[BEGIN] 2024/6/6 11:03:07
[    0.971453] goke_rtc 120e0000.rtc: rtc core: registered 120e0000.rtc as rtc0
[    0.978550] goke_rtc 120e0000.rtc: RTC driver for goke enabled
[    0.984521] i2c /dev entries driver
[    0.988529] goke-i2c 12060000.i2c: goke-i2c0@100000hz registered
[    0.994953] goke-i2c 12061000.i2c: goke-i2c1@100000hz registered
[    1.001386] goke-i2c 12062000.i2c: goke-i2c2@100000hz registered
[    1.007963] sdhci: Secure Digital Host Controller Interface driver
[    1.014184] sdhci: Copyright(c) Pierre Ossman
[    1.018536] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.081236] mmc0: SDHCI controller on 10010000.sdhci [10010000.sdhci] using ADMA in legacy mode
[    1.161228] mmc1: SDHCI controller on 10020000.sdhci [10020000.sdhci] using ADMA in legacy mode
[    1.170362] Initializing XFRM netlink socket
[    1.174698] NET: Registered protocol family 17
[    1.179185] NET: Registered protocol family 15
[    1.199967] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[    1.207378] Freeing unused kernel memory: 148K (c046f000 - c0494000)
[    1.213750] This architecture does not have kernel memory protection.
[    1.388870] usb 1-1: new high-speed USB device number 3 using xhci-hcd
[RCS]: /etc/init.d/S00devs
mount ro fs
mount rw file system
[RCS]: /etc/init.d/S01udev
[RCS]: /etc/init.d/S02moutfs
[    2.286886] random: S02moutfs: uninitialized urandom read (4 bytes read)
mount param fs dir.
param fs mounted.
mount app fs.
app fs mounted.
[RCS]: /etc/init.d/S80network
ifconfig: SIOCSIFHWADDR: No such device
ifconfig: SIOCSIFADDR: No such device
route: SIOCADDRT: Network is unreachable
[RCS]: /etc/init.d/S90decompress
Mount squashfs or nfs files done !
[RCS]: /etc/init.d/S91update
ls: /dev/mmcblk*: No such file or directory
rmdir: '/tmp/mmc': No such file or directory
start get main_pixel
main_pixel=4
[    2.603806] hi_gpio: loading out-of-tree module taints kernel.
[    2.610279] ===kernel=== gpio driver init finished!
ipc login: *** Board tools : ver0.0.1_20121120 *** 
[debug]: {/home/devin/vision_release/work/sdk_org/sdk/source/rootfs/regtools/source/utils/cmdshell.c:151}cmdstr:gkmm
0x112c0028: 0x00001000 --> 0x00001001 
[END]
0x112C002C: 0x00001000 --> 0x00001000 
[END]
target gpio:group:5,bit:5
set 46:1
write 46:0
0x100c000c: 0x00000601 --> 0x00001002 
[END]
0x100c0010: 0x00001000 --> 0x00001002 
[END]
mkdir: can't create directory '/usr/share/udhcpc': File exists
cp: can't stat '/usr/share/udhcpc/default.script': Not a directory
=================== sensor up ===================
write 46:1
=================== check sensor type ===================
0x112C0030: 0x00001C00 --> 0x00001C01 
[END]
0x112C0034: 0x00001C00 --> 0x00001C01 
[END]
Got Sensor Type : GC2083
mem=38
os_mem_size=38
REBOOT = 0
=================== check sensor type done  ====================
devid=V6202IR-GC2083
cp: can't stat '/mnt/flash/Server/databak/VideoInfo_4M': No such file or directory
diff: can't stat '/mnt/flash/Server/databak/CameraInfo': No such file or directory
cp: can't stat '/mnt/flash/Server/databak/CameraInfo': No such file or directory
[    3.052316] exFAT: Version 1.2.9
ls: mmcblk*: No such file or directory
silent_state=noneed_silent_reboot_4
silent_stste=noneed_silent_rebo
target gpio:group:1,bit:6
set 15:1
write 15:0
target gpio:group:2,bit:0
set 17:1
write 17:0
sh: mtd1: unknown operand
ls: mtd1: No such file or directory
/dev/mtd0
boot not found
/dev/mtd1
ls: /mnt/flash/mmc/hk_bootargs: No such file or directory
/mnt/flash/mmc/hk_bootargs not found
/dev/mtd2
ls: /mnt/flash/mmc/hk_kernel: No such file or directory
/mnt/flash/mmc/hk_kernel not found
/dev/mtd3
ls: /mnt/flash/mmc/hk_rootfs: No such file or directory
/mnt/flash/mmc/hk_rootfs not found
/dev/mtd5
ls: /mnt/flash/mmc/hk_data: No such file or directory
/mnt/flash/mmc/hk_data not found
umount: can't unmount /mnt/flash/mmc: Invalid argument
./loadgk7205v200 -i -sensor gc2083 -osmem 38 -yuv0 0
mmz_start: 0x42600000, mmz_size: 26M
[    3.312495] FUNC:parse_sensor_clock line:133  SNS: is [gc2083]!
[    3.318421] FUNC:parse_sensor_bus_type line:90  SNS is [gc2083]  !
[    3.324642] ==== online_flag=0, cmos_yuv_flag=0, sensor=gc2083, chip=gk7202v300, board=demo====
[    3.333342] ==== g_quick_start_flag=0 ====
[    3.337429] sysconfig init success!
[    3.349990] Module media: init ok
[    3.353364] Media Memory Zone Manager
[    3.357203] osal 1.0 init success!
[    3.388412] register dev
[    3.395864] Watchdog Timer: 0.01 initialized. default_margin=60 sec (nodeamon= 0)
[    3.403394] wtdg init ok. ver=Aug 17 2021, 10:54:08.
[    3.436912] gk7205v200_base: module license 'Proprietary' taints kernel.
[    3.443674] Disabling lock debugging due to kernel taint
[    3.489852] load sys.ko OK!
[    3.526773] load region.ko OK!
[    3.584055] load vgs.ko OK!
[    3.686812] load vi.ko OK !
[    3.738647] ISP Mod init!
[    3.841144] load vpss.ko OK!
[    3.851557] load chnl.ko OK!
[    3.863359] load vedu.ko OK!
[    3.902641] load rc.ko OK!
[    3.955838] load venc.ko OK!
[    3.991823] load h264e.ko OK!
[    4.038306] load h265e.ko OK!
[    4.062847] load jpege.ko OK!
[    4.126552] load ive.ko OK!
[    4.172372] Load sensor_spi.ko OK !
insert audio
[    4.328562] load mipi_rx driver successful!
[    4.344250] lsadc init ok. ver=Aug 17 2021, 10:54:08.
0x112C0030: 0x00001C01 --> 0x00001C01 
[END]
0x112C0034: 0x00001C01 --> 0x00001C01 
[END]
=================== check usbdev aic8800 inserted ===================
BOARD_ID=1076GV4
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 003: ID a69c:8d80
Bus 002 Device 001: ID 1d6b:0003
1d6b:0002
a69c:8d80
1d6b:0003
find usb wlan device
[    4.430453] aic_bluetooth_mod_init 
[    4.434022] RELEASE DATE:2023_0509_1122 
[    4.438127] AICWFDBG(LOGINFO)	aicwf_usb_probe vid:0xA69C pid:0x8D80 icl:0x0 isc:0x0 ipr:0x0 
[    4.446682] AICWFDBG(LOGINFO)	aicloadfw_chipmatch USE AIC8800D80
[    4.452797] Aic high speed USB device detected
[    4.459536] chip_id=7
[    4.462018] aic_load_firmware :firmware path = /mnt/flash/Server/resource/wifi/fw/aic8800D80/fw_adid_8800d80_u02.bin  
[    4.473004] file md5:f546881a81b960d89a672578eb45a809
[    4.478145] ### Upload fw_adid_8800d80_u02.bin firmware, @ = 201940  size=1708
[    4.485898] fw download complete
[    4.485898] 
[    4.490612] aic_load_firmware :firmware path = /mnt/flash/Server/resource/wifi/fw/aic8800D80/fw_patch_8800d80_u02.bin  
[    4.501792] file md5:b6c92209dc9a6e08f396aa377e13e7e7
[    4.506931] ### Upload fw_patch_8800d80_u02.bin firmware, @ = 20b43c  size=8280
[    4.516460] fw download complete
[    4.516460] 
[    4.521178] aic_load_firmware :firmware path = /mnt/flash/Server/resource/wifi/fw/aic8800D80/fw_patch_table_8800d80_u02.bin  
[    4.532734] file md5:8bca92b8cf5527ac4deb3ad3ae8304d2
[    4.537873] ### Upload fw_patch_table_8800d80_u02.bin fw_patch_table, size=552
[    4.549961] patch version - Apr 27 2023 15:50:58 - git 3a69da7
[    4.555894] fw_patch_table download complete
[    4.555894] 
[    4.561668] aic_load_firmware :firmware path = /mnt/flash/Server/resource/wifi/fw/aic8800D80/fmacfw_8800d80_u02.bin  
[    4.683460] file md5:1ae0e1c80f99d4db13c25007a59071b7
[    4.688608] ### Upload fmacfw_8800d80_u02.bin firmware, @ = 120000  size=314709
[    4.701115] random: fast init done
[    4.738374] fw download complete
[    4.738374] 
[    4.743452] usbcore: registered new interface driver aic_load_fw
[    4.749608] app_cmp
[    4.753993] usb 1-1: USB disconnect, device number 3
[    4.759205] aicwf_usb_disconnect enter 
[    4.763188] aicwf_bus_deinit[    6.016210] usb bustx thread will to stop
[    6.020222] usb bustx thread stop
[    6.028215] exit aicwf_bus_deinit
[    6.031698] usb busrx thread will to stop
[    6.035708] usb busrx thread stop
[    6.116494] usbcore: registered new interface driver aic8800_fdrv
[    6.381239] usb 1-1: new high-speed USB device number 4 using xhci-hcd
[    6.555239] AICWFDBG(LOGINFO)	aicwf_usb_probe vid:0xA69C pid:0x8D81 icl:0x0 isc:0x0 ipr:0x0 
[    6.563859] aic_load_fw: probe of 1-1:1.0 failed with error -1
[    6.572333] AICWFDBG(LOGINFO)	aicwf_usb_probe vid:0xA69C pid:0x8D81 icl:0x0 isc:0x0 ipr:0x0 
[    6.580882] aic_load_fw: probe of 1-1:1.1 failed with error -1
[    6.589029] AICWFDBG(LOGINFO)	aicwf_usb_probe vid:0xA69C pid:0x8D81 icl:0x0 isc:0x0 ipr:0x0 
[    6.597650] aic_load_fw: probe of 1-1:1.2 failed with error -1
[    6.722522] mac = 0x0 
[    6.724888] mac = 0x2a 
[    6.727326] mac = 0x2a 
[    6.729763] mac = 0x0 
[    6.732179] mac = 0x7 
[    6.734532] mac = 0x1 
[    6.737356] AICWFDBG(LOGINFO)	aicwf_prealloc_txq_alloc size is diff will to be kzalloc 
[    6.745530] AICWFDBG(LOGINFO)	aicwf_prealloc_txq_alloc txq kzalloc successful 
ifconfig: SIOCGIFFLAGS: No such device
load aic_load_fw.ko aic8800_fdrv.ko over!!!
Bus 001 Device 004: ID a69c:8d81
update fail,please check
check mount_dir success!
update new fail,please check
0x120100F0: 0x00000011 --> 0x00000019 
[END]
[19700101-08:00:07.170 D 1132] hankpublic.c 402: dual_gpioCfgInfo 0
[19700101-08:00:07.171 D 1132] hankpublic.c 410: dual_gpioWLevelInfo 0
[19700101-08:00:07.171 D 1132] hankpublic.c 295: use default device type is 2.0 lowlight camera
_HisiTypeCheck multiple = 0
_HisiTypeCheck g_Product_Type: 0 g_Product_Index: 0 Hisi_Type: 0
shared memory size 16
shared memory id:0
__ICP204____Success____
Open hi_i2c error!
target gpio:group:5,bit:1
set 42:1
set 17:1
status_indicator_led.sh REDLED_PIN=42
status_indicator_led.sh BLUELED_PIN=17
status_indicator_led.sh BLUE_LED_ENABLE=0
status_indicator_led.sh REDLED_ENABLE=1
check /mnt/flash/data/NetInfo info success .
delete old gateway error ! 
dhcp enable = 1
dhcp enable
Detect_EthLink err:No such deviceDetect_EthLink err:No such deviceDetect_EthLink err:No such device[dhcp]  FunCheckNetstat_link ret ====== -2!
