--------- beginning of system
08-30 11:05:42.558  1517  2766 W LightsService: setBrightness brightness: 97.0, brightnessMode:0
--------- beginning of main
08-30 11:05:42.559   949   949 E qdlights: access fath /sys/bus/platform/devices/oppo_iface.0/brightness fail
08-30 11:05:42.560  1517  2766 D OplusFeatureDCBacklight: notifySfRepaintEverything begin mCurrentDCMode:0
08-30 11:05:42.561  1517  2046 D DisplayPowerController: Animating brightness: target=103.0, rate=126.0, source= 12
08-30 11:05:42.643  1517  2766 W LightsService: setBrightness brightness: 98.0, brightnessMode:0
08-30 11:05:42.645  1517  2766 D OplusFeatureDCBacklight: notifySfRepaintEverything begin mCurrentDCMode:0
08-30 11:05:42.645  1517  2046 D DisplayPowerController: Animating brightness: target=103.0, rate=126.0, source= 12
08-30 11:05:42.723  1517  2766 W LightsService: setBrightness brightness: 99.0, brightnessMode:0
08-30 11:05:42.727  1517  2766 D OplusFeatureDCBacklight: notifySfRepaintEverything begin mCurrentDCMode:0
08-30 11:05:42.729  1517  2046 D DisplayPowerController: Animating brightness: target=103.0, rate=126.0, source= 12
08-30 11:05:42.821  1517  2766 W LightsService: setBrightness brightness: 100.0, brightnessMode:0
08-30 11:05:42.826  1517  2766 D OplusFeatureDCBacklight: notifySfRepaintEverything begin mCurrentDCMode:0
08-30 11:05:42.827  1517  2046 D DisplayPowerController: Animating brightness: target=103.0, rate=126.0, source= 12
08-30 11:05:42.726   949   949 I chatty  : uid=1000(system) android.hardwar identical 2 lines
08-30 11:05:42.825   949   949 E qdlights: access fath /sys/bus/platform/devices/oppo_iface.0/brightness fail
08-30 11:05:42.828   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:42.828   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:42.828   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:42.828   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:42.828   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:42.828   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:42.919  1517  2766 W LightsService: setBrightness brightness: 101.0, brightnessMode:0
08-30 11:05:42.922   949   949 E qdlights: access fath /sys/bus/platform/devices/oppo_iface.0/brightness fail
08-30 11:05:42.924  1517  2766 D OplusFeatureDCBacklight: notifySfRepaintEverything begin mCurrentDCMode:0
08-30 11:05:42.925  1517  2046 D DisplayPowerController: Animating brightness: target=103.0, rate=126.0, source= 12
08-30 11:05:43.018  1517  2766 W LightsService: setBrightness brightness: 102.0, brightnessMode:0
08-30 11:05:43.022  1517  2766 D OplusFeatureDCBacklight: notifySfRepaintEverything begin mCurrentDCMode:0
08-30 11:05:43.024  1517  2046 D DisplayPowerController: Animating brightness: target=103.0, rate=126.0, source= 12
08-30 11:05:43.087  1517  2046 D DisplayPowerController: Animating brightness: target=103.0, rate=126.0, source= 12
08-30 11:05:43.088  1517  2766 W LightsService: setBrightness brightness: 103.0, brightnessMode:0
08-30 11:05:43.094  1517  2766 D OplusFeatureDCBacklight: notifySfRepaintEverything begin mCurrentDCMode:0
08-30 11:05:43.100  1517  2046 D DisplayPowerController: Animating brightness: target=103.0, rate=126.0, source= 12
08-30 11:05:43.022   949   949 I chatty  : uid=1000(system) android.hardwar identical 1 line
08-30 11:05:43.093   949   949 E qdlights: access fath /sys/bus/platform/devices/oppo_iface.0/brightness fail
08-30 11:05:43.104  1517  1552 W System  : A resource failed to call release.
08-30 11:05:43.104  1517  1552 I chatty  : uid=1000(system) FinalizerDaemon identical 8 lines
08-30 11:05:43.105  1003  1003 D OppoExLayer: ~Layer() sequence=16468, name=Surface(name=29f1a38 NavigationBar0)/@0xe2b3d24 - animation-leash#1@0xb40000700e8cd000
08-30 11:05:43.105  1517  1552 W System  : A resource failed to call release.
08-30 11:05:43.105  1517  1552 W System  : A resource failed to call close.
08-30 11:05:43.114  1003  1003 D OppoExLayer: ~Layer() sequence=16442, name=Surface(name=29f1a38 NavigationBar0)/@0xe2b3d24 - animation-leash#1@0xb40000700e850000
08-30 11:05:43.114  1003  1003 D OppoExLayer: ~Layer() sequence=16467, name=Surface(name=74ffb6 StatusBar)/@0xbaad1b7 - animation-leash#0@0xb40000700e8bb000
08-30 11:05:43.114  1003  1003 D OppoExLayer: ~Layer() sequence=16461, name=Surface(name=29f1a38 NavigationBar0)/@0xe2b3d24 - animation-leash#0@0xb40000700e8d0000
08-30 11:05:43.114  1003  1003 D OppoExLayer: ~Layer() sequence=16441, name=Surface(name=74ffb6 StatusBar)/@0xbaad1b7 - animation-leash#0@0xb40000702ae96000
08-30 11:05:43.114  1003  1003 D OppoExLayer: ~Layer() sequence=16460, name=Surface(name=74ffb6 StatusBar)/@0xbaad1b7 - animation-leash#1@0xb40000702af9e000
08-30 11:05:43.239   955 17022 E sensors-hal: ssc_conn_event_cb:645, event[0] msg_id=776, ts=29540837520000 sensor_type = Device Orientation  Wakeup
08-30 11:05:43.239   955 17022 E sensors-hal: handle_sns_client_event:89, device_orient_event:qcom ssc_ts=29540837520000 tk, ts=1538581201334205, type=0
08-30 11:05:43.240  1517  1856 V WindowOrientationListener: onSensorChanged mDesiredRotation = 0 newRotation = 0
08-30 11:05:43.243   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:43.243   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:43.243   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:43.243   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:43.243   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:43.243   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:43.248  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:43.271  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 64ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653645 wlan0TxPtk=942983 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:43.594  1517  2519 D WN_S    : Didn't send and receive any pkt.
08-30 11:05:43.594  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:43.841 26030 26115 E Thing-Network: connect failed!error code 110,msg: Connection timed out
08-30 11:05:43.880  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:05:43.880  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=29,badLossCount=0,txLoss=0,mLinkDetectTimes= 598,mIndex =0
08-30 11:05:43.880  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 64, 0, 0, 0, 0, 676, 64, 0, 0, 0, 0, 676, 64, 0, 0, 0, 0, 676, 64, 0, 0, 0, 0, 676, 64, 0, 0, 0, 0]
08-30 11:05:43.880  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:05:43.880  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:05:43.881  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:05:43.881  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:05:43.881  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-43,mIndex =0,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12574289384
08-30 11:05:43.881  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:05:43.881  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:05:43.881  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:05:43.881  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:05:43.881  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:05:43.882  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:05:43.882  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:05:44.095 30404 30447 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:05:44.099 30404 30447 D HoraeHelper: Thermal length:1
08-30 11:05:44.193 30404 30448 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:05:44.233 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"offer","trace_id":"","is_pre":0,"p2p_skill":99,"security_level":3,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1693364732 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6ce1f26844bfce86f3zrdp1693364732HD9FywgA\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:oAml\r\na=ice-pwd:zmADVTSZ3ROqzRsHCxHRLxUA\r\na=ice-options:trickle\r\na=aes-key:becb0000ee0fd04c0000060c300005ca\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1690445086544UqnKu\r\n","preconnect":true,"token":[{"urls":"stun:47.103.17.244:3478"},{"urls":"turn:47.103.29.37:3478","credential":"bP/q9f9Q9ssachwqUnnYVNi0Pew=","ttl":3600,"username":"1693368332:6ce1f26844bfce86f3zrdp"}],"tcp_token":{"urls":["tcp4:1.117.192.37:1443"],"credential":"bQBNnERjRDi8hbh
08-30 11:05:44.239 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:522295761 1 UDP 2130706431 :: 37457 typ host\r\n"}}} ...
08-30 11:05:44.245 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:430244233 1 UDP 2130706431 0.0.0.0 37457 typ host\r\n"}}} ...
08-30 11:05:44.246   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:44.246   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:44.246   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:44.246   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:44.246   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:44.246   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:44.252 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1387425366 1 UDP 2130706431 :: 37457 typ host\r\n"}}} ...
08-30 11:05:44.257 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:314966142 1 UDP 2130706431 :: 37457 typ host\r\n"}}} ...
08-30 11:05:44.266 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1627354644 1 UDP 1694498815 49.78.21.79 10497 typ srflx\r\n"}}} ...
08-30 11:05:44.272 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1053070589 1 UDP 16777215 47.103.29.37 62800 typ relay\r\n"}}} ...
08-30 11:05:44.284 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":""}}} ...
08-30 11:05:44.313  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 64ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653646 wlan0TxPtk=942987 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:44.510  1517  5210 I WifiService: getWifiEnabledState uid=1000
08-30 11:05:44.510  1517  5202 I WifiService: getWifiApEnabledState uid=1000
08-30 11:05:44.510  1517  5210 I WifiService: getConnectionInfo uid=1000
08-30 11:05:44.805  1517  1517 D OppoBaseBatteryService: send broadcast : oppo.intent.action.BATTERY_DATA_UPDATE
08-30 11:05:44.805  1517  1517 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1158 com.android.server.OppoBaseBatteryService$2.run:280 android.os.Handler.handleCallback:938 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:263
08-30 11:05:44.805  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:05:44.814  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3437900
08-30 11:05:44.814  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:05:45.351  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 62ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653654 wlan0TxPtk=942995 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:45.512  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-46 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:05:45.512  1517  2519 D OplusRssiMonitor: update rssi:-46
08-30 11:05:45.512  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:05:45.512  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:05:45.512  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:05:45.512  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-43 for "abc_ling"WPA_PSK
08-30 11:05:45.512  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:05:45.512  1517  2519 D WifiDataStall: L2 txTputKbps: 66000, rxTputKbps: 66000, L3 txTputKbps: 14, rxTputKbps: 2, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:05:45.513  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -44, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:05:45.513  1517  2519 D WifiScoreCard: txRate: 7 txSpeed: 96
08-30 11:05:45.513  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -44 txSpeed 96
08-30 11:05:45.513  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:05:45.513  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538583514 LastRssiPoll: -44 LastTxSpeedPoll: 96
08-30 11:05:45.513  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:05:45.513  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:45.513  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:45.514  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -44 level: 4
08-30 11:05:45.515  2938 14644 V WifiManager: TrafficStateCallbackProxy: onStateChanged state=3
08-30 11:05:45.516  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -44
08-30 11:05:45.517  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-44 f=2462 sc=0 link=96 tx=5.5, 1.3, 0.0  rx=3.2 bcn=9009145 [on:1087 tx:21 rx:20 period:3006] from screen [on:4910622 period:6535447] score=0
08-30 11:05:45.524  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:05:45.525  1517 13105 I WifiService: getConnectionInfo uid=10060
08-30 11:05:45.525  1517 13105 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:05:45.527  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:05:45.594  1517  2519 D WN_S    : DT,tP=942995, dTP=12, rP=1653654, dRP=9 mIR=true, mRPLC=0
08-30 11:05:45.594  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:46.023  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3437900
08-30 11:05:46.023  3234  3234 D DeviceInfoHidlClient: isPowerInfoNeverSent()=true
08-30 11:05:46.023  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:05:46.391  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 62ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653654 wlan0TxPtk=942995 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:46.743  3304  3304 E OplusNecManagerHelper: com.oplus.nec.OplusNecManager.notifyOrigSignalStrengthChanged [class android.telephony.SignalStrength, int]
08-30 11:05:46.748  1517  1517 D OplusSlaManager_RSRP: onSignalStrengthsChanged oldRsrp=0 newRsrp=-105
08-30 11:05:46.885  1353  1379 D bspCriticalLog: thermal_monitor ddr-usr: open fail -1
08-30 11:05:46.885  1353  1379 D bspCriticalLog: thermal_monitor gpuss-0-usr: open fail -1
08-30 11:05:46.885  1353  1379 D bspCriticalLog: thermal_monitor cpu-1-0-usr: open fail -1
08-30 11:05:46.885  1353  1381 D bspCriticalLog: power_monitor cpu-1-0-usr: open fail -1
08-30 11:05:47.228 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746755,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":4,"as":2,"h":1,"e":-3,"ex":-50,"d":15160} ...
08-30 11:05:47.229 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746755,"v":"3.5.2","p":"rtc_session_add","tid":"","s":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","ca":"connect_v2","st":"new_session","e":-3,"ex":-50,"d":15160} ...
08-30 11:05:47.229 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746756,"v":"3.5.2","p":"rtc_session_disconnect","tid":"","s":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"cr":10,"crl":0,"crr":0,"e":-3,"ex":-50,"d":15161} ...
08-30 11:05:47.229 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.230 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746756,"v":"3.5.2","p":"rtc_connect_result","tid":"","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","rd":"6ce1f26844bfce86f3zrdp","ca":"connect_v3","ex":-3,"d":15161} ...
08-30 11:05:47.230 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sub_dev_id":"","sessionid":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","moto_id":"","type":"disconnect","trace_id":"","path":"mqtt"},"msg":{"close_reason_local":0,"close_reason":10}}} ...
08-30 11:05:47.231 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] m_P2pStepStatus:3
08-30 11:05:47.231 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] return:-3 p2pType:4 connect time cost:15163 leave(-3)...
08-30 11:05:47.235 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746762,"v":"3.5.2","p":"rtc_session_destroy","tid":"","s":"6ce1f26844bfce86f3zrdp1693364732HD9FywgA","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":15167} ...
08-30 11:05:47.241 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback {"p2p_3_0_cxx_https_request":"thing.m.rtc.log_1.0", "devId":""} here..
08-30 11:05:47.241 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback here.....
08-30 11:05:47.243 25924 26310 I ThingAvLoggerSDK: ThingP2PSDK::init enter..
08-30 11:05:47.243 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::Initialize sdkversion:3.4.55-rc.0 ....
08-30 11:05:47.243 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::Initialize p2p version : 0XF4030502
08-30 11:05:47.243 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::Initialize p2p connect open...
08-30 11:05:47.243 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_init enter...
08-30 11:05:47.243 25924 26310 I ThingAvLoggerSDK: ThingP2PSDK::init init return:0..
08-30 11:05:47.244 25924 26310 I ThingCameraSDK: ThingCameraNative setDeviceFeatures,the handle is :0x6f8a600040
08-30 11:05:47.244 25924 26310 I ThingCameraSDK: ThingCameraBase::SetDeviceFeatures Port[0] features:{"DecPostProcess":{"mirror":0,"rotation":0}} enter...
08-30 11:05:47.245 25924 26310 I ThingCameraSDK: ThingCameraBase::SetDeviceFeatures Port[0] leave(-1)...
08-30 11:05:47.246 25924 26310 I ThingCameraSDK: ThingCameraNative setSmartRectFeatures,the handle is :0x6f8a600040
08-30 11:05:47.246 25924 26310 I ThingCameraSDK: ThingCameraBase::SetSmartRectFeatures Port[0] channel:0 features:{"SmartRectFeature":[{"brushWidth":0,"flashFps":{"drawKeepFrames":0,"stopKeepFrames":0},"index":0,"rgb":16711680,"shape":1,"type":0}]} enter...
08-30 11:05:47.246 25924 26310 I ThingCameraSDK: ThingCameraAttributes::setSmartRectFeatures feature:{"SmartRectFeature":[{"brushWidth":0,"flashFps":{"drawKeepFrames":0,"stopKeepFrames":0},"index":0,"rgb":16711680,"shape":1,"type":0}]} enter.....
08-30 11:05:47.246 25924 26310 I ThingCameraSDK: ThingCameraBase::SetSmartRectFeatures Port[0] leave(0)...
08-30 11:05:47.248 25924 26310 I ThingCameraSDK: ThingCameraNative setSmartRectFeatures,the handle is :0x6f8a600040
08-30 11:05:47.248 25924 26310 I ThingCameraSDK: ThingCameraBase::SetCameraConfig Port[0] enter
08-30 11:05:47.248 25924 26310 I ThingCameraSDK: ThingCameraBase::SetCameraConfig Port[0] audio capability:3
08-30 11:05:47.250 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] enter...
08-30 11:05:47.250 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364747250,"m":"camera","did":"6ce1f26844bfce86f3zrdp","op":"connect","tid":"no traceId"} ...
08-30 11:05:47.250 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] new link pre connect connectOption:1...
08-30 11:05:47.251 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746777,"v":"3.5.2","p":"rtc_session_create","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"h":0,"lk":99,"rk":0,"c":"kcp"} ...
08-30 11:05:47.251 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746778,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":0,"as":2,"h":1,"e":0,"ex":0,"d":1} ...
08-30 11:05:47.251 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746778,"v":"3.5.2","p":"rtc_session_http_req","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","a":"thing.m.rtc.session.offer_1.0","d":1} ...
08-30 11:05:47.322 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:65537 is_pre:0 state:4 active_state:2 error:-3...
08-30 11:05:47.323 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:65538 is_pre:0 state:0 active_state:2 error:0...
08-30 11:05:47.323 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback {"p2p_3_0_cxx_https_request":"thing.m.rtc.session.offer_1.0", "devId":"6ce1f26844bfce86f3zrdp"} here..
08-30 11:05:47.323 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback here.....
08-30 11:05:47.404 25924 26336 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_http_result.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":api:thing.m.rtc.log_1.0 content:{"success":true}}..
08-30 11:05:47.431  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 64ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653668 wlan0TxPtk=943009 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:47.457 25924 26296 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_http_result.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":api:thing.m.rtc.session.offer_1.0 content:{"vedioClarity":4,"auth":"Lj9+0+MkuZXWBKweVSJVwmfLATquSr0eLGGW+4r+1Mc=","supportWebrtcRecord":true,"timeZoneId":"Asia/Shanghai","upgradeRelay":true,"motoId":"signaling14146","p2pId":"","isLowPower":false,"vedioClaritys":[2,4],"supportsWebrtc":true,"password":"adeda472","isCloudP2P":false,"p2pType":4,"p2pPolicy":0,"skill":"{\"v\":2,\"sdk_version\":\"5.6.32\",\"channel_num\":1,\"cloudGW\":1,\"cloudStorage\":1,\"localStorage\":513,\"webrtc\":115,\"p2p\":99,\"upnp\":11,\"video_num\":2,\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":0,\"profileId\":\"\",\"width\":1920,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":0,\"width\":768,\"height\":864}],\"audios\":[{\"codecType\":105,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]}","maxZoomInTimes":0,"audioAttributes":{"callMode":[1,2],"hardwareCapability":[1,2]},"p2pConfig":{"preconnect":true,"tcpRelay
08-30 11:05:47.457 25924 26296 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746983,"v":"3.5.2","p":"rtc_session_http_resp","l":"ay1690445086544UqnKu","a":"thing.m.rtc.session.offer_1.0","c":0,"r":"","e":"{\"vedioClarity\":4,\"auth\":\"Lj9+0+MkuZXWBKweVSJVwmfLATquSr0eLGGW+4r+1Mc=\",\"supportWebrtcRecord\":true,\"timeZoneId\":\"Asia/Shanghai\",\"upgradeRelay\":true,\"motoId\":\"signaling14146\",\"p2pId\":\"\",\"isLowPower\":false,\"vedioClaritys\":[2,4],\"supportsWebrtc\":true,\"password\":\"adeda472\",\"isCloudP2P\":false,\"p2pType\":4,\"p2pPolicy\":0,\"skill\":\"{\\\"v\\\":2,\\\"sdk_version\\\":\\\"5.6.32\\\",\\\"channel_num\\\":1,\\\"cloudGW\\\":1,\\\"cloudStorage\\\":1,\\\"localStorage\\\":513,\\\"webrtc\\\":115,\\\"p2p\\\":99,\\\"upnp\\\":11,\\\"video_num\\\":2,\\\"videos\\\":[{\\\"streamType\\\":2,\\\"codecType\\\":4,\\\"sampleRate\\\":0,\\\"profileId\\\":\\\"\\\",\\\"width\\\":1920,\\\"height\\\":2160},{\\\"streamType\\\":4,\\\"codecType\\\":2,\\\"sampleRate\\\":0,\\\"width\\\":768,\\\"height\\\":864}],\\\"audios\\\":[
08-30 11:05:47.466 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746992,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":1,"as":2,"h":1,"e":0,"ex":0,"d":215} ...
08-30 11:05:47.467 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364746994,"v":"3.5.2","p":"rtc_ice_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":0,"d":217,"m":0,"nl":"","nr":""} ...
08-30 11:05:47.453 25924 25924 W Thread-211: type=1400 audit(0.0:162971): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tclass=netlink_route_socket permissive=0 b/155595000 app=com.tuya.smartiot
08-30 11:05:47.470 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnGetDeviceAddress enter..
08-30 11:05:47.453 25924 25924 W Thread-211: type=1400 audit(0.0:162972): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tclass=netlink_route_socket permissive=0 b/155595000 app=com.tuya.smartiot
08-30 11:05:47.471 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.471 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"offer","trace_id":"","is_pre":0,"p2p_skill":99,"security_level":3,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1693364747 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6ce1f26844bfce86f3zrdp1693364747fb4ItmZl\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:Vy99\r\na=ice-pwd:cDHufbKYKxdUXmd5GoSxXxfW\r\na=ice-options:trickle\r\na=aes-key:0030d000020e0000c0a0500c016000ae\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1690445086544UqnKu\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"urls":"turn:47.103.2.131:3478","credential":"X+mL+gJbCE7O5bTawRE1VmDzL6k=","ttl":3600,"username":"1693368347:6ce1f26844bfce86f3zrdp"}],"tcp_token":{"urls":["tcp4:1.117.192.37:1443"],"credential":"ZcXI3Oi4MrCJRJQE
08-30 11:05:47.453 25924 25924 W Thread-212: type=1400 audit(0.0:162973): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tclass=netlink_route_socket permissive=0 b/155595000 app=com.tuya.smartiot
08-30 11:05:47.474 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364747001,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1203632304 1 UDP 2130706431 :: 47428 typ host\r\n","d":224} ...
08-30 11:05:47.475 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.475 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364747002,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:125314865 1 UDP 2130706431 0.0.0.0 47428 typ host\r\n","d":225} ...
08-30 11:05:47.476 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.476 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364747003,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1016807572 1 UDP 2130706431 :: 47428 typ host\r\n","d":226} ...
08-30 11:05:47.476 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364747003,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:304027100 1 UDP 2130706431 :: 47428 typ host\r\n","d":226} ...
08-30 11:05:47.477 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364747004,"v":"3.5.2","p":"rtc_ice_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":1,"d":227,"m":0,"nl":"","nr":""} ...
08-30 11:05:47.477 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364747004,"v":"3.5.2","p":"rtc_tcp_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":0,"d":227,"tconn":0,"tresp":0,"tcomp":0} ...
08-30 11:05:47.479 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.480 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.482 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1203632304 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:47.490 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:125314865 1 UDP 2130706431 0.0.0.0 47428 typ host\r\n"}}} ...
08-30 11:05:47.494 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1016807572 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:47.502 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:304027100 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:47.507 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnGetDeviceAddress enter..
08-30 11:05:47.493 25924 25924 W Thread-228: type=1400 audit(0.0:162974): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tclass=netlink_route_socket permissive=0 b/155595000 app=com.tuya.smartiot
08-30 11:05:47.508 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364747035,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1258010157 1 UDP 1694498815 49.78.21.79 10251 typ srflx\r\n","d":258} ...
08-30 11:05:47.509 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.510 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1258010157 1 UDP 1694498815 49.78.21.79 10251 typ srflx\r\n"}}} ...
08-30 11:05:47.524 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:65538 is_pre:0 state:1 active_state:2 error:0...
08-30 11:05:47.529  1517  5210 I WifiService: getWifiEnabledState uid=1000
08-30 11:05:47.529  1517 13105 I WifiService: getWifiApEnabledState uid=1000
08-30 11:05:47.529  1517  5210 I WifiService: getConnectionInfo uid=1000
08-30 11:05:47.549 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364747076,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1980245951 1 UDP 16777215 47.103.2.131 51207 typ relay\r\n","d":299} ...
08-30 11:05:47.551 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.551 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1980245951 1 UDP 16777215 47.103.2.131 51207 typ relay\r\n"}}} ...
08-30 11:05:47.552 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:47.560 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":""}}} ...
08-30 11:05:47.596  1517  2519 D WN_S    : DT,tP=943009, dTP=14, rP=1653668, dRP=14 mIR=true, mRPLC=0
08-30 11:05:47.596  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:47.704   955 17022 E sensors-hal: ssc_conn_event_cb:645, event[0] msg_id=776, ts=29540922960000 sensor_type = Device Orientation  Wakeup
08-30 11:05:47.705   955 17022 E sensors-hal: handle_sns_client_event:89, device_orient_event:qcom ssc_ts=29540922960000 tk, ts=1538585651334205, type=4
08-30 11:05:46.017  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:05:47.705  1517  1856 V WindowOrientationListener: onSensorChanged mDesiredRotation = 4
08-30 11:05:48.471  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 62ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653684 wlan0TxPtk=943025 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:48.518  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-49 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:05:48.518  1517  2519 D OplusRssiMonitor: update rssi:-49
08-30 11:05:48.519  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:05:48.519  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:05:48.519  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:05:48.519  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-44 for "abc_ling"WPA_PSK
08-30 11:05:48.519  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:05:48.519  1517  2519 D WifiDataStall: L2 txTputKbps: 56760, rxTputKbps: 66000, L3 txTputKbps: 70, rxTputKbps: 20, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:05:48.519  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -45, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:05:48.519  1517  2519 D WifiScoreCard: txRate: 13 txSpeed: 96
08-30 11:05:48.519  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -45 txSpeed 96
08-30 11:05:48.520  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:05:48.520  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538586521 LastRssiPoll: -45 LastTxSpeedPoll: 96
08-30 11:05:48.520  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:05:48.520  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:48.520  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:48.523  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:05:48.523  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -45
08-30 11:05:48.523  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:05:48.524  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -45 level: 4
08-30 11:05:48.525  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-45 f=2462 sc=0 link=96 tx=10.9, 1.9, 0.0  rx=8.6 bcn=9009172 [on:1600 tx:38 rx:37 period:3003] from screen [on:4912222 period:6538455] score=0
08-30 11:05:48.526  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:05:48.526  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:05:48.881  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:05:48.881  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=60,badLossCount=0,txLoss=0,mLinkDetectTimes= 599,mIndex =1
08-30 11:05:48.881  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 62, 0, 0, 0, 0, 676, 64, 0, 0, 0, 0, 676, 62, 0, 0, 0, 0, 676, 62, 0, 0, 0, 0, 676, 64, 0, 0, 0, 0]
08-30 11:05:48.881  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:05:48.881  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:05:48.881  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:05:48.882  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:05:48.882  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-45,mIndex =1,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12574297447
08-30 11:05:48.882  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:05:48.882  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:05:48.882  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:05:48.882  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:05:48.882  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:05:48.882  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:05:48.882  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:05:48.966 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"offer","trace_id":"","is_pre":0,"p2p_skill":99,"security_level":3,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1693364747 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6ce1f26844bfce86f3zrdp1693364747fb4ItmZl\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:Vy99\r\na=ice-pwd:cDHufbKYKxdUXmd5GoSxXxfW\r\na=ice-options:trickle\r\na=aes-key:0030d000020e0000c0a0500c016000ae\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1690445086544UqnKu\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"urls":"turn:47.103.2.131:3478","credential":"X+mL+gJbCE7O5bTawRE1VmDzL6k=","ttl":3600,"username":"1693368347:6ce1f26844bfce86f3zrdp"}],"tcp_token":{"urls":["tcp4:1.117.192.37:1443"],"credential":"ZcXI3Oi4MrCJRJQE
08-30 11:05:48.975 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1203632304 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:48.980 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:125314865 1 UDP 2130706431 0.0.0.0 47428 typ host\r\n"}}} ...
08-30 11:05:48.986 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1016807572 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:48.994 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:304027100 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:48.999 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1258010157 1 UDP 1694498815 49.78.21.79 10251 typ srflx\r\n"}}} ...
08-30 11:05:49.008 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1980245951 1 UDP 16777215 47.103.2.131 51207 typ relay\r\n"}}} ...
08-30 11:05:49.015 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":""}}} ...
08-30 11:05:49.127 30404 30444 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:05:49.185 30404 30447 D HoraeHelper: Thermal length:1
08-30 11:05:49.193 30404 30444 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:05:49.198 30404 30447 D HoraeHelper: skinThermal:35.51
08-30 11:05:49.511  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 62ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653693 wlan0TxPtk=943037 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:49.597  1517  2519 D WN_S    : DT,tP=943037, dTP=28, rP=1653693, dRP=25 mIR=true, mRPLC=0
08-30 11:05:49.597  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:50.469 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"offer","trace_id":"","is_pre":0,"p2p_skill":99,"security_level":3,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1693364747 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6ce1f26844bfce86f3zrdp1693364747fb4ItmZl\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:Vy99\r\na=ice-pwd:cDHufbKYKxdUXmd5GoSxXxfW\r\na=ice-options:trickle\r\na=aes-key:0030d000020e0000c0a0500c016000ae\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1690445086544UqnKu\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"urls":"turn:47.103.2.131:3478","credential":"X+mL+gJbCE7O5bTawRE1VmDzL6k=","ttl":3600,"username":"1693368347:6ce1f26844bfce86f3zrdp"}],"tcp_token":{"urls":["tcp4:1.117.192.37:1443"],"credential":"ZcXI3Oi4MrCJRJQE
08-30 11:05:50.479 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1203632304 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:50.485 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:125314865 1 UDP 2130706431 0.0.0.0 47428 typ host\r\n"}}} ...
08-30 11:05:50.491 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1016807572 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:50.500 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:304027100 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:50.505 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1258010157 1 UDP 1694498815 49.78.21.79 10251 typ srflx\r\n"}}} ...
08-30 11:05:50.513 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1980245951 1 UDP 16777215 47.103.2.131 51207 typ relay\r\n"}}} ...
08-30 11:05:50.521 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":""}}} ...
08-30 11:05:50.524  1517 13105 I WifiService: getWifiEnabledState uid=1000
08-30 11:05:50.524  1517  5210 I WifiService: getWifiApEnabledState uid=1000
08-30 11:05:50.524  1517 13105 I WifiService: getConnectionInfo uid=1000
08-30 11:05:50.552  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 60ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653696 wlan0TxPtk=943042 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:50.659  8177  8177 D wpa_supplicant: nl80211: Drv Event 103 (NL80211_CMD_VENDOR) received for p2p0
08-30 11:05:50.662   958  2819 I WifiHAL : event received NL80211_CMD_VENDOR, vendor_id = 0x1374, subcmd = 0xa
08-30 11:05:50.662  8177  8177 D wpa_supplicant: nl80211: Vendor event: wiphy=0 vendor_id=0x1374 subcmd=10
08-30 11:05:50.662  8177  8177 D wpa_supplicant: nl80211: Avoid frequency range: 5500-5640
08-30 11:05:50.662  8177  8177 D wpa_supplicant: p2p0: Event AVOID_FREQUENCIES (48) received
08-30 11:05:50.662  8177  8177 I wpa_supplicant: p2p0: CTRL-EVENT-AVOID-FREQ ranges=5500-5640
08-30 11:05:50.662  8177  8177 D wpa_supplicant: nl80211: Drv Event 113 (NL80211_CMD_WIPHY_REG_CHANGE) received for p2p0
08-30 11:05:50.662  8177  8177 D wpa_supplicant: nl80211: Regulatory domain change
08-30 11:05:50.662  8177  8177 D wpa_supplicant:  * initiator=2
08-30 11:05:50.662  8177  8177 D wpa_supplicant:  * type=0
08-30 11:05:50.662  8177  8177 D wpa_supplicant:  * alpha2=CN
08-30 11:05:50.662  8177  8177 D wpa_supplicant: p2p0: Event CHANNEL_LIST_CHANGED (27) received
08-30 11:05:50.662  8177  8177 I wpa_supplicant: p2p0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=CN
08-30 11:05:50.662  8177  8177 D wpa_supplicant: p2p0: Updating hw mode
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: Regulatory information - country=CN
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: 2402-2482 @ 40 MHz 20 mBm
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: 5170-5250 @ 80 MHz 23 mBm
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: 5250-5330 @ 80 MHz 23 mBm (DFS)
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: 5735-5835 @ 80 MHz 33 mBm
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: Added 802.11b mode based on 802.11g information
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: Mode IEEE 802.11g: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484[DISABLED]
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: Mode IEEE 802.11a: 5180 5200 5220 5240 5260[RADAR] 5280[RADAR] 5300[RADAR] 5320[RADAR] 5500[DISABLED] 5520[DISABLED] 5540[DISABLED] 5560[DISABLED] 5580[DISABLED] 5600[DISABLED] 5620[DISABLED] 5640[DISABLED]
08-30 11:05:50.663  8177  8177 D wpa_supplicant: nl80211: Mode IEEE 802.11b: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 2467 2472 2484[DISABLED]
08-30 11:05:50.663  8177  8177 D wpa_supplicant: wlan0: Updating hw mode
08-30 11:05:50.663  8177  8177 D wpa_supplicant: p2p0: Determining shared radio frequencies (max len 2)
08-30 11:05:50.663  8177  8177 D wpa_supplicant: p2p0: Shared frequencies (len=1): completed iteration
08-30 11:05:50.663  8177  8177 D wpa_supplicant: p2p0: freq[0]: 2462, flags=0x1
08-30 11:05:50.663  8177  8177 D wpa_supplicant: P2P: Update channel list
08-30 11:05:50.663  8177  8177 D wpa_supplicant: P2P: channels: 81:1,2,3,4,5,6,7,8,9,10,11,12,13 115:36,40,44,48 116:36,44 117:40,48 124:149,153,157,161 125:149,153,157,161,165 126:149,157 127:153,161 128:36,40,44,48 130:36,40,44,48
08-30 11:05:50.663  8177  8177 D wpa_supplicant: P2P: cli_channels:
08-30 11:05:50.695 25924 25937 I m.tuya.smartio: Background concurrent copying GC freed 300281(14MB) AllocSpace objects, 34(792KB) LOS objects, 50% free, 17MB/35MB, paused 119us total 120.474ms
08-30 11:05:50.820   955 17022 E sensors-hal: ssc_conn_event_cb:645, event[0] msg_id=776, ts=29540982480000 sensor_type = Device Orientation  Wakeup
08-30 11:05:50.820   955 17022 E sensors-hal: handle_sns_client_event:89, device_orient_event:qcom ssc_ts=29540982480000 tk, ts=1538588751334205, type=0
08-30 11:05:50.823  1517  1856 V WindowOrientationListener: onSensorChanged mDesiredRotation = 0 newRotation = 0
08-30 11:05:50.825   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:50.826   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:50.826   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:50.826   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:50.826   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:50.826   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:50.828  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:51.059  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:05:51.068  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3439000
08-30 11:05:51.068  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:05:51.525  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-46 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:05:51.525  1517  2519 D OplusRssiMonitor: update rssi:-46
08-30 11:05:51.525  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:05:51.525  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:05:51.525  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:05:51.526  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-44 for "abc_ling"WPA_PSK
08-30 11:05:51.526  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:05:51.526  1517  2519 D WifiDataStall: L2 txTputKbps: 62700, rxTputKbps: 66000, L3 txTputKbps: 27, rxTputKbps: 4, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:05:51.527  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -45, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:05:51.527  1517  2519 D WifiScoreCard: txRate: 12 txSpeed: 96
08-30 11:05:51.527  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -45 txSpeed 96
08-30 11:05:51.527  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:05:51.527  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538589529 LastRssiPoll: -45 LastTxSpeedPoll: 96
08-30 11:05:51.527  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:05:51.527  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:51.527  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:51.531  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:05:51.531  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:05:51.531  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -45
08-30 11:05:51.533  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:05:51.533  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:05:51.533  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -45 level: 4
08-30 11:05:51.534  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-45 f=2462 sc=0 link=96 tx=10.7, 1.1, 0.0  rx=7.1 bcn=9009202 [on:1811 tx:31 rx:42 period:3009] from screen [on:4914033 period:6541464] score=0
08-30 11:05:51.594  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 60ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653702 wlan0TxPtk=943047 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:51.597  1517  2519 D WN_S    : DT,tP=943047, dTP=10, rP=1653702, dRP=9 mIR=true, mRPLC=0
08-30 11:05:51.597  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:51.827   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:51.827   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:51.827   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:51.827   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:51.827   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:51.827   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:52.117 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=31.0, y[0]=192.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343763083, downTime=343763083, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:52.117 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=31.0, y[0]=192.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343763083, downTime=343763083, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:52.118 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=31.0, y[0]=192.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343763083, downTime=343763083, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:52.184 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=31.0, y[0]=192.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343763152, downTime=343763083, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:52.184 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=31.0, y[0]=192.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343763152, downTime=343763083, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:52.202  1517  5210 V ColorZoomWindowManagerService: prepareZoomTransition: curStack=Task{564553c #1831 visible=true type=standard mode=fullscreen translucent=true A=10030:com.tuya.smartiot U=0 StackId=1831 sz=2}   nextStackTask{564553c #1831 visible=true type=standard mode=fullscreen translucent=true A=10030:com.tuya.smartiot U=0 StackId=1831 sz=2}
08-30 11:05:52.202  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestatePAUSING
08-30 11:05:52.203  1517  5210 D ActivityTrigger: ActivityTrigger activityPauseTrigger
08-30 11:05:52.203   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:52.203   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:52.203   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:05:52.203   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:05:52.203  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestatePAUSING
08-30 11:05:52.203   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:05:52.203   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for GameOptimization
08-30 11:05:52.203   966  1041 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:05:52.204   966  1041 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:05:52.204   966  1041 I ANDR-PERF-LM: Core: lmMain() 391: runAsync for GameOptimization returned
08-30 11:05:52.204   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:05:52.204   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:05:52.207  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:52.215 25924 25924 D AudioManager: setMode mode=0 from com.tuya.smartiot
08-30 11:05:52.215  1517  5210 I AS.AudioService: setMode(mode = 0, callingPackage = com.tuya.smartiot, Process ID: 25924
08-30 11:05:52.215  1517  5210 D AS.AudioService: +notifyAtlasServiceModesUpdate onlyRead :true
08-30 11:05:52.215  1517  5210 D AS.AudioService: modekey = allmodes=
08-30 11:05:52.216  1517  5210 D AS.AudioService: -notifyAtlasServiceModesUpdate
08-30 11:05:52.218  1517  5210 D AS.AudioService: ringVolumeDefault :0
08-30 11:05:52.219   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.220   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.221   999  5227 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.221   999  5227 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.223   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.223   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.224   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.225   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.227   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.228  4254  4320 D OppoAtlasAudioState: getActiveAudioMusic ret = false
08-30 11:05:52.229   999  5227 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.230   999  5227 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.232  1517  5202 I InputDispatcher: Focus left window: Window{f3521a9 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:05:52.233   999  5227 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.241  1517  2577 I AS.AudioDeviceBroker: In updateSpeakerphoneOn(), mForcedUseForCommExt: 1
08-30 11:05:52.241 25924 25924 I AudioManager: In isBluetoothScoOn(), calling application: com.tuya.smartiot
08-30 11:05:52.242  1517  5210 I AS.AudioDeviceBroker: In isBluetoothScoOnForApp(), mForcedUseForCommExt: 1
08-30 11:05:52.242   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.242  1517  5208 I MediaFocusControl: abandonAudioFocus() from uid/pid 10030/25924 clientId=android.media.AudioManager@117a91acom.thingclips.smart.ipc.camera.rnpanel.cameramanager.TRCTCameraManager$2@b51c4b
08-30 11:05:52.243  4254  4320 D AudioManager: getStreamVolume packageName=com.oppo.atlas, index=0, streamType=3
08-30 11:05:52.243  1517 13105 D AS.AudioService: getParameters() keyValuePairs:OPLUS_AUDIO_GET_DEVICE_FORSTREAM:3
08-30 11:05:52.243   999 14533 D AudioPolicyManagerCustom: setForceUse() usage 7, config 0, mPhoneState 0
08-30 11:05:52.244 25924 25924 D AudioManager: setMode mode=0 from com.tuya.smartiot
08-30 11:05:52.244  1517  5208 I AS.AudioService: setMode(mode = 0, callingPackage = com.tuya.smartiot, Process ID: 25924
08-30 11:05:52.244   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.244  1517  5208 D AS.AudioService: +notifyAtlasServiceModesUpdate onlyRead :true
08-30 11:05:52.244  1517  5208 D AS.AudioService: modekey = allmodes=
08-30 11:05:52.245  1517  5208 D AS.AudioService: -notifyAtlasServiceModesUpdate
08-30 11:05:52.245  4254  4320 D OppoAtlasAudioState: isSpeakerMute() device: 2 ,index:0,ST:3
08-30 11:05:52.245  4254  4320 D OppoAtlasAudioState: checkAndSetPaState(state:4,mute:true), hasMusic:false,mode:0 ,mIsPlaybackRecord:false
08-30 11:05:52.245   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000001, index 14
08-30 11:05:52.246   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.246   999  5227 D AudioPolicyManagerCustom: setForceUse() usage 0, config 1, mPhoneState 0
08-30 11:05:52.247   999  5227 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 12
08-30 11:05:52.247   999  5227 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.248  1517  5208 D AS.AudioService: ringVolumeDefault :0
08-30 11:05:52.248   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 14
08-30 11:05:52.248   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.249   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 12
08-30 11:05:52.249   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.249   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 14
08-30 11:05:52.249   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 14
08-30 11:05:52.250   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.251   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.253   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.253  1517  2527 I OplusWifiSarManager: Received action: android.media.ACTION_AUDIO_DEVICE_ROUTE_CHANGED
08-30 11:05:52.255   999 12926 I chatty  : uid=1041(audioserver) Binder:999_B identical 1 line
08-30 11:05:52.257   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.263  4254  4320 D OppoAtlasAudioState: getActiveAudioMusic ret = false
08-30 11:05:52.264  1517  2577 I AS.AudioDeviceBroker: In updateSpeakerphoneOn(), mForcedUseForCommExt: 1
08-30 11:05:52.264 25924 25924 I AudioManager: In isBluetoothScoOn(), calling application: com.tuya.smartiot
08-30 11:05:52.265  1517  5208 I AS.AudioDeviceBroker: In isBluetoothScoOnForApp(), mForcedUseForCommExt: 1
08-30 11:05:52.265   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.265  1517  5208 I MediaFocusControl: abandonAudioFocus() from uid/pid 10030/25924 clientId=android.media.AudioManager@117a91acom.thingclips.smart.ipc.camera.rnpanel.multicamera.MultiCameraTRCTManager$5@8773ce6
08-30 11:05:52.266   999 12926 D AudioPolicyManagerCustom: setForceUse() usage 0, config 1, mPhoneState 0
08-30 11:05:52.266   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 9
08-30 11:05:52.269   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000008, index 9
08-30 11:05:52.270  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestatePAUSED
08-30 11:05:52.270   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 9
08-30 11:05:52.270  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestatePAUSED
08-30 11:05:52.271  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateSTOPPING
08-30 11:05:52.271   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 8
08-30 11:05:52.271  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateSTOPPING
08-30 11:05:52.272  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateRESUMED
08-30 11:05:52.272   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 04000000, index 8
08-30 11:05:52.273   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:52.273   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:52.273   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:05:52.273   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:05:52.273   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:05:52.273   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for GameOptimization
08-30 11:05:52.273   966  1041 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:05:52.273  1517 13105 I OppoBaseActivityStack: notifyAppSwitch the same packageName!
08-30 11:05:52.273   966  1041 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:05:52.273   966  1041 I ANDR-PERF-LM: Core: lmMain() 391: runAsync for GameOptimization returned
08-30 11:05:52.273  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateRESUMED
08-30 11:05:52.273   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:05:52.273   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:05:52.274  1517  2592 I MotorManagerService: notifyActivityChanged: mBackgroudPkg = com.tuya.smartiot mFocusPkg = com.tuya.smartiot mIsSplitMode = true mBackActivity = com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity mFocusActivity = com.thingclips.smart.hometab.activity.FamilyHomeActivity
08-30 11:05:52.275  1517 13105 I InputDispatcher: setFocusedApplication displayId=0 ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity t1831}
08-30 11:05:52.275  1517 13105 V WindowManager: Changing focus from Window{f3521a9 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} to null,diplayid=0
08-30 11:05:52.275   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 9
08-30 11:05:52.276  1517 13105 D Theia.NoFocusWindow: FocusWindowErrorScene CheckFreezeScreen
08-30 11:05:52.281  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:52.281  1517 13105 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:05:52.286   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.286   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.287   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.288   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.288   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.290   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.293   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.296   999 14533 D AudioPolicyManagerCustom: setForceUse() usage 7, config 0, mPhoneState 0
08-30 11:05:52.297   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000001, index 14
08-30 11:05:52.297   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.298   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 12
08-30 11:05:52.299   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.300   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 14
08-30 11:05:52.300   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.301   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 12
08-30 11:05:52.301   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.302   999 14533 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 14
08-30 11:05:52.302   999 14533 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.303   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 14
08-30 11:05:52.303   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.305   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:52.309   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 9
08-30 11:05:52.311   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000008, index 9
08-30 11:05:52.313   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 9
08-30 11:05:52.314   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 8
08-30 11:05:52.315  1517  5202 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:05:52.315   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 04000000, index 8
08-30 11:05:52.316   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 9
08-30 11:05:52.284  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:52.318  1517  5202 V WindowManager: Changing focus from null to Window{6d8b026 u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity},diplayid=0
08-30 11:05:52.319   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.320  4254  4320 D AudioManager: getStreamVolume packageName=com.oppo.atlas, index=0, streamType=3
08-30 11:05:52.320  1517  5210 D AS.AudioService: getParameters() keyValuePairs:OPLUS_AUDIO_GET_DEVICE_FORSTREAM:3
08-30 11:05:52.320  1517  5202 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:05:52.321   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:52.322  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:52.323  4254  4320 D OppoAtlasAudioState: isSpeakerMute() device: 2 ,index:0,ST:3
08-30 11:05:52.323  4254  4320 D OppoAtlasAudioState: checkAndSetPaState(state:4,mute:true), hasMusic:false,mode:0 ,mIsPlaybackRecord:false
08-30 11:05:52.337  1003  1129 D DispPerfService: onframeavailable pid=25924, slot=2, seq=16496, name=com.tuya.smartiot:com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity#0
08-30 11:05:52.344  1517  1861 D ColorZoomWindowManagerService: adjustWindowCropForLeash start: appToken = ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity t1831}
08-30 11:05:52.346  1517  1861 D ColorZoomWindowManagerService: adjustWindowCropForLeash start: appToken = ActivityRecord{312b839 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity t1831 f}}
08-30 11:05:52.356  1517  2527 I OplusWifiSarManager: Received action: android.media.ACTION_AUDIO_DEVICE_ROUTE_CHANGED
08-30 11:05:52.356  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:52.359  1517  5210 I InputDispatcher: Focus entered window: Window{6d8b026 u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity} in display 0
08-30 11:05:52.363  1517 13105 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:05:52.363  1517 13105 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:05:52.356  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:05:52.363  1517 13105 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:05:52.363  1517 13105 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:05:52.377  1517 13105 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:05:52.379  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:52.435  1517  2586 D JobScheduler.Temperature: get temperature=35.733
08-30 11:05:52.476 25924 26340 I ThingCameraSDK: ThingCameraSimple::StopPreview Port[0] channel:0 enter....
