[root@/]# [LOG_I][RingBuffer.c: 459] Create ring buffer success, bufName:LogBuf, usrName:LogWriter, memAddr:0x76d7b008, usrIndex:0 [LOG_I][RingBuffer.c: 459] Create ring buffer success, bufName:LogBuf, usrName:LogReader, memAddr:0x76d7b008, usrIndex:0 [LOG_I][FactoryData.c: 54] Read factory data success, len:812 [LOG_W][FactoryData.c: 98] Station Sn not exist [LOG_W][main.c: 81] Use tuya platform [LOG_I][PDTParam.c: 58] Read PDT param success, len:2420 [LOG_I][PDTParam.c: 165] Read PDT param success, size:2420 [LOG_I][PDTParam.c: 195] PDT param check success, crc:0x6ad5cc76 [LOG_W][AppConfig.c: 120] Start read configs, size:0x1318 [LOG_I][AppConfig.c: 47] Read app data success, len:4888 [LOG_I][AppConfig.c: 47] Read app data success, len:4888 [LOG_W][AppConfig.c: 123] Read configs complete [LOG_I][AppConfig.c: 214] Generate event channel:0X13DB656F [LOG_I][AppConfig.c: 267] Erase @ 0, len:0x8000 [LOG_I][AppConfig.c: 267] Erase @ 0x8000, len:0x8000 [LOG_I][AppConfig.c: 279] App config erased [LOG_I][AppConfig.c: 76] Write app data success, len:4888 [LOG_I][AppConfig.c: 307] Save app config, size:4888, crc:0X638EED46 [LOG_I][AppConfig.c: 267] Erase @ 0, len:0x8000 [LOG_I][AppConfig.c: 267] Erase @ 0x8000, len:0x8000 [LOG_I][AppConfig.c: 279] App config erased [LOG_I][AppConfig.c: 76] Write app data success, len:4888 [LOG_I][AppConfig.c: 312] Save app backup config, size:4888, crc:0X638EED46 [DBG_][main.c: 169] ************************************************* [DBG_][main.c: 170] FW compile date =[Jan 9 2024 10:28:30] [DBG_][main.c: 171] BUILD_FW_TYPE_VER: 1 [DBG_][main.c: 172] FW_VER_CODE : 1000 [DBG_][main.c: 173] modelName : D2PT [DBG_][main.c: 174] customerName : STD [DBG_][main.c: 175] ************************************************* [LOG_I][main.c: 215] Force open LED [DBG_][NetTask.c: 557] enter net_task_app_main [DBG_][AVTask.c: 122] enter av_task_app_main [DBG_][AVStream.c: 1172] Start video stream [DBG_][AVStream.c: 227] imp_system_init start [DBG_][AVStream.c: 236] IMP_ISP_Open succ [LOG_I][DevStatusLedTask.c: 210] LED started [LOG_I][DevStatusLedTask.c: 127] led_set led = 2 status = 1 [DBG_][main.c: 251] start main CmdLoop!!! [LOG_I][DevKeyScanTask.c: 128] start key_task_main [LOG_I][EasyCamTask.c: 678] enter easycam_task_app_main [LOG_I][RecordTask.c: 114] enter record_task_app_main [LOG_I][PlayRecord.c: 302] init_play_record success [LOG_I][UpgradeTask.c: 694] enter upgrade_task_app_main [LOG_I][UpgradeTask.c: 706] upgrade_flag:0 [LOG_I][UpgradeTask.c: 711] sdio is ready [LOG_I][DevMngTask.c: 330] enter dev_mng_task_app_main [LOG_W][SdCard.c: 820] enter sd_card_task_app_main [LOG_W][SdCard.c: 846] sdCardStatus change [0 -> 1]. [LOG_I][SdCard.c: 685] Start mount:[/dev/mmcblk0p1] to [/sd] [LOG_W][TuyaService.c: 522] Tuya SDK Version:< TuyaOS V:6.1.0 BS:40.00_PT:2.3_LAN:3.5_CAD:1.0.5_CD:1.0.0 > < BUILD AT:2023_11_23_19_01_19 BY ci_manage FOR tuyaos-ipc AT T23_uclibc > IOT DEFS < WIFI_GW:1 DEBUG:0 KV_FILE:0 LITTLE_END:1 SL:1 OPERATING_SYSTEM:100 RELIABLE_TRANSFER:0 > [LOG_I][TuyaService.c: 550] Start init tuya sdk, pid:cvl9vkajuag8etrx, uuid:rs016d2565b7e5db4a24, auth_key:2kAWx7SYw1um2SAGYACj0RY7TTmCeYBk, fw version:10.0.0 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:wq_system,stackDepth:6144,totalstackDepth:10240,priority:3 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:wq_highpri,stackDepth:5120,totalstackDepth:15360,priority:4 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:16896,priority:5 [01-01 00:00:00 ty I][mqc_app.c:429] mqc app init ... [01-01 00:00:00 ty E][log_seq.c:865] open err [01-01 00:00:00 ty I][kv_storge.c:45] Init Kvs With File:/tuya_config/ [LOG_W][NightVision.c: 281] IRCut status in uboot is day [LOG_I][NightVision.c: 63] close_infra_led [01-01 00:00:00 ty N][tuya_tls.c:852] uni_random_init... [01-01 00:00:00 ty N][tuya_tls.c:279] tuya_tls_rand_init ok! [01-01 00:00:00 ty N][tuya_wifi_connect.c:289] mf is open need stop fastconnect [LOG_I][TuyaService.c: 562] Tuya sdk inited, pid:cvl9vkajuag8etrx, uuid:rs016d2565b7e5db4a24, auth_key:2kAWx7SYw1um2SAGYACj0RY7TTmCeYBk, fw version:10.0.0 [01-01 00:00:00 ty D][uni_network.c:312] set_dns_cache_priority:1 [DBG_][TuyaService.c: 565] unm_set_dns_cache_priority => ret: 0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][tuya_ws_db.c:657] gw_bi not found in kv, read from protected [01-01 00:00:00 ty E][ws_db_gw.c:84] wd_protected_read fails gw_bi -6 [01-01 00:00:00 ty D][ws_db_gw.c:146] gw_bi read ret:-6 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][simplekv.c:369] write key:gw_bi And Value Len:224 [01-01 00:00:00 ty D][simplekv.c:437] new space 0 startpos:28700 size:292 [01-01 00:00:00 ty D][simplekv.c:459] new space. seek to end and write zero [01-01 00:00:00 ty D][simplekv.c:207] update crc 1539305800 [01-01 00:00:00 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:00 ty D][simplekv.c:492] write success [01-01 00:00:00 ty D][ws_db_gw.c:146] gw_bi write ret:0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][simplekv.c:369] write key:gw_wsm And Value Len:144 [01-01 00:00:00 ty D][simplekv.c:437] new space 1 startpos:28992 size:212 [01-01 00:00:00 ty D][simplekv.c:459] new space. seek to end and write zero [01-01 00:00:00 ty D][simplekv.c:207] update crc 618559177 [01-01 00:00:00 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:00 ty D][simplekv.c:492] write success [01-01 00:00:00 ty D][ws_db_gw.c:255] gw_wsm write ret:0 [LOG_I][EasyCamTask.c: 736] upgrade_status:0 [LOG_I][EasyCamTask.c: 737] upgrade_err_code:0 [LOG_I][EasyCamTask.c: 84] easycam_task_handle_msg, msg_id:0x2, msg_param:0 [LOG_W][TuyaService.c: 582] tuya_ipc_start_sdk start, mode:1 [DBG_][AVStream.c: 246] IMP_ISP_AddSensor succ [DBG_][AVStream.c: 255] IMP_ISP_EnableSensor succ [DBG_][AVStream.c: 263] IMP_System_Init succ [DBG_][AVStream.c: 274] IMP_ISP_EnableTuning succ [DBG_][AVStream.c: 311] ImpSystemInit success i264e[info]: profile High, level 5.0 i264e[info]: profile High, level 2.2 [LOG_I][NightVision.c: 78] ircut_day [LOG_I][DevWatchdog.c: 35] watchdogDevInit [LOG_I][DevMngTask.c: 222] devmng_task_handle_msg, msg_id:0x6, msg_param:0 [LOG_I][DevStatusLedTask.c: 127] led_set led = 1 status = 4 i264e[info]: profile High, level 2.2 [LOG_I][Osd.c: 198] Osd group:0 created [LOG_I][Osd.c: 198] Osd group:1 created [LOG_I][Osd.c: 293] Osd group:0 handle:2 created [LOG_I][Osd.c: 293] Osd group:0 handle:3 created [LOG_I][Osd.c: 293] Osd group:0 handle:4 created [LOG_I][Osd.c: 293] Osd group:0 handle:5 created [LOG_I][Osd.c: 293] Osd group:0 handle:6 created [LOG_I][Osd.c: 293] Osd group:1 handle:7 created [LOG_I][Osd.c: 293] Osd group:1 handle:8 created [LOG_I][Osd.c: 293] Osd group:1 handle:9 created [LOG_I][Osd.c: 293] Osd group:1 handle:10 created [LOG_I][Osd.c: 293] Osd group:1 handle:11 created [DBG_][AVStream.c: 1265] Start video stream success!!! [LOG_I][RingBuffer.c: 462] Create ring buffer success, bufName:MainVideo, usrName:Encoder, memAddr:0x6744c008 [LOG_I][RingBuffer.c: 462] Create ring buffer success, bufName:SubVideo, usrName:Encoder, memAddr:0x67409008 [LOG_I][Osd.c: 428] Osd timestamp length changed, oldLen:0, newLen:17 [LOG_I][Osd.c: 428] Osd timestamp length changed, oldLen:0, newLen:17 [DBG_][AVStream.c: 838] *****Got first video frame, chn: 0 [DBG_][AVStream.c: 838] *****Got first video frame, chn: 1 [LOG_W][SdCard.c: 846] sdCardStatus change [1 -> 2]. [LOG_W][SdCard.c: 628] upload_sd_status = 2 [LOG_I][EasyCamTask.c: 84] easycam_task_handle_msg, msg_id:0x15, msg_param:0x2 [LOG_I][UpgradeTask.c: 719] Sd card mount complete [LOG_I][UpgradeTask.c: 725] sd card status = 2 [LOG_I][UpgradeTask.c: 762] Start check upgrade flag file [LOG_I][upgradeCheck.c: 47] Found