    Phyplus Microelectronics Limited confidential and proprietary.
    All rights reserved.
    IMPORTANT: All rights of this software belong to Phyplus Microelectronics
    Limited ("Phyplus"). Your use of this Software is limited to those
    specific rights granted under  the terms of the business contract, the
    confidential agreement, the non-disclosure agreement and any other forms
    of agreements as a customer or a partner of Phyplus. You may not use this
    Software unless you agree to abide by the terms of these agreements.
    You acknowledge that the Software may not be modified, copied,
    distributed or disclosed unless embedded on a Phyplus Bluetooth Low Energy
    (BLE) integrated circuit, either as a product or is integrated into your
    products.  Other than for the aforementioned purposes, you may not use,
    reproduce, copy, prepare derivative works of, modify, distribute, perform,
    display or sell this Software and/or its documentation for any purposes.
    YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
    PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
    INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
    NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
    PHYPLUS OR ITS SUBSIDIARIES BE LIABLE OR OBLIGATED UNDER CONTRACT,
    NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
    LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
    INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
    OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
    OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
    (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
    @file     spi.h
    @brief    Contains all functions support for spi driver
    @version  0.0
    @date     18. Oct. 2017
    @author   qing.han
#ifndef _SPI_H_
#define _SPI_H_
#include "types.h"
#include "gpio.h"
#include "clock.h"
#include "bus_dev.h"
#define  SPI_MASTER_MODE      1    //define master mode,1:master mode,0:salve mode
#define  SPI_USE_TIMEOUT 1
#define  SPI_OP_TIMEOUT  1000        //100ms for an Byte operation
#if(SPI_USE_TIMEOUT == 1)
    #define SPI_INIT_TOUT(to)               int to = hal_systick()
    #define SPI_CHECK_TOUT(to, timeout,loginfo)   {if(hal_ms_intv(to) > timeout){LOG(loginfo);return PPlus_ERR_TIMEOUT;}}
#define  ENABLE_SPI           Ssix->SSIEN = 1
#define  DISABLE_SPI          Ssix->SSIEN = 0
#define  NUMBER_DATA_RX_FIFO  Ssix->RXFLR
#define  NUMBER_DATA_TX_FIFO  Ssix->TXFLR
#define  SPI_BUSY             0x1
#define  TX_FIFO_NOT_FULL     0x2
#define  TX_FIFO_EMPTY        0x4
#define  RX_FIFO_NOT_EMPTY    0x8
typedef enum
    SPI_MODE0=0,      //SCPOL=0,SCPH=0
    SPI_MODE1,        //SCPOL=0,SCPH=1
    SPI_MODE2,        //SCPOL=1,SCPH=0
    SPI_MODE3,        //SCPOL=1,SCPH=1
} SPI_SCMOD_e;
typedef enum
    SPI_4BIT = 0x03,
    SPI_5BIT = 0x04,
    SPI_6BIT = 0x05,
    SPI_7BIT = 0x06,
    SPI_8BIT = 0x07,SPI_1BYTE = 0x07, // 1byte
    SPI_9BIT = 0x08,
    SPI_10BIT = 0x09,
    SPI_11BIT = 0x0a,
    SPI_12BIT = 0x0b,
    SPI_13BIT = 0x0c,
    SPI_14BIT = 0x0d,
    SPI_15BIT = 0x0e,
    SPI_16BIT = 0x0f,SPI_2BYTE = 0x0f, // 2byte
} SPI_DFS_e;
typedef enum
    SPI_TRXD=0,        //Transmit & Receive
    SPI_TXD,         //Transmit Only
    SPI_RXD,         //Receive Only
    SPI_EEPROM,      //EEPROM Read
} SPI_TMOD_e;
typedef enum
    SPI0=0,          //use spi 0
    SPI1,          //use spi 1
} SPI_INDEX_e;
typedef enum
    SPI_TX_COMPLETED = 1,
    SPI_RX_COMPLETED,
    SPI_TX_REQ_S,   //slave tx
    SPI_RX_DATA_S,  //slave rx
} SPI_EVT_e;
typedef struct _spi_evt_t
    uint8_t     id;
    SPI_EVT_e   evt;
    uint8_t*    data;
    uint8_t     len;
} spi_evt_t;
typedef void (*spi_hdl_t)(spi_evt_t* pevt);
typedef struct _spi_Cfg_t
    GPIO_Pin_e      sclk_pin;
    GPIO_Pin_e      ssn_pin;
    GPIO_Pin_e      MOSI;
    GPIO_Pin_e      MISO;
    uint32_t        baudrate;
    SPI_TMOD_e      spi_tmod;
    SPI_SCMOD_e     spi_scmod;
    SPI_DFS_e       spi_dfsmod;
    #if DMAC_USE
    bool            dma_tx_enable;
    bool            dma_rx_enable;
    bool            int_mode;
    bool            force_cs;
    spi_hdl_t       evt_handler;
} spi_Cfg_t;
typedef enum
    TRANSMIT_FIFO_EMPTY = 0x01,
    TRANSMIT_FIFO_OVERFLOW = 0x02,
    RECEIVE_FIFO_UNDERFLOW = 0x04,
    RECEIVE_FIFO_OVERFLOW = 0x08,
    RECEIVE_FIFO_FULL = 0x10,
} SPI_INT_STATUS_e;
typedef struct _hal_spi_t
    SPI_INDEX_e spi_index;
} hal_spi_t;
typedef struct
    bool        busy;
    uint16_t    xmit_len;
    uint16_t    buf_len;
    uint8_t*   tx_buf;
    uint8_t*   rx_buf;
    uint16_t    tx_offset;
    uint16_t    rx_offset;
} spi_xmit_t;
void __attribute__((weak)) hal_SPI0_IRQHandler(void);
void __attribute__((weak)) hal_SPI1_IRQHandler(void);
void hal_spi_tmod_set(hal_spi_t* spi_ptr,SPI_TMOD_e mod);
void hal_spi_dfs_set(hal_spi_t* spi_ptr,SPI_DFS_e mod);
int hal_spis_clear_rx(hal_spi_t* spi_ptr);
uint32_t hal_spis_rx_len(hal_spi_t* spi_ptr);
int hal_spis_read_rxn(hal_spi_t* spi_ptr, uint8_t* pbuf, uint16_t len);
int hal_spi_bus_init(hal_spi_t* spi_ptr,spi_Cfg_t cfg);
int hal_spis_bus_init(hal_spi_t* spi_ptr,spi_Cfg_t cfg);
int hal_spi_bus_deinit(hal_spi_t* spi_ptr);
int hal_spi_init(SPI_INDEX_e channel);
int hal_spi_transmit
    hal_spi_t*  spi_ptr,
    SPI_TMOD_e  mod,
    uint8_t*    tx_buf,
    uint8_t*    rx_buf,
    uint16_t    tx_len,
    uint16_t    rx_len
int hal_spi_set_tx_buffer(hal_spi_t* spi_ptr,uint8_t* tx_buf,uint16_t len);
int hal_spi_set_int_mode(hal_spi_t* spi_ptr,bool en);
int hal_spi_set_force_cs(hal_spi_t* spi_ptr,bool en);
bool hal_spi_get_transmit_bus_state(hal_spi_t* spi_ptr);
int hal_spi_TxComplete(hal_spi_t* spi_ptr);
int hal_spi_send_byte(hal_spi_t* spi_ptr,uint8_t data);
#if DMAC_USE
    int hal_spi_dma_set(hal_spi_t* spi_ptr,bool ten,bool ren);
