[main, 571] Jan 24 2024,16:55:32 token[AYPVEWzz0omLW8] raw_path[/tmp/] cfg_path[tuya/tuya_device_cfg.json] detect auto test enviroment, load config from tuya/tuya_device_cfg.json buffer is { "pid":"qbylirgk3e9fmuvx", "uuid": "uuid77e39b4dd67846ff", "authkey": "ocjCPqs1hasiXASMZs8riYAVUtqDmAjl", "storage": "./", "media_path": "./", "sd_path": "/tmp/", "upgrade_file": "/tmp/upgrade.file", "app_version": "1.2.3" } s_ipc_pid: qbylirgk3e9fmuvx s_ipc_uuid: uuid77e39b4dd67846ff s_ipc_authkey: ocjCPqs1hasiXASMZs8riYAVUtqDmAjl s_ipc_storage: ./ s_raw_path: ./ s_ipc_sd_path: /tmp/ s_ipc_upgrade_file: /tmp/upgrade.file s_app_version: 1.2.3 SDK Version:< TuyaOS V:6.1.1 BS:40.00_PT:2.3_LAN:3.5_CAD:1.0.5_CD:1.0.0 > < BUILD AT:2024_01_18_14_41_48 BY ci_manage FOR tuyaos-ipc AT gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf > IOT DEFS < WIFI_GW:1 DEBUG:0 KV_FILE:0 LITTLE_END:1 SL:1 OPERATING_SYSTEM:100 RELIABLE_TRANSFER:0 > MODE:2 LINK_TYPE:2 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:wq_system,stackDepth:6144,totalstackDepth:10240,priority:3 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:wq_highpri,stackDepth:5120,totalstackDepth:15360,priority:4 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:16896,priority:5 [01-01 00:00:00 ty I][mqc_app.c:429] mqc app init ... [01-01 00:00:00 ty N][tal_wifi_reconnet.c:208] wifi status changed to 0 [01-01 00:00:00 ty I][kv_storge.c:45] Init Kvs With File:./ [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:lan_sock_loop,stackDepth:4096,totalstackDepth:20992,priority:3 [01-01 00:00:00 ty N][tuya_tls.c:852] uni_random_init... [01-01 00:00:00 ty N][tuya_tls.c:279] tuya_tls_rand_init ok! [01-01 00:00:00 ty N][tuya_wifi_connect.c:289] mf is open need stop fastconnect [01-01 00:00:00 ty D][tuya_ipc_media_adapter.c:97] media adapter init success. avaliable_res_size:5000 [01-01 00:00:00 ty D][tuya_ipc_media_adapter.c:465] insert media info node success! device:[0] channel:[0] [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:0 Enable:1 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:577] video_bitrate 1024, video_fps 30 [01-01 00:00:00 ty D][tuya_ring_buffer.c:637] Init Ring Buffer. ch0st0tr0 bitrate:1024 fps:30 [01-01 00:00:00 ty D][tuya_ring_buffer.c:660] Ring buffer malloc 1310720 bytes for ch0st0tr0, max frame size 196608 [01-01 00:00:00 ty I][tuya_ring_buffer.c:681] Init Ring Buffer success: ch0st0tr0 size:1310720 nodes:300 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:585] init ring buffer success. channel:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:1 Enable:1 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:577] video_bitrate 512, video_fps 30 [01-01 00:00:00 ty D][tuya_ring_buffer.c:637] Init Ring Buffer. ch0st0tr1 bitrate:512 fps:30 [01-01 00:00:00 ty D][tuya_ring_buffer.c:660] Ring buffer malloc 655360 bytes for ch0st0tr1, max frame size 98304 [01-01 00:00:00 ty I][tuya_ring_buffer.c:681] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:300 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:585] init ring buffer success. channel:1 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:2 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:3 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:4 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:5 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:6 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:7 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:8 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:9 Enable:1 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:568] audio_sample 8000, audio_databits 16, audio_fps 25 [01-01 00:00:00 ty D][tuya_ring_buffer.c:637] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25 [01-01 00:00:00 ty D][tuya_ring_buffer.c:660] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936 [01-01 00:00:00 ty I][tuya_ring_buffer.c:681] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:585] init ring buffer success. channel:9 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:10 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:11 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:12 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:13 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:14 Enable:0 [01-01 00:00:00 ty D][ty_sdk_media_callback.c:559] init ring buffer Channel:0 Stream:15 Enable:0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:1 gw_bi [01-01 00:00:00 ty D][simplekv.c:1185] key:gw_bi find value.Len:224 [01-01 00:00:00 ty D][tuya_ws_db.c:651] sync to protected len[223] [01-01 00:00:00 ty D][ws_db_gw.c:146] gw_bi read ret:0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:2 gw_wsm [01-01 00:00:00 ty D][simplekv.c:1185] key:gw_wsm find value.Len:144 [01-01 00:00:00 ty D][tuya_ws_db.c:651] sync to protected len[140] [01-01 00:00:00 ty D][ws_db_gw.c:255] gw_wsm read ret:0 [01-01 00:00:00 ty N][tuya_svc_devos.c:494] Last reset reason: 7 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_bi isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:1 gw_bi [01-01 00:00:00 ty D][simplekv.c:1185] key:gw_bi find value.Len:224 [01-01 00:00:00 ty D][tuya_ws_db.c:651] sync to protected len[223] [01-01 00:00:00 ty D][ws_db_gw.c:146] gw_bi read ret:0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_wsm isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:2 gw_wsm [01-01 00:00:00 ty D][simplekv.c:1185] key:gw_wsm find value.Len:144 [01-01 00:00:00 ty D][tuya_ws_db.c:651] sync to protected len[140] [01-01 00:00:00 ty D][ws_db_gw.c:255] gw_wsm read ret:0 [01-01 00:00:00 ty N][tuya_svc_devos.c:299] gw_cntl->gw_wsm.stat:0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_di isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:3 gw_di [01-01 00:00:00 ty