08-30 11:05:52.476 25924 26340 I ThingCameraSDK: ThingCameraSimple::StopPreview Port[0] requestId:1 cmd high:6 low:3 operateion:3...
08-30 11:05:52.476 25924 26340 I ThingCameraSDK: ThingCameraSimple::StopPreview Port[0] cmd high:6 low:5 operateion:5...
08-30 11:05:52.476 25924 26340 I ThingCameraSDK: ThingCameraSimple::StopPreview Port[0] leave(-10002)...
08-30 11:05:52.621  1517  1861 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{312b839 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity t1831 f}}
08-30 11:05:52.621  1517  1861 I OplusMirageDisplayManagerService: onAnimationFinished:
08-30 11:05:52.621  1517  1861 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity t1831}
08-30 11:05:52.622  1517  1861 I ColorAppSwitchManagerService:  handleAppVisible , r = ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity t1831}
08-30 11:05:52.622  1517  1861 I OplusMirageDisplayManagerService: onAnimationFinished:
08-30 11:05:52.627  1517  1860 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateFINISHING
08-30 11:05:52.627  1517  1860 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateFINISHING
08-30 11:05:52.627  1517  1860 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateDESTROYING
08-30 11:05:52.627  1517  1860 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateDESTROYING
08-30 11:05:52.628  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:52.631  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 60ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653704 wlan0TxPtk=943049 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:52.636  1003  1003 D OppoExLayer: ~Layer() sequence=16500, name=Surface(name=ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity)/@0x4126c9a - animation-bounds#0@0xb40000702ae96000
08-30 11:05:52.636  1003  1003 D OppoExLayer: ~Layer() sequence=16499, name=Surface(name=ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity)/@0x4126c9a - animation-leash#0@0xb40000702af3c000
08-30 11:05:52.636  1003  1003 D OppoExLayer: ~Layer() sequence=16502, name=Surface(name=ActivityRecord{312b839 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x5d2e61d - animation-bounds#0@0xb40000702af30000
08-30 11:05:52.636  1003  1003 D OppoExLayer: ~Layer() sequence=16501, name=Surface(name=ActivityRecord{312b839 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x5d2e61d - animation-leash#0@0xb40000702aef3000
08-30 11:05:52.646 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:52.647 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:52.647 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:52.650 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:52.650 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:52.653  1003  1003 D OppoExLayer: ~Layer() sequence=16495, name=Background for -SurfaceView - com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e966000
08-30 11:05:52.654 25924 25924 V SensorManager: unRegisterListener by com.thingclips.smart.rnplugin.trctsensorsmanager.TRCTSensorsManager and its name is lsm6dsm Gyroscope Non-wakeup
08-30 11:05:52.655 25924 25924 V SensorManager: unRegisterListener by com.thingclips.smart.rnplugin.trctsensorsmanager.TRCTSensorsManager and its name is gravity  Non-wakeup
08-30 11:05:52.655 25924 25924 V SensorManager: unRegisterListener by com.thingclips.smart.rnplugin.trctsensorsmanager.TRCTSensorsManager and its name is lsm6dsm Accelerometer Non-wakeup
08-30 11:05:52.655 25924 25924 V SensorManager: unRegisterListener by com.thingclips.smart.rnplugin.trctsensorsmanager.TRCTSensorsManager and its name is ak0991x Magnetometer Non-wakeup
08-30 11:05:52.662  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateDESTROYED
08-30 11:05:52.663  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateDESTROYED
08-30 11:05:52.664  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:52.669  1003  1003 D OppoExLayer: ~Layer() sequence=16485, name=f3521a9 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000702af50000
08-30 11:05:52.669  1003  1003 D OppoExLayer: ~Layer() sequence=16486, name=com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000702afe0000
08-30 11:05:52.669  1003  1003 D OppoExLayer: ~Layer() sequence=16493, name=Bounds for - com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e9fd000
08-30 11:05:52.669  1003  1003 D OppoExLayer: ~Layer() sequence=16494, name=SurfaceView - com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e963000
08-30 11:05:52.686  1003  1003 D OppoExLayer: ~Layer() sequence=16484, name=ActivityRecord{312b839 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000702af4d000
08-30 11:05:52.843 26030 26115 E Thing-Network: connect failed!error code 110,msg: Connection timed out
08-30 11:05:52.664  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:05:53.015  1517  1517 D OppoBaseBatteryService: send broadcast : oppo.intent.action.BATTERY_DATA_UPDATE
08-30 11:05:53.015  1517  1517 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1158 com.android.server.OppoBaseBatteryService$2.run:280 android.os.Handler.handleCallback:938 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:263
08-30 11:05:53.016  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:05:53.021  2662  2803 W auto_download: Condition change condition:BatteryTemptureCondtion#status:Phone tempture:34
08-30 11:05:53.023  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3439000
08-30 11:05:53.023  3234  3234 D DeviceInfoHidlClient: isPowerInfoNeverSent()=true
08-30 11:05:53.023  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:05:53.025  2662  2803 W market_app_upload: [check] checkUploadFrequency from condition change fail! condition: 3_8, current frequency: 86400000, last check time: 1693349803236
08-30 11:05:53.053 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=610.0, y[0]=1143.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343764021, downTime=343764021, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:53.054 25924 25924 D ViewRootImpl[FamilyHomeActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=610.0, y[0]=1143.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343764021, downTime=343764021, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:53.054 25924 25924 D ViewRootImpl[FamilyHomeActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=610.0, y[0]=1143.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343764021, downTime=343764021, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:53.107 25924 25924 D ViewRootImpl[FamilyHomeActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=610.0, y[0]=1143.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343764075, downTime=343764021, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:53.107 25924 25924 D ViewRootImpl[FamilyHomeActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=610.0, y[0]=1143.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343764075, downTime=343764021, deviceId=3, source=0x1002, displayId=0 }
08-30 11:05:53.112 25924 25924 E Parcel  : Reading a NULL string not supported here.
08-30 11:05:53.113  1517  5208 I ActivityTaskManager: START u0 {cmp=com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity (has extras) mCallingUid=10030} from uid 10030 and from pid 25924
08-30 11:05:53.113  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateINITIALIZING
08-30 11:05:53.114  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateINITIALIZING
08-30 11:05:53.114  1517  5208 D ColorZoomWindowRUSConfigManager: isSupportZoomModeWithPolicyLocked: target = com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity
08-30 11:05:53.114  1517  5208 D ColorZoomWindowRUSConfigManager: targetPkg = com.tuya.smartiot
08-30 11:05:53.114  1517  5208 V ColorZoomWindowManagerService: unSupportZoom: false ,callingPid: 25924 ,sourceStack: Task{564553c #1831 visible=true type=standard mode=fullscreen translucent=true A=10030:com.tuya.smartiot U=0 StackId=1831 sz=1}
08-30 11:05:53.114   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:53.114   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:53.114   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:05:53.114   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:05:53.115   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:05:53.115   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for AdaptLaunch
08-30 11:05:53.115   966  1041 I ANDR-PERF-LM: Core: lmMain() 391: runAsync for AdaptLaunch returned
08-30 11:05:53.115   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:05:53.115   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:05:53.115  1517  5208 D OplusDisplayCompatUtils: com.tuya.smartiot, maxAspectRatio: 2.2 >>> 0.0
08-30 11:05:53.117  1517  5208 D ColorZoomWindowRUSConfigManager: isSupportZoomModeWithPolicyLocked: target = com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity
08-30 11:05:53.117  1517  5208 D ColorZoomWindowRUSConfigManager: targetPkg = com.tuya.smartiot
08-30 11:05:53.117  1517  5208 V ColorZoomWindowManagerService: unSupportZoom: false ,callingPid: 25924 ,sourceStack: Task{564553c #1831 visible=true type=standard mode=fullscreen translucent=true A=10030:com.tuya.smartiot U=0 StackId=1831 sz=2}
08-30 11:05:53.117  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateRESUMED
08-30 11:05:53.117   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:53.117   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:53.117   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:05:53.117   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:05:53.117  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestatePAUSING
08-30 11:05:53.118  1517  5208 D ActivityTrigger: ActivityTrigger activityPauseTrigger
08-30 11:05:53.118   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:53.118   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:53.118   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:53.118   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:53.118   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:53.118   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:53.119   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:53.119   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:53.119   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=1
08-30 11:05:53.119   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=2
08-30 11:05:53.119  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestatePAUSING
08-30 11:05:53.119   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=1
08-30 11:05:53.119   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for GameOptimization
08-30 11:05:53.119   966  1041 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:05:53.119   966  1041 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:05:53.120   966  1041 I ANDR-PERF-LM: Core: lmMain() 391: runAsync for GameOptimization returned
08-30 11:05:53.120   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:05:53.120   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=1
08-30 11:05:53.120   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:05:53.120   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for GameOptimization
08-30 11:05:53.120   966  1041 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:05:53.120   966  1041 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:05:53.120   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:05:53.127  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestatePAUSED
08-30 11:05:53.127  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestatePAUSED
08-30 11:05:53.127  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateRESUMED
08-30 11:05:53.128   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:53.128   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:53.128   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:05:53.128   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:05:53.128   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:05:53.128   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for GameOptimization
08-30 11:05:53.128  1517 13105 I OppoBaseActivityStack: notifyAppSwitch the same packageName!
08-30 11:05:53.128   966  1041 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:05:53.128  1517 13105 I ActivityTaskManager: The Process com.tuya.smartiot Already Exists in BG. So sending its PID: 25924
08-30 11:05:53.128  1517  2592 I MotorManagerService: notifyActivityChanged: mBackgroudPkg = com.tuya.smartiot mFocusPkg = com.tuya.smartiot mIsSplitMode = true mBackActivity = com.thingclips.smart.hometab.activity.FamilyHomeActivity mFocusActivity = com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity
08-30 11:05:53.128   966  1041 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:05:53.128   966  1041 I ANDR-PERF-LM: Core: lmMain() 391: runAsync for GameOptimization returned
08-30 11:05:53.128   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:05:53.128   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:05:53.128  1517 13105 W ActivityTaskManager: Tried to set launchTime (0) < mLastActivityLaunchTime (343743016)
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for AdaptLaunch
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: MetaMeter: isValidAsync() 194: AsyncInfo: hintID = 4225
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: hintType: 102
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: isPrimary = 0
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: MetaMeter: isValidAsync() 203: Invalid (hintID,hintType,appName,duration,appPID,appThreadTID) = (4225, 102,com.tuya.smartiot,25924,1517,13105)
08-30 11:05:53.129   966  1041 E ANDR-PERF-LM: MetaMeter: handleAsync() 164: AdaptLaunch Invalid Async
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: Core: lmMain() 391: runAsync for AdaptLaunch returned
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:05:53.129   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:05:53.130  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateRESUMED
08-30 11:05:53.130  1517 13105 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateRESUMED
08-30 11:05:53.131  1517 13105 I InputDispatcher: setFocusedApplication displayId=0 <invalid>
08-30 11:05:53.131  1517 13105 V WindowManager: Changing focus from Window{6d8b026 u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity} to null,diplayid=0
08-30 11:05:53.132  1517 13105 D Theia.NoFocusWindow: FocusWindowErrorScene CheckFreezeScreen
08-30 11:05:53.136 25924 26515 E libEGL  : Invalid file path for libcolorx-loader.so
08-30 11:05:53.136  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.140   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:53.140   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:53.140   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:53.140   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:53.141   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:53.141   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:53.143  1517  1861 W Choreographer: Frame time is 0.075051 ms in the future!  Check that graphics HAL is generating vsync timestamps using the correct timebase.
08-30 11:05:53.146 25924 25924 W m.tuya.smartio: Accessing hidden field Landroid/view/LayoutInflater;->mConstructorArgs:[Ljava/lang/Object; (greylist-max-p, reflection, denied)
08-30 11:05:53.154 25924 25924 I chatty  : uid=10030(com.tuya.smartiot) identical 3 lines
08-30 11:05:53.155 25924 25924 W m.tuya.smartio: Accessing hidden field Landroid/view/LayoutInflater;->mConstructorArgs:[Ljava/lang/Object; (greylist-max-p, reflection, denied)
08-30 11:05:53.161  1517  5210 I InputDispatcher: Focus left window: Window{6d8b026 u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity} in display 0
08-30 11:05:53.171 25924 25924 W m.tuya.smartio: Accessing hidden field Landroid/view/LayoutInflater;->mConstructorArgs:[Ljava/lang/Object; (greylist-max-p, reflection, denied)
08-30 11:05:53.179 25924 25924 D AudioManager: setMode mode=0 from com.tuya.smartiot
08-30 11:05:53.179  1517  5209 I AS.AudioService: setMode(mode = 0, callingPackage = com.tuya.smartiot, Process ID: 25924
08-30 11:05:53.179  1517  5209 D AS.AudioService: +notifyAtlasServiceModesUpdate onlyRead :true
08-30 11:05:53.179  1517  5209 D AS.AudioService: modekey = allmodes=
08-30 11:05:53.180  1517  5209 D AS.AudioService: -notifyAtlasServiceModesUpdate
08-30 11:05:53.181  1517  5209 D AS.AudioService: ringVolumeDefault :0
08-30 11:05:53.182  4254  4320 D OppoAtlasAudioState: getActiveAudioMusic ret = false
08-30 11:05:53.182   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.183   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.183  4254  4320 D AudioManager: getStreamVolume packageName=com.oppo.atlas, index=0, streamType=3
08-30 11:05:53.183  1517  3119 D AS.AudioService: getParameters() keyValuePairs:OPLUS_AUDIO_GET_DEVICE_FORSTREAM:3
08-30 11:05:53.184   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:53.184   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.185   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.185   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:53.186   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:53.187   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:53.187   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.188   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.189   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.190   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.197 25924 25924 I AudioManager: In stopBluetoothSco(), calling application: com.tuya.smartiot
08-30 11:05:53.197  1517  2577 I AS.AudioDeviceBroker: In updateSpeakerphoneOn(), mForcedUseForCommExt: 1
08-30 11:05:53.197   999  5227 D AudioPolicyManagerCustom: setForceUse() usage 7, config 0, mPhoneState 0
08-30 11:05:53.197  1517 13105 I AS.AudioService: In stopBluetoothSco()
08-30 11:05:53.197  1517 13105 D BluetoothAdapter: 153783973: getState(). Returning OFF
08-30 11:05:53.197  1517 13105 I AS.AudioService: stopBluetoothSco(), BT is not turned ON or adapter is null
08-30 11:05:53.197 25924 25924 I AudioManager: In setBluetoothScoOn(), on: false, calling application: com.tuya.smartiot
08-30 11:05:53.197   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.198   999 12926 D AudioPolicyManagerCustom: setForceUse() usage 0, config 1, mPhoneState 0
08-30 11:05:53.198  4254  4320 D OppoAtlasAudioState: isSpeakerMute() device: 2 ,index:0,ST:3
08-30 11:05:53.198  4254  4320 D OppoAtlasAudioState: checkAndSetPaState(state:4,mute:true), hasMusic:false,mode:0 ,mIsPlaybackRecord:false
08-30 11:05:53.198   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000001, index 14
08-30 11:05:53.200 25924 25924 D AudioManager: setBluetoothScoOn keys: get_device_change_authority=com.tuya.smartiot, mAuthoriyStr = true
08-30 11:05:53.200  1517  5210 I AS.AudioService: In setBluetoothScoOn(), on: false. The calling application Uid: 10030, is greater than FIRST_APPLICATION_UID exiting from setBluetoothScoOn()
08-30 11:05:53.200  1517  5210 I AS.AudioDeviceBroker: In setBluetoothScoOnByApp(), mForcedUseForCommExt: 1
08-30 11:05:53.200  1517  5210 I AS.AudioDeviceBroker: after setBluetoothScoOnByApp(), mForcedUseForCommExt: 1
08-30 11:05:53.200   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.200 25924 25924 I AudioManager: In setSpeakerphoneOn(), on: true, calling application: com.tuya.smartiot
08-30 11:05:53.201  1517  5209 I AS.AudioService: In setSpeakerphoneOn(), on: true, eventSource: setSpeakerphoneOn(true) from u/pid:10030/25924
08-30 11:05:53.201  1517  5209 I AS.AudioDeviceBroker: In isSpeakerphoneOn(), mForcedUseForCommExt: 1
08-30 11:05:53.201  1517  5209 I AS.AudioDeviceBroker: In updateSpeakerphoneOn(), mForcedUseForCommExt: 1
08-30 11:05:53.201   999  1508 D AudioPolicyManagerCustom: setForceUse() usage 0, config 1, mPhoneState 0
08-30 11:05:53.202   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 12
08-30 11:05:53.202   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.139  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.203 25924 25924 D ColorViewRootUtil: initSwipState, isDisplayCompatApp false
08-30 11:05:53.203 25924 25924 D ColorViewRootUtil: mScreenHeight 2400, mScreenWidth 1080
08-30 11:05:53.203 25924 25924 D WindowManager: Add to mViews: DecorView@a180d2e[TRCTSmartCameraPanelActivity],pkg= com.tuya.smartiot
08-30 11:05:53.203   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 14
08-30 11:05:53.203   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.204   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 12
08-30 11:05:53.204   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.205   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 14
08-30 11:05:53.205   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.206  1517  3119 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:05:53.208   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 14
08-30 11:05:53.209   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:53.210   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:53.211   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 9
08-30 11:05:53.212  1517  2527 I OplusWifiSarManager: Received action: android.media.ACTION_AUDIO_DEVICE_ROUTE_CHANGED
08-30 11:05:53.213  1517 13105 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:05:53.213   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000008, index 9
08-30 11:05:53.214   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 9
08-30 11:05:53.214   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 8
08-30 11:05:53.214   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 04000000, index 8
08-30 11:05:53.215   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 9
08-30 11:05:53.215  1517 13105 V WindowManager: Changing focus from null to Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:05:53.216 25924 26526 I MMKV    : <MMKV.cpp:198::initializeMMKV> root dir: /data/user/0/com.tuya.smartiot/files/thingmmkv
08-30 11:05:53.217  1517 13105 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:05:53.218  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.219 25924 25924 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 2400 getDecorView.DecorView@a180d2e[TRCTSmartCameraPanelActivity]
08-30 11:05:53.224  1003  1746 D DispPerfService: onframeavailable pid=25924, slot=0, seq=16505, name=com.tuya.smartiot:com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0
08-30 11:05:53.230  1517  1861 D ColorZoomWindowManagerService: adjustWindowCropForLeash start: appToken = ActivityRecord{51118d4 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity t1831}
08-30 11:05:53.232  1517  1861 D ColorZoomWindowManagerService: adjustWindowCropForLeash start: appToken = ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity t1831}
08-30 11:05:53.233   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:53.233   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:53.233   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:05:53.233   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:05:53.233   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:05:53.233   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:05:53.233   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:05:53.233  1517  1882 I ActivityTaskManager: Displayed com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity: +119ms
08-30 11:05:53.237   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:53.237   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:53.237   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:05:53.237   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:05:53.237   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:05:53.240  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.241  1003  1003 D OppoExLayer: ~Layer() sequence=16497, name=Surface(name=74ffb6 StatusBar)/@0xbaad1b7 - animation-leash#0@0xb40000701dbaf000
08-30 11:05:53.241  1003  1003 D OppoExLayer: ~Layer() sequence=16498, name=Surface(name=29f1a38 NavigationBar0)/@0xe2b3d24 - animation-leash#1@0xb40000701dbe4000
08-30 11:05:53.242  1517  5209 I InputDispatcher: Focus entered window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:05:53.244  1517 13105 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:05:53.244  1517 13105 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:05:53.241  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.244  1517 13105 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:05:53.244  1517 13105 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:05:53.245  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.257 25924 26526 I MMKV    : <MMKV.cpp:198::initializeMMKV> root dir: /data/user/0/com.tuya.smartiot/files/thingmmkv
08-30 11:05:53.260  1517 13105 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:05:53.279   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:53.279   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:53.279   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:05:53.280   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:05:53.280   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:05:53.288 25924 26530 E ReactNativeJNI: init V8 by wrapper
08-30 11:05:53.297 12694 12707 W method.sogouoe: Reducing the number of considered missed Gc histogram windows from 356 to 100
08-30 11:05:53.303 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.art.ARTGroupViewManager
08-30 11:05:53.303 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.art.ARTGroupShadowNode
08-30 11:05:53.304 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.art.ARTShapeViewManager
08-30 11:05:53.305 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.art.ARTShapeShadowNode
08-30 11:05:53.305 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.art.ARTTextViewManager
08-30 11:05:53.305 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.art.ARTTextShadowNode
08-30 11:05:53.306 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.checkbox.ReactCheckBoxManager
08-30 11:05:53.309 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.uimanager.LayoutShadowNode
08-30 11:05:53.310 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.picker.ReactDialogPickerManager
08-30 11:05:53.311 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.drawer.ReactDrawerLayoutManager
08-30 11:05:53.311 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.picker.ReactDropdownPickerManager
08-30 11:05:53.312 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.scroll.ReactHorizontalScrollViewManager
08-30 11:05:53.313 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.scroll.ReactHorizontalScrollContainerViewManager
08-30 11:05:53.313 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.progressbar.ReactProgressBarViewManager
08-30 11:05:53.314 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.progressbar.ProgressBarShadowNode
08-30 11:05:53.314 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.scroll.ReactScrollViewManager
08-30 11:05:53.315 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.slider.ReactSliderManager
08-30 11:05:53.316 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.slider.ReactSliderManager$ReactSliderShadowNode
08-30 11:05:53.316 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.switchview.ReactSwitchManager
08-30 11:05:53.317 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.switchview.ReactSwitchManager$ReactSwitchShadowNode
08-30 11:05:53.317 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.toolbar.ReactToolbarManager
08-30 11:05:53.318 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.webview.ReactWebViewManager
08-30 11:05:53.319 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.swiperefresh.SwipeRefreshLayoutManager
08-30 11:05:53.320 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.art.ARTSurfaceViewManager
08-30 11:05:53.320 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.art.ARTSurfaceViewShadowNode
08-30 11:05:53.321 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.text.frescosupport.FrescoBasedReactTextInlineImageViewManager
08-30 11:05:53.322 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.text.frescosupport.FrescoBasedReactTextInlineImageShadowNode
08-30 11:05:53.322 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.image.ReactImageManager
08-30 11:05:53.323 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.modal.ReactModalHostManager
08-30 11:05:53.324 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.modal.ModalHostShadowNode
08-30 11:05:53.325 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.text.ReactRawTextManager
08-30 11:05:53.325 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.text.ReactRawTextShadowNode
08-30 11:05:53.325 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.textinput.ReactTextInputManager
08-30 11:05:53.328 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.textinput.ReactTextInputShadowNode
08-30 11:05:53.329 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.text.ReactTextViewManager
08-30 11:05:53.330 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.text.ReactTextShadowNode
08-30 11:05:53.330 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.view.ReactViewManager
08-30 11:05:53.332 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.viewpager.ReactViewPagerManager
08-30 11:05:53.332 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.text.ReactVirtualTextViewManager
08-30 11:05:53.333 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.facebook.react.views.text.ReactVirtualTextShadowNode
08-30 11:05:53.333 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctvisionmap.TRCTVisionMap
08-30 11:05:53.334 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctvisionmap.ThingRCTVisionMap
08-30 11:05:53.335 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.swmansion.gesturehandler.react.RNGestureHandlerRootViewManager
08-30 11:05:53.335 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.swmansion.gesturehandler.react.RNGestureHandlerButtonViewManager
08-30 11:05:53.336 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctslider.TRCTSlider
08-30 11:05:53.337 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctslider.ThingRCTSlider
08-30 11:05:53.337 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.RenderableViewManager
08-30 11:05:53.338 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.GroupShadowNode
08-30 11:05:53.339 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.PathShadowNode
08-30 11:05:53.339 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.CircleShadowNode
08-30 11:05:53.340 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.EllipseShadowNode
08-30 11:05:53.340 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.LineShadowNode
08-30 11:05:53.341 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.RectShadowNode
08-30 11:05:53.342 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.TextShadowNode
08-30 11:05:53.343 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.TSpanShadowNode
08-30 11:05:53.343 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.TextPathShadowNode
08-30 11:05:53.343 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.ImageShadowNode
08-30 11:05:53.344 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.ClipPathShadowNode
08-30 11:05:53.344 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.DefsShadowNode
08-30 11:05:53.344 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.UseShadowNode
08-30 11:05:53.344 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.SymbolShadowNode
08-30 11:05:53.344 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.LinearGradientShadowNode
08-30 11:05:53.345 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.RadialGradientShadowNode
08-30 11:05:53.345 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.ConicalGradientShadowNode
08-30 11:05:53.345 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.SvgViewManager
08-30 11:05:53.345 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.horcrux.svg.SvgViewShadowNode
08-30 11:05:53.345 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctgesturelockviewmanager.TRCTGestureLockViewManager
08-30 11:05:53.346 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctgesturelockviewmanager.ThingRCTGestureLockViewManager
08-30 11:05:53.346 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trcthuecircleview.TRCTHueCircleView
08-30 11:05:53.347 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trcthuecircleview.ThingRCTHueCircleView
08-30 11:05:53.347 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctencryptimagemanager.TRCTEncryptImageManager
08-30 11:05:53.348 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctencryptimagemanager.ThingRCTEncryptImageManager
08-30 11:05:53.348 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcameraviewmanager.TRCTCameraViewManager
08-30 11:05:53.348 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcameraviewmanager.ThingRCTCameraViewManager
08-30 11:05:53.349 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctlinechartview.TRCTLineChartView
08-30 11:05:53.350 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctlinechartview.ThingRCTLineChartView
08-30 11:05:53.350 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class org.reactnative.maskedview.RNCMaskedViewManager
08-30 11:05:53.350 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.reactnativecommunity.webview.RNCWebViewManager
08-30 11:05:53.351 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.airbnb.android.react.lottie.LottieAnimationViewManager
08-30 11:05:53.352 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctrtspmediaplayermanager.TRCTRTSPMediaPlayerManager
08-30 11:05:53.352 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctrtspmediaplayermanager.ThingRCTRTSPMediaPlayerManager
08-30 11:05:53.352 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctchartsmanager.TRCTChartsManager
08-30 11:05:53.353 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctchartsmanager.ThingRCTChartsManager
08-30 11:05:53.353 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctswitch.TRCTSwitch
08-30 11:05:53.354 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctswitch.ThingRCTSwitch
08-30 11:05:53.354 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctpicker.TRCTPicker
08-30 11:05:53.355 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctpicker.ThingRCTPicker
08-30 11:05:53.355 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctchartmarker.TRCTChartMarkerManager
08-30 11:05:53.355 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctchartmarker.ThingChartMarkerManager
08-30 11:05:53.356 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctlasermap.TRCTLaserMap
08-30 11:05:53.359 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctlasermap.ThingRCTLaserMap
08-30 11:05:53.359 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.cmcewen.blurview.BlurViewManager
08-30 11:05:53.360 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctdigitalfunbitmapview.TRCTDigitalFunBitmapView
08-30 11:05:53.360 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctdigitalfunbitmapview.ThingRCTDigitalFunBitmapView
08-30 11:05:53.360 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.BV.LinearGradient.LinearGradientManager
08-30 11:05:53.361 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trcttopbar.TRCTTopBar
08-30 11:05:53.361 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trcttopbar.ThingRCTTopBar
08-30 11:05:53.361 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.th3rdwave.safeareacontext.SafeAreaProviderManager
08-30 11:05:53.361 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.th3rdwave.safeareacontext.SafeAreaViewManager
08-30 11:05:53.362 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.th3rdwave.safeareacontext.SafeAreaViewShadowNode
08-30 11:05:53.362 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctnumberpicker.TRCTNumberPicker
08-30 11:05:53.363 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctnumberpicker.ThingRCTNumberPicker
08-30 11:05:53.363 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.swmansion.rnscreens.ScreenContainerViewManager
08-30 11:05:53.363 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.swmansion.rnscreens.ScreenViewManager
08-30 11:05:53.363 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.swmansion.rnscreens.ScreenStackViewManager
08-30 11:05:53.363 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.swmansion.rnscreens.ScreenStackHeaderConfigViewManager
08-30 11:05:53.364 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.swmansion.rnscreens.ScreenStackHeaderSubviewManager
08-30 11:05:53.364 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctqqwebview.TRCTQQWebView
08-30 11:05:53.364 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctqqwebview.ThingRCTQQWebView
08-30 11:05:53.364 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctwheelviewmanager.TRCTWheelViewManager
08-30 11:05:53.365 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctwheelviewmanager.ThingRCTWheelViewManager
08-30 11:05:53.365 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctpointmap.TRCTPointMap
08-30 11:05:53.366 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctpointmap.ThingRCTPointMap
08-30 11:05:53.366 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctnewtopbar.TRCTNewTopBar
08-30 11:05:53.366 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctnewtopbar.ThingRCTNewTopBar
08-30 11:05:53.366 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.rctvideomanager.RCTVideoManager
08-30 11:05:53.367 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctmultilinechartview.TRCTMultiLineChartView
08-30 11:05:53.368 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctmultilinechartview.ThingRCTMultiLineChartView
08-30 11:05:53.368 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcurvechartview.TRCTCurveChartView
08-30 11:05:53.368 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcurvechartview.ThingRCTCurveChartView
08-30 11:05:53.369 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.amap.manager.AMapManager
08-30 11:05:53.369 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.amap.manager.AMapMarkerManager
08-30 11:05:53.370 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.amap.manager.AMapPolylineManager
08-30 11:05:53.370 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.amap.manager.AMapPolygonManager
08-30 11:05:53.370 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.amap.manager.AMapCircleManager
08-30 11:05:53.371 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.amap.manager.AMapCalloutManager
08-30 11:05:53.371 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcameramessagemediaplayermanager.TRCTCameraMessageMediaPlayerManager
08-30 11:05:53.371 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcameramessagemediaplayermanager.ThingRCTCameraMessageMediaPlayerManager
08-30 11:05:53.372 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcameraplayer.TRCTCameraPlayer
08-30 11:05:53.373 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcameraplayer.ThingRCTCameraPlayer
08-30 11:05:53.373 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctthingcameraplayer.TRCTThingCameraPlayer
08-30 11:05:53.374 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctthingcameraplayer.ThingRCTThingCameraPlayer
08-30 11:05:53.374 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcameratimelineviewmanager.TRCTCameraTimeLineViewManager
08-30 11:05:53.374 25924 26531 W unknown:ViewManagerPropertyUpdater: Could not find generated setter for class com.thingclips.smart.rnplugin.trctcameratimelineviewmanager.ThingRCTCameraTimeLineViewManager
08-30 11:05:53.383 25924 26531 I ThingMediaPlayerSDK: [2023-08-30 11:05:53.383] int ThingInitialize call ThingInitialize , result = 0
08-30 11:05:53.384 25924 26531 I ThingMediaPlayerSDK: [2023-08-30 11:05:53.384] int ThingInitialize call ThingInitialize , result = 0
08-30 11:05:53.472 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"offer","trace_id":"","is_pre":0,"p2p_skill":99,"security_level":3,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1693364747 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6ce1f26844bfce86f3zrdp1693364747fb4ItmZl\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:Vy99\r\na=ice-pwd:cDHufbKYKxdUXmd5GoSxXxfW\r\na=ice-options:trickle\r\na=aes-key:0030d000020e0000c0a0500c016000ae\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1690445086544UqnKu\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"urls":"turn:47.103.2.131:3478","credential":"X+mL+gJbCE7O5bTawRE1VmDzL6k=","ttl":3600,"username":"1693368347:6ce1f26844bfce86f3zrdp"}],"tcp_token":{"urls":["tcp4:1.117.192.37:1443"],"credential":"ZcXI3Oi4MrCJRJQE
08-30 11:05:53.479 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1203632304 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:53.484 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:125314865 1 UDP 2130706431 0.0.0.0 47428 typ host\r\n"}}} ...
08-30 11:05:53.489 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1016807572 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:53.495 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:304027100 1 UDP 2130706431 :: 47428 typ host\r\n"}}} ...
08-30 11:05:53.500 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1258010157 1 UDP 1694498815 49.78.21.79 10251 typ srflx\r\n"}}} ...
08-30 11:05:53.263  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.503  1517  1861 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{51118d4 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity t1831}
08-30 11:05:53.504  1517  1861 I ColorAppSwitchManagerService:  handleAppVisible , r = ActivityRecord{51118d4 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity t1831}
08-30 11:05:53.504  1517  1861 I OplusMirageDisplayManagerService: onAnimationFinished:
08-30 11:05:53.504  1517  1861 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity t1831}
08-30 11:05:53.505  1517  1860 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateSTOPPING
08-30 11:05:53.505  1517  1860 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateSTOPPING
08-30 11:05:53.511  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.512 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1980245951 1 UDP 16777215 47.103.2.131 51207 typ relay\r\n"}}} ...
08-30 11:05:53.518 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":""}}} ...
08-30 11:05:53.519  1003  1003 D OppoExLayer: ~Layer() sequence=16511, name=Surface(name=ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity)/@0x4126c9a - animation-bounds#0@0xb40000702affc000
08-30 11:05:53.519  1003  1003 D OppoExLayer: ~Layer() sequence=16510, name=Surface(name=ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity)/@0x4126c9a - animation-leash#0@0xb40000702af22000
08-30 11:05:53.519  1003  1003 D OppoExLayer: ~Layer() sequence=16509, name=Surface(name=ActivityRecord{51118d4 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x526c87a - animation-bounds#0@0xb40000702af9e000
08-30 11:05:53.519  1003  1003 D OppoExLayer: ~Layer() sequence=16508, name=Surface(name=ActivityRecord{51118d4 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x526c87a - animation-leash#0@0xb40000702afa7000
08-30 11:05:53.532  1517  5208 I WifiService: getWifiEnabledState uid=1000
08-30 11:05:53.533  1517  3119 I WifiService: getWifiApEnabledState uid=1000
08-30 11:05:53.533  1517  3119 I WifiService: getConnectionInfo uid=1000
08-30 11:05:53.525  1517  1860 I chatty  : uid=1000(system) android.display identical 2 lines
08-30 11:05:53.528  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:53.539  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateSTOPPED
08-30 11:05:53.539  1517  5208 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateSTOPPED
08-30 11:05:53.552  1003  1003 D OppoExLayer: ~Layer() sequence=16496, name=com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity#0@0xb40000701dd57000
08-30 11:05:53.599  1517  2519 D WN_S    : DT,tP=943049, dTP=2, rP=1653704, dRP=2 mIR=true, mRPLC=0
08-30 11:05:53.599  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:53.616   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:53.616   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:53.616   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:53.616   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:53.616   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:53.616   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:53.671  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 58ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653720 wlan0TxPtk=943066 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:53.709 25924 26530 I MMKV    : <MMKV.cpp:198::initializeMMKV> root dir: /data/user/0/com.tuya.smartiot/files/thingmmkv
08-30 11:05:53.739   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:05:53.739   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:05:53.739   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:05:53.739   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:05:53.739   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:05:53.739   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:05:53.881  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:05:53.882  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=32,badLossCount=0,txLoss=0,mLinkDetectTimes= 600,mIndex =0
08-30 11:05:53.882  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 58, 0, 0, 0, 0, 676, 60, 0, 0, 0, 0, 676, 60, 0, 0, 0, 0, 676, 60, 0, 0, 0, 0, 676, 62, 0, 0, 0, 0]
08-30 11:05:53.882  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:05:53.882  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:05:53.882  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:05:53.884  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:05:53.884  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-45,mIndex =0,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12574301493
08-30 11:05:53.884  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:05:53.884  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:05:53.884  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:05:53.884  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:05:53.884  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:05:53.884  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:05:53.884  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:05:54.098 30404 30444 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:05:54.100 30404 30444 D HoraeHelper: Thermal length:1
08-30 11:05:54.193 30404 30447 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:05:54.260 25924 25924 D TestOverScroll: getScaledOverscrollDistance: b
08-30 11:05:54.274 25924 25924 D TestOverScroll: getScaledOverscrollDistance: b
08-30 11:05:54.364  1517  5210 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:05:54.370  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:54.376 25924 25924 D TestOverScroll: getScaledOverscrollDistance: b
08-30 11:05:54.380  1517  5210 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:05:54.394 25924 25924 I MMKV    : <MMKV.cpp:198::initializeMMKV> root dir: /data/user/0/com.tuya.smartiot/files/thingmmkv
08-30 11:05:54.426 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:54.426 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:54.448  1517  5210 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:05:54.464 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:54.464 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:54.464 25924 26551 E libEGL  : Invalid file path for libcolorx-loader.so
08-30 11:05:54.467 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:54.467 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:54.470  1003  1003 E OppoExLayer: using cid as pid, cid=25924, name=Background for -SurfaceView - com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0
08-30 11:05:54.382  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:05:54.453  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:05:54.484  1517  5210 W ActivityManager: setGlThreads detect 25924 26551
08-30 11:05:54.484  1003  1129 D DispPerfService: onframeavailable pid=25924, slot=0, seq=16513, name=com.tuya.smartiot:SurfaceView - com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0
08-30 11:05:54.490   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:05:54.490   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:05:54.490   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:05:54.490   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:05:54.490   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:05:54.494 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:54.494 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:54.534  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-45 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:05:54.534  1517  2519 D OplusRssiMonitor: update rssi:-45
08-30 11:05:54.536  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:05:54.536  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:05:54.536  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:05:54.536  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-44 for "abc_ling"WPA_PSK
08-30 11:05:54.536  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:05:54.538  1517  2519 D WifiDataStall: L2 txTputKbps: 59400, rxTputKbps: 66000, L3 txTputKbps: 85, rxTputKbps: 27, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:05:54.539  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -45, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:05:54.539  1517  2519 D WifiScoreCard: txRate: 16 txSpeed: 96
08-30 11:05:54.539  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -45 txSpeed 96
08-30 11:05:54.539  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:05:54.539  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538592540 LastRssiPoll: -45 LastTxSpeedPoll: 96
08-30 11:05:54.539  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:05:54.539  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:54.539  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:54.543  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -45 level: 4
08-30 11:05:54.544  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-45 f=2462 sc=0 link=96 tx=14.2, 1.7, 0.0  rx=12.1 bcn=9009231 [on:1778 tx:45 rx:36 period:3009] from screen [on:4915811 period:6544474] score=0
08-30 11:05:54.549  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -45
08-30 11:05:54.549  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:05:54.550  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:05:54.554  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:05:54.554  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:05:54.712  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 56ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653748 wlan0TxPtk=943094 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:54.748  1517  3181 I ColorHansManager : pkg: com.tencent.mm,state: R -> F
08-30 11:05:54.751  1517  3181 I ColorHansManager : freeze uid: 10011 package: com.tencent.mm reason: F-direct scene: LcdOnScene
08-30 11:05:54.752  5580  7502 D IHansComunication: HANS sendMessageToKernel: threadId = 514316025024, netLinkSetup = 1, type = PKG, targetUid = 10011, pkgCmd = ADD_ONE_UID
08-30 11:05:54.753  1517  3181 I ColorHansManager : pkg: com.google.android.gms,state: R -> F
08-30 11:05:54.755  1517  3181 I ColorHansManager : freeze uid: 10034 package: com.google.android.gms reason: F-direct scene: LcdOnScene
08-30 11:05:54.756  5580  7502 D IHansComunication: HANS sendMessageToKernel: threadId = 514316025024, netLinkSetup = 1, type = PKG, targetUid = 10034, pkgCmd = ADD_ONE_UID
08-30 11:05:54.830 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:54.830 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:54.831 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:54.832 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:54.846 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:54.846 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:54.864 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:05:54.864 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:05:55.601  1517  2519 D WN_S    : DT,tP=943094, dTP=45, rP=1653748, dRP=44 mIR=true, mRPLC=0
08-30 11:05:55.601  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:55.751  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 56ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653757 wlan0TxPtk=943102 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:56.017  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:05:56.023  1517  1991 I ColorHansManager : unfreeze uid: 10011 package: com.tencent.mm reason: Broadcast scene: LcdOnScene
08-30 11:05:56.023  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3440200
08-30 11:05:56.023  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:05:56.024  1517  1991 I ColorHansManager : pkg: com.tencent.mm,state: F -> M
08-30 11:05:56.550  1517  1863 V OppoBaseWatchdog: @WatchDog_ error e: java.io.FileNotFoundException: /d/wakeup_sources: open failed: ENOENT (No such file or directory)
08-30 11:05:56.551  1517  5210 I WifiService: getWifiEnabledState uid=1000
08-30 11:05:56.552  1517  5210 I WifiService: getWifiApEnabledState uid=1000
08-30 11:05:56.552  1517  5210 I WifiService: getConnectionInfo uid=1000
08-30 11:05:56.753  5580  7502 D IHansComunication: HansComunication::configCheckedUid-- 10011, type = 0
08-30 11:05:56.753  5580  7502 D IHansComunication: HANS sendMessageToKernel: threadId = 514316025024, netLinkSetup = 1, type = FROZEN_TRANS, targetUid = 10011, pkgCmd = PKG_CMD_MAX
08-30 11:05:56.756  5580  7502 D IHansComunication: HansComunication::configCheckedUid-- 10034, type = 0
08-30 11:05:56.756  5580  7502 D IHansComunication: HANS sendMessageToKernel: threadId = 514316025024, netLinkSetup = 1, type = FROZEN_TRANS, targetUid = 10034, pkgCmd = PKG_CMD_MAX
08-30 11:05:56.791  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 56ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653757 wlan0TxPtk=943102 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:57.507 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757034,"v":"3.5.2","p":"rtc_tcp_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":2,"d":10257,"tconn":1693364747036,"tresp":1693364747086,"tcomp":0} ...
08-30 11:05:57.546  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-38 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:05:57.546  1517  2519 D OplusRssiMonitor: update rssi:-38
08-30 11:05:57.546  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:05:57.546  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:05:57.546  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:05:57.547  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-40 for "abc_ling"WPA_PSK
08-30 11:05:57.547  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:05:57.547  1517  2519 D WifiDataStall: L2 txTputKbps: 46860, rxTputKbps: 66000, L3 txTputKbps: 13, rxTputKbps: 31, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:05:57.548  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -38, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:05:57.548  1517  2519 D WifiScoreCard: txRate: 13 txSpeed: 96
08-30 11:05:57.548  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -38 txSpeed 96
08-30 11:05:57.548  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:05:57.548  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538595550 LastRssiPoll: -38 LastTxSpeedPoll: 96
08-30 11:05:57.548  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:05:57.548  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:57.548  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:05:57.553  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -38
08-30 11:05:57.554  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -38 level: 4
08-30 11:05:57.554  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:05:57.555  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-38 f=2462 sc=0 link=96 tx=9.8, 2.5, 0.0  rx=13.1 bcn=9009260 [on:1234 tx:17 rx:41 period:3010] from screen [on:4917045 period:6547485] score=0
08-30 11:05:57.555  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:05:57.555  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:05:57.559  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:05:57.601  1517  2519 D WN_S    : DT,tP=943102, dTP=8, rP=1653757, dRP=9 mIR=true, mRPLC=0
08-30 11:05:57.602  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:57.621 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757147,"v":"3.5.2","p":"rtc_session_answer","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":10370} ...
08-30 11:05:57.622 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757148,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:36917577 1 UDP 2130706431 192.168.243.224 57195 typ host\r\n","d":10371} ...
08-30 11:05:57.622 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757149,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:325396740 1 UDP 1694498815 49.78.21.79 10257 typ srflx\r\n","d":10372} ...
08-30 11:05:57.622 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757149,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:569354893 1 UDP 16777215 47.103.2.131 50420 typ relay\r\n","d":10372} ...
08-30 11:05:57.653 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757179,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"","d":10402} ...
08-30 11:05:57.667 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757193,"v":"3.5.2","p":"rtc_ice_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":2,"d":10417,"m":1,"nl":"192.168.243.62:47428","nr":"192.168.243.224:57195"} ...
08-30 11:05:57.667 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757194,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":3,"as":2,"h":1,"e":0,"ex":0,"d":10417} ...
08-30 11:05:57.668 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757194,"v":"3.5.2","p":"rtc_session_add","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","ca":"connect_v2","st":"new_session","e":0,"ex":0,"d":10417} ...
08-30 11:05:57.668 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757195,"v":"3.5.2","p":"rtc_connect_result","tid":"","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","rd":"6ce1f26844bfce86f3zrdp","ca":"connect_v3","ex":0,"d":10418} ...
08-30 11:05:57.668 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] m_P2pStepStatus:2
08-30 11:05:57.668 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364757668,"m":"camera","did":"6ce1f26844bfce86f3zrdp","op":"connect successed.","dt":10418 ,"tid":"no traceId"} ...
08-30 11:05:57.669 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] return:65538 p2pType:4 connect time cost:10418 leave(0)...
08-30 11:05:57.669 25924 26310 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 0, high_cmd = 10, low_cmd = 0, session = 65538, thing_p2p_rtc_send_data=24[] send...
08-30 11:05:57.670 25924 26310 I ThingCameraSDK: ThingCameraSimple::GetAudioParams Port[0] channel:0 enter....
08-30 11:05:57.670 25924 26310 I ThingCameraSDK: ThingCameraSimple::GetAudioParams Port[0] requestId:3 cmd high:2 low:0 ...
08-30 11:05:57.670 25924 26310 I ThingCameraSDK: ThingCameraSimple::GetAudioParams Port[0] leave(0)...
08-30 11:05:57.672 25924 26310 W unknown:ReactNative: Invoking JS callback after bridge has been destroyed.
08-30 11:05:57.672 25924 26310 W unknown:ReactNative: Calling JS function after bridge has been destroyed: RCTDeviceEventEmitter.emit(["connectionEnded",{"devId":"6ce1f26844bfce86f3zrdp","code":0}])
08-30 11:05:57.679 25924 26575 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 3, high_cmd = 2, low_cmd = 0, session = 65538, thing_p2p_rtc_send_data=24[] send...
