[BEGIN] 2024/8/7 8:57:08
[2024/8/7 8:58:13 083] 
[2024/8/7 8:58:13 084] resetting ...
[2024/8/7 8:58:13 180] 
[2024/8/7 8:58:13 196] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 8:58:13 196] CPU: XM550V200WX2
[2024/8/7 8:58:13 196] DRAM:  128 MiB
[2024/8/7 8:58:13 307] MMC:   arasan: 0
[2024/8/7 8:58:13 372] In:    serial
[2024/8/7 8:58:13 372] Out:   serial
[2024/8/7 8:58:13 372] Err:   serial
[2024/8/7 8:58:13 580] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 8:58:13 580] Press Ctrl+C to stop autoboot
[2024/8/7 8:58:13 996] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 8:58:13 996] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 8:58:14 012]    Image Name:   Linux-3.10.103+
[2024/8/7 8:58:14 012]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 8:58:14 012]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 8:58:14 012]    Load Address: 80008000
[2024/8/7 8:58:14 012]    Entry Point:  80008000
[2024/8/7 8:58:14 028]    XIP Kernel Image ... OK
[2024/8/7 8:58:14 028] Starting kernel ...
[2024/8/7 8:58:14 908] Uncompressing Linux... done, booting the kernel.
[2024/8/7 8:58:15 035] Booting Linux on physical CPU 0x0
[2024/8/7 8:58:15 051] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 8:58:15 052] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 8:58:15 068] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 8:58:15 068] Machine: xm530v200
[2024/8/7 8:58:15 068] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 8:58:15 084] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 8:58:15 084] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 8:58:15 099] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 8:58:15 099] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 8:58:15 115] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 8:58:15 116] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 8:58:15 116] Memory: 52MB = 52MB total
[2024/8/7 8:58:15 116] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 8:58:15 131] Virtual kernel memory layout:
[2024/8/7 8:58:15 131]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 8:58:15 131]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 8:58:15 132]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 8:58:15 147]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 8:58:15 148]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 8:58:15 148]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 8:58:15 148]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 8:58:15 164]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 8:58:15 164]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 8:58:15 164] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 8:58:15 179] Hierarchical RCU implementation.
[2024/8/7 8:58:15 180] NR_IRQS:128
[2024/8/7 8:58:15 180] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 8:58:15 180] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 8:58:15 195] pid_max: default: 32768 minimum: 301
[2024/8/7 8:58:15 195] Mount-cache hash table entries: 512
[2024/8/7 8:58:15 196] CPU: Testing write buffer coherency: ok
[2024/8/7 8:58:15 196] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 8:58:15 196] L310 cache controller enabled
[2024/8/7 8:58:15 212] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 8:58:15 212] CPU1: Booted secondary processor
[2024/8/7 8:58:15 212] Brought up 2 CPUs
[2024/8/7 8:58:15 212] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 8:58:15 227] CPU: All CPU(s) started in SVC mode.
[2024/8/7 8:58:15 227] NET: Registered protocol family 16
[2024/8/7 8:58:15 227] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 8:58:15 227] Serial: AMBA PL011 UART driver
[2024/8/7 8:58:15 246] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 8:58:15 246] console [ttyAMA0] enabled
[2024/8/7 8:58:15 246] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 8:58:15 260] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 8:58:15 276] bio: create slab <bio-0> at 0
[2024/8/7 8:58:15 276] usbcore: registered new interface driver usbfs
[2024/8/7 8:58:15 292] usbcore: registered new interface driver hub
[2024/8/7 8:58:15 292] usbcore: registered new device driver usb
[2024/8/7 8:58:15 292] Switching to clocksource arm_global_timer
[2024/8/7 8:58:15 308] NET: Registered protocol family 2
[2024/8/7 8:58:15 308] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 8:58:15 308] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 8:58:15 324] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 8:58:15 324] TCP: reno registered
[2024/8/7 8:58:15 324] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 8:58:15 324] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 8:58:15 340] NET: Registered protocol family 1
[2024/8/7 8:58:15 340] RPC: Registered named UNIX socket transport module.
[2024/8/7 8:58:15 340] RPC: Registered udp transport module.
[2024/8/7 8:58:15 340] RPC: Registered tcp transport module.
[2024/8/7 8:58:15 356] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 8:58:15 372] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 8:58:15 372] NFS: Registering the id_resolver key type
[2024/8/7 8:58:15 372] Key type id_resolver registered
[2024/8/7 8:58:15 388] Key type id_legacy registered
[2024/8/7 8:58:15 388] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 8:58:15 388] fuse init (API version 7.22)
[2024/8/7 8:58:15 388] msgmni has been set to 95
[2024/8/7 8:58:15 404] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 8:58:15 404] io scheduler noop registered
[2024/8/7 8:58:15 404] io scheduler deadline registered (default)
[2024/8/7 8:58:15 404] io scheduler cfq registered
[2024/8/7 8:58:15 420] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 8:58:15 420] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 8:58:15 436] uart-pl011 uart:0: no DMA platform data
[2024/8/7 8:58:15 436] uart-pl011 uart:1: no DMA platform data
[2024/8/7 8:58:15 436] uart-pl011 uart:2: no DMA platform data
[2024/8/7 8:58:15 452] brd: module loaded
[2024/8/7 8:58:15 452] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 8:58:15 468] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 8:58:15 468] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 8:58:15 468] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 8:58:15 484] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 8:58:15 484] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 8:58:15 484] 0x000000300000-0x000000730000 : "user"
[2024/8/7 8:58:15 500] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 8:58:15 500] PPP generic driver version 2.4.2
[2024/8/7 8:58:15 500] NET: Registered protocol family 24
[2024/8/7 8:58:15 500] usbcore: registered new interface driver asix
[2024/8/7 8:58:15 516] usbcore: registered new interface driver cdc_ether
[2024/8/7 8:58:15 516] usbcore: registered new interface driver rndis_host
[2024/8/7 8:58:15 516] XMMMAC driver:
[2024/8/7 8:58:15 516] 	platform registration... 
[2024/8/7 8:58:15 516] 	done!
[2024/8/7 8:58:15 532] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 8:58:15 532] 	IO base addr: 0xfe010000)
[2024/8/7 8:58:15 532] libphy: XMMMAC MII Bus: probed
[2024/8/7 8:58:15 532] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 8:58:15 548] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 8:58:15 548] usbcore: registered new interface driver cdc_acm
[2024/8/7 8:58:15 548] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 8:58:15 564] usbcore: registered new interface driver usbserial
[2024/8/7 8:58:15 564] usbcore: registered new interface driver option
[2024/8/7 8:58:15 564] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 8:58:15 580] usbcore: registered new interface driver qcserial
[2024/8/7 8:58:15 580] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 8:58:15 580] TCP: cubic registered
[2024/8/7 8:58:15 580] NET: Registered protocol family 17
[2024/8/7 8:58:15 596] Key type dns_resolver registered
[2024/8/7 8:58:15 596] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 8:58:15 596] registered taskstats version 1
[2024/8/7 8:58:15 612] VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 8:58:15 612] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 8:58:15 964] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 8:58:16 524] arasan_set_clock:
[2024/8/7 8:58:16 540] 	new freq 400000
[2024/8/7 8:58:16 540] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 8:58:16 556] arasan_set_clock:
[2024/8/7 8:58:16 603] 	new freq 300000arasan_set_clock:
[2024/8/7 8:58:16 620] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 8:58:16 620] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 8:58:16 620] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 8:58:16 620] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 8:58:16 636] [reg] = 0x20000078,[val]= 0xc103c0ff
[2024/8/7 8:58:16 636] [reg] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 8:58:16 637] [reg] = 0x20000000,[val]= 0x00arasan_set_clock:
[2024/8/7 8:58:16 637] 	new freq 195312000000
[2024/8/7 8:58:16 637] [reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 8:58:16 652] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 8:58:16 652] [reg] = 0x200505f0,[i2c: module license 'Proprietary' taints kernel.
[2024/8/7 8:58:16 652] val]= 0x00000001
[2024/8/7 8:58:16 652] Disabling lock debugging due to kernel taint
[2024/8/7 8:58:16 668] i2c init is ok!
[2024/8/7 8:58:16 684] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 8:58:16 796] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 8:58:16 876] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 8:58:16 893] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 8:58:16 893] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 8:58:16 924] acodec init is ok!
[2024/8/7 8:58:16 940] i2s clk:2048000Hz
[2024/8/7 8:58:17 083] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 8:58:17 083] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 8:58:17 083] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 8:58:17 083] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 8:58:17 099] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 8:58:17 099] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 8:58:17 099] usb usb1: Product: DWC OTG Controller
[2024/8/7 8:58:17 115] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 8:58:17 115] usb usb1: SerialNumber: dwc2.0
[2024/8/7 8:58:17 115] hub 1-0:1.0: USB hub found
[2024/8/7 8:58:17 115] hub 1-0:1.0: 1 port detected
[2024/8/7 8:58:17 147] xm_wdt init is ok
[2024/8/7 8:58:17 163] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 8:58:17 467] nn_kernel: NN: request mem  fail
[2024/8/7 8:58:17 483] nn_kernel: addr iomap fail
[2024/8/7 8:58:17 515] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 8:58:18 075] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 8:58:18 092] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtusbwifi_init.
[2024/8/7 8:58:18 092] d/user.sh: not fPDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 8:58:18 092] ound
[2024/8/7 8:58:18 107] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 8:58:18 140] exfatfsck 1.3.0
[2024/8/7 8:58:18 140] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 8:58:18 156] exfatfsck 1.3.0
[2024/8/7 8:58:18 156] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 8:58:30 774] ,i¢郑ҁ}¥½н¹̽н±½Ց}։±хʑ5jR´jÒҊȂ¢U 
[2024/8/7 8:58:30 774]                               TµU¹¥}¹ҝ½ɭ¹颂ꚕн¹̽¡}¥½ɥҥ鑪ԤhjÒҊȂ¢U 
[2024/8/7 8:58:30 806]                                                               Tµ댗ҁ¹銪¢郑ҁ}¹́¹烚*¹ىВɽb½¹¥ӚµZ劒Bґɱbr}в±͕񲚉Z劒jƑЕɱbr}в±͕񲚉Z劒BґM±Uɱbr}Ңʕ񲚉Z劒jƑҍM±Uɱbr}Ңʕ񲚉Z劒:¡½ΑUɱbr}Ңʕ𶳵jR´jÒҊȂ¢U 
[2024/8/7 8:58:30 806]        Tµ댗ҁ¹銪˪:сªɱ½¹¥胑ҁΩzzBȲJ½ѵ"¹͹½µ½²ĺªɱ}½¹¥5jR´jÒҊȂ¢U 
[2024/8/7 8:58:30 822]                        Tµҁ¹ꂊ蛵¹¹ҩBȲJ½ѵ"¹͹½µ½ʑ炢¢jj󱫔¤hjÒҊȂ¢U 
[2024/8/7 8:58:30 822]                                                             TµU¹¥}¹ҝ½ɭ¹隊¢ꪹܽѡ½Α幅µBȲJ½ѵ"¹͹½µ±ɥ½j¤ԨH甖­k¬/+V«ԥ*ʉ½ʩª孹½ݹB½Α5RڊjÒҊȂ¢U 
[2024/8/7 8:58:30 838]                                ©TµU¹¥}¹ҝ½ɭ¹隲貅¥±¢½:ѡ½Α幅µj¤ԨHhjÒҊȂ¢U 
[2024/8/7 8:58:30 838]        TµU¹¥}¹ҝ½ɭ¹雊颽ݕȽ¹̽¡}¥½ɥҥ遪ԤhjÒҊȂ¢U 
[2024/8/7 8:58:30 854]     ©Tµҁ¹颪²鳵*¹҉俲½ɁB½ΑBȲJ½ѵ"¹͹½µ2½չ¹jªjԤhjÒҊȂ¢U 
[2024/8/7 8:58:30 854]                                                 ©Tµҁ¹骢꛵­сɕѥ½¹2½ɁBȲJ½ѵ"¹͹½µ颢2¥±5jR´jÒҊȂ¢U 
[2024/8/7 8:58:30 854]        Tµҁ¹ꂊª蛵¹¹ҩBȲJ½ѵ"¹͹½µ½ʑ炢¢jj㠂b誊ªjԤhjÒҊȂ¢U 
[2024/8/7 8:58:30 870]                                    ©Tµҁ}¥¹¹骊麕¹΍¥½¹2¥±灂ґ蹺BȲJ½ѵ"¹͹½µ½²ĺªɱ}½¹¥BjªJjԤhjÒҊȂ¢U 
[2024/8/7 8:58:30 870]        ©Tµ댗ҁ¹銪貅¥±¢½:с±½ՑªɱjªjԤhjÒҊȂ¢U 
[2024/8/7 8:58:31 189]                           TµU¹¥}¹ҝ½ɭ¹颂ꚕн¹̽¡}¥½ɥҥ遪5¡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±a͡±±ÿXshell[1970-01-01 00:00:45] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:31 205] [1970-01-01 00:00:46] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:31 205] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:58:31 221] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:58:31 640] 
[2024/8/7 8:58:31 654] Auto login as root ...
[2024/8/7 8:58:31 702] (none) login: [1970-01-01 00:00:46] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:31 702] [1970-01-01 00:00:46] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:58:31 718] [1970-01-01 00:00:46] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:58:31 734] [1970-01-01 00:00:46] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time16572
[2024/8/7 8:58:31 734] [1970-01-01 00:00:46] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 113554
[2024/8/7 8:58:31 750] [1970-01-01 00:00:46] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:31 750] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:58:31 766] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:58:31 766] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:31 766] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:58:31 782] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:58:31 782] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:31 798] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:58:31 798] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:58:31 798] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:31 814] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:31 814] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:31 830] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:58:31 830] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:58:31 830] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:58:31 862] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:58:31 862] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:58:31 878] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:58:31 878] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:58:31 878] gethostbyname_r error: Unknown host
[2024/8/7 8:58:31 894] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:58:31 894] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:58:31 910] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:58:31 910] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:58:31 925] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:58:31 926] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:58:31 941] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:58:31 941] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:58:31 957] motor auto test over
[2024/8/7 8:58:31 957] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 8:58:31 973] action=idle
[2024/8/7 8:58:31 973] dir=
[2024/8/7 8:58:31 973] flag=|auto-test-cmplt
[2024/8/7 8:58:31 974]  steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 8:58:31 974] YYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 8:58:31 974] action=idle
[2024/8/7 8:58:31 974] dir=
[2024/8/7 8:58:31 974] flag=
[2024/8/7 8:58:31 989]  steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 8:58:32 102] 
[2024/8/7 8:58:32 262] (none) login: [1970-01-01 00:00:46] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:32 262] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 8:58:32 278] [1970-01-01 00:00:47] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:32 278] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:58:32 294] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:58:32 310] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 8:58:32 326] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 8:58:32 726] [1970-01-01 00:00:47] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:32 742] [01-01 18:12:22 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:58:32 742] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:58:32 758] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:32 758] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:58:32 758] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:58:32 774] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:32 774] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:58:32 790] [01-01 18:12:22 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:58:32 790] [01-01 18:12:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:32 790] [01-01 18:12:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:32 806] [01-01 18:12:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:32 806] [01-01 18:12:22 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:58:32 806] [01-01 18:12:22 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:58:32 822] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:58:32 838] [01-01 18:12:22 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:58:32 854] [01-01 18:12:22 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:58:32 854] [01-01 18:12:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:58:32 869] [01-01 18:12:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:58:32 870] 
[2024/8/7 8:58:32 870] gethostbyname_r error: Unknown host
[2024/8/7 8:58:32 870] [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:58:32 886] [01-01 18:12:22 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:58:32 886] [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:58:32 902] [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:58:32 902] [01-01 18:12:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:58:32 918] [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:58:32 918] [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:58:32 918] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:58:32 933] [01-01 18:12:22 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 8:58:33 318] [1970-01-01 00:00:47] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:33 334] [1970-01-01 00:00:48] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:33 334] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:58:33 350] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:58:33 766] ۦ§¦	SS	S$&L'LL8] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:58:33 782] [1970-01-01 00:00:48] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:33 798] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:58:33 798] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:58:33 816] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:33 816] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:58:33 816] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:58:33 832] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:33 832] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:58:33 848] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:58:33 848] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:33 848] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:33 863] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:33 864] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:58:33 879] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:58:33 879] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:58:33 895] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:58:33 911] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:58:33 911] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:58:33 927] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:58:33 927] gethostbyname_r error: Unknown host
[2024/8/7 8:58:33 927] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:58:33 943] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:58:33 943] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:58:33 959] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:58:33 959] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:58:33 975] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:58:33 975] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:58:33 975] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:58:34 384] £«&¦[«LN¦	SS	S$&L'LL9] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:34 401] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 8:58:34 417] [1970-01-01 00:00:49] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:58:34 417] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:58:34 784] [1970-01-01 00:00:49] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:34 801] [1970-01-01 00:00:49] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 8:58:34 816] [1970-01-01 00:00:49] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 8:58:34 816] mpId[0] is [0].
[2024/8/7 8:58:34 816] mpId[1] is [0].
[2024/8/7 8:58:34 816] mpId[2] is [0].
[2024/8/7 8:58:34 816] mpId[3] is [0].
[2024/8/7 8:58:34 816] mpId[4] is [0].
[2024/8/7 8:58:34 816] mpId[5] is [0].
[2024/8/7 8:58:34 832] [1970-01-01 00:00:49] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 8:58:34 849] [1970-01-01 00:00:49] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:58:34 849] [1970-01-01 00:00:49] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:34 865] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:58:34 865] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:58:34 881] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:34 881] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:58:34 881] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:58:34 898] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:34 898] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:58:34 913] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:58:34 913] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:34 913] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:34 929] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:34 929] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:58:34 945] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:58:34 945] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:58:34 961] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:58:34 977] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:58:34 977] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:58:34 993] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:58:34 993] gethostbyname_r error: Unknown host
[2024/8/7 8:58:34 993] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:58:35 009] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:58:35 009] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:58:35 025] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:58:35 025] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:58:35 041] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:58:35 041] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:58:35 041] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:58:35 393] [1970-01-01 00:00:50] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:35 409] [1970-01-01 00:00:50] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:58:35 425] [1970-01-01 00:00:50] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:58:35 425] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:58:35 440] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:58:36 027] K50
[2024/8/7 8:58:36 027] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:58:47 322] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 8:58:47 338] set basic_indicator_onoff:0 
[2024/8/7 8:58:47 338] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:47 354] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:47 354] set basic_indicator_onoff:1 
[2024/8/7 8:58:47 354] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:47 370] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:47 370] set basic_indicator_onoff:0 
[2024/8/7 8:58:47 386] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:47 386] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:47 386] set basic_indicator_onoff:1 
[2024/8/7 8:58:47 402] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:47 402] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:47 418] [01-01 18:12:36 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 8:58:47 818] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 8:58:47 833] Mode(Product):0
[2024/8/7 8:58:47 834] BpuMode:[Online]
[2024/8/7 8:58:47 834] VpssMode:[Online]
[2024/8/7 8:58:47 834] [0.LimitUp_info]:
[2024/8/7 8:58:47 834] LimitUp:[Disable]
[2024/8/7 8:58:47 834] [2680*0]->[3840*0])
[2024/8/7 8:58:47 834] chn	TotalSize	ActiveSize
[2024/8/7 8:58:47 834] 0	5040*2246	2680*2160
[2024/8/7 8:58:47 849] 0	5040*2246	3840*2160
[2024/8/7 8:58:47 849] Repair: En:1	Cnt:0x00000000
[2024/8/7 8:58:47 849] [1.VICU_info]:
[2024/8/7 8:58:47 849] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 8:58:47 849] 0	25.0	622	0	0	183	linear	8ddb00
[2024/8/7 8:58:47 849] 0	0.0	0	0	0	0	linear	0
[2024/8/7 8:58:47 865] 0	0.0	0	0	0	0	linear	0
[2024/8/7 8:58:47 865] en	op_type	m_chn	now
[2024/8/7 8:58:47 865] 0	1	1	1
[2024/8/7 8:58:47 865] [2.VI_info]:
[2024/8/7 8:58:47 865] chn	TotalSize	ActiveSize
[2024/8/7 8:58:47 865] 0	5034*2246	3848*2166
[2024/8/7 8:58:47 865] 1	   0*   0	   0*   0
[2024/8/7 8:58:47 865] [3.MIPI_info]:
[2024/8/7 8:58:47 882] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 8:58:47 882] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 8:58:47 882] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 8:58:47 882] [4.Cut_info]:
[2024/8/7 8:58:47 882] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 8:58:47 897] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 8:58:47 897] h_d	0	1	 	 	2684	2160	  
[2024/8/7 8:58:47 897] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 8:58:47 897] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 8:58:47 897] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 8:58:47 913] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 8:58:47 913] [5.IB(isp buffer info)]:
[2024/8/7 8:58:47 913] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 8:58:47 914] PoolId  Count  Size
[2024/8/7 8:58:47 930] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 8:58:47 930] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:58:47 946] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 8:58:47 946] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:58:47 946] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 8:58:47 962] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:58:47 962] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 8:58:47 962] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 8:58:47 978] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 8:58:47 978] 0       0         0          0          4       
[2024/8/7 8:58:47 978] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 8:58:47 994]      --265--            --264--                                               
[2024/8/7 8:58:47 994] Count      Line     Count      Line     
[2024/8/7 8:58:47 994] 473        480      1124       560      
[2024/8/7 8:58:48 010] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 8:58:48 010] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 8:58:48 026] 0   3840   2160    H265  0      0        0           288       983038     2        	
[2024/8/7 8:58:48 026] 1   640    360     H265  0  [atbm_log]:hw_priv->scan.status 0
[2024/8/7 8:58:48 026]     0        0          [atbm_log]:atbm_scan_work:end(0)
[2024/8/7 8:58:48 026]  175       43197      3        	
[2024/8/7 8:58:48 042] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 8:58:48 042] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 8:58:48 058] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 8:58:48 074] 0   Y      288      0       0       15       0        288      288      370       65515         58576    89874    64551    12      
[2024/8/7 8:58:48 090] 1   Y      175      0       9       1        0        175      175      370       3093          1876     24791    2991     8       
[2024/8/7 8:58:48 090] 3   N      0        0       0       1    [atbm_log]:eth2:free authen bss ++
[2024/8/7 8:58:48 090]     0        0  [atbm_log]:authen:(a4:a9:30:ce:5e:66),ssid(Xiaomi_F1DC)
[2024/8/7 8:58:48 106]       0        3[atbm_log]:authenticate[a4:a9:30:ce:5e:66]:[0][1]
[2024/8/7 8:58:48 106] 71       0      [atbm_log]:eth2: authenticate with a4:a9:30:ce:5e:66 (try 1) (1)(0)
[2024/8/7 8:58:48 122]        0        [atbm_log]:[STA] Join DTIM: 1, interval: 100
[2024/8/7 8:58:48 122] 0        0        0       
[2024/8/7 8:58:48 153] [atbm_log]:[TX]:authen, delay suspend
[2024/8/7 8:58:48 202] [atbm_log]:eth2: authenticated
[2024/8/7 8:58:48 218] [atbm_log]:work:flush sta[a4:a9:30:ce:5e:66]
[2024/8/7 8:58:48 218] [atbm_log]:sta has been insert(0)
[2024/8/7 8:58:48 218] [atbm_log]:wk->assoc.use_he 1 1++
[2024/8/7 8:58:48 218] [atbm_log]:flush sta(0):
[2024/8/7 8:58:48 218] [atbm_log]:eth2: associated
[2024/8/7 8:58:48 234] [atbm_log]:eth2:free authen bss ++
[2024/8/7 8:58:48 234] [atbm_log]:eth2:free authen bss --
[2024/8/7 8:58:48 234] [atbm_log]:is_wifi6_ap++
[2024/8/7 8:58:48 234] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 8:58:48 250] [atbm_log]:eth2  WMM AC=0 acm=0 aifs=2 cWmin=3 cWmax=7 txop=47 uapsd=0
[2024/8/7 8:58:48 250] [atbm_log]:eth2  WMM AC=1 acm=0 aifs=2 cWmin=7 cWmax=15 txop=94 uapsd=0
[2024/8/7 8:58:48 266] [atbm_log]:eth2  WMM AC=2 acm=0 aifs=3 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 8:58:48 266] [atbm_log]:eth2  WMM AC=3 acm=0 aifs=7 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 8:58:48 282] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 8:58:48 282] [atbm_log]:[a4:a9:30:ce:5e:66]:20M channel
[2024/8/7 8:58:48 282] [atbm_log]:atbm_bss_info_changed:chatype(1),channelNumber(3)
[2024/8/7 8:58:48 298] [atbm_log]:BssidColor[34]
[2024/8/7 8:58:48 298] [atbm_log]:[STA] color 34, he_support_flag: 53
[2024/8/7 8:58:48 298] [atbm_log]:==>connect wifi6 AP open AX, set BA WIN short
[2024/8/7 8:58:48 362] [atbm_log]:[eth2] Waiting Txq Ready[1]
[2024/8/7 8:58:48 409] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 8:58:48 409] [atbm_log]:[eth2]:dtim changed [0]->[1]
[2024/8/7 8:58:48 426] [atbm_log]:[eth2 Rx]:da:[ff:ff:ff:ff:ff:ff] sa:[60:dc:81:06:42:59] bssid:[a4:a9:30:ce:5e:66],PTK[  (null)],FLAGS[10800063],skb->len[296]
[2024/8/7 8:58:48 442] [atbm_log]:[RX] MIC failure. ENCRYPTION [0],da:[ff:ff:ff:ff:ff:ff] sa:[60:dc:81:06:42:59] bssid:[a4:a9:30:ce:5e:66]
[2024/8/7 8:58:48 442] [atbm_log]:[RX]:need sw decrypted?
[2024/8/7 8:58:48 442] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 8:58:48 458] NOHZ: local_softirq_pending 08
[2024/8/7 8:58:48 505] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 8:58:48 521] [atbm_log]:QosNUll Htc(807)
[2024/8/7 8:58:48 521] [atbm_log]:send htc qos null
[2024/8/7 8:58:48 521] [atbm_log]:om work(1)
[2024/8/7 8:58:48 810] [atbm_log]:QosNUll Htc(807)
[2024/8/7 8:58:48 810] [atbm_log]:send htc qos null
[2024/8/7 8:58:48 810] [atbm_log]:om work(2)
[2024/8/7 8:58:49 066] [atbm_log]:QosNUll Htc(807)
[2024/8/7 8:58:49 066] [atbm_log]:send htc qos null
[2024/8/7 8:58:49 066] [atbm_log]:om work(3)
[2024/8/7 8:58:49 305] [atbm_log]:QosNUll Htc(807)
[2024/8/7 8:58:49 305] [atbm_log]:send htc qos null
[2024/8/7 8:58:49 305] [atbm_log]:om work(4)
[2024/8/7 8:58:49 434] set basic_indicator_onoff:0 
[2024/8/7 8:58:49 450] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 452] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:49 452] [1970-01-01 00:01:02] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 8:58:49 466] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 8:58:49 466] set basic_indicator_onoff:1 
[2024/8/7 8:58:49 482] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 482] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:49 482] set basic_indicator_onoff:0 
[2024/8/7 8:58:49 498] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 498] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:49 514] [1970-01-01 00:01:02] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time32793
[2024/8/7 8:58:49 530] [1970-01-01 00:01:02] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 122651
[2024/8/7 8:58:49 530] [1970-01-01 00:01:02] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:58:49 530] set basic_indicator_onoff:1 
[2024/8/7 8:58:49 546] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 546] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:49 562] [1970-01-01 00:01:03] xm_main.c(371) <AutoMaintenance_pro>: -[atbm_log]:om done
[2024/8/7 8:58:49 562] ----------------------------
[2024/8/7 8:58:49 562] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:1
[2024/8/7 8:58:49 578] set basic_indicator_onoff:0 
[2024/8/7 8:58:49 578] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 594] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:49 594] set basic_indicator_onoff:1 
[2024/8/7 8:58:49 594] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 610] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:49 610] set basic_indicator_onoff:0 
[2024/8/7 8:58:49 626] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 626] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:49 626] set basic_indicator_onoff:1 
[2024/8/7 8:58:49 647] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IP[atbm_log]:Open B®Y®®Z
[2024/8/7 8:58:49 647]        ˒WV®WԮW$ՋR,§¬N§&L§¬Y§MY6 tid 0
[2024/8/7 8:58:49 647] C_APP_set_basic_[atbm_l𐑽AՕՕ5R¹¥ѽȽ½¹½򆑉µ}±½u
[2024/8/7 8:58:49 663]                                           鑑¢½¹¥¹¡JBJj¤Lu󿿙±󲅱͕mщµ}±½u碡Aº½ɭ¡ťjRӈh´jmۅښjmƊºjj҂҂뫪フ5Ej
[2024/8/7 8:58:49 663] 鵥½]ɥѕ¡Jڕ拪ª¥½ʑ򛅒녲±򛆪5Rڴښɪ5Rсͥ}¥¹¥ѽȽ½¹½适jԤh´5jmƊºjj҂҂꣕儽¥M}=¡¹±ɹ¡²Jስ
[2024/8/7 8:58:49 686]        薵5нͥ}¥¹¥ѽȽ½¹½♵󿿙±󲅱͕5RڴjmۅښjmƊºjj҂҂뫪フ5Ej
[2024/8/7 8:58:49 696]        鵥½]ɥѕ¡Jڕ拪ª¥½ʑ򛅒녲±򛂪5Rڴښɪ5Rсͥ}¥¹¥ѽȽ½¹½鈂jԤh´5jmƊºjj҂҂꣕儽¥M}=¡¹±ɹ¡²Jስ
[2024/8/7 8:58:49 696]        薵5нͥ}¥¹¥ѽȽ½¹½♵󿿙±󲅱͕5RڴjmۅښjmƊºjj҂҂뫪フ5Ej
[2024/8/7 8:58:49 711]               鵥½]ɥѕ¡Jڕ拪ª¥½ʑ򛅒녲±򛆪5Rڴښɪ5Rсͥ}¥¹¥ѽȽ½¹½适jԤh´5jmƊºjj҂҂꣕儽¥M}=¡¹±ɹ¡²Jስ
[2024/8/7 8:58:49 711]        薵5нͥ}¥¹¥ѽȽ½¹½♵󿿙±󲅱͕5RڴjmۅښjmƊºjj҂҂뫪フ5Ej
[2024/8/7 8:58:49 727]                      鵥½]ɥѕ¡Jڕ拪ª¥½ʑ򛅒녲±򛂪5Rڴښɪ5Rсͥ}¥¹¥ѽȽ½¹½鈂jԤh´5jmƊºjjؕщµ}±½u
[2024/8/7 8:58:49 727]        紁Umѡʪ
[2024/8/7 8:58:49 727]        鎑¥½¹mʪ±¢¥mª±͹mª±ՙ}ͥ锭ª±¢½­¹mª±¢mҒ
[2024/8/7 8:58:49 743]                  撚К騪鲲.'¦L'LMWºuya_i[atbm_log]:activated addBA response timer on tid 0
[2024/8/7 8:58:49 743] pc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 759] [1970-01-01[atbm_log]:aggtx wake queue
[2024/8/7 8:58:49 759]  00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[atbm_log]:switched off addBA timer for tid 0
[2024/8/7 8:58:49 759] [1]
[2024/8/7 8:58:49 759] se[atbm_log]:Aggregation is on for tid 0
[2024/8/7 8:58:49 775] t basic_indicato[atbm_log]:AMPDU[eth2]:action[4],tid[0],ssn[0],buff_size[64],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:58:49 775] r_onoff:0 
[2024/8/7 8:58:49 791] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 791] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:49 791] set basic_indicator_onoff:1 
[2024/8/7 8:58:49 807] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 807] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:49 823] set basic_indicator_onoff:0 
[2024/8/7 8:58:49 823] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:49 839] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:49 839] set basic_indicator_onoff:1 
[2024/8/7 8:58:49 839] [197[atbm_log]:dhcp work(2)
[2024/8/7 8:58:50 046] 0-01-01 00:01:04XshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshell[atbm_log]:dhcp work(3)
[2024/8/7 8:58:50 287] [atbm_log]:dhcp work(4)
[2024/8/7 8:58:51 663] [atbm_log]:dhcp done] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 663] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 663] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 679] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 679] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:51 679] set basic_indicator_onoff:1 
[2024/8/7 8:58:51 696] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 696] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 712] 
[2024/8/7 8:58:51 713] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 713] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 727] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:51 727] set basic_indicator_onoff:1 
[2024/8/7 8:58:51 743] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 743] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 743] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 759] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 759] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:51 759] set basic_indicator_onoff:1 
[2024/8/7 8:58:51 775] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 775] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 790] 
[2024/8/7 8:58:51 791] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 791] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 807] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:51 807] set basic_indicator_onoff:1 
[2024/8/7 8:58:51 824] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 824] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 824] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 839] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 839] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:51 839] set basic_indicator_onoff:1 
[2024/8/7 8:58:51 855] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 855] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 871] 
[2024/8/7 8:58:51 872] [1970-01-01 00:01:06] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:58:51 872] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 886] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 887] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:51 887] set basic_indicator_onoff:1 
[2024/8/7 8:58:51 903] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 919] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 919] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 919] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 935] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:51 935] set basic_indicator_onoff:1 
[2024/8/7 8:58:51 951] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 951] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 951] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 967] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 967] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:51 967] set basic_indicator_onoff:1 
[2024/8/7 8:58:51 983] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:51 999] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:51 999] set basic_indicator_onoff:0 
[2024/8/7 8:58:51 999] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:52 335] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 8:58:52 335] ],val=[0]
[2024/8/7 8:58:52 335] set basic_indicator_onoff:1 
[2024/8/7 8:58:52 350] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:52 350] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:52 367] [1970-01-01 00:01:06] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time36801
[2024/8/7 8:58:52 367] set basic_indicator_onoff:0 
[2024/8/7 8:58:52 383] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:52 383] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:52 383] set basic_indicator_onoff:1 
[2024/8/7 8:58:52 399] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:52 399] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:52 399] set basic_indicator_onoff:0 
[2024/8/7 8:58:52 415] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:52 415] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:52 431] 
[2024/8/7 8:58:52 431] set basic_indicator_onoff:1 
[2024/8/7 8:58:52 431] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:52 447] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:52 447] [01-01 18:12:41 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 8:58:52 830] [atbm_log]:dhcp work(1)
[2024/8/7 8:58:53 038] [atbm_log]:dhcp work(2)
[2024/8/7 8:58:53 070] 
[2024/8/7 8:58:53 086] Auto login as root ...
[2024/8/7 8:58:53 279] (none) login: [atbm_log]:dhcp work(3)
[2024/8/7 8:58:53 326] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 8:58:53 327] 
[2024/8/7 8:58:53 327] [atbm_log]:dhcp done[atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 8:58:53 342] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 8:58:53 343] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 8:58:53 358] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[6]
[2024/8/7 8:58:53 358] [atbm_log]:AMPDU[eth2]:action[0],tid[6],ssn[5],buff_size[64],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:58:53 375] [atbm_log]:Rx A-MPDU request on tid 6 result 0
[2024/8/7 8:58:53 375] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[0]
[2024/8/7 8:58:53 390] [atbm_log]:AMPDU[eth2]:action[0],tid[0],ssn[0],buff_size[64],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:58:53 407] 
[2024/8/7 8:58:53 423] (none) login: [atbm_log]:Rx A-MPDU request on tid 0 result 0
[2024/8/7 8:58:53 423] [atbm_log]:dhcp work(1)
[2024/8/7 8:58:53 455] [atbm_log]:ieee80211_wk_connecting: time out waitting for dhcp
[2024/8/7 8:58:53 455] [atbm_log]:connecting done for waitting dhcp  
[2024/8/7 8:58:53 935] [atbm_log]:dhcp donerelease an RX reorder frame due to timeout sn 5
[2024/8/7 8:58:53 983] route: SIOCDELRT: No such process
[2024/8/7 8:58:54 574] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 591] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 592] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 592] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 607] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 607] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:54 607] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 623] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 623] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 639] 
[2024/8/7 8:58:54 640] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 640] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 654] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:54 654] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 655] [1970-01-01 00:01:08] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 670] [1970-01-01 00:01:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 671] 
[2024/8/7 8:58:54 671] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 687] [1970-01-01 00:01:08] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 687] [1970-01-01 00:01:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:54 687] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 703] [1970-01-01 00:01:08] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 703] [1970-01-01 00:01:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 719] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 719] [1970-01-01 00:01:08] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 735] [1970-01-01 00:01:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:54 735] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 735] [1970-01-01 00:01:08] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 751] [1970-01-01 00:01:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 751] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 767] [1970-01-01 00:01:08] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 767] [1970-01-01 00:01:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:54 767] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 782] [1970-01-01 00:01:08] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 783] [1970-01-01 00:01:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 799] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 799] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 814] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:54 814] [1970-01-01 00:01:09] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:58:54 814] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 830] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 830] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 846] 
[2024/8/7 8:58:54 847] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 847] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 862] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:54 862] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 878] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 878] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 878] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 894] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 894] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:54 894] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 910] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 926] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:54 926] [0]
[2024/8/7 8:58:54 926] set basic_indicator_onoff:1 
[2024/8/7 8:58:54 942] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 942] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[5]
[2024/8/7 8:58:54 959] -01-01 00:01:09][atbm_log]:AMPDU[eth2]:action[0],tid[5],ssn[3],buff_size[64],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:58:54 959]  ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1[atbm_log]:napi schedule
[2024/8/7 8:58:54 959] ]
[2024/8/7 8:58:54 959] set basic_indicator_onoff:0 
[2024/8/7 8:58:54 974] [atbm_log]:Rx A-MPDU request on tid 5 result 0
[2024/8/7 8:58:54 975] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:54 975] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:54 990] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:54 990] curr event:6 
[2024/8/7 8:58:55 006] IPC_APP_Notify_LED_Sound_Status_CB line(497) -------------------------- IPC_CONNECT_WIFI_SUCCESS(6)
[2024/8/7 8:58:55 022] [1970-01-01 00:01:09] tuya_ipc_system_control_demo.c(498) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECT_SUCCESS, 0, 0, 0, 1))
[2024/8/7 8:58:55 022] [01-01 18:12:44 TUYA D][tuya_devos_netlink.c:313] wf connect success!
[2024/8/7 8:58:55 023] [01-01 18:12:44 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 8:58:55 038] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 8:58:55 039] [01-01 18:12:44 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 8:58:55 054] [01-01 18:12:44 TUYA E][mqtt_client.c:807] hand null.
[2024/8/7 8:58:55 055] [1970-01-01 00:01:09] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/ServerConnect_english.pcm]
[2024/8/7 8:58:55 070] [1970-01-01 00:01:09] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 8:58:55 070] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 8:58:55 086] [01-01 18:12:44 TUYA D][tuya_iot_wired_wifi_api.c:584] wired wifi default stat:1,change:1
[2024/8/7 8:58:55 086] [01-01 18:12:44 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[2024/8/7 8:58:55 102] [01-01 18:12:44 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[2024/8/7 8:58:55 102] [01-01 18:12:44 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 8:58:55 118] dev id key: 16
[2024/8/7 8:58:55 119] c0 b9 30 cc 91 82 20 e0 27 d3 45 b3 ab 3c 27 bf 
[2024/8/7 8:58:55 119] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 8:58:55 134] [01-01 18:12:44 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 8:58:55 134] 2 1 6 3 2 1 a2 14 16 1 a2 0 1c 6a 97 74 ce 42 f4 54 8c 72 2e 92 d 9f a1 db 
[2024/8/7 8:58:55 134] [01-01 18:12:44 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 8:58:55 150] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 30 7b 27 8c c6 8b 14 13 8e 36 f6 75 73 7d 4b 
[2024/8/7 8:58:55 150] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 8:58:55 166] [01-01 18:12:44 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 8:58:55 166] [01-01 18:12:44 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 8:58:55 182] [01-01 18:12:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 8:58:55 182] tuya_hal_bt_send 20
[2024/8/7 8:58:55 182] 00 21 33 05 46 cf ce 96 50 ad 5d 36 bc 0d 7f 24 91 f8 92 4b 
[2024/8/7 8:58:55 182] [01-01 18:12:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 8:58:55 198] 0 21 33 5 46 cf ce 96 50 ad 5d 36 bc d 7f 24 91 f8 92 4b 
[2024/8/7 8:58:55 198] XmBleSendBuf 20: 00 21 33 05 46 cf ce 96 50 ad 5d 36 bc 0d 7f 24 91 f8 92 4b
[2024/8/7 8:58:55 214] GATT procedure initiated: notify; att_handle=23
[2024/8/7 8:58:55 215] ble_slave_gap_event->type=13
[2024/8/7 8:58:55 215] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 8:58:55 215] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 8:58:55 230] [01-01 18:12:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 8:58:55 230] set basic_indicator_onoff:1 
[2024/8/7 8:58:55 230] [1970-01-01 00:01:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:55 246] [1970-01-01 00:01:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:55 246] [01-01 18:12:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 8:58:55 262] tuya_hal_bt_send 17
[2024/8/7 8:58:55 262] 01 81 d6 2c 15 3e f9 5a 82 33 cb cb 99 78 93 d4 b7 
[2024/8/7 8:58:55 262] [01-01 18:12:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 8:58:55 278] 1 81 d6 2c 15 3e f9 5a 82 33 cb cb 99 78 93 d4 b7 
[2024/8/7 8:58:55 278] XmBleSendBuf 17: 01 81 d6 2c 15 3e f9 5a 82 33 cb cb 99 78 93 d4 b7
[2024/8/7 8:58:55 278] GATT procedure initiated: notify; att_handle=23
[2024/8/7 8:58:55 278] ble_slave_gap_event->type=13
[2024/8/7 8:58:55 294] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 8:58:55 294] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 8:58:55 294] [01-01 18:12:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 8:58:55 310] [01-01 18:12:44 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 8:58:55 310] [01-01 18:12:44 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 8:58:55 327] [01-01 18:12:44 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:58:55 327] [01-01 18:12:44 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:55 327] [01-01 18:12:44 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:58:55 342] [01-01 18:12:44 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:58:55 342] [01-01 18:12:44 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:55 358] [01-01 18:12:44 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:58:55 358] [01-01 18:12:44 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:58:55 358] [01-01 18:12:44 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:55 375] [01-01 18:12:44 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:55 375] [01-01 18:12:44 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:55 375] [01-01 18:12:44 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:58:55 391] [01-01 18:12:44 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:58:55 391] [01-01 18:12:44 TUYA D][iot_httpc.c:1435] sign_buffer:env=26MU&region=AY&ts=29&uuid=uuidcaab27b0a838d239
[2024/8/7 8:58:55 407] [01-01 18:12:44 TUYA D][iot_httpc.c:1443] sign_base64_encode:tP9BdmtGZiTC9WCJaO9vv3rsTWEkHIp2MFndl3UpZIs=
[2024/8/7 8:58:55 407] [01-01 18:12:44 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 8:58:55 439] [01-01 18:12:44 TUYA D][iot_httpc.c:1514] http_dns send: {"region":"AY","env":"26MU","uuid":"uuidcaab27b0a838d239","ts":29,"sign":"tP9BdmtGZiTC9WCJaO9vv3rsTWEkHIp2MFndl3UpZIs=","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:58:55 454] [01-01 18:12:44 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v2/url_config
[2024/8/7 8:58:55 455] [01-01 18:12:44 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:58:55 470] [01-01 18:12:44 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 8:58:55 471] [01-01 18:12:44 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 8:58:55 486] [01-01 18:12:44 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 8:58:55 486] set basic_indicator_onoff:0 
[2024/8/7 8:58:55 502] [1970-01-01 00:01:10] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:55 502] [1970-01-01 00:01:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:55 502] [01-01 18:12:44 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 8:58:55 518] [01-01 18:12:44 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:58:55 534] [01-01 18:12:44 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:58:55 534] [01-01 18:12:44 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:58:55 534] [1970-01-01 00:01:10] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:58:55 550] [01-01 18:12:44 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 8:58:55 550] [01-01 18:12:44 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:58:55 550] set basic_indicator_onoff:1 
[2024/8/7 8:58:55 566] [1970-01-01 00:01:10] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:55 566] [1970-01-01 00:01:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:55 582] 
[2024/8/7 8:58:55 584] set basic_indicator_onoff:0 
[2024/8/7 8:58:55 584] [1970-01-01 00:01:10] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:55 598] [1970-01-01 00:01:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:55 598] [01-01 18:12:44 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 8:58:55 614] [01-01 18:12:44 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:58:55 614] set basic_indicator_onoff:1 
[2024/8/7 8:58:55 630] [1970-01-01 00:01:10] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:55 630] [1970-01-01 00:01:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:55 646] [01-01 18:12:44 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 8:58:55 646] [01-01 18:12:44 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:58:55 646] [01-01 18:12:44 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:58:55 662] [01-01 18:12:44 TUYA D][iot_httpc.c:1578] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216]
[2024/8/7 8:58:55 662] [01-01 18:12:44 TUYA D][iot_httpc.c:1579] mqttUrl:[m2.tuyacn.com:1883][42.192.30.165]
[2024/8/7 8:58:55 678] [01-01 18:12:44 TUYA D][iot_httpc.c:1602] httpsSelfUrl:[https://a2.tuyacn.com/d.json][42.192.31.36]
[2024/8/7 8:58:55 694] [01-01 18:12:44 TUYA D][iot_httpc.c:1603] mqttsSelfUrl:[m2.tuyacn.com:8883][42.192.30.165]
[2024/8/7 8:58:55 694] [01-01 18:12:44 TUYA D][iot_httpc.c:1670] ghostUrl:[baal.tuyacn.com:443][42.192.35.108]
[2024/8/7 8:58:55 694] [01-01 18:12:44 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:58:55 710] [01-01 18:12:44 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:55 710] [01-01 [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:55 710] 18:12:44 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:58:55 726] [01-01 18:12:44 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:58:55 726] [01-01 18:12:44 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:58:55 742] [01-01 18:12:44 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:58:55 742] [01-01 18:12:44 TUYA D][iot_httpc.c:1684] tls_ca_name:tls_ca0
[2024/8/7 8:58:55 742] [01-01 18:12:44 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 8:58:55 758] [01-01 18:12:44 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:55 758] [01-01 18:12:44 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:55 758] [01-01 18:12:44 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:55 775] [01-01 18:12:44 TUYA D][simplekv.c:374] write key:tls_ca0 And Value Len:2688
[2024/8/7 8:58:55 775] [01-01 18:12:44 TUYA D][simplekv.c:457] new space 8 startpos:30428 size:2756
[2024/8/7 8:58:55 791] [01-01 18:12:44 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:58:55 791] [01-01 18:12:44 TUYA D][simplekv.c:203] update crc 1395591596
[2024/8/7 8:58:55 791] [01-01 18:12:44 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:55 806] [01[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:55 806] -01 18:12:44 TUYA D][simplekv.c:520] wri[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:55 806] te success
[2024/8/7 8:58:55 822] [01-01 18:12:44 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:58:55 822] [01-01 18:12:44 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:55 838] [01-01 18:12:44 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:55 839] [01-01 18:12:44 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:55 839] [01-01 18:12:44 TUYA D][simplekv.c:374] write key:tls_ca_cnt And Value Len:16
[2024/8/7 8:58:55 854] [01-01 18:12:44 TUYA D][simplekv.c:457] new space 9 startpos:33184 size:84
[2024/8/7 8:58:55 854] [01-01 18:12:44 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:58:55 870] [01-01 18:12:44 TUYA D][simplekv.c:203] update crc 213719394
[2024/8/7 8:58:55 870] [01-01 18:12:44 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:55 870] [01-01 18:12:44 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:55 887] [01-01 18:12:44 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 8:58:55 887] [01-01 18:12:44 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216]
[2024/8/7 8:58:55 902] [01-01 18:12:44 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36]
[2024/8/7 8:58:55 902] [01-01 18:12:44 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165]
[2024/8/7 8:58:55 918] [01-01 18:12:44 TUYA D][uni_network.c:268] cache dns[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:55 918]  [m2.tuyacn.com:8883]<->[42.192.30.165]
[2024/8/7 8:58:55 918] set basic_indicator_onoff:0 
[2024/8/7 8:58:55 934] [1970-01-01 00:01:10] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:55 934] [1970-01-01 00:01:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:55 951] [01-01 18:12:44 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108]
[2024/8/7 8:58:55 951] [01-01 18:12:44 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:58:55 967] [01-01 18:12:44 TUYA D][simplekv.c:1251] find key:9 tls_ca_cnt
[2024/8/7 8:58:55 967] [01-01 18:12:44 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[2024/8/7 8:58:55 967] [01-01 18:12:44 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[2024/8/7 8:58:55 982] [01-01 18:12:44 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 8:58:55 982] [01-01 18:12:44 TUYA D][simplekv.c:1251] find key:8 tls_ca0
[2024/8/7 8:58:55 998] [01-01 18:12:44 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688
[2024/8/7 8:58:55 998] [01-01 18:12:44 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
[2024/8/7 8:58:55 998] [01-01 18:12:44 TUYA D][iot_httpc.c:1696] end
[2024/8/7 8:58:56 014] [01-01 18:12:44 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 8:58:56 014] [01-01 18:12:44 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 8:58:56 014] [01-01 18:12:44 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 8:58:56 014] bt_ack_uncrypt 2
[2024/8/7 8:58:56 030] 00 00 
[2024/8/7 8:58:56 031] [01-01 18:12:44 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 8:58:56 031] [01-01 18:12:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 8:58:56 047] tuya_hal_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:56 047] bt_send 20
[2024/8/7 8:58:56 047] 00 21 34 02 1e 90 ad e4 d6 17 87 02 8e 90 e0 b3 bf 8a ea 23 
[2024/8/7 8:58:56 062] [01-01 18:12:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 8:58:56 062] 0 21 34 2 1e 90 ad e4 d6 17 87 2 8e 90 e0 b3 bf 8a ea 23 
[2024/8/7 8:58:56 063] XmBleSendBuf 20: 00 21 34 02 1e 90 ad e4 d6 17 87 02 8e 90 e0 b3 bf 8a ea 23
[2024/8/7 8:58:56 078] GATT procedure initiated: notify; att_handle=23
[2024/8/7 8:58:56 078] ble_slave_gap_event->type=13
[2024/8/7 8:58:56 079] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 8:58:56 079] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 8:58:56 094] [01-01 18:12:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 8:58:56 094] [01-01 18:12:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 8:58:56 094] tuya_hal_bt_send 17
[2024/8/7 8:58:56 110] 01 5b f1 cb fb 17 a9 a1 f4 e4 50 b8 aa 93 19 96 b3 
[2024/8/7 8:58:56 110] [01-01 18:12:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 8:58:56 110] 1 5b f1 cb fb 17 a9 a1 f4 e4 50 b8 aa 93 19 96 b3 
[2024/8/7 8:58:56 126] XmBleSendBuf 17: 01 5b f1 cb fb 17 a9 a1 f4 e4 50 b8 aa 93 19 96 b3
[2024/8/7 8:58:56 126] GATT procedure initiated: notify; att_handle=23
[2024/8/7 8:58:56 126] ble_slave_gap_event->type=13
[2024/8/7 8:58:56 142] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 8:58:56 143] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 8:58:56 143] [01-01 18:12:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 8:58:56 158] [01-01 18:12:44 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 8:58:56 158] set basic_indicator_onoff:1 
[2024/8/7 8:58:56 158] [1970-01-01 00:01:10] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 174] [1970-01-01 00:01:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:56 174] [01-01 18:12:44 TUYA D][tuya_devos_activate.c:356] dev_nw_cfg_active_stage:5
[2024/8/7 8:58:56 190] [01-01 18:12:44 TUYA D][iot_httpc.c:3195] modules:(null)
[2024/8/7 8:58:56 190] [01-01 18:12:44 TUYA D][simplekv.c:1211] read key:last_reset_info isFuzzy:0 skipCnt:0
[2024/8/7 8:58:56 190] [01-01 18:12:44 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:56 206] [01-01 18:12:44 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:56 206] [01-01 18:12:44 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:56 222] [01-01 18:12:44 TUYA D][iot_httpc.c:3198] options:{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}
[2024/8/7 8:58:56 286] [01-01 18:12:44 TUYA D][iot_httpc.c:1161] Post Data: {"token":"pxRKWRjU","softVer":"1.5.431","productKey":"fvijo8jvloagv1gm","protocolVer":"2.2","baselineVer":"40.00","hid":"90314ba51650","skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}}","devAttribute":67,"cadVer":"1.0.4","cdVer":"1.0.0","options":"{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}","t":29}
[2024/8/7 8:58:56 302] [01-01 18:12:44 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.active&et=1&t=29&uuid=uuidcaab27b0a838d239&v=4.4&sign=c04c63e50d2bdad013e5cfee27b87076
[2024/8/7 8:58:56 303] [01-01 18:12:44 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:58:56 318] [01-01 18:12:44 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:58:56 319] [01-01 18:12:44 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:58:56 334] [01-01 18:12:44 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:58:56 335] [01-01 18:12:45 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:58:56 350] [01-01 18:12:45 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:58:56 350] [01-01 18:12:45 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:58:56 366] [01-01 18:12:45 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:58:56 366] [01-01 18:12:45 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:58:56 366] [01-01 18:12:45 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:58:56 382] [01-01 18:12:45 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:58:56 382] [1970-01-01 00:01:10] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time40826
[2024/8/7 8:58:56 398] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 8:58:56 398] Len=20 step 0
[2024/8/7 8:58:56 398] att=0x0 0x21 0x20 0x2 0x14 0x5 0xe9 0x99 0x7f 0x9c 0x5a 0xb4 0xd0 0x25 0xa4 0x68 0x63 0x94 0xc2 0xaf 
[2024/8/7 8:58:56 414]  RCVS len:20
[2024/8/7 8:58:56 415] set basic_indicator_onoff:0 
[2024/8/7 8:58:56 415] [1970-01-01 00:01:10] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 430] [1970-01-01 00:01:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:56 430] [1970-01-01 00:01:10] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:58:56 430] XmBleReadBuf 20:
[2024/8/7 8:58:56 446] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 8:58:56 446] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 8:58:56 446] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 8:58:56 462] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 8:58:56 462] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 8:58:56 478] [01-01 18:12:45 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 8:58:56 478] [01-01 18:12:45 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 8:58:56 478] [01-01 18:12:45 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 8:58:56 478] bt_rev_raw 20
[2024/8/7 8:58:56 494] 00 21 20 02 14 05 e9 99 7f 9c 5a b4 d0 25 a4 68 63 94 c2 af 
[2024/8/7 8:58:56 494] [01-01 18:12:45 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 8:58:56 510] [01-01 18:12:45 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 8:58:56 510] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 8:58:56 526] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 8:58:56 527]  ---
[2024/8/7 8:58:56 527] Len=17 step 0
[2024/8/7 8:58:56 527] att=0x1 0xe7 0x84 0xd7 0x6b 0x50 0xaa 0xc0 0xa7 0xa7 0x9e 0xfd 0xaa 0xef 0x6f 0xa3 0x9 
[2024/8/7 8:58:56 527]  RCVS len:17
[2024/8/7 8:58:56 527] set basic_indicator_onoff:1 
[2024/8/7 8:58:56 543] [1970-01-01 00:01:11] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 543] [1970-01-01 00:01:11] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:56 558] XmBleReadBuf 17:
[2024/8/7 8:58:56 558] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 8:58:56 558] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 8:58:56 558] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 8:58:56 574] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 8:58:56 574] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 8:58:56 590] [01-01 18:12:45 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 8:58:56 590] [01-01 18:12:45 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 8:58:56 606] [01-01 18:12:45 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 8:58:56 606] bt_rev_raw 17
[2024/8/7 8:58:56 606] 01 e7 84 d7 6b 50 aa c0 a7 a7 9e fd aa ef 6f a3 09 
[2024/8/7 8:58:56 606] [01-01 18:12:45 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 8:58:56 622] ble rev data 33
[2024/8/7 8:58:56 622] 02 14 05 e9 99 7f 9c 5a b4 d0 25 a4 68 63 94 c2 af e7 84 d7 6b 50 aa c0 a7 a7 9e fd aa ef 6f a3 09 
[2024/8/7 8:58:56 622] ble decryped data 16
[2024/8/7 8:58:56 638] 00 00 00 04 00 00 00 00 00 22 00 01 00 d6 49 00 
[2024/8/7 8:58:56 638] [01-01 18:12:45 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 8:58:56 638] [01-01 18:12:45 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 8:58:56 654] [01-01 18:12:45 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 8:58:56 654] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 8:58:56 655] set basic_indicator_onoff:0 
[2024/8/7 8:58:56 670] [1970-01-01 00:01:11] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 670] [1970-01-01 00:01:11] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:56 686] [01-01 18:12:45 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:58:56 702] [01-01 18:12:45 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:58:56 767] set basic_indicator_onoff:1 
[2024/8/7 8:58:56 767] [1970-01-01 00:01:11] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 783] [1970-01-01 00:01:11] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:56 783] set basic_indicator_onoff:0 
[2024/8/7 8:58:56 798] [1970-01-01 00:01:11] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 799] [1970-01-01 00:01:11] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:56 799] set basic_indicator_onoff:1 
[2024/8/7 8:58:56 815] [1970-01-01 00:01:11] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 815] [1970-01-01 00:01:11] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:56 830] set basic_indicator_onoff:0 
[2024/8/7 8:58:56 830] [1970-01-01 00:01:11] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 847] [1970-01-01 00:01:11] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:56 847] set basic_indicator_onoff:1 
[2024/8/7 8:58:56 847] [1970-01-01 00:01:11] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:56 863] [1970-01-01 00:01:11] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:56 863] g_AudioTipsList.size() enable: 0[01-01 18:12:46 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 8:58:56 959] [01-01 18:12:46 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"capability":1,"devId":"6c22076b2d2b61448fm8uy","dstIntervals":[],"localKey":"Do(Ws'}yEzbR`xe{","resetFactory":false,"schema":"[{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":103,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":104,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"range\":[\"0\",\"1\",\"2\"],\"type\":\"enum\"},\"id\":106,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":109,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"min\":1,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":110,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":111,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":113,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\
[2024/8/7 8:58:56 959] [08-07 19:11:14 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:58:56 976] [08-07 19:11:14 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:58:56 976] [08-07 19:11:14 TUYA D][tuya_devos_activate.c:210] cloud_reset:0 local_reset:1
[2024/8/7 8:58:56 991] [08-07 19:11:14 TUYA D][tuya_devos_activate.c:256] __tmm_gw_actv_work: reset stride flag.
[2024/8/7 8:58:56 991] [08-07 19:11:14 TUYA D][tuya_devos_entry.c:1477] write stride to flash:0
[2024/8/7 8:58:57 007] [08-07 19:11:14 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 8:58:57 007] [08-07 19:11:14 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:57 007] [08-07 19:11:14 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:57 023] [08-07 19:11:14 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:57 023] [08-07 19:11:14 TUYA D][simplekv.c:374] write key:is_stride And Value Len:16
[2024/8/7 8:58:57 023] [08-07 19:11:14 TUYA D][simplekv.c:457] new space 10 startpos:33268 size:84
[2024/8/7 8:58:57 038] [08-07 19:11:14 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:58:57 038] [08-07 19:11:14 TUYA D][simplekv.c:203] update crc 1143988772
[2024/8/7 8:58:57 038] set basic_indicator_onoff:0 
[2024/8/7 8:58:57 054] [1970-01-01 00:01:11] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:57 054] [1970-01-01 00:01:11] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:57 070] [08-07 1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:57 070] 9:11:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:57 086] [08-07 19:11:14 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:57 087] [08-07 19:11:14 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 8:58:57 087] [08-07 19:11:14 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 8:58:57 103] [08-07 19:11:14 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 8:58:57 103] [08-07 19:11:14 TUYA D][simplekv.c:374] write key:gw_di And Value Len:416
[2024/8/7 8:58:57 103] [08-07 19:11:14 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416
[2024/8/7 8:58:57 118] [08-07 19:11:14 TUYA D][simplekv.c:430] find 2 available space
[2024/8/7 8:58:57 118] [08-07 19:11:14 TUYA D][simplekv.c:474] reuse available space 29188
[2024/8/7 8:58:57 134] [08-07 19:11:14 TUYA D][simplekv.c:203] update crc 2660144084
[2024/8/7 8:58:57 134] [08-07 19:11:14 TUYA D][simplekv.c:359[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:57 134] ] write head to normal file success
[2024/8/7 8:58:57 150] [08-07 19:11:14 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:57 150] [08-07 19:11:14 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 8:58:57 150] [08-07 19:11:14 TUYA D][simplekv.c:1211] read key:flvlrc isFuzzy:0 skipCnt:0
[2024/8/7 8:58:57 166] [08-07 19:11:14 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:57 166] [08-07 19:11:14 TUYA D][simplekv.c:1294] __read_kv_raw[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:57 166]  fail. -3
[2024/8/7 8:58:57 182] [08-07 19:11:14 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:57 182] [08-07 19:11:14 TUYA D][simplekv.c:374] write key:flvlrc And Value Len:2928
[2024/8/7 8:58:57 198] [08-07 19:11:14 TUYA D][simplekv.c:457] new space 11 startpos:33352 size:2996
[2024/8/7 8:58:57 198] [08-07 19:11:14 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:58:57 198] [08-07 19:11:14 TUYA D][simplekv.c:203] update crc 4011591785
[2024/8/7 8:58:57 214] [08-07 19:11:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:57 214] [08-07 19:11:14 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:57 214] [08-07 19:11:14 TUYA D][ws_db_gw.c:670] schema write success
[2024/8/7 8:58:57 230] [08-07 19:11:14 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success 
[2024/8/7 8:58:57 230] [08-07 19:11:14 TUYA D][tuya_ipc_sdk_init.c:183] ON post active:0x1705f58
[2024/8/7 8:58:57 246] [08-07 19:11:14 TUYA D][tuya_ipc_sdk_init.c:172] skillResult p2pId:[]
[2024/8/7 8:58:57 246] [08-07 19:11:14 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 8:58:57 246] [08-07 19:11:14 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 8:58:57 263] [08-07 19:11:14 TUYA D][simplekv.c:1280] key:gw_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:57 263] ai find value.Len:368
[2024/8/7 8:58:57 279] [08-07 19:11:14 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:544
[2024/8/7 8:58:57 279] [08-07 19:11:14 TUYA D][simplekv.c:394] 4 key same BUT size old 436 < new 544 need find new hd
[2024/8/7 8:58:57 279] [08-07 19:11:14 TUYA D][simplekv.c:457] new space 12 startpos:36348 size:612
[2024/8/7 8:58:57 295] [08-07 19:11:14 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:58:57 295] [08-07 19:11:14 TUYA D][simplekv.c:203] update crc 684634011
[2024/8/7 8:58:57 311] [08-07 19:11:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:57 311] [08-07 19:11:14 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:57 311] [08-07 19:11:14 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 8:58:57 327] [08-07 19:11:14 TUYA D][ws_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:57 343] db_gw.c:61] write buf:{"nc_tp":9,"ssid":"WGlhb21pX0YxREM=","passwd":"eG01MTI1MjA=","md":0,"random":0,"wfb64":1,"stat":2,"token":"pxRKWRjU","region":"AY","reg_key":"26MU","dns_prio":0 }
[2024/8/7 8:58:57 343] [08-07 19:11:14 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 8:58:57 358] [08-07 19:11:14 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 8:58:57 359] [08-07 19:11:14 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 8:58:57 359] [08-07 1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:58:57 375] 9:11:14 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:176
[2024/8/7 8:58:57 375] [08-07 19:11:14 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 176
[2024/8/7 8:58:57 375] [08-07 19:11:14 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 8:58:57 391] [08-07 19:11:14 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 8:58:57 391] [08-07 19:11:14 TUYA D][simplekv.c:203] update crc 1120241085
[2024/8/7 8:58:57 407] [08-07 19:11:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:57 407] [08-07 19:11:14 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:57 407] [08-07 19:11:14 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 8:58:57 423] __IPC_APP_Get_Net_Status_cb line(188) -------------------------- stat(1)==STAT_UNPROVISION 
[2024/8/7 8:58:57 423] [08-07 19:11:14 TUYA D][wifi_netcfg_frame_transporter.c:472] ----destroy Transporter,session:0x16c5d58
[2024/8/7 8:58:57 439] [08-07 19:11:14 TUYA D][tuya_devos_entry.c:560] dev_nw_cfg_active_stage:6
[2024/8/7 8:58:57 439] __IPC_APP_Get_Net_Status_cb line(198) -------------------------- stat(3)==STAT_AP_STA_DISC 
[2024/8/7 8:58:57 455] [08-07 19:11:14 TUYA N][tuya_bt_sdk.c:171] ty bt upd localkey
[2024/8/7 8:58:57 455] [08-07 19:11:14 TUYA N][tuya_ble_api.c:425] upd login key len:6
[2024/8/7 8:58:57 455] [08-07 19:11:14 TUYA I][mqc_app.c:387] mqc app start ...
[2024/8/7 8:58:57 471] [08-07 19:11:14 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883
[2024/8/7 8:58:57 471] [08-07 19:11:14 TUYA D][mqc_app.c:473] TLS disable
[2024/8/7 8:58:57 471] [08-07 19:11:14 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 8:58:57 487] [08-07 19:11:14 TUYA D][mqtt_client.c:321] subcribe_topic:smart/device/in/6c22076b2d2b61448fm8uy, client_id:6c22076b2d2b61448fm8uy, user_name:6c22076b2d2b61448fm8uy, passwd:55efd00495fd8a58
[2024/8/7 8:58:57 503] [08-07 19:11:14 TUYA D][mqtt_client.c:352] domain<0> m2.tuyacn.com:8883 HAVE PORT
[2024/8/7 8:58:57 503] [08-07 19:11:14 TUYA D][mqtt_client.c:355] PARSE m2.tuyacn.com:8883
[2024/8/7 8:58:57 519] [08-07 19:11:14 TUYA D][mqtt_client.c:383] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT
[2024/8/7 8:58:57 519] [08-07 19:11:14 TUYA D][mqtt_client.c:386] PARSE m2.tuyacn.com:1883
[2024/8/7 8:58:57 535] [08-07 19:11:14 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6c22076b2d2b61448fm8uy
[2024/8/7 8:58:57 535] [08-07 19:11:14 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6c22076b2d2b61448fm8uy
[2024/8/7 8:58:57 551] [08-07 19:11:14 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:25600,priority:4
[2024/8/7 8:58:57 567] [08-07 19:11:14 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[2024/8/7 8:58:57 567] [08-07 19:11:14 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[2024/8/7 8:58:57 567] [08-07 19:11:14 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[2024/8/7 8:58:57 582] [08-07 19:11:14 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 8:58:57 583] [08-07 19:11:14 TUYA N][bt_dp.c:228] bt rpt conn stat:9
[2024/8/7 8:58:57 583] [08-07 19:11:14 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 8:58:57 599] [08-07 19:11:14 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 8:58:57 599] bt_ack_uncrypt 2
[2024/8/7 8:58:57 599] 00 09 
[2024/8/7 8:58:57 599] [08-07 19:11:14 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 8:58:57 614] [08-07 19:11:14 TUYA D][tuya_ble_api.c:1005] start to get mesh
[2024/8/7 8:58:57 614] [08-07 19:11:14 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992339}
[2024/8/7 8:58:57 631] [08-07 19:11:14 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.mesh.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992339&v=1.0&sign=737c389ed8586ddd0cf53190d4f38f25
[2024/8/7 8:58:57 646] [08-07 19:11:14 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:58:57 648] [08-07 19:11:14 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:58:57 662] [08-07 19:11:14 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:58:57 663] [08-07 19:11:14 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:58:57 663] [08-07 19:11:14 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[2024/8/7 8:58:57 679] [08-07 19:11:14 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 8:58:57 679] [08-07 19:11:14 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:57 695] [08-07 19:11:14 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:57 695] [08-07 19:11:14 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:57 695] [08-07 19:11:14 TUYA D][tuya_svc_timer_task.c:146] no timer
[2024/8/7 8:58:57 711] [08-07 19:11:14 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[2024/8/7 8:58:57 711] [08-07 19:11:14 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[2024/8/7 8:58:57 711] [08-07 19:11:14 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[2024/8/7 8:58:57 727] [08-07 19:11:14 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6c22076b2d2b61448fm8uy
[2024/8/7 8:58:57 727] [08-07 19:11:14 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6c22076b2d2b61448fm8uy
[2024/8/7 8:58:57 742] [08-07 19:11:14 TUYA D][svc_online_log.c:317] svc online log active success
[2024/8/7 8:58:57 742] [08-07 08:58:59 TUYA D][tuya_ipc_sdk_init.c:137] sys stop timer: 14
[2024/8/7 8:58:57 743] 
[2024/8/7 8:58:57 758] [08-07 08:58:59 TUYA D][tuya_ipc_sdk_init.c:140] sys delete timer: 14
[2024/8/7 8:58:57 759] [08-07 08:58:59 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[2024/8/7 8:58:57 759] [08-07 08:58:59 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[2024/8/7 8:58:57 774] [08-07 08:58:59 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 8:58:57 774] dev id key: 16
[2024/8/7 8:58:57 774] f2 56 ed 25 80 48 ce 69 f5 84 2d 0a 16 61 5b 0c 
[2024/8/7 8:58:57 790] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 8:58:57 790] [08-07 08:58:59 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 8:58:57 790] 2 1 6 3 2 1 a2 14 16 1 a2 0 c4 2e b6 99 fc bc 6a 37 24 b1 9 75 5c 56 c0 9c 
[2024/8/7 8:58:57 806] [08-07 08:58:59 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 8:58:57 806] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 5b c7 1a 31 d4 74 9 6b a0 32 c4 7f ab 55 85 2f 
[2024/8/7 8:58:57 822] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 8:58:57 822] [08-07 08:58:59 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 8:58:57 838] [08-07 08:58:59 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 8:58:57 838] [08-07 08:58:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 8:58:57 838] tuya_hal_bt_send 20
[2024/8/7 8:58:57 854] 00 21 35 02 95 04 1b 83 bb 25 f6 ab 8a a0 76 d5 86 8c 0b 90 
[2024/8/7 8:58:57 854] [08-07 08:58:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 8:58:57 854] 0 21 35 2 95 4 1b 83 bb 25 f6 ab 8a a0 76 d5 86 8c b 90 
[2024/8/7 8:58:57 870] XmBleSendBuf 20: 00 21 35 02 95 04 1b 83 bb 25 f6 ab 8a a0 76 d5 86 8c 0b 90
[2024/8/7 8:58:57 870] GATT procedure initiated: notify; att_handle=23
[2024/8/7 8:58:57 870] ble_slave_gap_event->type=13
[2024/8/7 8:58:57 870] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 8:58:57 886] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 8:58:57 886] set basic_indicator_onoff:1 
[2024/8/7 8:58:57 886] [08-07 08:58:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 8:58:57 902] [08-07 08:58:59 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 8:58:57 902] [08-07 08:58:59 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 8:58:57 918] [1970-01-01 00:01:12] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:57 918] [08-07 08:58:59 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 8:58:57 934] [08-07 08:58:59 TUYA D][tuya_ipc_p2p_common.c:530] p2p passwd change to adb2c6d3
[2024/8/7 8:58:57 935] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:57 935] [08-07 08:58:59 TUYA D][iot_httpc.c:1161] Post Data: {"password":"adb2c6d3","t":1722992339}
[2024/8/7 8:58:57 966] [08-07 08:58:59 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.password.update&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992339&v=1.0&sign=8b1ce221bee9465a7bbced0a311c15d5
[2024/8/7 8:58:57 966] [08-07 08:58:59 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:58:57 982] [08-07 08:58:59 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:58:57 983] 
[2024/8/7 8:58:57 983] [08-07 08:58:59 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:58:57 983] [08-07 08:58:59 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:58:57 998] [08-07 08:58:59 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:58:57 998] [08-07 08:58:59 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:58:58 014] [08-07 08:58:59 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:58:58 014] [08-07 08:58:59 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:58:58 030] [08-07 08:58:59 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:58:58 030] [08-07 08:58:59 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:58:58 046] [08-07 08:58:59 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:58:58 046] [08-07 08:58:59 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:58:58 062] [08-07 08:58:59 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:58:58 062] [08-07 08:58:59 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:58:58 078] [08-07 08:58:59 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:58:58 078] [08-07 08:58:59 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:58:58 078] [08-07 08:58:59 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:58:58 095] [08-07 08:58:59 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:58:58 095] [1970-01-01 00:01:12] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:58:58 111] [08-07 08:58:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 8:58:58 111] tuya_hal_bt_send 17
[2024/8/7 8:58:58 111] 01 0e 14 63 0c c2 e6 01 65 45 c6 a7 b0 a3 43 ba da 
[2024/8/7 8:58:58 126] [08-07 08:58:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 8:58:58 126] 1 e 14 63 c c2 e6 1 65 45 c6 a7 b0 a3 43 ba da 
[2024/8/7 8:58:58 127] XmBleSendBuf 17: 01 0e 14 63 0c c2 e6 01 65 45 c6 a7 b0 a3 43 ba da
[2024/8/7 8:58:58 142] GATT procedure initiated: notify; att_handle=23
[2024/8/7 8:58:58 143] ble_slave_gap_event->type=13
[2024/8/7 8:58:58 143] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 8:58:58 143] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 8:58:58 159] [08-07 08:58:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 8:58:58 159] [08-07 08:58:59 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:58:58 174] [08-07 08:58:59 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:58:58 190] [08-07 08:58:59 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:58:58 206] [08-07 08:58:59 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:58:58 206] set basic_indicator_onoff:0 
[2024/8/7 8:58:58 207] [1970-01-01 00:01:12] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:58 222] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:58 223] [08-07 08:58:59 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 8:58:58 238] [08-07 08:58:59 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992339,"success":true}
[2024/8/7 8:58:58 239] [08-07 08:58:59 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:58:58 255] [1970-01-01 00:01:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:58:58 255] [08-07 08:58:59 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:58:58 255] [08-07 08:58:59 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 8:58:58 271] [08-07 08:58:59 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 8:58:58 271] [08-07 08:58:59 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 8:58:58 287] [08-07 08:58:59 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 8:58:58 287] [08-07 08:58:59 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 8:58:58 287] [08-07 08:58:59 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 8:58:58 303] [08-07 08:58:59 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 8:58:58 303] [08-07 08:58:59 TUYA D][simplekv.c:203] update crc 3710529939
[2024/8/7 8:58:58 320] [08-07 08:58:59 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"appKey":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","networkKey":"D59774254FA876FF1D204D16DF5223A5"},"t":1722992339,"success":true}
[2024/8/7 8:58:58 336] [08-07 08:58:59 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:58:58 337] [08-07 08:58:59 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:58:58 353] [08-07 08:58:59 TUYA D][tuya_ble_api.c:1014] start to write flash, app_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66", network_key:"D59774254FA876FF1D204D16DF5223A5"
[2024/8/7 8:58:58 353] [08-07 08:58:59 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:58 353] [08-07 08:58:59 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:58 367] [08-07 08:58:59 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 8:58:58 367] [08-07 08:58:59 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:58 382] [08-07 08:58:59 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:58 382] [08-07 08:58:59 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:58 383] [08-07 08:58:59 TUYA D][simplekv.c:374] write key:ble_app_key And Value Len:48
[2024/8/7 8:58:58 399] [08-07 08:58:59 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 48
[2024/8/7 8:58:58 399] [08-07 08:58:59 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 8:58:58 414] [08-07 08:58:59 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 8:58:58 414] [08-07 08:58:59 TUYA D][simplekv.c:203] update crc 401384796
[2024/8/7 8:58:58 414] [08-07 08:58:59 TUYA D][tuya_devos_utils.c:341] set gw ext_stat:2
[2024/8/7 8:58:58 430] [08-07 08:58:59 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 0
[2024/8/7 8:58:58 430] [08-07 08:58:59 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.30.165 for domain m2.tuyacn.com
[2024/8/7 8:58:58 446] [08-07 08:58:59 TUYA D][mqtt_client.c:1472] select mqtt host:m2.tuyacn.com
[2024/8/7 8:58:58 446] [08-07 08:58:59 TUYA N][mqtt_client.c:1493] mqtt get serve ip success
[2024/8/7 8:58:58 462] [08-07 08:58:59 TUYA D][mqtt_client.c:989] serverIP 717233829 port:8883
[2024/8/7 8:58:58 462] set basic_indicator_onoff:1 
[2024/8/7 8:58:58 462] [1970-01-01 00:01:12] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:58 478] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:58 479] 
[2024/8/7 8:58:58 479] [08-07 08:58:59 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:58 494] [08-07 08:58:59 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:58 494] [08-07 08:58:59 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 8:58:58 494] [08-07 08:58:59 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:58 510] [08-07 08:58:59 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:58 510] [08-07 08:58:59 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:58 526] [08-07 08:58:59 TUYA D][simplekv.c:374] write key:ble_network_key And Value Len:48
[2024/8/7 8:58:58 527] [08-07 08:58:59 TUYA D][simplekv.c:457] new space 13 startpos:36960 size:116
[2024/8/7 8:58:58 527] [08-07 08:58:59 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:58:58 542] [08-07 08:58:59 TUYA D][simplekv.c:203] update crc 1899987369
[2024/8/7 8:58:58 542] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 8:58:58 542] Len=20 step 0
[2024/8/7 8:58:58 558] att=0x0 0x21 0x20 0x2 0xf7 0x31 0x51 0xa8 0xb8 0x61 0x62 0x59 0xc6 0x57 0xe2 0xe7 0xca 0xa6 0x87 0xb8 
[2024/8/7 8:58:58 558]  RCVS len:20
[2024/8/7 8:58:58 558] [08-07 08:58:59 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:58 574] [08-07 08:58:59 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:58 574] [08-07 08:58:59 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992339}
[2024/8/7 8:58:58 590] [08-07 08:58:59 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.beacon.key.fetch&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992339&v=1.0&sign=0dc84fd15f3864b9abc83caf91a0dd4e
[2024/8/7 8:58:58 591] [08-07 08:58:59 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:58:58 606] [08-07 08:58:59 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:58:58 607] [08-07 08:58:59 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:58:58 622] 
[2024/8/7 8:58:58 623] [08-07 08:58:59 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:58:58 623] XmBleReadBuf 20:
[2024/8/7 8:58:58 623] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 8:58:58 638] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 8:58:58 639] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 8:58:58 639] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 8:58:58 655] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 8:58:58 655] [08-07 08:58:59 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 8:58:58 670] [08-07 08:58:59 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 8:58:58 671] [08-07 08:58:59 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 8:58:58 671] bt_rev_raw 20
[2024/8/7 8:58:58 671] 00 21 20 02 f7 31 51 a8 b8 61 62 59 c6 57 e2 e7 ca a6 87 b8 
[2024/8/7 8:58:58 687] [08-07 08:58:59 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 8:58:58 687] [08-07 08:58:59 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 8:58:58 703] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 8:58:58 703] [08-07 08:58:59 TUYA D][mqtt_client.c:1014] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883
[2024/8/7 8:58:58 718] [08-07 08:58:59 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:58:58 734] [08-07 08:58:59 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyacn.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:58:58 735] [08-07 08:58:59 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:58:58 735] [08-07 08:58:59 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:58:58 750] [08-07 08:58:59 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:58:58 751] [08-07 08:58:59 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:58:58 766] [08-07 08:58:59 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:58:58 767] [08-07 08:58:59 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:58:58 782] [08-07 08:58:59 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:58:58 783] [08-07 08:58:59 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:58:58 798] [08-07 08:58:59 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:58:58 799] [08-07 08:58:59 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:58:58 799] [08-07 08:58:59 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:58:58 814] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 8:58:58 815] Len=17 step 0
[2024/8/7 8:58:58 815] att=0x1 0x1 0xd7 0x4a 0x76 0x1a 0x46 0x10 0x98 0xd4 0xe4 0xf7 0xc4 0xe6 0xa 0xef 0xac 
[2024/8/7 8:58:58 815]  RCVS len:17
[2024/8/7 8:58:58 830] [08-07 08:58:59 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:58:58 846] [08-07 08:58:59 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:58:58 846] set basic_indicator_onoff:0 
[2024/8/7 8:58:58 846] [1970-01-01 00:01:12] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:58 862] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:58 862] [1970-01-01 00:01:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:58:58 879] XmBleReadBuf 17:
[2024/8/7 8:58:58 879] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 8:58:58 880] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 8:58:58 880] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 8:58:58 894] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 8:58:58 894] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 8:58:58 910] [08-07 08:58:59 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 8:58:58 910] [08-07 08:58:59 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 8:58:58 926] [08-07 08:58:59 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 8:58:58 926] bt_rev_raw 17
[2024/8/7 8:58:58 926] 01 01 d7 4a 76 1a 46 10 98 d4 e4 f7 c4 e6 0a ef ac 
[2024/8/7 8:58:58 926] [08-07 08:58:59 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 8:58:58 942] ble rev data 33
[2024/8/7 8:58:58 942] 02 f7 31 51 a8 b8 61 62 59 c6 57 e2 e7 ca a6 87 b8 01 d7 4a 76 1a 46 10 98 d4 e4 f7 c4 e6 0a ef ac 
[2024/8/7 8:58:58 942] ble decryped data 16
[2024/8/7 8:58:58 958] 00 00 00 05 00 00 00 00 00 22 00 01 00 13 18 00 
[2024/8/7 8:58:58 958] [08-07 08:58:59 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 8:58:58 958] [08-07 08:58:59 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 8:58:58 974] [08-07 08:58:59 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 8:58:58 974] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 8:58:58 990] [08-07 08:58:59 TUYA D][app_agent.c:706] udp ip: 192.168.31.144
[2024/8/7 8:58:58 990] [08-07 08:58:59 TUYA D][iot_httpc.c:601] Decode Rev:{"result":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","t":1722992340,"success":true}
[2024/8/7 8:58:59 006] [08-07 08:59:00 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:58:59 006] [08-07 08:59:00 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:58:59 022] [08-07 08:59:00 TUYA D][tuya_ble_api.c:986] start to write flash, beacon_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66"
[2024/8/7 8:58:59 022] [08-07 08:59:00 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 8:58:59 022] [08-07 08:59:00 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:59 038] [08-07 08:59:00 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:59 038] [08-07 08:59:00 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:59 054] [08-07 08:59:00 TUYA D][simplekv.c:374] write key:ble_beaconkey And Value Len:48
[2024/8/7 8:58:59 054] [08-07 08:59:00 TUYA D][simplekv.c:457] new space 14 startpos:37076 size:116
[2024/8/7 8:58:59 054] [08-07 08:59:00 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:58:59 070] [08-07 08:59:00 TUYA D][simplekv.c:203] update crc 1132059661
[2024/8/7 8:58:59 070] [08-07 08:59:00 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:59 086] [08-07 08:59:00 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:59 087] [08-07 08:59:00 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 8:58:59 087] [08-07 08:59:00 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 8:58:59 102] [1970-01-01 00:01:12] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 8:58:59 102] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 8:58:59 102] set basic_indicator_onoff:1 
[2024/8/7 8:58:59 118] [1970-01-01 00:01:12] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:59 118] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:59 134] set basic_indicator_onoff:0 
[2024/8/7 8:58:59 134] [1970-01-01 00:01:12] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:59 150] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:59 151] set basic_indicator_onoff:1 
[2024/8/7 8:58:59 151] [1970-01-01 00:01:12] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:59 167] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:59 167] set basic_indicator_onoff:0 
[2024/8/7 8:58:59 182] [1970-01-01 00:01:12] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:59 183] [1970-01-01 00:01:12] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:59 198] [08-07 08:59:00 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyacn.com. set send/recv to user set
[2024/8/7 8:58:59 214] [08-07 08:59:00 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyacn.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:58:59 215] [08-07 08:59:00 TUYA N][mqtt_client.c:1531] mqtt create success, begin to connect
[2024/8/7 8:58:59 215] [08-07 08:59:00 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 8:58:59 215] set basic_indicator_onoff:1 
[2024/8/7 8:58:59 230] [1970-01-01 00:01:13] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:59 248] [1970-01-01 00:01:13] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:59 248] [08-07 08:59:00 TUYA D][mqtt_client.c:1413] cnt 1
[2024/8/7 8:58:59 248] [08-07 08:59:00 TUYA D][mqtt_client.c:1104] mqtt subscribe success
[2024/8/7 8:58:59 262] [08-07 08:59:00 TUYA D][mqc_app.c:732] mqtt connect success
[2024/8/7 8:58:59 262] [08-07 08:59:00 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[2024/8/7 8:58:59 262] [08-07 08:59:00 TUYA D][mqtt_client.c:1994] subscribe new topic /av/d/6c22076b2d2b61448fm8uy ret:1 
[2024/8/7 8:58:59 280] [08-07 08:59:00 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[2024/8/7 8:58:59 280] __IPC_APP_Get_Net_Status_cb line(243) -------------------------- stat(11)==STAT_MQTT_ONLINE 
[2024/8/7 8:58:59 280] curr event:11 
[2024/8/7 8:58:59 294] IPC_APP_Notify_LED_Sound_Status_CB line(550) -------------------------- IPC_MQTT_ONLINE(11)
[2024/8/7 8:58:59 294] set basic_indicator_onoff:0 
[2024/8/7 8:58:59 310] [1970-01-01 00:01:13] tuya_ipc_system_control_demo.c(551) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(DEVICE_ONLINE, 0, 0, 0, 1))
[2024/8/7 8:58:59 310] Disable Qrcode
[2024/8/7 8:58:59 326] [1970-01-01 00:01:13] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:59 342] [1970-01-01 00:01:13] tuya_ipc_system_control_demo.c(558) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONFIG_SUCCESS, 0, 0, 0, 1))
[2024/8/7 8:58:59 342] [1970-01-01 00:01:13] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:58:59 358] [1970-01-01 00:01:13] xm_musicPlayer.cpp(91) <PlayAudioTips>: Open audio file /usr/share/audios/_english.pcm failed, No such file or directory
[2024/8/7 8:58:59 358] mqtt subscribe ack 5
[2024/8/7 8:58:59 374] 90 03 00 02 00 [1970-01-01 00:01:13] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/AddSuccess_english.pcm]
[2024/8/7 8:58:59 374] [1970-01-01 00:01:13] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 8:58:59 390] [1970-01-01 00:01:13] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 8:58:59 390] set basic_indicator_onoff:1 
[2024/8/7 8:58:59 406] [1970-01-01 00:01:13] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:58:59 406] [1970-01-01 00:01:13] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:58:59 407] 
[2024/8/7 8:58:59 422] [08-07 08:59:01 TUYA D][MainApp.c:537] tuya_ipc_sdk_mqtt_online_proc is start run
[2024/8/7 8:58:59 423] [08-07 08:59:01 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992341 28800
[2024/8/7 8:58:59 438] [08-07 08:59:01 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992341 28800
[2024/8/7 8:58:59 439] Init tuya_ipc_ss_init
[2024/8/7 8:58:59 439] [08-07 08:59:01 TUYA D][tuya_ipc_stream_storage.c:2015] Init stream_storage.base_path:/mnt/mmc v:4 a:101, max event per day 289 skills 1
[2024/8/7 8:58:59 455] [08-07 08:59:01 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:35 ip:0xc0a81ff2
[2024/8/7 8:58:59 455] [08-07 08:59:01 TUYA D][tuya_ipc_stream_storage.c:2161] stream storage task init success
[2024/8/7 8:58:59 470] [08-07 08:59:01 TUYA D][MainApp.c:567] local storage init result is 0
[2024/8/7 8:58:59 471] [08-07 08:59:01 TUYA D][tuya_ipc_stream_storage.c:1571] SD task begin___
[2024/8/7 8:58:59 486] [08-07 08:59:01 TUYA D][tuya_ipc_stream_storage.c:1585] report sd status 0 -> 5
[2024/8/7 8:58:59 487] 
[2024/8/7 8:58:59 487] [08-07 08:59:01 TUYA E][tuya_ipc_stream_storage.c:1914] storage not inited
[2024/8/7 8:58:59 502] [08-07 08:59:01 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 3
[2024/8/7 8:58:59 503] [08-07 08:59:01 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 8:58:59 503] [08-07 08:59:01 TUYA D][app_agent.c:961] local_key
[2024/8/7 8:58:59 519] [08-07 08:59:01 TUYA D][app_agent.c:600] send length:64, id:35, sequence_out:14047
[2024/8/7 8:58:59 519] [08-07 08:59:01 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 8:58:59 519] [08-07 08:59:01 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 8:58:59 535] [08-07 08:59:01 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 5
[2024/8/7 8:58:59 535] [08-07 08:59:01 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 8:58:59 535] [08-07 08:59:01 TUYA D][app_agent.c:961] local_key
[2024/8/7 8:58:59 551] [08-07 08:59:01 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 16
[2024/8/7 8:58:59 551] [08-07 08:59:01 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 8:58:59 551] [08-07 08:59:01 TUYA D][app_agent.c:958] session_key
[2024/8/7 8:58:59 567] [08-07 08:59:01 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:0,dpnum:41.
[2024/8/7 8:58:59 567] [08-07 08:59:01 TUYA D][smart_frame.c:2517] Nothing To Pack
[2024/8/7 8:58:59 567] [08-07 08:59:01 TUYA D][app_agent.c:1234] nothing to report
[2024/8/7 8:58:59 583] [08-07 08:59:01 TUYA D][app_agent.c:600] send length:32, id:35, sequence_out:14048
[2024/8/7 8:58:59 583] [08-07 08:59:01 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 8:58:59 599] [08-07 08:59:01 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:59 599] [08-07 08:59:01 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:59 599] [08-07 08:59:01 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:59 615] [08-07 08:59:01 TUYA E][svc_online_log_db.c:25] ret:-6
[2024/8/7 8:58:59 615] [08-07 08:59:01 TUYA D][svc_online_log.c:182] load env fail. maybe not exist.
[2024/8/7 8:58:59 631] [08-07 08:59:01 TUYA D][svc_online_log.c:187] update property:{"value":"{\"embed_sys_env\":\"arm-xm-linux\"}"}
[2024/8/7 8:58:59 631] [08-07 08:59:01 TUYA D][iot_httpc.c:1161] Post Data: {"value":"{\"embed_sys_env\":\"arm-xm-linux\"}","t":1722992341}
[2024/8/7 8:58:59 662] [08-07 08:59:01 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.property.save&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992341&v=1.0&sign=90bb17883f561a4154e2ca1fb229ce21
[2024/8/7 8:58:59 662] [08-07 08:59:01 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:58:59 662] [08-07 08:59:01 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:58:59 678] [08-07 08:59:01 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:58:59 678] [08-07 08:59:01 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:58:59 694] [08-07 08:59:01 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:58:59 694] [08-07 08:59:01 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:58:59 710] [08-07 08:59:01 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:58:59 710] [08-07 08:59:01 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:58:59 726] [08-07 08:59:01 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:58:59 726] [08-07 08:59:01 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:58:59 742] [08-07 08:59:01 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:58:59 742] [08-07 08:59:01 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:58:59 758] [08-07 08:59:01 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:58:59 758] [08-07 08:59:01 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992341,"success":true}
[2024/8/7 8:58:59 774] [08-07 08:59:01 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:58:59 774] [08-07 08:59:01 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:58:59 790] [08-07 08:59:01 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 8:58:59 790] [08-07 08:59:01 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:58:59 790] [08-07 08:59:01 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:58:59 806] [08-07 08:59:01 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:58:59 806] [08-07 08:59:01 TUYA D][simplekv.c:374] write key:em_sys_env And Value Len:32
[2024/8/7 8:58:59 822] [08-07 08:59:01 TUYA D][simplekv.c:457] new space 15 startpos:37192 size:100
[2024/8/7 8:58:59 822] [08-07 08:59:01 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:58:59 822] [08-07 08:59:01 TUYA D][simplekv.c:203] update crc 325624754
[2024/8/7 8:58:59 838] [08-07 08:59:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:58:59 838] [08-07 08:59:01 TUYA D][simplekv.c:520] write success
[2024/8/7 8:58:59 854] [08-07 08:59:01 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[2024/8/7 8:58:59 854] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 8:58:59 870] [08-07 08:59:01 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
[2024/8/7 8:58:59 870] [08-07 08:59:01 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:2  -->>
[2024/8/7 8:58:59 870] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 8:58:59 886] [08-07 08:59:01 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:2  <<--
[2024/8/7 8:58:59 886] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:58:59 902] [08-07 08:59:01 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 8:58:59 918] [08-07 08:59:01 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 8:58:59 919] [1970-01-01 00:01:14] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time44820
[2024/8/7 8:58:59 934] [08-07 08:59:02 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992342}
[2024/8/7 8:58:59 950] [08-07 08:59:02 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.uuid.pskkey.get&et=1&t=1722992342&uuid=uuidcaab27b0a838d239&v=1.0&sign=c1ad2e82d036e1fc2db839c495a6f32b
[2024/8/7 8:58:59 950] [08-07 08:59:02 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:58:59 966] [08-07 08:59:02 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:58:59 966] [08-07 08:59:02 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:58:59 967] 
[2024/8/7 8:58:59 982] [08-07 08:59:02 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:58:59 983] [08-07 08:59:02 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:58:59 999] [08-07 08:59:02 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:58:59 999] [08-07 08:59:02 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:00 015] [08-07 08:59:02 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:00 015] [08-07 08:59:02 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:00 015] [08-07 08:59:02 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:00 031] [08-07 08:59:02 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:00 031] [08-07 08:59:02 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:00 047] [08-07 08:59:02 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:00 062] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 8:59:00 078] Mode(Product):0
[2024/8/7 8:59:00 078] BpuMode:[Online]
[2024/8/7 8:59:00 078] VpssMode:[Online]
[2024/8/7 8:59:00 078] [0.LimitUp_info]:
[2024/8/7 8:59:00 078] LimitUp:[Disable]
[2024/8/7 8:59:00 078] [2680*0]->[3840*0])
[2024/8/7 8:59:00 078] chn	TotalSize	ActiveSize
[2024/8/7 8:59:00 079] 0	5034*2246	2680*2160
[2024/8/7 8:59:00 079] 0	5040*2246	2680*2160
[2024/8/7 8:59:00 094] 0	5040*2246	3840*2160
[2024/8/7 8:59:00 094] Repair: En:1	Cnt:0x00000000
[2024/8/7 8:59:00 094] [1.VICU_info]:
[2024/8/7 8:59:00 095] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 8:59:00 095] 0	25.0	928	0	0	183	linear	8ddb00
[2024/8/7 8:59:00 095] 0	0.0	0	0	0	0	linear	0
[2024/8/7 8:59:00 110] 0	0.0	0	0	0	0	linear	0
[2024/8/7 8:59:00 110] en	op_type	m_chn	now
[2024/8/7 8:59:00 110] 0	1	1	1
[2024/8/7 8:59:00 110] [2.VI_info]:
[2024/8/7 8:59:00 110] chn	TotalSize	ActiveSize
[2024/8/7 8:59:00 110] 0	5040*2246	3848*2166
[2024/8/7 8:59:00 111] 1	   0*   0	   0*   0
[2024/8/7 8:59:00 111] [3.MIPI_info]:
[2024/8/7 8:59:00 126] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 8:59:00 126] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 8:59:00 126] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 8:59:00 126] [4.Cut_info]:
[2024/8/7 8:59:00 142] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 8:59:00 142] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 8:59:00 142] h_d	0	1	 	 	2684	2160	  
[2024/8/7 8:59:00 142] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 8:59:00 142] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 8:59:00 142] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 8:59:00 159] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 8:59:00 159] [5.IB(isp buffer info)]:
[2024/8/7 8:59:00 159] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 8:59:00 159] PoolId  Count  Size
[2024/8/7 8:59:00 174] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:00 174] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:00 190] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:00 190] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:00 190] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:00 206] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:00 206] [1970-01-01 00:01:15] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:59:00 222] [08-07 08:59:02 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c22076b2d2b61448fm8uy, dp_rept_chan:3
[2024/8/7 8:59:00 222] [08-07 08:59:02 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 8:59:00 238] [08-07 08:59:02 TUYA D][smart_frame.c:2517] Nothing To Pack
[2024/8/7 8:59:00 238] [08-07 08:59:02 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 8:59:00 238] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 8:59:00 254] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 8:59:00 254] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 8:59:00 254] 0       0         0          0          4       
[2024/8/7 8:59:00 270] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 8:59:00 270]      --265--            --264--                                               
[2024/8/7 8:59:00 270] Count      Line     Count      Line     
[2024/8/7 8:59:00 286] 727        437      1632       560      
[2024/8/7 8:59:00 286] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 8:59:00 286] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 8:59:00 302] 0   3840   2160    H265  0      0        0           433       872241     110799   	
[2024/8/7 8:59:00 302] 1   640    360     H265  0      0        0           284       43193      7        	
[2024/8/7 8:59:00 318] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 8:59:00 318] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 8:59:00 334] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 8:59:00 350] 0   Y      433      0       0       14       1        432      432      573       59088         58576    149384   65469    12      
[2024/8/7 8:59:00 350] 1   Y      284      0       9       1        0        284      284      574       2542          1876     24791    2850     9       
[2024/8/7 8:59:00 366] 3   N      0        0       0       1        0        0        0        574       0             0        0        0        0       
[2024/8/7 8:59:00 382] [1970-01-01 00:01:15] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:59:00 398] [08-07 08:59:02 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"pskKey":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80"},"t":1722992342,"success":true}
[2024/8/7 8:59:00 398] [08-07 08:59:02 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:00 398] [08-07 08:59:02 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:00 430] [08-07 08:59:02 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80","auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 8:59:00 430] [08-07 08:59:02 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 8:59:00 446] [08-07 08:59:02 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 8:59:00 446] [08-07 08:59:02 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 8:59:00 446] [08-07 08:59:02 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:256
[2024/8/7 8:59:00 462] [08-07 08:59:02 TUYA D][simplekv.c:397] 0 key same AND size old 276 >= new 256
[2024/8/7 8:59:00 462] [08-07 08:59:02 TUYA D][simplekv.c:430] find 0 available space
[2024/8/7 8:59:00 478] [08-07 08:59:02 TUYA D][simplekv.c:474] reuse available space 28700
[2024/8/7 8:59:00 478] [08-07 08:59:02 TUYA D][simplekv.c:203] update crc 4076842051
[2024/8/7 8:59:00 478] [08-07 08:59:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:00 494] [08-07 08:59:02 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:00 494] [08-07 08:59:02 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 8:59:00 590] [08-07 08:59:03 TUYA D][tuya_ble_api.c:1417] cloud connected, stop adv!
[2024/8/7 8:59:00 605] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(640): stop_adv ---
[2024/8/7 8:59:00 606] exit_ble_thread create suc
[2024/8/7 8:59:00 606] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(644): XmBleAdvStop ---
[2024/8/7 8:59:00 621] [08-07 08:59:03 TUYA D][tuya_ble_api.c:1376] nw stat change:1->2, rpt to app.
[2024/8/7 8:59:00 622] [08-07 08:59:03 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:2
[2024/8/7 8:59:00 622] [08-07 08:59:03 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 8:59:00 638] [08-07 08:59:03 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 8:59:00 638] bt_ack_uncrypt 1
[2024/8/7 8:59:00 638] 02 
[2024/8/7 8:59:00 638] [08-07 08:59:03 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 8:59:00 654] [08-07 08:59:03 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 8:59:00 654] tuya_hal_bt_send 20
[2024/8/7 8:59:00 654] 00 21 36 05 2f 30 50 ce ad eb 99 c9 02 3f 7e 46 45 ab 87 83 
[2024/8/7 8:59:00 670] [08-07 08:59:03 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 8:59:00 670] 0 21 36 5 2f 30 50 ce ad eb 99 c9 2 3f 7e 46 45 ab 87 83 
[2024/8/7 8:59:00 686] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 8:59:00 686] [08-07 08:59:03 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 8:59:00 686] --- tracepoint bt_ext_porting.c,ty_btext_thread(433): tuya_hal_thread_release ---
[2024/8/7 8:59:00 702] [08-07 08:59:03 TUYA E][bt_ext_porting.c:434] [TUYA-BTUART]ty_btext_thread deleted
[2024/8/7 8:59:00 702] set sd_record_on_off:1 
[2024/8/7 8:59:00 702] set sd_record_mode:0 
[2024/8/7 8:59:00 718] [08-07 08:59:03 TUYA E][tuya_ipc_stream_storage.c:1912] the ss mgr not inited, but msg buffered: set mode 1
[2024/8/7 8:59:00 718] [08-07 08:59:03 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 8:59:00 718] tuya_hal_bt_send 17
[2024/8/7 8:59:00 734] 01 83 7a c0 0a a1 3f 83 d6 9b 4c a1 5c 37 70 9b f9 
[2024/8/7 8:59:00 734] [08-07 08:59:03 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 8:59:00 734] 1 83 7a c0 a a1 3f 83 d6 9b 4c a1 5c 37 70 9b f9 
[2024/8/7 8:59:00 750] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 8:59:00 750] [08-07 08:59:03 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 8:59:00 750] write RecordMode success  0 
[2024/8/7 8:59:00 766] [08-07 08:59:03 TUYA D][tuya_ipc_cloud_storage.c:2188] init cloud storage begin
[2024/8/7 8:59:00 766] [08-07 08:59:03 TUYA D][simplekv.c:1211] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[2024/8/7 8:59:00 783] [08-07 08:59:03 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:00 783] [08-07 08:59:03 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:00 783] [08-07 08:59:03 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:00 799] [08-07 08:59:03 TUYA E][tuya_ipc_cloud_storage.c:365] iot_wd_common_read fails md5_encrypt_key -6
[2024/8/7 8:59:00 799] [08-07 08:59:03 TUYA E][tuya_ipc_cloud_storage.c:450] read key_key file failed.
[2024/8/7 8:59:00 816] [08-07 08:59:03 TUYA D][tuya_ipc_cloud_storage.c:2240] __check_md5_encrypt_key fail, need update from server
[2024/8/7 8:59:00 831] [08-07 08:59:03 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 8:59:00 831] [08-07 08:59:03 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:00 831] [08-07 08:59:03 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:00 847] [08-07 08:59:03 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:00 847] [08-07 08:59:03 TUYA E][tuya_ipc_cloud_storage.c:942] iot_wd_common_read fails storage_restriction -6
[2024/8/7 8:59:00 864] [08-07 08:59:03 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992343}
[2024/8/7 8:59:00 879] [08-07 08:59:03 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.restriction.config.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992343&v=1.0&sign=296f4905f1ac113c10e1ee6cf4a607ad
[2024/8/7 8:59:00 879] [08-07 08:59:03 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:00 895] [08-07 08:59:03 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:00 895] [08-07 08:59:03 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:00 910] [08-07 08:59:03 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:00 912] [08-07 08:59:03 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:00 912] [08-07 08:59:03 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:00 929] [08-07 08:59:03 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:00 929] [08-07 08:59:03 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:00 942] [08-07 08:59:03 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:00 942] [08-07 08:59:03 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:00 958] [08-07 08:59:03 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:00 958] [08-07 08:59:03 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 8:59:00 974] [08-07 08:59:03 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:00 990] [08-07 08:59:03 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:01 006] [08-07 08:59:03 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"msg":{"audioDuration":15,"audioInterval":300,"videoDuration":6,"videoInterval":300},"storage":{"mtu":10}},"t":1722992343,"success":true}
[2024/8/7 8:59:01 006] [08-07 08:59:03 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:01 006] [08-07 08:59:03 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:01 022] [08-07 08:59:03 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 8:59:01 022] [08-07 08:59:03 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:01 038] [08-07 08:59:03 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:01 038] [08-07 08:59:03 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:01 054] [08-07 08:59:03 TUYA D][simplekv.c:374] write key:storage_restriction And Value Len:32
[2024/8/7 8:59:01 055] [08-07 08:59:03 TUYA D][simplekv.c:457] new space 16 startpos:37292 size:100
[2024/8/7 8:59:01 055] [08-07 08:59:03 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:59:01 070] [08-07 08:59:03 TUYA D][simplekv.c:203] update crc 117552742
[2024/8/7 8:59:01 070] [08-07 08:59:03 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:01 070] [08-07 08:59:03 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:01 086] [08-07 08:59:03 TUYA D][tuya_ipc_cloud_storage.c:920] slice_duration write success
[2024/8/7 8:59:01 086] [08-07 08:59:03 TUYA D][tuya_ipc_cloud_storage.c:999] case 2 get slice duration from cloud 10
[2024/8/7 8:59:01 102] [08-07 08:59:03 TUYA D][tuya_ipc_cloud_storage.c:1043] cloud storage seize 3059584 bytes memory for media data, each slice 10 seconds
[2024/8/7 8:59:01 118] [08-07 08:59:03 TUYA I][uni_thread.c:228] thread_create name:cloud_storage,stackDepth:65536,totalstackDepth:91136,priority:3
[2024/8/7 8:59:01 118] [08-07 08:59:03 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[2024/8/7 8:59:01 134] [08-07 08:59:03 TUYA D][tuya_ipc_cloud_storage.c:2289] init cloud storage success
[2024/8/7 8:59:01 134] [08-07 08:59:03 TUYA D][MainApp.c:590] cloud storage init result is 0
[2024/8/7 8:59:01 134] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 150] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 150] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:01 166] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 166] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"105":false}
[2024/8/7 8:59:01 182] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43530 Q:1 Data:{"dps":{"105":false}}
[2024/8/7 8:59:01 182] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 198] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 198] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 8:59:01 214] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 214] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"101":true}
[2024/8/7 8:59:01 230] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43531 Q:1 Data:{"dps":{"101":true}}
[2024/8/7 8:59:01 230] [08-07 08:59:03 TUYA D][uni_thread.c:250] Thread:cloud_storage Exec Start. Set to Running Stat
[2024/8/7 8:59:01 246] [08-07 08:59:03 TUYA D][iot_httpc.c:1161] Post Data: {"type":"MediaStor","t":1722992343}
[2024/8/7 8:59:01 262] [08-07 08:59:03 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992343&v=3.0&sign=2267aa82975dfd888e0c031ecb23b230
[2024/8/7 8:59:01 262] [08-07 08:59:03 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:01 278] [08-07 08:59:03 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:01 278] [08-07 08:59:03 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:01 294] [08-07 08:59:03 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:01 294] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 310] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 310] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:01 310] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 326] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"103":false}
[2024/8/7 8:59:01 326] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43532 Q:1 Data:{"dps":{"103":false}}
[2024/8/7 8:59:01 342] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 342] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 358] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 8:59:01 358] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 374] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"104":true}
[2024/8/7 8:59:01 374] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43533 Q:1 Data:{"dps":{"104":true}}
[2024/8/7 8:59:01 374] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 390] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:107 not find
[2024/8/7 8:59:01 390] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:01 406] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:01 406] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 406] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:108 not find
[2024/8/7 8:59:01 422] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:01 422] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:01 422] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 8:59:01 438] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 8:59:01 438] DEBUG: camera_set_dnc_mode_chn 0 
[2024/8/7 8:59:01 438] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 8:59:01 438] DEBUG: software pohtoR!
[2024/8/7 8:59:01 454] IPC_APP_get_smart_mutile_light_mode line(546) ----------  
[2024/8/7 8:59:01 454] IPC_APP_set_smart_mutile_light_mode line(451) ---------- :0 ,g_SMLAbility=[0]
[2024/8/7 8:59:01 470] IPC_APP_set_smart_mutile_light_mode line(536) ---------- :mode=[0] 
[2024/8/7 8:59:01 470] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 486] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<124> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 486] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 486] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"124":"auto"}
[2024/8/7 8:59:01 501] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43534 Q:1 Data:{"dps":{"124":"auto"}}
[2024/8/7 8:59:01 501] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 517] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 518] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 8:59:01 533] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 533] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"134":true}
[2024/8/7 8:59:01 550] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43535 Q:1 Data:{"dps":{"134":true}}
[2024/8/7 8:59:01 550] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 566] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 567] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 582] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"106":"1"}
[2024/8/7 8:59:01 582] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43536 Q:1 Data:{"dps":{"106":"1"}}
[2024/8/7 8:59:01 582] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 598] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:168 not find
[2024/8/7 8:59:01 598] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:01 614] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:01 614] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(855):  ---
[2024/8/7 8:59:01 614] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(866):  ---
[2024/8/7 8:59:01 630] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(872):  ---
[2024/8/7 8:59:01 630] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(892):  ---
[2024/8/7 8:59:01 646] [IPC_APP_get_alarm_zone_draw][893] alarm zone[{\"num\":1,\"region0\":{\"x\":1,\"y\":1,\"xlen\":99,\"ylen\":99}}]
[2024/8/7 8:59:01 646] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 662] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:169 not find
[2024/8/7 8:59:01 662] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:01 663] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:01 663] curr sd_status:1 
[2024/8/7 8:59:01 678] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 678] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 694] [08-07 08:59:03 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:5
[2024/8/7 8:59:01 694] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 710] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"110":5}
[2024/8/7 8:59:01 710] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43537 Q:1 Data:{"dps":{"110":5}}
[2024/8/7 8:59:01 726] [08-07 08:59:03 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 8:59:01 726] [08-07 08:59:03 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 8:59:01 726] [08-07 08:59:03 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 8:59:01 742] [08-07 08:59:03 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:01 742] [08-07 08:59:03 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:01 757] [08-07 08:59:03 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:01 758] [08-07 08:59:03 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:01 774] [08-07 08:59:03 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:01 774] [08-07 08:59:03 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:01 774] [08-07 08:59:03 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:01 790] [08-07 08:59:03 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 8:59:01 790] handle_DP_SD_STORAGE_ONLY_GET line(654) --------------------- 
[2024/8/7 8:59:01 806] [1970-01-01 00:01:16] tuya_ipc_sd_demo.c(182) <tuya_ipc_sd_get_capacity>: XM_SDCardGetPartitionInfo failed
[2024/8/7 8:59:01 806] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:01 822] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:01 822] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:01 838] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0"}
[2024/8/7 8:59:01 838] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43538 Q:1 Data:{"dps":{"109":"0|0|0"}}
[2024/8/7 8:59:01 854] [08-07 08:59:03 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 8:59:01 854] [08-07 08:59:03 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 8:59:01 854] [08-07 08:59:03 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 8:59:01 870] [08-07 08:59:03 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 8:59:01 870] [08-07 08:59:03 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 8:59:01 885] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[2024/8/7 8:59:01 885] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:105, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:01 901] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:105, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:01 902] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:105, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:01 917] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0
[2024/8/7 8:59:01 918] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:101, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:01 934] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:101, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:01 950] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:101, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:01 950] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0
[2024/8/7 8:59:01 966] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:103, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:01 966] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:103, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:01 982] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:103, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:01 982] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0
[2024/8/7 8:59:01 998] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:104, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:02 014] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:104, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:02 014] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:104, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:02 030] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"124":"auto"}}, mqtt async dp cb:0
[2024/8/7 8:59:02 030] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:124, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:02 046] [08-07 08:59:03 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:02 062] [08-07 08:59:03 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:02 062] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:124, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:02 078] [08-07 08:59:03 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 8:59:02 078] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"105":false}} pro:4 num:43530
[2024/8/7 8:59:02 094] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"105":false}}} offset:58
[2024/8/7 8:59:02 094] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"105":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:02 110] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14049
[2024/8/7 8:59:02 110] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"101":true}} pro:4 num:43531
[2024/8/7 8:59:02 126] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"101":true}}} offset:57
[2024/8/7 8:59:02 126] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:02 142] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"101":true}}, msg_len:20, out_len:72
[2024/8/7 8:59:02 142] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14050
[2024/8/7 8:59:02 158] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"103":false}} pro:4 num:43532
[2024/8/7 8:59:02 174] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"103":false}}} offset:58
[2024/8/7 8:59:02 174] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"103":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:02 190] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:124, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:02 190] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14051
[2024/8/7 8:59:02 206] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"104":true}} pro:4 num:43533
[2024/8/7 8:59:02 206] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0
[2024/8/7 8:59:02 222] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"104":true}}} offset:57
[2024/8/7 8:59:02 238] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:02 238] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 8:59:02 238] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:02 254] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"104":true}}, msg_len:20, out_len:72
[2024/8/7 8:59:02 270] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:134, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:02 270] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:134, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:02 286] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:134, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:02 286] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14052
[2024/8/7 8:59:02 302] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"124":"auto"}} pro:4 num:43534
[2024/8/7 8:59:02 302] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"124":"auto"}}} offset:59
[2024/8/7 8:59:02 318] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"124":"auto"}}, msg_len:22, out_len:74
[2024/8/7 8:59:02 318] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"106":"1"}}, mqtt async dp cb:0
[2024/8/7 8:59:02 334] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14053
[2024/8/7 8:59:02 350] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:106, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:02 350] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:106, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:02 366] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:106, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:02 382] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"134":true}} pro:4 num:43535
[2024/8/7 8:59:02 382] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"134":true}}} offset:57
[2024/8/7 8:59:02 398] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"134":true}}, msg_len:20, out_len:72
[2024/8/7 8:59:02 398] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14054
[2024/8/7 8:59:02 414] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"106":"1"}} pro:4 num:43536
[2024/8/7 8:59:02 414] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"106":"1"}}} offset:56
[2024/8/7 8:59:02 430] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"106":"1"}}, msg_len:19, out_len:71
[2024/8/7 8:59:02 430] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14055
[2024/8/7 8:59:02 446] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"110":5}} pro:4 num:43537
[2024/8/7 8:59:02 462] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"110":5}}} offset:54
[2024/8/7 8:59:02 462] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"110":5}}, msg_len:17, out_len:69
[2024/8/7 8:59:02 478] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"150":true}
[2024/8/7 8:59:02 478] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14056
[2024/8/7 8:59:02 494] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43539 Q:1 Data:{"dps":{"150":true}}
[2024/8/7 8:59:02 494] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"109":"0|0|0"}} pro:4 num:43538
[2024/8/7 8:59:02 510] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"109":"0|0|0"}}} offset:60
[2024/8/7 8:59:02 510] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"109":"0|0|0"}}, msg_len:23, out_len:75
[2024/8/7 8:59:02 526] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14057
[2024/8/7 8:59:02 526] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"150":true}} pro:4 num:43539
[2024/8/7 8:59:02 542] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"150":true}}} offset:57
[2024/8/7 8:59:02 558] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"150":true}}, msg_len:20, out_len:72
[2024/8/7 8:59:02 558] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14058
[2024/8/7 8:59:02 558] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:02 574] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:02 590] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:02 590] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"151":"1"}
[2024/8/7 8:59:02 590] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43540 Q:1 Data:{"dps":{"151":"1"}}
[2024/8/7 8:59:02 606] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"151":"1"}} pro:4 num:43540
[2024/8/7 8:59:02 622] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"151":"1"}}} offset:56
[2024/8/7 8:59:02 622] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"151":"1"}}, msg_len:19, out_len:71
[2024/8/7 8:59:02 638] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14059
[2024/8/7 8:59:02 638] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:02 654] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:02 654] [08-07 08:59:03 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:0
[2024/8/7 8:59:02 654] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:02 670] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 8:59:02 670] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"117":0}} pro:4 num:43541
[2024/8/7 8:59:02 686] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43541 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 8:59:02 702] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"117":0}}} offset:54
[2024/8/7 8:59:02 702] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"117":0}}, msg_len:17, out_len:69
[2024/8/7 8:59:02 718] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14060
[2024/8/7 8:59:02 718] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:02 734] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<138> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:02 734] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:02 734] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:02 750] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"138":false}
[2024/8/7 8:59:02 766] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43542 Q:1 Data:{"dps":{"138":false}}
[2024/8/7 8:59:02 766] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"138":false}} pro:4 num:43542
[2024/8/7 8:59:02 782] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"138":false}}} offset:58
[2024/8/7 8:59:02 798] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"138":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:02 798] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14061
[2024/8/7 8:59:02 798] current power mode:1
[2024/8/7 8:59:02 814] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:02 814] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:146 not find
[2024/8/7 8:59:02 814] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:02 830] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:02 830] current battery percent:80
[2024/8/7 8:59:02 830] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:02 846] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:145 not find
[2024/8/7 8:59:02 846] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:02 846] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:02 862] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:02 862] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:02 878] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:02 878] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:02 893] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"170":false}
[2024/8/7 8:59:02 894] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43543 Q:1 Data:{"dps":{"170":false}}
[2024/8/7 8:59:02 909] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"170":false}} pro:4 num:43543
[2024/8/7 8:59:02 910] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"170":false}}} offset:58
[2024/8/7 8:59:02 925] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"170":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:02 925] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14062
[2024/8/7 8:59:02 941] src/intelligent_track_thread.c(1466) [XM_GetBodyTarckEnable]: 
[2024/8/7 8:59:02 941] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:02 958] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:02 958] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:02 973] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:02 974] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"161":false}
[2024/8/7 8:59:02 989] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43544 Q:1 Data:{"dps":{"161":false}}
[2024/8/7 8:59:02 989] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"161":false}} pro:4 num:43544
[2024/8/7 8:59:03 006] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"161":false}}} offset:58
[2024/8/7 8:59:03 006] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"161":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:03 021] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14063
[2024/8/7 8:59:03 022] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 038] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:186 not find
[2024/8/7 8:59:03 038] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:03 038] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:03 053] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 053] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<133> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:03 070] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:03 070] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3"}
[2024/8/7 8:59:03 086] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"133":"3"}} pro:4 num:43545
[2024/8/7 8:59:03 086] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"133":"3"}}} offset:56
[2024/8/7 8:59:03 101] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"133":"3"}}, msg_len:19, out_len:71
[2024/8/7 8:59:03 101] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14064
[2024/8/7 8:59:03 118] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43545 Q:1 Data:{"dps":{"133":"3"}}
[2024/8/7 8:59:03 118] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 134] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:03 134] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:03 150] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:03 150] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 8:59:03 167] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"139":false}} pro:4 num:43546
[2024/8/7 8:59:03 167] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"139":false}}} offset:58
[2024/8/7 8:59:03 182] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"139":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:03 198] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14065
[2024/8/7 8:59:03 199] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43546 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 8:59:03 199] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 70 enable 0 volume
[2024/8/7 8:59:03 214]  ---
[2024/8/7 8:59:03 214] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 214] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:03 230] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:03 230] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"140":"1"}
[2024/8/7 8:59:03 246] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"140":"1"}} pro:4 num:43547
[2024/8/7 8:59:03 262] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"140":"1"}}} offset:56
[2024/8/7 8:59:03 262] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"140":"1"}}, msg_len:19, out_len:71
[2024/8/7 8:59:03 278] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14066
[2024/8/7 8:59:03 278] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43547 Q:1 Data:{"dps":{"140":"1"}}
[2024/8/7 8:59:03 278] [08-07 08:59:03 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 8:59:03 294] [08-07 08:59:03 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 8:59:03 294] [08-07 08:59:03 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 8:59:03 294] [08-07 08:59:03 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 8:59:03 310] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 310] [08-07 08:59:03 TUYA E][smart_frame.c:569] dparr[0] type not match:1 0
[2024/8/7 8:59:03 326] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3586
[2024/8/7 8:59:03 326] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 342] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:03 342] [08-07 08:59:03 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:50
[2024/8/7 8:59:03 342] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:03 358] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"160":50}
[2024/8/7 8:59:03 358] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"160":50}} pro:4 num:43548
[2024/8/7 8:59:03 374] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"160":50}}} offset:55
[2024/8/7 8:59:03 390] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"160":50}}, msg_len:18, out_len:70
[2024/8/7 8:59:03 390] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14067
[2024/8/7 8:59:03 406] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43548 Q:1 Data:{"dps":{"160":50}}
[2024/8/7 8:59:03 406] [08-07 08:59:03 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 8:59:03 406] [08-07 08:59:03 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 8:59:03 422] [08-07 08:59:03 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 8:59:03 422] [08-07 08:59:03 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 8:59:03 422] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 438] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:195 not find
[2024/8/7 8:59:03 438] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:03 438] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:03 454] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 454] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:194 not find
[2024/8/7 8:59:03 470] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:03 470] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:03 470] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 486] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:158 not find
[2024/8/7 8:59:03 486] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:03 486] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:03 502] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 502] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:03 518] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:03 518] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:03 534] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 8:59:03 534] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:43549
[2024/8/7 8:59:03 550] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 8:59:03 566] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:03 568] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14068
[2024/8/7 8:59:03 568] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43549 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 8:59:03 582] [08-07 08:59:03 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 8:59:03 582] [08-07 08:59:03 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 8:59:03 598] [08-07 08:59:03 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 8:59:03 598] [08-07 08:59:03 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 8:59:03 598] [1970-01-01 00:01:16] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 8:59:03 614] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 614] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:03 629] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:03 630] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:03 646] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"174":false}
[2024/8/7 8:59:03 646] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"174":false}} pro:4 num:43550
[2024/8/7 8:59:03 662] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"174":false}}} offset:58
[2024/8/7 8:59:03 662] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"174":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:03 678] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14069
[2024/8/7 8:59:03 678] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43550 Q:1 Data:{"dps":{"174":false}}
[2024/8/7 8:59:03 694] [08-07 08:59:03 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 8:59:03 694] [08-07 08:59:03 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 8:59:03 709] [08-07 08:59:03 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 8:59:03 709] [08-07 08:59:03 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 8:59:03 709] [1970-01-01 00:01:16] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 8:59:03 725] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 725] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:03 742] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:03 742] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"175":"0"}
[2024/8/7 8:59:03 758] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"175":"0"}} pro:4 num:43551
[2024/8/7 8:59:03 758] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"175":"0"}}} offset:56
[2024/8/7 8:59:03 774] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"175":"0"}}, msg_len:19, out_len:71
[2024/8/7 8:59:03 774] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14070
[2024/8/7 8:59:03 790] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43551 Q:1 Data:{"dps":{"175":"0"}}
[2024/8/7 8:59:03 790] [08-07 08:59:03 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 8:59:03 806] [08-07 08:59:03 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 8:59:03 806] [08-07 08:59:03 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 8:59:03 806] [08-07 08:59:03 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 8:59:03 822] [1970-01-01 00:01:16] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 8:59:03 822] cruiseTimeMode is 0.
[2024/8/7 8:59:03 822] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:03 838] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:03 838] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:03 855] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"176":"0"}
[2024/8/7 8:59:03 855] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"176":"0"}} pro:4 num:43552
[2024/8/7 8:59:03 871] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"176":"0"}}} offset:56
[2024/8/7 8:59:03 887] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"176":"0"}}, msg_len:19, out_len:71
[2024/8/7 8:59:03 887] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14071
[2024/8/7 8:59:03 902] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43552 Q:1 Data:{"dps":{"176":"0"}}
[2024/8/7 8:59:03 902] [08-07 08:59:03 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 8:59:03 902] [08-07 08:59:03 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 8:59:03 919] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0
[2024/8/7 8:59:03 919] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:150, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:03 934] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:150, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:03 952] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:150, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:03 952] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[2024/8/7 8:59:03 965] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:151, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:03 966] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:151, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:03 981] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:151, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:03 982] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[2024/8/7 8:59:03 997] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:117, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:04 013] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:117, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 013] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:117, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 029] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"138":false}}, mqtt async dp cb:0
[2024/8/7 8:59:04 030] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:138, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:04 045] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:138, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 045] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:138, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 061] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"170":false}}, mqtt async dp cb:0
[2024/8/7 8:59:04 077] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:170, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:04 077] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:170, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 093] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:170, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 094] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"161":false}}, mqtt async dp cb:0
[2024/8/7 8:59:04 109] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:161, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:04 110] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:161, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 125] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:161, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 141] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"133":"3"}}, mqtt async dp cb:0
[2024/8/7 8:59:04 141] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:133, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:04 157] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:133, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 157] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:133, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 174] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"139":false}}, mqtt async dp cb:0
[2024/8/7 8:59:04 174] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:139, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:04 189] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:139, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 205] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:139, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 205] [08-07 08:59:03 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1722992343,"success":true}
[2024/8/7 8:59:04 221] [08-07 08:59:03 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:04 222] [08-07 08:59:03 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:04 237] [08-07 08:59:03 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[2024/8/7 8:59:04 238] [08-07 08:59:03 TUYA D][tuya_ipc_cloud_storage.c:535] order expire or remote server error
[2024/8/7 8:59:04 253] [08-07 08:59:03 TUYA E][tuya_ipc_cloud_storage.c:1695] check cloud storage count failed, op_ret = -1
[2024/8/7 8:59:04 254] [08-07 08:59:03 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 8:59:04 254] [08-07 08:59:03 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 8:59:04 269] [1970-01-01 00:01:16] utils.c(322) <ReadTYJsonConfig>: Get antiFlicker object error!
[2024/8/7 8:59:04 270] anti Flicker mode is 0.
[2024/8/7 8:59:04 270] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:04 285] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:188 not find
[2024/8/7 8:59:04 286] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:04 301] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:04 302] [1970-01-01 00:01:16] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 8:59:04 302] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:04 318] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:192 not find
[2024/8/7 8:59:04 318] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:04 334] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:04 334] [1970-01-01 00:01:16] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 8:59:04 334] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:04 349] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:193 not find
[2024/8/7 8:59:04 350] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:04 350] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:04 365] [1970-01-01 00:01:16] utils.c(322) <ReadTYJsonConfig>: Get FlightWarn object error!
[2024/8/7 8:59:04 365] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:04 381] [08-07 08:59:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:173 not find
[2024/8/7 8:59:04 381] [08-07 08:59:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 8:59:04 397] [08-07 08:59:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 8:59:04 398] [1970-01-01 00:01:16] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 8:59:04 398] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:04 415] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:04 415] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:04 430] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:04 430] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"120":false}
[2024/8/7 8:59:04 446] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43553 Q:1 Data:{"dps":{"120":false}}
[2024/8/7 8:59:04 446] [08-07 08:59:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:04 462] [08-07 08:59:03 TUYA D][smart_frame.c:419] dp<231> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:04 462] [08-07 08:59:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:04 478] [08-07 08:59:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:04 478] [08-07 08:59:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"231":false}
[2024/8/7 8:59:04 494] [08-07 08:59:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43554 Q:1 Data:{"dps":{"231":false}}
[2024/8/7 8:59:04 494] [08-07 08:59:03 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}","t":1722992343}
[2024/8/7 8:59:04 526] [08-07 08:59:03 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992343&v=1.0&sign=9a5fb66c0b555ed5d09fcc52cea57f9b
[2024/8/7 8:59:04 526] [08-07 08:59:03 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:04 526] [08-07 08:59:03 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:04 542] [08-07 08:59:03 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:04 542] [08-07 08:59:03 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:04 558] [08-07 08:59:03 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:04 558] [08-07 08:59:03 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:04 574] [08-07 08:59:03 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:04 574] [08-07 08:59:03 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:04 590] [08-07 08:59:03 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:04 590] [08-07 08:59:03 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:04 606] [08-07 08:59:03 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:04 606] [08-07 08:59:03 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 8:59:04 606] [08-07 08:59:03 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 8:59:04 622] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"120":false}}, mqtt async dp cb:0
[2024/8/7 8:59:04 622] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:120, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:04 638] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:120, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 654] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:120, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 654] [08-07 08:59:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"231":false}}, mqtt async dp cb:0
[2024/8/7 8:59:04 670] [08-07 08:59:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:231, curr_t:1722992343, rept_cnt:1.
[2024/8/7 8:59:04 670] [08-07 08:59:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:231, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 686] [08-07 08:59:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:231, curr_t:1722992343, rept_cnt:0.
[2024/8/7 8:59:04 686] [08-07 08:59:03 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 8:59:04 702] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"120":false}} pro:4 num:43553
[2024/8/7 8:59:04 702] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"120":false}}} offset:58
[2024/8/7 8:59:04 718] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"120":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:04 718] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14072
[2024/8/7 8:59:04 734] [08-07 08:59:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"231":false}} pro:4 num:43554
[2024/8/7 8:59:04 750] [08-07 08:59:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992343,"data":{"dps":{"231":false}}} offset:58
[2024/8/7 8:59:04 750] [08-07 08:59:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"231":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:04 766] [08-07 08:59:03 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14073
[2024/8/7 8:59:04 766] [08-07 08:59:03 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:04 782] [08-07 08:59:03 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:04 782] [08-07 08:59:04 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992343,"success":true}
[2024/8/7 8:59:04 798] [08-07 08:59:04 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:04 798] [08-07 08:59:04 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:04 814] [08-07 08:59:04 TUYA D][tuya_ipc_skill.c:198] upload data: {\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}
[2024/8/7 8:59:04 814] [08-07 08:59:04 TUYA D][MainApp.c:597] tuya_ipc_sdk_mqtt_online_proc is end run
[2024/8/7 8:59:04 830] [1970-01-01 00:01:16] MainApp.c(599) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 8:59:04 830] tuya_ipc_p2p_demo.c(455)<TUYA_APP_Enable_P2PTransfer> Dbg: Init P2P With Max Users:5
[2024/8/7 8:59:04 846] [08-07 08:59:04 TUYA D][tuya_ipc_webrtc.c:1534] begin___
[2024/8/7 8:59:04 846] [08-07 08:59:04 TUYA D][tuya_ipc_webrtc.c:1541] --audio-:8000,format:101
[2024/8/7 8:59:04 862] [08-07 08:59:04 TUYA D][tuya_ipc_webrtc.c:1542] end___ audiocbk_hdl(0x18f5c)
[2024/8/7 8:59:04 862] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5086] gw actived
[2024/8/7 8:59:04 862] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5095] p2p max_client_num[5]
[2024/8/7 8:59:04 878] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5096] p2p init media info:
[2024/8/7 8:59:04 878] [08-07 08:59:04 TUYA D][tuya_ipc_webrtc.c:1526] webrtc playback start_id 5
[2024/8/7 8:59:04 878] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 8:59:04 894] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4782] height[2160] width[3840] bitrate[2048]
[2024/8/7 8:59:04 894] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 8:59:04 910] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4782] height[360] width[640] bitrate[1024]
[2024/8/7 8:59:04 910] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 8:59:04 926] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4794] height[2160] width[3840] bitrate[2048]
[2024/8/7 8:59:04 926] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 8:59:04 943] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4794] height[360] width[640] bitrate[1024]
[2024/8/7 8:59:04 943] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 8:59:04 943] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 8:59:04 959] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 8:59:04 959] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 8:59:04 975] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 8:59:04 975] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 8:59:04 990] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 8:59:04 991] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 8:59:05 007] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 8:59:05 007] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 8:59:05 022] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 8:59:05 022] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4796] videoNum[2] audio codec[129] sample[0]
[2024/8/7 8:59:05 022] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4797] databits[1] channel[0]
[2024/8/7 8:59:05 039] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5122] need speaker audio codec[129] sample[0] databits[1] channel[0] defLiveMode[0]
[2024/8/7 8:59:05 054] [08-07 08:59:04 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 8:59:05 054] [08-07 08:59:04 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 8:59:05 054] [08-07 08:59:04 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 8:59:05 070] [08-07 08:59:04 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = adb2c6d3
[2024/8/7 8:59:05 070] [08-07 08:59:04 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[2024/8/7 8:59:05 086] [08-07 08:59:04 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 8:59:05 086] [08-07 08:59:04 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 8:59:05 086] [08-07 08:59:04 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 8:59:05 102] [08-07 08:59:04 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 8:59:05 102] [08-07 08:59:04 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 8:59:05 118] [08-07 08:59:04 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 8:59:05 118] [08-07 08:59:04 TUYA D][tuya_ipc_p2p_common.c:455] update p2p_auth_info from service, type 4
[2024/8/7 8:59:05 134] [08-07 08:59:04 TUYA D][iot_httpc.c:1161] Post Data: {"type":4,"t":1722992344}
[2024/8/7 8:59:05 150] [08-07 08:59:04 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.p2p.config.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992344&v=2.0&sign=088aa2afe844d7f2281747617cc8e3dc
[2024/8/7 8:59:05 150] [08-07 08:59:04 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:05 166] [08-07 08:59:04 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:05 166] [08-07 08:59:04 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:05 166] [08-07 08:59:04 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:05 182] [08-07 08:59:04 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:05 182] [08-07 08:59:04 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:05 198] [08-07 08:59:04 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:05 198] [08-07 08:59:04 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:05 214] [08-07 08:59:04 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:05 214] [08-07 08:59:04 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:05 230] [08-07 08:59:04 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:05 230] [08-07 08:59:04 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:05 246] [08-07 08:59:04 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:05 261] [08-07 08:59:04 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"p2pId":"","type":4},"t":1722992344,"success":true}
[2024/8/7 8:59:05 261] [08-07 08:59:04 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:05 261] [08-07 08:59:04 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:05 277] [08-07 08:59:04 TUYA D][tuya_ipc_p2p_common.c:381] SY P2P AUTH:{"p2pId":"","type":4}
[2024/8/7 8:59:05 277] [08-07 08:59:04 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 8:59:05 293] [08-07 08:59:04 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 8:59:05 293] [08-07 08:59:04 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 8:59:05 309] [08-07 08:59:04 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:32
[2024/8/7 8:59:05 309] [08-07 08:59:04 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 32
[2024/8/7 8:59:05 309] [08-07 08:59:04 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 8:59:05 325] [08-07 08:59:04 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 8:59:05 325] [08-07 08:59:04 TUYA D][simplekv.c:203] update crc 3905405328
[2024/8/7 8:59:05 342] [08-07 08:59:04 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:05 342] [08-07 08:59:04 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:05 342] [08-07 08:59:04 TUYA D][tuya_ipc_p2p_common.c:458] get p2p auth info from service
[2024/8/7 8:59:05 358] [08-07 08:59:04 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 8:59:05 358] [08-07 08:59:04 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 8:59:05 358] [08-07 08:59:04 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 8:59:05 374] [08-07 08:59:04 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 8:59:05 374] [08-07 08:59:04 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 8:59:05 390] [08-07 08:59:04 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 8:59:05 390] [08-07 08:59:04 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 8:59:05 390] [08-07 08:59:04 TUYA D][simplekv.c:203] update crc 2307957859
[2024/8/7 8:59:05 406] [08-07 08:59:04 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:05 406] [08-07 08:59:04 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:05 422] [08-07 08:59:04 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 8:59:05 422] [08-07 08:59:04 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 8:59:05 422] [08-07 08:59:04 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 8:59:05 438] [08-07 08:59:04 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[2024/8/7 8:59:05 438] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5178] p2p did[] apiLicense[] initString[]
[2024/8/7 8:59:05 454] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5181] support p2p type = 4
[2024/8/7 8:59:05 454] P2P API Version: 244.3.4.107
[2024/8/7 8:59:05 454] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4974] no encrypt
[2024/8/7 8:59:05 470] 46686 (null) INFO:6241316: tuya p2p rtc sdk version: 0xf403046b, Nov 16 2023 10:52:20
[2024/8/7 8:59:05 470] tuya liteos uv
[2024/8/7 8:59:05 470] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5039] _mqtt_p2p_listen_sessions create
[2024/8/7 8:59:05 486] [08-07 08:59:04 TUYA E][tuya_ipc_p2p.c:5190] p2p v3 init ok
[2024/8/7 8:59:05 486] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4124] Begin to Listen mqtt p2p client connects In Thread
[2024/8/7 8:59:05 502] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 8:59:05 502] 47152 (null) [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5230] speaker task create success
[2024/8/7 8:59:05 502] INFO:6241316: try listen
[2024/8/7 8:59:05 518] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5273] __p2p_session_detech create
[2024/8/7 8:59:05 518] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:4652] Begin to session detech
[2024/8/7 8:59:05 518] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:5290] __p2p_video_send_proc create ok
[2024/8/7 8:59:05 534] [08-07 08:59:04 TUYA D][tuya_ipc_upnp.c:437] tuya_ipc_upnp_init start
[2024/8/7 8:59:05 550] [08-07 08:59:04 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:156672,priority:2
[2024/8/7 8:59:05 550] [08-07 08:59:04 TUYA D][tuya_ipc_upnp.c:458] tuya_ipc_upnp_init success
[2024/8/7 8:59:05 550] [08-07 08:59:04 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[2024/8/7 8:59:05 566] [08-07 08:59:04 TUYA D][tuya_ipc_packager.c:62] get packager instance
[2024/8/7 8:59:05 566] [08-07 08:59:04 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[2024/8/7 8:59:05 582] [08-07 08:59:04 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 8:59:05 582] [08-07 08:59:04 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:05 582] [08-07 08:59:04 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:05 598] [08-07 08:59:04 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:05 598] [08-07 08:59:04 TUYA E][tuya_ipc_encrypt.c:178] read local cloud encrypt key fails ..-6
[2024/8/7 8:59:05 614] [08-07 08:59:04 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992344}
[2024/8/7 8:59:05 630] [08-07 08:59:04 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.storage.secret.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992344&v=1.0&sign=a87967bf4712bbf59cfdeaffb6ea4f41
[2024/8/7 8:59:05 630] [08-07 08:59:04 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:05 646] [08-07 08:59:04 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:05 646] [08-07 08:59:04 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:05 662] [08-07 08:59:04 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:05 663] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:3771] into p2p video send
[2024/8/7 8:59:05 663] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [0]
[2024/8/7 8:59:05 678] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:3553] New Thread To proc, init source
[2024/8/7 8:59:05 678] [08-07 08:59:04 TUYA D][tuya_ipc_p2p.c:3572] session cmd recv proc alive [0] num[0]
[2024/8/7 8:59:05 694] [08-07 08:59:04 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[2024/8/7 8:59:05 694] [08-07 08:59:04 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1722992344}
[2024/8/7 8:59:05 710] [08-07 08:59:04 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992344&v=1.0&sign=4f042b93cb86a163d8449ffd3b9fdd93
[2024/8/7 8:59:05 726] [08-07 08:59:04 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:05 726] [08-07 08:59:04 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:05 742] [08-07 08:59:04 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:05 742] [08-07 08:59:04 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:05 757] [08-07 08:59:04 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:05 759] [08-07 08:59:04 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:05 759] [08-07 08:59:04 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:05 776] [08-07 08:59:04 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:05 789] [08-07 08:59:04 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:05 789] [08-07 08:59:04 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:05 805] [08-07 08:59:04 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:05 805] [08-07 08:59:04 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:05 805] [08-07 08:59:04 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:05 821] [08-07 08:59:04 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:05 821] [08-07 08:59:04 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:05 837] [08-07 08:59:04 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:05 837] [08-07 08:59:04 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:05 837] [08-07 08:59:04 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:05 854] [08-07 08:59:04 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 8:59:05 854] [08-07 08:59:04 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 8:59:05 870] [08-07 08:59:04 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:05 886] [08-07 08:59:04 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:05 886] [08-07 08:59:04 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:05 902] [08-07 08:59:04 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:05 918] [08-07 08:59:04 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"unitList":[{"port":7000,"protocol":"TCP"},{"port":8080,"protocol":"TCP"},{"port":5000,"protocol":"UDP"},{"port":8000,"protocol":"UDP"}]},"t":1722992344,"success":true}
[2024/8/7 8:59:05 934] [08-07 08:59:04 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:05 934] [08-07 08:59:04 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:05 934] [08-07 08:59:04 TUYA D][tuya_ipc_upnp.c:171] upnp get config success result:{
[2024/8/7 8:59:05 934] 	"unitList":	[{
[2024/8/7 8:59:05 950] 			"port":	7000,
[2024/8/7 8:59:05 950] 			"protocol":	"TCP"
[2024/8/7 8:59:05 950] 		}, {
[2024/8/7 8:59:05 950] 			"port":	8080,
[2024/8/7 8:59:05 950] 			"port":	5000,
[2024/8/7 8:59:05 950] 			"protocol":	"UDP"
[2024/8/7 8:59:05 950] 			"port":	8000,
[2024/8/7 8:59:05 950] 		}]
[2024/8/7 8:59:05 966] [08-07 08:59:04 TUYA D][tuya_ipc_upnp.c:293] tuya_ipc_upnp_start start
[2024/8/7 8:59:05 966] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10.
[2024/8/7 8:59:05 982] [08-07 08:59:04 TUYA I][uni_thread.c:228] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:222208,priority:3
[2024/8/7 8:59:05 998] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0
[2024/8/7 8:59:05 998] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0
[2024/8/7 8:59:06 014] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:6886 
[2024/8/7 8:59:06 030] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 6886, in_port 6886 protocol:UDP, status:0
[2024/8/7 8:59:06 030] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:2912 
[2024/8/7 8:59:06 046] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 2912, in_port 2912 protocol:UDP, status:0
[2024/8/7 8:59:06 046] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:1956 
[2024/8/7 8:59:06 062] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 1956, in_port 1956 protocol:UDP, status:0
[2024/8/7 8:59:06 062] [08-07 08:59:04 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5!
[2024/8/7 8:59:06 078] [08-07 08:59:04 TUYA D][tuya_ipc_upnp.c:314] tuya_ipc_upnp_start success
[2024/8/7 8:59:06 078] [08-07 08:59:04 TUYA D][tuya_ipc_upnp.c:421] start upnp module success, exit thread
[2024/8/7 8:59:06 094] [08-07 08:59:04 TUYA D][uni_thread.c:310] Del Thrd:ipc_upnp
[2024/8/7 8:59:06 094] [08-07 08:59:04 TUYA D][uni_thread.c:250] Thread:UPnP_PROC Exec Start. Set to Running Stat
[2024/8/7 8:59:06 110] [08-07 08:59:04 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"encryptKey":"992e9749e8f3402a"},"t":1722992344,"success":true}
[2024/8/7 8:59:06 110] [08-07 08:59:04 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:06 126] [08-07 08:59:04 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:06 126] [08-07 08:59:04 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 8:59:06 126] [08-07 08:59:04 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:06 142] [08-07 08:59:04 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:06 142] [08-07 08:59:04 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:06 158] [08-07 08:59:04 TUYA D][simplekv.c:374] write key:cloud_enc_key And Value Len:32
[2024/8/7 8:59:06 158] [08-07 08:59:04 TUYA D][simplekv.c:457] new space 17 startpos:37392 size:100
[2024/8/7 8:59:06 158] [08-07 08:59:04 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 8:59:06 174] [08-07 08:59:04 TUYA D][simplekv.c:203] update crc 46642907
[2024/8/7 8:59:06 174] [08-07 08:59:04 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:06 189] [08-07 08:59:04 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:06 190] [08-07 08:59:05 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:230400,priority:3
[2024/8/7 8:59:06 205] [08-07 08:59:05 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[2024/8/7 8:59:06 221] [08-07 08:59:05 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":90000,\"profileId\":\"\",\"width\":3840,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[2024/8/7 8:59:06 238] [1970-01-01 00:01:17] tuya_ipc_p2p_demo.c(475) <TUYA_APP_Enable_P2PTransfer>: tuya_ipc_tranfser_init ret=[0]
[2024/8/7 8:59:06 253] [1970-01-01 00:01:17] MainApp.c(606) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 8:59:06 254] [1970-01-01 00:01:17] MainApp.c(614) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 8:59:06 270] [1970-01-01 00:01:17] MainApp.c(615) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 8:59:06 270] [1970-01-01 00:01:17] MainApp.c(616) <tuya_ipc_sdk_mqtt_online_proc>: v_handle=[0x16ff660]
[2024/8/7 8:59:06 286] [1970-01-01 00:01:17] MainApp.c(617) <tuya_ipc_sdk_mqtt_online_proc>: v_handle_sub=[0x16ff558]
[2024/8/7 8:59:06 286] [1970-01-01 00:01:17] MainApp.c(618) <tuya_ipc_sdk_mqtt_online_proc>: a_handle_sub=[0x170d1a8]
[2024/8/7 8:59:06 302] [1970-01-01 00:01:17] xm_main.c(1104) <XM_RegisterTYCallFunc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 8:59:06 317] [1970-01-01 00:01:17] xm_main.c(1105) <XM_RegisterTYCallFunc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 8:59:06 317] [1970-01-01 00:01:17] xm_main.c(1106) <XM_RegisterTYCallFunc>: a_handle_sub=[0x170d1a8]
[2024/8/7 8:59:06 333] [1970-01-01 00:01:17] xm_main.c(1107) <XM_RegisterTYCallFunc>: v_handle=[0x16ff660]
[2024/8/7 8:59:06 334] [1970-01-01 00:01:17] xm_main.c(1108) <XM_RegisterTYCallFunc>: v_handle_sub=[0x16ff558]
[2024/8/7 8:59:06 349] [1970-01-01 00:01:17] MainApp.c(620) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 8:59:06 349] [1970-01-01 00:01:17] MainApp.c(621) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 8:59:06 365] [08-07 08:59:05 TUYA D][uni_thread.c:125] del list not empty...deleting 0x17003cc, next 0x16c46b8
[2024/8/7 8:59:06 365] [08-07 08:59:05 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 8:59:06 381] [08-07 08:59:05 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[2024/8/7 8:59:06 381] [08-07 08:59:05 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[2024/8/7 8:59:06 381] [08-07 08:59:05 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[2024/8/7 8:59:06 397] [1970-01-01 00:01:17] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 110[08-07 08:59:05 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992345 28800
[2024/8/7 8:59:06 413] [08-07 08:59:05 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992345 28800
[2024/8/7 8:59:06 429] --- tracepoint tuya_ipc_system_control_demo.c,XM_CheckDls_Pro(810): server time_zone 28800 time 1722992345 dls 0 loacl time 77
[2024/8/7 8:59:06 429] [08-07 08:59:05 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 90314ba51650
[2024/8/7 8:59:06 429] [08-07 08:59:05 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING...
[2024/8/7 8:59:06 445] [08-07 08:59:05 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 8:59:06 445] [08-07 08:59:05 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 8:59:06 461] [08-07 08:59:05 TUYA D][uni_thread.c:268] Thread:ipc_upnp Exec Finish. Set to Del Stat
[2024/8/7 8:59:06 461] [08-07 08:59:05 TUYA D][uni_thread.c:125] del list not empty...deleting 0x17003cc, next 0x16c46b8
[2024/8/7 8:59:06 477] [08-07 08:59:05 TUYA D][uni_thread.c:132] Final Free Thread:ipc_upnp, is_self:1
[2024/8/7 8:59:06 477] [08-07 08:59:05 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 8:59:06 477] [08-07 08:59:05 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 8:59:06 494] [08-07 08:59:05 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.107, Nov 16 2023 10:52:20\"}","t":1722992345}
[2024/8/7 8:59:06 510] [08-07 08:59:05 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992345&v=1.0&sign=bc67f01d07f4943754fbd8ca01013a92
[2024/8/7 8:59:06 526] [08-07 08:59:05 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:06 526] [08-07 08:59:05 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:06 542] [08-07 08:59:05 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:06 542] [08-07 08:59:05 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:06 558] [08-07 08:59:05 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:06 558] [08-07 08:59:05 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:06 574] [08-07 08:59:05 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:06 574] [08-07 08:59:05 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:06 589] [08-07 08:59:05 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:06 590] [08-07 08:59:05 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:06 590] [08-07 08:59:05 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:06 606] [08-07 08:59:05 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:06 622] [08-07 08:59:05 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:06 622] [08-07 08:59:05 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722992345,"success":true}
[2024/8/7 8:59:06 638] [08-07 08:59:05 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:06 638] [08-07 08:59:05 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:06 654] g_AudioTipsList.size() enable: 0[08-07 08:59:05 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:06 654] [08-07 08:59:05 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:1 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 8:59:06 670] [08-07 08:59:05 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 8:59:06 670] [08-07 08:59:05 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:06 686] [08-07 08:59:05 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 8:59:06 686] [08-07 08:59:05 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43555 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 8:59:06 701] [08-07 08:59:05 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:43555
[2024/8/7 8:59:06 701] [08-07 08:59:05 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992345,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 8:59:06 718] [08-07 08:59:05 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 8:59:06 718] [08-07 08:59:05 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:14074
[2024/8/7 8:59:06 734] [2024-08-07 08:59:05] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 806[08-07 08:59:05 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 8:59:06 749] [08-07 08:59:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722992345, rept_cnt:1.
[2024/8/7 8:59:06 765] [08-07 08:59:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:06 765] [08-07 08:59:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:06 781] [08-07 08:59:05 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c22076b2d2b61448fm8uy, dp_rept_chan:3
[2024/8/7 8:59:06 781] [08-07 08:59:05 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 8:59:06 797] [08-07 08:59:05 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:109.
[2024/8/7 8:59:06 797] [08-07 08:59:05 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:110.
[2024/8/7 8:59:06 813] [08-07 08:59:05 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:140.
[2024/8/7 8:59:06 813] [08-07 08:59:05 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:160.
[2024/8/7 8:59:06 830] [08-07 08:59:05 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:174.
[2024/8/7 8:59:06 830] [08-07 08:59:05 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:175.
[2024/8/7 8:59:06 846] [08-07 08:59:05 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:176.
[2024/8/7 8:59:06 862] [08-07 08:59:05 TUYA D][smart_frame.c:2547] final pack:{"109":"0|0|0","110":5,"140":"1","160":50,"174":false,"175":"0","176":"0"}
[2024/8/7 8:59:06 862] [08-07 08:59:05 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0","110":5,"140":"1","160":50,"174":false,"175":"0","176":"0"}
[2024/8/7 8:59:06 878] [08-07 08:59:05 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43556 Q:1 Data:{"dps":{"109":"0|0|0","110":5,"140":"1","160":50,"174":false,"175":"0","176":"0"}}
[2024/8/7 8:59:06 894] [08-07 08:59:05 TUYA D][smart_frame.c:2135] sync rslt:0
[2024/8/7 8:59:06 894] [08-07 08:59:05 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 8:59:06 910] [08-07 08:59:05 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"109":"0|0|0","110":5,"140":"1","160":50,"174":false,"175":"0","176":"0"}}, mqtt async dp cb:0
[2024/8/7 8:59:06 910] [08-07 08:59:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:109, curr_t:1722992345, rept_cnt:1.
[2024/8/7 8:59:06 926] [08-07 08:59:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:109, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:06 942] [08-07 08:59:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:109, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:06 942] [08-07 08:59:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:110, curr_t:1722992345, rept_cnt:1.
[2024/8/7 8:59:06 958] [08-07 08:59:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:110, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:06 958] [08-07 08:59:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:110, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:06 975] [08-07 08:59:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:140, curr_t:1722992345, rept_cnt:1.
[2024/8/7 8:59:06 975] [08-07 08:59:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:140, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:06 990] [08-07 08:59:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:140, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 006] [08-07 08:59:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:160, curr_t:1722992345, rept_cnt:1.
[2024/8/7 8:59:07 006] [2024-08-07 08:59:05] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:59:07 022] [08-07 08:59:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:160, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 022] [08-07 08:59:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:160, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 038] [08-07 08:59:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:174, curr_t:1722992345, rept_cnt:1.
[2024/8/7 8:59:07 054] [08-07 08:59:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:174, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 054] [08-07 08:59:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:174, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 070] [08-07 08:59:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:175, curr_t:1722992345, rept_cnt:1.
[2024/8/7 8:59:07 070] [08-07 08:59:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:175, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 086] [08-07 08:59:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:175, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 102] [08-07 08:59:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:176, curr_t:1722992345, rept_cnt:1.
[2024/8/7 8:59:07 102] [08-07 08:59:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:176, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 118] [08-07 08:59:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:176, curr_t:1722992345, rept_cnt:0.
[2024/8/7 8:59:07 118] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 8:59:07 118] Mode(Product):0
[2024/8/7 8:59:07 118] BpuMode:[Online]
[2024/8/7 8:59:07 118] VpssMode:[Online]
[2024/8/7 8:59:07 118] [0.LimitUp_info]:
[2024/8/7 8:59:07 133] LimitUp:[Disable]
[2024/8/7 8:59:07 133] [2680*0]->[3840*0])
[2024/8/7 8:59:07 133] chn	TotalSize	ActiveSize
[2024/8/7 8:59:07 133] 0	5040*2246	2680*2160
[2024/8/7 8:59:07 133] 0	5040*2246	3840*2160
[2024/8/7 8:59:07 133] Repair: En:1	Cnt:0x00000000
[2024/8/7 8:59:07 133] [1.VICU_info]:
[2024/8/7 8:59:07 150] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 8:59:07 150] 0	25.0	1008	0	0	183	linear	8ddb00
[2024/8/7 8:59:07 150] 0	0.0	0	0	0	0	linear	0
[2024/8/7 8:59:07 150] en	op_type	m_chn	now
[2024/8/7 8:59:07 150] 0	1	1	1
[2024/8/7 8:59:07 150] [2.VI_info]:
[2024/8/7 8:59:07 150] chn	TotalSize	ActiveSize
[2024/8/7 8:59:07 165] 0	5040*2246	3848*2166
[2024/8/7 8:59:07 165] 1	   0*   0	   0*   0
[2024/8/7 8:59:07 165] [3.MIPI_info]:
[2024/8/7 8:59:07 165] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 8:59:07 181] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 8:59:07 181] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 8:59:07 181] [4.Cut_info]:
[2024/8/7 8:59:07 181] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 8:59:07 181] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 8:59:07 181] h_d	0	1	 	 	2684	2160	  
[2024/8/7 8:59:07 197] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 8:59:07 197] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 8:59:07 197] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 8:59:07 197] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 8:59:07 197] [5.IB(isp buffer info)]:
[2024/8/7 8:59:07 213] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 8:59:07 213] PoolId  Count  Size
[2024/8/7 8:59:07 213] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:07 230] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:07 230] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:07 245] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:07 245] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:07 261] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 8:59:07 261] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 8:59:07 261] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 8:59:07 278] 0       0         0          0          4       
[2024/8/7 8:59:07 278] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 8:59:07 278]      --265--            --264--                                               
[2024/8/7 8:59:07 294] Count      Line     Count      Line     
[2024/8/7 8:59:07 294] 799        437      1795       560      
[2024/8/7 8:59:07 294] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 8:59:07 310] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 8:59:07 310] 0   3840   2160    H265  0      0        0           474       975234     7806     	
[2024/8/7 8:59:07 326] 1   640    360     H265  0      0        0           315       43194      6        	
[2024/8/7 8:59:07 326] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 8:59:07 341] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 8:59:07 341] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 8:59:07 357] 0   Y      474      0       0       14       1        473      473      625       63994         58576    149384   65459    12      
[2024/8/7 8:59:07 373] 1   Y      315      0       9       1        0        315      315      626       2543          1876     24791    2805     9       
[2024/8/7 8:59:07 389] 3   N      0        0       0       1        0        0        0        626       0             0        0        0        0       
[2024/8/7 8:59:07 406] [2024-08-07 08:59:05] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 16472[2024-08-07 08:59:05] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:59:07 406] [2024-08-07 08:59:06] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 8:59:07 421] [2024-08-07 08:59:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 8:59:07 421] [2024-08-07 08:59:06] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time48803
[2024/8/7 8:59:07 438] [08-07 08:59:06 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 8:59:07 438] [08-07 08:59:06 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:07 438] [08-07 08:59:06 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:07 454] [08-07 08:59:06 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:07 454] [08-07 08:59:06 TUYA D][tuya_svc_schema_upgrade.c:223] schema[flvlrc] not updated since activated
[2024/8/7 8:59:07 486] [2024-08-07 08:59:07] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 16523[2024-08-07 08:59:07] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 16536[2024-08-07 08:59:08] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 8:59:07 486] [2024-08-07 08:59:08] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 8:59:07 501] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=12.000 ms
[2024/8/7 8:59:07 502] [2024-08-07 08:59:08] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 8:59:07 518] [2024-08-07 08:59:09] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:07 518] [08-07 08:59:09 TUYA D][iot_httpc.c:1161] Post Data: {"data":"255","t":1722992349}
[2024/8/7 8:59:07 534] [08-07 08:59:09 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992349&sign=56f992d22b6c98d83f0c5c7ad9111426
[2024/8/7 8:59:07 550] [08-07 08:59:09 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:07 550] [08-07 08:59:09 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:07 566] [08-07 08:59:09 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:07 566] [08-07 08:59:09 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:07 582] [08-07 08:59:09 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:07 582] [08-07 08:59:09 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:07 598] [08-07 08:59:09 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:07 598] [08-07 08:59:09 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:07 614] [08-07 08:59:09 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:07 614] [08-07 08:59:09 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:07 630] [08-07 08:59:09 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:07 630] [08-07 08:59:09 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:07 646] [08-07 08:59:09 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:07 646] [08-07 08:59:09 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722992349,"success":true}
[2024/8/7 8:59:07 662] [08-07 08:59:09 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:07 662] [08-07 08:59:09 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:07 678] [08-07 08:59:09 TUYA D][tuya_devos_entry.c:406] put rst log finish
[2024/8/7 8:59:07 678] [08-07 08:59:09 TUYA D][iot_httpc.c:1161] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1722992349}
[2024/8/7 8:59:07 694] [08-07 08:59:09 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992349&v=2.0&sign=059b2f2ae890f6a416a2729c29f9c4c7
[2024/8/7 8:59:07 710] [08-07 08:59:09 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:07 710] [08-07 08:59:09 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:07 726] [08-07 08:59:09 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:07 726] [08-07 08:59:09 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:07 741] [08-07 08:59:09 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:07 742] [08-07 08:59:09 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:07 757] [08-07 08:59:09 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:07 757] [08-07 08:59:09 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:07 757] [08-07 08:59:09 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:07 773] [08-07 08:59:09 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:07 773] [08-07 08:59:09 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:07 789] [08-07 08:59:09 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:07 805] [08-07 08:59:09 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:07 821] [08-07 08:59:09 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722992349,"validTime":1800}},"t":1722992349,"success":true}
[2024/8/7 8:59:07 821] [08-07 08:59:09 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:07 837] [08-07 08:59:09 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:07 837] [08-07 08:59:09 TUYA D][iot_httpc.c:3388] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1722992349}, ret:0.
[2024/8/7 8:59:07 853] [08-07 08:59:09 TUYA D][tuya_devos_entry.c:479] timezone:+08:00
[2024/8/7 8:59:07 854] [08-07 08:59:09 TUYA D][tuya_devos_entry.c:500] summer_time_zone:[]
[2024/8/7 8:59:07 854] [08-07 08:59:09 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 8:59:07 869] [08-07 08:59:09 TUYA D][simplekv.c:1251] find key:12 gw_ai
[2024/8/7 8:59:07 869] [08-07 08:59:09 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544
[2024/8/7 8:59:07 869] [08-07 08:59:09 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 8:59:07 886] [08-07 08:59:09 TUYA D][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722992349,"validTime":1800}}.
[2024/8/7 8:59:07 902] [08-07 08:59:09 TUYA D][tuya_devos_utils.c:94] reset dp rate rule finish.
