目前视频可以播放，但是音频不能是因为什么呀？
	MEDIA_FRAME_T pcm_frame;
	static RING_BUFFER_USER_HANDLE_T audioMainHandle = NULL;
	if(NULL == audioMainHandle)
		audioMainHandle = tuya_ipc_ring_buffer_open(0, 0, E_IPC_STREAM_AUDIO_MAIN, E_RBUF_WRITE);
	        _logErr("RING_BUFFER_USER_HANDLE_T get audioMainHandle is NULL\n");
	pcm_frame.type = E_AUDIO_FRAME;
	pcm_frame.size = Len;
	pcm_frame.p_buf = pData;
	pcm_frame.pts = (FrameTimeStamp/1000);
	pcm_frame.timestamp= (FrameTimeStamp/1000);
	TUYA_APP_Put_Frame(audioMainHandle, &pcm_frame);
OPERATE_RET TUYA_APP_Put_Frame(RING_BUFFER_USER_HANDLE_T handle, IN CONST MEDIA_FRAME_T *p_frame)
    PR_TRACE("Put Frame. type:%d size:%u pts:%llu ts:%llu",
             p_frame->type, p_frame->size, p_frame->pts, p_frame->timestamp);
    OPERATE_RET ret = tuya_ipc_ring_buffer_append_data(handle,p_frame->p_buf, p_frame->size,p_frame->type,p_frame->pts);
    if(ret != OPRT_OK)
        PR_ERR("Put Frame Fail.%d  type:%d size:%u pts:%llu ts:%llu",ret,
我们将传入的音频码流保存到sd卡中可以在电脑上直接播放有声音
这是ffmpeg对保存的音频文件的分析
zp@ubuntu:~/nfs$ ffmpeg -i appshiping_0.aac 
ffmpeg version 3.4.11-0ubuntu0.1 Copyright (c) 2000-2022 the FFmpeg developers
  built with gcc 7 (Ubuntu 7.5.0-3ubuntu1~18.04)
  configuration: --prefix=/usr --extra-version=0ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libavresample   3.  7.  0 /  3.  7.  0
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
[aac @ 0x5574024fc8c0] Estimating duration from bitrate, this may be inaccurate
Input #0, aac, from 'appshiping_0.aac':
  Duration: 00:02:35.65, bitrate: 16 kb/s
    Stream #0:0: Audio: aac (LC), 16000 Hz, mono, fltp, 16 kb/s
At least one output file must be specified
这是设置音频流（aac的3种格式都试验了没有声音）
    /* Audio stream configuration.
    Note: The internal P2P preview, cloud storage, and local storage of the SDK are all use E_IPC_STREAM_AUDIO_MAIN data. */
    /*-----音频流 :使能位、编码格式、采样率、数据位数、通道数、帧率-----*/
    ipc_sdk_run_var.media_info.media_info.stream_enable[E_IPC_STREAM_AUDIO_MAIN] = TRUE;         /* Whether to enable local sound collection */
    ipc_sdk_run_var.media_info.media_info.audio_codec[E_IPC_STREAM_AUDIO_MAIN] = TUYA_CODEC_AUDIO_AAC_ADTS;/* Encoding format TUYA_CODEC_AUDIO_AAC_ADTS*/
    ipc_sdk_run_var.media_info.media_info.audio_sample [E_IPC_STREAM_AUDIO_MAIN]= TUYA_AUDIO_SAMPLE_16K;/* Sampling Rate */
    ipc_sdk_run_var.media_info.media_info.audio_databits [E_IPC_STREAM_AUDIO_MAIN]= TUYA_AUDIO_DATABITS_16;/* Bit width */
    ipc_sdk_run_var.media_info.media_info.audio_channel[E_IPC_STREAM_AUDIO_MAIN]= TUYA_AUDIO_CHANNEL_MONO;/* channel */
    ipc_sdk_run_var.media_info.media_info.audio_fps[E_IPC_STREAM_AUDIO_MAIN] = 15;/* Fragments per second */