[hank_dev_prase_domejson] ver_num=1
[hank_dev_prase_domejson] day_night_ctrl_type=1
[hank_dev_prase_domejson] dton=900
[hank_dev_prase_domejson] ntod=400
[hank_dev_prase_domejson] polarity=0
[hank_dev_prase_domejson] type=1
[hank_dev_prase_domejson] first_[    9.367406] AICWFDBG(LOGERROR)	no mac address in efuse!language=0
[hank_dev_prase_domejson] second_language=0
[hank_dev_prase_domejson] en_level=1
[hank_dev_prase_domejson] autotrace=0
[hank_dev_prase_domejson] vdir_trace=0
[hank_dev_prase_domejson] hspeed_trace=80
[hank_dev_prase_domejson] vspeed_trace=60
[hank_dev_prase_domejson] mirror=0
[hank_dev_prase_domejson] double_light_mode=0
[hank_dev_prase_domejson] irlevel=0
[hank_dev_prase_domejson] type=0
[hank_dev_prase_domejson] wlevel=0
[hank_dev_prase_domejson] hdir=0
[hank_dev_prase_domejson] hmaxstep=4100
[hank_de[    9.418860] rwnx_reg_notifier Enter
v_prase_domejson] hspeed=70
[hank_dev_prase_domejson] hlocat=50[    9.430112] ieee80211 phy0: 
[    9.430112] *******************************************************
[    9.430112] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
[hank_dev_prase_domejson] vdir=0
[hank_dev_prase_domejson] vmaxstep=1140
[hank_dev_prase_domejson] vspeed=50
[hank_dev_prase_domejson] vlocat=50
[hank_dev_prase_domejson] main=4
[hank_dev_read_json] /mnt/flash/productinfo/odmJson.cfg error .
[19700101-08:00:09.238 I 1177] hank_parameter.c 259: user_default_param_version:2 default_param_version:2 update_check:0
[19700101-08:00:09.239 I 1177] hank_parameter.c 134: user_update_param_version:3 update_param_version:3 update_check:0
[19700101-08:00:09.239 D 1177] hankpublic.c 402: dual_gpioCfgInfo 0
[19700101-08:00:09.239 D 1177] hankpublic.c 410: dual_gpioWLevelInfo 0
[19700101-08:00:09.240 D 1177] hankpublic.c 295: use default device type is 2.0 lowlight camera
MOTO_TYPE 5
ipc_dom type = 10, af_flag = 0, ir_out_mode 0 gSelfAlgType = 0 dzoom_enable = 0
get sensor GC2083
VinRes 1280x960
limit max res 2560x1440
ipc_dom 10, vivpss_scaling_mode 0
SENSOR_TYPE 30, 1920 1080
0x120100a0: 0x00240400 --> 0x00040400 
[END]
minor 640 360,  mjpeg
ENABLE_PD_MAIN 1, ENABLE_PD_SUB 1
[19700101-08:00:09.534 D 1177] mw_init_api.c 2543: sdk_app : hi3516ev200 = 1, h265[major,minor] = [1,0], ICR_TYPE = 0
0x100C000C: 0x00001002 --> 0x00000000 
[END]
0x100C0010: 0x00001002 --> 0x00000000 
[END]
[19700101-08:00:09.579 D 1177] mw_isp_api.c 3529: AUDIO_CTRL 1, ICR_LED_CTRL -1, ICR_CAMERA_POS 5, ICR_CAMERA_NEG 4
0x120C0018: 0x00001002 --> 0x00001003 
[END]
[19700101-08:00:09.599 I 1177] mw_isp_api.c 1063: pwm ioctl RED_LED   enable:0 pwm_num:2 period:1000 duty:0
[19700101-08:00:09.599 I 1177] mw_isp_api.c 3542: use pwm:2 ctrl RED_LED
/dev/null /dev/console /dev/console
[19700101-08:00:09.699 I 1181] main.c 1758: syscmd_pid:1137
[19700101-08:00:09.700 I 1181] main.c 1616: generate version:3.4.0 suc.
[19700101-08:00:09.701 I 1181] main.c 1675: generate factory_version:V3.4.0-Tuya_240606 suc.
[19700101-08:00:09.703 D 1181] main.c 1788: hisi chip 3516E200
[19700101-08:00:09.820 D 1181] main.c 1869: ^_^ hk_factory_mode=0 ^_^
[hank_dev_prase_domejson] first_language=0
[hank_dev_prase_domejson] hspeed=70
[19700101-08:00:09.871 I 1181] hank_parameter.c 259: user_default_param_version:2 default_param_version:2 update_check:0
[19700101-08:00:09.871 I 1181] hank_parameter.c 134: user_update_param_version:3 update_param_version:3 update_check:0
[19700101-08:00:09.871 D 1181] hankpublic.c 402: dual_gpioCfgInfo 0
[19700101-08:00:09.871 D 1181] hankpublic.c 410: dual_gpioWLevelInfo 0
[19700101-08:00:09.894 D 1181] manage.c 3581: default max pan 4200, tilt 800
[19700101-08:00:09.894 D 1181] hankpublic.c 295: use default device type is 2.0 lowlight camera
[19700101-08:00:09.894 D 1181] manage.c 1519: WIFI ON
[19700101-08:00:09.894 D 1181] manage.c 1522: GK7202V300 without phy
[19700101-08:00:09.904 D 1181] manage.c 819: gSelfAlgType= 0 hisi_ir_flag= 0 gOnlyNetCtrl= 0
[19700101-08:00:09.905 I 1181] manage.c 679: DeviceModel:IPC-G3B2D0D2-TY
[19700101-08:00:09.905 I 1181] manage.c 703: generate device_mode:IPC-G3B2D0D2-TY suc.
[19700101-08:00:09.906 D 1181] main.c 1915: find noneed_silent_reboot success!!!
got time from RTC: 1717642654
set pll 3276913
OTP check OK !!!
[20240606-10:57:34.000 D 1181] device_info.c 221: == IR module will not be called in the device. ==
[20240606-10:57:34.000 D 1181] device_info.c 237: == prepared zoom lens will not be used ==
[20240606-10:57:34.000 D 1181] device_info.c 253: == prepared zoom lens will not be used ==
[20240606-10:57:34.000 D 1181] device_info.c 309: === get device_type:1, device_af:0, device_ir:0, lens_type:4 sensor_type:1 ===
[20240606-10:57:34.001 D 1181] hank_alarm.c 4323: Alarm_In_Num = 1 , Alarm_Out_Num = 1
/bin/sh: himm: not found
output IO -1
input IO -1
[20240606-10:57:34.034 I 1181] manage.c 3696: use hank_parameter[OutPutVolume]=7
[20240606-10:57:34.035 I 1181] manage.c 3705: use hank_parameter[InPutVolume]=5
[20240606-10:57:34.035 I 1181] manage.c 3706: use hank_parameter[InPutType]=0
[20240606-10:57:34.035 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] SampleRate=-1
[20240606-10:57:34.035 D 1181] manage.c 258: talk voice info audioInType:0 audioInput:4 audioOutput:4
[20240606-10:57:34.035 D 1181] manage.c 262: ptz voice info audioInType:1 audioInput:5 audioOutput:7
[20240606-10:57:34.036 D 1181] manage.c 232: moto_set_mute Create moto_mute_proc thrd=0xb6c8c4c0 Success!
[20240606-10:57:34.036 I 1181] manage.c 3721: hiapp audioEnable 1, audioFormat 0, audioInput 5, audioOutput 7, audioSampleRate 8000
[20240606-10:57:34.036 D 1181] manage.c 3625: get /mnt/flash/data/SysRebootInfo info failure .
[20240606-10:57:34.039 D 1181] manage.c 3625: get /mnt/flash/data/WifiBitrateInfo info failure .
[20240606-10:57:34.040 I 1181] global_var_manage_video.c 718: time_config X:2 Y:3 Enable:1 Osdfont:3 Osdformat:0
[20240606-10:57:34.041 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] mainFrameRate=15
[20240606-10:57:34.041 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] mainIPrate=30
[20240606-10:57:34.041 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] subStreamResolution=36
[20240606-10:57:34.041 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] subIPrate=30
[20240606-10:57:34.042 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] jpegStreamResolution=-1
[20240606-10:57:34.042 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] jpegStreamFrameRate=-1
[20240606-10:57:34.042 I 1181] global_var_manage_video.c 367: stream[0] cBitRateCrl:0 iStreamRate:1536 cFrameRate:15 cResolution:29
[20240606-10:57:34.042 I 1181] global_var_manage_video.c 369: stream[1] cBitRateCrl:0 iStreamRate:512 cFrameRate:15 cResolution:36
[20240606-10:57:34.042 I 1181] global_var_manage_video.c 371: stream[2] cFrameRate:5 cResolution:6
[20240606-10:57:34.043 I 1181] global_var_manage_video.c 525: SoundDetectEnable:0 Sensitivity=70
[20240606-10:57:34.043 I 1181] global_var_manage_video.c 607: pd_config enable:1 filter:1 draw:1
[20240606-10:57:34.047 I 1181] global_var_manage_ptz.c 122: PTZ Address:1 PanSpeed:7 TiltSpeed:5 PtzProtocol:0
[20240606-10:57:34.048 I 1181] global_var_manage_isp.c 146: use han_parameter Antiflicker=50
[20240606-10:57:34.048 D 1181] global_var_manage_isp.c 157: DayNightContrl:2 cICRMode:1 WhiteLightValue:50
[20240606-10:57:34.384 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] AESceneMode=2
[20240606-10:57:34.384 D 1181] global_var_manage_isp.c 181: CameraInfo SceneSelect:2 cEXP:56 MirrorH:0 MirrorV:0
[20240606-10:57:34.384 D 1181] manage.c 3625: get /mnt/flash/data/AFMoveInfo info failure .
[20240606-10:57:34.385 D 1181] global_var_manage_af.c 117: default Zoomspeed 4, iMultiple 0
[20240606-10:57:34.385 D 1181] manage.c 3625: get /mnt/flash/data/AFMoveInfo info failure .
globalSDInit audiorec = 1
[20240606-10:57:34.385 D 1181] manage.c 3625: get /mnt/flash/data/MlsInfo info failure .
[20240606-10:57:34.386 D 1181] main.c 623: Fun:FunInitSystem Line:623 
[20240606-10:57:34.386 D 1181] main.c 623: Initialize SysParamInit OK.
[20240606-10:57:34.386 D 1181] hank_sys.c 793:  timezoneminute == 26 ! 
[20240606-10:57:34.167 E 1177] mw_isp_interface.c 1530: ISP_Set_EVBias:1530 Get ExposureAttr failed!!
[20240606-10:57:34.387 E 1177] mw_isp_api.c 2167: mw_img_set_ae_daynight:2167 Get ExposureAttr attr failed!!
[20240606-10:57:34.432 D 1181] hank_sys.c 802:  cmd == 'echo CST-8 > /etc/TZ'
[20240606-10:57:34.433 D 1181] hank_sys.c 803: Update timezone info OKOKOK.
[20240606-10:57:34.433 D 1181] hank_ntp.c 110: !!!!!!ntp timezone change :timezone=26  daylight=0
[20240606-10:57:34.433 D 1181] action_manage_recording.c 38: Action_Record_Set_ManualEnable : start
[20240606-10:57:34.433 D 1181] main.c 632: ======== we are going to init share buff ========
[20240606-10:57:34.433 D 1181] shbuf_mng.c 115: hiapp MAJOR[0] shbuf_size=512000
[20240606-10:57:34.433 D 1181] shbuf_mng.c 123: hiapp MINOR[1] shbuf_size=204800
[20240606-10:57:34.434 D 1181] shbuf_mng.c 131: hiapp MJPEG[2] shbuf_size=102400
[20240606-10:57:34.434 D 1181] shbuf_mng.c 140: hiapp AUDIOOUT[4] shbuf_size=65536
[20240606-10:57:34.434 D 1181] shbuf_mng.c 149: hiapp AUDIOOT_AAC[9] shbuf_size=16384
[20240606-10:57:34.434 D 1181] shbuf_mng.c 158: hiapp max frame AUDIOIN[5] size:16384
[20240606-10:57:34.434 D 1181] shbuf_mng.c 161: not need init Submajor Subminor shbuf!
[20240606-10:57:34.434 D 1181] main.c 639: Fun:FunInitSystem Line:639 
[20240606-10:57:34.434 D 1181] main.c 639: [InitShBuf] is OKOKOL.
[20240606-10:57:34.434 D 1181] Usart.c 951: @@@@@@@@@@RS485 /dev/ttyAMA1 BaudRate=2@@@@@@@@@@@@@@@@@
usart0 open 
: No such device or address
[20240606-10:57:34.435 D 1181] Usart.c 836: Set Serial Speed : 9600
tcsetattr fd1: Bad file descriptor
[20240606-10:57:34.435 D 1181] main.c 643: Fun:FunInitSystem Line:643 
[20240606-10:57:34.435 D 1181] main.c 643: [Init_Usart] is OKOKOL.
[20240606-10:57:34.436 D 1181] hank_alarm.c 3805: NetAccess is 1
===== Thread_ShareFD thread create =====
[20240606-10:57:34.439 D 1363] netreq.c 3539: =========== NetReqProc thread start ===========
[20240606-10:57:34.439 D 1363] netreq.c 3545: 
 video video servport==90
hisi test : mw_server pid = 1177
======== Detect echo thread start ========
[20240606-10:57:34.444 D 1361] hank_alarm.c 3049: =========TH_RecvAN========
[20240606-10:57:34.444 D 1361] hank_alarm.c 3082: alarmserver bind OKOK!!!
[20240606-10:57:34.493 E 1177] mw_isp_api.c 4280: mw_img_set_brightness_api:4280 Get CSC attribute failed!!
[20240606-10:57:34.494 E 1177] mw_isp_api.c 4398: mw_img_set_contrast_api:4398 Get CSC attribute failed!!
[20240606-10:57:34.494 E 1177] mw_isp_interface.c 1753: ISP_Set_DN_Gamma:1753 HI_MPI_ISP_GetGammaAttr failed !
