U-Boot 2014.04 (Oct 09 2022 - 19:12:01)
CPU: XM530V200WX1
DRAM:  64 MiB
MMC:   arasan: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   PHY id1 0 id2 ffff dwmac.10010000
Hit any key to stop autoboot:  0 
nvram_flash_read_zbuf: offs: 0x10000, len: 65536
ASUS NVRAM, v0.08. Available space: 65536. Integrity: OK
key value:1
SF: 1769472 bytes @ 0x40000 Read: OK
## Booting kernel from Legacy Image at 80007fc0 ...
   Image Name:   Linux-4.9.37
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1624984 Bytes = 1.5 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 4.9.37 (root@dell-PowerEdge-R740) (gcc version 4.9.2 (Buildroot 2014.08) ) #1 SMP Tue Sep 27 13:00:53 UTC 2022
CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: xm530v200
Memory policy: Data cache writealloc
percpu: Embedded 12 pages/cpu @c2398000 s20160 r8192 d20800 u49152
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 9144
Kernel command line: console=ttyAMA0,115200 rootfstype=squashfs ro init=/linuxrc dm-mod.create="dm-crypt,,0,rw,0 1920 crypt aes-cbc-essiv:sha256 dcc734ac6ed58f7bbdc8c9253922defc17aaeffb1ff39d7685d3debe166151d6 0 /dev/mtdblock2 0" root=/dev/dm-0 mem=36M mtdparts=xm_sfc:256k(boot),1728k(kernel),960k(rootfs),704k(drv),2048k(user),2048k(backup),320k(data),128k(factory)
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 29980K/36864K available (4096K kernel code, 134K rwdata, 496K rodata, 1024K init, 129K bss, 6884K reserved, 0K cma-reserved)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xc2800000 - 0xff800000   ( 976 MB)
    lowmem  : 0xc0000000 - 0xc2400000   (  36 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc0500000   (5088 kB)
      .init : 0xc0600000 - 0xc0700000   (1024 kB)
      .data : 0xc0700000 - 0xc0721a40   ( 135 kB)
       .bss : 0xc0721a40 - 0xc07420e8   ( 130 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
        Build-time adjustment of leaf fanout to 32.
NR_IRQS:128
clocksource: timer0: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
Calibrating delay loop... 398.13 BogoMIPS (lpj=1990656)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x80100000 - 0x80100058
L2C: DT/platform modifies aux control register: 0x32020000 -> 0x32420000
L2C: DT/platform tries to modify or specify cache size
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating disabled, standby mode disabled
L2C-310 cache controller enabled, 8 ways, 128 kB
L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x36420000
Brought up 2 CPUs
SMP: Total of 2 processors activated (796.26 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Serial: AMBA PL011 UART driver
uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32, base_baud = 0) is a PL011 rev1
console [ttyAMA0] enabled
uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33, base_baud = 0) is a PL011 rev1
uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34, base_baud = 0) is a PL011 rev1
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
clocksource: Switched to clocksource timer0
NET: Registered protocol family 2
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
workingset: timestamp_bits=30 max_order=13 bucket_order=0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
brd: module loaded
XMSFCV2: Unsupported flash IDs: 0x204017 using default8 cmdlinepart partitions found on MTD device xm_sfc
Creating 8 MTD partitions on "xm_sfc":
0x000000000000-0x000000040000 : "boot"
0x000000040000-0x0000001f0000 : "kernel"
0x0000001f0000-0x0000002e0000 : "rootfs"
0x0000002e0000-0x000000390000 : "drv"
0x000000390000-0x000000590000 : "user"
0x000000590000-0x000000790000 : "backup"
0x000000790000-0x0000007e0000 : "data"
0x0000007e0000-0x000000800000 : "factory"
PPP generic driver version 2.4.2
NET: Registered protocol family 24
XMMMAC driver:
        platform registration...        done!
        eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
        IO base addr: 0xfe010000)
libphy: XMMMAC MII Bus: probed
eth0: PHY ID 0000ffff at 0 IRQ -1 (0:00)
eth0: PHY ID 0000ffff at 1 IRQ 0 (0:01) active
eth0: PHY ID 0000ffff at 2 IRQ -1 (0:02)
eth0: PHY ID 0000ffff at 3 IRQ -1 (0:03)
eth0: PHY ID 0000ffff at 4 IRQ -1 (0:04)
eth0: PHY ID 0000ffff at 5 IRQ -1 (0:05)
eth0: PHY ID 0000ffff at 6 IRQ -1 (0:06)
eth0: PHY ID 0000ffff at 7 IRQ -1 (0:07)
eth0: PHY ID 0000ffff at 8 IRQ -1 (0:08)
eth0: PHY ID 0000ffff at 9 IRQ -1 (0:09)
eth0: PHY ID 0000ffff at 10 IRQ -1 (0:0a)
eth0: PHY ID 0000ffff at 11 IRQ -1 (0:0b)
eth0: PHY ID 0000ffff at 12 IRQ -1 (0:0c)
eth0: PHY ID 0000ffff at 13 IRQ -1 (0:0d)
eth0: PHY ID 0000ffff at 14 IRQ -1 (0:0e)
eth0: PHY ID 0000ffff at 15 IRQ -1 (0:0f)
eth0: PHY ID 0000ffff at 16 IRQ -1 (0:10)
eth0: PHY ID 0000ffff at 17 IRQ -1 (0:11)
eth0: PHY ID 0000ffff at 18 IRQ -1 (0:12)
eth0: PHY ID 0000ffff at 19 IRQ -1 (0:13)
eth0: PHY ID 0000ffff at 20 IRQ -1 (0:14)
eth0: PHY ID 0000ffff at 21 IRQ -1 (0:15)
eth0: PHY ID 0000ffff at 22 IRQ -1 (0:16)
eth0: PHY ID 0000ffff at 23 IRQ -1 (0:17)
eth0: PHY ID 0000ffff at 24 IRQ -1 (0:18)
eth0: PHY ID 0000ffff at 25 IRQ -1 (0:19)
eth0: PHY ID 0000ffff at 26 IRQ -1 (0:1a)
eth0: PHY ID 0000ffff at 27 IRQ -1 (0:1b)
eth0: PHY ID 0000ffff at 28 IRQ -1 (0:1c)
eth0: PHY ID 0000ffff at 29 IRQ -1 (0:1d)
eth0: PHY ID 0000ffff at 30 IRQ -1 (0:1e)
eth0: PHY ID 0000ffff at 31 IRQ -1 (0:1f)
device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
Key type dns_resolver registered
Registering SWP/SWPB emulation handler
registered taskstats version 1
device-mapper: init: waiting for all devices to be available before creating mapped devices
device-mapper: ioctl: dm-0 (dm-crypt) is ready
VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
Freeing unused kernel memory: 1024K (c0600000 - c0700000)
mdev add ...
/etc/init.d/rcS: line 0: can't open '/dev/null': No such file or directory
random: cat: uninitialized urandom read (4 bytes read)
random: cut: uninitialized urandom read (4 bytes read)
random: grep: uninitialized urandom read (4 bytes read)
nvram_kernel_driver_unstripped: loading out-of-tree module taints kernel.
arasan_set_clock:
        new freq 400000mmc0: driver initialized... IRQ: 74, Base addr 0xc4a00000
INFO:driver built in: 13:02:06 Sep 27 2022
INFO:ty_motor_init module is installed
arasan_set_clock:
        new freq 300000
arasan_set_clock:
        new freq 200000
dwc2 dwc2.0: dwc2_check_params: Invalid parameter host_nperio_tx_fifo_size=512
dwc2 dwc2.0: DWC OTG Controller
dwc2 dwc2.0: new USB bus registered, assigned bus number 1
dwc2 dwc2.0: irq 76, io mem 0x50300000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DWC OTG Controller
usb usb1: Manufacturer: Linux 4.9.37 dwc2_hsotg
usb usb1: SerialNumber: dwc2.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
arasan_set_clock:
        new freq 195312usbwifi_init.
PDN pin is low, ouput high and delay 2 sec. gpio:163 : 0x0
ouput high and delay 2000ms
usb 1-1: new high-speed USB device number 2 using dwc2
usb 1-1: New USB device found, idVendor=007a, idProduct=8888
usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
usb 1-1: Product: AltoBeam_WIFI
usb 1-1: Manufacturer: AltoBeam inc.
[atbm_log]:atbm_usb_module_init 0
[atbm_log]:SVN_VER=20811,DPLL_CLOCK=2,BUILD_TIME=[===USB-ARES_B==
[atbm_log]:Probe called -1 v1
[atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[atbm_log]:CONFIG_TX_NO_CONFIRM
[atbm_log]:Allocated hw_priv @ c17caf40
[atbm_log]:atbmwifi INIT_WORK enable
[atbm_log]:atbm_before_load_firmware++
[atbm_log]:atbm_HwGetChipType, chipver=0x49, g_wifi_chip_type[10]
[atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[atbm_log]:===================~_~====================
[atbm_log]:atbm_start_load_firmware++
[atbm_log]:used firmware.h=
[atbm_log]:START DOWNLOAD ICCM=========
[atbm_log]:atbm_load_firmware_generic: addr 10000: len 22000
random: fast init done
[atbm_log]:START DOWNLOAD DCCM=========
[atbm_log]:atbm_load_firmware_generic: addr 800000: len 8000
[atbm_log]:atbm_after_load_firmware++
[atbm_log]:0x1610102c=0x40a0e
[atbm_log]:0x1610102c=0x10a0f
[atbm_log]:0x16101000=0x8000e08
[atbm_log]:set_block_size=256
[atbm_log]:mdelay wait wsm_startup_done  !!