08-30 11:05:57.683 25924 26310 I ThingCameraSDK: ThingCameraBase::Disconnect Port[0] description:Closed by disconnect api invoke. enter...
08-30 11:05:57.683 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364757683,"m":"camera","did":"6ce1f26844bfce86f3zrdp","op":"disconnect" ,"tid":"no traceId"} ...
08-30 11:05:57.683 25924 26310 I ThingCameraSDK: ThingCameraBase::Disconnect Port[0] p2pType:4 break return:0 ...
08-30 11:05:57.740 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:65538 is_pre:0 state:3 active_state:2 error:0...
08-30 11:05:57.770 25924 26576 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] version major:1 minor:2 ....
08-30 11:05:57.770 25924 26576 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:0 high_cmd:10 low_cmd:0 received...
08-30 11:05:57.771 25924 26576 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:0 highCmd:10 lowCmd:0
08-30 11:05:57.772 25924 26576 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:3 high_cmd:2 low_cmd:0 received...
08-30 11:05:57.772 25924 26576 I ThingCameraSDK: ThingNetRequestCommand::onResponse Port[0] this:0x6f8cdc2910 nRequestId:3...
08-30 11:05:57.773 25924 26576 I ThingCameraSDK: ThingAudioCallBack::onResponse Port[0] requestId:3 high cmd:2 low cmd:0
08-30 11:05:57.773 25924 26576 I ThingCameraSDK: ThingAudioCallBack::onGetAudioParams Port[0] response. sample_rate:8000 codecType:133 ..
08-30 11:05:57.779 25924 26580 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] thread exit...
08-30 11:05:57.780 25924 26576 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:3 highCmd:2 lowCmd:0
08-30 11:05:57.781 25924 26576 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] audioTalk parameters type:133 simpleRate:8000
08-30 11:05:57.831  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 56ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653775 wlan0TxPtk=943119 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:57.880 25924 26579 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadAudioStream Port[0] thread exit...
08-30 11:05:57.880 25924 26575 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommandPackageRunner Port[0] exit normally.
08-30 11:05:57.881 25924 26577 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::ResponseCommandTimeoutRunner Port[0] exit normally.
08-30 11:05:57.889 25924 26576 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::RecvCommandPackageRunner Port[0] exit normally.
08-30 11:05:57.891 25924 26310 W libc    : invalid pthread_t (0) passed to pthread_join
08-30 11:05:57.892 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757418,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":3,"as":3,"h":1,"e":0,"ex":0,"d":10641} ...
08-30 11:05:57.892 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:57.893 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"suspend","trace_id":"","path":"mqtt"},"msg":{"handle":1,"reason":0,"seq":1}}} ...
08-30 11:05:57.898 25924 26310 I ThingCameraSDK: ThingCameraBase::Disconnect Port[0] {"inner_p2p_type":4,"did":"6ce1f26844bfce86f3zrdp","thing_p2p_rtc_close":0,"sessionId":"65538","p2p_close_description":"Closed by disconnect api invoke."}
08-30 11:05:57.898 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364757898,"m":"camera","did":"6ce1f26844bfce86f3zrdp","op":"disconnect","dt":"215" ,"tid":"no traceId"} ...
08-30 11:05:57.898 25924 26310 I ThingCameraSDK: ThingCameraBase::Disconnect Port[0] p2pType:4 description:Closed by disconnect api invoke. return:0 ...
08-30 11:05:57.899 25924 26310 W libc    : invalid pthread_t (0) passed to pthread_join
08-30 11:05:57.899 25924 26310 I ThingAudioEngineSDK: ThingAudioControllerImpl::StopPlayBack enter this:0x6faa4d6f10 play status:0
08-30 11:05:57.899 25924 26310 I ThingAudioEngineSDK: ThingAudioControllerImpl::StopRecord enter
08-30 11:05:57.900 25924 26310 W unknown:ReactNative: Calling JS function after bridge has been destroyed: RCTDeviceEventEmitter.emit(["disconnectEnded",{"devId":"6ce1f26844bfce86f3zrdp","code":0}])
08-30 11:05:57.906 25924 26310 I ThingAvLoggerSDK: ThingP2PSDK::init enter..
08-30 11:05:57.906 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::Initialize sdkversion:3.4.55-rc.0 ....
08-30 11:05:57.906 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::Initialize p2p version : 0XF4030502
08-30 11:05:57.906 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::Initialize p2p connect open...
08-30 11:05:57.906 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_init enter...
08-30 11:05:57.906 25924 26310 I ThingAvLoggerSDK: ThingP2PSDK::init init return:0..
08-30 11:05:57.908 25924 26310 I ThingCameraSDK: ThingCameraNative setDeviceFeatures,the handle is :0x6f8a600040
08-30 11:05:57.908 25924 26310 I ThingCameraSDK: ThingCameraBase::SetDeviceFeatures Port[0] features:{"DecPostProcess":{"mirror":0,"rotation":0}} enter...
08-30 11:05:57.908 25924 26310 I ThingCameraSDK: ThingCameraBase::SetDeviceFeatures Port[0] leave(-1)...
08-30 11:05:57.909 25924 26310 I ThingCameraSDK: ThingCameraNative setSmartRectFeatures,the handle is :0x6f8a600040
08-30 11:05:57.909 25924 26310 I ThingCameraSDK: ThingCameraBase::SetSmartRectFeatures Port[0] channel:0 features:{"SmartRectFeature":[{"brushWidth":0,"flashFps":{"drawKeepFrames":0,"stopKeepFrames":0},"index":0,"rgb":16711680,"shape":1,"type":0}]} enter...
08-30 11:05:57.909 25924 26310 I ThingCameraSDK: ThingCameraAttributes::setSmartRectFeatures feature:{"SmartRectFeature":[{"brushWidth":0,"flashFps":{"drawKeepFrames":0,"stopKeepFrames":0},"index":0,"rgb":16711680,"shape":1,"type":0}]} enter.....
08-30 11:05:57.909 25924 26310 I ThingCameraSDK: ThingCameraBase::SetSmartRectFeatures Port[0] leave(0)...
08-30 11:05:57.910 25924 26310 I ThingCameraSDK: ThingCameraNative setSmartRectFeatures,the handle is :0x6f8a600040
08-30 11:05:57.910 25924 26310 I ThingCameraSDK: ThingCameraBase::SetCameraConfig Port[0] enter
08-30 11:05:57.910 25924 26310 I ThingCameraSDK: ThingCameraBase::SetCameraConfig Port[0] audio capability:3
08-30 11:05:57.912 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] enter...
08-30 11:05:57.912 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364757912,"m":"camera","did":"6ce1f26844bfce86f3zrdp","op":"connect","tid":"no traceId"} ...
08-30 11:05:57.912 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] new link pre connect connectOption:1...
08-30 11:05:57.913 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757440,"v":"3.5.2","p":"rtc_session_create","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"h":0,"lk":99,"rk":0,"c":"kcp"} ...
08-30 11:05:57.913 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757440,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":0,"as":2,"h":1,"e":0,"ex":0,"d":1} ...
08-30 11:05:57.914 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757440,"v":"3.5.2","p":"rtc_session_http_req","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","a":"thing.m.rtc.session.offer_1.0","d":1} ...
08-30 11:05:57.941 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback {"p2p_3_0_cxx_https_request":"thing.m.rtc.log_1.0", "devId":""} here..
08-30 11:05:57.941 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback here.....
08-30 11:05:57.942 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:65538 is_pre:0 state:3 active_state:3 error:0...
08-30 11:05:57.943 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:65539 is_pre:0 state:0 active_state:2 error:0...
08-30 11:05:57.943 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback {"p2p_3_0_cxx_https_request":"thing.m.rtc.session.offer_1.0", "devId":"6ce1f26844bfce86f3zrdp"} here..
08-30 11:05:57.943 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback here.....
08-30 11:05:58.008 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":}..
08-30 11:05:58.009 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","to":"ay1690445086544UqnKu","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","moto_id":"","type":"suspend_resp","trace_id":"","path":"lan"},"msg":{"handle":1,"error":0,"seq":1}}}..
08-30 11:05:58.009 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757536,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":3,"as":0,"h":1,"e":0,"ex":0,"d":10759} ...
08-30 11:05:58.027 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","moto_id":"","path":"mqtt","sessionid":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","to":"ay1690445086544UqnKu","trace_id":"","type":"suspend_resp"},"msg":{"error":0,"handle":1,"seq":1}}}..
08-30 11:05:58.062 25924 26296 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_http_result.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":api:thing.m.rtc.log_1.0 content:{"success":true}}..
08-30 11:05:58.064 25924 26298 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_http_result.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":api:thing.m.rtc.session.offer_1.0 content:{"vedioClarity":4,"auth":"Lj9+0+MkuZXWBKweVSJVwmfLATquSr0eLGGW+4r+1Mc=","supportWebrtcRecord":true,"timeZoneId":"Asia/Shanghai","upgradeRelay":true,"motoId":"signaling14151","p2pId":"","isLowPower":false,"vedioClaritys":[2,4],"supportsWebrtc":true,"password":"adeda472","isCloudP2P":false,"p2pType":4,"p2pPolicy":0,"skill":"{\"v\":2,\"sdk_version\":\"5.6.32\",\"channel_num\":1,\"cloudGW\":1,\"cloudStorage\":1,\"localStorage\":513,\"webrtc\":115,\"p2p\":99,\"upnp\":11,\"video_num\":2,\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":0,\"profileId\":\"\",\"width\":1920,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":0,\"width\":768,\"height\":864}],\"audios\":[{\"codecType\":105,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]}","maxZoomInTimes":0,"audioAttributes":{"callMode":[1,2],"hardwareCapability":[1,2]},"p2pConfig":{"preconnect":true,"tcpRelay
08-30 11:05:58.064 25924 26298 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757590,"v":"3.5.2","p":"rtc_session_http_resp","l":"ay1690445086544UqnKu","a":"thing.m.rtc.session.offer_1.0","c":0,"r":"","e":"{\"vedioClarity\":4,\"auth\":\"Lj9+0+MkuZXWBKweVSJVwmfLATquSr0eLGGW+4r+1Mc=\",\"supportWebrtcRecord\":true,\"timeZoneId\":\"Asia/Shanghai\",\"upgradeRelay\":true,\"motoId\":\"signaling14151\",\"p2pId\":\"\",\"isLowPower\":false,\"vedioClaritys\":[2,4],\"supportsWebrtc\":true,\"password\":\"adeda472\",\"isCloudP2P\":false,\"p2pType\":4,\"p2pPolicy\":0,\"skill\":\"{\\\"v\\\":2,\\\"sdk_version\\\":\\\"5.6.32\\\",\\\"channel_num\\\":1,\\\"cloudGW\\\":1,\\\"cloudStorage\\\":1,\\\"localStorage\\\":513,\\\"webrtc\\\":115,\\\"p2p\\\":99,\\\"upnp\\\":11,\\\"video_num\\\":2,\\\"videos\\\":[{\\\"streamType\\\":2,\\\"codecType\\\":4,\\\"sampleRate\\\":0,\\\"profileId\\\":\\\"\\\",\\\"width\\\":1920,\\\"height\\\":2160},{\\\"streamType\\\":4,\\\"codecType\\\":2,\\\"sampleRate\\\":0,\\\"width\\\":768,\\\"height\\\":864}],\\\"audios\\\":[
08-30 11:05:58.071 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757597,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":1,"as":2,"h":1,"e":0,"ex":0,"d":158} ...
08-30 11:05:58.072 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757599,"v":"3.5.2","p":"rtc_ice_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":0,"d":160,"m":0,"nl":"","nr":""} ...
08-30 11:05:58.073 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnGetDeviceAddress enter..
08-30 11:05:58.063 25924 25924 W Thread-392: type=1400 audit(0.0:162975): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tclass=netlink_route_socket permissive=0 b/155595000 app=com.tuya.smartiot
08-30 11:05:58.074 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:58.074 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"offer","trace_id":"","is_pre":0,"p2p_skill":99,"security_level":3,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 1693364758 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6ce1f26844bfce86f3zrdp1693364757dV3BEFRv\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:Y4BH\r\na=ice-pwd:pbKmh21Dd6U7gnM6Ua4p7J7z\r\na=ice-options:trickle\r\na=aes-key:a000a0b00b00f000000a010006008e80\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1690445086544UqnKu\r\n","preconnect":true,"token":[{"urls":"stun:47.103.32.85:3478"},{"urls":"turn:47.103.29.37:3478","credential":"Cmqp9xxj1gDd1IFfUetWcOaFLog=","ttl":3600,"username":"1693368358:6ce1f26844bfce86f3zrdp"}],"tcp_token":{"urls":["tcp4:1.117.192.37:1443"],"credential":"Pfeu0cbanGP7lVDL
08-30 11:05:58.063 25924 25924 W Thread-392: type=1400 audit(0.0:162976): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tclass=netlink_route_socket permissive=0 b/155595000 app=com.tuya.smartiot
08-30 11:05:58.063 25924 25924 W Thread-393: type=1400 audit(0.0:162977): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tclass=netlink_route_socket permissive=0 b/155595000 app=com.tuya.smartiot
08-30 11:05:58.076 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757603,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1236756961 1 UDP 2130706431 :: 45518 typ host\r\n","d":164} ...
08-30 11:05:58.077 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757603,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:557003559 1 UDP 2130706431 0.0.0.0 45518 typ host\r\n","d":164} ...
08-30 11:05:58.077 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757604,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:94592113 1 UDP 2130706431 :: 45518 typ host\r\n","d":165} ...
08-30 11:05:58.077 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757604,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1336872123 1 UDP 2130706431 :: 45518 typ host\r\n","d":165} ...
08-30 11:05:58.077 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757604,"v":"3.5.2","p":"rtc_ice_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":1,"d":165,"m":0,"nl":"","nr":""} ...
08-30 11:05:58.078 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757604,"v":"3.5.2","p":"rtc_tcp_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":0,"d":165,"tconn":0,"tresp":0,"tcomp":0} ...
08-30 11:05:58.078 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:58.080 25924 26175 I chatty  : uid=10030(com.tuya.smartiot) Thread-448 identical 2 lines
08-30 11:05:58.081 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:58.082 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1236756961 1 UDP 2130706431 :: 45518 typ host\r\n"}}} ...
08-30 11:05:58.091 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:557003559 1 UDP 2130706431 0.0.0.0 45518 typ host\r\n"}}} ...
08-30 11:05:58.096 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:94592113 1 UDP 2130706431 :: 45518 typ host\r\n"}}} ...
08-30 11:05:58.104 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1336872123 1 UDP 2130706431 :: 45518 typ host\r\n"}}} ...
08-30 11:05:58.107 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnGetDeviceAddress enter..
08-30 11:05:58.093 25924 25924 W Thread-406: type=1400 audit(0.0:162978): avc: denied { bind } for scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tclass=netlink_route_socket permissive=0 b/155595000 app=com.tuya.smartiot
08-30 11:05:58.109 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757636,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:10454382 1 UDP 1694498815 49.78.21.79 10261 typ srflx\r\n","d":197} ...
08-30 11:05:58.110 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:58.114 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:10454382 1 UDP 1694498815 49.78.21.79 10261 typ srflx\r\n"}}} ...
08-30 11:05:58.145 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:2 is_pre:1 state:3 active_state:0 error:0...
08-30 11:05:58.145 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:65539 is_pre:0 state:1 active_state:2 error:0...
08-30 11:05:58.183 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757710,"v":"3.5.2","p":"rtc_candidate_local","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1484610910 1 UDP 16777215 47.103.29.37 49332 typ relay\r\n","d":271} ...
08-30 11:05:58.184 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:58.185 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":"a=candidate:1484610910 1 UDP 16777215 47.103.29.37 49332 typ relay\r\n"}}} ...
08-30 11:05:58.186 25924 26175 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughLAN remoteId:6ce1f26844bfce86f3zrdp...
08-30 11:05:58.190 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":}..
08-30 11:05:58.194 25924 26174 I ThingAvLoggerSDK: ThingSmartP2PSDK::SendMessageThroughMQTT msg:{"p2p_3_0_cxx_mqtt_send":{"header":{"from":"ay1690445086544UqnKu","to":"6ce1f26844bfce86f3zrdp","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"mqtt"},"msg":{"candidate":""}}} ...
08-30 11:05:58.203 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":}..
08-30 11:05:58.209 25924 25924 I chatty  : uid=10030(com.tuya.smartiot) identical 2 lines
08-30 11:05:58.210 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":}..
08-30 11:05:58.219 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","to":"ay1690445086544UqnKu","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"answer","trace_id":"","is_pre":0,"p2p_skill":99,"path":"lan"},"msg":{"sdp":"v=0\r\no=- 1693364757 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6ce1f26844bfce86f3zrdp1693364757dV3BEFRv\r\nm=application 9 tuya 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:yCVv\r\na=ice-pwd:Vu4TlYCK6roKvpT3evW9MPft\r\na=ice-options:trickle\r\na=aes-key:a000a0b00b00f000000a010006008e80\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 3\r\na=ssrc:0 cname:6ce1f26844bfce86f3zrdp\r\n","preconnect":true,"token":[{"urls":"stun:47.103.32.85:3478"},{"credential":"Cmqp9xxj1gDd1IFfUetWcOaFLog=","ttl":3600,"urls":"turn:47.103.29.37:3478","username":"1693368358:6ce1f26844bfce86f3zrdp"}],"tcp_token":{"credential":"Pfeu0cbanGP7lVDLCl6dADmbxR8=","domain":"wework-2-
08-30 11:05:58.220 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757746,"v":"3.5.2","p":"rtc_session_answer","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":307} ...
08-30 11:05:58.225 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":}..
08-30 11:05:58.226 25924 25924 I chatty  : uid=10030(com.tuya.smartiot) identical 1 line
08-30 11:05:58.227 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":}..
08-30 11:05:58.227 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","to":"ay1690445086544UqnKu","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"lan"},"msg":{"candidate":"a=candidate:31670248 1 UDP 2130706431 192.168.243.224 54422 typ host\r\n"}}}..
08-30 11:05:58.227 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757754,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:31670248 1 UDP 2130706431 192.168.243.224 54422 typ host\r\n","d":315} ...
08-30 11:05:58.269 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","is_pre":0,"moto_id":"","p2p_skill":99,"path":"mqtt","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","to":"ay1690445086544UqnKu","trace_id":"","type":"answer"},"msg":{"preconnect":true,"sdp":"v=0\r\no=- 1693364757 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6ce1f26844bfce86f3zrdp1693364757dV3BEFRv\r\nm=application 9 tuya 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:yCVv\r\na=ice-pwd:Vu4TlYCK6roKvpT3evW9MPft\r\na=ice-options:trickle\r\na=aes-key:a000a0b00b00f000000a010006008e80\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 3\r\na=ssrc:0 cname:6ce1f26844bfce86f3zrdp\r\n","tcp_token":{"credential":"Pfeu0cbanGP7lVDLCl6dADmbxR8=","domain":"wework-2-cn.stream.iot-11.com","sessionId":"6ce1f26844bfce86f3zrdp1693400758ts2MJtj6","urls":["tcp4:1.117.192.37:1443"],"username":"1693400758:6ce1f26844bfce86f3zrdp"},"token":[{"urls":"st
08-30 11:05:58.269 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","to":"ay1690445086544UqnKu","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"lan"},"msg":{"candidate":"a=candidate:437976453 1 UDP 1694498815 49.78.21.79 10263 typ srflx\r\n"}}}..
08-30 11:05:58.270 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757796,"v":"3.5.2","p":"rtc_session_answer","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":357} ...
08-30 11:05:58.270 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757797,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:437976453 1 UDP 1694498815 49.78.21.79 10263 typ srflx\r\n","d":358} ...
08-30 11:05:58.279 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","moto_id":"","path":"mqtt","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","to":"ay1690445086544UqnKu","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:31670248 1 UDP 2130706431 192.168.243.224 54422 typ host\r\n"}}}..
08-30 11:05:58.279 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757806,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:31670248 1 UDP 2130706431 192.168.243.224 54422 typ host\r\n","d":367} ...
08-30 11:05:58.298 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757825,"v":"3.5.2","p":"rtc_ice_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":2,"d":386,"m":1,"nl":"192.168.243.62:45518","nr":"192.168.243.224:54422"} ...
08-30 11:05:58.301 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757828,"v":"3.5.2","p":"rtc_session_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":3,"as":2,"h":1,"e":0,"ex":0,"d":389} ...
08-30 11:05:58.302 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757828,"v":"3.5.2","p":"rtc_session_add","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","ca":"connect_v2","st":"new_session","e":0,"ex":0,"d":389} ...
08-30 11:05:58.303 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757829,"v":"3.5.2","p":"rtc_connect_result","tid":"","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","rd":"6ce1f26844bfce86f3zrdp","ca":"connect_v3","ex":0,"d":390} ...
08-30 11:05:58.303 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] m_P2pStepStatus:2
08-30 11:05:58.303 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364758303,"m":"camera","did":"6ce1f26844bfce86f3zrdp","op":"connect successed.","dt":391 ,"tid":"no traceId"} ...
08-30 11:05:58.305 25924 26310 I ThingCameraSDK: ThingCameraBase::Connect Port[0] return:65539 p2pType:4 connect time cost:391 leave(0)...
08-30 11:05:58.305 25924 26310 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 0, high_cmd = 10, low_cmd = 0, session = 65539, thing_p2p_rtc_send_data=24[] send...
08-30 11:05:58.305 25924 26310 I ThingCameraSDK: ThingCameraSimple::GetAudioParams Port[0] channel:0 enter....
08-30 11:05:58.305 25924 26310 I ThingCameraSDK: ThingCameraSimple::GetAudioParams Port[0] requestId:5 cmd high:2 low:0 ...
08-30 11:05:58.305 25924 26310 I ThingCameraSDK: ThingCameraSimple::GetAudioParams Port[0] leave(0)...
08-30 11:05:58.308 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","moto_id":"","path":"mqtt","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","to":"ay1690445086544UqnKu","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:437976453 1 UDP 1694498815 49.78.21.79 10263 typ srflx\r\n"}}}..
08-30 11:05:58.309 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757836,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:437976453 1 UDP 1694498815 49.78.21.79 10263 typ srflx\r\n","d":397} ...
08-30 11:05:58.314 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","to":"ay1690445086544UqnKu","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"lan"},"msg":{"candidate":""}}}..
08-30 11:05:58.315 25924 26310 I ThingCameraSDK: ThingCameraNative setDeviceFeatures,the handle is :0x6f8a600040
08-30 11:05:58.315 25924 26310 I ThingCameraSDK: ThingCameraBase::SetDeviceFeatures Port[0] features:{"DecPostProcess":{"mirror":0,"rotation":0}} enter...
08-30 11:05:58.315 25924 26310 I ThingCameraSDK: ThingCameraBase::SetDeviceFeatures Port[0] leave(-1)...
08-30 11:05:58.315 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757842,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"","d":403} ...
08-30 11:05:58.318 25924 26587 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 5, high_cmd = 2, low_cmd = 0, session = 65539, thing_p2p_rtc_send_data=24[] send...
08-30 11:05:58.318 25924 26310 I ThingCameraSDK: ThingCameraNative setSmartRectFeatures,the handle is :0x6f8a600040
08-30 11:05:58.318 25924 26310 I ThingCameraSDK: ThingCameraBase::SetSmartRectFeatures Port[0] channel:0 features:{"SmartRectFeature":[{"brushWidth":0,"flashFps":{"drawKeepFrames":0,"stopKeepFrames":0},"index":0,"rgb":16711680,"shape":1,"type":0}]} enter...
08-30 11:05:58.318 25924 26310 I ThingCameraSDK: ThingCameraAttributes::setSmartRectFeatures feature:{"SmartRectFeature":[{"brushWidth":0,"flashFps":{"drawKeepFrames":0,"stopKeepFrames":0},"index":0,"rgb":16711680,"shape":1,"type":0}]} enter.....
08-30 11:05:58.318 25924 26310 I ThingCameraSDK: ThingCameraBase::SetSmartRectFeatures Port[0] leave(0)...
08-30 11:05:58.320 25924 26310 I ThingCameraSDK: ThingCameraSimple::StartPreview Port[0] mode:4 v-fmt:1 a-fmt:1 enter...
08-30 11:05:58.320 25924 26310 I ThingCameraSDK: ThingPlayTask::ThingPlayTask Port[0] this:0x6f6d59a010
08-30 11:05:58.320 25924 26310 I ThingCameraSDK: ThingAVModule::SetMute Port[0] mute:1
08-30 11:05:58.322 25924 26310 I ThingCameraSDK: ThingAVQualityMonitor::Start Start
08-30 11:05:58.322 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchRunner Port[0] m_bKeepRealTime:1
08-30 11:05:58.323 25924 26310 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364758322,"m":"camera","did":"6ce1f26844bfce86f3zrdp","op":"startpreview","mode":4 ,"tid":"no traceId"} ...
08-30 11:05:58.323 25924 26310 I ThingCameraSDK: ThingCameraSimple::StartPreview Port[0] mode:4 cmd high:9 low:0 .
08-30 11:05:58.323 25924 26310 I ThingCameraSDK: ThingCameraSimple::StartPreview Port[0] mode:4 requestId:65542 cmd high:6 low:0 open video.
08-30 11:05:58.323 25924 26310 I ThingCameraSDK: ThingCameraSimple::StartPreview Port[0] mode:4 requestId:65544 cmd high:6 low:4 operateion:4...
08-30 11:05:58.323 25924 26310 I ThingCameraSDK: ThingCameraSimple::StartPreview Port[0] leave(0)...
08-30 11:05:58.323 25924 26587 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 65543, high_cmd = 9, low_cmd = 0, session = 65539, thing_p2p_rtc_send_data=28[] send...
08-30 11:05:58.323 25924 26594 I ThingCameraSDK: ThingAVCacheManager::AudioDataDispatchRunner Port[0] this:0x6f6d59a3f0
08-30 11:05:58.324 25924 26596 I ThingCameraSDK: ThingAVSyncronizer::AudioDispatchRunner Port[0] m_bKeepRealTime:1
08-30 11:05:58.325 25924 26596 I ThingCameraSDK: ThingAVSyncronizer::AudioDispatchInRealTime Port[0] m_bSyncNeedExit:0 thread
08-30 11:05:58.325 25924 26587 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 65542, high_cmd = 6, low_cmd = 0, session = 65539, thing_p2p_rtc_send_data=28[] send...
08-30 11:05:58.326 25924 26587 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 65544, high_cmd = 6, low_cmd = 4, session = 65539, thing_p2p_rtc_send_data=28[] send...
08-30 11:05:58.326 25924 26310 I ThingCameraSDK: ThingCameraBase::EnableIVA Port[0] iva:1 enter...
08-30 11:05:58.326 25924 26310 I ThingCameraSDK: ThingCameraBase::EnableIVA Port[0] leave...
08-30 11:05:58.326 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] m_bSyncNeedExit:0 thread
08-30 11:05:58.327 25924 26595 I ThingCameraSDK: ThingAVCacheManager::VideoDataDispatchRunner Port[0] this:0x6f6d59a3f0
08-30 11:05:58.344 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","to":"ay1690445086544UqnKu","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","moto_id":"","type":"candidate","trace_id":"","path":"lan"},"msg":{"candidate":"a=candidate:1903320632 1 UDP 16777215 47.103.29.37 52912 typ relay\r\n"}}}..
08-30 11:05:58.344 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757871,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1903320632 1 UDP 16777215 47.103.29.37 52912 typ relay\r\n","d":432} ...
08-30 11:05:58.347 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::OnSessionStateChanged remoteID:6ce1f26844bfce86f3zrdp handle:65539 is_pre:0 state:3 active_state:2 error:0...
08-30 11:05:58.348 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback {"p2p_3_0_cxx_https_request":"thing.m.rtc.log_1.0", "devId":""} here..
08-30 11:05:58.348 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback here.....
08-30 11:05:58.381 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","moto_id":"","path":"mqtt","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","to":"ay1690445086544UqnKu","trace_id":"","type":"candidate"},"msg":{"candidate":""}}}..
08-30 11:05:58.381 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757908,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"","d":469} ...
08-30 11:05:58.384 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757910,"v":"3.5.2","p":"rtc_tcp_state","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"a":1,"d":471,"tconn":1693364757647,"tresp":1693364757712,"tcomp":1693364757910} ...
08-30 11:05:58.387 25924 26588 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] version major:1 minor:2 ....
08-30 11:05:58.388 25924 26588 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:0 high_cmd:10 low_cmd:0 received...
08-30 11:05:58.388 25924 26588 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:0 highCmd:10 lowCmd:0
08-30 11:05:58.388 25924 26588 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:5 high_cmd:2 low_cmd:0 received...
08-30 11:05:58.388 25924 26588 I ThingCameraSDK: ThingNetRequestCommand::onResponse Port[0] this:0x6f8cdc2a10 nRequestId:5...
08-30 11:05:58.389 25924 26588 I ThingCameraSDK: ThingAudioCallBack::onResponse Port[0] requestId:5 high cmd:2 low cmd:0
08-30 11:05:58.389 25924 26588 I ThingCameraSDK: ThingAudioCallBack::onGetAudioParams Port[0] response. sample_rate:8000 codecType:133 ..
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:5 highCmd:2 lowCmd:0
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] audioTalk parameters type:133 simpleRate:8000
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:65543 high_cmd:9 low_cmd:0 received...
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:65543 highCmd:9 lowCmd:0
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:65542 high_cmd:6 low_cmd:0 received...
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingNetRequestCommand::onResponse Port[0] this:0x702d096710 nRequestId:65542...
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingPreviewCallBack::onResponse Port[1852401748] response requestId:65542 highcmd:6 lowcmd:0
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingPreviewCallBack::onResponse Port[1852401748] highCmd:6 lowCmd:0 result:1...
08-30 11:05:58.390 25924 26588 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:65542 highCmd:6 lowCmd:0
08-30 11:05:58.413 25924 25924 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_signaling.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":{"header":{"from":"6ce1f26844bfce86f3zrdp","moto_id":"","path":"mqtt","sessionid":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","to":"ay1690445086544UqnKu","trace_id":"","type":"candidate"},"msg":{"candidate":"a=candidate:1903320632 1 UDP 16777215 47.103.29.37 52912 typ relay\r\n"}}}..
08-30 11:05:58.415 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364757941,"v":"3.5.2","p":"rtc_candidate_remote","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"c":"a=candidate:1903320632 1 UDP 16777215 47.103.29.37 52912 typ relay\r\n","d":502} ...
08-30 11:05:58.430 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364756743 ,count:0
08-30 11:05:58.430 25924 26592 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364758430,"m":"camera","did":"6ce1f26844bfce86f3zrdp","status":"first rtp packet recved.","tid":"no traceId"} ...
08-30 11:05:58.432 25924 26588 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:65544 high_cmd:6 low_cmd:4 received...
08-30 11:05:58.432 25924 26588 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:65544 highCmd:6 lowCmd:4
08-30 11:05:58.451 25924 26531 W AudioManager: Use of stream types is deprecated for operations other than volume control
08-30 11:05:58.451 25924 26531 W AudioManager: See the documentation of requestAudioFocus() for what to use instead with android.media.AudioAttributes to qualify your playback use case
08-30 11:05:58.454  1517  5210 I MediaFocusControl: requestAudioFocus() from uid/pid 10030/25924 clientId=android.media.AudioManager@117a91acom.thingclips.smart.ipc.camera.rnpanel.cameramanager.TRCTCameraManager$2@9c944c1 callingPack=com.tuya.smartiot req=1 flags=0x0 sdk=33
08-30 11:05:58.476 25924 26296 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_http_result.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":api:thing.m.rtc.log_1.0 content:{"success":true}}..
08-30 11:05:58.547 25924 26531 W AudioManager: Use of stream types is deprecated for operations other than volume control
08-30 11:05:58.547 25924 26531 W AudioManager: See the documentation of requestAudioFocus() for what to use instead with android.media.AudioAttributes to qualify your playback use case
08-30 11:05:58.547  1517  5210 I MediaFocusControl: requestAudioFocus() from uid/pid 10030/25924 clientId=android.media.AudioManager@117a91acom.thingclips.smart.ipc.camera.rnpanel.cameramanager.TRCTCameraManager$2@9c944c1 callingPack=com.tuya.smartiot req=1 flags=0x0 sdk=33
08-30 11:05:58.654 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:05:58.655 25924 26592 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364758655,"m":"camera","did":"","status":"first full frame recved.","tid":"no traceId"} ...
08-30 11:05:58.655 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364758655 TS:1693364756743 diff: 335 fragment:1 cache: 1 size:1920x2160 codec:20 len:150881 V-Count:0 IFrame:1....
08-30 11:05:58.655 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364758655 TS:1693364757410 diff:   0 fragment:1 cache:11 size:1920x2160 codec:20 len:561 V-Count:10 IFrame:0....
08-30 11:05:58.655 25924 26595 I ThingCameraSDK: ThingAVModule::SetupVideoParams Port[0] frame_rate:15 width:1920 height:2160
08-30 11:05:58.655 25924 26595 I ThingCameraSDK: ThingAVModule::OnCacheVideoPacketRecved Port[0] the video parameters changed, video decoder will reset!!!
08-30 11:05:58.656 25924 26595 I ThingVideoDecodeSDK: [VideoCodecSDK Version:1.3.5]
08-30 11:05:58.658 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecDecoder::TravellMobileProductInfo travell the mobile product information(model = PCKM00,
08-30 11:05:58.658 25924 26595 I ThingVideoDecodeSDK: name = PCKM00, brand = OPPO,device = OP4A57, hardware = qcom, version = 11, sdkVersion = 30)
08-30 11:05:58.661 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::InitH265Decoder w:1920 h:2160
08-30 11:05:58.664 25924 26595 E Parcel  : Reading a NULL string not supported here.
08-30 11:05:58.665 25924 26595 D ACodec  : ACodec() ro.oplus.audio.effect.type = dolby ro.oplus.audio.dolby.type = v351
08-30 11:05:58.665 25924 26595 I ACodec  : new ACodec()
08-30 11:05:58.665 25924 26595 D ACodec  : Now uninitialized
08-30 11:05:58.665 25924 26595 D OplusACodec: OplusACodec [131]:
08-30 11:05:58.665 25924 26595 D OplusACodec: getBufferChannel: New
08-30 11:05:58.667 25924 26604 I OMXClient: IOmx service obtained
08-30 11:05:58.667 25924 26604 I m.tuya.smartio: OPPOLoadFrame::CreateSpace -- create new namespace oppoex
08-30 11:05:58.668 25924 26604 I m.tuya.smartio: OPPOLoadFrame::CreateSpace -- executable_path = /system/bin/app_process64
08-30 11:05:58.668 25924 26604 I m.tuya.smartio: OPPOLoadFrame::GetCurrentSection -- ld_config_file_path = /linkerconfig/ld.config.txt
08-30 11:05:58.669 25924 26604 I m.tuya.smartio: OPPOLoadFrame::CreateSpace -- section = system
08-30 11:05:58.669 25924 26604 I m.tuya.smartio: OPPOLoadFrame::ReadLink --  read /system/etc/public.libraries.txt success!
08-30 11:05:58.670 25924 26604 I m.tuya.smartio: OPPOLoadFrame::ReadLink --  read /apex/com.android.vndk.v30/etc/llndk.libraries.30.txt success!
08-30 11:05:58.670 25924 26604 I m.tuya.smartio: OPPOLoadFrame::ReadLink --  read /system_ext/oppoex/public.libraries-oppoex.txt success!
08-30 11:05:58.671 25924 26604 I m.tuya.smartio: OPPOLoadFrame::ReadLink --  read /apex/com.android.vndk.v30/etc/vndksp.libraries.30.txt success!
08-30 11:05:58.671 25924 26604 I m.tuya.smartio: OPPOLoadFrame::ReadLink --  read /vendor/etc/public.libraries.txt success!
08-30 11:05:58.672 25924 26604 I m.tuya.smartio: OPPOLoadFrame::CreateSpace -- paths = /my_company/lib64/oppoex:/my_carrier/lib64/oppoex:/my_region/lib64/oppoex:/my_product/lib64/oppoex:/system_ext/lib64/oppoex:/system/lib64/oppoex
08-30 11:05:58.675 25924 26604 I m.tuya.smartio: OPPOLoadFrame::CreateSpace -- link default : libandroid.so:libaaudio.so:libamidi.so:libbinder_ndk.so:libc.so:libcamera2ndk.so:libdl.so:libEGL.so:libGLESv1_CM.so:libGLESv2.so:libGLESv3.so:libicui18n.so:libicuuc.so:libjnigraphics.so:liblog.so:libmediandk.so:libm.so:libnativewindow.so:libneuralnetworks.so:libOpenMAXAL.so:libOpenSLES.so:libRS.so:libstdc++.so:libsync.so:libvulkan.so:libwebviewchromium_plat_support.so:libz.so:libEGL.so:libGLESv1_CM.so:libGLESv2.so:libGLESv3.so:libRS.so:libandroid_net.so:libbinder_ndk.so:libc.so:libcgrouprc.so:libclang_rt.asan-aarch64-android.so:libclang_rt.asan-arm-android.so:libdl.so:libft2.so:liblog.so:libm.so:libmediandk.so:libnativewindow.so:libneuralnetworks.so:libselinux.so:libsync.so:libvndksupport.so:libvulkan.so:libbinder.so
08-30 11:05:58.678 25924 26604 I m.tuya.smartio: OPPOLoadFrame::CreateSpace -- link sphal : libqti-perfd-client.so:libadsprpc.so:libcdsprpc.so:libsdsprpc.so:libfastcvopt.so:liblistensoundmodel2.so:libOpenCL.so:libnpu.so:libhta_hexagon_runtime.so:libAlgoProcess.so:libancbase_rt_bokeh.so:libAncHumBokeh.so:libsnpe_loader.so:libstblur_api.so:libstdc++.so:libAncHumVideoBase.so:libmidasserviceintf.so:libarcsoft_scbokeh_video.so
08-30 11:05:58.678 25924 26604 I m.tuya.smartio: OPPOLoadFrame::CreateSpace -- link vndk : android.hardware.common-V1-ndk_platform.so:android.hardware.graphics.common-V1-ndk_platform.so:android.hardware.graphics.common@1.0.so:android.hardware.graphics.common@1.1.so:android.hardware.graphics.common@1.2.so:android.hardware.graphics.mapper@2.0.so:android.hardware.graphics.mapper@2.1.so:android.hardware.graphics.mapper@3.0.so:android.hardware.graphics.mapper@4.0.so:android.hardware.renderscript@1.0.so:android.hidl.memory.token@1.0.so:android.hidl.memory@1.0-impl.so:android.hidl.memory@1.0.so:android.hidl.safe_union@1.0.so:libRSCpuRef.so:libRSDriver.so:libRS_internal.so:libbacktrace.so:libbase.so:libbcinfo.so:libblas.so:libc++.so:libcompiler_rt.so:libcutils.so:libgralloctypes.so:libhardware.so:libhidlbase.so:libhidlmemory.so:libion.so:libjsoncpp.so:liblzma.so:libprocessgroup.so:libunwindstack.so:libutils.so:libutilscallstack.so:libz.so
08-30 11:05:58.679 25924 26604 W m.tuya.smartio: OPPOLoadFrame::init --  failed: dlopen failed: library "libOplusDualHeadPhoneEx.so" not found
08-30 11:05:58.679 25924 26604 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx exp == NULL return NULL.
08-30 11:05:58.679 25924 26604 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:58.680   915   975 D audio_hw_primary: adev_set_parameters: enter: HQV_wl_pid=25924
08-30 11:05:58.680   915   975 D audio_hw_hfp: hfp_set_parameters: enter
08-30 11:05:58.680   915   975 D audio_hw_primary: adev_set_parameters: set dual headphone enable: 0x0
08-30 11:05:58.680   915   975 D audio_hw_extn: audio_extn_fm_set_parameters: Enter
08-30 11:05:58.680   915   975 D audio_hw_primary: adev_set_parameters: exit with code(0)
08-30 11:05:58.682  1406 19786 I OMXMaster: makeComponentInstance(OMX.qcom.video.decoder.hevc) in android.hardwar process
08-30 11:05:58.684  1406 19786 D PlatformConfig: getInstance: Enter
08-30 11:05:58.684  1406 19786 D PlatformConfig: getInt32 Config name: vidc_dec_log_in value: 0
08-30 11:05:58.684  1406 19786 D PlatformConfig: getInt32 Config name: vidc_dec_log_out value: 0
08-30 11:05:58.684  1406 19786 D PlatformConfig: getInt32 Config name: vidc_dec_sec_prefetch_size_internal value: 31457280
08-30 11:05:58.684  1406 19786 D PlatformConfig: getInt32 Config name: vidc_dec_sec_prefetch_size_output value: 3276800
08-30 11:05:58.684  1406 19786 D PlatformConfig: getInt32 Config name: vidc_dec_arb_mode_override value: 7
08-30 11:05:58.684  1406 19786 D PlatformConfig: getInt32: Returning default
08-30 11:05:58.684  1406 19786 I OMX-VDEC-1080P: component_init: OMX.qcom.video.decoder.hevc : fd=7
08-30 11:05:58.684  1406 19786 E OMX-VDEC-1080P: Unsupported output color format for c2d (2141391876)
08-30 11:05:58.684  1406 19786 E OMX-VDEC-1080P: Setting color format failed
08-30 11:05:58.689  1406 19786 D PlatformConfig: getInstance: Enter
08-30 11:05:58.689  1406 19786 D PlatformConfig: getInt32: Returning default
08-30 11:05:58.689  1406 19786 I OMX-VDEC-1080P: omx_vdec::component_init() success : fd=7
08-30 11:05:58.689 25924 26604 I ACodec  : Successfully allocate component [OMX.qcom.video.decoder.hevc]
08-30 11:05:58.689 25924 26604 D ACodec  : AllocateComponent OMX.qcom.video.decoder.hevc success
08-30 11:05:58.690 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Loaded
08-30 11:05:58.696 25924 26604 D m.tuya.smartio: OplusTpCompLogExProxy::getOplusTpCompLogEx -- exp != NULL
08-30 11:05:58.696 25924 26604 D OplusACodec: [configureCodec:L947] OplusFeedbackInfo  mFeedbackID:481238327296
08-30 11:05:58.696 25924 26604 D IAtlas  : IAtlas::init CallingPid 25924
08-30 11:05:58.697 25924 26604 D IAtlas  : IAtlas::init this 0x7013f14430
08-30 11:05:58.697  1378  1429 D AtlasService: clientsCount 1
08-30 11:05:58.697  1378  1429 D AtlasService: notify 1025 to client
08-30 11:05:58.698 25924 26604 I BpBinder: onLastStrongRef automatically unlinking death recipients: <uncached descriptor>
08-30 11:05:58.698  1406 19786 E OMX-VDEC-1080P: Extension: OMX.google.android.index.storeANWBufferInMetadata not implemented
08-30 11:05:58.698  1406 19786 E OMX-VDEC-1080P: Extension: OMX.google.android.index.configureVideoTunnelMode not implemented
08-30 11:05:58.698  1406 19786 E OMX-VDEC-1080P: Extension: OMX.google.android.index.useAndroidNativeBuffer is supported
08-30 11:05:58.698  1406 19786 E OMX-VDEC-1080P: get_parameter: unknown param 7f000046
08-30 11:05:58.698  1406 19786 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.hevc, ??(0x7f000046)) ERROR: UnsupportedIndex(0x8000101a)
08-30 11:05:58.699 25924 26604 I ACodec  : configureCodec() mime = video/hevc
08-30 11:05:58.699 25924 26604 D OplusUtils: ACodec getComponentRole [92]: mime:video/hevc
08-30 11:05:58.699 25924 26604 I ExtendedACodec: setupVideoDecoder()
08-30 11:05:58.699 25924 26604 E OplusACodec: [GetVideoCodingTypeFromMime:L726] mime:video/hevc
08-30 11:05:58.702  1406  6934 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.hevc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:05:58.702  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.693  1406  1406 W HwBinder:1406_D: type=1400 audit(0.0:162979): avc: denied { read } for name="adreno_config.txt" dev="sda10" ino=4849726 scontext=u:r:mediacodec:s0 tcontext=u:object_r:gpudump_config_file:s0 tclass=file permissive=0
08-30 11:05:58.704  1406 19786 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.705  1406 19786 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.707 25924 26604 I ExtendedACodec: Decoder will be in frame by frame mode
08-30 11:05:58.710 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] input format is AMessage(what = 0x00000000) = {
08-30 11:05:58.710 25924 26604 D ACodec  :   int32_t adaptive-playback = 0
08-30 11:05:58.710 25924 26604 D ACodec  :   int32_t roi-on = 0
08-30 11:05:58.710 25924 26604 D ACodec  :   string mime = "video/hevc"
08-30 11:05:58.710 25924 26604 D ACodec  :   int32_t width = 1920
08-30 11:05:58.710 25924 26604 D ACodec  :   int32_t height = 2160
08-30 11:05:58.710 25924 26604 D ACodec  : }
08-30 11:05:58.712  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.712  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.712  1406  6934 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.hevc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:05:58.714 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] output format is AMessage(what = 0x00000000) = {
08-30 11:05:58.714 25924 26604 D ACodec  :   int32_t roi-on = 0
08-30 11:05:58.714 25924 26604 D ACodec  :   string mime = "video/raw"
08-30 11:05:58.714 25924 26604 D ACodec  :   int32_t stride = 1920
08-30 11:05:58.714 25924 26604 D ACodec  :   int32_t slice-height = 2160
08-30 11:05:58.714 25924 26604 D ACodec  :   int32_t color-format = 21
08-30 11:05:58.714 25924 26604 D ACodec  :   Buffer *image-data = 0x6ffcf15ec0
08-30 11:05:58.714 25924 26604 D ACodec  :   Rect crop(0, 0, 1919, 2159)
08-30 11:05:58.714 25924 26604 D ACodec  :   Buffer hdr-static-info = {
08-30 11:05:58.714 25924 26604 D ACodec  :     00000000:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
08-30 11:05:58.714 25924 26604 D ACodec  :     00000010:  00 00 00 00 00 00 00 00  00                       .........
08-30 11:05:58.714 25924 26604 D ACodec  :   }
08-30 11:05:58.714 25924 26604 D ACodec  :   int32_t width = 1920
08-30 11:05:58.714 25924 26604 D ACodec  :   int32_t height = 2160
08-30 11:05:58.715 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Loaded->Idle
08-30 11:05:58.716 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Allocating 6 buffers of size 8847360 (from 8847360 using PresetByteBuffer) on input port
08-30 11:05:58.729  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.729 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Allocating 14 buffers of size 6221824 (from 6221824 using PresetByteBuffer) on output port
08-30 11:05:58.792  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.793  1373  3005 W ResourceManagerService: Ignoring request to add new resource entry with value <= 0
08-30 11:05:58.793 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Idle->Executing
08-30 11:05:58.795 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet decoder initialize failed retCode:0
08-30 11:05:58.795 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Executing
08-30 11:05:58.799 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364758799 TS:1693364756743 cache buffer:0 w:1920 h:2160  count:0 .....