[20240606-10:57:34.494 D 1177] mw_isp_api.c 4678: HI_MPI_ISP_GetIspSharpenAttr error 0xa01c8041 
[20240606-10:57:34.494 D 1177] mw_isp_api.c 4766: HI_MPI_ISP_SetIspSharpenAttr error 0xa01c8041 
[20240606-10:57:34.494 D 1177] mw_isp_api.c 2470: HI_MPI_ISP_SetLDCIAttr=-1608744895
[20240606-10:57:34.494 D 1177] mw_isp_api.c 2474: Second HI_MPI_ISP_SetLDCIAttr=-1608744895
[20240606-10:57:34.495 D 1177] mw_init_api.c 2588: 1920x1080
[20240606-10:57:34.495 D 1177] mw_init_api.c 2602: vivpss_scaling_mode 2
[20240606-10:57:34.495 D 1177] mw_init_api.c 2606: limit max res 2560x1440
[20240606-10:57:34.495 D 1177] mw_init_api.c 345: profile[0] 0
[20240606-10:57:34.495 D 1177] mw_init_api.c 346: profile[1] 0
[20240606-10:57:34.495 D 1177] shbuf_mng.c 99: sdk_app MAJOR[0] shbuf_size=512000
[20240606-10:57:34.495 D 1177] shbuf_mng.c 109: sdk_app MINOR[1] shbuf_size=204800
[20240606-10:57:34.496 D 1177] shbuf_mng.c 119: sdk_app MJPEG[2] shbuf_size=102400
[20240606-10:57:34.496 D 1177] shbuf_mng.c 127: sdk_app AUDIOOUT[4] shbuf_size=65536
[20240606-10:57:34.496 D 1177] shbuf_mng.c 135: sdk_app max frame AUDIOIN[5] size:16384
[20240606-10:57:34.832 D 1177] mw_init_api.c 1400: chn:0 CompressMode:0 Width:2560 Height:1440
[20240606-10:57:34.832 D 1177] mw_init_api.c 1400: chn:1 CompressMode:0 Width:640 Height:360
[20240606-10:57:34.832 D 1177] mw_init_api.c 1400: chn:2 CompressMode:0 Width:640 Height:360
[20240606-10:57:34.832 D 1177] mw_init_api.c 2640: stParam ViVpssMode 1
[20240606-10:57:34.832 D 1177] mw_init_api.c 2642: stParam[0] 2560 1440
[20240606-10:57:34.832 D 1177] mw_init_api.c 2642: stParam[1] 640 360
[20240606-10:57:34.832 D 1177] mw_init_api.c 2642: stParam[2] 352 288
[20240606-10:57:34.963 D 1177] mw_init_api.c 2285: SAMPLE_VENC_GetCommVbAttr w-h [1920-1080]
[20240606-10:57:34.963 D 1177] mw_init_api.c 2292: vb[0] size 2592000 count 1
[20240606-10:57:34.963 D 1177] mw_init_api.c 2310: vb[1] size 5529600 count 1
[20240606-10:57:34.963 D 1177] mw_init_api.c 2320: vb[2] size 345600 count 3
[20240606-10:57:34.963 D 1177] mw_init_api.c 2330: vb[3] size 152064 count 1
[20240606-10:57:34.963 D 1177] mw_init_api.c 2340: vb[4] size 152064 count 1
[SAMPLE_COMM_VI_SetMipiAttr]-2031: ============= MipiDev 0, SetMipiAttr enWDRMode: 0
frameInterruptAttr.enIntType 3, frame_interrupt_earlyline 680
GC2083_SENSOR_1080P_30FPS_LINEAR_MODE
[Func]:cmos_fps_set [Line]:240 [Info]:set vmax Fps01: 2250
[Func]:cmos_fps_set [Line]:252 [Info]:set vmax Fps03: 2250
===Galaxycore GC2083_1080P_30FPS_10BIT_LINEAR_Init_OK!===
[20240606-10:57:35.042 D 1177] mw_init_api.c 1709: SAMPLE_VENC_VPSS_ChnEnable stVpssChnAttr.u32Width == 2560,stVpssChnAttr.u32Height == 1440
[20240606-10:57:35.043 D 1177] mw_init_api.c 1709: SAMPLE_VENC_VPSS_ChnEnable stVpssChnAttr.u32Width == 640,stVpssChnAttr.u32Height == 360
[20240606-10:57:35.043 D 1177] mw_init_api.c 1709: SAMPLE_VENC_VPSS_ChnEnable stVpssChnAttr.u32Width == 352,stVpssChnAttr.u32Height == 288
[SAMPLE_COMM_VENC_OtherParams]-2656: HI_MPI_VENC_GetSkipBias [2] faild with 0xa0088008!
[SAMPLE_COMM_VENC_OtherParams]-2674: HI_MPI_VENC_SetSkipBias [2] faild with 0xa0088008!
[20240606-10:57:35.046 D 1177] mw_init_api.c 2878: mjpeg stVencChnAttr.stVencAttr.u32PicWidth === 640 360 
img_width 640, img_height 360, size 920
[SAMPLE_COMM_ISP_Thread]-469: ISP Dev 0 running !
dhcp enable = 1
No such device: GetLocalIp(2)
Cannot assign requested address: GetLocalIp(2)
ioctl siocgifaddr errorioctl siocgifaddr errorHankBatchUpdateServer tcp serverIp:0.0.0.0	port:20203
wdt timeout 60
add [sdk_app] to watchdog list.
add [hiapp] to watchdog list.
[20240606-10:57:35.580 I 1177] ivp.c 3490: set pd filter motionless_enable:1 motionless_sensitivity:0.900000
md_size 352x288 
[20240606-10:57:35.581 I 1177] mw_init_api.c 1177: use hank_parameter[OutPutVolume]=7
[20240606-10:57:35.581 I 1177] mw_init_api.c 1186: use hank_parameter[InPutVolume]=5
[20240606-10:57:35.581 I 1177] mw_init_api.c 1187: use hank_parameter[InPutType]=0
[20240606-10:57:35.582 I 1177] mw_init_api.c 1190: audioEnable=1, audioFormat=0, audioInput=5, audioOutput 7, audioSample 8000
audio_set_enable audioEnable 1, audioFormat 0, audioSample 8000
AAC_MODULES 0
[20240606-10:57:35.582 I 1177] mw_init_api.c 747: use hank_parameter[DenoiseState]=0
vpssChn0 0, vpssChn1 -1, chnCount 1
md VpssGrp ==== 0,VpssChn ============ 2
vpssChn0 1, vpssChn1 -1, chnCount 1
[20240606-10:57:35.595 D 1177] mw_init_api.c 1019: [mw_audio_AiAenc_AdecAo_init]:1019 audioInput 5
[20240606-10:57:35.596 I 1177] sample_comm_audio.c 360: SAMPLE_INNER_CODEC_Input odm_param_enable:0 InputVol[0:50]:41
[20240606-10:57:35.596 I 1177] hank_parameter.c 326: [hk_parameter_get_ro_int] audio_output_gain_7=-2
[20240606-10:57:35.596 I 1177] sample_comm_audio.c 416: SAMPLE_INNER_CODEC_Output ao HiVol:0 odm_param_enable:0 OutputVal[-121~6]:-2
process_client_request start
[20240606-10:57:35.619 D 1181] main.c 2036: ====== we are going to init af params ======
===>>>sdk_app set multiple: 0
err:can not find right section name
[20240606-10:57:35.620 D 1181] pipe.c 183: == app head == symbol:SHVDR, msg_length 8
[20240606-10:57:35.620 D 1181] pipe.c 184: == app recv from mw == symbol:SHVDR, result:-1
[20240606-10:57:35.620 D 1181] hank_af_manage_API.c 248: ===>>>send_msg_to_mw failure.
===>>>sdk_app set zoom speed: 4
===>>>sdk_app set focus speed: 4
clean up cache!
[20240606-10:57:35.620 D 1181] pipe.c 183: == app head == symbol:SHVST, msg_length 8
[20240606-10:57:35.620 D 1181] pipe.c 184: == app recv from mw == symbol:SHVST, result:-1
[20240606-10:57:35.620 D 1181] hank_af_manage_API.c 276: ===>>>send_msg_to_mw failure.
clean up cache!
[20240606-10:57:35.621 D 1181] pipe.c 183: == app head == symbol:SHVRE, msg_length 8
[20240606-10:57:35.621 D 1181] pipe.c 184: == app recv from mw == symbol:SHVRE, result:-1
[20240606-10:57:35.621 D 1181] hank_af_manage_API.c 851: ===>>>send_msg_to_mw failure.
[20240606-10:57:35.621 D 1181] main.c 2038: ====== we are going to init image ======
[20240606-10:57:35.621 I 1181] hank_parameter.c 363: [hk_parameter_set_int] Antiflicker=50
clean up cache!
[20240606-10:57:35.625 D 1395] mw_isp_api.c 2950: to Get DRC attr!!
hiapp : head.symbol=SMIR,head.id=00000,mirror=3 
clean up cache!
[20240606-10:57:35.628 D 1395] mw_isp_api.c 5311: sdk_app: eMirror 3
[20240606-10:57:35.628 D 1181] pipe.c 183: == app head == symbol:SHVDR, msg_length 8
[20240606-10:57:35.628 D 1181] pipe.c 184: == app recv from mw == symbol:SHVDR, result:-1
[20240606-10:57:35.628 D 1181] hank_af_manage_API.c 248: ===>>>send_msg_to_mw failure.
[20240606-10:57:35.637 D 1181] main.c 2040: ====== we are going to init encode ======
DevicePixel 1228800, Resolution 8
=========in init_video_params: Stream 0 :resolution h:1440 w:2560
[20240606-10:57:35.640 E 1395] mw_isp_api.c 4011: irc_mode:MW_INFRARED_OFF[6] must domeJson daynight_ctrl_type==0,but daynight_ctrl_type=1
[20240606-10:57:35.640 D 1395] mw_isp_api.c 4181: senconds = 3
[20240606-10:57:35.640 D 1395] mw_isp_api.c 4199: ***set c2bwthr = 20****
[20240606-10:57:35.640 D 1395] mw_isp_api.c 4217: ***set bw2cthr = 70****
[20240606-10:57:35.641 I 1395] mw_isp_api.c 5585: sdk_app set ExposureAttr Compensation=70
[20240606-10:57:35.644 D 1395] mw_isp_api.c 6165: Get vi LDC attr err:0xa0108008
[20240606-10:57:35.644 D 1395] mw_isp_api.c 6206: Get vi LDC attr err:0xa0108008
set stream 0 resolution: 2560 1440 to 2560 1440
[20240606-10:57:35.645 D 1181] hank_video_manage_API.c 5964: app framerate:15
=========in init_video_params: Stream 1 :resolution h:360 w:640
=========in init_video_params: Stream 2 :resolution h:480 w:640
[20240606-10:57:35.646 E 1394] mw_enc_check.c 154: mw_enc_check_resolution:154 invalid param, change res to MAX
[20240606-10:57:35.646 D 1181] hank_video_manage_API.c 5964: app framerate:5
[20240606-10:57:35.647 E 1181] main.c 2064: silent_reboot not exist or factory now
[20240606-10:57:35.983 D 1181] hank_alarm.c 4759: hank_Play_AudioFile pri 2, file /mnt/flash/Server/resource/audio/cn/1.g711u, repeat 1, duration -1, block 1
[20240606-10:57:35.983 D 1181] hank_audio_manage_API.c 367: hiapp : symbol=SAMPE,value=1,len=4
vbr enRcMode 12, u32MaxBitRate 1536 
u32Gop 30, u32StatTime 2, u32SrcFrmRate 16, fr32DstFrmRate 15
stream 0 , VBR framerate : In 15, Fps 15, gop 30, statTime 2
set stream 1 resolution: 640 360 to 640 360
vbr enRcMode 2, u32MaxBitRate 512 
stream 1 , VBR framerate : In 15, Fps 15, gop 30, statTime 2
set stream 2 resolution: 640 360 to 640 360
______sdk_app: enable = 1 sensitivity = 50, thr 220
pd_set enable 1, sensitivity 50, draw 1, filter 1, autotrace 0
[20240606-10:57:35.985 I 1395] ivp.c 655: sample_ivp_param: enable:1 draw:1 filter:1 autotrace:0
sdkapp sizeof(ENC_DLINE_ST) 104
dLine enable 1
[0]enable 1
dLine x 50, y 0, end x 50, end y 100
^_^ osd time width=2560 height=1440 fsize=44 size=3
[Func]:cmos_fps_set [Line]:240 [Info]:set vmax Fps01: 2025
[Func]:cmos_fps_set [Line]:252 [Info]:set vmax Fps03: 2025
[20240606-10:57:36.104 D 1181] hank_alarm.c 4454: hank_Play_AudioFile_now begin /mnt/flash/Server/resource/audio/cn/1.g711u
^_^ osd time width=640 height=360 fsize=20 size=3
[20240606-10:57:36.198 D 1395] mw_enc_api.c 3281: [mw_set_audioamplifier_enable] amplifier_enable:1
[20240606-10:57:36.199 D 1395] stream_reader.c 161: audio swtich ON AUDIO_CTRL:1
[20240606-10:57:38.478 D 1181] hank_alarm.c 4574: hank_Play_AudioFile_now /mnt/flash/Server/resource/audio/cn/1.g711u end
[20240606-10:57:38.479 D 1181] hank_alarm.c 4575: total_data_len 19177, play_time 2306, audio_time 2397
[20240606-10:57:38.479 D 1181] shaking.c 2191: maxLRStep 4100, maxUDStep 1140
[   14.707682] maxLRStep:4100,maxUDStep:1140
[20240606-10:57:39.629 D 1181] shaking.c 2208: last motor position 2050 570
[20240606-10:57:39.630 D 1181] shaking.c 2217: [moto_init_config]--[2217] g_motorFd ==== 11
[20240606-10:57:39.630 D 1181] shaking.c 2014: user GK7202V300 gpio init moto
[   15.949354] MotorHReverse=0 MotorVReverse=0
[20240606-10:57:39.854 D 1181] shaking.c 1832: org: p_speed=70 t_speed=50
[20240606-10:57:39.854 D 1181] shaking.c 1868: use: p_speed=7 t_speed=5
[20240606-10:57:39.855 D 1181] shaking.c 3198: [moto_set_h_speed] shaking not support this!
