[BEGIN] 2024/8/7 9:24:13
[2024/8/7 9:25:12 817] 
[2024/8/7 9:25:12 817] resetting ...
[2024/8/7 9:25:12 913] 
[2024/8/7 9:25:12 913] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 9:25:12 913] CPU: XM550V200WX2
[2024/8/7 9:25:12 913] DRAM:  128 MiB
[2024/8/7 9:25:13 040] MMC:   arasan: 0
[2024/8/7 9:25:13 089] In:    serial
[2024/8/7 9:25:13 089] Out:   serial
[2024/8/7 9:25:13 089] Err:   serial
[2024/8/7 9:25:13 313] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 9:25:13 313] Press Ctrl+C to stop autoboot
[2024/8/7 9:25:13 729] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 9:25:13 729] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 9:25:13 729]    Image Name:   Linux-3.10.103+
[2024/8/7 9:25:13 745]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 9:25:13 745]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 9:25:13 745]    Load Address: 80008000
[2024/8/7 9:25:13 745]    Entry Point:  80008000
[2024/8/7 9:25:13 745]    XIP Kernel Image ... OK
[2024/8/7 9:25:13 745] Starting kernel ...
[2024/8/7 9:25:14 640] Uncompressing Linux... done, booting the kernel.
[2024/8/7 9:25:14 768] Booting Linux on physical CPU 0x0
[2024/8/7 9:25:14 784] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 9:25:14 784] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 9:25:14 784] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 9:25:14 800] Machine: xm530v200
[2024/8/7 9:25:14 800] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 9:25:14 800] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 9:25:14 816] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 9:25:14 816] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 9:25:14 833] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 9:25:14 833] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 9:25:14 833] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 9:25:14 850] Memory: 52MB = 52MB total
[2024/8/7 9:25:14 850] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 9:25:14 850] Virtual kernel memory layout:
[2024/8/7 9:25:14 850]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 9:25:14 865]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 9:25:14 865]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 9:25:14 865]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 9:25:14 865]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 9:25:14 881]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 9:25:14 881]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 9:25:14 881]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 9:25:14 897]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 9:25:14 897] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 9:25:14 897] Hierarchical RCU implementation.
[2024/8/7 9:25:14 897] NR_IRQS:128
[2024/8/7 9:25:14 913] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 9:25:14 913] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 9:25:14 913] pid_max: default: 32768 minimum: 301
[2024/8/7 9:25:14 913] Mount-cache hash table entries: 512
[2024/8/7 9:25:14 913] CPU: Testing write buffer coherency: ok
[2024/8/7 9:25:14 929] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 9:25:14 929] L310 cache controller enabled
[2024/8/7 9:25:14 929] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 9:25:14 945] CPU1: Booted secondary processor
[2024/8/7 9:25:14 945] Brought up 2 CPUs
[2024/8/7 9:25:14 945] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 9:25:14 945] CPU: All CPU(s) started in SVC mode.
[2024/8/7 9:25:14 945] NET: Registered protocol family 16
[2024/8/7 9:25:14 961] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 9:25:14 961] Serial: AMBA PL011 UART driver
[2024/8/7 9:25:14 961] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 9:25:14 961] console [ttyAMA0] enabled
[2024/8/7 9:25:14 977] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 9:25:14 977] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 9:25:14 993] bio: create slab <bio-0> at 0
[2024/8/7 9:25:15 009] usbcore: registered new interface driver usbfs
[2024/8/7 9:25:15 009] usbcore: registered new interface driver hub
[2024/8/7 9:25:15 009] usbcore: registered new device driver usb
[2024/8/7 9:25:15 025] Switching to clocksource arm_global_timer
[2024/8/7 9:25:15 025] NET: Registered protocol family 2
[2024/8/7 9:25:15 041] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:25:15 041] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:25:15 041] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 9:25:15 041] TCP: reno registered
[2024/8/7 9:25:15 057] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:25:15 057] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:25:15 057] NET: Registered protocol family 1
[2024/8/7 9:25:15 057] RPC: Registered named UNIX socket transport module.
[2024/8/7 9:25:15 073] RPC: Registered udp transport module.
[2024/8/7 9:25:15 073] RPC: Registered tcp transport module.
[2024/8/7 9:25:15 073] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 9:25:15 089] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 9:25:15 105] NFS: Registering the id_resolver key type
[2024/8/7 9:25:15 105] Key type id_resolver registered
[2024/8/7 9:25:15 105] Key type id_legacy registered
[2024/8/7 9:25:15 105] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 9:25:15 121] fuse init (API version 7.22)
[2024/8/7 9:25:15 121] msgmni has been set to 95
[2024/8/7 9:25:15 121] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 9:25:15 137] io scheduler noop registered
[2024/8/7 9:25:15 137] io scheduler deadline registered (default)
[2024/8/7 9:25:15 137] io scheduler cfq registered
[2024/8/7 9:25:15 153] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 9:25:15 153] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 9:25:15 153] uart-pl011 uart:0: no DMA platform data
[2024/8/7 9:25:15 153] uart-pl011 uart:1: no DMA platform data
[2024/8/7 9:25:15 169] uart-pl011 uart:2: no DMA platform data
[2024/8/7 9:25:15 185] brd: module loaded
[2024/8/7 9:25:15 185] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 9:25:15 185] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:25:15 201] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:25:15 201] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 9:25:15 201] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 9:25:15 201] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 9:25:15 217] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 9:25:15 217] 0x000000300000-0x000000730000 : "user"
[2024/8/7 9:25:15 217] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 9:25:15 233] PPP generic driver version 2.4.2
[2024/8/7 9:25:15 234] NET: Registered protocol family 24
[2024/8/7 9:25:15 234] usbcore: registered new interface driver asix
[2024/8/7 9:25:15 234] usbcore: registered new interface driver cdc_ether
[2024/8/7 9:25:15 249] usbcore: registered new interface driver rndis_host
[2024/8/7 9:25:15 249] XMMMAC driver:
[2024/8/7 9:25:15 249] 	platform registration... 
[2024/8/7 9:25:15 249] 	done!
[2024/8/7 9:25:15 249] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 9:25:15 249] 	IO base addr: 0xfe010000)
[2024/8/7 9:25:15 265] libphy: XMMMAC MII Bus: probed
[2024/8/7 9:25:15 265] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 9:25:15 265] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 9:25:15 281] usbcore: registered new interface driver cdc_acm
[2024/8/7 9:25:15 281] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 9:25:15 281] usbcore: registered new interface driver usbserial
[2024/8/7 9:25:15 296] usbcore: registered new interface driver option
[2024/8/7 9:25:15 297] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 9:25:15 297] usbcore: registered new interface driver qcserial
[2024/8/7 9:25:15 312] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 9:25:15 313] TCP: cubic registered
[2024/8/7 9:25:15 313] NET: Registered protocol family 17
[2024/8/7 9:25:15 313] Key type dns_resolver registered
[2024/8/7 9:25:15 329] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 9:25:15 329] registered taskstats version 1
[2024/8/7 9:25:15 329] ÿVFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 9:25:15 345] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 9:25:15 680] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 9:25:16 241] arasan_set_clock:
[2024/8/7 9:25:16 257] 	new freq 400000
[2024/8/7 9:25:16 272] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 9:25:16 288] arasan_set_clock:
[2024/8/7 9:25:16 320] 	new freq 300000arasan_set_clock:
[2024/8/7 9:25:16 336] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 9:25:16 352] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 9:25:16 353] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 9:25:16 353] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 9:25:16 353] [reg] = 0x20000078,[val]= 0xc103c0ff
[2024/8/7 9:25:16 353] [reg] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 9:25:16 368] [reg] = 0x20000000,[val]= 0x00arasan_set_clock:
[2024/8/7 9:25:16 368] 	new freq 195312000000
[2024/8/7 9:25:16 368] [reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 9:25:16 368] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 9:25:16 384] [reg] = 0x200505f0,[i2c: module license 'Proprietary' taints kernel.
[2024/8/7 9:25:16 384] val]= 0x00000001
[2024/8/7 9:25:16 384] Disabling lock debugging due to kernel taint
[2024/8/7 9:25:16 384] i2c init is ok!
[2024/8/7 9:25:16 400] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 9:25:16 512] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 9:25:16 592] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 9:25:16 608] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 9:25:16 624] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 9:25:16 640] acodec init is ok!
[2024/8/7 9:25:16 657] i2s clk:2048000Hz
[2024/8/7 9:25:16 817] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 9:25:16 817] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 9:25:16 817] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 9:25:16 832] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 9:25:16 833] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 9:25:16 833] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 9:25:16 849] usb usb1: Product: DWC OTG Controller
[2024/8/7 9:25:16 849] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 9:25:16 849] usb usb1: SerialNumber: dwc2.0
[2024/8/7 9:25:16 849] hub 1-0:1.0: USB hub found
[2024/8/7 9:25:16 849] hub 1-0:1.0: 1 port detected
[2024/8/7 9:25:16 896] xm_wdt init is ok
[2024/8/7 9:25:16 912] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 9:25:17 216] nn_kernel: NN: request mem  fail
[2024/8/7 9:25:17 216] nn_kernel: addr iomap fail
[2024/8/7 9:25:17 248] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 9:25:17 793] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 9:25:17 825] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtusbwifi_init.
[2024/8/7 9:25:17 825] d/user.sh: not fPDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 9:25:17 825] ound
[2024/8/7 9:25:17 841] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 9:25:17 872] exfatfsck 1.3.0
[2024/8/7 9:25:17 872] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:25:19 824] ouput high and delay 2000ms
[2024/8/7 9:25:19 904] Auto login as root ...
[2024/8/7 9:25:19 952] (none) login: not found /dev/mmcxxx  
[2024/8/7 9:25:19 968] Tcp server success, Wait connet ...
[2024/8/7 9:25:19 968] Get xmauto Fialed ,xmauto = 1
[2024/8/7 9:25:19 968] auto start to app 
[2024/8/7 9:25:19 984] macGuarder: Get telnetctrl Fialed, telnetctrl=0
[2024/8/7 9:25:20 000] macGuarder: Close telnetd Forever 
[2024/8/7 9:25:20 289] usb 1-1: new high-speed USB device number 4 using dwc2
[2024/8/7 9:25:20 464] 
[2024/8/7 9:25:20 480] (none) login: usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:25:20 496] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:25:20 496] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:25:20 496] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:25:21 008] 
[2024/8/7 9:25:21 872] (none) login: [atbm_log]:atbm_usb_module_init 0
[2024/8/7 9:25:21 887] [atbm_log]:platform_init(253)
[2024/8/7 9:25:21 888] [atbm_log]:SVN_VER=33341,DPLL_CLOCK=1,BUILD_TIME=[2024-04-03_14:40:53]
[2024/8/7 9:25:21 888] [atbm_log]:Probe called -1 v1
[2024/8/7 9:25:21 888] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[2024/8/7 9:25:21 903] [atbm_log]:CONFIG_TX_NO_CONFIRM
[2024/8/7 9:25:21 904] wiphy_new_nm support CONFIG_WIRELESS_EXT 
[2024/8/7 9:25:21 904] [atbm_log]:Allocated hw_priv @ c270d960
[2024/8/7 9:25:21 920] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[2024/8/7 9:25:21 920] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c270d960)
[2024/8/7 9:25:21 936] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c270d960)
[2024/8/7 9:25:21 937] [atbm_log]:not support ldpc & ht40!
[2024/8/7 9:25:21 937] [atbm_log]:atbm_get_chiptype, chipver=0x5a, g_wifi_chip_type[14]
[2024/8/7 9:25:21 952] [[atbm_log]:atbm_before_load_firmware++
[2024/8/7 9:25:21 952] 1970-01-01 00:00:07] <json_parse[atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[2024/8/7 9:25:21 967] .c> ==> XMJSON_ParseExVb(526)[ER[atbm_log]:===================~_~====================
[2024/8/7 9:25:21 967] ROR]: Get Vb object error!
[2024/8/7 9:25:21 968] [1970-01-01 00:00:07] <xm_system.c> ==> XMSDK_ParseJson(48)[ERROR]: Parse Vb Failed!
[2024/8/7 9:25:21 984] [1970-01-01 00:00:[atbm_log]:atbm_start_load_firmware++
[2024/8/7 9:25:21 984] 07] <json_parse.fwhdr->flags 34353678 sram_addr 9022000
[2024/8/7 9:25:21 984] c> ==> XMJSON_Pa[atbm_log]:
[2024/8/7 9:25:21 984] ======>>> load WIFI BLE COMB firmware <<<======
[2024/8/7 9:25:22 000] rseIsp(452)[ERRO[atbm_log]:START DOWNLOAD ICCM=========
[2024/8/7 9:25:22 000] R]: Get Isp obje[atbm_log]:atbm_load_firmware_generic: addr 60000: len 20000
[2024/8/7 9:25:22 000] ct u32Flag error set value 1!
[2024/8/7 9:25:22 015] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(464)[ERROR]: Get Isp object u32Others error set value 0!
[2024/8/7 9:25:22 033] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(476)[ERROR]: Get Isp object CmosPort error set value 0!
[2024/8/7 9:25:22 033] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(488)[ERROR]: Get Isp object splice_mode error set value 0!
[2024/8/7 9:25:22 048] [1970-01-01 00:00:06] MainApp.c(1802) <main>: build @Jul 31 2024 13:28:12
[2024/8/7 9:25:22 048] [1970-01-01 00:00:06] MainApp.c(1710) <SetLogLevel>: set Sofia log level 2 suceess
[2024/8/7 9:25:22 065] [1970-01-01 00:00:06] ==> XMSDK_SetLogLevel(226)[NOTICE]: set xmsdk log 4
[2024/8/7 9:25:22 065] [1970-01-01 00:00:07] xm_log.c(100) <XM_RegisterLogAndInit>: Register Log level 2
[2024/8/7 9:25:22 080] [1970-01-01 00:00:07] xm_hwinfo.c(162) <XM_HwinfoInit>: Sync hwinfo to Hwfile success!
[2024/8/7 9:25:22 096] Get Hw info: AppId [fvijo8jvloagv1gm], license [uuidcaab27b0a838d239], mac[j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:25:22 097] [1970-01-01 00:00:07] utils.c(974) <ReadJsonConfig>: Have not find pClass [DeviceGpio] pNumber [NetStatusLedGpio]
[2024/8/7 9:25:22 112] [1970-01-01 00:00:07] xm_device.c(226) <ParseDeviceJsonFile>: Get g_NetStatusLed [0] failed
[2024/8/7 9:25:22 113] **********************************************************************
[2024/8/7 9:25:22 128] |                      SYSTEM INFO                                       
[2024/8/7 9:25:22 128] |       product type:		RC50X80
[2024/8/7 9:25:22 128] |           DSP chip:		XM550V200
[2024/8/7 9:25:22 128] |          wifi type:		ATBM6062U
[2024/8/7 9:25:22 129] |             HW mac:		90314ba51650
[2024/8/7 9:25:22 129] |        git version:		a590e8b3
[2024/8/7 9:25:22 144] |          make time:		20240731132812
[2024/8/7 9:25:22 144] **********************************************************************
[2024/8/7 9:25:22 160] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(143)[INFO]: SensorSrcFrmRate = 25
[2024/8/7 9:25:22 160] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(137)[INFO]: SensorIFS = 0
[2024/8/7 9:25:22 176] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(156)[INFO]: Vi CapW 2680, CapH 2160, CapX 0, CapY 0
[2024/8/7 9:25:22 176] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 0: size=[3840, 2160] @3
[2024/8/7 9:25:22 192] [1970-01-01 00:00:07] ==> XMJS[atbm_log]:START DOWNLOAD DCCM=========
[2024/8/7 9:25:22 192] ON_ParseViX(110)[atbm_log]:atbm_load_firmware_generic: addr 800000: len d000
[2024/8/7 9:25:22 192] [INFO]: ViChn 1: size=[640, 360] @3
[2024/8/7 9:25:22 208] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 2: size=[640, 224] @3
[2024/8/7 9:25:22 208] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(406)[INFO]: ISPRsltType
[2024/8/7 9:25:22 224] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(428)[INFO]: ISPRsltType 0
[2024/8/7 9:25:22 224] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(442)[INFO]: ISPRsltType
[2024/8/7 9:25:22 239] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_Parse4gMoudle(500)[WARN]: Get 4GModule object error!
[2024/8/7 9:25:22 239] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(80)[NOTICE]: ISP=> Svtd: PAL
[2024/8/7 9:25:22 240] 
[2024/8/7 9:25:22 256] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(81)[NOTICE]: ISP=>RsltType: 0
[2024/8/7 9:25:22 256] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(84)[NOTICE]: IRCut: gpio 19534 Swap 0
[2024/8/7 9:25:22 272] [1970-01-01 00:00:07] xm_main.c(345) <AutoMaintenance_pro>:[atbm_log]:START DOWNLOAD BLE SRAM=========
[2024/8/7 9:25:22 272]  Set device auto[atbm_log]:atbm_load_firmware_generic: addr 9022000: len 10000
[2024/8/7 9:25:22 288]  mantenance time: -001_-1_-1 02:25:26 wenkday: Tuesday
[2024/8/7 9:25:22 288] [1970-01-01 00:00:07] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:25:22 304] [1970-01-01 00:00:07] xm_main.c(349) <AutoMaintenance_pro>: Get Last AutoMantence Date [] failed
[2024/8/7 9:25:22 304] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(88)[NOTICE]: Infrared: gpio 0 swap 1
[2024/8/7 9:25:22 320] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(92)[NOTICE]: WLight: gpio 11 swap 0
[2024/8/7 9:25:22 320] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(96)[NOTICE]: IRLight: gpio 10 swap 0
[2024/8/7 9:25:22 336] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(99)[NOTICE]: Vi: sensorIFS=0 sensorFPS=25, capW=2680,capH=2160,capX=0,capY=0
[2024/8/7 9:25:22 352] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(100)[NOTICE]: ViChn  ImageSizei2c_write timeout 0x2
[2024/8/7 9:25:22 352]       vbBlk
[2024/8/7 9:25:22 352] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    0  [3840, 2160]    3
[2024/8/7 9:25:22 368] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    1  [ 640,  360]    2
[2024/8/7 9:25:22 368] [1970-01-01 00:00:07] =[atbm_log]:atbm_after_load_firmware++
[2024/8/7 9:25:22 368] => XMSDK_ParseJs[atbm_log]:alloc urb work
[2024/8/7 9:25:22 384] on(105)[NOTICE]:[atbm_log]:usb:try to flush rx....
[2024/8/7 9:25:22 384]     2  [ 640,  224]    2
[2024/8/7 9:25:22 400] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(107)[NOTICE]: VencChn    MaxSize   PreReleaseVbi2c_write timeout 0x2
[2024/8/7 9:25:22 400] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    0   [3840, 2160]	 false
[2024/8/7 9:25:22 416] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    1   [ 640,  360]	 false
[2024/8/7 9:25:22 416] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(116)[NOTICE]: 4GModule: gpio 0 Swap 0
[2024/8/7 9:25:22 432] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: AudioSwap: 0
[2024/8/7 9:25:22 432] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFileDEBUG: [libispapp]:Jul  5 2024 16:14:06 ,GENERAL
[2024/8/7 9:25:22 432] DEBUG: Vstd_init	[ PAL ]
[2024/8/7 9:25:22 448] DEBUG: RsltSns0	[ 8 ]
[2024/8/7 9:25:22 448] DEBUG: Dsp:		[0x0][ CHIPV200 ]
[2024/8/7 9:25:22 448] DEBUG: [libsns]:Jul  5 2024 16:13:32 ,GENERAL
[2024/8/7 9:25:22 480] [atbm_log]:flush rx[-110][0]
[2024/8/7 9:25:22 480] [atbm_log]:0x1610102c=0x4300a
[2024/8/7 9:25:22 480] [atbm_log]:0x1610102c=0x6300b
[2024/8/7 9:25:22 480] [atbm_log]:0x16101000=0x0
[2024/8/7 9:25:22 480] [atbm_log]:set_block_size=256
[2024/8/7 9:25:22 496] [atbm_log]:mdelay wait wsm_startup_done  !!
[2024/8/7 9:25:22 496] [atbm_log]:firmwareCap 31e9
[2024/8/7 9:25:22 496] [atbm_log]:firmwareCap2 1b8c
[2024/8/7 9:25:22 496] [atbm_log]:wsm_caps.firmwareCap 1b8c31e9 16[atbm_log]:apollo wifi WSM init done.
[2024/8/7 9:25:22 512]    Input buffers: 32 x 1632 bytes
[2024/8/7 9:25:22 512]    Hardware: 7.21
[2024/8/7 9:25:22 528]    WSM firmware [=MODEM=DPLL24M+BLE+plat=4 ApSleep 2GHZ Jan 30 2024 10:58:03], ver: 19514, build: 6431, api: 1060, cap: 0x1B8C31E9 Config[31010]  expection 900c094, ep0 cmd addr 901b340 NumOfStations[0x10] NumOfInterfaces[3]
[2024/8/7 9:25:22 528] i2c_write timeout 0x2
[2024/8/7 9:25:22 528] [atbm_log]:EFUSE(8)				[0]
[2024/8/7 9:25:22 528] [atbm_log]:EFUSE(I)					[0]
[2024/8/7 9:25:22 528] [atbm_log]:EFUSE(B)			[0]
[2024/8/7 9:25:22 544] [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [0]
[2024/8/7 9:25:22 544] [atbm_log]:CAPABILITIES_NVR_IPC              [0]
[2024/8/7 9:25:22 544] i2c_write timeout 0x2
[2024/8/7 9:25:22 544] [atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[2024/8/7 9:25:22 560] [atbm_log]:CAPABILITIES_WOW                  [0]
[2024/8/7 9:25:22 560] [atbm_log]:CAPABILITIES_NO_BACKOFF           [1]
[2024/8/7 9:25:22 560] [atbm_log]:CAPABILITIES_CFO                  [1]
[2024/8/7 9:25:22 576] [atbm_log]:CAPABILITIES_CHIP_FLAG            [1]
[2024/8/7 9:25:22 576] [atbm_log]:CAPABILITIES_TXCAL                [1]
[2024/8/7 9:25:22 576] DEBUG: SC[atbm_log]:CAPABILITIES_HIF_TRACE       		[0]
[2024/8/7 9:25:22 576] 831HAI! Chn:0
[2024/8/7 9:25:22 592]  tbm_log]:CAPABILITIES_FORCE_PM_ACTIVE      [0]
[2024/8/7 9:25:22 594] [m[atbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[2024/8/7 9:25:22 594] [atbm_log]:CAPABILITIES_ETF                  [1]
[2024/8/7 9:25:22 594] [atbm_log]:CAPABILITIES_BLE		  			[1]
[2024/8/7 9:25:22 594] [atbm_log]:CAPABILITIES_40M			  		[0]
[2024/8/7 9:25:22 608] [atbm_log]:CAPABILITIES_LDPC 		  		[0]
[2024/8/7 9:25:22 608] DEBUG: Is[atbm_log]:CAPABILITIES_NAV_ENABLE              [0]
[2024/8/7 9:25:22 608] pNum[[atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [0]
[2024/8/7 9:25:22 608] 1]
[2024/8/7 9:25:22 624] DE[atbm_log]:CAPABILITIES_USE_IPC              [1]
[2024/8/7 9:25:22 624] BUG: IspChn:[ atbm_log]:CAPABILITIES_OUTER_PA             [0]
[2024/8/7 9:25:22 624] m0 atbm_log]:CAPABILITIES_WFA    [0]
[2024/8/7 9:25:22 624] ;35m]
[2024/8/7 9:25:22 640] atbm_log]:CAPABILITIES_EAP_GROUP_REKEY  [0]
[2024/8/7 9:25:22 640] mDEBUG: I2CChn:[[atbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[2024/8/7 9:25:22 640]  0 [atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[2024/8/7 9:25:22 640] ]
[2024/8/7 9:25:22 656] atbm_log]:CAPABILITIES_RXCAL       [1]
[2024/8/7 9:25:22 656] ;35mDEBUG: limit[atbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[2024/8/7 9:25:22 656] edUp: no
[2024/8/7 9:25:22 656] [atbm_log]:CAPABILITIES_80211_TO_8023 [1]
[2024/8/7 9:25:22 673] DEBUG: --[atbm_log]:CAPABILITIES_NEW_CHIPER  [1]
[2024/8/7 9:25:22 673] -----------SC831[atbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [0]
[2024/8/7 9:25:22 673] Hai 4K 30fps ini[atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[2024/8/7 9:25:22 689] t ok! (20240322)--------[atbm_log]:LMAC NOT SUPPORT 40M !!!
[2024/8/7 9:25:22 689] -----
[2024/8/7 9:25:22 689] atbm_log]:LMAC NOT SUPPORT LDPC !!!
[2024/8/7 9:25:22 689] mDEBUG: camera_set_saved_status OK!
[2024/8/7 9:25:22 705] DEBUG: [libautoscene]:Jul  5 2024 16:13:42 ,GENERAL
[2024/8/7 9:25:22 705] DEBUG: [libautoscene]:use libfvideo!
[2024/8/7 9:25:22 705] DEBUG: [libfvideo]:Jul  5 2024 15:41:09 
[2024/8/7 9:25:22 705] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:25:22 720] DEBUG: [libsdnc]:Aug 22 2023 13:55:14
[2024/8/7 9:25:22 720] DEBUG: LED: [IR] 
[2024/8/7 9:25:22 720] DEBUG: software LED
[2024/8/7 9:25:22 720] DEBUG: hardware pohtoR!
[2024/8/7 9:25:22 737] DEBUG: isp_sample over!
[2024/8/7 9:25:22 737] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:25:22 737] (656)[INFO]: AudioSwap=[0]
[2024/8/7 9:25:22 737] [1970-01-01 00:00:07] ==>IspKo: clean cut!
[2024/8/7 9:25:22 752]  XMJSON_GetInt(570)[INFO]: HighAdcValue: 0
[2024/8/7 9:25:22 754] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: LowAdcValue: 0
[2024/8/7 9:25:22 754] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: IRLightLevel: 0
[2024/8/7 9:25:22 769] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: InfraredSwap: 0
[2024/8/7 9:25:22 769] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: WhiteLightLevel: 0
[2024/8/7 9:25:22 784] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFIspKo: set cut 0x0 0xf00 0x1 0x871
[2024/8/7 9:25:22 784] O]: VideoHorizontalFlipGun: 0
[2024/8/7 9:25:22 800] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoVerticalFlipGun: 0
[2024/8/7 9:25:22 801] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: setMonocular: 1
[2024/8/7 9:25:22 801] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedX: 17
[2024/8/7 9:25:22 816] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedY: 17
[2024/8/7 9:25:22 816] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: soundValue: 50
[2024/8/7 9:25:22 832] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: lightChannel: 0
[2024/8/7 9:25:22 832] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: dayAndNightMode: 0
[2024/8/7 9:25:22 848] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: hardAndSoftLight: 1
[2024/8/7 9:25:22 848] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeX: 400
[2024/8/7 9:25:22 864] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeY: 200
[2024/8/7 9:25:22 864] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(587)[INFO]: RatioOfGear: 1:1
[2024/8/7 9:25:22 880] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(593)[INFO]: high 1: low 1
[2024/8/7 9:25:22 880] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(690)[INFO]: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:25:22 896] [1970-0[atbm_log]:wsm_generic_confirm:status(2)
[2024/8/7 9:25:22 896] 1-01 00:00:07] x[atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[2024/8/7 9:25:22 896] m_main.c(462) <GetVideoResolution>: Vide[atbm_log]:apollo wifi : can't open /data/.mac.info
[2024/8/7 9:25:22 912] o resolution: captrue wi[atbm_log]:efuse data is [0x1,0x38,0x15,0x16,0x16,0x8,0x0,0x0,0x90:0x31:0x4b:0xa5:0x16:0x50]
[2024/8/7 9:25:22 928] dth 2680 height [atbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[2024/8/7 9:25:22 928] 2160 resolution [atbm_log]:win txpower:0main: width 3840
[2024/8/7 9:25:22 928] [atbm_log]:use default power
[2024/8/7 9:25:22 928]  height 2160 extra:  width 640 height 360 [2]: width 640 height 224
[2024/8/7 9:25:22 944] [1970-01-01 00:00:07] MainApp.c(1812) <main>: version , date 20240724, time 182054, plus 0
[2024/8/7 9:25:22 960] [1970-01-01 00:00:07] ==> XMSDK_StartUp(174)[INFO]: XMSDK_StartUp enter, Jul 24 2024, 18:20[atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[2024/8/7 9:25:22 960] :55
[2024/8/7 9:25:22 960] atbm_log]:==read success==
[2024/8/7 9:25:22 960] 1;32m[1970-01-01[atbm_log]:set delta power
[2024/8/7 9:25:22 976]  00:00:07] ==> IspConfigInit(158)[INFO]: maxHeight 2160 maxWidth 3840 u32RsltType 8
[2024/8/7 9:25:22 976] [1970-01-01 00:00:07] ==> XMSDK_StartUp(203)[INFO]: g_stProductMgr.viMgr.ca[atbm_log]:get chip id [0][0][0] 
[2024/8/7 9:25:22 992] pW =[2680] g_stP[atbm_log]:current chiptype ATBM6062-U20-noLDPC 
[2024/8/7 9:25:22 992] roductMgr.viMgr.[atbm_log]:default country code:00,support channel=14
[2024/8/7 9:25:22 992] capH = [2160]
[2024/8/7 9:25:23 008]  tbm_log]:Use an internal power amplifier!
[2024/8/7 9:25:23 008] [0;39m
[2024/8/7 9:25:23 008] [1970-01-01 00:00:07] ==> XMSDK_S[atbm_log]:enable sg
[2024/8/7 9:25:23 008] tartUp(220)[INFO[atbm_log]:[eth2] has been disabled
[2024/8/7 9:25:23 024] ]: g_stProductMgr.vencMgr.vencChn[0].maxHeight =[2160] g_stProductMgr.encMgr.vencChn[0].maxWidth = [3840]
[2024/8/7 9:25:23 024] [1970-01-01 00:00:07] ==> XMSDK_StartUp(286)[INFO]: ispCfg.u3[atbm_log]:enable sg
[2024/8/7 9:25:23 024] 2Others 0x0
[2024/8/7 9:25:23 040] atbm_log]:[p2p0] has been disabled
[2024/8/7 9:25:23 040] ;39m
[2024/8/7 9:25:23 056] [1970-01-01 00:00:07] ==> XMSDK_StartUp(288)[INFO]: ispCfg.u32FunExt 0x0 u32Infrared 0x80000000 u32snsRsltType 0x0 u32RsltType 0x8 au32IrCut 0x80004c4e  au32SoftLed[0]: 0x800b0a11 u32Flag[atbm_log]:ble start
[2024/8/7 9:25:23 056] : 0x1 SensorRstI[atbm_log]:[ALTOBEAM-ble_recv] start
[2024/8/7 9:25:23 056] O: 0x800000a4 u3[atbm_log]:ble subscribe
[2024/8/7 9:25:23 056] 2ComsPort: 0x0
[2024/8/7 9:25:23 072] [atbm_log]:[ALTOBEAM-ble_xmit] start
[2024/8/7 9:25:23 072] [1970-01[atbm_log]:ble_platform_probe(c1ded480)
[2024/8/7 9:25:23 072] -01 00:00:38] ==[atbm_log]:is registered as 'ALTOBEAM'
[2024/8/7 9:25:23 088] > SampleCreate(1[atbm_log]:[atbm_wtd]:set wtd_probe = 1
[2024/8/7 9:25:23 088] 709)[INFO]: viChn:0 vstd:0 enterusbcore: registered new interface driver atbm_wlan
[2024/8/7 9:25:23 104] [1970-01-01 00:00:38] ==> ViChnConfig(866)[INFO]: set vichn 0 size [3840, 2160]
[2024/8/7 9:25:23 104] [1970-01-01 00:00:38] ==> ViChnConfig(866)[INFO]: set vichn 1 size [640, 360]
[2024/8/7 9:25:23 120] [1970-01-01 00:00:38] ==> ViChnConfig(866)[INFO]: set vichn 2 size [640, 224]
[2024/8/7 9:25:23 120] [1970-01-01 00:00:38] ==> VencChCreate(1058)[INFO]: channel:0 enter
[2024/8/7 9:25:23 136] [1970-01-01 00:00:38] ==> VencChCreate(1079)[INFO]: VcChn[0].vencMem = VENCMEM_MICRO
[2024/8/7 9:25:23 136] [1970-01-01 00:00:38] ==> COMM_VENC_Start(890)[INFO]: VencChn = 0,width = 3840,height = 2160,enType = 265
[2024/8/7 9:25:23 136] NORM ENC MODE
[2024/8/7 9:25:23 152] [1970-01-01 00:00:38] ==> VencChCreate(1079)[INFO]: VcChn[1].vencMem = VENCMEM_MICRO
[2024/8/7 9:25:23 169] [1970-01-01 00:00:38] ==> COMM_VENC_Start(890)[INFO]: VencChn = 1,width = 640,height = 360,enType = 265
[2024/8/7 9:25:23 169] NORM ENC MODE
[2024/8/7 9:25:23 169] aec 1; agc 1; ans 1
[2024/8/7 9:25:23 169] [1970-01-01 00:00:38] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 21,DestChnId = 0,DestModId = 23
[2024/8/7 9:25:23 184] [1970-01-01 00:00:38] ==> AudioCreate(1656)[INFO]: XM_AENC_CreateCH OK
[2024/8/7 9:25:23 184] [1970-01-01 00:00:38] ==> AudioCreate(1685)[INFO]: XM_MPI_ADEC_CreateChn OK
[2024/8/7 9:25:23 200] [1970-01-01 00:00:38DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:25:23 200] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:25:23 200] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:25:23 200] DEBUG: software pohtoR!
[2024/8/7 9:25:23 216] DEBUG: camera_set_photosensitive_chn 0 1 0x1
[2024/8/7 9:25:23 216] ] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 24,DestChnId = 0,DestModId = 22
[2024/8/7 9:25:23 232] [1970-01-01 00:00:38] ==> JPEGChCreate(1556)[INFO]: enter JPEGChCreate channel=0, VencChn = 3
[2024/8/7 9:25:23 248] [1970-01-01 00:00:38] ==> COMM_VENC_Start(890)[INFO]: VencChn = 3,width = 640,height = 360,enType = 26
[2024/8/7 9:25:23 249] [1970-01-01 00:00:38] ==> COMM_VENC_Start(913)[INFO]: set JpegAttr
[2024/8/7 9:25:23 264] [1970-01-01 00:00:38] ==> SysBind(2342)[INFO]: SrcChnId = 1,SrcModId = 7,DestChnId = 3,DestModId = 7
[2024/8/7 9:25:23 264] [1970-01-01 00:00:38] ==> COMM_VENC_Start(1032)[INFO]: JPEG_CHN[3] bind VENC_CHN[1] success!.
[2024/8/7 9:25:23 280] [1970-01-01 00:00:38] MainApp.c(1816) <main>: [1970-01-01 00:00:38] MainApp.c(1823) <main>: [1970-01-01 00:00:38] MainApp.c(1883) <main>: g_fps=[12]
[2024/8/7 9:25:23 296] [1970-01-01 00:00:38] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:25:23 312] [1970-01-01 00:00:38] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=0,brc=1,w=3840,h=2160,qua=4,frame=12,br=1000,gop=4
[2024/8/7 9:25:23 312] [1970-01-01 00:00:38] xm_main.c(700) <XM_SetCameraFactoryConfig>: Get AutoMantence flags [0] failed
[2024/8/7 9:25:23 328] [1970-01-01 00:00:38] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[0],wh[3840,2160]-----------
[2024/8/7 9:25:23 328] [1970-01-01 00:00:38] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:25:23 344] [1970-01-01 00:00:38] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=1,brc=1,w=640,h=360,qua=4,frame=9,br=256,gop=1
[2024/8/7 9:25:23 360] [1970-01-01 00:00:38] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[1],wh[640,360]-----------
[2024/8/7 9:25:23 360] [1970-01-01 00:00:38] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:25:23 376] [1970-01-01 00:00:38] MainApp.c(1885) <main>: [1970-01-01 00:00:38] MainApp.c(1893) <main>: 
[2024/8/7 9:25:23 376] [1970-01-01 00:00:38] MainApp.c(1898) <main>: 
[2024/8/7 9:25:23 392] [1970-01-01 00:00:38] xm_main.c(1899) <PtzControl_Pro>: 
[2024/8/7 9:25:23 392] PtzControl_Pro[1970-01-01 00:00:38] ==> XMSDK_MotorCreate(120)[INFO]: xlimit 5006, ylimit 2161
[2024/8/7 9:25:23 408] [1970-01-01 00:00:38] xm_main.c(1903) <PtzControl_Pro>: g_sPtz.xMaxStep 5006 g_sPtz.yMaxStep 2161 
[2024/8/7 9:25:23 408] [1970-01-01 00:00:38] xm_main.c(1747) <XM_RealVideo_Pro>: realy video play start___0
[2024/8/7 9:25:23 424] [1970-01-01 00:00:38] xm_main.c(1375) <XM_RealAudio_Pro>: real Audio play start___
[2024/8/7 9:25:23 424] [1970-01-01 00:00:38] ==> AudioInSetFormat(68)[INFO]: pFormat.EncodeTye = 2
[2024/8/7 9:25:23 440] [1970-01-01 00:00:38] ==> XMSDK_AudioInSetFormat(445)[INFO]: anr(1) agc(1) aec(0)
[2024/8/7 9:25:23 440] aec 0; agc 1; ans 1
[2024/8/7 9:25:23 440] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:25:23 456] [1970-01-01 00:00:38] xm_main.c(821) <XM_SetCameraFactoryConfig>: get default language ChineseEnglish
[2024/8/7 9:25:23 472] [1970-01-01 00:00:38] xm_main.c(822) <XM_SetCameraFactoryConfig>: get defult IRcurt reverse: no picture reverse mirror:yes filp:yes
[2024/8/7 9:25:23 472] [1970-01-01 00:00:38] xm_main.c(823) <XM_SetCameraFactoryConfig>: set defult motor ptz reverse  mirror:yes filp:no
[2024/8/7 9:25:23 487] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:25:23 488] [1970-01-01 00:00:38] xm_main.c(824) <XM_SetCameraFactoryConfig>: get defult autotrack motor reverse mirror:yes filp:no
[2024/8/7 9:25:23 503] [1970-01-01 00:00:38] xm_main.c(825) <XM_SetCameraFactoryConfig>: get defult ptz preset x:1556 y:950
[2024/8/7 9:25:23 504] [1970-01-01 00:00:38] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 0
[2024/8/7 9:25:23 519] [1970-01-01 00:00:38] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 0 OK
[2024/8/7 9:25:23 535] [1970-01-01 00:00:38] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 1
[2024/8/7 9:25:23 537] [1970-01-01 00:00:38] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 1 OK
[2024/8/7 9:25:23 552] [1970-01-01 00:00:38] xm_main.c(920) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:25:23 567] [1970-01-01 00:00:38] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:25:23 568] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[597],val=[1]
[2024/8/7 9:25:23 583] [1970-01-01 00:00:38DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:25:23 584] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:25:23 584] DEBUG: camera_set_photosensitive_chn 0 0 0x1
[2024/8/7 9:25:23 584] killall: hostapd: no process killed
[2024/8/7 9:25:23 600] ERR: v[atbm_log]:ioctl_open(c264d100)(c1ded480)
[2024/8/7 9:25:23 600] arLED_pwmGpioInit 970 gp[atbm_log]:atbm_ioctl_ble_start
[2024/8/7 9:25:23 648] io 11 not support PWM!DEBUG: camera_set_ledType:  2
[2024/8/7 9:25:23 648] DEBUG: camera_set_dnc_mode_chn 3 
[2024/8/7 9:25:23 648] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:25:23 648] DEBUG: LED: [IR] [WL] 
[2024/8/7 9:25:23 664] DEBUG: software LED
[2024/8/7 9:25:23 664] DEBUG: software pohtoR!
[2024/8/7 9:25:23 664] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:25:23 664] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:25:23 680] DEBUG: camera_set_ledHold: 60000
[2024/8/7 9:25:23 681] ] xm_main.c(969) <XM_SetCameraFactoryConfig>: get factory language ChineseEnglish
[2024/8/7 9:25:23 697] [1970-01-01 00:00:38] xm_main.c(970) <XM_SetCameraFactoryConfig>: get factory IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:25:23 697] [1970-01-01 00:00:38] xm_main.c(971) <XM_SetCameraFactoryConfig>: set factory motor ptz reverse  mirror:yes filp:yes
[2024/8/7 9:25:23 712] [1970-01-01 00:00:38] xm_main.c(972) <XM_SetCameraFactoryConfig>: get factory autotrack motor reverse mirror:no filp:no
[2024/8/7 9:25:23 728] [1970-01-01 00:00:38] xm_main.c(973) <XM_SetCameraFactoryConfig>: get factory ptz preset x:3110 y:0
[2024/8/7 9:25:23 745] [1970-01-01 00:00:38] xm_main.c(1007) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:25:23 747] [1970-01-01 00:00:38] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:25:23 761] [1970-01-01 00:00:38] xm_main.c(1040) <XM_SetCameraFactoryConfig>: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:25:23 777] [1970-01-01 00:00:38] xm_main.c(1060) <XM_SetCameraFactoryConfig>: set IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:25:23 777] [1970-01-01 00:00:38] xm_main.c(1078) <XM_SetCameraFactoryConfig>: camera_set_softIr_thr(1) ret=[0]
[2024/8/7 9:25:23 791] ************last intra 0
[2024/8/7 9:25:23 792] venc_encode[1184]:overflow bufsize =5ff00 streamlen=5ff02
[2024/8/7 9:25:23 792] ************last intra 0
[2024/8/7 9:25:23 792] [1970-01-01 00:00:38] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time8301
[2024/8/7 9:25:23 808] [1970-01-01 00:00:38] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 1985
[2024/8/7 9:25:23 808] [1970-01-01 00:00:38] MainApp.c(1900) <main>: 
[2024/8/7 9:25:23 824] [1970-01-01 00:00:38] MainApp.c(1905) <main>: 
[2024/8/7 9:25:23 824] [1970-01-01 00:00:38] utils.c(760) <ReadJsonConfig>: Get pClass:Register pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:25:23 839] [1970-01-01 00:00:38] ==> XMSDK_AudioSetSpeakerVol(641)[INFO]: enter: Speaker Open
[2024/8/7 9:25:23 839] [1970-01-01 00:00:38] MainApp.c(1913) <main>: 
[2024/8/7 9:25:23 855] [1970-01-01 00:00:38] ==> XMSDK_WifiInit(601)[INFO]: Wifi Init success
[2024/8/7 9:25:23 855] [1970-01-01 00:00:38] MainApp.c(1915) <main>: 
[2024/8/7 9:25:23 855] [1970-01-01 00:00:38] MainApp.c(1918) <main>: 
[2024/8/7 9:25:23 855] lib_ble_main_init
[2024/8/7 9:25:23 871] ======>>atbm_ble_start>>>
[2024/8/7 9:25:23 871] nimble_port_init++
[2024/8/7 9:25:23 871] nimble_host_task
[2024/8/7 9:25:23 871] ble_coexist_start--
[2024/8/7 9:25:23 871] hif_ioctl_loop
[2024/8/7 9:25:23 872] ble_hs_sync:333
[2024/8/7 9:25:23 872] ble_smart_cfg_startup!11
[2024/8/7 9:25:23 872] [ATBM lOG]set default tx power(0)
[2024/8/7 9:25:23 887] pub addr 90:31:4b:a5:16:51
[2024/8/7 9:25:23 887] [1970-01-01 00:00:38] MainApp.c(1922) <main>: ble_ret=[0]
[2024/8/7 9:25:23 888] [1970-01-01 00:00:38] MainApp.c(1200) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 903] [1970-01-01 00:00:39] MainApp.c(1229) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 903] [1970-01-01 00:00:39] MainApp.c(1258) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 919] [1970-01-01 00:00:39] MainApp.c(1260) <GetAndSetTyDefalutConfig>: SMLMode=[2]
[2024/8/7 9:25:23 920] [1970-01-01 00:00:39] MainApp.c(1263) <GetAndSetTyDefalutConfig>: g_SMLAbility=[0]
[2024/8/7 9:25:23 935] [1970-01-01 00:00:39] MainApp.c(1266) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 935] [1970-01-01 00:00:39] MainApp.c(1338) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 936] [1970-01-01 00:00:39] MainApp.c(1346) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 951] [1970-01-01 00:00:39] MainApp.c(1357) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 952] [1970-01-01 00:00:39] MainApp.c(1387) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 968] [1970-01-01 00:00:39] MainApp.c(1390) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:23 968] [1970-01-01 00:00:39] xm_ai.c(564) <XM_CreatePersionDetect>: 
[2024/8/7 9:25:23 968] [1970-01-01 00:00:39] xm_ai.c(574) <XM_CreatePersionDetect>: 
[2024/8/7 9:25:23 983] [1970-01-01 00:00:39] xm_ai.c(585) <XM_CreatePersionDetect>: 
[2024/8/7 9:25:23 984] [1970-01-01 00:00:39] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:25:24 000] [1970-01-01 00:00:39] xm_ai.c(588) <XM_CreatePersionDetect>: 
[2024/8/7 9:25:24 000] [1970-01-01 00:00:39] xm_ai.c(608) <XM_CreatePersionDetect>: 
[2024/8/7 9:25:24 016] [1970-01-01 00:00:39] xm_ai.c(645) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:25:24 112] [1970-01-01 00:00:39] xm_ai.c(646) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:39] xm_ai.c(647) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTime = [ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!ListMng - BufListCreate: index 1 OK
[2024/8/7 9:25:24 992] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:25:25 007] Mode(Product):0
[2024/8/7 9:25:25 007] BpuMode:[Online]
[2024/8/7 9:25:25 007] VpssMode:[Online]
[2024/8/7 9:25:25 007] [0.LimitUp_info]:
[2024/8/7 9:25:25 008] LimitUp:[Disable]
[2024/8/7 9:25:25 008] [2680*0]->[3840*0])
[2024/8/7 9:25:25 008] chn	TotalSize	ActiveSize
[2024/8/7 9:25:25 008] 0	5040*2246	2680*2160
[2024/8/7 9:25:25 023] 0	5040*2246	3840*2160
[2024/8/7 9:25:25 023] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:25:25 023] [1.VICU_info]:
[2024/8/7 9:25:25 023] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:25:25 023] 0	25.0	57	0	0	183	linear	8ddb00
[2024/8/7 9:25:25 024] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:25:25 039] en	op_type	m_chn	now
[2024/8/7 9:25:25 039] 0	1	1	1
[2024/8/7 9:25:25 039] [2.VI_info]:
[2024/8/7 9:25:25 039] chn	TotalSize	ActiveSize
[2024/8/7 9:25:25 040] 0	5040*2246	3848*2166
[2024/8/7 9:25:25 040] 1	   0*   0	   0*   0
[2024/8/7 9:25:25 040] [3.MIPI_info]:
[2024/8/7 9:25:25 055] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:25:25 056] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:25:25 056] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:25:25 056] [4.Cut_info]:
[2024/8/7 9:25:25 056] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:25:25 071] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:25:25 071] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:25:25 071] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:25:25 071] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:25:25 072] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:25:25 088] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:25:25 088] [5.IB(isp buffer info)]:
[2024/8/7 9:25:25 088] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:25:25 088] PoolId  Count  Size
[2024/8/7 9:25:25 104] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:25 104] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:25 104] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:25 120] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:25 121] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:25 136] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:25 136] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:25:25 136] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:25:25 153] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:25:25 153] 0       0         0          2          4       
[2024/8/7 9:25:25 153] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:25:25 168]      --265--            --264--                                               
[2024/8/7 9:25:25 168] Count      Line     Count      Line     
[2024/8/7 9:25:25 168] 35         437      79         560      
[2024/8/7 9:25:25 184] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:25:25 184] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:25:25 200] 0   3840   2160    H265  0      0        0           18        964918     18122    	
[2024/8/7 9:25:25 200] 1   640    360     H265  0      0        0           15        43195      5        	
[2024/8/7 9:25:25 216] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:25:25 216] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:25:25 232] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:25:25 232] 0   Y      18       1       0       14       1        17       17       30        63085         60779    66075    62747    0       
[2024/8/7 9:25:25 248] 1   Y      15       0       0       1        0        15       15       31        2546          2020     7002     3337     0       
[2024/8/7 9:25:25 264] 3   N      0        0       0       1        0        0        0        32        0             0        0        0        0       
[2024/8/7 9:25:25 264] DEBUG: autoscene chn[0]: Bw!