D][simplekv.c:1185] key:gw_di find value.Len:672 [01-01 00:00:00 ty D][ws_db_gw.c:372] gw_di read ret:0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:is_stride isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][tuya_devos_stride.c:55] stride from flash: 0. [01-01 00:00:00 ty D][tuya_devos_stride.c:62] no actived, no upgrade:0 [01-01 00:00:00 ty N][tuya_svc_devos.c:347] gw_cntl->gw_if.abi:0 input:0 [01-01 00:00:00 ty N][tuya_svc_devos.c:348] gw_cntl->gw_if.product_key:qbylirgk3e9fmuvx, input:qbylirgk3e9fmuvx [01-01 00:00:00 ty N][tuya_svc_devos.c:349] gw_cntl->gw_if.tp:0, input:0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:gw_ai isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:4 gw_ai [01-01 00:00:00 ty D][simplekv.c:1185] key:gw_ai find value.Len:352 [01-01 00:00:00 ty D][ws_db_gw.c:454] gw_ai read ret:0 [01-01 00:00:00 ty N][tuya_svc_devos.c:523] enter success_proc WIFI Get MAC 00-00-00-00-00-00 [01-01 00:00:00 ty N][tuya_svc_devos.c:526] serial_no:000000000000 [01-01 00:00:00 ty D][tuya_svc_upgrade.c:1291] tuya svc upgrade init success! [01-01 00:00:00 ty D][simplekv.c:1128] read key:rcs.active isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][tuya_ws_db.c:657] rcs.active not found in kv, read from protected [01-01 00:00:00 ty D][simplekv.c:1128] read key:rcs.mf isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][tuya_ws_db.c:657] rcs.mf not found in kv, read from protected [01-01 00:00:00 ty D][tuya_register_center.c:350] use default rcs [-6] [01-01 00:00:00 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:6 tls_ca_cnt [01-01 00:00:00 ty D][simplekv.c:1185] key:tls_ca_cnt find value.Len:16 [01-01 00:00:00 ty D][tuya_cert_manager.c:467] tls_ca_cnt:1 and parse:1 [01-01 00:00:00 ty D][simplekv.c:1128] read key:tls_ca0 isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:5 tls_ca0 [01-01 00:00:00 ty D][simplekv.c:1185] key:tls_ca0 find value.Len:736 [01-01 00:00:00 ty D][tuya_cert_manager.c:497] Parse DER tls_ca0:540 success [01-01 00:00:00 ty D][tuya_register_center.c:308] def rcs url0:h3.iot-dns.com [01-01 00:00:00 ty D][tuya_register_center.c:311] def rcs urlx:h6.iot-dns.com [01-01 00:00:00 ty D][tuya_cert_manager.c:963] psk key was 1.0 [01-01 00:00:00 ty D][tuya_cert_manager.c:1058] cert manager init [01-01 00:00:00 ty D][simplekv.c:1128] read key:kv.meta.report isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][ty_meta_report.c:97] meta in kv {"metas":{}} [01-01 00:00:00 ty D][mqc_app.c:103] mq_pro:300 cnt:3 [01-01 00:00:00 ty D][mqc_app.c:103] mq_pro:302 cnt:4 [01-01 00:00:00 ty D][mqc_app.c:103] mq_pro:304 cnt:5 [01-01 00:00:00 ty D][mqc_app.c:103] mq_pro:307 cnt:6 [01-01 00:00:00 ty D][mqc_app.c:103] mq_pro:308 cnt:7 [01-01 00:00:00 ty D][mqc_app.c:103] mq_pro:312 cnt:8 [01-01 00:00:00 ty D][tuya_ipc_mqtt_subscribe.c:292] iot_register_extra_mqt_cb done [01-01 00:00:00 ty D][tuya_ipc_sdk_init.c:106] sys add timer: 7720144 [01-01 00:00:00 ty D][tuya_ipc_sdk_init.c:112] sys start timer: 7720144 [01-01 00:00:00 ty D][tuya_iot_base_api.c:316] register wired network monitor. interval:1 [01-01 00:00:00 ty D][tuya_svc_devos.c:760] state change from 0 to 1 [01-01 00:00:00 ty D][main.c:347] tuya ipc sdk start is complete [01-01 00:00:00 ty D][svc_netcfg_qrcode.c:127] start config [01-01 00:00:00 ty D][tuya_svc_mqtt_direct.c:264] start direct mqtt [01-01 00:00:00 ty D][uni_network.c:312] set_dns_cache_priority:1 [01-01 00:00:00 ty N][tuya_svc_netmgr_linkage.c:270] default linkage[1] is set [01-01 00:00:00 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:00 ty D][simplekv.c:1254] cnt:7 delete bit arr len:1 [01-01 00:00:00 ty D][simplekv.c:1279] delete key find 6 [01-01 00:00:00 ty D][simplekv.c:1311] Delete key:tls_ca_cnt 6 success [01-01 00:00:00 ty D][simplekv.c:207] update crc 1355485961 [01-01 00:00:00 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:00 ty D][simplekv.c:1320] Delete success [01-01 00:00:00 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:00 ty D][simplekv.c:1254] cnt:7 delete bit arr len:1 [01-01 00:00:00 ty D][simplekv.c:1273] fuzzy del find 5 tls_ca0 And set Arr[0]=0x20 [01-01 00:00:00 ty D][simplekv.c:1303] Delete key:5 tls_ca0 [01-01 00:00:00 ty D][simplekv.c:207] update crc 4210245718 [01-01 00:00:00 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:00 ty D][simplekv.c:1320] Delete success [01-01 00:00:00 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][tuya_cert_manager.c:463] load tls_ca_cnt fail. no ca in local db [01-01 00:00:00 ty D][iot_httpc.c:1367] http_iot_dns_get_cloud_url start [01-01 00:00:00 ty D][iot_httpc.c:1412] http_dns region , send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsPSKUrl","need_ca":false},{"key":"mqttsPSK3Url","need_ca":false},{"key":"httpsStdUrl","need_ca":true},{"key":"mqttsStdUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]} [01-01 00:00:00 ty D][tuya_register_center.c:434] rcs.urlx:h6.iot-dns.com [01-01 00:00:00 ty D][iot_httpc.c:1416] get url config:https://h6.iot-dns.com/v1/url_config tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:00 ty D][httpc.c:620] Connect: h6.iot-dns.com Port: 443 -->> [01-01 00:00:00 ty D][uni_network.c:230] unw_gethostbyname h6.iot-dns.com, prio 1 [01-01 00:00:00 ty D][uni_network.c:258] use system dns ip 42.192.31.176 for domain h6.iot-dns.com [01-01 00:00:00 ty D][uni_network.c:185] cache dns [h6.iot-dns.com]<->[42.192.31.176] [01-01 00:00:00 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:0 ok [01-01 00:00:00 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:00 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect h6.iot-dns.com:443 [01-01 00:00:00 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:00 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:00 ty D][tuya_cert_manager.c:209] iot-dns url [01-01 