[LOG_I][AVTask.c: 27] av_task_handle_msg, msg_id:0xb, msg_param:0xe98250 [LOG_I][AVTask.c: 39] avSnapPicture Snap AV_TASK_MSG_ID_SNAP [LOG_I][DevMngTask.c: 222] devmng_task_handle_msg, msg_id:0x4, msg_param:0x2 [LOG_I][DevMngTask.c: 117] open chime, chimeType=3 [LOG_I][RecordTask.c: 50] record_task_handle_msg, msg_id:0xop_record, dropRecord:0 [LOG_I][AVRecord.c: 673] not recording, no need stop. [LOG_I][AVRecord.c: 576] start_record, type:14, msg_param:0x1 [LOG_I][AVRecord.c: 667] st [LOG_W][AVRecord.c: 594] start_record failed, sd card no ready, status = 0 [LOG_I][AudioRes.c: 43] Read audio res success, len:192 [LOG_I][AudioRes.c: 43] Read audio res success, len:31200 [DBG_][AVStream.c: 1819] Resample audio res, size:31200, newSampleRate:8000[LOG_W][AVTaskMsg.c: 60] Snap complete, size:3986 [LOG_I][EsPush.c: 553] ring pSnapMsgContext->snapSize = 3986 [LOG_W][TuyaMediaService.c: 663] Notify start cloud storage, type=0 [LOG_W][EsPush.c: 312] Got push message:0 [LOG_I][EsPush.c: 323] tuya_ipc_notify_with_event [01-25 15:36:25 ty D][tuya_ipc_notify.c:187] size:0 type 1 [01-25 15:36:25 ty D][mqc_app.c:691] Send MQTT Msg.P:43 N:56366 Q:1 Data:{"etype":"ac_doorbell","edata":"ce5e6ef1706168185","devId":"6c69a0ff1dcce7b03a0opf","filename":"1706168185.jpeg","time":"1706168185"} [01-25 15:36:25 ty D][tuya_svc_mqtt_client.c:427] packet id: 64 [01-25 15:36:25 ty D][tuya_ipc_notify.c:197] send mq done [01-25 15:36:25 ty D][tuya_ipc_event.c:803] start upload alarm to cloud [01-25 15:36:25 ty D][tuya_ipc_event.c:848] start tuya_notification_content_upload_from_buffer_unify [01-25 15:36:25 ty D][upload_notification.c:649] cfg_type=2, security_level=3 [01-25 15:36:25 ty D][encrypt_pic.c:193] en with key md5 34712824cd5f21a2ce2e2f5043b8a8f1 [01-25 15:36:25 ty D][encrypt_pic.c:129] security_level[3] en with iv[acfa372ae3fff366], size 3986 to 4000 [01-25 15:36:25 ty D][encrypt_pic.c:132] en with key md5 34712824cd5f21a2ce2e2f5043b8a8f1 [01-25 15:36:25 ty D][encrypt_pic.c:140] en with size 3986 to 4064 [01-25 15:36:25 ty D][upload_notification.c:498] notification from buffer. type:image/jpeg name:1706168185.jpeg data_len:4064 [01-25 15:36:25 ty D][cloud_operation.c:1626] Final PUT:https://ty-cn-storage30-1254153901.tuyacn.com/2df829-69933427-rs016d2565b7e5db4a24/unify/1706168185.jpeg,size 4064 [LOG_I][tkl_wifi.c: 816] tkl_wifi_station_get_status => status: 6 [01-25 15:36:25 ty D][httpc.c:620] Connect: ty-cn-storage30-1254153901.tuyacn.com Port: 443 -->> [01-25 15:36:25 ty D][uni_network.c:230] unw_gethostbyname ty-cn-storage30-1254153901.tuyacn.com, prio 0 [01-25 15:36:25 ty D][uni_network.c:90] use dynamic dns ip 121.4.234.200 for domain ty-cn-storage30-1254153901.tuyacn.com [01-25 15:36:25 ty D][tcp_transporter.c:79] bind ip:c0a81d05 port:0 ok [01-25 15:36:25 ty E][tuya_ipc_cloud_storage.c:2549] event on going now, stop it first [01-25 15:36:26 ty