µVision Build Log
Tool Versions:
IDE-Version: ¦ÌVision V5.28.0.0 Copyright (C) 2019 ARM Ltd and ARM Germany GmbH. All rights reserved. License Information: aa 1161586918@qq.com, aa, LIC=P6F5U-S017W-06EQU-SESX2-2UWXC-SC4JB Tool Versions: Toolchain: MDK-ARM Professional Version: 5.28.0.0 Toolchain Path: C:\Keil_v5\ARM\ARMCC\Bin C Compiler: Armcc.exe V5.06 update 6 (build 750) Assembler: Armasm.exe V5.06 update 6 (build 750) Linker/Locator: ArmLink.exe V5.06 update 6 (build 750) Library Manager: ArmAr.exe V5.06 update 6 (build 750) Hex Converter: FromElf.exe V5.06 update 6 (build 750) CPU DLL: SARMCM3.DLL V5.28.0.0 Dialog DLL: DARMCM1.DLL V1.19.2.0 Target DLL: UL2CM3.DLL V1.162.16.0 Dialog DLL: TARMCM1.DLL V1.14.1.0
Project:
D:\Git\TestLab\PHY6222\tuya_os20220426\software\TuyaOS-PHY6222\vendor\phy6222_ble\sdk\phy62xx-sdk-v3\example\OTA\slboot\slboot.uvprojx Project File Date: 09/13/2022
Output:
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin' Rebuild target 'slboot' compiling ota_flash.c... compiling slboot.c... compiling slb.c... compiling jump_table.c... compiling my_printf.c... compiling main.c... compiling gpio.c... compiling uart.c... assembling startup_ARMCM0.s... compiling system_ARMCM0.c... compiling clock.c... compiling flash.c... compiling pwrmgr.c... linking... Program Size: Code=6712 RO-data=1524 RW-data=17624 ZI-data=1908 After Build - User command #1: fromelf.exe --bin -o ./bin ./Objects/slboot.axf After Build - User command #2: fromelf.exe .\Objects\slboot.axf --i32combined --output .\bin\slboot.hex ".\Objects\slboot.axf" - 0 Error(s), 0 Warning(s).
Software Packages used:
Package Vendor: ARM http://www.keil.com/pack/ARM.CMSIS.5.5.1.pack ARM.CMSIS.5.5.1 CMSIS (Cortex Microcontroller Software Interface Standard) * Component: CORE Version: 5.2.0 * Component: Startup Version: 1.1.0
Collection of Component include folders:
.\RTE\_slboot C:\Users\11615\AppData\Local\Arm\Packs\ARM\CMSIS\5.5.1\CMSIS\Core\Include C:\Users\11615\AppData\Local\Arm\Packs\ARM\CMSIS\5.5.1\Device\ARM\ARMCM0\Include
Collection of Component Files used:
* Component: ARM::CMSIS:CORE:5.2.0 * Component: ARM::Device:Startup:1.1.0 Include file: Device\ARM\ARMCM0\Include\ARMCM0.h Source file: Device\ARM\ARMCM0\Source\system_ARMCM0.c Source file: Device\ARM\ARMCM0\Source\ARM\startup_ARMCM0.s Build Time Elapsed: 00:00:02