00:00:00 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:00 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:00 ty D][tuya_tls.c:1098] handshake finish for h6.iot-dns.com. set send/recv to user set [01-01 00:00:00 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect h6.iot-dns.com:443 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:00 ty D][httpc.c:622] Connect: h6.iot-dns.com Port: 443 --<< ,r:0 [01-01 00:00:00 ty D][tls_transporter.c:93] tls transporter close socket fd:6 [01-01 00:00:00 ty D][tcp_transporter.c:177] tcp transporter close socket fd:6 [01-01 00:00:00 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa4202ae8 [01-01 00:00:00 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:00 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:00 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:00 ty D][iot_httpc.c:1437] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216] [01-01 00:00:00 ty D][iot_httpc.c:1442] mqttUrl:[m2.tuyacn.com:1883][42.192.31.13] [01-01 00:00:00 ty D][iot_httpc.c:1466] httpsStdUrl:[https://a6.tuyacn.com/d.json][81.69.183.170] [01-01 00:00:00 ty D][iot_httpc.c:1467] mqttsStdUrl:[m6.tuyacn.com:8886][121.5.96.27] [01-01 00:00:00 ty D][iot_httpc.c:1506] httpsPSKUrl:[https://a3.tuyacn.com/d.json][81.69.183.170] [01-01 00:00:00 ty D][iot_httpc.c:1507] mqttsPSK3Url:[m3.tuyacn.com:8886][121.5.96.27] [01-01 00:00:00 ty D][iot_httpc.c:1518] ghostUrl:[baal.tuyacn.com:443][42.192.35.108] [01-01 00:00:00 ty D][simplekv.c:1248] delete key:tls_ca_cnt isFuzzy:0 [01-01 00:00:00 ty D][simplekv.c:1254] cnt:7 delete bit arr len:1 [01-01 00:00:00 ty D][simplekv.c:1287] key:tls_ca_cnt not find [01-01 00:00:00 ty D][simplekv.c:1248] delete key:tls_ca isFuzzy:1 [01-01 00:00:00 ty D][simplekv.c:1254] cnt:7 delete bit arr len:1 [01-01 00:00:00 ty D][simplekv.c:1287] key:tls_ca not find [01-01 00:00:00 ty D][tuya_cert_manager.c:438] tls_ca_name:tls_ca0 [01-01 00:00:00 ty D][simplekv.c:1128] read key:tls_ca0 isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][simplekv.c:369] write key:tls_ca0 And Value Len:736 [01-01 00:00:00 ty D][simplekv.c:401] 5 valid is false AND size old 804 >= new 736 [01-01 00:00:00 ty D][simplekv.c:415] find 5 available space [01-01 00:00:00 ty D][simplekv.c:452] reuse available space 30512 [01-01 00:00:00 ty D][simplekv.c:207] update crc 191124342 [01-01 00:00:00 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:00 ty D][simplekv.c:492] write success [01-01 00:00:00 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1156] no key find [01-01 00:00:00 ty D][simplekv.c:1198] __read_kv_raw fail. -3 [01-01 00:00:00 ty D][simplekv.c:1236] __read_kv_with_decode fail. -3 [01-01 00:00:00 ty D][simplekv.c:369] write key:tls_ca_cnt And Value Len:16 [01-01 00:00:00 ty D][simplekv.c:401] 6 valid is false AND size old 84 >= new 16 [01-01 00:00:00 ty D][simplekv.c:415] find 6 available space [01-01 00:00:00 ty D][simplekv.c:452] reuse available space 31316 [01-01 00:00:00 ty D][simplekv.c:207] update crc 1061858745 [01-01 00:00:00 ty D][simplekv.c:356] write head to normal file success [01-01 00:00:00 ty D][simplekv.c:492] write success [01-01 00:00:00 ty D][uni_network.c:185] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216] [01-01 00:00:00 ty D][uni_network.c:185] cache dns [https://a6.tuyacn.com/d.json]<->[81.69.183.170] [01-01 00:00:00 ty D][uni_network.c:185] cache dns [https://a3.tuyacn.com/d.json]<->[81.69.183.170] [01-01 00:00:00 ty D][uni_network.c:185] cache dns [m2.tuyacn.com:1883]<->[42.192.31.13] [01-01 00:00:00 ty D][uni_network.c:185] cache dns [m6.tuyacn.com:8886]<->[121.5.96.27] [01-01 00:00:00 ty D][uni_network.c:185] cache dns [m3.tuyacn.com:8886]<->[121.5.96.27] [01-01 00:00:00 ty D][uni_network.c:185] cache dns [baal.tuyacn.com:443]<->[42.192.35.108] [01-01 00:00:00 ty D][simplekv.c:1128] read key:tls_ca_cnt isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:6 tls_ca_cnt [01-01 00:00:00 ty D][simplekv.c:1185] key:tls_ca_cnt find value.Len:16 [01-01 00:00:00 ty D][tuya_cert_manager.c:467] tls_ca_cnt:1 and parse:1 [01-01 00:00:00 ty D][simplekv.c:1128] read key:tls_ca0 isFuzzy:0 skipCnt:0 [01-01 00:00:00 ty D][simplekv.c:1159] find key:5 tls_ca0 [01-01 00:00:00 ty D][simplekv.c:1185] key:tls_ca0 find value.Len:736 [01-01 00:00:00 ty D][tuya_cert_manager.c:497] Parse DER tls_ca0:540 success [01-01 00:00:00 ty D][iot_httpc.c:1529] end [01-01 00:00:00 ty D][uni_network.c:312] set_dns_cache_priority:1 [01-01 00:00:00 ty D][tuya_svc_mqtt_direct.c:179] SECURITY_LEVEL:1 direct connect MQTT URL:m6.tuyacn.com:8886 Port:8883 Sub:d/ai/uuid77e39b4dd67846ff tls:1 [01-01 00:00:00 ty I][tal_thread.c:185] thread_create name:mqtt_thread,stackDepth:9216,totalstackDepth:30208,priority:4 [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 0 -> 1 [01-01 00:00:00 ty D][ty_sdk_status_callback.c:79] status chaged: group[1] status[5] [01-01 00:00:00 ty D][ty_sdk_status_callback.c:32] __on_netcfg_start, netcfg start. You can start your own netcfg task now. Set Country Code:0 [01-01 00:00:00 ty D][tuya_wifi_reset.c:559] reset init mthd:0, short timer:0 long timer:0 [01-01 00:00:00 ty D][tuya_wifi_netcfg.c:424] do proxy actived work,mode:5,stat:0,nc_tp:0 Exec Cmd:ifconfig wlan0 up [01-01 00:00:00 ty D][tal_thread.c:204] Thread:mqtt_thread Exec Start. Set to Running Stat [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:00 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:00 ty D][uni_network.c:246] use dynamic dns ip:121.5.96.27 for domain:m6.tuyacn.com [01-01 00:00:00 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:58578 ok WIFI Set Mode 0 [01-01 00:00:00 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:00 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:00 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:00 