[2024/8/7 9:25:25 264] DEBUG: ***u16num***[512]
[2024/8/7 9:25:25 280] 8];src/ped_thread.c(746) [Smart_Ped_Create]: Smart_Ped_Create_ver: Jul 24 2024 18:21:40
[2024/8/7 9:25:25 280] src/ped_thread.c(656) [Ped_Init_IA_Work]: Ped_Init_IA_Work start ver:Jul 24 2024 18:21:40
[2024/8/7 9:25:25 296] [FUNC: IA_InitLog] Creat OK.
[2024/8/7 9:25:25 296] [INIT]: XM_IA_Init() done.
[2024/8/7 9:25:25 296] src/ped_thread.c(705) [Ped_Init_IA_Work]: ruler 0 region (0,0) (0,0) (0,0) (0,0)
[2024/8/7 9:25:25 312] [INIT]:LIBXMIA IAtype 700 Complied at May  8 2024 08:39:39 GIT_ID:cb3a4ed0
[2024/8/7 9:25:25 312] [INIT]: TD Version: TD_V_3.2.4.2[May 15 2024 19:14:32]
[2024/8/7 9:25:25 312] -- TD INIT -- 
[2024/8/7 9:25:25 312]  uiTdMaxNum: 12 
[2024/8/7 9:25:25 312]  acClassBinPath: /usr/bin 
[2024/8/7 9:25:25 312]  ePlatForm: 50 
[2024/8/7 9:25:25 328]  eDevImgType: 17 
[2024/8/7 9:25:25 328]  stDevImgSize: (2680,2160) 
[2024/8/7 9:25:25 328]  iTrackFlag: 1 
[2024/8/7 9:25:25 328]  iTrackType: 2 
[2024/8/7 9:25:25 328] -- TD EXTF -- 
[2024/8/7 9:25:25 328]  ucPedFallDownEnable: 0
[2024/8/7 9:25:25 328]  ucTDFeatureEnable: 0
[2024/8/7 9:25:25 328]  ucSmokeEnable: 0
[2024/8/7 9:25:25 328]  ucFaceDetEnable: 0
[2024/8/7 9:25:25 344]  ucFaceMaskEnable: 0
[2024/8/7 9:25:25 344]  ucFaceAngEnable: 0
[2024/8/7 9:25:25 344]  ucFaceRegEnable: 0
[2024/8/7 9:25:25 344]  ucPlateDetEnable: 0
[2024/8/7 9:25:25 344]  ucPlateRegEnable: 0
[2024/8/7 9:25:25 344]  ucPedPointEnable: 0
[2024/8/7 9:25:25 344]  ucHandPointEnable: 0
[2024/8/7 9:25:25 344]  ucHelmetEnable: 0
[2024/8/7 9:25:25 360]  ucHandgestureEnable: 0
[2024/8/7 9:25:25 360]  efdfreq: 10
[2024/8/7 9:25:25 360] [INIT]: XM_IA_TD_PED_S Version: 20230719_person_noexp_v200
[2024/8/7 9:25:25 360] [INIT] Alg Malloc Size 27232
[2024/8/7 9:25:25 360] -- TD CFG --  
[2024/8/7 9:25:25 360]  iMDFlag: 0
[2024/8/7 9:25:25 360]  ucDetectDisable: 0
[2024/8/7 9:25:25 360]  iDetectType: 5
[2024/8/7 9:25:25 376]  ePattern: 3
[2024/8/7 9:25:25 376]  eSensitivity: 2
[2024/8/7 9:25:25 376]  ucFishEyeCorrectFlag:0
[2024/8/7 9:25:25 376]  eRotate:0
[2024/8/7 9:25:25 376]  ucSationaryTd: 0
[2024/8/7 9:25:25 376]  ucClearnessFlg:0
[2024/8/7 9:25:25 376]  usInImgWidth:0
[2024/8/7 9:25:25 376]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:25:25 392] [CFG]: Rule:0 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:25:25 392] [CFG]: Rule:1 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:25:25 392] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:25:25 408] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:25:25 408] [CFG]: DEFAULT iBoundaryPtsNum 4 eAlarmDirect 2 (0 0) (8191 0) (8191 8191) (0 8191)
[2024/8/7 9:25:25 408] [1970-01-01 00:00:39] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 2003
[2024/8/7 9:25:25 424] [FUNC:PbdcnnConfig][L:578] (nil) 0xbec4a2f8 Pointer Null.
[2024/8/7 9:25:25 424] [INIT]: PdConfig pvHandle 0xb11f9000. Config OK
[2024/8/7 9:25:25 424] [INIT] Alg Malloc Size 30000
[2024/8/7 9:25:25 440] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:25:25 440] [1970-01-01 00:00:39] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 48232
[2024/8/7 9:25:25 456] [INIT]:memPoolSize 1351680.
[2024/8/7 9:25:25 456] V1.6.x date Sep  5 2023, time 23:32:25 npu load start
[2024/8/7 9:25:25 456] dpu version v1.1.0 build time Aug  5 2022
[2024/8/7 9:25:25 456] [INIT]: Update MemPoolSize 0 to 1351680.
[2024/8/7 9:25:25 472] [INIT]: MmzAlloc MemPoolSize 1351680 0xb1037000~0xb1181000.
[2024/8/7 9:25:25 472] 0 Model 0xa6ef7c MemPoolIdx 0 MemPoolInfo 0x6d5f10
[2024/8/7 9:25:25 472] [INIT]: version 20230719_person_noexp_v200, debug 0, profile 0
[2024/8/7 9:25:25 488] [INIT] Alg Malloc Size 240736
[2024/8/7 9:25:25 488] CNNMemory: 2064977 bulk 240736 mmz 1824241
[2024/8/7 9:25:25 488] CNNINIT INPUT IMAGESIZE:(640,224)
[2024/8/7 9:25:25 488] TD_DETECT stAlgImgSize (640,224) 
[2024/8/7 9:25:25 488] [INIT] Alg Malloc Size 60672
[2024/8/7 9:25:25 504] MdInit ok![INIT] Alg Malloc Size 79704
[2024/8/7 9:25:25 504] [FUNC: trackInit][L: 273] API_Creat_IMG 
[2024/8/7 9:25:25 504] [INIT]: PdInit pvHandle 0xa6edc0 *pvHandle 0xb11f9000 OK
[2024/8/7 9:25:25 504] IA_LOG 87c6a000 value 0
[2024/8/7 9:25:25 504] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:25:25 520] Ped_Init_IA_Work end 
[2024/8/7 9:25:25 520] src/ped_thread.c(774) [Smart_Ped_Create]: Create list success, index 1 maxsize 2
[2024/8/7 9:25:25 520] src/ped_thread.c(495) [PedProc_v2]: 
[2024/8/7 9:25:25 536] src/ped_thread.c(520) [PedProc_v2]: 
[2024/8/7 9:25:25 536] [FUNC: DetectTarget][L: 1489] API_Creat_IMG_MdInImg 
[2024/8/7 9:25:25 536] [FUNC: PbdcnnWork][L: 1084] API_Creat_CSCIMG 
[2024/8/7 9:25:25 552] [1970-01-01 00:00:39] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 168235
[2024/8/7 9:25:25 552] [1970-01-01 00:00:40] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 208131
[2024/8/7 9:25:25 568] [1970-01-01 00:00:40] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:25:25 568] [1970-01-01 00:00:40] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:25:25 584] src/ped_thread.c(803) [Smart_Ped_Create]: Ped_Creat Success @0x39e24
[2024/8/7 9:25:25 584] [1970-01-01 00:00:40] xm_ai.c(649) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:25:25 616] [1970-01-01 00:00:40] xm_ai.c(657) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:40] xm_ai.c(658) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTime = [8];-- TD CFG --  
[2024/8/7 9:25:25 616]  iMDFlag: 0
[2024/8/7 9:25:25 616]  ucDetectDisable: 0
[2024/8/7 9:25:25 616]  iDetectType: 5
[2024/8/7 9:25:25 616]  ePattern: 3
[2024/8/7 9:25:25 616]  eSensitivity: 0
[2024/8/7 9:25:25 616]  ucFishEyeCorrectFlag:0
[2024/8/7 9:25:25 632]  eRotate:0
[2024/8/7 9:25:25 632]  ucSationaryTd: 0
[2024/8/7 9:25:25 632]  ucClearnessFlg:0
[2024/8/7 9:25:25 632]  usInImgWidth:0
[2024/8/7 9:25:25 632]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:25:25 632] [CFG]: Rule:0 ucRuleEnable:[MMZ] BUILD TIME:[Jul 14 2021 15:42:31]
[2024/8/7 9:25:25 648] [0x83400000--------0x88000000]
[2024/8/7 9:25:25 648] --START-----------SIZE----------------OVERFLOW----NAME---------------
[2024/8/7 9:25:25 648] 0x83400000	0xbde000  (12152k)	0	vb[bdd800][0]
[2024/8/7 9:25:25 648] 0x83fde000	0xbde000  (12152k)	0	vb[bdd800][1]
[2024/8/7 9:25:25 664] 0x84bbc000	0xbde000  (12152k)	0	vb[bdd800][2]
[2024/8/7 9:25:25 664] 0x8579a000	0x55000   (  340k)	0	vb[54600][0]
[2024/8/7 9:25:25 664] 0x857ef000	0x55000   (  340k)	0	vb[54600][1]
[2024/8/7 9:25:25 664] 0x85844000	0x35000   (  212k)	0	vb[34800][0]
[2024/8/7 9:25:25 680] 0x85879000	0x35000   (  212k)	0	vb[34800][1]
[2024/8/7 9:25:25 680] 0x858ae000	0x24000   (  144k)	0	isp_nr_alpha_ch0
[2024/8/7 9:25:25 680] 0x858d2000	0x163000  ( 1420k)	0	isp_nr_idx_ch0
[2024/8/7 9:25:25 696] 0x85a35000	0x1000    (    4k)	0	isp_nr_idx_max_ch0
[2024/8/7 9:25:25 696] 0x85a36000	0x84f000  ( 8508k)	0	isp_nr_fetch_ch0
[2024/8/7 9:25:25 696] 0x86285000	0x2000    (    8k)	0	isp_defog_ch0
[2024/8/7 9:25:25 696] 0x86287000	0xc24000  (12432k)	0	vencRfcFrame[0]
[2024/8/7 9:25:25 712] 0x86eab000	0xc24000  (12432k)	0	vencRfcFrame[1]
[2024/8/7 9:25:25 712] 0x87acf000	0xf1000   (  964k)	0	stream_chn[0]
[2024/8/7 9:25:25 712] 0x87bc0000	0x4c000   (  304k)	0	vencWrapLuma[0]
[2024/8/7 9:25:25 712] 0x87c0c000	0x26000   (  152k)	0	vencWrapChroma[0]
[2024/8/7 9:25:25 728] 0x87c32000	0xb000    (   44k)	0	stream_chn[1]
[2024/8/7 9:25:25 728] 0x87c3d000	0x2b000   (  172k)	0	stream_chn[3]
[2024/8/7 9:25:25 728] 0x87c68000	0x1000    (    4k)	0	osd_block[0]
[2024/8/7 9:25:25 728] 0x87c69000	0x1000    (    4k)	0	osd_block[4]
[2024/8/7 9:25:25 744] 0x87c6a000	0x1000    (    4k)	0	IA_LOG
[2024/8/7 9:25:25 744] 0x87c6b000	0x7000    (   28k)	0	IA_MANAGE_1
[2024/8/7 9:25:25 744] 0x87c72000	0x8000    (   32k)	0	IA_MANAGE_2
[2024/8/7 9:25:25 744] 0x87c7a000	0x70000   (  448k)	0	firm_mem_0
[2024/8/7 9:25:25 760] 0x87cea000	0x14b000  ( 1324k)	0	mempool_1
[2024/8/7 9:25:25 760] 0x87e35000	0x1000    (    4k)	0	dst_mem_1
[2024/8/7 9:25:25 760] 0x87e36000	0x1000    (    4k)	0	dst_mem_2
[2024/8/7 9:25:25 760] 0x87e37000	0x3000    (   12k)	0	dst_mem_3
[2024/8/7 9:25:25 760] 0x87e3a000	0x1000    (    4k)	0	dst_mem_4
[2024/8/7 9:25:25 776] 0x87e3b000	0x14000   (   80k)	0	IA_MANAGE_3
[2024/8/7 9:25:25 776] 0x87e4f000	0x35000   (  212k)	0	IA_Image_1
[2024/8/7 9:25:25 776] 0x87e84000	0x6a000   (  424k)	0	IA_Image_2
[2024/8/7 9:25:25 776] 0x87eee000	0x112000  ( 1096k)	1	
[2024/8/7 9:25:25 792] ---------------------------------------------------------------------
[2024/8/7 9:25:25 792] SIZE: 0x4c00000(77824k)  USED: 0x4aee000(76728k)  FREE: 0x112000(1096k)
[2024/8/7 9:25:25 792] 1 AlarmType:0 eRuleType:1
[2024/8/7 9:25:25 808] [CFG]: IA_PERIMETER_V1 iBoundaryPtsNum 4 eAlarmDirect 0 (0 0) (8191 0) (8191 8191) (0 8191) [CFG]: Rule:1 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:25:25 808] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:25:25 824] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:25:25 824] [INIT]: PdConfig pvHandle 0xb11f9000. Config OK
[2024/8/7 9:25:25 824] IA_LOG 87c6a000 value 0
[2024/8/7 9:25:25 824] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:25:25 840] src/ped_thread.c(831) [Smart_Ped_SetParam]: Ped_SetParam Success
[2024/8/7 9:25:25 840] [1970-01-01 00:00:40] xm_ai.c(666) <XM_CreatePersionDetect>: 
[2024/8/7 9:25:25 840] [1970-01-01 00:00:40] xm_ai.c(674) <XM_CreatePersionDetect>: 
[2024/8/7 9:25:25 856] [1970-01-01 00:00:40] MainApp.c(1395) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:25 856] [1970-01-01 00:00:40] MainApp.c(1397) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:25 872] [1970-01-01 00:00:40] MainApp.c(1402) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:25 872] [1970-01-01 00:00:40] MainApp.c(1481) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:25 888] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 60 enable 0 volume
[2024/8/7 9:25:25 888] [1970-01-01 00:00:40] MainApp.c(1525) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:25 888]  PTZPreset is empty!
[2024/8/7 9:25:25 904]  PTZPreset is empty!
[2024/8/7 9:25:25 904] [1970-01-01 00:00:40] MainApp.c(1554) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:25 920] [1970-01-01 00:00:40] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:25:25 920] [1970-01-01 00:00:40] MainApp.c(1568) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:25 936] [1970-01-01 00:00:40] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:25:25 952] [1970-01-01 00:00:40] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:25:25 952] [1970-01-01 00:00:40] MainApp.c(1584) <GetAndSetTyDefalutConfig>: cruisetime_pro create!
[2024/8/7 9:25:25 968] [1970-01-01 00:00:40] MainApp.c(1607) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:25:25 968] [1970-01-01 00:00:40] MainApp.c(1925) <main>: 
[2024/8/7 9:25:25 968] [1970-01-01 00:00:40] MainApp.c(1116) <GetRegisterMode>: -------- register mode 1
[2024/8/7 9:25:25 984] [1970-01-01 00:00:40] MainApp.c(1927) <main>: 
[2024/8/7 9:25:25 984] [1970-01-01 00:00:40] MainApp.c(1930) <main>: 
[2024/8/7 9:25:25 984] *************
[2024/8/7 9:25:25 984]  0x6d123c 
[2024/8/7 9:25:25 984] *****************
[2024/8/7 9:25:25 984]  0x3287c 
[2024/8/7 9:25:26 000] *****************
[2024/8/7 9:25:26 001] beginend[1970-01-01 00:00:40] MainApp.c(1938) <main>: 
[2024/8/7 9:25:26 001] [1970-01-01 00:00:40] MainApp.c(866) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:25:26 016] [1970-01-01 00:00:40] MainApp.c(174) <GetDeviceHWInfo>: Get Hwinfo APP_ID [fvijo8jvloagv1gm], UUID[uuidcaab27b0a838d239] AUTHKEY [j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:25:26 032] [1970-01-01 00:00:40] MainApp.c(909) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:25:26 032] [1970-01-01 00:00:40] MainApp.c(942) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:25:26 032] [1970-01-01 00:00:40] MainApp.c(986) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:25:26 048] [1970-01-01 00:00:40] MainApp.c(1019) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:25:26 048] sdk start
[2024/8/7 9:25:26 064] [1970-01-01 00:00:40] MainApp.c(752) <tuya_ipc_sdk_start>: log_level 0[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/mtd/Config/ty/ 
[2024/8/7 9:25:26 064] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/mtd/Config/ty/
[2024/8/7 9:25:26 064] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/mtd/Config/ty/
[2024/8/7 9:25:26 080] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[2024/8/7 9:25:26 080] [01-01 18:12:15 TUYA D][simplekv.c:999] normal file exist. bak file not exist
[2024/8/7 9:25:26 097] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[2024/8/7 9:25:26 097] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[2024/8/7 9:25:26 097] [01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file
[2024/8/7 9:25:26 112] [01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade
[2024/8/7 9:25:26 112] [01-01 18:12:15 TUYA D][simplekv.c:555] head check success
[2024/8/7 9:25:26 128] [01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success
[2024/8/7 9:25:26 128] [01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success
[2024/8/7 9:25:26 144] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[2024/8/7 9:25:26 144] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[2024/8/7 9:25:26 144] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[2024/8/7 9:25:26 160] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[2024/8/7 9:25:26 160] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[2024/8/7 9:25:26 176] [01-01 18:12:15 TUYA D][mqc_ap[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:25:26 176] p.c:144] mq_pro:31 cnt:2
[2024/8/7 9:25:26 176] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[2024/8/7 9:25:26 192] [01-01 18:12:15 TUYA E][log_seq.c:863] open err
[2024/8/7 9:25:26 192] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[2024/8/7 9:25:26 208] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[2024/8/7 9:25:26 208] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[2024/8/7 9:25:26 224] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[2024/8/7 9:25:26 224] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 224] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:25:26 256] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:25:26 256] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:25:26 272] [01-01 18:1[atbm_log]:eth2:free authen bss ++
[2024/8/7 9:25:26 272] 2:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
[2024/8/7 9:25:26 272] uuid: 20
[2024/8/7 9:25:26 272] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:25:26 272] devid_tmp: 16
[2024/8/7 9:25:26 288] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:25:26 288] devid_tmp2: 20
[2024/8/7 9:25:26 288] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:25:26 304] [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:25:26 304] dev id key: 16
[2024/8/7 9:25:26 304] d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[2024/8/7 9:25:26 304] --- tracepoint bt_ext_porting.c,tuya_ext_bt_port_init(464): tuya_ext_bt_port_init ---
[2024/8/7 9:25:26 320] [01-01 18:12:15 TUYA I][bt_ext_porting.c:466] [TUYA-BTUART]tuya ext bt port init
[2024/8/7 9:25:26 320] --- tracepoint bt_uart_drv.c,tuya_bt_uart_open(187): tuya_bt_uart_open ---
[2024/8/7 9:25:26 336] --- tracepoint bt_uart_drv.c,tuya_bt_uart_init(60): tuya_bt_uart_init  0 ---
[2024/8/7 9:25:26 336] --- tracepoint bt_ext_porting.c,ty_btext_thread(370):  ---
[2024/8/7 9:25:26 352] [01-01 18:12:15 TUYA I][bt_ext_porting.c:485] [TUYA-BTUART]thread ty_btext_thread create cplt mode 1
[2024/8/7 9:25:26 352] [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[2024/8/7 9:25:26 352] [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[2024/8/7 9:25:26 368] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish
[2024/8/7 9:25:26 368] [1970-01-01 00:00:40] MainApp.c(822) <tuya_ipc_sdk_start>: create ring buffer start 
[2024/8/7 9:25:26 384] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:0 Enable:1
[2024/8/7 9:25:26 384] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 2048, video_fps 12
[2024/8/7 9:25:26 400] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr0 bitrate:2048 fps:12
[2024/8/7 9:25:26 400] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 2621440 bytes for ch0st0tr0, max frame size 393216
[2024/8/7 9:25:26 416] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr0 size:2621440 nodes:120
[2024/8/7 9:25:26 416] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:0
[2024/8/7 9:25:26 432] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:1 Enable:1
[2024/8/7 9:25:26 432] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 1024, video_fps 12
[2024/8/7 9:25:26 448] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr1 bitrate:1024 fps:12
[2024/8/7 9:25:26 448] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1310720 bytes for ch0st0tr1, max frame size 196608
[2024/8/7 9:25:26 464] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr1 size:1310720 nodes:120
[2024/8/7 9:25:26 464] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:1
[2024/8/7 9:25:26 480] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:2 Enable:0
[2024/8/7 9:25:26 480] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:3 Enable:0
[2024/8/7 9:25:26 481] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:4 Enable:0
[2024/8/7 9:25:26 496] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:5 Enable:0
[2024/8/7 9:25:26 496] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:6 Enable:0
[2024/8/7 9:25:26 512] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:7 Enable:0
[2024/8/7 9:25:26 512] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:8 Enable:0
[2024/8/7 9:25:26 528] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:9 Enable:1
[2024/8/7 9:25:26 528] [01-01 18:12:15 TUYA D][MainApp.c:439] audio_sample 8000, audio_databits 16, audio_fps 25
[2024/8/7 9:25:26 544] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[2024/8/7 9:25:26 544] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[2024/8/7 9:25:26 560] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[2024/8/7 9:25:26 560] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:9
[2024/8/7 9:25:26 576] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:10 Enable:0
[2024/8/7 9:25:26 576] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:11 Enable:0
[2024/8/7 9:25:26 576] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:12 Enable:0
[2024/8/7 9:25:26 592] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:13 Enable:0
[2024/8/7 9:25:26 592] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:14 Enable:0
[2024/8/7 9:25:26 608] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:15 Enable:0
[2024/8/7 9:25:26 608] [1970-01-01 00:00:40] MainApp.c(830) <tuya_ipc_sdk_start>: pRunInfo->net_info.connect_mo[atbm_log]:[eth2] change to [3]
[2024/8/7 9:25:26 624] de 1[01-01 1[atbm_log]:[eth2] has been disabled
[2024/8/7 9:25:26 624] 8:12:15 TUYA D][[atbm_log]:add iftype(6),if_cnt(2),flags(c24e3bf8)
[2024/8/7 9:25:26 624] simplekv.c:1211][atbm_log]:enable sg
[2024/8/7 9:25:26 640]  read key:gw_bi [atbm_log]:[mon.eth2] has been disabled
[2024/8/7 9:25:26 640] isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 640] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:25:26 640] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:25:26 656] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:25:26 656] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[2024/8/7 9:25:26 672] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1776] Last reset reason: 255
[2024/8/7 9:25:26 672] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 672] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:25:26 688] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:25:26 688] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:25:26 704] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 704] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:26 704] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:26 720] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:26 720] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:26 720] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:25:26 735] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1140] serial_no:90314ba51650
[2024/8/7 9:25:26 735] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 751] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:25:26 752] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:25:26 752] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[2024/8/7 9:25:26 767] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1171] gw_cntl.gw_wsm.stat:0
[2024/8/7 9:25:26 768] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 768] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[2024/8/7 9:25:26 783] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[2024/8/7 9:25:26 784] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:648] <__gw_upd_nc_type> bcustom_mode:0, old_wf_start_mode: 0
[2024/8/7 9:25:26 799] [01-01 18:12:15 TUYA N][tuya_devos_netcf[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:25:26 800] g.c:1347] gw_cnt[atbm_log]:[WSM] Drop frame
[2024/8/7 9:25:26 800] l->gw_wsm.nc_tp:2
[2024/8/7 9:25:26 815] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1348] gw_cntl->gw_wsm.md:0
[2024/8/7 9:25:26 815] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 816] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 9:25:26 831] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 9:25:26 831] [01-01 18:12:15 TUYA D][ws_db_gw.c:515] gw_di read success
[2024/8/7 9:25:26 847] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 847] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:26 847] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:26 863] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:26 864] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:788] stride from flash: 0.
[2024/8/7 9:25:26 880] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:795] no actived, no upgrade:0
[2024/8/7 9:25:26 881] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1230] gw_cntl.gw_if.abi:0 input:0
[2024/8/7 9:25:26 895] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1231] gw_cntl.gw_if.product_key:fvijo8jvloagv1gm, input:fvijo8jvloagv1gm
[2024/8/7 9:25:26 895] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1232] gw_cntl.gw_if.tp:0, input:0
[2024/8/7 9:25:26 896] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:25:26 911] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 9:25:26 912] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[2024/8/7 9:25:26 912] [01-01 18:12:15 TUYA D][ws_db_gw.c:640] gw_ai read success
[2024/8/7 9:25:26 928] [01-01 18:12:15 TUYA D][uni_netwo[atbm_log]:[eth2] start driver he ap
[2024/8/7 9:25:26 928] rk.c:417] set_dn[atbm_log]:BSS_CHANGED_BEACON
[2024/8/7 9:25:26 928] s_region:0
[2024/8/7 9:25:26 928] [01[atbm_log]:change ds_params channel 6 
[2024/8/7 9:25:26 943] -01 18:12:15 TUYA D][tuya_devos_entry.c:1798] enter success_proc
[2024/8/7 9:25:26 944] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[2024/8/7 9:25:26 960] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[2024/8/7 9:25:26 960] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[2024/8/7 9:25:26 976] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[2024/8/7 9:25:26 976] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[2024/8/7 9:25:26 976] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[2024/8/7 9:25:26 992] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[2024/8/7 9:25:26 992] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[2024/8/7 9:25:26 992] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[2024/8/7 9:25:27 008] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[2024/8/7 9:25:27 008] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[2024/8/7 9:25:27 024] [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[2024/8/7 9:25:27 024] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[2024/8/7 9:25:27 136] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}
[2024/8/7 9:25:27 152] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:116] sys add timer: 14
[2024/8/7 9:25:27 152] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:122] sys start timer: 14
[2024/8/7 9:25:27 152] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[2024/8/7 9:25:27 167] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[2024/8/7 9:25:27 167] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[2024/8/7 9:25:27 168] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[2024/8/7 9:25:27 183] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:fvijo8jvloagv1gm 0
[2024/8/7 9:25:27 184] uuid: 20
[2024/8/7 9:25:27 184] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:25:27 184] dev_id_tmp: 16
[2024/8/7 9:25:27 199] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:25:27 200] dev_id_tmp2: 20
[2024/8/7 9:25:27 200] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:25:27 215] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[2024/8/7 9:25:27 216] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:25:27 216] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1066] nc_tp:2, md:0
[2024/8/7 9:25:27 232] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1297] dev_nw_cfg_active_stage:2
[2024/8/7 9:25:27 232] [01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[2024/8/7 9:25:27 248] [1970-01-01 00:00:41] MainApp.c(838) <tuya_ipc_sdk_start>: [01-01 18:12:15 TUYA D][MainApp.c:854] tuya ipc sdk start is complete
[2024/8/7 9:25:27 248] [1970-01-01 00:00:41] MainApp.c(1028) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:25:27 265] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:25:27 265] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:25:27 280] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:25:27 280] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[2024/8/7 9:25:27 280] killall: hostapd: no process killed
[2024/8/7 9:25:27 280] route: netmask and route address conflict
[2024/8/7 9:25:27 296] DEBUG: ***u16num***[329]
[2024/8/7 9:25:27 296] DEBUG: ***u16num***[512]
[2024/8/7 9:25:27 312] [1970-01-01 00:00:41] MainApp.c(1053) <TUYA_IPC_SDK_START>: pthread_create BasicIndicatorTimer suc
[2024/8/7 9:25:27 312] [1970-01-01 00:00:41] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [0] change to [1]
[2024/8/7 9:25:27 327] 
[2024/8/7 9:25:27 329] [1970-01-01 00:00:41] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [0] change to [1]
[2024/8/7 9:25:27 329] [1970-01-01 00:00:41] MainApp.c(1968) <main>: FLIP
[2024/8/7 9:25:27 343] [1970-01-01 00:00:41] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [1] change to [0]
[2024/8/7 9:25:27 359] [1970-01-01 00:00:41] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [1] change to [0]
[2024/8/7 9:25:27 359] [1970-01-01 00:00:41] MainApp.c(1972) <main>: FLIP
[2024/8/7 9:25:27 359] [1970-01-01 00:00:41] MainApp.c(1622) <PostInit>: 
[2024/8/7 9:25:27 375] src/intelligent_track_thread.c(1398) [XM_SmartBodyTarckCreate]: 
[2024/8/7 9:25:27 375] src/intelligent_track_thread.c(1374) [Smart_Track_GetAbility]: 
[2024/8/7 9:25:27 375] src/intelligent_track_thread.c(1379) [Smart_Track_GetAbility]: 
[2024/8/7 9:25:27 392] src/intelligent_track_thread.c(1272) [GetMotorCtrlPara]: 
[2024/8/7 9:25:27 392] src/intelligent_track_thread.c(1277) [GetMotorCtrlPara]: 
[2024/8/7 9:25:27 408] src/intelligent_track_thread.c(1283) [GetMotorCtrlPara]: 
[2024/8/7 9:25:27 408] src/intelligent_track_thread.c(1298) [GetMotorCtrlPara]: max_steps_x=5006 ,max_steps_y=2161
[2024/8/7 9:25:27 408] src/intelligent_track_thread.c(1301) [GetMotorCtrlPara]: 
[2024/8/7 9:25:27 425] src/intelligent_track_thread.c(1307) [GetMotorCtrlPara]: 
[2024/8/7 9:25:27 425] src/intelligent_track_thread.c(1323) [GetMotorCtrlPara]: 
[2024/8/7 9:25:27 441] src/intelligent_track_thread.c(1336) [GetMotorCtrlPara]: track_default_degrees_y=95
[2024/8/7 9:25:27 441] src/intelligent_track_thread.c(1345) [GetMotorCtrlPara]: LoadTrackSet Motor_x_turnover:no
[2024/8/7 9:25:27 457] src/intelligent_track_thread.c(1346) [GetMotorCtrlPara]: LoadTrackSet Motor_y_turnover:no
[2024/8/7 9:25:27 472] src/intelligent_track_thread.c(1348) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 540
[2024/8/7 9:25:27 472] src/intelligent_track_thread.c(1367) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 400
[2024/8/7 9:25:27 488] src/intelligent_track_thread.c(1368) [GetMotorCtrlPara]: LoadTrackSet HEIGHT_STEP = 200
[2024/8/7 9:25:27 601] src/intelligent_track_thread.c(1390) [Smart_Track_GetAbility]: Track_Ability : Enable
[2024/8/7 9:25:27 616] src/intelligent_track_thread.c(1451) [XM_SmartBodyTarckCreate]: Intelligent Track_pthread create Success 1920x1080
[2024/8/7 9:25:27 616] src/intelligent_track_thread.c(667) [TrackProcV200]: 
[2024/8/7 9:25:27 631] [1970-01-01 00:00:41] MainApp.c(277) <BasicIndicatorTimer>: BasicIndicatorTimer start ----
[2024/8/7 9:25:27 631] [1970-01-01 00:00:41] MainApp.c(1640) <PostInit>: ln -s /mnt/mtd/Log/sofia.log /tmp/tuya.log
[2024/8/7 9:25:27 647] [1970-01-01 00:00:41] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:25:27 648] [1970-01-01 00:00:41] MainApp.c(1665) <PostInit>: MotionDetect Sensitive 1 set onvif_on_off:0 
[2024/8/7 9:25:27 648] curr event:3 
[2024/8/7 9:25:27 664] IPC_APP_Notify_LED_Sound_Status_CB line(480) -------------------------- IPC_START_WIFI_AP_CFG(3)
[2024/8/7 9:25:27 664] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-1650
[2024/8/7 9:25:27 679] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:25:27 679] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:25:27 679] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:25:27 695] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:25:27 695] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:25:27 711] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:25:27 711] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[2024/8/7 9:25:27 711] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[2024/8/7 9:25:27 727] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[2024/8/7 9:25:27 727] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:25:27 743] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:25:27 743] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:27 744] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:27 759] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:27 759] DEBUG: ***u16num***[512]
[2024/8/7 9:25:27 759] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:27 775] [01-01 18:12:16 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:25:27 776] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:27 791] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:27 792] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:27 792] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:27 807] [01-01 18:12:16 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:25:27 807] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:25:27 807] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:27 823] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:27 823] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:27 839] [01-01 18:12:16 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:25:27 839] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[2024/8/7 9:25:27 855] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:25:27 855] udhcpd (v1.22.1) started
[2024/8/7 9:25:27 855] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:25:27 871] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:2  -->>
[2024/8/7 9:25:27 871] __IPC_APP_Get_Net_Status_cb line(193) -------------------------- stat(2)==STAT_AP_STA_UNCFG 
[2024/8/7 9:25:27 887] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:2  <<--
[2024/8/7 9:25:27 888] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:25:27 903] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:25:27 903] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:25:27 903] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:27 919] [01-01 18:12:16 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:27 919] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[2024/8/7 9:25:27 935] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 9:25:27 935] [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 9:25:27 951] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:21504,priority:5
[2024/8/7 9:25:27 951] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[2024/8/7 9:25:27 967] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[2024/8/7 9:25:28 048] [01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[2024/8/7 9:25:28 048] [01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:25:28 048] dev id key: 16
[2024/8/7 9:25:28 064] d0 7d 89 57 d1 c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 9:25:28 064] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:25:28 064] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:25:28 080] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:25:28 080] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:25:28 096] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:25:28 097] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 9:25:28 112] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0xb19030),len(28)
[2024/8/7 9:25:28 112] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 9:25:28 128] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:25:28 130] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0xb19050),len(30)
[2024/8/7 9:25:28 130] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 9:25:28 145] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:25:28 145] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 9:25:28 145] adv_len:28
[2024/8/7 9:25:28 156] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:25:28 164] svc_data_uu+$«Kj¤´´5jmƊºjj҂Ң騕¥¹¹¡ʺJ᪅¥¹⺅¥с2½Ɂ:}٥=¹±¥¹rrrj¤´´jmۑښ²jµjjڅԋ«VW.W­®YQ¼W«L¦LLWrc=[0]
[2024/8/7 9:25:28 164]  ---
[2024/8/7 9:25:28 183] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 9:25:28 183] rsp_len:30
[2024/8/7 9:25:28 183] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:25:28 183] mfg_data`len:30
[2024/8/7 9:25:28 195] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 9:25:28 195] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 9:25:28 195] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 9:25:28 195] [1970-01-01 00:00:42] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:28 211] ---[XmBlmAdvertiseEx][1241]: rc=[0]
[2024/8/7 9:25:28 211] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 9:25:28 211] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 9:25:28 224] [1970-01-01 00:00:42] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:28 240] adv_star𫇏x0
[2024/8/7 9:25:28 240] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 9:25:28 240] [01-01 18:&§L$UU«(HQW«]+ꅡɕ¹钪ꢅɕ骑==ڍ*хʑ¹Uс¢½չ¹¥¹хϵjR´jÒҊ²¢U 
[2024/8/7 9:25:28 259]                                                             ɪµE֥}±}e¹麒º蒱 
[2024/8/7 9:25:28 259]        ف22΁¡¹5jR´jÒҊ²¢U 
[2024/8/7 9:25:28 259]        TµE֥}ٽ̽ѥمѕ¹ 銂ªꋉ 
[2024/8/7 9:25:28 259]      ѥٕ*¹فɽ±¥½¹rձ±5jR´jÒҊ²¢U 
[2024/8/7 9:25:28 273]                            Tµ5¥µq­ٹ銚¢ê"±ѕZ橢±̽}¹сJ˙֩ꦩjԤhjÒҊ²¢U 
[2024/8/7 9:25:28 273]                                                              Tµ5¥µq­ٹ銚ª¢蚹ҩ"±ѕ¥ҿÿ¹ len:1
[2024/8/7 9:25:28 273] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:28 287] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:28 287] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:28 287] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:28 303] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:28 303] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:28 319] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:28 319] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:28 319] [01-01 18:12:16 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:28 335] [01-01 18:12:16 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:28 335] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:28 367] [01-01 18:12:16 TUYA D][iot_httpc.c:151󻫻"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:28 367] [01-01 18:12:16 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:28 383] [01-01 18:12:16 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:28 383] [01-01 18:12:16 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:28 383] gethostbyname_r error: Unknown host
[2024/8/7 9:25:28 399] [01-01 18:12:16 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:28 399] [01-01 18:12:16 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:28 399] [01-01 18:12:16 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:28 415] [01-01 18:12:16 TUYA E][httXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:28 432] [01-01 18:12:16 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:28 432] [01-01 18:12:16 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:28 440] [01-01 18:12:16 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:28 451] [01-0猜12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:28 451] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:25:28 451] DEBUG: ***u16num***[512]
[2024/8/7 9:25:28 467] DEBUG: ***u16num***[512]
[2024/8/7 9:25:28 468] [1970-01-01 00:00:42] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time12435
[2024/8/7 9:25:28 484] [1970-01-01 00:00:42] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:28 500] [1970-01-01 00:00:42] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:28 515] [1970-01-01 00:00:42] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:28 516] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:25:28 516] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:28 532] [01-01 18:12:17 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:28 532] DEBUG: ***u16num***[512]
[2024/8/7 9:25:28 548] [1970-01-01 00:00:43] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:28 548] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:25:28 563] [01-01 18:12:17 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:25:28 563] [01-01 18:12:17 TUYA D][tuya_ble_api.c:1470] ble get conn stat:4
[2024/8/7 9:25:28 564] [01-01 18:12:17 TUYA N][tuya_ble_api.c:750] ble_sdk_send skip, no connect:4
[2024/8/7 9:25:28 580] [1970-01-01 00:00:43] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:25:28 580] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:28 596] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:28 596] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:28 611] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:28 612] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:28 612] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:28 628] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:28 628] [01-01 18:12:17 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:28 644] [01-01 18:12:17 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:28 645] [01-01 18:12:17 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:28 645] [01-01 18:12:17 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:28 661] [01-01 18:12:17 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:28 661] [01-01 18:12:17 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:28 676] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:28 700] [01-01 18:12:17 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:28 700] [01-01 18:12:17 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:28 708] [01-01 18:12:17 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:28 708] [01-01 18:12:17 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:28 724] gethostbyname_r error: Unknown host
[2024/8/7 9:25:28 724] [01-01 18:12:17 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:28 724] [01-01 18:12:17 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:28 740] [01-01 18:12:17 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:28 740] [01-01 18:12:17 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:28 756] [01-01 18:12:17 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:28 756] [01-01 18:12:17 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:28 772] [01-01 18:12:17 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:28 772] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:28 772] DEBUG: ***u16num***[512]
[2024/8/7 9:25:28 788] DEBUG: ***u16num***[512]
[2024/8/7 9:25:28 804] [1970-01-01 00:00:43] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:28 821] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:28 821] [01-01 18:12:18 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:28 947] DEBUG: ***u16num***[512]
[2024/8/7 9:25:29 155] DEBUG: ***u16num***[512]
[2024/8/7 9:25:29 370] ۍjmƊºjj҂Ң¢낵}ݥ¥¹¡²Jフ󔌍Eɍ½フ󔌍Eɍ½ʍ%5늖¤ʫV$®¬[Y®]¬Y®.HW--$&$ZYZ-¤&&$YXºX«WC£+L[£«&¦[«LN¦	SS	S$&L'LL4] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once fra񝫙®.HW--$&$ZYZ-¤&&$YXºX«WC£+L[£«&¦[«LN¦	SS	S$&L'LL4] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:29 386] [01-01 18:12:18 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:29 407] [01-01 18UU«(HQW«®Z[¸¶ekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:29 407] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:29 423] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:29 423] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:29 423] [01-01 18:12:18 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:29 429] [01-01 18:12:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:29 442] [01-01 18:12:18 TUYA$Tµ5¥µq­ٹ銒ʢ뻵%}­ؽɅ݁2¥±¹jjԤhjÒҊ¢U 
[2024/8/7 9:25:29 442]                                                     Tµ5¥µq­ٹ銚²뻵%}­ؽݥѡ}½2¥±¹jjԤhjÒҊ¢U 
[2024/8/7 9:25:29 458]        TµE֥}ѱ͹隊ª颽¢±̽}¹с2¥±¹r½J¹b½±"5jR´jÒҊ¢U 
[2024/8/7 9:25:29 458]                         Tµ댗ҁ¹銢郑ҁ}¥½н¹̽н±½Ց}։±хʑ5jR´jÒҊ¢U 
[2024/8/7 9:25:29 474]                                                           TµU¹¥}¹ҝ½ɭ¹颂ꚕн¹̽¡}¥½ɥҥ鑪ԤhjÒҊ¢U 
[2024/8/7 9:25:29 490]        Tµ댗ҁ¹銪¢郑ҁ}¹́¹烚*¹ىВɽb½¹¥ӚµZ劒Bґɱbr}в±͕񲚉Z劒jƑЕɱbr}в±͕񲚉Z劒BґM±Uɱbr}Ңʕ񲚉Z劒jƑҍM±Uɱbr}Ңʕ񲚉Z劒:¡½ΑUɱbr}Ңʕ𶳵jR´jÒҊ¢U 
[2024/8/7 9:25:29 490]        Tµ댗ҁ¹銪˪:сªɱ½¹¥胑ҁΩzzBȲJ½ѵ"¹͹½µ½²ĺªɱ}½¹¥5jR´jÒҊ¢U 
[2024/8/7 9:25:29 506]                                                  Tµҁ¹ꂊ蛵¹¹ҩBȲJ½ѵ"¹͹½µ½ʑ炢¢jj󱫔¤hjÒҊ¢U 
[2024/8/7 9:25:29 522]        TµU¹¥}¹ҝ½ɭ¹隊¢ꪹܽѡ½Α幅µBȲJ½ѵ"¹͹½µ±ɥ½j¤ԨH甖­k¬/+V«ԥ*ʉ½ʩª孹½ݹB½Α5RڊjÒҊ¢U 
[2024/8/7 9:25:29 522]                                                       ©TµU¹¥}¹ҝ½ɭ¹隲貅¥±]
[2024/8/7 9:25:29 522]        і­k¬/+V«&¦C¡CC+LLKLL12:18 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:29 538] [01-01 18:12:18 TA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:29 538] [01-01 18:12:18 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:29 554] [01-01 18:12:18 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:29 554] [01-01 18:1񤲳ion failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:29 570] [01-01 18:12:18 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:29 570] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:29 570] XshellXshellXshellDEBUG: ***u16num***[512]
[2024/8/7 9:25:29 586] XshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellDEBUG: ***u16num***[512]
[2024/8/7 9:25:29 810] [1970-01-01 00:00:44] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:29 826] [1970-01-01 00:00:45] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:29 841] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:25:29 841] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:29 858] [01-01 18:12:19 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:29 858] DEBUG: ***u16num***[512]
[2024/8/7 9:25:29 970] DEBUG: ***u16num***[512]
[2024/8/7 9:25:30 018] [1970-01-01 00:00:45] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:30 034] [01-01 18:12:19 TUYA D][tuya_ble_api.c:1376] nw stat change:0->1, rpt to app.