[atbm_log]:firmwareCap f58f
[atbm_log]:firmwareCap2 51ae
[atbm_log]:wsm_caps.firmwareCap 51aef58f[atbm_log]:apollo wifi WSM init done.
   Input buffers: 32 x 2048 bytes
   Hardware: 7.1280
   WSM firmware [=MODEM=RF=Ares_AX  2GHZ Apr 19 2022 18:53:51NOTXConfrim], ver: 14195, build: 2807, api: 1060, cap: 0x51AEF58F Config[30008]  expection 900a5c0, ep0 cmd addr 901be2c NumOfStations[8] NumOfInterfaces[3]
[atbm_log]:EFUSE(8)                             [0]
[atbm_log]:EFUSE(I)                                     [1]
[atbm_log]:EFUSE(B)                     [0]
[atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [1]
[atbm_log]:CAPABILITIES_NVR_IPC              [1]
[atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[atbm_log]:CAPABILITIES_SDIO_PATCH           [0]
[atbm_log]:CAPABILITIES_NO_BACKOFF           [0]
[atbm_log]:CAPABILITIES_CFO                  [0]
[atbm_log]:CAPABILITIES_AGC                  [1]
[atbm_log]:CAPABILITIES_TXCAL                [1]
[atbm_log]:CAPABILITIES_MONITOR              [0]
[atbm_log]:CAPABILITIES_CUSTOM               [1]
[atbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[atbm_log]:CAPABILITIES_ETF                  [1]
[atbm_log]:CAPABILITIES_LMAC_RATECTL         [1]
[atbm_log]:CAPABILITIES_LMAC_TPC             [1]
[atbm_log]:CAPABILITIES_LMAC_TEMPC           [1]
[atbm_log]:CAPABILITIES_CTS_BUG              [0]
[atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [1]
[atbm_log]:CAPABILITIES_USE_IPC              [1]
[atbm_log]:CAPABILITIES_OUTER_PA             [0]
[atbm_log]:CAPABILITIES_POWER_CONSUMPTION    [1]
[atbm_log]:CAPABILITIES_RSSI_DECIDE_TXPOWER  [0]
[atbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[atbm_log]:CAPABILITIES_SHARE_CRYSTAL       [0]
[atbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[atbm_log]:CAPABILITIES_SINGLE_CHANNEL_MULRX [0]
[atbm_log]:CAPABILITIES_CFO_DCXO_CORRECTION  [1]
[atbm_log]:EX_CAPABILITIES_TWO_CHIP_ONE_SOC     [0][atbm_log]:EX_CAPABILITIES_MANUAL_SET_AC     [0]
[atbm_log]:EX_CAPABILITIES_LMAC_BW_CONTROL      [1][atbm_log]:EX_CAPABILITIES_SUPPORT_TWO_ANTENNA       [0]
[atbm_log]:EX_CAPABILITIES_ENABLE_STA_REMAIN_ON_CHANNEL [1][atbm_log]:EX_CAPABILITIES_ENABLE_PS            [0]
[atbm_log]:EX_CAPABILITIES_TX_REQUEST_FIFO_LINK            [0][atbm_log]:EX_CAPABILITIES_CHIP_TYPE              6032IS
[atbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [1]
[atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[atbm_log]:wsm_generic_confirm:status(2)
[atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[atbm_log]:apollo wifi : can't open /data/.mac.info
[atbm_log]:efuse data is [0x1,0x3b,0x1e,0x1e,0x0,0xf,0x0,0x0,0xa4:0xef:0x15:0x50:0x10:0xbd]
[atbm_log]:xm cmd: set_txpwr_and_dcxo,-1,-1,-1,-1,20,20,20,20,20,20 
[atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[atbm_log]:get chip id [94][1][1] 
[atbm_log]:current chiptype 6032is 
[atbm_log]:enable sg
[atbm_log]:is registered as 'ALTOBEAM'
[atbm_log]:[atbm_wtd]:set wtd_probe = 1
usbcore: registered new interface driver atbm_wlan
vm.overcommit_memory = 0
vm.overcommit_ratio = 50
vm.min_free_kbytes = 1024
vm.dirty_background_ratio = 2
vm.dirty_expire_centisecs = 500
vm.dirty_ratio = 2
vm.dirty_writeback_centisecs = 100
vm.admin_reserve_kbytes = 0
vm.user_reserve_kbytes = 0
Tuya login: status: active CC:
pll start
[reg] = 0x20000000,[val]= 0x00000001
pll 54
[reg] = 0x20000054,[val]= 0x00000703
Tuya login: pll 74
[reg] = 0x20000074,[val]= 0xc103c103
pll 78
[reg] = 0x20000078,[val]= 0xc103c103
pll 7C
[reg] = 0x2000007c,[val]= 0x0000c103
[reg] = 0x20000000,[val]= 0x00000000
pll end
490
[reg] = 0x20050490,[val]= 0x00000001
540
Tuya login: [reg] = 0x20050540,[val]= 0x00000001
5F0
[reg] = 0x200505f0,[val]= 0x00000001
end
Tuya login: 
Tuya login: 
Tuya login: Start tycam ...