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:00 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:00 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:00 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:00 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:00 ty N][tuya_wifi_status.c:168] cur stat:0 0x0 -->> [01-01 00:00:00 ty N][tuya_wifi_status.c:171] wifi netstat changed to:0 -->> [01-01 00:00:00 ty N][tuya_svc_devos.c:216] __devos_init_evt success [01-01 00:00:00 ty D][tuya_iot_base_api.c:298] wired netstat changed to:1 -->> [01-01 00:00:00 ty D][ty_sdk_status_callback.c:79] status chaged: group[3] status[21] [01-01 00:00:00 ty D][ty_sdk_status_callback.c:86] status ignore. cb is null. [01-01 00:00:00 ty D][tuya_iot_base_api.c:300] wired netstat changed to:1 <<-- [01-01 00:00:00 ty D][tuya_svc_netmgr_linkage.c:117] link[1] is_up[1] active_link[2] status[2] [01-01 00:00:00 ty N][tuya_svc_netmgr_linkage.c:138] default linkage[1] is set, switch is disabled [01-01 00:00:00 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:00 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:00 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:00:00 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:00 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:1 [01-01 00:00:00 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:00 ty D][tls_transporter.c:93] tls transporter close socket fd:6 [01-01 00:00:00 ty D][tcp_transporter.c:177] tcp transporter close socket fd:6 [01-01 00:00:00 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa4300a08 [01-01 00:00:00 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:00 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:00 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:00 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:00 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:00 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:00 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:1, sleeptime:1017 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:01 ty N][tuya_svc_lan.c:713] Not actived, use linkage addr[192.168.248.173][c0a8f8ad] [01-01 00:00:01 ty D][tuya_lan_sock.c:331] reg post queue 6 [01-01 00:00:01 ty D][tuya_lan_sock.c:331] reg post queue 7 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:01 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:01 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:01 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:01 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:01 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:01 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:11984 ok [01-01 00:00:01 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:01 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:01 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:01 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:01 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:01 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:01 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:01 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:01 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:01 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:01 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:01 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:01 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:01 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:01 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:02 ty D][tuya_lan_sock.c:127] reg lan sock 6,read:0x7754c tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:02 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:02 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:2 [01-01 00:00:02 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:02 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:02 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:02 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:02 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:02 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:02 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:02 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:02 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:02 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:02 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:02 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:2, sleeptime:3452 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:03 ty D][tuya_lan_sock.c:127] reg lan sock 7,read:0x7a5f0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:05 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:05 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:05 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:05 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:05 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:05 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:37411 ok [01-01 00:00:05 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:05 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:05 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:05 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:05 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:05 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:05 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:05 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:05 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:05 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:05 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:05 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:05 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:05 