[2024/8/7 8:59:07 918] [08-07 08:59:09 TUYA D][iot_httpc.c:1161] Post Data: {"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722992349}
[2024/8/7 8:59:07 934] [08-07 08:59:09 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.ack&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992349&v=2.0&sign=a1ab14c67ae7e49390656e00668e36c2
[2024/8/7 8:59:07 934] [08-07 08:59:09 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:07 950] [08-07 08:59:09 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:07 950] [08-07 08:59:09 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:07 950] [08-07 08:59:09 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:07 966] [08-07 08:59:09 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:07 966] [08-07 08:59:09 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:07 982] [08-07 08:59:09 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:07 982] [08-07 08:59:09 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:07 998] [08-07 08:59:09 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:07 998] [08-07 08:59:09 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:08 014] [08-07 08:59:09 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:08 014] [08-07 08:59:09 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:08 030] [08-07 08:59:09 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:08 046] [08-07 08:59:09 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992349,"success":true}
[2024/8/7 8:59:08 047] [08-07 08:59:09 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:08 047] [08-07 08:59:09 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:08 062] [08-07 08:59:09 TUYA D][iot_httpc.c:2411] dynamic cfg post data:{"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722992349}, ret:0.
[2024/8/7 8:59:10 541] [2024-08-07 08:59:10] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 16693[2024-08-07 08:59:10] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time52815
[2024/8/7 8:59:10 541] [2024-08-07 08:59:12] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:10 557] [08-07 08:59:13 TUYA D][tuya_upnp_module_mg.c:1432] upnpDiscover failed
[2024/8/7 8:59:11 597] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:11 757] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:11 965] while(lib_ble_start) before
[2024/8/7 8:59:11 966] [2024-08-07 08:59:13] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 16695--- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:2
[2024/8/7 8:59:11 981]  ---
[2024/8/7 8:59:11 981] GAP procedure initiated: terminate connection; conn_handle=1 hci_reason=19
[2024/8/7 8:59:11 981] ble_slave_gap_event->type=14
[2024/8/7 8:59:11 997] subscribe event; conn_handle=1 attr_handle=23 reason=2 prevn=1 curn=0 previ=0 curi=0
[2024/8/7 8:59:11 998] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 8:59:11 998] ble_slave_gap_event->type=1
[2024/8/7 8:59:11 998] disconnect; reason=534 
[2024/8/7 8:59:12 013] [2024-08-07 08:59:14] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time56801
[2024/8/7 8:59:12 014] [08-07 08:59:14 TUYA D][iot_httpc.c:1161] Post Data: {"subId":null,"t":1722992354}
[2024/8/7 8:59:12 029] [08-07 08:59:14 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upgrade.silent.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992354&v=4.4&sign=5ecfc28290300af161b982a46e421efa
[2024/8/7 8:59:12 045] [08-07 08:59:14 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:12 045] [08-07 08:59:14 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:12 061] [08-07 08:59:14 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:12 062] [08-07 08:59:14 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:12 077] [08-07 08:59:14 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:12 078] [08-07 08:59:14 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:12 093] [08-07 08:59:14 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:12 094] [08-07 08:59:14 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:12 109] [08-07 08:59:14 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:12 109] [08-07 08:59:14 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:12 110] [08-07 08:59:14 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:12 126] [08-07 08:59:14 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:12 141] [08-07 08:59:14 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:12 142] [08-07 08:59:14 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992354,"success":true}
[2024/8/7 8:59:12 157] [08-07 08:59:14 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:12 157] [08-07 08:59:14 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:12 157] [08-07 08:59:14 TUYA E][tuya_svc_upgrade.c:436] result null
[2024/8/7 8:59:12 173] [08-07 08:59:14 TUYA D][tuya_svc_upgrade.c:511] silent get firmware fail
[2024/8/7 8:59:12 174] [08-07 08:59:14 TUYA D][tuya_svc_upgrade.c:205] next detect timer: 21600s
[2024/8/7 8:59:12 189] [08-07 08:59:14 TUYA N][tuya_svc_timer_task.c:796] Update Timer from cloud
[2024/8/7 8:59:12 190] [08-07 08:59:14 TUYA D][iot_httpc.c:1161] Post Data: {"devId":"6c22076b2d2b61448fm8uy","lastFetchTime":"0","t":1722992354}
[2024/8/7 8:59:12 205] [08-07 08:59:14 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.timer.count&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992354&v=4.2&sign=c463bee6afb79086e130a898cb6fa6a6
[2024/8/7 8:59:12 222] [08-07 08:59:14 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:12 222] [08-07 08:59:14 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:12 238] [08-07 08:59:14 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:12 238] [08-07 08:59:14 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:12 254] [08-07 08:59:14 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:12 254] [08-07 08:59:14 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:12 270] [08-07 08:59:14 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:12 270] [08-07 08:59:14 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:12 285] [08-07 08:59:14 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:12 285] [08-07 08:59:14 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:12 285] [08-07 08:59:14 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:12 301] [08-07 08:59:14 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:12 317] [08-07 08:59:14 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:12 333] [08-07 08:59:14 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"code":"200","count":0,"devId":"6c22076b2d2b61448fm8uy","lastFetchTime":0},"t":1722992354,"success":true}
[2024/8/7 8:59:12 333] [08-07 08:59:14 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:12 333] [08-07 08:59:14 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:12 349] [08-07 08:59:14 TUYA D][tuya_svc_timer_task.c:451] time eq skip:0
[2024/8/7 8:59:12 685] [2024-08-07 08:59:15] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:12 701] [08-07 08:59:15 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992355 28800
[2024/8/7 8:59:12 701] [08-07 08:59:15 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992355 28800
[2024/8/7 8:59:14 125] <====== ble_gap_terminate(ble_conn_handle,19);
[2024/8/7 8:59:14 126] <====== ble_smart_cfg_task end step 0
[2024/8/7 8:59:14 126] [08-07 08:59:16 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 8:59:14 413] [atbm_log]:atbm_ioctl_ble_stop
[2024/8/7 8:59:15 597] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 8:59:15 597] Mode(Product):0
[2024/8/7 8:59:15 597] BpuMode:[Online]
[2024/8/7 8:59:15 597] VpssMode:[Online]
[2024/8/7 8:59:15 613] [0.LimitUp_info]:
[2024/8/7 8:59:15 613] LimitUp:[Disable]
[2024/8/7 8:59:15 613] [2680*0]->[3840*0])
[2024/8/7 8:59:15 613] chn	TotalSize	ActiveSize
[2024/8/7 8:59:15 613] 0	5040*2246	2680*2160
[2024/8/7 8:59:15 613] 0	5040*2246	3840*2160
[2024/8/7 8:59:15 613] Repair: En:1	Cnt:0x00000000
[2024/8/7 8:59:15 629] [1.VICU_info]:
[2024/8/7 8:59:15 629] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 8:59:15 629] 0	25.0	1316	0	0	183	linear	8ddb00
[2024/8/7 8:59:15 629] 0	0.0	0	0	0	0	linear	0
[2024/8/7 8:59:15 629] en	op_type	m_chn	now
[2024/8/7 8:59:15 629] 0	1	1	1
[2024/8/7 8:59:15 645] [2.VI_info]:
[2024/8/7 8:59:15 647] chn	TotalSize	ActiveSize
[2024/8/7 8:59:15 647] 0	5040*2246	3848*2166
[2024/8/7 8:59:15 647] 1	   0*   0	   0*   0
[2024/8/7 8:59:15 647] [3.MIPI_info]:
[2024/8/7 8:59:15 647] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 8:59:15 661] 0x2b	6472*2166	3848*2166		5046*2166	3848*2166	   0
[2024/8/7 8:59:15 661] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 8:59:15 661] [4.Cut_info]:
[2024/8/7 8:59:15 661] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 8:59:15 661] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 8:59:15 677] vicu	0	1	1	2	3840	2160	  
[2024/8/7 8:59:15 678] h_d	0	1	 	 	2684	2160	  
[2024/8/7 8:59:15 678] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 8:59:15 678] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 8:59:15 678] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 8:59:15 678] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 8:59:15 678] [5.IB(isp buffer info)]:
[2024/8/7 8:59:15 693] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 8:59:15 693] PoolId  Count  Size
[2024/8/7 8:59:15 693] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:15 709] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:15 709] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:15 725] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:15 725] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:15 741] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 8:59:15 741] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 8:59:15 741] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 8:59:15 757] 0       0         0          0          4       
[2024/8/7 8:59:15 757] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 8:59:15 773]      --265--            --264--                                               
[2024/8/7 8:59:15 773] Count      Line     Count      Line     
[2024/8/7 8:59:15 773] 1060       480      2374       560      
[2024/8/7 8:59:15 774] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 8:59:15 790] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 8:59:15 790] 0   3840   2160    H265  0      0        0           623       983036     4        	
[2024/8/7 8:59:15 806] 1   640    360     H265  0      0        0           415       43195      5        	
[2024/8/7 8:59:15 806] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 8:59:15 821] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 8:59:15 837] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 8:59:15 837] 0   Y      623      0       0       15       0        623      623      829       68626         58576    149384   65066    12      
[2024/8/7 8:59:15 853] 1   Y      415      0       10      1        0        415      415      810       1914          1875     24791    2663     9       
[2024/8/7 8:59:15 869] 3   N      0        0       0       1        0        0        0        810       0             0        0        0        0       
[2024/8/7 8:59:18 973] exit ble process
[2024/8/7 8:59:18 973] ble_hs_hci_cmd_reset
[2024/8/7 8:59:18 973] cli_free before
[2024/8/7 8:59:18 973] nimble_port_atbmos_free before
[2024/8/7 8:59:18 973] nimble_port_release before
[2024/8/7 8:59:18 973] ble_gap_free before
[2024/8/7 8:59:18 989] ble_hs_hci_free before
[2024/8/7 8:59:18 989] ble_hs_free before
[2024/8/7 8:59:18 989] ble_hs_free after
[2024/8/7 8:59:18 989] nimble_release after
[2024/8/7 8:59:18 989] ble_smart_cfg_exit before
[2024/8/7 8:59:18 989] ble_smart_cfg_exit after
[2024/8/7 8:59:18 989] atbm_stopThread after
[2024/8/7 8:59:19 005] [2024-08-07 08:59:18] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:59:19 005] [2024-08-07 08:59:18] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:59:19 021] [2024-08-07 08:59:18] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time60821
[2024/8/7 8:59:19 021] [2024-08-07 08:59:21] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:19 037] tuya_ipc_ss_start_event:2288 :start new event
[2024/8/7 8:59:19 037] [08-07 08:59:21 TUYA E][tuya_ipc_stream_storage.c:2294] the ss mgr not inited, but msg buffed
[2024/8/7 8:59:19 069] thread_ai_detect_proc line(194) ----------tuya_ipc_ss_start_event-----------RecordMode :0 alarm_flag   1
[2024/8/7 8:59:19 085] [2024-08-07 08:59:21] tuya_ipc_ai_detect.demo.c(196) <thread_ai_detect_proc>: 
[2024/8/7 8:59:19 085] [2024-08-07 08:59:21] xm_main.c(1810) <XM_GetCatchJpgStream>: 
[2024/8/7 8:59:19 085] [2024-08-07 08:59:21] xm_main.c(1813) <XM_GetCatchJpgStream>: 
[2024/8/7 8:59:19 101] [2024-08-07 08:59:21] xm_main.c(1833) <XM_GetCatchJpgStream>: 
[2024/8/7 8:59:19 101] snap_size:25990
[2024/8/7 8:59:19 101] [2024-08-07 08:59:21] tuya_ipc_ai_detect.demo.c(200) <thread_ai_detect_proc>: 
[2024/8/7 8:59:19 117] [08-07 08:59:21 TUYA D][tuya_ipc_cloud_storage.c:1249] new event index 0, id: 1, added: type 0,notify type 2[1722992361-1722992661]
[2024/8/7 8:59:19 133] [08-07 08:59:21 TUYA D][tuya_ipc_cloud_storage.c:2380] add event start done, event_id 1 time 1722992361-1722992661
[2024/8/7 8:59:19 133] [08-07 08:59:21 TUYA D][tuya_ipc_notify.c:85] size:25990 type: 1
[2024/8/7 8:59:19 149] [08-07 08:59:21 TUYA D][upload_notification.c:526] notification from buffer. type:image/jpeg name:1722992361.jpeg path:2 data_len:26064
[2024/8/7 8:59:19 149] [08-07 08:59:21 TUYA D][upload_notification.c:473] cloud config 0 Not Inited
[2024/8/7 8:59:19 165] [08-07 08:59:21 TUYA D][iot_httpc.c:1161] Post Data: {"type":"Motion","t":1722992361}
[2024/8/7 8:59:19 181] [08-07 08:59:21 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992361&v=3.0&sign=40c55356eff6b92c57023e69814bb705
[2024/8/7 8:59:19 181] [08-07 08:59:21 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:19 197] [08-07 08:59:21 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:19 197] [08-07 08:59:21 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:19 213] [08-07 08:59:21 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:19 213] [08-07 08:59:21 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 8:59:19 213] [08-07 08:59:21 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 8:59:19 229] [08-07 08:59:21 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:19 229] [08-07 08:59:21 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:19 245] [08-07 08:59:21 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:19 245] [08-07 08:59:21 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:19 261] [08-07 08:59:21 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:19 261] [08-07 08:59:21 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:19 277] [08-07 08:59:21 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:19 277] [08-07 08:59:21 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:19 293] [08-07 08:59:21 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:19 373] [08-07 08:59:21 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"ak":"AKIDt7W9eL69jW-4U7VdGQ2QiqLj5LSZQ3gue7JJ8jgXWojkgAFFRmVvL7hXTpdREE4V","bucket":"ty-cn-storage30-pic-1254153901","countLeftToday":30,"endpoint":"tuyacn.com","eventSilenceInterval":120,"expiration":"2024-08-07T02:59:21Z","lifeCycle":2592000,"msgType":1,"pathConfig":{"detect":"/6e95b4-167507504-uuidcaab27b0a838d239/detect","log":"/6e95b4-167507504-uuidcaab27b0a838d239/log"},"provider":"oss","region":"cos.ap-shanghai","sk":"jfJw07GUpZKPLCKvGyO37DwetM3hgJLLmDKF5CbsIRc=","token":"RhX4bNdzqs5VkS5OwCIn8787VFkm5BPa0965af124a70d2e85d8d5dba2f984428hnA_pwn4WoDkbLLyx_rh9RpHaqhV8Rd3hbE9u6N2RQjN-v-xTZygSRsqeHoGxIya8XMqt5XtrsTAOJJgdjcllKs9sQGGfLs5CUlPwJPQ2k4MwqnXOg5cDxh4e0OmodofB5K8X-alo5w7stblgCeWlnEg_-d_6dq-UD-TucrZIdxvSKbdvNH5LPPTqzuHOrMzPoiENV9Nl82aDPa7QlkFqqLZaVX0o-b8gMLjzRWnlni4-24IUS7VpzqaRh_pmwnaKU0nIxQ5BCB8TBWs5trWfrUAmVjqSDkU7194pReusvcWQcC05fyHR43E1iCDDQ4QcizTaH3NLB83eQ6bj_yfqTw5SfLpxl52j72x2buWWqw4WuXSaQnHiBNGv6c5XPqZ3q6wl_7cRsPGddVus2tOk0S3L
[2024/8/7 8:59:19 389] [08-07 08:59:21 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:19 389] [08-07 08:59:21 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:19 405] [08-07 08:59:21 TUYA E][cloud_operation.c:647] fail to get value for key mediaStor
[2024/8/7 8:59:19 405] [08-07 08:59:21 TUYA D][upload_notification.c:511] cloud config 0 Init Success
[2024/8/7 8:59:19 421] [08-07 08:59:21 TUYA D][cloud_operation.c:1095] Final PUT:https://ty-cn-storage30-pic-1254153901.tuyacn.com/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992361.jpeg,size 26064
[2024/8/7 8:59:19 437] [08-07 08:59:21 TUYA D][httpc.c:813] Connect: ty-cn-storage30-pic-1254153901.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:19 437] [08-07 08:59:21 TUYA D][uni_network.c:314] unw_gethostbyname ty-cn-storage30-pic-1254153901.tuyacn.com, prio 0
[2024/8/7 8:59:19 453] [08-07 08:59:21 TUYA D][uni_network.c:188] use dns service to get ip for domain ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 8:59:19 469] [08-07 08:59:21 TUYA D][iot_httpc.c:1755] dns_query:https://h2.iot-dns.com/v1/dns_query [{"domain":"ty-cn-storage30-pic-1254153901.tuyacn.com"}]
[2024/8/7 8:59:19 469] [08-07 08:59:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:19 485] [08-07 08:59:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 8:59:19 485] [08-07 08:59:21 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 8:59:19 501] [08-07 08:59:21 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 8:59:19 501] [08-07 08:59:21 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 8:59:19 517] [08-07 08:59:21 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:19 519] [08-07 08:59:21 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:19 533] [08-07 08:59:21 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:19 533] [08-07 08:59:21 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:19 533] [08-07 08:59:21 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 8:59:19 548] [08-07 08:59:21 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:19 549] [08-07 08:59:21 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 8:59:19 564] [08-07 08:59:21 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:19 581] [08-07 08:59:21 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 8:59:19 582] [08-07 08:59:21 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:19 582] [08-07 08:59:21 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:19 597] [08-07 08:59:21 TUYA D][uni_network.c:100] get ip 121.4.234.150
[2024/8/7 8:59:19 597] [08-07 08:59:21 TUYA D][uni_network.c:197] dns service get ip 121.4.234.150 for domain ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 8:59:19 613] [08-07 08:59:21 TUYA D][uni_network.c:268] cache dns [ty-cn-storage30-pic-1254153901.tuyacn.com]<->[121.4.234.150]
[2024/8/7 8:59:19 613] [08-07 08:59:21 TUYA D][httpc.c:477] ----got ipaddr:121,4,234,150
[2024/8/7 8:59:19 628] [08-07 08:59:21 TUYA D][httpc.c:815] Connect: ty-cn-storage30-pic-1254153901.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:19 628] [08-07 08:59:21 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:19 644] [08-07 08:59:21 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect ty-cn-storage30-pic-1254153901.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:19 661] [08-07 08:59:21 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:19 661] [08-07 08:59:21 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:19 661] [08-07 08:59:21 TUYA D][tuya_iot_com_api.c:275] third cloud url
[2024/8/7 8:59:19 677] [08-07 08:59:21 TUYA D][tuya_iot_com_api.c:147] not found third ca
[2024/8/7 8:59:19 677] [08-07 08:59:21 TUYA D][tuya_iot_com_api.c:159] require CA for url ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 8:59:19 693] [08-07 08:59:21 TUYA D][iot_httpc.c:3536] query URL:ty-cn-storage30-pic-1254153901.tuyacn.com and Parse: ty-cn-storage30-pic-1254153901.tuyacn.com 443
[2024/8/7 8:59:19 709] [08-07 08:59:21 TUYA D][iot_httpc.c:1803] HTTP_DNS_QUERY:https://h2.iot-dns.com/device/dns_query
[2024/8/7 8:59:19 725] [08-07 08:59:21 TUYA D][iot_httpc.c:1804] http_dns send:[{"host":"ty-cn-storage30-pic-1254153901.tuyacn.com","port":443,"need_ca":true,"need_ip":false}]
[2024/8/7 8:59:19 725] [08-07 08:59:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:19 725] [08-07 08:59:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 8:59:19 741] [08-07 08:59:21 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 8:59:19 741] [08-07 08:59:21 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 8:59:19 757] [08-07 08:59:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 8:59:19 757] [08-07 08:59:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:19 773] [08-07 08:59:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:19 773] [08-07 08:59:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:19 789] [08-07 08:59:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:19 789] [08-07 08:59:22 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 8:59:19 805] [08-07 08:59:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:19 805] [08-07 08:59:22 TUYA D][tuya_ipc_cloud_storage.c:1200] force event 0 stop done
[2024/8/7 8:59:19 821] [08-07 08:59:22 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 8:59:19 821] [08-07 08:59:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:19 836] [2024-08-07 08:59:22] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time64815
[2024/8/7 8:59:19 837] [08-07 08:59:22 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 8:59:19 852] [08-07 08:59:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:19 853] [08-07 08:59:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:19 868] [08-07 08:59:22 TUYA D][tuya_iot_com_api.c:235] new CA stored for url ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 8:59:19 869] [08-07 08:59:22 TUYA D][tuya_iot_com_api.c:140] load ca to tls
[2024/8/7 8:59:19 884] [08-07 08:59:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:20 237] [atbm_log]:tso xmit(2934)
[2024/8/7 8:59:20 333] [08-07 08:59:22 TUYA D][tuya_tls.c:1539] handshake finish for ty-cn-storage30-pic-1254153901.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:20 349] [08-07 08:59:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect ty-cn-storage30-pic-1254153901.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:20 381] [08-07 08:59:23 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:20 397] [08-07 08:59:23 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:20 414] [08-07 08:59:23 TUYA D][cloud_operation.c:1165] HTTPS PUT https://ty-cn-storage30-pic-1254153901.tuyacn.com/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992361.jpeg done,size 26064 cost 1174 ms
[2024/8/7 8:59:20 414] [08-07 08:59:23 TUYA D][upload_notification.c:554] __notification_content_upload_from_buffer success
[2024/8/7 8:59:20 429] [08-07 08:59:23 TUYA D][upload_notification.c:161] notify DP:115 timeout:5
[2024/8/7 8:59:20 461] [08-07 08:59:23 TUYA D][upload_notification.c:181] final:{"v":"3.0","bucket":"ty-cn-storage30-pic-1254153901","files":[["/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992361.jpeg","dea13119e29f8d3d"]]}
[2024/8/7 8:59:20 461] [08-07 08:59:23 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 8:59:20 477] [08-07 08:59:23 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 8:59:20 493] [08-07 08:59:23 TUYA D][smart_frame.c:786] Send dp:115, RAW:{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyMzYxLmpwZWciLCJkZWExMzExOWUyOWY4ZDNkIl1dfQ=="}, retrans:1
[2024/8/7 8:59:20 525] [08-07 08:59:23 TUYA D][smart_frame.c:2219] dp rept_type:1, data:{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyMzYxLmpwZWciLCJkZWExMzExOWUyOWY4ZDNkIl1dfQ=="}
[2024/8/7 8:59:20 541] [08-07 08:59:23 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:43557 Q:1 Data:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyMzYxLmpwZWciLCJkZWExMzExOWUyOWY4ZDNkIl1dfQ=="}}
[2024/8/7 8:59:20 572] [08-07 08:59:23 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyMzYxLmpwZWciLCJkZWExMzExOWUyOWY4ZDNkIl1dfQ=="}} pro:4 num:43557
[2024/8/7 8:59:20 604] [08-07 08:59:23 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992363,"data":{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyMzYxLmpwZWciLCJkZWExMzExOWUyOWY4ZDNkIl1dfQ=="}}} offset:255
[2024/8/7 8:59:20 620] [08-07 08:59:23 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyMzYxLmpwZWciLCJkZWExMzExOWUyOWY4ZDNkIl1dfQ=="}}, msg_len:218, out_len:270
[2024/8/7 8:59:20 637] [08-07 08:59:23 TUYA D][app_agent.c:600] send length:272, id:35, sequence_out:14077
[2024/8/7 8:59:20 637] [08-07 08:59:23 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:115, curr_t:1722992363, rept_cnt:1.
[2024/8/7 8:59:20 653] [08-07 08:59:23 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:115, curr_t:1722992363, rept_cnt:0.
[2024/8/7 8:59:20 653] [08-07 08:59:23 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:115, curr_t:1722992363, rept_cnt:0.
[2024/8/7 8:59:20 669] [08-07 08:59:23 TUYA D][upload_notification.c:190] notification_message_upload success
[2024/8/7 8:59:21 293] curr event:17 
[2024/8/7 8:59:21 309] IPC_APP_Notify_LED_Sound_Status_CB line(609) -------------------------- IPC_ALARM_MOTION(17)
[2024/8/7 8:59:21 309] [2024-08-07 08:59:23] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 8:59:21 325] [2024-08-07 08:59:23] tuya_ipc_system_control_demo.c(628) <IPC_APP_Notify_LED_Sound_Status_CB>: sirenSwitch=[0],sirenVolumn=[30]
[2024/8/7 8:59:21 341] [2024-08-07 08:59:23] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 8:59:21 341] [2024-08-07 08:59:23] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 8:59:21 357] [2024-08-07 08:59:23] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 8:59:21 357] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=16.000 ms
[2024/8/7 8:59:21 373] [2024-08-07 08:59:23] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 8:59:21 373] [08-07 08:59:23 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 8:59:21 997] [2024-08-07 08:59:24] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:22 013] [08-07 08:59:24 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 8:59:22 013] [08-07 08:59:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:22 013] [08-07 08:59:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:22 029] [08-07 08:59:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:22 029] [08-07 08:59:24 TUYA D][tuya_svc_upgrade_http.c:125] schema get:{"schemaId":"flvlrc","version":""}
[2024/8/7 8:59:22 045] [08-07 08:59:24 TUYA D][iot_httpc.c:1161] Post Data: {"schemaId":"flvlrc","version":"","t":1722992364}
[2024/8/7 8:59:22 061] [08-07 08:59:24 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.schema.newest.get&devId=6c22076b2d2b61448fm8uy&et=1&t=1722992364&v=1.1&sign=3eb1f6a5d8e6318d5552c0c40d538d69
[2024/8/7 8:59:22 061] [08-07 08:59:24 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 8:59:22 077] [08-07 08:59:24 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 8:59:22 077] [08-07 08:59:24 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 8:59:22 093] [08-07 08:59:24 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 8:59:22 093] [08-07 08:59:24 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 8:59:22 109] [08-07 08:59:24 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 8:59:22 109] [08-07 08:59:24 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 8:59:22 125] [08-07 08:59:24 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 8:59:22 125] [08-07 08:59:24 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 8:59:22 141] [08-07 08:59:24 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 8:59:22 141] [08-07 08:59:24 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 8:59:22 157] [08-07 08:59:24 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 8:59:22 157] [08-07 08:59:24 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 8:59:22 173] [08-07 08:59:24 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"schema":"","schemaId":"flvlrc"},"t":1722992364,"success":true}
[2024/8/7 8:59:22 189] [08-07 08:59:24 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:22 190] [08-07 08:59:24 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:22 190] [08-07 08:59:24 TUYA D][tuya_svc_upgrade_http.c:133] schema get result:{"schema":"","schemaId":"flvlrc"}
[2024/8/7 8:59:22 205] [08-07 08:59:24 TUYA D][tuya_svc_schema_upgrade.c:130] schema[flvlrc] ver not update
[2024/8/7 8:59:22 525] [08-07 08:59:25 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"devId":"6c22076b2d2b61448fm8uy","gwId":"6c22076b2d2b61448fm8uy"},"protocol":11,"s":1785858,"t":1722992365}
[2024/8/7 8:59:22 525] [08-07 08:59:25 TUYA D][mqtt_client.c:916] disconnect mqtt
[2024/8/7 8:59:22 525] [08-07 08:59:25 TUYA E][app_agent.c:1479] close socket,errno:-100 errno:0
[2024/8/7 8:59:22 541] [08-07 08:59:25 TUYA D][app_agent.c:213] set socket fault 35
[2024/8/7 8:59:22 541] [08-07 08:59:25 TUYA D][app_agent.c:274] i:0,time:1722992365,c_time:1722992361,fault:1
[2024/8/7 8:59:22 557] [08-07 08:59:25 TUYA D][app_agent.c:163] close socket 35
[2024/8/7 8:59:22 604] [08-07 08:59:25 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 8:59:22 620] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 8:59:22 620] [08-07 08:59:25 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 8:59:22 637] [08-07 08:59:25 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 8:59:22 637] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 8:59:22 653] [08-07 08:59:25 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 8:59:22 653] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:22 669] [08-07 08:59:25 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 8:59:22 669] [08-07 08:59:25 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 8:59:22 716] [08-07 08:59:25 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992365 28800
[2024/8/7 8:59:22 733] [08-07 08:59:25 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992365 28800
[2024/8/7 8:59:23 085] [08-07 08:59:25 TUYA D][gw_mqc_cb.c:60] unactive
[2024/8/7 8:59:23 085] [08-07 08:59:25 TUYA E][mqtt_client.c:1652] mq_recv err:-30848 len:0
[2024/8/7 8:59:23 085] [08-07 08:59:25 TUYA D][tuya_devos_reset.c:418] unactive Reset
[2024/8/7 8:59:23 101] [08-07 08:59:25 TUYA D][tuya_devos_reset.c:261] gw reset called. tp:1 stat:1
[2024/8/7 8:59:23 101] __IPC_APP_Get_Net_Status_cb line(183) -------------------------- stat(0)==STAT_LOW_POWER 
[2024/8/7 8:59:23 117] [08-07 08:59:25 TUYA D][tuya_devos_reset.c:85] <__wf_reset> nc_tp:2, rst_tp:1, wifi_start_mode:0
[2024/8/7 8:59:23 117] [08-07 08:59:25 TUYA D][tuya_devos_reset.c:325] <__gw_reset> tuya_ble_clear_mesh
[2024/8/7 8:59:23 133] [08-07 08:59:25 TUYA D][tuya_ble_api.c:1050] start to clr appkey.
[2024/8/7 8:59:23 133] [08-07 08:59:25 TUYA D][simplekv.c:1348] delete key:ble_app_key isFuzzy:0
[2024/8/7 8:59:23 149] [08-07 08:59:25 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 8:59:23 150] [08-07 08:59:25 TUYA D][simplekv.c:1386] delete key find 4
[2024/8/7 8:59:23 150] [08-07 08:59:25 TUYA D][simplekv.c:1424] Delete key:ble_app_key 4 success
[2024/8/7 8:59:23 165] [08-07 08:59:25 TUYA D][simplekv.c:203] update crc 1347506755
[2024/8/7 8:59:23 165] [08-07 08:59:25 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:23 165] [08-07 08:59:25 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 8:59:23 181] [08-07 08:59:25 TUYA D][tuya_ble_api.c:1058] start to clr network_key.
[2024/8/7 8:59:23 181] [08-07 08:59:25 TUYA D][simplekv.c:1348] delete key:ble_network_key isFuzzy:0
[2024/8/7 8:59:23 197] [08-07 08:59:25 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 8:59:23 197] [08-07 08:59:25 TUYA D][simplekv.c:1386] delete key find 13
[2024/8/7 8:59:23 197] [08-07 08:59:25 TUYA D][simplekv.c:1424] Delete key:ble_network_key 13 success
[2024/8/7 8:59:23 213] [08-07 08:59:25 TUYA D][simplekv.c:203] update crc 771434461
[2024/8/7 8:59:23 213] [08-07 08:59:25 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:23 213] [08-07 08:59:25 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 8:59:23 229] [08-07 08:59:25 TUYA D][tuya_ble_api.c:1035] start to clr beaconkey.
[2024/8/7 8:59:23 229] [08-07 08:59:25 TUYA D][simplekv.c:1348] delete key:ble_beaconkey isFuzzy:0
[2024/8/7 8:59:23 244] [08-07 08:59:25 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 8:59:23 244] [08-07 08:59:25 TUYA D][simplekv.c:1386] delete key find 14
[2024/8/7 8:59:23 244] [08-07 08:59:25 TUYA D][simplekv.c:1424] Delete key:ble_beaconkey 14 success
[2024/8/7 8:59:23 260] [08-07 08:59:25 TUYA D][simplekv.c:203] update crc 1934809815
[2024/8/7 8:59:23 260] [08-07 08:59:25 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:23 260] [08-07 08:59:25 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 8:59:23 276] [08-07 08:59:25 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":1,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 8:59:23 292] [08-07 08:59:25 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 8:59:23 292] [08-07 08:59:25 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 8:59:23 309] [08-07 08:59:25 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:176
[2024/8/7 8:59:23 309] [08-07 08:59:25 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 8:59:23 309] [08-07 08:59:25 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 8:59:23 325] [08-07 08:59:25 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 8:59:23 325] [08-07 08:59:25 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 8:59:23 325] [08-07 08:59:25 TUYA D][simplekv.c:203] update crc 852014126
[2024/8/7 8:59:23 341] [08-07 08:59:25 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:23 341] [08-07 08:59:25 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:23 357] [08-07 08:59:25 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 8:59:23 357] [08-07 08:59:25 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 8:59:23 357] [08-07 08:59:25 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[2024/8/7 8:59:23 373] [08-07 08:59:25 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[2024/8/7 8:59:23 373] [08-07 08:59:25 TUYA D][tuya_svc_timer_task.c:107] reset. write_disk:1
[2024/8/7 8:59:23 389] [08-07 08:59:25 TUYA D][tuya_svc_timer_task.c:310] max len:128
[2024/8/7 8:59:23 389] [08-07 08:59:25 TUYA D][tuya_svc_timer_task.c:378] offset:27
[2024/8/7 8:59:23 389] [08-07 08:59:25 TUYA D][tuya_svc_timer_task.c:397] save TIMER:{"lastFetchTime":0,"cnt":0}
[2024/8/7 8:59:23 405] [08-07 08:59:25 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 8:59:23 405] [08-07 08:59:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:23 405] [08-07 08:59:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:23 421] [08-07 08:59:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:23 421] [08-07 08:59:25 TUYA D][simplekv.c:374] write key:timer_arr And Value Len:32
[2024/8/7 8:59:23 437] [08-07 08:59:25 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 32
[2024/8/7 8:59:23 437] [08-07 08:59:25 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 8:59:23 453] [08-07 08:59:25 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 8:59:23 455] [08-07 08:59:25 TUYA D][simplekv.c:203] update crc 3429414184
[2024/8/7 8:59:23 455] [08-07 08:59:25 TUYA N][mqtt_client.c:1703] mqtt close
[2024/8/7 8:59:23 455] [08-07 08:59:25 TUYA N][mqtt_client.c:839] close mqtt -->>
[2024/8/7 8:59:23 469] [08-07 08:59:25 TUYA D][mqtt_client.c:851] sh[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 8:59:23 469] utdown fd enabled
[2024/8/7 8:59:23 469] [08-07 08:59:25 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 8:59:23 485] [08-07 08:59:25 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 8:59:23 485] [08-07 08:59:25 TUYA N][mqtt_client.c:886] close mqtt <<--
[2024/8/7 8:59:23 501] [08-07 08:59:25 TUYA D][mqtt_client.c:1720] mqtt fail_cnt:1, sleept[atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 8:59:23 501] ime:5483 ms
[2024/8/7 8:59:23 501] [0[atbm_log]:aggtx stop queue
[2024/8/7 8:59:23 501] 8-07 08:59:25 TU[atbm_log]:add to pending(0)(20)
[2024/8/7 8:59:23 517] YA E][log_seq.c:[atbm_log]:AMPDU[eth2]:action[2],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:59:23 517] [atbm_log]:activated addBA response timer on tid 6
[2024/8/7 8:59:23 532] [08-07 08:59:25[atbm_log]:ignore pending[5][20]
[2024/8/7 8:59:23 532]  TUYA D][simplekv.c:359][atbm_log]:aggtx wake queue
[2024/8/7 8:59:23 533]  write head to normal fi[atbm_log]:not assoc 
[2024/8/7 8:59:23 533] le success
[2024/8/7 8:59:23 548] [08-07 08:5[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 8:59:23 549] 9:25 TUYA D][simplekv.c:[atbm_log]:AMPDU[eth2]:action[3],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:59:23 564] 520] write succe[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 8:59:23 564] ss
[2024/8/7 8:59:23 565] [08-07 08:5[atbm_log]:AMPDU[eth2]:action[1],tid[0],ssn[0],buff_size[0],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:59:23 580] 9:25 TUYA D][simplekv.c:1348] delete key:last_reset_info isFuzzy:0
[2024/8/7 8:59:23 580] [08-07 08:59:25 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 8:59:23 596] [08-07 08:59:25 TUYA D][simplekv.c:1395] key:last_reset_info not find
[2024/8/7 8:59:23 596] [08-07 08:59:25 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 8:59:23 596] [08-07 08:59:25 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 8:59:23 612] [08-07 08[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 5
[2024/8/7 8:59:23 612] :59:25 TUYA D][simplekv.[atbm_log]:AMPDU[eth2]:action[1],tid[5],ssn[0],buff_size[0],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:59:23 628] c:1251] find key:5 p2p_auth_info
[2024/8/7 8:59:23 628] [08-07 08:59:25 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 8:59:23 645] [08-07 08:59:25 TUYA D][simple[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 8:59:23 645] kv.c:374] write [atbm_log]:AMPDU[eth2]:action[3],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:59:23 661] key:p2p_auth_inf[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 8:59:23 661] o And Value Len:[atbm_log]:AMPDU[eth2]:action[1],tid[6],ssn[0],buff_size[0],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 8:59:23 661] 16
[2024/8/7 8:59:23 677] [08-07 08:59:25 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 16
[2024/8/7 8:59:23 677] [08-07 08:59:25 TUYA D][simplekv.c:430] find 5 avail[atbm_log]:eth2: deauthenticating from a4:a9:30:ce:5e:66 by local choice (reason=3)
[2024/8/7 8:59:23 677] able space
[2024/8/7 8:59:23 693] [08-07 08:59:25 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 8:59:23 693] [08-07 08:59:25 TUYA D][simplekv.c:203] update crc 2029288537
[2024/8/7 8:59:23 708] [08-07 08:59:25 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:23 708] [08-07 08:59:25 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:23 708] [08-07 08:59:25 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 8:59:23 724] [08-07 08:59:25 TUYA D][simplekv.[atbm_log]:[TX]:[0]:deatuhen[a4:a9:30:ce:5e:66]
[2024/8/7 8:59:23 724] c:1251] find key:6 p2p_p[atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 8:59:23 724] wd
[2024/8/7 8:59:23 740] [08-07 08:59:25 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 8:59:23 740] [08-07 08:59:25 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 8:59:23 740] [08-07 08:59:25 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 8:59:23 756] [08-07 08:59:25 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 8:59:23 756] [08-07 08:59:25 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 8:59:23 773] [08-07 08:59:25 TUYA D][simplekv.c:203] update crc 3252489268
[2024/8/7 8:59:23 773] [08-07 08:59:25 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:23 773] [08-07 08:59:25 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:23 788] [08-07 08:59:25 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 8:59:23 788] [08-07 08:59:25 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 8:59:23 788] [08-07 08:59:25 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 8:59:23 805] [08-07 08:59:25 TUYA D][s[atbm_log]:[STA]:unjoin ++
[2024/8/7 8:59:23 805] implekv.c:374] write key:p2p_typ[atbm_log]:[STA]:unjoin --
[2024/8/7 8:59:23 805] e And Value Len:16
[2024/8/7 8:59:23 820] [08-07 08:59:25 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 8:59:23 820] [08-07 08:59:25 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 8:59:23 820] [08-07 08:59:25 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 8:59:23 837] [08-07 08:59:25 TUYA D][simplekv.c:203] update crc 2183235102
[2024/8/7 8:59:23 837] [08-07 08:59:25 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 8:59:23 837] [08-07 08:59:25 TUYA D][simplekv.c:520] write success
[2024/8/7 8:59:23 853] rm: can't remove '/mnt/mtd/Config/localtime': Device or resource busy
[2024/8/7 8:59:23 853] rm: can't remove '/mnt/mtd/Config/resolv.conf': Device or resource busy
[2024/8/7 8:59:23 869] rm: can't remove '/mnt/mt[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 8:59:23 869] d/Config': Directory not empty
[2024/8/7 8:59:23 948] [atbm_log]:eth2:free authen bss ++
[2024/8/7 8:59:24 701] IPC_APP_Reset_System_CB line(143) -------------------------- 
[2024/8/7 8:59:24 717] [2024-08-07 08:59:26] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 08:59:26] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 8:59:24 717] set basic_indicator_onoff:0 
[2024/8/7 8:59:24 733] [2024-08-07 08:59:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:24 733] [2024-08-07 08:59:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:59:24 749] 
[2024/8/7 8:59:24 765] [2024-08-07 08:59:26] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 08:59:26] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 8:59:24 765] [2024-08-07 08:59:26] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time68823
[2024/8/7 8:59:24 781] [2024-08-07 08:59:26] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 08:59:26] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 8:59:24 797] [2024-08-07 08:59:26] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 08:59:26] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 8:59:24 829] [2024-08-07 08:59:26] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 08:59:26] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 8:59:24 829] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(150): cmd=[killall wpa_supplicant udhcpc;ifconfig eth2 down;ifconfig eth0 down;]
[2024/8/7 8:59:24 845]  ---
[2024/8/7 8:59:24 845] curr event:13 
[2024/8/7 8:59:24 845] IPC_APP_Notify_LED_Sound_Status_CB line(583) -------------------------- IPC_RESET_SUCCESS(13)
[2024/8/7 8:59:24 861] [2024-08-07 08:59:26] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/Reset_english.pcm]
[2024/8/7 8:59:24 861] [2024-08-07 08:59:26] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 8:59:24 877] [2024-08-07 08:59:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 8:59:24 893] [2024-08-07 08:59:26] tuya_ipc_system_control_demo.c(585) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(RESET, 0, 1, 0, 1))
[2024/8/7 8:59:24 893] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(155):  ---
[2024/8/7 8:59:24 909] [2024-08-07 08:59:26] xm_main.c(2440) <XMSDK_SystemRebootTY>: XMSDK_MotorGetPostion(3110,0) suc
[2024/8/7 8:59:24 909] [2024-08-07 08:59:26] xm_main.c(2064) <XM_SaveLocalPtzPosition>: Save PTZ xPosition 3110 failed
[2024/8/7 8:59:24 926] [2024-08-07 08:59:26] xm_main.c(2445) <XMSDK_SystemRebootTY>: XM_SaveLocalPtzPosition(3110,0) failed,ret=[-1]
[2024/8/7 8:59:24 926] XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 8:59:24 941] [2024-08-07 08:59:26] xm_main.c(2454) <XMSDK_SystemRebootTY>: XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 8:59:24 957] [2024-08-07 08:59:26] ==> XMSDK_SystemReboot(198)[INFO]: Sys XMSDK_SystemReboot Reboot
[2024/8/7 8:59:24 957] [2024-08-07 08:59:26] ==> XMSDK_SystemReboot(199)[INFO]: Sys Will Reboot
[2024/8/7 8:59:24 973] [2024-08-07 08:59:26] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 08:59:26] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 8:59:24 973] set basic_indicator_onoff:0 
[2024/8/7 8:59:24 989] [2024-08-07 08:59:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:24 989] [2024-08-07 08:59:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:59:25 006] [08-07 08:59:27 TUYA D][tuya_ble_api.c:1426] cloud disconnected, start adv!
[2024/8/7 8:59:25 006] [08-07 08:59:27 TUYA I][bt_ext_porting.c:628] [TUYA-BTUART]start_adv
[2024/8/7 8:59:25 020] --- tracepoint bt_ext_porting.c,tuya_ext_bt_start_adv(629): start_adv ---
[2024/8/7 8:59:25 021] [08-07 08:59:27 TUYA D][tuya_ble_api.c:1376] nw stat change:2->0, rpt to app.
[2024/8/7 8:59:25 036] [08-07 08:59:27 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 8:59:26 093] [2024-08-07 08:59:27] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:26 093] [08-07 08:59:28 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 8:59:26 220] g_AudioTipsList.size() enable: 0[2024-08-07 08:59:28] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 08:59:28] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [MotionDetect] pNumber[SirenSwitch]!
[2024/8/7 8:59:26 221] [08-07 08:59:28 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 8:59:27 532] [2024-08-07 08:59:28] xm_musicPlayer.cpp(177) <PlayAudioTips>: match reset audio
[2024/8/7 8:59:27 548] [08-07 08:59:30 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 8:59:27 885] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 8:59:27 885] Mode(Product):0
[2024/8/7 8:59:27 885] BpuMode:[Online]
[2024/8/7 8:59:27 885] VpssMode:[Online]
[2024/8/7 8:59:27 885] [0.LimitUp_info]:
[2024/8/7 8:59:27 885] LimitUp:[Disable]
[2024/8/7 8:59:27 885] [2680*0]->[3840*0])
[2024/8/7 8:59:27 901] chn	TotalSize	ActiveSize
[2024/8/7 8:59:27 901] 0	5040*2246	2680*2160
[2024/8/7 8:59:27 901] 0	5040*2246	3840*2160
[2024/8/7 8:59:27 901] Repair: En:1	Cnt:0x00000000
[2024/8/7 8:59:27 901] [1.VICU_info]:
[2024/8/7 8:59:27 917] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 8:59:27 917] 0	25.0	1623	0	0	183	linear	8ddb00
[2024/8/7 8:59:27 917] 0	0.0	0	0	0	0	linear	0
[2024/8/7 8:59:27 917] en	op_type	m_chn	now
[2024/8/7 8:59:27 917] 0	1	1	1
[2024/8/7 8:59:27 917] [2.VI_info]:
[2024/8/7 8:59:27 917] chn	TotalSize	ActiveSize
[2024/8/7 8:59:27 917] 0	5040*2246	3848*2166
[2024/8/7 8:59:27 933] 1	   0*   0	   0*   0
[2024/8/7 8:59:27 933] [3.MIPI_info]:
[2024/8/7 8:59:27 933] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 8:59:27 933] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 8:59:27 949] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 8:59:27 949] [4.Cut_info]:
[2024/8/7 8:59:27 949] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 8:59:27 949] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 8:59:27 949] h_d	0	1	 	 	2684	2160	  
[2024/8/7 8:59:27 965] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 8:59:27 965] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 8:59:27 965] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 8:59:27 965] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 8:59:27 965] [5.IB(isp buffer info)]:
[2024/8/7 8:59:27 981] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 8:59:27 981] PoolId  Count  Size
[2024/8/7 8:59:27 981] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:27 996] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:27 997] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:27 997] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:28 013] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:28 013] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:28 013] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 8:59:28 029] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 8:59:28 029] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 8:59:28 029] 0       0         0          0          4       
[2024/8/7 8:59:28 045] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 8:59:28 045]      --265--            --264--                                               
[2024/8/7 8:59:28 045] Count      Line     Count      Line     
[2024/8/7 8:59:28 061] 1294       480      2879       560      
[2024/8/7 8:59:28 061] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 8:59:28 076] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 8:59:28 077] 0   3840   2160    H265  0      0        0           757       983033     7        	
[2024/8/7 8:59:28 092] 1   640    360     H265  0      0        0           526       43195      5        	
[2024/8/7 8:59:28 093] 3   640    360     JPEG  0      0        0           1         172799     1        	
[2024/8/7 8:59:28 093] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 8:59:28 109] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 8:59:28 125] 0   Y      757      0       0       15       0        757      757      1017      63992         58576    149384   65187    12      
[2024/8/7 8:59:28 140] 1   Y      526      0       10      1        0        526      526      1017      2550          1875     24791    2574     9       
[2024/8/7 8:59:28 141] 3   N      1        0       0       1        0        1        1        1020      1801          1801     1801     1801     0       
[2024/8/7 8:59:29 244] xmsfc_shutdown 2 2 
[2024/8/7 8:59:29 244] Restarting system.
[2024/8/7 8:59:29 292] 
[2024/8/7 8:59:29 293] 
[2024/8/7 8:59:29 293] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 8:59:29 293] CPU: XM550V200WX2
[2024/8/7 8:59:29 293] DRAM:  128 MiB
[2024/8/7 8:59:29 421] MMC:   arasan: 0
[2024/8/7 8:59:29 469] In:    serial
[2024/8/7 8:59:29 469] Out:   serial
[2024/8/7 8:59:29 469] Err:   serial
[2024/8/7 8:59:29 692] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 8:59:29 692] Press Ctrl+C to stop autoboot
[2024/8/7 8:59:30 108] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 8:59:30 108] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 8:59:30 108]    Image Name:   Linux-3.10.103+
[2024/8/7 8:59:30 108]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 8:59:30 124]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 8:59:30 124]    Load Address: 80008000
[2024/8/7 8:59:30 124]    Entry Point:  80008000
[2024/8/7 8:59:30 124]    XIP Kernel Image ... OK
[2024/8/7 8:59:30 124] Starting kernel ...
[2024/8/7 8:59:31 021] Uncompressing Linux... done, booting the kernel.
[2024/8/7 8:59:31 148] Booting Linux on physical CPU 0x0
[2024/8/7 8:59:31 164] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 8:59:31 164] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 8:59:31 164] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 8:59:31 164] Machine: xm530v200
[2024/8/7 8:59:31 180] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 8:59:31 180] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 8:59:31 196] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 8:59:31 196] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 8:59:31 212] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 8:59:31 213] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 8:59:31 213] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 8:59:31 228] Memory: 52MB = 52MB total
[2024/8/7 8:59:31 228] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 8:59:31 228] Virtual kernel memory layout:
[2024/8/7 8:59:31 229]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 8:59:31 245]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 8:59:31 245]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 8:59:31 245]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 8:59:31 245]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 8:59:31 260]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 8:59:31 260]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 8:59:31 260]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 8:59:31 276]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 8:59:31 276] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 8:59:31 276] Hierarchical RCU implementation.
[2024/8/7 8:59:31 276] NR_IRQS:128
[2024/8/7 8:59:31 276] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 8:59:31 292] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 8:59:31 292] pid_max: default: 32768 minimum: 301
[2024/8/7 8:59:31 292] Mount-cache hash table entries: 512
[2024/8/7 8:59:31 292] CPU: Testing write buffer coherency: ok
[2024/8/7 8:59:31 308] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 8:59:31 308] L310 cache controller enabled
[2024/8/7 8:59:31 309] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 8:59:31 324] CPU1: Booted secondary processor
[2024/8/7 8:59:31 324] Brought up 2 CPUs
[2024/8/7 8:59:31 324] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 8:59:31 325] CPU: All CPU(s) started in SVC mode.
[2024/8/7 8:59:31 325] NET: Registered protocol family 16
[2024/8/7 8:59:31 340] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 8:59:31 340] Serial: AMBA PL011 UART driver
[2024/8/7 8:59:31 341] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 8:59:31 341] console [ttyAMA0] enabled
[2024/8/7 8:59:31 356] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 8:59:31 357] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 8:59:31 372] bio: create slab <bio-0> at 0
[2024/8/7 8:59:31 388] usbcore: registered new interface driver usbfs
[2024/8/7 8:59:31 388] usbcore: registered new interface driver hub
[2024/8/7 8:59:31 388] usbcore: registered new device driver usb
[2024/8/7 8:59:31 404] Switching to clocksource arm_global_timer
[2024/8/7 8:59:31 404] NET: Registered protocol family 2
[2024/8/7 8:59:31 405] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 8:59:31 420] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 8:59:31 420] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 8:59:31 420] TCP: reno registered
[2024/8/7 8:59:31 436] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 8:59:31 437] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 8:59:31 437] NET: Registered protocol family 1
[2024/8/7 8:59:31 437] RPC: Registered named UNIX socket transport module.
[2024/8/7 8:59:31 452] RPC: Registered udp transport module.
[2024/8/7 8:59:31 452] RPC: Registered tcp transport module.
[2024/8/7 8:59:31 452] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 8:59:31 468] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 8:59:31 484] NFS: Registering the id_resolver key type
[2024/8/7 8:59:31 484] Key type id_resolver registered
[2024/8/7 8:59:31 484] Key type id_legacy registered
[2024/8/7 8:59:31 484] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 8:59:31 500] fuse init (API version 7.22)
[2024/8/7 8:59:31 500] msgmni has been set to 95
[2024/8/7 8:59:31 500] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 8:59:31 500] io scheduler noop registered
[2024/8/7 8:59:31 516] io scheduler deadline registered (default)
[2024/8/7 8:59:31 516] io scheduler cfq registered
[2024/8/7 8:59:31 516] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 8:59:31 532] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 8:59:31 532] uart-pl011 uart:0: no DMA platform data
[2024/8/7 8:59:31 532] uart-pl011 uart:1: no DMA platform data
[2024/8/7 8:59:31 548] uart-pl011 uart:2: no DMA platform data
[2024/8/7 8:59:31 548] brd: module loaded
[2024/8/7 8:59:31 564] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 8:59:31 564] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 8:59:31 580] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 8:59:31 580] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 8:59:31 580] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 8:59:31 596] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 8:59:31 596] 0x000000300000-0x000000730000 : "user"
[2024/8/7 8:59:31 596] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 8:59:31 596] PPP generic driver version 2.4.2
[2024/8/7 8:59:31 612] NET: Registered protocol family 24
[2024/8/7 8:59:31 612] usbcore: registered new interface driver asix
[2024/8/7 8:59:31 612] usbcore: registered new interface driver cdc_ether
[2024/8/7 8:59:31 628] usbcore: registered new interface driver rndis_host
[2024/8/7 8:59:31 628] XMMMAC driver:
[2024/8/7 8:59:31 628] 	platform registration... 
[2024/8/7 8:59:31 628] 	done!
[2024/8/7 8:59:31 628] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 8:59:31 628] 	IO base addr: 0xfe010000)
[2024/8/7 8:59:31 644] libphy: XMMMAC MII Bus: probed
[2024/8/7 8:59:31 644] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 8:59:31 644] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 8:59:31 644] usbcore: registered new interface driver cdc_acm
[2024/8/7 8:59:31 660] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 8:59:31 660] usbcore: registered new interface driver usbserial
[2024/8/7 8:59:31 660] usbcore: registered new interface driver option
[2024/8/7 8:59:31 677] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 8:59:31 677] usbcore: registered new interface driver qcserial
[2024/8/7 8:59:31 692] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 8:59:31 692] TCP: cubic registered
[2024/8/7 8:59:31 692] NET: Registered protocol family 17
[2024/8/7 8:59:31 692] Key type dns_resolver registered
[2024/8/7 8:59:31 692] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 8:59:31 708] registered taskstats version 1
[2024/8/7 8:59:31 708] ÿVFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 8:59:31 724] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 8:59:32 060] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 8:59:32 604] arasan_set_clock:
[2024/8/7 8:59:32 620] 	new freq 400000
[2024/8/7 8:59:32 622] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 8:59:32 638] arasan_set_clock:
[2024/8/7 8:59:32 684] 	new freq 300000arasan_set_clock:
[2024/8/7 8:59:32 700] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 8:59:32 700] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 8:59:32 700] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 8:59:32 716] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 8:59:32 716] [reg] = 0x20000078,[val]= 0xc103c0ff
[2024/8/7 8:59:32 716] [reg] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 8:59:32 716] [reg] = 0x20000000,[val]= 0x00000000
[2024/8/7 8:59:32 716] arasan_set_clock:
[2024/8/7 8:59:32 732] 	new freq 195312[reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 8:59:32 732] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 8:59:32 732] [reg] = 0x20i2c: module license 'Proprietary' taints kernel.
[2024/8/7 8:59:32 748] 0505f0,[val]= 0xDisabling lock debugging due to kernel taint
[2024/8/7 8:59:32 748] 00000001
[2024/8/7 8:59:32 748] i2c init is ok!
[2024/8/7 8:59:32 764] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 8:59:32 876] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 8:59:32 956] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 8:59:32 972] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 8:59:32 988] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 8:59:33 020] acodec init is ok!
[2024/8/7 8:59:33 020] i2s clk:2048000Hz
[2024/8/7 8:59:33 180] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 8:59:33 180] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 8:59:33 180] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 8:59:33 180] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 8:59:33 196] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 8:59:33 196] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 8:59:33 196] usb usb1: Product: DWC OTG Controller
[2024/8/7 8:59:33 212] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 8:59:33 213] usb usb1: SerialNumber: dwc2.0
[2024/8/7 8:59:33 213] hub 1-0:1.0: USB hub found
[2024/8/7 8:59:33 213] hub 1-0:1.0: 1 port detected
[2024/8/7 8:59:33 259] xm_wdt init is ok
[2024/8/7 8:59:33 276] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 8:59:33 580] nn_kernel: NN: request mem  fail
[2024/8/7 8:59:33 580] nn_kernel: addr iomap fail
[2024/8/7 8:59:33 612] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 8:59:33 916] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 8:59:34 124] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 8:59:34 124] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 8:59:34 140] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 8:59:34 140] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 8:59:34 187] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtusbwifi_init.
[2024/8/7 8:59:34 187] d/user.sh: not fPDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 8:59:34 187] ound
[2024/8/7 8:59:34 219] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 8:59:34 252] exfatfsck 1.3.0
[2024/8/7 8:59:34 252] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 8:59:34 315] usb 1-1: USB disconnect, device number 3
[2024/8/7 8:59:44 855] µ½¹¡ªJم֥}Ƚݥɕ}¥}½¹¹н¥¹ѕɹе灪¤´´jmJjÒҊ²¢U 
[2024/8/7 8:59:44 855]                                      蕵E֥}¥½нݥɕ}ݥ¥}e¹骊ê¹ܽ¥}ݥɕ}½¹¹н¹с*ʉ½ɹjj¤´jÒҊ²¢U 
[2024/8/7 8:59:44 855]        Tµ 
[2024/8/7 8:59:44 870]        }¹э¹ꊂ 
[2024/8/7 8:59:44 870]        끁хʑ鲪ªjԤhjÒҊ²¢U 
[2024/8/7 8:59:44 871]       )ªµU¹¥}ѡɕ¹钒ê¢¡ɕ}ɕѕrµ骑==ڍbх­¡險¢b¢½х±Α­¡钊ª¢bɥ½ɥҥ驪ԤhjÒҊ²¢U 
[2024/8/7 8:59:44 886]        Tµ嫋זז֫V«iªꛑʑÅҩjԤhjÒҊ²¢U 
[2024/8/7 8:59:44 887]              Tµ%}¹э¹銊º蓑rэхʑ5jR´jÒҊ²¢U 
[2024/8/7 8:59:44 902]                                        ɪµE֥}±}e¹颚˪ªQѕ½չхҩjԤhjÒҊ²¢U 
[2024/8/7 8:59:44 903]        Tµ嫋זז֫V«iªꛑʑÅ¢ҩjԤhjÒҊ²¢U 
[2024/8/7 8:59:44 903]        TµE֥}±}e¹ 隊ª꫁ 
[2024/8/7 8:59:44 918]     فɅ±¹½¹¹}ɕŁ½¹¹jj¤D«ɗR-¤­Y^16
[2024/8/7 8:59:44 919] d0 7d 89 57 d1 c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 8:59:44 919] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 8:59:44 935] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 8:59:44 935] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 8:59:44 935] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 8:59:44 951] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 8:59:44 951] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 8:59:44 967] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0x2009de8),len(28)
[2024/8/7 8:59:44 967] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 8:59:44 983] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 8:59:44 983] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0x2009e08),len(30)
[2024/8/7 8:59:44 999] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 8:59:45 062] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a XshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshelle3 
[2024/8/7 8:59:45 079] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 8:59:45 079] adv_len:28
[2024/8/7 8:59:45 079] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 8:59:45 079] svc_data_uuid16 len:18
[2024/8/7 8:59:45 095] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:45 095] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 8:59:45 111] [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 8:59:45 111] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[2024/8/7 8:59:45 111] ---[XmBleAdvertiseEx][1210]: rc=[0]
[2024/8/7 8:59:45 127] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 8:59:45 127] rsp_len:30
[2024/8/7 8:59:45 127] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 8:59:45 127] mfg_data len:30
[2024/8/7 8:59:45 143] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 8:59:45 143] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 8:59:45 143] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 8:59:45 159] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:45 159] ---[XmBleAdvertiseEx][1241]: rc=[0]
[2024/8/7 8:59:45 159] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 8:59:45 159] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 8:59:45 175] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:45 175] adv_start rc = 0x0
[2024/8/7 8:59:45 191] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 8:59:45 191] [01-01 18:12:16 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 8:59:45 207] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:45 208] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:45 208] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:45 223] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:45 223] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:45 223] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:45 239] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:45 239] [01-01 18:12:17 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:45 255] [01-01 18:12:17 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:45 255] [01-01 18:12:17 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:45 255] [01-01 18:12:17 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:45 271] [01-01 18:12:17 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:45 271] [01-01 18:12:17 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:45 287] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:45 302] [01-01 18:12:17 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:45 303] [01-01 18:12:17 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:45 319] [01-01 18:12:17 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:45 319] [01-01 18:12:17 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:45 335] gethostbyname_r error: Unknown host
[2024/8/7 8:59:45 335] [01-01 18:12:17 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:45 335] [01-01 18:12:17 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:45 350] [01-01 18:12:17 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:45 350] [01-01 18:12:17 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:45 366] [01-01 18:12:17 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:45 366] [01-01 18:12:17 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:45 382] [01-01 18:12:17 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:45 382] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:45 382] [01-01 18:12:17 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 8:59:45 398] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:45 414] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:45 414] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 8:59:45 430] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:45 430] [01-01 18:12:17 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:45 447] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:45 462] [1970-01-01 00:00:13] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:45 462] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 8:59:45 462] [01-01 18:12:17 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 8:59:45 479] [01-01 18:12:17 TUYA D][tuya_ble_api.c:1470] ble get conn stat:4
[2024/8/7 8:59:45 479] [01-01 18:12:17 TUYA N][tuya_ble_api.c:750] ble_sdk_send skip, no connect:4
[2024/8/7 8:59:45 495] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:45 495] [01-01 18:12:18 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:45 510] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:45 510] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:45 526] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:45 528] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:45 528] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:45 542] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:45 542] [01-01 18:12:18 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:45 542] [01-01 18:12:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:45 559] [01-01 18:12:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:45 559] [01-01 18:12:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:45 574] [01-01 18:12:18 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:45 574] [01-01 18:12:18 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:45 574] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:45 606] [01-01 18:12:18 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:45 606] [01-01 18:12:18 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:45 622] [01-01 18:12:18 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:45 622] [01-01 18:12:18 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:45 622] gethostbyname_r error: Unknown host
[2024/8/7 8:59:45 638] [01-01 18:12:18 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:45 638] [01-01 18:12:18 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:45 654] [01-01 18:12:18 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:45 654] [01-01 18:12:18 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:45 670] [01-01 18:12:18 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:45 670] [01-01 18:12:18 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:45 686] [01-01 18:12:18 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:45 686] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:45 702] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:45 718] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:45 718] [01-01 18:12:18 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:46 166] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:46 166] [1970-01-01 00:00:14] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:46 182] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:46 198] [01-01 18:12:19 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:46 198] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:46 198] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:46 214] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:46 214] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:46 230] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:46 230] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:46 230] [01-01 18:12:19 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:46 247] [01-01 18:12:19 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:46 247] [01-01 18:12:19 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:46 247] [01-01 18:12:19 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:46 262] [01-01 18:12:19 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:46 262] [01-01 18:12:19 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:46 278] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:46 294] [01-01 18:12:19 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:46 310] [01-01 18:12:19 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:46 310] [01-01 18:12:19 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:46 311] [01-01 18:12:19 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:46 326] gethostbyname_r error: Unknown host
[2024/8/7 8:59:46 326] [01-01 18:12:19 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:46 327] 
[2024/8/7 8:59:46 327] [01-01 18:12:19 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:46 343] [01-01 18:12:19 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:46 343] [01-01 18:12:19 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:46 358] [01-01 18:12:19 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:46 359] [01-01 18:12:19 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:46 374] [01-01 18:12:19 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:46 374] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:46 454] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 8:59:46 454] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:46 470] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:46 470] [01-01 18:12:19 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:46 774] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:46 774] [01-01 18:12:19 TUYA D][tuya_ble_api.c:1376] nw stat change:0->1, rpt to app.
[2024/8/7 8:59:46 790] [01-01 18:12:19 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 8:59:47 174] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:47 189] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:47 190] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:47 206] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:47 207] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:47 207] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:47 225] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:47 226] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:47 226] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:47 238] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:47 238] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:47 238] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:47 254] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:47 254] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:47 270] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:47 286] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:47 302] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:47 302] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:47 318] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:47 318] gethostbyname_r error: Unknown host
[2024/8/7 8:59:47 318] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:47 334] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:47 334] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:47 334] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:47 350] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:47 350] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:47 366] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:47 366] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:47 446] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:47 462] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:47 462] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:48 149] motor auto test over
[2024/8/7 8:59:48 165] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 8:59:48 166] action=idle
[2024/8/7 8:59:48 166] dir=
[2024/8/7 8:59:48 166] flag=|auto-test-cmplt
[2024/8/7 8:59:48 166]  steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 8:59:48 166] YYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 8:59:48 182] flag=
[2024/8/7 8:59:48 182]  steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 8:59:48 197] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:48 198] [1970-01-01 00:00:16] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time16487
[2024/8/7 8:59:48 213] [1970-01-01 00:00:16] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:48 214] [1970-01-01 00:00:16] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:48 230] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:48 245] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:48 246] [01-01 18:12:21 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:48 261] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:48 262] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:48 278] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:48 278] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:48 278] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:48 295] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:48 295] [01-01 18:12:21 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:48 295] [01-01 18:12:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:48 310] [01-01 18:12:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:48 310] [01-01 18:12:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:48 326] [01-01 18:12:21 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:48 326] [01-01 18:12:21 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:48 327] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:48 358] [01-01 18:12:21 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:48 358] [01-01 18:12:21 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:48 374] [01-01 18:12:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:48 374] [01-01 18:12:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:48 375] gethostbyname_r error: Unknown host
[2024/8/7 8:59:48 390] [01-01 18:12:21 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:48 390] [01-01 18:12:21 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:48 406] [01-01 18:12:21 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:48 406] [01-01 18:12:21 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:48 422] [01-01 18:12:21 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:48 422] [01-01 18:12:21 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:48 438] [01-01 18:12:21 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:48 438] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:48 470] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 8:59:48 486] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:48 486] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:48 502] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:48 790] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 8:59:48 806] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:48 822] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 8:59:49 222] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:49 238] [01-01 18:12:22 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:49 238] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:49 254] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:49 255] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:49 255] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:49 270] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:49 270] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:49 270] [01-01 18:12:22 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:49 286] [01-01 18:12:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:49 286] [01-01 18:12:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:49 286] [01-01 18:12:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:49 302] [01-01 18:12:22 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:49 302] [01-01 18:12:22 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:49 318] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:49 334] [01-01 18:12:22 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:49 350] [01-01 18:12:22 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:49 350] [01-01 18:12:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:49 366] [01-01 18:12:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:49 366] gethostbyname_r error: Unknown host
[2024/8/7 8:59:49 366] [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:49 382] [01-01 18:12:22 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:49 382] [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:49 382] [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:49 398] [01-01 18:12:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:49 398] [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:49 414] [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:49 414] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:49 430] [01-01 18:12:22 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 8:59:49 477] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:49 493] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:49 493] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:50 294] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:50 310] [1970-01-01 00:00:18] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:50 326] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:50 326] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:50 342] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:50 342] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:50 358] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:50 358] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:50 358] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:50 374] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:50 374] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:50 390] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:50 390] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:50 390] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:50 406] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:50 406] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:50 422] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:50 422] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:50 438] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:50 454] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:50 454] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:50 470] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:50 470] gethostbyname_r error: Unknown host
[2024/8/7 8:59:50 470] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:50 486] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:50 486] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:50 502] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:50 502] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:50 518] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:50 518] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:50 518] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:50 533] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 8:59:50 549] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:50 565] [1970-01-01 00:00:19] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:50 566] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:51 334] [1970-01-01 00:00:19] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 8:59:51 334] [1970-01-01 00:00:19] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 8:59:51 350] mpId[0] is [0].
[2024/8/7 8:59:51 350] mpId[1] is [0].
[2024/8/7 8:59:51 350] mpId[2] is [0].
[2024/8/7 8:59:51 350] mpId[3] is [0].
[2024/8/7 8:59:51 350] mpId[4] is [0].
[2024/8/7 8:59:51 350] mpId[5] is [0].
[2024/8/7 8:59:51 350] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 8:59:51 366] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 8:59:51 382] [1970-01-01 00:00:19] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:51 382] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:51 398] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:51 414] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:51 414] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:51 430] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:51 430] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:51 430] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:51 446] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:51 446] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:51 461] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:51 462] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:51 462] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:51 477] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:51 477] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:51 493] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:51 493] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:51 493] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:51 526] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:51 526] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:51 541] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:51 541] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:51 541] gethostbyname_r error: Unknown host
[2024/8/7 8:59:51 559] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:51 560] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:51 574] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:51 574] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:51 590] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:51 590] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:51 590] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:51 606] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:51 622] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:51 622] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:51 638] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:52 392] [1970-01-01 00:00:20] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time20493
[2024/8/7 8:59:52 406] [1970-01-01 00:00:20] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:52 406] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:52 422] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:52 437] [01-01 18:12:25 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:52 438] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:52 453] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:52 454] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:52 454] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:52 469] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:52 469] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:52 469] [01-01 18:12:25 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:52 486] [01-01 18:12:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:52 486] [01-01 18:12:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:52 487] [01-01 18:12:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:52 502] [01-01 18:12:25 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:52 502] [01-01 18:12:25 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:52 518] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:52 533] [01-01 18:12:25 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:52 550] [01-01 18:12:25 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:52 550] [01-01 18:12:25 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:52 566] [01-01 18:12:25 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:52 566] gethostbyname_r error: Unknown host
[2024/8/7 8:59:52 566] [01-01 18:12:25 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:52 582] [01-01 18:12:25 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:52 582] [01-01 18:12:25 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:52 582] [01-01 18:12:25 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:52 599] [01-01 18:12:25 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:52 599] [01-01 18:12:25 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:52 616] [01-01 18:12:25 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:52 616] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:52 710] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:52 726] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 8:59:52 741] src/intelligent_track_thread.c(709) [TrackProcV200]: Intelligent Track Enable eSensitivity=0 intervalTime_sec=15
[2024/8/7 8:59:52 742] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 8:59:52 742] [01-01 18:12:25 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 8:59:53 525] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:53 541] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:53 542] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:53 558] [01-01 18:12:26 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:53 558] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:53 573] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:53 573] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:53 574] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:53 589] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:53 589] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:53 605] [01-01 18:12:26 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:53 605] [01-01 18:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:53 605] [01-01 18:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:53 621] [01-01 18:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:53 621] [01-01 18:12:26 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:53 621] [01-01 18:12:26 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:53 638] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:53 654] [01-01 18:12:26 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:53 670] [01-01 18:12:26 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:53 670] [01-01 18:12:26 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:53 686] [01-01 18:12:26 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:53 686] gethostbyname_r error: Unknown host
[2024/8/7 8:59:53 686] [01-01 18:12:26 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:53 702] [01-01 18:12:26 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:53 702] [01-01 18:12:26 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:53 718] [01-01 18:12:26 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:53 718] [01-01 18:12:26 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:53 734] [01-01 18:12:26 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:53 734] [01-01 18:12:26 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:53 734] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:53 750] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 8:59:53 750] Mode(Product):0
[2024/8/7 8:59:53 750] BpuMode:[Online]
[2024/8/7 8:59:53 750] VpssMode:[Online]
[2024/8/7 8:59:53 750] [0.LimitUp_info]:
[2024/8/7 8:59:53 750] LimitUp:[Disable]
[2024/8/7 8:59:53 750] [2680*0]->[3840*0])
[2024/8/7 8:59:53 750] chn	TotalSize	ActiveSize
[2024/8/7 8:59:53 766] 0	5040*2246	2680*2160
[2024/8/7 8:59:53 766] 0	5040*2246	3840*2160
[2024/8/7 8:59:53 766] Repair: En:1	Cnt:0x00000000
[2024/8/7 8:59:53 766] [1.VICU_info]:
[2024/8/7 8:59:53 766] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 8:59:53 782] 0	25.0	364	0	0	183	linear	8ddb00
[2024/8/7 8:59:53 782] 0	0.0	0	0	0	0	linear	0
[2024/8/7 8:59:53 782] en	op_type	m_chn	now
[2024/8/7 8:59:53 782] 0	1	1	1
[2024/8/7 8:59:53 782] [2.VI_info]:
[2024/8/7 8:59:53 783] chn	TotalSize	ActiveSize
[2024/8/7 8:59:53 783] 0	5040*2246	3848*2166
[2024/8/7 8:59:53 783] 1	   0*   0	   0*   0
[2024/8/7 8:59:53 797] [3.MIPI_info]:
[2024/8/7 8:59:53 798] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 8:59:53 799] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 8:59:53 799] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 8:59:53 813] [4.Cut_info]:
[2024/8/7 8:59:53 813] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 8:59:53 814] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 8:59:53 814] h_d	0	1	 	 	2684	2160	  
[2024/8/7 8:59:53 814] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 8:59:53 814] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 8:59:53 829] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 8:59:53 829] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 8:59:53 829] [5.IB(isp buffer info)]:
[2024/8/7 8:59:53 830] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 8:59:53 845] PoolId  Count  Size
[2024/8/7 8:59:53 845] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:53 845] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:53 861] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:53 861] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:53 877] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 8:59:53 877] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 8:59:53 893] 
[2024/8/7 8:59:53 894] 
[2024/8/7 8:59:53 894] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 8:59:53 894] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 8:59:53 894] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 8:59:53 909] 0       0         0          0          4       
[2024/8/7 8:59:53 909] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 8:59:53 925]      --265--            --264--                                               
[2024/8/7 8:59:53 925] Count      Line     Count      Line     
[2024/8/7 8:59:53 925] 269        480      606        560      
[2024/8/7 8:59:53 941] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 8:59:53 942] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 8:59:53 942] 0   3840   2160    H265  0      0        0           160       983033     7        	
[2024/8/7 8:59:53 957] 1   640    360     H265  0      0        0           106       43196      4        	
[2024/8/7 8:59:53 958] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 8:59:53 974] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 8:59:53 990] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 8:59:53 990] 0   Y      160      0       0       15       0        160      160      223       66256         59217    92469    65061    12      
[2024/8/7 8:59:54 006] 1   Y      106      0       2       1        0        106      106      224       2213          1910     63542    3865     8       
[2024/8/7 8:59:54 022] 3   N      0        0       0       1        0        0        0        225       0             0        0        0        0       
[2024/8/7 8:59:54 022] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 8:59:54 038] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:54 038] [1970-01-01 00:00:22] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:59:54 054] [1970-01-01 00:00:22] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 8:59:54 054] [01-01 18:12:27 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 8:59:54 565] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:54 582] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:54 582] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:54 598] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:54 613] [01-01 18:12:27 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:54 613] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:54 613] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:54 630] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:54 630] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:54 646] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:54 646] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:54 646] [01-01 18:12:27 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:54 662] [01-01 18:12:27 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:54 662] [01-01 18:12:27 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:54 662] [01-01 18:12:27 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:54 678] [01-01 18:12:27 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:54 678] [01-01 18:12:27 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:54 694] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:54 710] [01-01 18:12:27 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:54 726] [01-01 18:12:27 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:54 726] [01-01 18:12:27 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:54 726] [01-01 18:12:27 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:54 742] gethostbyname_r error: Unknown host
[2024/8/7 8:59:54 742] [01-01 18:12:27 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:54 742] [01-01 18:12:27 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:54 758] [01-01 18:12:27 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:54 758] [01-01 18:12:27 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:54 774] [01-01 18:12:27 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:54 774] [01-01 18:12:27 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:54 790] [01-01 18:12:27 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:54 790] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:54 790] [01-01 18:12:27 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 8:59:55 718] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:55 718] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:55 734] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:55 750] [01-01 18:12:28 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:55 750] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:55 750] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:55 766] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:55 766] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:55 782] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:55 782] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:55 782] [01-01 18:12:28 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:55 798] [01-01 18:12:28 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:55 798] [01-01 18:12:28 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:55 798] [01-01 18:12:28 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:55 814] [01-01 18:12:28 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:55 814] [01-01 18:12:28 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:55 830] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:55 846] [01-01 18:12:28 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:55 861] [01-01 18:12:28 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:55 861] [01-01 18:12:28 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:55 861] [01-01 18:12:28 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:55 877] 
[2024/8/7 8:59:55 878] gethostbyname_r error: Unknown host
[2024/8/7 8:59:55 878] [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:55 878] [01-01 18:12:28 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:55 893] [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:55 893] [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:55 909] [01-01 18:12:28 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:55 909] [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:55 925] [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:55 925] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:56 837] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:56 837] [1970-01-01 00:00:24] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time24759
[2024/8/7 8:59:56 853] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:56 869] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:56 869] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:56 885] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:56 901] [01-01 18:12:29 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:56 901] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:56 901] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:56 917] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:56 917] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:56 917] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:56 933] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:56 933] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:56 949] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:56 949] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:56 949] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:56 965] [01-01 18:12:30 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:56 965] [01-01 18:12:30 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:56 981] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:56 997] [01-01 18:12:30 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:56 997] [01-01 18:12:30 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:57 013] [01-01 18:12:30 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:57 013] [01-01 18:12:30 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:57 029] gethostbyname_r error: Unknown host
[2024/8/7 8:59:57 029] [01-01 18:12:30 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:57 029] [01-01 18:12:30 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:57 045] [01-01 18:12:30 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:57 045] [01-01 18:12:30 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:57 061] [01-01 18:12:30 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:57 061] [01-01 18:12:30 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:57 077] [01-01 18:12:30 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:57 077] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:57 398] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:57 398] [1970-01-01 00:00:25] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 8:59:57 414] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:57 414] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 8:59:57 765] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:57 781] set basic_indicator_onoff:0 
[2024/8/7 8:59:57 781] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(257) <IPC_APP_set_basic_indicator_onoff>: Get BasicIndicator suc,gpio value=[0x0c]
[2024/8/7 8:59:57 797] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:57 797] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:59:57 813] set basic_indicator_onoff:1 
[2024/8/7 8:59:57 813] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:57 829] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:59:57 829] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:57 829] ble_slave_gap_event->type=0
[2024/8/7 8:59:57 845] connection established; status=0 GATT procedure initiated: exchange mtu
[2024/8/7 8:59:57 845] connection, handle=1
[2024/8/7 8:59:57 845] set basic_indicator_onoff:0 
[2024/8/7 8:59:57 861] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:57 861] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:59:57 877] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:57 877] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:57 893] --- tracepoint bt_ext_porting.c,ty_btext_thread(423): TY_BT_EVENT_CONNECTED1 ---
[2024/8/7 8:59:57 893] [01-01 18:12:30 TUYA D][tuya_ble_api.c:543] rev ble event 1
[2024/8/7 8:59:57 893] [01-01 18:12:30 TUYA N][tuya_ble_api.c:472] Ble Connected
[2024/8/7 8:59:57 909] [01-01 18:12:30 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[2024/8/7 8:59:57 909] [01-01 18:12:30 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
[2024/8/7 8:59:57 942] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:57 958] --- tracepoint bt_ext_porting.c,ty_btext_thread(425): TY_BT_EVENT_CONNECTED2 ---
[2024/8/7 8:59:57 958] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:57 974] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:57 974] ble_slave_gap_event->type=15
[2024/8/7 8:59:57 974] mtu update event; conn_handle=1 cid=4 mtu=255
[2024/8/7 8:59:57 989] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:57 989] ble_slave_gap_event->type=4
[2024/8/7 8:59:57 989] connection update request
[2024/8/7 8:59:57 989] [01-01 18:12:31 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:58 005] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 8:59:58 006] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 021] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:58 021] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:58 038] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:58 038] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:58 038] [01-01 18:12:31 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:58 053] [01-01 18:12:31 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:58 054] [01-01 18:12:31 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:58 054] [01-01 18:12:31 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:58 069] [01-01 18:12:31 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:58 070] [01-01 18:12:31 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:58 086] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dn[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 086] s_cache_priority:2
[2024/8/7 8:59:58 102] [01-01 18:12:31 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:58 118] [01-01 18:12:31 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:58 118] [01-01 18:12:31 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:58 134] [01-01 18:12:31 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:58 134] gethostbyname_r error: Unknown host
[2024/8/7 8:59:58 134] [01-01 18:12:31 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 8:59:58 150] [01-01 18:12:31 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:58 150] [01-01 18:12:31 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:58 165] [01-01 18:12:31 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:58 166] [01-01 18:12:31 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:58 182] [01-01 18:12:31 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:58 182] [01-01 18:12:31 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:58 182] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:58 261] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 406] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 421] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 581] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 661] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 837] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 886] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 8:59:58 886] set basic_indicator_onoff:1 
[2024/8/7 8:59:58 902] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:58 902] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:58 918] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:59:58 934] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:58 934] set basic_indicator_onoff:0 
[2024/8/7 8:59:58 934] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:58 950] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:59:58 950] set basic_indicator_onoff:1 
[2024/8/7 8:59:58 966] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=fal[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 966] se
[2024/8/7 8:59:58 966] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:59:58 982] [1970-01-01 00:00:27] MainApp.c(1978) <main[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 982] >: wait for g_DeviceOnline ... 
[2024/8/7 8:59:58 998] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:58 998] ble_slave_gap_event->ty[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:58 998] pe=3
[2024/8/7 8:59:59 014] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 8:59:59 014] set basic_indicator_onoff:0 
[2024/8/7 8:59:59 030] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:59 030] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:59:59 045] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:59 045] ble_slave_gap_event->type=4
[2024/8/7 8:59:59 045] connection update request
[2024/8/7 8:59:59 045] set basic_indicator_onoff:1 
[2024/8/7 8:59:59 062] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:59 062] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 8:59:59 077] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:59 094] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:59 094] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:59 094] set basic_indicator_onoff:0 
[2024/8/7 8:59:59 110] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:59 110] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 8:59:59 126] [01-01 18:12:32 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 8:59:59 142] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 8:59:59 142] set basic_indicator_onoff:1 
[2024/8/7 8:59:59 142] [1970-01-01 00:00:27] tuya[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 158] _ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 8:59:59 158] ble_slave_gap_event->type=3
[2024/8/7 8:59:59 158] connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 8:59:59 174] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 8:59:59 174] [01-01 18:12:32 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 8:59:59 190] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 190] cnt isFuzzy:0
[2024/8/7 8:59:59 190] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:59 206] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 8:59:59 206] [01-01 18:12:32 TUYA D][simplekv.c:1348[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 222] ] delete key:tls_ca isFuzzy:1
[2024/8/7 8:59:59 222] [01-01 18:12:32 TUYA D][simplekv[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 222] .c:1354] cnt:8 delete bit arr len:1
[2024/8/7 8:59:59 238] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 8:59:59 238] [01-01 18:12:32 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 8:59:59 238] [01-01 18:12:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 8:59:59 254] [01-01 18:12:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 8:59:59 254] [01-01 18:12:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 8:59:59 270] [01-01 18:12:32 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 8:59:59 270] [01-01 18:12:32 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 8:59:59 270] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 8:59:59 286] [01-01 18:12:32 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_c[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 302] a":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 8:59:59 317] [01-01 18:12:32 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 8:59:59 318] [01-01 18:12:32 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 8:59:59 333] [01-01 18:12:32 TUYA D][uni_network.c:314] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 334] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 8:59:59 334] gethostbyname_r error: Unknown host
[2024/8/7 8:59:59 349] [01-01 18:12:32 TUYA E][uni_network.c:[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 349] 360] fail to gethostbyname 22
[2024/8/7 8:59:59 349] [01-01 18:12:32 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 8:59:59 365] [01-01 18:12:32 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 8:59:59 365] [01-01 18:12:32 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 8:59:59 365] [01-01 18:12:32 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 8:59:59 381] [01-01 18:12:32 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 8:59:59 381] [01-01 18:12:32 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 8:59:59 397] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 8:59:59 493] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 654] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 8:59:59 990] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:00 006] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:00 006] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:00 006] set basic_indicator_onoff:0 
[2024/8/7 9:00:00 021] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 021] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:00 037] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:00 053] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:00 053] set basic_indicator_onoff:1 
[2024/8/7 9:00:00 053] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 069] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:00 069] [1970-01-01 00:00:28] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:00 086] ble_slave_gap_event->type=4
[2024/8/7 9:00:00 086] connection update request
[2024/8/7 9:00:00 086] set basic_indicator_onoff:0 
[2024/8/7 9:00:00 102] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 102] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:00 102] ble_slave_gap_event->type=14
[2024/8/7 9:00:00 118] subscribe event; conn_handle=1 attr_handle=23 reason=1 prevn=0 curn=1 previ=0 curi=0
[2024/8/7 9:00:00 118] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:00:00 118] ble_slave_gap_event->type=3
[2024/8/7 9:00:00 134] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:00:00 149] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:00 150] atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 150] mset basic_indicator_onoff:1 
[2024/8/7 9:00:00 165] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 165] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:00 181] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:00 181] set basic_indicator_onoff:0 
[2024/8/7 9:00:00 181] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 197] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:00 213] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame su[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 213] cess width 640 height 360 data[][atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 229] set basic_indicator_onoff:1 
[2024/8/7 9:00:00 229] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 245] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:00 245] [01-01 18:12:33 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:00 245] [01-01 18:12:33 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:00 261] [01-01 18:12:33 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:00 261] [01-01 18:12:33 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:00 277] [01-01 18:12:33 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:00 277] [01-01 18:12:33 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:00 277] [01-01 18:12:33 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:00 293] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:00 293] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:00 293] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:00 309] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:00 309] [0[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 325] 1-01 18:12:33 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:00 325] [01-01 18:12:33 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:00 325] [01-01 18:12:33 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:00 357] [01-01 18:12:33 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:00 357] [01-01 18:12:33 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:00 373] [01-01 18:12:33 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:00 389] [01-01 18:12:33 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:00 405] gethostbyname_r error: Unknown host
[2024/8/7 9:00:00 405] [01-01 18:12:33 TU[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 405] YA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:00 421] [01-01 18:12:33 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:00 421] [01-01 18:12:33 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:00 438] [01-01 18:12:33 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:00 438] [01-01 18:12:33 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:00 454] [01-01 18:12:33 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:00 454] [01-01 18:12:33 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:00 454] [01-01 18:12:33 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:00 470] [01-01 18:12:33 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:00:00 470] [1970-01-01 00:00:29] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time29059
[2024/8/7 9:00:00 470] set basic_indicator_onoff:0 
[2024/8/7 9:00:00 486] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 486] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:00 502] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:00 502] Len=20 step 0
[2024/8/7 9:00:00 502] att=0x0 0x21 0x20 0x1 0xf2 0xa1 0x71 0xa0 0xf6 0x53 0xbb 0x67 0x38 0xee 0x1c 0xff 0xd5 0x51 0xad 0x80 
[2024/8/7 9:00:00 518]  RCVS len:20
[2024/8/7 9:00:00 518] XmBleReadBuf 20:
[2024/8/7 9:00:00 518] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:00 518] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:00 533] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:00 533] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:00 534] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:00 549] [01-01 18:12:33 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:00 550] [01-01 18:12:33 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:00 565] [01-01 18:12:33 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:00 565] bt_rev_raw 20
[2024/8/7 9:00:00 565] 00 21 20 01 f2 a1 71 a0 f6 53 bb 67 38 ee 1c ff d5 51 ad 80 
[2024/8/7 9:00:00 582] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:00:00 582] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:00 597] --- tracepoint bt_ext_portin[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 597] g.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:00 613] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:00 613] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:00 613] Len=17 step 0
[2024/8/7 9:00:00 629] att=0x1 0xf6 0x65 0xd3 0x58 0x9c 0xda 0xfb 0x16 0x44 0xf 0xd3 0xdb 0x3 0xd0 0xf 0xaf 
[2024/8/7 9:00:00 631]  RCVS len:17
[2024/8/7 9:00:00 631] set basic_indicator_onoff:1 
[2024/8/7 9:00:00 631] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 645] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:00 645] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:00 645] XmBleReadBuf 17:
[2024/8/7 9:00:00 661] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:00 661] --- tracepoint bt_ext_po[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 661] rting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:00 677] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:00 677] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:00:00 677] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:00:00 693] [01-01 18:12:33 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:00:00 693] [01-01 18:12:33 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:00 709] [01-01 18:12:33 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:00 709] bt_rev_raw 17
[2024/8/7 9:00:00 709] 01 f6 65 d3 58 9c da fb 16 44 0f d3 db 03 d0 0f af 
[2024/8/7 9:00:00 725] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:00:00 725] ble rev data 33
[2024/8/7 9:00:00 725] 01 f2 a1 71 a0 f6 53 bb 67 38 ee 1c ff d5 51 ad 80 f[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 741] 6 65 d3 58 9c da fb 16 44 0f d3 db 03 d0 0f af 
[2024/8/7 9:00:00 741] [01-01 18:12:33 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:00:00 741] ble decryped data 16
[2024/8/7 9:00:00 741] 00 00 00 01 00 00 00 00 00 00 00 00 92 69 00 00 
[2024/8/7 9:00:00 759] [01-01 18:12:33 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:00:00 759] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x0 
[2024/8/7 9:00:00 775] [01-01 18:12:33 TUYA N][tuya_ble_data_handler.c:451] tuya_ble_handle_dev_infor_req state:0, pkg_len:20
[2024/8/7 9:00:00 775] [01-01 18:12:33 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:00:00 775] [01-01 18:12:33 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:00:00 790] [01-01 18:12:33 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:00:00 790] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:00:00 808] [01-01 18:12:33 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:4, send_data:16
[2024/8/7 9:00:00 808] tuya_hal_bt_send 20
[2024/8/7 9:00:00 808] 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:00:00 822] [01-01 18:12:33 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:00 822] 0 81 1 30 1 57 27 a7 5 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:00:00 822] XmBleSendBuf 20: 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58
[2024/8/7 9:00:00 838] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:00 838] ble_slave_gap_event->type=13
[2024/8/7 9:00:00 838] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:00 838] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:00 853] [01-01 18:12:33 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:00 853] [01-01 18:12:33 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:00 870] tuya_hal_bt_send 20
[2024/8/7 9:00:00 870] 01 3d c5 66 ed 55 a3 04 e7 22 85 b9 4c ba 08 9a c9 83 c7 fe 
[2024/8/7 9:00:00 870] [01-01 18:12:33 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:00 885] 1 3d c5 66 ed 55 a3 4 e7 22 85 b9 4c ba 8 9a c9 83 c7 fe 
[2024/8/7 9:00:00 885] XmBleSendBuf 20: 01 3d c5 66 ed 55 a3 04 e7 22 85 b9 4c ba 08 9a c9 83 c7 fe
[2024/8/7 9:00:00 885] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:00 885] ble_slave_gap_event->type=13
[2024/8/7 9:00:00 901] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:00 902] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:00 902] [01-01 18:12:33 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:00 917] set basic_indicator_onoff:0 
[2024/8/7 9:00:00 917] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:00 934] [[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:00 934] 1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:00 949] [01-01 18:12:33 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:00 949] tuya_hal_bt_send 20
[2024/8/7 9:00:00 949] 02 9b 23 e6 b9 48 6e ce 84 7c fc 4f 5d 73 2c 5c 32 1f b5 79 
[2024/8/7 9:00:00 949] [01-01 18:12:33 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:00 965] 2 9b 23 e6 b9 48 6e ce 84 7c fc 4f 5d 73 2c 5c 32 1f b5 79 
[2024/8/7 9:00:00 965] XmBleSendBuf 20: 02 9b 23 e6 b9 48 6e ce 84 7c fc 4f 5d 73 2c 5c 32 1f b5 79
[2024/8/7 9:00:00 965] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:00 981] ble_slave_gap_event->type=13
[2024/8/7 9:00:00 981] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:00 981] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:00 997] [01-01 18:12:33 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:00 997] set basic_indicator_onoff:1 
[2024/8/7 9:00:00 997] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:01 013] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:01 013] [01-01 18:12:33 TUYA D][tuya_ble_mutli_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 029] tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:01 029] tuya_hal_bt_send 20
[2024/8/7 9:00:01 029] 03 30 a9 8c ee f9 e6 6b 58 58 af 5f a0 ce 00 3a 8a d8 17 0f 
[2024/8/7 9:00:01 029] [01-01 18:12:33 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:01 045] 3 30 a9 8c ee f9 e6 6b 58 58 af 5f a0 ce 0 3a 8a d8 17 f 
[2024/8/7 9:00:01 045] XmBleSendBuf 20: 03 30 a9 8c ee f9 e6 6b 58 58 af 5f a0 ce 00 3a 8a d8 17 0f
[2024/8/7 9:00:01 061] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:01 061] ble_slave_gap_event->type=13
[2024/8/7 9:00:01 061] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:01 061] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:01 078] [01-01 18:12:33 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:01 078] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:01 093] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:01 093] [01-01 18:12:33 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:01 109] tuya_hal_bt_send 20
[2024/8/7 9:00:01 109] 04 58 5a 02 47 ef 6f 13 5f 0f 8e b2 24 ea a2 af 00 cb 93 d6 
[2024/8/7 9:00:01 109] [01-01 18:12:33 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:01 125] 4 58 5a 2 47 ef 6f 13 5f f 8e b2 24 ea a2 af 0 cb 93 d6 
[2024/8/7 9:00:01 125] XmBleSendBuf 20: 04 58 5a 02 47 ef 6f 13 5f 0f 8e b2 24 ea a2 af 00 cb 93 d6
[2024/8/7 9:00:01 125] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:01 125] ble_slave_gap_event->type=13
[2024/8/7 9:00:01 141] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:01 141] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:01 141] [01-01 18:12:33 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:01 157] [01-01 18:12:33 TUYA D][tuya_ble_mutl[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 157] i_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:01 157] tuya_hal_bt_send 20
[2024/8/7 9:00:01 173] 05 af 13 1d 81 56 d7 0d 1a 26 43 72 ee b2 63 36 ca 50 20 bc 
[2024/8/7 9:00:01 173] [01-01 18:12:33 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:01 173] 5 af 13 1d 81 56 d7 d 1a 26 43 72 ee b2 63 36 ca 50 20 bc 
[2024/8/7 9:00:01 189] XmBleSendBuf 20: 05 af 13 1d 81 56 d7 0d 1a 26 43 72 ee b2 63 36 ca 50 20 bc
[2024/8/7 9:00:01 189] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:01 189] ble_slave_gap_event->type=13
[2024/8/7 9:00:01 205] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:01 205] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:01 205] [01-01 18:12:33 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:01 221] [01-01 18:12:33 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:18
[2024/8/7 9:00:01 221] tuya_hal_bt_send 19
[2024/8/7 9:00:01 221] 06 cb 4d 57 ba c1 57 db f9 92 0a e8 e7 46 7d b6 93 db 18 
[2024/8/7 9:00:01 237] [01-01 18:12:33 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:01 237] 6 cb 4d 57 ba c1 57 db f9 92 a e8 e7 46 7d b6 93 db 18 
[2024/8/7 9:00:01 237] XmBleSendBuf 19: 06 cb 4d 57 ba c1 57 db f9 92 0a e8 e7 46 7d b6 93 db 18
[2024/8/7 9:00:01 253] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:01 253] ble_slave_gap_event->type=13
[2024/8/7 9:00:01 253] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:01 253] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:01 269] [01-01 18:12:33 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:01 269] set basic_indicator_onoff:0 
[2024/8/7 9:00:01 285] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:01 285] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:01 301] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_Device[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 301] Online ... 
[2024/8/7 9:00:01 301] [01-01 18:12:33 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:129, send_ret:0x0
[2024/8/7 9:00:01 317] [01-01 18:12:33 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:0
[2024/8/7 9:00:01 317] set basic_indicator_onoff:1 
[2024/8/7 9:00:01 334] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:01 335] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:01 352] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:01 352] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:01 352] Len=20 step 0
[2024/8/7 9:00:01 366] att=0x0 0x51 0x20 0x2 0x97 0xf1 0x4c 0x2f 0x37 0x[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 366] eb 0x4b 0x2 0x8f 0x92 0x[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 366] a0 0x94 0x77 0x61 0xb4 0x9d 
[2024/8/7 9:00:01 366]  RCVS len:20
[2024/8/7 9:00:01 381] set basic_indicator_onoff:0 
[2024/8/7 9:00:01 382] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:01 397] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:01 397] XmBleReadBuf 20:
[2024/8/7 9:00:01 398] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:01 398] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:01 413] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:01 413] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:01 414] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:01 429] [01-01 18:12:34 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:01 429] [01-01 18:12:34 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:01 445] [01-01 18:12:34 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:01 445] bt_rev_raw 20
[2024/8/7 9:00:01 445] 00 51 20 02 97 f1 4c 2f 37 eb 4b 02 8f 92 a0 94 77 61 b4 9d 
[2024/8/7 9:00:01 461] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:00:01 461] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:01 477] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:01 477] [01-01 18:12:34 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:01 493] [01-01 18:12:34 TUYA D][simplek[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 493] v.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:01 493] [01-01 18:12:34 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:01 509] [01-01 18:12:34 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:01 509] [01-01 18:12:34 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:01 509] [01-01 18:12:34 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:01 525] [01-01 18:12:34 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:01 525] [01-01 18:12:34 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:01 525] [01-01 18:12:34 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:01 541] [01-01 18:12:34 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:01 542] [01-01 18:12:34 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:01 557] [01-01 18:12:34 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:01 558] [01-01 18:12:34 TUYA D][iot_httpc.c:1410] http_iot_dns_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 558] get_cloud_url start
[2024/8/7 9:00:01 573] [01-01 18:12:34 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:01 589] [01-01 18:12:34 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:01 605] [01-01 18:12:34 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:01 605] [01-01 18:12:34 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:01 621] [01-01 18:12:34 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:01 621] gethostbyname_r error: Unknown host
[2024/8/7 9:00:01 621] [01-01 18:12:34 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:01 637] [01-01 18:12:34 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:01 637] [01-01 18:12:34 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:01 653] [01-01 18:12:34 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:01 653] [01-01 18:12:34 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:01 669] [01-01 18:12:34 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:01 669] [01-01 18:12:34 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:01 669] [01-01 18:12:34 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:01 685] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:01 685] Len=20 step 0
[2024/8/7 9:00:01 685] att=0x1 0xf9 0x34 0xb2 0x62 0x9f 0x4f 0x1c 0x31 0xe 0xff 0xf1 0x36 0x7a 0xb3 0x56 0x7f 0xef 0x49 0xc0 
[2024/8/7 9:00:01 685]  RCVS len:20
[2024/8/7 9:00:01 701] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:01 701] set basic_indicator_onoff:1 
[2024/8/7 9:00:01 717] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:01 717] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:01 733] XmBleReadBuf 20:
[2024/8/7 9:00:01 734] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:01 734] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:01 734] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:01 749] --- tracepoint bt_ext_porting.c,t[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 749] y_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:01 765] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:01 765] [01-01 18:12:34 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:01 765] [01-01 18:12:34 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:01 781] [01-01 18:12:34 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:01 781] bt_rev_raw 20
[2024/8/7 9:00:01 781] 01 f9 34 b2 62 9f 4f 1c 31 0e ff f1 36 7a b3 56 7f ef 49 c0 
[2024/8/7 9:00:01 797] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:00:01 797] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:01 813] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offs[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 813] et is ....:28 ---
[2024/8/7 9:00:01 813] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:01 829] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:01 829] Len=20 step 0
[2024/8/7 9:00:01 829] att=0x2 0x4d 0x5f 0x9a 0x9d 0x4d 0x13 0x6f 0xa9 0xef 0x27 0x5d 0xf7 0x37 0x2d 0x0 0xe2 0x7 0xa4 0x2a 
[2024/8/7 9:00:01 845]  RCVS len:20
[2024/8/7 9:00:01 845] XmBleReadBuf 20:
[2024/8/7 9:00:01 845] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:01 845] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:01 861] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:01 861] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:01 861] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:01 877] [01-01 18:12:34 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:01 877] [01-01 18:12:34 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:01 941] [01-01 18:12:34 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:01 941] bt_rev_raw 20
[2024/8/7 9:00:01 959] 02 4d 5f 9a 9d 4d 13 6f a9 ef 27 5d f7 37 2d 00 e2 07 a4 2a 
[2024/8/7 9:00:01 959] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:137] recive sub_p[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:01 976] kg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:00:01 976] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:01 990] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:01 990] set basic_indicator_onoff:0 
[2024/8/7 9:00:01 990] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:02 006] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:02 006] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:02 006] Len=20 step 0
[2024/8/7 9:00:02 022] att=0x3 0x5b 0x36 0x7e 0x6d 0x6a 0x74 0xac 0x9e 0x28 0xf1 0x79 0xf9 0x10 0x54 0x9a 0x92 0x3d 0xa6 0xe 
[2024/8/7 9:00:02 022]  RCVS len:20
[2024/8/7 9:00:02 022] XmBleReadBuf 20:
[2024/8/7 9:00:02 022] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:02 038] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:02 038] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:02 038] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:02 053] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:02 053] [01-01 18:12:34 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:02 069] [01-01 18:12:34 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:02 069] [01-01 18:12:34 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:02 069] bt_rev_raw 20
[2024/8/7 9:00:02 069] 03 5b 36 7e 6d 6a 74 ac 9e 28 f1 79 f9 10 54 9a 92 3d a6 0e 
[2024/8/7 9:00:02 085] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:137][atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:02 085]  recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:00:02 102] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:02 102] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:02 102] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:02 118]  ---
[2024/8/7 9:00:02 119] Len=8 step 0
[2024/8/7 9:00:02 119] att=0x4 0x74 0x5c 0x11 0xef 0x73 0x3e 0x41 
[2024/8/7 9:00:02 119]  RCVS len:8
[2024/8/7 9:00:02 119] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:02 133] set basic_indicator_onoff:1 
[2024/8/7 9:00:02 133] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:02 149] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:02 149] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:02 149] XmBleReadBuf 8:
[2024/8/7 9:00:02 165] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:02 165] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:02 165] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:02 181] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 16 rcount 16 offset 0 ---
[2024/8/7 9:00:02 181] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 16 ---
[2024/8/7 9:00:02 197] [01-01 18:12:34 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x9]
[2024/8/7 9:00:02 197] [01-01 18:12:34 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:02 197] [01-01 18:12:34 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:02 213] bt_rev_raw 8
[2024/8/7 9:00:02 213] 04 74 5c 11 ef 73 3e 41 
[2024/8/7 9:00:02 213] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:5, pack_len:7, total_len:81
[2024/8/7 9:00:02 213] ble rev data 81
[2024/8/7 9:00:02 229] 02 97 f1 4c 2f 37 eb 4b 02 8f 92 a0 94 77 61 b4 9d f9 34 b2 62 9f 4f 1c 31 0e ff f1 36 7a b3 56 7f ef 49 c0 4d 5f 9a 9d 4d 13 6f a9 ef 27 5d f7 37 2d 00 e2 07 a4 2a 5b 36 7e 6d 6a 74 ac 9e 28 
[2024/8/7 9:00:02 245] f1 79 f9 10 54 9a 92 3d a6 0e 74 5c 11 ef 73 3e 41 
[2024/8/7 9:00:02 245] ble decryped data 64
[2024/8/7 9:00:02 261] 00 00 00 02 00 00 00 00 00 01 00 2c 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca 1e 00 00 00 00 0[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:02 261] 0 00 
[2024/8/7 9:00:02 277] [01-01 18:12:34 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:00:02 277] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x1 
[2024/8/7 9:00:02 277] [01-01 18:12:34 TUYA D][tuya_ble_api.c:573] conn monitor timer stopped
[2024/8/7 9:00:02 293] [01-01 18:12:34 TUYA N][tuya_ble_api.c:1464] ble set conn stat:3
[2024/8/7 9:00:02 293] [01-01 18:12:34 TUYA N][tuya_ble_data_handler.c:367] PAIR_REQ ok:0
[2024/8/7 9:00:02 309] [01-01 18:12:34 TUYA N][tuya_ble_data_handler.c:342] ble_time_req start...
[2024/8/7 9:00:02 309] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:348] no need to query time. network stat:1, work stat:0
[2024/8/7 9:00:02 309] [01-01 18:12:34 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:00:02 325] [01-01 18:12:34 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:02 325] [01-01 18:12:34 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:02 341] tuya_hal_bt_send 20
[2024/8/7 9:00:02 341] 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:00:02 341] [01-01 18:12:34 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:02 357] 0 21 31 2 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:00:02 357] XmBleSendBuf 20: 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c
[2024/8/7 9:00:02 357] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:02 357] ble_slave_gap_event->type=13
[2024/8/7 9:00:02 373] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:02 373] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:02 373] [01-01 18:12:34 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:02 389] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:16 ---
[2024/8/7 9:00:02 389] [01-01 18:12:34 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:00:02 405] tuya_hal_bt_send 1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:02 405] 7
[2024/8/7 9:00:02 405] 01 65 f0 28 07 74 3c 73 5c 6e c8 22 80 1d 92 a7 28 
[2024/8/7 9:00:02 405] [01-01 18:12:34 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:02 421] 1 65 f0 28 7 74 3c 73 5c 6e c8 22 80 1d 92 a7 28 
[2024/8/7 9:00:02 421] XmBleSendBuf 17: 01 65 f0 28 07 74 3c 73 5c 6e c8 22 80 1d 92 a7 28
[2024/8/7 9:00:02 421] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:02 437] ble_slave_gap_event->type=13
[2024/8/7 9:00:02 437] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:02 437] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:02 453] [01-01 18:12:34 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:02 453] set basic_indicator_onoff:0 
[2024/8/7 9:00:02 453] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:02 469] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:02 469] [01-01 18:12:34 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:00:02 486] [01-01 18:12:34 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:1
[2024/8/7 9:00:02 486] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:02 486] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:02 501]  ---
[2024/8/7 9:00:02 502] Len=20 step 0
[2024/8/7 9:00:02 502] att=0x0 0x61 0x20 0x2 0xdc 0x86 0x9d 0x96 0x8d 0xdf 0xd5 0x3e 0xb7 0x8f 0xba 0x7a 0x38 0x60 0xbe 0x8f 
[2024/8/7 9:00:02 502]  RCVS len:20
[2024/8/7 9:00:02 502] set basic_indicator_onoff:1 
[2024/8/7 9:00:02 517] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:02 517] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:02 533] XmBleReadBuf 20:
[2024/8/7 9:00:02 533] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:02 533] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:02 533] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:02 549] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:02 549] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:02 565] [01-01 18:12:34 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:02 565] [01-01 18:12:34 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:02 581] [01-01 18:12:34 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:02 581] bt_rev_raw 20
[2024/8/7 9:00:02 581] 00 61 20 [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QR[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:02 598] code once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:02 598] 02 dc 86 9d 96 8d df d5 3e b7 8f ba 7a 38 60 be 8f 
[2024/8/7 9:00:02 614] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:00:02 614] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:02 629] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:02 630] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:02 630] Len=20 step 0
[2024/8/7 9:00:02 645] att=0x1 0x7e 0x8f 0x79 0xd6 0xec 0xba 0x69 0x36 0x78 0xa9 0x6f 0xd9 0xca 0x93 0xbc 0xde 0x53 0x87 0x1 
[2024/8/7 9:00:02 645]  RCVS len:20
[2024/8/7 9:00:02 646] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:02 646] XmBleReadBuf 20:
[2024/8/7 9:00:02 646] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:02 661] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  -[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:02 662] --
[2024/8/7 9:00:02 662] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:02 677] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:02 677] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:02 725] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:02 725] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:02 725] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:02 725] bt_rev_raw 20
[2024/8/7 9:00:02 741] 01 7e 8f 79 d6 ec ba 69 36 78 a9 6f d9 ca 93 bc de 53 87 01 
[2024/8/7 9:00:02 741] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:00:02 757] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:02 757] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:02 757] set basic_indicator_onoff:0 
[2024/8/7 9:00:02 773] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:02 773] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:02 789] [01-01 18:12:35 TUYA D][tuya_ble_api.c:1376] nw stat change:1->1, rpt to app.
[2024/8/7 9:00:02 789] [01-01 18:12:35 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:00:02 805] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:02 805] Len=20 step 0
[2024/8/7 9:00:02 805] att=0x2 0x47 0x67 0xd3 0x5d 0x7b 0x43 0x5f 0x8c 0x33 0x10 0x29 0x9f 0xea 0x77 0x2f 0xf3 0x8f 0xde 0x10 
[2024/8/7 9:00:02 805]  RCVS len:20
[2024/8/7 9:00:02 821] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:02 821] XmBleReadBuf 20:
[2024/8/7 9:00:02 837] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:02 837] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:02 837] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:02 853] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:02 853] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:02 869] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:02 869] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:02 869] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:02 869] bt_rev_raw 20
[2024/8/7 9:00:02 885] 02 47 67 d3 5d 7b 43 5f 8c 33 10 29 9f ea 77 2f f3 8f de 10 
[2024/8/7 9:00:02 885] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:00:02 901] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:02 901] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:02 917] [01-01 18:12:35 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:02 917] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:02 917] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:02 933] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:02 933] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:02 949] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:02 949] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:02 949] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:02 965] [01-01 18:12:35 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:02 965] [01-01 18:12:35 TUYA D][sim[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:00:02 965] plekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:02 981] [01-01 18:12:35 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:02 981] [01-01 18:12:35 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:02 997] [01-01 18:12:35 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:02 997] [01-01 18:12:35 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:03 013] [01-01 18:12:35 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:03 029] [01-01 18:12:35 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:03 029] [01-01 18:12:35 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:03 045] [01-01 18:12:35 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:03 045] gethostbyname_r error: Unknown host
[2024/8/7 9:00:03 045] [01-01 18:12:35 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:03 061] [01-01 18:12:35 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:03 061] [01-01 18:12:35 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:03 077] [01-01 18:12:35 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:03 077] [01-01 18:12:35 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:03 093] [01-01 18:12:35 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:03 093] [01-01 18:12:35 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:03 093] [01-01 18:12:35 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:03 109] set basic_indicator_onoff:1 
[2024/8/7 9:00:03 109] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:03 125] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:03 125] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:03 125] Len=20 step 0
[2024/8/7 9:00:03 141] att=0x3 0xaf 0x34 0xa9 0x1c 0x6b 0x27 0x5e 0x3d 0x9c 0xad 0x6f 0x26 0x2f 0xc7 0xe0 0x9c 0x31 0xe1 0x9c 
[2024/8/7 9:00:03 141]  RCVS len:20
[2024/8/7 9:00:03 141] XmBleReadBuf 20:
[2024/8/7 9:00:03 141] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:03 141] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:03 157] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:03 157] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:03 173] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:03 173] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:03 173] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:03 189] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:03 189] bt_rev_raw 20
[2024/8/7 9:00:03 189] 03 af 34 a9 1c 6b 27 5e 3d 9c ad 6[atbm_log]:[ieee80211_csa_cancel][mon.eth2]:[0][0]
[2024/8/7 9:00:03 205] f 26 2f c7 e0 9c 31 e1 9c 
[2024/8/7 9:00:03 205] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:00:03 221] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:03 221] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:03 221] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:03 221] Len=20 step 0
[2024/8/7 9:00:03 237] att=0x4 0x1c 0xd9 0xe 0xf 0xef 0xa7 0x76 0x56 0xaf 0x3e 0xb9 0x11 0x95 0xa8 0x97 0x0 0x75 0x5 0x14 
[2024/8/7 9:00:03 237]  RCVS len:20
[2024/8/7 9:00:03 237] set basic_indicator_onoff:0 
[2024/8/7 9:00:03 253] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:03 253] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:03 253] XmBleReadBuf 20:
[2024/8/7 9:00:03 269] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:03 269] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:03 269] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:03 286] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:03 286] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:03 301] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:03 302] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:03 302] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:03 317] bt_rev_raw 20
[2024/8/7 9:00:03 317] 04 1c d9 0e 0f ef a7 76 56 af 3e b9 11 95 a8 97 00 75 05 14 
[2024/8/7 9:00:03 318] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:5, pack_len:19, total_len:93
[2024/8/7 9:00:03 333] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:03 334] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:03 349] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:03 349] set basic_indicator_onoff:1 
[2024/8/7 9:00:03 365] [1970-01-01 00:00:31] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:03 365] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:03 366]  ---
[2024/8/7 9:00:03 366] Len=5 step 0
[2024/8/7 9:00:03 366] att=0x5 0x61 0x4e 0x79 0x7 
[2024/8/7 9:00:03 381]  RCVS len:5
[2024/8/7 9:00:03 382] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:03 397] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:03 398] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:03 398] XmBleReadBuf 5:
[2024/8/7 9:00:03 398] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:03 414] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:03 414] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:03 429] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 13 rcount 13 offset 0 ---
[2024/8/7 9:00:03 430] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 13 ---
[2024/8/7 9:00:03 430] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x6]
[2024/8/7 9:00:03 445] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:03 445] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:03 446] bt_rev_raw 5
[2024/8/7 9:00:03 446] 05 61 4e 79 07 
[2024/8/7 9:00:03 461] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:6, pack_len:4, total_len:97
[2024/8/7 9:00:03 461] ble rev data 97
[2024/8/7 9:00:03 477] 02 dc 86 9d 96 8d df d5 3e b7 8f ba 7a 38 60 be 8f 7e 8f 79 d6 ec ba 69 36 78 a9 6f d9 ca 93 bc de 53 87 01 47 67 d3 5d 7b 43 5f 8c 33 10 29 9f ea 77 2f f3 8f de 10 af 34 a9 1c 6b 27 5e 3d 9c 
[2024/8/7 9:00:03 494] ad 6f 26 2f c7 e0 9c 31 e1 9c 1c d9 0e 0f ef a7 76 56 af 3e b9 11 95 a8 97 00 75 05 14 61 4e 79 07 
[2024/8/7 9:00:03 494] ble decryped data 80
[2024/8/7 9:00:03 509] 00 00 00 03 00 00 00 00 00 21 00 41 7b 22 70 77 64 22 3a 22 78 6d 35 31 32 35 32 30 22 2c 22 73 73 69 64 22 3a 22 58 69 61 6f 6d 69 5f 46 31 44 43 22 2c 22 74 6f 6b 65 6e 22 3a 22 41 59 33 73 
[2024/8/7 9:00:03 509] 36 43 34 64 6c 67 31 44 72 76 22 7d 00 dc cd 00 
[2024/8/7 9:00:03 510] [01-01 18:12:35 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:03 525] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x21 
[2024/8/7 9:00:03 525] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:33 Has No def operate
[2024/8/7 9:00:03 541] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:13 ---
[2024/8/7 9:00:03 542] [01-01 18:12:35 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:33
[2024/8/7 9:00:03 557] [01-01 18:12:35 TUYA N][bt_netcfg.c:63] Rev Net Cfg:{"pwd":"xm512520","ssid":"Xiaomi_F1DC","token":"AY3s6C4dlg1Drv"}
[2024/8/7 9:00:03 557] [01-01 18:12:35 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:03 573] [01-01 18:12:35 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x21 encrpyt:2
[2024/8/7 9:00:03 573] bt_ack_uncrypt 1
[2024/8/7 9:00:03 573] 00 
[2024/8/7 9:00:03 573] [01-01 18:12:35 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:03 589] [01-01 18:12:35 TUYA N][bt_netcfg.c:98] cfg ssid:Xiaomi_F1DC, passwd:xm512520, token:AY3s6C4dlg1Drv
[2024/8/7 9:00:03 589] [01-01 18:12:35 TUYA D][tuya_devos_netcfg.c:464] concurrent Netcfg Finish type:0x10004 ssid:Xiaomi_F1DC passwd:xm512520 cur_netcfg_type:0
[2024/8/7 9:00:03 605] [01-01 18:12:35 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:03 605] tuya_hal_bt_send 20
[2024/8/7 9:00:03 605] 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:00:03 621] [01-01 18:12:35 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:03 621] 0 21 32 2 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:00:03 621] XmBleSendBuf 20: 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7
[2024/8/7 9:00:03 637] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:03 637] ble_slave_gap_event->type=13
[2024/8/7 9:00:03 637] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:03 637] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:03 653]  ---
[2024/8/7 9:00:03 654] [01-01 18:12:35 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:03 654] [01-01 18:12:35 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:00:03 669] tuya_hal_bt_send 17
[2024/8/7 9:00:03 669] 01 36 e3 e8 78 41 6f 7e a4 d2 64 6f 01 74 98 ac 6b 
[2024/8/7 9:00:03 669] [01-01 18:12:35 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:03 685] 1 36 e3 e8 78 41 6f 7e a4 d2 64 6f 1 74 98 ac 6b 
[2024/8/7 9:00:03 685] XmBleSendBuf 17: 01 36 e3 e8 78 41 6f 7e a4 d2 64 6f 01 74 98 ac 6b
[2024/8/7 9:00:03 685] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:03 685] ble_slave_gap_event->type=13
[2024/8/7 9:00:03 701] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:03 701] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:03 701] [01-01 18:12:35 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:03 701] set basic_indicator_onoff:0 
[2024/8/7 9:00:03 717] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:03 733] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:03 733] [01-01 18:12:35 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:00:03 749] [01-01 18:12:35 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait
[2024/8/7 9:00:03 749] [01-01 18:12:35 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10002
[2024/8/7 9:00:03 749] [01-01 18:12:35 TUYA D][ap_netcfg.c:950] ap cfg stop:65538
[2024/8/7 9:00:03 765] [01-01 18:12:35 TUYA D][uni_thread.c:310] Del Thrd:udp_ap_v3
[2024/8/7 9:00:03 765] [1970-01-01[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:00:03 781]  00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:03 781] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:03 781] set basic_indicator_onoff:1 
[2024/8/7 9:00:03 797] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:03 797] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:03 813] [01-01 18:12:35 TUYA N][ap_netcfg.c:172] exit ap_net_cfg task
[2024/8/7 9:00:03 813] Received SIGTERM
[2024/8/7 9:00:03 813] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:00:03 813] set basic_indicator_onoff:0 
[2024/8/7 9:00:03 829] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:03 829] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:03 845] [01-01 18:12:36 TUYA D][ap_netcfg.c:553] wf_ap_stop:0
[2024/8/7 9:00:03 845] [01-01 18:12:36 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10100
[2024/8/7 9:00:03 861] [01-01 18:12:36 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10004
[2024/8/7 9:00:03 861] [01-01 18:12:36 TUYA N][tuya_ble_api.c:439] update bound stat:1
[2024/8/7 9:00:03 861] [01-01 18:12:36 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:0
[2024/8/7 9:00:03 877] [01-01 18:12:36 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:00:03 877] [01-01 18:12:36 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:00:03 893] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:03 893] [01-01 18:12:36 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:03 893] [01-01 18:12:36 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:03 909] [01-01 18:12:36 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:03 909] [01-01 18:12:36 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:00:03 925] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:03 925] [01-01 18:12:36 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:03 925] [01-01 18:12:36 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:03 941] [01-01 18:12:36 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:03 941] [01-01 18:12:36 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:00:03 941] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:00:03 957] [01-01 18:12:36 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:03 957] [01-01 18:12:36 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:03 973] [01-01 18:12:36 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:03 973] [01-01 18:12:36 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:00:03 973] [01-01 18:12:36 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:00:03 989] [01-01 18:12:36 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:00:03 989] [01-01 18:12:36 TUYA N][tuya_devos_activate.c:774] already inited
[2024/8/7 9:00:03 989] [01-01 18:12:36 TUYA D][uni_thread.c:268] Thread:udp_ap_v3 Exec Finish. Set to Del Stat
[2024/8/7 9:00:04 005] [01-01 18:12:36 TUYA D][uni_thread.c:125] del list not empty...deleting 0x2009ddc, next 0x1ff88e8
[2024/8/7 9:00:04 005] [01-01 18:12:36 TUYA D][uni_thread.c:132] Final Free Thread:udp_ap_v3, is_self:1
[2024/8/7 9:00:04 021] [01-01 18:12:36 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:00:04 021] [01-01 18:12:36 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:00:04 037] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:04 037] set basic_indicator_onoff:1 
[2024/8/7 9:00:04 037] [19[atbm_log]:[eth2] change to [2]
[2024/8/7 9:00:04 053] 70-01-01 00:00:3[atbm_log]:[eth2] has been disabled
[2024/8/7 9:00:04 053] 1] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 069] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:04 069] curr event:5 
[2024/8/7 9:00:04 069] IPC_APP_Notify_LED_Sound_Status_CB line(491) -------------------------- IPC_CONNECTING_WIFI(5)
[2024/8/7 9:00:04 085] [1970-01-01 00:00:32] tuya_ipc_system_control_demo.c(492) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECTING, 0, 0, 0, 1))
[2024/8/7 9:00:04 101] [1970-01-01 00:00:32] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/RouterConnect_english.pcm]
[2024/8/7 9:00:04 101] [1970-01-01 00:00:32] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:00:04 117] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:00:04 117] set basic_indicator_onoff:0 
[2024/8/7 9:00:04 133] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 133] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:04 149] [01-01 18:12:36 TUYA I][bt_ext_porting.c:618] [TUYA-BTUART]ble_monitor_thread exit
[2024/8/7 9:00:04 149] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:00:04 149] --- tracepoint MainApp.c,ConfigTimer(372): g_WifiConectStatuts 1 ---
[2024/8/7 9:00:04 165] [1970-01-01 00:00:32] MainApp.c(373) <ConfigTimer>: ConfigTimer exit ----
[2024/8/7 9:00:04 165] set basic_indicator_onoff:1 
[2024/8/7 9:00:04 165] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 181] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:04 181] set basic_indicator_onoff:0 
[2024/8/7 9:00:04 197] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 197] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:04 197] set basic_indicator_onoff:1 
[2024/8/7 9:00:04 213] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 213] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:04 229] set basic_indicator_onoff:0 
[2024/8/7 9:00:04 229] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 245] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:04 245] set basic_indicator_onoff:1 
[2024/8/7 9:00:04 245] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 261] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:04 261] set basic_indicator_onoff:0 
[2024/8/7 9:00:04 277] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 277] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:04 277] set basic_indicator_onoff:1 
[2024/8/7 9:00:04 293] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 293] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:04 309] [1970-01-01 00:00:32] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time32916
[2024/8/7 9:00:04 325] [01-01 18:12:37 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:00:04 357] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 ++++++++ 
[2024/8/7 9:00:04 373] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 --------- 
[2024/8/7 9:00:04 373] [atbm_log]:atbm_hw_scan:if_id(0)
[2024/8/7 9:00:04 373] [atbm_log]:atbm_hw_scan:scan, delay suspend
[2024/8/7 9:00:04 389] [atbm_log]:scan start band(0),(14)
[2024/8/7 9:00:04 837] set basic_indicator_onoff:0 
[2024/8/7 9:00:04 853] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 853] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:04 853] set basic_indicator_onoff:1 
[2024/8/7 9:00:04 871] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 871] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:04 885] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:1
[2024/8/7 9:00:04 885] set basic_indicator_onoff:0 
[2024/8/7 9:00:04 901] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 901] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:04 901] set basic_indicator_onoff:1 
[2024/8/7 9:00:04 917] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 917] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:04 933] set basic_indicator_onoff:0 
[2024/8/7 9:00:04 933] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 949] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:04 949] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:04 949] set basic_indicator_onoff:1 
[2024/8/7 9:00:04 965] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:04 965] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:04 981] g_AudioTipsList.size() enable: 0[01-01 18:12:38 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:00:05 477] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:00:05 477] Mode(Product):0
[2024/8/7 9:00:05 477] BpuMode:[Online]
[2024/8/7 9:00:05 477] VpssMode:[Online]
[2024/8/7 9:00:05 477] [0.LimitUp_info]:
[2024/8/7 9:00:05 477] LimitUp:[Disable]
[2024/8/7 9:00:05 477] [2680*0]->[3840*0])
[2024/8/7 9:00:05 493] chn	TotalSize	ActiveSize
[2024/8/7 9:00:05 493] 0	5040*2246	2680*2160
[2024/8/7 9:00:05 493] 0	5040*2246	3840*2160
[2024/8/7 9:00:05 493] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:00:05 493] [1.VICU_info]:
[2024/8/7 9:00:05 493] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:00:05 509] 0	25.0	659	0	0	183	linear	8ddb00
[2024/8/7 9:00:05 509] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:00:05 509] en	op_type	m_chn	now
[2024/8/7 9:00:05 509] 0	1	1	1
[2024/8/7 9:00:05 509] [2.VI_info]:
[2024/8/7 9:00:05 509] chn	TotalSize	ActiveSize
[2024/8/7 9:00:05 509] 0	5040*2246	3848*2166
[2024/8/7 9:00:05 525] 1	   0*   0	   0*   0
[2024/8/7 9:00:05 526] 
[2024/8/7 9:00:05 526] [3.MIPI_info]:
[2024/8/7 9:00:05 526] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:00:05 526] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:00:05 542] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:00:05 542] [4.Cut_info]:
[2024/8/7 9:00:05 542] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:00:05 542] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:00:05 542] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:00:05 542] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:00:05 557] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:00:05 557] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:00:05 557] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:00:05 557] [5.IB(isp buffer info)]:
[2024/8/7 9:00:05 557] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:00:05 573] PoolId  Count  Size
[2024/8/7 9:00:05 573] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:05 573] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:05 589] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:05 589] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:05 605] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:05 605] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:05 605] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:00:05 621] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:00:05 621] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:00:05 621] 0       0         0          0          4       
[2024/8/7 9:00:05 637] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:00:05 637]      --265--            --264--                                               
[2024/8/7 9:00:05 637] Count      Line     Count      Line     
[2024/8/7 9:00:05 653] 493        480      1179       560      
[2024/8/7 9:00:05 653] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:00:05 669] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:00:05 669] 0   3840   2160    H265  0      0        0           298       983033     7        	
[2024/8/7 9:00:05 669] 1   640    360     H265  0      0        0           188       43200      0        	
[2024/8/7 9:00:05 685] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:00:05 685] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:00:05 701] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:00:05 717] 0   Y      298      0       0       15       0        298      298      405       64830         59091    92469    64648    12      
[2024/8/7 9:00:05 733] 1   Y      188      0       6       1        0        188      188      405       2695          1883     63542    3369     7       
[2024/8/7 9:00:05 733] 3   N      0        0       0       1        0        0        0        407       0             0        0        0        0       
[2024/8/7 9:00:05 781] [atbm_log]:hw_priv->scan.status 0
[2024/8/7 9:00:05 797] [atbm_log]:atbm_scan_work:end(0)
[2024/8/7 9:00:05 813] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:00:05 813] [atbm_log]:authen:(a4:a9:30:ce:5e:66),ssid(Xiaomi_F1DC)
[2024/8/7 9:00:05 813] [atbm_log]:authenticate[a4:a9:30:ce:5e:66]:[0][1]
[2024/8/7 9:00:05 829] [atbm_log]:eth2: authenticate with a4:a9:30:ce:5e:66 (try 1) (1)(0)
[2024/8/7 9:00:05 829] [atbm_log]:[STA] Join DTIM: 1, interval: 100
[2024/8/7 9:00:05 845] [atbm_log]:[TX]:authen, delay suspend
[2024/8/7 9:00:05 845] [atbm_log]:eth2: authenticated
[2024/8/7 9:00:05 861] [atbm_log]:work:flush sta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:05 861] [atbm_log]:sta has been insert(0)
[2024/8/7 9:00:05 861] [atbm_log]:wk->assoc.use_he 1 1++
[2024/8/7 9:00:05 877] [atbm_log]:flush sta(0):
[2024/8/7 9:00:05 925] [atbm_log]:eth2: associated
[2024/8/7 9:00:05 925] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:00:05 925] [atbm_log]:eth2:free authen bss --
[2024/8/7 9:00:05 941] [atbm_log]:is_wifi6_ap++
[2024/8/7 9:00:05 941] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:00:05 941] [atbm_log]:eth2  WMM AC=0 acm=0 aifs=2 cWmin=3 cWmax=7 txop=47 uapsd=0
[2024/8/7 9:00:05 957] [atbm_log]:eth2  WMM AC=1 acm=0 aifs=2 cWmin=7 cWmax=15 txop=94 uapsd=0
[2024/8/7 9:00:05 957] [atbm_log]:eth2  WMM AC=2 acm=0 aifs=3 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:00:05 973] [atbm_log]:eth2  WMM AC=3 acm=0 aifs=7 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:00:05 989] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:00:05 989] [atbm_log]:[a4:a9:30:ce:5e:66]:20M channel
[2024/8/7 9:00:05 989] [atbm_log]:atbm_bss_info_changed:chatype(1),channelNumber(3)
[2024/8/7 9:00:06 037] [atbm_log]:BssidColor[34]
[2024/8/7 9:00:06 037] [atbm_log]:[STA] color 34, he_support_flag: 53
[2024/8/7 9:00:06 053] [atbm_log]:==>connect wifi6 AP open AX, set BA WIN short
[2024/8/7 9:00:06 069] [atbm_log]:[eth2] Waiting Txq Ready[1]
[2024/8/7 9:00:06 117] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:00:06 133] [atbm_log]:[eth2]:dtim changed [0]->[1]
[2024/8/7 9:00:06 133] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:00:06 197] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:00:06 197] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:00:06 213] [atbm_log]:send htc qos null
[2024/8/7 9:00:06 213] [atbm_log]:om work(1)
[2024/8/7 9:00:06 453] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:00:06 453] [atbm_log]:send htc qos null
[2024/8/7 9:00:06 453] [atbm_log]:om work(2)
[2024/8/7 9:00:06 469] [atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:00:06 485] [atbm_log]:aggtx stop queue
[2024/8/7 9:00:06 485] [atbm_log]:add to pending(2)(20)
[2024/8/7 9:00:06 485] [atbm_log]:dhcp work(1)
[2024/8/7 9:00:06 533] [atbm_log]:AMPDU[eth2]:action[2],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:06 533] [atbm_log]:activated addBA response timer on tid 0
[2024/8/7 9:00:06 533] [atbm_log]:aggtx wake queue
[2024/8/7 9:00:06 533] [atbm_log]:sta_hdr
[2024/8/7 9:00:06 549] [atbm_log]:switched off addBA timer for tid 0
[2024/8/7 9:00:06 549] [atbm_log]:Aggregation is on for tid 0
[2024/8/7 9:00:06 549] [atbm_log]:AMPDU[eth2]:action[4],tid[0],ssn[0],buff_size[64],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:06 597] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:00:06 597] [atbm_log]:dhcp done
[2024/8/7 9:00:06 597] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[6]
[2024/8/7 9:00:06 613] [atbm_log]:AMPDU[eth2]:action[0],tid[6],ssn[1],buff_size[64],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:06 628] [atbm_log]:Rx A-MPDU request on tid 6 result 0
[2024/8/7 9:00:06 628] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[0]
[2024/8/7 9:00:06 644] [atbm_log]:AMPDU[eth2]:action[0],tid[0],ssn[0],buff_size[64],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:06 645] [atbm_log]:Rx A-MPDU request on tid 0 result 0
[2024/8/7 9:00:06 660] [atbm_log]:dhcp work(1)
[2024/8/7 9:00:06 660] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:00:06 660] [atbm_log]:dhcp doneNOHZ: local_softirq_pending 08
[2024/8/7 9:00:06 692] 
[2024/8/7 9:00:06 708] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:00:06 708] [atbm_log]:send htc qos null
[2024/8/7 9:00:06 709] [atbm_log]:om work(3)
[2024/8/7 9:00:06 725] route: SIOCDELRT: No such process
[2024/8/7 9:00:06 741] [atbm_log]:connecting done for waitting dhcp  
[2024/8/7 9:00:06 805] set basic_indicator_onoff:0 
[2024/8/7 9:00:06 821] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:06 821] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:06 837] set basic_indicator_onoff:1 
[2024/8/7 9:00:06 837] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:06 853] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:06 853] set basic_indicator_onoff:0 
[2024/8/7 9:00:06 853] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:06 869] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:06 869] set basic_indicator_onoff:1 
[2024/8/7 9:00:06 885] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:06 885] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:06 885] set basic_indicator_onoff:0 
[2024/8/7 9:00:06 901] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:06 901] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:06 917] [1970-01-01 00:00:34] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:00:06 917] set basic_indicator_onoff:1 
[2024/8/7 9:00:06 933] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:06 933] [1970-01-01 00:00:34] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:00:06 949] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:00:06 949] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:06 949] s[atbm_log]:QosNUll Htc(807)
[2024/8/7 9:00:06 965] et basic_indicat[atbm_log]:send htc qos null
[2024/8/7 9:00:06 965] or_onoff:0 
[2024/8/7 9:00:06 965] atbm_log]:om work(4)
[2024/8/7 9:00:06 965] 32m[1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:06 981] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:06 981] [1970-01-01 00:00:34] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:00:06 997] set basic_indicator_onoff:1 
[2024/8/7 9:00:06 997] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 013] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:07 013] set basic_indicator_onoff:0 
[2024/8/7 9:00:07 013] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 028] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:07 028] set basic_indicator_onoff:1 
[2024/8/7 9:00:07 045] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 045] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:07 045] set basic_indicator_onoff:0 
[2024/8/7 9:00:07 061] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 061] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:07 077] set basic_indicator_onoff:1 
[2024/8/7 9:00:07 077] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 093] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:07 093] set basic_indicator_onoff:0 
[2024/8/7 9:00:07 093] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 109] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:07 109] set basic_indicator_onoff:1 
[2024/8/7 9:00:07 125] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 125] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:07 125] set basic_indicator_onoff:0 
[2024/8/7 9:00:07 141] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 141] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:07 157] set basic_indicator_onoff:1 
[2024/8/7 9:00:07 158] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 173] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:07 173] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:07 205] set basic_indicator_onoff:[atbm_log]:om done
[2024/8/7 9:00:07 397] 0 
[2024/8/7 9:00:07 413] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 413] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:07 413] set basic_indicator_onoff:1 
[2024/8/7 9:00:07 429] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 444] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[[atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[5]
[2024/8/7 9:00:07 444] 1]
[2024/8/7 9:00:07 444] set[atbm_log]:<WIFI> rx ampdu ++ 
[2024/8/7 9:00:07 460]  basic_indicator[atbm_log]:AMPDU[eth2]:action[0],tid[5],ssn[3],buff_size[64],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:07 460] _onoff:0 
[2024/8/7 9:00:07 460] [1970-0[atbm_log]:napi schedule
[2024/8/7 9:00:07 460] 1-01 00:00:35] tuya_ipc_dp_handl[atbm_log]:Rx A-MPDU request on tid 5 result 0
[2024/8/7 9:00:07 476] er.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 476] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:07 476] set basic_indicator_onoff:1 
[2024/8/7 9:00:07 492] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 492] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:07 508] set basic_indicator_onoff:0 
[2024/8/7 9:00:07 509] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 524] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:07 524] curr event:6 
[2024/8/7 9:00:07 524] IPC_APP_Notify_LED_Sound_Status_CB line(497) -------------------------- IPC_CONNECT_WIFI_SUCCESS(6)
[2024/8/7 9:00:07 540] [1970-01-01 00:00:36] tuya_ipc_system_control_demo.c(498) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECT_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:00:07 556] [01-01 18:12:40 TUYA D][tuya_devos_netlink.c:313] wf connect success!
[2024/8/7 9:00:07 556] [01-01 18:12:40 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:00:07 556] dev id key: 16
[2024/8/7 9:00:07 556] c0 b9 30 cc 91 82 20 e0 27 d3 45 b3 ab 3c 27 bf 
[2024/8/7 9:00:07 572] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:00:07 572] [01-01 18:12:40 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:00:07 588] 2 1 6 3 2 1 a2 14 16 1 a2 0 1c 6a 97 74 ce 42 f4 54 8c 72 2e 92 d 9f a1 db 
[2024/8/7 9:00:07 588] [01-01 18:12:40 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:00:07 589] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 30 7b 27 8c c6 8b 14 13 8e 36 f6 75 73 7d 4b 
[2024/8/7 9:00:07 604] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:00:07 604] [01-01 18:12:40 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:00:07 620] [01-01 18:12:40 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:00:07 620] [01-01 18:12:40 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:00:07 636] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:00:07 636] [01-01 18:12:40 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:00:07 636] [01-01 18:12:40 TUYA E][mqtt_client.c:807] hand null.
[2024/8/7 9:00:07 652] set basic_indicator_onoff:1 
[2024/8/7 9:00:07 652] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 668] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:07 668] [01-01 18:12:40 TUYA D][tuya_iot_wired_wifi_api.c:584] wired wifi default stat:1,change:1
[2024/8/7 9:00:07 684] [01-01 18:12:40 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[2024/8/7 9:00:07 684] [01-01 18:12:40 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[2024/8/7 9:00:07 700] [01-01 18:12:40 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:00:07 701] [01-01 18:12:40 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:07 701] [01-01 18:12:40 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:07 717] [01-01 18:12:40 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:07 717] [01-01 18:12:40 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:07 733] [01-01 18:12:40 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:07 733] [01-01 18:12:40 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:07 733] [01-01 18:12:40 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:07 748] [01-01 18:12:40 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:07 748] [01-01 18:12:40 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:07 749] [01-01 18:12:40 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:07 765] [01-01 18:12:40 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:07 765] [01-01 18:12:40 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:07 781] [01-01 18:12:40 TUYA D][iot_httpc.c:1435] sign_buffer:env=1Drv&region=AY&ts=25&uuid=uuidcaab27b0a838d239
[2024/8/7 9:00:07 781] [01-01 18:12:40 TUYA D][iot_httpc.c:1443] sign_base64_encode:rcyhQdjWUH1XOKfATrDqeKVJjnZD1WYkGUDujM/zY/o=
[2024/8/7 9:00:07 797] [01-01 18:12:40 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:00:07 829] [01-01 18:12:40 TUYA D][iot_httpc.c:1514] http_dns send: {"region":"AY","env":"1Drv","uuid":"uuidcaab27b0a838d239","ts":25,"sign":"rcyhQdjWUH1XOKfATrDqeKVJjnZD1WYkGUDujM/zY/o=","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:07 829] [01-01 18:12:40 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v2/url_config
[2024/8/7 9:00:07 844] [01-01 18:12:40 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:07 844] [01-01 18:12:40 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:00:07 860] [01-01 18:12:40 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:00:07 860] [01-01 18:12:40 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:00:07 876] [1970-01-01 00:00:36] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/ServerConnect_english.pcm]
[2024/8/7 9:00:07 876] [1970-01-01 00:00:36] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:00:07 892] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:00:07 892] [01-01 18:12:40 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:00:07 908] [01-01 18:12:40 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:07 908] [01-01 18:12:40 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:07 924] [01-01 18:12:40 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:07 924] [01-01 18:12:40 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:00:07 924] set basic_indicator_onoff:0 
[2024/8/7 9:00:07 940] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 940] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:07 956] [01-01 18:12:40 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:07 956] set basic_indicator_onoff:1 
[2024/8/7 9:00:07 972] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 972] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:07 972] set basic_indicator_onoff:0 
[2024/8/7 9:00:07 988] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:07 988] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:08 004] set basic_indicator_onoff:1 
[2024/8/7 9:00:08 004] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:08 020] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:08 020] [01-01 18:12:41 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:00:08 020] set basic_indicator_onoff:0 
[2024/8/7 9:00:08 036] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:08 052] [01-01 18:12:41 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:08 052] [1970-01-01 00:00:36] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time36915
[2024/8/7 9:00:08 068] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:08 069] [01-01 18:12:41 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:00:08 085] [01-01 18:12:41 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:08 086] [01-01 18:12:41 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:08 086] [01-01 18:12:41 TUYA D][iot_httpc.c:1578] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216]
[2024/8/7 9:00:08 100] [01-01 18:12:41 TUYA D][iot_httpc.c:1579] mqttUrl:[m2.tuyacn.com:1883][42.192.30.165]
[2024/8/7 9:00:08 100] [01-01 18:12:41 TUYA D][iot_httpc.c:1602] httpsSelfUrl:[https://a2.tuyacn.com/d.json][42.192.31.36]
[2024/8/7 9:00:08 117] [01-01 18:12:41 TUYA D][iot_httpc.c:1603] mqttsSelfUrl:[m2.tuyacn.com:8883][42.192.30.165]
[2024/8/7 9:00:08 117] [01-01 18:12:41 TUYA D][iot_httpc.c:1670] ghostUrl:[baal.tuyacn.com:443][42.192.35.108]
[2024/8/7 9:00:08 132] [01-01 18:12:41 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:08 132] [01-01 18:12:41 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:08 148] [01-01 18:12:41 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:08 148] [01-01 18:12:41 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:08 149] [01-01 18:12:41 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:08 165] [01-01 18:12:41 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:08 165] [01-01 18:12:41 TUYA D][iot_httpc.c:1684] tls_ca_name:tls_ca0
[2024/8/7 9:00:08 165] [01-01 18:12:41 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:00:08 181] [01-01 18:12:41 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:08 181] [01-01 18:12:41 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:08 197] [01-01 18:12:41 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:08 197] [01-01 18:12:41 TUYA D][simplekv.c:374] write key:tls_ca0 And Value Len:2688
[2024/8/7 9:00:08 197] [01-01 18:12:41 TUYA D][simplekv.c:457] new space 8 startpos:30428 size:2756
[2024/8/7 9:00:08 213] [01-01 18:12:41 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:08 213] [01-01 18:12:41 TUYA D][simplekv.c:203] update crc 1395591596
[2024/8/7 9:00:08 228] [01-01 18:12:41 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:08 229] [01-01 18:12:41 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:08 229] [01-01 18:12:41 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:08 244] [01-01 18:12:41 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:08 244] [01-01 18:12:41 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:08 245] [01-01 18:12:41 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:08 261] [01-01 18:12:41 TUYA D][simplekv.c:374] write key:tls_ca_cnt And Value Len:16[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:08 277] [01-01 18:12:41 TUYA D][simplekv.c:457] new space 9 startpos:33184 size:84
[2024/8/7 9:00:08 277] [01-01 18:12:41 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:08 277] set basic_indicator_onoff:1 
[2024/8/7 9:00:08 293] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:08 293] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:08 309] [01-01 18:12:41 TUYA D][simplekv.c:203] update crc 213719394
[2024/8/7 9:00:08 309] [01-01 18:12:41 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:08 309] [01-01 18:12:41 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:08 325] [01-01 18:12:41 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:00:08 325] [01-01 18:12:41 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216]
[2024/8/7 9:00:08 341] [01-01 18:12:41 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36]
[2024/8/7 9:00:08 341] [01-01 18:12:41 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165]
[2024/8/7 9:00:08 357] [01-01 18:12:41 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[42.192.30.165]
[2024/8/7 9:00:08 357] [01-01 18:12:41 TUYA D][uni_netw[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:08 373] ork.c:268] cache[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:08 373]  dns [baal.tuyacn.com:443]<->[42.192.35.108]
[2024/8/7 9:00:08 373] [01-01 18:12:41 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:08 389] [01-01 18:12:41 TUYA D][simplekv.c:1251] find key:9 tls_ca_cnt
[2024/8/7 9:00:08 389] [01-01 18:12:41 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[2024/8/7 9:00:08 389] [01-01 18:12:41 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[2024/8/7 9:00:08 405] [01-01 18:12:41 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:00:08 405] [01-01 18:12:41 TUYA D][simplekv.c:1251] find key:8 tls_ca0
[2024/8/7 9:00:08 421] [01-01 18:12:41 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688
[2024/8/7 9:00:08 421] [01-01 18:12:41 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
[2024/8/7 9:00:08 421] [01-01 18:12:41 TUYA D][iot_httpc.c:1696] end
[2024/8/7 9:00:08 437] [01-01 18:12:41 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:00:08 437] [01-01 18:12:41 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:08 437] [01-01 18:12:41 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:00:08 453] bt_ack_uncrypt 2
[2024/8/7 9:00:08 453] 00 00 
[2024/8/7 9:00:08 453] [01-01 18:12:41 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:08 469] [01-01 18:12:41 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:08 469] tuya_hal_bt_send 20
[2024/8/7 9:00:08 469] 00 21 33 02 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41 
[2024/8/7 9:00:08 469] [01-01 18:12[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:08 485] :41 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:08 485] 0 21 33 2 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41 
[2024/8/7 9:00:08 485] XmBleSendBuf 20: 00 21 33 02 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41
[2024/8/7 9:00:08 500] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:08 500] ble_slave_gap_event->type=13
[2024/8/7 9:00:08 500] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:08 500] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:08 516] [01-01 18:12:41 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:08 516] [01-01 18:12:41 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:00:08 532] tuya_hal_bt_send 17
[2024/8/7 9:00:08 532] 01 79 34 62 e6 e0 30 7e 39 ae 4f b3 c6 85 92 e5 15 
[2024/8/7 9:00:08 532] [01-01 18:12:41 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:08 532] 1 79 34 62 e6 e0 30 7e 39 ae 4f b3 c6 85 92 e5 15 
[2024/8/7 9:00:08 549] XmBleSendBuf 17: 01 79 34 62 e6 e0 30 7e 39 ae 4f b3 c6 85 92 e5 15
[2024/8/7 9:00:08 549] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:08 549] ble_slave_gap_event->type=13
[2024/8/7 9:00:08 565] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:08 565] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:08 565] [01-01 18:12:41 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:08 580] [01-01 18:12:41 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:00:08 581] set basic_indicator_onoff:0 
[2024/8/7 9:00:08 596] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:08 596] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:08 596] atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:08 597] 9m
[2024/8/7 9:00:08 612] [01-01 18:12:41 TUYA D][tuya_devos_activate.c:356] dev_nw_cfg_active_stage:5
[2024/8/7 9:00:08 612] [01-01 18:12:41 TUYA D][iot_httpc.c:3195] modules:(null)
[2024/8/7 9:00:08 628] [01-01 18:12:41 TUYA D][simplekv.c:1211] read key:last_reset_info isFuzzy:0 skipCnt:0
[2024/8/7 9:00:08 628] [01-01 18:12:41 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:08 628] [01-01 18:12:41 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:08 644] [01-01 18:12:41 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:08 660] [01-01 18:12:41 TUYA D][iot_httpc.c:3198] options:{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}
[2024/8/7 9:00:08 708] [01-01 18:12:41 TUYA D][iot_httpc.c:1161] Post Data: {"token":"3s6C4dlg","softVer":"1.5.431","productKey":"fvijo8jvloagv1gm","protocolVer":"2.2","baselineVer":"40.00","hid":"90314ba51650","skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}}","devAttribute":67,"cadVer":"1.0.4","cdVer":"1.0.0","options":"{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}","t":26}
[2024/8/7 9:00:08 725] [01-01 18:12:41 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.active&et=1&t=26&uuid=uuidcaab27b0a838d239&v=4.4&sign=23532fa4ed88bf50803038c2cd369e5c
[2024/8/7 9:00:08 741] [01-01 18:12:41 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:08 741] [01-01 18:12:41 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:08 757] [01-01 18:12:41 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:08 757] [01-01 18:12:41 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:08 773] [01-01 18:12:41 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:08 773] [01-01 18:12:41 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:08 789] [01-01 18:12:41 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:08 789] [01-01 18:12:41 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:08 789] [01-01 18:12:41 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:08 805] [01-01 18:12:41 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:08 805] [01-01 18:12:41 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:08 820] set basic_indicator_onoff:1 
[2024/8/7 9:00:08 821] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:08 837] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:08 837] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:08 837] Len=20 step 0
[2024/8/7 9:00:08 853] att=0x0 0x21 0x20 0x2 0xe7 0x3d 0x4b 0xf4 0x19 0xad 0x7a 0xf9 0x9 0xd7 0x87 0xf8 0x64 0x67 0xb6 0xb2 
[2024/8/7 9:00:08 853]  RCVS len:20
[2024/8/7 9:00:08 853] XmBleReadBuf 20:
[2024/8/7 9:00:08 853] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:08 853] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:08 869] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:08 869] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:08 869] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:08 885] [01-01 18:12:41 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:08 885] [01-01 18:12:41 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:08 901] [01-01 18:12:41 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:08 901] bt_rev_raw 20
[2024/8/7 9:00:08 901] 00 21 20 02 e7 3d 4b f4 19 ad 7a f9 09 d7 87 f8 64 67 b6 b2 
[2024/8/7 9:00:08 917] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:00:08 917] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:08 932] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:08 933] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:08 933] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:08 949] Len=17 step 0
[2024/8/7 9:00:08 949] att=0x1 0xf6 0xed 0xa9 0x84 0xb7 0xa3 0x1b 0x35 0x3b 0xbf 0x87 0xfd 0xde 0x2a 0xea 0x34 
[2024/8/7 9:00:08 949]  RCVS len:17
[2024/8/7 9:00:08 949] set basic_indicator_onoff:0 
[2024/8/7 9:00:08 964] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:08 965] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:08 965] XmBleReadBuf 17:
[2024/8/7 9:00:08 980] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:08 980] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:08 980] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:08 996] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:00:08 996] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:00:09 012] [01-01 18:12:41 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:00:09 012] [01-01 18:12:41 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:09 012] [01-01 18:12:41 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:09 028] bt_rev_raw 17
[2024/8/7 9:00:09 029] 01 f6 ed a9 84 b7 a3 1b 35 3b bf 87 fd de 2a ea 34 
[2024/8/7 9:00:09 029] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:00:09 029] ble rev data 33
[2024/8/7 9:00:09 044] 02 e7 3d 4b f4 19 ad 7a f9 09 d7 87 f8 64 67 b6 b2 f6 ed a9 84 b7 a3 1b 35 3b bf 87 fd de 2a ea 34 
[2024/8/7 9:00:09 045] ble decryped data 16
[2024/8/7 9:00:09 045] 00 00 00 04 00 00 00 00 00 22 00 01 00 d6 49 00 
[2024/8/7 9:00:09 061] [01-01 18:12:41 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:09 061] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:00:09 076] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:00:09 077] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:00:09 093] [1970-01-01 00:00:37] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:09 093] set basic_indicator_onoff:1 
[2024/8/7 9:00:09 093] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:09 109] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:09 109] [1970-01-01 00:00:37] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:00:09 133] [1970-01-01 00:00:37] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:00:09 134] set basic_indicator_onoff:0 
[2024/8/7 9:00:09 141] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:09 141] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:09 157] [01-01 18:12:41 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:09 173] [01-01 18:12:41 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:09 173] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=3.000 ms
[2024/8/7 9:00:09 189] [1970-01-01 00:00:37] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:00:09 189] set basic_indicator_onoff:1 
[2024/8/7 9:00:09 189] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:09 205] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:09 205] set basic_indicator_onoff:0 
[2024/8/7 9:00:09 221] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:09 221] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:09 237] [01-01 18:12:42 TUYA D][app_agent.c:706] udp ip: 192.168.31.144
[2024/8/7 9:00:09 237] set basic_indicator_onoff:1 
[2024/8/7 9:00:09 237] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:09 253] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:09 253] set basic_indicator_onoff:0 
[2024/8/7 9:00:09 269] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:09 269] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:09 365] [01-01 18:12:42 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"capability":1,"devId":"6c98df4eddddc79e62pkva","dstIntervals":[],"localKey":"l(I{n)S!B@HD$mb!","resetFactory":false,"schema":"[{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":103,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":104,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"range\":[\"0\",\"1\",\"2\"],\"type\":\"enum\"},\"id\":106,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":109,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"min\":1,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":110,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":111,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":113,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\
[2024/8/7 9:00:09 365] [08-07 19:12:26 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:09 365] [08-07 19:12:26 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:09 381] [08-07 19:12:26 TUYA D][tuya_devos_activate.c:210] cloud_reset:0 local_reset:1
[2024/8/7 9:00:09 381] [08-07 19:12:26 TUYA D][tuya_devos_activate.c:256] __tmm_gw_actv_work: reset stride flag.
[2024/8/7 9:00:09 397] [08-07 19:12:26 TUYA D][tuya_devos_entry.c:1477] write stride to flash:0
[2024/8/7 9:00:09 397] [08-07 19:12:26 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 9:00:09 397] [08-07 19:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:09 413] [08-07 19:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:09 413] [08-07 19:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:09 429] [08-07 19:12:26 TUYA D][simplekv.c:374] write key:is_stride And Value Len:16
[2024/8/7 9:00:09 429] [08-07 19:12:26 TUYA D][simplekv.c:457] new space 10 startpos:33268 size:84
[2024/8/7 9:00:09 429] [08-07 19:12:26 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:09 445] [08-07 19:12:26 TUYA D][simplekv.c:203] update crc 1143988772
[2024/8/7 9:00:09 445] [08-07 19:12:26 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:09 461] [08-07 19:12:26 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:09 461] [08-07 19:12:26 TUYA D][simplekv.c:1211[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:09 461] ] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:00:09 477] [08-07 19:12:26 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 9:00:09 477] [08-07 19:12:26 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 9:00:09 477] [08-07 19:12:26 TUYA D][simplekv.c:374] write key:gw_di And Value Len:416
[2024/8/7 9:00:09 493] [08-07 19:12:26 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416
[2024/8/7 9:00:09 493] [08-07 19:12:26 TUYA D][simplekv.c:430] find 2 available space
[2024/8/7 9:00:09 509] [08-07 19:12:26 TUYA D][simplekv.c:474] reuse available space 29188
[2024/8/7 9:00:09 509] [08-07 19:12:26 TUYA D][simplekv.c:203] update crc 3307541868
[2024/8/7 9:00:09 509] [08-07 19:12:26 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:09 525] [08-07 19:12:26 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:09 525] [08-07 19:12:26 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:00:09 525] [08-07 19:12:26 TUYA D][simplekv.c:1211] read key:flvlrc isFuzzy:0 skipCnt:0
[2024/8/7 9:00:09 541] [08-07 19:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:09 541] [08-07 19:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:09 541] [08-07 19:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:09 557] [08-07 19:12:26 TUYA D][simplekv.c:374] write key:flvlrc And Value Len:2928
[2024/8/7 9:00:09 573] [08-07 19:12:26 TUYA D][simplekv.c:457] new space 11 st[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:09 574] artpos:33352 size:2996
[2024/8/7 9:00:09 574] [08-07 19:12:26 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:09 574] [08-07 19:12:26 TUYA D][simplekv.c:203] update crc 503454677
[2024/8/7 9:00:09 589] [08-07 19:12:26 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:09 589] [08-07 19:12:26 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:09 589] [08-07 19:12:26 TUYA D][ws_db_gw.c:670] schema write success
[2024/8/7 9:00:09 605] set basic_indicator_onoff:1 
[2024/8/7 9:00:09 605] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:09 621] [1970-01[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:09 621] -01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:09 621] [08-07 19:12:26 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success 
[2024/8/7 9:00:09 637] [08-07 19:12:26 TUYA D][tuya_ipc_sdk_init.c:183] ON post active:0x200d868
[2024/8/7 9:00:09 637] [08-07 19:12:26 TUYA D][tuya_ipc_sdk_init.c:172] skillResult p2pId:[]
[2024/8/7 9:00:09 653] [08-07 19:12:26 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:00:09 653] [08-07 19:12:26 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 9:00:09 653] [08-07 19:12:26 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[2024/8/7 9:00:09 669] [08-07 19:12:26 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:544
[2024/8/7 9:00:09 669] [08-07 19:12:26 TUYA D][simplekv.c:394] 4 key same BUT size old 436 < new 544 need find new hd
[2024/8/7 9:00:09 685] [08-07 19:12:26 TUYA D][simplekv.[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:09 685] c:457] new space 12 startpos:36348 size:612
[2024/8/7 9:00:09 700] [08-07 19:12:26 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:09 701] [08-07 19:12:26 TUYA D][simplekv.c:203] update crc 1734318936
[2024/8/7 9:00:09 701] [08-07 19:12:26 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:09 716] [08-07 19:12:26 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:09 716] [08-07 19:12:26 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:00:09 732] [08-07 19:12:26 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":9,"ssid":"WGlhb21pX0YxREM=","passwd":"eG01MTI1MjA=","md":0,"random":0,"wfb64":1,"stat":2,"token":"3s6C4dlg","region":"AY","reg_key":"1Drv","dns_prio":0 }
[2024/8/7 9:00:09 732] [08-07 19:12:26 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:00:09 748] [08-07 19:12:26 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:00:09 748] [08-07 19:12:26 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:00:09 764] [08-07 19:12:26 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:176
[2024/8/7 9:00:09 764] [08-07 19:12:26 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 176
[2024/8/7 9:00:09 764] [08-07 19:12:26 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:00:09 780] [08-07 19:12:26 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:00:09 780] [08-07 19:12:26 TUYA D][simplekv.c:203] update crc 905977580
[2024/8/7 9:00:09 796] [08-07 19:12:26 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:09 796] [08-07 19:12:26 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:09 796] [08-07 19:12:26 TUYA D][ws_db[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:09 813] _gw.c:280] gw_wsm write success
[2024/8/7 9:00:09 813] __IPC_APP_Get_Net_Status_cb line(188) -------------------------- stat(1)==STAT_UNPROVISION 
[2024/8/7 9:00:09 829] [08-07 19:12:26 TUYA D][wifi_netcfg_frame_transporter.c:472] ----destroy Transporter,session:0x1ffa060
[2024/8/7 9:00:09 829] [08-07 19:12:26 TUYA D][tuya_devos_entry.c:560] dev_nw_cfg_active_stage:6
[2024/8/7 9:00:09 846] __IPC_APP_Get_Net_Status_cb line(198) -------------------------- stat(3)==STAT_AP_STA_DISC 
[2024/8/7 9:00:09 846] [08-07 19:12:26 TUYA N][tuya_bt_sdk.c:171] ty bt upd localkey
[2024/8/7 9:00:09 846] [08-07 19:12:26 TUYA N][tuya_ble_api.c:425] upd login key len:6
[2024/8/7 9:00:09 862] [08-07 19:12:26 TUYA I][mqc_app.c:387] mqc app start ...
