [07-18 18:05:23:51 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:69 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:21799782 ts:0 [07-18 18:05:23:69 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:21799782 [07-18 18:05:23:69 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:589266 dataSize:1143 [07-18 18:05:23:69 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:54 timestamp:1689674723069 [07-18 18:05:23:69 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:21799782 ts:0 [07-18 18:05:23:69 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:21799782 [07-18 18:05:23:69 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:589266 dataSize:1143 [07-18 18:05:23:69 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:54 timestamp:1689674723069 [07-18 18:05:23:103 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:21833115 ts:0 [07-18 18:05:23:103 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:21833115 [07-18 18:05:23:103 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:590409 dataSize:383 [07-18 18:05:23:103 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:55 timestamp:1689674723103 [07-18 18:05:23:103 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:21833115 ts:0 [07-18 18:05:23:103 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:21833115 [07-18 18:05:23:103 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:590409 dataSize:383 [07-18 18:05:23:103 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:55 timestamp:1689674723103 [07-18 18:05:23:136 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:21866448 ts:0 [07-18 18:05:23:136 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:21866448 [07-18 18:05:23:136 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:590792 dataSize:235 [07-18 18:05:23:136 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:56 timestamp:1689674723136 [07-18 18:05:23:136 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:21866448 ts:0 [07-18 18:05:23:136 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:21866448 [07-18 18:05:23:136 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:590792 dataSize:235 [07-18 18:05:23:136 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:56 timestamp:1689674723136 [07-18 18:05:23:161 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:161 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 90, head index 56 [07-18 18:05:23:161 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 91, seqNo 391, timestamp 1689674714217 [07-18 18:05:23:161 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:170 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:21899781 ts:0 [07-18 18:05:23:170 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:21899781 [07-18 18:05:23:170 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:591027 dataSize:165 [07-18 18:05:23:170 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:57 timestamp:1689674723170 [07-18 18:05:23:170 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:21899781 ts:0 [07-18 18:05:23:170 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:21899781 [07-18 18:05:23:170 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:591027 dataSize:165 [07-18 18:05:23:170 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:57 timestamp:1689674723170 [07-18 18:05:23:204 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:21933114 ts:0 [07-18 18:05:23:204 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:21933114 [07-18 18:05:23:204 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:591192 dataSize:457 [07-18 18:05:23:204 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:58 timestamp:1689674723204 [07-18 18:05:23:204 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:21933114 ts:0 [07-18 18:05:23:204 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:21933114 [07-18 18:05:23:204 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:591192 dataSize:457 [07-18 18:05:23:204 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:58 timestamp:1689674723204 [07-18 18:05:23:237 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:21966447 ts:0 [07-18 18:05:23:237 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:21966447 [07-18 18:05:23:237 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:591649 dataSize:673 [07-18 18:05:23:237 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:59 timestamp:1689674723237 [07-18 18:05:23:237 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:21966447 ts:0 [07-18 18:05:23:237 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:21966447 [07-18 18:05:23:237 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:591649 dataSize:673 [07-18 18:05:23:237 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:59 timestamp:1689674723237 [07-18 18:05:23:271 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:21999780 ts:0 [07-18 18:05:23:271 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:21999780 [07-18 18:05:23:271 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:592322 dataSize:465 [07-18 18:05:23:271 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:60 timestamp:1689674723271 [07-18 18:05:23:271 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:21999780 ts:0 [07-18 18:05:23:271 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:21999780 [07-18 18:05:23:271 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:592322 dataSize:465 [07-18 18:05:23:271 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:60 timestamp:1689674723271 [07-18 18:05:23:271 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:271 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 91, head index 60 [07-18 18:05:23:271 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 92, seqNo 392, timestamp 1689674714250 [07-18 18:05:23:271 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:305 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:22033113 ts:0 [07-18 18:05:23:305 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:22033113 [07-18 18:05:23:305 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:592787 dataSize:248 [07-18 18:05:23:305 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:61 timestamp:1689674723305 [07-18 18:05:23:305 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:22033113 ts:0 [07-18 18:05:23:305 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:22033113 [07-18 18:05:23:305 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:592787 dataSize:248 [07-18 18:05:23:305 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:61 timestamp:1689674723305 [07-18 18:05:23:338 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:22066446 ts:0 [07-18 18:05:23:338 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:22066446 [07-18 18:05:23:338 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:593035 dataSize:217 [07-18 18:05:23:338 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:62 timestamp:1689674723338 [07-18 18:05:23:338 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:22066446 ts:0 [07-18 18:05:23:338 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:22066446 [07-18 18:05:23:338 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:593035 dataSize:217 [07-18 18:05:23:338 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:62 timestamp:1689674723338 [07-18 18:05:23:372 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:22099779 ts:0 [07-18 18:05:23:372 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:22099779 [07-18 18:05:23:372 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:593252 dataSize:280 [07-18 18:05:23:372 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:63 timestamp:1689674723372 [07-18 18:05:23:372 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:22099779 ts:0 [07-18 18:05:23:372 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:22099779 [07-18 18:05:23:372 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:593252 dataSize:280 [07-18 18:05:23:372 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:63 timestamp:1689674723372 [07-18 18:05:23:381 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:382 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 92, head index 63 [07-18 18:05:23:382 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 93, seqNo 393, timestamp 1689674714284 [07-18 18:05:23:382 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:406 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:22133112 ts:0 [07-18 18:05:23:406 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:22133112 [07-18 18:05:23:406 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:593532 dataSize:12088 [07-18 18:05:23:406 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:64 timestamp:1689674723406 [07-18 18:05:23:406 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:22133112 ts:0 [07-18 18:05:23:406 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:22133112 [07-18 18:05:23:406 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:593532 dataSize:12088 [07-18 18:05:23:406 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:64 timestamp:1689674723406 [07-18 18:05:23:439 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:22166445 ts:0 [07-18 18:05:23:439 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:22166445 [07-18 18:05:23:439 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:605620 dataSize:1051 [07-18 18:05:23:439 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:65 timestamp:1689674723439 [07-18 18:05:23:439 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:22166445 ts:0 [07-18 18:05:23:439 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:22166445 [07-18 18:05:23:439 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:605620 dataSize:1051 [07-18 18:05:23:439 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:65 timestamp:1689674723439 [07-18 18:05:23:473 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:22199778 ts:0 [07-18 18:05:23:473 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:22199778 [07-18 18:05:23:473 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:606671 dataSize:209 [07-18 18:05:23:473 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:66 timestamp:1689674723473 [07-18 18:05:23:473 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:22199778 ts:0 [07-18 18:05:23:473 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:22199778 [07-18 18:05:23:473 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:606671 dataSize:209 [07-18 18:05:23:473 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:66 timestamp:1689674723473 [07-18 18:05:23:492 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:492 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 93, head index 66 [07-18 18:05:23:492 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 94, seqNo 394, timestamp 1689674714318 [07-18 18:05:23:492 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:507 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:22233111 ts:0 [07-18 18:05:23:507 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:22233111 [07-18 18:05:23:507 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:606880 dataSize:118 [07-18 18:05:23:507 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:67 timestamp:1689674723507 [07-18 18:05:23:507 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:22233111 ts:0 [07-18 18:05:23:507 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:22233111 [07-18 18:05:23:507 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:606880 dataSize:118 [07-18 18:05:23:507 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:67 timestamp:1689674723507 [07-18 18:05:23:540 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:22266444 ts:0 [07-18 18:05:23:540 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:22266444 [07-18 18:05:23:540 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:606998 dataSize:110 [07-18 18:05:23:540 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:68 timestamp:1689674723540 [07-18 18:05:23:540 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:22266444 ts:0 [07-18 18:05:23:541 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:22266444 [07-18 18:05:23:541 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:606998 dataSize:110 [07-18 18:05:23:541 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:68 timestamp:1689674723541 [07-18 18:05:23:574 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:22299777 ts:0 [07-18 18:05:23:574 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:22299777 [07-18 18:05:23:574 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:607108 dataSize:695 [07-18 18:05:23:574 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:69 timestamp:1689674723574 [07-18 18:05:23:574 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:22299777 ts:0 [07-18 18:05:23:574 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:22299777 [07-18 18:05:23:574 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:607108 dataSize:695 [07-18 18:05:23:574 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:69 timestamp:1689674723574 [07-18 18:05:23:602 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:603 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 94, head index 69 [07-18 18:05:23:603 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 95, seqNo 395, timestamp 1689674714352 [07-18 18:05:23:603 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:608 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:22333110 ts:0 [07-18 18:05:23:608 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:22333110 [07-18 18:05:23:608 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:607803 dataSize:1146 [07-18 18:05:23:608 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:70 timestamp:1689674723608 [07-18 18:05:23:608 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:22333110 ts:0 [07-18 18:05:23:608 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:22333110 [07-18 18:05:23:608 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:607803 dataSize:1146 [07-18 18:05:23:608 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:70 timestamp:1689674723608 [07-18 18:05:23:641 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:22366443 ts:0 [07-18 18:05:23:641 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:22366443 [07-18 18:05:23:641 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:608949 dataSize:276 [07-18 18:05:23:641 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:71 timestamp:1689674723641 [07-18 18:05:23:641 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:22366443 ts:0 [07-18 18:05:23:641 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:22366443 [07-18 18:05:23:641 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:608949 dataSize:276 [07-18 18:05:23:641 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:71 timestamp:1689674723641 [07-18 18:05:23:675 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:22399776 ts:0 [07-18 18:05:23:675 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:22399776 [07-18 18:05:23:675 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:609225 dataSize:152 [07-18 18:05:23:675 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:72 timestamp:1689674723675 [07-18 18:05:23:675 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:22399776 ts:0 [07-18 18:05:23:675 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:22399776 [07-18 18:05:23:675 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:609225 dataSize:152 [07-18 18:05:23:675 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:72 timestamp:1689674723675 [07-18 18:05:23:709 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:22433109 ts:0 [07-18 18:05:23:709 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:22433109 [07-18 18:05:23:709 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:609377 dataSize:136 [07-18 18:05:23:709 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:73 timestamp:1689674723709 [07-18 18:05:23:709 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:22433109 ts:0 [07-18 18:05:23:709 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:22433109 [07-18 18:05:23:709 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:609377 dataSize:136 [07-18 18:05:23:709 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:73 timestamp:1689674723709 [07-18 18:05:23:713 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:713 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 95, head index 73 [07-18 18:05:23:713 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 96, seqNo 396, timestamp 1689674714386 [07-18 18:05:23:713 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:742 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:22466442 ts:0 [07-18 18:05:23:742 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:22466442 [07-18 18:05:23:742 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:609513 dataSize:725 [07-18 18:05:23:742 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:74 timestamp:1689674723742 [07-18 18:05:23:742 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:22466442 ts:0 [07-18 18:05:23:742 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:22466442 [07-18 18:05:23:742 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:609513 dataSize:725 [07-18 18:05:23:742 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:74 timestamp:1689674723742 [07-18 18:05:23:776 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:22499775 ts:0 [07-18 18:05:23:776 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:22499775 [07-18 18:05:23:776 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:610238 dataSize:1369 [07-18 18:05:23:776 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:75 timestamp:1689674723776 [07-18 18:05:23:776 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:22499775 ts:0 [07-18 18:05:23:776 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:22499775 [07-18 18:05:23:776 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:610238 dataSize:1369 [07-18 18:05:23:776 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:75 timestamp:1689674723776 [07-18 18:05:23:809 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:22533108 ts:0 [07-18 18:05:23:810 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:22533108 [07-18 18:05:23:810 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:611607 dataSize:367 [07-18 18:05:23:810 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:76 timestamp:1689674723810 [07-18 18:05:23:810 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:22533108 ts:0 [07-18 18:05:23:810 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:22533108 [07-18 18:05:23:810 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:611607 dataSize:367 [07-18 18:05:23:810 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:76 timestamp:1689674723810 [07-18 18:05:23:823 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:823 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 96, head index 76 [07-18 18:05:23:823 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 97, seqNo 397, timestamp 1689674714419 [07-18 18:05:23:823 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:843 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:22566441 ts:0 [07-18 18:05:23:843 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:22566441 [07-18 18:05:23:843 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:611974 dataSize:141 [07-18 18:05:23:843 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:77 timestamp:1689674723843 [07-18 18:05:23:843 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:22566441 ts:0 [07-18 18:05:23:843 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:22566441 [07-18 18:05:23:843 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:611974 dataSize:141 [07-18 18:05:23:843 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:77 timestamp:1689674723843 [07-18 18:05:23:877 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:22599774 ts:0 [07-18 18:05:23:877 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:22599774 [07-18 18:05:23:877 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:612115 dataSize:160 [07-18 18:05:23:877 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:78 timestamp:1689674723877 [07-18 18:05:23:877 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:22599774 ts:0 [07-18 18:05:23:877 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:22599774 [07-18 18:05:23:877 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:612115 dataSize:160 [07-18 18:05:23:877 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:78 timestamp:1689674723877 [07-18 18:05:23:911 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:22633107 ts:0 [07-18 18:05:23:911 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:22633107 [07-18 18:05:23:911 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:612275 dataSize:756 [07-18 18:05:23:911 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:79 timestamp:1689674723911 [07-18 18:05:23:911 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:22633107 ts:0 [07-18 18:05:23:911 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:22633107 [07-18 18:05:23:911 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:612275 dataSize:756 [07-18 18:05:23:911 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:79 timestamp:1689674723911 [07-18 18:05:23:933 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:23:933 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 97, head index 79 [07-18 18:05:23:933 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 98, seqNo 398, timestamp 1689674714453 [07-18 18:05:23:933 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:23:944 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:22666440 ts:0 [07-18 18:05:23:944 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:22666440 [07-18 18:05:23:944 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:613031 dataSize:1610 [07-18 18:05:23:945 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:80 timestamp:1689674723945 [07-18 18:05:23:945 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:22666440 ts:0 [07-18 18:05:23:945 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:22666440 [07-18 18:05:23:945 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:613031 dataSize:1610 [07-18 18:05:23:945 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:80 timestamp:1689674723945 [07-18 18:05:23:969 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:23:969 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:23:978 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:22699773 ts:0 [07-18 18:05:23:978 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:22699773 [07-18 18:05:23:978 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:614641 dataSize:516 [07-18 18:05:23:978 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:81 timestamp:1689674723978 [07-18 18:05:23:978 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:22699773 ts:0 [07-18 18:05:23:978 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:22699773 [07-18 18:05:23:978 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:614641 dataSize:516 [07-18 18:05:23:978 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:81 timestamp:1689674723978 [07-18 18:05:24:12 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:22733106 ts:0 [07-18 18:05:24:12 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:22733106 [07-18 18:05:24:12 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:615157 dataSize:231 [07-18 18:05:24:12 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:82 timestamp:1689674724012 [07-18 18:05:24:12 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:22733106 ts:0 [07-18 18:05:24:12 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:22733106 [07-18 18:05:24:12 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:615157 dataSize:231 [07-18 18:05:24:12 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:82 timestamp:1689674724012 [07-18 18:05:24:44 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:44 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 98, head index 82 [07-18 18:05:24:44 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 99, seqNo 399, timestamp 1689674714486 [07-18 18:05:24:44 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:45 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:22766439 ts:0 [07-18 18:05:24:45 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:22766439 [07-18 18:05:24:45 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:615388 dataSize:250 [07-18 18:05:24:45 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:83 timestamp:1689674724045 [07-18 18:05:24:45 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:22766439 ts:0 [07-18 18:05:24:46 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:22766439 [07-18 18:05:24:46 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:615388 dataSize:250 [07-18 18:05:24:46 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:83 timestamp:1689674724046 [07-18 18:05:24:79 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:22799772 ts:0 [07-18 18:05:24:79 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:22799772 [07-18 18:05:24:79 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:615638 dataSize:1143 [07-18 18:05:24:79 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:84 timestamp:1689674724079 [07-18 18:05:24:79 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:22799772 ts:0 [07-18 18:05:24:79 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:22799772 [07-18 18:05:24:79 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:615638 dataSize:1143 [07-18 18:05:24:79 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:84 timestamp:1689674724079 [07-18 18:05:24:113 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:22833105 ts:0 [07-18 18:05:24:113 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:22833105 [07-18 18:05:24:113 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:616781 dataSize:383 [07-18 18:05:24:113 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:85 timestamp:1689674724113 [07-18 18:05:24:113 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:22833105 ts:0 [07-18 18:05:24:113 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:22833105 [07-18 18:05:24:113 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:616781 dataSize:383 [07-18 18:05:24:113 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:85 timestamp:1689674724113 [07-18 18:05:24:146 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:22866438 ts:0 [07-18 18:05:24:146 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:22866438 [07-18 18:05:24:146 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:617164 dataSize:235 [07-18 18:05:24:146 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:86 timestamp:1689674724146 [07-18 18:05:24:146 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:22866438 ts:0 [07-18 18:05:24:146 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:22866438 [07-18 18:05:24:146 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:617164 dataSize:235 [07-18 18:05:24:146 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:86 timestamp:1689674724146 [07-18 18:05:24:154 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:154 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 99, head index 86 [07-18 18:05:24:154 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:399->686) [07-18 18:05:24:154 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:399->686) [07-18 18:05:24:154 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:400->686) [07-18 18:05:24:154 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 124 seqNo 424 ch0st0tr0 [07-18 18:05:24:154 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:180 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:22899771 ts:0 [07-18 18:05:24:180 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:22899771 [07-18 18:05:24:180 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:617399 dataSize:165 [07-18 18:05:24:180 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:87 timestamp:1689674724180 [07-18 18:05:24:180 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:22899771 ts:0 [07-18 18:05:24:180 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:22899771 [07-18 18:05:24:180 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:617399 dataSize:165 [07-18 18:05:24:180 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:87 timestamp:1689674724180 [07-18 18:05:24:213 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:22933104 ts:0 [07-18 18:05:24:213 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:22933104 [07-18 18:05:24:214 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:617564 dataSize:457 [07-18 18:05:24:214 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:88 timestamp:1689674724214 [07-18 18:05:24:214 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:22933104 ts:0 [07-18 18:05:24:214 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:22933104 [07-18 18:05:24:214 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:617564 dataSize:457 [07-18 18:05:24:214 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:88 timestamp:1689674724214 [07-18 18:05:24:247 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:22966437 ts:0 [07-18 18:05:24:247 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:22966437 [07-18 18:05:24:247 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:618021 dataSize:673 [07-18 18:05:24:247 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:89 timestamp:1689674724247 [07-18 18:05:24:247 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:22966437 ts:0 [07-18 18:05:24:247 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:22966437 [07-18 18:05:24:247 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:618021 dataSize:673 [07-18 18:05:24:247 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:89 timestamp:1689674724247 [07-18 18:05:24:268 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:268 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 124, head index 89 [07-18 18:05:24:268 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 125, seqNo 425, timestamp 1689674715360 [07-18 18:05:24:268 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:281 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:22999770 ts:0 [07-18 18:05:24:281 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:22999770 [07-18 18:05:24:281 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:618694 dataSize:465 [07-18 18:05:24:281 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:90 timestamp:1689674724281 [07-18 18:05:24:281 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:22999770 ts:0 [07-18 18:05:24:281 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:22999770 [07-18 18:05:24:281 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:618694 dataSize:465 [07-18 18:05:24:281 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:90 timestamp:1689674724281 [07-18 18:05:24:314 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:23033103 ts:0 [07-18 18:05:24:315 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:23033103 [07-18 18:05:24:315 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:619159 dataSize:248 [07-18 18:05:24:315 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:91 timestamp:1689674724315 [07-18 18:05:24:315 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:23033103 ts:0 [07-18 18:05:24:315 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:23033103 [07-18 18:05:24:315 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:619159 dataSize:248 [07-18 18:05:24:315 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:91 timestamp:1689674724315 [07-18 18:05:24:348 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:23066436 ts:0 [07-18 18:05:24:348 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:23066436 [07-18 18:05:24:348 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:619407 dataSize:217 [07-18 18:05:24:348 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:92 timestamp:1689674724348 [07-18 18:05:24:348 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:23066436 ts:0 [07-18 18:05:24:348 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:23066436 [07-18 18:05:24:348 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:619407 dataSize:217 [07-18 18:05:24:348 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:92 timestamp:1689674724348 [07-18 18:05:24:379 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:379 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 125, head index 92 [07-18 18:05:24:379 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 126, seqNo 426, timestamp 1689674715394 [07-18 18:05:24:379 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:382 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:23099769 ts:0 [07-18 18:05:24:382 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:23099769 [07-18 18:05:24:382 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:619624 dataSize:280 [07-18 18:05:24:382 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:93 timestamp:1689674724382 [07-18 18:05:24:382 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:23099769 ts:0 [07-18 18:05:24:382 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:23099769 [07-18 18:05:24:382 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:619624 dataSize:280 [07-18 18:05:24:382 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:93 timestamp:1689674724382 [07-18 18:05:24:415 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:23133102 ts:0 [07-18 18:05:24:415 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:23133102 [07-18 18:05:24:416 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:619904 dataSize:12088 [07-18 18:05:24:416 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:94 timestamp:1689674724416 [07-18 18:05:24:416 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:23133102 ts:0 [07-18 18:05:24:416 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:23133102 [07-18 18:05:24:416 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:619904 dataSize:12088 [07-18 18:05:24:416 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:94 timestamp:1689674724416 [07-18 18:05:24:449 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:23166435 ts:0 [07-18 18:05:24:449 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:23166435 [07-18 18:05:24:449 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:631992 dataSize:1051 [07-18 18:05:24:449 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:95 timestamp:1689674724449 [07-18 18:05:24:449 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:23166435 ts:0 [07-18 18:05:24:449 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:23166435 [07-18 18:05:24:449 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:631992 dataSize:1051 [07-18 18:05:24:449 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:95 timestamp:1689674724449 [07-18 18:05:24:483 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:23199768 ts:0 [07-18 18:05:24:483 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:23199768 [07-18 18:05:24:483 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:633043 dataSize:209 [07-18 18:05:24:483 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:96 timestamp:1689674724483 [07-18 18:05:24:483 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:23199768 ts:0 [07-18 18:05:24:483 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:23199768 [07-18 18:05:24:483 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:633043 dataSize:209 [07-18 18:05:24:483 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:96 timestamp:1689674724483 [07-18 18:05:24:489 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:489 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 126, head index 96 [07-18 18:05:24:489 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 127, seqNo 427, timestamp 1689674715428 [07-18 18:05:24:489 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:516 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:23233101 ts:0 [07-18 18:05:24:517 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:23233101 [07-18 18:05:24:517 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:633252 dataSize:118 [07-18 18:05:24:517 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:97 timestamp:1689674724517 [07-18 18:05:24:517 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:23233101 ts:0 [07-18 18:05:24:517 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:23233101 [07-18 18:05:24:517 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:633252 dataSize:118 [07-18 18:05:24:517 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:97 timestamp:1689674724517 [07-18 18:05:24:550 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:23266434 ts:0 [07-18 18:05:24:550 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:23266434 [07-18 18:05:24:550 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:633370 dataSize:110 [07-18 18:05:24:550 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:98 timestamp:1689674724550 [07-18 18:05:24:550 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:23266434 ts:0 [07-18 18:05:24:550 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:23266434 [07-18 18:05:24:550 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:633370 dataSize:110 [07-18 18:05:24:550 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:98 timestamp:1689674724550 [07-18 18:05:24:584 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:23299767 ts:0 [07-18 18:05:24:584 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:23299767 [07-18 18:05:24:584 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:633480 dataSize:695 [07-18 18:05:24:584 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:99 timestamp:1689674724584 [07-18 18:05:24:584 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:23299767 ts:0 [07-18 18:05:24:584 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:23299767 [07-18 18:05:24:584 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:633480 dataSize:695 [07-18 18:05:24:584 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:99 timestamp:1689674724584 [07-18 18:05:24:599 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:599 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 127, head index 99 [07-18 18:05:24:599 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 128, seqNo 428, timestamp 1689674715461 [07-18 18:05:24:599 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:617 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:23333100 ts:0 [07-18 18:05:24:618 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:23333100 [07-18 18:05:24:618 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:634175 dataSize:1146 [07-18 18:05:24:618 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:100 timestamp:1689674724618 [07-18 18:05:24:618 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:23333100 ts:0 [07-18 18:05:24:618 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:23333100 [07-18 18:05:24:618 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:634175 dataSize:1146 [07-18 18:05:24:618 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:100 timestamp:1689674724618 [07-18 18:05:24:651 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:23366433 ts:0 [07-18 18:05:24:651 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:23366433 [07-18 18:05:24:651 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:635321 dataSize:276 [07-18 18:05:24:651 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:101 timestamp:1689674724651 [07-18 18:05:24:651 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:23366433 ts:0 [07-18 18:05:24:651 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:23366433 [07-18 18:05:24:651 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:635321 dataSize:276 [07-18 18:05:24:651 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:101 timestamp:1689674724651 [07-18 18:05:24:685 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:23399766 ts:0 [07-18 18:05:24:685 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:23399766 [07-18 18:05:24:685 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:635597 dataSize:152 [07-18 18:05:24:685 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:102 timestamp:1689674724685 [07-18 18:05:24:685 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:23399766 ts:0 [07-18 18:05:24:685 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:23399766 [07-18 18:05:24:685 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:635597 dataSize:152 [07-18 18:05:24:685 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:102 timestamp:1689674724685 [07-18 18:05:24:710 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:710 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 128, head index 102 [07-18 18:05:24:710 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 129, seqNo 429, timestamp 1689674715495 [07-18 18:05:24:710 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:718 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:23433099 ts:0 [07-18 18:05:24:719 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:23433099 [07-18 18:05:24:719 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:635749 dataSize:136 [07-18 18:05:24:719 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:103 timestamp:1689674724719 [07-18 18:05:24:719 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:23433099 ts:0 [07-18 18:05:24:719 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:23433099 [07-18 18:05:24:719 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:635749 dataSize:136 [07-18 18:05:24:719 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:103 timestamp:1689674724719 [07-18 18:05:24:752 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:23466432 ts:0 [07-18 18:05:24:752 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:23466432 [07-18 18:05:24:752 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:635885 dataSize:725 [07-18 18:05:24:752 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:104 timestamp:1689674724752 [07-18 18:05:24:752 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:23466432 ts:0 [07-18 18:05:24:752 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:23466432 [07-18 18:05:24:752 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:635885 dataSize:725 [07-18 18:05:24:752 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:104 timestamp:1689674724752 [07-18 18:05:24:786 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:23499765 ts:0 [07-18 18:05:24:786 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:23499765 [07-18 18:05:24:786 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:636610 dataSize:1369 [07-18 18:05:24:786 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:105 timestamp:1689674724786 [07-18 18:05:24:786 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:23499765 ts:0 [07-18 18:05:24:786 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:23499765 [07-18 18:05:24:786 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:636610 dataSize:1369 [07-18 18:05:24:786 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:105 timestamp:1689674724786 [07-18 18:05:24:819 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:23533098 ts:0 [07-18 18:05:24:819 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:23533098 [07-18 18:05:24:819 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:637979 dataSize:367 [07-18 18:05:24:819 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:106 timestamp:1689674724819 [07-18 18:05:24:819 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:23533098 ts:0 [07-18 18:05:24:820 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:23533098 [07-18 18:05:24:820 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:637979 dataSize:367 [07-18 18:05:24:820 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:106 timestamp:1689674724820 [07-18 18:05:24:820 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:820 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 129, head index 106 [07-18 18:05:24:820 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 130, seqNo 430, timestamp 1689674715529 [07-18 18:05:24:820 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:853 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:23566431 ts:0 [07-18 18:05:24:853 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:23566431 [07-18 18:05:24:853 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:638346 dataSize:141 [07-18 18:05:24:853 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:107 timestamp:1689674724853 [07-18 18:05:24:853 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:23566431 ts:0 [07-18 18:05:24:853 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:23566431 [07-18 18:05:24:853 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:638346 dataSize:141 [07-18 18:05:24:853 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:107 timestamp:1689674724853 [07-18 18:05:24:887 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:23599764 ts:0 [07-18 18:05:24:887 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:23599764 [07-18 18:05:24:887 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:638487 dataSize:160 [07-18 18:05:24:887 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:108 timestamp:1689674724887 [07-18 18:05:24:887 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:23599764 ts:0 [07-18 18:05:24:887 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:23599764 [07-18 18:05:24:887 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:638487 dataSize:160 [07-18 18:05:24:887 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:108 timestamp:1689674724887 [07-18 18:05:24:920 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:23633097 ts:0 [07-18 18:05:24:920 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:23633097 [07-18 18:05:24:920 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:638647 dataSize:756 [07-18 18:05:24:920 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:109 timestamp:1689674724920 [07-18 18:05:24:920 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:23633097 ts:0 [07-18 18:05:24:920 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:23633097 [07-18 18:05:24:921 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:638647 dataSize:756 [07-18 18:05:24:921 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:109 timestamp:1689674724921 [07-18 18:05:24:930 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:24:930 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 130, head index 109 [07-18 18:05:24:930 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 131, seqNo 431, timestamp 1689674715562 [07-18 18:05:24:930 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:24:954 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:23666430 ts:0 [07-18 18:05:24:954 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:23666430 [07-18 18:05:24:954 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:639403 dataSize:1610 [07-18 18:05:24:954 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:110 timestamp:1689674724954 [07-18 18:05:24:954 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:23666430 ts:0 [07-18 18:05:24:954 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:23666430 [07-18 18:05:24:954 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:639403 dataSize:1610 [07-18 18:05:24:954 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:110 timestamp:1689674724954 [07-18 18:05:24:970 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:24:970 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:24:988 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:23699763 ts:0 [07-18 18:05:24:988 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:23699763 [07-18 18:05:24:988 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:641013 dataSize:516 [07-18 18:05:24:988 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:111 timestamp:1689674724988 [07-18 18:05:24:988 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:23699763 ts:0 [07-18 18:05:24:988 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:23699763 [07-18 18:05:24:988 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:641013 dataSize:516 [07-18 18:05:24:988 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:111 timestamp:1689674724988 [07-18 18:05:25:21 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:23733096 ts:0 [07-18 18:05:25:21 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:23733096 [07-18 18:05:25:21 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:641529 dataSize:231 [07-18 18:05:25:21 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:112 timestamp:1689674725021 [07-18 18:05:25:21 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:23733096 ts:0 [07-18 18:05:25:21 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:23733096 [07-18 18:05:25:22 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:641529 dataSize:231 [07-18 18:05:25:22 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:112 timestamp:1689674725022 [07-18 18:05:25:40 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:41 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 131, head index 112 [07-18 18:05:25:41 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 132, seqNo 432, timestamp 1689674715596 [07-18 18:05:25:41 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:55 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:23766429 ts:0 [07-18 18:05:25:55 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:23766429 [07-18 18:05:25:55 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:641760 dataSize:250 [07-18 18:05:25:55 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:113 timestamp:1689674725055 [07-18 18:05:25:55 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:23766429 ts:0 [07-18 18:05:25:55 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:23766429 [07-18 18:05:25:55 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:641760 dataSize:250 [07-18 18:05:25:55 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:113 timestamp:1689674725055 [07-18 18:05:25:89 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:23799762 ts:0 [07-18 18:05:25:89 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:23799762 [07-18 18:05:25:89 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:642010 dataSize:1143 [07-18 18:05:25:89 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:114 timestamp:1689674725089 [07-18 18:05:25:89 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:23799762 ts:0 [07-18 18:05:25:89 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:23799762 [07-18 18:05:25:89 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:642010 dataSize:1143 [07-18 18:05:25:89 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:114 timestamp:1689674725089 [07-18 18:05:25:122 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:23833095 ts:0 [07-18 18:05:25:122 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:23833095 [07-18 18:05:25:122 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:643153 dataSize:383 [07-18 18:05:25:122 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:115 timestamp:1689674725122 [07-18 18:05:25:122 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:23833095 ts:0 [07-18 18:05:25:122 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:23833095 [07-18 18:05:25:122 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:643153 dataSize:383 [07-18 18:05:25:123 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:115 timestamp:1689674725123 [07-18 18:05:25:151 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:151 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 132, head index 115 [07-18 18:05:25:151 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 133, seqNo 433, timestamp 1689674715630 [07-18 18:05:25:151 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:156 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:23866428 ts:0 [07-18 18:05:25:156 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:23866428 [07-18 18:05:25:156 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:643536 dataSize:235 [07-18 18:05:25:156 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:116 timestamp:1689674725156 [07-18 18:05:25:156 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:23866428 ts:0 [07-18 18:05:25:156 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:23866428 [07-18 18:05:25:156 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:643536 dataSize:235 [07-18 18:05:25:156 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:116 timestamp:1689674725156 [07-18 18:05:25:190 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:23899761 ts:0 [07-18 18:05:25:190 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:23899761 [07-18 18:05:25:190 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:643771 dataSize:165 [07-18 18:05:25:190 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:117 timestamp:1689674725190 [07-18 18:05:25:190 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:23899761 ts:0 [07-18 18:05:25:190 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:23899761 [07-18 18:05:25:190 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:643771 dataSize:165 [07-18 18:05:25:190 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:117 timestamp:1689674725190 [07-18 18:05:25:223 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:23933094 ts:0 [07-18 18:05:25:223 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:23933094 [07-18 18:05:25:223 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:643936 dataSize:457 [07-18 18:05:25:223 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:118 timestamp:1689674725223 [07-18 18:05:25:223 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:23933094 ts:0 [07-18 18:05:25:223 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:23933094 [07-18 18:05:25:223 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:643936 dataSize:457 [07-18 18:05:25:223 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:118 timestamp:1689674725223 [07-18 18:05:25:257 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:23966427 ts:0 [07-18 18:05:25:257 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:23966427 [07-18 18:05:25:257 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:644393 dataSize:673 [07-18 18:05:25:257 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:119 timestamp:1689674725257 [07-18 18:05:25:257 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:23966427 ts:0 [07-18 18:05:25:257 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:23966427 [07-18 18:05:25:257 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:644393 dataSize:673 [07-18 18:05:25:257 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:119 timestamp:1689674725257 [07-18 18:05:25:261 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:261 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 133, head index 119 [07-18 18:05:25:261 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:433->719) [07-18 18:05:25:261 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:433->719) [07-18 18:05:25:261 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 154 seqNo 454 ch0st0tr0 [07-18 18:05:25:262 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:291 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:23999760 ts:0 [07-18 18:05:25:291 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:23999760 [07-18 18:05:25:291 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:645066 dataSize:465 [07-18 18:05:25:291 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:120 timestamp:1689674725291 [07-18 18:05:25:291 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:23999760 ts:0 [07-18 18:05:25:291 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:23999760 [07-18 18:05:25:291 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:645066 dataSize:465 [07-18 18:05:25:291 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:120 timestamp:1689674725291 [07-18 18:05:25:324 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:24033093 ts:0 [07-18 18:05:25:324 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:24033093 [07-18 18:05:25:324 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:645531 dataSize:248 [07-18 18:05:25:324 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:121 timestamp:1689674725324 [07-18 18:05:25:324 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:24033093 ts:0 [07-18 18:05:25:324 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:24033093 [07-18 18:05:25:324 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:645531 dataSize:248 [07-18 18:05:25:324 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:121 timestamp:1689674725324 [07-18 18:05:25:358 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:24066426 ts:0 [07-18 18:05:25:358 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:24066426 [07-18 18:05:25:358 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:645779 dataSize:217 [07-18 18:05:25:358 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:122 timestamp:1689674725358 [07-18 18:05:25:358 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:24066426 ts:0 [07-18 18:05:25:358 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:24066426 [07-18 18:05:25:358 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:645779 dataSize:217 [07-18 18:05:25:358 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:122 timestamp:1689674725358 [07-18 18:05:25:372 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:372 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 154, head index 122 [07-18 18:05:25:372 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 155, seqNo 455, timestamp 1689674716370 [07-18 18:05:25:372 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:391 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:24099759 ts:0 [07-18 18:05:25:392 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:24099759 [07-18 18:05:25:392 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:645996 dataSize:280 [07-18 18:05:25:392 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:123 timestamp:1689674725392 [07-18 18:05:25:392 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:24099759 ts:0 [07-18 18:05:25:392 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:24099759 [07-18 18:05:25:392 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:645996 dataSize:280 [07-18 18:05:25:392 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:123 timestamp:1689674725392 [07-18 18:05:25:425 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:24133092 ts:0 [07-18 18:05:25:425 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:24133092 [07-18 18:05:25:425 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:646276 dataSize:12088 [07-18 18:05:25:425 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:124 timestamp:1689674725425 [07-18 18:05:25:425 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:24133092 ts:0 [07-18 18:05:25:425 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:24133092 [07-18 18:05:25:425 TUYA Trace][tuya_ring_buffer.c:152] reach end,restart.ch0st0tr1 tailOffset:646276 dataSize:12088 [07-18 18:05:25:425 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:124 timestamp:1689674725425 [07-18 18:05:25:459 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:24166425 ts:0 [07-18 18:05:25:459 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:24166425 [07-18 18:05:25:459 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:658364 dataSize:1051 [07-18 18:05:25:459 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:125 timestamp:1689674725459 [07-18 18:05:25:459 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:24166425 ts:0 [07-18 18:05:25:459 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:24166425 [07-18 18:05:25:459 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:12088 dataSize:1051 [07-18 18:05:25:459 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:125 timestamp:1689674725459 [07-18 18:05:25:482 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:482 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 155, head index 125 [07-18 18:05:25:482 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 156, seqNo 456, timestamp 1689674716403 [07-18 18:05:25:482 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:492 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:24199758 ts:0 [07-18 18:05:25:492 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:24199758 [07-18 18:05:25:492 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:659415 dataSize:209 [07-18 18:05:25:492 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:126 timestamp:1689674725492 [07-18 18:05:25:493 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:24199758 ts:0 [07-18 18:05:25:493 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:24199758 [07-18 18:05:25:493 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:13139 dataSize:209 [07-18 18:05:25:493 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:126 timestamp:1689674725493 [07-18 18:05:25:526 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:24233091 ts:0 [07-18 18:05:25:526 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:24233091 [07-18 18:05:25:526 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:659624 dataSize:118 [07-18 18:05:25:526 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:127 timestamp:1689674725526 [07-18 18:05:25:526 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:24233091 ts:0 [07-18 18:05:25:526 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:24233091 [07-18 18:05:25:526 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:13348 dataSize:118 [07-18 18:05:25:526 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:127 timestamp:1689674725526 [07-18 18:05:25:560 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:24266424 ts:0 [07-18 18:05:25:560 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:24266424 [07-18 18:05:25:560 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:659742 dataSize:110 [07-18 18:05:25:560 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:128 timestamp:1689674725560 [07-18 18:05:25:560 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:24266424 ts:0 [07-18 18:05:25:560 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:24266424 [07-18 18:05:25:560 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:13466 dataSize:110 [07-18 18:05:25:560 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:128 timestamp:1689674725560 [07-18 18:05:25:593 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:593 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 156, head index 128 [07-18 18:05:25:593 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 157, seqNo 457, timestamp 1689674716437 [07-18 18:05:25:593 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:593 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:24299757 ts:0 [07-18 18:05:25:593 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:24299757 [07-18 18:05:25:593 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:659852 dataSize:695 [07-18 18:05:25:593 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:129 timestamp:1689674725593 [07-18 18:05:25:593 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:24299757 ts:0 [07-18 18:05:25:593 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:24299757 [07-18 18:05:25:593 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:13576 dataSize:695 [07-18 18:05:25:593 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:129 timestamp:1689674725593 [07-18 18:05:25:627 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:24333090 ts:0 [07-18 18:05:25:627 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:24333090 [07-18 18:05:25:627 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:660547 dataSize:1146 [07-18 18:05:25:627 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:130 timestamp:1689674725627 [07-18 18:05:25:627 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:24333090 ts:0 [07-18 18:05:25:627 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:24333090 [07-18 18:05:25:627 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:14271 dataSize:1146 [07-18 18:05:25:627 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:130 timestamp:1689674725627 [07-18 18:05:25:660 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:24366423 ts:0 [07-18 18:05:25:660 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:24366423 [07-18 18:05:25:660 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:661693 dataSize:276 [07-18 18:05:25:661 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:131 timestamp:1689674725661 [07-18 18:05:25:661 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:24366423 ts:0 [07-18 18:05:25:661 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:24366423 [07-18 18:05:25:661 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:15417 dataSize:276 [07-18 18:05:25:661 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:131 timestamp:1689674725661 [07-18 18:05:25:694 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:24399756 ts:0 [07-18 18:05:25:694 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:24399756 [07-18 18:05:25:694 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:661969 dataSize:152 [07-18 18:05:25:694 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:132 timestamp:1689674725694 [07-18 18:05:25:694 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:24399756 ts:0 [07-18 18:05:25:694 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:24399756 [07-18 18:05:25:694 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:15693 dataSize:152 [07-18 18:05:25:694 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:132 timestamp:1689674725694 [07-18 18:05:25:703 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:703 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 157, head index 132 [07-18 18:05:25:703 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 158, seqNo 458, timestamp 1689674716471 [07-18 18:05:25:703 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:728 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:24433089 ts:0 [07-18 18:05:25:728 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:24433089 [07-18 18:05:25:728 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:662121 dataSize:136 [07-18 18:05:25:728 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:133 timestamp:1689674725728 [07-18 18:05:25:728 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:24433089 ts:0 [07-18 18:05:25:728 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:24433089 [07-18 18:05:25:728 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:15845 dataSize:136 [07-18 18:05:25:728 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:133 timestamp:1689674725728 [07-18 18:05:25:761 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:24466422 ts:0 [07-18 18:05:25:761 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:24466422 [07-18 18:05:25:761 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:662257 dataSize:725 [07-18 18:05:25:761 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:134 timestamp:1689674725761 [07-18 18:05:25:761 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:24466422 ts:0 [07-18 18:05:25:761 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:24466422 [07-18 18:05:25:761 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:15981 dataSize:725 [07-18 18:05:25:762 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:134 timestamp:1689674725761 [07-18 18:05:25:795 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:24499755 ts:0 [07-18 18:05:25:795 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:24499755 [07-18 18:05:25:795 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:662982 dataSize:1369 [07-18 18:05:25:795 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:135 timestamp:1689674725795 [07-18 18:05:25:795 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:24499755 ts:0 [07-18 18:05:25:795 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:24499755 [07-18 18:05:25:795 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:16706 dataSize:1369 [07-18 18:05:25:795 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:135 timestamp:1689674725795 [07-18 18:05:25:813 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:813 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 158, head index 135 [07-18 18:05:25:814 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 159, seqNo 459, timestamp 1689674716505 [07-18 18:05:25:814 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:829 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:24533088 ts:0 [07-18 18:05:25:829 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:24533088 [07-18 18:05:25:829 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:664351 dataSize:367 [07-18 18:05:25:829 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:136 timestamp:1689674725829 [07-18 18:05:25:829 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:24533088 ts:0 [07-18 18:05:25:829 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:24533088 [07-18 18:05:25:829 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18075 dataSize:367 [07-18 18:05:25:829 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:136 timestamp:1689674725829 [07-18 18:05:25:862 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:24566421 ts:0 [07-18 18:05:25:862 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:24566421 [07-18 18:05:25:862 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:664718 dataSize:141 [07-18 18:05:25:862 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:137 timestamp:1689674725862 [07-18 18:05:25:862 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:24566421 ts:0 [07-18 18:05:25:862 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:24566421 [07-18 18:05:25:862 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18442 dataSize:141 [07-18 18:05:25:862 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:137 timestamp:1689674725862 [07-18 18:05:25:896 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:24599754 ts:0 [07-18 18:05:25:896 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:24599754 [07-18 18:05:25:896 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:664859 dataSize:160 [07-18 18:05:25:896 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:138 timestamp:1689674725896 [07-18 18:05:25:896 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:24599754 ts:0 [07-18 18:05:25:896 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:24599754 [07-18 18:05:25:896 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18583 dataSize:160 [07-18 18:05:25:896 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:138 timestamp:1689674725896 [07-18 18:05:25:924 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:25:924 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 159, head index 138 [07-18 18:05:25:924 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 160, seqNo 460, timestamp 1689674716538 [07-18 18:05:25:924 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:25:929 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:24633087 ts:0 [07-18 18:05:25:929 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:24633087 [07-18 18:05:25:929 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:665019 dataSize:756 [07-18 18:05:25:929 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:139 timestamp:1689674725929 [07-18 18:05:25:929 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:24633087 ts:0 [07-18 18:05:25:929 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:24633087 [07-18 18:05:25:929 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18743 dataSize:756 [07-18 18:05:25:929 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:139 timestamp:1689674725929 [07-18 18:05:25:963 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:24666420 ts:0 [07-18 18:05:25:963 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:24666420 [07-18 18:05:25:963 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:665775 dataSize:1610 [07-18 18:05:25:963 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:140 timestamp:1689674725963 [07-18 18:05:25:963 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:24666420 ts:0 [07-18 18:05:25:963 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:24666420 [07-18 18:05:25:963 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:19499 dataSize:1610 [07-18 18:05:25:963 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:140 timestamp:1689674725963 [07-18 18:05:25:971 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:25:971 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:25:997 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:24699753 ts:0 [07-18 18:05:25:997 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:24699753 [07-18 18:05:25:997 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:667385 dataSize:516 [07-18 18:05:25:997 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:141 timestamp:1689674725997 [07-18 18:05:25:997 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:24699753 ts:0 [07-18 18:05:25:997 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:24699753 [07-18 18:05:25:997 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:21109 dataSize:516 [07-18 18:05:25:997 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:141 timestamp:1689674725997 [07-18 18:05:26:30 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:24733086 ts:0 [07-18 18:05:26:30 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:24733086 [07-18 18:05:26:30 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:667901 dataSize:231 [07-18 18:05:26:30 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:142 timestamp:1689674726030 [07-18 18:05:26:30 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:24733086 ts:0 [07-18 18:05:26:30 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:24733086 [07-18 18:05:26:30 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:21625 dataSize:231 [07-18 18:05:26:31 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:142 timestamp:1689674726031 [07-18 18:05:26:34 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:34 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 160, head index 142 [07-18 18:05:26:34 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 161, seqNo 461, timestamp 1689674716572 [07-18 18:05:26:34 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:64 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:24766419 ts:0 [07-18 18:05:26:64 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:24766419 [07-18 18:05:26:64 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:668132 dataSize:250 [07-18 18:05:26:64 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:143 timestamp:1689674726064 [07-18 18:05:26:64 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:24766419 ts:0 [07-18 18:05:26:64 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:24766419 [07-18 18:05:26:64 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:21856 dataSize:250 [07-18 18:05:26:64 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:143 timestamp:1689674726064 [07-18 18:05:26:97 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:24799752 ts:0 [07-18 18:05:26:98 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:24799752 [07-18 18:05:26:98 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:668382 dataSize:1143 [07-18 18:05:26:98 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:144 timestamp:1689674726098 [07-18 18:05:26:98 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:24799752 ts:0 [07-18 18:05:26:98 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:24799752 [07-18 18:05:26:98 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:22106 dataSize:1143 [07-18 18:05:26:98 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:144 timestamp:1689674726098 [07-18 18:05:26:132 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:24833085 ts:0 [07-18 18:05:26:132 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:24833085 [07-18 18:05:26:132 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:669525 dataSize:383 [07-18 18:05:26:132 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:145 timestamp:1689674726132 [07-18 18:05:26:132 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:24833085 ts:0 [07-18 18:05:26:132 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:24833085 [07-18 18:05:26:132 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23249 dataSize:383 [07-18 18:05:26:132 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:145 timestamp:1689674726132 [07-18 18:05:26:145 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:145 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 161, head index 145 [07-18 18:05:26:145 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 162, seqNo 462, timestamp 1689674716606 [07-18 18:05:26:145 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:165 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:24866418 ts:0 [07-18 18:05:26:165 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:24866418 [07-18 18:05:26:165 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:669908 dataSize:235 [07-18 18:05:26:165 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:146 timestamp:1689674726165 [07-18 18:05:26:165 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:24866418 ts:0 [07-18 18:05:26:165 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:24866418 [07-18 18:05:26:165 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23632 dataSize:235 [07-18 18:05:26:165 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:146 timestamp:1689674726165 [07-18 18:05:26:199 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:24899751 ts:0 [07-18 18:05:26:199 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:24899751 [07-18 18:05:26:199 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:670143 dataSize:165 [07-18 18:05:26:199 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:147 timestamp:1689674726199 [07-18 18:05:26:199 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:24899751 ts:0 [07-18 18:05:26:199 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:24899751 [07-18 18:05:26:199 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23867 dataSize:165 [07-18 18:05:26:199 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:147 timestamp:1689674726199 [07-18 18:05:26:232 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:24933084 ts:0 [07-18 18:05:26:232 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:24933084 [07-18 18:05:26:232 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:670308 dataSize:457 [07-18 18:05:26:233 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:148 timestamp:1689674726233 [07-18 18:05:26:233 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:24933084 ts:0 [07-18 18:05:26:233 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:24933084 [07-18 18:05:26:233 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:24032 dataSize:457 [07-18 18:05:26:233 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:148 timestamp:1689674726233 [07-18 18:05:26:255 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:255 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 162, head index 148 [07-18 18:05:26:255 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:462->748) [07-18 18:05:26:255 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:462->748) [07-18 18:05:26:255 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 184 seqNo 484 ch0st0tr0 [07-18 18:05:26:256 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:266 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:24966417 ts:0 [07-18 18:05:26:266 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:24966417 [07-18 18:05:26:266 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:670765 dataSize:673 [07-18 18:05:26:266 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:149 timestamp:1689674726266 [07-18 18:05:26:266 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:24966417 ts:0 [07-18 18:05:26:266 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:24966417 [07-18 18:05:26:266 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:24489 dataSize:673 [07-18 18:05:26:266 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:149 timestamp:1689674726266 [07-18 18:05:26:300 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:24999750 ts:0 [07-18 18:05:26:300 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:24999750 [07-18 18:05:26:300 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:671438 dataSize:465 [07-18 18:05:26:300 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:150 timestamp:1689674726300 [07-18 18:05:26:300 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:24999750 ts:0 [07-18 18:05:26:300 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:24999750 [07-18 18:05:26:300 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:25162 dataSize:465 [07-18 18:05:26:300 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:150 timestamp:1689674726300 [07-18 18:05:26:333 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:25033083 ts:0 [07-18 18:05:26:333 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:25033083 [07-18 18:05:26:333 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:671903 dataSize:248 [07-18 18:05:26:333 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:151 timestamp:1689674726333 [07-18 18:05:26:333 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:25033083 ts:0 [07-18 18:05:26:333 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:25033083 [07-18 18:05:26:333 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:25627 dataSize:248 [07-18 18:05:26:333 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:151 timestamp:1689674726333 [07-18 18:05:26:366 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:366 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 184, head index 151 [07-18 18:05:26:366 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 185, seqNo 485, timestamp 1689674717379 [07-18 18:05:26:366 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:367 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:25066416 ts:0 [07-18 18:05:26:367 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:25066416 [07-18 18:05:26:367 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:672151 dataSize:217 [07-18 18:05:26:367 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:152 timestamp:1689674726367 [07-18 18:05:26:367 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:25066416 ts:0 [07-18 18:05:26:367 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:25066416 [07-18 18:05:26:367 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:25875 dataSize:217 [07-18 18:05:26:367 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:152 timestamp:1689674726367 [07-18 18:05:26:400 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:25099749 ts:0 [07-18 18:05:26:401 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:25099749 [07-18 18:05:26:401 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:672368 dataSize:280 [07-18 18:05:26:401 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:153 timestamp:1689674726401 [07-18 18:05:26:401 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:25099749 ts:0 [07-18 18:05:26:401 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:25099749 [07-18 18:05:26:401 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:26092 dataSize:280 [07-18 18:05:26:401 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:153 timestamp:1689674726401 [07-18 18:05:26:434 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:25133082 ts:0 [07-18 18:05:26:434 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:25133082 [07-18 18:05:26:434 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:672648 dataSize:12088 [07-18 18:05:26:434 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:154 timestamp:1689674726434 [07-18 18:05:26:434 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:25133082 ts:0 [07-18 18:05:26:434 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:25133082 [07-18 18:05:26:434 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:26372 dataSize:12088 [07-18 18:05:26:434 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:154 timestamp:1689674726434 [07-18 18:05:26:468 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:25166415 ts:0 [07-18 18:05:26:468 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:25166415 [07-18 18:05:26:468 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:684736 dataSize:1051 [07-18 18:05:26:468 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:155 timestamp:1689674726468 [07-18 18:05:26:468 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:25166415 ts:0 [07-18 18:05:26:468 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:25166415 [07-18 18:05:26:468 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:38460 dataSize:1051 [07-18 18:05:26:468 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:155 timestamp:1689674726468 [07-18 18:05:26:476 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:476 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 185, head index 155 [07-18 18:05:26:476 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 186, seqNo 486, timestamp 1689674717413 [07-18 18:05:26:477 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:501 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:25199748 ts:0 [07-18 18:05:26:501 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:25199748 [07-18 18:05:26:501 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:685787 dataSize:209 [07-18 18:05:26:501 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:156 timestamp:1689674726501 [07-18 18:05:26:502 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:25199748 ts:0 [07-18 18:05:26:502 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:25199748 [07-18 18:05:26:502 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:39511 dataSize:209 [07-18 18:05:26:502 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:156 timestamp:1689674726502 [07-18 18:05:26:535 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:25233081 ts:0 [07-18 18:05:26:535 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:25233081 [07-18 18:05:26:535 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:685996 dataSize:118 [07-18 18:05:26:535 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:157 timestamp:1689674726535 [07-18 18:05:26:535 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:25233081 ts:0 [07-18 18:05:26:535 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:25233081 [07-18 18:05:26:535 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:39720 dataSize:118 [07-18 18:05:26:535 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:157 timestamp:1689674726535 [07-18 18:05:26:569 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:25266414 ts:0 [07-18 18:05:26:569 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:25266414 [07-18 18:05:26:569 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:686114 dataSize:110 [07-18 18:05:26:569 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:158 timestamp:1689674726569 [07-18 18:05:26:569 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:25266414 ts:0 [07-18 18:05:26:569 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:25266414 [07-18 18:05:26:569 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:39838 dataSize:110 [07-18 18:05:26:569 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:158 timestamp:1689674726569 [07-18 18:05:26:587 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:587 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 186, head index 158 [07-18 18:05:26:587 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 187, seqNo 487, timestamp 1689674717447 [07-18 18:05:26:587 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:602 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:25299747 ts:0 [07-18 18:05:26:602 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:25299747 [07-18 18:05:26:602 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:686224 dataSize:695 [07-18 18:05:26:602 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:159 timestamp:1689674726602 [07-18 18:05:26:602 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:25299747 ts:0 [07-18 18:05:26:602 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:25299747 [07-18 18:05:26:602 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:39948 dataSize:695 [07-18 18:05:26:602 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:159 timestamp:1689674726602 [07-18 18:05:26:636 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:25333080 ts:0 [07-18 18:05:26:636 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:25333080 [07-18 18:05:26:636 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:686919 dataSize:1146 [07-18 18:05:26:636 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:160 timestamp:1689674726636 [07-18 18:05:26:636 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:25333080 ts:0 [07-18 18:05:26:636 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:25333080 [07-18 18:05:26:636 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:40643 dataSize:1146 [07-18 18:05:26:636 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:160 timestamp:1689674726636 [07-18 18:05:26:669 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:25366413 ts:0 [07-18 18:05:26:669 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:25366413 [07-18 18:05:26:670 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:688065 dataSize:276 [07-18 18:05:26:670 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:161 timestamp:1689674726670 [07-18 18:05:26:670 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:25366413 ts:0 [07-18 18:05:26:670 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:25366413 [07-18 18:05:26:670 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:41789 dataSize:276 [07-18 18:05:26:670 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:161 timestamp:1689674726670 [07-18 18:05:26:697 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:697 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 187, head index 161 [07-18 18:05:26:697 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 188, seqNo 488, timestamp 1689674717480 [07-18 18:05:26:697 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:703 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:25399746 ts:0 [07-18 18:05:26:703 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:25399746 [07-18 18:05:26:703 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:688341 dataSize:152 [07-18 18:05:26:703 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:162 timestamp:1689674726703 [07-18 18:05:26:703 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:25399746 ts:0 [07-18 18:05:26:703 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:25399746 [07-18 18:05:26:703 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:42065 dataSize:152 [07-18 18:05:26:703 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:162 timestamp:1689674726703 [07-18 18:05:26:737 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:25433079 ts:0 [07-18 18:05:26:737 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:25433079 [07-18 18:05:26:737 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:688493 dataSize:136 [07-18 18:05:26:737 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:163 timestamp:1689674726737 [07-18 18:05:26:737 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:25433079 ts:0 [07-18 18:05:26:737 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:25433079 [07-18 18:05:26:737 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:42217 dataSize:136 [07-18 18:05:26:737 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:163 timestamp:1689674726737 [07-18 18:05:26:770 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:25466412 ts:0 [07-18 18:05:26:770 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:25466412 [07-18 18:05:26:770 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:688629 dataSize:725 [07-18 18:05:26:770 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:164 timestamp:1689674726770 [07-18 18:05:26:770 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:25466412 ts:0 [07-18 18:05:26:770 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:25466412 [07-18 18:05:26:770 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:42353 dataSize:725 [07-18 18:05:26:770 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:164 timestamp:1689674726770 [07-18 18:05:26:804 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:25499745 ts:0 [07-18 18:05:26:804 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:25499745 [07-18 18:05:26:804 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:689354 dataSize:1369 [07-18 18:05:26:804 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:165 timestamp:1689674726804 [07-18 18:05:26:804 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:25499745 ts:0 [07-18 18:05:26:804 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:25499745 [07-18 18:05:26:804 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:43078 dataSize:1369 [07-18 18:05:26:804 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:165 timestamp:1689674726804 [07-18 18:05:26:808 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:808 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 188, head index 165 [07-18 18:05:26:808 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 189, seqNo 489, timestamp 1689674717514 [07-18 18:05:26:808 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:838 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:25533078 ts:0 [07-18 18:05:26:838 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:25533078 [07-18 18:05:26:838 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:690723 dataSize:367 [07-18 18:05:26:838 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:166 timestamp:1689674726838 [07-18 18:05:26:838 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:25533078 ts:0 [07-18 18:05:26:838 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:25533078 [07-18 18:05:26:838 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44447 dataSize:367 [07-18 18:05:26:838 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:166 timestamp:1689674726838 [07-18 18:05:26:871 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:25566411 ts:0 [07-18 18:05:26:871 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:25566411 [07-18 18:05:26:871 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:691090 dataSize:141 [07-18 18:05:26:871 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:167 timestamp:1689674726871 [07-18 18:05:26:871 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:25566411 ts:0 [07-18 18:05:26:871 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:25566411 [07-18 18:05:26:871 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44814 dataSize:141 [07-18 18:05:26:871 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:167 timestamp:1689674726871 [07-18 18:05:26:905 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:25599744 ts:0 [07-18 18:05:26:905 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:25599744 [07-18 18:05:26:905 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:691231 dataSize:160 [07-18 18:05:26:905 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:168 timestamp:1689674726905 [07-18 18:05:26:905 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:25599744 ts:0 [07-18 18:05:26:905 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:25599744 [07-18 18:05:26:905 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44955 dataSize:160 [07-18 18:05:26:905 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:168 timestamp:1689674726905 [07-18 18:05:26:918 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:26:918 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 189, head index 168 [07-18 18:05:26:918 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 190, seqNo 490, timestamp 1689674717548 [07-18 18:05:26:918 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:26:938 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:25633077 ts:0 [07-18 18:05:26:938 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:25633077 [07-18 18:05:26:938 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:691391 dataSize:756 [07-18 18:05:26:938 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:169 timestamp:1689674726938 [07-18 18:05:26:938 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:25633077 ts:0 [07-18 18:05:26:939 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:25633077 [07-18 18:05:26:939 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:45115 dataSize:756 [07-18 18:05:26:939 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:169 timestamp:1689674726939 [07-18 18:05:26:971 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:26:971 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:26:972 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:25666410 ts:0 [07-18 18:05:26:972 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:25666410 [07-18 18:05:26:972 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:692147 dataSize:1610 [07-18 18:05:26:972 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:170 timestamp:1689674726972 [07-18 18:05:26:972 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:25666410 ts:0 [07-18 18:05:26:972 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:25666410 [07-18 18:05:26:972 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:45871 dataSize:1610 [07-18 18:05:26:972 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:170 timestamp:1689674726972 [07-18 18:05:27:6 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:25699743 ts:0 [07-18 18:05:27:6 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:25699743 [07-18 18:05:27:6 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:693757 dataSize:516 [07-18 18:05:27:6 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:171 timestamp:1689674727006 [07-18 18:05:27:6 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:25699743 ts:0 [07-18 18:05:27:6 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:25699743 [07-18 18:05:27:6 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:47481 dataSize:516 [07-18 18:05:27:6 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:171 timestamp:1689674727006 [07-18 18:05:27:28 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:28 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 190, head index 171 [07-18 18:05:27:28 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 191, seqNo 491, timestamp 1689674717581 [07-18 18:05:27:29 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:39 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:25733076 ts:0 [07-18 18:05:27:39 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:25733076 [07-18 18:05:27:39 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:694273 dataSize:231 [07-18 18:05:27:39 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:172 timestamp:1689674727039 [07-18 18:05:27:39 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:25733076 ts:0 [07-18 18:05:27:39 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:25733076 [07-18 18:05:27:39 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:47997 dataSize:231 [07-18 18:05:27:39 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:172 timestamp:1689674727039 [07-18 18:05:27:73 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:25766409 ts:0 [07-18 18:05:27:73 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:25766409 [07-18 18:05:27:73 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:694504 dataSize:250 [07-18 18:05:27:73 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:173 timestamp:1689674727073 [07-18 18:05:27:73 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:25766409 ts:0 [07-18 18:05:27:73 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:25766409 [07-18 18:05:27:73 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:48228 dataSize:250 [07-18 18:05:27:73 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:173 timestamp:1689674727073 [07-18 18:05:27:106 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:25799742 ts:0 [07-18 18:05:27:106 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:25799742 [07-18 18:05:27:107 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:694754 dataSize:1143 [07-18 18:05:27:107 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:174 timestamp:1689674727107 [07-18 18:05:27:107 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:25799742 ts:0 [07-18 18:05:27:107 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:25799742 [07-18 18:05:27:107 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:48478 dataSize:1143 [07-18 18:05:27:107 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:174 timestamp:1689674727107 [07-18 18:05:27:139 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:139 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 191, head index 174 [07-18 18:05:27:139 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 192, seqNo 492, timestamp 1689674717615 [07-18 18:05:27:139 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:140 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:25833075 ts:0 [07-18 18:05:27:140 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:25833075 [07-18 18:05:27:140 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:695897 dataSize:383 [07-18 18:05:27:140 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:175 timestamp:1689674727140 [07-18 18:05:27:140 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:25833075 ts:0 [07-18 18:05:27:140 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:25833075 [07-18 18:05:27:140 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:49621 dataSize:383 [07-18 18:05:27:140 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:175 timestamp:1689674727140 [07-18 18:05:27:174 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:25866408 ts:0 [07-18 18:05:27:174 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:25866408 [07-18 18:05:27:174 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:696280 dataSize:235 [07-18 18:05:27:174 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:176 timestamp:1689674727174 [07-18 18:05:27:174 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:25866408 ts:0 [07-18 18:05:27:174 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:25866408 [07-18 18:05:27:174 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50004 dataSize:235 [07-18 18:05:27:174 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:176 timestamp:1689674727174 [07-18 18:05:27:207 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:25899741 ts:0 [07-18 18:05:27:207 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:25899741 [07-18 18:05:27:207 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:696515 dataSize:165 [07-18 18:05:27:207 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:177 timestamp:1689674727207 [07-18 18:05:27:207 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:25899741 ts:0 [07-18 18:05:27:207 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:25899741 [07-18 18:05:27:207 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50239 dataSize:165 [07-18 18:05:27:207 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:177 timestamp:1689674727207 [07-18 18:05:27:241 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:25933074 ts:0 [07-18 18:05:27:241 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:25933074 [07-18 18:05:27:241 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:696680 dataSize:457 [07-18 18:05:27:241 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:178 timestamp:1689674727241 [07-18 18:05:27:241 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:25933074 ts:0 [07-18 18:05:27:241 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:25933074 [07-18 18:05:27:241 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50404 dataSize:457 [07-18 18:05:27:241 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:178 timestamp:1689674727241 [07-18 18:05:27:249 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:249 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 192, head index 178 [07-18 18:05:27:249 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:492->778) [07-18 18:05:27:249 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:492->778) [07-18 18:05:27:249 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 214 seqNo 514 ch0st0tr0 [07-18 18:05:27:250 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:274 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:25966407 ts:0 [07-18 18:05:27:275 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:25966407 [07-18 18:05:27:275 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:697137 dataSize:673 [07-18 18:05:27:275 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:179 timestamp:1689674727275 [07-18 18:05:27:275 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:25966407 ts:0 [07-18 18:05:27:275 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:25966407 [07-18 18:05:27:275 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50861 dataSize:673 [07-18 18:05:27:275 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:179 timestamp:1689674727275 [07-18 18:05:27:308 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:25999740 ts:0 [07-18 18:05:27:308 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:25999740 [07-18 18:05:27:308 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:697810 dataSize:465 [07-18 18:05:27:308 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:180 timestamp:1689674727308 [07-18 18:05:27:308 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:25999740 ts:0 [07-18 18:05:27:308 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:25999740 [07-18 18:05:27:308 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:51534 dataSize:465 [07-18 18:05:27:308 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:180 timestamp:1689674727308 [07-18 18:05:27:342 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:26033073 ts:0 [07-18 18:05:27:342 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:26033073 [07-18 18:05:27:342 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:698275 dataSize:248 [07-18 18:05:27:342 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:181 timestamp:1689674727342 [07-18 18:05:27:342 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:26033073 ts:0 [07-18 18:05:27:342 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:26033073 [07-18 18:05:27:342 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:51999 dataSize:248 [07-18 18:05:27:342 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:181 timestamp:1689674727342 [07-18 18:05:27:360 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:360 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 214, head index 181 [07-18 18:05:27:360 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 215, seqNo 515, timestamp 1689674718389 [07-18 18:05:27:360 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:375 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:26066406 ts:0 [07-18 18:05:27:375 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:26066406 [07-18 18:05:27:375 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:698523 dataSize:217 [07-18 18:05:27:375 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:182 timestamp:1689674727375 [07-18 18:05:27:376 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:26066406 ts:0 [07-18 18:05:27:376 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:26066406 [07-18 18:05:27:376 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52247 dataSize:217 [07-18 18:05:27:376 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:182 timestamp:1689674727376 [07-18 18:05:27:409 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:26099739 ts:0 [07-18 18:05:27:409 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:26099739 [07-18 18:05:27:409 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:698740 dataSize:280 [07-18 18:05:27:409 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:183 timestamp:1689674727409 [07-18 18:05:27:409 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:26099739 ts:0 [07-18 18:05:27:409 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:26099739 [07-18 18:05:27:409 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52464 dataSize:280 [07-18 18:05:27:409 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:183 timestamp:1689674727409 [07-18 18:05:27:443 