D][tuya_tls.c:945] MAX SECURITY_LEVEL:1, TUYA SECURITY_LEVEL:1, mode:1 [01-25 15:36:26 ty D][tuya_tls.c:954] TUYA_TLS Begin Connect ty-cn-storage30-1254153901.tuyacn.com:443 [01-25 15:36:26 ty D][tuya_tls.c:714] mbedtls authmode: MBEDTLS_SSL_VERIFY_REQUIRED [01-25 15:36:26 ty D][tuya_tls.c:727] load tuya cert. [01-25 15:36:26 ty D][tuya_cert_manager.c:213] p_url:ty-cn-storage30-1254153901.tuyacn.com, rcs.urlx:h6.iot-dns.com [01-25 15:36:26 ty D][tuya_cert_manager.c:241] third cloud url [01-25 15:36:26 ty D][tuya_cert_manager.c:103] load ca to tls [01-25 15:36:26 ty D][tuya_tls.c:1036] socket fd is set. set to inner send/recv to handshake [LOG_I][tkl_wifi.c: 816] tkl_wifi_station_get_status => status: 6 [01-25 15:36:26 ty D][tuya_svc_lan.c:1827] fd:236, wk_stat = 2, type = 32 [01-25 15:36:26 ty I][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":269615,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_state","tid":"","s":"6c69a0ff1dcce7b03a0opf1706168132jA86vkdk","l":"6c69a0ff1dcce7b03a0opf","r":"ay1668160283687MvekA","o":1,"a":3,"as":2,"h":2,"e":0,"ex":0,"d":53158} [01-25 15:36:26 ty I][tuya_ipc_media_stream.c:71] [RTC LOG] {"t":269616,"v":"tuya_p2p_sdk_v3.4.120","p":"rtc_session_add","tid":"","s":"6c69a0ff1dcce7b03a0opf1706168132jA86vkdk","l":"6c69a0ff1dcce7b03a0opf","r":"ay1668160283687MvekA","ca":"","st":"new_session","e":0,"ex":0,"d":53159,"th":{"tconn":217523,"tresp":217796,"tcomp":218259},"ih":{"ha":true,"hlc":true,"hlh":true,"hls":true,"hlr":true,"hrc":true,"hrh":true,"hrs":true,"hrr":true}} [01-25 15:36:26 ty D][tuya_ipc_p2p.c:4974] __p2p_deal_with_listen, session[131075] [01-25 15:36:26 ty D][mqc_app.c:691] Send MQTT Msg.P:302 N:56367 Q:0 Data:{"header":{"from":"6c69a0ff1dcce7b03a0opf","to":"ay1668160283687MvekA","sessionid":"6c69a0ff1dcce7b03a0opf1706168132jA86vkdk","moto_id":"","type":"activate_resp","trace_id":"","path":"mqtt"},"msg":{"handle":2,"error":0,"seq":3}} [01-25 15:36:26 ty D][mqc_app.c:336] Rev MQTT:{"data":{"header":{"from":"ay1668160283687MvekA","moto_id":"","path":"mqtt","sessionid":"6c69a0ff1dcce7b03a0opf1706168132jA86vkdk","to":"6c69a0ff1dcce7b03a0opf","trace_id":"","type":"activate"},"msg":{"handle":2,"seq":3}},"protocol":302,"t":1706168185} [01-25 15:36:26 ty D][tuya_ipc_mqtt_subscribe.c:213] recv mq: protocol 302 [01-25 15:36:26 ty D][tuya_tls.c:687] mbedtls_cert_pkey_free. [01-25 15:36:26 ty D][tuya_tls.c:1098] handshake finish for ty-cn-storage30-1254153901.tuyacn.com. set send/recv to user set [01-25 15:36:26 ty D][tuya_tls.c:1104] TUYA_TLS Success Connect ty-cn-storage30-1254153901.tuyacn.com:443 Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256 [01-25 15:36:26 ty D][httpc.c:622] Connect: ty-cn-storage30-1254153901.tuyacn.com Port: 443 --<< ,r:0 [01-25 15:36:26 ty D][tuya_ipc_p2p.c:4250] compare passwd [01-25 15:36:26 ty D][tuya_ipc_p2p.c:4271] auth success [01-25 15:36:26 ty