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:05 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:00:05 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:05 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:3 [01-01 00:00:05 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:05 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:05 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:05 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:05 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:05 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:05 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:05 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:05 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:05 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:05 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:05 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:3, sleeptime:2463 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:08 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:08 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:08 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:08 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:08 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:08 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:5357 ok [01-01 00:00:08 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:08 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:08 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:08 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:08 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:08 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:08 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:08 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:08 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:08 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:08 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:08 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:08 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:08 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:08 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:00:08 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:08 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:4 [01-01 00:00:08 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:08 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:08 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:08 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:08 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:08 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:08 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:08 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:08 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:08 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:08 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:08 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:4, sleeptime:1772 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:09 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:09 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:09 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:09 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:09 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:09 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:24365 ok [01-01 00:00:09 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:09 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:09 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:09 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:09 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:09 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:09 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:09 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:10 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:10 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:10 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:10 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:10 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:10 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:10 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:00:10 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:10 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:5 [01-01 00:00:10 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:10 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:10 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:10 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:10 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:10 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:10 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:10 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:10 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:10 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:10 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:10 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:5, sleeptime:8842 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:18 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:18 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:18 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:18 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:18 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:18 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:4826 ok [01-01 00:00:18 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:18 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:18 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:18 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:18 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:18 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:18 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:18 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:18 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:18 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:18 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:18 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:18 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:18 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:18 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:19 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:19 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:6 [01-01 00:00:19 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:19 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:19 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:19 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:19 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:19 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:19 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:19 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:19 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:19 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:19 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:19 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:6, sleeptime:6378 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:25 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:25 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:25 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:25 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:25 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:25 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:14062 ok [01-01 00:00:25 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:25 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:25 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:25 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:25 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:25 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:25 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:25 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:25 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:25 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:25 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:25 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:25 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:25 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:25 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:00:25 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:25 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:7 [01-01 00:00:25 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:25 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:25 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:25 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:25 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:25 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:25 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:25 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:25 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:25 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:25 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:25 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:7, sleeptime:7626 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:33 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:33 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:33 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:33 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:33 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:33 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:5558 ok [01-01 00:00:33 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:33 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:33 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:33 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:33 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:33 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:33 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:33 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:33 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:33 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:33 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:33 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:33 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:33 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:33 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:00:33 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:33 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:8 [01-01 00:00:33 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:33 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:33 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:33 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:33 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:33 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:33 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:33 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:33 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:33 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:33 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:33 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:8, sleeptime:11544 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:44 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:44 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:44 