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:26133072 ts:0 [07-18 18:05:27:443 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:26133072 [07-18 18:05:27:443 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:699020 dataSize:12088 [07-18 18:05:27:443 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:184 timestamp:1689674727443 [07-18 18:05:27:443 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:26133072 ts:0 [07-18 18:05:27:443 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:26133072 [07-18 18:05:27:443 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52744 dataSize:12088 [07-18 18:05:27:443 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:184 timestamp:1689674727443 [07-18 18:05:27:470 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:470 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 215, head index 184 [07-18 18:05:27:471 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 216, seqNo 516, timestamp 1689674718423 [07-18 18:05:27:471 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:476 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:26166405 ts:0 [07-18 18:05:27:476 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:26166405 [07-18 18:05:27:476 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:711108 dataSize:1051 [07-18 18:05:27:476 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:185 timestamp:1689674727476 [07-18 18:05:27:476 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:26166405 ts:0 [07-18 18:05:27:476 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:26166405 [07-18 18:05:27:476 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:64832 dataSize:1051 [07-18 18:05:27:477 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:185 timestamp:1689674727477 [07-18 18:05:27:510 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:26199738 ts:0 [07-18 18:05:27:510 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:26199738 [07-18 18:05:27:510 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:712159 dataSize:209 [07-18 18:05:27:510 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:186 timestamp:1689674727510 [07-18 18:05:27:510 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:26199738 ts:0 [07-18 18:05:27:510 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:26199738 [07-18 18:05:27:510 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:65883 dataSize:209 [07-18 18:05:27:510 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:186 timestamp:1689674727510 [07-18 18:05:27:544 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:26233071 ts:0 [07-18 18:05:27:544 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:26233071 [07-18 18:05:27:544 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:712368 dataSize:118 [07-18 18:05:27:544 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:187 timestamp:1689674727544 [07-18 18:05:27:544 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:26233071 ts:0 [07-18 18:05:27:544 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:26233071 [07-18 18:05:27:544 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:66092 dataSize:118 [07-18 18:05:27:544 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:187 timestamp:1689674727544 [07-18 18:05:27:577 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:26266404 ts:0 [07-18 18:05:27:577 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:26266404 [07-18 18:05:27:577 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:712486 dataSize:110 [07-18 18:05:27:577 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:188 timestamp:1689674727577 [07-18 18:05:27:577 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:26266404 ts:0 [07-18 18:05:27:577 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:26266404 [07-18 18:05:27:577 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:66210 dataSize:110 [07-18 18:05:27:577 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:188 timestamp:1689674727577 [07-18 18:05:27:581 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:581 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 216, head index 188 [07-18 18:05:27:581 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 217, seqNo 517, timestamp 1689674718456 [07-18 18:05:27:581 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:611 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:26299737 ts:0 [07-18 18:05:27:611 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:26299737 [07-18 18:05:27:611 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:712596 dataSize:695 [07-18 18:05:27:611 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:189 timestamp:1689674727611 [07-18 18:05:27:611 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:26299737 ts:0 [07-18 18:05:27:611 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:26299737 [07-18 18:05:27:611 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:66320 dataSize:695 [07-18 18:05:27:611 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:189 timestamp:1689674727611 [07-18 18:05:27:645 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:26333070 ts:0 [07-18 18:05:27:645 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:26333070 [07-18 18:05:27:645 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:713291 dataSize:1146 [07-18 18:05:27:645 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:190 timestamp:1689674727645 [07-18 18:05:27:645 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:26333070 ts:0 [07-18 18:05:27:645 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:26333070 [07-18 18:05:27:645 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:67015 dataSize:1146 [07-18 18:05:27:645 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:190 timestamp:1689674727645 [07-18 18:05:27:678 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:26366403 ts:0 [07-18 18:05:27:678 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:26366403 [07-18 18:05:27:678 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:714437 dataSize:276 [07-18 18:05:27:678 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:191 timestamp:1689674727678 [07-18 18:05:27:678 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:26366403 ts:0 [07-18 18:05:27:678 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:26366403 [07-18 18:05:27:678 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:68161 dataSize:276 [07-18 18:05:27:678 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:191 timestamp:1689674727678 [07-18 18:05:27:691 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:691 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 217, head index 191 [07-18 18:05:27:691 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 218, seqNo 518, timestamp 1689674718490 [07-18 18:05:27:691 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:712 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:26399736 ts:0 [07-18 18:05:27:712 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:26399736 [07-18 18:05:27:712 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:714713 dataSize:152 [07-18 18:05:27:712 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:192 timestamp:1689674727712 [07-18 18:05:27:712 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:26399736 ts:0 [07-18 18:05:27:712 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:26399736 [07-18 18:05:27:712 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:68437 dataSize:152 [07-18 18:05:27:712 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:192 timestamp:1689674727712 [07-18 18:05:27:746 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:26433069 ts:0 [07-18 18:05:27:746 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:26433069 [07-18 18:05:27:746 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:714865 dataSize:136 [07-18 18:05:27:746 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:193 timestamp:1689674727746 [07-18 18:05:27:746 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:26433069 ts:0 [07-18 18:05:27:746 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:26433069 [07-18 18:05:27:746 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:68589 dataSize:136 [07-18 18:05:27:746 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:193 timestamp:1689674727746 [07-18 18:05:27:779 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:26466402 ts:0 [07-18 18:05:27:780 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:26466402 [07-18 18:05:27:780 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:715001 dataSize:725 [07-18 18:05:27:780 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:194 timestamp:1689674727780 [07-18 18:05:27:780 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:26466402 ts:0 [07-18 18:05:27:780 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:26466402 [07-18 18:05:27:780 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:68725 dataSize:725 [07-18 18:05:27:780 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:194 timestamp:1689674727780 [07-18 18:05:27:793 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 18:05:27:793 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 18:05:27:802 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:802 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 218, head index 194 [07-18 18:05:27:802 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 219, seqNo 519, timestamp 1689674718524 [07-18 18:05:27:802 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:811 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:27:811 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:27:811 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:27:811 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 18:05:27:818 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:26499735 ts:0 [07-18 18:05:27:818 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:26499735 [07-18 18:05:27:818 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:715726 dataSize:1369 [07-18 18:05:27:818 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:195 timestamp:1689674727818 [07-18 18:05:27:818 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:26499735 ts:0 [07-18 18:05:27:818 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:26499735 [07-18 18:05:27:818 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:69450 dataSize:1369 [07-18 18:05:27:818 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:195 timestamp:1689674727818 [07-18 18:05:27:836 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:27:852 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:26533068 ts:0 [07-18 18:05:27:852 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:26533068 [07-18 18:05:27:852 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:717095 dataSize:367 [07-18 18:05:27:852 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:196 timestamp:1689674727852 [07-18 18:05:27:852 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:26533068 ts:0 [07-18 18:05:27:852 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:26533068 [07-18 18:05:27:852 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:70819 dataSize:367 [07-18 18:05:27:852 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:196 timestamp:1689674727852 [07-18 18:05:27:886 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:26566401 ts:0 [07-18 18:05:27:886 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:26566401 [07-18 18:05:27:886 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:717462 dataSize:141 [07-18 18:05:27:886 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:197 timestamp:1689674727886 [07-18 18:05:27:886 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:26566401 ts:0 [07-18 18:05:27:886 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:26566401 [07-18 18:05:27:886 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:71186 dataSize:141 [07-18 18:05:27:886 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:197 timestamp:1689674727886 [07-18 18:05:27:912 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:27:912 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 219, head index 197 [07-18 18:05:27:912 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 220, seqNo 520, timestamp 1689674718558 [07-18 18:05:27:912 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:27:919 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:26599734 ts:0 [07-18 18:05:27:919 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:26599734 [07-18 18:05:27:919 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:717603 dataSize:160 [07-18 18:05:27:919 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:198 timestamp:1689674727919 [07-18 18:05:27:919 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:26599734 ts:0 [07-18 18:05:27:919 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:26599734 [07-18 18:05:27:919 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:71327 dataSize:160 [07-18 18:05:27:919 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:198 timestamp:1689674727919 [07-18 18:05:27:953 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:26633067 ts:0 [07-18 18:05:27:953 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:26633067 [07-18 18:05:27:953 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:717763 dataSize:756 [07-18 18:05:27:953 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:199 timestamp:1689674727953 [07-18 18:05:27:953 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:26633067 ts:0 [07-18 18:05:27:953 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:26633067 [07-18 18:05:27:953 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:71487 dataSize:756 [07-18 18:05:27:953 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:199 timestamp:1689674727953 [07-18 18:05:27:986 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:26666400 ts:0 [07-18 18:05:27:986 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:26666400 [07-18 18:05:27:986 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:718519 dataSize:1610 [07-18 18:05:27:987 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:200 timestamp:1689674727987 [07-18 18:05:27:987 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:26666400 ts:0 [07-18 18:05:27:987 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:26666400 [07-18 18:05:27:987 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:72243 dataSize:1610 [07-18 18:05:27:987 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:200 timestamp:1689674727987 [07-18 18:05:28:20 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:26699733 ts:0 [07-18 18:05:28:20 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:26699733 [07-18 18:05:28:20 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:720129 dataSize:516 [07-18 18:05:28:20 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:201 timestamp:1689674728020 [07-18 18:05:28:20 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:26699733 ts:0 [07-18 18:05:28:20 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:26699733 [07-18 18:05:28:20 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:73853 dataSize:516 [07-18 18:05:28:20 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:201 timestamp:1689674728020 [07-18 18:05:28:22 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:22 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 220, head index 201 [07-18 18:05:28:22 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 221, seqNo 521, timestamp 1689674718591 [07-18 18:05:28:22 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:54 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:26733066 ts:0 [07-18 18:05:28:54 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:26733066 [07-18 18:05:28:54 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:720645 dataSize:231 [07-18 18:05:28:54 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:202 timestamp:1689674728054 [07-18 18:05:28:54 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:26733066 ts:0 [07-18 18:05:28:54 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:26733066 [07-18 18:05:28:54 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:74369 dataSize:231 [07-18 18:05:28:54 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:202 timestamp:1689674728054 [07-18 18:05:28:87 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:26766399 ts:0 [07-18 18:05:28:87 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:26766399 [07-18 18:05:28:87 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:720876 dataSize:250 [07-18 18:05:28:88 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:203 timestamp:1689674728087 [07-18 18:05:28:88 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:26766399 ts:0 [07-18 18:05:28:88 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:26766399 [07-18 18:05:28:88 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:74600 dataSize:250 [07-18 18:05:28:88 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:203 timestamp:1689674728088 [07-18 18:05:28:121 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:26799732 ts:0 [07-18 18:05:28:121 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:26799732 [07-18 18:05:28:121 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:721126 dataSize:1143 [07-18 18:05:28:121 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:204 timestamp:1689674728121 [07-18 18:05:28:121 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:26799732 ts:0 [07-18 18:05:28:121 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:26799732 [07-18 18:05:28:121 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:74850 dataSize:1143 [07-18 18:05:28:121 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:204 timestamp:1689674728121 [07-18 18:05:28:133 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:133 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 221, head index 204 [07-18 18:05:28:133 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 222, seqNo 522, timestamp 1689674718625 [07-18 18:05:28:133 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:155 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:26833065 ts:0 [07-18 18:05:28:155 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:26833065 [07-18 18:05:28:155 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:722269 dataSize:383 [07-18 18:05:28:155 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:205 timestamp:1689674728155 [07-18 18:05:28:155 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:26833065 ts:0 [07-18 18:05:28:155 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:26833065 [07-18 18:05:28:155 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:75993 dataSize:383 [07-18 18:05:28:155 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:205 timestamp:1689674728155 [07-18 18:05:28:188 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:26866398 ts:0 [07-18 18:05:28:188 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:26866398 [07-18 18:05:28:188 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:722652 dataSize:235 [07-18 18:05:28:188 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:206 timestamp:1689674728188 [07-18 18:05:28:188 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:26866398 ts:0 [07-18 18:05:28:188 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:26866398 [07-18 18:05:28:189 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:76376 dataSize:235 [07-18 18:05:28:189 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:206 timestamp:1689674728189 [07-18 18:05:28:222 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:26899731 ts:0 [07-18 18:05:28:222 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:26899731 [07-18 18:05:28:222 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:722887 dataSize:165 [07-18 18:05:28:222 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:207 timestamp:1689674728222 [07-18 18:05:28:222 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:26899731 ts:0 [07-18 18:05:28:222 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:26899731 [07-18 18:05:28:222 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:76611 dataSize:165 [07-18 18:05:28:222 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:207 timestamp:1689674728222 [07-18 18:05:28:243 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:243 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 222, head index 207 [07-18 18:05:28:243 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 223, seqNo 523, timestamp 1689674718659 [07-18 18:05:28:243 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:256 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:26933064 ts:0 [07-18 18:05:28:256 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:26933064 [07-18 18:05:28:256 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:723052 dataSize:457 [07-18 18:05:28:256 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:208 timestamp:1689674728256 [07-18 18:05:28:256 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:26933064 ts:0 [07-18 18:05:28:256 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:26933064 [07-18 18:05:28:256 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:76776 dataSize:457 [07-18 18:05:28:256 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:208 timestamp:1689674728256 [07-18 18:05:28:284 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:05:28:284 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:05:28:284 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:05:28:284 TUYA Debug][smart_frame.c:353] dp<17> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:05:28:284 TUYA Debug][smart_frame.c:369] dp_cntl value:8882, dp_data value:8881 [07-18 18:05:28:284 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:05:28:284 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"17":8881} [07-18 18:05:28:290 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:26966397 ts:0 [07-18 18:05:28:291 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:26966397 [07-18 18:05:28:291 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:723509 dataSize:673 [07-18 18:05:28:291 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:209 timestamp:1689674728291 [07-18 18:05:28:291 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:26966397 ts:0 [07-18 18:05:28:291 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:26966397 [07-18 18:05:28:291 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:77233 dataSize:673 [07-18 18:05:28:291 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:209 timestamp:1689674728291 [07-18 18:05:28:308 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58396 Q:1 Data:{"dps":{"17":8881}} [07-18 18:05:28:308 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:28:324 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:26999730 ts:0 [07-18 18:05:28:324 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:26999730 [07-18 18:05:28:324 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:724182 dataSize:465 [07-18 18:05:28:324 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:210 timestamp:1689674728324 [07-18 18:05:28:324 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:26999730 ts:0 [07-18 18:05:28:324 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:26999730 [07-18 18:05:28:324 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:77906 dataSize:465 [07-18 18:05:28:324 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:210 timestamp:1689674728324 [07-18 18:05:28:327 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:28:327 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:28:327 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:28:327 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 18:05:28:327 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"17":8881}}, mqtt async dp cb:0 [07-18 18:05:28:327 TUYA Trace][smart_frame.c:2512] DP ID 17 Set To 3 [07-18 18:05:28:327 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:17, curr_t:1689674728, rept_cnt:1. [07-18 18:05:28:327 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:17, curr_t:1689674728, rept_cnt:0. [07-18 18:05:28:327 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:17, curr_t:1689674728, rept_cnt:0. [07-18 18:05:28:350 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:28:353 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:353 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 223, head index 210 [07-18 18:05:28:353 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:523->810) [07-18 18:05:28:353 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:523->810) [07-18 18:05:28:353 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:524->810) [07-18 18:05:28:353 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 244 seqNo 544 ch0st0tr0 [07-18 18:05:28:354 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:358 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:27033063 ts:0 [07-18 18:05:28:358 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:27033063 [07-18 18:05:28:358 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:724647 dataSize:248 [07-18 18:05:28:358 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:211 timestamp:1689674728358 [07-18 18:05:28:358 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:27033063 ts:0 [07-18 18:05:28:358 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:27033063 [07-18 18:05:28:358 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:78371 dataSize:248 [07-18 18:05:28:358 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:211 timestamp:1689674728358 [07-18 18:05:28:391 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:27066396 ts:0 [07-18 18:05:28:391 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:27066396 [07-18 18:05:28:392 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:724895 dataSize:217 [07-18 18:05:28:392 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:212 timestamp:1689674728392 [07-18 18:05:28:392 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:27066396 ts:0 [07-18 18:05:28:392 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:27066396 [07-18 18:05:28:392 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:78619 dataSize:217 [07-18 18:05:28:392 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:212 timestamp:1689674728392 [07-18 18:05:28:425 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:27099729 ts:0 [07-18 18:05:28:425 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:27099729 [07-18 18:05:28:425 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:725112 dataSize:280 [07-18 18:05:28:425 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:213 timestamp:1689674728425 [07-18 18:05:28:425 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:27099729 ts:0 [07-18 18:05:28:425 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:27099729 [07-18 18:05:28:425 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:78836 dataSize:280 [07-18 18:05:28:425 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:213 timestamp:1689674728425 [07-18 18:05:28:459 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:27133062 ts:0 [07-18 18:05:28:459 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:27133062 [07-18 18:05:28:459 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:725392 dataSize:12088 [07-18 18:05:28:459 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:214 timestamp:1689674728459 [07-18 18:05:28:459 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:27133062 ts:0 [07-18 18:05:28:459 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:27133062 [07-18 18:05:28:459 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:79116 dataSize:12088 [07-18 18:05:28:459 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:214 timestamp:1689674728459 [07-18 18:05:28:464 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:464 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 244, head index 214 [07-18 18:05:28:464 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 245, seqNo 545, timestamp 1689674719399 [07-18 18:05:28:464 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:492 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:27166395 ts:0 [07-18 18:05:28:493 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:27166395 [07-18 18:05:28:493 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:737480 dataSize:1051 [07-18 18:05:28:493 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:215 timestamp:1689674728493 [07-18 18:05:28:493 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:27166395 ts:0 [07-18 18:05:28:493 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:27166395 [07-18 18:05:28:493 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:91204 dataSize:1051 [07-18 18:05:28:493 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:215 timestamp:1689674728493 [07-18 18:05:28:526 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:27199728 ts:0 [07-18 18:05:28:526 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:27199728 [07-18 18:05:28:526 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:738531 dataSize:209 [07-18 18:05:28:526 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:216 timestamp:1689674728526 [07-18 18:05:28:526 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:27199728 ts:0 [07-18 18:05:28:526 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:27199728 [07-18 18:05:28:526 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:92255 dataSize:209 [07-18 18:05:28:526 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:216 timestamp:1689674728526 [07-18 18:05:28:559 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:05:28:560 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:27233061 ts:0 [07-18 18:05:28:560 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:27233061 [07-18 18:05:28:560 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:738740 dataSize:118 [07-18 18:05:28:560 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:217 timestamp:1689674728560 [07-18 18:05:28:560 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:27233061 ts:0 [07-18 18:05:28:560 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:27233061 [07-18 18:05:28:560 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:92464 dataSize:118 [07-18 18:05:28:560 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:217 timestamp:1689674728560 [07-18 18:05:28:575 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:575 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 245, head index 217 [07-18 18:05:28:575 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 246, seqNo 546, timestamp 1689674719432 [07-18 18:05:28:575 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:593 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:27266394 ts:0 [07-18 18:05:28:593 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:27266394 [07-18 18:05:28:594 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:738858 dataSize:110 [07-18 18:05:28:594 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:218 timestamp:1689674728594 [07-18 18:05:28:594 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:27266394 ts:0 [07-18 18:05:28:594 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:27266394 [07-18 18:05:28:594 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:92582 dataSize:110 [07-18 18:05:28:594 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:218 timestamp:1689674728594 [07-18 18:05:28:627 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:27299727 ts:0 [07-18 18:05:28:627 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:27299727 [07-18 18:05:28:627 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:738968 dataSize:695 [07-18 18:05:28:627 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:219 timestamp:1689674728627 [07-18 18:05:28:627 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:27299727 ts:0 [07-18 18:05:28:627 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:27299727 [07-18 18:05:28:627 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:92692 dataSize:695 [07-18 18:05:28:627 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:219 timestamp:1689674728627 [07-18 18:05:28:661 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:27333060 ts:0 [07-18 18:05:28:661 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:27333060 [07-18 18:05:28:661 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:739663 dataSize:1146 [07-18 18:05:28:661 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:220 timestamp:1689674728661 [07-18 18:05:28:661 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:27333060 ts:0 [07-18 18:05:28:661 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:27333060 [07-18 18:05:28:661 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:93387 dataSize:1146 [07-18 18:05:28:661 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:220 timestamp:1689674728661 [07-18 18:05:28:685 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:685 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 246, head index 220 [07-18 18:05:28:685 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 247, seqNo 547, timestamp 1689674719466 [07-18 18:05:28:685 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:694 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:27366393 ts:0 [07-18 18:05:28:694 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:27366393 [07-18 18:05:28:694 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:740809 dataSize:276 [07-18 18:05:28:694 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:221 timestamp:1689674728694 [07-18 18:05:28:694 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:27366393 ts:0 [07-18 18:05:28:695 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:27366393 [07-18 18:05:28:695 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:94533 dataSize:276 [07-18 18:05:28:695 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:221 timestamp:1689674728695 [07-18 18:05:28:728 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:27399726 ts:0 [07-18 18:05:28:728 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:27399726 [07-18 18:05:28:728 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:741085 dataSize:152 [07-18 18:05:28:728 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:222 timestamp:1689674728728 [07-18 18:05:28:728 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:27399726 ts:0 [07-18 18:05:28:728 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:27399726 [07-18 18:05:28:728 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:94809 dataSize:152 [07-18 18:05:28:728 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:222 timestamp:1689674728728 [07-18 18:05:28:762 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:27433059 ts:0 [07-18 18:05:28:762 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:27433059 [07-18 18:05:28:762 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:741237 dataSize:136 [07-18 18:05:28:762 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:223 timestamp:1689674728762 [07-18 18:05:28:762 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:27433059 ts:0 [07-18 18:05:28:762 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:27433059 [07-18 18:05:28:762 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:94961 dataSize:136 [07-18 18:05:28:762 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:223 timestamp:1689674728762 [07-18 18:05:28:795 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:795 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 247, head index 223 [07-18 18:05:28:795 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 248, seqNo 548, timestamp 1689674719500 [07-18 18:05:28:795 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:796 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:27466392 ts:0 [07-18 18:05:28:796 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:27466392 [07-18 18:05:28:796 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:741373 dataSize:725 [07-18 18:05:28:796 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:224 timestamp:1689674728796 [07-18 18:05:28:796 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:27466392 ts:0 [07-18 18:05:28:796 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:27466392 [07-18 18:05:28:796 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:95097 dataSize:725 [07-18 18:05:28:796 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:224 timestamp:1689674728796 [07-18 18:05:28:829 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:27499725 ts:0 [07-18 18:05:28:829 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:27499725 [07-18 18:05:28:829 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:742098 dataSize:1369 [07-18 18:05:28:829 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:225 timestamp:1689674728829 [07-18 18:05:28:829 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:27499725 ts:0 [07-18 18:05:28:829 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:27499725 [07-18 18:05:28:829 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:95822 dataSize:1369 [07-18 18:05:28:829 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:225 timestamp:1689674728829 [07-18 18:05:28:863 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:27533058 ts:0 [07-18 18:05:28:863 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:27533058 [07-18 18:05:28:863 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:743467 dataSize:367 [07-18 18:05:28:863 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:226 timestamp:1689674728863 [07-18 18:05:28:863 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:27533058 ts:0 [07-18 18:05:28:863 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:27533058 [07-18 18:05:28:863 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97191 dataSize:367 [07-18 18:05:28:863 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:226 timestamp:1689674728863 [07-18 18:05:28:896 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:27566391 ts:0 [07-18 18:05:28:896 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:27566391 [07-18 18:05:28:896 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:743834 dataSize:141 [07-18 18:05:28:896 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:227 timestamp:1689674728896 [07-18 18:05:28:896 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:27566391 ts:0 [07-18 18:05:28:896 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:27566391 [07-18 18:05:28:896 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97558 dataSize:141 [07-18 18:05:28:896 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:227 timestamp:1689674728896 [07-18 18:05:28:906 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:28:906 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 248, head index 227 [07-18 18:05:28:906 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 249, seqNo 549, timestamp 1689674719533 [07-18 18:05:28:906 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:28:930 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:27599724 ts:0 [07-18 18:05:28:930 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:27599724 [07-18 18:05:28:930 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:743975 dataSize:160 [07-18 18:05:28:930 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:228 timestamp:1689674728930 [07-18 18:05:28:930 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:27599724 ts:0 [07-18 18:05:28:930 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:27599724 [07-18 18:05:28:930 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97699 dataSize:160 [07-18 18:05:28:930 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:228 timestamp:1689674728930 [07-18 18:05:28:964 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:27633057 ts:0 [07-18 18:05:28:964 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:27633057 [07-18 18:05:28:964 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:744135 dataSize:756 [07-18 18:05:28:964 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:229 timestamp:1689674728964 [07-18 18:05:28:964 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:27633057 ts:0 [07-18 18:05:28:964 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:27633057 [07-18 18:05:28:964 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97859 dataSize:756 [07-18 18:05:28:964 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:229 timestamp:1689674728964 [07-18 18:05:28:997 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:27666390 ts:0 [07-18 18:05:28:997 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:27666390 [07-18 18:05:28:997 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:744891 dataSize:1610 [07-18 18:05:28:997 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:230 timestamp:1689674728997 [07-18 18:05:28:997 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:27666390 ts:0 [07-18 18:05:28:997 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:27666390 [07-18 18:05:28:997 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:98615 dataSize:1610 [07-18 18:05:28:997 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:230 timestamp:1689674728997 [07-18 18:05:29:16 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:16 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 249, head index 230 [07-18 18:05:29:16 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 250, seqNo 550, timestamp 1689674719567 [07-18 18:05:29:16 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:31 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:27699723 ts:0 [07-18 18:05:29:31 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:27699723 [07-18 18:05:29:31 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:746501 dataSize:516 [07-18 18:05:29:31 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:231 timestamp:1689674729031 [07-18 18:05:29:31 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:27699723 ts:0 [07-18 18:05:29:31 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:27699723 [07-18 18:05:29:31 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:100225 dataSize:516 [07-18 18:05:29:31 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:231 timestamp:1689674729031 [07-18 18:05:29:64 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:27733056 ts:0 [07-18 18:05:29:65 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:27733056 [07-18 18:05:29:65 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:747017 dataSize:231 [07-18 18:05:29:65 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:232 timestamp:1689674729065 [07-18 18:05:29:65 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:27733056 ts:0 [07-18 18:05:29:65 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:27733056 [07-18 18:05:29:65 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:100741 dataSize:231 [07-18 18:05:29:65 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:232 timestamp:1689674729065 [07-18 18:05:29:98 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:27766389 ts:0 [07-18 18:05:29:98 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:27766389 [07-18 18:05:29:98 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:747248 dataSize:250 [07-18 18:05:29:98 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:233 timestamp:1689674729098 [07-18 18:05:29:98 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:27766389 ts:0 [07-18 18:05:29:98 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:27766389 [07-18 18:05:29:98 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:100972 dataSize:250 [07-18 18:05:29:98 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:233 timestamp:1689674729098 [07-18 18:05:29:123 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[2]lstCnt[145]vIFrameCnt[145] [07-18 18:05:29:123 TUYA Debug][tuya_ipc_p2p.c:5031] session[131073] detech staticCnt[0]lstCnt[10]vIFrameCnt[10] [07-18 18:05:29:126 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:126 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 250, head index 233 [07-18 18:05:29:126 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 251, seqNo 551, timestamp 1689674719600 [07-18 18:05:29:126 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:132 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:27799722 ts:0 [07-18 18:05:29:132 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:27799722 [07-18 18:05:29:132 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:747498 dataSize:1143 [07-18 18:05:29:132 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:234 timestamp:1689674729132 [07-18 18:05:29:132 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:27799722 ts:0 [07-18 18:05:29:132 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:27799722 [07-18 18:05:29:132 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:101222 dataSize:1143 [07-18 18:05:29:132 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:234 timestamp:1689674729132 [07-18 18:05:29:165 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:27833055 ts:0 [07-18 18:05:29:165 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:27833055 [07-18 18:05:29:165 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:748641 dataSize:383 [07-18 18:05:29:165 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:235 timestamp:1689674729165 [07-18 18:05:29:165 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:27833055 ts:0 [07-18 18:05:29:165 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:27833055 [07-18 18:05:29:166 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:102365 dataSize:383 [07-18 18:05:29:166 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:235 timestamp:1689674729166 [07-18 18:05:29:199 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:27866388 ts:0 [07-18 18:05:29:199 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:27866388 [07-18 18:05:29:199 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:749024 dataSize:235 [07-18 18:05:29:199 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:236 timestamp:1689674729199 [07-18 18:05:29:199 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:27866388 ts:0 [07-18 18:05:29:199 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:27866388 [07-18 18:05:29:199 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:102748 dataSize:235 [07-18 18:05:29:199 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:236 timestamp:1689674729199 [07-18 18:05:29:233 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:27899721 ts:0 [07-18 18:05:29:233 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:27899721 [07-18 18:05:29:233 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:749259 dataSize:165 [07-18 18:05:29:233 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:237 timestamp:1689674729233 [07-18 18:05:29:233 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:27899721 ts:0 [07-18 18:05:29:233 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:27899721 [07-18 18:05:29:233 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:102983 dataSize:165 [07-18 18:05:29:233 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:237 timestamp:1689674729233 [07-18 18:05:29:237 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:237 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 251, head index 237 [07-18 18:05:29:237 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:551->837) [07-18 18:05:29:237 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:551->837) [07-18 18:05:29:237 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 274 seqNo 574 ch0st0tr0 [07-18 18:05:29:237 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:268 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:27933054 ts:0 [07-18 18:05:29:268 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:27933054 [07-18 18:05:29:268 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:749424 dataSize:457 [07-18 18:05:29:268 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:238 timestamp:1689674729268 [07-18 18:05:29:269 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:27933054 ts:0 [07-18 18:05:29:269 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:27933054 [07-18 18:05:29:269 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:103148 dataSize:457 [07-18 18:05:29:269 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:238 timestamp:1689674729269 [07-18 18:05:29:302 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:27966387 ts:0 [07-18 18:05:29:302 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:27966387 [07-18 18:05:29:302 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:749881 dataSize:673 [07-18 18:05:29:302 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:239 timestamp:1689674729302 [07-18 18:05:29:302 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:27966387 ts:0 [07-18 18:05:29:302 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:27966387 [07-18 18:05:29:302 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:103605 dataSize:673 [07-18 18:05:29:302 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:239 timestamp:1689674729302 [07-18 18:05:29:336 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:27999720 ts:0 [07-18 18:05:29:336 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:27999720 [07-18 18:05:29:336 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:750554 dataSize:465 [07-18 18:05:29:336 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:240 timestamp:1689674729336 [07-18 18:05:29:336 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:27999720 ts:0 [07-18 18:05:29:336 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:27999720 [07-18 18:05:29:336 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:104278 dataSize:465 [07-18 18:05:29:336 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:240 timestamp:1689674729336 [07-18 18:05:29:347 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:347 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 274, head index 240 [07-18 18:05:29:347 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 275, seqNo 575, timestamp 1689674720407 [07-18 18:05:29:347 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:351 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:29:351 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:29:369 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:28033053 ts:0 [07-18 18:05:29:369 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:28033053 [07-18 18:05:29:370 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:751019 dataSize:248 [07-18 18:05:29:370 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:241 timestamp:1689674729370 [07-18 18:05:29:370 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:28033053 ts:0 [07-18 18:05:29:370 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:28033053 [07-18 18:05:29:370 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:104743 dataSize:248 [07-18 18:05:29:370 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:241 timestamp:1689674729370 [07-18 18:05:29:403 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:28066386 ts:0 [07-18 18:05:29:403 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:28066386 [07-18 18:05:29:403 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:751267 dataSize:217 [07-18 18:05:29:403 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:242 timestamp:1689674729403 [07-18 18:05:29:403 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:28066386 ts:0 [07-18 18:05:29:403 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:28066386 [07-18 18:05:29:403 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:104991 dataSize:217 [07-18 18:05:29:403 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:242 timestamp:1689674729403 [07-18 18:05:29:437 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:28099719 ts:0 [07-18 18:05:29:437 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:28099719 [07-18 18:05:29:437 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:751484 dataSize:280 [07-18 18:05:29:437 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:243 timestamp:1689674729437 [07-18 18:05:29:437 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:28099719 ts:0 [07-18 18:05:29:437 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:28099719 [07-18 18:05:29:437 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:105208 dataSize:280 [07-18 18:05:29:437 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:243 timestamp:1689674729437 [07-18 18:05:29:458 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:458 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 275, head index 243 [07-18 18:05:29:458 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 276, seqNo 576, timestamp 1689674720441 [07-18 18:05:29:458 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:470 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:28133052 ts:0 [07-18 18:05:29:470 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:28133052 [07-18 18:05:29:471 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:751764 dataSize:12088 [07-18 18:05:29:471 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:244 timestamp:1689674729471 [07-18 18:05:29:471 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:28133052 ts:0 [07-18 18:05:29:471 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:28133052 [07-18 18:05:29:471 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:105488 dataSize:12088 [07-18 18:05:29:471 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:244 timestamp:1689674729471 [07-18 18:05:29:504 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:28166385 ts:0 [07-18 18:05:29:504 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:28166385 [07-18 18:05:29:504 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:763852 dataSize:1051 [07-18 18:05:29:504 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:245 timestamp:1689674729504 [07-18 18:05:29:504 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:28166385 ts:0 [07-18 18:05:29:504 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:28166385 [07-18 18:05:29:504 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:117576 dataSize:1051 [07-18 18:05:29:504 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:245 timestamp:1689674729504 [07-18 18:05:29:538 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:28199718 ts:0 [07-18 18:05:29:538 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:28199718 [07-18 18:05:29:538 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:764903 dataSize:209 [07-18 18:05:29:538 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:246 timestamp:1689674729538 [07-18 18:05:29:538 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:28199718 ts:0 [07-18 18:05:29:538 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:28199718 [07-18 18:05:29:538 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:118627 dataSize:209 [07-18 18:05:29:538 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:246 timestamp:1689674729538 [07-18 18:05:29:568 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:568 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 276, head index 246 [07-18 18:05:29:568 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 277, seqNo 577, timestamp 1689674720474 [07-18 18:05:29:568 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:572 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:28233051 ts:0 [07-18 18:05:29:572 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:28233051 [07-18 18:05:29:572 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:765112 dataSize:118 [07-18 18:05:29:572 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:247 timestamp:1689674729572 [07-18 18:05:29:572 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:28233051 ts:0 [07-18 18:05:29:572 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:28233051 [07-18 18:05:29:572 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:118836 dataSize:118 [07-18 18:05:29:572 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:247 timestamp:1689674729572 [07-18 18:05:29:605 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:28266384 ts:0 [07-18 18:05:29:605 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:28266384 [07-18 18:05:29:605 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:765230 dataSize:110 [07-18 18:05:29:605 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:248 timestamp:1689674729605 [07-18 18:05:29:605 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:28266384 ts:0 [07-18 18:05:29:605 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:28266384 [07-18 18:05:29:606 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:118954 dataSize:110 [07-18 18:05:29:606 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:248 timestamp:1689674729606 [07-18 18:05:29:639 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:28299717 ts:0 [07-18 18:05:29:639 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:28299717 [07-18 18:05:29:639 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:765340 dataSize:695 [07-18 18:05:29:639 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:249 timestamp:1689674729639 [07-18 18:05:29:639 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:28299717 ts:0 [07-18 18:05:29:639 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:28299717 [07-18 18:05:29:639 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:119064 dataSize:695 [07-18 18:05:29:639 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:249 timestamp:1689674729639 [07-18 18:05:29:673 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:28333050 ts:0 [07-18 18:05:29:673 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:28333050 [07-18 18:05:29:673 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:766035 dataSize:1146 [07-18 18:05:29:673 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:250 timestamp:1689674729673 [07-18 18:05:29:673 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:28333050 ts:0 [07-18 18:05:29:673 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:28333050 [07-18 18:05:29:673 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:119759 dataSize:1146 [07-18 18:05:29:673 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:250 timestamp:1689674729673 [07-18 18:05:29:678 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:678 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 277, head index 250 [07-18 18:05:29:678 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 278, seqNo 578, timestamp 1689674720508 [07-18 18:05:29:678 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:706 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:28366383 ts:0 [07-18 18:05:29:706 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:28366383 [07-18 18:05:29:706 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:767181 dataSize:276 [07-18 18:05:29:706 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:251 timestamp:1689674729706 [07-18 18:05:29:706 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:28366383 ts:0 [07-18 18:05:29:706 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:28366383 [07-18 18:05:29:706 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:120905 dataSize:276 [07-18 18:05:29:707 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:251 timestamp:1689674729707 [07-18 18:05:29:740 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:28399716 ts:0 [07-18 18:05:29:740 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:28399716 [07-18 18:05:29:740 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:767457 dataSize:152 [07-18 18:05:29:740 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:252 timestamp:1689674729740 [07-18 18:05:29:740 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:28399716 ts:0 [07-18 18:05:29:740 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:28399716 [07-18 18:05:29:740 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:121181 dataSize:152 [07-18 18:05:29:740 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:252 timestamp:1689674729740 [07-18 18:05:29:774 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:28433049 ts:0 [07-18 18:05:29:774 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:28433049 [07-18 18:05:29:774 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:767609 dataSize:136 [07-18 18:05:29:774 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:253 timestamp:1689674729774 [07-18 18:05:29:774 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:28433049 ts:0 [07-18 18:05:29:774 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:28433049 [07-18 18:05:29:774 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:121333 dataSize:136 [07-18 18:05:29:774 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:253 timestamp:1689674729774 [07-18 18:05:29:788 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:788 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 278, head index 253 [07-18 18:05:29:788 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 279, seqNo 579, timestamp 1689674720542 [07-18 18:05:29:789 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:807 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:28466382 ts:0 [07-18 18:05:29:807 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:28466382 [07-18 18:05:29:807 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:767745 dataSize:725 [07-18 18:05:29:807 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:254 timestamp:1689674729807 [07-18 18:05:29:807 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:28466382 ts:0 [07-18 18:05:29:807 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:28466382 [07-18 18:05:29:807 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:121469 dataSize:725 [07-18 18:05:29:807 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:254 timestamp:1689674729807 [07-18 18:05:29:841 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:28499715 ts:0 [07-18 18:05:29:841 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:28499715 [07-18 18:05:29:841 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:768470 dataSize:1369 [07-18 18:05:29:841 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:255 timestamp:1689674729841 [07-18 18:05:29:841 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:28499715 ts:0 [07-18 18:05:29:841 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:28499715 [07-18 18:05:29:841 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:122194 dataSize:1369 [07-18 18:05:29:841 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:255 timestamp:1689674729841 [07-18 18:05:29:875 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:28533048 ts:0 [07-18 18:05:29:875 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:28533048 [07-18 18:05:29:875 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:769839 dataSize:367 [07-18 18:05:29:875 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:256 timestamp:1689674729875 [07-18 18:05:29:875 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:28533048 ts:0 [07-18 18:05:29:875 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:28533048 [07-18 18:05:29:875 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:123563 dataSize:367 [07-18 18:05:29:875 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:256 timestamp:1689674729875 [07-18 18:05:29:899 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:29:899 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 279, head index 256 [07-18 18:05:29:899 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 280, seqNo 580, timestamp 1689674720575 [07-18 18:05:29:899 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:29:908 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:28566381 ts:0 [07-18 18:05:29:909 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:28566381 [07-18 18:05:29:909 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:770206 dataSize:141 [07-18 18:05:29:909 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:257 timestamp:1689674729909 [07-18 18:05:29:909 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:28566381 ts:0 [07-18 18:05:29:909 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:28566381 [07-18 18:05:29:909 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:123930 dataSize:141 [07-18 18:05:29:909 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:257 timestamp:1689674729909 [07-18 18:05:29:942 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:28599714 ts:0 [07-18 18:05:29:942 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:28599714 [07-18 18:05:29:942 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:770347 dataSize:160 [07-18 18:05:29:942 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:258 timestamp:1689674729942 [07-18 18:05:29:942 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:28599714 ts:0 [07-18 18:05:29:942 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:28599714 [07-18 18:05:29:942 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:124071 dataSize:160 [07-18 18:05:29:942 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:258 timestamp:1689674729942 [07-18 18:05:29:976 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:28633047 ts:0 [07-18 18:05:29:976 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:28633047 [07-18 18:05:29:976 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:770507 dataSize:756 [07-18 18:05:29:976 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:259 timestamp:1689674729976 [07-18 18:05:29:976 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:28633047 ts:0 [07-18 18:05:29:976 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:28633047 [07-18 18:05:29:976 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:124231 dataSize:756 [07-18 18:05:29:976 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:259 timestamp:1689674729976 [07-18 18:05:30:9 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:9 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 280, head index 259 [07-18 18:05:30:9 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 281, seqNo 581, timestamp 1689674720609 [07-18 18:05:30:9 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:9 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:28666380 ts:0 [07-18 18:05:30:9 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:28666380 [07-18 18:05:30:10 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:771263 dataSize:1610 [07-18 18:05:30:10 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:260 timestamp:1689674730010 [07-18 18:05:30:10 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:28666380 ts:0 [07-18 18:05:30:10 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:28666380 [07-18 18:05:30:10 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:124987 dataSize:1610 [07-18 18:05:30:10 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:260 timestamp:1689674730010 [07-18 18:05:30:43 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:28699713 ts:0 [07-18 18:05:30:43 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:28699713 [07-18 18:05:30:43 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:772873 dataSize:516 [07-18 18:05:30:43 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:261 timestamp:1689674730043 [07-18 18:05:30:43 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:28699713 ts:0 [07-18 18:05:30:43 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:28699713 [07-18 18:05:30:43 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:126597 dataSize:516 [07-18 18:05:30:43 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:261 timestamp:1689674730043 [07-18 18:05:30:77 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:28733046 ts:0 [07-18 18:05:30:77 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:28733046 [07-18 18:05:30:77 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:773389 dataSize:231 [07-18 18:05:30:77 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:262 timestamp:1689674730077 [07-18 18:05:30:77 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:28733046 ts:0 [07-18 18:05:30:77 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:28733046 [07-18 18:05:30:77 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:127113 dataSize:231 [07-18 18:05:30:77 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:262 timestamp:1689674730077 [07-18 18:05:30:110 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:28766379 ts:0 [07-18 18:05:30:110 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:28766379 [07-18 18:05:30:110 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:773620 dataSize:250 [07-18 18:05:30:110 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:263 timestamp:1689674730110 [07-18 18:05:30:110 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:28766379 ts:0 [07-18 18:05:30:110 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:28766379 [07-18 18:05:30:111 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:127344 dataSize:250 [07-18 18:05:30:111 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:263 timestamp:1689674730111 [07-18 18:05:30:119 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:120 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 281, head index 263 [07-18 18:05:30:120 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 282, seqNo 582, timestamp 1689674720643 [07-18 18:05:30:120 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:144 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:28799712 ts:0 [07-18 18:05:30:144 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:28799712 [07-18 18:05:30:144 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:773870 dataSize:1143 [07-18 18:05:30:144 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:264 timestamp:1689674730144 [07-18 18:05:30:144 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:28799712 ts:0 [07-18 18:05:30:144 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:28799712 [07-18 18:05:30:144 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:127594 dataSize:1143 [07-18 18:05:30:144 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:264 timestamp:1689674730144 [07-18 18:05:30:178 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:28833045 ts:0 [07-18 18:05:30:178 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:28833045 [07-18 18:05:30:178 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:775013 dataSize:383 [07-18 18:05:30:178 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:265 timestamp:1689674730178 [07-18 18:05:30:178 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:28833045 ts:0 [07-18 18:05:30:178 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:28833045 [07-18 18:05:30:178 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:128737 dataSize:383 [07-18 18:05:30:178 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:265 timestamp:1689674730178 [07-18 18:05:30:211 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:28866378 ts:0 [07-18 18:05:30:211 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:28866378 [07-18 18:05:30:212 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:775396 dataSize:235 [07-18 18:05:30:212 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:266 timestamp:1689674730212 [07-18 18:05:30:212 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:28866378 ts:0 [07-18 18:05:30:212 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:28866378 [07-18 18:05:30:212 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:129120 dataSize:235 [07-18 18:05:30:212 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:266 timestamp:1689674730212 [07-18 18:05:30:230 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:230 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 282, head index 266 [07-18 18:05:30:230 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 283, seqNo 583, timestamp 1689674720676 [07-18 18:05:30:230 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:245 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:28899711 ts:0 [07-18 18:05:30:245 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:28899711 [07-18 18:05:30:245 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:775631 dataSize:165 [07-18 18:05:30:245 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:267 timestamp:1689674730245 [07-18 18:05:30:245 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:28899711 ts:0 [07-18 18:05:30:245 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:28899711 [07-18 18:05:30:245 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:129355 dataSize:165 [07-18 18:05:30:245 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:267 timestamp:1689674730245 [07-18 18:05:30:279 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:28933044 ts:0 [07-18 18:05:30:279 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:28933044 [07-18 18:05:30:279 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:775796 dataSize:457 [07-18 18:05:30:279 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:268 timestamp:1689674730279 [07-18 18:05:30:279 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:28933044 ts:0 [07-18 18:05:30:279 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:28933044 [07-18 18:05:30:279 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:129520 dataSize:457 [07-18 18:05:30:279 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:268 timestamp:1689674730279 [07-18 18:05:30:312 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:28966377 ts:0 [07-18 18:05:30:312 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:28966377 [07-18 18:05:30:313 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:776253 dataSize:673 [07-18 18:05:30:313 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:269 timestamp:1689674730313 [07-18 18:05:30:313 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:28966377 ts:0 [07-18 18:05:30:313 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:28966377 [07-18 18:05:30:313 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:129977 dataSize:673 [07-18 18:05:30:313 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:269 timestamp:1689674730313 [07-18 18:05:30:340 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:340 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 283, head index 269 [07-18 18:05:30:340 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:583->869) [07-18 18:05:30:340 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:583->869) [07-18 18:05:30:340 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 4 seqNo 604 ch0st0tr0 [07-18 18:05:30:341 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:346 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:28999710 ts:0 [07-18 18:05:30:346 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:28999710 [07-18 18:05:30:346 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:776926 dataSize:465 [07-18 18:05:30:346 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:270 timestamp:1689674730346 [07-18 18:05:30:346 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:28999710 ts:0 [07-18 18:05:30:346 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:28999710 [07-18 18:05:30:346 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:130650 dataSize:465 [07-18 18:05:30:346 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:270 timestamp:1689674730346 [07-18 18:05:30:351 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:30:351 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:30:352 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [49000] num[2] [07-18 18:05:30:380 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:29033043 ts:0 [07-18 18:05:30:380 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:29033043 [07-18 18:05:30:380 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:777391 dataSize:248 [07-18 18:05:30:380 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:271 timestamp:1689674730380 [07-18 18:05:30:380 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:29033043 ts:0 [07-18 18:05:30:380 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:29033043 [07-18 18:05:30:380 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:131115 dataSize:248 [07-18 18:05:30:380 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:271 timestamp:1689674730380 [07-18 18:05:30:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:29066376 ts:0 [07-18 18:05:30:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:29066376 [07-18 18:05:30:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:777639 dataSize:217 [07-18 18:05:30:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:272 timestamp:1689674730413 [07-18 18:05:30:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:29066376 ts:0 [07-18 18:05:30:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:29066376 [07-18 18:05:30:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:131363 dataSize:217 [07-18 18:05:30:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:272 timestamp:1689674730413 [07-18 18:05:30:447 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:29099709 ts:0 [07-18 18:05:30:447 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:29099709 [07-18 18:05:30:447 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:777856 dataSize:280 [07-18 18:05:30:447 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:273 timestamp:1689674730447 [07-18 18:05:30:447 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:29099709 ts:0 [07-18 18:05:30:447 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:29099709 [07-18 18:05:30:447 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:131580 dataSize:280 [07-18 18:05:30:447 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:273 timestamp:1689674730447 [07-18 18:05:30:451 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:451 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 4, head index 273 [07-18 18:05:30:451 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 5, seqNo 605, timestamp 1689674721416 [07-18 18:05:30:451 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:481 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:29133042 ts:0 [07-18 18:05:30:481 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:29133042 [07-18 18:05:30:481 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:778136 dataSize:12088 [07-18 18:05:30:481 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:274 timestamp:1689674730481 [07-18 18:05:30:481 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:29133042 ts:0 [07-18 18:05:30:481 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:29133042 [07-18 18:05:30:481 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:131860 dataSize:12088 [07-18 18:05:30:481 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:274 timestamp:1689674730481 [07-18 18:05:30:514 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:29166375 ts:0 [07-18 18:05:30:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:29166375 [07-18 18:05:30:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:790224 dataSize:1051 [07-18 18:05:30:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:275 timestamp:1689674730514 [07-18 18:05:30:514 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:29166375 ts:0 [07-18 18:05:30:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:29166375 [07-18 18:05:30:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:143948 dataSize:1051 [07-18 18:05:30:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:275 timestamp:1689674730514 [07-18 18:05:30:548 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:29199708 ts:0 [07-18 18:05:30:548 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:29199708 [07-18 18:05:30:548 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:791275 dataSize:209 [07-18 18:05:30:548 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:276 timestamp:1689674730548 [07-18 18:05:30:548 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:29199708 ts:0 [07-18 18:05:30:548 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:29199708 [07-18 18:05:30:548 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:144999 dataSize:209 [07-18 18:05:30:548 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:276 timestamp:1689674730548 [07-18 18:05:30:562 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:562 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 5, head index 276 [07-18 18:05:30:562 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 6, seqNo 606, timestamp 1689674721454 [07-18 18:05:30:562 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:29233041 ts:0 [07-18 18:05:30:582 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:29233041 [07-18 18:05:30:582 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:791484 dataSize:118 [07-18 18:05:30:582 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:277 timestamp:1689674730582 [07-18 18:05:30:582 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:29233041 ts:0 [07-18 18:05:30:582 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:29233041 [07-18 18:05:30:582 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:145208 dataSize:118 [07-18 18:05:30:582 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:277 timestamp:1689674730582 [07-18 18:05:30:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:29266374 ts:0 [07-18 18:05:30:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:29266374 [07-18 18:05:30:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:791602 dataSize:110 [07-18 18:05:30:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:278 timestamp:1689674730615 [07-18 18:05:30:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:29266374 ts:0 [07-18 18:05:30:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:29266374 [07-18 18:05:30:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:145326 dataSize:110 [07-18 18:05:30:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:278 timestamp:1689674730615 [07-18 18:05:30:649 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:29299707 ts:0 [07-18 18:05:30:649 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:29299707 [07-18 18:05:30:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:791712 dataSize:695 [07-18 18:05:30:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:279 timestamp:1689674730649 [07-18 18:05:30:649 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:29299707 ts:0 [07-18 18:05:30:649 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:29299707 [07-18 18:05:30:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:145436 dataSize:695 [07-18 18:05:30:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:279 timestamp:1689674730649 [07-18 18:05:30:672 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:672 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 6, head index 279 [07-18 18:05:30:672 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 7, seqNo 607, timestamp 1689674721488 [07-18 18:05:30:672 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:29333040 ts:0 [07-18 18:05:30:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:29333040 [07-18 18:05:30:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:792407 dataSize:1146 [07-18 18:05:30:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:280 timestamp:1689674730682 [07-18 18:05:30:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:29333040 ts:0 [07-18 18:05:30:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:29333040 [07-18 18:05:30:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:146131 dataSize:1146 [07-18 18:05:30:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:280 timestamp:1689674730682 [07-18 18:05:30:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:29366373 ts:0 [07-18 18:05:30:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:29366373 [07-18 18:05:30:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:793553 dataSize:276 [07-18 18:05:30:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:281 timestamp:1689674730716 [07-18 18:05:30:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:29366373 ts:0 [07-18 18:05:30:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:29366373 [07-18 18:05:30:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:147277 dataSize:276 [07-18 18:05:30:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:281 timestamp:1689674730716 [07-18 18:05:30:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:29399706 ts:0 [07-18 18:05:30:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:29399706 [07-18 18:05:30:750 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:793829 dataSize:152 [07-18 18:05:30:750 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:282 timestamp:1689674730750 [07-18 18:05:30:750 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:29399706 ts:0 [07-18 18:05:30:750 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:29399706 [07-18 18:05:30:750 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:147553 dataSize:152 [07-18 18:05:30:750 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:282 timestamp:1689674730750 [07-18 18:05:30:782 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:782 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 7, head index 282 [07-18 18:05:30:782 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 8, seqNo 608, timestamp 1689674721521 [07-18 18:05:30:782 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:29433039 ts:0 [07-18 18:05:30:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:29433039 [07-18 18:05:30:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:793981 dataSize:136 [07-18 18:05:30:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:283 timestamp:1689674730783 [07-18 18:05:30:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:29433039 ts:0 [07-18 18:05:30:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:29433039 [07-18 18:05:30:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:147705 dataSize:136 [07-18 18:05:30:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:283 timestamp:1689674730783 [07-18 18:05:30:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:29466372 ts:0 [07-18 18:05:30:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:29466372 [07-18 18:05:30:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:794117 dataSize:725 [07-18 18:05:30:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:284 timestamp:1689674730817 [07-18 18:05:30:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:29466372 ts:0 [07-18 18:05:30:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:29466372 [07-18 18:05:30:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:147841 dataSize:725 [07-18 18:05:30:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:284 timestamp:1689674730817 [07-18 18:05:30:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:29499705 ts:0 [07-18 18:05:30:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:29499705 [07-18 18:05:30:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:794842 dataSize:1369 [07-18 18:05:30:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:285 timestamp:1689674730850 [07-18 18:05:30:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:29499705 ts:0 [07-18 18:05:30:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:29499705 [07-18 18:05:30:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:148566 dataSize:1369 [07-18 18:05:30:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:285 timestamp:1689674730850 [07-18 18:05:30:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:29533038 ts:0 [07-18 18:05:30:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:29533038 [07-18 18:05:30:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:796211 dataSize:367 [07-18 18:05:30:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:286 timestamp:1689674730884 [07-18 18:05:30:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:29533038 ts:0 [07-18 18:05:30:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:29533038 [07-18 18:05:30:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:149935 dataSize:367 [07-18 18:05:30:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:286 timestamp:1689674730884 [07-18 18:05:30:893 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:30:893 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 8, head index 286 [07-18 18:05:30:893 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 9, seqNo 609, timestamp 1689674721555 [07-18 18:05:30:893 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:30:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:29566371 ts:0 [07-18 18:05:30:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:29566371 [07-18 18:05:30:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:796578 dataSize:141 [07-18 18:05:30:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:287 timestamp:1689674730918 [07-18 18:05:30:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:29566371 ts:0 [07-18 18:05:30:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:29566371 [07-18 18:05:30:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:150302 dataSize:141 [07-18 18:05:30:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:287 timestamp:1689674730918 [07-18 18:05:30:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:29599704 ts:0 [07-18 18:05:30:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:29599704 [07-18 18:05:30:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:796719 dataSize:160 [07-18 18:05:30:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:288 timestamp:1689674730951 [07-18 18:05:30:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:29599704 ts:0 [07-18 18:05:30:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:29599704 [07-18 18:05:30:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:150443 dataSize:160 [07-18 18:05:30:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:288 timestamp:1689674730951 [07-18 18:05:30:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:29633037 ts:0 [07-18 18:05:30:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:29633037 [07-18 18:05:30:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:796879 dataSize:756 [07-18 18:05:30:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:289 timestamp:1689674730985 [07-18 18:05:30:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:29633037 ts:0 [07-18 18:05:30:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:29633037 [07-18 18:05:30:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:150603 dataSize:756 [07-18 18:05:30:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:289 timestamp:1689674730985 [07-18 18:05:31:3 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:3 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 9, head index 289 [07-18 18:05:31:3 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 10, seqNo 610, timestamp 1689674721589 [07-18 18:05:31:3 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:19 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:29666370 ts:0 [07-18 18:05:31:19 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:29666370 [07-18 18:05:31:19 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:797635 dataSize:1610 [07-18 18:05:31:19 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:290 timestamp:1689674731019 [07-18 18:05:31:19 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:29666370 ts:0 [07-18 18:05:31:19 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:29666370 [07-18 18:05:31:19 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:151359 dataSize:1610 [07-18 18:05:31:19 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:290 timestamp:1689674731019 [07-18 18:05:31:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:29699703 ts:0 [07-18 18:05:31:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:29699703 [07-18 18:05:31:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:799245 dataSize:516 [07-18 18:05:31:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:291 timestamp:1689674731052 [07-18 18:05:31:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:29699703 ts:0 [07-18 18:05:31:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:29699703 [07-18 18:05:31:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:152969 dataSize:516 [07-18 18:05:31:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:291 timestamp:1689674731052 [07-18 18:05:31:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:29733036 ts:0 [07-18 18:05:31:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:29733036 [07-18 18:05:31:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:799761 dataSize:231 [07-18 18:05:31:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:292 timestamp:1689674731086 [07-18 18:05:31:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:29733036 ts:0 [07-18 18:05:31:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:29733036 [07-18 18:05:31:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:153485 dataSize:231 [07-18 18:05:31:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:292 timestamp:1689674731086 [07-18 18:05:31:113 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:113 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 10, head index 292 [07-18 18:05:31:113 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 11, seqNo 611, timestamp 1689674721622 [07-18 18:05:31:114 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:120 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:29766369 ts:0 [07-18 18:05:31:120 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:29766369 [07-18 18:05:31:120 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:799992 dataSize:250 [07-18 18:05:31:120 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:293 timestamp:1689674731120 [07-18 18:05:31:120 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:29766369 ts:0 [07-18 18:05:31:120 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:29766369 [07-18 18:05:31:120 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:153716 dataSize:250 [07-18 18:05:31:120 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:293 timestamp:1689674731120 [07-18 18:05:31:153 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:29799702 ts:0 [07-18 18:05:31:153 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:29799702 [07-18 18:05:31:153 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:800242 dataSize:1143 [07-18 18:05:31:153 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:294 timestamp:1689674731153 [07-18 18:05:31:153 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:29799702 ts:0 [07-18 18:05:31:153 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:29799702 [07-18 18:05:31:153 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:153966 dataSize:1143 [07-18 18:05:31:153 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:294 timestamp:1689674731153 [07-18 18:05:31:187 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:29833035 ts:0 [07-18 18:05:31:187 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:29833035 [07-18 18:05:31:187 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:801385 dataSize:383 [07-18 18:05:31:187 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:295 timestamp:1689674731187 [07-18 18:05:31:187 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:29833035 ts:0 [07-18 18:05:31:187 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:29833035 [07-18 18:05:31:187 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:155109 dataSize:383 [07-18 18:05:31:187 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:295 timestamp:1689674731187 [07-18 18:05:31:220 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:29866368 ts:0 [07-18 18:05:31:220 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:29866368 [07-18 18:05:31:220 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:801768 dataSize:235 [07-18 18:05:31:220 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:296 timestamp:1689674731220 [07-18 18:05:31:221 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:29866368 ts:0 [07-18 18:05:31:221 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:29866368 [07-18 18:05:31:221 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:155492 dataSize:235 [07-18 18:05:31:221 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:296 timestamp:1689674731221 [07-18 18:05:31:224 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:224 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 11, head index 296 [07-18 18:05:31:224 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 12, seqNo 612, timestamp 1689674721656 [07-18 18:05:31:224 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:254 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:29899701 ts:0 [07-18 18:05:31:254 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:29899701 [07-18 18:05:31:254 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:802003 dataSize:165 [07-18 18:05:31:254 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:297 timestamp:1689674731254 [07-18 18:05:31:254 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:29899701 ts:0 [07-18 18:05:31:254 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:29899701 [07-18 18:05:31:254 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:155727 dataSize:165 [07-18 18:05:31:254 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:297 timestamp:1689674731254 [07-18 18:05:31:288 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:29933034 ts:0 [07-18 18:05:31:288 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:29933034 [07-18 18:05:31:288 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:802168 dataSize:457 [07-18 18:05:31:288 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:298 timestamp:1689674731288 [07-18 18:05:31:288 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:29933034 ts:0 [07-18 18:05:31:288 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:29933034 [07-18 18:05:31:288 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:155892 dataSize:457 [07-18 18:05:31:288 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:298 timestamp:1689674731288 [07-18 18:05:31:321 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:29966367 ts:0 [07-18 18:05:31:321 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:29966367 [07-18 18:05:31:321 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:802625 dataSize:673 [07-18 18:05:31:321 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:299 timestamp:1689674731321 [07-18 18:05:31:321 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:29966367 ts:0 [07-18 18:05:31:322 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:29966367 [07-18 18:05:31:322 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:156349 dataSize:673 [07-18 18:05:31:322 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:299 timestamp:1689674731322 [07-18 18:05:31:334 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:334 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 12, head index 299 [07-18 18:05:31:334 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:612->899) [07-18 18:05:31:334 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:612->899) [07-18 18:05:31:334 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:613->899) [07-18 18:05:31:334 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 34 seqNo 634 ch0st0tr0 [07-18 18:05:31:335 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:352 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:31:352 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:31:355 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:29999700 ts:0 [07-18 18:05:31:355 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:29999700 [07-18 18:05:31:355 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:803298 dataSize:465 [07-18 18:05:31:355 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:0 timestamp:1689674731355 [07-18 18:05:31:355 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:29999700 ts:0 [07-18 18:05:31:355 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:29999700 [07-18 18:05:31:355 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:157022 dataSize:465 [07-18 18:05:31:355 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:0 timestamp:1689674731355 [07-18 18:05:31:389 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:30033033 ts:0 [07-18 18:05:31:389 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:30033033 [07-18 18:05:31:389 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:803763 dataSize:248 [07-18 18:05:31:389 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:1 timestamp:1689674731389 [07-18 18:05:31:389 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:30033033 ts:0 [07-18 18:05:31:389 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:30033033 [07-18 18:05:31:389 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:157487 dataSize:248 [07-18 18:05:31:389 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:1 timestamp:1689674731389 [07-18 18:05:31:422 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:30066366 ts:0 [07-18 18:05:31:422 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:30066366 [07-18 18:05:31:422 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:804011 dataSize:217 [07-18 18:05:31:422 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:2 timestamp:1689674731422 [07-18 18:05:31:422 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:30066366 ts:0 [07-18 18:05:31:422 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:30066366 [07-18 18:05:31:422 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:157735 dataSize:217 [07-18 18:05:31:422 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:2 timestamp:1689674731422 [07-18 18:05:31:445 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:445 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 34, head index 2 [07-18 18:05:31:445 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 35, seqNo 635, timestamp 1689674722430 [07-18 18:05:31:445 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:456 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:30099699 ts:0 [07-18 18:05:31:456 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:30099699 [07-18 18:05:31:456 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:804228 dataSize:280 [07-18 18:05:31:456 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:3 timestamp:1689674731456 [07-18 18:05:31:456 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:30099699 ts:0 [07-18 18:05:31:456 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:30099699 [07-18 18:05:31:456 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:157952 dataSize:280 [07-18 18:05:31:456 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:3 timestamp:1689674731456 [07-18 18:05:31:489 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:30133032 ts:0 [07-18 18:05:31:490 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:30133032 [07-18 18:05:31:490 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:804508 dataSize:12088 [07-18 18:05:31:490 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:4 timestamp:1689674731490 [07-18 18:05:31:490 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:30133032 ts:0 [07-18 18:05:31:490 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:30133032 [07-18 18:05:31:490 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:158232 dataSize:12088 [07-18 18:05:31:490 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:4 timestamp:1689674731490 [07-18 18:05:31:523 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:30166365 ts:0 [07-18 18:05:31:523 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:30166365 [07-18 18:05:31:523 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:816596 dataSize:1051 [07-18 18:05:31:523 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:5 timestamp:1689674731523 [07-18 18:05:31:523 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:30166365 ts:0 [07-18 18:05:31:523 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:30166365 [07-18 18:05:31:523 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:170320 dataSize:1051 [07-18 18:05:31:523 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:5 timestamp:1689674731523 [07-18 18:05:31:556 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:556 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 35, head index 5 [07-18 18:05:31:556 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 36, seqNo 636, timestamp 1689674722463 [07-18 18:05:31:556 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:557 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:30199698 ts:0 [07-18 18:05:31:557 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:30199698 [07-18 18:05:31:557 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:817647 dataSize:209 [07-18 18:05:31:557 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:6 timestamp:1689674731557 [07-18 18:05:31:557 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:30199698 ts:0 [07-18 18:05:31:557 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:30199698 [07-18 18:05:31:557 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:171371 dataSize:209 [07-18 18:05:31:557 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:6 timestamp:1689674731557 [07-18 18:05:31:590 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:30233031 ts:0 [07-18 18:05:31:590 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:30233031 [07-18 18:05:31:590 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:817856 dataSize:118 [07-18 18:05:31:590 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:7 timestamp:1689674731590 [07-18 18:05:31:590 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:30233031 ts:0 [07-18 18:05:31:590 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:30233031 [07-18 18:05:31:590 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:171580 dataSize:118 [07-18 18:05:31:590 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:7 timestamp:1689674731590 [07-18 18:05:31:624 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:30266364 ts:0 [07-18 18:05:31:624 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:30266364 [07-18 18:05:31:624 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:817974 dataSize:110 [07-18 18:05:31:624 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:8 timestamp:1689674731624 [07-18 18:05:31:624 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:30266364 ts:0 [07-18 18:05:31:624 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:30266364 [07-18 18:05:31:624 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:171698 dataSize:110 [07-18 18:05:31:624 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:8 timestamp:1689674731624 [07-18 18:05:31:658 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:30299697 ts:0 [07-18 18:05:31:658 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:30299697 [07-18 18:05:31:658 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:818084 dataSize:695 [07-18 18:05:31:658 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:9 timestamp:1689674731658 [07-18 18:05:31:658 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:30299697 ts:0 [07-18 18:05:31:658 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:30299697 [07-18 18:05:31:658 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:171808 dataSize:695 [07-18 18:05:31:658 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:9 timestamp:1689674731658 [07-18 18:05:31:666 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:666 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 36, head index 9 [07-18 18:05:31:666 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 37, seqNo 637, timestamp 1689674722497 [07-18 18:05:31:666 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:691 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:30333030 ts:0 [07-18 18:05:31:692 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:30333030 [07-18 18:05:31:692 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:818779 dataSize:1146 [07-18 18:05:31:692 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:10 timestamp:1689674731692 [07-18 18:05:31:692 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:30333030 ts:0 [07-18 18:05:31:692 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:30333030 [07-18 18:05:31:692 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:172503 dataSize:1146 [07-18 18:05:31:692 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:10 timestamp:1689674731692 [07-18 18:05:31:726 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:30366363 ts:0 [07-18 18:05:31:726 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:30366363 [07-18 18:05:31:726 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:819925 dataSize:276 [07-18 18:05:31:726 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:11 timestamp:1689674731726 [07-18 18:05:31:726 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:30366363 ts:0 [07-18 18:05:31:726 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:30366363 [07-18 18:05:31:726 