[2024/8/7 9:00:09 862] [08-07 19:12:26 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883
[2024/8/7 9:00:09 862] [08-07 19:12:26 TUYA D][mqc_app.c:473] TLS disable
[2024/8/7 9:00:09 878] [08-07 19:12:26 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:00:09 895] [08-07 19:12:26 TUYA D][mqtt_client.c:321] subcribe_topic:smart/device/in/6c98df4eddddc79e62pkva, client_id:6c98df4eddddc79e62pkva, user_name:6c98df4eddddc79e62pkva, passwd:2d23cc7103203b11
[2024/8/7 9:00:09 895] [08-07 19:12:26 TUYA D][mqtt_client.c:352] domain<0> m2.tuyacn.com:8883 HAVE PORT
[2024/8/7 9:00:09 895] [08-07 19:12:26 TUYA D][mqtt_client.c:355] PARSE m2.tuyacn.com:8883
[2024/8/7 9:00:09 910] [08-07 19:12:26 TUYA D][mqtt_client.c:383] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT
[2024/8/7 9:00:09 910] [08-07 19:12:26 TUYA D][mqtt_client.c:386] PARSE m2.tuyacn.com:1883
[2024/8/7 9:00:09 926] [08-07 19:12:26 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6c98df4eddddc79e62pkva
[2024/8/7 9:00:09 926] [08-07 19:12:26 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6c98df4eddddc79e62pkva
[2024/8/7 9:00:09 942] [08-07 19:12:26 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:25600,priority:4
[2024/8/7 9:00:09 942] [08-07 19:12:26 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:00:09 958] [08-07 19:12:26 TUYA N][bt_dp.c:228] bt rpt conn stat:9
[2024/8/7 9:00:09 958] [08-07 19:12:26 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:09 974] [08-07 19:12:26 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:00:09 974] bt_ack_uncrypt 2
[2024/8/7 9:00:09 974] 00 09 
[2024/8/7 9:00:09 974] [08-07 19:12:26 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:09 974] [08-07 19:12:26 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[2024/8/7 9:00:09 989] [08-07 19:12:26 TUYA D][tuya_ble_api.c:1005] start to get mesh
[2024/8/7 9:00:09 989] [08-07 19:12:26 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[2024/8/7 9:00:09 989] [08-07 19:12:26 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[2024/8/7 9:00:10 007] [08-07 19:12:26 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[2024/8/7 9:00:10 007] [08-07 19:12:26 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:00:10 022] [08-07 19:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:10 022] [08-07 19:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:10 022] [08-07 19:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:10 038] [08-07 19:12:26 TUYA D][tuya_svc_timer_task.c:146] no timer
[2024/8/7 9:00:10 038] [08-07 19:12:26 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[2024/8/7 9:00:10 038] [08-07 19:12:26 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[2024/8/7 9:00:10 053] [08-07 19:12:26 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:00:10 053] [08-07 19:12:26 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:00:10 069] [08-07 19:12:26 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:00:10 069] [08-07 19:12:26 TUYA D][tuya_ipc_p2p_common.c:530] p2p passwd change to adb2c71b
[2024/8/7 9:00:10 084] [08-07 19:12:26 TUYA D][iot_httpc.c:1161] Post Data: {"password":"adb2c71b","t":1722992411}
[2024/8/7 9:00:10 100] [08-07 19:12:26 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.password.update&devId=6c98df4eddddc79e62pkva&et=1&t=1722992411&v=1.0&sign=9def30ed650c36a56e405de9c85bc4d8
[2024/8/7 9:00:10 100] [08-07 19:12:26 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:10 117] [08-07 19:12:26 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:10 117] [08-07 19:12:26 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:10 117] [08-07 19:12:26 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:10 133] [08-07 19:12:26 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992411}
[2024/8/7 9:00:10 149] [08-07 19:12:26 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.mesh.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992411&v=1.0&sign=f91759ae15004c2af29b215f2635cb64
[2024/8/7 9:00:10 149] [08-07 19:12:26 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:10 164] [08-07 19:12:26 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:10 165] [08-07 19:12:26 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:10 181] [08-07 19:12:26 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:10 181] [08-07 19:12:26 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[2024/8/7 9:00:10 196] [08-07 19:12:26 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6c98df4eddddc79e62pkva
[2024/8/7 9:00:10 196] [08-07 19:12:26 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6c98df4eddddc79e62pkva
[2024/8/7 9:00:10 212] [08-07 19:12:26 TUYA D][svc_online_log.c:317] svc online log active success
[2024/8/7 9:00:10 212] [08-07 09:00:11 TUYA D][tuya_ipc_sdk_init.c:137] sys stop timer: 14
[2024/8/7 9:00:10 213] [08-07 09:00:11 TUYA D][tuya_ipc_sdk_init.c:140] sys delete timer: 14
[2024/8/7 9:00:10 229] [08-07 09:00:11 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[2024/8/7 9:00:10 229] [08-07 09:00:11 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[2024/8/7 9:00:10 244] [08-07 09:00:11 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:00:10 244] dev id key: 16
[2024/8/7 9:00:10 244] c7 92 c0 e5 1f 4f ee 72 66 d6 71 3f 09 42 a4 5f 
[2024/8/7 9:00:10 245] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:00:10 260] [08-07 09:00:11 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:00:10 261] 2 1 6 3 2 1 a2 14 16 1 a2 0 75 94 2 c5 19 16 6 2a 3f b2 25 c3 23 6b 21 42 
[2024/8/7 9:00:10 276] [08-07 09:00:11 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:00:10 277] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 e3 fa be e2 35 75 b4 d a4 cb 3c bc 19 48 62 ef 
[2024/8/7 9:00:10 292] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:00:10 293] [08-07 09:00:11 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:00:10 293] [08-07 09:00:11 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:00:10 309] [08-07 09:00:11 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:10 309] tuya_hal_bt_send 20
[2024/8/7 9:00:10 309] 00 21 34 02 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 02 95 57 
[2024/8/7 9:00:10 325] [08-07 09:00:11 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:10 325] 0 21 34 2 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 2 95 57 
[2024/8/7 9:00:10 341] XmBleSendBuf 20: 00 21 34 02 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 02 95 57
[2024/8/7 9:00:10 341] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:10 341] ble_slave_gap_event->type=13
[2024/8/7 9:00:10 341] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:10 357] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:10 357] [08-07 09:00:11 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:10 373] g_AudioTipsList.size() enable: 0[08-07 09:00:11 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:00:10 373] tuya_hal_bt_send 17
[2024/8/7 9:00:10 373] 01 fa ed 7f bd 99 8d 1d a1 03 1f 03 01 e8 72 01 54 
[2024/8/7 9:00:10 389] [08-07 09:00:11 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:10 389] 1 fa ed 7f bd 99 8d 1d a1 3 1f 3 1 e8 72 1 54 
[2024/8/7 9:00:10 390] XmBleSendBuf 17: 01 fa ed 7f bd 99 8d 1d a1 03 1f 03 01 e8 72 01 54
[2024/8/7 9:00:10 390] [08-07 09:00:11 TUYA D][smart_frame.c:3490] rept chan:4
[2024/8/7 9:00:10 405] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:10 405] [08-07 09:00:11 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:10 421] [08-07 09:00:11 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:10 421] [08-07 09:00:11 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:10 421] __dp_data_report_data 4
[2024/8/7 9:00:10 421] 9f 01 01 00 
[2024/8/7 9:00:10 437] [08-07 09:00:11 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:10 437] [08-07 09:00:11 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:10 437] bt_ack_uncrypt 4
[2024/8/7 9:00:10 437] 9f 01 01 00 
[2024/8/7 9:00:10 453] [08-07 09:00:11 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:10 453] [08-07 09:00:11 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:10 469] [08-07 09:00:11 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:10 469] [08-07 09:00:11 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:10 485] [08-07 09:00:11 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:10 485] [08-07 09:00:11 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:10 501] [08-07 09:00:11 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:10 501] [08-07 09:00:11 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:10 517] [08-07 09:00:11 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:10 517] set basic_indicator_onoff:0 
[2024/8/7 9:00:10 517] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:10 533] [08-07 09:00:11 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:10 533] [08-07 09:00:11 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:10 549] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:10 549] [08-07 09:00:11 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:10 565] [08-07 09:00:11 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:10 565] [08-07 09:00:11 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:10 581] [08-07 09:00:11 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:10 582] ble_slave_gap_event->type=13
[2024/8/7 9:00:10 582] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:10 582] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:10 599] [08-07 09:00:11 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:10 599] [08-07 09:00:11 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:00:10 613] [08-07 09:00:11 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:10 613] tuya_hal_bt_send 20
[2024/8/7 9:00:10 613] 00 31 35 05 85 68 e3 03 d5 41 83 f2 4e 7c 38 aa c2 4f 02 5a 
[2024/8/7 9:00:10 629] [08-07 09:00:11 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:10 629] 0 31 35 5 85 68 e3 3 d5 41 83 f2 4e 7c 38 aa c2 4f 2 5a 
[2024/8/7 9:00:10 629] XmBleSendBuf 20: 00 31 35 05 85 68 e3 03 d5 41 83 f2 4e 7c 38 aa c2 4f 02 5a
[2024/8/7 9:00:10 645] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:10 645] ble_slave_gap_event->type=13
[2024/8/7 9:00:10 645] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:10 645] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:10 661] [08-07 09:00:11 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:10 661] [08-07 09:00:11 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:10 676] [08-07 09:00:11 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:10 692] [08-07 09:00:11 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:10 692] [08-07 09:00:11 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:10 708] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:10 708] Len=20 step 0
[2024/8/7 9:00:10 708] att=0x0 0x21 0x20 0x2 0x35 0xc 0x69 0xae 0xd6 0x4a 0xd2 0x40 0x99 0x26 0xd3 0xa0 0x21 0x41 0x4e 0xe7 
[2024/8/7 9:00:10 708]  RCVS len:20
[2024/8/7 9:00:10 724] set basic_indicator_onoff:1 
[2024/8/7 9:00:10 724] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:10 740] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:10 740] [08-07 09:00:11 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:10 740] tuya_hal_bt_send 20
[2024/8/7 9:00:10 756] 01 15 b6 13 94 81 ae 2a 81 ba d8 6a 21 d3 5a ec 75 ae 25 15 
[2024/8/7 9:00:10 756] [08-07 09:00:11 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:10 756] 1 15 b6 13 94 81 ae 2a 81 ba d8 6a 21 d3 5a ec 75 ae 25 15 
[2024/8/7 9:00:10 772] XmBleSendBuf 20: 01 15 b6 13 94 81 ae 2a 81 ba d8 6a 21 d3 5a ec 75 ae 25 15
[2024/8/7 9:00:10 772] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:10 788] [1970-01-01 00:00:38] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:10 804] [08-07 09:00:11 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"appKey":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","networkKey":"D59774254FA876FF1D204D16DF5223A5"},"t":1722992412,"success":true}
[2024/8/7 9:00:10 804] [08-07 09:00:11 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992412,"success":true}
[2024/8/7 9:00:10 804] [08-07 09:00:12 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:10 820] [08-07 09:00:12 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:10 836] [08-07 09:00:12 TUYA D][tuya_ble_api.c:1014] start to write flash, app_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66", network_key:"D59774254FA876FF1D204D16DF5223A5"
[2024/8/7 9:00:10 837] [08-07 09:00:12 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:10 852] [08-07 09:00:12 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:10 853] [08-07 09:00:12 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:10 853] [08-07 09:00:12 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:10 869] [08-07 09:00:12 TUYA D][simplekv.c:374] write key:ble_app_key And Value Len:48
[2024/8/7 9:00:10 869] [08-07 09:00:12 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 48
[2024/8/7 9:00:10 885] [08-07 09:00:12 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:00:10 885] [08-07 09:00:12 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:00:10 885] [08-07 09:00:12 TUYA D][simplekv.c:203] update crc 851548997
[2024/8/7 9:00:10 901] [08-07 09:00:12 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:10 901] [08-07 09:00:12 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:10 901] ble_slave_gap_event->type=13
[2024/8/7 9:00:10 901] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:10 917] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:10 917] [08-07 09:00:12 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:10 917] XmBleReadBuf 20:
[2024/8/7 9:00:10 933] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:10 933] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:10 933] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:10 949] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:00:10 949] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:00:10 965] [08-07 09:00:12 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:00:10 965] [08-07 09:00:12 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:10 965] [08-07 09:00:12 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:10 965] bt_rev_raw 20
[2024/8/7 9:00:10 981] 00 21 20 02 35 0c 69 ae d6 4a d2 40 99 26 d3 a0 21 41 4e e7 
[2024/8/7 9:00:10 981] [08-07 09:00:12 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:00:10 997] [08-07 09:00:12 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:00:10 997] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:00:11 013] [08-07 09:00:12 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:11 013] [08-07 09:00:12 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:11 013] [08-07 09:00:12 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:00:11 029] [08-07 09:00:12 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:00:11 029] [08-07 09:00:12 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:00:11 029] [08-07 09:00:12 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:00:11 045] [08-07 09:00:12 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:00:11 045] [08-07 09:00:12 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:00:11 061] [08-07 09:00:12 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:00:11 061] [08-07 09:00:12 TUYA D][simplekv.c:203] update crc 386669276
[2024/8/7 9:00:11 061] [08-07 09:00:12 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:11 077] [08-07 09:00:12 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:11 077] [08-07 09:00:12 TUYA D][tuya_devos_utils.c:341] set gw ext_stat:2
[2024/8/7 9:00:11 077] [08-07 09:00:12 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 0
[2024/8/7 9:00:11 093] 
[2024/8/7 9:00:11 094] [08-07 09:00:12 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.30.165 for domain m2.tuyacn.com
[2024/8/7 9:00:11 094] [08-07 09:00:12 TUYA D][mqtt_client.c:1472] select mqtt host:m2.tuyacn.com
[2024/8/7 9:00:11 109] [08-07 09:00:12 TUYA N][mqtt_client.c:1493] mqtt get serve ip success
[2024/8/7 9:00:11 109] [08-07 09:00:12 TUYA D][mqtt_client.c:989] serverIP 717233829 port:8883
[2024/8/7 9:00:11 125] [08-07 09:00:12 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:11 125] [08-07 09:00:12 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:11 125] [08-07 09:00:12 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:11 141] [08-07 09:00:12 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:11 141] [08-07 09:00:12 TUYA D][simplekv.c:374] write key:ble_network_key And Value Len:48
[2024/8/7 9:00:11 157] [08-07 09:00:12 TUYA D][simplekv.c:457] new space 13 startpos:36960 size:116
[2024/8/7 9:00:11 157] [08-07 09:00:12 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:11 157] [08-07 09:00:12 TUYA D][simplekv.c:203] update crc 477742926
[2024/8/7 9:00:11 173] [08-07 09:00:12 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:11 173] [08-07 09:00:12 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:11 189] [08-07 09:00:12 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992412}
[2024/8/7 9:00:11 205] [08-07 09:00:12 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.beacon.key.fetch&devId=6c98df4eddddc79e62pkva&et=1&t=1722992412&v=1.0&sign=216517a41f4b80db2d0c00b3ac769d20
[2024/8/7 9:00:11 205] [08-07 09:00:12 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:11 221] [08-07 09:00:12 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:11 221] [08-07 09:00:12 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:11 237] [08-07 09:00:12 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:11 237] [08-07 09:00:12 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:11 237] tuya_hal_bt_send 14
[2024/8/7 9:00:11 237] 02 db 85 5e 82 95 a1 e8 82 a7 d5 f5 9c 95 
[2024/8/7 9:00:11 253] [08-07 09:00:12 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:11 253] 2 db 85 5e 82 95 a1 e8 82 a7 d5 f5 9c 95 
[2024/8/7 9:00:11 253] XmBleSendBuf 14: 02 db 85 5e 82 95 a1 e8 82 a7 d5 f5 9c 95
[2024/8/7 9:00:11 269] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:00:11 269] ble_slave_gap_event->type=13
[2024/8/7 9:00:11 269] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:00:11 269] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:00:11 285] [08-07 09:00:12 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:11 285] [08-07 09:00:12 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:11 301] [08-07 09:00:12 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:11 301] [08-07 09:00:12 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:11 317] [08-07 09:00:12 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:11 317] [08-07 09:00:12 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:11 333] [08-07 09:00:12 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:11 333] [08-07 09:00:12 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:11 349] [08-07 09:00:12 TUYA D][mqtt_client.c:1014] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883
[2024/8/7 9:00:11 349] [08-07 09:00:12 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:11 365] [08-07 09:00:12 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyacn.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:11 365] [08-07 09:00:12 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:11 365] [08-07 09:00:12 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:11 381] [08-07 09:00:12 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:11 381] [08-07 09:00:12 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:11 396] [08-07 09:00:12 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:11 397] set basic_indicator_onoff:0 
[2024/8/7 9:00:11 397] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:00:11 397] Len=17 step 0
[2024/8/7 9:00:11 412] att=0x1 [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:11 428] 0x4 0x77 0xe7 0xc0 0x36 0xdf 0x97 0xcf 0xd8 0x2e 0xa2 0x58 0x2b 0x42 0x23 0x91 
[2024/8/7 9:00:11 428]  RCVS len:17
[2024/8/7 9:00:11 428] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:11 444] [1970-01-01 00:00:38] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:11 444] XmBleReadBuf 17:
[2024/8/7 9:00:11 444] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:00:11 444] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:00:11 460] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:00:11 460] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:00:11 460] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:00:11 476] [08-07 09:00:12 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:00:11 476] [08-07 09:00:12 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:00:11 492] [08-07 09:00:12 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:00:11 492] bt_rev_raw 17
[2024/8/7 9:00:11 492] 01 04 77 e7 c0 36 df 97 cf d8 2e a2 58 2b 42 23 91 
[2024/8/7 9:00:11 508] [08-07 09:00:12 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:00:11 508] ble rev data 33
[2024/8/7 9:00:11 508] 02 35 0c 69 ae d6 4a d2 40 99 26 d3 a0 21 41 4e e7 04 77 e7 c0 36 df 97 cf d8 2e a2 58 2b 42 23 91 
[2024/8/7 9:00:11 509] ble decryped data 16
[2024/8/7 9:00:11 524] 00 00 00 05 00 00 00 00 00 22 00 01 00 13 18 00 
[2024/8/7 9:00:11 524] [08-07 09:00:12 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:11 524] [08-07 09:00:12 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:00:11 540] [08-07 09:00:12 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:00:11 540] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:00:11 556] [08-07 09:00:12 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:11 572] [08-07 09:00:12 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:11 572] [08-07 09:00:12 TUYA D][iot_httpc.c:601] Decode Rev:{"result":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","t":1722992412,"success":true}
[2024/8/7 9:00:11 588] [08-07 09:00:12 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:11 588] [08-07 09:00:12 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:11 604] [08-07 09:00:12 TUYA D][tuya_ble_api.c:986] start to write flash, beacon_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66"
[2024/8/7 9:00:11 604] [08-07 09:00:12 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:00:11 604] [08-07 09:00:12 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:11 620] [08-07 09:00:12 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:11 620] [08-07 09:00:12 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:11 636] [08-07 09:00:12 TUYA D][simplekv.c:374] write key:ble_beaconkey And Value Len:48
[2024/8/7 9:00:11 636] [08-07 09:00:12 TUYA D][simplekv.c:457] new space 14 startpos:37076 size:116
[2024/8/7 9:00:11 652] [08-07 09:00:12 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:11 652] [08-07 09:00:12 TUYA D][simplekv.c:203] update crc 3935339627
[2024/8/7 9:00:11 652] set basic_indicator_onoff:1 
[2024/8/7 9:00:11 668] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:11 668] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:11 684] [08-07 09:00:12 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:11 684] [08-07 09:00:12 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:11 684] [08-07 09:00:12 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:00:11 700] [08-07 09:00:12 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:00:11 700] set basic_indicator_onoff:0 
[2024/8/7 9:00:11 700] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:11 716] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:11 716] set basic_indicator_onoff:1 
[2024/8/7 9:00:11 732] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:11 732] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:11 749] [1970-01-01 00:00:38] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:00:11 749] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:00:11 749] set basic_indicator_onoff:0 
[2024/8/7 9:00:11 764] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:11 764] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:11 780] [08-07 09:00:12 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:11 796] [08-07 09:00:12 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyacn.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:11 796] [08-07 09:00:12 TUYA N][mqtt_client.c:1531] mqtt create success, begin to connect
[2024/8/7 9:00:11 796] [08-07 09:00:12 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:00:11 813] set basic_indicator_onoff:1 
[2024/8/7 9:00:11 813] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:11 829] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:00:11 829] [08-07 09:00:12 TUYA D][mqtt_client.c:1413] cnt 1
[2024/8/7 9:00:11 829] [08-07 09:00:12 TUYA D][mqtt_client.c:1104] mqtt subscribe success
[2024/8/7 9:00:11 845] [08-07 09:00:12 TUYA D][mqc_app.c:732] mqtt connect success
[2024/8/7 9:00:11 845] [08-07 09:00:12 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[2024/8/7 9:00:11 861] [08-07 09:00:12 TUYA D][mqtt_client.c:1994] subscribe new topic /av/d/6c98df4eddddc79e62pkva ret:1 
[2024/8/7 9:00:11 861] [08-07 09:00:12 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[2024/8/7 9:00:11 861] __IPC_APP_Get_Net_Status_cb line(243) -------------------------- stat(11)==STAT_MQTT_ONLINE 
[2024/8/7 9:00:11 877] curr event:11 
[2024/8/7 9:00:11 877] IPC_APP_Notify_LED_Sound_Status_CB line(550) -------------------------- IPC_MQTT_ONLINE(11)
[2024/8/7 9:00:11 893] [1970-01-01 00:00:39] tuya_ipc_system_control_demo.c(551) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(DEVICE_ONLINE, 0, 0, 0, 1))
[2024/8/7 9:00:11 893] Disable Qrcode
[2024/8/7 9:00:11 910] [1970-01-01 00:00:39] tuya_ipc_system_control_demo.c(558) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONFIG_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:00:11 910] mqtt subscribe ack 5
[2024/8/7 9:00:11 910] 90 03 00 02 00 
[2024/8/7 9:00:11 925] [1970-01-01 00:00:39] xm_musicPlayer.cpp(91) <PlayAudioTips>: Open audio file /usr/share/audios/_english.pcm failed, No such file or directory
[2024/8/7 9:00:11 941] [1970-01-01 00:00:39] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/AddSuccess_english.pcm]
[2024/8/7 9:00:11 941] [1970-01-01 00:00:39] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:00:11 957] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:00:11 957] [08-07 09:00:13 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:00:11 973] [08-07 09:00:13 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:11 974] [08-07 09:00:13 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:11 974] [08-07 09:00:13 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:11 993] [08-07 09:00:13 TUYA E][svc_online_log_db.c:25] ret:-6
[2024/8/7 9:00:11 993] [08-07 09:00:13 TUYA D][svc_online_log.c:182] load env fail. maybe not exist.
[2024/8/7 9:00:12 005] [08-07 09:00:13 TUYA D][svc_online_log.c:187] update property:{"value":"{\"embed_sys_env\":\"arm-xm-linux\"}"}
[2024/8/7 9:00:12 005] [08-07 09:00:13 TUYA D][iot_httpc.c:1161] Post Data: {"value":"{\"embed_sys_env\":\"arm-xm-linux\"}","t":1722992413}
[2024/8/7 9:00:12 021] [08-07 09:00:13 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.property.save&devId=6c98df4eddddc79e62pkva&et=1&t=1722992413&v=1.0&sign=63f5e85942438622789f9d948257ee8c
[2024/8/7 9:00:12 037] [08-07 09:00:13 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:12 037] [08-07 09:00:13 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:12 053] [08-07 09:00:13 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:12 053] [08-07 09:00:13 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:12 069] [08-07 09:00:13 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:12 069] [08-07 09:00:13 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:12 085] [08-07 09:00:13 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:12 085] [08-07 09:00:13 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:12 101] [08-07 09:00:13 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:12 101] [08-07 09:00:13 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:12 101] [08-07 09:00:13 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:12 117] [08-07 09:00:13 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:12 133] [08-07 09:00:13 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:12 133] [08-07 09:00:13 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992413,"success":true}
[2024/8/7 9:00:12 149] [08-07 09:00:13 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:12 149] [08-07 09:00:13 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:12 149] [08-07 09:00:13 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:00:12 166] [08-07 09:00:13 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:12 166] [08-07 09:00:13 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:12 166] [08-07 09:00:13 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:12 180] [08-07 09:00:13 TUYA D][simplekv.c:374] write key:em_sys_env And Value Len:32
[2024/8/7 9:00:12 180] [08-07 09:00:13 TUYA D][simplekv.c:457] new space 15 startpos:37192 size:100
[2024/8/7 9:00:12 198] [08-07 09:00:13 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:12 198] [08-07 09:00:13 TUYA D][simplekv.c:203] update crc 2249098859
[2024/8/7 9:00:12 213] [08-07 09:00:13 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:12 213] [08-07 09:00:13 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:12 213] [08-07 09:00:13 TUYA D][MainApp.c:537] tuya_ipc_sdk_mqtt_online_proc is start run
[2024/8/7 9:00:12 229] [08-07 09:00:13 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992413 28800
[2024/8/7 9:00:12 229] [08-07 09:00:13 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992413 28800
[2024/8/7 9:00:12 229] Init tuya_ipc_ss_init
[2024/8/7 9:00:12 245] [08-07 09:00:13 TUYA D][tuya_ipc_stream_storage.c:2015] Init stream_storage.base_path:/mnt/mmc v:4 a:101, max event per day 289 skills 1
[2024/8/7 9:00:12 261] [08-07 09:00:13 TUYA D][tuya_ipc_stream_storage.c:2161] stream storage task init success
[2024/8/7 9:00:12 261] [08-07 09:00:13 TUYA D][MainApp.c:567] local storage init result is 0
[2024/8/7 9:00:12 261] [08-07 09:00:13 TUYA D][tuya_ipc_stream_storage.c:1571] SD task begin___
[2024/8/7 9:00:12 276] [08-07 09:00:13 TUYA D][tuya_ipc_stream_storage.c:1585] report sd status 0 -> 5
[2024/8/7 9:00:12 276] [08-07 09:00:13 TUYA E][tuya_ipc_stream_storage.c:1914] storage not inited
[2024/8/7 9:00:12 292] [08-07 09:00:13 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:00:12 292] [08-07 09:00:13 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:00:12 292] [08-07 09:00:13 TUYA D][tuya_ble_api.c:1417] cloud connected, stop adv!
[2024/8/7 9:00:12 308] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(640): stop_adv ---
[2024/8/7 9:00:12 308] exit_ble_thread create suc
[2024/8/7 9:00:12 308] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(644): XmBleAdvStop ---
[2024/8/7 9:00:12 324] [08-07 09:00:13 TUYA D][tuya_ble_api.c:1376] nw stat change:1->2, rpt to app.
[2024/8/7 9:00:12 324] [08-07 09:00:13 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:2
[2024/8/7 9:00:12 340] [08-07 09:00:13 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:12 340] [08-07 09:00:13 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:00:12 340] bt_ack_uncrypt 1
[2024/8/7 9:00:12 340] 02 
[2024/8/7 9:00:12 357] [08-07 09:00:13 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:12 358] [08-07 09:00:13 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:12 358] tuya_hal_bt_send 20
[2024/8/7 9:00:12 373] 00 21 36 05 fe c2 b1 a0 88 a0 95 be ba ba ba 86 12 02 c5 fc 
[2024/8/7 9:00:12 373] [08-07 09:00:13 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:12 373] 0 21 36 5 fe c2 b1 a0 88 a0 95 be ba ba ba 86 12 2 c5 fc 
[2024/8/7 9:00:12 389] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:12 389] [08-07 09:00:13 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:12 405] ---[XmBleReadBuf][132]: already stop ble,could not call XmBleReadBuf
[2024/8/7 9:00:12 405] [08-07 09:00:13 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:00:12 405] tuya_hal_bt_send 17
[2024/8/7 9:00:12 420] 01 b7 65 bc 6e fd cb b1 1d 44 d4 5c c7 6d 04 30 b4 
[2024/8/7 9:00:12 420] [08-07 09:00:13 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:12 420] 1 b7 65 bc 6e fd cb b1 1d 44 d4 5c c7 6d 4 30 b4 
[2024/8/7 9:00:12 437] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:12 437] [08-07 09:00:13 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:12 453] --- tracepoint bt_ext_porting.c,ty_btext_thread(433): tuya_hal_thread_release ---
[2024/8/7 9:00:12 453] [08-07 09:00:13 TUYA E][bt_ext_porting.c:434] [TUYA-BTUART]ty_btext_thread deleted
[2024/8/7 9:00:12 469] [08-07 09:00:13 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:00:12 469] [08-07 09:00:13 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[2024/8/7 9:00:12 469] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:00:12 485] [08-07 09:00:13 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
[2024/8/7 9:00:12 485] [08-07 09:00:13 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:2  -->>
[2024/8/7 9:00:12 500] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:00:12 500] [08-07 09:00:13 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:2  <<--
[2024/8/7 9:00:12 516] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:12 516] [08-07 09:00:13 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:00:12 532] [08-07 09:00:13 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:00:12 549] [1970-01-01 00:00:40] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:12 549] [1970-01-01 00:00:40] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time40951
[2024/8/7 9:00:12 565] [08-07 09:00:14 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c98df4eddddc79e62pkva, dp_rept_chan:5
[2024/8/7 9:00:12 565] [08-07 09:00:14 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:00:12 581] [08-07 09:00:14 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:159.
[2024/8/7 9:00:12 581] [08-07 09:00:14 TUYA D][smart_frame.c:2547] final pack:{"159":false}
[2024/8/7 9:00:12 597] [08-07 09:00:14 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:00:12 597] [08-07 09:00:14 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59408 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:00:12 597] [08-07 09:00:14 TUYA D][smart_frame.c:2135] sync rslt:0
[2024/8/7 9:00:12 613] [08-07 09:00:14 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:00:12 613] [08-07 09:00:14 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992414}
[2024/8/7 9:00:12 629] [08-07 09:00:14 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.uuid.pskkey.get&et=1&t=1722992414&uuid=uuidcaab27b0a838d239&v=1.0&sign=62e5f26fdd57b4e06575ed3d52ec0eb2
[2024/8/7 9:00:12 645] [08-07 09:00:14 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:12 645] [08-07 09:00:14 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:12 661] [08-07 09:00:14 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:12 661] [08-07 09:00:14 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:12 677] [08-07 09:00:14 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:12 677] [08-07 09:00:14 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:12 694] [08-07 09:00:14 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:12 694] [08-07 09:00:14 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:12 694] [08-07 09:00:14 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:12 709] [08-07 09:00:14 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:12 709] [08-07 09:00:14 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:12 725] [08-07 09:00:14 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:00:12 725] [08-07 09:00:14 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722992414, rept_cnt:1.
[2024/8/7 9:00:12 741] [08-07 09:00:14 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722992414, rept_cnt:0.
[2024/8/7 9:00:12 757] [08-07 09:00:14 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722992414, rept_cnt:0.
[2024/8/7 9:00:12 757] [08-07 09:00:14 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:12 773] [08-07 09:00:14 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:12 789] [08-07 09:00:14 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"pskKey":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80"},"t":1722992415,"success":true}
[2024/8/7 9:00:12 789] [08-07 09:00:15 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:12 789] [08-07 09:00:15 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:12 821] [08-07 09:00:15 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80","auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:00:12 837] [08-07 09:00:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:00:12 837] [08-07 09:00:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:00:12 837] [08-07 09:00:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:00:12 853] [08-07 09:00:15 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:256
[2024/8/7 9:00:12 853] [08-07 09:00:15 TUYA D][simplekv.c:397] 0 key same AND size old 276 >= new 256
[2024/8/7 9:00:12 853] [08-07 09:00:15 TUYA D][simplekv.c:430] find 0 available space
[2024/8/7 9:00:12 869] [08-07 09:00:15 TUYA D][simplekv.c:474] reuse available space 28700
[2024/8/7 9:00:12 869] [08-07 09:00:15 TUYA D][simplekv.c:203] update crc 1738115482
[2024/8/7 9:00:12 885] [08-07 09:00:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:12 885] [08-07 09:00:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:12 885] [08-07 09:00:15 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:00:12 980] set sd_record_on_off:1 
[2024/8/7 9:00:12 980] set sd_record_mode:0 
[2024/8/7 9:00:12 980] [08-07 09:00:15 TUYA E][tuya_ipc_stream_storage.c:1912] the ss mgr not inited, but msg buffered: set mode 1
[2024/8/7 9:00:12 980] write RecordMode success  0 
[2024/8/7 9:00:12 996] [08-07 09:00:15 TUYA D][tuya_ipc_cloud_storage.c:2188] init cloud storage begin
[2024/8/7 9:00:12 996] [08-07 09:00:15 TUYA D][simplekv.c:1211] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:13 012] [08-07 09:00:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:13 012] [08-07 09:00:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:13 012] [08-07 09:00:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:13 028] [08-07 09:00:15 TUYA E][tuya_ipc_cloud_storage.c:365] iot_wd_common_read fails md5_encrypt_key -6
[2024/8/7 9:00:13 029] [08-07 09:00:15 TUYA E][tuya_ipc_cloud_storage.c:450] read key_key file failed.
[2024/8/7 9:00:13 044] [08-07 09:00:15 TUYA D][tuya_ipc_cloud_storage.c:2240] __check_md5_encrypt_key fail, need update from server
[2024/8/7 9:00:13 060] [08-07 09:00:15 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:00:13 061] [08-07 09:00:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:13 061] [08-07 09:00:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:13 076] [08-07 09:00:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:13 077] [08-07 09:00:15 TUYA E][tuya_ipc_cloud_storage.c:942] iot_wd_common_read fails storage_restriction -6
[2024/8/7 9:00:13 092] [08-07 09:00:15 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992415}
[2024/8/7 9:00:13 108] [08-07 09:00:15 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.restriction.config.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992415&v=1.0&sign=2c0db1302f3942c80d9adedf654ee8e6
[2024/8/7 9:00:13 109] [08-07 09:00:15 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:13 125] [08-07 09:00:15 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:13 125] [08-07 09:00:15 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:13 125] [08-07 09:00:15 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:13 141] [08-07 09:00:15 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:13 141] [08-07 09:00:15 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:13 157] [08-07 09:00:15 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:13 157] [08-07 09:00:15 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:13 172] [08-07 09:00:15 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:13 173] [08-07 09:00:15 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:13 188] [08-07 09:00:15 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:13 189] [08-07 09:00:15 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:13 205] [08-07 09:00:15 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:13 221] [08-07 09:00:15 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"msg":{"audioDuration":15,"audioInterval":300,"videoDuration":6,"videoInterval":300},"storage":{"mtu":10}},"t":1722992415,"success":true}
[2024/8/7 9:00:13 236] [08-07 09:00:15 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:13 237] [08-07 09:00:15 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:13 237] [08-07 09:00:15 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:00:13 253] [08-07 09:00:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:13 253] [08-07 09:00:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:13 253] [08-07 09:00:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:13 269] [08-07 09:00:15 TUYA D][simplekv.c:374] write key:storage_restriction And Value Len:32
[2024/8/7 9:00:13 269] [08-07 09:00:15 TUYA D][simplekv.c:457] new space 16 startpos:37292 size:100
[2024/8/7 9:00:13 284] [08-07 09:00:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:13 285] [08-07 09:00:15 TUYA D][simplekv.c:203] update crc 2199389280
[2024/8/7 9:00:13 300] [08-07 09:00:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:13 301] [08-07 09:00:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:13 301] [08-07 09:00:15 TUYA D][tuya_ipc_cloud_storage.c:920] slice_duration write success
[2024/8/7 9:00:13 316] [08-07 09:00:15 TUYA D][tuya_ipc_cloud_storage.c:999] case 2 get slice duration from cloud 10
[2024/8/7 9:00:13 333] [08-07 09:00:15 TUYA D][tuya_ipc_cloud_storage.c:1043] cloud storage seize 3059584 bytes memory for media data, each slice 10 seconds
[2024/8/7 9:00:13 333] [08-07 09:00:15 TUYA I][uni_thread.c:228] thread_create name:cloud_storage,stackDepth:65536,totalstackDepth:91136,priority:3
[2024/8/7 9:00:13 348] [08-07 09:00:15 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[2024/8/7 9:00:13 348] [08-07 09:00:15 TUYA D][tuya_ipc_cloud_storage.c:2289] init cloud storage success
[2024/8/7 9:00:13 364] [08-07 09:00:15 TUYA D][MainApp.c:590] cloud storage init result is 0
[2024/8/7 9:00:13 364] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:13 380] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:13 380] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:13 380] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:13 396] __dp_data_report_data 4
[2024/8/7 9:00:13 396] 69 01 01 00 
[2024/8/7 9:00:13 396] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 396] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:13 412] bt_ack_uncrypt 4
[2024/8/7 9:00:13 412] 69 01 01 00 
[2024/8/7 9:00:13 412] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 412] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"105":false}
[2024/8/7 9:00:13 428] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59409 Q:1 Data:{"dps":{"105":false}}
[2024/8/7 9:00:13 428] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:13 444] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:13 444] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:00:13 460] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:13 460] __dp_data_report_data 4
[2024/8/7 9:00:13 460] 65 01 01 01 
[2024/8/7 9:00:13 460] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 476] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:13 476] bt_ack_uncrypt 4
[2024/8/7 9:00:13 476] 65 01 01 01 
[2024/8/7 9:00:13 476] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 493] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"101":true}
[2024/8/7 9:00:13 493] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59410 Q:1 Data:{"dps":{"101":true}}
[2024/8/7 9:00:13 509] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:13 509] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:13 525] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:13 525] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:13 525] __dp_data_report_data 4
[2024/8/7 9:00:13 525] 67 01 01 00 
[2024/8/7 9:00:13 541] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 541] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:13 541] bt_ack_uncrypt 4
[2024/8/7 9:00:13 541] 67 01 01 00 
[2024/8/7 9:00:13 557] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 557] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"103":false}
[2024/8/7 9:00:13 573] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59411 Q:1 Data:{"dps":{"103":false}}
[2024/8/7 9:00:13 573] [08-07 09:00:15 TUYA D][uni_thread.c:250] Thread:cloud_storage Exec Start. Set to Running Stat
[2024/8/7 9:00:13 589] [08-07 09:00:15 TUYA D][iot_httpc.c:1161] Post Data: {"type":"MediaStor","t":1722992415}
[2024/8/7 9:00:13 604] [08-07 09:00:15 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992415&v=3.0&sign=22fea49320304b453ae02ffe092fdaf5
[2024/8/7 9:00:13 605] [08-07 09:00:15 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:13 621] [08-07 09:00:15 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:13 621] [08-07 09:00:15 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:13 637] [08-07 09:00:15 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:13 637] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:13 652] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:13 652] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:00:13 652] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:13 668] __dp_data_report_data 4
[2024/8/7 9:00:13 668] 68 01 01 01 
[2024/8/7 9:00:13 668] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 684] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:13 684] bt_ack_uncrypt 4
[2024/8/7 9:00:13 684] 68 01 01 01 
[2024/8/7 9:00:13 684] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 700] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"104":true}
[2024/8/7 9:00:13 700] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59412 Q:1 Data:{"dps":{"104":true}}
[2024/8/7 9:00:13 700] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:13 716] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:107 not find
[2024/8/7 9:00:13 716] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:13 732] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:13 732] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:13 732] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:108 not find
[2024/8/7 9:00:13 748] [08-07 09:00:15 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:00:13 748] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[2024/8/7 9:00:13 764] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:105, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:13 764] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:105, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:13 780] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:105, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:13 780] [08-07 09:00:15 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:00:13 796] [08-07 09:00:15 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:13 796] tuya_hal_bt_send 20
[2024/8/7 9:00:13 796] 00 31 37 05 76 7f 7a 42 b0 84 ae 02 14 3f 84 d4 da be 92 7f 
[2024/8/7 9:00:13 812] [08-07 09:00:15 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:13 812] 0 31 37 5 76 7f 7a 42 b0 84 ae 2 14 3f 84 d4 da be 92 7f 
[2024/8/7 9:00:13 812] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:13 828] [08-07 09:00:15 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:13 828] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:13 845] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:13 845] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:00:13 845] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:00:13 845] IPC_APP_get_smart_mutile_light_mode line(546) ----------  
[2024/8/7 9:00:13 861] IPC_APP_set_smart_mutile_light_mode line(451) ---------- :0 ,g_SMLAbility=[0]
[2024/8/7 9:00:13 861] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0
[2024/8/7 9:00:13 877] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:101, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:13 893] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:101, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:13 893] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:101, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:13 893] DEBUG: camera_set_dnc_mode_chn 0 
[2024/8/7 9:00:13 909] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:00:13 909] DEBUG: software pohtoR!
[2024/8/7 9:00:13 909] IPC_APP_set_smart_mutile_light_mode line(536) ---------- :mode=[0] 
[2024/8/7 9:00:13 925] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:13 925] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<124> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:13 941] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:13 941] __dp_data_report_data 4
[2024/8/7 9:00:13 941] 7c 04 01 00 
[2024/8/7 9:00:13 941] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:13 957] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:13 957] bt_ack_uncrypt 4
[2024/8/7 9:00:13 957] 7c 04 01 [08-07 09:00:15 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:13 972] [08-07 09:00:15 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:13 972] [08-07 09:00:15 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:13 988] [08-07 09:00:15 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:13 988] [08-07 09:00:15 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:14 004] [08-07 09:00:15 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:14 004] [08-07 09:00:15 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:14 004] 00 
[2024/8/7 9:00:14 004] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 020] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"124":"auto"}
[2024/8/7 9:00:14 020] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59413 Q:1 Data:{"dps":{"124":"auto"}}
[2024/8/7 9:00:14 036] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 036] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:14 053] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:00:14 053] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:14 053] __dp_data_report_data 4
[2024/8/7 9:00:14 069] 86 01 01 01 
[2024/8/7 9:00:14 070] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 070] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:14 070] bt_ack_uncrypt 4
[2024/8/7 9:00:14 084] 86 01 01 01 
[2024/8/7 9:00:14 084] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 084] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"134":true}
[2024/8/7 9:00:14 100] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59414 Q:1 Data:{"dps":{"134":true}}
[2024/8/7 9:00:14 100] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 117] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:14 117] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:14 117] __dp_data_report_data 4
[2024/8/7 9:00:14 117] 6a 04 01 01 
[2024/8/7 9:00:14 133] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 133] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:14 133] bt_ack_uncrypt 4
[2024/8/7 9:00:14 133] 6a 04 01 01 
[2024/8/7 9:00:14 149] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 149] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"106":"1"}
[2024/8/7 9:00:14 165] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59415 Q:1 Data:{"dps":{"106":"1"}}
[2024/8/7 9:00:14 165] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 181] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:168 not find
[2024/8/7 9:00:14 181] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:14 181] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:14 197] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(855):  ---
[2024/8/7 9:00:14 197] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(866):  ---
[2024/8/7 9:00:14 213] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(872):  ---
[2024/8/7 9:00:14 213] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(892):  ---
[2024/8/7 9:00:14 229] [IPC_APP_get_alarm_zone_draw][893] alarm zone[{\"num\":1,\"region0\":{\"x\":1,\"y\":1,\"xlen\":99,\"ylen\":99}}]
[2024/8/7 9:00:14 229] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 229] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:169 not find
[2024/8/7 9:00:14 245] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:14 245] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:14 245] curr sd_status:1 
[2024/8/7 9:00:14 245] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 261] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:14 277] [08-07 09:00:15 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:5
[2024/8/7 9:00:14 277] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:14 277] __dp_data_report_data 7
[2024/8/7 9:00:14 277] 6e 02 04 00 00 00 05 
[2024/8/7 9:00:14 292] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 293] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:14 293] bt_ack_uncrypt 7
[2024/8/7 9:00:14 293] 6e 02 04 00 00 00 05 
[2024/8/7 9:00:14 308] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 309] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"110":5}
[2024/8/7 9:00:14 325] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59416 Q:1 Data:{"dps":{"110":5}}
[2024/8/7 9:00:14 325] [08-07 09:00:15 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:14 325] tuya_hal_bt_send 20
[2024/8/7 9:00:14 341] 01 dc cd 4d 3e 51 e9 b7 dc b4 6b 2c 4e 04 93 e0 a8 9b 6b 77 
[2024/8/7 9:00:14 341] [08-07 09:00:15 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:14 341] 1 dc cd 4d 3e 51 e9 b7 dc b4 6b 2c 4e 4 93 e0 a8 9b 6b 77 
[2024/8/7 9:00:14 357] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:14 357] [08-07 09:00:15 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:14 372] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0
[2024/8/7 9:00:14 373] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:103, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:14 389] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:103, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 404] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:103, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 405] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0
[2024/8/7 9:00:14 421] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:104, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:14 421] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:104, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 437] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:104, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 437] handle_DP_SD_STORAGE_ONLY_GET line(654) --------------------- 
[2024/8/7 9:00:14 453] [1970-01-01 00:00:42] tuya_ipc_sd_demo.c(182) <tuya_ipc_sd_get_capacity>: XM_SDCardGetPartitionInfo failed
[2024/8/7 9:00:14 453] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 469] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:14 469] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:14 469] __dp_data_report_data 8
[2024/8/7 9:00:14 485] 6d 03 05 30 7c 30 7c 30 
[2024/8/7 9:00:14 485] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 485] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:14 485] bt_ack_uncrypt 8
[2024/8/7 9:00:14 505] 6d 03 05 30 7c 30 7c 30 
[2024/8/7 9:00:14 505] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 505] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0"}
[2024/8/7 9:00:14 517] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59417 Q:1 Data:{"dps":{"109":"0|0|0"}}
[2024/8/7 9:00:14 517] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 532] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:14 532] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:00:14 549] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:14 549] __dp_data_report_data 4
[2024/8/7 9:00:14 549] 96 01 01 01 
[2024/8/7 9:00:14 549] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 565] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:14 565] bt_ack_uncrypt 4
[2024/8/7 9:00:14 565] 96 01 01 01 
[2024/8/7 9:00:14 565] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 581] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"150":true}
[2024/8/7 9:00:14 581] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59418 Q:1 Data:{"dps":{"150":true}}
[2024/8/7 9:00:14 597] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 597] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:14 613] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:14 613] __dp_data_report_data 4
[2024/8/7 9:00:14 613] 97 04 01 00 
[2024/8/7 9:00:14 613] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 629] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"124":"auto"}}, mqtt async dp cb:0
[2024/8/7 9:00:14 629] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:124, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:14 645] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:124, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 661] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:124, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 661] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0
[2024/8/7 9:00:14 677] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:134, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:14 677] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:134, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 693] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:134, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 693] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"106":"1"}}, mqtt async dp cb:0
[2024/8/7 9:00:14 709] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:106, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:14 725] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:106, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 725] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:106, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 741] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0
[2024/8/7 9:00:14 741] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:110, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:14 756] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:110, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 757] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:110, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 772] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"109":"0|0|0"}}, mqtt async dp cb:0
[2024/8/7 9:00:14 788] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:109, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:14 788] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:109, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 805] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:109, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 805] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0
[2024/8/7 9:00:14 820] [08-07 09:00:15 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:14 820] tuya_hal_bt_send 14
[2024/8/7 9:00:14 821] 02 6f 00 87 f9 09 7d 62 81 6b 1e 00 a9 ec 
[2024/8/7 9:00:14 836] [08-07 09:00:15 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:14 836] 2 6f 0 87 f9 9 7d 62 81 6b 1e 0 a9 ec 
[2024/8/7 9:00:14 836] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:14 852] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:14 853] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:150, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:14 868] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:150, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 884] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:150, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:14 884] [08-07 09:00:15 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:14 900] [08-07 09:00:15 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:14 901] [08-07 09:00:15 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:14 901] bt_ack_uncrypt 4
[2024/8/7 9:00:14 901] 97 04 01 00 
[2024/8/7 9:00:14 916] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 916] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"151":"1"}
[2024/8/7 9:00:14 933] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59419 Q:1 Data:{"dps":{"151":"1"}}
[2024/8/7 9:00:14 934] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:14 948] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:14 948] [08-07 09:00:15 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:0
[2024/8/7 9:00:14 964] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:14 964] __dp_data_report_data 7
[2024/8/7 9:00:14 964] 75 02 04 00 00 00 00 
[2024/8/7 9:00:14 964] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 980] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:14 980] bt_ack_uncrypt 7
[2024/8/7 9:00:14 980] 75 02 04 00 00 00 00 
[2024/8/7 9:00:14 980] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:14 996] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 9:00:14 996] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59420 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 9:00:15 012] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 012] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<138> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:15 028] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:15 028] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:15 028] __dp_data_report_data 4
[2024/8/7 9:00:15 028] 8a 01 01 00 
[2024/8/7 9:00:15 044] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 044] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:15 044] bt_ack_uncrypt 4
[2024/8/7 9:00:15 044] 8a 01 01 00 
[2024/8/7 9:00:15 060] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 060] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"138":false}
[2024/8/7 9:00:15 077] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59421 Q:1 Data:{"dps":{"138":false}}
[2024/8/7 9:00:15 077] current power mode:1
[2024/8/7 9:00:15 077] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 077] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:146 not find
[2024/8/7 9:00:15 092] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:15 092] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:15 092] current battery percent:80
[2024/8/7 9:00:15 108] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 108] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:145 not find
[2024/8/7 9:00:15 108] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:15 124] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:15 124] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 141] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:15 141] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:15 157] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:15 157] __dp_data_report_data 4
[2024/8/7 9:00:15 157] aa 01 01 00 
[2024/8/7 9:00:15 157] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 173] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:15 173] bt_ack_uncrypt 4
[2024/8/7 9:00:15 173] aa 01 01 00 
[2024/8/7 9:00:15 173] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 189] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"170":false}
[2024/8/7 9:00:15 189] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59422 Q:1 Data:{"dps":{"170":false}}
[2024/8/7 9:00:15 205] src/intelligent_track_thread.c(1466) [XM_GetBodyTarckEnable]: 
[2024/8/7 9:00:15 205] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 221] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:15 221] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:15 221] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:15 237] __dp_data_report_data 4
[2024/8/7 9:00:15 237] a1 01 01 00 
[2024/8/7 9:00:15 237] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 253] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:15 253] bt_ack_uncrypt 4
[2024/8/7 9:00:15 253] a1 01 01 00 
[2024/8/7 9:00:15 253] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 269] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"161":false}
[2024/8/7 9:00:15 269] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59423 Q:1 Data:{"dps":{"161":false}}
[2024/8/7 9:00:15 269] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 285] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:186 not find
[2024/8/7 9:00:15 285] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:15 301] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:15 301] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 317] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<133> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:15 317] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:15 317] __dp_data_report_data 4
[2024/8/7 9:00:15 317] 85 04 01 01 
[2024/8/7 9:00:15 333] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 333] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:15 333] bt_ack_uncrypt 4
[2024/8/7 9:00:15 333] 85 04 01 01 
[2024/8/7 9:00:15 349] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 349] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3"}
[2024/8/7 9:00:15 349] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59424 Q:1 Data:{"dps":{"133":"3"}}
[2024/8/7 9:00:15 364] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 365] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:15 380] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:15 380] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:15 380] __dp_data_report_data 4
[2024/8/7 9:00:15 396] 8b 01 01 00 
[2024/8/7 9:00:15 396] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 396] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:15 396] bt_ack_uncrypt 4
[2024/8/7 9:00:15 412] 8b 01 01 00 
[2024/8/7 9:00:15 412] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 412] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 9:00:15 428] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59425 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 9:00:15 429] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[2024/8/7 9:00:15 445] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:151, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:15 460] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:151, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 461] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:151, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 476] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[2024/8/7 9:00:15 477] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:117, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:15 492] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:117, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 493] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:117, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 508] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 70 enable 0 volume
[2024/8/7 9:00:15 509]  ---
[2024/8/7 9:00:15 509] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"138":false}}, mqtt async dp cb:0
[2024/8/7 9:00:15 524] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:138, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:15 541] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:138, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 541] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:138, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 556] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"170":false}}, mqtt async dp cb:0
[2024/8/7 9:00:15 556] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 573] [08-07 09:00:15 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:15 573] [08-07 09:00:15 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:15 573] tuya_hal_bt_send 20
[2024/8/7 9:00:15 589] 00 31 38 05 72 5f 39 23 e3 67 a4 77 26 a9 cc 01 68 5f 00 50 
[2024/8/7 9:00:15 589] [08-07 09:00:15 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:15 589] 0 31 38 5 72 5f 39 23 e3 67 a4 77 26 a9 cc 1 68 5f 0 50 
[2024/8/7 9:00:15 604] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:15 604] [08-07 09:00:15 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:15 620] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:170, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:15 620] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:170, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 636] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:170, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 652] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:15 652] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:15 652] __dp_data_report_data 4
[2024/8/7 9:00:15 652] 8c 04 01 01 
[2024/8/7 9:00:15 668] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 668] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:15 668] bt_ack_uncrypt 4
[2024/8/7 9:00:15 668] 8c 04 01 01 
[2024/8/7 9:00:15 684] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 684] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"140":"1"}
[2024/8/7 9:00:15 700] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59426 Q:1 Data:{"dps":{"140":"1"}}
[2024/8/7 9:00:15 700] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"161":false}}, mqtt async dp cb:0
[2024/8/7 9:00:15 716] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:161, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:15 716] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:161, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 732] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:161, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 732] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 748] [08-07 09:00:15 TUYA E][smart_frame.c:569] dparr[0] type not match:1 0
[2024/8/7 9:00:15 748] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3586
[2024/8/7 9:00:15 748] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 764] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:15 764] [08-07 09:00:15 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:50
[2024/8/7 9:00:15 780] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:15 780] __dp_data_report_data 7
[2024/8/7 9:00:15 780] a0 02 04 00 00 00 32 
[2024/8/7 9:00:15 780] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 796] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:15 796] bt_ack_uncrypt 7
[2024/8/7 9:00:15 796] a0 02 04 00 00 00 32 
[2024/8/7 9:00:15 812] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:15 812] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"160":50}
[2024/8/7 9:00:15 812] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"133":"3"}}, mqtt async dp cb:0
[2024/8/7 9:00:15 828] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59427 Q:1 Data:{"dps":{"160":50}}
[2024/8/7 9:00:15 844] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:133, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:15 844] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:133, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 860] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:133, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 860] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"139":false}}, mqtt async dp cb:0
[2024/8/7 9:00:15 876] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:139, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:15 876] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:139, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 892] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:139, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:15 892] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 908] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:195 not find
[2024/8/7 9:00:15 908] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:15 924] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:15 924] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 924] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:194 not find
[2024/8/7 9:00:15 940] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:15 940] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:15 940] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 956] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:158 not find
[2024/8/7 9:00:15 956] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:15 972] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:15 972] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:15 988] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:15 988] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:15 988] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:15 988] __dp_data_report_data 4
[2024/8/7 9:00:16 005] 9f 01 01 00 
[2024/8/7 9:00:16 005] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 005] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:16 020] bt_ack_uncrypt 4
[2024/8/7 9:00:16 021] 9f 01 01 00 
[2024/8/7 9:00:16 021] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 021] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:00:16 036] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59428 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:00:16 036] [1970-01-01 00:00:42] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:00:16 053] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 053] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:16 069] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:16 069] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:16 069] __dp_data_report_data 4
[2024/8/7 9:00:16 069] ae 01 01 00 
[2024/8/7 9:00:16 085] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 085] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:16 085] bt_ack_uncrypt 4
[2024/8/7 9:00:16 085] ae 01 01 00 
[2024/8/7 9:00:16 101] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 101] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"174":false}
[2024/8/7 9:00:16 117] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59429 Q:1 Data:{"dps":{"174":false}}
[2024/8/7 9:00:16 117] [1970-01-01 00:00:42] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:00:16 132] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 133] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:16 149] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:16 149] __dp_data_report_data 4
[2024/8/7 9:00:16 149] af 04 01 00 
[2024/8/7 9:00:16 149] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 165] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:16 165] bt_ack_uncrypt 4
[2024/8/7 9:00:16 165] af 04 01 00 
[2024/8/7 9:00:16 165] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 180] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"175":"0"}
[2024/8/7 9:00:16 180] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59430 Q:1 Data:{"dps":{"175":"0"}}
[2024/8/7 9:00:16 196] [1970-01-01 00:00:42] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:00:16 196] cruiseTimeMode is 0.
[2024/8/7 9:00:16 197] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 212] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:16 213] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:16 213] __dp_data_report_data 4
[2024/8/7 9:00:16 228] b0 04 01 00 
[2024/8/7 9:00:16 228] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 228] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:16 228] bt_ack_uncrypt 4
[2024/8/7 9:00:16 244] b0 04 01 00 
[2024/8/7 9:00:16 244] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 244] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"176":"0"}
[2024/8/7 9:00:16 260] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59431 Q:1 Data:{"dps":{"176":"0"}}
[2024/8/7 9:00:16 260] [1970-01-01 00:00:42] utils.c(322) <ReadTYJsonConfig>: Get antiFlicker object error!
[2024/8/7 9:00:16 276] anti Flicker mode is 0.
[2024/8/7 9:00:16 276] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 276] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:188 not find
[2024/8/7 9:00:16 292] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:16 292] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:16 292] [1970-01-01 00:00:42] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:00:16 308] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 308] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:192 not find
[2024/8/7 9:00:16 324] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:16 324] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:16 324] [1970-01-01 00:00:42] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:00:16 340] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 340] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:193 not find
[2024/8/7 9:00:16 356] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:16 356] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:16 372] [08-07 09:00:15 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:16 372] tuya_hal_bt_send 20
[2024/8/7 9:00:16 373] 01 5a b9 51 73 2e 35 81 6e e0 87 19 dd aa a7 dd f6 34 a8 12 
[2024/8/7 9:00:16 373] [08-07 09:00:15 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:16 388] 1 5a b9 51 73 2e 35 81 6e e0 87 19 dd aa a7 dd f6 34 a8 12 
[2024/8/7 9:00:16 388] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:16 404] [08-07 09:00:15 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:16 404] [1970-01-01 00:00:42] utils.c(322) <ReadTYJsonConfig>: Get FlightWarn object error!
[2024/8/7 9:00:16 404] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 420] [08-07 09:00:15 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:173 not find
[2024/8/7 9:00:16 420] [08-07 09:00:15 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:00:16 436] [08-07 09:00:15 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:00:16 436] [1970-01-01 00:00:42] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:00:16 436] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 452] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:16 452] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:16 468] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:16 468] __dp_data_report_data 4
[2024/8/7 9:00:16 468] 78 01 01 00 
[2024/8/7 9:00:16 468] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 484] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:16 484] bt_ack_uncrypt 4
[2024/8/7 9:00:16 484] 78 01 01 00 
[2024/8/7 9:00:16 484] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 500] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"120":false}
[2024/8/7 9:00:16 500] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59432 Q:1 Data:{"dps":{"120":false}}
[2024/8/7 9:00:16 516] [08-07 09:00:15 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1722992415,"success":true}
[2024/8/7 9:00:16 532] [08-07 09:00:15 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:16 532] [08-07 09:00:15 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:16 533] [08-07 09:00:15 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[2024/8/7 9:00:16 549] [08-07 09:00:15 TUYA D][tuya_ipc_cloud_storage.c:535] order expire or remote server error
[2024/8/7 9:00:16 564] [08-07 09:00:15 TUYA E][tuya_ipc_cloud_storage.c:1695] check cloud storage count failed, op_ret = -1
[2024/8/7 9:00:16 565] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"140":"1"}}, mqtt async dp cb:0
[2024/8/7 9:00:16 581] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:140, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:16 581] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:140, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 597] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:140, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 597] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"160":50}}, mqtt async dp cb:0
[2024/8/7 9:00:16 613] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:160, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:16 613] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:160, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 630] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:160, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 644] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:00:16 645] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722992415, rept_cnt:2.
[2024/8/7 9:00:16 661] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 661] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 677] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"174":false}}, mqtt async dp cb:0
[2024/8/7 9:00:16 693] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:174, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:16 694] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:174, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 708] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:174, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 708] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"175":"0"}}, mqtt async dp cb:0
[2024/8/7 9:00:16 724] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:175, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:16 724] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:175, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 740] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:175, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 740] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"176":"0"}}, mqtt async dp cb:0
[2024/8/7 9:00:16 756] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:176, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:16 773] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:176, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 773] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:176, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 789] [08-07 09:00:15 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:00:16 789] [08-07 09:00:15 TUYA D][smart_frame.c:419] dp<231> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:16 805] [08-07 09:00:15 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:16 805] [08-07 09:00:15 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:16 805] __dp_data_report_data 4
[2024/8/7 9:00:16 805] e7 01 01 00 
[2024/8/7 9:00:16 821] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 821] [08-07 09:00:15 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:00:16 821] bt_ack_uncrypt 4
[2024/8/7 9:00:16 821] e7 01 01 00 
[2024/8/7 9:00:16 837] [08-07 09:00:15 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:00:16 837] [08-07 09:00:15 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"231":false}
[2024/8/7 9:00:16 853] [08-07 09:00:15 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59433 Q:1 Data:{"dps":{"231":false}}
[2024/8/7 9:00:16 868] [08-07 09:00:15 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}","t":1722992415}
[2024/8/7 9:00:16 884] [08-07 09:00:15 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c98df4eddddc79e62pkva&et=1&t=1722992415&v=1.0&sign=acf52e513d7457ab3a028848a416180e
[2024/8/7 9:00:16 884] [08-07 09:00:15 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:16 900] [08-07 09:00:15 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:16 901] 
[2024/8/7 9:00:16 901] [08-07 09:00:15 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:16 901] [08-07 09:00:15 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:16 917] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"120":false}}, mqtt async dp cb:0
[2024/8/7 9:00:16 932] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:120, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:16 932] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:120, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 948] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:120, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:16 948] [08-07 09:00:15 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:16 964] [08-07 09:00:15 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:16 964] [08-07 09:00:15 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:16 981] [08-07 09:00:15 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:16 981] [08-07 09:00:15 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:16 981] [08-07 09:00:15 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:16 996] [08-07 09:00:15 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:16 996] [08-07 09:00:15 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"231":false}}, mqtt async dp cb:0
[2024/8/7 9:00:17 013] [08-07 09:00:15 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:231, curr_t:1722992415, rept_cnt:1.
[2024/8/7 9:00:17 028] [08-07 09:00:15 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:231, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:17 028] [08-07 09:00:15 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:231, curr_t:1722992415, rept_cnt:0.
[2024/8/7 9:00:17 044] [08-07 09:00:15 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:17 044] tuya_hal_bt_send 14
[2024/8/7 9:00:17 044] 02 73 7a 11 c0 fb 38 ac 37 b3 ff f6 b4 23 
[2024/8/7 9:00:17 061] [08-07 09:00:15 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:17 061] 2 73 7a 11 c0 fb 38 ac 37 b3 ff f6 b4 23 
[2024/8/7 9:00:17 061] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:17 077] [08-07 09:00:15 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:17 077] [08-07 09:00:15 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:17 093] [08-07 09:00:15 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:17 109] [08-07 09:00:15 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:17 109] [08-07 09:00:15 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:17 109] tuya_hal_bt_send 20
[2024/8/7 9:00:17 124] 00 31 39 05 7b bf 28 de a6 cc d5 cd 76 a2 ce 5f 02 4f af 6e 
[2024/8/7 9:00:17 125] [08-07 09:00:15 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:17 125] 0 31 39 5 7b bf 28 de a6 cc d5 cd 76 a2 ce 5f 2 4f af 6e 
[2024/8/7 9:00:17 141] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:17 141] [08-07 09:00:15 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:17 157] [08-07 09:00:15 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992416,"success":true}
[2024/8/7 9:00:17 157] [08-07 09:00:16 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:17 157] [08-07 09:00:16 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:17 173] [08-07 09:00:16 TUYA D][tuya_ipc_skill.c:198] upload data: {\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}
[2024/8/7 9:00:17 188] [08-07 09:00:16 TUYA D][MainApp.c:597] tuya_ipc_sdk_mqtt_online_proc is end run
[2024/8/7 9:00:17 188] [1970-01-01 00:00:42] MainApp.c(599) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:00:17 204] tuya_ipc_p2p_demo.c(455)<TUYA_APP_Enable_P2PTransfer> Dbg: Init P2P With Max Users:5
[2024/8/7 9:00:17 204] [08-07 09:00:16 TUYA D][tuya_ipc_webrtc.c:1534] begin___
[2024/8/7 9:00:17 204] [08-07 09:00:16 TUYA D][tuya_ipc_webrtc.c:1541] --audio-:8000,format:101
[2024/8/7 9:00:17 221] [08-07 09:00:16 TUYA D][tuya_ipc_webrtc.c:1542] end___ audiocbk_hdl(0x18f5c)
[2024/8/7 9:00:17 221] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5086] gw actived
[2024/8/7 9:00:17 221] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5095] p2p max_client_num[5]
[2024/8/7 9:00:17 237] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5096] p2p init media info:
[2024/8/7 9:00:17 237] [08-07 09:00:16 TUYA D][tuya_ipc_webrtc.c:1526] webrtc playback start_id 5
[2024/8/7 9:00:17 253] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:00:17 253] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4782] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:00:17 269] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:00:17 271] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4782] height[360] width[640] bitrate[1024]
[2024/8/7 9:00:17 271] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:00:17 286] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4794] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:00:17 286] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:00:17 301] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4794] height[360] width[640] bitrate[1024]
[2024/8/7 9:00:17 301] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:00:17 317] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:00:17 317] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:00:17 333] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:00:17 333] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:00:17 349] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:00:17 349] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:00:17 364] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:00:17 364] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:00:17 380] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:00:17 381] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4796] videoNum[2] audio codec[129] sample[0]
[2024/8/7 9:00:17 396] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4797] databits[1] channel[0]
[2024/8/7 9:00:17 396] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5122] need speaker audio codec[129] sample[0] databits[1] channel[0] defLiveMode[0]
[2024/8/7 9:00:17 413] [08-07 09:00:16 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:00:17 413] [08-07 09:00:16 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:00:17 413] [08-07 09:00:16 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:00:17 429] [08-07 09:00:16 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = adb2c71b
[2024/8/7 9:00:17 429] [08-07 09:00:16 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[2024/8/7 9:00:17 445] [08-07 09:00:16 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:00:17 445] [08-07 09:00:16 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:00:17 460] [08-07 09:00:16 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:00:17 460] [08-07 09:00:16 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:00:17 460] [08-07 09:00:16 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:00:17 476] [08-07 09:00:16 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:00:17 477] [08-07 09:00:16 TUYA D][tuya_ipc_p2p_common.c:455] update p2p_auth_info from service, type 4
[2024/8/7 9:00:17 492] [08-07 09:00:16 TUYA D][iot_httpc.c:1161] Post Data: {"type":4,"t":1722992416}
[2024/8/7 9:00:17 508] [08-07 09:00:16 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.p2p.config.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992416&v=2.0&sign=17485abe477c87d57aca57abac593834
[2024/8/7 9:00:17 509] [08-07 09:00:16 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:17 524] [08-07 09:00:16 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:17 525] [08-07 09:00:16 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:17 541] [08-07 09:00:16 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:17 541] [08-07 09:00:16 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:17 557] [08-07 09:00:16 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:17 558] [08-07 09:00:16 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:17 572] [08-07 09:00:16 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:17 572] [08-07 09:00:16 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:17 572] [08-07 09:00:16 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:17 588] [08-07 09:00:16 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:17 588] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:17 604] tuya_hal_bt_send 20
[2024/8/7 9:00:17 604] 01 7c 74 4c d3 8d d2 f2 e0 54 b9 9c ff 51 f5 15 bc 1d 0e 8f 
[2024/8/7 9:00:17 604] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:17 620] 1 7c 74 4c d3 8d d2 f2 e0 54 b9 9c ff 51 f5 15 bc 1d e 8f 
[2024/8/7 9:00:17 620] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:17 620] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:17 636] [08-07 09:00:16 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:17 652] [08-07 09:00:16 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:17 652] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:17 668] tuya_hal_bt_send 14
[2024/8/7 9:00:17 669] 02 45 7c 57 9f 9a da 9b 1a da 7b a7 49 86 
[2024/8/7 9:00:17 669] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:17 669] 2 45 7c 57 9f 9a da 9b 1a da 7b a7 49 86 
[2024/8/7 9:00:17 684] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:17 685]  ---
[2024/8/7 9:00:17 685] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:17 700] [08-07 09:00:16 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:17 701] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:17 701] tuya_hal_bt_send 20
[2024/8/7 9:00:17 717] 00 31 3a 05 87 e5 5e 2e 32 b3 fb a9 57 4b 88 d8 1a b7 48 a2 
[2024/8/7 9:00:17 717] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:17 717] 0 31 3a 5 87 e5 5e 2e 32 b3 fb a9 57 4b 88 d8 1a b7 48 a2 
[2024/8/7 9:00:17 733] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:17 733] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:17 749] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:17 749] tuya_hal_bt_send 20
[2024/8/7 9:00:17 749] 01 23 72 24 d1 d8 6d 98 66 5e 7a a7 ab 8b 75 62 89 d6 63 ad 
[2024/8/7 9:00:17 765] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:17 765] 1 23 72 24 d1 d8 6d 98 66 5e 7a a7 ab 8b 75 62 89 d6 63 ad 
[2024/8/7 9:00:17 780] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:17 780] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:17 797] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:17 797] tuya_hal_bt_send 14
[2024/8/7 9:00:17 797] 02 1f dd 42 1c 85 75 d2 33 9c 82 69 5c b2 
[2024/8/7 9:00:17 797] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:17 797] 2 1f dd 42 1c 85 75 d2 33 9c 82 69 5c b2 
[2024/8/7 9:00:17 813] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:17 813] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:17 828] [08-07 09:00:16 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:17 828] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:17 844] tuya_hal_bt_send 20
[2024/8/7 9:00:17 845] 00 31 3b 05 bb 13 e1 80 05 fc 93 81 72 0d 41 89 11 31 e0 19 
[2024/8/7 9:00:17 845] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:17 861] 0 31 3b 5 bb 13 e1 80 5 fc 93 81 72 d 41 89 11 31 e0 19 
[2024/8/7 9:00:17 861] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:17 861] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:17 877] [08-07 09:00:16 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"p2pId":"","type":4},"t":1722992416,"success":true}
[2024/8/7 9:00:17 877] [08-07 09:00:16 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:17 892] [08-07 09:00:16 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:17 892] [08-07 09:00:16 TUYA D][tuya_ipc_p2p_common.c:381] SY P2P AUTH:{"p2pId":"","type":4}
[2024/8/7 9:00:17 909] [08-07 09:00:16 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:00:17 909] [08-07 09:00:16 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:00:17 925] [08-07 09:00:16 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:00:17 925] [08-07 09:00:16 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:32
[2024/8/7 9:00:17 925] [08-07 09:00:16 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 32
[2024/8/7 9:00:17 941] [08-07 09:00:16 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:00:17 941] [08-07 09:00:16 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:00:17 957] [08-07 09:00:16 TUYA D][simplekv.c:203] update crc 1826517910
[2024/8/7 9:00:17 957] [08-07 09:00:16 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:17 958] [08-07 09:00:16 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:17 973] [08-07 09:00:16 TUYA D][tuya_ipc_p2p_common.c:458] get p2p auth info from service
[2024/8/7 9:00:17 973] [08-07 09:00:16 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:00:17 989] [08-07 09:00:16 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:00:17 991] [08-07 09:00:16 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:00:17 991] [08-07 09:00:16 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:00:18 004] [08-07 09:00:16 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:00:18 004] [08-07 09:00:16 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:00:18 005] [08-07 09:00:16 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:00:18 021] [08-07 09:00:16 TUYA D][simplekv.c:203] update crc 227087973
[2024/8/7 9:00:18 021] [08-07 09:00:16 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:18 037] [08-07 09:00:16 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:18 037] [08-07 09:00:16 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:00:18 037] [08-07 09:00:16 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:00:18 053] [08-07 09:00:16 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:00:18 053] [08-07 09:00:16 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[2024/8/7 9:00:18 068] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5178] p2p did[] apiLicense[] initString[]
[2024/8/7 9:00:18 068] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5181] support p2p type = 4
[2024/8/7 9:00:18 068] P2P API Version: 244.3.4.107
[2024/8/7 9:00:18 084] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4974] no encrypt
[2024/8/7 9:00:18 084] 42613 (null) INFO:6241316: tuya p2p rtc sdk version: 0xf403046b, Nov 16 2023 10:52:20
[2024/8/7 9:00:18 084] tuya liteos uv
[2024/8/7 9:00:18 100] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:18 100] tuya_hal_bt_send 20
[2024/8/7 9:00:18 100] 01 55 8d f2 dc 66 2f 74 9b ca 2e ee ba 3f 2e 81 79 66 ef eb 
[2024/8/7 9:00:18 116] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 116] 1 55 8d f2 dc 66 2f 74 9b ca 2e ee ba 3f 2e 81 79 66 ef eb 
[2024/8/7 9:00:18 116] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 132] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 132] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:18 148] tuya_hal_bt_send 14
[2024/8/7 9:00:18 148] 02 00 5f be f1 9c 52 1c a6 63 a7 1d fd 1d 
[2024/8/7 9:00:18 148] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 148] 2 0 5f be f1 9c 52 1c a6 63 a7 1d fd 1d 
[2024/8/7 9:00:18 164] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 164] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 180] [08-07 09:00:16 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:18 181] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:18 181] tuya_hal_bt_send 20
[2024/8/7 9:00:18 196] 00 31 3c 05 5d b9 6f e2 b6 82 e3 a8 8f a4 32 20 d5 14 3a 3d 
[2024/8/7 9:00:18 196] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 197] 0 31 3c 5 5d b9 6f e2 b6 82 e3 a8 8f a4 32 20 d5 14 3a 3d 
[2024/8/7 9:00:18 212] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 212] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 228] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:18 228] tuya_hal_bt_send 20
[2024/8/7 9:00:18 228] 01 2b 25 56 62 ce 51 23 7f 43 c2 c5 92 67 cd e1 8d b2 8d 94 
[2024/8/7 9:00:18 244] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 244] 1 2b 25 56 62 ce 51 23 7f 43 c2 c5 92 67 cd e1 8d b2 8d 94 
[2024/8/7 9:00:18 260] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 260] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 276] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:18 276] tuya_hal_bt_send 14
[2024/8/7 9:00:18 276] 02 92 d3 29 0f 4b 20 db f4 37 06 cc 63 18 
[2024/8/7 9:00:18 276] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 292] 2 92 d3 29 f 4b 20 db f4 37 6 cc 63 18 
[2024/8/7 9:00:18 292] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 292] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 308] [08-07 09:00:16 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:18 309] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:18 325] tuya_hal_bt_send 20
[2024/8/7 9:00:18 325] 00 31 3d 05 37 ad 06 6d 30 e9 16 40 8f 48 60 e4 db 1a 22 0c 
[2024/8/7 9:00:18 325] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 340] 0 31 3d 5 37 ad 6 6d 30 e9 16 40 8f 48 60 e4 db 1a 22 c 
[2024/8/7 9:00:18 340] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 340] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 356] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:18 356] tuya_hal_bt_send 20
[2024/8/7 9:00:18 372] 01 38 ab 85 0c a0 05 29 5f 35 0d 58 b4 13 c5 4a d8 25 76 70 
[2024/8/7 9:00:18 372] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 373] 1 38 ab 85 c a0 5 29 5f 35 d 58 b4 13 c5 4a d8 25 76 70 
[2024/8/7 9:00:18 388] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 388] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 404] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5039] _mqtt_p2p_listen_sessions create
[2024/8/7 9:00:18 404] [08-07 09:00:16 TUYA E][tuya_ipc_p2p.c:5190] p2p v3 init ok
[2024/8/7 9:00:18 404] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5230] speaker task create success
[2024/8/7 9:00:18 420] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5273] __p2p_session_detech create
[2024/8/7 9:00:18 420] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:5290] __p2p_video_send_proc create ok
[2024/8/7 9:00:18 420] [08-07 09:00:16 TUYA D][tuya_ipc_upnp.c:437] tuya_ipc_upnp_init start
[2024/8/7 9:00:18 436] [08-07 09:00:16 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:156672,priority:2
[2024/8/7 9:00:18 452] [08-07 09:00:16 TUYA D][tuya_ipc_upnp.c:458] tuya_ipc_upnp_init success
[2024/8/7 9:00:18 452] [08-07 09:00:16 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[2024/8/7 9:00:18 452] [08-07 09:00:16 TUYA D][tuya_ipc_packager.c:62] get packager instance
[2024/8/7 9:00:18 468] [08-07 09:00:16 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[2024/8/7 9:00:18 468] [08-07 09:00:16 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:18 484] [08-07 09:00:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:18 485] [08-07 09:00:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:18 485] [08-07 09:00:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:18 500] [08-07 09:00:16 TUYA E][tuya_ipc_encrypt.c:178] read local cloud encrypt key fails ..-6
[2024/8/7 9:00:18 500] [08-07 09:00:16 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992416}
[2024/8/7 9:00:18 516] [08-07 09:00:16 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.storage.secret.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992416&v=1.0&sign=6680f118e1d9329113350f48c36a4f82
[2024/8/7 9:00:18 532] [08-07 09:00:16 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:18 532] [08-07 09:00:16 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:18 548] [08-07 09:00:16 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:18 548] [08-07 09:00:16 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:18 548] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:3771] into p2p video send
[2024/8/7 9:00:18 564] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [0]
[2024/8/7 9:00:18 564] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4124] Begin to Listen mqtt p2p client connects In Thread
[2024/8/7 9:00:18 580] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 9:00:18 580] 43074 (null) INFO:6241316: try listen
[2024/8/7 9:00:18 596] [08-07 09:00:16 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[2024/8/7 9:00:18 596] [08-07 09:00:16 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1722992416}
[2024/8/7 9:00:18 613] [08-07 09:00:16 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992416&v=1.0&sign=94f248e0e58ea403efc7a3362da6603e
[2024/8/7 9:00:18 627] [08-07 09:00:16 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:18 628] [08-07 09:00:16 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:18 644] [08-07 09:00:16 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:18 644] [08-07 09:00:16 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:18 660] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:18 660] tuya_hal_bt_send 14
[2024/8/7 9:00:18 660] 02 f8 44 9a 8d 87 f9 18 9b 79 5a 00 44 c0 
[2024/8/7 9:00:18 660] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 677] 2 f8 44 9a 8d 87 f9 18 9b 79 5a 0 44 c0 
[2024/8/7 9:00:18 677] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 677] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 693] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:3553] New Thread To proc, init source
[2024/8/7 9:00:18 693] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:3572] session cmd recv proc alive [0] num[0]
[2024/8/7 9:00:18 708] [08-07 09:00:16 TUYA D][tuya_ipc_p2p.c:4652] Begin to session detech
[2024/8/7 9:00:18 708] [08-07 09:00:16 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:18 724] [08-07 09:00:16 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:18 724] [08-07 09:00:16 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:18 740] [08-07 09:00:16 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:18 740] [08-07 09:00:16 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:18 756] [08-07 09:00:16 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:18 756] [08-07 09:00:16 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:18 756] [08-07 09:00:16 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:18 772] [08-07 09:00:16 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:18 788] [08-07 09:00:16 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:18 788] [08-07 09:00:16 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:18 788] [08-07 09:00:16 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:18 804] [08-07 09:00:16 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:18 804] [08-07 09:00:16 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:18 820] [08-07 09:00:16 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:18 820] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:18 820] tuya_hal_bt_send 20
[2024/8/7 9:00:18 836] 00 31 3e 05 c6 7c e8 77 e6 7e 37 f5 47 17 da 23 32 7d 2f d9 
[2024/8/7 9:00:18 837] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 837] 0 31 3e 5 c6 7c e8 77 e6 7e 37 f5 47 17 da 23 32 7d 2f d9 
[2024/8/7 9:00:18 853] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 853] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 868] [08-07 09:00:16 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:18 885] [08-07 09:00:16 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:18 885] [08-07 09:00:16 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:18 901] [08-07 09:00:16 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:18 917] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:18 917] tuya_hal_bt_send 20
[2024/8/7 9:00:18 917] 01 81 8b 55 5f 33 81 b1 4c 84 bb 5c 70 e9 cd 32 22 dd 02 ef 
[2024/8/7 9:00:18 917] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:18 933] 1 81 8b 55 5f 33 81 b1 4c 84 bb 5c 70 e9 cd 32 22 dd 2 ef 
[2024/8/7 9:00:18 933] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:18 949] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:18 964] [08-07 09:00:16 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"unitList":[{"port":7000,"protocol":"TCP"},{"port":8080,"protocol":"TCP"},{"port":5000,"protocol":"UDP"},{"port":8000,"protocol":"UDP"}]},"t":1722992416,"success":true}
[2024/8/7 9:00:18 964] [08-07 09:00:16 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:18 981] [08-07 09:00:16 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:18 981] [08-07 09:00:16 TUYA D][tuya_ipc_upnp.c:171] upnp get config success result:{
[2024/8/7 9:00:18 981] 	"unitList":	[{
[2024/8/7 9:00:18 981] 			"port":	7000,
[2024/8/7 9:00:18 981] 			"protocol":	"TCP"
[2024/8/7 9:00:18 981] 		}, {
[2024/8/7 9:00:18 996] 			"port":	8080,
[2024/8/7 9:00:18 996] 			"protocol":	"TCP"
[2024/8/7 9:00:18 996] 		}, {
[2024/8/7 9:00:18 996] 			"port":	5000,
[2024/8/7 9:00:18 996] 			"protocol":	"UDP"
[2024/8/7 9:00:18 996] 			"port":	8000,
[2024/8/7 9:00:18 996] 		}]
[2024/8/7 9:00:19 012] [08-07 09:00:16 TUYA D][tuya_ipc_upnp.c:293] tuya_ipc_upnp_start start
[2024/8/7 9:00:19 012] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10.
[2024/8/7 9:00:19 028] [08-07 09:00:16 TUYA I][uni_thread.c:228] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:222208,priority:3
[2024/8/7 9:00:19 028] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0
[2024/8/7 9:00:19 044] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0
[2024/8/7 9:00:19 060] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:8343 
[2024/8/7 9:00:19 060] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8343, in_port 8343 protocol:UDP, status:0
[2024/8/7 9:00:19 076] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:5761 
[2024/8/7 9:00:19 076] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5761, in_port 5761 protocol:UDP, status:0
[2024/8/7 9:00:19 092] 
[2024/8/7 9:00:19 093] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:2499 
[2024/8/7 9:00:19 108] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 2499, in_port 2499 protocol:UDP, status:0
[2024/8/7 9:00:19 109] 
[2024/8/7 9:00:19 109] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5!
[2024/8/7 9:00:19 124] [08-07 09:00:16 TUYA D][tuya_ipc_upnp.c:314] tuya_ipc_upnp_start success
[2024/8/7 9:00:19 124] [08-07 09:00:16 TUYA D][tuya_ipc_upnp.c:421] start upnp module success, exit thread
[2024/8/7 9:00:19 125] [08-07 09:00:16 TUYA D][uni_thread.c:310] Del Thrd:ipc_upnp
[2024/8/7 9:00:19 140] [08-07 09:00:16 TUYA D][uni_thread.c:250] Thread:UPnP_PROC Exec Start. Set to Running Stat
[2024/8/7 9:00:19 141] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:19 156] tuya_hal_bt_send 14
[2024/8/7 9:00:19 156] 02 29 36 48 9d 3e 29 19 b6 ff 2a b9 40 60 
[2024/8/7 9:00:19 157] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:19 157] 2 29 36 48 9d 3e 29 19 b6 ff 2a b9 40 60 
[2024/8/7 9:00:19 173] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:19 173] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:19 188] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 90314ba51650
[2024/8/7 9:00:19 188] [08-07 09:00:16 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING...
[2024/8/7 9:00:19 204] [08-07 09:00:16 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"encryptKey":"992e9749e8f3402a"},"t":1722992416,"success":true}
[2024/8/7 9:00:19 205] [08-07 09:00:16 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:19 221] [08-07 09:00:16 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:19 221] [08-07 09:00:16 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:19 221] [08-07 09:00:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:19 236] [08-07 09:00:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:19 236] [08-07 09:00:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:19 252] [08-07 09:00:16 TUYA D][simplekv.c:374] write key:cloud_enc_key And Value Len:32
[2024/8/7 9:00:19 252] [08-07 09:00:16 TUYA D][simplekv.c:457] new space 17 startpos:37392 size:100
[2024/8/7 9:00:19 268] [08-07 09:00:16 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:19 268] [08-07 09:00:16 TUYA D][simplekv.c:203] update crc 839607698
[2024/8/7 9:00:19 269] [08-07 09:00:16 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:19 284] [08-07 09:00:16 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:19 285] [08-07 09:00:16 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:230400,priority:3
[2024/8/7 9:00:19 301] [08-07 09:00:16 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[2024/8/7 9:00:19 332] [08-07 09:00:16 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":90000,\"profileId\":\"\",\"width\":3840,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[2024/8/7 9:00:19 333] [1970-01-01 00:00:43] tuya_ipc_p2p_demo.c(475) <TUYA_APP_Enable_P2PTransfer>: tuya_ipc_tranfser_init ret=[0]
[2024/8/7 9:00:19 348] [1970-01-01 00:00:43] MainApp.c(606) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:00:19 348] [1970-01-01 00:00:43] MainApp.c(614) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:00:19 364] [1970-01-01 00:00:43] MainApp.c(615) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:00:19 364] [1970-01-01 00:00:43] MainApp.c(616) <tuya_ipc_sdk_mqtt_online_proc>: v_handle=[0x1ffa410]
[2024/8/7 9:00:19 380] [1970-01-01 00:00:43] MainApp.c(617) <tuya_ipc_sdk_mqtt_online_proc>: v_handle_sub=[0x201bbf8]
[2024/8/7 9:00:19 396] [1970-01-01 00:00:43] MainApp.c(618) <tuya_ipc_sdk_mqtt_online_proc>: a_handle_sub=[0x201e140]
[2024/8/7 9:00:19 396] [1970-01-01 00:00:43] xm_main.c(1104) <XM_RegisterTYCallFunc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:00:19 412] [1970-01-01 00:00:43] xm_main.c(1105) <XM_RegisterTYCallFunc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:00:19 412] [1970-01-01 00:00:43] xm_main.c(1106) <XM_RegisterTYCallFunc>: a_handle_sub=[0x201e140]
[2024/8/7 9:00:19 428] [1970-01-01 00:00:43] xm_main.c(1107) <XM_RegisterTYCallFunc>: v_handle=[0x1ffa410]
[2024/8/7 9:00:19 428] [1970-01-01 00:00:43] xm_main.c(1108) <XM_RegisterTYCallFunc>: v_handle_sub=[0x201bbf8]
[2024/8/7 9:00:19 444] [08-07 09:00:16 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:19 444] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:19 444] tuya_hal_bt_send 20
[2024/8/7 9:00:19 460] 00 31 3f 05 d7 76 ab be f4 62 b4 bb 79 90 df 2b 8d 8e 05 12 
[2024/8/7 9:00:19 460] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:19 476] 0 31 3f 5 d7 76 ab be f4 62 b4 bb 79 90 df 2b 8d 8e 5 12 
[2024/8/7 9:00:19 476] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:19 476] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:19 492] [1970-01-01 00:00:43] MainApp.c(620) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:00:19 492] [1970-01-01 00:00:43] MainApp.c(621) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:00:19 508] [08-07 09:00:16 TUYA D][uni_thread.c:125] del list not empty...deleting 0x200d384, next 0x1ff88e8
[2024/8/7 9:00:19 508] [08-07 09:00:16 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:00:19 524] [08-07 09:00:16 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[2024/8/7 9:00:19 524] [08-07 09:00:16 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[2024/8/7 9:00:19 540] [08-07 09:00:16 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[2024/8/7 9:00:19 540] [08-07 09:00:16 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992416 28800
[2024/8/7 9:00:19 556] [08-07 09:00:16 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992416 28800
[2024/8/7 9:00:19 556] --- tracepoint tuya_ipc_system_control_demo.c,XM_CheckDls_Pro(810): server time_zone 28800 time 1722992416 dls 0 loacl time 43
[2024/8/7 9:00:19 572] [08-07 09:00:16 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:19 572] tuya_hal_bt_send 20
[2024/8/7 9:00:19 572] 01 60 71 2e c4 54 1f ac 5a d7 48 0f 9c a1 9a 11 c5 5f 61 da 
[2024/8/7 9:00:19 588] [08-07 09:00:16 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:19 588] 1 60 71 2e c4 54 1f ac 5a d7 48 f 9c a1 9a 11 c5 5f 61 da 
[2024/8/7 9:00:19 588] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:19 604] [08-07 09:00:16 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:19 604] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:19 619] tuya_hal_bt_send 14
[2024/8/7 9:00:19 620] 02 07 79 c0 90 fd 23 37 bb cc 45 31 30 3e 
[2024/8/7 9:00:19 620] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:19 620] 2 7 79 c0 90 fd 23 37 bb cc 45 31 30 3e 
[2024/8/7 9:00:19 636] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:19 636] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:19 652] [2024-08-07 09:00:16] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 167[08-07 09:00:17 TUYA D][uni_thread.c:268] Thread:ipc_upnp Exec Finish. Set to Del Stat
[2024/8/7 9:00:19 668] [08-07 09:00:17 TUYA D][uni_thread.c:125] del list not empty...deleting 0x200d384, next 0x1ff88e8
[2024/8/7 9:00:19 668] [08-07 09:00:17 TUYA D][uni_thread.c:132] Final Free Thread:ipc_upnp, is_self:1
[2024/8/7 9:00:19 684] [08-07 09:00:17 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:00:19 684] [08-07 09:00:17 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:00:19 700] [08-07 09:00:17 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:19 700] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:19 700] tuya_hal_bt_send 20
[2024/8/7 9:00:19 716] 00 31 30 05 4e 1d 69 c3 7f 9d 7f f8 2e de 25 3b ed a9 4e 6c 
[2024/8/7 9:00:19 716] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:19 716] 0 31 30 5 4e 1d 69 c3 7f 9d 7f f8 2e de 25 3b ed a9 4e 6c 
[2024/8/7 9:00:19 732] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:19 732] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:19 748] [08-07 09:00:17 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.107, Nov 16 2023 10:52:20\"}","t":1722992417}
[2024/8/7 9:00:19 764] [08-07 09:00:17 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c98df4eddddc79e62pkva&et=1&t=1722992417&v=1.0&sign=2925bf8ab1c60edda622dab2c7a48e0a
[2024/8/7 9:00:19 780] [08-07 09:00:17 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:19 780] [08-07 09:00:17 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:19 796] [08-07 09:00:17 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:19 796] [08-07 09:00:17 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:19 796] [08-07 09:00:17 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:19 812] [08-07 09:00:17 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:19 828] [08-07 09:00:17 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:19 828] [08-07 09:00:17 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:19 828] [08-07 09:00:17 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:19 844] [08-07 09:00:17 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:19 845] [08-07 09:00:17 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:19 860] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:19 860] tuya_hal_bt_send 20
[2024/8/7 9:00:19 860] 01 f8 bc 9f d3 79 ff d4 08 5b 34 b6 0d 90 91 9c 98 fe c0 e3 
[2024/8/7 9:00:19 876] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:19 876] 1 f8 bc 9f d3 79 ff d4 8 5b 34 b6 d 90 91 9c 98 fe c0 e3 
[2024/8/7 9:00:19 876] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:19 892] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:19 892] [08-07 09:00:17 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:19 908] [08-07 09:00:17 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:19 924] [08-07 09:00:17 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:36 ip:0xc0a81ff2
[2024/8/7 9:00:19 924] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:19 924] tuya_hal_bt_send 14
[2024/8/7 9:00:19 940] 02 ab f8 2a 00 c7 a9 45 73 3a fa a2 bb 03 
[2024/8/7 9:00:19 940] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:19 940] 2 ab f8 2a 0 c7 a9 45 73 3a fa a2 bb 3 
[2024/8/7 9:00:19 956] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:19 956] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:19 956] [08-07 09:00:17 TUYA D][app_agent.c:1540] fd:36, wk_stat = 2, type = 3
[2024/8/7 9:00:19 971] [08-07 09:00:17 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:00:19 972] [08-07 09:00:17 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:00:19 988] [08-07 09:00:17 TUYA D][app_agent.c:600] send length:64, id:36, sequence_out:21739
[2024/8/7 9:00:19 988] [08-07 09:00:17 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722992417,"success":true}
[2024/8/7 9:00:19 988] [08-07 09:00:17 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:20 005] [08-07 09:00:17 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:20 005] [2024-08-07 09:00:16] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:00:20 020] [08-07 09:00:17 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:20 036] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:20 037] tuya_hal_bt_send 20
[2024/8/7 9:00:20 037] 00 31 30 05 2c 08 34 c1 84 a2 4e 06 6b 25 64 81 6d 6e 81 93 
[2024/8/7 9:00:20 037] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 052] 0 31 30 5 2c 8 34 c1 84 a2 4e 6 6b 25 64 81 6d 6e 81 93 
[2024/8/7 9:00:20 053] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 068] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 068] [08-07 09:00:17 TUYA D][app_agent.c:1540] fd:36, wk_stat = 2, type = 5
[2024/8/7 9:00:20 068] [08-07 09:00:17 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:00:20 084] [08-07 09:00:17 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:00:20 084] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:00:20 084] Mode(Product):0
[2024/8/7 9:00:20 084] BpuMode:[Online]
[2024/8/7 9:00:20 084] VpssMode:[Online]
[2024/8/7 9:00:20 084] [0.LimitUp_info]:
[2024/8/7 9:00:20 084] LimitUp:[Disable]
[2024/8/7 9:00:20 084] [2680*0]->[3840*0])
[2024/8/7 9:00:20 100] chn	TotalSize	ActiveSize
[2024/8/7 9:00:20 100] 0	5040*2246	2680*2160
[2024/8/7 9:00:20 100] 0	5040*2246	3840*2160
[2024/8/7 9:00:20 100] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:00:20 100] [1.VICU_info]:
[2024/8/7 9:00:20 100] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:00:20 116] 0	25.0	889	0	0	183	linear	8ddb00
[2024/8/7 9:00:20 116] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:00:20 116] en	op_type	m_chn	now
[2024/8/7 9:00:20 116] 0	1	1	1
[2024/8/7 9:00:20 116] [2.VI_info]:
[2024/8/7 9:00:20 116] chn	TotalSize	ActiveSize
[2024/8/7 9:00:20 116] 0	5040*2246	3848*2166
[2024/8/7 9:00:20 132] 1	   0*   0	   0*   0
[2024/8/7 9:00:20 132] [3.MIPI_info]:
[2024/8/7 9:00:20 132] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:00:20 132] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:00:20 148] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:00:20 148] [4.Cut_info]:
[2024/8/7 9:00:20 148] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:00:20 148] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:00:20 148] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:00:20 149] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:00:20 164] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:00:20 164] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:00:20 164] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:00:20 164] [5.IB(isp buffer info)]:
[2024/8/7 9:00:20 180] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:00:20 180] PoolId  Count  Size
[2024/8/7 9:00:20 180] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:20 196] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:20 200] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:20 200] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:20 215] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:20 215] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:20 228] [08-07 09:00:17 TUYA D][app_agent.c:1540] fd:36, wk_stat = 2, type = 16
[2024/8/7 9:00:20 228] [08-07 09:00:17 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:00:20 228] [08-07 09:00:17 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:00:20 244] [08-07 09:00:17 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:0,dpnum:41.
[2024/8/7 9:00:20 276] [08-07 09:00:17 TUYA D][smart_frame.c:2547] final pack:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"117":0,"120":false,"124":"auto","133":"3","134":true,"138":false,"139":false,"140":"1","150":true,"151":"1","159":false,"160":50,"161":false,"170":false,"174":false,"175":"0","176":"0","231":false}}
[2024/8/7 9:00:20 293] [08-07 09:00:17 TUYA D][app_agent.c:1240] Send Query To App:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"117":0,"120":false,"124":"auto","133":"3","134":true,"138":false,"139":false,"140":"1","150":true,"151":"1","159":false,"160":50,"161":false,"170":false,"174":false,"175":"0","176":"0","231":false}}
[2024/8/7 9:00:20 308] [08-07 09:00:17 TUYA D][app_agent.c:600] send length:288, id:36, sequence_out:21740
[2024/8/7 9:00:20 309] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:20 325] tuya_hal_bt_send 20
[2024/8/7 9:00:20 325] 01 b2 6e a7 86 ee bb df 8c c8 7b f6 cf ae 27 e7 2e 73 fb be 
[2024/8/7 9:00:20 325] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 340] 1 b2 6e a7 86 ee bb df 8c c8 7b f6 cf ae 27 e7 2e 73 fb be 
[2024/8/7 9:00:20 340] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 340] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 372] [2024-08-07 09:00:16] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 169[08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:20 372] tuya_hal_bt_send 14
[2024/8/7 9:00:20 372] 02 c0 4d 15 07 bf dd 89 53 e0 ab 79 7a 98 
[2024/8/7 9:00:20 372] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 388] 2 c0 4d 15 7 bf dd 89 53 e0 ab 79 7a 98 
[2024/8/7 9:00:20 388] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 388] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 404] [08-07 09:00:17 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:20 404] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:20 420] tuya_hal_bt_send 20
[2024/8/7 9:00:20 420] 00 31 30 05 53 22 71 d8 c4 bf 5e af 64 c3 b1 d2 b1 33 e5 97 
[2024/8/7 9:00:20 420] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 436] 0 31 30 5 53 22 71 d8 c4 bf 5e af 64 c3 b1 d2 b1 33 e5 97 
[2024/8/7 9:00:20 436] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 452] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 453] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:20 453] tuya_hal_bt_send 20
[2024/8/7 9:00:20 468] 01 11 71 2d 79 b5 62 de 29 c1 60 7c 2f 61 c2 c8 fa 74 0c 54 
[2024/8/7 9:00:20 468] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 468] 1 11 71 2d 79 b5 62 de 29 c1 60 7c 2f 61 c2 c8 fa 74 c 54 
[2024/8/7 9:00:20 484] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 484] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 500] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:20 500] tuya_hal_bt_send 14
[2024/8/7 9:00:20 500] 02 14 74 07 67 38 f6 d7 8b 3b a8 d5 65 ab 
[2024/8/7 9:00:20 500] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 516] 2 14 74 7 67 38 f6 d7 8b 3b a8 d5 65 ab 
[2024/8/7 9:00:20 516] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 532] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 548] [2024-08-07 09:00:16] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 600[08-07 09:00:17 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:20 548] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:20 548] tuya_hal_bt_send 20
[2024/8/7 9:00:20 564] 00 31 30 05 da 74 d4 1f b3 34 ce 19 77 00 6b 29 33 d0 c0 cf 
[2024/8/7 9:00:20 564] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 564] 0 31 30 5 da 74 d4 1f b3 34 ce 19 77 0 6b 29 33 d0 c0 cf 
[2024/8/7 9:00:20 580] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 580] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 596] g_AudioTipsList.size() enable: 0[08-07 09:00:17 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:00:20 596] [08-07 09:00:17 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:00:20 612] [08-07 09:00:17 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:00:20 612] [08-07 09:00:17 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:20 628] [08-07 09:00:17 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:00:20 628] [08-07 09:00:17 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59434 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:00:20 644] [2024-08-07 09:00:16] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 12270[08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:20 644] tuya_hal_bt_send 20
[2024/8/7 9:00:20 660] 01 20 68 4d 8c 89 66 64 2a 15 8e 7d 86 51 70 4d f6 7f 22 a5 
[2024/8/7 9:00:20 660] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 660] 1 20 68 4d 8c 89 66 64 2a 15 8e 7d 86 51 70 4d f6 7f 22 a5 
[2024/8/7 9:00:20 676] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 676] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 692] [08-07 09:00:17 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:00:20 692] [08-07 09:00:17 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722992417, rept_cnt:3.
[2024/8/7 9:00:20 708] [08-07 09:00:17 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722992417, rept_cnt:0.
[2024/8/7 9:00:20 724] [08-07 09:00:17 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722992417, rept_cnt:0.
[2024/8/7 9:00:20 724] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:20 724] tuya_hal_bt_send 14
[2024/8/7 9:00:20 724] 02 e8 54 b9 fa 69 88 68 ca 4c c9 15 1a 96 
[2024/8/7 9:00:20 740] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 740] 2 e8 54 b9 fa 69 88 68 ca 4c c9 15 1a 96 
[2024/8/7 9:00:20 740] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 756]  ---
[2024/8/7 9:00:20 756] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 756] [08-07 09:00:17 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:20 772] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:20 772] tuya_hal_bt_send 20
[2024/8/7 9:00:20 772] 00 31 30 05 24 cf bc d7 83 8c 70 fa 0c 5b 24 40 2c 64 8f 96 
[2024/8/7 9:00:20 788] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 788] 0 31 30 5 24 cf bc d7 83 8c 70 fa c 5b 24 40 2c 64 8f 96 
[2024/8/7 9:00:20 804] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 804] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 820] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:20 820] tuya_hal_bt_send 20
[2024/8/7 9:00:20 820] 01 a2 61 6e eb d6 1f 7b 0d f3 76 1d 59 c2 d1 85 2e db 3b 6c 
[2024/8/7 9:00:20 820] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 836] 1 a2 61 6e eb d6 1f 7b d f3 76 1d 59 c2 d1 85 2e db 3b 6c 
[2024/8/7 9:00:20 836] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 852] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 852] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:20 852] tuya_hal_bt_send 14
[2024/8/7 9:00:20 868] 02 c1 db 10 fd 65 37 d9 12 67 88 b3 2c fb 
[2024/8/7 9:00:20 868] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 868] 2 c1 db 10 fd 65 37 d9 12 67 88 b3 2c fb 
[2024/8/7 9:00:20 884] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 884] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 900] [08-07 09:00:17 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:20 900] [08-07 09:00:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:20 900] tuya_hal_bt_send 20
[2024/8/7 9:00:20 916] 00 31 30 05 43 82 3e c6 8e 2f c1 9a 0a 65 5a 37 c9 ea 4d d1 
[2024/8/7 9:00:20 916] [08-07 09:00:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 916] 0 31 30 5 43 82 3e c6 8e 2f c1 9a a 65 5a 37 c9 ea 4d d1 
[2024/8/7 9:00:20 932] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 932] [08-07 09:00:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 948] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:20 948] tuya_hal_bt_send 20
[2024/8/7 9:00:20 948] 01 f4 d3 5a 8b 68 24 6a 5b 8e b2 90 c6 e0 e1 b1 7b d4 6a ab 
[2024/8/7 9:00:20 964] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:20 964] 1 f4 d3 5a 8b 68 24 6a 5b 8e b2 90 c6 e0 e1 b1 7b d4 6a ab 
[2024/8/7 9:00:20 964] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:20 980] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:20 980] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:00:20 980] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:00:20 996] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:00:20 996] 0       0         0          1          4       
[2024/8/7 9:00:20 996] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:00:21 012]      --265--            --264--                                               
[2024/8/7 9:00:21 012] Count      Line     Count      Line     
[2024/8/7 9:00:21 012] 691        480      1575       560      
[2024/8/7 9:00:21 028] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:00:21 028] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:00:21 044] 0   3840   2160    H265  0      0        0           411       983035     5        	
[2024/8/7 9:00:21 044] 1   640    360     H265  0      0        0           273       43195      5        	
[2024/8/7 9:00:21 060] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:00:21 060] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:00:21 076] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:00:21 092] 0   Y      411      0       0       15       0        411      411      569       62294         59046    158034   65233    12      
[2024/8/7 9:00:21 092] 1   Y      273      0       6       1        0        273      273      569       3203          1883     88670    3419     9       
[2024/8/7 9:00:21 108] 3   N      0        0       0       1        0        0        0        570       0             0        0        0        0       
[2024/8/7 9:00:21 124] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:21 124] tuya_hal_bt_send 14
[2024/8/7 9:00:21 124] 02 72 51 d6 ad 04 53 81 2f 9c 39 8b fc 1f 
[2024/8/7 9:00:21 124] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 140] 2 72 51 d6 ad 4 53 81 2f 9c 39 8b fc 1f 
[2024/8/7 9:00:21 140] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 140] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 156] [2024-08-07 09:00:17] xm_device.c(499) <XM_SetAoStat[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:21 156] us>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:00:21 172] [2024-08-07 09:00:17] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:00:21 172] [2024-08-07 09:00:17] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:00:21 188] [08-07 09:00:18 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:21 188] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:21 204] tuya_hal_bt_send 20
[2024/8/7 9:00:21 204] 00 31 30 05 0e 42 36 1c f0 77 36 fa dc 91 32 a6 fb 00 f7 17 
[2024/8/7 9:00:21 204] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 220] 0 31 30 5 e 42 36 1c f0 77 36 fa dc 91 32 a6 fb 0 f7 17 
[2024/8/7 9:00:21 220] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 220] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 236] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:21 236] tuya_hal_bt_send 20
[2024/8/7 9:00:21 236] 01 0f c3 1f 61 ec 47 ec 23 be bb bc 3c bc 70 ca 02 e5 7b 34 
[2024/8/7 9:00:21 252] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 252] 1 f c3 1f 61 ec 47 ec 23 be bb bc 3c bc 70 ca 2 e5 7b 34 
[2024/8/7 9:00:21 268] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 268] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 284] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:21 284] tuya_hal_bt_send 14
[2024/8/7 9:00:21 284] 02 05 42[atbm_log]:tso xmit(2934)
[2024/8/7 9:00:21 284]  5e 9b 58 38 31 3b 4f fe 92 98 86 
[2024/8/7 9:00:21 284] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 300] 2 5 42 5e 9b 58 38 31 3b 4f fe 92 98 86 
[2024/8/7 9:00:21 300] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 316] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 316] [2024-08[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:00:21 316] -07 09:00:17] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time44922
[2024/8/7 9:00:21 332] [08-07 09:00:18 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:21 348] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:21 348] tuya_hal_bt_send 20
[2024/8/7 9:00:21 348] 00 31 30 05 5f 23 3c 50 1b 72 ca f7 83 fd 1f 7f 7d 17 16 62 
[2024/8/7 9:00:21 348] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 364] 0 31 30 5 5f 23 3c 50 1b 72 ca f7 83 fd 1f 7f 7d 17 16 62 
[2024/8/7 9:00:21 364] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 380] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 380] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:21 380] tuya_hal_bt_send 20
[2024/8/7 9:00:21 396] 01 7f 83 27 a0 87 1b 81 dd f7 23 e6 2b a9 bb 2c f3 51 6c fa 
[2024/8/7 9:00:21 396] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 396] 1 7f 83 27 a0 87 1b 81 dd f7 23 e6 2b a9 bb 2c f3 51 6c fa 
[2024/8/7 9:00:21 412] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 412] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 428] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:21 428] tuya_hal_bt_send 14
[2024/8/7 9:00:21 428] 02 2f 07 b0 09 46 77 88 4f f2 d0 b0 c9 2b 
[2024/8/7 9:00:21 428] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 444] 2 2f 7 b0 9 46 77 88 4f f2 d0 b0 c9 2b 
[2024/8/7 9:00:21 444] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 460] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 460] [08-07 09:00:18 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:21 475] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:21 475] tuya_hal_bt_send 20
[2024/8/7 9:00:21 475] 00 31 30 05 e6 b8 73 02 ab 3f 7a 2f bc 99 2f 3a 30 c4 9c a1 
[2024/8/7 9:00:21 475] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 491] 0 31 30 5 e6 b8 73 2 ab 3f 7a 2f bc 99 2f 3a 30 c4 9c a1 
[2024/8/7 9:00:21 491] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 492]  ---
[2024/8/7 9:00:21 508] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 508] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:21 508] tuya_hal_bt_send 20
[2024/8/7 9:00:21 524] 01 98 cd d7 4d cb 07 a2 16 6e f0 8d 16 3f 64 a8 bb 2a 75 77 
[2024/8/7 9:00:21 524] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 524] 1 98 cd d7 4d cb 7 a2 16 6e f0 8d 16 3f 64 a8 bb 2a 75 77 
[2024/8/7 9:00:21 540] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 540] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 556] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:21 556] tuya_hal_bt_send 14
[2024/8/7 9:00:21 556] 02 b1 02 9f 7f d1 ad 30 52 c1 ec 03 f7 d1 
[2024/8/7 9:00:21 572] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 572] 2 b1 2 9f 7f d1 ad 30 52 c1 ec 3 f7 d1 
[2024/8/7 9:00:21 572] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 588] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 588] [08-07 09:00:18 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:21 604] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:21 604] tuya_hal_bt_send 20
[2024/8/7 9:00:21 604] 00 31 30 05 c1 45 1b 6d 84 15 1d 41 ae cb 7b df 90 97 01 46 
[2024/8/7 9:00:21 620] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 620] 0 31 30 5 c1 45 1b 6d 84 15 1d 41 ae cb 7b df 90 97 1 46 
[2024/8/7 9:00:21 620] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 636] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 636] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:21 636] tuya_hal_bt_send 20
[2024/8/7 9:00:21 652] 01 ea e0 e9 2c 9b aa 78 38 9f 3e 8b 74 14 d6 a9 0b 33 59 65 
[2024/8/7 9:00:21 652] [08-07 09:00:18 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 668] 1 ea e0 e9 2c 9b aa 78 38 9f 3e 8b 74 14 d6 a9 b 33 59 65 
[2024/8/7 9:00:21 668] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 668] [08-07 09:00:18 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 684] [08-07 09:00:18 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:21 684] tuya_hal_bt_send 14
[2024/8/7 9:00:21 684] 02 1e c6 db d3 7d e9 a5 e0 9b 7b 90 fc f0 
[2024/8/7 9:00:21 700] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 700] 2 1e c6 db d3 7d e9 a5 e0 9b 7b 90 fc f0 
[2024/8/7 9:00:21 700] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 716] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 716] [08-07 09:00:19 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:21 732] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:21 732] tuya_hal_bt_send 20
[2024/8/7 9:00:21 748] 00 31 30 05 21 6e 8c a5 83 29 [2024-08-07 09:00:18] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 1243666 b2 f4 e1 12 05 f8 92 4b 30 
[2024/8/7 9:00:21 748] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 764] 0 31 30 5 21 6e 8c a5 83 29 66 b2 f4 e1 12 5 f8 92 4b 30 
[2024/8/7 9:00:21 764] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 764] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 780] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:21 780] tuya_hal_bt_send 20
[2024/8/7 9:00:21 780] 01 bb c8 ea ab c2 18 f5 62 85 b8 cd 83 11 bb 25 40 ad f0 63 
[2024/8/7 9:00:21 796] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 796] 1 bb c8 ea ab c2 18 f5 62 85 b8 cd 83 11 bb 25 40 ad f0 63 
[2024/8/7 9:00:21 812] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 812] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 828] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:21 828] tuya_hal_bt_send 14
[2024/8/7 9:00:21 828] 02 6c d1 55 9d bc d7 f6 66 3d 1e 34 e3 af 
[2024/8/7 9:00:21 828] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 844] 2 6c d1 55 9d bc d7 f6 66 3d 1e 34 e3 af 
[2024/8/7 9:00:21 844] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 844] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 860] [08-07 09:00:19 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:21 876] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:21 876] tuya_hal_bt_send 20
[2024/8/7 9:00:21 876] 00 31 30 05 ec ed 45 ef 96 ab 22 8b 0d 34 91 06 c6 5c b5 8c 
[2024/8/7 9:00:21 876] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 892] 0 31 30 5 ec ed 45 ef 96 ab 22 8b d 34 91 6 c6 5c b5 8c 
[2024/8/7 9:00:21 892] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 908] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 908] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:21 908] tuya_hal_bt_send 20
[2024/8/7 9:00:21 924] 01 ec b1 29 e9 a9 e9 3b 38 bf 4b de 92 2d e9 7b 27 7c a4 9c 
[2024/8/7 9:00:21 924] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 924] 1 ec b1 29 e9 a9 e9 3b 38 bf 4b de 92 2d e9 7b 27 7c a4 9c 
[2024/8/7 9:00:21 940] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 940] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 956] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:21 956] tuya_hal_bt_send 14
[2024/8/7 9:00:21 956] 02 22 3b 3e 1b c4 c4 7a 19 4e 3a 21 6d b5 
[2024/8/7 9:00:21 972] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:21 972] 2 22 3b 3e 1b c4 c4 7a 19 4e 3a 21 6d b5 
[2024/8/7 9:00:21 973] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:21 988] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:21 988] [08-07 09:00:19 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:22 004] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:22 004] tuya_hal_bt_send 20
[2024/8/7 9:00:22 004] 00 31 30 05 8b 65 8c 23 90 ae 2e 9d 63 3f 23 a9 9c d8 37 c7 
[2024/8/7 9:00:22 020] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 020] 0 31 30 5 8b 65 8c 23 90 ae 2e 9d 63 3f 23 a9 9c d8 37 c7 
[2024/8/7 9:00:22 020] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 036] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 036] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:22 036] tuya_hal_bt_send 20
[2024/8/7 9:00:22 052] 01 e9 9a a4 f0 9c 7a 6b d0 9b 36 83 cb dc 37 23 a5 25 28 d6 
[2024/8/7 9:00:22 052] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 052] 1 e9 9a a4 f0 9c 7a 6b d0 9b 36 83 cb dc 37 23 a5 25 28 d6 
[2024/8/7 9:00:22 067] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 068]  ---
[2024/8/7 9:00:22 068] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 084] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:22 084] tuya_hal_bt_send 14
[2024/8/7 9:00:22 084] 02 ff bd 7e 85 73 a8 e9 bf 45 ba d5 fe 58 
[2024/8/7 9:00:22 099] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 100] 2 ff bd 7e 85 73 a8 e9 bf 45 ba d5 fe 58 
[2024/8/7 9:00:22 100] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 115] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 116] [08-07 09:00:19 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:22 133] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:22 133] tuya_hal_bt_send 20
[2024/8/7 9:00:22 134] 00 31 30 05 e5 6b e9 76 9a 98 93 7d d7 b6 27 f3 0f dd bb e7 
[2024/8/7 9:00:22 148] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 149] 0 31 30 5 e5 6b e9 76 9a 98 93 7d d7 b6 27 f3 f dd bb e7 
[2024/8/7 9:00:22 149] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 165] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 165] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:22 181] tuya_hal_bt_send 20
[2024/8/7 9:00:22 181] 01 90 16 ed 8f 0c a2 60 53 c1 24 a3 2c 44 73 26 ab 8a 65 2a 
[2024/8/7 9:00:22 181] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 197] 1 90 16 ed 8f c a2 60 53 c1 24 a3 2c 44 73 26 ab 8a 65 2a 
[2024/8/7 9:00:22 197] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 197] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 212] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:22 212] tuya_hal_bt_send 14
[2024/8/7 9:00:22 212] 02 28 db 89 1d 76 49 c4 8b a2 49 70 87 39 
[2024/8/7 9:00:22 229] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 229] 2 28 db 89 1d 76 49 c4 8b a2 49 70 87 39 
[2024/8/7 9:00:22 229] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 245]  ---
[2024/8/7 9:00:22 247] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 247] [08-07 09:00:19 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:22 260] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:22 260] tuya_hal_bt_send 20
[2024/8/7 9:00:22 260] 00 31 30 05 1c 3d d8 b6 d5 6c 34 2e a3 da 22 b2 b9 5e 1a 16 
[2024/8/7 9:00:22 277] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 277] 0 31 30 5 1c 3d d8 b6 d5 6c 34 2e a3 da 22 b2 b9 5e 1a 16 
[2024/8/7 9:00:22 292] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 292] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 308] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:22 308] tuya_hal_bt_send 20
[2024/8/7 9:00:22 308] 01 75 da f8 4e 23 73 60 b4 61 3a 1f 89 60 fc 1b 8d 91 02 99 
[2024/8/7 9:00:22 308] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 324] 1 75 da f8 4e 23 73 60 b4 61 3a 1f 89 60 fc 1b 8d 91 2 99 
[2024/8/7 9:00:22 324] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 340] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 340] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:22 340] tuya_hal_bt_send 14
[2024/8/7 9:00:22 356] 02 2c 33 e7 9d 7f da eb 89 f6 f1 f1 27 ba 
[2024/8/7 9:00:22 356] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 356] 2 2c 33 e7 9d 7f da eb 89 f6 f1 f1 27 ba 
[2024/8/7 9:00:22 372] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 372] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 388] [08-07 09:00:19 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:22 388] [08-07 09:00:19 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:00:22 388] [08-07 09:00:19 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:00:22 404] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:00:22 404] tuya_hal_bt_send 20
[2024/8/7 9:00:22 404] 00 31 30 05 8d 1d 50 e3 0a 04 12 ad df b3 df 19 91 fa ae 08 
[2024/8/7 9:00:22 420] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 420] 0 31 30 5 8d 1d 50 e3 a 4 12 ad df b3 df 19 91 fa ae 8 
[2024/8/7 9:00:22 420] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 436] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 436] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:00:22 452] tuya_hal_bt_send 20
[2024/8/7 9:00:22 453] 01 9f d1 9d 79 67 a3 84 d6 0e 52 d0 bc cd 7d d0 16 92 22 6a 
[2024/8/7 9:00:22 453] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 468] 1 9f d1 9d 79 67 a3 84 d6 e 52 d0 bc cd 7d d0 16 92 22 6a 
[2024/8/7 9:00:22 468] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 468] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 484] [08-07 09:00:19 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:00:22 484] tuya_hal_bt_send 14
[2024/8/7 9:00:22 484] 02 53 19 b7 36 13 46 af 71 9e f7 1d 41 77 
[2024/8/7 9:00:22 500] [08-07 09:00:19 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:00:22 500] 2 53 19 b7 36 13 46 af 71 9e f7 1d 41 77 
[2024/8/7 9:00:22 500] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:00:22 516] [08-07 09:00:19 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:00:22 516] [08-07 09:00:19 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:00:22 532] [08-07 09:00:19 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:00:22 532] [08-07 09:00:19 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:00:22 548] [08-07 09:00:19 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:00:22 548] [08-07 09:00:19 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:59434
[2024/8/7 9:00:22 564] [08-07 09:00:19 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992419,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 9:00:22 564] [08-07 09:00:19 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 9:00:22 580] [08-07 09:00:19 TUYA D][app_agent.c:600] send length:80, id:36, sequence_out:21741
[2024/8/7 9:00:22 580] [08-07 09:00:20 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:00:22 596] [08-07 09:00:20 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 9:00:22 596] [08-07 09:00:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:22 596] [08-07 09:00:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:22 612] [08-07 09:00:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:22 612] [08-07 09:00:20 TUYA D][tuya_svc_schema_upgrade.c:223] schema[flvlrc] not updated since activated
[2024/8/7 9:00:22 628] [2024-08-07 09:00:20] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:22 628] [08-07 09:00:21 TUYA D][iot_httpc.c:1161] Post Data: {"data":"255","t":1722992421}
[2024/8/7 9:00:22 644] [08-07 09:00:21 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6c98df4eddddc79e62pkva&et=1&t=1722992421&sign=e48800d430cf9cc1494dbb02accd5321
[2024/8/7 9:00:22 660] [08-07 09:00:21 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:22 660] [08-07 09:00:21 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:22 676] [08-07 09:00:21 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:22 676] [08-07 09:00:21 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:22 692] [08-07 09:00:21 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:22 692] [08-07 09:00:21 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:22 708] [08-07 09:00:21 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:22 708] [08-07 09:00:21 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:22 723] [08-07 09:00:21 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:22 723] [08-07 09:00:21 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:22 723] [08-07 09:00:21 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:22 739] [08-07 09:00:21 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:22 755] [08-07 09:00:21 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:22 755] [08-07 09:00:22 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722992422,"success":true}
[2024/8/7 9:00:22 771] [08-07 09:00:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:22 771] [08-07 09:00:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:22 772] [08-07 09:00:22 TUYA D][tuya_devos_entry.c:406] put rst log finish
[2024/8/7 9:00:22 787] [08-07 09:00:22 TUYA D][iot_httpc.c:1161] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1722992422}
[2024/8/7 9:00:22 803] [08-07 09:00:22 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992422&v=2.0&sign=e9011d5f5b945daa5765b9e7385e530c
[2024/8/7 9:00:22 820] [08-07 09:00:22 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:22 820] [08-07 09:00:22 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:22 836] [08-07 09:00:22 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:22 836] [08-07 09:00:22 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:22 836] [08-07 09:00:22 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:22 852] [08-07 09:00:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:22 867] [08-07 09:00:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:22 867] [08-07 09:00:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:22 867] [08-07 09:00:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:22 883] [08-07 09:00:22 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:22 883] [08-07 09:00:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:22 900] [08-07 09:00:22 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:22 916] [08-07 09:00:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:22 916] tuya_ipc_ss_start_event:2288 :start new event
[2024/8/7 9:00:22 916] [08-07 09:00:22 TUYA E][tuya_ipc_stream_storage.c:2294] the ss mgr not inited, but msg buffed
[2024/8/7 9:00:22 932] thread_ai_detect_proc line(194) ----------tuya_ipc_ss_start_event-----------RecordMode :0 alarm_flag   1
[2024/8/7 9:00:22 932] [2024-08-07 09:00:21] tuya_ipc_ai_detect.demo.c(196) <thread_ai_detect_proc>: 
[2024/8/7 9:00:22 948] [2024-08-07 09:00:21] xm_main.c(1810) <XM_GetCatchJpgStream>: 
[2024/8/7 9:00:22 948] [2024-08-07 09:00:21] xm_main.c(1813) <XM_GetCatchJpgStream>: 
[2024/8/7 9:00:22 964] [2024-08-07 09:00:21] xm_main.c(1833) <XM_GetCatchJpgStream>: 
[2024/8/7 9:00:22 964] snap_size:21710
[2024/8/7 9:00:22 964] [2024-08-07 09:00:21] tuya_ipc_ai_detect.demo.c(200) <thread_ai_detect_proc>: 
[2024/8/7 9:00:22 980] [08-07 09:00:22 TUYA D][tuya_ipc_cloud_storage.c:1249] new event index 0, id: 1, added: type 0,notify type 2[1722992422-1722992722]
[2024/8/7 9:00:22 996] [08-07 09:00:22 TUYA D][tuya_ipc_cloud_storage.c:2380] add event start done, event_id 1 time 1722992422-1722992722
[2024/8/7 9:00:22 997] [08-07 09:00:22 TUYA D][tuya_ipc_notify.c:85] size:21710 type: 1
[2024/8/7 9:00:23 012] [08-07 09:00:22 TUYA D][upload_notification.c:526] notification from buffer. type:image/jpeg name:1722992422.jpeg path:2 data_len:21776
[2024/8/7 9:00:23 012] [08-07 09:00:22 TUYA D][upload_notification.c:473] cloud config 0 Not Inited
[2024/8/7 9:00:23 028] [08-07 09:00:22 TUYA D][iot_httpc.c:1161] Post Data: {"type":"Motion","t":1722992422}
[2024/8/7 9:00:23 044] [08-07 09:00:22 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992422&v=3.0&sign=c13d582fce5e4273dd5d8256175ab244
[2024/8/7 9:00:23 044] [08-07 09:00:22 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:23 060] [08-07 09:00:22 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:23 060] [08-07 09:00:22 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:23 060] [08-07 09:00:22 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:23 076] [08-07 09:00:22 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:00:23 076] [08-07 09:00:22 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:00:23 092] [08-07 09:00:22 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:23 092] [08-07 09:00:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:23 108] [08-07 09:00:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:23 108] [08-07 09:00:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:23 108] [08-07 09:00:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:23 124] [08-07 09:00:22 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:23 124] [08-07 09:00:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:23 140] [08-07 09:00:22 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:23 156] [08-07 09:00:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:23 156] [08-07 09:00:22 TUYA D][tuya_ipc_cloud_storage.c:1200] force event 0 stop done
[2024/8/7 9:00:23 172] [08-07 09:00:22 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722992422,"validTime":1800}},"t":1722992422,"success":true}
[2024/8/7 9:00:23 188] [08-07 09:00:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:23 188] [08-07 09:00:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:23 204] [08-07 09:00:22 TUYA D][iot_httpc.c:3388] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1722992422}, ret:0.
[2024/8/7 9:00:23 204] [08-07 09:00:22 TUYA D][tuya_devos_entry.c:479] timezone:+08:00
[2024/8/7 9:00:23 204] [08-07 09:00:22 TUYA D][tuya_devos_entry.c:500] summer_time_zone:[]
[2024/8/7 9:00:23 220] [08-07 09:00:22 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:00:23 220] [08-07 09:00:22 TUYA D][simplekv.c:1251] find key:12 gw_ai
[2024/8/7 9:00:23 236] [08-07 09:00:22 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544
[2024/8/7 9:00:23 236] [08-07 09:00:22 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:00:23 252] [08-07 09:00:22 TUYA D][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722992422,"validTime":1800}}.
[2024/8/7 9:00:23 252] [08-07 09:00:22 TUYA D][tuya_devos_utils.c:94] reset dp rate rule finish.
[2024/8/7 9:00:23 268] [08-07 09:00:22 TUYA D][iot_httpc.c:1161] Post Data: {"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722992422}
[2024/8/7 9:00:23 284] [08-07 09:00:22 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.ack&devId=6c98df4eddddc79e62pkva&et=1&t=1722992422&v=2.0&sign=dabe7f55e5c75912907039f1abd822e6
[2024/8/7 9:00:23 299] [08-07 09:00:22 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:23 299] [08-07 09:00:22 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:23 315] [08-07 09:00:22 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:23 316] 
[2024/8/7 9:00:23 316] [08-07 09:00:22 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:23 412] [08-07 09:00:22 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"ak":"AKIDDlblRrQAbjkOtMGjOyrPYLQREFa5qJ0QjDglf6qWes3XY3HH2DG0wkMTePe9NNRU","bucket":"ty-cn-storage30-pic-1254153901","countLeftToday":30,"endpoint":"tuyacn.com","eventSilenceInterval":120,"expiration":"2024-08-07T03:00:22Z","lifeCycle":2592000,"msgType":1,"pathConfig":{"detect":"/6e95b4-167507504-uuidcaab27b0a838d239/detect","log":"/6e95b4-167507504-uuidcaab27b0a838d239/log"},"provider":"oss","region":"cos.ap-shanghai","sk":"ON8KqY/GeR7ROufcH7TZsg5OvrlJDaSz0aYbDezXcaY=","token":"2Id6cvKHICb7BUzGQXvQGw4NBKvhteia7e6e3a0f3df96c4d0cd1f276cd5578180I3XZJs7VmIw_I39w2HmVJn6njKopqq9ZfMayhDA8xMlVizqjM-pYgcM1fq94NoZydyg26QdQKNeqNIB6XbDslCV1Dm9PuEuAp83NUq4RJ8rvCZ6wY22zX5PTX1zeG9OI0gtqcwrmGpfahcwE1b8dFxVthxUKRP2cB6HN_V5GjxTSkCAKNkDzQ5XKn86wd-m2Y5s2G_aPVMSq-cNjWy4a7uTDm5Rt_IPR2Epk9lRZmkQsjvthOWTQXsM28J13ExM5VfR0IhXmohDdrkiLI0YllTqLv-GbriynwHxpSRQ-czPRYpbOyy-KsfkjEKOog4bOouDphhGA4gsuTV6zX-pikXScn7WmI4DUZDWXpn8plDXSHM5TBFc4RXXOyFkdQyJgR-RM3CUlJ3GbtvFC0kmvbR0k
[2024/8/7 9:00:23 413] [08-07 09:00:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:23 413] [08-07 09:00:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:23 428] [08-07 09:00:22 TUYA E][cloud_operation.c:647] fail to get value for key mediaStor
[2024/8/7 9:00:23 428] [08-07 09:00:22 TUYA D][upload_notification.c:511] cloud config 0 Init Success
[2024/8/7 9:00:23 444] [08-07 09:00:22 TUYA D][cloud_operation.c:1095] Final PUT:https://ty-cn-storage30-pic-1254153901.tuyacn.com/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992422.jpeg,size 21776
[2024/8/7 9:00:23 460] [08-07 09:00:22 TUYA D][httpc.c:813] Connect: ty-cn-storage30-pic-1254153901.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:23 460] [08-07 09:00:22 TUYA D][uni_network.c:314] unw_gethostbyname ty-cn-storage30-pic-1254153901.tuyacn.com, prio 0
[2024/8/7 9:00:23 476] [08-07 09:00:22 TUYA D][uni_network.c:188] use dns service to get ip for domain ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 9:00:23 492] [08-07 09:00:22 TUYA D][iot_httpc.c:1755] dns_query:https://h2.iot-dns.com/v1/dns_query [{"domain":"ty-cn-storage30-pic-1254153901.tuyacn.com"}]
[2024/8/7 9:00:23 492] [08-07 09:00:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:23 508] [08-07 09:00:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:00:23 508] [08-07 09:00:22 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:00:23 525] [08-07 09:00:22 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:00:23 525] [08-07 09:00:22 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:23 540] [08-07 09:00:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:23 540] [08-07 09:00:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:23 556] [08-07 09:00:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:23 556] [08-07 09:00:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:23 556] [08-07 09:00:22 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:23 572] [08-07 09:00:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:23 572] [08-07 09:00:22 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:23 588] [08-07 09:00:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:23 604] [08-07 09:00:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:00:23 604] [08-07 09:00:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:23 620] [08-07 09:00:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:23 620] [08-07 09:00:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:23 636] [08-07 09:00:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:23 636] [08-07 09:00:22 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:00:23 636] [08-07 09:00:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:23 651] [08-07 09:00:22 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992422,"success":true}
[2024/8/7 9:00:23 651] [08-07 09:00:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:23 667] [08-07 09:00:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:23 667] [08-07 09:00:22 TUYA D][iot_httpc.c:2411] dynamic cfg post data:{"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722992422}, ret:0.
[2024/8/7 9:00:23 684] [2024-08-07 09:00:21] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time48892
[2024/8/7 9:00:23 700] [08-07 09:00:22 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:00:23 700] [08-07 09:00:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:23 716] [08-07 09:00:22 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:00:23 716] [08-07 09:00:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:23 716] [08-07 09:00:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:23 732] [08-07 09:00:22 TUYA D][uni_network.c:100] get ip 121.4.234.169
[2024/8/7 9:00:23 732] [08-07 09:00:22 TUYA D][uni_network.c:197] dns service get ip 121.4.234.169 for domain ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 9:00:23 748] 
[2024/8/7 9:00:23 749] [08-07 09:00:22 TUYA D][uni_network.c:268] cache dns [ty-cn-storage30-pic-1254153901.tuyacn.com]<->[121.4.234.169]
[2024/8/7 9:00:23 764] [08-07 09:00:22 TUYA D][httpc.c:477] ----got ipaddr:121,4,234,169
[2024/8/7 9:00:23 765] [08-07 09:00:22 TUYA D][httpc.c:815] Connect: ty-cn-storage30-pic-1254153901.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:23 780] [08-07 09:00:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:23 780] [08-07 09:00:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect ty-cn-storage30-pic-1254153901.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:23 796] [08-07 09:00:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:23 796] [08-07 09:00:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:23 812] [08-07 09:00:22 TUYA D][tuya_iot_com_api.c:275] third cloud url
[2024/8/7 9:00:23 813] [08-07 09:00:22 TUYA D][tuya_iot_com_api.c:147] not found third ca
[2024/8/7 9:00:23 813] [08-07 09:00:22 TUYA D][tuya_iot_com_api.c:159] require CA for url ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 9:00:23 828] [08-07 09:00:22 TUYA D][iot_httpc.c:3536] query URL:ty-cn-storage30-pic-1254153901.tuyacn.com and Parse: ty-cn-storage30-pic-1254153901.tuyacn.com 443
[2024/8/7 9:00:23 844] [08-07 09:00:22 TUYA D][iot_httpc.c:1803] HTTP_DNS_QUERY:https://h2.iot-dns.com/device/dns_query
[2024/8/7 9:00:23 860] [08-07 09:00:22 TUYA D][iot_httpc.c:1804] http_dns send:[{"host":"ty-cn-storage30-pic-1254153901.tuyacn.com","port":443,"need_ca":true,"need_ip":false}]
[2024/8/7 9:00:23 860] [08-07 09:00:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:23 876] [08-07 09:00:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:00:23 876] [08-07 09:00:22 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:00:23 892] [08-07 09:00:22 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:00:23 892] [08-07 09:00:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:00:23 892] [08-07 09:00:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:23 908] [08-07 09:00:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:23 908] [08-07 09:00:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:23 924] [08-07 09:00:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:23 924] [08-07 09:00:22 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:00:23 940] [08-07 09:00:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:23 940] [08-07 09:00:23 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:00:23 956] [08-07 09:00:23 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:23 956] [08-07 09:00:23 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:00:23 972] [08-07 09:00:23 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:23 972] [08-07 09:00:23 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:23 988] [08-07 09:00:23 TUYA D][tuya_iot_com_api.c:235] new CA stored for url ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 9:00:23 988] [08-07 09:00:23 TUYA D][tuya_iot_com_api.c:140] load ca to tls
[2024/8/7 9:00:24 004] [08-07 09:00:23 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:24 004] while(lib_ble_start) before
[2024/8/7 9:00:24 004] GAP procedure initiated: terminate connection; conn_handle=1 hci_reason=19
[2024/8/7 9:00:24 020] [08-07 09:00:23 TUYA D][tuya_tls.c:1539] handshake finish for ty-cn-storage30-pic-1254153901.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:24 036] [08-07 09:00:23 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect ty-cn-storage30-pic-1254153901.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:24 036] [2024-08-07 09:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:24 052] ble_slave_gap_event->type=14
[2024/8/7 9:00:24 052] subscribe event; conn_handle=1 attr_handle=23 reason=2 prevn=1 curn=0 previ=0 curi=0
[2024/8/7 9:00:24 052] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:00:24 068] ble_slave_gap_event->type=1
[2024/8/7 9:00:24 068] disconnect; reason=534 
[2024/8/7 9:00:24 068] [08-07 09:00:23 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:24 084] [08-07 09:00:23 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:24 100] [08-07 09:00:23 TUYA D][cloud_operation.c:1165] HTTPS PUT https://ty-cn-storage30-pic-1254153901.tuyacn.com/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992422.jpeg done,size 21776 cost 1662 ms
[2024/8/7 9:00:24 100] [08-07 09:00:23 TUYA D][upload_notification.c:554] __notification_content_upload_from_buffer success
[2024/8/7 9:00:24 116] [08-07 09:00:23 TUYA D][upload_notification.c:161] notify DP:115 timeout:5
[2024/8/7 9:00:24 116] [08-07 09:00:23 TUYA D][upload_notification.c:181] fina[atbm_log]:atbm_ioctl_ble_stop
[2024/8/7 9:00:24 131] l:{"v":"3.0","bucket":"ty-cn-storage30-pic-1254153901","files":[["/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992422.jpeg","6bb66d75bc26f11a"]]}
[2024/8/7 9:00:24 131] [08-07 09:00:23 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:00:24 147] [08-07 09:00:23 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:00:24 164] [08-07 09:00:23 TUYA D][smart_frame.c:786] Send dp:115, RAW:{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDIyLmpwZWciLCI2YmI2NmQ3NWJjMjZmMTFhIl1dfQ=="}, retrans:1
[2024/8/7 9:00:24 195] [08-07 09:00:23 TUYA D][smart_frame.c:2219] dp rept_type:1, data:{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDIyLmpwZWciLCI2YmI2NmQ3NWJjMjZmMTFhIl1dfQ=="}
[2024/8/7 9:00:24 211] [08-07 09:00:23 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDIyLmpwZWciLCI2YmI2NmQ3NWJjMjZmMTFhIl1dfQ=="}} pro:4 num:59435
[2024/8/7 9:00:24 243] [08-07 09:00:23 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992423,"data":{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDIyLmpwZWciLCI2YmI2NmQ3NWJjMjZmMTFhIl1dfQ=="}}} offset:255
[2024/8/7 9:00:24 275] [08-07 09:00:23 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDIyLmpwZWciLCI2YmI2NmQ3NWJjMjZmMTFhIl1dfQ=="}}, msg_len:218, out_len:270
[2024/8/7 9:00:24 276] [08-07 09:00:23 TUYA D][app_agent.c:600] send length:272, id:36, sequence_out:21742
[2024/8/7 9:00:24 307] [08-07 09:00:23 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:59435 Q:1 Data:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDIyLmpwZWciLCI2YmI2NmQ3NWJjMjZmMTFhIl1dfQ=="}}
[2024/8/7 9:00:24 308] [08-07 09:00:23 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:115, curr_t:1722992423, rept_cnt:1.
[2024/8/7 9:00:24 324] [08-07 09:00:23 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:115, curr_t:1722992423, rept_cnt:0.
[2024/8/7 9:00:24 339] [08-07 09:00:23 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:115, curr_t:1722992423, rept_cnt:0.
[2024/8/7 9:00:24 339] [08-07 09:00:23 TUYA D][upload_notification.c:190] notification_message_upload success
[2024/8/7 9:00:24 340] curr event:17 
[2024/8/7 9:00:24 355] IPC_APP_Notify_LED_Sound_Status_CB line(609) -------------------------- IPC_ALARM_MOTION(17)
[2024/8/7 9:00:24 356] [2024-08-07 09:00:23] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:00:24 372] [2024-08-07 09:00:23] tuya_ipc_system_control_demo.c(628) <IPC_APP_Notify_LED_Sound_Status_CB>: sirenSwitch=[0],sirenVolumn=[30]
[2024/8/7 9:00:24 372] [2024-08-07 09:00:23] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:00:24 388] [2024-08-07 09:00:23] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:24 388] [08-07 09:00:25 TUYA D][tuya_upnp_module_mg.c:1432] upnpDiscover failed
[2024/8/7 9:00:24 403] [2024-08-07 09:00:24] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:00:24 419] [2024-08-07 09:00:24] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:00:24 420] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=21.000 ms
[2024/8/7 9:00:24 420] [2024-08-07 09:00:24] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:00:24 435] <====== ble_gap_terminate(ble_conn_handle,19);
[2024/8/7 9:00:24 435] <====== ble_smart_cfg_task end step 0
[2024/8/7 9:00:24 436] [2024-08-07 09:00:25] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time52918
[2024/8/7 9:00:24 451] exit ble process
[2024/8/7 9:00:24 451] ble_hs_hci_cmd_reset
[2024/8/7 9:00:24 452] cli_free before
[2024/8/7 9:00:24 452] nimble_port_atbmos_free before
[2024/8/7 9:00:24 452] nimble_port_release before
[2024/8/7 9:00:24 452] ble_gap_free before
[2024/8/7 9:00:24 452] ble_hs_hci_free before
[2024/8/7 9:00:24 467] ble_hs_free before
[2024/8/7 9:00:24 468] ble_hs_free after
[2024/8/7 9:00:24 468] nimble_release after
[2024/8/7 9:00:24 468] ble_smart_cfg_exit before
[2024/8/7 9:00:24 468] ble_smart_cfg_exit after
[2024/8/7 9:00:24 468] atbm_stopThread after
[2024/8/7 9:00:24 483] [08-07 09:00:26 TUYA D][iot_httpc.c:1161] Post Data: {"subId":null,"t":1722992426}
[2024/8/7 9:00:24 499] [08-07 09:00:26 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upgrade.silent.get&devId=6c98df4eddddc79e62pkva&et=1&t=1722992426&v=4.4&sign=c0453843b07536bb5482f41b95227a9f
[2024/8/7 9:00:24 500] [08-07 09:00:26 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:24 515] [08-07 09:00:26 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:24 516] [08-07 09:00:26 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:24 531] [08-07 09:00:26 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:24 532] [08-07 09:00:26 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:24 532] [08-07 09:00:26 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:24 547] [08-07 09:00:26 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:24 547] [08-07 09:00:26 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:24 564] [08-07 09:00:26 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:24 564] [08-07 09:00:26 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:24 579] [08-07 09:00:26 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:24 579] [08-07 09:00:27 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:24 595] [08-07 09:00:27 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:24 611] [08-07 09:00:27 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992427 28800
[2024/8/7 9:00:24 611] [08-07 09:00:27 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992427 28800
[2024/8/7 9:00:24 627] [08-07 09:00:27 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992427,"success":true}
[2024/8/7 9:00:24 627] [08-07 09:00:27 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:24 627] [08-07 09:00:27 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:24 643] [08-07 09:00:27 TUYA E][tuya_svc_upgrade.c:436] result null
[2024/8/7 9:00:24 643] [08-07 09:00:27 TUYA D][tuya_svc_upgrade.c:511] silent get firmware fail
[2024/8/7 9:00:24 643] [08-07 09:00:27 TUYA D][tuya_svc_upgrade.c:205] next detect timer: 21600s
[2024/8/7 9:00:24 659] [08-07 09:00:27 TUYA N][tuya_svc_timer_task.c:796] Update Timer from cloud
[2024/8/7 9:00:24 675] [08-07 09:00:27 TUYA D][iot_httpc.c:1161] Post Data: {"devId":"6c98df4eddddc79e62pkva","lastFetchTime":"0","t":1722992427}
[2024/8/7 9:00:24 691] [08-07 09:00:27 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.timer.count&devId=6c98df4eddddc79e62pkva&et=1&t=1722992427&v=4.2&sign=5b9effd2e03ca24ba2c91cea4a1c4789
[2024/8/7 9:00:24 691] [08-07 09:00:27 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:00:24 691] [08-07 09:00:27 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:00:24 707] 
[2024/8/7 9:00:24 709] [08-07 09:00:27 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:00:24 709] [08-07 09:00:27 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:00:24 724] [08-07 09:00:27 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:00:24 724] [08-07 09:00:27 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:00:24 739] [08-07 09:00:27 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:00:24 739] [08-07 09:00:27 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:00:24 756] [08-07 09:00:27 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:00:24 756] [08-07 09:00:27 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:00:24 772] [08-07 09:00:27 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:00:24 772] [08-07 09:00:27 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:00:24 788] [08-07 09:00:27 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:00:24 804] [08-07 09:00:27 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"code":"200","count":0,"devId":"6c98df4eddddc79e62pkva","lastFetchTime":0},"t":1722992427,"success":true}
[2024/8/7 9:00:24 804] [08-07 09:00:27 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:24 820] [08-07 09:00:27 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:24 820] [08-07 09:00:27 TUYA D][tuya_svc_timer_task.c:451] time eq skip:0
[2024/8/7 9:00:25 013] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:00:25 013] Mode(Product):0
[2024/8/7 9:00:25 013] BpuMode:[Online]
[2024/8/7 9:00:25 013] VpssMode:[Online]
[2024/8/7 9:00:25 013] [0.LimitUp_info]:
[2024/8/7 9:00:25 013] LimitUp:[Disable]
[2024/8/7 9:00:25 013] [2680*0]->[3840*0])
[2024/8/7 9:00:25 013] chn	TotalSize	ActiveSize
[2024/8/7 9:00:25 013] 0	5040*2246	2680*2160
[2024/8/7 9:00:25 028] 0	5040*2246	2680*2160
[2024/8/7 9:00:25 028] 0	5040*2246	3840*2160
[2024/8/7 9:00:25 028] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:00:25 028] [1.VICU_info]:
[2024/8/7 9:00:25 028] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:00:25 028] 0	25.0	1147	0	0	183	linear	8ddb00
[2024/8/7 9:00:25 028] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:00:25 043] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:00:25 043] en	op_type	m_chn	now
[2024/8/7 9:00:25 043] 0	1	1	1
[2024/8/7 9:00:25 043] [2.VI_info]:
[2024/8/7 9:00:25 043] chn	TotalSize	ActiveSize
[2024/8/7 9:00:25 043] 0	5040*2246	3848*2166
[2024/8/7 9:00:25 043] 1	   0*   0	   0*   0
[2024/8/7 9:00:25 043] [3.MIPI_info]:
[2024/8/7 9:00:25 060] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:00:25 060] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:00:25 060] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:00:25 060] [4.Cut_info]:
[2024/8/7 9:00:25 075] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:00:25 075] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:00:25 075] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:00:25 075] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:00:25 075] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:00:25 075] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:00:25 091] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:00:25 091] [5.IB(isp buffer info)]:
[2024/8/7 9:00:25 091] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:00:25 091] PoolId  Count  Size
[2024/8/7 9:00:25 107] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:25 107] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:25 123] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:25 123] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:25 123] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:25 139] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:25 139] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:00:25 139] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:00:25 155] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:00:25 155] 0       0         0          0          4       
[2024/8/7 9:00:25 155] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:00:25 171]      --265--            --264--                                               
[2024/8/7 9:00:25 171] Count      Line     Count      Line     
[2024/8/7 9:00:25 171] 915        480      2074       560      
[2024/8/7 9:00:25 187] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:00:25 187] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:00:25 203] 0   3840   2160    H265  0      0        0           539       983038     2        	
[2024/8/7 9:00:25 203] 1   640    360     H265  0      0        0           364       43194      6        	
[2024/8/7 9:00:25 220] 3   640    360     JPEG  0      0        0           1         172799     1        	
[2024/8/7 9:00:25 220] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:00:25 236] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:00:25 252] 0   Y      539      0       0       15       0        539      539      751       64198         59046    158034   65156    12      
[2024/8/7 9:00:25 252] 1   Y      364      0       11      1        0        364      364      751       3179          1883     88670    3134     9       
[2024/8/7 9:00:25 268] 3   N      1        0       0       1        0        1        1        755       1841          1841     1841     1841     0       
[2024/8/7 9:00:26 036] [2024-08-07 09:00:26] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:00:26 052] [2024-08-07 09:00:26] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:00:26 068] [2024-08-07 09:00:27] tuya_ipc_ai_detect.demo.c(371) <thread_ai_detect_proc>: 
[2024/8/7 9:00:26 068] [2024-08-07 09:00:27] xm_main.c(1810) <XM_GetCatchJpgStream>: 
[2024/8/7 9:00:26 068] [2024-08-07 09:00:27] xm_main.c(1813) <XM_GetCatchJpgStream>: 
[2024/8/7 9:00:26 084] [2024-08-07 09:00:27] xm_main.c(1833) <XM_GetCatchJpgStream>: 
[2024/8/7 9:00:26 084] [08-07 09:00:28 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 9:00:29 411] [2024-08-07 09:00:29] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time56892
[2024/8/7 9:00:29 411] [2024-08-07 09:00:29] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:29 427] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:2
[2024/8/7 9:00:29 444] [08-07 09:00:31 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"devId":"6c98df4eddddc79e62pkva","gwId":"6c98df4eddddc79e62pkva"},"protocol":11,"s":1785858,"t":1722992432}
[2024/8/7 9:00:29 444] [08-07 09:00:31 TUYA D][mqtt_client.c:916] disconnect mqtt
[2024/8/7 9:00:29 571] [08-07 09:00:32 TUYA E][app_agent.c:1479] close socket,errno:-100 errno:0
[2024/8/7 9:00:29 571] [08-07 09:00:32 TUYA D][app_agent.c:213] set socket fault 36
[2024/8/7 9:00:29 587] [08-07 09:00:32 TUYA D][app_agent.c:274] i:0,time:1722992432,c_time:1722992427,fault:1
[2024/8/7 9:00:29 587] [08-07 09:00:32 TUYA D][app_agent.c:163] close socket 36
[2024/8/7 9:00:29 763] [08-07 09:00:32 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:00:29 779] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:00:29 779] [08-07 09:00:32 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:00:29 796] [08-07 09:00:32 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:00:29 796] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:00:29 812] [08-07 09:00:32 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:00:29 812] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:29 828] [08-07 09:00:32 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:00:29 828] [08-07 09:00:32 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:00:29 907] [08-07 09:00:32 TUYA D][gw_mqc_cb.c:60] unactive
[2024/8/7 9:00:29 907] [08-07 09:00:32 TUYA E][mqtt_client.c:1652] mq_recv err:-30848 len:0
[2024/8/7 9:00:29 923] [08-07 09:00:32 TUYA D][tuya_devos_reset.c:418] unactive Reset
[2024/8/7 9:00:29 923] [08-07 09:00:32 TUYA D][tuya_devos_reset.c:261] gw reset called. tp:1 stat:1
[2024/8/7 9:00:29 939] __IPC_APP_Get_Net_Status_cb line(183) -------------------------- stat(0)==STAT_LOW_POWER 
[2024/8/7 9:00:29 939] [08-07 09:00:32 TUYA D][tuya_devos_reset.c:85] <__wf_reset> nc_tp:2, rst_tp:1, wifi_start_mode:0
[2024/8/7 9:00:29 955] [08-07 09:00:32 TUYA D][tuya_devos_reset.c:325] <__gw_reset> tuya_ble_clear_mesh
[2024/8/7 9:00:29 956] [08-07 09:00:32 TUYA D][tuya_ble_api.c:1050] start to clr appkey.
[2024/8/7 9:00:29 956] [08-07 09:00:32 TUYA D][simplekv.c:1348] delete key:ble_app_key isFuzzy:0
[2024/8/7 9:00:29 971] [08-07 09:00:32 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:00:29 971] [08-07 09:00:32 TUYA D][simplekv.c:1386] delete key find 4
[2024/8/7 9:00:29 971] [08-07 09:00:32 TUYA D][simplekv.c:1424] Delete key:ble_app_key 4 success
[2024/8/7 9:00:29 987] [08-07 09:00:32 TUYA D][simplekv.c:203] update crc 1620934922
[2024/8/7 9:00:29 987] [08-07 09:00:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:29 987] [08-07 09:00:32 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:00:30 003] [08-07 09:00:32 TUYA D][tuya_ble_api.c:1058] start to clr network_key.
[2024/8/7 9:00:30 003] [08-07 09:00:32 TUYA D][simplekv.c:1348] delete key:ble_network_key isFuzzy:0
[2024/8/7 9:00:30 019] [08-07 09:00:32 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:00:30 019] [08-07 09:00:32 TUYA D][simplekv.c:1386] delete key find 13
[2024/8/7 9:00:30 020] [08-07 09:00:32 TUYA D][simplekv.c:1424] Delete key:ble_network_key 13 success
[2024/8/7 9:00:30 035] [08-07 09:00:32 TUYA D][simplekv.c:203] update crc 490206356
[2024/8/7 9:00:30 035] [08-07 09:00:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:30 051] [08-07 09:00:32 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:00:30 051] [08-07 09:00:32 TUYA D][tuya_ble_api.c:1035] start to clr beaconkey.
[2024/8/7 9:00:30 051] [08-07 09:00:32 TUYA D][simplekv.c:1348] delete key:ble_beaconkey isFuzzy:0
[2024/8/7 9:00:30 067] [08-07 09:00:32 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:00:30 067] [08-07 09:00:32 TUYA D][simplekv.c:1386] delete key find 14
[2024/8/7 9:00:30 083] [08-07 09:00:32 TUYA D][simplekv.c:1424] Delete key:ble_beaconkey 14 success
[2024/8/7 9:00:30 084] [08-07 09:00:32 TUYA D][simplekv.c:203] update crc 1134430622
[2024/8/7 9:00:30 084] [08-07 09:00:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:30 103] [08-07 09:00:32 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:00:30 115] [08-07 09:00:32 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":1,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:00:30 115] [08-07 09:00:32 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:00:30 115] [08-07 09:00:32 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:00:30 131] [08-07 09:00:32 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:176
[2024/8/7 9:00:30 131] [08-07 09:00:32 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:00:30 147] [08-07 09:00:32 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:00:30 147] [08-07 09:00:32 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:00:30 147] [08-07 09:00:32 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:00:30 163] [08-07 09:00:32 TUYA D][simplekv.c:203] update crc 913212372
[2024/8/7 9:00:30 163] [08-07 09:00:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:30 163] [08-07 09:00:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:30 179] [08-07 09:00:32 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:00:30 179] [08-07 09:00:32 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:00:30 195] [08-07 09:00:32 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[2024/8/7 9:00:30 195] [08-07 09:00:32 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[2024/8/7 9:00:30 211] [08-07 09:00:32 TUYA D][tuya_svc_timer_task.c:107] reset. [atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:00:30 211] write_disk:1
[2024/8/7 9:00:30 211] [08-07 09:00:32 TUYA D][tuya_svc_timer_task.c:310] max len:128
[2024/8/7 9:00:30 211] [08-07 09:00:32 TUYA D][tuya_svc_timer_task.c:378] offset:27
[2024/8/7 9:00:30 227] [08-07 09:00:32 TUYA D][tuya_svc_timer_task.c:397] save TIMER:{"l[atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:00:30 227] astFetchTime":0,[atbm_log]:aggtx stop queue
[2024/8/7 9:00:30 227] "cnt":0}
[2024/8/7 9:00:30 243] [08-0[atbm_log]:add to pending(0)(20)
[2024/8/7 9:00:30 243] 7 09:00:32 TUYA [atbm_log]:AMPDU[eth2]:action[2],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:30 243] D][simplekv.c:12[atbm_log]:activated addBA response timer on tid 6
[2024/8/7 9:00:30 259] 11] read key:tim[atbm_log]:ignore pending[5][20]
[2024/8/7 9:00:30 259] er_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:00:30 259] [08[atbm_log]:aggtx wake queue
[2024/8/7 9:00:30 259] -07 09:00:32 TUY[atbm_log]:not assoc 
[2024/8/7 9:00:30 275] A D][simplekv.c:1247] no[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:00:30 275]  key find
[2024/8/7 9:00:30 275] [08-07 09:00:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:30 291] [08-07 09:00:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:30 291] [08-07 09:00:32 TUYA D][simplekv.c:374] write key:timer_arr And Value Len:32
[2024/8/7 9:00:30 307] [08-07 09:00:32 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 32
[2024/8/7 9:00:30 308] [08-07 09:00:32 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:00:30 308] [08-07 09:00:32 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:00:30 323] [08-07 09:00:32 TUYA D][simplekv.c:203] update crc 3368977106
[2024/8/7 9:00:30 323] [08-07 09:00:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:30 323] [08-07 09:00:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:30 339] [08-07 09:00:32 TUYA D][simplekv.c:1348] delete key:last_reset_info isFuzzy:0
[2024/8/7 9:00:30 339] [08-07 09:00:32 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:00:30 355] [08-07 09[atbm_log]:AMPDU[eth2]:action[3],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:30 355] :00:32 TUYA D][s[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:00:30 372] implekv.c:1395] [atbm_log]:AMPDU[eth2]:action[1],tid[0],ssn[0],buff_size[0],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:30 372] key:last_reset_info not find
[2024/8/7 9:00:30 372] [08-07 09:00:32 T[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 5
[2024/8/7 9:00:30 387] UYA D][tuya_ipc_[atbm_log]:AMPDU[eth2]:action[1],tid[5],ssn[0],buff_size[0],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:30 387] p2p_common.c:488] __begin
[2024/8/7 9:00:30 387] [08-[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:00:30 404] 07 09:00:32 TUYA[atbm_log]:AMPDU[eth2]:action[3],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:30 419]  D][simplekv.c:1[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:00:30 419] 211] read key:p2[atbm_log]:AMPDU[eth2]:action[1],tid[6],ssn[0],buff_size[0],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:30 419] p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:00:30 435] [08-07 09:00:32 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:00:30 435] [08-07 09:00:32 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:00:30 451] [08-07 09:00:32 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:00:30 451] [08-07 09:00:32 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 16
[2024/8/7 9:00:30 451] [08-07 09:00:32 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:00:30 468] [08-07 09:00:32 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:00:30 468] [08-07 09:00:32 TUYA D][simplekv.c:203] update crc 2085768099
[2024/8/7 9:00:30 468] [08-07 09:00:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:30 484] [08-07 09:00:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:30 484] [08-07 09:00:32 TUYA D][simplekv.c:121[atbm_log]:eth2: deauthenticating from a4:a9:30:ce:5e:66 by local choice (reason=3)
[2024/8/7 9:00:30 500] 1] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:00:30 500] [08-07 09:00:32 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:00:30 500] [08-07 09:00:32 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:00:30 516] [08-07 09:00:32 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:00:30 516] [08-07 09:00:32 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:00:30 531] [08-07 09:00:32 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:00:30 531] [08-07 09:00:32 TUYA D][simplekv.c:474] reuse available space 3026[atbm_log]:[TX]:[0]:deatuhen[a4:a9:30:ce:5e:66]
[2024/8/7 9:00:30 531] 0
[2024/8/7 9:00:30 547] [08-07 09:00:32 TUYA[atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:00:30 547]  D][simplekv.c:203] update crc 3484288763
[2024/8/7 9:00:30 547] [08-07 09:00:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:30 563] [08-07 09:00:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:30 563] [08-07 09:00:32 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:00:30 563] [08-07 09:00:32 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:00:30 579] [08-07 09:00:32 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:00:30 579] [08-07 09:00:32 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:00:30 595] [08-07 09:00:32 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:00:30 595] [08-07 09:00:32 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:00:30 595] [08-07 09:00:32 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:00:30 612] [08-07 09:00:32 TUYA D][simplekv.c:203] update crc 2354220241
[2024/8/7 9:00:30 612] [08-07 09:00:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:30 612] [08-07 09:00:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:30 628] IPC_APP_Reset_System_CB line(143) -------------------------- 
[2024/8/7 9:00:30 628] [08-07 09:00:32 TUYA N][mqtt_client.c:1703] mqtt close
[2024/8/7 9:00:30 628] [08-07 09:00:32 TUYA N][mqtt_client.c:839] close mqtt -->>
[2024/8/7 9:00:30 643] [08-07 09:00:32 TUYA D][mqtt_client.c:851] shutdown fd enabled
[2024/8/7 9:00:30 643] [08-07 09:00:32 [atbm_log]:[STA]:unjoin ++
[2024/8/7 9:00:30 643] TUYA E][log_seq.c:152] ret:-1027[atbm_log]:[STA]:unjoin --
[2024/8/7 9:00:30 659] [08-07 09:00:32 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:00:30 659] [08-07 09:00:32 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:00:30 659] [08-07 09:00:32 TUYA N][mqtt_client.c:886] close mqtt <<--
[2024/8/7 9:00:30 675] [08-07 09:00:32 TUYA D][mqtt_client.c:1720] mqtt fail_cnt:1, sleeptime:6130 ms
[2024/8/7 9:00:30 675] rm: can't remove '/mnt/mtd/Config/localtime': Device or resource busy
[2024/8/7 9:00:30 691] rm: can't remove '/mnt/mtd/Config/resolv.conf': Device or resource busy
[2024/8/7 9:00:30 691] rm: can't remove '/mnt/mtd/Config': Directory not empty
[2024/8/7 9:00:30 691] [atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:00:30 755] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:00:32 212] [2024-08-07 09:00:31] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:31] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:00:32 212] set basic_indicator_onoff:0 
[2024/8/7 9:00:32 228] [2024-08-07 09:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:32 228] [2024-08-07 09:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:32 244] [2024-08-07 09:00:31] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:31] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:00:32 275] [2024-08-07 09:00:32] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:32] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:00:32 291] [2024-08-07 09:00:32] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:32] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:00:32 307] [2024-08-07 09:00:32] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:32] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:00:32 323] [2024-08-07 09:00:32] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:32] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:00:32 339] [2024-08-07 09:00:32] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:32] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:00:32 355] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(150): cmd=[killall wpa_supplicant udhcpc;ifconfig eth2 down;ifconfig eth0 down;]
[2024/8/7 9:00:32 356] curr event:13 
[2024/8/7 9:00:32 371] IPC_APP_Notify_LED_Sound_Status_CB line(583) -------------------------- IPC_RESET_SUCCESS(13)
[2024/8/7 9:00:32 387] [2024-08-07 09:00:32] tuya_ipc_system_control_demo.c(585) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(RESET, 0, 1, 0, 1))
[2024/8/7 9:00:32 387] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(155):  ---
[2024/8/7 9:00:32 403] [2024-08-07 09:00:32] xm_main.c(2440) <XMSDK_SystemRebootTY>: XMSDK_MotorGetPostion(3110,0) suc
[2024/8/7 9:00:32 403] [2024-08-07 09:00:32] xm_main.c(2064) <XM_SaveLocalPtzPosition>: Save PTZ xPosition 3110 failed
[2024/8/7 9:00:32 419] [2024-08-07 09:00:32] xm_main.c(2445) <XMSDK_SystemRebootTY>: XM_SaveLocalPtzPosition(3110,0) failed,ret=[-1]
[2024/8/7 9:00:32 419] XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:00:32 435] [2024-08-07 09:00:32] xm_main.c(2454) <XMSDK_SystemRebootTY>: XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:00:32 435] [2024-08-07 09:00:32] ==> XMSDK_SystemReboot(198)[INFO]: Sys XMSDK_SystemReboot Reboot
[2024/8/7 9:00:32 451] [2024-08-07 09:00:32] ==> XMSDK_SystemReboot(199)[INFO]: Sys Will Reboot
[2024/8/7 9:00:32 467] [2024-08-07 09:00:32] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/Reset_english.pcm]
[2024/8/7 9:00:32 467] [2024-08-07 09:00:32] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:00:32 483] [2024-08-07 09:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:00:32 499] [2024-08-07 09:00:32] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:32] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:00:32 499] set basic_indicator_onoff:0 
[2024/8/7 9:00:32 515] [2024-08-07 09:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:00:32 515] [2024-08-07 09:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:00:32 531] [2024-08-07 09:00:32] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:32 531] [2024-08-07 09:00:33] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time60994
[2024/8/7 9:00:32 547] [08-07 09:00:34 TUYA D][tuya_ble_api.c:1426] cloud disconnected, start adv!