[2024/8/7 9:25:30 034] [01-01 18:12:19 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:25:30 226] DEBUG: ***u16num***[512]
[2024/8/7 9:25:30 417] DEBUG: ***u16num***[512]
[2024/8/7 9:25:30 433] [1970-01-01 00:00:45] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:30 433] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:30 449] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:30 451] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:30 451] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:30 465] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:30 465] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:30 465] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:30 481] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:30 481] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:30 482] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:30 497] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:30 497] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:30 513] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:30 513] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:30 545] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:30 545] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:30 545] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:30 562] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:30 562] gethostbyname_r error: Unknown host
[2024/8/7 9:25:30 578] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:30 578] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:30 578] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:30 594] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:30 594] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:30 611] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:30 611] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:30 626] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:30 626] DEBUG: ***u16num***[512]
[2024/8/7 9:25:30 690] DEBUG: ***u16num***[512]
[2024/8/7 9:25:30 833] [1970-01-01 00:00:45] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:30 851] [1970-01-01 00:00:46] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:30 851] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:30 866] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:30 897] DEBUG: ***u16num***[512]
[2024/8/7 9:25:31 169] DEBUG: ***u16num***[512]
[2024/8/7 9:25:31 409] [1970-01-01 00:00:46] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:31 410] [1970-01-01 00:00:46] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:25:31 425] [1970-01-01 00:00:46] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:31 425] [1970-01-01 00:00:46] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time16655
[2024/8/7 9:25:31 441] [1970-01-01 00:00:46] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:31 457] [01-01 18:12:21 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:31 457] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:31 473] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:31 473] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:31 473] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:31 489] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:31 489] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:31 489] [01-01 18:12:21 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:31 505] [01-01 18:12:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:31 505] [01-01 18:12:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:31 505] [01-01 18:12:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:31 521] [01-01 18:12:21 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:31 521] [01-01 18:12:21 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:31 537] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:31 553] [01-01 18:12:21 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:31 569] [01-01 18:12:21 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:31 569] [01-01 18:12:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:31 585] [01-01 18:12:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:31 585] gethostbyname_r error: Unknown host
[2024/8/7 9:25:31 586] [01-01 18:12:21 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:31 601] [01-01 18:12:21 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:31 601] [01-01 18:12:21 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:31 602] [01-01 18:12:21 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:31 617] [01-01 18:12:21 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:31 633] [01-01 18:12:21 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:31 634] [01-01 18:12:21 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:31 634] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:31 634] DEBUG: ***u16num***[512]
[2024/8/7 9:25:31 683] DEBUG: ***u16num***[512]
[2024/8/7 9:25:31 809] DEBUG: ***u16num***[512]
[2024/8/7 9:25:31 938] motor auto test over
[2024/8/7 9:25:31 954] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 9:25:31 954] action=idle
[2024/8/7 9:25:31 954] dir=
[2024/8/7 9:25:31 954] flag=|auto-test-cmplt
[2024/8/7 9:25:31 954] [1970-01-01 steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 9:25:31 954]  00:00:47] xm_wi
[2024/8/7 9:25:31 970] fi.c(611) <XM_PaYYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 9:25:31 970] rseQrcode>: XM_Paction=idle
[2024/8/7 9:25:31 970] arseQrcode Parsedir=
[2024/8/7 9:25:31 970]   QRcode once frflag=
[2024/8/7 9:25:31 970] ame sucess width steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 9:25:31 970]  640 height 360 
[2024/8/7 9:25:31 970] data[]
[2024/8/7 9:25:31 986] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:25:32 002] [1970-01-01 00:00:47] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:32 002] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:32 018] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:32 018] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:25:32 018] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:25:32 034] DEBUG: ***u16num***[512]
[2024/8/7 9:25:32 162] DEBUG: ***u16num***[512]
[2024/8/7 9:25:32 369] DEBUG: ***u16num***[512]
[2024/8/7 9:25:32 419] [1970-01-01 00:00:47] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:32 433] [01-01 18:12:22 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:32 433] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:32 433] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:32 449] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:32 449] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:32 465] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:32 465] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:32 465] [01-01 18:12:22 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:32 481] [01-01 18:12:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:32 481] [01-01 18:12:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:32 481] [01-01 18:12:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:32 497] [01-01 18:12:22 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:32 497] [01-01 18:12:22 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:32 513] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:32 529] [01-01 18:12:22 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:32 545] [01-01 18:12:22 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:32 545] [01-01 18:12:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:32 545] [01-01 18:12:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:32 562] 
[2024/8/7 9:25:32 565] gethostbyname_r error: Unknown host
[2024/8/7 9:25:32 565] [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:32 565] [01-01 18:12:22 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:32 581] [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:32 581] [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:32 594] [01-01 18:12:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:32 594] [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:32 609] [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:32 610] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:32 610] [01-01 18:12:22 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:25:32 626] DEBUG: ***u16num***[512]
[2024/8/7 9:25:32 865] DEBUG: ***u16num***[512]
[2024/8/7 9:25:32 978] [1970-01-01 00:00:47] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:32 994] [1970-01-01 00:00:48] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:32 994] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:33 010] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:33 042] DEBUG: ***u16num***[512]
[2024/8/7 9:25:33 249] DEBUG: ***u16num***[367]
[2024/8/7 9:25:33 425] [1970-01-01 00:00:48] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:33 441] [1970-01-01 00:00:48] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:33 457] [1970-01-01 00:00:48] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:33 457] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:33 457] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:33 474] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:33 474] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:33 489] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:33 489] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:33 489] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:33 505] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:33 505] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:33 505] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:33 521] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:33 521] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:33 537] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:33 537] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:33 554] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:33 569] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:33 569] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:33 585] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:33 585] gethostbyname_r error: Unknown host
[2024/8/7 9:25:33 585] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:33 602] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:33 602] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:33 618] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:33 618] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:33 634] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:33 634] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:33 650] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:33 650] DEBUG: ***u16num***[57]
[2024/8/7 9:25:33 681] DEBUG: ***u16num***[442]
[2024/8/7 9:25:33 906] DEBUG: ***u16num***[501]
[2024/8/7 9:25:34 002] [1970-01-01 00:00:48] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:34 017] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:25:34 034] [1970-01-01 00:00:49] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:34 036] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:34 036] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:34 049] DEBUG: ***u16num***[512]
[2024/8/7 9:25:34 305] DEBUG: ***u16num***[512]
[2024/8/7 9:25:34 453] DEBUG: ***u16num***[512]
[2024/8/7 9:25:34 529] [1970-01-01 00:00:49] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:25:34 545] [1970-01-01 00:00:49] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17[1970-01-01 00:00:49] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 9:25:34 562] [1970-01-01 00:00:49] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:34 562] [1970-01-01 00:00:49] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 9:25:34 562] mpId[0] is [0].
[2024/8/7 9:25:34 562] mpId[1] is [0].
[2024/8/7 9:25:34 562] mpId[2] is [0].
[2024/8/7 9:25:34 562] mpId[3] is [0].
[2024/8/7 9:25:34 578] mpId[4] is [0].
[2024/8/7 9:25:34 578] mpId[5] is [0].
[2024/8/7 9:25:34 578] [1970-01-01 00:00:49] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:25:34 595] [1970-01-01 00:00:49] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:25:34 595] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:34 610] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:34 610] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:34 610] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:34 627] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:34 627] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:34 627] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:34 642] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:34 642] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:34 660] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:34 661] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:34 661] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:34 674] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:34 674] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:34 706] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:34 706] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:34 722] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:34 722] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:34 722] gethostbyname_r error: Unknown host
[2024/8/7 9:25:34 738] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:34 739] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:34 739] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:34 756] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:34 756] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:34 772] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:34 773] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:34 786] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:34 786] DEBUG: ***u16num***[512]
[2024/8/7 9:25:34 977] DEBUG: ***u16num***[512]
[2024/8/7 9:25:35 025] [1970-01-01 00:00:50] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:35 041] [1970-01-01 00:00:50] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:35 042] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:35 057] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:35 281] DEBUG: ***u16num***[512]
[2024/8/7 9:25:35 522] DEBUG: ***u16num***[512]
[2024/8/7 9:25:35 553] [1970-01-01 00:00:50] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:35 554] [1970-01-01 00:00:50] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:35 569] [1970-01-01 00:00:50] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time20634
[2024/8/7 9:25:35 570] [1970-01-01 00:00:50] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:35 589] [01-01 18:12:25 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:35 589] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:35 601] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:35 601] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:35 601] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:35 617] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:35 617] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:35 617] [01-01 18:12:25 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:35 635] [01-01 18:12:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:35 635] [01-01 18:12:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:35 649] [01-01 18:12:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:35 649] [01-01 18:12:25 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:35 650] [01-01 18:12:25 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:35 666] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:35 681] [01-01 18:12:25 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:35 697] [01-01 18:12:25 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:35 697] [01-01 18:12:25 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:35 713] [01-01 18:12:25 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:35 713] gethostbyname_r error: Unknown host
[2024/8/7 9:25:35 713] [01-01 18:12:25 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:35 729] [01-01 18:12:25 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:35 729] [01-01 18:12:25 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:35 729] [01-01 18:12:25 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:35 745] [01-01 18:12:25 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:35 761] [01-01 18:12:25 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:35 761] [01-01 18:12:25 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:35 761] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:35 761] DEBUG: ***u16num***[512]
[2024/8/7 9:25:35 825] DEBUG: ***u16num***[512]
[2024/8/7 9:25:35 969] DEBUG: ***u16num***[512]
[2024/8/7 9:25:36 081] [1970-01-01 00:00:51] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:36 097] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:25:36 097] src/intelligent_track_thread.c(709) [TrackProcV200]: Intelligent Track Enable eSensitivity=0 intervalTime_sec=15
[2024/8/7 9:25:36 113] [1970-01-01 00:00:51] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:36 129] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:36 129] [01-01 18:12:25 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:25:36 145] DEBUG: ***u16num***[512]
[2024/8/7 9:25:36 337] DEBUG: ***u16num***[512]
[2024/8/7 9:25:36 561] [1970-01-01 00:00:51] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:36 578] [1970-01-01 00:00:51] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:36 578] [01-01 18:12:26 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:36 578] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:36 593] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:36 594] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:36 609] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:36 609] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:36 609] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:36 625] [01-01 18:12:26 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:36 625] [01-01 18:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:36 625] [01-01 18:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:36 641] [01-01 18:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:36 641] [01-01 18:12:26 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:36 657] [01-01 18:12:26 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:36 657] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:36 674] [01-01 18:12:26 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:36 690] [01-01 18:12:26 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:36 690] [01-01 18:12:26 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:36 705] [01-01 18:12:26 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:36 705] gethostbyname_r error: Unknown host
[2024/8/7 9:25:36 705] [01-01 18:12:26 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:36 721] [01-01 18:12:26 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:36 722] [01-01 18:12:26 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:36 737] [01-01 18:12:26 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:36 737] [01-01 18:12:26 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:36 753] [01-01 18:12:26 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:36 753] [01-01 18:12:26 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:36 769] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:36 769] DEBUG: ***u16num***[512]
[2024/8/7 9:25:36 833] DEBUG: ***u16num***[512]
[2024/8/7 9:25:37 073] DEBUG: ***u16num***[512]
[2024/8/7 9:25:37 089] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:25:37 105] [1970-01-01 00:00:52] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:37 122] [01-01 18:12:26 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:25:37 201] DEBUG: ***u16num***[512]
[2024/8/7 9:25:37 297] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:25:37 297] Mode(Product):0
[2024/8/7 9:25:37 297] BpuMode:[Online]
[2024/8/7 9:25:37 297] VpssMode:[Online]
[2024/8/7 9:25:37 297] [0.LimitUp_info]:
[2024/8/7 9:25:37 297] LimitUp:[Disable]
[2024/8/7 9:25:37 297] [2680*0]->[3840*0])
[2024/8/7 9:25:37 297] chn	TotalSize	ActiveSize
[2024/8/7 9:25:37 297] 0	5040*2246	2680*2160
[2024/8/7 9:25:37 313] 0	5040*2246	2680*2160
[2024/8/7 9:25:37 313] 0	5040*2246	3840*2160
[2024/8/7 9:25:37 313] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:25:37 313] [1.VICU_info]:
[2024/8/7 9:25:37 313] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:25:37 313] 0	25.0	364	0	0	183	linear	8ddb00
[2024/8/7 9:25:37 329] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:25:37 329] en	op_type	m_chn	now
[2024/8/7 9:25:37 329] 0	1	1	1
[2024/8/7 9:25:37 329] [2.VI_info]:
[2024/8/7 9:25:37 329] chn	TotalSize	ActiveSize
[2024/8/7 9:25:37 329] 0	5040*2246	3848*2166
[2024/8/7 9:25:37 329] 1	   0*   0	   0*   0
[2024/8/7 9:25:37 329] [3.MIPI_info]:
[2024/8/7 9:25:37 344] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:25:37 345] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:25:37 345] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:25:37 345] [4.Cut_info]:
[2024/8/7 9:25:37 361] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:25:37 361] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:25:37 361] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:25:37 361] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:25:37 361] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:25:37 377] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:25:37 377] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:25:37 377] [5.IB(isp buffer info)]:
[2024/8/7 9:25:37 377] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:25:37 377] PoolId  Count  Size
[2024/8/7 9:25:37 393] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:37 393] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:37 409] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:37 409] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:37 409] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:37 425] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:37 425] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:25:37 441] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:25:37 441] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:25:37 441] 0       0         0          0          4       
[2024/8/7 9:25:37 457] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:25:37 458]      --265--            --264--                                               
[2024/8/7 9:25:37 458] Count      Line     Count      Line     
[2024/8/7 9:25:37 458] 268        437      654        560      
[2024/8/7 9:25:37 473] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:25:37 473] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:25:37 490] 0   3840   2160    H265  0      0        0           159       981868     1172     	
[2024/8/7 9:25:37 491] 1   640    360     H265  0      0        0           103       43195      5        	
[2024/8/7 9:25:37 505] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:25:37 505] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:25:37 521] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:25:37 537] 0   Y      159      1       0       13       2        157      157      214       62559         59245    130420   64548    12      
[2024/8/7 9:25:37 537] 1   Y      103      0       4       1        0        103      103      216       2565          1945     7318     2671     7       
[2024/8/7 9:25:37 553] 3   N      0        0       0       1        0        0        0        217       0             0        0        0        0       
[2024/8/7 9:25:37 553] DEBUG: ***u16num***[512]
[2024/8/7 9:25:37 649] [1970-01-01 00:00:52] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:25:37 665] [1970-01-01 00:00:52] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:37 665] [1970-01-01 00:00:52] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:25:37 681] [1970-01-01 00:00:52] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:37 697] [1970-01-01 00:00:52] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:37 697] [01-01 18:12:27 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:37 713] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:37 713] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:37 713] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:37 729] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:37 729] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:37 745] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:37 745] [01-01 18:12:27 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:37 745] [01-01 18:12:27 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:37 761] DEBUG: ***u16num***[512[01-01 18:12:27 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:37 761] ]
[2024/8/7 9:25:37 761] [01-01 18:12:27 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:37 777] [01-01 18:12:27 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:37 777] [01-01 18:12:27 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:37 777] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:37 809] [01-01 18:12:27 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:37 809] [01-01 18:12:27 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:37 825] [01-01 18:12:27 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:37 825] [01-01 18:12:27 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:37 841] gethostbyname_r error: Unknown host
[2024/8/7 9:25:37 841] [01-01 18:12:27 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:37 841] [01-01 18:12:27 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:37 857] [01-01 18:12:27 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:37 857] [01-01 18:12:27 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:37 873] [01-01 18:12:27 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:37 873] [01-01 18:12:27 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:37 889] [01-01 18:12:27 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:37 889] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:37 889] [01-01 18:12:27 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:25:37 889] DEBUG: ***u16num***[512]
[2024/8/7 9:25:38 081] DEBUG: ***u16num***[512]
[2024/8/7 9:25:38 353] DEBUG: ***u16num***[512]
[2024/8/7 9:25:38 577] DEBUG: ***u16num***[512]
[2024/8/7 9:25:38 673] [1970-01-01 00:00:53] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:38 689] [1970-01-01 00:00:53] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:38 705] [1970-01-01 00:00:53] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:38 705] [01-01 18:12:28 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:38 721] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:38 721] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:38 721] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:38 737] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:38 737] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:38 752] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:38 753] [01-01 18:12:28 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:38 753] [01-01 18:12:28 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:38 769] [01-01 18:12:28 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:38 769] [01-01 18:12:28 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:38 769] [01-01 18:12:28 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:38 785] [01-01 18:12:28 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:38 785] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:38 817] [01-01 18:12:28 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:38 818] [01-01 18:12:28 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:38 833] [01-01 18:12:28 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:38 834] [01-01 18:12:28 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:38 834] gethostbyname_r error: Unknown host
[2024/8/7 9:25:38 849] [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:38 849] [01-01 18:12:28 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:38 865] [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:38 865] [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:38 865] [01-01 18:12:28 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:38 881] [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:38 881] [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:38 898] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:38 898] DEBUG: ***u16num***[512]
[2024/8/7 9:25:38 913] [1970-01-01 00:00:54] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:38 913] ble_slave_gap_event->type=0
[2024/8/7 9:25:38 913] connection established; status=0 GATT procedure initiated: exchange mtu
[2024/8/7 9:25:38 913] connection, handle=1
[2024/8/7 9:25:38 929] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:38 945] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:38 945] --- tracepoint bt_ext_porting.c,ty_btext_thread(423): TY_BT_EVENT_CONNECTED1 ---
[2024/8/7 9:25:38 961] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 1
[2024/8/7 9:25:38 961] [01-01 18:12:28 TUYA N][tuya_ble_api.c:472] Ble Connected
[2024/8/7 9:25:38 961] [01-01 18:12:28 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[2024/8/7 9:25:38 977] [01-01 18:12:28 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
[2024/8/7 9:25:39 072] DEBUG: ***u16num***[512]
[2024/8/7 9:25:39 201] DEBUG: ***u16num***[512]
[2024/8/7 9:25:39 457] DEBUG: ***u16num***[512]
[2024/8/7 9:25:39 697] DEBUG: ***u16num***[512]
[2024/8/7 9:25:39 697] --- tracepoint bt_ext_porting.c,ty_btext_thread(425): TY_BT_EVENT_CONNECTED2 ---
[2024/8/7 9:25:39 713] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 713] ble_slave_gap_event->type=15
[2024/8/7 9:25:39 729] mtu update event; conn_handle=1 cid=4 mtu=255
[2024/8/7 9:25:39 729] [1970-01-01 00:00:54] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:39 745] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 745] ble_slave_gap_event->type=4
[2024/8/7 9:25:39 745] connection update request
[2024/8/7 9:25:39 761] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 777] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 777] [1970-01-01 00:00:54] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:39 793] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 809] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 809] [1970-01-01 00:00:54] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:39 825] ble_slave_gap_event->type=3
[2024/8/7 9:25:39 825] connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:25:39 841] [1970-01-01 00:00:54] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 841] [1970-01-01 00:00:54] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time24931
[2024/8/7 9:25:39 857] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 872] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:39 873] [01-01 18:12:29 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:39 888] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:39 890] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:39 890] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:39 904] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:39 905] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:39 905] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:39 921] [01-01 18:12:29 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:39 921] [01-01 18:12:29 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:39 921] [01-01 18:12:29 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:39 937] [01-01 18:12:29 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:39 937] [01-01 18:12:29 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:39 953] [01-01 18:12:29 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:39 953] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:39 985] [01-01 18:12:29 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:39 985] [01-01 18:12:29 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:39 985] [01-01 18:12:29 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:40 001] [01-01 18:12:29 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:40 001] gethostbyname_r error: Unknown host
[2024/8/7 9:25:40 017] [01-01 18:12:29 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:40 017] [01-01 18:12:29 TUYA[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 017]  D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:40 033] [01-01 18:12:29 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:40 033] [01-01 18:12:29 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:40 049] [01-01 18:12:29 TUYA D][httpc.c:815] Connect: h2.iot-dns.com [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 049] Port: 443  --<< ,r:-15
[2024/8/7 9:25:40 065] [01-01 18:12:29 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:40 066] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.oud url -2050
[2024/8/7 9:25:40 081] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:40 081] DEBUG: ***u16num***[512]
[2024/8/7 9:25:40 224] DEBUG: **[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 224] *u16num***[512]
[2024/8/7 9:25:40 369] DEBUG: ***u16num***[512]
[2024/8/7 9:25:40 560] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 576] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:40 592] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:40 594] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:40 608] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:40 624] [1970-01-01 00:00:55] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:40 624] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:40 640] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:40 640] ble_slave_gap_event->type=4
[2024/8/7 9:25:40 640] connection update request
[2024/8/7 9:25:40 640] ble_slave_gap_event->type=14
[2024/8/7 9:25:40 656] subscribe event; conn_handle=1 attr_handle=23 reason=1 prevn=0 curn=1 previ=0 curi=0
[2024/8/7 9:25:40 656] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:25:40 657] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:40 672] ble_slave_gap_event->type=3
[2024/8/7 9:25:40 673] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:25:40 689] [1970-01-01 00:00:55] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:40 689] [1970-01-01 00:00:55] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:40 705] [1970-01-01 00:00:55] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:25:40 720] [1970-01-01 00:00:55] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 720] frame sucess width 640 height 360 data[]
[2024/8/7 9:25:40 720] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:40 736] Len=20 step 0
[2024/8/7 9:25:40 736] att=0x0 0x21 0x20 0x1 0x79 0x23 0x4e 0x27 0x1a 0x28 0x9c 0x6e 0x24 0xdb 0xef 0x93 0x43 0x14 0x9e 0x22 
[2024/8/7 9:25:40 736]  RCVS len:20
[2024/8/7 9:25:40 736] XmBleReadBuf 20:
[2024/8/7 9:25:40 753] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:40 753] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:40 753] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:40 769] --- tracepoint bt_ext_porting.c,ty_msg_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 769] proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:40 769] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:40 785] [01-01 18:12:30 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:40 785] [01-01 18:12:30 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:40 801] [01-01 18:12:30 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:40 801] bt_rev_raw 20
[2024/8/7 9:25:40 801] 00 21 20 01 79 23 4e 27 1a 28 9c 6e 24 db ef 93 43 14 9e 22 
[2024/8/7 9:25:40 818] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:25:40 818] [01-01 18:12:30 TUYA D][tu[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 818] ya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:40 833] DEBUG: ***u16num***[512]
[2024/8/7 9:25:40 833] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:40 833] [01-01 18:12:30 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:40 850] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:40 850] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:40 865] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:40 865] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:40 865] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:40 881] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:40 881] [01-01 18:1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 897] 2:30 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:40 898] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:40 898] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:40 913] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:40 913] [01-01 18:12:30 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:40 913] [01-01 18:12:30 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:40 930] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:40 945] [01-01 18:12:30 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:40 961] [01-01 18:12:30 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:40 961] [01-01 18:12:30 TU[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:40 962] YA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:40 977] [01-01 18:12:30 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:40 977] gethostbyname_r error: Unknown host
[2024/8/7 9:25:40 993] [01-01 18:12:30 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:40 993] [01-01 18:12:30 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:40 994] [01-01 18:12:30 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:41 009] [01-01 18:12:30 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:41 009] [01-01 18:12:30 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:41 025] [01-01 18:12:30 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:41 025] [01-01 18:12:30 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:41 041] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:41 041] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:41 041] Len=17 step 0
[2024/8/7 9:25:41 057] att=0x1 0x68 0x11 0xb8 0xb3 0x83 0x8c 0x11 0x10 0x43 0xd8 0x5e 0x9d 0xf5 0x93 0xb3 0xd6 
[2024/8/7 9:25:41 057]  RCVS len:17
[2024/8/7 9:25:41 057] XmBleReadBuf 17:
[2024/8/7 9:25:41 057] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:41 057] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:41 073] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:41 073] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:25:41 073] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:25:41 089] [01-01 18:12:30 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:25:41 105] [01-01 18:12:30 TUYA D][tuya_ble_api.c:543] rev ble [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:41 105] event 2
[2024/8/7 9:25:41 105] [01-01 18:12:30 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:41 105] bt_rev_raw 17
[2024/8/7 9:25:41 105] 01 68 11 b8 b3 83 8c 11 10 43 d8 5e 9d f5 93 b3 d6 
[2024/8/7 9:25:41 121] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:25:41 121] ble rev data 33
[2024/8/7 9:25:41 137] 01 79 23 4e 27 1a 28 9c 6e 24 db ef 93 43 14 9e 22 68 11 b8 b3 83 8c 11 10 43 d8 5e 9d f5 93 b3 d6 
[2024/8/7 9:25:41 137] [01-01 18:12:30 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:25:41 137] ble decryped data 16
[2024/8/7 9:25:41 137] 00 00 00 01 00 00 00 00 00 00 00 00 92 69 00 00 
[2024/8/7 9:25:41 153] [01-01 18:12:30 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:25:41 153] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x0 
[2024/8/7 9:25:41 169] [01-01 18:12:30 TUYA N][tuya[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:41 169] _ble_data_handler.c:451] tuya_ble_handle_dev_infor_req state:0, pkg_len:20
[2024/8/7 9:25:41 169] [01-01 18:12:30 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:25:41 185] [01-01 18:12:30 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:25:41 185] [01-01 18:12:30 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:25:41 201] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:25:41 201] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:4, send_data:16
[2024/8/7 9:25:41 201] tuya_hal_bt_send 20
[2024/8/7 9:25:41 217] 00 81 01 30 01 07 b4 df aa 01 2e ba be 69 49 83 d7 c9 a4 08 
[2024/8/7 9:25:41 217] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:41 217] 0 81 1 30 1 7 b4 df aa 1 2e ba be 69 49 83 d7 c9 a4 8 
[2024/8/7 9:25:41 233] XmBleSendBuf 20: 00 81 01 30 01 07 b4 df aa 01 2e ba be 69 49 83 d7 c9 a4 08
[2024/8/7 9:25:41 233] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:41 233] ble_slave_gap_event->type=13
[2024/8/7 9:25:41 249] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:41 249] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:41 249] [01-01 18:1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:41 249] 2:30 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:41 265] DEBUG: ***u16num***[512]
[2024/8/7 9:25:41 265] [1970-01-01 00:00:56] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:41 281] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:25:41 281] tuya_hal_bt_send 20
[2024/8/7 9:25:41 281] 01 f3 47 b9 9e 54 fa 5c 76 4f 4d 1a d0 2d f2 83 ee bc d0 93 
[2024/8/7 9:25:41 297] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:41 297] 1 f3 47 b9 9e 54 fa 5c 76 4f 4d 1a d0 2d f2 83 ee bc d0 93 
[2024/8/7 9:25:41 297] XmBleSendBuf 20: 01 f3 47 b9 9e 54 fa 5c 76 4f 4d 1a d0 2d f2 83 ee bc d0 93
[2024/8/7 9:25:41 312] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:41 313] ble_slave_gap_event->type=13
[2024/8/7 9:25:41 313] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:41 313] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:41 328] [01-01 18:12:30 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:41 328] [1970-01-01 00:00:56] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:41 345] [1970-01-01 00:00:56] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:41 345] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:25:41 361] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:25:41 361] tuya_hal_bt_send 20
[2024/8/7 9:25:41 361] 02 67 c5 b6 93 3e 3d 7e 99 05 18 b4 4f b4 24 27 e2 33 91 d8 
[2024/8/7 9:25:41 376] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:41 377] 2 67 c5 b6 93 3e 3d 7e 99 5 18 b4 4f b4 24 27 e2 33 91 d8 
[2024/8/7 9:25:41 377] XmBleSendBuf 20: 02 67 c5 b6 93 3e 3d 7e 99 05 18 b4 4f b4 24 27 e2 33 91 d8
[2024/8/7 9:25:41 392] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:41 392] ble_slave_gap_event->type=13
[2024/8/7 9:25:41 393] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:41 393] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:41 409] [01-01 18:12:30 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:41 409] set basic_indicator_onoff:0 
[2024/8/7 9:25:41 425] [1970-01-01 00:00:56] tuya_ipc_dp_handler.c(257) <IPC_APP_set_basic_indicator_onoff>: Get BasicIndicator suc,gpio value=[0x0c]
[2024/8/7 9:25:41 425] [1970-01-01 00:0[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:41 440] 0:56] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:41 441] [1970-01-01 00:00:56] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:41 457] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:25:41 457] tuya_hal_bt_send 20
[2024/8/7 9:25:41 457] 03 b7 5e 81 87 f0 51 4c b7 0e 56 33 57 5e 67 c7 22 91 7e 6f 
[2024/8/7 9:25:41 473] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:41 473] 3 b7 5e 81 87 f0 51 4c b7 e 56 33 57 5e 67 c7 22 91 7e 6f 
[2024/8/7 9:25:41 473] XmBleSendBuf 20: 03 b7 5e 81 87 f0 51 4c b7 0e 56 33 57 5e 67 c7 22 91 7e 6f
[2024/8/7 9:25:41 488] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:41 489] ble_slave_gap_event->type=13
[2024/8/7 9:25:41 489] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:41 489] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:41 601] [01-01 18:12:30 TUYA D][bt_ext_porting.c:456] [TUY[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:41 601] A-BTUART]BT TX end
[2024/8/7 9:25:41 601] DEBUG: ***u16num***[512]
[2024/8/7 9:25:41 617] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:25:41 617] tuya_hal_bt_send 20
[2024/8/7 9:25:41 617] 04 3a 87 87 72 90 b3 56 6f ee 95 55 51 e1 8b d1 2c d5 3f 14 
[2024/8/7 9:25:41 633] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:41 633] 4 3a 87 87 72 90 b3 56 6f ee 95 55 51 e1 8b d1 2c d5 3f 14 
[2024/8/7 9:25:41 633] XmBleSendBuf 20: 04 3a 87 87 72 90 b3 56 6f ee 95 55 51 e1 8b d1 2c d5 3f 14
[2024/8/7 9:25:41 649] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:41 649] ble_slave_gap_event->type=13
[2024/8/7 9:25:41 649] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:41 649] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:41 665]  ---
[2024/8/7 9:25:41 666] [01-01 18:12:30 TUY[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:41 666] A D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:41 681] [1970-01-01 00:00:56] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:41 681] set basic_indicator_onoff:1 
[2024/8/7 9:25:41 697] [1970-01-01 00:00:56] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:41 697] [1970-01-01 00:00:56] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:41 713] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:25:41 713] tuya_hal_bt_send 20
[2024/8/7 9:25:41 713] 05 34 7b 75 e7 60 b2 7e 10 44 c2 50 e7 e0 c7 81 12 7c d5 07 
[2024/8/7 9:25:41 729] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:41 729] 5 34 7b 75 e7 60 b2 7e 10 44 c2 50 e7 e0 c7 81 12 7c d5 7 
[2024/8/7 9:25:41 729] XmBleSendBuf 20: 05 34 7b 75 e7 60 b2 7e 10 44 c2 50 e7 e0 c7 81 12 7c d5 07
[2024/8/7 9:25:41 745] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:41 745] ble_slave_gap_event->type=13
[2024/8/7 9:25:41 745] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:41 745] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:41 761] [01-01 18:12:30 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:41 761] [1970-01-01 00:00:56] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:41 777] [01-01 18:12:30 TUYA D][tuya_ble_mutli_tsf_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:41 777] protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:18
[2024/8/7 9:25:41 777] tuya_hal_bt_send 19
[2024/8/7 9:25:41 793] 06 bb a2 30 d1 c4 dd 16 54 95 17 86 a7 f8 12 1e 31 f1 4f 
[2024/8/7 9:25:41 793] [01-01 18:12:30 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:41 793] 6 bb a2 30 d1 c4 dd 16 54 95 17 86 a7 f8 12 1e 31 f1 4f 
[2024/8/7 9:25:41 809] XmBleSendBuf 19: 06 bb a2 30 d1 c4 dd 16 54 95 17 86 a7 f8 12 1e 31 f1 4f
[2024/8/7 9:25:41 809] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:41 809] ble_slave_gap_event->type=13
[2024/8/7 9:25:41 809] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:41 825] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:41 825] [01-01 18:12:30 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:41 825] DEBUG: ***u16num***[512]
[2024/8/7 9:25:41 841] [01-01 18:12:30 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:129, send_ret:0x0
[2024/8/7 9:25:41 841] [01-01 18:12:30 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:0
[2024/8/7 9:25:41 841] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:41 857]  ---
[2024/8/7 9:25:41 857] Len=20 step 0
[2024/8/7 9:25:41 857] att=0x0 0x51 0x20 0x2 0xc1 0x5 0x11 0x17 0x73 0x88 0x11 0xbc 0xe1 0x9b 0x80 0x43 0x55 0x92 0xa1 0x5c 
[2024/8/7 9:25:41 857]  RCVS len:20
[2024/8/7 9:25:41 857] set basic_indicator_onoff:0 
[2024/8/7 9:25:41 873] [1970-01-01 00:00:56] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:41 873] [1970-01-01 00:00:56] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:41 889] XmBleReadBuf 20:
[2024/8/7 9:25:41 889] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:41 889] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:41 889] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:41 905] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:41 905] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:41 921] [01-01 18:12:30 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:41 921] [01-01 18:12:30 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:41 937] [01-01 18:12:30 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:41 937] bt_rev_raw 20
[2024/8/7 9:25:41 937] 00 51 20 02 c1 05 11 17 73 88 11 bc e1 9b 80 43 55 92 a1 5c 
[2024/8/7 9:25:41 953] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:25:41 953] [01-01 18:12:30 TUYA D][tuya_ble_data_handler.c:566] ble d[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:41 953] ata pkg is multi-pack, receive...
[2024/8/7 9:25:41 970] DEBUG: ***u16num***[512]
[2024/8/7 9:25:41 970] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:41 985] [1970-01-01 00:00:56] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:41 985] set basic_indicator_onoff:1 
[2024/8/7 9:25:41 985] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:41 985] Len=20 step 0
[2024/8/7 9:25:42 001] att=0x1 0xa8 0x16 0xc6 0x6c 0xb0 0x85 0x8b 0x88 0x3f 0x11 0xeb 0x96 0x7c 0xb7 0xa2 0xe8 0x69 0xe9 0x5a 
[2024/8/7 9:25:42 001]  RCVS len:20
[2024/8/7 9:25:42 017] [1970-01-01 00:00:56] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: Swap[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 017] Flag=false
[2024/8/7 9:25:42 017] [1970-01-01 00:00:56] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:42 033] [1970-01-01 00:00:56] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:42 033] XmBleReadBuf 20:
[2024/8/7 9:25:42 033] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:42 049] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:42 049] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:42 049] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:42 065] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:42 065] [01-01 18:12:31 TUYA I][bt_ext_porting.[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 081] c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:42 081] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:42 081] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:42 081] bt_rev_raw 20
[2024/8/7 9:25:42 097] 01 a8 16 c6 6c b0 85 8b 88 3f 11 eb 96 7c b7 a2 e8 69 e9 5a 
[2024/8/7 9:25:42 097] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:25:42 112] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:42 113] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:42 113] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:42 129]  ---
[2024/8/7 9:25:42 130] Len=20 step 0
[2024/8/7 9:25:42 130] att=0x2 0x13 0x39 0xb9 0x25 0xbb 0xdc 0xaa 0xf0 0xa4 0x9a 0x63 0x67 0x42 0x22 0x5c 0x33 0x36 0x39 0xc9 
[2024/8/7 9:25:42 130]  RCVS len:20
[2024/8/7 9:25:42 130] set basic_indicator_onoff:0 
[2024/8/7 9:25:42 145] [1970-01-01 00:00:56] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:42 145] [1970-01-01 00:00:56] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:42 160] 
[2024/8/7 9:25:42 162] [1970-01-01 00:00:56] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRc[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 176] ode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:42 176] XmBleReadBuf 20:
[2024/8/7 9:25:42 176] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:42 176] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:42 192] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:42 192] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:42 193] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:42 208] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:42 208] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:42 224] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:42 224] bt_rev_raw 20
[2024/8/7 9:25:42 224] 02 13 39 b9 25 bb dc aa f0 a4 9a 63 67 42 22 5c 33 36 39 c9 
[2024/8/7 9:25:42 240] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:25:42 240] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:42 241] DEBUG: ***u16num***[512]
[2024/8/7 9:25:42 256] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:42 256] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:42 256] Len[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 272] =20 step 0
[2024/8/7 9:25:42 273] att=0x3 0x5b 0x97 0x32 0x66 0xa4 0x83 0xdd 0xff 0x38 0x1b 0x8a 0x44 0xb0 0x29 0xb3 0xd3 0xad 0x73 0xaf 
[2024/8/7 9:25:42 273]  RCVS len:20
[2024/8/7 9:25:42 288] [1970-01-01 00:00:57] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:42 289] [01-01 18:12:31 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:42 289] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:42 305] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:42 305] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:42 320] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:42 321] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:42 321] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:42 336] [01-01 18:12:31 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:42 337] [01-01 18:12:31 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:42 337] [01-01 18:12:31 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:42 352] [01-01 18:12:31 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:42 353] [01-01 18:12:31 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:42 369] [01-01 18:12:31 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:42 369] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:42 400] [01-01 18:12:31 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:42 401] [01-01 18:12:31 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:42 401] [01-01 18:1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 416] 2:31 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:42 417] [01-01 18:12:31 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:42 417] XmBleReadBuf 20:
[2024/8/7 9:25:42 432] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:42 433] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:42 433] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:42 448] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:42 449] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:42 464] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:42 465] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:42 465] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:42 465] bt_rev_raw 20
[2024/8/7 9:25:42 480] 03 5b 97 32 66 a4 83 dd ff 38 1b 8a 44 b0 29 b3 d3 ad 73 af 
[2024/8/7 9:25:42 480] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:25:42 496] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:42 496] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:42 496] gethostbyname_r error: Unknown host
[2024/8/7 9:25:42 512] [01-01 18:12:31 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:42 512] [01-01 18:12:31 TUYA D][uni_network.[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 529] c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:42 529] [01-01 18:12:31 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:42 529] [01-01 18:12:31 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:42 544] [01-01 18:12:31 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:42 544] [01-01 18:12:31 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:42 560] [01-01 18:12:31 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:42 560] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:42 560] DEBUG: ***u16num***[512]
[2024/8/7 9:25:42 576] set basic_indicator_onoff:1 
[2024/8/7 9:25:42 576] [1970-01-01 00:00:57] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:42 592] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:42 592] Len=8 step 0
[2024/8/7 9:25:42 592] att=0x4 0xb6 0xb9 0xe7 0x14 0x24 0x90 0x55 
[2024/8/7 9:25:42 592]  RCVS len:8
[2024/8/7 9:25:42 592] [1970-01-01 00:00:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:42 608] [1970-01-01 00:00:57] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:42 608] XmBleReadBuf 8:
[2024/8/7 9:25:42 624] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:42 624] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:42 624] --- tracepoint bt_ext_porting.c,my_msg_rcv(3[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 641] 53):  ---
[2024/8/7 9:25:42 644] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 16 rcount 16 offset 0 ---
[2024/8/7 9:25:42 644] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 16 ---
[2024/8/7 9:25:42 663] [1970-01-01 00:00:57] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:42 663] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x9]
[2024/8/7 9:25:42 673] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:42 673] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:42 673] bt_rev_raw 8
[2024/8/7 9:25:42 673] 04 b6 b9 e7 14 24 90 55 
[2024/8/7 9:25:42 690] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:5, pack_len:7, total_len:81
[2024/8/7 9:25:42 690] ble rev data 81
[2024/8/7 9:25:42 705] 02 c1 05 11 17 73 88 11 bc e1 9b 80 43 55 92 a1 5c a8 16 c6 6c b0 85 8b 88 3f 11 eb 96 7c b7 a2 e8 69 e9 5a 13 39 b9 25 bb dc aa f0 a4 9a 63 67 42 22 5c 33 36 39 c9 5b 97 32 66 a4 83 dd ff 38 
[2024/8/7 9:25:42 721] 1b 8a 44 b0 29 b3 d3 ad 73 af b6 b9 e[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 721] 7 14 24 90 55 
[2024/8/7 9:25:42 721] ble decryped data 64
[2024/8/7 9:25:42 737] 00 00 00 02 00 00 00 00 00 01 00 2c 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca 1e 00 00 00 00 00 00 
[2024/8/7 9:25:42 737] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:25:42 753] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x1 
[2024/8/7 9:25:42 753] [01-01 18:12:31 TUYA D][tuya_ble_api.c:573] conn monitor timer stopped
[2024/8/7 9:25:42 753] [01-01 18:12:31 TUYA N][tuya_ble_api.c:1464] ble set conn stat:3
[2024/8/7 9:25:42 769] [01-01 18:12:31 TUYA N][tuya_ble_data_handler.c:367] PAIR_REQ ok:0
[2024/8/7 9:25:42 769] [01-01 18:12:31 TUYA N][tuya_ble_data_handler.c:342] ble_time_req start...
[2024/8/7 9:25:42 785] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:348] no need to query time. network stat:1, work stat:0
[2024/8/7 9:25:42 785] [01-01 18:12:31 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:25:42 785] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:42 801] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:16 ---
[2024/8/7 9:25:42 801] set basic_indicator_onoff:0 
[2024/8/7 9:25:42 817] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:25:42 817] tuya_hal_b[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 817] t_send 20
[2024/8/7 9:25:42 833] 00 21 31 02 d1 f4 f4 5b cf 7f 5f [1970-01-01 00:00:57] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:42 833] c6 e5 0f 2f c9 e6 84 f9 [1970-01-01 00:00:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:42 833] ee 
[2024/8/7 9:25:42 849] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:42 849] 0 21 31 2 d1 f4 f4 5b cf 7f 5f c6 e5 f 2f c9 e6 84 f9 ee 
[2024/8/7 9:25:42 865] XmBleSendBuf 20: 00 21 31 02 d1 f4 f4 5b cf 7f 5f c6 e5 0f 2f c9 e6 84 f9 ee
[2024/8/7 9:25:42 865] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:42 865] ble_slave_gap_event->type=13
[2024/8/7 9:25:42 865] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:42 982] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:42 982] [01-01 18:12:31 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:42 982] [01-01 18:12:31 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:25:42 982] tuya_hal_bt_send 17
[2024/8/7 9:25:42 982] 01 ee d9 c1 ee 17 a4 1c 3c c6 42 0d 9f d3 2f 28 24 
[2024/8/7 9:25:42 982] [01-01 18:12:31 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:42 982] 1 ee d9 c1 ee 17 a4 1c 3c c6 42 d 9f d3 2f 28 24 
[2024/8/7 9:25:42 982] XmBleSendBuf 17: 01 ee d9 c1 ee 17 a4 1c 3c c6 42 0d 9f d3 2f 28 24
[2024/8/7 9:25:42 982] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:42 982] ble_slave_gap_event->type=13
[2024/8/7 9:25:42 982] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:42 982] [01-01 18:12:31 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:25:42 982] [01-01 18:12:31 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:1
[2024/8/7 9:25:42 982] set basic_indicator_onoff:1 
[2024/8/7 9:25:42 982] [1970-01-01 00:00:57] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:42 982] [1970-01-01 00:00:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:42 982] [01-01 18:12:31 TUYA D][tuya_ble_api.c:1376] nw stat change:1->1, rpt to app.