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:173649 dataSize:276 [07-18 18:05:31:726 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:11 timestamp:1689674731726 [07-18 18:05:31:759 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:30399696 ts:0 [07-18 18:05:31:759 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:30399696 [07-18 18:05:31:759 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:820201 dataSize:152 [07-18 18:05:31:759 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:12 timestamp:1689674731759 [07-18 18:05:31:759 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:30399696 ts:0 [07-18 18:05:31:759 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:30399696 [07-18 18:05:31:759 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:173925 dataSize:152 [07-18 18:05:31:759 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:12 timestamp:1689674731759 [07-18 18:05:31:776 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:776 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 37, head index 12 [07-18 18:05:31:776 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 38, seqNo 638, timestamp 1689674722531 [07-18 18:05:31:777 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:793 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:30433029 ts:0 [07-18 18:05:31:793 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:30433029 [07-18 18:05:31:793 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:820353 dataSize:136 [07-18 18:05:31:793 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:13 timestamp:1689674731793 [07-18 18:05:31:793 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:30433029 ts:0 [07-18 18:05:31:793 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:30433029 [07-18 18:05:31:793 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:174077 dataSize:136 [07-18 18:05:31:793 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:13 timestamp:1689674731793 [07-18 18:05:31:826 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:30466362 ts:0 [07-18 18:05:31:826 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:30466362 [07-18 18:05:31:826 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:820489 dataSize:725 [07-18 18:05:31:826 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:14 timestamp:1689674731826 [07-18 18:05:31:826 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:30466362 ts:0 [07-18 18:05:31:826 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:30466362 [07-18 18:05:31:827 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:174213 dataSize:725 [07-18 18:05:31:827 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:14 timestamp:1689674731827 [07-18 18:05:31:860 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:30499695 ts:0 [07-18 18:05:31:860 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:30499695 [07-18 18:05:31:860 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:821214 dataSize:1369 [07-18 18:05:31:860 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:15 timestamp:1689674731860 [07-18 18:05:31:860 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:30499695 ts:0 [07-18 18:05:31:860 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:30499695 [07-18 18:05:31:860 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:174938 dataSize:1369 [07-18 18:05:31:860 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:15 timestamp:1689674731860 [07-18 18:05:31:887 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:887 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 38, head index 15 [07-18 18:05:31:887 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 39, seqNo 639, timestamp 1689674722564 [07-18 18:05:31:887 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:31:894 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:30533028 ts:0 [07-18 18:05:31:894 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:30533028 [07-18 18:05:31:894 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:822583 dataSize:367 [07-18 18:05:31:894 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:16 timestamp:1689674731894 [07-18 18:05:31:894 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:30533028 ts:0 [07-18 18:05:31:894 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:30533028 [07-18 18:05:31:894 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:176307 dataSize:367 [07-18 18:05:31:894 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:16 timestamp:1689674731894 [07-18 18:05:31:927 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:30566361 ts:0 [07-18 18:05:31:927 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:30566361 [07-18 18:05:31:927 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:822950 dataSize:141 [07-18 18:05:31:927 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:17 timestamp:1689674731927 [07-18 18:05:31:927 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:30566361 ts:0 [07-18 18:05:31:927 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:30566361 [07-18 18:05:31:927 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:176674 dataSize:141 [07-18 18:05:31:927 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:17 timestamp:1689674731927 [07-18 18:05:31:961 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:30599694 ts:0 [07-18 18:05:31:961 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:30599694 [07-18 18:05:31:961 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:823091 dataSize:160 [07-18 18:05:31:961 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:18 timestamp:1689674731961 [07-18 18:05:31:961 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:30599694 ts:0 [07-18 18:05:31:961 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:30599694 [07-18 18:05:31:961 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:176815 dataSize:160 [07-18 18:05:31:961 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:18 timestamp:1689674731961 [07-18 18:05:31:994 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:30633027 ts:0 [07-18 18:05:31:994 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:30633027 [07-18 18:05:31:994 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:823251 dataSize:756 [07-18 18:05:31:995 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:19 timestamp:1689674731995 [07-18 18:05:31:995 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:30633027 ts:0 [07-18 18:05:31:995 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:30633027 [07-18 18:05:31:995 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:176975 dataSize:756 [07-18 18:05:31:995 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:19 timestamp:1689674731995 [07-18 18:05:31:997 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:31:997 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 39, head index 19 [07-18 18:05:31:997 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 40, seqNo 640, timestamp 1689674722598 [07-18 18:05:31:997 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:28 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:30666360 ts:0 [07-18 18:05:32:28 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:30666360 [07-18 18:05:32:28 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:824007 dataSize:1610 [07-18 18:05:32:28 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:20 timestamp:1689674732028 [07-18 18:05:32:28 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:30666360 ts:0 [07-18 18:05:32:28 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:30666360 [07-18 18:05:32:28 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:177731 dataSize:1610 [07-18 18:05:32:28 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:20 timestamp:1689674732028 [07-18 18:05:32:62 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:30699693 ts:0 [07-18 18:05:32:62 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:30699693 [07-18 18:05:32:62 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:825617 dataSize:516 [07-18 18:05:32:62 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:21 timestamp:1689674732062 [07-18 18:05:32:62 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:30699693 ts:0 [07-18 18:05:32:62 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:30699693 [07-18 18:05:32:62 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:179341 dataSize:516 [07-18 18:05:32:62 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:21 timestamp:1689674732062 [07-18 18:05:32:95 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:30733026 ts:0 [07-18 18:05:32:95 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:30733026 [07-18 18:05:32:95 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:826133 dataSize:231 [07-18 18:05:32:96 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:22 timestamp:1689674732096 [07-18 18:05:32:96 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:30733026 ts:0 [07-18 18:05:32:96 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:30733026 [07-18 18:05:32:96 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:179857 dataSize:231 [07-18 18:05:32:96 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:22 timestamp:1689674732096 [07-18 18:05:32:108 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:108 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 40, head index 22 [07-18 18:05:32:108 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 41, seqNo 641, timestamp 1689674722632 [07-18 18:05:32:108 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:129 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:30766359 ts:0 [07-18 18:05:32:129 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:30766359 [07-18 18:05:32:129 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:826364 dataSize:250 [07-18 18:05:32:129 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:23 timestamp:1689674732129 [07-18 18:05:32:129 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:30766359 ts:0 [07-18 18:05:32:129 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:30766359 [07-18 18:05:32:129 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:180088 dataSize:250 [07-18 18:05:32:129 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:23 timestamp:1689674732129 [07-18 18:05:32:163 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:30799692 ts:0 [07-18 18:05:32:163 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:30799692 [07-18 18:05:32:163 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:826614 dataSize:1143 [07-18 18:05:32:163 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:24 timestamp:1689674732163 [07-18 18:05:32:163 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:30799692 ts:0 [07-18 18:05:32:163 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:30799692 [07-18 18:05:32:163 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:180338 dataSize:1143 [07-18 18:05:32:163 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:24 timestamp:1689674732163 [07-18 18:05:32:196 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:30833025 ts:0 [07-18 18:05:32:196 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:30833025 [07-18 18:05:32:196 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:827757 dataSize:383 [07-18 18:05:32:196 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:25 timestamp:1689674732196 [07-18 18:05:32:196 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:30833025 ts:0 [07-18 18:05:32:196 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:30833025 [07-18 18:05:32:196 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:181481 dataSize:383 [07-18 18:05:32:196 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:25 timestamp:1689674732196 [07-18 18:05:32:218 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:218 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 41, head index 25 [07-18 18:05:32:218 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 42, seqNo 642, timestamp 1689674722665 [07-18 18:05:32:218 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:230 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:30866358 ts:0 [07-18 18:05:32:230 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:30866358 [07-18 18:05:32:230 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:828140 dataSize:235 [07-18 18:05:32:230 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:26 timestamp:1689674732230 [07-18 18:05:32:230 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:30866358 ts:0 [07-18 18:05:32:230 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:30866358 [07-18 18:05:32:230 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:181864 dataSize:235 [07-18 18:05:32:230 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:26 timestamp:1689674732230 [07-18 18:05:32:263 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:30899691 ts:0 [07-18 18:05:32:264 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:30899691 [07-18 18:05:32:264 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:828375 dataSize:165 [07-18 18:05:32:264 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:27 timestamp:1689674732264 [07-18 18:05:32:264 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:30899691 ts:0 [07-18 18:05:32:264 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:30899691 [07-18 18:05:32:264 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:182099 dataSize:165 [07-18 18:05:32:264 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:27 timestamp:1689674732264 [07-18 18:05:32:297 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:30933024 ts:0 [07-18 18:05:32:297 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:30933024 [07-18 18:05:32:297 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:828540 dataSize:457 [07-18 18:05:32:297 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:28 timestamp:1689674732297 [07-18 18:05:32:297 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:30933024 ts:0 [07-18 18:05:32:297 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:30933024 [07-18 18:05:32:297 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:182264 dataSize:457 [07-18 18:05:32:297 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:28 timestamp:1689674732297 [07-18 18:05:32:328 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:328 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 42, head index 28 [07-18 18:05:32:328 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:642->928) [07-18 18:05:32:328 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:642->928) [07-18 18:05:32:329 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 64 seqNo 664 ch0st0tr0 [07-18 18:05:32:329 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:331 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:30966357 ts:0 [07-18 18:05:32:331 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:30966357 [07-18 18:05:32:331 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:828997 dataSize:673 [07-18 18:05:32:331 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:29 timestamp:1689674732331 [07-18 18:05:32:331 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:30966357 ts:0 [07-18 18:05:32:331 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:30966357 [07-18 18:05:32:331 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:182721 dataSize:673 [07-18 18:05:32:331 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:29 timestamp:1689674732331 [07-18 18:05:32:353 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:32:353 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:32:364 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:30999690 ts:0 [07-18 18:05:32:364 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:30999690 [07-18 18:05:32:364 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:829670 dataSize:465 [07-18 18:05:32:364 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:30 timestamp:1689674732364 [07-18 18:05:32:364 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:30999690 ts:0 [07-18 18:05:32:364 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:30999690 [07-18 18:05:32:364 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:183394 dataSize:465 [07-18 18:05:32:364 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:30 timestamp:1689674732364 [07-18 18:05:32:398 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:31033023 ts:0 [07-18 18:05:32:398 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:31033023 [07-18 18:05:32:398 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:830135 dataSize:248 [07-18 18:05:32:398 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:31 timestamp:1689674732398 [07-18 18:05:32:398 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:31033023 ts:0 [07-18 18:05:32:398 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:31033023 [07-18 18:05:32:398 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:183859 dataSize:248 [07-18 18:05:32:398 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:31 timestamp:1689674732398 [07-18 18:05:32:432 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:31066356 ts:0 [07-18 18:05:32:432 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:31066356 [07-18 18:05:32:432 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:830383 dataSize:217 [07-18 18:05:32:432 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:32 timestamp:1689674732432 [07-18 18:05:32:432 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:31066356 ts:0 [07-18 18:05:32:432 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:31066356 [07-18 18:05:32:432 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:184107 dataSize:217 [07-18 18:05:32:432 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:32 timestamp:1689674732432 [07-18 18:05:32:439 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:439 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 64, head index 32 [07-18 18:05:32:439 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 65, seqNo 665, timestamp 1689674723439 [07-18 18:05:32:439 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:465 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:31099689 ts:0 [07-18 18:05:32:465 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:31099689 [07-18 18:05:32:465 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:830600 dataSize:280 [07-18 18:05:32:465 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:33 timestamp:1689674732465 [07-18 18:05:32:465 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:31099689 ts:0 [07-18 18:05:32:465 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:31099689 [07-18 18:05:32:465 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:184324 dataSize:280 [07-18 18:05:32:465 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:33 timestamp:1689674732465 [07-18 18:05:32:499 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:31133022 ts:0 [07-18 18:05:32:499 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:31133022 [07-18 18:05:32:499 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:830880 dataSize:12088 [07-18 18:05:32:499 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:34 timestamp:1689674732499 [07-18 18:05:32:499 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:31133022 ts:0 [07-18 18:05:32:499 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:31133022 [07-18 18:05:32:499 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:184604 dataSize:12088 [07-18 18:05:32:499 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:34 timestamp:1689674732499 [07-18 18:05:32:533 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:31166355 ts:0 [07-18 18:05:32:533 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:31166355 [07-18 18:05:32:533 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:842968 dataSize:1051 [07-18 18:05:32:533 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:35 timestamp:1689674732533 [07-18 18:05:32:533 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:31166355 ts:0 [07-18 18:05:32:533 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:31166355 [07-18 18:05:32:533 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:196692 dataSize:1051 [07-18 18:05:32:533 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:35 timestamp:1689674732533 [07-18 18:05:32:550 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:550 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 65, head index 35 [07-18 18:05:32:550 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 66, seqNo 666, timestamp 1689674723473 [07-18 18:05:32:550 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:566 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:31199688 ts:0 [07-18 18:05:32:566 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:31199688 [07-18 18:05:32:566 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:844019 dataSize:209 [07-18 18:05:32:566 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:36 timestamp:1689674732566 [07-18 18:05:32:566 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:31199688 ts:0 [07-18 18:05:32:566 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:31199688 [07-18 18:05:32:566 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:197743 dataSize:209 [07-18 18:05:32:567 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:36 timestamp:1689674732567 [07-18 18:05:32:600 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:31233021 ts:0 [07-18 18:05:32:600 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:31233021 [07-18 18:05:32:600 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:844228 dataSize:118 [07-18 18:05:32:600 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:37 timestamp:1689674732600 [07-18 18:05:32:600 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:31233021 ts:0 [07-18 18:05:32:600 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:31233021 [07-18 18:05:32:600 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:197952 dataSize:118 [07-18 18:05:32:600 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:37 timestamp:1689674732600 [07-18 18:05:32:634 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:31266354 ts:0 [07-18 18:05:32:634 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:31266354 [07-18 18:05:32:634 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:844346 dataSize:110 [07-18 18:05:32:634 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:38 timestamp:1689674732634 [07-18 18:05:32:634 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:31266354 ts:0 [07-18 18:05:32:634 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:31266354 [07-18 18:05:32:634 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:198070 dataSize:110 [07-18 18:05:32:634 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:38 timestamp:1689674732634 [07-18 18:05:32:660 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:660 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 66, head index 38 [07-18 18:05:32:660 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 67, seqNo 667, timestamp 1689674723507 [07-18 18:05:32:660 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:667 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:31299687 ts:0 [07-18 18:05:32:667 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:31299687 [07-18 18:05:32:667 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:844456 dataSize:695 [07-18 18:05:32:667 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:39 timestamp:1689674732667 [07-18 18:05:32:667 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:31299687 ts:0 [07-18 18:05:32:667 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:31299687 [07-18 18:05:32:667 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:198180 dataSize:695 [07-18 18:05:32:667 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:39 timestamp:1689674732667 [07-18 18:05:32:701 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:31333020 ts:0 [07-18 18:05:32:701 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:31333020 [07-18 18:05:32:701 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:845151 dataSize:1146 [07-18 18:05:32:701 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:40 timestamp:1689674732701 [07-18 18:05:32:701 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:31333020 ts:0 [07-18 18:05:32:701 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:31333020 [07-18 18:05:32:701 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:198875 dataSize:1146 [07-18 18:05:32:701 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:40 timestamp:1689674732701 [07-18 18:05:32:734 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:31366353 ts:0 [07-18 18:05:32:734 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:31366353 [07-18 18:05:32:734 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:846297 dataSize:276 [07-18 18:05:32:734 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:41 timestamp:1689674732734 [07-18 18:05:32:734 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:31366353 ts:0 [07-18 18:05:32:734 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:31366353 [07-18 18:05:32:734 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:200021 dataSize:276 [07-18 18:05:32:734 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:41 timestamp:1689674732734 [07-18 18:05:32:768 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:31399686 ts:0 [07-18 18:05:32:768 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:31399686 [07-18 18:05:32:768 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:846573 dataSize:152 [07-18 18:05:32:768 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:42 timestamp:1689674732768 [07-18 18:05:32:768 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:31399686 ts:0 [07-18 18:05:32:768 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:31399686 [07-18 18:05:32:768 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:200297 dataSize:152 [07-18 18:05:32:768 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:42 timestamp:1689674732768 [07-18 18:05:32:770 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:770 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 67, head index 42 [07-18 18:05:32:770 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 68, seqNo 668, timestamp 1689674723540 [07-18 18:05:32:771 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:802 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:31433019 ts:0 [07-18 18:05:32:802 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:31433019 [07-18 18:05:32:802 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:846725 dataSize:136 [07-18 18:05:32:802 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:43 timestamp:1689674732802 [07-18 18:05:32:802 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:31433019 ts:0 [07-18 18:05:32:802 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:31433019 [07-18 18:05:32:802 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:200449 dataSize:136 [07-18 18:05:32:802 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:43 timestamp:1689674732802 [07-18 18:05:32:835 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:31466352 ts:0 [07-18 18:05:32:835 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:31466352 [07-18 18:05:32:835 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:846861 dataSize:725 [07-18 18:05:32:835 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:44 timestamp:1689674732835 [07-18 18:05:32:835 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:31466352 ts:0 [07-18 18:05:32:835 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:31466352 [07-18 18:05:32:835 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:200585 dataSize:725 [07-18 18:05:32:835 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:44 timestamp:1689674732835 [07-18 18:05:32:869 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:31499685 ts:0 [07-18 18:05:32:869 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:31499685 [07-18 18:05:32:869 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:847586 dataSize:1369 [07-18 18:05:32:869 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:45 timestamp:1689674732869 [07-18 18:05:32:869 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:31499685 ts:0 [07-18 18:05:32:869 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:31499685 [07-18 18:05:32:869 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:201310 dataSize:1369 [07-18 18:05:32:869 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:45 timestamp:1689674732869 [07-18 18:05:32:881 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:881 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 68, head index 45 [07-18 18:05:32:881 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 69, seqNo 669, timestamp 1689674723574 [07-18 18:05:32:881 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:32:902 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:31533018 ts:0 [07-18 18:05:32:902 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:31533018 [07-18 18:05:32:902 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:848955 dataSize:367 [07-18 18:05:32:902 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:46 timestamp:1689674732902 [07-18 18:05:32:902 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:31533018 ts:0 [07-18 18:05:32:902 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:31533018 [07-18 18:05:32:902 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:202679 dataSize:367 [07-18 18:05:32:902 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:46 timestamp:1689674732902 [07-18 18:05:32:936 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:31566351 ts:0 [07-18 18:05:32:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:31566351 [07-18 18:05:32:936 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:849322 dataSize:141 [07-18 18:05:32:936 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:47 timestamp:1689674732936 [07-18 18:05:32:936 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:31566351 ts:0 [07-18 18:05:32:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:31566351 [07-18 18:05:32:936 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:203046 dataSize:141 [07-18 18:05:32:936 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:47 timestamp:1689674732936 [07-18 18:05:32:970 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:31599684 ts:0 [07-18 18:05:32:970 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:31599684 [07-18 18:05:32:970 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:849463 dataSize:160 [07-18 18:05:32:970 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:48 timestamp:1689674732970 [07-18 18:05:32:970 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:31599684 ts:0 [07-18 18:05:32:970 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:31599684 [07-18 18:05:32:970 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:203187 dataSize:160 [07-18 18:05:32:970 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:48 timestamp:1689674732970 [07-18 18:05:32:992 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:32:992 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 69, head index 48 [07-18 18:05:32:992 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 70, seqNo 670, timestamp 1689674723608 [07-18 18:05:32:992 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:3 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:31633017 ts:0 [07-18 18:05:33:3 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:31633017 [07-18 18:05:33:3 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:849623 dataSize:756 [07-18 18:05:33:3 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:49 timestamp:1689674733003 [07-18 18:05:33:3 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:31633017 ts:0 [07-18 18:05:33:3 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:31633017 [07-18 18:05:33:3 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:203347 dataSize:756 [07-18 18:05:33:3 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:49 timestamp:1689674733003 [07-18 18:05:33:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:31666350 ts:0 [07-18 18:05:33:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:31666350 [07-18 18:05:33:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:850379 dataSize:1610 [07-18 18:05:33:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:50 timestamp:1689674733037 [07-18 18:05:33:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:31666350 ts:0 [07-18 18:05:33:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:31666350 [07-18 18:05:33:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:204103 dataSize:1610 [07-18 18:05:33:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:50 timestamp:1689674733037 [07-18 18:05:33:70 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:31699683 ts:0 [07-18 18:05:33:70 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:31699683 [07-18 18:05:33:71 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:851989 dataSize:516 [07-18 18:05:33:71 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:51 timestamp:1689674733071 [07-18 18:05:33:71 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:31699683 ts:0 [07-18 18:05:33:71 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:31699683 [07-18 18:05:33:71 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:205713 dataSize:516 [07-18 18:05:33:71 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:51 timestamp:1689674733071 [07-18 18:05:33:102 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:102 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 70, head index 51 [07-18 18:05:33:102 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 71, seqNo 671, timestamp 1689674723641 [07-18 18:05:33:102 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:104 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:31733016 ts:0 [07-18 18:05:33:104 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:31733016 [07-18 18:05:33:104 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:852505 dataSize:231 [07-18 18:05:33:104 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:52 timestamp:1689674733104 [07-18 18:05:33:104 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:31733016 ts:0 [07-18 18:05:33:104 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:31733016 [07-18 18:05:33:104 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:206229 dataSize:231 [07-18 18:05:33:104 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:52 timestamp:1689674733104 [07-18 18:05:33:138 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:31766349 ts:0 [07-18 18:05:33:138 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:31766349 [07-18 18:05:33:138 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:852736 dataSize:250 [07-18 18:05:33:138 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:53 timestamp:1689674733138 [07-18 18:05:33:138 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:31766349 ts:0 [07-18 18:05:33:138 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:31766349 [07-18 18:05:33:138 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:206460 dataSize:250 [07-18 18:05:33:138 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:53 timestamp:1689674733138 [07-18 18:05:33:171 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:31799682 ts:0 [07-18 18:05:33:171 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:31799682 [07-18 18:05:33:172 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:852986 dataSize:1143 [07-18 18:05:33:172 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:54 timestamp:1689674733172 [07-18 18:05:33:172 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:31799682 ts:0 [07-18 18:05:33:172 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:31799682 [07-18 18:05:33:172 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:206710 dataSize:1143 [07-18 18:05:33:172 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:54 timestamp:1689674733172 [07-18 18:05:33:205 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:31833015 ts:0 [07-18 18:05:33:205 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:31833015 [07-18 18:05:33:205 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:854129 dataSize:383 [07-18 18:05:33:205 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:55 timestamp:1689674733205 [07-18 18:05:33:205 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:31833015 ts:0 [07-18 18:05:33:205 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:31833015 [07-18 18:05:33:205 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:207853 dataSize:383 [07-18 18:05:33:205 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:55 timestamp:1689674733205 [07-18 18:05:33:213 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:213 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 71, head index 55 [07-18 18:05:33:213 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 72, seqNo 672, timestamp 1689674723675 [07-18 18:05:33:213 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:239 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:31866348 ts:0 [07-18 18:05:33:239 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:31866348 [07-18 18:05:33:239 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:854512 dataSize:235 [07-18 18:05:33:239 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:56 timestamp:1689674733239 [07-18 18:05:33:239 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:31866348 ts:0 [07-18 18:05:33:239 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:31866348 [07-18 18:05:33:239 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:208236 dataSize:235 [07-18 18:05:33:239 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:56 timestamp:1689674733239 [07-18 18:05:33:266 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:05:33:272 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:31899681 ts:0 [07-18 18:05:33:272 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:31899681 [07-18 18:05:33:272 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:854747 dataSize:165 [07-18 18:05:33:272 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:57 timestamp:1689674733272 [07-18 18:05:33:272 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:31899681 ts:0 [07-18 18:05:33:272 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:31899681 [07-18 18:05:33:272 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:208471 dataSize:165 [07-18 18:05:33:272 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:57 timestamp:1689674733272 [07-18 18:05:33:306 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:31933014 ts:0 [07-18 18:05:33:306 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:31933014 [07-18 18:05:33:306 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:854912 dataSize:457 [07-18 18:05:33:306 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:58 timestamp:1689674733306 [07-18 18:05:33:306 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:31933014 ts:0 [07-18 18:05:33:306 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:31933014 [07-18 18:05:33:306 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:208636 dataSize:457 [07-18 18:05:33:306 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:58 timestamp:1689674733306 [07-18 18:05:33:323 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:323 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 72, head index 58 [07-18 18:05:33:323 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:672->958) [07-18 18:05:33:323 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:672->958) [07-18 18:05:33:323 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 94 seqNo 694 ch0st0tr0 [07-18 18:05:33:324 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:340 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:31966347 ts:0 [07-18 18:05:33:340 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:31966347 [07-18 18:05:33:340 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:855369 dataSize:673 [07-18 18:05:33:340 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:59 timestamp:1689674733340 [07-18 18:05:33:340 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:31966347 ts:0 [07-18 18:05:33:340 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:31966347 [07-18 18:05:33:340 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:209093 dataSize:673 [07-18 18:05:33:340 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:59 timestamp:1689674733340 [07-18 18:05:33:354 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:33:354 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:33:373 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:31999680 ts:0 [07-18 18:05:33:373 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:31999680 [07-18 18:05:33:373 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:856042 dataSize:465 [07-18 18:05:33:373 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:60 timestamp:1689674733373 [07-18 18:05:33:373 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:31999680 ts:0 [07-18 18:05:33:373 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:31999680 [07-18 18:05:33:373 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:209766 dataSize:465 [07-18 18:05:33:373 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:60 timestamp:1689674733373 [07-18 18:05:33:407 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:32033013 ts:0 [07-18 18:05:33:407 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:32033013 [07-18 18:05:33:407 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:856507 dataSize:248 [07-18 18:05:33:407 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:61 timestamp:1689674733407 [07-18 18:05:33:407 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:32033013 ts:0 [07-18 18:05:33:407 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:32033013 [07-18 18:05:33:407 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:210231 dataSize:248 [07-18 18:05:33:407 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:61 timestamp:1689674733407 [07-18 18:05:33:434 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:434 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 94, head index 61 [07-18 18:05:33:434 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 95, seqNo 695, timestamp 1689674724449 [07-18 18:05:33:434 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:441 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:32066346 ts:0 [07-18 18:05:33:441 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:32066346 [07-18 18:05:33:441 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:856755 dataSize:217 [07-18 18:05:33:441 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:62 timestamp:1689674733441 [07-18 18:05:33:441 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:32066346 ts:0 [07-18 18:05:33:441 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:32066346 [07-18 18:05:33:441 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:210479 dataSize:217 [07-18 18:05:33:441 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:62 timestamp:1689674733441 [07-18 18:05:33:474 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:32099679 ts:0 [07-18 18:05:33:474 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:32099679 [07-18 18:05:33:474 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:856972 dataSize:280 [07-18 18:05:33:474 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:63 timestamp:1689674733474 [07-18 18:05:33:474 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:32099679 ts:0 [07-18 18:05:33:474 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:32099679 [07-18 18:05:33:474 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:210696 dataSize:280 [07-18 18:05:33:474 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:63 timestamp:1689674733474 [07-18 18:05:33:508 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:32133012 ts:0 [07-18 18:05:33:508 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:32133012 [07-18 18:05:33:508 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:857252 dataSize:12088 [07-18 18:05:33:508 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:64 timestamp:1689674733508 [07-18 18:05:33:508 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:32133012 ts:0 [07-18 18:05:33:508 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:32133012 [07-18 18:05:33:508 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:210976 dataSize:12088 [07-18 18:05:33:508 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:64 timestamp:1689674733508 [07-18 18:05:33:542 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:32166345 ts:0 [07-18 18:05:33:542 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:32166345 [07-18 18:05:33:542 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:869340 dataSize:1051 [07-18 18:05:33:542 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:65 timestamp:1689674733542 [07-18 18:05:33:542 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:32166345 ts:0 [07-18 18:05:33:542 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:32166345 [07-18 18:05:33:542 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:223064 dataSize:1051 [07-18 18:05:33:542 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:65 timestamp:1689674733542 [07-18 18:05:33:545 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:545 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 95, head index 65 [07-18 18:05:33:546 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 96, seqNo 696, timestamp 1689674724483 [07-18 18:05:33:546 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:575 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:32199678 ts:0 [07-18 18:05:33:575 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:32199678 [07-18 18:05:33:575 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:870391 dataSize:209 [07-18 18:05:33:575 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:66 timestamp:1689674733575 [07-18 18:05:33:575 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:32199678 ts:0 [07-18 18:05:33:575 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:32199678 [07-18 18:05:33:575 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:224115 dataSize:209 [07-18 18:05:33:575 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:66 timestamp:1689674733575 [07-18 18:05:33:609 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:32233011 ts:0 [07-18 18:05:33:609 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:32233011 [07-18 18:05:33:609 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:870600 dataSize:118 [07-18 18:05:33:609 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:67 timestamp:1689674733609 [07-18 18:05:33:609 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:32233011 ts:0 [07-18 18:05:33:609 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:32233011 [07-18 18:05:33:609 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:224324 dataSize:118 [07-18 18:05:33:609 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:67 timestamp:1689674733609 [07-18 18:05:33:643 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:32266344 ts:0 [07-18 18:05:33:643 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:32266344 [07-18 18:05:33:643 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:870718 dataSize:110 [07-18 18:05:33:643 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:68 timestamp:1689674733643 [07-18 18:05:33:643 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:32266344 ts:0 [07-18 18:05:33:643 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:32266344 [07-18 18:05:33:643 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:224442 dataSize:110 [07-18 18:05:33:643 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:68 timestamp:1689674733643 [07-18 18:05:33:656 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:656 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 96, head index 68 [07-18 18:05:33:656 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 97, seqNo 697, timestamp 1689674724517 [07-18 18:05:33:656 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:676 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:32299677 ts:0 [07-18 18:05:33:676 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:32299677 [07-18 18:05:33:676 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:870828 dataSize:695 [07-18 18:05:33:676 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:69 timestamp:1689674733676 [07-18 18:05:33:676 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:32299677 ts:0 [07-18 18:05:33:676 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:32299677 [07-18 18:05:33:676 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:224552 dataSize:695 [07-18 18:05:33:676 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:69 timestamp:1689674733676 [07-18 18:05:33:710 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:32333010 ts:0 [07-18 18:05:33:710 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:32333010 [07-18 18:05:33:710 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:871523 dataSize:1146 [07-18 18:05:33:710 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:70 timestamp:1689674733710 [07-18 18:05:33:710 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:32333010 ts:0 [07-18 18:05:33:710 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:32333010 [07-18 18:05:33:710 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:225247 dataSize:1146 [07-18 18:05:33:710 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:70 timestamp:1689674733710 [07-18 18:05:33:744 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:32366343 ts:0 [07-18 18:05:33:744 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:32366343 [07-18 18:05:33:744 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:872669 dataSize:276 [07-18 18:05:33:744 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:71 timestamp:1689674733744 [07-18 18:05:33:744 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:32366343 ts:0 [07-18 18:05:33:744 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:32366343 [07-18 18:05:33:744 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:226393 dataSize:276 [07-18 18:05:33:744 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:71 timestamp:1689674733744 [07-18 18:05:33:766 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:766 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 97, head index 71 [07-18 18:05:33:766 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 98, seqNo 698, timestamp 1689674724550 [07-18 18:05:33:766 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:777 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:32399676 ts:0 [07-18 18:05:33:777 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:32399676 [07-18 18:05:33:777 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:872945 dataSize:152 [07-18 18:05:33:777 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:72 timestamp:1689674733777 [07-18 18:05:33:777 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:32399676 ts:0 [07-18 18:05:33:777 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:32399676 [07-18 18:05:33:777 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:226669 dataSize:152 [07-18 18:05:33:777 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:72 timestamp:1689674733777 [07-18 18:05:33:811 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:32433009 ts:0 [07-18 18:05:33:811 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:32433009 [07-18 18:05:33:811 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:873097 dataSize:136 [07-18 18:05:33:811 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:73 timestamp:1689674733811 [07-18 18:05:33:811 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:32433009 ts:0 [07-18 18:05:33:811 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:32433009 [07-18 18:05:33:811 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:226821 dataSize:136 [07-18 18:05:33:811 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:73 timestamp:1689674733811 [07-18 18:05:33:844 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:32466342 ts:0 [07-18 18:05:33:844 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:32466342 [07-18 18:05:33:844 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:873233 dataSize:725 [07-18 18:05:33:844 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:74 timestamp:1689674733844 [07-18 18:05:33:844 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:32466342 ts:0 [07-18 18:05:33:844 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:32466342 [07-18 18:05:33:844 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:226957 dataSize:725 [07-18 18:05:33:845 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:74 timestamp:1689674733845 [07-18 18:05:33:877 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:877 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 98, head index 74 [07-18 18:05:33:877 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 99, seqNo 699, timestamp 1689674724584 [07-18 18:05:33:877 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:33:878 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:32499675 ts:0 [07-18 18:05:33:878 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:32499675 [07-18 18:05:33:878 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:873958 dataSize:1369 [07-18 18:05:33:878 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:75 timestamp:1689674733878 [07-18 18:05:33:878 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:32499675 ts:0 [07-18 18:05:33:878 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:32499675 [07-18 18:05:33:878 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:227682 dataSize:1369 [07-18 18:05:33:878 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:75 timestamp:1689674733878 [07-18 18:05:33:911 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:32533008 ts:0 [07-18 18:05:33:912 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:32533008 [07-18 18:05:33:912 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:875327 dataSize:367 [07-18 18:05:33:912 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:76 timestamp:1689674733912 [07-18 18:05:33:912 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:32533008 ts:0 [07-18 18:05:33:912 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:32533008 [07-18 18:05:33:912 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:229051 dataSize:367 [07-18 18:05:33:912 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:76 timestamp:1689674733912 [07-18 18:05:33:945 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:32566341 ts:0 [07-18 18:05:33:945 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:32566341 [07-18 18:05:33:945 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:875694 dataSize:141 [07-18 18:05:33:945 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:77 timestamp:1689674733945 [07-18 18:05:33:945 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:32566341 ts:0 [07-18 18:05:33:945 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:32566341 [07-18 18:05:33:945 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:229418 dataSize:141 [07-18 18:05:33:945 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:77 timestamp:1689674733945 [07-18 18:05:33:979 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:32599674 ts:0 [07-18 18:05:33:979 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:32599674 [07-18 18:05:33:979 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:875835 dataSize:160 [07-18 18:05:33:979 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:78 timestamp:1689674733979 [07-18 18:05:33:979 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:32599674 ts:0 [07-18 18:05:33:979 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:32599674 [07-18 18:05:33:979 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:229559 dataSize:160 [07-18 18:05:33:979 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:78 timestamp:1689674733979 [07-18 18:05:33:987 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:33:987 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 99, head index 78 [07-18 18:05:33:987 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 100, seqNo 700, timestamp 1689674724618 [07-18 18:05:33:987 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:12 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:32633007 ts:0 [07-18 18:05:34:12 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:32633007 [07-18 18:05:34:12 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:875995 dataSize:756 [07-18 18:05:34:12 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:79 timestamp:1689674734012 [07-18 18:05:34:12 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:32633007 ts:0 [07-18 18:05:34:12 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:32633007 [07-18 18:05:34:12 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:229719 dataSize:756 [07-18 18:05:34:12 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:79 timestamp:1689674734012 [07-18 18:05:34:46 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:32666340 ts:0 [07-18 18:05:34:46 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:32666340 [07-18 18:05:34:46 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:876751 dataSize:1610 [07-18 18:05:34:46 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:80 timestamp:1689674734046 [07-18 18:05:34:46 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:32666340 ts:0 [07-18 18:05:34:46 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:32666340 [07-18 18:05:34:46 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:230475 dataSize:1610 [07-18 18:05:34:46 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:80 timestamp:1689674734046 [07-18 18:05:34:80 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:32699673 ts:0 [07-18 18:05:34:80 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:32699673 [07-18 18:05:34:80 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:878361 dataSize:516 [07-18 18:05:34:80 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:81 timestamp:1689674734080 [07-18 18:05:34:80 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:32699673 ts:0 [07-18 18:05:34:80 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:32699673 [07-18 18:05:34:80 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:232085 dataSize:516 [07-18 18:05:34:80 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:81 timestamp:1689674734080 [07-18 18:05:34:98 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:98 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 100, head index 81 [07-18 18:05:34:98 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 101, seqNo 701, timestamp 1689674724651 [07-18 18:05:34:98 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:113 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:32733006 ts:0 [07-18 18:05:34:113 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:32733006 [07-18 18:05:34:113 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:878877 dataSize:231 [07-18 18:05:34:113 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:82 timestamp:1689674734113 [07-18 18:05:34:113 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:32733006 ts:0 [07-18 18:05:34:113 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:32733006 [07-18 18:05:34:113 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:232601 dataSize:231 [07-18 18:05:34:113 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:82 timestamp:1689674734113 [07-18 18:05:34:113 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:05:34:113 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:05:34:113 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:35 [07-18 18:05:34:147 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:32766339 ts:0 [07-18 18:05:34:147 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:32766339 [07-18 18:05:34:147 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:879108 dataSize:250 [07-18 18:05:34:147 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:83 timestamp:1689674734147 [07-18 18:05:34:147 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:32766339 ts:0 [07-18 18:05:34:147 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:32766339 [07-18 18:05:34:147 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:232832 dataSize:250 [07-18 18:05:34:147 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:83 timestamp:1689674734147 [07-18 18:05:34:181 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:32799672 ts:0 [07-18 18:05:34:181 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:32799672 [07-18 18:05:34:181 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:879358 dataSize:1143 [07-18 18:05:34:181 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:84 timestamp:1689674734181 [07-18 18:05:34:181 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:32799672 ts:0 [07-18 18:05:34:181 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:32799672 [07-18 18:05:34:181 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:233082 dataSize:1143 [07-18 18:05:34:181 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:84 timestamp:1689674734181 [07-18 18:05:34:208 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:208 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 101, head index 84 [07-18 18:05:34:208 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 102, seqNo 702, timestamp 1689674724685 [07-18 18:05:34:208 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:214 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:32833005 ts:0 [07-18 18:05:34:214 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:32833005 [07-18 18:05:34:214 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:880501 dataSize:383 [07-18 18:05:34:214 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:85 timestamp:1689674734214 [07-18 18:05:34:214 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:32833005 ts:0 [07-18 18:05:34:214 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:32833005 [07-18 18:05:34:214 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:234225 dataSize:383 [07-18 18:05:34:214 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:85 timestamp:1689674734214 [07-18 18:05:34:248 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:32866338 ts:0 [07-18 18:05:34:248 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:32866338 [07-18 18:05:34:248 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:880884 dataSize:235 [07-18 18:05:34:248 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:86 timestamp:1689674734248 [07-18 18:05:34:248 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:32866338 ts:0 [07-18 18:05:34:248 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:32866338 [07-18 18:05:34:248 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:234608 dataSize:235 [07-18 18:05:34:248 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:86 timestamp:1689674734248 [07-18 18:05:34:281 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:32899671 ts:0 [07-18 18:05:34:282 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:32899671 [07-18 18:05:34:282 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:881119 dataSize:165 [07-18 18:05:34:282 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:87 timestamp:1689674734282 [07-18 18:05:34:282 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:32899671 ts:0 [07-18 18:05:34:282 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:32899671 [07-18 18:05:34:282 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:234843 dataSize:165 [07-18 18:05:34:282 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:87 timestamp:1689674734282 [07-18 18:05:34:317 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:32933004 ts:0 [07-18 18:05:34:317 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:32933004 [07-18 18:05:34:317 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:881284 dataSize:457 [07-18 18:05:34:317 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:88 timestamp:1689674734317 [07-18 18:05:34:317 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:32933004 ts:0 [07-18 18:05:34:317 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:32933004 [07-18 18:05:34:317 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:235008 dataSize:457 [07-18 18:05:34:317 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:88 timestamp:1689674734317 [07-18 18:05:34:318 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:319 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 102, head index 88 [07-18 18:05:34:319 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:702->988) [07-18 18:05:34:319 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:702->988) [07-18 18:05:34:319 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 124 seqNo 724 ch0st0tr0 [07-18 18:05:34:319 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:351 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:32966337 ts:0 [07-18 18:05:34:351 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:32966337 [07-18 18:05:34:351 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:881741 dataSize:673 [07-18 18:05:34:351 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:89 timestamp:1689674734351 [07-18 18:05:34:351 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:32966337 ts:0 [07-18 18:05:34:351 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:32966337 [07-18 18:05:34:351 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:235465 dataSize:673 [07-18 18:05:34:351 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:89 timestamp:1689674734351 [07-18 18:05:34:355 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:34:355 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:34:384 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:32999670 ts:0 [07-18 18:05:34:384 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:32999670 [07-18 18:05:34:384 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:882414 dataSize:465 [07-18 18:05:34:384 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:90 timestamp:1689674734384 [07-18 18:05:34:384 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:32999670 ts:0 [07-18 18:05:34:385 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:32999670 [07-18 18:05:34:385 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:236138 dataSize:465 [07-18 18:05:34:385 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:90 timestamp:1689674734385 [07-18 18:05:34:418 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:33033003 ts:0 [07-18 18:05:34:418 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:33033003 [07-18 18:05:34:418 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:882879 dataSize:248 [07-18 18:05:34:418 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:91 timestamp:1689674734418 [07-18 18:05:34:418 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:33033003 ts:0 [07-18 18:05:34:418 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:33033003 [07-18 18:05:34:418 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:236603 dataSize:248 [07-18 18:05:34:418 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:91 timestamp:1689674734418 [07-18 18:05:34:430 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:430 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 124, head index 91 [07-18 18:05:34:430 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 125, seqNo 725, timestamp 1689674725459 [07-18 18:05:34:430 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:452 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:33066336 ts:0 [07-18 18:05:34:452 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:33066336 [07-18 18:05:34:452 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:883127 dataSize:217 [07-18 18:05:34:452 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:92 timestamp:1689674734452 [07-18 18:05:34:452 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:33066336 ts:0 [07-18 18:05:34:452 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:33066336 [07-18 18:05:34:452 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:236851 dataSize:217 [07-18 18:05:34:452 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:92 timestamp:1689674734452 [07-18 18:05:34:485 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:33099669 ts:0 [07-18 18:05:34:485 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:33099669 [07-18 18:05:34:485 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:883344 dataSize:280 [07-18 18:05:34:485 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:93 timestamp:1689674734485 [07-18 18:05:34:485 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:33099669 ts:0 [07-18 18:05:34:485 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:33099669 [07-18 18:05:34:485 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:237068 dataSize:280 [07-18 18:05:34:485 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:93 timestamp:1689674734485 [07-18 18:05:34:519 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:33133002 ts:0 [07-18 18:05:34:519 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:33133002 [07-18 18:05:34:519 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:883624 dataSize:12088 [07-18 18:05:34:519 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:94 timestamp:1689674734519 [07-18 18:05:34:519 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:33133002 ts:0 [07-18 18:05:34:519 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:33133002 [07-18 18:05:34:519 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:237348 dataSize:12088 [07-18 18:05:34:519 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:94 timestamp:1689674734519 [07-18 18:05:34:545 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:545 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 125, head index 94 [07-18 18:05:34:545 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 126, seqNo 726, timestamp 1689674725492 [07-18 18:05:34:545 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:553 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:33166335 ts:0 [07-18 18:05:34:553 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:33166335 [07-18 18:05:34:553 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:895712 dataSize:1051 [07-18 18:05:34:553 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:95 timestamp:1689674734553 [07-18 18:05:34:553 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:33166335 ts:0 [07-18 18:05:34:553 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:33166335 [07-18 18:05:34:553 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:249436 dataSize:1051 [07-18 18:05:34:553 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:95 timestamp:1689674734553 [07-18 18:05:34:586 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:33199668 ts:0 [07-18 18:05:34:586 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:33199668 [07-18 18:05:34:586 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:896763 dataSize:209 [07-18 18:05:34:586 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:96 timestamp:1689674734586 [07-18 18:05:34:586 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:33199668 ts:0 [07-18 18:05:34:586 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:33199668 [07-18 18:05:34:586 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:250487 dataSize:209 [07-18 18:05:34:586 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:96 timestamp:1689674734586 [07-18 18:05:34:620 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:33233001 ts:0 [07-18 18:05:34:620 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:33233001 [07-18 18:05:34:620 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:896972 dataSize:118 [07-18 18:05:34:620 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:97 timestamp:1689674734620 [07-18 18:05:34:620 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:33233001 ts:0 [07-18 18:05:34:620 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:33233001 [07-18 18:05:34:620 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:250696 dataSize:118 [07-18 18:05:34:620 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:97 timestamp:1689674734620 [07-18 18:05:34:653 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:33266334 ts:0 [07-18 18:05:34:654 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:33266334 [07-18 18:05:34:654 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:897090 dataSize:110 [07-18 18:05:34:654 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:98 timestamp:1689674734654 [07-18 18:05:34:654 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:33266334 ts:0 [07-18 18:05:34:654 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:33266334 [07-18 18:05:34:654 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:250814 dataSize:110 [07-18 18:05:34:654 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:98 timestamp:1689674734654 [07-18 18:05:34:655 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:655 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 126, head index 98 [07-18 18:05:34:655 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 127, seqNo 727, timestamp 1689674725526 [07-18 18:05:34:655 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:687 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:33299667 ts:0 [07-18 18:05:34:687 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:33299667 [07-18 18:05:34:687 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:897200 dataSize:695 [07-18 18:05:34:687 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:99 timestamp:1689674734687 [07-18 18:05:34:687 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:33299667 ts:0 [07-18 18:05:34:687 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:33299667 [07-18 18:05:34:687 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:250924 dataSize:695 [07-18 18:05:34:687 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:99 timestamp:1689674734687 [07-18 18:05:34:721 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:33333000 ts:0 [07-18 18:05:34:721 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:33333000 [07-18 18:05:34:721 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:897895 dataSize:1146 [07-18 18:05:34:721 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:100 timestamp:1689674734721 [07-18 18:05:34:721 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:33333000 ts:0 [07-18 18:05:34:721 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:33333000 [07-18 18:05:34:721 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:251619 dataSize:1146 [07-18 18:05:34:721 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:100 timestamp:1689674734721 [07-18 18:05:34:754 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:33366333 ts:0 [07-18 18:05:34:755 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:33366333 [07-18 18:05:34:755 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:899041 dataSize:276 [07-18 18:05:34:755 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:101 timestamp:1689674734755 [07-18 18:05:34:755 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:33366333 ts:0 [07-18 18:05:34:755 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:33366333 [07-18 18:05:34:755 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:252765 dataSize:276 [07-18 18:05:34:755 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:101 timestamp:1689674734755 [07-18 18:05:34:766 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:766 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 127, head index 101 [07-18 18:05:34:766 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 128, seqNo 728, timestamp 1689674725560 [07-18 18:05:34:766 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:788 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:33399666 ts:0 [07-18 18:05:34:788 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:33399666 [07-18 18:05:34:788 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:899317 dataSize:152 [07-18 18:05:34:788 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:102 timestamp:1689674734788 [07-18 18:05:34:788 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:33399666 ts:0 [07-18 18:05:34:788 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:33399666 [07-18 18:05:34:788 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:253041 dataSize:152 [07-18 18:05:34:788 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:102 timestamp:1689674734788 [07-18 18:05:34:822 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:33432999 ts:0 [07-18 18:05:34:822 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:33432999 [07-18 18:05:34:822 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:899469 dataSize:136 [07-18 18:05:34:822 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:103 timestamp:1689674734822 [07-18 18:05:34:822 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:33432999 ts:0 [07-18 18:05:34:822 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:33432999 [07-18 18:05:34:822 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:253193 dataSize:136 [07-18 18:05:34:822 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:103 timestamp:1689674734822 [07-18 18:05:34:856 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:33466332 ts:0 [07-18 18:05:34:856 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:33466332 [07-18 18:05:34:856 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:899605 dataSize:725 [07-18 18:05:34:856 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:104 timestamp:1689674734856 [07-18 18:05:34:856 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:33466332 ts:0 [07-18 18:05:34:856 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:33466332 [07-18 18:05:34:856 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:253329 dataSize:725 [07-18 18:05:34:856 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:104 timestamp:1689674734856 [07-18 18:05:34:876 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:876 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 128, head index 104 [07-18 18:05:34:876 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 129, seqNo 729, timestamp 1689674725593 [07-18 18:05:34:876 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:889 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:33499665 ts:0 [07-18 18:05:34:889 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:33499665 [07-18 18:05:34:889 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:900330 dataSize:1369 [07-18 18:05:34:889 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:105 timestamp:1689674734889 [07-18 18:05:34:889 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:33499665 ts:0 [07-18 18:05:34:889 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:33499665 [07-18 18:05:34:889 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:254054 dataSize:1369 [07-18 18:05:34:889 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:105 timestamp:1689674734889 [07-18 18:05:34:923 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:33532998 ts:0 [07-18 18:05:34:923 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:33532998 [07-18 18:05:34:923 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:901699 dataSize:367 [07-18 18:05:34:923 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:106 timestamp:1689674734923 [07-18 18:05:34:923 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:33532998 ts:0 [07-18 18:05:34:923 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:33532998 [07-18 18:05:34:923 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:255423 dataSize:367 [07-18 18:05:34:923 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:106 timestamp:1689674734923 [07-18 18:05:34:956 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:33566331 ts:0 [07-18 18:05:34:957 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:33566331 [07-18 18:05:34:957 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:902066 dataSize:141 [07-18 18:05:34:957 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:107 timestamp:1689674734957 [07-18 18:05:34:957 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:33566331 ts:0 [07-18 18:05:34:957 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:33566331 [07-18 18:05:34:957 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:255790 dataSize:141 [07-18 18:05:34:957 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:107 timestamp:1689674734957 [07-18 18:05:34:986 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:34:986 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 129, head index 107 [07-18 18:05:34:986 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 130, seqNo 730, timestamp 1689674725627 [07-18 18:05:34:986 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:34:990 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:33599664 ts:0 [07-18 18:05:34:990 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:33599664 [07-18 18:05:34:990 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:902207 dataSize:160 [07-18 18:05:34:990 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:108 timestamp:1689674734990 [07-18 18:05:34:990 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:33599664 ts:0 [07-18 18:05:34:990 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:33599664 [07-18 18:05:34:990 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:255931 dataSize:160 [07-18 18:05:34:990 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:108 timestamp:1689674734990 [07-18 18:05:35:24 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:33632997 ts:0 [07-18 18:05:35:24 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:33632997 [07-18 18:05:35:24 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:902367 dataSize:756 [07-18 18:05:35:24 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:109 timestamp:1689674735024 [07-18 18:05:35:24 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:33632997 ts:0 [07-18 18:05:35:24 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:33632997 [07-18 18:05:35:24 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:256091 dataSize:756 [07-18 18:05:35:24 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:109 timestamp:1689674735024 [07-18 18:05:35:57 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:33666330 ts:0 [07-18 18:05:35:57 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:33666330 [07-18 18:05:35:57 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:903123 dataSize:1610 [07-18 18:05:35:57 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:110 timestamp:1689674735057 [07-18 18:05:35:57 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:33666330 ts:0 [07-18 18:05:35:57 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:33666330 [07-18 18:05:35:57 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:256847 dataSize:1610 [07-18 18:05:35:58 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:110 timestamp:1689674735058 [07-18 18:05:35:91 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:33699663 ts:0 [07-18 18:05:35:91 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:33699663 [07-18 18:05:35:91 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:904733 dataSize:516 [07-18 18:05:35:91 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:111 timestamp:1689674735091 [07-18 18:05:35:91 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:33699663 ts:0 [07-18 18:05:35:91 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:33699663 [07-18 18:05:35:91 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:258457 dataSize:516 [07-18 18:05:35:91 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:111 timestamp:1689674735091 [07-18 18:05:35:96 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:96 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 130, head index 111 [07-18 18:05:35:96 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 131, seqNo 731, timestamp 1689674725661 [07-18 18:05:35:97 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:35:125 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:33732996 ts:0 [07-18 18:05:35:125 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:33732996 [07-18 18:05:35:125 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:905249 dataSize:231 [07-18 18:05:35:125 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:112 timestamp:1689674735125 [07-18 18:05:35:125 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:33732996 ts:0 [07-18 18:05:35:125 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:33732996 [07-18 18:05:35:125 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:258973 dataSize:231 [07-18 18:05:35:125 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:112 timestamp:1689674735125 [07-18 18:05:35:158 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:33766329 ts:0 [07-18 18:05:35:158 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:33766329 [07-18 18:05:35:158 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:905480 dataSize:250 [07-18 18:05:35:158 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:113 timestamp:1689674735158 [07-18 18:05:35:158 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:33766329 ts:0 [07-18 18:05:35:158 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:33766329 [07-18 18:05:35:158 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:259204 dataSize:250 [07-18 18:05:35:158 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:113 timestamp:1689674735158 [07-18 18:05:35:192 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:33799662 ts:0 [07-18 18:05:35:192 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:33799662 [07-18 18:05:35:192 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:905730 dataSize:1143 [07-18 18:05:35:192 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:114 timestamp:1689674735192 [07-18 18:05:35:192 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:33799662 ts:0 [07-18 18:05:35:192 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:33799662 [07-18 18:05:35:192 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:259454 dataSize:1143 [07-18 18:05:35:192 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:114 timestamp:1689674735192 [07-18 18:05:35:207 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:207 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 131, head index 114 [07-18 18:05:35:207 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 132, seqNo 732, timestamp 1689674725694 [07-18 18:05:35:207 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:35:226 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:33832995 ts:0 [07-18 18:05:35:226 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:33832995 [07-18 18:05:35:226 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:906873 dataSize:383 [07-18 18:05:35:226 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:115 timestamp:1689674735226 [07-18 18:05:35:226 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:33832995 ts:0 [07-18 18:05:35:226 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:33832995 [07-18 18:05:35:226 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:260597 dataSize:383 [07-18 18:05:35:226 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:115 timestamp:1689674735226 [07-18 18:05:35:259 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:33866328 ts:0 [07-18 18:05:35:259 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:33866328 [07-18 18:05:35:259 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:907256 dataSize:235 [07-18 18:05:35:259 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:116 timestamp:1689674735259 [07-18 18:05:35:259 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:33866328 ts:0 [07-18 18:05:35:259 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:33866328 [07-18 18:05:35:259 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:260980 dataSize:235 [07-18 18:05:35:259 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:116 timestamp:1689674735259 [07-18 18:05:35:293 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:33899661 ts:0 [07-18 18:05:35:293 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:33899661 [07-18 18:05:35:293 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:907491 dataSize:165 [07-18 18:05:35:293 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:117 timestamp:1689674735293 [07-18 18:05:35:293 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:33899661 ts:0 [07-18 18:05:35:293 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:33899661 [07-18 18:05:35:293 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:261215 dataSize:165 [07-18 18:05:35:293 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:117 timestamp:1689674735293 [07-18 18:05:35:317 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:317 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 132, head index 117 [07-18 18:05:35:317 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 133, seqNo 733, timestamp 1689674725728 [07-18 18:05:35:317 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:35:326 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:33932994 ts:0 [07-18 18:05:35:326 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:33932994 [07-18 18:05:35:327 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:907656 dataSize:457 [07-18 18:05:35:327 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:118 timestamp:1689674735327 [07-18 18:05:35:327 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:33932994 ts:0 [07-18 18:05:35:327 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:33932994 [07-18 18:05:35:327 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:261380 dataSize:457 [07-18 18:05:35:327 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:118 timestamp:1689674735327 [07-18 18:05:35:356 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:35:356 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:35:360 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:33966327 ts:0 [07-18 18:05:35:360 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:33966327 [07-18 18:05:35:360 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:908113 dataSize:673 [07-18 18:05:35:360 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:119 timestamp:1689674735360 [07-18 18:05:35:360 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:33966327 ts:0 [07-18 18:05:35:360 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:33966327 [07-18 18:05:35:360 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:261837 dataSize:673 [07-18 18:05:35:360 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:119 timestamp:1689674735360 [07-18 18:05:35:394 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:33999660 ts:0 [07-18 18:05:35:394 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:33999660 [07-18 18:05:35:394 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:908786 dataSize:465 [07-18 18:05:35:394 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:120 timestamp:1689674735394 [07-18 18:05:35:394 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:33999660 ts:0 [07-18 18:05:35:394 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:33999660 [07-18 18:05:35:394 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:262510 dataSize:465 [07-18 18:05:35:394 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:120 timestamp:1689674735394 [07-18 18:05:35:427 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:427 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 133, head index 120 [07-18 18:05:35:427 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:733->1020) [07-18 18:05:35:427 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:733->1020) [07-18 18:05:35:427 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:734->1020) [07-18 18:05:35:427 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 154 seqNo 754 ch0st0tr0 [07-18 18:05:35:427 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:34032993 ts:0 [07-18 18:05:35:427 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:34032993 [07-18 18:05:35:428 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:909251 dataSize:248 [07-18 18:05:35:428 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:121 timestamp:1689674735428 [07-18 18:05:35:428 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:34032993 ts:0 [07-18 18:05:35:428 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:34032993 [07-18 18:05:35:428 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:262975 dataSize:248 [07-18 18:05:35:428 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:121 timestamp:1689674735428 [07-18 18:05:35:428 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:35:461 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:34066326 ts:0 [07-18 18:05:35:461 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:34066326 [07-18 18:05:35:461 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:909499 dataSize:217 [07-18 18:05:35:461 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:122 timestamp:1689674735461 [07-18 18:05:35:461 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:34066326 ts:0 [07-18 18:05:35:461 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:34066326 [07-18 18:05:35:461 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:263223 dataSize:217 [07-18 18:05:35:461 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:122 timestamp:1689674735461 [07-18 18:05:35:495 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:34099659 ts:0 [07-18 18:05:35:495 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:34099659 [07-18 18:05:35:495 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:909716 dataSize:280 [07-18 18:05:35:495 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:123 timestamp:1689674735495 [07-18 18:05:35:495 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:34099659 ts:0 [07-18 18:05:35:495 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:34099659 [07-18 18:05:35:495 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:263440 dataSize:280 [07-18 18:05:35:495 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:123 timestamp:1689674735495 [07-18 18:05:35:528 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:34132992 ts:0 [07-18 18:05:35:528 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:34132992 [07-18 18:05:35:528 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:909996 dataSize:12088 [07-18 18:05:35:528 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:124 timestamp:1689674735528 [07-18 18:05:35:528 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:34132992 ts:0 [07-18 18:05:35:529 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:34132992 [07-18 18:05:35:529 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:263720 dataSize:12088 [07-18 18:05:35:529 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:124 timestamp:1689674735529 [07-18 18:05:35:538 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:538 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 154, head index 124 [07-18 18:05:35:538 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 155, seqNo 755, timestamp 1689674726468 [07-18 18:05:35:538 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:35:562 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:34166325 ts:0 [07-18 18:05:35:562 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:34166325 [07-18 18:05:35:562 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:922084 dataSize:1051 [07-18 18:05:35:562 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:125 timestamp:1689674735562 [07-18 18:05:35:562 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:34166325 ts:0 [07-18 18:05:35:562 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:34166325 [07-18 18:05:35:562 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:275808 dataSize:1051 [07-18 18:05:35:562 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:125 timestamp:1689674735562 [07-18 18:05:35:596 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:34199658 ts:0 [07-18 18:05:35:596 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:34199658 [07-18 18:05:35:596 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:923135 dataSize:209 [07-18 18:05:35:596 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:126 timestamp:1689674735596 [07-18 18:05:35:596 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:34199658 ts:0 [07-18 18:05:35:596 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:34199658 [07-18 18:05:35:596 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:276859 dataSize:209 [07-18 18:05:35:596 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:126 timestamp:1689674735596 [07-18 18:05:35:629 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:34232991 ts:0 [07-18 18:05:35:629 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:34232991 [07-18 18:05:35:630 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:923344 dataSize:118 [07-18 18:05:35:630 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:127 timestamp:1689674735630 [07-18 18:05:35:630 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:34232991 ts:0 [07-18 18:05:35:630 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:34232991 [07-18 18:05:35:630 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:277068 dataSize:118 [07-18 18:05:35:630 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:127 timestamp:1689674735630 [07-18 18:05:35:648 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:648 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 155, head index 127 [07-18 18:05:35:648 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 156, seqNo 756, timestamp 1689674726501 [07-18 18:05:35:648 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:35:663 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:34266324 ts:0 [07-18 18:05:35:663 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:34266324 [07-18 18:05:35:663 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:923462 dataSize:110 [07-18 18:05:35:663 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:128 timestamp:1689674735663 [07-18 18:05:35:663 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:34266324 ts:0 [07-18 18:05:35:663 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:34266324 [07-18 18:05:35:663 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:277186 dataSize:110 [07-18 18:05:35:663 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:128 timestamp:1689674735663 [07-18 18:05:35:697 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:34299657 ts:0 [07-18 18:05:35:697 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:34299657 [07-18 18:05:35:697 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:923572 dataSize:695 [07-18 18:05:35:697 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:129 timestamp:1689674735697 [07-18 18:05:35:697 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:34299657 ts:0 [07-18 18:05:35:697 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:34299657 [07-18 18:05:35:697 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:277296 dataSize:695 [07-18 18:05:35:697 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:129 timestamp:1689674735697 [07-18 18:05:35:730 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:34332990 ts:0 [07-18 18:05:35:730 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:34332990 [07-18 18:05:35:730 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:924267 dataSize:1146 [07-18 18:05:35:730 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:130 timestamp:1689674735730 [07-18 18:05:35:731 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:34332990 ts:0 [07-18 18:05:35:731 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:34332990 [07-18 18:05:35:731 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:277991 dataSize:1146 [07-18 18:05:35:731 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:130 timestamp:1689674735731 [07-18 18:05:35:758 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:759 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 156, head index 130 [07-18 18:05:35:759 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 157, seqNo 757, timestamp 1689674726535 [07-18 18:05:35:759 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:35:764 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:34366323 ts:0 [07-18 18:05:35:764 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:34366323 [07-18 18:05:35:764 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:925413 dataSize:276 [07-18 18:05:35:764 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:131 timestamp:1689674735764 [07-18 18:05:35:764 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:34366323 ts:0 [07-18 18:05:35:764 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:34366323 [07-18 18:05:35:764 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:279137 dataSize:276 [07-18 18:05:35:764 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:131 timestamp:1689674735764 [07-18 18:05:35:798 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:34399656 ts:0 [07-18 18:05:35:798 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:34399656 [07-18 18:05:35:798 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:925689 dataSize:152 [07-18 18:05:35:798 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:132 timestamp:1689674735798 [07-18 18:05:35:798 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:34399656 ts:0 [07-18 18:05:35:798 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:34399656 [07-18 18:05:35:798 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:279413 dataSize:152 [07-18 18:05:35:798 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:132 timestamp:1689674735798 [07-18 18:05:35:831 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:34432989 ts:0 [07-18 18:05:35:831 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:34432989 [07-18 18:05:35:831 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:925841 dataSize:136 [07-18 18:05:35:831 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:133 timestamp:1689674735831 [07-18 18:05:35:832 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:34432989 ts:0 [07-18 18:05:35:832 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:34432989 [07-18 18:05:35:832 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:279565 dataSize:136 [07-18 18:05:35:832 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:133 timestamp:1689674735832 [07-18 18:05:35:865 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:34466322 ts:0 [07-18 18:05:35:865 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:34466322 [07-18 18:05:35:865 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:925977 dataSize:725 [07-18 18:05:35:865 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:134 timestamp:1689674735865 [07-18 18:05:35:865 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:34466322 ts:0 [07-18 18:05:35:865 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:34466322 [07-18 18:05:35:865 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:279701 dataSize:725 [07-18 18:05:35:865 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:134 timestamp:1689674735865 [07-18 18:05:35:869 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:869 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 157, head index 134 [07-18 18:05:35:869 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 158, seqNo 758, timestamp 1689674726569 [07-18 18:05:35:869 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:35:899 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:34499655 ts:0 [07-18 18:05:35:899 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:34499655 [07-18 18:05:35:899 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:926702 dataSize:1369 [07-18 18:05:35:899 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:135 timestamp:1689674735899 [07-18 18:05:35:899 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:34499655 ts:0 [07-18 18:05:35:899 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:34499655 [07-18 18:05:35:899 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:280426 dataSize:1369 [07-18 18:05:35:899 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:135 timestamp:1689674735899 [07-18 18:05:35:932 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:34532988 ts:0 [07-18 18:05:35:933 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:34532988 [07-18 18:05:35:933 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:928071 dataSize:367 [07-18 18:05:35:933 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:136 timestamp:1689674735933 [07-18 18:05:35:933 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:34532988 ts:0 [07-18 18:05:35:933 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:34532988 [07-18 18:05:35:933 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:281795 dataSize:367 [07-18 18:05:35:933 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:136 timestamp:1689674735933 [07-18 18:05:35:966 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:34566321 ts:0 [07-18 18:05:35:966 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:34566321 [07-18 18:05:35:966 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:928438 dataSize:141 [07-18 18:05:35:966 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:137 timestamp:1689674735966 [07-18 18:05:35:966 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:34566321 ts:0 [07-18 18:05:35:966 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:34566321 [07-18 18:05:35:966 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:282162 dataSize:141 [07-18 18:05:35:966 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:137 timestamp:1689674735966 [07-18 18:05:35:979 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:35:979 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 158, head index 137 [07-18 18:05:35:979 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 159, seqNo 759, timestamp 1689674726602 [07-18 18:05:35:979 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:0 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:34599654 ts:0 [07-18 18:05:36:0 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:34599654 [07-18 18:05:36:0 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:928579 dataSize:160 [07-18 18:05:36:0 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:138 timestamp:1689674736000 [07-18 18:05:36:0 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:34599654 ts:0 [07-18 18:05:36:0 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:34599654 [07-18 18:05:36:0 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:282303 dataSize:160 [07-18 18:05:36:0 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:138 timestamp:1689674736000 [07-18 18:05:36:33 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:34632987 ts:0 [07-18 18:05:36:33 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:34632987 [07-18 18:05:36:34 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:928739 dataSize:756 [07-18 18:05:36:34 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:139 timestamp:1689674736034 [07-18 18:05:36:34 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:34632987 ts:0 [07-18 18:05:36:34 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:34632987 [07-18 18:05:36:34 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:282463 dataSize:756 [07-18 18:05:36:34 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:139 timestamp:1689674736034 [07-18 18:05:36:67 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:34666320 ts:0 [07-18 18:05:36:67 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:34666320 [07-18 18:05:36:67 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:929495 dataSize:1610 [07-18 18:05:36:67 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:140 timestamp:1689674736067 [07-18 18:05:36:67 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:34666320 ts:0 [07-18 18:05:36:67 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:34666320 [07-18 18:05:36:67 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:283219 dataSize:1610 [07-18 18:05:36:67 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:140 timestamp:1689674736067 [07-18 18:05:36:89 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:89 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 159, head index 140 [07-18 18:05:36:89 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 160, seqNo 760, timestamp 1689674726636 [07-18 18:05:36:90 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:101 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:34699653 ts:0 [07-18 18:05:36:101 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:34699653 [07-18 18:05:36:101 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:931105 dataSize:516 [07-18 18:05:36:101 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:141 timestamp:1689674736101 [07-18 18:05:36:101 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:34699653 ts:0 [07-18 18:05:36:101 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:34699653 [07-18 18:05:36:101 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:284829 dataSize:516 [07-18 18:05:36:101 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:141 timestamp:1689674736101 [07-18 18:05:36:134 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:34732986 ts:0 [07-18 18:05:36:134 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:34732986 [07-18 18:05:36:134 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:931621 dataSize:231 [07-18 18:05:36:134 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:142 timestamp:1689674736134 [07-18 18:05:36:135 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:34732986 ts:0 [07-18 18:05:36:135 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:34732986 [07-18 18:05:36:135 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:285345 dataSize:231 [07-18 18:05:36:135 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:142 timestamp:1689674736135 [07-18 18:05:36:168 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:34766319 ts:0 [07-18 18:05:36:168 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:34766319 [07-18 18:05:36:168 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:931852 dataSize:250 [07-18 18:05:36:168 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:143 timestamp:1689674736168 [07-18 18:05:36:168 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:34766319 ts:0 [07-18 18:05:36:168 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:34766319 [07-18 18:05:36:168 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:285576 dataSize:250 [07-18 18:05:36:168 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:143 timestamp:1689674736168 [07-18 18:05:36:200 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:200 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 160, head index 143 [07-18 18:05:36:200 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 161, seqNo 761, timestamp 1689674726670 [07-18 18:05:36:200 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:202 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:34799652 ts:0 [07-18 18:05:36:202 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:34799652 [07-18 18:05:36:202 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:932102 dataSize:1143 [07-18 18:05:36:202 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:144 timestamp:1689674736202 [07-18 18:05:36:202 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:34799652 ts:0 [07-18 18:05:36:202 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:34799652 [07-18 18:05:36:202 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:285826 dataSize:1143 [07-18 18:05:36:202 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:144 timestamp:1689674736202 [07-18 18:05:36:235 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:34832985 ts:0 [07-18 18:05:36:235 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:34832985 [07-18 18:05:36:235 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:933245 dataSize:383 [07-18 18:05:36:235 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:145 timestamp:1689674736235 [07-18 18:05:36:236 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:34832985 ts:0 [07-18 18:05:36:236 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:34832985 [07-18 18:05:36:236 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:286969 dataSize:383 [07-18 18:05:36:236 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:145 timestamp:1689674736236 [07-18 18:05:36:269 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:34866318 ts:0 [07-18 18:05:36:269 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:34866318 [07-18 18:05:36:269 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:933628 dataSize:235 [07-18 18:05:36:269 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:146 timestamp:1689674736269 [07-18 18:05:36:269 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:34866318 ts:0 [07-18 18:05:36:269 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:34866318 [07-18 18:05:36:269 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:287352 dataSize:235 [07-18 18:05:36:269 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:146 timestamp:1689674736269 [07-18 18:05:36:303 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:34899651 ts:0 [07-18 18:05:36:303 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:34899651 [07-18 18:05:36:303 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:933863 dataSize:165 [07-18 18:05:36:303 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:147 timestamp:1689674736303 [07-18 18:05:36:303 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:34899651 ts:0 [07-18 18:05:36:303 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:34899651 [07-18 18:05:36:303 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:287587 dataSize:165 [07-18 18:05:36:303 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:147 timestamp:1689674736303 [07-18 18:05:36:310 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:310 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 161, head index 147 [07-18 18:05:36:310 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:761->1047) [07-18 18:05:36:310 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:761->1047) [07-18 18:05:36:310 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 184 seqNo 784 ch0st0tr0 [07-18 18:05:36:311 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:336 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:34932984 ts:0 [07-18 18:05:36:336 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:34932984 [07-18 18:05:36:336 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:934028 dataSize:457 [07-18 18:05:36:336 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:148 timestamp:1689674736336 [07-18 18:05:36:336 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:34932984 ts:0 [07-18 18:05:36:336 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:34932984 [07-18 18:05:36:336 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:287752 dataSize:457 [07-18 18:05:36:336 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:148 timestamp:1689674736336 [07-18 18:05:36:357 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:36:357 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:36:370 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:34966317 ts:0 [07-18 18:05:36:370 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:34966317 [07-18 18:05:36:370 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:934485 dataSize:673 [07-18 18:05:36:370 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:149 timestamp:1689674736370 [07-18 18:05:36:370 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:34966317 ts:0 [07-18 18:05:36:370 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:34966317 [07-18 18:05:36:370 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:288209 dataSize:673 [07-18 18:05:36:370 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:149 timestamp:1689674736370 [07-18 18:05:36:404 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:34999650 ts:0 [07-18 18:05:36:404 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:34999650 [07-18 18:05:36:404 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:935158 dataSize:465 [07-18 18:05:36:404 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:150 timestamp:1689674736404 [07-18 18:05:36:404 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:34999650 ts:0 [07-18 18:05:36:404 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:34999650 [07-18 18:05:36:404 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:288882 dataSize:465 [07-18 18:05:36:404 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:150 timestamp:1689674736404 [07-18 18:05:36:421 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:421 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 184, head index 150 [07-18 18:05:36:421 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 185, seqNo 785, timestamp 1689674727476 [07-18 18:05:36:421 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:437 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:35032983 ts:0 [07-18 18:05:36:437 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:35032983 [07-18 18:05:36:437 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:935623 dataSize:248 [07-18 18:05:36:437 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:151 timestamp:1689674736437 [07-18 18:05:36:437 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:35032983 ts:0 [07-18 18:05:36:437 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:35032983 [07-18 18:05:36:437 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:289347 dataSize:248 [07-18 18:05:36:437 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:151 timestamp:1689674736437 [07-18 18:05:36:471 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:35066316 ts:0 [07-18 18:05:36:471 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:35066316 [07-18 18:05:36:471 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:935871 dataSize:217 [07-18 18:05:36:471 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:152 timestamp:1689674736471 [07-18 18:05:36:471 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:35066316 ts:0 [07-18 18:05:36:471 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:35066316 [07-18 18:05:36:471 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:289595 dataSize:217 [07-18 18:05:36:471 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:152 timestamp:1689674736471 [07-18 18:05:36:504 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:35099649 ts:0 [07-18 18:05:36:504 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:35099649 [07-18 18:05:36:504 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:936088 dataSize:280 [07-18 18:05:36:505 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:153 timestamp:1689674736505 [07-18 18:05:36:505 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:35099649 ts:0 [07-18 18:05:36:505 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:35099649 [07-18 18:05:36:505 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:289812 dataSize:280 [07-18 18:05:36:505 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:153 timestamp:1689674736505 [07-18 18:05:36:532 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:532 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 185, head index 153 [07-18 18:05:36:532 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 186, seqNo 786, timestamp 1689674727510 [07-18 18:05:36:532 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:538 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:35132982 ts:0 [07-18 18:05:36:538 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:35132982 [07-18 18:05:36:538 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:936368 dataSize:12088 [07-18 18:05:36:538 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:154 timestamp:1689674736538 [07-18 18:05:36:538 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:35132982 ts:0 [07-18 18:05:36:538 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:35132982 [07-18 18:05:36:538 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:290092 dataSize:12088 [07-18 18:05:36:538 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:154 timestamp:1689674736538 [07-18 18:05:36:572 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:35166315 ts:0 [07-18 18:05:36:572 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:35166315 [07-18 18:05:36:572 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:948456 dataSize:1051 [07-18 18:05:36:572 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:155 timestamp:1689674736572 [07-18 18:05:36:572 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:35166315 ts:0 [07-18 18:05:36:572 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:35166315 [07-18 18:05:36:572 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:302180 dataSize:1051 [07-18 18:05:36:572 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:155 timestamp:1689674736572 [07-18 18:05:36:605 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:35199648 ts:0 [07-18 18:05:36:605 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:35199648 [07-18 18:05:36:605 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:949507 dataSize:209 [07-18 18:05:36:605 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:156 timestamp:1689674736605 [07-18 18:05:36:605 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:35199648 ts:0 [07-18 18:05:36:605 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:35199648 [07-18 18:05:36:605 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:303231 dataSize:209 [07-18 18:05:36:606 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:156 timestamp:1689674736606 [07-18 18:05:36:639 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:35232981 ts:0 [07-18 18:05:36:639 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:35232981 [07-18 18:05:36:639 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:949716 dataSize:118 [07-18 18:05:36:639 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:157 timestamp:1689674736639 [07-18 18:05:36:639 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:35232981 ts:0 [07-18 18:05:36:639 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:35232981 [07-18 18:05:36:639 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:303440 dataSize:118 [07-18 18:05:36:639 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:157 timestamp:1689674736639 [07-18 18:05:36:642 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:642 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 186, head index 157 [07-18 18:05:36:642 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 187, seqNo 787, timestamp 1689674727544 [07-18 18:05:36:642 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:673 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:35266314 ts:0 [07-18 18:05:36:673 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:35266314 [07-18 18:05:36:673 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:949834 dataSize:110 [07-18 18:05:36:673 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:158 timestamp:1689674736673 [07-18 18:05:36:673 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:35266314 ts:0 [07-18 18:05:36:673 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:35266314 [07-18 18:05:36:673 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:303558 dataSize:110 [07-18 18:05:36:673 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:158 timestamp:1689674736673 [07-18 18:05:36:706 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:35299647 ts:0 [07-18 18:05:36:706 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:35299647 [07-18 18:05:36:706 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:949944 dataSize:695 [07-18 18:05:36:706 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:159 timestamp:1689674736706 [07-18 18:05:36:706 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:35299647 ts:0 [07-18 18:05:36:706 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:35299647 [07-18 18:05:36:706 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:303668 dataSize:695 [07-18 18:05:36:706 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:159 timestamp:1689674736706 [07-18 18:05:36:740 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:35332980 ts:0 [07-18 18:05:36:740 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:35332980 [07-18 18:05:36:740 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:950639 dataSize:1146 [07-18 18:05:36:740 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:160 timestamp:1689674736740 [07-18 18:05:36:740 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:35332980 ts:0 [07-18 18:05:36:740 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:35332980 [07-18 18:05:36:740 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:304363 dataSize:1146 [07-18 18:05:36:740 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:160 timestamp:1689674736740 [07-18 18:05:36:753 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:753 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 187, head index 160 [07-18 18:05:36:753 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 188, seqNo 788, timestamp 1689674727577 [07-18 18:05:36:753 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:774 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:35366313 ts:0 [07-18 18:05:36:774 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:35366313 [07-18 18:05:36:774 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:951785 dataSize:276 [07-18 18:05:36:774 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:161 timestamp:1689674736774 [07-18 18:05:36:774 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:35366313 ts:0 [07-18 18:05:36:774 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:35366313 [07-18 18:05:36:774 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:305509 dataSize:276 [07-18 18:05:36:774 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:161 timestamp:1689674736774 [07-18 18:05:36:807 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:35399646 ts:0 [07-18 18:05:36:807 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:35399646 [07-18 18:05:36:807 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:952061 dataSize:152 [07-18 18:05:36:807 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:162 timestamp:1689674736807 [07-18 18:05:36:807 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:35399646 ts:0 [07-18 18:05:36:807 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:35399646 [07-18 18:05:36:807 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:305785 dataSize:152 [07-18 18:05:36:807 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:162 timestamp:1689674736807 [07-18 18:05:36:841 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:35432979 ts:0 [07-18 18:05:36:841 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:35432979 [07-18 18:05:36:841 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:952213 dataSize:136 [07-18 18:05:36:841 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:163 timestamp:1689674736841 [07-18 18:05:36:841 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:35432979 ts:0 [07-18 18:05:36:841 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:35432979 [07-18 18:05:36:841 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:305937 dataSize:136 [07-18 18:05:36:841 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:163 timestamp:1689674736841 [07-18 18:05:36:863 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:863 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 188, head index 163 [07-18 18:05:36:863 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 189, seqNo 789, timestamp 1689674727611 [07-18 18:05:36:863 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:874 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:35466312 ts:0 [07-18 18:05:36:875 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:35466312 [07-18 18:05:36:875 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:952349 dataSize:725 [07-18 18:05:36:875 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:164 timestamp:1689674736875 [07-18 18:05:36:875 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:35466312 ts:0 [07-18 18:05:36:875 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:35466312 [07-18 18:05:36:875 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:306073 dataSize:725 [07-18 18:05:36:875 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:164 timestamp:1689674736875 [07-18 18:05:36:908 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:35499645 ts:0 [07-18 18:05:36:908 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:35499645 [07-18 18:05:36:908 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:953074 dataSize:1369 [07-18 18:05:36:908 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:165 timestamp:1689674736908 [07-18 18:05:36:908 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:35499645 ts:0 [07-18 18:05:36:908 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:35499645 [07-18 18:05:36:908 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:306798 dataSize:1369 [07-18 18:05:36:908 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:165 timestamp:1689674736908 [07-18 18:05:36:942 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:35532978 ts:0 [07-18 18:05:36:942 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:35532978 [07-18 18:05:36:942 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:954443 dataSize:367 [07-18 18:05:36:942 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:166 timestamp:1689674736942 [07-18 18:05:36:942 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:35532978 ts:0 [07-18 18:05:36:942 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:35532978 [07-18 18:05:36:942 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:308167 dataSize:367 [07-18 18:05:36:942 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:166 timestamp:1689674736942 [07-18 18:05:36:973 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:36:973 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 189, head index 166 [07-18 18:05:36:973 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 190, seqNo 790, timestamp 1689674727645 [07-18 18:05:36:973 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:36:975 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:35566311 ts:0 [07-18 18:05:36:976 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:35566311 [07-18 18:05:36:976 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:954810 dataSize:141 [07-18 18:05:36:976 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:167 timestamp:1689674736976 [07-18 18:05:36:976 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:35566311 ts:0 [07-18 18:05:36:976 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:35566311 [07-18 18:05:36:976 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:308534 dataSize:141 [07-18 18:05:36:976 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:167 timestamp:1689674736976 [07-18 18:05:37:9 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:35599644 ts:0 [07-18 18:05:37:9 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:35599644 [07-18 18:05:37:9 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:954951 dataSize:160 [07-18 18:05:37:9 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:168 timestamp:1689674737009 [07-18 18:05:37:9 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:35599644 ts:0 [07-18 18:05:37:9 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:35599644 [07-18 18:05:37:9 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:308675 dataSize:160 [07-18 18:05:37:9 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:168 timestamp:1689674737009 [07-18 18:05:37:43 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:35632977 ts:0 [07-18 18:05:37:43 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:35632977 [07-18 18:05:37:43 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:955111 dataSize:756 [07-18 18:05:37:43 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:169 timestamp:1689674737043 [07-18 18:05:37:43 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:35632977 ts:0 [07-18 18:05:37:43 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:35632977 [07-18 18:05:37:43 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:308835 dataSize:756 [07-18 18:05:37:43 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:169 timestamp:1689674737043 [07-18 18:05:37:76 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:35666310 ts:0 [07-18 18:05:37:76 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:35666310 [07-18 18:05:37:76 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:955867 dataSize:1610 [07-18 18:05:37:76 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:170 timestamp:1689674737076 [07-18 18:05:37:76 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:35666310 ts:0 [07-18 18:05:37:77 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:35666310 [07-18 18:05:37:77 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:309591 dataSize:1610 [07-18 18:05:37:77 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:170 timestamp:1689674737077 [07-18 18:05:37:84 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:84 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 190, head index 170 [07-18 18:05:37:84 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 191, seqNo 791, timestamp 1689674727678 [07-18 18:05:37:84 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:110 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:35699643 ts:0 [07-18 18:05:37:110 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:35699643 [07-18 18:05:37:110 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:957477 dataSize:516 [07-18 18:05:37:110 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:171 timestamp:1689674737110 [07-18 18:05:37:110 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:35699643 ts:0 [07-18 18:05:37:110 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:35699643 [07-18 18:05:37:110 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:311201 dataSize:516 [07-18 18:05:37:110 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:171 timestamp:1689674737110 [07-18 18:05:37:144 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:35732976 ts:0 [07-18 18:05:37:144 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:35732976 [07-18 18:05:37:144 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:957993 dataSize:231 [07-18 18:05:37:144 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:172 timestamp:1689674737144 [07-18 18:05:37:144 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:35732976 ts:0 [07-18 18:05:37:144 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:35732976 [07-18 18:05:37:144 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:311717 dataSize:231 [07-18 18:05:37:144 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:172 timestamp:1689674737144 [07-18 18:05:37:177 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:35766309 ts:0 [07-18 18:05:37:177 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:35766309 [07-18 18:05:37:177 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:958224 dataSize:250 [07-18 18:05:37:177 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:173 timestamp:1689674737177 [07-18 18:05:37:177 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:35766309 ts:0 [07-18 18:05:37:177 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:35766309 [07-18 18:05:37:177 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:311948 dataSize:250 [07-18 18:05:37:177 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:173 timestamp:1689674737177 [07-18 18:05:37:194 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:194 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 191, head index 173 [07-18 18:05:37:194 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 192, seqNo 792, timestamp 1689674727712 [07-18 18:05:37:194 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:211 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:35799642 ts:0 [07-18 18:05:37:211 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:35799642 [07-18 18:05:37:211 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:958474 dataSize:1143 [07-18 18:05:37:211 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:174 timestamp:1689674737211 [07-18 18:05:37:211 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:35799642 ts:0 [07-18 18:05:37:211 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:35799642 [07-18 18:05:37:211 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:312198 dataSize:1143 [07-18 18:05:37:211 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:174 timestamp:1689674737211 [07-18 18:05:37:245 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:35832975 ts:0 [07-18 18:05:37:245 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:35832975 [07-18 18:05:37:245 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:959617 dataSize:383 [07-18 18:05:37:245 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:175 timestamp:1689674737245 [07-18 18:05:37:245 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:35832975 ts:0 [07-18 18:05:37:245 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:35832975 [07-18 18:05:37:245 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:313341 dataSize:383 [07-18 18:05:37:245 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:175 timestamp:1689674737245 [07-18 18:05:37:278 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:35866308 ts:0 [07-18 18:05:37:278 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:35866308 [07-18 18:05:37:278 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:960000 dataSize:235 [07-18 18:05:37:278 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:176 timestamp:1689674737278 [07-18 18:05:37:278 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:35866308 ts:0 [07-18 18:05:37:278 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:35866308 [07-18 18:05:37:278 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:313724 dataSize:235 [07-18 18:05:37:278 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:176 timestamp:1689674737278 [07-18 18:05:37:304 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:304 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 192, head index 176 [07-18 18:05:37:304 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 193, seqNo 793, timestamp 1689674727746 [07-18 18:05:37:304 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:312 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:35899641 ts:0 [07-18 18:05:37:312 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:35899641 [07-18 18:05:37:312 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:960235 dataSize:165 [07-18 18:05:37:312 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:177 timestamp:1689674737312 [07-18 18:05:37:312 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:35899641 ts:0 [07-18 18:05:37:312 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:35899641 [07-18 18:05:37:312 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:313959 dataSize:165 [07-18 18:05:37:312 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:177 timestamp:1689674737312 [07-18 18:05:37:346 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:35932974 ts:0 [07-18 18:05:37:346 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:35932974 [07-18 18:05:37:346 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:960400 dataSize:457 [07-18 18:05:37:346 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:178 timestamp:1689674737346 [07-18 18:05:37:346 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:35932974 ts:0 [07-18 18:05:37:346 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:35932974 [07-18 18:05:37:346 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:314124 dataSize:457 [07-18 18:05:37:346 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:178 timestamp:1689674737346 [07-18 18:05:37:358 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:37:358 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:37:379 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:35966307 ts:0 [07-18 18:05:37:379 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:35966307 [07-18 18:05:37:379 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:960857 dataSize:673 [07-18 18:05:37:379 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:179 timestamp:1689674737379 [07-18 18:05:37:379 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:35966307 ts:0 [07-18 18:05:37:379 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:35966307 [07-18 18:05:37:379 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:314581 dataSize:673 [07-18 18:05:37:379 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:179 timestamp:1689674737379 [07-18 18:05:37:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:35999640 ts:0 [07-18 18:05:37:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:35999640 [07-18 18:05:37:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:961530 dataSize:465 [07-18 18:05:37:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:180 timestamp:1689674737413 [07-18 18:05:37:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:35999640 ts:0 [07-18 18:05:37:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:35999640 [07-18 18:05:37:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:315254 dataSize:465 [07-18 18:05:37:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:180 timestamp:1689674737413 [07-18 18:05:37:414 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:414 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 193, head index 180 [07-18 18:05:37:414 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:793->1080) [07-18 18:05:37:414 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:793->1080) [07-18 18:05:37:414 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:794->1080) [07-18 18:05:37:414 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 214 seqNo 814 ch0st0tr0 [07-18 18:05:37:415 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:447 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:36032973 ts:0 [07-18 18:05:37:447 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:36032973 [07-18 18:05:37:447 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:961995 dataSize:248 [07-18 18:05:37:447 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:181 timestamp:1689674737447 [07-18 18:05:37:447 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:36032973 ts:0 [07-18 18:05:37:447 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:36032973 [07-18 18:05:37:447 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:315719 dataSize:248 [07-18 18:05:37:447 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:181 timestamp:1689674737447 [07-18 18:05:37:480 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:36066306 ts:0 [07-18 18:05:37:480 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:36066306 [07-18 18:05:37:480 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:962243 dataSize:217 [07-18 18:05:37:480 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:182 timestamp:1689674737480 [07-18 18:05:37:480 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:36066306 ts:0 [07-18 18:05:37:480 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:36066306 [07-18 18:05:37:480 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:315967 dataSize:217 [07-18 18:05:37:480 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:182 timestamp:1689674737480 [07-18 18:05:37:514 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:36099639 ts:0 [07-18 18:05:37:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:36099639 [07-18 18:05:37:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:962460 dataSize:280 [07-18 18:05:37:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:183 timestamp:1689674737514 [07-18 18:05:37:514 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:36099639 ts:0 [07-18 18:05:37:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:36099639 [07-18 18:05:37:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:316184 dataSize:280 [07-18 18:05:37:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:183 timestamp:1689674737514 [07-18 18:05:37:525 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:525 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 214, head index 183 [07-18 18:05:37:525 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 215, seqNo 815, timestamp 1689674728493 [07-18 18:05:37:525 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:547 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:36132972 ts:0 [07-18 18:05:37:547 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:36132972 [07-18 18:05:37:547 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:962740 dataSize:12088 [07-18 18:05:37:547 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:184 timestamp:1689674737547 [07-18 18:05:37:548 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:36132972 ts:0 [07-18 18:05:37:548 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:36132972 [07-18 18:05:37:548 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:316464 dataSize:12088 [07-18 18:05:37:548 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:184 timestamp:1689674737548 [07-18 18:05:37:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:36166305 ts:0 [07-18 18:05:37:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:36166305 [07-18 18:05:37:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:974828 dataSize:1051 [07-18 18:05:37:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:185 timestamp:1689674737581 [07-18 18:05:37:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:36166305 ts:0 [07-18 18:05:37:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:36166305 [07-18 18:05:37:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:328552 dataSize:1051 [07-18 18:05:37:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:185 timestamp:1689674737581 [07-18 18:05:37:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:36199638 ts:0 [07-18 18:05:37:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:36199638 [07-18 18:05:37:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:975879 dataSize:209 [07-18 18:05:37:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:186 timestamp:1689674737615 [07-18 18:05:37:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:36199638 ts:0 [07-18 18:05:37:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:36199638 [07-18 18:05:37:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:329603 dataSize:209 [07-18 18:05:37:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:186 timestamp:1689674737615 [07-18 18:05:37:635 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:636 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 215, head index 186 [07-18 18:05:37:636 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 216, seqNo 816, timestamp 1689674728526 [07-18 18:05:37:636 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:649 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:36232971 ts:0 [07-18 18:05:37:649 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:36232971 [07-18 18:05:37:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:976088 dataSize:118 [07-18 18:05:37:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:187 timestamp:1689674737649 [07-18 18:05:37:649 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:36232971 ts:0 [07-18 18:05:37:649 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:36232971 [07-18 18:05:37:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:329812 dataSize:118 [07-18 18:05:37:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:187 timestamp:1689674737649 [07-18 18:05:37:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:36266304 ts:0 [07-18 18:05:37:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:36266304 [07-18 18:05:37:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:976206 dataSize:110 [07-18 18:05:37:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:188 timestamp:1689674737682 [07-18 18:05:37:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:36266304 ts:0 [07-18 18:05:37:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:36266304 [07-18 18:05:37:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:329930 dataSize:110 [07-18 18:05:37:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:188 timestamp:1689674737682 [07-18 18:05:37:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:36299637 ts:0 [07-18 18:05:37:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:36299637 [07-18 18:05:37:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:976316 dataSize:695 [07-18 18:05:37:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:189 timestamp:1689674737716 [07-18 18:05:37:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:36299637 ts:0 [07-18 18:05:37:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:36299637 [07-18 18:05:37:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:330040 dataSize:695 [07-18 18:05:37:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:189 timestamp:1689674737716 [07-18 18:05:37:746 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:746 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 216, head index 189 [07-18 18:05:37:746 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 217, seqNo 817, timestamp 1689674728560 [07-18 18:05:37:746 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:36332970 ts:0 [07-18 18:05:37:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:36332970 [07-18 18:05:37:749 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:977011 dataSize:1146 [07-18 18:05:37:749 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:190 timestamp:1689674737749 [07-18 18:05:37:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:36332970 ts:0 [07-18 18:05:37:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:36332970 [07-18 18:05:37:749 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:330735 dataSize:1146 [07-18 18:05:37:749 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:190 timestamp:1689674737749 [07-18 18:05:37:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:36366303 ts:0 [07-18 18:05:37:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:36366303 [07-18 18:05:37:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:978157 dataSize:276 [07-18 18:05:37:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:191 timestamp:1689674737783 [07-18 18:05:37:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:36366303 ts:0 [07-18 18:05:37:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:36366303 [07-18 18:05:37:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:331881 dataSize:276 [07-18 18:05:37:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:191 timestamp:1689674737783 [07-18 18:05:37:816 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:36399636 ts:0 [07-18 18:05:37:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:36399636 [07-18 18:05:37:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:978433 dataSize:152 [07-18 18:05:37:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:192 timestamp:1689674737817 [07-18 18:05:37:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:36399636 ts:0 [07-18 18:05:37:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:36399636 [07-18 18:05:37:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:332157 dataSize:152 [07-18 18:05:37:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:192 timestamp:1689674737817 [07-18 18:05:37:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:36432969 ts:0 [07-18 18:05:37:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:36432969 [07-18 18:05:37:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:978585 dataSize:136 [07-18 18:05:37:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:193 timestamp:1689674737850 [07-18 18:05:37:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:36432969 ts:0 [07-18 18:05:37:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:36432969 [07-18 18:05:37:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:332309 dataSize:136 [07-18 18:05:37:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:193 timestamp:1689674737850 [07-18 18:05:37:856 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:856 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 217, head index 193 [07-18 18:05:37:856 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 218, seqNo 818, timestamp 1689674728594 [07-18 18:05:37:856 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:36466302 ts:0 [07-18 18:05:37:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:36466302 [07-18 18:05:37:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:978721 dataSize:725 [07-18 18:05:37:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:194 timestamp:1689674737884 [07-18 18:05:37:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:36466302 ts:0 [07-18 18:05:37:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:36466302 [07-18 18:05:37:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:332445 dataSize:725 [07-18 18:05:37:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:194 timestamp:1689674737884 [07-18 18:05:37:917 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:36499635 ts:0 [07-18 18:05:37:917 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:36499635 [07-18 18:05:37:917 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:979446 dataSize:1369 [07-18 18:05:37:917 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:195 timestamp:1689674737917 [07-18 18:05:37:917 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:36499635 ts:0 [07-18 18:05:37:917 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:36499635 [07-18 18:05:37:917 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:333170 dataSize:1369 [07-18 18:05:37:917 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:195 timestamp:1689674737917 [07-18 18:05:37:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:36532968 ts:0 [07-18 18:05:37:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:36532968 [07-18 18:05:37:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:980815 dataSize:367 [07-18 18:05:37:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:196 timestamp:1689674737951 [07-18 18:05:37:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:36532968 ts:0 [07-18 18:05:37:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:36532968 [07-18 18:05:37:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:334539 dataSize:367 [07-18 18:05:37:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:196 timestamp:1689674737951 [07-18 18:05:37:967 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:37:967 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 218, head index 196 [07-18 18:05:37:967 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 219, seqNo 819, timestamp 1689674728627 [07-18 18:05:37:967 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:37:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:36566301 ts:0 [07-18 18:05:37:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:36566301 [07-18 18:05:37:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:981182 dataSize:141 [07-18 18:05:37:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:197 timestamp:1689674737985 [07-18 18:05:37:985 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:36566301 ts:0 [07-18 18:05:37:985 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:36566301 [07-18 18:05:37:985 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:334906 dataSize:141 [07-18 18:05:37:985 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:197 timestamp:1689674737985 [07-18 18:05:38:18 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:36599634 ts:0 [07-18 18:05:38:18 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:36599634 [07-18 18:05:38:18 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:981323 dataSize:160 [07-18 18:05:38:18 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:198 timestamp:1689674738018 [07-18 18:05:38:18 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:36599634 ts:0 [07-18 18:05:38:18 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:36599634 [07-18 18:05:38:18 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:335047 dataSize:160 [07-18 18:05:38:18 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:198 timestamp:1689674738018 [07-18 18:05:38:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:36632967 ts:0 [07-18 18:05:38:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:36632967 [07-18 18:05:38:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:981483 dataSize:756 [07-18 18:05:38:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:199 timestamp:1689674738052 [07-18 18:05:38:52 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:36632967 ts:0 [07-18 18:05:38:52 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:36632967 [07-18 18:05:38:52 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:335207 dataSize:756 [07-18 18:05:38:52 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:199 timestamp:1689674738052 [07-18 18:05:38:77 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:77 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 219, head index 199 [07-18 18:05:38:77 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 220, seqNo 820, timestamp 1689674728661 [07-18 18:05:38:77 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:36666300 ts:0 [07-18 18:05:38:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:36666300 [07-18 18:05:38:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:982239 dataSize:1610 [07-18 18:05:38:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:200 timestamp:1689674738086 [07-18 18:05:38:86 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:36666300 ts:0 [07-18 18:05:38:86 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:36666300 [07-18 18:05:38:86 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:335963 dataSize:1610 [07-18 18:05:38:86 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:200 timestamp:1689674738086 [07-18 18:05:38:119 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:36699633 ts:0 [07-18 18:05:38:119 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:36699633 [07-18 18:05:38:119 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:983849 dataSize:516 [07-18 18:05:38:119 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:201 timestamp:1689674738119 [07-18 18:05:38:119 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:36699633 ts:0 [07-18 18:05:38:119 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:36699633 [07-18 18:05:38:119 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:337573 dataSize:516 [07-18 18:05:38:119 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:201 timestamp:1689674738119 [07-18 18:05:38:153 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:36732966 ts:0 [07-18 18:05:38:153 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:36732966 [07-18 18:05:38:153 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:984365 dataSize:231 [07-18 18:05:38:153 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:202 timestamp:1689674738153 [07-18 18:05:38:153 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:36732966 ts:0 [07-18 18:05:38:153 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:36732966 [07-18 18:05:38:153 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:338089 dataSize:231 [07-18 18:05:38:153 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:202 timestamp:1689674738153 [07-18 18:05:38:186 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:36766299 ts:0 [07-18 18:05:38:186 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:36766299 [07-18 18:05:38:186 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:984596 dataSize:250 [07-18 18:05:38:186 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:203 timestamp:1689674738186 [07-18 18:05:38:186 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:36766299 ts:0 [07-18 18:05:38:186 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:36766299 [07-18 18:05:38:186 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:338320 dataSize:250 [07-18 18:05:38:187 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:203 timestamp:1689674738187 [07-18 18:05:38:188 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:188 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 220, head index 203 [07-18 18:05:38:188 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 221, seqNo 821, timestamp 1689674728694 [07-18 18:05:38:188 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:220 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:36799632 ts:0 [07-18 18:05:38:220 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:36799632 [07-18 18:05:38:220 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:984846 dataSize:1143 [07-18 18:05:38:220 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:204 timestamp:1689674738220 [07-18 18:05:38:220 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:36799632 ts:0 [07-18 18:05:38:220 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:36799632 [07-18 18:05:38:220 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:338570 dataSize:1143 [07-18 18:05:38:220 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:204 timestamp:1689674738220 [07-18 18:05:38:254 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:36832965 ts:0 [07-18 18:05:38:254 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:36832965 [07-18 18:05:38:254 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:985989 dataSize:383 [07-18 18:05:38:254 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:205 timestamp:1689674738254 [07-18 18:05:38:254 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:36832965 ts:0 [07-18 18:05:38:254 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:36832965 [07-18 18:05:38:254 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:339713 dataSize:383 [07-18 18:05:38:254 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:205 timestamp:1689674738254 [07-18 18:05:38:287 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:36866298 ts:0 [07-18 18:05:38:287 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:36866298 [07-18 18:05:38:287 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:986372 dataSize:235 [07-18 18:05:38:287 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:206 timestamp:1689674738287 [07-18 18:05:38:287 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:36866298 ts:0 [07-18 18:05:38:287 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:36866298 [07-18 18:05:38:287 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:340096 dataSize:235 [07-18 18:05:38:287 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:206 timestamp:1689674738287 [07-18 18:05:38:298 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:298 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 221, head index 206 [07-18 18:05:38:298 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 222, seqNo 822, timestamp 1689674728728 [07-18 18:05:38:298 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:321 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:36899631 ts:0 [07-18 18:05:38:321 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:36899631 [07-18 18:05:38:321 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:986607 dataSize:165 [07-18 18:05:38:321 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:207 timestamp:1689674738321 [07-18 18:05:38:321 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:36899631 ts:0 [07-18 18:05:38:321 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:36899631 [07-18 18:05:38:321 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:340331 dataSize:165 [07-18 18:05:38:321 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:207 timestamp:1689674738321 [07-18 18:05:38:354 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:36932964 ts:0 [07-18 18:05:38:354 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:36932964 [07-18 18:05:38:355 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:986772 dataSize:457 [07-18 18:05:38:355 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:208 timestamp:1689674738355 [07-18 18:05:38:355 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:36932964 ts:0 [07-18 18:05:38:355 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:36932964 [07-18 18:05:38:355 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:340496 dataSize:457 [07-18 18:05:38:355 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:208 timestamp:1689674738355 [07-18 18:05:38:359 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:38:359 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:38:388 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:36966297 ts:0 [07-18 18:05:38:388 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:36966297 [07-18 18:05:38:388 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:987229 dataSize:673 [07-18 18:05:38:388 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:209 timestamp:1689674738388 [07-18 18:05:38:388 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:36966297 ts:0 [07-18 18:05:38:388 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:36966297 [07-18 18:05:38:388 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:340953 dataSize:673 [07-18 18:05:38:388 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:209 timestamp:1689674738388 [07-18 18:05:38:408 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:408 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 222, head index 209 [07-18 18:05:38:408 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:822->1109) [07-18 18:05:38:408 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:822->1109) [07-18 18:05:38:408 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:823->1109) [07-18 18:05:38:408 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 244 seqNo 844 ch0st0tr0 [07-18 18:05:38:409 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:422 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:36999630 ts:0 [07-18 18:05:38:422 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:36999630 [07-18 18:05:38:422 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:987902 dataSize:465 [07-18 18:05:38:422 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:210 timestamp:1689674738422 [07-18 18:05:38:422 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:36999630 ts:0 [07-18 18:05:38:422 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:36999630 [07-18 18:05:38:422 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:341626 dataSize:465 [07-18 18:05:38:422 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:210 timestamp:1689674738422 [07-18 18:05:38:455 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:37032963 ts:0 [07-18 18:05:38:455 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:37032963 [07-18 18:05:38:455 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:988367 dataSize:248 [07-18 18:05:38:455 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:211 timestamp:1689674738455 [07-18 18:05:38:455 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:37032963 ts:0 [07-18 18:05:38:455 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:37032963 [07-18 18:05:38:455 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:342091 dataSize:248 [07-18 18:05:38:456 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:211 timestamp:1689674738456 [07-18 18:05:38:489 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:37066296 ts:0 [07-18 18:05:38:489 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:37066296 [07-18 18:05:38:489 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:988615 dataSize:217 [07-18 18:05:38:489 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:212 timestamp:1689674738489 [07-18 18:05:38:489 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:37066296 ts:0 [07-18 18:05:38:489 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:37066296 [07-18 18:05:38:489 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:342339 dataSize:217 [07-18 18:05:38:489 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:212 timestamp:1689674738489 [07-18 18:05:38:519 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:519 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 244, head index 212 [07-18 18:05:38:519 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 245, seqNo 845, timestamp 1689674729504 [07-18 18:05:38:519 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:523 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:37099629 ts:0 [07-18 18:05:38:523 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:37099629 [07-18 18:05:38:523 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:988832 dataSize:280 [07-18 18:05:38:523 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:213 timestamp:1689674738523 [07-18 18:05:38:523 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:37099629 ts:0 [07-18 18:05:38:523 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:37099629 [07-18 18:05:38:523 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:342556 dataSize:280 [07-18 18:05:38:523 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:213 timestamp:1689674738523 [07-18 18:05:38:556 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:37132962 ts:0 [07-18 18:05:38:556 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:37132962 [07-18 18:05:38:556 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:989112 dataSize:12088 [07-18 18:05:38:556 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:214 timestamp:1689674738556 [07-18 18:05:38:556 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:37132962 ts:0 [07-18 18:05:38:556 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:37132962 [07-18 18:05:38:556 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:342836 dataSize:12088 [07-18 18:05:38:557 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:214 timestamp:1689674738557 [07-18 18:05:38:571 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:05:38:590 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:37166295 ts:0 [07-18 18:05:38:590 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:37166295 [07-18 18:05:38:590 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1001200 dataSize:1051 [07-18 18:05:38:590 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:215 timestamp:1689674738590 [07-18 18:05:38:590 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:37166295 ts:0 [07-18 18:05:38:590 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:37166295 [07-18 18:05:38:590 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:354924 dataSize:1051 [07-18 18:05:38:590 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:215 timestamp:1689674738590 [07-18 18:05:38:624 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:37199628 ts:0 [07-18 18:05:38:624 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:37199628 [07-18 18:05:38:624 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1002251 dataSize:209 [07-18 18:05:38:624 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:216 timestamp:1689674738624 [07-18 18:05:38:624 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:37199628 ts:0 [07-18 18:05:38:624 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:37199628 [07-18 18:05:38:624 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:355975 dataSize:209 [07-18 18:05:38:624 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:216 timestamp:1689674738624 [07-18 18:05:38:629 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:629 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 245, head index 216 [07-18 18:05:38:629 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 246, seqNo 846, timestamp 1689674729538 [07-18 18:05:38:629 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:657 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:37232961 ts:0 [07-18 18:05:38:657 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:37232961 [07-18 18:05:38:657 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1002460 dataSize:118 [07-18 18:05:38:657 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:217 timestamp:1689674738657 [07-18 18:05:38:657 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:37232961 ts:0 [07-18 18:05:38:657 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:37232961 [07-18 18:05:38:658 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:356184 dataSize:118 [07-18 18:05:38:658 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:217 timestamp:1689674738658 [07-18 18:05:38:691 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:37266294 ts:0 [07-18 18:05:38:691 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:37266294 [07-18 18:05:38:691 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1002578 dataSize:110 [07-18 18:05:38:691 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:218 timestamp:1689674738691 [07-18 18:05:38:691 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:37266294 ts:0 [07-18 18:05:38:691 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:37266294 [07-18 18:05:38:691 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:356302 dataSize:110 [07-18 18:05:38:691 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:218 timestamp:1689674738691 [07-18 18:05:38:725 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:37299627 ts:0 [07-18 18:05:38:725 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:37299627 [07-18 18:05:38:725 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1002688 dataSize:695 [07-18 18:05:38:725 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:219 timestamp:1689674738725 [07-18 18:05:38:725 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:37299627 ts:0 [07-18 18:05:38:725 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:37299627 [07-18 18:05:38:725 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:356412 dataSize:695 [07-18 18:05:38:725 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:219 timestamp:1689674738725 [07-18 18:05:38:740 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:740 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 246, head index 219 [07-18 18:05:38:740 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 247, seqNo 847, timestamp 1689674729572 [07-18 18:05:38:740 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:758 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:37332960 ts:0 [07-18 18:05:38:758 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:37332960 [07-18 18:05:38:758 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1003383 dataSize:1146 [07-18 18:05:38:758 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:220 timestamp:1689674738758 [07-18 18:05:38:758 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:37332960 ts:0 [07-18 18:05:38:758 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:37332960 [07-18 18:05:38:758 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:357107 dataSize:1146 [07-18 18:05:38:758 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:220 timestamp:1689674738758 [07-18 18:05:38:792 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:37366293 ts:0 [07-18 18:05:38:792 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:37366293 [07-18 18:05:38:792 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1004529 dataSize:276 [07-18 18:05:38:792 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:221 timestamp:1689674738792 [07-18 18:05:38:792 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:37366293 ts:0 [07-18 18:05:38:792 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:37366293 [07-18 18:05:38:792 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:358253 dataSize:276 [07-18 18:05:38:792 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:221 timestamp:1689674738792 [07-18 18:05:38:826 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:37399626 ts:0 [07-18 18:05:38:826 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:37399626 [07-18 18:05:38:826 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1004805 dataSize:152 [07-18 18:05:38:826 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:222 timestamp:1689674738826 [07-18 18:05:38:826 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:37399626 ts:0 [07-18 18:05:38:826 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:37399626 [07-18 18:05:38:826 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:358529 dataSize:152 [07-18 18:05:38:826 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:222 timestamp:1689674738826 [07-18 18:05:38:850 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:850 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 247, head index 222 [07-18 18:05:38:850 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 248, seqNo 848, timestamp 1689674729605 [07-18 18:05:38:850 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:859 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:37432959 ts:0 [07-18 18:05:38:859 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:37432959 [07-18 18:05:38:859 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1004957 dataSize:136 [07-18 18:05:38:859 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:223 timestamp:1689674738859 [07-18 18:05:38:859 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:37432959 ts:0 [07-18 18:05:38:859 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:37432959 [07-18 18:05:38:859 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:358681 dataSize:136 [07-18 18:05:38:859 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:223 timestamp:1689674738859 [07-18 18:05:38:893 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:37466292 ts:0 [07-18 18:05:38:893 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:37466292 [07-18 18:05:38:893 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1005093 dataSize:725 [07-18 18:05:38:893 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:224 timestamp:1689674738893 [07-18 18:05:38:893 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:37466292 ts:0 [07-18 18:05:38:893 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:37466292 [07-18 18:05:38:893 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:358817 dataSize:725 [07-18 18:05:38:893 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:224 timestamp:1689674738893 [07-18 18:05:38:926 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:37499625 ts:0 [07-18 18:05:38:927 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:37499625 [07-18 18:05:38:927 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1005818 dataSize:1369 [07-18 18:05:38:927 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:225 timestamp:1689674738927 [07-18 18:05:38:927 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:37499625 ts:0 [07-18 18:05:38:927 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:37499625 [07-18 18:05:38:927 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:359542 dataSize:1369 [07-18 18:05:38:927 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:225 timestamp:1689674738927 [07-18 18:05:38:960 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:38:960 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 248, head index 225 [07-18 18:05:38:960 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 249, seqNo 849, timestamp 1689674729639 [07-18 18:05:38:960 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:37532958 ts:0 [07-18 18:05:38:960 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:37532958 [07-18 18:05:38:960 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1007187 dataSize:367 [07-18 18:05:38:960 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:226 timestamp:1689674738960 [07-18 18:05:38:960 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:37532958 ts:0 [07-18 18:05:38:960 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:37532958 [07-18 18:05:38:960 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:360911 dataSize:367 [07-18 18:05:38:960 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:226 timestamp:1689674738960 [07-18 18:05:38:960 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:38:994 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:37566291 ts:0 [07-18 18:05:38:994 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:37566291 [07-18 18:05:38:994 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1007554 dataSize:141 [07-18 18:05:38:994 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:227 timestamp:1689674738994 [07-18 18:05:38:994 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:37566291 ts:0 [07-18 18:05:38:994 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:37566291 [07-18 18:05:38:994 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:361278 dataSize:141 [07-18 18:05:38:994 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:227 timestamp:1689674738994 [07-18 18:05:39:28 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:37599624 ts:0 [07-18 18:05:39:28 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:37599624 [07-18 18:05:39:28 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1007695 dataSize:160 [07-18 18:05:39:28 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:228 timestamp:1689674739028 [07-18 18:05:39:28 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:37599624 ts:0 [07-18 18:05:39:28 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:37599624 [07-18 18:05:39:28 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:361419 dataSize:160 [07-18 18:05:39:28 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:228 timestamp:1689674739028 [07-18 18:05:39:61 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:37632957 ts:0 [07-18 18:05:39:61 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:37632957 [07-18 18:05:39:61 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1007855 dataSize:756 [07-18 18:05:39:61 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:229 timestamp:1689674739061 [07-18 18:05:39:61 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:37632957 ts:0 [07-18 18:05:39:61 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:37632957 [07-18 18:05:39:61 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:361579 dataSize:756 [07-18 18:05:39:61 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:229 timestamp:1689674739061 [07-18 18:05:39:71 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:71 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 249, head index 229 [07-18 18:05:39:71 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 250, seqNo 850, timestamp 1689674729673 [07-18 18:05:39:71 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:95 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:37666290 ts:0 [07-18 18:05:39:95 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:37666290 [07-18 18:05:39:95 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1008611 dataSize:1610 [07-18 18:05:39:95 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:230 timestamp:1689674739095 [07-18 18:05:39:95 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:37666290 ts:0 [07-18 18:05:39:95 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:37666290 [07-18 18:05:39:95 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:362335 dataSize:1610 [07-18 18:05:39:95 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:230 timestamp:1689674739095 [07-18 18:05:39:128 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:37699623 ts:0 [07-18 18:05:39:128 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:37699623 [07-18 18:05:39:128 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1010221 dataSize:516 [07-18 18:05:39:128 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:231 timestamp:1689674739128 [07-18 18:05:39:128 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:37699623 ts:0 [07-18 18:05:39:128 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:37699623 [07-18 18:05:39:128 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:363945 dataSize:516 [07-18 18:05:39:128 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:231 timestamp:1689674739128 [07-18 18:05:39:131 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[3]lstCnt[145]vIFrameCnt[145] [07-18 18:05:39:131 TUYA Debug][tuya_ipc_p2p.c:5031] session[131073] detech staticCnt[0]lstCnt[20]vIFrameCnt[20] [07-18 18:05:39:162 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:37732956 ts:0 [07-18 18:05:39:162 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:37732956 [07-18 18:05:39:162 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1010737 dataSize:231 [07-18 18:05:39:162 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:232 timestamp:1689674739162 [07-18 18:05:39:162 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:37732956 ts:0 [07-18 18:05:39:162 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:37732956 [07-18 18:05:39:162 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:364461 dataSize:231 [07-18 18:05:39:162 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:232 timestamp:1689674739162 [07-18 18:05:39:181 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:181 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 250, head index 232 [07-18 18:05:39:181 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 251, seqNo 851, timestamp 1689674729706 [07-18 18:05:39:181 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:196 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:37766289 ts:0 [07-18 18:05:39:196 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:37766289 [07-18 18:05:39:196 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1010968 dataSize:250 [07-18 18:05:39:196 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:233 timestamp:1689674739196 [07-18 18:05:39:196 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:37766289 ts:0 [07-18 18:05:39:196 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:37766289 [07-18 18:05:39:196 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:364692 dataSize:250 [07-18 18:05:39:196 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:233 timestamp:1689674739196 [07-18 18:05:39:229 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:37799622 ts:0 [07-18 18:05:39:229 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:37799622 [07-18 18:05:39:229 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1011218 dataSize:1143 [07-18 18:05:39:229 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:234 timestamp:1689674739229 [07-18 18:05:39:229 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:37799622 ts:0 [07-18 18:05:39:229 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:37799622 [07-18 18:05:39:229 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:364942 dataSize:1143 [07-18 18:05:39:229 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:234 timestamp:1689674739229 [07-18 18:05:39:263 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:37832955 ts:0 [07-18 18:05:39:263 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:37832955 [07-18 18:05:39:263 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1012361 dataSize:383 [07-18 18:05:39:263 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:235 timestamp:1689674739263 [07-18 18:05:39:263 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:37832955 ts:0 [07-18 18:05:39:263 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:37832955 [07-18 18:05:39:263 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:366085 dataSize:383 [07-18 18:05:39:263 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:235 timestamp:1689674739263 [07-18 18:05:39:292 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:292 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 251, head index 235 [07-18 18:05:39:292 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 252, seqNo 852, timestamp 1689674729740 [07-18 18:05:39:292 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:300 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:37866288 ts:0 [07-18 18:05:39:300 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:37866288 [07-18 18:05:39:300 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1012744 dataSize:235 [07-18 18:05:39:300 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:236 timestamp:1689674739300 [07-18 18:05:39:300 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:37866288 ts:0 [07-18 18:05:39:300 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:37866288 [07-18 18:05:39:301 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:366468 dataSize:235 [07-18 18:05:39:301 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:236 timestamp:1689674739301 [07-18 18:05:39:334 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:37899621 ts:0 [07-18 18:05:39:334 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:37899621 [07-18 18:05:39:334 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1012979 dataSize:165 [07-18 18:05:39:334 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:237 timestamp:1689674739334 [07-18 18:05:39:334 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:37899621 ts:0 [07-18 18:05:39:334 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:37899621 [07-18 18:05:39:334 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:366703 dataSize:165 [07-18 18:05:39:334 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:237 timestamp:1689674739334 [07-18 18:05:39:359 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:39:359 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:39:368 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:37932954 ts:0 [07-18 18:05:39:368 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:37932954 [07-18 18:05:39:368 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1013144 dataSize:457 [07-18 18:05:39:368 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:238 timestamp:1689674739368 [07-18 18:05:39:368 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:37932954 ts:0 [07-18 18:05:39:368 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:37932954 [07-18 18:05:39:368 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:366868 dataSize:457 [07-18 18:05:39:368 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:238 timestamp:1689674739368 [07-18 18:05:39:401 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:37966287 ts:0 [07-18 18:05:39:401 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:37966287 [07-18 18:05:39:401 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1013601 dataSize:673 [07-18 18:05:39:401 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:239 timestamp:1689674739401 [07-18 18:05:39:402 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:37966287 ts:0 [07-18 18:05:39:402 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:37966287 [07-18 18:05:39:402 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:367325 dataSize:673 [07-18 18:05:39:402 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:239 timestamp:1689674739402 [07-18 18:05:39:402 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:402 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 252, head index 239 [07-18 18:05:39:402 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:852->1139) [07-18 18:05:39:402 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:852->1139) [07-18 18:05:39:402 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:853->1139) [07-18 18:05:39:402 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 274 seqNo 874 ch0st0tr0 [07-18 18:05:39:402 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:435 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:37999620 ts:0 [07-18 18:05:39:435 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:37999620 [07-18 18:05:39:435 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1014274 dataSize:465 [07-18 18:05:39:435 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:240 timestamp:1689674739435 [07-18 18:05:39:435 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:37999620 ts:0 [07-18 18:05:39:435 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:37999620 [07-18 18:05:39:435 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:367998 dataSize:465 [07-18 18:05:39:435 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:240 timestamp:1689674739435 [07-18 18:05:39:469 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:38032953 ts:0 [07-18 18:05:39:469 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:38032953 [07-18 18:05:39:469 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1014739 dataSize:248 [07-18 18:05:39:469 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:241 timestamp:1689674739469 [07-18 18:05:39:469 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:38032953 ts:0 [07-18 18:05:39:469 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:38032953 [07-18 18:05:39:469 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:368463 dataSize:248 [07-18 18:05:39:469 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:241 timestamp:1689674739469 [07-18 18:05:39:502 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:38066286 ts:0 [07-18 18:05:39:502 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:38066286 [07-18 18:05:39:502 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1014987 dataSize:217 [07-18 18:05:39:502 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:242 timestamp:1689674739502 [07-18 18:05:39:503 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:38066286 ts:0 [07-18 18:05:39:503 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:38066286 [07-18 18:05:39:503 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:368711 dataSize:217 [07-18 18:05:39:503 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:242 timestamp:1689674739503 [07-18 18:05:39:513 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:513 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 274, head index 242 [07-18 18:05:39:513 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 275, seqNo 875, timestamp 1689674730514 [07-18 18:05:39:513 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:536 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:38099619 ts:0 [07-18 18:05:39:536 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:38099619 [07-18 18:05:39:536 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1015204 dataSize:280 [07-18 18:05:39:536 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:243 timestamp:1689674739536 [07-18 18:05:39:536 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:38099619 ts:0 [07-18 18:05:39:536 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:38099619 [07-18 18:05:39:536 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:368928 dataSize:280 [07-18 18:05:39:536 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:243 timestamp:1689674739536 [07-18 18:05:39:570 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:38132952 ts:0 [07-18 18:05:39:570 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:38132952 [07-18 18:05:39:570 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1015484 dataSize:12088 [07-18 18:05:39:570 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:244 timestamp:1689674739570 [07-18 18:05:39:570 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:38132952 ts:0 [07-18 18:05:39:570 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:38132952 [07-18 18:05:39:570 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:369208 dataSize:12088 [07-18 18:05:39:570 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:244 timestamp:1689674739570 [07-18 18:05:39:603 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:38166285 ts:0 [07-18 18:05:39:603 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:38166285 [07-18 18:05:39:603 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1027572 dataSize:1051 [07-18 18:05:39:604 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:245 timestamp:1689674739604 [07-18 18:05:39:604 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:38166285 ts:0 [07-18 18:05:39:604 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:38166285 [07-18 18:05:39:604 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:381296 dataSize:1051 [07-18 18:05:39:604 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:245 timestamp:1689674739604 [07-18 18:05:39:623 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:623 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 275, head index 245 [07-18 18:05:39:623 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 276, seqNo 876, timestamp 1689674730548 [07-18 18:05:39:623 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:637 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:38199618 ts:0 [07-18 18:05:39:637 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:38199618 [07-18 18:05:39:637 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1028623 dataSize:209 [07-18 18:05:39:637 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:246 timestamp:1689674739637 [07-18 18:05:39:637 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:38199618 ts:0 [07-18 18:05:39:637 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:38199618 [07-18 18:05:39:637 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:382347 dataSize:209 [07-18 18:05:39:637 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:246 timestamp:1689674739637 [07-18 18:05:39:671 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:38232951 ts:0 [07-18 18:05:39:671 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:38232951 [07-18 18:05:39:671 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1028832 dataSize:118 [07-18 18:05:39:671 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:247 timestamp:1689674739671 [07-18 18:05:39:671 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:38232951 ts:0 [07-18 18:05:39:671 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:38232951 [07-18 18:05:39:671 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:382556 dataSize:118 [07-18 18:05:39:671 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:247 timestamp:1689674739671 [07-18 18:05:39:704 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:38266284 ts:0 [07-18 18:05:39:704 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:38266284 [07-18 18:05:39:704 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1028950 dataSize:110 [07-18 18:05:39:705 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:248 timestamp:1689674739705 [07-18 18:05:39:705 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:38266284 ts:0 [07-18 18:05:39:705 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:38266284 [07-18 18:05:39:705 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:382674 dataSize:110 [07-18 18:05:39:705 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:248 timestamp:1689674739705 [07-18 18:05:39:733 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:733 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 276, head index 248 [07-18 18:05:39:733 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 277, seqNo 877, timestamp 1689674730582 [07-18 18:05:39:733 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:738 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:38299617 ts:0 [07-18 18:05:39:738 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:38299617 [07-18 18:05:39:738 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1029060 dataSize:695 [07-18 18:05:39:738 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:249 timestamp:1689674739738 [07-18 18:05:39:738 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:38299617 ts:0 [07-18 18:05:39:738 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:38299617 [07-18 18:05:39:738 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:382784 dataSize:695 [07-18 18:05:39:738 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:249 timestamp:1689674739738 [07-18 18:05:39:771 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:38332950 ts:0 [07-18 18:05:39:772 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:38332950 [07-18 18:05:39:772 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1029755 dataSize:1146 [07-18 18:05:39:772 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:250 timestamp:1689674739772 [07-18 18:05:39:772 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:38332950 ts:0 [07-18 18:05:39:772 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:38332950 [07-18 18:05:39:772 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:383479 dataSize:1146 [07-18 18:05:39:772 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:250 timestamp:1689674739772 [07-18 18:05:39:805 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:38366283 ts:0 [07-18 18:05:39:805 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:38366283 [07-18 18:05:39:805 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1030901 dataSize:276 [07-18 18:05:39:805 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:251 timestamp:1689674739805 [07-18 18:05:39:805 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:38366283 ts:0 [07-18 18:05:39:805 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:38366283 [07-18 18:05:39:805 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:384625 dataSize:276 [07-18 18:05:39:805 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:251 timestamp:1689674739805 [07-18 18:05:39:839 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:38399616 ts:0 [07-18 18:05:39:839 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:38399616 [07-18 18:05:39:839 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1031177 dataSize:152 [07-18 18:05:39:839 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:252 timestamp:1689674739839 [07-18 18:05:39:839 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:38399616 ts:0 [07-18 18:05:39:839 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:38399616 [07-18 18:05:39:839 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:384901 dataSize:152 [07-18 18:05:39:839 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:252 timestamp:1689674739839 [07-18 18:05:39:844 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:844 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 277, head index 252 [07-18 18:05:39:844 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 278, seqNo 878, timestamp 1689674730615 [07-18 18:05:39:844 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:873 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:38432949 ts:0 [07-18 18:05:39:873 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:38432949 [07-18 18:05:39:873 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1031329 dataSize:136 [07-18 18:05:39:873 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:253 timestamp:1689674739873 [07-18 18:05:39:873 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:38432949 ts:0 [07-18 18:05:39:873 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:38432949 [07-18 18:05:39:873 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:385053 dataSize:136 [07-18 18:05:39:873 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:253 timestamp:1689674739873 [07-18 18:05:39:906 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:38466282 ts:0 [07-18 18:05:39:906 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:38466282 [07-18 18:05:39:906 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1031465 dataSize:725 [07-18 18:05:39:906 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:254 timestamp:1689674739906 [07-18 18:05:39:906 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:38466282 ts:0 [07-18 18:05:39:906 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:38466282 [07-18 18:05:39:906 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:385189 dataSize:725 [07-18 18:05:39:906 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:254 timestamp:1689674739906 [07-18 18:05:39:940 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:38499615 ts:0 [07-18 18:05:39:940 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:38499615 [07-18 18:05:39:940 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1032190 dataSize:1369 [07-18 18:05:39:940 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:255 timestamp:1689674739940 [07-18 18:05:39:940 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:38499615 ts:0 [07-18 18:05:39:940 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:38499615 [07-18 18:05:39:940 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:385914 dataSize:1369 [07-18 18:05:39:940 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:255 timestamp:1689674739940 [07-18 18:05:39:954 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:39:954 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 278, head index 255 [07-18 18:05:39:954 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 279, seqNo 879, timestamp 1689674730649 [07-18 18:05:39:954 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:39:974 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:38532948 ts:0 [07-18 18:05:39:974 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:38532948 [07-18 18:05:39:974 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1033559 dataSize:367 [07-18 18:05:39:974 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:256 timestamp:1689674739974 [07-18 18:05:39:974 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:38532948 ts:0 [07-18 18:05:39:974 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:38532948 [07-18 18:05:39:974 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:387283 dataSize:367 [07-18 18:05:39:974 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:256 timestamp:1689674739974 [07-18 18:05:40:7 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:38566281 ts:0 [07-18 18:05:40:7 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:38566281 [07-18 18:05:40:7 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1033926 dataSize:141 [07-18 18:05:40:7 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:257 timestamp:1689674740007 [07-18 18:05:40:7 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:38566281 ts:0 [07-18 18:05:40:7 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:38566281 [07-18 18:05:40:7 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:387650 dataSize:141 [07-18 18:05:40:7 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:257 timestamp:1689674740007 [07-18 18:05:40:41 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:38599614 ts:0 [07-18 18:05:40:41 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:38599614 [07-18 18:05:40:41 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1034067 dataSize:160 [07-18 18:05:40:41 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:258 timestamp:1689674740041 [07-18 18:05:40:41 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:38599614 ts:0 [07-18 18:05:40:41 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:38599614 [07-18 18:05:40:41 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:387791 dataSize:160 [07-18 18:05:40:41 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:258 timestamp:1689674740041 [07-18 18:05:40:64 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:64 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 279, head index 258 [07-18 18:05:40:64 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 280, seqNo 880, timestamp 1689674730682 [07-18 18:05:40:64 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:74 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:38632947 ts:0 [07-18 18:05:40:75 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:38632947 [07-18 18:05:40:75 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1034227 dataSize:756 [07-18 18:05:40:75 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:259 timestamp:1689674740075 [07-18 18:05:40:75 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:38632947 ts:0 [07-18 18:05:40:75 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:38632947 [07-18 18:05:40:75 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:387951 dataSize:756 [07-18 18:05:40:75 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:259 timestamp:1689674740075 [07-18 18:05:40:108 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:38666280 ts:0 [07-18 18:05:40:108 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:38666280 [07-18 18:05:40:108 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1034983 dataSize:1610 [07-18 18:05:40:108 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:260 timestamp:1689674740108 [07-18 18:05:40:108 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:38666280 ts:0 [07-18 18:05:40:108 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:38666280 [07-18 18:05:40:108 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:388707 dataSize:1610 [07-18 18:05:40:108 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:260 timestamp:1689674740108 [07-18 18:05:40:142 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:38699613 ts:0 [07-18 18:05:40:142 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:38699613 [07-18 18:05:40:142 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1036593 dataSize:516 [07-18 18:05:40:142 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:261 timestamp:1689674740142 [07-18 18:05:40:142 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:38699613 ts:0 [07-18 18:05:40:142 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:38699613 [07-18 18:05:40:142 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:390317 dataSize:516 [07-18 18:05:40:142 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:261 timestamp:1689674740142 [07-18 18:05:40:174 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:175 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 280, head index 261 [07-18 18:05:40:175 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 281, seqNo 881, timestamp 1689674730716 [07-18 18:05:40:175 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:175 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:38732946 ts:0 [07-18 18:05:40:176 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:38732946 [07-18 18:05:40:176 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1037109 dataSize:231 [07-18 18:05:40:176 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:262 timestamp:1689674740176 [07-18 18:05:40:176 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:38732946 ts:0 [07-18 18:05:40:176 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:38732946 [07-18 18:05:40:176 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:390833 dataSize:231 [07-18 18:05:40:176 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:262 timestamp:1689674740176 [07-18 18:05:40:209 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:38766279 ts:0 [07-18 18:05:40:209 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:38766279 [07-18 18:05:40:209 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1037340 dataSize:250 [07-18 18:05:40:209 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:263 timestamp:1689674740209 [07-18 18:05:40:209 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:38766279 ts:0 [07-18 18:05:40:209 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:38766279 [07-18 18:05:40:209 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:391064 dataSize:250 [07-18 18:05:40:209 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:263 timestamp:1689674740209 [07-18 18:05:40:243 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:38799612 ts:0 [07-18 18:05:40:243 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:38799612 [07-18 18:05:40:243 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1037590 dataSize:1143 [07-18 18:05:40:243 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:264 timestamp:1689674740243 [07-18 18:05:40:243 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:38799612 ts:0 [07-18 18:05:40:243 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:38799612 [07-18 18:05:40:243 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:391314 dataSize:1143 [07-18 18:05:40:243 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:264 timestamp:1689674740243 [07-18 18:05:40:276 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:38832945 ts:0 [07-18 18:05:40:276 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:38832945 [07-18 18:05:40:276 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1038733 dataSize:383 [07-18 18:05:40:276 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:265 timestamp:1689674740276 [07-18 18:05:40:276 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:38832945 ts:0 [07-18 18:05:40:277 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:38832945 [07-18 18:05:40:277 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:392457 dataSize:383 [07-18 18:05:40:277 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:265 timestamp:1689674740277 [07-18 18:05:40:285 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:285 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 281, head index 265 [07-18 18:05:40:285 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 282, seqNo 882, timestamp 1689674730750 [07-18 18:05:40:285 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:310 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:38866278 ts:0 [07-18 18:05:40:310 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:38866278 [07-18 18:05:40:310 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1039116 dataSize:235 [07-18 18:05:40:310 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:266 timestamp:1689674740310 [07-18 18:05:40:310 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:38866278 ts:0 [07-18 18:05:40:310 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:38866278 [07-18 18:05:40:310 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:392840 dataSize:235 [07-18 18:05:40:310 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:266 timestamp:1689674740310 [07-18 18:05:40:344 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:38899611 ts:0 [07-18 18:05:40:344 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:38899611 [07-18 18:05:40:344 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1039351 dataSize:165 [07-18 18:05:40:344 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:267 timestamp:1689674740344 [07-18 18:05:40:344 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:38899611 ts:0 [07-18 18:05:40:344 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:38899611 [07-18 18:05:40:344 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:393075 dataSize:165 [07-18 18:05:40:344 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:267 timestamp:1689674740344 [07-18 18:05:40:360 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:40:360 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:40:377 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:38932944 ts:0 [07-18 18:05:40:377 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:38932944 [07-18 18:05:40:377 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1039516 dataSize:457 [07-18 18:05:40:378 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:268 timestamp:1689674740378 [07-18 18:05:40:378 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:38932944 ts:0 [07-18 18:05:40:378 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:38932944 [07-18 18:05:40:378 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:393240 dataSize:457 [07-18 18:05:40:378 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:268 timestamp:1689674740378 [07-18 18:05:40:395 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:395 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 282, head index 268 [07-18 18:05:40:395 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:882->1168) [07-18 18:05:40:395 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:882->1168) [07-18 18:05:40:395 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 4 seqNo 904 ch0st0tr0 [07-18 18:05:40:396 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:411 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:38966277 ts:0 [07-18 18:05:40:411 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:38966277 [07-18 18:05:40:411 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1039973 dataSize:673 [07-18 18:05:40:411 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:269 timestamp:1689674740411 [07-18 18:05:40:411 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:38966277 ts:0 [07-18 18:05:40:411 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:38966277 [07-18 18:05:40:411 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:393697 dataSize:673 [07-18 18:05:40:411 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:269 timestamp:1689674740411 [07-18 18:05:40:445 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:38999610 ts:0 [07-18 18:05:40:445 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:38999610 [07-18 18:05:40:445 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1040646 dataSize:465 [07-18 18:05:40:445 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:270 timestamp:1689674740445 [07-18 18:05:40:445 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:38999610 ts:0 [07-18 18:05:40:445 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:38999610 [07-18 18:05:40:445 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:394370 dataSize:465 [07-18 18:05:40:445 