[2024/8/7 9:00:32 547] [08-07 09:00:34 TUYA I][bt_ext_porting.c:628] [TUYA-BTUART]start_adv
[2024/8/7 9:00:32 547] --- tracepoint bt_ext_porting.c,tuya_ext_bt_start_adv(629): start_adv ---
[2024/8/7 9:00:32 563] [08-07 09:00:34 TUYA D][tuya_ble_api.c:1376] nw stat change:2->0, rpt to app.
[2024/8/7 9:00:32 563] [08-07 09:00:34 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:00:33 059] g_AudioTipsList.size() enable: 0[2024-08-07 09:00:34] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:00:34] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [MotionDetect] pNumber[SirenSwitch]!
[2024/8/7 9:00:33 059] [08-07 09:00:35 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:00:34 003] [2024-08-07 09:00:34] xm_musicPlayer.cpp(177) <PlayAudioTips>: match reset audio
[2024/8/7 9:00:34 019] [08-07 09:00:36 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 9:00:34 531] [2024-08-07 09:00:35] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:34 531] [08-07 09:00:37 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992437 28800
[2024/8/7 9:00:34 547] [08-07 09:00:37 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992437 28800
[2024/8/7 9:00:36 051] xmsfc_shutdown 2 2 
[2024/8/7 9:00:36 051] Restarting system.
[2024/8/7 9:00:36 099] 
[2024/8/7 9:00:36 100] 
[2024/8/7 9:00:36 100] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 9:00:36 100] CPU: XM550V200WX2
[2024/8/7 9:00:36 100] DRAM:  128 MiB
[2024/8/7 9:00:36 226] MMC:   arasan: 0
[2024/8/7 9:00:36 275] In:    serial
[2024/8/7 9:00:36 275] Out:   serial
[2024/8/7 9:00:36 275] Err:   serial
[2024/8/7 9:00:36 498] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 9:00:36 499] Press Ctrl+C to stop autoboot
[2024/8/7 9:00:36 899] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 9:00:36 915] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 9:00:36 915]    Image Name:   Linux-3.10.103+
[2024/8/7 9:00:36 915]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 9:00:36 916]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 9:00:36 931]    Load Address: 80008000
[2024/8/7 9:00:36 931]    Entry Point:  80008000
[2024/8/7 9:00:36 931]    XIP Kernel Image ... OK
[2024/8/7 9:00:36 931] Starting kernel ...
[2024/8/7 9:00:37 811] Uncompressing Linux... done, booting the kernel.
[2024/8/7 9:00:37 955] Booting Linux on physical CPU 0x0
[2024/8/7 9:00:37 955] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 9:00:37 971] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 9:00:37 971] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 9:00:37 971] Machine: xm530v200
[2024/8/7 9:00:37 987] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 9:00:37 987] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 9:00:37 987] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 9:00:38 003] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 9:00:38 019] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 9:00:38 019] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 9:00:38 019] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 9:00:38 019] Memory: 52MB = 52MB total
[2024/8/7 9:00:38 035] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 9:00:38 035] Virtual kernel memory layout:
[2024/8/7 9:00:38 035]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 9:00:38 035]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 9:00:38 051]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 9:00:38 051]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 9:00:38 051]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 9:00:38 067]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 9:00:38 069]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 9:00:38 069]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 9:00:38 069]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 9:00:38 083] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 9:00:38 083] Hierarchical RCU implementation.
[2024/8/7 9:00:38 083] NR_IRQS:128
[2024/8/7 9:00:38 083] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 9:00:38 099] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 9:00:38 099] pid_max: default: 32768 minimum: 301
[2024/8/7 9:00:38 099] Mount-cache hash table entries: 512
[2024/8/7 9:00:38 099] CPU: Testing write buffer coherency: ok
[2024/8/7 9:00:38 114] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 9:00:38 115] L310 cache controller enabled
[2024/8/7 9:00:38 115] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 9:00:38 115] CPU1: Booted secondary processor
[2024/8/7 9:00:38 115] Brought up 2 CPUs
[2024/8/7 9:00:38 130] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 9:00:38 131] CPU: All CPU(s) started in SVC mode.
[2024/8/7 9:00:38 131] NET: Registered protocol family 16
[2024/8/7 9:00:38 131] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 9:00:38 147] Serial: AMBA PL011 UART driver
[2024/8/7 9:00:38 147] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 9:00:38 147] console [ttyAMA0] enabled
[2024/8/7 9:00:38 162] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 9:00:38 163] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 9:00:38 178] bio: create slab <bio-0> at 0
[2024/8/7 9:00:38 195] usbcore: registered new interface driver usbfs
[2024/8/7 9:00:38 195] usbcore: registered new interface driver hub
[2024/8/7 9:00:38 195] usbcore: registered new device driver usb
[2024/8/7 9:00:38 210] Switching to clocksource arm_global_timer
[2024/8/7 9:00:38 211] NET: Registered protocol family 2
[2024/8/7 9:00:38 211] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:00:38 226] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:00:38 226] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 9:00:38 226] TCP: reno registered
[2024/8/7 9:00:38 227] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:00:38 242] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:00:38 242] NET: Registered protocol family 1
[2024/8/7 9:00:38 242] RPC: Registered named UNIX socket transport module.
[2024/8/7 9:00:38 242] RPC: Registered udp transport module.
[2024/8/7 9:00:38 259] RPC: Registered tcp transport module.
[2024/8/7 9:00:38 259] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 9:00:38 274] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 9:00:38 274] NFS: Registering the id_resolver key type
[2024/8/7 9:00:38 290] Key type id_resolver registered
[2024/8/7 9:00:38 290] Key type id_legacy registered
[2024/8/7 9:00:38 290] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 9:00:38 290] fuse init (API version 7.22)
[2024/8/7 9:00:38 307] msgmni has been set to 95
[2024/8/7 9:00:38 307] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 9:00:38 307] io scheduler noop registered
[2024/8/7 9:00:38 323] io scheduler deadline registered (default)
[2024/8/7 9:00:38 323] io scheduler cfq registered
[2024/8/7 9:00:38 323] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 9:00:38 339] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 9:00:38 339] uart-pl011 uart:0: no DMA platform data
[2024/8/7 9:00:38 339] uart-pl011 uart:1: no DMA platform data
[2024/8/7 9:00:38 339] uart-pl011 uart:2: no DMA platform data
[2024/8/7 9:00:38 355] brd: module loaded
[2024/8/7 9:00:38 371] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 9:00:38 371] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:00:38 387] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 9:00:38 388] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 9:00:38 388] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 9:00:38 388] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 9:00:38 403] 0x000000300000-0x000000730000 : "user"
[2024/8/7 9:00:38 403] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 9:00:38 403] PPP generic driver version 2.4.2
[2024/8/7 9:00:38 403] NET: Registered protocol family 24
[2024/8/7 9:00:38 419] usbcore: registered new interface driver asix
[2024/8/7 9:00:38 419] usbcore: registered new interface driver cdc_ether
[2024/8/7 9:00:38 419] usbcore: registered new interface driver rndis_host
[2024/8/7 9:00:38 435] XMMMAC driver:
[2024/8/7 9:00:38 436] 	platform registration... 
[2024/8/7 9:00:38 436] 	done!
[2024/8/7 9:00:38 436] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 9:00:38 436] 	IO base addr: 0xfe010000)
[2024/8/7 9:00:38 436] libphy: XMMMAC MII Bus: probed
[2024/8/7 9:00:38 450] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 9:00:38 450] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 9:00:38 450] usbcore: registered new interface driver cdc_acm
[2024/8/7 9:00:38 466] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 9:00:38 466] usbcore: registered new interface driver usbserial
[2024/8/7 9:00:38 466] usbcore: registered new interface driver option
[2024/8/7 9:00:38 482] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 9:00:38 482] usbcore: registered new interface driver qcserial
[2024/8/7 9:00:38 482] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 9:00:38 482] TCP: cubic registered
[2024/8/7 9:00:38 498] NET: Registered protocol family 17
[2024/8/7 9:00:38 498] Key type dns_resolver registered
[2024/8/7 9:00:38 499] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 9:00:38 514] registered taskstats version 1
[2024/8/7 9:00:38 515] VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 9:00:38 531] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 9:00:38 866] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 9:00:39 428] arasan_set_clock:
[2024/8/7 9:00:39 443] 	new freq 400000
[2024/8/7 9:00:39 446] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 9:00:39 459] arasan_set_clock:
[2024/8/7 9:00:39 506] 	new freq 300000arasan_set_clock:
[2024/8/7 9:00:39 522] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 9:00:39 522] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 9:00:39 538] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 9:00:39 538] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 9:00:39 538] [reg] = 0x20000078,[val]= 0xc103c0ff
[2024/8/7 9:00:39 538] [reg] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 9:00:39 538] [reg] = 0x20000000,[val]= 0x00arasan_set_clock:
[2024/8/7 9:00:39 554] 	new freq 195312000000
[2024/8/7 9:00:39 554] [reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 9:00:39 554] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 9:00:39 554] [reg] = 0x200505f0,[val]= 0x00000001i2c: module license 'Proprietary' taints kernel.
[2024/8/7 9:00:39 555] 
[2024/8/7 9:00:39 570] Disabling lock debugging due to kernel taint
[2024/8/7 9:00:39 570] i2c init is ok!
[2024/8/7 9:00:39 586] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 9:00:39 698] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 9:00:39 779] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 9:00:39 795] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 9:00:39 811] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 9:00:39 827] acodec init is ok!
[2024/8/7 9:00:39 842] i2s clk:2048000Hz
[2024/8/7 9:00:40 003] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 9:00:40 003] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 9:00:40 003] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 9:00:40 003] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 9:00:40 019] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 9:00:40 019] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 9:00:40 019] usb usb1: Product: DWC OTG Controller
[2024/8/7 9:00:40 035] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 9:00:40 035] usb usb1: SerialNumber: dwc2.0
[2024/8/7 9:00:40 035] hub 1-0:1.0: USB hub found
[2024/8/7 9:00:40 035] hub 1-0:1.0: 1 port detected
[2024/8/7 9:00:40 083] xm_wdt init is ok
[2024/8/7 9:00:40 099] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 9:00:40 403] nn_kernel: NN: request mem  fail
[2024/8/7 9:00:40 403] nn_kernel: addr iomap fail
[2024/8/7 9:00:40 451] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 9:00:40 723] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 9:00:40 915] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:00:40 930] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:00:40 930] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:00:40 931] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:00:41 027] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtusbwifi_init.
[2024/8/7 9:00:41 027] d/user.sh: not found
[2024/8/7 9:00:41 043] PDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 9:00:41 059] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 9:00:41 090] exfatfsck 1.3.0
[2024/8/7 9:00:41 090] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:00:41 106] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:00:41 122] usb 1-1: USB disconnect, device number 3
[2024/8/7 9:00:43 043] ouput high and delay 2000ms
[2024/8/7 9:00:43 138] Auto login as root ...
[2024/8/7 9:00:43 170] (none) login: not found /dev/mmcxxx  
[2024/8/7 9:00:43 186] Tcp server success, Wait connet ...
[2024/8/7 9:00:43 202] macGuarder: Get telnetctrl Fialed, telnetctrl=0
[2024/8/7 9:00:43 219] macGuarder: Close telnetd Forever 
[2024/8/7 9:00:43 219] Get xmauto Fialed ,xmauto = 1
[2024/8/7 9:00:43 219] auto start to app 
[2024/8/7 9:00:43 475] usb 1-1: new high-speed USB device number 4 using dwc2
[2024/8/7 9:00:43 683] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:00:43 699] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:00:43 699] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:00:43 699] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:00:45 074] [atbm_log]:atbm_usb_module_init 0
[2024/8/7 9:00:45 090] [atbm_log]:platform_init(253)
[2024/8/7 9:00:45 090] [atbm_log]:SVN_VER=33341,DPLL_CLOCK=1,BUILD_TIME=[2024-04-03_14:40:53]
[2024/8/7 9:00:45 090] [atbm_log]:Probe called -1 v1
[2024/8/7 9:00:45 106] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[2024/8/7 9:00:45 106] [atbm_log]:CONFIG_TX_NO_CONFIRM
[2024/8/7 9:00:45 106] wiphy_new_nm support CONFIG_WIRELESS_EXT 
[2024/8/7 9:00:45 106] [atbm_log]:Allocated hw_priv @ c27cd960
[2024/8/7 9:00:45 122] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[2024/8/7 9:00:45 138] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c27cd960)
[2024/8/7 9:00:45 138] [atbm_log]:not support ldpc & ht40!
[2024/8/7 9:00:45 154] [atbm_log]:atbm_get_chiptype, chipver=0x5a, g_wifi_chip_type[14]
[2024/8/7 9:00:45 154] [atbm_log]:atbm_before_load_firmware++
[2024/8/7 9:00:45 154] [atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[2024/8/7 9:00:45 154] [[atbm_log]:===================~_~====================
[2024/8/7 9:00:45 170] 1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseExVb(526)[ERROR]: Get Vb object error!
[2024/8/7 9:00:45 170] [1970-01-[atbm_log]:atbm_start_load_firmware++
[2024/8/7 9:00:45 186] 01 00:00:07] <xmfwhdr->flags 34353678 sram_addr 9022000
[2024/8/7 9:00:45 186] _system.c> ==> X[atbm_log]:
[2024/8/7 9:00:45 186] ======>>> load WIFI BLE COMB firmware <<<======
[2024/8/7 9:00:45 202] MSDK_ParseJson(4[atbm_log]:START DOWNLOAD ICCM=========
[2024/8/7 9:00:45 202] 8)[ERROR]: Parse[atbm_log]:atbm_load_firmware_generic: addr 60000: len 20000
[2024/8/7 9:00:45 202]  Vb Failed!
[2024/8/7 9:00:45 218] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(452)[ERROR]: Get Isp object u32Flag error set value 1!
[2024/8/7 9:00:45 218] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(464)[ERROR]: Get Isp object u32Others error set value 0!
[2024/8/7 9:00:45 234] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(476)[ERROR]: Get Isp object CmosPort error set value 0!
[2024/8/7 9:00:45 250] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(488)[ERROR]: Get Isp object splice_mode error set value 0!
[2024/8/7 9:00:45 250] [1970-01-01 00:00:06] MainApp.c(1802) <main>: build @Jul 31 2024 13:28:12
[2024/8/7 9:00:45 266] [1970-01-01 00:00:06] MainApp.c(1710) <SetLogLevel>: set Sofia log level 2 suceess
[2024/8/7 9:00:45 266] [1970-01-01 00:00:06] ==> XMSDK_SetLogLevel(226)[NOTICE]: set xmsdk log 4
[2024/8/7 9:00:45 282] [1970-01-01 00:00:07] xm_log.c(100) <XM_RegisterLogAndInit>: Register Log level 2
[2024/8/7 9:00:45 282] [1970-01-01 00:00:07] xm_hwinfo.c(162) <XM_HwinfoInit>: Sync hwinfo to Hwfile success!
[2024/8/7 9:00:45 298] Get Hw info: AppId [fvijo8jvloagv1gm], license [uuidcaab27b0a838d239], mac[j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:00:45 314] [1970-01-01 00:00:07] utils.c(974) <ReadJsonConfig>: Have not find pClass [DeviceGpio] pNumber [NetStatusLedGpio]
[2024/8/7 9:00:45 314] [1970-01-01 00:00:07] xm_device.c(226) <ParseDeviceJsonFile>: Get g_NetStatusLed [0] failed
[2024/8/7 9:00:45 330] **********************************************************************
[2024/8/7 9:00:45 330] |                      SYSTEM INFO                                       
[2024/8/7 9:00:45 330] |       product type:		RC50X80
[2024/8/7 9:00:45 330] |           DSP chip:		XM550V200
[2024/8/7 9:00:45 330] |          wifi type:		ATBM6062U
[2024/8/7 9:00:45 346] |             HW mac:		90314ba51650
[2024/8/7 9:00:45 346] |        git version:		a590e8b3
[2024/8/7 9:00:45 346] |          make time:		20240731132812
[2024/8/7 9:00:45 346] **********************************************************************
[2024/8/7 9:00:45 362] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(143)[INFO]: SensorSrcFrmRate = 25
[2024/8/7 9:00:45 362] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(137)[INFO]: SensorIFS = 0
[2024/8/7 9:00:45 378] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(156)[INFO]: Vi CapW 2680, CapH 2160, CapX 0, CapY 0
[2024/8/7 9:00:45 394] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 0: size=[3840, 2160] @3
[2024/8/7 9:00:45 395] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 1: size=[640, 360] @3
[2024/8/7 9:00:45 410] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 2: size=[640, 224] @3
[2024/8/7 9:00:45 410] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(406)[INFO]: ISPRsltTy[atbm_log]:START DOWNLOAD DCCM=========
[2024/8/7 9:00:45 410] pe
[2024/8/7 9:00:45 426] atbm_log]:atbm_load_firmware_generic: addr 800000: len d000
[2024/8/7 9:00:45 426] 2m[1970-01-01 00:00:07] ==> XMJSON_ParseIsp(428)[INFO]: ISPRsltType 0
[2024/8/7 9:00:45 442] [1970-01-01 00:00:07] xm_main.c(345) <AutoMaintenance_pro>: Set device auto mantenance time: -001_-1_-1 02:25:26 wenkday: Tuesday
[2024/8/7 9:00:45 458] [1970-01-01 00:00:07] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:00:45 458] [1970-01-01 00:00:07] xm_main.c(349) <AutoMaintenance_pro>: Get Last AutoMantence Date [] failed
[2024/8/7 9:00:45 474] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(442)[INFO]: ISPRsltType
[2024/8/7 9:00:45 474] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_Parse4gMoudle(500)[WARN]: Get 4GModule object error!
[2024/8/7 9:00:45 490] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(80)[NOTICE]: ISP=> Svtd: PAL
[2024/8/7 9:00:45 490] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(81)[NOTICE]: ISP=>RsltType: 0
[2024/8/7 9:00:45 506] [1970-01-01 00:00[atbm_log]:START DOWNLOAD BLE SRAM=========
[2024/8/7 9:00:45 506] :07] ==> XMSDK_P[atbm_log]:atbm_load_firmware_generic: addr 9022000: len 10000
[2024/8/7 9:00:45 506] arseJson(84)[NOTICE]: IRCut: gpio 19534 Swap 0
[2024/8/7 9:00:45 522] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(88)[NOTICE]: Infrared: gpio 0 swap 1
[2024/8/7 9:00:45 522] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(92)[NOTICE]: WLight: gpio 11 swap 0
[2024/8/7 9:00:45 539] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(96)[NOTICE]: IRLight: gpio 10 swap 0
[2024/8/7 9:00:45 555] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(99)[NOTICE]: Vi: sensorIFS=0 sensorFPS=25, capW=2680,capH=2160,capX=0,capY=0
[2024/8/7 9:00:45 555] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(100)[NOTICE]: ViChn  ImageSize      vbBlk
[2024/8/7 9:00:45 572] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    0  [3840, 2160]    3
[2024/8/7 9:00:45 572] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    1  [ 640,  360]    2
[2024/8/7 9:00:45 587] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    2  [ 640,  224]    2
[2024/8/7 9:00:45 603] [1970-01-01 00:00:07] ==> XMSDK_ParseJson([atbm_log]:atbm_after_load_firmware++
[2024/8/7 9:00:45 603] i2c_write timeout 0x2
[2024/8/7 9:00:45 603] 107)[NOTICE]: Ve[atbm_log]:alloc urb work
[2024/8/7 9:00:45 603] ncChn    MaxSize[atbm_log]:usb:try to flush rx....
[2024/8/7 9:00:45 619]    PreReleaseVb
[2024/8/7 9:00:45 620] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    0   [3840, 2160]	 false
[2024/8/7 9:00:45 635] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    1   [ 640,  360]	 false
[2024/8/7 9:00:45 635] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(116)[NOTICE]: 4GModule: gpio 0 Swap 0
[2024/8/7 9:00:45 652] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: AudioSwap: 0
[2024/8/7 9:00:45 654] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFileDEBUG: [libispapp]:Jul  5 2024 16:14:06 ,GENERAL
[2024/8/7 9:00:45 654] 2c_write timeout 0x2
[2024/8/7 9:00:45 654] [mDEBUG: Vstd_init	[ PAL ]
[2024/8/7 9:00:45 667] DEBUG: RsltSns0	[ 8 ]
[2024/8/7 9:00:45 667] DEBUG: Dsp:		[0x0][ CHIPV200 ]
[2024/8/7 9:00:45 667] DEBUG: [libsns]:Jul  5 2024 16:13:32 ,GENERAL
[2024/8/7 9:00:45 698] [atbm_log]:flush rx[-110][0]
[2024/8/7 9:00:45 714] [atbm_log]:0x1610102c=0x4300a
[2024/8/7 9:00:45 714] [atbm_log]:0x1610102c=0x6300b
[2024/8/7 9:00:45 714] [atbm_log]:0x16101000=0x0
[2024/8/7 9:00:45 714] [atbm_log]:set_block_size=256
[2024/8/7 9:00:45 714] [atbm_log]:mdelay wait wsm_startup_done  !!
[2024/8/7 9:00:45 730] [atbm_log]:firmwareCap 31e9
[2024/8/7 9:00:45 730] [atbm_log]:firmwareCap2 1b8c
[2024/8/7 9:00:45 731] [atbm_log]:wsm_caps.firmwareCap 1b8c31e9 16[atbm_log]:apollo wifi WSM init done.
[2024/8/7 9:00:45 731]    Input buffers: 32 x 1632 bytes
[2024/8/7 9:00:45 746]    Hardware: 7.21
[2024/8/7 9:00:45 762]    WSM firmware [=MODEM=DPLL24M+BLE+plat=4 ApSleep 2GHZ Jan 30 2024 10:58:03], ver: 19514, build: 6431, api: 1060, cap: 0x1B8C31E9 Config[31010]  expection 900c094, ep0 cmd addr 901b340 NumOfStations[0x10] NumOfInterfaces[3]
[2024/8/7 9:00:45 762] i2c_write timeout 0x2
[2024/8/7 9:00:45 762] [atbm_log]:EFUSE(8)				[0]
[2024/8/7 9:00:45 763] [atbm_log]:EFUSE(I)					[0]
[2024/8/7 9:00:45 763] [atbm_log]:EFUSE(B)			[0]
[2024/8/7 9:00:45 778] [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [0]
[2024/8/7 9:00:45 778] [atbm_log]:CAPABILITIES_NVR_IPC              [0]
[2024/8/7 9:00:45 778] [atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[2024/8/7 9:00:45 779] [atbm_log]:CAPABILITIES_WOW                  [0]
[2024/8/7 9:00:45 794] [atbm_log]:CAPABILITIES_NO_BACKOFF           [1]
[2024/8/7 9:00:45 794] [atbm_log]:CAPABILITIES_CFO                  [1]
[2024/8/7 9:00:45 794] [atbm_log]:CAPABILITIES_CHIP_FLAG            [1]
[2024/8/7 9:00:45 795] i2c_write timeout 0x2
[2024/8/7 9:00:45 810] [atbm_log]:CAPABILITIES_TXCAL                [1]
[2024/8/7 9:00:45 810] [atbm_log]:CAPABILITIES_HIF_TRACE       		[0]
[2024/8/7 9:00:45 810] DEBUG: SC[atbm_log]:CAPABILITIES_FORCE_PM_ACTIVE      [0]
[2024/8/7 9:00:45 810] 831HAI! Chn:0
[2024/8/7 9:00:45 826]  tbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[2024/8/7 9:00:45 826] [m[atbm_log]:CAPABILITIES_ETF                  [1]
[2024/8/7 9:00:45 826] [atbm_log]:CAPABILITIES_BLE		  			[1]
[2024/8/7 9:00:45 826] [atbm_log]:CAPABILITIES_40M			  		[0]
[2024/8/7 9:00:45 842] [atbm_log]:CAPABILITIES_LDPC 		  		[0]
[2024/8/7 9:00:45 842] [atbm_log]:CAPABILITIES_NAV_ENABLE              [0]
[2024/8/7 9:00:45 842] [atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [0]
[2024/8/7 9:00:45 842] DEBUG: Is[atbm_log]:CAPABILITIES_USE_IPC              [1]
[2024/8/7 9:00:45 858] pNum[1]
[2024/8/7 9:00:45 858] atbm_log]:CAPABILITIES_OUTER_PA             [0]
[2024/8/7 9:00:45 858] 35mDEBUG: IspChn[atbm_log]:CAPABILITIES_WFA    [0]
[2024/8/7 9:00:45 858] :[ 0  tbm_log]:CAPABILITIES_EAP_GROUP_REKEY  [0]
[2024/8/7 9:00:45 874] [m]
[2024/8/7 9:00:45 874]  tbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[2024/8/7 9:00:45 874] [1;35mDEBUG: I2C[atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[2024/8/7 9:00:45 890] Chn:[ [atbm_log]:CAPABILITIES_RXCAL       [1]
[2024/8/7 9:00:45 891] 0 ]
[2024/8/7 9:00:45 891]  tbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[2024/8/7 9:00:45 891] [mDEBUG: [atbm_log]:CAPABILITIES_80211_TO_8023 [1]
[2024/8/7 9:00:45 891] limitedUp: no
[2024/8/7 9:00:45 891]  tbm_log]:CAPABILITIES_NEW_CHIPER  [1]
[2024/8/7 9:00:45 906] [mDEBUG: [atbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [0]
[2024/8/7 9:00:45 906] -------------SC8[atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[2024/8/7 9:00:45 922] 31Hai 4K 30fps init ok! [atbm_log]:LMAC NOT SUPPORT 40M !!!
[2024/8/7 9:00:45 922] (20240322)------[atbm_log]:LMAC NOT SUPPORT LDPC !!!
[2024/8/7 9:00:45 922] -------
[2024/8/7 9:00:45 922] DEBUG: camera_set_saved_status OK!
[2024/8/7 9:00:45 922] DEBUG: [libautoscene]:Jul  5 2024 16:13:42 ,GENERAL
[2024/8/7 9:00:45 938] DEBUG: [libautoscene]:use libfvideo!
[2024/8/7 9:00:45 938] DEBUG: [libfvideo]:Jul  5 2024 15:41:09 
[2024/8/7 9:00:45 938] DEBUG: doubleLED_SetLedModeAttr 0xIspKo: clean cut!
[2024/8/7 9:00:45 938] 0 0 1
[2024/8/7 9:00:45 954] DEBUG: [libsdnc]:Aug 22 2023 13:55:14
[2024/8/7 9:00:45 954] DEBUG: LED: [IR] 
[2024/8/7 9:00:45 954] DEBUG: software LED
[2024/8/7 9:00:45 954] DEBUG: hardware pohtoR!
[2024/8/7 9:00:45 970] DEBUG: isp_sample over!
[2024/8/7 9:00:45 970] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:00:45 970] (656)[INFO]: AudioSwap=[0]
[2024/8/7 9:00:45 970] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: HighAdcValue: 0
[2024/8/7 9:00:45 986] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: LowAdcVaIspKo: set cut 0x0 0xf00 0x1 0x871
[2024/8/7 9:00:45 986] lue: 0
[2024/8/7 9:00:46 002] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: IRLightLevel: 0
[2024/8/7 9:00:46 003] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: InfraredSwap: 0
[2024/8/7 9:00:46 003] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: WhiteLightLevel: 0
[2024/8/7 9:00:46 018] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoHorizontalFlipGun: 0
[2024/8/7 9:00:46 018] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoVerticalFlipGun: 0
[2024/8/7 9:00:46 035] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: setMonocular: 1
[2024/8/7 9:00:46 035] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedX: 17
[2024/8/7 9:00:46 050] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedY: 17
[2024/8/7 9:00:46 050] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: soundValue: 50
[2024/8/7 9:00:46 066] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: lightChannel: 0
[2024/8/7 9:00:46 066] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: dayAndNightMode: 0
[2024/8/7 9:00:46 082] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: hardAndSoftLight: 1
[2024/8/7 9:00:46 082] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeX: 400
[2024/8/7 9:00:46 098] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeY: 200
[2024/8/7 9:00:46 098] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(587)[INFO]: RatioOfGear: 1:1
[2024/8/7 9:00:46 098] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(593)[INFO]: high 1: low 1
[2024/8/7 9:00:46 114] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(690)[INFO]: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:00:46 114] [1970[atbm_log]:wsm_generic_confirm:status(2)
[2024/8/7 9:00:46 131] -01-01 00:00:07][atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[2024/8/7 9:00:46 131]  xm_main.c(462) [atbm_log]:apollo wifi : can't open /data/.mac.info
[2024/8/7 9:00:46 147] <GetVideoResolut[atbm_log]:efuse data is [0x1,0x38,0x15,0x16,0x16,0x8,0x0,0x0,0x90:0x31:0x4b:0xa5:0x16:0x50]
[2024/8/7 9:00:46 147] ion>: Video resolution: [atbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[2024/8/7 9:00:46 163] captrue width 26[atbm_log]:win txpower:080 height 2160 r
[2024/8/7 9:00:46 163] [atbm_log]:use default power
[2024/8/7 9:00:46 163] esolution main: width 3840 height 2160 extra:  width 640 height 360 [2]: width 640 height 224
[2024/8/7 9:00:46 179] [1970-01-01 00:00:07] MainApp.c(1812) <main>: version , date 20240724, time 182054, plus 0
[2024/8/7 9:00:46 195] [1970-01-01 00:00:07] ==> XMSDK_StartUp(174)[INFO]: XMSDK_StartUp[atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[2024/8/7 9:00:46 195]  enter, Jul 24 2[atbm_log]:==read success==
[2024/8/7 9:00:46 195] 024, 18:20:55
[2024/8/7 9:00:46 195]  tbm_log]:set delta power
[2024/8/7 9:00:46 195] [0;39m
[2024/8/7 9:00:46 211] [1970-01-01 00:00:07] ==> IspConfigInit(158)[INFO]: maxHeight 2160 maxWidth 3840 u32RsltType 8
[2024/8/7 9:00:46 211] [1970-01-01 00:00:07] ==>[atbm_log]:get chip id [0][0][0] 
[2024/8/7 9:00:46 211]  XMSDK_StartUp(2[atbm_log]:current chiptype ATBM6062-U20-noLDPC 
[2024/8/7 9:00:46 227] 03)[INFO]: g_stP[atbm_log]:default country code:00,support channel=14
[2024/8/7 9:00:46 227] roductMgr.viMgr.capW =[2[atbm_log]:Use an internal power amplifier!
[2024/8/7 9:00:46 243] 680] g_stProductMgr.viMgr.capH =[atbm_log]:enable sg
[2024/8/7 9:00:46 243]  [2160]
[2024/8/7 9:00:46 243] [atbm_log]:[eth2] has been disabled
[2024/8/7 9:00:46 259] [1970-01-01 00:00:07] ==> XMSDK_StartUp(220)[INFO]: g_stProductMgr.vencMgr.vencChn[0].maxHeight =[2160] g_stProductMgr.encMgr.vencChn[0].maxWidth = [3840]
[2024/8/7 9:00:46 259] [19[atbm_log]:enable sg
[2024/8/7 9:00:46 259] 70-01-01 00:00:0[atbm_log]:[p2p0] has been disabled
[2024/8/7 9:00:46 275] 7] ==> XMSDK_StartUp(286)[INFO]: ispCfg.u32Others 0x0
[2024/8/7 9:00:46 291] [1970-01-01 00:00:07] ==> XMSDK_StartUp(288)[INFO]: ispCfg.u32FunExt 0x0 u32Infrared 0x80000000 u32snsRsltType 0x0 u32RsltType 0x8 au32IrCut 0x80[atbm_log]:ble start
[2024/8/7 9:00:46 292] 004c4e  au32Soft[atbm_log]:[ALTOBEAM-ble_recv] start
[2024/8/7 9:00:46 292] [atbm_log]:ble subscribe
[2024/8/7 9:00:46 292] [atbm_log]:[ALTOBEAM-ble_xmit] start
[2024/8/7 9:00:46 292] [atbm_log]:ble_platform_probe(c1ed0980)
[2024/8/7 9:00:46 307] [atbm_log]:is registered as 'ALTOBEAM'
[2024/8/7 9:00:46 307] [atbm_log]:[atbm_wtd]:set wtd_probe = 1
[2024/8/7 9:00:46 307] usbcore: registered new interface driver atbm_wlan
[2024/8/7 9:00:46 307] Led[0]: 0x800b0a11 u32Flag: 0x1 SensorRstIO: 0x800000a4 u32ComsPort: 0x0
[2024/8/7 9:00:46 323] 
[2024/8/7 9:00:46 323] [1970-01-01 00:00:08] ==> SampleCreate(1709)[INFO]: viChn:0 vstd:0 enter
[2024/8/7 9:00:46 339] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 0 size [3840, 2160]
[2024/8/7 9:00:46 339] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 1 size [640, 360]
[2024/8/7 9:00:46 355] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 2 size [640, 224]
[2024/8/7 9:00:46 355] [1970-01-01 00:00:08] ==> VencChCreate(1058)[INFO]: channel:0 enter
[2024/8/7 9:00:46 370] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[0].vencMem = VENCMEM_MICRO
[2024/8/7 9:00:46 371] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 0,width = 3840,height = 2160,enType = 265
[2024/8/7 9:00:46 371] NORM ENC MODE
[2024/8/7 9:00:46 387] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[1].vencMem = VENCMEM_MICRO
[2024/8/7 9:00:46 387] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 1,width = 640,height = 360,enType = 265
[2024/8/7 9:00:46 403] NORM ENC MODE
[2024/8/7 9:00:46 403] aec 1; agc 1; ans 1
[2024/8/7 9:00:46 403] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 21,DestChnId = 0,DestModId = 23
[2024/8/7 9:00:46 418] [1970-01-01 00:00:08] ==> AudioCreate(1656)[INFO]: XM_AENC_CreateCH OK
[2024/8/7 9:00:46 419] [1970-01-01 00:00:08] ==> AudioCreate(1685)[INFO]: XM_MPI_ADEC_CreateChn OK
[2024/8/7 9:00:46 434] [1970-01-01 00:00:08DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:00:46 434] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:00:46 434] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:00:46 435] DEBUG: software pohtoR!
[2024/8/7 9:00:46 450] DEBUG: camera_set_photosensitive_chn 0 1 0x1
[2024/8/7 9:00:46 451] ] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 24,DestChnId = 0,DestModId = 22
[2024/8/7 9:00:46 467] [1970-01-01 00:00:08] ==> JPEGChCreate(1556)[INFO]: enter JPEGChCreate channel=0, VencChn = 3
[2024/8/7 9:00:46 467] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 3,width = 640,height = 360,enType = 26
[2024/8/7 9:00:46 482] [1970-01-01 00:00:08] ==> COMM_VENC_Start(913)[INFO]: set JpegAttr
[2024/8/7 9:00:46 498] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 1,SrcModId = 7,DestChnId = 3,DestModId = 7
[2024/8/7 9:00:46 499] [1970-01-01 00:00:08] ==> COMM_VENC_Start(1032)[INFO]: JPEG_CHN[3] bind VENC_CHN[1] success!.
[2024/8/7 9:00:46 514] [1970-01-01 00:00:08] MainApp.c(1816) <main>: [1970-01-01 00:00:08] MainApp.c(1823) <main>: [1970-01-01 00:00:08] MainApp.c(1883) <main>: g_fps=[12]
[2024/8/7 9:00:46 530] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:00:46 530] [1970-01-01 00:00:08] xm_main.c(700) <XM_SetCameraFactoryConfig>: Get AutoMantence flags [0] failed
[2024/8/7 9:00:46 546] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=0,brc=1,w=3840,h=2160,qua=4,frame=12,br=1000,gop=4
[2024/8/7 9:00:46 562] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[0],wh[3840,2160]-----------
[2024/8/7 9:00:46 578] [1970-01-01 00:00:08] xm_main.c(821) <XM_SetCameraFactoryConfig>: get default language ChineseEnglish
[2024/8/7 9:00:46 578] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:00:46 594] [1970-01-01 00:00:08] xm_main.c(822) <XM_SetCameraFactoryConfig>: get defult IRcurt reverse: no picture reverse mirror:yes filp:yes
[2024/8/7 9:00:46 595] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=1,brc=1,w=640,h=360,qua=4,frame=9,br=256,gop=1
[2024/8/7 9:00:46 611] [1970-01-01 00:00:08] xm_main.c(823) <XM_SetCameraFactoryConfig>: set defult motor ptz reverse  mirror:yes filp:no
[2024/8/7 9:00:46 627] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[1],wh[640,360]-----------
[2024/8/7 9:00:46 642] [1970-01-01 00:00:08] xm_main.c(824) <XM_SetCameraFactoryConfig>: get defult autotrack motor reverse mirror:yes filp:no
[2024/8/7 9:00:46 643] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:00:46 658] [1970-01-01 00:00:08] xm_main.c(825) <XM_SetCameraFactoryConfig>: get defult ptz preset x:1556 y:950
[2024/8/7 9:00:46 658] [1970-01-01 00:00:08] MainApp.c(1885) <main>: [1970-01-01 00:00:08] MainApp.c(1893) <main>: 
[2024/8/7 9:00:46 674] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:00:46 674] [1970-01-01 00:00:08] xm_main.c(920) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:00:46 690] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:00:46 691] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:00:46 706] [1970-01-01 00:00:08] xm_main.c(1375) <XM_RealAudio_Pro>: real Audio play start___
[2024/8/7 9:00:46 707] [1970-01-01 00:00:08] xm_main.c(1747) <XM_RealVideo_Pro>: realy video play start___0
[2024/8/7 9:00:46 722] [1970-01-01 00:00:08] MainApp.c(1898) <main>: 
[2024/8/7 9:00:46 722] [1970-01-01 00:00:08] ==> AudioInSetFormat(68)[INFO]: pFormat.EncodeTye = 2
[2024/8/7 9:00:46 738] [1970-01-01 00:00:08] ==> XMSDK_AudioInSetFormat(445)[INFO]: anr(1) agc(1) aec(0)
[2024/8/7 9:00:46 738] aec 0; agc 1; ans 1
[2024/8/7 9:00:46 738] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 0
[2024/8/7 9:00:46 754] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 0 OK
[2024/8/7 9:00:46 770] [1970-01-01 00:00:08] xm_main.c(969) <XM_SetCameraFactoryConfig>: get factory language ChineseEnglish
[2024/8/7 9:00:46 770] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 1
[2024/8/7 9:00:46 770] [1970-01-01 00:00:08] xm_main.c(1899) <PtzControl_Pro>: 
[2024/8/7 9:00:46 787] PtzControl_Pro[1970-01-01 00:00:08] xm_main.c(970) <XM_SetCameraFactoryConfig>: get factory IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:00:46 803] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 1 OK
[2024/8/7 9:00:46 803] [1970-01-01 00:00:08] xm_main.c(971) <XM_SetCameraFactoryConfigDEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:00:46 818] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:00:46 818] DEBUG: camera_set_photosensitive_chn 0 0 0x1
[2024/8/7 9:00:46 834] ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!killall: hostapd: no process kill[atbm_log]:ioctl_open(c248a300)(c1ed0980)
[2024/8/7 9:00:46 834] ed
[2024/8/7 9:00:46 834] [atbm_log]:atbm_ioctl_ble_start
[2024/8/7 9:00:46 866] DEBUG: camera_set_ledType:  2
[2024/8/7 9:00:46 882] DEBUG: camera_set_dnc_mode_chn 3 
[2024/8/7 9:00:46 882] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:00:46 882] DEBUG: LED: [IR] [WL] 
[2024/8/7 9:00:46 882] DEBUG: software LED
[2024/8/7 9:00:46 898] DEBUG: software pohtoR!
[2024/8/7 9:00:46 898] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:00:46 898] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:00:46 898] DEBUG: camera_set_ledHold: 60000
[2024/8/7 9:00:46 914] >: set factory motor ptz reverse  mirror:yes filp:yes
[2024/8/7 9:00:46 914] [1970-01-01 00:00:08] ==> XMSDK_MotorCreate(120)[INFO]: xlimit 5006, ylimit 2161
[2024/8/7 9:00:46 930] [1970-01-01 00:00:08] xm_main.c(972) <XM_SetCameraFactoryConfig>: get factory autotrack motor reverse mirror:no filp:no
[2024/8/7 9:00:46 946] [1970-01-01 00:00:08] xm_main.c(1903) <PtzControl_Pro>: g_sPtz.xMaxStep 5006 g_sPtz.yMaxStep 2161 
[2024/8/7 9:00:46 946] [1970-01-01 00:00:08] xm_main.c(973) <XM_SetCameraFactoryConfig>: get factory ptz preset x:3110 y:0
[2024/8/7 9:00:46 962] [1970-01-01 00:00:08] xm_main.c(1007) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:00:46 979] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:00:46 979] [1970-01-01 00:00:08] xm_main.c(1040) <XM_SetCameraFactoryConfig>: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:00:46 994] [1970-01-01 00:00:08] xm_main.c(1060) <XM_SetCameraFactoryConfig>: set IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:00:47 010] [1970-01-01 00:00:08] xm_main.c(1078) <XM_SetCameraFactoryConfig>: camera_set_softIr_thr(1) ret=[0]
[2024/8/7 9:00:47 010] [1970-01-01 00:00:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[597],val=[1]
[2024/8/7 9:00:47 010] ************last intra 0
[2024/8/7 9:00:47 026] ************last intra 0
[2024/8/7 9:00:47 026] [1970-01-01 00:00:08] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time8280
[2024/8/7 9:00:47 042] [1970-01-01 00:00:08] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 110029
[2024/8/7 9:00:47 042] [1970-01-01 00:00:08] MainApp.c(1900) <main>: 
[2024/8/7 9:00:47 042] [1970-01-01 00:00:08] MainApp.c(1905) <main>: 
[2024/8/7 9:00:47 059] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:Register pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:00:47 059] [1970-01-01 00:00:08] ==> XMSDK_AudioSetSpeakerVol(641)[INFO]: enter: Speaker Open
[2024/8/7 9:00:47 074] [1970-01-01 00:00:08] MainApp.c(1913) <main>: 
[2024/8/7 9:00:47 074] [1970-01-01 00:00:08] ==> XMSDK_WifiInit(601)[INFO]: Wifi Init success
[2024/8/7 9:00:47 091] [1970-01-01 00:00:08] MainApp.c(1915) <main>: 
[2024/8/7 9:00:47 091] [1970-01-01 00:00:08] MainApp.c(1918) <main>: 
[2024/8/7 9:00:47 091] lib_ble_main_init
[2024/8/7 9:00:47 091] ======>>atbm_ble_start>>>
[2024/8/7 9:00:47 091] nimble_port_init++
[2024/8/7 9:00:47 091] nimble_host_task
[2024/8/7 9:00:47 091] ble_coexist_start--
[2024/8/7 9:00:47 107] hif_ioctl_loop
[2024/8/7 9:00:47 107] ble_hs_sync:333
[2024/8/7 9:00:47 107] ble_smart_cfg_startup!11
[2024/8/7 9:00:47 107] [ATBM lOG]set default tx power(0)
[2024/8/7 9:00:47 107] pub addr 90:31:4b:a5:16:51
[2024/8/7 9:00:47 107] [1970-01-01 00:00:08] MainApp.c(1922) <main>: ble_ret=[0]
[2024/8/7 9:00:47 123] [1970-01-01 00:00:08] MainApp.c(1200) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 123] [1970-01-01 00:00:08] MainApp.c(1229) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 139] [1970-01-01 00:00:08] MainApp.c(1258) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 139] [1970-01-01 00:00:08] MainApp.c(1260) <GetAndSetTyDefalutConfig>: SMLMode=[2]
[2024/8/7 9:00:47 154] [1970-01-01 00:00:08] MainApp.c(1263) <GetAndSetTyDefalutConfig>: g_SMLAbility=[0]
[2024/8/7 9:00:47 154] [1970-01-01 00:00:08] MainApp.c(1266) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 170] [1970-01-01 00:00:08] MainApp.c(1338) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 171] [1970-01-01 00:00:08] MainApp.c(1346) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 171] [1970-01-01 00:00:08] MainApp.c(1357) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 187] [1970-01-01 00:00:08] MainApp.c(1387) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 187] [1970-01-01 00:00:08] MainApp.c(1390) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:47 203] [1970-01-01 00:00:08] xm_ai.c(564) <XM_CreatePersionDetect>: 
[2024/8/7 9:00:47 203] [1970-01-01 00:00:08] xm_ai.c(574) <XM_CreatePersionDetect>: 
[2024/8/7 9:00:47 203] [1970-01-01 00:00:08] xm_ai.c(585) <XM_CreatePersionDetect>: 
[2024/8/7 9:00:47 218] [1970-01-01 00:00:08] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:00:47 218] [1970-01-01 00:00:08] xm_ai.c(588) <XM_CreatePersionDetect>: 
[2024/8/7 9:00:47 234] [1970-01-01 00:00:08] xm_ai.c(608) <XM_CreatePersionDetect>: 
[2024/8/7 9:00:47 234] [1970-01-01 00:00:08] xm_ai.c(645) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:00:47 346] [1970-01-01 00:00:08] xm_ai.c(646) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:08] xm_ai.c(647) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTime = [8];src/ped_thread.c(746) [Smart_Ped_CreateERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!ListMng - BufListCreate: index 1 OK
[2024/8/7 9:00:48 211] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:00:48 211] Mode(Product):0
[2024/8/7 9:00:48 211] BpuMode:[Online]
[2024/8/7 9:00:48 211] VpssMode:[Online]
[2024/8/7 9:00:48 211] [0.LimitUp_info]:
[2024/8/7 9:00:48 227] LimitUp:[Disable]
[2024/8/7 9:00:48 227] [2680*0]->[3840*0])
[2024/8/7 9:00:48 227] chn	TotalSize	ActiveSize
[2024/8/7 9:00:48 227] 0	5046*2246	2680*2160
[2024/8/7 9:00:48 227] 0	5034*2246	2680*2160
[2024/8/7 9:00:48 227] 0	5046*2246	3840*2160
[2024/8/7 9:00:48 227] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:00:48 227] [1.VICU_info]:
[2024/8/7 9:00:48 243] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:00:48 243] 0	25.0	57	0	0	183	linear	8ddb00
[2024/8/7 9:00:48 243] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:00:48 243] en	op_type	m_chn	now
[2024/8/7 9:00:48 243] 0	1	1	1
[2024/8/7 9:00:48 243] [2.VI_info]:
[2024/8/7 9:00:48 258] chn	TotalSize	ActiveSize
[2024/8/7 9:00:48 258] 0	5046*2246	3848*2166
[2024/8/7 9:00:48 258] 1	   0*   0	   0*   0
[2024/8/7 9:00:48 258] [3.MIPI_info]:
[2024/8/7 9:00:48 258] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:00:48 275] 0x2b	6472*2166	3848*2166		5046*2166	3848*2166	   0
[2024/8/7 9:00:48 275] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:00:48 275] [4.Cut_info]:
[2024/8/7 9:00:48 275] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:00:48 275] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:00:48 291] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:00:48 293] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:00:48 293] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:00:48 293] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:00:48 293] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:00:48 293] [5.IB(isp buffer info)]:
[2024/8/7 9:00:48 306] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:00:48 306] PoolId  Count  Size
[2024/8/7 9:00:48 307] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:48 323] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:48 323] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:48 339] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:00:48 339] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:00:48 355] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:00:48 355] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:00:48 355] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:00:48 370] 0       0         0          1          4       
[2024/8/7 9:00:48 370] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:00:48 371]      --265--            --264--                                               
[2024/8/7 9:00:48 386] Count      Line     Count      Line     
[2024/8/7 9:00:48 386] 34         480      74         560      
[2024/8/7 9:00:48 386] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:00:48 403] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:00:48 403] 0   3840   2160    H265  0      0        0           18        983034     6        	
[2024/8/7 9:00:48 418] 1   640    360     H265  0      0        0           15        43198      2        	
[2024/8/7 9:00:48 418] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:00:48 434] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:00:48 434] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:00:48 450] 0   Y      18       0       0       15       0        18       18       29        64597         59008    79220    65170    0       
[2024/8/7 9:00:48 466] 1   Y      15       0       0       1        0        15       15       30        2444          2193     27580    6703     0       
[2024/8/7 9:00:48 482] 3   N      0        0       0       1        0        0        0        30        0             0        0        0        0       
[2024/8/7 9:00:48 482] ]: Smart_Ped_Create_ver: Jul 24 2024 18:21:40
[2024/8/7 9:00:48 482] src/ped_thread.c(656) [Ped_Init_IA_Work]: Ped_Init_IA_Work start ver:Jul 24 2024 18:21:40
[2024/8/7 9:00:48 498] [FUNC: IA_InitLog] Creat OK.
[2024/8/7 9:00:48 498] [INIT]: XM_IA_Init() done.
[2024/8/7 9:00:48 498] src/ped_thread.c(705) [Ped_Init_IA_Work]: ruler 0 region (0,0) (0,0) (0,0) (0,0)
[2024/8/7 9:00:48 514] [INIT]:LIBXMIA IAtype 700 Complied at May  8 2024 08:39:39 GIT_ID:cb3a4ed0
[2024/8/7 9:00:48 514] [INIT]: TD Version: TD_V_3.2.4.2[May 15 2024 19:14:32]
[2024/8/7 9:00:48 514] -- TD INIT -- 
[2024/8/7 9:00:48 514]  uiTdMaxNum: 12 
[2024/8/7 9:00:48 514]  acClassBinPath: /usr/bin 
[2024/8/7 9:00:48 514]  ePlatForm: 50 
[2024/8/7 9:00:48 530]  eDevImgType: 17 
[2024/8/7 9:00:48 530]  stDevImgSize: (2680,2160) 
[2024/8/7 9:00:48 530]  iTrackFlag: 1 
[2024/8/7 9:00:48 530]  iTrackType: 2 
[2024/8/7 9:00:48 530] -- TD EXTF -- 
[2024/8/7 9:00:48 530]  ucPedFallDownEnable: 0
[2024/8/7 9:00:48 530]  ucTDFeatureEnable: 0
[2024/8/7 9:00:48 530]  ucSmokeEnable: 0
[2024/8/7 9:00:48 530]  ucFaceDetEnable: 0
[2024/8/7 9:00:48 546]  ucFaceMaskEnable: 0
[2024/8/7 9:00:48 546]  ucFaceAngEnable: 0
[2024/8/7 9:00:48 546]  ucFaceRegEnable: 0
[2024/8/7 9:00:48 546]  ucPlateDetEnable: 0
[2024/8/7 9:00:48 546]  ucPlateRegEnable: 0
[2024/8/7 9:00:48 546]  ucPedPointEnable: 0
[2024/8/7 9:00:48 546]  ucHandPointEnable: 0
[2024/8/7 9:00:48 546]  ucHelmetEnable: 0
[2024/8/7 9:00:48 546]  ucHandgestureEnable: 0
[2024/8/7 9:00:48 562]  efdfreq: 10
[2024/8/7 9:00:48 562] [INIT]: XM_IA_TD_PED_S Version: 20230719_person_noexp_v200
[2024/8/7 9:00:48 562] [INIT] Alg Malloc Size 27232
[2024/8/7 9:00:48 562] -- TD CFG --  
[2024/8/7 9:00:48 562]  iMDFlag: 0
[2024/8/7 9:00:48 562]  ucDetectDisable: 0
[2024/8/7 9:00:48 562]  iDetectType: 5
[2024/8/7 9:00:48 578]  ePattern: 3
[2024/8/7 9:00:48 579]  eSensitivity: 2
[2024/8/7 9:00:48 579]  ucFishEyeCorrectFlag:0
[2024/8/7 9:00:48 579]  eRotate:0
[2024/8/7 9:00:48 579]  ucSationaryTd: 0
[2024/8/7 9:00:48 579]  ucClearnessFlg:0
[2024/8/7 9:00:48 579]  usInImgWidth:0
[2024/8/7 9:00:48 579]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:00:48 594] [CFG]: Rule:0 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:00:48 594] [CFG]: Rule:1 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:00:48 594] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:00:48 594] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:00:48 610] [CFG]: DEFAULT iBoundaryPtsNum 4 eAlarmDirect 2 (0 0) (8191 0) (8191 8191) (0 8191)
[2024/8/7 9:00:48 610] [FUNC:PbdcnnConfig][L:578] (nil) 0xbe9972f8 Pointer Null.
[2024/8/7 9:00:48 610] [INIT]: PdConfig pvHandle 0xb1258000. Config OK
[2024/8/7 9:00:48 626] [INIT] Alg Malloc Size 30000
[2024/8/7 9:00:48 626] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:00:48 626] [INIT]:memPoolSize 1351680.
[2024/8/7 9:00:48 642] V1.6.x date Sep  5 2023, time 23:32:25 npu load start
[2024/8/7 9:00:48 642] dpu version v1.1.0 build time Aug  5 2022
[2024/8/7 9:00:48 642] [INIT]: Update MemPoolSize 0 to 1351680.
[2024/8/7 9:00:48 659] [INIT]: MmzAlloc MemPoolSize 1351680 0xb1096000~0xb11e0000.
[2024/8/7 9:00:48 659] 0 Model 0x1c7e184 MemPoolIdx 0 MemPoolInfo 0x6d5f10
[2024/8/7 9:00:48 659] [INIT]: version 20230719_person_noexp_v200, debug 0, profile 0
[2024/8/7 9:00:48 659] [INIT] Alg Malloc Size 240736
[2024/8/7 9:00:48 674] CNNMemory: 2064977 bulk 240736 mmz 1824241
[2024/8/7 9:00:48 674] CNNINIT INPUT IMAGESIZE:(640,224)
[2024/8/7 9:00:48 674] TD_DETECT stAlgImgSize (640,224) 
[2024/8/7 9:00:48 674] [INIT] Alg Malloc Size 60672
[2024/8/7 9:00:48 674] MdInit ok![INIT] Alg Malloc Size 79704
[2024/8/7 9:00:48 691] [FUNC: trackInit][L: 273] API_Creat_IMG 
[2024/8/7 9:00:48 691] [INIT]: PdInit pvHandle 0x1c5f230 *pvHandle 0xb1258000 OK
[2024/8/7 9:00:48 691] IA_LOG 87c6a000 value 0
[2024/8/7 9:00:48 691] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:00:48 691] Ped_Init_IA_Work end 
[2024/8/7 9:00:48 707] src/ped_thread.c(774) [Smart_Ped_Create]: Create list success, index 1 maxsize 2
[2024/8/7 9:00:48 707] src/ped_thread.c(495) [PedProc_v2]: 
[2024/8/7 9:00:48 707] src/ped_thread.c(520) [PedProc_v2]: 
[2024/8/7 9:00:48 723] [FUNC: DetectTarget][L: 1489] API_Creat_IMG_MdInImg 
[2024/8/7 9:00:48 723] [FUNC: PbdcnnWork][L: 1084] API_Creat_CSCIMG 
[2024/8/7 9:00:48 739] [1970-01-01 00:00:10] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:00:48 739] [1970-01-01 00:00:10] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:00:48 739] src/ped_thread.c(803) [Smart_Ped_Create]: Ped_Creat Success @0x39e24
[2024/8/7 9:00:48 754] [1970-01-01 00:00:10] xm_ai.c(649) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:00:48 786] [1970-01-01 00:00:10] xm_ai.c(657) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:10] xm_ai.c(658) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTime = [8];-- TD CFG --  
[2024/8/7 9:00:48 786]  iMDFlag: 0
[2024/8/7 9:00:48 786]  ucDetectDisable: 0
[2024/8/7 9:00:48 786]  iDetectType: 5
[2024/8/7 9:00:48 786]  ePattern: 3
[2024/8/7 9:00:48 786]  eSensitivity: 0
[2024/8/7 9:00:48 786]  ucFishEyeCorrectFlag:0
[2024/8/7 9:00:48 786]  eRotate:0
[2024/8/7 9:00:48 803]  ucSationaryTd: 0
[2024/8/7 9:00:48 804]  ucClearnessFlg:0
[2024/8/7 9:00:48 804]  usInImgWidth:0
[2024/8/7 9:00:48 804]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:00:48 804] [CFG]: Rule:0 ucRuleEnable:1 AlarmType:0 eRuleType:1
[2024/8/7 9:00:48 818] [CFG]: IA_PERIMETER_V1 iBoundaryPtsNum 4 eAlarmDirect 0 (0 0) (8191 0) (8191 8191) (0 8191) [CFG]: Rule:1 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:00:48 818] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:00:48 835] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:00:48 835] [INIT]: PdConfig pvHandle 0xb1258000. Config OK
[2024/8/7 9:00:48 835] IA_LOG 87c6a000 value 0
[2024/8/7 9:00:48 835] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:00:48 851] src/ped_thread.c(831) [Smart_Ped_SetParam[MMZ] BUILD TIME:[Jul 14 2021 15:42:31]
[2024/8/7 9:00:48 851] [0x83400000--------0x88000000]
[2024/8/7 9:00:48 851] --START-----------SIZE----------------OVERFLOW----NAME---------------
[2024/8/7 9:00:48 851] 0x83400000	0xbde000  (12152k)	0	vb[bdd800][0]
[2024/8/7 9:00:48 866] 0x83fde000	0xbde000  (12152k)	0	vb[bdd800][1]
[2024/8/7 9:00:48 866] 0x84bbc000	0xbde000  (12152k)	0	vb[bdd800][2]
[2024/8/7 9:00:48 866] 0x8579a000	0x55000   (  340k)	0	vb[54600][0]
[2024/8/7 9:00:48 866] 0x857ef000	0x55000   (  340k)	0	vb[54600][1]
[2024/8/7 9:00:48 883] 0x85844000	0x35000   (  212k)	0	vb[34800][0]
[2024/8/7 9:00:48 883] 0x85879000	0x35000   (  212k)	0	vb[34800][1]
[2024/8/7 9:00:48 883] 0x858ae000	0x24000   (  144k)	0	isp_nr_alpha_ch0
[2024/8/7 9:00:48 883] 0x858d2000	0x163000  ( 1420k)	0	isp_nr_idx_ch0
[2024/8/7 9:00:48 898] 0x85a35000	0x1000    (    4k)	0	isp_nr_idx_max_ch0
[2024/8/7 9:00:48 898] 0x85a36000	0x84f000  ( 8508k)	0	isp_nr_fetch_ch0
[2024/8/7 9:00:48 898] 0x86285000	0x2000    (    8k)	0	isp_defog_ch0
[2024/8/7 9:00:48 914] 0x86287000	0xc24000  (12432k)	0	vencRfcFrame[0]
[2024/8/7 9:00:48 914] 0x86eab000	0xc24000  (12432k)	0	vencRfcFrame[1]
[2024/8/7 9:00:48 914] 0x87acf000	0xf1000   (  964k)	0	stream_chn[0]
[2024/8/7 9:00:48 914] 0x87bc0000	0x4c000   (  304k)	0	vencWrapLuma[0]
[2024/8/7 9:00:48 931] 0x87c0c000	0x26000   (  152k)	0	vencWrapChroma[0]
[2024/8/7 9:00:48 931] 0x87c32000	0xb000    (   44k)	0	stream_chn[1]
[2024/8/7 9:00:48 931] 0x87c3d000	0x2b000   (  172k)	0	stream_chn[3]
[2024/8/7 9:00:48 931] 0x87c68000	0x1000    (    4k)	0	osd_block[0]
[2024/8/7 9:00:48 946] 0x87c69000	0x1000    (    4k)	0	osd_block[4]
[2024/8/7 9:00:48 946] 0x87c6a000	0x1000    (    4k)	0	IA_LOG
[2024/8/7 9:00:48 946] 0x87c6b000	0x7000    (   28k)	0	IA_MANAGE_1
[2024/8/7 9:00:48 946] 0x87c72000	0x8000    (   32k)	0	IA_MANAGE_2
[2024/8/7 9:00:48 962] 0x87c7a000	0x70000   (  448k)	0	firm_mem_0
[2024/8/7 9:00:48 962] 0x87cea000	0x14b000  ( 1324k)	0	mempool_1
[2024/8/7 9:00:48 962] 0x87e35000	0x1000    (    4k)	0	dst_mem_1
[2024/8/7 9:00:48 962] 0x87e36000	0x1000    (    4k)	0	dst_mem_2
[2024/8/7 9:00:48 962] 0x87e37000	0x3000    (   12k)	0	dst_mem_3
[2024/8/7 9:00:48 978] 0x87e3a000	0x1000    (    4k)	0	dst_mem_4
[2024/8/7 9:00:48 978] 0x87e3b000	0x14000   (   80k)	0	IA_MANAGE_3
[2024/8/7 9:00:48 978] 0x87e4f000	0x35000   (  212k)	0	IA_Image_1
[2024/8/7 9:00:48 978] 0x87e84000	0x6a000   (  424k)	0	IA_Image_2
[2024/8/7 9:00:48 994] 0x87eee000	0x112000  ( 1096k)	1	
[2024/8/7 9:00:48 994] ---------------------------------------------------------------------
[2024/8/7 9:00:48 994] SIZE: 0x4c00000(77824k)  USED: 0x4aee000(76728k)  FREE: 0x112000(1096k)
[2024/8/7 9:00:49 010] ]: Ped_SetParam Success
[2024/8/7 9:00:49 010] [1970-01-01 00:00:10] xm_ai.c(666) <XM_CreatePersionDetect>: 
[2024/8/7 9:00:49 010] [1970-01-01 00:00:10] xm_ai.c(674) <XM_CreatePersionDetect>: 
[2024/8/7 9:00:49 026] [1970-01-01 00:00:10] MainApp.c(1395) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:49 026] [1970-01-01 00:00:10] MainApp.c(1397) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:49 043] [1970-01-01 00:00:10] MainApp.c(1402) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:49 043] [1970-01-01 00:00:10] MainApp.c(1481) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:49 043] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 60 enable 0 volume
[2024/8/7 9:00:49 058] [1970-01-01 00:00:10] MainApp.c(1525) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:49 058]  PTZPreset is empty!
[2024/8/7 9:00:49 074]  PTZPreset is empty!
[2024/8/7 9:00:49 074] [1970-01-01 00:00:10] MainApp.c(1554) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:49 090] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:00:49 090] [1970-01-01 00:00:10] MainApp.c(1568) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:49 106] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:00:49 122] [1970-01-01 00:00:10] MainApp.c(1584) <GetAndSetTyDefalutConfig>: cruisetime_pro create!
[2024/8/7 9:00:49 122] [1970-01-01 00:00:10] MainApp.c(1607) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:00:49 138] [1970-01-01 00:00:10] MainApp.c(1925) <main>: 
[2024/8/7 9:00:49 138] [1970-01-01 00:00:10] MainApp.c(1116) <GetRegisterMode>: -------- register mode 1
[2024/8/7 9:00:49 154] [1970-01-01 00:00:10] MainApp.c(1927) <main>: 
[2024/8/7 9:00:49 154] [1970-01-01 00:00:10] MainApp.c(1930) <main>: 
[2024/8/7 9:00:49 154] *************
[2024/8/7 9:00:49 154]  0x6d123c 
[2024/8/7 9:00:49 154] *****************
[2024/8/7 9:00:49 154]  0x3287c 
[2024/8/7 9:00:49 171] beginend[1970-01-01 00:00:10] MainApp.c(1938) <main>: 
[2024/8/7 9:00:49 171] [1970-01-01 00:00:10] MainApp.c(866) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:00:49 187] [1970-01-01 00:00:10] MainApp.c(174) <GetDeviceHWInfo>: Get Hwinfo APP_ID [fvijo8jvloagv1gm], UUID[uuidcaab27b0a838d239] AUTHKEY [j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:00:49 187] [1970-01-01 00:00:10] MainApp.c(909) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:00:49 202] [1970-01-01 00:00:10] MainApp.c(942) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:00:49 202] [1970-01-01 00:00:10] MainApp.c(986) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:00:49 218] [1970-01-01 00:00:10] MainApp.c(1019) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:00:49 218] sdk start
[2024/8/7 9:00:49 219] [1970-01-01 00:00:10] MainApp.c(752) <tuya_ipc_sdk_start>: log_level 0[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/mtd/Config/ty/ 
[2024/8/7 9:00:49 234] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/mtd/Config/ty/
[2024/8/7 9:00:49 235] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/mtd/Config/ty/
[2024/8/7 9:00:49 250] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[2024/8/7 9:00:49 251] [01-01 18:12:15 TUYA D][simplekv.c:989] both file not exist /mnt/mtd/Config/ty/tuya_user.db
[2024/8/7 9:00:49 266] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[2024/8/7 9:00:49 267] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[2024/8/7 9:00:49 267] [01-01 18:12:15 TUYA D][simplekv.c:1083] init NEW normal file
[2024/8/7 9:00:49 283] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 3536627844
[2024/8/7 9:00:49 283] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:49 298] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[2024/8/7 9:00:49 299] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[2024/8/7 9:00:49 314] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[2024/8/7 9:00:49 315] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[2024/8/7 9:00:49 315] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[2024/8/7 9:00:49 330] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[2024/8/7 9:00:49 330] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[2024/8/7 9:00:49 330] [01-01 18:12:15 TUYA E][log_seq.c:863] open err
[2024/8/7 9:00:49 346] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[2024/8/7 9:00:49 362] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[2024/8/7 9:00:49 362] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[2024/8/7 9:00:49 378] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[2024/8/7 9:00:49 378] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:00:49 378] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:49 394] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:49 394] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:49 394] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:00:49 410] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:00:49 410] [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
[2024/8/7 9:00:49 426] [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:00:49 426] dev id key: 16
[2024/8/7 9:00:49 426] d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[2024/8/7 9:00:49 426] --- tracepoint bt_ext_porting.c,tuya_ext_bt_port_init(464): tuya_ext_bt_port_init ---
[2024/8/7 9:00:49 443] [01-01 18:12:15 TUYA I][bt_ext_porting.c:466] [TUYA-BTUART]tuya ext bt port init
[2024/8/7 9:00:49 443] --- tracepoint bt_uart_drv.c,tuya_bt_uart_open(187): tuya_bt_uart_open ---
[2024/8/7 9:00:49 458] --- tracepoint bt_uart_drv.c,tuya_bt_uart_init(60): tuya_bt_uart_init  0 ---
[2024/8/7 9:00:49 458] [01-01 18:12:15 TUYA I][bt_ext_porting.c:485] [TUYA-BTUART]thread ty_btext_thread create cplt mode 1
[2024/8/7 9:00:49 474] [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[2024/8/7 9:00:49 474] [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[2024/8/7 9:00:49 474] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish
[2024/8/7 9:00:49 490] [1970-01-01 00:00:10] MainApp.c(822) <tuya_ipc_sdk_start>: create ring buffer start 
[2024/8/7 9:00:49 490] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:0 Enable:1
[2024/8/7 9:00:49 506] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 2048, video_fps 12
[2024/8/7 9:00:49 506] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr0 bitrate:2048 fps:12
[2024/8/7 9:00:49 523] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 2621440 bytes for ch0st0tr0, max frame size 393216
[2024/8/7 9:00:49 523] --- tracepoint bt_ext_porting.c,ty_btext_thread(370):  ---
[2024/8/7 9:00:49 538] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr0 size:2621440 nodes:120
[2024/8/7 9:00:49 539] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:0
[2024/8/7 9:00:49 555] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:1 Enable:1
[2024/8/7 9:00:49 555] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 1024, video_fps 12
[2024/8/7 9:00:49 570] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr1 bitrate:1024 fps:12
[2024/8/7 9:00:49 570] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1310720 bytes for ch0st0tr1, max frame size 196608
[2024/8/7 9:00:49 586] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr1 size:1310720 nodes:120
[2024/8/7 9:00:49 586] [01-01 [atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:00:49 602] 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:1
[2024/8/7 9:00:49 602] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:2 Enable:0
[2024/8/7 9:00:49 602] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:3 Enable:0
[2024/8/7 9:00:49 618] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:4 Enable:0
[2024/8/7 9:00:49 618] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:5 Enable:0
[2024/8/7 9:00:49 634] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:6 Enable:0
[2024/8/7 9:00:49 634] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:7 Enable:0
[2024/8/7 9:00:49 634] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:8 Enable:0
[2024/8/7 9:00:49 650] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:9 Enable:1
[2024/8/7 9:00:49 650] [01-01 18:12:15 TUYA D][MainApp.c:439] audio_sample 8000, audio_databits 16, audio_fps 25
[2024/8/7 9:00:49 666] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25[atbm_log]:eth2:free authen bss ++
[2024/8/7 9:00:49 682] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[2024/8/7 9:00:49 682] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[2024/8/7 9:00:49 698] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:9
[2024/8/7 9:00:49 698] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:10 Enable:0
[2024/8/7 9:00:49 714] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:11 Enable:0
[2024/8/7 9:00:49 714] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:12 Enable:0
[2024/8/7 9:00:49 714] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:13 Enable:0
[2024/8/7 9:00:49 730] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:14 Enable:0
[2024/8/7 9:00:49 731] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:15 Enable:0
[2024/8/7 9:00:49 747] [1970-01-01 00:00:10] MainApp.c(830) <tuya_ipc_sdk_start>: pRunInfo->net_info.connect_mode 1[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:00:49 762] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:49 763] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:49 763] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:49 778] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:00:49 779] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:00:49 795] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":null,"auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:00:49 810] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:00:49 810] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:49 826] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:49 826] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:49 826] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:208
[2024/8/7 9:00:49 842] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 0 startpos:28700 size:276
[2024/8/7 9:00:49 842] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:49 858] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 1056267009
[2024/8/7 9:00:49 858] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:49 858] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:49 874] [01-01 18:12:15 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:00:49 890] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":0,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:00:49 890] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:00:49 890] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:49 906] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:49 907] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:49 922] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:00:49 922] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 1 startpos:28976 size:212
[2024/8/7 9:00:49 922] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:49 938] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2367317337
[2024/8/7 9:00:49 938] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:49 939] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:49 954] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:00:49 955] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[2024/8/7 9:00:49 970] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1776] Last reset reason: 255
[2024/8/7 9:00:49 970] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:00:49 970] [01-01 18:12:15 TUYA D][simplekv.c:1251] [atbm_log]:[eth2] change to [3]
[2024/8/7 9:00:49 986] find key:0 gw_bi[atbm_log]:[eth2] has been disabled
[2024/8/7 9:00:49 986] [01-01 18:12:15 TUYA [atbm_log]:add iftype(6),if_cnt(2),flags(c25fdbf8)
[2024/8/7 9:00:49 986] D][simplekv.c:12[atbm_log]:enable sg
[2024/8/7 9:00:50 002] 80] key:gw_bi fi[atbm_log]:[mon.eth2] has been disabled
[2024/8/7 9:00:50 002] nd value.Len:208
[2024/8/7 9:00:50 002] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:00:50 018] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 018] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:50 018] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 034] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 034] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:50 034] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:00:50 050] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1140] serial_no:90314ba51650
[2024/8/7 9:00:50 050] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 066] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:00:50 066] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:00:50 066] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[2024/8/7 9:00:50 082] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1171] gw_cntl.gw_wsm.stat:0
[2024/8/7 9:00:50 082] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1347] gw_cntl->gw_wsm.nc_tp:0
[2024/8/7 9:00:50 098] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1348] gw_cntl->gw_wsm.md:0
[2024/8/7 9:00:50 099] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1362] wifi config method not fit
[2024/8/7 9:00:50 099] [01-01 18:12:15 TUYA E][tuya_devos_entry.c:1787] ret:-2
[2024/8/7 9:00:50 114] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1808] enter reset factory
[2024/8/7 9:00:50 114] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 114] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:50 130] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 130] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 130] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_di -6
[2024/8/7 9:00:50 146] [01-01 18:12:15 TUYA E][ws_db_gw.c:494] gw_di read fail:-6
[2024/8/7 9:00:50 146] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 162] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:50 162] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 162] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 178] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_di And Value Len:400
[2024/8/7 9:00:50 178] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 2 startpos:29188 size:468
[2024/8/7 9:00:50 194] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:50 194] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 876692212
[2024/8/7 9:00:50 194] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:50 210] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:50 210] [01-01 18:12:15 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:00:50 210] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:593] nc_tp:2, wifi_start_mode:0
[2024/8/7 9:00:50 226] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 226] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:50 242] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 243] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 243] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:wf_start_md And Value Len:16
[2024/8/7 9:00:50 258] [01-01[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:00:50 258]  18:12:15 TUYA D[atbm_log]:[WSM] Drop frame
[2024/8/7 9:00:50 258] ][simplekv.c:457] new space 3 startpos:29656 size:84
[2024/8/7 9:00:50 274] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:50 274] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 411742493
[2024/8/7 9:00:50 274] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:50 289] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:50 307] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:00:50 307] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 307] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:00:50 322] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:00:50 322] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:00:50 338] [01-01 18:12:15 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:00:50 338] [01-01 18:12:15 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:00:50 338] [01-01 18:12:15 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:00:50 354] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4146866774
[2024/8/7 9:00:50 354] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:50 354] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:50 370] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:00:50 370] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 370] [01-0[atbm_log]:[eth2] start driver he ap
[2024/8/7 9:00:50 386] 1 18:12:15 TUYA [atbm_log]:BSS_CHANGED_BEACON
[2024/8/7 9:00:50 386] D][simplekv.c:1247] no k[atbm_log]:change ds_params channel 6 
[2024/8/7 9:00:50 386] ey find
[2024/8/7 9:00:50 386] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 402] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 402] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6
[2024/8/7 9:00:50 418] [01-01 18:12:15 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6
[2024/8/7 9:00:50 418] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 418] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:50 434] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 434] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 434] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:368
[2024/8/7 9:00:50 450] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 4 startpos:29740 size:436
[2024/8/7 9:00:50 450] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:50 466] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 216605884
[2024/8/7 9:00:50 466] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:50 466] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:50 482] [01-01 18:12:15 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:00:50 482] [01-01 18:12:15 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:00:50 498] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 498] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:50 498] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 514] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 514] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:00:50 514] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 5 startpos:30176 size:84
[2024/8/7 9:00:50 530] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:50 530] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4220141073
[2024/8/7 9:00:50 546] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:50 546] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:50 546] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 562] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:50 562] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 562] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 578] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:00:50 578] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 6 startpos:30260 size:84
[2024/8/7 9:00:50 594] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:50 594] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 860452950
[2024/8/7 9:00:50 594] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:50 610] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:50 610] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:00:50 627] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:50 627] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:50 627] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:50 642] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:00:50 643] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 7 startpos:30344 size:84
[2024/8/7 9:00:50 658] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:00:50 658] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2541358761
[2024/8/7 9:00:50 659] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:00:50 674] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:00:50 674] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[2024/8/7 9:00:50 691] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[2024/8/7 9:00:50 691] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[2024/8/7 9:00:50 707] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[2024/8/7 9:00:50 707] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[2024/8/7 9:00:50 707] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[2024/8/7 9:00:50 722] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[2024/8/7 9:00:50 722] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[2024/8/7 9:00:50 722] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[2024/8/7 9:00:50 738] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[2024/8/7 9:00:50 738] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[2024/8/7 9:00:50 755] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[2024/8/7 9:00:50 755] [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[2024/8/7 9:00:50 770] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[2024/8/7 9:00:50 787] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}
[2024/8/7 9:00:50 802] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:116] sys add timer: 14
[2024/8/7 9:00:50 803] 
[2024/8/7 9:00:50 803] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:122] sys start timer: 14
[2024/8/7 9:00:50 803] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[2024/8/7 9:00:50 819] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[2024/8/7 9:00:50 819] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[2024/8/7 9:00:50 819] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[2024/8/7 9:00:50 834] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:fvijo8jvloagv1gm 0
[2024/8/7 9:00:50 834] uuid: 20
[2024/8/7 9:00:50 835] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:00:50 835] dev_id_tmp: 16
[2024/8/7 9:00:50 850] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:00:50 850] dev_id_tmp2: 20
[2024/8/7 9:00:50 850] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:00:50 850] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:00:50 866] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1066] nc_tp:2, md:0
[2024/8/7 9:00:50 866] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1297] dev_nw_cfg_active_stage:2
[2024/8/7 9:00:50 882] [01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[2024/8/7 9:00:50 882] [1970-01-01 00:00:11] MainApp.c(838) <tuya_ipc_sdk_start>: [01-01 18:12:15 TUYA D][MainApp.c:854] tuya ipc sdk start is complete
[2024/8/7 9:00:50 898] [1970-01-01 00:00:11] MainApp.c(1028) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:00:50 898] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:00:50 914] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:00:50 914] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:00:50 914] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[2024/8/7 9:00:50 914] killall: hostapd: no process killed
[2024/8/7 9:00:50 930] route: netmask and route address conflict
[2024/8/7 9:00:50 930] [1970-01-01 00:00:11] MainApp.c(1053) <TUYA_IPC_SDK_START>: pthread_create BasicIndicatorTimer suc
[2024/8/7 9:00:50 946] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [0] change to [1]
[2024/8/7 9:00:50 946] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [0] change to [1]
[2024/8/7 9:00:50 962] [1970-01-01 00:00:11] MainApp.c(1968) <main>: FLIP
[2024/8/7 9:00:50 962] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [1] change to [0]
[2024/8/7 9:00:50 978] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [1] change to [0]
[2024/8/7 9:00:50 978] [1970-01-01 00:00:11] MainApp.c(1972) <main>: FLIP
[2024/8/7 9:00:51 042] [1970-01-01 00:00:11] MainApp.c(1622) <PostInit>: 
[2024/8/7 9:00:51 042] src/intelligent_track_thread.c(1398) [XM_SmartBodyTarckCreate]: 
[2024/8/7 9:00:51 042] src/intelligent_track_thread.c(1374) [Smart_Track_GetAbility]: 
[2024/8/7 9:00:51 058] src/intelligent_track_thread.c(1379) [Smart_Track_GetAbility]: 
[2024/8/7 9:00:51 058] src/intelligent_track_thread.c(1272) [GetMotorCtrlPara]: 
[2024/8/7 9:00:51 074] src/intelligent_track_thread.c(1277) [GetMotorCtrlPara]: 
[2024/8/7 9:00:51 075] src/intelligent_track_thread.c(1283) [GetMotorCtrlPara]: 
[2024/8/7 9:00:51 090] src/intelligent_track_thread.c(1298) [GetMotorCtrlPara]: max_steps_x=5006 ,max_steps_y=2161
[2024/8/7 9:00:51 090] src/intelligent_track_thread.c(1301) [GetMotorCtrlPara]: 
[2024/8/7 9:00:51 090] src/intelligent_track_thread.c(1307) [GetMotorCtrlPara]: 
[2024/8/7 9:00:51 106] src/intelligent_track_thread.c(1323) [GetMotorCtrlPara]: 
[2024/8/7 9:00:51 106] src/intelligent_track_thread.c(1336) [GetMotorCtrlPara]: track_default_degrees_y=95
[2024/8/7 9:00:51 122] src/intelligent_track_thread.c(1345) [GetMotorCtrlPara]: LoadTrackSet Motor_x_turnover:no
[2024/8/7 9:00:51 122] src/intelligent_track_thread.c(1346) [GetMotorCtrlPara]: LoadTrackSet Motor_y_turnover:no
[2024/8/7 9:00:51 138] src/intelligent_track_thread.c(1348) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 540
[2024/8/7 9:00:51 154] src/intelligent_track_thread.c(1367) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 400
[2024/8/7 9:00:51 154] src/intelligent_track_thread.c(1368) [GetMotorCtrlPara]: LoadTrackSet HEIGHT_STEP = 200
[2024/8/7 9:00:51 170] src/intelligent_track_thread.c(1390) [Smart_Track_GetAbility]: Track_Ability : Enable
[2024/8/7 9:00:51 170] src/intelligent_track_thread.c(1451) [XM_SmartBodyTarckCreate]: Intelligent Track_pthread create Success 1920x1080
[2024/8/7 9:00:51 186] src/intelligent_track_thread.c(667) [TrackProcV200]: 
[2024/8/7 9:00:51 186] [1970-01-01 00:00:11] MainApp.c(277) <BasicIndicatorTimer>: BasicIndicatorTimer start ----
[2024/8/7 9:00:51 202] [1970-01-01 00:00:11] MainApp.c(1640) <PostInit>: ln -s /mnt/mtd/Log/sofia.log /tmp/tuya.log
[2024/8/7 9:00:51 202] [1970-01-01 00:00:11] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:00:51 218] [1970-01-01 00:00:11] MainApp.c(1665) <PostInit>: MotionDetect Sensitive 1 set onvif_on_off:0 
[2024/8/7 9:00:51 218] [1970-01-01 00:00:12] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time12326
[2024/8/7 9:00:51 234] [1970-01-01 00:00:12] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 112953
[2024/8/7 9:00:51 234] curr event:3 
[2024/8/7 9:00:51 250] IPC_APP_Notify_LED_Sound_Status_CB line(480) -------------------------- IPC_START_WIFI_AP_CFG(3)
[2024/8/7 9:00:51 250] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-1650
[2024/8/7 9:00:51 250] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:00:51 266] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:00:51 266] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:00:51 266] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:00:51 282] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:00:51 282] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:00:51 298] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[2024/8/7 9:00:51 298] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[2024/8/7 9:00:51 314] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[2024/8/7 9:00:51 314] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:00:51 314] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:00:51 330] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:51 330] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:51 330] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:51 346] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:51 346] [01-01 18:12:16 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:00:51 362] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:00:51 362] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:51 362] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:51 378] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:51 378] [01-01 18:12:16 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:00:51 394] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:00:51 394] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:51 394] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:51 410] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:51 410] [01-01 18:12:16 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:00:51 426] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[2024/8/7 9:00:51 426] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:00:51 442] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:2  -->>
[2024/8/7 9:00:51 442] __IPC_APP_Get_Net_Status_cb line(193) -------------------------- stat(2)==STAT_AP_STA_UNCFG 
[2024/8/7 9:00:51 458] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:2  <<--
[2024/8/7 9:00:51 458] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:00:51 474] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:00:51 475] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:00:51 475] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:51 490] [01-01 18:12:16 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:51 490] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[2024/8/7 9:00:51 507] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:21504,priority:5
[2024/8/7 9:00:51 507] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[2024/8/7 9:00:51 522] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[2024/8/7 9:00:51 522] [01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt netcfg start
[2024/8/7 9:00:51 522] [01-01 18:12:16 TUYA N][tuya_ble_api.c:439] update bound stat:0
[2024/8/7 9:00:51 538] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[2024/8/7 9:00:51 538] [01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:00:51 538] dev id key: 16
[2024/8/7 9:00:51 554] d0 7d 89 57 d1 c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 9:00:51 555] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:00:51 555] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:00:51 570] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:00:51 570] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:00:51 570] udhcpd (v1.22.1) started
[2024/8/7 9:00:51 586] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:00:51 586] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 9:00:51 602] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0x1d03220),len(28)
[2024/8/7 9:00:51 602] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 9:00:51 602] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:00:51 618] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:00:51 618] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0x1d03240),len(30)
[2024/8/7 9:00:51 634] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 9:00:51 634] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:00:51 634] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 9:00:51 650]  ---
[2024/8/7 9:00:51 651] adv_len:28
[2024/8/7 9:00:51 651] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:00:51 651] svc_data_uuid16 len:18
[2024/8/7 9:00:51 666] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 9:00:51 666] ---[XmBleAdvertiseEx][1210]: rc=[0]
[2024/8/7 9:00:51 666] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 9:00:51 666] rsp_len:30
[2024/8/7 9:00:51 682] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:00:51 682] mfg_data len:30
[2024/8/7 9:00:51 682] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 9:00:51 682] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 9:00:51 698] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 9:00:51 698] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:51 714] [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 9:00:51 714] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[2024/8/7 9:00:51 714] ---[XmBleAdvertiseEx][1241]: rc=[0]
[2024/8/7 9:00:51 730] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 9:00:51 730] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 9:00:51 730] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:51 746] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:51 746] adv_start rc = 0x0
[2024/8/7 9:00:51 746] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 9:00:51 762] [01-01 18:12:16 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:00:51 762] [01-01 18:12:16 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:51 762] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:51 778] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:51 794] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:51 794] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:51 794] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:51 810] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:51 810] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:51 826] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:51 826] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:51 826] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:51 842] [01-01 18:12:16 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:51 842] [01-01 18:12:16 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:51 858] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:51 874] [01-01 18:12:16 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:51 890] [01-01 18:12:16 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:51 891] [01-01 18:12:16 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:51 891] [01-01 18:12:16 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:51 906] gethostbyname_r error: Unknown host
[2024/8/7 9:00:51 906] [01-01 18:12:16 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:51 906] [01-01 18:12:16 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:51 922] [01-01 18:12:16 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:51 922] [01-01 18:12:16 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:51 938] [01-01 18:12:16 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:51 938] [01-01 18:12:16 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:51 954] [01-01 18:12:17 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:51 954] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:51 954] [01-01 18:12:17 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:00:51 970] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:51 986] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:00:51 986] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:52 002] [01-01 18:12:17 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:52 002] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:52 017] [1970-01-01 00:00:13] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:52 034] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:52 034] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:00:52 034] [01-01 18:12:17 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:00:52 050] [01-01 18:12:17 TUYA D][tuya_ble_api.c:1470] ble get conn stat:4
[2024/8/7 9:00:52 050] [01-01 18:12:17 TUYA N][tuya_ble_api.c:750] ble_sdk_send skip, no connect:4
[2024/8/7 9:00:52 066] [01-01 18:12:18 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:52 067] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:52 067] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:52 082] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:52 082] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:52 098] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:52 098] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:52 098] [01-01 18:12:18 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:52 114] [01-01 18:12:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:52 114] [01-01 18:12:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:52 114] [01-01 18:12:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:52 130] [01-01 18:12:18 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:52 130] [01-01 18:12:18 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:52 146] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:52 195] [01-01 18:12:18 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:52 195] [01-01 18:12:18 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:52 211] [01-01 18:12:18 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:52 211] [01-01 18:12:18 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:52 211] gethostbyname_r error: Unknown host
[2024/8/7 9:00:52 227] [01-01 18:12:18 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:52 227] [01-01 18:12:18 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:52 243] [01-01 18:12:18 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:52 244] [01-01 18:12:18 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:52 244] [01-01 18:12:18 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:52 258] [01-01 18:12:18 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:52 258] [01-01 18:12:18 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:52 275] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:52 290] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:52 292] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:52 292] [01-01 18:12:18 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:52 674] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:52 690] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:52 690] [1970-01-01 00:00:14] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:52 706] [01-01 18:12:19 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:52 706] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:52 706] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:52 722] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:52 722] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:52 738] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:52 738] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:52 738] [01-01 18:12:19 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:52 754] [01-01 18:12:19 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:52 754] [01-01 18:12:19 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:52 754] [01-01 18:12:19 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:52 770] [01-01 18:12:19 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:52 770] [01-01 18:12:19 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:52 786] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:52 803] [01-01 18:12:19 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:52 818] [01-01 18:12:19 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:52 818] [01-01 18:12:19 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:52 834] [01-01 18:12:19 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:52 834] gethostbyname_r error: Unknown host
[2024/8/7 9:00:52 834] [01-01 18:12:19 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:52 849] [01-01 18:12:19 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:52 850] [01-01 18:12:19 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:52 850] [01-01 18:12:19 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:52 866] [01-01 18:12:19 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:52 867] [01-01 18:12:19 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:52 882] [01-01 18:12:19 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:52 882] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:53 122] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:53 138] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:53 154] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:00:53 154] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:53 170] [01-01 18:12:19 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:53 601] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:53 617] [01-01 18:12:19 TUYA D][tuya_ble_api.c:1376] nw stat change:0->1, rpt to app.
[2024/8/7 9:00:53 618] [01-01 18:12:19 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:00:53 746] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:53 746] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:53 762] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:53 762] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:53 762] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:53 778] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:53 778] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:53 794] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:53 794] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:53 794] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:53 810] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:53 810] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:53 826] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:53 827] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:53 827] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:53 858] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:53 858] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:53 874] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:53 874] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:53 874] gethostbyname_r error: Unknown host
[2024/8/7 9:00:53 890] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:53 890] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:53 906] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:53 906] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:53 922] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:53 922] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:53 923] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:53 938] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:54 178] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:54 194] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:54 194] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:54 738] [1970-01-01 00:00:16] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time16332
[2024/8/7 9:00:54 754] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:54 754] [1970-01-01 00:00:16] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:54 770] [1970-01-01 00:00:16] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:54 786] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:54 786] [01-01 18:12:21 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:54 802] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:54 802] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:54 802] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:54 818] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:54 818] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:54 818] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:54 834] [01-01 18:12:21 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:54 834] [01-01 18:12:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:54 850] [01-01 18:12:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:54 851] [01-01 18:12:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:54 851] [01-01 18:12:21 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:54 866] [01-01 18:12:21 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:54 866] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:54 898] [01-01 18:12:21 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:54 898] [01-01 18:12:21 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:54 914] [01-01 18:12:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:54 914] [01-01 18:12:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:54 914] gethostbyname_r error: Unknown host
[2024/8/7 9:00:54 930] [01-01 18:12:21 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:54 930] [01-01 18:12:21 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:54 930] [01-01 18:12:21 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:54 946] [01-01 18:12:21 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:54 946] [01-01 18:12:21 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:54 962] [01-01 18:12:21 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:54 962] [01-01 18:12:21 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:54 978] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:55 059] motor auto test over
[2024/8/7 9:00:55 059] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 9:00:55 059] action=idle
[2024/8/7 9:00:55 059] dir=
[2024/8/7 9:00:55 059] flag=|auto-test-cmplt
[2024/8/7 9:00:55 059]  steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 9:00:55 059] YYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 9:00:55 074] action=idle
[2024/8/7 9:00:55 074] dir=
[2024/8/7 9:00:55 074] flag=
[2024/8/7 9:00:55 074]  steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 9:00:55 186] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:55 186] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:00:55 202] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:55 202] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:55 650] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:00:55 666] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:55 666] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:00:55 762] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:55 762] [01-01 18:12:22 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:55 777] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:55 778] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:55 778] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:55 793] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:55 794] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:55 794] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:55 809] [01-01 18:12:22 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:55 810] [01-01 18:12:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:55 810] [01-01 18:12:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:55 825] [01-01 18:12:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:55 825] [01-01 18:12:22 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:55 841] [01-01 18:12:22 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:55 841] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:55 873] [01-01 18:12:22 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:55 873] [01-01 18:12:22 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:55 889] [01-01 18:12:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:55 890] [01-01 18:12:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:55 890] gethostbyname_r error: Unknown host
[2024/8/7 9:00:55 905] [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:55 905] [01-01 18:12:22 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:55 905] [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:55 921] [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:55 921] [01-01 18:12:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:55 938] [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:55 938] [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:55 954] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:55 954] [01-01 18:12:22 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:00:56 194] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:56 194] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:56 194] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:56 865] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:56 865] [1970-01-01 00:00:18] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:56 881] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:56 881] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:56 897] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:56 897] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:56 913] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:56 914] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:56 915] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:56 930] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:56 930] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:56 930] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:56 946] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:56 946] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:56 962] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:56 962] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:56 962] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:56 994] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:56 994] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:57 010] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:57 010] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:57 010] gethostbyname_r error: Unknown host
[2024/8/7 9:00:57 026] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:57 026] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:57 042] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:57 042] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:57 058] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:57 058] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:57 073] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:57 074] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:57 201] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:57 217] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:00:57 233] [1970-01-01 00:00:19] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:57 233] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:57 938] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:57 954] [1970-01-01 00:00:19] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 9:00:57 954] [1970-01-01 00:00:19] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 9:00:57 969] mpId[0] is [0].
[2024/8/7 9:00:57 969] mpId[1] is [0].
[2024/8/7 9:00:57 969] mpId[2] is [0].
[2024/8/7 9:00:57 969] mpId[3] is [0].
[2024/8/7 9:00:57 969] mpId[4] is [0].
[2024/8/7 9:00:57 970] mpId[5] is [0].
[2024/8/7 9:00:57 970] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:00:57 986] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:00:58 002] [1970-01-01 00:00:19] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:00:58 002] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:58 018] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:58 034] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:58 034] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:58 034] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:58 049] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:58 049] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:58 049] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:58 066] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:58 066] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:58 082] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:58 082] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:58 082] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:58 098] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:58 098] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:58 114] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:58 129] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:58 129] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:58 145] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:58 146] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:58 161] gethostbyname_r error: Unknown host
[2024/8/7 9:00:58 161] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:58 162] 
[2024/8/7 9:00:58 162] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:58 177] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:58 178] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:58 193] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:58 193] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:58 209] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:58 209] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:58 225] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:58 225] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:58 241] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:58 945] [1970-01-01 00:00:20] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time20452
[2024/8/7 9:00:58 961] [1970-01-01 00:00:20] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 114464
[2024/8/7 9:00:58 961] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:58 977] [1970-01-01 00:00:20] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:00:58 993] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:58 993] [01-01 18:12:25 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:00:58 993] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:00:59 009] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:59 009] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:00:59 026] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:00:59 026] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:00:59 026] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:00:59 041] [01-01 18:12:25 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:00:59 041] [01-01 18:12:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:00:59 041] [01-01 18:12:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:00:59 058] [01-01 18:12:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:00:59 059] [01-01 18:12:25 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:00:59 074] [01-01 18:12:25 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:00:59 074] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:00:59 106] [01-01 18:12:25 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:00:59 107] [01-01 18:12:25 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:00:59 107] [01-01 18:12:25 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:00:59 122] [01-01 18:12:25 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:00:59 122] gethostbyname_r error: Unknown host
[2024/8/7 9:00:59 138] [01-01 18:12:25 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:00:59 139] [01-01 18:12:25 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:00:59 139] [01-01 18:12:25 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:00:59 154] [01-01 18:12:25 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:00:59 154] [01-01 18:12:25 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:00:59 170] [01-01 18:12:25 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:00:59 170] [01-01 18:12:25 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:00:59 186] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:00:59 233] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:00:59 249] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:00:59 265] src/intelligent_track_thread.c(709) [TrackProcV200]: Intelligent Track Enable eSensitivity=0 intervalTime_sec=15
[2024/8/7 9:00:59 266] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:00:59 266] [01-01 18:12:25 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:00:59 986] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:00 003] [01-01 18:12:26 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:01:00 003] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:00 018] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:00 018] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:00 018] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:00 034] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:00 034] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:00 050] [01-01 18:12:26 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:00 050] [01-01 18:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:00 050] [01-01 18:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:00 066] [01-01 18:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:00 066] [01-01 18:12:26 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:01:00 066] [01-01 18:12:26 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:01:00 082] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:01:00 098] [01-01 18:12:26 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:01:00 114] [01-01 18:12:26 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:01:00 114] [01-01 18:12:26 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:00 130] [01-01 18:12:26 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:01:00 130] gethostbyname_r error: Unknown host
[2024/8/7 9:01:00 130] [01-01 18:12:26 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:01:00 146] [01-01 18:12:26 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:01:00 146] [01-01 18:12:26 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:01:00 162] [01-01 18:12:26 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:01:00 162] [01-01 18:12:26 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:01:00 178] [01-01 18:12:26 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:01:00 178] [01-01 18:12:26 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:01:00 178] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:01:00 561] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:01:00 561] Mode(Product):0
[2024/8/7 9:01:00 561] BpuMode:[Online]
[2024/8/7 9:01:00 561] VpssMode:[Online]
[2024/8/7 9:01:00 561] [0.LimitUp_info]:
[2024/8/7 9:01:00 561] LimitUp:[Disable]
[2024/8/7 9:01:00 577] [2680*0]->[3840*0])
[2024/8/7 9:01:00 577] chn	TotalSize	ActiveSize
[2024/8/7 9:01:00 577] 0	5040*2246	2680*2160
[2024/8/7 9:01:00 577] 0	5040*2246	3840*2160
[2024/8/7 9:01:00 577] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:01:00 577] [1.VICU_info]:
[2024/8/7 9:01:00 593] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:01:00 593] 0	25.0	366	0	0	183	linear	8ddb00
[2024/8/7 9:01:00 593] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:01:00 593] en	op_type	m_chn	now
[2024/8/7 9:01:00 593] 0	1	1	1
[2024/8/7 9:01:00 593] [2.VI_info]:
[2024/8/7 9:01:00 593] chn	TotalSize	ActiveSize
[2024/8/7 9:01:00 609] 0	5040*2246	3848*2166
[2024/8/7 9:01:00 609] 1	   0*   0	   0*   0
[2024/8/7 9:01:00 609] [3.MIPI_info]:
[2024/8/7 9:01:00 609] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:01:00 609] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:01:00 625] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:01:00 625] [4.Cut_info]:
[2024/8/7 9:01:00 625] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:01:00 625] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:01:00 625] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:01:00 641] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:01:00 641] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:01:00 641] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:01:00 641] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:01:00 641] [5.IB(isp buffer info)]:
[2024/8/7 9:01:00 657] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:01:00 657] PoolId  Count  Size
[2024/8/7 9:01:00 657] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:00 673] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:00 673] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:00 689] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:00 689] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:00 689] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:01:00 705] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:01:00 705] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:01:00 705] 0       0         0          3          4       
[2024/8/7 9:01:00 721] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:01:00 721]      --265--            --264--                                               
[2024/8/7 9:01:00 737] Count      Line     Count      Line     
[2024/8/7 9:01:00 737] 273        480      619        560      
[2024/8/7 9:01:00 737] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:01:00 753] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:01:00 753] 0   3840   2160    H265  0      0        0           167       983040     0        	
[2024/8/7 9:01:00 769] 1   640    360     H265  0      0        0           106       43197      3        	
[2024/8/7 9:01:00 769] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:01:00 785] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:01:00 785] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:01:00 801] 0   Y      167      0       0       15       0        167      167      237       65841         59008    122088   65063    12      
[2024/8/7 9:01:00 817] 1   Y      106      0       0       1        0        106      106      238       2227          1888     27580    3152     7       
[2024/8/7 9:01:00 817] 3   N      0        0       0       1        0        0        0        238       0             0        0        0        0       
[2024/8/7 9:01:00 833] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:01:00 849] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:00 852] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:00 865] [1970-01-01 00:00:22] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:00 881] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:00 881] [1970-01-01 00:00:22] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:00 897] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:00 897] [01-01 18:12:27 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:01:00 979] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:00 994] [01-01 18:12:27 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:01:00 994] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:01 010] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:01 010] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:01 010] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:01 026] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:01 026] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:01 042] [01-01 18:12:27 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:01 042] [01-01 18:12:27 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:01 042] [01-01 18:12:27 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:01 058] [01-01 18:12:27 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:01 058] [01-01 18:12:27 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:01:01 074] [01-01 18:12:27 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:01:01 074] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:01:01 090] [01-01 18:12:27 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:01:01 106] [01-01 18:12:27 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:01:01 106] [01-01 18:12:27 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:01 122] [01-01 18:12:27 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:01:01 122] gethostbyname_r error: Unknown host
[2024/8/7 9:01:01 122] [01-01 18:12:27 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:01:01 138] [01-01 18:12:27 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:01:01 138] [01-01 18:12:27 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:01:01 154] [01-01 18:12:27 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:01:01 154] [01-01 18:12:27 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:01:01 170] [01-01 18:12:27 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:01:01 170] [01-01 18:12:27 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:01:01 170] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:01:01 186] [01-01 18:12:27 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:01:02 114] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:02 129] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:02 145] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:02 161] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:02 161] [01-01 18:12:28 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:01:02 177] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:02 179] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:02 179] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:02 196] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:02 196] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:02 197] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:02 209] [01-01 18:12:28 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:02 209] [01-01 18:12:28 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:02 209] [01-01 18:12:28 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:02 225] [01-01 18:12:28 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:02 225] [01-01 18:12:28 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:01:02 241] [01-01 18:12:28 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:01:02 241] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:01:02 273] [01-01 18:12:28 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:01:02 273] [01-01 18:12:28 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:01:02 273] [01-01 18:12:28 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:02 289] [01-01 18:12:28 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:01:02 289] gethostbyname_r error: Unknown host
[2024/8/7 9:01:02 305] [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:01:02 305] [01-01 18:12:28 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:01:02 305] [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:01:02 321] [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:01:02 321] [01-01 18:12:28 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:01:02 337] [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:01:02 337] [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:01:02 353] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:01:02 353] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:02 353] ble_slave_gap_event->type=0
[2024/8/7 9:01:02 369] connection established; status=0 GATT procedure initiated: exchange mtu
[2024/8/7 9:01:02 369] connection, handle=1
[2024/8/7 9:01:02 369] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:02 386] --- tracepoint bt_ext_porting.c,ty_btext_thread(423): TY_BT_EVENT_CONNECTED1 ---
[2024/8/7 9:01:02 386] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 1
[2024/8/7 9:01:02 386] [01-01 18:12:28 TUYA N][tuya_ble_api.c:472] Ble Connected
[2024/8/7 9:01:02 401] [01-01 18:12:28 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[2024/8/7 9:01:02 401] [01-01 18:12:28 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
[2024/8/7 9:01:03 185] --- tracepoint bt_ext_porting.c,ty_btext_thread(425): TY_BT_EVENT_CONNECTED2 ---
[2024/8/7 9:01:03 185] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:03 201] [1970-01-01 00:00:24] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time24484
[2024/8/7 9:01:03 217] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:03 217] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:03 217] ble_slave_gap_event->type=15
[2024/8/7 9:01:03 234] mtu update event; conn_handle=1 cid=4 mtu=255
[2024/8/7 9:01:03 234] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:03 250] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:03 250] ble_slave_gap_event->type=4
[2024/8/7 9:01:03 250] connection update request
[2024/8/7 9:01:03 266] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:03 282] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:03 282] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:03 297] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:03 313] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:03 313] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:03 330] [01-01 18:12:29 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:01:03 330] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:03 330] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:03 345] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:03 346] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:03 361] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:03 361] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:03 361] [01-01 18:12:29 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:03 377] [01-01 18:12:29 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:03 377] [01-01 18:12:29 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:03 377] [01-01 18:12:29 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:03 393] [01-01 18:12:29 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:01:03 393] [01-01 18:12:29 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:01:03 409] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:01:03 425] [01-01 18:12:29 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:01:03 441] [01-01 18:12:29 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:01:03 441] [01-01 18:12:29 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:03 441] [01-01 18:12:29 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:01:03 457] gethostbyname_r error: Unknown host
[2024/8/7 9:01:03 457] [01-01 18:12:29 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:01:03 457] [01-01 18:12:29 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:01:03 473] [01-01 18:12:29 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:01:03 473] [01-01 18:12:29 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:01:03 489] [01-01 18:12:29 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:01:03 489] [01-01 18:12:29 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:01:03 505] [01-01 18:12:29 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:01:03 505] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:01:04 129] ble_slave_gap_event->type=3
[2024/8/7 9:01:04 145] connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:01:04 145] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 162] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 178] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 194] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:04 194] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 210] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 226] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 226] ble_slave_gap_event->type=4
[2024/8/7 9:01:04 226] connection update request
[2024/8/7 9:01:04 242] ble_slave_gap_event->type=14
[2024/8/7 9:01:04 242] subscribe event; conn_handle=1 attr_handle=23 reason=1 prevn=0 curn=1 previ=0 curi=0
[2024/8/7 9:01:04 258] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:01:04 258] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 274] [1970-01-01 00:00:25] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:04 274] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 274] ble_slave_gap_event->type=3
[2024/8/7 9:01:04 290] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:01:04 290] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 306] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:04 321] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:04 322] [01-01 18:12:30 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:01:04 338] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:04 338] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:04 338] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:04 353] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:04 354] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:04 369] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:04 369] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:04 370] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:04 385] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:04 385] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:04 401] [01-01 18:12:30 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:01:04 401] [01-01 18:12:30 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:01:04 401] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:01:04 433] [01-01 18:12:30 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:01:04 433] [01-01 18:12:30 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:01:04 449] [01-01 18:12:30 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:04 449] [01-01 18:12:30 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:01:04 449] gethostbyname_r error: Unknown host
[2024/8/7 9:01:04 465] [01-01 18:12:30 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:01:04 465] [01-01 18:12:30 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:01:04 481] [01-01 18:12:30 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:01:04 481] [01-01 18:12:30 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:01:04 497] [01-01 18:12:30 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:01:04 594] [01-01 18:12:30 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:01:04 610] [01-01 18:12:30 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:01:04 610] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:01:04 610] set basic_indicator_onoff:0 
[2024/8/7 9:01:04 626] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(257) <IPC_APP_set_basic_indicator_onoff>: Get BasicIndicator suc,gpio value=[0x0c]
[2024/8/7 9:01:04 641] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:04 642] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:04 642] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:01:04 657] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:04 657] Len=20 step 0
[2024/8/7 9:01:04 657] att=0x0 0x21 0x20 0x1 0xf7 0x2 0x96 0xb0 0xdc 0xbb 0x74 0xd6 0xd4 0xdc 0x89 0x96 0xb 0xd4 0xf3 0x51 
[2024/8/7 9:01:04 673]  RCVS len:20
[2024/8/7 9:01:04 673] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 689] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:04 689] XmBleReadBuf 20:
[2024/8/7 9:01:04 690] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:04 690] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:04 705] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:04 705] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:04 721] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:04 721] [01-01 18:12:30 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:04 722] [01-01 18:12:30 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:04 737] [01-01 18:12:30 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:04 738] bt_rev_raw 20
[2024/8/7 9:01:04 738] 00 21 20 01 f7 02 96 b0 dc bb 74 d6 d4 dc 89 96 0b d4 f3 51 
[2024/8/7 9:01:04 753] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:01:04 753] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:04 769] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:04 769] set basic_indicator_onoff:1 
[2024/8/7 9:01:04 785] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:04 787] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:04 787] Len=17 step 0
[2024/8/7 9:01:04 787] att=0x1 0xfc 0xa9 0xe9 0xa 0xcf 0x2c 0xfc 0xac 0xdd 0xfc 0xd8 0xfa 0x71 0xd6 0x6b 0x1c 
[2024/8/7 9:01:04 801]  RCVS len:17
[2024/8/7 9:01:04 802] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:04 802] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:04 817] XmBleReadBuf 17:
[2024/8/7 9:01:04 817] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:04 817] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:04 817] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:04 833] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:01:04 833] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:01:04 849] [01-01 18:12:30 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:01:04 849] [01-01 18:12:30 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:04 865] [01-01 18:12:30 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:04 865] bt_rev_raw 17
[2024/8/7 9:01:04 865] 01 fc a9 e9 0a cf 2c fc ac dd fc d8 fa 71 d6 6b 1c 
[2024/8/7 9:01:04 865] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:01:04 881] ble rev data 33
[2024/8/7 9:01:04 881] 01 f7 02 96 b0 dc bb 74 d6 d4 dc 89 96 0b d4 f3 51 fc a9 e9 0a cf 2c fc ac dd fc d8 fa 71 d6 6b 1c 
[2024/8/7 9:01:04 897] [01-01 18:12:30 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:01:04 897] ble decryped data 16
[2024/8/7 9:01:04 897] 00 00 00 01 00 00 00 00 00 00 00 00 92 69 00 00 
[2024/8/7 9:01:04 897] [01-01 18:12:30 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:01:04 913] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x0 
[2024/8/7 9:01:04 913] [01-01 18:12:30 TUYA N][tuya_ble_data_handler.c:451] tuya_ble_handle_dev_infor_req state:0, pkg_len:20
[2024/8/7 9:01:04 929] [01-01 18:12:30 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:01:04 929] [01-01 18:12:30 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:01:04 929] [01-01 18:12:30 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:01:04 945] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:4, send_data:16
[2024/8/7 9:01:04 945] tuya_hal_bt_send 20
[2024/8/7 9:01:04 945] 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:01:04 961] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:04 961] 0 81 1 30 1 57 27 a7 5 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:01:04 977] XmBleSendBuf 20: 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58
[2024/8/7 9:01:04 977] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:04 977] ble_slave_gap_event->type=13
[2024/8/7 9:01:04 977] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:04 992] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:04 993]  ---
[2024/8/7 9:01:04 993] [01-01 18:12:30 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:04 993] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:01:05 010] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:05 010] tuya_hal_bt_send 20
[2024/8/7 9:01:05 010] 01 3d 43 cc ad fe 1c 15 1e 3b de c4 af 53 63 d4 94 b9 44 25 
[2024/8/7 9:01:05 026] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:05 026] 1 3d 43 cc ad fe 1c 15 1e 3b de c4 af 53 63 d4 94 b9 44 25 
[2024/8/7 9:01:05 042] XmBleSendBuf 20: 01 3d 43 cc ad fe 1c 15 1e 3b de c4 af 53 63 d4 94 b9 44 25
[2024/8/7 9:01:05 042] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:05 042] ble_slave_gap_event->type=13
[2024/8/7 9:01:05 042] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:05 042] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:05 057]  ---
[2024/8/7 9:01:05 057] [01-01 18:12:30 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:05 058] set basic_indicator_onoff:0 
[2024/8/7 9:01:05 073] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:05 074] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:05 090] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:05 090] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:05 090] tuya_hal_bt_send 20
[2024/8/7 9:01:05 106] 02 f7 7c 47 10 e1 3d d2 bf 76 11 82 a1 55 14 3f 91 9b 15 79 
[2024/8/7 9:01:05 106] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:05 106] 2 f7 7c 47 10 e1 3d d2 bf 76 11 82 a1 55 14 3f 91 9b 15 79 
[2024/8/7 9:01:05 122] XmBleSendBuf 20: 02 f7 7c 47 10 e1 3d d2 bf 76 11 82 a1 55 14 3f 91 9b 15 79
[2024/8/7 9:01:05 122] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:05 122] ble_slave_gap_event->type=13
[2024/8/7 9:01:05 138] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:05 138] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:05 138] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:05 153] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:05 153] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:05 169] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:05 169] tuya_hal_bt_send 20
[2024/8/7 9:01:05 170] 03 48 a6 9a f8 fa 0c c2 65 0e 13 cf 64 e0 07 b1 76 42 6c 90 
[2024/8/7 9:01:05 185] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:05 185] 3 48 a6 9a f8 fa c c2 65 e 13 cf 64 e0 7 b1 76 42 6c 90 
[2024/8/7 9:01:05 201] XmBleSendBuf 20: 03 48 a6 9a f8 fa 0c c2 65 0e 13 cf 64 e0 07 b1 76 42 6c 90
[2024/8/7 9:01:05 201] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:05 201] ble_slave_gap_event->type=13
[2024/8/7 9:01:05 201] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:05 217] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:05 217] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:05 217] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:05 233] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:05 233] tuya_hal_bt_send 20
[2024/8/7 9:01:05 233] 04 ae 97 60 a0 dd 12 6f ee 3b 2f 7e 5b 14 8d ff de 07 c7 04 
[2024/8/7 9:01:05 249] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:05 249] 4 ae 97 60 a0 dd 12 6f ee 3b 2f 7e 5b 14 8d ff de 7 c7 4 
[2024/8/7 9:01:05 265] XmBleSendBuf 20: 04 ae 97 60 a0 dd 12 6f ee 3b 2f 7e 5b 14 8d ff de 07 c7 04
[2024/8/7 9:01:05 265] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:05 265] ble_slave_gap_event->type=13
[2024/8/7 9:01:05 265] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:05 281] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:05 281] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:05 281] set basic_indicator_onoff:1 
[2024/8/7 9:01:05 297] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:05 297] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:05 313] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:05 313] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:05 313] tuya_hal_bt_send 20
[2024/8/7 9:01:05 329] 05 5f d6 c9 f5 15 3b 86 50 cf 5c 36 d1 91 b3 8c 76 2b 61 03 
[2024/8/7 9:01:05 329] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:05 329] 5 5f d6 c9 f5 15 3b 86 50 cf 5c 36 d1 91 b3 8c 76 2b 61 3 
[2024/8/7 9:01:05 345] XmBleSendBuf 20: 05 5f d6 c9 f5 15 3b 86 50 cf 5c 36 d1 91 b3 8c 76 2b 61 03
[2024/8/7 9:01:05 345] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:05 345] ble_slave_gap_event->type=13
[2024/8/7 9:01:05 361] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:05 361] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:05 361] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:05 377] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:18
[2024/8/7 9:01:05 377] tuya_hal_bt_send 19
[2024/8/7 9:01:05 377] 06 fc 19 02 64 e3 23 d9 f5 c1 77 13 dc 82 11 90 27 b1 25 
[2024/8/7 9:01:05 393] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:05 393] 6 fc 19 2 64 e3 23 d9 f5 c1 77 13 dc 82 11 90 27 b1 25 
[2024/8/7 9:01:05 393] XmBleSendBuf 19: 06 fc 19 02 64 e3 23 d9 f5 c1 77 13 dc 82 11 90 27 b1 25
[2024/8/7 9:01:05 409] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:05 409] ble_slave_gap_event->type=13
[2024/8/7 9:01:05 409] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:05 409] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:05 425] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:05 425] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:05 425] set basic_indicator_onoff:0 
[2024/8/7 9:01:05 441] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:05 441] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:05 457] 
[2024/8/7 9:01:05 458] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:05 473] [01-01 18:12:31 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:129, send_ret:0x0
[2024/8/7 9:01:05 473] [01-01 18:12:31 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:0
[2024/8/7 9:01:05 473] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:05 489]  ---
[2024/8/7 9:01:05 490] Len=20 step 0
[2024/8/7 9:01:05 505] att=0x0 0x51 0x20 0x2 0xd2 0x10 0xaa 0x0 0xbb 0xa2 0xd3 0x1e 0x98 0xe0 0xd0 0x75 0xd8 0x3 0x24 0x75 [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:05 505]  RCVS len:20
[2024/8/7 9:01:05 505] set basic_indicator_onoff:1 
[2024/8/7 9:01:05 505] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:05 521] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:05 521] XmBleReadBuf 20:
[2024/8/7 9:01:05 521] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:05 537] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:05 537] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:05 537] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:05 553] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:05 553] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:05 569] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:05 569] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:05 569] bt_rev_raw 20
[2024/8/7 9:01:05 569] 00 51 20 02 d2 10 aa 00 bb a2 d3 1e 98 e0 d0 75 d8 03 24 75 
[2024/8/7 9:01:05 585] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:01:05 601] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:05 601] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:05 601] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:05 617] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:05 617] Len=20 step 0
[2024/8/7 9:01:05 617] att=0x1 0xa5 0xd5 0x49 0xfe 0xf8 0x0 0xe4 0xf3 0xca 0xc8 0xf9 0x5d 0x8d 0x47 0x91 0xcd 0xbb 0x7 0x14 
[2024/8/7 9:01:05 617]  RCVS len:20
[2024/8/7 9:01:05 634] [01-01 18:12:31 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:01:05 634] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:05 650] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:05 650] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:05 650] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:05 666] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:05 666] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:05 682] [01-01 18:12:31 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:05 682] [01-01 18:12:31 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:05 682] [01-01 18:12:31 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:05 698] [01-01 18:12:31 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:05 698] [01-01 18:12:31 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:01:05 714] [01-01 18:12:31 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:01:05 714] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:01:05 730] [01-01 18:12:31 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:01:05 746] [01-01 18:12:31 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:01:05 746] [01-01 18:12:31 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:05 762] [01-01 18:12:31 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:01:05 762] gethostbyname_r error: Unknown host
[2024/8/7 9:01:05 762] [01-01 18:12:31 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:01:05 777] [01-01 18:12:31 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:01:05 777] [01-01 18:12:31 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:01:05 793] [01-01 18:12:31 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:01:05 794] [01-01 18:12:31 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:01:05 809] [01-01 18:12:31 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:01:05 809] [01-01 18:12:31 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:01:05 809] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:01:05 826] XmBleReadBuf 20:
[2024/8/7 9:01:05 826] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:05 826] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:05 826] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:05 841] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:05 841] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:05 857] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:05 857] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:05 873] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:05 873] bt_rev_raw 20
[2024/8/7 9:01:05 873] 01 a5 d5 49 fe f8 00 e4 f3 ca c8 f9 5d 8d 47 91 cd bb 07 14 
[2024/8/7 9:01:05 890] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:01:05 890] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:05 890] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:05 905] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:05 905] Len=20 step 0
[2024/8/7 9:01:05 921] att=0x2 0x90 [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:05 921] 0xf3 0x3a 0xc3 0xd1 0xe6 0xeb 0x42 0x9a 0xb8 0x57 0x83 0x3a 0x84 0x2c 0xe6 0xbb 0x56 0xbc 
[2024/8/7 9:01:05 921]  RCVS len:20
[2024/8/7 9:01:05 937] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:05 937] XmBleReadBuf 20:
[2024/8/7 9:01:05 937] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:05 937] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:05 953] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:05 953] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:05 969] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:05 969] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:05 969] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:05 985] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:05 985] bt_rev_raw 20
[2024/8/7 9:01:05 985] 02 90 f3 3a c3 d1 e6 eb 42 9a b8 57 83 3a 84 2c e6 bb 56 bc 
[2024/8/7 9:01:06 001] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:01:06 001] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:06 017] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:06 017] set basic_indicator_onoff:0 
[2024/8/7 9:01:06 033] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:06 035] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:06 035] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:06 035] Len=20 step 0
[2024/8/7 9:01:06 049] att=0x3 0x84 0xc 0x95 0x94 0x88 0x41 0x10 0x1f 0x30 0x5e 0x66 0xfb 0x2c 0xf6 0xe6 0x1b 0x9c 0x89 0x61 
[2024/8/7 9:01:06 049]  RCVS len:20
[2024/8/7 9:01:06 065] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:06 066] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:06 066] XmBleReadBuf 20:
[2024/8/7 9:01:06 066] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:06 081] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:06 081] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:06 081] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:06 097] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:06 097] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:06 113] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:06 113] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:06 113] bt_rev_raw 20
[2024/8/7 9:01:06 113] 03 84 0c 95 94 88 41 10 1f 30 5e 66 fb 2c f6 e6 1b 9c 89 61 
[2024/8/7 9:01:06 129] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:01:06 145] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:06 145] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:06 145] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:06 162] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:06 162] Len=8 step 0
[2024/8/7 9:01:06 177] att=0x4 0x88 0x21 0x1c 0x6d 0x26 0x8e 0x73 
[2024/8/7 9:01:06 178]  RCVS len:8
[2024/8/7 9:01:06 178] set basic_indicator_onoff:1 
[2024/8/7 9:01:06 193] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:06 194] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:06 194] XmBleReadBuf 8:
[2024/8/7 9:01:06 209] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:06 209] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:06 209] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:06 225] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 16 rcount 16 offset 0 ---
[2024/8/7 9:01:06 225] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 16 ---
[2024/8/7 9:01:06 241] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x9]
[2024/8/7 9:01:06 241] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:06 241] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:06 241] bt_rev_raw 8
[2024/8/7 9:01:06 257] 04 88 21 1c 6d 26 8e 73 
[2024/8/7 9:01:06 257] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:5, pack_len:7, total_len:81
[2024/8/7 9:01:06 257] ble rev data 81
[2024/8/7 9:01:06 273] 02 d2 10 aa 00 bb a2 d3 1e 98 e0 d0 75 d8 03 24 75 a5 d5 49 fe f8 00 e4 f3 ca c8 f9 5d 8d 47 91 cd bb 07 14 90 f3 3a c3 d1 e6 eb 42 9a b8 57 83 3a 84 2c e6 bb 56 bc 84 0c 95 94 88 41 10 1f 30 
[2024/8/7 9:01:06 289] 5e 66 fb 2c f6 e6 1b 9c 89 61 88 21 1c 6d 26 8e 73 
[2024/8/7 9:01:06 289] ble decryped data 64
[2024/8/7 9:01:06 305] 00 00 00 02 00 00 00 00 00 01 00 2c 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca 1e 00 00 00 00 00 00 
[2024/8/7 9:01:06 305] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:01:06 321] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x1 
[2024/8/7 9:01:06 321] [01-01 18:12:31 TUYA D][tuya_ble_api.c:573] conn monitor timer stopped
[2024/8/7 9:01:06 321] [01-01 18:12:31 TUYA N][tuya_ble_api.c:1464] ble set conn stat:3
[2024/8/7 9:01:06 337] [01-01 18:12:31 TUYA N][tuya_ble_data_handler.c:367] PAIR_REQ ok:0
[2024/8/7 9:01:06 337] [01-01 18:12:31 TUYA N][tuya_ble_data_handler.c:342] ble_time_req start...
[2024/8/7 9:01:06 353] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:348] no need to query time. network stat:1, work stat:0
[2024/8/7 9:01:06 353] [01-01 18:12:31 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:01:06 369] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:06 370] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:06 370] tuya_hal_bt_send 20
[2024/8/7 9:01:06 385] 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:01:06 385] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:06 385] 0 21 31 2 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:01:06 401] XmBleSendBuf 20: 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c
[2024/8/7 9:01:06 401] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:06 401] ble_slave_gap_event->type=13
[2024/8/7 9:01:06 401] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:06 417] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:06 417] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:06 417] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:16 ---
[2024/8/7 9:01:06 433] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:06 449] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:01:06 449] tuya_hal_bt_send 17
[2024/8/7 9:01:06 449] 01 ad 80 9d 97 d1 04 28 cd e7 b6 1e 95 b1 41 bc 57 
[2024/8/7 9:01:06 465] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:06 465] 1 ad 80 9d 97 d1 4 28 cd e7 b6 1e 95 b1 41 bc 57 
[2024/8/7 9:01:06 465] XmBleSendBuf 17: 01 ad 80 9d 97 d1 04 28 cd e7 b6 1e 95 b1 41 bc 57
[2024/8/7 9:01:06 481] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:06 482] ble_slave_gap_event->type=13
[2024/8/7 9:01:06 482] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:06 482] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:06 497] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:06 497] set basic_indicator_onoff:0 
[2024/8/7 9:01:06 497] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:06 513] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:06 513] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:06 529] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:06 529] Len=20 step 0
[2024/8/7 9:01:06 529] att=0x0 0x61 0x20 0x2 0x64 0x78 0xdd 0xb1 0xf6 0xb2 0xdc 0x9b 0xc6 0x9c 0x69 0x16 0xa4 0x46 0xab 0xb8 
[2024/8/7 9:01:06 529]  RCVS len:20
[2024/8/7 9:01:06 545] XmBleReadBuf 20:
[2024/8/7 9:01:06 545] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:06 545] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:06 545] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:06 561] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:06 561] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:06 577] [01-01 18:12:31 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:01:06 577] [01-01 18:12:31 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:1
[2024/8/7 9:01:06 593] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:06 593] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:06 593] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:06 593] bt_rev_raw 20
[2024/8/7 9:01:06 609] 00 61 20 02 64 78 dd b1 f6 b2 dc 9b c6 9c 69 16 a4 46 ab b8 
[2024/8/7 9:01:06 609] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:01:06 625] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:06 625] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:06 641] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:06 641] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:06 641] Len=20 step 0
[2024/8/7 9:01:06 657] att=0x1 0x5 0xce 0x46 0x3e 0x50 0x0 0x4b 0x36 0x8a 0xf2 0x3c 0x54 0xf9 0xab 0x23 0x9d 0xd 0x3 0xe2 
[2024/8/7 9:01:06 657]  RCVS len:20
[2024/8/7 9:01:06 657] set basic_indicator_onoff:1 
[2024/8/7 9:01:06 673] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:06 673] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:06 689] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:06 689] XmBleReadBuf 20:
[2024/8/7 9:01:06 689] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:06 705] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:06 705] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:06 705] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:06 721] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:06 721] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:06 737] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:06 737] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:06 737] bt_rev_raw 20
[2024/8/7 9:01:06 737] 01 05 ce 46 3e 50 00 4b 36 8a f2 3c 54 f9 ab 23 9d 0d 03 e2 
[2024/8/7 9:01:06 753] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:01:06 753] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:06 769] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:01:06 769] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:06 785] [01-01 18:12:32 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:01:06 785] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1376] nw stat change:1->1, rpt to app.
[2024/8/7 9:01:06 801] [01-01 18:12:32 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:01:06 801] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:06 801] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:06 802]  ---
[2024/8/7 9:01:06 802] Len=20 step 0
[2024/8/7 9:01:06 817] att=0x2 0xe8 0x62 0xf4 0xb2 0xeb 0xa0 0xf8 0xa 0x2d 0xaa 0xf2 0xbd 0x1c 0xa3 0xdb 0x51 0xf3 0x28 0x64 
[2024/8/7 9:01:06 817]  RCVS len:20
[2024/8/7 9:01:06 817] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:06 833] XmBleReadBuf 20:
[2024/8/7 9:01:06 833] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:06 833] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:06 833] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:06 849] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:06 849] --- t[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:01:06 865] racepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:06 865] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:06 865] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:06 881] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:06 881] bt_rev_raw 20
[2024/8/7 9:01:06 881] 02 e8 62 f4 b2 eb a0 f8 0a 2d aa f2 bd 1c a3 db 51 f3 28 64 
[2024/8/7 9:01:06 897] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:01:06 897] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:06 913] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:06 913] set basic_indicator_onoff:0 
[2024/8/7 9:01:06 929] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:06 929] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:06 945] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait[atbm_log]:[ieee80211_csa_cancel][mon.eth2]:[0][0]
[2024/8/7 9:01:06 945]  for g_DeviceOnline ... 
[2024/8/7 9:01:06 945] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:06 945] Len=20 step 0
[2024/8/7 9:01:06 961] att=0x3 0x21 0x88 0xa4 0x3e 0xa2 0x94 0x93 0x2d 0xbc 0x4a 0x69 0x67 0xc5 0xc6 0xc7 0x43 0x49 0x9c 0xc2 
[2024/8/7 9:01:06 962]  RCVS len:20
[2024/8/7 9:01:06 962] XmBleReadBuf 20:
[2024/8/7 9:01:06 962] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:06 977] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:06 977] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:06 977] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:06 993] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:06 993] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:07 009] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:07 009] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:07 009] bt_rev_raw 20
[2024/8/7 9:01:07 009] 03 21 88 a4 3e a2 94 93 2d bc 4a 69 67 c5 c6 c7 43 49 9c c2 
[2024/8/7 9:01:07 025] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:01:07 025] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:07 041] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:07 057] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:07 057] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:07 073] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:07 074] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:07 074] Len=20 step 0
[2024/8/7 9:01:07 089] att=0x4 0xb2 0x13 0x75 0xcc 0xbe 0x7f 0xb2 0x61 0x46 0x46 0xee 0x59 0xc9 0x94 0x9b 0x7d 0xfe 0xe8 0x72 
[2024/8/7 9:01:07 089]  RCVS len:20
[2024/8/7 9:01:07 089] [01-01 18:12:32 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:01:07 089] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:07 106] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:07 106] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:07 121] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:07 121] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:07 121] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:07 137] [01-01 18:12:32 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:07 137] [01-01 18:12:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:07 137] [01-01 18:12:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:07 153] [01-01 18:12:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:07 153] XmBleReadBuf 20:
[2024/8/7 9:01:07 153] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:07 169] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:07 170] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:07 170] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:07 185] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:07 185] [01-01 18:12:32 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:01:07 185] [01-01 18:12:32 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:01:07 201] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:01:07 217] [01-01 18:12:32 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:01:07 233] [01-01 18:12:32 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:01:07 233] [01-01 18:12:32 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:07 249] [01-01 18:12:32 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:01:07 265] gethostbyname_r error: Unknown host
[2024/8/7 9:01:07 266] [01-01 18:12:32 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:01:07 266] [01-01 18:12:32 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:01:07 281] [01-01 18:12:32 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:01:07 281] [01-01 18:12:32 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:01:07 297] [01-01 18:12:32 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:01:07 297] [01-01 18:12:32 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:01:07 313] [01-01 18:12:32 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:01:07 313] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:01:07 313] [01-01 18:12:32 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:01:07 329] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:07 329] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:07 345] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:07 345] bt_rev_raw 20
[2024/8/7 9:01:07 345] 04 b2 13 75 cc be 7f b2 61 46 46 ee 59 c9 94 9b 7d fe e8 72 
[2024/8/7 9:01:07 361] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:5, pack_len:19, total_len:93
[2024/8/7 9:01:07 361] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:07 361] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:07 377] set basic_indicator_onoff:1 
[2024/8/7 9:01:07 377] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:07 393] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:07 393] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:07 393] Len=5 step 0
[2024/8/7 9:01:07 393] att=0x5 0x64 0xf8 0x7a 0x70 
[2024/8/7 9:01:07 393]  RCVS len:5
[2024/8/7 9:01:07 409] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:07 409] set basic_indicator_onoff:0 
[2024/8/7 9:01:07 425] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:07 442] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:07 443] 
[2024/8/7 9:01:07 443] XmBleReadBuf 5:
[2024/8/7 9:01:07 443] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:07 443] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:07 457] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:07 457] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 13 rcount 13 offset 0 ---
[2024/8/7 9:01:07 457] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 13 ---
[2024/8/7 9:01:07 473] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x6]
[2024/8/7 9:01:07 474] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:07 490] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:07 490] bt_rev_raw 5
[2024/8/7 9:01:07 490] 05 64 f8 7a 70 
[2024/8/7 9:01:07 491] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:6, pack_len:4, total_len:97
[2024/8/7 9:01:07 491] ble rev data 97
[2024/8/7 9:01:07 521] 02 64 78 dd b1 f6 b2 dc 9b c6 9c 69 16 a4 46 ab b8 05 ce 46 3e 50 00 4b 36 8a f2 3c 54 f9 ab 23 9d 0d 03 e2 e8 62 f4 b2 eb a0 f8 0a 2d aa f2 bd 1c a3 db 51 f3 28 64 21 88 a4 3e a2 94 93 2d bc 
[2024/8/7 9:01:07 521] 4a 69 67 c5 c6 c7 43 49 9c c2 b2 13 75 cc be 7f b2 61 46 46 ee 59 c9 94 9b 7d fe e8 72 64 f8 7a 70 
[2024/8/7 9:01:07 521] ble decryped data 80
[2024/8/7 9:01:07 537] 00 00 00 03 00 00 00 00 00 21 00 41 7b 22 70 77 64 22 3a 22 78 6d 35 31 32 35 32 30 22 2c 22 73 73 69 64 22 3a 22 58 69 61 6f 6d 69 5f 46 31 44 43 22 2c 22 74 6f 6b 65 6e 22 3a 22 41 59 76 58 
[2024/8/7 9:01:07 553] 57 78 77 57 41 71 31 37 36 39 22 7d 00 a4 42 00 
[2024/8/7 9:01:07 553] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:07 553] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:01:07 569] :675] Parse BT Cmd:0x21 
[2024/8/7 9:01:07 569] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:33 Has No def operate
[2024/8/7 9:01:07 569] [01-01 18:12:32 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:33
[2024/8/7 9:01:07 585] [01-01 18:12:32 TUYA N][bt_netcfg.c:63] Rev Net Cfg:{"pwd":"xm512520","ssid":"Xiaomi_F1DC","token":"AYvXWxwWAq1769"}
[2024/8/7 9:01:07 585] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:07 601] [01-01 18:12:32 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x21 encrpyt:2
[2024/8/7 9:01:07 601] bt_ack_uncrypt 1
[2024/8/7 9:01:07 601] 00 
[2024/8/7 9:01:07 601] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:07 617] [01-01 18:12:32 TUYA N][bt_netcfg.c:98] cfg ssid:Xiaomi_F1DC, passwd:xm512520, token:AYvXWxwWAq1769
[2024/8/7 9:01:07 633] [01-01 18:12:32 TUYA D][tuya_devos_netcfg.c:464] concurrent Netcfg Finish type:0x10004 ssid:Xiaomi_F1DC passwd:xm512520 cur_netcfg_type:0
[2024/8/7 9:01:07 633] [01-01 18:12:32 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:07 633] tuya_hal_bt_send 20
[2024/8/7 9:01:07 649] 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:01:07 649] [01-01 18:12:32 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:07 649] 0 21 32 2 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:01:07 665] XmBleSendBuf 20: 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7
[2024/8/7 9:01:07 665] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:07 665] ble_slave_gap_event->type=13
[2024/8/7 9:01:07 681] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:07 681] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:07 681] [01-01 18:12:32 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:07 697] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:13 ---
[2024/8/7 9:01:07 697] [01-01 18:12:32 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:01:07 697] tuya_hal_bt_send 17
[2024/8/7 9:01:07 713] 01 97 2d 9b 6f 46 bb 33 66 ef 40 22 8f 2a a4 77 ba 
[2024/8/7 9:01:07 713] [01-01 18:12:32 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:07 713] 1 97 2d 9b 6f 46 bb 33 66 ef 40 22 8f 2a a4 77 ba 
[2024/8/7 9:01:07 729] XmBleSendBuf 17: 01 97 2d 9b 6f 46 bb 33 66 ef 40 22 8f 2a a4 77 ba
[2024/8/7 9:01:07 729] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:07 729] ble_slave_gap_event->type=13
[2024/8/7 9:01:07 729] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:07 745] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:07 745] [01-01 18:12:32 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:07 761] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:07 761] [01-01 18:12:32 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:01:07 777] [01-01 18:12:32 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait
[2024/8/7 9:01:07 777] [01-01 18:12:32 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10002
[2024/8/7 9:01:07 793] [01-01 18:12:32 TUYA D][ap_netcfg.c:950] ap cfg stop:65538
[2024/8/7 9:01:07 793] [01-01 18:12:32 TUYA D][uni_thread.c:310] Del Thrd:udp_ap_v3
[2024/8/7 9:01:07 793] Received SIGTERM
[2024/8/7 9:01:07 793] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:01:07 809] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:07 809] set basic_indicator_onoff:1 
[2024/8/7 9:01:07 825] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:07 825] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:07 841] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:07 841] [1970-01-01 00:00:28] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:07 841] set basic_indicator_onoff:0 
[2024/8/7 9:01:07 857] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:07 857] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:07 873] [1970-01-01 00:00:28] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time28752
[2024/8/7 9:01:07 873] [1970-01-01 00:00:28] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 115683
[2024/8/7 9:01:07 889] set basic_indicator_onoff:1 
[2024/8/7 9:01:07 889] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:07 905] [1970-01-01[atbm_log]:[eth2] change to [2]
[2024/8/7 9:01:07 905]  00:00:28] ==> X[atbm_log]:[eth2] has been disabled
[2024/8/7 9:01:07 905] MSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:07 921] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:01:07 921] [01-01 18:12:33 TUYA D][ap_netcfg.c:553] wf_ap_stop:0
[2024/8/7 9:01:07 921] set basic_indicator_onoff:0 
[2024/8/7 9:01:07 937] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:07 937] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:07 953] set basic_indicator_onoff:1 
[2024/8/7 9:01:07 953] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:07 969] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:07 969] [01-01 18:12:33 TUYA N][ap_netcfg.c:172] exit ap_net_cfg task
[2024/8/7 9:01:07 969] [01-01 18:12:33 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10100
[2024/8/7 9:01:07 985] [01-01 18:12:33 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10004
[2024/8/7 9:01:07 985] [01-01 18:12:33 TUYA N][tuya_ble_api.c:439] update bound stat:1
[2024/8/7 9:01:08 017] [01-01 18:12:33 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:0
[2024/8/7 9:01:08 032] [01-01 18:12:33 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:01:08 032] [01-01 18:12:33 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:01:08 048] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:01:08 049] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:08 049] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:08 065] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:08 065] [01-01 18:12:33 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:01:08 065] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:01:08 080] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:08 081] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:08 081] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:08 096] [01-01 18:12:33 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:01:08 097] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:01:08 112] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:08 112] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:08 113] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:08 129] [01-01 18:12:33 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:01:08 129] [01-01 18:12:33 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:01:08 129] [01-01 18:12:33 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:01:08 145] [01-01 18:12:33 TUYA N][tuya_devos_activate.c:774] already inited
[2024/8/7 9:01:08 145] set basic_indicator_onoff:0 
[2024/8/7 9:01:08 160] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:08 160] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:08 160] set basic_indicator_onoff:1 
[2024/8/7 9:01:08 177] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:08 177] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:08 193] [01-01 18:12:33 TUYA D][uni_thread.c:268] Thread:udp_ap_v3 Exec Finish. Set to Del Stat
[2024/8/7 9:01:08 193] [01-01 18:12:33 TUYA D][uni_thread.c:125] del list not empty...deleting 0x1d02dc4, next 0x1cef4a0
[2024/8/7 9:01:08 208] [01-01 18:12:33 TUYA D][uni_thread.c:132] Final Free Thread:udp_ap_v3, is_self:1
[2024/8/7 9:01:08 209] [01-01 18:12:33 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:01:08 224] [01-01 18:12:33 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:01:08 224] set basic_indicator_onoff:0 
[2024/8/7 9:01:08 224] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:08 241] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:08 241] curr event:5 
[2024/8/7 9:01:08 241] IPC_APP_Notify_LED_Sound_Status_CB line(491) -------------------------- IPC_CONNECTING_WIFI(5)
[2024/8/7 9:01:08 257] [1970-01-01 00:00:29] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/RouterConnect_english.pcm]
[2024/8/7 9:01:08 273] [1970-01-01 00:00:29] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:01:08 273] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:01:08 273] set basic_indicator_onoff:1 
[2024/8/7 9:01:08 289] [1970-01-01 00:00:29] tuya_ipc_system_control_demo.c(492) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECTING, 0, 0, 0, 1))
[2024/8/7 9:01:08 305] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:08 305] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:08 321] --- tracepoint MainApp.c,ConfigTimer(372): g_WifiConectStatuts 1 ---
[2024/8/7 9:01:08 321] [1970-01-01 00:00:29] MainApp.c(373) <ConfigTimer>: ConfigTimer exit ----
[2024/8/7 9:01:08 337] [01-01 18:12:34 TUYA I][bt_ext_porting.c:618] [TUYA-BTUART]ble_monitor_thread exit
[2024/8/7 9:01:08 737] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 ++++++++ 
[2024/8/7 9:01:08 753] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 --------- 
[2024/8/7 9:01:08 753] [atbm_log]:atbm_hw_scan:if_id(0)
[2024/8/7 9:01:08 753] [atbm_log]:atbm_hw_scan:scan, delay suspend
[2024/8/7 9:01:08 817] [atbm_log]:scan start band(0),(14)
[2024/8/7 9:01:09 297] set basic_indicator_onoff:0 
[2024/8/7 9:01:09 297] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 313] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:09 313] set basic_indicator_onoff:1 
[2024/8/7 9:01:09 329] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 329] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:09 329] set basic_indicator_onoff:0 
[2024/8/7 9:01:09 345] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 345] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:09 361] set basic_indicator_onoff:1 
[2024/8/7 9:01:09 361] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 377] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:09 377] set basic_indicator_onoff:0 
[2024/8/7 9:01:09 377] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 393] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:09 393] set basic_indicator_onoff:1 
[2024/8/7 9:01:09 409] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 409] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:09 409] set basic_indicator_onoff:0 
[2024/8/7 9:01:09 424] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 424] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:09 425] 
[2024/8/7 9:01:09 440] set basic_indicator_onoff:1 
[2024/8/7 9:01:09 441] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 456] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:09 457] 
[2024/8/7 9:01:09 457] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:09 457] set basic_indicator_onoff:0 
[2024/8/7 9:01:09 472] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 473] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:09 473] set basic_indicator_onoff:1 
[2024/8/7 9:01:09 488] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 505] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:09 505] set basic_indicator_onoff:0 
[2024/8/7 9:01:09 505] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 521] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:09 521] set basic_indicator_onoff:1 
[2024/8/7 9:01:09 537] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 537] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:09 537] set basic_indicator_onoff:0 
[2024/8/7 9:01:09 553] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 553] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:09 553] set basic_indicator_onoff:1 
[2024/8/7 9:01:09 569] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:09 585] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:09 586] g_AudioTipsList.size() enable: 0[01-01 18:12:35 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:01:10 193] [atbm_log]:hw_priv->scan.status 0
[2024/8/7 9:01:10 193] [atbm_log]:atbm_scan_work:end(0)
[2024/8/7 9:01:10 256] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:01:10 272] [atbm_log]:authen:(a4:a9:30:ce:5e:66),ssid(Xiaomi_F1DC)
[2024/8/7 9:01:10 272] [atbm_log]:authenticate[a4:a9:30:ce:5e:66]:[0][1]
[2024/8/7 9:01:10 272] [atbm_log]:eth2: authenticate with a4:a9:30:ce:5e:66 (try 1) (1)(0)
[2024/8/7 9:01:10 288] [atbm_log]:[STA] Join DTIM: 1, interval: 100
[2024/8/7 9:01:10 304] [atbm_log]:[TX]:authen, delay suspend
[2024/8/7 9:01:10 304] [atbm_log]:eth2: authenticated
[2024/8/7 9:01:10 304] [atbm_log]:work:flush sta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:10 320] [atbm_log]:sta has been insert(0)
[2024/8/7 9:01:10 320] [atbm_log]:wk->assoc.use_he 1 1++
[2024/8/7 9:01:10 320] [atbm_log]:flush sta(0):
[2024/8/7 9:01:10 385] [atbm_log]:eth2: associated
[2024/8/7 9:01:10 385] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:01:10 385] [atbm_log]:eth2:free authen bss --
[2024/8/7 9:01:10 385] [atbm_log]:is_wifi6_ap++
[2024/8/7 9:01:10 385] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:01:10 401] [atbm_log]:eth2  WMM AC=0 acm=0 aifs=2 cWmin=3 cWmax=7 txop=47 uapsd=0
[2024/8/7 9:01:10 401] [atbm_log]:eth2  WMM AC=1 acm=0 aifs=2 cWmin=7 cWmax=15 txop=94 uapsd=0
[2024/8/7 9:01:10 417] [atbm_log]:eth2  WMM AC=2 acm=0 aifs=3 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:01:10 433] [atbm_log]:eth2  WMM AC=3 acm=0 aifs=7 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:01:10 449] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:01:10 449] [atbm_log]:[a4:a9:30:ce:5e:66]:20M channel
[2024/8/7 9:01:10 449] [atbm_log]:atbm_bss_info_changed:chatype(1),channelNumber(3)
[2024/8/7 9:01:10 497] [atbm_log]:BssidColor[34]
[2024/8/7 9:01:10 497] [atbm_log]:[STA] color 34, he_support_flag: 53
[2024/8/7 9:01:10 497] [atbm_log]:==>connect wifi6 AP open AX, set BA WIN short
[2024/8/7 9:01:10 513] [atbm_log]:[eth2] Waiting Txq Ready[1]
[2024/8/7 9:01:10 592] [atbm_log]:connecting done for waitting dhcp  
[2024/8/7 9:01:10 657] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:01:10 657] [atbm_log]:[eth2]:dtim changed [0]->[1]
[2024/8/7 9:01:10 673] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:01:10 673] NOHZ: local_softirq_pending 08
[2024/8/7 9:01:10 689] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:01:10 689] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:01:10 705] [atbm_log]:send htc qos null
[2024/8/7 9:01:10 705] [atbm_log]:om work(1)
[2024/8/7 9:01:10 721] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:01:10 721] set basic_indicator_onoff:0 
[2024/8/7 9:01:10 721] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 737] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:10 737] set basic_indicator_onoff:1 
[2024/8/7 9:01:10 753] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 753] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:10 753] set basic_indicator_onoff:0 
[2024/8/7 9:01:10 769] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 769] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:10 785] [1970-01-01 00:00:31] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:10 785] set basic_indicator_onoff:1 
[2024/8/7 9:01:10 801] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 801] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:10 801] set basic_indicator_onoff:0 
[2024/8/7 9:01:10 817] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 817] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:10 833] set basic_indicator_onoff:1 
[2024/8/7 9:01:10 833] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 849] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:10 849] [1970-01-01 00:00:32] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:01:10 865] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:01:10 865] set basic_indicator_onoff:0 
[2024/8/7 9:01:10 865] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 881] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:10 881] set basic_indicator_onoff:1 
[2024/8/7 9:01:10 897] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 897] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:10 897] set basic_indicator_onoff:0 
[2024/8/7 9:01:10 913] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 913] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:10 928] set basic_indicator_onoff:1 
[2024/8/7 9:01:10 929] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 945] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:10 945] set basic_indicator_onoff:0 
[2024/8/7 9:01:10 945] [1970-01-01 00:00:32] tuya_ipc_dp_ha[atbm_log]:QosNUll Htc(807)
[2024/8/7 9:01:10 945] ndler.c(262) <IP[atbm_log]:send htc qos null
[2024/8/7 9:01:10 961] C_APP_set_basic_[atbm_log]:om work(2)
[2024/8/7 9:01:10 961] indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 961] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:10 978] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:10 978] set basic_indicator_onoff:1 
[2024/8/7 9:01:10 993] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:10 995] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:11 008] [1970-01-01 00:00:32] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time32771
[2024/8/7 9:01:11 008] [01-01 18:12:37 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:01:11 201] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:01:11 201] [atbm_log]:send htc qos null
[2024/8/7 9:01:11 201] [atbm_log]:om work(3)
[2024/8/7 9:01:11 488] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:01:11 505] [atbm_log]:send htc qos null
[2024/8/7 9:01:11 505] [atbm_log]:om work(4)
[2024/8/7 9:01:11 745] [atbm_log]:om done
[2024/8/7 9:01:11 889] [atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:01:11 889] [atbm_log]:aggtx stop queue
[2024/8/7 9:01:11 889] [atbm_log]:add to pending(2)(20)
[2024/8/7 9:01:11 937] [atbm_log]:AMPDU[eth2]:action[2],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:11 937] [atbm_log]:activated addBA response timer on tid 0
[2024/8/7 9:01:11 937] [atbm_log]:aggtx wake queue
[2024/8/7 9:01:11 937] [atbm_log]:sta_hdr
[2024/8/7 9:01:11 953] [atbm_log]:switched off addBA timer for tid 0
[2024/8/7 9:01:11 953] [atbm_log]:Aggregation is on for tid 0
[2024/8/7 9:01:11 953] [atbm_log]:AMPDU[eth2]:action[4],tid[0],ssn[0],buff_size[64],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:11 969] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[0]
[2024/8/7 9:01:11 969] [atbm_log]:AMPDU[eth2]:action[0],tid[0],ssn[0],buff_size[64],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:11 985] [atbm_log]:Rx A-MPDU request on tid 0 result 0
[2024/8/7 9:01:11 985] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[6]
[2024/8/7 9:01:12 001] [atbm_log]:AMPDU[eth2]:action[0],tid[6],ssn[1],buff_size[64],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:12 033] [atbm_log]:Rx A-MPDU request on tid 6 result 0
[2024/8/7 9:01:12 144] route: SIOCDELRT: No such process
[2024/8/7 9:01:12 705] set basic_indicator_onoff:0 
[2024/8/7 9:01:12 722] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 722] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:12 738] set basic_indicator_onoff:1 
[2024/8/7 9:01:12 738] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 754] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:12 754] set basic_indicator_onoff:0 
[2024/8/7 9:01:12 754] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 768] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:12 768] set basic_indicator_onoff:1 
[2024/8/7 9:01:12 784] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 784] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:12 784]  tbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[5]
[2024/8/7 9:01:12 801] [0;39m
[2024/8/7 9:01:12 802] set basi[atbm_log]:<WIFI> rx ampdu ++ 
[2024/8/7 9:01:12 802] c_indicator_onof[atbm_log]:napi schedule
[2024/8/7 9:01:12 802] f:0 
[2024/8/7 9:01:12 817] [197[atbm_log]:AMPDU[eth2]:action[0],tid[5],ssn[3],buff_size[64],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:12 817] 0-01-01 00:00:33] tuya_i[atbm_log]:Rx A-MPDU request on tid 5 result 0
[2024/8/7 9:01:12 817] pc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 833] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:12 833] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:1
[2024/8/7 9:01:12 849] set basic_indicator_onoff:1 
[2024/8/7 9:01:12 849] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 865] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:12 865] set basic_indicator_onoff:0 
[2024/8/7 9:01:12 865] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 881] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:12 881] set basic_indicator_onoff:1 
[2024/8/7 9:01:12 897] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 897] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:12 897] set basic_indicator_onoff:0 
[2024/8/7 9:01:12 913] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 913] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:12 929] set basic_indicator_onoff:1 
[2024/8/7 9:01:12 930] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 945] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:12 945] set basic_indicator_onoff:0 
[2024/8/7 9:01:12 945] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 961] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:12 961] set basic_indicator_onoff:1 
[2024/8/7 9:01:12 977] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 977] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:12 977] set basic_indicator_onoff:0 
[2024/8/7 9:01:12 993] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:12 993] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:12 993] set basic_indicator_onoff:1 
[2024/8/7 9:01:13 009] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 025] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:13 025] set basic_indicator_onoff:0 
[2024/8/7 9:01:13 025] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 041] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:13 041] set basic_indicator_onoff:1 
[2024/8/7 9:01:13 057] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 057] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:13 073] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:13 073] [1970-01-01 00:00:34] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:13 073] set basic_indicator_onoff:0 
[2024/8/7 9:01:13 089] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 105] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12[ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:01:13 105] Mode(Product):0
[2024/8/7 9:01:13 105] BpuMode:[Online]
[2024/8/7 9:01:13 105] VpssMode:[Online]
[2024/8/7 9:01:13 105] [0.LimitUp_info]:
[2024/8/7 9:01:13 105] LimitUp:[Disable]
[2024/8/7 9:01:13 105] [2680*0]->[3840*0])
[2024/8/7 9:01:13 105] chn	TotalSize	ActiveSize
[2024/8/7 9:01:13 105] 0	5040*2246	2680*2160
[2024/8/7 9:01:13 121] 0	5040*2246	2680*2160
[2024/8/7 9:01:13 121] 0	5040*2246	3840*2160
[2024/8/7 9:01:13 121] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:01:13 121] [1.VICU_info]:
[2024/8/7 9:01:13 121] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:01:13 121] 0	25.0	670	0	0	183	linear	8ddb00
[2024/8/7 9:01:13 121] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:01:13 137] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:01:13 137] en	op_type	m_chn	now
[2024/8/7 9:01:13 137] 0	1	1	1
[2024/8/7 9:01:13 137] [2.VI_info]:
[2024/8/7 9:01:13 137] chn	TotalSize	ActiveSize
[2024/8/7 9:01:13 137] 0	5040*2246	3848*2166
[2024/8/7 9:01:13 137] 1	   0*   0	   0*   0
[2024/8/7 9:01:13 137] [3.MIPI_info]:
[2024/8/7 9:01:13 153] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:01:13 153] 0x2b	6472*2166	3848*2166		5046*2166	3848*2166	   0
[2024/8/7 9:01:13 153] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:01:13 153] [4.Cut_info]:
[2024/8/7 9:01:13 169] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:01:13 169] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:01:13 169] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:01:13 169] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:01:13 169] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:01:13 169] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:01:13 185] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:01:13 185] [5.IB(isp buffer info)]:
[2024/8/7 9:01:13 185] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:01:13 185] PoolId  Count  Size
[2024/8/7 9:01:13 201] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:13 201] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:13 217] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:13 217] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:13 217] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:13 233] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:13 233] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:01:13 233] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:01:13 249] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:01:13 249] 0       0         0          2          4       
[2024/8/7 9:01:13 249] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:01:13 265]      --265--            --264--                                               
[2024/8/7 9:01:13 265] Count      Line     Count      Line     
[2024/8/7 9:01:13 265] 511        480      1206       560      
[2024/8/7 9:01:13 281] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:01:13 281] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:01:13 297] 0   3840   2160    H265  0      0        0           310       983036     4        	
[2024/8/7 9:01:13 297] 1   640    360     H265  0      0        0           198       43196      4        	
[2024/8/7 9:01:13 313] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:01:13 313] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:01:13 329] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:01:13 344] 0   Y      310      0       0       15       0        310      310      430       65405         59008    122088   64856    12      
[2024/8/7 9:01:13 344] 1   Y      198      0       2       1        0        198      198      430       2450          1888     27580    2984     9       
[2024/8/7 9:01:13 360] 3   N      0        0       0       1        0        0        0        431       0             0        0        0        0       
[2024/8/7 9:01:13 360] ],val=[0]
[2024/8/7 9:01:13 360] curr event:6 
[2024/8/7 9:01:13 376] IPC_APP_Notify_LED_Sound_Status_CB line(497) -------------------------- IPC_CONNECT_WIFI_SUCCESS(6)
[2024/8/7 9:01:13 392] [1970-01-01 00:00:34] tuya_ipc_system_control_demo.c(498) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECT_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:01:13 392] [01-01 18:12:39 TUYA D][tuya_devos_netlink.c:313] wf connect success!
[2024/8/7 9:01:13 408] [01-01 18:12:39 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:01:13 408] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:01:13 424] [1970-01-01 00:00:34] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:13 424] [01-01 18:12:39 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:01:13 424] [01-01 18:12:39 TUYA E][mqtt_client.c:807] hand null.