[20240606-10:57:39.855 D 1181] shaking.c 3186: [moto_set_v_speed] shaking not support this!
[20240606-10:57:39.857 D 1181] shaking.c 2337: create moto_self_chek_ex proc over!
[20240606-10:57:39.857 I 1430] hank_parameter.c 326: [hk_parameter_get_ro_int] PTZLRSelfCheckSpeed=-1
[20240606-10:57:39.858 I 1430] hank_parameter.c 326: [hk_parameter_get_ro_int] PTZUDSelfCheckSpeed=-1
[20240606-10:57:39.858 I 1430] shaking.c 1112: [moto_self_chek_ex]h_speed:7 v_speed:5
[20240606-10:57:39.858 I 1430] hank_parameter.c 326: [hk_parameter_get_ro_int] CustomBJDelay_7=-1
[20240606-10:57:39.858 D 1430] shaking.c 215: BJSetSpeed speed[7]=7500
[20240606-10:57:39.858 I 1430] shaking.c 1167: [moto_self_chek_ex] start goto maxLRStep:4100
[20240606-10:57:40.649 D 1398] motion_detect.c 218: md module start
[20240606-10:57:42.029 D 1397] mw_isp_api.c 10493: HI_MPI_VPSS_GetGrpNRSParam return ret = 0xa0078003
[20240606-10:57:42.030 D 1397] mw_isp_api.c 10622: gain 1, noise_level 0, quality_record[0] 2
[20240606-10:57:42.030 D 1397] mw_isp_api.c 10670: set 3dnr param failed ret = 0xa0078003
[20240606-10:57:42.139 D 1397] mw_isp_api.c 10622: gain 1, noise_level 0, quality_record[0] 2
[20240606-10:57:47.138 D 1391] stream_reader.c 171: audio swtich OFF AUDIO_CTRL:1
[20240606-10:57:50.198 D 1430] shaking.c 288: app motor done ==== 1
[20240606-10:57:50.199 I 1430] shaking.c 1184: [moto_self_chek_ex] start goto zero LRStep:0
[   32.007365] random: crng init done
[20240606-10:58:00.488 D 1430] shaking.c 288: app motor done ==== 1
[20240606-10:58:00.489 I 1430] hank_parameter.c 326: [hk_parameter_get_ro_int] CustomBJDelay_5=-1
[20240606-10:58:00.489 D 1430] shaking.c 215: BJSetSpeed speed[5]=12500
[20240606-10:58:00.489 I 1430] shaking.c 1201: [moto_self_chek_ex] start goto maxUDStep:1140
[20240606-10:58:05.318 D 1430] shaking.c 288: app motor done ==== 1
[20240606-10:58:05.319 I 1430] shaking.c 1218: [moto_self_chek_ex] start goto zero UDStep:0
[20240606-10:58:10.148 D 1430] shaking.c 288: app motor done ==== 1
[20240606-10:58:10.149 D 1430] shaking.c 1242: [moto_self_chek_ex] goto reset position x=2050 y=570
[20240606-10:58:10.149 I 1430] hank_parameter.c 326: [hk_parameter_get_ro_int] PTZLRTraceSpeed=-1
[20240606-10:58:10.149 I 1430] hank_parameter.c 326: [hk_parameter_get_ro_int] PTZUDTraceSpeed=-1
[20240606-10:58:10.149 D 1430] shaking.c 1445: moto_calling_preset = 2 h_speed = 8 v_speed = 8
[20240606-10:58:10.149 D 1430] shaking.c 1448: currLRDirect ==== 2 currUDDirect ==== 0
[20240606-10:58:10.150 D 1430] shaking.c 1450: moto_call_position 0 0, 2050 570
[20240606-10:58:10.150 D 1430] shaking.c 1455: [moto_call_position]--[1455] R Move stepnum ==== 2050
[20240606-10:58:10.150 I 1430] hank_parameter.c 326: [hk_parameter_get_ro_int] CustomBJDelay_8=-1
[20240606-10:58:10.150 D 1430] shaking.c 215: BJSetSpeed speed[8]=5000
[20240606-10:58:13.649 D 1430] shaking.c 288: app motor done ==== 1
[20240606-10:58:13.650 D 1430] shaking.c 1489: [moto_call_position]--[1489] D Move stepnum ==== 570
[20240606-10:58:13.650 I 1430] hank_parameter.c 326: [hk_parameter_get_ro_int] CustomBJDelay_8=-1
[20240606-10:58:13.650 D 1430] shaking.c 215: BJSetSpeed speed[8]=5000
[20240606-10:58:14.638 D 1430] shaking.c 288: app motor done ==== 1
[20240606-10:58:14.657 I 1430] shaking.c 1263: clean noneed_silent_reboot file over!!!
[20240606-10:58:14.658 I 1430] shaking.c 1266: [moto_self_chek_ex] self check over, CurrLRStep:2050 CurrUDStep:570
[20240606-10:58:14.658 D 1181] shaking.c 2340: join moto_self_chek_ex proc over!
dhcp_enable = 1
DHCP enabled~~~~~~~~
[   50.790708] hiapp (1181): drop_caches: 3
[20240606-10:58:14.818 D 1354] manage.c 187: normal voice info audioInType:0 audioInput:5 audioOutput:7
killall: udhcpc: no process killed
killall: udhcpd: no process killed
killall: hostapd: no process killed
Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
[20240606-10:58:16.487 D 1181] hank_wifi_cfg80211.c 711: [wlan_wpa_open_connection]--[711] gs_sta.s_fd 12 local.sun_path /var/run/wpa_supplicant/wpa_1181_0
[20240606-10:58:16.487 D 1181] hank_wifi_cfg80211.c 720: [wlan_wpa_open_connection]--[720] gs_sta.s_fd 12 remote.sun_path /var/run/wpa_supplicant/wlan0
Scan List:
  ID / SSID / MAC Address / Channel / Security / Signal Level
  00  HUAWEI-1111_5G  22:57:fe:da:b4:54  157  WPA_WPA2_PSK  65
  01  \xe6\xb5\x8b\xe8\xaf\x95\xe9\x83\xa8test1  3c:06:a7:16:90:bf  40  WPA_WPA2_PSK  60
  02  TP-LINK_IMXJL5G  f4:6d:2f:83:1d:eb  161  WPA_WPA2_PSK  55
  03  HKTEST11  82:43:41:dc:b4:54  161  WPA_WPA2_PSK  53
  04  HK-Test3-5G  34:f7:16:a2:56:15  40  WPA_WPA2_PSK  52
  05  \xe6\x9e\x97@5G  34:f7:16:7f:80:c8  161  WPA_WPA2_PSK  47
  06  HUAWEI-TP-LINK_cloud_5G  82:d5:55:5b:56:c6  157  WPA_WPA2_PSK  49
  07  \xe5\xb8\xb8\xe7\x94\xb5\xe9\xbb\x91\xe5\x85\x89_5G  04:42:1a:c1:20:ac  157  WPA_WPA2_PSK  48
  08  HANHTEST1_5G  3c:06:a7:14:12:83  48  WPA_WPA2_PSK  54
  09  xyz-5G  f8:8c:21:c7:c9:48  157  WPA_WPA2_PSK  41
  10  testl_5G  54:16:51:02:cb:32  36  WPA_WPA2_PSK  56
  11  ChinaNet-d3hG-5G  08:6b:d1:fa:df:31  52  WPA_WPA2_PSK  21
  12  @PHICOMM_64_5G  2c:b2:1a:44:2a:67  44  WPA_WPA2_PSK  48
  13  TP-LINK_1097  f8:8c:21:46:10:97  6  WPA_WPA2_PSK  69
  14  HUAWEI-1111  22:57:fe:da:b4:50  6  WPA_WPA2_PSK  75
  15  TP-LINK_80C3  34:f7:16:7f:80:c3  6  WPA_WPA2_PSK  69
  16  cyg  62:38:22:d8:b4:50  6  WPA_WPA2_PSK  52
  17  hank_factory  36:f7:16:5f:80:c6  11  WPA_WPA2_PSK  60
  18  \xe6\x9e\x97@2.4G  34:f7:16:7f:80:c6  11  WPA_WPA2_PSK  58
  19  TP-LINK_VALLEY_24_5G  d0:ee:07:2d:f9:ba  44  WPA_WPA2_PSK  41
  20  ASUS_TXW  24:4b:fe:18:3a:18  6  WPA_WPA2_PSK  41
  21  test6-5G  f4:84:8d:63:26:c0  149  WPA_WPA2_PSK  54
  22  abc123_5G  62:38:5e:a5:97:aa  36  WPA_WPA2_PSK  44
  23  HKTEST11  82:43:41:dc:b4:50  7  WPA_WPA2_PSK  57
  24  Xiaomi_CB64  3c:cd:57:6c:cb:65  6  WPA_WPA2_PSK  38
  25  360WiFi-hzc  a4:56:02:72:85:fd  11  WPA_WPA2_PSK  54
  26  lucy_wifi_5G  68:26:2a:e9:2c:e9  149  WPA_WPA2_PSK  48
  27  ASUSTXW_5G  24:4b:fe:18:3a:1c  149  WPA_WPA2_PSK  48
  28  zzzwww  34:f7:16:7f:ec:1e  11  WPA_WPA2_PSK  50
  29  31415926  f8:8c:21:c9:52:85  11  WPA_WPA2_PSK  49
  30  test6  f4:84:8d:63:26:be  10  WPA_WPA2_PSK  59
  31  @PHICOMM_64_2.4G  2c:b2:1a:44:2a:66  9  WPA_WPA2_PSK  64
  32  TP-LINK_VALLEY_24  d4:ee:07:2d:f9:ba  9  WPA_WPA2_PSK  62
  33  TP-LINK_22B2  7c:b5:9b:6c:22:b4  157  WPA_WPA2_PSK  18
  34  5G-88888888  34:f7:16:7f:ec:53  149  WPA_WPA2_PSK  41
  35  test_123  f4:6d:2f:83:0d:60  11  WPA_WPA2_PSK  42
  36  Xiaomi_Hank  3c:cd:57:6c:cc:3f  8  WPA_WPA2_PSK  64
  37  TP-LINK_1097  f8:8c:21:46:10:99  153  WPA_WPA2_PSK  73
  38  yan  d8:a4:91:6b:88:bc  12  WPA_WPA2_PSK  46
  39  hank_factory_lwb_rs80  64:6e:97:42:bb:4f  13  WPA_WPA2_PSK  46
  40  \xe6\xb5\x8b\xe8\xaf\x95\xe9\x83\xa8test1  3c:06:a7:16:90:bd  1  WPA_WPA2_PSK  67
  41  testl_2.4g  54:16:51:02:cb:31  1  WPA_WPA2_PSK  67
  42  FYF_6AD3  0c:4b:54:4f:6a:d5  157  WPA_WPA2_PSK  14
  43  TP-LINK_5G_34F7  b0:95:8e:10:34:f9  149  WPA_WPA2_PSK  39
  44  HKiOS0200\xe7\x9a\x84Wi-Fi  8a:7e:cd:4a:62:03  36  WPA_WPA2_PSK  30
  45  TP-LINK_5G_8138  34:f7:16:7f:81:3a  149  WPA_WPA2_PSK  38
  46  TP-LINK_IMXJL2.4G  f4:6d:2f:83:1d:e9  1  WPA_WPA2_PSK  65
  47  HKYF-007  5c:63:bf:79:50:c0  1  WPA_WPA2_PSK  60
  48  hank_nvr_rs50  50:fa:84:77:12:ce  4  WPA_WPA2_PSK  43
  49  Xiaomi_C8D6  3c:cd:57:69:c8:d7  2  WPA_WPA2_PSK  60
  50  DAP-9J0CEB9RAGEE3C7  fc:5f:49:57:73:e5  4  WPA_WPA2_PSK  43
  51  \xe6\xb5\x8b\xe8\xaf\x95110  34:f7:16:7f:ec:2c  153  WPA_WPA2_PSK  56
  52  HUAWEI-TP-LINK_cloud  82:d5:55:5b:56:c2  1  WPA_WPA2_PSK  57
  53  abc123  62:38:5e:a5:97:a6  1  WPA_WPA2_PSK  48
  54  TP-LINK_8138  34:f7:16:7f:81:38  5  WPA_WPA2_PSK  48
  55  TPGuest_8138  36:f7:16:5f:81:38  5  WPA_WPA2_PSK  46
  56  yangji  f4:6d:2f:82:c3:13  153  WPA_WPA2_PSK  40
  57  GCSC  82:89:12:e6:b4:54  153  WPA_WPA2_PSK  35
Scan List:
[20240606-10:58:24.519 D 1181] hank_wifi_cfg80211.c 1317: Wifi_build_scan_wpaConfig hotspotNum 58
[   60.669378] hiapp (1181): drop_caches: 3
[20240606-10:58:24.573 D 1181] hank_wifi_cfg80211.c 868: Detect_ap0_up start detect ap0 ======================
[20240606-10:58:24.783 D 1181] hank_wifi_cfg80211.c 905: Detect_ra0_up start detect wlan0 ======================
[   60.934824] hiapp (1181): drop_caches: 3
[20240606-10:58:24.836 D 1181] hank_wifi_cfg80211.c 1410: [Wifi_Load_Module] get wifi mode=0 ssid=,key=
[20240606-10:58:24.836 D 1181] hank_wifi_cfg80211.c 1419: [Wifi_Load_Module] wifi work mode=0
[20240606-10:58:25.086 D 1181] hank_wifi_cfg80211.c 1449: [Wifi_Load_Module] wifiDriver_mode === 0
[20240606-10:58:25.089 D 1181] hank_wifi_cfg80211.c 905: Detect_ra0_up start detect wlan0 ======================
[20240606-10:58:25.100 D 1181] hank_wifi_cfg80211.c 868: Detect_ap0_up start detect ap0 ======================
killall: wpa_supplicant: no process killed
[20240606-10:58:26.209 D 1181] hank_wifi_cfg80211.c 1635: Wifi_AP_Start wifiDriver_mode === 0
/bin/sh: /mnt/flash/Server/resource/wifi/hostapd: not found
[20240606-10:58:26.240 D 1181] hank_wifi_cfg80211.c 1667: To start udhcpd server
[20240606-10:58:26.293 D 1181] hank_wifi_cfg80211.c 1675: Set ap_name=ap0 to tmp/udhcpd.conf
[20240606-10:58:26.338 D 1181] hank_wifi_cfg80211.c 1694: Start udhcpd /tmp/udhcpd.conf
[20240606-10:58:26.351 D 1181] hank_ntp.c 92: ntpconfig : ip:time.windows.com
time: 23:59:00
 interval:24
enable:1
[20240606-10:58:26.352 D 1181] main.c 2076: Fun:main Line:2076 
[20240606-10:58:26.352 D 1181] main.c 2076: [NetParmInit] is OKOKOL.