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:270 timestamp:1689674740445 [07-18 18:05:40:478 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:39032943 ts:0 [07-18 18:05:40:478 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:39032943 [07-18 18:05:40:478 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1041111 dataSize:248 [07-18 18:05:40:478 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:271 timestamp:1689674740478 [07-18 18:05:40:478 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:39032943 ts:0 [07-18 18:05:40:478 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:39032943 [07-18 18:05:40:478 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:394835 dataSize:248 [07-18 18:05:40:478 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:271 timestamp:1689674740478 [07-18 18:05:40:506 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:506 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 4, head index 271 [07-18 18:05:40:506 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 5, seqNo 905, timestamp 1689674731523 [07-18 18:05:40:506 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:512 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:39066276 ts:0 [07-18 18:05:40:512 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:39066276 [07-18 18:05:40:512 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1041359 dataSize:217 [07-18 18:05:40:512 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:272 timestamp:1689674740512 [07-18 18:05:40:512 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:39066276 ts:0 [07-18 18:05:40:512 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:39066276 [07-18 18:05:40:512 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:395083 dataSize:217 [07-18 18:05:40:512 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:272 timestamp:1689674740512 [07-18 18:05:40:546 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:39099609 ts:0 [07-18 18:05:40:546 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:39099609 [07-18 18:05:40:546 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1041576 dataSize:280 [07-18 18:05:40:546 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:273 timestamp:1689674740546 [07-18 18:05:40:546 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:39099609 ts:0 [07-18 18:05:40:546 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:39099609 [07-18 18:05:40:546 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:395300 dataSize:280 [07-18 18:05:40:546 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:273 timestamp:1689674740546 [07-18 18:05:40:579 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:39132942 ts:0 [07-18 18:05:40:579 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:39132942 [07-18 18:05:40:579 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1041856 dataSize:12088 [07-18 18:05:40:579 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:274 timestamp:1689674740579 [07-18 18:05:40:579 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:39132942 ts:0 [07-18 18:05:40:579 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:39132942 [07-18 18:05:40:579 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:395580 dataSize:12088 [07-18 18:05:40:579 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:274 timestamp:1689674740579 [07-18 18:05:40:613 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:39166275 ts:0 [07-18 18:05:40:613 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:39166275 [07-18 18:05:40:613 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1053944 dataSize:1051 [07-18 18:05:40:613 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:275 timestamp:1689674740613 [07-18 18:05:40:613 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:39166275 ts:0 [07-18 18:05:40:613 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:39166275 [07-18 18:05:40:613 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:407668 dataSize:1051 [07-18 18:05:40:613 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:275 timestamp:1689674740613 [07-18 18:05:40:616 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:616 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 5, head index 275 [07-18 18:05:40:616 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 6, seqNo 906, timestamp 1689674731557 [07-18 18:05:40:616 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:646 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:39199608 ts:0 [07-18 18:05:40:646 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:39199608 [07-18 18:05:40:646 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1054995 dataSize:209 [07-18 18:05:40:647 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:276 timestamp:1689674740647 [07-18 18:05:40:647 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:39199608 ts:0 [07-18 18:05:40:647 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:39199608 [07-18 18:05:40:647 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:408719 dataSize:209 [07-18 18:05:40:647 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:276 timestamp:1689674740647 [07-18 18:05:40:680 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:39232941 ts:0 [07-18 18:05:40:680 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:39232941 [07-18 18:05:40:680 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1055204 dataSize:118 [07-18 18:05:40:680 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:277 timestamp:1689674740680 [07-18 18:05:40:680 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:39232941 ts:0 [07-18 18:05:40:680 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:39232941 [07-18 18:05:40:680 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:408928 dataSize:118 [07-18 18:05:40:680 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:277 timestamp:1689674740680 [07-18 18:05:40:714 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:39266274 ts:0 [07-18 18:05:40:714 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:39266274 [07-18 18:05:40:714 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1055322 dataSize:110 [07-18 18:05:40:714 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:278 timestamp:1689674740714 [07-18 18:05:40:714 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:39266274 ts:0 [07-18 18:05:40:714 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:39266274 [07-18 18:05:40:714 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:409046 dataSize:110 [07-18 18:05:40:714 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:278 timestamp:1689674740714 [07-18 18:05:40:727 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:727 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 6, head index 278 [07-18 18:05:40:727 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 7, seqNo 907, timestamp 1689674731590 [07-18 18:05:40:727 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:747 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:39299607 ts:0 [07-18 18:05:40:747 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:39299607 [07-18 18:05:40:747 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1055432 dataSize:695 [07-18 18:05:40:747 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:279 timestamp:1689674740747 [07-18 18:05:40:747 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:39299607 ts:0 [07-18 18:05:40:747 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:39299607 [07-18 18:05:40:747 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:409156 dataSize:695 [07-18 18:05:40:747 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:279 timestamp:1689674740747 [07-18 18:05:40:781 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:39332940 ts:0 [07-18 18:05:40:781 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:39332940 [07-18 18:05:40:781 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1056127 dataSize:1146 [07-18 18:05:40:781 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:280 timestamp:1689674740781 [07-18 18:05:40:781 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:39332940 ts:0 [07-18 18:05:40:781 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:39332940 [07-18 18:05:40:781 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:409851 dataSize:1146 [07-18 18:05:40:781 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:280 timestamp:1689674740781 [07-18 18:05:40:815 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:39366273 ts:0 [07-18 18:05:40:815 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:39366273 [07-18 18:05:40:815 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1057273 dataSize:276 [07-18 18:05:40:815 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:281 timestamp:1689674740815 [07-18 18:05:40:815 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:39366273 ts:0 [07-18 18:05:40:815 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:39366273 [07-18 18:05:40:815 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:410997 dataSize:276 [07-18 18:05:40:815 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:281 timestamp:1689674740815 [07-18 18:05:40:837 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:837 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 7, head index 281 [07-18 18:05:40:837 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 8, seqNo 908, timestamp 1689674731624 [07-18 18:05:40:837 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:848 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:39399606 ts:0 [07-18 18:05:40:848 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:39399606 [07-18 18:05:40:848 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1057549 dataSize:152 [07-18 18:05:40:848 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:282 timestamp:1689674740848 [07-18 18:05:40:848 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:39399606 ts:0 [07-18 18:05:40:848 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:39399606 [07-18 18:05:40:848 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:411273 dataSize:152 [07-18 18:05:40:848 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:282 timestamp:1689674740848 [07-18 18:05:40:882 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:39432939 ts:0 [07-18 18:05:40:882 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:39432939 [07-18 18:05:40:882 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1057701 dataSize:136 [07-18 18:05:40:882 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:283 timestamp:1689674740882 [07-18 18:05:40:882 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:39432939 ts:0 [07-18 18:05:40:882 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:39432939 [07-18 18:05:40:882 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:411425 dataSize:136 [07-18 18:05:40:882 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:283 timestamp:1689674740882 [07-18 18:05:40:915 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:39466272 ts:0 [07-18 18:05:40:915 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:39466272 [07-18 18:05:40:916 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1057837 dataSize:725 [07-18 18:05:40:916 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:284 timestamp:1689674740916 [07-18 18:05:40:916 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:39466272 ts:0 [07-18 18:05:40:916 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:39466272 [07-18 18:05:40:916 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:411561 dataSize:725 [07-18 18:05:40:916 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:284 timestamp:1689674740916 [07-18 18:05:40:947 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:40:947 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 8, head index 284 [07-18 18:05:40:947 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 9, seqNo 909, timestamp 1689674731658 [07-18 18:05:40:948 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:40:949 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:39499605 ts:0 [07-18 18:05:40:949 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:39499605 [07-18 18:05:40:949 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1058562 dataSize:1369 [07-18 18:05:40:949 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:285 timestamp:1689674740949 [07-18 18:05:40:949 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:39499605 ts:0 [07-18 18:05:40:949 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:39499605 [07-18 18:05:40:949 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:412286 dataSize:1369 [07-18 18:05:40:949 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:285 timestamp:1689674740949 [07-18 18:05:40:982 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:39532938 ts:0 [07-18 18:05:40:983 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:39532938 [07-18 18:05:40:983 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1059931 dataSize:367 [07-18 18:05:40:983 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:286 timestamp:1689674740983 [07-18 18:05:40:983 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:39532938 ts:0 [07-18 18:05:40:983 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:39532938 [07-18 18:05:40:983 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:413655 dataSize:367 [07-18 18:05:40:983 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:286 timestamp:1689674740983 [07-18 18:05:41:16 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:39566271 ts:0 [07-18 18:05:41:16 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:39566271 [07-18 18:05:41:16 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1060298 dataSize:141 [07-18 18:05:41:16 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:287 timestamp:1689674741016 [07-18 18:05:41:16 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:39566271 ts:0 [07-18 18:05:41:16 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:39566271 [07-18 18:05:41:16 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:414022 dataSize:141 [07-18 18:05:41:16 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:287 timestamp:1689674741016 [07-18 18:05:41:50 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:39599604 ts:0 [07-18 18:05:41:50 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:39599604 [07-18 18:05:41:50 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1060439 dataSize:160 [07-18 18:05:41:50 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:288 timestamp:1689674741050 [07-18 18:05:41:50 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:39599604 ts:0 [07-18 18:05:41:50 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:39599604 [07-18 18:05:41:50 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:414163 dataSize:160 [07-18 18:05:41:50 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:288 timestamp:1689674741050 [07-18 18:05:41:58 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:58 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 9, head index 288 [07-18 18:05:41:58 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 10, seqNo 910, timestamp 1689674731692 [07-18 18:05:41:58 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:83 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:39632937 ts:0 [07-18 18:05:41:84 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:39632937 [07-18 18:05:41:84 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1060599 dataSize:756 [07-18 18:05:41:84 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:289 timestamp:1689674741084 [07-18 18:05:41:84 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:39632937 ts:0 [07-18 18:05:41:84 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:39632937 [07-18 18:05:41:84 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:414323 dataSize:756 [07-18 18:05:41:84 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:289 timestamp:1689674741084 [07-18 18:05:41:117 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:39666270 ts:0 [07-18 18:05:41:117 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:39666270 [07-18 18:05:41:117 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1061355 dataSize:1610 [07-18 18:05:41:117 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:290 timestamp:1689674741117 [07-18 18:05:41:117 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:39666270 ts:0 [07-18 18:05:41:117 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:39666270 [07-18 18:05:41:117 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:415079 dataSize:1610 [07-18 18:05:41:117 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:290 timestamp:1689674741117 [07-18 18:05:41:151 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:39699603 ts:0 [07-18 18:05:41:151 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:39699603 [07-18 18:05:41:151 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1062965 dataSize:516 [07-18 18:05:41:151 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:291 timestamp:1689674741151 [07-18 18:05:41:151 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:39699603 ts:0 [07-18 18:05:41:151 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:39699603 [07-18 18:05:41:151 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:416689 dataSize:516 [07-18 18:05:41:151 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:291 timestamp:1689674741151 [07-18 18:05:41:168 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:168 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 10, head index 291 [07-18 18:05:41:168 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 11, seqNo 911, timestamp 1689674731726 [07-18 18:05:41:168 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:184 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:39732936 ts:0 [07-18 18:05:41:185 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:39732936 [07-18 18:05:41:185 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1063481 dataSize:231 [07-18 18:05:41:185 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:292 timestamp:1689674741185 [07-18 18:05:41:185 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:39732936 ts:0 [07-18 18:05:41:185 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:39732936 [07-18 18:05:41:185 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:417205 dataSize:231 [07-18 18:05:41:185 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:292 timestamp:1689674741185 [07-18 18:05:41:218 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:39766269 ts:0 [07-18 18:05:41:218 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:39766269 [07-18 18:05:41:218 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1063712 dataSize:250 [07-18 18:05:41:218 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:293 timestamp:1689674741218 [07-18 18:05:41:218 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:39766269 ts:0 [07-18 18:05:41:218 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:39766269 [07-18 18:05:41:218 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:417436 dataSize:250 [07-18 18:05:41:218 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:293 timestamp:1689674741218 [07-18 18:05:41:252 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:39799602 ts:0 [07-18 18:05:41:252 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:39799602 [07-18 18:05:41:252 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1063962 dataSize:1143 [07-18 18:05:41:252 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:294 timestamp:1689674741252 [07-18 18:05:41:252 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:39799602 ts:0 [07-18 18:05:41:252 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:39799602 [07-18 18:05:41:252 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:417686 dataSize:1143 [07-18 18:05:41:252 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:294 timestamp:1689674741252 [07-18 18:05:41:278 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:279 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 11, head index 294 [07-18 18:05:41:279 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 12, seqNo 912, timestamp 1689674731759 [07-18 18:05:41:279 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:285 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:39832935 ts:0 [07-18 18:05:41:285 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:39832935 [07-18 18:05:41:285 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1065105 dataSize:383 [07-18 18:05:41:285 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:295 timestamp:1689674741285 [07-18 18:05:41:285 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:39832935 ts:0 [07-18 18:05:41:285 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:39832935 [07-18 18:05:41:285 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:418829 dataSize:383 [07-18 18:05:41:285 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:295 timestamp:1689674741285 [07-18 18:05:41:319 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:39866268 ts:0 [07-18 18:05:41:319 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:39866268 [07-18 18:05:41:319 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1065488 dataSize:235 [07-18 18:05:41:319 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:296 timestamp:1689674741319 [07-18 18:05:41:319 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:39866268 ts:0 [07-18 18:05:41:319 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:39866268 [07-18 18:05:41:319 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:419212 dataSize:235 [07-18 18:05:41:319 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:296 timestamp:1689674741319 [07-18 18:05:41:353 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:39899601 ts:0 [07-18 18:05:41:353 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:39899601 [07-18 18:05:41:353 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1065723 dataSize:165 [07-18 18:05:41:353 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:297 timestamp:1689674741353 [07-18 18:05:41:353 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:39899601 ts:0 [07-18 18:05:41:353 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:39899601 [07-18 18:05:41:353 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:419447 dataSize:165 [07-18 18:05:41:353 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:297 timestamp:1689674741353 [07-18 18:05:41:361 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:41:361 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:41:386 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:39932934 ts:0 [07-18 18:05:41:386 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:39932934 [07-18 18:05:41:386 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1065888 dataSize:457 [07-18 18:05:41:386 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:298 timestamp:1689674741386 [07-18 18:05:41:386 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:39932934 ts:0 [07-18 18:05:41:386 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:39932934 [07-18 18:05:41:386 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:419612 dataSize:457 [07-18 18:05:41:386 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:298 timestamp:1689674741386 [07-18 18:05:41:389 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:389 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 12, head index 298 [07-18 18:05:41:389 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:912->1198) [07-18 18:05:41:389 TUYA Debug][tuya_ring_buffer.c:204] ch0st0tr0 delay too much(seqNo:912->1198) [07-18 18:05:41:389 TUYA Debug][tuya_ring_buffer.c:906] skip to next frame, type(1) node 34 seqNo 934 ch0st0tr0 [07-18 18:05:41:390 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:420 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:39966267 ts:0 [07-18 18:05:41:420 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:39966267 [07-18 18:05:41:420 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1066345 dataSize:673 [07-18 18:05:41:420 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:299 timestamp:1689674741420 [07-18 18:05:41:420 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:39966267 ts:0 [07-18 18:05:41:420 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:39966267 [07-18 18:05:41:420 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:420069 dataSize:673 [07-18 18:05:41:420 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:299 timestamp:1689674741420 [07-18 18:05:41:453 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:39999600 ts:0 [07-18 18:05:41:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:39999600 [07-18 18:05:41:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1067018 dataSize:465 [07-18 18:05:41:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:0 timestamp:1689674741454 [07-18 18:05:41:454 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:39999600 ts:0 [07-18 18:05:41:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:39999600 [07-18 18:05:41:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:420742 dataSize:465 [07-18 18:05:41:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:0 timestamp:1689674741454 [07-18 18:05:41:487 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:40032933 ts:0 [07-18 18:05:41:487 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:40032933 [07-18 18:05:41:487 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1067483 dataSize:248 [07-18 18:05:41:487 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:1 timestamp:1689674741487 [07-18 18:05:41:487 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:40032933 ts:0 [07-18 18:05:41:487 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:40032933 [07-18 18:05:41:487 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:421207 dataSize:248 [07-18 18:05:41:487 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:1 timestamp:1689674741487 [07-18 18:05:41:500 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:500 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 3 node index 34, head index 1 [07-18 18:05:41:500 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 35, seqNo 935, timestamp 1689674732533 [07-18 18:05:41:500 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:521 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:40066266 ts:0 [07-18 18:05:41:521 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:40066266 [07-18 18:05:41:521 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1067731 dataSize:217 [07-18 18:05:41:521 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:2 timestamp:1689674741521 [07-18 18:05:41:521 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:40066266 ts:0 [07-18 18:05:41:521 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:40066266 [07-18 18:05:41:521 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:421455 dataSize:217 [07-18 18:05:41:521 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:2 timestamp:1689674741521 [07-18 18:05:41:554 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:40099599 ts:0 [07-18 18:05:41:554 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:40099599 [07-18 18:05:41:554 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1067948 dataSize:280 [07-18 18:05:41:554 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:3 timestamp:1689674741554 [07-18 18:05:41:554 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:40099599 ts:0 [07-18 18:05:41:554 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:40099599 [07-18 18:05:41:554 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:421672 dataSize:280 [07-18 18:05:41:554 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:3 timestamp:1689674741554 [07-18 18:05:41:588 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:40132932 ts:0 [07-18 18:05:41:588 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:40132932 [07-18 18:05:41:588 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1068228 dataSize:12088 [07-18 18:05:41:588 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:4 timestamp:1689674741588 [07-18 18:05:41:588 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:40132932 ts:0 [07-18 18:05:41:588 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:40132932 [07-18 18:05:41:588 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:421952 dataSize:12088 [07-18 18:05:41:588 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:4 timestamp:1689674741588 [07-18 18:05:41:610 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:610 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 35, head index 4 [07-18 18:05:41:611 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 36, seqNo 936, timestamp 1689674732566 [07-18 18:05:41:611 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:622 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:40166265 ts:0 [07-18 18:05:41:622 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:40166265 [07-18 18:05:41:622 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1080316 dataSize:1051 [07-18 18:05:41:622 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:5 timestamp:1689674741622 [07-18 18:05:41:622 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:40166265 ts:0 [07-18 18:05:41:622 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:40166265 [07-18 18:05:41:622 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:434040 dataSize:1051 [07-18 18:05:41:622 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:5 timestamp:1689674741622 [07-18 18:05:41:655 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:40199598 ts:0 [07-18 18:05:41:655 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:40199598 [07-18 18:05:41:655 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1081367 dataSize:209 [07-18 18:05:41:655 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:6 timestamp:1689674741655 [07-18 18:05:41:655 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:40199598 ts:0 [07-18 18:05:41:655 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:40199598 [07-18 18:05:41:655 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:435091 dataSize:209 [07-18 18:05:41:655 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:6 timestamp:1689674741655 [07-18 18:05:41:689 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:40232931 ts:0 [07-18 18:05:41:689 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:40232931 [07-18 18:05:41:689 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1081576 dataSize:118 [07-18 18:05:41:689 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:7 timestamp:1689674741689 [07-18 18:05:41:689 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:40232931 ts:0 [07-18 18:05:41:689 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:40232931 [07-18 18:05:41:689 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:435300 dataSize:118 [07-18 18:05:41:689 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:7 timestamp:1689674741689 [07-18 18:05:41:721 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:721 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 36, head index 7 [07-18 18:05:41:721 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 37, seqNo 937, timestamp 1689674732600 [07-18 18:05:41:721 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:722 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:40266264 ts:0 [07-18 18:05:41:722 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:40266264 [07-18 18:05:41:722 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1081694 dataSize:110 [07-18 18:05:41:722 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:8 timestamp:1689674741722 [07-18 18:05:41:722 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:40266264 ts:0 [07-18 18:05:41:722 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:40266264 [07-18 18:05:41:722 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:435418 dataSize:110 [07-18 18:05:41:723 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:8 timestamp:1689674741723 [07-18 18:05:41:756 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:40299597 ts:0 [07-18 18:05:41:756 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:40299597 [07-18 18:05:41:756 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1081804 dataSize:695 [07-18 18:05:41:756 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:9 timestamp:1689674741756 [07-18 18:05:41:756 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:40299597 ts:0 [07-18 18:05:41:756 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:40299597 [07-18 18:05:41:756 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:435528 dataSize:695 [07-18 18:05:41:756 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:9 timestamp:1689674741756 [07-18 18:05:41:790 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:40332930 ts:0 [07-18 18:05:41:790 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:40332930 [07-18 18:05:41:790 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1082499 dataSize:1146 [07-18 18:05:41:790 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:10 timestamp:1689674741790 [07-18 18:05:41:790 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:40332930 ts:0 [07-18 18:05:41:790 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:40332930 [07-18 18:05:41:790 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:436223 dataSize:1146 [07-18 18:05:41:790 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:10 timestamp:1689674741790 [07-18 18:05:41:823 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:40366263 ts:0 [07-18 18:05:41:823 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:40366263 [07-18 18:05:41:823 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1083645 dataSize:276 [07-18 18:05:41:823 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:11 timestamp:1689674741823 [07-18 18:05:41:823 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:40366263 ts:0 [07-18 18:05:41:823 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:40366263 [07-18 18:05:41:823 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:437369 dataSize:276 [07-18 18:05:41:823 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:11 timestamp:1689674741823 [07-18 18:05:41:831 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:831 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 37, head index 11 [07-18 18:05:41:831 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 38, seqNo 938, timestamp 1689674732634 [07-18 18:05:41:832 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:857 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:40399596 ts:0 [07-18 18:05:41:857 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:40399596 [07-18 18:05:41:857 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1083921 dataSize:152 [07-18 18:05:41:857 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:12 timestamp:1689674741857 [07-18 18:05:41:857 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:40399596 ts:0 [07-18 18:05:41:857 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:40399596 [07-18 18:05:41:857 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:437645 dataSize:152 [07-18 18:05:41:857 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:12 timestamp:1689674741857 [07-18 18:05:41:890 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:40432929 ts:0 [07-18 18:05:41:891 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:40432929 [07-18 18:05:41:891 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1084073 dataSize:136 [07-18 18:05:41:891 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:13 timestamp:1689674741891 [07-18 18:05:41:891 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:40432929 ts:0 [07-18 18:05:41:891 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:40432929 [07-18 18:05:41:891 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:437797 dataSize:136 [07-18 18:05:41:891 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:13 timestamp:1689674741891 [07-18 18:05:41:924 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:40466262 ts:0 [07-18 18:05:41:924 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:40466262 [07-18 18:05:41:924 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1084209 dataSize:725 [07-18 18:05:41:924 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:14 timestamp:1689674741924 [07-18 18:05:41:924 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:40466262 ts:0 [07-18 18:05:41:924 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:40466262 [07-18 18:05:41:924 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:437933 dataSize:725 [07-18 18:05:41:924 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:14 timestamp:1689674741924 [07-18 18:05:41:942 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:41:942 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 38, head index 14 [07-18 18:05:41:942 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 39, seqNo 939, timestamp 1689674732667 [07-18 18:05:41:942 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:41:958 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:40499595 ts:0 [07-18 18:05:41:958 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:40499595 [07-18 18:05:41:958 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1084934 dataSize:1369 [07-18 18:05:41:958 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:15 timestamp:1689674741958 [07-18 18:05:41:958 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:40499595 ts:0 [07-18 18:05:41:958 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:40499595 [07-18 18:05:41:958 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:438658 dataSize:1369 [07-18 18:05:41:958 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:15 timestamp:1689674741958 [07-18 18:05:41:991 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:40532928 ts:0 [07-18 18:05:41:991 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:40532928 [07-18 18:05:41:991 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1086303 dataSize:367 [07-18 18:05:41:991 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:16 timestamp:1689674741991 [07-18 18:05:41:992 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:40532928 ts:0 [07-18 18:05:41:992 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:40532928 [07-18 18:05:41:992 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:440027 dataSize:367 [07-18 18:05:41:992 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:16 timestamp:1689674741992 [07-18 18:05:42:25 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:40566261 ts:0 [07-18 18:05:42:25 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:40566261 [07-18 18:05:42:25 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1086670 dataSize:141 [07-18 18:05:42:25 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:17 timestamp:1689674742025 [07-18 18:05:42:25 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:40566261 ts:0 [07-18 18:05:42:25 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:40566261 [07-18 18:05:42:25 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:440394 dataSize:141 [07-18 18:05:42:25 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:17 timestamp:1689674742025 [07-18 18:05:42:52 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:42:53 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 39, head index 17 [07-18 18:05:42:53 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 40, seqNo 940, timestamp 1689674732701 [07-18 18:05:42:53 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:42:59 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:40599594 ts:0 [07-18 18:05:42:59 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:40599594 [07-18 18:05:42:59 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1086811 dataSize:160 [07-18 18:05:42:59 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:18 timestamp:1689674742059 [07-18 18:05:42:59 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:40599594 ts:0 [07-18 18:05:42:59 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:40599594 [07-18 18:05:42:59 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:440535 dataSize:160 [07-18 18:05:42:59 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:18 timestamp:1689674742059 [07-18 18:05:42:92 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:40632927 ts:0 [07-18 18:05:42:92 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:40632927 [07-18 18:05:42:92 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1086971 dataSize:756 [07-18 18:05:42:92 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:19 timestamp:1689674742092 [07-18 18:05:42:92 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:40632927 ts:0 [07-18 18:05:42:92 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:40632927 [07-18 18:05:42:92 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:440695 dataSize:756 [07-18 18:05:42:92 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:19 timestamp:1689674742092 [07-18 18:05:42:126 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:40666260 ts:0 [07-18 18:05:42:126 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:40666260 [07-18 18:05:42:126 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1087727 dataSize:1610 [07-18 18:05:42:126 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:20 timestamp:1689674742126 [07-18 18:05:42:126 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:40666260 ts:0 [07-18 18:05:42:126 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:40666260 [07-18 18:05:42:126 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:441451 dataSize:1610 [07-18 18:05:42:126 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:20 timestamp:1689674742126 [07-18 18:05:42:159 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:40699593 ts:0 [07-18 18:05:42:159 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:40699593 [07-18 18:05:42:159 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1089337 dataSize:516 [07-18 18:05:42:160 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:21 timestamp:1689674742160 [07-18 18:05:42:160 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:40699593 ts:0 [07-18 18:05:42:160 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:40699593 [07-18 18:05:42:160 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:443061 dataSize:516 [07-18 18:05:42:160 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:21 timestamp:1689674742160 [07-18 18:05:42:163 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:05:42:163 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 40, head index 21 [07-18 18:05:42:163 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 41, seqNo 941, timestamp 1689674732734 [07-18 18:05:42:163 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:42:193 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:40732926 ts:0 [07-18 18:05:42:193 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:40732926 [07-18 18:05:42:193 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1089853 dataSize:231 [07-18 18:05:42:193 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:22 timestamp:1689674742193 [07-18 18:05:42:193 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:40732926 ts:0 [07-18 18:05:42:193 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:40732926 [07-18 18:05:42:193 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:443577 dataSize:231 [07-18 18:05:42:193 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:22 timestamp:1689674742193 [07-18 18:05:42:226 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [6] low cmd[3] [07-18 18:05:42:226 TUYA Debug][tuya_ipc_p2p.c:2006] session[131073] [1] send video stop to dev [07-18 18:05:42:226 TUYA Debug][tuya_ipc_p2p.c:2013] session[131073] video stop [07-18 18:05:42:273 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:05:42:324 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [6] low cmd[5] [07-18 18:05:42:324 TUYA Debug][tuya_ipc_p2p.c:2100] session[131073] [1] send audio stop to dev [07-18 18:05:42:362 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:42:362 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:43:362 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:43:363 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:44:363 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:44:363 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:44:376 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [100] low cmd[7] [07-18 18:05:44:376 TUYA Debug][tuya_ipc_p2p.c:3082] CTRL PLAY BACK session[131073] high[100] low[7] [07-18 18:05:44:376 TUYA Debug][tuya_ipc_p2p.c:3085] CTRL PLAY BACK session[131073] chn[0] speed[1] [07-18 18:05:44:376 TUYA Err][tuya_ipc_p2p.c:3092] err CTRL PLAY BACK session[131073] chn[0] speed[1] [07-18 18:05:44:437 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [7] low cmd[3] [07-18 18:05:44:437 TUYA Err][tuya_ipc_p2p.c:1726] session[131073] cur cmd[0] [07-18 18:05:44:497 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[131073] higcmd [7] low cmd[5] [07-18 18:05:44:498 TUYA Debug][tuya_ipc_p2p.c:1886] session pb audio stop[131073] [07-18 18:05:44:632 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:44:632 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:44:632 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:05:44:632 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:05:44:632 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:05:44:632 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 78 [07-18 18:05:44:632 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674744,"protocol":302,"data":{"msg":{"handle":2,"seq":6,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674710077"}}} [07-18 18:05:44:632 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:05:44:632 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:05:44:632 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:05:44:632 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c600 [07-18 18:05:44:632 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:05:44:641 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58397 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":2,"error":0,"seq":6}} [07-18 18:05:44:641 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:05:44:653 TUYA Err][tuya_ipc_p2p.c:3667] session[131073] was close by client ret[-11] [07-18 18:05:44:653 TUYA Err][tuya_ipc_p2p.c:3778] session[131073] read cmd failed [-1] [07-18 18:05:44:653 TUYA Debug][tuya_ipc_p2p.c:3547] close session[131073] [07-18 18:05:44:653 TUYA Debug][tuya_ipc_p2p.c:2179] session[131073] cmd[0] status[7] [07-18 18:05:44:653 TUYA Err][tuya_ipc_p2p.c:2534] speaker not start [07-18 18:05:44:654 TUYA Err][tuya_ipc_p2p.c:3628] session[131073] is try to releasing [07-18 18:05:44:654 TUYA Debug][tuya_ipc_p2p.c:5134] session[131073] __p2p_wait_concurr_idle start [07-18 18:05:44:657 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:44:684 TUYA Debug][tuya_ipc_p2p.c:5151] session[131073] concurr idle[2][2] [07-18 18:05:44:684 TUYA Debug][tuya_ipc_p2p.c:5157] session[131073] __p2p_wait_concurr_idle end [07-18 18:05:44:684 TUYA Debug][tuya_ipc_p2p.c:4100] session[131073] playback_send_video start release [07-18 18:05:44:684 TUYA Debug][tuya_ipc_p2p.c:3576] release source [131073] [07-18 18:05:44:684 TUYA Debug][tuya_ipc_p2p.c:3616] release va session[131073] [07-18 18:05:44:684 TUYA Debug][tuya_ipc_p2p.c:4102] session[0] closed [07-18 18:05:44:822 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:05:44:822 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:05:44:822 TUYA Trace][iot_httpc.c:940] api[tuya.device.log.report] hash[0x9f81e2a5] [07-18 18:05:44:822 TUYA Debug][iot_httpc.c:984] Post Data: {"type":"tuya_p2p_log","data":"{\"type\":\"connection\",\"connection_type\":\"kcp\",\"session_id\":\"6c9127b907229c12a5bqfi1689674678SjKMLgf7\",\"trace_id\":\"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552\",\"moto_id\":\"\",\"session_handle\":1,\"active_handle\":2,\"role\":\"callee\",\"local_id\":\"6c9127b907229c12a5bqfi\",\"remote_id\":\"ay1689142558741Q9RvD\",\"dev_id\":\"\",\"local_p2p_skill\":35,\"remote_p2p_skill\":99,\"preconnect\":true,\"sdk_version\":\"tuya_p2p_sdk_v3.4.3\",\"activate\":{\"channel_info\":{\"write_bytes\":[352,429616,0,0,0,0,284],\"read_bytes\":[568,0,0,0,0,0,0],\"send_bytes\":[304,429616,0,0,0,0,-20],\"recv_bytes\":[568,0,0,0,0,0,0],\"socket_send_bytes\":[1136,472040,0,0,0,0,59160],\"socket_recv_bytes\":[1640,9768,0,0,0,0,0],\"first_send_time_ms\":[73,345,-1,-1,-1,-1,1],\"first_write_time_ms\":[70,345,-1,-1,-1,-1,0],\"first_read_time_ms\":[31,-1,-1,-1,-1,-1,-1],\"first_read_try_time_ms\":[1,-1,-1,-1,-1,-1,-1],\"first_da [07-18 18:05:44:822 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674744&v=1.0&sign=93b2cf7231c3ca1f10a49d38abe55fe3 [07-18 18:05:44:822 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:05:44:822 TUYA Trace][httpc.c:663] No port number given [07-18 18:05:44:822 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674744&v=1.0&sign=93b2cf7231c3ca1f10a49d38abe55fe3 [07-18 18:05:44:822 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 18:05:44:822 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 18:05:44:822 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 18:05:44:822 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 18:05:44:822 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 18:05:44:822 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 18:05:44:822 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 18:05:44:844 TUYA Trace][httpc.c:560] Connected .. sockfd: 65 [07-18 18:05:44:844 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 18:05:44:844 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 18:05:44:844 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 18:05:44:844 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 18:05:44:844 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 18:05:44:844 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 18:05:44:874 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 18:05:44:874 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 18:05:44:874 TUYA Trace][httpc.c:952] Have to extract [07-18 18:05:44:874 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:05:44:874 TUYA Trace][httpc.c:663] No port number given [07-18 18:05:44:874 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674744&v=1.0&sign=93b2cf7231c3ca1f10a49d38abe55fe3 [07-18 18:05:44:874 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 18:05:44:874 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674744&v=1.0&sign=93b2cf7231c3ca1f10a49d38abe55fe3 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 2213 [07-18 18:05:44:874 TUYA Trace][httpc.c:996] content len:2213 [07-18 18:05:44:874 TUYA Trace][httpc.c:343] Start header read [07-18 18:05:44:927 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 18:05:44:927 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: 8e9f0aa2618b4fb9ac2d4708c2583427 content-type: application/json;charset=UTF-8 content-length: 119 date: Tue, 18 Jul 2023 10:05:44 GMT server: https {"result":"ZeQSvBEdHjHl1j5RF4jn6KoC4AivL4PkqJGHJsDkU8sEQif8+0oQ6avZeQooIEYp","sign":"799454e47e11d7b2","t":1689674745} [07-18 18:05:44:927 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 18:05:44:927 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 305 bytes header [07-18 18:05:44:927 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:120 [07-18 18:05:44:927 TUYA Trace][httpc.c:1748] contentlen:119 size_remain:119 size_to_read:119 [07-18 18:05:44:927 TUYA Trace][httpc.c:425] Using prefetch: 186 119 119 119 [07-18 18:05:44:927 TUYA Trace][iot_httpc.c:807] RESP:{"result":"ZeQSvBEdHjHl1j5RF4jn6KoC4AivL4PkqJGHJsDkU8sEQif8+0oQ6avZeQooIEYp","sign":"799454e47e11d7b2","t":1689674745} [07-18 18:05:44:927 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 18:05:44:927 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":true,"t":1689674745,"success":true} [07-18 18:05:45:1 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 18:05:45:1 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 18:05:45:731 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:45:731 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:46:663 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [102000] [07-18 18:05:46:732 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:46:732 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:47:733 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:47:733 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:48:653 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:05:48:734 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:48:734 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:49:189 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:05:49:189 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:36 [07-18 18:05:49:190 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:05:49:215 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[4]lstCnt[145]vIFrameCnt[145] [07-18 18:05:49:735 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:49:735 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:50:736 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:50:736 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:51:737 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:51:737 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:51:770 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [103000] [07-18 18:05:52:738 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:52:738 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:53:339 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:05:53:740 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:53:740 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:54:741 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:54:741 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:55:742 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:55:742 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:56:743 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:56:743 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:56:861 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [104000] [07-18 18:05:57:745 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:57:745 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:58:661 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:05:58:746 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:58:746 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:05:59:222 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[5]lstCnt[145]vIFrameCnt[145] [07-18 18:05:59:747 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:05:59:747 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:00:748 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:00:748 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:01:749 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:01:749 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:01:960 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [105000] [07-18 18:06:02:750 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:02:750 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:03:751 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:03:751 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:04:193 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:06:04:193 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:04:193 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:37 [07-18 18:06:04:752 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:04:752 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:05:753 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:05:753 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:06:754 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:06:754 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:07:67 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [106000] [07-18 18:06:07:754 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:07:754 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:08:668 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:06:08:759 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:08:759 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:09:230 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[6]lstCnt[145]vIFrameCnt[145] [07-18 18:06:09:760 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:09:760 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:10:760 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:10:761 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:11:761 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:11:761 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:12:170 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [107000] [07-18 18:06:12:762 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:12:762 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:13:340 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:06:13:340 TUYA Debug][tuya_devos_health.c:255] checking device health, prev stat:1, reason:0 [07-18 18:06:13:340 TUYA Debug][tuya_devos_health.c:179] tuya device health check finish, status is 1, reason is 0 [07-18 18:06:13:340 TUYA Debug][tuya_devos_health.c:180] cur free heap: -1 [07-18 18:06:13:340 TUYA Debug][tuya_devos_health.c:182] cur workq depth: 0, msgq depth: 0, timeq depth: 7 [07-18 18:06:13:340 TUYA Trace][uni_work_queue.c:154] work_queue add task:c0008c0 [07-18 18:06:13:340 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:13:763 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:13:763 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:14:764 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:14:764 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:15:765 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:15:765 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:16:766 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:16:766 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:17:300 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [108000] [07-18 18:06:17:767 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:17:767 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:17:916 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:17:916 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:17:916 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:17:916 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:17:916 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:17:916 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:17:949 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58398 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:17:949 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:17:990 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:17:990 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:17:990 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:17:991 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:17:991 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674777, rept_cnt:1. [07-18 18:06:17:991 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674777, rept_cnt:0. [07-18 18:06:17:991 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674777, rept_cnt:0. [07-18 18:06:17:991 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:17:991 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:17:991 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:17:998 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:17:998 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:17:998 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:18:30 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:18:42 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58399 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:18:42 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:18:50 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:18:63 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:18:63 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:18:63 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:18:74 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:18:74 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674778, rept_cnt:2. [07-18 18:06:18:74 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674778, rept_cnt:0. [07-18 18:06:18:74 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674778, rept_cnt:0. [07-18 18:06:18:91 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:18:674 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:06:19:92 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:19:92 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:19:195 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:06:19:195 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:19:195 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:38 [07-18 18:06:19:238 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[0]lstCnt[173]vIFrameCnt[173] [07-18 18:06:19:490 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[17] [07-18 18:06:19:954 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:19:954 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:19:954 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:19:954 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:19:954 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:19:954 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:19:986 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58400 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:19:986 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:20:12 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:20:12 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:20:12 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:20:12 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:20:12 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674780, rept_cnt:3. [07-18 18:06:20:12 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674780, rept_cnt:0. [07-18 18:06:20:12 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674780, rept_cnt:0. [07-18 18:06:20:13 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:20:13 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:20:13 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:20:20 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:20:20 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:20:20 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:20:39 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:20:46 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58401 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:20:46 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:20:75 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:20:75 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:20:75 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:20:75 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:20:75 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674780, rept_cnt:4. [07-18 18:06:20:75 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674780, rept_cnt:0. [07-18 18:06:20:75 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674780, rept_cnt:0. [07-18 18:06:20:89 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:20:99 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:21:100 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:21:100 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:22:100 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:22:100 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:22:453 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [109000] [07-18 18:06:23:101 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:23:101 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:23:125 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[21] [07-18 18:06:24:102 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:24:102 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:25:103 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:25:103 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:25:139 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:25:139 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:25:139 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:25:139 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:25:139 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:25:139 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:25:168 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58402 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:25:168 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:25:274 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:25:274 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:25:274 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:25:282 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:25:282 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674785, rept_cnt:5. [07-18 18:06:25:282 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674785, rept_cnt:0. [07-18 18:06:25:282 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674785, rept_cnt:0. [07-18 18:06:25:282 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:25:282 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:25:282 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:25:282 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:25:282 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:25:282 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:25:301 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:25:309 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58403 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:25:309 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:25:467 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:25:467 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:25:467 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:25:467 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:25:467 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674785, rept_cnt:6. [07-18 18:06:25:467 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674785, rept_cnt:0. [07-18 18:06:25:467 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674785, rept_cnt:0. [07-18 18:06:25:490 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:26:492 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:26:492 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:27:493 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:27:493 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:27:586 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [110000] [07-18 18:06:27:892 TUYA Debug][mqtt_client.c:229] mqtt_ping -->> [07-18 18:06:27:892 TUYA Debug][mqtt_client.c:247] mqtt_ping <<-- [07-18 18:06:27:910 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:27:910 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:27:910 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:27:910 TUYA Debug][mqtt_client.c:1294] ping respond. update fail_cnt:0 [07-18 18:06:27:942 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:28:357 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:28:358 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:28:358 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:28:358 TUYA Debug][smart_frame.c:353] dp<17> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:06:28:358 TUYA Debug][smart_frame.c:369] dp_cntl value:8881, dp_data value:8880 [07-18 18:06:28:358 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:28:358 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"17":8880} [07-18 18:06:28:382 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58404 Q:1 Data:{"dps":{"17":8880}} [07-18 18:06:28:382 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:28:401 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:28:401 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:28:401 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:28:401 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 18:06:28:401 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"17":8880}}, mqtt async dp cb:0 [07-18 18:06:28:401 TUYA Trace][smart_frame.c:2512] DP ID 17 Set To 3 [07-18 18:06:28:401 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:17, curr_t:1689674788, rept_cnt:1. [07-18 18:06:28:401 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:17, curr_t:1689674788, rept_cnt:0. [07-18 18:06:28:401 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:17, curr_t:1689674788, rept_cnt:0. [07-18 18:06:28:425 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:28:681 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:06:29:250 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[0]lstCnt[220]vIFrameCnt[220] [07-18 18:06:29:425 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:29:425 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:30:401 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:30:401 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:30:401 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:30:401 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:30:401 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:30:401 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:30:426 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58405 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:30:426 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:30:426 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:30:426 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:30:449 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:30:449 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:30:449 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:30:449 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:30:449 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674790, rept_cnt:7. [07-18 18:06:30:449 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674790, rept_cnt:0. [07-18 18:06:30:449 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674790, rept_cnt:0. [07-18 18:06:30:449 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:30:449 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:30:449 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:30:457 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:30:457 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:30:457 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:30:476 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:30:484 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58406 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:30:484 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:30:504 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:30:505 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:30:505 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:30:505 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:30:505 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674790, rept_cnt:8. [07-18 18:06:30:505 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674790, rept_cnt:0. [07-18 18:06:30:505 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674790, rept_cnt:0. [07-18 18:06:30:528 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:31:529 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:31:529 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:32:530 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:32:530 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:32:719 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [111000] [07-18 18:06:33:340 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:06:33:531 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:33:531 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:34:196 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:06:34:196 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:34:196 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:39 [07-18 18:06:34:532 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:34:532 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:35:533 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:35:533 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:35:548 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:35:549 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[25] [07-18 18:06:35:714 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:35:714 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:35:714 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:35:714 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:35:714 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:35:714 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:35:741 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58407 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:35:741 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:35:763 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:35:763 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:35:763 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:35:763 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:35:763 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674795, rept_cnt:9. [07-18 18:06:35:763 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674795, rept_cnt:0. [07-18 18:06:35:763 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674795, rept_cnt:0. [07-18 18:06:35:763 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:35:763 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:35:763 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:35:771 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:35:771 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:35:771 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:35:789 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:35:797 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58408 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:35:797 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:35:811 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:35:812 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[29] [07-18 18:06:35:821 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:35:822 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:35:822 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:35:822 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:35:822 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674795, rept_cnt:10. [07-18 18:06:35:822 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674795, rept_cnt:0. [07-18 18:06:35:822 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674795, rept_cnt:0. [07-18 18:06:35:846 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:36:74 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:36:645 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:36:645 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:36:645 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:36:645 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:36:645 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:36:645 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 79 [07-18 18:06:36:645 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674796,"protocol":302,"data":{"msg":{"handle":3,"seq":7},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"activate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674796706"}}} [07-18 18:06:36:645 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:36:645 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:36:645 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:36:646 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c500 [07-18 18:06:36:646 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:36:654 TUYA Debug][tuya_ipc_p2p.c:4512] listen ok session[196609] [07-18 18:06:36:654 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58409 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"activate_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":3,"error":0,"seq":7}} [07-18 18:06:36:654 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:36:670 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:36:704 TUYA Debug][tuya_ipc_p2p.c:3987] compare passwd [07-18 18:06:36:704 TUYA Debug][tuya_ipc_p2p.c:3988] get ipc auth gw_local_key[Mro9dY$MHLv!DTHz]p2p_passwd[adb63309] [07-18 18:06:36:704 TUYA Debug][tuya_ipc_p2p.c:4006] Client Auth admin efa628a6c8b8f6f591f69df58cfba471 <-> admin adb63309 [07-18 18:06:36:704 TUYA Debug][tuya_ipc_p2p.c:4007] localkey:Mro9dY$MHLv!DTHz final:efa628a6c8b8f6f591f69df58cfba471 [07-18 18:06:36:704 TUYA Debug][tuya_ipc_p2p.c:4010] auth success [07-18 18:06:36:704 TUYA Debug][tuya_ipc_p2p.c:592] __p2p_get_idle_session begin [07-18 18:06:36:704 TUYA Debug][tuya_ipc_p2p.c:4624] create p2p sessions. cur online session num = 2 [07-18 18:06:36:704 TUYA Debug][tuya_ipc_p2p.c:4445] mqtt p2p LISTEN session........ [07-18 18:06:36:808 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [10] low cmd[0] [07-18 18:06:36:869 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [2] low cmd[0] [07-18 18:06:36:929 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [9] low cmd[0] [07-18 18:06:36:992 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [9] low cmd[0] [07-18 18:06:37:53 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [6] low cmd[0] [07-18 18:06:37:53 TUYA Debug][tuya_ipc_p2p.c:1911] open ringbuff handle[(nil)] stream[0] [07-18 18:06:37:53 TUYA Debug][tuya_ipc_p2p.c:1946] session[196609]video video_start wait_concurr_idle [07-18 18:06:37:53 TUYA Debug][tuya_ipc_p2p.c:5134] session[196609] __p2p_wait_concurr_idle start [07-18 18:06:37:83 TUYA Debug][tuya_ipc_p2p.c:5151] session[196609] concurr idle[2][2] [07-18 18:06:37:83 TUYA Debug][tuya_ipc_p2p.c:5157] session[196609] __p2p_wait_concurr_idle end [07-18 18:06:37:83 TUYA Debug][tuya_ipc_p2p.c:1978] session[196609] [1] send video start to dev [07-18 18:06:37:84 TUYA Debug][tuya_ipc_p2p.c:1984] session video start[196609] [07-18 18:06:37:84 TUYA Debug][linkbey_sdk_v11.cpp:573] start live video using /oem/ros_file/demo7_video.264 [07-18 18:06:37:84 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:40766259 ts:0 [07-18 18:06:37:84 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:40766259 [07-18 18:06:37:84 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1090084 dataSize:12088 [07-18 18:06:37:84 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:23 timestamp:1689674797084 [07-18 18:06:37:84 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:40766259 ts:0 [07-18 18:06:37:84 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:40766259 [07-18 18:06:37:84 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:443808 dataSize:12088 [07-18 18:06:37:84 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:84 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 0 node index 0, head index 23 [07-18 18:06:37:84 TUYA Trace][tuya_ring_buffer.c:800] get latest frame node type 1 [07-18 18:06:37:84 TUYA Debug][tuya_ring_buffer.c:806] get latest I frame success, node 23 seqNo 1223 ch0st0tr0 [07-18 18:06:37:84 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:23 timestamp:1689674797084 [07-18 18:06:37:85 TUYA Debug][tuya_ipc_p2p.c:4169] session[196609] I Frame Send ok len[12088] pts[40766259] count[1]timestamp[1689674797084] [07-18 18:06:37:85 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:85 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 23, head index 23 [07-18 18:06:37:95 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:95 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 23, head index 23 [07-18 18:06:37:105 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:105 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 23, head index 23 [07-18 18:06:37:115 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:115 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 23, head index 23 [07-18 18:06:37:118 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:40799592 ts:0 [07-18 18:06:37:118 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:40799592 [07-18 18:06:37:118 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1102172 dataSize:1051 [07-18 18:06:37:118 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:24 timestamp:1689674797118 [07-18 18:06:37:118 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:40799592 ts:0 [07-18 18:06:37:118 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:40799592 [07-18 18:06:37:118 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:455896 dataSize:1051 [07-18 18:06:37:118 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:24 timestamp:1689674797118 [07-18 18:06:37:126 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:126 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 23, head index 24 [07-18 18:06:37:126 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 24, seqNo 1224, timestamp 1689674797118 [07-18 18:06:37:126 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:126 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 24, head index 24 [07-18 18:06:37:136 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:136 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 24, head index 24 [07-18 18:06:37:144 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [6] low cmd[4] [07-18 18:06:37:144 TUYA Debug][tuya_ipc_p2p.c:2041] session[196609] [1] send audio start to dev [07-18 18:06:37:146 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:146 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 24, head index 24 [07-18 18:06:37:151 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:40832925 ts:0 [07-18 18:06:37:151 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:40832925 [07-18 18:06:37:151 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1103223 dataSize:209 [07-18 18:06:37:151 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:25 timestamp:1689674797151 [07-18 18:06:37:151 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:40832925 ts:0 [07-18 18:06:37:151 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:40832925 [07-18 18:06:37:151 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:456947 dataSize:209 [07-18 18:06:37:151 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:25 timestamp:1689674797151 [07-18 18:06:37:156 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:37:185 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:40866258 ts:0 [07-18 18:06:37:185 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:40866258 [07-18 18:06:37:185 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1103432 dataSize:118 [07-18 18:06:37:185 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:26 timestamp:1689674797185 [07-18 18:06:37:185 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:40866258 ts:0 [07-18 18:06:37:185 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:40866258 [07-18 18:06:37:185 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:457156 dataSize:118 [07-18 18:06:37:185 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:26 timestamp:1689674797185 [07-18 18:06:37:219 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:40899591 ts:0 [07-18 18:06:37:219 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:40899591 [07-18 18:06:37:219 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1103550 dataSize:110 [07-18 18:06:37:219 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:27 timestamp:1689674797219 [07-18 18:06:37:219 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:40899591 ts:0 [07-18 18:06:37:219 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:40899591 [07-18 18:06:37:219 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:457274 dataSize:110 [07-18 18:06:37:219 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:27 timestamp:1689674797219 [07-18 18:06:37:252 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:40932924 ts:0 [07-18 18:06:37:252 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:40932924 [07-18 18:06:37:252 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1103660 dataSize:695 [07-18 18:06:37:252 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:28 timestamp:1689674797252 [07-18 18:06:37:252 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:40932924 ts:0 [07-18 18:06:37:252 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:40932924 [07-18 18:06:37:252 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:457384 dataSize:695 [07-18 18:06:37:252 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:28 timestamp:1689674797252 [07-18 18:06:37:266 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:266 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 24, head index 28 [07-18 18:06:37:266 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 25, seqNo 1225, timestamp 1689674797151 [07-18 18:06:37:267 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:37:286 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:40966257 ts:0 [07-18 18:06:37:286 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:40966257 [07-18 18:06:37:286 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1104355 dataSize:1146 [07-18 18:06:37:286 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:29 timestamp:1689674797286 [07-18 18:06:37:286 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:40966257 ts:0 [07-18 18:06:37:286 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:40966257 [07-18 18:06:37:286 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:458079 dataSize:1146 [07-18 18:06:37:286 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:29 timestamp:1689674797286 [07-18 18:06:37:320 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:40999590 ts:0 [07-18 18:06:37:320 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:40999590 [07-18 18:06:37:320 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1105501 dataSize:276 [07-18 18:06:37:320 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:30 timestamp:1689674797320 [07-18 18:06:37:320 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:40999590 ts:0 [07-18 18:06:37:320 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:40999590 [07-18 18:06:37:320 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:459225 dataSize:276 [07-18 18:06:37:320 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:30 timestamp:1689674797320 [07-18 18:06:37:353 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:41032923 ts:0 [07-18 18:06:37:353 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:41032923 [07-18 18:06:37:353 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1105777 dataSize:152 [07-18 18:06:37:353 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:31 timestamp:1689674797353 [07-18 18:06:37:353 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:41032923 ts:0 [07-18 18:06:37:353 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:41032923 [07-18 18:06:37:353 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:459501 dataSize:152 [07-18 18:06:37:353 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:31 timestamp:1689674797353 [07-18 18:06:37:377 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:377 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 25, head index 31 [07-18 18:06:37:377 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 26, seqNo 1226, timestamp 1689674797185 [07-18 18:06:37:377 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:37:387 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:41066256 ts:0 [07-18 18:06:37:387 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:41066256 [07-18 18:06:37:387 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1105929 dataSize:136 [07-18 18:06:37:387 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:32 timestamp:1689674797387 [07-18 18:06:37:387 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:41066256 ts:0 [07-18 18:06:37:387 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:41066256 [07-18 18:06:37:387 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:459653 dataSize:136 [07-18 18:06:37:387 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:32 timestamp:1689674797387 [07-18 18:06:37:420 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:41099589 ts:0 [07-18 18:06:37:420 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:41099589 [07-18 18:06:37:420 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1106065 dataSize:725 [07-18 18:06:37:420 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:33 timestamp:1689674797420 [07-18 18:06:37:420 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:41099589 ts:0 [07-18 18:06:37:420 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:41099589 [07-18 18:06:37:420 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:459789 dataSize:725 [07-18 18:06:37:421 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:33 timestamp:1689674797421 [07-18 18:06:37:454 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:41132922 ts:0 [07-18 18:06:37:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:41132922 [07-18 18:06:37:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1106790 dataSize:1369 [07-18 18:06:37:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:34 timestamp:1689674797454 [07-18 18:06:37:454 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:41132922 ts:0 [07-18 18:06:37:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:41132922 [07-18 18:06:37:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:460514 dataSize:1369 [07-18 18:06:37:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:34 timestamp:1689674797454 [07-18 18:06:37:487 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:487 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 26, head index 34 [07-18 18:06:37:487 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 27, seqNo 1227, timestamp 1689674797219 [07-18 18:06:37:487 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:37:488 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:41166255 ts:0 [07-18 18:06:37:488 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:41166255 [07-18 18:06:37:488 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1108159 dataSize:367 [07-18 18:06:37:488 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:35 timestamp:1689674797488 [07-18 18:06:37:488 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:41166255 ts:0 [07-18 18:06:37:488 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:41166255 [07-18 18:06:37:488 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:461883 dataSize:367 [07-18 18:06:37:488 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:35 timestamp:1689674797488 [07-18 18:06:37:521 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:41199588 ts:0 [07-18 18:06:37:521 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:41199588 [07-18 18:06:37:521 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1108526 dataSize:141 [07-18 18:06:37:521 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:36 timestamp:1689674797521 [07-18 18:06:37:521 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:41199588 ts:0 [07-18 18:06:37:521 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:41199588 [07-18 18:06:37:521 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:462250 dataSize:141 [07-18 18:06:37:521 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:36 timestamp:1689674797521 [07-18 18:06:37:555 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:41232921 ts:0 [07-18 18:06:37:555 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:41232921 [07-18 18:06:37:555 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1108667 dataSize:160 [07-18 18:06:37:555 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:37 timestamp:1689674797555 [07-18 18:06:37:555 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:41232921 ts:0 [07-18 18:06:37:555 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:41232921 [07-18 18:06:37:555 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:462391 dataSize:160 [07-18 18:06:37:555 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:37 timestamp:1689674797555 [07-18 18:06:37:588 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:41266254 ts:0 [07-18 18:06:37:588 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:41266254 [07-18 18:06:37:588 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1108827 dataSize:756 [07-18 18:06:37:589 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:38 timestamp:1689674797589 [07-18 18:06:37:589 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:41266254 ts:0 [07-18 18:06:37:589 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:41266254 [07-18 18:06:37:589 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:462551 dataSize:756 [07-18 18:06:37:589 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:38 timestamp:1689674797589 [07-18 18:06:37:597 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:598 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 27, head index 38 [07-18 18:06:37:598 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 28, seqNo 1228, timestamp 1689674797252 [07-18 18:06:37:598 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:37:622 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:41299587 ts:0 [07-18 18:06:37:622 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:41299587 [07-18 18:06:37:622 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1109583 dataSize:1610 [07-18 18:06:37:622 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:39 timestamp:1689674797622 [07-18 18:06:37:622 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:41299587 ts:0 [07-18 18:06:37:622 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:41299587 [07-18 18:06:37:622 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:463307 dataSize:1610 [07-18 18:06:37:622 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:39 timestamp:1689674797622 [07-18 18:06:37:656 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:41332920 ts:0 [07-18 18:06:37:656 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:41332920 [07-18 18:06:37:656 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1111193 dataSize:516 [07-18 18:06:37:656 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:40 timestamp:1689674797656 [07-18 18:06:37:656 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:41332920 ts:0 [07-18 18:06:37:656 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:41332920 [07-18 18:06:37:656 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:464917 dataSize:516 [07-18 18:06:37:656 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:40 timestamp:1689674797656 [07-18 18:06:37:671 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:37:671 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:37:689 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:41366253 ts:0 [07-18 18:06:37:689 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:41366253 [07-18 18:06:37:689 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1111709 dataSize:231 [07-18 18:06:37:689 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:41 timestamp:1689674797689 [07-18 18:06:37:689 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:41366253 ts:0 [07-18 18:06:37:689 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:41366253 [07-18 18:06:37:689 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:465433 dataSize:231 [07-18 18:06:37:689 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:41 timestamp:1689674797689 [07-18 18:06:37:708 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:708 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 28, head index 41 [07-18 18:06:37:708 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 29, seqNo 1229, timestamp 1689674797286 [07-18 18:06:37:708 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:37:723 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:41399586 ts:0 [07-18 18:06:37:723 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:41399586 [07-18 18:06:37:723 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1111940 dataSize:250 [07-18 18:06:37:723 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:42 timestamp:1689674797723 [07-18 18:06:37:723 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:41399586 ts:0 [07-18 18:06:37:723 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:41399586 [07-18 18:06:37:723 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:465664 dataSize:250 [07-18 18:06:37:723 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:42 timestamp:1689674797723 [07-18 18:06:37:756 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:41432919 ts:0 [07-18 18:06:37:756 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:41432919 [07-18 18:06:37:756 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1112190 dataSize:1143 [07-18 18:06:37:757 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:43 timestamp:1689674797757 [07-18 18:06:37:757 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:41432919 ts:0 [07-18 18:06:37:757 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:41432919 [07-18 18:06:37:757 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:465914 dataSize:1143 [07-18 18:06:37:757 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:43 timestamp:1689674797757 [07-18 18:06:37:790 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:41466252 ts:0 [07-18 18:06:37:790 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:41466252 [07-18 18:06:37:790 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1113333 dataSize:383 [07-18 18:06:37:790 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:44 timestamp:1689674797790 [07-18 18:06:37:790 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:41466252 ts:0 [07-18 18:06:37:790 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:41466252 [07-18 18:06:37:790 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:467057 dataSize:383 [07-18 18:06:37:790 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:44 timestamp:1689674797790 [07-18 18:06:37:818 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:818 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 29, head index 44 [07-18 18:06:37:819 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 30, seqNo 1230, timestamp 1689674797320 [07-18 18:06:37:819 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:37:824 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:41499585 ts:0 [07-18 18:06:37:824 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:41499585 [07-18 18:06:37:824 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1113716 dataSize:235 [07-18 18:06:37:824 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:45 timestamp:1689674797824 [07-18 18:06:37:824 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:41499585 ts:0 [07-18 18:06:37:824 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:41499585 [07-18 18:06:37:824 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:467440 dataSize:235 [07-18 18:06:37:824 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:45 timestamp:1689674797824 [07-18 18:06:37:857 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:41532918 ts:0 [07-18 18:06:37:857 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:41532918 [07-18 18:06:37:858 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1113951 dataSize:165 [07-18 18:06:37:858 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:46 timestamp:1689674797858 [07-18 18:06:37:858 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:41532918 ts:0 [07-18 18:06:37:858 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:41532918 [07-18 18:06:37:858 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:467675 dataSize:165 [07-18 18:06:37:858 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:46 timestamp:1689674797858 [07-18 18:06:37:891 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:41566251 ts:0 [07-18 18:06:37:891 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:41566251 [07-18 18:06:37:891 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1114116 dataSize:457 [07-18 18:06:37:891 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:47 timestamp:1689674797891 [07-18 18:06:37:891 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:41566251 ts:0 [07-18 18:06:37:891 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:41566251 [07-18 18:06:37:891 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:467840 dataSize:457 [07-18 18:06:37:891 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:47 timestamp:1689674797891 [07-18 18:06:37:925 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:41599584 ts:0 [07-18 18:06:37:925 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:41599584 [07-18 18:06:37:925 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1114573 dataSize:673 [07-18 18:06:37:925 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:48 timestamp:1689674797925 [07-18 18:06:37:925 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:41599584 ts:0 [07-18 18:06:37:925 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:41599584 [07-18 18:06:37:925 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:468297 dataSize:673 [07-18 18:06:37:925 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:48 timestamp:1689674797925 [07-18 18:06:37:929 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:37:929 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 30, head index 48 [07-18 18:06:37:929 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 31, seqNo 1231, timestamp 1689674797353 [07-18 18:06:37:929 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:37:960 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:41632917 ts:0 [07-18 18:06:37:960 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:41632917 [07-18 18:06:37:960 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1115246 dataSize:465 [07-18 18:06:37:961 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:49 timestamp:1689674797961 [07-18 18:06:37:961 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:41632917 ts:0 [07-18 18:06:37:961 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:41632917 [07-18 18:06:37:961 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:468970 dataSize:465 [07-18 18:06:37:961 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:49 timestamp:1689674797961 [07-18 18:06:37:994 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:41666250 ts:0 [07-18 18:06:37:994 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:41666250 [07-18 18:06:37:994 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1115711 dataSize:248 [07-18 18:06:37:994 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:50 timestamp:1689674797994 [07-18 18:06:37:994 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:41666250 ts:0 [07-18 18:06:37:994 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:41666250 [07-18 18:06:37:994 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:469435 dataSize:248 [07-18 18:06:37:994 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:50 timestamp:1689674797994 [07-18 18:06:38:28 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:41699583 ts:0 [07-18 18:06:38:28 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:41699583 [07-18 18:06:38:28 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1115959 dataSize:217 [07-18 18:06:38:28 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:51 timestamp:1689674798028 [07-18 18:06:38:28 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:41699583 ts:0 [07-18 18:06:38:28 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:41699583 [07-18 18:06:38:28 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:469683 dataSize:217 [07-18 18:06:38:28 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:51 timestamp:1689674798028 [07-18 18:06:38:39 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:39 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 31, head index 51 [07-18 18:06:38:39 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 32, seqNo 1232, timestamp 1689674797387 [07-18 18:06:38:39 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:62 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:41732916 ts:0 [07-18 18:06:38:62 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:41732916 [07-18 18:06:38:62 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1116176 dataSize:280 [07-18 18:06:38:62 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:52 timestamp:1689674798062 [07-18 18:06:38:62 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:41732916 ts:0 [07-18 18:06:38:62 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:41732916 [07-18 18:06:38:62 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:469900 dataSize:280 [07-18 18:06:38:62 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:52 timestamp:1689674798062 [07-18 18:06:38:95 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:41766249 ts:0 [07-18 18:06:38:95 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:41766249 [07-18 18:06:38:95 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1116456 dataSize:12088 [07-18 18:06:38:95 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:53 timestamp:1689674798095 [07-18 18:06:38:95 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:41766249 ts:0 [07-18 18:06:38:95 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:41766249 [07-18 18:06:38:95 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:470180 dataSize:12088 [07-18 18:06:38:95 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:53 timestamp:1689674798095 [07-18 18:06:38:129 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:41799582 ts:0 [07-18 18:06:38:129 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:41799582 [07-18 18:06:38:129 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1128544 dataSize:1051 [07-18 18:06:38:129 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:54 timestamp:1689674798129 [07-18 18:06:38:129 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:41799582 ts:0 [07-18 18:06:38:129 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:41799582 [07-18 18:06:38:129 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:482268 dataSize:1051 [07-18 18:06:38:129 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:54 timestamp:1689674798129 [07-18 18:06:38:150 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:150 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 32, head index 54 [07-18 18:06:38:150 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 33, seqNo 1233, timestamp 1689674797420 [07-18 18:06:38:150 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:162 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:41832915 ts:0 [07-18 18:06:38:163 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:41832915 [07-18 18:06:38:163 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1129595 dataSize:209 [07-18 18:06:38:163 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:55 timestamp:1689674798163 [07-18 18:06:38:163 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:41832915 ts:0 [07-18 18:06:38:163 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:41832915 [07-18 18:06:38:163 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:483319 dataSize:209 [07-18 18:06:38:163 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:55 timestamp:1689674798163 [07-18 18:06:38:196 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:41866248 ts:0 [07-18 18:06:38:196 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:41866248 [07-18 18:06:38:196 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1129804 dataSize:118 [07-18 18:06:38:196 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:56 timestamp:1689674798196 [07-18 18:06:38:196 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:41866248 ts:0 [07-18 18:06:38:196 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:41866248 [07-18 18:06:38:196 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:483528 dataSize:118 [07-18 18:06:38:196 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:56 timestamp:1689674798196 [07-18 18:06:38:230 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:41899581 ts:0 [07-18 18:06:38:230 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:41899581 [07-18 18:06:38:230 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1129922 dataSize:110 [07-18 18:06:38:230 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:57 timestamp:1689674798230 [07-18 18:06:38:230 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:41899581 ts:0 [07-18 18:06:38:230 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:41899581 [07-18 18:06:38:230 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:483646 dataSize:110 [07-18 18:06:38:230 