08-30 11:05:58.825  1406 26606 E OMX_COMMON:  Invalid key : -22 Cannot find key in map
08-30 11:05:58.843 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364758842 TS:1693364758079 diff:  30 fragment:1 cache:15 size:1920x2160 codec:20 len:2300 V-Count:20 IFrame:0....
08-30 11:05:58.844  1406 26606 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.845  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.845  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.846  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:05:58.846  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:58.846  1406  7010 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.hevc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:05:58.847 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] output format is AMessage(what = 0x00000000) = {
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t roi-on = 0
08-30 11:05:58.847 25924 26604 D ACodec  :   string mime = "video/raw"
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t stride = 1920
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t slice-height = 2160
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t color-format = 21
08-30 11:05:58.847 25924 26604 D ACodec  :   Buffer *image-data = 0x6ffcfef9c0
08-30 11:05:58.847 25924 26604 D ACodec  :   Rect crop(0, 0, 1919, 2159)
08-30 11:05:58.847 25924 26604 D ACodec  :   Buffer hdr-static-info = {
08-30 11:05:58.847 25924 26604 D ACodec  :     00000000:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
08-30 11:05:58.847 25924 26604 D ACodec  :     00000010:  00 00 00 00 00 00 00 00  00                       .........
08-30 11:05:58.847 25924 26604 D ACodec  :   }
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t width = 1920
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t height = 2160
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t color-range = 1
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t color-standard = 1
08-30 11:05:58.847 25924 26604 D ACodec  :   int32_t color-transfer = 3
08-30 11:05:58.856  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:58.856  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:58.863 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364758863 cache len:6 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:0....
08-30 11:05:58.864 25924 26610 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364758863,"m":"camera","did":"6ce1f26844bfce86f3zrdp","status":"first frame decoded.","tid":"no traceId"} ...
08-30 11:05:58.864 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] no sei exists!
08-30 11:05:58.867  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:58.868  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:58.872  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 55ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653816 wlan0TxPtk=943163 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:58.878 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364758878 TS:1693364756743 width:1920 height:2160 size:1 count:0.
08-30 11:05:58.878 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364758878 TS:1693364756743 interTimems:0 size:1 cache:0 speed:1.000000 count:0 ....
08-30 11:05:58.878 25924 26597 I ThingCameraSDK: ThingPreviewCallBack::onFirstFrameArrived Port[1852401748] width:1920 height:2160..
08-30 11:05:58.878  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:58.878  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:58.879  1406 19786 E OMX-VDEC-1080P: Extension: OMX.QTI.index.config.video.getdsmode not implemented
08-30 11:05:58.882 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756351,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:58.882 25924 26610 I ThingCameraSDK: VideoConvert::CreateFrame w:1920 h:2160 type:1...
08-30 11:05:58.882  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:05:58.882  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=71,badLossCount=0,txLoss=0,mLinkDetectTimes= 601,mIndex =1
08-30 11:05:58.883  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 55, 0, 0, 0, 0, 676, 56, 0, 0, 0, 0, 676, 56, 0, 0, 0, 0, 676, 56, 0, 0, 0, 0, 676, 56, 0, 0, 0, 0]
08-30 11:05:58.883  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:05:58.883  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:05:58.883  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:05:58.884  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:05:58.884  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-38,mIndex =1,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12574547652
08-30 11:05:58.884  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:05:58.884  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:05:58.884  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:05:58.884  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:05:58.884  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:05:58.884  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:05:58.884  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:05:58.884 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364756743 ts:1693364756 progress:-1 count:0...
08-30 11:05:58.885 25924 26597 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364758885,"m":"camera","did":"6ce1f26844bfce86f3zrdp","status":"first frame renderered.","tid":"no traceId"} ...
08-30 11:05:58.889  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:58.889  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:58.903  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:58.906  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:58.929  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:58.968 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364758965 TS:1693364758430 diff: 645 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:0
08-30 11:05:58.969 25924 26591 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadAudioStream Port[0] audio rtp package recved ,count:0
08-30 11:05:58.971 25924 26594 I ThingCameraSDK: ThingAVModule::SetupAudioParams Port[0] sampleRate:8000 channel:2
08-30 11:05:58.973 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364758973 TS:1693364757410 cache buffer:8 w:1920 h:2160  count:10 .....
08-30 11:05:58.973 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364758545 ,count:200
08-30 11:05:58.974 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364758974 TS:1693364758744 diff:   0 fragment:1 cache:21 size:1920x2160 codec:20 len:1180 V-Count:30 IFrame:0....
08-30 11:05:58.981  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:58.983 25924 26597 I ThingCameraSDK: ThingCameraBase::Snapshot Port[0] path:/data/user/0/com.tuya.smartiot/cache/Camera/Cover/6ce1f26844bfce86f3zrdp/thing_camera.jpg rotate:0 enter...
08-30 11:05:58.984 25924 26597 I ThingCameraSDK: ThingImageUtils::Yuv2JpegToPath rotate:0 enter...
08-30 11:05:58.989  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:58.989  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:58.996  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:58.996  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.001 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364759001 TS:1693364758846 diff:   0 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:10
08-30 11:05:59.006  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.006  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.013  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.014  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.022 26611 26611 F crashpad: dlopen: dlopen failed: library "libandroidicu.so" not found: needed by /system/lib64/libharfbuzz_ng.so in namespace (default)
08-30 11:05:59.024 25924 26531 I ThingCameraSDK: ThingCameraBase::SetMute Port[0] mute:1 enter...
08-30 11:05:59.024 25924 26531 I ThingCameraSDK: ThingAVModule::SetMute Port[0] mute:1
08-30 11:05:59.024 25924 26531 I ThingCameraSDK: ThingCameraBase::stopAudioPlayback Port[0] enter...
08-30 11:05:59.024 25924 26531 I ThingAudioEngineSDK: ThingAudioControllerImpl::StopPlayBack enter this:0x6faa4d6f10 play status:0
08-30 11:05:59.024 25924 26531 I ThingCameraSDK: ThingCameraBase::stopAudioPlayback Port[0] leave(-1)...
08-30 11:05:59.024 25924 26531 I ThingCameraSDK: ThingCameraBase::SetMute Port[0] leave(0)...
08-30 11:05:59.025 25924 26531 D AudioManager: setMode mode=0 from com.tuya.smartiot
08-30 11:05:59.025  1517  5208 I AS.AudioService: setMode(mode = 0, callingPackage = com.tuya.smartiot, Process ID: 25924
08-30 11:05:59.026  1517  5208 D AS.AudioService: +notifyAtlasServiceModesUpdate onlyRead :true
08-30 11:05:59.026  1517  5208 D AS.AudioService: modekey = allmodes=
08-30 11:05:59.026  1517  5208 D AS.AudioService: -notifyAtlasServiceModesUpdate
08-30 11:05:59.031  4254  4320 D OppoAtlasAudioState: getActiveAudioMusic ret = false
08-30 11:05:59.032 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756413,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.032  1517  5208 D AS.AudioService: ringVolumeDefault :0
08-30 11:05:59.032   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.034  4254  4320 D AudioManager: getStreamVolume packageName=com.oppo.atlas, index=0, streamType=3
08-30 11:05:59.034  1517  5086 D AS.AudioService: getParameters() keyValuePairs:OPLUS_AUDIO_GET_DEVICE_FORSTREAM:3
08-30 11:05:59.034  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.035   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.036   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.036  4254  4320 D OppoAtlasAudioState: isSpeakerMute() device: 2 ,index:0,ST:3
08-30 11:05:59.036  4254  4320 D OppoAtlasAudioState: checkAndSetPaState(state:4,mute:true), hasMusic:false,mode:0 ,mIsPlaybackRecord:false
08-30 11:05:59.037   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.041   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.041   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.042   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.042   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.043   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.045  1517  2527 I OplusWifiSarManager: Received action: android.media.ACTION_AUDIO_DEVICE_ROUTE_CHANGED
08-30 11:05:59.045   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.045  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.046  1371 18628 D AudioAnalytics: gc(1700, 2000): log size:1700 item map size:29, item map items:1700
08-30 11:05:59.047   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.048   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.049 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756484,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.055  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.056   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.059   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.066 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756551,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.080  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.085 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.086  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.088  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.091   999 12926 D AudioPolicyManagerCustom: setForceUse() usage 7, config 0, mPhoneState 0
08-30 11:05:59.092   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000001, index 14
08-30 11:05:59.092   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.094   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 12
08-30 11:05:59.094   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.095   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 14
08-30 11:05:59.095   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.096  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.096  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.098   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 12
08-30 11:05:59.098   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.100  1517  2577 I AS.AudioDeviceBroker: In updateSpeakerphoneOn(), mForcedUseForCommExt: 1
08-30 11:05:59.101   999  1508 D AudioPolicyManagerCustom: setForceUse() usage 0, config 1, mPhoneState 0
08-30 11:05:59.102   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 14
08-30 11:05:59.102   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.102 25924 26531 I AudioManager: In isBluetoothScoOn(), calling application: com.tuya.smartiot
08-30 11:05:59.103  1517  5086 I AS.AudioDeviceBroker: In isBluetoothScoOnForApp(), mForcedUseForCommExt: 1
08-30 11:05:59.103   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 14
08-30 11:05:59.103   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.104   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.105   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 9
08-30 11:05:59.106   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000008, index 9
08-30 11:05:59.106   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 9
08-30 11:05:59.107   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 8
08-30 11:05:59.108   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 04000000, index 8
08-30 11:05:59.108   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 9
08-30 11:05:59.112  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.112  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.112 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756685,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.121  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.121  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.127 30404 30452 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:05:59.129  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.129  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.134 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756751,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.139  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.139  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.145  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.149 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364759149 TS:1693364758079 cache buffer:12 w:1920 h:2160  count:20 .....
08-30 11:05:59.152 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756817,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.159  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.168  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.168  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.169 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756899,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.176  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.177  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.185  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.186 30404 30444 D HoraeHelper: Thermal length:1
08-30 11:05:59.187  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.193 30404 30448 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:05:59.193  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.194 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364759194 cache len:15 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:10....
08-30 11:05:59.194 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364756951,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.202  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.203 30404 30452 D HoraeHelper: skinThermal:35.895
08-30 11:05:59.208  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.212 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364759212 TS:1693364758744 cache buffer:19 w:1920 h:2160  count:30 .....
08-30 11:05:59.214 25924 26597 I ThingCameraSDK: ThingCameraBase::Snapshot Port[0] leave(0)...
08-30 11:05:59.224 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364759224 TS:1693364757410 width:1920 height:2160 size:10 count:10.
08-30 11:05:59.225 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757017,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.230 25924 25937 I m.tuya.smartio: NativeAlloc concurrent copying GC freed 114762(7159KB) AllocSpace objects, 42(1016KB) LOS objects, 48% free, 25MB/49MB, paused 245us total 112.526ms
08-30 11:05:59.231 25924 25939 W System  : A resource failed to call close.
08-30 11:05:59.234  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.239 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757085,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.239  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.248  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.257  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.259 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757151,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.267  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.272  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.279 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757217,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.283  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.287 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757285,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.290  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.299  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.306 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757350,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.308  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.312 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364757009 ts:1693364757 progress:-1 count:4...
08-30 11:05:59.316 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757417,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.318  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.326  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.327  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.332 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757485,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.334  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.343  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:05:59.345 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757550,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.350  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:05:59.351  4348  5503 I Athena  : MemoryGuardAction: psi onPress:22,size:3943,psi weightedValue:0.0,thresholdValue:12
08-30 11:05:59.359 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364759359 cache len:11 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:20....
08-30 11:05:59.359 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.365 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364759365 TS:1693364758079 width:1920 height:2160 size:13 count:20.
08-30 11:05:59.367 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757686,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.382 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757751,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.389 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757817,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.397 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364759397 TS:1693364757410 interTimems:6 size:13 cache:867 speed:0.100000 count:10 ....
08-30 11:05:59.398 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757886,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.405 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364757953,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.413 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758017,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.421 25924 26531 I ThingCameraSDK: ThingCameraBase::SetMute Port[0] mute:1 enter...
08-30 11:05:59.421 25924 26531 I ThingCameraSDK: ThingAVModule::SetMute Port[0] mute:1
08-30 11:05:59.421 25924 26531 I ThingCameraSDK: ThingCameraBase::stopAudioPlayback Port[0] enter...
08-30 11:05:59.422 25924 26531 I ThingAudioEngineSDK: ThingAudioControllerImpl::StopPlayBack enter this:0x6faa4d6f10 play status:0
08-30 11:05:59.422 25924 26531 I ThingCameraSDK: ThingCameraBase::stopAudioPlayback Port[0] leave(-1)...
08-30 11:05:59.422 25924 26531 I ThingCameraSDK: ThingCameraBase::SetMute Port[0] leave(0)...
08-30 11:05:59.423 25924 26531 D AudioManager: setMode mode=0 from com.tuya.smartiot
08-30 11:05:59.423  1517  5208 I AS.AudioService: setMode(mode = 0, callingPackage = com.tuya.smartiot, Process ID: 25924
08-30 11:05:59.423 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758086,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.425  1517  5208 D AS.AudioService: +notifyAtlasServiceModesUpdate onlyRead :true
08-30 11:05:59.425  1517  5208 D AS.AudioService: modekey = allmodes=
08-30 11:05:59.427  1517  5208 D AS.AudioService: -notifyAtlasServiceModesUpdate
08-30 11:05:59.431  4254  4320 D OppoAtlasAudioState: getActiveAudioMusic ret = false
08-30 11:05:59.432   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.432  4254  4320 D AudioManager: getStreamVolume packageName=com.oppo.atlas, index=0, streamType=3
08-30 11:05:59.433  1517  5208 D AS.AudioService: ringVolumeDefault :0
08-30 11:05:59.433  1517  5210 D AS.AudioService: getParameters() keyValuePairs:OPLUS_AUDIO_GET_DEVICE_FORSTREAM:3
08-30 11:05:59.434   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.435   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.436  4254  4320 D OppoAtlasAudioState: isSpeakerMute() device: 2 ,index:0,ST:3
08-30 11:05:59.436  4254  4320 D OppoAtlasAudioState: checkAndSetPaState(state:4,mute:true), hasMusic:false,mode:0 ,mIsPlaybackRecord:false
08-30 11:05:59.437   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.437 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758152,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.439  1517  2527 I OplusWifiSarManager: Received action: android.media.ACTION_AUDIO_DEVICE_ROUTE_CHANGED
08-30 11:05:59.440   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.440   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.446   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.447   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.447   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.449 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758217,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.449   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.452   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.456   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.458   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.459 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364759459 cache len:1 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:30....
08-30 11:05:59.459 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758284,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.460   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.465   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.469 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364759469 TS:1693364758744 width:1920 height:2160 size:13 count:30.
08-30 11:05:59.473 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758352,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:05:59.486  1517  2577 I AS.AudioDeviceBroker: In updateSpeakerphoneOn(), mForcedUseForCommExt: 1
08-30 11:05:59.486 25924 26531 I AudioManager: In isBluetoothScoOn(), calling application: com.tuya.smartiot
08-30 11:05:59.486   999  1508 D AudioPolicyManagerCustom: setForceUse() usage 7, config 0, mPhoneState 0
08-30 11:05:59.486  1517  5208 I AS.AudioDeviceBroker: In isBluetoothScoOnForApp(), mForcedUseForCommExt: 1
08-30 11:05:59.486   999 12926 D AudioPolicyManagerCustom: setForceUse() usage 0, config 1, mPhoneState 0
08-30 11:05:59.487   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000001, index 14
08-30 11:05:59.487   999 12926 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.493   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 12
08-30 11:05:59.493   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.494   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 14
08-30 11:05:59.494   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.496   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 12
08-30 11:05:59.496   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.496 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364758009 ts:1693364758 progress:-1 count:19...
08-30 11:05:59.497   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 14
08-30 11:05:59.497   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:05:59.497   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 14
08-30 11:05:59.500   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000002, index 0
08-30 11:05:59.502   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000004, index 9
08-30 11:05:59.504   999 12926 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000008, index 9
08-30 11:05:59.506   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000010, index 9
08-30 11:05:59.507   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 00000080, index 8
08-30 11:05:59.510   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 04000000, index 8
08-30 11:05:59.511   999  1508 D APM_AudioPolicyManager: setVolumeCurveIndex device 40000000, index 9
08-30 11:05:59.517 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364759517 TS:1693364758079 interTimems:16 size:12 cache:732 speed:0.250000 count:20 ....
08-30 11:05:59.550 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364759550 TS:1693364758882 diff: 549 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:11
08-30 11:05:59.563  1517  5208 I WifiService: getWifiEnabledState uid=1000
08-30 11:05:59.563  1517  5086 I WifiService: getWifiApEnabledState uid=1000
08-30 11:05:59.563  1517  5208 I WifiService: getConnectionInfo uid=1000
08-30 11:05:59.602  1517  2519 D WN_S    : DT,tP=943163, dTP=61, rP=1653816, dRP=59 mIR=true, mRPLC=0
08-30 11:05:59.602  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:05:59.800 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 34 fps, mOutputBufCnt = 32 fps, mRenderFrameCnt = 0 fps
08-30 11:05:59.911  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 55ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653821 wlan0TxPtk=943168 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:05:59.937 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364759937 TS:1693364758744 interTimems:94 size:2 cache:66 speed:1.500000 count:30 ....
08-30 11:06:00.004  4985  4985 I WeatherS_WeatherServiceVersionUtils: serviceVersionCode8002022
08-30 11:06:00.004  4985  4985 I chatty  : uid=10076(com.coloros.alarmclock) identical 1 line
08-30 11:06:00.014  4985  4985 E Parcel  : Reading a NULL string not supported here.
08-30 11:06:00.019  2938  2938 D SingleClockView: updateTime,  24hfmt=true, h=11, m=06
08-30 11:06:00.033  1517  5208 E OplusCustomizeRestrictionManagerService: isBiometricDisabled start
08-30 11:06:00.052 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 127.484398 kbps packet cache:0, frame cache:282
08-30 11:06:00.053 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364760053 TS:1693364758879 diff:1079 fragment:1 cache: 1 size:1920x2160 codec:20 len:1114 V-Count:32 IFrame:0....
08-30 11:06:00.053 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364760053 TS:1693364759071 diff: 462 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:16
08-30 11:06:00.053 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364760053 TS:1693364759229 diff:   0 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:20
08-30 11:06:00.064  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.073  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.074  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.076 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758418,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.089  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.090  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.094 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758486,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.100  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.101  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.104 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758550,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.111  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.113  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.115 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.122  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.125 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758685,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.133  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.143  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.143  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.146 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758751,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.155  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.155  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.158 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758816,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.164  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.171 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364758884,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.235 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364759009 ts:1693364759 progress:-1 count:34...
08-30 11:06:00.260  4289  4304 E horae   : 0: back:36095,frame:36095,front:36095, 5, +(0), 1 ,36095
08-30 11:06:00.352  4348  5503 I Athena  : MemoryGuardAction: psi onPress:0,size:3997,psi weightedValue:0.0,thresholdValue:12
08-30 11:06:00.455 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364760454 TS:1693364759452 diff: 401 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:25
08-30 11:06:00.455 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364760455 TS:1693364759644 diff:   0 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:30
08-30 11:06:00.455 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364760455 TS:1693364760029 diff:   0 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:40
08-30 11:06:00.553  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-16 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:00.553  1517  2519 D OplusRssiMonitor: update rssi:-16
08-30 11:06:00.553  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:00.553  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:00.553  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:00.553  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-26 for "abc_ling"WPA_PSK
08-30 11:06:00.553  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:00.553  1517  2519 D WifiDataStall: L2 txTputKbps: 59400, rxTputKbps: 66000, L3 txTputKbps: 193, rxTputKbps: 2038, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:00.554  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -16, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:00.554  1517  2519 D WifiScoreCard: txRate: 45 txSpeed: 96
08-30 11:06:00.554  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -16 txSpeed 96
08-30 11:06:00.554  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:00.554  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538598555 LastRssiPoll: -16 LastTxSpeedPoll: 96
08-30 11:06:00.554  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:00.554  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:00.554  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:00.558  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -16
08-30 11:06:00.559  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:00.559  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:00.560  1517  5086 I WifiService: getConnectionInfo uid=10060
08-30 11:06:00.560  1517  5086 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:00.561  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -16 level: 4
08-30 11:06:00.562  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-16 f=2462 sc=0 link=96 tx=39.6, 4.9, 0.0  rx=173.6 bcn=9009288 [on:2937 tx:103 rx:99 period:3006] from screen [on:4919982 period:6550492] score=0
08-30 11:06:00.801 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 8 fps, mOutputBufCnt = 8 fps, mRenderFrameCnt = 0 fps
08-30 11:06:00.818  1517  2470 D SensorService: FusionLight processRawLux, stop to shot
08-30 11:06:00.818  1517  2470 D SensorService: ShotOnce, after outEvent->light = 183.170547, comp_lux = 392.107727, RGB(255.000000,255.000000,255.000000), C = 208.000000, threshold = 1000, mBrightLevel = 103
08-30 11:06:00.844 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:06:00.844 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364760844 TS:1693364759409 diff: 759 fragment:1 cache: 1 size:1920x2160 codec:20 len:151271 V-Count:40 IFrame:1....
08-30 11:06:00.845 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364760845 TS:1693364760078 diff:   0 fragment:1 cache:11 size:1920x2160 codec:20 len:560 V-Count:50 IFrame:0....
08-30 11:06:00.849 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364760849 TS:1693364759409 cache buffer:0 w:1920 h:2160  count:40 .....
08-30 11:06:00.868 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364760868 TS:1693364760158 diff: 413 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:43
08-30 11:06:00.869 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364760868 TS:1693364760445 diff:   0 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:50
08-30 11:06:00.869 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364759293 size:640...
08-30 11:06:00.870 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364759325 size:640...
08-30 11:06:00.870 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364759357 size:640...
08-30 11:06:00.870 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364759391 size:640...
08-30 11:06:00.870 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364759452 size:640...
08-30 11:06:00.870 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364759484 size:640...
08-30 11:06:00.870 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364759517 size:640...
08-30 11:06:00.873  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.881  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.881  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.885 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364760885 cache len:7 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:40....
08-30 11:06:00.885 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] no sei exists!
08-30 11:06:00.887 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364760887 TS:1693364759409 width:1920 height:2160 size:1 count:40.
08-30 11:06:00.887 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364760887 TS:1693364759409 interTimems:-466 size:1 cache:0 speed:2.000000 count:40 ....
08-30 11:06:00.892  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.892  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.895 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759017,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.905  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.905  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.914 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759083,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.915  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.915  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.923 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759151,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1468,147,1783,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.926  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.926  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.932 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759217,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.934  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.936  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.942  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.942 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759284,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.948 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364760948 TS:1693364760078 cache buffer:4 w:1920 h:2160  count:50 .....
08-30 11:06:00.951  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 54ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653825 wlan0TxPtk=943172 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:00.952 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759350,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.955  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.962  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.963  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.965 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759416,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.970  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.971  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.975 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759484,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.978  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.981  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.985 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759551,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.987  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:00.988  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:00.994 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364760994 cache len:1 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:50....
08-30 11:06:00.995 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.995  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.006 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364761006 TS:1693364760078 width:1920 height:2160 size:8 count:50.
08-30 11:06:01.009 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759685,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:00.035  1517  5208 E OplusCustomizeRestrictionManagerService: isBiometricDisabled start
08-30 11:06:01.070  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:01.077  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3440200
08-30 11:06:01.077  3234  3234 D DeviceInfoHidlClient: isPowerInfoNeverSent()=true
08-30 11:06:01.077  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:01.091 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 156.662613 kbps packet cache:0, frame cache:346
08-30 11:06:01.091 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364761091 TS:1693364760209 diff: 246 fragment:1 cache: 1 size:1920x2160 codec:20 len:541 V-Count:52 IFrame:0....
08-30 11:06:01.091 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364760547 ,count:400
08-30 11:06:01.103  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.108  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.110  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.111 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759752,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.116  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.118  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.120 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759817,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1438,147,1783,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.125  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.126  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.131 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759886,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.135  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.135  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.138 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364761138 TS:1693364760604 diff: 269 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:54
08-30 11:06:01.139 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364761139 TS:1693364760828 diff:   0 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:60
08-30 11:06:01.141 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364759950,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.143 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364761143 TS:1693364760744 diff:   0 fragment:1 cache: 3 size:1920x2160 codec:20 len:2288 V-Count:60 IFrame:0....
08-30 11:06:01.146  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.147  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.149 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364761149 TS:1693364760744 cache buffer:4 w:1920 h:2160  count:60 .....
08-30 11:06:01.150 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760016,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.154  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.164  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.166 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760085,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.171  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.173  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.176 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760154,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1783,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.180 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364761180 TS:1693364761246 diff:  31 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:70
08-30 11:06:01.184  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.187  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.188 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760217,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.194  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.195  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.203  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.203  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.205 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364761205 cache len:5 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:60....
08-30 11:06:01.205 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760284,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.211 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364760009 ts:1693364760 progress:-1 count:49...
08-30 11:06:01.212 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364761211 TS:1693364760744 width:1920 height:2160 size:11 count:60.
08-30 11:06:01.213  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.213  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.215 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760351,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.222  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.226 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760417,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.231 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364761231 TS:1693364760078 interTimems:16 size:11 cache:730 speed:0.250000 count:50 ....
08-30 11:06:01.234  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.241  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3440200
08-30 11:06:01.241  3234  3234 D DeviceInfoHidlClient: isPowerInfoNeverSent()=true
08-30 11:06:01.241  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:01.243 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760485,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.243  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.243  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.254  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.254  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.256 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760550,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.263  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.265 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.273  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.273 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760684,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.282  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.283  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.285 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760754,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.292  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.296 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760818,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1798,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.302  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.308  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.309 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364760319 size:640...
08-30 11:06:01.310 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364760352 size:640...
08-30 11:06:01.310 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364760414 size:640...
08-30 11:06:01.311 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364760445 size:640...
08-30 11:06:01.311 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364760481 size:640...
08-30 11:06:01.312 25924 26594 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364760509 size:640...
08-30 11:06:01.313 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760886,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.349 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364761349 TS:1693364761409 diff:  61 fragment:1 cache: 1 size:1920x2160 codec:20 len:1214 V-Count:70 IFrame:0....
08-30 11:06:01.349 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364761349 TS:1693364761409 cache buffer:0 w:1920 h:2160  count:70 .....
08-30 11:06:01.359  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.364  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.366 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364761366 cache len:0 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:70....
08-30 11:06:01.366 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364760951,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.371 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364761370 TS:1693364761409 width:1920 height:2160 size:11 count:70.
08-30 11:06:01.385 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364761385 TS:1693364760744 interTimems:13 size:11 cache:666 speed:0.250000 count:60 ....
08-30 11:06:01.420  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.426  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.429 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761016,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.490 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364761009 ts:1693364761 progress:-1 count:64...
08-30 11:06:01.491  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.498  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.500 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761085,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.552  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.558  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.560 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761150,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.562 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364761562 TS:1693364761630 diff:  21 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:80
08-30 11:06:01.602  1517  2519 D WN_S    : DT,tP=943172, dTP=9, rP=1653825, dRP=9 mIR=true, mRPLC=0
08-30 11:06:01.602  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:01.615  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.619  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.622 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761217,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.686  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.691  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.693 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761284,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.698 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364761698 TS:1693364761409 interTimems:31 size:5 cache:331 speed:0.500000 count:70 ....
08-30 11:06:01.767  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.771  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.774 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761350,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.801 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 38 fps, mOutputBufCnt = 37 fps, mRenderFrameCnt = 0 fps
08-30 11:06:01.828  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.833  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.835 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761417,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.892  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.898  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.900 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761486,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.951  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:01.957  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.960 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761551,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:01.985 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364761985 TS:1693364762045 diff:  30 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:90
08-30 11:06:01.991  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 54ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653829 wlan0TxPtk=943176 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:02.062  4348  5498 I Athena  : MemoryGuardAction: 343735s since the last releasing, try to force trigger
08-30 11:06:02.062  4348  5498 I Athena  : MemoryGuardAction: triggerMemory:2000MB, availMemory:4010MB
08-30 11:06:02.154 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:06:02.154 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 166.527344 kbps packet cache:0, frame cache:579
08-30 11:06:02.154 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364762154 TS:1693364762080 diff: 214 fragment:1 cache: 1 size:1920x2160 codec:20 len:151201 V-Count:80 IFrame:1....
08-30 11:06:02.159 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364762159 TS:1693364762080 cache buffer:0 w:1920 h:2160  count:80 .....
08-30 11:06:02.182  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.190  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.193  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.194 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364762194 cache len:2 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:80....
08-30 11:06:02.195 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] no sei exists!
08-30 11:06:02.197 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364762197 TS:1693364762080 width:1920 height:2160 size:2 count:80.
08-30 11:06:02.201  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.203  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.205 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761687,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.212  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.215 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761747,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.236  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.244  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.247 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761817,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.296 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364762009 ts:1693364762 progress:-1 count:79...
08-30 11:06:02.297  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.306  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.313 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761888,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.347 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364762409 ,count:600
08-30 11:06:02.358  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.362  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.365 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364761951,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.369 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364762369 TS:1693364762080 interTimems:68 size:4 cache:270 speed:1.000000 count:80 ....
08-30 11:06:02.374 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364762374 TS:1693364762430 diff:  21 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:100
08-30 11:06:02.433  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.439  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:01.229  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:02.442  1517  2586 D JobScheduler.Temperature: get temperature=36.095
08-30 11:06:02.443 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762016,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.481  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.487  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.489 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762085,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.552  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.558  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.560  1517  5208 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:02.560  1517  5210 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:02.560  1517  5208 I WifiService: getConnectionInfo uid=1000
08-30 11:06:02.562 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762150,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1438,147,1798,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.632  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.638  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.641 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762217,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.671 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364762197,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":15420} ...
08-30 11:06:02.703 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364762703 TS:1693364762744 diff:  81 fragment:1 cache: 1 size:1920x2160 codec:20 len:555 V-Count:90 IFrame:0....
08-30 11:06:02.703 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364762703 TS:1693364762744 cache buffer:0 w:1920 h:2160  count:90 .....
08-30 11:06:02.713  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.718  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.720 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364762720 cache len:0 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:90....
08-30 11:06:02.721 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762284,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.724 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364762724 TS:1693364762744 width:1920 height:2160 size:4 count:90.
08-30 11:06:02.757  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.761  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.765 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762351,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.780 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364762780 TS:1693364762846 diff:  30 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:110
08-30 11:06:02.801 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 16 fps, mOutputBufCnt = 15 fps, mRenderFrameCnt = 0 fps
08-30 11:06:02.827  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.832  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.834 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762416,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.899  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.904  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.906 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762486,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1783,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.949  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:02.955  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:02.957 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762551,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:02.999 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364762999 TS:1693364762744 interTimems:63 size:4 cache:266 speed:1.000000 count:90 ....
08-30 11:06:03.023  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.028  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.031 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.031  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 54ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653834 wlan0TxPtk=943181 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:03.083  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.089  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.093 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762684,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.154  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.162  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.164 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762751,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.169 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364763169 TS:1693364763229 diff:  31 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:120
08-30 11:06:03.214 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 11.918670 kbps packet cache:0, frame cache:632
08-30 11:06:03.225  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.232  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.235 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762818,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1783,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.264 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364763009 ts:1693364763 progress:-1 count:94...
08-30 11:06:03.285  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.294  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.297 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762885,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.305 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364762831,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":5392,"channels":[[0,236,152,236,152,676,476,402,393,475,392,470],[1,0,575369,0,575369,1496,1248368,623,-1,517,393,517],[2,0,45632,0,45632,836,97236,1093,-1,994,393,990],[330,3216,0,-240,0,92448,0,390,159,-1,-1,-1]]} ...
08-30 11:06:03.346 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364763346 TS:1693364763410 diff:  71 fragment:1 cache: 1 size:1920x2160 codec:20 len:2159 V-Count:100 IFrame:0....
08-30 11:06:03.347 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364763347 TS:1693364763410 cache buffer:0 w:1920 h:2160  count:100 .....
08-30 11:06:03.357  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.365  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.367 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364763367 cache len:0 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:100....
08-30 11:06:03.368 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364762950,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.373 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364763373 TS:1693364763410 width:1920 height:2160 size:4 count:100.
08-30 11:06:03.417  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.428  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.430 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763017,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.499  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.507  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.509 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763086,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.560  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.562  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-26 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:03.562  1517  2519 D OplusRssiMonitor: update rssi:-26
08-30 11:06:03.562  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:03.562  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:03.562  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:03.562  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-26 for "abc_ling"WPA_PSK
08-30 11:06:03.562  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:03.563  1517  2519 D WifiDataStall: L2 txTputKbps: 62700, rxTputKbps: 66000, L3 txTputKbps: 16, rxTputKbps: 1762, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:03.563  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -26, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:03.563  1517  2519 D WifiScoreCard: txRate: 32 txSpeed: 96
08-30 11:06:03.565  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -26 txSpeed 96
08-30 11:06:03.566  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:03.566  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538601566 LastRssiPoll: -26 LastTxSpeedPoll: 96
08-30 11:06:03.566  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:03.566  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:03.566  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:03.568  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.570  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -26 level: 4
08-30 11:06:03.571  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-26 f=2462 sc=0 link=96 tx=28.9, 2.6, 0.0  rx=222.3 bcn=9009317 [on:2936 tx:48 rx:103 period:3007] from screen [on:4922918 period:6553501] score=0
08-30 11:06:03.571  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -26
08-30 11:06:03.571  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:03.571  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:03.572 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763152,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1783,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.574  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:06:03.574  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:03.585 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364763585 TS:1693364763645 diff:  30 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:130
08-30 11:06:03.603  1517  2519 D WN_S    : DT,tP=943181, dTP=9, rP=1653834, dRP=9 mIR=true, mRPLC=0
08-30 11:06:03.603  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:03.632  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.640  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.643 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763217,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.665 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364763665 TS:1693364763410 interTimems:65 size:4 cache:264 speed:1.000000 count:100 ....
08-30 11:06:03.693  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.701  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.704 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763284,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.754  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.762  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.765 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763351,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.801 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 15 fps, mOutputBufCnt = 15 fps, mRenderFrameCnt = 0 fps
08-30 11:06:03.801 25924 26604 D IAtlas  : IAtlas::init CallingPid 25924
08-30 11:06:03.802 25924 26604 D IAtlas  : IAtlas::init this 0x6ffd467ad0
08-30 11:06:03.802  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:03.802  1378  1429 D AtlasService: notify 1029 to client
08-30 11:06:03.826  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.835  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.837 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763417,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1799,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.883  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:06:03.883  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=239,badLossCount=0,txLoss=0,mLinkDetectTimes= 602,mIndex =0
08-30 11:06:03.883  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 54, 0, 0, 0, 0, 676, 54, 0, 0, 0, 0, 676, 54, 0, 0, 0, 0, 676, 55, 0, 0, 0, 0, 676, 55, 0, 0, 0, 0]
08-30 11:06:03.884  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:06:03.884  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:06:03.884  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:06:03.884  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:06:03.884  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-26,mIndex =0,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12575758874
08-30 11:06:03.884  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:06:03.884  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:06:03.884  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:06:03.884  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:06:03.884  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:06:03.884  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:06:03.884  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:06:03.889  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.896  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.898 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763485,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1783,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.959  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:03.966  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:03.969 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763551,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:03.971 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364763971 TS:1693364764029 diff:  41 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:140
08-30 11:06:04.071  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 54ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653838 wlan0TxPtk=943185 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:04.095 30404 30448 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:06:04.096 30404 30448 D HoraeHelper: Thermal length:1
08-30 11:06:04.131 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364764130 TS:1693364764078 diff: 182 fragment:1 cache: 1 size:1920x2160 codec:20 len:1032 V-Count:110 IFrame:0....
08-30 11:06:04.131 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364764131 TS:1693364764078 cache buffer:0 w:1920 h:2160  count:110 .....
08-30 11:06:04.143  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.151  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.153 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364764153 cache len:1 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:110....
08-30 11:06:04.153 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.154  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.158 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364764158 TS:1693364764078 width:1920 height:2160 size:2 count:110.
08-30 11:06:04.166  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.172 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763685,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.176  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.185  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.189 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763750,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.193 30404 30452 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:06:04.215 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 19.597589 kbps packet cache:0, frame cache:674
08-30 11:06:04.226  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.235  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.239 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763817,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1783,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.277  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.285  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.288 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763885,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.295 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364764009 ts:1693364764 progress:-1 count:109...
08-30 11:06:04.339 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364764339 TS:1693364764078 interTimems:25 size:5 cache:266 speed:0.500000 count:110 ....
08-30 11:06:04.352  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.361  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.364 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364763950,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.400 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364764400 TS:1693364764446 diff:  51 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:150
08-30 11:06:04.432  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.441  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.444 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764016,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.494  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.502  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.504 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764086,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.595  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.603  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.606 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764151,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1798,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.625  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.633  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.636 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764217,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.803 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 13 fps, mOutputBufCnt = 13 fps, mRenderFrameCnt = 0 fps
08-30 11:06:04.889 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364764744 ,count:800
08-30 11:06:04.892 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364764892 TS:1693364764765 diff: 214 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:158
08-30 11:06:04.909 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:06:04.910 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364764910 TS:1693364764744 diff: 295 fragment:1 cache: 1 size:1920x2160 codec:20 len:151248 V-Count:120 IFrame:1....
08-30 11:06:04.915 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364764915 TS:1693364764744 cache buffer:0 w:1920 h:2160  count:120 .....
08-30 11:06:04.916 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364764915 TS:1693364764828 diff:  23 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:160
08-30 11:06:04.939  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.948  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.948  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.951 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364764951 cache len:3 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:120....
08-30 11:06:04.951 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] no sei exists!
08-30 11:06:04.953 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364764953 TS:1693364764744 width:1920 height:2160 size:1 count:120.
08-30 11:06:04.956  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.957  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.960 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764353,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.966  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.967  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.969 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764413,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.975  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.978 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764485,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:04.985  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:04.994  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:04.997 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764550,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.033  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.043  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.046 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.055 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364765055 TS:1693364764744 interTimems:32 size:5 cache:338 speed:0.500000 count:120 ....
08-30 11:06:05.103  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.111  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 53ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653842 wlan0TxPtk=943189 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:05.115  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.117 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764685,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.155  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.165  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.173 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764751,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.180 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364765180 TS:1693364765245 diff:  30 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:170
08-30 11:06:05.225  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.234  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.237 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764816,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.286 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 149.729553 kbps packet cache:0, frame cache:719
08-30 11:06:05.291 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364765009 ts:1693364765 progress:-1 count:124...
08-30 11:06:05.300  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.310  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.313 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764884,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.342 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364765342 TS:1693364765409 diff:  56 fragment:1 cache: 1 size:1920x2160 codec:20 len:625 V-Count:130 IFrame:0....
08-30 11:06:05.342 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364765342 TS:1693364765409 cache buffer:0 w:1920 h:2160  count:130 .....
08-30 11:06:05.352  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.360  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.363 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364765363 cache len:0 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:130....
08-30 11:06:05.363 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364764950,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.370 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364765370 TS:1693364765409 width:1920 height:2160 size:4 count:130.
08-30 11:06:05.424  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.432  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.435 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765016,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.494  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.503  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.506 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765085,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.556 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364765556 TS:1693364765630 diff:  20 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:180
08-30 11:06:05.557  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.565  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.567 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765150,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.573  1517  5086 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:05.573  1517  5210 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:05.573  1517  5210 I WifiService: getConnectionInfo uid=1000
08-30 11:06:05.604  1517  2519 D WN_S    : DT,tP=943189, dTP=8, rP=1653842, dRP=8 mIR=true, mRPLC=0
08-30 11:06:05.604  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:05.616  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.624  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.627 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765216,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.667 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364765667 TS:1693364765409 interTimems:62 size:4 cache:265 speed:1.000000 count:130 ....
08-30 11:06:05.687  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.696  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.699 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765284,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.780  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.787  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.790 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765351,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.803 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 18 fps, mOutputBufCnt = 17 fps, mRenderFrameCnt = 0 fps
08-30 11:06:05.820  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.827  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.830 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765417,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1799,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.890  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.898  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.900 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765487,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.961  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:05.969  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:05.973 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765550,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:05.983 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364765983 TS:1693364766046 diff:  30 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:190
08-30 11:06:06.015  1517  1517 D OppoBaseBatteryService: send broadcast : oppo.intent.action.BATTERY_DATA_UPDATE
08-30 11:06:06.015  1517  1517 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1158 com.android.server.OppoBaseBatteryService$2.run:280 android.os.Handler.handleCallback:938 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:263
08-30 11:06:06.016  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:06.023  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3441300
08-30 11:06:06.023  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:06.023 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364766023 TS:1693364766079 diff:  72 fragment:1 cache: 1 size:1920x2160 codec:20 len:2232 V-Count:140 IFrame:0....
08-30 11:06:06.024 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364766024 TS:1693364766079 cache buffer:0 w:1920 h:2160  count:140 .....
08-30 11:06:06.035  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.044  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.047 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364766047 cache len:0 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:140....
08-30 11:06:06.047 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.051 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364766051 TS:1693364766079 width:1920 height:2160 size:4 count:140.
08-30 11:06:06.086  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.095  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.098 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765686,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.151  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 53ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653846 wlan0TxPtk=943193 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:06.167  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.175  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.177 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765751,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.219  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.228  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.231 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765816,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.267 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364766009 ts:1693364766 progress:-1 count:139...
08-30 11:06:06.288  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.296  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.299 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765884,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.337 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364766337 TS:1693364766079 interTimems:67 size:4 cache:265 speed:1.000000 count:140 ....
08-30 11:06:06.349 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 15.497303 kbps packet cache:0, frame cache:769
08-30 11:06:06.360  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.367  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.369 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364766369 TS:1693364766428 diff:  20 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:200
08-30 11:06:06.369 25924 26591 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadAudioStream Port[0] audio rtp package recved ,count:200
08-30 11:06:06.371 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364765950,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.420  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.428  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.432 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766016,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.482  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.490  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.493 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766085,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.563  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.569  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-29 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:06.569  1517  2519 D OplusRssiMonitor: update rssi:-29
08-30 11:06:06.570  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:06.570  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:06.570  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.573 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766150,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.578  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:06.578  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-27 for "abc_ling"WPA_PSK
08-30 11:06:06.578  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:06.578  1517  2519 D WifiDataStall: L2 txTputKbps: 56760, rxTputKbps: 66000, L3 txTputKbps: 10, rxTputKbps: 701, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:06.578  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -29, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:06.578  1517  2519 D WifiScoreCard: txRate: 25 txSpeed: 96
08-30 11:06:06.579  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -29 txSpeed 96
08-30 11:06:06.579  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:06.579  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538604580 LastRssiPoll: -29 LastTxSpeedPoll: 96
08-30 11:06:06.579  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:06.579  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:06.579  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:06.582  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:06.582  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -29
08-30 11:06:06.582  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:06.583  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -29 level: 4
08-30 11:06:06.584  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-29 f=2462 sc=0 link=96 tx=21.5, 2.9, 0.0  rx=148.8 bcn=9009347 [on:2939 tx:41 rx:70 period:3012] from screen [on:4925857 period:6556514] score=0
08-30 11:06:06.584  1517  5086 I WifiService: getConnectionInfo uid=10060
08-30 11:06:06.584  1517  5086 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:06.624  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.631  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.634 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766216,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.685 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364766685 TS:1693364766744 diff:  71 fragment:1 cache: 1 size:1920x2160 codec:20 len:1080 V-Count:150 IFrame:0....
08-30 11:06:06.685 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364766685 TS:1693364766744 cache buffer:0 w:1920 h:2160  count:150 .....
08-30 11:06:06.697  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.704  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.707 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364766707 cache len:0 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:150....
08-30 11:06:06.707 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766284,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.711 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364766711 TS:1693364766744 width:1920 height:2160 size:4 count:150.
08-30 11:06:06.769  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.777  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.779 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766351,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.786 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364766786 TS:1693364766845 diff:  31 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:210
08-30 11:06:06.803 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 15 fps, mOutputBufCnt = 15 fps, mRenderFrameCnt = 0 fps
08-30 11:06:06.828  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.836  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.840 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766417,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.885  1353  1379 D bspCriticalLog: thermal_monitor ddr-usr: open fail -1
08-30 11:06:06.885  1353  1379 D bspCriticalLog: thermal_monitor gpuss-0-usr: open fail -1
08-30 11:06:06.885  1353  1379 D bspCriticalLog: thermal_monitor cpu-1-0-usr: open fail -1
08-30 11:06:06.885  1353  1381 D bspCriticalLog: power_monitor cpu-1-0-usr: open fail -1
08-30 11:06:06.890  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.898  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.901 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766486,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:06.951  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:06.959  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:06.962 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766551,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:07.002 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364767002 TS:1693364766744 interTimems:64 size:4 cache:265 speed:1.000000 count:150 ....
08-30 11:06:07.022  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:07.030  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:07.033 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:07.062  3304  3304 E OplusNecManagerHelper: com.oplus.nec.OplusNecManager.notifyOrigSignalStrengthChanged [class android.telephony.SignalStrength, int]
08-30 11:06:07.066  1517  1517 D OplusSlaManager_RSRP: onSignalStrengthsChanged oldRsrp=0 newRsrp=-105
08-30 11:06:07.093  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:07.101  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:07.104 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766685,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:07.153  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:07.161  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:07.164 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766752,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:07.176 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364767176 TS:1693364767229 diff:  50 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:220
08-30 11:06:07.191  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 53ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653852 wlan0TxPtk=943199 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:07.227  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:07.235  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:07.238 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766817,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:07.267 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364767009 ts:1693364767 progress:-1 count:154...
08-30 11:06:07.298  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:07.306  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:07.309 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364766885,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:07.605  1517  2519 D WN_S    : DT,tP=943199, dTP=10, rP=1653852, dRP=10 mIR=true, mRPLC=0
08-30 11:06:07.605  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:07.671 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364767198,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":20421} ...
08-30 11:06:07.733 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364767410 ,count:1000
08-30 11:06:07.797 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364767797 TS:1693364767453 diff: 468 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:225
08-30 11:06:07.803 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 8 fps, mOutputBufCnt = 8 fps, mRenderFrameCnt = 0 fps
08-30 11:06:08.221 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:06:08.222 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 86.123634 kbps packet cache:0, frame cache:814
08-30 11:06:08.222 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364768222 TS:1693364767410 diff: 935 fragment:1 cache: 1 size:1920x2160 codec:20 len:151087 V-Count:160 IFrame:1....