[2024/8/7 9:25:42 983] [01-01 18:12:31 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:25:42 993] DEBUG: [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:42 993] ***u16num***[512]
[2024/8/7 9:25:42 993] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:42 993] Len=20 step 0
[2024/8/7 9:25:43 009] att=0x0 0x61 0x20 0x2 0x9b 0xee 0xe 0x3b 0xc6 0x9a 0x70 0x8a 0xda 0xc5 0x54 0xda 0x68 0x72 0x52 0xbe 
[2024/8/7 9:25:43 009]  RCVS len:20
[2024/8/7 9:25:43 009] XmBleReadBuf 20:
[2024/8/7 9:25:43 009] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:43 025] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:43 025] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:43 025] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:43 041] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:43 041] [01-01 18:12:31 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:43 057] [01-01 18:12:31 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:43 089] [01-01 18:12:31 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:43 089] bt_rev_raw 20
[2024/8/7 9:25:43 089] 00 61 20 02 9b ee 0e 3b c6 9a 70 8a da c5 54 da 68 72 52 be 
[2024/8/7 9:25:43 105] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:25:43 105] [01-01 18:12:31 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:43 105] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:25:43 121] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:43 121] [1970-01-01 00:00:57] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:43 137] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:43 137] Len=20 step 0
[2024/8/7 9:25:43 137] att=0x1 0x42 0xa3 0x4b 0xff 0x6 0x2e 0x3a 0x5d 0x32 0x73 0xe2 0xb9 0xa9 0x1b 0xcf 0x3b 0x54 0x39 0xe2 
[2024/8/7 9:25:43 137]  RCVS len:20
[2024/8/7 9:25:43 153] [01-01 18:12:31 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:25:43 153] DEBUG: ***u16num***[512]
[2024/8/7 9:25:43 153] set basic_indicator_onoff:0 
[2024/8/7 9:25:43 169] [1970-01-01 00:00:57] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:43 169] [1970-01-01 00:00:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:43 185] [1970-01-01 00:00:57] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:43 185] XmBleReadBuf 20:
[2024/8/7 9:25:43 201] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:43 202] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:43 202] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:43 217] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:43 217] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:43 233] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:43 233] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:43 234] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:43 234] bt_rev_raw 20
[2024/8/7 9:25:43 249] 01 42 a3 4b ff 06 2e 3a 5d 32 73 e2 b9 a9 1b cf 3b 54 39 e2 
[2024/8/7 9:25:43 249] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:25:43 265] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:43 265] DEBUG: ***u16num***[512]
[2024/8/7 9:25:43 265] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:43 265] set basic_indicator_onoff:1 
[2024/8/7 9:25:43 281] [1970-01-01 00:00:57] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:43 297] [1970-01-01 00:00:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:43 297] [1970-01-01 00:00:57] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:43 297] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:43 297] Len=20 step 0
[2024/8/7 9:25:43 313] att=0x2 0xc 0xe1 0xce 0x47 0x26 0xb8 0xdd 0x7a 0xa2 0xde 0xee 0x9f 0xe0 0x19 0xc9 0x11 0x57 0x90 0x20 
[2024/8/7 9:25:43 313]  RCVS len:20
[2024/8/7 9:25:43 313] XmBleReadBuf 20:
[2024/8/7 9:25:43 313] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:43 329] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:43 329] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:43 345] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:43 345] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:43 345] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:43 361] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:43 361] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:43 361] bt_rev_raw 20
[2024/8/7 9:25:43 377] 02 0c e1 ce 47 26 b8 dd 7a a2 de ee 9f e0 19 c9 11 57 90 20 
[2024/8/7 9:25:43 377] [01-01 18[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:25:43 377] :12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:25:43 393] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:43 393] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:43 409] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:43 409] Len=20 step 0
[2024/8/7 9:25:43 409] att=0x3 0xdd 0x36 0xde 0xdd 0x87 0x2e 0xf0 0x62 0x61 0xfd 0x45 0xa3 0x6a 0x65 0x8b 0xb6 0x41 0x6e 0xce 
[2024/8/7 9:25:43 409]  RCVS len:20
[2024/8/7 9:25:43 425] set basic_indicator_onoff:0 
[2024/8/7 9:25:43 425] [1970-01-01 00:00:57] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:43 440] [1970-01-01 00:00:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:43 441] 
[2024/8/7 9:25:43 441] [1970-01-01 00:00:57] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:43 456] XmBleReadBuf 20:
[2024/8/7 9:25:43 457] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:43 520] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:43 521] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:43 537] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:43 537] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:43 553] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:43 553] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:43 553] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:43 553] bt_rev_raw 20
[2024/8/7 9:25:43 569] 03 dd 36 de dd 87 2e f0 62 61 fd 45 a3 6a 65 8b b6 41 6e ce 
[2024/8/7 9:25:43 569] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:25:43 585] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:43 585] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:43 585] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:43 601]  ---
[2024/8/7 9:25:43 601] Len=20 step 0
[2024/8/7 9:25:43 601] att=0x4 0xb3 0xdb 0x4b 0xff 0x9f 0x63 0x3d 0xb0 0xbe 0xee 0x6 0x8d 0x40 0x4f 0x22 0x31 0xb8 0x45 0xa 
[2024/8/7 9:25:43 601]  RCVS len:20
[2024/8/7 9:25:43 601] set basic_indicator_onoff:1 
[2024/8/7 9:25:43 617] [1970-01-01 00:00:58] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:43 617] [1970-01-01 00:00:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:43 633] 
[2024/8/7 9:25:43 633] XmBleReadBuf 20:
[2024/8/7 9:25:43 633] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:43 633] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:43 649] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:43 649] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:43 649] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:43 665] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[[atbm_log]:[ieee80211_csa_cancel][mon.eth2]:[0][0]
[2024/8/7 9:25:43 665] 0x15]
[2024/8/7 9:25:43 681] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:43 681] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:43 681] bt_rev_raw 20
[2024/8/7 9:25:43 682] 04 b3 db 4b ff 9f 63 3d b0 be ee 06 8d 40 4f 22 31 b8 45 0a 
[2024/8/7 9:25:43 697] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:5, pack_len:19, total_len:93
[2024/8/7 9:25:43 697] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:43 714] DEBUG: ***u16num***[512]
[2024/8/7 9:25:43 714] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:43 714] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:43 714] Len=5 step 0
[2024/8/7 9:25:43 729] att=0x5 0xd8 0x99 0xbc 0xc1 
[2024/8/7 9:25:43 729]  RCVS len:5
[2024/8/7 9:25:43 729] [1970-01-01 00:00:58] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:43 729] set basic_indicator_onoff:0 
[2024/8/7 9:25:43 745] [1970-01-01 00:00:58] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:43 745] [1970-01-01 00:00:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:43 761] [01-01 18:12:32 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:25:43 761] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:43 777] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:43 777] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:43 777] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:43 793] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:43 793] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:43 809] [01-01 18:12:32 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:43 810] [01-01 18:12:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:43 810] [01-01 18:12:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:43 825] [01-01 18:12:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:43 825] [01-01 18:12:32 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:43 825] [01-01 18:12:32 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:43 841] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:25:43 857] [01-01 18:12:32 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:43 873] [01-01 18:12:32 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:25:43 873] [01-01 18:12:32 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:43 889] [01-01 18:12:32 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:25:43 889] gethostbyname_r error: Unknown host
[2024/8/7 9:25:43 889] [01-01 18:12:32 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:25:43 905] [01-01 18:12:32 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:25:43 905] [01-01 18:12:32 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:25:43 921] [01-01 18:12:32 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:25:43 921] [01-01 18:12:32 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:25:43 937] [01-01 18:12:32 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:25:43 937] [01-01 18:12:32 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:25:43 937] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:25:43 954] [01-01 18:12:32 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:25:43 954] XmBleReadBuf 5:
[2024/8/7 9:25:43 954] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:43 954] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:43 969] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:43 969] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 13 rcount 13 offset 0 ---
[2024/8/7 9:25:43 969] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 13 ---
[2024/8/7 9:25:43 985] [01-01 18:12:32 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x6]
[2024/8/7 9:25:43 985] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:44 001] [01-01 18:12:32 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:44 001] bt_rev_raw 5
[2024/8/7 9:25:44 001] 05 d8 99 bc c1 
[2024/8/7 9:25:44 001] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:6, pack_len:4, total_len:97
[2024/8/7 9:25:44 019] ble rev data 97
[2024/8/7 9:25:44 033] 02 9b ee 0e 3b c6 9a 70 8a da c5 54 da 68 72 52 be 42 a3 4b ff 06 2e 3a 5d 32 73 e2 b9 a9 1b cf 3b 54 39 e2 0c e1 ce 47 26 b8 dd 7a a2 de ee 9f e0 19 c9 11 57 90 20 dd 36 de dd 87 2e f0 62 61 
[2024/8/7 9:25:44 033] fd 45 a3 6a 65 8b b6 41 6e ce b3 db 4b ff 9f 63 3d b0 be ee 06 8d 40 4f 22 31 b8 45 0a d8 99 bc c1 
[2024/8/7 9:25:44 033] ble decryped data 80
[2024/8/7 9:25:44 049] 00 00 00 03 00 00 00 00 00 21 00 41 7b 22 70 77 64 22 3a 22 78 6d 35 31 32 35 32 30 22 2c 22 73 73 69 64 22 3a 22 58 69 61 6f 6d 69 5f 46 31 44 43 22 2c 22 74 6f 6b 65 6e 22 3a 22 41 59 70 48 
[2024/8/7 9:25:44 066] 6f 52 4d 4b 4f 50 32 38 73 37 22 7d 00 77 7e 00 
[2024/8/7 9:25:44 066] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:44 066] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x21 
[2024/8/7 9:25:44 082] [01-01 18:12:32 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:33 Has No def operate
[2024/8/7 9:25:44 082] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:13 ---
[2024/8/7 9:25:44 098] [01-01 18:12:32 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:33
[2024/8/7 9:25:44 098] [01-01 18:12:32 TUYA N][bt_netcfg.c:63] Rev Net Cfg:{"pwd":"xm512520","ssid":"Xiaomi_F1DC","token":"AYpHoRMKOP28s7"}
[2024/8/7 9:25:44 112] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:44 112] [01-01 18:12:32 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x21 encrpyt:2
[2024/8/7 9:25:44 112] bt_ack_uncrypt 1
[2024/8/7 9:25:44 112] 00 
[2024/8/7 9:25:44 129] [01-01 18:12:32 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:44 129] [01-01 18:12:32 TUYA N][bt_netcfg.c:98] cfg ssid:Xiaomi_F1DC, passwd:xm512520, token:AYpHoRMKOP28s7
[2024/8/7 9:25:44 145] [01-01 18:12:32 TUYA D][tuya_devos_netcfg.c:464] concurrent Netcfg Finish type:0x10004 ssid:Xiaomi_F1DC passwd:xm512520 cur_netcfg_type:0
[2024/8/7 9:25:44 145] [01-01 18:12:32 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:25:44 161] tuya_hal_bt_send 20
[2024/8/7 9:25:44 161] 00 21 32 02 3a d9 19 3b 87 53 7a f0 9d 7d 48 67 a1 51 5b 73 
[2024/8/7 9:25:44 161] [01-01 18:12:32 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:44 176] 0 21 32 2 3a d9 19 3b 87 53 7a f0 9d 7d 48 67 a1 51 5b 73 
[2024/8/7 9:25:44 176] XmBleSendBuf 20: 00 21 32 02 3a d9 19 3b 87 53 7a f0 9d 7d 48 67 a1 51 5b 73
[2024/8/7 9:25:44 176] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:44 192] ble_slave_gap_event->type=13
[2024/8/7 9:25:44 193] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:44 193] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:44 193] [01-01 18:12:32 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:44 208] [01-01 18:12:32 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:25:44 208] tuya_hal_bt_send 17
[2024/8/7 9:25:44 208] 01 7b 16 55 d6 5f 83 95 e8 9e 46 92 07 b7 1b c4 ad 
[2024/8/7 9:25:44 224] [01-01 18:12:32 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:44 224] 1 7b 16 55 d6 5f 83 95 e8 9e 46 92 7 b7 1b c4 ad 
[2024/8/7 9:25:44 224] XmBleSendBuf 17: 01 7b 16 55 d6 5f 83 95 e8 9e 46 92 07 b7 1b c4 ad
[2024/8/7 9:25:44 240] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:44 240] ble_slave_gap_event->type=13
[2024/8/7 9:25:44 240] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:44 240] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:44 256]  ---
[2024/8/7 9:25:44 257] [01-01 18:12:32 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:44 272] [1970-01-01 00:00:58] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:44 272] [01-01 18:12:32 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:25:44 288] [01-01 18:12:32 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait
[2024/8/7 9:25:44 288] [01-01 18:12:32 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10002
[2024/8/7 9:25:44 288] [01-01 18:12:32 TUYA D][ap_netcfg.c:950] ap cfg stop:65538
[2024/8/7 9:25:44 304] DEBUG: ***u16num***[512]
[2024/8/7 9:25:44 304] [01-01 18:12:32 TUYA D][uni_thread.c:310] Del Thrd:udp_ap_v3
[2024/8/7 9:25:44 304] Received SIGTERM
[2024/8/7 9:25:44 320] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:25:44 320] DEBUG: ***u16num***[512]
[2024/8/7 9:25:44 320] atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:25:44 320] mset basic_indicator_onoff:1 
[2024/8/7 9:25:44 336] [1970-01-01 00:00:58] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:44 336] [1970-01-01 00:00:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:44 353] set basic_indicator_onoff:0 
[2024/8/7 9:25:44 353] [1970-01-01 00:00:58] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:44 368] [1970-01-01 00:00:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:44 368] [1970-01-01 00:00:58] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:44 384] set basic_indicator_onoff:1 
[2024/8/7 9:25:44 384] [1970-01-01 00:00:58] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:44 400] [1970-01-01 00:00:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:44 400] [01-01 18:12:33 TUYA D][ap_netcfg.c:553] wf_ap_stop:0
[2024/8/7 9:25:44 400] DEBUG: ***u16num***[512]
[2024/8/7 9:25:44 416] [1970-01-01 00:00:58] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:25:44 416] [1970-01-01 00:00:58] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:25:44 433] set basic_indicator_onoff:0 
[2024/8/7 9:25:44 433] [1970-01-01 00:00:58] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:44 449] [1970-01-01 00:00:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:44 449] set basic_indicator_onoff:1 
[2024/8/7 9:25:44 449] [1970-01-01 00:00:59] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:44 465] [1970-01-01 00:00:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:44 465] [1970-01-01 00:00:59] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time28952
[2024/8/7 9:25:44 481] set basic_indicator_onoff:0 
[2024/8/7 9:25:44 481] [1970-01-01 00:00:59] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:44 497] [1970-01-01 00:00:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:44 497] [01-01 18:12:33 TUYA N][ap_netcfg.c:172] exit ap_net_cfg task
[2024/8/7 9:25:44 497] [01-01 18:12:33 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10100
[2024/8/7 9:25:44 513] [01-01 18:12:33 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10004
[2024/8/7 9:25:44 513] [01-01 18:12:33 TUYA N][tuya_ble_api.c:439] update bound stat:1
[2024/8/7 9:25:44 529] [01-01 18:12:33 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:0
[2024/8/7 9:25:44 529] [01-01 18:12:33 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:25:44 529] [01-01 18:12:33 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:25:44 545] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:44 545] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:44 561] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:44 561] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:44 561] [01-01 18:12:33 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:25:44 577] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:44 577] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:44 577] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:44 593] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:44 593] [01-01 18:12:33 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:25:44 609] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:25:44 609] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:44 609] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:44 625] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:44 625] [01-01 18:12:33 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:25:44 641] [01-01 18:12:33 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:25:44 641] [01-01 18:12:33 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:25:44 641] [01-01 18:12:33 TUYA N][tuya_devos_ac[atbm_log]:[eth2] change to [2]
[2024/8/7 9:25:44 657] tivate.c:774] al[atbm_log]:[eth2] has been disabled
[2024/8/7 9:25:44 657] ready inited
[2024/8/7 9:25:44 657] DEBUG: ***u16num***[512]
[2024/8/7 9:25:44 657] curr event:5 
[2024/8/7 9:25:44 657] IPC_APP_Notify_LED_Sound_Status_CB line(491) -------------------------- IPC_CONNECTING_WIFI(5)
[2024/8/7 9:25:44 672] [1970-01-01 00:00:59] tuya_ipc_system_control_demo.c(492) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECTING, 0, 0, 0, 1))
[2024/8/7 9:25:44 689] [1970-01-01 00:00:59] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/RouterConnect_english.pcm]
[2024/8/7 9:25:44 705] [1970-01-01 00:00:59] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:25:44 705] [1970-01-01 00:00:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:25:44 705] set basic_indicator_onoff:1 
[2024/8/7 9:25:44 721] [1970-01-01 00:00:59] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:44 721] [1970-01-01 00:00:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:44 737] --- tracepoint MainApp.c,ConfigTimer(372): g_WifiConectStatuts 1 ---
[2024/8/7 9:25:44 737] [1970-01-01 00:00:59] MainApp.c(373) <ConfigTimer>: ConfigTimer exit ----
[2024/8/7 9:25:44 753] [01-01 18:12:33 TUYA I][bt_ext_porting.c:618] [TUYA-BTUART]ble_monitor_thread exit
[2024/8/7 9:25:44 753] [01-01 18:12:33 TUYA D][uni_thread.c:268] Thread:udp_ap_v3 Exec Finish. Set to Del Stat
[2024/8/7 9:25:44 769] [01-01 18:12:33 TUYA D][uni_thread.c:125] del list not empty...deleting 0xaebe3c, next 0xae0be8
[2024/8/7 9:25:44 769] [01-01 18:12:33 TUYA D][uni_thread.c:132] Final Free Thread:udp_ap_v3, is_self:1
[2024/8/7 9:25:44 769] [01-01 18:12:33 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:25:44 784] [01-01 18:12:33 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:25:44 784] DEBUG: ***u16num***[512]
[2024/8/7 9:25:44 801] DEBUG: ***u16num***[512]
[2024/8/7 9:25:44 880] DEBUG: ***u16num***[512]
[2024/8/7 9:25:45 025] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 ++++++++ 
[2024/8/7 9:25:45 041] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 --------- 
[2024/8/7 9:25:45 041] [atbm_log]:atbm_hw_scan:if_id(0)
[2024/8/7 9:25:45 041] [atbm_log]:atbm_hw_scan:scan, delay suspend
[2024/8/7 9:25:45 057] [atbm_log]:scan start band(0),(14)
[2024/8/7 9:25:45 057] DEBUG: ***u16num***[512]
[2024/8/7 9:25:45 200] DEBUG: ***u16num***[512]
[2024/8/7 9:25:45 409] DEBUG: ***u16num***[512]
[2024/8/7 9:25:45 633] DEBUG: ***u16num***[512]
[2024/8/7 9:25:45 713] set basic_indicator_onoff:0 
[2024/8/7 9:25:45 713] [1970-01-01 00:00:59] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 728] [1970-01-01 00:00:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:45 729] 
[2024/8/7 9:25:45 729] set basic_indicator_onoff:1 
[2024/8/7 9:25:45 745] [1970-01-01 00:00:59] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 745] [1970-01-01 00:00:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:45 745] set basic_indicator_onoff:0 
[2024/8/7 9:25:45 761] [1970-01-01 00:00:59] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 761] [1970-01-01 00:00:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:45 776] set basic_indicator_onoff:1 
[2024/8/7 9:25:45 777] [1970-01-01 00:00:59] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 792] [1970-01-01 00:00:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:45 792] set basic_indicator_onoff:0 
[2024/8/7 9:25:45 793] [1970-01-01 00:01:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 809] [1970-01-01 00:01:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:45 809] set basic_indicator_onoff:1 
[2024/8/7 9:25:45 824] [1970-01-01 00:01:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 824] [1970-01-01 00:01:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:45 824] set basic_indicator_onoff:0 
[2024/8/7 9:25:45 840] [1970-01-01 00:01:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 840] [1970-01-01 00:01:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:45 856] set basic_indicator_onoff:1 
[2024/8/7 9:25:45 856] [1970-01-01 00:01:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 872] [1970-01-01 00:01:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:45 872] set basic_indicator_onoff:0 
[2024/8/7 9:25:45 873] [1970-01-01 00:01:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 888] [1970-01-01 00:01:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:45 888] set basic_indicator_onoff:1 
[2024/8/7 9:25:45 904] [1970-01-01 00:01:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 904] [1970-01-01 00:01:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:45 904] set basic_indicator_onoff:0 
[2024/8/7 9:25:45 920] [1970-01-01 00:01:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 920] [1970-01-01 00:01:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:45 936] set basic_indicator_onoff:1 
[2024/8/7 9:25:45 936] [1970-01-01 00:01:00] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 952] [1970-01-01 00:01:00] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:45 952] set basic_indicator_onoff:0 
[2024/8/7 9:25:45 952] [1970-01-01 00:01:01] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:45 968] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:45 968] g_AudioTipsList.size() enable: 0[01-01 18:12:35 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:25:45 984] DEBUG: ***u16num***[512]
[2024/8/7 9:25:46 080] DEBUG: ***u16num***[512]
[2024/8/7 9:25:46 209] DEBUG: ***u16num***[512]
[2024/8/7 9:25:46 400] [atbm_log]:hw_priv->scan.status 0
[2024/8/7 9:25:46 432] [atbm_log]:atbm_scan_work:end(0)
[2024/8/7 9:25:46 449] DEBUG: ***u16num***[512]
[2024/8/7 9:25:46 465] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:25:46 465] [atbm_log]:authen:(a4:a9:30:ce:5e:66),ssid(Xiaomi_F1DC)
[2024/8/7 9:25:46 465] [atbm_log]:authenticate[a4:a9:30:ce:5e:66]:[0][1]
[2024/8/7 9:25:46 481] [atbm_log]:eth2: authenticate with a4:a9:30:ce:5e:66 (try 1) (1)(0)
[2024/8/7 9:25:46 481] [atbm_log]:[STA] Join DTIM: 1, interval: 100
[2024/8/7 9:25:46 513] [atbm_log]:[TX]:authen, delay suspend
[2024/8/7 9:25:46 513] [atbm_log]:eth2: authenticated
[2024/8/7 9:25:46 513] [atbm_log]:work:flush sta[a4:a9:30:ce:5e:66]
[2024/8/7 9:25:46 576] [atbm_log]:sta has been insert(0)
[2024/8/7 9:25:46 577] [atbm_log]:wk->assoc.use_he 1 1++
[2024/8/7 9:25:46 577] [atbm_log]:flush sta(0):
[2024/8/7 9:25:46 577] DEBUG: ***u16num***[512]
[2024/8/7 9:25:46 593] [atbm_log]:eth2: associated
[2024/8/7 9:25:46 593] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:25:46 609] [atbm_log]:eth2:free authen bss --
[2024/8/7 9:25:46 609] [atbm_log]:is_wifi6_ap++
[2024/8/7 9:25:46 609] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:25:46 609] [atbm_log]:eth2  WMM AC=0 acm=0 aifs=2 cWmin=3 cWmax=7 txop=47 uapsd=0
[2024/8/7 9:25:46 625] [atbm_log]:eth2  WMM AC=1 acm=0 aifs=2 cWmin=7 cWmax=15 txop=94 uapsd=0
[2024/8/7 9:25:46 641] [atbm_log]:eth2  WMM AC=2 acm=0 aifs=3 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:25:46 641] [atbm_log]:eth2  WMM AC=3 acm=0 aifs=7 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:25:46 641] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:25:46 656] [atbm_log]:[a4:a9:30:ce:5e:66]:20M channel
[2024/8/7 9:25:46 656] [atbm_log]:atbm_bss_info_changed:chatype(1),channelNumber(3)
[2024/8/7 9:25:46 656] [atbm_log]:BssidColor[34]
[2024/8/7 9:25:46 672] [atbm_log]:[STA] color 34, he_support_flag: 53
[2024/8/7 9:25:46 672] [atbm_log]:==>connect wifi6 AP open AX, set BA WIN short
[2024/8/7 9:25:46 673] [atbm_log]:[eth2] Waiting Txq Ready[1]
[2024/8/7 9:25:46 720] [atbm_log]:[eth2]:dtim changed [0]->[1]
[2024/8/7 9:25:46 721] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:25:46 721] NOHZ: local_softirq_pending 08
[2024/8/7 9:25:46 721] DEBUG: ***u16num***[512]
[2024/8/7 9:25:46 737] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:25:46 737] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:25:46 737] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:25:46 753] [atbm_log]:send htc qos null
[2024/8/7 9:25:46 753] [atbm_log]:om work(1)
[2024/8/7 9:25:46 928] DEBUG: ***u16num***[512]
[2024/8/7 9:25:46 992] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:25:46 992] [atbm_log]:send htc qos null
[2024/8/7 9:25:46 992] [atbm_log]:om work(2)
[2024/8/7 9:25:47 072] DEBUG: ***u16num***[512]
[2024/8/7 9:25:47 185] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:25:47 185] set basic_indicator_onoff:1 
[2024/8/7 9:25:47 201] [1970-01-01 00:01:01] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 201] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:47 201] set basic_indicator_onoff:0 
[2024/8/7 9:25:47 217] [1970-01-01 00:01:01] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 217] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:47 217] set basic_indicator_onoff:1 
[2024/8/7 9:25:47 233] [1970-01-01 00:01:01] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 233] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:47 249] 
[2024/8/7 9:25:47 249] set basic_indicat[atbm_log]:QosNUll Htc(807)
[2024/8/7 9:25:47 250] or_onoff:0 
[2024/8/7 9:25:47 250] atbm_log]:send htc qos null
[2024/8/7 9:25:47 250] 32m[1970-01-01 0[atbm_log]:om work(3)
[2024/8/7 9:25:47 265] 0:01:01] tuya_ip[atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:25:47 265] c_dp_handler.c(2[atbm_log]:aggtx stop queue
[2024/8/7 9:25:47 265] 62) <IPC_APP_set[atbm_log]:add to pending(2)(20)
[2024/8/7 9:25:47 265] _basic_indicator[atbm_log]:dhcp work(1)
[2024/8/7 9:25:47 281] _onoff>: SwapFlag=false
[2024/8/7 9:25:47 281] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:47 281] set basic_indicator_onoff:1 
[2024/8/7 9:25:47 297] [1970-01-01 00:01:01] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 297] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:47 313] [1970-01-01 00:01:01] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:25:47 313] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:25:47 313] set basic_indicator_onoff:0 
[2024/8/7 9:25:47 329] [1970-01-01 00:01:01] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 329] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:47 345] 
[2024/8/7 9:25:47 346] set basic_indicator_onoff:1 
[2024/8/7 9:25:47 346] [1970-01-01 00:01:01] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 363] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:47 377] [1970-01-01 00:01:01] xm_main.c(374) <AutoMaintenance[atbm_log]:AMPDU[eth2]:action[2],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:25:47 377] _pro>: The time [atbm_log]:activated addBA response timer on tid 0
[2024/8/7 9:25:47 377] did not reach 10 seconds[atbm_log]:aggtx wake queue
[2024/8/7 9:25:47 377] set basic_[atbm_log]:sta_hdr
[2024/8/7 9:25:47 393] indicator_onoff:0 
[2024/8/7 9:25:47 393] [1970-[atbm_log]:switched off addBA timer for tid 0
[2024/8/7 9:25:47 393] 01-01 00:01:01] [atbm_log]:Aggregation is on for tid 0
[2024/8/7 9:25:47 410] tuya_ipc_dp_hand[atbm_log]:AMPDU[eth2]:action[4],tid[0],ssn[0],buff_size[64],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:25:47 410] ler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 425] [1970-01-01 00:01:01] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:47 425] set basic_indicator_onoff:1 
[2024/8/7 9:25:47 425] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 440] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:47 440] set basic_indicator_onoff:0 
[2024/8/7 9:25:47 440] [1970-01-01 00:01:[atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:25:47 457] 02] tuya_ipc_dp_[atbm_log]:dhcp donehandler.c(262) <
[2024/8/7 9:25:47 457] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[6]
[2024/8/7 9:25:47 473] IPC_APP_set_basic_indica[atbm_log]:AMPDU[eth2]:action[0],tid[6],ssn[1],buff_size[64],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:25:47 473] tor_onoff>: SwapFlag=false
[2024/8/7 9:25:47 473] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:47 493] set basic_indicator_onoff:1 
[2024/8/7 9:25:47 493]  tbm_log]:Rx A-MPDU request on tid 6 result 0
[2024/8/7 9:25:47 493] [32m[1970-01-01 [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[0]
[2024/8/7 9:25:47 505] 00:01:02] tuya_i[atbm_log]:AMPDU[eth2]:action[0],tid[0],ssn[0],buff_size[64],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:25:47 505] pc_dp_handler.c([atbm_log]:Rx A-MPDU request on tid 0 result 0
[2024/8/7 9:25:47 505] 262) <IPC_APP_se[atbm_log]:QosNUll Htc(807)
[2024/8/7 9:25:47 521] t_basic_indicato[atbm_log]:send htc qos null
[2024/8/7 9:25:47 521] r_onoff>: SwapFl[atbm_log]:om work(4)
[2024/8/7 9:25:47 521] ag=false
[2024/8/7 9:25:47 521] atbm_log]:dhcp work(1)
[2024/8/7 9:25:47 537] 1;32m[1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:47 537] set basic_[atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:25:47 537] indicator_onoff:[atbm_log]:dhcp done0 
[2024/8/7 9:25:47 553] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:47 553] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:47 569] [01-01 18:12:36 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:25:47 569] DEBUG: ***u16num***[512]
[2024/8/7 9:25:47 569] DEBUG: ***u16num***[51[atbm_log]:connecting done for waitting dhcp  
[2024/8/7 9:25:47 569] 2]
[2024/8/7 9:25:47 585] route: SIOCDELRT: No such process
[2024/8/7 9:25:47 681] DEBUG: ***u16num***[512]
[2024/8/7 9:25:47 792] 
[2024/8/7 9:25:47 808] [atbm_log]:om done
[2024/8/7 9:25:47 808] DEBUG: ***u16num***[512]
[2024/8/7 9:25:48 049] DEBUG: ***u16num***[512]
[2024/8/7 9:25:48 096] set basic_indicator_onoff:1 
[2024/8/7 9:25:48 112] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 113] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:48 113] set basic_indicator_onoff:0 
[2024/8/7 9:25:48 129] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 129] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:48 145] set basic_indicator_onoff:1 
[2024/8/7 9:25:48 145] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 161] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:48 161] set basic_indicator_onoff:0 
[2024/8/7 9:25:48 161] [1970-01-01 00:01:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 177] [1970-01-01 00:01:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:48 177] [1970-01-01 00:01:02] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time32900
[2024/8/7 9:25:48 193] set basic_indicator_onoff:1 
[2024/8/7 9:25:48 193] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indic[atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[5]
[2024/8/7 9:25:48 209] ator_onoff>: Swa[atbm_log]:<WIFI> rx ampdu ++ 
[2024/8/7 9:25:48 209] pFlag=false
[2024/8/7 9:25:48 209] atbm_log]:napi schedule
[2024/8/7 9:25:48 225] m[1970-01[atbm_log]:AMPDU[eth2]:action[0],tid[5],ssn[3],buff_size[64],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:25:48 225] -01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:48 225] set basic_indicator_onoff:0 
[2024/8/7 9:25:48 241] [1970-01-01 00:01:03] tuya_[atbm_log]:Rx A-MPDU request on tid 5 result 0
[2024/8/7 9:25:48 241] ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 241] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:48 257] set basic_indicator_onoff:1 
[2024/8/7 9:25:48 257] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 273] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:48 273] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:1
[2024/8/7 9:25:48 273] set basic_indicator_onoff:0 
[2024/8/7 9:25:48 289] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 289] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:48 305] curr event:6 
[2024/8/7 9:25:48 306] IPC_APP_Notify_LED_Sound_Status_CB line(497) -------------------------- IPC_CONNECT_WIFI_SUCCESS(6)
[2024/8/7 9:25:48 321] [1970-01-01 00:01:03] tuya_ipc_system_control_demo.c(498) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECT_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:25:48 321] [01-01 18:12:37 TUYA D][tuya_devos_netlink.c:313] wf connect success!
[2024/8/7 9:25:48 337] [01-01 18:12:37 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:25:48 338] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:25:48 353] [01-01 18:12:37 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:25:48 353] [01-01 18:12:37 TUYA E][mqtt_client.c:807] hand null.
[2024/8/7 9:25:48 370] [1970-01-01 00:01:03] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/ServerConnect_english.pcm]
[2024/8/7 9:25:48 370] [1970-01-01 00:01:03] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:25:48 385] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:25:48 385] [01-01 18:12:37 TUYA D][tuya_iot_wired_wifi_api.c:584] wired wifi default stat:1,change:1
[2024/8/7 9:25:48 401] [01-01 18:12:37 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[2024/8/7 9:25:48 401] [01-01 18:12:37 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[2024/8/7 9:25:48 418] [01-01 18:12:37 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:25:48 418] dev id key: 16
[2024/8/7 9:25:48 418] c0 b9 30 cc 91 82 20 e0 27 d3 45 b3 ab 3c 27 bf 
[2024/8/7 9:25:48 432] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:25:48 432] [01-01 18:12:37 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:25:48 433] 2 1 6 3 2 1 a2 14 16 1 a2 0 1c 6a 97 74 ce 42 f4 54 8c 72 2e 92 d 9f a1 db 
[2024/8/7 9:25:48 448] [01-01 18:12:37 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:25:48 448] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 30 7b 27 8c c6 8b 14 13 8e 36 f6 75 73 7d 4b 
[2024/8/7 9:25:48 465] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:25:48 465] [01-01 18:12:37 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:25:48 480] [01-01 18:12:37 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:25:48 480] [01-01 18:12:37 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:25:48 481] [01-01 18:12:37 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:48 496] [01-01 18:12:37 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:48 497] [01-01 18:12:37 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:48 497] [01-01 18:12:37 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:48 513] [01-01 18:12:37 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:48 513] [01-01 18:12:37 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:48 529] [01-01 18:12:37 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:48 529] [01-01 18:12:37 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:48 529] [01-01 18:12:37 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:48 544] [01-01 18:12:37 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:48 545] [01-01 18:12:37 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:25:48 560] [01-01 18:12:37 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:25:48 561] [01-01 18:12:37 TUYA D][iot_httpc.c:1435] sign_buffer:env=28s7&region=AY&ts=22&uuid=uuidcaab27b0a838d239
[2024/8/7 9:25:48 576] [01-01 18:12:37 TUYA D][iot_httpc.c:1443] sign_base64_encode:SwZGPQeAr+fvzAOZ44oXQfFVGH/UMG/pPkMprcEy4qU=
[2024/8/7 9:25:48 577] [01-01 18:12:37 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:25:48 609] [01-01 18:12:37 TUYA D][iot_httpc.c:1514] http_dns send: {"region":"AY","env":"28s7","uuid":"uuidcaab27b0a838d239","ts":22,"sign":"SwZGPQeAr+fvzAOZ44oXQfFVGH/UMG/pPkMprcEy4qU=","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:25:48 631] [01-01 18:12:37 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v2/url_config
[2024/8/7 9:25:48 631] [01-01 18:12:37 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:25:48 631] [01-01 18:12:37 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:25:48 643] 
[2024/8/7 9:25:48 644] [01-01 18:12:37 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:25:48 644] [01-01 18:12:37 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:25:48 658] set basic_indicator_onoff:1 
[2024/8/7 9:25:48 658] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 673] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:48 673] [01-01 18:12:37 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:25:48 689] [01-01 18:12:37 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:48 689] [01-01 18:12:37 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:48 705] [01-01 18:12:37 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:48 705] [01-01 18:12:37 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:25:48 705] DEBUG: ***u16num***[512]
[2024/8/7 9:25:48 721] [01-01 18:12:37 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:48 721] DEBUG: ***u16num***[512]
[2024/8/7 9:25:48 721] set basic_indicator_onoff:0 
[2024/8/7 9:25:48 737] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 737] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:48 737] set basic_indicator_onoff:1 
[2024/8/7 9:25:48 753] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 753] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:48 769] [01-01 18:12:38 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:25:48 769] set basic_indicator_onoff:0 
[2024/8/7 9:25:48 784] [1970-01-01 00:01:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:48 784] [1970-01-01 00:01:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:48 800] [01-01 18:12:38 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:48 800] [01-01 18:12:38 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:25:48 817] [01-01 18:12:38 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:48 817] [01-01 18:12:38 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:48 833] [01-01 18:12:38 TUYA D][iot_httpc.c:1578] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216]
[2024/8/7 9:25:48 833] [01-01 18:12:38 TUYA D][iot_httpc.c:1579] mqttUrl:[m2.tuyacn.com:1883][121.5.96.167]
[2024/8/7 9:25:48 849] [01-01 18:12:38 TUYA D][iot_httpc.c:1602] httpsSelfUrl:[https://a2.tuyacn.com[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:48 849] /d.json][42.192.31.36]
[2024/8/7 9:25:48 849] [01-01 18:12:38 TUYA D][iot_httpc.c:1603] mqttsSelfUrl:[m2.tuyacn.com:8883][121.5.96.167]
[2024/8/7 9:25:48 865] [01-01 18:12:38 TUYA D][iot_httpc.c:1670] g[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:48 865] hostUrl:[baal.tuyacn.com:443][42.192.35.108]
[2024/8/7 9:25:48 881] [01-01 18:12:38 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:25:48 881] [01-01 18:12:38 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:48 881] [01-01 18:12:38 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:25:48 897] [01-01 18:12:38 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:25:48 897] [01-01 18:12:38 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:25:48 912] [01-01 18:12:38 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:25:48 913] [01-01 18:12:38 TUYA D][iot_httpc.c:1684] tls_ca_name:tls_ca0
[2024/8/7 9:25:48 913] [01-01 18:12:38 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:25:48 929] [01-01 18:12:38 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:48 929] [01-01 18:12:38 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:48 929] [01-01 18:12:38 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:48 945] [01-01 18:12:38 TUYA D][simplekv.c:374] write key:tls_ca0 And Value Len:2688
[2024/8/7 9:25:48 945] [01-01 18:12:38 TUYA D][simplekv.c:457] new space 8 startpos:30428 size:2756
[2024/8/7 9:25:48 961] [01-01 18:12:38 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:48 961] [01-01 18:12:38 TUYA D][simplekv.c:203] update crc 1395591596
[2024/8/7 9:25:48 961] [01-01 18:12:38 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:48 977] [01-01 18:12:38 TUYA D][simplekv.c:520] write succes[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:48 977] s
[2024/8/7 9:25:48 977] [01-01 18:12:38 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:48 993] [01-01 18:12:38 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:48 993] [01-01 18:12:38 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:49 009] [01-01 18:12:38 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:49 009] DEBUG: ***u16num***[512]
[2024/8/7 9:25:49 009] [01-01 18:12:38 TUYA D][simplekv.c:374] write key:tls_ca_cnt And Value Len:16
[2024/8/7 9:25:49 025] [01-01 18:12:38 TUYA D][simplekv.c:457] new space 9 startpos:33184 size:84
[2024/8/7 9:25:49 025] [01-01 18:12:38 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:49 025] [01-01 18:12:38 TUYA D][simplekv.c:203] update crc 213719394
[2024/8/7 9:25:49 041] set basic_indicator_onoff:1 
[2024/8/7 9:25:49 041] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:49 057] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:49 057] [01-01 18:12:38 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:49 057] [01-01 18:12:38 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:49 072] [01-01 18:12:38 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:25:49 073] [01-01 18:12:38 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216]
[2024/8/7 9:25:49 089] [01-01 18:12:38 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36]
[2024/8/7 9:25:49 089] [01-01 18:12:38 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[121.5.96.167]
[2024/8/7 9:25:49 105] [01-01 18:12:38 TUYA D][uni_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:49 105] network.c:268] cache dns [m2.tuyacn.com:8883]<->[121.5.96.167]
[2024/8/7 9:25:49 120] [01-01 18:12:38 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108]
[2024/8/7 9:25:49 120] [01-01 18:12:38 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:25:49 121] [01-01 18:12:38 TUYA D][simplekv.c:1251] find key:9 tls_ca_cnt
[2024/8/7 9:25:49 136] [01-01 18:12:38 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[2024/8/7 9:25:49 136] [01-01 18:12:38 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[2024/8/7 9:25:49 152] [01-01 18:12:38 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:25:49 152] [01-01 18:12:38 TUYA D][simplekv.c:1251] find key:8 tls_ca0
[2024/8/7 9:25:49 153] [01-01 18:12:38 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688
[2024/8/7 9:25:49 169] [01-01 18:12:38 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
[2024/8/7 9:25:49 169] [01-01 18:12:38 TUYA D][iot_httpc.c:1696] end
[2024/8/7 9:25:49 169] [01-01 18:12:38 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:25:49 184] [01-01 18:12:38 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:49 184] [01-01 18:12:38 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:25:49 184] bt_ack_uncrypt 2
[2024/8/7 9:25:49 184] 00 00 
[2024/8/7 9:25:49 200] [01-01 18:12:38 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:49 200] [01-01 18:12:38 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:25:49 200] tuya_hal_bt_send 20
[2024/8/7 9:25:49 216] 00 21 33 02 e3 7a c1 01 03 1c 13 12 c7 67 47 9f 6f d4 d0 51 
[2024/8/7 9:25:49 216] [01-01 18:12:38 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:49 217] 0 21 33 2 e3 7a c1 1 3 1c 13 12 c7 67 47 9f 6f d4 d0 51 
[2024/8/7 9:25:49 232] XmBleSendBuf 20: 00 21 33 02 e3 7a c1 01 03 1c 13 12 c7 67 47 9f 6f d4 d0 51
[2024/8/7 9:25:49 232] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:49 232] ble_slave_gap_event->type=13
[2024/8/7 9:25:49 248] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:49 248] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:49 248] [01-01 18:12:38 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:49 264] [01-01 18:12:38 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:25:49 264] tuya_hal_bt_send 17
[2024/8/7 9:25:49 264] 01 80 d9 23 f3 59 44 c5 57 93 81 fc 7f a3 ea 35 9f 
[2024/8/7 9:25:49 280] [01-01 18:12:38 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:49 280] 1 80 d9 23 f3 59 44 c5 57 93 81 fc 7f a3 ea 35 9f 
[2024/8/7 9:25:49 280] XmBleSendBuf 17: 01 80 d9 23 f3 59 44 c5 57 93 81 fc 7f a3 ea 35 9f
[2024/8/7 9:25:49 280] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:49 296] ble_slave_gap_event->type=13
[2024/8/7 9:25:49 296] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:49 296] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:49 312] [01-01 18:12:38 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:49 312] DEBUG: ***u16num***[512]
[2024/8/7 9:25:49 312] [01-01 18:12:38 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:25:49 328] [1970-01-01 00:01:04] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:49 328] [01-01 18:12:38 TUYA D][tuya_devos_activate.c:356] dev_nw_cfg_active_stage:5
[2024/8/7 9:25:49 344] [01-01 18:12:38 TUYA D][iot_httpc.c:3195] modules:(null)
[2024/8/7 9:25:49 344] [01-01 18:12:38 TUYA D][simplekv.c:1211] read key:last_reset_info isFuzzy:0 skipCnt:0
[2024/8/7 9:25:49 344] [01-01 18:12:38 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:49 360] [01-01 18:12:38 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:49 360] [01-01 18:12:38 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:49 376] [01-01 18:12:38 TUYA D][iot_httpc.c:3198] options:{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}
[2024/8/7 9:25:49 376] set basic_indicator_onoff:0 
[2024/8/7 9:25:49 441] [01-01 18:12:38 TUYA D][iot_httpc.c:1161] Post Data: {"token":"pHoRMKOP","softVer":"1.5.431","productKey":"fvijo8jvloagv1gm","protocolVer":"2.2","baselineVer":"40.00","hid":"90314ba51650","skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}}","devAttribute":67,"cadVer":"1.0.4","cdVer":"1.0.0","options":"{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}","t":23}
[2024/8/7 9:25:49 441] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:49 473] [01-01 18:12:38 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.active&et=1&t=23&uuid=uuidcaab27b0a838d239&v=4.4&sign=bcc54fee761bf77237da552946576ceb
[2024/8/7 9:25:49 476] [01-01 18:12:38 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:49 476] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:49 488] [01-01 18:12:38 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:49 489] [01-01 18:12:38 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:49 505] [01-01 18:12:38 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:49 505] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:49 505] Len=20 step 0
[2024/8/7 9:25:49 520] att=0x0 0x21 0x20 0x2 0xcb 0x77 0x26 0x1f 0x3 0xda 0xce 0x3a 0x3f 0x5c 0x85 0x29 0x3d 0x36 0x44 0xe8 
[2024/8/7 9:25:49 520]  RCVS len:20
[2024/8/7 9:25:49 521] [01-01 18:12:38 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:49 537] [01-01 18:12:38 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:49 537] [01-01 18:12:38 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:49 553] [01-01 18:12:38 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:49 553] [01-01 18:12:38 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:49 570] [01-01 18:12:38 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:49 570] [01-01 18:12:38 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:49 571] XmBleReadBuf 20:
[2024/8/7 9:25:49 571] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:49 585] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:49 585] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:49 600] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:49 600] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:49 600] [01-01 18:12:38 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:49 616] [01-01 18:12:38 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:49 616] [01-01 18:12:38 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:49 616] bt_rev_raw 20
[2024/8/7 9:25:49 632] 00 21 20 02 cb 77 26 1f 03 da ce 3a 3f 5c 85 29 3d 36 44 e8 
[2024/8/7 9:25:49 632] [01-01 18:12:38 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:25:49 648] [01-01 18:12:38 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:49 648] DEBUG: ***u16num***[512]
[2024/8/7 9:25:49 648] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:49 648] set basic_indicator_onoff:1 
[2024/8/7 9:25:49 664] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:49 680] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:49 681] 
[2024/8/7 9:25:49 681] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:49 681] Len=17 step 0
[2024/8/7 9:25:49 681] att=0x1 0x9 0xcb 0x1c 0xcc 0x55 0xab 0x36 0x7 0xea 0x49 0x91 0x18 0x2d 0xf8 0x1 0x41 
[2024/8/7 9:25:49 696]  RCVS len:17
[2024/8/7 9:25:49 696] [1970-01-01 00:01:04] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:49 696] XmBleReadBuf 17:
[2024/8/7 9:25:49 696] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:49 712] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:49 712] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:49 712] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:25:49 728] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:25:49 728] [01-01 18:12:38 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:25:49 744] [01-01 18:12:38 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:49 744] [01-01 18:12:38 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:49 744] bt_rev_raw 17
[2024/8/7 9:25:49 744] 01 09 cb 1c cc 55 ab 36 07 ea 49 91 18 2d f8 01 41 
[2024/8/7 9:25:49 760] [01-01 18:12:38 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:25:49 760] ble rev data 33
[2024/8/7 9:25:49 776] 02 cb 77 26 1f 03 da ce 3a 3f 5c 85 29 3d 36 44 e8 09 cb 1c cc 55 ab 36 07 ea 49 91 18 2d f8 01 41 
[2024/8/7 9:25:49 776] ble decryped data 16
[2024/8/7 9:25:49 776] 00 00 00 04 00 00 00 00 00 22 00 01 00 d6 49 00 
[2024/8/7 9:25:49 776] [01-01 18:12:38 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:49 792] [01-01 18:12:38 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:25:49 792] [01-01 18:12:38 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:25:49 792] DEBUG: ***u16num***[512]
[2024/8/7 9:25:49 808] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:25:49 808] set basic_indicator_onoff:0 
[2024/8/7 9:25:49 824] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:49 824] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:49 824] set basic_indicator_onoff:1 
[2024/8/7 9:25:49 840] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:49 840] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:49 856] [01-01 18:12:38 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:49 872] [01-01 18:12:38 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:49 872] DEBUG: ***u16num***[512]
[2024/8/7 9:25:49 872] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:25:49 872] Mode(Product):0
[2024/8/7 9:25:49 872] BpuMode:[Online]
[2024/8/7 9:25:49 888] VpssMode:[Online]
[2024/8/7 9:25:49 888] [0.LimitUp_info]:
[2024/8/7 9:25:49 888] LimitUp:[Disable]
[2024/8/7 9:25:49 888] [2680*0]->[3840*0])
[2024/8/7 9:25:49 888] chn	TotalSize	ActiveSize
[2024/8/7 9:25:49 888] 0	5040*2246	2680*2160
[2024/8/7 9:25:49 888] 0	5040*2246	3840*2160
[2024/8/7 9:25:49 904] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:25:49 904] [1.VICU_info]:
[2024/8/7 9:25:49 904] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:25:49 904] 0	25.0	672	0	0	183	linear	8ddb00
[2024/8/7 9:25:49 904] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:25:49 904] en	op_type	m_chn	now
[2024/8/7 9:25:49 920] 0	1	1	1
[2024/8/7 9:25:49 921] 
[2024/8/7 9:25:49 921] [2.VI_info]:
[2024/8/7 9:25:49 921] chn	TotalSize	ActiveSize
[2024/8/7 9:25:49 921] 0	5040*2246	3848*2166
[2024/8/7 9:25:49 921] 1	   0*   0	   0*   0
[2024/8/7 9:25:49 921] [3.MIPI_info]:
[2024/8/7 9:25:49 921] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:25:49 936] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:25:49 936] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:25:49 936] [4.Cut_info]:
[2024/8/7 9:25:49 936] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:25:49 936] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:25:49 952] vicu	0	1	1	2	3840	2160	  
[2024/8/7 9:25:49 952] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:25:49 952] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:25:49 952] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:25:49 952] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:25:49 952] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:25:49 968] [5.IB(isp buffer info)]:
[2024/8/7 9:25:49 968] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:25:49 968] PoolId  Count  Size
[2024/8/7 9:25:49 984] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:49 984] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:49 984] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:50 000] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:50 000] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:25:50 017] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:25:50 017] DEBUG: ***u16num***[512]
[2024/8/7 9:25:50 017] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:25:50 017] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:25:50 034] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:25:50 034] 0       0         0          0          4       
[2024/8/7 9:25:50 034] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:25:50 049]      --265--            --264--                                               
[2024/8/7 9:25:50 049] Count      Line     Count      Line     
[2024/8/7 9:25:50 049] 505        437      1244       560      
[2024/8/7 9:25:50 065] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:25:50 065] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:25:50 081] 0   3840   2160    H265  0      0        0           301       983033     7        	
[2024/8/7 9:25:50 081] 1   640    360     H265  0      0        0           194       43197      3        	
[2024/8/7 9:25:50 097] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:25:50 097] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:25:50 113] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:25:50 129] 0   Y      301      1       0       15       0        301      301      393       65225         59245    137634   64973    12      
[2024/8/7 9:25:50 129] 1   Y      194      0       8       1        0        194      194      393       3592          1945     20266    2623     8       
[2024/8/7 9:25:50 145] 3   N      0        0       0       1        0        0        0        393       0             0        0        0        0       
[2024/8/7 9:25:50 145] DEBUG: ***u16num***[512]
[2024/8/7 9:25:50 145] set basic_indicator_onoff:0 
[2024/8/7 9:25:50 160] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:50 176] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.t=[12],val=[0]
[2024/8/7 9:25:50 176] set basic_indicator_onoff:1 
[2024/8/7 9:25:50 176] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:50 192] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:50 192] [1970-01-01 00:01:04] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:25:50 209] set basic_indicator_onoff:0 
[2024/8/7 9:25:50 209] [1970-01-01 00:01:04] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:50 225] [1970-01-01 00:01:04] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:50 225] [1970-01-01 00:01:05] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:25:50 225] set basic_indicator_onoff:1 
[2024/8/7 9:25:50 241] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:50 241] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:50 257] 
[2024/8/7 9:25:50 257] set basic_indicator_onoff:0 
[2024/8/7 9:25:50 257] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:50 273] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:50 289] [01-01 18:12:39 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"capability":1,"devId":"6c15d25ee258e171f90aba","dstIntervals":[],"localKey":"iWDZSY/RmhDGqMt~","resetFactory":false,"schema":"[{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":101,\"[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:50 321] type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":103,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:50 337] 104,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"range\":[\"0\",\"1\",\"2\"[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:50 368] ],\"type\":\"enum\"},\"id\":106,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":109,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"min\":1,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":110,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":111,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":113,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\
[2024/8/7 9:25:50 384] [08-07 19:38:07 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:50 384] [08-07 19:38:07 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:50 384] [08-07 19:38:07 TUYA D][tuya_devos_activate.c:210] cloud_reset:0 local_reset:1
[2024/8/7 9:25:50 400] [08-07 19:38:07 TUYA D][tuya_devos_activate.c:256] __tmm_gw_actv_work: reset stride flag.