[20240606-10:58:26.356 D 1181] main.c 2096: Thread_status_check creat ok!
[ImageManage_Set_DualMode_priv]---[1495] dualMode === 0 lightValue === 50 DayNightContrl === 2
[20240606-10:58:26.364 D 1395] mw_isp_api.c 1137: [mw_img_set_DUALM_Start]---[1137] g_dualSupport == 0 light_value == 50 pwm_value == 0
[20240606-10:58:26.364 D 1395] mw_isp_api.c 1138: [mw_img_set_DUALM_Start]---[1138] dual_led_Mode == 0 r_led_open == 0
[20240606-10:58:26.364 D 1395] mw_isp_api.c 1139: [mw_img_set_DUALM_Start]---[1139] dayNightContrl == 2 ICR_STATE == 1 w_led_open == 0
[20240606-10:58:26.372 D 1181] netreq.c 1913: UserIRMode:1 DoubleLightMode=0 DayNightCutMode:0 PhotosensitiveType:SotfPhotosensitive
[20240606-10:58:26.373 D 1181] infrared.c 1900: icr_mode:1
[20240606-10:58:26.373 D 1181] main.c 2208: TH_AlarmProcess_API creat ok!
Create thread <cameramode_task> successful !
[20240606-10:58:26.377 D 1181] ips_record_new.c 3118: Start_Record_new !! 
[20240606-10:58:26.378 D 1181] tuyap2p.c 1877: [start_tuya_module]---[1877] start_tuya_module ===================
[20240606-10:58:26.378 D 1505] main.c 1354: Thread_Reset ...........
[20240606-10:58:26.380 D 1506] infrared.c 1179: =================== Thread IR start! ===================
[20240606-10:58:26.385 D 1511] ips_record_new.c 2714: new rec module start
[20240606-10:58:26.395 D 1181] tuyap2p.c 1119: hk_tuya_get_oem_pid alsqsx6kcoqznl72 
Dbg:hk_tuya_init info: alsqsx6kcoqznl72 hhws92211069322dcd07 Q7MUANuycemR7MULRSvgMdNRpdfGvhBl 1
Err:fopen read /tmp/wifiConfigError failed!
Dbg:hk_tuya_stream_init ===================
Dbg:APssid  ==== SmartLife_322dcd07
Dbg:Wifi_Up
[20240606-10:58:26.401 D 1181] hank_wifi_cfg80211.c 905: Detect_ra0_up start detect wlan0 ======================
0x112C0044: 0x00000000 --> 0x00000000 
[END]
[20240606-10:58:26.531 D 1181] hank_wifi_cfg80211.c 868: Detect_ap0_up start detect ap0 ======================
0x120C0020: 0x00000002 --> 0x00000002 
[END]
[20240606-10:58:26.565 I 1516] tuya_led_1076G.c 164: INDICATORLED GPIO CMD:gkmm 0x112C0044 0x0 REDLED  GPIO:42 ENABLE_LEVEL:1
[20240606-10:58:26.566 I 1516] tuya_led_1076G.c 165: INDICATORLED GPIO CMD:gkmm 0x120C0020 0x2 BLUELED GPIO:17 ENABLE_LEVEL:0
0x120c0004: 0x00001000 --> 0x00001001 
[END]
[20240606-10:58:26.587 D 1506] infrared.c 984: use adc ch1, get daynight state
[20240606-10:58:26.588 D 1506] infrared.c 591: [IR_Hi_ADC_configStart]--[591] channel ==== 1 enAdcMode ==== 1
0x112c0040: 0x00001000 --> 0x00001000 
[END]
[20240606-10:58:26.614 D 1505] main.c 1427: Thread_Reset: reset_io_num 41
route: SIOCADDRT: Network is down
[20240606-10:58:27.728 D 1181] hank_wifi_cfg80211.c 1635: Wifi_AP_Start wifiDriver_mode === 0
[20240606-10:58:27.785 D 1181] hank_wifi_cfg80211.c 1667: To start udhcpd server
[20240606-10:58:27.850 D 1181] hank_wifi_cfg80211.c 1675: Set ap_name=ap0 to tmp/udhcpd.conf
[20240606-10:58:27.890 D 1181] hank_wifi_cfg80211.c 1694: Start udhcpd /tmp/udhcpd.conf
Dbg:tWifiConn.connStatus ==== 0
Dbg:hk_tuya_netMonitor_start ============================
Dbg:hk_tuya_qrcodeServer_start ============================
[20240606-10:58:29.043 D 1181] autotrace.c 124: [trace_init]:124 motor_coef_x=8.695652 motor_coef_y=4.257246 h_ratio=1 v_ratio=1 
[20240606-10:58:29.043 D 1571] autotrace.c 587: [trace_loop,587]max_x=4070,max_y=1058
 0x1df14c 
 0x759ec 
beginend[20240606-10:58:29.046 D 1569] tuya_ipc_qrcode_api.c 212: Qrcode Thread start
[20240606-10:58:29.057 I 1569] tuya_ipc_qrcode_api.c 246: start init call_key cmd:gkmm 0x120C001C 0x1502 gpio_num:16 enable_level:0
[20240606-10:58:29.058 I 1571] hank_parameter.c 326: [hk_parameter_get_ro_int] TraceVdirEnable=0
[20240606-10:58:29.065 D 1571] autotrace.c 594: trace module start vdir_trace_en 0
[20240606-10:58:29.066 I 1571] shaking.c 2276: first not need reset_autotrace!
0x120C001C: 0x00001402 --> 0x00001502 
[END]
Dbg:IPC_APP_Init_SDK WIFI_INIT_MODE_E init_mode : 1
Dbg:SDK Version:< TUYA IOT SDK V:5.3.41 BS:40.00_PT:2.2_LAN:3.4_CAD:1.0.4_CD:1.0.0 >
< BUILD AT:2024_01_24_10_51_49 BY ci_manage FOR ty_ipc_wr_wl_linux_sdk AT arm-gcc6.3-linux-uclibceabi >
IOT DEFS < WIFI_GW:1 DEBUG:1 KV_FILE:1 SHUTDOWN_MODE:1 LITTLE_END:1 TLS_MODE:4 ENABLE_CLOUD_OPERATION:1 OPERATING_SYSTEM:100 ENABLE_SYS_RPC:0 RELIABLE_TRANSFER:0 ENABLE_LAN_ENCRYPTION:1 ENABLE_LAN_LINKAGE:0 ENABLE_LAN_DEV:0 >
Dbg:Init Value.storage_path /mnt/flash/productinfo/tuyaconfig/
Dbg:Init Value.upgrade_file_path /tmp/update.bin
Dbg:Init Value.sd_base_path /mnt/flash/mmc/video/
Dbg:Init Value.product_key alsqsx6kcoqznl72
Dbg:Init Value.uuid hhws92211069322dcd07
Dbg:Init Value.auth_key Q7MUANuycemR7MULRSvgMdNRpdfGvhBl
Dbg:Init Value.p2p_id 
Dbg:Init Value.dev_sw_version 3.4.0
Dbg:Init Value.max_p2p_user 3
[IPC_APP_Notify_LED_Sound_Status_CB]--[190] curr event:0 
[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/flash/productinfo/tuyaconfig/ 
[01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/flash/productinfo/tuyaconfig/
[01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/flash/productinfo/tuyaconfig/
[01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[01-01 18:12:15 TUYA D][simplekv.c:999] normal file exist. bak file not exist
[01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file
[01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade
[01-01 18:12:15 TUYA D][simplekv.c:555] head check success
[01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success
[01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[01-01 18:12:15 TUYA E][log_seq.c:863] open err
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
uuid: 20
68 68 77 73 39 32 32 31 31 30 36 39 33 32 32 64 63 64 30 37 
devid_tmp: 16
45 18 1c 24 20 81 04 01 89 0c 20 8d 30 d0 07 ff 
devid_tmp2: 20
[01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
dev id key: 16
d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[20240606-10:58:33.451 D 1570] bt_ext_porting.c 434: wei bt_test tuya_ext_bt_port_init ptr:0xabb31944...
[20240606-10:58:33.452 D 1570] bt_ext_porting.c 439: tuya ext bt port init
[01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish
Dbg:[IPC_APP_Init_SDK]--[411] tuya_ipc_init_sdk Success!
[01-01 18:12:15 TUYA N][uni_log.c:197] SetLogManageAttr 5
[20240606-10:58:33.453 D 1570] tuya_ipc_media_api.c 168: [IPC_APP_Set_Media_Info]--[168] s_media_info.video_codec E_CHANNEL_VIDEO_MAIN 4
Dbg:fps:15
Dbg:gop:30
Dbg:bitrate:1536 kbps
Dbg:video_main_width:2560
Dbg:video_main_height:1440
Dbg:video_freq:90000
Dbg:video_codec:4
[20240606-10:58:33.453 D 1570] tuya_ipc_media_api.c 198: [IPC_APP_Set_Media_Info]--[198] s_media_info.video_codec E_CHANNEL_VIDEO_SUB 2
Dbg:channel_enable:1 1 0
Dbg:fps:15
Dbg:gop:30
Dbg:bitrate:512 kbps
Dbg:video_main_width:640
Dbg:video_main_height:360
Dbg:video_codec:2
Dbg:audio_codec:105
Dbg:audio_sample:8000
Dbg:audio_databits:16
Dbg:audio_channel:0
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
             total       used       free     shared    buffers     cached
Mem:         33628      25752       7876        904        716       7948
-/+ buffers/cache:      17088      16540
Swap:            0          0          0
Dbg:init ring buffer Channel:0 Enable:1
Dbg:video_bitrate 1536, video_fps 15
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:540] Init Ring Buffer. ch0st0tr0 bitrate:1536 fps:15
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:572] Ring buffer malloc 1966080 bytes for ch0st0tr0, max frame size 294912
[01-01 18:12:15 TUYA I][tuya_ring_buffer.c:592] Init Ring Buffer success: ch0st0tr0 size:1966080 nodes:150
Dbg:init ring buffer success. channel:0
Dbg:init ring buffer Channel:1 Enable:1
Dbg:video_bitrate 512, video_fps 15
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:540] Init Ring Buffer. ch0st0tr1 bitrate:512 fps:15
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:572] Ring buffer malloc 655360 bytes for ch0st0tr1, max frame size 98304
[01-01 18:12:15 TUYA I][tuya_ring_buffer.c:592] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:150
Dbg:init ring buffer success. channel:1
Dbg:init ring buffer Channel:2 Enable:0
Dbg:init ring buffer Channel:3 Enable:0
Dbg:init ring buffer Channel:4 Enable:0
Dbg:init ring buffer Channel:5 Enable:0
Dbg:init ring buffer Channel:6 Enable:0
Dbg:init ring buffer Channel:7 Enable:0
Dbg:init ring buffer Channel:8 Enable:0
Dbg:init ring buffer Channel:9 Enable:1
Dbg:audio_sample 8000, audio_databits 16, audio_fps 25
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:540] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[01-01 18:12:15 TUYA D][tuya_ring_buffer.c:572] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[01-01 18:12:15 TUYA I][tuya_ring_buffer.c:592] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
Dbg:init ring buffer success. channel:9
Dbg:init ring buffer Channel:10 Enable:0
Dbg:init ring buffer Channel:11 Enable:0
Dbg:init ring buffer Channel:12 Enable:0
Dbg:init ring buffer Channel:13 Enable:0
Dbg:init ring buffer Channel:14 Enable:0
Dbg:init ring buffer Channel:15 Enable:0
[01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1758] Last reset reason: 255
[01-01 18:12:15 TUYA T][tuya_tls.c:383] tls register constant hhws92211069322dcd07 Q7MUANuycemR7MULRSvgMdNRpdfGvhBl 
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[20240606-10:58:33.821 D 1570] tuya_ipc_wifi_api.c 707: hwl_wf_get_mac
[20240606-10:58:33.845 D 1570] tuya_ipc_wifi_api.c 738: WIFI Get MAC 80-DF-25-00-00-00
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1122] serial_no:80df25000000
[20240606-10:58:33.846 D 1570] tuya_ipc_wifi_api.c 1028: Set Country Code:(null) 
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1153] gw_cntl.gw_wsm.stat:0
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:648] <__gw_upd_nc_type> bcustom_mode:0, old_wf_start_mode: 0
[01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1345] gw_cntl->gw_wsm.nc_tp:2
[01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1346] gw_cntl->gw_wsm.md:0
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[01-01 18:12:15 TUYA D][ws_db_gw.c:515] gw_di read success
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][tuya_devos_entry.c:770] stride from flash: 0.