[main, 73]
root
Password: [1970-1-1 0:4:21.003  ty_sys.c ty_sys_start(1192) Debug] start 
[1970-1-1 0:4:21.215  ty_sys.c __sys_msg_start(1034) Debug] __begin
[1970-1-1 0:4:21.216  ty_sys.c __sys_msg_proc(1004) Debug] msg proc begin
[1970-1-1 0:4:21.216  ty_sys_cfg.c ty_sys_cfg_init(207) Debug] fopen file_path[/tuya/data/tuya_cfg.bin]
[1970-1-1 0:4:21.217  ty_sys.c __sys_msg_proc(1012) Debug] main msg loop [0] run_step [0]
[1970-1-1 0:4:21.218  ty_sys_cfg.c ty_sys_cfg_init(266) Debug] crc32[3085040635] version[1] num[3] len[120]
[1970-1-1 0:4:21.218  ty_sys_cfg.c ty_sys_cfg_init(326) Debug] cfg info ver[1] num[3] len[120]
[1970-1-1 0:4:21.219  ty_wifi.c ty_hwl_wifi_init(935) Debug] bigin___
[1970-1-1 0:4:21.219  ty_wifi.c ty_hwl_wifi_init(949) Debug] end___
tkl_venc_set_osd is dls:0, enable:1
[chip_osd_enable:228]Error Code: [0xA0128007]
[1970-1-1 0:4:21.279  ty_sys.c __set_default_cfg_before(463) Info] led_switch:1
ty_sys_led_mode_set[430] status[0] switch:1
ty_sys_led_mode_set[443] status[0] switch:1
ty_sys_led_mode_set[449] status[0] switch:1
[1970-1-1 0:4:21.279  ty_sys_av.c ty_sys_av_start(317) Debug] __begin
[1970-1-1 0:4:21.280  ty_sys_av.c __video_task(248) Debug] __begin type = 0
[1970-1-1 0:4:21.280  ty_sys_av.c __video_task(257) Info] wait time sync start,type:0...
[1970-1-1 0:4:21.281  ty_sys_av.c __audio_task(167) Debug] __begin type = 0
[1970-1-1 0:4:21.281  ty_sys_av.c __audio_task(174) Info] ty_time_wait_sync wait start,type:0...
[1970-1-1 0:4:21.282  ty_sys_av.c __video_task(248) Debug] __begin type = 1
[1970-1-1 0:4:21.396  ty_sys_av.c __video_task(257) Info] wait time sync start,type:1...
DEBUG: [libispapp]:Sep  8 2022 09:59:56
DEBUG: Vstd_init        [ PAL ]
DEBUG: RsltSns0 [ 1 ]
DEBUG: Dsp:             [0x0][ CHIPV200 ]
  ________  ____  _____     __   _               
 /_  __/ / / /\ \/ / _ |   / /  (_)__  __ ____ __
  / / / /_/ /  \  / __ |  / /__/ / _ \/ // /\ \ /
 /_/  \____/   /_/_/ |_| /____/_/_//_/\_,_//_\_\ 
 For further information check:
 https://developer.tuya.com
Jan  1 00:04:22 login[560]: root login on 'console'
~ # ERR: Sensor:unknow! Chn:0
ERR: Not Support This Sensor!
[src/ispapp.c:1588]config_by_sns failed with 0xffffffff!
ERR: isp_app line:1892 get_product_info failed!
DEBUG: test_pattern_set 47 enable:1
DEBUG: isp_sample over!
[tkl_vi_init:93]Error Code: [0xFFFFFFFF]
wait for time sync
[1970-1-1 0:4:22.436  ty_dsp_adapter.c ty_dsp_init(80) Error] ty_dsp_init failed,-1
[1970-1-1 0:4:22.437  ty_sys_av.c ty_sys_av_start(425) Error] ####failed
[1970-1-1 0:4:22.437  ty_sys.c ty_sys_start(1217) Error] ####failed
[main, 84] sys start failed
process not exit or aborted, try to restart...
~ # udhcpc: started, v1.31.1
Setting IP address 0.0.0.0 on eth0
grep: /etc/resolv.conf: No such file or directory
udhcpc: sending discover
~ # udhcpc: sending discover
udhcpc: no lease, forking to background
eth_sta = 1