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:57 timestamp:1689674798230 [07-18 18:06:38:260 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:260 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 33, head index 57 [07-18 18:06:38:260 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 34, seqNo 1234, timestamp 1689674797454 [07-18 18:06:38:260 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:263 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:41932914 ts:0 [07-18 18:06:38:263 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:41932914 [07-18 18:06:38:263 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1130032 dataSize:695 [07-18 18:06:38:263 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:58 timestamp:1689674798263 [07-18 18:06:38:263 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:41932914 ts:0 [07-18 18:06:38:263 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:41932914 [07-18 18:06:38:263 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:483756 dataSize:695 [07-18 18:06:38:263 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:58 timestamp:1689674798263 [07-18 18:06:38:297 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:41966247 ts:0 [07-18 18:06:38:297 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:41966247 [07-18 18:06:38:297 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1130727 dataSize:1146 [07-18 18:06:38:297 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:59 timestamp:1689674798297 [07-18 18:06:38:297 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:41966247 ts:0 [07-18 18:06:38:297 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:41966247 [07-18 18:06:38:297 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:484451 dataSize:1146 [07-18 18:06:38:297 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:59 timestamp:1689674798297 [07-18 18:06:38:331 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:41999580 ts:0 [07-18 18:06:38:331 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:41999580 [07-18 18:06:38:331 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1131873 dataSize:276 [07-18 18:06:38:331 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:60 timestamp:1689674798331 [07-18 18:06:38:331 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:41999580 ts:0 [07-18 18:06:38:331 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:41999580 [07-18 18:06:38:331 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:485597 dataSize:276 [07-18 18:06:38:331 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:60 timestamp:1689674798331 [07-18 18:06:38:364 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:42032913 ts:0 [07-18 18:06:38:364 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:42032913 [07-18 18:06:38:364 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1132149 dataSize:152 [07-18 18:06:38:364 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:61 timestamp:1689674798364 [07-18 18:06:38:364 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:42032913 ts:0 [07-18 18:06:38:364 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:42032913 [07-18 18:06:38:364 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:485873 dataSize:152 [07-18 18:06:38:364 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:61 timestamp:1689674798364 [07-18 18:06:38:370 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:370 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 34, head index 61 [07-18 18:06:38:370 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 35, seqNo 1235, timestamp 1689674797488 [07-18 18:06:38:371 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:398 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:42066246 ts:0 [07-18 18:06:38:398 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:42066246 [07-18 18:06:38:398 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1132301 dataSize:136 [07-18 18:06:38:398 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:62 timestamp:1689674798398 [07-18 18:06:38:398 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:42066246 ts:0 [07-18 18:06:38:398 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:42066246 [07-18 18:06:38:398 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:486025 dataSize:136 [07-18 18:06:38:398 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:62 timestamp:1689674798398 [07-18 18:06:38:431 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:42099579 ts:0 [07-18 18:06:38:431 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:42099579 [07-18 18:06:38:431 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1132437 dataSize:725 [07-18 18:06:38:431 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:63 timestamp:1689674798431 [07-18 18:06:38:431 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:42099579 ts:0 [07-18 18:06:38:431 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:42099579 [07-18 18:06:38:431 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:486161 dataSize:725 [07-18 18:06:38:431 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:63 timestamp:1689674798431 [07-18 18:06:38:465 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:42132912 ts:0 [07-18 18:06:38:465 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:42132912 [07-18 18:06:38:465 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1133162 dataSize:1369 [07-18 18:06:38:465 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:64 timestamp:1689674798465 [07-18 18:06:38:465 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:42132912 ts:0 [07-18 18:06:38:465 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:42132912 [07-18 18:06:38:465 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:486886 dataSize:1369 [07-18 18:06:38:465 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:64 timestamp:1689674798465 [07-18 18:06:38:481 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:481 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 35, head index 64 [07-18 18:06:38:481 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 36, seqNo 1236, timestamp 1689674797521 [07-18 18:06:38:481 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:499 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:42166245 ts:0 [07-18 18:06:38:499 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:42166245 [07-18 18:06:38:499 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1134531 dataSize:367 [07-18 18:06:38:499 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:65 timestamp:1689674798499 [07-18 18:06:38:499 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:42166245 ts:0 [07-18 18:06:38:499 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:42166245 [07-18 18:06:38:499 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:488255 dataSize:367 [07-18 18:06:38:499 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:65 timestamp:1689674798499 [07-18 18:06:38:532 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:42199578 ts:0 [07-18 18:06:38:532 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:42199578 [07-18 18:06:38:532 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1134898 dataSize:141 [07-18 18:06:38:532 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:66 timestamp:1689674798532 [07-18 18:06:38:532 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:42199578 ts:0 [07-18 18:06:38:532 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:42199578 [07-18 18:06:38:532 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:488622 dataSize:141 [07-18 18:06:38:532 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:66 timestamp:1689674798532 [07-18 18:06:38:566 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:42232911 ts:0 [07-18 18:06:38:566 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:42232911 [07-18 18:06:38:566 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1135039 dataSize:160 [07-18 18:06:38:566 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:67 timestamp:1689674798566 [07-18 18:06:38:566 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:42232911 ts:0 [07-18 18:06:38:566 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:42232911 [07-18 18:06:38:566 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:488763 dataSize:160 [07-18 18:06:38:566 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:67 timestamp:1689674798566 [07-18 18:06:38:591 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:591 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 36, head index 67 [07-18 18:06:38:591 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 37, seqNo 1237, timestamp 1689674797555 [07-18 18:06:38:591 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:599 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:42266244 ts:0 [07-18 18:06:38:599 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:42266244 [07-18 18:06:38:599 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1135199 dataSize:756 [07-18 18:06:38:599 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:68 timestamp:1689674798599 [07-18 18:06:38:599 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:42266244 ts:0 [07-18 18:06:38:599 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:42266244 [07-18 18:06:38:599 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:488923 dataSize:756 [07-18 18:06:38:599 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:68 timestamp:1689674798599 [07-18 18:06:38:633 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:42299577 ts:0 [07-18 18:06:38:633 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:42299577 [07-18 18:06:38:633 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1135955 dataSize:1610 [07-18 18:06:38:633 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:69 timestamp:1689674798633 [07-18 18:06:38:633 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:42299577 ts:0 [07-18 18:06:38:633 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:42299577 [07-18 18:06:38:633 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:489679 dataSize:1610 [07-18 18:06:38:633 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:69 timestamp:1689674798633 [07-18 18:06:38:667 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:42332910 ts:0 [07-18 18:06:38:667 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:42332910 [07-18 18:06:38:667 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1137565 dataSize:516 [07-18 18:06:38:667 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:70 timestamp:1689674798667 [07-18 18:06:38:667 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:42332910 ts:0 [07-18 18:06:38:667 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:42332910 [07-18 18:06:38:667 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:491289 dataSize:516 [07-18 18:06:38:667 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:70 timestamp:1689674798667 [07-18 18:06:38:672 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:38:672 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:38:689 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:06:38:700 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:42366243 ts:0 [07-18 18:06:38:700 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:42366243 [07-18 18:06:38:701 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1138081 dataSize:231 [07-18 18:06:38:701 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:71 timestamp:1689674798701 [07-18 18:06:38:701 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:42366243 ts:0 [07-18 18:06:38:701 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:42366243 [07-18 18:06:38:701 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:491805 dataSize:231 [07-18 18:06:38:701 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:71 timestamp:1689674798701 [07-18 18:06:38:702 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:702 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 37, head index 71 [07-18 18:06:38:702 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 38, seqNo 1238, timestamp 1689674797589 [07-18 18:06:38:702 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:734 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:42399576 ts:0 [07-18 18:06:38:734 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:42399576 [07-18 18:06:38:734 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1138312 dataSize:250 [07-18 18:06:38:734 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:72 timestamp:1689674798734 [07-18 18:06:38:734 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:42399576 ts:0 [07-18 18:06:38:734 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:42399576 [07-18 18:06:38:734 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:492036 dataSize:250 [07-18 18:06:38:734 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:72 timestamp:1689674798734 [07-18 18:06:38:768 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:42432909 ts:0 [07-18 18:06:38:768 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:42432909 [07-18 18:06:38:768 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1138562 dataSize:1143 [07-18 18:06:38:768 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:73 timestamp:1689674798768 [07-18 18:06:38:768 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:42432909 ts:0 [07-18 18:06:38:768 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:42432909 [07-18 18:06:38:768 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:492286 dataSize:1143 [07-18 18:06:38:768 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:73 timestamp:1689674798768 [07-18 18:06:38:801 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:42466242 ts:0 [07-18 18:06:38:801 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:42466242 [07-18 18:06:38:801 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1139705 dataSize:383 [07-18 18:06:38:801 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:74 timestamp:1689674798801 [07-18 18:06:38:801 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:42466242 ts:0 [07-18 18:06:38:801 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:42466242 [07-18 18:06:38:801 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:493429 dataSize:383 [07-18 18:06:38:801 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:74 timestamp:1689674798801 [07-18 18:06:38:812 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:812 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 38, head index 74 [07-18 18:06:38:812 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 39, seqNo 1239, timestamp 1689674797622 [07-18 18:06:38:812 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:835 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:42499575 ts:0 [07-18 18:06:38:835 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:42499575 [07-18 18:06:38:835 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1140088 dataSize:235 [07-18 18:06:38:835 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:75 timestamp:1689674798835 [07-18 18:06:38:835 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:42499575 ts:0 [07-18 18:06:38:835 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:42499575 [07-18 18:06:38:835 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:493812 dataSize:235 [07-18 18:06:38:835 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:75 timestamp:1689674798835 [07-18 18:06:38:869 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:42532908 ts:0 [07-18 18:06:38:869 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:42532908 [07-18 18:06:38:869 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1140323 dataSize:165 [07-18 18:06:38:869 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:76 timestamp:1689674798869 [07-18 18:06:38:869 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:42532908 ts:0 [07-18 18:06:38:869 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:42532908 [07-18 18:06:38:869 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:494047 dataSize:165 [07-18 18:06:38:869 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:76 timestamp:1689674798869 [07-18 18:06:38:902 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:42566241 ts:0 [07-18 18:06:38:902 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:42566241 [07-18 18:06:38:902 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1140488 dataSize:457 [07-18 18:06:38:902 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:77 timestamp:1689674798902 [07-18 18:06:38:902 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:42566241 ts:0 [07-18 18:06:38:902 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:42566241 [07-18 18:06:38:902 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:494212 dataSize:457 [07-18 18:06:38:902 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:77 timestamp:1689674798902 [07-18 18:06:38:922 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:38:922 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 39, head index 77 [07-18 18:06:38:922 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 40, seqNo 1240, timestamp 1689674797656 [07-18 18:06:38:923 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:38:936 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:42599574 ts:0 [07-18 18:06:38:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:42599574 [07-18 18:06:38:936 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1140945 dataSize:673 [07-18 18:06:38:936 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:78 timestamp:1689674798936 [07-18 18:06:38:936 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:42599574 ts:0 [07-18 18:06:38:936 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:42599574 [07-18 18:06:38:936 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:494669 dataSize:673 [07-18 18:06:38:936 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:78 timestamp:1689674798936 [07-18 18:06:38:970 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:42632907 ts:0 [07-18 18:06:38:970 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:42632907 [07-18 18:06:38:970 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1141618 dataSize:465 [07-18 18:06:38:970 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:79 timestamp:1689674798970 [07-18 18:06:38:970 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:42632907 ts:0 [07-18 18:06:38:970 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:42632907 [07-18 18:06:38:970 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:495342 dataSize:465 [07-18 18:06:38:970 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:79 timestamp:1689674798970 [07-18 18:06:39:3 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:42666240 ts:0 [07-18 18:06:39:3 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:42666240 [07-18 18:06:39:3 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1142083 dataSize:248 [07-18 18:06:39:4 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:80 timestamp:1689674799004 [07-18 18:06:39:4 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:42666240 ts:0 [07-18 18:06:39:4 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:42666240 [07-18 18:06:39:4 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:495807 dataSize:248 [07-18 18:06:39:4 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:80 timestamp:1689674799004 [07-18 18:06:39:33 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:39:33 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 40, head index 80 [07-18 18:06:39:33 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 41, seqNo 1241, timestamp 1689674797689 [07-18 18:06:39:33 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:39:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:42699573 ts:0 [07-18 18:06:39:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:42699573 [07-18 18:06:39:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1142331 dataSize:217 [07-18 18:06:39:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:81 timestamp:1689674799037 [07-18 18:06:39:37 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:42699573 ts:0 [07-18 18:06:39:37 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:42699573 [07-18 18:06:39:37 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:496055 dataSize:217 [07-18 18:06:39:37 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:81 timestamp:1689674799037 [07-18 18:06:39:51 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [6] low cmd[3] [07-18 18:06:39:51 TUYA Debug][tuya_ipc_p2p.c:2006] session[196609] [1] send video stop to dev [07-18 18:06:39:51 TUYA Debug][tuya_ipc_p2p.c:2013] session[196609] video stop [07-18 18:06:39:143 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:39:194 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [6] low cmd[5] [07-18 18:06:39:194 TUYA Debug][tuya_ipc_p2p.c:2100] session[196609] [1] send audio stop to dev [07-18 18:06:39:263 TUYA Debug][tuya_ipc_p2p.c:5031] session[65538] detech staticCnt[0]lstCnt[289]vIFrameCnt[289] [07-18 18:06:39:263 TUYA Debug][tuya_ipc_p2p.c:5031] session[196609] detech staticCnt[0]lstCnt[1]vIFrameCnt[1] [07-18 18:06:39:673 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:39:673 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:39:875 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [112000] [07-18 18:06:40:346 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:40:346 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:40:346 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:40:347 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:40:347 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:40:347 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 80 [07-18 18:06:40:347 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674800,"protocol":302,"data":{"msg":{"close_reason_local":0,"close_reason":4},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","path":"mqtt","sub_dev_id":"","type":"disconnect","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723"}}} [07-18 18:06:40:347 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:40:347 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:40:347 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:40:347 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c500 [07-18 18:06:40:347 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:40:355 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58410 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sub_dev_id":"","sessionid":"6c9127b907229c12a5bqfi1689674693VjWbLDLw","moto_id":"","type":"disconnect","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723","path":"mqtt"},"msg":{"close_reason_local":0,"close_reason":4}} [07-18 18:06:40:355 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:40:358 TUYA Err][tuya_ipc_p2p.c:3667] session[65538] was close by client ret[-13] [07-18 18:06:40:358 TUYA Err][tuya_ipc_p2p.c:3778] session[65538] read cmd failed [-1] [07-18 18:06:40:358 TUYA Debug][tuya_ipc_p2p.c:3547] close session[65538] [07-18 18:06:40:358 TUYA Debug][tuya_ipc_p2p.c:5393] download cancel album ipc_sweeper_robot [07-18 18:06:40:359 TUYA Err][tuya_ipc_p2p.c:6611] Write data failed [-13][80] [07-18 18:06:40:359 TUYA Err][tuya_ipc_p2p.c:6612] send failed to app [07-18 18:06:40:359 TUYA Err][tuya_ipc_p2p.c:2601] p2p Write failed ret = -13 [07-18 18:06:40:359 TUYA Err][tuya_ipc_album_sweeper.c:128] download data failed -1, exit task [07-18 18:06:40:359 TUYA Debug][tuya_ipc_album_sweeper.c:130] simple_album_send_finish_2_app [07-18 18:06:40:359 TUYA Debug][tuya_ipc_p2p.c:2179] session[65538] cmd[0] status[5] [07-18 18:06:40:359 TUYA Err][tuya_ipc_p2p.c:2534] speaker not start [07-18 18:06:40:363 TUYA Err][tuya_ipc_p2p.c:3628] session[65538] is try to releasing [07-18 18:06:40:363 TUYA Debug][tuya_ipc_p2p.c:5134] session[65538] __p2p_wait_concurr_idle start [07-18 18:06:40:364 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[196609] higcmd [100] low cmd[7] [07-18 18:06:40:364 TUYA Debug][tuya_ipc_p2p.c:3082] CTRL PLAY BACK session[196609] high[100] low[7] [07-18 18:06:40:364 TUYA Debug][tuya_ipc_p2p.c:3085] CTRL PLAY BACK session[196609] chn[0] speed[1] [07-18 18:06:40:364 TUYA Err][tuya_ipc_p2p.c:3092] err CTRL PLAY BACK session[196609] chn[0] speed[1] [07-18 18:06:40:371 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:40:394 TUYA Debug][tuya_ipc_p2p.c:5151] session[65538] concurr idle[2][2] [07-18 18:06:40:394 TUYA Debug][tuya_ipc_p2p.c:5157] session[65538] __p2p_wait_concurr_idle end [07-18 18:06:40:394 TUYA Debug][tuya_ipc_p2p.c:4100] session[65538] playback_send_video start release [07-18 18:06:40:394 TUYA Debug][tuya_ipc_p2p.c:3576] release source [65538] [07-18 18:06:40:394 TUYA Debug][tuya_ipc_p2p.c:3616] release va session[65538] [07-18 18:06:40:394 TUYA Debug][tuya_ipc_p2p.c:4102] session[0] closed [07-18 18:06:40:447 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:06:40:447 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:06:40:447 TUYA Trace][iot_httpc.c:940] api[tuya.device.log.report] hash[0x9f81e2a5] [07-18 18:06:40:447 TUYA Debug][iot_httpc.c:984] Post Data: {"type":"tuya_p2p_log","data":"{\"type\":\"connection\",\"connection_type\":\"kcp\",\"session_id\":\"6c9127b907229c12a5bqfi1689674693VjWbLDLw\",\"trace_id\":\"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674693723\",\"moto_id\":\"\",\"session_handle\":65538,\"active_handle\":1,\"role\":\"callee\",\"local_id\":\"6c9127b907229c12a5bqfi\",\"remote_id\":\"ay1689142558741Q9RvD\",\"dev_id\":\"\",\"local_p2p_skill\":35,\"remote_p2p_skill\":99,\"preconnect\":true,\"sdk_version\":\"tuya_p2p_sdk_v3.4.3\",\"open\":{\"init_time\":540272,\"ice_token\":[{\"urls\":\"stun:47.103.29.37:3478\"},{\"username\":\"1689678293:6c9127b907229c12a5bqfi\",\"ttl\":3600,\"urls\":\"turn:47.103.17.244:3478\",\"credential\":\"bVvdpohx4iS99rIl5TfdK5/EU4U=\"}],\"tcp_token\":{\"username\":\"1689710693:6c9127b907229c12a5bqfi\",\"sessionId\":\"6c9127b907229c12a5bqfi16897106930Sc6mAfr\",\"urls\":[\"tcp4:124.221.79.86:1443\"],\"domain\":\"wework-1-cn.stream.iot-11.com\",\"credential\":\"UN0es [07-18 18:06:40:447 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674800&v=1.0&sign=5d4526c649ae1d60f9bf5f18efdaa2d7 [07-18 18:06:40:447 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:06:40:447 TUYA Trace][httpc.c:663] No port number given [07-18 18:06:40:447 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674800&v=1.0&sign=5d4526c649ae1d60f9bf5f18efdaa2d7 [07-18 18:06:40:447 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 18:06:40:447 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 18:06:40:447 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 18:06:40:447 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 18:06:40:447 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 18:06:40:447 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 18:06:40:448 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 18:06:40:450 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:40:450 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:40:450 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:40:450 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:40:450 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:40:450 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 81 [07-18 18:06:40:450 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674800,"protocol":302,"data":{"msg":{"handle":3,"seq":8,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674796706"}}} [07-18 18:06:40:450 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:40:450 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:40:450 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:40:450 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c600 [07-18 18:06:40:450 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:40:459 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58411 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":3,"error":0,"seq":8}} [07-18 18:06:40:459 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:40:467 TUYA Err][tuya_ipc_p2p.c:3667] session[196609] was close by client ret[-13] [07-18 18:06:40:467 TUYA Err][tuya_ipc_p2p.c:3778] session[196609] read cmd failed [-1] [07-18 18:06:40:467 TUYA Debug][tuya_ipc_p2p.c:3547] close session[196609] [07-18 18:06:40:467 TUYA Debug][tuya_ipc_p2p.c:2179] session[196609] cmd[0] status[7] [07-18 18:06:40:467 TUYA Err][tuya_ipc_p2p.c:2534] speaker not start [07-18 18:06:40:467 TUYA Err][tuya_ipc_p2p.c:3628] session[196609] is try to releasing [07-18 18:06:40:467 TUYA Debug][tuya_ipc_p2p.c:5134] session[196609] __p2p_wait_concurr_idle start [07-18 18:06:40:468 TUYA Trace][httpc.c:560] Connected .. sockfd: 45 [07-18 18:06:40:468 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 18:06:40:468 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 18:06:40:468 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 18:06:40:468 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 18:06:40:468 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 18:06:40:468 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 18:06:40:474 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:40:491 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 18:06:40:491 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 18:06:40:491 TUYA Trace][httpc.c:952] Have to extract [07-18 18:06:40:491 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:06:40:491 TUYA Trace][httpc.c:663] No port number given [07-18 18:06:40:491 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674800&v=1.0&sign=5d4526c649ae1d60f9bf5f18efdaa2d7 [07-18 18:06:40:491 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 18:06:40:491 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674800&v=1.0&sign=5d4526c649ae1d60f9bf5f18efdaa2d7 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 6725 [07-18 18:06:40:491 TUYA Trace][httpc.c:996] content len:6725 [07-18 18:06:40:492 TUYA Trace][httpc.c:343] Start header read [07-18 18:06:40:497 TUYA Debug][tuya_ipc_p2p.c:5151] session[196609] concurr idle[2][2] [07-18 18:06:40:497 TUYA Debug][tuya_ipc_p2p.c:5157] session[196609] __p2p_wait_concurr_idle end [07-18 18:06:40:497 TUYA Debug][tuya_ipc_p2p.c:4100] session[196609] playback_send_video start release [07-18 18:06:40:497 TUYA Debug][tuya_ipc_p2p.c:3576] release source [196609] [07-18 18:06:40:497 TUYA Debug][tuya_ipc_p2p.c:3616] release va session[196609] [07-18 18:06:40:497 TUYA Debug][tuya_ipc_p2p.c:4102] session[0] closed [07-18 18:06:40:540 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 18:06:40:540 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: 9107b29aed454af1a2b3b546ce0fd39f content-type: application/json;charset=UTF-8 content-length: 119 date: Tue, 18 Jul 2023 10:06:39 GMT server: https {"result":"ZeQSvBEdHjHl1j5RF4jn6NfG8oXvi64aYNuDBZV0QZUEQif8+0oQ6avZeQooIEYp","sign":"a89c63fe6c609cc2","t":1689674800} [07-18 18:06:40:540 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 18:06:40:540 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 305 bytes header [07-18 18:06:40:540 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:120 [07-18 18:06:40:540 TUYA Trace][httpc.c:1748] contentlen:119 size_remain:119 size_to_read:119 [07-18 18:06:40:540 TUYA Trace][httpc.c:425] Using prefetch: 186 119 119 119 [07-18 18:06:40:540 TUYA Trace][iot_httpc.c:807] RESP:{"result":"ZeQSvBEdHjHl1j5RF4jn6NfG8oXvi64aYNuDBZV0QZUEQif8+0oQ6avZeQooIEYp","sign":"a89c63fe6c609cc2","t":1689674800} [07-18 18:06:40:540 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 18:06:40:540 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":true,"t":1689674800,"success":true} [07-18 18:06:40:541 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 18:06:40:541 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 18:06:40:541 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:06:40:541 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:06:40:541 TUYA Trace][iot_httpc.c:940] api[tuya.device.log.report] hash[0x9f81e2a5] [07-18 18:06:40:541 TUYA Debug][iot_httpc.c:984] Post Data: {"type":"tuya_p2p_log","data":"{\"type\":\"connection\",\"connection_type\":\"kcp\",\"session_id\":\"6c9127b907229c12a5bqfi1689674678SjKMLgf7\",\"trace_id\":\"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552\",\"moto_id\":\"\",\"session_handle\":1,\"active_handle\":3,\"role\":\"callee\",\"local_id\":\"6c9127b907229c12a5bqfi\",\"remote_id\":\"ay1689142558741Q9RvD\",\"dev_id\":\"\",\"local_p2p_skill\":35,\"remote_p2p_skill\":99,\"preconnect\":true,\"sdk_version\":\"tuya_p2p_sdk_v3.4.3\",\"activate\":{\"channel_info\":{\"write_bytes\":[264,23219,0,0,0,0,284],\"read_bytes\":[476,0,0,0,0,0,0],\"send_bytes\":[216,23219,0,0,0,0,-20],\"recv_bytes\":[476,0,0,0,0,0,0],\"socket_send_bytes\":[888,25484,0,0,0,0,6612],\"socket_recv_bytes\":[1348,704,0,0,0,0,0],\"first_send_time_ms\":[154,438,-1,-1,-1,-1,4],\"first_write_time_ms\":[155,431,-1,-1,-1,-1,1],\"first_read_time_ms\":[51,-1,-1,-1,-1,-1,-1],\"first_read_try_time_ms\":[1,-1,-1,-1,-1,-1,-1],\"first_data_t [07-18 18:06:40:541 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674800&v=1.0&sign=5d4526c649ae1d60f9bf5f18efdaa2d7 [07-18 18:06:40:541 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:06:40:541 TUYA Trace][httpc.c:663] No port number given [07-18 18:06:40:541 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674800&v=1.0&sign=5d4526c649ae1d60f9bf5f18efdaa2d7 [07-18 18:06:40:541 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 18:06:40:541 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 18:06:40:541 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 18:06:40:541 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 18:06:40:541 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 18:06:40:541 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 18:06:40:541 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 18:06:40:556 TUYA Trace][httpc.c:560] Connected .. sockfd: 45 [07-18 18:06:40:556 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 18:06:40:556 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 18:06:40:556 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 18:06:40:556 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 18:06:40:556 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 18:06:40:556 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 18:06:40:574 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 18:06:40:574 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 18:06:40:574 TUYA Trace][httpc.c:952] Have to extract [07-18 18:06:40:574 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:06:40:574 TUYA Trace][httpc.c:663] No port number given [07-18 18:06:40:574 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674800&v=1.0&sign=5d4526c649ae1d60f9bf5f18efdaa2d7 [07-18 18:06:40:574 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 18:06:40:574 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674800&v=1.0&sign=5d4526c649ae1d60f9bf5f18efdaa2d7 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 2213 [07-18 18:06:40:574 TUYA Trace][httpc.c:996] content len:2213 [07-18 18:06:40:575 TUYA Trace][httpc.c:343] Start header read [07-18 18:06:40:604 TUYA Debug][tuya_ipc_p2p.c:3751] session cmd recv proc alive [50000] num[0] [07-18 18:06:40:635 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 18:06:40:635 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: 0045dd6d4409411ca50f795268215a11 content-type: application/json;charset=UTF-8 content-length: 119 date: Tue, 18 Jul 2023 10:06:40 GMT server: https {"result":"ZeQSvBEdHjHl1j5RF4jn6NfG8oXvi64aYNuDBZV0QZUEQif8+0oQ6avZeQooIEYp","sign":"a89c63fe6c609cc2","t":1689674800} [07-18 18:06:40:635 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 18:06:40:635 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 305 bytes header [07-18 18:06:40:635 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:120 [07-18 18:06:40:635 TUYA Trace][httpc.c:1748] contentlen:119 size_remain:119 size_to_read:119 [07-18 18:06:40:635 TUYA Trace][httpc.c:425] Using prefetch: 186 119 119 119 [07-18 18:06:40:635 TUYA Trace][iot_httpc.c:807] RESP:{"result":"ZeQSvBEdHjHl1j5RF4jn6NfG8oXvi64aYNuDBZV0QZUEQif8+0oQ6avZeQooIEYp","sign":"a89c63fe6c609cc2","t":1689674800} [07-18 18:06:40:635 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 18:06:40:635 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":true,"t":1689674800,"success":true} [07-18 18:06:40:635 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 18:06:40:635 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 18:06:40:756 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:40:756 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:40:756 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:40:756 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:40:756 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:40:756 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 82 [07-18 18:06:40:756 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674800,"protocol":302,"data":{"msg":{"handle":3,"seq":9,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674796706"}}} [07-18 18:06:40:756 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:40:756 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:40:756 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:40:756 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c600 [07-18 18:06:40:756 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:40:766 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58412 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":3,"error":0,"seq":9}} [07-18 18:06:40:766 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:40:782 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:70 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:70 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:70 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:70 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:70 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:70 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 83 [07-18 18:06:41:70 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":302,"data":{"msg":{"handle":3,"seq":10,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674796706"}}} [07-18 18:06:41:70 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:70 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:70 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:41:70 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c600 [07-18 18:06:41:71 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:41:80 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58413 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":3,"error":0,"seq":10}} [07-18 18:06:41:81 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:98 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:110 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:110 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:111 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:111 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:111 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:111 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 84 [07-18 18:06:41:111 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":22,"data":{"reqType":"sigQry"}} [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:2 mq_pro:304 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:3 mq_pro:307 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:4 mq_pro:308 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:5 mq_pro:312 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:6 mq_pro:5 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:7 mq_pro:31 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:8 mq_pro:11 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:9 mq_pro:41 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:10 mq_pro:100 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:11 mq_pro:27 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:12 mq_pro:64 [07-18 18:06:41:111 TUYA Trace][mqc_app.c:719] index:13 mq_pro:22 [07-18 18:06:41:111 TUYA Debug][gw_mqc_cb.c:184] Rev sigQry Req [07-18 18:06:41:139 TUYA Debug][tuya_devos_netlink.c:1221] Get Rssi:98 [07-18 18:06:41:140 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:23 N:58414 Q:0 Data:{"reqType":"sigQry","data":{"signal":98}} [07-18 18:06:41:140 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:166 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:200 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:41:200 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:41:200 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:41:200 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:41:200 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:41:201 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:41:226 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58415 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:41:226 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:245 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:245 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:245 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:245 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:41:245 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:11. [07-18 18:06:41:245 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:0. [07-18 18:06:41:245 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:0. [07-18 18:06:41:252 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:41:252 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:41:252 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:41:252 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:41:252 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:41:252 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:41:271 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:271 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:271 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:271 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:271 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:271 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:271 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 85 [07-18 18:06:41:272 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":302,"data":{"msg":{"log":{"size":1024,"tcp":{"address":"1.117.192.37","key":"6e9d446e4a2d2cdc","domain":"wework-2-cn.stream.iot-11.com","port":9092},"interval":60,"level":2,"topic":"\/av\/moto\/log","api":"thing.m.rtc.log"},"sdp":"v=0\r\no=- 1689674801 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9127b907229c12a5bqfi1689674801LTjBSuhC\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:YYXl\r\na=ice-pwd:0Pf3LPtDN7HKLtPkdxzCIDUY\r\na=ice-options:trickle\r\na=aes-key:2000ffc00090000008000000e000d800\r\na=mid:imm0\r\na=rtpmap:6001 AES\/KCP 330\r\na=ssrc:0 cname:ay1689142558741Q9RvD\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"username":"1689678401:6c9127b907229c12a5bqfi","ttl":3600,"urls":"turn:47.103.29.37:3478","credential":"cg9SUFpg0OeWG0oBuhiYPe9rU2E="}],"tcp_token":{"username":"1689710801:6c9127b907229c12a5bqfi","sessionId": [07-18 18:06:41:272 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:272 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:272 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:41:272 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c002fc0 [07-18 18:06:41:272 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:41:283 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58416 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","moto_id":"","type":"answer","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258","is_pre":0,"p2p_skill":35,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1689674800 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c9127b907229c12a5bqfi1689674801LTjBSuhC\r\nm=application 9 tuya 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:Ek7t\r\na=ice-pwd:ZteDpapRHZO0afgp53lzOx5e\r\na=ice-options:trickle\r\na=aes-key:2000ffc00090000008000000e000d800\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 3\r\na=ssrc:0 cname:6c9127b907229c12a5bqfi\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"username":"1689678401:6c9127b907229c12a5bqfi","ttl":3600,"urls":"turn:47.103.29.37:3478","credential":"cg9SUFpg0OeWG0oBuhiYPe9rU2E="}],"tcp_token":{"username":"16897 [07-18 18:06:41:284 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:284 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58417 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:41:284 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:287 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58418 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258","path":"mqtt"},"msg":{"candidate":"a=candidate:1363335325 1 UDP 2130706431 192.168.2.111 39261 typ host\r\n"}} [07-18 18:06:41:287 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:287 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58419 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258","path":"mqtt"},"msg":{"candidate":"a=candidate:2046722280 1 UDP 2130706431 192.250.250.1 39261 typ host\r\n"}} [07-18 18:06:41:287 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:298 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:298 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:298 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:298 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:298 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:299 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:299 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 86 [07-18 18:06:41:299 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":302,"data":{"msg":{"candidate":"a=candidate:1925511015 1 UDP 2130706431 10.94.71.231 49493 typ host\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258"}}} [07-18 18:06:41:299 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:299 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:299 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:41:299 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c002fc0 [07-18 18:06:41:299 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:41:311 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58420 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258","path":"mqtt"},"msg":{"candidate":"a=candidate:1095868914 1 UDP 1694498815 49.73.254.50 42131 typ srflx\r\n"}} [07-18 18:06:41:311 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:326 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:326 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:326 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:326 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:326 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:326 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:326 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 87 [07-18 18:06:41:326 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":302,"data":{"msg":{"candidate":"a=candidate:315577215 1 UDP 2130706431 192.168.2.74 49493 typ host\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258"}}} [07-18 18:06:41:326 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:326 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:326 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:41:326 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c530 [07-18 18:06:41:326 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:41:342 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58421 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258","path":"mqtt"},"msg":{"candidate":"a=candidate:31170080 1 UDP 16777215 47.103.29.37 58318 typ relay\r\n"}} [07-18 18:06:41:342 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:343 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58422 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","moto_id":"","type":"candidate","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258","path":"mqtt"},"msg":{"candidate":""}} [07-18 18:06:41:343 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:354 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:354 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:354 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:354 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:355 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:355 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:355 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 88 [07-18 18:06:41:355 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":302,"data":{"msg":{"candidate":"a=candidate:429074594 1 UDP 1694498815 49.73.254.50 42125 typ srflx\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258"}}} [07-18 18:06:41:355 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:355 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:355 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:41:355 TUYA Debug][tuya_ipc_p2p.c:4512] listen ok session[65539] [07-18 18:06:41:355 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c530 [07-18 18:06:41:355 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:41:375 TUYA Debug][tuya_ipc_p2p.c:3987] compare passwd [07-18 18:06:41:375 TUYA Debug][tuya_ipc_p2p.c:3988] get ipc auth gw_local_key[Mro9dY$MHLv!DTHz]p2p_passwd[adb63309] [07-18 18:06:41:376 TUYA Debug][tuya_ipc_p2p.c:4006] Client Auth admin efa628a6c8b8f6f591f69df58cfba471 <-> admin adb63309 [07-18 18:06:41:376 TUYA Debug][tuya_ipc_p2p.c:4007] localkey:Mro9dY$MHLv!DTHz final:efa628a6c8b8f6f591f69df58cfba471 [07-18 18:06:41:376 TUYA Debug][tuya_ipc_p2p.c:4010] auth success [07-18 18:06:41:376 TUYA Debug][tuya_ipc_p2p.c:592] __p2p_get_idle_session begin [07-18 18:06:41:376 TUYA Debug][tuya_ipc_p2p.c:4624] create p2p sessions. cur online session num = 1 [07-18 18:06:41:376 TUYA Debug][tuya_ipc_p2p.c:4445] mqtt p2p LISTEN session........ [07-18 18:06:41:381 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:381 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:381 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:381 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:381 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:381 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:381 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 89 [07-18 18:06:41:381 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":302,"data":{"msg":{"candidate":"a=candidate:352303500 1 UDP 16777215 47.103.29.37 64103 typ relay\r\n"},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258"}}} [07-18 18:06:41:381 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:381 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:381 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:41:381 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c530 [07-18 18:06:41:381 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:41:412 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:412 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:412 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:412 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:412 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:41:412 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:12. [07-18 18:06:41:412 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:0. [07-18 18:06:41:412 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:0. [07-18 18:06:41:436 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:436 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:436 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:436 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:436 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:436 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:436 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 90 [07-18 18:06:41:436 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":302,"data":{"msg":{"candidate":""},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674801LTjBSuhC","path":"mqtt","type":"candidate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674801258"}}} [07-18 18:06:41:436 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:436 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:436 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:41:436 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c470 [07-18 18:06:41:437 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:41:461 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:504 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65539] higcmd [100] low cmd[12] [07-18 18:06:41:504 TUYA Debug][tuya_ipc_p2p.c:3082] CTRL PLAY BACK session[65539] high[100] low[12] [07-18 18:06:41:504 TUYA Debug][tuya_ipc_p2p.c:5366] album ipc_sweeper_robot [07-18 18:06:41:504 TUYA Debug][tuya_ipc_p2p.c:3307] query file ok [07-18 18:06:41:596 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[65539] higcmd [100] low cmd[13] [07-18 18:06:41:596 TUYA Debug][tuya_ipc_p2p.c:3082] CTRL PLAY BACK session[65539] high[100] low[13] [07-18 18:06:41:596 TUYA Debug][tuya_ipc_p2p.c:3338] album download info: [07-18 18:06:41:596 TUYA Debug][tuya_ipc_p2p.c:3339] album name:ipc_sweeper_robot [07-18 18:06:41:596 TUYA Debug][tuya_ipc_p2p.c:3342] file map.bin.stream [07-18 18:06:41:596 TUYA Debug][tuya_ipc_p2p.c:3342] file cleanPath.bin.stream [07-18 18:06:41:597 TUYA Debug][tuya_ipc_p2p.c:3342] file navPath.bin.stream [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:43] 5 map.bin.stream navPath.bin.stream [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:43] 4 map.bin.stream cleanPath.bin.stream [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:43] 3 map.bin.stream map.bin.stream [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:72] ##fileArrBit 3 set [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:43] 5 cleanPath.bin.stream navPath.bin.stream [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:43] 4 cleanPath.bin.stream cleanPath.bin.stream [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:72] ##fileArrBit 4 set [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:43] 5 navPath.bin.stream navPath.bin.stream [07-18 18:06:41:597 TUYA Debug][tuya_ipc_album_sweeper.c:72] ##fileArrBit 5 set [07-18 18:06:41:598 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:41:598 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:41:598 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:41:598 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:41:598 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:41:598 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:41:626 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58423 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:41:626 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:654 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:654 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:654 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:654 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:41:654 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:41:654 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 91 [07-18 18:06:41:654 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674801,"protocol":302,"data":{"msg":{"handle":3,"seq":11,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674796706"}}} [07-18 18:06:41:654 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:41:654 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:41:654 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:41:654 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c620 [07-18 18:06:41:654 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:41:663 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58424 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":3,"error":0,"seq":11}} [07-18 18:06:41:663 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:680 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:680 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:680 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:680 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:681 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:41:681 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:13. [07-18 18:06:41:681 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:0. [07-18 18:06:41:681 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:0. [07-18 18:06:41:681 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:41:681 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:41:681 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:41:688 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:41:688 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:41:688 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:41:706 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:715 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58425 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:41:716 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:41:744 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:744 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:41:744 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:41:744 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:41:744 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:14. [07-18 18:06:41:744 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:0. [07-18 18:06:41:744 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674801, rept_cnt:0. [07-18 18:06:41:751 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:41:768 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:114 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:42:114 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:114 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:42:114 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:42:114 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:42:114 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 92 [07-18 18:06:42:114 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674802,"protocol":5,"data":{"dps":{"16":"get_both"}}} [07-18 18:06:42:115 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:42:115 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:42:115 TUYA Trace][mqc_app.c:719] index:2 mq_pro:304 [07-18 18:06:42:115 TUYA Trace][mqc_app.c:719] index:3 mq_pro:307 [07-18 18:06:42:115 TUYA Trace][mqc_app.c:719] index:4 mq_pro:308 [07-18 18:06:42:115 TUYA Trace][mqc_app.c:719] index:5 mq_pro:312 [07-18 18:06:42:115 TUYA Trace][mqc_app.c:719] index:6 mq_pro:5 [07-18 18:06:42:115 TUYA Debug][sf_mqc_cb.c:11] Rev DP Cmd [07-18 18:06:42:115 TUYA Debug][smart_frame.c:1067] Rev Cmd 1, data:0x4c00dbe0 [07-18 18:06:42:123 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[33] [07-18 18:06:42:124 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:42:124 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:42:124 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:42:124 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:42:124 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:42:124 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:42:142 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:157 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58426 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:42:157 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:42:179 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:42:179 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:179 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:42:179 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:42:179 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674802, rept_cnt:15. [07-18 18:06:42:179 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674802, rept_cnt:0. [07-18 18:06:42:179 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674802, rept_cnt:0. [07-18 18:06:42:187 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:42:187 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:42:187 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:42:187 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:42:187 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:42:187 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:42:208 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:217 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58427 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:42:217 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:42:238 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:42:238 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:238 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:42:238 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:42:238 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674802, rept_cnt:16. [07-18 18:06:42:238 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674802, rept_cnt:0. [07-18 18:06:42:238 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674802, rept_cnt:0. [07-18 18:06:42:257 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:42:267 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:692 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:42:692 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:692 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:42:692 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:42:692 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:42:692 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 93 [07-18 18:06:42:692 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674802,"protocol":302,"data":{"msg":{"handle":4,"seq":12},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"activate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674802771"}}} [07-18 18:06:42:692 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:42:692 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:42:692 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:42:692 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c500 [07-18 18:06:42:692 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:42:703 TUYA Debug][tuya_ipc_p2p.c:4512] listen ok session[262145] [07-18 18:06:42:703 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58428 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"activate_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":4,"error":0,"seq":12}} [07-18 18:06:42:704 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:42:721 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:42:733 TUYA Debug][tuya_ipc_p2p.c:3987] compare passwd [07-18 18:06:42:733 TUYA Debug][tuya_ipc_p2p.c:3988] get ipc auth gw_local_key[Mro9dY$MHLv!DTHz]p2p_passwd[adb63309] [07-18 18:06:42:733 TUYA Debug][tuya_ipc_p2p.c:4006] Client Auth admin efa628a6c8b8f6f591f69df58cfba471 <-> admin adb63309 [07-18 18:06:42:733 TUYA Debug][tuya_ipc_p2p.c:4007] localkey:Mro9dY$MHLv!DTHz final:efa628a6c8b8f6f591f69df58cfba471 [07-18 18:06:42:733 TUYA Debug][tuya_ipc_p2p.c:4010] auth success [07-18 18:06:42:733 TUYA Debug][tuya_ipc_p2p.c:592] __p2p_get_idle_session begin [07-18 18:06:42:733 TUYA Debug][tuya_ipc_p2p.c:4624] create p2p sessions. cur online session num = 2 [07-18 18:06:42:734 TUYA Debug][tuya_ipc_p2p.c:4445] mqtt p2p LISTEN session........ [07-18 18:06:42:856 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [10] low cmd[0] [07-18 18:06:42:917 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [2] low cmd[0] [07-18 18:06:42:982 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [9] low cmd[0] [07-18 18:06:43:44 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [9] low cmd[0] [07-18 18:06:43:105 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [6] low cmd[0] [07-18 18:06:43:105 TUYA Debug][tuya_ipc_p2p.c:1911] open ringbuff handle[(nil)] stream[0] [07-18 18:06:43:105 TUYA Debug][tuya_ipc_p2p.c:1946] session[262145]video video_start wait_concurr_idle [07-18 18:06:43:105 TUYA Debug][tuya_ipc_p2p.c:5134] session[262145] __p2p_wait_concurr_idle start [07-18 18:06:43:135 TUYA Debug][tuya_ipc_p2p.c:5151] session[262145] concurr idle[2][2] [07-18 18:06:43:135 TUYA Debug][tuya_ipc_p2p.c:5157] session[262145] __p2p_wait_concurr_idle end [07-18 18:06:43:135 TUYA Debug][tuya_ipc_p2p.c:1978] session[262145] [1] send video start to dev [07-18 18:06:43:135 TUYA Debug][tuya_ipc_p2p.c:1984] session video start[262145] [07-18 18:06:43:135 TUYA Debug][linkbey_sdk_v11.cpp:573] start live video using /oem/ros_file/demo7_video.264 [07-18 18:06:43:135 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:42732906 ts:0 [07-18 18:06:43:135 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:42732906 [07-18 18:06:43:135 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1142548 dataSize:12088 [07-18 18:06:43:135 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:82 timestamp:1689674803135 [07-18 18:06:43:135 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:42732906 ts:0 [07-18 18:06:43:135 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:42732906 [07-18 18:06:43:135 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:496272 dataSize:12088 [07-18 18:06:43:135 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:82 timestamp:1689674803135 [07-18 18:06:43:136 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:136 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 0 node index 0, head index 82 [07-18 18:06:43:136 TUYA Trace][tuya_ring_buffer.c:800] get latest frame node type 1 [07-18 18:06:43:136 TUYA Debug][tuya_ring_buffer.c:806] get latest I frame success, node 82 seqNo 1282 ch0st0tr0 [07-18 18:06:43:136 TUYA Debug][tuya_ipc_p2p.c:4169] session[262145] I Frame Send ok len[12088] pts[42732906] count[1]timestamp[1689674803135] [07-18 18:06:43:136 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:136 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 82, head index 82 [07-18 18:06:43:146 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:147 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 82, head index 82 [07-18 18:06:43:157 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:157 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 82, head index 82 [07-18 18:06:43:167 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:167 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 82, head index 82 [07-18 18:06:43:169 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:42766239 ts:0 [07-18 18:06:43:169 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:42766239 [07-18 18:06:43:169 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1154636 dataSize:1051 [07-18 18:06:43:169 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:83 timestamp:1689674803169 [07-18 18:06:43:169 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:42766239 ts:0 [07-18 18:06:43:169 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:42766239 [07-18 18:06:43:169 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:508360 dataSize:1051 [07-18 18:06:43:169 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:83 timestamp:1689674803169 [07-18 18:06:43:177 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:177 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 82, head index 83 [07-18 18:06:43:177 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 83, seqNo 1283, timestamp 1689674803169 [07-18 18:06:43:177 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:177 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 83, head index 83 [07-18 18:06:43:187 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:187 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 83, head index 83 [07-18 18:06:43:196 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [6] low cmd[4] [07-18 18:06:43:196 TUYA Debug][tuya_ipc_p2p.c:2041] session[262145] [1] send audio start to dev [07-18 18:06:43:197 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:197 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 83, head index 83 [07-18 18:06:43:203 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:42799572 ts:0 [07-18 18:06:43:203 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:42799572 [07-18 18:06:43:203 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1155687 dataSize:209 [07-18 18:06:43:203 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:84 timestamp:1689674803203 [07-18 18:06:43:203 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:42799572 ts:0 [07-18 18:06:43:203 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:42799572 [07-18 18:06:43:203 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:509411 dataSize:209 [07-18 18:06:43:203 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:84 timestamp:1689674803203 [07-18 18:06:43:208 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:43:236 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:42832905 ts:0 [07-18 18:06:43:236 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:42832905 [07-18 18:06:43:236 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1155896 dataSize:118 [07-18 18:06:43:236 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:85 timestamp:1689674803236 [07-18 18:06:43:236 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:42832905 ts:0 [07-18 18:06:43:236 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:42832905 [07-18 18:06:43:236 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:509620 dataSize:118 [07-18 18:06:43:236 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:85 timestamp:1689674803236 [07-18 18:06:43:256 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [5] low cmd[0] [07-18 18:06:43:270 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:42866238 ts:0 [07-18 18:06:43:270 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:42866238 [07-18 18:06:43:270 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1156014 dataSize:110 [07-18 18:06:43:270 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:86 timestamp:1689674803270 [07-18 18:06:43:270 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:42866238 ts:0 [07-18 18:06:43:270 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:42866238 [07-18 18:06:43:270 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:509738 dataSize:110 [07-18 18:06:43:270 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:86 timestamp:1689674803270 [07-18 18:06:43:303 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:42899571 ts:0 [07-18 18:06:43:303 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:42899571 [07-18 18:06:43:303 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1156124 dataSize:695 [07-18 18:06:43:303 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:87 timestamp:1689674803303 [07-18 18:06:43:303 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:42899571 ts:0 [07-18 18:06:43:304 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:42899571 [07-18 18:06:43:304 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:509848 dataSize:695 [07-18 18:06:43:304 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:87 timestamp:1689674803304 [07-18 18:06:43:318 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:318 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 83, head index 87 [07-18 18:06:43:318 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 84, seqNo 1284, timestamp 1689674803203 [07-18 18:06:43:318 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:43:337 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:42932904 ts:0 [07-18 18:06:43:337 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:42932904 [07-18 18:06:43:337 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1156819 dataSize:1146 [07-18 18:06:43:337 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:88 timestamp:1689674803337 [07-18 18:06:43:337 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:42932904 ts:0 [07-18 18:06:43:337 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:42932904 [07-18 18:06:43:337 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:510543 dataSize:1146 [07-18 18:06:43:337 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:88 timestamp:1689674803337 [07-18 18:06:43:371 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:42966237 ts:0 [07-18 18:06:43:371 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:42966237 [07-18 18:06:43:371 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1157965 dataSize:276 [07-18 18:06:43:371 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:89 timestamp:1689674803371 [07-18 18:06:43:371 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:42966237 ts:0 [07-18 18:06:43:371 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:42966237 [07-18 18:06:43:371 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:511689 dataSize:276 [07-18 18:06:43:371 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:89 timestamp:1689674803371 [07-18 18:06:43:404 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:42999570 ts:0 [07-18 18:06:43:404 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:42999570 [07-18 18:06:43:404 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1158241 dataSize:152 [07-18 18:06:43:404 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:90 timestamp:1689674803404 [07-18 18:06:43:404 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:42999570 ts:0 [07-18 18:06:43:404 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:42999570 [07-18 18:06:43:405 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:511965 dataSize:152 [07-18 18:06:43:405 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:90 timestamp:1689674803405 [07-18 18:06:43:428 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:428 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 84, head index 90 [07-18 18:06:43:428 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 85, seqNo 1285, timestamp 1689674803236 [07-18 18:06:43:428 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:43:438 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:43032903 ts:0 [07-18 18:06:43:438 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:43032903 [07-18 18:06:43:438 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1158393 dataSize:136 [07-18 18:06:43:438 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:91 timestamp:1689674803438 [07-18 18:06:43:438 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:43032903 ts:0 [07-18 18:06:43:438 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:43032903 [07-18 18:06:43:438 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:512117 dataSize:136 [07-18 18:06:43:438 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:91 timestamp:1689674803438 [07-18 18:06:43:472 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:43066236 ts:0 [07-18 18:06:43:472 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:43066236 [07-18 18:06:43:472 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1158529 dataSize:725 [07-18 18:06:43:472 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:92 timestamp:1689674803472 [07-18 18:06:43:472 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:43066236 ts:0 [07-18 18:06:43:472 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:43066236 [07-18 18:06:43:472 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:512253 dataSize:725 [07-18 18:06:43:472 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:92 timestamp:1689674803472 [07-18 18:06:43:506 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:43099569 ts:0 [07-18 18:06:43:506 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:43099569 [07-18 18:06:43:506 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1159254 dataSize:1369 [07-18 18:06:43:506 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:93 timestamp:1689674803506 [07-18 18:06:43:506 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:43099569 ts:0 [07-18 18:06:43:506 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:43099569 [07-18 18:06:43:506 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:512978 dataSize:1369 [07-18 18:06:43:506 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:93 timestamp:1689674803506 [07-18 18:06:43:538 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:538 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 85, head index 93 [07-18 18:06:43:538 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 86, seqNo 1286, timestamp 1689674803270 [07-18 18:06:43:538 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:43:539 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:43132902 ts:0 [07-18 18:06:43:539 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:43132902 [07-18 18:06:43:539 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1160623 dataSize:367 [07-18 18:06:43:540 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:94 timestamp:1689674803540 [07-18 18:06:43:540 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:43132902 ts:0 [07-18 18:06:43:540 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:43132902 [07-18 18:06:43:540 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:514347 dataSize:367 [07-18 18:06:43:540 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:94 timestamp:1689674803540 [07-18 18:06:43:573 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:43166235 ts:0 [07-18 18:06:43:573 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:43166235 [07-18 18:06:43:573 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1160990 dataSize:141 [07-18 18:06:43:573 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:95 timestamp:1689674803573 [07-18 18:06:43:573 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:43166235 ts:0 [07-18 18:06:43:573 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:43166235 [07-18 18:06:43:573 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:514714 dataSize:141 [07-18 18:06:43:573 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:95 timestamp:1689674803573 [07-18 18:06:43:607 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:43199568 ts:0 [07-18 18:06:43:607 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:43199568 [07-18 18:06:43:607 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1161131 dataSize:160 [07-18 18:06:43:607 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:96 timestamp:1689674803607 [07-18 18:06:43:607 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:43199568 ts:0 [07-18 18:06:43:607 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:43199568 [07-18 18:06:43:607 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:514855 dataSize:160 [07-18 18:06:43:607 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:96 timestamp:1689674803607 [07-18 18:06:43:640 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:43232901 ts:0 [07-18 18:06:43:640 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:43232901 [07-18 18:06:43:640 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1161291 dataSize:756 [07-18 18:06:43:640 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:97 timestamp:1689674803640 [07-18 18:06:43:640 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:43232901 ts:0 [07-18 18:06:43:640 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:43232901 [07-18 18:06:43:640 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:515015 dataSize:756 [07-18 18:06:43:640 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:97 timestamp:1689674803640 [07-18 18:06:43:649 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:649 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 86, head index 97 [07-18 18:06:43:649 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 87, seqNo 1287, timestamp 1689674803303 [07-18 18:06:43:649 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:43:674 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:43266234 ts:0 [07-18 18:06:43:674 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:43266234 [07-18 18:06:43:674 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1162047 dataSize:1610 [07-18 18:06:43:674 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:98 timestamp:1689674803674 [07-18 18:06:43:674 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:43266234 ts:0 [07-18 18:06:43:674 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:43266234 [07-18 18:06:43:674 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:515771 dataSize:1610 [07-18 18:06:43:674 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:98 timestamp:1689674803674 [07-18 18:06:43:708 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:43299567 ts:0 [07-18 18:06:43:708 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:43299567 [07-18 18:06:43:708 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1163657 dataSize:516 [07-18 18:06:43:708 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:99 timestamp:1689674803708 [07-18 18:06:43:708 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:43299567 ts:0 [07-18 18:06:43:708 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:43299567 [07-18 18:06:43:708 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:517381 dataSize:516 [07-18 18:06:43:708 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:99 timestamp:1689674803708 [07-18 18:06:43:722 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:43:722 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:43:741 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:43332900 ts:0 [07-18 18:06:43:741 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:43332900 [07-18 18:06:43:741 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1164173 dataSize:231 [07-18 18:06:43:741 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:100 timestamp:1689674803741 [07-18 18:06:43:741 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:43332900 ts:0 [07-18 18:06:43:741 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:43332900 [07-18 18:06:43:741 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:517897 dataSize:231 [07-18 18:06:43:741 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:100 timestamp:1689674803741 [07-18 18:06:43:759 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:759 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 87, head index 100 [07-18 18:06:43:759 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 88, seqNo 1288, timestamp 1689674803337 [07-18 18:06:43:759 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:43:775 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:43366233 ts:0 [07-18 18:06:43:775 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:43366233 [07-18 18:06:43:775 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1164404 dataSize:250 [07-18 18:06:43:775 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:101 timestamp:1689674803775 [07-18 18:06:43:775 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:43366233 ts:0 [07-18 18:06:43:775 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:43366233 [07-18 18:06:43:775 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:518128 dataSize:250 [07-18 18:06:43:775 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:101 timestamp:1689674803775 [07-18 18:06:43:808 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:43399566 ts:0 [07-18 18:06:43:809 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:43399566 [07-18 18:06:43:809 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1164654 dataSize:1143 [07-18 18:06:43:809 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:102 timestamp:1689674803809 [07-18 18:06:43:809 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:43399566 ts:0 [07-18 18:06:43:809 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:43399566 [07-18 18:06:43:809 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:518378 dataSize:1143 [07-18 18:06:43:809 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:102 timestamp:1689674803809 [07-18 18:06:43:842 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:43432899 ts:0 [07-18 18:06:43:842 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:43432899 [07-18 18:06:43:842 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1165797 dataSize:383 [07-18 18:06:43:842 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:103 timestamp:1689674803842 [07-18 18:06:43:842 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:43432899 ts:0 [07-18 18:06:43:842 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:43432899 [07-18 18:06:43:842 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:519521 dataSize:383 [07-18 18:06:43:842 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:103 timestamp:1689674803842 [07-18 18:06:43:869 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:869 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 88, head index 103 [07-18 18:06:43:869 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 89, seqNo 1289, timestamp 1689674803371 [07-18 18:06:43:869 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:43:876 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:43466232 ts:0 [07-18 18:06:43:876 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:43466232 [07-18 18:06:43:876 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1166180 dataSize:235 [07-18 18:06:43:876 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:104 timestamp:1689674803876 [07-18 18:06:43:876 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:43466232 ts:0 [07-18 18:06:43:876 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:43466232 [07-18 18:06:43:876 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:519904 dataSize:235 [07-18 18:06:43:876 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:104 timestamp:1689674803876 [07-18 18:06:43:909 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:43499565 ts:0 [07-18 18:06:43:909 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:43499565 [07-18 18:06:43:909 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1166415 dataSize:165 [07-18 18:06:43:910 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:105 timestamp:1689674803909 [07-18 18:06:43:910 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:43499565 ts:0 [07-18 18:06:43:910 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:43499565 [07-18 18:06:43:910 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:520139 dataSize:165 [07-18 18:06:43:910 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:105 timestamp:1689674803910 [07-18 18:06:43:943 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:43532898 ts:0 [07-18 18:06:43:943 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:43532898 [07-18 18:06:43:943 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1166580 dataSize:457 [07-18 18:06:43:943 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:106 timestamp:1689674803943 [07-18 18:06:43:943 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:43532898 ts:0 [07-18 18:06:43:943 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:43532898 [07-18 18:06:43:943 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:520304 dataSize:457 [07-18 18:06:43:943 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:106 timestamp:1689674803943 [07-18 18:06:43:982 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:43566231 ts:0 [07-18 18:06:43:982 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:43566231 [07-18 18:06:43:982 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1167037 dataSize:673 [07-18 18:06:43:982 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:107 timestamp:1689674803982 [07-18 18:06:43:982 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:43566231 ts:0 [07-18 18:06:43:982 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:43566231 [07-18 18:06:43:982 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:520761 dataSize:673 [07-18 18:06:43:982 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:107 timestamp:1689674803982 [07-18 18:06:43:983 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:43:983 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 89, head index 107 [07-18 18:06:43:983 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 90, seqNo 1290, timestamp 1689674803404 [07-18 18:06:43:983 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:16 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:43599564 ts:0 [07-18 18:06:44:16 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:43599564 [07-18 18:06:44:16 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1167710 dataSize:465 [07-18 18:06:44:16 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:108 timestamp:1689674804016 [07-18 18:06:44:16 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:43599564 ts:0 [07-18 18:06:44:16 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:43599564 [07-18 18:06:44:16 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:521434 dataSize:465 [07-18 18:06:44:16 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:108 timestamp:1689674804016 [07-18 18:06:44:50 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:43632897 ts:0 [07-18 18:06:44:50 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:43632897 [07-18 18:06:44:50 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1168175 dataSize:248 [07-18 18:06:44:50 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:109 timestamp:1689674804050 [07-18 18:06:44:50 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:43632897 ts:0 [07-18 18:06:44:50 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:43632897 [07-18 18:06:44:50 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:521899 dataSize:248 [07-18 18:06:44:50 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:109 timestamp:1689674804050 [07-18 18:06:44:84 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:43666230 ts:0 [07-18 18:06:44:84 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:43666230 [07-18 18:06:44:84 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1168423 dataSize:217 [07-18 18:06:44:84 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:110 timestamp:1689674804084 [07-18 18:06:44:84 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:43666230 ts:0 [07-18 18:06:44:84 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:43666230 [07-18 18:06:44:84 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:522147 dataSize:217 [07-18 18:06:44:84 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:110 timestamp:1689674804084 [07-18 18:06:44:93 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:93 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 90, head index 110 [07-18 18:06:44:93 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 91, seqNo 1291, timestamp 1689674803438 [07-18 18:06:44:93 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:117 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:43699563 ts:0 [07-18 18:06:44:117 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:43699563 [07-18 18:06:44:117 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1168640 dataSize:280 [07-18 18:06:44:117 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:111 timestamp:1689674804117 [07-18 18:06:44:117 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:43699563 ts:0 [07-18 18:06:44:117 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:43699563 [07-18 18:06:44:117 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:522364 dataSize:280 [07-18 18:06:44:117 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:111 timestamp:1689674804117 [07-18 18:06:44:151 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:43732896 ts:0 [07-18 18:06:44:151 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:43732896 [07-18 18:06:44:151 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1168920 dataSize:12088 [07-18 18:06:44:151 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:112 timestamp:1689674804151 [07-18 18:06:44:151 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:43732896 ts:0 [07-18 18:06:44:151 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:43732896 [07-18 18:06:44:151 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:522644 dataSize:12088 [07-18 18:06:44:151 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:112 timestamp:1689674804151 [07-18 18:06:44:185 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:43766229 ts:0 [07-18 18:06:44:185 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:43766229 [07-18 18:06:44:185 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1181008 dataSize:1051 [07-18 18:06:44:185 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:113 timestamp:1689674804185 [07-18 18:06:44:185 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:43766229 ts:0 [07-18 18:06:44:185 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:43766229 [07-18 18:06:44:185 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:534732 dataSize:1051 [07-18 18:06:44:185 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:113 timestamp:1689674804185 [07-18 18:06:44:203 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:203 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 91, head index 113 [07-18 18:06:44:203 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 92, seqNo 1292, timestamp 1689674803472 [07-18 18:06:44:204 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:218 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:43799562 ts:0 [07-18 18:06:44:218 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:43799562 [07-18 18:06:44:218 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1182059 dataSize:209 [07-18 18:06:44:218 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:114 timestamp:1689674804218 [07-18 18:06:44:218 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:43799562 ts:0 [07-18 18:06:44:218 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:43799562 [07-18 18:06:44:218 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:535783 dataSize:209 [07-18 18:06:44:218 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:114 timestamp:1689674804218 [07-18 18:06:44:252 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:43832895 ts:0 [07-18 18:06:44:252 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:43832895 [07-18 18:06:44:252 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1182268 dataSize:118 [07-18 18:06:44:252 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:115 timestamp:1689674804252 [07-18 18:06:44:252 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:43832895 ts:0 [07-18 18:06:44:252 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:43832895 [07-18 18:06:44:252 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:535992 dataSize:118 [07-18 18:06:44:252 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:115 timestamp:1689674804252 [07-18 18:06:44:286 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:43866228 ts:0 [07-18 18:06:44:286 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:43866228 [07-18 18:06:44:286 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1182386 dataSize:110 [07-18 18:06:44:286 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:116 timestamp:1689674804286 [07-18 18:06:44:286 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:43866228 ts:0 [07-18 18:06:44:286 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:43866228 [07-18 18:06:44:286 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:536110 dataSize:110 [07-18 18:06:44:286 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:116 timestamp:1689674804286 [07-18 18:06:44:314 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:314 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 92, head index 116 [07-18 18:06:44:314 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 93, seqNo 1293, timestamp 1689674803506 [07-18 18:06:44:314 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:319 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:43899561 ts:0 [07-18 18:06:44:320 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:43899561 [07-18 18:06:44:320 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1182496 dataSize:695 [07-18 18:06:44:320 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:117 timestamp:1689674804320 [07-18 18:06:44:320 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:43899561 ts:0 [07-18 18:06:44:320 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:43899561 [07-18 18:06:44:320 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:536220 dataSize:695 [07-18 18:06:44:320 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:117 timestamp:1689674804320 [07-18 18:06:44:353 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:43932894 ts:0 [07-18 18:06:44:353 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:43932894 [07-18 18:06:44:353 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1183191 dataSize:1146 [07-18 18:06:44:353 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:118 timestamp:1689674804353 [07-18 18:06:44:353 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:43932894 ts:0 [07-18 18:06:44:354 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:43932894 [07-18 18:06:44:354 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:536915 dataSize:1146 [07-18 18:06:44:354 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:118 timestamp:1689674804354 [07-18 18:06:44:387 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:43966227 ts:0 [07-18 18:06:44:387 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:43966227 [07-18 18:06:44:387 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1184337 dataSize:276 [07-18 18:06:44:387 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:119 timestamp:1689674804387 [07-18 18:06:44:387 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:43966227 ts:0 [07-18 18:06:44:387 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:43966227 [07-18 18:06:44:387 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:538061 dataSize:276 [07-18 18:06:44:387 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:119 timestamp:1689674804387 [07-18 18:06:44:421 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:43999560 ts:0 [07-18 18:06:44:421 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:43999560 [07-18 18:06:44:421 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1184613 dataSize:152 [07-18 18:06:44:421 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:120 timestamp:1689674804421 [07-18 18:06:44:421 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:43999560 ts:0 [07-18 18:06:44:421 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:43999560 [07-18 18:06:44:421 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:538337 dataSize:152 [07-18 18:06:44:421 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:120 timestamp:1689674804421 [07-18 18:06:44:428 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:428 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 93, head index 120 [07-18 18:06:44:428 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 94, seqNo 1294, timestamp 1689674803540 [07-18 18:06:44:428 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:454 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:44032893 ts:0 [07-18 18:06:44:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:44032893 [07-18 18:06:44:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1184765 dataSize:136 [07-18 18:06:44:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:121 timestamp:1689674804454 [07-18 18:06:44:455 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:44032893 ts:0 [07-18 18:06:44:455 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:44032893 [07-18 18:06:44:455 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:538489 dataSize:136 [07-18 18:06:44:455 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:121 timestamp:1689674804455 [07-18 18:06:44:488 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:44066226 ts:0 [07-18 18:06:44:488 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:44066226 [07-18 18:06:44:488 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1184901 dataSize:725 [07-18 18:06:44:488 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:122 timestamp:1689674804488 [07-18 18:06:44:488 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:44066226 ts:0 [07-18 18:06:44:488 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:44066226 [07-18 18:06:44:488 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:538625 dataSize:725 [07-18 18:06:44:488 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:122 timestamp:1689674804488 [07-18 18:06:44:522 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:44099559 ts:0 [07-18 18:06:44:522 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:44099559 [07-18 18:06:44:522 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1185626 dataSize:1369 [07-18 18:06:44:522 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:123 timestamp:1689674804522 [07-18 18:06:44:522 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:44099559 ts:0 [07-18 18:06:44:522 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:44099559 [07-18 18:06:44:522 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:539350 dataSize:1369 [07-18 18:06:44:522 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:123 timestamp:1689674804522 [07-18 18:06:44:539 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:539 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 94, head index 123 [07-18 18:06:44:539 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 95, seqNo 1295, timestamp 1689674803573 [07-18 18:06:44:539 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:555 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:44132892 ts:0 [07-18 18:06:44:555 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:44132892 [07-18 18:06:44:555 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1186995 dataSize:367 [07-18 18:06:44:555 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:124 timestamp:1689674804555 [07-18 18:06:44:556 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:44132892 ts:0 [07-18 18:06:44:556 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:44132892 [07-18 18:06:44:556 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:540719 dataSize:367 [07-18 18:06:44:556 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:124 timestamp:1689674804556 [07-18 18:06:44:589 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:44166225 ts:0 [07-18 18:06:44:589 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:44166225 [07-18 18:06:44:589 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1187362 dataSize:141 [07-18 18:06:44:589 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:125 timestamp:1689674804589 [07-18 18:06:44:589 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:44166225 ts:0 [07-18 18:06:44:589 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:44166225 [07-18 18:06:44:589 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:541086 dataSize:141 [07-18 18:06:44:589 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:125 timestamp:1689674804589 [07-18 18:06:44:598 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:44:598 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:44:598 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:44:598 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[33] [07-18 18:06:44:598 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:44:598 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:44:598 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:44:623 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58429 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:44:623 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:44:623 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:44199558 ts:0 [07-18 18:06:44:623 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:44199558 [07-18 18:06:44:623 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1187503 dataSize:160 [07-18 18:06:44:623 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:126 timestamp:1689674804623 [07-18 18:06:44:623 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:44199558 ts:0 [07-18 18:06:44:623 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:44199558 [07-18 18:06:44:623 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:541227 dataSize:160 [07-18 18:06:44:623 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:126 timestamp:1689674804623 [07-18 18:06:44:649 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:650 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 95, head index 126 [07-18 18:06:44:650 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 96, seqNo 1296, timestamp 1689674803607 [07-18 18:06:44:650 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:655 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:44:655 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:44:655 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:44:655 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:44:655 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674804, rept_cnt:17. [07-18 18:06:44:655 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674804, rept_cnt:0. [07-18 18:06:44:655 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674804, rept_cnt:0. [07-18 18:06:44:662 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:44232891 ts:0 [07-18 18:06:44:662 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:44232891 [07-18 18:06:44:662 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1187663 dataSize:756 [07-18 18:06:44:662 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:127 timestamp:1689674804662 [07-18 18:06:44:662 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:44232891 ts:0 [07-18 18:06:44:662 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:44232891 [07-18 18:06:44:662 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:541387 dataSize:756 [07-18 18:06:44:662 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:127 timestamp:1689674804662 [07-18 18:06:44:662 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:44:662 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:44:663 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:44:663 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:44:663 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:44:663 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:44:682 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:44:690 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58430 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:44:690 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:44:696 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:44266224 ts:0 [07-18 18:06:44:696 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:44266224 [07-18 18:06:44:696 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1188419 dataSize:1610 [07-18 18:06:44:696 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:128 timestamp:1689674804696 [07-18 18:06:44:696 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:44266224 ts:0 [07-18 18:06:44:696 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:44266224 [07-18 18:06:44:696 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:542143 dataSize:1610 [07-18 18:06:44:696 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:128 timestamp:1689674804696 [07-18 18:06:44:710 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:44:710 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:44:710 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:44:710 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:44:710 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674804, rept_cnt:18. [07-18 18:06:44:710 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674804, rept_cnt:0. [07-18 18:06:44:710 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674804, rept_cnt:0. [07-18 18:06:44:729 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:44299557 ts:0 [07-18 18:06:44:729 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:44299557 [07-18 18:06:44:729 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1190029 dataSize:516 [07-18 18:06:44:729 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:129 timestamp:1689674804729 [07-18 18:06:44:729 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:44299557 ts:0 [07-18 18:06:44:729 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:44299557 [07-18 18:06:44:729 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:543753 dataSize:516 [07-18 18:06:44:729 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:129 timestamp:1689674804729 [07-18 18:06:44:731 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:44:734 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:44:760 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:760 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 96, head index 129 [07-18 18:06:44:760 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 97, seqNo 1297, timestamp 1689674803640 [07-18 18:06:44:760 