D][tuya_ipc_p2p.c:577] __p2p_get_idle_session begin [01-25 15:36:26 ty D][tuya_ipc_media_adapter.c:150] alloc resource success: user handle [0xd64fb0][1000 KB], user num [2] res[4000] [01-25 15:36:26 ty D][tuya_ipc_p2p.c:4320] session:[0] malloc video send buffer success [01-25 15:36:26 ty D][tuya_ipc_p2p.c:4369] session:[0] malloc audio send buffer success [01-25 15:36:26 ty D][tuya_ipc_p2p.c:5043] create p2p sessions. cur online session num = 1 [01-25 15:36:26 ty D][tuya_ipc_p2p.c:2986] recv session[131075] high cmd[10] low cmd[0] len[4] req_id[0] [01-25 15:36:26 ty D][tuya_ipc_p2p.c:2986] recv session[131075] high cmd[2] low cmd[0] len[4] req_id[46] [01-25 15:36:26 ty D][tuya_ipc_p2p.c:2986] recv session[131075] high cmd[9] low cmd[0] len[8] req_id[327728] [01-25 15:36:26 ty D][tuya_ipc_p2p.c:3799] set video clarity session[131075]chn[0] op[4] clarity[1] [DBG_][TuyaMediaService.c: 708] p2p rev event cb=[34] [LOG_I][TuyaMediaService.c: 1038] set clarity:1 [01-25 15:36:26 ty D][tuya_ipc_p2p.c:3801] ipc chan 0 clarity 1 [01-25 15:36:26 ty D][tuya_ipc_p2p.c:2986] recv session[131075] high cmd[6] low cmd[0] len[8] req_id[327727] [01-25 15:36:26 ty D][tuya_ipc_p2p.c:3203] CTRL VIDEO session[131075] chn[0] op[0] [01-25 15:36:26 ty D][tuya_ipc_p2p.c:1791] session[131075]video video_start wait_concurr_idle [01-25 15:36:26 ty D][tuya_ipc_p2p.c:4938] session[131075] concurr idle[2][2] [DBG_][TuyaMediaService.c: 708] p2p rev event cb=[30] [LOG_I][TuyaMediaService.c: 721] chn[0] video start [01-25 15:36:26 ty D][tuya_ipc_p2p.c:1803] session[131075] video start success [01-25 15:36:26 ty D][tuya_ipc_p2p.c:2986] recv session[131075] high cmd[6] low cmd[4] len[8] req_id[327729] [01-25 15:36:26 ty D][tuya_imm_service_log.c:764] trigger upload timer.... [01-25 15:36:26 ty D][tuya_ipc_p2p.c:3203] CTRL VIDEO session[131075] chn[0] op[4] [01-25 15:36:26 ty D][tuya_ipc_p2p.c:1850] session[131075] send audio start to dev [DBG_][TuyaMediaService.c: 708] p2p rev event cb=[32] [LOG_I][TuyaMediaService.c: 759] chn[0] audio start [01-25 15:36:26 ty D][tuya_ipc_p2p.c:1857] session:[131075] audio start success [LOG_I][AVTask.c: 27] av_task_handle_msg, msg_id:0x8, msg_param:0 [01-25 15:36:26 ty D][tuya_imm_service_log.c:414] upload timer trigger.... [01-25 15:36:26 ty D][tuya_imm_service_log.c:437] start send. [01-25 15:36:26 ty D][mqc_app.c:891] Send MQTT Msg.P:312 N:56368 Q:0 [01-25 15:36:26 ty D][tuya_svc_mqtt_client.c:427] packet id: 65 [01-25 15:36:26 ty D][tuya_ring_buffer.c:767] ch0st0tr0 open with type 0 [01-25 15:36:26 ty E][tuya_ipc_p2p.c:4478] session[131075] open_stream video success [01-25 15:36:26 ty D][tuya_ring_buffer.c:767] ch0st0tr9 open with type 0 [01-25 15:36:26 ty E][tuya_ipc_p2p.c:4497] session[131075] open_stream audio success [01-25 15:36:26 ty D][tuya_ring_buffer.c:1051] get latest audio frame success, node 30 seq_no 5280 ch0st0tr9 [01-25 15:36:26 ty