[01-01 18:12:15 TUYA D][tuya_devos_entry.c:777] no actived, no upgrade:0
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1212] gw_cntl.gw_if.abi:0 input:0
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1213] gw_cntl.gw_if.product_key:alsqsx6kcoqznl72, input:alsqsx6kcoqznl72
[01-01 18:12:15 TUYA N][tuya_devos_entry.c:1214] gw_cntl.gw_if.tp:0, input:0
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:4 gw_ai
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[01-01 18:12:15 TUYA D][ws_db_gw.c:640] gw_ai read success
[01-01 18:12:15 TUYA D][uni_network.c:417] set_dns_region:0
[01-01 18:12:15 TUYA D][tuya_devos_entry.c:1780] enter success_proc
[01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.41\"},\"hardware\":{\"toolchain\":\"arm-gcc6.3-linux-uclibceabi\",\"cpu\":{\"model\":\"ARMv7 Processor rev 5 (v7l)\",\"bogomips\":\"100.00\",\"name\":\"Generic DT based system\"}}
[01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:117] sys add timer: 13
[01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:123] sys start timer: 13
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:alsqsx6kcoqznl72 0
uuid: 20
dev_id_tmp: 16
dev_id_tmp2: 20
[01-01 18:12:15 TUYA T][tuya_ble_api.c:415] upd product_id type:0 alsqsx6kcoqznl72 hhws92211069322dcd07 Q7MUANuycemR7MULRSvgMdNRpdfGvhBl
[20240606-10:58:34.191 D 1570] tuya_ipc_wifi_api.c 707: hwl_wf_get_mac
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[20240606-10:58:34.214 D 1570] tuya_ipc_wifi_api.c 738: WIFI Get MAC 00-00-00-00-00-00
[01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1064] nc_tp:2, md:0
[01-01 18:12:15 TUYA D][tuya_iot_wifi_api.c:415] register wifi network monitor. interval:1
Dbg:[IPC_APP_Init_SDK]--[428] tuya_ipc_start_sdk Success!
Dbg:[IPC_APP_Init_SDK]--[431] tuyaRegisterSta ==== 0!
[01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[20240606-10:58:34.216 D 1578] tuya_ipc_wifi_api.c 183: Exec Cmd:ifconfig wlan0 up 
[20240606-10:58:34.217 D 1570] tuyap2p.c 447: create file=/mnt/flash/data/noneed_silent_reboot success!!!
[20240606-10:58:34.238 I 1570] hank_wifi_cfg80211.c 2075: Wifi_Scan wifiDriver_mode ==== 0 gs_sta.s_fd === -1
[20240606-10:58:34.239 I 1570] hank_wifi_cfg80211.c 2155: Wifi_Scan hotspotNum 58
Dbg:Wifi_HotspotList.num ==== 58
[20240606-10:58:34.239 D 1570] tuya_ipc_qrcode_api.c 186: set_qrConfig_startus qrCodeEnable === 1
[qr_vpss_depthSetting]---[3229 ] vpssChn ==== 1 u32Depth === 1
[20240606-10:58:34.254 I 1570] hank_image_manage_API.c 1933: get exposure_config.cEXP=56
[20240606-10:58:34.254 D 1570] tuya_ipc_qrcode_api.c 191: [set_qrConfig_Enable]---[191] expValue ============ 56
[20240606-10:58:34.255 D 1570] hank_alarm.c 4759: hank_Play_AudioFile pri 2, file /mnt/flash/Server/resource/audio/cn/3.g711u, repeat 1, duration -1, block 1
[20240606-10:58:34.255 D 1570] hank_audio_manage_API.c 367: hiapp : symbol=SAMPE,value=1,len=4
[20240606-10:58:34.256 I 1395] mw_isp_api.c 5585: sdk_app set ExposureAttr Compensation=24
[20240606-10:58:34.256 D 1395] mw_enc_api.c 3281: [mw_set_audioamplifier_enable] amplifier_enable:1
[20240606-10:58:34.257 D 1395] stream_reader.c 161: audio swtich ON AUDIO_CTRL:1
[20240606-10:58:34.266 D 1578] tuya_ipc_wifi_api.c 768: hwl_wf_wk_mode_set current mode 3
[20240606-10:58:34.267 D 1578] tuya_ipc_wifi_api.c 803: WIFI Set Mode 3
[20240606-10:58:34.267 D 1578] tuya_ipc_wifi_api.c 993: cfg->ssid:SmartLife-0000 passwd=
[20240606-10:58:34.267 D 1578] tuya_ipc_wifi_api.c 994: cfg->ip:192.168.175.1 mask=255.255.255.0 gw=192.168.175.1
[20240606-10:58:34.358 D 1570] hank_alarm.c 4454: hank_Play_AudioFile_now begin /mnt/flash/Server/resource/audio/cn/3.g711u
[20240606-10:58:34.380 D 1569] tuya_ipc_qrcode_api.c 61: fixed QR to 640 * 360
[20240606-10:58:34.603 D 1578] tuya_ipc_wifi_api.c 1006: Start AP SSID:SmartLife-0000 
[01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-0000
[01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:18432,priority:5
[01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt netcfg start
[01-01 18:12:16 TUYA N][tuya_ble_api.c:439] update bound stat:0
[01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
dev id key: 16
5b 0b 51 12 96 74 91 c1 51 e2 aa b7 2d b9 3a 0a 
[20240606-10:58:34.607 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:34.670 D 1578] bt_ext_porting.c 506: wei bt_test tuya_ext_bt_reset_adv adv->len:28, scan_resp->len:30...
[20240606-10:58:34.679 D 1578] bt_ext_porting.c 511: reset adv: 
2 1 6 3 2 1 a2 14 16 1 a2 0 61 6c 73 71 73 78 36 6b 63 6f 71 7a 6e 6c 37 32 
[20240606-10:58:34.680 D 1578] bt_ext_porting.c 513: resp: 
3 9 54 59 19 ff d0 7 1 3 3 0 c 0 d7 b7 5c c2 81 e0 56 9b 7f e1 9a 8 3f 5d 48 b4 
[01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
killall: lbh_server: no process killed
start aic8800 ble server
[   71.075418] aic_btusb: AICBT_RELEASE_NAME: 202012_ANDROID
[   71.081523] aic_btusb: AicSemi Bluetooth USB driver module init, version 2.1.0
[   71.089947] aic_btusb: RELEASE DATE: 2023_0313_2254 
[   71.089947] 
[   71.096898] aic_btusb: Register usb char device interface for BT driver
[   71.104210] aic_btusb: btusb_probe: usb_interface c23e5000, bInterfaceNumber 0, idVendor 0xa69c, idProduct 0x8d81
[   71.115149] aicwf_usb_chipmatch USE AIC8800D80
[   71.119777] endpoint num 4
[   71.122539] endpoint num 1
[   71.125240] endpoint num 2
[   71.128497] aic_btusb: firmware_info_init: Auto suspend is disabled
[   71.134868] aic_btusb: btusb_probe: download begining...
[   71.140179] aic_btusb: btusb_probe: download ending...
[   71.145444] aic_btusb: btusb_probe: Check bt reset flag 0
[   71.151551] usbcore: registered new interface driver aic_btusb
[20240606-10:58:35.111 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:16 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
bt_hci_tool server setting
use USB
[   71.353948] aic_btusb:  btchr_ioctl DOWN_FW_CFG with Cmd:1074021808
[   71.363590] aic_btusb:  btchr_ioctl DOWN_FW_CFG
[   71.368794] aic_btusb: btusb_open: Start
[   71.372979] aic_btusb: btusb_open: End
[   71.410183] aic_btusb:  btchr_ioctl DOWN_FW_CFG with Cmd:-2147203660
[   71.416715] aic_btusb:  btchr_ioctl GET_USB_INFO
[   71.421378] aic_btusb: btusb_open: Start
[   71.425316] aic_btusb: btusb_open: End
[20240606-10:58:35.330 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
bt dev open successful
support ble  
bt device test ok 
app queue_ th wait connect accept
hci recv thread ready (nil)
[20240606-10:58:35.459 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
app_ble_init
app_smartconfig_init
bt stack thread ready3 (nil) 
 do notify
recv_len 4
COMMAND(4): 
01 03 0C 00 
txdone 1 
offset 4 recv_len 0
 do tx done
read byte(7): type 4
04 0E 04 05 03 0C 00 
recv_len 12
COMMAND(12): 
01 01 0C 08 FF FF FF FF FF 9F 00 20 
txdone 1 
offset 12 recv_len 0
 do notify
 do tx done
04 0E 04 05 01 0C 00 
 do notify
recv_len 12
COMMAND(12): 
01 01 20 08 FF FF 0F 00 00 00 00 00 
txdone 1 
 do tx done
04 0E 04 05 01 20 00 
 do notify
recv_len 4
COMMAND(4): 
01 02 20 00 
txdone 1 
offset 4 recv_len 0
 do tx done
read byte(10): type 4
04 0E 07 05 02 20 00 FB 00 0E 
recv_len 4
COMMAND(4): 
01 3A 20 00 
txdone 1 
offset 4 recv_len 0
 do notify
 do tx done
[20240606-10:58:35.660 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
read byte(9): type 4
04 0E 06 05 3A 20 00 F6 04 
hci_le_read_max_adv_data_len_cmd_cmp_evt_handler 8
rd max adv data len 1270
recv_len 4
COMMAND(4): 
01 3B 20 00 
txdone 1 
offset 4 recv_len 0
 do notify
 do tx done
read byte(8): type 4
04 0E 05 05 3B 20 00 06 
recv_len 10
COMMAND(10): 
01 01 FC 06 00 00 50 40 20 04 
txdone 1 
offset 10 recv_len 0
read byte(12): type 4
04 0E 09 05 01 FC 00 04 20 88 07 73 
is ok
 do notify
 do tx done
recv_len 7
COMMAND(7): 
01 31 20 03 03 00 00 
txdone 1 
offset 7 recv_len 0
 do tx done
04 0E 04 05 31 20 00 
 do notify
recv_len 8
COMMAND(8): 
01 4D 20 04 00 00 00 00 
txdone 1 
offset 8 recv_len 0
 do tx done
04 0E 04 05 4D 20 00 
 do notify
recv_len 8
COMMAND(8): 
01 24 20 04 1B 00 48 01 
txdone 1 
offset 8 recv_len 0
 do tx done
04 0E 04 05 24 20 00 
BLE: ble_user_add_svc_cb
smartconfig_init 
Found 2 characteristics
Fetched 2 characteristics.