firmware file:ACdoorbell_D2PT_STD_P30_V1.0.0.0_Tuya_20240109.bin [LOG_I][upgradeCheck.c: 176] Firmware file:ACdoorbell_D2PT_STD_P30_V1.0.0.0_Tuya_20240109.bin [LOG_I][upgradeCheck.c: 93] Upgrade file magic check success, versionCode:1000, md5: 50af5675faa0b5c0c44affb726ba3b33 [LOG_I][upgradeCheck.c: 197] force upgrade switch file not found, start check version and product name warn: shm_init,53shm init already [DBG_][AVStream.c: 1431] av_imp_audio_start_ai => succ!!! [DBG_][AVStream.c: 1640] Enter ai AudioEnc_Thread!!! [LOG_I][RingBuffer.c: 462] Create ring buffer success, bufName:AudioStream, usrName:Encoder, memAddr:0x107cec8 [LOG_I][RingBuffer.c: 462] Create ring buffer success, bufName:PCMAudioStream, usrName:Encoder, memAddr:0x10af918 warn: shm_init,53shm init already [DBG_][AVStream.c: 1956] start_audio_stream => succ!!! [DBG_][AVStream.c: 1754] Enter AudioOutput_Thread_Proc!!! [LOG_I][RingBuffer.c: 459] Create ring buffer success, bufName:AudioPlay, usrName:Player, memAddr:0x115c2e8, usrIndex:0 INFO(jzdl): jzdl version:1.4.0(00010400_0a593ef) built:20230925-1744(4.7.2 c) INFO(persondet): Ingenic DL PersonDet Promotion Version:0.0.8(00000008_111fcc8) built:20231008-1729(5.4.0 simd) param frameWidth: 640 frameHeight: 360 sense: 4 score: 0.500000 detdist: 0 ptime: 0 count: 0 mod: 0 enable_perm: 0 enable_move: 0 track_mode: 0 observation_period: 5 active_count: 2 move_scale: 1.000000 [DBG_][AIProcess.c: 757] AI_Detect_JzIvsInit => succ!!! [DBG_][AIProcess.c: 362] push motion detect event!!! [LOG_I][EasyCamTask.c: 84] easycam_task_handle_msg, msg_id:0x1f, msg_param:0x215a [DBG_][AVStream.c: 1612] av_imp_ai_enable_aec_mode => mode: 0!!! [01-01 00:00:05 ty D][tuya_devos_health.c:68] feed watchdog [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1159] find key:0 gw_bi [01-01 00:00:05 ty D][simplekv.c:1185] key:gw_bi find value.Len:224 [01-01 00:00:05 ty D][tuya_ws_db.c:651] sync to protected len[223] [01-01 00:00:05 ty D][ws_db_gw.c:146] gw_bi read ret:0 [01-01 00:00:05 ty D][tuya_wifi_link.c:762] tuya wifi link init mthd:0,wifi start mode:0, enable_station_ap:0 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1159] find key:1 gw_wsm [01-01 00:00:05 ty D][simplekv.c:1185] key:gw_wsm find value.Len:144 [01-01 00:00:05 ty D][tuya_ws_db.c:651] sync to protected len[140] [01-01 00:00:05 ty D][ws_db_gw.c:255] gw_wsm read ret:0 [01-01 00:00:05 ty N][tuya_wifi_link.c:83] start wifi link params validate, nc_tp:0 md:0 [01-01 00:00:05 ty N][tuya_wifi_link.c:95] wifi config method not fit [01-01 00:00:05 ty D][tuya_wifi_reset.c:625] nc_tp:2, wifi_start_mode:0 [01-01 00:00:05 ty N][tuya_wifi_link.c:45] reset wifi link params to factory state, nc_tp:2 md:0 mthd:0 start mode:0 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1159] find key:1 gw_wsm [01-01 00:00:05 ty D][simplekv.c:1185] key:gw_wsm find value.Len:144 [01-01 00:00:05 ty D][simplekv.c:369] write key:gw_wsm And Value Len:144 [01-01 00:00:05 ty D][simplekv.c:387] 1 key same AND size old 212 >= new 144 [01-01 00:00:05 ty D][simplekv.c:415] find 1 available space [01-01 00:00:05 ty D][simplekv.c:452] reuse available space 28992 [01-01 00:00:05 ty D][simplekv.c:207] update crc 263647297 [01-01 00:00:05 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:05 ty D][simplekv.c:492] write success [01-01 00:00:05 ty D][ws_db_gw.c:255] gw_wsm write ret:0 [01-01 00:00:05 ty E][tuya_wifi_link.c:769] ret:-2819 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1159] find key:1 gw_wsm [01-01 00:00:05 ty D][simplekv.c:1185] key:gw_wsm find value.Len:144 [01-01 00:00:05 ty D][tuya_ws_db.c:651] sync to protected len[140] [01-01 00:00:05 ty D][ws_db_gw.c:255] gw_wsm read ret:0 [01-01 00:00:05 ty D][simplekv.c:1128] read key:wf_start_md isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty E][tuya_wifi_reset.c:638] read wf start mode err:-6 [01-01 00:00:05 ty D][tuya_wifi_reset.c:675] <__gw_upd_nc_type> wf start mode change:-6, 0->0 [01-01 00:00:05 ty N][tuya_svc_devos.c:494] Last reset reason: 7 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1159] find key:0 gw_bi [01-01 00:00:05 ty D][simplekv.c:1185] key:gw_bi find value.Len:224 [01-01 00:00:05 ty D][tuya_ws_db.c:651] sync to protected len[223] [01-01 00:00:05 ty D][ws_db_gw.c:146] gw_bi read ret:0 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1159] find key:1 gw_wsm [01-01 00:00:05 ty D][simplekv.c:1185] key:gw_wsm find value.Len:144 [01-01 00:00:05 ty D][tuya_ws_db.c:651] sync to protected len[140] [01-01 00:00:05 ty D][ws_db_gw.c:255] gw_wsm read ret:0 [01-01 00:00:05 ty N][tuya_svc_devos.c:299] gw_cntl->gw_wsm.stat:0 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty E][tuya_ws_db.c:319] kvs_read fails gw_di -6 [01-01 00:00:05 ty D][ws_db_gw.c:372] gw_di read ret:-6 [01-01 00:00:05 ty E][tuya_svc_devos.c:315] desc read err:-6 [01-01 00:00:05 ty E][tuya_svc_devos.c:501] ret:-6 [01-01 00:00:05 ty N][tuya_svc_devos.c:661] enter reset factory [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty E][tuya_ws_db.c:319] kvs_read fails gw_di -6 [01-01 00:00:05 ty D][ws_db_gw.c:372] gw_di read ret:-6 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty D][simplekv.c:369] write key:gw_di And Value Len:672 [01-01 00:00:05 ty D][simplekv.c:437] new space 2 startpos:29204 size:740 [01-01 00:00:05 ty D][simplekv.c:459] new space. seek to end and write zero [01-01 00:00:05 ty D][simplekv.c:207] update crc 3186867025 [01-01 00:00:05 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:05 ty D][simplekv.c:492] write success [01-01 00:00:05 ty D][ws_db_gw.c:372] gw_di write ret:0 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty E][tuya_ws_db.c:319] kvs_read fails gw_ai -6 [01-01 00:00:05 ty D][ws_db_gw.c:454] gw_ai read ret:-6 [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty D][simplekv.c:369] write key:gw_ai And Value Len:352 [01-01 00:00:05 ty D][simplekv.c:437] new space 3 startpos:29944 size:420 [01-01 00:00:05 ty D][simplekv.c:459] new space. seek to end and write zero [01-01 00:00:05 ty D][simplekv.c:207] update crc 3694713072 [01-01 00:00:05 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:05 ty D][simplekv.c:492] write success [01-01 00:00:05 ty D][ws_db_gw.c:454] gw_ai write ret:0 [01-01 00:00:05 ty D][tuya_wifi_connect.c:95] fast connect mode:0 [01-01 00:00:05 ty D][simplekv.c:1248] delete key:ap_info_v2 isFuzzy:0 [01-01 00:00:05 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:05 ty D][simplekv.c:1287] key:ap_info_v2 not find [01-01 00:00:05 ty D][tuya_wifi_connect.c:362] del fast info success [01-01 00:00:05 ty D][simplekv.c:1128] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1159] find key:1 gw_wsm [01-01 00:00:05 ty D][simplekv.c:1185] key:gw_wsm find value.Len:144 [01-01 00:00:05 ty D][ws_db_gw.c:255] gw_wsm write ret:0 [LOG_I][TuyaService.c: 248] ipc status changed:1 [01-01 00:00:05 ty N][tuya_svc_devos.c:523] enter success_proc [LOG_I][tkl_wifi.c: 231] hwl_wf_get_mac[98:03:CF:62:E8:30] [01-01 00:00:05 ty N][tuya_svc_devos.c:526] serial_no:9803cf62e830 [01-01 00:00:05 ty D][tuya_devos_utils.c:295] timer ID:16663216 [01-01 00:00:05 ty D][tuya_svc_upgrade.c:1291] tuya svc upgrade init success! [01-01 00:00:05 ty D][simplekv.c:1128] read key:rcs.active isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty D][tuya_ws_db.c:657] rcs.active not found in kv, read from protected [01-01 00:00:05 ty D][simplekv.c:1128] read key:rcs.mf isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty D][tuya_ws_db.c:657] rcs.mf not found in kv, read from protected [01-01 00:00:05 ty D][tuya_register_center.c:350] use default rcs [-6] [01-01 00:00:05 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:05 ty