[2024/8/7 9:01:13 440] [01-01 18:12:39 TUYA D][tuya_iot_wired_wifi_api.c:584] wired wifi default stat:1,change:1
[2024/8/7 9:01:13 440] [01-01 18:12:39 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[2024/8/7 9:01:13 457] [01-01 18:12:39 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[2024/8/7 9:01:13 457] [01-01 18:12:39 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:01:13 472] dev id key: 16
[2024/8/7 9:01:13 473] c0 b9 30 cc 91 82 20 e0 27 d3 45 b3 ab 3c 27 bf 
[2024/8/7 9:01:13 473] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:01:13 488] [01-01 18:12:39 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:01:13 488] 2 1 6 3 2 1 a2 14 16 1 a2 0 1c 6a 97 74 ce 42 f4 54 8c 72 2e 92 d 9f a1 db 
[2024/8/7 9:01:13 488] [01-01 18:12:39 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:01:13 504] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 30 7b 27 8c c6 8b 14 13 8e 36 f6 75 73 7d 4b 
[2024/8/7 9:01:13 504] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:01:13 520] [01-01 18:12:39 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:01:13 520] [01-01 18:12:39 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:01:13 536] [01-01 18:12:39 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:01:13 537] [01-01 18:12:39 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:13 537] [01-01 18:12:39 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:13 552] [01-01 18:12:39 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:13 552] [01-01 18:12:39 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:13 552] [01-01 18:12:39 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:13 569] [01-01 18:12:39 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:13 569] [01-01 18:12:39 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:13 584] [01-01 18:12:39 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:13 584] [01-01 18:12:39 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:13 584] [01-01 18:12:39 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:13 600] [01-01 18:12:39 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:01:13 600] [01-01 18:12:39 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:01:13 616] [01-01 18:12:39 TUYA D][iot_httpc.c:1435] sign_buffer:env=1769&region=AY&ts=24&uuid=uuidcaab27b0a838d239
[2024/8/7 9:01:13 616] [01-01 18:12:39 TUYA D][iot_httpc.c:1443] sign_base64_encode:2PkGJl7eBgzr3XYOi9Pc3MG828QLIXHTHsDfxGxePU0=
[2024/8/7 9:01:13 633] [01-01 18:12:39 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:01:13 665] [01-01 18:12:39 TUYA D][iot_httpc.c:1514] http_dns send: {"region":"AY","env":"1769","uuid":"uuidcaab27b0a838d239","ts":24,"sign":"2PkGJl7eBgzr3XYOi9Pc3MG828QLIXHTHsDfxGxePU0=","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:01:13 665] [01-01 18:12:39 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v2/url_config
[2024/8/7 9:01:13 681] [01-01 18:12:39 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:13 681] [01-01 18:12:39 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:01:13 697] [01-01 18:12:39 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:01:13 697] [01-01 18:12:39 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:01:13 713] [1970-01-01 00:00:34] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/ServerConnect_english.pcm]
[2024/8/7 9:01:13 713] [1970-01-01 00:00:34] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:01:13 729] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:01:13 729] [01-01 18:12:39 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:01:13 745] [01-01 18:12:39 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:13 745] [01-01 18:12:39 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:13 761] [01-01 18:12:39 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:13 761] [01-01 18:12:39 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:01:13 761] [01-01 18:12:39 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:13 777] set basic_indicator_onoff:1 
[2024/8/7 9:01:13 777] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 793] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:13 793] set basic_indicator_onoff:0 
[2024/8/7 9:01:13 793] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 809] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:13 809] set basic_indicator_onoff:1 
[2024/8/7 9:01:13 825] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 825] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:13 825] set basic_indicator_onoff:0 
[2024/8/7 9:01:13 841] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 841] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:13 857] [01-01 18:12:39 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:01:13 873] [01-01 18:12:39 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:13 873] set basic_indicator_onoff:1 
[2024/8/7 9:01:13 889] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:13 889] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:13 889] [01-01 18:12:39 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:01:13 905] [01-01 18:12:39 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:13 905] [01-01 18:12:39 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:13 921] [01-01 18:12:39 TUYA D][iot_httpc.c:1578] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216]
[2024/8/7 9:01:13 921] [01-01 18:12:39 TUYA D][iot_httpc.c:1579] mqttUrl:[m2.tuyacn.com:1883][42.192.30.165]
[2024/8/7 9:01:13 937] [01-01 18:12:39 TUYA D][iot_httpc.c:1602] httpsSelfUrl:[https://a2.tuyacn.com/d.json][42.192.31.36]
[2024/8/7 9:01:13 937] [01-01 18:12:39 TUYA D][iot_httpc.c:1603] mqttsSelfUrl:[m2.tuyacn.com:8883][42.192.30.165]
[2024/8/7 9:01:13 953] [01-01 18:12:39 TUYA D][iot_httpc.c:1670] ghostUrl:[baal.tuyacn.com:443][42.192.35.108]
[2024/8/7 9:01:13 953] [01-01 18:12:39 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:01:13 969] [01-01 18:12:39 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:13 969] [01-01 18:12:39 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:01:13 969] [01-01 18:12:39 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:01:13 985] [01-01 18:12:39 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:01:13 985] [01-01 18:12:39 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:01:13 985] [01-01 18:12:39 TUYA D][iot_httpc.c:1684] tls_ca_name:tls_ca0
[2024/8/7 9:01:14 001] [01-01 18:12:39 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:01:14 001] [01-01 18:12:39 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:14 001] [01-01 18:12:39 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:14 017] [01-01 18:12:39 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:14 017] [01-01 18:12:39 TUYA D][simplekv.c:374] write key:tls_ca0 And Value Len:2688
[2024/8/7 9:01:14 033] [01-01 18:12:39 TUYA D][simplekv.c:457] new space 8 startpos:30428 size:2756
[2024/8/7 9:01:14 033] [01-01 18:12:39 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:14 033] [01-01 18:12:39 TUYA D][simplekv.c:203] update crc 1395591596
[2024/8/7 9:01:14 049] [01-01 18:12:39 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:14 049] [01-01 18:12:39 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:14 065] [01-01 18:12:39 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:14 065] [01-01 18:12:39 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:14 065] [01-01 18:12:39 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:14 081] [01-01 18:12:39 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:14 081] [01-01 18:12:39 TUYA D][simplekv.c:374] write key:tls_ca_cnt And Value Len:16
[2024/8/7 9:01:14 097] [01-01 18:12:39 TUYA D][simplekv.c:457] new space 9 startpos:33184 size:84
[2024/8/7 9:01:14 097] [01-01 18:12:39 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:14 097] [01-01 18:12:39 TUYA D][simplekv.c:203] update crc 213719394
[2024/8/7 9:01:14 097] set basic_indicator_onoff:0 
[2024/8/7 9:01:14 113] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:14 129] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:14 129] [01-01 18:12:39 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:14 129] [01-01 18:12:39 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:14 145] [01-01 18:12:39 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:01:14 145] [01-01 18:12:39 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216]
[2024/8/7 9:01:14 161] [01-01 18:12:39 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36]
[2024/8/7 9:01:14 161] [01-01 18:12:39 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165]
[2024/8/7 9:01:14 177] [01-01 18:12:39 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[42.192.30.165]
[2024/8/7 9:01:14 177] [01-01 18:12:39 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108]
[2024/8/7 9:01:14 193] [01-01 18:12:39 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:01:14 193] [01-01 18:12:39 TUYA D][simplekv.c:1251] find key:9 tls_ca_cnt
[2024/8/7 9:01:14 193] [01-01 18:12:39 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[2024/8/7 9:01:14 209] [01-01 18:12:39 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[2024/8/7 9:01:14 209] [01-01 18:12:39 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:01:14 225] [01-01 18:12:39 TUYA D][simplekv.c:1251] find key:8 tls_ca0
[2024/8/7 9:01:14 225] [01-01 18:12:39 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688
[2024/8/7 9:01:14 226] [01-01 18:12:39 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
[2024/8/7 9:01:14 241] [01-01 18:12:39 TUYA D][iot_httpc.c:1696] end
[2024/8/7 9:01:14 241] [01-01 18:12:39 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:01:14 241] [01-01 18:12:39 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:14 257] [01-01 18:12:39 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:01:14 257] bt_ack_uncrypt 2
[2024/8/7 9:01:14 257] 00 00 
[2024/8/7 9:01:14 257] [01-01 18:12:39 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:14 273] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:14 273] tuya_hal_bt_send 20
[2024/8/7 9:01:14 273] 00 21 33 02 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41 
[2024/8/7 9:01:14 288] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:14 289] 0 21 33 2 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41 
[2024/8/7 9:01:14 289] XmBleSendBuf 20: 00 21 33 02 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41
[2024/8/7 9:01:14 305] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:14 305] ble_slave_gap_event->type=13
[2024/8/7 9:01:14 305] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:14 305] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:14 321]  ---
[2024/8/7 9:01:14 321] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:14 321] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:01:14 336] tuya_hal_bt_send 17
[2024/8/7 9:01:14 336] 01 bf 5e ef df 94 5a 95 f1 f2 62 1f 7f 0a 05 ef 86 
[2024/8/7 9:01:14 336] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:14 352] 1 bf 5e ef df 94 5a 95 f1 f2 62 1f 7f a 5 ef 86 
[2024/8/7 9:01:14 352] XmBleSendBuf 17: 01 bf 5e ef df 94 5a 95 f1 f2 62 1f 7f 0a 05 ef 86
[2024/8/7 9:01:14 352] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:14 352] ble_slave_gap_event->type=13
[2024/8/7 9:01:14 368] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:14 368] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:14 368] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:14 384] [01-01 18:12:39 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:01:14 384] set basic_indicator_onoff:1 
[2024/8/7 9:01:14 400] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:14 400] [01-01 18:12:39 TUYA D][tuya_devos_activate.c:356] dev_nw_cfg_active_stage:5
[2024/8/7 9:01:14 400] [01-01 18:12:39 TUYA D][iot_httpc.c:3195] modules:(null)
[2024/8/7 9:01:14 416] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:14 416] [01-01 18:12:39 TUYA D][simplekv.c:1211] read key:last_reset_info isFuzzy:0 skipCnt:0
[2024/8/7 9:01:14 432] [01-01 18:12:39 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:14 432] [01-01 18:12:39 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:14 432] [01-01 18:12:39 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:14 448] [01-01 18:12:39 TUYA D][iot_httpc.c:3198] options:{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}
[2024/8/7 9:01:14 513] [01-01 18:12:39 TUYA D][iot_httpc.c:1161] Post Data: {"token":"vXWxwWAq","softVer":"1.5.431","productKey":"fvijo8jvloagv1gm","protocolVer":"2.2","baselineVer":"40.00","hid":"90314ba51650","skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}}","devAttribute":67,"cadVer":"1.0.4","cdVer":"1.0.0","options":"{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}","t":24}
[2024/8/7 9:01:14 529] [01-01 18:12:39 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.active&et=1&t=24&uuid=uuidcaab27b0a838d239&v=4.4&sign=d909b7e5f3ebd11829fb9c87205d0318
[2024/8/7 9:01:14 529] [01-01 18:12:39 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:14 544] [01-01 18:12:39 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:14 544] [01-01 18:12:39 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:14 560] [01-01 18:12:39 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:14 560] [01-01 18:12:39 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:14 576] [01-01 18:12:39 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:14 576] [01-01 18:12:39 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:14 592] [01-01 18:12:39 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:14 592] [01-01 18:12:39 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:14 608] [01-01 18:12:39 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:14 608] [01-01 18:12:39 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:14 608] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:14 625] set basic_indicator_onoff:0 
[2024/8/7 9:01:14 625] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:14 641] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:14 641] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:14 657] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:14 658]  ---
[2024/8/7 9:01:14 658] Len=20 step 0
[2024/8/7 9:01:14 658] att=0x0 0x21 0x20 0x2 0xf5 0x86 0xdd 0xba 0x4f 0x6d 0x98 0x69 0x2c 0xe0 0x3 0x82 0x9 0x98 0x2b 0xf7 
[2024/8/7 9:01:14 658]  RCVS len:20
[2024/8/7 9:01:14 658] XmBleReadBuf 20:
[2024/8/7 9:01:14 673] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:14 673] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:14 673] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:14 689] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:14 689] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:14 705] [01-01 18:12:40 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:14 705] [01-01 18:12:40 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:14 705] [01-01 18:12:40 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:14 705] bt_rev_raw 20
[2024/8/7 9:01:14 721] 00 21 20 02 f5 86 dd ba 4f 6d 98 69 2c e0 03 82 09 98 2b f7 
[2024/8/7 9:01:14 721] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:01:14 737] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:14 737] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:14 737] set basic_indicator_onoff:1 
[2024/8/7 9:01:14 753] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:14 753] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:14 769] 
[2024/8/7 9:01:14 769] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:14 769] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:14 769] Len=17 step 0
[2024/8/7 9:01:14 785] att=0x1 0x7e 0xe3 0xe4 0x48 0x71 0x49 0x2c 0x29 0xe5 0x92 0x47 0x62 0xd3 0x18 0x53 0x99 
[2024/8/7 9:01:14 785]  RCVS len:17
[2024/8/7 9:01:14 785] XmBleReadBuf 17:
[2024/8/7 9:01:14 785] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:14 801] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:14 801] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:14 801] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:01:14 817] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:01:14 817] [01-01 18:12:40 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:01:14 832] [01-01 18:12:40 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:14 833] [01-01 18:12:40 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:14 833] bt_rev_raw 17
[2024/8/7 9:01:14 833] 01 7e e3 e4 48 71 49 2c 29 e5 92 47 62 d3 18 53 99 
[2024/8/7 9:01:14 849] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:01:14 849] ble rev data 33
[2024/8/7 9:01:14 864] 02 f5 86 dd ba 4f 6d 98 69 2c e0 03 82 09 98 2b f7 7e e3 e4 48 71 49 2c 29 e5 92 47 62 d3 18 53 99 
[2024/8/7 9:01:14 864] ble decryped data 16
[2024/8/7 9:01:14 864] 00 00 00 04 00 00 00 00 00 22 00 01 00 d6 49 00 
[2024/8/7 9:01:14 864] [01-01 18:12:40 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:14 881] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:01:14 881] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:01:14 896] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:01:14 896] set basic_indicator_onoff:0 
[2024/8/7 9:01:14 896] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:14 912] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:14 912] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:14 928] set basic_indicator_onoff:1 
[2024/8/7 9:01:14 928] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:14 944] [01-01 18:12:40 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:14 944] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:14 960] [01-01 18:12:40 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:14 960] set basic_indicator_onoff:0 
[2024/8/7 9:01:14 976] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:14 976] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:14 976] set basic_indicator_onoff:1 
[2024/8/7 9:01:14 992] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:14 992] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:15 008] set basic_indicator_onoff:0 
[2024/8/7 9:01:15 008] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 024] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:15 024] set basic_indicator_onoff:1 
[2024/8/7 9:01:15 024] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 040] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:15 040] set basic_indicator_onoff:0 
[2024/8/7 9:01:15 057] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 057] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:15 073] [1970-01-01 00:00:36] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time36703
[2024/8/7 9:01:15 073] set basic_indicator_onoff:1 
[2024/8/7 9:01:15 089] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 089] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:15 105] g_AudioTipsList.size() enable: 0[01-01 18:12:41 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:01:15 201] release an RX reorder frame due to timeout sn 1b
[2024/8/7 9:01:15 217] set basic_indicator_onoff:0 
[2024/8/7 9:01:15 233] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 233] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:15 233] set basic_indicator_onoff:1 
[2024/8/7 9:01:15 249] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 249] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:15 265] set basic_indicator_onoff:0 
[2024/8/7 9:01:15 265] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 281] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:15 281] set basic_indicator_onoff:1 
[2024/8/7 9:01:15 281] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 297] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:15 377] [01-01 18:12:41 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"capability":1,"devId":"6c62194832a0f26036b5lh","dstIntervals":[],"localKey":"De6MrsZpM`Gy51VP","resetFactory":false,"schema":"[{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":103,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":104,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"range\":[\"0\",\"1\",\"2\"],\"type\":\"enum\"},\"id\":106,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":109,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"min\":1,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":110,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":111,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":113,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\
[2024/8/7 9:01:15 393] [08-07 19:13:32 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:15 393] [08-07 19:13:32 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:15 409] [08-07 19:13:32 TUYA D][tuya_devos_activate.c:210] cloud_reset:0 local_reset:1
[2024/8/7 9:01:15 409] [08-07 19:13:32 TUYA D][tuya_devos_activate.c:256] __tmm_gw_actv_work: reset stride flag.
[2024/8/7 9:01:15 424] [08-07 19:13:32 TUYA D][tuya_devos_entry.c:1477] write stride to flash:0
[2024/8/7 9:01:15 426] [08-07 19:13:32 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 9:01:15 426] [08-07 19:13:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:15 440] [08-07 19:13:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:15 440] [08-07 19:13:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:15 440] [08-07 19:13:32 TUYA D][simplekv.c:374] write key:is_stride And Value Len:16
[2024/8/7 9:01:15 456] [08-07 19:13:32 TUYA D][simplekv.c:457] new space 10 startpos:33268 size:84
[2024/8/7 9:01:15 457] [08-07 19:13:32 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:15 473] [08-07 19:13:32 TUYA D][simplekv.c:203] update crc 1143988772
[2024/8/7 9:01:15 473] [08-07 19:13:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:15 473] [08-07 19:13:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:15 488] [08-07 19:13:32 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:01:15 488] [08-07 19:13:32 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 9:01:15 488] [08-07 19:13:32 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 9:01:15 504] [08-07 19:13:32 TUYA D][simplekv.c:374] write key:gw_di And Value Len:416
[2024/8/7 9:01:15 504] [08-07 19:13:32 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416
[2024/8/7 9:01:15 520] [08-07 19:13:32 TUYA D][simplekv.c:430] find 2 available space
[2024/8/7 9:01:15 520] [08-07 19:13:32 TUYA D][simplekv.c:474] reuse available space 29188
[2024/8/7 9:01:15 520] [08-07 19:13:32 TUYA D][simplekv.c:203] update crc 239108715
[2024/8/7 9:01:15 536] [08-07 19:13:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:15 536] [08-07 19:13:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:15 536] [08-07 19:13:32 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:01:15 552] [08-07 19:13:32 TUYA D][simplekv.c:1211] read key:flvlrc isFuzzy:0 skipCnt:0
[2024/8/7 9:01:15 552] [08-07 19:13:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:15 568] [08-07 19:13:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:15 568] [08-07 19:13:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:15 568] [08-07 19:13:32 TUYA D][simplekv.c:374] write key:flvlrc And Value Len:2928
[2024/8/7 9:01:15 584] [08-07 19:13:32 TUYA D][simplekv.c:457] new space 11 startpos:33352 size:2996
[2024/8/7 9:01:15 584] [08-07 19:13:32 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:15 600] [08-07 19:13:32 TUYA D][simplekv.c:203] update crc 3251248970
[2024/8/7 9:01:15 600] set basic_indicator_onoff:0 
[2024/8/7 9:01:15 600] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 616] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:15 616] [08-07 19:13:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:15 632] [08-07 19:13:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:15 632] [08-07 19:13:32 TUYA D][ws_db_gw.c:670] schema write success
[2024/8/7 9:01:15 632] set basic_indicator_onoff:1 
[2024/8/7 9:01:15 648] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:15 648] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:15 664] [08-07 19:13:32 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success 
[2024/8/7 9:01:15 664] [08-07 19:13:32 TUYA D][tuya_ipc_sdk_init.c:183] ON post active:0x1cfaa70
[2024/8/7 9:01:15 664] [08-07 19:13:32 TUYA D][tuya_ipc_sdk_init.c:172] skillResult p2pId:[]
[2024/8/7 9:01:15 680] [08-07 19:13:32 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:01:15 680] [08-07 19:13:32 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 9:01:15 680] [08-07 19:13:32 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[2024/8/7 9:01:15 696] [08-07 19:13:32 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:544
[2024/8/7 9:01:15 696] [08-07 19:13:32 TUYA D][simplekv.c:394] 4 key same BUT size old 436 < new 544 need find new hd
[2024/8/7 9:01:15 713] [08-07 19:13:32 TUYA D][simplekv.c:457] new space 12 startpos:36348 size:612
[2024/8/7 9:01:15 713] [08-07 19:13:32 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:15 729] [08-07 19:13:32 TUYA D][simplekv.c:203] update crc 443298804
[2024/8/7 9:01:15 729] [1970-01-01 00:00:37] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:01:15 745] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:01:15 745] [08-07 19:13:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:15 745] [08-07 19:13:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:15 761] [08-07 19:13:32 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:01:15 777] [08-07 19:13:32 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":9,"ssid":"WGlhb21pX0YxREM=","passwd":"eG01MTI1MjA=","md":0,"random":0,"wfb64":1,"stat":2,"token":"vXWxwWAq","region":"AY","reg_key":"1769","dns_prio":0 }
[2024/8/7 9:01:15 777] [08-07 19:13:32 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:01:15 793] [08-07 19:13:32 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:01:15 793] [08-07 19:13:32 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:01:15 793] [08-07 19:13:32 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:176
[2024/8/7 9:01:15 809] [08-07 19:13:32 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 176
[2024/8/7 9:01:15 809] [08-07 19:13:32 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:01:15 825] [08-07 19:13:32 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:01:15 825] [08-07 19:13:32 TUYA D][simplekv.c:203] update crc 3066457077
[2024/8/7 9:01:15 825] [08-07 19:13:32 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:15 841] [08-07 19:13:32 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:15 841] [08-07 19:13:32 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:01:15 841] __IPC_APP_Get_Net_Status_cb line(188) -------------------------- stat(1)==STAT_UNPROVISION 
[2024/8/7 9:01:15 857] [08-07 19:13:32 TUYA D][wifi_netcfg_frame_transporter.c:472] ----destroy Transporter,session:0x1cf0e70
[2024/8/7 9:01:15 857] [08-07 19:13:32 TUYA D][tuya_devos_entry.c:560] dev_nw_cfg_active_stage:6
[2024/8/7 9:01:15 873] __IPC_APP_Get_Net_Status_cb line(198) -------------------------- stat(3)==STAT_AP_STA_DISC 
[2024/8/7 9:01:15 873] [08-07 19:13:32 TUYA N][tuya_bt_sdk.c:171] ty bt upd localkey
[2024/8/7 9:01:15 889] [08-07 19:13:32 TUYA N][tuya_ble_api.c:425] upd login key len:6
[2024/8/7 9:01:15 889] [08-07 19:13:32 TUYA I][mqc_app.c:387] mqc app start ...
[2024/8/7 9:01:15 889] [08-07 19:13:32 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883
[2024/8/7 9:01:15 905] [08-07 19:13:32 TUYA D][mqc_app.c:473] TLS disable
[2024/8/7 9:01:15 905] [08-07 19:13:32 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:01:15 921] [08-07 19:13:32 TUYA D][mqtt_client.c:321] subcribe_topic:smart/device/in/6c62194832a0f26036b5lh, client_id:6c62194832a0f26036b5lh, user_name:6c62194832a0f26036b5lh, passwd:a2cae55ed27d8612
[2024/8/7 9:01:15 937] [08-07 19:13:32 TUYA D][mqtt_client.c:352] domain<0> m2.tuyacn.com:8883 HAVE PORT
[2024/8/7 9:01:15 937] [08-07 19:13:32 TUYA D][mqtt_client.c:355] PARSE m2.tuyacn.com:8883
[2024/8/7 9:01:15 937] [08-07 19:13:32 TUYA D][mqtt_client.c:383] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT
[2024/8/7 9:01:15 953] [08-07 19:13:32 TUYA D][mqtt_client.c:386] PARSE m2.tuyacn.com:1883
[2024/8/7 9:01:15 953] [08-07 19:13:32 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6c62194832a0f26036b5lh
[2024/8/7 9:01:15 969] [08-07 19:13:32 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6c62194832a0f26036b5lh
[2024/8/7 9:01:15 985] [08-07 19:13:32 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:25600,priority:4
[2024/8/7 9:01:15 985] [08-07 19:13:32 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[2024/8/7 9:01:15 985] [08-07 19:13:32 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[2024/8/7 9:01:15 985] [08-07 19:13:32 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[2024/8/7 9:01:16 000] [08-07 19:13:32 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:01:16 000] [08-07 19:13:32 TUYA N][bt_dp.c:228] bt rpt conn stat:9
[2024/8/7 9:01:16 016] [08-07 19:13:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:16 016] [08-07 19:13:32 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:01:16 016] bt_ack_uncrypt 2
[2024/8/7 9:01:16 016] 00 09 
[2024/8/7 9:01:16 032] [08-07 19:13:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:16 033] [08-07 19:13:32 TUYA D][tuya_ble_api.c:1005] start to get mesh
[2024/8/7 9:01:16 033] [08-07 19:13:32 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992477}
[2024/8/7 9:01:16 048] [08-07 19:13:32 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.mesh.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992477&v=1.0&sign=ed1ca120d734a5a231776b5443b3ca5a
[2024/8/7 9:01:16 064] [08-07 19:13:32 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:16 064] [08-07 19:13:32 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:16 080] [08-07 19:13:32 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:16 080] [08-07 19:13:32 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:16 096] [08-07 19:13:32 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[2024/8/7 9:01:16 096] [08-07 19:13:32 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:01:16 096] [08-07 19:13:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:16 112] [08-07 19:13:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:16 112] [08-07 19:13:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:16 112] [08-07 19:13:32 TUYA D][tuya_svc_timer_task.c:146] no timer
[2024/8/7 9:01:16 128] [08-07 19:13:32 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[2024/8/7 9:01:16 128] [08-07 19:13:32 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[2024/8/7 9:01:16 144] [08-07 19:13:32 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:01:16 144] [08-07 19:13:32 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:01:16 144] [08-07 19:13:32 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[2024/8/7 9:01:16 161] [08-07 19:13:32 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6c62194832a0f26036b5lh
[2024/8/7 9:01:16 161] [08-07 19:13:32 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6c62194832a0f26036b5lh
[2024/8/7 9:01:16 177] [08-07 19:13:32 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:01:16 177] [08-07 19:13:32 TUYA D][svc_online_log.c:317] svc online log active success
[2024/8/7 9:01:16 192] [08-07 19:13:32 TUYA D][tuya_ipc_p2p_common.c:530] p2p passwd change to adb2c75d
[2024/8/7 9:01:16 192] [08-07 09:01:17 TUYA D][tuya_ipc_sdk_init.c:137] sys stop timer: 14
[2024/8/7 9:01:16 192] [08-07 09:01:17 TUYA D][tuya_ipc_sdk_init.c:140] sys delete timer: 14
[2024/8/7 9:01:16 208] [08-07 09:01:17 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[2024/8/7 9:01:16 208] [08-07 09:01:17 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[2024/8/7 9:01:16 225] [08-07 09:01:17 TUYA D][iot_httpc.c:1161] Post Data: {"password":"adb2c75d","t":1722992477}
[2024/8/7 9:01:16 225] [08-07 09:01:17 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:01:16 241] [08-07 09:01:17 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.password.update&devId=6c62194832a0f26036b5lh&et=1&t=1722992477&v=1.0&sign=c1cd57016eeb0b345459098f823de541
[2024/8/7 9:01:16 241] dev id key: 16
[2024/8/7 9:01:16 257] 8f 97 d6 f7 22 d7 5f c9 38 63 c0 37 d8 0b ee b3 
[2024/8/7 9:01:16 257] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:01:16 273] [08-07 09:01:17 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:16 273] [08-07 09:01:17 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:16 289] [08-07 09:01:17 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:16 289] [08-07 09:01:17 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:16 289] [08-07 09:01:17 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:01:16 305] 2 1 6 3 2 1 a2 14 16 1 a2 0 b4 28 b0 ae c3 6f a4 4b d4 94 f0 34 57 11 5f c6 
[2024/8/7 9:01:16 305] [08-07 09:01:17 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:01:16 321] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 e6 2e 59 fd 93 bf 11 28 6a 9c 9b 3e 8b c 26 e6 
[2024/8/7 9:01:16 321] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:01:16 321] [08-07 09:01:17 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:01:16 337]  
[2024/8/7 9:01:16 338] [08-07 09:01:17 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:01:16 338] [08-07 09:01:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:16 354] tuya_hal_bt_send 20
[2024/8/7 9:01:16 354] 00 21 34 02 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 02 95 57 
[2024/8/7 9:01:16 354] [08-07 09:01:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:16 368] 0 21 34 2 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 2 95 57 
[2024/8/7 9:01:16 368] XmBleSendBuf 20: 00 21 34 02 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 02 95 57
[2024/8/7 9:01:16 368] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:16 368] ble_slave_gap_event->type=13
[2024/8/7 9:01:16 384] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:16 384] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:16 385] [08-07 09:01:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:16 400] [08-07 09:01:17 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:16 400] [08-07 09:01:17 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:16 416] [08-07 09:01:17 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:16 416] [08-07 09:01:17 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:16 433] [08-07 09:01:17 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:16 433] [08-07 09:01:17 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:16 448] [08-07 09:01:17 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:16 448] [08-07 09:01:17 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:16 464] [08-07 09:01:17 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:16 464] [08-07 09:01:17 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:16 480] [08-07 09:01:17 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:16 480] [08-07 09:01:17 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:16 480] [08-07 09:01:17 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:16 496] [08-07 09:01:17 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:16 496] set basic_indicator_onoff:0 
[2024/8/7 9:01:16 512] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:16 512] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:16 528] [08-07 09:01:17 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:01:16 528] tuya_hal_bt_send 17
[2024/8/7 9:01:16 528] 01 98 6f f3 ac 9c 4c db d5 77 00 c0 1d e3 4f 56 2e 
[2024/8/7 9:01:16 528] [08-07 09:01:17 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:16 544] 1 98 6f f3 ac 9c 4c db d5 77 0 c0 1d e3 4f 56 2e 
[2024/8/7 9:01:16 544] XmBleSendBuf 17: 01 98 6f f3 ac 9c 4c db d5 77 00 c0 1d e3 4f 56 2e
[2024/8/7 9:01:16 544] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:01:16 560] [08-07 09:01:17 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:16 576] [08-07 09:01:17 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:16 576] ble_slave_gap_event->type=13
[2024/8/7 9:01:16 576] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:01:16 576] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:01:16 592]  ---
[2024/8/7 9:01:16 593] [08-07 09:01:17 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:16 593] [08-07 09:01:17 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:16 608] [08-07 09:01:17 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:16 624] [08-07 09:01:17 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"appKey":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","networkKey":"D59774254FA876FF1D204D16DF5223A5"},"t":1722992478,"success":true}
[2024/8/7 9:01:16 640] [08-07 09:01:18 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:16 640] [08-07 09:01:18 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:16 656] [08-07 09:01:18 TUYA D][tuya_ble_api.c:1014] start to write flash, app_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66", network_key:"D59774254FA876FF1D204D16DF5223A5"
[2024/8/7 9:01:16 656] [08-07 09:01:18 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:01:16 672] [08-07 09:01:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:16 672] [08-07 09:01:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:16 672] [08-07 09:01:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:16 688] [08-07 09:01:18 TUYA D][simplekv.c:374] write key:ble_app_key And Value Len:48
[2024/8/7 9:01:16 688] [08-07 09:01:18 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 48
[2024/8/7 9:01:16 704] [08-07 09:01:18 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:01:16 704] [08-07 09:01:18 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:01:16 704] [08-07 09:01:18 TUYA D][simplekv.c:203] update crc 2986864220
[2024/8/7 9:01:16 721] [08-07 09:01:18 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:01:16 721] [08-07 09:01:18 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:16 737] [08-07 09:01:18 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:16 737] [08-07 09:01:18 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:01:16 737] [08-07 09:01:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:16 753] [08-07 09:01:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:16 753] [08-07 09:01:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:16 769] [08-07 09:01:18 TUYA D][simplekv.c:374] write key:ble_network_key And Value Len:48
[2024/8/7 9:01:16 769] [08-07 09:01:18 TUYA D][simplekv.c:457] new space 13 startpos:36960 size:116
[2024/8/7 9:01:16 785] [08-07 09:01:18 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:16 788] [08-07 09:01:18 TUYA D][simplekv.c:203] update crc 3944625907
[2024/8/7 9:01:16 788] [08-07 09:01:18 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:16 801] [08-07 09:01:18 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:16 801] [08-07 09:01:18 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992478}
[2024/8/7 9:01:16 817] [08-07 09:01:18 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.beacon.key.fetch&devId=6c62194832a0f26036b5lh&et=1&t=1722992478&v=1.0&sign=2790dd065ba02025313337550442bb51
[2024/8/7 9:01:16 817] [08-07 09:01:18 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:16 833] [08-07 09:01:18 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:16 849] [08-07 09:01:18 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:16 849] [08-07 09:01:18 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:16 849] set basic_indicator_onoff:1 
[2024/8/7 9:01:16 864] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:16 865] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:16 880] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:16 881] [08-07 09:01:18 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992478,"success":true}
[2024/8/7 9:01:16 881] [08-07 09:01:18 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:16 896] [08-07 09:01:18 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:16 897] [08-07 09:01:18 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:01:16 912] [08-07 09:01:18 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:01:16 913] [08-07 09:01:18 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:01:16 913] [08-07 09:01:18 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:01:16 929] [08-07 09:01:18 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:01:16 929] [08-07 09:01:18 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:01:16 945] [08-07 09:01:18 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:01:16 945] [08-07 09:01:18 TUYA D][simplekv.c:203] update crc 1631554188
[2024/8/7 9:01:16 945] [08-07 09:01:18 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:16 960] [08-07 09:01:18 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:16 961] [08-07 09:01:18 TUYA D][tuya_devos_utils.c:341] set gw ext_stat:2
[2024/8/7 9:01:16 961] [08-07 09:01:18 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 0
[2024/8/7 9:01:16 977] [08-07 09:01:18 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.30.165 for domain m2.tuyacn.com
[2024/8/7 9:01:16 977] [08-07 09:01:18 TUYA D][mqtt_client.c:1472] select mqtt host:m2.tuyacn.com
[2024/8/7 9:01:16 992] [08-07 09:01:18 TUYA N][mqtt_client.c:1493] mqtt get serve ip success
[2024/8/7 9:01:16 993] [08-07 09:01:18 TUYA D][mqtt_client.c:989] serverIP 717233829 port:8883
[2024/8/7 9:01:17 008] [08-07 09:01:18 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:17 008] [08-07 09:01:18 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:17 024] [08-07 09:01:18 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:17 024] [08-07 09:01:18 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:17 040] [1970-01-01 00:00:37] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:01:17 040] [08-07 09:01:18 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:17 056] [1970-01-01 00:00:37] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:01:17 056] [08-07 09:01:18 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:17 072] [08-07 09:01:18 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:17 072] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:17 072] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:17 088]  ---
[2024/8/7 9:01:17 089] Len=20 step 0
[2024/8/7 9:01:17 089] att=0x0 0x21 0x20 0x2 0x16 0xb1 0x26 0xc0 0xb7 0x43 0x87 0xdd 0x10 0x82 0x91 0x9d 0x6a 0xb5 0x46 0x49 
[2024/8/7 9:01:17 089]  RCVS len:20
[2024/8/7 9:01:17 089] XmBleReadBuf 20:
[2024/8/7 9:01:17 104] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:17 104] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:17 104] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:17 120] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:01:17 120] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:01:17 136] [08-07 09:01:18 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:01:17 136] [08-07 09:01:18 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:17 136] [08-07 09:01:18 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:17 136] bt_rev_raw 20
[2024/8/7 9:01:17 152] 00 21 20 02 16 b1 26 c0 b7 43 87 dd 10 82 91 9d 6a b5 46 49 
[2024/8/7 9:01:17 152] [08-07 09:01:18 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:01:17 168] [08-07 09:01:18 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:01:17 168] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:01:17 184] [08-07 09:01:18 TUYA D][app_agent.c:706] udp ip: 192.168.31.144
[2024/8/7 9:01:17 184] [08-07 09:01:18 TUYA D][mqtt_client.c:1014] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883
[2024/8/7 9:01:17 200] [08-07 09:01:18 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:17 200] [08-07 09:01:18 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyacn.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:17 216] [08-07 09:01:18 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:17 216] [08-07 09:01:18 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:17 232] [08-07 09:01:18 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:17 232] [08-07 09:01:18 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:17 248] [08-07 09:01:18 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:17 248] [08-07 09:01:18 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:17 264] [1970-01-01 00:00:37] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:17 264] set basic_indicator_onoff:0 
[2024/8/7 9:01:17 280] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:17 280] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:17 296] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:17 296] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:01:17 296] Len=17 step 0
[2024/8/7 9:01:17 296] att=0x1 0xaa 0xfa 0xb9 0x2c 0xc9 0xb5 0x80 0xdb 0xbc 0xb9 0x69 0x64 0xf3 0x99 0x14 0xe2 
[2024/8/7 9:01:17 312]  RCVS len:17
[2024/8/7 9:01:17 312] [08-07 09:01:18 TUYA D][iot_httpc.c:601] Decode Rev:{"result":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","t":1722992478,"success":true}
[2024/8/7 9:01:17 328] [08-07 09:01:18 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:17 328] [08-07 09:01:18 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:17 344] [08-07 09:01:18 TUYA D][tuya_ble_api.c:986] start to write flash, beacon_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66"
[2024/8/7 9:01:17 344] [08-07 09:01:18 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:01:17 344] [08-07 09:01:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:17 360] [08-07 09:01:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:17 360] [08-07 09:01:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:17 376] [08-07 09:01:18 TUYA D][simplekv.c:374] write key:ble_beaconkey And Value Len:48
[2024/8/7 9:01:17 376] [08-07 09:01:18 TUYA D][simplekv.c:457] new space 14 startpos:37076 size:116
[2024/8/7 9:01:17 376] [08-07 09:01:18 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:17 392] [08-07 09:01:18 TUYA D][simplekv.c:203] update crc 31432705
[2024/8/7 9:01:17 392] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=86.000 ms
[2024/8/7 9:01:17 408] [1970-01-01 00:00:37] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:01:17 408] XmBleReadBuf 17:
[2024/8/7 9:01:17 408] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:01:17 408] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:01:17 424] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:01:17 424] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:01:17 440] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:01:17 440] [08-07 09:01:18 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:01:17 440] [08-07 09:01:18 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:01:17 456] [08-07 09:01:18 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:01:17 456] bt_rev_raw 17
[2024/8/7 9:01:17 456] 01 aa fa b9 2c c9 b5 80 db bc b9 69 64 f3 99 14 e2 
[2024/8/7 9:01:17 472] [08-07 09:01:18 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:01:17 472] ble rev data 33
[2024/8/7 9:01:17 472] 02 16 b1 26 c0 b7 43 87 dd 10 82 91 9d 6a b5 46 49 aa fa b9 2c c9 b5 80 db bc b9 69 64 f3 99 14 e2 
[2024/8/7 9:01:17 488] ble decryped data 16
[2024/8/7 9:01:17 488] 00 00 00 05 00 00 00 00 00 22 00 01 00 13 18 00 
[2024/8/7 9:01:17 488] [08-07 09:01:18 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:17 504] [08-07 09:01:18 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:17 504] [08-07 09:01:18 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:17 504] [08-07 09:01:18 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:01:17 520] [08-07 09:01:18 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:01:17 520] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:01:17 536] [08-07 09:01:18 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:01:17 536] [08-07 09:01:18 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:01:17 536] set basic_indicator_onoff:1 
[2024/8/7 9:01:17 552] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:17 552] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:17 568] [1970-01-01 00:00:38] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:17 568] set basic_indicator_onoff:0 
[2024/8/7 9:01:17 568] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:17 584] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:17 584] set basic_indicator_onoff:1 
[2024/8/7 9:01:17 600] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:17 600] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:17 600] set basic_indicator_onoff:0 
[2024/8/7 9:01:17 616] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:17 616] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:17 632] [08-07 09:01:18 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:17 648] [08-07 09:01:18 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyacn.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:17 648] [08-07 09:01:18 TUYA N][mqtt_client.c:1531] mqtt create success, begin to connect
[2024/8/7 9:01:17 648] [08-07 09:01:18 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:01:17 664] [08-07 09:01:18 TUYA D][mqtt_client.c:1413] cnt 1
[2024/8/7 9:01:17 664] set basic_indicator_onoff:1 
[2024/8/7 9:01:17 664] [08-07 09:01:18 TUYA D][mqtt_client.c:1104] mqtt subscribe success
[2024/8/7 9:01:17 680] [08-07 09:01:18 TUYA D][mqc_app.c:732] mqtt connect success
[2024/8/7 9:01:17 680] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:17 696] [08-07 09:01:18 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[2024/8/7 9:01:17 696] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:01:17 712] [08-07 09:01:18 TUYA D][mqtt_client.c:1994] subscribe new topic /av/d/6c62194832a0f26036b5lh ret:1 
[2024/8/7 9:01:17 712] [08-07 09:01:18 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[2024/8/7 9:01:17 728] __IPC_APP_Get_Net_Status_cb line(243) -------------------------- stat(11)==STAT_MQTT_ONLINE 
[2024/8/7 9:01:17 728] curr event:11 
[2024/8/7 9:01:17 728] IPC_APP_Notify_LED_Sound_Status_CB line(550) -------------------------- IPC_MQTT_ONLINE(11)
[2024/8/7 9:01:17 744] [1970-01-01 00:00:38] tuya_ipc_system_control_demo.c(551) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(DEVICE_ONLINE, 0, 0, 0, 1))
[2024/8/7 9:01:17 744] Disable Qrcode
[2024/8/7 9:01:17 760] [1970-01-01 00:00:38] tuya_ipc_system_control_demo.c(558) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONFIG_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:01:17 760] mqtt subscribe ack 5
[2024/8/7 9:01:17 760] 90 03 00 02 00 
[2024/8/7 9:01:17 776] [1970-01-01 00:00:38] xm_musicPlayer.cpp(91) <PlayAudioTips>: Open audio file /usr/share/audios/_english.pcm failed, No such file or directory
[2024/8/7 9:01:17 792] [1970-01-01 00:00:38] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/AddSuccess_english.pcm]
[2024/8/7 9:01:17 792] [1970-01-01 00:00:38] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:01:17 808] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:01:17 808] [08-07 09:01:18 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:34 ip:0xc0a81ff2
[2024/8/7 9:01:17 824] [08-07 09:01:19 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[2024/8/7 9:01:17 824] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:01:17 840] [08-07 09:01:19 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
[2024/8/7 9:01:17 840] [08-07 09:01:19 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:2  -->>
[2024/8/7 9:01:17 856] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:01:17 856] [08-07 09:01:19 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:2  <<--
[2024/8/7 9:01:17 873] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:01:17 873] [08-07 09:01:19 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:01:17 888] [08-07 09:01:19 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 3
[2024/8/7 9:01:17 888] [08-07 09:01:19 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:01:17 888] [08-07 09:01:19 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:01:17 905] [08-07 09:01:19 TUYA D][app_agent.c:600] send length:64, id:34, sequence_out:39751
[2024/8/7 9:01:17 905] [08-07 09:01:19 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 5
[2024/8/7 9:01:17 905] [08-07 09:01:19 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:01:17 921] [08-07 09:01:19 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:01:17 921] [08-07 09:01:19 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 16
[2024/8/7 9:01:17 921] [08-07 09:01:19 TUYA E][app_agent.c:1631] hmac error
[2024/8/7 9:01:17 921] hmac i 32
[2024/8/7 9:01:17 937] 7c 09 63 95 2d 42 d0 6e 8e 11 db 91 d1 cc 8d 0d ac 61 c9 f5 36 96 eb 00 c7 d5 8d a7 da 63 01 13 
[2024/8/7 9:01:17 937] hmac o 32
[2024/8/7 9:01:17 953] e3 4a a1 ad 81 d2 59 a2 82 5a b1 31 ec 8a b7 66 e9 83 c7 be 65 da f4 d9 89 8b b9 1f 29 02 b2 a7 
[2024/8/7 9:01:17 953] [08-07 09:01:19 TUYA D][app_agent.c:163] close socket 34
[2024/8/7 9:01:17 968] [08-07 09:01:19 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:01:17 969] [08-07 09:01:19 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:01:17 969] [08-07 09:01:19 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:17 985] [08-07 09:01:19 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:17 985] [08-07 09:01:19 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:17 985] [08-07 09:01:19 TUYA E][svc_online_log_db.c:25] ret:-6
[2024/8/7 9:01:18 001] [08-07 09:01:19 TUYA D][svc_online_log.c:182] load env fail. maybe not exist.
[2024/8/7 9:01:18 017] [08-07 09:01:19 TUYA D][svc_online_log.c:187] update property:{"value":"{\"embed_sys_env\":\"arm-xm-linux\"}"}
[2024/8/7 9:01:18 017] [08-07 09:01:19 TUYA D][iot_httpc.c:1161] Post Data: {"value":"{\"embed_sys_env\":\"arm-xm-linux\"}","t":1722992479}
[2024/8/7 9:01:18 032] [08-07 09:01:19 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.property.save&devId=6c62194832a0f26036b5lh&et=1&t=1722992479&v=1.0&sign=f4ab168961268a89fbf4487dc4d31503
[2024/8/7 9:01:18 048] [08-07 09:01:19 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:18 049] [08-07 09:01:19 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:18 064] [08-07 09:01:19 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:18 064] [08-07 09:01:19 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:18 080] [08-07 09:01:19 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:18 080] [08-07 09:01:19 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:18 096] [08-07 09:01:19 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:18 096] [08-07 09:01:19 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:18 096] [08-07 09:01:19 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:18 112] [08-07 09:01:19 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:18 112] [08-07 09:01:19 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:18 128] [08-07 09:01:19 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:18 144] [08-07 09:01:19 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:18 144] [08-07 09:01:19 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992479,"success":true}
[2024/8/7 9:01:18 144] [08-07 09:01:19 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:18 160] [08-07 09:01:19 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:18 160] [08-07 09:01:19 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:01:18 176] [08-07 09:01:19 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:18 176] [08-07 09:01:19 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:18 176] [08-07 09:01:19 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:18 192] [08-07 09:01:19 TUYA D][simplekv.c:374] write key:em_sys_env And Value Len:32
[2024/8/7 9:01:18 192] [08-07 09:01:19 TUYA D][simplekv.c:457] new space 15 startpos:37192 size:100
[2024/8/7 9:01:18 208] [08-07 09:01:19 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:18 208] [08-07 09:01:19 TUYA D][simplekv.c:203] update crc 2206041018
[2024/8/7 9:01:18 208] [08-07 09:01:19 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:18 224] [08-07 09:01:19 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:18 224] [08-07 09:01:19 TUYA D][MainApp.c:537] tuya_ipc_sdk_mqtt_online_proc is start run
[2024/8/7 9:01:18 240] [08-07 09:01:19 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992479 28800
[2024/8/7 9:01:18 240] [08-07 09:01:19 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992479 28800
[2024/8/7 9:01:18 240] Init tuya_ipc_ss_init
[2024/8/7 9:01:18 256] [08-07 09:01:19 TUYA D][tuya_ipc_stream_storage.c:2015] Init stream_storage.base_path:/mnt/mmc v:4 a:101, max event per day 289 skills 1
[2024/8/7 9:01:18 272] [08-07 09:01:19 TUYA D][tuya_ipc_stream_storage.c:2161] stream storage task init success
[2024/8/7 9:01:18 272] [08-07 09:01:19 TUYA D][MainApp.c:567] local storage init result is 0
[2024/8/7 9:01:18 272] [08-07 09:01:19 TUYA D][tuya_ipc_stream_storage.c:1571] SD task begin___
[2024/8/7 9:01:18 288] [08-07 09:01:19 TUYA D][tuya_ipc_stream_storage.c:1585] report sd status 0 -> 5
[2024/8/7 9:01:18 288] [08-07 09:01:19 TUYA E][tuya_ipc_stream_storage.c:1914] storage not inited
[2024/8/7 9:01:18 304] [08-07 09:01:19 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:01:18 304] [08-07 09:01:19 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:01:18 304] [08-07 09:01:20 TUYA D][tuya_ble_api.c:1417] cloud connected, stop adv!
[2024/8/7 9:01:18 320] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(640): stop_adv ---
[2024/8/7 9:01:18 320] exit_ble_thread create suc
[2024/8/7 9:01:18 320] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(644): XmBleAdvStop ---
[2024/8/7 9:01:18 336] [08-07 09:01:20 TUYA D][tuya_ble_api.c:1376] nw stat change:1->2, rpt to app.
[2024/8/7 9:01:18 336] [08-07 09:01:20 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:2
[2024/8/7 9:01:18 336] [08-07 09:01:20 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:18 353] [08-07 09:01:20 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:01:18 353] bt_ack_uncrypt 1
[2024/8/7 9:01:18 353] 02 
[2024/8/7 9:01:18 353] [08-07 09:01:20 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:18 369] [08-07 09:01:20 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:18 369] tuya_hal_bt_send 20
[2024/8/7 9:01:18 369] 00 21 35 05 c2 b1 a0 88 a0 95 be ba ba ba 86 12 02 c5 fc f8 
[2024/8/7 9:01:18 385] [08-07 09:01:20 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:18 385] 0 21 35 5 c2 b1 a0 88 a0 95 be ba ba ba 86 12 2 c5 fc f8 
[2024/8/7 9:01:18 400] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:18 400] [08-07 09:01:20 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:18 401] --- tracepoint bt_ext_porting.c,ty_btext_thread(433): tuya_hal_thread_release ---
[2024/8/7 9:01:18 416] [08-07 09:01:20 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:01:18 416] tuya_hal_bt_send 17
[2024/8/7 9:01:18 416] 01 76 2c 80 89 f0 93 42 c1 71 78 9d ec 59 4f 16 55 
[2024/8/7 9:01:18 432] [08-07 09:01:20 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:18 432] 1 76 2c 80 89 f0 93 42 c1 71 78 9d ec 59 4f 16 55 
[2024/8/7 9:01:18 448] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:18 452]  ---
[2024/8/7 9:01:18 452] [08-07 09:01:20 TUYA E][bt_ext_porting.c:434] [TUYA-BTUART]ty_btext_thread deleted
[2024/8/7 9:01:18 452] [08-07 09:01:20 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:18 464] [08-07 09:01:20 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:01:18 464] [1970-01-01 00:00:40] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:01:18 480] [08-07 09:01:20 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c62194832a0f26036b5lh, dp_rept_chan:5
[2024/8/7 9:01:18 480] [08-07 09:01:20 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:01:18 496] [08-07 09:01:20 TUYA D][smart_frame.c:2517] Nothing To Pack
[2024/8/7 9:01:18 496] [08-07 09:01:20 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:01:18 576] [08-07 09:01:20 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992480}
[2024/8/7 9:01:18 592] [08-07 09:01:20 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.uuid.pskkey.get&et=1&t=1722992480&uuid=uuidcaab27b0a838d239&v=1.0&sign=5721cc9d4ab2990452ce0a54ede8b1e6
[2024/8/7 9:01:18 592] [08-07 09:01:20 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:18 608] [08-07 09:01:20 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:18 608] [08-07 09:01:20 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:18 624] 
[2024/8/7 9:01:18 625] [08-07 09:01:20 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:18 625] [1970-01-01 00:00:40] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time40693
[2024/8/7 9:01:18 640] [08-07 09:01:20 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:18 640] [08-07 09:01:20 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:18 656] [08-07 09:01:20 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:18 656] [08-07 09:01:20 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:18 673] [08-07 09:01:20 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:18 673] [08-07 09:01:20 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:18 688] [08-07 09:01:20 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:18 688] [08-07 09:01:20 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:18 704] [08-07 09:01:20 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:18 721] [08-07 09:01:21 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"pskKey":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80"},"t":1722992481,"success":true}
[2024/8/7 9:01:18 721] [08-07 09:01:21 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:18 736] [08-07 09:01:21 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:18 752] [08-07 09:01:21 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80","auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:01:18 769] [08-07 09:01:21 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:01:18 769] [08-07 09:01:21 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:01:18 769] [08-07 09:01:21 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:01:18 785] [08-07 09:01:21 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:256
[2024/8/7 9:01:18 785] [08-07 09:01:21 TUYA D][simplekv.c:397] 0 key same AND size old 276 >= new 256
[2024/8/7 9:01:18 785] [08-07 09:01:21 TUYA D][simplekv.c:430] find 0 available space
[2024/8/7 9:01:18 802] [08-07 09:01:21 TUYA D][simplekv.c:474] reuse available space 28700
[2024/8/7 9:01:18 802] [08-07 09:01:21 TUYA D][simplekv.c:203] update crc 1659538507
[2024/8/7 9:01:18 817] [08-07 09:01:21 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:18 817] [08-07 09:01:21 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:18 817] [08-07 09:01:21 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:01:19 425] [1970-01-01 00:00:40] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:19 425] set sd_record_on_off:1 
[2024/8/7 9:01:19 425] set sd_record_mode:0 
[2024/8/7 9:01:19 441] [08-07 09:01:21 TUYA E][tuya_ipc_stream_storage.c:1912] the ss mgr not inited, but msg buffered: set mode 1
[2024/8/7 9:01:19 441] write RecordMode success  0 
[2024/8/7 9:01:19 441] [08-07 09:01:21 TUYA D][tuya_ipc_cloud_storage.c:2188] init cloud storage begin
[2024/8/7 9:01:19 456] [08-07 09:01:21 TUYA D][simplekv.c:1211] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[2024/8/7 9:01:19 456] [08-07 09:01:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:19 473] [08-07 09:01:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:19 473] [08-07 09:01:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:19 488] [08-07 09:01:21 TUYA E][tuya_ipc_cloud_storage.c:365] iot_wd_common_read fails md5_encrypt_key -6
[2024/8/7 9:01:19 488] [08-07 09:01:21 TUYA E][tuya_ipc_cloud_storage.c:450] read key_key file failed.
[2024/8/7 9:01:19 504] [08-07 09:01:21 TUYA D][tuya_ipc_cloud_storage.c:2240] __check_md5_encrypt_key fail, need update from server
[2024/8/7 9:01:19 504] [08-07 09:01:21 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:01:19 505] [08-07 09:01:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:19 520] [08-07 09:01:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:19 520] [08-07 09:01:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:19 536] [08-07 09:01:21 TUYA E][tuya_ipc_cloud_storage.c:942] iot_wd_common_read fails storage_restriction -6
[2024/8/7 9:01:19 537] [08-07 09:01:21 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992481}
[2024/8/7 9:01:19 553] [08-07 09:01:21 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.restriction.config.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992481&v=1.0&sign=7ffbd8e9bab98b6537599ede89cd2e60
[2024/8/7 9:01:19 568] [08-07 09:01:21 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:19 568] [08-07 09:01:21 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:19 584] [08-07 09:01:21 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:19 584] [08-07 09:01:21 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:19 600] [08-07 09:01:21 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:19 600] [08-07 09:01:21 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:19 616] [08-07 09:01:21 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:19 616] [08-07 09:01:21 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:19 616] [08-07 09:01:21 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:19 632] [08-07 09:01:21 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:19 632] [08-07 09:01:21 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:19 648] [08-07 09:01:21 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:19 664] [08-07 09:01:21 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:19 680] [08-07 09:01:21 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"msg":{"audioDuration":15,"audioInterval":300,"videoDuration":6,"videoInterval":300},"storage":{"mtu":10}},"t":1722992482,"success":true}
[2024/8/7 9:01:19 680] [08-07 09:01:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:19 696] [08-07 09:01:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:19 696] [08-07 09:01:22 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:01:19 696] [08-07 09:01:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:19 712] [08-07 09:01:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:19 712] [08-07 09:01:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:19 728] [08-07 09:01:22 TUYA D][simplekv.c:374] write key:storage_restriction And Value Len:32
[2024/8/7 9:01:19 728] [08-07 09:01:22 TUYA D][simplekv.c:457] new space 16 startpos:37292 size:100
[2024/8/7 9:01:19 728] [08-07 09:01:22 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:19 744] [08-07 09:01:22 TUYA D][simplekv.c:203] update crc 880880484
[2024/8/7 9:01:19 744] [08-07 09:01:22 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:19 744] [08-07 09:01:22 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:19 760] [08-07 09:01:22 TUYA D][tuya_ipc_cloud_storage.c:920] slice_duration write success
[2024/8/7 9:01:19 760] [08-07 09:01:22 TUYA D][tuya_ipc_cloud_storage.c:999] case 2 get slice duration from cloud 10
[2024/8/7 9:01:19 776] [08-07 09:01:22 TUYA D][tuya_ipc_cloud_storage.c:1043] cloud storage seize 3059584 bytes memory for media data, each slice 10 seconds
[2024/8/7 9:01:19 792] [08-07 09:01:22 TUYA I][uni_thread.c:228] thread_create name:cloud_storage,stackDepth:65536,totalstackDepth:91136,priority:3
[2024/8/7 9:01:19 792] [08-07 09:01:22 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[2024/8/7 9:01:19 808] [08-07 09:01:22 TUYA D][tuya_ipc_cloud_storage.c:2289] init cloud storage success
[2024/8/7 9:01:19 808] [08-07 09:01:22 TUYA D][MainApp.c:590] cloud storage init result is 0
[2024/8/7 9:01:19 824] [08-07 09:01:22 TUYA D][uni_thread.c:250] Thread:cloud_storage Exec Start. Set to Running Stat
[2024/8/7 9:01:19 824] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:19 840] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:19 840] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:19 856] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:19 856] __dp_data_report_data 4
[2024/8/7 9:01:19 856] 69 01 01 00 
[2024/8/7 9:01:19 856] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:19 872] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:19 872] bt_ack_uncrypt 4
[2024/8/7 9:01:19 872] 69 01 01 00 
[2024/8/7 9:01:19 872] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:19 888] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"105":false}
[2024/8/7 9:01:19 888] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62593 Q:1 Data:{"dps":{"105":false}}
[2024/8/7 9:01:19 888] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:19 904] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:19 904] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:01:19 920] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:19 920] __dp_data_report_data 4
[2024/8/7 9:01:19 920] 65 01 01 01 
[2024/8/7 9:01:19 920] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:19 936] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:19 936] bt_ack_uncrypt 4
[2024/8/7 9:01:19 936] 65 01 01 01 
[2024/8/7 9:01:19 952] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:19 953] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"101":true}
[2024/8/7 9:01:19 954] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62594 Q:1 Data:{"dps":{"101":true}}
[2024/8/7 9:01:19 968] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:19 968] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:19 984] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:19 984] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:19 984] __dp_data_report_data 4
[2024/8/7 9:01:19 984] 67 01 01 00 
[2024/8/7 9:01:20 001] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 001] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:20 001] bt_ack_uncrypt 4
[2024/8/7 9:01:20 016] 67 01 01 00 
[2024/8/7 9:01:20 017] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 017] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"103":false}
[2024/8/7 9:01:20 033] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62595 Q:1 Data:{"dps":{"103":false}}
[2024/8/7 9:01:20 033] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 049] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:20 049] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:01:20 065] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:20 065] __dp_data_report_data 4
[2024/8/7 9:01:20 065] 68 01 01 01 
[2024/8/7 9:01:20 065] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 080] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:20 080] bt_ack_uncrypt 4
[2024/8/7 9:01:20 080] 68 01 01 01 
[2024/8/7 9:01:20 080] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 096] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"104":true}
[2024/8/7 9:01:20 096] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62596 Q:1 Data:{"dps":{"104":true}}
[2024/8/7 9:01:20 112] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 112] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:107 not find
[2024/8/7 9:01:20 112] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:20 128] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:20 128] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 144] [08-07 09:01:22 TUYA D][iot_httpc.c:1161] Post Data: {"type":"MediaStor","t":1722992482}
[2024/8/7 9:01:20 160] [08-07 09:01:22 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992482&v=3.0&sign=cb9168180758a14b578e86332ed7eaf7
[2024/8/7 9:01:20 160] [08-07 09:01:22 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:20 176] [08-07 09:01:22 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:20 176] [08-07 09:01:22 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:20 176] [08-07 09:01:22 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:20 192] [08-07 09:01:22 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:01:20 192] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[2024/8/7 9:01:20 208] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:105, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:20 224] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:105, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 224] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:105, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 240] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0
[2024/8/7 9:01:20 240] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:101, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:20 256] [08-07 09:01:22 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:01:20 256] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:101, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 272] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:101, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 272] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:20 272] tuya_hal_bt_send 20
[2024/8/7 9:01:20 288] 00 31 36 05 25 a8 7b b9 50 eb 5e ac 51 ee [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:108 not find
[2024/8/7 9:01:20 288] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:20 304] 3c a2 [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:20 304] IPC_APP_get_smart_mutile_light_mode line(546) ----------  
[2024/8/7 9:01:20 304] 58 df 06 84 
[2024/8/7 9:01:20 320] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:20 320] 0 31 36 5 25 a8 7b b9 50 eb 5e ac 51 ee 3c a2 58 df 6 84 
[2024/8/7 9:01:20 320] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:20 337] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:20 337] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0
[2024/8/7 9:01:20 352] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:103, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:20 368] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:103, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 368] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:103, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 384] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0
[2024/8/7 9:01:20 384] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:104, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:20 400] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:104, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 400] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:104, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 416] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:01:20 416] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:01:20 416] IPC_APP_set_smart_mutile_light_mode line(451) ---------- :0 ,g_SMLAbility=[0]
[2024/8/7 9:01:20 432] [08-07 09:01:22 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:20 432] [08-07 09:01:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:20 448] [08-07 09:01:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:20 448] [08-07 09:01:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:20 464] [08-07 09:01:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:20 464] [08-07 09:01:22 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:20 480] [08-07 09:01:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:20 480] DEBUG: camera_set_dnc_mode_chn 0 
[2024/8/7 9:01:20 480] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:01:20 480] DEBUG: software pohtoR!
[2024/8/7 9:01:20 496] IPC_APP_set_smart_mutile_light_mode line(536) ---------- :mode=[0] 
[2024/8/7 9:01:20 496] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 512] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<124> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:20 512] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:20 512] __dp_data_report_data 4
[2024/8/7 9:01:20 512] 7c 04 01 00 
[2024/8/7 9:01:20 528] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 528] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:20 528] bt_ack_uncrypt 4
[2024/8/7 9:01:20 528] 7c 04 01 00 
[2024/8/7 9:01:20 544] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 544] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"124":"auto"}
[2024/8/7 9:01:20 560] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62597 Q:1 Data:{"dps":{"124":"auto"}}
[2024/8/7 9:01:20 560] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 576] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:20 576] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:01:20 576] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:20 592] __dp_data_report_data 4
[2024/8/7 9:01:20 592] 86 01 01 01 
[2024/8/7 9:01:20 592] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 608] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:20 608] bt_ack_uncrypt 4
[2024/8/7 9:01:20 608] 86 01 01 01 
[2024/8/7 9:01:20 608] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 625] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"134":true}
[2024/8/7 9:01:20 625] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62598 Q:1 Data:{"dps":{"134":true}}
[2024/8/7 9:01:20 625] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 641] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:20 641] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:20 657] __dp_data_report_data 4
[2024/8/7 9:01:20 657] 6a 04 01 01 
[2024/8/7 9:01:20 657] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 672] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:20 673] bt_ack_uncrypt 4
[2024/8/7 9:01:20 673] 6a 04 01 01 
[2024/8/7 9:01:20 673] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 673] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"106":"1"}
[2024/8/7 9:01:20 689] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62599 Q:1 Data:{"dps":{"106":"1"}}
[2024/8/7 9:01:20 689] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 705] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:168 not find
[2024/8/7 9:01:20 705] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:20 705] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:20 721] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(855):  ---
[2024/8/7 9:01:20 721] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(866):  ---
[2024/8/7 9:01:20 737] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(872):  ---
[2024/8/7 9:01:20 737] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(892):  ---
[2024/8/7 9:01:20 753] [IPC_APP_get_alarm_zone_draw][893] alarm zone[{\"num\":1,\"region0\":{\"x\":1,\"y\":1,\"xlen\":99,\"ylen\":99}}]
[2024/8/7 9:01:20 753] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 769] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:169 not find
[2024/8/7 9:01:20 769] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:20 769] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:20 769] curr sd_status:1 
[2024/8/7 9:01:20 785] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 785] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:20 800] [08-07 09:01:22 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:5
[2024/8/7 9:01:20 800] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:20 800] __dp_data_report_data 7
[2024/8/7 9:01:20 800] 6e 02 04 00 00 00 05 
[2024/8/7 9:01:20 816] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 816] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:20 816] bt_ack_uncrypt 7
[2024/8/7 9:01:20 832] 6e 02 04 00 00 00 05 
[2024/8/7 9:01:20 832] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 832] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"110":5}
[2024/8/7 9:01:20 848] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62600 Q:1 Data:{"dps":{"110":5}}
[2024/8/7 9:01:20 848] handle_DP_SD_STORAGE_ONLY_GET line(654) --------------------- 
[2024/8/7 9:01:20 864] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"124":"auto"}}, mqtt async dp cb:0
[2024/8/7 9:01:20 864] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:124, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:20 880] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:124, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 880] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:124, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:20 896] [08-07 09:01:22 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:20 912] [08-07 09:01:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:20 912] [1970-01-01 00:00:41] tuya_ipc_sd_demo.c(182) <tuya_ipc_sd_get_capacity>: XM_SDCardGetPartitionInfo failed
[2024/8/7 9:01:20 928] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:20 928] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:20 944] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:20 944] __dp_data_report_data 8
[2024/8/7 9:01:20 944] 6d 03 05 30 7c 30 7c 30 
[2024/8/7 9:01:20 960] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 960] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:20 960] bt_ack_uncrypt 8
[2024/8/7 9:01:20 960] 6d 03 05 30 7c 30 7c 30 
[2024/8/7 9:01:20 976] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:20 976] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0"}
[2024/8/7 9:01:20 992] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62601 Q:1 Data:{"dps":{"109":"0|0|0"}}
[2024/8/7 9:01:20 992] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 008] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:21 008] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:01:21 008] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:21 024] __dp_data_report_data 4
[2024/8/7 9:01:21 024] 96 01 01 01 
[2024/8/7 9:01:21 024] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 024] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:21 040] bt_ack_uncrypt 4
[2024/8/7 9:01:21 040] 96 01 01 01 
[2024/8/7 9:01:21 040] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 040] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"150":true}
[2024/8/7 9:01:21 056] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62602 Q:1 Data:{"dps":{"150":true}}
[2024/8/7 9:01:21 056] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0
[2024/8/7 9:01:21 072] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:134, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:21 088] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:134, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 088] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:134, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 104] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:21 104] tuya_hal_bt_send 20
[2024/8/7 9:01:21 104] 01 63 69 c0 4e 6c ee 70 3e 99 81 96 7f be 75 49 57 be 7e 8c 
[2024/8/7 9:01:21 120] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:21 120] 1 63 69 c0 4e 6c ee 70 3e 99 81 96 7f be 75 49 57 be 7e 8c 
[2024/8/7 9:01:21 120] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:21 136] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:21 136] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 152] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:21 152] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:21 152] __dp_data_report_data 4
[2024/8/7 9:01:21 152] 97 04 01 00 
[2024/8/7 9:01:21 168] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 168] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:21 168] bt_ack_uncrypt 4
[2024/8/7 9:01:21 184] 97 04 01 00 
[2024/8/7 9:01:21 185] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 185] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"151":"1"}
[2024/8/7 9:01:21 204] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62603 Q:1 Data:{"dps":{"151":"1"}}
[2024/8/7 9:01:21 204] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"106":"1"}}, mqtt async dp cb:0
[2024/8/7 9:01:21 216] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:106, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:21 232] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:106, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 232] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:106, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 232] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 248] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:21 264] [08-07 09:01:22 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:0
[2024/8/7 9:01:21 265] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:21 265] __dp_data_report_data 7
[2024/8/7 9:01:21 265] 75 02 04 00 00 00 00 
[2024/8/7 9:01:21 280] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 280] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:21 280] bt_ack_uncrypt 7
[2024/8/7 9:01:21 280] 75 02 04 00 00 00 00 
[2024/8/7 9:01:21 295] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 296] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 9:01:21 312] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0
[2024/8/7 9:01:21 312] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62604 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 9:01:21 328] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:110, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:21 328] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:110, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 344] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:110, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 344] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 360] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<138> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:21 360] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:21 376] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:21 376] __dp_data_report_data 4
[2024/8/7 9:01:21 376] 8a 01 01 00 
[2024/8/7 9:01:21 376] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 392] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:21 392] bt_ack_uncrypt 4
[2024/8/7 9:01:21 392] 8a 01 01 00 
[2024/8/7 9:01:21 392] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 408] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"138":false}
[2024/8/7 9:01:21 408] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62605 Q:1 Data:{"dps":{"138":false}}
[2024/8/7 9:01:21 408] current power mode:1
[2024/8/7 9:01:21 423] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 424] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:146 not find
[2024/8/7 9:01:21 424] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:21 440] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:21 441] current battery percent:80
[2024/8/7 9:01:21 441] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 457] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:145 not find
[2024/8/7 9:01:21 457] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:21 457] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:21 472] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 472] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:21 488] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:21 488] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:21 489] __dp_data_report_data 4
[2024/8/7 9:01:21 505] aa 01 01 00 
[2024/8/7 9:01:21 505] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 505] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:21 505] bt_ack_uncrypt 4
[2024/8/7 9:01:21 520] aa 01 01 00 
[2024/8/7 9:01:21 520] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 521] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"170":false}
[2024/8/7 9:01:21 536] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62606 Q:1 Data:{"dps":{"170":false}}
[2024/8/7 9:01:21 537] src/intelligent_track_thread.c(1466) [XM_GetBodyTarckEnable]: 
[2024/8/7 9:01:21 552] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 552] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:21 568] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:21 568] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:21 568] __dp_data_report_data 4
[2024/8/7 9:01:21 568] a1 01 01 00 
[2024/8/7 9:01:21 584] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 584] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:21 584] bt_ack_uncrypt 4
[2024/8/7 9:01:21 584] a1 01 01 00 
[2024/8/7 9:01:21 600] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 600] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"161":false}
[2024/8/7 9:01:21 616] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62607 Q:1 Data:{"dps":{"161":false}}
[2024/8/7 9:01:21 616] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 616] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:186 not find
[2024/8/7 9:01:21 632] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:21 632] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:21 632] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 648] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<133> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:21 664] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:21 664] __dp_data_report_data 4
[2024/8/7 9:01:21 664] 85 04 01 01 
[2024/8/7 9:01:21 664] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 680] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:21 680] bt_ack_uncrypt 4
[2024/8/7 9:01:21 680] 85 04 01 01 
[2024/8/7 9:01:21 680] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 696] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3"}
[2024/8/7 9:01:21 696] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62608 Q:1 Data:{"dps":{"133":"3"}}
[2024/8/7 9:01:21 696] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:21 712] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:21 712] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:21 728] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:21 728] __dp_data_report_data 4
[2024/8/7 9:01:21 728] 8b 01 01 00 
[2024/8/7 9:01:21 728] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 744] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:21 744] bt_ack_uncrypt 4
[2024/8/7 9:01:21 744] 8b 01 01 00 
[2024/8/7 9:01:21 760] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:21 761] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 9:01:21 761] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62609 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 9:01:21 776] [08-07 09:01:22 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 9:01:21 776] [08-07 09:01:22 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 9:01:21 792] [08-07 09:01:22 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 9:01:21 792] [08-07 09:01:22 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 9:01:21 792] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 70 enable 0 volume
[2024/8/7 9:01:21 808] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:21 808] tuya_hal_bt_send 14
[2024/8/7 9:01:21 808] 02 f5 2b cf 81 1a a2 3d 17 db be 08 74 85 
[2024/8/7 9:01:21 824] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:21 824] 2 f5 2b cf 81 1a a2 3d 17 db be 8 74 85 
[2024/8/7 9:01:21 825] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:21 840] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:21 840] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"109":"0|0|0"}}, mqtt async dp cb:0
[2024/8/7 9:01:21 856] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:109, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:21 872] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:109, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 872] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:109, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 888] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0
[2024/8/7 9:01:21 889] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:150, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:21 904] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:150, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 904] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:150, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 920] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[2024/8/7 9:01:21 936] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:151, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:21 937] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:151, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 952] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:151, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 952] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[2024/8/7 9:01:21 968] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:117, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:21 969] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:117, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 984] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:117, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:21 985] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"138":false}}, mqtt async dp cb:0
[2024/8/7 9:01:22 000] [08-07 09:01:22 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1722992482,"success":true}
[2024/8/7 9:01:22 017] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:138, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:22 017] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:138, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 033] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:138, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 033] [08-07 09:01:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:22 048] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"170":false}}, mqtt async dp cb:0
[2024/8/7 9:01:22 049] [08-07 09:01:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:22 065] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:170, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:22 081] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:170, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 081] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:170, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 096] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"161":false}}, mqtt async dp cb:0
[2024/8/7 9:01:22 096] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:161, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:22 112] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:161, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 112] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:161, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 129] [08-07 09:01:22 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[2024/8/7 9:01:22 129] [08-07 09:01:22 TUYA D][tuya_ipc_cloud_storage.c:535] order expire or remote server error
[2024/8/7 9:01:22 144] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"133":"3"}}, mqtt async dp cb:0
[2024/8/7 9:01:22 160] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:133, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:22 160] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:133, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 176] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:133, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 176] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 192] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:22 192] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:22 192] __dp_data_report_data 4
[2024/8/7 9:01:22 192] 8c 04 01 01 
[2024/8/7 9:01:22 208] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 208] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:22 208] bt_ack_uncrypt 4
[2024/8/7 9:01:22 208] 8c 04 01 01 
[2024/8/7 9:01:22 224] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 224] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"140":"1"}
[2024/8/7 9:01:22 240] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62610 Q:1 Data:{"dps":{"140":"1"}}
[2024/8/7 9:01:22 240] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 240] [08-07 09:01:22 TUYA E][smart_frame.c:569] dparr[0] type not match:1 0
[2024/8/7 9:01:22 256] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3586
[2024/8/7 9:01:22 256] [08-07 09:01:22 TUYA E][tuya_ipc_cloud_storage.c:1695] check cloud storage count failed, op_ret = -1
[2024/8/7 9:01:22 272] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 272] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:22 288] [08-07 09:01:22 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:50
[2024/8/7 9:01:22 288] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:22 288] __dp_data_report_data 7
[2024/8/7 9:01:22 288] a0 02 04 00 00 00 32 
[2024/8/7 9:01:22 304] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 304] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:22 304] bt_ack_uncrypt 7
[2024/8/7 9:01:22 304] a0 02 04 00 00 00 32 
[2024/8/7 9:01:22 320] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 320] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"160":50}
[2024/8/7 9:01:22 336] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62611 Q:1 Data:{"dps":{"160":50}}
[2024/8/7 9:01:22 336] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 352] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:195 not find
[2024/8/7 9:01:22 352] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:22 352] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:22 368] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 368] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:194 not find
[2024/8/7 9:01:22 368] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:22 384] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:22 384] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 400] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:158 not find
[2024/8/7 9:01:22 401] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:22 401] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:22 416] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 416] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:22 432] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:22 432] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:22 432] __dp_data_report_data 4
[2024/8/7 9:01:22 432] 9f 01 01 00 
[2024/8/7 9:01:22 448] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 448] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:22 448] bt_ack_uncrypt 4
[2024/8/7 9:01:22 448] 9f 01 01 00 
[2024/8/7 9:01:22 464] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 464] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:01:22 480] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62612 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:01:22 480] [1970-01-01 00:00:41] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:01:22 480] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 496] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:22 512] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:22 512] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:22 512] __dp_data_report_data 4
[2024/8/7 9:01:22 512] ae 01 01 00 
[2024/8/7 9:01:22 528] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 528] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:22 528] bt_ack_uncrypt 4
[2024/8/7 9:01:22 528] ae 01 01 00 
[2024/8/7 9:01:22 544] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 544] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"174":false}
[2024/8/7 9:01:22 560] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62613 Q:1 Data:{"dps":{"174":false}}
[2024/8/7 9:01:22 560] [1970-01-01 00:00:41] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:01:22 560] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 576] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:22 576] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:22 592] __dp_data_report_data 4
[2024/8/7 9:01:22 592] af 04 01 00 
[2024/8/7 9:01:22 592] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 592] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:22 608] bt_ack_uncrypt 4
[2024/8/7 9:01:22 608] af 04 01 00 
[2024/8/7 9:01:22 608] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 608] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"175":"0"}
[2024/8/7 9:01:22 624] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62614 Q:1 Data:{"dps":{"175":"0"}}
[2024/8/7 9:01:22 640] [08-07 09:01:22 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:22 640] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:22 640] tuya_hal_bt_send 20
[2024/8/7 9:01:22 656] 00 31 37 05 0e b8 38 79 18 e4 4b 86 21 ed df 80 73 64 f6 72 
[2024/8/7 9:01:22 656] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:22 656] 0 31 37 5 e b8 38 79 18 e4 4b 86 21 ed df 80 73 64 f6 72 
[2024/8/7 9:01:22 672] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:22 673]  ---
[2024/8/7 9:01:22 673] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:22 688] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"140":"1"}}, mqtt async dp cb:0
[2024/8/7 9:01:22 688] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:140, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:22 704] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:140, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 704] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:140, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 720] [1970-01-01 00:00:41] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:01:22 720] cruiseTimeMode is 0.
[2024/8/7 9:01:22 720] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 736] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:22 736] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:22 752] __dp_data_report_data 4
[2024/8/7 9:01:22 752] b0 04 01 00 
[2024/8/7 9:01:22 752] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 752] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:22 768] bt_ack_uncrypt 4
[2024/8/7 9:01:22 768] b0 04 01 00 
[2024/8/7 9:01:22 768] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:22 768] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"176":"0"}
[2024/8/7 9:01:22 784] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62615 Q:1 Data:{"dps":{"176":"0"}}
[2024/8/7 9:01:22 784] [1970-01-01 00:00:41] utils.c(322) <ReadTYJsonConfig>: Get antiFlicker object error!
[2024/8/7 9:01:22 800] anti Flicker mode is 0.
[2024/8/7 9:01:22 800] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 800] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:188 not find
[2024/8/7 9:01:22 816] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:22 816] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:22 831] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"160":50}}, mqtt async dp cb:0
[2024/8/7 9:01:22 832] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:160, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:22 847] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:160, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 848] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:160, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 863] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:01:22 879] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:22 880] [1970-01-01 00:00:41] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:01:22 895] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 896] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 912] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 913] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:192 not find
[2024/8/7 9:01:22 913] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:22 928] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:22 928] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"174":false}}, mqtt async dp cb:0
[2024/8/7 9:01:22 944] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:174, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:22 944] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:174, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 960] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:174, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:22 960] [1970-01-01 00:00:41] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:01:22 976] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:22 976] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:193 not find
[2024/8/7 9:01:22 992] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:22 992] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:22 992] [1970-01-01 00:00:41] utils.c(322) <ReadTYJsonConfig>: Get FlightWarn object error!
[2024/8/7 9:01:23 008] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:23 008] [08-07 09:01:22 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:173 not find
[2024/8/7 9:01:23 024] [08-07 09:01:22 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:01:23 024] [08-07 09:01:22 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:01:23 024] [1970-01-01 00:00:41] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:01:23 040] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:23 040] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:23 056] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:23 057] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:23 057] __dp_data_report_data 4
[2024/8/7 9:01:23 057] 78 01 01 00 
[2024/8/7 9:01:23 072] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:23 073] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:23 073] bt_ack_uncrypt 4
[2024/8/7 9:01:23 073] 78 01 01 00 
[2024/8/7 9:01:23 088] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:23 088] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"120":false}
[2024/8/7 9:01:23 104] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62616 Q:1 Data:{"dps":{"120":false}}
[2024/8/7 9:01:23 104] [08-07 09:01:22 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:23 120] [08-07 09:01:22 TUYA D][smart_frame.c:419] dp<231> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:23 120] [08-07 09:01:22 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:23 136] [08-07 09:01:22 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:23 136] __dp_data_report_data 4
[2024/8/7 9:01:23 136] e7 01 01 00 
[2024/8/7 9:01:23 136] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:23 152] [08-07 09:01:22 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:23 152] bt_ack_uncrypt 4
[2024/8/7 9:01:23 152] e7 01 01 00 
[2024/8/7 9:01:23 152] [08-07 09:01:22 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:23 168] [08-07 09:01:22 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"231":false}
[2024/8/7 9:01:23 168] [08-07 09:01:22 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62617 Q:1 Data:{"dps":{"231":false}}
[2024/8/7 9:01:23 184] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"175":"0"}}, mqtt async dp cb:0
[2024/8/7 9:01:23 184] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:175, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:23 200] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:175, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:23 200] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:175, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:23 216] [08-07 09:01:22 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}","t":1722992482}
[2024/8/7 9:01:23 232] [08-07 09:01:22 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c62194832a0f26036b5lh&et=1&t=1722992482&v=1.0&sign=549730b0ba5e885ad6ba06459335f5a3
[2024/8/7 9:01:23 248] [08-07 09:01:22 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:23 248] [08-07 09:01:22 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:23 264] [08-07 09:01:22 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:23 264] [08-07 09:01:22 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:23 280] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"176":"0"}}, mqtt async dp cb:0
[2024/8/7 9:01:23 280] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:176, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:23 296] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:176, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:23 312] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:176, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:23 312] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"120":false}}, mqtt async dp cb:0
[2024/8/7 9:01:23 328] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:120, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:23 328] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:120, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:23 344] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:120, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:23 344] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:23 360] tuya_hal_bt_send 20
[2024/8/7 9:01:23 360] 01 81 0f 8d 2c 45 b1 34 a0 ab d8 22 4c 47 7b c8 64 74 cc 0d 
[2024/8/7 9:01:23 360] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:23 376] 1 81 f 8d 2c 45 b1 34 a0 ab d8 22 4c 47 7b c8 64 74 cc d 
[2024/8/7 9:01:23 376] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:23 376] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:23 392] [08-07 09:01:22 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:23 392] [08-07 09:01:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:23 408] [08-07 09:01:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:23 408] [08-07 09:01:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:23 424] [08-07 09:01:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:23 424] [08-07 09:01:22 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:23 440] [08-07 09:01:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:23 440] [08-07 09:01:22 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"231":false}}, mqtt async dp cb:0
[2024/8/7 9:01:23 456] [08-07 09:01:22 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:231, curr_t:1722992482, rept_cnt:1.
[2024/8/7 9:01:23 456] [08-07 09:01:22 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:231, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:23 472] [08-07 09:01:22 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:231, curr_t:1722992482, rept_cnt:0.
[2024/8/7 9:01:23 489] [08-07 09:01:22 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:23 489] [08-07 09:01:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:23 504] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:23 504] tuya_hal_bt_send 14
[2024/8/7 9:01:23 504] 02 20 b5 47 a5 a2 1b 20 b2 af 36 d8 f8 7a 
[2024/8/7 9:01:23 520] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:23 520] 2 20 b5 47 a5 a2 1b 20 b2 af 36 d8 f8 7a 
[2024/8/7 9:01:23 520] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:23 536] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:23 536] [08-07 09:01:22 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:23 552] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:23 552] tuya_hal_bt_send 20
[2024/8/7 9:01:23 552] 00 31 38 05 b9 88 66 51 6d 31 57 0e 1f 37 0f 12 1c 06 84 7b 
[2024/8/7 9:01:23 568] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:23 568] 0 31 38 5 b9 88 66 51 6d 31 57 e 1f 37 f 12 1c 6 84 7b 
[2024/8/7 9:01:23 568] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:23 584] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:23 584] [08-07 09:01:22 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992482,"success":true}
[2024/8/7 9:01:23 600] [08-07 09:01:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:23 600] [08-07 09:01:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:23 616] [08-07 09:01:22 TUYA D][tuya_ipc_skill.c:198] upload data: {\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}
[2024/8/7 9:01:23 616] [08-07 09:01:22 TUYA D][MainApp.c:597] tuya_ipc_sdk_mqtt_online_proc is end run
[2024/8/7 9:01:23 632] [1970-01-01 00:00:42] MainApp.c(599) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:01:23 632] tuya_ipc_p2p_demo.c(455)<TUYA_APP_Enable_P2PTransfer> Dbg: Init P2P With Max Users:5
[2024/8/7 9:01:23 648] [08-07 09:01:22 TUYA D][tuya_ipc_webrtc.c:1534] begin___
[2024/8/7 9:01:23 648] [08-07 09:01:22 TUYA D][tuya_ipc_webrtc.c:1541] --audio-:8000,format:101
[2024/8/7 9:01:23 648] [08-07 09:01:22 TUYA D][tuya_ipc_webrtc.c:1542] end___ audiocbk_hdl(0x18f5c)
[2024/8/7 9:01:23 664] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:5086] gw actived
[2024/8/7 9:01:23 664] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:5095] p2p max_client_num[5]
[2024/8/7 9:01:23 664] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:5096] p2p init media info:
[2024/8/7 9:01:23 680] [08-07 09:01:22 TUYA D][tuya_ipc_webrtc.c:1526] webrtc playback start_id 5
[2024/8/7 9:01:23 680] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:01:23 696] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4782] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:01:23 696] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:01:23 712] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4782] height[360] width[640] bitrate[1024]
[2024/8/7 9:01:23 712] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:01:23 728] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4794] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:01:23 728] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:01:23 728] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4794] height[360] width[640] bitrate[1024]
[2024/8/7 9:01:23 744] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:01:23 744] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:01:23 760] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:01:23 760] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:01:23 777] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:01:23 777] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:01:23 792] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:01:23 792] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:01:23 808] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:01:23 808] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:01:23 824] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4796] videoNum[2] audio codec[129] sample[0]
[2024/8/7 9:01:23 824] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4797] databits[1] channel[0]
[2024/8/7 9:01:23 841] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:5122] need speaker audio codec[129] sample[0] databits[1] channel[0] defLiveMode[0]
[2024/8/7 9:01:23 841] [08-07 09:01:22 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:01:23 857] [08-07 09:01:22 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:01:23 857] [08-07 09:01:22 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:01:23 872] [08-07 09:01:22 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = adb2c75d
[2024/8/7 9:01:23 872] [08-07 09:01:22 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[2024/8/7 9:01:23 872] [08-07 09:01:22 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:01:23 888] [08-07 09:01:22 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:01:23 888] [08-07 09:01:22 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:01:23 904] [08-07 09:01:22 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:01:23 904] [08-07 09:01:22 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:01:23 904] [08-07 09:01:22 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:01:23 920] [08-07 09:01:22 TUYA D][tuya_ipc_p2p_common.c:455] update p2p_auth_info from service, type 4
[2024/8/7 9:01:23 920] [08-07 09:01:22 TUYA D][iot_httpc.c:1161] Post Data: {"type":4,"t":1722992482}
[2024/8/7 9:01:23 952] [08-07 09:01:22 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.p2p.config.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992482&v=2.0&sign=fda0e62e5dcb7126b29fafba7237afa0
[2024/8/7 9:01:23 952] [08-07 09:01:22 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:23 953] [08-07 09:01:22 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:23 968] [08-07 09:01:22 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:23 968] [08-07 09:01:22 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:23 984] [08-07 09:01:22 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:23 984] [08-07 09:01:22 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:24 000] [08-07 09:01:22 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:24 000] [08-07 09:01:22 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:24 016] [08-07 09:01:22 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:24 016] [08-07 09:01:22 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:24 032] [08-07 09:01:22 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:24 032] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:24 033] tuya_hal_bt_send 20
[2024/8/7 9:01:24 048] 01 f2 45 b6 4f b2 7f 60 2d 4e c5 e6 a8 4b 28 36 d4 7f 7b 59 
[2024/8/7 9:01:24 048] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 049] 1 f2 45 b6 4f b2 7f 60 2d 4e c5 e6 a8 4b 28 36 d4 7f 7b 59 
[2024/8/7 9:01:24 064] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 064] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 080] [08-07 09:01:22 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:24 096] [08-07 09:01:22 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:24 096] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:24 096] tuya_hal_bt_send 14
[2024/8/7 9:01:24 096] 02 7d 47 02 79 4a 9d 77 5c 86 be 0d 8e dd 
[2024/8/7 9:01:24 112] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 112] 2 7d 47 2 79 4a 9d 77 5c 86 be d 8e dd 
[2024/8/7 9:01:24 112] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 128]  ---
[2024/8/7 9:01:24 128] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 128] [08-07 09:01:22 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:24 144] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:24 144] tuya_hal_bt_send 20
[2024/8/7 9:01:24 144] 00 31 39 05 b7 55 59 a4 86 b0 b2 26 e8 c1 38 84 48 bd 7f 87 
[2024/8/7 9:01:24 160] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 160] 0 31 39 5 b7 55 59 a4 86 b0 b2 26 e8 c1 38 84 48 bd 7f 87 
[2024/8/7 9:01:24 176] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 176] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 193] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:24 193] tuya_hal_bt_send 20
[2024/8/7 9:01:24 193] 01 6b 08 7d 76 bf 77 fa 64 6a f2 2e 12 a6 39 1b 8d 3f 0b 0c 
[2024/8/7 9:01:24 193] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 208] 1 6b 8 7d 76 bf 77 fa 64 6a f2 2e 12 a6 39 1b 8d 3f b c 
[2024/8/7 9:01:24 208] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 224] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 224] [08-07 09:01:22 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"p2pId":"","type":4},"t":1722992482,"success":true}
[2024/8/7 9:01:24 240] [08-07 09:01:22 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:24 241] [08-07 09:01:22 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:24 256] [08-07 09:01:22 TUYA D][tuya_ipc_p2p_common.c:381] SY P2P AUTH:{"p2pId":"","type":4}
[2024/8/7 9:01:24 258] [08-07 09:01:22 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:01:24 258] [08-07 09:01:22 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:01:24 272] [08-07 09:01:22 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:01:24 272] [08-07 09:01:22 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:32
[2024/8/7 9:01:24 288] [08-07 09:01:22 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 32
[2024/8/7 9:01:24 288] [08-07 09:01:22 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:01:24 288] [08-07 09:01:22 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:01:24 304] [08-07 09:01:22 TUYA D][simplekv.c:203] update crc 3678887058
[2024/8/7 9:01:24 304] [08-07 09:01:22 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:24 304] [08-07 09:01:22 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:24 319] [08-07 09:01:22 TUYA D][tuya_ipc_p2p_common.c:458] get p2p auth info from service
[2024/8/7 9:01:24 319] [08-07 09:01:22 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:01:24 335] [08-07 09:01:22 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:01:24 335] [08-07 09:01:22 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:01:24 351] [08-07 09:01:22 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:01:24 352] [08-07 09:01:22 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:01:24 352] [08-07 09:01:22 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:01:24 367] [08-07 09:01:22 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:01:24 367] [08-07 09:01:22 TUYA D][simplekv.c:203] update crc 3121625441
[2024/8/7 9:01:24 384] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:24 384] tuya_hal_bt_send 14
[2024/8/7 9:01:24 384] 02 c0 51 6f 0d d9 45 2a 1d 9b 17 f2 63 67 
[2024/8/7 9:01:24 384] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 400] 2 c0 51 6f d d9 45 2a 1d 9b 17 f2 63 67 
[2024/8/7 9:01:24 400] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 400] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 416] [08-07 09:01:22 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:24 432] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:24 432] tuya_hal_bt_send 20
[2024/8/7 9:01:24 432] 00 31 3a 05 35 3b ba 41 68 01 56 99 60 3b 8a 59 f7 a2 c8 bb 
[2024/8/7 9:01:24 432] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 448] 0 31 3a 5 35 3b ba 41 68 1 56 99 60 3b 8a 59 f7 a2 c8 bb 
[2024/8/7 9:01:24 448] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 464] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 464] [08-07 09:01:22 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:24 464] [08-07 09:01:22 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:24 480] [08-07 09:01:22 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:01:24 480] [08-07 09:01:22 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:01:24 496] [08-07 09:01:22 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:01:24 496] [08-07 09:01:22 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[2024/8/7 9:01:24 496] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:5178] p2p did[] apiLicense[] initString[]
[2024/8/7 9:01:24 512] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:5181] support p2p type = 4
[2024/8/7 9:01:24 512] P2P API Version: 244.3.4.107
[2024/8/7 9:01:24 512] [08-07 09:01:22 TUYA D][tuya_ipc_p2p.c:4974] no encrypt
[2024/8/7 9:01:24 528] 42375 (null) INFO:6241316: tuya p2p rtc sdk version: 0xf403046b, Nov 16 2023 10:52:20
[2024/8/7 9:01:24 528] tuya liteos uv
[2024/8/7 9:01:24 544] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:24 545] tuya_hal_bt_send 20
[2024/8/7 9:01:24 545] 01 17 b7 66 de 73 17 84 81 fc 34 56 9c 36 32 d2 dd eb d1 7a 
[2024/8/7 9:01:24 545] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 560] 1 17 b7 66 de 73 17 84 81 fc 34 56 9c 36 32 d2 dd eb d1 7a 
[2024/8/7 9:01:24 560] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 576] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 576] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:24 576] tuya_hal_bt_send 14
[2024/8/7 9:01:24 576] 02 27 c5 3a d9 b4 76 6a b4 bd 19 7e 1e 88 
[2024/8/7 9:01:24 592] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 592] 2 27 c5 3a d9 b4 76 6a b4 bd 19 7e 1e 88 
[2024/8/7 9:01:24 608] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 608] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 608] [08-07 09:01:22 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:24 624] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:24 624] tuya_hal_bt_send 20
[2024/8/7 9:01:24 640] 00 31 3b 05 9b 53 a8 05 54 7e 1e b5 3a 28 8e 32 ca d6 ed 5d 
[2024/8/7 9:01:24 641] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 641] 0 31 3b 5 9b 53 a8 5 54 7e 1e b5 3a 28 8e 32 ca d6 ed 5d 
[2024/8/7 9:01:24 656] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 656] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 672] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:24 672] tuya_hal_bt_send 20
[2024/8/7 9:01:24 672] 01 48 db 29 86 e2 3e 89 42 03 ba a1 d3 29 9c c9 8a 93 ce 0b 
[2024/8/7 9:01:24 672] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 688] 1 48 db 29 86 e2 3e 89 42 3 ba a1 d3 29 9c c9 8a 93 ce b 
[2024/8/7 9:01:24 688] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 704] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 704] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:24 704] tuya_hal_bt_send 14
[2024/8/7 9:01:24 720] 02 f4 f7 c3 ce 7e 4a e9 fd bf 6a 9c bc 1d 
[2024/8/7 9:01:24 720] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 720] 2 f4 f7 c3 ce 7e 4a e9 fd bf 6a 9c bc 1d 
[2024/8/7 9:01:24 736] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 736] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 752] [08-07 09:01:22 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:24 752] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:24 752] tuya_hal_bt_send 20
[2024/8/7 9:01:24 768] 00 31 3c 05 0d 65 34 62 e3 52 97 1e 7b 26 d0 c5 fd be a3 37 
[2024/8/7 9:01:24 768] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 768] 0 31 3c 5 d 65 34 62 e3 52 97 1e 7b 26 d0 c5 fd be a3 37 
[2024/8/7 9:01:24 784] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 784] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 800] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:24 800] tuya_hal_bt_send 20
[2024/8/7 9:01:24 800] 01 ba 18 41 a9 e2 c9 f0 6f 2e b7 9f 92 62 a3 30 1b a3 63 a0 
[2024/8/7 9:01:24 816] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 816] 1 ba 18 41 a9 e2 c9 f0 6f 2e b7 9f 92 62 a3 30 1b a3 63 a0 
[2024/8/7 9:01:24 816] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 832] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 832] [08-07 09:01:22 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:24 848] tuya_hal_bt_send 14
[2024/8/7 9:01:24 848] 02 ec ec 42 83 b5 77 39 6f 83 f8 01 ef 52 
[2024/8/7 9:01:24 848] [08-07 09:01:22 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 848] 2 ec ec 42 83 b5 77 39 6f 83 f8 1 ef 52 
[2024/8/7 9:01:24 864] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 864] [08-07 09:01:22 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 881] [08-07 09:01:23 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:24 881] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:24 881] tuya_hal_bt_send 20
[2024/8/7 9:01:24 896] 00 31 3d 05 07 40 0a 6b 13 a1 09 0e 47 d9 53 c4 99 f6 7b c6 
[2024/8/7 9:01:24 896] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 896] 0 31 3d 5 7 40 a 6b 13 a1 9 e 47 d9 53 c4 99 f6 7b c6 
[2024/8/7 9:01:24 912] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 912] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 928] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:24 928] tuya_hal_bt_send 20
[2024/8/7 9:01:24 928] 01 61 ab 64 e0 e1 6a 30 71 12 67 1d 42 c8 89 d2 7d 76 17 5c 
[2024/8/7 9:01:24 944] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:24 944] 1 61 ab 64 e0 e1 6a 30 71 12 67 1d 42 c8 89 d2 7d 76 17 5c 
[2024/8/7 9:01:24 944] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:24 960]  ---
[2024/8/7 9:01:24 960] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:24 960] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:5039] _mqtt_p2p_listen_sessions create
[2024/8/7 9:01:24 976] [08-07 09:01:23 TUYA E][tuya_ipc_p2p.c:5190] p2p v3 init ok
[2024/8/7 9:01:24 976] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:5230] speaker task create success
[2024/8/7 9:01:24 993] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:5273] __p2p_session_detech create
[2024/8/7 9:01:24 994] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:4652] Begin to session detech
[2024/8/7 9:01:24 995] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:5290] __p2p_video_send_proc create ok
[2024/8/7 9:01:25 008] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:3771] into p2p video send
[2024/8/7 9:01:25 008] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [0]
[2024/8/7 9:01:25 008] [08-07 09:01:23 TUYA D][tuya_ipc_upnp.c:437] tuya_ipc_upnp_init start
[2024/8/7 9:01:25 025] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:3553] New Thread To proc, init source
[2024/8/7 9:01:25 025] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:3572] session cmd recv proc alive [0] num[0]
[2024/8/7 9:01:25 041] [08-07 09:01:23 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:156672,priority:2
[2024/8/7 9:01:25 056] [08-07 09:01:23 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[2024/8/7 9:01:25 056] [08-07 09:01:23 TUYA D][tuya_ipc_upnp.c:458] tuya_ipc_upnp_init success
[2024/8/7 9:01:25 056] [08-07 09:01:23 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[2024/8/7 9:01:25 072] [08-07 09:01:23 TUYA D][tuya_ipc_packager.c:62] get packager instance
[2024/8/7 9:01:25 072] [08-07 09:01:23 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[2024/8/7 9:01:25 088] [08-07 09:01:23 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:01:25 088] [08-07 09:01:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:25 088] [08-07 09:01:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:25 105] [08-07 09:01:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:25 105] [08-07 09:01:23 TUYA E][tuya_ipc_encrypt.c:178] read local cloud encrypt key fails ..-6
[2024/8/7 9:01:25 120] [08-07 09:01:23 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992483}
[2024/8/7 9:01:25 137] [08-07 09:01:23 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.storage.secret.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992483&v=1.0&sign=def34ccc2b77e81694c5b3ed0adf0593
[2024/8/7 9:01:25 137] [08-07 09:01:23 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:25 152] [08-07 09:01:23 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:25 152] [08-07 09:01:23 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:25 152] [08-07 09:01:23 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:25 168] [08-07 09:01:23 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1722992483}
[2024/8/7 9:01:25 185] [08-07 09:01:23 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992483&v=1.0&sign=c4eb17b29130a33fec0e72b7c64cbe7e
[2024/8/7 9:01:25 199] [08-07 09:01:23 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:25 200] [08-07 09:01:23 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:25 216] [08-07 09:01:23 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:25 216] [08-07 09:01:23 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:25 217] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:25 231] tuya_hal_bt_send 14
[2024/8/7 9:01:25 231] 02 19 c4 c1 fa 01 a4 e2 e2 2d f4 58 dd 8f 
[2024/8/7 9:01:25 231] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:25 231] 2 19 c4 c1 fa 1 a4 e2 e2 2d f4 58 dd 8f 
[2024/8/7 9:01:25 247] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:25 247] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:25 263] [08-07 09:01:23 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:25 264] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:25 279] tuya_hal_bt_send 20
[2024/8/7 9:01:25 279] 00 31 3e 05 1d 69 c3 7f 9d 7f f8 2e de [08-07 09:01:23 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:25 296] [08-07 09:01:23 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:25 296] [08-07 09:01:23 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:25 311] [08-07 09:01:23 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:25 311] [08-07 09:01:23 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:25 311] [08-07 09:01:23 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:25 327] [08-07 09:01:23 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:25 327] 25 3b ed a9 4e 6c 13 
[2024/8/7 9:01:25 327] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:25 343] 0 31 3e 5 1d 69 c3 7f 9d 7f f8 2e de 25 3b ed a9 4e 6c 13 
[2024/8/7 9:01:25 343] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:25 360] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:25 360] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:4124] Begin to Listen mqtt p2p client connects In Thread
[2024/8/7 9:01:25 376] [08-07 09:01:23 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 9:01:25 376] 42860 (null) INFO:6241316: try listen
[2024/8/7 9:01:25 376] [08-07 09:01:23 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:25 393] [08-07 09:01:23 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:25 409] [08-07 09:01:23 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:25 409] [08-07 09:01:23 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:25 409] [08-07 09:01:23 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:25 425] [08-07 09:01:23 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:25 425] [08-07 09:01:23 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:25 440] [08-07 09:01:23 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:25 440] [08-07 09:01:23 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:25 456] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:25 456] tuya_hal_bt_send 20
[2024/8/7 9:01:25 472] 01 c3 4d 20 56 75 62 61 99 ec 12 b3 6b 3e 94 ab ab 03 f2 3c 
[2024/8/7 9:01:25 472] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:25 472] 1 c3 4d 20 56 75 62 61 99 ec 12 b3 6b 3e 94 ab ab 3 f2 3c 
[2024/8/7 9:01:25 488] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:25 488] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:25 504] [08-07 09:01:23 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:25 504] [08-07 09:01:23 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:25 520] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:25 520] tuya_hal_bt_send 14
[2024/8/7 9:01:25 520] 02 db fa 6b 08 61 62 32 27 b1 e6 97 4b ff 
[2024/8/7 9:01:25 536] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:25 536] 2 db fa 6b 8 61 62 32 27 b1 e6 97 4b ff 
[2024/8/7 9:01:25 536] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:25 552] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:25 568] [08-07 09:01:23 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"unitList":[{"port":7000,"protocol":"TCP"},{"port":8080,"protocol":"TCP"},{"port":5000,"protocol":"UDP"},{"port":8000,"protocol":"UDP"}]},"t":1722992483,"success":true}
[2024/8/7 9:01:25 584] [08-07 09:01:23 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:25 585] [08-07 09:01:23 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:25 600] [08-07 09:01:23 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"encryptKey":"992e9749e8f3402a"},"t":1722992483,"success":true}
[2024/8/7 9:01:25 600] [08-07 09:01:23 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:25 600] [08-07 09:01:23 TUYA D][tuya_ipc_upnp.c:171] upnp get config success result:{
[2024/8/7 9:01:25 600] 	"unitList":	[{
[2024/8/7 9:01:25 616] 			"port":	7000,
[2024/8/7 9:01:25 616] 			"protocol":	"TCP"
[2024/8/7 9:01:25 616] 		}, {
[2024/8/7 9:01:25 616] 			"port":	8080,
[2024/8/7 9:01:25 616] 			"port":	5000,
[2024/8/7 9:01:25 616] 			"protocol":	"UDP"
[2024/8/7 9:01:25 616] 			"port":	8000,
[2024/8/7 9:01:25 632] 		}]
[2024/8/7 9:01:25 632] [08-07 09:01:23 TUYA D][tuya_ipc_upnp.c:293] tuya_ipc_upnp_start start
[2024/8/7 9:01:25 632] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10.
[2024/8/7 9:01:25 648] [08-07 09:01:23 TUYA I][uni_thread.c:228] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:222208,priority:3
[2024/8/7 9:01:25 664] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0
[2024/8/7 9:01:25 664] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0
[2024/8/7 9:01:25 680] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:3098 
[2024/8/7 9:01:25 697] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 3098, in_port 3098 protocol:UDP, status:0
[2024/8/7 9:01:25 697] [08-07 09:01:23 TUYA D][uni_thread.c:250] Thread:UPnP_PROC Exec Start. Set to Running Stat
[2024/8/7 9:01:25 712] [08-07 09:01:23 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:25 712] [08-07 09:01:23 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:01:25 712] [08-07 09:01:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:25 728] [08-07 09:01:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:25 728] [08-07 09:01:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:25 728] [08-07 09:01:23 TUYA D][simplekv.c:374] write key:cloud_enc_key And Value Len:32
[2024/8/7 9:01:25 744] [08-07 09:01:23 TUYA D][simplekv.c:457] new space 17 startpos:37392 size:100
[2024/8/7 9:01:25 744] [08-07 09:01:23 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:01:25 760] [08-07 09:01:23 TUYA D][simplekv.c:203] update crc 535541058
[2024/8/7 9:01:25 760] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:7048 
[2024/8/7 9:01:25 776] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 7048, in_port 7048 protocol:UDP, status:0
[2024/8/7 9:01:25 776] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:8404 
[2024/8/7 9:01:25 792] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8404, in_port 8404 protocol:UDP, status:0
[2024/8/7 9:01:25 807] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5!
[2024/8/7 9:01:25 808] [08-07 09:01:23 TUYA D][tuya_ipc_upnp.c:314] tuya_ipc_upnp_start success
[2024/8/7 9:01:25 808] [08-07 09:01:23 TUYA D][tuya_ipc_upnp.c:421] start upnp module success, exit thread
[2024/8/7 9:01:25 823] [08-07 09:01:23 TUYA D][uni_thread.c:310] Del Thrd:ipc_upnp
[2024/8/7 9:01:25 823] [08-07 09:01:23 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:25 824] [08-07 09:01:23 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:25 839] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 90314ba51650
[2024/8/7 9:01:25 840] 
[2024/8/7 9:01:25 840] [08-07 09:01:23 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING...
[2024/8/7 9:01:25 855] [08-07 09:01:23 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:25 871] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:25 871] tuya_hal_bt_send 20
[2024/8/7 9:01:25 872] 00 31 3f 05 dc 6e 68 7a 6e 62 29 cc 07 64 ba 30 32 28 c2 03 
[2024/8/7 9:01:25 872] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:25 887] 0 31 3f 5 dc 6e 68 7a 6e 62 29 cc 7 64 ba 30 32 28 c2 3 
[2024/8/7 9:01:25 887] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:25 903] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:25 903] [08-07 09:01:23 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:230400,priority:3
[2024/8/7 9:01:25 919] [08-07 09:01:23 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[2024/8/7 9:01:25 951] [08-07 09:01:23 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":90000,\"profileId\":\"\",\"width\":3840,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[2024/8/7 9:01:25 951] [1970-01-01 00:00:43] tuya_ipc_p2p_demo.c(475) <TUYA_APP_Enable_P2PTransfer>: tuya_ipc_tranfser_init ret=[0]
[2024/8/7 9:01:25 968] [1970-01-01 00:00:43] MainApp.c(606) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:01:25 968] [1970-01-01 00:00:43] MainApp.c(614) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:01:25 984] [1970-01-01 00:00:43] MainApp.c(615) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:01:25 984] [1970-01-01 00:00:43] MainApp.c(616) <tuya_ipc_sdk_mqtt_online_proc>: v_handle=[0x1d0ed10]
[2024/8/7 9:01:26 000] [1970-01-01 00:00:43] MainApp.c(617) <tuya_ipc_sdk_mqtt_online_proc>: v_handle_sub=[0x1d12010]
[2024/8/7 9:01:26 000] [1970-01-01 00:00:43] MainApp.c(618) <tuya_ipc_sdk_mqtt_online_proc>: a_handle_sub=[0x1d10f38]
[2024/8/7 9:01:26 016] [1970-01-01 00:00:43] xm_main.c(1104) <XM_RegisterTYCallFunc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:01:26 031] [1970-01-01 00:00:43] xm_main.c(1105) <XM_RegisterTYCallFunc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:01:26 031] [1970-01-01 00:00:43] xm_main.c(1106) <XM_RegisterTYCallFunc>: a_handle_sub=[0x1d10f38]
[2024/8/7 9:01:26 049] [1970-01-01 00:00:43] xm_main.c(1107) <XM_RegisterTYCallFunc>: v_handle=[0x1d0ed10]
[2024/8/7 9:01:26 049] [1970-01-01 00:00:43] xm_main.c(1108) <XM_RegisterTYCallFunc>: v_handle_sub=[0x1d12010]
[2024/8/7 9:01:26 064] [1970-01-01 00:00:43] MainApp.c(620) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:01:26 064] [1970-01-01 00:00:43] MainApp.c(621) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:01:26 080] [08-07 09:01:23 TUYA D][uni_thread.c:125] del list not empty...deleting 0x1d02fdc, next 0x1cef4a0
[2024/8/7 9:01:26 080] [08-07 09:01:23 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:01:26 096] [08-07 09:01:23 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[2024/8/7 9:01:26 096] [08-07 09:01:23 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[2024/8/7 9:01:26 096] [08-07 09:01:23 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[2024/8/7 9:01:26 112] [08-07 09:01:23 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992483 28800
[2024/8/7 9:01:26 112] [08-07 09:01:23 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992483 28800
[2024/8/7 9:01:26 128] --- tracepoint tuya_ipc_system_control_demo.c,XM_CheckDls_Pro(810): server time_zone 28800 time 1722992483 dls 0 loacl time 43
[2024/8/7 9:01:26 144] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:26 144] tuya_hal_bt_send 20
[2024/8/7 9:01:26 144] 01 9d 97 69 af b6 84 1f 6a 6e ea 3d c3 cf 66 d1 73 0e 9a 79 
[2024/8/7 9:01:26 144] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 160] 1 9d 97 69 af b6 84 1f 6a 6e ea 3d c3 cf 66 d1 73 e 9a 79 
[2024/8/7 9:01:26 160] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 176] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 192] [2024-08-07 09:01:23] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 128[08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:26 192] tuya_hal_bt_send 14
[2024/8/7 9:01:26 192] 02 0d 46 56 75 99 bd 3e e5 6e 90 6b d1 31 
[2024/8/7 9:01:26 192] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 208] 2 d 46 56 75 99 bd 3e e5 6e 90 6b d1 31 
[2024/8/7 9:01:26 208] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 224] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 224] [08-07 09:01:23 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:26 240] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:26 240] tuya_hal_bt_send 20
[2024/8/7 9:01:26 240] 00 31 30 05 78 e8 a0 66 ca 49 33 51 2d 6e 81 60 16 c4 63 2c 
[2024/8/7 9:01:26 256] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 256] 0 31 30 5 78 e8 a0 66 ca 49 33 51 2d 6e 81 60 16 c4 63 2c 
[2024/8/7 9:01:26 256] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 272] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 288] [2024-08-07 09:01:23] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 182[08-07 09:01:23 TUYA D][uni_thread.c:268] Thread:ipc_upnp Exec Finish. Set to Del Stat
[2024/8/7 9:01:26 288] [08-07 09:01:23 TUYA D][uni_thread.c:125] del list not empty...deleting 0x1d02fdc, next 0x1cef4a0
[2024/8/7 9:01:26 304] [08-07 09:01:23 TUYA D][uni_thread.c:132] Final Free Thread:ipc_upnp, is_self:1
[2024/8/7 9:01:26 304] [08-07 09:01:23 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:01:26 304] [08-07 09:01:23 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:01:26 320] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:26 320] tuya_hal_bt_send 20
[2024/8/7 9:01:26 335] 01 c5 76 56 e3 38 50 82 b7 af 2a 02 1c f7 0b 20 e6 92 28 59 
[2024/8/7 9:01:26 336] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 336] 1 c5 76 56 e3 38 50 82 b7 af 2a 2 1c f7 b 20 e6 92 28 59 
[2024/8/7 9:01:26 352] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 352] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 367] [08-07 09:01:23 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.107, Nov 16 2023 10:52:20\"}","t":1722992483}
[2024/8/7 9:01:26 383] [08-07 09:01:23 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c62194832a0f26036b5lh&et=1&t=1722992483&v=1.0&sign=327aab693ac44ba8a6fcc5013e3aff2d
[2024/8/7 9:01:26 399] [08-07 09:01:23 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:26 400] [08-07 09:01:23 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:26 415] [08-07 09:01:23 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:26 415] [08-07 09:01:23 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:26 416] g_AudioTipsList.size() enable: 0[08-07 09:01:23 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:01:26 431] [08-07 09:01:23 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:01:26 432] [08-07 09:01:23 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:01:26 447] [08-07 09:01:23 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:26 447] __dp_data_report_data 4
[2024/8/7 9:01:26 464] 9f 01 01 [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:26 464] tuya_hal_bt_send 14
[2024/8/7 9:01:26 464] 02 13 c7 2b 00 
[2024/8/7 9:01:26 464] [08-07 09:01:23 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:26 479] [08-07 09:01:23 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:01:26 479] bt_ack_uncrypt 4
[2024/8/7 9:01:26 479] 9f 01 01 00 
[2024/8/7 9:01:26 480] [08-07 09:01:23 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:01:26 496] [08-07 09:01:23 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:01:26 496] [08-07 09:01:23 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62618 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:01:26 512] [08-07 09:01:23 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:26 512] 79 eb 4c c0 45 f1 60 77 33 ec 
[2024/8/7 9:01:26 512] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 512] 2 13 c7 2b 79 eb 4c c0 45 f1 60 77 33 ec 
[2024/8/7 9:01:26 528] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 528] [08-07 09:01:23 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:26 544] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 544] [08-07 09:01:23 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:26 560] [08-07 09:01:23 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:26 560] [08-07 09:01:23 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:26 576] [08-07 09:01:23 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:26 576] [08-07 09:01:23 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:26 592] [2024-08-07 09:01:23] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 765[08-07 09:01:23 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:01:26 608] [08-07 09:01:23 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722992483, rept_cnt:2.
[2024/8/7 9:01:26 608] [08-07 09:01:23 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722992483, rept_cnt:0.
[2024/8/7 9:01:26 624] [08-07 09:01:23 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722992483, rept_cnt:0.
[2024/8/7 9:01:26 624] [08-07 09:01:23 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:26 640] [08-07 09:01:23 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:26 656] [08-07 09:01:23 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:26 656] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:26 656] tuya_hal_bt_send 20
[2024/8/7 9:01:26 672] 00 31 30 05 e9 b3 4c b4 fc fe 85 a9 6d 86 0a 83 4b ed 2f 53 
[2024/8/7 9:01:26 672] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 688] 0 31 30 5 e9 b3 4c b4 fc fe 85 a9 6d 86 a 83 4b ed 2f 53 
[2024/8/7 9:01:26 688] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 688] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 705] [08-07 09:01:23 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722992483,"success":true}
[2024/8/7 9:01:26 705] [08-07 09:01:23 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:26 721] [08-07 09:01:23 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:26 736] [2024-08-07 09:01:23] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 916[08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:26 736] tuya_hal_bt_send 20
[2024/8/7 9:01:26 736] 01 4a b8 ce a2 2b 13 f9 91 46 ac c3 30 89 d1 f9 c9 a3 35 c5 
[2024/8/7 9:01:26 752] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 752] 1 4a b8 ce a2 2b 13 f9 91 46 ac c3 30 89 d1 f9 c9 a3 35 c5 
[2024/8/7 9:01:26 752] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 753]  ---
[2024/8/7 9:01:26 768] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 768] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:26 785] tuya_hal_bt_send 14
[2024/8/7 9:01:26 786] 02 1c 98 37 ba 94 6b e8 96 0e bc bb 88 79 
[2024/8/7 9:01:26 786] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 787] 2 1c 98 37 ba 94 6b e8 96 e bc bb 88 79 
[2024/8/7 9:01:26 800] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 801]  ---
[2024/8/7 9:01:26 801] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 816] [08-07 09:01:23 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:26 816] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:26 816] tuya_hal_bt_send 20
[2024/8/7 9:01:26 832] 00 31 30 05 99 e3 51 96 e2 56 40 d0 dc ca d3 29 b8 83 7c da 
[2024/8/7 9:01:26 832] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 832] 0 31 30 5 99 e3 51 96 e2 56 40 d0 dc ca d3 29 b8 83 7c da 
[2024/8/7 9:01:26 848] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 848] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 864] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:26 864] tuya_hal_bt_send 20
[2024/8/7 9:01:26 864] 01 94 e1 5a e6 b9 f2 69 2c 86 3a 89 e5 25 f8 c5 9c b1 6f b3 
[2024/8/7 9:01:26 880] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 880] 1 94 e1 5a e6 b9 f2 69 2c 86 3a 89 e5 25 f8 c5 9c b1 6f b3 
[2024/8/7 9:01:26 896] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 897]  ---
[2024/8/7 9:01:26 897] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 912] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:26 912] tuya_hal_bt_send 14
[2024/8/7 9:01:26 912] 02 c6 70 32 e6 92 6b 33 c1 91 d1 6c 4f 46 
[2024/8/7 9:01:26 912] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:26 912] 2 c6 70 32 e6 92 6b 33 c1 91 d1 6c 4f 46 
[2024/8/7 9:01:26 928] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:26 928] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:26 944] [08-07 09:01:23 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:35 ip:0xc0a81ff2
[2024/8/7 9:01:26 944] [08-07 09:01:23 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 3
[2024/8/7 9:01:26 960] [08-07 09:01:23 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:01:26 961] [08-07 09:01:23 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:01:26 961] [08-07 09:01:23 TUYA D][app_agent.c:600] send length:64, id:35, sequence_out:53210
[2024/8/7 9:01:26 976] [08-07 09:01:23 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:26 976] [08-07 09:01:23 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:26 992] tuya_hal_bt_send 20
[2024/8/7 9:01:26 992] 00 31 30 05 24 a0 80 07 f6 40 57 d4 0b 2c 7d 43 af f9 1e 24 
[2024/8/7 9:01:26 992] [08-07 09:01:23 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 008] 0 31 30 5 24 a0 80 7 f6 40 57 d4 b 2c 7d 43 af f9 1e 24 
[2024/8/7 9:01:27 008] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 008] [08-07 09:01:23 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 024] [2024-08-07 09:01:23] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 13914[08-07 09:01:23 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 5
[2024/8/7 9:01:27 040] [08-07 09:01:23 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:01:27 040] [08-07 09:01:23 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:01:27 040] [08-07 09:01:23 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 16
[2024/8/7 9:01:27 056] [08-07 09:01:23 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:01:27 056] [08-07 09:01:23 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:01:27 072] [08-07 09:01:24 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:0,dpnum:41.
[2024/8/7 9:01:27 088] [08-07 09:01:24 TUYA D][smart_frame.c:2547] final pack:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"117":0,"120":false,"124":"auto","133":"3","134":true,"138":false,"139":false,"140":"1","150":true,"151":"1","159":false,"160":50,"161":false,"170":false,"174":false,"175":"0","176":"0","231":false}}
[2024/8/7 9:01:27 119] [08-07 09:01:24 TUYA D][app_agent.c:1240] Send Query To App:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"117":0,"120":false,"124":"auto","133":"3","134":true,"138":false,"139":false,"140":"1","150":true,"151":"1","159":false,"160":50,"161":false,"170":false,"174":false,"175":"0","176":"0","231":false}}
[2024/8/7 9:01:27 135] [08-07 09:01:24 TUYA D][app_agent.c:600] send length:288, id:35, sequence_out:53211
[2024/8/7 9:01:27 136] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:27 136] tuya_hal_bt_send 20
[2024/8/7 9:01:27 151] 01 d1 2c 43 22 89 b4 fc 59 f3 d9 a2 49 da 3f 9f ff de 06 6c 
[2024/8/7 9:01:27 151] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 151] 1 d1 2c 43 22 89 b4 fc 59 f3 d9 a2 49 da 3f 9f ff de 6 6c 
[2024/8/7 9:01:27 167] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 167] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 183] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:27 183] tuya_hal_bt_send 14
[2024/8/7 9:01:27 183] 02 4f d1 ae 27 86 e4 13 aa 37 93 5b 85 1a 
[2024/8/7 9:01:27 199] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 199] 2 4f d1 ae 27 86 e4 13 aa 37 93 5b 85 1a 
[2024/8/7 9:01:27 199] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 215] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 215] [08-07 09:01:24 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:27 231] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:27 231] tuya_hal_bt_send 20
[2024/8/7 9:01:27 231] 00 31 30 05 b0 96 0f a7 d7 67 fb e2 13 79 27 c2 f3 c4 66 43 
[2024/8/7 9:01:27 247] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 247] 0 31 30 5 b0 96 f a7 d7 67 fb e2 13 79 27 c2 f3 c4 66 43 
[2024/8/7 9:01:27 247] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 264] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 264] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:27 280] tuya_hal_bt_send 20
[2024/8/7 9:01:27 280] 01 d3 a1 41 40 f6 09 6f d4 59 4a f4 d7 e9 b2 01 fa 78 aa bf 
[2024/8/7 9:01:27 280] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 296] 1 d3 a1 41 40 f6 9 6f d4 59 4a f4 d7 e9 b2 1 fa 78 aa bf 
[2024/8/7 9:01:27 296] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 296] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 312] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:27 312] tuya_hal_bt_send 14
[2024/8/7 9:01:27 312] 02 a0 9e 49 2b 2c 58 87 ce a2 c0 0f 8b 13 
[2024/8/7 9:01:27 328] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 328] 2 a0 9e 49 2b 2c 58 87 ce a2 c0 f 8b 13 
[2024/8/7 9:01:27 328] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 344]  ---
[2024/8/7 9:01:27 345] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 345] [2024-08-07 09:01:23] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:01:27 360] [2024-08-07 09:01:23] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:01:27 360] [08-07 09:01:24 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:27 376] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:27 376] tuya_hal_bt_send 20
[2024/8/7 9:01:27 376] 00 31 30 05 e4 e0 c2 bc c7 3f 1f da 38 46 1d 2c 8b 83 6f 0e 
[2024/8/7 9:01:27 392] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 392] 0 31 30 5 e4 e0 c2 bc c7 3f 1f da 38 46 1d 2c 8b 83 6f e 
[2024/8/7 9:01:27 408] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 408] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 424] [2024-08-07 09:01:23] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:27 424] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:27 424] tuya_hal_bt_send 20
[2024/8/7 9:01:27 440] 01 25 2f 42 51 1f 60 ef 43 cf f6 22 a8 5f 08 17 e6 a9 53 e7 
[2024/8/7 9:01:27 440] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 440] 1 25 2f 42 51 1f 60 ef 43 cf f6 22 a8 5f 8 17 e6 a9 53 e7 
[2024/8/7 9:01:27 456] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 456] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 472] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:27 472] tuya_hal_bt_send 14
[2024/8/7 9:01:27 472] 02 7a be 45 fc 1d 5e 4c 5b f6 1a 8d b6 85 
[2024/8/7 9:01:27 472] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 488] 2 7a be 45 fc 1d 5e 4c 5b f6 1a 8d b6 85 
[2024/8/7 9:01:27 488] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 504] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 504] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:01:27 504] Mode(Product):0
[2024/8/7 9:01:27 504] BpuMode:[Online]
[2024/8/7 9:01:27 504] VpssMode:[Online]
[2024/8/7 9:01:27 504] [0.LimitUp_info]:
[2024/8/7 9:01:27 504] LimitUp:[Disable]
[2024/8/7 9:01:27 520] [2680*0]->[3840*0])
[2024/8/7 9:01:27 520] chn	TotalSize	ActiveSize
[2024/8/7 9:01:27 520] 0	5040*2246	2680*2160
[2024/8/7 9:01:27 520] 0	5040*2246	3840*2160
[2024/8/7 9:01:27 520] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:01:27 520] [1.VICU_info]:
[2024/8/7 9:01:27 536] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:01:27 536] 0	25.0	900	0	0	183	linear	8ddb00
[2024/8/7 9:01:27 536] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:01:27 536] en	op_type	m_chn	now
[2024/8/7 9:01:27 536] 0	1	1	1
[2024/8/7 9:01:27 536] [2.VI_info]:
[2024/8/7 9:01:27 536] chn	TotalSize	ActiveSize
[2024/8/7 9:01:27 536] 0	5040*2246	3848*2166
[2024/8/7 9:01:27 552] 1	   0*   0	   0*   0
[2024/8/7 9:01:27 552] [3.MIPI_info]:
[2024/8/7 9:01:27 552] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:01:27 552] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:01:27 568] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:01:27 568] [4.Cut_info]:
[2024/8/7 9:01:27 568] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:01:27 568] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:01:27 568] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:01:27 584] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:01:27 584] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:01:27 584] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:01:27 584] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:01:27 584] [5.IB(isp buffer info)]:
[2024/8/7 9:01:27 600] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:01:27 600] PoolId  Count  Size
[2024/8/7 9:01:27 600] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:27 616] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:27 616] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:27 632] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:27 632] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:27 647] [08-07 09:01:24 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:27 648] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:27 648] tuya_hal_bt_send 20
[2024/8/7 9:01:27 664] 00 31 30 05 59 59 21 21 18 40 7c 51 07 19 fc 92 9d 6d 20 5f 
[2024/8/7 9:01:27 664] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 664] 0 31 30 5 59 59 21 21 18 40 7c 51 7 19 fc 92 9d 6d 20 5f 
[2024/8/7 9:01:27 679] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 680]  ---
[2024/8/7 9:01:27 680] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 696] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:27 696] tuya_hal_bt_send 20
[2024/8/7 9:01:27 696] 01 5c 8c 9c c4 12 64 60 df e1 26 d0 e1 b2 47 fa 9f f5 0b d3 
[2024/8/7 9:01:27 711] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 711] 1 5c 8c 9c c4 12 64 60 df e1 26 d0 e1 b2 47 fa 9f f5 b d3 
[2024/8/7 9:01:27 712] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 727] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 727] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:27 744] tuya_hal_bt_send 14
[2024/8/7 9:01:27 744] 02 4f 71 6e e1 5b ff 8b ac 12 e9 c6 2d 4e 
[2024/8/7 9:01:27 744] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 744] 2 4f 71 6e e1 5b ff 8b ac 12 e9 c6 2d 4e 
[2024/8/7 9:01:27 760] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 760] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 775] [08-07 09:01:24 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:27 775] [08-07 09:01:24 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:01:27 776] [08-07 09:01:24 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:01:27 791] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:27 792] tuya_hal_bt_send 20
[2024/8/7 9:01:27 807] 00 31 30 05 23 3c 50 1b 72 ca f7 83 fd 1f 7f 7d 17 16 62 70 
[2024/8/7 9:01:27 808] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 808] 0 31 30 5 23 3c 50 1b 72 ca f7 83 fd 1f 7f 7d 17 16 62 70 
[2024/8/7 9:01:27 825] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 825] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 839] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:27 839] tuya_hal_bt_send 20
[2024/8/7 9:01:27 839] 01 56 11 a1 af b1 84 e5 16 98 53 23 59 b5 4d 42 d3 8d 93 c6 
[2024/8/7 9:01:27 840] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 855] 1 56 11 a1 af b1 84 e5 16 98 53 23 59 b5 4d 42 d3 8d 93 c6 
[2024/8/7 9:01:27 856] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 871] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 872] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:27 872] tuya_hal_bt_send 14
[2024/8/7 9:01:27 887] 02 c2 b5 41 72 e3 d6 35 8c 86 bf 53 7d db 
[2024/8/7 9:01:27 887] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 888] 2 c2 b5 41 72 e3 d6 35 8c 86 bf 53 7d db 
[2024/8/7 9:01:27 903] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 904]  ---
[2024/8/7 9:01:27 904] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 919] [08-07 09:01:24 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:27 920] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:27 920] tuya_hal_bt_send 20
[2024/8/7 9:01:27 936] 00 31 30 05 b8 73 02 ab 3f 7a 2f bc 99 2f 3a 30 c4 9c a1 b4 
[2024/8/7 9:01:27 936] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 936] 0 31 30 5 b8 73 2 ab 3f 7a 2f bc 99 2f 3a 30 c4 9c a1 b4 
[2024/8/7 9:01:27 952] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 952] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 968] [08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:27 968] tuya_hal_bt_send 20
[2024/8/7 9:01:27 968] 01 ea 96 b8 37 ff 1e 6c f8 23 bb a6 1f bf d2 82 67 a0 f4 75 
[2024/8/7 9:01:27 983] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:27 983] 1 ea 96 b8 37 ff 1e 6c f8 23 bb a6 1f bf d2 82 67 a0 f4 75 
[2024/8/7 9:01:27 983] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:27 999] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:27 999] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:01:28 015] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:01:28 015] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:01:28 015] 0       0         0          0          4       
[2024/8/7 9:01:28 032] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:01:28 033]      --265--            --264--                                               
[2024/8/7 9:01:28 033] Count      Line     Count      Line     
[2024/8/7 9:01:28 033] 691        437      1573       560      
[2024/8/7 9:01:28 048] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:01:28 048] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:01:28 064] 0   3840   2160    H265  0      0        0           413       979968     3072     	
[2024/8/7 9:01:28 064] 1   640    360     H265  0      0        0           275       43195      5        	
[2024/8/7 9:01:28 080] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:01:28 080] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:01:28 096] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:01:28 112] 0   Y      413      0       0       14       1        412      412      587       64811         59008    122088   64878    12      
[2024/8/7 9:01:28 112] 1   Y      275      0       2       1        0        275      275      588       2486          1888     27580    2854     9       
[2024/8/7 9:01:28 128] 3   N      0        0       0       1        0        0        0        589       0             0        0        0        0       
[2024/8/7 9:01:28 144] [2024-08-07 09:01:24] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:28 160] [2024-08-07 09:01:24] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 14035[08-07 09:01:24 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:28 160] tuya_hal_bt_send 14
[2024/8/7 9:01:28 160] 02 1f 6d f1 ee a1 52 ce e1 d4 82 4d 84 17 
[2024/8/7 9:01:28 160] [08-07 09:01:24 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 176] 2 1f 6d f1 ee a1 52 ce e1 d4 82 4d 84 17 
[2024/8/7 9:01:28 176] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 192] [08-07 09:01:24 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 192] [08-07 09:01:25 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:28 209] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:28 209] tuya_hal_bt_send 20
[2024/8/7 9:01:28 209] 00 31 30 05 45 1b 6d 84 15 1d 41 ae cb 7b df 90 97 01 46 37 
[2024/8/7 9:01:28 209] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 225] 0 31 30 5 45 1b 6d 84 15 1d 41 ae cb 7b df 90 97 1 46 37 
[2024/8/7 9:01:28 225] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 240] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 240] [2024-08-07 09:01:24] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time44726
[2024/8/7 9:01:28 256] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:28 256] tuya_hal_bt_send 20
[2024/8/7 9:01:28 256] 01 df 3d 43 73 8c 4c 38 45 0f 60 eb 99 0d 3f 0f 1b 5d 56 84 
[2024/8/7 9:01:28 273] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 273] 1 df 3d 43 73 8c 4c 38 45 f 60 eb 99 d 3f f 1b 5d 56 84 
[2024/8/7 9:01:28 273] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 289] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 289] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:28 289] tuya_hal_bt_send 14
[2024/8/7 9:01:28 305] 02 4c e1 96 d2 dd 7a 4b 9c 10 82 fd 62 6e 
[2024/8/7 9:01:28 305] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 305] 2 4c e1 96 d2 dd 7a 4b 9c 10 82 fd 62 6e 
[2024/8/7 9:01:28 321] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 321] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 336] [08-07 09:01:25 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:28 336] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:28 336] tuya_hal_bt_send 20
[2024/8/7 9:01:28 352] 00 31 30 05 6e 8c a5 83 29 66 b2 f4 e1 12 05 f8 92 4b 30 46 
[2024/8/7 9:01:28 352] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 352] 0 31 30 5 6e 8c a5 83 29 66 b2 f4 e1 12 5 f8 92 4b 30 46 
[2024/8/7 9:01:28 368] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 368] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 384] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:28 384] tuya_hal_bt_send 20
[2024/8/7 9:01:28 384] 01 8d 7a af 4f f7 8c 50 5c 25 92 6b 35 94 29 2c af 09 32 9a 
[2024/8/7 9:01:28 400] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 400] 1 8d 7a af 4f f7 8c 50 5c 25 92 6b 35 94 29 2c af 9 32 9a 
[2024/8/7 9:01:28 400] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 415]  ---
[2024/8/7 9:01:28 415] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 433] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:28 435] tuya_hal_bt_send 14
[2024/8/7 9:01:28 435] 02 4b 71 a1 30 5f 76 34 b6 9c ea 3b 43 57 
[2024/8/7 9:01:28 435] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 435] 2 4b 71 a1 30 5f 76 34 b6 9c ea 3b 43 57 
[2024/8/7 9:01:28 450] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 450] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 464] [08-07 09:01:25 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:28 464] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:28 479] tuya_hal_bt_send 20
[2024/8/7 9:01:28 479] 00 31 30 05 ed 45 ef 96 ab 22 8b 0d 34 91 06 c6 5c b5 8c ab 
[2024/8/7 9:01:28 479] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 497] 0 31 30 5 ed 45 ef 96 ab 22 8b d 34 91 6 c6 5c b5 8c ab 
[2024/8/7 9:01:28 497] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 497] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 512] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:28 512] tuya_hal_bt_send 20
[2024/8/7 9:01:28 512] 01 b6 75 ed 75 1a 83 40 c0 b3 ec 7e 02 d9 c6 21 2e dc 6a 3c 
[2024/8/7 9:01:28 528] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 528] 1 b6 75 ed 75 1a 83 40 c0 b3 ec 7e 2 d9 c6 21 2e dc 6a 3c 
[2024/8/7 9:01:28 544] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 544] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 560] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:28 560] tuya_hal_bt_send 14
[2024/8/7 9:01:28 560] 02 71 0e 06 5d 38 d3 00 be 18 34 a5 07 83 
[2024/8/7 9:01:28 560] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 576] 2 71 e 6 5d 38 d3 0 be 18 34 a5 7 83 
[2024/8/7 9:01:28 576] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 576] [08-07 09:01:25 TUYA D][bt_ext_port[atbm_log]:tso xmit(2934)
[2024/8/7 9:01:28 592] ing.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 592] [08-07 09:01:25 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:28 608] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:28 608] tuya_hal_bt_send 20
[2024/8/7 9:01:28 608] 00 31 30 05 65 8c 23 90 ae 2e 9d 63 3f 23 a9 9c d8 37 c7 d7 
[2024/8/7 9:01:28 624] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 624] 0 31 30 5 65 8c 23 90 ae 2e 9d 63 3f 23 a9 9c d8 37 c7 d7 
[2024/8/7 9:01:28 624] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 640] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 640] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:28 640] tuya_hal_bt_send 20
[2024/8/7 9:01:28 656] 01 74 49 81 3d fd d5 8f 26 52 d3 58 47 ff eb e9 2b 09 20 68 
[2024/8/7 9:01:28 656] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 672] 1 74 49 81 3d fd d5 8f 26 52 d3 58 47 ff eb e9 2b 9 20 68 
[2024/8/7 9:01:28 672] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 672] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 688] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:28 688] tuya_hal_bt_send 14
[2024/8/7 9:01:28 688] 02 8b 05 b3 5f 48 20 ab 56 ed b6 02 50 54 
[2024/8/7 9:01:28 704] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 704] 2 8b 5 b3 5f 48 20 ab 56 ed b6 2 50 54 
[2024/8/7 9:01:28 704] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 720] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 720] [08-07 09:01:25 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:28 735] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:28 735] tuya_hal_bt_send 20
[2024/8/7 9:01:28 735] 00 31 30 05 6b e9 76 9a 98 93 7d d7 b6 27 f3 0f dd bb e7 dc 
[2024/8/7 9:01:28 751] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 751] 0 31 30 5 6b e9 76 9a 98 93 7d d7 b6 27 f3 f dd bb e7 dc 
[2024/8/7 9:01:28 752] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 767]  ---
[2024/8/7 9:01:28 767] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 783] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:28 785] tuya_hal_bt_send 20
[2024/8/7 9:01:28 785] 01 5a 69 ff 44 7f 7d 4a 5e 19 91 d4 c0 8f 53 82 03 e8 44 ba 
[2024/8/7 9:01:28 785] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 799] 1 5a 69 ff 44 7f 7d 4a 5e 19 91 d4 c0 8f 53 82 3 e8 44 ba 
[2024/8/7 9:01:28 799] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 815] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 816] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:28 816] tuya_hal_bt_send 14
[2024/8/7 9:01:28 816] 02 da 2a dc c7 c2 ea e0 b8 84 99 af 42 7e 
[2024/8/7 9:01:28 832] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 832] 2 da 2a dc c7 c2 ea e0 b8 84 99 af 42 7e 
[2024/8/7 9:01:28 847] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 849]  ---
[2024/8/7 9:01:28 849] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 849] [08-07 09:01:25 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:28 863] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:28 864] tuya_hal_bt_send 20
[2024/8/7 9:01:28 879] 00 31 30 05 3d d8 b6 d5 6c 34 2e a3 da 22 b2 b9 5e 1a 16 75 
[2024/8/7 9:01:28 881] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 881] 0 31 30 5 3d d8 b6 d5 6c 34 2e a3 da 22 b2 b9 5e 1a 16 75 
[2024/8/7 9:01:28 895] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 895] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 912] [08-07 09:01:25 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:28 912] tuya_hal_bt_send 20
[2024/8/7 9:01:28 912] 01 ad 99 5b 66 b1 05 1a 0b 8c 25 24 40 4f 1b db 65 a0 0d c9 
[2024/8/7 9:01:28 912] [08-07 09:01:25 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 927] 1 ad 99 5b 66 b1 5 1a b 8c 25 24 40 4f 1b db 65 a0 d c9 
[2024/8/7 9:01:28 927] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 943] [08-07 09:01:25 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 943] [08-07 09:01:26 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:28 943] tuya_hal_bt_send 14
[2024/8/7 9:01:28 960] 02 d7 bb 66 8a 61 44 86 cb 28 0b ec b5 e5 
[2024/8/7 9:01:28 960] [08-07 09:01:26 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:28 960] 2 d7 bb 66 8a 61 44 86 cb 28 b ec b5 e5 
[2024/8/7 9:01:28 976] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:28 976] [08-07 09:01:26 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:28 992] [2024-08-07 09:01:25] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 14262[08-07 09:01:26 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:28 992] [08-07 09:01:26 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:01:29 008] [08-07 09:01:26 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:01:29 008] [08-07 09:01:26 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:01:29 024] [08-07 09:01:26 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:01:29 024] tuya_hal_bt_send 20
[2024/8/7 9:01:29 024] 00 31 30 05 23 bc ec 68 ee 3e 80 3e cb a5 37 d2 46 72 69 4b 
[2024/8/7 9:01:29 040] [08-07 09:01:26 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:29 040] 0 31 30 5 23 bc ec 68 ee 3e 80 3e cb a5 37 d2 46 72 69 4b 
[2024/8/7 9:01:29 056] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:29 056] [08-07 09:01:26 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:29 072] [08-07 09:01:26 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:01:29 072] tuya_hal_bt_send 20
[2024/8/7 9:01:29 072] 01 62 ac d9 99 e4 3e 2b 96 f8 c3 a7 b6 a0 9f 9c e4 74 b8 98 
[2024/8/7 9:01:29 072] [08-07 09:01:26 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:29 088] 1 62 ac d9 99 e4 3e 2b 96 f8 c3 a7 b6 a0 9f 9c e4 74 b8 98 
[2024/8/7 9:01:29 088] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:29 103] [08-07 09:01:26 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:29 104] [08-07 09:01:26 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:01:29 104] tuya_hal_bt_send 14
[2024/8/7 9:01:29 119] 02 56 4e f3 79 be 8c 12 9f 9a f7 6a b8 00 
[2024/8/7 9:01:29 120] [08-07 09:01:26 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:01:29 120] 2 56 4e f3 79 be 8c 12 9f 9a f7 6a b8 0 
[2024/8/7 9:01:29 135] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:01:29 136]  ---
[2024/8/7 9:01:29 136] [08-07 09:01:26 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:01:29 152] [08-07 09:01:26 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:01:29 152] [08-07 09:01:26 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c62194832a0f26036b5lh, dp_rept_chan:3
[2024/8/7 9:01:29 167] [08-07 09:01:26 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:01:29 167] [08-07 09:01:26 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:139.
[2024/8/7 9:01:29 183] [08-07 09:01:26 TUYA D][smart_frame.c:2547] final pack:{"139":false}
[2024/8/7 9:01:29 183] [08-07 09:01:26 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 9:01:29 199] [08-07 09:01:26 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62619 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 9:01:29 200] [08-07 09:01:26 TUYA D][smart_frame.c:2135] sync rslt:0
[2024/8/7 9:01:29 200] [08-07 09:01:26 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:01:29 215] [08-07 09:01:26 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"139":false}}, mqtt async dp cb:0
[2024/8/7 9:01:29 215] [08-07 09:01:26 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:139, curr_t:1722992486, rept_cnt:1.
[2024/8/7 9:01:29 231] [08-07 09:01:26 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:139, curr_t:1722992486, rept_cnt:0.
[2024/8/7 9:01:29 231] [08-07 09:01:26 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:139, curr_t:1722992486, rept_cnt:0.
[2024/8/7 9:01:29 247] [08-07 09:01:26 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:01:29 247] [08-07 09:01:26 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 9:01:29 263] [08-07 09:01:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:29 263] [08-07 09:01:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:29 263] [08-07 09:01:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:29 279] [08-07 09:01:26 TUYA D][tuya_svc_schema_upgrade.c:223] schema[flvlrc] not updated since activated
[2024/8/7 9:01:29 295] [2024-08-07 09:01:26] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 14333[2024-08-07 09:01:27] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:29 296] [08-07 09:01:27 TUYA D][iot_httpc.c:1161] Post Data: {"data":"255","t":1722992487}
[2024/8/7 9:01:29 312] [08-07 09:01:27 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6c62194832a0f26036b5lh&et=1&t=1722992487&sign=7d3a25ba0bad4ad0519dcf6e5e7ab55d
[2024/8/7 9:01:29 327] [08-07 09:01:27 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:29 327] [08-07 09:01:27 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:29 343] [08-07 09:01:27 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:29 343] [08-07 09:01:27 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:29 359] [08-07 09:01:27 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:29 359] [08-07 09:01:27 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:29 375] [08-07 09:01:27 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:29 375] [08-07 09:01:27 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:29 391] [08-07 09:01:27 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:29 391] [08-07 09:01:27 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:29 391] [08-07 09:01:27 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:29 407] [08-07 09:01:27 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:29 424] [08-07 09:01:27 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:29 424] [08-07 09:01:28 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722992488,"success":true}
[2024/8/7 9:01:29 440] [08-07 09:01:28 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:29 440] [08-07 09:01:28 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:29 440] [08-07 09:01:28 TUYA D][tuya_devos_entry.c:406] put rst log finish
[2024/8/7 9:01:29 456] [08-07 09:01:28 TUYA D][iot_httpc.c:1161] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1722992488}
[2024/8/7 9:01:29 472] [08-07 09:01:28 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992488&v=2.0&sign=b62b1f209a679b0c852d50bcb6ad703e
[2024/8/7 9:01:29 488] [08-07 09:01:28 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:29 488] [08-07 09:01:28 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:29 504] [08-07 09:01:28 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:29 504] [08-07 09:01:28 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:29 504] [08-07 09:01:28 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:29 520] [08-07 09:01:28 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:29 536] [08-07 09:01:28 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:29 536] [08-07 09:01:28 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:29 536] [08-07 09:01:28 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:29 552] [08-07 09:01:28 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:29 552] [08-07 09:01:28 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:29 568] [08-07 09:01:28 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:29 583] [08-07 09:01:28 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:29 599] [08-07 09:01:28 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722992488,"validTime":1800}},"t":1722992488,"success":true}
[2024/8/7 9:01:29 600] [08-07 09:01:28 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:29 600] [08-07 09:01:28 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:29 616] [08-07 09:01:28 TUYA D][iot_httpc.c:3388] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1722992488}, ret:0.
[2024/8/7 9:01:29 631] [08-07 09:01:28 TUYA D][tuya_devos_entry.c:479] timezone:+08:00
[2024/8/7 9:01:29 631] [08-07 09:01:28 TUYA D][tuya_devos_entry.c:500] summer_time_zone:[]
[2024/8/7 9:01:29 631] [08-07 09:01:28 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:01:29 647] [08-07 09:01:28 TUYA D][simplekv.c:1251] find key:12 gw_ai
[2024/8/7 9:01:29 647] [08-07 09:01:28 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544
[2024/8/7 9:01:29 647] [08-07 09:01:28 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:01:29 664] [08-07 09:01:28 TUYA D][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722992488,"validTime":1800}}.
[2024/8/7 9:01:29 680] [08-07 09:01:28 TUYA D][tuya_devos_utils.c:94] reset dp rate rule finish.
[2024/8/7 9:01:29 680] [08-07 09:01:28 TUYA D][iot_httpc.c:1161] Post Data: {"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722992488}
[2024/8/7 9:01:29 712] [08-07 09:01:28 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.ack&devId=6c62194832a0f26036b5lh&et=1&t=1722992488&v=2.0&sign=b44c35ed0bda73475a445ae7c2916eda
[2024/8/7 9:01:29 712] [08-07 09:01:28 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:29 712] [08-07 09:01:28 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:29 728] [08-07 09:01:28 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:29 728] [08-07 09:01:28 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:29 743] [08-07 09:01:28 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:29 744] [08-07 09:01:28 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:29 759] [08-07 09:01:28 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:29 760] [08-07 09:01:28 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:29 775] [08-07 09:01:28 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:29 775] [08-07 09:01:28 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:29 792] [08-07 09:01:28 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:29 792] [08-07 09:01:28 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:29 807] [08-07 09:01:28 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:29 807] [08-07 09:01:28 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992488,"success":true}
[2024/8/7 9:01:29 823] [08-07 09:01:28 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:29 823] [08-07 09:01:28 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:29 839] [08-07 09:01:28 TUYA D][iot_httpc.c:2411] dynamic cfg post data:{"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722992488}, ret:0.
[2024/8/7 9:01:29 855] [2024-08-07 09:01:28] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 14398[2024-08-07 09:01:28] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time48705
[2024/8/7 9:01:29 855] tuya_ipc_ss_start_event:2288 :start new event
[2024/8/7 9:01:29 871] [08-07 09:01:29 TUYA E][tuya_ipc_stream_storage.c:2294] the ss mgr not inited, but msg buffed
[2024/8/7 9:01:29 871] thread_ai_detect_proc line(194) ----------tuya_ipc_ss_start_event-----------RecordMode :0 alarm_flag   1
[2024/8/7 9:01:29 887] [2024-08-07 09:01:29] tuya_ipc_ai_detect.demo.c(196) <thread_ai_detect_proc>: 
[2024/8/7 9:01:29 887] [2024-08-07 09:01:29] xm_main.c(1810) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:29 903] [2024-08-07 09:01:29] xm_main.c(1813) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:29 903] [2024-08-07 09:01:29] xm_main.c(1833) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:29 903] snap_size:24843
[2024/8/7 9:01:29 919] [2024-08-07 09:01:29] tuya_ipc_ai_detect.demo.c(200) <thread_ai_detect_proc>: 
[2024/8/7 9:01:29 919] [08-07 09:01:29 TUYA D][tuya_ipc_cloud_storage.c:1249] new event index 0, id: 1, added: type 0,notify type 2[1722992489-1722992789]
[2024/8/7 9:01:29 935] [08-07 09:01:29 TUYA D][tuya_ipc_cloud_storage.c:2380] add event start done, event_id 1 time 1722992489-1722992789
[2024/8/7 9:01:29 935] [08-07 09:01:29 TUYA D][tuya_ipc_notify.c:85] size:24843 type: 1
[2024/8/7 9:01:29 951] [08-07 09:01:29 TUYA D][upload_notification.c:526] not[atbm_log]:atbm_ioctl_ble_stop
[2024/8/7 9:01:29 951] ification from b[atbm_log]:ioctl_release(c248a300)(c1ed0980)
[2024/8/7 9:01:29 951] uffer. type:image/jpeg name:1722992489.jpeg path:2 data_len:24912
[2024/8/7 9:01:29 967] [08-07 09:01:29 TUYA D][upload_notification.c:473] cloud config 0 Not Inited
[2024/8/7 9:01:29 967] [08-07 09:01:29 TUYA D][iot_httpc.c:1161] Post Data: {"type":"Motion","t":1722992489}
[2024/8/7 9:01:29 999] [08-07 09:01:29 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992489&v=3.0&sign=83b64650bd70c334d1acb0e283a1789c
[2024/8/7 9:01:29 999] [08-07 09:01:29 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:29 999] [08-07 09:01:29 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:30 015] [08-07 09:01:29 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:30 015] [08-07 09:01:29 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:30 031] [08-07 09:01:29 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:01:30 031] [08-07 09:01:29 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:01:30 031] [08-07 09:01:29 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:30 048] [08-07 09:01:29 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:30 063] [08-07 09:01:29 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:30 063] [08-07 09:01:29 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:30 063] [08-07 09:01:29 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:30 080] [08-07 09:01:29 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:30 080] [08-07 09:01:29 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:30 096] [08-07 09:01:29 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:30 111] [08-07 09:01:29 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:30 191] [08-07 09:01:29 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"ak":"AKIDLuqPBsC0EqAtkSuSR9mKtga20VX2lgv9m3DyTH08d45cy-ATDEt1JaemmHk6nRPg","bucket":"ty-cn-storage30-pic-1254153901","countLeftToday":30,"endpoint":"tuyacn.com","eventSilenceInterval":120,"expiration":"2024-08-07T03:01:30Z","lifeCycle":2592000,"msgType":1,"pathConfig":{"detect":"/6e95b4-167507504-uuidcaab27b0a838d239/detect","log":"/6e95b4-167507504-uuidcaab27b0a838d239/log"},"provider":"oss","region":"cos.ap-shanghai","sk":"DQVeOwU36bn+UsSOo9QPiSwfkYPgsp/w2np+azq01ww=","token":"RhX4bNdzqs5VkS5OwCIn8787VFkm5BPa89756856eedbd7d60e74b1135a984448hnA_pwn4WoDkbLLyx_rh9Z-4Azccy6NnSdeKIOwkVKjskjZHlMYL6pxOTZMlZRo_hFCycT6L1WXVsmuqEo6owKcFHQScOYBC1JxqphKawGxYDkz7L8bxYSjuGhPATVq0WIF6RS0YtuFpVS4Kye1eCo04V0eWwV3zId9bb3Gy4QVnXiewXPnAeAmbP_ypdHPG3eAIORuV34Luyw1giyLEPyNi0NAa7SiGOWHEduEJbBIV95hqRc-ECwu6_CzjeECHoHpfEYzYDeBCb1DixR9VOK56nhHunjVBXsa_4ZBFox_khSeZLQ1cE8o1XTDaUxVSzy6K7VFH6JQwxAf5Mt8cEa7dPjx__gHNW86XHlmdn-ikfOq3Fk7WZDE2AfKic7NGPQqcOE5-bS5TftXQ1P5CusSFw
[2024/8/7 9:01:30 207] [08-07 09:01:30 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:30 208] [08-07 09:01:30 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:30 208] [08-07 09:01:30 TUYA E][cloud_operation.c:647] fail to get value for key mediaStor
[2024/8/7 9:01:30 223] [08-07 09:01:30 TUYA D][upload_notification.c:511] cloud config 0 Init Success
[2024/8/7 9:01:30 239] [08-07 09:01:30 TUYA D][cloud_operation.c:1095] Final PUT:https://ty-cn-storage30-pic-1254153901.tuyacn.com/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992489.jpeg,size 24912
[2024/8/7 9:01:30 239] [08-07 09:01:30 TUYA D][httpc.c:813] Connect: ty-cn-storage30-pic-1254153901.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:30 255] [08-07 09:01:30 TUYA D][uni_network.c:314] unw_gethostbyname ty-cn-storage30-pic-1254153901.tuyacn.com, prio 0
[2024/8/7 9:01:30 271] [08-07 09:01:30 TUYA D][uni_network.c:188] use dns service to get ip for domain ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 9:01:30 271] [08-07 09:01:30 TUYA D][iot_httpc.c:1755] dns_query:https://h2.iot-dns.com/v1/dns_query [{"domain":"ty-cn-storage30-pic-1254153901.tuyacn.com"}]
[2024/8/7 9:01:30 287] [08-07 09:01:30 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:30 287] [08-07 09:01:30 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:01:30 303] [08-07 09:01:30 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:01:30 303] [08-07 09:01:30 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:01:30 319] [08-07 09:01:30 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:01:30 319] [08-07 09:01:30 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:30 335] [08-07 09:01:30 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:30 335] [08-07 09:01:30 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:30 351] [08-07 09:01:30 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:30 351] [08-07 09:01:30 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:01:30 367] [08-07 09:01:30 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:30 367] [2024-08-07 09:01:29] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 14455[08-07 09:01:30 TUYA D][tuya_ipc_cloud_storage.c:1200] force event 0 stop done
[2024/8/7 9:01:30 383] while(lib_ble_start) before
[2024/8/7 9:01:30 383] GAP procedure initiated: terminate connection; conn_handle=1 hci_reason=19
[2024/8/7 9:01:30 399] [08-07 09:01:30 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:01:30 399] [08-07 09:01:30 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:30 416] [08-07 09:01:30 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:01:30 416] [08-07 09:01:30 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:30 416] [08-07 09:01:30 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:30 432] [08-07 09:01:30 TUYA D][uni_network.c:100] get ip 121.4.234.169
[2024/8/7 9:01:30 448] [08-07 09:01:30 TUYA D][uni_network.c:197] dns service get ip 121.4.234.169 for domain ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 9:01:30 448] [08-07 09:01:30 TUYA D][uni_network.c:268] cache dns [ty-cn-storage30-pic-1254153901.tuyacn.com]<->[121.4.234.169]
[2024/8/7 9:01:30 464] [08-07 09:01:30 TUYA D][httpc.c:477] ----got ipaddr:121,4,234,169
[2024/8/7 9:01:30 464] [08-07 09:01:30 TUYA D][httpc.c:815] Connect: ty-cn-storage30-pic-1254153901.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:30 480] [08-07 09:01:30 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:30 480] [08-07 09:01:30 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect ty-cn-storage30-pic-1254153901.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:30 496] [08-07 09:01:30 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:30 496] [08-07 09:01:30 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:30 512] [08-07 09:01:30 TUYA D][tuya_iot_com_api.c:275] third cloud url
[2024/8/7 9:01:30 512] [08-07 09:01:30 TUYA D][tuya_iot_com_api.c:147] not found third ca
[2024/8/7 9:01:30 528] [08-07 09:01:30 TUYA D][tuya_iot_com_api.c:159] require CA for url ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 9:01:30 528] [08-07 09:01:30 TUYA D][iot_httpc.c:3536] query URL:ty-cn-storage30-pic-1254153901.tuyacn.com and Parse: ty-cn-storage30-pic-1254153901.tuyacn.com 443
[2024/8/7 9:01:30 544] [08-07 09:01:30 TUYA D][iot_httpc.c:1803] HTTP_DNS_QUERY:https://h2.iot-dns.com/device/dns_query
[2024/8/7 9:01:30 560] [08-07 09:01:30 TUYA D][iot_httpc.c:1804] http_dns send:[{"host":"ty-cn-storage30-pic-1254153901.tuyacn.com","port":443,"need_ca":true,"need_ip":false}]
[2024/8/7 9:01:30 560] [08-07 09:01:30 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:01:30 576] [08-07 09:01:30 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:01:30 576] [08-07 09:01:30 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:01:30 592] [08-07 09:01:30 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:01:30 592] [08-07 09:01:30 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:01:30 592] ble_slave_gap_event->type=14
[2024/8/7 9:01:30 608] subscribe event; conn_handle=1 attr_handle=23 reason=2 prevn=1 curn=0 previ=0 curi=0
[2024/8/7 9:01:30 608] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:01:30 624] [08-07 09:01:30 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:30 624] ble_slave_gap_event->type=1
[2024/8/7 9:01:30 624] disconnect; reason=534 
[2024/8/7 9:01:30 640] [08-07 09:01:30 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:30 640] [08-07 09:01:30 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:30 640] [08-07 09:01:30 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:30 656] [08-07 09:01:30 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:01:30 656] [08-07 09:01:30 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:30 672] [08-07 09:01:30 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:01:30 688] [08-07 09:01:30 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:30 688] [08-07 09:01:30 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:01:30 688] [08-07 09:01:30 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:30 704] [08-07 09:01:30 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:30 704] [08-07 09:01:30 TUYA D][tuya_iot_com_api.c:235] new CA stored for url ty-cn-storage30-pic-1254153901.tuyacn.com
[2024/8/7 9:01:30 720] [08-07 09:01:30 TUYA D][tuya_iot_com_api.c:140] load ca to tls
[2024/8/7 9:01:30 720] [08-07 09:01:30 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:30 736] [2024-08-07 09:01:30] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:30 736] [08-07 09:01:31 TUYA D][tuya_tls.c:1539] handshake finish for ty-cn-storage30-pic-1254153901.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:30 752] [08-07 09:01:31 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect ty-cn-storage30-pic-1254153901.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:30 768] [08-07 09:01:31 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:30 768] [08-07 09:01:31 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:30 784] [08-07 09:01:31 TUYA D][cloud_operation.c:1165] HTTPS PUT https://ty-cn-storage30-pic-1254153901.tuyacn.com/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992489.jpeg done,size 24912 cost 1195 ms
[2024/8/7 9:01:30 800] [08-07 09:01:31 TUYA D][upload_notification.c:554] __notification_content_upload_from_buffer success
[2024/8/7 9:01:30 800] [08-07 09:01:31 TUYA D][upload_notification.c:161] notify DP:115 timeout:5
[2024/8/7 9:01:30 816] [08-07 09:01:31 TUYA D][upload_notification.c:181] final:{"v":"3.0","bucket":"ty-cn-storage30-pic-1254153901","files":[["/6e95b4-167507504-uuidcaab27b0a838d239/detect/1722992489.jpeg","3ffcc87c2f355421"]]}
[2024/8/7 9:01:30 832] [08-07 09:01:31 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:01:30 832] [08-07 09:01:31 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:01:30 864] [08-07 09:01:31 TUYA D][smart_frame.c:786] Send dp:115, RAW:{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDg5LmpwZWciLCIzZmZjYzg3YzJmMzU1NDIxIl1dfQ=="}, retrans:1
[2024/8/7 9:01:30 880] [08-07 09:01:31 TUYA D][smart_frame.c:2219] dp rept_type:1, data:{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDg5LmpwZWciLCIzZmZjYzg3YzJmMzU1NDIxIl1dfQ=="}
[2024/8/7 9:01:30 912] [08-07 09:01:31 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62620 Q:1 Data:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDg5LmpwZWciLCIzZmZjYzg3YzJmMzU1NDIxIl1dfQ=="}}
[2024/8/7 9:01:30 928] [08-07 09:01:31 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDg5LmpwZWciLCIzZmZjYzg3YzJmMzU1NDIxIl1dfQ=="}} pro:4 num:62620
[2024/8/7 9:01:30 959] [08-07 09:01:31 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992491,"data":{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDg5LmpwZWciLCIzZmZjYzg3YzJmMzU1NDIxIl1dfQ=="}}} offset:255
[2024/8/7 9:01:30 992] [08-07 09:01:31 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"115":"eyJ2IjoiMy4wIiwiYnVja2V0IjoidHktY24tc3RvcmFnZTMwLXBpYy0xMjU0MTUzOTAxIiwiZmlsZXMiOltbIi82ZTk1YjQtMTY3NTA3NTA0LXV1aWRjYWFiMjdiMGE4MzhkMjM5L2RldGVjdC8xNzIyOTkyNDg5LmpwZWciLCIzZmZjYzg3YzJmMzU1NDIxIl1dfQ=="}}, msg_len:218, out_len:270
[2024/8/7 9:01:30 992] [08-07 09:01:31 TUYA D][app_agent.c:600] send length:272, id:35, sequence_out:53212
[2024/8/7 9:01:31 007] [08-07 09:01:31 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:115, curr_t:1722992491, rept_cnt:1.
[2024/8/7 9:01:31 008] [08-07 09:01:31 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:115, curr_t:1722992491, rept_cnt:0.
[2024/8/7 9:01:31 023] [08-07 09:01:31 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:115, curr_t:1722992491, rept_cnt:0.