[2024/8/7 9:25:50 400] [08-07 19:38:07 TUYA D][tuya_devos_entry.c:1477] write stride to flash:0
[2024/8/7 9:25:50 416] [0[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:25:50 416] 8-07 19:38:07 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 9:25:50 416] [08-07 19:38:07 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:50 432] [08-07 19:38:07 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:50 432] [08-07 19:38:07 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:50 448] [08-07 19:38:07 TUYA D][simplekv.c:374] write key:is_stride And Value Len:16
[2024/8/7 9:25:50 448] [08-07 19:38:07 TUYA D][simplekv.c:457] new space 10 startpos:33268 size:84
[2024/8/7 9:25:50 464] [08-07 19:38:07 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:50 464] [08-07 19:38:07 TUYA D][simplekv.c:203] update crc 1143988772
[2024/8/7 9:25:50 464] set basic_indicator_onoff:1 
[2024/8/7 9:25:50 480] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:50 480] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:50 496] [08-07 19:38:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:50 497] [08-07 19:38:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:50 497] [08-07 19:38:07 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:25:50 512] [08-07 19:38:07 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 9:25:50 512] [08-07 19:38:07 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 9:25:50 512] [08-07 19:38:07 TUYA D][simplekv.c:374] write key:gw_di And Value Len:416
[2024/8/7 9:25:50 528] [08-07 19:38:07 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416
[2024/8/7 9:25:50 528] [08-07 19:38:07 TUYA D][simplekv.c:430] find 2 available space
[2024/8/7 9:25:50 544] [08-07 19:38:07 TUYA D][simplekv.c:474] reuse available space 29188
[2024/8/7 9:25:50 544] [08-07 19:38:07 TUYA D][simplekv.c:203] update crc 2215986191
[2024/8/7 9:25:50 544] [08-07 19:38:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:50 560] [08-07 19:38:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:50 560] [08-07 19:38:07 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:25:50 560] [08-07 19:38:07 TUYA D][simplekv.c:1211] read key:flvlrc isFuzzy:0 skipCnt:0
[2024/8/7 9:25:50 576] [08-07 19:38:07 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:50 576] [08-07 19:38:07 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:50 576] [08-07 19:38:07 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:50 592] [08-07 19:38:07 TUYA D][simplekv.c:374] write key:flvlrc And Value Len:2928
[2024/8/7 9:25:50 592] [08-07 19:38:07 TUYA D][simplekv.c:457] new space 11 startpos:33352 size:2996
[2024/8/7 9:25:50 612] [08-07 19:38:07 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:50 612] [08-07 19:38:07 TUYA D][simplekv.c:203] update crc 2325723110
[2024/8/7 9:25:50 612] DEBUG: ***u16num***[512]
[2024/8/7 9:25:50 624] [08-07 19:38:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:50 624] [08-07 19:38:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:50 624] [08-07 19:38:07 TUYA D][ws_db_gw.c:670] schema write success
[2024/8/7 9:25:50 640] [08-07 19:38:07 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success 
[2024/8/7 9:25:50 640] [08-07 19:38:07 TUYA D][tuya_ipc_sdk_init.c:183] ON post active:0xb1cc58
[2024/8/7 9:25:50 656] [08-07 19:38:07 TUYA D][tuya_ipc_sdk_init.c:172] skillResult p2pId:[]
[2024/8/7 9:25:50 656] [08-07 19:38:07 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:25:50 656] [08-07 19:38:07 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 9:25:50 672] [08-07 19:38:07 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[2024/8/7 9:25:50 672] [08-07 19:38:07 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:544
[2024/8/7 9:25:50 688] [08-07 19:38:07 TUYA D][simplekv.c:394] 4 key same BUT size old 436 < new 544 need find new hd
[2024/8/7 9:25:50 688] [08-07 19:38:07 TUYA D][simplekv.c:457] new space 12 startpos:36348 size:612
[2024/8/7 9:25:50 688] [08-07 19:38:07 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:50 704] [08-07 19:38:07 TUYA D][simplekv.c:203] update crc 3244018397
[2024/8/7 9:25:50 705] [08-07 19:38:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:50 720] [08-07 19:38:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:50 720] [08-07 19:38:07 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:25:50 738] [08-07 19:38:07 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":9,"ssid":"WGlhb21pX0YxREM=","passwd":"eG01MTI1MjA=","md":0,"random":0,"wfb64":1,"stat":2,"token":"pHoRMKOP","region":"AY","reg_key":"28s7","dns_prio":0 }
[2024/8/7 9:25:50 738] [08-07 19:38:07 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:25:50 752] [08-07 19:38:07 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:25:50 752] [08-07 19:38:07 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:25:50 768] [08-07 19:38:07 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:176
[2024/8/7 9:25:50 768] [08-07 19:38:07 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 176
[2024/8/7 9:25:50 768] [08-07 19:38:07 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:25:50 784] [08-07 19:38:07 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:25:50 784] [08-07 19:38:07 TUYA D][simplekv.c:203] update crc 651841698
[2024/8/7 9:25:50 800] [08-07 19:38:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:50 800] [08-07 19:38:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:50 800] [08-07 19:38:07 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:25:50 816] __IPC_APP_Get_Net_Status_cb line(188) -------------------------- stat(1)==STAT_UNPROVISION 
[2024/8/7 9:25:50 816] [08-07 19:38:07 TUYA D][wifi_netcfg_frame_transporter.c:472] ----destroy Transporter,session:0xae06f0
[2024/8/7 9:25:50 832] [08-07 19:38:07 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:25:50 832] [08-07 19:38:07 TUYA N][bt_dp.c:228] bt rpt conn stat:9
[2024/8/7 9:25:50 832] [08-07 19:38:07 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:50 848] [08-07 19:38:07 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:25:50 848] bt_ack_uncrypt 2
[2024/8/7 9:25:50 848] 00 09 
[2024/8/7 9:25:50 848] [08-07 19:38:07 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:50 864] [08-07 19:38:07 TUYA D][tuya_devos_entry.c:560] dev_nw_cfg_active_stage:6
[2024/8/7 9:25:50 864] __IPC_APP_Get_Net_Status_cb linerelease an RX reorder frame due to timeout sn 2b
[2024/8/7 9:25:50 864] (198) -------------------------- stat(3)==STAT_AP_STA_DISC 
[2024/8/7 9:25:50 880] [08-07 19:38:07 TUYA D][tuya_ble_api.c:1005] start to get mesh
[2024/8/7 9:25:50 880] [08-07 19:38:07 TUYA N][tuya_bt_sdk.c:171] ty bt upd localkey
[2024/8/7 9:25:50 896] [08-07 19:38:07 TUYA N][tuya_ble_api.c:425] upd login key len:6
[2024/8/7 9:25:50 897] [08-07 19:38:07 TUYA I][mqc_app.c:387] mqc app start ...
[2024/8/7 9:25:50 897] [08-07 19:38:07 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883
[2024/8/7 9:25:50 912] [08-07 19:38:07 TUYA D][mqc_app.c:473] TLS disable
[2024/8/7 9:25:50 912] [08-07 19:38:07 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:25:50 912] [08-07 19:38:07 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722993952}
[2024/8/7 9:25:50 928] [08-07 19:38:07 TUYA D][mqtt_client.c:321] subcribe_topic:smart/device/in/6c15d25ee258e171f90aba, client_id:6c15d25ee258e171f90aba, user_name:6c15d25ee258e171f90aba, passwd:8ccce8d31442fa9d
[2024/8/7 9:25:50 944] [08-07 19:38:07 TUYA D][mqtt_client.c:352] domain<0> m2.tuyacn.com:8883 HAVE PORT
[2024/8/7 9:25:50 944] [08-07 19:38:07 TUYA D][mqtt_client.c:355] PARSE m2.tuyacn.com:8883
[2024/8/7 9:25:50 960] [08-07 19:38:07 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.mesh.get&devId=6c15d25ee258e171f90aba&et=1&t=1722993952&v=1.0&sign=8dfb6aa774ecb7a3669269e900144e69
[2024/8/7 9:25:50 976] [08-07 19:38:07 TUYA D][mqtt_client.c:383] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT
[2024/8/7 9:25:50 976] [08-07 19:38:07 TUYA D][mqtt_client.c:386] PARSE m2.tuyacn.com:1883
[2024/8/7 9:25:50 992] [08-07 19:38:07 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:50 992] [08-07 19:38:07 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:51 008] [08-07 19:38:07 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6c15d25ee258e171f90aba
[2024/8/7 9:25:51 008] [08-07 19:38:07 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6c15d25ee258e171f90aba
[2024/8/7 9:25:51 024] [08-07 19:38:07 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:51 024] [08-07 19:38:07 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:51 040] [08-07 19:38:07 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:25600,priority:4
[2024/8/7 9:25:51 040] [08-07 19:38:07 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[2024/8/7 9:25:51 040] [08-07 19:38:07 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[2024/8/7 9:25:51 056] [08-07 19:38:07 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[2024/8/7 9:25:51 056] [08-07 19:38:07 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:25:51 056] [08-07 19:38:07 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:51 072] [08-07 19:38:07 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:51 072] [08-07 19:38:07 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:51 072] [08-07 19:38:07 TUYA D][tuya_svc_timer_task.c:146] no timer
[2024/8/7 9:25:51 088] [08-07 19:38:07 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[2024/8/7 9:25:51 088] [08-07 19:38:07 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[2024/8/7 9:25:51 088] [08-07 19:38:07 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[2024/8/7 9:25:51 104] [08-07 19:38:07 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6c15d25ee258e171f90aba
[2024/8/7 9:25:51 120] [08-07 19:38:07 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6c15d25ee258e171f90aba
[2024/8/7 9:25:51 120] [08-07 19:38:07 TUYA D][svc_online_log.c:317] svc online log active success
[2024/8/7 9:25:51 120] [08-07 09:25:52 TUYA D][tuya_ipc_sdk_init.c:137] sys stop timer: 14
[2024/8/7 9:25:51 136] [08-07 09:25:52 TUYA D][tuya_ipc_sdk_init.c:140] sys delete timer: 14
[2024/8/7 9:25:51 136] [08-07 09:25:52 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:25:51 136] tuya_hal_bt_send 20
[2024/8/7 9:25:51 152] 00 21 34 02 8a a0 ec 28 18 c9 89 bf a7 13 45 02 ce fa d1 0d 
[2024/8/7 9:25:51 152] [08-07 09:25:52 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:51 152] 0 21 34 2 8a a0 ec 28 18 c9 89 bf a7 13 45 2 ce fa d1 d 
[2024/8/7 9:25:51 168] XmBleSendBuf 20: 00 21 34 02 8a a0 ec 28 18 c9 89 bf a7 13 45 02 ce fa d1 0d
[2024/8/7 9:25:51 168] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:51 168] ble_slave_gap_event->type=13
[2024/8/7 9:25:51 184] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:51 184] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:51 184] [08-07 09:25:52 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:51 200] [08-07 09:25:52 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[2024/8/7 9:25:51 200] [08-07 09:25:52 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:25:51 216] [08-07 09:25:52 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:25:51 216] [08-07 09:25:52 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:25:51 216] [08-07 09:25:52 TUYA D][tuya_ipc_p2p_common.c:530] p2p passwd change to adb2cd20
[2024/8/7 9:25:51 232] [08-07 09:25:52 TUYA D][iot_httpc.c:1161] Post Data: {"password":"adb2cd20","t":1722993952}
[2024/8/7 9:25:51 248] [08-07 09:25:52 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.password.update&devId=6c15d25ee258e171f90aba&et=1&t=1722993952&v=1.0&sign=94d2b21b7db46d772f46a368bc0dc1fe
[2024/8/7 9:25:51 264] [08-07 09:25:52 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:51 264] [08-07 09:25:52 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:51 280] [08-07 09:25:52 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:51 280] [08-07 09:25:52 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:51 280] set basic_indicator_onoff:0 
[2024/8/7 9:25:51 296] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:51 296] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:51 312] [08-07 09:25:52 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:51 312] [08-07 09:25:52 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:51 328] [08-07 09:25:52 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:51 328] [08-07 09:25:52 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:51 344] [08-07 09:25:52 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:51 345] [08-07 09:25:52 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:51 345] [08-07 09:25:52 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:51 360] [08-07 09:25:52 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:51 361] [08-07 09:25:52 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:51 377] [08-07 09:25:52 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:51 377] [08-07 09:25:52 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:51 392] [08-07 09:25:52 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:51 392] [08-07 09:25:52 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:51 408] [08-07 09:25:52 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:51 408] g_AudioTipsList.size() enable: 0[08-07 09:25:52 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:25:51 408] tuya_hal_bt_send 17
[2024/8/7 9:25:51 424] 01 9d 73 55 b4 0b 30 9e ab 93 b9 51 23 fa 41 0f 1d 
[2024/8/7 9:25:51 424] [08-07 09:25:52 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:51 425] 1 9d 73 55 b4 b 30 9e ab 93 b9 51 23 fa 41 f 1d 
[2024/8/7 9:25:51 440] XmBleSendBuf 17: 01 9d 73 55 b4 0b 30 9e ab 93 b9 51 23 fa 41 0f 1d
[2024/8/7 9:25:51 440] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:51 440] ble_slave_gap_event->type=13
[2024/8/7 9:25:51 457] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:51 457] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:51 457] [08-07 09:25:52 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:51 457] DEBUG: ***u16num***[512]
[2024/8/7 9:25:51 472] [08-07 09:25:52 TUYA D][smart_frame.c:3490] rept chan:4
[2024/8/7 9:25:51 472] [08-07 09:25:52 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:51 488] [08-07 09:25:52 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:51 488] [08-07 09:25:52 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:51 488] __dp_data_report_data 4
[2024/8/7 9:25:51 488] 9f 01 01 00 
[2024/8/7 9:25:51 504] [08-07 09:25:52 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:51 504] [08-07 09:25:52 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:25:51 504] bt_ack_uncrypt 4
[2024/8/7 9:25:51 504] 9f 01 01 00 
[2024/8/7 9:25:51 520] [08-07 09:25:52 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:51 520] [1970-01-01 00:01:05] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:51 536] [08-07 09:25:52 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:51 552] [08-07 09:25:52 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:51 552] [08-07 09:25:52 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:51 568] [08-07 09:25:52 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:51 568] set basic_indicator_onoff:1 
[2024/8/7 9:25:51 584] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:51 584] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:51 600] [08-07 09:25:52 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:25:51 600] [08-07 09:25:52 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[2024/8/7 9:25:51 616] [08-07 09:25:52 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[2024/8/7 9:25:51 616] [08-07 09:25:52 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:25:51 616] dev id key: 16
[2024/8/7 9:25:51 616] 33 55 bf 9a 75 03 1d 24 dd 04 89 c8 15 91 18 9d 
[2024/8/7 9:25:51 632] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:25:51 632] [08-07 09:25:52 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:25:51 648] 2 1 6 3 2 1 a2 14 16 1 a2 0 94 1 5f fe ea d1 68 52 4a f5 d da e2 7 17 a8 
[2024/8/7 9:25:51 648] [08-07 09:25:52 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:25:51 648] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 69 8d 6 1c fa a6 49 13 4a a4 5b 91 ea 91 47 
[2024/8/7 9:25:51 664] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:25:51 664] [08-07 09:25:52 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:25:51 680] [08-07 09:25:52 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:25:51 680] [08-07 09:25:52 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:25:51 680] tuya_hal_bt_send 20
[2024/8/7 9:25:51 696] 00 31 35 05 4d 98 c5 a0 07 84 2f 9d a4 56 66 7e e9 a4 31 04 
[2024/8/7 9:25:51 696] [08-07 09:25:52 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:51 696] 0 31 35 5 4d 98 c5 a0 7 84 2f 9d a4 56 66 7e e9 a4 31 4 
[2024/8/7 9:25:51 712] XmBleSendBuf 20: 00 31 35 05 4d 98 c5 a0 07 84 2f 9d a4 56 66 7e e9 a4 31 04
[2024/8/7 9:25:51 712] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:51 712] ble_slave_gap_event->type=13
[2024/8/7 9:25:51 728] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:51 728] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:51 728] [08-07 09:25:52 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:51 744] [08-07 09:25:52 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"appKey":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","networkKey":"D59774254FA876FF1D204D16DF5223A5"},"t":1722993952,"success":true}
[2024/8/7 9:25:51 760] [08-07 09:25:52 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:51 760] [08-07 09:25:52 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:51 776] [08-07 09:25:52 TUYA D][tuya_ble_api.c:1014] start to write flash, app_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66", network_key:"D59774254FA876FF1D204D16DF5223A5"
[2024/8/7 9:25:51 776] [08-07 09:25:52 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:51 792] [08-07 09:25:52 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:51 792] [08-07 09:25:52 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:51 792] [08-07 09:25:52 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:51 808] [08-07 09:25:52 TUYA D][simplekv.c:374] write key:ble_app_key And Value Len:48
[2024/8/7 9:25:51 808] [08-07 09:25:52 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 48
[2024/8/7 9:25:51 824] [08-07 09:25:52 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:25:51 824] [08-07 09:25:52 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:25:51 824] [08-07 09:25:52 TUYA D][simplekv.c:203] update crc 572249355
[2024/8/7 9:25:51 840] [08-07 09:25:52 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:51 840] [08-07 09:25:52 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:51 856] [08-07 09:25:52 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:51 856] [08-07 09:25:52 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:51 856] [08-07 09:25:52 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:51 872] [08-07 09:25:52 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:51 872] [08-07 09:25:52 TUYA D][simplekv.c:374] write key:ble_network_key And Value Len:48
[2024/8/7 9:25:51 889] [08-07 09:25:52 TUYA D][simplekv.c:457] new space 13 startpos:36960 size:116
[2024/8/7 9:25:51 889] [08-07 09:25:52 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:51 889] [08-07 09:25:52 TUYA D][simplekv.c:203] update crc 2184514989
[2024/8/7 9:25:51 905] [08-07 09:25:52 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722993952,"success":true}
[2024/8/7 9:25:51 905] [08-07 09:25:52 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:25:51 905] tuya_hal_bt_send 20
[2024/8/7 9:25:51 921] 01 db 19 ce 66 8c de c7 26 24 55 16 06 5e 19 c1 d7 8a f7 dc 
[2024/8/7 9:25:51 921] [08-07 09:25:52 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:51 936] 1 db 19 ce 66 8c de c7 26 24 55 16 6 5e 19 c1 d7 8a f7 dc 
[2024/8/7 9:25:51 939] XmBleSendBuf 20: 01 db 19 ce 66 8c de c7 26 24 55 16 06 5e 19 c1 d7 8a f7 dc
[2024/8/7 9:25:51 939] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:51 952] [08-07 09:25:52 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:51 952] [08-07 09:25:52 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:51 953] [08-07 09:25:52 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722993952}
[2024/8/7 9:25:51 969] [08-07 09:25:52 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.beacon.key.fetch&devId=6c15d25ee258e171f90aba&et=1&t=1722993952&v=1.0&sign=9035761d4353318e9a797d542d228e99
[2024/8/7 9:25:51 985] [08-07 09:25:52 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:51 985] [08-07 09:25:52 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:52 001] [08-07 09:25:52 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:52 001] [08-07 09:25:52 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:52 016] [08-07 09:25:52 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:52 016] ble_slave_gap_event->type=13
[2024/8/7 9:25:52 016] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:52 016] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:52 032] [08-07 09:25:52 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:52 032] [08-07 09:25:52 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:52 048] [08-07 09:25:52 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:25:52 048] [08-07 09:25:52 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:25:52 048] [08-07 09:25:52 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:25:52 065] [08-07 09:25:52 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:25:52 065] [08-07 09:25:52 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:25:52 065] [08-07 09:25:52 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:25:52 080] [08-07 09:25:52 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:25:52 080] [08-07 09:25:52 TUYA D][simplekv.c:203] update crc 1802825338
[2024/8/7 9:25:52 080] DEBUG: ***u16num***[512]
[2024/8/7 9:25:52 096] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:52 096] Len=20 step 0
[2024/8/7 9:25:52 096] att=0x0 0x21 0x20 0x2 0xc4 0x90 0x2a 0x6 0x91 0xb8 0xcb 0x5a 0xea 0xbc 0x33 0x8f 0x66 0x26 0x3d 0x19 
[2024/8/7 9:25:52 096]  RCVS len:20
[2024/8/7 9:25:52 112] XmBleReadBuf 20:
[2024/8/7 9:25:52 112] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:52 112] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:52 112] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:52 128] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:25:52 128] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:25:52 144] [08-07 09:25:52 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:25:52 144] [08-07 09:25:52 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:52 160] [08-07 09:25:52 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:52 160] bt_rev_raw 20
[2024/8/7 9:25:52 160] 00 21 20 02 c4 90 2a 06 91 b8 cb 5a ea bc 33 8f 66 26 3d 19 
[2024/8/7 9:25:52 176] [08-07 09:25:52 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:25:52 176] [08-07 09:25:52 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:25:52 176] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:25:52 192] [08-07 09:25:52 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:52 192] [08-07 09:25:52 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:52 208] [08-07 09:25:52 TUYA D][tuya_devos_utils.c:341] set gw ext_stat:2
[2024/8/7 9:25:52 208] [08-07 09:25:52 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 0
[2024/8/7 9:25:52 224] [08-07 09:25:52 TUYA D][uni_network.c:181] use dynamic dns ip 121.5.96.167 for domain m2.tuyacn.com
[2024/8/7 9:25:52 224] [08-07 09:25:52 TUYA D][mqtt_client.c:1472] select mqtt host:m2.tuyacn.com
[2024/8/7 9:25:52 224] [08-07 09:25:52 TUYA N][mqtt_client.c:1493] mqtt get serve ip success
[2024/8/7 9:25:52 240] [08-07 09:25:52 TUYA D][mqtt_client.c:989] serverIP 2030395559 port:8883
[2024/8/7 9:25:52 240] set basic_indicator_onoff:0 
[2024/8/7 9:25:52 256] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 256] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:52 273] [08-07 09:25:52 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:52 273] [08-07 09:25:52 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:52 288] [08-07 09:25:52 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:52 288] [08-07 09:25:52 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:52 288] [08-07 09:25:52 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:52 304] [08-07 09:25:52 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:52 304] [08-07 09:25:52 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:52 320] [1970-01-01 00:01:05] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:52 320] [08-07 09:25:52 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:25:52 320] tuya_hal_bt_send 14
[2024/8/7 9:25:52 336] 02 bf 01 e7 01 75 a8 a5 ba 8a 07 85 aa fd 
[2024/8/7 9:25:52 336] [08-07 09:25:52 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:52 336] 2 bf 1 e7 1 75 a8 a5 ba 8a 7 85 aa fd 
[2024/8/7 9:25:52 352] XmBleSendBuf 14: 02 bf 01 e7 01 75 a8 a5 ba 8a 07 85 aa fd
[2024/8/7 9:25:52 352] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:25:52 352] ble_slave_gap_event->type=13
[2024/8/7 9:25:52 352] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:25:52 368] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:25:52 368] [08-07 09:25:52 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:52 384] [08-07 09:25:52 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:52 384] [08-07 09:25:52 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:52 400] [08-07 09:25:52 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:25:52 400] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:25:52 400] Len=17 step 0
[2024/8/7 9:25:52 416] att=0x1 0x5a 0xe0 0xf3 0x77 0x25 0x5e 0x81 0xf 0x4 0xe7 0x20 0x7d 0x98 0xc7 0x0 0xfe 
[2024/8/7 9:25:52 416]  RCVS len:17
[2024/8/7 9:25:52 416] [1970-01-01 00:01:05] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:52 416] XmBleReadBuf 17:
[2024/8/7 9:25:52 432] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:25:52 432] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:25:52 432] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:25:52 448] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:25:52 448] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:25:52 464] [08-07 09:25:52 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:25:52 464] [08-07 09:25:52 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:25:52 464] [08-07 09:25:52 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:25:52 464] bt_rev_raw 17
[2024/8/7 9:25:52 480] 01 5a e0 f3 77 25 5e 81 0f 04 e7 20 7d 98 c7 00 fe 
[2024/8/7 9:25:52 480] [08-07 09:25:52 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:25:52 481] ble rev data 33
[2024/8/7 9:25:52 496] 02 c4 90 2a 06 91 b8 cb 5a ea bc 33 8f 66 26 3d 19 5a e0 f3 77 25 5e 81 0f 04 e7 20 7d 98 c7 00 fe 
[2024/8/7 9:25:52 496] ble decryped data 16
[2024/8/7 9:25:52 496] 00 00 00 05 00 00 00 00 00 22 00 01 00 13 18 00 
[2024/8/7 9:25:52 512] [08-07 09:25:52 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:52 512] [08-07 09:25:52 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:25:52 528] [08-07 09:25:52 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:25:52 528] DEBUG: ***u16num***[512]
[2024/8/7 9:25:52 544] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:25:52 544] set basic_indicator_onoff:1 
[2024/8/7 9:25:52 544] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 560] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:52 560] [1970-01-01 00:01:05] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:52 560] set basic_indicator_onoff:0 
[2024/8/7 9:25:52 576] [1970-01-01 00:01:05] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 592] [1970-01-01 00:01:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:52 592] set basic_indicator_onoff:1 
[2024/8/7 9:25:52 592] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 608] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:52 608] [1970-01-01 00:01:06] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:25:52 624] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:25:52 624] set basic_indicator_onoff:0 
[2024/8/7 9:25:52 640] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 640] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:52 656] [08-07 09:25:52 TUYA D][iot_httpc.c:601] Decode Rev:{"result":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","t":1722993953,"success":true}
[2024/8/7 9:25:52 656] [08-07 09:25:53 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:52 672] [08-07 09:25:53 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:52 672] [08-07 09:25:53 TUYA D][tuya_ble_api.c:986] start to write flash, beacon_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66"
[2024/8/7 9:25:52 688] [08-07 09:25:53 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:25:52 688] [08-07 09:25:53 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:52 688] [08-07 09:25:53 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:52 704] [08-07 09:25:53 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:52 704] [08-07 09:25:53 TUYA D][simplekv.c:374] write key:ble_beaconkey And Value Len:48
[2024/8/7 9:25:52 720] [08-07 09:25:53 TUYA D][simplekv.c:457] new space 14 startpos:37076 size:116
[2024/8/7 9:25:52 720] [08-07 09:25:53 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:52 720] [08-07 09:25:53 TUYA D][simplekv.c:203] update crc 1995495045
[2024/8/7 9:25:52 736] [08-07 09:25:53 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:52 736] [08-07 09:25:53 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:52 736] set basic_indicator_onoff:1 
[2024/8/7 9:25:52 752] [08-07 09:25:53 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:25:52 752] [08-07 09:25:53 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:25:52 752] DEBUG: ***u16num***[512]
[2024/8/7 9:25:52 768] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 768] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:52 784] set basic_indicator_onoff:0 
[2024/8/7 9:25:52 784] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 800] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:52 800] set basic_indicator_onoff:1 
[2024/8/7 9:25:52 800] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 816] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:52 816] set basic_indicator_onoff:0 
[2024/8/7 9:25:52 832] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 832] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:52 848] [08-07 09:25:53 TUYA D][mqtt_client.c:1014] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883
[2024/8/7 9:25:52 848] [08-07 09:25:53 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:52 864] [08-07 09:25:53 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyacn.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:52 864] [08-07 09:25:53 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:52 880] [08-07 09:25:53 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:52 880] [08-07 09:25:53 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:52 880] [08-07 09:25:53 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:52 896] DEBUG: ***u16num***[512]
[2024/8/7 9:25:52 896] set basic_indicator_onoff:1 
[2024/8/7 9:25:52 912] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 912] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:52 912] set basic_indicator_onoff:0 
[2024/8/7 9:25:52 928] [1970-01-01 00:01:06] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 928] [1970-01-01 00:01:06] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:52 944] set basic_indicator_onoff:1 
[2024/8/7 9:25:52 944] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:52 960] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:52 960] [1970-01-01 00:01:07] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time36959
[2024/8/7 9:25:52 976] [08-07 09:25:53 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:52 992] [08-07 09:25:53 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyacn.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:52 993] [08-07 09:25:53 TUYA N][mqtt_client.c:1531] mqtt create success, begin to connect
[2024/8/7 9:25:52 993] [08-07 09:25:53 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:25:53 008] [08-07 09:25:53 TUYA D][mqtt_client.c:1413] cnt 1
[2024/8/7 9:25:53 008] set basic_indicator_onoff:0 
[2024/8/7 9:25:53 008] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:53 024] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:25:53 024] [08-07 09:25:53 TUYA D][mqtt_client.c:1104] mqtt subscribe success
[2024/8/7 9:25:53 024] [08-07 09:25:53 TUYA D][mqc_app.c:732] mqtt connect success
[2024/8/7 9:25:53 040] [08-07 09:25:53 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[2024/8/7 9:25:53 041] [08-07 09:25:53 TUYA D][mqtt_client.c:1994] subscribe new topic /av/d/6c15d25ee258e171f90aba ret:1 
[2024/8/7 9:25:53 057] [08-07 09:25:53 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[2024/8/7 9:25:53 057] __IPC_APP_Get_Net_Status_cb line(243) -------------------------- stat(11)==STAT_MQTT_ONLINE 
[2024/8/7 9:25:53 057] curr event:11 
[2024/8/7 9:25:53 072] IPC_APP_Notify_LED_Sound_Status_CB line(550) -------------------------- IPC_MQTT_ONLINE(11)
[2024/8/7 9:25:53 088] [1970-01-01 00:01:07] tuya_ipc_system_control_demo.c(551) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(DEVICE_ONLINE, 0, 0, 0, 1))
[2024/8/7 9:25:53 088] Disable Qrcode
[2024/8/7 9:25:53 104] [1970-01-01 00:01:07] tuya_ipc_system_control_demo.c(558) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONFIG_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:25:53 104] mqtt subscribe ack 5
[2024/8/7 9:25:53 104] 90 03 00 02 00 
[2024/8/7 9:25:53 104] DEBUG: ***u16num***[512]
[2024/8/7 9:25:53 120] [1970-01-01 00:01:07] xm_musicPlayer.cpp(91) <PlayAudioTips>: Open audio file /usr/share/audios/_english.pcm failed, No such file or directory
[2024/8/7 9:25:53 136] [1970-01-01 00:01:07] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/AddSuccess_english.pcm]
[2024/8/7 9:25:53 136] [1970-01-01 00:01:07] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:25:53 152] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:25:53 152] set basic_indicator_onoff:1 
[2024/8/7 9:25:53 168] [1970-01-01 00:01:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:25:53 168] [1970-01-01 00:01:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:25:53 184] [08-07 09:25:54 TUYA D][MainApp.c:537] tuya_ipc_sdk_mqtt_online_proc is start run
[2024/8/7 9:25:53 184] [08-07 09:25:54 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722993954 28800
[2024/8/7 9:25:53 200] [08-07 09:25:54 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722993954 28800
[2024/8/7 9:25:53 200] Init tuya_ipc_ss_init
[2024/8/7 9:25:53 216] [08-07 09:25:54 TUYA D][tuya_ipc_stream_storage.c:2015] Init stream_storage.base_path:/mnt/mmc v:4 a:101, max event per day 289 skills 1
[2024/8/7 9:25:53 217] [08-07 09:25:54 TUYA D][tuya_ipc_stream_storage.c:1571] SD task begin___
[2024/8/7 9:25:53 217] [08-07 09:25:54 TUYA D][tuya_ipc_stream_storage.c:2161] stream storage task init success
[2024/8/7 9:25:53 232] [08-07 09:25:54 TUYA D][MainApp.c:567] local storage init result is 0
[2024/8/7 9:25:53 232] [08-07 09:25:54 TUYA D][tuya_ipc_stream_storage.c:1585] report sd status 0 -> 5
[2024/8/7 9:25:53 248] [08-07 09:25:54 TUYA E][tuya_ipc_stream_storage.c:1914] storage not inited
[2024/8/7 9:25:53 248] [08-07 09:25:54 TUYA D][app_agent.c:706] udp ip: 192.168.31.144
[2024/8/7 9:25:53 248] [08-07 09:25:54 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:25:53 264] [08-07 09:25:54 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:25:53 264] [08-07 09:25:54 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:25:53 264] [08-07 09:25:54 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:53 280] [08-07 09:25:54 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:53 280] [08-07 09:25:54 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:53 296] [08-07 09:25:54 TUYA E][svc_online_log_db.c:25] ret:-6
[2024/8/7 9:25:53 296] [08-07 09:25:54 TUYA D][svc_online_log.c:182] load env fail. maybe not exist.
[2024/8/7 9:25:53 312] [08-07 09:25:54 TUYA D][svc_online_log.c:187] update property:{"value":"{\"embed_sys_env\":\"arm-xm-linux\"}"}
[2024/8/7 9:25:53 312] [08-07 09:25:54 TUYA D][iot_httpc.c:1161] Post Data: {"value":"{\"embed_sys_env\":\"arm-xm-linux\"}","t":1722993954}
[2024/8/7 9:25:53 328] [08-07 09:25:54 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.property.save&devId=6c15d25ee258e171f90aba&et=1&t=1722993954&v=1.0&sign=c6617fe54b54089e49293ccddbc5a4f6
[2024/8/7 9:25:53 344] [08-07 09:25:54 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:53 344] [08-07 09:25:54 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:53 360] [08-07 09:25:54 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:53 360] [08-07 09:25:54 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:53 360] DEBUG: ***u16num***[512]
[2024/8/7 9:25:53 376] [08-07 09:25:54 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:53 376] [08-07 09:25:54 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:53 392] [08-07 09:25:54 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:53 392] [08-07 09:25:54 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:53 408] [08-07 09:25:54 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:53 408] [08-07 09:25:54 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:53 424] [08-07 09:25:54 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:53 424] [08-07 09:25:54 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:53 440] [08-07 09:25:54 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:53 440] [08-07 09:25:54 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722993955,"success":true}
[2024/8/7 9:25:53 456] [08-07 09:25:55 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:53 456] [08-07 09:25:55 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:53 472] [08-07 09:25:55 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:25:53 472] [08-07 09:25:55 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:53 472] [08-07 09:25:55 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:53 488] [08-07 09:25:55 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:53 488] [08-07 09:25:55 TUYA D][simplekv.c:374] write key:em_sys_env And Value Len:32
[2024/8/7 9:25:53 488] [08-07 09:25:55 TUYA D][simplekv.c:457] new space 15 startpos:37192 size:100
[2024/8/7 9:25:53 504] [08-07 09:25:55 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:53 504] [08-07 09:25:55 TUYA D][simplekv.c:203] update crc 3130881308
[2024/8/7 9:25:53 520] [08-07 09:25:55 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:53 520] [08-07 09:25:55 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:53 520] DEBUG: ***u16num***[512]
[2024/8/7 9:25:53 536] [1970-01-01 00:01:07] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:25:53 536] [1970-01-01 00:01:07] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:25:53 552] [1970-01-01 00:01:07] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:25:53 552] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=17.000 ms
[2024/8/7 9:25:53 568] [1970-01-01 00:01:08] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:25:53 568] [1970-01-01 00:01:08] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:25:53 584] [08-07 09:25:55 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:35 ip:0xc0a81ff2
[2024/8/7 9:25:53 584] [08-07 09:25:55 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 3
[2024/8/7 9:25:53 600] [08-07 09:25:55 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:25:53 664] [08-07 09:25:55 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:25:53 664] [08-07 09:25:55 TUYA D][app_agent.c:600] send length:64, id:35, sequence_out:5183
[2024/8/7 9:25:53 664] DEBUG: ***u16num***[512]
[2024/8/7 9:25:53 680] [08-07 09:25:55 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[2024/8/7 9:25:53 680] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:25:53 696] [08-07 09:25:55 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
[2024/8/7 9:25:53 696] [08-07 09:25:55 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:2  -->>
[2024/8/7 9:25:53 712] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:25:53 712] [08-07 09:25:55 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:2  <<--
[2024/8/7 9:25:53 728] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:25:53 728] [08-07 09:25:55 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:25:53 744] [08-07 09:25:55 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 5
[2024/8/7 9:25:53 744] [08-07 09:25:55 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:25:53 744] [08-07 09:25:55 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:25:53 760] [08-07 09:25:55 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:25:53 760] [08-07 09:25:55 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 16
[2024/8/7 9:25:53 776] [08-07 09:25:55 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:25:53 776] [08-07 09:25:55 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:25:53 776] [08-07 09:25:55 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:0,dpnum:41.
[2024/8/7 9:25:53 792] DEBUG: ***u16num***[512]
[2024/8/7 9:25:53 792] [08-07 09:25:55 TUYA D][smart_frame.c:2547] final pack:{"dps":{"159":false}}
[2024/8/7 9:25:53 792] [08-07 09:25:55 TUYA D][app_agent.c:1240] Send Query To App:{"dps":{"159":false}}
[2024/8/7 9:25:53 808] [08-07 09:25:55 TUYA D][app_agent.c:600] send length:32, id:35, sequence_out:5184
[2024/8/7 9:25:53 808] [08-07 09:25:55 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722993955}
[2024/8/7 9:25:53 824] [08-07 09:25:55 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.uuid.pskkey.get&et=1&t=1722993955&uuid=uuidcaab27b0a838d239&v=1.0&sign=871156d8e22def06553fffef9f8f9651
[2024/8/7 9:25:53 840] [08-07 09:25:55 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:53 840] [08-07 09:25:55 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:53 856] [08-07 09:25:55 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:53 856] [08-07 09:25:55 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:53 871] [08-07 09:25:55 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:53 872] [08-07 09:25:55 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:53 888] [08-07 09:25:55 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:53 888] [08-07 09:25:55 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:53 904] [08-07 09:25:55 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:53 904] [08-07 09:25:55 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:53 904] [08-07 09:25:55 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:53 920] [08-07 09:25:55 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:53 936] [08-07 09:25:55 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:53 936] DEBUG: ***u16num***[512]
[2024/8/7 9:25:53 952] [08-07 09:25:55 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"pskKey":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80"},"t":1722993955,"success":true}
[2024/8/7 9:25:53 952] [08-07 09:25:55 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:53 968] [08-07 09:25:55 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:53 984] [08-07 09:25:55 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80","auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:25:54 000] [08-07 09:25:55 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:25:54 001] [08-07 09:25:55 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:25:54 001] [08-07 09:25:55 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:25:54 016] [08-07 09:25:55 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:256
[2024/8/7 9:25:54 016] [08-07 09:25:55 TUYA D][simplekv.c:397] 0 key same AND size old 276 >= new 256
[2024/8/7 9:25:54 016] [08-07 09:25:55 TUYA D][simplekv.c:430] find 0 available space
[2024/8/7 9:25:54 032] [08-07 09:25:55 TUYA D][simplekv.c:474] reuse available space 28700
[2024/8/7 9:25:54 032] [08-07 09:25:55 TUYA D][simplekv.c:203] update crc 1527413485
[2024/8/7 9:25:54 048] [08-07 09:25:55 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:54 048] [08-07 09:25:55 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:54 048] [08-07 09:25:55 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:25:54 048] DEBUG: ***u16num***[512]
[2024/8/7 9:25:54 064] DEBUG: ***u16num***[512]
[2024/8/7 9:25:54 064] [08-07 09:25:56 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c15d25ee258e171f90aba, dp_rept_chan:3
[2024/8/7 9:25:54 080] [08-07 09:25:56 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:25:54 080] [08-07 09:25:56 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:159.
[2024/8/7 9:25:54 096] [08-07 09:25:56 TUYA D][smart_frame.c:2547] final pack:{"159":false}
[2024/8/7 9:25:54 096] [08-07 09:25:56 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:25:54 112] [08-07 09:25:56 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25913 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:25:54 112] [08-07 09:25:56 TUYA D][smart_frame.c:2135] sync rslt:0
[2024/8/7 9:25:54 112] [08-07 09:25:56 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:25:54 128] DEBUG: ***u16num***[512]
[2024/8/7 9:25:54 128] [08-07 09:25:56 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:25:54 145] [08-07 09:25:56 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722993956, rept_cnt:1.
[2024/8/7 9:25:54 145] [08-07 09:25:56 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722993956, rept_cnt:0.
[2024/8/7 9:25:54 161] [08-07 09:25:56 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722993956, rept_cnt:0.
[2024/8/7 9:25:54 161] DEBUG: ***u16num***[512]
[2024/8/7 9:25:54 256] [08-07 09:25:56 TUYA D][tuya_ble_api.c:1417] cloud connected, stop adv!
[2024/8/7 9:25:54 256] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(640): stop_adv ---
[2024/8/7 9:25:54 256] exit_ble_thread create suc
[2024/8/7 9:25:54 272] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(644): XmBleAdvStop ---
[2024/8/7 9:25:54 272] [08-07 09:25:56 TUYA D][tuya_ble_api.c:1376] nw stat change:1->2, rpt to app.
[2024/8/7 9:25:54 287] [08-07 09:25:56 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:2
[2024/8/7 9:25:54 287] [08-07 09:25:56 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:54 287] [08-07 09:25:56 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:25:54 303] bt_ack_uncrypt 1
[2024/8/7 9:25:54 303] 02 
[2024/8/7 9:25:54 303] [08-07 09:25:56 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:25:54 319] [08-07 09:25:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:25:54 320] tuya_hal_bt_send 20
[2024/8/7 9:25:54 320] 00 21 36 05 ea 30 79 b2 05 e0 ce d7 86 02 a7 ab 83 80 4a e0 
[2024/8/7 9:25:54 320] [08-07 09:25:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:54 336] 0 21 36 5 ea 30 79 b2 5 e0 ce d7 86 2 a7 ab 83 80 4a e0 
[2024/8/7 9:25:54 336] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:25:54 352] [08-07 09:25:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:54 352] set sd_record_on_off:1 
[2024/8/7 9:25:54 352] set sd_record_mode:0 
[2024/8/7 9:25:54 352] [08-07 09:25:56 TUYA E][tuya_ipc_stream_storage.c:1912] the ss mgr not inited, but msg buffered: set mode 1
[2024/8/7 9:25:54 368] ---[XmBleReadBuf][132]: already stop ble,could not call XmBleReadBuf
[2024/8/7 9:25:54 368] write RecordMode success  0 
[2024/8/7 9:25:54 368] [08-07 09:25:56 TUYA D][tuya_ipc_cloud_storage.c:2188] init cloud storage begin
[2024/8/7 9:25:54 384] [08-07 09:25:56 TUYA D][simplekv.c:1211] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:54 384] [08-07 09:25:56 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:54 400] [08-07 09:25:56 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:54 400] [08-07 09:25:56 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:54 416] [08-07 09:25:56 TUYA E][tuya_ipc_cloud_storage.c:365] iot_wd_common_read fails md5_encrypt_key -6
[2024/8/7 9:25:54 416] [08-07 09:25:56 TUYA E][tuya_ipc_cloud_storage.c:450] read key_key file failed.