08-30 11:06:08.226 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364768226 TS:1693364767410 cache buffer:0 w:1920 h:2160  count:160 .....
08-30 11:06:08.231  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 53ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653854 wlan0TxPtk=943201 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:08.249  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.260  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.260  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.264 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364768264 cache len:2 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:160....
08-30 11:06:08.265 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] no sei exists!
08-30 11:06:08.266 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364768266 TS:1693364767410 width:1920 height:2160 size:1 count:160.
08-30 11:06:08.266 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364768266 TS:1693364767410 interTimems:-1106 size:1 cache:0 speed:2.000000 count:160 ....
08-30 11:06:08.269  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.270  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.273 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767019,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.282  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.287 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767083,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.295 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=106.0, y[0]=351.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343779262, downTime=343779262, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:08.295 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=106.0, y[0]=351.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343779262, downTime=343779262, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:08.296 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=106.0, y[0]=351.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343779262, downTime=343779262, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:08.306 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364767833,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":10394,"channels":[[0,236,152,236,152,676,476,402,393,475,392,470],[1,0,960999,0,960999,3080,1660384,623,-1,517,393,517],[2,0,83904,0,83904,2156,143412,1093,-1,994,393,990],[330,3216,0,-240,0,188748,0,390,159,-1,-1,-1]]} ...
08-30 11:06:08.320 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364768320 TS:1693364767550 diff: 523 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:228
08-30 11:06:08.320 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364768320 TS:1693364767646 diff:   0 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:230
08-30 11:06:08.329  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.336  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.340 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767152,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.346  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.354 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=106.0, y[0]=351.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343779322, downTime=343779262, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:08.354  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.354 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=106.0, y[0]=351.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343779322, downTime=343779262, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:08.358 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767218,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1153,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.451 25924 25924 D ColorViewRootUtil: initSwipState, isDisplayCompatApp false
08-30 11:06:08.451 25924 25924 D ColorViewRootUtil: mScreenHeight 2400, mScreenWidth 1080
08-30 11:06:08.451 25924 25924 D WindowManager: Add to mViews: DecorView@3025104[TRCTSmartCameraPanelActivity],pkg= com.tuya.smartiot
08-30 11:06:08.455  1517  5208 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:08.457  1517  5208 V WindowManager: Changing focus from Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} to Window{2cc15e2 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:06:08.462  1517  5208 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:08.468  1517  5086 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:08.475  1517  5208 I InputDispatcher: Focus left window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:08.479 25924 25924 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 2400 getDecorView.DecorView@3025104[TRCTSmartCameraPanelActivity]
08-30 11:06:08.481  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:08.489  1003  1124 D DispPerfService: onframeavailable pid=25924, slot=1, seq=16518, name=com.tuya.smartiot:com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#1
08-30 11:06:08.503  1517 13105 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:08.508  1517  5086 I InputDispatcher: Focus entered window: Window{2cc15e2 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:08.521  1517 13105 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:06:08.521  1517 13105 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:08.506  1517  1860 I chatty  : uid=1000(system) android.display identical 4 lines
08-30 11:06:08.511  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:08.521  1517 13105 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:08.521  1517 13105 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:08.530  1517 13105 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:08.534  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:08.583  1517  5208 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:08.583  1517 13105 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:08.583  1517  5208 I WifiService: getConnectionInfo uid=1000
08-30 11:06:08.595 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364768595 TS:1693364767710 diff: 274 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:232
08-30 11:06:08.628 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364768628 TS:1693364767744 diff: 300 fragment:1 cache: 1 size:1920x2160 codec:20 len:641 V-Count:165 IFrame:0....
08-30 11:06:08.639  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.649  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.651 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767286,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.736  1003  1003 D OppoExLayer: ~Layer() sequence=16519, name=Surface(name=2cc15e2 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x2967f3a - animation-leash#0@0xb40000702af6b000
08-30 11:06:08.778  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.784  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.789 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767351,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.793  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.799  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.800  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.803 25924 26604 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 11 fps, mOutputBufCnt = 7 fps, mRenderFrameCnt = 0 fps
08-30 11:06:08.804  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:08.804  1378  1429 D AtlasService: notify 1025 to client
08-30 11:06:08.805  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:08.805  1378  1429 D AtlasService: notify 1029 to client
08-30 11:06:08.807  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.808  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.810 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767417,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.815  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.824 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767485,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1453,147,1798,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.829 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767550,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.863 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364768863 TS:1693364768029 diff:  92 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:240
08-30 11:06:08.880 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364768879 TS:1693364768077 diff: 113 fragment:1 cache: 1 size:1920x2160 codec:20 len:568 V-Count:170 IFrame:0....
08-30 11:06:08.880 25924 26595 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364768880 TS:1693364768077 cache buffer:0 w:1920 h:2160  count:170 .....
08-30 11:06:08.884  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:06:08.885  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=52,badLossCount=0,txLoss=0,mLinkDetectTimes= 603,mIndex =1
08-30 11:06:08.885  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 53, 0, 0, 0, 0, 676, 53, 0, 0, 0, 0, 676, 53, 0, 0, 0, 0, 676, 53, 0, 0, 0, 0, 676, 54, 0, 0, 0, 0]
08-30 11:06:08.885  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:06:08.885  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:06:08.885  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:06:08.887  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:06:08.887  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-29,mIndex =1,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12576361020
08-30 11:06:08.887  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:06:08.887  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:06:08.887  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:06:08.887  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:06:08.887  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:06:08.887  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:06:08.887  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:06:08.891  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.896  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.899 25924 26610 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364768899 cache len:0 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:170....
08-30 11:06:08.899 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767616,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.903 25924 26610 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364768903 TS:1693364768077 width:1920 height:2160 size:2 count:170.
08-30 11:06:08.941  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.946  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.948 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767685,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:08.962  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:08.968  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:08.970 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767752,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,309,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-40,1814,1653],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:09.041 25924 26597 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364768009 ts:1693364768 progress:-1 count:169...
08-30 11:06:09.109 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364769109 TS:1693364768077 interTimems:57 size:3 cache:132 speed:1.000000 count:170 ....
08-30 11:06:09.127 30404 30447 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:06:09.185 30404 30448 D HoraeHelper: Thermal length:1
08-30 11:06:09.193 30404 30447 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:06:09.204 30404 30447 D HoraeHelper: skinThermal:36.318
08-30 11:06:08.724  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:08.742  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:09.232 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=732.0, y[0]=2001.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343780200, downTime=343780200, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:09.233 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=732.0, y[0]=2001.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343780200, downTime=343780200, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:09.233 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=732.0, y[0]=2001.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343780200, downTime=343780200, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:09.267 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 8.555435 kbps packet cache:0, frame cache:826
08-30 11:06:09.268 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364769268 TS:1693364768278 diff: 317 fragment:1 cache: 1 size:1920x2160 codec:20 len:891 V-Count:173 IFrame:0....
08-30 11:06:09.271  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 53ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653858 wlan0TxPtk=943205 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:09.280  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:09.285 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=732.0, y[0]=2001.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343780253, downTime=343780200, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:09.285 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=732.0, y[0]=2001.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343780253, downTime=343780200, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:09.289  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:09.293 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767817,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":2,"rect": [1438,147,1798,415],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:09.303  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:09.312  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:09.312  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:09.315 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767885,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:09.323  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:09.323  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:09.327 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364767950,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:09.332  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:09.333  1406 26607 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:09.335 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364768016,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:09.343  1406 26607 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:09.346 25924 26610 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364768086,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,295,1543,1652],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:09.346 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364769346 TS:1693364768253 diff: 392 fragment:1 codec:133 sampleRate:8000 len:320 A-Count:245
08-30 11:06:09.349 25924 26531 W AudioManager: Use of stream types is deprecated for operations other than volume control
08-30 11:06:09.349 25924 26531 W AudioManager: See the documentation of requestAudioFocus() for what to use instead with android.media.AudioAttributes to qualify your playback use case
08-30 11:06:09.351  1517  5208 I MediaFocusControl: requestAudioFocus() from uid/pid 10030/25924 clientId=android.media.AudioManager@117a91acom.thingclips.smart.ipc.camera.rnpanel.cameramanager.TRCTCameraManager$2@9c944c1 callingPack=com.tuya.smartiot req=1 flags=0x0 sdk=33
08-30 11:06:09.353 25924 26531 I ThingCameraSDK: ThingCameraSimple::SetVideoClarity Port[0] channel:0 mode:2 enter....
08-30 11:06:09.353 25924 26531 I ThingCameraSDK: ThingAVQualityMonitor::Stop Stop
08-30 11:06:09.354 25924 26531 I ThingCameraSDK: ThingAVQualityMonitor::Upload Port[0] json {"session_id":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","device_id":"6ce1f26844bfce86f3zrdp","trace_id":"","product_id":"zwlarqxkjsq","task_type":"Thing_TASK_TYPE_PREVIEW","statistics":{"width":1920,"height":2160,"frame_rate":15,"visual_fps":17.222497940063478,"average_delay":756,"profile":0,"level":150.0,"codec_mine":"video/hevc","decoder_type":"HWDecoder","decoder_name":"MediaCodec_Decoder","sample_rate":8000,"bitwidth":16,"channel":2,"average_bitrate":84.59112548828125,"average_decode_time":68,"post_process_time":4,"jitter_rate":6.179775297641754,"lost_packet_rate":0.0,"net_stutter_rate":9.516644724468686,"visual_stutter_rate":0.0,"av_unsync_rate":0.0,"p2p_connect_time_cost":391,"recv_first_packet_time":333,"recv_first_image_time":926}}
08-30 11:06:09.355 25924 26596 I ThingCameraSDK: ThingAVSyncronizer::AudioDispatchInRealTime Port[0] m_bSyncNeedExit:1 this:0x6f6d59a068,threadid:0x6fcd0fdcc0 thread exit....
08-30 11:06:09.358 25924 26597 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] this:0x6f6d59a068,threadid:0x6fccfffcc0 exit....
08-30 11:06:09.360 25924 26595 I ThingCameraSDK: ThingAVCacheManager::VideoDataDispatchRunner Port[0] VideoDataDispatchRunner(0x6fcd1fbcc0) this:0x6f6d59a3f0 exit...
08-30 11:06:09.361 25924 26594 I ThingCameraSDK: ThingAVCacheManager::AudioDataDispatchRunner Port[0] (0x6fe8af1cc0) exit...
08-30 11:06:09.362 25924 26531 W libc    : invalid pthread_t (0) passed to pthread_join
08-30 11:06:09.363 25924 26603 I OplusFeedbackInfo: [sendFeedbackInfo:L293]  send:MM_FB_EventID#21001#ClientPid#25924#ReportLevel#0#isHDRVideo#false#timeUsage#11#videoComponent#OMX.qcom.video.decoder.hevc#videoHeight#2160#videoMime#video/hevc#videoWidth#1920
08-30 11:06:09.364  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:09.364  1378  1429 D AtlasService: notify 256 to client
08-30 11:06:09.365 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Executing->Idle
08-30 11:06:09.365 25924 26531 I ThingCameraSDK: ThingAVQualityMonitor::Stop Stop
08-30 11:06:09.365 25924 26531 W libc    : invalid pthread_t (0) passed to pthread_join
08-30 11:06:09.366 25924 26531 I chatty  : uid=10030(com.tuya.smartiot) mqt_native_modu identical 2 lines
08-30 11:06:09.366 25924 26531 W libc    : invalid pthread_t (0) passed to pthread_join
08-30 11:06:09.366 25924 26531 I ThingCameraSDK: ThingPlayTask::ThingPlayTask Port[0] this:0x6f6d59a010
08-30 11:06:09.366 25924 26531 I ThingCameraSDK: ThingAVModule::SetMute Port[0] mute:1
08-30 11:06:09.368  4254  5981 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1701 android.content.ContextWrapper.startService:730 com.oplus.util.OplusStatisticsImpl.startService:216 com.oplus.util.OplusStatisticsImpl.sendDataToDCS:192 com.oplus.util.OplusStatisticsImpl.onCommonSync:84
08-30 11:06:09.372 30090 30160 I [0]DCS-StrategyManager: isNeedUpload: false, type: 2006, appID: 30384, logTag: video, eventID: 21001
08-30 11:06:09.372 30090 30160 W [0]DCS  : Record event failed. DCS reject event: [appId=30384,logTag=video,eventId=21001] . Pls check server config.
08-30 11:06:09.383 25924 26671 I ThingCameraSDK: ThingAVCacheManager::AudioDataDispatchRunner Port[0] this:0x6f6d59a3f0
08-30 11:06:09.401 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.401 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-815 identical 3 lines
08-30 11:06:09.402 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.402 25924 26673 I ThingCameraSDK: ThingAVSyncronizer::AudioDispatchRunner Port[0] m_bKeepRealTime:1
08-30 11:06:09.402 25924 26531 I ThingCameraSDK: ThingAVQualityMonitor::Start Start
08-30 11:06:09.402 25924 26531 I ThingCameraSDK: ThingCameraSimple::SetVideoClarity Port[0] mode:2 requestId:131081 cmd high:9 low:0 ...
08-30 11:06:09.403 25924 26673 I ThingCameraSDK: ThingAVSyncronizer::AudioDispatchInRealTime Port[0] m_bSyncNeedExit:0 thread
08-30 11:06:09.403 25924 26587 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 131081, high_cmd = 9, low_cmd = 0, session = 65539, thing_p2p_rtc_send_data=28[] send...
08-30 11:06:09.404 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchRunner Port[0] m_bKeepRealTime:1
08-30 11:06:09.405 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] m_bSyncNeedExit:0 thread
08-30 11:06:09.407 25924 26531 I ThingCameraSDK: ThingCameraSimple::SetVideoClarity Port[0] leave(0)...
08-30 11:06:09.408 25924 26672 I ThingCameraSDK: ThingAVCacheManager::VideoDataDispatchRunner Port[0] this:0x6f6d59a3f0
08-30 11:06:09.409 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364769402 TS:1693364768510 diff:  36 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:0
08-30 11:06:09.410 25924 26671 I ThingCameraSDK: ThingAVModule::SetupAudioParams Port[0] sampleRate:8000 channel:2
08-30 11:06:09.411 25924 26531 I ThingCameraSDK: ThingCameraBase::EnableIVA Port[0] iva:1 enter...
08-30 11:06:09.411 25924 26531 I ThingCameraSDK: ThingCameraBase::EnableIVA Port[0] leave...
08-30 11:06:09.428 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Idle->Loaded
08-30 11:06:09.428 25924 26604 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Loaded
08-30 11:06:09.428  1406  6934 I OMX-VDEC-1080P: omx_vdec::component_deinit() complete
08-30 11:06:09.431  1406  6934 I OMX-VDEC-1080P: Exit OMX vdec Destructor: fd=7
08-30 11:06:09.435 25924 26604 D ACodec  : Now uninitialized
08-30 11:06:09.437 25924 26603 D OplusACodec: ~OplusACodec [145]:
08-30 11:06:09.437 25924 26603 I ACodec  : ~ACodec()
08-30 11:06:09.445  1517  1517 D OppoBaseBatteryService: send broadcast : oppo.intent.action.BATTERY_DATA_UPDATE
08-30 11:06:09.445  1517  1517 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1158 com.android.server.OppoBaseBatteryService$2.run:280 android.os.Handler.handleCallback:938 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:263
08-30 11:06:09.473 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.481  1517 13105 V WindowManager: Changing focus from Window{2cc15e2 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity EXITING} to Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:06:09.474 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.481  1517  5208 I InputDispatcher: Focus left window: Window{2cc15e2 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:09.484 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.487  1517 13105 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:09.492 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.497  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:09.492 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-830 identical 1 line
08-30 11:06:09.493 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.507  1517  5208 I InputDispatcher: Focus entered window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:09.515  1517 13105 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:06:09.515  1517 13105 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:09.516  1517 13105 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:09.516  1517 13105 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:09.527  1517  5208 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:09.530  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:09.582  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-30 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:09.582  1517  2519 D OplusRssiMonitor: update rssi:-30
08-30 11:06:09.582  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:09.582  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:09.582  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:09.582  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-28 for "abc_ling"WPA_PSK
08-30 11:06:09.582  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:09.583  1517  2519 D WifiDataStall: L2 txTputKbps: 56100, rxTputKbps: 66000, L3 txTputKbps: 20, rxTputKbps: 1187, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:09.583  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -30, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:09.583  1517  2519 D WifiScoreCard: txRate: 28 txSpeed: 96
08-30 11:06:09.583  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -30 txSpeed 96
08-30 11:06:09.583  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:09.583  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538607585 LastRssiPoll: -30 LastTxSpeedPoll: 96
08-30 11:06:09.583  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:09.583  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:09.583  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:09.587  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:09.587  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -30 level: 4
08-30 11:06:09.588  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-30 f=2462 sc=0 link=96 tx=23.7, 4.0, 0.0  rx=161.4 bcn=9009375 [on:2941 tx:56 rx:78 period:3003] from screen [on:4928798 period:6559518] score=0
08-30 11:06:09.588  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -30
08-30 11:06:09.592  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:09.594  1517  5208 I WifiService: getConnectionInfo uid=10060
08-30 11:06:09.594  1517  5208 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:09.595 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364769595 TS:1693364768926 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:10
08-30 11:06:09.595 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.596 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-834 identical 1 line
08-30 11:06:09.596 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.606  1517  2519 D WN_S    : DT,tP=943205, dTP=6, rP=1653858, dRP=6 mIR=true, mRPLC=0
08-30 11:06:09.606  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:09.631 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.683 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-838 identical 2 lines
08-30 11:06:09.704 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.718  1003  1003 D OppoExLayer: ~Layer() sequence=16520, name=Surface(name=2cc15e2 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x2967f3a - animation-leash#0@0xb40000700e8ef000
08-30 11:06:09.718  1003  1003 D OppoExLayer: ~Layer() sequence=16515, name=2cc15e2 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000702af25000
08-30 11:06:09.719  1003  1003 D OppoExLayer: ~Layer() sequence=16518, name=com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#1@0xb40000701dd57000
08-30 11:06:09.776 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:10.004 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-846 identical 6 lines
08-30 11:06:10.004 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:10.007 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364770007 TS:1693364769309 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:20
08-30 11:06:10.036 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:10.284 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-853 identical 4 lines
08-30 11:06:10.305 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:10.311  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 63ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653861 wlan0TxPtk=943208 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:10.387 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:10.393 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364768510 size:640...
08-30 11:06:10.393 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364768574 size:640...
08-30 11:06:10.393 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364768610 size:640...
08-30 11:06:10.393 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364768636 size:640...
08-30 11:06:10.393 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364768670 size:640...
08-30 11:06:10.393 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364768732 size:640...
08-30 11:06:10.419 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:10.594 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-865 identical 3 lines
08-30 11:06:10.606 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:10.644 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364770644 TS:1693364769726 diff:  41 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:30
08-30 11:06:10.707 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:09.709  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:09.725  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:11.056  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:11.061 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-872 identical 4 lines
08-30 11:06:11.064 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:11.071  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3441300
08-30 11:06:11.071  3234  3234 D DeviceInfoHidlClient: isPowerInfoNeverSent()=true
08-30 11:06:11.071  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:11.146 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:11.331 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-876 identical 2 lines
08-30 11:06:11.331 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:11.351  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 63ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653864 wlan0TxPtk=943211 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:11.385 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:11.558 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-931 identical 53 lines
08-30 11:06:11.571 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:11.587  1517  5208 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:11.587  1517 13105 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:11.588  1517 13105 I WifiService: getConnectionInfo uid=1000
08-30 11:06:11.607  1517  2519 D WN_S    : DT,tP=943211, dTP=6, rP=1653864, dRP=6 mIR=true, mRPLC=0
08-30 11:06:11.607  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:11.612 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:11.714 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-962 identical 23 lines
08-30 11:06:11.719 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:11.719 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364770080 ,count:1200
08-30 11:06:12.040 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-1023 identical 64 lines
08-30 11:06:12.040 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:12.222 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364772221 TS:1693364770014 diff:1071 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:37
08-30 11:06:12.233 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364772232 TS:1693364770110 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:40
08-30 11:06:12.293 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364772293 TS:1693364770526 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:50
08-30 11:06:12.294 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364772294 TS:1693364770909 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:60
08-30 11:06:12.314 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364772314 TS:1693364771326 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:70
08-30 11:06:12.391  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 63ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653868 wlan0TxPtk=943215 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:12.452  1517  2586 D JobScheduler.Temperature: get temperature=36.48
08-30 11:06:12.588  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-28 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:12.588  1517  2519 D OplusRssiMonitor: update rssi:-28
08-30 11:06:12.589  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:12.589  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:12.589  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:12.589  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-27 for "abc_ling"WPA_PSK
08-30 11:06:12.589  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:12.590  1517  2519 D WifiDataStall: L2 txTputKbps: 62700, rxTputKbps: 66000, L3 txTputKbps: 16, rxTputKbps: 1363, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:12.590  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -27, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:12.590  1517  2519 D WifiScoreCard: txRate: 25 txSpeed: 96
08-30 11:06:12.590  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -27 txSpeed 96
08-30 11:06:12.590  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:12.590  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538610592 LastRssiPoll: -27 LastTxSpeedPoll: 96
08-30 11:06:12.590  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:12.590  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:12.590  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:12.592  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -27 level: 4
08-30 11:06:12.593  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -27
08-30 11:06:12.593  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:12.594  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:12.596  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-27 f=2462 sc=0 link=96 tx=22.6, 2.3, 0.0  rx=208.5 bcn=9009405 [on:2935 tx:51 rx:69 period:3007] from screen [on:4931733 period:6562526] score=0
08-30 11:06:12.599  1517 13105 I WifiService: getConnectionInfo uid=10060
08-30 11:06:12.599  1517 13105 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:12.674 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364772201,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":25424} ...
08-30 11:06:13.193 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:13.199 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-1077 identical 46 lines
08-30 11:06:13.199 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:13.307 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364772834,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":15395,"channels":[[0,264,152,216,152,2424,476,402,393,475,392,470],[1,0,1183111,0,1183111,4752,2386836,623,-1,517,393,517],[2,0,119600,0,119600,3212,330336,1093,-1,994,393,990],[330,3216,0,-240,0,285048,0,390,159,-1,-1,-1]]} ...
08-30 11:06:13.431  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 61ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653870 wlan0TxPtk=943218 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:13.485 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364773485 TS:1693364771454 diff:1171 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:73
08-30 11:06:13.485 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364773485 TS:1693364771709 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:80
08-30 11:06:13.486 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364773486 TS:1693364772124 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:90
08-30 11:06:13.486 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364773486 TS:1693364772509 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:100
08-30 11:06:13.609  1517  2519 D WN_S    : DT,tP=943218, dTP=7, rP=1653870, dRP=6 mIR=true, mRPLC=0
08-30 11:06:13.609  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:13.783  3304  3304 E OplusNecManagerHelper: com.oplus.nec.OplusNecManager.notifyOrigSignalStrengthChanged [class android.telephony.SignalStrength, int]
08-30 11:06:13.787  1517  1517 D OplusSlaManager_RSRP: onSignalStrengthsChanged oldRsrp=0 newRsrp=-105
08-30 11:06:13.884  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:06:13.885  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=141,badLossCount=0,txLoss=0,mLinkDetectTimes= 604,mIndex =0
08-30 11:06:13.885  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 61, 0, 0, 0, 0, 676, 63, 0, 0, 0, 0, 676, 63, 0, 0, 0, 0, 676, 63, 0, 0, 0, 0, 676, 53, 0, 0, 0, 0]
08-30 11:06:13.885  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:06:13.885  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:06:13.885  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:06:13.886  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:06:13.886  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-27,mIndex =0,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12577339258
08-30 11:06:13.886  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:06:13.887  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:06:13.887  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:06:13.887  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:06:13.887  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:06:13.887  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:06:13.887  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:06:14.079 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:14.080 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-1090 identical 6 lines
08-30 11:06:14.080 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:14.095 30404 30452 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:06:14.095 30404 30452 D HoraeHelper: Thermal length:1
08-30 11:06:14.101 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:14.108 25924 26592 I chatty  : uid=10030(com.tuya.smartiot) Thread-1114 identical 22 lines
08-30 11:06:14.108 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:2 received:1, !!!
08-30 11:06:14.184 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364774184 TS:1693364772735 diff: 698 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:105
08-30 11:06:14.193 30404 30448 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:06:14.255 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364774255 TS:1693364772926 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:110
08-30 11:06:14.266 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364774266 TS:1693364773309 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:120
08-30 11:06:14.266 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364774266 TS:1693364773725 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:130
08-30 11:06:14.267 25924 26588 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:131081 high_cmd:9 low_cmd:0 received...
08-30 11:06:14.267 25924 26588 I ThingCameraSDK: ThingNetRequestCommand::onResponse Port[0] this:0x6fe1713510 nRequestId:131081...
08-30 11:06:14.268 25924 26588 I ThingCameraSDK: ThingVideoClarityCallBack::onResponse Port[0] response requestId:131081 highcmd:9 lowcmd:0
08-30 11:06:14.271 25924 26588 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:131081 highCmd:9 lowCmd:0
08-30 11:06:14.305 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:768 h:864 fr:15 profile:100 level:4.000000
08-30 11:06:14.306 25924 26592 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364774305,"m":"camera","did":"","status":"first full frame recved.","tid":"no traceId"} ...
08-30 11:06:14.306 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364774306 TS:1693364772145 diff:4940 fragment:2 cache: 1 size:768x864 codec:18 len:29744 V-Count:0 IFrame:1....
08-30 11:06:14.306 25924 26672 I ThingCameraSDK: ThingAVModule::SetupVideoParams Port[0] frame_rate:15 width:768 height:864
08-30 11:06:14.306 25924 26672 I ThingCameraSDK: ThingAVModule::OnCacheVideoPacketRecved Port[0] the video parameters changed, video decoder will reset!!!
08-30 11:06:14.307 25924 26672 I ThingVideoDecodeSDK: [VideoCodecSDK Version:1.3.5]
08-30 11:06:14.307 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecDecoder::TravellMobileProductInfo travell the mobile product information(model = PCKM00,
08-30 11:06:14.307 25924 26672 I ThingVideoDecodeSDK: name = PCKM00, brand = OPPO,device = OP4A57, hardware = qcom, version = 11, sdkVersion = 30)
08-30 11:06:14.309 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniH264Decoder::InitH264Decoder w:768 h:864
08-30 11:06:14.312 25924 26672 E Parcel  : Reading a NULL string not supported here.
08-30 11:06:14.313 25924 26672 D ACodec  : ACodec() ro.oplus.audio.effect.type = dolby ro.oplus.audio.dolby.type = v351
08-30 11:06:14.314 25924 26672 I ACodec  : new ACodec()
08-30 11:06:14.314 25924 26672 D ACodec  : Now uninitialized
08-30 11:06:14.314 25924 26672 D OplusACodec: OplusACodec [131]:
08-30 11:06:14.314 25924 26672 D OplusACodec: getBufferChannel: New
08-30 11:06:14.317 25924 26680 I OMXClient: IOmx service obtained
08-30 11:06:14.317 25924 26680 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:06:14.318   915   975 D audio_hw_primary: adev_set_parameters: enter: HQV_wl_pid=25924
08-30 11:06:14.318   915   975 D audio_hw_hfp: hfp_set_parameters: enter
08-30 11:06:14.318   915   975 D audio_hw_primary: adev_set_parameters: set dual headphone enable: 0x0
08-30 11:06:14.318   915   975 D audio_hw_extn: audio_extn_fm_set_parameters: Enter
08-30 11:06:14.318   915   975 D audio_hw_primary: adev_set_parameters: exit with code(0)
08-30 11:06:14.320  1406  6934 I OMXMaster: makeComponentInstance(OMX.qcom.video.decoder.avc) in android.hardwar process
08-30 11:06:14.325  1406  6934 E android.hardware.media.omx@1.0-service: Service not available yet
08-30 11:06:14.329  1406  6934 D PlatformConfig: getInstance: Enter
08-30 11:06:14.329  1406  6934 D PlatformConfig: getInt32 Config name: vidc_dec_log_in value: 0
08-30 11:06:14.329  1406  6934 D PlatformConfig: getInt32 Config name: vidc_dec_log_out value: 0
08-30 11:06:14.329  1406  6934 D PlatformConfig: getInt32 Config name: vidc_dec_sec_prefetch_size_internal value: 31457280
08-30 11:06:14.329  1406  6934 D PlatformConfig: getInt32 Config name: vidc_dec_sec_prefetch_size_output value: 3276800
08-30 11:06:14.329  1406  6934 D PlatformConfig: getInt32 Config name: vidc_dec_arb_mode_override value: 7
08-30 11:06:14.329  1406  6934 D PlatformConfig: getInt32: Returning default
08-30 11:06:14.330  1406  6934 I OMX-VDEC-1080P: component_init: OMX.qcom.video.decoder.avc : fd=7
08-30 11:06:14.330  1406  6934 E OMX-VDEC-1080P: Unsupported output color format for c2d (2141391876)
08-30 11:06:14.330  1406  6934 E OMX-VDEC-1080P: Setting color format failed
08-30 11:06:14.336 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364774336 TS:1693364772807 diff:   0 fragment:2 cache:11 size:768x864 codec:18 len:300 V-Count:10 IFrame:0....
08-30 11:06:14.337 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364772943 ,count:1400
08-30 11:06:14.337 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364774337 TS:1693364773478 diff:   0 fragment:2 cache:21 size:768x864 codec:18 len:313 V-Count:20 IFrame:0....
08-30 11:06:14.337  1406  6934 D PlatformConfig: getInstance: Enter
08-30 11:06:14.337 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364774337 TS:1693364774145 diff:   0 fragment:2 cache:31 size:768x864 codec:18 len:316 V-Count:30 IFrame:0....
08-30 11:06:14.337  1406  6934 D PlatformConfig: getInt32: Returning default
08-30 11:06:14.338  1406  6934 I OMX-VDEC-1080P: omx_vdec::component_init() success : fd=7
08-30 11:06:14.338 25924 26680 I ACodec  : Successfully allocate component [OMX.qcom.video.decoder.avc]
08-30 11:06:14.338 25924 26680 D ACodec  : AllocateComponent OMX.qcom.video.decoder.avc success
08-30 11:06:14.339 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Now Loaded
08-30 11:06:14.339 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364774339 TS:1693364774110 diff:   0 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:140
08-30 11:06:14.341 25924 26680 D OplusACodec: [configureCodec:L947] OplusFeedbackInfo  mFeedbackID:481238327296
08-30 11:06:14.341 25924 26680 D IAtlas  : IAtlas::init CallingPid 25924
08-30 11:06:14.342 25924 26680 D IAtlas  : IAtlas::init this 0x6faa2a3820
08-30 11:06:14.342  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:14.342  1378  1429 D AtlasService: notify 1025 to client
08-30 11:06:14.344  1406  6934 E OMX-VDEC-1080P: Extension: OMX.google.android.index.storeANWBufferInMetadata not implemented
08-30 11:06:14.344  1406  6934 E OMX-VDEC-1080P: Extension: OMX.google.android.index.configureVideoTunnelMode not implemented
08-30 11:06:14.344  1406  6934 E OMX-VDEC-1080P: Extension: OMX.google.android.index.useAndroidNativeBuffer is supported
08-30 11:06:14.344  1406  6934 E OMX-VDEC-1080P: get_parameter: unknown param 7f000046
08-30 11:06:14.344  1406  6934 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.avc, ??(0x7f000046)) ERROR: UnsupportedIndex(0x8000101a)
08-30 11:06:14.344 25924 26680 I ACodec  : configureCodec() mime = video/avc
08-30 11:06:14.344 25924 26680 D OplusUtils: ACodec getComponentRole [92]: mime:video/avc
08-30 11:06:14.344 25924 26680 I ExtendedACodec: setupVideoDecoder()
08-30 11:06:14.345 25924 26680 E OplusACodec: [GetVideoCodingTypeFromMime:L726] mime:video/avc
08-30 11:06:14.347  1406  4204 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.avc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:06:14.347  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.333  1406  1406 W HwBinder:1406_F: type=1400 audit(0.0:162980): avc: denied { read } for name="adreno_config.txt" dev="sda10" ino=4849726 scontext=u:r:mediacodec:s0 tcontext=u:object_r:gpudump_config_file:s0 tclass=file permissive=0
08-30 11:06:14.349  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.350  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.351 25924 26680 I ExtendedACodec: Decoder will be in frame by frame mode
08-30 11:06:14.353 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] input format is AMessage(what = 0x00000000) = {
08-30 11:06:14.353 25924 26680 D ACodec  :   int32_t adaptive-playback = 0
08-30 11:06:14.353 25924 26680 D ACodec  :   int32_t roi-on = 0
08-30 11:06:14.353 25924 26680 D ACodec  :   string mime = "video/avc"
08-30 11:06:14.353 25924 26680 D ACodec  :   int32_t width = 768
08-30 11:06:14.353 25924 26680 D ACodec  :   int32_t height = 864
08-30 11:06:14.353 25924 26680 D ACodec  : }
08-30 11:06:14.354  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.354  1406  6934 I chatty  : uid=1046(mediacodec) HwBinder:1406_D identical 1 line
08-30 11:06:14.354  1406  7010 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.avc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:06:14.355 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] output format is AMessage(what = 0x00000000) = {
08-30 11:06:14.355 25924 26680 D ACodec  :   int32_t roi-on = 0
08-30 11:06:14.355 25924 26680 D ACodec  :   string mime = "video/raw"
08-30 11:06:14.355 25924 26680 D ACodec  :   int32_t stride = 768
08-30 11:06:14.355 25924 26680 D ACodec  :   int32_t slice-height = 864
08-30 11:06:14.355 25924 26680 D ACodec  :   int32_t color-format = 21
08-30 11:06:14.355 25924 26680 D ACodec  :   Buffer *image-data = 0x6ffcfef140
08-30 11:06:14.355 25924 26680 D ACodec  :   Rect crop(0, 0, 767, 863)
08-30 11:06:14.355 25924 26680 D ACodec  :   Buffer hdr-static-info = {
08-30 11:06:14.355 25924 26680 D ACodec  :     00000000:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
08-30 11:06:14.355 25924 26680 D ACodec  :     00000010:  00 00 00 00 00 00 00 00  00                       .........
08-30 11:06:14.355 25924 26680 D ACodec  :   }
08-30 11:06:14.355 25924 26680 D ACodec  :   int32_t width = 768
08-30 11:06:14.355 25924 26680 D ACodec  :   int32_t height = 864
08-30 11:06:14.356 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Now Loaded->Idle
08-30 11:06:14.356 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Allocating 6 buffers of size 8847360 (from 8847360 using PresetByteBuffer) on input port
08-30 11:06:14.370  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.370 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Allocating 14 buffers of size 995328 (from 995328 using PresetByteBuffer) on output port
08-30 11:06:14.380 25924 26591 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadAudioStream Port[0] audio rtp package recved ,count:400
08-30 11:06:14.383  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.384  1373  3005 W ResourceManagerService: Ignoring request to add new resource entry with value <= 0
08-30 11:06:14.384 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Now Idle->Executing
08-30 11:06:14.387 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Now Executing
08-30 11:06:14.388 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364774388 TS:1693364772145 cache buffer:0 w:768 h:864  count:0 .....
08-30 11:06:14.395  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.395  1406 19786 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.396  1406 19786 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.396  1406  6934 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.avc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:06:14.397 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] output format is AMessage(what = 0x00000000) = {
08-30 11:06:14.397 25924 26680 D ACodec  :   int32_t roi-on = 0
08-30 11:06:14.397 25924 26680 D ACodec  :   string mime = "video/raw"
08-30 11:06:14.397 25924 26680 D ACodec  :   int32_t stride = 768
08-30 11:06:14.397 25924 26680 D ACodec  :   int32_t slice-height = 864
08-30 11:06:14.397 25924 26680 D ACodec  :   int32_t color-format = 21
08-30 11:06:14.397 25924 26680 D ACodec  :   Buffer *image-data = 0x6f89aa0b40
08-30 11:06:14.397 25924 26680 D ACodec  :   Rect crop(0, 0, 767, 863)
08-30 11:06:14.397 25924 26680 D ACodec  :   Buffer hdr-static-info = {
08-30 11:06:14.397 25924 26680 D ACodec  :     00000000:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
08-30 11:06:14.397 25924 26680 D ACodec  :     00000010:  00 00 00 00 00 00 00 00  00                       .........
08-30 11:06:14.397 25924 26680 D ACodec  :   }
08-30 11:06:14.397 25924 26680 D ACodec  :   int32_t width = 768
08-30 11:06:14.397 25924 26680 D ACodec  :   int32_t height = 864
08-30 11:06:14.418  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.418 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Allocating 20 buffers of size 995328 (from 995328 using PresetByteBuffer) on output port
08-30 11:06:14.433  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.437 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Now Executing
08-30 11:06:14.444 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364774444 TS:1693364772807 cache buffer:10 w:768 h:864  count:10 .....
08-30 11:06:14.452 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364774452 TS:1693364774526 diff:  21 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:150
08-30 11:06:14.461  1406 26681 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.461  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.466  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.466  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.466  1406 19786 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.466  1406  4204 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(768X864) dest(768X864)
08-30 11:06:14.467  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.468  1406 19786 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.avc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:06:14.469  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.469  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.470 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] output format is AMessage(what = 0x00000000) = {
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t roi-on = 0
08-30 11:06:14.470 25924 26680 D ACodec  :   string mime = "video/raw"
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t stride = 768
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t slice-height = 864
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t color-format = 21
08-30 11:06:14.470 25924 26680 D ACodec  :   Buffer *image-data = 0x6f6da35440
08-30 11:06:14.470 25924 26680 D ACodec  :   Rect crop(0, 0, 767, 863)
08-30 11:06:14.470 25924 26680 D ACodec  :   Buffer hdr-static-info = {
08-30 11:06:14.470 25924 26680 D ACodec  :     00000000:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
08-30 11:06:14.470 25924 26680 D ACodec  :     00000010:  00 00 00 00 00 00 00 00  00                       .........
08-30 11:06:14.470 25924 26680 D ACodec  :   }
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t width = 768
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t height = 864
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t color-range = 1
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t color-standard = 1
08-30 11:06:14.470 25924 26680 D ACodec  :   int32_t color-transfer = 3
08-30 11:06:14.472  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 61ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653879 wlan0TxPtk=943226 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:14.472  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.472  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.474 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364774474 cache len:19 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:0....
08-30 11:06:14.474 25924 26688 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364774474,"m":"camera","did":"6ce1f26844bfce86f3zrdp","status":"first frame decoded.","tid":"no traceId"} ...
08-30 11:06:14.474 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364771685,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.474 25924 26688 I ThingCameraSDK: VideoConvert::CreateFrame w:768 h:864 type:1...
08-30 11:06:14.474  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.475  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.477 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364774477 TS:1693364772145 width:768 height:864 size:1 count:0.
08-30 11:06:14.477 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364774477 TS:1693364772145 interTimems:0 size:1 cache:0 speed:1.000000 count:0 ....
08-30 11:06:14.478 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364772145 ts:1693364772 progress:-1 count:173...
08-30 11:06:14.479  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.479  1406  6934 E OMX-VDEC-1080P: Extension: OMX.QTI.index.config.video.getdsmode not implemented
08-30 11:06:14.479  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.481  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.485 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364774485 TS:1693364773478 cache buffer:19 w:768 h:864  count:20 .....
08-30 11:06:14.485  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.486 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364771752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.488  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.488  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.491 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364771817,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.492  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.494 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364771887,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.495 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364772124 size:640...
08-30 11:06:14.496 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364772161 size:640...
08-30 11:06:14.497 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364772192 size:640...
08-30 11:06:14.497 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364772253 size:640...
08-30 11:06:14.498 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364771952,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.499 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364772288 size:640...
08-30 11:06:14.500  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.502 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772017,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.502  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.502  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.502 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364772318 size:640...
08-30 11:06:14.503 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364772350 size:640...
08-30 11:06:14.504  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.505  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.506 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772087,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.507  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.507  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.509  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.510  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.510 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772152,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.512  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.513  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.515  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.515 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772217,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.518 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.522 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364774522 cache len:17 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:10....
08-30 11:06:14.522 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.524 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364774524 TS:1693364772807 width:768 height:864 size:10 count:10.
08-30 11:06:14.525  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.525 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364774525 TS:1693364774145 cache buffer:19 w:768 h:864  count:30 .....
08-30 11:06:14.526 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772414,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.527  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.528  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.530 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772486,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.530  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.530  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.532  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.533  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.535  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.536 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772550,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.538  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.540 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772618,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.541  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.541  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.544 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772688,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.544  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.544  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.547  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.547  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.550 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.552  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.553  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.554 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772820,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.555  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.556  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.557 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772885,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.557  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.561  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.561 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364772951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.563  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.563  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.565 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364774565 cache len:17 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:20....
08-30 11:06:14.565 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773017,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.566  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.566 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364774566 TS:1693364773478 width:768 height:864 size:16 count:20.
08-30 11:06:14.568 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773085,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.572 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773152,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.574 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773217,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.577 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773288,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.580 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.595  1517 13105 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:14.597  1517 13105 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:14.597  1517  5208 I WifiService: getConnectionInfo uid=1000
08-30 11:06:14.609 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364774609 TS:1693364772807 interTimems:6 size:16 cache:997 speed:0.100000 count:10 ....
08-30 11:06:14.617  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.619  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.620 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773417,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.629 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364773011 ts:1693364773 progress:-1 count:186...
08-30 11:06:14.688  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.690  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.693 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773486,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,398,982,1073],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.764 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364774764 TS:1693364773478 interTimems:34 size:8 cache:466 speed:0.500000 count:20 ....
08-30 11:06:14.806 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:768 h:864 fr:15 profile:100 level:4.000000
08-30 11:06:14.807 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364774807 TS:1693364774810 diff: 122 fragment:2 cache: 1 size:768x864 codec:18 len:29842 V-Count:40 IFrame:1....
08-30 11:06:14.810 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364774810 TS:1693364774810 cache buffer:12 w:768 h:864  count:40 .....
08-30 11:06:14.813 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364773534 size:640...
08-30 11:06:14.814 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364773570 size:640...
08-30 11:06:14.814 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364773599 size:640...
08-30 11:06:14.815 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364773630 size:640...
08-30 11:06:14.816 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364773694 size:640...
08-30 11:06:14.816 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364773725 size:640...
08-30 11:06:14.816 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364773758 size:640...
08-30 11:06:14.821  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.823  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.823  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.825 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773551,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,398,982,1073],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.826  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.826  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.828  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.828  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.830 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773616,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,398,982,1073],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.830  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.830  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.832  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.832  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.834  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.835  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.835 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364774835 cache len:11 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:30....
08-30 11:06:14.835 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773688,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,398,982,1073],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.837 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364774837 TS:1693364774145 width:768 height:864 size:7 count:30.
08-30 11:06:14.837  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.837  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.838 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,398,982,1073],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.839  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.839  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.843 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773818,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.843  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.843  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.845  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.846  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.846 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773887,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.848  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.848  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:14.849 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364773952,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.850 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364774849 TS:1693364774910 diff:  30 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:160
08-30 11:06:14.850  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:14.853 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774017,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.855 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774086,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.858 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774152,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.860 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774216,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.862 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:14.909 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364774009 ts:1693364774 progress:-1 count:201...
08-30 11:06:14.944 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364774944 TS:1693364774145 interTimems:16 size:10 cache:600 speed:0.250000 count:30 ....
08-30 11:06:15.260  4289  4304 E horae   : 0: back:36622,frame:36622,front:36622, 5, +(0), 1 ,36622
08-30 11:06:15.265 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364775265 TS:1693364775326 diff:  20 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:170
08-30 11:06:15.353 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 70.550117 kbps packet cache:0, frame cache:378
08-30 11:06:15.387 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 54 fps, mOutputBufCnt = 40 fps, mRenderFrameCnt = 0 fps
08-30 11:06:15.414 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364775414 TS:1693364775478 diff:  61 fragment:2 cache: 1 size:768x864 codec:18 len:298 V-Count:50 IFrame:0....
08-30 11:06:15.414 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364775414 TS:1693364775478 cache buffer:10 w:768 h:864  count:50 .....
08-30 11:06:15.512  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653883 wlan0TxPtk=943230 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:15.539  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:15.544  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:15.545 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364775545 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:40....
08-30 11:06:15.545 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:15.547 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364775547 TS:1693364774810 width:768 height:864 size:1 count:40.
08-30 11:06:15.548 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364775548 TS:1693364774810 interTimems:-200 size:1 cache:0 speed:2.000000 count:40 ....
08-30 11:06:15.595  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-30 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:15.595  1517  2519 D OplusRssiMonitor: update rssi:-30
08-30 11:06:15.595  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:15.595  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:15.595  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:15.596  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-26 for "abc_ling"WPA_PSK
08-30 11:06:15.596  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:15.596  1517  2519 D WifiDataStall: L2 txTputKbps: 55440, rxTputKbps: 66000, L3 txTputKbps: 21, rxTputKbps: 2066, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:15.596  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -26, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:15.596  1517  2519 D WifiScoreCard: txRate: 30 txSpeed: 96
08-30 11:06:15.596  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -26 txSpeed 96
08-30 11:06:15.596  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:15.596  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538613597 LastRssiPoll: -26 LastTxSpeedPoll: 96
08-30 11:06:15.596  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:15.596  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:15.596  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:15.600  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -26
08-30 11:06:15.600  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:15.600  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:15.603  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -26 level: 4
08-30 11:06:15.604  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-26 f=2462 sc=0 link=96 tx=25.1, 4.2, 0.0  rx=314.7 bcn=9009434 [on:2935 tx:61 rx:135 period:3007] from screen [on:4934668 period:6565534] score=0
08-30 11:06:15.604  1517  5208 I WifiService: getConnectionInfo uid=10060
08-30 11:06:15.604  1517  5208 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:15.608  1517  2519 D WN_S    : DT,tP=943230, dTP=12, rP=1653883, dRP=13 mIR=true, mRPLC=0
08-30 11:06:15.608  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:15.620  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:15.622  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:15.623 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774417,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:15.659 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364775659 TS:1693364775709 diff:  41 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:180
08-30 11:06:15.692  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:15.694  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:15.695 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774487,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:15.752  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:15.754  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:15.755 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774550,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:15.769 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364775010 ts:1693364775 progress:-1 count:216...
08-30 11:06:15.816  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:15.818  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:15.819 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774617,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:15.887  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:15.889  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:15.891 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774685,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:15.927 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=980.0, y[0]=2152.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343786895, downTime=343786895, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:15.927 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=980.0, y[0]=2152.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343786895, downTime=343786895, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:15.928 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=980.0, y[0]=2152.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343786895, downTime=343786895, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:15.958  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:15.960  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:15.963 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [787,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.010  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.012  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.013 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774817,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.018 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=980.0, y[0]=2152.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343786986, downTime=343786895, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:16.019 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=980.0, y[0]=2152.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343786986, downTime=343786895, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:16.021  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:16.029  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3442500
08-30 11:06:16.029  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:16.058 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364776058 TS:1693364776126 diff:  20 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:190
08-30 11:06:16.059 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364775134 size:640...