[2024/8/7 9:01:31 023] [08-07 09:01:31 TUYA D][upload_notification.c:190] notification_message_upload success
[2024/8/7 9:01:31 039] curr event:17 
[2024/8/7 9:01:31 039] IPC_APP_Notify_LED_Sound_Status_CB line(609) -------------------------- IPC_ALARM_MOTION(17)
[2024/8/7 9:01:31 039] [2024-08-07 09:01:30] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:01:31 055] [2024-08-07 09:01:30] tuya_ipc_system_control_demo.c(628) <IPC_APP_Notify_LED_Sound_Status_CB>: sirenSwitch=[0],sirenVolumn=[30]
[2024/8/7 9:01:31 071] [2024-08-07 09:01:30] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:01:31 071] [08-07 09:01:31 TUYA D][tuya_upnp_module_mg.c:1432] upnpDiscover failed
[2024/8/7 9:01:31 087] [2024-08-07 09:01:31] tuya_ipc_ai_detect.demo.c(371) <thread_ai_detect_proc>: 
[2024/8/7 9:01:31 087] [2024-08-07 09:01:31] xm_main.c(1810) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:31 087] [2024-08-07 09:01:31] xm_main.c(1813) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:31 103] [2024-08-07 09:01:31] xm_main.c(1833) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:31 103] <====== ble_gap_terminate(ble_conn_handle,19);
[2024/8/7 9:01:31 103] <====== ble_smart_cfg_task end step 0
[2024/8/7 9:01:31 103] exit ble process
[2024/8/7 9:01:31 119] ble_hs_hci_cmd_reset
[2024/8/7 9:01:31 120] cli_free before
[2024/8/7 9:01:31 120] nimble_port_atbmos_free before
[2024/8/7 9:01:31 120] nimble_port_release before
[2024/8/7 9:01:31 120] ble_gap_free before
[2024/8/7 9:01:31 120] ble_hs_hci_free before
[2024/8/7 9:01:31 120] ble_hs_free before
[2024/8/7 9:01:31 120] ble_hs_free after
[2024/8/7 9:01:31 120] nimble_release after
[2024/8/7 9:01:31 135] [2024-08-07 09:01:32] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:01:31 151] [2024-08-07 09:01:32] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:01:31 151] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=17.000 ms
[2024/8/7 9:01:31 167] [2024-08-07 09:01:32] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:01:31 167] [08-07 09:01:33 TUYA D][iot_httpc.c:1161] Post Data: {"subId":null,"t":1722992493}
[2024/8/7 9:01:31 183] [08-07 09:01:33 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upgrade.silent.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992493&v=4.4&sign=bd9f728940ed6f1ef78b3abf291bb2f4
[2024/8/7 9:01:31 200] [08-07 09:01:33 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:31 200] [08-07 09:01:33 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:31 216] [08-07 09:01:33 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:31 216] [08-07 09:01:33 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:31 232] [08-07 09:01:33 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:31 232] [08-07 09:01:33 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:31 248] [08-07 09:01:33 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:31 248] [08-07 09:01:33 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:31 248] [08-07 09:01:33 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:31 264] [08-07 09:01:33 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:31 264] [08-07 09:01:33 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:31 280] [08-07 09:01:33 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:31 296] [08-07 09:01:33 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:31 296] [2024-08-07 09:01:32] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time52726
[2024/8/7 9:01:31 312] [08-07 09:01:33 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992493,"success":true}
[2024/8/7 9:01:31 312] [08-07 09:01:33 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:31 312] [08-07 09:01:33 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:31 328] [08-07 09:01:33 TUYA E][tuya_svc_upgrade.c:436] result null
[2024/8/7 9:01:31 328] [08-07 09:01:33 TUYA D][tuya_svc_upgrade.c:511] silent get firmware fail
[2024/8/7 9:01:31 344] [08-07 09:01:33 TUYA D][tuya_svc_upgrade.c:205] next detect timer: 21600s
[2024/8/7 9:01:31 344] [08-07 09:01:33 TUYA N][tuya_svc_timer_task.c:796] Update Timer from cloud
[2024/8/7 9:01:31 360] [08-07 09:01:33 TUYA D][iot_httpc.c:1161] Post Data: {"devId":"6c62194832a0f26036b5lh","lastFetchTime":"0","t":1722992493}
[2024/8/7 9:01:31 376] [08-07 09:01:33 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.timer.count&devId=6c62194832a0f26036b5lh&et=1&t=1722992493&v=4.2&sign=fed9290f7eca5fd0daca122438e91489
[2024/8/7 9:01:31 376] [08-07 09:01:33 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:31 392] [08-07 09:01:33 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:31 392] [08-07 09:01:33 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:31 408] [08-07 09:01:33 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:31 408] [08-07 09:01:33 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:31 423] [08-07 09:01:33 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:31 426] [08-07 09:01:33 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:31 440] [08-07 09:01:33 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:31 441] [08-07 09:01:33 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:31 441] [08-07 09:01:33 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:31 456] [08-07 09:01:33 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:31 456] [08-07 09:01:33 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:31 472] [08-07 09:01:33 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:31 490] [08-07 09:01:33 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"code":"200","count":0,"devId":"6c62194832a0f26036b5lh","lastFetchTime":0},"t":1722992493,"success":true}
[2024/8/7 9:01:31 490] [08-07 09:01:33 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:31 505] [08-07 09:01:33 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:31 505] [08-07 09:01:33 TUYA D][tuya_svc_timer_task.c:451] time eq skip:0
[2024/8/7 9:01:31 505] ble_smart_cfg_exit before
[2024/8/7 9:01:31 520] ble_smart_cfg_exit after
[2024/8/7 9:01:31 520] atbm_stopThread after
[2024/8/7 9:01:31 520] [08-07 09:01:33 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992493 28800
[2024/8/7 9:01:31 536] [08-07 09:01:33 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992493 28800
[2024/8/7 9:01:32 671] [2024-08-07 09:01:33] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 14481[2024-08-07 09:01:33] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:32 687] [2024-08-07 09:01:34] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 14585[08-07 09:01:35 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 9:01:34 639] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:01:34 639] Mode(Product):0
[2024/8/7 9:01:34 639] BpuMode:[Online]
[2024/8/7 9:01:34 639] VpssMode:[Online]
[2024/8/7 9:01:34 639] [0.LimitUp_info]:
[2024/8/7 9:01:34 655] LimitUp:[Disable]
[2024/8/7 9:01:34 655] [2680*0]->[3840*0])
[2024/8/7 9:01:34 655] chn	TotalSize	ActiveSize
[2024/8/7 9:01:34 655] 0	5040*2246	2680*2160
[2024/8/7 9:01:34 655] 0	5040*2246	3840*2160
[2024/8/7 9:01:34 655] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:01:34 655] [1.VICU_info]:
[2024/8/7 9:01:34 671] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:01:34 671] 0	25.0	1218	0	0	183	linear	8ddb00
[2024/8/7 9:01:34 671] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:01:34 671] en	op_type	m_chn	now
[2024/8/7 9:01:34 671] 0	1	1	1
[2024/8/7 9:01:34 671] [2.VI_info]:
[2024/8/7 9:01:34 687] chn	TotalSize	ActiveSize
[2024/8/7 9:01:34 687] 0	5040*2246	3848*2166
[2024/8/7 9:01:34 687] 1	   0*   0	   0*   0
[2024/8/7 9:01:34 687] [3.MIPI_info]:
[2024/8/7 9:01:34 687] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:01:34 703] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:01:34 703] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:01:34 703] [4.Cut_info]:
[2024/8/7 9:01:34 703] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:01:34 703] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:01:34 719] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:01:34 719] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:01:34 719] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:01:34 719] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:01:34 719] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:01:34 719] [5.IB(isp buffer info)]:
[2024/8/7 9:01:34 736] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:01:34 736] PoolId  Count  Size
[2024/8/7 9:01:34 736] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:34 752] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:34 752] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:34 768] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:34 769] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:34 769] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:34 784] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:01:34 784] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:01:34 784] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:01:34 799] 0       0         0          1          4       
[2024/8/7 9:01:34 799] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:01:34 799]      --265--            --264--                                               
[2024/8/7 9:01:34 815] Count      Line     Count      Line     
[2024/8/7 9:01:34 815] 960        480      2064       560      
[2024/8/7 9:01:34 815] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:01:34 831] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:01:34 831] 0   3840   2160    H265  0      0        0           567       983035     5        	
[2024/8/7 9:01:34 848] 1   640    360     H265  0      0        0           391       42512      688      	
[2024/8/7 9:01:34 848] 3   640    360     JPEG  0      0        0           3         172796     4        	
[2024/8/7 9:01:34 864] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:01:34 864] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:01:34 880] 0   Y      567      0       0       15       0        567      567      809       65499         59008    122088   64873    12      
[2024/8/7 9:01:34 896] 1   Y      391      0       2       0        1        390      390      809       2540          1888     27580    2701     9       
[2024/8/7 9:01:34 912] 3   N      3        0       0       1        0        3        3        813       1789          1758     1789     1772     1       
[2024/8/7 9:01:40 575] [2024-08-07 09:01:35] tuya_ipc_ai_detect.demo.c(371) <thread_ai_detect_proc>: 
[2024/8/7 9:01:40 591] [2024-08-07 09:01:35] xm_main.c(1810) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 591] [2024-08-07 09:01:35] xm_main.c(1813) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 591] [2024-08-07 09:01:35] xm_main.c(1833) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 623] [2024-08-07 09:01:35] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 14588[2024-08-07 09:01:36] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 15048[2024-08-07 09:01:36] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time56702
[2024/8/7 9:01:40 623] [2024-08-07 09:01:36] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:40 639] [2024-08-07 09:01:36] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:40 639] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:2
[2024/8/7 9:01:40 655]  ---
[2024/8/7 9:01:40 655] [2024-08-07 09:01:38] tuya_ipc_ai_detect.demo.c(371) <thread_ai_detect_proc>: 
[2024/8/7 9:01:40 655] [2024-08-07 09:01:38] xm_main.c(1810) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 671] [2024-08-07 09:01:38] xm_main.c(1813) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 671] [2024-08-07 09:01:38] xm_main.c(1833) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 687] [2024-08-07 09:01:39] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:40 687] [2024-08-07 09:01:40] tuya_ipc_ai_detect.demo.c(371) <thread_ai_detect_proc>: 
[2024/8/7 9:01:40 703] [2024-08-07 09:01:40] xm_main.c(1810) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 703] [2024-08-07 09:01:40] xm_main.c(1813) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 703] [2024-08-07 09:01:40] xm_main.c(1833) <XM_GetCatchJpgStream>: 
[2024/8/7 9:01:40 719] [2024-08-07 09:01:40] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time60706
[2024/8/7 9:01:40 719] [08-07 09:01:43 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 9:01:40 735] [08-07 09:01:43 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:40 735] [08-07 09:01:43 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:40 735] [08-07 09:01:43 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:40 751] [08-07 09:01:43 TUYA D][tuya_svc_upgrade_http.c:125] schema get:{"schemaId":"flvlrc","version":""}
[2024/8/7 9:01:40 767] [08-07 09:01:43 TUYA D][iot_httpc.c:1161] Post Data: {"schemaId":"flvlrc","version":"","t":1722992503}
[2024/8/7 9:01:40 783] [08-07 09:01:43 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.schema.newest.get&devId=6c62194832a0f26036b5lh&et=1&t=1722992503&v=1.1&sign=c41310af13da3273931a8c9054c3adf5
[2024/8/7 9:01:40 783] [08-07 09:01:43 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:01:40 799] [08-07 09:01:43 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:01:40 799] [08-07 09:01:43 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:01:40 815] [08-07 09:01:43 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:01:40 815] [08-07 09:01:43 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:01:40 815] [08-07 09:01:43 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:01:40 831] [08-07 09:01:43 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:01:40 831] [08-07 09:01:43 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:01:40 847] [08-07 09:01:43 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:01:40 847] [08-07 09:01:43 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:01:40 862] [08-07 09:01:43 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:01:40 863] [08-07 09:01:43 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:01:40 878] [08-07 09:01:43 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:01:40 894] [08-07 09:01:43 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"schema":"","schemaId":"flvlrc"},"t":1722992503,"success":true}
[2024/8/7 9:01:40 895] [08-07 09:01:43 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:40 910] [08-07 09:01:43 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:40 911] [08-07 09:01:43 TUYA D][tuya_svc_upgrade_http.c:133] schema get result:{"schema":"","schemaId":"flvlrc"}
[2024/8/7 9:01:40 927] [08-07 09:01:43 TUYA D][tuya_svc_schema_upgrade.c:130] schema[flvlrc] ver not update
[2024/8/7 9:01:41 183] [2024-08-07 09:01:42] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:41 183] [08-07 09:01:43 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992503 28800
[2024/8/7 9:01:41 199] [08-07 09:01:43 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992503 28800
[2024/8/7 9:01:43 150] 
[2024/8/7 9:01:43 215] Login timed oAuto login as root ...
[2024/8/7 9:01:44 542] (none) login: [2024-08-07 09:01:44] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time64724
[2024/8/7 9:01:44 543] [2024-08-07 09:01:45] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:44 559] [2024-08-07 09:01:46] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:01:44 559] [2024-08-07 09:01:46] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:01:44 575] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=8.000 ms
[2024/8/7 9:01:44 575] [2024-08-07 09:01:46] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:01:44 591] [08-07 09:01:47 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:01:44 654] [08-07 09:01:47 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 9:01:45 263] [08-07 09:01:47 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [1000]
[2024/8/7 9:01:46 735] [2024-08-07 09:01:48] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time68703
[2024/8/7 9:01:46 735] [08-07 09:01:49 TUYA D][tuya_svc_schema_upgrade.c:170] next schema get slot 77976.
[2024/8/7 9:01:46 846] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:01:46 846] Mode(Product):0
[2024/8/7 9:01:46 846] BpuMode:[Online]
[2024/8/7 9:01:46 846] VpssMode:[Online]
[2024/8/7 9:01:46 846] [0.LimitUp_info]:
[2024/8/7 9:01:46 862] LimitUp:[Disable]
[2024/8/7 9:01:46 862] [2680*0]->[3840*0])
[2024/8/7 9:01:46 862] chn	TotalSize	ActiveSize
[2024/8/7 9:01:46 862] 0	5040*2246	2680*2160
[2024/8/7 9:01:46 862] 0	5034*2246	3840*2160
[2024/8/7 9:01:46 862] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:01:46 862] [1.VICU_info]:
[2024/8/7 9:01:46 878] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:01:46 878] 0	25.0	1523	0	0	183	linear	8ddb00
[2024/8/7 9:01:46 878] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:01:46 878] en	op_type	m_chn	now
[2024/8/7 9:01:46 878] 0	1	1	1
[2024/8/7 9:01:46 878] [2.VI_info]:
[2024/8/7 9:01:46 878] chn	TotalSize	ActiveSize
[2024/8/7 9:01:46 894] 0	5034*2246	3848*2166
[2024/8/7 9:01:46 894] 1	   0*   0	   0*   0
[2024/8/7 9:01:46 894] [3.MIPI_info]:
[2024/8/7 9:01:46 894] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:01:46 910] 0x2b	6480*2166	3848*2166		5034*2166	3848*2166	   0
[2024/8/7 9:01:46 910] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:01:46 910] [4.Cut_info]:
[2024/8/7 9:01:46 910] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:01:46 910] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:01:46 910] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:01:46 926] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:01:46 926] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:01:46 926] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:01:46 926] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:01:46 926] [5.IB(isp buffer info)]:
[2024/8/7 9:01:46 943] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:01:46 943] PoolId  Count  Size
[2024/8/7 9:01:46 943] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:46 959] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:46 959] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:46 975] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:46 975] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:46 990] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:01:46 990] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:01:46 990] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:01:47 006] 0       0         0          0          4       
[2024/8/7 9:01:47 006] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:01:47 006]      --265--            --264--                                               
[2024/8/7 9:01:47 022] Count      Line     Count      Line     
[2024/8/7 9:01:47 022] 1226       480      2670       560      
[2024/8/7 9:01:47 022] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:01:47 038] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:01:47 039] 0   3840   2160    H265  0      0        0           719       983037     3        	
[2024/8/7 9:01:47 054] 1   640    360     H265  0      0        0           504       43198      2        	
[2024/8/7 9:01:47 054] 3   640    360     JPEG  0      0        0           5         172793     7        	
[2024/8/7 9:01:47 070] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:01:47 070] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:01:47 086] 0   Y      719      0       0       15       0        719      719      1031      63996         59008    122088   64764    12      
[2024/8/7 9:01:47 102] 1   Y      504      0       2       1        0        504      504      1031      2632          1888     27580    2596     9       
[2024/8/7 9:01:47 118] 3   N      5        0       0       1        0        5        5        1038      1748          1748     1851     1782     0       
[2024/8/7 9:01:51 214] [2024-08-07 09:01:48] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:51 230] [2024-08-07 09:01:48] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:01:51 230] [2024-08-07 09:01:52] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:51 246] [2024-08-07 09:01:52] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time72725
[2024/8/7 9:01:51 246] [08-07 09:01:53 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992513 28800
[2024/8/7 9:01:51 262] [08-07 09:01:53 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992513 28800
[2024/8/7 9:01:54 942] [2024-08-07 09:01:55] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:54 942] [2024-08-07 09:01:56] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time76702
[2024/8/7 9:01:54 958] [08-07 09:01:57 TUYA E][app_agent.c:1479] close socket,errno:-100 errno:0
[2024/8/7 9:01:54 958] [08-07 09:01:57 TUYA D][app_agent.c:213] set socket fault 35
[2024/8/7 9:01:54 958] [08-07 09:01:57 TUYA D][app_agent.c:274] i:0,time:1722992517,c_time:1722992514,fault:1
[2024/8/7 9:01:54 974] [08-07 09:01:57 TUYA D][app_agent.c:163] close socket 35
[2024/8/7 9:01:54 990] [08-07 09:01:57 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"devId":"6c62194832a0f26036b5lh","gwId":"6c62194832a0f26036b5lh"},"protocol":11,"s":2547715,"t":1722992517}
[2024/8/7 9:01:54 990] [08-07 09:01:57 TUYA D][mqtt_client.c:916] disconnect mqtt
[2024/8/7 9:01:55 422] [08-07 09:01:57 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:01:55 422] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:01:55 438] [08-07 09:01:57 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:01:55 439] [08-07 09:01:57 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:01:55 454] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:01:55 454] [08-07 09:01:57 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:01:55 470] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:01:55 470] [08-07 09:01:57 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:01:55 486] [08-07 09:01:57 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:01:55 486] [08-07 09:01:57 TUYA D][gw_mqc_cb.c:60] unactive
[2024/8/7 9:01:55 486] [08-07 09:01:57 TUYA D][tuya_devos_reset.c:418] unactive Reset
[2024/8/7 9:01:55 502] [08-07 09:01:57 TUYA D][tuya_devos_reset.c:261] gw reset called. tp:1 stat:1
[2024/8/7 9:01:55 502] __IPC_APP_Get_Net_Status_cb line(183) -------------------------- stat(0)==STAT_LOW_POWER 
[2024/8/7 9:01:55 518] [08-07 09:01:57 TUYA D][tuya_devos_reset.c:85] <__wf_reset> nc_tp:2, rst_tp:1, wifi_start_mode:0
[2024/8/7 9:01:55 518] [08-07 09:01:57 TUYA D][tuya_devos_reset.c:325] <__gw_reset> tuya_ble_clear_mesh
[2024/8/7 9:01:55 534] [08-07 09:01:57 TUYA D][tuya_ble_api.c:1050] start to clr appkey.
[2024/8/7 9:01:55 534] [08-07 09:01:57 TUYA D][simplekv.c:1348] delete key:ble_app_key isFuzzy:0
[2024/8/7 9:01:55 550] [08-07 09:01:57 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:01:55 550] [08-07 09:01:57 TUYA D][simplekv.c:1386] delete key find 4
[2024/8/7 9:01:55 550] [08-07 09:01:57 TUYA D][simplekv.c:1424] Delete key:ble_app_key 4 success
[2024/8/7 9:01:55 566] [08-07 09:01:57 TUYA D][simplekv.c:203] update crc 1300058586
[2024/8/7 9:01:55 566] [08-07 09:01:57 TUYA E][mqtt_client.c:1652] mq_recv err:-30848 len:0
[2024/8/7 9:01:55 566] [08-07 09:01:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:55 582] [08-07 09:01:57 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:01:55 582] [08-07 09:01:57 TUYA D][tuya_ble_api.c:1058] start to clr network_key.
[2024/8/7 9:01:55 598] [08-07 09:01:57 TUYA D][simplekv.c:1348] delete key:ble_network_key isFuzzy:0
[2024/8/7 9:01:55 598] [08-07 09:01:57 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:01:55 598] [08-07 09:01:57 TUYA D][simplekv.c:1386] delete key find 13
[2024/8/7 9:01:55 613] [08-07 09:01:57 TUYA D][simplekv.c:1424] Delete key:ble_network_key 13 success
[2024/8/7 9:01:55 614] [08-07 09:01:57 TUYA D][simplekv.c:203] update crc 819405892
[2024/8/7 9:01:55 614] [08-07 09:01:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:55 630] [08-07 09:01:57 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:01:55 630] [08-07 09:01:57 TUYA D][tuya_ble_api.c:1035] start to clr beaconkey.
[2024/8/7 9:01:55 646] [08-07 09:01:57 TUYA D][simplekv.c:1348] delete key:ble_beaconkey isFuzzy:0
[2024/8/7 9:01:55 646] [08-07 09:01:57 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:01:55 646] [08-07 09:01:57 TUYA D][simplekv.c:1386] delete key find 14
[2024/8/7 9:01:55 662] [08-07 09:01:57 TUYA D][simplekv.c:1424] Delete key:ble_beaconkey 14 success
[2024/8/7 9:01:55 662] [08-07 09:01:57 TUYA D][simplekv.c:203] update crc 1853806926
[2024/8/7 9:01:55 678] [08-07 09:01:58 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:55 678] [08-07 09:01:58 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:01:55 694] [08-07 09:01:58 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":1,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:01:55 694] [08-07 09:01:58 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:01:55 710] [08-07 09:01:58 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:01:55 710] [08-07 09:01:58 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:176
[2024/8/7 9:01:55 710] [08-07 09:01:58 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:01:55 726] [08-07 09:01:58 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:01:55 726] [08-07 09:01:58 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:01:55 742] [08-07 09:01:58 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:01:55 742] [08-07 09:01:58 TUYA D][simplekv.c:203] update crc 2110129228
[2024/8/7 9:01:55 742] [08-07 09:01:58 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:55 758] [08-07 09:01:58 TUYA D][simplekv.c:52[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:01:55 758] 0] write success
[2024/8/7 9:01:55 758] [08-07 09:01:58 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:01:55 774] [08-07 09:01:58 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:01:55 774] [08-07 09:01:58 TU[atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:01:55 774] YA D][simplekv.c[atbm_log]:aggtx stop queue
[2024/8/7 9:01:55 790] :1251] find key:[atbm_log]:add to pending(0)(20)
[2024/8/7 9:01:55 790] 3 wf_start_md
[2024/8/7 9:01:55 790] [08-07 0[atbm_log]:AMPDU[eth2]:action[2],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:55 806] 9:01:58 TUYA D][[atbm_log]:activated addBA response timer on tid 6
[2024/8/7 9:01:55 806] simplekv.c:1280][atbm_log]:ignore pending[5][20]
[2024/8/7 9:01:55 806]  key:wf_start_md find value.Len:[atbm_log]:aggtx wake queue
[2024/8/7 9:01:55 806] 16
[2024/8/7 9:01:55 806] [08-07 09:0[atbm_log]:not assoc 
[2024/8/7 9:01:55 822] 1:58 TUYA D][tuy[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:01:55 840] a_svc_timer_task.c:107] [atbm_log]:AMPDU[eth2]:action[3],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:55 840] reset. write_dis[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:01:55 840] k:1
[2024/8/7 9:01:55 854] [08-07 09:[atbm_log]:AMPDU[eth2]:action[1],tid[0],ssn[0],buff_size[0],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:55 854] 01:58 TUYA D][tuya_svc_t[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 5
[2024/8/7 9:01:55 870] imer_task.c:310][atbm_log]:AMPDU[eth2]:action[1],tid[5],ssn[0],buff_size[0],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:55 870]  max len:128
[2024/8/7 9:01:55 871] [08-07 09:01:58 T[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:01:55 886] UYA D][tuya_svc_timer_task.c:378] offset:27
[2024/8/7 9:01:55 886] [08-07 09:01:58 TUYA D][tuya_svc_timer_task.c:397] save TIMER:{"lastFetchTime":0,"cnt":0}
[2024/8/7 9:01:55 886] [08-07 09:01:58 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:01:55 902] [08-07 09:01:58 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:01:55 902] [08-07 09:01:58 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:01:55 918] [08-07 09:01:58 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:01:55 918] [08-07 09:01:58 TUYA D][simplekv.c:374] write key:timer_arr And Value Len:32
[2024/8/7 9:01:55 918] [08-07 09:01:58 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 32
[2024/8/7 9:01:55 934] [08-07 09:01:58 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:01:55 950] [08-07 09:01:58 TUYA D][simplekv.c:474] reuse available spa[atbm_log]:AMPDU[eth2]:action[3],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:55 950] ce 29740
[2024/8/7 9:01:55 950] [08-07 09:01:[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:01:55 966] 58 TUYA D][simpl[atbm_log]:AMPDU[eth2]:action[1],tid[6],ssn[0],buff_size[0],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:01:55 966] ekv.c:203] update crc 2204501322
[2024/8/7 9:01:55 966] [08-07 09:01:58 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:55 981] [08-07 09:01:58 TUYA D][s[atbm_log]:eth2: deauthenticating from a4:a9:30:ce:5e:66 by local choice (reason=3)
[2024/8/7 9:01:55 982] implekv.c:520] write success
[2024/8/7 9:01:55 998] [08-07 09:01:58 TUYA D][simplekv.c:1348] delete key:last_reset_info isFuzzy:0
[2024/8/7 9:01:55 999] [08-07 09:01:58 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:01:55 999] [08-07 09:01:58 TUYA D][simplekv.c:1395] key:last_reset_info not find
[2024/8/7 9:01:56 014] [08-07 09:01:58 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:01:56 014] [atbm_log]:[TX]:[0]:deatuhen[a4:a9:30:ce:5e:66]ey:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:01:56 030] [08-07 09:01:58 TUYA D][atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:01:56 030] [simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:01:56 030] [08-07 09:01:58 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:01:56 046] [08-07 09:01:58 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:01:56 046] [08-07 09:01:58 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 16
[2024/8/7 9:01:56 062] [08-07 09:01:58 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:01:56 062] [08-07 09:01:58 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:01:56 062] [08-07 09:01:58 TUYA D][simplekv.c:203] update crc 939183163
[2024/8/7 9:01:56 078] [08-07 09:01:58 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:56 094] [08-07 09:01:58 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:56 094] [08-07 09:01:58[atbm_log]:[STA]:unjoin ++
[2024/8/7 9:01:56 110]  TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 ski[atbm_log]:[STA]:unjoin --
[2024/8/7 9:01:56 110] pCnt:0
[2024/8/7 9:01:56 110] [08-07 09:01:58 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:01:56 126] [08-07 09:01:58 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:01:56 126] [08-07 09:01:58 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:01:56 126] [08-07 09:01:58 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:01:56 142] [08-07 09:01:58 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:01:56 142] [08-07 09:01:58 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:01:56 142] [08-07 09:01:58 TUYA D][simplekv.c:203] update crc 3033894865
[2024/8/7 9:01:56 158] [08-07 09:01:58 TUYA N][mqtt_client.c:1703] mqtt close
[2024/8/7 9:01:56 158] [08-07 09:01:58 TUYA N][mqtt_client.c:839] close mqtt -->>
[2024/8/7 9:01:56 158] [08-07 09:01:58 TUYA D][mqtt_client.c:851] shutdown fd enabled
[2024/8/7 9:01:56 174] [08-07 09:01:58 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:01:56 174] [08-07 09:01:58 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:01:56 190] [08-07 09:01:58 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:01:56 190] [08-07 09:01:58 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:56 190] [08-07 09:01:58 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:56 206] [08-07 09:01:58 TUYA N][mqtt_client.c:886] close mqtt <<--
[2024/8/7 9:01:56 206] [08-07 09:01:58 TUYA D][mqtt_client.c:1720] mqtt fail_cnt:1, sleeptime:6939 ms
[2024/8/7 9:01:56 206] [08-07 09:01:58 TUYA D][simpl[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:01:56 222] ekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:01:56 222] [08-07 09:01:58 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:01:56 222] [08-07 09:01:58 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:01:56 238] [08-07 09:01:58 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:01:56 238] [08-07 09:01:58 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:01:56 254] [08-07 09:01:58 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:01:56 254] [atbm_log]:eth2:free authen bss ++:474] reuse available space 30344
[2024/8/7 9:01:56 270] [08-07 09:01:58 TUYA D][simplekv.c:203] update crc 4146660859
[2024/8/7 9:01:56 270] [08-07 09:01:58 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:01:56 270] [08-07 09:01:58 TUYA D][simplekv.c:520] write success
[2024/8/7 9:01:56 286] rm: can't remove '/mnt/mtd/Config/localtime': Device or resource busy
[2024/8/7 9:01:56 286] rm: can't remove '/mnt/mtd/Config/resolv.conf': Device or resource busy
[2024/8/7 9:01:56 286] rm: can't remove '/mnt/mtd/Config': Directory not empty
[2024/8/7 9:01:56 589] IPC_APP_Reset_System_CB line(143) -------------------------- 
[2024/8/7 9:01:56 606] [2024-08-07 09:01:57] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:57] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:56 606] set basic_indicator_onoff:0 
[2024/8/7 9:01:56 606] [2024-08-07 09:01:57] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:56 622] [2024-08-07 09:01:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:56 638] [2024-08-07 09:01:57] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:57] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:56 654] [2024-08-07 09:01:58] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:01:56 669] [2024-08-07 09:01:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:56 686] [2024-08-07 09:01:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:56 702] [2024-08-07 09:01:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:56 718] [2024-08-07 09:01:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:56 734] [2024-08-07 09:01:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:56 750] [08-07 09:01:59 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 9:01:56 766] [2024-08-07 09:01:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:56 782] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(150): cmd=[killall wpa_supplicant udhcpc;ifconfig eth2 down;ifconfig eth0 down;]
[2024/8/7 9:01:56 782] curr event:13 
[2024/8/7 9:01:56 798] IPC_APP_Notify_LED_Sound_Status_CB line(583) -------------------------- IPC_RESET_SUCCESS(13)
[2024/8/7 9:01:56 798] [2024-08-07 09:01:58] tuya_ipc_system_control_demo.c(585) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(RESET, 0, 1, 0, 1))
[2024/8/7 9:01:56 814] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(155):  ---
[2024/8/7 9:01:56 814] [2024-08-07 09:01:58] xm_main.c(2440) <XMSDK_SystemRebootTY>: XMSDK_MotorGetPostion(3110,0) suc
[2024/8/7 9:01:56 830] [2024-08-07 09:01:58] xm_main.c(2064) <XM_SaveLocalPtzPosition>: Save PTZ xPosition 3110 failed
[2024/8/7 9:01:56 846] [2024-08-07 09:01:58] xm_main.c(2445) <XMSDK_SystemRebootTY>: XM_SaveLocalPtzPosition(3110,0) failed,ret=[-1]
[2024/8/7 9:01:56 846] XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:01:56 862] [2024-08-07 09:01:58] xm_main.c(2454) <XMSDK_SystemRebootTY>: XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:01:56 862] [2024-08-07 09:01:58] ==> XMSDK_SystemReboot(198)[INFO]: Sys XMSDK_SystemReboot Reboot
[2024/8/7 9:01:56 878] [2024-08-07 09:01:58] ==> XMSDK_SystemReboot(199)[INFO]: Sys Will Reboot
[2024/8/7 9:01:56 878] [2024-08-07 09:01:58] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/Reset_english.pcm]
[2024/8/7 9:01:56 894] [2024-08-07 09:01:58] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:01:56 894] [2024-08-07 09:01:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:01:56 910] 
[2024/8/7 9:01:56 912] [08-07 09:01:59 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 9:01:57 006] [2024-08-07 09:01:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:01:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:01:57 022] set basic_indicator_onoff:0 
[2024/8/7 9:01:57 022] [2024-08-07 09:01:58] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:01:57 038] [2024-08-07 09:01:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:01:57 039] 
[2024/8/7 9:01:57 039] [08-07 09:01:59 TUYA D][tuya_ble_api.c:1426] cloud disconnected, start adv!
[2024/8/7 9:01:57 054] [08-07 09:01:59 TUYA I][bt_ext_porting.c:628] [TUYA-BTUART]start_adv
[2024/8/7 9:01:57 054] --- tracepoint bt_ext_porting.c,tuya_ext_bt_start_adv(629): start_adv ---
[2024/8/7 9:01:57 054] [08-07 09:01:59 TUYA D][tuya_ble_api.c:1376] nw stat change:2->0, rpt to app.
[2024/8/7 9:01:57 070] [08-07 09:01:59 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:01:58 622] g_AudioTipsList.size() enable: 0[2024-08-07 09:02:00] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:02:00] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [MotionDetect] pNumber[SirenSwitch]!
[2024/8/7 9:01:58 638] [08-07 09:02:01 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:01:59 005] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:01:59 005] Mode(Product):0
[2024/8/7 9:01:59 006] BpuMode:[Online]
[2024/8/7 9:01:59 006] VpssMode:[Online]
[2024/8/7 9:01:59 006] [0.LimitUp_info]:
[2024/8/7 9:01:59 021] LimitUp:[Disable]
[2024/8/7 9:01:59 021] [2680*0]->[3840*0])
[2024/8/7 9:01:59 021] chn	TotalSize	ActiveSize
[2024/8/7 9:01:59 021] 0	5034*2246	2680*2160
[2024/8/7 9:01:59 021] 0	5040*2246	3840*2160
[2024/8/7 9:01:59 021] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:01:59 021] [1.VICU_info]:
[2024/8/7 9:01:59 037] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:01:59 037] 0	25.0	1827	0	0	183	linear	8ddb00
[2024/8/7 9:01:59 037] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:01:59 037] en	op_type	m_chn	now
[2024/8/7 9:01:59 037] 0	1	1	1
[2024/8/7 9:01:59 038] [2.VI_info]:
[2024/8/7 9:01:59 053] chn	TotalSize	ActiveSize
[2024/8/7 9:01:59 053] 0	5046*2246	3848*2166
[2024/8/7 9:01:59 053] 1	   0*   0	   0*   0
[2024/8/7 9:01:59 053] [3.MIPI_info]:
[2024/8/7 9:01:59 054] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:01:59 069] 0x2b	6480*2166	3848*2166		5034*2166	3848*2166	   0
[2024/8/7 9:01:59 069] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:01:59 069] [4.Cut_info]:
[2024/8/7 9:01:59 069] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:01:59 069] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:01:59 085] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:01:59 085] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:01:59 085] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:01:59 085] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:01:59 085] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:01:59 086] [5.IB(isp buffer info)]:
[2024/8/7 9:01:59 101] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:01:59 101] PoolId  Count  Size
[2024/8/7 9:01:59 101] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:59 117] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:59 118] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:59 133] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:59 133] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:01:59 134] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:01:59 149] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:01:59 149] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:01:59 149] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:01:59 165] 0       0         0          0          4       
[2024/8/7 9:01:59 165] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:01:59 165]      --265--            --264--                                               
[2024/8/7 9:01:59 181] Count      Line     Count      Line     
[2024/8/7 9:01:59 181] 1470       480      3235       560      
[2024/8/7 9:01:59 181] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:01:59 197] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:01:59 197] 0   3840   2160    H265  0      0        0           858       983037     3        	
[2024/8/7 9:01:59 213] 1   640    360     H265  0      0        0           608       43195      5        	
[2024/8/7 9:01:59 213] 3   640    360     JPEG  0      0        0           5         172793     7        	
[2024/8/7 9:01:59 229] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:01:59 229] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:01:59 245] 0   Y      858      0       0       15       0        858      858      1231      63364         59008    122088   64733    12      
[2024/8/7 9:01:59 261] 1   Y      608      0       3       1        0        608      608      1231      2627          1880     27580    2565     9       
[2024/8/7 9:01:59 278] 3   N      5        0       0       1        0        5        5        1237      1748          1748     1851     1782     0       
[2024/8/7 9:02:00 957] [2024-08-07 09:02:00] xm_musicPlayer.cpp(177) <PlayAudioTips>: match reset audio
[2024/8/7 9:02:00 957] [2024-08-07 09:02:00] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time80726
[2024/8/7 9:02:00 973] [2024-08-07 09:02:01] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:00 973] [2024-08-07 09:02:01] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:00 989] [2024-08-07 09:02:01] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:02:00 989] [2024-08-07 09:02:01] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:02:01 006] sendto error send_packet 108 
[2024/8/7 9:02:01 006] recvfrom Error  
[2024/8/7 9:02:01 006] FUNCTION:recv_packet	LINE:139 
[2024/8/7 9:02:01 006] [2024-08-07 09:02:01] xm_wifi.c(386) <WifiConnectCheck>: gate way is  ping res is 0 error_cnt:1
[2024/8/7 9:02:01 022] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:2
[2024/8/7 9:02:01 022] [08-07 09:02:03 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 9:02:01 295] [08-07 09:02:03 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992523 28800
[2024/8/7 9:02:01 310] [08-07 09:02:03 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992523 28800
[2024/8/7 9:02:01 614] xmsfc_shutdown 2 2 
[2024/8/7 9:02:01 614] Restarting system.
[2024/8/7 9:02:01 661] 
[2024/8/7 9:02:01 662] 
[2024/8/7 9:02:01 662] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 9:02:01 662] CPU: XM550V200WX2
[2024/8/7 9:02:01 662] DRAM:  128 MiB
[2024/8/7 9:02:01 789] MMC:   arasan: 0
[2024/8/7 9:02:01 837] In:    serial
[2024/8/7 9:02:01 837] Out:   serial
[2024/8/7 9:02:01 837] Err:   serial
[2024/8/7 9:02:02 045] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 9:02:02 061] Press Ctrl+C to stop autoboot
[2024/8/7 9:02:02 461] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 9:02:02 478] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 9:02:02 478]    Image Name:   Linux-3.10.103+
[2024/8/7 9:02:02 478]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 9:02:02 478]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 9:02:02 494]    Load Address: 80008000
[2024/8/7 9:02:02 494]    Entry Point:  80008000
[2024/8/7 9:02:02 494]    XIP Kernel Image ... OK
[2024/8/7 9:02:02 494] Starting kernel ...
[2024/8/7 9:02:03 373] Uncompressing Linux... done, booting the kernel.
[2024/8/7 9:02:03 517] Booting Linux on physical CPU 0x0
[2024/8/7 9:02:03 517] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 9:02:03 533] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 9:02:03 533] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 9:02:03 533] Machine: xm530v200
[2024/8/7 9:02:03 533] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 9:02:03 550] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 9:02:03 550] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 9:02:03 566] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 9:02:03 566] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 9:02:03 582] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 9:02:03 582] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 9:02:03 582] Memory: 52MB = 52MB total
[2024/8/7 9:02:03 598] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 9:02:03 598] Virtual kernel memory layout:
[2024/8/7 9:02:03 598]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 9:02:03 598]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 9:02:03 614]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 9:02:03 614]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 9:02:03 614]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 9:02:03 614]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 9:02:03 631]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 9:02:03 631]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 9:02:03 631]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 9:02:03 646] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 9:02:03 646] Hierarchical RCU implementation.
[2024/8/7 9:02:03 646] NR_IRQS:128
[2024/8/7 9:02:03 646] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 9:02:03 662] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 9:02:03 662] pid_max: default: 32768 minimum: 301
[2024/8/7 9:02:03 662] Mount-cache hash table entries: 512
[2024/8/7 9:02:03 662] CPU: Testing write buffer coherency: ok
[2024/8/7 9:02:03 662] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 9:02:03 677] L310 cache controller enabled
[2024/8/7 9:02:03 677] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 9:02:03 677] CPU1: Booted secondary processor
[2024/8/7 9:02:03 677] Brought up 2 CPUs
[2024/8/7 9:02:03 694] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 9:02:03 694] CPU: All CPU(s) started in SVC mode.
[2024/8/7 9:02:03 694] NET: Registered protocol family 16
[2024/8/7 9:02:03 694] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 9:02:03 709] Serial: AMBA PL011 UART driver
[2024/8/7 9:02:03 710] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 9:02:03 710] console [ttyAMA0] enabled
[2024/8/7 9:02:03 710] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 9:02:03 725] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 9:02:03 741] bio: create slab <bio-0> at 0
[2024/8/7 9:02:03 757] usbcore: registered new interface driver usbfs
[2024/8/7 9:02:03 757] usbcore: registered new interface driver hub
[2024/8/7 9:02:03 757] usbcore: registered new device driver usb
[2024/8/7 9:02:03 757] Switching to clocksource arm_global_timer
[2024/8/7 9:02:03 773] NET: Registered protocol family 2
[2024/8/7 9:02:03 773] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:02:03 789] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:02:03 789] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 9:02:03 789] TCP: reno registered
[2024/8/7 9:02:03 789] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:02:03 805] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:02:03 805] NET: Registered protocol family 1
[2024/8/7 9:02:03 805] RPC: Registered named UNIX socket transport module.
[2024/8/7 9:02:03 805] RPC: Registered udp transport module.
[2024/8/7 9:02:03 805] RPC: Registered tcp transport module.
[2024/8/7 9:02:03 821] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 9:02:03 837] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 9:02:03 837] NFS: Registering the id_resolver key type
[2024/8/7 9:02:03 853] Key type id_resolver registered
[2024/8/7 9:02:03 853] Key type id_legacy registered
[2024/8/7 9:02:03 853] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 9:02:03 853] fuse init (API version 7.22)
[2024/8/7 9:02:03 869] msgmni has been set to 95
[2024/8/7 9:02:03 869] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 9:02:03 869] io scheduler noop registered
[2024/8/7 9:02:03 869] io scheduler deadline registered (default)
[2024/8/7 9:02:03 886] io scheduler cfq registered
[2024/8/7 9:02:03 886] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 9:02:03 902] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 9:02:03 902] uart-pl011 uart:0: no DMA platform data
[2024/8/7 9:02:03 902] uart-pl011 uart:1: no DMA platform data
[2024/8/7 9:02:03 902] uart-pl011 uart:2: no DMA platform data
[2024/8/7 9:02:03 918] brd: module loaded
[2024/8/7 9:02:03 934] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 9:02:03 934] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:02:03 934] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 9:02:03 949] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 9:02:03 950] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 9:02:03 950] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 9:02:03 965] 0x000000300000-0x000000730000 : "user"
[2024/8/7 9:02:03 966] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 9:02:03 966] PPP generic driver version 2.4.2
[2024/8/7 9:02:03 966] NET: Registered protocol family 24
[2024/8/7 9:02:03 982] usbcore: registered new interface driver asix
[2024/8/7 9:02:03 982] usbcore: registered new interface driver cdc_ether
[2024/8/7 9:02:03 982] usbcore: registered new interface driver rndis_host
[2024/8/7 9:02:03 982] XMMMAC driver:
[2024/8/7 9:02:03 998] 	platform registration... 
[2024/8/7 9:02:03 998] 	done!
[2024/8/7 9:02:03 998] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 9:02:03 998] 	IO base addr: 0xfe010000)
[2024/8/7 9:02:03 998] libphy: XMMMAC MII Bus: probed
[2024/8/7 9:02:04 014] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 9:02:04 014] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 9:02:04 014] usbcore: registered new interface driver cdc_acm
[2024/8/7 9:02:04 030] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 9:02:04 030] usbcore: registered new interface driver usbserial
[2024/8/7 9:02:04 030] usbcore: registered new interface driver option
[2024/8/7 9:02:04 046] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 9:02:04 046] usbcore: registered new interface driver qcserial
[2024/8/7 9:02:04 046] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 9:02:04 046] TCP: cubic registered
[2024/8/7 9:02:04 061] NET: Registered protocol family 17
[2024/8/7 9:02:04 061] Key type dns_resolver registered
[2024/8/7 9:02:04 062] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 9:02:04 062] registered taskstats version 1
[2024/8/7 9:02:04 077] ÿVFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 9:02:04 077] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 9:02:04 429] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 9:02:04 989] arasan_set_clock:
[2024/8/7 9:02:05 005] 	new freq 400000
[2024/8/7 9:02:05 006] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 9:02:05 021] arasan_set_clock:
[2024/8/7 9:02:05 069] 	new freq 300000arasan_set_clock:
[2024/8/7 9:02:05 085] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 9:02:05 101] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 9:02:05 101] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 9:02:05 101] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 9:02:05 101] [reg] = 0x20000078,[val]= 0xc103c0ff
[2024/8/7 9:02:05 101] [regarasan_set_clock:
[2024/8/7 9:02:05 117] 	new freq 195312] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 9:02:05 117] [reg] = 0x20000000,[val]= 0x00000000
[2024/8/7 9:02:05 117] [reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 9:02:05 117] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 9:02:05 133] [reg] = 0x200505f0,[i2c: module license 'Proprietary' taints kernel.
[2024/8/7 9:02:05 133] val]= 0x00000001Disabling lock debugging due to kernel taint
[2024/8/7 9:02:05 133] i2c init is ok!
[2024/8/7 9:02:05 149] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 9:02:05 261] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 9:02:05 342] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 9:02:05 358] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 9:02:05 358] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 9:02:05 406] acodec init is ok!
[2024/8/7 9:02:05 406] i2s clk:2048000Hz
[2024/8/7 9:02:05 550] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 9:02:05 550] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 9:02:05 550] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 9:02:05 566] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 9:02:05 566] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 9:02:05 566] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 9:02:05 582] usb usb1: Product: DWC OTG Controller
[2024/8/7 9:02:05 582] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 9:02:05 582] usb usb1: SerialNumber: dwc2.0
[2024/8/7 9:02:05 598] hub 1-0:1.0: USB hub found
[2024/8/7 9:02:05 598] hub 1-0:1.0: 1 port detected
[2024/8/7 9:02:05 646] xm_wdt init is ok
[2024/8/7 9:02:05 678] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 9:02:05 981] nn_kernel: NN: request mem  fail
[2024/8/7 9:02:05 982] nn_kernel: addr iomap fail
[2024/8/7 9:02:06 046] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 9:02:06 557] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 9:02:06 590] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtd/user.sh: not fusbwifi_init.
[2024/8/7 9:02:06 590] ound
[2024/8/7 9:02:06 605] PDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 9:02:06 621] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 9:02:06 637] exfatfsck 1.3.0
[2024/8/7 9:02:06 654] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:02:06 654] exfatfsck 1.3.0
[2024/8/7 9:02:08 589] ouput high and delay 2000ms
[2024/8/7 9:02:08 685] Auto login as root ...
[2024/8/7 9:02:08 733] (none) login: not found /dev/mmcxxx  
[2024/8/7 9:02:08 733] Tcp server success, Wait connet ...
[2024/8/7 9:02:08 749] macGuarder: Get telnetctrl Fialed, telnetctrl=0
[2024/8/7 9:02:08 765] macGuarder: Close telnetd Forever 
[2024/8/7 9:02:08 765] Get xmauto Fialed ,xmauto = 1
[2024/8/7 9:02:08 765] auto start to app 
[2024/8/7 9:02:09 038] usb 1-1: new high-speed USB device number 4 using dwc2
[2024/8/7 9:02:09 245] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:02:09 261] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:02:09 261] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:02:09 261] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:02:10 637] [atbm_log]:atbm_usb_module_init 0
[2024/8/7 9:02:10 653] [atbm_log]:platform_init(253)
[2024/8/7 9:02:10 653] [atbm_log]:SVN_VER=33341,DPLL_CLOCK=1,BUILD_TIME=[2024-04-03_14:40:53]
[2024/8/7 9:02:10 653] [atbm_log]:Probe called -1 v1
[2024/8/7 9:02:10 668] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[2024/8/7 9:02:10 668] [atbm_log]:CONFIG_TX_NO_CONFIRM
[2024/8/7 9:02:10 669] wiphy_new_nm support CONFIG_WIRELESS_EXT 
[2024/8/7 9:02:10 669] [atbm_log]:Allocated hw_priv @ c270d960
[2024/8/7 9:02:10 685] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[2024/8/7 9:02:10 701] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c270d960)
[2024/8/7 9:02:10 701] [atbm_log]:not support ldpc & ht40!
[2024/8/7 9:02:10 717] [atbm_log]:atbm_get_chiptype, chipver=0x5a, g_wifi_chip_type[14]
[2024/8/7 9:02:10 717] [[atbm_log]:atbm_before_load_firmware++
[2024/8/7 9:02:10 717] [atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[2024/8/7 9:02:10 733] 1970-01-01 00:00[atbm_log]:===================~_~====================
[2024/8/7 9:02:10 733] :07] <json_parse.c> ==> XMJSON_ParseExVb(526)[ERROR]: Get Vb object error!
[2024/8/7 9:02:10 733] [1970-01-01 00:00:07] [atbm_log]:atbm_start_load_firmware++
[2024/8/7 9:02:10 749] <xm_system.c> ==fwhdr->flags 34353678 sram_addr 9022000
[2024/8/7 9:02:10 749] > XMSDK_ParseJso[atbm_log]:
[2024/8/7 9:02:10 749] ======>>> load WIFI BLE COMB firmware <<<======
[2024/8/7 9:02:10 749] n(48)[ERROR]: Pa[atbm_log]:START DOWNLOAD ICCM=========
[2024/8/7 9:02:10 765] rse Vb Failed!atbm_log]:atbm_load_firmware_generic: addr 60000: len 20000
[2024/8/7 9:02:10 765] 0;39m
[2024/8/7 9:02:10 781] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(452)[ERROR]: Get Isp object u32Flag error set value 1!
[2024/8/7 9:02:10 781] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(464)[ERROR]: Get Isp object u32Others error set value 0!
[2024/8/7 9:02:10 797] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(476)[ERROR]: Get Isp object CmosPort error set value 0!
[2024/8/7 9:02:10 813] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(488)[ERROR]: Get Isp object splice_mode error set value 0!
[2024/8/7 9:02:10 813] [1970-01-01 00:00:06] MainApp.c(1802) <main>: build @Jul 31 2024 13:28:12
[2024/8/7 9:02:10 829] [1970-01-01 00:00:06] MainApp.c(1710) <SetLogLevel>: set Sofia log level 2 suceess
[2024/8/7 9:02:10 829] [1970-01-01 00:00:06] ==> XMSDK_SetLogLevel(226)[NOTICE]: set xmsdk log 4
[2024/8/7 9:02:10 845] [1970-01-01 00:00:07] xm_log.c(100) <XM_RegisterLogAndInit>: Register Log level 2
[2024/8/7 9:02:10 845] [1970-01-01 00:00:07] xm_hwinfo.c(162) <XM_HwinfoInit>: Sync hwinfo to Hwfile success!
[2024/8/7 9:02:10 861] Get Hw info: AppId [fvijo8jvloagv1gm], license [uuidcaab27b0a838d239], mac[j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:02:10 861] [1970-01-01 00:00:07] utils.c(974) <ReadJsonConfig>: Have not find pClass [DeviceGpio] pNumber [NetStatusLedGpio]
[2024/8/7 9:02:10 877] [1970-01-01 00:00:07] xm_device.c(226) <ParseDeviceJsonFile>: Get g_NetStatusLed [0] failed
[2024/8/7 9:02:10 877] **********************************************************************
[2024/8/7 9:02:10 893] |                      SYSTEM INFO                                       
[2024/8/7 9:02:10 893] |       product type:		RC50X80
[2024/8/7 9:02:10 893] |           DSP chip:		XM550V200
[2024/8/7 9:02:10 893] |          wifi type:		ATBM6062U
[2024/8/7 9:02:10 909] |             HW mac:		90314ba51650
[2024/8/7 9:02:10 909] |        git version:		a590e8b3
[2024/8/7 9:02:10 909] |          make time:		20240731132812
[2024/8/7 9:02:10 909] **********************************************************************
[2024/8/7 9:02:10 925] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(143)[INFO]: SensorSrcFrmRate = 25
[2024/8/7 9:02:10 925] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(137)[INFO]: SensorIFS = 0
[2024/8/7 9:02:10 941] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(156)[INFO]: Vi CapW 2680, CapH 2160, CapX 0, CapY 0
[2024/8/7 9:02:10 941] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 0: size=[3840, 2160] @3
[2024/8/7 9:02:10 957] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 1: size=[640, 360] @3
[2024/8/7 9:02:10 957] [1970-01-01 00:00:07][atbm_log]:START DOWNLOAD DCCM=========
[2024/8/7 9:02:10 973]  ==> XMJSON_ParseViX(110)[INFO]:[atbm_log]:atbm_load_firmware_generic: addr 800000: len d000
[2024/8/7 9:02:10 974]  ViChn 2: size=[640, 224] @3
[2024/8/7 9:02:10 974] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(406)[INFO]: ISPRsltType
[2024/8/7 9:02:10 989] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(428)[INFO]: ISPRsltType 0
[2024/8/7 9:02:10 989] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(442)[INFO]: ISPRsltType
[2024/8/7 9:02:11 006] [1970-01-01 00:00:07] xm_main.c(345) <AutoMaintenance_pro>: Set device auto mantenance time: -001_-1_-1 02:25:26 wenkday: Tuesday
[2024/8/7 9:02:11 022] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_Parse4gMoudle(500)[WARN]: Get 4GModule object error!
[2024/8/7 9:02:11 022] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(80)[NOTICE]: ISP=> Svtd: PAL
[2024/8/7 9:02:11 039] [1970-01-01 00:00:07] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:02:11 039] [197[atbm_log]:START DOWNLOAD BLE SRAM=========
[2024/8/7 9:02:11 053] 0-01-01 00:00:07] xm_main.c(349)[atbm_log]:atbm_load_firmware_generic: addr 9022000: len 10000
[2024/8/7 9:02:11 053]  <AutoMaintenance_pro>: Get Last AutoMantence Date [] failed
[2024/8/7 9:02:11 070] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(81)[NOTICE]: ISP=>RsltType: 0
[2024/8/7 9:02:11 070] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(84)[NOTICE]: IRCut: gpio 19534 Swap 0
[2024/8/7 9:02:11 085] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(88)[NOTICE]: Infrared: gpio 0 swap 1
[2024/8/7 9:02:11 086] 
[2024/8/7 9:02:11 086] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(92)[NOTICE]: WLight: gpio 11 swap 0
[2024/8/7 9:02:11 101] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(96)[NOTICE]: IRLight: gpio 10 swap 0
[2024/8/7 9:02:11 101] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(99)[NOTICE]: Vi: sensorIFS=0 sensorFPS=25, capW=2680,capH=2160,capX=0,capY=0
[2024/8/7 9:02:11 117] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(100)[NOTICE]: ViChn  ImageSize      vbBlk
[2024/8/7 9:02:11 117] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    0  [3840, 2160]    3
[2024/8/7 9:02:11 133] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    1  [ 640,  360]    2
[2024/8/7 9:02:11 133] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    2  [ 640,  224]    2
[2024/8/7 9:02:11 149] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(107)[NOTICE]: VencChn    MaxSize   PreReleaseVb
[2024/8/7 9:02:11 165] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    0   [3840, 2160]	 false
[2024/8/7 9:02:11 165] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    1   [ 640,  360]	 false
[2024/8/7 9:02:11 165] [19[atbm_log]:atbm_after_load_firmware++
[2024/8/7 9:02:11 181] 70-01-01 00:00:07] ==> XMSDK_Par[atbm_log]:alloc urb work
[2024/8/7 9:02:11 181] seJson(116)[NOTICE]: 4GModule: g[atbm_log]:usb:try to flush rx....
[2024/8/7 9:02:11 181] pio 0 Swap 0
[2024/8/7 9:02:11 197] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: AudioSwap: 0
[2024/8/7 9:02:11 197] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFileDEBUG: [libispapp]:Jul  5 2024 16:14:06 ,GENERAL
[2024/8/7 9:02:11 261] DEBUG: Vstd_init	[ PAL ]
[2024/8/7 9:02:11 277] DEBUG: RsltSns0	[ 8 ]
[2024/8/7 9:02:11 277] DEBUG: Dsp:		[0x0][ CHIPV200 ]
[2024/8/7 9:02:11 277] [atbm_log]:flush rx[-110][0]
[2024/8/7 9:02:11 277] [atbm_log]:0x1610102c=0x4300a
[2024/8/7 9:02:11 277] [atbm_log]:0x1610102c=0x6300b
[2024/8/7 9:02:11 293] [atbm_log]:0x16101000=0x0
[2024/8/7 9:02:11 293] [atbm_log]:set_block_size=256
[2024/8/7 9:02:11 293] [atbm_log]:mdelay wait wsm_startup_done  !!
[2024/8/7 9:02:11 293] [atbm_log]:firmwareCap 31e9
[2024/8/7 9:02:11 293] DEBUG: [l[atbm_log]:firmwareCap2 1b8c
[2024/8/7 9:02:11 309] ibsns]:Jul  5 20
[2024/8/7 9:02:11 309] [atbm_log]:wsm_caps.firmwareCap 1b8c31e9 1624 16:13:32 ,[atbm_log]:apollo wifi WSM init done.
[2024/8/7 9:02:11 309]    Input buffers: 32 x 1632 bytes
[2024/8/7 9:02:11 309]    Hardware: 7.21
[2024/8/7 9:02:11 341]    WSM firmware [=MODEM=DPLL24M+BLE+plat=4 ApSleep 2GHZ Jan 30 2024 10:58:03], ver: 19514, build: 6431, api: 1060, cap: 0x1B8C31E9 Config[31010]  expection 900c094, ep0 cmd addr 901b340 NumOfStations[0x10] NumOfInterfaces[3]
[2024/8/7 9:02:11 341] [atbm_log]:EFUSE(8)				[0]
[2024/8/7 9:02:11 341] [atbm_log]:EFUSE(I)					[0]
[2024/8/7 9:02:11 341] i2c_write timeout 0x2
[2024/8/7 9:02:11 341] GENERAL
[2024/8/7 9:02:11 341] [atbm_log]:EFUSE(B)			[0]
[2024/8/7 9:02:11 357] [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [0]
[2024/8/7 9:02:11 357] [atbm_log]:CAPABILITIES_NVR_IPC              [0]
[2024/8/7 9:02:11 357] [atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[2024/8/7 9:02:11 357] [atbm_log]:CAPABILITIES_WOW                  [0]
[2024/8/7 9:02:11 373] [atbm_log]:CAPABILITIES_NO_BACKOFF           [1]
[2024/8/7 9:02:11 373] [atbm_log]:CAPABILITIES_CFO                  [1]
[2024/8/7 9:02:11 373] [atbm_log]:CAPABILITIES_CHIP_FLAG            [1]
[2024/8/7 9:02:11 373] [atbm_log]:CAPABILITIES_TXCAL                [1]
[2024/8/7 9:02:11 389] [atbm_log]:CAPABILITIES_HIF_TRACE       		[0]
[2024/8/7 9:02:11 389] i2c_write timeout 0x2
[2024/8/7 9:02:11 389] [atbm_log]:CAPABILITIES_FORCE_PM_ACTIVE      [0]
[2024/8/7 9:02:11 389] [atbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[2024/8/7 9:02:11 405] [atbm_log]:CAPABILITIES_ETF                  [1]
[2024/8/7 9:02:11 405] [atbm_log]:CAPABILITIES_BLE		  			[1]
[2024/8/7 9:02:11 405] [atbm_log]:CAPABILITIES_40M			  		[0]
[2024/8/7 9:02:11 405] [atbm_log]:CAPABILITIES_LDPC 		  		[0]
[2024/8/7 9:02:11 421] [atbm_log]:CAPABILITIES_NAV_ENABLE              [0]
[2024/8/7 9:02:11 421] [atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [0]
[2024/8/7 9:02:11 421] [atbm_log]:CAPABILITIES_USE_IPC              [1]
[2024/8/7 9:02:11 421] [atbm_log]:CAPABILITIES_OUTER_PA             [0]
[2024/8/7 9:02:11 437] [atbm_log]:CAPABILITIES_WFA    [0]
[2024/8/7 9:02:11 437] [atbm_log]:CAPABILITIES_EAP_GROUP_REKEY  [0]
[2024/8/7 9:02:11 437] [atbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[2024/8/7 9:02:11 437] [atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[2024/8/7 9:02:11 453] [atbm_log]:CAPABILITIES_RXCAL       [1]
[2024/8/7 9:02:11 453] [atbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[2024/8/7 9:02:11 453] [atbm_log]:CAPABILITIES_80211_TO_8023 [1]
[2024/8/7 9:02:11 453] [atbm_log]:CAPABILITIES_NEW_CHIPER  [1]
[2024/8/7 9:02:11 469] [atbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [0]
[2024/8/7 9:02:11 469] [atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[2024/8/7 9:02:11 469] [atbm_log]:LMAC NOT SUPPORT 40M !!!
[2024/8/7 9:02:11 469] [atbm_log]:LMAC NOT SUPPORT LDPC !!!
[2024/8/7 9:02:11 485] i2c_write timeout 0x2
[2024/8/7 9:02:11 517] i2c_write timeout 0x2
[2024/8/7 9:02:11 533] DEBUG: SC831HAI! Chn:0
[2024/8/7 9:02:11 565] DEBUG: IspNum[1]
[2024/8/7 9:02:11 565] DEBUG: IspChn:[ 0 ]
[2024/8/7 9:02:11 565] DEBUG: I2CChn:[ 0 ]
[2024/8/7 9:02:11 565] DEBUG: limitedUp: no
[2024/8/7 9:02:11 612] DEBUG: -------------SC831Hai 4K 30fps init ok! (20240322)-------------
[2024/8/7 9:02:11 613] DEBUG: camera_set_saved_status OK!
[2024/8/7 9:02:11 613] DEBUG: [libautoscIspKo: clean cut!
[2024/8/7 9:02:11 629] ene]:Jul  5 2024 16:13:42 ,GENERAL
[2024/8/7 9:02:11 629] DEBUG: [libautoscene]:use libfvideo!
[2024/8/7 9:02:11 629] DEBUG: [libfvideo]:Jul  5 2024 15:41:09 
[2024/8/7 9:02:11 629] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:02:11 645] DEBUG: [libsdnc]:Aug 22 2023 13:55:14
[2024/8/7 9:02:11 645] DEBUG: LED: [IR] 
[2024/8/7 9:02:11 645] DEBUG: software LED
[2024/8/7 9:02:11 645] DEBUG: hardware pohtoR!
[2024/8/7 9:02:11 661] DEBUG: isp_sample over!
[2024/8/7 9:02:11 661] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:02:11 661] IspKo: set cut 0x0 0xf00 0x1 0x871
[2024/8/7 9:02:11 661] (656)[INFO]: AudioSwap=[0]
[2024/8/7 9:02:11 677] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: HighAdcValue: 0
[2024/8/7 9:02:11 677] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: LowAdcValue: 0
[2024/8/7 9:02:11 694] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: IRLightLevel: 0
[2024/8/7 9:02:11 695] [1970-01-01 00:00:07] ==> XMJSON_GetInt(5[atbm_log]:wsm_generic_confirm:status(2)
[2024/8/7 9:02:11 695] 70)[INFO]: Infra[atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[2024/8/7 9:02:11 709] redSwap: 0
[2024/8/7 9:02:11 710] [1970-01-01 00:00:07] [atbm_log]:apollo wifi : can't open /data/.mac.info
[2024/8/7 9:02:11 726] ==> XMJSON_GetIn[atbm_log]:efuse data is [0x1,0x38,0x15,0x16,0x16,0x8,0x0,0x0,0x90:0x31:0x4b:0xa5:0x16:0x50]
[2024/8/7 9:02:11 726] t(570)[INFO]: Wh[atbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[2024/8/7 9:02:11 726] [atbm_log]:win txpower:0
[2024/8/7 9:02:11 726]                         [1970-01
[2024/8/7 9:02:11 741] [atbm_log]:use default power
[2024/8/7 9:02:11 741] -01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoHorizontalFlipGun: 0
[2024/8/7 9:02:11 742] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoVerticalFlipGun: 0
[2024/8/7 9:02:11 757] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: setMonocular: 1
[2024/8/7 9:02:11 757] atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[2024/8/7 9:02:11 773] 32m[1970-01-01 0[atbm_log]:==read success==
[2024/8/7 9:02:11 776] 0:00:07] ==> XMJ[atbm_log]:set delta power
[2024/8/7 9:02:11 776] SON_GetInt(570)[INFO]: MotorSpeedX: 17
[2024/8/7 9:02:11 776] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedY: 17
[2024/8/7 9:02:11 789] [1970-01-01 00:00:07] ==> XMJSON_GetInt[atbm_log]:get chip id [0][0][0] 
[2024/8/7 9:02:11 789] (570)[INFO]: sou[atbm_log]:current chiptype ATBM6062-U20-noLDPC 
[2024/8/7 9:02:11 805] ndValue: 50atbm_log]:default country code:00,support channel=14
[2024/8/7 9:02:11 805] 9m
[2024/8/7 9:02:11 805] [1970[atbm_log]:Use an internal power amplifier!
[2024/8/7 9:02:11 805] -01-01 00:00:07] ==> XMJSON_GetInt(570)[[atbm_log]:enable sg
[2024/8/7 9:02:11 821] INFO]: lightChan[atbm_log]:[eth2] has been disabled
[2024/8/7 9:02:11 821] nel: 0
[2024/8/7 9:02:11 821] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: dayAndNightMode: 0
[2024/8/7 9:02:11 837] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: hardAndSoftLight[atbm_log]:enable sg
[2024/8/7 9:02:11 837] : 1
[2024/8/7 9:02:11 837] atbm_log]:[p2p0] has been disabled
[2024/8/7 9:02:11 837] 32m[1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeX: 400
[2024/8/7 9:02:11 853] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeY: 200
[2024/8/7 9:02:11 853] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(587)[INFO]: RatioOfGear: 1:1[atbm_log]:ble start
[2024/8/7 9:02:11 869] [1970-0[atbm_log]:[ALTOBEAM-ble_recv] start
[2024/8/7 9:02:11 869] [atbm_log]:ble subscribe
[2024/8/7 9:02:11 869] [atbm_log]:[ALTOBEAM-ble_xmit] start
[2024/8/7 9:02:11 869] [atbm_log]:ble_platform_probe(c1e148c0)
[2024/8/7 9:02:11 885] [atbm_log]:is registered as 'ALTOBEAM'
[2024/8/7 9:02:11 885] [atbm_log]:[atbm_wtd]:set wtd_probe = 1
[2024/8/7 9:02:11 885] usbcore: registered new interface driver atbm_wlan
[2024/8/7 9:02:11 885] 1-01 00:00:07] ==> XMJSON_GetRatio(593)[INFO]: high 1: low 1
[2024/8/7 9:02:11 901] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(690)[INFO]: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:02:11 917] [1970-01-01 00:00:07] xm_main.c(462) <GetVideoResolution>: Video resolution: captrue width 2680 height 2160 resolution main: width 3840 height 2160 extra:  width 640 height 360 [2]: width 640 height 224
[2024/8/7 9:02:11 933] [1970-01-01 00:00:07] MainApp.c(1812) <main>: version , date 20240724, time 182054, plus 0
[2024/8/7 9:02:11 933] [1970-01-01 00:00:07] ==> XMSDK_StartUp(174)[INFO]: XMSDK_StartUp enter, Jul 24 2024, 18:20:55
[2024/8/7 9:02:11 949] [1970-01-01 00:00:07] ==> IspConfigInit(158)[INFO]: maxHeight 2160 maxWidth 3840 u32RsltType 8
[2024/8/7 9:02:11 965] [1970-01-01 00:00:07] ==> XMSDK_StartUp(203)[INFO]: g_stProductMgr.viMgr.capW =[2680] g_stProductMgr.viMgr.capH = [2160]
[2024/8/7 9:02:11 981] [1970-01-01 00:00:07] ==> XMSDK_StartUp(220)[INFO]: g_stProductMgr.vencMgr.vencChn[0].maxHeight =[2160] g_stProductMgr.encMgr.vencChn[0].maxWidth = [3840]
[2024/8/7 9:02:11 981] [1970-01-01 00:00:07] ==> XMSDK_StartUp(286)[INFO]: ispCfg.u32Others 0x0
[2024/8/7 9:02:12 013] [1970-01-01 00:00:07] ==> XMSDK_StartUp(288)[INFO]: ispCfg.u32FunExt 0x0 u32Infrared 0x80000000 u32snsRsltType 0x0 u32RsltType 0x8 au32IrCut 0x80004c4e  au32SoftLed[0]: 0x800b0a11 u32Flag: 0x1 SensorRstIO: 0x800000a4 u32ComsPort: 0x0
[2024/8/7 9:02:12 013] [1970-01-01 00:00:08] ==> SampleCreate(1709)[INFO]: viChn:0 vstd:0 enter
[2024/8/7 9:02:12 029] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 0 size [3840, 2160]
[2024/8/7 9:02:12 029] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 1 size [640, 360]
[2024/8/7 9:02:12 045] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 2 size [640, 224]
[2024/8/7 9:02:12 045] [1970-01-01 00:00:08] ==> VencChCreate(1058)[INFO]: channel:0 enter
[2024/8/7 9:02:12 061] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[0].vencMem = VENCMEM_MICRO
[2024/8/7 9:02:12 061] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 0,width = 3840,height = 2160,enType = 265
[2024/8/7 9:02:12 061] NORM ENC MODE
[2024/8/7 9:02:12 077] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[1].vencMem = VENCMEM_MICRO
[2024/8/7 9:02:12 077] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 1,width = 640,height = 360,enType = 265
[2024/8/7 9:02:12 093] NORM ENC MODE
[2024/8/7 9:02:12 093] aec 1; agc 1; ans 1
[2024/8/7 9:02:12 093] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 21,DestChnId = 0,DestModId = 23
[2024/8/7 9:02:12 109] [1970-01-01 00:00:08] ==> AudioCreate(1656)[INFO]: XM_AENC_CreateCH OK
[2024/8/7 9:02:12 109] [1970-01-01 00:00:08] ==> AudioCreate(1685)[INFO]: XM_MPI_ADEC_CreateChn OK
[2024/8/7 9:02:12 125] [1970-01-01 00:00:08DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:02:12 125] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:02:12 125] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:02:12 125] DEBUG: software pohtoR!
[2024/8/7 9:02:12 141] DEBUG: camera_set_photosensitive_chn 0 1 0x1
[2024/8/7 9:02:12 141] ] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 24,DestChnId = 0,DestModId = 22
[2024/8/7 9:02:12 157] [1970-01-01 00:00:08] ==> JPEGChCreate(1556)[INFO]: enter JPEGChCreate channel=0, VencChn = 3
[2024/8/7 9:02:12 157] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 3,width = 640,height = 360,enType = 26
[2024/8/7 9:02:12 173] [1970-01-01 00:00:08] ==> COMM_VENC_Start(913)[INFO]: set JpegAttr
[2024/8/7 9:02:12 189] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 1,SrcModId = 7,DestChnId = 3,DestModId = 7
[2024/8/7 9:02:12 190] [1970-01-01 00:00:08] ==> COMM_VENC_Start(1032)[INFO]: JPEG_CHN[3] bind VENC_CHN[1] success!.
[2024/8/7 9:02:12 205] [1970-01-01 00:00:08] MainApp.c(1816) <main>: [1970-01-01 00:00:08] MainApp.c(1823) <main>: [1970-01-01 00:00:08] MainApp.c(1883) <main>: g_fps=[12]
[2024/8/7 9:02:12 221] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=0,brc=1,w=3840,h=2160,qua=4,frame=12,br=1000,gop=4
[2024/8/7 9:02:12 236] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[0],wh[3840,2160]-----------
[2024/8/7 9:02:12 237] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:02:12 252] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=1,brc=1,w=640,h=360,qua=4,frame=9,br=256,gop=1
[2024/8/7 9:02:12 253] 
[2024/8/7 9:02:12 269] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[1],wh[640,360]-----------
[2024/8/7 9:02:12 272] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:02:12 285] [1970-01-01 00:00:08] MainApp.c(1885) <main>: [1970-01-01 00:00:08] MainApp.c(1893) <main>: 
[2024/8/7 9:02:12 285] [1970-01-01 00:00:08] MainApp.c(1898) <main>: 
[2024/8/7 9:02:12 285] [1970-01-01 00:00:08] xm_main.c(1899) <PtzControl_Pro>: 
[2024/8/7 9:02:12 301] PtzControl_Pro[1970-01-01 00:00:08] ==> XMSDK_MotorCreate(120)[INFO]: xlimit 5006, ylimit 2161
[2024/8/7 9:02:12 301] [1970-01-01 00:00:08] xm_main.c(1903) <PtzControl_Pro>: g_sPtz.xMaxStep 5006 g_sPtz.yMaxStep 2161 
[2024/8/7 9:02:12 317] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:02:12 333] [1970-01-01 00:00:08] xm_main.c(700) <XM_SetCameraFactoryConfig>: Get AutoMantence flags [0] failed
[2024/8/7 9:02:12 333] [1970-01-01 00:00:08] xm_main.c(1747) <XM_RealVideo_Pro>: realy video play start___0
[2024/8/7 9:02:12 349] [1970-01-01 00:00:08] xm_main.c(1375) <XM_RealAudio_Pro>: real Audio play start___
[2024/8/7 9:02:12 349] [1970-01-01 00:00:08] ==> AudioInSetFormat(68)[INFO]: pFormat.EncodeTye = 2
[2024/8/7 9:02:12 365] [1970-01-01 00:00:08] ==> XMSDK_AudioInSetFormat(445)[INFO]: anr(1) agc(1) aec(0)
[2024/8/7 9:02:12 365] aec 0; agc 1; ans 1
[2024/8/7 9:02:12 365] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 0
[2024/8/7 9:02:12 381] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 0 OK
[2024/8/7 9:02:12 396] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 1
[2024/8/7 9:02:12 397] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 1 OK
[2024/8/7 9:02:12 413] [1970-01-01 00:00:08] xm_main.c(821) <XM_SetCameraFactoryConfig>: get default language ChineseEnglish
[2024/8/7 9:02:12 413] [1970-01-01 00:00:08] xm_main.c(822) <XM_SetCameraFactoryConfig>: get defult IRcurt reverse: no picture reverse mirror:yes filp:yes
[2024/8/7 9:02:12 429] [1970-01-01 00:00:08] xm_main.c(823) <XM_SetCameraFactoryConfig>: set defult motor ptz reverse  mirror:yes filp:no
[2024/8/7 9:02:12 446] [1970-01-01 00:00:08] xm_main.c(824) <XM_SetCameraFactoryConfig>: get defult autotrack motor reverse mirror:yes filp:no
[2024/8/7 9:02:12 446] [1970-01-01 00:00:08] xm_main.c(825) <XM_SetCameraFactoryConfig>: get defult ptz preset x:1556 y:950
[2024/8/7 9:02:12 461] [1970-01-01 00:00:08] xm_main.c(920) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:02:12 478] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:02:12 478] [1970-01-01 00:00:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[597],val=[1]
[2024/8/7 9:02:12 494] 
[2024/8/7 9:02:12 495] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:02:12 495] [1970-01-01 00:00:08DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:02:12 509] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:02:12 509] DEBUG: camera_set_photosensitive_chn 0 0 0x1
[2024/8/7 9:02:12 509] killall: hostapd: no process killed
[2024/8/7 9:02:12 525] ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM![atbm_log]:ioctl_open(c2c83700)(c1e148c0)
[2024/8/7 9:02:12 525] [atbm_log]:atbm_ioctl_ble_start
[2024/8/7 9:02:12 556] DEBUG: camera_set_ledType:  2
[2024/8/7 9:02:12 572] DEBUG: camera_set_dnc_mode_chn 3 
[2024/8/7 9:02:12 572] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:02:12 572] DEBUG: LED: [IR] [WL] 
[2024/8/7 9:02:12 572] DEBUG: software LED
[2024/8/7 9:02:12 588] DEBUG: software pohtoR!
[2024/8/7 9:02:12 588] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:02:12 588] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:02:12 588] DEBUG: camera_set_ledHold: 60000
[2024/8/7 9:02:12 605] ] xm_main.c(969) <XM_SetCameraFactoryConfig>: get factory language ChineseEnglish
[2024/8/7 9:02:12 621] [1970-01-01 00:00:08] xm_main.c(970) <XM_SetCameraFactoryConfig>: get factory IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:02:12 637] [1970-01-01 00:00:08] xm_main.c(971) <XM_SetCameraFactoryConfig>: set factory motor ptz reverse  mirror:yes filp:yes
[2024/8/7 9:02:12 637] [1970-01-01 00:00:08] xm_main.c(972) <XM_SetCameraFactoryConfig>: get factory autotrack motor reverse mirror:no filp:no
[2024/8/7 9:02:12 653] [1970-01-01 00:00:08] xm_main.c(973) <XM_SetCameraFactoryConfig>: get factory ptz preset x:3110 y:0
[2024/8/7 9:02:12 669] [1970-01-01 00:00:08] xm_main.c(1007) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:02:12 685] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:02:12 685] [1970-01-01 00:00:08] xm_main.c(1040) <XM_SetCameraFactoryConfig>: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:02:12 701] [1970-01-01 00:00:08] xm_main.c(1060) <XM_SetCameraFactoryConfig>: set IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:02:12 717] [1970-01-01 00:00:08] xm_main.c(1078) <XM_SetCameraFactoryConfig>: camera_set_softIr_thr(1) ret=[0]
[2024/8/7 9:02:12 717] ************last intra 0
[2024/8/7 9:02:12 717] [1970-01-01 00:00:08] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time8397
[2024/8/7 9:02:12 733] [1970-01-01 00:00:08] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 105184
[2024/8/7 9:02:12 733] [1970-01-01 00:00:08] MainApp.c(1900) <main>: 
[2024/8/7 9:02:12 749] [1970-01-01 00:00:08] MainApp.c(1905) <main>: 
[2024/8/7 9:02:12 749] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:Register pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:02:12 765] [1970-01-01 00:00:08] ==> XMSDK_AudioSetSpeakerVol(641)[INFO]: enter: Speaker Open
[2024/8/7 9:02:12 765] [1970-01-01 00:00:08] MainApp.c(1913) <main>: 
[2024/8/7 9:02:12 781] [1970-01-01 00:00:08] ==> XMSDK_WifiInit(601)[INFO]: Wifi Init success
[2024/8/7 9:02:12 781] [1970-01-01 00:00:08] MainApp.c(1915) <main>: 
[2024/8/7 9:02:12 781] [1970-01-01 00:00:08] MainApp.c(1918) <main>: 
[2024/8/7 9:02:12 781] lib_ble_main_init
[2024/8/7 9:02:12 797] ======>>atbm_ble_start>>>
[2024/8/7 9:02:12 797] nimble_port_init++
[2024/8/7 9:02:12 797] nimble_host_task
[2024/8/7 9:02:12 797] ble_coexist_start--
[2024/8/7 9:02:12 797] hif_ioctl_loop
[2024/8/7 9:02:12 797] ble_hs_sync:333
[2024/8/7 9:02:12 797] ble_smart_cfg_startup!11
[2024/8/7 9:02:12 797] [ATBM lOG]set default tx power(0)
[2024/8/7 9:02:12 813] pub addr 90:31:4b:a5:16:51
[2024/8/7 9:02:12 814] [1970-01-01 00:00:09] MainApp.c(1922) <main>: ble_ret=[0]
[2024/8/7 9:02:12 814] [1970-01-01 00:00:09] MainApp.c(1200) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 829] [1970-01-01 00:00:09] MainApp.c(1229) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 829] [1970-01-01 00:00:09] MainApp.c(1258) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 845] [1970-01-01 00:00:09] MainApp.c(1260) <GetAndSetTyDefalutConfig>: SMLMode=[2]
[2024/8/7 9:02:12 845] [1970-01-01 00:00:09] MainApp.c(1263) <GetAndSetTyDefalutConfig>: g_SMLAbility=[0]
[2024/8/7 9:02:12 861] [1970-01-01 00:00:09] MainApp.c(1266) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 862] [1970-01-01 00:00:09] MainApp.c(1338) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 862] [1970-01-01 00:00:09] MainApp.c(1346) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 877] [1970-01-01 00:00:09] MainApp.c(1357) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 877] [1970-01-01 00:00:09] MainApp.c(1387) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 893] [1970-01-01 00:00:09] MainApp.c(1390) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:12 893] [1970-01-01 00:00:09] xm_ai.c(564) <XM_CreatePersionDetect>: 
[2024/8/7 9:02:12 893] [1970-01-01 00:00:09] xm_ai.c(574) <XM_CreatePersionDetect>: 
[2024/8/7 9:02:12 909] [1970-01-01 00:00:09] xm_ai.c(585) <XM_CreatePersionDetect>: 
[2024/8/7 9:02:12 909] [1970-01-01 00:00:09] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:02:12 925] [1970-01-01 00:00:09] xm_ai.c(588) <XM_CreatePersionDetect>: 
[2024/8/7 9:02:12 925] [1970-01-01 00:00:09] xm_ai.c(608) <XM_CreatePersionDetect>: 
[2024/8/7 9:02:12 941] [1970-01-01 00:00:09] xm_ai.c(645) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:02:13 021] [1970-01-01 00:00:09] xm_ai.c(646) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:09] xm_ai.c(647) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTime = [8];src/ped_thread.c(746) [Smart_Ped_CreateERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!ListMng - BufListCreate: index 1 OK
[2024/8/7 9:02:13 756] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:02:13 772] Mode(Product):0
[2024/8/7 9:02:13 772] BpuMode:[Online]
[2024/8/7 9:02:13 772] VpssMode:[Online]
[2024/8/7 9:02:13 772] [0.LimitUp_info]:
[2024/8/7 9:02:13 772] LimitUp:[Disable]
[2024/8/7 9:02:13 773] [2680*0]->[3840*0])
[2024/8/7 9:02:13 773] chn	TotalSize	ActiveSize
[2024/8/7 9:02:13 773] 0	5040*2246	2680*2160
[2024/8/7 9:02:13 788] 0	5046*2246	3840*2160
[2024/8/7 9:02:13 788] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:02:13 788] [1.VICU_info]:
[2024/8/7 9:02:13 788] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:02:13 788] 0	25.0	54	0	0	183	linear	8ddb00
[2024/8/7 9:02:13 788] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:02:13 804] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:02:13 804] en	op_type	m_chn	now
[2024/8/7 9:02:13 804] 0	1	1	1
[2024/8/7 9:02:13 804] [2.VI_info]:
[2024/8/7 9:02:13 804] chn	TotalSize	ActiveSize
[2024/8/7 9:02:13 804] 0	5034*2246	3848*2166
[2024/8/7 9:02:13 804] 1	   0*   0	   0*   0
[2024/8/7 9:02:13 804] [3.MIPI_info]:
[2024/8/7 9:02:13 820] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:02:13 820] 0x2b	6472*2166	3848*2166		5046*2166	3848*2166	   0
[2024/8/7 9:02:13 820] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:02:13 820] [4.Cut_info]:
[2024/8/7 9:02:13 820] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:02:13 836] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:02:13 836] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:02:13 836] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:02:13 836] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:02:13 836] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:02:13 852] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:02:13 852] [5.IB(isp buffer info)]:
[2024/8/7 9:02:13 852] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:02:13 852] PoolId  Count  Size
[2024/8/7 9:02:13 869] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:13 869] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:13 885] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:13 885] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:13 885] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:13 901] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:13 901] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:02:13 901] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:02:13 917] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:02:13 917] 0       0         0          1          4       
[2024/8/7 9:02:13 917] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:02:13 933]      --265--            --264--                                               
[2024/8/7 9:02:13 933] Count      Line     Count      Line     
[2024/8/7 9:02:13 933] 37         480      82         560      
[2024/8/7 9:02:13 949] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:02:13 949] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:02:13 965] 0   3840   2160    H265  0      0        0           20        983035     5        	
[2024/8/7 9:02:13 965] 1   640    360     H265  0      0        0           16        43195      5        	
[2024/8/7 9:02:13 981] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:02:13 981] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:02:13 997] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:02:14 013] 0   Y      20       0       0       15       0        20       20       33        64557         61544    88527    65959    0       
[2024/8/7 9:02:14 014] 1   Y      16       0       0       1        0        16       16       33        2555          1939     29187    5425     0       
[2024/8/7 9:02:14 029] 3   N      0        0       0       1        0        0        0        35        0             0        0        0        0       
[2024/8/7 9:02:14 125] ]: Smart_Ped_Create_ver: Jul 24 2024 18:21:40
[2024/8/7 9:02:14 140] src/ped_thread.c(656) [Ped_Init_IA_Work]: Ped_Init_IA_Work start ver:Jul 24 2024 18:21:40
[2024/8/7 9:02:14 141] [FUNC: IA_InitLog] Creat OK.
[2024/8/7 9:02:14 141] [INIT]: XM_IA_Init() done.
[2024/8/7 9:02:14 157] src/ped_thread.c(705) [Ped_Init_IA_Work]: ruler 0 region (0,0) (0,0) (0,0) (0,0)
[2024/8/7 9:02:14 157] [INIT]:LIBXMIA IAtype 700 Complied at May  8 2024 08:39:39 GIT_ID:cb3a4ed0
[2024/8/7 9:02:14 157] [INIT]: TD Version: TD_V_3.2.4.2[May 15 2024 19:14:32]
[2024/8/7 9:02:14 157] -- TD INIT -- 
[2024/8/7 9:02:14 172]  uiTdMaxNum: 12 
[2024/8/7 9:02:14 172]  acClassBinPath: /usr/bin 
[2024/8/7 9:02:14 172]  ePlatForm: 50 
[2024/8/7 9:02:14 173]  eDevImgType: 17 
[2024/8/7 9:02:14 173]  stDevImgSize: (2680,2160) 
[2024/8/7 9:02:14 173]  iTrackFlag: 1 
[2024/8/7 9:02:14 173]  iTrackType: 2 
[2024/8/7 9:02:14 173] -- TD EXTF -- 
[2024/8/7 9:02:14 173]  ucPedFallDownEnable: 0
[2024/8/7 9:02:14 188]  ucTDFeatureEnable: 0
[2024/8/7 9:02:14 188]  ucSmokeEnable: 0
[2024/8/7 9:02:14 188]  ucFaceDetEnable: 0
[2024/8/7 9:02:14 188]  ucFaceMaskEnable: 0
[2024/8/7 9:02:14 188]  ucFaceAngEnable: 0
[2024/8/7 9:02:14 188]  ucFaceRegEnable: 0
[2024/8/7 9:02:14 188]  ucPlateDetEnable: 0
[2024/8/7 9:02:14 188]  ucPlateRegEnable: 0
[2024/8/7 9:02:14 204]  ucPedPointEnable: 0
[2024/8/7 9:02:14 204]  ucHandPointEnable: 0
[2024/8/7 9:02:14 204]  ucHelmetEnable: 0
[2024/8/7 9:02:14 204]  ucHandgestureEnable: 0
[2024/8/7 9:02:14 204]  efdfreq: 10
[2024/8/7 9:02:14 204] [INIT]: XM_IA_TD_PED_S Version: 20230719_person_noexp_v200
[2024/8/7 9:02:14 204] [INIT] Alg Malloc Size 27232
[2024/8/7 9:02:14 220] -- TD CFG --  
[2024/8/7 9:02:14 220]  iMDFlag: 0
[2024/8/7 9:02:14 220]  ucDetectDisable: 0
[2024/8/7 9:02:14 220]  iDetectType: 5
[2024/8/7 9:02:14 220]  ePattern: 3
[2024/8/7 9:02:14 220]  eSensitivity: 2
[2024/8/7 9:02:14 220]  ucFishEyeCorrectFlag:0
[2024/8/7 9:02:14 221]  eRotate:0
[2024/8/7 9:02:14 221]  ucSationaryTd: 0
[2024/8/7 9:02:14 221]  ucClearnessFlg:0
[2024/8/7 9:02:14 221]  usInImgWidth:0
[2024/8/7 9:02:14 236]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:02:14 236] [CFG]: Rule:0 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:02:14 236] [CFG]: Rule:1 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:02:14 252] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:02:14 252] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:02:14 252] [CFG]: DEFAULT iBoundaryPtsNum 4 eAlarmDirect 2 (0 0) (8191 0) (8191 8191) (0 8191)
[2024/8/7 9:02:14 269] [FUNC:PbdcnnConfig][L:578] (nil) 0xbefb72f8 Pointer Null.
[2024/8/7 9:02:14 269] [INIT]: PdConfig pvHandle 0xb11aa000. Config OK
[2024/8/7 9:02:14 269] [INIT] Alg Malloc Size 30000
[2024/8/7 9:02:14 269] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:02:14 286] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:02:14 286] [INIT]:memPoolSize 1351680.
[2024/8/7 9:02:14 286] V1.6.x date Sep  5 2023, time 23:32:25 npu load start
[2024/8/7 9:02:14 286] dpu version v1.1.0 build time Aug  5 2022
[2024/8/7 9:02:14 301] [INIT]: Update MemPoolSize 0 to 1351680.
[2024/8/7 9:02:14 301] [INIT]: MmzAlloc MemPoolSize 1351680 0xb0fe8000~0xb1132000.
[2024/8/7 9:02:14 301] 0 Model 0x18a4104 MemPoolIdx 0 MemPoolInfo 0x6d5f10
[2024/8/7 9:02:14 317] [INIT]: version 20230719_person_noexp_v200, debug 0, profile 0
[2024/8/7 9:02:14 317] [INIT] Alg Malloc Size 240736
[2024/8/7 9:02:14 317] CNNMemory: 2064977 bulk 240736 mmz 1824241
[2024/8/7 9:02:14 317] CNNINIT INPUT IMAGESIZE:(640,224)
[2024/8/7 9:02:14 333] TD_DETECT stAlgImgSize (640,224) 
[2024/8/7 9:02:14 334] [INIT] Alg Malloc Size 60672
[2024/8/7 9:02:14 334] MdInit ok![INIT] Alg Malloc Size 79704
[2024/8/7 9:02:14 334] [FUNC: trackInit][L: 273] API_Creat_IMG 
[2024/8/7 9:02:14 334] [INIT]: PdInit pvHandle 0x1897ff0 *pvHandle 0xb11aa000 OK
[2024/8/7 9:02:14 349] IA_LOG 87c6a000 value 0
[2024/8/7 9:02:14 349] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:02:14 349] Ped_Init_IA_Work end 
[2024/8/7 9:02:14 349] src/ped_thread.c(774) [Smart_Ped_Create]: Create list success, index 1 maxsize 2
[2024/8/7 9:02:14 365] src/ped_thread.c(495) [PedProc_v2]: 
[2024/8/7 9:02:14 365] src/ped_thread.c(520) [PedProc_v2]: 
[2024/8/7 9:02:14 365] [FUNC: DetectTarget][L: 1489] API_Creat_IMG_MdInImg 
[2024/8/7 9:02:14 365] [FUNC: PbdcnnWork][L: 1084] API_Creat_CSCIMG 
[2024/8/7 9:02:14 381] [1970-01-01 00:00:10] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:14 381] [1970-01-01 00:00:10] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:14 397] src/ped_thread.c(803) [Smart_Ped_Create]: Ped_Creat Success @0x39e24
[2024/8/7 9:02:14 413] [1970-01-01 00:00:10] xm_ai.c(649) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:02:14 429] [1970-01-01 00:00:10] xm_ai.c(657) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:10] xm_ai.c(658) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTime = [8];-- TD CFG --  
[2024/8/7 9:02:14 430]  iMDFlag: 0
[2024/8/7 9:02:14 430]  ucDetectDisable: 0
[2024/8/7 9:02:14 430]  iDetectType: 5
[2024/8/7 9:02:14 430]  ePattern: 3
[2024/8/7 9:02:14 444]  eSensitivity: 0
[2024/8/7 9:02:14 444]  ucFishEyeCorrectFlag:0
[2024/8/7 9:02:14 444]  eRotate:0
[2024/8/7 9:02:14 445]  ucSationaryTd: 0
[2024/8/7 9:02:14 445]  ucClearnessFlg:0
[2024/8/7 9:02:14 445]  usInImgWidth:0
[2024/8/7 9:02:14 445]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:02:14 460] [CFG]: Rule:0 ucRuleEnable:1 AlarmType:0 eRuleType:1
[2024/8/7 9:02:14 461] [CFG]: IA_PERIMETER_V1 iBoundaryPtsNum 4 eAlarmDirect 0 (0 0) (8191 0) (8191 8191) (0 8191) [CFG]: Rule:1 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:02:14 476] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:02:14 476] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:02:14 476] [INIT]: PdConfig pvHandle 0xb11aa000. Config OK
[2024/8/7 9:02:14 477] IA_LOG 87c6a000 value 0
[2024/8/7 9:02:14 477] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:02:14 493] src/ped_thread.c(831) [Smart_Ped_SetParam[MMZ] BUILD TIME:[Jul 14 2021 15:42:31]
[2024/8/7 9:02:14 493] [0x83400000--------0x88000000]
[2024/8/7 9:02:14 509] --START-----------SIZE----------------OVERFLOW----NAME---------------
[2024/8/7 9:02:14 509] 0x83400000	0xbde000  (12152k)	0	vb[bdd800][0]
[2024/8/7 9:02:14 509] 0x83fde000	0xbde000  (12152k)	0	vb[bdd800][1]
[2024/8/7 9:02:14 509] 0x84bbc000	0xbde000  (12152k)	0	vb[bdd800][2]
[2024/8/7 9:02:14 525] 0x8579a000	0x55000   (  340k)	0	vb[54600][0]
[2024/8/7 9:02:14 525] 0x857ef000	0x55000   (  340k)	0	vb[54600][1]
[2024/8/7 9:02:14 525] 0x85844000	0x35000   (  212k)	0	vb[34800][0]
[2024/8/7 9:02:14 525] 0x85879000	0x35000   (  212k)	0	vb[34800][1]
[2024/8/7 9:02:14 542] 0x858ae000	0x24000   (  144k)	0	isp_nr_alpha_ch0
[2024/8/7 9:02:14 542] 0x858d2000	0x163000  ( 1420k)	0	isp_nr_idx_ch0
[2024/8/7 9:02:14 542] 0x85a35000	0x1000    (    4k)	0	isp_nr_idx_max_ch0
[2024/8/7 9:02:14 542] 0x85a36000	0x84f000  ( 8508k)	0	isp_nr_fetch_ch0
[2024/8/7 9:02:14 557] 0x86285000	0x2000    (    8k)	0	isp_defog_ch0
[2024/8/7 9:02:14 557] 0x86287000	0xc24000  (12432k)	0	vencRfcFrame[0]
[2024/8/7 9:02:14 557] 0x86eab000	0xc24000  (12432k)	0	vencRfcFrame[1]
[2024/8/7 9:02:14 557] 0x87acf000	0xf1000   (  964k)	0	stream_chn[0]
[2024/8/7 9:02:14 574] 0x87bc0000	0x4c000   (  304k)	0	vencWrapLuma[0]
[2024/8/7 9:02:14 574] 0x87c0c000	0x26000   (  152k)	0	vencWrapChroma[0]
[2024/8/7 9:02:14 574] 0x87c32000	0xb000    (   44k)	0	stream_chn[1]
[2024/8/7 9:02:14 574] 0x87c3d000	0x2b000   (  172k)	0	stream_chn[3]
[2024/8/7 9:02:14 589] 0x87c68000	0x1000    (    4k)	0	osd_block[0]
[2024/8/7 9:02:14 589] 0x87c69000	0x1000    (    4k)	0	osd_block[4]
[2024/8/7 9:02:14 589] 0x87c6a000	0x1000    (    4k)	0	IA_LOG
[2024/8/7 9:02:14 589] 0x87c6b000	0x7000    (   28k)	0	IA_MANAGE_1
[2024/8/7 9:02:14 605] 0x87c72000	0x8000    (   32k)	0	IA_MANAGE_2
[2024/8/7 9:02:14 605] 0x87c7a000	0x70000   (  448k)	0	firm_mem_0
[2024/8/7 9:02:14 605] 0x87cea000	0x14b000  ( 1324k)	0	mempool_1
[2024/8/7 9:02:14 605] 0x87e35000	0x1000    (    4k)	0	dst_mem_1
[2024/8/7 9:02:14 621] 0x87e36000	0x1000    (    4k)	0	dst_mem_2
[2024/8/7 9:02:14 621] 0x87e37000	0x3000    (   12k)	0	dst_mem_3
[2024/8/7 9:02:14 621] 0x87e3a000	0x1000    (    4k)	0	dst_mem_4
[2024/8/7 9:02:14 621] 0x87e3b000	0x14000   (   80k)	0	IA_MANAGE_3
[2024/8/7 9:02:14 637] 0x87e4f000	0x35000   (  212k)	0	IA_Image_1
[2024/8/7 9:02:14 637] 0x87e84000	0x6a000   (  424k)	0	IA_Image_2
[2024/8/7 9:02:14 637] 0x87eee000	0x112000  ( 1096k)	1	
[2024/8/7 9:02:14 637] ---------------------------------------------------------------------
[2024/8/7 9:02:14 653] SIZE: 0x4c00000(77824k)  USED: 0x4aee000(76728k)  FREE: 0x112000(1096k)
[2024/8/7 9:02:14 653] ]: Ped_SetParam Success
[2024/8/7 9:02:14 653] [1970-01-01 00:00:10] xm_ai.c(666) <XM_CreatePersionDetect>: 
[2024/8/7 9:02:14 669] [1970-01-01 00:00:10] xm_ai.c(674) <XM_CreatePersionDetect>: 
[2024/8/7 9:02:14 669] [1970-01-01 00:00:10] MainApp.c(1395) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:14 685] [1970-01-01 00:00:10] MainApp.c(1397) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:14 685] [1970-01-01 00:00:10] MainApp.c(1402) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:14 685] [1970-01-01 00:00:10] MainApp.c(1481) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:14 701] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 60 enable 0 volume
[2024/8/7 9:02:14 701] [1970-01-01 00:00:10] MainApp.c(1525) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:14 701]  PTZPreset is empty!
[2024/8/7 9:02:14 717]  PTZPreset is empty!
[2024/8/7 9:02:14 717] [1970-01-01 00:00:10] MainApp.c(1554) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:14 733] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:02:14 733] [1970-01-01 00:00:10] MainApp.c(1568) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:14 749] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:02:14 765] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:02:14 765] [1970-01-01 00:00:10] MainApp.c(1584) <GetAndSetTyDefalutConfig>: cruisetime_pro create!
[2024/8/7 9:02:14 781] [1970-01-01 00:00:10] MainApp.c(1607) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:02:14 781] [1970-01-01 00:00:10] MainApp.c(1925) <main>: 
[2024/8/7 9:02:14 797] [1970-01-01 00:00:10] MainApp.c(1116) <GetRegisterMode>: -------- register mode 1
[2024/8/7 9:02:14 797] [1970-01-01 00:00:10] MainApp.c(1927) <main>: 
[2024/8/7 9:02:14 797] [1970-01-01 00:00:10] MainApp.c(1930) <main>: 
[2024/8/7 9:02:14 797] *************
[2024/8/7 9:02:14 797]  0x6d123c 
[2024/8/7 9:02:14 812] *****************
[2024/8/7 9:02:14 812]  0x3287c 
[2024/8/7 9:02:14 812] beginend[1970-01-01 00:00:10] MainApp.c(1938) <main>: 
[2024/8/7 9:02:14 813] [1970-01-01 00:00:10] MainApp.c(866) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:02:14 828] [1970-01-01 00:00:10] MainApp.c(174) <GetDeviceHWInfo>: Get Hwinfo APP_ID [fvijo8jvloagv1gm], UUID[uuidcaab27b0a838d239] AUTHKEY [j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:02:14 845] [1970-01-01 00:00:10] MainApp.c(909) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:02:14 845] [1970-01-01 00:00:10] MainApp.c(942) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:02:14 861] [1970-01-01 00:00:10] MainApp.c(986) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:02:14 861] [1970-01-01 00:00:10] MainApp.c(1019) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:02:14 861] sdk start
[2024/8/7 9:02:14 877] [1970-01-01 00:00:10] MainApp.c(752) <tuya_ipc_sdk_start>: log_level 0[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/mtd/Config/ty/ 
[2024/8/7 9:02:14 877] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/mtd/Config/ty/
[2024/8/7 9:02:14 893] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/mtd/Config/ty/
[2024/8/7 9:02:14 893] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[2024/8/7 9:02:14 909] [01-01 18:12:15 TUYA D][simplekv.c:989] both file not exist /mnt/mtd/Config/ty/tuya_user.db
[2024/8/7 9:02:14 909] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[2024/8/7 9:02:14 909] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[2024/8/7 9:02:14 925] [01-01 18:12:15 TUYA D][simplekv.c:1083] init NEW normal file
[2024/8/7 9:02:14 925] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 3536627844
[2024/8/7 9:02:14 941] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:14 941] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[2024/8/7 9:02:14 957] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[2024/8/7 9:02:14 957] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[2024/8/7 9:02:14 973] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[2024/8/7 9:02:14 973] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[2024/8/7 9:02:14 973] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[2024/8/7 9:02:14 989] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[2024/8/7 9:02:14 989] [01-01 18:12:15 TUYA E][log_seq.c:863] open err
[2024/8/7 9:02:15 005] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[2024/8/7 9:02:15 005] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[2024/8/7 9:02:15 021] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[2024/8/7 9:02:15 022] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 022] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:15 038] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:15 038] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:15 038] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:02:15 053] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:02:15 053] [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
[2024/8/7 9:02:15 069] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[2024/8/7 9:02:15 069] [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:02:15 069] dev id key: 16
[2024/8/7 9:02:15 069] d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[2024/8/7 9:02:15 085] --- tracepoint bt_ext_porting.c,tuya_ext_bt_port_init(464): tuya_ext_bt_port_init ---
[2024/8/7 9:02:15 085] [01-01 18:12:15 TUYA I][bt_ext_porting.c:466] [TUYA-BTUART]tuya ext bt port init
[2024/8/7 9:02:15 101] --- tracepoint bt_uart_drv.c,tuya_bt_uart_open(187): tuya_bt_uart_open ---
[2024/8/7 9:02:15 101] --- tracepoint bt_uart_drv.c,tuya_bt_uart_init(60): tuya_bt_uart_init  0 ---
[2024/8/7 9:02:15 101] --- tracepoint bt_ext_porting.c,ty_btext_thread(370):  ---
[2024/8/7 9:02:15 117] [01-01 18:12:15 TUYA I][bt_ext_porting.c:485] [TUYA-BTUART]thread ty_btext_thread create cplt mode 1
[2024/8/7 9:02:15 117] [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[2024/8/7 9:02:15 133] [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[2024/8/7 9:02:15 133] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish
[2024/8/7 9:02:15 149] [1970-01-01 00:00:11] MainApp.c(822) <tuya_ipc_sdk_start>: create ring buffer start 
[2024/8/7 9:02:15 149] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:0 Enable:1
[2024/8/7 9:02:15 149] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 2048, video_fps 12
[2024/8/7 9:02:15 165] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr0 bitrate:2048 fps:12
[2024/8/7 9:02:15 181] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 2621440 bytes for ch0st0tr0, max frame size 393216
[2024/8/7 9:02:15 181] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr0 size:2621440 nodes:120
[2024/8/7 9:02:15 197] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:0
[2024/8/7 9:02:15 197] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:1 Enable:1
[2024/8/7 9:02:15 213] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 1024, video_fps 12
[2024/8/7 9:02:15 214] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr1 bitrate:1024 fps:12
[2024/8/7 9:02:15 229] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1310720 bytes for ch0st0tr1, max frame size 196608
[2024/8/7 9:02:15 229] [01-01 18:12:15 TUYA I][tuya_ri[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:02:15 245] ng_buffer.c:591] Init Ring Buffer success: ch0st0tr1 size:1310720 nodes:120
[2024/8/7 9:02:15 245] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:1
[2024/8/7 9:02:15 245] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:2 Enable:0
[2024/8/7 9:02:15 260] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:3 Enable:0
[2024/8/7 9:02:15 260] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:4 Enable:0
[2024/8/7 9:02:15 276] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:5 Enable:0
[2024/8/7 9:02:15 276] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:6 Enable:0
[2024/8/7 9:02:15 276] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:7 Enable:0
[2024/8/7 9:02:15 293] [01-01 18:12:15 TUYA D][atbm_log]:eth2:free authen bss ++
[2024/8/7 9:02:15 293] [MainApp.c:430] init ring buffer Channel:8 Enable:0
[2024/8/7 9:02:15 293] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:9 Enable:1
[2024/8/7 9:02:15 309] [01-01 18:12:15 TUYA D][MainApp.c:439] audio_sample 8000, audio_databits 16, audio_fps 25
[2024/8/7 9:02:15 326] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[2024/8/7 9:02:15 329] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[2024/8/7 9:02:15 341] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[2024/8/7 9:02:15 341] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:9
[2024/8/7 9:02:15 357] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:10 Enable:0
[2024/8/7 9:02:15 357] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:11 Enable:0
[2024/8/7 9:02:15 357] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:12 Enable:0
[2024/8/7 9:02:15 373] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:13 Enable:0
[2024/8/7 9:02:15 373] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:14 Enable:0
[2024/8/7 9:02:15 389] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:15 Enable:0
[2024/8/7 9:02:15 405] [1970-01-01 00:00:11] MainApp.c(830) <tuya_ipc_sdk_start>: pRunInfo->net_info.connect_mode 1[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 405] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:15 405] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:15 421] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:15 421] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:02:15 421] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:02:15 453] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":null,"auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:02:15 453] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 469] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:15 469] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:15 469] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:15 485] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:208
[2024/8/7 9:02:15 485] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 0 startpos:28700 size:276
[2024/8/7 9:02:15 501] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:15 501] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 1056267009
[2024/8/7 9:02:15 501] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:15 517] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:15 518] [01-01 18:12:15 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:02:15 533] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":0,"ssid":null,"passwd":null,"md":0,"random":0,"wf[atbm_log]:[eth2] change to [3]
[2024/8/7 9:02:15 533] b64":1,"stat":0,[atbm_log]:[eth2] has been disabled
[2024/8/7 9:02:15 534] "token":null,"re[atbm_log]:add iftype(6),if_cnt(2),flags(c1ef1bf8)
[2024/8/7 9:02:15 549] gion":null,"reg_key":nul[atbm_log]:enable sg
[2024/8/7 9:02:15 549] l,"dns_prio":0 }[atbm_log]:[mon.eth2] has been disabled
[2024/8/7 9:02:15 549] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 565] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:15 565] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:15 581] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:15 581] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:02:15 581] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 1 startpos:28976 size:212
[2024/8/7 9:02:15 597] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:15 597] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2367317337
[2024/8/7 9:02:15 613] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:15 613] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:15 613] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:02:15 629] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[2024/8/7 9:02:15 629] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1776] Last reset reason: 255
[2024/8/7 9:02:15 629] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 644] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:02:15 644] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:02:15 661] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:02:15 661] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 661] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:15 676] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:15 676] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:15 676] [01-01 18:12:15 TU[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:02:15 693] YA D][tuya_tls.c[atbm_log]:[WSM] Drop frame
[2024/8/7 9:02:15 693] :315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:15 693] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:02:15 709] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1140] serial_no:90314ba51650
[2024/8/7 9:02:15 709] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 709] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:02:15 725] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:02:15 725] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[2024/8/7 9:02:15 741] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1171] gw_cntl.gw_wsm.stat:0
[2024/8/7 9:02:15 741] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1347] gw_cntl->gw_wsm.nc_tp:0
[2024/8/7 9:02:15 741] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1348] gw_cntl->gw_wsm.md:0
[2024/8/7 9:02:15 757] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1362] wifi config method not fit
[2024/8/7 9:02:15 757] [01-01 18:12:15 TUYA E][tuya_devos_entry.c:1787] ret:-2
[2024/8/7 9:02:15 757] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1808] enter reset factory
[2024/8/7 9:02:15 773] [01-01 18:12:[atbm_log]:[eth2] start driver he ap
[2024/8/7 9:02:15 773] 15 TUYA D][simpl[atbm_log]:BSS_CHANGED_BEACON
[2024/8/7 9:02:15 773] ekv.c:1211] read[atbm_log]:change ds_params channel 6 
[2024/8/7 9:02:15 773]  key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 789] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:15 789] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:15 805] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:15 805] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_di -6
[2024/8/7 9:02:15 805] [01-01 18:12:15 TUYA E][ws_db_gw.c:494] gw_di read fail:-6
[2024/8/7 9:02:15 821] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 821] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:15 821] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:15 837] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:15 837] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_di And Value Len:400
[2024/8/7 9:02:15 853] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 2 startpos:29188 size:468
[2024/8/7 9:02:15 853] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:15 853] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 876692212
[2024/8/7 9:02:15 869] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:15 869] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:15 869] [01-01 18:12:15 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:02:15 885] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:593] nc_tp:2, wifi_start_mode:0
[2024/8/7 9:02:15 885] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 901] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:15 901] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:15 901] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:15 917] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:wf_start_md And Value Len:16
[2024/8/7 9:02:15 917] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 3 startpos:29656 size:84
[2024/8/7 9:02:15 933] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:15 933] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 411742493
[2024/8/7 9:02:15 933] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:15 948] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:15 964] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:02:15 965] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:02:15 965] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:02:15 980] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:02:15 980] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:02:15 996] [01-01 18:12:15 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:02:15 996] [01-01 18:12:15 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:02:15 996] [01-01 18:12:15 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:02:16 012] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4146866774
[2024/8/7 9:02:16 012] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:16 061] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:16 077] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:02:16 077] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:02:16 077] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:16 093] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:16 093] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:16 093] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6
[2024/8/7 9:02:16 109] [01-01 18:12:15 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6
[2024/8/7 9:02:16 109] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:02:16 125] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:16 126] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:16 126] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:16 141] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:368
[2024/8/7 9:02:16 141] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 4 startpos:29740 size:436
[2024/8/7 9:02:16 157] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:16 157] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 216605884
[2024/8/7 9:02:16 157] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:16 173] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:16 173] [01-01 18:12:15 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:02:16 173] [01-01 18:12:15 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:02:16 189] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:02:16 189] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:16 189] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:16 205] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:16 205] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:02:16 221] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 5 startpos:30176 size:84
[2024/8/7 9:02:16 221] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:16 221] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4220141073
[2024/8/7 9:02:16 237] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:16 237] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:16 253] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:02:16 253] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:16 253] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:16 269] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:16 269] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:02:16 269] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 6 startpos:30260 size:84
[2024/8/7 9:02:16 285] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:16 285] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 860452950
[2024/8/7 9:02:16 301] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:16 301] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:16 301] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:02:16 317] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:16 317] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:16 317] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:16 332] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:02:16 333] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 7 startpos:30344 size:84
[2024/8/7 9:02:16 348] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:16 348] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2541358761
[2024/8/7 9:02:16 348] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:16 364] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:16 364] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[2024/8/7 9:02:16 380] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[2024/8/7 9:02:16 380] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[2024/8/7 9:02:16 396] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[2024/8/7 9:02:16 396] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[2024/8/7 9:02:16 412] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[2024/8/7 9:02:16 412] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[2024/8/7 9:02:16 413] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[2024/8/7 9:02:16 428] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[2024/8/7 9:02:16 428] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[2024/8/7 9:02:16 428] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[2024/8/7 9:02:16 460] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[2024/8/7 9:02:16 460] [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[2024/8/7 9:02:16 476] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[2024/8/7 9:02:16 492] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}
[2024/8/7 9:02:16 508] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:116] sys add timer: 14
[2024/8/7 9:02:16 508] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:122] sys start timer: 14
[2024/8/7 9:02:16 508] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[2024/8/7 9:02:16 524] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[2024/8/7 9:02:16 524] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[2024/8/7 9:02:16 524] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[2024/8/7 9:02:16 540] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:fvijo8jvloagv1gm 0
[2024/8/7 9:02:16 540] uuid: 20
[2024/8/7 9:02:16 540] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:02:16 540] dev_id_tmp: 16
[2024/8/7 9:02:16 556] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:02:16 556] dev_id_tmp2: 20
[2024/8/7 9:02:16 556] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:02:16 556] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:02:16 572] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1066] nc_tp:2, md:0
[2024/8/7 9:02:16 572] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1297] dev_nw_cfg_active_stage:2
[2024/8/7 9:02:16 588] [01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[2024/8/7 9:02:16 588] [1970-01-01 00:00:11] MainApp.c(838) <tuya_ipc_sdk_start>: [01-01 18:12:15 TUYA D][MainApp.c:854] tuya ipc sdk start is complete
[2024/8/7 9:02:16 604] [1970-01-01 00:00:11] MainApp.c(1028) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:02:16 604] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:02:16 620] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:02:16 620] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:02:16 620] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[2024/8/7 9:02:16 636] killall: hostapd: no process killed
[2024/8/7 9:02:16 636] route: netmask and route address conflict
[2024/8/7 9:02:16 636] [1970-01-01 00:00:11] MainApp.c(1053) <TUYA_IPC_SDK_START>: pthread_create BasicIndicatorTimer suc
[2024/8/7 9:02:16 652] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [0] change to [1]
[2024/8/7 9:02:16 668] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [0] change to [1]
[2024/8/7 9:02:16 668] [1970-01-01 00:00:11] MainApp.c(1968) <main>: FLIP
[2024/8/7 9:02:16 668] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [1] change to [0]
[2024/8/7 9:02:16 685] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [1] change to [0]
[2024/8/7 9:02:16 685] [1970-01-01 00:00:11] MainApp.c(1972) <main>: FLIP
[2024/8/7 9:02:16 701] [1970-01-01 00:00:11] MainApp.c(1622) <PostInit>: 
[2024/8/7 9:02:16 701] src/intelligent_track_thread.c(1398) [XM_SmartBodyTarckCreate]: 
[2024/8/7 9:02:16 717] src/intelligent_track_thread.c(1374) [Smart_Track_GetAbility]: 
[2024/8/7 9:02:16 717] src/intelligent_track_thread.c(1379) [Smart_Track_GetAbility]: 
[2024/8/7 9:02:16 717] src/intelligent_track_thread.c(1272) [GetMotorCtrlPara]: 
[2024/8/7 9:02:16 733] src/intelligent_track_thread.c(1277) [GetMotorCtrlPara]: 
[2024/8/7 9:02:16 733] src/intelligent_track_thread.c(1283) [GetMotorCtrlPara]: 
[2024/8/7 9:02:16 749] src/intelligent_track_thread.c(1298) [GetMotorCtrlPara]: max_steps_x=5006 ,max_steps_y=2161
[2024/8/7 9:02:16 749] src/intelligent_track_thread.c(1301) [GetMotorCtrlPara]: 
[2024/8/7 9:02:16 749] src/intelligent_track_thread.c(1307) [GetMotorCtrlPara]: 
[2024/8/7 9:02:16 765] src/intelligent_track_thread.c(1323) [GetMotorCtrlPara]: 
[2024/8/7 9:02:16 765] src/intelligent_track_thread.c(1336) [GetMotorCtrlPara]: track_default_degrees_y=95
[2024/8/7 9:02:16 781] src/intelligent_track_thread.c(1345) [GetMotorCtrlPara]: LoadTrackSet Motor_x_turnover:no
[2024/8/7 9:02:16 781] src/intelligent_track_thread.c(1346) [GetMotorCtrlPara]: LoadTrackSet Motor_y_turnover:no
[2024/8/7 9:02:16 797] src/intelligent_track_thread.c(1348) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 540
[2024/8/7 9:02:16 813] src/intelligent_track_thread.c(1367) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 400
[2024/8/7 9:02:16 813] src/intelligent_track_thread.c(1368) [GetMotorCtrlPara]: LoadTrackSet HEIGHT_STEP = 200
[2024/8/7 9:02:16 860] src/intelligent_track_thread.c(1390) [Smart_Track_GetAbility]: Track_Ability : Enable
[2024/8/7 9:02:16 876] src/intelligent_track_thread.c(1451) [XM_SmartBodyTarckCreate]: Intelligent Track_pthread create Success 1920x1080
[2024/8/7 9:02:16 877] [1970-01-01 00:00:11] MainApp.c(277) <BasicIndicatorTimer>: BasicIndicatorTimer start ----
[2024/8/7 9:02:16 877] src/intelligent_track_thread.c(667) [TrackProcV200]: 
[2024/8/7 9:02:16 893] [1970-01-01 00:00:11] MainApp.c(1640) <PostInit>: ln -s /mnt/mtd/Log/sofia.log /tmp/tuya.log
[2024/8/7 9:02:16 893] [1970-01-01 00:00:11] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:02:16 908] [1970-01-01 00:00:11] MainApp.c(1665) <PostInit>: MotionDetect Sensitive 1 set onvif_on_off:0 
[2024/8/7 9:02:16 908] curr event:3 
[2024/8/7 9:02:16 924] IPC_APP_Notify_LED_Sound_Status_CB line(480) -------------------------- IPC_START_WIFI_AP_CFG(3)
[2024/8/7 9:02:16 924] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-1650
[2024/8/7 9:02:16 924] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:02:16 940] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:02:16 940] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:02:16 956] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:02:16 956] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:02:16 956] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:02:16 972] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[2024/8/7 9:02:16 972] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[2024/8/7 9:02:16 988] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[2024/8/7 9:02:16 988] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:02:16 988] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:02:17 006] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:17 006] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:17 006] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:17 022] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:17 022] [01-01 18:12:16 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:02:17 038] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:17 038] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:17 038] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:17 053] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:17 053] [01-01 18:12:16 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:02:17 069] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:02:17 070] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:17 070] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:17 085] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:17 085] [01-01 18:12:16 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:02:17 101] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[2024/8/7 9:02:17 101] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:02:17 117] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:2  -->>
[2024/8/7 9:02:17 117] __IPC_APP_Get_Net_Status_cb line(193) -------------------------- stat(2)==STAT_AP_STA_UNCFG 
[2024/8/7 9:02:17 133] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:2  <<--
[2024/8/7 9:02:17 133] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:02:17 149] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:02:17 149] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:02:17 149] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:17 165] [01-01 18:12:16 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:17 165] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[2024/8/7 9:02:17 181] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:21504,priority:5
[2024/8/7 9:02:17 181] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[2024/8/7 9:02:17 197] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[2024/8/7 9:02:17 197] [01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt netcfg start
[2024/8/7 9:02:17 197] [01-01 18:12:16 TUYA N][tuya_ble_api.c:439] update bound stat:0
[2024/8/7 9:02:17 213] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[2024/8/7 9:02:17 213] [01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:02:17 213] dev id key: 16
[2024/8/7 9:02:17 308] d0 7d 89 57 d1 c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 9:02:17 309] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:02:17 309] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:02:17 324] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:02:17 324] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:02:17 340] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:02:17 340] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 9:02:17 356] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0x1950530),len(28)
[2024/8/7 9:02:17 356] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 9:02:17 372] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:02:17 372] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0x1950550),len(30)
[2024/8/7 9:02:17 388] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 9:02:17 389] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:02:17 389] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 9:02:17 389] adv_len:28
[2024/8/7 9:02:17 404] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:02:17 404] svc_data_uuid16 len:18
[2024/8/7 9:02:17 404] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[2024/8/7 9:02:17 420] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:17 420] ---[XmBleAdvertiseEx][1210]: rc=[0]
[2024/8/7 9:02:17 420] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 9:02:17 420] rsp_len:30
[2024/8/7 9:02:17 437] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:02:17 437] mfg_data len:30
[2024/8/7 9:02:17 437] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 9:02:17 453] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 9:02:17 453] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 9:02:17 453] ---[XmBleAdvertiseEx][1241]: rc=[0]
[2024/8/7 9:02:17 453] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 9:02:17 469] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 9:02:17 469] adv_start rc = 0x0
[2024/8/7 9:02:17 469] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 9:02:17 469] [01-01 18:12:16 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:02:17 485] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 9:02:17 485] [1970-01-01 00:00:12] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time12442
[2024/8/7 9:02:17 501] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:17 501] [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 9:02:17 501] udhcpd (v1.22.1) started
[2024/8/7 9:02:17 517] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:02:17 517] [1970-01-01 00:00:12] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 110918
[2024/8/7 9:02:17 533] [01-01 18:12:16 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:17 533] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:17 549] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:17 549] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:17 549] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:17 565] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:17 565] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:17 581] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:17 581] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:17 581] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:17 597] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:17 597] [01-01 18:12:16 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:17 597] [01-01 18:12:16 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:17 613] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:17 628] [01-01 18:12:16 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:17 644] [01-01 18:12:16 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:17 644] [01-01 18:12:16 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:17 661] [01-01 18:12:16 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:17 661] gethostbyname_r error: Unknown host
[2024/8/7 9:02:17 661] [01-01 18:12:16 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:17 677] [01-01 18:12:16 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:17 677] [01-01 18:12:16 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:17 692] [01-01 18:12:16 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:17 692] [01-01 18:12:16 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:17 708] [01-01 18:12:16 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:17 708] [01-01 18:12:16 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:17 708] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:17 725] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:02:17 725] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:17 741] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:17 756] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:17 756] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:02:17 773] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:17 773] [01-01 18:12:17 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:17 789] [1970-01-01 00:00:13] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:17 789] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:02:17 805] [01-01 18:12:17 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:02:17 805] [01-01 18:12:17 TUYA D][tuya_ble_api.c:1470] ble get conn stat:4
[2024/8/7 9:02:17 805] [01-01 18:12:17 TUYA N][tuya_ble_api.c:750] ble_sdk_send skip, no connect:4
[2024/8/7 9:02:17 821] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:17 837] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:17 837] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:17 837] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:17 853] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:17 853] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:17 869] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:17 869] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:17 869] [01-01 18:12:17 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:17 885] [01-01 18:12:17 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:17 885] [01-01 18:12:17 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:17 885] [01-01 18:12:17 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:17 901] [01-01 18:12:17 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:17 901] [01-01 18:12:17 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:17 917] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:17 933] [01-01 18:12:17 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:17 949] [01-01 18:12:17 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:17 949] [01-01 18:12:17 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:17 965] [01-01 18:12:17 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:17 965] gethostbyname_r error: Unknown host
[2024/8/7 9:02:17 965] [01-01 18:12:17 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:17 966] 
[2024/8/7 9:02:17 966] [01-01 18:12:17 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:17 981] [01-01 18:12:17 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:17 981] [01-01 18:12:17 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:17 997] [01-01 18:12:17 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:17 997] [01-01 18:12:17 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:18 013] [01-01 18:12:17 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:18 013] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:18 029] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:18 045] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:18 045] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:18 061] [01-01 18:12:18 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:18 109] [1970-01-01 00:00:14] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:18 125] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:18 141] [01-01 18:12:18 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:18 141] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:18 141] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:18 157] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:18 157] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:18 157] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:18 173] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:18 173] [01-01 18:12:18 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:18 189] [01-01 18:12:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:18 189] [01-01 18:12:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:18 189] [01-01 18:12:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:18 205] [01-01 18:12:18 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:18 205] [01-01 18:12:18 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:18 221] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:18 237] [01-01 18:12:18 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:18 253] [01-01 18:12:18 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:18 254] [01-01 18:12:18 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:18 254] [01-01 18:12:18 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:18 269] gethostbyname_r error: Unknown host
[2024/8/7 9:02:18 269] [01-01 18:12:18 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:18 269] [01-01 18:12:18 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:18 284] [01-01 18:12:18 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:18 285] [01-01 18:12:18 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:18 300] [01-01 18:12:18 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:18 300] [01-01 18:12:18 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:18 317] [01-01 18:12:18 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:18 317] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:18 908] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:18 924] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:18 924] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:02:18 941] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:18 941] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:18 956] [01-01 18:12:19 TUYA D][tuya_ble_api.c:1376] nw stat change:0->1, rpt to app.
[2024/8/7 9:02:18 956] [01-01 18:12:19 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:02:18 972] [01-01 18:12:19 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:19 132] [01-01 18:12:19 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:19 132] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:19 133] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:19 148] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:19 148] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:19 148] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:19 165] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:19 165] [01-01 18:12:19 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:19 180] [01-01 18:12:19 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:19 180] [01-01 18:12:19 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:19 180] [01-01 18:12:19 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:19 197] [01-01 18:12:19 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:19 197] [01-01 18:12:19 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:19 212] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:19 229] [01-01 18:12:19 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:19 244] [01-01 18:12:19 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:19 244] [01-01 18:12:19 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:19 244] [01-01 18:12:19 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:19 261] gethostbyname_r error: Unknown host
[2024/8/7 9:02:19 261] [01-01 18:12:19 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:19 261] [01-01 18:12:19 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:19 276] [01-01 18:12:19 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:19 276] [01-01 18:12:19 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:19 293] [01-01 18:12:19 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:19 293] [01-01 18:12:19 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:19 309] [01-01 18:12:19 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:19 309] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:19 980] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:19 996] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:19 996] [1970-01-01 00:00:16] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:20 013] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:20 013] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:20 029] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:20 156] [1970-01-01 00:00:16] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:20 156] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:20 172] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:20 172] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:20 188] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:20 188] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:20 188] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:20 204] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:20 204] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:20 204] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:20 220] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:20 220] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:20 236] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:20 236] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:20 252] [1970-01-01 00:00:16] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time16570
[2024/8/7 9:02:20 252] [1970-01-01 00:00:16] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 111417
[2024/8/7 9:02:20 252] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:20 284] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:20 284] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:20 300] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:20 300] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:20 300] gethostbyname_r error: Unknown host
[2024/8/7 9:02:20 316] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:20 316] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:20 333] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:20 333] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:20 349] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:20 349] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:20 365] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:20 365] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:20 588] motor auto test over
[2024/8/7 9:02:20 588] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 9:02:20 588] action=idle
[2024/8/7 9:02:20 588] dir=
[2024/8/7 9:02:20 588] flag=|auto-test-cmplt
[2024/8/7 9:02:20 588]  steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 9:02:20 606] YYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 9:02:20 608] action=idle
[2024/8/7 9:02:20 608] dir=
[2024/8/7 9:02:20 608] flag=
[2024/8/7 9:02:20 608]  steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 9:02:20 893] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:02:20 893] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:20 909] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:20 925] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:02:20 925] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:02:20 973] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:20 989] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:20 989] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:21 180] [01-01 18:12:21 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:21 180] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:21 180] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:21 196] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:21 196] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:21 212] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:21 212] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:21 212] [01-01 18:12:21 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:21 228] [01-01 18:12:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:21 228] [01-01 18:12:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:21 228] [01-01 18:12:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:21 244] [01-01 18:12:21 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:21 244] [01-01 18:12:21 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:21 260] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:21 276] [01-01 18:12:21 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:21 292] [01-01 18:12:21 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:21 292] [01-01 18:12:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:21 292] [01-01 18:12:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:21 308] 
[2024/8/7 9:02:21 309] gethostbyname_r error: Unknown host
[2024/8/7 9:02:21 309] [01-01 18:12:21 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:21 309] [01-01 18:12:21 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:21 324] [01-01 18:12:21 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:21 324] [01-01 18:12:21 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:21 341] [01-01 18:12:21 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:21 341] [01-01 18:12:21 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:21 357] [01-01 18:12:21 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:21 357] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:21 357] [01-01 18:12:21 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:02:21 981] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:21 996] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:22 012] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:22 012] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:22 220] [1970-01-01 00:00:18] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:22 220] [01-01 18:12:22 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:22 236] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:22 236] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:22 253] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:22 253] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:22 253] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:22 268] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:22 268] [01-01 18:12:22 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:22 268] [01-01 18:12:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:22 285] [01-01 18:12:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:22 285] [01-01 18:12:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:22 301] [01-01 18:12:22 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:22 301] [01-01 18:12:22 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:22 301] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:22 333] [01-01 18:12:22 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:22 333] [01-01 18:12:22 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:22 349] [01-01 18:12:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:22 349] [01-01 18:12:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:22 365] gethostbyname_r error: Unknown host
[2024/8/7 9:02:22 365] [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:22 365] [01-01 18:12:22 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:22 380] [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:22 381] [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:22 397] [01-01 18:12:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:22 397] [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:22 412] [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:22 413] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:22 989] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:22 989] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:23 005] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:02:23 005] [1970-01-01 00:00:19] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:23 020] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:23 037] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:23 037] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:23 229] [1970-01-01 00:00:19] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17[1970-01-01 00:00:19] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 9:02:23 244] [1970-01-01 00:00:19] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 9:02:23 244] mpId[0] is [0].
[2024/8/7 9:02:23 244] mpId[1] is [0].
[2024/8/7 9:02:23 244] mpId[2] is [0].
[2024/8/7 9:02:23 244] mpId[3] is [0].
[2024/8/7 9:02:23 244] mpId[4] is [0].
[2024/8/7 9:02:23 244] mpId[5] is [0].
[2024/8/7 9:02:23 260] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:02:23 276] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:23 292] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:23 292] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:23 292] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:23 309] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:23 309] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:23 324] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:23 325] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:23 325] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:23 341] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:23 341] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:23 341] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:23 357] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:23 357] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:23 372] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:23 388] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:23 404] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:23 404] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:23 420] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:23 421] 
[2024/8/7 9:02:23 421] gethostbyname_r error: Unknown host
[2024/8/7 9:02:23 421] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:23 436] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:23 437] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:23 437] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:23 452] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:23 452] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:23 468] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:23 468] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:24 028] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:24 044] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:24 044] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:24 060] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:24 236] [1970-01-01 00:00:20] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:24 253] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:24 254] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:24 269] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:24 269] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:24 269] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:24 285] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:24 285] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:24 285] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:24 301] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:24 301] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:24 317] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:24 319] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:24 319] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:24 332] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:24 332] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:24 364] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:24 364] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:24 380] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:24 380] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:24 380] gethostbyname_r error: Unknown host
[2024/8/7 9:02:24 396] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:24 396] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:24 396] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:24 412] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:24 412] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:24 428] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:24 428] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:24 444] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:25 020] [1970-01-01 00:00:20] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time20855
[2024/8/7 9:02:25 036] [1970-01-01 00:00:20] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 117605
[2024/8/7 9:02:25 037] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:25 052] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:02:25 068] src/intelligent_track_thread.c(709) [TrackProcV200]: Intelligent Track Enable eSensitivity=0 intervalTime_sec=15
[2024/8/7 9:02:25 069] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:25 084] ble_slave_gap_event->type=0
[2024/8/7 9:02:25 085] connection established; status=0 GATT procedure initiated: exchange mtu
[2024/8/7 9:02:25 085] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 100] connection, handle=1
[2024/8/7 9:02:25 100] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:25 100] [01-01 18:12:25 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:02:25 116] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 116] --- tracepoint bt_ext_porting.c,ty_btext_thread(423): TY_BT_EVENT_CONNECTED1 ---
[2024/8/7 9:02:25 132] [01-01 18:12:25 TUYA D][tuya_ble_api.c:543] rev ble event 1
[2024/8/7 9:02:25 132] [01-01 18:12:25 TUYA N][tuya_ble_api.c:472] Ble Connected
[2024/8/7 9:02:25 132] [01-01 18:12:25 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[2024/8/7 9:02:25 148] [01-01 18:12:25 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
[2024/8/7 9:02:25 260] --- tracepoint bt_ext_porting.c,ty_btext_thread(425): TY_BT_EVENT_CONNECTED2 ---
[2024/8/7 9:02:25 260] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 276] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 276] ble_slave_gap_event->type=15
[2024/8/7 9:02:25 276] mtu update event; conn_handle=1 cid=4 mtu=255
[2024/8/7 9:02:25 292] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:25 308] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 308] [01-01 18:12:25 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:25 309] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:25 324] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:25 324] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:25 340] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:25 341] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:25 341] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:25 356] [01-01 18:12:25 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:25 357] [01-01 18:12:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:25 357] [01-01 18:12:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:25 372] [01-01 18:12:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:25 372] [01-01 18:12:25 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:25 388] [01-01 18:12:25 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:25 388] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:25 404] [01-01 18:12:25 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:25 420] [01-01 18:12:25 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:25 420] [01-01 18:12:25 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:25 436] [01-01 18:12:25 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:25 436] gethostbyname_r error: Unknown host
[2024/8/7 9:02:25 436] [01-01 18:12:25 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:25 452] [01-01 18:12:25 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:25 452] [01-01 18:12:25 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:25 468] [01-01 18:12:25 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:25 468] [01-01 18:12:25 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:25 484] [01-01 18:12:25 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:25 484] [01-01 18:12:25 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:25 500] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:25 900] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:02:25 900] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 900] ble_slave_gap_event->type=4
[2024/8/7 9:02:25 916] connection update request
[2024/8/7 9:02:25 916] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 932] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 933] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 948] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 964] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:25 964] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 964] ble_slave_gap_event->type=3
[2024/8/7 9:02:25 980] connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:02:25 980] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:25 996] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 012] [01-01 18:12:26 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:02:26 012] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:02:26 012] Mode(Product):0
[2024/8/7 9:02:26 012] BpuMode:[Online]
[2024/8/7 9:02:26 012] VpssMode:[Online]
[2024/8/7 9:02:26 028] [0.LimitUp_info]:
[2024/8/7 9:02:26 028] LimitUp:[Disable]
[2024/8/7 9:02:26 028] [2680*0]->[3840*0])
[2024/8/7 9:02:26 028] chn	TotalSize	ActiveSize
[2024/8/7 9:02:26 028] 0	5040*2246	2680*2160
[2024/8/7 9:02:26 028] 0	5040*2246	3840*2160
[2024/8/7 9:02:26 028] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:02:26 044] [1.VICU_info]:
[2024/8/7 9:02:26 045] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:02:26 045] 0	25.0	358	0	0	183	linear	8ddb00
[2024/8/7 9:02:26 045] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:02:26 045] en	op_type	m_chn	now
[2024/8/7 9:02:26 045] 0	1	1	1
[2024/8/7 9:02:26 045] [2.VI_info]:
[2024/8/7 9:02:26 060] chn	TotalSize	ActiveSize
[2024/8/7 9:02:26 060] 0	5040*2246	3848*2166
[2024/8/7 9:02:26 060] 1	   0*   0	   0*   0
[2024/8/7 9:02:26 060] [3.MIPI_info]:
[2024/8/7 9:02:26 060] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:02:26 076] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:02:26 076] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:02:26 076] [4.Cut_info]:
[2024/8/7 9:02:26 076] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:02:26 076] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:02:26 091] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:02:26 091] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:02:26 092] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:02:26 092] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:02:26 092] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:02:26 092] [5.IB(isp buffer info)]:
[2024/8/7 9:02:26 107] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:02:26 108] PoolId  Count  Size
[2024/8/7 9:02:26 108] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:26 125] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:26 125] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:26 140] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:26 141] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:26 141] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:26 156] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:02:26 157] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:02:26 157] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:02:26 172] 0       0         0          2          4       
[2024/8/7 9:02:26 173] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:02:26 173]      --265--            --264--                                               
[2024/8/7 9:02:26 188] Count      Line     Count      Line     
[2024/8/7 9:02:26 189] 254        480      596        560      
[2024/8/7 9:02:26 189] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:02:26 204] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:02:26 205] 0   3840   2160    H265  0      0        0           154       983033     7        	
[2024/8/7 9:02:26 220] 1   640    360     H265  0      0        0           97        43195      5        	
[2024/8/7 9:02:26 220] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:02:26 236] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:02:26 236] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:02:26 253] 0   Y      154      0       0       15       0        154      154      216       65753         59047    104190   65247    11      
[2024/8/7 9:02:26 268] 1   Y      97       0       2       1        0        97       97       218       2614          1897     38238    3746     6       
[2024/8/7 9:02:26 284] 3   N      0        0       0       1        0        0        0        219       0             0        0        0        0       
[2024/8/7 9:02:26 284] [1970-01-01 00:00:22] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:26 301] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:26 301] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 317] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 332] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 348] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 364] [1970-01-01 00:00:22] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:26 364] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 380] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 396] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 396] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:26 413] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 413] ble_slave_gap_event->type=4
[2024/8/7 9:02:26 413] connection update request
[2024/8/7 9:02:26 413] ble_slave_gap_event->type=14
[2024/8/7 9:02:26 428] subscribe event; conn_handle=1 attr_handle=23 reason=1 prevn=0 curn=1 previ=0 curi=0
[2024/8/7 9:02:26 428] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:02:26 444] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 445] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 460] [01-01 18:12:26 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:26 460] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:26 460] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:26 476] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:26 476] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:26 476] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:26 493] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:26 493] [01-01 18:12:26 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:26 508] [01-01 18:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:26 508] [01-01 18:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:26 508] [01-01 18:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:26 524] [01-01 18:12:26 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:26 524] [01-01 18:12:26 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:26 540] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:26 556] [01-01 18:12:26 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:26 556] [01-01 18:12:26 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:26 572] [01-01 18:12:26 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:26 572] [01-01 18:12:26 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:26 588] gethostbyname_r error: Unknown host
[2024/8/7 9:02:26 588] [01-01 18:12:26 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:26 588] [01-01 18:12:26 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:26 604] [01-01 18:12:26 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:26 604] [01-01 18:12:26 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:26 620] [01-01 18:12:26 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:26 620] [01-01 18:12:26 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:26 636] [01-01 18:12:26 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:26 637] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:26 637] [01-01 18:12:26 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:02:26 940] ble_slave_gap_event->type=3
[2024/8/7 9:02:26 955] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:02:26 956] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:26 972] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:26 988] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:26 988] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:26 989] Len=20 step 0
[2024/8/7 9:02:27 004] att=0x0 0x21 0x20 0x1 0x41 0xcc 0x4 0x60 0xa7 0xfd 0xe 0x3a 0x75 0xc2 0x38 0xcf 0xf7 0x7 0xa4 0x67 
[2024/8/7 9:02:27 004]  RCVS len:20
[2024/8/7 9:02:27 004] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:27 004] XmBleReadBuf 20:
[2024/8/7 9:02:27 020] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:27 020] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:27 021] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:27 036] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:27 036] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:27 052] [01-01 18:12:27 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:27 052] [01-01 18:12:27 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:27 052] [01-01 18:12:27 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:27 052] bt_rev_raw 20
[2024/8/7 9:02:27 068] 00 21 20 01 41 cc 04 60 a7 fd 0e 3a 75 c2 38 cf f7 07 a4 67 
[2024/8/7 9:02:27 068] [01-01 18:12:27 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:02:27 084] [01-01 18:12:27 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:27 084] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:27 100] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:27 100] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:27 100] Len=17 step 0
[2024/8/7 9:02:27 115] att=0x1 0xdf 0x3 0x40 0x61 0x7d 0x8f 0xbd 0xc2 0xde 0x22 0x2c 0xe5 0x56 0xb3 0x74 0xdd 
[2024/8/7 9:02:27 116]  RCVS len:17
[2024/8/7 9:02:27 116] XmBleReadBuf 17:
[2024/8/7 9:02:27 116] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:27 116] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:27 131] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:27 131] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:02:27 132] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:02:27 149] [01-01 18:12:27 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:02:27 149] [01-01 18:12:27 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:27 164] [01-01 18:12:27 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:27 164] bt_rev_raw 17
[2024/8/7 9:02:27 164] 01 df 03 40 61 7d 8f bd c2 de 22 2c e5 56 b3 74 dd 
[2024/8/7 9:02:27 180] [01-01 18:12:27 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:02:27 180] ble rev data 33
[2024/8/7 9:02:27 180] 01 41 cc 04 60 a7 fd 0e 3a 75 c2 38 cf f7 07 a4 67 df 03 40 61 7d 8f bd c2 de 22 2c e5 56 b3 74 dd 
[2024/8/7 9:02:27 196] [01-01 18:12:27 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:02:27 196] ble decryped data 16
[2024/8/7 9:02:27 196] 00 00 00 01 00 00 00 00 00 00 00 00 92 69 00 00 
[2024/8/7 9:02:27 196] [01-01 18:12:27 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:02:27 212] [01-01 18:12:27 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x0 
[2024/8/7 9:02:27 212] [01-01 18:12:27 TUYA N][tuya_ble_data_handler.c:451] tuya_ble_handle_dev_infor_req state:0, pkg_len:20
[2024/8/7 9:02:27 228] [01-01 18:12:27 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:02:27 228] [01-01 18:12:27 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:02:27 244] [01-01 18:12:27 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:02:27 244] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:4, send_data:16
[2024/8/7 9:02:27 244] tuya_hal_bt_send 20
[2024/8/7 9:02:27 260] 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:02:27 260] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:27 260] 0 81 1 30 1 57 27 a7 5 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:02:27 276] XmBleSendBuf 20: 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58
[2024/8/7 9:02:27 276] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:27 276] ble_slave_gap_event->type=13
[2024/8/7 9:02:27 276] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:27 293] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:27 293] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:27 308] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:02:27 308] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:27 308] tuya_hal_bt_send 20
[2024/8/7 9:02:27 325] 01 3d ca 49 30 a0 69 a4 9a a8 61 14 f7 42 26 52 09 9c 66 bf 
[2024/8/7 9:02:27 325] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:27 325] 1 3d ca 49 30 a0 69 a4 9a a8 61 14 f7 42 26 52 9 9c 66 bf 
[2024/8/7 9:02:27 340] XmBleSendBuf 20: 01 3d ca 49 30 a0 69 a4 9a a8 61 14 f7 42 26 52 09 9c 66 bf
[2024/8/7 9:02:27 340] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:27 340] ble_slave_gap_event->type=13
[2024/8/7 9:02:27 340] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:27 356] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:27 356] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:27 372] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:27 372] tuya_hal_bt_send 20
[2024/8/7 9:02:27 372] 02 7e ab 47 78 c3 f6 c4 fd a7 04 f9 30 6b 80 71 56 b2 ac 8a 
[2024/8/7 9:02:27 372] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:27 387] 2 7e ab 47 78 c3 f6 c4 fd a7 4 f9 30 6b 80 71 56 b2 ac 8a 
[2024/8/7 9:02:27 387] XmBleSendBuf 20: 02 7e ab 47 78 c3 f6 c4 fd a7 04 f9 30 6b 80 71 56 b2 ac 8a
[2024/8/7 9:02:27 404] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:27 405] ble_slave_gap_event->type=13
[2024/8/7 9:02:27 405] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:27 405] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:27 420] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:27 420] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:27 420] tuya_hal_bt_send 20
[2024/8/7 9:02:27 436] 03 71 bc c3 d2 c7 9a 5a 90 8f 09 48 c6 7e 5c 0f fd 6e e7 96 
[2024/8/7 9:02:27 436] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:27 436] 3 71 bc c3 d2 c7 9a 5a 90 8f 9 48 c6 7e 5c f fd 6e e7 96 
[2024/8/7 9:02:27 452] XmBleSendBuf 20: 03 71 bc c3 d2 c7 9a 5a 90 8f 09 48 c6 7e 5c 0f fd 6e e7 96
[2024/8/7 9:02:27 452] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:27 452] ble_slave_gap_event->type=13
[2024/8/7 9:02:27 468] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:27 468] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:27 468] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:27 484] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:27 484] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:27 500] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:27 500] tuya_hal_bt_send 20
[2024/8/7 9:02:27 500] 04 2f a3 d8 d7 02 12 32 96 0a 5c a4 ad c7 36 1a 96 35 ec 91 
[2024/8/7 9:02:27 516] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:27 516] 4 2f a3 d8 d7 2 12 32 96 a 5c a4 ad c7 36 1a 96 35 ec 91 
[2024/8/7 9:02:27 532] XmBleSendBuf 20: 04 2f a3 d8 d7 02 12 32 96 0a 5c a4 ad c7 36 1a 96 35 ec 91
[2024/8/7 9:02:27 532] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:27 532] ble_slave_gap_event->type=13
[2024/8/7 9:02:27 532] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:27 548] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:27 548] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:27 548] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:27 564] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:27 564] tuya_hal_bt_send 20
[2024/8/7 9:02:27 580] 05 a4 18 7e 0c d9 40 ad 38 09 ab 0d 6d 8b 85 f1 40 af 11 f5 
[2024/8/7 9:02:27 581] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:27 581] 5 a4 18 7e c d9 40 ad 38 9 ab d 6d 8b 85 f1 40 af 11 f5 
[2024/8/7 9:02:27 595] XmBleSendBuf 20: 05 a4 18 7e 0c d9 40 ad 38 09 ab 0d 6d 8b 85 f1 40 af 11 f5
[2024/8/7 9:02:27 596] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:27 596] ble_slave_gap_event->type=13
[2024/8/7 9:02:27 596] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:27 612] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:27 612] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:27 612] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:27 628] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:18
[2024/8/7 9:02:27 628] tuya_hal_bt_send 19
[2024/8/7 9:02:27 643] 06 0a 5d 70 39 6a 5d 71 63 e5 ea 0b 80 18 6b 0a 30 a4 5f 
[2024/8/7 9:02:27 644] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:27 644] 6 a 5d 70 39 6a 5d 71 63 e5 ea b 80 18 6b a 30 a4 5f 
[2024/8/7 9:02:27 660] XmBleSendBuf 19: 06 0a 5d 70 39 6a 5d 71 63 e5 ea 0b 80 18 6b 0a 30 a4 5f
[2024/8/7 9:02:27 660] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:27 660] ble_slave_gap_event->type=13
[2024/8/7 9:02:27 660] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:27 675] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:27 676] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:27 691] [01-01 18:12:28 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:129, send_ret:0x0
[2024/8/7 9:02:27 692] [01-01 18:12:28 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:27 692] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:27 707] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:27 707] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:27 724] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:27 724] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:27 724] [01-01 18:12:28 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:0
[2024/8/7 9:02:27 740] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:27 740] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:27 756] [01-01 18:12:28 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:27 757] [01-01 18:12:28 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:27 757] [01-01 18:12:28 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:27 772] [01-01 18:12:28 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:27 772] [01-01 18:12:28 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:27 772] [01-01 18:12:28 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:27 788] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:27 804] [01-01 18:12:28 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:27 820] [01-01 18:12:28 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:27 820] [01-01 18:12:28 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:27 836] [01-01 18:12:28 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:27 836] gethostbyname_r error: Unknown host
[2024/8/7 9:02:27 836] [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:27 852] [01-01 18:12:28 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:27 852] [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:27 868] [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:02:27 868] [01-01 18:12:28 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:27 884] [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:27 884] [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:27 884] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:27 900] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:27 900] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:27 900] Len=20 step 0
[2024/8/7 9:02:27 916] att=0x0 0x51 0x20 0x2 0xe0 0x91 0x24 0x22 0xc6 0xba 0xb3 0x7b 0x6b 0xc3 0x65 0xd6 0x36 0x96 0x50 0x5f 
[2024/8/7 9:02:27 916]  RCVS len:20
[2024/8/7 9:02:27 916] XmBleReadBuf 20:
[2024/8/7 9:02:27 916] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:27 932] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:27 932] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:27 932] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:27 948] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:27 948] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:27 964] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:27 964] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:27 964] bt_rev_raw 20
[2024/8/7 9:02:27 964] 00 51 20 02 e0 91 24 22 c6 ba b3 7b 6b c3 65 d6 36 96 50 5f 
[2024/8/7 9:02:27 980] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:02:28 012] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:28 012] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:28 028] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:28 028] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:28 028] Len=20 step 0
[2024/8/7 9:02:28 044] att=0x1 0xce 0x93 0x49 0x9 0x6c 0x97 0x8d 0x31 0xbe 0xd4 0xe 0x9a 0xf7 0x8e 0x64 0xd7 0xc2 0x6e 0x7f 
[2024/8/7 9:02:28 044]  RCVS len:20
[2024/8/7 9:02:28 044] XmBleReadBuf 20:
[2024/8/7 9:02:28 044] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:28 044] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:28 059] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:28 060] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:28 060] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:28 075] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:28 075] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:28 091] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:28 091] bt_rev_raw 20
[2024/8/7 9:02:28 091] 01 ce 93 49 09 6c 97 8d 31 be d4 0e 9a f7 8e 64 d7 c2 6e 7f 
[2024/8/7 9:02:28 107] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:02:28 107] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:28 123] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:28 124] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:28 139] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:28 139] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:28 139] Len=20 step 0
[2024/8/7 9:02:28 155] att=0x2 0x6d 0x75 0x62 0x7b 0x7c 0x1d 0x23 0x6 0x93 0xed 0x9a 0xce 0x97 0xba 0x26 0x91 0xd4 0xc5 0x17 
[2024/8/7 9:02:28 155]  RCVS len:20
[2024/8/7 9:02:28 155] XmBleReadBuf 20:
[2024/8/7 9:02:28 155] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:28 171] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:28 171] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:28 172] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:28 188] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:28 188] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:28 204] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:28 204] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:28 204] bt_rev_raw 20
[2024/8/7 9:02:28 204] 02 6d 75 62 7b 7c 1d 23 06 93 ed 9a ce 97 ba 26 91 d4 c5 17 
[2024/8/7 9:02:28 220] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:02:28 235] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:28 235] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:28 235] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:28 235] Len=20 step 0
[2024/8/7 9:02:28 251] att=0x3 0x91 0x87 0xa3 0x57 0xc4 0x8d 0x49 0x62 0xc3 0xbe 0x39 0x4f 0x51 0x31 0x23 0xa9 0x53 0x9c 0x32 
[2024/8/7 9:02:28 251]  RCVS len:20
[2024/8/7 9:02:28 251] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:28 268] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:28 268] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:28 268] Len=8 step 0
[2024/8/7 9:02:28 284] att=0x4 0x33 0xc2 0x87 0x6 0x69 0xd 0x44 
[2024/8/7 9:02:28 284]  RCVS len:8
[2024/8/7 9:02:28 284] XmBleReadBuf 20:
[2024/8/7 9:02:28 284] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:28 284] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:28 300] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:28 300] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:28 300] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:28 317] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:28 317] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:28 332] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:28 332] bt_rev_raw 20
[2024/8/7 9:02:28 332] 03 91 87 a3 57 c4 8d 49 62 c3 be 39 4f 51 31 23 a9 53 9c 32 
[2024/8/7 9:02:28 348] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:02:28 348] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:28 364] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:28 364] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:28 411] XmBleReadBuf 8:
[2024/8/7 9:02:28 411] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:28 411] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:28 428] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:28 428] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 16 rcount 16 offset 0 ---
[2024/8/7 9:02:28 428] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 16 ---
[2024/8/7 9:02:28 444] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x9]
[2024/8/7 9:02:28 444] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:28 459] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:28 459] bt_rev_raw 8
[2024/8/7 9:02:28 459] 04 33 c2 87 06 69 0d 44 
[2024/8/7 9:02:28 476] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:5, pack_len:7, total_len:81
[2024/8/7 9:02:28 477] ble rev data 81
[2024/8/7 9:02:28 491] 02 e0 91 24 22 c6 ba b3 7b 6b c3 65 d6 36 96 50 5f ce 93 49 09 6c 97 8d 31 be d4 0e 9a f7 8e 64 d7 c2 6e 7f 6d 75 62 7b 7c 1d 23 06 93 ed 9a ce 97 ba 26 91 d4 c5 17 91 87 a3 57 c4 8d 49 62 c3 
[2024/8/7 9:02:28 491] be 39 4f 51 31 23 a9 53 9c 32 33 c2 87 06 69 0d 44 
[2024/8/7 9:02:28 491] ble decryped data 64
[2024/8/7 9:02:28 508] 00 00 00 02 00 00 00 00 00 01 00 2c 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca 1e 00 00 00 00 00 00 
[2024/8/7 9:02:28 524] [01-01 18:12:28 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:02:28 525] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x1 
[2024/8/7 9:02:28 525] [01-01 18:12:28 TUYA D][tuya_ble_api.c:573] conn monitor timer stopped
[2024/8/7 9:02:28 540] [01-01 18:12:28 TUYA N][tuya_ble_api.c:1464] ble set conn stat:3
[2024/8/7 9:02:28 540] [01-01 18:12:28 TUYA N][tuya_ble_data_handler.c:367] PAIR_REQ ok:0
[2024/8/7 9:02:28 540] [01-01 18:12:28 TUYA N][tuya_ble_data_handler.c:342] ble_time_req start...
[2024/8/7 9:02:28 556] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:348] no need to query time. network stat:1, work stat:0
[2024/8/7 9:02:28 556] [01-01 18:12:28 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:02:28 572] [01-01 18:12:28 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:28 572] [01-01 18:12:28 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:28 572] tuya_hal_bt_send 20
[2024/8/7 9:02:28 588] 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:02:28 588] [01-01 18:12:28 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:28 604] 0 21 31 2 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:02:28 604] XmBleSendBuf 20: 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c
[2024/8/7 9:02:28 604] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:28 604] ble_slave_gap_event->type=13
[2024/8/7 9:02:28 620] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:28 620] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:28 620] [01-01 18:12:28 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:28 636] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:16 ---
[2024/8/7 9:02:28 636] [01-01 18:12:28 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:02:28 636] tuya_hal_bt_send 17
[2024/8/7 9:02:28 651] 01 63 e7 10 a9 a2 f7 d1 55 55 7f d7 93 27 8b fe 7a 
[2024/8/7 9:02:28 651] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:28 667] [01-01 18:12:28 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:28 667] 1 63 e7 10 a9 a2 f7 d1 55 55 7f d7 93 27 8b fe 7a 
[2024/8/7 9:02:28 667] XmBleSendBuf 17: 01 63 e7 10 a9 a2 f7 d1 55 55 7f d7 93 27 8b fe 7a
[2024/8/7 9:02:28 667] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:28 683] ble_slave_gap_event->type=13
[2024/8/7 9:02:28 683] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:28 683] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:28 699] [01-01 18:12:28 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:28 699] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:28 715] [01-01 18:12:28 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:02:28 715] [01-01 18:12:28 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:1
[2024/8/7 9:02:28 715] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:28 715] Len=20 step 0
[2024/8/7 9:02:28 731] att=0x0 0x61 0x20 0x2 0x76 0x54 0x87 0x17 0xc5 0x85 0xb2 0x89 0x9 0xbe 0x4e 0x32 0x95 0x96 0xa4 0x2e 
[2024/8/7 9:02:28 731]  RCVS len:20
[2024/8/7 9:02:28 731] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:28 747] XmBleReadBuf 20:
[2024/8/7 9:02:28 747] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:28 747] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:28 763] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:28 764] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:28 764] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:28 876] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:28 876] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:28 876] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:28 876] bt_rev_raw 20
[2024/8/7 9:02:28 892] 00 61 20 02 76 54 87 17 c5 85 b2 89 09 be 4e 32 95 96 a4 2e 
[2024/8/7 9:02:28 892] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:02:28 908] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:28 908] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:28 924] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:28 924] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:28 924] Len=20 step 0
[2024/8/7 9:02:28 940] att=0x1 0x7c 0xca 0xbf 0x5 0xc9 0xa1 0xff 0xce 0x0 0x53 0xf4 0x4f 0x3c 0x12 0x13 0x59 0x2 0x22 0xed 
[2024/8/7 9:02:28 940]  RCVS len:20
[2024/8/7 9:02:28 940] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:28 956] XmBleReadBuf 20:
[2024/8/7 9:02:28 956] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:28 956] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:28 956] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:28 972] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:28 972] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:28 988] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:28 988] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:29 004] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:29 004] bt_rev_raw 20
[2024/8/7 9:02:29 004] 01 7c ca bf 05 c9 a1 ff ce 00 53 f4 4f 3c 12 13 59 02 22 ed 
[2024/8/7 9:02:29 020] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:02:29 020] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:29 021] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:29 035] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:29 036]  ---
[2024/8/7 9:02:29 036] Len=20 step 0
[2024/8/7 9:02:29 036] att=0x2 0xa2 0xe8 0xc2 0xf0 0xb4 0x95 0x6e 0xc7 0x10 0x89 0xb0 0x24 0xda 0x2 0x8e 0x4f 0xc5 0xb7 0xfe 
[2024/8/7 9:02:29 051]  RCVS len:20
[2024/8/7 9:02:29 052] [1970-01-01 00:00:24] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time24862
[2024/8/7 9:02:29 067] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:29 069] [01-01 18:12:29 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:02:29 069] XmBleReadBuf 20:
[2024/8/7 9:02:29 069] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:29 084] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:29 085] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:29 085] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:29 100] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:29 100] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:29 116] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:29 116] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:29 116] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:29 133] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:29 133] bt_rev_raw 20
[2024/8/7 9:02:29 133] 02 a2 e8 c2 f0 b4 95 6e c7 10 89 b0 24 da 02 8e 4f c5 b7 fe 
[2024/8/7 9:02:29 148] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:02:29 148] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:29 164] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:29 164] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:29 180] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:29 180] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:29 180] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:29 196] [01-01 18:12:29 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:29 196] [01-01 18:12:29 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:29 196] [01-01 18:12:29 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:29 212] [01-01 18:12:29 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:29 212] [01-01 18:12:29 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:29 228] [01-01 18:12:29 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:29 228] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:02:29 244] [01-01 18:12:29 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:29 260] [01-01 18:12:29 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:02:29 260] [01-01 18:12:29 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:29 277] [01-01 18:12:29 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:02:29 277] gethostbyname_r error: Unknown host
[2024/8/7 9:02:29 277] [01-01 18:12:29 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:02:29 292] [01-01 18:12:29 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:02:29 292] [01-01 18:12:29 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:02:29 307] [01-01 18:12:29 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.co[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:02:29 308] m:443 failed
[2024/8/7 9:02:29 308] [01-01 18:12:29 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:02:29 323] [01-01 18:12:29 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:02:29 323] [01-01 18:12:29 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:02:29 340] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:02:29 340] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:29 356] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:29 356] Len=20 step 0
[2024/8/7 9:02:29 356] att=0x3 0xf1 0xcd 0xa1 0x94 0xad 0x65 0xd5 0xca 0xc3 0x74 0x5d 0xe5 0xea 0x6e 0x81 0x61 0xaf 0xf6 0xcf 
[2024/8/7 9:02:29 356]  RCVS len:20
[2024/8/7 9:02:29 356] XmBleReadBuf 20:
[2024/8/7 9:02:29 372] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:29 372] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:29 372] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:29 388] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:29 388] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:29 404] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:29 404] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:29 404] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:29 404] bt_rev_raw 20
[2024/8/7 9:02:29 420] 03 f1 cd a1 94 ad 65 d5 ca c3 74 5d e5 ea 6e 81 61 af f6 cf 
[2024/8/7 9:02:29 420] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:02:29 436] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:29 436] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:29 452] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:29 452]  -[atbm_log]:[ieee80211_csa_cancel][mon.eth2]:[0][0]
[2024/8/7 9:02:29 452] Len=20 step 0
[2024/8/7 9:02:29 468] att=0x4 0x43 0x6e 0xe1 0x21 0xcf 0xb9 0xcd 0x1b 0xa6 0xab 0x83 0xcc 0x14 0x8e 0xf9 0x21 0xf1 0xb0 0x85 
[2024/8/7 9:02:29 468]  RCVS len:20
[2024/8/7 9:02:29 468] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:29 484] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:29 484] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:29 500] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:29 500] Len=5 step 0
[2024/8/7 9:02:29 500] att=0x5 0xe8 0x4d 0x79 0xa0 
[2024/8/7 9:02:29 500]  RCVS len:5
[2024/8/7 9:02:29 500] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:29 516] XmBleReadBuf 20:
[2024/8/7 9:02:29 516] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:29 516] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:29 516] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:29 532] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:29 532] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:29 549] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:29 549] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:29 565] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:29 565] bt_rev_raw 20
[2024/8/7 9:02:29 565] 04 43 6e e1 21 cf b9 cd 1b a6 ab 83 cc 14 8e f9 21 f1 b0 85 
[2024/8/7 9:02:29 580] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:5, pack_len:19, total_len:93
[2024/8/7 9:02:29 580] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:29 580] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:29 596] XmBleReadBuf 5:
[2024/8/7 9:02:29 596] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:29 596] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:29 596] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:29 612] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 13 rcount 13 offset 0 ---
[2024/8/7 9:02:29 612] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 13 ---
[2024/8/7 9:02:29 628] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x6]
[2024/8/7 9:02:29 628] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:29 644] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:29 644] bt_rev_raw 5
[2024/8/7 9:02:29 644] 05 e8 4d 79 a0 
[2024/8/7 9:02:29 644] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:6, pack_len:4, total_len:97
[2024/8/7 9:02:29 644] ble rev data 97
[2024/8/7 9:02:29 660] 02 76 54 87 17 c5 85 b2 89 09 be 4e 32 95 96 a4 2e 7c ca bf 05 c9 a1 ff ce 00 53 f4 4f 3c 12 13 59 02 22 ed a2 e8 c2 f0 b4 95 6e c7 10 89 b0 24 da 02 8e 4f c5 b7 fe f1 cd a1 94 ad 65 d5 ca c3 
[2024/8/7 9:02:29 676] 74 5d e5 ea 6e 81 61 af f6 cf 43 6e e1 21 cf b9 cd 1b a6 ab 83 cc 14 8e f9 21 f1 b0 85 e8 4d 79 a0 
[2024/8/7 9:02:29 676] ble decryped data 80
[2024/8/7 9:02:29 692] 00 00 00 03 00 00 00 00 00 21 00 41 7b 22 70 77 64 22 3a 22 78 6d 35 31 32 35 32 30 22 2c 22 73 73 69 64 22 3a 22 58 69 61 6f 6d 69 5f 46 31 44 43 22 2c 22 74 6f 6b 65 6e 22 3a 22 41 59 4d 61 
[2024/8/7 9:02:29 692] 68 31 5a 45 68 71 31 4c 45 67 22 7d 00 98 97 00 
[2024/8/7 9:02:29 708] [01-01 18:12:29 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:29 708] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x21 
[2024/8/7 9:02:29 724] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:33 Has No def operate
[2024/8/7 9:02:29 724] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:13 ---
[2024/8/7 9:02:29 724] [01-01 18:12:29 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:33
[2024/8/7 9:02:29 740] [01-01 18:12:29 TUYA N][bt_netcfg.c:63] Rev Net Cfg:{"pwd":"xm512520","ssid":"Xiaomi_F1DC","token":"AYMah1ZEhq1LEg"}
[2024/8/7 9:02:29 740] [01-01 18:12:29 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:29 756] [01-01 18:12:29 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x21 encrpyt:2
[2024/8/7 9:02:29 756] bt_ack_uncrypt 1
[2024/8/7 9:02:29 756] 00 
[2024/8/7 9:02:29 756] [01-01 18:12:29 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:29 772] [01-01 18:12:29 TUYA N][bt_netcfg.c:98] cfg ssid:Xiaomi_F1DC, passwd:xm512520, token:AYMah1ZEhq1LEg
[2024/8/7 9:02:29 787] [01-01 18:12:29 TUYA D][tuya_devos_netcfg.c:464] concurrent Netcfg Finish type:0x10004 ssid:Xiaomi_F1DC passwd:xm512520 cur_netcfg_type:0
[2024/8/7 9:02:29 787] [01-01 18:12:29 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:29 787] tuya_hal_bt_send 20
[2024/8/7 9:02:29 803] 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:02:29 803] [01-01 18:12:29 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:29 803] 0 21 32 2 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:02:29 819] XmBleSendBuf 20: 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7
[2024/8/7 9:02:29 819] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:29 819] ble_slave_gap_event->type=13
[2024/8/7 9:02:29 835] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:29 835] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:29 835] [01-01 18:12:29 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:29 852] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:29 852] [01-01 18:12:29 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:02:29 852] tuya_hal_bt_send 17
[2024/8/7 9:02:29 867] 01 40 3f 16 fa fc c3 74 d9 b7 9b 96 77 51 45 24 fa 
[2024/8/7 9:02:29 867] [01-01 18:12:29 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:29 867] 1 40 3f 16 fa fc c3 74 d9 b7 9b 96 77 51 45 24 fa 
[2024/8/7 9:02:29 883] XmBleSendBuf 17: 01 40 3f 16 fa fc c3 74 d9 b7 9b 96 77 51 45 24 fa
[2024/8/7 9:02:29 883] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:29 883] ble_slave_gap_event->type=13
[2024/8/7 9:02:29 899] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:29 899] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:29 899] [01-01 18:12:29 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:29 915] [01-01 18:12:29 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:02:29 915] [01-01 18:12:29 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait
[2024/8/7 9:02:29 931] [01-01 18:12:29 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10002
[2024/8/7 9:02:29 931] [01-01 18:12:29 TUYA D][ap_netcfg.c:950] ap cfg stop:65538
[2024/8/7 9:02:29 931] [01-01 18:12:29 TUYA D][uni_thread.c:310] Del Thrd:udp_ap_v3
[2024/8/7 9:02:29 947] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:29 947] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:29 963] [1970-01-01 00:00:25] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:29 979] [01-01 18:12:29 TUYA N][ap_netcfg.c:172] exit ap_net_cfg task
[2024/8/7 9:02:29 979] Received SIGTERM
[2024/8/7 9:02:29 979] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:02:29 995] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:29 996] [01-01 18:12:30 TUYA D][ap_netcfg.c:553] wf_ap_stop:0
[2024/8/7 9:02:30 011] [01-01 18:12:30 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10100
[2024/8/7 9:02:30 012] [01-01 18:12:30 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10004
[2024/8/7 9:02:30 028] [01-01 18:12:30 TUYA N][tuya_ble_api.c:439] update bound stat:1
[2024/8/7 9:02:30 028] [01-01 18:12:30 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:0
[2024/8/7 9:02:30 044] [01-01 18:12:30 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:02:30 045] [01-01 18:12:30 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:02:30 045] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:30 060] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:30 060] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:30 060] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:30 076] [01-01 18:12:30 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:02:30 076] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:30 092] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:30 092] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:30 092] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:30 107] [01-01 18:12:30 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:02:30 107] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:02:30 107] [01-01 1[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:02:30 123] 8:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:30 123] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:30 123] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:30 140] [01-01 18:12:30 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:02:30 140] [01-01 18:12:30 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:02:30 155] [01-01 18:12:30 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:02:30 155] [01-01 18:12:30 TUYA N][tuya_devos_activate.c:774] already inited
[2024/8/7 9:02:30 156] [01-01 18:12:30 TUYA D][uni_thread.c:268] Thread:udp_ap_v3 Exec Finish. Set to Del Stat
[2024/8/7 9:02:30 172] [01-01 18:12:30 TUYA D][uni_thread.c:125] del list not empty...deleting 0x19500ec, next 0x190d8c8
[2024/8/7 9:02:30 172] [01-01 18:12:30 TUYA D][uni_thread.c:132] Final Free Thread:udp_ap_v3, is_self:1
[2024/8/7 9:02:30 188] [01-01 18:12:30 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:02:30 188] [01-01 18:12:30 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:02:30 204] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:02:30 204] curr event:5 
[2024/8/7 9:02:30 220] IPC_APP_Notify_LED_Sound_Status_CB line(491) -------------------------- IPC_CONNECTING_WIFI(5)
[2024/8/7 9:02:30 220] [1970-01-01 00:00:26] tuya_ipc_system_control_demo.c(492) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECTING, 0, 0, 0, 1))
[2024/8/7 9:02:30 236] [1970-01-01 00:00:26] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/RouterConnect_english.pcm]
[2024/8/7 9:02:30 252] [1970-01-01 00:00:26] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:02:30 252] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:02:30 268] --- tracepoint MainApp.c,ConfigTimer(372): g_WifiConectStatuts 1 ---
[2024/8/7 9:02:30 268] [1970-01-01 00:00:26] MainApp.c(373) <ConfigTimer>: ConfigTimer exit ----
[2024/8/7 9:02:30 268] [01-01 18:12:30 TUYA I][bt_ext_porting.c:618] [TUYA-BTUART]ble_monitor_thread exit
[2024/8/7 9:02:30 284] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:02:30 427] [atbm_log]:[eth2] change to [2]
[2024/8/7 9:02:30 427] [atbm_log]:[eth2] has been disabled
[2024/8/7 9:02:30 875] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 ++++++++ 
[2024/8/7 9:02:30 891] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 --------- 
[2024/8/7 9:02:30 891] [atbm_log]:atbm_hw_scan:if_id(0)
[2024/8/7 9:02:30 891] [atbm_log]:atbm_hw_scan:scan, delay suspend
[2024/8/7 9:02:30 907] [atbm_log]:scan start band(0),(14)
[2024/8/7 9:02:30 907] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:02:30 907] set basic_indicator_onoff:0 
[2024/8/7 9:02:30 924] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(257) <IPC_APP_set_basic_indicator_onoff>: Get BasicIndicator suc,gpio value=[0x0c]
[2024/8/7 9:02:30 939] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:30 940] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:30 940] set basic_indicator_onoff:1 
[2024/8/7 9:02:30 955] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:30 955] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:30 971] set basic_indicator_onoff:0 
[2024/8/7 9:02:30 971] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:30 988] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:30 988] set basic_indicator_onoff:1 
[2024/8/7 9:02:30 988] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 003] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:31 003] set basic_indicator_onoff:0 
[2024/8/7 9:02:31 019] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 019] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:31 019] set basic_indicator_onoff:1 
[2024/8/7 9:02:31 035] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 035] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:31 052] set basic_indicator_onoff:0 
[2024/8/7 9:02:31 052] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 067] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:31 067] set basic_indicator_onoff:1 
[2024/8/7 9:02:31 067] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 084] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:31 084] set basic_indicator_onoff:0 
[2024/8/7 9:02:31 100] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 100] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:31 116] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:31 116] [01-01 18:12:31 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:02:31 116] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1376] nw stat change:1->1, rpt to app.