[2024/8/7 9:25:54 432] [08-07 09:25:56 TUYA D][tuya_ipc_cloud_storage.c:2240] __check_md5_encrypt_key fail, need update from server
[2024/8/7 9:25:54 432] [08-07 09:25:56 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:25:54 432] [08-07 09:25:56 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:54 448] [08-07 09:25:56 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:54 448] [08-07 09:25:56 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:54 464] [08-07 09:25:56 TUYA E][tuya_ipc_cloud_storage.c:942] iot_wd_common_read fails storage_restriction -6
[2024/8/7 9:25:54 464] [08-07 09:25:56 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722993956}
[2024/8/7 9:25:54 480] [08-07 09:25:56 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.restriction.config.get&devId=6c15d25ee258e171f90aba&et=1&t=1722993956&v=1.0&sign=776d39de1706cedad5daa7597dcaf3ea
[2024/8/7 9:25:54 496] [08-07 09:25:56 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:54 496] [08-07 09:25:56 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:54 512] [08-07 09:25:56 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:54 512] [08-07 09:25:56 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:54 528] [08-07 09:25:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:25:54 528] tuya_hal_bt_send 17
[2024/8/7 9:25:54 528] 01 d1 39 33 81 33 86 26 5e 66 ad c3 c8 7b e6 da c6 
[2024/8/7 9:25:54 528] [08-07 09:25:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:25:54 544] 1 d1 39 33 81 33 86 26 5e 66 ad c3 c8 7b e6 da c6 
[2024/8/7 9:25:54 544] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:25:54 560] [08-07 09:25:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:25:54 560] DEBUG: ***u16num***[512]
[2024/8/7 9:25:54 560] --- tracepoint bt_ext_porting.c,ty_btext_thread(433): tuya_hal_thread_release ---
[2024/8/7 9:25:54 576] [08-07 09:25:56 TUYA E][bt_ext_porting.c:434] [TUYA-BTUART]ty_btext_thread deleted
[2024/8/7 9:25:54 576] [08-07 09:25:56 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:25:54 592] [08-07 09:25:56 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:54 592] [08-07 09:25:56 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:54 608] [08-07 09:25:56 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:54 608] [08-07 09:25:56 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:54 625] [08-07 09:25:56 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:54 625] [08-07 09:25:56 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:54 625] [08-07 09:25:56 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:54 640] [08-07 09:25:56 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:54 655] [08-07 09:25:56 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:54 671] [08-07 09:25:56 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"msg":{"audioDuration":15,"audioInterval":300,"videoDuration":6,"videoInterval":300},"storage":{"mtu":10}},"t":1722993957,"success":true}
[2024/8/7 9:25:54 672] [08-07 09:25:57 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:54 687] [08-07 09:25:57 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:54 688] [08-07 09:25:57 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:25:54 688] [08-07 09:25:57 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:54 703] [08-07 09:25:57 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:54 704] [08-07 09:25:57 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:54 720] [08-07 09:25:57 TUYA D][simplekv.c:374] write key:storage_restriction And Value Len:32
[2024/8/7 9:25:54 720] [08-07 09:25:57 TUYA D][simplekv.c:457] new space 16 startpos:37292 size:100
[2024/8/7 9:25:54 736] [08-07 09:25:57 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:54 736] [08-07 09:25:57 TUYA D][simplekv.c:203] update crc 1897441337
[2024/8/7 9:25:54 736] [08-07 09:25:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:54 752] [08-07 09:25:57 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:54 752] [08-07 09:25:57 TUYA D][tuya_ipc_cloud_storage.c:920] slice_duration write success
[2024/8/7 9:25:54 768] [08-07 09:25:57 TUYA D][tuya_ipc_cloud_storage.c:999] case 2 get slice duration from cloud 10
[2024/8/7 9:25:54 768] [08-07 09:25:57 TUYA D][tuya_ipc_cloud_storage.c:1043] cloud storage seize 3059584 bytes memory for media data, each slice 10 seconds
[2024/8/7 9:25:54 784] [08-07 09:25:57 TUYA I][uni_thread.c:228] thread_create name:cloud_storage,stackDepth:65536,totalstackDepth:91136,priority:3
[2024/8/7 9:25:54 784] [08-07 09:25:57 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[2024/8/7 9:25:54 800] [08-07 09:25:57 TUYA D][tuya_ipc_cloud_storage.c:2289] init cloud storage success
[2024/8/7 9:25:54 800] [08-07 09:25:57 TUYA D][MainApp.c:590] cloud storage init result is 0
[2024/8/7 9:25:54 816] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:54 816] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:54 832] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:54 832] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:54 848] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"105":false}
[2024/8/7 9:25:54 848] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25914 Q:1 Data:{"dps":{"105":false}}
[2024/8/7 9:25:54 848] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:54 864] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:54 864] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:25:54 880] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:54 880] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"101":true}
[2024/8/7 9:25:54 896] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25915 Q:1 Data:{"dps":{"101":true}}
[2024/8/7 9:25:54 896] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:54 912] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:54 912] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:54 929] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:54 929] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"103":false}
[2024/8/7 9:25:54 944] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25916 Q:1 Data:{"dps":{"103":false}}
[2024/8/7 9:25:54 944] [08-07 09:25:57 TUYA D][uni_thread.c:250] Thread:cloud_storage Exec Start. Set to Running Stat
[2024/8/7 9:25:54 960] [08-07 09:25:57 TUYA D][iot_httpc.c:1161] Post Data: {"type":"MediaStor","t":1722993957}
[2024/8/7 9:25:54 976] [08-07 09:25:57 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c15d25ee258e171f90aba&et=1&t=1722993957&v=3.0&sign=597b3ce17c208200d00be3090f010591
[2024/8/7 9:25:54 976] [08-07 09:25:57 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:54 993] [08-07 09:25:57 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:54 993] [08-07 09:25:57 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:55 009] [08-07 09:25:57 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:55 009] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 024] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:55 025] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:25:55 025] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:55 039] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"104":true}
[2024/8/7 9:25:55 039] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25917 Q:1 Data:{"dps":{"104":true}}
[2024/8/7 9:25:55 055] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 056] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:107 not find
[2024/8/7 9:25:55 056] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:55 071] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:55 071] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 087] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:108 not find
[2024/8/7 9:25:55 088] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:55 088] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:55 104] IPC_APP_get_smart_mutile_light_mode line(546) ----------  
[2024/8/7 9:25:55 104] [08-07 09:25:57 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:25:55 104] [08-07 09:25:57 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:25:55 120] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"105":false}} pro:4 num:25914
[2024/8/7 9:25:55 136] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"105":false}}} offset:58
[2024/8/7 9:25:55 136] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"105":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:55 152] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5185
[2024/8/7 9:25:55 152] IPC_APP_set_smart_mutile_light_mode line(451) ---------- :0 ,g_SMLAbility=[0]
[2024/8/7 9:25:55 168] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"101":true}} pro:4 num:25915
[2024/8/7 9:25:55 168] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"101":true}}} offset:57
[2024/8/7 9:25:55 184] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"101":true}}, msg_len:20, out_len:72
[2024/8/7 9:25:55 184] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5186
[2024/8/7 9:25:55 200] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"103":false}} pro:4 num:25916
[2024/8/7 9:25:55 200] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"103":false}}} offset:58
[2024/8/7 9:25:55 216] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"103":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:55 248] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5187
[2024/8/7 9:25:55 248] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"104":true}} pro:4 num:25917
[2024/8/7 9:25:55 264] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"104":true}}} offset:57
[2024/8/7 9:25:55 280] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"104":true}}, msg_len:20, out_len:72
[2024/8/7 9:25:55 281] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5188
[2024/8/7 9:25:55 281] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:25:55 281] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:25:55 296] DEBUG: camera_set_dnc_mode_chn 0 
[2024/8/7 9:25:55 296] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:25:55 296] DEBUG: software pohtoR!
[2024/8/7 9:25:55 312] IPC_APP_set_smart_mutile_light_mode line(536) ---------- :mode=[0] 
[2024/8/7 9:25:55 312] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 328] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<124> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:55 328] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:55 328] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"124":"auto"}
[2024/8/7 9:25:55 344] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"124":"auto"}} pro:4 num:25918
[2024/8/7 9:25:55 360] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"124":"auto"}}} offset:59
[2024/8/7 9:25:55 360] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"124":"auto"}}, msg_len:22, out_len:74
[2024/8/7 9:25:55 376] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5189
[2024/8/7 9:25:55 376] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25918 Q:1 Data:{"dps":{"124":"auto"}}
[2024/8/7 9:25:55 393] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 393] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:55 408] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:25:55 408] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:55 408] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"134":true}
[2024/8/7 9:25:55 423] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"134":true}} pro:4 num:25919
[2024/8/7 9:25:55 443] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"134":true}}} offset:57
[2024/8/7 9:25:55 443] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"134":true}}, msg_len:20, out_len:72
[2024/8/7 9:25:55 455] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5190
[2024/8/7 9:25:55 455] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25919 Q:1 Data:{"dps":{"134":true}}
[2024/8/7 9:25:55 472] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 472] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:55 488] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:55 488] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"106":"1"}
[2024/8/7 9:25:55 504] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"106":"1"}} pro:4 num:25920
[2024/8/7 9:25:55 504] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"106":"1"}}} offset:56
[2024/8/7 9:25:55 520] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"106":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:25:55 520] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5191
[2024/8/7 9:25:55 536] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25920 Q:1 Data:{"dps":{"106":"1"}}
[2024/8/7 9:25:55 536] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 552] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:168 not find
[2024/8/7 9:25:55 553] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:55 553] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:55 568] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(855):  ---
[2024/8/7 9:25:55 568] [08-07 09:25:57 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:55 584] [08-07 09:25:57 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:55 584] [08-07 09:25:57 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:55 600] [08-07 09:25:57 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:55 600] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[2024/8/7 9:25:55 616] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:105, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:55 648] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:105, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:55 649] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:105, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:55 664] [08-07 09:25:57 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:55 664] [08-07 09:25:57 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:55 665] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(866):  ---
[2024/8/7 9:25:55 680] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(872):  ---
[2024/8/7 9:25:55 680] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(892):  ---
[2024/8/7 9:25:55 696] [IPC_APP_get_alarm_zone_draw][893] alarm zone[{\"num\":1,\"region0\":{\"x\":1,\"y\":1,\"xlen\":99,\"ylen\":99}}]
[2024/8/7 9:25:55 696] [08-07 09:25:57 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:55 712] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0
[2024/8/7 9:25:55 712] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:101, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:55 728] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:101, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:55 744] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:101, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:55 744] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0
[2024/8/7 9:25:55 760] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:103, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:55 760] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:103, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:55 776] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:103, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:55 776] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 792] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:169 not find
[2024/8/7 9:25:55 792] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:55 792] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:55 808] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0
[2024/8/7 9:25:55 823] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:104, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:55 824] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:104, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:55 840] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:104, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:55 840] curr sd_status:1 
[2024/8/7 9:25:55 840] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 856] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:55 856] [08-07 09:25:57 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:5
[2024/8/7 9:25:55 872] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:55 872] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"110":5}
[2024/8/7 9:25:55 888] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"110":5}} pro:4 num:25921
[2024/8/7 9:25:55 888] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"110":5}}} offset:54
[2024/8/7 9:25:55 904] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"110":5}}, msg_len:17, out_len:69
[2024/8/7 9:25:55 904] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5192
[2024/8/7 9:25:55 920] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25921 Q:1 Data:{"dps":{"110":5}}
[2024/8/7 9:25:55 920] handle_DP_SD_STORAGE_ONLY_GET line(654) --------------------- 
[2024/8/7 9:25:55 936] [1970-01-01 00:01:09] tuya_ipc_sd_demo.c(182) <tuya_ipc_sd_get_capacity>: XM_SDCardGetPartitionInfo failed
[2024/8/7 9:25:55 936] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:55 952] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:55 952] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:55 968] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0"}
[2024/8/7 9:25:55 968] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"109":"0|0|0"}} pro:4 num:25922
[2024/8/7 9:25:55 984] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"109":"0|0|0"}}} offset:60
[2024/8/7 9:25:55 984] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"109":"0|0|0"}}, msg_len:23, out_len:75
[2024/8/7 9:25:56 000] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5193
[2024/8/7 9:25:56 000] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25922 Q:1 Data:{"dps":{"109":"0|0|0"}}
[2024/8/7 9:25:56 016] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 016] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:56 032] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:25:56 032] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:56 048] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"150":true}
[2024/8/7 9:25:56 048] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"150":true}} pro:4 num:25923
[2024/8/7 9:25:56 064] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"150":true}}} offset:57
[2024/8/7 9:25:56 064] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"150":true}}, msg_len:20, out_len:72
[2024/8/7 9:25:56 080] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5194
[2024/8/7 9:25:56 080] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25923 Q:1 Data:{"dps":{"150":true}}
[2024/8/7 9:25:56 096] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 096] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:56 112] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:56 112] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"151":"1"}
[2024/8/7 9:25:56 128] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"151":"1"}} pro:4 num:25924
[2024/8/7 9:25:56 128] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"151":"1"}}} offset:56
[2024/8/7 9:25:56 144] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"151":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:25:56 144] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5195
[2024/8/7 9:25:56 160] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25924 Q:1 Data:{"dps":{"151":"1"}}
[2024/8/7 9:25:56 160] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 176] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:56 176] [08-07 09:25:57 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:0
[2024/8/7 9:25:56 192] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:56 192] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 9:25:56 208] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"117":0}} pro:4 num:25925
[2024/8/7 9:25:56 208] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"117":0}}} offset:54
[2024/8/7 9:25:56 224] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"117":0}}, msg_len:17, out_len:69
[2024/8/7 9:25:56 224] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5196
[2024/8/7 9:25:56 239] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25925 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 9:25:56 239] [08-07 09:25:57 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:56 255] [08-07 09:25:57 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:56 271] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"124":"auto"}}, mqtt async dp cb:0
[2024/8/7 9:25:56 272] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:124, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:56 287] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:124, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 303] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:124, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 304] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0
[2024/8/7 9:25:56 319] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:134, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:56 320] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:134, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 336] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:134, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 336] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"106":"1"}}, mqtt async dp cb:0
[2024/8/7 9:25:56 353] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:106, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:56 368] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:106, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 368] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:106, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 368] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 385] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<138> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:56 400] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:56 400] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:56 400] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"138":false}
[2024/8/7 9:25:56 416] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"138":false}} pro:4 num:25926
[2024/8/7 9:25:56 416] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0
[2024/8/7 9:25:56 432] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"138":false}}} offset:58
[2024/8/7 9:25:56 447] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"138":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:56 448] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5197
[2024/8/7 9:25:56 463] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25926 Q:1 Data:{"dps":{"138":false}}
[2024/8/7 9:25:56 464] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:110, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:56 479] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:110, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 480] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:110, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 496] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"109":"0|0|0"}}, mqtt async dp cb:0
[2024/8/7 9:25:56 511] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:109, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:56 511] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:109, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 528] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:109, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 528] current power mode:1
[2024/8/7 9:25:56 528] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 544] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:146 not find
[2024/8/7 9:25:56 544] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:56 544] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:56 560] current battery percent:80
[2024/8/7 9:25:56 560] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0
[2024/8/7 9:25:56 561] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 576] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:150, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:56 592] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:150, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 592] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:150, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 608] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:145 not find
[2024/8/7 9:25:56 608] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:56 608] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:56 624] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[2024/8/7 9:25:56 624] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:151, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:56 640] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:151, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 656] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:151, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 656] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[2024/8/7 9:25:56 672] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:117, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:56 672] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:117, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 689] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:117, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:56 689] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 705] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:56 705] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:56 720] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:56 720] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"170":false}
[2024/8/7 9:25:56 736] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"170":false}} pro:4 num:25927
[2024/8/7 9:25:56 736] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"170":false}}} offset:58
[2024/8/7 9:25:56 752] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"170":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:56 752] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5198
[2024/8/7 9:25:56 768] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25927 Q:1 Data:{"dps":{"170":false}}
[2024/8/7 9:25:56 768] src/intelligent_track_thread.c(1466) [XM_GetBodyTarckEnable]: 
[2024/8/7 9:25:56 784] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 784] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:56 800] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:56 800] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:56 816] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"161":false}
[2024/8/7 9:25:56 816] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"161":false}} pro:4 num:25928
[2024/8/7 9:25:56 832] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"161":false}}} offset:58
[2024/8/7 9:25:56 832] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"161":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:56 848] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5199
[2024/8/7 9:25:56 848] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25928 Q:1 Data:{"dps":{"161":false}}
[2024/8/7 9:25:56 864] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 864] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:186 not find
[2024/8/7 9:25:56 864] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:56 880] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:56 880] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 896] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<133> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:56 896] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:56 912] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3"}
[2024/8/7 9:25:56 912] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"133":"3"}} pro:4 num:25929
[2024/8/7 9:25:56 928] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"133":"3"}}} offset:56
[2024/8/7 9:25:56 928] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"133":"3"}}, msg_len:19, out_len:71
[2024/8/7 9:25:56 944] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5200
[2024/8/7 9:25:56 944] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25929 Q:1 Data:{"dps":{"133":"3"}}
[2024/8/7 9:25:56 960] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:56 960] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:56 975] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:56 975] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:56 991] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 9:25:56 992] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"139":false}} pro:4 num:25930
[2024/8/7 9:25:57 007] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"139":false}}} offset:58
[2024/8/7 9:25:57 008] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"139":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:57 023] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5201
[2024/8/7 9:25:57 024] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25930 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 9:25:57 039] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 70 enable 0 volume
[2024/8/7 9:25:57 040] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 056] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:57 056] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:57 072] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"140":"1"}
[2024/8/7 9:25:57 072] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"140":"1"}} pro:4 num:25931
[2024/8/7 9:25:57 087] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"140":"1"}}} offset:56
[2024/8/7 9:25:57 087] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"140":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:25:57 103] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5202
[2024/8/7 9:25:57 103] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25931 Q:1 Data:{"dps":{"140":"1"}}
[2024/8/7 9:25:57 119] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 119] [08-07 09:25:57 TUYA E][smart_frame.c:569] dparr[0] type not match:1 0
[2024/8/7 9:25:57 135] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3586
[2024/8/7 9:25:57 135] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 135] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:57 151] [08-07 09:25:57 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:50
[2024/8/7 9:25:57 151] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:57 167] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"160":50}
[2024/8/7 9:25:57 167] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"160":50}} pro:4 num:25932
[2024/8/7 9:25:57 184] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"160":50}}} offset:55
[2024/8/7 9:25:57 184] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"160":50}}, msg_len:18, out_len:70
[2024/8/7 9:25:57 199] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5203
[2024/8/7 9:25:57 199] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25932 Q:1 Data:{"dps":{"160":50}}
[2024/8/7 9:25:57 216] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 216] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:195 not find
[2024/8/7 9:25:57 232] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:57 232] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:57 232] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"138":false}}, mqtt async dp cb:0
[2024/8/7 9:25:57 247] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:138, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:57 263] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:138, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 263] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:138, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 279] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 279] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:194 not find
[2024/8/7 9:25:57 279] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:57 295] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:57 295] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 311] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:158 not find
[2024/8/7 9:25:57 312] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:57 312] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:57 327] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 327] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:57 343] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:57 345] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:57 359] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:25:57 361] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:25933
[2024/8/7 9:25:57 375] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 9:25:57 375] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:57 391] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"170":false}}, mqtt async dp cb:0
[2024/8/7 9:25:57 391] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5204
[2024/8/7 9:25:57 407] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25933 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:25:57 407] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:170, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:57 423] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:170, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 441] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:170, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 441] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"161":false}}, mqtt async dp cb:0
[2024/8/7 9:25:57 456] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:161, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:57 456] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:161, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 472] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:161, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 472] [1970-01-01 00:01:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:25:57 488] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 488] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:57 504] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:57 504] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:57 520] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"174":false}
[2024/8/7 9:25:57 520] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"174":false}} pro:4 num:25934
[2024/8/7 9:25:57 536] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"174":false}}} offset:58
[2024/8/7 9:25:57 536] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"174":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:57 552] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5205
[2024/8/7 9:25:57 552] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25934 Q:1 Data:{"dps":{"174":false}}
[2024/8/7 9:25:57 568] [1970-01-01 00:01:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:25:57 568] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 584] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:57 584] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:57 600] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"175":"0"}
[2024/8/7 9:25:57 600] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"175":"0"}} pro:4 num:25935
[2024/8/7 9:25:57 616] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"175":"0"}}} offset:56
[2024/8/7 9:25:57 616] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"175":"0"}}, msg_len:19, out_len:71
[2024/8/7 9:25:57 631] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5206
[2024/8/7 9:25:57 632] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25935 Q:1 Data:{"dps":{"175":"0"}}
[2024/8/7 9:25:57 648] [1970-01-01 00:01:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:25:57 648] cruiseTimeMode is 0.
[2024/8/7 9:25:57 648] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 664] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:57 664] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:57 680] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"176":"0"}
[2024/8/7 9:25:57 680] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"176":"0"}} pro:4 num:25936
[2024/8/7 9:25:57 696] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"176":"0"}}} offset:56
[2024/8/7 9:25:57 712] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"176":"0"}}, msg_len:19, out_len:71
[2024/8/7 9:25:57 712] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5207
[2024/8/7 9:25:57 728] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25936 Q:1 Data:{"dps":{"176":"0"}}
[2024/8/7 9:25:57 728] [1970-01-01 00:01:10] utils.c(322) <ReadTYJsonConfig>: Get antiFlicker object error!
[2024/8/7 9:25:57 728] anti Flicker mode is 0.
[2024/8/7 9:25:57 744] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 744] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:188 not find
[2024/8/7 9:25:57 744] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:57 759] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:57 760] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"133":"3"}}, mqtt async dp cb:0
[2024/8/7 9:25:57 775] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:133, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:57 776] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:133, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 792] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:133, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 808] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"139":false}}, mqtt async dp cb:0
[2024/8/7 9:25:57 808] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:139, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:57 824] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:139, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 824] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:139, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 840] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"140":"1"}}, mqtt async dp cb:0
[2024/8/7 9:25:57 840] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:140, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:57 856] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:140, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 872] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:140, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 872] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"160":50}}, mqtt async dp cb:0
[2024/8/7 9:25:57 888] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:160, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:57 888] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:160, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 904] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:160, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 904] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:25:57 920] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722993957, rept_cnt:2.
[2024/8/7 9:25:57 936] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 936] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:57 952] [1970-01-01 00:01:10] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:25:57 952] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 952] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:192 not find
[2024/8/7 9:25:57 968] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:57 968] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:57 984] [1970-01-01 00:01:10] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:25:57 984] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:57 984] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:193 not find
[2024/8/7 9:25:58 001] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:58 001] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:58 016] [1970-01-01 00:01:10] utils.c(322) <ReadTYJsonConfig>: Get FlightWarn object error!
[2024/8/7 9:25:58 016] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:58 016] [08-07 09:25:57 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:173 not find
[2024/8/7 9:25:58 032] [08-07 09:25:57 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:25:58 032] [08-07 09:25:57 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:25:58 048] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"174":false}}, mqtt async dp cb:0
[2024/8/7 9:25:58 048] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:174, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:58 064] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:174, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 064] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:174, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 080] [1970-01-01 00:01:10] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:25:58 080] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:58 096] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:58 096] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:58 112] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"175":"0"}}, mqtt async dp cb:0
[2024/8/7 9:25:58 112] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:58 128] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:175, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:58 128] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:175, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 144] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:175, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 161] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"120":false}
[2024/8/7 9:25:58 163] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25937 Q:1 Data:{"dps":{"120":false}}
[2024/8/7 9:25:58 163] [08-07 09:25:57 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:25:58 175] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"120":false}} pro:4 num:25937
[2024/8/7 9:25:58 191] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"120":false}}} offset:58
[2024/8/7 9:25:58 192] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"120":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:58 207] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5208
[2024/8/7 9:25:58 207] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"176":"0"}}, mqtt async dp cb:0
[2024/8/7 9:25:58 223] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:176, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:58 224] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:176, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 239] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:176, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 255] [08-07 09:25:57 TUYA D][smart_frame.c:419] dp<231> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:25:58 255] [08-07 09:25:57 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:25:58 256] [08-07 09:25:57 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:25:58 272] [08-07 09:25:57 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"231":false}
[2024/8/7 9:25:58 272] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"120":false}}, mqtt async dp cb:0
[2024/8/7 9:25:58 287] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:120, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:58 303] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:120, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 303] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:120, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 319] [08-07 09:25:57 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25938 Q:1 Data:{"dps":{"231":false}}
[2024/8/7 9:25:58 319] [08-07 09:25:57 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"231":false}} pro:4 num:25938
[2024/8/7 9:25:58 335] [08-07 09:25:57 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993957,"data":{"dps":{"231":false}}} offset:58
[2024/8/7 9:25:58 335] [08-07 09:25:57 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"231":false}}, msg_len:21, out_len:73
[2024/8/7 9:25:58 351] [08-07 09:25:57 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5209
[2024/8/7 9:25:58 367] [08-07 09:25:57 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}","t":1722993957}
[2024/8/7 9:25:58 383] [08-07 09:25:57 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c15d25ee258e171f90aba&et=1&t=1722993957&v=1.0&sign=0c9017dad63936ea6ffa54d426fe1d39
[2024/8/7 9:25:58 383] [08-07 09:25:57 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:58 400] [08-07 09:25:57 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:58 400] [08-07 09:25:57 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:58 416] [08-07 09:25:57 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:58 416] [08-07 09:25:57 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:58 432] [08-07 09:25:57 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:58 432] [08-07 09:25:57 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:58 448] [08-07 09:25:57 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:58 448] [08-07 09:25:57 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:58 448] [08-07 09:25:57 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:58 464] [08-07 09:25:57 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:58 464] [08-07 09:25:57 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"231":false}}, mqtt async dp cb:0
[2024/8/7 9:25:58 480] [08-07 09:25:57 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:231, curr_t:1722993957, rept_cnt:1.
[2024/8/7 9:25:58 496] [08-07 09:25:57 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:231, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 496] [08-07 09:25:57 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:231, curr_t:1722993957, rept_cnt:0.
[2024/8/7 9:25:58 512] [08-07 09:25:57 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1722993957,"success":true}
[2024/8/7 9:25:58 512] [08-07 09:25:57 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:58 528] [08-07 09:25:57 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:58 528] [08-07 09:25:57 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[2024/8/7 9:25:58 544] [08-07 09:25:57 TUYA D][tuya_ipc_cloud_storage.c:535] order expire or remote server error
[2024/8/7 9:25:58 544] [08-07 09:25:57 TUYA E][tuya_ipc_cloud_storage.c:1695] check cloud storage count failed, op_ret = -1
[2024/8/7 9:25:58 560] [08-07 09:25:57 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:58 576] [08-07 09:25:57 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:58 576] [08-07 09:25:57 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:25:58 576] [08-07 09:25:57 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:25:58 592] [08-07 09:25:57 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722993957,"success":true}
[2024/8/7 9:25:58 592] [08-07 09:25:57 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:58 608] [08-07 09:25:57 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:58 608] [08-07 09:25:57 TUYA D][tuya_ipc_skill.c:198] upload data: {\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}
[2024/8/7 9:25:58 624] [08-07 09:25:57 TUYA D][MainApp.c:597] tuya_ipc_sdk_mqtt_online_proc is end run
[2024/8/7 9:25:58 624] [1970-01-01 00:01:10] MainApp.c(599) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:25:58 640] tuya_ipc_p2p_demo.c(455)<TUYA_APP_Enable_P2PTransfer> Dbg: Init P2P With Max Users:5
[2024/8/7 9:25:58 640] [08-07 09:25:57 TUYA D][tuya_ipc_webrtc.c:1534] begin___
[2024/8/7 9:25:58 640] [08-07 09:25:57 TUYA D][tuya_ipc_webrtc.c:1541] --audio-:8000,format:101
[2024/8/7 9:25:58 656] [08-07 09:25:57 TUYA D][tuya_ipc_webrtc.c:1542] end___ audiocbk_hdl(0x18f5c)
[2024/8/7 9:25:58 656] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:5086] gw actived
[2024/8/7 9:25:58 672] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:5095] p2p max_client_num[5]
[2024/8/7 9:25:58 672] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:5096] p2p init media info:
[2024/8/7 9:25:58 672] [08-07 09:25:57 TUYA D][tuya_ipc_webrtc.c:1526] webrtc playback start_id 5
[2024/8/7 9:25:58 688] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:25:58 688] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4782] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:25:58 704] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:25:58 704] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4782] height[360] width[640] bitrate[1024]
[2024/8/7 9:25:58 720] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:25:58 720] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4794] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:25:58 736] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4794] height[360] width[640] bitrate[1024]
[2024/8/7 9:25:58 736] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:25:58 752] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:25:58 752] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:25:58 768] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:25:58 768] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:25:58 783] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:25:58 784] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:25:58 800] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:25:58 800] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:25:58 816] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:25:58 816] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4796] videoNum[2] audio codec[129] sample[0]
[2024/8/7 9:25:58 832] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4797] databits[1] channel[0]
[2024/8/7 9:25:58 832] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:5122] need speaker audio codec[129] sample[0] databits[1] channel[0] defLiveMode[0]
[2024/8/7 9:25:58 848] [08-07 09:25:57 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:25:58 848] [08-07 09:25:57 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:25:58 864] [08-07 09:25:57 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:25:58 864] [08-07 09:25:57 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = adb2cd20
[2024/8/7 9:25:58 864] [08-07 09:25:57 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[2024/8/7 9:25:58 879] [08-07 09:25:57 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:25:58 879] [08-07 09:25:57 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:25:58 896] [08-07 09:25:57 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:25:58 896] [08-07 09:25:57 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:25:58 896] [08-07 09:25:57 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:25:58 912] [08-07 09:25:57 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:25:58 912] [08-07 09:25:57 TUYA D][tuya_ipc_p2p_common.c:455] update p2p_auth_info from service, type 4
[2024/8/7 9:25:58 928] [08-07 09:25:57 TUYA D][iot_httpc.c:1161] Post Data: {"type":4,"t":1722993957}
[2024/8/7 9:25:58 944] [08-07 09:25:57 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.p2p.config.get&devId=6c15d25ee258e171f90aba&et=1&t=1722993957&v=2.0&sign=0b9c6bac89a2716dc6b9ea1276236b33
[2024/8/7 9:25:58 944] [08-07 09:25:57 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:58 960] [08-07 09:25:57 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:58 960] [08-07 09:25:57 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:58 976] [08-07 09:25:57 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:58 976] [08-07 09:25:57 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:58 992] [08-07 09:25:57 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:58 992] [08-07 09:25:57 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:59 008] [08-07 09:25:57 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:59 008] [08-07 09:25:57 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:59 008] [08-07 09:25:57 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:59 024] [08-07 09:25:57 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:59 040] [08-07 09:25:57 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:59 040] [08-07 09:25:57 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:59 056] [08-07 09:25:57 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"p2pId":"","type":4},"t":1722993957,"success":true}
[2024/8/7 9:25:59 056] [08-07 09:25:57 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:59 072] [08-07 09:25:57 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:59 072] [08-07 09:25:57 TUYA D][tuya_ipc_p2p_common.c:381] SY P2P AUTH:{"p2pId":"","type":4}
[2024/8/7 9:25:59 088] [08-07 09:25:57 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:25:59 088] [08-07 09:25:57 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:25:59 088] [08-07 09:25:57 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:25:59 104] [08-07 09:25:57 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:32
[2024/8/7 9:25:59 104] [08-07 09:25:57 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 32
[2024/8/7 9:25:59 120] [08-07 09:25:57 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:25:59 120] [08-07 09:25:57 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:25:59 120] [08-07 09:25:57 TUYA D][simplekv.c:203] update crc 2665406415
[2024/8/7 9:25:59 136] [08-07 09:25:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:59 136] [08-07 09:25:57 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:59 151] [08-07 09:25:57 TUYA D][tuya_ipc_p2p_common.c:458] get p2p auth info from service
[2024/8/7 9:25:59 152] [08-07 09:25:57 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:25:59 152] [08-07 09:25:57 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:25:59 168] [08-07 09:25:57 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:25:59 168] [08-07 09:25:57 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:25:59 184] [08-07 09:25:57 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:25:59 184] [08-07 09:25:57 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:25:59 184] [08-07 09:25:57 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:25:59 200] [08-07 09:25:57 TUYA D][simplekv.c:203] update crc 4287216188
[2024/8/7 9:25:59 200] [08-07 09:25:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:59 200] [08-07 09:25:57 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:59 216] [08-07 09:25:57 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:25:59 216] [08-07 09:25:57 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:25:59 232] [08-07 09:25:57 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:25:59 232] [08-07 09:25:57 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[2024/8/7 9:25:59 247] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:5178] p2p did[] apiLicense[] initString[]
[2024/8/7 9:25:59 248] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:5181] support p2p type = 4
[2024/8/7 9:25:59 248] P2P API Version: 244.3.4.107
[2024/8/7 9:25:59 248] [08-07 09:25:57 TUYA D][tuya_ipc_p2p.c:4974] no encrypt
[2024/8/7 9:25:59 263] 40449 (null) INFO:6241316: tuya p2p rtc sdk version: 0xf403046b, Nov 16 2023 10:52:20
[2024/8/7 9:25:59 264] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:25:59 264] tuya liteos uv
[2024/8/7 9:25:59 279] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:5039] _mqtt_p2p_listen_sessions create
[2024/8/7 9:25:59 279] [08-07 09:25:58 TUYA E][tuya_ipc_p2p.c:5190] p2p v3 init ok
[2024/8/7 9:25:59 295] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:4124] Begin to Listen mqtt p2p client connects In Thread
[2024/8/7 9:25:59 296] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 9:25:59 311] 40844 (null) [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:5230] speaker task create success
[2024/8/7 9:25:59 311] INFO:6241316: try listen
[2024/8/7 9:25:59 311] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:5273] __p2p_session_detech create
[2024/8/7 9:25:59 327] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:4652] Begin to session detech
[2024/8/7 9:25:59 327] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:5290] __p2p_video_send_proc create ok
[2024/8/7 9:25:59 327] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:3771] into p2p video send
[2024/8/7 9:25:59 344] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [0]
[2024/8/7 9:25:59 344] [08-07 09:25:58 TUYA D][tuya_ipc_upnp.c:437] tuya_ipc_upnp_init start
[2024/8/7 9:25:59 360] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:3553] New Thread To proc, init source
[2024/8/7 9:25:59 360] [08-07 09:25:58 TUYA D][tuya_ipc_p2p.c:3572] session cmd recv proc alive [0] num[0]
[2024/8/7 9:25:59 376] [08-07 09:25:58 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:156672,priority:2
[2024/8/7 9:25:59 376] [08-07 09:25:58 TUYA D][tuya_ipc_upnp.c:458] tuya_ipc_upnp_init success
[2024/8/7 9:25:59 392] [08-07 09:25:58 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[2024/8/7 9:25:59 392] [08-07 09:25:58 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1722993958}
[2024/8/7 9:25:59 408] [08-07 09:25:58 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6c15d25ee258e171f90aba&et=1&t=1722993958&v=1.0&sign=f5e57c2652053ed451515e17f3f2f46b
[2024/8/7 9:25:59 424] [08-07 09:25:58 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:59 424] [08-07 09:25:58 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:59 440] [08-07 09:25:58 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:59 440] [08-07 09:25:58 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:59 440] [08-07 09:25:58 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[2024/8/7 9:25:59 456] [08-07 09:25:58 TUYA D][tuya_ipc_packager.c:62] get packager instance
[2024/8/7 9:25:59 456] [08-07 09:25:58 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[2024/8/7 9:25:59 471] [08-07 09:25:58 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:59 471] [08-07 09:25:58 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:59 471] [08-07 09:25:58 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:59 487] [08-07 09:25:58 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:59 487] [08-07 09:25:58 TUYA E][tuya_ipc_encrypt.c:178] read local cloud encrypt key fails ..-6
[2024/8/7 9:25:59 503] [08-07 09:25:58 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722993958}
[2024/8/7 9:25:59 519] [08-07 09:25:58 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.storage.secret.get&devId=6c15d25ee258e171f90aba&et=1&t=1722993958&v=1.0&sign=306300f3d7a966fa7b18dd4f80f75d75
[2024/8/7 9:25:59 519] [08-07 09:25:58 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:25:59 535] [08-07 09:25:58 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:25:59 535] [08-07 09:25:58 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:25:59 551] [08-07 09:25:58 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:25:59 551] [08-07 09:25:58 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:59 552] [08-07 09:25:58 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:59 567] [08-07 09:25:58 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:59 583] [08-07 09:25:58 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:59 583] [08-07 09:25:58 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:59 583] [08-07 09:25:58 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:59 599] [08-07 09:25:58 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:59 599] [08-07 09:25:58 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:25:59 615] [08-07 09:25:58 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:25:59 615] [08-07 09:25:58 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:25:59 631] [08-07 09:25:58 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:25:59 631] [08-07 09:25:58 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:25:59 647] [08-07 09:25:58 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:25:59 648] [08-07 09:25:58 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:25:59 648] [08-07 09:25:58 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:25:59 663] [08-07 09:25:58 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:25:59 663] [08-07 09:25:58 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:59 679] [08-07 09:25:58 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:59 695] [08-07 09:25:58 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:25:59 696] [08-07 09:25:58 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:25:59 711] [08-07 09:25:58 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"encryptKey":"992e9749e8f3402a"},"t":1722993958,"success":true}
[2024/8/7 9:25:59 712] [08-07 09:25:58 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:25:59 727] [08-07 09:25:58 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:25:59 727] [08-07 09:25:58 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:25:59 743] [08-07 09:25:58 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:25:59 743] [08-07 09:25:58 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:25:59 743] [08-07 09:25:58 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:25:59 759] [08-07 09:25:58 TUYA D][simplekv.c:374] write key:cloud_enc_key And Value Len:32
[2024/8/7 9:25:59 759] [08-07 09:25:58 TUYA D][simplekv.c:457] new space 17 startpos:37392 size:100
[2024/8/7 9:25:59 775] [08-07 09:25:58 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:25:59 775] [08-07 09:25:58 TUYA D][simplekv.c:203] update crc 43388062
[2024/8/7 9:25:59 775] [08-07 09:25:58 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:25:59 791] [08-07 09:25:58 TUYA D][simplekv.c:520] write success
[2024/8/7 9:25:59 791] [1970-01-01 00:01:11] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time40960
[2024/8/7 9:25:59 807] [08-07 09:25:58 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:164864,priority:3
[2024/8/7 9:25:59 807] [08-07 09:25:58 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[2024/8/7 9:25:59 840] [08-07 09:25:58 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":90000,\"profileId\":\"\",\"width\":3840,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[2024/8/7 9:25:59 855] [1970-01-01 00:01:11] tuya_ipc_p2p_demo.c(475) <TUYA_APP_Enable_P2PTransfer>: tuya_ipc_tranfser_init ret=[0]
[2024/8/7 9:25:59 855] [1970-01-01 00:01:11] MainApp.c(606) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:25:59 872] [1970-01-01 00:01:11] MainApp.c(614) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:25:59 888] [1970-01-01 00:01:11] MainApp.c(615) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:25:59 888] [1970-01-01 00:01:11] MainApp.c(616) <tuya_ipc_sdk_mqtt_online_proc>: v_handle=[0xb57b30]
[2024/8/7 9:25:59 904] [1970-01-01 00:01:11] MainApp.c(617) <tuya_ipc_sdk_mqtt_online_proc>: v_handle_sub=[0xaec040]
[2024/8/7 9:25:59 904] [1970-01-01 00:01:11] MainApp.c(618) <tuya_ipc_sdk_mqtt_online_proc>: a_handle_sub=[0xb26ee8]
[2024/8/7 9:25:59 920] [1970-01-01 00:01:11] xm_main.c(1104) <XM_RegisterTYCallFunc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:25:59 920] [1970-01-01 00:01:11] xm_main.c(1105) <XM_RegisterTYCallFunc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:25:59 936] [1970-01-01 00:01:11] xm_main.c(1106) <XM_RegisterTYCallFunc>: a_handle_sub=[0xb26ee8]
[2024/8/7 9:25:59 936] [1970-01-01 00:01:11] xm_main.c(1107) <XM_RegisterTYCallFunc>: v_handle=[0xb57b30]
[2024/8/7 9:25:59 952] [1970-01-01 00:01:11] xm_main.c(1108) <XM_RegisterTYCallFunc>: v_handle_sub=[0xaec040]
[2024/8/7 9:25:59 952] [1970-01-01 00:01:11] MainApp.c(620) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:25:59 968] [1970-01-01 00:01:11] MainApp.c(621) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:25:59 968] [08-07 09:25:58 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[2024/8/7 9:25:59 984] [08-07 09:25:58 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[2024/8/7 9:25:59 984] [08-07 09:25:58 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[2024/8/7 9:26:00 000] [08-07 09:25:58 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722993958 28800
[2024/8/7 9:26:00 000] [08-07 09:25:58 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722993958 28800
[2024/8/7 9:26:00 016] --- tracepoint tuya_ipc_system_control_demo.c,XM_CheckDls_Pro(810): server time_zone 28800 time 1722993958 dls 0 loacl time 71
[2024/8/7 9:26:00 048] [2024-08-07 01:25:58] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 34[08-07 09:25:58 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"unitList":[{"port":7000,"protocol":"TCP"},{"port":8080,"protocol":"TCP"},{"port":5000,"protocol":"UDP"},{"port":8000,"protocol":"UDP"}]},"t":1722993958,"success":true}
[2024/8/7 9:26:00 048] [08-07 09:25:58 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:26:00 048] [08-07 09:25:58 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:26:00 064] [08-07 09:25:58 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:00 064] [08-07 09:25:58 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:00 064] [08-07 09:25:58 TUYA D][tuya_ipc_upnp.c:171] upnp get config success result:{
[2024/8/7 9:26:00 080] 	"unitList":	[{
[2024/8/7 9:26:00 080] 			"port":	7000,
[2024/8/7 9:26:00 080] 			"protocol":	"TCP"
[2024/8/7 9:26:00 080] 		}, {
[2024/8/7 9:26:00 080] 			"port":	8080,
[2024/8/7 9:26:00 080] 			"port":	5000,
[2024/8/7 9:26:00 080] 			"protocol":	"UDP"
[2024/8/7 9:26:00 080] 			"port":	8000,
[2024/8/7 9:26:00 096] 			"protocol":	"UDP"
[2024/8/7 9:26:00 096] 		}]
[2024/8/7 9:26:00 096] [08-07 09:25:58 TUYA D][tuya_ipc_upnp.c:293] tuya_ipc_upnp_start start
[2024/8/7 9:26:00 111] [2024-08-07 09:25:58] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:26:00 112] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10.
[2024/8/7 9:26:00 112] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:26:00 112] Mode(Product):0
[2024/8/7 9:26:00 127] BpuMode:[Online]
[2024/8/7 9:26:00 128] VpssMode:[Online]
[2024/8/7 9:26:00 128] [0.LimitUp_info]:
[2024/8/7 9:26:00 128] LimitUp:[Disable]
[2024/8/7 9:26:00 128] [2680*0]->[3840*0])
[2024/8/7 9:26:00 128] chn	TotalSize	ActiveSize
[2024/8/7 9:26:00 128] 0	5040*2246	2680*2160
[2024/8/7 9:26:00 128] 0	5040*2246	3840*2160
[2024/8/7 9:26:00 143] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:26:00 143] [1.VICU_info]:
[2024/8/7 9:26:00 144] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:26:00 144] 0	25.0	828	0	0	183	linear	8ddb00
[2024/8/7 9:26:00 144] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:26:00 160] en	op_type	m_chn	now
[2024/8/7 9:26:00 160] 0	1	1	1
[2024/8/7 9:26:00 160] [2.VI_info]:
[2024/8/7 9:26:00 160] chn	TotalSize	ActiveSize
[2024/8/7 9:26:00 160] 0	5040*2246	3848*2166
[2024/8/7 9:26:00 160] 1	   0*   0	   0*   0
[2024/8/7 9:26:00 160] [3.MIPI_info]:
[2024/8/7 9:26:00 176] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:26:00 176] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:26:00 176] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:26:00 176] [4.Cut_info]:
[2024/8/7 9:26:00 176] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:26:00 192] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:26:00 192] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:26:00 192] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:26:00 192] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:26:00 192] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:26:00 192] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:26:00 207] [5.IB(isp buffer info)]:
[2024/8/7 9:26:00 208] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:26:00 208] PoolId  Count  Size
[2024/8/7 9:26:00 224] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:00 224] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:00 224] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:00 239] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:00 240] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:00 255] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:00 256] [08-07 09:25:58 TUYA I][uni_thread.c:228] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:230400,priority:3
[2024/8/7 9:26:00 272] [08-07 09:25:58 TUYA D][uni_thread.c:250] Thread:UPnP_PROC Exec Start. Set to Running Stat
[2024/8/7 9:26:00 272] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0
[2024/8/7 9:26:00 288] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0
[2024/8/7 9:26:00 304] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:8943 
[2024/8/7 9:26:00 304] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8943, in_port 8943 protocol:UDP, status:0
[2024/8/7 9:26:00 319] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:1168 
[2024/8/7 9:26:00 320] 
[2024/8/7 9:26:00 320] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 1168, in_port 1168 protocol:UDP, status:0
[2024/8/7 9:26:00 335] 
[2024/8/7 9:26:00 336] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:9081 
[2024/8/7 9:26:00 351] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 9081, in_port 9081 protocol:UDP, status:0
[2024/8/7 9:26:00 351] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5!
[2024/8/7 9:26:00 367] [08-07 09:25:58 TUYA D][tuya_ipc_upnp.c:314] tuya_ipc_upnp_start success
[2024/8/7 9:26:00 367] [08-07 09:25:58 TUYA D][tuya_ipc_upnp.c:421] start upnp module success, exit thread
[2024/8/7 9:26:00 368] [08-07 09:25:58 TUYA D][uni_thread.c:310] Del Thrd:ipc_upnp
[2024/8/7 9:26:00 383] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 90314ba51650
[2024/8/7 9:26:00 384] [08-07 09:25:58 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING...