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:44 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:44 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:44 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:12889 ok [01-01 00:00:44 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:44 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:44 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:44 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:44 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:44 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:44 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:44 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:44 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:44 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:44 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:44 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:44 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:44 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:44 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:00:44 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:44 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:9 [01-01 00:00:44 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:44 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:44 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:44 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:44 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:44 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:44 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:44 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:44 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:44 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:44 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:44 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:9, sleeptime:7217 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:52 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:00:52 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:00:52 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:00:52 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:00:52 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:00:52 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:9238 ok [01-01 00:00:52 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:00:52 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:00:52 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:00:52 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:00:52 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:00:52 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:00:52 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:00:52 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:00:52 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:00:52 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:00:52 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:00:52 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:00:52 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:00:52 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:00:52 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:00:52 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:00:52 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:10 [01-01 00:00:52 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:52 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:00:52 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:00:52 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:00:52 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:00:52 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:00:52 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:00:52 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:00:52 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:00:52 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:00:52 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:00:52 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:10, sleeptime:10889 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:01:03 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:01:03 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:01:03 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:01:03 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:01:03 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:01:03 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:28697 ok [01-01 00:01:03 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:01:03 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:01:03 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:01:03 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:01:03 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:01:03 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:01:03 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:01:03 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:01:03 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:01:03 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:01:03 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:01:03 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:01:03 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:01:03 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:01:03 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:01:03 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:01:03 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:11 [01-01 00:01:03 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:01:03 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:01:03 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:01:03 