[2024/8/7 9:02:31 132] [01-01 18:12:31 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:1
[2024/8/7 9:02:31 132] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:31 148] [01-01 18:12:31 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:02:31 148] bt_ack_uncrypt 1
[2024/8/7 9:02:31 148] 01 
[2024/8/7 9:02:31 148] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:31 420] set basic_indicator_onoff:1 
[2024/8/7 9:02:31 435] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 435] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:31 435] set basic_indicator_onoff:0 
[2024/8/7 9:02:31 451] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 452] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:31 467] set basic_indicator_onoff:1 
[2024/8/7 9:02:31 467] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 483] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:31 483] set basic_indicator_onoff:0 
[2024/8/7 9:02:31 483] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:31 499] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:31 515] g_AudioTipsList.size() enable: 0[01-01 18:12:32 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:02:32 267] [atbm_log]:hw_priv->scan.status 0
[2024/8/7 9:02:32 332] [atbm_log]:atbm_scan_work:end(0)
[2024/8/7 9:02:32 332] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:02:32 347] [atbm_log]:authen:(a4:a9:30:ce:5e:66),ssid(Xiaomi_F1DC)
[2024/8/7 9:02:32 347] [atbm_log]:authenticate[a4:a9:30:ce:5e:66]:[0][1]
[2024/8/7 9:02:32 347] [atbm_log]:eth2: authenticate with a4:a9:30:ce:5e:66 (try 1) (1)(0)
[2024/8/7 9:02:32 364] [atbm_log]:[STA] Join DTIM: 1, interval: 100
[2024/8/7 9:02:32 380] [atbm_log]:[TX]:authen, delay suspend
[2024/8/7 9:02:32 395] [atbm_log]:eth2: authenticated
[2024/8/7 9:02:32 395] [atbm_log]:work:flush sta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:32 444] [atbm_log]:sta has been insert(0)
[2024/8/7 9:02:32 444] [atbm_log]:wk->assoc.use_he 1 1++
[2024/8/7 9:02:32 444] [atbm_log]:flush sta(0):
[2024/8/7 9:02:32 460] [atbm_log]:eth2: associated
[2024/8/7 9:02:32 460] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:02:32 460] [atbm_log]:eth2:free authen bss --
[2024/8/7 9:02:32 475] [atbm_log]:is_wifi6_ap++
[2024/8/7 9:02:32 475] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:02:32 475] [atbm_log]:eth2  WMM AC=0 acm=0 aifs=2 cWmin=3 cWmax=7 txop=47 uapsd=0
[2024/8/7 9:02:32 492] [atbm_log]:eth2  WMM AC=1 acm=0 aifs=2 cWmin=7 cWmax=15 txop=94 uapsd=0
[2024/8/7 9:02:32 507] [atbm_log]:eth2  WMM AC=2 acm=0 aifs=3 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:02:32 507] [atbm_log]:eth2  WMM AC=3 acm=0 aifs=7 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:02:32 507] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:02:32 523] [atbm_log]:[a4:a9:30:ce:5e:66]:20M channel
[2024/8/7 9:02:32 523] [atbm_log]:atbm_bss_info_changed:chatype(1),channelNumber(3)
[2024/8/7 9:02:32 523] [atbm_log]:BssidColor[34]
[2024/8/7 9:02:32 539] [atbm_log]:[STA] color 34, he_support_flag: 53
[2024/8/7 9:02:32 539] [atbm_log]:==>connect wifi6 AP open AX, set BA WIN short
[2024/8/7 9:02:32 539] [atbm_log]:[eth2] Waiting Txq Ready[1]
[2024/8/7 9:02:32 571] [atbm_log]:[eth2]:dtim changed [0]->[1]
[2024/8/7 9:02:32 587] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:02:32 652] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:02:32 652] NOHZ: local_softirq_pending 08
[2024/8/7 9:02:32 652] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:02:32 668] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:02:32 668] [atbm_log]:send htc qos null
[2024/8/7 9:02:32 668] [atbm_log]:om work(1)
[2024/8/7 9:02:32 908] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:02:32 908] [atbm_log]:send htc qos null
[2024/8/7 9:02:32 908] [atbm_log]:om work(2)
[2024/8/7 9:02:33 036] [atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:02:33 052] [atbm_log]:aggtx stop queue
[2024/8/7 9:02:33 052] [atbm_log]:add to pending(2)(20)
[2024/8/7 9:02:33 052] [atbm_log]:dhcp work(1)
[2024/8/7 9:02:33 148] [atbm_log]:AMPDU[eth2]:action[2],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:33 164] [atbm_log]:activated addBA response timer on tid 0
[2024/8/7 9:02:33 164] [atbm_log]:aggtx wake queue
[2024/8/7 9:02:33 164] [atbm_log]:sta_hdr
[2024/8/7 9:02:33 164] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:02:33 179] [atbm_log]:send htc qos null
[2024/8/7 9:02:33 179] [atbm_log]:om work(3)
[2024/8/7 9:02:33 179] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:02:33 179] [atbm_log]:dhcp done
[2024/8/7 9:02:33 180] [atbm_log]:switched off addBA timer for tid 0
[2024/8/7 9:02:33 196] [atbm_log]:Aggregation is on for tid 0
[2024/8/7 9:02:33 196] [atbm_log]:AMPDU[eth2]:action[4],tid[0],ssn[0],buff_size[64],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:33 211] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[6]
[2024/8/7 9:02:33 211] [atbm_log]:AMPDU[eth2]:action[0],tid[6],ssn[1],buff_size[64],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:33 212] [atbm_log]:Rx A-MPDU request on tid 6 result 0
[2024/8/7 9:02:33 227] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[0]
[2024/8/7 9:02:33 227] [atbm_log]:AMPDU[eth2]:action[0],tid[0],ssn[0],buff_size[64],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:33 275] [atbm_log]:Rx A-MPDU request on tid 0 result 0
[2024/8/7 9:02:33 275] [atbm_log]:dhcp work(1)
[2024/8/7 9:02:33 275] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:02:33 339] [atbm_log]:dhcp doneroute: SIOCDELRT: No such process
[2024/8/7 9:02:33 339] [atbm_log]:connecting done for waitting dhcp  
[2024/8/7 9:02:33 420] set basic_indica[atbm_log]:QosNUll Htc(807)
[2024/8/7 9:02:33 420] tor_onoff:1 
[2024/8/7 9:02:33 420] [197[atbm_log]:send htc qos null
[2024/8/7 9:02:33 420] 0-01-01 00:00:28[atbm_log]:om work(4)
[2024/8/7 9:02:33 436] ] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 436] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 452] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 452] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 468] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 468] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 468] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 484] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 484] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 500] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 500] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 500] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 516] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 516] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 532] [1970-01-01 00:00:28] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:02:33 532] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:02:33 548] [1970-01-01 00:00:28] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:33 548] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 564] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 564] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 564] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 580] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 580] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 596] [1970-01-01 00:00:28] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time28818
[2024/8/7 9:02:33 596] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 612] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 612] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 612] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 628] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 628] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 644] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 644] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 660] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 660] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 676] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag[atbm_log]:om done
[2024/8/7 9:02:33 676] =false
[2024/8/7 9:02:33 676] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 676] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 691] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 691] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 707] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:33 707] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 726] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 726] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 726] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 739] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 739] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 739] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 755] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 755] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 771] 
[2024/8/7 9:02:33 772] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 772] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 787] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 899] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 916] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 916] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 916] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 931] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 931] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 931] set basic_indicator_onoff:1 
[2024/8/7 9:02:33 948] [1970-01-01 00:00:30] tuya_ipc_dp_[atbm_log]:<WIFI> rx ampdu ++ 
[2024/8/7 9:02:33 948] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[5]
[2024/8/7 9:02:33 963] [atbm_log]:AMPDU[eth2]:action[0],tid[5],ssn[3],buff_size[64],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:33 963] handler.c(262) <IPC_APP_[atbm_log]:napi schedule
[2024/8/7 9:02:33 963] set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 979] [[atbm_log]:Rx A-MPDU request on tid 5 result 0
[2024/8/7 9:02:33 979] 1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:33 979] set basic_indicator_onoff:0 
[2024/8/7 9:02:33 995] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:33 995] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:33 995] set basic_indicator_onoff:1 
[2024/8/7 9:02:34 011] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:34 027] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:34 028] 
[2024/8/7 9:02:34 028] curr event:6 
[2024/8/7 9:02:34 028] IPC_APP_Notify_LED_Sound_Status_CB line(497) -------------------------- IPC_CONNECT_WIFI_SUCCESS(6)
[2024/8/7 9:02:34 044] [1970-01-01 00:00:30] tuya_ipc_system_control_demo.c(498) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECT_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:02:34 060] [01-01 18:12:34 TUYA D][tuya_devos_netlink.c:313] wf connect success!
[2024/8/7 9:02:34 060] [01-01 18:12:34 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:02:34 076] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:02:34 076] [01-01 18:12:34 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:02:34 077] [01-01 18:12:34 TUYA E][mqtt_client.c:807] hand null.
[2024/8/7 9:02:34 092] [01-01 18:12:34 TUYA D][tuya_iot_wired_wifi_api.c:584] wired wifi default stat:1,change:1
[2024/8/7 9:02:34 092] [01-01 18:12:34 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[2024/8/7 9:02:34 107] [01-01 18:12:34 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[2024/8/7 9:02:34 108] [01-01 18:12:34 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:02:34 108] dev id key: 16
[2024/8/7 9:02:34 124] c0 b9 30 cc 91 82 20 e0 27 d3 45 b3 ab 3c 27 bf 
[2024/8/7 9:02:34 124] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:02:34 124] [01-01 18:12:34 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:02:34 140] 2 1 6 3 2 1 a2 14 16 1 a2 0 1c 6a 97 74 ce 42 f4 54 8c 72 2e 92 d 9f a1 db 
[2024/8/7 9:02:34 140] [01-01 18:12:34 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:02:34 156] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 30 7b 27 8c c6 8b 14 13 8e 36 f6 75 73 7d 4b 
[2024/8/7 9:02:34 156] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:02:34 172] [01-01 18:12:34 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:02:34 172] [01-01 18:12:34 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:02:34 188] [01-01 18:12:34 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:34 188] tuya_hal_bt_send 20
[2024/8/7 9:02:34 188] 00 21 33 05 f9 96 fc 1e e0 66 2c 0e 7b 8c ca 30 42 8f bc 9f 
[2024/8/7 9:02:34 188] [01-01 18:12:34 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:34 203] 0 21 33 5 f9 96 fc 1e e0 66 2c e 7b 8c ca 30 42 8f bc 9f 
[2024/8/7 9:02:34 204] XmBleSendBuf 20: 00 21 33 05 f9 96 fc 1e e0 66 2c 0e 7b 8c ca 30 42 8f bc 9f
[2024/8/7 9:02:34 204] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:34 220] ble_slave_gap_event->type=13
[2024/8/7 9:02:34 220] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:34 220] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:34 236] [01-01 18:12:34 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:34 236] [01-01 18:12:34 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:02:34 236] [01-01 18:12:34 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:34 252] [01-01 18:12:34 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:34 252] [01-01 18:12:34 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:34 252] [01-01 18:12:34 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:34 268] [01-01 18:12:34 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:34 268] [01-01 18:12:34 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:34 283] [01-01 18:12:34 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:34 284] [01-01 18:12:34 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:34 284] [01-01 18:12:34 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:34 300] [01-01 18:12:34 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:34 300] [01-01 18:12:34 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:02:34 331] [01-01 18:12:34 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:02:34 332] [01-01 18:12:34 TUYA D][iot_httpc.c:1435] sign_buffer:env=1LEg&region=AY&ts=19&uuid=uuidcaab27b0a838d239
[2024/8/7 9:02:34 347] [01-01 18:12:34 TUYA D][iot_httpc.c:1443] sign_base64_encode:+ZqBIKbBZgf45EGa9SNaUedVSWuK0sNcj2Y3o/b73zA=
[2024/8/7 9:02:34 347] [01-01 18:12:34 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:02:34 379] [01-01 18:12:34 TUYA D][iot_httpc.c:1514] http_dns send: {"region":"AY","env":"1LEg","uuid":"uuidcaab27b0a838d239","ts":19,"sign":"+ZqBIKbBZgf45EGa9SNaUedVSWuK0sNcj2Y3o/b73zA=","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:02:34 395] [01-01 18:12:34 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v2/url_config
[2024/8/7 9:02:34 395] [01-01 18:12:34 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:02:34 395] [01-01 18:12:34 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:02:34 411] [01-01 18:12:34 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:02:34 411] [01-01 18:12:34 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:02:34 427] [1970-01-01 00:00:30] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/ServerConnect_english.pcm]
[2024/8/7 9:02:34 443] [1970-01-01 00:00:30] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:02:34 443] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:02:34 459] [01-01 18:12:34 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:02:34 459] [01-01 18:12:34 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:34 475] [01-01 18:12:34 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:02:34 475] tuya_hal_bt_send 17
[2024/8/7 9:02:34 475] 01 de 65 26 42 11 6a 4b 47 f9 cb 66 9d 20 7c eb 04 
[2024/8/7 9:02:34 475] [01-01 18:12:34 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:34 492] 1 de 65 26 42 11 6a 4b 47 f9 cb 66 9d 20 7c eb 4 
[2024/8/7 9:02:34 492] XmBleSendBuf 17: 01 de 65 26 42 11 6a 4b 47 f9 cb 66 9d 20 7c eb 04
[2024/8/7 9:02:34 492] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:34 492] ble_slave_gap_event->type=13
[2024/8/7 9:02:34 508] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:34 508] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:34 508] [01-01 18:12:34 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:34 524] [01-01 18:12:34 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:34 524] [01-01 18:12:34 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:34 540] [01-01 18:12:34 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:02:34 540] set basic_indicator_onoff:0 
[2024/8/7 9:02:34 556] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:34 556] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:34 572] [01-01 18:12:34 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:02:34 572] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:34 588] [01-01 18:12:34 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:34 588] set basic_indicator_onoff:1 
[2024/8/7 9:02:34 588] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:34 604] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:34 604] set basic_indicator_onoff:0 
[2024/8/7 9:02:34 620] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:34 620] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:34 620] set basic_indicator_onoff:1 
[2024/8/7 9:02:34 636] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:34 636] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:34 652] [01-01 18:12:35 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:02:34 668] [01-01 18:12:35 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:34 668] [01-01 18:12:35 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:02:34 668] [01-01 18:12:35 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:34 684] [01-01 18:12:35 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:34 684] [01-01 18:12:35 TUYA D][iot_httpc.c:1578] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216]
[2024/8/7 9:02:34 700] [01-01 18:12:35 TUYA D][iot_httpc.c:1579] mqttUrl:[m2.tuyacn.com:1883][42.192.30.165]
[2024/8/7 9:02:34 700] [01-01 18:12:35 TUYA D][iot_httpc.c:1602] httpsSelfUrl:[https://a2.tuyacn.com/d.json][42.192.31.36]
[2024/8/7 9:02:34 716] [01-01 18:12:35 TUYA D][iot_httpc.c:1603] mqttsSelfUrl:[m2.tuyacn.com:8883][42.192.30.165]
[2024/8/7 9:02:34 716] [01-01 18:12:35 TUYA D][iot_httpc.c:1670] ghostUrl:[baal.tuyacn.com:443][42.192.35.108]
[2024/8/7 9:02:34 732] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:02:34 732] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:34 732] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:02:34 748] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:02:34 748] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:02:34 764] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:02:34 764] [01-01 18:12:35 TUYA D][iot_httpc.c:1684] tls_ca_name:tls_ca0
[2024/8/7 9:02:34 764] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:02:34 780] [01-01 18:12:35 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:34 780] [01-01 18:12:35 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:34 780] [01-01 18:12:35 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:34 796] [01-01 18:12:35 TUYA D][simplekv.c:374] write key:tls_ca0 And Value Len:2688
[2024/8/7 9:02:34 796] [01-01 18:12:35 TUYA D][simplekv.c:457] new space 8 startpos:30428 size:2756
[2024/8/7 9:02:34 811] [01-01 18:12:35 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:34 811] [01-01 18:12:35 TUYA D][simplekv.c:203] update crc 1395591596
[2024/8/7 9:02:34 812] [01-01 18:12:35 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:34 828] [01-01 18:12:35 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:34 828] set basic_indicator_onoff:0 
[2024/8/7 9:02:34 828] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:34 843] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:34 844] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:34 859] [01-01 18:12:35 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:34 859] [01-01 18:12:35 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:34 859] [01-01 18:12:35 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:34 875] [01-01 18:12:35 TUYA D][simplekv.c:374] write key:tls_ca_cnt And Value Len:16
[2024/8/7 9:02:34 875] [01-01 18:12:35 TUYA D][simplekv.c:457] new space 9 startpos:33184 size:84
[2024/8/7 9:02:34 891] [01-01 18:12:35 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:34 891] [01-01 18:12:35 TUYA D][simplekv.c:203] update crc 213719394
[2024/8/7 9:02:34 891] set basic_indicator_onoff:1 
[2024/8/7 9:02:34 908] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:34 908] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:34 924] [01-01 18:12:35 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:34 924] [01-01 18:12:35 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:34 924] [01-01 18:12:35 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:02:34 941] [01-01 18:12:35 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216]
[2024/8/7 9:02:34 956] [01-01 18:12:35 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36]
[2024/8/7 9:02:34 956] [01-01 18:12:35 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165]
[2024/8/7 9:02:34 972] [01-01 18:12:35 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[42.192.30.165]
[2024/8/7 9:02:34 972] [01-01 18:12:35 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108]
[2024/8/7 9:02:34 987] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:02:34 988] [01-01 18:12:35 TUYA D][simplekv.c:1251] find key:9 tls_ca_cnt
[2024/8/7 9:02:34 988] [01-01 18:12:35 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[2024/8/7 9:02:35 003] [01-01 18:12:35 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[2024/8/7 9:02:35 003] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:02:35 003] [01-01 18:12:35 TUYA D][simplekv.c:1251] find key:8 tls_ca0
[2024/8/7 9:02:35 019] [01-01 18:12:35 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688
[2024/8/7 9:02:35 019] [01-01 18:12:35 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
[2024/8/7 9:02:35 019] [01-01 18:12:35 TUYA D][iot_httpc.c:1696] end
[2024/8/7 9:02:35 035] [01-01 18:12:35 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:02:35 035] [01-01 18:12:35 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:35 051] [01-01 18:12:35 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:02:35 051] bt_ack_uncrypt 2
[2024/8/7 9:02:35 051] 00 00 
[2024/8/7 9:02:35 051] [01-01 18:12:35 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:35 067] [01-01 18:12:35 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:35 067] tuya_hal_bt_send 20
[2024/8/7 9:02:35 067] 00 21 34 02 08 6a 0c 35 2c b1 2a d1 3c ab c5 ef 54 55 53 83 
[2024/8/7 9:02:35 083] [01-01 18:12:35 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:35 083] 0 21 34 2 8 6a c 35 2c b1 2a d1 3c ab c5 ef 54 55 53 83 
[2024/8/7 9:02:35 083] XmBleSendBuf 20: 00 21 34 02 08 6a 0c 35 2c b1 2a d1 3c ab c5 ef 54 55 53 83
[2024/8/7 9:02:35 100] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:35 100] ble_slave_gap_event->type=13
[2024/8/7 9:02:35 100] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:35 100] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:35 116] [01-01 18:12:35 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:35 116] [01-01 18:12:35 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:02:35 116] tuya_hal_bt_send 17
[2024/8/7 9:02:35 132] 01 3a 45 2a d6 a1 37 3e be 74 d3 17 82 9b 12 c0 e8 
[2024/8/7 9:02:35 132] [01-01 18:12:35 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:35 132] 1 3a 45 2a d6 a1 37 3e be 74 d3 17 82 9b 12 c0 e8 
[2024/8/7 9:02:35 148] XmBleSendBuf 17: 01 3a 45 2a d6 a1 37 3e be 74 d3 17 82 9b 12 c0 e8
[2024/8/7 9:02:35 148] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:35 149] ble_slave_gap_event->type=13
[2024/8/7 9:02:35 149] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:35 164] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:35 164] [01-01 18:12:35 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:35 179] [01-01 18:12:35 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:02:35 179] [01-01 18:12:35 TUYA D][tuya_devos_activate.c:356] dev_nw_cfg_active_stage:5
[2024/8/7 9:02:35 179] [01-01 18:12:35 TUYA D][iot_httpc.c:3195] modules:(null)
[2024/8/7 9:02:35 196] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:last_reset_info isFuzzy:0 skipCnt:0
[2024/8/7 9:02:35 196] [01-01 18:12:35 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:35 211] [01-01 18:12:35 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:35 211] [01-01 18:12:35 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:35 229] [01-01 18:12:35 TUYA D][iot_httpc.c:3198] options:{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}
[2024/8/7 9:02:35 292] [01-01 18:12:35 TUYA D][iot_httpc.c:1161] Post Data: {"token":"Mah1ZEhq","softVer":"1.5.431","productKey":"fvijo8jvloagv1gm","protocolVer":"2.2","baselineVer":"40.00","hid":"90314ba51650","skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}}","devAttribute":67,"cadVer":"1.0.4","cdVer":"1.0.0","options":"{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}","t":20}
[2024/8/7 9:02:35 308] [01-01 18:12:35 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.active&et=1&t=20&uuid=uuidcaab27b0a838d239&v=4.4&sign=3e4f1719f250f8ca9634eeda33a5dbef
[2024/8/7 9:02:35 308] [01-01 18:12:35 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:35 308] [01-01 18:12:35 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:35 324] [01-01 18:12:35 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:35 324] [01-01 18:12:35 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:35 340] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:35 340] set basic_indicator_onoff:0 
[2024/8/7 9:02:35 355] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 356] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:35 371] [01-01 18:12:35 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:35 372] [01-01 18:12:35 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:35 388] [01-01 18:12:35 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:35 388] [01-01 18:12:35 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:35 388] [01-01 18:12:35 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:35 404] [01-01 18:12:35 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:35 404] [01-01 18:12:35 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:35 420] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:35 436] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:35 436] Len=20 step 0
[2024/8/7 9:02:35 436] att=0x0 0x21 0x20 0x2 0xe5 0xdf 0xcb 0xb7 0x36 0xa6 0x62 0xe0 0x89 0x21 0xac 0xc8 0xed 0xfb 0x65 0xea 
[2024/8/7 9:02:35 436]  RCVS len:20
[2024/8/7 9:02:35 451] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:35 452] set basic_indicator_onoff:1 
[2024/8/7 9:02:35 467] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 468] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:35 468] XmBleReadBuf 20:
[2024/8/7 9:02:35 468] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:35 483] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:35 483] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:35 484] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:35 499] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:35 500] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:35 515] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:35 515] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:35 515] bt_rev_raw 20
[2024/8/7 9:02:35 531] 00 21 20 02 e5 df cb b7 36 a6 62 e0 89 21 ac c8 ed fb 65 ea 
[2024/8/7 9:02:35 532] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:02:35 547] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:35 547] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:35 547] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:35 563] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:35 563] Len=17 step 0
[2024/8/7 9:02:35 563] att=0x1 0x38 0x2 0xb0 0x59 0xd8 0xc8 0x7c 0x8 0xd2 0x91 0xad 0x12 0x5d 0xd8 0x97 0xe9 
[2024/8/7 9:02:35 563]  RCVS len:17
[2024/8/7 9:02:35 579] set basic_indicator_onoff:0 
[2024/8/7 9:02:35 579] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 595] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:35 595] XmBleReadBuf 17:
[2024/8/7 9:02:35 595] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:35 595] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:35 611] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:35 612] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:02:35 612] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:02:35 627] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:02:35 627] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:35 643] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:35 643] bt_rev_raw 17
[2024/8/7 9:02:35 643] 01 38 02 b0 59 d8 c8 7c 08 d2 91 ad 12 5d d8 97 e9 
[2024/8/7 9:02:35 659] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:02:35 659] ble rev data 33
[2024/8/7 9:02:35 659] 02 e5 df cb b7 36 a6 62 e0 89 21 ac c8 ed fb 65 ea 38 02 b0 59 d8 c8 7c 08 d2 91 ad 12 5d d8 97 e9 
[2024/8/7 9:02:35 676] ble decryped data 16
[2024/8/7 9:02:35 676] 00 00 00 04 00 00 00 00 00 22 00 01 00 d6 49 00 
[2024/8/7 9:02:35 676] [01-01 18:12:35 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:35 692] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:02:35 692] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:02:35 692] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:02:35 708] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:35 708] [1970-01-01 00:00:31] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:35 723] set basic_indicator_onoff:1 
[2024/8/7 9:02:35 724] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 740] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:35 740] [01-01 18:12:35 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:35 755] [01-01 18:12:35 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:35 851] set basic_indicator_onoff:0 
[2024/8/7 9:02:35 867] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 867] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:35 883] set basic_indicator_onoff:1 
[2024/8/7 9:02:35 883] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 899] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:35 899] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:2
[2024/8/7 9:02:35 899] set basic_indicator_onoff:0 
[2024/8/7 9:02:35 915] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 915] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:35 931] set basic_indicator_onoff:1 
[2024/8/7 9:02:35 931] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 947] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:35 947] set basic_indicator_onoff:0 
[2024/8/7 9:02:35 947] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 963] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:35 963] set basic_indicator_onoff:1 
[2024/8/7 9:02:35 979] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:35 979] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:36 075] [01-01 18:12:36 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"capability":1,"devId":"6c96f4208f733a0b737eix","dstIntervals":[],"localKey":"e*HtZQ*3*LSN07F$","resetFactory":false,"schema":"[{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":103,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":104,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"range\":[\"0\",\"1\",\"2\"],\"type\":\"enum\"},\"id\":106,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":109,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"min\":1,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":110,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":111,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":113,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\
[2024/8/7 9:02:36 075] [08-07 19:14:53 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:36 075] [08-07 19:14:53 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:36 091] [08-07 19:14:53 TUYA D][tuya_devos_activate.c:210] cloud_reset:0 local_reset:1
[2024/8/7 9:02:36 091] [08-07 19:14:53 TUYA D][tuya_devos_activate.c:256] __tmm_gw_actv_work: reset stride flag.
[2024/8/7 9:02:36 107] [08-07 19:14:53 TUYA D][tuya_devos_entry.c:1477] write stride to flash:0
[2024/8/7 9:02:36 107] [08-07 19:14:53 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 9:02:36 123] [08-07 19:14:53 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:36 123] [08-07 19:14:53 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:36 123] [08-07 19:14:53 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:36 139] [08-07 19:14:53 TUYA D][simplekv.c:374] write key:is_stride And Value Len:16
[2024/8/7 9:02:36 139] [08-07 19:14:53 TUYA D][simplekv.c:457] new space 10 startpos:33268 size:84
[2024/8/7 9:02:36 155] [08-07 19:14:53 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:36 155] [08-07 19:14:53 TUYA D][simplekv.c:203] update crc 1143988772
[2024/8/7 9:02:36 155] [08-07 19:14:53 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:36 171] [08-07 19:14:53 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:36 171] [08-07 19:14:53 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:02:36 171] [08-07 19:14:53 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 9:02:36 188] [08-07 19:14:53 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 9:02:36 188] [08-07 19:14:53 TUYA D][simplekv.c:374] write key:gw_di And Value Len:416
[2024/8/7 9:02:36 203] [08-07 19:14:53 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416
[2024/8/7 9:02:36 203] [08-07 19:14:53 TUYA D][simplekv.c:430] find 2 available space
[2024/8/7 9:02:36 203] [08-07 19:14:53 TUYA D][simplekv.c:474] reuse available space 29188
[2024/8/7 9:02:36 221] [08-07 19:14:53 TUYA D][simplekv.c:203] update crc 1018420927
[2024/8/7 9:02:36 221] g_AudioTipsList.size() enable: 0[08-07 19:14:53 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:02:36 236] [08-07 19:14:53 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:36 236] [08-07 19:14:53 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:36 236] [08-07 19:14:53 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:02:36 253] [08-07 19:14:53 TUYA D][simplekv.c:1211] read key:flvlrc isFuzzy:0 skipCnt:0
[2024/8/7 9:02:36 253] [08-07 19:14:53 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:36 253] [08-07 19:14:53 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:36 268] [08-07 19:14:53 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:36 269] [08-07 19:14:53 TUYA D][simplekv.c:374] write key:flvlrc And Value Len:2928
[2024/8/7 9:02:36 284] [08-07 19:14:53 TUYA D][simplekv.c:457] new space 11 startpos:33352 size:2996
[2024/8/7 9:02:36 285] [08-07 19:14:53 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:36 285] [08-07 19:14:53 TUYA D][simplekv.c:203] update crc 2123005537
[2024/8/7 9:02:36 301] [08-07 19:14:53 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:36 301] [08-07 19:14:53 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:36 316] [08-07 19:14:53 TUYA D][ws_db_gw.c:670] schema write success
[2024/8/7 9:02:36 318] [08-07 19:14:53 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success 
[2024/8/7 9:02:36 318] [08-07 19:14:53 TUYA D][tuya_ipc_sdk_init.c:183] ON post active:0x1951800
[2024/8/7 9:02:36 332] [08-07 19:14:53 TUYA D][tuya_ipc_sdk_init.c:172] skillResult p2pId:[]
[2024/8/7 9:02:36 332] [08-07 19:14:53 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:02:36 332] [08-07 19:14:53 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 9:02:36 348] [08-07 19:14:53 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[2024/8/7 9:02:36 348] [08-07 19:14:53 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:544
[2024/8/7 9:02:36 363] [08-07 19:14:53 TUYA D][simplekv.c:394] 4 key same BUT size old 436 < new 544 need find new hd
[2024/8/7 9:02:36 364] [08-07 19:14:53 TUYA D][simplekv.c:457] new space 12 startpos:36348 size:612
[2024/8/7 9:02:36 380] [08-07 19:14:53 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:36 380] [08-07 19:14:53 TUYA D][simplekv.c:203] update crc 1431025971
[2024/8/7 9:02:36 380] set basic_indicator_onoff:0 
[2024/8/7 9:02:36 396] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:36 396] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:36 412] [08-07 19:14:53 TUYA D][app_agent.c:706] udp ip: 192.168.31.144
[2024/8/7 9:02:36 412] [08-07 19:14:53 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:36 412] [08-07 19:14:53 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:36 428] [08-07 19:14:53 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:02:36 444] [08-07 19:14:53 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":9,"ssid":"WGlhb21pX0YxREM=","passwd":"eG01MTI1MjA=","md":0,"random":0,"wfb64":1,"stat":2,"token":"Mah1ZEhq","region":"AY","reg_key":"1LEg","dns_prio":0 }
[2024/8/7 9:02:36 444] [08-07 19:14:53 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:02:36 459] [08-07 19:14:53 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:02:36 460] [08-07 19:14:53 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:02:36 460] [08-07 19:14:53 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:176
[2024/8/7 9:02:36 476] [08-07 19:14:53 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 176
[2024/8/7 9:02:36 476] [08-07 19:14:53 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:02:36 492] [08-07 19:14:53 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:02:36 492] [08-07 19:14:53 TUYA D][simplekv.c:203] update crc 66692921
[2024/8/7 9:02:36 492] [08-07 19:14:53 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:36 508] [08-07 19:14:53 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:36 508] [08-07 19:14:53 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:02:36 508] __IPC_APP_Get_Net_Status_cb line(188) -------------------------- stat(1)==STAT_UNPROVISION 
[2024/8/7 9:02:36 523] [08-07 19:14:53 TUYA D][wifi_netcfg_frame_transporter.c:472] ----destroy Transporter,session:0x190d7e0
[2024/8/7 9:02:36 524] [08-07 19:14:53 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:02:36 539] [08-07 19:14:53 TUYA N][bt_dp.c:228] bt rpt conn stat:9
[2024/8/7 9:02:36 539] [08-07 19:14:53 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:36 555] [08-07 19:14:53 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:02:36 555] bt_ack_uncrypt 2
[2024/8/7 9:02:36 555] 00 09 
[2024/8/7 9:02:36 555] [08-07 19:14:53 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:36 555] [08-07 19:14:53 TUYA D][tuya_devos_entry.c:560] dev_nw_cfg_active_stage:6
[2024/8/7 9:02:36 571] __IPC_APP_Get_Net_Status_cb line(198) -------------------------- stat(3)==STAT_AP_STA_DISC 
[2024/8/7 9:02:36 571] [08-07 19:14:53 TUYA D][tuya_ble_api.c:1005] start to get mesh
[2024/8/7 9:02:36 587] [08-07 19:14:53 TUYA N][tuya_bt_sdk.c:171] ty bt upd localkey
[2024/8/7 9:02:36 587] [08-07 19:14:53 TUYA N][tuya_ble_api.c:425] upd login key len:6
[2024/8/7 9:02:36 587] [08-07 19:14:53 TUYA I][mqc_app.c:387] mqc app start ...
[2024/8/7 9:02:36 603] [08-07 19:14:53 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883
[2024/8/7 9:02:36 603] [08-07 19:14:53 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992558}
[2024/8/7 9:02:36 619] [08-07 19:14:53 TUYA D][mqc_app.c:473] TLS disable
[2024/8/7 9:02:36 620] [08-07 19:14:53 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:02:36 635] [08-07 19:14:53 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.mesh.get&devId=6c96f4208f733a0b737eix&et=1&t=1722992558&v=1.0&sign=6e21f71cf7657ab89a40bd6cf88bb63e
[2024/8/7 9:02:36 651] [08-07 19:14:53 TUYA D][mqtt_client.c:321] subcribe_topic:smart/device/in/6c96f4208f733a0b737eix, client_id:6c96f4208f733a0b737eix, user_name:6c96f4208f733a0b737eix, passwd:af214283f5ba6347
[2024/8/7 9:02:36 651] [08-07 19:14:53 TUYA D][mqtt_client.c:352] domain<0> m2.tuyacn.com:8883 HAVE PORT
[2024/8/7 9:02:36 667] [08-07 19:14:53 TUYA D][mqtt_client.c:355] PARSE m2.tuyacn.com:8883
[2024/8/7 9:02:36 667] [08-07 19:14:53 TUYA D][mqtt_client.c:383] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT
[2024/8/7 9:02:36 683] [08-07 19:14:53 TUYA D][mqtt_client.c:386] PARSE m2.tuyacn.com:1883
[2024/8/7 9:02:36 683] [08-07 19:14:53 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:36 699] [08-07 19:14:53 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:36 699] [08-07 19:14:53 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6c96f4208f733a0b737eix
[2024/8/7 9:02:36 715] [08-07 19:14:53 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6c96f4208f733a0b737eix
[2024/8/7 9:02:36 715] [08-07 19:14:53 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:36 715] [08-07 19:14:53 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:36 731] [08-07 19:14:53 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:25600,priority:4
[2024/8/7 9:02:36 731] [08-07 19:14:53 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[2024/8/7 9:02:36 747] [08-07 19:14:53 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[2024/8/7 9:02:36 747] [08-07 19:14:53 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[2024/8/7 9:02:36 763] [08-07 19:14:53 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:02:36 763] [08-07 19:14:53 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:36 763] [08-07 19:14:53 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:36 779] [08-07 19:14:53 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:36 779] [08-07 19:14:53 TUYA D][tuya_svc_timer_task.c:146] no timer
[2024/8/7 9:02:36 779] [08-07 19:14:53 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[2024/8/7 9:02:36 795] [08-07 19:14:53 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[2024/8/7 9:02:36 795] [08-07 19:14:53 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[2024/8/7 9:02:36 811] [08-07 19:14:53 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6c96f4208f733a0b737eix
[2024/8/7 9:02:36 811] [08-07 19:14:53 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6c96f4208f733a0b737eix
[2024/8/7 9:02:36 827] [08-07 19:14:53 TUYA D][svc_online_log.c:317] svc online log active success
[2024/8/7 9:02:36 828] [08-07 09:02:38 TUYA D][tuya_ipc_sdk_init.c:137] sys stop timer: 14
[2024/8/7 9:02:36 828] [08-07 09:02:38 TUYA D][tuya_ipc_sdk_init.c:140] sys delete timer: 14
[2024/8/7 9:02:36 843] [08-07 09:02:38 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:36 843] tuya_hal_bt_send 20
[2024/8/7 9:02:36 843] 00 21 35 02 e5 85 68 e3 03 d5 41 83 f2 4e 7c 38 aa c2 4f 02 
[2024/8/7 9:02:36 859] [08-07 09:02:38 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:36 859] 0 21 35 2 e5 85 68 e3 3 d5 41 83 f2 4e 7c 38 aa c2 4f 2 
[2024/8/7 9:02:36 859] XmBleSendBuf 20: 00 21 35 02 e5 85 68 e3 03 d5 41 83 f2 4e 7c 38 aa c2 4f 02
[2024/8/7 9:02:36 875] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:36 875] ble_slave_gap_event->type=13
[2024/8/7 9:02:36 875] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:36 875] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:36 891] [08-07 09:02:38 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:36 891] [08-07 09:02:38 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[2024/8/7 9:02:36 908] [08-07 09:02:38 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:02:36 908] [08-07 09:02:38 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:02:36 924] [08-07 09:02:38 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:02:36 924] [08-07 09:02:38 TUYA D][tuya_ipc_p2p_common.c:530] p2p passwd change to adb2c7ae
[2024/8/7 9:02:36 940] [08-07 09:02:38 TUYA D][iot_httpc.c:1161] Post Data: {"password":"adb2c7ae","t":1722992558}
[2024/8/7 9:02:36 955] [08-07 09:02:38 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.password.update&devId=6c96f4208f733a0b737eix&et=1&t=1722992558&v=1.0&sign=21df7da82b47b9ee312887a52016b9ac
[2024/8/7 9:02:36 955] [08-07 09:02:38 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:36 972] [08-07 09:02:38 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:36 972] [08-07 09:02:38 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:36 972] [08-07 09:02:38 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:36 988] [08-07 09:02:38 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:36 988] [08-07 09:02:38 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:37 004] [08-07 09:02:38 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:37 004] [08-07 09:02:38 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:37 020] [08-07 09:02:38 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:37 020] [08-07 09:02:38 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:37 036] [08-07 09:02:38 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:37 036] [08-07 09:02:38 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:37 052] [08-07 09:02:38 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:37 052] [08-07 09:02:38 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:37 068] [08-07 09:02:38 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:37 068] [08-07 09:02:38 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:37 068] [08-07 09:02:38 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:37 084] [08-07 09:02:38 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:37 084] [08-07 09:02:38 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:02:37 100] tuya_hal_bt_send 17
[2024/8/7 9:02:37 100] 01 36 2b ff 68 28 60 1e 11 9a e9 9e 77 d9 dd f7 21 
[2024/8/7 9:02:37 100] [08-07 09:02:38 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:37 116] 1 36 2b ff 68 28 60 1e 11 9a e9 9e 77 d9 dd f7 21 
[2024/8/7 9:02:37 116] XmBleSendBuf 17: 01 36 2b ff 68 28 60 1e 11 9a e9 9e 77 d9 dd f7 21
[2024/8/7 9:02:37 116] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:02:37 116] ble_slave_gap_event->type=13
[2024/8/7 9:02:37 132] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:02:37 132] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:02:37 132] [08-07 09:02:38 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:37 148] [08-07 09:02:38 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:37 164] [08-07 09:02:38 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:37 164] set basic_indicator_onoff:1 
[2024/8/7 9:02:37 164] [08-07 09:02:38 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:37 180] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:37 180] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:37 196] [08-07 09:02:38 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:37 211] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:37 211] [08-07 09:02:38 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:02:37 227] [08-07 09:02:38 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[2024/8/7 9:02:37 228] [08-07 09:02:38 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[2024/8/7 9:02:37 243] [08-07 09:02:38 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:02:37 243] dev id key: 16
[2024/8/7 9:02:37 244] b8 8d fe f9 0e f4 fa 9a c5 8c f5 1c 4c 9e f4 15 
[2024/8/7 9:02:37 244] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:02:37 259] [08-07 09:02:38 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:02:37 260] 2 1 6 3 2 1 a2 14 16 1 a2 0 49 be d5 e4 a4 b2 96 65 64 7c 1c ac e4 41 4 16 
[2024/8/7 9:02:37 260] [08-07 09:02:38 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:02:37 275] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 80 86 14 96 94 e9 13 17 19 70 9c de 66 75 17 cd 
[2024/8/7 9:02:37 276] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:02:37 291] [08-07 09:02:38 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:02:37 292]  
[2024/8/7 9:02:37 292] [08-07 09:02:38 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:02:37 308] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:37 308] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:37 308] Len=20 step 0
[2024/8/7 9:02:37 323] att=0x0 0x21 0x20 0x2 0xd6 0xb0 0xb7 0x19 0x22 0xb9 0xfa 0xa9 0xc9 0x8 0xd6 0xdc 0x7 0xe4 0x6f 0xc3 
[2024/8/7 9:02:37 324]  RCVS len:20
[2024/8/7 9:02:37 324] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:37 324] XmBleReadBuf 20:
[2024/8/7 9:02:37 340] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:37 340] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:37 340] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:37 356] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:02:37 356] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:02:37 371] [08-07 09:02:38 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:02:37 372] [08-07 09:02:38 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:37 372] [08-07 09:02:38 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:37 372] bt_rev_raw 20
[2024/8/7 9:02:37 387] 00 21 20 02 d6 b0 b7 19 22 b9 fa a9 c9 08 d6 dc 07 e4 6f c3 
[2024/8/7 9:02:37 388] [08-07 09:02:38 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:02:37 404] [08-07 09:02:38 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:02:37 404] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:02:37 419] [08-07 09:02:38 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"appKey":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","networkKey":"D59774254FA876FF1D204D16DF5223A5"},"t":1722992558,"success":true}
[2024/8/7 9:02:37 435] [08-07 09:02:38 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:37 436] [08-07 09:02:38 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:37 451] [08-07 09:02:38 TUYA D][tuya_ble_api.c:1014] start to write flash, app_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66", network_key:"D59774254FA876FF1D204D16DF5223A5"
[2024/8/7 9:02:37 452] [08-07 09:02:38 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:37 468] [08-07 09:02:38 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:37 468] [08-07 09:02:38 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:37 468] [08-07 09:02:38 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:37 483] [08-07 09:02:38 TUYA D][simplekv.c:374] write key:ble_app_key And Value Len:48
[2024/8/7 9:02:37 484] [08-07 09:02:38 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 48
[2024/8/7 9:02:37 499] [08-07 09:02:38 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:02:37 499] [08-07 09:02:38 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:02:37 499] [08-07 09:02:38 TUYA D][simplekv.c:203] update crc 121119376
[2024/8/7 9:02:37 515] [08-07 09:02:38 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:37 516] [08-07 09:02:38 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:37 531] [08-07 09:02:38 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:37 531] [08-07 09:02:38 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:37 532] [08-07 09:02:38 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:37 547] [08-07 09:02:38 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:37 548] [08-07 09:02:38 TUYA D][simplekv.c:374] write key:ble_network_key And Value Len:48
[2024/8/7 9:02:37 548] [08-07 09:02:38 TUYA D][simplekv.c:457] new space 13 startpos:36960 size:116
[2024/8/7 9:02:37 564] [08-07 09:02:38 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:37 564] [08-07 09:02:38 TUYA D][simplekv.c:203] update crc 1032694273
[2024/8/7 9:02:37 579] [08-07 09:02:38 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:37 579] [08-07 09:02:38 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:37 579] [08-07 09:02:38 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992558}
[2024/8/7 9:02:37 595] [08-07 09:02:38 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.beacon.key.fetch&devId=6c96f4208f733a0b737eix&et=1&t=1722992558&v=1.0&sign=5587efe85674a5abde6b10746f8dd180
[2024/8/7 9:02:37 611] [08-07 09:02:38 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:37 611] [08-07 09:02:38 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:37 627] [08-07 09:02:38 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:37 627] [08-07 09:02:38 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:37 643] [08-07 09:02:38 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:37 643] [08-07 09:02:38 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:37 660] [08-07 09:02:38 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:37 660] [08-07 09:02:38 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:37 675] [08-07 09:02:38 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:37 675] [08-07 09:02:38 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:37 692] [08-07 09:02:38 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:37 692] set basic_indicator_onoff:0 
[2024/8/7 9:02:37 692] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:02:37 692] Len=17 step 0
[2024/8/7 9:02:37 707] att=0x1 0x3 0x32 0x71 0xbb 0x80 0xc9 0xe3 0x57 0x4e 0x55 0x4a 0x8b 0x28 0x8e 0x17 0xae 
[2024/8/7 9:02:37 707]  RCVS len:17
[2024/8/7 9:02:37 707] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:37 723] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:37 723] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:37 740] [08-07 09:02:38 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:37 756] [08-07 09:02:38 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:37 756] XmBleReadBuf 17:
[2024/8/7 9:02:37 756] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:02:37 756] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:02:37 772] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:02:37 772] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:02:37 772] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:02:37 788] [08-07 09:02:38 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:02:37 788] [08-07 09:02:38 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:02:37 803] [08-07 09:02:38 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:02:37 803] bt_rev_raw 17
[2024/8/7 9:02:37 803] 01 03 32 71 bb 80 c9 e3 57 4e 55 4a 8b 28 8e 17 ae 
[2024/8/7 9:02:37 819] [08-07 09:02:38 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:02:37 819] ble rev data 33
[2024/8/7 9:02:37 819] 02 d6 b0 b7 19 22 b9 fa [1970-01-01 00:00:32] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time32822
[2024/8/7 9:02:37 835] a9 c9 08 d6 dc 07 e4 6f c3 03 32 71 bb 80 c9 e3 57 4e 55 4a 8b 28 8e 17 ae 
[2024/8/7 9:02:37 835] ble decryped data 16
[2024/8/7 9:02:37 835] 00 00 00 05 00 00 00 00 00 22 00 01 00 13 18 00 
[2024/8/7 9:02:37 851] [08-07 09:02:38 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:37 851] [08-07 09:02:38 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:02:37 851] [08-07 09:02:38 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:02:37 867] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:02:37 883] [08-07 09:02:38 TUYA D][iot_httpc.c:601] Decode Rev:{"result":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","t":1722992558,"success":true}
[2024/8/7 9:02:37 883] [08-07 09:02:38 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:37 883] [08-07 09:02:38 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:37 899] [08-07 09:02:38 TUYA D][tuya_ble_api.c:986] start to write flash, beacon_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66"
[2024/8/7 9:02:37 899] [08-07 09:02:38 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:02:37 915] [08-07 09:02:38 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:37 915] [08-07 09:02:38 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:37 915] [08-07 09:02:38 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:37 931] [08-07 09:02:38 TUYA D][simplekv.c:374] write key:ble_beaconkey And Value Len:48
[2024/8/7 9:02:37 931] [08-07 09:02:38 TUYA D][simplekv.c:457] new space 14 startpos:37076 size:116
[2024/8/7 9:02:37 947] [08-07 09:02:38 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:37 947] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:37 948] set basic_indicator_onoff:1 
[2024/8/7 9:02:37 964] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:37 964] [08-07 09:02:38 TUYA D][simplekv.c:203] update crc 481086870
[2024/8/7 9:02:37 980] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:37 980] [08-07 09:02:38 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992558,"success":true}
[2024/8/7 9:02:37 995] [08-07 09:02:38 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:37 995] [08-07 09:02:38 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:37 995] [08-07 09:02:38 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:38 011] [08-07 09:02:38 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:38 011] [08-07 09:02:38 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:02:38 027] [08-07 09:02:38 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:02:38 028] [08-07 09:02:38 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:02:38 028] [08-07 09:02:38 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:02:38 044] [08-07 09:02:38 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:02:38 044] [08-07 09:02:38 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:02:38 044] [08-07 09:02:38 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:02:38 059] [08-07 09:02:38 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:02:38 059] [08-07 09:02:38 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:02:38 075] [08-07 09:02:38 TUYA D][simplekv.c:203] update crc 3742538115
[2024/8/7 9:02:38 075] [08-07 09:02:38 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:38 075] [08-07 09:02:38 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:38 091] [08-07 09:02:38 TUYA D][tuya_devos_utils.c:341] set gw ext_stat:2
[2024/8/7 9:02:38 091] [08-07 09:02:38 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 0
[2024/8/7 9:02:38 092] 
[2024/8/7 9:02:38 107] [08-07 09:02:38 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.30.165 for domain m2.tuyacn.com
[2024/8/7 9:02:38 108] [08-07 09:02:38 TUYA D][mqtt_client.c:1472] select mqtt host:m2.tuyacn.com
[2024/8/7 9:02:38 108] [08-07 09:02:38 TUYA N][mqtt_client.c:1493] mqtt get serve ip success
[2024/8/7 9:02:38 124] [08-07 09:02:38 TUYA D][mqtt_client.c:989] serverIP 717233829 port:8883
[2024/8/7 9:02:38 124] [08-07 09:02:38 TUYA D][mqtt_client.c:1014] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883
[2024/8/7 9:02:38 140] [08-07 09:02:38 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:38 156] [08-07 09:02:38 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyacn.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:38 156] [08-07 09:02:38 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:38 156] [08-07 09:02:38 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:38 171] [08-07 09:02:38 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:38 171] [08-07 09:02:38 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:38 171] set basic_indicator_onoff:0 
[2024/8/7 9:02:38 188] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:38 188] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:38 204] [1970-01-01 00:00:33] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:02:38 204] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:02:38 220] set basic_indicator_onoff:1 
[2024/8/7 9:02:38 220] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:38 236] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:38 236] set basic_indicator_onoff:0 
[2024/8/7 9:02:38 236] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:38 252] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:38 252] set basic_indicator_onoff:1 
[2024/8/7 9:02:38 268] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:38 268] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:38 268] set basic_indicator_onoff:0 
[2024/8/7 9:02:38 284] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:38 284] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:02:38 299] set basic_indicator_onoff:1 
[2024/8/7 9:02:38 300] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:02:38 315] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:02:38 316] [08-07 09:02:39 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:38 332] [08-07 09:02:39 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyacn.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:38 347] [08-07 09:02:39 TUYA N][mqtt_client.c:1531] mqtt create success, begin to connect
[2024/8/7 9:02:38 348] [08-07 09:02:39 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:02:38 348] [08-07 09:02:39 TUYA D][mqtt_client.c:1413] cnt 1
[2024/8/7 9:02:38 348] [08-07 09:02:39 TUYA D][mqtt_client.c:1104] mqtt subscribe success
[2024/8/7 9:02:38 363] [08-07 09:02:39 TUYA D][mqc_app.c:732] mqtt connect success
[2024/8/7 9:02:38 363] [08-07 09:02:39 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[2024/8/7 9:02:38 379] [08-07 09:02:39 TUYA D][mqtt_client.c:1994] subscribe new topic /av/d/6c96f4208f733a0b737eix ret:1 
[2024/8/7 9:02:38 379] [08-07 09:02:39 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[2024/8/7 9:02:38 395] __IPC_APP_Get_Net_Status_cb line(243) -------------------------- stat(11)==STAT_MQTT_ONLINE 
[2024/8/7 9:02:38 395] curr event:11 
[2024/8/7 9:02:38 395] IPC_APP_Notify_LED_Sound_Status_CB line(550) -------------------------- IPC_MQTT_ONLINE(11)
[2024/8/7 9:02:38 411] [1970-01-01 00:00:33] tuya_ipc_system_control_demo.c(551) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(DEVICE_ONLINE, 0, 0, 0, 1))
[2024/8/7 9:02:38 411] Disable Qrcode
[2024/8/7 9:02:38 427] [1970-01-01 00:00:33] tuya_ipc_system_control_demo.c(558) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONFIG_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:02:38 427] mqtt subscribe ack 5
[2024/8/7 9:02:38 427] 90 03 00 02 00 
[2024/8/7 9:02:38 443] [1970-01-01 00:00:33] xm_musicPlayer.cpp(91) <PlayAudioTips>: Open audio file /usr/share/audios/_english.pcm failed, No such file or directory
[2024/8/7 9:02:38 459] [1970-01-01 00:00:33] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/AddSuccess_english.pcm]
[2024/8/7 9:02:38 459] [1970-01-01 00:00:33] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:02:38 475] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:02:38 475] [08-07 09:02:39 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[2024/8/7 9:02:38 491] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:02:38 491] [08-07 09:02:39 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
[2024/8/7 9:02:38 508] [08-07 09:02:39 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:2  -->>
[2024/8/7 9:02:38 508] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:02:38 523] [08-07 09:02:39 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:2  <<--
[2024/8/7 9:02:38 523] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:02:38 539] [08-07 09:02:39 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:02:38 539] [08-07 09:02:39 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:02:38 556] [08-07 09:02:39 TUYA D][MainApp.c:537] tuya_ipc_sdk_mqtt_online_proc is start run
[2024/8/7 9:02:38 556] [08-07 09:02:39 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992559 28800
[2024/8/7 9:02:38 572] [08-07 09:02:39 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992559 28800
[2024/8/7 9:02:38 572] Init tuya_ipc_ss_init
[2024/8/7 9:02:38 588] [08-07 09:02:39 TUYA D][tuya_ipc_stream_storage.c:2015] Init stream_storage.base_path:/mnt/mmc v:4 a:101, max event per day 289 skills 1
[2024/8/7 9:02:38 588] [08-07 09:02:39 TUYA D][tuya_ipc_stream_storage.c:2161] stream storage task init success
[2024/8/7 9:02:38 604] [08-07 09:02:39 TUYA D][MainApp.c:567] local storage init result is 0
[2024/8/7 9:02:38 604] [08-07 09:02:39 TUYA D][tuya_ipc_stream_storage.c:1571] SD task begin___
[2024/8/7 9:02:38 604] [08-07 09:02:39 TUYA D][tuya_ipc_stream_storage.c:1585] report sd status 0 -> 5
[2024/8/7 9:02:38 620] 
[2024/8/7 9:02:38 621] [08-07 09:02:39 TUYA E][tuya_ipc_stream_storage.c:1914] storage not inited
[2024/8/7 9:02:38 621] [08-07 09:02:39 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:02:38 636] [08-07 09:02:39 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:02:38 636] [08-07 09:02:40 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:02:38 636] [08-07 09:02:40 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:38 652] [08-07 09:02:40 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:38 652] [08-07 09:02:40 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:38 652] [08-07 09:02:40 TUYA E][svc_online_log_db.c:25] ret:-6
[2024/8/7 9:02:38 668] [08-07 09:02:40 TUYA D][svc_online_log.c:182] load env fail. maybe not exist.
[2024/8/7 9:02:38 668] [08-07 09:02:40 TUYA D][svc_online_log.c:187] update property:{"value":"{\"embed_sys_env\":\"arm-xm-linux\"}"}
[2024/8/7 9:02:38 684] [08-07 09:02:40 TUYA D][iot_httpc.c:1161] Post Data: {"value":"{\"embed_sys_env\":\"arm-xm-linux\"}","t":1722992560}
[2024/8/7 9:02:38 700] [08-07 09:02:40 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.property.save&devId=6c96f4208f733a0b737eix&et=1&t=1722992560&v=1.0&sign=39a342ab6498d76412dc8fd5cb9441ee
[2024/8/7 9:02:38 716] [08-07 09:02:40 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:38 716] [08-07 09:02:40 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:38 732] [08-07 09:02:40 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:38 732] [08-07 09:02:40 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:38 748] [1970-01-01 00:00:34] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:38 748] [08-07 09:02:40 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:38 748] [08-07 09:02:40 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:38 763] [08-07 09:02:40 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:38 764] [08-07 09:02:40 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:38 779] [08-07 09:02:40 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:38 780] [08-07 09:02:40 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:38 795] [08-07 09:02:40 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:38 795] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:02:38 796] Mode(Product):0
[2024/8/7 9:02:38 796] BpuMode:[Online]
[2024/8/7 9:02:38 796] VpssMode:[Online]
[2024/8/7 9:02:38 796] [0.LimitUp_info]:
[2024/8/7 9:02:38 811] LimitUp:[Disable]
[2024/8/7 9:02:38 811] [2680*0]->[3840*0])
[2024/8/7 9:02:38 811] chn	TotalSize	ActiveSize
[2024/8/7 9:02:38 811] 0	5040*2246	2680*2160
[2024/8/7 9:02:38 812] 0	5040*2246	3840*2160
[2024/8/7 9:02:38 812] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:02:38 812] [1.VICU_info]:
[2024/8/7 9:02:38 827] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:02:38 827] 0	25.0	664	0	0	183	linear	8ddb00
[2024/8/7 9:02:38 827] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:02:38 827] en	op_type	m_chn	now
[2024/8/7 9:02:38 827] 0	1	1	1
[2024/8/7 9:02:38 828] 
[2024/8/7 9:02:38 828] [2.VI_info]:
[2024/8/7 9:02:38 843] chn	TotalSize	ActiveSize
[2024/8/7 9:02:38 843] 0	5040*2246	3848*2166
[2024/8/7 9:02:38 843] 1	   0*   0	   0*   0
[2024/8/7 9:02:38 843] [3.MIPI_info]:
[2024/8/7 9:02:38 843] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:02:38 859] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:02:38 859] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:02:38 859] [4.Cut_info]:
[2024/8/7 9:02:38 859] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:02:38 859] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:02:38 875] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:02:38 875] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:02:38 875] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:02:38 875] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:02:38 875] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:02:38 875] [5.IB(isp buffer info)]:
[2024/8/7 9:02:38 891] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:02:38 891] PoolId  Count  Size
[2024/8/7 9:02:38 891] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:38 907] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:38 907] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:38 923] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:38 923] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:38 939] [08-07 09:02:40 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:38 955] [08-07 09:02:40 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:38 955] [08-07 09:02:40 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992560,"success":true}
[2024/8/7 9:02:38 971] [08-07 09:02:40 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:38 971] [08-07 09:02:40 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:38 971] [08-07 09:02:40 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:02:38 987] [08-07 09:02:40 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:38 987] [08-07 09:02:40 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:38 987] [08-07 09:02:40 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:39 003] [08-07 09:02:40 TUYA D][simplekv.c:374] write key:em_sys_env And Value Len:32
[2024/8/7 9:02:39 003] [08-07 09:02:40 TUYA D][simplekv.c:457] new space 15 startpos:37192 size:100
[2024/8/7 9:02:39 019] [08-07 09:02:40 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:39 019] [08-07 09:02:40 TUYA D][simplekv.c:203] update crc 2405064634
[2024/8/7 9:02:39 019] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:02:39 036] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:02:39 036] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:02:39 036] 0       0         0          0          4       
[2024/8/7 9:02:39 051] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:02:39 051]      --265--            --264--                                               
[2024/8/7 9:02:39 051] Count      Line     Count      Line     
[2024/8/7 9:02:39 067] 504        480      1131       560      
[2024/8/7 9:02:39 067] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:02:39 083] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:02:39 083] 0   3840   2160    H265  0      0        0           303       983040     0        	
[2024/8/7 9:02:39 083] 1   640    360     H265  0      0        0           199       24120      19080    	
[2024/8/7 9:02:39 099] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:02:39 099] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:02:39 115] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:02:39 131] 0   Y      303      0       0       15       0        303      303      422       66658         58814    146314   65543    12      
[2024/8/7 9:02:39 147] 1   Y      199      0       2       0        1        198      198      422       1944          1894     38238    3246     9       
[2024/8/7 9:02:39 147] 3   N      0        0       0       1        0        0        0        423       0             0        0        0        0       
[2024/8/7 9:02:39 163] [1970-01-01 00:00:34] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:39 163] [08-07 09:02:40 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:39 179] [08-07 09:02:40 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:39 179] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:02:39 179] [08-07 09:02:41 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992561}
[2024/8/7 9:02:39 211] [08-07 09:02:41 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.uuid.pskkey.get&et=1&t=1722992561&uuid=uuidcaab27b0a838d239&v=1.0&sign=c34aef5934e4b5c4f8a4c96cd7747123
[2024/8/7 9:02:39 211] [08-07 09:02:41 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:39 211] [08-07 09:02:41 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:39 227] [08-07 09:02:41 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:39 227] [08-07 09:02:41 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:39 243] [08-07 09:02:41 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:39 243] [08-07 09:02:41 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:39 259] [08-07 09:02:41 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:39 259] [08-07 09:02:41 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:39 275] [08-07 09:02:41 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:39 275] [08-07 09:02:41 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:39 291] [08-07 09:02:41 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:39 291] [08-07 09:02:41 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:39 308] [08-07 09:02:41 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:39 323] [08-07 09:02:41 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"pskKey":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80"},"t":1722992561,"success":true}
[2024/8/7 9:02:39 324] [08-07 09:02:41 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:39 324] [08-07 09:02:41 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:39 355] [08-07 09:02:41 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80","auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:02:39 355] [08-07 09:02:41 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:02:39 371] [08-07 09:02:41 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:02:39 371] [08-07 09:02:41 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:02:39 387] [08-07 09:02:41 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:256
[2024/8/7 9:02:39 387] [08-07 09:02:41 TUYA D][simplekv.c:397] 0 key same AND size old 276 >= new 256
[2024/8/7 9:02:39 387] [08-07 09:02:41 TUYA D][simplekv.c:430] find 0 available space
[2024/8/7 9:02:39 403] [08-07 09:02:41 TUYA D][simplekv.c:474] reuse available space 28700
[2024/8/7 9:02:39 403] [08-07 09:02:41 TUYA D][simplekv.c:203] update crc 1858949195
[2024/8/7 9:02:39 419] [08-07 09:02:41 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:39 419] [08-07 09:02:41 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:39 419] [08-07 09:02:41 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:02:39 435] [08-07 09:02:41 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c96f4208f733a0b737eix, dp_rept_chan:5
[2024/8/7 9:02:39 435] [08-07 09:02:41 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:02:39 451] [08-07 09:02:41 TUYA D][smart_frame.c:2517] Nothing To Pack
[2024/8/7 9:02:39 451] [08-07 09:02:41 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:02:39 771] set sd_record_on_off:1 
[2024/8/7 9:02:39 787] set sd_record_mode:0 
[2024/8/7 9:02:39 787] [08-07 09:02:41 TUYA E][tuya_ipc_stream_storage.c:1912] the ss mgr not inited, but msg buffered: set mode 1
[2024/8/7 9:02:39 787] write RecordMode success  0 
[2024/8/7 9:02:39 803] [08-07 09:02:41 TUYA D][tuya_ipc_cloud_storage.c:2188] init cloud storage begin
[2024/8/7 9:02:39 803] [08-07 09:02:41 TUYA D][simplekv.c:1211] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:39 819] [08-07 09:02:41 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:39 819] [08-07 09:02:41 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:39 819] [08-07 09:02:41 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:39 835] [08-07 09:02:41 TUYA E][tuya_ipc_cloud_storage.c:365] iot_wd_common_read fails md5_encrypt_key -6
[2024/8/7 9:02:39 835] [08-07 09:02:41 TUYA E][tuya_ipc_cloud_storage.c:450] read key_key file failed.
[2024/8/7 9:02:39 851] [08-07 09:02:41 TUYA D][tuya_ipc_cloud_storage.c:2240] __check_md5_encrypt_key fail, need update from server
[2024/8/7 9:02:39 851] [08-07 09:02:41 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:02:39 868] [08-07 09:02:41 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:39 868] [08-07 09:02:41 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:39 868] [08-07 09:02:41 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:39 883] [08-07 09:02:41 TUYA E][tuya_ipc_cloud_storage.c:942] iot_wd_common_read fails storage_restriction -6
[2024/8/7 9:02:39 884] [08-07 09:02:41 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992561}
[2024/8/7 9:02:39 915] [08-07 09:02:41 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.restriction.config.get&devId=6c96f4208f733a0b737eix&et=1&t=1722992561&v=1.0&sign=ca8ee9db7672f3f2ebc2a874d471fb88
[2024/8/7 9:02:39 916] [08-07 09:02:41 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:39 916] [08-07 09:02:41 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:39 932] [08-07 09:02:41 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:39 932] [08-07 09:02:41 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:39 947] [08-07 09:02:41 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:39 947] [08-07 09:02:41 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:39 963] [08-07 09:02:41 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:39 963] [08-07 09:02:41 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:39 979] [08-07 09:02:41 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:39 979] [08-07 09:02:41 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:39 995] [08-07 09:02:41 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:39 995] [08-07 09:02:42 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:40 011] [08-07 09:02:42 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:40 027] [1970-01-01 00:00:36] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:02:40 027] [1970-01-01 00:00:36] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:02:40 043] [08-07 09:02:42 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"msg":{"audioDuration":15,"audioInterval":300,"videoDuration":6,"videoInterval":300},"storage":{"mtu":10}},"t":1722992562,"success":true}
[2024/8/7 9:02:40 059] [08-07 09:02:42 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:40 059] [08-07 09:02:42 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:40 075] [08-07 09:02:42 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:02:40 075] [08-07 09:02:42 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:40 075] [08-07 09:02:42 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:40 091] [08-07 09:02:42 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:40 091] [08-07 09:02:42 TUYA D][simplekv.c:374] write key:storage_restriction And Value Len:32
[2024/8/7 9:02:40 107] [08-07 09:02:42 TUYA D][simplekv.c:457] new space 16 startpos:37292 size:100
[2024/8/7 9:02:40 107] [08-07 09:02:42 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:40 107] [08-07 09:02:42 TUYA D][simplekv.c:203] update crc 2276547773
[2024/8/7 9:02:40 123] [08-07 09:02:42 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:40 123] [08-07 09:02:42 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:40 123] [08-07 09:02:42 TUYA D][tuya_ipc_cloud_storage.c:920] slice_duration write success
[2024/8/7 9:02:40 139] [08-07 09:02:42 TUYA D][tuya_ipc_cloud_storage.c:999] case 2 get slice duration from cloud 10
[2024/8/7 9:02:40 155] [08-07 09:02:42 TUYA D][tuya_ipc_cloud_storage.c:1043] cloud storage seize 3059584 bytes memory for media data, each slice 10 seconds
[2024/8/7 9:02:40 155] [08-07 09:02:42 TUYA I][uni_thread.c:228] thread_create name:cloud_storage,stackDepth:65536,totalstackDepth:91136,priority:3
[2024/8/7 9:02:40 172] [08-07 09:02:42 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[2024/8/7 9:02:40 172] [08-07 09:02:42 TUYA D][tuya_ipc_cloud_storage.c:2289] init cloud storage success
[2024/8/7 9:02:40 188] [08-07 09:02:42 TUYA D][MainApp.c:590] cloud storage init result is 0
[2024/8/7 9:02:40 188] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:40 188] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1417] cloud connected, stop adv!
[2024/8/7 9:02:40 203] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(640): stop_adv ---
[2024/8/7 9:02:40 203] exit_ble_thread create suc
[2024/8/7 9:02:40 203] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(644): XmBleAdvStop ---
[2024/8/7 9:02:40 219] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1376] nw stat change:1->2, rpt to app.
[2024/8/7 9:02:40 219] [08-07 09:02:42 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:2
[2024/8/7 9:02:40 236] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 236] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:02:40 236] bt_ack_uncrypt 1
[2024/8/7 9:02:40 236] 02 
[2024/8/7 9:02:40 251] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 252] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:40 267] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:40 268] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:40 268] __dp_data_report_data 4
[2024/8/7 9:02:40 268] 69 01 01 00 
[2024/8/7 9:02:40 283] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 283] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:40 283] bt_ack_uncrypt 4
[2024/8/7 9:02:40 283] 69 01 01 00 
[2024/8/7 9:02:40 299] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 299] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"105":false}
[2024/8/7 9:02:40 316] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18492 Q:1 Data:{"dps":{"105":false}}
[2024/8/7 9:02:40 316] [08-07 09:02:42 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:02:40 316] [08-07 09:02:42 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:02:40 331] [08-07 09:02:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:40 331] tuya_hal_bt_send 20
[2024/8/7 9:02:40 331] 00 21 36 05 63 2c 17 79 76 cb b1 09 6c d0 8f 90 82 41 1c ba 
[2024/8/7 9:02:40 348] [08-07 09:02:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:40 348] 0 21 36 5 63 2c 17 79 76 cb b1 9 6c d0 8f 90 82 41 1c ba 
[2024/8/7 9:02:40 348] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:40 363]  ---
[2024/8/7 9:02:40 364] [08-07 09:02:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:40 364] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:40 381] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:40 381] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:02:40 395] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:40 395] __dp_data_report_data 4
[2024/8/7 9:02:40 395] 65 01 01 01 
[2024/8/7 9:02:40 395] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 411] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:40 411] bt_ack_uncrypt 4
[2024/8/7 9:02:40 411] 65 01 01 01 
[2024/8/7 9:02:40 411] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 427] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"101":true}
[2024/8/7 9:02:40 427] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18493 Q:1 Data:{"dps":{"101":true}}
[2024/8/7 9:02:40 443] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:40 443] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[2024/8/7 9:02:40 459] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:105, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:40 459] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:105, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:40 475] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:105, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:40 475] [08-07 09:02:42 TUYA D][uni_thread.c:250] Thread:cloud_storage Exec Start. Set to Running Stat
[2024/8/7 9:02:40 491] [08-07 09:02:42 TUYA D][iot_httpc.c:1161] Post Data: {"type":"MediaStor","t":1722992562}
[2024/8/7 9:02:40 507] [08-07 09:02:42 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c96f4208f733a0b737eix&et=1&t=1722992562&v=3.0&sign=9e5332b756975e8a250e634c5507d22a
[2024/8/7 9:02:40 507] [08-07 09:02:42 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:40 523] [08-07 09:02:42 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:40 523] [08-07 09:02:42 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:40 540] --- tracepoint bt_ext_porting.c,ty_btext_thread(433): tuya_hal_thread_release ---
[2024/8/7 9:02:40 540] [08-07 09:02:42 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:40 556] [08-07 09:02:42 TUYA E][bt_ext_porting.c:434] [TUYA-BTUART]ty_btext_thread deleted
[2024/8/7 9:02:40 556] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:40 571] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:40 571] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:40 571] __dp_data_report_data 4
[2024/8/7 9:02:40 571] 67 01 01 00 
[2024/8/7 9:02:40 587] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 587] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:40 587] bt_ack_uncrypt 4
[2024/8/7 9:02:40 587] 67 01 01 00 
[2024/8/7 9:02:40 603] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 603] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"103":false}
[2024/8/7 9:02:40 619] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18494 Q:1 Data:{"dps":{"103":false}}
[2024/8/7 9:02:40 619] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:40 635] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:40 635] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:02:40 651] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:40 651] __dp_data_report_data 4
[2024/8/7 9:02:40 651] 68 01 01 01 
[2024/8/7 9:02:40 651] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 667] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:40 667] bt_ack_uncrypt 4
[2024/8/7 9:02:40 667] 68 01 01 01 
[2024/8/7 9:02:40 667] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:40 683] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"104":true}
[2024/8/7 9:02:40 683] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18495 Q:1 Data:{"dps":{"104":true}}
[2024/8/7 9:02:40 699] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:40 700] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:107 not find
[2024/8/7 9:02:40 700] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:40 715] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:40 715] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0
[2024/8/7 9:02:40 731] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:101, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:40 731] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:101, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:40 747] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:101, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:40 747] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=5.000 ms
[2024/8/7 9:02:40 763] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:40 763] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:108 not find
[2024/8/7 9:02:40 763] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:40 779] [1970-01-01 00:00:36] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:02:40 779] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:40 795] IPC_APP_get_smart_mutile_light_mode line(546) ----------  
[2024/8/7 9:02:40 795] [08-07 09:02:42 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:40 812] [08-07 09:02:42 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:40 812] [08-07 09:02:42 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:40 827] [08-07 09:02:42 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:40 827] [08-07 09:02:42 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:40 828] [08-07 09:02:42 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:40 843] [08-07 09:02:42 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:40 859] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0
[2024/8/7 9:02:40 860] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:103, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:40 875] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:103, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:40 875] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:103, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:40 891] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:02:40 891] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:02:40 891] IPC_APP_set_smart_mutile_light_mode line(451) ---------- :0 ,g_SMLAbility=[0]
[2024/8/7 9:02:40 907] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0
[2024/8/7 9:02:40 907] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:104, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:40 923] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:104, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:40 939] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:104, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:40 939] [08-07 09:02:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:02:40 939] tuya_hal_bt_send 17
[2024/8/7 9:02:40 955] 01 40 ee 1f e9 0d 3d 59 ac 10 9c f1 97 5f 27 15 d0 
[2024/8/7 9:02:40 955] [08-07 09:02:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:40 955] 1 40 ee 1f e9 d 3d 59 ac 10 9c f1 97 5f 27 15 d0 
[2024/8/7 9:02:40 971] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:40 971] [08-07 09:02:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:40 987] [08-07 09:02:42 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:40 987] [08-07 09:02:42 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:41 003] DEBUG: camera_set_dnc_mode_chn 0 
[2024/8/7 9:02:41 003] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:02:41 003] DEBUG: software pohtoR!
[2024/8/7 9:02:41 003] IPC_APP_set_smart_mutile_light_mode line(536) ---------- :mode=[0] 
[2024/8/7 9:02:41 019] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 019] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<124> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 035] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 035] __dp_data_report_data 4
[2024/8/7 9:02:41 035] 7c 04 01 00 
[2024/8/7 9:02:41 051] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 052] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 052] bt_ack_uncrypt 4
[2024/8/7 9:02:41 052] 7c 04 01 00 
[2024/8/7 9:02:41 067] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 067] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"124":"auto"}
[2024/8/7 9:02:41 083] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18496 Q:1 Data:{"dps":{"124":"auto"}}
[2024/8/7 9:02:41 083] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 099] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 099] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:02:41 099] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 115] __dp_data_report_data 4
[2024/8/7 9:02:41 115] 86 01 01 01 
[2024/8/7 9:02:41 115] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 115] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 131] bt_ack_uncrypt 4
[2024/8/7 9:02:41 131] 86 01 01 01 
[2024/8/7 9:02:41 131] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 131] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"134":true}
[2024/8/7 9:02:41 147] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18497 Q:1 Data:{"dps":{"134":true}}
[2024/8/7 9:02:41 147] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 164] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 164] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 164] __dp_data_report_data 4
[2024/8/7 9:02:41 179] 6a 04 01 01 
[2024/8/7 9:02:41 179] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 179] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 195] bt_ack_uncrypt 4
[2024/8/7 9:02:41 196] 6a 04 01 01 
[2024/8/7 9:02:41 196] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 196] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"106":"1"}
[2024/8/7 9:02:41 211] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18498 Q:1 Data:{"dps":{"106":"1"}}
[2024/8/7 9:02:41 211] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 227] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:168 not find
[2024/8/7 9:02:41 227] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:41 227] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:41 243] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(855):  ---
[2024/8/7 9:02:41 243] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(866):  ---
[2024/8/7 9:02:41 259] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(872):  ---
[2024/8/7 9:02:41 259] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(892):  ---
[2024/8/7 9:02:41 275] [IPC_APP_get_alarm_zone_draw][893] alarm zone[{\"num\":1,\"region0\":{\"x\":1,\"y\":1,\"xlen\":99,\"ylen\":99}}]
[2024/8/7 9:02:41 275] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 275] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:169 not find
[2024/8/7 9:02:41 291] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:41 291] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:41 291] curr sd_status:1 
[2024/8/7 9:02:41 307] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 308] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 323] [08-07 09:02:42 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:5
[2024/8/7 9:02:41 323] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 324] __dp_data_report_data 7
[2024/8/7 9:02:41 324] 6e 02 04 00 00 00 05 
[2024/8/7 9:02:41 339] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 339] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 339] bt_ack_uncrypt 7
[2024/8/7 9:02:41 339] 6e 02 04 00 00 00 05 
[2024/8/7 9:02:41 355] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 355] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"110":5}
[2024/8/7 9:02:41 371] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18499 Q:1 Data:{"dps":{"110":5}}
[2024/8/7 9:02:41 372] handle_DP_SD_STORAGE_ONLY_GET line(654) --------------------- 
[2024/8/7 9:02:41 387] [1970-01-01 00:00:36] tuya_ipc_sd_demo.c(182) <tuya_ipc_sd_get_capacity>: XM_SDCardGetPartitionInfo failed
[2024/8/7 9:02:41 387] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 403] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 403] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 403] __dp_data_report_data 8
[2024/8/7 9:02:41 403] 6d 03 05 30 7c 30 7c 30 
[2024/8/7 9:02:41 419] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 419] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 419] bt_ack_uncrypt 8
[2024/8/7 9:02:41 419] 6d 03 05 30 7c 30 7c 30 
[2024/8/7 9:02:41 435] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 435] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0"}
[2024/8/7 9:02:41 451] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18500 Q:1 Data:{"dps":{"109":"0|0|0"}}
[2024/8/7 9:02:41 451] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"124":"auto"}}, mqtt async dp cb:0
[2024/8/7 9:02:41 467] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:124, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:41 483] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:124, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:41 483] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:124, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:41 483] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 499] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 515] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:02:41 515] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 515] __dp_data_report_data 4
[2024/8/7 9:02:41 515] 96 01 01 01 
[2024/8/7 9:02:41 531] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 531] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 531] bt_ack_uncrypt 4
[2024/8/7 9:02:41 531] 96 01 01 01 
[2024/8/7 9:02:41 547] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 547] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"150":true}
[2024/8/7 9:02:41 563] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18501 Q:1 Data:{"dps":{"150":true}}
[2024/8/7 9:02:41 563] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 563] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 579] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 579] __dp_data_report_data 4
[2024/8/7 9:02:41 579] 97 04 01 00 
[2024/8/7 9:02:41 595] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 596] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 596] bt_ack_uncrypt 4
[2024/8/7 9:02:41 596] 97 04 01 00 
[2024/8/7 9:02:41 611] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 611] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"151":"1"}
[2024/8/7 9:02:41 611] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18502 Q:1 Data:{"dps":{"151":"1"}}
[2024/8/7 9:02:41 627] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0
[2024/8/7 9:02:41 643] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:134, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:41 643] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:134, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:41 659] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:134, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:41 659] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 675] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 675] [08-07 09:02:42 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:0
[2024/8/7 9:02:41 691] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 691] __dp_data_report_data 7
[2024/8/7 9:02:41 691] 75 02 04 00 00 00 00 
[2024/8/7 9:02:41 691] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 707] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 707] bt_ack_uncrypt 7
[2024/8/7 9:02:41 707] 75 02 04 00 00 00 00 
[2024/8/7 9:02:41 707] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 723] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 9:02:41 723] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18503 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 9:02:41 738] [08-07 09:02:42 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:02:41 739] [08-07 09:02:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:41 739] tuya_hal_bt_send 20
[2024/8/7 9:02:41 755] 00 31 37 05 bc 25 a8 7b b9 50 eb 5e ac 51 ee 3c a2 58 df 06 
[2024/8/7 9:02:41 755] [08-07 09:02:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:41 755] 0 31 37 5 bc 25 a8 7b b9 50 eb 5e ac 51 ee 3c a2 58 df 6 
[2024/8/7 9:02:41 771] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:41 771] [08-07 09:02:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:41 787] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 787] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<138> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 803] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:41 803] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 803] __dp_data_report_data 4
[2024/8/7 9:02:41 803] 8a 01 01 00 
[2024/8/7 9:02:41 819] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 819] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 819] bt_ack_uncrypt 4
[2024/8/7 9:02:41 819] 8a 01 01 00 
[2024/8/7 9:02:41 835] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 835] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"138":false}
[2024/8/7 9:02:41 851] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18504 Q:1 Data:{"dps":{"138":false}}
[2024/8/7 9:02:41 851] current power mode:1
[2024/8/7 9:02:41 851] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 867] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:146 not find
[2024/8/7 9:02:41 867] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:41 867] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:41 867] current battery percent:80
[2024/8/7 9:02:41 883] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 883] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:145 not find
[2024/8/7 9:02:41 899] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:41 899] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:41 899] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 915] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 915] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:41 931] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:41 931] __dp_data_report_data 4
[2024/8/7 9:02:41 931] aa 01 01 00 
[2024/8/7 9:02:41 931] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 947] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:41 947] bt_ack_uncrypt 4
[2024/8/7 9:02:41 947] aa 01 01 00 
[2024/8/7 9:02:41 947] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:41 963] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"170":false}
[2024/8/7 9:02:41 963] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18505 Q:1 Data:{"dps":{"170":false}}
[2024/8/7 9:02:41 979] src/intelligent_track_thread.c(1466) [XM_GetBodyTarckEnable]: 
[2024/8/7 9:02:41 979] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:41 995] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:41 995] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:42 011] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:42 011] __dp_data_report_data 4
[2024/8/7 9:02:42 011] a1 01 01 00 
[2024/8/7 9:02:42 011] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 027] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:42 027] bt_ack_uncrypt 4
[2024/8/7 9:02:42 027] a1 01 01 00 
[2024/8/7 9:02:42 027] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 043] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"161":false}
[2024/8/7 9:02:42 043] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18506 Q:1 Data:{"dps":{"161":false}}
[2024/8/7 9:02:42 059] [08-07 09:02:42 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 9:02:42 059] [08-07 09:02:42 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 9:02:42 059] [08-07 09:02:42 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 9:02:42 075] [08-07 09:02:42 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 9:02:42 075] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 075] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:186 not find
[2024/8/7 9:02:42 091] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:42 091] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:42 091] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 107] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<133> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:42 107] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:42 123] __dp_data_report_data 4
[2024/8/7 9:02:42 123] 85 04 01 01 
[2024/8/7 9:02:42 123] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 139] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:42 140] bt_ack_uncrypt 4
[2024/8/7 9:02:42 140] 85 04 01 01 
[2024/8/7 9:02:42 140] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 140] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3"}
[2024/8/7 9:02:42 155] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18507 Q:1 Data:{"dps":{"133":"3"}}
[2024/8/7 9:02:42 155] [08-07 09:02:42 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 9:02:42 171] [08-07 09:02:42 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 9:02:42 171] [08-07 09:02:42 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 9:02:42 171] [08-07 09:02:42 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 9:02:42 187] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"106":"1"}}, mqtt async dp cb:0
[2024/8/7 9:02:42 203] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:106, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 203] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:106, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 219] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:106, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 219] [08-07 09:02:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:42 219] tuya_hal_bt_send 20
[2024/8/7 9:02:42 235] 01 d7 61 cc 61 e0 f4 03 e2 26 00 9b 6a 4e f8 3b ee fa 00 3a 
[2024/8/7 9:02:42 235] [08-07 09:02:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:42 236] 1 d7 61 cc 61 e0 f4 3 e2 26 0 9b 6a 4e f8 3b ee fa 0 3a 
[2024/8/7 9:02:42 251] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:42 251] [08-07 09:02:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:42 266] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0
[2024/8/7 9:02:42 267] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:110, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 283] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:110, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 298] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:110, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 299] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 314] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:42 315] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:42 315] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:42 331] __dp_data_report_data 4
[2024/8/7 9:02:42 331] 8b 01 01 00 
[2024/8/7 9:02:42 331] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 331] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:42 346] bt_ack_uncrypt 4
[2024/8/7 9:02:42 346] 8b 01 01 00 
[2024/8/7 9:02:42 347] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 362] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"109":"0|0|0"}}, mqtt async dp cb:0
[2024/8/7 9:02:42 362] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 9:02:42 379] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:109, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 380] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:109, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 395] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:109, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 396] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18508 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 9:02:42 411] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0
[2024/8/7 9:02:42 411] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:150, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 427] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:150, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 443] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:150, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 443] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[2024/8/7 9:02:42 459] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:151, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 459] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:151, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 475] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:151, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 475] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[2024/8/7 9:02:42 491] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:117, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 507] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:117, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 507] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:117, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 523] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 70 enable 0 volume
[2024/8/7 9:02:42 523] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"138":false}}, mqtt async dp cb:0
[2024/8/7 9:02:42 539] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:138, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 539] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:138, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 556] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:138, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 556] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"170":false}}, mqtt async dp cb:0
[2024/8/7 9:02:42 571] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:170, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 587] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:170, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 587] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:170, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 603] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 603] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:42 619] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:42 620] __dp_data_report_data 4
[2024/8/7 9:02:42 620] 8c 04 01 01 
[2024/8/7 9:02:42 620] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 635] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:42 635] bt_ack_uncrypt 4
[2024/8/7 9:02:42 635] 8c 04 01 01 
[2024/8/7 9:02:42 635] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 651] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"140":"1"}
[2024/8/7 9:02:42 651] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18509 Q:1 Data:{"dps":{"140":"1"}}
[2024/8/7 9:02:42 651] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 667] [08-07 09:02:42 TUYA E][smart_frame.c:569] dparr[0] type not match:1 0
[2024/8/7 9:02:42 667] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3586
[2024/8/7 9:02:42 683] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 683] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:42 699] [08-07 09:02:42 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:50
[2024/8/7 9:02:42 699] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:42 699] __dp_data_report_data 7
[2024/8/7 9:02:42 699] a0 02 04 00 00 00 32 
[2024/8/7 9:02:42 715] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 715] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:42 715] bt_ack_uncrypt 7
[2024/8/7 9:02:42 715] a0 02 04 00 00 00 32 
[2024/8/7 9:02:42 731] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 731] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"160":50}
[2024/8/7 9:02:42 747] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18510 Q:1 Data:{"dps":{"160":50}}
[2024/8/7 9:02:42 747] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 763] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:195 not find
[2024/8/7 9:02:42 763] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:42 764] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:42 779] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 779] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:194 not find
[2024/8/7 9:02:42 779] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:42 795] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:42 795] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 795] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:158 not find
[2024/8/7 9:02:42 811] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:42 811] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:42 827] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 827] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:42 843] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:42 843] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:42 843] __dp_data_report_data 4
[2024/8/7 9:02:42 843] 9f 01 01 00 
[2024/8/7 9:02:42 859] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 859] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:42 859] bt_ack_uncrypt 4
[2024/8/7 9:02:42 859] 9f 01 01 00 
[2024/8/7 9:02:42 874] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 875] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"139":false}}, mqtt async dp cb:0
[2024/8/7 9:02:42 891] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:02:42 891] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18511 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:02:42 907] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:139, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:42 908] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:139, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 923] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:139, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:42 924] [1970-01-01 00:00:36] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:02:42 939] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:42 939] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:42 955] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:42 955] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:42 955] __dp_data_report_data 4
[2024/8/7 9:02:42 955] ae 01 01 00 
[2024/8/7 9:02:42 972] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 972] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:42 972] bt_ack_uncrypt 4
[2024/8/7 9:02:42 972] ae 01 01 00 
[2024/8/7 9:02:42 987] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:42 987] [08-07 09:02:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:43 003] tuya_hal_bt_send 14
[2024/8/7 9:02:43 003] 02 a2 12 68 c8 5c 87 38 05 60 df 63 b9 33 
[2024/8/7 9:02:43 003] [08-07 09:02:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:43 003] 2 a2 12 68 c8 5c 87 38 5 60 df 63 b9 33 
[2024/8/7 9:02:43 019] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:43 019] [08-07 09:02:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:43 035] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"174":false}
[2024/8/7 9:02:43 035] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18512 Q:1 Data:{"dps":{"174":false}}
[2024/8/7 9:02:43 051] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"140":"1"}}, mqtt async dp cb:0
[2024/8/7 9:02:43 051] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:140, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:43 067] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:140, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 083] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:140, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 086] [1970-01-01 00:00:36] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:02:43 098] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"160":50}}, mqtt async dp cb:0
[2024/8/7 9:02:43 098] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:43 098] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:160, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:43 115] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:160, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 130] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:160, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 131] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:43 147] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:43 147] __dp_data_report_data 4
[2024/8/7 9:02:43 147] af 04 01 00 
[2024/8/7 9:02:43 147] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:43 162] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:43 162] bt_ack_uncrypt 4
[2024/8/7 9:02:43 162] af 04 01 00 
[2024/8/7 9:02:43 163] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:43 179] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"175":"0"}
[2024/8/7 9:02:43 179] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18513 Q:1 Data:{"dps":{"175":"0"}}
[2024/8/7 9:02:43 195] [1970-01-01 00:00:36] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:02:43 195] cruiseTimeMode is 0.
[2024/8/7 9:02:43 195] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:43 211] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:43 211] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:43 227] __dp_data_report_data 4
[2024/8/7 9:02:43 227] b0 04 01 00 
[2024/8/7 9:02:43 227] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:43 243] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:43 243] bt_ack_uncrypt 4
[2024/8/7 9:02:43 243] b0 04 01 00 
[2024/8/7 9:02:43 243] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:43 259] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"176":"0"}
[2024/8/7 9:02:43 260] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18514 Q:1 Data:{"dps":{"176":"0"}}
[2024/8/7 9:02:43 275] [1970-01-01 00:00:36] utils.c(322) <ReadTYJsonConfig>: Get antiFlicker object error!
[2024/8/7 9:02:43 275] anti Flicker mode is 0.
[2024/8/7 9:02:43 275] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:43 275] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:188 not find
[2024/8/7 9:02:43 291] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:43 291] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:43 307] [1970-01-01 00:00:36] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:02:43 307] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:43 307] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:192 not find
[2024/8/7 9:02:43 323] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:43 323] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:43 339] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:02:43 339] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:43 355] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 355] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 371] [1970-01-01 00:00:36] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:02:43 371] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"174":false}}, mqtt async dp cb:0
[2024/8/7 9:02:43 387] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:174, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:43 403] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:174, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 403] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:174, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 419] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:43 419] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:193 not find
[2024/8/7 9:02:43 419] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:43 435] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:43 435] [1970-01-01 00:00:36] utils.c(322) <ReadTYJsonConfig>: Get FlightWarn object error!
[2024/8/7 9:02:43 451] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:43 451] [08-07 09:02:42 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:173 not find
[2024/8/7 9:02:43 451] [08-07 09:02:42 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:02:43 467] [08-07 09:02:42 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:02:43 467] [1970-01-01 00:00:36] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:02:43 483] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:43 483] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:43 500] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:43 500] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:43 500] __dp_data_report_data 4
[2024/8/7 9:02:43 500] 78 01 01 00 
[2024/8/7 9:02:43 514] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:43 514] [1970-01-01 00:00:36] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time36824
[2024/8/7 9:02:43 531] [08-07 09:02:42 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1722992562,"success":true}
[2024/8/7 9:02:43 531] [08-07 09:02:42 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:43 547] [08-07 09:02:42 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:43 547] [08-07 09:02:42 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[2024/8/7 9:02:43 563] [08-07 09:02:42 TUYA D][tuya_ipc_cloud_storage.c:535] order expire or remote server error
[2024/8/7 9:02:43 563] [08-07 09:02:42 TUYA E][tuya_ipc_cloud_storage.c:1695] check cloud storage count failed, op_ret = -1
[2024/8/7 9:02:43 579] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"175":"0"}}, mqtt async dp cb:0
[2024/8/7 9:02:43 579] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:175, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:43 595] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:175, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 611] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:175, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 612] [08-07 09:02:42 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:43 627] [08-07 09:02:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:43 627] tuya_hal_bt_send 20
[2024/8/7 9:02:43 627] 00 31 38 05 67 0e b8 38 79 18 e4 4b 86 21 ed df 80 73 64 f6 
[2024/8/7 9:02:43 627] [08-07 09:02:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:43 643] 0 31 38 5 67 e b8 38 79 18 e4 4b 86 21 ed df 80 73 64 f6 
[2024/8/7 9:02:43 643] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:43 659] [08-07 09:02:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:43 659] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"176":"0"}}, mqtt async dp cb:0
[2024/8/7 9:02:43 675] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:176, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:43 675] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:176, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 691] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:176, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 691] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:43 691] bt_ack_uncrypt 4
[2024/8/7 9:02:43 707] 78 01 01 00 
[2024/8/7 9:02:43 707] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:43 707] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"120":false}
[2024/8/7 9:02:43 723] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18515 Q:1 Data:{"dps":{"120":false}}
[2024/8/7 9:02:43 723] [08-07 09:02:42 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:02:43 739] [08-07 09:02:42 TUYA D][smart_frame.c:419] dp<231> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:43 739] [08-07 09:02:42 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:43 755] [08-07 09:02:42 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:43 755] __dp_data_report_data 4
[2024/8/7 9:02:43 755] e7 01 01 00 
[2024/8/7 9:02:43 755] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:43 771] [08-07 09:02:42 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:02:43 771] bt_ack_uncrypt 4
[2024/8/7 9:02:43 771] e7 01 01 00 
[2024/8/7 9:02:43 771] [08-07 09:02:42 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:02:43 787] [08-07 09:02:42 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"231":false}
[2024/8/7 9:02:43 787] [08-07 09:02:42 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18516 Q:1 Data:{"dps":{"231":false}}
[2024/8/7 9:02:43 803] [08-07 09:02:42 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}","t":1722992562}
[2024/8/7 9:02:43 819] [08-07 09:02:42 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c96f4208f733a0b737eix&et=1&t=1722992562&v=1.0&sign=2e1b6ee57d55f350ffceec83361909de
[2024/8/7 9:02:43 834] [08-07 09:02:42 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:43 834] [08-07 09:02:42 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:43 850] [08-07 09:02:42 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:43 850] [08-07 09:02:42 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:43 866] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"120":false}}, mqtt async dp cb:0
[2024/8/7 9:02:43 867] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:120, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:43 882] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:120, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 883] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:120, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 898] [08-07 09:02:42 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:43 899] [08-07 09:02:42 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:43 915] [08-07 09:02:42 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:43 915] [08-07 09:02:42 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:43 930] [08-07 09:02:42 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:43 931] [08-07 09:02:42 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:43 946] [08-07 09:02:42 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:43 947] [08-07 09:02:42 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"231":false}}, mqtt async dp cb:0
[2024/8/7 9:02:43 963] [08-07 09:02:42 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:231, curr_t:1722992562, rept_cnt:1.
[2024/8/7 9:02:43 963] [08-07 09:02:42 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:231, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 978] [08-07 09:02:42 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:231, curr_t:1722992562, rept_cnt:0.
[2024/8/7 9:02:43 978] [08-07 09:02:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:43 994] tuya_hal_bt_send 20
[2024/8/7 9:02:43 994] 01 cc 2b ba a8 6d 97 bc 13 45 46 f5 78 af ec 15 91 3d 6e 28 
[2024/8/7 9:02:43 994] [08-07 09:02:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:44 011] 1 cc 2b ba a8 6d 97 bc 13 45 46 f5 78 af ec 15 91 3d 6e 28 
[2024/8/7 9:02:44 011] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:44 027] [08-07 09:02:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:44 027] [08-07 09:02:42 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:44 043] [08-07 09:02:42 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:44 043] [08-07 09:02:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:44 060] tuya_hal_bt_send 14
[2024/8/7 9:02:44 060] 02 5c e4 d5 6d 90 4f e7 37 cc f1 8b de b0 
[2024/8/7 9:02:44 060] [08-07 09:02:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:44 060] 2 5c e4 d5 6d 90 4f e7 37 cc f1 8b de b0 
[2024/8/7 9:02:44 075] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:44 075] [08-07 09:02:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:44 091] [08-07 09:02:42 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992563,"success":true}
[2024/8/7 9:02:44 091] [08-07 09:02:43 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:44 107] [08-07 09:02:43 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:44 108] [08-07 09:02:43 TUYA D][tuya_ipc_skill.c:198] upload data: {\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}
[2024/8/7 9:02:44 123] [08-07 09:02:43 TUYA D][MainApp.c:597] tuya_ipc_sdk_mqtt_online_proc is end run
[2024/8/7 9:02:44 123] [1970-01-01 00:00:37] MainApp.c(599) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:02:44 139] tuya_ipc_p2p_demo.c(455)<TUYA_APP_Enable_P2PTransfer> Dbg: Init P2P With Max Users:5
[2024/8/7 9:02:44 139] [08-07 09:02:43 TUYA D][tuya_ipc_webrtc.c:1534] begin___
[2024/8/7 9:02:44 139] [08-07 09:02:43 TUYA D][tuya_ipc_webrtc.c:1541] --audio-:8000,format:101
[2024/8/7 9:02:44 155] [08-07 09:02:43 TUYA D][tuya_ipc_webrtc.c:1542] end___ audiocbk_hdl(0x18f5c)
[2024/8/7 9:02:44 155] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5086] gw actived
[2024/8/7 9:02:44 171] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5095] p2p max_client_num[5]
[2024/8/7 9:02:44 171] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5096] p2p init media info:
[2024/8/7 9:02:44 171] [08-07 09:02:43 TUYA D][tuya_ipc_webrtc.c:1526] webrtc playback start_id 5
[2024/8/7 9:02:44 187] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:02:44 187] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4782] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:02:44 203] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:02:44 203] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4782] height[360] width[640] bitrate[1024]
[2024/8/7 9:02:44 218] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:02:44 219] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4794] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:02:44 219] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:02:44 234] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4794] height[360] width[640] bitrate[1024]
[2024/8/7 9:02:44 234] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:02:44 250] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:02:44 251] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:02:44 266] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:02:44 266] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:02:44 282] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:02:44 282] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:02:44 299] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:02:44 299] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:02:44 315] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:02:44 315] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4796] videoNum[2] audio codec[129] sample[0]
[2024/8/7 9:02:44 331] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4797] databits[1] channel[0]
[2024/8/7 9:02:44 331] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5122] need speaker audio codec[129] sample[0] databits[1] channel[0] defLiveMode[0]
[2024/8/7 9:02:44 347] [08-07 09:02:43 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:02:44 347] [08-07 09:02:43 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:02:44 363] [08-07 09:02:43 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:02:44 363] [08-07 09:02:43 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = adb2c7ae
[2024/8/7 9:02:44 363] [08-07 09:02:43 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[2024/8/7 9:02:44 379] [08-07 09:02:43 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:02:44 379] [08-07 09:02:43 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:02:44 395] [08-07 09:02:43 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:02:44 395] [08-07 09:02:43 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:02:44 395] [08-07 09:02:43 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:02:44 411] [08-07 09:02:43 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:02:44 411] [08-07 09:02:43 TUYA D][tuya_ipc_p2p_common.c:455] update p2p_auth_info from service, type 4
[2024/8/7 9:02:44 427] [08-07 09:02:43 TUYA D][iot_httpc.c:1161] Post Data: {"type":4,"t":1722992563}
[2024/8/7 9:02:44 443] [08-07 09:02:43 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.p2p.config.get&devId=6c96f4208f733a0b737eix&et=1&t=1722992563&v=2.0&sign=e2b6b031ce5727e1f7338b115fa54616
[2024/8/7 9:02:44 443] [08-07 09:02:43 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:44 459] [08-07 09:02:43 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:44 459] [08-07 09:02:43 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:44 475] [08-07 09:02:43 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:44 475] [08-07 09:02:43 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:44 491] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:44 491] tuya_hal_bt_send 20
[2024/8/7 9:02:44 491] 00 31 39 05 ec b9 88 66 51 6d 31 57 0e 1f 37 0f 12 1c 06 84 
[2024/8/7 9:02:44 507] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:44 507] 0 31 39 5 ec b9 88 66 51 6d 31 57 e 1f 37 f 12 1c 6 84 
[2024/8/7 9:02:44 507] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:44 523] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:44 523] [08-07 09:02:43 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:44 539] [08-07 09:02:43 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:44 539] [08-07 09:02:43 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:44 555] [08-07 09:02:43 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:44 555] [08-07 09:02:43 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:44 571] [08-07 09:02:43 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:44 571] [08-07 09:02:43 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:44 587] [08-07 09:02:43 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:44 587] [08-07 09:02:43 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:44 602] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:44 603] tuya_hal_bt_send 20
[2024/8/7 9:02:44 603] 01 a5 25 2d 7f 7e 85 23 53 03 52 d4 71 c5 0e db ac 61 f1 41 
[2024/8/7 9:02:44 618] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:44 618] 1 a5 25 2d 7f 7e 85 23 53 3 52 d4 71 c5 e db ac 61 f1 41 
[2024/8/7 9:02:44 634] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:44 635]  ---
[2024/8/7 9:02:44 635] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:44 650] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:44 651] tuya_hal_bt_send 14
[2024/8/7 9:02:44 651] 02 4f 8f 56 c5 a4 4b 17 46 c9 96 58 4f d9 
[2024/8/7 9:02:44 651] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:44 666] 2 4f 8f 56 c5 a4 4b 17 46 c9 96 58 4f d9 
[2024/8/7 9:02:44 667] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:44 667] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:44 683] [08-07 09:02:43 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:44 698] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:44 698] tuya_hal_bt_send 20
[2024/8/7 9:02:44 699] 00 31 3a 05 88 b7 55 59 a4 86 b0 b2 26 e8 c1 38 84 48 bd 7f 
[2024/8/7 9:02:44 699] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:44 715] 0 31 3a 5 88 b7 55 59 a4 86 b0 b2 26 e8 c1 38 84 48 bd 7f 
[2024/8/7 9:02:44 715] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:44 730] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:44 731] [08-07 09:02:43 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"p2pId":"","type":4},"t":1722992563,"success":true}
[2024/8/7 9:02:44 747] [08-07 09:02:43 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:44 747] [08-07 09:02:43 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:44 747] [08-07 09:02:43 TUYA D][tuya_ipc_p2p_common.c:381] SY P2P AUTH:{"p2pId":"","type":4}
[2024/8/7 9:02:44 763] [08-07 09:02:43 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:02:44 763] [08-07 09:02:43 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:02:44 778] [08-07 09:02:43 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:02:44 779] [08-07 09:02:43 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:32
[2024/8/7 9:02:44 795] [08-07 09:02:43 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 32
[2024/8/7 9:02:44 795] [08-07 09:02:43 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:02:44 795] [08-07 09:02:43 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:02:44 811] [08-07 09:02:43 TUYA D][simplekv.c:203] update crc 1752640331
[2024/8/7 9:02:44 811] [08-07 09:02:43 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:44 811] [08-07 09:02:43 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:44 827] [08-07 09:02:43 TUYA D][tuya_ipc_p2p_common.c:458] get p2p auth info from service
[2024/8/7 9:02:44 827] [08-07 09:02:43 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:02:44 843] [08-07 09:02:43 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:02:44 843] [08-07 09:02:43 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:02:44 843] [08-07 09:02:43 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:02:44 859] [08-07 09:02:43 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:02:44 859] [08-07 09:02:43 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:02:44 875] [08-07 09:02:43 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:02:44 875] [08-07 09:02:43 TUYA D][simplekv.c:203] update crc 153112248
[2024/8/7 9:02:44 875] [08-07 09:02:43 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:44 891] [08-07 09:02:43 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:44 891] [08-07 09:02:43 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:02:44 891] [08-07 09:02:43 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:02:44 907] [08-07 09:02:43 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:02:44 907] [08-07 09:02:43 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[2024/8/7 9:02:44 923] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5178] p2p did[] apiLicense[] initString[]
[2024/8/7 9:02:44 923] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5181] support p2p type = 4
[2024/8/7 9:02:44 923] P2P API Version: 244.3.4.107
[2024/8/7 9:02:44 938] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4974] no encrypt
[2024/8/7 9:02:44 938] 37167 (null) INFO:6241316: tuya p2p rtc sdk version: 0xf403046b, Nov 16 2023 10:52:20
[2024/8/7 9:02:44 938] tuya liteos uv
[2024/8/7 9:02:44 955] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:44 955] tuya_hal_bt_send 20
[2024/8/7 9:02:44 955] 01 6a 6b ae 2e 3b 37 9c 7d 87 b5 b8 bb 50 38 56 17 78 89 83 
[2024/8/7 9:02:44 971] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:44 971] 1 6a 6b ae 2e 3b 37 9c 7d 87 b5 b8 bb 50 38 56 17 78 89 83 
[2024/8/7 9:02:44 972] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:44 987]  ---
[2024/8/7 9:02:44 987] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 003] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:45 003] tuya_hal_bt_send 14
[2024/8/7 9:02:45 003] 02 fc 54 9c 17 f9 3e 71 4b ed 30 d7 9a 5b 
[2024/8/7 9:02:45 003] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 003] 2 fc 54 9c 17 f9 3e 71 4b ed 30 d7 9a 5b 
[2024/8/7 9:02:45 019] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 019] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 035] [08-07 09:02:43 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:45 035] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:45 051] tuya_hal_bt_send 20
[2024/8/7 9:02:45 051] 00 31 3b 05 5d b9 6f e2 b6 82 e3 a8 8f a4 32 20 d5 14 3a 3d 
[2024/8/7 9:02:45 051] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 067] 0 31 3b 5 5d b9 6f e2 b6 82 e3 a8 8f a4 32 20 d5 14 3a 3d 
[2024/8/7 9:02:45 067] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 067] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 083] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:45 083] tuya_hal_bt_send 20
[2024/8/7 9:02:45 099] 01 f0 6b 41 ad 4f d6 8e 6d 18 b6 e0 8a 3d eb e1 e4 0b a9 a4 
[2024/8/7 9:02:45 099] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 099] 1 f0 6b 41 ad 4f d6 8e 6d 18 b6 e0 8a 3d eb e1 e4 b a9 a4 
[2024/8/7 9:02:45 115] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 115] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 131] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:45 131] tuya_hal_bt_send 14
[2024/8/7 9:02:45 131] 02 90 68 84 8e 34 82 91 d0 40 9e 95 8e d5 
[2024/8/7 9:02:45 131] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 146] 2 90 68 84 8e 34 82 91 d0 40 9e 95 8e d5 
[2024/8/7 9:02:45 147] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 147] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 163] [08-07 09:02:43 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:45 178] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:45 178] tuya_hal_bt_send 20
[2024/8/7 9:02:45 178] 00 31 3c 05 37 ad 06 6d 30 e9 16 40 8f 48 60 e4 db 1a 22 0c 
[2024/8/7 9:02:45 178] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 195] 0 31 3c 5 37 ad 6 6d 30 e9 16 40 8f 48 60 e4 db 1a 22 c 
[2024/8/7 9:02:45 195] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 211] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 211] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:45 211] tuya_hal_bt_send 20
[2024/8/7 9:02:45 227] 01 95 7f 5f 6e de fe 54 50 d4 e8 29 65 44 1c 08 f7 9c b4 1f 
[2024/8/7 9:02:45 227] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 227] 1 95 7f 5f 6e de fe 54 50 d4 e8 29 65 44 1c 8 f7 9c b4 1f 
[2024/8/7 9:02:45 243] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 243] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 260] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:45 260] tuya_hal_bt_send 14
[2024/8/7 9:02:45 260] 02 8f aa 6e 15 f0 2e 32 0e 2c a0 16 9c 62 
[2024/8/7 9:02:45 275] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 275] 2 8f aa 6e 15 f0 2e 32 e 2c a0 16 9c 62 
[2024/8/7 9:02:45 275] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 291] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 292] [08-07 09:02:43 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:45 307] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:45 307] tuya_hal_bt_send 20
[2024/8/7 9:02:45 307] 00 31 3d 05 c6 7c e8 77 e6 7e 37 f5 47 17 da 23 32 7d 2f d9 
[2024/8/7 9:02:45 323] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 323] 0 31 3d 5 c6 7c e8 77 e6 7e 37 f5 47 17 da 23 32 7d 2f d9 
[2024/8/7 9:02:45 323] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 339] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 339] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:45 339] tuya_hal_bt_send 20
[2024/8/7 9:02:45 355] 01 3b 19 a6 53 bb ef 58 2b 7d 4e 1c b2 57 3a 64 b7 2c 0d b7 
[2024/8/7 9:02:45 355] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 355] 1 3b 19 a6 53 bb ef 58 2b 7d 4e 1c b2 57 3a 64 b7 2c d b7 
[2024/8/7 9:02:45 371] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 371] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 387] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5039] _mqtt_p2p_listen_sessions create
[2024/8/7 9:02:45 387] [08-07 09:02:43 TUYA E][tuya_ipc_p2p.c:5190] p2p v3 init ok
[2024/8/7 9:02:45 403] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5230] speaker task create success
[2024/8/7 9:02:45 403] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5273] __p2p_session_detech create
[2024/8/7 9:02:45 403] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:5290] __p2p_video_send_proc create ok
[2024/8/7 9:02:45 419] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4124] Begin to Listen mqtt p2p client connects In Thread
[2024/8/7 9:02:45 419] [08-07 09:02:43 TUYA D][tuya_ipc_upnp.c:437] tuya_ipc_upnp_init start
[2024/8/7 9:02:45 434] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 9:02:45 434] 37739 (null) INFO:6241316: try listen
[2024/8/7 9:02:45 450] [08-07 09:02:43 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:156672,priority:2
[2024/8/7 9:02:45 450] [08-07 09:02:43 TUYA D][tuya_ipc_upnp.c:458] tuya_ipc_upnp_init success
[2024/8/7 9:02:45 451] [08-07 09:02:43 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[2024/8/7 9:02:45 467] [08-07 09:02:43 TUYA D][tuya_ipc_packager.c:62] get packager instance
[2024/8/7 9:02:45 467] [08-07 09:02:43 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[2024/8/7 9:02:45 482] [08-07 09:02:43 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:45 483] [08-07 09:02:43 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:45 483] [08-07 09:02:43 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:45 498] [08-07 09:02:43 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:45 498] [08-07 09:02:43 TUYA E][tuya_ipc_encrypt.c:178] read local cloud encrypt key fails ..-6
[2024/8/7 9:02:45 514] [08-07 09:02:43 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[2024/8/7 9:02:45 515] [08-07 09:02:43 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1722992563}
[2024/8/7 9:02:45 531] [08-07 09:02:43 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6c96f4208f733a0b737eix&et=1&t=1722992563&v=1.0&sign=5e7a262a4b4a0f8d5c7aa0ea331fd2b9
[2024/8/7 9:02:45 547] [08-07 09:02:43 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:45 547] [08-07 09:02:43 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:45 563] [08-07 09:02:43 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:45 563] [08-07 09:02:43 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:45 578] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:3553] New Thread To proc, init source
[2024/8/7 9:02:45 579] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:3572] session cmd recv proc alive [0] num[0]
[2024/8/7 9:02:45 579] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:4652] Begin to session detech
[2024/8/7 9:02:45 594] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:3771] into p2p video send
[2024/8/7 9:02:45 594] [08-07 09:02:43 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [0]
[2024/8/7 9:02:45 610] [08-07 09:02:43 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722992563}
[2024/8/7 9:02:45 627] [08-07 09:02:43 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.storage.secret.get&devId=6c96f4208f733a0b737eix&et=1&t=1722992563&v=1.0&sign=5ba5dfae1d040b61586a6909ab22c55b
[2024/8/7 9:02:45 627] [08-07 09:02:43 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:45 643] [08-07 09:02:43 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:45 643] [08-07 09:02:43 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:45 659] [08-07 09:02:43 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:45 659] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:45 659] tuya_hal_bt_send 14
[2024/8/7 9:02:45 675] 02 9e 0d 17 fa a1 e0 11 42 76 96 13 ed 0f 
[2024/8/7 9:02:45 675] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 675] 2 9e d 17 fa a1 e0 11 42 76 96 13 ed f 
[2024/8/7 9:02:45 691] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 691] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 691] [08-07 09:02:43 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:45 707] [08-07 09:02:43 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:45 707] [08-07 09:02:43 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:45 723] [08-07 09:02:43 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:45 723] [08-07 09:02:43 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:45 739] [08-07 09:02:43 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:45 739] [08-07 09:02:43 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:45 755] [08-07 09:02:43 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:45 755] [08-07 09:02:43 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:45 771] [08-07 09:02:43 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:45 771] [08-07 09:02:43 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:45 787] [08-07 09:02:43 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:45 787] [08-07 09:02:43 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:45 787] [08-07 09:02:43 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:45 803] [08-07 09:02:43 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:45 819] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:45 819] tuya_hal_bt_send 20
[2024/8/7 9:02:45 819] 00 31 3e 05 d7 76 ab be f4 62 b4 bb 79 90 df 2b 8d 8e 05 12 
[2024/8/7 9:02:45 819] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 835] 0 31 3e 5 d7 76 ab be f4 62 b4 bb 79 90 df 2b 8d 8e 5 12 
[2024/8/7 9:02:45 835] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 851] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 851] [1970-01-01 00:00:37] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:45 867] [08-07 09:02:43 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:45 867] [08-07 09:02:43 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:45 883] [08-07 09:02:43 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:45 899] [08-07 09:02:43 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:45 899] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:45 914] tuya_hal_bt_send 20
[2024/8/7 9:02:45 914] 01 a4 fa 19 ec be de 60 b9 64 23 25 6e 5b 8b fa d4 a8 e7 0f 
[2024/8/7 9:02:45 915] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:45 930] 1 a4 fa 19 ec be de 60 b9 64 23 25 6e 5b 8b fa d4 a8 e7 f 
[2024/8/7 9:02:45 930] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:45 931] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:45 946] [08-07 09:02:43 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"encryptKey":"992e9749e8f3402a"},"t":1722992563,"success":true}
[2024/8/7 9:02:45 946] [08-07 09:02:43 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:45 978] [08-07 09:02:43 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"unitList":[{"port":7000,"protocol":"TCP"},{"port":8080,"protocol":"TCP"},{"port":5000,"protocol":"UDP"},{"port":8000,"protocol":"UDP"}]},"t":1722992563,"success":true}
[2024/8/7 9:02:45 978] [08-07 09:02:43 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:45 994] [08-07 09:02:43 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:02:45 994] [08-07 09:02:43 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:45 994] [08-07 09:02:43 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:46 010] [08-07 09:02:43 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:46 010] [08-07 09:02:43 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:46 026] [08-07 09:02:43 TUYA D][simplekv.c:374] write key:cloud_enc_key And Value Len:32
[2024/8/7 9:02:46 027] [08-07 09:02:43 TUYA D][simplekv.c:457] new space 17 startpos:37392 size:100
[2024/8/7 9:02:46 027] [08-07 09:02:43 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:46 042] [08-07 09:02:43 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:02:46 042] [08-07 09:02:43 TUYA D][simplekv.c:203] update crc 254552848
[2024/8/7 9:02:46 058] [08-07 09:02:43 TUYA D][tuya_ipc_upnp.c:171] upnp get config success result:{
[2024/8/7 9:02:46 058] 	"unitList":	[{
[2024/8/7 9:02:46 058] 			"port":	7000,
[2024/8/7 9:02:46 058] 			"protocol":	"TCP"
[2024/8/7 9:02:46 058] 		}, {
[2024/8/7 9:02:46 058] 			"port":	8080,
[2024/8/7 9:02:46 058] 			"port":	5000,
[2024/8/7 9:02:46 058] 			"protocol":	"UDP"
[2024/8/7 9:02:46 058] 			"port":	8000,
[2024/8/7 9:02:46 074] 			"protocol":	"UDP"
[2024/8/7 9:02:46 074] 		}]
[2024/8/7 9:02:46 074] [08-07 09:02:43 TUYA D][tuya_ipc_upnp.c:293] tuya_ipc_upnp_start start
[2024/8/7 9:02:46 090] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10.
[2024/8/7 9:02:46 090] [08-07 09:02:43 TUYA I][uni_thread.c:228] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:222208,priority:3
[2024/8/7 9:02:46 106] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0
[2024/8/7 9:02:46 122] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0
[2024/8/7 9:02:46 122] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:7250 
[2024/8/7 9:02:46 138] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 7250, in_port 7250 protocol:UDP, status:0
[2024/8/7 9:02:46 139] 
[2024/8/7 9:02:46 139] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:6426 
[2024/8/7 9:02:46 154] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 6426, in_port 6426 protocol:UDP, status:0
[2024/8/7 9:02:46 154] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:2633 
[2024/8/7 9:02:46 155] 
[2024/8/7 9:02:46 171] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 2633, in_port 2633 protocol:UDP, status:0
[2024/8/7 9:02:46 187] [08-07 09:02:43 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5!
[2024/8/7 9:02:46 187] [08-07 09:02:43 TUYA D][tuya_ipc_upnp.c:314] tuya_ipc_upnp_start success
[2024/8/7 9:02:46 203] [08-07 09:02:43 TUYA D][tuya_ipc_upnp.c:421] start upnp module success, exit thread
[2024/8/7 9:02:46 204] [08-07 09:02:43 TUYA D][uni_thread.c:310] Del Thrd:ipc_upnp
[2024/8/7 9:02:46 204] [08-07 09:02:43 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:46 219] [08-07 09:02:43 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:46 219] [08-07 09:02:43 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:230400,priority:3
[2024/8/7 9:02:46 235] [08-07 09:02:43 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[2024/8/7 9:02:46 267] [08-07 09:02:43 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":90000,\"profileId\":\"\",\"width\":3840,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[2024/8/7 9:02:46 267] [1970-01-01 00:00:37] tuya_ipc_p2p_demo.c(475) <TUYA_APP_Enable_P2PTransfer>: tuya_ipc_tranfser_init ret=[0]
[2024/8/7 9:02:46 283] [1970-01-01 00:00:37] MainApp.c(606) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:02:46 283] [1970-01-01 00:00:37] MainApp.c(614) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:02:46 299] [1970-01-01 00:00:37] MainApp.c(615) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:02:46 299] [1970-01-01 00:00:37] MainApp.c(616) <tuya_ipc_sdk_mqtt_online_proc>: v_handle=[0x1967798]
[2024/8/7 9:02:46 315] [1970-01-01 00:00:37] MainApp.c(617) <tuya_ipc_sdk_mqtt_online_proc>: v_handle_sub=[0x1967720]
[2024/8/7 9:02:46 331] [1970-01-01 00:00:37] MainApp.c(618) <tuya_ipc_sdk_mqtt_online_proc>: a_handle_sub=[0x19676a8]
[2024/8/7 9:02:46 331] [1970-01-01 00:00:37] xm_main.c(1104) <XM_RegisterTYCallFunc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:02:46 347] [1970-01-01 00:00:37] xm_main.c(1105) <XM_RegisterTYCallFunc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:02:46 347] [1970-01-01 00:00:37] xm_main.c(1106) <XM_RegisterTYCallFunc>: a_handle_sub=[0x19676a8]
[2024/8/7 9:02:46 363] [1970-01-01 00:00:37] xm_main.c(1107) <XM_RegisterTYCallFunc>: v_handle=[0x1967798]
[2024/8/7 9:02:46 363] [1970-01-01 00:00:37] xm_main.c(1108) <XM_RegisterTYCallFunc>: v_handle_sub=[0x1967720]
[2024/8/7 9:02:46 379] [1970-01-01 00:00:37] MainApp.c(620) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:02:46 379] [1970-01-01 00:00:37] MainApp.c(621) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:02:46 395] [08-07 09:02:43 TUYA D][uni_thread.c:125] del list not empty...deleting 0x195ad24, next 0x190d8c8
[2024/8/7 9:02:46 395] [08-07 09:02:43 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:02:46 411] [08-07 09:02:43 TUYA D][uni_thread.c:250] Thread:UPnP_PROC Exec Start. Set to Running Stat
[2024/8/7 9:02:46 411] [08-07 09:02:43 TUYA D][uni_thread.c:125] del list not empty...deleting 0x195ad24, next 0x190d8c8
[2024/8/7 9:02:46 427] [08-07 09:02:43 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:02:46 427] [08-07 09:02:43 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[2024/8/7 9:02:46 443] [08-07 09:02:43 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[2024/8/7 9:02:46 444] [08-07 09:02:43 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[2024/8/7 9:02:46 444] [08-07 09:02:43 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992563 28800
[2024/8/7 9:02:46 459] [08-07 09:02:43 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992563 28800
[2024/8/7 9:02:46 474] --- tracepoint tuya_ipc_system_control_demo.c,XM_CheckDls_Pro(810): server time_zone 28800 time 1722992563 dls 0 loacl time 37
[2024/8/7 9:02:46 475] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:46 475] tuya_hal_bt_send 14
[2024/8/7 9:02:46 490] 02 08 de c9 80 f3 e8 1e a4 42 ae 26 89 0a 
[2024/8/7 9:02:46 491] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:46 491] 2 8 de c9 80 f3 e8 1e a4 42 ae 26 89 a 
[2024/8/7 9:02:46 506] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:46 506] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:46 506] [08-07 09:02:43 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:46 522] [08-07 09:02:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:46 522] tuya_hal_bt_send 20
[2024/8/7 9:02:46 540] 00 31 3f 05 4e 1d 69 c3 7f 9d 7f f8 2e de 25 3b ed a9 4e 6c 
[2024/8/7 9:02:46 540] [08-07 09:02:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:46 540] 0 31 3f 5 4e 1d 69 c3 7f 9d 7f f8 2e de 25 3b ed a9 4e 6c 
[2024/8/7 9:02:46 555] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:46 555] [08-07 09:02:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:46 571] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:46 571] tuya_hal_bt_send 20
[2024/8/7 9:02:46 571] 01 23 d8 79 75 a4 cb bb 4c b6 69 fc 1d 1d 7e b0 65 1a 07 15 
[2024/8/7 9:02:46 587] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:46 588] 1 23 d8 79 75 a4 cb bb 4c b6 69 fc 1d 1d 7e b0 65 1a 7 15 
[2024/8/7 9:02:46 588] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:46 603] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:46 619] [2024-08-07 09:02:43] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 1039[08-07 09:02:44 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 90314ba51650
[2024/8/7 9:02:46 619] [08-07 09:02:44 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING...
[2024/8/7 9:02:46 635] [08-07 09:02:44 TUYA D][uni_thread.c:268] Thread:ipc_upnp Exec Finish. Set to Del Stat
[2024/8/7 9:02:46 635] [08-07 09:02:44 TUYA D][uni_thread.c:125] del list not empty...deleting 0x195ad24, next 0x190d8c8
[2024/8/7 9:02:46 651] [08-07 09:02:44 TUYA D][uni_thread.c:132] Final Free Thread:ipc_upnp, is_self:1
[2024/8/7 9:02:46 651] [08-07 09:02:44 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:02:46 651] [08-07 09:02:44 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:02:46 667] [2024-08-07 09:02:43] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 17883[08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:46 683] tuya_hal_bt_send 14
[2024/8/7 9:02:46 683] 02 4a 94 27 b6 72 f7 93 bc 97 03 3e 7f 8c 
[2024/8/7 9:02:46 683] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:46 683] 2 4a 94 27 b6 72 f7 93 bc 97 3 3e 7f 8c 
[2024/8/7 9:02:46 699] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:46 699] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:46 715] [08-07 09:02:44 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:46 715] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:46 731] tuya_hal_bt_send 20
[2024/8/7 9:02:46 731] 00 31 30 05 69 dc 6e 68 7a 6e 62 29 cc 07 64 ba 30 32 28 c2 
[2024/8/7 9:02:46 731] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:46 747] 0 31 30 5 69 dc 6e 68 7a 6e 62 29 cc 7 64 ba 30 32 28 c2 
[2024/8/7 9:02:46 747] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:46 747] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:46 763] [08-07 09:02:44 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.107, Nov 16 2023 10:52:20\"}","t":1722992564}
[2024/8/7 9:02:46 779] [08-07 09:02:44 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c96f4208f733a0b737eix&et=1&t=1722992564&v=1.0&sign=ac9af141c6092145dd009b5f8b07384d
[2024/8/7 9:02:46 795] [08-07 09:02:44 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:46 795] [08-07 09:02:44 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:46 811] [08-07 09:02:44 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:46 811] [08-07 09:02:44 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:46 827] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:46 827] tuya_hal_bt_send 20
[2024/8/7 9:02:46 827] 01 9f f6 91 6b ba 97 98 19 8f 50 7c 20 53 42 91 e5 b5 3e 27 
[2024/8/7 9:02:46 842] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:46 842] 1 9f f6 91 6b ba 97 98 19 8f 50 7c 20 53 42 91 e5 b5 3e 27 
[2024/8/7 9:02:46 843] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:46 858]  ---
[2024/8/7 9:02:46 859] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:46 859] [08-07 09:02:44 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:46 874] [08-07 09:02:44 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:46 875] [08-07 09:02:44 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:46 890] [08-07 09:02:44 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:46 890] [08-07 09:02:44 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:46 907] [08-07 09:02:44 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:46 907] [08-07 09:02:44 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:46 923] [08-07 09:02:44 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:46 923] [08-07 09:02:44 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:46 939] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:46 939] tuya_hal_bt_send 14
[2024/8/7 9:02:46 939] 02 3f fa e5 56 2b 27 81 4b 8b 80 4d 36 b9 
[2024/8/7 9:02:46 955] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:46 955] 2 3f fa e5 56 2b 27 81 4b 8b 80 4d 36 b9 
[2024/8/7 9:02:46 955] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:46 971] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:46 971] [08-07 09:02:44 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:36 ip:0xc0a81ff2
[2024/8/7 9:02:46 987] [08-07 09:02:44 TUYA D][app_agent.c:1540] fd:36, wk_stat = 2, type = 3
[2024/8/7 9:02:46 987] [08-07 09:02:44 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:02:46 987] [08-07 09:02:44 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:02:47 003] [08-07 09:02:44 TUYA D][app_agent.c:600] send length:64, id:36, sequence_out:48928
[2024/8/7 9:02:47 003] [08-07 09:02:44 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722992564,"success":true}
[2024/8/7 9:02:47 019] [08-07 09:02:44 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:47 019] [08-07 09:02:44 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:47 035] [08-07 09:02:44 TUYA D][app_agent.c:1540] fd:36, wk_stat = 2, type = 5
[2024/8/7 9:02:47 035] [08-07 09:02:44 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:02:47 035] [08-07 09:02:44 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:02:47 051] [08-07 09:02:44 TUYA D][app_agent.c:1540] fd:36, wk_stat = 2, type = 16
[2024/8/7 9:02:47 051] [08-07 09:02:44 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:02:47 051] [08-07 09:02:44 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:02:47 067] [08-07 09:02:44 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:0,dpnum:41.
[2024/8/7 9:02:47 098] [08-07 09:02:44 TUYA D][smart_frame.c:2547] final pack:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"117":0,"120":false,"124":"auto","133":"3","134":true,"138":false,"139":false,"140":"1","150":true,"151":"1","159":false,"160":50,"161":false,"170":false,"174":false,"175":"0","176":"0","231":false}}
[2024/8/7 9:02:47 115] [08-07 09:02:44 TUYA D][app_agent.c:1240] Send Query To App:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"117":0,"120":false,"124":"auto","133":"3","134":true,"138":false,"139":false,"140":"1","150":true,"151":"1","159":false,"160":50,"161":false,"170":false,"174":false,"175":"0","176":"0","231":false}}
[2024/8/7 9:02:47 131] [08-07 09:02:44 TUYA D][app_agent.c:600] send length:288, id:36, sequence_out:48929
[2024/8/7 9:02:47 131] [08-07 09:02:44 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:47 147] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:47 147] tuya_hal_bt_send 20
[2024/8/7 9:02:47 162] 00 31 30 05 25 78 e8 a0 66 ca 49 33 51 2d 6e 81 60 16 c4 63 
[2024/8/7 9:02:47 164] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 164] 0 31 30 5 25 78 e8 a0 66 ca 49 33 51 2d 6e 81 60 16 c4 63 
[2024/8/7 9:02:47 178] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 178] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 195] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:47 195] tuya_hal_bt_send 20
[2024/8/7 9:02:47 195] 01 18 1a 7a 38 1c 9e 39 60 7a e1 c1 06 ab 3c 60 6e a5 53 92 
[2024/8/7 9:02:47 195] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 210] 1 18 1a 7a 38 1c 9e 39 60 7a e1 c1 6 ab 3c 60 6e a5 53 92 
[2024/8/7 9:02:47 210] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 211]  ---
[2024/8/7 9:02:47 226] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 226] g_AudioTipsList.size() enable: 0[08-07 09:02:44 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:02:47 242] [08-07 09:02:44 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:02:47 243] [08-07 09:02:44 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:02:47 258] [08-07 09:02:44 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:02:47 258] [08-07 09:02:44 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:02:47 274] [08-07 09:02:44 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18517 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:02:47 274] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:47 274] tuya_hal_bt_send 14
[2024/8/7 9:02:47 291] 02 9f 68 fa ac 6e 4f 20 67 f4 34 00 d4 58 
[2024/8/7 9:02:47 291] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 291] 2 9f 68 fa ac 6e 4f 20 67 f4 34 0 d4 58 
[2024/8/7 9:02:47 307] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 307] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 323] [08-07 09:02:44 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:02:47 323] [08-07 09:02:44 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722992564, rept_cnt:2.
[2024/8/7 9:02:47 339] [08-07 09:02:44 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722992564, rept_cnt:0.
[2024/8/7 9:02:47 339] [08-07 09:02:44 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722992564, rept_cnt:0.
[2024/8/7 9:02:47 355] [08-07 09:02:44 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:47 355] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:47 371] tuya_hal_bt_send 20
[2024/8/7 9:02:47 371] 00 31 30 05 66 e9 b3 4c b4 fc fe 85 a9 6d 86 0a 83 4b ed 2f 
[2024/8/7 9:02:47 371] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 387] 0 31 30 5 66 e9 b3 4c b4 fc fe 85 a9 6d 86 a 83 4b ed 2f 
[2024/8/7 9:02:47 387] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 387] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 403] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:47 403] tuya_hal_bt_send 20
[2024/8/7 9:02:47 403] 01 e0 04 f7 c5 26 74 0e 25 81 6e 81 74 cf 40 f6 f5 af dc 18 
[2024/8/7 9:02:47 419] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 419] 1 e0 4 f7 c5 26 74 e 25 81 6e 81 74 cf 40 f6 f5 af dc 18 
[2024/8/7 9:02:47 435] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 435] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 451] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:47 451] tuya_hal_bt_send 14
[2024/8/7 9:02:47 451] 02 aa 09 84 5e 67 63 d2 ce fa 28 c5 f7 50 
[2024/8/7 9:02:47 451] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 467] 2 aa 9 84 5e 67 63 d2 ce fa 28 c5 f7 50 
[2024/8/7 9:02:47 467] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 467] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 483] [08-07 09:02:44 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:47 499] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:47 499] tuya_hal_bt_send 20
[2024/8/7 9:02:47 499] 00 31 30 05 1d 99 e3 51 96 e2 56 40 d0 dc ca d3 29 b8 83 7c 
[2024/8/7 9:02:47 499] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 515] 0 31 30 5 1d 99 e3 51 96 e2 56 40 d0 dc ca d3 29 b8 83 7c 
[2024/8/7 9:02:47 515] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 531] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 531] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:47 531] tuya_hal_bt_send 20
[2024/8/7 9:02:47 547] 01 f4 78 1c ae 6d d7 10 41 b7 d0 16 22 3e 14 e5 18 7c 52 c3 
[2024/8/7 9:02:47 547] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 547] 1 f4 78 1c ae 6d d7 10 41 b7 d0 16 22 3e 14 e5 18 7c 52 c3 
[2024/8/7 9:02:47 563] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 563] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 579] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:47 579] tuya_hal_bt_send 14
[2024/8/7 9:02:47 579] 02 79 1e 93 31 97 05 8d 65 58 d1 81 f6 5a 
[2024/8/7 9:02:47 595] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 596] 2 79 1e 93 31 97 5 8d 65 58 d1 81 f6 5a 
[2024/8/7 9:02:47 596] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 611] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 611] [08-07 09:02:44 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:47 627] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:47 627] tuya_hal_bt_send 20
[2024/8/7 9:02:47 627] 00 31 30 05 6a 24 a0 80 07 f6 40 57 d4 0b 2c 7d 43 af f9 1e 
[2024/8/7 9:02:47 643] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 643] 0 31 30 5 6a 24 a0 80 7 f6 40 57 d4 b 2c 7d 43 af f9 1e 
[2024/8/7 9:02:47 643] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 659] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 659] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:47 659] tuya_hal_bt_send 20
[2024/8/7 9:02:47 675] 01 3a 96 04 eb 84 23 bd 64 70 f6 bc 5a 44 1f ed db b9 15 96 
[2024/8/7 9:02:47 675] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 675] 1 3a 96 4 eb 84 23 bd 64 70 f6 bc 5a 44 1f ed db b9 15 96 
[2024/8/7 9:02:47 691] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 691] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 707] [08-07 09:02:44 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:47 707] tuya_hal_bt_send 14
[2024/8/7 9:02:47 707] 02 12 7d e2 5b 61 fe f5 23 3b eb 51 bd fe 
[2024/8/7 9:02:47 723] [08-07 09:02:44 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 723] 2 12 7d e2 5b 61 fe f5 23 3b eb 51 bd fe 
[2024/8/7 9:02:47 723] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 739] [08-07 09:02:44 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 739] [08-07 09:02:45 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:47 755] [2024-08-07 09:02:44] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:02:47 755] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:47 755] tuya_hal_bt_send 20
[2024/8/7 9:02:47 770] 00 31 30 05 88 b0 96 0f a7 d7 67 fb e2 13 [2024-08-07 09:02:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:02:47 771] 
[2024/8/7 9:02:47 771] 79 27 c2 f3 c4 66 
[2024/8/7 9:02:47 786] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 787] 0 31 30 5 88 b0 96 f a7 d7 67 fb e2 13 79 27 c2 f3 c4 66 
[2024/8/7 9:02:47 787] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 802] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 802] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:47 818] tuya_hal_bt_send 20
[2024/8/7 9:02:47 818] 01 cd 69 fb 4c b8 83 b5 c4 9f 4a 7b 78 92 5b 14 97 62 36 08 
[2024/8/7 9:02:47 818] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 835] 1 cd 69 fb 4c b8 83 b5 c4 9f 4a 7b 78 92 5b 14 97 62 36 8 
[2024/8/7 9:02:47 835] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 835] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 850] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:47 850] tuya_hal_bt_send 14
[2024/8/7 9:02:47 850] 02 1d cd b4 e8 ab cd 65 dd 1c c5 6f 5c 03 
[2024/8/7 9:02:47 866] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 866] 2 1d cd b4 e8 ab cd 65 dd 1c c5 6f 5c 3 
[2024/8/7 9:02:47 866] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 882] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 882] [08-07 09:02:45 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:47 898] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:47 898] tuya_hal_bt_send 20
[2024/8/7 9:02:47 898] 00 31 30 05 43 82 3e c6 8e 2f c1 9a 0a 65 5a 37 c9 ea 4d d1 
[2024/8/7 9:02:47 916] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 916] 0 31 30 5 43 82 3e c6 8e 2f c1 9a a 65 5a 37 c9 ea 4d d1 
[2024/8/7 9:02:47 931] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 931] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 947] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:47 947] tuya_hal_bt_send 20
[2024/8/7 9:02:47 947] 01 f5 5d e3 ca 1d e0 69 31 07 79 f4 03 70 ad ae 09 af 38 b0 
[2024/8/7 9:02:47 947] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 963] 1 f5 5d e3 ca 1d e0 69 31 7 79 f4 3 70 ad ae 9 af 38 b0 
[2024/8/7 9:02:47 963] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:47 979] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:47 979] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:47 980] tuya_hal_bt_send 14
[2024/8/7 9:02:47 995] 02 c0 75 e8 b6 85 44 db 74 98 3b 76 84 ca 
[2024/8/7 9:02:47 996] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:47 996] 2 c0 75 e8 b6 85 44 db 74 98 3b 76 84 ca 
[2024/8/7 9:02:48 011] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 011] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 011] [08-07 09:02:45 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:48 027] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:48 027] tuya_hal_bt_send 20
[2024/8/7 9:02:48 043] 00 31 30 05 1b e4 e0 c2 bc c7 3f 1f da 38 46 1d 2c 8b 83 6f 
[2024/8/7 9:02:48 043] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 043] 0 31 30 5 1b e4 e0 c2 bc c7 3f 1f da 38 46 1d 2c 8b 83 6f 
[2024/8/7 9:02:48 059] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 059] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 074] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:48 074] tuya_hal_bt_send 20
[2024/8/7 9:02:48 075] 01 c6 d6 55 56 52 f0 0a 72 e2 75 76 67 2e 58 e3 82 77 d3 75 
[2024/8/7 9:02:48 091] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 091] 1 c6 d6 55 56 52 f0 a 72 e2 75 76 67 2e 58 e3 82 77 d3 75 
[2024/8/7 9:02:48 092] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 106] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 107] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:48 107] tuya_hal_bt_send 14
[2024/8/7 9:02:48 122] 02 02 fe 28 52 d2 36 64 77 6f 0e bc a2 ce 
[2024/8/7 9:02:48 122] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 122] 2 2 fe 28 52 d2 36 64 77 6f e bc a2 ce 
[2024/8/7 9:02:48 138] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 138] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 154] [08-07 09:02:45 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:48 154] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:48 154] tuya_hal_bt_send 20
[2024/8/7 9:02:48 170] 00 31 30 05 e4 59 59 21 21 18 40 7c 51 07 19 fc 92 9d 6d 20 
[2024/8/7 9:02:48 170] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 170] 0 31 30 5 e4 59 59 21 21 18 40 7c 51 7 19 fc 92 9d 6d 20 
[2024/8/7 9:02:48 186] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 186] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 202] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:48 202] tuya_hal_bt_send 20
[2024/8/7 9:02:48 202] 01 ef 4c fb 6b 8b 2a ad 73 12 60 ae 07 95 40 05 7b fe b8 b9 
[2024/8/7 9:02:48 218] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 218] 1 ef 4c fb 6b 8b 2a ad 73 12 60 ae 7 95 40 5 7b fe b8 b9 
[2024/8/7 9:02:48 218] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 234] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 234] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:48 250] tuya_hal_bt_send 14
[2024/8/7 9:02:48 250] 02 8d 24 14 48 33 e7 d7 c6 0f ff 45 d5 b5 
[2024/8/7 9:02:48 250] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 250] 2 8d 24 14 48 33 e7 d7 c6 f ff 45 d5 b5 
[2024/8/7 9:02:48 266] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 266] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 282] [08-07 09:02:45 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:48 282] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:48 283] tuya_hal_bt_send 20
[2024/8/7 9:02:48 298] 00 31 30 05 70 ef 83 12 08 c3 0e 59 ca 27 57 dc c4 44 fc a3 
[2024/8/7 9:02:48 298] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 298] 0 31 30 5 70 ef 83 12 8 c3 e 59 ca 27 57 dc c4 44 fc a3 
[2024/8/7 9:02:48 314] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 314] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 330] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:48 330] tuya_hal_bt_send 20
[2024/8/7 9:02:48 330] 01 41 59 42 5e bf d3 32 cf 9e a5 d7 51 64 28 73 d2 3e 0e 95 
[2024/8/7 9:02:48 346] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 346] 1 41 59 42 5e bf d3 32 cf 9e a5 d7 51 64 28 73 d2 3e e 95 
[2024/8/7 9:02:48 362] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 363]  ---
[2024/8/7 9:02:48 363] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 378] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:48 378] tuya_hal_bt_send 14
[2024/8/7 9:02:48 378] 02 a3 90 b8 2e 40 3f 7e 4b b7 8f 19 51 9f 
[2024/8/7 9:02:48 378] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 378] 2 a3 90 b8 2e 40 3f 7e 4b b7 8f 19 51 9f 
[2024/8/7 9:02:48 394] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 394] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 410] [08-07 09:02:45 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:48 410] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:48 426] tuya_hal_bt_send 20
[2024/8/7 9:02:48 426] 00 31 30 05 b4 9f 33 bd e2 41 96 ae 68 6d 0b ad b1 09 51 19 
[2024/8/7 9:02:48 426] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 442] 0 31 30 5 b4 9f 33 bd e2 41 96 ae 68 6d b ad b1 9 51 19 
[2024/8/7 9:02:48 442] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 442] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 458] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:48 458] tuya_hal_bt_send 20
[2024/8/7 9:02:48 474] 01 4b c7 07 d4 f9 98 98 9f fb e6 3b 56 8e 77 23 f4 8f 17 55 
[2024/8/7 9:02:48 475] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 475] 1 4b c7 7 d4 f9 98 98 9f fb e6 3b 56 8e 77 23 f4 8f 17 55 
[2024/8/7 9:02:48 490] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 491] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 506] [08-07 09:02:45 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:48 506] tuya_hal_bt_send 14
[2024/8/7 9:02:48 506] 02 47 2e 01 1e 85 1e f4 2c 22 9f d3 6f cd 
[2024/8/7 9:02:48 506] [08-07 09:02:45 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 522] 2 47 2e 1 1e 85 1e f4 2c 22 9f d3 6f cd 
[2024/8/7 9:02:48 522] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 522] [08-07 09:02:45 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 538] [08-07 09:02:46 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:48 554] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:48 554] tuya_hal_bt_send 20
[2024/8/7 9:02:48 554] 00 31 30 05 37 b3 83 1a f4 1a 48 dc 88 54 8a b9 dc 5c d2 9e 
[2024/8/7 9:02:48 554] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 570] 0 31 30 5 37 b3 83 1a f4 1a 48 dc 88 54 8a b9 dc 5c d2 9e 
[2024/8/7 9:02:48 570] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 586] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 586] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:48 586] tuya_hal_bt_send 20
[2024/8/7 9:02:48 603] 01 95 14 ea 91 60 01 8c 1b 43 3b 6e b7 8b 24 2d 40 de 6d 69 
[2024/8/7 9:02:48 603] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 603] 1 95 14 ea 91 60 1 8c 1b 43 3b 6e b7 8b 24 2d 40 de 6d 69 
[2024/8/7 9:02:48 618] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 618] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 635] [2024-08-07 09:02:45] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 17977[08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:48 635] tuya_hal_bt_send 14
[2024/8/7 9:02:48 651] 02 5f ca 03 38 d3 fa ef ff 56 eb 17 63 06 
[2024/8/7 9:02:48 651] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 651] 2 5f ca 3 38 d3 fa ef ff 56 eb 17 63 6 
[2024/8/7 9:02:48 667] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 667] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 683] [08-07 09:02:46 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:48 683] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:48 683] tuya_hal_bt_send 20
[2024/8/7 9:02:48 699] 00 31 30 05 46 ce c9 3b 69 92 97 71 e6 a2 2b c3 7e 7e e1 9f 
[2024/8/7 9:02:48 699] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 699] 0 31 30 5 46 ce c9 3b 69 92 97 71 e6 a2 2b c3 7e 7e e1 9f 
[2024/8/7 9:02:48 715] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 715] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 731] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:48 731] tuya_hal_bt_send 20
[2024/8/7 9:02:48 731] 01 39 27 0f 87 fc 2c f9 63 64 49 11 77 15 a0 60 be 0b ad 98 
[2024/8/7 9:02:48 747] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 747] 1 39 27 f 87 fc 2c f9 63 64 49 11 77 15 a0 60 be b ad 98 
[2024/8/7 9:02:48 747] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 763] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 763] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:48 779] tuya_hal_bt_send 14
[2024/8/7 9:02:48 779] 02 bc 58 0b da f8 46 6d 79 86 28 ed 45 6e 
[2024/8/7 9:02:48 779] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 779] 2 bc 58 b da f8 46 6d 79 86 28 ed 45 6e 
[2024/8/7 9:02:48 795] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 795] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 811] [08-07 09:02:46 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:48 811] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:48 811] tuya_hal_bt_send 20
[2024/8/7 9:02:48 827] 00 31 30 05 ab fe 47 94 91 df 06 f7 82 31 3b 01 af 1e a0 1c 
[2024/8/7 9:02:48 827] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 843] 0 31 30 5 ab fe 47 94 91 df 6 f7 82 31 3b 1 af 1e a0 1c 
[2024/8/7 9:02:48 843] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 843] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 858] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:48 858] tuya_hal_bt_send 20
[2024/8/7 9:02:48 859] 01 52 96 45 bd fc be 35 2d 3a 09 88 f2 ae 59 f1 b9 7c ba ae 
[2024/8/7 9:02:48 875] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 875] 1 52 96 45 bd fc be 35 2d 3a 9 88 f2 ae 59 f1 b9 7c ba ae 
[2024/8/7 9:02:48 890] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 890] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 906] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:48 907] tuya_hal_bt_send 14
[2024/8/7 9:02:48 907] 02 8a 76 38 a8 21 79 fb 17 7b 40 0a 49 2d 
[2024/8/7 9:02:48 907] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 922] 2 8a 76 38 a8 21 79 fb 17 7b 40 a 49 2d 
[2024/8/7 9:02:48 923] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 923] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:48 938] [08-07 09:02:46 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:48 939] [08-07 09:02:46 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:02:48 954] [08-07 09:02:46 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:02:48 955] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:48 955] tuya_hal_bt_send 20
[2024/8/7 9:02:48 970] 00 31 30 05 d7 fd 5c e9 dd 62 e1 df 13 1e 60 43 bb 80 5f c6 
[2024/8/7 9:02:48 970] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:48 970] 0 31 30 5 d7 fd 5c e9 dd 62 e1 df 13 1e 60 43 bb 80 5f c6 
[2024/8/7 9:02:48 986] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:48 986] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:49 002] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:49 002] tuya_hal_bt_send 20
[2024/8/7 9:02:49 002] 01 a9 e5 42 06 06 a0 d6 17 4f 50 d5 cc dd cd b2 09 14 30 71 
[2024/8/7 9:02:49 018] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:49 018] 1 a9 e5 42 6 6 a0 d6 17 4f 50 d5 cc dd cd b2 9 14 30 71 
[2024/8/7 9:02:49 018] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:49 034] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:49 034] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:49 034] tuya_hal_bt_send 14
[2024/8/7 9:02:49 050] 02 87 d4 50 16 c2 ff e1 5c cc 68 20 11 b3 
[2024/8/7 9:02:49 050] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:49 050] 2 87 d4 50 16 c2 ff e1 5c cc 68 20 11 b3 
[2024/8/7 9:02:49 066] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:49 066] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:49 082] [08-07 09:02:46 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:49 082] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:02:49 082] tuya_hal_bt_send 20
[2024/8/7 9:02:49 099] 00 31 30 05 dc 97 51 3a f9 33 1b 8d d0 fa d0 0c 7c af d3 e1 
[2024/8/7 9:02:49 099] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:49 099] 0 31 30 5 dc 97 51 3a f9 33 1b 8d d0 fa d0 c 7c af d3 e1 
[2024/8/7 9:02:49 115] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:49 115] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:49 132] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:02:49 132] tuya_hal_bt_send 20
[2024/8/7 9:02:49 132] 01 85 d6 10 d1 45 d8 b0 2c 5e 3f d2 51 ba b9 7b 29 cd c4 b2 
[2024/8/7 9:02:49 147] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:49 147] 1 85 d6 10 d1 45 d8 b0 2c 5e 3f d2 51 ba b9 7b 29 cd c4 b2 
[2024/8/7 9:02:49 147] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:49 163]  ---
[2024/8/7 9:02:49 164] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:49 164] [08-07 09:02:46 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:02:49 179] tuya_hal_bt_send 14
[2024/8/7 9:02:49 179] 02 1b 3d 1d ab d8 e1 b5 74 1a 2e 08 6b 83 
[2024/8/7 9:02:49 179] [08-07 09:02:46 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:02:49 179] 2 1b 3d 1d ab d8 e1 b5 74 1a 2e 8 6b 83 
[2024/8/7 9:02:49 195] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:02:49 195] [08-07 09:02:46 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:02:49 211] [2024-08-07 09:02:45] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time40816
[2024/8/7 9:02:49 211] [08-07 09:02:46 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:02:49 227] [08-07 09:02:46 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 9:02:49 227] [08-07 09:02:46 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:49 227] [08-07 09:02:46 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:49 243] [08-07 09:02:46 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:49 243] [08-07 09:02:46 TUYA D][tuya_svc_schema_upgrade.c:223] schema[flvlrc] not updated since activated
[2024/8/7 9:02:49 259] [2024-08-07 09:02:45] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:49 259] [08-07 09:02:46 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:02:49 275] [08-07 09:02:46 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:02:49 275] [08-07 09:02:46 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:02:49 291] [08-07 09:02:46 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:18517
[2024/8/7 9:02:49 291] [08-07 09:02:46 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722992566,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 9:02:49 307] [08-07 09:02:46 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 9:02:49 323] [08-07 09:02:46 TUYA D][app_agent.c:600] send length:80, id:36, sequence_out:48930
[2024/8/7 9:02:49 323] [08-07 09:02:46 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c96f4208f733a0b737eix, dp_rept_chan:3
[2024/8/7 9:02:49 339] [08-07 09:02:46 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:02:49 339] [08-07 09:02:46 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:133.
[2024/8/7 9:02:49 354] [08-07 09:02:46 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:161.
[2024/8/7 9:02:49 354] [08-07 09:02:46 TUYA D][smart_frame.c:2547] final pack:{"133":"3","161":false}
[2024/8/7 9:02:49 370] [08-07 09:02:46 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3","161":false}
[2024/8/7 9:02:49 370] [08-07 09:02:46 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:18518 Q:1 Data:{"dps":{"133":"3","161":false}}
[2024/8/7 9:02:49 371] [08-07 09:02:46 TUYA D][smart_frame.c:2135] sync rslt:0
[2024/8/7 9:02:49 386] [08-07 09:02:46 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:02:49 386] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:02:49 386] Mode(Product):0
[2024/8/7 9:02:49 386] BpuMode:[Online]
[2024/8/7 9:02:49 386] VpssMode:[Online]
[2024/8/7 9:02:49 402] [0.LimitUp_info]:
[2024/8/7 9:02:49 403] LimitUp:[Disable]
[2024/8/7 9:02:49 403] [2680*0]->[3840*0])
[2024/8/7 9:02:49 403] chn	TotalSize	ActiveSize
[2024/8/7 9:02:49 403] 0	5040*2246	2680*2160
[2024/8/7 9:02:49 403] 0	5040*2246	3840*2160
[2024/8/7 9:02:49 403] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:02:49 403] [1.VICU_info]:
[2024/8/7 9:02:49 419] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:02:49 419] 0	25.0	818	0	0	183	linear	8ddb00
[2024/8/7 9:02:49 419] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:02:49 419] en	op_type	m_chn	now
[2024/8/7 9:02:49 419] 0	1	1	1
[2024/8/7 9:02:49 419] [2.VI_info]:
[2024/8/7 9:02:49 434] chn	TotalSize	ActiveSize
[2024/8/7 9:02:49 434] 0	5040*2246	3848*2166
[2024/8/7 9:02:49 434] 1	   0*   0	   0*   0
[2024/8/7 9:02:49 434] [3.MIPI_info]:
[2024/8/7 9:02:49 434] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:02:49 450] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:02:49 450] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:02:49 450] [4.Cut_info]:
[2024/8/7 9:02:49 450] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:02:49 450] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:02:49 466] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:02:49 466] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:02:49 466] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:02:49 466] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:02:49 466] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:02:49 466] [5.IB(isp buffer info)]:
[2024/8/7 9:02:49 482] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:02:49 482] PoolId  Count  Size
[2024/8/7 9:02:49 482] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:49 498] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:49 498] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:49 514] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:49 514] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:49 530] [08-07 09:02:46 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"133":"3","161":false}}, mqtt async dp cb:0
[2024/8/7 9:02:49 546] [08-07 09:02:46 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:133, curr_t:1722992566, rept_cnt:1.
[2024/8/7 9:02:49 546] [08-07 09:02:46 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:133, curr_t:1722992566, rept_cnt:0.
[2024/8/7 9:02:49 562] [08-07 09:02:46 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:133, curr_t:1722992566, rept_cnt:0.
[2024/8/7 9:02:49 562] [08-07 09:02:46 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:161, curr_t:1722992566, rept_cnt:1.
[2024/8/7 9:02:49 578] [08-07 09:02:46 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:161, curr_t:1722992566, rept_cnt:0.
[2024/8/7 9:02:49 578] [08-07 09:02:46 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:161, curr_t:1722992566, rept_cnt:0.
[2024/8/7 9:02:49 594] 
[2024/8/7 9:02:49 595] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:02:49 595] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:02:49 595] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:02:49 610] 0       0         0          1          4       
[2024/8/7 9:02:49 610] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:02:49 626]      --265--            --264--                                               
[2024/8/7 9:02:49 626] Count      Line     Count      Line     
[2024/8/7 9:02:49 626] 636        480      1378       560      
[2024/8/7 9:02:49 642] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:02:49 642] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:02:49 642] 0   3840   2160    H265  0      0        0           378       983038     2        	
[2024/8/7 9:02:49 659] 1   640    360     H265  0      0        0           255       43194      6        	
[2024/8/7 9:02:49 659] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:02:49 674] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:02:49 690] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:02:49 690] 0   Y      378      0       0       15       0        378      378      525       66329         58814    146314   65431    12      
[2024/8/7 9:02:49 706] 1   Y      255      0       2       1        0        255      255      526       2339          1894     38238    3056     9       
[2024/8/7 9:02:49 722] 3   N      0        0       0       1        0        0        0        526       0             0        0        0        0       
[2024/8/7 9:02:49 722] [2024-08-07 09:02:46] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:49 739] [2024-08-07 09:02:46] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 18156[08-07 09:02:48 TUYA D][iot_httpc.c:1161] Post Data: {"data":"255","t":1722992568}
[2024/8/7 9:02:49 755] [08-07 09:02:48 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6c96f4208f733a0b737eix&et=1&t=1722992568&sign=1b4944ed46fee5b427b4fe857d82a8a6
[2024/8/7 9:02:49 771] [08-07 09:02:48 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:49 771] [08-07 09:02:48 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:49 787] [08-07 09:02:48 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:49 787] [08-07 09:02:48 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:49 803] [08-07 09:02:48 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:49 803] [08-07 09:02:48 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:49 819] [08-07 09:02:48 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:49 819] [08-07 09:02:48 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:49 819] [08-07 09:02:48 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:49 835] [08-07 09:02:48 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:49 835] [08-07 09:02:48 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:49 851] [08-07 09:02:48 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:49 866] [08-07 09:02:48 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:49 866] [08-07 09:02:48 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722992568,"success":true}
[2024/8/7 9:02:49 882] [08-07 09:02:48 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:49 882] [08-07 09:02:48 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:49 882] [08-07 09:02:48 TUYA D][tuya_devos_entry.c:406] put rst log finish
[2024/8/7 9:02:49 898] [08-07 09:02:48 TUYA D][iot_httpc.c:1161] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1722992568}
[2024/8/7 9:02:49 915] [08-07 09:02:48 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6c96f4208f733a0b737eix&et=1&t=1722992568&v=2.0&sign=9b228d87ffa18819959f0f4c670eca2b
[2024/8/7 9:02:49 931] [08-07 09:02:48 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:49 932] [08-07 09:02:48 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:49 946] [08-07 09:02:48 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:49 946] [08-07 09:02:48 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:49 946] [08-07 09:02:48 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:49 962] [08-07 09:02:48 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:49 979] [08-07 09:02:48 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:49 980] [08-07 09:02:48 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:49 980] [08-07 09:02:48 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:49 995] [08-07 09:02:48 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:49 995] [08-07 09:02:48 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:50 011] [08-07 09:02:48 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:50 011] [08-07 09:02:48 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:50 043] [08-07 09:02:48 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722992568,"validTime":1800}},"t":1722992568,"success":true}
[2024/8/7 9:02:50 043] [08-07 09:02:48 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:50 043] [08-07 09:02:48 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:50 059] [08-07 09:02:48 TUYA D][iot_httpc.c:3388] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1722992568}, ret:0.