Database: 
uuid: 0x00 0x28 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 
perm: 0x00000200
ext perm: 0x00000000
max len: 0x00000000
uuid: 0x03 0x28 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 
perm: 0x00000200
max len: 0x00000000
uuid: 0xfb 0x34 0x9b 0x5f 0x80 0x00 0x00 0x80 0x00 0x10 0x00 0x00 0x11 0x2b 0x00 0x00 
perm: 0x00000400
ext perm: 0x0000c000
max len: 0x000000c8
perm: 0x00000200
max len: 0x00000000
uuid: 0xfb 0x34 0x9b 0x5f 0x80 0x00 0x00 0x80 0x00 0x10 0x00 0x00 0x10 0x2b 0x00 0x00 
perm: 0x00001000
max len: 0x000000c8
uuid: 0x02 0x29 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 
perm: 0x00000a00
max len: 0x00000000
gapm_profile_added_ind_handler
ble_s_to_c send(0,0): 
recv_len 36
COMMAND(36): 
01 17 20 20 67 45 8B 6B C6 23 7B 32 69 98 3C 64 73 48 33 66 51 DC B0 74 FF 5C 49 19 4A 94 E8 2A EC 58 55 62 
txdone 1 
offset 36 recv_len 0
read byte(23): type 4
04 0E 14 05 17 20 00 1C E6 DA 1A 3D 49 C6 FD AF 9F 53 66 75 FE F8 08 
recv_len 36
COMMAND(36): 
01 17 20 20 29 1F 8E 23 CD 7C E8 46 BA 58 1B 3D AB D7 7E 50 F2 41 B1 2E FB 1E B7 41 E3 A9 E2 79 46 E1 45 75 
txdone 1 
04 0E 14 05 17 20 00 C5 6F E3 2B 1C F5 79 FD A7 4E 6C 78 40 70 0C FC 
 do notify
 do tx done
[20240606-10:58:35.913 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:36.047 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:36.167 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:17 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:36.280 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:36.393 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:36.506 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:36.625 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:36.746 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:36.865 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:36.990 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:37.100 D 1578] bt_ext_porting.c 118: MAC address = 
002a2a000701
[20240606-10:58:37.100 D 1578] bt_ext_porting.c 536: ==============mac ret=============
00 2A 2A 00 07 01 
[20240606-10:58:37.101 D 1578] bt_ext_porting.c 543: ==============mac end=============
[01-01 18:12:18 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[01-01 18:12:18 TUYA D][tuya_iot_wifi_api.c:381] wifi netstat changed to:2  -->>
Dbg:__IPC_APP_Get_Net_Status_cb Net status change to:2
[01-01 18:12:18 TUYA D][tuya_iot_wifi_api.c:384] wifi netstat changed to:2  <<--
[20240606-10:58:37.120 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:18 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:37.234 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:37.342 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:37.487 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:37.579 D 1570] hank_alarm.c 4574: hank_Play_AudioFile_now /mnt/flash/Server/resource/audio/cn/3.g711u end
[20240606-10:58:37.579 D 1570] hank_alarm.c 4575: total_data_len 24000, play_time 2905, audio_time 3000
[20240606-10:58:37.580 D 1570] tuyap2p.c 487: hk_tuya_net_prompt =
[01-01 18:12:19 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
dev id key: 16
[20240606-10:58:37.580 D 1570] bt_ext_porting.c 434: wei bt_test tuya_ext_bt_port_init ptr:0xabb31e54...
[20240606-10:58:37.581 D 1570] bt_ext_porting.c 439: tuya ext bt port init
[01-01 18:12:19 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[20240606-10:58:37.581 D 1618] bt_ext_porting.c 421: wei bt_test BLE start run ok
app_queue_reg_callback 
client version :v 0.1.0
app_q_client_socket  7
app_q_server_socket connect OK
client recv_len 3
recv_num_len 0,  recv_num_offset 0
[20240606-10:58:37.586 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
00 00 
[20240606-10:58:37.586 D 1618] lbh_ble.c 53: ****msg.msg_id:0
msg send(4,28): 
 app_queue_done on 
 queue_recv_len 31
0x4  0x1c  0x0  0x2  0x1  0x6  0x3  0x2  0x1  0xa2  0x14  0x16  0x1  0xa2  0x0  0x61  0x6c  0x73  0x71  0x73  0x78  0x36  0x6b  0x63  0x6f  0x71  0x7a  0x6e  0x6c  0x37  0x32  
 recv_s_len 28,  recv_s_offset 0
APP:ble_only_msg id:4 ,len = 28 
APP: msg id:4 :status:0 exit
ble_s_to_c send(1,0): 
queue_recv_len 0
send ok 31  
msg send(18,30): 
 app_queue_done on 
 queue_recv_len 33
0x12  0x1e  0x0  0x3  0x9  0x54  0x59  0x19  0xff  0xd0  0x7  0x1  0x3  0x3  0x0  0xc  0x0  0xd7  0xb7  0x5c  0xc2  0x81  0xe0  0x56  0x9b  0x7f  0xe1  0x9a  0x8  0x3f  0x5d  0x48  0xb4  
 recv_s_len 30,  recv_s_offset 0
APP:ble_only_msg id:18 ,len = 30 
APP: msg id:18 :status:0 exit
queue_recv_len 0
send ok 33  
msg send(19,2): 
 app_queue_done on 
 queue_recv_len 5
0x13  0x2  0x0  0x54  0x59  
 recv_s_len 2,  recv_s_offset 0
APP:ble_only_msg id:19 ,len = 2 
APP: msg id:19 :status:0 exit
queue_recv_len 0
send ok 5  
msg send(17,6): 
 app_queue_done on 
 queue_recv_len 9
0x11  0x6  0x0  0x1  0x7  0x0  0x2a  0x2a  0x0  
 recv_s_len 6,  recv_s_offset 0
APP:ble_only_msg id:17 ,len = 6 
set bt addr is:  0x1 0x7 0x0 0x2a 0x2a 0x0 
APP: msg id:17 :status:0 exit
queue_recv_len 0
recv_len 10
COMMAND(10): 
01 70 FC 06 01 07 00 2A 2A 00 
txdone 1 
gapm_dev_set_bt_addr_cmd_handler
 do notify
 do tx done
send ok 9  
04 0E 04 05 70 FC 00 
!!!!!!!!  set bt addr  complete
 do notify
[20240606-10:58:37.600 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
msg send(5,9): 
 app_queue_done on 
 queue_recv_len 12
0x5  0x9  0x0  0xa0  0x0  0x0  0x0  0xa0  0x0  0x0  0x0  0xa  
 recv_s_len 9,  recv_s_offset 0
APP:ble_only_msg id:5 ,len = 9 
set  adv param ,min_intv 160,adv_intv_max  160,max_tx_pwr 10
APP: msg id:5 :status:0 exit
queue_recv_len 0
send ok 12  
msg send(9,0): 
 app_queue_done on 
 queue_recv_len 3
0x9  0x0  0x0  
 recv_s_len 0,  recv_s_offset 0
APP:ble_only_msg id:9 ,len = 0 
appm_adv_fsm_next,adv_state 0
APP: msg id:9 :status:0 exit
queue_recv_len 0
gapm_activity_create_cmd_handler, 0
gapm_adv_check_param, error = 0 ,0
gapm_adv_create, 0
gapm_adv_send_hci_le_set_ext_adv_param_cmd,0,13,a0,0,0,a0,0,0
 2: 0,0,0,0,0,0,a,0
recv_len 29
COMMAND(29): 
01 36 20 19 00 13 00 A0 00 00 A0 00 00 07 00 00 00 00 00 00 00 00 00 0A 01 00 00 00 00 
txdone 1 
offset 29 recv_len 0
 do notify
 do tx done
04 0E 05 05 36 20 00 08 
hci_le_cmd_cmp_evt_creating_handler ,state 0
gapm_cmp_evt_handler op 0xa0, adv_op a0, scan_op 0,init_op 0
appm_adv_fsm_next,adv_state 1
appm_set_adv_data, adv_data_len = 28
appm_set_adv_data, adv_param.type = 0
appm_set_adv_data, adv_state = 2
recv_len 36
COMMAND(36): 
01 37 20 20 00 03 00 1C 02 01 06 03 02 01 A2 14 16 01 A2 00 61 6C 73 71 73 78 36 6B 63 6F 71 7A 6E 6C 37 32 
txdone 1 
 do notify
 do tx done
send ok 3  
[20240606-10:58:37.613 D 1618] lbh_ble.c 73: BLE  INITIATIVE  DONE
[20240606-10:58:37.949 D 1618] lbh_ble.c 78: ptuyaEventCallback TY_BT_EVENT_ADV_READY
[01-01 18:12:19 TUYA D][tuya_ble_api.c:543] rev ble event 3
client recv_len 18
[20240606-10:58:37.949 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
01 00 
[20240606-10:58:37.950 D 1618] lbh_ble.c 53: ****msg.msg_id:1
[20240606-10:58:37.950 D 1618] lbh_ble.c 84: BLE_CLEITN_MSG_SEND_DONE
recv_num_len 0,  recv_num_offset 3
[20240606-10:58:37.950 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
01 00 
recv_num_len 0,  recv_num_offset 6
01 00 
recv_num_len 0,  recv_num_offset 9
01 00 
[20240606-10:58:37.951 D 1618] lbh_ble.c 84: BLE_CLEITN_MSG_SEND_DONE
recv_num_len 0,  recv_num_offset 12
[20240606-10:58:37.951 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
01 00 
[20240606-10:58:37.951 D 1618] lbh_ble.c 53: ****msg.msg_id:1
recv_num_len 0,  recv_num_offset 15
01 00 
04 0E 04 05 37 20 00 
gapm_cmp_evt_handler op 0xa9, adv_op a9, scan_op 0,init_op 0
appm_adv_fsm_next,adv_state 2
appm_set_scan_rsp_data, scan_res_len = 30
 do notify
[20240606-10:58:37.732 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
recv_len 38
COMMAND(38): 
01 38 20 22 00 03 00 1E 03 09 54 59 19 FF D0 07 01 03 03 00 0C 00 D7 B7 5C C2 81 E0 56 9B 7F E1 9A 08 3F 5D 48 B4 
txdone 1 
offset 38 recv_len 0
 do tx done
04 0E 04 05 38 20 00 
gapm_cmp_evt_handler op 0xaa, adv_op aa, scan_op 0,init_op 0
appm_adv_fsm_next,adv_state 3
 do notify
recv_len 10
COMMAND(10): 
01 39 20 06 01 01 00 00 00 00 
txdone 1 
 do tx done
04 0E 04 05 39 20 00 
gapm_cmp_evt_handler op 0xa4, adv_op a4, scan_op 0,init_op 0
appm_adv_fsm_next,adv_state 5
ble_s_to_c send(2,0): 
 do notify
client recv_len 3
[20240606-10:58:37.967 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
02 00 
[20240606-10:58:37.967 D 1618] lbh_ble.c 53: ****msg.msg_id:2
[20240606-10:58:37.967 D 1618] lbh_ble.c 87: BLE_ADV_ENABLE
[20240606-10:58:38.070 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:38.190 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:19 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:38.310 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:38.424 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:38.542 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:38.700 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:38.820 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:38.931 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:39.033 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:39.142 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:39.249 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:20 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:39.363 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:39.486 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:39.603 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:39.730 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:39.839 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:39.939 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:40.049 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:40.166 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:21 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:40.285 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:40.401 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:40.509 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:40.629 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:40.739 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:40.890 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:41.005 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:41.110 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:41.230 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:22 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:41.350 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
read byte(34): type 4
04 3E 1F 0A 00 11 00 01 01 2B BF 1A E9 7F 53 00 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 F4 01 05 
ble_app_connection_cb connect 0
ble_s_to_c send(7,18): 
11 00 24 00 00 00 F4 01 05 01 2B BF 1A E9 7F 53 01 00 
 do notify
client recv_len 21
recv_num_len 18,  recv_num_offset 0
[20240606-10:58:41.433 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:20):
07 12 11 00 24 00 00 00 F4 01 05 01 2B BF 1A E9 7F 53 01 00 
[20240606-10:58:41.433 D 1618] lbh_ble.c 53: ****msg.msg_id:7
[20240606-10:58:41.433 D 1618] lbh_ble.c 131: BLE_CONNECTION conhdl 0x11,interval 36, peer_addr_type 1,addr: 0x2b,0xbf,0x1a,0xe9,0x7f,0x53 
04 3E 04 14 11 00 00 
 do notify
04 3E 06 12 00 00 11 00 00 
## gapm_activity_stopped_ind_handler app_env.adv_state 7
appm_adv_fsm_next,adv_state 7
ble_s_to_c send(3,0): 
 do notify
[20240606-10:58:41.490 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
msg send(16,4): 
send ok 7  
[20240606-10:58:41.540 D 1618] lbh_ble.c 136: ptuyaEventCallback TY_BT_EVENT_CONNECTED
[01-01 18:12:23 TUYA D][tuya_ble_api.c:543] rev ble event 1
[01-01 18:12:23 TUYA N][tuya_ble_api.c:472] Ble Connected
[01-01 18:12:23 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[01-01 18:12:23 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
client recv_len 3
[20240606-10:58:41.541 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