D][tuya_register_center.c:308] def rcs url0:h3.iot-dns.com [01-01 00:00:05 ty D][tuya_register_center.c:311] def rcs urlx:h6.iot-dns.com [01-01 00:00:05 ty D][tuya_cert_manager.c:963] psk key was 1.0 [01-01 00:00:05 ty D][tuya_cert_manager.c:1058] cert manager init [01-01 00:00:05 ty D][simplekv.c:1128] read key:kv.meta.report isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty D][ty_meta_report.c:97] meta in kv {"metas":{}} [01-01 00:00:05 ty D][mqc_app.c:103] mq_pro:300 cnt:3 [01-01 00:00:05 ty D][mqc_app.c:103] mq_pro:302 cnt:4 [01-01 00:00:05 ty D][mqc_app.c:103] mq_pro:304 cnt:5 [01-01 00:00:05 ty D][mqc_app.c:103] mq_pro:307 cnt:6 [01-01 00:00:05 ty D][mqc_app.c:103] mq_pro:308 cnt:7 [01-01 00:00:05 ty D][mqc_app.c:103] mq_pro:312 cnt:8 [01-01 00:00:05 ty D][tuya_ipc_mqtt_subscribe.c:292] iot_register_extra_mqt_cb done [01-01 00:00:05 ty E][tuya_ring_buffer.c:113] ring buffer list not inited! [01-01 00:00:05 ty E][tuya_ring_buffer.c:113] ring buffer list not inited! [01-01 00:00:05 ty E][tuya_ring_buffer.c:113] ring buffer list not inited! [01-01 00:00:05 ty E][tuya_ring_buffer.c:113] ring buffer list not inited! [01-01 00:00:05 ty E][tuya_ring_buffer.c:113] ring buffer list not inited! [01-01 00:00:05 ty E][tuya_ring_buffer.c:113] ring buffer list not inited! [01-01 00:00:05 ty E][tuya_ring_buffer.c:113] ring buffer list not inited! [01-01 00:00:05 ty E][tuya_ring_buffer.c:113] ring buffer list not inited! [01-01 00:00:05 ty D][tuya_ipc_sdk_init.c:105] sys add timer: 18889616 [01-01 00:00:05 ty D][tuya_ipc_sdk_init.c:111] sys start timer: 18889616 [01-01 00:00:05 ty D][tuya_svc_devos.c:760] state change from 0 to 1 [LOG_I][TuyaService.c: 248] ipc status changed:1 [01-01 00:00:05 ty D][simplekv.c:1128] read key:wf_start_md isFuzzy:0 skipCnt:0 [01-01 00:00:05 ty D][simplekv.c:1156] no key find [01-01 00:00:05 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:05 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:05 ty E][tuya_wifi_reset.c:638] read wf start mode err:-6 [01-01 00:00:05 ty D][tuya_wifi_reset.c:675] <__gw_upd_nc_type> wf start mode change:-6, 0->0 [01-01 00:00:05 ty D][tuya_wifi_reset.c:559] reset init mthd:0, short timer:0 long timer:0 [01-01 00:00:05 ty D][tuya_wifi_netcfg.c:424] do proxy actived work,mode:5,stat:0,nc_tp:2 [01-01 00:00:05 ty D][tuya_wifi_netcfg.c:709] nc_tp:2, md:0 [01-01 00:00:05 ty D][netcfg_module.c:133] type:0x10002,is_set:0 [01-01 00:00:05 ty D][netcfg_module.c:133] type:0x10100,is_set:0 [01-01 00:00:05 ty D][netcfg_module.c:133] type:0x10002,is_set:1 [01-01 00:00:05 ty D][tuya_wifi_link.c:138] start ap netcfg, wk_md:3 [LOG_I][tkl_wifi.c: 238] hwl_wf_wk_mode_set, mode:3 [LOG_I][tkl_wifi.c: 289] Start wait AP mode ready [LOG_I][NetTask.c: 77] net_task_handle_msg, msg_id:0xd, msg_param:0 [LOG_I][NetTask.c: 169] NET_TASK_MSG_ID_START_WIFI_CONFIG [LOG_I][WiFiManager.c: 741] Start soft AP:SmartLife_rs016d2565b7e5db4a24 [LOG_I][EasyCamTask.c: 84] easycam_task_handle_msg, msg_id:0x2, msg_param:0 [01-01 00:00:05 ty D][tuya_iot_wifi_api.c:443] register wifi network monitor. interval:1 [LOG_W][TuyaService.c: 589] tuya_ipc_start_sdk complete killall: wpa_supplicant: no process killed killall: udhcpc: no process killed [LOG_I][WiFiManager.c: 167] flen = 125 [LOG_I][WiFiManager.c: 271] flen = 0 [LOG_I][WiFiManager.c: 289] write_dnsmasq_cifg OK [LOG_I][WiFiManager.c: 232] ap_ifconfig_ip OK /bin/sh: dnsmasq: not found [LOG_I][WiFiManager.c: 309] set dnsmasq dnsmasq -C /tmp/etc/dnsmasq.conf -l /tmp/var/lib/misc/dnsmasq.leases -x /tmp/var/run/dnsmasq.pid [LOG_I][WiFiManager.c: 747] Soft AP opne finifh [LOG_I][tkl_wifi.c: 291] AP mode is ready now [LOG_I][tkl_wifi.c: 231] hwl_wf_get_mac[98:03:CF:62:E8:30] [DBG_][tkl_wifi.c: 168] Start soft AP, ssid:SmartLife-E830, passwd: [LOG_I][EasyCamTask.c: 84] easycam_task_handle_msg, msg_id:0x3, msg_param:0 [LOG_W][EasyCamTask.c: 100] EASYCAM_TASK_MSG_ID_START_WIFI_SYNC_SUCCESS, sSystemSleepTimeTick:192501 [DBG_][AIProcess.c: 588] AI_Detect_EnableQrScan => succ, bEnable: 1 [01-01 00:00:12 ty D][tuya_wifi_netcfg.c:575] start ap success:SmartLife-E830 [01-01 00:00:12 ty D][netcfg_module.c:133] type:0x10002,is_set:0 [01-01 00:00:12 ty D][netcfg_module.c:133] type:0x10100,is_set:0 [01-01 00:00:12 ty D][netcfg_module.c:133] type:0x10002,is_set:0 [01-01 00:00:12 ty D][netcfg_module.c:133] type:0x10100,is_set:0 [01-01 00:00:12 ty N][tuya_wifi_status.c:168] cur stat:2 0x4b8830 -->> [01-01 00:00:12 ty N][tuya_wifi_status.c:171] wifi netstat changed to:2 -->> [01-01 00:00:12 ty N][tuya_wifi_status.c:175] report wifi netstat[2] to callback -->> [01-01 00:00:12 ty E][tuya_ipc_sdk_init.c:339] wf nw status changed to [2], but not notify [01-01 00:00:12 ty D][netcfg_module.c:334] netcfg module start type:0x10100 [01-01 00:00:12 ty N][tuya_wifi_reset.c:404] timer stated, short timer:0x0, long timer:0x0 [01-01 00:00:12 ty D][tuya_wifi_netcfg.c:787] nc_tp:2, md:0 [01-01 00:00:12 ty N][tuya_svc_devos.c:216] __devos_init_evt success [01-01 00:00:12 ty D][netcfg_module.c:116] start 0x10100 ret:0 [01-01 00:00:12 ty D][netcfg_module.c:334] netcfg module start type:0x10002 [01-01 00:00:12 ty D][ap_netcfg.c:1279] ap cfg start:65538 [01-01 00:00:12 ty D][ap_netcfg.c:1157] ap netcfg server ip:192.168.29.1 [01-01 00:00:12 ty I][tal_thread.c:185] thread_create name:ap_tcp_v4,stackDepth:3584,totalstackDepth:20480,priority:5 [01-01 00:00:12 ty D][netcfg_module.c:116] start 0x10002 ret:0 [01-01 00:00:12 ty D][tal_thread.c:204] Thread:ap_tcp_v4 Exec Start. Set to Running Stat [01-01 00:00:12 ty D][ap_netcfg.c:748] start TCP ap thread [01-01 00:00:12 ty D][ap_netcfg.c:786] Waiting for a remote connection Configuration file: /tmp/etc/Wireless/hostapd.conf nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory) Using interface wlan0 with hwaddr 98:03:cf:62:e8:30 and ssid "SmartLife_rs016d2565b7e5db4a24" wlan0: interface state UNINITIALIZED->ENABLED wlan0: AP-ENABLED decoded QR-Code symbol "{"p":"1234567890","s":"ChinaNet-AC12","t":"AYNU1EBUHX5bSP"}" [DBG_][AIProcess.c: 195] [IVSDoneThread_QrScanTask] => payload: {"p":"1234567890","s":"ChinaNet-AC12","t":"AYNU1EBUHX5bSP"}, payload_len: 59 [DBG_][TuyaService.c: 64] tuya_wifi_QrScanCallback => data_len: 59, data: {"p":"1234567890","s":"ChinaNet-AC12","t":"AYNU1EBUHX5bSP"}[01-01 00:00:13 ty D][tuya_ipc_sdk_init.c:654] Rev:{"p":"1234567890","s":"ChinaNet-AC12","t":"AYNU1EBUHX5bSP"} [01-01 00:00:13 ty D][tuya_ipc_sdk_init.c:655] Source:0 [01-01 00:00:13 ty D][tuya_ipc_sdk_init.c:684] Parse ssid:ChinaNet-AC12 token:AYNU1EBUHX5bSP [01-01 00:00:13 ty D][tuya_ipc_sdk_init.c:697] Parse passwd:1234567890 [01-01 00:00:13 ty D][tuya_wifi_netcfg.c:689] user Netcfg Finish type:0x10100 ssid:ChinaNet-AC12 passwd:1234567890 cur_netcfg_type:0 [01-01 00:00:13 ty D][tuya_svc_netmgr_linkage.c:184] link[2] stage[0] type[0] [2] [LOG_I][TuyaService.c: 248] ipc status changed:1 [01-01 00:00:13 ty D][tuya_svc_devos.c:176] activate type 0 [01-01 00:00:13 ty D][tuya_svc_devos_activate_token.c:110] token activate start 0x1207e40 [01-01 00:00:13 ty D][svc_netcfg_qrcode.c:117] activate evt [01-01 00:00:13 ty D][svc_netcfg_qrcode.c:99] stop config [01-01 00:00:13 ty D][tuya_wifi_netcfg.c:341] active event, type:0, stage:0 info->linkage:2 [01-01 00:00:13 ty D][netcfg_module.c:405] netcfg module stop type:0x10002 [01-01 00:00:13 ty D][ap_netcfg.c:1330] ap cfg stop:65538,0 [01-01 00:00:13 ty D][netcfg_module.c:405] netcfg module stop type:0x10100 [01-01 00:00:13 ty D][wifi_netcfg_frame_transporter.c:485] ----destroy Transporter,session:0x1201d78 [01-01 00:00:13 ty N][tuya_wifi_netcfg.c:188] stop smt cfg mthd:0, ret:0 [01-01 00:00:13 ty N][tuya_wifi_status.c:168] cur stat:5 0x4b8830 -->> [01-01 