[2024/8/7 9:02:50 059] [08-07 09:02:48 TUYA D][tuya_devos_entry.c:479] timezone:+08:00
[2024/8/7 9:02:50 075] [08-07 09:02:48 TUYA D][tuya_devos_entry.c:500] summer_time_zone:[]
[2024/8/7 9:02:50 075] [08-07 09:02:48 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:02:50 091] [08-07 09:02:48 TUYA D][simplekv.c:1251] find key:12 gw_ai
[2024/8/7 9:02:50 091] [08-07 09:02:48 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544
[2024/8/7 9:02:50 091] [08-07 09:02:48 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:02:50 107] [08-07 09:02:48 TUYA D][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722992568,"validTime":1800}}.
[2024/8/7 9:02:50 123] [08-07 09:02:48 TUYA D][tuya_devos_utils.c:94] reset dp rate rule finish.
[2024/8/7 9:02:50 123] [08-07 09:02:48 TUYA D][iot_httpc.c:1161] Post Data: {"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722992568}
[2024/8/7 9:02:50 139] [08-07 09:02:48 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.ack&devId=6c96f4208f733a0b737eix&et=1&t=1722992568&v=2.0&sign=02db4c39e383fe8ff71ae633cb81edbb
[2024/8/7 9:02:50 155] [08-07 09:02:48 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:50 155] [08-07 09:02:48 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:50 171] [08-07 09:02:48 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:50 171] [08-07 09:02:48 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:50 187] [08-07 09:02:48 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:50 187] [08-07 09:02:48 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:50 203] [08-07 09:02:48 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:50 203] [08-07 09:02:48 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:50 219] [08-07 09:02:48 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:50 219] [08-07 09:02:48 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:50 235] [08-07 09:02:48 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:50 235] [08-07 09:02:48 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:50 251] [08-07 09:02:48 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:50 251] [08-07 09:02:49 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992569,"success":true}
[2024/8/7 9:02:50 267] [08-07 09:02:49 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:50 267] [08-07 09:02:49 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:50 283] [08-07 09:02:49 TUYA D][iot_httpc.c:2411] dynamic cfg post data:{"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722992568}, ret:0.
[2024/8/7 9:02:50 299] [2024-08-07 09:02:48] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 18626[2024-08-07 09:02:49] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:50 299] [2024-08-07 09:02:49] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time44838
[2024/8/7 9:02:50 314] [08-07 09:02:52 TUYA D][tuya_upnp_module_mg.c:1432] upnpDiscover failed
[2024/8/7 9:02:50 314] [08-07 09:02:52 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:02:50 986] while(lib_ble_start) before
[2024/8/7 9:02:51 003] GAP procedure initiated: terminate connection; conn_handle=1 hci_reason=19
[2024/8/7 9:02:51 003] [2024-08-07 09:02:52] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:51 003] ble_slave_gap_event->type=14
[2024/8/7 9:02:51 018] subscribe event; conn_handle=1 attr_handle=23 reason=2 prevn=1 curn=0 previ=0 curi=0
[2024/8/7 9:02:51 018] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:02:51 018] ble_slave_gap_event->type=1
[2024/8/7 9:02:51 034] disconnect; reason=534 
[2024/8/7 9:02:51 034] [08-07 09:02:53 TUYA D][iot_httpc.c:1161] Post Data: {"subId":null,"t":1722992573}
[2024/8/7 9:02:51 050] [08-07 09:02:53 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upgrade.silent.get&devId=6c96f4208f733a0b737eix&et=1&t=1722992573&v=4.4&sign=e5aad19cfac0a9ada472fea85a551bdc
[2024/8/7 9:02:51 066] [08-07 09:02:53 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:51 066] [08-07 09:02:53 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:51 082] [08-07 09:02:53 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:51 082] [08-07 09:02:53 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:51 082] [08-07 09:02:53 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:51 098] [08-07 09:02:53 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:51 115] [08-07 09:02:53 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:51 115] [08-07 09:02:53 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:51 115] [08-07 09:02:53 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:51 130] [08-07 09:02:53 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:51 130] [08-07 09:02:53 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:51 147] [08-07 09:02:53 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:51 163] [08-07 09:02:53 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:51 179] [08-07 09:02:53 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722992573,"success":true}
[2024/8/7 9:02:51 179] [08-07 09:02:53 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:51 195] [08-07 09:02:53 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:51 195] [08-07 09:02:53 TUYA E][tuya_svc_upgrade.c:436] result null
[2024/8/7 9:02:51 195] [08-07 09:02:53 TUYA D][tuya_svc_upgrade.c:511] silent get firmware fail
[2024/8/7 9:02:51 212] [08-07 09:02:53 TUYA D][tuya_svc_upgrade.c:205] next detect timer: 21600s
[2024/8/7 9:02:51 212] [08-07 09:02:53 TUYA N][tuya_svc_timer_task.c:796] Update Timer from cloud
[2024/8/7 9:02:51 227] [08-07 09:02:53 TUYA D][iot_httpc.c:1161] Post Data: {"devId":"6c96f4208f733a0b737eix","lastFetchTime":"0","t":1722992573}
[2024/8/7 9:02:51 243] [08-07 09:02:53 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.timer.count&devId=6c96f4208f733a0b737eix&et=1&t=1722992573&v=4.2&sign=9f290f8bbc0514f188d000f378631aba
[2024/8/7 9:02:51 243] [08-07 09:02:53 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:02:51 258] [08-07 09:02:53 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:02:51 259] 
[2024/8/7 9:02:51 274] [08-07 09:02:53 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:02:51 275] 
[2024/8/7 9:02:51 275] [08-07 09:02:53 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:02:51 276] [08-07 09:02:53 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:02:51 293] [08-07 09:02:53 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:02:51 294] [08-07 09:02:53 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:02:51 306] [08-07 09:02:53 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:02:51 306] [08-07 09:02:53 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:02:51 322] [08-07 09:02:53 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:02:51 322] [08-07 09:02:53 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:02:51 338] [08-07 09:02:53 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:02:51 338] [08-07 09:02:53 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:02:51 354] [08-07 09:02:53 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"code":"200","count":0,"devId":"6c96f4208f733a0b737eix","lastFetchTime":0},"t":1722992573,"success":true}
[2024/8/7 9:02:51 370] [08-07 09:02:53 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:51 370] [08-07 09:02:53 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:51 386] [08-07 09:02:53 TUYA D][tuya_svc_timer_task.c:451] time eq skip:0
[2024/8/7 9:02:51 578] [08-07 09:02:54 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992574 28800
[2024/8/7 9:02:51 594] [08-07 09:02:54 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992574 28800
[2024/8/7 9:02:53 082] [2024-08-07 09:02:53] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time48861
[2024/8/7 9:02:53 082] <====== ble_gap_terminate(ble_conn_handle,19);
[2024/8/7 9:02:53 098] <====== ble_smart_cfg_task end step 0
[2024/8/7 9:02:53 099] [08-07 09:02:55 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 9:02:53 450] [atbm_log]:atbm_ioctl_ble_stop
[2024/8/7 9:02:53 467] [atbm_log]:ioctl_release(c2c83700)(c1e148c0)
[2024/8/7 9:02:56 554] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:02:56 570] Mode(Product):0
[2024/8/7 9:02:56 570] BpuMode:[Online]
[2024/8/7 9:02:56 570] VpssMode:[Online]
[2024/8/7 9:02:56 570] [0.LimitUp_info]:
[2024/8/7 9:02:56 570] LimitUp:[Disable]
[2024/8/7 9:02:56 570] [2680*0]->[3840*0])
[2024/8/7 9:02:56 570] chn	TotalSize	ActiveSize
[2024/8/7 9:02:56 570] 0	5034*2246	2680*2160
[2024/8/7 9:02:56 586] 0	5046*2246	3840*2160
[2024/8/7 9:02:56 586] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:02:56 586] [1.VICU_info]:
[2024/8/7 9:02:56 586] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:02:56 586] 0	25.0	1124	0	0	183	linear	8ddb00
[2024/8/7 9:02:56 586] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:02:56 602] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:02:56 603] en	op_type	m_chn	now
[2024/8/7 9:02:56 603] 0	1	1	1
[2024/8/7 9:02:56 603] [2.VI_info]:
[2024/8/7 9:02:56 603] chn	TotalSize	ActiveSize
[2024/8/7 9:02:56 603] 0	5040*2246	3848*2166
[2024/8/7 9:02:56 603] 1	   0*   0	   0*   0
[2024/8/7 9:02:56 603] [3.MIPI_info]:
[2024/8/7 9:02:56 618] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:02:56 618] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:02:56 618] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:02:56 618] [4.Cut_info]:
[2024/8/7 9:02:56 618] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:02:56 634] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:02:56 634] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:02:56 634] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:02:56 634] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:02:56 634] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:02:56 650] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:02:56 650] [5.IB(isp buffer info)]:
[2024/8/7 9:02:56 650] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:02:56 650] PoolId  Count  Size
[2024/8/7 9:02:56 666] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:56 666] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:56 682] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:56 683] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:56 683] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:02:56 698] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:02:56 698] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:02:56 698] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:02:56 714] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:02:56 714] 0       0         0          0          4       
[2024/8/7 9:02:56 714] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:02:56 730]      --265--            --264--                                               
[2024/8/7 9:02:56 730] Count      Line     Count      Line     
[2024/8/7 9:02:56 730] 899        437      1951       560      
[2024/8/7 9:02:56 746] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:02:56 746] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:02:56 762] 0   3840   2160    H265  0      0        0           529       869107     113933   	
[2024/8/7 9:02:56 762] 1   640    360     H265  0      0        0           368       43198      2        	
[2024/8/7 9:02:56 778] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:02:56 778] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:02:56 794] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:02:56 794] 0   Y      529      0       0       14       1        528      528      738       59086         58814    146314   65090    12      
[2024/8/7 9:02:56 810] 1   Y      368      0       2       1        0        368      368      739       3252          1884     38238    2806     9       
[2024/8/7 9:02:56 826] 3   N      0        0       0       1        0        0        0        739       0             0        0        0        0       
[2024/8/7 9:02:58 329] [2024-08-07 09:02:55] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:02:58 329] exit ble process
[2024/8/7 9:02:58 346] ble_hs_hci_cmd_reset
[2024/8/7 9:02:58 346] cli_free before
[2024/8/7 9:02:58 346] nimble_port_atbmos_free before
[2024/8/7 9:02:58 346] nimble_port_release before
[2024/8/7 9:02:58 346] ble_gap_free before
[2024/8/7 9:02:58 346] ble_hs_hci_free before
[2024/8/7 9:02:58 346] ble_hs_free before
[2024/8/7 9:02:58 346] ble_hs_free after
[2024/8/7 9:02:58 362] nimble_release after
[2024/8/7 9:02:58 362] ble_smart_cfg_exit before
[2024/8/7 9:02:58 362] ble_smart_cfg_exit after
[2024/8/7 9:02:58 362] atbm_stopThread after
[2024/8/7 9:02:58 378] [2024-08-07 09:02:55] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:02:58 379] [2024-08-07 09:02:55] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:02:58 394] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=24.000 ms
[2024/8/7 9:02:58 394] [2024-08-07 09:02:55] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:02:58 410] [2024-08-07 09:02:57] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time52838
[2024/8/7 9:02:58 410] [2024-08-07 09:02:58] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:58 426] [2024-08-07 09:02:58] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:02:58 442] [08-07 09:03:00 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"devId":"6c96f4208f733a0b737eix","gwId":"6c96f4208f733a0b737eix"},"protocol":11,"s":1667079,"t":1722992580}
[2024/8/7 9:02:58 442] [08-07 09:03:00 TUYA D][mqtt_client.c:916] disconnect mqtt
[2024/8/7 9:02:58 442] [08-07 09:03:00 TUYA E][app_agent.c:1479] close socket,errno:-100 errno:0
[2024/8/7 9:02:58 458] [08-07 09:03:00 TUYA D][app_agent.c:213] set socket fault 36
[2024/8/7 9:02:58 458] [08-07 09:03:00 TUYA D][app_agent.c:274] i:0,time:1722992580,c_time:1722992574,fault:1
[2024/8/7 9:02:58 474] [08-07 09:03:00 TUYA D][app_agent.c:163] close socket 36
[2024/8/7 9:02:58 842] [08-07 09:03:01 TUYA D][gw_mqc_cb.c:60] unactive
[2024/8/7 9:02:58 842] [08-07 09:03:01 TUYA E][mqtt_client.c:1652] mq_recv err:-30848 len:0
[2024/8/7 9:02:58 858] [08-07 09:03:01 TUYA D][tuya_devos_reset.c:418] unactive Reset
[2024/8/7 9:02:58 858] [08-07 09:03:01 TUYA D][tuya_devos_reset.c:261] gw reset called. tp:1 stat:1
[2024/8/7 9:02:58 874] __IPC_APP_Get_Net_Status_cb line(183) -------------------------- stat(0)==STAT_LOW_POWER 
[2024/8/7 9:02:58 874] [08-07 09:03:01 TUYA D][tuya_devos_reset.c:85] <__wf_reset> nc_tp:2, rst_tp:1, wifi_start_mode:0
[2024/8/7 9:02:58 890] [08-07 09:03:01 TUYA D][tuya_devos_reset.c:325] <__gw_reset> tuya_ble_clear_mesh
[2024/8/7 9:02:58 890] [08-07 09:03:01 TUYA D][tuya_ble_api.c:1050] start to clr appkey.
[2024/8/7 9:02:58 905] [08-07 09:03:01 TUYA D][simplekv.c:1348] delete key:ble_app_key isFuzzy:0
[2024/8/7 9:02:58 906] [08-07 09:03:01 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:02:58 906] [08-07 09:03:01 TUYA D][simplekv.c:1386] delete key find 4
[2024/8/7 9:02:58 921] [08-07 09:03:01 TUYA D][simplekv.c:1424] Delete key:ble_app_key 4 success
[2024/8/7 9:02:58 921] [08-07 09:03:01 TUYA D][simplekv.c:203] update crc 1572523912
[2024/8/7 9:02:58 921] [08-07 09:03:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:58 938] [08-07 09:03:01 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:02:58 938] [08-07 09:03:01 TUYA D][tuya_ble_api.c:1058] start to clr network_key.
[2024/8/7 9:02:58 954] [08-07 09:03:01 TUYA D][simplekv.c:1348] delete key:ble_network_key isFuzzy:0
[2024/8/7 9:02:58 954] [08-07 09:03:01 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:02:58 954] [08-07 09:03:01 TUYA D][simplekv.c:1386] delete key find 13
[2024/8/7 9:02:58 970] [08-07 09:03:01 TUYA D][simplekv.c:1424] Delete key:ble_network_key 13 success
[2024/8/7 9:02:58 970] [08-07 09:03:01 TUYA D][simplekv.c:203] update crc 537967126
[2024/8/7 9:02:58 986] [08-07 09:03:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:58 986] [08-07 09:03:01 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:02:58 986] [08-07 09:03:01 TUYA D][tuya_ble_api.c:1035] start to clr beaconkey.
[2024/8/7 9:02:59 002] [08-07 09:03:01 TUYA D][simplekv.c:1348] delete key:ble_beaconkey isFuzzy:0
[2024/8/7 9:02:59 002] [08-07 09:03:01 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:02:59 002] [08-07 09:03:01 TUYA D][simplekv.c:1386] delete key find 14
[2024/8/7 9:02:59 018] [08-07 09:03:01 TUYA D][simplekv.c:1424] Delete key:ble_beaconkey 14 success
[2024/8/7 9:02:59 019] [08-07 09:03:01 TUYA D][simplekv.c:203] update crc 2126071580
[2024/8/7 9:02:59 034] [08-07 09:03:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:59 034] [08-07 09:03:01 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:02:59 050] [08-07 09:03:01 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":1,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:02:59 050] [08-07 09:03:01 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:02:59 066] [08-07 09:03:01 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:02:59 066] [08-07 09:03:01 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:176
[2024/8/7 9:02:59 066] [08-07 09:03:01 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:02:59 082] [08-07 09:03:01 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:02:59 082] [08-07 09:03:01 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:02:59 098] [08-07 09:03:01 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:02:59 098] [08-07 09:03:01 TUYA D][simplekv.c:203] update crc 2581898597
[2024/8/7 9:02:59 098] [08-07 09:03:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:59 114] [08-07 09:03:01 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:59 114] [08-07 09:03:01 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:02:59 114] [08-07 09:03:01 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:02:59 131] [08-07 09:03:01 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[2024/8/7 9:02:59 131] [08-07 09:03:01 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[2024/8/7 9:02:59 146] [08-07 09:03:01 TUYA D][tuya_svc_timer_task.c:107] reset. write_disk:1
[2024/8/7 9:02:59 146] [08-07 09:03:01 TUYA D][tuya_svc_timer_task.c:310] max len:128
[2024/8/7 9:02:59 146] [08-07 09:03:01 TUYA D][tuya_svc_timer_task.c:378] offset:27
[2024/8/7 9:02:59 162] [08-07 09:03:01 TUYA D][tuya_svc_timer_task.c:397] save TIMER:{"lastFetchTime":0,"cnt":0}
[2024/8/7 9:02:59 162] [08-07 09:03:01 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:02:59 178] [08-07 09:03:01 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:02:59 178] [08-07 09:03:01 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:02:59 178] [08-07 09:03:01 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:02:59 194] [08-07 09:03:01 TUYA D][simplekv.c:374] write key:timer_arr And Value Len:32
[2024/8/7 9:02:59 194] [08-07 09:03:01 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 32
[2024/8/7 9:02:59 210] [08-07 09:03:01 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:02:59 210] [08-07 09:03:01 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:02:59 210] [08-07 09:03:01 TUYA D][simplekv.c:203] update crc 1732551779
[2024/8/7 9:02:59 226] [08-07 09:03:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:59 226] [08-07 09:03:01 TUYA D][simplekv.c:520[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:02:59 226] ] write success
[2024/8/7 9:02:59 242] [08-07 09:03:01 TUYA D][simplekv.c:1348] delete key:last_reset_info isFuzzy:0
[2024/8/7 9:02:59 242] [08-07 09:03:01 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:02:59 258] [08-07 09:03:01 TUYA D][simplekv.c:1395] key:la[atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:02:59 258] st_reset_info no[atbm_log]:aggtx stop queue
[2024/8/7 9:02:59 258] t find
[2024/8/7 9:02:59 258] [08-07 09:03:01[atbm_log]:add to pending(0)(20)
[2024/8/7 9:02:59 274]  TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:02:59 274] [08-07 09:03:01 TUYA D][simplekv.c[atbm_log]:AMPDU[eth2]:action[2],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:59 290] :1211] read key:p2p_auth_info is[atbm_log]:activated addBA response timer on tid 6
[2024/8/7 9:02:59 290] Fuzzy:0 skipCnt:0
[2024/8/7 9:02:59 290] [08-07 09:03[atbm_log]:ignore pending[5][20]
[2024/8/7 9:02:59 290] :01 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:02:59 306] [08-07 09:03:01 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:02:59 306] [08-07 09:03:01 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:02:59 322] [08-07 09:03:01 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 16
[2024/8/7 9:02:59 322] [08-07 09:03:01 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:02:59 322] [08-07 09:03:01 TUYA D][simplekv.c:474[atbm_log]:aggtx wake queue
[2024/8/7 9:02:59 338] ] reuse availabl[atbm_log]:not assoc 
[2024/8/7 9:02:59 338] e space 30176
[2024/8/7 9:02:59 338] [08-07 09:03:01 TUYA D][[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:02:59 338] simplekv.c:203] update crc 3554176274
[2024/8/7 9:02:59 354] [08-07 09:03:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:59 369] [08-07 09:03:01 TUYA D][simplekv.c:520] writ[atbm_log]:AMPDU[eth2]:action[3],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:59 369] e success
[2024/8/7 9:02:59 370] [08-07 09:03:01 TUYA[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:02:59 385]  D][simplekv.c:1211] read key:p2[atbm_log]:AMPDU[eth2]:action[1],tid[0],ssn[0],buff_size[0],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:59 385] p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:02:59 386] [08-07 09:03:01 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:02:59 402] [08-07[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 5
[2024/8/7 9:02:59 402]  09:03:01 TUYA D[atbm_log]:AMPDU[eth2]:action[1],tid[5],ssn[0],buff_size[0],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:59 417] ][simplekv.c:1280] key:p2p_pwd find value.Len:16[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:02:59 434] [08-07 09:03:01 TUYA D][simplekv.c:37[atbm_log]:AMPDU[eth2]:action[3],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:59 434] 4] write key:p2p_pwd And Value L[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:02:59 434] en:16
[2024/8/7 9:02:59 450] [08-07 09:03:01 TUYA D][[atbm_log]:AMPDU[eth2]:action[1],tid[6],ssn[0],buff_size[0],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:59 450] simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:02:59 466] [08-07 09:03:01 T[atbm_log]:eth2: deauthenticating from a4:a9:30:ce:5e:66 by local choice (reason=3)
[2024/8/7 9:02:59 466] UYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:02:59 466] [08-07 09:03:01 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:02:59 482] [08-07 09:03:01 TUYA D][simplekv.c:203] update crc 802794983
[2024/8/7 9:02:59 482] [08-07 09:03:01 TUYA N][mqtt_client.c:1703] mqtt close
[2024/8/7 9:02:59 482] [08-07 09:03:01 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:02:59 498] [08-07 09:03:01 TUYA N][mqtt_client.c:839] close mqtt -->>
[2024/8/7 9:02:59 498] [08-07 09:03:01 TUYA D][mqtt_client.c:851] shutdown fd ena[atbm_log]:[TX]:[0]:deatuhen[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:59 498] bled
[2024/8/7 9:02:59 514] [08-07 09:03:01 T[atbm_log]:[eth2 Rx]:da:[ff:ff:ff:ff:ff:ff] sa:[92:88:d9:e0:36:6a] bssid:[a4:a9:30:ce:5e:66],PTK[c269ca00],FLAGS[1080046b],skb->len[76]
[2024/8/7 9:02:59 530] UYA D][simplekv.[atbm_log]:[RX] MIC failure. ENCRYPTION [0],da:[ff:ff:ff:ff:ff:ff] sa:[92:88:d9:e0:36:6a] bssid:[a4:a9:30:ce:5e:66]
[2024/8/7 9:02:59 530] c:359] write head to normal file[atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:02:59 530]  success
[2024/8/7 9:02:59 546] [08-07 09:03:01 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:59 546] [08-07 09:03:01 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:02:59 546] [08-07 09:03:01 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:02:59 562] [08-07 09:03:01 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:02:59 562] [08-07 09:03:01 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:02:59 578] [08-07 09:03:01 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:02:59 578] [08-07 09:03:01 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:02:59 578] [08-07 09:03:01 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:02:59 594] [08-07 09:03:01 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:02:59 594] [08-07 09:03:01 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:02:59 594] [08-07 09:03:01 TUYA D][sim[atbm_log]:[STA]:unjoin ++
[2024/8/7 9:02:59 610] plekv.c:203] update crc 18143743[atbm_log]:[STA]:unjoin --
[2024/8/7 9:02:59 610] 49
[2024/8/7 9:02:59 610] [08-07 09:03:01 TUYA N][mqtt_client.c:886] close mqtt <<--
[2024/8/7 9:02:59 626] [08-07 09:03:01 TUYA D][mqtt_client.c:1720] mqtt fail_cnt:1, sleeptime:3650 ms
[2024/8/7 9:02:59 627] [08-07 09:03:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:02:59 627] [08-07 09:03:01 TUYA D][simplekv.c:520] write success
[2024/8/7 9:02:59 642] rm: can't remove '/mnt/mtd/Config/localtime': Device or resource busy
[2024/8/7 9:02:59 642] rm: can't remove '/mnt/mtd/Config/resolv.conf': Device or resource busy
[2024/8/7 9:02:59 642] rm: can't remove '/mnt/mtd/Config': Directory not empty
[2024/8/7 9:02:59 658] [atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:02:59 689] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:03:01 018] IPC_APP_Reset_System_CB line(143) -------------------------- 
[2024/8/7 9:03:01 034] [2024-08-07 09:03:00] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:03:00] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:03:01 034] set basic_indicator_onoff:0 
[2024/8/7 9:03:01 034] [2024-08-07 09:03:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:01 050] [2024-08-07 09:03:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:01 066] [2024-08-07 09:03:00] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:03:00] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:03:01 082] [2024-08-07 09:03:01] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:03:01] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:03:01 098] [2024-08-07 09:03:01] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:03:01] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:03:01 114] [2024-08-07 09:03:01] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:03:01 130] [2024-08-07 09:03:01] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:03:01] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:03:01 146] [2024-08-07 09:03:01] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:03:01] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:03:01 161] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:2
[2024/8/7 9:03:01 177] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(150): cmd=[killall wpa_supplicant udhcpc;ifconfig eth2 down;ifconfig eth0 down;]
[2024/8/7 9:03:01 178]  ---
[2024/8/7 9:03:01 178] curr event:13 
[2024/8/7 9:03:01 178] IPC_APP_Notify_LED_Sound_Status_CB line(583) -------------------------- IPC_RESET_SUCCESS(13)
[2024/8/7 9:03:01 194] [2024-08-07 09:03:01] tuya_ipc_system_control_demo.c(585) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(RESET, 0, 1, 0, 1))
[2024/8/7 9:03:01 209] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(155):  ---
[2024/8/7 9:03:01 209] [2024-08-07 09:03:01] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/Reset_english.pcm]
[2024/8/7 9:03:01 226] [2024-08-07 09:03:01] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:03:01 226] [2024-08-07 09:03:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:03:01 242] [2024-08-07 09:03:01] xm_main.c(2440) <XMSDK_SystemRebootTY>: XMSDK_MotorGetPostion(3110,0) suc
[2024/8/7 9:03:01 242] [2024-08-07 09:03:01] xm_main.c(2064) <XM_SaveLocalPtzPosition>: Save PTZ xPosition 3110 failed
[2024/8/7 9:03:01 258] [2024-08-07 09:03:01] xm_main.c(2445) <XMSDK_SystemRebootTY>: XM_SaveLocalPtzPosition(3110,0) failed,ret=[-1]
[2024/8/7 9:03:01 258] XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:03:01 274] [2024-08-07 09:03:01] xm_main.c(2454) <XMSDK_SystemRebootTY>: XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:03:01 290] [2024-08-07 09:03:01] ==> XMSDK_SystemReboot(198)[INFO]: Sys XMSDK_SystemReboot Reboot
[2024/8/7 9:03:01 290] [2024-08-07 09:03:01] ==> XMSDK_SystemReboot(199)[INFO]: Sys Will Reboot
[2024/8/7 9:03:01 306] [2024-08-07 09:03:01] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:03:01] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:03:01 306] set basic_indicator_onoff:0 
[2024/8/7 9:03:01 322] [2024-08-07 09:03:01] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:01 338] [2024-08-07 09:03:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:01 338] [2024-08-07 09:03:01] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time56823
[2024/8/7 9:03:01 354] [08-07 09:03:03 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 9:03:01 354] [08-07 09:03:03 TUYA D][tuya_ble_api.c:1426] cloud disconnected, start adv!
[2024/8/7 9:03:01 354] [08-07 09:03:03 TUYA I][bt_ext_porting.c:628] [TUYA-BTUART]start_adv
[2024/8/7 9:03:01 370] --- tracepoint bt_ext_porting.c,tuya_ext_bt_start_adv(629): start_adv ---
[2024/8/7 9:03:01 370] [08-07 09:03:03 TUYA D][tuya_ble_api.c:1376] nw stat change:2->0, rpt to app.
[2024/8/7 9:03:01 386] [08-07 09:03:03 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:03:01 690] [08-07 09:03:04 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722992584 28800
[2024/8/7 9:03:01 706] [08-07 09:03:04 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722992584 28800
[2024/8/7 9:03:01 946] g_AudioTipsList.size() enable: 0[2024-08-07 09:03:03] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:03:03] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [MotionDetect] pNumber[SirenSwitch]!
[2024/8/7 9:03:01 946] [08-07 09:03:04 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:03:04 953] 
[2024/8/7 9:03:04 954] xmsfc_shutdown 2 2 
[2024/8/7 9:03:04 954] Restarting system.
[2024/8/7 9:03:05 002] 
[2024/8/7 9:03:05 018] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 9:03:05 018] CPU: XM550V200WX2
[2024/8/7 9:03:05 018] DRAM:  128 MiB
[2024/8/7 9:03:05 130] MMC:   arasan: 0
[2024/8/7 9:03:05 178] In:    serial
[2024/8/7 9:03:05 194] Out:   serial
[2024/8/7 9:03:05 194] Err:   serial
[2024/8/7 9:03:05 401] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 9:03:05 401] Press Ctrl+C to stop autoboot
[2024/8/7 9:03:05 817] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 9:03:05 817] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 9:03:05 833]    Image Name:   Linux-3.10.103+
[2024/8/7 9:03:05 833]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 9:03:05 833]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 9:03:05 833]    Load Address: 80008000
[2024/8/7 9:03:05 833]    Entry Point:  80008000
[2024/8/7 9:03:05 850]    XIP Kernel Image ... OK
[2024/8/7 9:03:05 850] Starting kernel ...
[2024/8/7 9:03:06 730] Uncompressing Linux... done, booting the kernel.
[2024/8/7 9:03:06 858] Booting Linux on physical CPU 0x0
[2024/8/7 9:03:06 874] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 9:03:06 874] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 9:03:06 890] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 9:03:06 890] Machine: xm530v200
[2024/8/7 9:03:06 890] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 9:03:06 906] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 9:03:06 906] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 9:03:06 922] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 9:03:06 922] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 9:03:06 922] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 9:03:06 937] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 9:03:06 937] Memory: 52MB = 52MB total
[2024/8/7 9:03:06 938] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 9:03:06 938] Virtual kernel memory layout:
[2024/8/7 9:03:06 953]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 9:03:06 953]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 9:03:06 953]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 9:03:06 969]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 9:03:06 969]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 9:03:06 969]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 9:03:06 969]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 9:03:06 985]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 9:03:06 985]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 9:03:06 985] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 9:03:06 985] Hierarchical RCU implementation.
[2024/8/7 9:03:07 002] NR_IRQS:128
[2024/8/7 9:03:07 002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 9:03:07 002] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 9:03:07 002] pid_max: default: 32768 minimum: 301
[2024/8/7 9:03:07 018] Mount-cache hash table entries: 512
[2024/8/7 9:03:07 018] CPU: Testing write buffer coherency: ok
[2024/8/7 9:03:07 018] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 9:03:07 018] L310 cache controller enabled
[2024/8/7 9:03:07 034] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 9:03:07 034] CPU1: Booted secondary processor
[2024/8/7 9:03:07 034] Brought up 2 CPUs
[2024/8/7 9:03:07 034] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 9:03:07 050] CPU: All CPU(s) started in SVC mode.
[2024/8/7 9:03:07 050] NET: Registered protocol family 16
[2024/8/7 9:03:07 050] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 9:03:07 050] Serial: AMBA PL011 UART driver
[2024/8/7 9:03:07 066] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 9:03:07 066] console [ttyAMA0] enabled
[2024/8/7 9:03:07 066] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 9:03:07 082] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 9:03:07 098] bio: create slab <bio-0> at 0
[2024/8/7 9:03:07 098] usbcore: registered new interface driver usbfs
[2024/8/7 9:03:07 114] usbcore: registered new interface driver hub
[2024/8/7 9:03:07 114] usbcore: registered new device driver usb
[2024/8/7 9:03:07 114] Switching to clocksource arm_global_timer
[2024/8/7 9:03:07 130] NET: Registered protocol family 2
[2024/8/7 9:03:07 130] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:03:07 130] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:03:07 146] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 9:03:07 146] TCP: reno registered
[2024/8/7 9:03:07 146] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:03:07 146] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:03:07 146] NET: Registered protocol family 1
[2024/8/7 9:03:07 162] RPC: Registered named UNIX socket transport module.
[2024/8/7 9:03:07 162] RPC: Registered udp transport module.
[2024/8/7 9:03:07 162] RPC: Registered tcp transport module.
[2024/8/7 9:03:07 178] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 9:03:07 194] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 9:03:07 194] NFS: Registering the id_resolver key type
[2024/8/7 9:03:07 194] Key type id_resolver registered
[2024/8/7 9:03:07 194] Key type id_legacy registered
[2024/8/7 9:03:07 210] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 9:03:07 210] fuse init (API version 7.22)
[2024/8/7 9:03:07 210] msgmni has been set to 95
[2024/8/7 9:03:07 226] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 9:03:07 226] io scheduler noop registered
[2024/8/7 9:03:07 226] io scheduler deadline registered (default)
[2024/8/7 9:03:07 226] io scheduler cfq registered
[2024/8/7 9:03:07 242] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 9:03:07 242] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 9:03:07 258] uart-pl011 uart:0: no DMA platform data
[2024/8/7 9:03:07 258] uart-pl011 uart:1: no DMA platform data
[2024/8/7 9:03:07 258] uart-pl011 uart:2: no DMA platform data
[2024/8/7 9:03:07 273] brd: module loaded
[2024/8/7 9:03:07 273] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 9:03:07 289] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:03:07 289] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 9:03:07 289] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 9:03:07 306] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 9:03:07 306] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 9:03:07 306] 0x000000300000-0x000000730000 : "user"
[2024/8/7 9:03:07 321] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 9:03:07 321] PPP generic driver version 2.4.2
[2024/8/7 9:03:07 321] NET: Registered protocol family 24
[2024/8/7 9:03:07 321] usbcore: registered new interface driver asix
[2024/8/7 9:03:07 337] usbcore: registered new interface driver cdc_ether
[2024/8/7 9:03:07 337] usbcore: registered new interface driver rndis_host
[2024/8/7 9:03:07 337] XMMMAC driver:
[2024/8/7 9:03:07 337] 	platform registration... 
[2024/8/7 9:03:07 337] 	done!
[2024/8/7 9:03:07 353] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 9:03:07 353] 	IO base addr: 0xfe010000)
[2024/8/7 9:03:07 353] libphy: XMMMAC MII Bus: probed
[2024/8/7 9:03:07 353] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 9:03:07 370] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 9:03:07 370] usbcore: registered new interface driver cdc_acm
[2024/8/7 9:03:07 370] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 9:03:07 386] usbcore: registered new interface driver usbserial
[2024/8/7 9:03:07 386] usbcore: registered new interface driver option
[2024/8/7 9:03:07 386] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 9:03:07 401] usbcore: registered new interface driver qcserial
[2024/8/7 9:03:07 402] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 9:03:07 402] TCP: cubic registered
[2024/8/7 9:03:07 402] NET: Registered protocol family 17
[2024/8/7 9:03:07 417] Key type dns_resolver registered
[2024/8/7 9:03:07 418] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 9:03:07 418] registered taskstats version 1
[2024/8/7 9:03:07 434] VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 9:03:07 434] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 9:03:07 786] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 9:03:08 314] arasan_set_clock:
[2024/8/7 9:03:08 330] 	new freq 400000
[2024/8/7 9:03:08 346] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 9:03:08 362] arasan_set_clock:
[2024/8/7 9:03:08 393] 	new freq 300000arasan_set_clock:
[2024/8/7 9:03:08 409] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 9:03:08 425] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 9:03:08 425] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 9:03:08 441] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 9:03:08 442] [reg] = 0x20000078,[val]= 0xc103c0ff
[2024/8/7 9:03:08 442] [regarasan_set_clock:
[2024/8/7 9:03:08 442] 	new freq 195312] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 9:03:08 442] [reg] = 0x20000000,[val]= 0x00000000
[2024/8/7 9:03:08 457] [reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 9:03:08 457] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 9:03:08 457] [regi2c: module license 'Proprietary' taints kernel.
[2024/8/7 9:03:08 457] ] = 0x200505f0,[Disabling lock debugging due to kernel taint
[2024/8/7 9:03:08 457] val]= 0x00000001
[2024/8/7 9:03:08 473] i2c init is ok!
[2024/8/7 9:03:08 490] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 9:03:08 602] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 9:03:08 666] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 9:03:08 697] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 9:03:08 697] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 9:03:08 730] acodec init is ok!
[2024/8/7 9:03:08 746] i2s clk:2048000Hz
[2024/8/7 9:03:08 873] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 9:03:08 889] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 9:03:08 889] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 9:03:08 890] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 9:03:08 906] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 9:03:08 906] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 9:03:08 906] usb usb1: Product: DWC OTG Controller
[2024/8/7 9:03:08 906] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 9:03:08 922] usb usb1: SerialNumber: dwc2.0
[2024/8/7 9:03:08 922] hub 1-0:1.0: USB hub found
[2024/8/7 9:03:08 922] hub 1-0:1.0: 1 port detected
[2024/8/7 9:03:08 969] xm_wdt init is ok
[2024/8/7 9:03:08 985] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 9:03:09 289] nn_kernel: NN: request mem  fail
[2024/8/7 9:03:09 289] nn_kernel: addr iomap fail
[2024/8/7 9:03:09 337] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 9:03:09 881] /usr/etc/loadmod: /usr/etc/loadpusb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 9:03:09 881] ublic: line 106:usbwifi_init.
[2024/8/7 9:03:09 897]  /mnt/mtd/user.sPDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 9:03:09 897] h: not found
[2024/8/7 9:03:09 897] dwc2 dwc2.0: Not connected
[2024/8/7 9:03:09 929] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 9:03:09 962] exfatfsck 1.3.0
[2024/8/7 9:03:09 962] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:03:11 881] ouput high and delay 2000ms
[2024/8/7 9:03:11 993] Auto login as root ...
[2024/8/7 9:03:12 041] (none) login: not found /dev/mmcxxx  
[2024/8/7 9:03:12 057] Tcp server success, Wait connet ...
[2024/8/7 9:03:12 058] Get xmauto Fialed ,xmauto = 1
[2024/8/7 9:03:12 058] auto start to app 
[2024/8/7 9:03:12 073] macGuarder: Get telnetctrl Fialed, telnetctrl=0
[2024/8/7 9:03:12 089] macGuarder: Close telnetd Forever 
[2024/8/7 9:03:12 393] usb 1-1: new high-speed USB device number 4 using dwc2
[2024/8/7 9:03:12 617] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:03:12 618] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:03:12 618] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:03:12 618] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:03:13 928] [atbm_log]:atbm_usb_module_init 0
[2024/8/7 9:03:13 945] [atbm_log]:platform_init(253)
[2024/8/7 9:03:13 945] [atbm_log]:SVN_VER=33341,DPLL_CLOCK=1,BUILD_TIME=[2024-04-03_14:40:53]
[2024/8/7 9:03:13 945] [atbm_log]:Probe called -1 v1
[2024/8/7 9:03:13 960] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[2024/8/7 9:03:13 960] [atbm_log]:CONFIG_TX_NO_CONFIRM
[2024/8/7 9:03:13 960] wiphy_new_nm support CONFIG_WIRELESS_EXT 
[2024/8/7 9:03:13 961] [atbm_log]:Allocated hw_priv @ c2789960
[2024/8/7 9:03:13 977] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[2024/8/7 9:03:13 977] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c2789960)
[2024/8/7 9:03:13 992] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c2789960)
[2024/8/7 9:03:13 992] [atbm_log]:not support ldpc & ht40!
[2024/8/7 9:03:13 993] [atbm_log]:atbm_get_chiptype, chipver=0x5a, g_wifi_chip_type[14]
[2024/8/7 9:03:14 008] [atbm_log]:atbm_before_load_firmware++
[2024/8/7 9:03:14 008] [atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[2024/8/7 9:03:14 008] [atbm_log]:===================~_~====================
[2024/8/7 9:03:14 009] [atbm_log]:atbm_start_load_firmware++
[2024/8/7 9:03:14 025] fwhdr->flags 34353678 sram_addr 9022000
[2024/8/7 9:03:14 025] [[atbm_log]:
[2024/8/7 9:03:14 025] ======>>> load WIFI BLE COMB firmware <<<======
[2024/8/7 9:03:14 025] 1970-01-01 00:00[atbm_log]:START DOWNLOAD ICCM=========
[2024/8/7 9:03:14 041] :07] <json_parse[atbm_log]:atbm_load_firmware_generic: addr 60000: len 20000
[2024/8/7 9:03:14 041] .c> ==> XMJSON_ParseExVb(526)[ERROR]: Get Vb object error!
[2024/8/7 9:03:14 057] [1970-01-01 00:00:07] <xm_system.c> ==> XMSDK_ParseJson(48)[ERROR]: Parse Vb Failed!
[2024/8/7 9:03:14 057] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(452)[ERROR]: Get Isp object u32Flag error set value 1!
[2024/8/7 9:03:14 073] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(464)[ERROR]: Get Isp object u32Others error set value 0!
[2024/8/7 9:03:14 089] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(476)[ERROR]: Get Isp object CmosPort error set value 0!
[2024/8/7 9:03:14 089] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(488)[ERROR]: Get Isp object splice_mode error set value 0!
[2024/8/7 9:03:14 105] [1970-01-01 00:00:06] MainApp.c(1802) <main>: build @Jul 31 2024 13:28:12
[2024/8/7 9:03:14 105] [1970-01-01 00:00:06] MainApp.c(1710) <SetLogLevel>: set Sofia log level 2 suceess
[2024/8/7 9:03:14 121] [1970-01-01 00:00:06] ==> XMSDK_SetLogLevel(226)[NOTICE]: set xmsdk log 4
[2024/8/7 9:03:14 121] [1970-01-01 00:00:07] xm_log.c(100) <XM_RegisterLogAndInit>: Register Log level 2
[2024/8/7 9:03:14 137] [1970-01-01 00:00:07] xm_hwinfo.c(162) <XM_HwinfoInit>: Sync hwinfo to Hwfile success!
[2024/8/7 9:03:14 153] Get Hw info: AppId [fvijo8jvloagv1gm], license [uuidcaab27b0a838d239], mac[j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:03:14 153] [1970-01-01 00:00:07] utils.c(974) <ReadJsonConfig>: Have not find pClass [DeviceGpio] pNumber [NetStatusLedGpio]
[2024/8/7 9:03:14 169] [1970-01-01 00:00:07] xm_device.c(226) <ParseDeviceJsonFile>: Get g_NetStatusLed [0] failed
[2024/8/7 9:03:14 169] **********************************************************************
[2024/8/7 9:03:14 185] |                      SYSTEM INFO                                       
[2024/8/7 9:03:14 185] |       product type:		RC50X80
[2024/8/7 9:03:14 185] |           DSP chip:		XM550V200
[2024/8/7 9:03:14 185] |          wifi type:		ATBM6062U
[2024/8/7 9:03:14 185] |             HW mac:		90314ba51650
[2024/8/7 9:03:14 185] |        git version:		a590e8b3
[2024/8/7 9:03:14 201] |          make time:		20240731132812
[2024/8/7 9:03:14 201] **********************************************************************
[2024/8/7 9:03:14 217] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(143)[INFO]: SensorSrcFrmRate = 25
[2024/8/7 9:03:14 217] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(137)[INFO]: SensorIFS = 0
[2024/8/7 9:03:14 233] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(156)[INFO]: Vi CapW 2680, CapH 2160, CapX 0, CapY 0
[2024/8/7 9:03:14 233] [1970-01-01 00:00:07] ==>[atbm_log]:START DOWNLOAD DCCM=========
[2024/8/7 9:03:14 233]  XMJSON_ParseViX[atbm_log]:atbm_load_firmware_generic: addr 800000: len d000
[2024/8/7 9:03:14 249] (110)[INFO]: ViChn 0: size=[3840, 2160] @3
[2024/8/7 9:03:14 249] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 1: size=[640, 360] @3
[2024/8/7 9:03:14 265] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 2: size=[640, 224] @3
[2024/8/7 9:03:14 265] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(406)[INFO]: ISPRsltType
[2024/8/7 9:03:14 281] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(428)[INFO]: ISPRsltType 0
[2024/8/7 9:03:14 281] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(442)[INFO]: ISPRsltType
[2024/8/7 9:03:14 297] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_Parse4gMoudle(500)[WARN]: Get 4GModule object error!
[2024/8/7 9:03:14 297] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(80)[NOTICE]: ISP=> Svtd: PAL
[2024/8/7 9:03:14 313] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(81)[NOTICE]: ISP=>RsltType: 0
[2024/8/7 9:03:14 313] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(84)[NOTICE]: IRCut: gpio[atbm_log]:START DOWNLOAD BLE SRAM=========
[2024/8/7 9:03:14 313]  19534 Swap 0
[2024/8/7 9:03:14 329]  tbm_log]:atbm_load_firmware_generic: addr 9022000: len 10000
[2024/8/7 9:03:14 329] [0;39m
[2024/8/7 9:03:14 329] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(88)[NOTICE]: Infrared: gpio 0 swap 1
[2024/8/7 9:03:14 345] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(92)[NOTICE]: WLight: gpio 11 swap 0
[2024/8/7 9:03:14 345] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(96)[NOTICE]: IRLight: gpio 10 swap 0
[2024/8/7 9:03:14 361] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(99)[NOTICE]: Vi: sensorIFS=0 sensorFPS=25, capW=2680,capH=2160,capX=0,capY=0
[2024/8/7 9:03:14 378] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(100)[NOTICE]: ViChn  ImageSize      vbBlk
[2024/8/7 9:03:14 378] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    0  [3840, 2160]    3
[2024/8/7 9:03:14 393] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    1  [ 640,  360]    2
[2024/8/7 9:03:14 393] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    2  [ 640,  224]    2
[2024/8/7 9:03:14 410] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(107)[NOTICE]: VencChn    MaxSize   PreReleaseVb
[2024/8/7 9:03:14 410] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    0   [3840, 2160]	 false
[2024/8/7 9:03:14 426] [1970-01-[atbm_log]:atbm_after_load_firmware++
[2024/8/7 9:03:14 426] 01 00:00:07] ==>[atbm_log]:alloc urb work
[2024/8/7 9:03:14 426]  XMSDK_ParseJson[atbm_log]:usb:try to flush rx....
[2024/8/7 9:03:14 442] (113)[NOTICE]:    1   [ 640,  3i2c_write timeout 0x2
[2024/8/7 9:03:14 442] 60]	 false
[2024/8/7 9:03:14 458] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(116)[NOTICE]: 4GModule: gpio 0 Swap 0
[2024/8/7 9:03:14 458] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: AudioSwap: 0
[2024/8/7 9:03:14 458] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(656)[INFO]: AudioSwap=[0]
[2024/8/7 9:03:14 474] 
[2024/8/7 9:03:14 476] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: HighAdcValue: 0
[2024/8/7 9:03:14 476] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: LowAdcValue: 0
[2024/8/7 9:03:14 490] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: IRLightLevei2c_write timeout 0x2
[2024/8/7 9:03:14 490] l: 0
[2024/8/7 9:03:14 490] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: InfraredSwap: 0
[2024/8/7 9:03:14 506] [1970-01-01 00:00:07DEBUG: [libispapp]:Jul  5 2024 16:14:06 ,GENERAL
[2024/8/7 9:03:14 506] DEBUG: Vstd_init	[ PAL ]
[2024/8/7 9:03:14 506] DEBUG: RsltSns0	[ 8 ]
[2024/8/7 9:03:14 506] DEBUG: Dsp:		[0x0][ CHIPV200 ]
[2024/8/7 9:03:14 522] DEBUG: [libsns]:Jul  5 2024 16:13:32 ,GENERAL
[2024/8/7 9:03:14 522] [atbm_log]:flush rx[-110][0]
[2024/8/7 9:03:14 537] [atbm_log]:0x1610102c=0x4300a
[2024/8/7 9:03:14 537] [atbm_log]:0x1610102c=0x6300b
[2024/8/7 9:03:14 537] [atbm_log]:0x16101000=0x0
[2024/8/7 9:03:14 537] [atbm_log]:set_block_size=256
[2024/8/7 9:03:14 537] [atbm_log]:mdelay wait wsm_startup_done  !!
[2024/8/7 9:03:14 553] [atbm_log]:firmwareCap 31e9
[2024/8/7 9:03:14 553] [atbm_log]:firmwareCap2 1b8c
[2024/8/7 9:03:14 553] [atbm_log]:wsm_caps.firmwareCap 1b8c31e9 16[atbm_log]:apollo wifi WSM init done.
[2024/8/7 9:03:14 553]    Input buffers: 32 x 1632 bytes
[2024/8/7 9:03:14 569]    Hardware: 7.21
[2024/8/7 9:03:14 585]    WSM firmware [=MODEM=DPLL24M+BLE+plat=4 ApSleep 2GHZ Jan 30 2024 10:58:03], ver: 19514, build: 6431, api: 1060, cap: 0x1B8C31E9 Config[31010]  expection 900c094, ep0 cmd addr 901b340 NumOfStations[0x10] NumOfInterfaces[3]
[2024/8/7 9:03:14 585] [atbm_log]:EFUSE(8)				[0]
[2024/8/7 9:03:14 585] [atbm_log]:EFUSE(I)					[0]
[2024/8/7 9:03:14 585] [atbm_log]:EFUSE(B)			[0]
[2024/8/7 9:03:14 585] i2c_write timeout 0x2
[2024/8/7 9:03:14 601] [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [0]
[2024/8/7 9:03:14 601] [atbm_log]:CAPABILITIES_NVR_IPC              [0]
[2024/8/7 9:03:14 601] [atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[2024/8/7 9:03:14 601] [atbm_log]:CAPABILITIES_WOW                  [0]
[2024/8/7 9:03:14 617] [atbm_log]:CAPABILITIES_NO_BACKOFF           [1]
[2024/8/7 9:03:14 617] [atbm_log]:CAPABILITIES_CFO                  [1]
[2024/8/7 9:03:14 617] [atbm_log]:CAPABILITIES_CHIP_FLAG            [1]
[2024/8/7 9:03:14 633] [atbm_log]:CAPABILITIES_TXCAL                [1]
[2024/8/7 9:03:14 633] [atbm_log]:CAPABILITIES_HIF_TRACE       		[0]
[2024/8/7 9:03:14 633] i2c_write timeout 0x2
[2024/8/7 9:03:14 633] [atbm_log]:CAPABILITIES_FORCE_PM_ACTIVE      [0]
[2024/8/7 9:03:14 633] [atbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[2024/8/7 9:03:14 649] DEBUG: SC[atbm_log]:CAPABILITIES_ETF                  [1]
[2024/8/7 9:03:14 649] 831HAI! Chn:[atbm_log]:CAPABILITIES_BLE		  			[1]
[2024/8/7 9:03:14 649] 0
[2024/8/7 9:03:14 649] [atbm_log]:CAPABILITIES_40M			  		[0]
[2024/8/7 9:03:14 664] [atbm_log]:CAPABILITIES_LDPC 		  		[0]
[2024/8/7 9:03:14 664] [atbm_log]:CAPABILITIES_NAV_ENABLE              [0]
[2024/8/7 9:03:14 664] [atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [0]
[2024/8/7 9:03:14 665] [atbm_log]:CAPABILITIES_USE_IPC              [1]
[2024/8/7 9:03:14 680] [atbm_log]:CAPABILITIES_OUTER_PA             [0]
[2024/8/7 9:03:14 681] [atbm_log]:CAPABILITIES_WFA    [0]
[2024/8/7 9:03:14 681] DEBUG: Is[atbm_log]:CAPABILITIES_EAP_GROUP_REKEY  [0]
[2024/8/7 9:03:14 681] pNum[1]
[2024/8/7 9:03:14 696] atbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[2024/8/7 9:03:14 697] 35mDEBUG: IspChn[atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[2024/8/7 9:03:14 697] :[ 0  tbm_log]:CAPABILITIES_RXCAL       [1]
[2024/8/7 9:03:14 697] [m]
[2024/8/7 9:03:14 712]  tbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[2024/8/7 9:03:14 712] [1;35mDEBUG: I2C[atbm_log]:CAPABILITIES_80211_TO_8023 [1]
[2024/8/7 9:03:14 712] Chn:[ [atbm_log]:CAPABILITIES_NEW_CHIPER  [1]
[2024/8/7 9:03:14 713] 0 ]
[2024/8/7 9:03:14 728]  tbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [0]
[2024/8/7 9:03:14 728] [mDEBUG: [atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[2024/8/7 9:03:14 728] limitedUp: no
[2024/8/7 9:03:14 729] atbm_log]:LMAC NOT SUPPORT 40M !!!
[2024/8/7 9:03:14 744] mDEBUG: --------[atbm_log]:LMAC NOT SUPPORT LDPC !!!
[2024/8/7 9:03:14 744] -----SC831Hai 4K 30fps init ok! (20240322)-------------
[2024/8/7 9:03:14 744] DEBUG: camera_set_saved_status OK!
[2024/8/7 9:03:14 761] DEBUG: [libautoscene]:Jul  5 2024 16:13:42 ,GENERAL
[2024/8/7 9:03:14 762] DEBUG: [libautoscene]:use libfvideo!
[2024/8/7 9:03:14 762] DEBUG: [libfvideo]:Jul  5 2024 15:41:09 
[2024/8/7 9:03:14 762] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:03:14 777] DEBUG: IspKo: clean cut!
[2024/8/7 9:03:14 777] [libsdnc]:Aug 22 2023 13:55:14
[2024/8/7 9:03:14 777] DEBUG: LED: [IR] 
[2024/8/7 9:03:14 777] DEBUG: software LED
[2024/8/7 9:03:14 777] DEBUG: hardware pohtoR!
[2024/8/7 9:03:14 793] DEBUG: isp_sample over!
[2024/8/7 9:03:14 793] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:03:14 793] ] ==> XMJSON_GetInt(570)[INFO]: WhiteLightLevel: 0
[2024/8/7 9:03:14 809] [1970-01-01 00:00:07] xm_main.c(345) <AutoMaintenance_pro>: Set device auto mantenance time: -001_-1_-1 02:25:26 wenkday: Tuesday
[2024/8/7 9:03:14 809] [1970IspKo: set cut 0x0 0xf00 0x1 0x871
[2024/8/7 9:03:14 825] -01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoHorizontalFlipGun: 0
[2024/8/7 9:03:14 825] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoVerticalFlipGun: 0
[2024/8/7 9:03:14 825] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: setMonocular: 1
[2024/8/7 9:03:14 841] [1970-01-01 00:00:07] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:03:14 857] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedX: 17
[2024/8/7 9:03:14 857] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedY: 17
[2024/8/7 9:03:14 873] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: soundValue: 50
[2024/8/7 9:03:14 873] [1970-01-01 00:00:07] xm_main.c(349) <AutoMaintenance_pro>: Get Last AutoMantence Date [] failed
[2024/8/7 9:03:14 889] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: lightChannel: 0
[2024/8/7 9:03:14 889] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: dayAndNightMode: 0
[2024/8/7 9:03:14 905] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: hardAndSoftLight: 1
[2024/8/7 9:03:14 905] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeX: 400
[2024/8/7 9:03:14 921] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeY: 200
[2024/8/7 9:03:14 922] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(587)[INFO]: RatioOfGear: 1:1
[2024/8/7 9:03:14 922] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(593)[INFO]: high 1: low 1
[2024/8/7 9:03:14 937] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(690)[INFO]: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:03:14 937] [197[atbm_log]:wsm_generic_confirm:status(2)
[2024/8/7 9:03:14 953] 0-01-01 00:00:07[atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[2024/8/7 9:03:14 953] ] xm_main.c(462) <GetVideoResolu[atbm_log]:apollo wifi : can't open /data/.mac.info
[2024/8/7 9:03:14 969] tion>: Video res[atbm_log]:efuse data is [0x1,0x38,0x15,0x16,0x16,0x8,0x0,0x0,0x90:0x31:0x4b:0xa5:0x16:0x50]
[2024/8/7 9:03:14 969] olution: captrue width 2[atbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[2024/8/7 9:03:14 985] 680 height 2160 resoluti[atbm_log]:win txpower:0on main: width 3
[2024/8/7 9:03:14 985] 840 height 2160 [atbm_log]:use default power
[2024/8/7 9:03:14 985] extra:  width 640 height 360 [2]: width 640 height 224
[2024/8/7 9:03:15 001] [1970-01-01 00:00:07] MainApp.c(1812) <main>: version , date 20240724, time 182054, plus 0
[2024/8/7 9:03:15 001] [1970-01-01 00:00:07] ==> XMSDK_StartUp(174)[INFO]: XMSDK_StartUp enter, Jul 24 2024, 18:20:55
[2024/8/7 9:03:15 017] [1970-01[atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[2024/8/7 9:03:15 017] -01 00:00:07] ==[atbm_log]:==read success==
[2024/8/7 9:03:15 017] > IspConfigInit([atbm_log]:set delta power
[2024/8/7 9:03:15 033] 158)[INFO]: maxHeight 2160 maxWidth 3840 u32RsltType 8
[2024/8/7 9:03:15 033] [1970-01-01 00:00:07] ==> XMSDK_StartUp(203)[INFO]: g_stProductMgr.viMgr.capW =[2680] g_stProduc[atbm_log]:get chip id [0][0][0] 
[2024/8/7 9:03:15 049] tMgr.viMgr.capH [atbm_log]:current chiptype ATBM6062-U20-noLDPC 
[2024/8/7 9:03:15 049] = [2160]
[2024/8/7 9:03:15 049] atbm_log]:default country code:00,support channel=14
[2024/8/7 9:03:15 065] 2m[1970-01-01 00[atbm_log]:Use an internal power amplifier!
[2024/8/7 9:03:15 065] :00:07] ==> XMSDK_StartUp(220)[INFO]: g_[atbm_log]:enable sg
[2024/8/7 9:03:15 065] stProductMgr.ven[atbm_log]:[eth2] has been disabled
[2024/8/7 9:03:15 081] cMgr.vencChn[0].maxHeight =[2160] g_stProductMgr.encMgr.vencChn[0].maxWidth = [3840]
[2024/8/7 9:03:15 081] [1970-01-01 00:00:07] ==> XMSDK_StartUp(286)[INFO]: ispCfg.u32Others 0x0
[2024/8/7 9:03:15 081] [atbm_log]:enable sg
[2024/8/7 9:03:15 097] [atbm_log]:[p2p0] has been disabled
[2024/8/7 9:03:15 113] [1970-01-01 00:00:07] ==> XMSDK_StartUp(288)[INFO]: ispCfg.u32FunExt 0x0 u32Infrared 0x80000000 u32snsRsltType 0x0 u32RsltType 0x8 au32IrCut 0x80004c4e  au32SoftLed[0]: 0x800b0a11 u32Flag: 0x1 SensorRstIO: 0x[atbm_log]:ble start
[2024/8/7 9:03:15 113] 800000a4 u32Coms[atbm_log]:[ALTOBEAM-ble_recv] start
[2024/8/7 9:03:15 113] Port: 0x0
[2024/8/7 9:03:15 113] atbm_log]:ble subscribe
[2024/8/7 9:03:15 129] [atbm_log]:[ALTOBEAM-ble_xmit] start
[2024/8/7 9:03:15 129] 9m
[2024/8/7 9:03:15 129] [1970-01-01 0[atbm_log]:ble_platform_probe(c1e14940)
[2024/8/7 9:03:15 129] 0:00:07] ==> SampleCreat[atbm_log]:is registered as 'ALTOBEAM'
[2024/8/7 9:03:15 145] e(1709)[INFO]: v[atbm_log]:[atbm_wtd]:set wtd_probe = 1
[2024/8/7 9:03:15 145] iChn:0 vstd:0 enter
[2024/8/7 9:03:15 145]        sbcore: registered new interface driver atbm_wlan
[2024/8/7 9:03:15 161] 32m[1970-01-01 00:00:07] ==> ViChnConfig(866)[INFO]: set vichn 0 size [3840, 2160]
[2024/8/7 9:03:15 162] [1970-01-01 00:00:07] ==> ViChnConfig(866)[INFO]: set vichn 1 size [640, 360]
[2024/8/7 9:03:15 177] [1970-01-01 00:00:07] ==> ViChnConfig(866)[INFO]: set vichn 2 size [640, 224]
[2024/8/7 9:03:15 177] [1970-01-01 00:00:07] ==> VencChCreate(1058)[INFO]: channel:0 enter
[2024/8/7 9:03:15 193] [1970-01-01 00:00:07] ==> VencChCreate(1079)[INFO]: VcChn[0].vencMem = VENCMEM_MICRO
[2024/8/7 9:03:15 194] [1970-01-01 00:00:07] ==> COMM_VENC_Start(890)[INFO]: VencChn = 0,width = 3840,height = 2160,enType = 265
[2024/8/7 9:03:15 194] NORM ENC MODE
[2024/8/7 9:03:15 209] [1970-01-01 00:00:07] ==> VencChCreate(1079)[INFO]: VcChn[1].vencMem = VENCMEM_MICRO
[2024/8/7 9:03:15 209] [1970-01-01 00:00:07] ==> COMM_VENC_Start(890)[INFO]: VencChn = 1,width = 640,height = 360,enType = 265
[2024/8/7 9:03:15 225] NORM ENC MODE
[2024/8/7 9:03:15 226] aec 1; agc 1; ans 1
[2024/8/7 9:03:15 226] [1970-01-01 00:00:07] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 21,DestChnId = 0,DestModId = 23
[2024/8/7 9:03:15 241] [1970-01-01 00:00:07] ==> AudioCreate(1656)[INFO]: XM_AENC_CreateCH OK
[2024/8/7 9:03:15 241] [1970-01-01 00:00:07] ==> AudioCreate(1685)[INFO]: XM_MPI_ADEC_CreateChn OK
[2024/8/7 9:03:15 258] [1970-01-01 00:00:07] ==> DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:03:15 258] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:03:15 258] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:03:15 258] DEBUG: software pohtoR!
[2024/8/7 9:03:15 274] DEBUG: camera_set_photosensitive_chn 0 1 0x1
[2024/8/7 9:03:15 274] SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 24,DestChnId = 0,DestModId = 22
[2024/8/7 9:03:15 291] [1970-01-01 00:00:07] ==> JPEGChCreate(1556)[INFO]: enter JPEGChCreate channel=0, VencChn = 3
[2024/8/7 9:03:15 292] [1970-01-01 00:00:07] ==> COMM_VENC_Start(890)[INFO]: VencChn = 3,width = 640,height = 360,enType = 26
[2024/8/7 9:03:15 309] [1970-01-01 00:00:07] ==> COMM_VENC_Start(913)[INFO]: set JpegAttr
[2024/8/7 9:03:15 309] [1970-01-01 00:00:07] ==> SysBind(2342)[INFO]: SrcChnId = 1,SrcModId = 7,DestChnId = 3,DestModId = 7
[2024/8/7 9:03:15 325] [1970-01-01 00:00:07] ==> COMM_VENC_Start(1032)[INFO]: JPEG_CHN[3] bind VENC_CHN[1] success!.
[2024/8/7 9:03:15 342] [1970-01-01 00:00:07] MainApp.c(1816) <main>: [1970-01-01 00:00:07] MainApp.c(1823) <main>: [1970-01-01 00:00:07] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:03:15 358] [1970-01-01 00:00:07] MainApp.c(1883) <main>: g_fps=[12]
[2024/8/7 9:03:15 358] [1970-01-01 00:00:07] xm_main.c(700) <XM_SetCameraFactoryConfig>: Get AutoMantence flags [0] failed
[2024/8/7 9:03:15 374] [1970-01-01 00:00:07] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=0,brc=1,w=3840,h=2160,qua=4,frame=12,br=1000,gop=4
[2024/8/7 9:03:15 390] [1970-01-01 00:00:07] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[0],wh[3840,2160]-----------
[2024/8/7 9:03:15 390] [1970-01-01 00:00:07] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:03:15 406] [1970-01-01 00:00:07] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=1,brc=1,w=640,h=360,qua=4,frame=9,br=256,gop=1
[2024/8/7 9:03:15 422] [1970-01-01 00:00:07] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[1],wh[640,360]-----------
[2024/8/7 9:03:15 422] [1970-01-01 00:00:07] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:03:15 433] [1970-01-01 00:00:07] MainApp.c(1885) <main>: [1970-01-01 00:00:07] MainApp.c(1893) <main>: 
[2024/8/7 9:03:15 433] [1970-01-01 00:00:07] MainApp.c(1898) <main>: 
[2024/8/7 9:03:15 433] [1970-01-01 00:00:07] xm_main.c(1899) <PtzControl_Pro>: 
[2024/8/7 9:03:15 448] PtzControl_Pro[1970-01-01 00:00:07] ==> XMSDK_MotorCreate(120)[INFO]: xlimit 5006, ylimit 2161
[2024/8/7 9:03:15 464] [1970-01-01 00:00:07] xm_main.c(1903) <PtzControl_Pro>: g_sPtz.xMaxStep 5006 g_sPtz.yMaxStep 2161 
[2024/8/7 9:03:15 464] [1970-01-01 00:00:07] xm_main.c(1747) <XM_RealVideo_Pro>: realy video play start___0
[2024/8/7 9:03:15 480] [1970-01-01 00:00:07] xm_main.c(1375) <XM_RealAudio_Pro>: real Audio play start___
[2024/8/7 9:03:15 480] [1970-01-01 00:00:07] ==> AudioInSetFormat(68)[INFO]: pFormat.EncodeTye = 2
[2024/8/7 9:03:15 496] [1970-01-01 00:00:07] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 0
[2024/8/7 9:03:15 496] [1970-01-01 00:00:07] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 0 OK
[2024/8/7 9:03:15 512] [1970-01-01 00:00:07] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 1
[2024/8/7 9:03:15 512] [1970-01-01 00:00:07] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 1 OK
[2024/8/7 9:03:15 529] [1970-01-01 00:00:07] xm_main.c(821) <XM_SetCameraFactoryConfig>: get default language ChineseEnglish
[2024/8/7 9:03:15 545] [1970-01-01 00:00:07] xm_main.c(822) <XM_SetCameraFactoryConfig>: get defult IRcurt reverse: no picture reverse mirror:yes filp:yes
[2024/8/7 9:03:15 545] [1970-01-01 00:00:07] xm_main.c(823) <XM_SetCameraFactoryConfig>: set defult motor ptz reverse  mirror:yes filp:no
[2024/8/7 9:03:15 561] [1970-01-01 00:00:07] xm_main.c(824) <XM_SetCameraFactoryConfig>: get defult autotrack motor reverse mirror:yes filp:no
[2024/8/7 9:03:15 577] [1970-01-01 00:00:07] xm_main.c(825) <XM_SetCameraFactoryConfig>: get defult ptz preset x:1556 y:950
[2024/8/7 9:03:15 577] [1970-01-01 00:00:07] xm_main.c(920) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:03:15 593] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:03:15 609] [1970-01-01 00:00:07] ==> XMSDK_AudioInSetFormat(445)[INFO]: anr(1) agc(1) aec(0)
[2024/8/7 9:03:15 609] aec 0; agc 1; ans 1
[2024/8/7 9:03:15 610] [1970-01-01 00:00:07] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:03:15 625] 
[2024/8/7 9:03:15 626] [1970-01-01 00:00:08] xm_main.c(969) <XM_SetCameraFactoryConfig>: get factory language ChineseEnglish
[2024/8/7 9:03:15 626] [DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:03:15 641] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:03:15 641] DEBUG: camera_set_photosensitive_chn 0 0 0x1
[2024/8/7 9:03:15 641] killall: hostapd: no process killed
[2024/8/7 9:03:15 657] ERR: varLED_pwmGpioInit 970 gpio 11 not[atbm_log]:ioctl_open(c1c74e00)(c1e14940)
[2024/8/7 9:03:15 657]  support PWM![atbm_log]:atbm_ioctl_ble_start
[2024/8/7 9:03:15 689] DEBUG: camera_set_ledType:  2
[2024/8/7 9:03:15 689] DEBUG: camera_set_dnc_mode_chn 3 
[2024/8/7 9:03:15 689] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:03:15 705] DEBUG: LED: [IR] [WL] 
[2024/8/7 9:03:15 705] DEBUG: software LED
[2024/8/7 9:03:15 705] DEBUG: software pohtoR!
[2024/8/7 9:03:15 705] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:03:15 721] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:03:15 721] DEBUG: camera_set_ledHold: 60000
[2024/8/7 9:03:15 737] 1970-01-01 00:00:08] xm_main.c(970) <XM_SetCameraFactoryConfig>: get factory IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:03:15 737] [1970-01-01 00:00:08] xm_main.c(971) <XM_SetCameraFactoryConfig>: set factory motor ptz reverse  mirror:yes filp:yes
[2024/8/7 9:03:15 753] [1970-01-01 00:00:08] xm_main.c(972) <XM_SetCameraFactoryConfig>: get factory autotrack motor reverse mirror:no filp:no
[2024/8/7 9:03:15 769] [1970-01-01 00:00:08] xm_main.c(973) <XM_SetCameraFactoryConfig>: get factory ptz preset x:3110 y:0
[2024/8/7 9:03:15 771] [1970-01-01 00:00:08] xm_main.c(1007) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:03:15 785] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:03:15 801] [1970-01-01 00:00:08] xm_main.c(1040) <XM_SetCameraFactoryConfig>: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:03:15 817] [1970-01-01 00:00:08] xm_main.c(1060) <XM_SetCameraFactoryConfig>: set IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:03:15 818] [1970-01-01 00:00:08] xm_main.c(1078) <XM_SetCameraFactoryConfig>: camera_set_softIr_thr(1) ret=[0]
[2024/8/7 9:03:15 833] [1970-01-01 00:00:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[597],val=[1]
[2024/8/7 9:03:15 833] ************last intra 0
[2024/8/7 9:03:15 834] [1970-01-01 00:00:08] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time8193
[2024/8/7 9:03:15 850] [1970-01-01 00:00:08] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 107328
[2024/8/7 9:03:15 850] [1970-01-01 00:00:08] MainApp.c(1900) <main>: 
[2024/8/7 9:03:15 865] [1970-01-01 00:00:08] MainApp.c(1905) <main>: 
[2024/8/7 9:03:15 865] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:Register pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:03:15 881] [1970-01-01 00:00:08] ==> XMSDK_AudioSetSpeakerVol(641)[INFO]: enter: Speaker Open
[2024/8/7 9:03:15 881] [1970-01-01 00:00:08] MainApp.c(1913) <main>: 
[2024/8/7 9:03:15 897] [1970-01-01 00:00:08] ==> XMSDK_WifiInit(601)[INFO]: Wifi Init success
[2024/8/7 9:03:15 897] [1970-01-01 00:00:08] MainApp.c(1915) <main>: 
[2024/8/7 9:03:15 897] [1970-01-01 00:00:08] MainApp.c(1918) <main>: 
[2024/8/7 9:03:15 897] lib_ble_main_init
[2024/8/7 9:03:15 913] ======>>atbm_ble_start>>>
[2024/8/7 9:03:15 914] nimble_port_init++
[2024/8/7 9:03:15 914] nimble_host_task
[2024/8/7 9:03:15 914] ble_coexist_start--
[2024/8/7 9:03:15 914] hif_ioctl_loop
[2024/8/7 9:03:15 914] ble_hs_sync:333
[2024/8/7 9:03:15 914] ble_smart_cfg_startup!11
[2024/8/7 9:03:15 914] [ATBM lOG]set default tx power(0)
[2024/8/7 9:03:15 914] pub addr 90:31:4b:a5:16:51
[2024/8/7 9:03:15 929] [1970-01-01 00:00:08] MainApp.c(1922) <main>: ble_ret=[0]
[2024/8/7 9:03:15 929] [1970-01-01 00:00:08] MainApp.c(1200) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:15 945] [1970-01-01 00:00:08] MainApp.c(1229) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:15 945] [1970-01-01 00:00:08] MainApp.c(1258) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:15 961] [1970-01-01 00:00:08] MainApp.c(1260) <GetAndSetTyDefalutConfig>: SMLMode=[2]
[2024/8/7 9:03:15 961] [1970-01-01 00:00:08] MainApp.c(1263) <GetAndSetTyDefalutConfig>: g_SMLAbility=[0]
[2024/8/7 9:03:15 961] [1970-01-01 00:00:08] MainApp.c(1266) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:15 977] [1970-01-01 00:00:08] MainApp.c(1338) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:15 977] [1970-01-01 00:00:08] MainApp.c(1346) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:15 993] [1970-01-01 00:00:08] MainApp.c(1357) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:15 993] [1970-01-01 00:00:08] MainApp.c(1387) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:16 009] [1970-01-01 00:00:08] MainApp.c(1390) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:16 009] [1970-01-01 00:00:08] xm_ai.c(564) <XM_CreatePersionDetect>: 
[2024/8/7 9:03:16 009] [1970-01-01 00:00:08] xm_ai.c(574) <XM_CreatePersionDetect>: 
[2024/8/7 9:03:16 025] [1970-01-01 00:00:08] xm_ai.c(585) <XM_CreatePersionDetect>: 
[2024/8/7 9:03:16 025] [1970-01-01 00:00:08] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:03:16 041] [1970-01-01 00:00:08] xm_ai.c(588) <XM_CreatePersionDetect>: 
[2024/8/7 9:03:16 041] [1970-01-01 00:00:08] xm_ai.c(608) <XM_CreatePersionDetect>: 
[2024/8/7 9:03:16 056] [1970-01-01 00:00:08] xm_ai.c(645) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:03:16 185] [1970-01-01 00:00:08] xm_ai.c(646) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:08] xm_ai.c(647) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTime = [8];src/ped_thread.c(746) [Smart_Ped_CreateERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!ListMng - BufListCreate: index 1 OK
[2024/8/7 9:03:17 145] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:03:17 145] Mode(Product):0
[2024/8/7 9:03:17 145] BpuMode:[Online]
[2024/8/7 9:03:17 145] VpssMode:[Online]
[2024/8/7 9:03:17 145] [0.LimitUp_info]:
[2024/8/7 9:03:17 145] LimitUp:[Disable]
[2024/8/7 9:03:17 145] [2680*0]->[3840*0])
[2024/8/7 9:03:17 161] chn	TotalSize	ActiveSize
[2024/8/7 9:03:17 161] 0	5040*2246	2680*2160
[2024/8/7 9:03:17 161] 0	5040*2246	3840*2160
[2024/8/7 9:03:17 161] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:03:17 161] [1.VICU_info]:
[2024/8/7 9:03:17 161] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:03:17 177] 0	25.0	60	0	0	183	linear	8ddb00
[2024/8/7 9:03:17 177] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:03:17 177] en	op_type	m_chn	now
[2024/8/7 9:03:17 177] 0	1	1	1
[2024/8/7 9:03:17 178] [2.VI_info]:
[2024/8/7 9:03:17 178] chn	TotalSize	ActiveSize
[2024/8/7 9:03:17 178] 0	5040*2246	3848*2166
[2024/8/7 9:03:17 193] 1	   0*   0	   0*   0
[2024/8/7 9:03:17 194] 
[2024/8/7 9:03:17 195] [3.MIPI_info]:
[2024/8/7 9:03:17 195] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:03:17 195] 0x2b	6488*2166	3848*2166		5046*2166	3848*2166	   0
[2024/8/7 9:03:17 209] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:03:17 209] [4.Cut_info]:
[2024/8/7 9:03:17 209] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:03:17 209] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:03:17 209] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:03:17 209] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:03:17 225] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:03:17 225] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:03:17 225] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:03:17 225] [5.IB(isp buffer info)]:
[2024/8/7 9:03:17 225] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:03:17 241] PoolId  Count  Size
[2024/8/7 9:03:17 241] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:03:17 241] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:03:17 257] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:03:17 257] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:03:17 273] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:03:17 273] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:03:17 273] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:03:17 289] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:03:17 289] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:03:17 289] 0       0         0          0          4       
[2024/8/7 9:03:17 305] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:03:17 305]      --265--            --264--                                               
[2024/8/7 9:03:17 305] Count      Line     Count      Line     
[2024/8/7 9:03:17 321] 28         480      71         560      
[2024/8/7 9:03:17 321] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:03:17 337] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:03:17 337] 0   3840   2160    H265  0      0        0           14        983037     3        	
[2024/8/7 9:03:17 337] 1   640    360     H265  0      0        0           13        43196      4        	
[2024/8/7 9:03:17 353] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:03:17 354] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:03:17 369] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:03:17 385] 0   Y      14       0       0       15       0        14       14       25        63842         58808    79142    64115    0       
[2024/8/7 9:03:17 401] 1   Y      13       0       0       1        0        13       13       26        2282          1956     7498     3207     0       
[2024/8/7 9:03:17 401] 3   N      0        0       0       1        0        0        0        27        0             0        0        0        0       
[2024/8/7 9:03:17 416] ]: Smart_Ped_Create_ver: Jul 24 2024 18:21:40
[2024/8/7 9:03:17 417] src/ped_thread.c(656) [Ped_Init_IA_Work]: Ped_Init_IA_Work start ver:Jul 24 2024 18:21:40
[2024/8/7 9:03:17 417] [FUNC: IA_InitLog] Creat OK.
[2024/8/7 9:03:17 432] [INIT]: XM_IA_Init() done.
[2024/8/7 9:03:17 433] src/ped_thread.c(705) [Ped_Init_IA_Work]: ruler 0 region (0,0) (0,0) (0,0) (0,0)
[2024/8/7 9:03:17 433] [INIT]:LIBXMIA IAtype 700 Complied at May  8 2024 08:39:39 GIT_ID:cb3a4ed0
[2024/8/7 9:03:17 448] [INIT]: TD Version: TD_V_3.2.4.2[May 15 2024 19:14:32]
[2024/8/7 9:03:17 449] -- TD INIT -- 
[2024/8/7 9:03:17 449]  uiTdMaxNum: 12 
[2024/8/7 9:03:17 449]  acClassBinPath: /usr/bin 
[2024/8/7 9:03:17 449]  ePlatForm: 50 
[2024/8/7 9:03:17 449]  eDevImgType: 17 
[2024/8/7 9:03:17 449]  stDevImgSize: (2680,2160) 
[2024/8/7 9:03:17 464]  iTrackFlag: 1 
[2024/8/7 9:03:17 465]  iTrackType: 2 
[2024/8/7 9:03:17 465] -- TD EXTF -- 
[2024/8/7 9:03:17 465]  ucPedFallDownEnable: 0
[2024/8/7 9:03:17 465]  ucTDFeatureEnable: 0
[2024/8/7 9:03:17 465]  ucSmokeEnable: 0
[2024/8/7 9:03:17 465]  ucFaceDetEnable: 0
[2024/8/7 9:03:17 465]  ucFaceMaskEnable: 0
[2024/8/7 9:03:17 465]  ucFaceAngEnable: 0
[2024/8/7 9:03:17 480]  ucFaceRegEnable: 0
[2024/8/7 9:03:17 480]  ucPlateDetEnable: 0
[2024/8/7 9:03:17 480]  ucPlateRegEnable: 0
[2024/8/7 9:03:17 480]  ucPedPointEnable: 0
[2024/8/7 9:03:17 480]  ucHandPointEnable: 0
[2024/8/7 9:03:17 480]  ucHelmetEnable: 0
[2024/8/7 9:03:17 480]  ucHandgestureEnable: 0
[2024/8/7 9:03:17 480]  efdfreq: 10
[2024/8/7 9:03:17 496] [INIT]: XM_IA_TD_PED_S Version: 20230719_person_noexp_v200
[2024/8/7 9:03:17 496] [INIT] Alg Malloc Size 27232
[2024/8/7 9:03:17 496] -- TD CFG --  
[2024/8/7 9:03:17 496]  iMDFlag: 0
[2024/8/7 9:03:17 496]  ucDetectDisable: 0
[2024/8/7 9:03:17 496]  iDetectType: 5
[2024/8/7 9:03:17 496]  ePattern: 3
[2024/8/7 9:03:17 496]  eSensitivity: 2
[2024/8/7 9:03:17 496]  ucFishEyeCorrectFlag:0
[2024/8/7 9:03:17 512]  eRotate:0
[2024/8/7 9:03:17 512]  ucSationaryTd: 0
[2024/8/7 9:03:17 512]  ucClearnessFlg:0
[2024/8/7 9:03:17 512]  usInImgWidth:0
[2024/8/7 9:03:17 513]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:03:17 513] [CFG]: Rule:0 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:03:17 528] [CFG]: Rule:1 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:03:17 528] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:03:17 529] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:03:17 544] [CFG]: DEFAULT iBoundaryPtsNum 4 eAlarmDirect 2 (0 0) (8191 0) (8191 8191) (0 8191)
[2024/8/7 9:03:17 545] [FUNC:PbdcnnConfig][L:578] (nil) 0xbefe02f8 Pointer Null.
[2024/8/7 9:03:17 545] [INIT]: PdConfig pvHandle 0xb1292000. Config OK
[2024/8/7 9:03:17 545] [INIT] Alg Malloc Size 30000
[2024/8/7 9:03:17 560] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:03:17 561] [INIT]:memPoolSize 1351680.
[2024/8/7 9:03:17 561] V1.6.x date Sep  5 2023, time 23:32:25 npu load start
[2024/8/7 9:03:17 576] dpu version v1.1.0 build time Aug  5 2022
[2024/8/7 9:03:17 576] [INIT]: Update MemPoolSize 0 to 1351680.
[2024/8/7 9:03:17 576] [INIT]: MmzAlloc MemPoolSize 1351680 0xb10d0000~0xb121a000.
[2024/8/7 9:03:17 592] 0 Model 0x1352d9c MemPoolIdx 0 MemPoolInfo 0x6d5f10
[2024/8/7 9:03:17 592] [INIT]: version 20230719_person_noexp_v200, debug 0, profile 0
[2024/8/7 9:03:17 592] [INIT] Alg Malloc Size 240736
[2024/8/7 9:03:17 592] CNNMemory: 2064977 bulk 240736 mmz 1824241
[2024/8/7 9:03:17 609] CNNINIT INPUT IMAGESIZE:(640,224)
[2024/8/7 9:03:17 609] TD_DETECT stAlgImgSize (640,224) 
[2024/8/7 9:03:17 609] [INIT] Alg Malloc Size 60672
[2024/8/7 9:03:17 609] MdInit ok![INIT] Alg Malloc Size 79704
[2024/8/7 9:03:17 609] [FUNC: trackInit][L: 273] API_Creat_IMG 
[2024/8/7 9:03:17 625] [INIT]: PdInit pvHandle 0x1352be0 *pvHandle 0xb1292000 OK
[2024/8/7 9:03:17 625] IA_LOG 87c6a000 value 0
[2024/8/7 9:03:17 625] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:03:17 625] Ped_Init_IA_Work end 
[2024/8/7 9:03:17 640] src/ped_thread.c(774) [Smart_Ped_Create]: Create list success, index 1 maxsize 2
[2024/8/7 9:03:17 640] src/ped_thread.c(495) [PedProc_v2]: 
[2024/8/7 9:03:17 640] src/ped_thread.c(520) [PedProc_v2]: 
[2024/8/7 9:03:17 640] [FUNC: DetectTarget][L: 1489] API_Creat_IMG_MdInImg 
[2024/8/7 9:03:17 656] [FUNC: PbdcnnWork][L: 1084] API_Creat_CSCIMG 
[2024/8/7 9:03:17 656] [1970-01-01 00:00:10] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:03:17 672] [1970-01-01 00:00:10] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:03:17 672] src/ped_thread.c(803) [Smart_Ped_Create]: Ped_Creat Success @0x39e24
[2024/8/7 9:03:17 689] [1970-01-01 00:00:10] xm_ai.c(649) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:03:17 705] [1970-01-01 00:00:10] xm_ai.c(657) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:10] xm_ai.c(658) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTime = [8];-- TD CFG --  
[2024/8/7 9:03:17 721]  iMDFlag: 0
[2024/8/7 9:03:17 721]  ucDetectDisable: 0
[2024/8/7 9:03:17 721]  iDetectType: 5
[2024/8/7 9:03:17 721]  ePattern: 3
[2024/8/7 9:03:17 721]  eSensitivity: 0
[2024/8/7 9:03:17 721]  ucFishEyeCorrectFlag:0
[2024/8/7 9:03:17 721]  eRotate:0
[2024/8/7 9:03:17 721]  ucSationaryTd: 0
[2024/8/7 9:03:17 721]  ucClearnessFlg:0
[2024/8/7 9:03:17 721]  usInImgWidth:0
[2024/8/7 9:03:17 737]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:03:17 737] [CFG]: Rule:0 ucRuleEnable:1 AlarmType:0 eRuleType:1
[2024/8/7 9:03:17 753] [CFG]: IA_PERIMETER_V1 iBoundaryPtsNum 4 eAlarmDirect 0 (0 0) (8191 0) (8191 8191) (0 8191) [CFG]: Rule:1 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:03:17 753] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:03:17 753] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:03:17 769] [INIT]: PdConfig pvHandle 0xb1292000. Config OK
[2024/8/7 9:03:17 769] IA_LOG 87c6a000 value 0
[2024/8/7 9:03:17 769] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:03:17 769] src/ped_thread.c(831) [Smart_Ped_SetParam[MMZ] BUILD TIME:[Jul 14 2021 15:42:31]
[2024/8/7 9:03:17 769] [0x83400000--------0x88000000]
[2024/8/7 9:03:17 785] --START-----------SIZE----------------OVERFLOW----NAME---------------
[2024/8/7 9:03:17 785] 0x83400000	0xbde000  (12152k)	0	vb[bdd800][0]
[2024/8/7 9:03:17 785] 0x83fde000	0xbde000  (12152k)	0	vb[bdd800][1]
[2024/8/7 9:03:17 801] 0x84bbc000	0xbde000  (12152k)	0	vb[bdd800][2]
[2024/8/7 9:03:17 801] 0x8579a000	0x55000   (  340k)	0	vb[54600][0]
[2024/8/7 9:03:17 801] 0x857ef000	0x55000   (  340k)	0	vb[54600][1]
[2024/8/7 9:03:17 801] 0x85844000	0x35000   (  212k)	0	vb[34800][0]
[2024/8/7 9:03:17 817] 0x85879000	0x35000   (  212k)	0	vb[34800][1]
[2024/8/7 9:03:17 817] 0x858ae000	0x24000   (  144k)	0	isp_nr_alpha_ch0
[2024/8/7 9:03:17 817] 0x858d2000	0x163000  ( 1420k)	0	isp_nr_idx_ch0
[2024/8/7 9:03:17 817] 0x85a35000	0x1000    (    4k)	0	isp_nr_idx_max_ch0
[2024/8/7 9:03:17 832] 0x85a36000	0x84f000  ( 8508k)	0	isp_nr_fetch_ch0
[2024/8/7 9:03:17 832] 0x86285000	0x2000    (    8k)	0	isp_defog_ch0
[2024/8/7 9:03:17 833] 0x86287000	0xc24000  (12432k)	0	vencRfcFrame[0]
[2024/8/7 9:03:17 849] 0x86eab000	0xc24000  (12432k)	0	vencRfcFrame[1]
[2024/8/7 9:03:17 849] 0x87acf000	0xf1000   (  964k)	0	stream_chn[0]
[2024/8/7 9:03:17 849] 0x87bc0000	0x4c000   (  304k)	0	vencWrapLuma[0]
[2024/8/7 9:03:17 849] 0x87c0c000	0x26000   (  152k)	0	vencWrapChroma[0]
[2024/8/7 9:03:17 865] 0x87c32000	0xb000    (   44k)	0	stream_chn[1]
[2024/8/7 9:03:17 865] 0x87c3d000	0x2b000   (  172k)	0	stream_chn[3]
[2024/8/7 9:03:17 865] 0x87c68000	0x1000    (    4k)	0	osd_block[0]
[2024/8/7 9:03:17 865] 0x87c69000	0x1000    (    4k)	0	osd_block[4]
[2024/8/7 9:03:17 881] 0x87c6a000	0x1000    (    4k)	0	IA_LOG
[2024/8/7 9:03:17 881] 0x87c6b000	0x7000    (   28k)	0	IA_MANAGE_1
[2024/8/7 9:03:17 881] 0x87c72000	0x8000    (   32k)	0	IA_MANAGE_2
[2024/8/7 9:03:17 881] 0x87c7a000	0x70000   (  448k)	0	firm_mem_0
[2024/8/7 9:03:17 898] 0x87cea000	0x14b000  ( 1324k)	0	mempool_1
[2024/8/7 9:03:17 899] 0x87e35000	0x1000    (    4k)	0	dst_mem_1
[2024/8/7 9:03:17 899] 0x87e36000	0x1000    (    4k)	0	dst_mem_2
[2024/8/7 9:03:17 899] 0x87e37000	0x3000    (   12k)	0	dst_mem_3
[2024/8/7 9:03:17 900] 0x87e3a000	0x1000    (    4k)	0	dst_mem_4
[2024/8/7 9:03:17 915] 0x87e3b000	0x14000   (   80k)	0	IA_MANAGE_3
[2024/8/7 9:03:17 915] 0x87e4f000	0x35000   (  212k)	0	IA_Image_1
[2024/8/7 9:03:17 915] 0x87e84000	0x6a000   (  424k)	0	IA_Image_2
[2024/8/7 9:03:17 915] 0x87eee000	0x112000  ( 1096k)	1	
[2024/8/7 9:03:17 929] ---------------------------------------------------------------------
[2024/8/7 9:03:17 929] SIZE: 0x4c00000(77824k)  USED: 0x4aee000(76728k)  FREE: 0x112000(1096k)
[2024/8/7 9:03:17 929] ]: Ped_SetParam Success
[2024/8/7 9:03:17 945] [1970-01-01 00:00:10] xm_ai.c(666) <XM_CreatePersionDetect>: 
[2024/8/7 9:03:17 945] [1970-01-01 00:00:10] xm_ai.c(674) <XM_CreatePersionDetect>: 
[2024/8/7 9:03:17 945] [1970-01-01 00:00:10] MainApp.c(1395) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:17 961] [1970-01-01 00:00:10] MainApp.c(1397) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:17 961] [1970-01-01 00:00:10] MainApp.c(1402) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:17 977] [1970-01-01 00:00:10] MainApp.c(1481) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:17 977] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 60 enable 0 volume
[2024/8/7 9:03:17 993] [1970-01-01 00:00:10] MainApp.c(1525) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:17 993]  PTZPreset is empty!
[2024/8/7 9:03:18 009] [1970-01-01 00:00:10] MainApp.c(1554) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:18 009] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:03:18 025] [1970-01-01 00:00:10] MainApp.c(1568) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:18 025] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:03:18 040] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:03:18 041] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:03:18 057] [1970-01-01 00:00:10] MainApp.c(1584) <GetAndSetTyDefalutConfig>: cruisetime_pro create!
[2024/8/7 9:03:18 057] [1970-01-01 00:00:10] MainApp.c(1607) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:03:18 057] [1970-01-01 00:00:10] MainApp.c(1925) <main>: 
[2024/8/7 9:03:18 073] [1970-01-01 00:00:10] MainApp.c(1116) <GetRegisterMode>: -------- register mode 1
[2024/8/7 9:03:18 073] [1970-01-01 00:00:10] MainApp.c(1927) <main>: 
[2024/8/7 9:03:18 088] [1970-01-01 00:00:10] MainApp.c(1930) <main>: 
[2024/8/7 9:03:18 088] *************
[2024/8/7 9:03:18 088]  0x6d123c 
[2024/8/7 9:03:18 088] *****************
[2024/8/7 9:03:18 088]  0x3287c 
[2024/8/7 9:03:18 089] beginend[1970-01-01 00:00:10] MainApp.c(1938) <main>: 
[2024/8/7 9:03:18 104] [1970-01-01 00:00:10] MainApp.c(866) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:03:18 120] [1970-01-01 00:00:10] MainApp.c(174) <GetDeviceHWInfo>: Get Hwinfo APP_ID [fvijo8jvloagv1gm], UUID[uuidcaab27b0a838d239] AUTHKEY [j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:03:18 121] [1970-01-01 00:00:10] MainApp.c(909) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:03:18 136] [1970-01-01 00:00:10] MainApp.c(942) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:03:18 136] [1970-01-01 00:00:10] MainApp.c(986) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:03:18 136] [1970-01-01 00:00:10] MainApp.c(1019) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:03:18 136] sdk start
[2024/8/7 9:03:18 152] [1970-01-01 00:00:10] MainApp.c(752) <tuya_ipc_sdk_start>: log_level 0[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/mtd/Config/ty/ 
[2024/8/7 9:03:18 169] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/mtd/Config/ty/
[2024/8/7 9:03:18 169] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/mtd/Config/ty/
[2024/8/7 9:03:18 169] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[2024/8/7 9:03:18 185] [01-01 18:12:15 TUYA D][simplekv.c:989] both file not exist /mnt/mtd/Config/ty/tuya_user.db
[2024/8/7 9:03:18 185] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[2024/8/7 9:03:18 201] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[2024/8/7 9:03:18 201] [01-01 18:12:15 TUYA D][simplekv.c:1083] init NEW normal file
[2024/8/7 9:03:18 201] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 3536627844
[2024/8/7 9:03:18 217] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:18 233] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[2024/8/7 9:03:18 233] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[2024/8/7 9:03:18 233] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[2024/8/7 9:03:18 249] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[2024/8/7 9:03:18 249] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[2024/8/7 9:03:18 265] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[2024/8/7 9:03:18 265] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[2024/8/7 9:03:18 265] [01-01 18:12:15 TUYA E][log_seq.c:863] open err
[2024/8/7 9:03:18 281] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[2024/8/7 9:03:18 281] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[2024/8/7 9:03:18 297] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[2024/8/7 9:03:18 297] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:03:18 313] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:18 313] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:18 313] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:18 329] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:03:18 329] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:03:18 329] [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
[2024/8/7 9:03:18 345] [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:03:18 345] dev id key: 16
[2024/8/7 9:03:18 360] d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[2024/8/7 9:03:18 361] --- tracepoint bt_ext_porting.c,tuya_ext_bt_port_init(464): tuya_ext_bt_port_init ---
[2024/8/7 9:03:18 377] [01-01 18:12:15 TUYA I][bt_ext_porting.c:466] [TUYA-BTUART]tuya ext bt port init
[2024/8/7 9:03:18 377] --- tracepoint bt_uart_drv.c,tuya_bt_uart_open(187): tuya_bt_uart_open ---
[2024/8/7 9:03:18 393] --- tracepoint bt_uart_drv.c,tuya_bt_uart_init(60): tuya_bt_uart_init  0 ---
[2024/8/7 9:03:18 393] [01-01 18:12:15 TUYA I][bt_ext_porting.c:485] [TUYA-BTUART]thread ty_btext_thread create cplt mode 1
[2024/8/7 9:03:18 393] [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[2024/8/7 9:03:18 409] [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[2024/8/7 9:03:18 409] [01-01 18:12:15 TUYA N][tuya_bt_[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:03:18 424] sdk.c:141] ty bt sdk init success finish
[2024/8/7 9:03:18 425] [1970-01-01 00:00:10] MainApp.c(822) <tuya_ipc_sdk_start>: create ring buffer start 
[2024/8/7 9:03:18 425] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:0 Enable:1
[2024/8/7 9:03:18 441] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 2048, video_fps 12
[2024/8/7 9:03:18 441] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr0 bitrate:2048 fps:12
[2024/8/7 9:03:18 457] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 2621440 bytes for ch0st0tr0, max frame size 393216
[2024/8/7 9:03:18 457] --- t[atbm_log]:eth2:free authen bss ++
[2024/8/7 9:03:18 473] racepoint bt_ext_porting.c,ty_btext_thread(370):  ---
[2024/8/7 9:03:18 473] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[2024/8/7 9:03:18 489] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr0 size:2621440 nodes:120
[2024/8/7 9:03:18 489] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:0
[2024/8/7 9:03:18 489] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:1 Enable:1
[2024/8/7 9:03:18 505] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 1024, video_fps 12
[2024/8/7 9:03:18 505] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr1 bitrate:1024 fps:12
[2024/8/7 9:03:18 521] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1310720 bytes for ch0st0tr1, max frame size 196608
[2024/8/7 9:03:18 536] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr1 size:1310720 nodes:120
[2024/8/7 9:03:18 537] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:1
[2024/8/7 9:03:18 537] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:2 Enable:0
[2024/8/7 9:03:18 552] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:3 Enable:0
[2024/8/7 9:03:18 553] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:4 Enable:0
[2024/8/7 9:03:18 568] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:5 Enable:0
[2024/8/7 9:03:18 568] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:6 Enable:0
[2024/8/7 9:03:18 584] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:7 Enable:0
[2024/8/7 9:03:18 584] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:8 Enable:0
[2024/8/7 9:03:18 585] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:9 Enable:1
[2024/8/7 9:03:18 600] [01-01 18:12:15 TUYA D][MainApp.c:439] audio_sample 8000, audio_databits 16, audio_fps 25
[2024/8/7 9:03:18 601] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[2024/8/7 9:03:18 616] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[2024/8/7 9:03:18 632] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[2024/8/7 9:03:18 632] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:9
[2024/8/7 9:03:18 632] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:10 Enable:0
[2024/8/7 9:03:18 648] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:11 Enable:0
[2024/8/7 9:03:18 648] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:12 Enable:0
[2024/8/7 9:03:18 665] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:13 Enable:0
[2024/8/7 9:03:18 665] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:14 Enable:0
[2024/8/7 9:03:18 681] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:15 Enable:0
[2024/8/7 9:03:18 697] [1970-01-01 00:00:10] MainApp.c(830) <tuya_ipc_sdk_start>: pRunInfo->net_info.connect_mode 1[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:03:18 697] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:18 697] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:18 713] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:18 713] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:03:18 713] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base r[atbm_log]:[eth2] change to [3]
[2024/8/7 9:03:18 729] ead finish:-6
[2024/8/7 9:03:18 729] [atbm_log]:[eth2] has been disabled
[2024/8/7 9:03:18 729] [01-01 18:12:15 [atbm_log]:add iftype(6),if_cnt(2),flags(c24f5bf8)
[2024/8/7 9:03:18 729] TUYA D][ws_db_gw[atbm_log]:enable sg
[2024/8/7 9:03:18 745] .c:61] write buf[atbm_log]:[mon.eth2] has been disabled
[2024/8/7 9:03:18 761] :{"uuid":"uuidcaab27b0a838d239","psk_key":null,"auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:03:18 761] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:03:18 777] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:18 778] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:18 778] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:18 793] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:208
[2024/8/7 9:03:18 793] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 0 startpos:28700 size:276
[2024/8/7 9:03:18 809] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:03:18 809] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 1056267009
[2024/8/7 9:03:18 809] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:18 825] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:18 825] [01-01 18:12:15 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:03:18 841] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":0,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:03:18 841] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:03:18 857] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:18 857] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:18 857] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:18 873] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:03:18 873] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 1 startpos:28976 size:212
[2024/8/7 9:03:18 889] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:03:18 889] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2367317337
[2024/8/7 9:03:18 889] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:18 905] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:18 905] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:03:18 921] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[2024/8/7 9:03:18 921] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1776] Last reset reason: 255
[2024/8/7 9:03:18 921] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:03:18 937] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:03:18 937] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:03:18 937] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:03:18 953] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:18 953] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:18 969] [01-01 18:12:15 TUYA D][si[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:03:18 969] mplekv.c:1294] _[atbm_log]:[WSM] Drop frame
[2024/8/7 9:03:18 969] _read_kv_raw fail. -3
[2024/8/7 9:03:18 969] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:18 985] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:18 985] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:03:19 001] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1140] serial_no:90314ba51650
[2024/8/7 9:03:19 001] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 001] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:03:19 016] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:03:19 017] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[2024/8/7 9:03:19 017] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1171] gw_cntl.gw_wsm.stat:0
[2024/8/7 9:03:19 032] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1347] gw_cntl->gw_wsm.nc_tp:0
[2024/8/7 9:03:19 032] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1348] gw_cntl->gw_wsm.md:0
[2024/8/7 9:03:19 048] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1362] wifi config method not fit
[2024/8/7 9:03:19 048] [01-01 18:12:15 TUYA E][tuya_devos_entry.c:1787] ret:[atbm_log]:[eth2] start driver he ap
[2024/8/7 9:03:19 048] -2
[2024/8/7 9:03:19 048] [01-01 18:1[atbm_log]:BSS_CHANGED_BEACON
[2024/8/7 9:03:19 065] 2:15 TUYA D][tuy[atbm_log]:change ds_params channel 6 
[2024/8/7 9:03:19 065] a_devos_entry.c:1808] enter reset factory
[2024/8/7 9:03:19 065] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 081] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:19 081] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:19 081] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:19 097] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_di -6
[2024/8/7 9:03:19 097] [01-01 18:12:15 TUYA E][ws_db_gw.c:494] gw_di read fail:-6
[2024/8/7 9:03:19 112] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 112] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:19 112] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:19 128] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:19 128] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_di And Value Len:400
[2024/8/7 9:03:19 128] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 2 startpos:29188 size:468
[2024/8/7 9:03:19 144] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:03:19 144] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 876692212
[2024/8/7 9:03:19 160] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:19 160] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:19 160] [01-01 18:12:15 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:03:19 176] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:593] nc_tp:2, wifi_start_mode:0
[2024/8/7 9:03:19 176] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 176] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:19 192] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:19 192] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:19 208] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:wf_start_md And Value Len:16
[2024/8/7 9:03:19 208] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 3 startpos:29656 size:84
[2024/8/7 9:03:19 225] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:03:19 225] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 411742493
[2024/8/7 9:03:19 225] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:19 240] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:19 257] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:03:19 257] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 257] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:03:19 273] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:03:19 273] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:03:19 289] [01-01 18:12:15 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:03:19 289] [01-01 18:12:15 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:03:19 289] [01-01 18:12:15 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:03:19 305] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4146866774
[2024/8/7 9:03:19 305] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:19 305] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:19 321] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:03:19 321] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 321] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:19 337] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:19 337] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:19 353] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6
[2024/8/7 9:03:19 353] [01-01 18:12:15 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6
[2024/8/7 9:03:19 353] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 369] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:19 369] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:19 369] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:19 385] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:368
[2024/8/7 9:03:19 385] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 4 startpos:29740 size:436
[2024/8/7 9:03:19 401] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:03:19 401] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 216605884
[2024/8/7 9:03:19 401] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:19 417] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:19 417] [01-01 18:12:15 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:03:19 417] [01-01 18:12:15 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:03:19 433] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 433] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:19 433] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:19 449] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:19 449] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:03:19 465] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 5 startpos:30176 size:84
[2024/8/7 9:03:19 465] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:03:19 481] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4220141073
[2024/8/7 9:03:19 481] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:19 481] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:19 497] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 497] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:19 497] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:19 513] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:19 513] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:03:19 529] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 6 startpos:30260 size:84
[2024/8/7 9:03:19 529] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:03:19 529] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 860452950
[2024/8/7 9:03:19 545] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:19 545] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:19 561] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:03:19 562] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:19 562] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:19 576] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:19 576] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:03:19 576] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 7 startpos:30344 size:84
[2024/8/7 9:03:19 592] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:03:19 593] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2541358761
[2024/8/7 9:03:19 608] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:03:19 609] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:03:19 609] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[2024/8/7 9:03:19 624] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[2024/8/7 9:03:19 640] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[2024/8/7 9:03:19 640] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[2024/8/7 9:03:19 641] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[2024/8/7 9:03:19 656] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[2024/8/7 9:03:19 656] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[2024/8/7 9:03:19 656] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[2024/8/7 9:03:19 672] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[2024/8/7 9:03:19 672] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[2024/8/7 9:03:19 672] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[2024/8/7 9:03:19 688] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[2024/8/7 9:03:19 689] [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[2024/8/7 9:03:19 705] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[2024/8/7 9:03:19 737] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}
[2024/8/7 9:03:19 737] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:116] sys add timer: 14
[2024/8/7 9:03:19 737] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:122] sys start timer: 14
[2024/8/7 9:03:19 753] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[2024/8/7 9:03:19 753] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[2024/8/7 9:03:19 753] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[2024/8/7 9:03:19 768] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[2024/8/7 9:03:19 769] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:fvijo8jvloagv1gm 0
[2024/8/7 9:03:19 769] uuid: 20
[2024/8/7 9:03:19 769] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:03:19 784] dev_id_tmp: 16
[2024/8/7 9:03:19 784] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:03:19 785] dev_id_tmp2: 20
[2024/8/7 9:03:19 785] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:03:19 800] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:03:19 816] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1066] nc_tp:2, md:0
[2024/8/7 9:03:19 816] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1297] dev_nw_cfg_active_stage:2
[2024/8/7 9:03:19 832] [01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[2024/8/7 9:03:19 832] [1970-01-01 00:00:11] MainApp.c(838) <tuya_ipc_sdk_start>: [01-01 18:12:15 TUYA D][MainApp.c:854] tuya ipc sdk start is complete
[2024/8/7 9:03:19 848] [1970-01-01 00:00:11] MainApp.c(1028) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:03:19 848] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:03:19 864] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:03:19 864] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:03:19 864] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[2024/8/7 9:03:19 882] killall: hostapd: no process killed
[2024/8/7 9:03:19 882] route: netmask and route address conflict
[2024/8/7 9:03:19 882] [1970-01-01 00:00:11] MainApp.c(1053) <TUYA_IPC_SDK_START>: pthread_create BasicIndicatorTimer suc
[2024/8/7 9:03:19 897] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [0] change to [1]
[2024/8/7 9:03:19 897] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [0] change to [1]
[2024/8/7 9:03:19 913] 
[2024/8/7 9:03:19 914] [1970-01-01 00:00:11] MainApp.c(1968) <main>: FLIP
[2024/8/7 9:03:19 914] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [1] change to [0]
[2024/8/7 9:03:19 929] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [1] change to [0]
[2024/8/7 9:03:19 929] [1970-01-01 00:00:11] MainApp.c(1972) <main>: FLIP
[2024/8/7 9:03:19 945] [1970-01-01 00:00:11] MainApp.c(1622) <PostInit>: 
[2024/8/7 9:03:19 945] src/intelligent_track_thread.c(1398) [XM_SmartBodyTarckCreate]: 
[2024/8/7 9:03:19 961] src/intelligent_track_thread.c(1374) [Smart_Track_GetAbility]: 
[2024/8/7 9:03:19 962] src/intelligent_track_thread.c(1379) [Smart_Track_GetAbility]: 
[2024/8/7 9:03:19 962] src/intelligent_track_thread.c(1272) [GetMotorCtrlPara]: 
[2024/8/7 9:03:19 977] src/intelligent_track_thread.c(1277) [GetMotorCtrlPara]: 
[2024/8/7 9:03:19 977] src/intelligent_track_thread.c(1283) [GetMotorCtrlPara]: 
[2024/8/7 9:03:19 993] src/intelligent_track_thread.c(1298) [GetMotorCtrlPara]: max_steps_x=5006 ,max_steps_y=2161
[2024/8/7 9:03:19 993] src/intelligent_track_thread.c(1301) [GetMotorCtrlPara]: 
[2024/8/7 9:03:19 993] src/intelligent_track_thread.c(1307) [GetMotorCtrlPara]: 
[2024/8/7 9:03:20 009] src/intelligent_track_thread.c(1323) [GetMotorCtrlPara]: 
[2024/8/7 9:03:20 009] src/intelligent_track_thread.c(1336) [GetMotorCtrlPara]: track_default_degrees_y=95
[2024/8/7 9:03:20 025] src/intelligent_track_thread.c(1345) [GetMotorCtrlPara]: LoadTrackSet Motor_x_turnover:no
[2024/8/7 9:03:20 025] src/intelligent_track_thread.c(1346) [GetMotorCtrlPara]: LoadTrackSet Motor_y_turnover:no
[2024/8/7 9:03:20 041] src/intelligent_track_thread.c(1348) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 540
[2024/8/7 9:03:20 057] src/intelligent_track_thread.c(1367) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 400
[2024/8/7 9:03:20 057] src/intelligent_track_thread.c(1368) [GetMotorCtrlPara]: LoadTrackSet HEIGHT_STEP = 200
[2024/8/7 9:03:20 073] src/intelligent_track_thread.c(1390) [Smart_Track_GetAbility]: Track_Ability : Enable
[2024/8/7 9:03:20 073] src/intelligent_track_thread.c(1451) [XM_SmartBodyTarckCreate]: Intelligent Track_pthread create Success 1920x1080
[2024/8/7 9:03:20 088] [1970-01-01 00:00:11] MainApp.c(277) <BasicIndicatorTimer>: BasicIndicatorTimer start ----
[2024/8/7 9:03:20 088] src/intelligent_track_thread.c(667) [TrackProcV200]: 
[2024/8/7 9:03:20 104] [1970-01-01 00:00:11] MainApp.c(1640) <PostInit>: ln -s /mnt/mtd/Log/sofia.log /tmp/tuya.log
[2024/8/7 9:03:20 104] [1970-01-01 00:00:11] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:03:20 120] [1970-01-01 00:00:11] MainApp.c(1665) <PostInit>: MotionDetect Sensitive 1 set onvif_on_off:0 
[2024/8/7 9:03:20 121] [1970-01-01 00:00:12] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time12301
[2024/8/7 9:03:20 136] [1970-01-01 00:00:12] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 114029
[2024/8/7 9:03:20 136] curr event:3 
[2024/8/7 9:03:20 152] IPC_APP_Notify_LED_Sound_Status_CB line(480) -------------------------- IPC_START_WIFI_AP_CFG(3)
[2024/8/7 9:03:20 152] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-1650
[2024/8/7 9:03:20 152] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:03:20 168] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:03:20 168] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:03:20 168] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:03:20 184] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:03:20 184] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:03:20 200] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[2024/8/7 9:03:20 200] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[2024/8/7 9:03:20 216] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[2024/8/7 9:03:20 216] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:03:20 216] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:03:20 232] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:03:20 232] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:20 232] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:20 248] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:20 248] [01-01 18:12:16 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:03:20 264] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:03:20 264] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:20 264] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:20 280] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:20 280] [01-01 18:12:16 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:03:20 296] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:03:20 296] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:20 296] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:20 312] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:20 312] [01-01 18:12:16 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:03:20 328] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[2024/8/7 9:03:20 328] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:03:20 344] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:2  -->>
[2024/8/7 9:03:20 344] __IPC_APP_Get_Net_Status_cb line(193) -------------------------- stat(2)==STAT_AP_STA_UNCFG 
[2024/8/7 9:03:20 361] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:2  <<--
[2024/8/7 9:03:20 362] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:03:20 362] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:03:20 377] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:03:20 377] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:20 393] [01-01 18:12:16 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:20 393] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[2024/8/7 9:03:20 409] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:21504,priority:5
[2024/8/7 9:03:20 409] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[2024/8/7 9:03:20 425] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[2024/8/7 9:03:20 425] [01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt netcfg start
[2024/8/7 9:03:20 425] [01-01 18:12:16 TUYA N][tuya_ble_api.c:439] update bound stat:0
[2024/8/7 9:03:20 442] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[2024/8/7 9:03:20 442] [01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:03:20 442] dev id key: 16
[2024/8/7 9:03:20 442] d0 7d 89 57 d1 c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 9:03:20 458] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:03:20 458] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:03:20 458] udhcpd (v1.22.1) started
[2024/8/7 9:03:20 474] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:03:20 474] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:03:20 491] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:03:20 491] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:03:20 491] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 9:03:20 506] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0x13d6c88),len(28)
[2024/8/7 9:03:20 506] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 9:03:20 522] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:03:20 522] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0x13d70b0),len(30)
[2024/8/7 9:03:20 617] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 9:03:20 617] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:03:20 617] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 9:03:20 633]  ---
[2024/8/7 9:03:20 634] adv_len:28
[2024/8/7 9:03:20 634] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:03:20 634] svc_data_uuid16 len:18
[2024/8/7 9:03:20 649] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 9:03:20 649] [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 9:03:20 665] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[2024/8/7 9:03:20 665] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:20 665] ---[XmBleAdvertiseEx][1210]: rc=[0]
[2024/8/7 9:03:20 681] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 9:03:20 681] rsp_len:30
[2024/8/7 9:03:20 681] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:03:20 681] mfg_data len:30
[2024/8/7 9:03:20 696] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 9:03:20 697] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 9:03:20 697] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 9:03:20 697] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:20 713] ---[XmBleAdvertiseEx][1241]: rc=[0]
[2024/8/7 9:03:20 713] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 9:03:20 713] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 9:03:20 729] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:20 729] adv_start rc = 0x0
[2024/8/7 9:03:20 744] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 9:03:20 745] [01-01 18:12:16 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:03:20 745] [01-01 18:12:16 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:20 760] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:20 760] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:20 776] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:20 776] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:20 776] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:20 792] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:20 792] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:20 792] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:20 808] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:20 808] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:20 824] [01-01 18:12:16 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:20 824] [01-01 18:12:16 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:20 824] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:20 856] [01-01 18:12:16 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:20 856] [01-01 18:12:16 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:20 873] [01-01 18:12:16 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:20 873] [01-01 18:12:16 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:20 873] gethostbyname_r error: Unknown host
[2024/8/7 9:03:20 889] [01-01 18:12:16 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:20 889] [01-01 18:12:16 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:20 905] [01-01 18:12:16 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:20 905] [01-01 18:12:16 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:20 921] [01-01 18:12:16 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:20 921] [01-01 18:12:16 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:20 937] [01-01 18:12:16 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:20 937] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:20 937] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:03:20 953] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:20 969] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:20 969] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:03:20 985] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:20 985] [01-01 18:12:17 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:21 000] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:21 001] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:03:21 016] [01-01 18:12:17 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:03:21 016] [01-01 18:12:17 TUYA D][tuya_ble_api.c:1470] ble get conn stat:4
[2024/8/7 9:03:21 017] [01-01 18:12:17 TUYA N][tuya_ble_api.c:750] ble_sdk_send skip, no connect:4
[2024/8/7 9:03:21 032] [1970-01-01 00:00:13] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:03:21 048] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:21 051] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:21 051] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:21 065] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:21 065] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:21 065] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:21 080] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:21 080] [01-01 18:12:17 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:21 096] [01-01 18:12:17 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:21 097] [01-01 18:12:17 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:21 097] [01-01 18:12:17 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:21 112] [01-01 18:12:17 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:21 112] [01-01 18:12:17 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:21 128] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:21 144] [01-01 18:12:17 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:21 144] [01-01 18:12:17 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:21 160] [01-01 18:12:17 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:21 160] [01-01 18:12:17 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:21 176] gethostbyname_r error: Unknown host
[2024/8/7 9:03:21 176] [01-01 18:12:17 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:21 176] [01-01 18:12:17 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:21 192] [01-01 18:12:17 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:21 192] [01-01 18:12:17 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:21 208] [01-01 18:12:17 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:21 208] [01-01 18:12:17 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:21 224] [01-01 18:12:17 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:21 224] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:21 240] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:21 256] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:21 256] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:21 272] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:21 272] [01-01 18:12:18 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:21 449] [1970-01-01 00:00:14] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:21 465] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:21 465] [01-01 18:12:18 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:21 465] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:21 480] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:21 481] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:21 497] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:21 497] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:21 497] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:21 512] [01-01 18:12:18 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:21 512] [01-01 18:12:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:21 513] [01-01 18:12:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:21 528] [01-01 18:12:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:21 528] [01-01 18:12:18 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:21 544] [01-01 18:12:18 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:21 544] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:21 560] [01-01 18:12:18 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:21 576] [01-01 18:12:18 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:21 576] [01-01 18:12:18 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:21 592] [01-01 18:12:18 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:21 592] gethostbyname_r error: Unknown host
[2024/8/7 9:03:21 592] [01-01 18:12:18 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:21 608] [01-01 18:12:18 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:21 608] [01-01 18:12:18 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:21 624] [01-01 18:12:18 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:21 624] [01-01 18:12:18 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:21 640] [01-01 18:12:18 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:21 640] [01-01 18:12:18 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:21 656] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:22 041] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:22 041] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:22 057] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:03:22 057] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:22 073] [01-01 18:12:19 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:22 169] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:22 184] [01-01 18:12:19 TUYA D][tuya_ble_api.c:1376] nw stat change:0->1, rpt to app.
[2024/8/7 9:03:22 185] [01-01 18:12:19 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:03:22 472] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:22 472] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:22 472] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:22 488] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:22 488] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:22 504] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:22 504] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:22 504] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:22 520] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:22 520] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:22 520] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:22 537] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:22 537] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:22 553] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:22 553] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:22 569] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:22 585] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:22 585] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:22 601] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:22 601] gethostbyname_r error: Unknown host
[2024/8/7 9:03:22 601] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:22 617] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:22 617] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:22 633] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:22 633] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:22 649] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:22 649] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:22 665] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:23 048] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:23 064] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:23 064] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:23 080] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:23 480] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:23 496] [1970-01-01 00:00:16] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:03:23 496] [1970-01-01 00:00:16] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:23 513] [1970-01-01 00:00:16] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time16628
[2024/8/7 9:03:23 513] [01-01 18:12:21 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:23 529] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:23 529] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:23 529] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:23 545] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:23 545] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:23 561] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:23 562] [01-01 18:12:21 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:23 562] [01-01 18:12:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:23 577] [01-01 18:12:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:23 577] [01-01 18:12:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:23 577] [01-01 18:12:21 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:23 593] [01-01 18:12:21 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:23 593] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:23 625] [01-01 18:12:21 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:23 625] [01-01 18:12:21 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:23 641] [01-01 18:12:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:23 641] [01-01 18:12:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:23 641] gethostbyname_r error: Unknown host
[2024/8/7 9:03:23 657] [01-01 18:12:21 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:23 657] [01-01 18:12:21 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:23 673] [01-01 18:12:21 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:23 673] [01-01 18:12:21 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:23 673] [01-01 18:12:21 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:23 689] [01-01 18:12:21 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:23 689] [01-01 18:12:21 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:23 705] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:23 881] motor auto test over
[2024/8/7 9:03:23 881] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 9:03:23 881] action=idle
[2024/8/7 9:03:23 881] dir=
[2024/8/7 9:03:23 881] flag=|auto-test-cmplt
[2024/8/7 9:03:23 897]  steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 9:03:23 897] YYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 9:03:23 897] action=idle
[2024/8/7 9:03:23 897] dir=
[2024/8/7 9:03:23 897] flag=
[2024/8/7 9:03:23 897]  steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 9:03:24 105] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:24 121] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:24 121] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:03:24 137] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:24 137] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:24 153] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:24 153] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:03:24 169] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:03:24 552] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:24 568] [01-01 18:12:22 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:24 568] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:24 568] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:24 584] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:24 584] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:24 584] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:24 600] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:24 600] [01-01 18:12:22 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:24 616] [01-01 18:12:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:24 616] [01-01 18:12:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:24 616] [01-01 18:12:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:24 632] [01-01 18:12:22 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:24 632] [01-01 18:12:22 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:24 648] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:24 664] [01-01 18:12:22 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:24 664] [01-01 18:12:22 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:24 680] [01-01 18:12:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:24 680] [01-01 18:12:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:24 697] gethostbyname_r error: Unknown host
[2024/8/7 9:03:24 697] [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:24 697] [01-01 18:12:22 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:24 713] [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:24 713] [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:24 729] [01-01 18:12:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:24 729] [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:24 745] [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:24 745] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:24 745] [01-01 18:12:22 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:03:25 097] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:25 112] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:25 112] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:25 128] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:25 688] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:25 688] [1970-01-01 00:00:18] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:25 704] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:25 720] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:25 722] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:25 722] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:25 736] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:25 737] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:25 737] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:25 752] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:25 752] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:25 768] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:25 768] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:25 768] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:25 784] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:25 784] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:25 800] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:25 817] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:25 817] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:25 832] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:25 832] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:25 849] gethostbyname_r error: Unknown host
[2024/8/7 9:03:25 849] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:25 849] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:25 864] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:25 864] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:25 881] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:25 881] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:25 897] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:25 897] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:26 120] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:26 152] [1970-01-01 00:00:19] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17[1970-01-01 00:00:19] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 9:03:26 152] [1970-01-01 00:00:19] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 9:03:26 152] mpId[0] is [0].
[2024/8/7 9:03:26 152] mpId[1] is [0].
[2024/8/7 9:03:26 152] mpId[2] is [0].
[2024/8/7 9:03:26 152] mpId[3] is [0].
[2024/8/7 9:03:26 168] mpId[4] is [0].
[2024/8/7 9:03:26 168] mpId[5] is [0].
[2024/8/7 9:03:26 168] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:03:26 184] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:03:26 184] src/intelligent_track_thread.c(709) [TrackProcV200]: Intelligent Track Enable eSensitivity=0 intervalTime_sec=15
[2024/8/7 9:03:26 200] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:03:26 217] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:26 217] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:26 232] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:26 696] [1970-01-01 00:00:19] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:03:26 696] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:26 712] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:26 712] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:26 729] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:26 729] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:26 729] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:26 744] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:26 744] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:26 744] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:26 760] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:26 760] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:26 776] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:26 776] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:26 776] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:26 792] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:26 810] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:26 824] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:26 825] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:26 841] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:26 841] gethostbyname_r error: Unknown host
[2024/8/7 9:03:26 841] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:26 857] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:26 857] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:26 872] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:26 873] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:26 888] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:26 888] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:26 889] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:27 176] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:27 192] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:27 192] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:27 208] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:27 768] [1970-01-01 00:00:20] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:27 784] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:27 785] [1970-01-01 00:00:20] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time20705
[2024/8/7 9:03:27 800] [1970-01-01 00:00:20] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 117101
[2024/8/7 9:03:27 800] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:27 816] [01-01 18:12:25 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:27 816] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:27 832] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:27 832] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:27 832] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:27 848] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:27 848] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:27 864] [01-01 18:12:25 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:27 864] [01-01 18:12:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:27 864] [01-01 18:12:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:27 880] [01-01 18:12:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:27 880] [01-01 18:12:25 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:27 880] [01-01 18:12:25 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:27 896] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:27 912] [01-01 18:12:25 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:27 928] [01-01 18:12:25 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:27 928] [01-01 18:12:25 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:27 944] [01-01 18:12:25 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:27 944] gethostbyname_r error: Unknown host
[2024/8/7 9:03:27 944] [01-01 18:12:25 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:27 960] [01-01 18:12:25 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:27 960] [01-01 18:12:25 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:27 976] [01-01 18:12:25 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:27 976] [01-01 18:12:25 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:27 993] [01-01 18:12:25 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:27 993] [01-01 18:12:25 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:27 993] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:28 200] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:28 200] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:03:28 216] [01-01 18:12:25 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:03:28 792] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:28 808] [01-01 18:12:26 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:28 808] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:28 824] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:28 824] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:28 824] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:28 840] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:28 840] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:28 840] [01-01 18:12:26 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:28 856] [01-01 18:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:28 856] [01-01 18:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:28 872] [01-01 18:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:28 872] [01-01 18:12:26 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:28 872] [01-01 18:12:26 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:28 888] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:28 904] [01-01 18:12:26 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:28 920] [01-01 18:12:26 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:28 920] [01-01 18:12:26 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:28 936] [01-01 18:12:26 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:28 936] gethostbyname_r error: Unknown host
[2024/8/7 9:03:28 936] [01-01 18:12:26 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:28 952] [01-01 18:12:26 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:28 952] [01-01 18:12:26 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:28 968] [01-01 18:12:26 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:28 969] [01-01 18:12:26 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:28 984] [01-01 18:12:26 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:28 984] [01-01 18:12:26 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:28 984] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:29 177] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:03:29 192] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:29 209] [01-01 18:12:26 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:03:29 432] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:03:29 432] Mode(Product):0
[2024/8/7 9:03:29 432] BpuMode:[Online]
[2024/8/7 9:03:29 432] VpssMode:[Online]
[2024/8/7 9:03:29 432] [0.LimitUp_info]:
[2024/8/7 9:03:29 432] LimitUp:[Disable]
[2024/8/7 9:03:29 432] [2680*0]->[3840*0])
[2024/8/7 9:03:29 432] chn	TotalSize	ActiveSize
[2024/8/7 9:03:29 432] 0	5040*2246	2680*2160
[2024/8/7 9:03:29 448] 0	5040*2246	2680*2160
[2024/8/7 9:03:29 448] 0	5040*2246	3840*2160
[2024/8/7 9:03:29 448] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:03:29 448] [1.VICU_info]:
[2024/8/7 9:03:29 448] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:03:29 448] 0	25.0	367	0	0	183	linear	8ddb00
[2024/8/7 9:03:29 464] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:03:29 464] en	op_type	m_chn	now
[2024/8/7 9:03:29 464] 0	1	1	1
[2024/8/7 9:03:29 464] [2.VI_info]:
[2024/8/7 9:03:29 465] chn	TotalSize	ActiveSize
[2024/8/7 9:03:29 465] 0	5040*2246	3848*2166
[2024/8/7 9:03:29 465] 1	   0*   0	   0*   0
[2024/8/7 9:03:29 465] [3.MIPI_info]:
[2024/8/7 9:03:29 480] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:03:29 480] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:03:29 480] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:03:29 481] 
[2024/8/7 9:03:29 481] [4.Cut_info]:
[2024/8/7 9:03:29 496] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:03:29 496] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:03:29 496] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:03:29 496] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:03:29 497] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:03:29 512] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:03:29 512] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:03:29 512] [5.IB(isp buffer info)]:
[2024/8/7 9:03:29 512] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:03:29 513] PoolId  Count  Size
[2024/8/7 9:03:29 528] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:03:29 528] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:03:29 544] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:03:29 544] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:03:29 545] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:03:29 560] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:03:29 560] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:03:29 576] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:03:29 576] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:03:29 576] 0       0         0          0          4       
[2024/8/7 9:03:29 592] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:03:29 592]      --265--            --264--                                               
[2024/8/7 9:03:29 592] Count      Line     Count      Line     
[2024/8/7 9:03:29 592] 266        480      681        560      
[2024/8/7 9:03:29 608] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:03:29 608] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:03:29 624] 0   3840   2160    H265  0      0        0           158       976649     6391     	
[2024/8/7 9:03:29 624] 1   640    360     H265  0      0        0           104       43194      6        	
[2024/8/7 9:03:29 640] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:03:29 640] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:03:29 656] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:03:29 672] 0   Y      158      0       0       14       1        157      157      219       63865         58629    111411   64678    12      
[2024/8/7 9:03:29 672] 1   Y      104      0       4       1        0        104      104      221       2984          1882     19676    2665     7       
[2024/8/7 9:03:29 688] 3   N      0        0       0       1        0        0        0        221       0             0        0        0        0       
[2024/8/7 9:03:29 784] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:29 800] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:29 817] [1970-01-01 00:00:22] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:03:29 817] [1970-01-01 00:00:22] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:03:29 833] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:29 833] [01-01 18:12:27 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:29 849] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:29 849] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:29 849] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:29 864] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:29 864] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:29 880] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:29 880] [01-01 18:12:27 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:29 880] [01-01 18:12:27 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:29 897] [01-01 18:12:27 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:29 897] [01-01 18:12:27 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:29 912] [01-01 18:12:27 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:29 912] [01-01 18:12:27 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:29 912] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:29 944] [01-01 18:12:27 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:29 944] [01-01 18:12:27 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:29 960] [01-01 18:12:27 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:29 960] [01-01 18:12:27 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:29 960] gethostbyname_r error: Unknown host
[2024/8/7 9:03:29 976] [01-01 18:12:27 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:29 976] [01-01 18:12:27 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:29 992] [01-01 18:12:27 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:29 992] [01-01 18:12:27 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:30 008] [01-01 18:12:27 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:30 008] [01-01 18:12:27 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:30 008] [01-01 18:12:27 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:30 024] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:30 024] [01-01 18:12:27 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:03:30 808] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:30 824] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:30 840] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:30 840] [01-01 18:12:28 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:30 840] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:30 856] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:30 856] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:30 872] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:30 872] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:30 872] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:30 888] [01-01 18:12:28 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:30 888] [01-01 18:12:28 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:30 888] [01-01 18:12:28 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:30 904] [01-01 18:12:28 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:30 904] [01-01 18:12:28 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:30 920] [01-01 18:12:28 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:30 920] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:30 936] [01-01 18:12:28 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:30 952] [01-01 18:12:28 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:30 952] [01-01 18:12:28 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:30 968] [01-01 18:12:28 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:30 968] gethostbyname_r error: Unknown host
[2024/8/7 9:03:30 968] [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:30 984] 
[2024/8/7 9:03:30 985] [01-01 18:12:28 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:30 985] [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:31 000] [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:31 000] [01-01 18:12:28 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:31 016] [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:31 016] [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:31 032] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:31 849] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:31 864] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:31 865] [1970-01-01 00:00:24] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time24703
[2024/8/7 9:03:31 880] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:31 896] [01-01 18:12:29 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:31 896] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:31 896] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:31 911] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:31 911] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:31 928] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:31 928] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:31 928] [01-01 18:12:29 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:31 944] [01-01 18:12:29 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:31 944] [01-01 18:12:29 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:31 944] [01-01 18:12:29 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:31 959] [01-01 18:12:29 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:31 959] [01-01 18:12:29 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:31 975] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:31 991] [01-01 18:12:29 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:32 007] [01-01 18:12:29 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:32 007] [01-01 18:12:29 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:32 007] [01-01 18:12:29 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:32 023] gethostbyname_r error: Unknown host
[2024/8/7 9:03:32 023] [01-01 18:12:29 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:32 023] [01-01 18:12:29 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:32 039] [01-01 18:12:29 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:32 039] [01-01 18:12:29 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:32 055] [01-01 18:12:29 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:32 055] [01-01 18:12:29 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:32 071] [01-01 18:12:29 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:32 071] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:32 103] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:32 120] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 120] ble_slave_gap_event->type=0
[2024/8/7 9:03:32 120] connection established; status=0 GATT procedure initiated: exchange mtu
[2024/8/7 9:03:32 136] connection, handle=1
[2024/8/7 9:03:32 136] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 136] --- tracepoint bt_ext_porting.c,ty_btext_thread(423): TY_BT_EVENT_CONNECTED1 ---
[2024/8/7 9:03:32 152] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 1
[2024/8/7 9:03:32 152] [01-01 18:12:29 TUYA N][tuya_ble_api.c:472] Ble Connected
[2024/8/7 9:03:32 152] [01-01 18:12:29 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[2024/8/7 9:03:32 168] [01-01 18:12:29 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
[2024/8/7 9:03:32 856] --- tracepoint bt_ext_porting.c,ty_btext_thread(425): TY_BT_EVENT_CONNECTED2 ---
[2024/8/7 9:03:32 856] ble_slave_gap_event->type=15
[2024/8/7 9:03:32 856] mtu update event; conn_handle=1 cid=4 mtu=255
[2024/8/7 9:03:32 872] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 872] ble_slave_gap_event->type=4
[2024/8/7 9:03:32 872] connection update request
[2024/8/7 9:03:32 888] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 904] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:32 904] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 920] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 920] [1970-01-01 00:00:25] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:03:32 936] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 952] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:32 952] ble_slave_gap_event->type=3
[2024/8/7 9:03:32 968] connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:03:32 968] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 983] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:32 984] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:33 000] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:33 015] [01-01 18:12:30 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:33 016] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:33 016] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:33 032] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:33 032] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:33 048] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:33 049] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:33 049] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:33 064] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:33 064] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:33 064] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:33 079] [01-01 18:12:30 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:33 080] [01-01 18:12:30 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:33 095] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:33 112] [01-01 18:12:30 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:33 127] [01-01 18:12:30 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:33 128] [01-01 18:12:30 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:33 128] [01-01 18:12:30 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:33 143] gethostbyname_r error: Unknown host
[2024/8/7 9:03:33 143] [01-01 18:12:30 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:33 144] [01-01 18:12:30 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:33 159] [01-01 18:12:30 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:33 159] [01-01 18:12:30 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:33 175] [01-01 18:12:30 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:33 175] [01-01 18:12:30 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:33 191] [01-01 18:12:30 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:33 191] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:33 207] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:33 223] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:03:33 831] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:33 831] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:33 847] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:33 864] ble_slave_gap_event->type=4
[2024/8/7 9:03:33 864] connection update request
[2024/8/7 9:03:33 864] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:33 864] ble_slave_gap_event->type=14
[2024/8/7 9:03:33 879] subscribe event; conn_handle=1 attr_handle=23 reason=1 prevn=0 curn=1 previ=0 curi=0
[2024/8/7 9:03:33 879] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:03:33 895] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:33 895] set basic_indicator_onoff:0 
[2024/8/7 9:03:33 912] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(257) <IPC_APP_set_basic_indicator_onoff>: Get BasicIndicator suc,gpio value=[0x0c]
[2024/8/7 9:03:33 912] ble_slave_gap_event->type=3
[2024/8/7 9:03:33 912] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:03:33 928] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:33 928] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:33 944] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:33 960] set basic_indicator_onoff:1 
[2024/8/7 9:03:33 960] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:33 976] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:33 976] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:33 992] set basic_indicator_onoff:0 
[2024/8/7 9:03:33 992] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:34 008] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:34 008] set basic_indicator_onoff:1 
[2024/8/7 9:03:34 008] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:34 024] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:34 040] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:34 040] set basic_indicator_onoff:0 
[2024/8/7 9:03:34 040] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:34 056] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:34 056] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:34 056] Len=20 step 0
[2024/8/7 9:03:34 072] att=0x0 0x21 0x20 0x1 0xff 0x22 0x4c 0x3 0xa3 0x2e 0x2a 0xc5 0x92 0xf5 0xf6 0x63 0x81 0x98 0x7d 0xbb 
[2024/8/7 9:03:34 072]  RCVS len:20
[2024/8/7 9:03:34 072] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:34 088] XmBleReadBuf 20:
[2024/8/7 9:03:34 088] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:34 088] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:34 088] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:34 104] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:34 104] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:34 120] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:34 120] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:34 136] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:34 137] bt_rev_raw 20
[2024/8/7 9:03:34 137] 00 21 20 01 ff 22 4c 03 a3 2e 2a c5 92 f5 f6 63 81 98 7d bb 
[2024/8/7 9:03:34 152] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:03:34 152] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:34 152] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:34 168] set basic_indicator_onoff:1 
[2024/8/7 9:03:34 168] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:34 184] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:34 184] [01-01 18:12:31 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:34 200] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:34 200] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:34 200] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:34 216] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:34 216] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:34 216] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:34 232] [01-01 18:12:31 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:34 232] [01-01 18:12:31 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:34 248] [01-01 18:12:31 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:34 249] [01-01 18:12:31 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:34 249] [01-01 18:12:31 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:34 264] [01-01 18:12:31 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:34 264] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:34 296] [01-01 18:12:31 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:34 296] [01-01 18:12:31 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:34 312] [01-01 18:12:31 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:34 312] [01-01 18:12:31 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:34 312] gethostbyname_r error: Unknown host
[2024/8/7 9:03:34 328] [01-01 18:12:31 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:34 328] [01-01 18:12:31 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:34 328] [01-01 18:12:31 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:34 344] [01-01 18:12:31 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:34 344] [01-01 18:12:31 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:34 360] [01-01 18:12:31 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:34 360] [01-01 18:12:31 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:34 376] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:34 376] set basic_indicator_onoff:0 
[2024/8/7 9:03:34 376] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:34 392] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:34 392] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:34 408] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:34 408] Len=17 step 0
[2024/8/7 9:03:34 408] att=0x1 0x2 0xc4 0x38 0xaa 0xc6 0x43 0xd4 0x2a 0xf0 0xb6 0xb7 0xa5 0xb7 0x73 0x69 0x14 
[2024/8/7 9:03:34 408]  RCVS len:17
[2024/8/7 9:03:34 424] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:34 424] XmBleReadBuf 17:
[2024/8/7 9:03:34 439] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:34 440] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:34 440] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:34 455] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:03:34 455] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:03:34 471] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:03:34 471] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:34 471] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:34 471] bt_rev_raw 17
[2024/8/7 9:03:34 487] 01 02 c4 38 aa c6 43 d4 2a f0 b6 b7 a5 b7 73 69 14 
[2024/8/7 9:03:34 487] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:03:34 487] ble rev data 33
[2024/8/7 9:03:34 503] 01 ff 22 4c 03 a3 2e 2a c5 92 f5 f6 63 81 98 7d bb 02 c4 38 aa c6 43 d4 2a f0 b6 b7 a5 b7 73 69 14 
[2024/8/7 9:03:34 503] [01-01 18:12:31 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:03:34 503] ble decryped data 16
[2024/8/7 9:03:34 520] 00 00 00 01 00 00 00 00 00 00 00 00 92 69 00 00 
[2024/8/7 9:03:34 520] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:03:34 520] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x0 
[2024/8/7 9:03:34 537] [01-01 18:12:31 TUYA N][tuya_ble_data_handler.c:451] tuya_ble_handle_dev_infor_req state:0, pkg_len:20
[2024/8/7 9:03:34 537] [01-01 18:12:31 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:03:34 552] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:03:34 552] [01-01 18:12:31 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:03:34 552] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:03:34 568] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:4, send_data:16
[2024/8/7 9:03:34 568] tuya_hal_bt_send 20
[2024/8/7 9:03:34 584] 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:03:34 584] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:34 584] 0 81 1 30 1 57 27 a7 5 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:03:34 600] XmBleSendBuf 20: 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58
[2024/8/7 9:03:34 600] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:34 600] ble_slave_gap_event->type=13
[2024/8/7 9:03:34 600] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:34 617] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:34 617] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:34 617] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:34 633] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:03:34 633] tuya_hal_bt_send 20
[2024/8/7 9:03:34 648] 01 3d 06 a6 bb b1 95 9e 22 f3 dc 3c 8b 6d a3 75 bd b9 fb 64 
[2024/8/7 9:03:34 648] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:34 648] 1 3d 6 a6 bb b1 95 9e 22 f3 dc 3c 8b 6d a3 75 bd b9 fb 64 
[2024/8/7 9:03:34 664] XmBleSendBuf 20: 01 3d 06 a6 bb b1 95 9e 22 f3 dc 3c 8b 6d a3 75 bd b9 fb 64
[2024/8/7 9:03:34 664] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:34 664] ble_slave_gap_event->type=13
[2024/8/7 9:03:34 664] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:34 680] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:34 680] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:34 696] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:34 696] set basic_indicator_onoff:1 
[2024/8/7 9:03:34 696] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:03:34 696] tuya_hal_bt_send 20
[2024/8/7 9:03:34 712] 02 28 56 35 cc 67 bd 9c [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:34 712] 0d dd 6f 1f f3 84 d7 cc a9 e9 4c af 
[2024/8/7 9:03:34 727] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:34 728] 
[2024/8/7 9:03:34 728] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:34 744] 2 28 56 35 cc 67 bd 9c d dd 6f 1f f3 84 d7 cc a9 e9 4c af 
[2024/8/7 9:03:34 744] XmBleSendBuf 20: 02 28 56 35 cc 67 bd 9c 0d dd 6f 1f f3 84 d7 cc a9 e9 4c af
[2024/8/7 9:03:34 744] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:34 745] ble_slave_gap_event->type=13
[2024/8/7 9:03:34 760] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:34 760] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:34 760] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:34 776] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:03:34 776] [01-01 18:12:31 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:03:34 791] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:03:34 791] tuya_hal_bt_send 20
[2024/8/7 9:03:34 791] 03 69 73 39 7b c7 4e 1c 14 47 55 27 8f b6 93 47 c7 08 96 f2 
[2024/8/7 9:03:34 807] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:34 807] 3 69 73 39 7b c7 4e 1c 14 47 55 27 8f b6 93 47 c7 8 96 f2 
[2024/8/7 9:03:34 807] XmBleSendBuf 20: 03 69 73 39 7b c7 4e 1c 14 47 55 27 8f b6 93 47 c7 08 96 f2
[2024/8/7 9:03:34 824] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:34 824] ble_slave_gap_event->type=13
[2024/8/7 9:03:34 824] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:34 824] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:34 839] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:34 839] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:03:34 840] tuya_hal_bt_send 20
[2024/8/7 9:03:34 855] 04 33 33 55 52 f5 71 ea dc 4a 33 39 6b 20 53 7e 69 33 4c 79 
[2024/8/7 9:03:34 855] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:34 855] 4 33 33 55 52 f5 71 ea dc 4a 33 39 6b 20 53 7e 69 33 4c 79 
[2024/8/7 9:03:34 872] XmBleSendBuf 20: 04 33 33 55 52 f5 71 ea dc 4a 33 39 6b 20 53 7e 69 33 4c 79
[2024/8/7 9:03:34 872] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:34 872] ble_slave_gap_event->type=13
[2024/8/7 9:03:34 888] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:34 888] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:34 888] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:34 904] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:34 904] set basic_indicator_onoff:0 
[2024/8/7 9:03:34 920] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:34 920] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:35 016] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:35 032] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:35 048] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:03:35 049] tuya_hal_bt_send 20
[2024/8/7 9:03:35 049] 05 94 12 8a 44 01 79 90 ad 20 ad 38 60 20 0d be d4 36 7f 0d 
[2024/8/7 9:03:35 049] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:35 064] 5 94 12 8a 44 1 79 90 ad 20 ad 38 60 20 d be d4 36 7f d 
[2024/8/7 9:03:35 064] XmBleSendBuf 20: 05 94 12 8a 44 01 79 90 ad 20 ad 38 60 20 0d be d4 36 7f 0d
[2024/8/7 9:03:35 064] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:35 064] ble_slave_gap_event->type=13
[2024/8/7 9:03:35 081] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:35 081] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:35 081] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:35 096] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:18
[2024/8/7 9:03:35 096] tuya_hal_bt_send 19
[2024/8/7 9:03:35 112] 06 b8 dd 13 2d bb 6a f0 2e 91 81 9f 7e c7 0d 7a 78 63 fc 
[2024/8/7 9:03:35 113] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:35 113] 6 b8 dd 13 2d bb 6a f0 2e 91 81 9f 7e c7 d 7a 78 63 fc 
[2024/8/7 9:03:35 128] XmBleSendBuf 19: 06 b8 dd 13 2d bb 6a f0 2e 91 81 9f 7e c7 0d 7a 78 63 fc
[2024/8/7 9:03:35 128] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:35 128] ble_slave_gap_event->type=13
[2024/8/7 9:03:35 128] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:35 144] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:35 144] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:35 144] set basic_indicator_onoff:1 
[2024/8/7 9:03:35 160] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:35 160] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:35 176] [01-01 18:12:31 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:129, send_ret:0x0
[2024/8/7 9:03:35 176] [01-01 18:12:31 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:0
[2024/8/7 9:03:35 192] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:35 192] set basic_indicator_onoff:0 
[2024/8/7 9:03:35 192] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:35 208] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:35 208] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:35 224] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:35 224] Len=20 step 0
[2024/8/7 9:03:35 224] att=0x0 0x51 0x20 0x2 0xbe 0x26 0xbb 0x81 0x49 0xd4 0x67 0xdd 0xa9 0x57 0x51 0xca 0xc6 0x46 0x1c 0x9e 
[2024/8/7 9:03:35 224]  RCVS len:20
[2024/8/7 9:03:35 224] XmBleReadBuf 20:
[2024/8/7 9:03:35 240] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:35 240] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:35 240] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:35 256] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:35 256] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:35 272] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:35 272] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:35 272] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:35 288] bt_rev_raw 20
[2024/8/7 9:03:35 288] 00 51 20 02 be 26 bb 81 49 d4 67 dd a9 57 51 ca c6 46 1c 9e 
[2024/8/7 9:03:35 288] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:03:35 304] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:35 304] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:35 320] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:35 320] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:35 320] Len=20 step 0
[2024/8/7 9:03:35 336] att=0x1 0x23 0x1f 0x45 0xa0 0x86 0x1e 0xa2 0xee 0x75 0x8f 0x60 0x56 0xc7 0x99 0x79 0x94 0x3b 0xb5 0x24 
[2024/8/7 9:03:35 336]  RCVS len:20
[2024/8/7 9:03:35 336] set basic_indicator_onoff:1 
[2024/8/7 9:03:35 352] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:35 352] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:35 352] XmBleReadBuf 20:
[2024/8/7 9:03:35 368] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:35 368] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:35 368] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:35 384] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:35 384] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:35 400] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:35 400] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:35 400] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:35 400] bt_rev_raw 20
[2024/8/7 9:03:35 416] 01 23 1f 45 a0 86 1e a2 ee 75 8f 60 56 c7 99 79 94 3b b5 24 
[2024/8/7 9:03:35 416] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:03:35 432] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:35 432] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:35 448] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:35 448] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:35 464] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:35 464] Len=20 step 0
[2024/8/7 9:03:35 464] att=0x2 0xd3 0x3b 0x43 0x5 0x77 0x67 0xea 0x66 0xd1 0x74 0x71 0x4c 0xc1 0xf3 0x6a 0x50 0x75 0x29 0x8c 
[2024/8/7 9:03:35 464]  RCVS len:20
[2024/8/7 9:03:35 480] XmBleReadBuf 20:
[2024/8/7 9:03:35 480] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:35 480] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:35 480] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:35 496] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:35 496] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:35 512] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:35 512] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:35 528] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:35 528] bt_rev_raw 20
[2024/8/7 9:03:35 528] 02 d3 3b 43 05 77 67 ea 66 d1 74 71 4c c1 f3 6a 50 75 29 8c 
[2024/8/7 9:03:35 544] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:03:35 544] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:35 544] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:35 560] set basic_indicator_onoff:0 
[2024/8/7 9:03:35 560] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:35 576] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:35 576] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:35 576] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:35 592]  ---
[2024/8/7 9:03:35 593] Len=20 step 0
[2024/8/7 9:03:35 593] att=0x3 0x34 0xba 0xb9 0xb9 0x9 0xcb 0x2c 0x58 0xe 0xb6 0x35 0x17 0x9f 0x3e 0xab 0x2a 0xbe 0x8d 0x8b 
[2024/8/7 9:03:35 593]  RCVS len:20
[2024/8/7 9:03:35 608] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:35 608] [01-01 18:12:32 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:35 623] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:35 623] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:35 623] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:35 639] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:35 639] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:35 639] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:35 656] [01-01 18:12:32 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:35 656] [01-01 18:12:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:03:35 672] [01-01 18:12:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:35 673] [01-01 18:12:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:35 673] [01-01 18:12:32 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:35 688] [01-01 18:12:32 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:35 688] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:35 720] [01-01 18:12:32 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:03:35 720] [01-01 18:12:32 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:03:35 736] [01-01 18:12:32 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:03:35 737] [01-01 18:12:32 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:03:35 752] gethostbyname_r error: Unknown host
[2024/8/7 9:03:35 768] [01-01 18:12:32 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:03:35 768] [01-01 18:12:32 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:03:35 783] [01-01 18:12:32 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:03:35 784] [01-01 18:12:32 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:03:35 799] [01-01 18:12:32 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:03:35 800] [01-01 18:12:32 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:03:35 816] [01-01 18:12:32 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:03:35 816] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:03:35 816] [01-01 18:12:32 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:03:35 816] XmBleReadBuf 20:
[2024/8/7 9:03:35 831] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:35 832] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:35 832] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:35 848] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:35 848] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:35 863] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:35 863] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:35 864] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:35 864] bt_rev_raw 20
[2024/8/7 9:03:35 879] 03 34 ba b9 b9 09 cb 2c 58 0e b6 35 17 9f 3e ab 2a be 8d 8b 
[2024/8/7 9:03:35 879] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:03:35 895] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:35 895] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:35 895] set basic_indicator_onoff:1 
[2024/8/7 9:03:35 911] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:35 911] Len=8 step 0
[2024/8/7 9:03:35 911] att=0x4 0x8e 0xe5 0x3d 0xa6 0x1 0xab 0x30 
[2024/8/7 9:03:35 911]  RCVS len:8
[2024/8/7 9:03:35 928] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:35 928] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:35 943] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:35 943] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:35 943] XmBleReadBuf 8:
[2024/8/7 9:03:35 960] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:35 961] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:35 961] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:35 976] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 16 rcount 16 offset 0 ---
[2024/8/7 9:03:35 976] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 16 ---
[2024/8/7 9:03:35 992] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x9]
[2024/8/7 9:03:35 992] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:35 992] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:36 007] bt_rev_raw 8
[2024/8/7 9:03:36 007] 04 8e e5 3d a6 01 ab 30 
[2024/8/7 9:03:36 008] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:5, pack_len:7, total_len:81
[2024/8/7 9:03:36 008] ble rev data 81
[2024/8/7 9:03:36 024] 02 be 26 bb 81 49 d4 67 dd a9 57 51 ca c6 46 1c 9e 23 1f 45 a0 86 1e a2 ee 75 8f 60 56 c7 99 79 94 3b b5 24 d3 3b 43 05 77 67 ea 66 d1 74 71 4c c1 f3 6a 50 75 29 8c 34 ba b9 b9 09 cb 2c 58 0e 
[2024/8/7 9:03:36 040] b6 35 17 9f 3e ab 2a be 8d 8b 8e e5 3d a6 01 ab 30 
[2024/8/7 9:03:36 040] ble decryped data 64
[2024/8/7 9:03:36 056] 00 00 00 02 00 00 00 00 00 01 00 2c 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca 1e 00 00 00 00 00 00 
[2024/8/7 9:03:36 056] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:03:36 072] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x1 
[2024/8/7 9:03:36 072] [01-01 18:12:32 TUYA D][tuya_ble_api.c:573] conn monitor timer stopped
[2024/8/7 9:03:36 072] [01-01 18:12:32 TUYA N][tuya_ble_api.c:1464] ble set conn stat:3
[2024/8/7 9:03:36 088] [01-01 18:12:32 TUYA N][tuya_ble_data_handler.c:367] PAIR_REQ ok:0
[2024/8/7 9:03:36 088] [01-01 18:12:32 TUYA N][tuya_ble_data_handler.c:342] ble_time_req start...
[2024/8/7 9:03:36 104] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:348] no need to query time. network stat:1, work stat:0
[2024/8/7 9:03:36 104] [01-01 18:12:32 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:03:36 119] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:03:36 154] [01-01 18:12:32 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:03:36 167] tuya_hal_bt_send 20
[2024/8/7 9:03:36 168] 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:03:36 168] [01-01 18:12:32 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:36 184] 0 21 31 2 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:03:36 184] XmBleSendBuf 20: 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c
[2024/8/7 9:03:36 184] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:36 184] ble_slave_gap_event->type=13
[2024/8/7 9:03:36 199] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:36 199] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:36 199] [01-01 18:12:32 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:36 215] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:16 ---
[2024/8/7 9:03:36 215] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:36 231] [01-01 18:12:32 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:03:36 231] tuya_hal_bt_send 17
[2024/8/7 9:03:36 231] 01 87 04 01 8a 8a 4e 3f 77 set basic_indicator_onoff:0 
[2024/8/7 9:03:36 231] ab 6d 70 d9 2c b2 77 7d 
[2024/8/7 9:03:36 247] [01-01 18:12:32 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:03:36 247] 1 87 4 1 8a 8a 4e 3f 77 ab 6d 70 d9 2c b2 77 7d 
[2024/8/7 9:03:36 248] XmBleSendBuf 17: 01 87 04 01 8a 8a 4e 3f 77 ab 6d 70 d9 2c b2 77 7d
[2024/8/7 9:03:36 264] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:03:36 264] ble_slave_gap_event->type=13
[2024/8/7 9:03:36 264] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:03:36 264] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:03:36 279] [01-01 18:12:32 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:03:36 280] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:36 296] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:36 296] [01-01 18:12:32 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:03:36 311] [01-01 18:12:32 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:1
[2024/8/7 9:03:36 312] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:36 312] set basic_indicator_onoff:1 
[2024/8/7 9:03:36 327] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:36 328] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:36 344] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:36 359] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:36 359] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:36 360]  ---
[2024/8/7 9:03:36 360] Len=20 step 0
[2024/8/7 9:03:36 375] att=0x0 0x61 0x20 0x2 0x80 0x71 0x2e 0x77 0xce 0xe7 0x25 0x76 0x84 0xc1 0xc2 0x2 0xed 0xab 0x5c 0x70 
[2024/8/7 9:03:36 376]  RCVS len:20
[2024/8/7 9:03:36 376] XmBleReadBuf 20:
[2024/8/7 9:03:36 376] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:36 376] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:36 391] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:36 392] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:36 407] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:36 408] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:36 408] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:36 424] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:36 424] bt_rev_raw 20
[2024/8/7 9:03:36 424] 00 61 20 02 80 71 2e 77 ce e7 25 76 84 c1 c2 02 ed ab 5c 70 
[2024/8/7 9:03:36 440] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:03:36 440] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:36 456] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:36 456] set basic_indicator_onoff:0 
[2024/8/7 9:03:36 471] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:36 472] [1970-01-01[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:03:36 472]  00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:36 487] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:36 487] Len=20 step 0
[2024/8/7 9:03:36 487] att=0x1 0xcb 0x5f 0xd7 0xe 0x2f 0xf1 0x73 0xa2 0x53 0x94 0x1d 0x37 0x42 0x3a 0x4d 0x51 0x57 0xbb 0xb0 
[2024/8/7 9:03:36 487]  RCVS len:20
[2024/8/7 9:03:36 503] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:36 503] XmBleReadBuf 20:
[2024/8/7 9:03:36 503] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:36 519] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:36 519] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:36 519] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:36 567] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:36 568] [01-01 18:12:33 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:36 585] [01-01 18:12:33 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:36 585] [01-01 18:12:33 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:36 585] bt_rev_raw 20
[2024/8/7 9:03:36 585] 01 cb 5f d7 0e 2f f1 73 a2 53 94 1d 37 42 3a 4d 51 57 bb b0 
[2024/8/7 9:03:36 600] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:03:36 616] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:36 616] --- tracepoint bt_ext_port[atbm_log]:[ieee80211_csa_cancel][mon.eth2]:[0][0]
[2024/8/7 9:03:36 616] ing.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:36 632] [1970-01-01 00:00:28] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:03:36 632] [1970-01-01 00:00:28] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time28762
[2024/8/7 9:03:36 648] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:36 648] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:36 648] Len=20 step 0
[2024/8/7 9:03:36 664] att=0x2 0x35 0x73 0xd9 0x3a 0xb 0x1a 0x8a 0xf2 0x86 0x7d 0xc0 0x63 0x32 0x9f 0x95 0xaf 0x76 0x1a 0xc6 
[2024/8/7 9:03:36 664]  RCVS len:20
[2024/8/7 9:03:36 664] set basic_indicator_onoff:1 
[2024/8/7 9:03:36 680] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:36 680] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:36 680] XmBleReadBuf 20:
[2024/8/7 9:03:36 696] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:36 696] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:36 697] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:36 712] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:36 712] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:36 712] [01-01 18:12:33 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:36 728] [01-01 18:12:33 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:36 728] [01-01 18:12:33 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:36 728] bt_rev_raw 20
[2024/8/7 9:03:36 744] 02 35 73 d9 3a 0b 1a 8a f2 86 7d c0 63 32 9f 95 af 76 1a c6 
[2024/8/7 9:03:36 744] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:03:36 759] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:36 760] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:36 760] set basic_indicator_onoff:0 
[2024/8/7 9:03:36 776] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:36 776] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:03:36 792] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:03:36 807] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:36 808] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:36 808] Len=20 step 0
[2024/8/7 9:03:36 823] att=0x3 0x63 0x3e 0xbd 0x2a 0xd9 0x17 0xec 0xa6 0xd7 0x29 0x66 0xb2 0x75 0x1f 0xdc 0xf0 0x1a 0xe8 0xe0 
[2024/8/7 9:03:36 824]  RCVS len:20
[2024/8/7 9:03:36 824] XmBleReadBuf 20:
[2024/8/7 9:03:36 824] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:36 824] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:36 840] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:36 840] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:36 840] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:36 855] [01-01 18:12:33 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:36 855] [01-01 18:12:33 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:36 871] [01-01 18:12:33 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:36 871] bt_rev_raw 20
[2024/8/7 9:03:36 871] 03 63 3e bd 2a d9 17 ec a6 d7 29 66 b2 75 1f dc f0 1a e8 e0 
[2024/8/7 9:03:36 887] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:03:36 887] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:36 903] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:36 903] set basic_indicator_onoff:1 
[2024/8/7 9:03:36 903] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:03:36 919] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:03:36 919] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:36 935] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:03:36 935] Len=20 step 0
[2024/8/7 9:03:36 935] att=0x4 0x46 0x8f 0x5e 0x8c 0x88 0x18 0x66 0x44 0xce 0x28 0xdf 0x83 0x8d 0xd0 0x51 0x70 0x1f 0x7 0x2e 
[2024/8/7 9:03:36 935]  RCVS len:20
[2024/8/7 9:03:36 952] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:03:36 952] XmBleReadBuf 20:
[2024/8/7 9:03:36 952] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:03:36 967] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:03:36 983] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:03:36 983] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:03:36 984] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:03:37 000] [01-01 18:12:33 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:03:37 000] [01-01 18:12:33 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:03:37 015] [01-01 18:12:33 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:03:37 015] bt_rev_raw 20
[2024/8/7 9:03:37 015] 04 46 8f 5e 8c 88 18 66 44 ce 28 df 83 8d d0 51 70 1f 07 2e 
[2024/8/7 9:03:37 032] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:5, pack_len:19, total_len:93
[2024/8/7 9:03:37 032] [01-01 18:12:33 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:03:37 048] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:03:37 048] [01-01 18:12:33 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:03:37 048] [01-01 18:12:33 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:03:37 064] [01-01 18:12:33 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:37 064] [01-01 18:12:33 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:03:37 080] [01-01 18:12:33 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:03:37 080] [01-01 18:12:33 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:03:37 080] [01-01 18:12:33 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:03:37 096] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:03:37 096] [01-01 18:12:33 TUYA [atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:03:37 096] D][simplekv.c:1247] no key find
[2024/8/7 9:03:37 112] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:03:37 112] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:03:37 128] [01-01 18:12:33 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:03:37 128] [01-01 18:12:33 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:03:37 128] [01-01 18:12:33 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:03:37 160] [01-01 18:12:33 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:0