08-30 11:06:16.059 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364775166 size:640...
08-30 11:06:16.059 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364775199 size:640...
08-30 11:06:16.059 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364775230 size:640...
08-30 11:06:16.059 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364775293 size:640...
08-30 11:06:16.059 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364775326 size:640...
08-30 11:06:16.060 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364775360 size:640...
08-30 11:06:16.099 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364776099 TS:1693364776144 diff:  93 fragment:2 cache: 1 size:768x864 codec:18 len:317 V-Count:60 IFrame:0....
08-30 11:06:16.099 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364776099 TS:1693364776144 cache buffer:12 w:768 h:864  count:60 .....
08-30 11:06:16.107  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.110  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.112 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774884,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.150 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:06:16.150 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:06:16.152 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:06:16.152 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:06:16.156  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.160  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.161 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364774951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.167 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:06:16.167 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:06:16.201 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:06:16.201 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:06:16.216  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.220  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.223 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364776223 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:50....
08-30 11:06:16.223 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775018,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.224 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364776224 TS:1693364775478 width:768 height:864 size:2 count:50.
08-30 11:06:16.287  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.289  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.290 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775085,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.341  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.345  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.348 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775156,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.361 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364776361 TS:1693364775478 interTimems:15 size:2 cache:129 speed:1.500000 count:50 ....
08-30 11:06:16.387 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 15 fps, mOutputBufCnt = 13 fps, mRenderFrameCnt = 0 fps
08-30 11:06:16.408 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 5.057761 kbps packet cache:0, frame cache:397
08-30 11:06:16.415  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.419  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.420 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775216,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.434 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364776434 TS:1693364776509 diff:  10 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:200
08-30 11:06:16.472  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.473  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.474 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.551  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653887 wlan0TxPtk=943234 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:16.553  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.559  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.561 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.614  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.616  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.617 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775418,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.704  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.706  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.708 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775486,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.751 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364776751 TS:1693364776811 diff:  50 fragment:2 cache: 1 size:768x864 codec:18 len:300 V-Count:70 IFrame:0....
08-30 11:06:16.752 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364776752 TS:1693364776811 cache buffer:12 w:768 h:864  count:70 .....
08-30 11:06:16.756  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.758  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.759 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775551,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.816  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.818  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.819 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775617,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.860 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364776860 TS:1693364776926 diff:  31 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:210
08-30 11:06:16.896  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.898  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.899 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364776899 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:60....
08-30 11:06:16.899 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775686,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.900 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364776900 TS:1693364776144 width:768 height:864 size:3 count:60.
08-30 11:06:16.957  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:16.959  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:16.960 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:16.990 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364776010 ts:1693364776 progress:-1 count:231...
08-30 11:06:17.027  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.029  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.030 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775818,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.078  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.080  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.082 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775884,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.124 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364777124 TS:1693364776144 interTimems:65 size:3 cache:199 speed:1.000000 count:60 ....
08-30 11:06:17.158  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.160  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.161 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364775951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.229  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.231  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.233 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776017,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.238 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364776188 size:640...
08-30 11:06:17.239 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364776254 size:640...
08-30 11:06:17.239 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364776285 size:640...
08-30 11:06:17.239 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364776316 size:640...
08-30 11:06:17.239 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364776348 size:640...
08-30 11:06:17.239 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364776414 size:640...
08-30 11:06:17.245 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364777245 TS:1693364777309 diff:  10 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:220
08-30 11:06:17.290  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.291  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.293 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776086,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.361  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.363  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.364 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776152,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.387 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 15 fps, mOutputBufCnt = 15 fps, mRenderFrameCnt = 0 fps
08-30 11:06:17.540 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:768 h:864 fr:15 profile:100 level:4.000000
08-30 11:06:17.540 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 29.458199 kbps packet cache:0, frame cache:423
08-30 11:06:17.540 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364777540 TS:1693364777478 diff: 183 fragment:2 cache: 1 size:768x864 codec:18 len:29752 V-Count:80 IFrame:1....
08-30 11:06:17.541 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364777541 TS:1693364777478 cache buffer:12 w:768 h:864  count:80 .....
08-30 11:06:17.546  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.553  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.553  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.555  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.555  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.555 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776216,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.558  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.558  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.560  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.560  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.562  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.563  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.564 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.565  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.566  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.567 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364777567 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:70....
08-30 11:06:17.568  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.568  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.567 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776351,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.570  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.571  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.574  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.574  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.574 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364777574 TS:1693364776811 width:768 height:864 size:3 count:70.
08-30 11:06:17.576 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776418,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.577  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.578  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.579 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776486,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.580  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.581 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=880.0, y[0]=988.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343788548, downTime=343788548, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:17.581 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=880.0, y[0]=988.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343788548, downTime=343788548, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:17.581  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:17.582 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=880.0, y[0]=988.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343788548, downTime=343788548, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:17.584  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:17.584 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776550,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.587 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776617,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.591 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776686,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.591  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653891 wlan0TxPtk=943239 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:17.594 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.598 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776820,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.600  1517  5086 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:17.601  1517 13105 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:17.601 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776888,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.602  1517 13105 I WifiService: getConnectionInfo uid=1000
08-30 11:06:17.604 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364776952,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:17.610  1517  2519 D WN_S    : DT,tP=943239, dTP=9, rP=1653891, dRP=8 mIR=true, mRPLC=0
08-30 11:06:17.611  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:17.635   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:17.635   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:17.635   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:17.635   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:17.635   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:17.636  1517  1517 D OppoBaseBatteryService: send broadcast : oppo.intent.action.BATTERY_DATA_UPDATE
08-30 11:06:17.637   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:17.637   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:17.637   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:17.637   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:17.637   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:17.637   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:17.637   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:17.637  1517  1517 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1158 com.android.server.OppoBaseBatteryService$2.run:280 android.os.Handler.handleCallback:938 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:263
08-30 11:06:17.637   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:17.638   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:17.638   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:17.647  1517  2515 I WifiService: getConnectionInfo uid=1000
08-30 11:06:17.655 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364777654 TS:1693364777725 diff:  20 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:230
08-30 11:06:17.656   929   929 D ORMS_HAL: OrmsHalService write file /proc/sys/kernel/slide_boost_enabled - 1.
08-30 11:06:17.658   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:17.658   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:17.658   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:17.658   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:17.658   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:17.658   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:17.678 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364777205,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":30428} ...
08-30 11:06:17.683 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364777744 ,count:1600
08-30 11:06:17.705 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364777705 TS:1693364776811 interTimems:16 size:10 cache:597 speed:0.250000 count:70 ....
08-30 11:06:17.789 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364777010 ts:1693364777 progress:-1 count:246...
08-30 11:06:17.876 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=997.1574, y[0]=705.6852, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343788844, downTime=343788548, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:17.877  1517  2599 E ORMS_CORE: Unsupported action!!!
08-30 11:06:17.877   929   929 D ORMS_HAL: OrmsHalService write file /proc/sys/kernel/slide_boost_enabled - 0.
08-30 11:06:17.877   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:17.877   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:17.877   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:17.877   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:17.877   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:17.878   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:17.878   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:17.878   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:17.878   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:17.878   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:17.878   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:17.878   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:17.879   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:17.879   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:17.879   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:17.879 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=997.1574, y[0]=705.6852, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343788844, downTime=343788548, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:17.879   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:17.879   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:17.880   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:17.880   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:17.880   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:17.880   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:17.880   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:17.880   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:18.051 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364778051 TS:1693364778110 diff:  30 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:240
08-30 11:06:18.081 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364778081 TS:1693364778141 diff:  61 fragment:2 cache: 1 size:768x864 codec:18 len:299 V-Count:90 IFrame:0....
08-30 11:06:18.082 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364778082 TS:1693364778141 cache buffer:10 w:768 h:864  count:90 .....
08-30 11:06:18.236  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.238  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.239 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364778239 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:80....
08-30 11:06:18.239 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777017,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.240 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364778240 TS:1693364777478 width:768 height:864 size:1 count:80.
08-30 11:06:18.240 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364778240 TS:1693364777478 interTimems:-4 size:1 cache:0 speed:2.000000 count:80 ....
08-30 11:06:18.297  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.299  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.300 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777086,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.309 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364777836,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":20397,"channels":[[0,264,180,264,180,2928,656,402,393,475,392,470],[1,0,1331304,0,1331304,6336,2843404,623,-1,517,393,517],[2,0,183632,0,183632,4576,514152,1093,-1,994,393,990],[330,3216,0,-240,0,377496,0,390,159,-1,-1,-1]]} ...
08-30 11:06:18.358  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.360  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.361 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777152,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.388 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 16 fps, mOutputBufCnt = 15 fps, mRenderFrameCnt = 0 fps
08-30 11:06:18.419  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.421  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.422 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777217,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.467 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364778467 TS:1693364778525 diff:  40 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:250
08-30 11:06:18.490  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.492  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.493 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.557 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 5.565542 kbps packet cache:0, frame cache:492
08-30 11:06:18.561  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.564  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.566 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.601  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-30 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:18.601  1517  2519 D OplusRssiMonitor: update rssi:-30
08-30 11:06:18.603  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:18.603  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:18.603  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:18.604  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-27 for "abc_ling"WPA_PSK
08-30 11:06:18.605  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:18.605  1517  2519 D WifiDataStall: L2 txTputKbps: 58740, rxTputKbps: 66000, L3 txTputKbps: 17, rxTputKbps: 265, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:18.606  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -28, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:18.606  1517  2519 D WifiScoreCard: txRate: 28 txSpeed: 96
08-30 11:06:18.606  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -28 txSpeed 96
08-30 11:06:18.606  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:18.606  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538616607 LastRssiPoll: -28 LastTxSpeedPoll: 96
08-30 11:06:18.606  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:18.606  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:18.606  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:18.608 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=542.0, y[0]=1949.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343789576, downTime=343789576, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:18.609 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=542.0, y[0]=1949.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343789576, downTime=343789576, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:18.609 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=542.0, y[0]=1949.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343789576, downTime=343789576, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:18.609  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -28 level: 4
08-30 11:06:18.610  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -28
08-30 11:06:18.611  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-28 f=2462 sc=0 link=96 tx=24.4, 3.4, 0.0  rx=162.0 bcn=9009463 [on:2936 tx:51 rx:62 period:3005] from screen [on:4937604 period:6568540] score=0
08-30 11:06:18.611  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:18.613  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:18.613  1517 13105 I WifiService: getConnectionInfo uid=10060
08-30 11:06:18.613  1517 13105 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:18.616  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.618  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.619 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777418,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.622 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364777694 size:640...
08-30 11:06:18.623 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364777725 size:640...
08-30 11:06:18.624   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:18.624   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:18.624   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:18.625   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:18.625   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:18.625 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364777758 size:640...
08-30 11:06:18.625 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364777790 size:640...
08-30 11:06:18.626 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364777853 size:640...
08-30 11:06:18.626   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:18.626 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364777888 size:640...
08-30 11:06:18.626   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:18.626   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:18.626   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:18.626   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:18.626   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:18.626 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364777916 size:640...
08-30 11:06:18.626   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:18.627   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:18.627   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:18.627   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:18.627   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:18.627   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:18.631  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653901 wlan0TxPtk=943247 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:18.637   929   929 D ORMS_HAL: OrmsHalService write file /proc/sys/kernel/slide_boost_enabled - 1.
08-30 11:06:18.640   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:18.640   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:18.640   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:18.640   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:18.640   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:18.640   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:18.687  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.690  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.692 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777488,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.745 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364778744 TS:1693364778810 diff:  61 fragment:2 cache: 1 size:768x864 codec:18 len:311 V-Count:100 IFrame:0....
08-30 11:06:18.745 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364778745 TS:1693364778810 cache buffer:12 w:768 h:864  count:100 .....
08-30 11:06:18.749  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.755  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.756 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777551,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.810  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.811  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.813 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777620,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.850 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364778850 TS:1693364778910 diff:  31 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:260
08-30 11:06:18.880 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364778013 ts:1693364778 progress:-1 count:261...
08-30 11:06:18.881  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.887  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.890 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364778889 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:90....
08-30 11:06:18.890 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777688,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:18.890 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364778890 TS:1693364778141 width:768 height:864 size:2 count:90.
08-30 11:06:18.891  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:06:18.891  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=152,badLossCount=0,txLoss=0,mLinkDetectTimes= 605,mIndex =1
08-30 11:06:18.891  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 59, 0, 0, 0, 0, 676, 59, 0, 0, 0, 0, 676, 59, 0, 0, 0, 0, 676, 59, 0, 0, 0, 0, 676, 61, 0, 0, 0, 0]
08-30 11:06:18.891  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:06:18.891  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:06:18.891  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:06:18.892  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:06:18.892  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-28,mIndex =1,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12577852953
08-30 11:06:18.892  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:06:18.892  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:06:18.892  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:06:18.892  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:06:18.892  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:06:18.892  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:06:18.893  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:06:18.904 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=593.0, y[0]=1294.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343789872, downTime=343789576, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:18.905  1517  2599 E ORMS_CORE: Unsupported action!!!
08-30 11:06:18.905   929   929 D ORMS_HAL: OrmsHalService write file /proc/sys/kernel/slide_boost_enabled - 0.
08-30 11:06:18.905   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:18.905   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:18.905   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:18.906   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:18.906   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:18.906 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=593.0, y[0]=1294.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343789872, downTime=343789576, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:18.907   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:18.908   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:18.908   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:18.908   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:18.908   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:18.908   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:18.908   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:18.908   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:18.908   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:18.908   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:18.908   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:18.908   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:18.908   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:18.909   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:18.909   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:18.909   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:18.909   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:18.909   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:18.951  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:18.953  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:18.954 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777748,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.032  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.037  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.039 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777818,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.045 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364779045 TS:1693364778141 interTimems:87 size:2 cache:134 speed:1.500000 count:90 ....
08-30 11:06:19.083  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.085  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.086 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777885,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.128 30404 30444 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:06:19.165  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.167  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.168 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364777951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.185 30404 30447 D HoraeHelper: Thermal length:1
08-30 11:06:19.193 30404 30444 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:06:19.205 30404 30444 D HoraeHelper: skinThermal:36.622
08-30 11:06:19.215  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.217  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.218 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778017,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.246 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=169.0, y[0]=1967.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343790213, downTime=343790213, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:19.246 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=169.0, y[0]=1967.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343790213, downTime=343790213, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:19.246 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=169.0, y[0]=1967.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343790213, downTime=343790213, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:19.259 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364779259 TS:1693364779326 diff:  10 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:270
08-30 11:06:19.285  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.287  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.288 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778086,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.321 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=151.0, y[0]=1957.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343790288, downTime=343790213, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:19.321 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=151.0, y[0]=1957.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343790288, downTime=343790213, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:19.322   929   929 D ORMS_HAL: OrmsHalService write file /proc/sys/kernel/slide_boost_enabled - 1.
08-30 11:06:19.326   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:19.326   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:19.326   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:19.326   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:19.326   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:19.326   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:19.356  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.358   929   929 D ORMS_HAL: OrmsHalService write file /proc/sys/kernel/slide_boost_enabled - 0.
08-30 11:06:19.359  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.360 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778152,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.361   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:19.361   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:19.361   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:19.361   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:19.361   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:19.361   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:19.388 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 15 fps, mOutputBufCnt = 15 fps, mRenderFrameCnt = 0 fps
08-30 11:06:19.388  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:19.388  1378  1429 D AtlasService: notify 1029 to client
08-30 11:06:19.414 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364779414 TS:1693364779480 diff:  61 fragment:2 cache: 1 size:768x864 codec:18 len:303 V-Count:110 IFrame:0....
08-30 11:06:19.416 25924 25924 D ColorViewRootUtil: initSwipState, isDisplayCompatApp false
08-30 11:06:19.416 25924 25924 D ColorViewRootUtil: mScreenHeight 2400, mScreenWidth 1080
08-30 11:06:19.416 25924 25924 D WindowManager: Add to mViews: DecorView@20db0e3[TRCTSmartCameraPanelActivity],pkg= com.tuya.smartiot
08-30 11:06:19.417 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364779417 TS:1693364779480 cache buffer:12 w:768 h:864  count:110 .....
08-30 11:06:19.419  1517  3119 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:19.421  1517  3119 V WindowManager: Changing focus from Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} to Window{c54664a u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:06:19.424  1517  3119 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:19.425  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.427  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.429 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778217,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.432  1517  3119 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:19.439 25924 25924 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 2400 getDecorView.DecorView@20db0e3[TRCTSmartCameraPanelActivity]
08-30 11:06:19.440  1517  3119 I InputDispatcher: Focus left window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:19.443  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:19.448  1003  1129 D DispPerfService: onframeavailable pid=25924, slot=0, seq=16526, name=com.tuya.smartiot:com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#1
08-30 11:06:19.463  1517  5208 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:19.471  1517  3119 I InputDispatcher: Focus entered window: Window{c54664a u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:19.481  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.483  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.484 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.490  1517 13105 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:06:19.490  1517 13105 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:19.469  1517  1860 I chatty  : uid=1000(system) android.display identical 4 lines
08-30 11:06:19.469  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:19.490  1517 13105 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:19.490  1517 13105 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:19.508  1517  3119 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:19.511  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:19.558 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 4.665257 kbps packet cache:0, frame cache:509
08-30 11:06:19.563  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.564  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.565 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364779565 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:100....
08-30 11:06:19.566 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.566 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364779566 TS:1693364778810 width:768 height:864 size:3 count:100.
08-30 11:06:19.611  1517  2519 D WN_S    : DT,tP=943247, dTP=8, rP=1653901, dRP=10 mIR=true, mRPLC=0
08-30 11:06:19.612  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:19.625  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.627  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.628 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778417,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.653 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364779652 TS:1693364779709 diff:  30 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:280
08-30 11:06:19.671  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653905 wlan0TxPtk=943251 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:19.691  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.693  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.694 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778485,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.699  1003  1003 D OppoExLayer: ~Layer() sequence=16527, name=Surface(name=c54664a com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x491c084 - animation-leash#0@0xb40000702af3c000
08-30 11:06:19.717 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364778718 size:640...
08-30 11:06:19.720 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364778750 size:640...
08-30 11:06:19.720 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364778814 size:640...
08-30 11:06:19.720 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364778846 size:640...
08-30 11:06:19.720 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364778881 size:640...
08-30 11:06:19.720 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364778910 size:640...
08-30 11:06:19.748  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.752  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.754 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778552,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.780 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364779780 TS:1693364778810 interTimems:64 size:3 cache:199 speed:1.000000 count:100 ....
08-30 11:06:19.820  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.822  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.823 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778618,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.890  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.892  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.894 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778686,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.951  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:19.953  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:19.954 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:19.981 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364779011 ts:1693364779 progress:-1 count:276...
08-30 11:06:20.012  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.014  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.015 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778818,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.069 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364780069 TS:1693364780125 diff:  40 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:290
08-30 11:06:20.119 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:768 h:864 fr:15 profile:100 level:4.000000
08-30 11:06:20.120 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364780120 TS:1693364780145 diff: 112 fragment:2 cache: 1 size:768x864 codec:18 len:29838 V-Count:120 IFrame:1....
08-30 11:06:20.121 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364780121 TS:1693364780145 cache buffer:12 w:768 h:864  count:120 .....
08-30 11:06:20.126  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.128  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.128  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.129 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778884,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.131  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.131  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.133 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364778951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.134  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.134  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.136 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364780135 cache len:10 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:110....
08-30 11:06:20.136 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779018,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.137  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.137  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.138 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364780138 TS:1693364779480 width:768 height:864 size:4 count:110.
08-30 11:06:20.139  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.140  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.140 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779087,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.143  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.143  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.145 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779153,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.145  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.145  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.148  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.148  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.150  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.150  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.152  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.152  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.152 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779217,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.154  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.154  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.155 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.156  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.159 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.161 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779418,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.163 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779486,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.165 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779552,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.167 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779618,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.275 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364780275 TS:1693364779480 interTimems:17 size:10 cache:598 speed:0.250000 count:110 ....
08-30 11:06:19.689  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:19.705  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:20.344 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=693.0, y[0]=914.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343791312, downTime=343791312, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:20.344 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=693.0, y[0]=914.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343791312, downTime=343791312, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:20.345 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=693.0, y[0]=914.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343791312, downTime=343791312, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:20.389 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 16 fps, mOutputBufCnt = 22 fps, mRenderFrameCnt = 0 fps
08-30 11:06:20.405 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=693.0, y[0]=914.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343791373, downTime=343791312, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:20.406 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=693.0, y[0]=914.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343791373, downTime=343791312, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:20.447 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364780447 TS:1693364780512 diff:  31 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:300
08-30 11:06:20.488  1517  3119 V WindowManager: Changing focus from Window{c54664a u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity EXITING} to Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:06:20.490  1517  3119 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:20.494  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:20.501  1003  1003 D OppoExLayer: ~Layer() sequence=16521, name=Surface(name=74ffb6 StatusBar)/@0xbaad1b7 - animation-leash#1@0xb40000702af6e000
08-30 11:06:20.501  1003  1003 D OppoExLayer: ~Layer() sequence=16522, name=Surface(name=29f1a38 NavigationBar0)/@0xe2b3d24 - animation-leash#0@0xb40000702afa7000
08-30 11:06:20.503  1517  3119 I InputDispatcher: Focus left window: Window{c54664a u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:20.519  1517  5208 I InputDispatcher: Focus entered window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:20.521  1517  5208 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:06:20.521  1517  5208 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:20.497  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:20.522  1517  5208 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:20.522  1517  5208 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:20.536  1517 13105 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:20.540  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:20.613  1517 13105 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:20.613  1517  5208 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:20.613  1517  3119 I WifiService: getConnectionInfo uid=1000
08-30 11:06:20.618 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 31.951099 kbps packet cache:0, frame cache:593
08-30 11:06:20.659 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364780011 ts:1693364780 progress:-1 count:291...
08-30 11:06:20.711  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 56ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653915 wlan0TxPtk=943263 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:20.730  1003  1003 D OppoExLayer: ~Layer() sequence=16528, name=Surface(name=c54664a com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x491c084 - animation-leash#0@0xb40000700e9e0000
08-30 11:06:20.730  1003  1003 D OppoExLayer: ~Layer() sequence=16523, name=c54664a com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000702afe0000
08-30 11:06:20.732  1003  1003 D OppoExLayer: ~Layer() sequence=16526, name=com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#1@0xb40000702af22000
08-30 11:06:20.741 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364780741 TS:1693364780807 diff:  62 fragment:2 cache: 1 size:768x864 codec:18 len:289 V-Count:130 IFrame:0....
08-30 11:06:20.741 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364780741 TS:1693364780807 cache buffer:10 w:768 h:864  count:130 .....
08-30 11:06:20.863 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364780863 TS:1693364780926 diff:  20 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:310
08-30 11:06:20.887  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.888  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.890 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364780890 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:120....
08-30 11:06:20.890 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779685,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.890 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364780890 TS:1693364780145 width:768 height:864 size:1 count:120.
08-30 11:06:20.891 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364780890 TS:1693364780145 interTimems:-188 size:1 cache:0 speed:2.000000 count:120 ....
08-30 11:06:20.947  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:20.948  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:20.950 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.018  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.020  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.021 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779818,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:20.720  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:20.739  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:21.055  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:21.066  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3443600
08-30 11:06:21.066  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:21.076 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=81.0, y[0]=365.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792044, downTime=343792044, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.076 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=81.0, y[0]=365.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792044, downTime=343792044, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.077 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=81.0, y[0]=365.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792044, downTime=343792044, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.081  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.084  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.085 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779885,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.136 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=81.0, y[0]=365.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792104, downTime=343792044, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.136 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=81.0, y[0]=365.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792104, downTime=343792044, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.152  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.154  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.155 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364779951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.229  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.233  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.235 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780017,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.241 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364781241 TS:1693364781310 diff:  31 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:320
08-30 11:06:21.244 25924 25924 D ColorViewRootUtil: initSwipState, isDisplayCompatApp false
08-30 11:06:21.245 25924 25924 D ColorViewRootUtil: mScreenHeight 2400, mScreenWidth 1080
08-30 11:06:21.245 25924 25924 D WindowManager: Add to mViews: DecorView@ce4c421[TRCTSmartCameraPanelActivity],pkg= com.tuya.smartiot
08-30 11:06:21.247  1517  5208 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:21.249  1517  5208 V WindowManager: Changing focus from Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} to Window{98e4a52 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:06:21.252  1517  5208 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:21.258  1517  5208 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:21.263  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:21.264  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:21.267 25924 25924 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 2400 getDecorView.DecorView@ce4c421[TRCTSmartCameraPanelActivity]
08-30 11:06:21.271  1517 13105 I InputDispatcher: Focus left window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:21.277  1003  3882 D DispPerfService: onframeavailable pid=25924, slot=0, seq=16534, name=com.tuya.smartiot:com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#1
08-30 11:06:21.289  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.290  1517  5208 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:21.291  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.293 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780087,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.300  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:21.303  1003  1003 D OppoExLayer: ~Layer() sequence=16530, name=Surface(name=29f1a38 NavigationBar0)/@0xe2b3d24 - animation-leash#0@0xb40000700e8ef000
08-30 11:06:21.303  1003  1003 D OppoExLayer: ~Layer() sequence=16529, name=Surface(name=74ffb6 StatusBar)/@0xbaad1b7 - animation-leash#1@0xb40000701dd57000
08-30 11:06:21.304  1517  5208 I InputDispatcher: Focus entered window: Window{98e4a52 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:21.327  1517 13105 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:06:21.327  1517 13105 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:21.303  1517  1860 I chatty  : uid=1000(system) android.display identical 2 lines
08-30 11:06:21.304  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:21.327  1517 13105 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:21.327  1517 13105 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:21.340  1517 13105 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:21.343  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:21.361  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.363  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.365 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780151,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.378 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364780446 size:640...
08-30 11:06:21.379 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364780479 size:640...
08-30 11:06:21.379 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364780512 size:640...
08-30 11:06:21.379 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364780574 size:640...
08-30 11:06:21.379 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364780606 size:640...
08-30 11:06:21.380 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364780637 size:640...
08-30 11:06:21.380 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364780670 size:640...
08-30 11:06:21.390 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 15 fps, mOutputBufCnt = 8 fps, mRenderFrameCnt = 0 fps
08-30 11:06:21.419 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364781419 TS:1693364781479 diff:  62 fragment:2 cache: 1 size:768x864 codec:18 len:307 V-Count:140 IFrame:0....
08-30 11:06:21.420 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364781420 TS:1693364781479 cache buffer:12 w:768 h:864  count:140 .....
08-30 11:06:21.426  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.430  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.432 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780216,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.484  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.487  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.489 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.532  1003  1003 D OppoExLayer: ~Layer() sequence=16535, name=Surface(name=98e4a52 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0xd3f444c - animation-leash#0@0xb40000702af9e000
08-30 11:06:21.544  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.546  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.547 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364781547 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:130....
08-30 11:06:21.547 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.550 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364781550 TS:1693364780807 width:768 height:864 size:2 count:130.
08-30 11:06:21.611  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-31 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:21.611  1517  2519 D OplusRssiMonitor: update rssi:-31
08-30 11:06:21.612  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:21.612  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:21.612  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:21.612  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-28 for "abc_ling"WPA_PSK
08-30 11:06:21.612  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:21.612  1517  2519 D WifiDataStall: L2 txTputKbps: 64680, rxTputKbps: 66000, L3 txTputKbps: 46, rxTputKbps: 262, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:21.615  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -29, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:21.615  1517  2519 D WifiScoreCard: txRate: 25 txSpeed: 96
08-30 11:06:21.615  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -29 txSpeed 96
08-30 11:06:21.615  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:21.615  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538619616 LastRssiPoll: -29 LastTxSpeedPoll: 96
08-30 11:06:21.615  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:21.615  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:21.615  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:21.619  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.621  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -29
08-30 11:06:21.622  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:21.623  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -29 level: 4
08-30 11:06:21.623  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:21.623  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.624  1517  5208 I WifiService: getConnectionInfo uid=10060
08-30 11:06:21.624  1517  5208 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:21.625  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-29 f=2462 sc=0 link=96 tx=22.6, 1.7, 0.0  rx=105.1 bcn=9009491 [on:2940 tx:48 rx:56 period:3012] from screen [on:4940544 period:6571554] score=0
08-30 11:06:21.625 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780414,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.626  1517  2519 D WN_S    : DT,tP=943263, dTP=16, rP=1653915, dRP=14 mIR=true, mRPLC=0
08-30 11:06:21.626  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:21.672 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364781672 TS:1693364781726 diff:  40 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:330
08-30 11:06:21.675 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364781675 TS:1693364780807 interTimems:13 size:2 cache:66 speed:1.500000 count:130 ....
08-30 11:06:21.694 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 5.106079 kbps packet cache:0, frame cache:607
08-30 11:06:21.699  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.701  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.702 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780486,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.751  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 56ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653919 wlan0TxPtk=943267 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:21.759  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.762  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.764 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780550,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.830  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.832  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.833 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780617,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.518  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:21.538  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:21.877 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=992.0, y[0]=1264.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792845, downTime=343792845, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.877 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=992.0, y[0]=1264.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792845, downTime=343792845, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.878 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=992.0, y[0]=1264.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792845, downTime=343792845, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.883  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.886  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.887 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780686,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.895 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364781010 ts:1693364781 progress:-1 count:306...
08-30 11:06:21.922 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=992.0, y[0]=1264.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792890, downTime=343792845, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.922 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=992.0, y[0]=1264.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343792890, downTime=343792845, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:21.961  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:21.963  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:21.964 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,222,1117,1072],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:21.996  1517  5208 V WindowManager: Changing focus from Window{98e4a52 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity EXITING} to Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:06:21.999  1517  5208 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:22.005  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:22.010  1517  5208 I InputDispatcher: Focus left window: Window{98e4a52 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:22.022  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.025  1517 13105 I InputDispatcher: Focus entered window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:22.025  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.027  1517 13105 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:06:22.027  1517 13105 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:22.006  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:22.027  1517 13105 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:22.027  1517 13105 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:22.027 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780817,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.041  1517 13105 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:22.045  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:22.050 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364782050 TS:1693364782110 diff:  31 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:340
08-30 11:06:22.080 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364782080 TS:1693364782145 diff:  61 fragment:2 cache: 1 size:768x864 codec:18 len:298 V-Count:150 IFrame:0....
08-30 11:06:22.080 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364782080 TS:1693364782145 cache buffer:12 w:768 h:864  count:150 .....
08-30 11:06:22.084  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.086  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.087 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780884,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.157  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.159  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.160 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364780951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.227  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.229  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.230 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364782230 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:140....
08-30 11:06:22.230 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781018,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.232 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364782232 TS:1693364781479 width:768 height:864 size:3 count:140.
08-30 11:06:22.236  1003  1003 D OppoExLayer: ~Layer() sequence=16536, name=Surface(name=98e4a52 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0xd3f444c - animation-leash#0@0xb40000701dbaf000
08-30 11:06:22.236  1003  1003 D OppoExLayer: ~Layer() sequence=16531, name=98e4a52 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e816000
08-30 11:06:22.237  1003  1003 D OppoExLayer: ~Layer() sequence=16534, name=com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#1@0xb40000700e963000
08-30 11:06:22.288  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.290  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.293 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781086,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.348  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.351  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.353 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781152,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.367 25924 26591 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadAudioStream Port[0] audio rtp package recved ,count:600
08-30 11:06:22.390 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 15 fps, mOutputBufCnt = 15 fps, mRenderFrameCnt = 0 fps
08-30 11:06:22.429  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.431  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.433 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781217,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.440 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364782440 TS:1693364781479 interTimems:68 size:3 cache:199 speed:1.000000 count:140 ....
08-30 11:06:22.225  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:22.242  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:22.463  1517  2586 D JobScheduler.Temperature: get temperature=36.74
08-30 11:06:22.468 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364782468 TS:1693364782525 diff:  40 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:350
08-30 11:06:22.479  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.482  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.483 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.533 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364781534 size:640...
08-30 11:06:22.533 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364781564 size:640...
08-30 11:06:22.533 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364781600 size:640...
08-30 11:06:22.533 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364781630 size:640...
08-30 11:06:22.534 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364781693 size:640...
08-30 11:06:22.534 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364781726 size:640...
08-30 11:06:22.534 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364781757 size:640...
08-30 11:06:22.560  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.562  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.564 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.611  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.613  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.614 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781419,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.680 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=949.0, y[0]=1251.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343793647, downTime=343793647, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:22.680 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=949.0, y[0]=1251.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343793647, downTime=343793647, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:22.680 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=949.0, y[0]=1251.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343793647, downTime=343793647, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:22.682 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364782209,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":35432} ...
08-30 11:06:22.684  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.685  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.687 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781487,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.747 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=949.0, y[0]=1251.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343793715, downTime=343793647, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:22.747 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=949.0, y[0]=1251.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343793715, downTime=343793647, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:22.769 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364782810 ,count:1800
08-30 11:06:22.770 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:768 h:864 fr:15 profile:100 level:4.000000
08-30 11:06:22.770 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 31.235479 kbps packet cache:0, frame cache:631
08-30 11:06:22.770 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364782770 TS:1693364782810 diff:  92 fragment:2 cache: 1 size:768x864 codec:18 len:29748 V-Count:160 IFrame:1....
08-30 11:06:22.772 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364782772 TS:1693364782810 cache buffer:12 w:768 h:864  count:160 .....
08-30 11:06:22.778  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.780  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.780  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.781 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781551,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.782  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.782  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.784 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781617,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.786  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.788 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364782788 cache len:10 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:150....
08-30 11:06:22.788 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781687,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.789 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364782789 TS:1693364782145 width:768 height:864 size:5 count:150.
08-30 11:06:22.790  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.791  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 56ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653923 wlan0TxPtk=943271 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:22.792  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.792  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.794  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.794  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.795 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.797  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.797  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.799  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.799  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.799 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781821,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.801  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.801  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.803 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781885,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.803  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.804  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.807 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364781951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.807  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.807  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.810  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.810  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:22.810 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782017,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.813  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:22.814 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782086,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.818 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782152,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.821 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782216,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.825 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782285,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:22.855 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364782854 TS:1693364782909 diff:  40 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:360
08-30 11:06:22.859 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364782010 ts:1693364782 progress:-1 count:321...
08-30 11:06:22.892 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:06:22.892 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:06:22.894 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:06:22.894 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:06:22.900 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364782900 TS:1693364782145 interTimems:16 size:10 cache:596 speed:0.250000 count:150 ....
08-30 11:06:22.908 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:06:22.908 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:06:22.926 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: get feature:IOplusScreenModeFeature
08-30 11:06:22.926 25924 25924 I oplus.android.OplusFrameworkFactoryImpl: getOplusScreenModeFeature
08-30 11:06:23.262 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364783261 TS:1693364783326 diff:  10 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:370
08-30 11:06:23.310 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364782837,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":25398,"channels":[[0,264,180,264,180,2928,656,402,393,475,392,470],[1,0,1423333,0,1423333,8008,2949748,623,-1,517,393,517],[2,0,229632,0,229632,6072,569652,1093,-1,994,393,990],[330,3216,0,-240,0,473796,0,390,159,-1,-1,-1]]} ...
08-30 11:06:23.368 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=92.0, y[0]=356.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343794336, downTime=343794336, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:23.368 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=92.0, y[0]=356.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343794336, downTime=343794336, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:23.369 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=92.0, y[0]=356.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343794336, downTime=343794336, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:23.391 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 16 fps, mOutputBufCnt = 17 fps, mRenderFrameCnt = 0 fps
08-30 11:06:23.414 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364783414 TS:1693364783475 diff:  72 fragment:2 cache: 1 size:768x864 codec:18 len:301 V-Count:170 IFrame:0....
08-30 11:06:23.416 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364783416 TS:1693364783475 cache buffer:10 w:768 h:864  count:170 .....
08-30 11:06:23.428 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=92.0, y[0]=356.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343794396, downTime=343794336, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:23.429 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=92.0, y[0]=356.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343794396, downTime=343794336, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:23.520 25924 25924 D ColorViewRootUtil: initSwipState, isDisplayCompatApp false
08-30 11:06:23.520 25924 25924 D ColorViewRootUtil: mScreenHeight 2400, mScreenWidth 1080
08-30 11:06:23.520 25924 25924 D WindowManager: Add to mViews: DecorView@ba7fcc1[TRCTSmartCameraPanelActivity],pkg= com.tuya.smartiot
08-30 11:06:23.523  1517 13105 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:23.525  1517 13105 V WindowManager: Changing focus from Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} to Window{41da505 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:06:23.527  1517 13105 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:23.534  1517 13105 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:23.539  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:23.541  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:23.541 25924 25924 V OplusZoomWindowDecorViewHelper: setLastReportedMergedConfiguration mZoomDisplayHeight: 2400 getDecorView.DecorView@ba7fcc1[TRCTSmartCameraPanelActivity]
08-30 11:06:23.546  1517 13105 I InputDispatcher: Focus left window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:23.553  1003  3882 D DispPerfService: onframeavailable pid=25924, slot=0, seq=16542, name=com.tuya.smartiot:com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#1
08-30 11:06:23.556  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:23.560  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:23.563 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364783563 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:160....
08-30 11:06:23.563 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782352,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:23.566 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364783566 TS:1693364782810 width:768 height:864 size:1 count:160.
08-30 11:06:23.566  1517  5210 D OppoDisplayPolicy: com.tuya.smartiot, no change cutoutMode: 0
08-30 11:06:23.566 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364783566 TS:1693364782810 interTimems:-322 size:1 cache:0 speed:2.000000 count:160 ....
08-30 11:06:23.574  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:23.578  1003  1003 D OppoExLayer: ~Layer() sequence=16537, name=Surface(name=74ffb6 StatusBar)/@0xbaad1b7 - animation-leash#1@0xb40000700e902000
08-30 11:06:23.578  1003  1003 D OppoExLayer: ~Layer() sequence=16538, name=Surface(name=29f1a38 NavigationBar0)/@0xe2b3d24 - animation-leash#0@0xb40000700e98b000
08-30 11:06:23.578  1517 13105 I InputDispatcher: Focus entered window: Window{41da505 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:23.585  1517 13105 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:06:23.586  1517 13105 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:23.574  1517  1860 I chatty  : uid=1000(system) android.display identical 2 lines
08-30 11:06:23.575  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:23.586  1517 13105 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:23.586  1517 13105 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:23.601  1517 13105 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:23.604  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:23.615  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:23.619  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:23.621 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782417,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:23.623  1517 13105 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:23.623  1517  3939 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:23.624  1517  3939 I WifiService: getConnectionInfo uid=1000
08-30 11:06:23.628  1517  2519 D WN_S    : DT,tP=943271, dTP=8, rP=1653923, dRP=8 mIR=true, mRPLC=0
08-30 11:06:23.628  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:23.645 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364783645 TS:1693364783709 diff:  31 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:380
08-30 11:06:23.699  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:23.701  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:23.703 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782487,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:23.760  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:23.763  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:23.765 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782550,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:23.807  1003  1003 D OppoExLayer: ~Layer() sequence=16543, name=Surface(name=41da505 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x5555167 - animation-leash#0@0xb40000702affc000
08-30 11:06:23.816 25924 26674 I ThingCameraSDK: ThingCameraListenerImpl::onVideoDecodedDataRecieved deviceId:6ce1f26844bfce86f3zrdp TS:1693364783011 ts:1693364783 progress:-1 count:336...
08-30 11:06:23.816 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 5.112482 kbps packet cache:0, frame cache:721
08-30 11:06:23.822  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:23.824  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:23.829 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782618,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:23.832  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 55ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653927 wlan0TxPtk=943275 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:23.883  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:23.885  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:23.887 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782685,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:23.891  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:06:23.892  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=65,badLossCount=0,txLoss=0,mLinkDetectTimes= 606,mIndex =0
08-30 11:06:23.892  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 55, 0, 0, 0, 0, 676, 56, 0, 0, 0, 0, 676, 56, 0, 0, 0, 0, 676, 56, 0, 0, 0, 0, 676, 59, 0, 0, 0, 0]
08-30 11:06:23.892  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:06:23.892  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:06:23.892  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:06:23.894  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:06:23.894  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-29,mIndex =0,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12578026900
08-30 11:06:23.894  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:06:23.894  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:06:23.894  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:06:23.896  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:06:23.896  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:06:23.896  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:06:23.896  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:06:23.943  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:23.945  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:23.946 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782752,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,391,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1110,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:24.014  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.016  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.018 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782818,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:24.063 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364784063 TS:1693364784125 diff:  21 fragment:2 codec:133 sampleRate:8000 len:320 A-Count:390
08-30 11:06:24.091 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364784091 TS:1693364784144 diff:  81 fragment:2 cache: 1 size:768x864 codec:18 len:293 V-Count:180 IFrame:0....
08-30 11:06:24.091 25924 26672 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH264Packet CT:1693364784091 TS:1693364784144 cache buffer:12 w:768 h:864  count:180 .....
08-30 11:06:24.094 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364783166 size:640...
08-30 11:06:24.094 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364783198 size:640...
08-30 11:06:24.095 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364783230 size:640...
08-30 11:06:24.095 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364783294 size:640...
08-30 11:06:24.095 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364783326 size:640...
08-30 11:06:24.095 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364783359 size:640...
08-30 11:06:24.095 25924 26671 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364783389 size:640...
08-30 11:06:24.096 30404 30444 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:06:24.096  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.097 30404 30444 D HoraeHelper: Thermal length:1
08-30 11:06:24.098  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.100 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782884,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:24.146  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.148  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.150 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364782951,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:23.795  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:23.813  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:24.187 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=791.0, y[0]=2151.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343795154, downTime=343795154, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:24.187 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=791.0, y[0]=2151.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343795154, downTime=343795154, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:24.187 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=791.0, y[0]=2151.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343795154, downTime=343795154, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:24.193 30404 30448 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:06:24.220  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.223  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.225 25924 26688 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364784225 cache len:12 size:995328 offset:0 color:0x15 crop top:0 bottom:863 left:0 right:767 stride w:768(768) h:864(864) count:170....
08-30 11:06:24.225 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364783018,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:24.225 25924 26688 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364784225 TS:1693364783475 width:768 height:864 size:2 count:170.
08-30 11:06:24.247 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=791.0, y[0]=2151.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343795215, downTime=343795154, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:24.247 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=791.0, y[0]=2151.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343795215, downTime=343795154, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:24.272 25924 26531 W AudioManager: Use of stream types is deprecated for operations other than volume control
08-30 11:06:24.272 25924 26531 W AudioManager: See the documentation of requestAudioFocus() for what to use instead with android.media.AudioAttributes to qualify your playback use case
08-30 11:06:24.274  1517  5208 I MediaFocusControl: requestAudioFocus() from uid/pid 10030/25924 clientId=android.media.AudioManager@117a91acom.thingclips.smart.ipc.camera.rnpanel.cameramanager.TRCTCameraManager$2@9c944c1 callingPack=com.tuya.smartiot req=1 flags=0x0 sdk=33
08-30 11:06:24.276 25924 26531 I ThingCameraSDK: ThingCameraSimple::SetVideoClarity Port[0] channel:0 mode:4 enter....
08-30 11:06:24.276 25924 26531 I ThingCameraSDK: ThingAVQualityMonitor::Stop Stop
08-30 11:06:24.276 25924 26531 I ThingCameraSDK: ThingAVQualityMonitor::Upload Port[0] json {"session_id":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","device_id":"6ce1f26844bfce86f3zrdp","trace_id":"","product_id":"zwlarqxkjsq","task_type":"Thing_TASK_TYPE_PREVIEW","statistics":{"width":768,"height":864,"frame_rate":15,"visual_fps":17.36465835571289,"average_delay":1094,"profile":100,"level":4.0,"codec_mine":"video/avc","decoder_type":"HWDecoder","decoder_name":"MediaCodec_Decoder","sample_rate":8000,"bitwidth":16,"channel":2,"average_bitrate":20.41006851196289,"average_decode_time":595,"post_process_time":0,"jitter_rate":1.0869565419852734,"lost_packet_rate":0.0,"net_stutter_rate":0.0,"visual_stutter_rate":0.0,"av_unsync_rate":0.0,"p2p_connect_time_cost":391,"recv_first_packet_time":4903,"recv_first_image_time":5080}}
08-30 11:06:24.281 25924 26673 I ThingCameraSDK: ThingAVSyncronizer::AudioDispatchInRealTime Port[0] m_bSyncNeedExit:1 this:0x6f6d59a068,threadid:0x702ecf1cc0 thread exit....
08-30 11:06:24.284  1406 26682 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.286  1406 26682 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.287 25924 26688 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364783082,"chn":1,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [397,384,982,1072],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [780,216,1117,1073],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:24.322 25924 26674 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] this:0x6f6d59a068,threadid:0x70017fbcc0 exit....
08-30 11:06:24.322 25924 26672 I ThingCameraSDK: ThingAVCacheManager::VideoDataDispatchRunner Port[0] VideoDataDispatchRunner(0x70939eecc0) this:0x6f6d59a3f0 exit...
08-30 11:06:24.327 25924 26671 I ThingCameraSDK: ThingAVCacheManager::AudioDataDispatchRunner Port[0] (0x7094207cc0) exit...
08-30 11:06:24.328 25924 26531 W libc    : invalid pthread_t (0) passed to pthread_join
08-30 11:06:24.330 25924 26679 I OplusFeedbackInfo: [sendFeedbackInfo:L293]  send:MM_FB_EventID#21001#ClientPid#25924#ReportLevel#0#isHDRVideo#false#timeUsage#10#videoComponent#OMX.qcom.video.decoder.avc#videoHeight#864#videoMime#video/avc#videoWidth#768
08-30 11:06:24.330  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:24.330  1378  1429 D AtlasService: notify 256 to client
08-30 11:06:24.331 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Now Executing->Idle
08-30 11:06:24.331 25924 26531 I ThingCameraSDK: ThingAVQualityMonitor::Stop Stop
08-30 11:06:24.332 25924 26531 W libc    : invalid pthread_t (0) passed to pthread_join
08-30 11:06:24.332 25924 26531 I chatty  : uid=10030(com.tuya.smartiot) mqt_native_modu identical 2 lines
08-30 11:06:24.332 25924 26531 I ThingCameraSDK: ThingPlayTask::ThingPlayTask Port[0] this:0x6f6d59a010
08-30 11:06:24.332 25924 26531 I ThingCameraSDK: ThingAVModule::SetMute Port[0] mute:1
08-30 11:06:24.333 25924 26531 I ThingCameraSDK: ThingAVQualityMonitor::Start Start
08-30 11:06:24.333 25924 26531 I ThingCameraSDK: ThingCameraSimple::SetVideoClarity Port[0] mode:4 requestId:196618 cmd high:9 low:0 ...