00:00:13 ty N][tuya_wifi_status.c:171] wifi netstat changed to:5 -->> [01-01 00:00:13 ty N][tuya_wifi_status.c:175] report wifi netstat[5] to callback -->> [LOG_I][TuyaService.c: 248] ipc status changed:2 [01-01 00:00:13 ty D][tuya_wifi_connect.c:388] __wifi_net_conn. [01-01 00:00:13 ty D][tuya_wifi_connect.c:264] status:5,mode:3 [01-01 00:00:13 ty D][tuya_wifi_connect.c:392] __wifi_net_conn, enable_station_ap:0 [DBG_][tkl_wifi.c: 176] enter tkl_wifi_stop_ap [DBG_][AIProcess.c: 588] AI_Detect_EnableQrScan => succ, bEnable: 0 [LOG_I][tkl_wifi.c: 238] hwl_wf_wk_mode_set, mode:2 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 0 [01-01 00:00:13 ty D][tuya_wifi_connect.c:264] status:5,mode:2 [01-01 00:00:13 ty D][tuya_wifi_connect.c:424] start wf connect, ssid:ChinaNet-AC12, pwd:1234567890 [01-01 00:00:13 ty D][tal_wifi_reconnet.c:91] wifi auto reconn ssid ChinaNet-AC12 [LOG_I][AppConfig.c: 267] Erase @ 0, len:0x8000 [DBG_][TuyaService.c: 69] tuya_wifi_QrScanCallback => tuya_ipc_direct_connect succ!!! [DBG_][AIProcess.c: 203] ivs_qr_scan_result_cb succ, DisableQrScan!!! [LOG_I][AppConfig.c: 267] Erase @ 0x8000, len:0x8000 [LOG_I][AppConfig.c: 279] App config erased [LOG_I][AppConfig.c: 76] Write app data success, len:4888 [01-01 00:00:14 ty D][ap_netcfg.c:705] ap thread exit [01-01 00:00:14 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:14 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:14 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:14 ty D][tal_thread.c:245] Del Thrd:ap_tcp_v4 [01-01 00:00:14 ty D][tal_thread.c:220] Thread:ap_tcp_v4 Exec Finish. Set to Del Stat [01-01 00:00:14 ty D][tal_thread.c:95] del list not empty...deleting 0x1207b9c, next 0xfe3c68 [01-01 00:00:14 ty D][tal_thread.c:103] Final Free Thread:ap_tcp_v4, is_self:1 [01-01 00:00:14 ty D][tal_thread.c:107] delay to delete thread self [01-01 00:00:14 ty D][tal_thread.c:119] finally delete thread self [01-01 00:00:14 ty D][tal_thread.c:73] real delete thread:0x1208028 [LOG_I][AppConfig.c: 307] Save app config, size:4888, crc:0X17139AED [LOG_I][AppConfig.c: 267] Erase @ 0, len:0x8000 [LOG_I][AppConfig.c: 267] Erase @ 0x8000, len:0x8000 [LOG_I][AppConfig.c: 279] App config erased [LOG_I][AppConfig.c: 76] Write app data success, len:4888 [LOG_I][AppConfig.c: 312] Save app backup config, size:4888, crc:0X17139AED [DBG_][tkl_wifi.c: 426] tkl_wifi_station_connect => ssid:ChinaNet-AC12, passwd:1234567890[LOG_I][NetTask.c: 77] net_task_handle_msg, msg_id:0xc, msg_param:0 [LOG_I][NetTask.c: 187] NET_TASK_MSG_ID_CONNECT_TO_AP [DBG_][tkl_wifi.c: 108] tuya_wifi_set_StationState changed, from state[0] to state[1] [LOG_I][WiFiManager.c: 767] connectToAP, ssid:ChinaNet-AC12, password:1234567890 [LOG_I][EasyCamTask.c: 84] easycam_task_handle_msg, msg_id:0x7, msg_param:0x66694c74 [LOG_I][DevMngTask.c: 222] devmng_task_handle_msg, msg_id:0x6, msg_param:0x1 [LOG_I][DevStatusLedTask.c: 127] led_set led = 2 status = 2 [01-01 00:00:14 ty D][tuya_wifi_connect.c:430] wf connect success! [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 1 [01-01 00:00:14 ty N][tuya_wifi_status.c:168] cur stat:5 0x4b8830 -->> wlan0: interface state ENABLED->DISABLED wlan0: AP-DISABLED nl80211: deinit ifname=wlan0 disabled_11b_rates=0 killall: udhcpd: no process killed [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 udhcpc (v1.22.1) started Sending discover... [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 [01-01 00:00:16 ty D][tuya_devos_health.c:68] feed watchdog [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 [ 17.910062] SSV WLAN driver SSV6006C: Set key VIF 0 VIF type 2 STA 0 algorithm = 4, key->keyidx = 0, cmd = 0 [ 17.924702] SET KEY 0 [ 17.929654] SSV WLAN driver SSV6006C: Set key VIF 0 VIF type 2 STA -1 algorithm = 4, key->keyidx = 1, cmd = 0 [ 17.948138] SET KEY 0 [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 Sending discover... [ 19.191941] AMPDU_TX_START 08:10:7A:9F:AC:13 0. [ 19.201609] AMPDU_TX_OPERATIONAL 08:10:7A:9F:AC:13 0. Sending select for 192.168.29.4... [ 19.429061] IEEE80211_AMPDU_RX_START 08:10:7A:9F:AC:13 5. [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 Lease of 192.168.29.4 obtained, lease time 86400 [DBG_][WiFiManager.c: 800] connectToAP => wait ip ready!!! cur_ip: 192.168.29.1 deleting routers route: SIOCDELRT: No such process gw is 192.168.29.1 dev is wlan0 [01-01 00:00:21 ty D][tuya_devos_health.c:68] feed watchdog adding dns 192.168.29.1 [DBG_][WiFiManager.c: 796] connectToAP => ip is ready!!! [LOG_I][WiFiManager.c: 811] ip: 192.168.29.4 [LOG_I][WiFiManager.c: 814] WiFi connection complete, errorCode:0 [DBG_][tkl_wifi.c: 108] tuya_wifi_set_StationState changed, from state[1] to state[6] [DBG_][tkl_wifi.c: 129] tuya_wifi_set_StationState => report 0 event complete!!! [01-01 00:00:21 ty N][tal_wifi_reconnet.c:208] wifi status changed to 0 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:21 ty D][tuya_svc_devos.c:770] set netcfgstat, stage:2, status:0 [01-01 00:00:21 ty D][tuya_ble_svc.c:1369] ble get conn stat:4 [01-01 00:00:21 ty D][tuya_wifi_link.c:286] stat:6 [01-01 00:00:21 ty D][tuya_svc_netmgr_linkage.c:117] link[2] is_up[1] active_link[1] status[0] [01-01 00:00:21 ty D][tuya_svc_devos_activate_token.c:93] token activate link up [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:21 ty N][tuya_wifi_status.c:168] cur stat:6 0x4b8830 -->> [01-01 00:00:21 ty N][tuya_wifi_status.c:171] wifi netstat changed to:6 -->> [01-01 00:00:21 ty N][tuya_wifi_status.c:175] report wifi netstat[6] to callback -->> [LOG_I][TuyaService.c: 248] ipc status changed:2 [01-01 00:00:21 ty I][tal_thread.c:185] thread_create name:lan_sock_loop,stackDepth:4096,totalstackDepth:24576,priority:3 [01-01 00:00:21 ty D][tuya_lan_sock.c:312] init sock loop success [01-01 00:00:21 ty D][tuya_svc_lan.c:2490] lan init success [01-01 00:00:21 ty D][tal_wifi_reconnet.c:225] wifi connected in check [01-01 00:00:21 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:21 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:21 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:21 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:21 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:21 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:21 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:21 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:21 ty D][simplekv.c:1156] no key find [01-01 00:00:21 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:21 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:21 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:21 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:21 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:21 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:21 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:21 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:21 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [LOG_I][EasyCamTask.c: 84] easycam_task_handle_msg, msg_id:0x8, msg_param:0x66694c74 [LOG_I][EasyCamTask.c: 149] ip:192.168.29.4, mask:255.255.255.0, gate:192.168.29.1, dns1:192.168.29.1, dns2: [LOG_W][EasyCamTask.c: 161] Connect to router success [LOG_I][EasyCamTask.c: 189] Set sleep at tick:33050 [LOG_I][AppConfig.c: 267] Erase @ 0, len:0x8000 [LOG_I][AVTask.c: 27] av_task_handle_msg, msg_id:0x6, msg_param:0x3 [LOG_I][AVTask.c: 51] AV_TASK_MSG_ID_START_PLAY_AUDIO_RES, id:3 [DBG_][AVStream.c: 2009] start_play_audio_res => res_id:3, loop:1 [01-01 00:00:21 ty D][tal_thread.c:204] Thread:lan_sock_loop Exec Start. Set to Running Stat [01-01 00:00:21 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:21 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:21 