D][tuya_ipc_p2p.c:2340] session send video cnt [1] ring[0] [01-25 15:36:26 ty D][tuya_ipc_p2p.c:2349] session send audio cnt [1] [01-25 15:36:26 ty D][tls_transporter.c:93] tls transporter close socket fd:240 [01-25 15:36:26 ty D][tcp_transporter.c:177] tcp transporter close socket fd:240 [01-25 15:36:26 ty D][tls_transporter.c:101] tls transporter close tls handler:0xb519b0 [01-25 15:36:26 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-25 15:36:26 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-25 15:36:26 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-25 15:36:26 ty D][cloud_operation.c:1688] HTTPS PUT https://ty-cn-storage30-1254153901.tuyacn.com/2df829-69933427-rs016d2565b7e5db4a24/unify/1706168185.jpeg done,size 4064 cost 685 ms [01-25 15:36:26 ty D][upload_notification.c:531] __notification_content_upload_from_buffer success [01-25 15:36:26 ty D][tuya_ipc_event.c:898] start tuya_notification_message_upload_for_event_unify [01-25 15:36:26 ty D][upload_notification.c:1516] notify DP:212 timeout:5 [01-25 15:36:26 ty D][upload_notification.c:1521] count:1 and len:834 [01-25 15:36:26 ty D][upload_notification.c:1552] final:{"v":"5.0","cost_time":"686","cmd":"ipc_doorbell","type":"image","with":"resource","alarm":true,"time":1706168185,"files":[["ty-cn-storage30-1254153901","/2df829-69933427-rs016d2565b7e5db4a24/unify/1706168185.jpeg","478c9c57bc474f67","1708760186"]]} [01-25 15:36:26 ty D][smart_frame.c:3797] rept chan:3 [01-25 15:36:26 ty D][smart_frame.c:518] is_need_update:1, is_dp_passive:0 [01-25 15:36:26 ty D][smart_frame.c:783] Send dp:212, RAW:{"212":"eyJ2IjoiNS4wIiwiY29zdF90aW1lIjoiNjg2IiwiY21kIjoiaXBjX2Rvb3JiZWxsIiwidHlwZSI6ImltYWdlIiwid2l0aCI6InJlc291cmNlIiwiYWxhcm0iOnRydWUsInRpbWUiOjE3MDYxNjgxODUsImZpbGVzIjpbWyJ0eS1jbi1zdG9yYWdlMzAtMTI1NDE1MzkwMSIsIi8yZGY4MjktNjk5MzM0MjctcnMwMTZkMjU2NWI3ZTVkYjRhMjQvdW5pZnkvMTcwNjE2ODE4NS5qcGVnIiwiNDc4YzljNTdiYzQ3NGY2NyIsIjE3MDg3NjAxODYiXV19"}, retrans:1 [01-25 15:36:26 ty D][smart_frame.c:2492] dp rept_type:1, data:{"212":"eyJ2IjoiNS4wIiwiY29zdF90aW1lIjoiNjg2IiwiY21kIjoiaXBjX2Rvb3JiZWxsIiwidHlwZSI6ImltYWdlIiwid2l0aCI6InJlc291cmNlIiwiYWxhcm0iOnRydWUsInRpbWUiOjE3MDYxNjgxODUsImZpbGVzIjpbWyJ0eS1jbi1zdG9yYWdlMzAtMTI1NDE1MzkwMSIsIi8yZGY4MjktNjk5MzM0MjctcnMwMTZkMjU2NWI3ZTVkYjRhMjQvdW5pZnkvMTcwNjE2ODE4NS5qcGVnIiwiNDc4YzljNTdiYzQ3NGY2NyIsIjE3MDg3NjAxODYiXV19"} [01-25 15:36:26 ty D][com_protocol.c:758] To:0 src:{"dps":{"212":"eyJ2IjoiNS4wIiwiY29zdF90aW1lIjoiNjg2IiwiY21kIjoiaXBjX2Rvb3JiZWxsIiwidHlwZSI6ImltYWdlIiwid2l0aCI6InJlc291cmNlIiwiYWxhcm0iOnRydWUsInRpbWUiOjE3MDYxNjgxODUsImZpbGVzIjpbWyJ0eS1jbi1zdG9yYWdlMzAtMTI1NDE1MzkwMSIsIi8yZGY4MjktNjk5MzM0MjctcnMwMTZkMjU2NWI3ZTVkYjRhMjQvdW5pZnkvMTcwNjE2ODE4NS5qcGVnIiwiNDc4YzljNTdiYzQ3NGY2NyIsIjE3MDg3NjAxODYiXV19"}} pro:4 num:56369 [01-25 15:36:26 ty D][com_protocol.c:773] After