[2024/8/7 9:26:00 399] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:26:00 400] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:26:00 400] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:26:00 415] 0       0         0          2          4       
[2024/8/7 9:26:00 416] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:26:00 416]      --265--            --264--                                               
[2024/8/7 9:26:00 432] Count      Line     Count      Line     
[2024/8/7 9:26:00 432] 653        437      1592       560      
[2024/8/7 9:26:00 432] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:26:00 448] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:26:00 448] 0   3840   2160    H265  0      0        0           386       982631     409      	
[2024/8/7 9:26:00 464] 1   640    360     H265  0      0        0           257       43197      3        	
[2024/8/7 9:26:00 464] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:26:00 481] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:26:00 481] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:26:00 496] 0   Y      386      1       0       14       1        386      385      509       62895         59245    137634   64947    12      
[2024/8/7 9:26:00 512] 1   Y      257      0       9       1        0        257      257      509       4419          1945     20266    2625     9       
[2024/8/7 9:26:00 527] 3   N      0        0       0       1        0        0        0        510       0             0        0        0        0       
[2024/8/7 9:26:00 528] [2024-08-07 09:25:58] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:26:00 559] [2024-08-07 09:25:58] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 869[08-07 09:25:58 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.107, Nov 16 2023 10:52:20\"}","t":1722993958}
[2024/8/7 9:26:00 575] [08-07 09:25:58 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c15d25ee258e171f90aba&et=1&t=1722993958&v=1.0&sign=d8a21f9cd47ce272373cce08dab7a246
[2024/8/7 9:26:00 576] [08-07 09:25:58 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:00 591] [08-07 09:25:58 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:00 592] [08-07 09:25:58 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:00 592] [08-07 09:25:58 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:00 607] [08-07 09:25:58 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:00 607] [08-07 09:25:58 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:00 623] [08-07 09:25:58 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:00 624] [08-07 09:25:58 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:00 639] [08-07 09:25:58 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:00 639] [08-07 09:25:58 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:00 655] [08-07 09:25:58 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:00 655] [08-07 09:25:58 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:00 671] [08-07 09:25:58 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:00 688] [2024-08-07 09:25:58] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 1308[08-07 09:25:58 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722993958,"success":true}
[2024/8/7 9:26:00 689] [08-07 09:25:58 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:00 703] [08-07 09:25:58 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:00 703] [08-07 09:25:58 TUYA D][uni_thread.c:268] Thread:ipc_upnp Exec Finish. Set to Del Stat
[2024/8/7 9:26:00 719] [08-07 09:25:58 TUYA D][uni_thread.c:125] del list not empty...deleting 0xb1d214, next 0xae0be8
[2024/8/7 9:26:00 719] [08-07 09:25:58 TUYA D][uni_thread.c:132] Final Free Thread:ipc_upnp, is_self:1
[2024/8/7 9:26:00 735] [08-07 09:25:58 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:26:00 735] [08-07 09:25:58 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:26:00 751] [2024-08-07 09:25:58] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 3113g_AudioTipsList.size() enable: 0[08-07 09:25:59 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:26:00 767] [08-07 09:25:59 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:26:00 767] [08-07 09:25:59 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:26:00 783] [08-07 09:25:59 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:26:00 783] [08-07 09:25:59 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:26:00 799] [08-07 09:25:59 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:25939 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:26:00 799] [08-07 09:25:59 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:25939
[2024/8/7 9:26:00 815] [08-07 09:25:59 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722993959,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 9:26:00 815] [08-07 09:25:59 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 9:26:00 831] [08-07 09:25:59 TUYA D][app_agent.c:600] send length:80, id:35, sequence_out:5210
[2024/8/7 9:26:00 831] [08-07 09:25:59 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:26:00 847] [08-07 09:25:59 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722993959, rept_cnt:3.
[2024/8/7 9:26:00 863] [08-07 09:25:59 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722993959, rept_cnt:0.
[2024/8/7 9:26:00 865] [08-07 09:25:59 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722993959, rept_cnt:0.
[2024/8/7 9:26:00 865] DEBUG: autoscene chn[0]: Bw!
[2024/8/7 9:26:00 865] DEBUG: ***u16num***[131]
[2024/8/7 9:26:00 879] DEBUG: ***u16num***[445]
[2024/8/7 9:26:00 879] [2024-08-07 09:25:59] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:00 895] [2024-08-07 09:25:59] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:26:00 911] [2024-08-07 09:25:59] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 6733[2024-08-07 09:26:01] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:00 911] [08-07 09:26:01 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 9:26:00 927] [08-07 09:26:01 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:00 927] [08-07 09:26:01 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:00 927] [08-07 09:26:01 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:00 943] [08-07 09:26:01 TUYA D][tuya_svc_schema_upgrade.c:223] schema[flvlrc] not updated since activated
[2024/8/7 9:26:00 943] DEBUG: ***u16num***[511]
[2024/8/7 9:26:00 943] DEBUG: ***u16num***[512]
[2024/8/7 9:26:00 959] DEBUG: ***u16num***[512]
[2024/8/7 9:26:00 975] [2024-08-07 09:26:01] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time44958
[2024/8/7 9:26:00 976] [08-07 09:26:02 TUYA D][iot_httpc.c:1161] Post Data: {"data":"255","t":1722993962}
[2024/8/7 9:26:00 991] [08-07 09:26:02 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6c15d25ee258e171f90aba&et=1&t=1722993962&sign=1dd556b8bd4feb5a43bd46345d4230b6
[2024/8/7 9:26:00 991] [08-07 09:26:02 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:01 007] [08-07 09:26:02 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:01 007] [08-07 09:26:02 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:01 023] [08-07 09:26:02 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:01 023] [08-07 09:26:02 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:01 039] [08-07 09:26:02 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:01 039] [08-07 09:26:02 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:01 055] [08-07 09:26:02 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:01 055] [08-07 09:26:02 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:01 071] [08-07 09:26:02 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:01 071] [08-07 09:26:02 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:01 087] [08-07 09:26:02 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:01 087] [08-07 09:26:02 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:01 103] [08-07 09:26:02 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722993962,"success":true}
[2024/8/7 9:26:01 103] [08-07 09:26:02 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:01 119] [08-07 09:26:02 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:01 119] [08-07 09:26:02 TUYA D][tuya_devos_entry.c:406] put rst log finish
[2024/8/7 9:26:01 135] [08-07 09:26:02 TUYA D][iot_httpc.c:1161] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1722993962}
[2024/8/7 9:26:01 151] [08-07 09:26:02 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6c15d25ee258e171f90aba&et=1&t=1722993962&v=2.0&sign=ef33508a55ef018eba01c8c7ba62f737
[2024/8/7 9:26:01 151] [08-07 09:26:02 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:01 167] [08-07 09:26:02 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:01 167] [08-07 09:26:02 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:01 183] [08-07 09:26:02 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:01 183] [08-07 09:26:02 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:01 199] [08-07 09:26:02 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:01 199] [08-07 09:26:02 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:01 215] [08-07 09:26:02 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:01 215] [08-07 09:26:02 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:01 215] [08-07 09:26:02 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:01 231] [08-07 09:26:02 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:01 231] [08-07 09:26:02 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:01 247] [08-07 09:26:02 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:01 247] DEBUG: ***u16num***[512]
[2024/8/7 9:26:01 279] [08-07 09:26:02 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722993962,"validTime":1800}},"t":1722993962,"success":true}
[2024/8/7 9:26:01 279] [08-07 09:26:02 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:01 279] [08-07 09:26:02 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:01 296] [08-07 09:26:02 TUYA D][iot_httpc.c:3388] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1722993962}, ret:0.
[2024/8/7 9:26:01 296] [08-07 09:26:02 TUYA D][tuya_devos_entry.c:479] timezone:+08:00
[2024/8/7 9:26:01 312] [08-07 09:26:02 TUYA D][tuya_devos_entry.c:500] summer_time_zone:[]
[2024/8/7 9:26:01 312] [08-07 09:26:02 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:26:01 312] [08-07 09:26:02 TUYA D][simplekv.c:1251] find key:12 gw_ai
[2024/8/7 9:26:01 328] [08-07 09:26:02 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544
[2024/8/7 9:26:01 328] [08-07 09:26:02 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:26:01 344] [08-07 09:26:02 TUYA D][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722993962,"validTime":1800}}.
[2024/8/7 9:26:01 360] [08-07 09:26:02 TUYA D][tuya_devos_utils.c:94] reset dp rate rule finish.
[2024/8/7 9:26:01 360] [08-07 09:26:02 TUYA D][iot_httpc.c:1161] Post Data: {"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722993962}
[2024/8/7 9:26:01 376] [08-07 09:26:02 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.ack&devId=6c15d25ee258e171f90aba&et=1&t=1722993962&v=2.0&sign=bbe772df3bd6f89d0dcbff8e10d4188c
[2024/8/7 9:26:01 391] [08-07 09:26:02 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:01 391] [08-07 09:26:02 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:01 407] [08-07 09:26:02 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:01 407] [08-07 09:26:02 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:01 423] [08-07 09:26:02 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:01 423] [08-07 09:26:02 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:01 439] [08-07 09:26:02 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:01 439] [08-07 09:26:02 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:01 455] [08-07 09:26:02 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:01 455] [08-07 09:26:02 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:01 455] [08-07 09:26:02 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:01 471] [08-07 09:26:02 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:01 488] [08-07 09:26:02 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:01 488] [08-07 09:26:03 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722993963,"success":true}
[2024/8/7 9:26:01 504] [08-07 09:26:03 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:01 504] [08-07 09:26:03 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:01 520] [08-07 09:26:03 TUYA D][iot_httpc.c:2411] dynamic cfg post data:{"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722993962}, ret:0.
[2024/8/7 9:26:01 520] DEBUG: ***u16num***[512]
[2024/8/7 9:26:01 536] [08-07 09:26:03 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:26:01 536] DEBUG: ***u16num***[512]
[2024/8/7 9:26:01 567] DEBUG: ***u16num***[512]
[2024/8/7 9:26:01 744] DEBUG: ***u16num***[512]
[2024/8/7 9:26:01 919] DEBUG: ***u16num***[512]
[2024/8/7 9:26:02 159] DEBUG: ***u16num***[512]
[2024/8/7 9:26:02 352] DEBUG: ***u16num***[512]
[2024/8/7 9:26:02 463] DEBUG: ***u16num***[512]
[2024/8/7 9:26:02 639] DEBUG: ***u16num***[512]
[2024/8/7 9:26:02 767] DEBUG: ***u16num***[512]
[2024/8/7 9:26:02 880] DEBUG: ***u16num***[512]
[2024/8/7 9:26:03 007] DEBUG: ***u16num***[512]
[2024/8/7 9:26:03 184] DEBUG: ***u16num***[512]
[2024/8/7 9:26:03 247] DEBUG: ***u16num***[512]
[2024/8/7 9:26:03 312] DEBUG: ***u16num***[512]
[2024/8/7 9:26:03 424] DEBUG: ***u16num***[512]
[2024/8/7 9:26:03 600] DEBUG: ***u16num***[512]
[2024/8/7 9:26:03 791] DEBUG: ***u16num***[512]
[2024/8/7 9:26:03 968] DEBUG: ***u16num***[512]
[2024/8/7 9:26:04 096] [2024-08-07 09:26:04] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:04 111] [2024-08-07 09:26:05] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time48963
[2024/8/7 9:26:04 111] [08-07 09:26:06 TUYA D][tuya_upnp_module_mg.c:1432] upnpDiscover failed
[2024/8/7 9:26:04 111] DEBUG: ***u16num***[512]
[2024/8/7 9:26:04 271] DEBUG: ***u16num***[512]
[2024/8/7 9:26:04 336] while(lib_ble_start) before
[2024/8/7 9:26:04 352] [08-07 09:26:06 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"devId":"6c15d25ee258e171f90aba","gwId":"6c15d25ee258e171f90aba"},"protocol":11,"s":1613827,"t":1722993966}
[2024/8/7 9:26:04 352] [08-07 09:26:06 TUYA D][mqtt_client.c:916] disconnect mqtt
[2024/8/7 9:26:04 384] DEBUG: ***u16num***[512]
[2024/8/7 9:26:04 560] DEBUG: ***u16num***[512]
[2024/8/7 9:26:04 687] DEBUG: ***u16num***[512]
[2024/8/7 9:26:04 703] [08-07 09:26:07 TUYA E][app_agent.c:1479] close socket,errno:-100 errno:0
[2024/8/7 9:26:04 705] [08-07 09:26:07 TUYA D][app_agent.c:213] set socket fault 35
[2024/8/7 9:26:04 705] [08-07 09:26:07 TUYA D][app_agent.c:274] i:0,time:1722993967,c_time:1722993965,fault:1
[2024/8/7 9:26:04 719] [08-07 09:26:07 TUYA D][app_agent.c:163] close socket 35
[2024/8/7 9:26:04 815] DEBUG: ***u16num***[512]
[2024/8/7 9:26:04 848] [08-07 09:26:07 TUYA D][gw_mqc_cb.c:60] unactive
[2024/8/7 9:26:04 848] [08-07 09:26:07 TUYA E][mqtt_client.c:1652] mq_recv err:-30848 len:0
[2024/8/7 9:26:04 864] [08-07 09:26:07 TUYA D][tuya_devos_reset.c:418] unactive Reset
[2024/8/7 9:26:04 864] [08-07 09:26:07 TUYA D][tuya_devos_reset.c:261] gw reset called. tp:1 stat:1
[2024/8/7 9:26:04 880] __IPC_APP_Get_Net_Status_cb line(183) -------------------------- stat(0)==STAT_LOW_POWER 
[2024/8/7 9:26:04 880] [08-07 09:26:07 TUYA D][tuya_devos_reset.c:85] <__wf_reset> nc_tp:2, rst_tp:1, wifi_start_mode:0
[2024/8/7 9:26:04 895] [08-07 09:26:07 TUYA D][tuya_devos_reset.c:325] <__gw_reset> tuya_ble_clear_mesh
[2024/8/7 9:26:04 895] [08-07 09:26:07 TUYA D][tuya_ble_api.c:1050] start to clr appkey.
[2024/8/7 9:26:04 895] [08-07 09:26:07 TUYA D][simplekv.c:1348] delete key:ble_app_key isFuzzy:0
[2024/8/7 9:26:04 911] [08-07 09:26:07 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:26:04 911] [08-07 09:26:07 TUYA D][simplekv.c:1386] delete key find 4
[2024/8/7 9:26:04 927] [08-07 09:26:07 TUYA D][simplekv.c:1424] Delete key:ble_app_key 4 success
[2024/8/7 9:26:04 927] [08-07 09:26:07 TUYA D][simplekv.c:203] update crc 1342236678
[2024/8/7 9:26:04 927] [08-07 09:26:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:04 943] [08-07 09:26:07 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:26:04 943] [08-07 09:26:07 TUYA D][tuya_ble_api.c:1058] start to clr network_key.
[2024/8/7 9:26:04 943] [08-07 09:26:07 TUYA D][simplekv.c:1348] delete key:ble_network_key isFuzzy:0
[2024/8/7 9:26:04 959] [08-07 09:26:07 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:26:04 959] [08-07 09:26:07 TUYA D][simplekv.c:1386] delete key find 13
[2024/8/7 9:26:04 975] [08-07 09:26:07 TUYA D][simplekv.c:1424] Delete key:ble_network_key 13 success
[2024/8/7 9:26:04 975] [08-07 09:26:07 TUYA D][simplekv.c:203] update crc 766156184
[2024/8/7 9:26:04 975] [08-07 09:26:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:04 991] [08-07 09:26:07 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:26:04 991] [08-07 09:26:07 TUYA D][tuya_ble_api.c:1035] start to clr beaconkey.
[2024/8/7 9:26:04 991] [08-07 09:26:07 TUYA D][simplekv.c:1348] delete key:ble_beaconkey isFuzzy:0
[2024/8/7 9:26:05 007] [08-07 09:26:07 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:26:05 007] [08-07 09:26:07 TUYA D][simplekv.c:1386] delete key find 14
[2024/8/7 9:26:05 023] [08-07 09:26:07 TUYA D][simplekv.c:1424] Delete key:ble_beaconkey 14 success
[2024/8/7 9:26:05 023] [08-07 09:26:07 TUYA D][simplekv.c:203] update crc 1929601170
[2024/8/7 9:26:05 023] DEBUG: ***u16num***[512]
[2024/8/7 9:26:05 040] [08-07 09:26:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:05 040] [08-07 09:26:07 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:26:05 056] [08-07 09:26:07 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":1,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:26:05 056] [08-07 09:26:07 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:26:05 072] [08-07 09:26:07 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:26:05 072] [08-07 09:26:07 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:176
[2024/8/7 9:26:05 072] [08-07 09:26:07 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:26:05 087] [08-07 09:26:07 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:26:05 088] [08-07 09:26:07 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:26:05 104] [08-07 09:26:07 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:26:05 104] [08-07 09:26:07 TUYA D][simplekv.c:203] update crc 3386030828
[2024/8/7 9:26:05 104] [08-07 09:26:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:05 119] [08-07 09:26:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:05 120] [08-07 09:26:07 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:26:05 120] [08-07 09:26:07 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:26:05 135] [08-07 09:26:07 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[2024/8/7 9:26:05 136] [08-07 09:26:07 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[2024/8/7 9:26:05 152] [08-07 09:26:07 TUYA D][tuya_svc_timer_task.c:107] reset. write_disk:1
[2024/8/7 9:26:05 152] [08-07 09:26:07 TUYA D][tuya_svc_timer_task.c:310] max len:128
[2024/8/7 9:26:05 152] [08-07 09:26:07 TUYA D][[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:26:05 168] tuya_svc_timer_task.c:378] offset:27
[2024/8/7 9:26:05 168] [08-07 09:26:07 TUYA D][tuya_svc_timer_task.c:397] save TIMER:{"lastFetchTime":0,"cnt":0}
[2024/8/7 9:26:05 183] [08-07 09:26:07 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:26:05 183] [08-07 09:26:07 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:05 183] [08-07 09:26:07 TUYA D][simp[atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:26:05 199] lekv.c:1294] __r[atbm_log]:aggtx stop queue
[2024/8/7 9:26:05 199] ead_kv_raw fail.[atbm_log]:add to pending(0)(20)
[2024/8/7 9:26:05 199]  -3
[2024/8/7 9:26:05 199] [08-07 09:26:07 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:05 215] [08-07 09:26:07 TUYA D][simplekv.c:374] write key:timer_arr And Value Len:32
[2024/8/7 9:26:05 215] [08-07 09:26:07 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 32
[2024/8/7 9:26:05 231] [08-07 09:26:07 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:26:05 232] [08-07 09:26:07 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:26:05 232] [08-07 09:26:07 TUYA D][simplekv.c:203] update crc 930266090
[2024/8/7 9:26:05 247] GAP procedure initiated: terminate connection; conn_handle=1 hci_reason=19
[2024/8/7 9:26:05 248] [08-07 09:26:07 TUYA D][s[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:26:05 248] implekv.c:359] write head to normal file success
[2024/8/7 9:26:05 263] [08-07 09:26:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:05 279] [08-07 09:26:07 TUYA D][simplekv.c:1348] delete key:l[atbm_log]:AMPDU[eth2]:action[3],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:05 279] ast_reset_info i[atbm_log]:add to pending(0)(20)
[2024/8/7 9:26:05 279] sFuzzy:0
[2024/8/7 9:26:05 280] [08-0[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:26:05 295] 7 09:26:07 TUYA [atbm_log]:AMPDU[eth2]:action[1],tid[0],ssn[0],buff_size[0],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:05 295] D][simplekv.c:1354] cnt:18 delete bit ar[atbm_log]:add to pending(0)(20)
[2024/8/7 9:26:05 295] r len:1
[2024/8/7 9:26:05 311] [08-07 09:26:0[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 5
[2024/8/7 9:26:05 311] 7 TUYA D][simple[atbm_log]:AMPDU[eth2]:action[1],tid[5],ssn[0],buff_size[0],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:05 328] kv.c:1395] key:last_reset_info n[atbm_log]:add to pending(0)(20)
[2024/8/7 9:26:05 328] ot find
[2024/8/7 9:26:05 328] [08-07[atbm_log]:aggtx wake queue
[2024/8/7 9:26:05 328]  09:26:07 TUYA D[atbm_log]:not assoc 
[2024/8/7 9:26:05 343] ][tuya_ipc_p2p_c[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:26:05 343] ommon.c:488] __begin
[2024/8/7 9:26:05 343] [[atbm_log]:AMPDU[eth2]:action[1],tid[6],ssn[0],buff_size[0],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:05 359] 08-07 09:26:07 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:26:05 359] [08-07 09:26:07 TUYA D][simplekv.c:1251] fi[atbm_log]:eth2: deauthenticating from a4:a9:30:ce:5e:66 by local choice (reason=3)
[2024/8/7 9:26:05 376] nd key:5 p2p_auth_info
[2024/8/7 9:26:05 376] [08-07 09:26:07 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:26:05 376] [08-07 09:26:07 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:26:05 391] [08-07 09:26:07 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 16
[2024/8/7 9:26:05 391] [08-07 09:26:07 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:26:05 407] [08-07 09:26:07 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:26:05 407] [08-07 09:26:07 TUYA D][simplekv.c:203] update crc 2213442203
[2024/8/7 9:26:05 407] [08-07 09:26:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:05 423] [08-07 09:26:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:05 423] [08-07 09:26:07 TUYA D][simplekv.c:1211] read key:p2p_pwd i[atbm_log]:[TX]:[0]:deatuhen[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:05 423] sFuzzy:0 skipCnt:0
[2024/8/7 9:26:05 439] [08-07 09:26:07 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:26:05 439] [08-07 09:26:07 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:26:05 455] [08-07 09:26:07 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:26:05 455] [08-07 09:26:07 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:26:05 455] [08-07 09:26:07 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:26:05 471] [08-07 09:26:07 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:26:05 471] [08-07 09:26:07 TUYA N][mqtt_client.c:1703] mqtt close
[2024/8/7 9:26:05 471] [08-07 09:26:07 TUYA N][mqtt_client.c:839] close mqtt -->>
[2024/8/7 9:26:05 487] [08-07 09:26:07 TUYA D][mqtt_client.c:851] shutdown fd enabled
[2024/8/7 9:26:05 487] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr027
[2024/8/7 9:26:05 503] [08-07 09:26:07 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:05 503] [08-07 09:26:07 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:05 503] [08-07 09:26:07 TUYA N][mqtt_client.c:886] close mqtt <<--
[2024/8/7 9:26:05 519] [08-07 09:26:07 TUYA D][mqtt_client.c:1720] mqtt fail_cnt:1, sleeptime:6724 ms
[2024/8/7 9:26:05 519] [08-07 09:26:07 TUYA D][simplekv.c:203] update crc 1612828776
[2024/8/7 9:26:05 519] [2024-08[atbm_log]:[STA]:unjoin ++
[2024/8/7 9:26:05 535] -07 09:26:07] xm_main.c(374) <AutoMainte[atbm_log]:[STA]:unjoin --
[2024/8/7 9:26:05 535] nance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:05 535] [08-07 09:26:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:05 551] [08-07 09:26:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:05 551] [08-07 09:26:07 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:26:05 551] [08-07 09:26:07 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:26:05 567] [08-07 09:26:07 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:26:05 567] [08-07 09:26:07 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:26:05 583] [08-07 09:26:07 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:26:05 583] [08-07 09:26:07 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:26:05 583] [08-07 09:26:07 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:26:05 599] [08-07 09:26:07 TUYA D][simplekv.c:203] update crc 601709122
[2024/8/7 9:26:05 599] [08-07 09:26:07 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:05 615] [08-07 0[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:26:05 615] 9:26:07 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:05 615] rm: can't remove '/mnt/mtd/Config/localtime': Device or resource busy
[2024/8/7 9:26:05 632] rm: can't remove '/mnt/mtd/Config/resolv.conf': Device or resource busy
[2024/8/7 9:26:05 632] DEBUG: ***u16num***[512]
[2024/8/7 9:26:05 632] rm: can't remove '/mnt/mtd/Config': Directory not empty
[2024/8/7 9:26:05 648] DEBUG: ***u16num***[512]
[2024/8/7 9:26:05 648] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:26:05 727] DEBUG: ***u16num***[512]
[2024/8/7 9:26:05 839] DEBUG: ***u16num***[512]
[2024/8/7 9:26:05 968] DEBUG: ***u16num***[512]
[2024/8/7 9:26:06 000] IPC_APP_Reset_System_CB line(143) -------------------------- 
[2024/8/7 9:26:06 000] ble_slave_gap_event->type=14
[2024/8/7 9:26:06 000] subscribe event; conn_handle=1 attr_handle=23 reason=2 prevn=1 curn=0 previ=0 curi=0
[2024/8/7 9:26:06 016] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:26:06 016] ble_slave_gap_event->type=1
[2024/8/7 9:26:06 016] disconnect; reason=534 
[2024/8/7 9:26:06 032] [2024-08-07 09:26:07] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:07] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:26:06 032] set basic_indicator_onoff:0 
[2024/8/7 9:26:06 048] [2024-08-07 09:26:07] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:06 048] [2024-08-07 09:26:07] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:06 064] [2024-08-07 09:26:07] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:07] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:26:06 095] [2024-08-07 09:26:07] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:07] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:26:06 111] [2024-08-07 09:26:07] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:07] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:26:06 128] [2024-08-07 09:26:07] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:07] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:26:06 143] [2024-08-07 09:26:08] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:08] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:26:06 160] [2024-08-07 09:26:08] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:08] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:26:06 175] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(150): cmd=[killall wpa_supplicant udhcpc;ifconfig eth2 down;ifconfig eth0 down;]
[2024/8/7 9:26:06 176]  ---
[2024/8/7 9:26:06 176] curr event:13 
[2024/8/7 9:26:06 191] IPC_APP_Notify_LED_Sound_Status_CB line(583) -------------------------- IPC_RESET_SUCCESS(13)
[2024/8/7 9:26:06 207] [2024-08-07 09:26:08] tuya_ipc_system_control_demo.c(585) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(RESET, 0, 1, 0, 1))
[2024/8/7 9:26:06 208] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(155):  ---
[2024/8/7 9:26:06 223] [2024-08-07 09:26:08] xm_main.c(2440) <XMSDK_SystemRebootTY>: XMSDK_MotorGetPostion(3110,0) suc
[2024/8/7 9:26:06 223] [2024-08-07 09:26:08] xm_main.c(2064) <XM_SaveLocalPtzPosition>: Save PTZ xPosition 3110 failed
[2024/8/7 9:26:06 239] [2024-08-07 09:26:08] xm_main.c(2445) <XMSDK_SystemRebootTY>: XM_SaveLocalPtzPosition(3110,0) failed,ret=[-1]
[2024/8/7 9:26:06 240] XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:26:06 255] [2024-08-07 09:26:08] xm_main.c(2454) <XMSDK_SystemRebootTY>: XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:26:06 255] [2024-08-07 09:26:08] ==> XMSDK_SystemReboot(198)[INFO]: Sys XMSDK_SystemReboot Reboot
[2024/8/7 9:26:06 271] [2024-08-07 09:26:08] ==> XMSDK_SystemReboot(199)[INFO]: Sys Will Reboot
[2024/8/7 9:26:06 287] [2024-08-07 09:26:08] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/Reset_english.pcm]
[2024/8/7 9:26:06 287] [2024-08-07 09:26:08] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:06 303] [2024-08-07 09:26:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:26:06 319] [2024-08-07 09:26:08] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:08] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:26:06 319] set basic_indicator_onoff:0 
[2024/8/7 9:26:06 335] [2024-08-07 09:26:08] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:06 337] [2024-08-07 09:26:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:06 337] [08-07 09:26:08 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722993968 28800
[2024/8/7 9:26:06 351] [08-07 09:26:08 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722993968 28800
[2024/8/7 9:26:06 351] DEBUG: ***u16num***[512]
[2024/8/7 9:26:06 367] [08-07 09:26:08 TUYA D][tuya_ble_api.c:1426] cloud disconnected, start adv!
[2024/8/7 9:26:06 367] [08-07 09:26:08 TUYA I][bt_ext_porting.c:628] [TUYA-BTUART]start_adv
[2024/8/7 9:26:06 383] --- tracepoint bt_ext_porting.c,tuya_ext_bt_start_adv(629): start_adv ---
[2024/8/7 9:26:06 383] [08-07 09:26:08 TUYA D][tuya_ble_api.c:1376] nw stat change:2->0, rpt to app.
[2024/8/7 9:26:06 383] [08-07 09:26:08 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:26:06 447] DEBUG: ***u16num***[512]
[2024/8/7 9:26:06 623] DEBUG: ***u16num***[512]
[2024/8/7 9:26:06 751] DEBUG: ***u16num***[512]
[2024/8/7 9:26:06 927] DEBUG: ***u16num***[512]
[2024/8/7 9:26:07 039] [atbm_log]:atbm_ioctl_ble_stop
[2024/8/7 9:26:07 055] [atbm_log]:ioctl_release(c264d100)(c1ded480)
[2024/8/7 9:26:07 183] DEBUG: ***u16num***[512]
[2024/8/7 9:26:07 247] <====== ble_gap_terminate(ble_conn_handle,19);
[2024/8/7 9:26:07 248] <====== ble_smart_cfg_task end step 0
[2024/8/7 9:26:07 248] exit ble process
[2024/8/7 9:26:07 248] ble_hs_hci_cmd_reset
[2024/8/7 9:26:07 248] cli_free before
[2024/8/7 9:26:07 248] nimble_port_atbmos_free before
[2024/8/7 9:26:07 248] nimble_port_release before
[2024/8/7 9:26:07 248] ble_gap_free before
[2024/8/7 9:26:07 263] ble_hs_hci_free before
[2024/8/7 9:26:07 263] ble_hs_free before
[2024/8/7 9:26:07 263] ble_hs_free after
[2024/8/7 9:26:07 263] nimble_release after
[2024/8/7 9:26:07 264] [08-07 09:26:09 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 9:26:07 279] DEBUG: ***u16num***[512]
[2024/8/7 9:26:07 488] DEBUG: ***u16num***[512]
[2024/8/7 9:26:07 519] [2024-08-07 09:26:09] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:26:07 520] [2024-08-07 09:26:09] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:26:07 520] sendto error send_packet 108 
[2024/8/7 9:26:07 520] recvfrom Error  
[2024/8/7 9:26:07 535] FUNCTION:recv_packet	LINE:139 
[2024/8/7 9:26:07 536] [2024-08-07 09:26:09] xm_wifi.c(386) <WifiConnectCheck>: gate way is  ping res is 0 error_cnt:1
[2024/8/7 9:26:07 536] ble_smart_cfg_exit before
[2024/8/7 9:26:07 551] ble_smart_cfg_exit after
[2024/8/7 9:26:07 551] atbm_stopThread after
[2024/8/7 9:26:07 551] [08-07 09:26:10 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 9:26:07 729] DEBUG: ***u16num***[512]
[2024/8/7 9:26:07 855] DEBUG: ***u16num***[512]
[2024/8/7 9:26:07 967] [2024-08-07 09:26:09] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time52966
[2024/8/7 9:26:07 999] g_AudioTipsList.size() enable: 0[2024-08-07 09:26:10] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:26:10] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [MotionDetect] pNumber[SirenSwitch]!
[2024/8/7 9:26:07 999] [08-07 09:26:10 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:26:08 031] DEBUG: ***u16num***[512]
[2024/8/7 9:26:08 127] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:26:08 127] Mode(Product):0
[2024/8/7 9:26:08 127] BpuMode:[Online]
[2024/8/7 9:26:08 143] VpssMode:[Online]
[2024/8/7 9:26:08 144] [0.LimitUp_info]:
[2024/8/7 9:26:08 144] LimitUp:[Disable]
[2024/8/7 9:26:08 144] [2680*0]->[3840*0])
[2024/8/7 9:26:08 144] chn	TotalSize	ActiveSize
[2024/8/7 9:26:08 144] 0	5040*2246	2680*2160
[2024/8/7 9:26:08 144] 0	5040*2246	3840*2160
[2024/8/7 9:26:08 144] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:26:08 159] 
[2024/8/7 9:26:08 160] [1.VICU_info]:
[2024/8/7 9:26:08 160] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:26:08 160] 0	25.0	1135	0	0	183	linear	8ddb00
[2024/8/7 9:26:08 160] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:26:08 160] en	op_type	m_chn	now
[2024/8/7 9:26:08 160] 0	1	1	1
[2024/8/7 9:26:08 175] [2.VI_info]:
[2024/8/7 9:26:08 175] chn	TotalSize	ActiveSize
[2024/8/7 9:26:08 175] 0	5040*2246	3848*2166
[2024/8/7 9:26:08 175] 1	   0*   0	   0*   0
[2024/8/7 9:26:08 175] [3.MIPI_info]:
[2024/8/7 9:26:08 175] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:26:08 191] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:26:08 191] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:26:08 192] [4.Cut_info]:
[2024/8/7 9:26:08 192] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:26:08 192] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:26:08 207] vicu	0	1	1	2	3840	2160	  
[2024/8/7 9:26:08 207] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:26:08 207] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:26:08 207] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:26:08 207] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:26:08 207] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:26:08 207] [5.IB(isp buffer info)]:
[2024/8/7 9:26:08 223] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:26:08 223] PoolId  Count  Size
[2024/8/7 9:26:08 224] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:08 239] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:08 239] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:08 255] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:08 255] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:08 271] DEBUG: ***u16num***[512]
[2024/8/7 9:26:08 271] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:26:08 272] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:26:08 289] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:26:08 289] 0       0         0          0          4       
[2024/8/7 9:26:08 289] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:26:08 303]      --265--            --264--                                               
[2024/8/7 9:26:08 303] Count      Line     Count      Line     
[2024/8/7 9:26:08 303] 898        480      2166       560      
[2024/8/7 9:26:08 319] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:26:08 319] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:26:08 335] 0   3840   2160    H265  0      0        0           526       980769     2271     	
[2024/8/7 9:26:08 335] 1   640    360     H265  0      0        0           361       43199      1        	
[2024/8/7 9:26:08 351] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:26:08 351] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:26:08 368] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:26:08 368] 0   Y      526      1       0       14       1        525      525      723       64464         59139    153681   65440    12      
[2024/8/7 9:26:08 383] 1   Y      361      0       9       1        0        361      361      724       1974          1945     20266    2580     9       
[2024/8/7 9:26:08 399] 3   N      0        0       0       1        0        0        0        726       0             0        0        0        0       
[2024/8/7 9:26:08 399] DEBUG: ***u16num***[512]
[2024/8/7 9:26:08 511] DEBUG: ***u16num***[512]
[2024/8/7 9:26:08 622] DEBUG: ***u16num***[512]
[2024/8/7 9:26:08 751] DEBUG: ***u16num***[512]
[2024/8/7 9:26:08 927] DEBUG: ***u16num***[512]
[2024/8/7 9:26:09 055] DEBUG: ***u16num***[512]
[2024/8/7 9:26:09 280] DEBUG: ***u16num***[512]
[2024/8/7 9:26:09 519] DEBUG: ***u16num***[512]
[2024/8/7 9:26:09 759] DEBUG: ***u16num***[512]
[2024/8/7 9:26:09 951] DEBUG: ***u16num***[512]
[2024/8/7 9:26:10 063] DEBUG: ***u16num***[512]
[2024/8/7 9:26:10 191] DEBUG: ***u16num***[512]
[2024/8/7 9:26:10 367] DEBUG: ***u16num***[512]
[2024/8/7 9:26:10 494] DEBUG: ***u16num***[512]
[2024/8/7 9:26:10 607] DEBUG: ***u16num***[512]
[2024/8/7 9:26:10 719] DEBUG: ***u16num***[512]
[2024/8/7 9:26:10 847] DEBUG: ***u16num***[512]
[2024/8/7 9:26:10 975] xmsfc_shutdown 2 2 
[2024/8/7 9:26:10 975] Restarting system.
[2024/8/7 9:26:11 023] ÿ
[2024/8/7 9:26:11 024] 
[2024/8/7 9:26:11 039] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 9:26:11 039] CPU: XM550V200WX2
[2024/8/7 9:26:11 039] DRAM:  128 MiB
[2024/8/7 9:26:11 151] MMC:   arasan: 0
[2024/8/7 9:26:11 198] In:    serial
[2024/8/7 9:26:11 198] Out:   serial
[2024/8/7 9:26:11 214] Err:   serial
[2024/8/7 9:26:11 423] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 9:26:11 423] Press Ctrl+C to stop autoboot
[2024/8/7 9:26:11 839] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 9:26:11 839] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 9:26:11 855]    Image Name:   Linux-3.10.103+
[2024/8/7 9:26:11 855]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 9:26:11 855]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 9:26:11 855]    Load Address: 80008000
[2024/8/7 9:26:11 855]    Entry Point:  80008000
[2024/8/7 9:26:11 871]    XIP Kernel Image ... OK
[2024/8/7 9:26:11 872] 
[2024/8/7 9:26:11 872] Starting kernel ...
[2024/8/7 9:26:12 751] Uncompressing Linux... done, booting the kernel.
[2024/8/7 9:26:12 879] Booting Linux on physical CPU 0x0
[2024/8/7 9:26:12 895] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 9:26:12 895] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 9:26:12 911] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 9:26:12 911] Machine: xm530v200
[2024/8/7 9:26:12 911] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 9:26:12 911] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 9:26:12 927] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 9:26:12 943] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 9:26:12 943] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 9:26:12 943] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 9:26:12 959] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 9:26:12 959] Memory: 52MB = 52MB total
[2024/8/7 9:26:12 959] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 9:26:12 959] Virtual kernel memory layout:
[2024/8/7 9:26:12 975]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 9:26:12 975]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 9:26:12 975]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 9:26:12 991]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 9:26:12 991]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 9:26:12 991]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 9:26:12 991]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 9:26:13 007]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 9:26:13 007]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 9:26:13 007] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 9:26:13 007] Hierarchical RCU implementation.
[2024/8/7 9:26:13 007] NR_IRQS:128
[2024/8/7 9:26:13 023] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 9:26:13 023] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 9:26:13 023] pid_max: default: 32768 minimum: 301
[2024/8/7 9:26:13 039] Mount-cache hash table entries: 512
[2024/8/7 9:26:13 039] CPU: Testing write buffer coherency: ok
[2024/8/7 9:26:13 039] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 9:26:13 039] L310 cache controller enabled
[2024/8/7 9:26:13 055] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 9:26:13 055] CPU1: Booted secondary processor
[2024/8/7 9:26:13 055] Brought up 2 CPUs
[2024/8/7 9:26:13 055] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 9:26:13 071] CPU: All CPU(s) started in SVC mode.
[2024/8/7 9:26:13 071] NET: Registered protocol family 16
[2024/8/7 9:26:13 071] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 9:26:13 071] Serial: AMBA PL011 UART driver
[2024/8/7 9:26:13 087] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 9:26:13 087] console [ttyAMA0] enabled
[2024/8/7 9:26:13 087] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 9:26:13 087] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 9:26:13 118] bio: create slab <bio-0> at 0
[2024/8/7 9:26:13 118] usbcore: registered new interface driver usbfs
[2024/8/7 9:26:13 119] usbcore: registered new interface driver hub
[2024/8/7 9:26:13 134] usbcore: registered new device driver usb
[2024/8/7 9:26:13 135] Switching to clocksource arm_global_timer
[2024/8/7 9:26:13 135] NET: Registered protocol family 2
[2024/8/7 9:26:13 150] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:26:13 150] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:26:13 151] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 9:26:13 166] TCP: reno registered
[2024/8/7 9:26:13 166] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:26:13 166] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:26:13 167] NET: Registered protocol family 1
[2024/8/7 9:26:13 182] RPC: Registered named UNIX socket transport module.
[2024/8/7 9:26:13 183] RPC: Registered udp transport module.
[2024/8/7 9:26:13 183] RPC: Registered tcp transport module.
[2024/8/7 9:26:13 183] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 9:26:13 214] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 9:26:13 215] NFS: Registering the id_resolver key type
[2024/8/7 9:26:13 215] Key type id_resolver registered
[2024/8/7 9:26:13 215] Key type id_legacy registered
[2024/8/7 9:26:13 230] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 9:26:13 231] fuse init (API version 7.22)
[2024/8/7 9:26:13 231] msgmni has been set to 95
[2024/8/7 9:26:13 247] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 9:26:13 247] io scheduler noop registered
[2024/8/7 9:26:13 247] io scheduler deadline registered (default)
[2024/8/7 9:26:13 247] io scheduler cfq registered
[2024/8/7 9:26:13 262] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 9:26:13 263] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 9:26:13 278] uart-pl011 uart:0: no DMA platform data
[2024/8/7 9:26:13 279] uart-pl011 uart:1: no DMA platform data
[2024/8/7 9:26:13 279] uart-pl011 uart:2: no DMA platform data
[2024/8/7 9:26:13 294] brd: module loaded
[2024/8/7 9:26:13 294] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 9:26:13 310] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:26:13 310] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 9:26:13 311] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 9:26:13 327] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 9:26:13 327] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 9:26:13 327] 0x000000300000-0x000000730000 : "user"
[2024/8/7 9:26:13 343] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 9:26:13 343] PPP generic driver version 2.4.2
[2024/8/7 9:26:13 343] NET: Registered protocol family 24
[2024/8/7 9:26:13 343] usbcore: registered new interface driver asix
[2024/8/7 9:26:13 359] usbcore: registered new interface driver cdc_ether
[2024/8/7 9:26:13 359] usbcore: registered new interface driver rndis_host
[2024/8/7 9:26:13 359] XMMMAC driver:
[2024/8/7 9:26:13 359] 	platform registration... 
[2024/8/7 9:26:13 359] 	done!
[2024/8/7 9:26:13 375] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 9:26:13 375] 	IO base addr: 0xfe010000)
[2024/8/7 9:26:13 375] libphy: XMMMAC MII Bus: probed
[2024/8/7 9:26:13 375] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 9:26:13 391] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 9:26:13 391] usbcore: registered new interface driver cdc_acm
[2024/8/7 9:26:13 391] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 9:26:13 407] usbcore: registered new interface driver usbserial
[2024/8/7 9:26:13 407] usbcore: registered new interface driver option
[2024/8/7 9:26:13 407] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 9:26:13 423] usbcore: registered new interface driver qcserial
[2024/8/7 9:26:13 423] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 9:26:13 423] TCP: cubic registered
[2024/8/7 9:26:13 423] NET: Registered protocol family 17
[2024/8/7 9:26:13 423] Key type dns_resolver registered
[2024/8/7 9:26:13 439] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 9:26:13 439] registered taskstats version 1
[2024/8/7 9:26:13 455] VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 9:26:13 455] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 9:26:13 807] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 9:26:14 350] arasan_set_clock:
[2024/8/7 9:26:14 382] 	new freq 400000
[2024/8/7 9:26:14 383] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 9:26:14 398] arasan_set_clock:
[2024/8/7 9:26:14 431] 	new freq 300000arasan_set_clock:
[2024/8/7 9:26:14 447] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 9:26:14 463] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 9:26:14 463] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 9:26:14 463] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 9:26:14 463] [reg] = 0x20000078,[val]= 0xc103c0ff
[2024/8/7 9:26:14 479] [reg] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 9:26:14 479] [reg] = 0x20000000,[val]= 0x00000000
[2024/8/7 9:26:14 479] arasan_set_clock:
[2024/8/7 9:26:14 479] 	new freq 195312[reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 9:26:14 495] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 9:26:14 496] [reg] = 0x20i2c: module license 'Proprietary' taints kernel.
[2024/8/7 9:26:14 496] 0505f0,[val]= 0xDisabling lock debugging due to kernel taint
[2024/8/7 9:26:14 496] 00000001
[2024/8/7 9:26:14 511] i2c init is ok!
[2024/8/7 9:26:14 511] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 9:26:14 639] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 9:26:14 703] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 9:26:14 735] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 9:26:14 735] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 9:26:14 766] acodec init is ok!
[2024/8/7 9:26:14 782] i2s clk:2048000Hz
[2024/8/7 9:26:14 926] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 9:26:14 926] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 9:26:14 943] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 9:26:14 943] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 9:26:14 943] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 9:26:14 959] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 9:26:14 959] usb usb1: Product: DWC OTG Controller
[2024/8/7 9:26:14 959] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 9:26:14 959] usb usb1: SerialNumber: dwc2.0
[2024/8/7 9:26:14 975] hub 1-0:1.0: USB hub found
[2024/8/7 9:26:14 975] hub 1-0:1.0: 1 port detected
[2024/8/7 9:26:15 023] xm_wdt init is ok
[2024/8/7 9:26:15 054] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 9:26:15 359] nn_kernel: NN: request mem  fail
[2024/8/7 9:26:15 359] nn_kernel: addr iomap fail
[2024/8/7 9:26:15 391] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 9:26:15 647] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 9:26:15 854] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:26:15 854] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:26:15 854] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:26:15 871] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:26:15 951] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtusbwifi_init.
[2024/8/7 9:26:15 967] d/user.sh: not fPDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 9:26:15 967] ound
[2024/8/7 9:26:15 983] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 9:26:16 015] exfatfsck 1.3.0
[2024/8/7 9:26:16 015] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:26:16 031] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:26:16 062] usb 1-1: USB disconnect, device number 3
[2024/8/7 9:26:17 967] ouput high and delay 2000ms
[2024/8/7 9:26:18 062] Auto login as root ...
[2024/8/7 9:26:18 094] (none) login: not found /dev/mmcxxx  
[2024/8/7 9:26:18 111] Tcp server success, Wait connet ...
[2024/8/7 9:26:18 111] Get xmauto Fialed ,xmauto = 1
[2024/8/7 9:26:18 127] auto start to app 
[2024/8/7 9:26:18 143] macGuarder: Get telnetctrl Fialed, telnetctrl=0
[2024/8/7 9:26:18 158] macGuarder: Close telnetd Forever 
[2024/8/7 9:26:18 398] usb 1-1: new high-speed USB device number 4 using dwc2
[2024/8/7 9:26:18 606] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:26:18 606] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:26:18 606] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:26:18 622] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:26:19 998] [atbm_log]:atbm_usb_module_init 0
[2024/8/7 9:26:20 014] [atbm_log]:platform_init(253)
[2024/8/7 9:26:20 014] [atbm_log]:SVN_VER=33341,DPLL_CLOCK=1,BUILD_TIME=[2024-04-03_14:40:53]
[2024/8/7 9:26:20 014] [atbm_log]:Probe called -1 v1
[2024/8/7 9:26:20 030] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[2024/8/7 9:26:20 030] [atbm_log]:CONFIG_TX_NO_CONFIRM
[2024/8/7 9:26:20 031] wiphy_new_nm support CONFIG_WIRELESS_EXT 
[2024/8/7 9:26:20 031] [atbm_log]:Allocated hw_priv @ c270d960
[2024/8/7 9:26:20 046] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[2024/8/7 9:26:20 062] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c270d960)
[2024/8/7 9:26:20 062] [atbm_log]:not support ldpc & ht40!