03 00 
[20240606-10:58:41.541 D 1618] lbh_ble.c 53: ****msg.msg_id:3
[20240606-10:58:41.541 D 1618] lbh_ble.c 90: BLE_ADV_DISABLE
 app_queue_done on 
 queue_recv_len 7
0x10  0x4  0x0  0x80  0x0  0x0  0x2  
 recv_s_len 4,  recv_s_offset 0
APP:ble_only_msg id:16 ,len = 4 
ble set data len  tx_octets 128 ,tx_time 0x200
APP: msg id:16 :status:0 exit
queue_recv_len 0
 do notify
recv_len 10
COMMAND(10): 
01 22 20 06 11 00 80 00 00 02 
txdone 1 
 do tx done
04 0E 06 05 22 20 00 11 00 
 do notify
client recv_len 3
[20240606-10:58:41.553 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
01 00 
[20240606-10:58:41.553 D 1618] lbh_ble.c 53: ****msg.msg_id:1
[20240606-10:58:41.553 D 1618] lbh_ble.c 84: BLE_CLEITN_MSG_SEND_DONE
[20240606-10:58:41.610 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
read byte(14): type 4
04 3E 0B 07 11 00 80 00 00 02 1B 00 48 01 
ble_s_to_c send(12,8): 
 do notify
client recv_len 11
recv_num_len 8,  recv_num_offset 0
[20240606-10:58:41.650 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:10):
0C 08 80 00 00 02 1B 00 48 01 
[20240606-10:58:41.650 D 1618] lbh_ble.c 53: ****msg.msg_id:12
[20240606-10:58:41.650 D 1618] lbh_ble.c 172: BLE_PKT_SIZE_IND max_rx_octets 0x1b ,max_rx_time 0x148 ,max_tx_octets 0x80 ,max_tx_time 0x200
[20240606-10:58:41.730 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:41.841 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
read byte(16): type 2
 do notify
recv_len 14
COMMAND(14): 
02 11 00 09 00 05 00 04 00 01 08 01 00 0A 
txdone 1 
offset 14 recv_len 0
 do tx done
[20240606-10:58:42.005 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
04 13 05 01 11 00 01 00 
 do notify
[20240606-10:58:42.131 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
 do notify
recv_len 29
COMMAND(29): 
02 11 00 18 00 14 00 04 00 11 06 01 00 07 00 00 18 08 00 0B 00 01 18 0C 00 11 00 10 19 
txdone 1 
 do tx done
[20240606-10:58:42.244 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:23 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
 do notify
04 3E 0B 06 11 00 06 00 06 00 00 00 F4 01 
ble_app_update_con_params_cb con param update 6 500
ble_s_to_c send(9,8): 
 do notify
client recv_len 11
[20240606-10:58:42.344 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:10):
09 08 06 00 06 00 00 00 F4 01 
[20240606-10:58:42.344 D 1618] lbh_ble.c 53: ****msg.msg_id:9
[20240606-10:58:42.345 D 1618] lbh_ble.c 158: BLE_CONNECTION_PARAM_UPDATE intv_min 0x6 ,intv_max 0x6, latency 0x0,time_out 0x1f4
recv_len 18
COMMAND(18): 
01 20 20 0E 11 00 06 00 06 00 00 00 F4 01 00 00 00 00 
txdone 1 
offset 18 recv_len 0
 do tx done
 do notify
recv_len 14
COMMAND(14): 
02 11 00 09 00 05 00 04 00 01 10 12 00 0A 
txdone 1 
 do tx done
04 0E 06 05 20 20 00 11 00 
 do notify
 do notify
[20240606-10:58:42.370 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
 do notify
recv_len 14
COMMAND(14): 
txdone 1 
 do tx done
 do notify
[20240606-10:58:42.502 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
 do notify
recv_len 32
COMMAND(32): 
02 11 00 1B 00 17 00 04 00 09 07 02 00 0A 03 00 00 2A 04 00 02 05 00 01 2A 06 00 02 07 00 C9 2A 
txdone 1 
offset 32 recv_len 0
 do tx done
[20240606-10:58:42.634 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
 do notify
[20240606-10:58:42.741 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
read byte(13): type 4
04 3E 0A 03 00 11 00 06 00 00 00 F4 01 
ble_s_to_c send(15,6): 
06 00 00 00 F4 01 
 do notify
client recv_len 9
recv_num_len 6,  recv_num_offset 0
[20240606-10:58:42.770 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:8):
0F 06 06 00 00 00 F4 01 
[20240606-10:58:42.770 D 1618] lbh_ble.c 53: ****msg.msg_id:15
[20240606-10:58:42.770 D 1618] lbh_ble.c 184: BLE_CON_UPDATE_CMP_DONE ,interval 0x6, latency 0x0, to 0x1f4
recv_len 14
COMMAND(14): 
02 11 00 09 00 05 00 04 00 01 08 07 00 0A 
txdone 1 
 do notify
 do tx done
 do notify
 do notify
recv_len 14
COMMAND(14): 
02 11 00 09 00 05 00 04 00 01 08 08 00 0A 
txdone 1 
 do tx done
 do notify
 do notify
recv_len 18
COMMAND(18): 
02 11 00 0D 00 09 00 04 00 09 07 09 00 22 0A 00 05 2A 
txdone 1 
 do tx done
 do notify
 do notify
recv_len 14
COMMAND(14): 
02 11 00 09 00 05 00 04 00 01 08 0A 00 0A 
txdone 1 
 do tx done
read byte(14): type 2
recv_len 15
COMMAND(15): 
02 11 00 0A 00 06 00 04 00 05 01 0B 00 02 29 
txdone 1 
offset 15 recv_len 0
[20240606-10:58:42.890 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
 do notify
 do tx done
 do notify
recv_len 14
COMMAND(14): 
02 11 00 09 00 05 00 04 00 01 08 0C 00 0A 
txdone 1 
 do tx done
 do notify
 do notify
recv_len 25
COMMAND(25): 
02 11 00 14 00 10 00 04 00 09 07 0D 00 04 0E 00 11 2B 0F 00 10 10 00 10 2B 
txdone 1 
offset 25 recv_len 0
 do tx done
 do notify
recv_len 14
COMMAND(14): 
02 11 00 09 00 05 00 04 00 01 08 10 00 0A 
txdone 1 
recv_len 15
COMMAND(15): 
02 11 00 0A 00 06 00 04 00 05 01 11 00 02 29 
txdone 1 
 do notify
 do tx done
[20240606-10:58:43.040 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
04 3E 0B 06 11 00 24 00 24 00 00 00 F4 01 
ble_app_update_con_params_cb con param update 36 500
 do notify
client recv_len 11
[20240606-10:58:43.049 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:10):
09 08 24 00 24 00 00 00 F4 01 
[20240606-10:58:43.050 D 1618] lbh_ble.c 53: ****msg.msg_id:9
[20240606-10:58:43.050 D 1618] lbh_ble.c 158: BLE_CONNECTION_PARAM_UPDATE intv_min 0x24 ,intv_max 0x24, latency 0x0,time_out 0x1f4
recv_len 18
COMMAND(18): 
01 20 20 0E 11 00 24 00 24 00 00 00 F4 01 00 00 00 00 
txdone 1 
 do tx done
ble_s_to_c send(14,17): 
FB 34 9B 5F 80 00 00 80 00 10 00 00 10 2B 00 00 01 
client recv_len 20
recv_num_len 17,  recv_num_offset 0
[20240606-10:58:43.063 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:19):
0E 11 FB 34 9B 5F 80 00 00 80 00 10 00 00 10 2B 00 00 01 
[20240606-10:58:43.064 D 1618] lbh_ble.c 53: ****msg.msg_id:14
[20240606-10:58:43.064 D 1618] lbh_ble.c 179: BLE_IND_SENT_DONE
recv_len 10
COMMAND(10): 
02 11 00 05 00 01 00 04 00 13 
txdone 1 
 do notify
 do tx done
 do notify
 do notify
04 3E 0A 03 00 11 00 24 00 00 00 F4 01 
24 00 00 00 F4 01 
 do notify
client recv_len 9
[20240606-10:58:43.182 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:8):
0F 06 24 00 00 00 F4 01 
[20240606-10:58:43.182 D 1618] lbh_ble.c 53: ****msg.msg_id:15
[20240606-10:58:43.182 D 1618] lbh_ble.c 184: BLE_CON_UPDATE_CMP_DONE ,interval 0x24, latency 0x0, to 0x1f4
[20240606-10:58:43.193 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[01-01 18:12:24 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:43.313 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
[20240606-10:58:43.422 D 1569] tuya_ipc_qrcode_api.c 76: qrFileName /tmp/qrcode.yuv fileLength 230400
read byte(32): type 2
ble_s_to_c send(11,36): 
FB 34 9B 5F 80 00 00 80 00 10 00 00 11 2B 00 00 00 21 20 01 E0 92 8A F1 B1 03 E3 1C 29 7F 5C 76 0E BA 52 C2 
 do notify
client recv_len 39
recv_num_len 36,  recv_num_offset 0
[20240606-10:58:43.489 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:38):
0B 24 FB 34 9B 5F 80 00 00 80 00 10 00 00 11 2B 00 00 00 21 20 01 E0 92 8A F1 B1 03 E3 1C 29 7F 5C 76 0E BA 52 C2 
[20240606-10:58:43.490 D 1618] lbh_ble.c 53: ****msg.msg_id:11
[20240606-10:58:43.490 D 1618] lbh_ble.c 119: ptuyaEventCallback TY_BT_EVENT_RX_DATA
[01-01 18:12:25 TUYA D][tuya_ble_api.c:543] rev ble event 2
[01-01 18:12:25 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
bt_rev_raw 19
21 20 01 e0 92 8a f1 b1 03 e3 1c 29 7f 5c 76 0e ba 52 c2 
[01-01 18:12:25 TUYA E][tuya_ble_data_handler.c:568] ble_data_unpack err:-7937
[20240606-10:58:43.491 D 1618] lbh_ble.c 123: BLE_SMARTCONFIG_DATA_RECV
[20240606-10:58:43.496 D 1619] hank_alarm.c 4759: hank_Play_AudioFile pri 2, file /mnt/flash/Server/resource/audio/cn/14.g711u, repeat 1, duration -1, block 1
[20240606-10:58:43.496 D 1619] hank_audio_manage_API.c 367: hiapp : symbol=SAMPE,value=1,len=4
[20240606-10:58:43.499 D 1395] mw_enc_api.c 3281: [mw_set_audioamplifier_enable] amplifier_enable:1
read byte(29): type 2
ble_s_to_c send(11,33): 
FB 34 9B 5F 80 00 00 80 00 10 00 00 11 2B 00 00 01 BC 9B ED D3 9F BA 46 A9 BB 96 0A 8E 4C 6A AB 59 
client recv_len 36
recv_num_len 33,  recv_num_offset 0
[20240606-10:58:43.542 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:35):
0B 21 FB 34 9B 5F 80 00 00 80 00 10 00 00 11 2B 00 00 01 BC 9B ED D3 9F BA 46 A9 BB 96 0A 8E 4C 6A AB 59 
[20240606-10:58:43.543 D 1618] lbh_ble.c 53: ****msg.msg_id:11
[20240606-10:58:43.544 D 1618] lbh_ble.c 119: ptuyaEventCallback TY_BT_EVENT_RX_DATA
bt_rev_raw 16
bc 9b ed d3 9f ba 46 a9 bb 96 0a 8e 4c 6a ab 59 
[20240606-10:58:43.544 D 1618] lbh_ble.c 123: BLE_SMARTCONFIG_DATA_RECV
 do notify
[20240606-10:58:43.609 D 1619] hank_alarm.c 4454: hank_Play_AudioFile_now begin /mnt/flash/Server/resource/audio/cn/14.g711u
[01-01 18:12:25 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:26 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:45.378 D 1619] hank_alarm.c 4574: hank_Play_AudioFile_now /mnt/flash/Server/resource/audio/cn/14.g711u end
[20240606-10:58:45.379 D 1619] hank_alarm.c 4575: total_data_len 14400, play_time 1705, audio_time 1800
04 3E 06 0C 00 11 00 02 02 
 do notify
[01-01 18:12:27 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:28 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:29 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:49.059 I 1181] hank_parameter.c 326: [hk_parameter_get_ro_int] kbpsCheckEnable=0
[01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[01-01 18:12:30 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:31 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[20240606-10:58:50.698 D 1391] stream_reader.c 171: audio swtich OFF AUDIO_CTRL:1
[01-01 18:12:32 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:33 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
04 3E 06 0C 00 11 00 01 02 
 do notify
[01-01 18:12:34 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:35 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[   90.613298] aic_btusb: check_sco_event: HCI_EV_DISCONN_COMPLETE(0x05)
04 05 04 00 11 00 13 
ble_app_disconnect_cb disconnect 17 19
app_smartconfig_disconnected
ble_s_to_c send(8,4): 
11 00 13 00 
 do notify
client recv_len 7
recv_num_len 4,  recv_num_offset 0
[20240606-10:58:54.526 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:6):
08 04 11 00 13 00 
[20240606-10:58:54.526 D 1618] lbh_ble.c 53: ****msg.msg_id:8
[20240606-10:58:54.526 D 1618] lbh_ble.c 143: BLE_DISCONNECT conhdl 0x11 ,reason 0x13 
msg send(9,0): 
send ok 3  
[20240606-10:58:54.526 D 1618] lbh_ble.c 149: ptuyaEventCallback TY_BT_EVENT_DISCONNECTED
[01-01 18:12:36 TUYA D][tuya_ble_api.c:543] rev ble event 0
[01-01 18:12:36 TUYA N][tuya_ble_api.c:485] Ble Disonnected
[01-01 18:12:36 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[01-01 18:12:36 TUYA N][tuya_ble_data_handler.c:78] ble clear pair rand
[01-01 18:12:36 TUYA N][tuya_ble_api.c:1464] ble set conn stat:0
 app_queue_done on 
 queue_recv_len 3
0x9  0x0  0x0  
appm_adv_fsm_next,adv_state 4
queue_recv_len 0
recv_len 10
COMMAND(10): 
txdone 1 
 do notify
 do tx done
client recv_len 3
[20240606-10:58:54.528 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
01 00 
[20240606-10:58:54.528 D 1618] lbh_ble.c 53: ****msg.msg_id:1
[20240606-10:58:54.528 D 1618] lbh_ble.c 84: BLE_CLEITN_MSG_SEND_DONE
 do notify
client recv_len 3
[20240606-10:58:54.569 D 1618] lbh_ble.c 44: client_queue_msg_callback(length:2):
02 00 
[20240606-10:58:54.569 D 1618] lbh_ble.c 53: ****msg.msg_id:2
[20240606-10:58:54.570 D 1618] lbh_ble.c 87: BLE_ADV_ENABLE
[01-01 18:12:36 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:37 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:38 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[01-01 18:12:39 TUYA T][tuya_devos_utils.c:356] get gw ext_stat:2
[END] 2024/6/6 11:04:40
