BIN = ./output/slboot.bin
IHEX = ./output/slboot.ihex
ELF = ./output/slboot.elf
ASM = ./output/slboot.asm
ROOT := ../../../..
PROJ_ROOT := ..
VPATH = $(PROJ_ROOT)
VPATH = $(PROJ_ROOT)/gcc
VPATH += $(PROJ_ROOT)/Source
include $(PROJ_ROOT)/gcc/slb_components.cflags
include $(PROJ_ROOT)/gcc/slb_components.mk
DEF += -DMAX_NUM_LL_CONN=1
DEF += -DGATT_MAX_NUM_CONN=MAX_NUM_LL_CONN+1
DEF += -DCFG_MTU_23=0
DEF += -DCFG_FLASH=512
DEF += -DCFG_OTA_BANK_MODE=OTA_SINGLE_BANK
DEF += -DUSE_FCT=0
DEF += -DON_SLB_BOOTLOADER=1
RAMONLY_LD = $(PROJ_ROOT)/slb.ld
SRC_RAW = main.c
SRC_RAW += ota.c
SRC_RAW += ota_flash.c
SRC_RAW += slboot.c
SRC_RAW += slb.c
VPATH += $(ROOT)/components/profiles/ota
VPATH += $(ROOT)/components/profiles/slb
INC += -I$(ROOT)/components/profiles/ota
INC += -I$(ROOT)/components/profiles/slb
INC += -I$(ROOT)/components/libraries/crc16
INC += -I$(ROOT)/components/gcc/CMSIS/device/phyplus
STARTUP_RAW = phy6222_slb_start.s
CSRCS += phy6222_slb_cstart.c
SRC_RAW += $(CSRCS)
INC += -I$(PROJ_ROOT)/source
CFLAGS += -O1
CFLAGS += -g3
CFLAGS += --specs=nosys.specs
CFLAGS += -mcpu=cortex-m0
#CFLAGS += -mfloat-abi=soft
CFLAGS += -mthumb
CFLAGS += -ffunction-sections
CFLAGS += -Wall
LFLAGS += -Wl,--gc-sections
LFLAGS += -Wl,-Map=build.map
LFLAGS += $(ROOT)/misc/bb_rom_sym_m0.gdbsym
LFLAGS += $(LIBS_PATH)
LFLAGS += $(LIBS)
OBJ = $(SRC_RAW:%.c=%.o)
OBJ :=  $(notdir $(OBJ))
STARTUP_OBJ = $(STARTUP_RAW:%.s=%.o)
STARTUP_OBJ :=  $(notdir $(STARTUP_OBJ))
all:$(OBJ) $(STARTUP_OBJ)
	@echo $(STARTUP_OBJ)
	@echo $(OBJ)
	@echo $(BIN)
	mkdir -p output
	arm-none-eabi-gcc -o $(ELF) $(CFLAGS) $(OBJ) $(STARTUP_OBJ) $(LFLAGS) -T$(RAMONLY_LD)
	arm-none-eabi-objcopy -O binary -S $(ELF) $(BIN)
	arm-none-eabi-objcopy -O ihex $(ELF) $(IHEX)
	arm-none-eabi-objdump -s -S $(ELF) > $(ASM)
%.o:%.s
	arm-none-eabi-gcc -c $(CFLAGS) $< -o $@
	@echo
%.o:%.c
	arm-none-eabi-gcc -c $(CFLAGS) $(DEF) $(INC) $< -o $@
	@echo
.PHONY: clean
clean :
	@-rm  $(BIN) $(ASM) $(ELF) $(IHEX)
	-rm $(OBJ)
	-rm $(STARTUP_OBJ)
	-rm *.map