08-30 11:06:24.333 25924 26531 I ThingCameraSDK: ThingCameraSimple::SetVideoClarity Port[0] leave(0)...
08-30 11:06:24.333 25924 26587 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::SendCommand Port[0] index = 0 reqId = 196618, high_cmd = 9, low_cmd = 0, session = 65539, thing_p2p_rtc_send_data=28[] send...
08-30 11:06:24.334 25924 26725 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchRunner Port[0] m_bKeepRealTime:1
08-30 11:06:24.334 25924 26725 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] m_bSyncNeedExit:0 thread
08-30 11:06:24.335 25924 26723 I ThingCameraSDK: ThingAVCacheManager::VideoDataDispatchRunner Port[0] this:0x6f6d59a3f0
08-30 11:06:24.336 25924 26722 I ThingCameraSDK: ThingAVCacheManager::AudioDataDispatchRunner Port[0] this:0x6f6d59a3f0
08-30 11:06:24.336  4254  5981 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1701 android.content.ContextWrapper.startService:730 com.oplus.util.OplusStatisticsImpl.startService:216 com.oplus.util.OplusStatisticsImpl.sendDataToDCS:192 com.oplus.util.OplusStatisticsImpl.onCommonSync:84
08-30 11:06:24.336 25924 26531 I ThingCameraSDK: ThingCameraBase::EnableIVA Port[0] iva:1 enter...
08-30 11:06:24.337 25924 26531 I ThingCameraSDK: ThingCameraBase::EnableIVA Port[0] leave...
08-30 11:06:24.337 25924 26724 I ThingCameraSDK: ThingAVSyncronizer::AudioDispatchRunner Port[0] m_bKeepRealTime:1
08-30 11:06:24.338 25924 26724 I ThingCameraSDK: ThingAVSyncronizer::AudioDispatchInRealTime Port[0] m_bSyncNeedExit:0 thread
08-30 11:06:24.342 30090 30160 I [0]DCS-StrategyManager: isNeedUpload: false, type: 2006, appID: 30384, logTag: video, eventID: 21001
08-30 11:06:24.342 30090 30160 W [0]DCS  : Record event failed. DCS reject event: [appId=30384,logTag=video,eventId=21001] . Pls check server config.
08-30 11:06:24.349 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:3 received:2, !!!
08-30 11:06:24.350 25924 26592 I ThingCameraSDK: ThingPlayTask::OnRtpVideoPackageRecved Port[0] drop rtp cause task_id diff my:3 received:2, !!!
08-30 11:06:24.350 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364784350 TS:1693364784414 diff:  18 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:0
08-30 11:06:24.353 25924 26722 I ThingCameraSDK: ThingAVModule::SetupAudioParams Port[0] sampleRate:8000 channel:2
08-30 11:06:24.366 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Now Idle->Loaded
08-30 11:06:24.366 25924 26680 D ACodec  : [OMX.qcom.video.decoder.avc] Now Loaded
08-30 11:06:24.366  1406  7010 I OMX-VDEC-1080P: omx_vdec::component_deinit() complete
08-30 11:06:24.374  1517  5208 V WindowManager: Changing focus from Window{41da505 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity EXITING} to Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity},diplayid=0
08-30 11:06:24.375 25924 26588 I ThingCameraSDK: ThingSmartIPC::CXX::ThingNetProtocolManager::OnCommandPackageRecved Port[0] index:0 requestId:196618 high_cmd:9 low_cmd:0 received...
08-30 11:06:24.375 25924 26588 I ThingCameraSDK: ThingNetRequestCommand::onResponse Port[0] this:0x6f8a1e2710 nRequestId:196618...
08-30 11:06:24.375 25924 26588 I ThingCameraSDK: ThingVideoClarityCallBack::onResponse Port[0] response requestId:196618 highcmd:9 lowcmd:0
08-30 11:06:24.378 25924 26588 I ThingCameraSDK: ThingCameraSimple::OnCommandPackageRecved Port[0] requestId:196618 highCmd:9 lowCmd:0
08-30 11:06:24.380  1517  5210 I InputDispatcher: Focus left window: Window{41da505 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:24.382  1406  7010 I OMX-VDEC-1080P: Exit OMX vdec Destructor: fd=7
08-30 11:06:24.384  1517  5208 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:24.391 25924 26680 D ACodec  : Now uninitialized
08-30 11:06:24.392 25924 26680 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 0 fps, mOutputBufCnt = 0 fps, mRenderFrameCnt = 0 fps
08-30 11:06:24.393  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:24.393  1378  1429 D AtlasService: notify 1025 to client
08-30 11:06:24.393  1378  1429 D AtlasService: notify 1029 to client
08-30 11:06:24.395 25924 26679 D OplusACodec: ~OplusACodec [145]:
08-30 11:06:24.395 25924 26679 I ACodec  : ~ACodec()
08-30 11:06:24.396  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:24.414  1517  3939 I InputDispatcher: Focus entered window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:24.433  1517  3939 D InputMethodManagerService: isSecurity: attribute.packageName=com.tuya.smartiot
08-30 11:06:24.433  1517  3939 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:24.433  1517  3939 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:24.434  1517  3939 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:24.450  1517  5208 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:24.454  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:24.522 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:06:24.522 25924 26592 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364784522,"m":"camera","did":"","status":"first full frame recved.","tid":"no traceId"} ...
08-30 11:06:24.522 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364784522 TS:1693364783410 diff: 190 fragment:3 cache: 1 size:1920x2160 codec:20 len:150754 V-Count:0 IFrame:1....
08-30 11:06:24.522 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364783544 ,count:2000
08-30 11:06:24.522 25924 26723 I ThingCameraSDK: ThingAVModule::SetupVideoParams Port[0] frame_rate:15 width:1920 height:2160
08-30 11:06:24.523 25924 26723 I ThingCameraSDK: ThingAVModule::OnCacheVideoPacketRecved Port[0] the video parameters changed, video decoder will reset!!!
08-30 11:06:24.523 25924 26723 I ThingVideoDecodeSDK: [VideoCodecSDK Version:1.3.5]
08-30 11:06:24.523 25924 26723 I ThingVideoDecodeSDK: ThingMediaCodecDecoder::TravellMobileProductInfo travell the mobile product information(model = PCKM00,
08-30 11:06:24.523 25924 26723 I ThingVideoDecodeSDK: name = PCKM00, brand = OPPO,device = OP4A57, hardware = qcom, version = 11, sdkVersion = 30)
08-30 11:06:24.526 25924 26723 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::InitH265Decoder w:1920 h:2160
08-30 11:06:24.531 25924 26723 E Parcel  : Reading a NULL string not supported here.
08-30 11:06:24.532 25924 26723 D ACodec  : ACodec() ro.oplus.audio.effect.type = dolby ro.oplus.audio.dolby.type = v351
08-30 11:06:24.532 25924 26723 I ACodec  : new ACodec()
08-30 11:06:24.532 25924 26723 D ACodec  : Now uninitialized
08-30 11:06:24.532 25924 26723 D OplusACodec: OplusACodec [131]:
08-30 11:06:24.532 25924 26723 D OplusACodec: getBufferChannel: New
08-30 11:06:24.533 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364784533 TS:1693364784077 diff:   0 fragment:3 cache:11 size:1920x2160 codec:20 len:600 V-Count:10 IFrame:0....
08-30 11:06:24.535 25924 26728 I OMXClient: IOmx service obtained
08-30 11:06:24.535 25924 26728 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:06:24.536   915  5224 D audio_hw_primary: adev_set_parameters: enter: HQV_wl_pid=25924
08-30 11:06:24.536   915  5224 D audio_hw_hfp: hfp_set_parameters: enter
08-30 11:06:24.536   915  5224 D audio_hw_primary: adev_set_parameters: set dual headphone enable: 0x0
08-30 11:06:24.536   915  5224 D audio_hw_extn: audio_extn_fm_set_parameters: Enter
08-30 11:06:24.536   915  5224 D audio_hw_primary: adev_set_parameters: exit with code(0)
08-30 11:06:24.538  1406  7010 I OMXMaster: makeComponentInstance(OMX.qcom.video.decoder.hevc) in android.hardwar process
08-30 11:06:24.540  1406  7010 D PlatformConfig: getInstance: Enter
08-30 11:06:24.540  1406  7010 D PlatformConfig: getInt32 Config name: vidc_dec_log_in value: 0
08-30 11:06:24.540  1406  7010 D PlatformConfig: getInt32 Config name: vidc_dec_log_out value: 0
08-30 11:06:24.540  1406  7010 D PlatformConfig: getInt32 Config name: vidc_dec_sec_prefetch_size_internal value: 31457280
08-30 11:06:24.540  1406  7010 D PlatformConfig: getInt32 Config name: vidc_dec_sec_prefetch_size_output value: 3276800
08-30 11:06:24.540  1406  7010 D PlatformConfig: getInt32 Config name: vidc_dec_arb_mode_override value: 7
08-30 11:06:24.540  1406  7010 D PlatformConfig: getInt32: Returning default
08-30 11:06:24.540  1406  7010 I OMX-VDEC-1080P: component_init: OMX.qcom.video.decoder.hevc : fd=7
08-30 11:06:24.540  1406  7010 E OMX-VDEC-1080P: Unsupported output color format for c2d (2141391876)
08-30 11:06:24.540  1406  7010 E OMX-VDEC-1080P: Setting color format failed
08-30 11:06:24.544  1406  7010 D PlatformConfig: getInstance: Enter
08-30 11:06:24.544  1406  7010 D PlatformConfig: getInt32: Returning default
08-30 11:06:24.544  1406  7010 I OMX-VDEC-1080P: omx_vdec::component_init() success : fd=7
08-30 11:06:24.545 25924 26728 I ACodec  : Successfully allocate component [OMX.qcom.video.decoder.hevc]
08-30 11:06:24.545 25924 26728 D ACodec  : AllocateComponent OMX.qcom.video.decoder.hevc success
08-30 11:06:24.545 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Loaded
08-30 11:06:24.549 25924 26728 D OplusACodec: [configureCodec:L947] OplusFeedbackInfo  mFeedbackID:481238328320
08-30 11:06:24.549 25924 26728 D IAtlas  : IAtlas::init CallingPid 25924
08-30 11:06:24.549 25924 26728 D IAtlas  : IAtlas::init this 0x6f8a489640
08-30 11:06:24.549  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:24.549  1378  1429 D AtlasService: notify 1025 to client
08-30 11:06:24.550  1406  7010 E OMX-VDEC-1080P: Extension: OMX.google.android.index.storeANWBufferInMetadata not implemented
08-30 11:06:24.550  1406  7010 E OMX-VDEC-1080P: Extension: OMX.google.android.index.configureVideoTunnelMode not implemented
08-30 11:06:24.550  1406  7010 E OMX-VDEC-1080P: Extension: OMX.google.android.index.useAndroidNativeBuffer is supported
08-30 11:06:24.550  1406  7010 E OMX-VDEC-1080P: get_parameter: unknown param 7f000046
08-30 11:06:24.550  1406  7010 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.hevc, ??(0x7f000046)) ERROR: UnsupportedIndex(0x8000101a)
08-30 11:06:24.550 25924 26728 I ACodec  : configureCodec() mime = video/hevc
08-30 11:06:24.550 25924 26728 D OplusUtils: ACodec getComponentRole [92]: mime:video/hevc
08-30 11:06:24.550 25924 26728 I ExtendedACodec: setupVideoDecoder()
08-30 11:06:24.550 25924 26728 E OplusACodec: [GetVideoCodingTypeFromMime:L726] mime:video/hevc
08-30 11:06:24.552  1406  4204 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.hevc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:06:24.553  1406  4207 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.543  1406  1406 W HwBinder:1406_8: type=1400 audit(0.0:162981): avc: denied { read } for name="adreno_config.txt" dev="sda10" ino=4849726 scontext=u:r:mediacodec:s0 tcontext=u:object_r:gpudump_config_file:s0 tclass=file permissive=0
08-30 11:06:24.554  1406  4207 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.556  1406  4207 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.556 25924 26728 I ExtendedACodec: Decoder will be in frame by frame mode
08-30 11:06:24.557 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] input format is AMessage(what = 0x00000000) = {
08-30 11:06:24.557 25924 26728 D ACodec  :   int32_t adaptive-playback = 0
08-30 11:06:24.557 25924 26728 D ACodec  :   int32_t roi-on = 0
08-30 11:06:24.557 25924 26728 D ACodec  :   string mime = "video/hevc"
08-30 11:06:24.557 25924 26728 D ACodec  :   int32_t width = 1920
08-30 11:06:24.557 25924 26728 D ACodec  :   int32_t height = 2160
08-30 11:06:24.557 25924 26728 D ACodec  : }
08-30 11:06:24.558  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.558  1406  4204 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.558  1406  7010 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.558  1406  7010 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.hevc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:06:24.560 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] output format is AMessage(what = 0x00000000) = {
08-30 11:06:24.560 25924 26728 D ACodec  :   int32_t roi-on = 0
08-30 11:06:24.560 25924 26728 D ACodec  :   string mime = "video/raw"
08-30 11:06:24.560 25924 26728 D ACodec  :   int32_t stride = 1920
08-30 11:06:24.560 25924 26728 D ACodec  :   int32_t slice-height = 2160
08-30 11:06:24.560 25924 26728 D ACodec  :   int32_t color-format = 21
08-30 11:06:24.560 25924 26728 D ACodec  :   Buffer *image-data = 0x6fef6a1a40
08-30 11:06:24.560 25924 26728 D ACodec  :   Rect crop(0, 0, 1919, 2159)
08-30 11:06:24.560 25924 26728 D ACodec  :   Buffer hdr-static-info = {
08-30 11:06:24.560 25924 26728 D ACodec  :     00000000:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
08-30 11:06:24.560 25924 26728 D ACodec  :     00000010:  00 00 00 00 00 00 00 00  00                       .........
08-30 11:06:24.560 25924 26728 D ACodec  :   }
08-30 11:06:24.560 25924 26728 D ACodec  :   int32_t width = 1920
08-30 11:06:24.560 25924 26728 D ACodec  :   int32_t height = 2160
08-30 11:06:24.564 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Loaded->Idle
08-30 11:06:24.564 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] Allocating 6 buffers of size 8847360 (from 8847360 using PresetByteBuffer) on input port
08-30 11:06:24.573  1406  4207 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.573 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] Allocating 14 buffers of size 6221824 (from 6221824 using PresetByteBuffer) on output port
08-30 11:06:24.609  1003  1003 D OppoExLayer: ~Layer() sequence=16544, name=Surface(name=41da505 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity)/@0x5555167 - animation-leash#0@0xb40000700e97a000
08-30 11:06:24.609  1003  1003 D OppoExLayer: ~Layer() sequence=16539, name=41da505 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000702af3c000
08-30 11:06:24.611  1003  1003 D OppoExLayer: ~Layer() sequence=16542, name=com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#1@0xb40000702aecb000
08-30 11:06:24.617  1406  6934 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.618  1373  3005 W ResourceManagerService: Ignoring request to add new resource entry with value <= 0
08-30 11:06:24.621 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Idle->Executing
08-30 11:06:24.623 25924 26723 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet decoder initialize failed retCode:0
08-30 11:06:24.624 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] Now Executing
08-30 11:06:24.629  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-32 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:24.629  1517  2519 D OplusRssiMonitor: update rssi:-32
08-30 11:06:24.631  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:24.631  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:24.631  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:24.632  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-29 for "abc_ling"WPA_PSK
08-30 11:06:24.632  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:24.633  1517  2519 D WifiDataStall: L2 txTputKbps: 61380, rxTputKbps: 66000, L3 txTputKbps: 12, rxTputKbps: 762, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:24.634  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -30, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:24.634  1517  2519 D WifiScoreCard: txRate: 24 txSpeed: 96
08-30 11:06:24.634  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -30 txSpeed 96
08-30 11:06:24.634  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:24.634  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538622635 LastRssiPoll: -30 LastTxSpeedPoll: 96
08-30 11:06:24.634  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:24.634  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:24.634  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:24.636 25924 26723 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364784636 TS:1693364783410 cache buffer:0 w:1920 h:2160  count:0 .....
08-30 11:06:24.637  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -30 level: 4
08-30 11:06:24.638  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -30
08-30 11:06:24.638  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:24.638  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-30 f=2462 sc=0 link=96 tx=21.3, 1.7, 0.0  rx=113.3 bcn=9009520 [on:2940 tx:47 rx:68 period:3013] from screen [on:4943484 period:6574568] score=0
08-30 11:06:24.638  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:24.644  1517  5208 I WifiService: getConnectionInfo uid=10060
08-30 11:06:24.644  1517  5208 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:24.652  1406 26729 E OMX_COMMON:  Invalid key : -22 Cannot find key in map
08-30 11:06:24.671  1406 26729 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.672  1406  4207 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.672  1406  7009 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.673  1406  7009 I OMX-VDEC-1080P: C2D: Set Resolution, Interlace(false) Conversion(0XB -> 0X3) src(1920X2160) dest(1920X2160)
08-30 11:06:24.673  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.673  1406  4207 E OMXNodeInstance: getParameter(0xe498ae44:qcom.decoder.hevc, ??(0x7f000044)) ERROR: UnsupportedSetting(0x80001019)
08-30 11:06:24.675 25924 26728 D ACodec  : [OMX.qcom.video.decoder.hevc] output format is AMessage(what = 0x00000000) = {
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t roi-on = 0
08-30 11:06:24.675 25924 26728 D ACodec  :   string mime = "video/raw"
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t stride = 1920
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t slice-height = 2160
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t color-format = 21
08-30 11:06:24.675 25924 26728 D ACodec  :   Buffer *image-data = 0x6f8a579fc0
08-30 11:06:24.675 25924 26728 D ACodec  :   Rect crop(0, 0, 1919, 2159)
08-30 11:06:24.675 25924 26728 D ACodec  :   Buffer hdr-static-info = {
08-30 11:06:24.675 25924 26728 D ACodec  :     00000000:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ................
08-30 11:06:24.675 25924 26728 D ACodec  :     00000010:  00 00 00 00 00 00 00 00  00                       .........
08-30 11:06:24.675 25924 26728 D ACodec  :   }
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t width = 1920
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t height = 2160
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t color-range = 1
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t color-standard = 1
08-30 11:06:24.675 25924 26728 D ACodec  :   int32_t color-transfer = 3
08-30 11:06:24.678 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364784678 TS:1693364784743 diff:  73 fragment:3 cache:15 size:1920x2160 codec:20 len:2225 V-Count:20 IFrame:0....
08-30 11:06:24.683  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.683  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.690 25924 26733 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::onReceivedDecodeBufferImpl CT:1693364784689 cache len:6 size:6221824 offset:0 color:0x15 crop top:0 bottom:2159 left:0 right:1919 stride w:1920(1920) h:2160(2160) count:0....
08-30 11:06:24.690 25924 26733 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"ts":1693364784690,"m":"camera","did":"6ce1f26844bfce86f3zrdp","status":"first frame decoded.","tid":"no traceId"} ...
08-30 11:06:24.690 25924 26733 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] no sei exists!
08-30 11:06:24.693  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.693  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.699  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.699  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.701 25924 26733 I ThingCameraSDK: ThingAVSyncronizer::PushVideoFrame Port[0] CT:1693364784701 TS:1693364783410 width:1920 height:2160 size:1 count:0.
08-30 11:06:24.701 25924 26725 I ThingCameraSDK: ThingAVSyncronizer::VideoDispatchInRealTime Port[0] CT:1693364784701 TS:1693364783410 interTimems:0 size:1 cache:0 speed:1.000000 count:0 ....
08-30 11:06:24.702  1406  4207 E OMX-VDEC-1080P: Extension: OMX.QTI.index.config.video.getdsmode not implemented
08-30 11:06:24.705 25924 26733 I ThingCameraSDK: ThingAVModule::GetDrawParam Port[0] sei:{"agtx":{"time":1693364783017,"chn":0,"key":1,"iva":{"od":[{"obj":{"id":0,"rect": [371,282,1543,1653],"vel":[0,0],"cat":"PEDESTRIAN"}},{"obj":{"id":1,"rect": [1138,-53,1814,1654],"vel":[0,0],"cat":"PEDESTRIAN"}}]}}}
08-30 11:06:24.706 25924 26733 I ThingCameraSDK: VideoConvert::CreateFrame w:1920 h:2160 type:1...
08-30 11:06:24.706  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.706  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.713  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.713  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.723  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.739 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364784739 TS:1693364784799 diff:  32 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:10
08-30 11:06:24.776  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.784  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.814 25924 26723 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364784813 TS:1693364784077 cache buffer:8 w:1920 h:2160  count:10 .....
08-30 11:06:24.820  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.827  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.827  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.833  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.835  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.842  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.843  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.850  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.851  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.857  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.859  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.865  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.867  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.872  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 55ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653931 wlan0TxPtk=943279 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:24.874  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.874  1406 26730 I OMX-VDEC-1080P: C2D: Start color convertion
08-30 11:06:24.876 25924 26723 I ThingVideoDecodeSDK: ThingMediaCodecJniDecoder::DecodeH265Packet CT:1693364784876 TS:1693364784743 cache buffer:18 w:1920 h:2160  count:20 .....
08-30 11:06:24.880  1406 26730 W C2DColorConvert: calcLumaAlign: unknown format (3) passed for luma alignment number.
08-30 11:06:24.891 26734 26734 E xcrash_dumper: THREAD: ptrace GETREGSET failed, errno=3
08-30 11:06:25.166 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364785166 TS:1693364784959 diff: 306 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:14
08-30 11:06:25.166 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364785166 TS:1693364785214 diff:   0 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:20
08-30 11:06:25.167 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364785167 TS:1693364785010 diff: 286 fragment:3 cache: 4 size:1920x2160 codec:20 len:1006 V-Count:24 IFrame:0....
08-30 11:06:25.267   599   599 E SELinux : avc:  denied  { find } for interface=android.hardware.memtrack::IMemtrack sid=u:r:untrusted_app:s0:c30,c256,c512,c768 pid=25924 scontext=u:r:untrusted_app:s0:c30,c256,c512,c768 tcontext=u:object_r:hal_memtrack_hwservice:s0 tclass=hwservice_manager permissive=0
08-30 11:06:25.267 25924 25951 E memtrack: Couldn't load memtrack module
08-30 11:06:25.353 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364785353 TS:1693364785409 diff:  51 fragment:3 cache:10 size:1920x2160 codec:20 len:1125 V-Count:30 IFrame:0....
08-30 11:06:25.355 25924 26722 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364784414 size:640...
08-30 11:06:25.356 25924 26722 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364784445 size:640...
08-30 11:06:25.356 25924 26722 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364784478 size:640...
08-30 11:06:25.356 25924 26722 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364784509 size:640...
08-30 11:06:25.356 25924 26722 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364784575 size:640...
08-30 11:06:25.356 25924 26722 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364784605 size:640...
08-30 11:06:25.356 25924 26722 I ThingCameraSDK: ThingAVSyncronizer::ThrowSomeAudioFrame Port[0] overrun happend throw some audio packet TS:1693364784638 size:640...
08-30 11:06:25.545 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364785545 TS:1693364785598 diff:  40 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:30
08-30 11:06:25.555 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 173.397980 kbps packet cache:0, frame cache:0
08-30 11:06:25.625 25924 26728 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 23 fps, mOutputBufCnt = 15 fps, mRenderFrameCnt = 0 fps
08-30 11:06:25.629  1517  2519 D WN_S    : DT,tP=943279, dTP=8, rP=1653931, dRP=8 mIR=true, mRPLC=0
08-30 11:06:25.629  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:24.600  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:24.620  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:25.844  1517  1517 D OppoBaseBatteryService: send broadcast : oppo.intent.action.BATTERY_DATA_UPDATE
08-30 11:06:25.844  1517  1517 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1158 com.android.server.OppoBaseBatteryService$2.run:280 android.os.Handler.handleCallback:938 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:263
08-30 11:06:25.911  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 55ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653935 wlan0TxPtk=943283 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:25.950 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364785950 TS:1693364786014 diff:  70 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:40
08-30 11:06:26.016  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:26.025  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3443600
08-30 11:06:26.025  3234  3234 D DeviceInfoHidlClient: isPowerInfoNeverSent()=true
08-30 11:06:26.025  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:26.054  1517  3181 I ColorHansManager : pkg: com.tencent.mm,state: M -> F
08-30 11:06:26.055  1517  3181 I ColorHansManager : freeze uid: 10011 package: com.tencent.mm reason: Broadcast scene: LcdOnScene
08-30 11:06:26.056  5580  7502 D IHansComunication: HANS sendMessageToKernel: threadId = 514316025024, netLinkSetup = 1, type = PKG, targetUid = 10011, pkgCmd = ADD_ONE_UID
08-30 11:06:26.192 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364786083 ,count:2200
08-30 11:06:26.222 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:06:26.223 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364786223 TS:1693364786083 diff: 273 fragment:3 cache:20 size:1920x2160 codec:20 len:151149 V-Count:40 IFrame:1....
08-30 11:06:26.370 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364786370 TS:1693364786397 diff:  51 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:50
08-30 11:06:26.550  1517  1863 V OppoBaseWatchdog: @WatchDog_ error e: java.io.FileNotFoundException: /d/wakeup_sources: open failed: ENOENT (No such file or directory)
08-30 11:06:26.625 25924 26728 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 0 fps, mOutputBufCnt = 0 fps, mRenderFrameCnt = 0 fps
08-30 11:06:26.629 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 148.451141 kbps packet cache:0, frame cache:0
08-30 11:06:26.640  1517  5208 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:26.641  1517  5210 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:26.641  1517  5208 I WifiService: getConnectionInfo uid=1000
08-30 11:06:26.691 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364786691 TS:1693364786743 diff:  62 fragment:3 cache:30 size:1920x2160 codec:20 len:588 V-Count:50 IFrame:0....
08-30 11:06:26.747 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364786747 TS:1693364786814 diff:  61 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:60
08-30 11:06:26.885  1353  1379 D bspCriticalLog: thermal_monitor ddr-usr: open fail -1
08-30 11:06:26.885  1353  1379 D bspCriticalLog: thermal_monitor gpuss-0-usr: open fail -1
08-30 11:06:26.885  1353  1381 D bspCriticalLog: power_monitor cpu-1-0-usr: open fail -1
08-30 11:06:26.885  1353  1379 D bspCriticalLog: thermal_monitor cpu-1-0-usr: open fail -1
08-30 11:06:26.951  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 54ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653939 wlan0TxPtk=943287 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:27.132 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364787132 TS:1693364787197 diff:  20 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:70
08-30 11:06:27.196 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=830.0, y[0]=1611.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343798163, downTime=343798163, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:27.196 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=830.0, y[0]=1611.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343798163, downTime=343798163, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:27.197 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=830.0, y[0]=1611.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343798163, downTime=343798163, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:27.288   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:27.288   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:27.288   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:27.289   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:27.289   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:27.290   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:27.290   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:27.290   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:27.290   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:27.290   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:27.290   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:27.290   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:27.292   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:27.292   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:27.292   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:27.292   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:27.292   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:27.327   929   929 D ORMS_HAL: OrmsHalService write file /proc/sys/kernel/slide_boost_enabled - 1.
08-30 11:06:27.328   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:27.328   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:27.328   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:27.328   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:27.328   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:27.328   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:27.349 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364787349 TS:1693364787409 diff:  71 fragment:3 cache:40 size:1920x2160 codec:20 len:2275 V-Count:60 IFrame:0....
08-30 11:06:27.561 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364787561 TS:1693364787614 diff:  51 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:80
08-30 11:06:27.625 25924 26728 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 0 fps, mOutputBufCnt = 0 fps, mRenderFrameCnt = 0 fps
08-30 11:06:27.630  1517  2519 D WN_S    : DT,tP=943287, dTP=8, rP=1653939, dRP=8 mIR=true, mRPLC=0
08-30 11:06:27.630  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:27.640  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-32 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:27.640  1517  2519 D OplusRssiMonitor: update rssi:-32
08-30 11:06:27.641  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:27.641  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:27.641  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:27.644  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-29 for "abc_ling"WPA_PSK
08-30 11:06:27.644  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:27.645  1517  2519 D WifiDataStall: L2 txTputKbps: 56100, rxTputKbps: 66000, L3 txTputKbps: 10, rxTputKbps: 726, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:27.645  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -30, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:27.646  1517  2519 D WifiScoreCard: txRate: 22 txSpeed: 96
08-30 11:06:27.646  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -30 txSpeed 96
08-30 11:06:27.646  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:27.646  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538625647 LastRssiPoll: -30 LastTxSpeedPoll: 96
08-30 11:06:27.646  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:27.646  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:27.646  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:27.649  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -30
08-30 11:06:27.649  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -30 level: 4
08-30 11:06:27.649  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:27.649  1517  1991 I ColorHansManager : unfreeze uid: 10011 package: com.tencent.mm reason: Broadcast scene: LcdOnScene
08-30 11:06:27.650  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-30 f=2462 sc=0 link=96 tx=19.2, 2.7, 0.0  rx=109.1 bcn=9009548 [on:2945 tx:41 rx:61 period:3011] from screen [on:4946429 period:6577580] score=0
08-30 11:06:27.651  1517  1991 I ColorHansManager : pkg: com.tencent.mm,state: F -> M
08-30 11:06:27.653  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:27.655  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:06:27.656  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:27.685 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364787211,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364747fb4ItmZl","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":40434} ...
08-30 11:06:27.695 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 16.149010 kbps packet cache:0, frame cache:0
08-30 11:06:27.772   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:27.772   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:27.772   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:27.772   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:27.772   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:27.772 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=668.56305, y[0]=1733.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343798740, downTime=343798163, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:27.773   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:27.773   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:27.773   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:27.773   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:27.773   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:27.773   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:27.773   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:27.774  1517  2599 E ORMS_CORE: Unsupported action!!!
08-30 11:06:27.774   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:27.774   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:27.774   966   966 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:27.775   966   966 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:27.775   929   929 D ORMS_HAL: OrmsHalService write file /proc/sys/kernel/slide_boost_enabled - 0.
08-30 11:06:27.775   966   966 I ANDR-PERF-LM: FeedbackAPI: getFeedback() 60: app:com.tuya.smartiot feature:AppClassifier feedback = 1
08-30 11:06:27.777   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:27.777   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:27.777   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:27.777   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:27.777   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:27.777   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:27.780 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=668.56305, y[0]=1733.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343798740, downTime=343798163, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:27.929 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364787929 TS:1693364787999 diff:  20 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:90
08-30 11:06:27.991  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 53ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653949 wlan0TxPtk=943295 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:28.052 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364788052 TS:1693364788077 diff:  91 fragment:3 cache:50 size:1920x2160 codec:20 len:1264 V-Count:70 IFrame:0....
08-30 11:06:28.057  5580  7502 D IHansComunication: HansComunication::configCheckedUid-- 10011, type = 0
08-30 11:06:28.057  5580  7502 D IHansComunication: HANS sendMessageToKernel: threadId = 514316025024, netLinkSetup = 1, type = FROZEN_TRANS, targetUid = 10011, pkgCmd = PKG_CMD_MAX
08-30 11:06:28.166 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback {"p2p_3_0_cxx_https_request":"thing.m.rtc.log_1.0", "devId":""} here..
08-30 11:06:28.167 25924 26173 I ThingAvLoggerSDK: ThingSmartP2PSDK::HttpsRequestCallback https request callback here.....
08-30 11:06:28.311 25924 26172 I ThingAvLoggerSDK: ThingSmartP2PSDK::on_thing_p2p_rtc_log_cb_t msg:{"t":1693364787838,"v":"3.5.2","p":"rtc_session_stats","tid":"","s":"6ce1f26844bfce86f3zrdp1693364757dV3BEFRv","l":"ay1690445086544UqnKu","r":"6ce1f26844bfce86f3zrdp","o":0,"d":30399,"channels":[[0,292,208,292,208,3064,748,402,393,475,392,470],[1,0,1824332,0,1824332,9636,3384948,623,-1,517,393,517],[2,0,275264,0,275632,7524,627816,1093,-1,994,393,990],[330,3216,0,-240,0,562392,0,390,159,-1,-1,-1]]} ...
08-30 11:06:28.342 25924 26336 I ThingAvLoggerSDK: ThingSmartP2PSDK::thing_p2p_rtc_set_http_result.info:{"p2p_3_0_mqtt_msg_cxx_set_signaling":api:thing.m.rtc.log_1.0 content:{"success":true}}..
08-30 11:06:28.345 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364788345 TS:1693364788414 diff:  30 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:100
08-30 11:06:28.625 25924 26728 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 0 fps, mOutputBufCnt = 0 fps, mRenderFrameCnt = 0 fps
08-30 11:06:28.893  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:06:28.893  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=116,badLossCount=0,txLoss=0,mLinkDetectTimes= 607,mIndex =1
08-30 11:06:28.893  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 53, 0, 0, 0, 0, 676, 54, 0, 0, 0, 0, 676, 55, 0, 0, 0, 0, 676, 55, 0, 0, 0, 0, 676, 55, 0, 0, 0, 0]
08-30 11:06:28.893  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:06:28.893  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:06:28.893  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:06:28.894  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:06:28.894  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-30,mIndex =1,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12578597479
08-30 11:06:28.894  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:06:28.894  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:06:28.894  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:06:28.894  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:06:28.894  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:06:28.894  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:06:28.894  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:06:28.953 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364788743 ,count:2400
08-30 11:06:29.027 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364789027 TS:1693364788764 diff: 348 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:109
08-30 11:06:29.031  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 58ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653958 wlan0TxPtk=943306 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:29.085 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:06:29.086 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 116.112648 kbps packet cache:0, frame cache:0
08-30 11:06:29.086 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364789086 TS:1693364788743 diff: 469 fragment:3 cache:60 size:1920x2160 codec:20 len:151076 V-Count:80 IFrame:1....
08-30 11:06:29.088 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364789088 TS:1693364788799 diff:  61 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:110
08-30 11:06:29.127 30404 30444 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:06:29.185 30404 30452 D HoraeHelper: Thermal length:1
08-30 11:06:29.193 30404 30447 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:06:29.205 30404 30447 D HoraeHelper: skinThermal:36.855
08-30 11:06:29.260 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364789260 TS:1693364789218 diff:  71 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:120
08-30 11:06:29.350 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364789350 TS:1693364789409 diff:  71 fragment:3 cache:70 size:1920x2160 codec:20 len:660 V-Count:90 IFrame:0....
08-30 11:06:29.533 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364789533 TS:1693364789598 diff:   0 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:130
08-30 11:06:29.625 25924 26728 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 0 fps, mOutputBufCnt = 0 fps, mRenderFrameCnt = 0 fps
08-30 11:06:29.625  1378  1429 D AtlasService: clientsCount 1
08-30 11:06:29.625  1378  1429 D AtlasService: notify 1029 to client
08-30 11:06:29.631  1517  2519 D WN_S    : DT,tP=943306, dTP=19, rP=1653958, dRP=19 mIR=true, mRPLC=0
08-30 11:06:29.631  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:29.653  1517  5210 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:29.653  1517  3939 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:29.655  1517  5210 I WifiService: getConnectionInfo uid=1000
08-30 11:06:29.947 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364789947 TS:1693364790014 diff:  51 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:140
08-30 11:06:30.006 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364790006 TS:1693364790078 diff:  61 fragment:3 cache:80 size:1920x2160 codec:20 len:2181 V-Count:100 IFrame:0....
08-30 11:06:30.071  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 58ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653964 wlan0TxPtk=943312 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:30.097 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 18.639688 kbps packet cache:0, frame cache:0
08-30 11:06:30.332 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364790332 TS:1693364790397 diff:  30 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:150
08-30 11:06:30.363 25924 26591 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadAudioStream Port[0] audio rtp package recved ,count:800
08-30 11:06:30.626 25924 26728 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 0 fps, mOutputBufCnt = 0 fps, mRenderFrameCnt = 0 fps
08-30 11:06:30.649  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-29 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:30.649  1517  2519 D OplusRssiMonitor: update rssi:-29
08-30 11:06:30.650  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:30.650  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:30.650  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:30.650  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-29 for "abc_ling"WPA_PSK
08-30 11:06:30.650  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:30.650  1517  2519 D WifiDataStall: L2 txTputKbps: 64020, rxTputKbps: 66000, L3 txTputKbps: 45, rxTputKbps: 943, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:30.651  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -29, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:30.651  1517  2519 D WifiScoreCard: txRate: 26 txSpeed: 96
08-30 11:06:30.651  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -29 txSpeed 96
08-30 11:06:30.651  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:30.651  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538628652 LastRssiPoll: -29 LastTxSpeedPoll: 96
08-30 11:06:30.651  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:30.651  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:30.651  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:30.655  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -29
08-30 11:06:30.656  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:30.656  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:30.657  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:06:30.657  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:30.658  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -29 level: 4
08-30 11:06:30.659  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-29 f=2462 sc=0 link=96 tx=23.8, 1.6, 0.0  rx=128.3 bcn=9009578 [on:2940 tx:59 rx:69 period:3007] from screen [on:4949369 period:6580589] score=0
08-30 11:06:30.679 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364790678 TS:1693364790743 diff:  50 fragment:3 cache:90 size:1920x2160 codec:20 len:1140 V-Count:110 IFrame:0....
08-30 11:06:30.742 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364790742 TS:1693364790814 diff:  61 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:160
08-30 11:06:31.066  1517  2002 D OppoThermalStats: REPORT_UPDATE_CPU  ->  phoneTemp:360  preHeatThreshold:400
08-30 11:06:31.067  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:31.077  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3444800
08-30 11:06:31.077  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:31.111  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653968 wlan0TxPtk=943316 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:31.143 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364791143 TS:1693364791199 diff:  41 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:170
08-30 11:06:31.155 25924 26592 I ThingCameraSDK: ThingAVQualityMonitor::GatherVideoPacketInfo av_quality instantaneous bitrate 15.972981 kbps packet cache:0, frame cache:0
08-30 11:06:31.543 25924 26592 I ThingCameraSDK: ThingSmartIPC::CXX::ThingAvStreamReader::HandleReadVideoStream Port[0] video rtp package recved TS:1693364791410 ,count:2600
08-30 11:06:31.621 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364791621 TS:1693364791452 diff: 255 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:176
08-30 11:06:31.626 25924 26728 I OplusFeedbackInfo: [sendFPSInfo:L333] mInputBufCnt = 0 fps, mOutputBufCnt = 0 fps, mRenderFrameCnt = 0 fps
08-30 11:06:31.632  1517  2519 D WN_S    : DT,tP=943316, dTP=10, rP=1653968, dRP=10 mIR=true, mRPLC=0
08-30 11:06:31.632  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:31.712 25924 26591 I ThingCameraSDK: ThingAVCacheManager::PushAudioPacket Port[0] CT:1693364791712 TS:1693364791614 diff:   0 fragment:3 codec:133 sampleRate:8000 len:320 A-Count:180
08-30 11:06:31.715 25924 26592 I ThingCameraSDK: DEBUG [hevc]: w:1920 h:2160 fr:15 profile:0 level:150.000000
08-30 11:06:31.715 25924 26592 I ThingCameraSDK: ThingAVCacheManager::PushVideoPacket Port[0] CT:1693364791715 TS:1693364791410 diff: 439 fragment:3 cache:100 size:1920x2160 codec:20 len:151533 V-Count:120 IFrame:1....
08-30 11:06:31.769 25924 25924 D ViewRootImpl: enqueueInputEventMotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=84.0, y[0]=345.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343802736, downTime=343802736, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:31.770 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=84.0, y[0]=345.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343802736, downTime=343802736, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:31.770 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_DOWN, actionButton=0, id[0]=0, x[0]=84.0, y[0]=345.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343802736, downTime=343802736, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:31.843 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: processMotionEvent MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=84.0, y[0]=345.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343802811, downTime=343802736, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:31.843 25924 25924 D ViewRootImpl[TRCTSmartCameraPanelActivity]: dispatchPointerEvent handled=true, event=MotionEvent { action=ACTION_UP, actionButton=0, id[0]=0, x[0]=84.0, y[0]=345.0, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, classification=NONE, metaState=0, flags=0x0, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=343802811, downTime=343802736, deviceId=3, source=0x1002, displayId=0 }
08-30 11:06:31.873  1517  5210 V ColorZoomWindowManagerService: prepareZoomTransition: curStack=Task{564553c #1831 visible=true type=standard mode=fullscreen translucent=true A=10030:com.tuya.smartiot U=0 StackId=1831 sz=2}   nextStackTask{564553c #1831 visible=true type=standard mode=fullscreen translucent=true A=10030:com.tuya.smartiot U=0 StackId=1831 sz=2}
08-30 11:06:31.873  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestatePAUSING
08-30 11:06:31.873  1517  5210 D ActivityTrigger: ActivityTrigger activityPauseTrigger
08-30 11:06:31.874   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:31.874   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:31.874   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:31.874   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:31.874   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:31.874   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for GameOptimization
08-30 11:06:31.874   966  1041 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:31.874   966  1041 D ANDR-PERF-LM: Feature: getData() 112: data.data = 1
08-30 11:06:31.875   966  1041 I ANDR-PERF-LM: Core: lmMain() 391: runAsync for GameOptimization returned
08-30 11:06:31.875   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:31.875   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:31.875  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestatePAUSING
08-30 11:06:31.877  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:31.884  1517  5210 V WindowManager: Changing focus from Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} to null,diplayid=0
08-30 11:06:31.885  1517  5210 D Theia.NoFocusWindow: FocusWindowErrorScene CheckFreezeScreen
08-30 11:06:31.886   929   929 E ORMS_HAL: open /sys/class/devfreq/soc:qcom,cpu-cpu-llcc-bw/bw_hwmon/hyst_trigger_count failed(Permission denied)
08-30 11:06:31.888   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:31.888   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:31.888   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:31.888   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:31.888   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:31.888   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:31.890  1517  5210 I InputDispatcher: setFocusedApplication displayId=0 ActivityRecord{914d9e8 u0 com.oppo.launcher/.Launcher t2}
08-30 11:06:31.890  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateFINISHING
08-30 11:06:31.890  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateFINISHING
08-30 11:06:31.891  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateFINISHING
08-30 11:06:31.891  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateDESTROYING
08-30 11:06:31.891  1517  5210 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateDESTROYING
08-30 11:06:31.894 25924 25951 I Process : Sending signal. PID: 25924 SIG: 9
08-30 11:06:31.898  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:31.906  1517  5210 I InputDispatcher: Focus left window: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity} in display 0
08-30 11:06:31.919   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/io_percent not supported
08-30 11:06:31.919   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 2]
08-30 11:06:31.919   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/bw_hwmon/sample_ms not supported
08-30 11:06:31.919   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 8]
08-30 11:06:31.919   966  1040 E ANDR-PERF-OPTSHANDLER: Perflock resource /sys/class/devfreq/soc:qcom,cpubw/min_freq not supported
08-30 11:06:31.919   966  1040 E ANDR-PERF-RESOURCEQS: Failed to apply optimization [6, 0]
08-30 11:06:31.954  1406  4207 E OMXNodeInstance: !!! Observer died. Quickly, do something, ... anything...
08-30 11:06:31.969  1517  5210 D DisplayManagerService: Display listener for pid 26146 died.
08-30 11:06:31.969  1517 13105 I ActivityManager: Process com.google.android.webview:sandboxed_process0:org.chromium.content.app.SandboxedProcessService0:0 (pid 26146) has died: fg  BTOP
08-30 11:06:31.969  1517 13105 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1143 com.android.server.am.OppoExtraActivityManagerService.setKeyLockModeNormal:51 com.android.server.am.ActivityManagerService.appDiedLocked:4303 com.android.server.am.ActivityManagerService$AppDeathRecipient.binderDied:1782 android.os.IBinder$DeathRecipient.binderDied:305
08-30 11:06:31.969  1517  1984 I libprocessgroup: Successfully killed process cgroup uid 99068 pid 26146 in 0ms
08-30 11:06:31.970   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:31.970   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:31.970   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:31.970   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:31.970   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:31.970   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:31.970   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:31.971  1517 13105 W ActivityManager: Scheduling restart of crashed service com.tuya.smartiot/org.chromium.content.app.SandboxedProcessService0:0 in 1000ms for connection
08-30 11:06:31.974  3100  3100 I Zygote  : Process 26146 exited cleanly (0)
08-30 11:06:31.981 30022 30699 E RemoteGuardClient.DWB.ActivityMonitor: onProcessDied com.tuya.smartiot pid = 26146 uid = 10030
08-30 11:06:31.983 30022 30048 I RemoteGuardClient.DWB.ActivityMonitor: topActivities = []
08-30 11:06:31.988   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup22: Permission denied
08-30 11:06:31.988   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup7: Permission denied
08-30 11:06:31.973   663   663 W Binder:663_2: type=1400 audit(0.0:162982): avc: denied { read } for name="wakeup22" dev="sysfs" ino=66613 scontext=u:r:system_suspend:s0 tcontext=u:object_r:oppo_sys_motor_file:s0 tclass=dir permissive=0
08-30 11:06:31.973   663   663 W Binder:663_2: type=1400 audit(0.0:162983): avc: denied { open } for path="/sys/devices/platform/soc/c440000.qcom,spmi/spmi-0/spmi0-00/c440000.qcom,spmi:qcom,pm6150@0:qcom,pm6150_rtc/wakeup/wakeup7" dev="sysfs" ino=53464 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=0
08-30 11:06:31.989   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup5: Permission denied
08-30 11:06:31.973   663   663 W Binder:663_2: type=1400 audit(0.0:162984): avc: denied { open } for path="/sys/devices/virtual/diag/diag/wakeup5" dev="sysfs" ino=48140 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=0
08-30 11:06:31.990   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup8: Permission denied
08-30 11:06:31.990  1517  5210 D ConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ LISTEN id=1048, [ Capabilities: MMS&SUPL&NOT_RESTRICTED&TRUSTED&NOT_VPN Uid: 10030 AdministratorUids: [] RequestorUid: 10030 RequestorPackageName: com.tuya.smartiot] ], android.os.BinderProxy@521815b)
08-30 11:06:31.990  1517  5210 D ConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ TRACK_DEFAULT id=1046, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Uid: 10030 AdministratorUids: [] RequestorUid: 10030 RequestorPackageName: com.tuya.smartiot] ], android.os.BinderProxy@c0ffdf8)
08-30 11:06:31.991   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup6: Permission denied
08-30 11:06:31.991  1517  5210 D ConnectivityService: ConnectivityService NetworkRequestInfo binderDied(NetworkRequest [ LISTEN id=1047, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Uid: 10030 AdministratorUids: [] RequestorUid: 10030 RequestorPackageName: com.tuya.smartiot] ], android.os.BinderProxy@800e2d1)
08-30 11:06:31.991  1517  3119 I MediaFocusControl: AudioFocus  removeFocusStackEntryOnDeath(): removing entry for android.os.BinderProxy@c227136
08-30 11:06:31.991  1373  3005 E mediaserver: unlinkToDeath: removed reference to death recipient but unlink failed.