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:763 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:44332890 ts:0 [07-18 18:06:44:763 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:44332890 [07-18 18:06:44:763 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1190545 dataSize:231 [07-18 18:06:44:763 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:130 timestamp:1689674804763 [07-18 18:06:44:763 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:44332890 ts:0 [07-18 18:06:44:763 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:44332890 [07-18 18:06:44:763 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:544269 dataSize:231 [07-18 18:06:44:763 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:130 timestamp:1689674804763 [07-18 18:06:44:796 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:44366223 ts:0 [07-18 18:06:44:796 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:44366223 [07-18 18:06:44:796 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1190776 dataSize:250 [07-18 18:06:44:796 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:131 timestamp:1689674804796 [07-18 18:06:44:796 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:44366223 ts:0 [07-18 18:06:44:796 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:44366223 [07-18 18:06:44:797 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:544500 dataSize:250 [07-18 18:06:44:797 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:131 timestamp:1689674804797 [07-18 18:06:44:830 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:44399556 ts:0 [07-18 18:06:44:830 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:44399556 [07-18 18:06:44:830 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1191026 dataSize:1143 [07-18 18:06:44:830 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:132 timestamp:1689674804830 [07-18 18:06:44:830 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:44399556 ts:0 [07-18 18:06:44:830 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:44399556 [07-18 18:06:44:830 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:544750 dataSize:1143 [07-18 18:06:44:830 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:132 timestamp:1689674804830 [07-18 18:06:44:864 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:44432889 ts:0 [07-18 18:06:44:864 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:44432889 [07-18 18:06:44:864 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1192169 dataSize:383 [07-18 18:06:44:864 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:133 timestamp:1689674804864 [07-18 18:06:44:864 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:44432889 ts:0 [07-18 18:06:44:864 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:44432889 [07-18 18:06:44:864 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:545893 dataSize:383 [07-18 18:06:44:864 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:133 timestamp:1689674804864 [07-18 18:06:44:870 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:870 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 97, head index 133 [07-18 18:06:44:870 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 98, seqNo 1298, timestamp 1689674803674 [07-18 18:06:44:870 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:897 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:44466222 ts:0 [07-18 18:06:44:897 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:44466222 [07-18 18:06:44:897 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1192552 dataSize:235 [07-18 18:06:44:897 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:134 timestamp:1689674804897 [07-18 18:06:44:897 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:44466222 ts:0 [07-18 18:06:44:897 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:44466222 [07-18 18:06:44:898 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:546276 dataSize:235 [07-18 18:06:44:898 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:134 timestamp:1689674804898 [07-18 18:06:44:931 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:44499555 ts:0 [07-18 18:06:44:931 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:44499555 [07-18 18:06:44:931 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1192787 dataSize:165 [07-18 18:06:44:931 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:135 timestamp:1689674804931 [07-18 18:06:44:931 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:44499555 ts:0 [07-18 18:06:44:931 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:44499555 [07-18 18:06:44:931 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:546511 dataSize:165 [07-18 18:06:44:932 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:135 timestamp:1689674804932 [07-18 18:06:44:965 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:44532888 ts:0 [07-18 18:06:44:965 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:44532888 [07-18 18:06:44:965 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1192952 dataSize:457 [07-18 18:06:44:965 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:136 timestamp:1689674804965 [07-18 18:06:44:965 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:44532888 ts:0 [07-18 18:06:44:965 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:44532888 [07-18 18:06:44:965 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:546676 dataSize:457 [07-18 18:06:44:965 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:136 timestamp:1689674804965 [07-18 18:06:44:986 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:44:986 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 98, head index 136 [07-18 18:06:44:986 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 99, seqNo 1299, timestamp 1689674803708 [07-18 18:06:44:986 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:44:999 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:44566221 ts:0 [07-18 18:06:44:999 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:44566221 [07-18 18:06:44:999 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1193409 dataSize:673 [07-18 18:06:44:999 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:137 timestamp:1689674804999 [07-18 18:06:44:999 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:44566221 ts:0 [07-18 18:06:44:999 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:44566221 [07-18 18:06:44:999 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:547133 dataSize:673 [07-18 18:06:44:999 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:137 timestamp:1689674804999 [07-18 18:06:45:32 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:44599554 ts:0 [07-18 18:06:45:32 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:44599554 [07-18 18:06:45:32 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1194082 dataSize:465 [07-18 18:06:45:32 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:138 timestamp:1689674805032 [07-18 18:06:45:32 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:44599554 ts:0 [07-18 18:06:45:32 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:44599554 [07-18 18:06:45:32 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:547806 dataSize:465 [07-18 18:06:45:33 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:138 timestamp:1689674805033 [07-18 18:06:45:66 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:44632887 ts:0 [07-18 18:06:45:66 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:44632887 [07-18 18:06:45:66 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1194547 dataSize:248 [07-18 18:06:45:66 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:139 timestamp:1689674805066 [07-18 18:06:45:66 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:44632887 ts:0 [07-18 18:06:45:66 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:44632887 [07-18 18:06:45:66 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:548271 dataSize:248 [07-18 18:06:45:66 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:139 timestamp:1689674805066 [07-18 18:06:45:97 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:45:97 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 99, head index 139 [07-18 18:06:45:97 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 100, seqNo 1300, timestamp 1689674803741 [07-18 18:06:45:97 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:45:100 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:44666220 ts:0 [07-18 18:06:45:100 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:44666220 [07-18 18:06:45:100 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1194795 dataSize:217 [07-18 18:06:45:100 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:140 timestamp:1689674805100 [07-18 18:06:45:100 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:44666220 ts:0 [07-18 18:06:45:100 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:44666220 [07-18 18:06:45:100 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:548519 dataSize:217 [07-18 18:06:45:100 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:140 timestamp:1689674805100 [07-18 18:06:45:133 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:44699553 ts:0 [07-18 18:06:45:133 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:44699553 [07-18 18:06:45:133 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1195012 dataSize:280 [07-18 18:06:45:133 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:141 timestamp:1689674805133 [07-18 18:06:45:133 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:44699553 ts:0 [07-18 18:06:45:133 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:44699553 [07-18 18:06:45:133 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:548736 dataSize:280 [07-18 18:06:45:134 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:141 timestamp:1689674805134 [07-18 18:06:45:167 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:44732886 ts:0 [07-18 18:06:45:167 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:44732886 [07-18 18:06:45:167 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1195292 dataSize:12088 [07-18 18:06:45:167 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:142 timestamp:1689674805167 [07-18 18:06:45:167 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:44732886 ts:0 [07-18 18:06:45:167 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:44732886 [07-18 18:06:45:167 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:549016 dataSize:12088 [07-18 18:06:45:167 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:142 timestamp:1689674805167 [07-18 18:06:45:201 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:44766219 ts:0 [07-18 18:06:45:201 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:44766219 [07-18 18:06:45:201 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1207380 dataSize:1051 [07-18 18:06:45:201 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:143 timestamp:1689674805201 [07-18 18:06:45:201 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:44766219 ts:0 [07-18 18:06:45:201 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:44766219 [07-18 18:06:45:201 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:561104 dataSize:1051 [07-18 18:06:45:201 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:143 timestamp:1689674805201 [07-18 18:06:45:207 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:45:207 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 100, head index 143 [07-18 18:06:45:207 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 101, seqNo 1301, timestamp 1689674803775 [07-18 18:06:45:207 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:45:234 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:44799552 ts:0 [07-18 18:06:45:234 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:44799552 [07-18 18:06:45:234 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1208431 dataSize:209 [07-18 18:06:45:234 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:144 timestamp:1689674805234 [07-18 18:06:45:234 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:44799552 ts:0 [07-18 18:06:45:234 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:44799552 [07-18 18:06:45:235 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:562155 dataSize:209 [07-18 18:06:45:235 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:144 timestamp:1689674805235 [07-18 18:06:45:268 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:44832885 ts:0 [07-18 18:06:45:268 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:44832885 [07-18 18:06:45:268 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1208640 dataSize:118 [07-18 18:06:45:268 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:145 timestamp:1689674805268 [07-18 18:06:45:268 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:44832885 ts:0 [07-18 18:06:45:268 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:44832885 [07-18 18:06:45:268 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:562364 dataSize:118 [07-18 18:06:45:268 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:145 timestamp:1689674805268 [07-18 18:06:45:302 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:44866218 ts:0 [07-18 18:06:45:302 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:44866218 [07-18 18:06:45:302 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1208758 dataSize:110 [07-18 18:06:45:302 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:146 timestamp:1689674805302 [07-18 18:06:45:302 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:44866218 ts:0 [07-18 18:06:45:302 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:44866218 [07-18 18:06:45:302 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:562482 dataSize:110 [07-18 18:06:45:302 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:146 timestamp:1689674805302 [07-18 18:06:45:303 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [6] low cmd[3] [07-18 18:06:45:303 TUYA Debug][tuya_ipc_p2p.c:2006] session[262145] [1] send video stop to dev [07-18 18:06:45:303 TUYA Debug][tuya_ipc_p2p.c:2013] session[262145] video stop [07-18 18:06:45:317 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:45:368 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [6] low cmd[5] [07-18 18:06:45:368 TUYA Debug][tuya_ipc_p2p.c:2100] session[262145] [1] send audio stop to dev [07-18 18:06:45:735 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:45:736 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:46:546 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:46:546 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:46:546 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:46:546 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:46:546 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:46:546 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:46:574 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58431 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:46:574 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:46:621 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:46:621 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:46:621 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:46:621 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:46:621 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674806, rept_cnt:19. [07-18 18:06:46:621 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674806, rept_cnt:0. [07-18 18:06:46:621 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674806, rept_cnt:0. [07-18 18:06:46:622 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:46:622 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:46:622 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:46:630 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:46:630 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:46:630 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:46:649 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:46:656 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58432 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:46:656 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:46:685 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:46:685 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:46:685 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:46:692 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:46:693 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674806, rept_cnt:20. [07-18 18:06:46:693 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674806, rept_cnt:0. [07-18 18:06:46:693 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674806, rept_cnt:0. [07-18 18:06:46:709 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:46:721 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:47:67 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[37] [07-18 18:06:47:281 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [113000] [07-18 18:06:47:459 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [100] low cmd[7] [07-18 18:06:47:459 TUYA Debug][tuya_ipc_p2p.c:3082] CTRL PLAY BACK session[262145] high[100] low[7] [07-18 18:06:47:459 TUYA Debug][tuya_ipc_p2p.c:3085] CTRL PLAY BACK session[262145] chn[0] speed[1] [07-18 18:06:47:459 TUYA Err][tuya_ipc_p2p.c:3092] err CTRL PLAY BACK session[262145] chn[0] speed[1] [07-18 18:06:47:519 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [7] low cmd[3] [07-18 18:06:47:520 TUYA Err][tuya_ipc_p2p.c:1726] session[262145] cur cmd[0] [07-18 18:06:47:580 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[262145] higcmd [7] low cmd[5] [07-18 18:06:47:580 TUYA Debug][tuya_ipc_p2p.c:1886] session pb audio stop[262145] [07-18 18:06:47:594 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:47:594 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:47:594 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:47:595 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:47:595 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:47:595 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 94 [07-18 18:06:47:595 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674807,"protocol":302,"data":{"msg":{"handle":4,"seq":13,"reason":0},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"suspend","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674802771"}}} [07-18 18:06:47:595 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:47:595 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:47:595 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:47:595 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c600 [07-18 18:06:47:595 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:47:602 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:47:602 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:47:602 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:47:602 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:47:602 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:47:602 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:47:604 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[37] [07-18 18:06:47:605 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58433 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"suspend_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":4,"error":0,"seq":13}} [07-18 18:06:47:605 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:47:615 TUYA Err][tuya_ipc_p2p.c:3667] session[262145] was close by client ret[-11] [07-18 18:06:47:615 TUYA Err][tuya_ipc_p2p.c:3778] session[262145] read cmd failed [-1] [07-18 18:06:47:615 TUYA Debug][tuya_ipc_p2p.c:3547] close session[262145] [07-18 18:06:47:615 TUYA Debug][tuya_ipc_p2p.c:2179] session[262145] cmd[0] status[7] [07-18 18:06:47:615 TUYA Err][tuya_ipc_p2p.c:2534] speaker not start [07-18 18:06:47:616 TUYA Err][tuya_ipc_p2p.c:3628] session[262145] is try to releasing [07-18 18:06:47:616 TUYA Debug][tuya_ipc_p2p.c:5134] session[262145] __p2p_wait_concurr_idle start [07-18 18:06:47:627 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:47:636 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58434 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:47:636 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:47:643 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:06:47:643 TUYA Trace][tuya_tls.c:792] set cert loaded:1 [07-18 18:06:47:643 TUYA Trace][iot_httpc.c:940] api[tuya.device.log.report] hash[0x9f81e2a5] [07-18 18:06:47:643 TUYA Debug][iot_httpc.c:984] Post Data: {"type":"tuya_p2p_log","data":"{\"type\":\"connection\",\"connection_type\":\"kcp\",\"session_id\":\"6c9127b907229c12a5bqfi1689674678SjKMLgf7\",\"trace_id\":\"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552\",\"moto_id\":\"\",\"session_handle\":1,\"active_handle\":4,\"role\":\"callee\",\"local_id\":\"6c9127b907229c12a5bqfi\",\"remote_id\":\"ay1689142558741Q9RvD\",\"dev_id\":\"\",\"local_p2p_skill\":35,\"remote_p2p_skill\":99,\"preconnect\":true,\"sdk_version\":\"tuya_p2p_sdk_v3.4.3\",\"activate\":{\"channel_info\":{\"write_bytes\":[352,23505,0,0,0,0,284],\"read_bytes\":[568,0,0,0,0,0,0],\"send_bytes\":[208,23505,0,0,0,0,-20],\"recv_bytes\":[568,0,0,0,0,0,0],\"socket_send_bytes\":[1180,25832,0,0,0,0,8352],\"socket_recv_bytes\":[1596,748,0,0,0,0,0],\"first_send_time_ms\":[134,444,-1,-1,-1,-1,3],\"first_write_time_ms\":[154,434,-1,-1,-1,-1,1],\"first_read_time_ms\":[31,-1,-1,-1,-1,-1,-1],\"first_read_try_time_ms\":[1,-1,-1,-1,-1,-1,-1],\"first_data_ [07-18 18:06:47:643 TUYA Debug][iot_httpc.c:996] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674807&v=1.0&sign=f8ac6859a25c812a328501b8f7fbd447 [07-18 18:06:47:643 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:06:47:643 TUYA Trace][httpc.c:663] No port number given [07-18 18:06:47:643 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674807&v=1.0&sign=f8ac6859a25c812a328501b8f7fbd447 [07-18 18:06:47:643 TUYA Trace][httpc.c:806] Force enable TLS flag [07-18 18:06:47:643 TUYA Debug][httpc.c:812] Connect: a2.tuyacn.com Port: 443 -->> [07-18 18:06:47:643 TUYA Debug][uni_network.c:345] unw_gethostbyname a2.tuyacn.com, prio 0 [07-18 18:06:47:643 TUYA Debug][uni_network.c:230] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com [07-18 18:06:47:643 TUYA Trace][httpc.c:460] got host a2.tuyacn.com 's ip : 36.31.192.42 [07-18 18:06:47:643 TUYA Debug][httpc.c:476] ----got ipaddr:42,192,31,36 [07-18 18:06:47:643 TUYA Trace][httpc.c:545] Connecting .. a2.tuyacn.com:443 [07-18 18:06:47:646 TUYA Debug][tuya_ipc_p2p.c:5151] session[262145] concurr idle[2][2] [07-18 18:06:47:646 TUYA Debug][tuya_ipc_p2p.c:5157] session[262145] __p2p_wait_concurr_idle end [07-18 18:06:47:646 TUYA Debug][tuya_ipc_p2p.c:4100] session[262145] playback_send_video start release [07-18 18:06:47:646 TUYA Debug][tuya_ipc_p2p.c:3576] release source [262145] [07-18 18:06:47:646 TUYA Debug][tuya_ipc_p2p.c:3616] release va session[262145] [07-18 18:06:47:646 TUYA Debug][tuya_ipc_p2p.c:4102] session[0] closed [07-18 18:06:47:659 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:47:659 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:47:659 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:47:659 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:47:659 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674807, rept_cnt:21. [07-18 18:06:47:659 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674807, rept_cnt:0. [07-18 18:06:47:659 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674807, rept_cnt:0. [07-18 18:06:47:659 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:47:659 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:47:659 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:47:666 TUYA Trace][httpc.c:560] Connected .. sockfd: 67 [07-18 18:06:47:666 TUYA Debug][httpc.c:814] Connect: a2.tuyacn.com Port: 443 --<< ,r:0 [07-18 18:06:47:666 TUYA Debug][tuya_tls.c:1201] ----enable_cert:1,DEFAULT_LOAD_CERT:1 [07-18 18:06:47:667 TUYA Debug][tuya_tls.c:1244] TUYA_TLS Begin Connect a2.tuyacn.com:443 CustomNet:TRUE Enable_Cert:TRUE Default:TRUE [07-18 18:06:47:667 TUYA Debug][tuya_tls.c:1303] load tuya cert. [07-18 18:06:47:667 TUYA Debug][tuya_tls.c:1308] parse crt <0> len <2002> ret <0> [07-18 18:06:47:667 TUYA Debug][tuya_tls.c:1418] socket fd is set. set to inner send/recv to handshake [07-18 18:06:47:668 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:47:668 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:47:668 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:47:686 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:47:698 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58435 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:47:698 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:47:710 TUYA Debug][tuya_tls.c:1460] handshake finish for a2.tuyacn.com. set send/recv to user set [07-18 18:06:47:710 TUYA Debug][tuya_tls.c:1475] TUYA_TLS Success Connect a2.tuyacn.com:443 CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [07-18 18:06:47:710 TUYA Trace][httpc.c:952] Have to extract [07-18 18:06:47:710 TUYA Trace][httpc.c:615] Scheme: https [07-18 18:06:47:710 TUYA Trace][httpc.c:663] No port number given [07-18 18:06:47:710 TUYA Trace][httpc.c:689] Resource: /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674807&v=1.0&sign=f8ac6859a25c812a328501b8f7fbd447 [07-18 18:06:47:710 TUYA Trace][httpc.c:1182] Enter: http_send_request [07-18 18:06:47:710 TUYA Trace][httpc.c:972] send header:POST /d.json?a=tuya.device.log.report&devId=6c9127b907229c12a5bqfi&et=1&t=1689674807&v=1.0&sign=f8ac6859a25c812a328501b8f7fbd447 HTTP/1.1 Host: a2.tuyacn.com User-Agent: TUYA_IOT_SDK Connection: keep-alive Content-Type: application/x-www-form-urlencoded; charset=UTF-8 Content-Length: 2213 [07-18 18:06:47:710 TUYA Trace][httpc.c:996] content len:2213 [07-18 18:06:47:710 TUYA Trace][httpc.c:343] Start header read [07-18 18:06:47:726 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:47:726 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:47:726 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:47:726 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:47:726 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674807, rept_cnt:22. [07-18 18:06:47:726 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674807, rept_cnt:0. [07-18 18:06:47:726 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674807, rept_cnt:0. [07-18 18:06:47:734 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:47:751 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:47:762 TUYA Trace][httpc.c:1372] Parsing HTTP header [07-18 18:06:47:762 TUYA Trace][httpc.c:1373] header:HTTP/1.1 200 OK x-request-id: f498febe12234b4b91664d0aa3d765b5 content-type: application/json;charset=UTF-8 content-length: 119 date: Tue, 18 Jul 2023 10:06:47 GMT server: https {"result":"ZeQSvBEdHjHl1j5RF4jn6IgD27TgpfiOhQrTMT49jokEQif8+0oQ6avZeQooIEYp","sign":"73d789251ea80807","t":1689674807} [07-18 18:06:47:762 TUYA Trace][httpc.c:1406] Defaulting to keep alive [07-18 18:06:47:762 TUYA Trace][httpc.c:1516] Header has used up 186 bytes from the 305 bytes header [07-18 18:06:47:762 TUYA Trace][iot_httpc.c:533] Malloc Buffer Size:120 [07-18 18:06:47:762 TUYA Trace][httpc.c:1748] contentlen:119 size_remain:119 size_to_read:119 [07-18 18:06:47:762 TUYA Trace][httpc.c:425] Using prefetch: 186 119 119 119 [07-18 18:06:47:762 TUYA Trace][iot_httpc.c:807] RESP:{"result":"ZeQSvBEdHjHl1j5RF4jn6IgD27TgpfiOhQrTMT49jokEQif8+0oQ6avZeQooIEYp","sign":"73d789251ea80807","t":1689674807} [07-18 18:06:47:763 TUYA Trace][iot_httpc.c:823] decode key NOT null cTtC>*KlO'RTxi9] [07-18 18:06:47:763 TUYA Debug][iot_httpc.c:663] Decode Rev:{"result":true,"t":1689674807,"success":true} [07-18 18:06:47:763 TUYA Debug][tuya_tls.c:1555] TUYA_TLS Disconnect ENTER [07-18 18:06:47:763 TUYA Debug][tuya_tls.c:1610] TUYA_TLS Disconnect Success [07-18 18:06:48:694 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:06:48:752 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:48:752 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:49:197 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:06:49:197 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:49:197 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:40 [07-18 18:06:49:281 TUYA Debug][tuya_ipc_p2p.c:5031] session[65539] detech staticCnt[0]lstCnt[144]vIFrameCnt[144] [07-18 18:06:49:753 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:49:753 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:50:602 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[37] [07-18 18:06:50:754 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:50:754 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:51:126 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008f0] len[41] [07-18 18:06:51:755 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:51:755 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:51:897 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:51:897 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:51:897 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:51:898 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:51:898 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:51:898 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:51:937 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58436 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:51:937 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:51:972 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:51:972 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:51:972 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:51:972 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:51:972 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674811, rept_cnt:23. [07-18 18:06:51:972 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674811, rept_cnt:0. [07-18 18:06:51:972 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674811, rept_cnt:0. [07-18 18:06:51:972 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:51:972 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:51:972 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:51:979 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:51:979 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:51:979 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:51:998 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:52:7 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58437 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:52:7 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:52:40 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:52:40 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:52:40 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:52:54 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:52:54 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674812, rept_cnt:24. [07-18 18:06:52:54 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674812, rept_cnt:0. [07-18 18:06:52:54 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674812, rept_cnt:0. [07-18 18:06:52:75 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:52:132 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:52:443 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [114000] [07-18 18:06:52:974 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[45] [07-18 18:06:53:76 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:53:76 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:53:341 TUYA Debug][tuya_devos_health.c:30] feed watchdog [07-18 18:06:54:76 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:54:76 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:55:77 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:55:77 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:56:79 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:56:79 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:56:667 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:56:667 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:56:667 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:56:667 TUYA Trace][tuya_devos_utils.c:356] get gw ext_stat:2 [07-18 18:06:56:667 TUYA Trace][com_protocol.c:280] Data From MQTT AND V=2.2 [07-18 18:06:56:667 TUYA Trace][com_protocol.c:157] pcmcd check success! from 73950912 95 [07-18 18:06:56:667 TUYA Debug][mqc_app.c:681] Rev MQTT:{"t":1689674816,"protocol":302,"data":{"msg":{"handle":5,"seq":14},"header":{"from":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","path":"mqtt","type":"activate","to":"6c9127b907229c12a5bqfi","moto_id":"","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674816732"}}} [07-18 18:06:56:667 TUYA Trace][mqc_app.c:719] index:0 mq_pro:300 [07-18 18:06:56:667 TUYA Trace][mqc_app.c:719] index:1 mq_pro:302 [07-18 18:06:56:667 TUYA Debug][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302 [07-18 18:06:56:667 TUYA Trace][uni_work_queue.c:154] work_queue add task:4c00c500 [07-18 18:06:56:667 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:06:56:675 TUYA Debug][tuya_ipc_p2p.c:4512] listen ok session[327681] [07-18 18:06:56:676 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:302 N:58438 Q:0 Data:{"header":{"from":"6c9127b907229c12a5bqfi","to":"ay1689142558741Q9RvD","sessionid":"6c9127b907229c12a5bqfi1689674678SjKMLgf7","moto_id":"","type":"activate_resp","trace_id":"ipc_p2p_ios_6c9127b907229c12a5bqfi_1689674678552","path":"mqtt"},"msg":{"handle":5,"error":0,"seq":14}} [07-18 18:06:56:676 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:56:692 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:56:726 TUYA Debug][tuya_ipc_p2p.c:3987] compare passwd [07-18 18:06:56:726 TUYA Debug][tuya_ipc_p2p.c:3988] get ipc auth gw_local_key[Mro9dY$MHLv!DTHz]p2p_passwd[adb63309] [07-18 18:06:56:726 TUYA Debug][tuya_ipc_p2p.c:4006] Client Auth admin efa628a6c8b8f6f591f69df58cfba471 <-> admin adb63309 [07-18 18:06:56:726 TUYA Debug][tuya_ipc_p2p.c:4007] localkey:Mro9dY$MHLv!DTHz final:efa628a6c8b8f6f591f69df58cfba471 [07-18 18:06:56:726 TUYA Debug][tuya_ipc_p2p.c:4010] auth success [07-18 18:06:56:726 TUYA Debug][tuya_ipc_p2p.c:592] __p2p_get_idle_session begin [07-18 18:06:56:726 TUYA Debug][tuya_ipc_p2p.c:4624] create p2p sessions. cur online session num = 2 [07-18 18:06:56:726 TUYA Debug][tuya_ipc_p2p.c:4445] mqtt p2p LISTEN session........ [07-18 18:06:56:850 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [10] low cmd[0] [07-18 18:06:56:911 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [2] low cmd[0] [07-18 18:06:56:972 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [9] low cmd[0] [07-18 18:06:57:32 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [9] low cmd[0] [07-18 18:06:57:94 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [6] low cmd[0] [07-18 18:06:57:94 TUYA Debug][tuya_ipc_p2p.c:1911] open ringbuff handle[(nil)] stream[0] [07-18 18:06:57:94 TUYA Debug][tuya_ipc_p2p.c:1946] session[327681]video video_start wait_concurr_idle [07-18 18:06:57:94 TUYA Debug][tuya_ipc_p2p.c:5134] session[327681] __p2p_wait_concurr_idle start [07-18 18:06:57:124 TUYA Debug][tuya_ipc_p2p.c:5151] session[327681] concurr idle[2][2] [07-18 18:06:57:124 TUYA Debug][tuya_ipc_p2p.c:5157] session[327681] __p2p_wait_concurr_idle end [07-18 18:06:57:124 TUYA Debug][tuya_ipc_p2p.c:1978] session[327681] [1] send video start to dev [07-18 18:06:57:124 TUYA Debug][tuya_ipc_p2p.c:1984] session video start[327681] [07-18 18:06:57:124 TUYA Debug][linkbey_sdk_v11.cpp:573] start live video using /oem/ros_file/demo7_video.264 [07-18 18:06:57:125 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:44899551 ts:0 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:44899551 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1208868 dataSize:12088 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:147 timestamp:1689674817125 [07-18 18:06:57:125 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:44899551 ts:0 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:44899551 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:562592 dataSize:12088 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:147 timestamp:1689674817125 [07-18 18:06:57:125 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 0 node index 0, head index 147 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:800] get latest frame node type 1 [07-18 18:06:57:125 TUYA Debug][tuya_ring_buffer.c:806] get latest I frame success, node 147 seqNo 1347 ch0st0tr0 [07-18 18:06:57:125 TUYA Debug][tuya_ipc_p2p.c:4169] session[327681] I Frame Send ok len[12088] pts[44899551] count[1]timestamp[1689674817125] [07-18 18:06:57:125 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:125 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 147, head index 147 [07-18 18:06:57:136 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:136 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 147, head index 147 [07-18 18:06:57:146 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:146 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 147, head index 147 [07-18 18:06:57:156 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:156 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 147, head index 147 [07-18 18:06:57:158 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:44932884 ts:0 [07-18 18:06:57:158 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:44932884 [07-18 18:06:57:158 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1220956 dataSize:1051 [07-18 18:06:57:158 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:148 timestamp:1689674817158 [07-18 18:06:57:158 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:44932884 ts:0 [07-18 18:06:57:158 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:44932884 [07-18 18:06:57:158 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:574680 dataSize:1051 [07-18 18:06:57:158 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:148 timestamp:1689674817158 [07-18 18:06:57:166 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:166 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 147, head index 148 [07-18 18:06:57:166 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 148, seqNo 1348, timestamp 1689674817158 [07-18 18:06:57:166 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:166 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 148, head index 148 [07-18 18:06:57:176 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:176 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 148, head index 148 [07-18 18:06:57:185 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [6] low cmd[4] [07-18 18:06:57:185 TUYA Debug][tuya_ipc_p2p.c:2041] session[327681] [1] send audio start to dev [07-18 18:06:57:187 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:187 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 148, head index 148 [07-18 18:06:57:192 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:44966217 ts:0 [07-18 18:06:57:192 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:44966217 [07-18 18:06:57:192 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1222007 dataSize:209 [07-18 18:06:57:192 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:149 timestamp:1689674817192 [07-18 18:06:57:192 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:44966217 ts:0 [07-18 18:06:57:192 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:44966217 [07-18 18:06:57:192 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:575731 dataSize:209 [07-18 18:06:57:192 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:149 timestamp:1689674817192 [07-18 18:06:57:197 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:57:225 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:44999550 ts:0 [07-18 18:06:57:225 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:44999550 [07-18 18:06:57:225 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1222216 dataSize:118 [07-18 18:06:57:226 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:150 timestamp:1689674817226 [07-18 18:06:57:226 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:44999550 ts:0 [07-18 18:06:57:226 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:44999550 [07-18 18:06:57:226 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:575940 dataSize:118 [07-18 18:06:57:226 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:150 timestamp:1689674817226 [07-18 18:06:57:259 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:45032883 ts:0 [07-18 18:06:57:259 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:45032883 [07-18 18:06:57:259 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1222334 dataSize:110 [07-18 18:06:57:259 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:151 timestamp:1689674817259 [07-18 18:06:57:259 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:45032883 ts:0 [07-18 18:06:57:259 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:45032883 [07-18 18:06:57:259 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:576058 dataSize:110 [07-18 18:06:57:259 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:151 timestamp:1689674817259 [07-18 18:06:57:293 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:45066216 ts:0 [07-18 18:06:57:293 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:45066216 [07-18 18:06:57:293 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1222444 dataSize:695 [07-18 18:06:57:293 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:152 timestamp:1689674817293 [07-18 18:06:57:293 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:45066216 ts:0 [07-18 18:06:57:293 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:45066216 [07-18 18:06:57:293 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:576168 dataSize:695 [07-18 18:06:57:293 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:152 timestamp:1689674817293 [07-18 18:06:57:307 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:307 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 148, head index 152 [07-18 18:06:57:307 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 149, seqNo 1349, timestamp 1689674817192 [07-18 18:06:57:307 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:57:327 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:45099549 ts:0 [07-18 18:06:57:327 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:45099549 [07-18 18:06:57:327 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1223139 dataSize:1146 [07-18 18:06:57:327 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:153 timestamp:1689674817327 [07-18 18:06:57:327 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:45099549 ts:0 [07-18 18:06:57:327 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:45099549 [07-18 18:06:57:328 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:576863 dataSize:1146 [07-18 18:06:57:328 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:153 timestamp:1689674817328 [07-18 18:06:57:362 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:45132882 ts:0 [07-18 18:06:57:362 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:45132882 [07-18 18:06:57:362 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1224285 dataSize:276 [07-18 18:06:57:362 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:154 timestamp:1689674817362 [07-18 18:06:57:362 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:45132882 ts:0 [07-18 18:06:57:362 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:45132882 [07-18 18:06:57:362 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:578009 dataSize:276 [07-18 18:06:57:362 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:154 timestamp:1689674817362 [07-18 18:06:57:395 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:45166215 ts:0 [07-18 18:06:57:395 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:45166215 [07-18 18:06:57:395 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1224561 dataSize:152 [07-18 18:06:57:395 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:155 timestamp:1689674817395 [07-18 18:06:57:395 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:45166215 ts:0 [07-18 18:06:57:395 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:45166215 [07-18 18:06:57:395 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:578285 dataSize:152 [07-18 18:06:57:395 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:155 timestamp:1689674817395 [07-18 18:06:57:418 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:418 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 149, head index 155 [07-18 18:06:57:418 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 150, seqNo 1350, timestamp 1689674817226 [07-18 18:06:57:418 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:57:429 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:45199548 ts:0 [07-18 18:06:57:429 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:45199548 [07-18 18:06:57:429 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1224713 dataSize:136 [07-18 18:06:57:429 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:156 timestamp:1689674817429 [07-18 18:06:57:429 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:45199548 ts:0 [07-18 18:06:57:429 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:45199548 [07-18 18:06:57:429 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:578437 dataSize:136 [07-18 18:06:57:429 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:156 timestamp:1689674817429 [07-18 18:06:57:444 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:57:444 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:57:444 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:57:444 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:57:444 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:06:57:444 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:06:57:463 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:45232881 ts:0 [07-18 18:06:57:463 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:45232881 [07-18 18:06:57:463 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1224849 dataSize:725 [07-18 18:06:57:463 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:157 timestamp:1689674817463 [07-18 18:06:57:463 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:45232881 ts:0 [07-18 18:06:57:463 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:45232881 [07-18 18:06:57:463 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:578573 dataSize:725 [07-18 18:06:57:463 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:157 timestamp:1689674817463 [07-18 18:06:57:473 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58439 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:06:57:473 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:57:496 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:45266214 ts:0 [07-18 18:06:57:496 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:45266214 [07-18 18:06:57:496 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1225574 dataSize:1369 [07-18 18:06:57:496 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:158 timestamp:1689674817496 [07-18 18:06:57:496 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:45266214 ts:0 [07-18 18:06:57:496 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:45266214 [07-18 18:06:57:496 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:579298 dataSize:1369 [07-18 18:06:57:497 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:158 timestamp:1689674817496 [07-18 18:06:57:528 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:528 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 150, head index 158 [07-18 18:06:57:528 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 151, seqNo 1351, timestamp 1689674817259 [07-18 18:06:57:531 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:57:531 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:45299547 ts:0 [07-18 18:06:57:531 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:45299547 [07-18 18:06:57:531 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1226943 dataSize:367 [07-18 18:06:57:531 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:159 timestamp:1689674817531 [07-18 18:06:57:531 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:45299547 ts:0 [07-18 18:06:57:531 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:45299547 [07-18 18:06:57:531 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:580667 dataSize:367 [07-18 18:06:57:531 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:159 timestamp:1689674817531 [07-18 18:06:57:540 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:57:540 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:57:540 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:57:550 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:57:550 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674817, rept_cnt:25. [07-18 18:06:57:550 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674817, rept_cnt:0. [07-18 18:06:57:550 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674817, rept_cnt:0. [07-18 18:06:57:550 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:06:57:550 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:06:57:550 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:06:57:551 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:06:57:551 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:06:57:551 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:06:57:564 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:45332880 ts:0 [07-18 18:06:57:564 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:45332880 [07-18 18:06:57:564 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1227310 dataSize:141 [07-18 18:06:57:564 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:160 timestamp:1689674817564 [07-18 18:06:57:564 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:45332880 ts:0 [07-18 18:06:57:564 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:45332880 [07-18 18:06:57:564 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:581034 dataSize:141 [07-18 18:06:57:564 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:160 timestamp:1689674817564 [07-18 18:06:57:569 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:06:57:571 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:57:576 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58440 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:06:57:576 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:06:57:598 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:45366213 ts:0 [07-18 18:06:57:598 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:45366213 [07-18 18:06:57:598 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1227451 dataSize:160 [07-18 18:06:57:598 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:161 timestamp:1689674817598 [07-18 18:06:57:598 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:45366213 ts:0 [07-18 18:06:57:598 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:45366213 [07-18 18:06:57:598 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:581175 dataSize:160 [07-18 18:06:57:598 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:161 timestamp:1689674817598 [07-18 18:06:57:604 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:57:604 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:57:604 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:06:57:604 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:06:57:604 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674817, rept_cnt:26. [07-18 18:06:57:604 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674817, rept_cnt:0. [07-18 18:06:57:604 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674817, rept_cnt:0. [07-18 18:06:57:628 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:57:631 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:45399546 ts:0 [07-18 18:06:57:631 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:45399546 [07-18 18:06:57:632 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1227611 dataSize:756 [07-18 18:06:57:632 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:162 timestamp:1689674817632 [07-18 18:06:57:632 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:45399546 ts:0 [07-18 18:06:57:632 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:45399546 [07-18 18:06:57:632 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:581335 dataSize:756 [07-18 18:06:57:632 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:162 timestamp:1689674817632 [07-18 18:06:57:641 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:641 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 151, head index 162 [07-18 18:06:57:641 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 152, seqNo 1352, timestamp 1689674817293 [07-18 18:06:57:641 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:57:665 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:45432879 ts:0 [07-18 18:06:57:665 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:45432879 [07-18 18:06:57:665 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1228367 dataSize:1610 [07-18 18:06:57:665 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:163 timestamp:1689674817665 [07-18 18:06:57:665 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:45432879 ts:0 [07-18 18:06:57:665 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:45432879 [07-18 18:06:57:665 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:582091 dataSize:1610 [07-18 18:06:57:665 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:163 timestamp:1689674817665 [07-18 18:06:57:699 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:45466212 ts:0 [07-18 18:06:57:699 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:45466212 [07-18 18:06:57:699 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1229977 dataSize:516 [07-18 18:06:57:699 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:164 timestamp:1689674817699 [07-18 18:06:57:699 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:45466212 ts:0 [07-18 18:06:57:699 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:45466212 [07-18 18:06:57:699 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:583701 dataSize:516 [07-18 18:06:57:699 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:164 timestamp:1689674817699 [07-18 18:06:57:732 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:45499545 ts:0 [07-18 18:06:57:733 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:45499545 [07-18 18:06:57:733 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1230493 dataSize:231 [07-18 18:06:57:733 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:165 timestamp:1689674817733 [07-18 18:06:57:733 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:45499545 ts:0 [07-18 18:06:57:733 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:45499545 [07-18 18:06:57:733 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:584217 dataSize:231 [07-18 18:06:57:733 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:165 timestamp:1689674817733 [07-18 18:06:57:751 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:751 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 152, head index 165 [07-18 18:06:57:751 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 153, seqNo 1353, timestamp 1689674817327 [07-18 18:06:57:751 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:57:766 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:45532878 ts:0 [07-18 18:06:57:766 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:45532878 [07-18 18:06:57:766 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1230724 dataSize:250 [07-18 18:06:57:766 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:166 timestamp:1689674817766 [07-18 18:06:57:766 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:45532878 ts:0 [07-18 18:06:57:766 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:45532878 [07-18 18:06:57:766 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:584448 dataSize:250 [07-18 18:06:57:766 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:166 timestamp:1689674817766 [07-18 18:06:57:800 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:45566211 ts:0 [07-18 18:06:57:800 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:45566211 [07-18 18:06:57:800 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1230974 dataSize:1143 [07-18 18:06:57:800 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:167 timestamp:1689674817800 [07-18 18:06:57:800 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:45566211 ts:0 [07-18 18:06:57:800 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:45566211 [07-18 18:06:57:800 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:584698 dataSize:1143 [07-18 18:06:57:800 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:167 timestamp:1689674817800 [07-18 18:06:57:833 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:45599544 ts:0 [07-18 18:06:57:833 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:45599544 [07-18 18:06:57:833 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1232117 dataSize:383 [07-18 18:06:57:833 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:168 timestamp:1689674817833 [07-18 18:06:57:833 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:45599544 ts:0 [07-18 18:06:57:833 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:45599544 [07-18 18:06:57:833 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:585841 dataSize:383 [07-18 18:06:57:834 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:168 timestamp:1689674817834 [07-18 18:06:57:862 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:862 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 153, head index 168 [07-18 18:06:57:862 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 154, seqNo 1354, timestamp 1689674817362 [07-18 18:06:57:862 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:57:867 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:45632877 ts:0 [07-18 18:06:57:867 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:45632877 [07-18 18:06:57:867 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1232500 dataSize:235 [07-18 18:06:57:867 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:169 timestamp:1689674817867 [07-18 18:06:57:867 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:45632877 ts:0 [07-18 18:06:57:867 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:45632877 [07-18 18:06:57:867 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:586224 dataSize:235 [07-18 18:06:57:867 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:169 timestamp:1689674817867 [07-18 18:06:57:901 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:45666210 ts:0 [07-18 18:06:57:901 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:45666210 [07-18 18:06:57:901 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1232735 dataSize:165 [07-18 18:06:57:901 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:170 timestamp:1689674817901 [07-18 18:06:57:901 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:45666210 ts:0 [07-18 18:06:57:901 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:45666210 [07-18 18:06:57:901 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:586459 dataSize:165 [07-18 18:06:57:901 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:170 timestamp:1689674817901 [07-18 18:06:57:934 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:45699543 ts:0 [07-18 18:06:57:934 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:45699543 [07-18 18:06:57:934 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1232900 dataSize:457 [07-18 18:06:57:934 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:171 timestamp:1689674817934 [07-18 18:06:57:934 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:45699543 ts:0 [07-18 18:06:57:934 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:45699543 [07-18 18:06:57:934 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:586624 dataSize:457 [07-18 18:06:57:934 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:171 timestamp:1689674817934 [07-18 18:06:57:968 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:45732876 ts:0 [07-18 18:06:57:968 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:45732876 [07-18 18:06:57:968 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1233357 dataSize:673 [07-18 18:06:57:968 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:172 timestamp:1689674817968 [07-18 18:06:57:968 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:45732876 ts:0 [07-18 18:06:57:968 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:45732876 [07-18 18:06:57:968 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:587081 dataSize:673 [07-18 18:06:57:968 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:172 timestamp:1689674817968 [07-18 18:06:57:972 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:57:972 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 154, head index 172 [07-18 18:06:57:972 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 155, seqNo 1355, timestamp 1689674817395 [07-18 18:06:57:972 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:1 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:45766209 ts:0 [07-18 18:06:58:1 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:45766209 [07-18 18:06:58:1 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1234030 dataSize:465 [07-18 18:06:58:1 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:173 timestamp:1689674818001 [07-18 18:06:58:1 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:45766209 ts:0 [07-18 18:06:58:1 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:45766209 [07-18 18:06:58:2 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:587754 dataSize:465 [07-18 18:06:58:2 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:173 timestamp:1689674818002 [07-18 18:06:58:35 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:45799542 ts:0 [07-18 18:06:58:35 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:45799542 [07-18 18:06:58:35 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1234495 dataSize:248 [07-18 18:06:58:35 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:174 timestamp:1689674818035 [07-18 18:06:58:35 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:45799542 ts:0 [07-18 18:06:58:35 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:45799542 [07-18 18:06:58:35 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:588219 dataSize:248 [07-18 18:06:58:35 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:174 timestamp:1689674818035 [07-18 18:06:58:69 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:45832875 ts:0 [07-18 18:06:58:69 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:45832875 [07-18 18:06:58:69 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1234743 dataSize:217 [07-18 18:06:58:69 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:175 timestamp:1689674818069 [07-18 18:06:58:69 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:45832875 ts:0 [07-18 18:06:58:69 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:45832875 [07-18 18:06:58:69 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:588467 dataSize:217 [07-18 18:06:58:69 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:175 timestamp:1689674818069 [07-18 18:06:58:82 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:82 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 155, head index 175 [07-18 18:06:58:82 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 156, seqNo 1356, timestamp 1689674817429 [07-18 18:06:58:82 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:102 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:45866208 ts:0 [07-18 18:06:58:102 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:45866208 [07-18 18:06:58:102 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1234960 dataSize:280 [07-18 18:06:58:102 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:176 timestamp:1689674818102 [07-18 18:06:58:102 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:45866208 ts:0 [07-18 18:06:58:102 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:45866208 [07-18 18:06:58:102 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:588684 dataSize:280 [07-18 18:06:58:102 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:176 timestamp:1689674818102 [07-18 18:06:58:136 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:45899541 ts:0 [07-18 18:06:58:136 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:45899541 [07-18 18:06:58:136 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1235240 dataSize:12088 [07-18 18:06:58:136 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:177 timestamp:1689674818136 [07-18 18:06:58:136 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:45899541 ts:0 [07-18 18:06:58:136 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:45899541 [07-18 18:06:58:136 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:588964 dataSize:12088 [07-18 18:06:58:136 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:177 timestamp:1689674818136 [07-18 18:06:58:170 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:45932874 ts:0 [07-18 18:06:58:170 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:45932874 [07-18 18:06:58:170 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1247328 dataSize:1051 [07-18 18:06:58:170 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:178 timestamp:1689674818170 [07-18 18:06:58:170 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:45932874 ts:0 [07-18 18:06:58:170 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:45932874 [07-18 18:06:58:170 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:601052 dataSize:1051 [07-18 18:06:58:170 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:178 timestamp:1689674818170 [07-18 18:06:58:193 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:193 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 156, head index 178 [07-18 18:06:58:193 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 157, seqNo 1357, timestamp 1689674817463 [07-18 18:06:58:193 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:203 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:45966207 ts:0 [07-18 18:06:58:203 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:45966207 [07-18 18:06:58:203 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1248379 dataSize:209 [07-18 18:06:58:203 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:179 timestamp:1689674818203 [07-18 18:06:58:203 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:45966207 ts:0 [07-18 18:06:58:203 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:45966207 [07-18 18:06:58:203 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:602103 dataSize:209 [07-18 18:06:58:203 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:179 timestamp:1689674818203 [07-18 18:06:58:237 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:45999540 ts:0 [07-18 18:06:58:237 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:45999540 [07-18 18:06:58:237 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1248588 dataSize:118 [07-18 18:06:58:237 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:180 timestamp:1689674818237 [07-18 18:06:58:237 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:45999540 ts:0 [07-18 18:06:58:237 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:45999540 [07-18 18:06:58:237 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:602312 dataSize:118 [07-18 18:06:58:237 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:180 timestamp:1689674818237 [07-18 18:06:58:271 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:46032873 ts:0 [07-18 18:06:58:271 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:46032873 [07-18 18:06:58:271 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1248706 dataSize:110 [07-18 18:06:58:271 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:181 timestamp:1689674818271 [07-18 18:06:58:271 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:46032873 ts:0 [07-18 18:06:58:271 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:46032873 [07-18 18:06:58:271 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:602430 dataSize:110 [07-18 18:06:58:271 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:181 timestamp:1689674818271 [07-18 18:06:58:303 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:303 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 157, head index 181 [07-18 18:06:58:303 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 158, seqNo 1358, timestamp 1689674817496 [07-18 18:06:58:303 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:304 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:46066206 ts:0 [07-18 18:06:58:304 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:46066206 [07-18 18:06:58:304 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1248816 dataSize:695 [07-18 18:06:58:304 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:182 timestamp:1689674818304 [07-18 18:06:58:304 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:46066206 ts:0 [07-18 18:06:58:304 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:46066206 [07-18 18:06:58:304 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:602540 dataSize:695 [07-18 18:06:58:304 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:182 timestamp:1689674818304 [07-18 18:06:58:338 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:46099539 ts:0 [07-18 18:06:58:338 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:46099539 [07-18 18:06:58:338 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1249511 dataSize:1146 [07-18 18:06:58:338 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:183 timestamp:1689674818338 [07-18 18:06:58:338 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:46099539 ts:0 [07-18 18:06:58:338 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:46099539 [07-18 18:06:58:338 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:603235 dataSize:1146 [07-18 18:06:58:338 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:183 timestamp:1689674818338 [07-18 18:06:58:361 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[49] [07-18 18:06:58:371 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:46132872 ts:0 [07-18 18:06:58:371 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:46132872 [07-18 18:06:58:371 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1250657 dataSize:276 [07-18 18:06:58:371 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:184 timestamp:1689674818371 [07-18 18:06:58:371 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:46132872 ts:0 [07-18 18:06:58:371 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:46132872 [07-18 18:06:58:371 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:604381 dataSize:276 [07-18 18:06:58:371 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:184 timestamp:1689674818371 [07-18 18:06:58:405 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:46166205 ts:0 [07-18 18:06:58:405 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:46166205 [07-18 18:06:58:405 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1250933 dataSize:152 [07-18 18:06:58:405 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:185 timestamp:1689674818405 [07-18 18:06:58:405 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:46166205 ts:0 [07-18 18:06:58:405 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:46166205 [07-18 18:06:58:405 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:604657 dataSize:152 [07-18 18:06:58:405 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:185 timestamp:1689674818405 [07-18 18:06:58:414 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:414 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 158, head index 185 [07-18 18:06:58:414 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 159, seqNo 1359, timestamp 1689674817531 [07-18 18:06:58:414 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:439 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:46199538 ts:0 [07-18 18:06:58:439 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:46199538 [07-18 18:06:58:439 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1251085 dataSize:136 [07-18 18:06:58:439 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:186 timestamp:1689674818439 [07-18 18:06:58:439 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:46199538 ts:0 [07-18 18:06:58:439 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:46199538 [07-18 18:06:58:439 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:604809 dataSize:136 [07-18 18:06:58:439 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:186 timestamp:1689674818439 [07-18 18:06:58:472 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:46232871 ts:0 [07-18 18:06:58:472 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:46232871 [07-18 18:06:58:472 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1251221 dataSize:725 [07-18 18:06:58:472 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:187 timestamp:1689674818472 [07-18 18:06:58:472 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:46232871 ts:0 [07-18 18:06:58:472 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:46232871 [07-18 18:06:58:472 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:604945 dataSize:725 [07-18 18:06:58:472 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:187 timestamp:1689674818472 [07-18 18:06:58:506 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:46266204 ts:0 [07-18 18:06:58:506 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:46266204 [07-18 18:06:58:506 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1251946 dataSize:1369 [07-18 18:06:58:506 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:188 timestamp:1689674818506 [07-18 18:06:58:506 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:46266204 ts:0 [07-18 18:06:58:506 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:46266204 [07-18 18:06:58:506 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:605670 dataSize:1369 [07-18 18:06:58:506 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:188 timestamp:1689674818506 [07-18 18:06:58:524 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:524 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 159, head index 188 [07-18 18:06:58:524 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 160, seqNo 1360, timestamp 1689674817564 [07-18 18:06:58:524 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:539 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:46299537 ts:0 [07-18 18:06:58:539 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:46299537 [07-18 18:06:58:539 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1253315 dataSize:367 [07-18 18:06:58:539 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:189 timestamp:1689674818539 [07-18 18:06:58:539 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:46299537 ts:0 [07-18 18:06:58:539 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:46299537 [07-18 18:06:58:540 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:607039 dataSize:367 [07-18 18:06:58:540 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:189 timestamp:1689674818540 [07-18 18:06:58:573 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:46332870 ts:0 [07-18 18:06:58:573 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:46332870 [07-18 18:06:58:573 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1253682 dataSize:141 [07-18 18:06:58:573 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:190 timestamp:1689674818573 [07-18 18:06:58:573 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:46332870 ts:0 [07-18 18:06:58:573 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:46332870 [07-18 18:06:58:573 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:607406 dataSize:141 [07-18 18:06:58:573 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:190 timestamp:1689674818573 [07-18 18:06:58:607 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:46366203 ts:0 [07-18 18:06:58:607 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:46366203 [07-18 18:06:58:607 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1253823 dataSize:160 [07-18 18:06:58:607 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:191 timestamp:1689674818607 [07-18 18:06:58:607 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:46366203 ts:0 [07-18 18:06:58:607 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:46366203 [07-18 18:06:58:607 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:607547 dataSize:160 [07-18 18:06:58:607 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:191 timestamp:1689674818607 [07-18 18:06:58:629 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:58:629 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:58:634 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:635 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 160, head index 191 [07-18 18:06:58:635 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 161, seqNo 1361, timestamp 1689674817598 [07-18 18:06:58:635 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:641 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:46399536 ts:0 [07-18 18:06:58:641 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:46399536 [07-18 18:06:58:641 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1253983 dataSize:756 [07-18 18:06:58:641 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:192 timestamp:1689674818641 [07-18 18:06:58:641 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:46399536 ts:0 [07-18 18:06:58:641 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:46399536 [07-18 18:06:58:641 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:607707 dataSize:756 [07-18 18:06:58:641 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:192 timestamp:1689674818641 [07-18 18:06:58:674 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:46432869 ts:0 [07-18 18:06:58:674 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:46432869 [07-18 18:06:58:674 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1254739 dataSize:1610 [07-18 18:06:58:674 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:193 timestamp:1689674818674 [07-18 18:06:58:674 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:46432869 ts:0 [07-18 18:06:58:674 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:46432869 [07-18 18:06:58:674 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:608463 dataSize:1610 [07-18 18:06:58:674 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:193 timestamp:1689674818674 [07-18 18:06:58:701 TUYA Trace][app_agent.c:786] lan listen select timeout [07-18 18:06:58:708 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:46466202 ts:0 [07-18 18:06:58:708 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:46466202 [07-18 18:06:58:708 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1256349 dataSize:516 [07-18 18:06:58:708 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:194 timestamp:1689674818708 [07-18 18:06:58:708 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:46466202 ts:0 [07-18 18:06:58:708 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:46466202 [07-18 18:06:58:708 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:610073 dataSize:516 [07-18 18:06:58:708 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:194 timestamp:1689674818708 [07-18 18:06:58:742 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:46499535 ts:0 [07-18 18:06:58:742 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:46499535 [07-18 18:06:58:742 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1256865 dataSize:231 [07-18 18:06:58:742 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:195 timestamp:1689674818742 [07-18 18:06:58:742 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:46499535 ts:0 [07-18 18:06:58:742 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:46499535 [07-18 18:06:58:742 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:610589 dataSize:231 [07-18 18:06:58:742 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:195 timestamp:1689674818742 [07-18 18:06:58:745 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:745 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 161, head index 195 [07-18 18:06:58:745 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 162, seqNo 1362, timestamp 1689674817632 [07-18 18:06:58:745 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:775 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:46532868 ts:0 [07-18 18:06:58:775 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:46532868 [07-18 18:06:58:775 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1257096 dataSize:250 [07-18 18:06:58:775 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:196 timestamp:1689674818775 [07-18 18:06:58:775 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:46532868 ts:0 [07-18 18:06:58:775 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:46532868 [07-18 18:06:58:775 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:610820 dataSize:250 [07-18 18:06:58:776 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:196 timestamp:1689674818776 [07-18 18:06:58:809 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:46566201 ts:0 [07-18 18:06:58:809 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:46566201 [07-18 18:06:58:809 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1257346 dataSize:1143 [07-18 18:06:58:809 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:197 timestamp:1689674818809 [07-18 18:06:58:809 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:46566201 ts:0 [07-18 18:06:58:809 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:46566201 [07-18 18:06:58:809 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:611070 dataSize:1143 [07-18 18:06:58:809 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:197 timestamp:1689674818809 [07-18 18:06:58:843 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:46599534 ts:0 [07-18 18:06:58:843 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:46599534 [07-18 18:06:58:843 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1258489 dataSize:383 [07-18 18:06:58:843 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:198 timestamp:1689674818843 [07-18 18:06:58:843 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:46599534 ts:0 [07-18 18:06:58:843 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:46599534 [07-18 18:06:58:843 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:612213 dataSize:383 [07-18 18:06:58:843 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:198 timestamp:1689674818843 [07-18 18:06:58:856 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:856 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 162, head index 198 [07-18 18:06:58:856 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 163, seqNo 1363, timestamp 1689674817665 [07-18 18:06:58:856 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:876 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:46632867 ts:0 [07-18 18:06:58:876 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:46632867 [07-18 18:06:58:876 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1258872 dataSize:235 [07-18 18:06:58:876 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:199 timestamp:1689674818876 [07-18 18:06:58:876 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:46632867 ts:0 [07-18 18:06:58:876 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:46632867 [07-18 18:06:58:876 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:612596 dataSize:235 [07-18 18:06:58:876 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:199 timestamp:1689674818876 [07-18 18:06:58:910 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:46666200 ts:0 [07-18 18:06:58:910 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:46666200 [07-18 18:06:58:910 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1259107 dataSize:165 [07-18 18:06:58:910 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:200 timestamp:1689674818910 [07-18 18:06:58:910 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:46666200 ts:0 [07-18 18:06:58:910 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:46666200 [07-18 18:06:58:910 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:612831 dataSize:165 [07-18 18:06:58:910 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:200 timestamp:1689674818910 [07-18 18:06:58:943 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:46699533 ts:0 [07-18 18:06:58:943 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:46699533 [07-18 18:06:58:943 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1259272 dataSize:457 [07-18 18:06:58:944 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:201 timestamp:1689674818944 [07-18 18:06:58:944 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:46699533 ts:0 [07-18 18:06:58:944 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:46699533 [07-18 18:06:58:944 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:612996 dataSize:457 [07-18 18:06:58:944 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:201 timestamp:1689674818944 [07-18 18:06:58:966 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:58:966 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 163, head index 201 [07-18 18:06:58:966 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 164, seqNo 1364, timestamp 1689674817699 [07-18 18:06:58:966 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:58:977 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:46732866 ts:0 [07-18 18:06:58:977 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:46732866 [07-18 18:06:58:977 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1259729 dataSize:673 [07-18 18:06:58:977 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:202 timestamp:1689674818977 [07-18 18:06:58:977 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:46732866 ts:0 [07-18 18:06:58:977 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:46732866 [07-18 18:06:58:977 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:613453 dataSize:673 [07-18 18:06:58:977 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:202 timestamp:1689674818977 [07-18 18:06:59:11 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:46766199 ts:0 [07-18 18:06:59:11 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:46766199 [07-18 18:06:59:11 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1260402 dataSize:465 [07-18 18:06:59:11 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:203 timestamp:1689674819011 [07-18 18:06:59:11 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:46766199 ts:0 [07-18 18:06:59:11 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:46766199 [07-18 18:06:59:11 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:614126 dataSize:465 [07-18 18:06:59:11 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:203 timestamp:1689674819011 [07-18 18:06:59:44 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:46799532 ts:0 [07-18 18:06:59:44 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:46799532 [07-18 18:06:59:44 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1260867 dataSize:248 [07-18 18:06:59:44 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:204 timestamp:1689674819044 [07-18 18:06:59:44 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:46799532 ts:0 [07-18 18:06:59:44 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:46799532 [07-18 18:06:59:44 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:614591 dataSize:248 [07-18 18:06:59:45 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:204 timestamp:1689674819044 [07-18 18:06:59:78 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:46832865 ts:0 [07-18 18:06:59:78 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:46832865 [07-18 18:06:59:78 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1261115 dataSize:217 [07-18 18:06:59:78 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:205 timestamp:1689674819078 [07-18 18:06:59:78 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:46832865 ts:0 [07-18 18:06:59:78 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:46832865 [07-18 18:06:59:78 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:614839 dataSize:217 [07-18 18:06:59:78 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:205 timestamp:1689674819078 [07-18 18:06:59:81 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:81 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 164, head index 205 [07-18 18:06:59:81 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 165, seqNo 1365, timestamp 1689674817733 [07-18 18:06:59:81 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:112 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:46866198 ts:0 [07-18 18:06:59:112 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:46866198 [07-18 18:06:59:112 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1261332 dataSize:280 [07-18 18:06:59:112 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:206 timestamp:1689674819112 [07-18 18:06:59:112 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:46866198 ts:0 [07-18 18:06:59:112 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:46866198 [07-18 18:06:59:112 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:615056 dataSize:280 [07-18 18:06:59:112 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:206 timestamp:1689674819112 [07-18 18:06:59:146 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:46899531 ts:0 [07-18 18:06:59:146 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:46899531 [07-18 18:06:59:146 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1261612 dataSize:12088 [07-18 18:06:59:146 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:207 timestamp:1689674819146 [07-18 18:06:59:146 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:46899531 ts:0 [07-18 18:06:59:146 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:46899531 [07-18 18:06:59:146 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:615336 dataSize:12088 [07-18 18:06:59:146 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:207 timestamp:1689674819146 [07-18 18:06:59:180 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:46932864 ts:0 [07-18 18:06:59:180 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:46932864 [07-18 18:06:59:180 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1273700 dataSize:1051 [07-18 18:06:59:180 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:208 timestamp:1689674819180 [07-18 18:06:59:180 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:46932864 ts:0 [07-18 18:06:59:180 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:46932864 [07-18 18:06:59:180 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:627424 dataSize:1051 [07-18 18:06:59:180 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:208 timestamp:1689674819180 [07-18 18:06:59:191 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:191 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 165, head index 208 [07-18 18:06:59:192 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 166, seqNo 1366, timestamp 1689674817766 [07-18 18:06:59:192 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:213 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:46966197 ts:0 [07-18 18:06:59:213 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:46966197 [07-18 18:06:59:213 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1274751 dataSize:209 [07-18 18:06:59:213 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:209 timestamp:1689674819213 [07-18 18:06:59:213 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:46966197 ts:0 [07-18 18:06:59:213 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:46966197 [07-18 18:06:59:214 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:628475 dataSize:209 [07-18 18:06:59:214 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:209 timestamp:1689674819214 [07-18 18:06:59:247 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:46999530 ts:0 [07-18 18:06:59:247 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:46999530 [07-18 18:06:59:247 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1274960 dataSize:118 [07-18 18:06:59:247 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:210 timestamp:1689674819247 [07-18 18:06:59:247 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:46999530 ts:0 [07-18 18:06:59:247 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:46999530 [07-18 18:06:59:247 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:628684 dataSize:118 [07-18 18:06:59:247 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:210 timestamp:1689674819247 [07-18 18:06:59:281 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:47032863 ts:0 [07-18 18:06:59:281 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:47032863 [07-18 18:06:59:281 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1275078 dataSize:110 [07-18 18:06:59:281 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:211 timestamp:1689674819281 [07-18 18:06:59:281 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:47032863 ts:0 [07-18 18:06:59:281 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:47032863 [07-18 18:06:59:281 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:628802 dataSize:110 [07-18 18:06:59:281 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:211 timestamp:1689674819281 [07-18 18:06:59:293 TUYA Debug][tuya_ipc_p2p.c:5031] session[65539] detech staticCnt[0]lstCnt[204]vIFrameCnt[204] [07-18 18:06:59:293 TUYA Debug][tuya_ipc_p2p.c:5031] session[327681] detech staticCnt[1]lstCnt[1]vIFrameCnt[1] [07-18 18:06:59:302 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:302 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 166, head index 211 [07-18 18:06:59:302 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 167, seqNo 1367, timestamp 1689674817800 [07-18 18:06:59:302 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:314 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:47066196 ts:0 [07-18 18:06:59:314 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:47066196 [07-18 18:06:59:314 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1275188 dataSize:695 [07-18 18:06:59:314 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:212 timestamp:1689674819314 [07-18 18:06:59:314 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:47066196 ts:0 [07-18 18:06:59:314 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:47066196 [07-18 18:06:59:314 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:628912 dataSize:695 [07-18 18:06:59:314 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:212 timestamp:1689674819314 [07-18 18:06:59:348 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:47099529 ts:0 [07-18 18:06:59:348 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:47099529 [07-18 18:06:59:348 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1275883 dataSize:1146 [07-18 18:06:59:348 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:213 timestamp:1689674819348 [07-18 18:06:59:348 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:47099529 ts:0 [07-18 18:06:59:348 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:47099529 [07-18 18:06:59:348 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:629607 dataSize:1146 [07-18 18:06:59:348 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:213 timestamp:1689674819348 [07-18 18:06:59:382 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:47132862 ts:0 [07-18 18:06:59:382 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:47132862 [07-18 18:06:59:382 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1277029 dataSize:276 [07-18 18:06:59:382 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:214 timestamp:1689674819382 [07-18 18:06:59:382 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:47132862 ts:0 [07-18 18:06:59:382 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:47132862 [07-18 18:06:59:382 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:630753 dataSize:276 [07-18 18:06:59:382 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:214 timestamp:1689674819382 [07-18 18:06:59:414 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:414 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 167, head index 214 [07-18 18:06:59:414 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 168, seqNo 1368, timestamp 1689674817833 [07-18 18:06:59:414 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:415 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:47166195 ts:0 [07-18 18:06:59:415 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:47166195 [07-18 18:06:59:415 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1277305 dataSize:152 [07-18 18:06:59:415 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:215 timestamp:1689674819415 [07-18 18:06:59:415 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:47166195 ts:0 [07-18 18:06:59:415 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:47166195 [07-18 18:06:59:415 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:631029 dataSize:152 [07-18 18:06:59:415 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:215 timestamp:1689674819415 [07-18 18:06:59:453 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:47199528 ts:0 [07-18 18:06:59:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:47199528 [07-18 18:06:59:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1277457 dataSize:136 [07-18 18:06:59:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:216 timestamp:1689674819454 [07-18 18:06:59:454 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:47199528 ts:0 [07-18 18:06:59:454 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:47199528 [07-18 18:06:59:454 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:631181 dataSize:136 [07-18 18:06:59:454 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:216 timestamp:1689674819454 [07-18 18:06:59:487 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:47232861 ts:0 [07-18 18:06:59:487 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:47232861 [07-18 18:06:59:487 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1277593 dataSize:725 [07-18 18:06:59:487 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:217 timestamp:1689674819487 [07-18 18:06:59:487 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:47232861 ts:0 [07-18 18:06:59:487 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:47232861 [07-18 18:06:59:487 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:631317 dataSize:725 [07-18 18:06:59:487 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:217 timestamp:1689674819487 [07-18 18:06:59:521 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:47266194 ts:0 [07-18 18:06:59:521 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:47266194 [07-18 18:06:59:521 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1278318 dataSize:1369 [07-18 18:06:59:521 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:218 timestamp:1689674819521 [07-18 18:06:59:521 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:47266194 ts:0 [07-18 18:06:59:521 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:47266194 [07-18 18:06:59:521 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:632042 dataSize:1369 [07-18 18:06:59:521 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:218 timestamp:1689674819521 [07-18 18:06:59:524 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:524 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 168, head index 218 [07-18 18:06:59:524 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 169, seqNo 1369, timestamp 1689674817867 [07-18 18:06:59:524 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:555 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:47299527 ts:0 [07-18 18:06:59:555 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:47299527 [07-18 18:06:59:555 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1279687 dataSize:367 [07-18 18:06:59:555 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:219 timestamp:1689674819555 [07-18 18:06:59:555 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:47299527 ts:0 [07-18 18:06:59:555 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:47299527 [07-18 18:06:59:555 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:633411 dataSize:367 [07-18 18:06:59:555 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:219 timestamp:1689674819555 [07-18 18:06:59:588 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:47332860 ts:0 [07-18 18:06:59:588 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:47332860 [07-18 18:06:59:588 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1280054 dataSize:141 [07-18 18:06:59:588 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:220 timestamp:1689674819588 [07-18 18:06:59:588 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:47332860 ts:0 [07-18 18:06:59:588 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:47332860 [07-18 18:06:59:588 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:633778 dataSize:141 [07-18 18:06:59:588 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:220 timestamp:1689674819588 [07-18 18:06:59:622 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:47366193 ts:0 [07-18 18:06:59:622 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:47366193 [07-18 18:06:59:622 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1280195 dataSize:160 [07-18 18:06:59:622 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:221 timestamp:1689674819622 [07-18 18:06:59:622 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:47366193 ts:0 [07-18 18:06:59:622 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:47366193 [07-18 18:06:59:622 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:633919 dataSize:160 [07-18 18:06:59:622 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:221 timestamp:1689674819622 [07-18 18:06:59:631 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:06:59:631 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:06:59:634 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:635 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 169, head index 221 [07-18 18:06:59:635 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 170, seqNo 1370, timestamp 1689674817901 [07-18 18:06:59:635 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:655 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:47399526 ts:0 [07-18 18:06:59:655 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:47399526 [07-18 18:06:59:655 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1280355 dataSize:756 [07-18 18:06:59:655 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:222 timestamp:1689674819655 [07-18 18:06:59:655 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:47399526 ts:0 [07-18 18:06:59:656 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:47399526 [07-18 18:06:59:656 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:634079 dataSize:756 [07-18 18:06:59:656 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:222 timestamp:1689674819656 [07-18 18:06:59:689 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:47432859 ts:0 [07-18 18:06:59:689 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:47432859 [07-18 18:06:59:689 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1281111 dataSize:1610 [07-18 18:06:59:689 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:223 timestamp:1689674819689 [07-18 18:06:59:689 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:47432859 ts:0 [07-18 18:06:59:689 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:47432859 [07-18 18:06:59:689 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:634835 dataSize:1610 [07-18 18:06:59:689 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:223 timestamp:1689674819689 [07-18 18:06:59:723 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:47466192 ts:0 [07-18 18:06:59:723 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:47466192 [07-18 18:06:59:723 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1282721 dataSize:516 [07-18 18:06:59:723 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:224 timestamp:1689674819723 [07-18 18:06:59:723 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:47466192 ts:0 [07-18 18:06:59:723 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:47466192 [07-18 18:06:59:723 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:636445 dataSize:516 [07-18 18:06:59:723 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:224 timestamp:1689674819723 [07-18 18:06:59:745 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:745 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 170, head index 224 [07-18 18:06:59:745 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 171, seqNo 1371, timestamp 1689674817934 [07-18 18:06:59:745 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:756 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:47499525 ts:0 [07-18 18:06:59:756 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:47499525 [07-18 18:06:59:756 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1283237 dataSize:231 [07-18 18:06:59:756 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:225 timestamp:1689674819756 [07-18 18:06:59:757 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:47499525 ts:0 [07-18 18:06:59:757 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:47499525 [07-18 18:06:59:757 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:636961 dataSize:231 [07-18 18:06:59:757 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:225 timestamp:1689674819757 [07-18 18:06:59:790 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:47532858 ts:0 [07-18 18:06:59:790 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:47532858 [07-18 18:06:59:790 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1283468 dataSize:250 [07-18 18:06:59:790 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:226 timestamp:1689674819790 [07-18 18:06:59:790 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:47532858 ts:0 [07-18 18:06:59:790 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:47532858 [07-18 18:06:59:790 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:637192 dataSize:250 [07-18 18:06:59:790 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:226 timestamp:1689674819790 [07-18 18:06:59:824 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:47566191 ts:0 [07-18 18:06:59:824 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:47566191 [07-18 18:06:59:824 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1283718 dataSize:1143 [07-18 18:06:59:824 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:227 timestamp:1689674819824 [07-18 18:06:59:824 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:47566191 ts:0 [07-18 18:06:59:824 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:47566191 [07-18 18:06:59:824 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:637442 dataSize:1143 [07-18 18:06:59:824 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:227 timestamp:1689674819824 [07-18 18:06:59:855 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:855 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 171, head index 227 [07-18 18:06:59:855 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 172, seqNo 1372, timestamp 1689674817968 [07-18 18:06:59:855 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:857 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:47599524 ts:0 [07-18 18:06:59:857 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:47599524 [07-18 18:06:59:857 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1284861 dataSize:383 [07-18 18:06:59:857 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:228 timestamp:1689674819857 [07-18 18:06:59:858 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:47599524 ts:0 [07-18 18:06:59:858 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:47599524 [07-18 18:06:59:858 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:638585 dataSize:383 [07-18 18:06:59:858 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:228 timestamp:1689674819858 [07-18 18:06:59:891 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:47632857 ts:0 [07-18 18:06:59:891 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:47632857 [07-18 18:06:59:891 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1285244 dataSize:235 [07-18 18:06:59:891 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:229 timestamp:1689674819891 [07-18 18:06:59:891 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:47632857 ts:0 [07-18 18:06:59:891 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:47632857 [07-18 18:06:59:891 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:638968 