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:01:03 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:01:03 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:01:03 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:01:03 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:01:03 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:01:03 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:01:03 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:01:03 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:11, sleeptime:9530 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:01:12 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:01:12 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:01:12 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:01:12 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:01:12 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:01:12 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:27232 ok [01-01 00:01:12 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:01:12 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:01:12 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:01:12 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:01:12 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:01:12 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:01:12 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:01:12 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:01:12 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:01:12 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:01:12 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:01:12 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:01:12 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:01:12 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:01:12 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:01:12 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:01:12 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:12 [01-01 00:01:12 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:01:12 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:01:12 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:01:12 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:01:12 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:01:12 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:01:12 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:01:12 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:01:12 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:01:12 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:01:12 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:01:12 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:12, sleeptime:9357 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:01:22 ty N][tuya_svc_mqtt_client.c:836] connect to mqtt broker mqtts://m6.tuyacn.com:8886 port 8886 tkl_wired_get_ip 317: ifname=eth0 [01-01 00:01:22 ty N][tuya_svc_mqtt_client.c:846] mqtt client ip:192.168.248.173 [01-01 00:01:22 ty D][uni_network.c:230] unw_gethostbyname m6.tuyacn.com, prio 1 [01-01 00:01:22 ty D][uni_network.c:258] use system dns ip 121.5.96.27 for domain m6.tuyacn.com [01-01 00:01:22 ty D][uni_network.c:185] cache dns [m6.tuyacn.com]<->[121.5.96.27] [01-01 00:01:22 ty D][tcp_transporter.c:79] bind ip:c0a8f8ad port:49725 ok [01-01 00:01:22 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-01 00:01:22 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect m6.tuyacn.com:8886 [01-01 00:01:22 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-01 00:01:22 ty D][tuya_tls.c:727] load tuya cert. [01-01 00:01:22 ty D][tuya_cert_manager.c:213] p_url:m6.tuyacn.com:8886, rcs.urlx:h6.iot-dns.com [01-01 00:01:22 ty D][tuya_cert_manager.c:236] tuya public url [01-01 00:01:22 ty D][tuya_cert_manager.c:1099] parse crt <0> len <540> ret <0> [01-01 00:01:22 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [01-01 00:01:22 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-01 00:01:22 ty D][tuya_tls.c:1098] handshake finish for m6.tuyacn.com. set send/recv to user set [01-01 00:01:22 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect m6.tuyacn.com:8886 Suit:TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256 [01-01 00:01:22 ty N][tuya_svc_mqtt_client.c:883] setup mqtt transporter success [01-01 00:01:22 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 1 -> 2 [01-01 00:01:22 ty N][tuya_svc_mqtt_client.c:908] send mqtt connect success [01-01 00:01:22 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 2 -> 3 [01-01 00:01:22 ty E][tuya_svc_mqtt_client.c:928] host[mqtts://m6.tuyacn.com:8886] mqtt connect resp err:5 [01-01 00:01:22 ty D][tuya_svc_mqtt_direct.c:132] mqtt connect deny:13 [01-01 00:01:22 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:01:22 ty N][tuya_svc_mqtt_client.c:665] mqtt close [01-01 00:01:22 ty D][tls_transporter.c:93] tls transporter close socket fd:9 [01-01 00:01:22 ty D][tcp_transporter.c:177] tcp transporter close socket fd:9 [01-01 00:01:22 ty D][tls_transporter.c:101] tls transporter close tls handler:0xa43009b8 [01-01 00:01:22 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-01 00:01:22 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-01 00:01:22 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-01 00:01:22 ty N][tuya_svc_mqtt_client.c:177] [mqtts://m6.tuyacn.com:8886] mqtt state change 3 -> 1 [01-01 00:01:22 ty D][tuya_svc_mqtt_direct.c:124] mqtt disconnected [01-01 00:01:22 ty N][svc_netcfg_qrcode.c:89] direct mqtt disconnected [01-01 00:01:22 ty D][tuya_svc_mqtt_client.c:717] mqtt fail_cnt:13, sleeptime:18241 ms tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 tkl_wired_get_ip 317: ifname=eth0 [signal_handle, 59] get signal(2) name(demo)