08-30 11:06:31.991  1517  2577 W AS.AudioDeviceBroker: Speaker client died
08-30 11:06:31.991  1517  2577 I AS.AudioDeviceBroker: In updateSpeakerphoneOn(), mForcedUseForCommExt: 0
08-30 11:06:31.991  1373  3005 E IPCThreadState: attemptIncStrongHandle(2): Not supported
08-30 11:06:31.992  1517  5209 I WindowManager: WIN DEATH: Window{6d8b026 u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity}
08-30 11:06:31.992  1517  5209 W InputDispatcher: Attempted to unregister already unregistered input channel '6d8b026 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity (server)'
08-30 11:06:31.992   999  1508 D AudioPolicyManagerCustom: setForceUse() usage 0, config 0, mPhoneState 0
08-30 11:06:31.992   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:06:31.993  1517  2559 D ConnectivityService: releasing NetworkRequest [ TRACK_DEFAULT id=1046, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED Uid: 10030 AdministratorUids: [] RequestorUid: 10030 RequestorPackageName: com.tuya.smartiot] ] (release request)
08-30 11:06:31.993   999  1508 I chatty  : uid=1041(audioserver) Binder:999_1 identical 6 lines
08-30 11:06:31.993   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:06:31.993   999  1508 W APM::AudioPolicyEngine: getDevicesForStrategy() unknown strategy: -1
08-30 11:06:31.973   663   663 W Binder:663_2: type=1400 audit(0.0:162986): avc: denied { open } for path="/sys/devices/platform/soc/888000.i2c/i2c-0/0-0028/wakeup/wakeup8" dev="sysfs" ino=56722 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=0
08-30 11:06:31.973   663   663 W Binder:663_2: type=1400 audit(0.0:162987): avc: denied { read } for name="wakeup6" dev="sysfs" ino=53439 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs_rtc:s0 tclass=dir permissive=0
08-30 11:06:31.995   797   797 I Zygote  : Process 25924 exited due to signal 9 (Killed)
08-30 11:06:31.995  1517 13105 E OppoThermalStats: Error getting package info: com.oppo.launcher
08-30 11:06:31.996  1517  3119 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
08-30 11:06:31.997  1517  3939 D DisplayManagerService: Display listener for pid 25924 died.
08-30 11:06:31.998  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:31.998  1517  3938 I WindowManager: WIN DEATH: Window{d67cf17 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity}
08-30 11:06:31.998  1517  3938 W InputDispatcher: Attempted to unregister already unregistered input channel 'd67cf17 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity (server)'
08-30 11:06:32.001  1517  2959 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
08-30 11:06:32.001  1517  5209 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
08-30 11:06:32.002  1517 13105 W Process : Unable to open /proc/25924/status
08-30 11:06:32.002  1517 13105 W ActivityManager: Process 25924 does not match uid 10030 ignore setting hits oom adj
08-30 11:06:32.006  1003  1003 D OppoExLayer: ~Layer() sequence=16435, name=6d8b026 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity#0@0xb40000701db67000
08-30 11:06:32.006  1003  1003 D OppoExLayer: ~Layer() sequence=16504, name=d67cf17 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e992000
08-30 11:06:32.008  1517  1517 I OppoPhoneWindowManager: KeyLockModeReceiver KeyLockMode: 0 ProcessName: com.google.android.webview:sandboxed_process0:org.chromium.content.app.SandboxedProcessService0:0
08-30 11:06:32.008  1003  1003 D OppoExLayer: ~Layer() sequence=16505, name=com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000702af39000
08-30 11:06:32.008  1003  1003 D OppoExLayer: ~Layer() sequence=16512, name=Bounds for - com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e819000
08-30 11:06:32.008  1003  1003 D OppoExLayer: ~Layer() sequence=16513, name=SurfaceView - com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e849000
08-30 11:06:32.008  1003  1003 D OppoExLayer: ~Layer() sequence=16514, name=Background for -SurfaceView - com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e850000
08-30 11:06:32.009  1517  1856 D OplusAppBwCore: onUidImportance: 99068, 1000
08-30 11:06:32.009  1517  1856 D OplusAppBwCore: onUidImportance: 10044, 100
08-30 11:06:32.010  5580  5582 E IHansComunication: HANS printMessageBody: RCVed message body: type = 0, port = 86870, caller_pid = 1517, caller_uid = 1000, target_pid = 8783, target_uid = 10034, pkg_cmd = -1
08-30 11:06:32.013  1517  3818 D TheiaCrashMonitor: com.tuya.smartiotcrash
08-30 11:06:32.013  1517  3818 I ActivityManager: Process com.tuya.smartiot (pid 25924) has died: prcp TOP
08-30 11:06:32.013  1517  3818 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1143 com.android.server.am.OppoExtraActivityManagerService.setKeyLockModeNormal:51 com.android.server.am.ActivityManagerService.appDiedLocked:4303 com.android.server.am.ActivityManagerService$AppDeathRecipient.binderDied:1782 android.os.IBinder$DeathRecipient.binderDied:305
08-30 11:06:32.013  1517  1984 I libprocessgroup: Successfully killed process cgroup uid 10030 pid 25924 in 0ms
08-30 11:06:32.014  1517  8815 D TheiaSocketClient: TheiaSend receive content : 4298113028:ApplicationFGCrash:1693364792013
08-30 11:06:32.014  1517  8815 D TheiaSocketClient: send message success
08-30 11:06:32.014  1517  3432 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1701 com.oplus.util.OplusStatisticsImpl.startService:216 com.oplus.util.OplusStatisticsImpl.sendDataToDCS:192 com.oplus.util.OplusStatisticsImpl.onCommonSync:84 com.oplus.util.OplusStatisticsImpl$1.run:124
08-30 11:06:32.014   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:32.014   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:32.014   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:32.014   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:32.014  1564  8817 I theia_socket: recv 4298113028:ApplicationFGCrash:1693364792013
08-30 11:06:32.014  1564  8817 I theia_socket: nowEvent is not KeyEvent
08-30 11:06:32.014   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:32.014   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:32.014   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:32.020 30022 30048 E Parcel  : Reading a NULL string not supported here.
08-30 11:06:32.022  1517  3818 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateDESTROYED
08-30 11:06:32.022  1517  3818 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateDESTROYED
08-30 11:06:32.024  1517  3818 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{51118d4 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity t1831 f}}
08-30 11:06:32.024  1517  3818 I OplusMirageDisplayManagerService: onAnimationFinished:
08-30 11:06:32.024  1517  3818 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateDESTROYED
08-30 11:06:32.025  1517  3818 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateDESTROYED
08-30 11:06:32.025  5580  5582 E IHansComunication: HANS printMessageBody: RCVed message body: type = 0, port = 86870, caller_pid = 1517, caller_uid = 1000, target_pid = 8783, target_uid = 10034, pkg_cmd = -1
08-30 11:06:32.025  1517  3818 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateDESTROYED
08-30 11:06:32.026  1517  3818 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag truestateRESUMED
08-30 11:06:32.026   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:32.026   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:32.026   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:32.026   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:32.026   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:32.026   966  1041 I ANDR-PERF-LM: Core: lmMain() 381: Calling runAsync for GameOptimization
08-30 11:06:32.026   966  1041 D ANDR-PERF-LM: Feature: lookup() 101: Feature Name = AppClassifier, total featuers = 3, featureFound = 1
08-30 11:06:32.026   966  1041 D ANDR-PERF-LM: Feature: getData() 112: data.data = 0
08-30 11:06:32.027   966  1041 I ANDR-PERF-LM: Core: lmMain() 391: runAsync for GameOptimization returned
08-30 11:06:32.027   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:32.027   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:32.027  1517  3818 I ColorHansManager : ColorHansManager : resume pkg: com.oppo.launcher, uid:10044, prev pkg: com.tuya.smartiot, prev uid: 10030
08-30 11:06:32.027   999  1508 D APM_AudioPolicyManager: setOutputDevice() output 13 device AUDIO_DEVICE_NONE force 0 delayMs 100
08-30 11:06:32.027  1517  3180 I ColorHansManager : enter fastfreezer
08-30 11:06:32.027  1517  3818 V ActivityTaskManager: Calling mServicetracker.OnActivityStateChange with flag falsestateRESUMED
08-30 11:06:32.028   999  1508 D OplusDualHeadPhoneEx: GetOplusDualHeadPhoneEx return exist one.
08-30 11:06:32.028  1517  2592 I MotorManagerService: notifyActivityChanged: mBackgroudPkg = com.tuya.smartiot mFocusPkg = com.oppo.launcher mIsSplitMode = true mBackActivity =  mFocusActivity = com.oppo.launcher.Launcher
08-30 11:06:32.028   999  1508 I chatty  : uid=1041(audioserver) Binder:999_1 identical 3 lines
08-30 11:06:32.030  1517  3448 V DCSEX-AppSwitchManager: OnAppSwitchObserver: onAppExit , info = OplusAppExitInfo = {  targetName = com.tuya.smartiot hasResumingActivity = true resumingPackageName = com.oppo.launcher resumingActivityName = com.oppo.launcher.Launcher resumingWindowMode = 1 isResumingMultiApp = false isResumingFirstStart = false extension = Bundle[{taskId=2, uid=10044}]}
08-30 11:06:32.030 30090 30160 I [0]DCS-StrategyManager: isNeedUpload: true, type: 1, appID: 0, logTag: , eventID:
08-30 11:06:32.030 30090 30160 I [0]DCS-BackgroundAppData: sendAppBgEvent: has no pkgName=com.oppo.launcher
08-30 11:06:32.030  1517  5965 D DCSEX-AppLaunchEventRecorder: onAppSwitch from = com.tuya.smartiot to = com.oppo.launcher
08-30 11:06:32.031  1517  5965 D DCSEX-AppLaunchEventRecorder: recordExitApp = com.tuya.smartiot
08-30 11:06:32.030 32429 32502 W OppoGuardElf: ThermalControlUtils: mForegroundPkg=com.oppo.launcher
08-30 11:06:32.031  5580  5582 E IHansComunication: HANS printMessageBody: RCVed message body: type = 0, port = 86870, caller_pid = 1517, caller_uid = 1000, target_pid = 8783, target_uid = 10034, pkg_cmd = -1
08-30 11:06:32.031  1517  3180 I ColorHansManager : freeze uid: 10011 package: com.tencent.mm reason: fastfreezer|10044 scene: FastFreezerScene
08-30 11:06:32.032  1517  3180 I ColorHansManager : freeze uid: 10053 package: com.redteamobile.roaming reason: fastfreezer|10044 scene: FastFreezerScene
08-30 11:06:32.032  1517  5965 E OplusTrack-ApkInfoUtil: java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.Object android.os.Bundle.get(java.lang.String)' on a null object reference
08-30 11:06:32.033  1517  5965 W System.err: java.lang.NullPointerException: Attempt to invoke virtual method 'java.lang.Object android.os.Bundle.get(java.lang.String)' on a null object reference
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.h.b.d(ApkInfoUtil.java:136)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.b.b.a(TrackEvent.java:141)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.b.b.<init>(TrackEvent.java:47)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.b.a.<init>(CommonBean.java:37)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.c.a(OplusTrack.java:223)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.e.a.a$a.a(AppLaunchEventRecorder.java:143)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.e.a.a$a.a(AppLaunchEventRecorder.java:102)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.e.a.-$$Lambda$2fHLmT8JZlr5OzkT2xnqiCVdLEk.onAppSwitch(Unknown Source:2)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.c.b.a(AppSwitchMonitor.java:97)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.c.b.lambda$yF2sSrETF4wpk07pjuI1ubPVnB8(Unknown Source:0)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.c.-$$Lambda$b$yF2sSrETF4wpk07pjuI1ubPVnB8.accept(Unknown Source:4)
08-30 11:06:32.033  1517  5965 W System.err: 	at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:832)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.c.b.b(AppSwitchMonitor.java:97)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.c.b.lambda$fX4Hi7f3z5t3AW9aa0q-E6iGF5w(Unknown Source:0)
08-30 11:06:32.033  1517  5965 W System.err: 	at com.oplus.statistics.c.-$$Lambda$b$fX4Hi7f3z5t3AW9aa0q-E6iGF5w.run(Unknown Source:4)
08-30 11:06:32.033  1517  5965 W System.err: 	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
08-30 11:06:32.033  1517  5965 W System.err: 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
08-30 11:06:32.033  1517  5965 W System.err: 	at java.lang.Thread.run(Thread.java:923)
08-30 11:06:32.033  1517  3180 I ColorHansManager : freeze uid: 10238 package: com.coloros.screenrecorder reason: fastfreezer|10044 scene: FastFreezerScene
08-30 11:06:32.033  1517  5965 W OplusTrack-TrackEvent: appId is empty
08-30 11:06:32.033  5580  5582 E IHansComunication: HANS printMessageBody: RCVed message body: type = 0, port = 86870, caller_pid = 1517, caller_uid = 1000, target_pid = 8783, target_uid = 10034, pkg_cmd = -1
08-30 11:06:32.034  1517 12848 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1701 com.oplus.statistics.d.e.a:49 com.oplus.statistics.d.d.a:28 com.oplus.statistics.a.c.a:14 com.oplus.statistics.c.b:264
08-30 11:06:32.038 29767 29783 E AppFeatureProviderUtils: getBoolean:
08-30 11:06:32.038 29767 29783 E AppFeatureProviderUtils: getAppFeatureCursor:
08-30 11:06:32.038 29767 29783 E AppFeatureProviderUtils: getAppFeatureCursor: query
08-30 11:06:32.039  1517  3448 I ColorResourcePreloadManager: resume pkg: com.oppo.launcher, uid:10044, prev pkg: com.tuya.smartiot, prev uid: 10030
08-30 11:06:32.039  1517  3448 V DCSEX-AppSwitchManager: OnAppSwitchObserver: onAppEnter , info = OplusAppEnterInfo = {  windowMode = 1 targetName = com.oppo.launcher multiApp = false firstStart = false launchedFromPackage = null intent = Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.oppo.launcher/.Launcher } extension = Bundle[{taskId=2, uid=10044}]}
08-30 11:06:32.041 30330 30352 D ZoomAppController: ignore onAppEnter: Invalid cvActionFlag = 0
08-30 11:06:32.042  3328  3328 E Parcel  : Reading a NULL string not supported here.
08-30 11:06:32.044 29767 29783 E AppFeatureProviderUtils: getStringForFeature value : true
08-30 11:06:32.044 29767 29783 E AppFeatureProviderUtils: getBoolean: v != null
08-30 11:06:32.046  1517  1860 W ActivityManager: setHasOverlayUi called on unknown pid: 25924
08-30 11:06:32.047 30022 30699 I RemoteGuardClient.DWB.ActivityMonitor: onForegroundActivitiesChanged 3328,10044,foreground true pkg= oppo.uid.launcher:10044
08-30 11:06:32.048  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.048  3328  3328 E Parcel  : Reading a NULL string not supported here.
08-30 11:06:32.051  1517  1517 I OppoPhoneWindowManager: KeyLockModeReceiver KeyLockMode: 0 ProcessName: com.tuya.smartiot
08-30 11:06:32.052  1003  1003 D OppoExLayer: ~Layer() sequence=16425, name=Task=1831#0@0xb40000700e96a000
08-30 11:06:32.052  1003  1003 D OppoExLayer: ~Layer() sequence=16503, name=ActivityRecord{51118d4 u0 com.tuya.smartiot/com.thingclips.smart.ipc.camera.rnpanel.activity.TRCTSmartCameraPanelActivity#0@0xb40000700e974000
08-30 11:06:32.052  1003  1003 D OppoExLayer: ~Layer() sequence=16434, name=ActivityRecord{e5f331c u0 com.tuya.smartiot/com.thingclips.smart.hometab.activity.FamilyHomeActivity#0@0xb40000701db38000
08-30 11:06:32.058  1517  2959 D OppoDisplayPolicy: com.oppo.launcher, change system app cutoutMode: color always
08-30 11:06:32.060  1517 25148 E ANDR-PERF-JNI: UXEngine Trigger - Returning null
08-30 11:06:32.052  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.061  1517  2959 V WindowManager: Changing focus from null to Window{3372de u0 com.oppo.launcher/com.oppo.launcher.Launcher},diplayid=0
08-30 11:06:32.063  1517  2959 D Theia.NoFocusWindow: FocusWindowErrorScene cancelCheckFreezeScreen
08-30 11:06:32.068  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.069  3328  3328 E Launcher.ColorBubbleTextView: mForceHideDot is false
08-30 11:06:32.069  3328  3328 I chatty  : uid=10044(com.oppo.launcher) identical 2 lines
08-30 11:06:32.070  3328  3328 E Launcher.ColorBubbleTextView: mForceHideDot is false
08-30 11:06:32.076  1003  1746 D DispPerfService: onframeavailable pid=3328, slot=0, seq=16547, name=com.oppo.launcher:com.oppo.launcher/com.oppo.launcher.Launcher#0
08-30 11:06:32.068  1517  1860 I chatty  : uid=1000(system) android.display identical 3 lines
08-30 11:06:32.074  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.078  1517  1861 V WindowManager: mIsWallpaper: setAlpha ok mShownAlpha = 0.98
08-30 11:06:32.081  2938  2938 D OplusWallpaperServiceHelper: isNightMode is false
08-30 11:06:32.081  2938  2938 I OplusWallpaperServiceHelper: getDarkModeWallpaperWindowAlpha. nightMode = false
08-30 11:06:32.084  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.085  1003  1003 D OppoExLayer: ~Layer() sequence=16545, name=Surface(name=74ffb6 StatusBar)/@0xbaad1b7 - animation-leash#1@0xb40000702aece000
08-30 11:06:32.085  1003  1003 D OppoExLayer: ~Layer() sequence=16546, name=Surface(name=29f1a38 NavigationBar0)/@0xe2b3d24 - animation-leash#0@0xb40000702af88000
08-30 11:06:32.086  1517  5210 I InputDispatcher: Focus entered window: Window{3372de u0 com.oppo.launcher/com.oppo.launcher.Launcher} in display 0
08-30 11:06:32.092  1003  1003 D OppoExSurfaceFlinger: RESOLUTIONSWITCH get resolution (1080, 2400) for config 0 !
08-30 11:06:32.092  1003  1003 I chatty  : uid=1000(system) /system/bin/surfaceflinger identical 1 line
08-30 11:06:32.097  1517  3566 D InputMethodManagerService: isSecurity: attribute.packageName=com.oppo.launcher
08-30 11:06:32.097  1517  3566 D InputMethodManagerService: isSecurity= false (  enable=true needShow=false inBlackList=false  isExist=true )
08-30 11:06:32.085  1517  1860 I chatty  : uid=1000(system) android.display identical 1 line
08-30 11:06:32.089  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.100  1517  3566 D ColorInputMethodManagerServiceEx: onHandleImeWindowVisibleStatus handledVis: 0, switcher visible: 0, switcher active: 0, needsToShowImeSwitcher: false
08-30 11:06:32.100  1517  3566 D OplusVerificationCodeController: notifyImeAttributeChanged: 64false
08-30 11:06:32.100  1517  3818 D ColorAppListInterceptManager: shouldFilterTask
08-30 11:06:32.100  1517  3818 D ColorAppListInterceptManager: shouldFilterTask::packageName = com.tuya.smartiot
08-30 11:06:32.100  1517  3818 D ColorAppListInterceptManager: shouldFilterTask::packageName = com.android.mms
08-30 11:06:32.101  1517  3818 D ColorAppListInterceptManager: shouldFilterTask
08-30 11:06:32.101  1517  3818 D ColorAppListInterceptManager: shouldFilterTask::packageName = com.android.settings
08-30 11:06:32.101  1517  3818 D ColorAppListInterceptManager: shouldFilterTask::packageName = com.google.android.captiveportallogin
08-30 11:06:32.107  1517  3566 D ColorAppListInterceptManager: shouldFilterTask
08-30 11:06:32.107  1517  3566 D ColorAppListInterceptManager: shouldFilterTask::packageName = com.tuya.smartiot
08-30 11:06:32.107  1517  3566 D ColorAppListInterceptManager: shouldFilterTask::packageName = com.android.mms
08-30 11:06:32.107  1517  3566 D ColorAppListInterceptManager: shouldFilterTask::packageName = com.android.settings
08-30 11:06:32.107  1517  3566 D ColorAppListInterceptManager: shouldFilterTask::packageName = com.google.android.captiveportallogin
08-30 11:06:32.111  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.111  1517  1856 D OplusAppBwCore: onUidImportance: 10030, 300
08-30 11:06:32.113  1517  3119 D AS.AudioService: getParameters() keyValuePairs:OPLUS_AUDIO_GET_FOCUS_STACK
08-30 11:06:32.113  5580  5582 E IHansComunication: HANS printMessageBody: RCVed message body: type = 0, port = 86870, caller_pid = 1517, caller_uid = 1000, target_pid = 8783, target_uid = 10034, pkg_cmd = -1
08-30 11:06:32.114 32429 32502 W OppoGuardElf: ThermalControllHandler: tempLevel=5,userMode=3,gameUserMode=-1,appType=-1,envTempType=1,appStates=[]
08-30 11:06:32.114  1517 13105 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:32.115 32429 32502 W OppoGuardElf: ThermalControllerCenter: mSafetyState=10000
08-30 11:06:32.115 32429 32502 W OppoGuardElf: ThermalControllHandler: tempGear=5,configItemName=common_config
08-30 11:06:32.116 32429 32523 W OppoGuardElf: ThermalControllHandler: MSG_THERMAL_CONTROL_CATEGORY_CHANGED
08-30 11:06:32.117 30090 30160 I [0]DCS-StrategyManager: isNeedUpload: true, type: 2006, appID: 20200, logTag: launch, eventID: launch
08-30 11:06:32.117  1517  3939 I WifiService: releaseMulticastLock uid=10030
08-30 11:06:32.120 30022 30699 E RemoteGuardClient.DWB.ActivityMonitor: onProcessDied com.tuya.smartiot pid = 25924 uid = 10030
08-30 11:06:32.120 26030 26030 I Process : Sending signal. PID: 26030 SIG: 9
08-30 11:06:32.122  4292  4308 E oiface  : packageSwitch pkg com.oppo.launcher, enter
08-30 11:06:32.122  4292  4308 E oiface  : current package is com.oppo.launcher and pid is 3328
08-30 11:06:32.123  1517  2959 D OppoDisplayPolicy: com.android.systemui, change system app cutoutMode: color always
08-30 11:06:32.125 30090 30160 I [0]DCS-StrategyManager: isNeedUpload: true, type: 2006, appID: 20120, logTag: CriticalLog, eventID: Theia
08-30 11:06:32.129  1517  2519 D WifiVendorHal: installPacketFilter filter length 235
08-30 11:06:32.131  1517  2519 D WifiClientModeImpl:  DefaultState screen=on len=235
08-30 11:06:32.139  4292  4302 E oiface  : Average freq 2206894 for 68s.
08-30 11:06:32.139  4292  4302 E oiface  : Average freq 1659932 for 68s.
08-30 11:06:32.123  1517  1517 W Binder:1517_7: type=1400 audit(0.0:162988): avc: denied { read } for name="freq_table_mhz" dev="sysfs" ino=48629 scontext=u:r:system_server:s0 tcontext=u:object_r:vendor_sysfs_kgsl:s0 tclass=file permissive=0
08-30 11:06:32.127  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.140  1517  2959 E ORMS_Platform : OplusResourceManagerPlatformUtils: readFile function exception:/sys/devices/platform/soc/5000000.qcom,kgsl-3d0/kgsl/kgsl-3d0/freq_table_mhz: open failed: EACCES (Permission denied)
08-30 11:06:32.140  4292  4302 E oiface  : get gpu freq table failed
08-30 11:06:32.146  4292  4302 E oiface  : client  not found, skipped
08-30 11:06:32.146  4292  4302 D oiface  : forground package is com.oppo.launcher
08-30 11:06:32.151  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653984 wlan0TxPtk=943332 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:32.166  1517  5210 E ORMS_Platform : OplusResourceManagerPlatformUtils: readFile function exception:/sys/devices/platform/soc/5000000.qcom,kgsl-3d0/kgsl/kgsl-3d0/freq_table_mhz: open failed: EACCES (Permission denied)
08-30 11:06:32.166  4292  4302 E oiface  : get gpu freq table failed
08-30 11:06:32.153  1517  1517 W Binder:1517_1E: type=1400 audit(0.0:162989): avc: denied { read } for name="freq_table_mhz" dev="sysfs" ino=48629 scontext=u:r:system_server:s0 tcontext=u:object_r:vendor_sysfs_kgsl:s0 tclass=file permissive=0
08-30 11:06:32.177  1517  3939 D DisplayManagerService: Display listener for pid 26030 died.
08-30 11:06:32.177  1517  5210 I ActivityManager: Process com.tuya.smartiot:monitor (pid 26030) has died: fg  SVC
08-30 11:06:32.177  1517  5210 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1143 com.android.server.am.OppoExtraActivityManagerService.setKeyLockModeNormal:51 com.android.server.am.ActivityManagerService.appDiedLocked:4303 com.android.server.am.ActivityManagerService$AppDeathRecipient.binderDied:1782 android.os.IBinder$DeathRecipient.binderDied:305
08-30 11:06:32.178   797   797 I Zygote  : Process 26030 exited due to signal 9 (Killed)
08-30 11:06:32.178   966   966 I ANDR-PERF-LM: LMPerfGlue: perfmodule_submit_request() 132: perfmodule_submit_request()
08-30 11:06:32.179   966   966 I ANDR-PERF-LM: Core: getInstance() 84: LM getInstance
08-30 11:06:32.179   966   966 I ANDR-PERF-LM: WQ: push() 59: LMTriggerQ push() size=0
08-30 11:06:32.179   966   966 I ANDR-PERF-LM: WQ: push() 61: LMTriggerQ push() done size=1
08-30 11:06:32.179   966  1041 I ANDR-PERF-LM: WQ: pop() 42: LMTriggerQ pop() done size=0
08-30 11:06:32.179   966  1041 I ANDR-PERF-LM: Core: lmMain() 373: Waiting on trigger Queue
08-30 11:06:32.179   966  1041 I ANDR-PERF-LM: WQ: pop() 31: LMTriggerQ pop() size=0
08-30 11:06:32.181 30022 30699 E RemoteGuardClient.DWB.ActivityMonitor: onProcessDied com.tuya.smartiot pid = 26030 uid = 10030
08-30 11:06:32.184  1517  1517 I OppoPhoneWindowManager: KeyLockModeReceiver KeyLockMode: 0 ProcessName: com.tuya.smartiot:monitor
08-30 11:06:32.187  1517  1984 I libprocessgroup: Successfully killed process cgroup uid 10030 pid 26030 in 10ms
08-30 11:06:32.194 32429 12484 W CursorWindow: Window is full: requested allocation 72 bytes, free space 15 bytes, window size 2097152 bytes
08-30 11:06:32.203  1517  2002 I WifiService: getSupportedFeatures uid=1000
08-30 11:06:32.203  1517  2002 D WifiAsyncChannel.WifiService: sendMessageSynchronously sendMessageSynchronously.send message=131133
08-30 11:06:32.204  1517  2519 D WifiClientModeImpl:  DefaultState screen=on uid=1000 0 0
08-30 11:06:32.204  1517  2002 D WifiAsyncChannel.WifiService: sendMessageSynchronously sendMessageSynchronously.recv message=131133 sendingUid=1000
08-30 11:06:32.209  1517  2002 I WifiService: getWifiActivityEnergyInfoAsync uid=1000
08-30 11:06:32.209  1517  2002 I WifiService: getWifiActivityEnergyInfo uid=1000
08-30 11:06:32.209  1517  2002 I WifiService: getSupportedFeatures uid=1000
08-30 11:06:32.209  1517  2002 D WifiAsyncChannel.WifiService: sendMessageSynchronously sendMessageSynchronously.send message=131133
08-30 11:06:32.210  1517  2519 D WifiClientModeImpl:  DefaultState screen=on uid=1000 0 0
08-30 11:06:32.210  1517  2002 D WifiAsyncChannel.WifiService: sendMessageSynchronously sendMessageSynchronously.recv message=131133 sendingUid=1000
08-30 11:06:32.214  1517  2002 D WifiAsyncChannel.WifiService: sendMessageSynchronously sendMessageSynchronously.send message=131135
08-30 11:06:32.217  3328  3328 E Launcher.ColorBubbleTextView: mForceHideDot is false
08-30 11:06:32.218  3328  3328 I chatty  : uid=10044(com.oppo.launcher) identical 8 lines
08-30 11:06:32.219  3328  3328 E Launcher.ColorBubbleTextView: mForceHideDot is false
08-30 11:06:32.224  1517  2002 D WifiAsyncChannel.WifiService: sendMessageSynchronously sendMessageSynchronously.recv message=131135 sendingUid=1000
08-30 11:06:32.224  1517  2519 D WifiClientModeImpl:  ConnectModeState screen=on uid=1000 0 0
08-30 11:06:32.226  1406  4207 I OMX-VDEC-1080P: omx_vdec::component_deinit() complete
08-30 11:06:32.226 30022 30048 E Parcel  : Reading a NULL string not supported here.
08-30 11:06:32.229  1406  4207 I OMX-VDEC-1080P: Exit OMX vdec Destructor: fd=7
08-30 11:06:32.233  3328  3328 E Launcher.ColorBubbleTextView: mForceHideDot is false
08-30 11:06:32.233  3328  3328 I chatty  : uid=10044(com.oppo.launcher) identical 1 line
08-30 11:06:32.238 30022 30048 I RemoteGuardClient.DWB.ActivityMonitor: topActivities = []
08-30 11:06:32.239 30022 30048 I RemoteGuardClient.DWB.ActivityMonitor: topActivities = []
08-30 11:06:32.240   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup22: Permission denied
08-30 11:06:32.240   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup7: Permission denied
08-30 11:06:32.241   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup5: Permission denied
08-30 11:06:32.242   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup1: Permission denied
08-30 11:06:32.243   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup8: Permission denied
08-30 11:06:32.243 30022 30048 I RemoteGuardClient.DWB.ActivityMonitor: topActivities = []
08-30 11:06:32.243   663   670 E android.system.suspend@1.0-service: Error opening kernel wakelock stats for: wakeup6: Permission denied
08-30 11:06:32.244   599   599 I hwservicemanager: getTransport: Cannot find entry android.hardware.power.stats@1.0::IPowerStats/default in either framework or device manifest.
08-30 11:06:32.245   599   599 I hwservicemanager: getTransport: Cannot find entry android.hardware.power@1.0::IPower/default in either framework or device manifest.
08-30 11:06:32.245  1517  2002 E BatteryStatsService: Unable to load Power Hal or power.stats HAL
08-30 11:06:32.299  1517  1861 V ColorZoomWindowManagerService: onAnimationFinished:  r = ActivityRecord{914d9e8 u0 com.oppo.launcher/.Launcher t2}
08-30 11:06:32.299  1517  1861 I ColorAppSwitchManagerService:  handleAppVisible , r = ActivityRecord{914d9e8 u0 com.oppo.launcher/.Launcher t2}
08-30 11:06:32.299  1517  1861 I OplusMirageDisplayManagerService: onAnimationFinished:
08-30 11:06:32.300  1517  3180 I ColorHansManager : unfreeze uid: 10053 package: com.redteamobile.roaming reason: F-direct scene: FastFreezerScene
08-30 11:06:32.301  1517  3180 I ColorHansManager : unfreeze uid: 10238 package: com.coloros.screenrecorder reason: F-direct scene: FastFreezerScene
08-30 11:06:32.302  1517  3180 I ColorHansManager : unfreeze uid: 10011 package: com.tencent.mm reason: F-direct scene: FastFreezerScene
08-30 11:06:32.303  1517  3180 I ColorHansManager : uid: 10011, state: M -> D
08-30 11:06:32.303  1517  3180 I ColorHansManager : exit fastfreezer, reason:F-direct
08-30 11:06:32.303  1517  3180 D OppoBasePowerManagerService: do restore jobs
08-30 11:06:32.304  1517  3181 I ColorHansManager : stateRToFFreeze--imporant case: pkgName: com.tencent.mm, reason: lastResumeProtect
08-30 11:06:32.305  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.314  1003  1003 D OppoExLayer: ~Layer() sequence=16550, name=Surface(name=Task=2)/@0xa09e1de - animation-leash#0@0xb40000700e8e4000
08-30 11:06:32.318  1517  1860 I chatty  : uid=1000(system) android.display identical 2 lines
08-30 11:06:32.400  1517  1860 D PowerManagerService: setScreenBrightnessOverrideFromWindowManagerInternal brightness=NaN mScreenBrightnessOverrideFromWindowManager=NaN
08-30 11:06:32.467  1517  2586 D JobScheduler.Temperature: get temperature=36.97
08-30 11:06:32.657  1517  5210 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:32.657  1517  2959 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:32.657  1517  5210 I WifiService: getConnectionInfo uid=1000
08-30 11:06:33.192  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:33.634  1517  2519 D WN_S    : DT,tP=943334, dTP=18, rP=1653986, dRP=18 mIR=true, mRPLC=0
08-30 11:06:33.634  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:33.656  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-29 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:33.656  1517  2519 D OplusRssiMonitor: update rssi:-29
08-30 11:06:33.657  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:33.657  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:33.657  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:33.657  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-29 for "abc_ling"WPA_PSK
08-30 11:06:33.657  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:33.657  1517  2519 D WifiDataStall: L2 txTputKbps: 62040, rxTputKbps: 66000, L3 txTputKbps: 17, rxTputKbps: 1174, TxTrafficHigh: true, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:33.658  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -29, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:33.658  1517  2519 D WifiScoreCard: txRate: 20 txSpeed: 96
08-30 11:06:33.658  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -29 txSpeed 96
08-30 11:06:33.658  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:33.658  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538631659 LastRssiPoll: -29 LastTxSpeedPoll: 96
08-30 11:06:33.658  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:33.658  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:33.658  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:33.659  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -29 level: 4
08-30 11:06:33.660  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-29 f=2462 sc=0 link=96 tx=17.9, 1.3, 0.0  rx=180.5 bcn=9009607 [on:2935 tx:36 rx:75 period:2999] from screen [on:4952304 period:6583589] score=0
08-30 11:06:33.661  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -29
08-30 11:06:33.661  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:33.661  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:33.662  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:06:33.662  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:33.893  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:06:33.894  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=0 dTxTotal=134,badLossCount=0,txLoss=0,mLinkDetectTimes= 608,mIndex =0
08-30 11:06:33.894  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[676, 59, 0, 0, 0, 0, 676, 59, 0, 0, 0, 0, 676, 59, 0, 0, 0, 0, 676, 58, 0, 0, 0, 0, 676, 58, 0, 0, 0, 0]
08-30 11:06:33.894  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:06:33.894  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:06:33.894  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:06:33.895  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:06:33.895  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-29,mIndex =0,score= 79,hls=false,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12579349829
08-30 11:06:33.895  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:06:33.895  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:06:33.896  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:06:33.896  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:06:33.896  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:06:33.896  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:06:33.896  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:06:34.048  4348  5498 I Athena  : MemoryGuardAction: triggerMemory:2000MB, availMemory:4695MB
08-30 11:06:34.049  3328  3710 D Launcher.: panicValue = false
08-30 11:06:34.055  1517  1517 D OppoBaseBatteryService: send broadcast : oppo.intent.action.BATTERY_DATA_UPDATE
08-30 11:06:34.056  1517  1517 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1158 com.android.server.OppoBaseBatteryService$2.run:280 android.os.Handler.handleCallback:938 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:263
08-30 11:06:34.056  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:34.066  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3445900
08-30 11:06:34.066  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:34.095 30404 30452 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:06:34.097 30404 30452 D HoraeHelper: Thermal length:1
08-30 11:06:34.193 30404 30444 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:06:34.232  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:35.002  1517  3566 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
08-30 11:06:35.015  1517  3566 I system_server: oneway function results will be dropped but finished with status OK and parcel size 4
08-30 11:06:35.273  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:676kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:35.635  1517  2519 D WN_S    : Didn't send and receive any pkt.
08-30 11:06:35.635  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:35.662  1517  3566 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:35.663  1517  3939 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:35.663  1517  3566 I WifiService: getConnectionInfo uid=1000
08-30 11:06:36.030  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3445900
08-30 11:06:36.030  3234  3234 D DeviceInfoHidlClient: isPowerInfoNeverSent()=true
08-30 11:06:36.030  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:36.312  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:909kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:36.666  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-20 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:36.666  1517  2519 D OplusRssiMonitor: update rssi:-20
08-30 11:06:36.667  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:36.668  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:36.668  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:36.668  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-23 for "abc_ling"WPA_PSK
08-30 11:06:36.668  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:36.668  1517  2519 D WifiDataStall: L2 txTputKbps: 62700, rxTputKbps: 66000, L3 txTputKbps: 3, rxTputKbps: 3949, TxTrafficHigh: false, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:36.669  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -20, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:36.669  1517  2519 D WifiScoreCard: txRate: 9 txSpeed: 96
08-30 11:06:36.669  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -20 txSpeed 96
08-30 11:06:36.669  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:36.669  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538634670 LastRssiPoll: -20 LastTxSpeedPoll: 96
08-30 11:06:36.669  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:36.669  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:36.669  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:36.671  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -20 level: 4
08-30 11:06:36.673  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -20
08-30 11:06:36.676  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-20 f=2462 sc=0 link=96 tx=7.2, 0.9, 0.0  rx=453.4 bcn=9009638 [on:2658 tx:6 rx:209 period:3015] from screen [on:4954962 period:6586605] score=0
08-30 11:06:36.681  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:36.682  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:36.683  1517  5210 I WifiService: getConnectionInfo uid=10060
08-30 11:06:36.683  1517  5210 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:37.352  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:1000kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:37.636  1517  2519 D WN_S    : Didn't send and receive any pkt.
08-30 11:06:37.636  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:38.392  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:1000kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:38.683  1517  5210 I WifiService: getWifiEnabledState uid=1000
08-30 11:06:38.683  1517  3566 I WifiService: getWifiApEnabledState uid=1000
08-30 11:06:38.684  1517  5210 I WifiService: getConnectionInfo uid=1000
08-30 11:06:38.895  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_FETCH
08-30 11:06:38.896  1517  2519 D WN_S    : calculateLinkLossScore key:"a***SKlinkLossScore=0 dTxBad=4 dTxTotal=6400,badLossCount=0,txLoss=0.06,mLinkDetectTimes= 609,mIndex =1
08-30 11:06:38.896  1517  2519 W OplusSlaManager_RTT: getRttAndSpeed(5):[1000, 59, 0, 0, 0, 0, 1000, 59, 0, 0, 0, 0, 909, 59, 0, 0, 0, 0, 676, 59, 0, 0, 0, 0, 676, 59, 0, 0, 0, 0]
08-30 11:06:38.896  1517  2519 D WN_S    : speed and rtt decreased 0 points.
08-30 11:06:38.896  1517  2519 D WN_S    : rssi decreased 0 points.
08-30 11:06:38.896  1517  2519 D WN_S    : tcp retransmission and dns delay decreased 0 points.
08-30 11:06:38.897  1517  2519 D WN_S    : getNetworkScore score=97 netId=216
08-30 11:06:38.897  1517  2519 D WN_S    : updateRecordLinkQuality key:"a***SK,rssi=-20,mIndex =1,score= 79,hls=true,mInterResult=true,mChangeScore=29,mNetQulityGoodCount=0, curTrafficBytes =12582929333
08-30 11:06:38.897  1517  2519 D WN_S    : currentQuality=79,comparedScore=79,mWlanInvalidThreshold=40,mChangedNetwork=false,mCanTriggerData=true,mChangedToData=false
08-30 11:06:38.898  1517  2519 D OplusSlaManager_score: After sendWifiScoreToKernel:result=true ifIndex=0 score=79
08-30 11:06:38.898  1517  2519 D OplusWifiAssistantUtils: setWifiScore wlan0 -->79
08-30 11:06:38.898  1517  2519 D WN_S    : Did not have saved 5g network, don't start 5g scan
08-30 11:06:38.898  1517  2519 D OplusWifiAssistantUtils: setCanChangeToCell wlan0 -->false
08-30 11:06:38.898  1517  2519 D OplusWifiAssistantUtils: addOrUpdateRecord: configKey="a***SK
08-30 11:06:38.898  1517  2519 D WN_S    :  NetworkMonitorState CMD_RSSI_PKTCNT_FETCH_SUCCEEDED
08-30 11:06:39.127 30404 30452 D HoraeHelper: getAllShellTemps tSize : 4
08-30 11:06:39.186 30404 30447 D HoraeHelper: Thermal length:1
08-30 11:06:39.193 30404 30452 E libc    : Access denied finding property "vendor.oplus.media.vpp.osie_sr.on"
08-30 11:06:39.206 30404 30447 D HoraeHelper: skinThermal:36.97
08-30 11:06:39.432  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:1000kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:39.639  1517  2519 D WN_S    : Didn't send and receive any pkt.
08-30 11:06:39.639  1517  2519 D WN_S    :  NetworkMonitorState CMD_TRAFFIC_MONITOR
08-30 11:06:39.677  1517  2519 D WifiClientModeImpl: fetchRssiLinkSpeedAndFrequencyNative rssi=-20 TxLinkspeed=96 freq=2462 RxLinkSpeed=96
08-30 11:06:39.677  1517  2519 D OplusRssiMonitor: update rssi:-20
08-30 11:06:39.678  1517  2519 D OplusScanResultsProxy: getScanResults() callingUid=1010 packageName:com.android.server.wifi mReportCache = true size:41
08-30 11:06:39.678  1517  2519 D WifiClientModeImpl: updateConnectedBand freq=2462 set=true
08-30 11:06:39.678  1517  2519 D WifiNative: ConnectedBand bitset={1}
08-30 11:06:39.679  1517  2519 V WifiConfigManager: Updating scan detail cache freq=2462 BSSID=9a:**:**:**:2d:98 RSSI=-21 for "abc_ling"WPA_PSK
08-30 11:06:39.679  1517  2519 D WifiDataStall:  ccaLevel = 80
08-30 11:06:39.680  1517  2519 D WifiDataStall: L2 txTputKbps: 62700, rxTputKbps: 66000, L3 txTputKbps: 4, rxTputKbps: 7782, TxTrafficHigh: false, RxTrafficHigh: true, Throughput Sufficient: true
08-30 11:06:39.681  1517  2519 D WifiScoreCard: BSSID update SIGNAL_POLL ID: 223048578 SSID: ab***ng, BSSID: 9a:**:**:**:2d:98, MAC: 18:**:**:**:22:37, Supplicant state: COMPLETED, HE Eight Max VHT Spatial Streams Supported AP: false, Eight Max VHT Spatial streams support: false, Wi-Fi standard: 4, RSSI: -20, Link speed: 96Mbps, Tx Link speed: 96Mbps, Max Supported Tx Link speed: 72Mbps, Rx Link speed: 96Mbps, Max Supported Rx Link speed: 72Mbps, Frequency: 2462MHz, Net ID: 25, Metered hint: true, score: 0
08-30 11:06:39.681  1517  2519 D WifiScoreCard: txRate: 5 txSpeed: 96
08-30 11:06:39.681  1517  2519 D WifiScoreCard: network update SIGNAL_POLL "abc_ling" ID: 1059815266 RSSI -20 txSpeed 96
08-30 11:06:39.681  1517  2519 D WifiScoreCard: SSID: "abc_ling"
08-30 11:06:39.681  1517  2519 D WifiScoreCard:  LastRssiPollTime: 1538637682 LastRssiPoll: -20 LastTxSpeedPoll: 96
08-30 11:06:39.681  1517  2519 D WifiScoreCard:  StatsRecent:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 10434 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 2 ConsecutiveConnectFailure: 0
08-30 11:06:39.681  1517  2519 D WifiScoreCard:  StatsCurr:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:39.681  1517  2519 D WifiScoreCard:  StatsPrev:  ConnectAttempt: 0 ConnectFailure: 0 ConnectDurSec: 0 AssocRej: 0 AssocTimeout: 0 AuthFailure: 0 ShortDiscNonlocal: 0 DisconnectNonlocal: 0 Disconnect: 0 ConsecutiveConnectFailure: 0
08-30 11:06:39.684  3187  3187 I QImsService: OplusWifiApmStateMgr : onReceive,wifiSignal: -20
08-30 11:06:39.684  3277  5805 D QCNEJ/WlanStaInfoRelay: Received action: android.net.wifi.RSSI_CHANGED
08-30 11:06:39.685  1517  2519 D OppoWifiClientModeImpl: rssi changes to: -20 level: 4
08-30 11:06:39.685  1517  2519 D WifiClientModeImpl:  L2ConnectedState screen=on 221 0 "abc_ling" 9a:**:**:**:2d:98 rssi=-20 f=2462 sc=0 link=96 tx=3.7, 0.3, 0.0  rx=1000.8 bcn=9009667 [on:2940 tx:4 rx:384 period:3009] from screen [on:4957902 period:6589615] score=0
08-30 11:06:39.686  2938  3592 D WifiStatusTracker: handleBroadcast: shouldUpdateLabel: true
08-30 11:06:39.687  1517  3939 I WifiService: getConnectionInfo uid=10060
08-30 11:06:39.687  1517  3939 V WifiService: getConnectionInfo: hideBssidSsidAndNetworkId=false, hideDefaultMacAddress=true
08-30 11:06:40.474  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:1000kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
08-30 11:06:36.021  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:41.063  1517  1517 D OppoBaseBatteryService: send broadcast : oppo.intent.action.BATTERY_DATA_UPDATE
08-30 11:06:41.063  1517  1517 W ContextImpl: Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1158 com.android.server.OppoBaseBatteryService$2.run:280 android.os.Handler.handleCallback:938 android.os.Handler.dispatchMessage:99 android.os.Looper.loop:263
08-30 11:06:41.064  1517  2614 D BatteryLed: getLightInColorState, oppoLightMgr empty!
08-30 11:06:41.074  3234  3234 D DeviceStatisticsService: chargerType=2 batteryLevel=87 totalBatteryCapacity=3447100
08-30 11:06:41.074  3234  3234 D DeviceInfoHidlClient: getPowerInfoSupportStatus()=-1
08-30 11:06:41.512  1517  2544 D OplusSlaManager_RTT: Received message:OPLUS_SLA_NOTIFY_SPEED_RTT:wlan0:1000kB/s 59ms; wlan1:0kB/s 0ms; cell:0kB/s 0ms; mKernelWorkMode=0 wlan0RxPtk=1653986 wlan0TxPtk=943334 wlan1RxPtk=0 wlan1TxPtk=0