dataSize:235 [07-18 18:06:59:891 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:229 timestamp:1689674819891 [07-18 18:06:59:925 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:47666190 ts:0 [07-18 18:06:59:925 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:47666190 [07-18 18:06:59:925 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1285479 dataSize:165 [07-18 18:06:59:925 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:230 timestamp:1689674819925 [07-18 18:06:59:925 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:47666190 ts:0 [07-18 18:06:59:925 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:47666190 [07-18 18:06:59:925 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:639203 dataSize:165 [07-18 18:06:59:925 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:230 timestamp:1689674819925 [07-18 18:06:59:958 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:47699523 ts:0 [07-18 18:06:59:958 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:47699523 [07-18 18:06:59:958 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1285644 dataSize:457 [07-18 18:06:59:958 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:231 timestamp:1689674819958 [07-18 18:06:59:958 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:47699523 ts:0 [07-18 18:06:59:958 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:47699523 [07-18 18:06:59:958 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:639368 dataSize:457 [07-18 18:06:59:958 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:231 timestamp:1689674819958 [07-18 18:06:59:965 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:06:59:966 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 172, head index 231 [07-18 18:06:59:966 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 173, seqNo 1373, timestamp 1689674818001 [07-18 18:06:59:966 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:06:59:992 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:47732856 ts:0 [07-18 18:06:59:992 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:47732856 [07-18 18:06:59:992 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1286101 dataSize:673 [07-18 18:06:59:992 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:232 timestamp:1689674819992 [07-18 18:06:59:992 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:47732856 ts:0 [07-18 18:06:59:992 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:47732856 [07-18 18:06:59:992 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:639825 dataSize:673 [07-18 18:06:59:992 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:232 timestamp:1689674819992 [07-18 18:07:00:26 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:47766189 ts:0 [07-18 18:07:00:26 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:47766189 [07-18 18:07:00:26 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1286774 dataSize:465 [07-18 18:07:00:26 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:233 timestamp:1689674820026 [07-18 18:07:00:26 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:47766189 ts:0 [07-18 18:07:00:26 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:47766189 [07-18 18:07:00:26 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:640498 dataSize:465 [07-18 18:07:00:26 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:233 timestamp:1689674820026 [07-18 18:07:00:59 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:47799522 ts:0 [07-18 18:07:00:59 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:47799522 [07-18 18:07:00:59 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1287239 dataSize:248 [07-18 18:07:00:59 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:234 timestamp:1689674820059 [07-18 18:07:00:59 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:47799522 ts:0 [07-18 18:07:00:59 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:47799522 [07-18 18:07:00:59 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:640963 dataSize:248 [07-18 18:07:00:59 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:234 timestamp:1689674820059 [07-18 18:07:00:77 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:00:77 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 173, head index 234 [07-18 18:07:00:77 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 174, seqNo 1374, timestamp 1689674818035 [07-18 18:07:00:77 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:00:89 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[53] [07-18 18:07:00:93 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:47832855 ts:0 [07-18 18:07:00:93 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:47832855 [07-18 18:07:00:93 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1287487 dataSize:217 [07-18 18:07:00:93 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:235 timestamp:1689674820093 [07-18 18:07:00:93 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:47832855 ts:0 [07-18 18:07:00:93 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:47832855 [07-18 18:07:00:93 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:641211 dataSize:217 [07-18 18:07:00:93 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:235 timestamp:1689674820093 [07-18 18:07:00:127 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:47866188 ts:0 [07-18 18:07:00:127 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:47866188 [07-18 18:07:00:127 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1287704 dataSize:280 [07-18 18:07:00:127 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:236 timestamp:1689674820127 [07-18 18:07:00:127 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:47866188 ts:0 [07-18 18:07:00:127 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:47866188 [07-18 18:07:00:127 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:641428 dataSize:280 [07-18 18:07:00:127 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:236 timestamp:1689674820127 [07-18 18:07:00:160 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:47899521 ts:0 [07-18 18:07:00:160 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:47899521 [07-18 18:07:00:160 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1287984 dataSize:12088 [07-18 18:07:00:160 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:237 timestamp:1689674820160 [07-18 18:07:00:160 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:47899521 ts:0 [07-18 18:07:00:160 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:47899521 [07-18 18:07:00:160 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:641708 dataSize:12088 [07-18 18:07:00:160 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:237 timestamp:1689674820160 [07-18 18:07:00:187 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:00:187 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 174, head index 237 [07-18 18:07:00:187 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 175, seqNo 1375, timestamp 1689674818069 [07-18 18:07:00:187 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:00:194 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:47932854 ts:0 [07-18 18:07:00:194 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:47932854 [07-18 18:07:00:194 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1300072 dataSize:1051 [07-18 18:07:00:194 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:238 timestamp:1689674820194 [07-18 18:07:00:195 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:47932854 ts:0 [07-18 18:07:00:195 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:47932854 [07-18 18:07:00:195 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:653796 dataSize:1051 [07-18 18:07:00:195 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:238 timestamp:1689674820195 [07-18 18:07:00:228 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:47966187 ts:0 [07-18 18:07:00:228 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:47966187 [07-18 18:07:00:228 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1301123 dataSize:209 [07-18 18:07:00:228 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:239 timestamp:1689674820228 [07-18 18:07:00:228 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:47966187 ts:0 [07-18 18:07:00:228 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:47966187 [07-18 18:07:00:228 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:654847 dataSize:209 [07-18 18:07:00:228 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:239 timestamp:1689674820228 [07-18 18:07:00:262 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:47999520 ts:0 [07-18 18:07:00:262 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:47999520 [07-18 18:07:00:262 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1301332 dataSize:118 [07-18 18:07:00:262 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:240 timestamp:1689674820262 [07-18 18:07:00:262 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:47999520 ts:0 [07-18 18:07:00:262 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:47999520 [07-18 18:07:00:262 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:655056 dataSize:118 [07-18 18:07:00:262 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:240 timestamp:1689674820262 [07-18 18:07:00:295 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:48032853 ts:0 [07-18 18:07:00:295 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:48032853 [07-18 18:07:00:295 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1301450 dataSize:110 [07-18 18:07:00:295 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:241 timestamp:1689674820295 [07-18 18:07:00:295 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:48032853 ts:0 [07-18 18:07:00:295 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:48032853 [07-18 18:07:00:295 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:655174 dataSize:110 [07-18 18:07:00:295 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:241 timestamp:1689674820295 [07-18 18:07:00:298 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:00:298 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 175, head index 241 [07-18 18:07:00:298 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 176, seqNo 1376, timestamp 1689674818102 [07-18 18:07:00:298 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:00:329 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:48066186 ts:0 [07-18 18:07:00:329 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:48066186 [07-18 18:07:00:329 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1301560 dataSize:695 [07-18 18:07:00:329 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:242 timestamp:1689674820329 [07-18 18:07:00:329 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:48066186 ts:0 [07-18 18:07:00:329 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:48066186 [07-18 18:07:00:329 TUYA Trace][tuya_ring_buffer.c:152] reach end,restart.ch0st0tr1 tailOffset:655284 dataSize:695 [07-18 18:07:00:329 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:242 timestamp:1689674820329 [07-18 18:07:00:363 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:48099519 ts:0 [07-18 18:07:00:363 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:48099519 [07-18 18:07:00:363 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1302255 dataSize:1146 [07-18 18:07:00:363 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:243 timestamp:1689674820363 [07-18 18:07:00:363 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:48099519 ts:0 [07-18 18:07:00:363 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:48099519 [07-18 18:07:00:363 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:695 dataSize:1146 [07-18 18:07:00:363 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:243 timestamp:1689674820363 [07-18 18:07:00:396 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:48132852 ts:0 [07-18 18:07:00:396 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:48132852 [07-18 18:07:00:396 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1303401 dataSize:276 [07-18 18:07:00:396 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:244 timestamp:1689674820396 [07-18 18:07:00:396 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:48132852 ts:0 [07-18 18:07:00:396 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:48132852 [07-18 18:07:00:396 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:1841 dataSize:276 [07-18 18:07:00:397 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:244 timestamp:1689674820397 [07-18 18:07:00:408 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:00:408 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 176, head index 244 [07-18 18:07:00:408 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 177, seqNo 1377, timestamp 1689674818136 [07-18 18:07:00:408 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:00:430 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:48166185 ts:0 [07-18 18:07:00:430 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:48166185 [07-18 18:07:00:430 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1303677 dataSize:152 [07-18 18:07:00:430 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:245 timestamp:1689674820430 [07-18 18:07:00:430 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:48166185 ts:0 [07-18 18:07:00:430 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:48166185 [07-18 18:07:00:430 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:2117 dataSize:152 [07-18 18:07:00:430 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:245 timestamp:1689674820430 [07-18 18:07:00:464 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:48199518 ts:0 [07-18 18:07:00:464 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:48199518 [07-18 18:07:00:464 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1303829 dataSize:136 [07-18 18:07:00:464 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:246 timestamp:1689674820464 [07-18 18:07:00:464 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:48199518 ts:0 [07-18 18:07:00:464 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:48199518 [07-18 18:07:00:464 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:2269 dataSize:136 [07-18 18:07:00:464 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:246 timestamp:1689674820464 [07-18 18:07:00:497 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:48232851 ts:0 [07-18 18:07:00:497 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:48232851 [07-18 18:07:00:497 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1303965 dataSize:725 [07-18 18:07:00:497 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:247 timestamp:1689674820497 [07-18 18:07:00:497 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:48232851 ts:0 [07-18 18:07:00:497 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:48232851 [07-18 18:07:00:497 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:2405 dataSize:725 [07-18 18:07:00:497 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:247 timestamp:1689674820497 [07-18 18:07:00:519 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:00:519 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 177, head index 247 [07-18 18:07:00:519 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 178, seqNo 1378, timestamp 1689674818170 [07-18 18:07:00:519 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:00:531 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:48266184 ts:0 [07-18 18:07:00:531 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:48266184 [07-18 18:07:00:531 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:1304690 dataSize:1369 [07-18 18:07:00:531 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:248 timestamp:1689674820531 [07-18 18:07:00:531 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:48266184 ts:0 [07-18 18:07:00:531 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:48266184 [07-18 18:07:00:531 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:3130 dataSize:1369 [07-18 18:07:00:531 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:248 timestamp:1689674820531 [07-18 18:07:00:532 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [6] low cmd[3] [07-18 18:07:00:532 TUYA Debug][tuya_ipc_p2p.c:2006] session[327681] [1] send video stop to dev [07-18 18:07:00:532 TUYA Debug][tuya_ipc_p2p.c:2013] session[327681] video stop [07-18 18:07:00:629 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:00:632 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:07:00:632 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:00:680 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [6] low cmd[5] [07-18 18:07:00:680 TUYA Debug][tuya_ipc_p2p.c:2100] session[327681] [1] send audio stop to dev [07-18 18:07:00:963 TUYA Debug][tuya_ipc_p2p.c:4072] video send proc alive [115000] [07-18 18:07:01:474 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f28000900] len[57] [07-18 18:07:01:633 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:07:01:633 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:02:459 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [9] low cmd[0] [07-18 18:07:02:521 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [9] low cmd[0] [07-18 18:07:02:582 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [6] low cmd[0] [07-18 18:07:02:582 TUYA Debug][tuya_ipc_p2p.c:1911] open ringbuff handle[(nil)] stream[0] [07-18 18:07:02:582 TUYA Debug][tuya_ipc_p2p.c:1946] session[327681]video video_start wait_concurr_idle [07-18 18:07:02:582 TUYA Debug][tuya_ipc_p2p.c:5134] session[327681] __p2p_wait_concurr_idle start [07-18 18:07:02:612 TUYA Debug][tuya_ipc_p2p.c:5151] session[327681] concurr idle[2][2] [07-18 18:07:02:612 TUYA Debug][tuya_ipc_p2p.c:5157] session[327681] __p2p_wait_concurr_idle end [07-18 18:07:02:612 TUYA Debug][tuya_ipc_p2p.c:1978] session[327681] [1] send video start to dev [07-18 18:07:02:612 TUYA Debug][tuya_ipc_p2p.c:1984] session video start[327681] [07-18 18:07:02:612 TUYA Debug][linkbey_sdk_v11.cpp:573] start live video using /oem/ros_file/demo7_video.264 [07-18 18:07:02:613 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:48299517 ts:0 [07-18 18:07:02:613 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:48299517 [07-18 18:07:02:613 TUYA Trace][tuya_ring_buffer.c:152] reach end,restart.ch0st0tr0 tailOffset:1306059 dataSize:12088 [07-18 18:07:02:613 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:249 timestamp:1689674822613 [07-18 18:07:02:613 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:48299517 ts:0 [07-18 18:07:02:613 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:48299517 [07-18 18:07:02:613 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:4499 dataSize:12088 [07-18 18:07:02:613 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:249 timestamp:1689674822613 [07-18 18:07:02:614 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:614 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 0 node index 0, head index 249 [07-18 18:07:02:614 TUYA Trace][tuya_ring_buffer.c:800] get latest frame node type 1 [07-18 18:07:02:614 TUYA Debug][tuya_ring_buffer.c:806] get latest I frame success, node 249 seqNo 1449 ch0st0tr0 [07-18 18:07:02:615 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:615 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 249, head index 249 [07-18 18:07:02:625 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:625 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 249, head index 249 [07-18 18:07:02:633 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:07:02:633 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:02:635 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:635 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 249, head index 249 [07-18 18:07:02:645 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:645 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 249, head index 249 [07-18 18:07:02:646 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:48332850 ts:0 [07-18 18:07:02:646 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:48332850 [07-18 18:07:02:646 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:12088 dataSize:1051 [07-18 18:07:02:646 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:250 timestamp:1689674822646 [07-18 18:07:02:646 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:48332850 ts:0 [07-18 18:07:02:646 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:48332850 [07-18 18:07:02:646 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:16587 dataSize:1051 [07-18 18:07:02:646 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:250 timestamp:1689674822646 [07-18 18:07:02:655 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:655 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 249, head index 250 [07-18 18:07:02:655 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 250, seqNo 1450, timestamp 1689674822646 [07-18 18:07:02:655 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:656 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 250, head index 250 [07-18 18:07:02:666 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:666 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 250, head index 250 [07-18 18:07:02:673 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [6] low cmd[4] [07-18 18:07:02:673 TUYA Debug][tuya_ipc_p2p.c:2041] session[327681] [1] send audio start to dev [07-18 18:07:02:676 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:676 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 250, head index 250 [07-18 18:07:02:680 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:48366183 ts:0 [07-18 18:07:02:680 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:48366183 [07-18 18:07:02:680 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:13139 dataSize:209 [07-18 18:07:02:680 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:251 timestamp:1689674822680 [07-18 18:07:02:680 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:48366183 ts:0 [07-18 18:07:02:680 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:48366183 [07-18 18:07:02:680 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:17638 dataSize:209 [07-18 18:07:02:680 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:251 timestamp:1689674822680 [07-18 18:07:02:686 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:02:714 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:48399516 ts:0 [07-18 18:07:02:714 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:48399516 [07-18 18:07:02:714 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:13348 dataSize:118 [07-18 18:07:02:714 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:252 timestamp:1689674822714 [07-18 18:07:02:714 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:48399516 ts:0 [07-18 18:07:02:714 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:48399516 [07-18 18:07:02:714 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:17847 dataSize:118 [07-18 18:07:02:714 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:252 timestamp:1689674822714 [07-18 18:07:02:748 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:48432849 ts:0 [07-18 18:07:02:748 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:48432849 [07-18 18:07:02:748 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:13466 dataSize:110 [07-18 18:07:02:748 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:253 timestamp:1689674822748 [07-18 18:07:02:748 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:48432849 ts:0 [07-18 18:07:02:748 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:48432849 [07-18 18:07:02:748 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:17965 dataSize:110 [07-18 18:07:02:748 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:253 timestamp:1689674822748 [07-18 18:07:02:781 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:48466182 ts:0 [07-18 18:07:02:781 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:48466182 [07-18 18:07:02:781 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:13576 dataSize:695 [07-18 18:07:02:781 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:254 timestamp:1689674822781 [07-18 18:07:02:781 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:48466182 ts:0 [07-18 18:07:02:781 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:48466182 [07-18 18:07:02:782 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18075 dataSize:695 [07-18 18:07:02:782 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:254 timestamp:1689674822782 [07-18 18:07:02:796 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:797 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 250, head index 254 [07-18 18:07:02:797 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 251, seqNo 1451, timestamp 1689674822680 [07-18 18:07:02:797 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:02:815 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:48499515 ts:0 [07-18 18:07:02:815 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:48499515 [07-18 18:07:02:815 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:14271 dataSize:1146 [07-18 18:07:02:815 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:255 timestamp:1689674822815 [07-18 18:07:02:815 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:48499515 ts:0 [07-18 18:07:02:815 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:48499515 [07-18 18:07:02:815 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:18770 dataSize:1146 [07-18 18:07:02:815 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:255 timestamp:1689674822815 [07-18 18:07:02:849 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:48532848 ts:0 [07-18 18:07:02:849 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:48532848 [07-18 18:07:02:849 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:15417 dataSize:276 [07-18 18:07:02:849 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:256 timestamp:1689674822849 [07-18 18:07:02:849 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:48532848 ts:0 [07-18 18:07:02:849 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:48532848 [07-18 18:07:02:849 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:19916 dataSize:276 [07-18 18:07:02:849 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:256 timestamp:1689674822849 [07-18 18:07:02:853 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:07:02:853 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:07:02:853 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:07:02:853 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:07:02:853 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACGwAb"}, retrans:1 [07-18 18:07:02:853 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACGwAb"} [07-18 18:07:02:878 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58441 Q:1 Data:{"dps":{"15":"qgACGwAb"}} [07-18 18:07:02:878 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:07:02:882 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:48566181 ts:0 [07-18 18:07:02:882 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:48566181 [07-18 18:07:02:882 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:15693 dataSize:152 [07-18 18:07:02:882 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:257 timestamp:1689674822882 [07-18 18:07:02:882 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:48566181 ts:0 [07-18 18:07:02:882 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:48566181 [07-18 18:07:02:882 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:20192 dataSize:152 [07-18 18:07:02:883 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:257 timestamp:1689674822883 [07-18 18:07:02:903 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:07:02:903 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:02:903 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:07:02:903 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:07:02:903 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674822, rept_cnt:27. [07-18 18:07:02:903 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674822, rept_cnt:0. [07-18 18:07:02:903 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674822, rept_cnt:0. [07-18 18:07:02:903 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:07:02:903 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:07:02:903 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:07:02:910 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:02:910 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 251, head index 257 [07-18 18:07:02:910 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 252, seqNo 1452, timestamp 1689674822714 [07-18 18:07:02:910 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:02:910 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:07:02:911 TUYA Debug][smart_frame.c:709] Send dp:15, RAW:{"15":"qgACEwAT"}, retrans:1 [07-18 18:07:02:911 TUYA Debug][smart_frame.c:2140] dp rept_type:1, data:{"15":"qgACEwAT"} [07-18 18:07:02:919 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:48599514 ts:0 [07-18 18:07:02:919 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:48599514 [07-18 18:07:02:919 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:15845 dataSize:136 [07-18 18:07:02:919 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:258 timestamp:1689674822919 [07-18 18:07:02:919 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:48599514 ts:0 [07-18 18:07:02:919 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:48599514 [07-18 18:07:02:919 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:20344 dataSize:136 [07-18 18:07:02:919 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:258 timestamp:1689674822919 [07-18 18:07:02:929 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:02:937 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58442 Q:1 Data:{"dps":{"15":"qgACEwAT"}} [07-18 18:07:02:937 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:07:02:953 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:48632847 ts:0 [07-18 18:07:02:953 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:48632847 [07-18 18:07:02:953 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:15981 dataSize:725 [07-18 18:07:02:953 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:259 timestamp:1689674822953 [07-18 18:07:02:953 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:48632847 ts:0 [07-18 18:07:02:953 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:48632847 [07-18 18:07:02:953 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:20480 dataSize:725 [07-18 18:07:02:953 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:259 timestamp:1689674822953 [07-18 18:07:02:956 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:07:02:957 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:02:957 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:07:02:957 TUYA Trace][smart_frame.c:2512] DP ID 15 Set To 3 [07-18 18:07:02:957 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:15, curr_t:1689674822, rept_cnt:28. [07-18 18:07:02:957 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:15, curr_t:1689674822, rept_cnt:0. [07-18 18:07:02:957 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:15, curr_t:1689674822, rept_cnt:0. [07-18 18:07:02:980 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:02:984 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[32563] [07-18 18:07:02:986 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:48666180 ts:0 [07-18 18:07:02:986 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:48666180 [07-18 18:07:02:986 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:16706 dataSize:1369 [07-18 18:07:02:986 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:260 timestamp:1689674822986 [07-18 18:07:02:986 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:48666180 ts:0 [07-18 18:07:02:986 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:48666180 [07-18 18:07:02:986 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:21205 dataSize:1369 [07-18 18:07:02:986 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:260 timestamp:1689674822986 [07-18 18:07:03:20 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:48699513 ts:0 [07-18 18:07:03:20 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:48699513 [07-18 18:07:03:20 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:18075 dataSize:367 [07-18 18:07:03:20 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:261 timestamp:1689674823020 [07-18 18:07:03:20 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:48699513 ts:0 [07-18 18:07:03:20 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:48699513 [07-18 18:07:03:20 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:22574 dataSize:367 [07-18 18:07:03:20 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:261 timestamp:1689674823020 [07-18 18:07:03:20 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:21 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 252, head index 261 [07-18 18:07:03:21 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 253, seqNo 1453, timestamp 1689674822748 [07-18 18:07:03:21 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:53 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:48732846 ts:0 [07-18 18:07:03:53 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:48732846 [07-18 18:07:03:53 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:18442 dataSize:141 [07-18 18:07:03:53 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:262 timestamp:1689674823053 [07-18 18:07:03:54 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:48732846 ts:0 [07-18 18:07:03:54 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:48732846 [07-18 18:07:03:54 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:22941 dataSize:141 [07-18 18:07:03:54 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:262 timestamp:1689674823054 [07-18 18:07:03:87 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:48766179 ts:0 [07-18 18:07:03:87 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:48766179 [07-18 18:07:03:87 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:18583 dataSize:160 [07-18 18:07:03:87 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:263 timestamp:1689674823087 [07-18 18:07:03:87 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:48766179 ts:0 [07-18 18:07:03:87 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:48766179 [07-18 18:07:03:87 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23082 dataSize:160 [07-18 18:07:03:87 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:263 timestamp:1689674823087 [07-18 18:07:03:121 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:48799512 ts:0 [07-18 18:07:03:121 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:48799512 [07-18 18:07:03:121 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:18743 dataSize:756 [07-18 18:07:03:121 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:264 timestamp:1689674823121 [07-18 18:07:03:121 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:48799512 ts:0 [07-18 18:07:03:121 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:48799512 [07-18 18:07:03:121 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23242 dataSize:756 [07-18 18:07:03:121 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:264 timestamp:1689674823121 [07-18 18:07:03:131 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:131 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 253, head index 264 [07-18 18:07:03:131 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 254, seqNo 1454, timestamp 1689674822781 [07-18 18:07:03:131 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:154 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:48832845 ts:0 [07-18 18:07:03:154 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:48832845 [07-18 18:07:03:154 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:19499 dataSize:1610 [07-18 18:07:03:154 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:265 timestamp:1689674823154 [07-18 18:07:03:154 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:48832845 ts:0 [07-18 18:07:03:154 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:48832845 [07-18 18:07:03:155 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:23998 dataSize:1610 [07-18 18:07:03:155 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:265 timestamp:1689674823155 [07-18 18:07:03:188 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:48866178 ts:0 [07-18 18:07:03:188 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:48866178 [07-18 18:07:03:188 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:21109 dataSize:516 [07-18 18:07:03:188 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:266 timestamp:1689674823188 [07-18 18:07:03:188 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:48866178 ts:0 [07-18 18:07:03:188 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:48866178 [07-18 18:07:03:188 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:25608 dataSize:516 [07-18 18:07:03:188 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:266 timestamp:1689674823188 [07-18 18:07:03:222 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:48899511 ts:0 [07-18 18:07:03:222 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:48899511 [07-18 18:07:03:222 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:21625 dataSize:231 [07-18 18:07:03:222 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:267 timestamp:1689674823222 [07-18 18:07:03:222 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:48899511 ts:0 [07-18 18:07:03:222 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:48899511 [07-18 18:07:03:222 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:26124 dataSize:231 [07-18 18:07:03:222 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:267 timestamp:1689674823222 [07-18 18:07:03:241 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:241 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 254, head index 267 [07-18 18:07:03:241 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 255, seqNo 1455, timestamp 1689674822815 [07-18 18:07:03:241 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:255 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:48932844 ts:0 [07-18 18:07:03:255 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:48932844 [07-18 18:07:03:255 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:21856 dataSize:250 [07-18 18:07:03:255 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:268 timestamp:1689674823255 [07-18 18:07:03:255 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:48932844 ts:0 [07-18 18:07:03:255 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:48932844 [07-18 18:07:03:256 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:26355 dataSize:250 [07-18 18:07:03:256 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:268 timestamp:1689674823256 [07-18 18:07:03:289 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:48966177 ts:0 [07-18 18:07:03:289 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:48966177 [07-18 18:07:03:289 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:22106 dataSize:1143 [07-18 18:07:03:289 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:269 timestamp:1689674823289 [07-18 18:07:03:289 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:48966177 ts:0 [07-18 18:07:03:289 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:48966177 [07-18 18:07:03:289 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:26605 dataSize:1143 [07-18 18:07:03:289 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:269 timestamp:1689674823289 [07-18 18:07:03:323 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:48999510 ts:0 [07-18 18:07:03:323 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:48999510 [07-18 18:07:03:323 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:23249 dataSize:383 [07-18 18:07:03:323 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:270 timestamp:1689674823323 [07-18 18:07:03:323 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:48999510 ts:0 [07-18 18:07:03:323 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:48999510 [07-18 18:07:03:323 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:27748 dataSize:383 [07-18 18:07:03:323 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:270 timestamp:1689674823323 [07-18 18:07:03:352 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:352 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 255, head index 270 [07-18 18:07:03:352 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 256, seqNo 1456, timestamp 1689674822849 [07-18 18:07:03:352 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:357 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:49032843 ts:0 [07-18 18:07:03:357 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:49032843 [07-18 18:07:03:357 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:23632 dataSize:235 [07-18 18:07:03:357 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:271 timestamp:1689674823357 [07-18 18:07:03:357 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:49032843 ts:0 [07-18 18:07:03:357 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:49032843 [07-18 18:07:03:357 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:28131 dataSize:235 [07-18 18:07:03:357 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:271 timestamp:1689674823357 [07-18 18:07:03:390 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:49066176 ts:0 [07-18 18:07:03:390 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:49066176 [07-18 18:07:03:390 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:23867 dataSize:165 [07-18 18:07:03:390 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:272 timestamp:1689674823390 [07-18 18:07:03:390 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:49066176 ts:0 [07-18 18:07:03:390 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:49066176 [07-18 18:07:03:390 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:28366 dataSize:165 [07-18 18:07:03:391 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:272 timestamp:1689674823391 [07-18 18:07:03:424 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:49099509 ts:0 [07-18 18:07:03:424 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:49099509 [07-18 18:07:03:424 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:24032 dataSize:457 [07-18 18:07:03:424 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:273 timestamp:1689674823424 [07-18 18:07:03:424 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:49099509 ts:0 [07-18 18:07:03:424 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:49099509 [07-18 18:07:03:424 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:28531 dataSize:457 [07-18 18:07:03:424 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:273 timestamp:1689674823424 [07-18 18:07:03:458 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:49132842 ts:0 [07-18 18:07:03:458 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:49132842 [07-18 18:07:03:458 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:24489 dataSize:673 [07-18 18:07:03:458 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:274 timestamp:1689674823458 [07-18 18:07:03:458 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:49132842 ts:0 [07-18 18:07:03:458 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:49132842 [07-18 18:07:03:458 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:28988 dataSize:673 [07-18 18:07:03:458 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:274 timestamp:1689674823458 [07-18 18:07:03:462 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:462 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 256, head index 274 [07-18 18:07:03:462 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 257, seqNo 1457, timestamp 1689674822882 [07-18 18:07:03:462 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:491 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:49166175 ts:0 [07-18 18:07:03:491 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:49166175 [07-18 18:07:03:491 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:25162 dataSize:465 [07-18 18:07:03:491 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:275 timestamp:1689674823491 [07-18 18:07:03:491 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:49166175 ts:0 [07-18 18:07:03:491 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:49166175 [07-18 18:07:03:491 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:29661 dataSize:465 [07-18 18:07:03:491 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:275 timestamp:1689674823491 [07-18 18:07:03:525 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:49199508 ts:0 [07-18 18:07:03:525 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:49199508 [07-18 18:07:03:525 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:25627 dataSize:248 [07-18 18:07:03:525 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:276 timestamp:1689674823525 [07-18 18:07:03:525 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:49199508 ts:0 [07-18 18:07:03:525 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:49199508 [07-18 18:07:03:525 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:30126 dataSize:248 [07-18 18:07:03:525 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:276 timestamp:1689674823525 [07-18 18:07:03:558 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:49232841 ts:0 [07-18 18:07:03:559 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:49232841 [07-18 18:07:03:559 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:25875 dataSize:217 [07-18 18:07:03:559 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:277 timestamp:1689674823559 [07-18 18:07:03:559 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:49232841 ts:0 [07-18 18:07:03:559 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:49232841 [07-18 18:07:03:559 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:30374 dataSize:217 [07-18 18:07:03:559 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:277 timestamp:1689674823559 [07-18 18:07:03:572 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:572 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 257, head index 277 [07-18 18:07:03:572 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 258, seqNo 1458, timestamp 1689674822919 [07-18 18:07:03:572 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:592 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:49266174 ts:0 [07-18 18:07:03:592 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:49266174 [07-18 18:07:03:592 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:26092 dataSize:280 [07-18 18:07:03:592 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:278 timestamp:1689674823592 [07-18 18:07:03:592 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:49266174 ts:0 [07-18 18:07:03:592 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:49266174 [07-18 18:07:03:592 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:30591 dataSize:280 [07-18 18:07:03:592 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:278 timestamp:1689674823592 [07-18 18:07:03:626 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:49299507 ts:0 [07-18 18:07:03:626 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:49299507 [07-18 18:07:03:626 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:26372 dataSize:12088 [07-18 18:07:03:626 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:279 timestamp:1689674823626 [07-18 18:07:03:626 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:49299507 ts:0 [07-18 18:07:03:626 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:49299507 [07-18 18:07:03:626 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:30871 dataSize:12088 [07-18 18:07:03:626 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:279 timestamp:1689674823626 [07-18 18:07:03:659 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:49332840 ts:0 [07-18 18:07:03:659 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:49332840 [07-18 18:07:03:659 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:38460 dataSize:1051 [07-18 18:07:03:659 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:280 timestamp:1689674823659 [07-18 18:07:03:659 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:49332840 ts:0 [07-18 18:07:03:659 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:49332840 [07-18 18:07:03:659 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:42959 dataSize:1051 [07-18 18:07:03:660 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:280 timestamp:1689674823660 [07-18 18:07:03:683 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:683 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 258, head index 280 [07-18 18:07:03:683 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 259, seqNo 1459, timestamp 1689674822953 [07-18 18:07:03:683 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:693 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:49366173 ts:0 [07-18 18:07:03:693 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:49366173 [07-18 18:07:03:693 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:39511 dataSize:209 [07-18 18:07:03:693 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:281 timestamp:1689674823693 [07-18 18:07:03:693 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:49366173 ts:0 [07-18 18:07:03:693 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:49366173 [07-18 18:07:03:693 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44010 dataSize:209 [07-18 18:07:03:693 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:281 timestamp:1689674823693 [07-18 18:07:03:727 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:49399506 ts:0 [07-18 18:07:03:727 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:49399506 [07-18 18:07:03:727 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:39720 dataSize:118 [07-18 18:07:03:727 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:282 timestamp:1689674823727 [07-18 18:07:03:727 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:49399506 ts:0 [07-18 18:07:03:727 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:49399506 [07-18 18:07:03:727 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44219 dataSize:118 [07-18 18:07:03:727 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:282 timestamp:1689674823727 [07-18 18:07:03:760 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:49432839 ts:0 [07-18 18:07:03:760 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:49432839 [07-18 18:07:03:760 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:39838 dataSize:110 [07-18 18:07:03:760 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:283 timestamp:1689674823760 [07-18 18:07:03:760 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:49432839 ts:0 [07-18 18:07:03:760 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:49432839 [07-18 18:07:03:760 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44337 dataSize:110 [07-18 18:07:03:760 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:283 timestamp:1689674823760 [07-18 18:07:03:793 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:793 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 259, head index 283 [07-18 18:07:03:793 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 260, seqNo 1460, timestamp 1689674822986 [07-18 18:07:03:793 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:794 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:49466172 ts:0 [07-18 18:07:03:794 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:49466172 [07-18 18:07:03:794 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:39948 dataSize:695 [07-18 18:07:03:794 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:284 timestamp:1689674823794 [07-18 18:07:03:794 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:49466172 ts:0 [07-18 18:07:03:794 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:49466172 [07-18 18:07:03:794 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:44447 dataSize:695 [07-18 18:07:03:794 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:284 timestamp:1689674823794 [07-18 18:07:03:827 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:49499505 ts:0 [07-18 18:07:03:827 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:49499505 [07-18 18:07:03:827 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:40643 dataSize:1146 [07-18 18:07:03:827 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:285 timestamp:1689674823827 [07-18 18:07:03:827 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:49499505 ts:0 [07-18 18:07:03:827 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:49499505 [07-18 18:07:03:827 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:45142 dataSize:1146 [07-18 18:07:03:827 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:285 timestamp:1689674823827 [07-18 18:07:03:861 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:49532838 ts:0 [07-18 18:07:03:861 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:49532838 [07-18 18:07:03:861 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:41789 dataSize:276 [07-18 18:07:03:861 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:286 timestamp:1689674823861 [07-18 18:07:03:861 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:49532838 ts:0 [07-18 18:07:03:861 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:49532838 [07-18 18:07:03:861 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:46288 dataSize:276 [07-18 18:07:03:861 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:286 timestamp:1689674823861 [07-18 18:07:03:894 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:49566171 ts:0 [07-18 18:07:03:895 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:49566171 [07-18 18:07:03:895 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:42065 dataSize:152 [07-18 18:07:03:895 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:287 timestamp:1689674823895 [07-18 18:07:03:895 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:49566171 ts:0 [07-18 18:07:03:895 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:49566171 [07-18 18:07:03:895 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:46564 dataSize:152 [07-18 18:07:03:895 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:287 timestamp:1689674823895 [07-18 18:07:03:903 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:03:903 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 260, head index 287 [07-18 18:07:03:904 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 261, seqNo 1461, timestamp 1689674823020 [07-18 18:07:03:904 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:03:928 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:49599504 ts:0 [07-18 18:07:03:928 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:49599504 [07-18 18:07:03:928 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:42217 dataSize:136 [07-18 18:07:03:928 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:288 timestamp:1689674823928 [07-18 18:07:03:928 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:49599504 ts:0 [07-18 18:07:03:928 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:49599504 [07-18 18:07:03:928 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:46716 dataSize:136 [07-18 18:07:03:928 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:288 timestamp:1689674823928 [07-18 18:07:03:962 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:49632837 ts:0 [07-18 18:07:03:962 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:49632837 [07-18 18:07:03:962 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:42353 dataSize:725 [07-18 18:07:03:962 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:289 timestamp:1689674823962 [07-18 18:07:03:962 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:49632837 ts:0 [07-18 18:07:03:962 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:49632837 [07-18 18:07:03:962 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:46852 dataSize:725 [07-18 18:07:03:962 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:289 timestamp:1689674823962 [07-18 18:07:03:981 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:07:03:982 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:03:995 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:49666170 ts:0 [07-18 18:07:03:995 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:49666170 [07-18 18:07:03:995 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:43078 dataSize:1369 [07-18 18:07:03:995 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:290 timestamp:1689674823995 [07-18 18:07:03:995 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:49666170 ts:0 [07-18 18:07:03:995 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:49666170 [07-18 18:07:03:995 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:47577 dataSize:1369 [07-18 18:07:03:995 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:290 timestamp:1689674823995 [07-18 18:07:04:14 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:14 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 261, head index 290 [07-18 18:07:04:14 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 262, seqNo 1462, timestamp 1689674823053 [07-18 18:07:04:14 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:29 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:49699503 ts:0 [07-18 18:07:04:29 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:49699503 [07-18 18:07:04:29 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:44447 dataSize:367 [07-18 18:07:04:29 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:291 timestamp:1689674824029 [07-18 18:07:04:29 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:49699503 ts:0 [07-18 18:07:04:29 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:49699503 [07-18 18:07:04:29 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:48946 dataSize:367 [07-18 18:07:04:29 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:291 timestamp:1689674824029 [07-18 18:07:04:63 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:49732836 ts:0 [07-18 18:07:04:63 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:49732836 [07-18 18:07:04:63 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:44814 dataSize:141 [07-18 18:07:04:63 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:292 timestamp:1689674824063 [07-18 18:07:04:63 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:49732836 ts:0 [07-18 18:07:04:63 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:49732836 [07-18 18:07:04:63 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:49313 dataSize:141 [07-18 18:07:04:63 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:292 timestamp:1689674824063 [07-18 18:07:04:96 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:49766169 ts:0 [07-18 18:07:04:96 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:49766169 [07-18 18:07:04:96 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:44955 dataSize:160 [07-18 18:07:04:96 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:293 timestamp:1689674824096 [07-18 18:07:04:96 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:49766169 ts:0 [07-18 18:07:04:96 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:49766169 [07-18 18:07:04:96 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:49454 dataSize:160 [07-18 18:07:04:96 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:293 timestamp:1689674824096 [07-18 18:07:04:124 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:124 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 262, head index 293 [07-18 18:07:04:124 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 263, seqNo 1463, timestamp 1689674823087 [07-18 18:07:04:125 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:130 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:49799502 ts:0 [07-18 18:07:04:130 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:49799502 [07-18 18:07:04:130 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:45115 dataSize:756 [07-18 18:07:04:130 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:294 timestamp:1689674824130 [07-18 18:07:04:130 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:49799502 ts:0 [07-18 18:07:04:130 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:49799502 [07-18 18:07:04:130 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:49614 dataSize:756 [07-18 18:07:04:130 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:294 timestamp:1689674824130 [07-18 18:07:04:163 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:49832835 ts:0 [07-18 18:07:04:164 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:49832835 [07-18 18:07:04:164 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:45871 dataSize:1610 [07-18 18:07:04:164 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:295 timestamp:1689674824164 [07-18 18:07:04:164 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:49832835 ts:0 [07-18 18:07:04:164 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:49832835 [07-18 18:07:04:164 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:50370 dataSize:1610 [07-18 18:07:04:164 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:295 timestamp:1689674824164 [07-18 18:07:04:197 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:49866168 ts:0 [07-18 18:07:04:197 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:49866168 [07-18 18:07:04:197 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:47481 dataSize:516 [07-18 18:07:04:197 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:296 timestamp:1689674824197 [07-18 18:07:04:197 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:49866168 ts:0 [07-18 18:07:04:197 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:49866168 [07-18 18:07:04:197 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:51980 dataSize:516 [07-18 18:07:04:197 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:296 timestamp:1689674824197 [07-18 18:07:04:204 TUYA Trace][uni_work_queue.c:154] work_queue add task:7c0103b0 [07-18 18:07:04:204 TUYA Trace][ty_work_queue.c:46] ty work queue add success [07-18 18:07:04:204 TUYA Trace][tuya_svc_timer_task.c:755] timer query cnt:41 [07-18 18:07:04:231 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:49899501 ts:0 [07-18 18:07:04:231 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:49899501 [07-18 18:07:04:231 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:47997 dataSize:231 [07-18 18:07:04:231 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:297 timestamp:1689674824231 [07-18 18:07:04:231 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:49899501 ts:0 [07-18 18:07:04:231 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:49899501 [07-18 18:07:04:231 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52496 dataSize:231 [07-18 18:07:04:231 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:297 timestamp:1689674824231 [07-18 18:07:04:235 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:235 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 263, head index 297 [07-18 18:07:04:235 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 264, seqNo 1464, timestamp 1689674823121 [07-18 18:07:04:235 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:264 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:49932834 ts:0 [07-18 18:07:04:264 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:49932834 [07-18 18:07:04:264 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:48228 dataSize:250 [07-18 18:07:04:264 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:298 timestamp:1689674824264 [07-18 18:07:04:264 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:49932834 ts:0 [07-18 18:07:04:265 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:49932834 [07-18 18:07:04:265 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52727 dataSize:250 [07-18 18:07:04:265 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:298 timestamp:1689674824265 [07-18 18:07:04:298 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:49966167 ts:0 [07-18 18:07:04:298 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:49966167 [07-18 18:07:04:298 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:48478 dataSize:1143 [07-18 18:07:04:298 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:299 timestamp:1689674824298 [07-18 18:07:04:298 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:49966167 ts:0 [07-18 18:07:04:298 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:49966167 [07-18 18:07:04:298 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:52977 dataSize:1143 [07-18 18:07:04:298 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:299 timestamp:1689674824298 [07-18 18:07:04:332 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:49999500 ts:0 [07-18 18:07:04:332 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:49999500 [07-18 18:07:04:332 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:49621 dataSize:383 [07-18 18:07:04:332 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:0 timestamp:1689674824332 [07-18 18:07:04:332 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:49999500 ts:0 [07-18 18:07:04:332 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:49999500 [07-18 18:07:04:332 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:54120 dataSize:383 [07-18 18:07:04:332 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:0 timestamp:1689674824332 [07-18 18:07:04:345 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:345 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 264, head index 0 [07-18 18:07:04:345 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 265, seqNo 1465, timestamp 1689674823154 [07-18 18:07:04:345 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:365 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:50032833 ts:0 [07-18 18:07:04:365 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:50032833 [07-18 18:07:04:365 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:50004 dataSize:235 [07-18 18:07:04:365 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:1 timestamp:1689674824365 [07-18 18:07:04:365 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:50032833 ts:0 [07-18 18:07:04:365 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:50032833 [07-18 18:07:04:365 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:54503 dataSize:235 [07-18 18:07:04:365 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:1 timestamp:1689674824365 [07-18 18:07:04:399 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:50066166 ts:0 [07-18 18:07:04:399 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:50066166 [07-18 18:07:04:399 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:50239 dataSize:165 [07-18 18:07:04:399 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:2 timestamp:1689674824399 [07-18 18:07:04:399 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:50066166 ts:0 [07-18 18:07:04:399 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:50066166 [07-18 18:07:04:399 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:54738 dataSize:165 [07-18 18:07:04:399 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:2 timestamp:1689674824399 [07-18 18:07:04:435 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:50099499 ts:0 [07-18 18:07:04:435 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:50099499 [07-18 18:07:04:435 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:50404 dataSize:457 [07-18 18:07:04:435 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:3 timestamp:1689674824435 [07-18 18:07:04:435 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:50099499 ts:0 [07-18 18:07:04:435 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:50099499 [07-18 18:07:04:435 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:54903 dataSize:457 [07-18 18:07:04:435 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:3 timestamp:1689674824435 [07-18 18:07:04:458 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:459 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 265, head index 3 [07-18 18:07:04:459 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 266, seqNo 1466, timestamp 1689674823188 [07-18 18:07:04:459 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:469 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:50132832 ts:0 [07-18 18:07:04:469 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:50132832 [07-18 18:07:04:469 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:50861 dataSize:673 [07-18 18:07:04:469 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:4 timestamp:1689674824469 [07-18 18:07:04:469 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:50132832 ts:0 [07-18 18:07:04:470 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:50132832 [07-18 18:07:04:470 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:55360 dataSize:673 [07-18 18:07:04:470 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:4 timestamp:1689674824470 [07-18 18:07:04:503 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:50166165 ts:0 [07-18 18:07:04:503 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:50166165 [07-18 18:07:04:503 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:51534 dataSize:465 [07-18 18:07:04:503 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:5 timestamp:1689674824503 [07-18 18:07:04:503 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:50166165 ts:0 [07-18 18:07:04:503 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:50166165 [07-18 18:07:04:503 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:56033 dataSize:465 [07-18 18:07:04:503 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:5 timestamp:1689674824503 [07-18 18:07:04:537 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:50199498 ts:0 [07-18 18:07:04:537 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:50199498 [07-18 18:07:04:537 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:51999 dataSize:248 [07-18 18:07:04:537 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:6 timestamp:1689674824537 [07-18 18:07:04:537 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:50199498 ts:0 [07-18 18:07:04:537 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:50199498 [07-18 18:07:04:537 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:56498 dataSize:248 [07-18 18:07:04:537 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:6 timestamp:1689674824537 [07-18 18:07:04:569 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:569 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 266, head index 6 [07-18 18:07:04:569 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 267, seqNo 1467, timestamp 1689674823222 [07-18 18:07:04:569 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:570 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:50232831 ts:0 [07-18 18:07:04:570 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:50232831 [07-18 18:07:04:570 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:52247 dataSize:217 [07-18 18:07:04:570 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:7 timestamp:1689674824570 [07-18 18:07:04:570 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:50232831 ts:0 [07-18 18:07:04:570 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:50232831 [07-18 18:07:04:570 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:56746 dataSize:217 [07-18 18:07:04:571 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:7 timestamp:1689674824571 [07-18 18:07:04:604 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:50266164 ts:0 [07-18 18:07:04:604 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:50266164 [07-18 18:07:04:604 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:52464 dataSize:280 [07-18 18:07:04:604 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:8 timestamp:1689674824604 [07-18 18:07:04:604 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:50266164 ts:0 [07-18 18:07:04:604 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:50266164 [07-18 18:07:04:604 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:56963 dataSize:280 [07-18 18:07:04:604 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:8 timestamp:1689674824604 [07-18 18:07:04:638 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:50299497 ts:0 [07-18 18:07:04:638 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:50299497 [07-18 18:07:04:638 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:52744 dataSize:12088 [07-18 18:07:04:638 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:9 timestamp:1689674824638 [07-18 18:07:04:638 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:50299497 ts:0 [07-18 18:07:04:638 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:50299497 [07-18 18:07:04:638 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:57243 dataSize:12088 [07-18 18:07:04:638 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:9 timestamp:1689674824638 [07-18 18:07:04:671 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:50332830 ts:0 [07-18 18:07:04:671 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:50332830 [07-18 18:07:04:671 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:64832 dataSize:1051 [07-18 18:07:04:671 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:10 timestamp:1689674824671 [07-18 18:07:04:671 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:50332830 ts:0 [07-18 18:07:04:671 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:50332830 [07-18 18:07:04:671 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:69331 dataSize:1051 [07-18 18:07:04:671 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:10 timestamp:1689674824671 [07-18 18:07:04:680 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:680 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 267, head index 10 [07-18 18:07:04:680 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 268, seqNo 1468, timestamp 1689674823255 [07-18 18:07:04:680 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:705 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:50366163 ts:0 [07-18 18:07:04:705 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:50366163 [07-18 18:07:04:705 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:65883 dataSize:209 [07-18 18:07:04:705 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:11 timestamp:1689674824705 [07-18 18:07:04:705 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:50366163 ts:0 [07-18 18:07:04:705 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:50366163 [07-18 18:07:04:705 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:70382 dataSize:209 [07-18 18:07:04:705 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:11 timestamp:1689674824705 [07-18 18:07:04:738 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:50399496 ts:0 [07-18 18:07:04:739 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:50399496 [07-18 18:07:04:739 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:66092 dataSize:118 [07-18 18:07:04:739 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:12 timestamp:1689674824739 [07-18 18:07:04:739 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:50399496 ts:0 [07-18 18:07:04:739 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:50399496 [07-18 18:07:04:739 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:70591 dataSize:118 [07-18 18:07:04:739 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:12 timestamp:1689674824739 [07-18 18:07:04:772 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:50432829 ts:0 [07-18 18:07:04:772 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:50432829 [07-18 18:07:04:772 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:66210 dataSize:110 [07-18 18:07:04:772 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:13 timestamp:1689674824772 [07-18 18:07:04:772 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:50432829 ts:0 [07-18 18:07:04:772 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:50432829 [07-18 18:07:04:772 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:70709 dataSize:110 [07-18 18:07:04:772 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:13 timestamp:1689674824772 [07-18 18:07:04:791 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:791 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 268, head index 13 [07-18 18:07:04:791 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 269, seqNo 1469, timestamp 1689674823289 [07-18 18:07:04:791 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:806 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:50466162 ts:0 [07-18 18:07:04:806 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:50466162 [07-18 18:07:04:806 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:66320 dataSize:695 [07-18 18:07:04:806 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:14 timestamp:1689674824806 [07-18 18:07:04:806 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:50466162 ts:0 [07-18 18:07:04:806 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:50466162 [07-18 18:07:04:806 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:70819 dataSize:695 [07-18 18:07:04:806 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:14 timestamp:1689674824806 [07-18 18:07:04:839 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:50499495 ts:0 [07-18 18:07:04:839 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:50499495 [07-18 18:07:04:839 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:67015 dataSize:1146 [07-18 18:07:04:839 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:15 timestamp:1689674824839 [07-18 18:07:04:839 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:50499495 ts:0 [07-18 18:07:04:839 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:50499495 [07-18 18:07:04:839 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:71514 dataSize:1146 [07-18 18:07:04:839 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:15 timestamp:1689674824839 [07-18 18:07:04:873 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:50532828 ts:0 [07-18 18:07:04:873 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:50532828 [07-18 18:07:04:873 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:68161 dataSize:276 [07-18 18:07:04:873 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:16 timestamp:1689674824873 [07-18 18:07:04:873 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:50532828 ts:0 [07-18 18:07:04:873 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:50532828 [07-18 18:07:04:873 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:72660 dataSize:276 [07-18 18:07:04:873 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:16 timestamp:1689674824873 [07-18 18:07:04:901 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:04:901 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 269, head index 16 [07-18 18:07:04:901 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 270, seqNo 1470, timestamp 1689674823323 [07-18 18:07:04:901 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:04:906 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:50566161 ts:0 [07-18 18:07:04:907 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:50566161 [07-18 18:07:04:907 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:68437 dataSize:152 [07-18 18:07:04:907 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:17 timestamp:1689674824907 [07-18 18:07:04:907 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:50566161 ts:0 [07-18 18:07:04:907 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:50566161 [07-18 18:07:04:907 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:72936 dataSize:152 [07-18 18:07:04:907 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:17 timestamp:1689674824907 [07-18 18:07:04:940 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:50599494 ts:0 [07-18 18:07:04:940 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:50599494 [07-18 18:07:04:940 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:68589 dataSize:136 [07-18 18:07:04:940 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:18 timestamp:1689674824940 [07-18 18:07:04:940 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:50599494 ts:0 [07-18 18:07:04:940 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:50599494 [07-18 18:07:04:940 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:73088 dataSize:136 [07-18 18:07:04:940 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:18 timestamp:1689674824940 [07-18 18:07:04:974 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:50632827 ts:0 [07-18 18:07:04:974 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:725 type:0 pts:50632827 [07-18 18:07:04:974 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:68725 dataSize:725 [07-18 18:07:04:974 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:19 timestamp:1689674824974 [07-18 18:07:04:974 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:725 pts:50632827 ts:0 [07-18 18:07:04:974 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:725 type:0 pts:50632827 [07-18 18:07:04:974 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:73224 dataSize:725 [07-18 18:07:04:974 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:19 timestamp:1689674824974 [07-18 18:07:04:983 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:07:04:983 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:05:7 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:50666160 ts:0 [07-18 18:07:05:7 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1369 type:0 pts:50666160 [07-18 18:07:05:7 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:69450 dataSize:1369 [07-18 18:07:05:7 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:20 timestamp:1689674825007 [07-18 18:07:05:7 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1369 pts:50666160 ts:0 [07-18 18:07:05:7 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1369 type:0 pts:50666160 [07-18 18:07:05:7 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:73949 dataSize:1369 [07-18 18:07:05:7 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:20 timestamp:1689674825007 [07-18 18:07:05:11 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:11 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 270, head index 20 [07-18 18:07:05:12 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 271, seqNo 1471, timestamp 1689674823357 [07-18 18:07:05:12 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:41 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:50699493 ts:0 [07-18 18:07:05:41 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:367 type:0 pts:50699493 [07-18 18:07:05:41 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:70819 dataSize:367 [07-18 18:07:05:41 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:21 timestamp:1689674825041 [07-18 18:07:05:41 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:367 pts:50699493 ts:0 [07-18 18:07:05:41 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:367 type:0 pts:50699493 [07-18 18:07:05:41 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:75318 dataSize:367 [07-18 18:07:05:41 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:21 timestamp:1689674825041 [07-18 18:07:05:74 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:50732826 ts:0 [07-18 18:07:05:74 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:141 type:0 pts:50732826 [07-18 18:07:05:74 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:71186 dataSize:141 [07-18 18:07:05:74 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:22 timestamp:1689674825074 [07-18 18:07:05:74 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:141 pts:50732826 ts:0 [07-18 18:07:05:74 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:141 type:0 pts:50732826 [07-18 18:07:05:74 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:75685 dataSize:141 [07-18 18:07:05:74 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:22 timestamp:1689674825074 [07-18 18:07:05:110 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:50766159 ts:0 [07-18 18:07:05:110 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:160 type:0 pts:50766159 [07-18 18:07:05:111 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:71327 dataSize:160 [07-18 18:07:05:111 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:23 timestamp:1689674825111 [07-18 18:07:05:111 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:160 pts:50766159 ts:0 [07-18 18:07:05:111 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:160 type:0 pts:50766159 [07-18 18:07:05:111 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:75826 dataSize:160 [07-18 18:07:05:111 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:23 timestamp:1689674825111 [07-18 18:07:05:122 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:122 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 271, head index 23 [07-18 18:07:05:122 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 272, seqNo 1472, timestamp 1689674823390 [07-18 18:07:05:122 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:144 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:50799492 ts:0 [07-18 18:07:05:144 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:756 type:0 pts:50799492 [07-18 18:07:05:144 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:71487 dataSize:756 [07-18 18:07:05:144 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:24 timestamp:1689674825144 [07-18 18:07:05:144 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:756 pts:50799492 ts:0 [07-18 18:07:05:144 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:756 type:0 pts:50799492 [07-18 18:07:05:144 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:75986 dataSize:756 [07-18 18:07:05:144 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:24 timestamp:1689674825144 [07-18 18:07:05:178 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:50832825 ts:0 [07-18 18:07:05:178 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1610 type:0 pts:50832825 [07-18 18:07:05:178 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:72243 dataSize:1610 [07-18 18:07:05:178 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:25 timestamp:1689674825178 [07-18 18:07:05:178 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1610 pts:50832825 ts:0 [07-18 18:07:05:178 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1610 type:0 pts:50832825 [07-18 18:07:05:178 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:76742 dataSize:1610 [07-18 18:07:05:178 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:25 timestamp:1689674825178 [07-18 18:07:05:211 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:50866158 ts:0 [07-18 18:07:05:211 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:516 type:0 pts:50866158 [07-18 18:07:05:211 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:73853 dataSize:516 [07-18 18:07:05:211 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:26 timestamp:1689674825211 [07-18 18:07:05:211 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:516 pts:50866158 ts:0 [07-18 18:07:05:211 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:516 type:0 pts:50866158 [07-18 18:07:05:211 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:78352 dataSize:516 [07-18 18:07:05:211 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:26 timestamp:1689674825211 [07-18 18:07:05:232 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:232 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 272, head index 26 [07-18 18:07:05:232 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 273, seqNo 1473, timestamp 1689674823424 [07-18 18:07:05:233 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:245 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:50899491 ts:0 [07-18 18:07:05:245 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:231 type:0 pts:50899491 [07-18 18:07:05:245 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:74369 dataSize:231 [07-18 18:07:05:245 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:27 timestamp:1689674825245 [07-18 18:07:05:245 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:231 pts:50899491 ts:0 [07-18 18:07:05:245 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:231 type:0 pts:50899491 [07-18 18:07:05:245 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:78868 dataSize:231 [07-18 18:07:05:245 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:27 timestamp:1689674825245 [07-18 18:07:05:279 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:50932824 ts:0 [07-18 18:07:05:279 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:250 type:0 pts:50932824 [07-18 18:07:05:279 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:74600 dataSize:250 [07-18 18:07:05:279 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:28 timestamp:1689674825279 [07-18 18:07:05:279 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:250 pts:50932824 ts:0 [07-18 18:07:05:279 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:250 type:0 pts:50932824 [07-18 18:07:05:279 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:79099 dataSize:250 [07-18 18:07:05:279 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:28 timestamp:1689674825279 [07-18 18:07:05:312 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:50966157 ts:0 [07-18 18:07:05:312 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1143 type:0 pts:50966157 [07-18 18:07:05:312 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:74850 dataSize:1143 [07-18 18:07:05:312 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:29 timestamp:1689674825312 [07-18 18:07:05:312 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1143 pts:50966157 ts:0 [07-18 18:07:05:312 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1143 type:0 pts:50966157 [07-18 18:07:05:312 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:79349 dataSize:1143 [07-18 18:07:05:312 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:29 timestamp:1689674825312 [07-18 18:07:05:343 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:343 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 273, head index 29 [07-18 18:07:05:343 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 274, seqNo 1474, timestamp 1689674823458 [07-18 18:07:05:343 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:346 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:50999490 ts:0 [07-18 18:07:05:346 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:383 type:0 pts:50999490 [07-18 18:07:05:346 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:75993 dataSize:383 [07-18 18:07:05:346 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:30 timestamp:1689674825346 [07-18 18:07:05:346 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:383 pts:50999490 ts:0 [07-18 18:07:05:346 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:383 type:0 pts:50999490 [07-18 18:07:05:346 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:80492 dataSize:383 [07-18 18:07:05:346 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:30 timestamp:1689674825346 [07-18 18:07:05:379 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:51032823 ts:0 [07-18 18:07:05:379 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:235 type:0 pts:51032823 [07-18 18:07:05:379 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:76376 dataSize:235 [07-18 18:07:05:379 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:31 timestamp:1689674825379 [07-18 18:07:05:379 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:235 pts:51032823 ts:0 [07-18 18:07:05:379 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:235 type:0 pts:51032823 [07-18 18:07:05:379 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:80875 dataSize:235 [07-18 18:07:05:379 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:31 timestamp:1689674825379 [07-18 18:07:05:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:51066156 ts:0 [07-18 18:07:05:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:165 type:0 pts:51066156 [07-18 18:07:05:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:76611 dataSize:165 [07-18 18:07:05:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:32 timestamp:1689674825413 [07-18 18:07:05:413 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:165 pts:51066156 ts:0 [07-18 18:07:05:413 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:165 type:0 pts:51066156 [07-18 18:07:05:413 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:81110 dataSize:165 [07-18 18:07:05:413 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:32 timestamp:1689674825413 [07-18 18:07:05:447 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:51099489 ts:0 [07-18 18:07:05:447 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:457 type:0 pts:51099489 [07-18 18:07:05:447 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:76776 dataSize:457 [07-18 18:07:05:447 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:33 timestamp:1689674825447 [07-18 18:07:05:447 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:457 pts:51099489 ts:0 [07-18 18:07:05:447 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:457 type:0 pts:51099489 [07-18 18:07:05:447 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:81275 dataSize:457 [07-18 18:07:05:447 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:33 timestamp:1689674825447 [07-18 18:07:05:453 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:453 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 274, head index 33 [07-18 18:07:05:453 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 275, seqNo 1475, timestamp 1689674823491 [07-18 18:07:05:453 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:480 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:51132822 ts:0 [07-18 18:07:05:480 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:673 type:0 pts:51132822 [07-18 18:07:05:480 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:77233 dataSize:673 [07-18 18:07:05:480 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:34 timestamp:1689674825480 [07-18 18:07:05:480 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:673 pts:51132822 ts:0 [07-18 18:07:05:480 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:673 type:0 pts:51132822 [07-18 18:07:05:480 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:81732 dataSize:673 [07-18 18:07:05:480 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:34 timestamp:1689674825480 [07-18 18:07:05:514 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:51166155 ts:0 [07-18 18:07:05:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:465 type:0 pts:51166155 [07-18 18:07:05:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:77906 dataSize:465 [07-18 18:07:05:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:35 timestamp:1689674825514 [07-18 18:07:05:514 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:465 pts:51166155 ts:0 [07-18 18:07:05:514 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:465 type:0 pts:51166155 [07-18 18:07:05:514 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:82405 dataSize:465 [07-18 18:07:05:514 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:35 timestamp:1689674825514 [07-18 18:07:05:547 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:51199488 ts:0 [07-18 18:07:05:548 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:248 type:0 pts:51199488 [07-18 18:07:05:548 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:78371 dataSize:248 [07-18 18:07:05:548 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:36 timestamp:1689674825548 [07-18 18:07:05:548 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:248 pts:51199488 ts:0 [07-18 18:07:05:548 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:248 type:0 pts:51199488 [07-18 18:07:05:548 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:82870 dataSize:248 [07-18 18:07:05:548 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:36 timestamp:1689674825548 [07-18 18:07:05:563 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:564 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 275, head index 36 [07-18 18:07:05:564 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 276, seqNo 1476, timestamp 1689674823525 [07-18 18:07:05:564 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:51232821 ts:0 [07-18 18:07:05:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:217 type:0 pts:51232821 [07-18 18:07:05:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:78619 dataSize:217 [07-18 18:07:05:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:37 timestamp:1689674825581 [07-18 18:07:05:581 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:217 pts:51232821 ts:0 [07-18 18:07:05:581 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:217 type:0 pts:51232821 [07-18 18:07:05:581 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:83118 dataSize:217 [07-18 18:07:05:581 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:37 timestamp:1689674825581 [07-18 18:07:05:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:51266154 ts:0 [07-18 18:07:05:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:280 type:0 pts:51266154 [07-18 18:07:05:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:78836 dataSize:280 [07-18 18:07:05:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:38 timestamp:1689674825615 [07-18 18:07:05:615 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:280 pts:51266154 ts:0 [07-18 18:07:05:615 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:280 type:0 pts:51266154 [07-18 18:07:05:615 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:83335 dataSize:280 [07-18 18:07:05:615 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:38 timestamp:1689674825615 [07-18 18:07:05:648 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:51299487 ts:0 [07-18 18:07:05:648 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:12088 type:1 pts:51299487 [07-18 18:07:05:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:79116 dataSize:12088 [07-18 18:07:05:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:39 timestamp:1689674825649 [07-18 18:07:05:649 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:1 size:12088 pts:51299487 ts:0 [07-18 18:07:05:649 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:12088 type:1 pts:51299487 [07-18 18:07:05:649 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:83615 dataSize:12088 [07-18 18:07:05:649 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:39 timestamp:1689674825649 [07-18 18:07:05:674 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:674 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 276, head index 39 [07-18 18:07:05:674 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 277, seqNo 1477, timestamp 1689674823559 [07-18 18:07:05:674 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:51332820 ts:0 [07-18 18:07:05:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1051 type:0 pts:51332820 [07-18 18:07:05:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:91204 dataSize:1051 [07-18 18:07:05:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:40 timestamp:1689674825682 [07-18 18:07:05:682 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1051 pts:51332820 ts:0 [07-18 18:07:05:682 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1051 type:0 pts:51332820 [07-18 18:07:05:682 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:95703 dataSize:1051 [07-18 18:07:05:682 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:40 timestamp:1689674825682 [07-18 18:07:05:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:51366153 ts:0 [07-18 18:07:05:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:209 type:0 pts:51366153 [07-18 18:07:05:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:92255 dataSize:209 [07-18 18:07:05:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:41 timestamp:1689674825716 [07-18 18:07:05:716 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:209 pts:51366153 ts:0 [07-18 18:07:05:716 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:209 type:0 pts:51366153 [07-18 18:07:05:716 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:96754 dataSize:209 [07-18 18:07:05:716 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:41 timestamp:1689674825716 [07-18 18:07:05:721 TUYA Trace][app_agent.c:1185] g_lan_ctrl_enable:1 [07-18 18:07:05:721 TUYA Trace][app_agent.c:1190] Curr Socket Num:0 [07-18 18:07:05:721 TUYA Debug][smart_frame.c:3408] rept chan:1 [07-18 18:07:05:721 TUYA Debug][smart_frame.c:353] dp<5> check. need_update:0 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:0 [07-18 18:07:05:721 TUYA Debug][smart_frame.c:450] is_need_update:1, is_dp_passive:0 [07-18 18:07:05:721 TUYA Debug][smart_frame.c:2140] dp rept_type:0, data:{"5":"mapping"} [07-18 18:07:05:744 TUYA Debug][mqc_app.c:890] Send MQTT Msg.P:4 N:58443 Q:1 Data:{"dps":{"5":"mapping"}} [07-18 18:07:05:745 TUYA Trace][com_protocol.c:600] Data To MQTT AND V=2.2 [07-18 18:07:05:745 TUYA Debug][tuya_ipc_p2p.c:6879] tuya_ipc_send_file_to_app buff[0x7f280008c0] len[61] [07-18 18:07:05:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:51399486 ts:0 [07-18 18:07:05:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:118 type:0 pts:51399486 [07-18 18:07:05:749 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:92464 dataSize:118 [07-18 18:07:05:749 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:42 timestamp:1689674825749 [07-18 18:07:05:749 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:118 pts:51399486 ts:0 [07-18 18:07:05:749 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:118 type:0 pts:51399486 [07-18 18:07:05:749 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:96963 dataSize:118 [07-18 18:07:05:749 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:42 timestamp:1689674825749 [07-18 18:07:05:767 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:07:05:767 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:05:767 TUYA Trace][mqtt_client.c:692] __mq_recv_raw----->end [07-18 18:07:05:767 TUYA Trace][smart_frame.c:1948] mqtt async dp cb 0 [07-18 18:07:05:767 TUYA Debug][smart_frame.c:1962] msg_data:{"dps":{"5":"mapping"}}, mqtt async dp cb:0 [07-18 18:07:05:767 TUYA Trace][smart_frame.c:2512] DP ID 5 Set To 3 [07-18 18:07:05:767 TUYA Debug][smart_frame.c:239] set short dp rate rule, dpID:5, curr_t:1689674825, rept_cnt:1. [07-18 18:07:05:767 TUYA Debug][smart_frame.c:247] set long dp rate rule, dpID:5, curr_t:1689674825, rept_cnt:0. [07-18 18:07:05:767 TUYA Debug][smart_frame.c:256] set all dp rate rule, dpID:5, curr_t:1689674825, rept_cnt:0. [07-18 18:07:05:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:51432819 ts:0 [07-18 18:07:05:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:110 type:0 pts:51432819 [07-18 18:07:05:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:92582 dataSize:110 [07-18 18:07:05:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:43 timestamp:1689674825783 [07-18 18:07:05:783 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:110 pts:51432819 ts:0 [07-18 18:07:05:783 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:110 type:0 pts:51432819 [07-18 18:07:05:783 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97081 dataSize:110 [07-18 18:07:05:783 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:43 timestamp:1689674825783 [07-18 18:07:05:784 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:784 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 277, head index 43 [07-18 18:07:05:784 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 278, seqNo 1478, timestamp 1689674823592 [07-18 18:07:05:784 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:791 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:05:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:51466152 ts:0 [07-18 18:07:05:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:695 type:0 pts:51466152 [07-18 18:07:05:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:92692 dataSize:695 [07-18 18:07:05:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:44 timestamp:1689674825817 [07-18 18:07:05:817 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:695 pts:51466152 ts:0 [07-18 18:07:05:817 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:695 type:0 pts:51466152 [07-18 18:07:05:817 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97191 dataSize:695 [07-18 18:07:05:817 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:44 timestamp:1689674825817 [07-18 18:07:05:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:51499485 ts:0 [07-18 18:07:05:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:1146 type:0 pts:51499485 [07-18 18:07:05:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:93387 dataSize:1146 [07-18 18:07:05:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:45 timestamp:1689674825850 [07-18 18:07:05:850 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:1146 pts:51499485 ts:0 [07-18 18:07:05:850 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:1146 type:0 pts:51499485 [07-18 18:07:05:850 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:97886 dataSize:1146 [07-18 18:07:05:850 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:45 timestamp:1689674825850 [07-18 18:07:05:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:51532818 ts:0 [07-18 18:07:05:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:276 type:0 pts:51532818 [07-18 18:07:05:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:94533 dataSize:276 [07-18 18:07:05:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:46 timestamp:1689674825884 [07-18 18:07:05:884 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:276 pts:51532818 ts:0 [07-18 18:07:05:884 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:276 type:0 pts:51532818 [07-18 18:07:05:884 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:99032 dataSize:276 [07-18 18:07:05:884 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:46 timestamp:1689674825884 [07-18 18:07:05:895 TUYA Debug][tuya_ipc_p2p.c:4145] pSession->av_mutex=0x0x7f7c00feb0 [07-18 18:07:05:895 TUYA Trace][tuya_ring_buffer.c:794] ch0st0tr0 retry:0 userInfo->status 1 node index 278, head index 46 [07-18 18:07:05:895 TUYA Trace][tuya_ring_buffer.c:923] ch0st0tr0 node index 279, seqNo 1479, timestamp 1689674823626 [07-18 18:07:05:895 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:05:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:51566151 ts:0 [07-18 18:07:05:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:152 type:0 pts:51566151 [07-18 18:07:05:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:94809 dataSize:152 [07-18 18:07:05:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:47 timestamp:1689674825918 [07-18 18:07:05:918 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:152 pts:51566151 ts:0 [07-18 18:07:05:918 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:152 type:0 pts:51566151 [07-18 18:07:05:918 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:99308 dataSize:152 [07-18 18:07:05:918 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:47 timestamp:1689674825918 [07-18 18:07:05:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:51599484 ts:0 [07-18 18:07:05:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr0 size:136 type:0 pts:51599484 [07-18 18:07:05:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr0 tailOffset:94961 dataSize:136 [07-18 18:07:05:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr0 node index:48 timestamp:1689674825951 [07-18 18:07:05:951 TUYA Trace][linkbey_sdk_v11.cpp:549] Put Frame. type:0 size:136 pts:51599484 ts:0 [07-18 18:07:05:951 TUYA Trace][tuya_ring_buffer.c:688] append to ch0st0tr1 size:136 type:0 pts:51599484 [07-18 18:07:05:951 TUYA Trace][tuya_ring_buffer.c:160] not reach end.ch0st0tr1 tailOffset:99460 dataSize:136 [07-18 18:07:05:951 TUYA Trace][tuya_ring_buffer.c:735] append done, ch0st0tr1 node index:48 timestamp:1689674825951 [07-18 18:07:05:965 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [6] low cmd[3] [07-18 18:07:05:965 TUYA Debug][tuya_ipc_p2p.c:2006] session[327681] [1] send video stop to dev [07-18 18:07:05:965 TUYA Debug][tuya_ipc_p2p.c:2013] session[327681] video stop [07-18 18:07:06:5 TUYA Err][tuya_ring_buffer.c:787] No data inside ring buffer. GET starts before PUT? ch0st0tr9 [07-18 18:07:06:56 TUYA Debug][tuya_ipc_p2p.c:2753] recv session[327681] higcmd [6] low cmd[5] [07-18 18:07:06:56 TUYA Debug][tuya_ipc_p2p.c:2100] session[327681] [1] send audio stop to dev [07-18 18:07:06:792 TUYA Trace][mqtt_client.c:689] __mq_recv_raw----->timeout [07-18 18:07:06:792 TUYA Trace][mqtt_client.c:684] __mq_recv_raw----->begin [07-18 18:07:07:545 TUYA Trace][mqtt_client.c:692] __mq_recv_raw---