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [01-01 00:00:21 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:21 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:21 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:21 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:21 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:21 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [LOG_I][AppConfig.c: 267] Erase @ 0x8000, len:0x8000 [LOG_I][AppConfig.c: 279] App config erased [LOG_I][AudioRes.c: 43] Read audio res success, len:192 [LOG_I][AudioRes.c: 43] Read audio res success, len:16000 [DBG_][AVStream.c: 1807] Resample audio res, size:16000, newSampleRate:8000[LOG_I][AppConfig.c: 76] Write app data success, len:4888 [01-01 00:00:22 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:22 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:22 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:22 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:22 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:22 ty D][tls_transporter.c:93] tls transporter close socket fd:29 [01-01 00:00:22 ty D][tcp_transporter.c:177] tcp transporter close socket fd:29 [01-01 00:00:22 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1204810 [01-01 00:00:22 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:22 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:22 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:22 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:22 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:22 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:22 ty D][uni_network.c:285] lower_dns_cache_priority:0 [01-01 00:00:22 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:22 ty E][log_seq.c:142] ret:-1027 [01-01 00:00:22 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:22 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][AppConfig.c: 307] Save app config, size:4888, crc:0X5CF15AB2 [LOG_I][AppConfig.c: 267] Erase @ 0, len:0x8000 [LOG_I][AppConfig.c: 267] Erase @ 0x8000, len:0x8000 [LOG_I][AppConfig.c: 279] App config erased [LOG_I][AppConfig.c: 76] Write app data success, len:4888 [LOG_I][AppConfig.c: 312] Save app backup config, size:4888, crc:0X5CF15AB2 [LOG_I][EasyCamDiscovery.c: 339] start discovery service success, socket:28 [LOG_E][TuyaMediaService.c: 1397] Please init media service firstly [LOG_I][DevMngTask.c: 222] devmng_task_handle_msg, msg_id:0x6, msg_param:0x2 [LOG_I][DevStatusLedTask.c: 127] led_set led = 2 status = 4 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:22 ty N][tuya_svc_lan.c:713] Not actived, use linkage addr[192.168.29.4][c0a81d04] [01-01 00:00:22 ty D][tuya_lan_sock.c:331] reg post queue 29 [01-01 00:00:22 ty D][tuya_lan_sock.c:331] reg post queue 30 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][EasyCamDiscovery.c: 243] Start listen discovery port [01-01 00:00:23 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:23 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:23 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:23 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:23 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:23 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:23 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:23 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:23 ty D][simplekv.c:1156] no key find [01-01 00:00:23 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:23 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:23 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:23 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:23 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:23 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:23 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:23 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:23 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 0 [01-01 00:00:23 ty D][uni_network.c:312] set_dns_cache_priority:1 [01-01 00:00:23 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:23 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:23 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:23 ty D][uni_network.c:312] set_dns_cache_priority:0 [01-01 00:00:23 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [01-01 00:00:23 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:23 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:23 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:23 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:23 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:23 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:23 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:23 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:23 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:23 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:23 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:23 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:23 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:23 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1206260 [01-01 00:00:23 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:23 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:23 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:23 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:23 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:23 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:23 ty D][uni_network.c:285] lower_dns_cache_priority:1 [01-01 00:00:23 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:23 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:23 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:23 ty D][tuya_lan_sock.c:127] reg lan sock 29,read:0x4abde4 [01-01 00:00:24 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:24 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:24 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:24 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:24 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:24 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:24 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:24 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:24 ty D][simplekv.c:1156] no key find [01-01 00:00:24 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:24 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:24 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:24 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:24 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:24 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:24 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:24 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:24 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:24 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:24 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:24 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:24 ty D][tuya_lan_sock.c:127] reg lan sock 30,read:0x4af260 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:26 ty D][tuya_devos_health.c:68] feed watchdog [01-01 00:00:26 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:26 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:26 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:26 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:26 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:26 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:26 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:26 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:26 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:26 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:26 