Pack:{"protocol":4,"t":1706168186,"data":{"dps":{"212":"eyJ2IjoiNS4wIiwiY29zdF90aW1lIjoiNjg2IiwiY21kIjoiaXBjX2Rvb3JiZWxsIiwidHlwZSI6ImltYWdlIiwid2l0aCI6InJlc291cmNlIiwiYWxhcm0iOnRydWUsInRpbWUiOjE3MDYxNjgxODUsImZpbGVzIjpbWyJ0eS1jbi1zdG9yYWdlMzAtMTI1NDE1MzkwMSIsIi8yZGY4MjktNjk5MzM0MjctcnMwMTZkMjU2NWI3ZTVkYjRhMjQvdW5pZnkvMTcwNjE2ODE4NS5qcGVnIiwiNDc4YzljNTdiYzQ3NGY2NyIsIjE3MDg3NjAxODYiXV19"}}} offset:387 [01-25 15:36:26 ty D][tuya_svc_lan.c:1198] Prepare To Send Lan:{"dps":{"212":"eyJ2IjoiNS4wIiwiY29zdF90aW1lIjoiNjg2IiwiY21kIjoiaXBjX2Rvb3JiZWxsIiwidHlwZSI6ImltYWdlIiwid2l0aCI6InJlc291cmNlIiwiYWxhcm0iOnRydWUsInRpbWUiOjE3MDYxNjgxODUsImZpbGVzIjpbWyJ0eS1jbi1zdG9yYWdlMzAtMTI1NDE1MzkwMSIsIi8yZGY4MjktNjk5MzM0MjctcnMwMTZkMjU2NWI3ZTVkYjRhMjQvdW5pZnkvMTcwNjE2ODE4NS5qcGVnIiwiNDc4YzljNTdiYzQ3NGY2NyIsIjE3MDg3NjAxODYiXV19"}}, msg_len:350, out_len:402 [LOG_I][tkl_wifi.c: 816] tkl_wifi_station_get_status => status: 6 [01-25 15:36:26 ty D][mqc_app.c:691] Send MQTT Msg.P:4 N:56369 Q:1 Data:{"dps":{"212":"eyJ2IjoiNS4wIiwiY29zdF90aW1lIjoiNjg2IiwiY21kIjoiaXBjX2Rvb3JiZWxsIiwidHlwZSI6ImltYWdlIiwid2l0aCI6InJlc291cmNlIiwiYWxhcm0iOnRydWUsInRpbWUiOjE3MDYxNjgxODUsImZpbGVzIjpbWyJ0eS1jbi1zdG9yYWdlMzAtMTI1NDE1MzkwMSIsIi8yZGY4MjktNjk5MzM0MjctcnMwMTZkMjU2NWI3ZTVkYjRhMjQvdW5pZnkvMTcwNjE2ODE4NS5qcGVnIiwiNDc4YzljNTdiYzQ3NGY2NyIsIjE3MDg3NjAxODYiXV19"}} [01-25 15:36:26 ty D][tuya_svc_mqtt_client.c:427] packet id: 66 [01-25 15:36:26 ty D][smart_frame.c:215] set short dp rate rule, dpID:212, curr_t:1706168186, rept_cnt:3. [01-25 15:36:26 ty D][smart_frame.c:223] set long dp rate rule, dpID:212, curr_t:1706168186, rept_cnt:0. [01-25 15:36:26 ty D][smart_frame.c:232] set all dp rate rule, dpID:212, curr_t:1706168186, rept_cnt:0. [01-25 15:36:26 ty D][upload_notification.c:1561] tuya_notify_message_upload success [01-25 15:36:26 ty D][tuya_ipc_event.c:946] stop upload alarm to cloud [LOG_I][EsPush.c: 335] ---2024-1-25--ES_PUSH_NOTIFICATION_TYPE_RING-tuya_ipc_notify_with_event success [LOG_I][tkl_wifi.c: 816] tkl_wifi_station_get_status => status: 6 [LOG_I][DevMngTask.c: 174] stop chime [LOG_I][tkl_wifi.c: 816] tkl_wifi_station_get_status => status: 6 [01-25 15:36:28 ty D][tls_transporter.c:93] tls transporter close socket fd:92 [01-25 15:36:28 ty D][tcp_transporter.c:177] tcp transporter close socket fd:92 [01-25 15:36:28 ty D][tls_transporter.c:101] tls transporter close tls handler:0xd2a640 [01-25 15:36:28 ty D][tuya_tls.c:1180] TUYA_TLS Disconnect ENTER [01-25 15:36:28 ty D][tuya_tls.c:1205] TUYA_TLS Disconnect Success [01-25 15:36:28 ty D][tuya_tls.c:907] tuya_tls_connect_destroy. [01-25 15:36:28 ty D][cloud_operation.c:1688] HTTPS PUT https://ty-cn-storage7.oss-cn-shanghai.aliyuncs.com/2df829-69933427-rs016d2565b7e5db4a24/v/1706167999_0175.media done,size 352678 cost 3210 ms [01-25 15:36:28 ty D][tuya_ipc_cloud_storage.c:970] new media file name 1706167999_0185.media [01-25 15:36:28 ty E][tuya_ipc_p2p.c:4626] no audio or video data count = [3000]