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:26 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:26 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:26 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1206260 [01-01 00:00:26 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:26 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:26 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:26 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:26 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:26 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:26 ty D][uni_network.c:285] lower_dns_cache_priority:0 [01-01 00:00:26 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:26 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:26 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:27 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:27 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:27 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:27 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:27 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:27 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:27 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:27 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:27 ty D][simplekv.c:1156] no key find [01-01 00:00:27 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:27 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:27 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:27 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:27 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:27 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:27 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:27 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:27 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 0 [01-01 00:00:27 ty D][uni_network.c:312] set_dns_cache_priority:1 [01-01 00:00:27 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:27 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:27 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:27 ty D][uni_network.c:312] set_dns_cache_priority:0 [01-01 00:00:27 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [01-01 00:00:27 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:27 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:27 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:27 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:27 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:27 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:28 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:28 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:28 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:28 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:28 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:28 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:28 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:28 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1206260 [01-01 00:00:28 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:28 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:28 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:28 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:28 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:28 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:28 ty D][uni_network.c:285] lower_dns_cache_priority:1 [01-01 00:00:28 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:28 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:28 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:29 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:29 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:29 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:29 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:29 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:29 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:29 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:29 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:29 ty D][simplekv.c:1156] no key find [01-01 00:00:29 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:29 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:29 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:29 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:29 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:29 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:29 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:29 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:29 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:29 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:29 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:29 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [01-01 00:00:29 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:29 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:29 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:29 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:29 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:29 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:29 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:29 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:29 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:29 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:29 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:29 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:29 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:29 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1207410 [01-01 00:00:29 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:29 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:29 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:29 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:29 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:29 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:29 ty D][uni_network.c:285] lower_dns_cache_priority:0 [01-01 00:00:29 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:29 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:29 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:30 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:30 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:30 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:30 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:30 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:30 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:30 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:30 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:30 ty D][simplekv.c:1156] no key find [01-01 00:00:30 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:30 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:30 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:30 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:30 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:30 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:30 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:30 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:30 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 0 [01-01 00:00:30 ty D][uni_network.c:312] set_dns_cache_priority:1 [01-01 00:00:30 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:30 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:30 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:30 ty D][uni_network.c:312] set_dns_cache_priority:0 [01-01 00:00:30 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [01-01 00:00:30 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:30 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:30 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:30 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:30 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:30 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:30 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:30 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:30 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:30 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:30 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:30 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:30 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:30 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1207340 [01-01 00:00:30 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:30 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:30 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:30 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:30 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:30 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:30 ty D][uni_network.c:285] lower_dns_cache_priority:1 [01-01 00:00:30 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:30 ty E][log_seq.c:142] ret:-1027 [01-01 00:00:30 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:30 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:31 ty D][tuya_devos_health.c:68] feed watchdog [01-01 00:00:31 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:31 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:31 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:31 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:31 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:31 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:31 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:31 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:31 ty D][simplekv.c:1156] no key find [01-01 00:00:31 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:31 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:31 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:31 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:31 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:31 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:31 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:31 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:31 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:31 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:31 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:31 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [01-01 00:00:31 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:31 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:31 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:31 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:31 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:31 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:31 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:31 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:31 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:31 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:31 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:31 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:31 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:31 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1206260 [01-01 00:00:31 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:31 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:31 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:31 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:31 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:31 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:31 ty D][uni_network.c:285] lower_dns_cache_priority:0 [01-01 00:00:31 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:31 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:31 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:32 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:32 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:32 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:32 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:32 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:32 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:32 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:32 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:32 ty D][simplekv.c:1156] no key find [01-01 00:00:32 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:32 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:32 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:32 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:32 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:32 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:32 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:32 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:32 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 0 [01-01 00:00:32 ty D][uni_network.c:312] set_dns_cache_priority:1 [01-01 00:00:32 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:32 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:32 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:32 ty D][uni_network.c:312] set_dns_cache_priority:0 [01-01 00:00:32 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:32 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:32 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:32 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:32 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:32 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:32 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:33 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:33 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:33 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:33 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:33 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:33 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:33 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:33 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1206260 [01-01 00:00:33 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:33 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:33 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:33 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:33 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:33 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:33 ty D][uni_network.c:285] lower_dns_cache_priority:1 [01-01 00:00:33 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:33 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:33 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:34 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:34 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:34 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:34 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:34 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:34 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:34 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:34 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:34 ty D][simplekv.c:1156] no key find [01-01 00:00:34 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:34 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:34 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:34 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:34 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:34 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:34 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:34 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:34 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:34 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:34 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:34 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [01-01 00:00:34 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:34 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:34 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:34 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:34 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:34 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:34 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:34 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:34 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:34 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:34 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:34 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:34 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:34 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1206260 [01-01 00:00:34 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:34 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:34 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:34 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:34 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:34 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:34 ty D][uni_network.c:285] lower_dns_cache_priority:0 [01-01 00:00:34 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:34 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:34 ty E][tuya_svc_devos_activate.c:183] activate backoff [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:35 ty D][tuya_svc_devos_activate_token.c:75] token activate get cloud url [01-01 00:00:35 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:35 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:35 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:35 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:35 ty D][simplekv.c:1254] cnt:4 delete bit arr len:1 [01-01 00:00:35 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:35 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:35 ty D][simplekv.c:1156] no key find [01-01 00:00:35 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:35 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:35 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:35 ty D][iot_httpc.c:1193] http_iot_dns_get_cloud_url start [01-01 00:00:35 ty D][iot_httpc.c:1239] http_dns region AY, send: {"region":"AY","env":"5bSP","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:35 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:35 ty D][iot_httpc.c:1243] get url config:https://h6.iot-dns.com/v2/url_config [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:35 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:35 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 0 [01-01 00:00:35 ty D][uni_network.c:312] set_dns_cache_priority:1 [01-01 00:00:35 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:35 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:35 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:35 ty D][uni_network.c:312] set_dns_cache_priority:0 [01-01 00:00:35 ty D][tcp_transporter.c:79] bind ip:c0a81d04 port:0 ok [01-01 00:00:35 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:35 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:35 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:35 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:35 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:35 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:35 ty D][tuya_tls.c:118] clear host session begin:h6.iot-dns.com [01-01 00:00:35 ty E][tuya_tls.c:1070] mbedtls_ssl_handshake returned 0x4e00 [01-01 00:00:35 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:35 ty E][tuya_tls.c:1110] TUYA_TLS faild Connect h6.iot-dns.com:443 [01-01 00:00:35 ty E][tls_transporter.c:71] tls transporter connect err:-19968 [01-01 00:00:35 ty D][tls_transporter.c:93] tls transporter close socket fd:32 [01-01 00:00:35 ty D][tcp_transporter.c:177] tcp transporter close socket fd:32 [01-01 00:00:35 ty D][tls_transporter.c:101] tls transporter close tls handler:0x1206260 [01-01 00:00:35 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:35 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:35 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:-1 [01-01 00:00:35 ty D][tls_transporter.c:93] tls transporter close socket fd:-1 [01-01 00:00:35 ty D][tls_transporter.c:98] tls transporter already closed [01-01 00:00:35 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:35 ty D][uni_network.c:285] lower_dns_cache_priority:1 [01-01 00:00:35 ty E][http_inf.c:59] Open session failed: https://h6.iot-dns.com/v2/url_config (-1) [01-01 00:00:35 ty E][iot_httpc.c:1251] fail to get cloud url -2050 [01-01 00:00:35 ty E][tuya_svc_devos_activate.c:189] activate timeout [LOG_I][TuyaService.c: 248] ipc status changed:1 [01-01 00:00:35 ty E][base_event.c:152] ret:-2 [01-01 00:00:35 ty D][tuya_wifi_netcfg.c:341] active event, type:0, stage:2 info->linkage:2 [01-01 00:00:35 ty D][tuya_wifi_netcfg.c:424] do proxy actived work,mode:2,stat:0,nc_tp:6 [01-01 00:00:35 ty D][tuya_svc_devos.c:770] set netcfgstat, stage:3, status:7 [01-01 00:00:35 ty D][tuya_ble_svc.c:1369] ble get conn stat:4 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:36 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:41 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:41 ty D][tuya_devos_utils.c:277] set time by rtc [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:46 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:51 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:00:56 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:01 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:06 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:11 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:11 ty D][tuya_devos_utils.c:277] set time by rtc [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:16 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:21 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:26 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:31 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:36 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:41 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:41 ty D][tuya_devos_utils.c:277] set time by rtc [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:46 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:51 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:01:56 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:02:01 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:02:06 ty D][tuya_devos_health.c:68] feed watchdog [01-01 00:02:06 ty D][simplekv.c:129] <__tmm_backup_work> backup file start...time: 126, MsTime: 672 [01-01 00:02:06 ty D][simplekv.c:241] backup normal file to bak success [01-01 00:02:06 ty D][simplekv.c:132] <__tmm_backup_work> backup file end...time: 126, MsTime: 688 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:02:11 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:02:11 ty D][tuya_devos_utils.c:277] set time by rtc [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:02:16 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [01-01 00:02:21 ty D][tuya_devos_health.c:68] feed watchdog [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6 [LOG_I][tkl_wifi.c: 469] tkl_wifi_station_get_status => status: 6