[2024/8/7 9:26:20 062] [atbm_log]:atbm_get_chiptype, chipver=0x5a, g_wifi_chip_type[14]
[2024/8/7 9:26:20 078] [atbm_log]:atbm_before_load_firmware++
[2024/8/7 9:26:20 078] [atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[2024/8/7 9:26:20 078] [atbm_log]:===================~_~====================
[2024/8/7 9:26:20 094] [atbm_log]:atbm_start_load_firmware++
[2024/8/7 9:26:20 094] fwhdr->flags 34353678 sram_addr 9022000
[2024/8/7 9:26:20 094] [1970-01-[atbm_log]:
[2024/8/7 9:26:20 094] ======>>> load WIFI BLE COMB firmware <<<======
[2024/8/7 9:26:20 110] 01 00:00:07] <js[atbm_log]:START DOWNLOAD ICCM=========
[2024/8/7 9:26:20 110] on_parse.c> ==> [atbm_log]:atbm_load_firmware_generic: addr 60000: len 20000
[2024/8/7 9:26:20 110] XMJSON_ParseExVb(526)[ERROR]: Get Vb object error!
[2024/8/7 9:26:20 126] [1970-01-01 00:00:07] <xm_system.c> ==> XMSDK_ParseJson(48)[ERROR]: Parse Vb Failed!
[2024/8/7 9:26:20 143] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(452)[ERROR]: Get Isp object u32Flag error set value 1!
[2024/8/7 9:26:20 144] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(464)[ERROR]: Get Isp object u32Others error set value 0!
[2024/8/7 9:26:20 158] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(476)[ERROR]: Get Isp object CmosPort error set value 0!
[2024/8/7 9:26:20 174] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(488)[ERROR]: Get Isp object splice_mode error set value 0!
[2024/8/7 9:26:20 175] [1970-01-01 00:00:06] MainApp.c(1802) <main>: build @Jul 31 2024 13:28:12
[2024/8/7 9:26:20 191] [1970-01-01 00:00:06] MainApp.c(1710) <SetLogLevel>: set Sofia log level 2 suceess
[2024/8/7 9:26:20 191] [1970-01-01 00:00:06] ==> XMSDK_SetLogLevel(226)[NOTICE]: set xmsdk log 4
[2024/8/7 9:26:20 207] [1970-01-01 00:00:07] xm_log.c(100) <XM_RegisterLogAndInit>: Register Log level 2
[2024/8/7 9:26:20 207] [1970-01-01 00:00:07] xm_hwinfo.c(162) <XM_HwinfoInit>: Sync hwinfo to Hwfile success!
[2024/8/7 9:26:20 223] Get Hw info: AppId [fvijo8jvloagv1gm], license [uuidcaab27b0a838d239], mac[j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:26:20 223] [1970-01-01 00:00:07] utils.c(974) <ReadJsonConfig>: Have not find pClass [DeviceGpio] pNumber [NetStatusLedGpio]
[2024/8/7 9:26:20 239] [1970-01-01 00:00:07] xm_device.c(226) <ParseDeviceJsonFile>: Get g_NetStatusLed [0] failed
[2024/8/7 9:26:20 239] **********************************************************************
[2024/8/7 9:26:20 254] |                      SYSTEM INFO                                       
[2024/8/7 9:26:20 254] |       product type:		RC50X80
[2024/8/7 9:26:20 254] |           DSP chip:		XM550V200
[2024/8/7 9:26:20 254] |          wifi type:		ATBM6062U
[2024/8/7 9:26:20 255] |             HW mac:		90314ba51650
[2024/8/7 9:26:20 270] |        git version:		a590e8b3
[2024/8/7 9:26:20 270] |          make time:		20240731132812
[2024/8/7 9:26:20 270] **********************************************************************
[2024/8/7 9:26:20 286] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(143)[INFO]: SensorSrcFrmRate = 25
[2024/8/7 9:26:20 286] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(137)[INFO]: SensorIFS = 0
[2024/8/7 9:26:20 302] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(156)[INFO]: Vi CapW 2680, CapH 2160, CapX 0, CapY 0
[2024/8/7 9:26:20 302] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 0: size=[3840, 2160] @3
[2024/8/7 9:26:20 319] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 1: size=[640, 360] @3
[2024/8/7 9:26:20 319] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 2: size=[640, 224] @3
[2024/8/7 9:26:20 334] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(406)[INFO]: ISPRsltType
[2024/8/7 9:26:20 334] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(428)[INFO]: ISPRsltType 0[atbm_log]:START DOWNLOAD DCCM=========
[2024/8/7 9:26:20 350] [atbm_log]:atbm_load_firmware_generic: addr 800000: len d000
[2024/8/7 9:26:20 350] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(442)[INFO]: ISPRsltType
[2024/8/7 9:26:20 366] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_Parse4gMoudle(500)[WARN]: Get 4GModule object error!
[2024/8/7 9:26:20 367] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(80)[NOTICE]: ISP=> Svtd: PAL
[2024/8/7 9:26:20 382] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(81)[NOTICE]: ISP=>RsltType: 0
[2024/8/7 9:26:20 382] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(84)[NOTICE]: IRCut: gpio 19534 Swap 0
[2024/8/7 9:26:20 398] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(88)[NOTICE]: Infrared: gpio 0 swap 1
[2024/8/7 9:26:20 398] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(92)[NOTICE]: WLight: gpio 11 swap 0
[2024/8/7 9:26:20 414] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(96)[NOTICE]: IRLight: gpio 10 swap 0
[2024/8/7 9:26:20 430] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(99)[NOTICE]: Vi: sensorIFS=0 sensorFPS=25, capW=2680,capH=2160,capX=0,capY=0
[2024/8/7 9:26:20 430] atbm_log]:START DOWNLOAD BLE SRAM=========
[2024/8/7 9:26:20 430] 39m
[2024/8/7 9:26:20 430] [197[atbm_log]:atbm_load_firmware_generic: addr 9022000: len 10000
[2024/8/7 9:26:20 446] 0-01-01 00:00:07] ==> XMSDK_ParseJson(100)[NOTICE]: ViChn  ImageSize      vbBlk
[2024/8/7 9:26:20 446] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    0  [3840, 2160]    3
[2024/8/7 9:26:20 462] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    1  [ 640,  360]    2
[2024/8/7 9:26:20 462] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    2  [ 640,  224]    2
[2024/8/7 9:26:20 479] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(107)[NOTICE]: VencChn    MaxSize   PreReleaseVb
[2024/8/7 9:26:20 479] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    0   [3840, 2160]	 false
[2024/8/7 9:26:20 495] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    1   [ 640,  360]	 false
[2024/8/7 9:26:20 495] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(116)[NOTICE]: 4GModule: gpio 0 Swap 0
[2024/8/7 9:26:20 511] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: AudioSwap: 0
[2024/8/7 9:26:20 511] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(656)[INFO]: AudioSwap=[0]
[2024/8/7 9:26:20 526] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: HighAdcValue: 0
[2024/8/7 9:26:20 526] [1970-01-01 00:00:07] ==> XMJS[atbm_log]:atbm_after_load_firmware++
[2024/8/7 9:26:20 542] ON_GetInt(570)[I[atbm_log]:alloc urb work
[2024/8/7 9:26:20 542] NFO]: LowAdcValu[atbm_log]:usb:try to flush rx....
[2024/8/7 9:26:20 542] e: 0
[2024/8/7 9:26:20 542] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: IRLightLevel: 0
[2024/8/7 9:26:20 558] [1970-01-01 00:00:07] ==> XMJSON_GetInt(5i2c_write timeout 0x2
[2024/8/7 9:26:20 558] 70)[INFO]: InfraredSwap: 0
[2024/8/7 9:26:20 558] [1970-01-01 00:00:07DEBUG: [libispapp]:Jul  5 2024 16:14:06 ,GENERAL
[2024/8/7 9:26:20 574] DEBUG: Vstd_init	[ PAL ]
[2024/8/7 9:26:20 574] DEBUG: RsltSns0	[ 8 ]
[2024/8/7 9:26:20 574] DEBUG: Dsp:		[0x0][ CHIPV200 ]
[2024/8/7 9:26:20 574] DEBUG: [libsns]:Jul  5 2024 16:13:32 ,GENERAL
[2024/8/7 9:26:20 590] i2c_write timeout 0x2
[2024/8/7 9:26:20 638] [atbm_log]:flush rx[-110][0]
[2024/8/7 9:26:20 638] [atbm_log]:0x1610102c=0x4300a
[2024/8/7 9:26:20 638] [atbm_log]:0x1610102c=0x6300b
[2024/8/7 9:26:20 654] [atbm_log]:0x16101000=0x0
[2024/8/7 9:26:20 654] [atbm_log]:set_block_size=256
[2024/8/7 9:26:20 654] [atbm_log]:mdelay wait wsm_startup_done  !!
[2024/8/7 9:26:20 654] [atbm_log]:firmwareCap 31e9
[2024/8/7 9:26:20 654] [atbm_log]:firmwareCap2 1b8c
[2024/8/7 9:26:20 670] [atbm_log]:wsm_caps.firmwareCap 1b8c31e9 16[atbm_log]:apollo wifi WSM init done.
[2024/8/7 9:26:20 670]    Input buffers: 32 x 1632 bytes
[2024/8/7 9:26:20 670]    Hardware: 7.21
[2024/8/7 9:26:20 687]    WSM firmware [=MODEM=DPLL24M+BLE+plat=4 ApSleep 2GHZ Jan 30 2024 10:58:03], ver: 19514, build: 6431, api: 1060, cap: 0x1B8C31E9 Config[31010]  expection 900c094, ep0 cmd addr 901b340 NumOfStations[0x10] NumOfInterfaces[3]
[2024/8/7 9:26:20 703] [atbm_log]:EFUSE(8)				[0]
[2024/8/7 9:26:20 703] [atbm_log]:EFUSE(I)					[0]
[2024/8/7 9:26:20 703] [atbm_log]:EFUSE(B)			[0]
[2024/8/7 9:26:20 703] i2c_write timeout 0x2
[2024/8/7 9:26:20 703] [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [0]
[2024/8/7 9:26:20 703] [atbm_log]:CAPABILITIES_NVR_IPC              [0]
[2024/8/7 9:26:20 719] [atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[2024/8/7 9:26:20 719] [atbm_log]:CAPABILITIES_WOW                  [0]
[2024/8/7 9:26:20 719] [atbm_log]:CAPABILITIES_NO_BACKOFF           [1]
[2024/8/7 9:26:20 735] [atbm_log]:CAPABILITIES_CFO                  [1]
[2024/8/7 9:26:20 735] [atbm_log]:CAPABILITIES_CHIP_FLAG            [1]
[2024/8/7 9:26:20 735] [atbm_log]:CAPABILITIES_TXCAL                [1]
[2024/8/7 9:26:20 735] [atbm_log]:CAPABILITIES_HIF_TRACE       		[0]
[2024/8/7 9:26:20 751] i2c_write timeout 0x2
[2024/8/7 9:26:20 753] [atbm_log]:CAPABILITIES_FORCE_PM_ACTIVE      [0]
[2024/8/7 9:26:20 753] [atbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[2024/8/7 9:26:20 753] DEBUG: SC[atbm_log]:CAPABILITIES_ETF                  [1]
[2024/8/7 9:26:20 753] 831HAI! Chn:0
[2024/8/7 9:26:20 767]  tbm_log]:CAPABILITIES_BLE		  			[1]
[2024/8/7 9:26:20 767] [m[atbm_log]:CAPABILITIES_40M			  		[0]
[2024/8/7 9:26:20 767] [atbm_log]:CAPABILITIES_LDPC 		  		[0]
[2024/8/7 9:26:20 767] [atbm_log]:CAPABILITIES_NAV_ENABLE              [0]
[2024/8/7 9:26:20 783] [atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [0]
[2024/8/7 9:26:20 783] [atbm_log]:CAPABILITIES_USE_IPC              [1]
[2024/8/7 9:26:20 783] [atbm_log]:CAPABILITIES_OUTER_PA             [0]
[2024/8/7 9:26:20 783] [atbm_log]:CAPABILITIES_WFA    [0]
[2024/8/7 9:26:20 799] DEBUG: Is[atbm_log]:CAPABILITIES_EAP_GROUP_REKEY  [0]
[2024/8/7 9:26:20 799] pNum[1]
[2024/8/7 9:26:20 799] atbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[2024/8/7 9:26:20 814] 35mDEBUG: IspChn[atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[2024/8/7 9:26:20 815] :[ 0  tbm_log]:CAPABILITIES_RXCAL       [1]
[2024/8/7 9:26:20 815] [m]
[2024/8/7 9:26:20 815]  tbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[2024/8/7 9:26:20 830] [1;35mDEBUG: I2C[atbm_log]:CAPABILITIES_80211_TO_8023 [1]
[2024/8/7 9:26:20 831] Chn:[ [atbm_log]:CAPABILITIES_NEW_CHIPER  [1]
[2024/8/7 9:26:20 831] 0 ]
[2024/8/7 9:26:20 831]  tbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [0]
[2024/8/7 9:26:20 847] [mDEBUG: [atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[2024/8/7 9:26:20 847] limitedUp: no
[2024/8/7 9:26:20 847] atbm_log]:LMAC NOT SUPPORT 40M !!!
[2024/8/7 9:26:20 847] mDEBUG: --------[atbm_log]:LMAC NOT SUPPORT LDPC !!!
[2024/8/7 9:26:20 847] -----SC831Hai 4K 30fps init ok! (20240322)-------------
[2024/8/7 9:26:20 862] DEBUG: camera_set_saved_status OK!
[2024/8/7 9:26:20 862] DEBUG: [libautoscene]:Jul  5 2024 16:13:42 ,GENERAL
[2024/8/7 9:26:20 862] DEBUG: [libautoscene]:use libfvideo!
[2024/8/7 9:26:20 878] DEBUG: [libfvideo]:Jul  5 2024 15:41:09 
[2024/8/7 9:26:20 878] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:26:20 878] DEBUG: [libsdnc]:Aug 22IspKo: clean cut!
[2024/8/7 9:26:20 878]  2023 13:55:14
[2024/8/7 9:26:20 894] DEBUG: LED: [IR] 
[2024/8/7 9:26:20 895] DEBUG: software LED
[2024/8/7 9:26:20 895] DEBUG: hardware pohtoR!
[2024/8/7 9:26:20 895] DEBUG: isp_sample over!
[2024/8/7 9:26:20 895] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:26:20 910] ] ==> XMJSON_GetInt(570)[INFO]: WhiteLightLevel: 0
[2024/8/7 9:26:20 910] [1970-01-01 00:00:07] xm_main.c(345) <AutoMaintenance_pro>: Set device auto mantenance time: -001_-1_-1 02:25:26 wenkday: Tuesday
[2024/8/7 9:26:20 926] [1970-01-01 00:00:07] utils.c(7IspKo: set cut 0x0 0xf00 0x1 0x871
[2024/8/7 9:26:20 926] 60) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:26:20 942] [1970-01-01 00:00:07] xm_main.c(349) <AutoMaintenance_pro>: Get Last AutoMantence Date [] failed
[2024/8/7 9:26:20 942] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoHorizontalFlipGun: 0
[2024/8/7 9:26:20 958] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoVerticalFlipGun: 0
[2024/8/7 9:26:20 958] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: setMonocular: 1
[2024/8/7 9:26:20 974] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedX: 17
[2024/8/7 9:26:20 974] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedY: 17
[2024/8/7 9:26:20 990] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: soundValue: 50
[2024/8/7 9:26:20 990] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: lightChannel: 0
[2024/8/7 9:26:21 006] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: dayAndNightMode: 0
[2024/8/7 9:26:21 006] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: hardAndSoftLight: 1
[2024/8/7 9:26:21 022] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeX: 400
[2024/8/7 9:26:21 022] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeY: 200
[2024/8/7 9:26:21 039] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(587)[INFO]: RatioOfGear: 1:1
[2024/8/7 9:26:21 039] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(593)[INFO]: high 1: low 1
[2024/8/7 9:26:21 055] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(690)[INFO]: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:26:21 055] [1970-01-01 [atbm_log]:wsm_generic_confirm:status(2)
[2024/8/7 9:26:21 055] 00:00:07] xm_mai[atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[2024/8/7 9:26:21 071] n.c(462) <GetVideoResolution>: V[atbm_log]:apollo wifi : can't open /data/.mac.info
[2024/8/7 9:26:21 071] ideo resolution:[atbm_log]:efuse data is [0x1,0x38,0x15,0x16,0x16,0x8,0x0,0x0,0x90:0x31:0x4b:0xa5:0x16:0x50]
[2024/8/7 9:26:21 086]  captrue width 2680 heig[atbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[2024/8/7 9:26:21 087] ht 2160 resolution main: width 3[atbm_log]:win txpower:0840 height 2160 
[2024/8/7 9:26:21 102] [atbm_log]:use default power
[2024/8/7 9:26:21 102] extra:  width 640 height 360 [2]: width 640 height 224
[2024/8/7 9:26:21 103] [1970-01-01 00:00:07] MainApp.c(1812) <main>: version , date 20240724, time 182054, plus 0
[2024/8/7 9:26:21 118] [1970-01-01 00:00:07] ==> XMSDK_StartUp(174)[INFO]: XMSDK_StartUp enter, Jul 24 2024, 18:20:55
[2024/8/7 9:26:21 118] [1970-01-01 00:0[atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[2024/8/7 9:26:21 134] 0:07] ==> IspCon[atbm_log]:==read success==
[2024/8/7 9:26:21 134] figInit(158)[INF[atbm_log]:set delta power
[2024/8/7 9:26:21 135] O]: maxHeight 2160 maxWidth 3840 u32RsltType 8
[2024/8/7 9:26:21 150] [1970-01-01 00:00:07] ==> XMSDK_StartUp(203)[INFO]: g_stProductMgr.viMgr.capW =[2680] g_stProductMgr.viM[atbm_log]:get chip id [0][0][0] 
[2024/8/7 9:26:21 151] gr.capH = [2160][atbm_log]:current chiptype ATBM6062-U20-noLDPC 
[2024/8/7 9:26:21 166] [1970-[atbm_log]:default country code:00,support channel=14
[2024/8/7 9:26:21 166] 01-01 00:00:07] [atbm_log]:Use an internal power amplifier!
[2024/8/7 9:26:21 182] ==> XMSDK_StartUp(220)[INFO]: g_stProduc[atbm_log]:enable sg
[2024/8/7 9:26:21 182] tMgr.vencMgr.ven[atbm_log]:[eth2] has been disabled
[2024/8/7 9:26:21 182] cChn[0].maxHeight =[2160] g_stProductMgr.encMgr.vencChn[0].maxWidth = [3840]
[2024/8/7 9:26:21 198] [1970-01-01 00:00:07] ==> XMSDK_StartUp(286)[INFO]: ispCfg.u32Others 0x0
[2024/8/7 9:26:21 198] [atbm_log]:enable sg
[2024/8/7 9:26:21 198] [1970-01-01 00:0[atbm_log]:[p2p0] has been disabled
[2024/8/7 9:26:21 214] 0:07] ==> XMSDK_StartUp(288)[INFO]: ispCfg.u32FunExt 0x0 u32Infrared 0x80000000 u32snsRsltType 0x0 u32RsltType 0x8 au32IrCut 0x80004c4e  au32SoftLed[0]: 0x800b0a11 u32Flag: 0x1 SensorRstIO: 0x800000a4 u32Coms[atbm_log]:ble start
[2024/8/7 9:26:21 230] Port: 0x0
[2024/8/7 9:26:21 230] [1970[atbm_log]:[ALTOBEAM-ble_recv] start
[2024/8/7 9:26:21 230] -01-01 00:00:08][atbm_log]:ble subscribe
[2024/8/7 9:26:21 230]  ==> SampleCreat[atbm_log]:[ALTOBEAM-ble_xmit] start
[2024/8/7 9:26:21 246] e(1709)[INFO]: v[atbm_log]:ble_platform_probe(c1e1a240)
[2024/8/7 9:26:21 246] iChn:0 vstd:0 en[atbm_log]:is registered as 'ALTOBEAM'
[2024/8/7 9:26:21 246] ter
[2024/8/7 9:26:21 246] atbm_log]:[atbm_wtd]:set wtd_probe = 1
[2024/8/7 9:26:21 262] 32m[1970-01-01 0usbcore: registered new interface driver atbm_wlan
[2024/8/7 9:26:21 262] 0:00:08] ==> ViChnConfig(866)[INFO]: set vichn 0 size [3840, 2160]
[2024/8/7 9:26:21 278] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 1 size [640, 360]
[2024/8/7 9:26:21 278] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 2 size [640, 224]
[2024/8/7 9:26:21 294] [1970-01-01 00:00:08] ==> VencChCreate(1058)[INFO]: channel:0 enter
[2024/8/7 9:26:21 295] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[0].vencMem = VENCMEM_MICRO
[2024/8/7 9:26:21 310] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 0,width = 3840,height = 2160,enType = 265
[2024/8/7 9:26:21 310] NORM ENC MODE
[2024/8/7 9:26:21 310] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[1].vencMem = VENCMEM_MICRO
[2024/8/7 9:26:21 326] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 1,width = 640,height = 360,enType = 265
[2024/8/7 9:26:21 326] NORM ENC MODE
[2024/8/7 9:26:21 326] aec 1; agc 1; ans 1
[2024/8/7 9:26:21 342] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 21,DestChnId = 0,DestModId = 23
[2024/8/7 9:26:21 342] [1970-01-01 00:00:08] ==> AudioCreate(1656)[INFO]: XM_AENC_CreateCH OK
[2024/8/7 9:26:21 358] [1970-01-01 00:00:08] ==> AudioCreate(1685)[INFO]: XM_MPI_ADEC_CreateChn OK
[2024/8/7 9:26:21 358] [1970-01-01 00:00:08] ==> DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:26:21 358] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:26:21 374] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:26:21 374] DEBUG: software pohtoR!
[2024/8/7 9:26:21 374] DEBUG: camera_set_photosensitive_chn 0 1 0x1
[2024/8/7 9:26:21 390] SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 24,DestChnId = 0,DestModId = 22
[2024/8/7 9:26:21 390] [1970-01-01 00:00:08] ==> JPEGChCreate(1556)[INFO]: enter JPEGChCreate channel=0, VencChn = 3
[2024/8/7 9:26:21 406] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 3,width = 640,height = 360,enType = 26
[2024/8/7 9:26:21 406] [1970-01-01 00:00:08] ==> COMM_VENC_Start(913)[INFO]: set JpegAttr
[2024/8/7 9:26:21 422] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 1,SrcModId = 7,DestChnId = 3,DestModId = 7
[2024/8/7 9:26:21 439] [1970-01-01 00:00:08] ==> COMM_VENC_Start(1032)[INFO]: JPEG_CHN[3] bind VENC_CHN[1] success!.
[2024/8/7 9:26:21 455] [1970-01-01 00:00:08] MainApp.c(1816) <main>: [1970-01-01 00:00:08] MainApp.c(1823) <main>: [1970-01-01 00:00:08] MainApp.c(1883) <main>: g_fps=[12]
[2024/8/7 9:26:21 455] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:26:21 470] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=0,brc=1,w=3840,h=2160,qua=4,frame=12,br=1000,gop=4
[2024/8/7 9:26:21 471] 
[2024/8/7 9:26:21 487] [1970-01-01 00:00:08] xm_main.c(700) <XM_SetCameraFactoryConfig>: Get AutoMantence flags [0] failed
[2024/8/7 9:26:21 487] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[0],wh[3840,2160]-----------
[2024/8/7 9:26:21 502] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:26:21 518] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=1,brc=1,w=640,h=360,qua=4,frame=9,br=256,gop=1
[2024/8/7 9:26:21 519] 
[2024/8/7 9:26:21 519] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[1],wh[640,360]-----------
[2024/8/7 9:26:21 534] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:26:21 534] [1970-01-01 00:00:08] MainApp.c(1885) <main>: [1970-01-01 00:00:08] MainApp.c(1893) <main>: 
[2024/8/7 9:26:21 551] [1970-01-01 00:00:08] MainApp.c(1898) <main>: 
[2024/8/7 9:26:21 551] [1970-01-01 00:00:08] xm_main.c(1899) <PtzControl_Pro>: 
[2024/8/7 9:26:21 566] PtzControl_Pro[1970-01-01 00:00:08] ==> XMSDK_MotorCreate(120)[INFO]: xlimit 5006, ylimit 2161
[2024/8/7 9:26:21 566] [1970-01-01 00:00:08] xm_main.c(1903) <PtzControl_Pro>: g_sPtz.xMaxStep 5006 g_sPtz.yMaxStep 2161 
[2024/8/7 9:26:21 582] [1970-01-01 00:00:08] xm_main.c(1747) <XM_RealVideo_Pro>: realy video play start___0
[2024/8/7 9:26:21 582] [1970-01-01 00:00:08] xm_main.c(1375) <XM_RealAudio_Pro>: real Audio play start___
[2024/8/7 9:26:21 598] [1970-01-01 00:00:08] ==> AudioInSetFormat(68)[INFO]: pFormat.EncodeTye = 2
[2024/8/7 9:26:21 598] [1970-01-01 00:00:08] ==> XMSDK_AudioInSetFormat(445)[INFO]: anr(1) agc(1) aec(0)
[2024/8/7 9:26:21 598] aec 0; agc 1; ans 1
[2024/8/7 9:26:21 614] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:26:21 614] [1970-01-01 00:00:08] xm_main.c(821) <XM_SetCameraFactoryConfig>: get default language ChineseEnglish
[2024/8/7 9:26:21 630] [1970-01-01 00:00:08] xm_main.c(822) <XM_SetCameraFactoryConfig>: get defult IRcurt reverse: no picture reverse mirror:yes filp:yes
[2024/8/7 9:26:21 646] [1970-01-01 00:00:08] xm_main.c(823) <XM_SetCameraFactoryConfig>: set defult motor ptz reverse  mirror:yes filp:no
[2024/8/7 9:26:21 646] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:26:21 663] [1970-01-01 00:00:08] xm_main.c(824) <XM_SetCameraFactoryConfig>: get defult autotrack motor reverse mirror:yes filp:no
[2024/8/7 9:26:21 663] [1970-01-01 00:00:08] xm_main.c(825) <XM_SetCameraFactoryConfig>: get defult ptz preset x:1556 y:950
[2024/8/7 9:26:21 678] [1970-01-01 00:00:08] xm_main.c(920) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:26:21 695] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:26:21 695] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 0
[2024/8/7 9:26:21 711] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 0 OK
[2024/8/7 9:26:21 726] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 1
[2024/8/7 9:26:21 728] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 1 OKatbm_log]:ioctl_open(c1e1ba00)(c1e1a240)
[2024/8/7 9:26:21 728] 39m
[2024/8/7 9:26:21 742] [1970-[atbm_log]:atbm_ioctl_ble_start
[2024/8/7 9:26:21 742] 01-01 00:00:08] xm_main.c(969) <XM_SetCameraFactoryConfig>: get factory language ChineseEnglish
[2024/8/7 9:26:21 742] [DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:26:21 759] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:26:21 759] DEBUG: camera_set_photosensitive_chn 0 0 0x1
[2024/8/7 9:26:21 759] killall: hostapd: no process killed
[2024/8/7 9:26:21 774] ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!DEBUG: camera_set_ledType:  2
[2024/8/7 9:26:21 774] DEBUG: camera_set_dnc_mode_chn 3 
[2024/8/7 9:26:21 774] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:26:21 790] DEBUG: LED: [IR] [WL] 
[2024/8/7 9:26:21 790] DEBUG: software LED
[2024/8/7 9:26:21 790] DEBUG: software pohtoR!
[2024/8/7 9:26:21 790] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:26:21 790] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:26:21 806] DEBUG: camera_set_ledHold: 60000
[2024/8/7 9:26:21 806] 1970-01-01 00:00:08] xm_main.c(970) <XM_SetCameraFactoryConfig>: get factory IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:26:21 822] [1970-01-01 00:00:08] xm_main.c(971) <XM_SetCameraFactoryConfig>: set factory motor ptz reverse  mirror:yes filp:yes
[2024/8/7 9:26:21 838] [1970-01-01 00:00:08] xm_main.c(972) <XM_SetCameraFactoryConfig>: get factory autotrack motor reverse mirror:no filp:no
[2024/8/7 9:26:21 838] [1970-01-01 00:00:08] xm_main.c(973) <XM_SetCameraFactoryConfig>: get factory ptz preset x:3110 y:0
[2024/8/7 9:26:21 854] [1970-01-01 00:00:08] xm_main.c(1007) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:26:21 870] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:26:21 886] [1970-01-01 00:00:08] xm_main.c(1040) <XM_SetCameraFactoryConfig>: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:26:21 886] [1970-01-01 00:00:08] xm_main.c(1060) <XM_SetCameraFactoryConfig>: set IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:26:21 903] [1970-01-01 00:00:08] xm_main.c(1078) <XM_SetCameraFactoryConfig>: camera_set_softIr_thr(1) ret=[0]
[2024/8/7 9:26:21 918] [1970-01-01 00:00:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[597],val=[1]
[2024/8/7 9:26:21 919] 
[2024/8/7 9:26:21 919] ************last intra 0
[2024/8/7 9:26:21 919] [1970-01-01 00:00:08] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time8281
[2024/8/7 9:26:21 934] [1970-01-01 00:00:08] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 2024
[2024/8/7 9:26:21 934] [1970-01-01 00:00:08] MainApp.c(1900) <main>: 
[2024/8/7 9:26:21 934] [1970-01-01 00:00:08] MainApp.c(1905) <main>: 
[2024/8/7 9:26:21 950] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:Register pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:26:21 966] [1970-01-01 00:00:08] ==> XMSDK_AudioSetSpeakerVol(641)[INFO]: enter: Speaker Open
[2024/8/7 9:26:21 966] [1970-01-01 00:00:08] MainApp.c(1913) <main>: 
[2024/8/7 9:26:21 982] [1970-01-01 00:00:08] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 2216
[2024/8/7 9:26:21 982] [1970-01-01 00:00:08] ==> XMSDK_WifiInit(601)[INFO]: Wifi Init success
[2024/8/7 9:26:21 982] [1970-01-01 00:00:08] MainApp.c(1915) <main>: 
[2024/8/7 9:26:21 998] [1970-01-01 00:00:08] MainApp.c(1918) <main>: 
[2024/8/7 9:26:21 998] lib_ble_main_init
[2024/8/7 9:26:21 998] ======>>atbm_ble_start>>>
[2024/8/7 9:26:21 998] nimble_port_init++
[2024/8/7 9:26:21 998] nimble_host_task
[2024/8/7 9:26:21 998] ble_coexist_start--
[2024/8/7 9:26:21 998] ble_hs_sync:333
[2024/8/7 9:26:21 998] hif_ioctl_loop
[2024/8/7 9:26:22 014] ble_smart_cfg_startup!11
[2024/8/7 9:26:22 014] [ATBM lOG]set default tx power(0)
[2024/8/7 9:26:22 014] pub addr 90:31:4b:a5:16:51
[2024/8/7 9:26:22 014] [1970-01-01 00:00:08] MainApp.c(1922) <main>: ble_ret=[0]
[2024/8/7 9:26:22 030] [1970-01-01 00:00:08] MainApp.c(1200) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 030] [1970-01-01 00:00:08] MainApp.c(1229) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 046] [1970-01-01 00:00:08] MainApp.c(1258) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 046] [1970-01-01 00:00:08] MainApp.c(1260) <GetAndSetTyDefalutConfig>: SMLMode=[2]
[2024/8/7 9:26:22 063] [1970-01-01 00:00:08] MainApp.c(1263) <GetAndSetTyDefalutConfig>: g_SMLAbility=[0]
[2024/8/7 9:26:22 063] [1970-01-01 00:00:08] MainApp.c(1266) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 063] [1970-01-01 00:00:08] MainApp.c(1338) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 078] [1970-01-01 00:00:08] MainApp.c(1346) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 078] [1970-01-01 00:00:08] MainApp.c(1357) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 094] [1970-01-01 00:00:08] MainApp.c(1387) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 095] [1970-01-01 00:00:08] MainApp.c(1390) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:22 095] [1970-01-01 00:00:08] xm_ai.c(564) <XM_CreatePersionDetect>: 
[2024/8/7 9:26:22 110] [1970-01-01 00:00:08] xm_ai.c(574) <XM_CreatePersionDetect>: 
[2024/8/7 9:26:22 110] [1970-01-01 00:00:08] xm_ai.c(585) <XM_CreatePersionDetect>: 
[2024/8/7 9:26:22 126] [1970-01-01 00:00:08] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:26:22 126] [1970-01-01 00:00:08] xm_ai.c(588) <XM_CreatePersionDetect>: 
[2024/8/7 9:26:22 126] [1970-01-01 00:00:08] xm_ai.c(608) <XM_CreatePersionDetect>: 
[2024/8/7 9:26:22 142] [1970-01-01 00:00:08] xm_ai.c(645) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:26:22 223] [1970-01-01 00:00:08] xm_ai.c(646) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:08] xm_ai.c(647) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTime = [ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!ListMng - BufListCreate: index 1 OK
[2024/8/7 9:26:23 214] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:26:23 214] Mode(Product):0
[2024/8/7 9:26:23 214] BpuMode:[Online]
[2024/8/7 9:26:23 214] VpssMode:[Online]
[2024/8/7 9:26:23 214] [0.LimitUp_info]:
[2024/8/7 9:26:23 230] LimitUp:[Disable]
[2024/8/7 9:26:23 230] [2680*0]->[3840*0])
[2024/8/7 9:26:23 230] chn	TotalSize	ActiveSize
[2024/8/7 9:26:23 230] 0	5040*2246	2680*2160
[2024/8/7 9:26:23 230] 0	5040*2246	3840*2160
[2024/8/7 9:26:23 230] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:26:23 230] [1.VICU_info]:
[2024/8/7 9:26:23 246] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:26:23 246] 0	25.0	59	0	0	183	linear	8ddb00
[2024/8/7 9:26:23 246] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:26:23 246] en	op_type	m_chn	now
[2024/8/7 9:26:23 246] 0	1	1	1
[2024/8/7 9:26:23 246] [2.VI_info]:
[2024/8/7 9:26:23 262] chn	TotalSize	ActiveSize
[2024/8/7 9:26:23 262] 0	5040*2246	3848*2166
[2024/8/7 9:26:23 262] 1	   0*   0	   0*   0
[2024/8/7 9:26:23 262] [3.MIPI_info]:
[2024/8/7 9:26:23 262] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:26:23 278] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:26:23 278] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:26:23 278] [4.Cut_info]:
[2024/8/7 9:26:23 278] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:26:23 278] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:26:23 294] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:26:23 294] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:26:23 294] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:26:23 294] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:26:23 294] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:26:23 294] [5.IB(isp buffer info)]:
[2024/8/7 9:26:23 310] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:26:23 310] PoolId  Count  Size
[2024/8/7 9:26:23 310] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:23 326] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:23 326] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:23 342] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:23 342] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:23 343] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:23 358] DEBUG: autoscene chn[0]: Bw!
[2024/8/7 9:26:23 358] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:26:23 358] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:26:23 374] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:26:23 374] 0       0         0          0          4       
[2024/8/7 9:26:23 374] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:26:23 390]      --265--            --264--                                               
[2024/8/7 9:26:23 390] Count      Line     Count      Line     
[2024/8/7 9:26:23 390] 28         437      71         560      
[2024/8/7 9:26:23 406] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:26:23 406] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:26:23 422] 0   3840   2160    H265  0      0        0           15        942907     40133    	
[2024/8/7 9:26:23 423] 1   640    360     H265  0      0        0           13        43200      0        	
[2024/8/7 9:26:23 423] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:26:23 438] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:26:23 454] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:26:23 454] 0   Y      15       0       0       14       1        14       14       26        63523         59724    79446    64775    0       
[2024/8/7 9:26:23 470] 1   Y      13       0       0       1        0        13       13       28        3104          1999     34379    5436     0       
[2024/8/7 9:26:23 486] 3   N      0        0       0       1        0        0        0        29        0             0        0        0        0       
[2024/8/7 9:26:23 487] 8];src/ped_thread.c(746) [Smart_Ped_Create]: Smart_Ped_Create_ver: Jul 24 2024 18:21:40
[2024/8/7 9:26:23 502] src/ped_thread.c(656) [Ped_Init_IA_Work]: Ped_Init_IA_Work start ver:Jul 24 2024 18:21:40
[2024/8/7 9:26:23 502] [FUNC: IA_InitLog] Creat OK.
[2024/8/7 9:26:23 502] [INIT]: XM_IA_Init() done.
[2024/8/7 9:26:23 518] src/ped_thread.c(705) [Ped_Init_IA_Work]: ruler 0 region (0,0) (0,0) (0,0) (0,0)
[2024/8/7 9:26:23 518] [INIT]:LIBXMIA IAtype 700 Complied at May  8 2024 08:39:39 GIT_ID:cb3a4ed0
[2024/8/7 9:26:23 534] [INIT]: TD Version: TD_V_3.2.4.2[May 15 2024 19:14:32]
[2024/8/7 9:26:23 534] -- TD INIT -- 
[2024/8/7 9:26:23 534]  uiTdMaxNum: 12 
[2024/8/7 9:26:23 534]  acClassBinPath: /usr/bin 
[2024/8/7 9:26:23 534]  ePlatForm: 50 
[2024/8/7 9:26:23 534]  eDevImgType: 17 
[2024/8/7 9:26:23 534]  stDevImgSize: (2680,2160) 
[2024/8/7 9:26:23 534]  iTrackFlag: 1 
[2024/8/7 9:26:23 534]  iTrackType: 2 
[2024/8/7 9:26:23 534] -- TD EXTF -- 
[2024/8/7 9:26:23 550]  ucPedFallDownEnable: 0
[2024/8/7 9:26:23 550]  ucTDFeatureEnable: 0
[2024/8/7 9:26:23 550]  ucSmokeEnable: 0
[2024/8/7 9:26:23 550]  ucFaceDetEnable: 0
[2024/8/7 9:26:23 550]  ucFaceMaskEnable: 0
[2024/8/7 9:26:23 550]  ucFaceAngEnable: 0
[2024/8/7 9:26:23 550]  ucFaceRegEnable: 0
[2024/8/7 9:26:23 550]  ucPlateDetEnable: 0
[2024/8/7 9:26:23 567]  ucPlateRegEnable: 0
[2024/8/7 9:26:23 567]  ucPedPointEnable: 0
[2024/8/7 9:26:23 567]  ucHandPointEnable: 0
[2024/8/7 9:26:23 567]  ucHelmetEnable: 0
[2024/8/7 9:26:23 567]  ucHandgestureEnable: 0
[2024/8/7 9:26:23 567]  efdfreq: 10
[2024/8/7 9:26:23 567] [INIT]: XM_IA_TD_PED_S Version: 20230719_person_noexp_v200
[2024/8/7 9:26:23 582] [INIT] Alg Malloc Size 27232
[2024/8/7 9:26:23 582] -- TD CFG --  
[2024/8/7 9:26:23 582]  iMDFlag: 0
[2024/8/7 9:26:23 582]  ucDetectDisable: 0
[2024/8/7 9:26:23 582]  iDetectType: 5
[2024/8/7 9:26:23 582]  ePattern: 3
[2024/8/7 9:26:23 582]  eSensitivity: 2
[2024/8/7 9:26:23 582]  ucFishEyeCorrectFlag:0
[2024/8/7 9:26:23 582]  eRotate:0
[2024/8/7 9:26:23 582]  ucSationaryTd: 0
[2024/8/7 9:26:23 598]  ucClearnessFlg:0
[2024/8/7 9:26:23 598]  usInImgWidth:0
[2024/8/7 9:26:23 598]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:26:23 598] [CFG]: Rule:0 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:26:23 614] [CFG]: Rule:1 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:26:23 614] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:26:23 631] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:26:23 631] [CFG]: DEFAULT iBoundaryPtsNum 4 eAlarmDirect 2 (0 0) (8191 0) (8191 8191) (0 8191)
[2024/8/7 9:26:23 631] [FUNC:PbdcnnConfig][L:578] (nil) 0xbe8ac2f8 Pointer Null.
[2024/8/7 9:26:23 646] [INIT]: PdConfig pvHandle 0xb1209000. Config OK
[2024/8/7 9:26:23 646] [INIT] Alg Malloc Size 30000
[2024/8/7 9:26:23 646] [1970-01-01 00:00:09] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 4921
[2024/8/7 9:26:23 662] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:26:23 678] [1970-01-01 00:00:09] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 12674
[2024/8/7 9:26:23 678] [1970-01-01 00:00:09] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 16703
[2024/8/7 9:26:23 678] [INIT]:memPoolSize 1351680.
[2024/8/7 9:26:23 694] V1.6.x date Sep  5 2023, time 23:32:25 npu load start
[2024/8/7 9:26:23 694] dpu version v1.1.0 build time Aug  5 2022
[2024/8/7 9:26:23 694] [INIT]: Update MemPoolSize 0 to 1351680.
[2024/8/7 9:26:23 694] [INIT]: MmzAlloc MemPoolSize 1351680 0xb1047000~0xb1191000.
[2024/8/7 9:26:23 710] 0 Model 0x25f0574 MemPoolIdx 0 MemPoolInfo 0x6d5f10
[2024/8/7 9:26:23 710] [INIT]: version 20230719_person_noexp_v200, debug 0, profile 0
[2024/8/7 9:26:23 710] [INIT] Alg Malloc Size 240736
[2024/8/7 9:26:23 726] CNNMemory: 2064977 bulk 240736 mmz 1824241
[2024/8/7 9:26:23 726] CNNINIT INPUT IMAGESIZE:(640,224)
[2024/8/7 9:26:23 726] TD_DETECT stAlgImgSize (640,224) 
[2024/8/7 9:26:23 726] [INIT] Alg Malloc Size 60672
[2024/8/7 9:26:23 726] MdInit ok![INIT] Alg Malloc Size 79704
[2024/8/7 9:26:23 742] [FUNC: trackInit][L: 273] API_Creat_IMG 
[2024/8/7 9:26:23 742] [INIT]: PdInit pvHandle 0x25f0318 *pvHandle 0xb1209000 OK
[2024/8/7 9:26:23 742] IA_LOG 87c6a000 value 0
[2024/8/7 9:26:23 742] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:26:23 742] Ped_Init_IA_Work end 
[2024/8/7 9:26:23 758] src/ped_thread.c(774) [Smart_Ped_Create]: Create list success, index 1 maxsize 2
[2024/8/7 9:26:23 758] src/ped_thread.c(495) [PedProc_v2]: 
[2024/8/7 9:26:23 758] src/ped_thread.c(520) [PedProc_v2]: 
[2024/8/7 9:26:23 774] [FUNC: DetectTarget][L: 1489] API_Creat_IMG_MdInImg 
[2024/8/7 9:26:23 774] [FUNC: PbdcnnWork][L: 1084] API_Creat_CSCIMG 
[2024/8/7 9:26:23 774] [1970-01-01 00:00:09] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 39864
[2024/8/7 9:26:23 790] [1970-01-01 00:00:09] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 72226
[2024/8/7 9:26:23 790] [1970-01-01 00:00:09] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 91837
[2024/8/7 9:26:23 806] [1970-01-01 00:00:09] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 111041
[2024/8/7 9:26:23 806] [1970-01-01 00:00:09] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 124284
[2024/8/7 9:26:23 822] [1970-01-01 00:00:10] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:26:23 822] src/ped_thread.c(803) [Smart_Ped_Create]: Ped_Creat Success @0x39e24
[2024/8/7 9:26:23 838] [1970-01-01 00:00:10] xm_ai.c(649) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:26:23 870] [1970-01-01 00:00:10] xm_ai.c(657) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:10] xm_ai.c(658) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTime = [[MMZ] BUILD TIME:[Jul 14 2021 15:42:31]
[2024/8/7 9:26:23 870] [0x83400000--------0x88000000]
[2024/8/7 9:26:23 870] --START-----------SIZE----------------OVERFLOW----NAME---------------
[2024/8/7 9:26:23 886] 0x83400000	0xbde000  (12152k)	0	vb[bdd800][0]
[2024/8/7 9:26:23 886] 0x83fde000	0xbde000  (12152k)	0	vb[bdd800][1]
[2024/8/7 9:26:23 886] 0x84bbc000	0xbde000  (12152k)	0	vb[bdd800][2]
[2024/8/7 9:26:23 886] 0x8579a000	0x55000   (  340k)	0	vb[54600][0]
[2024/8/7 9:26:23 902] 0x857ef000	0x55000   (  340k)	0	vb[54600][1]
[2024/8/7 9:26:23 902] 0x85844000	0x35000   (  212k)	0	vb[34800][0]
[2024/8/7 9:26:23 902] 0x85879000	0x35000   (  212k)	0	vb[34800][1]
[2024/8/7 9:26:23 902] 0x858ae000	0x24000   (  144k)	0	isp_nr_alpha_ch0
[2024/8/7 9:26:23 918] 0x858d2000	0x163000  ( 1420k)	0	isp_nr_idx_ch0
[2024/8/7 9:26:23 918] 0x85a35000	0x1000    (    4k)	0	isp_nr_idx_max_ch0
[2024/8/7 9:26:23 918] 0x85a36000	0x84f000  ( 8508k)	0	isp_nr_fetch_ch0
[2024/8/7 9:26:23 918] 0x86285000	0x2000    (    8k)	0	isp_defog_ch0
[2024/8/7 9:26:23 934] 0x86287000	0xc24000  (12432k)	0	vencRfcFrame[0]
[2024/8/7 9:26:23 934] 0x86eab000	0xc24000  (12432k)	0	vencRfcFrame[1]
[2024/8/7 9:26:23 934] 0x87acf000	0xf1000   (  964k)	0	stream_chn[0]
[2024/8/7 9:26:23 934] 0x87bc0000	0x4c000   (  304k)	0	vencWrapLuma[0]
[2024/8/7 9:26:23 950] 0x87c0c000	0x26000   (  152k)	0	vencWrapChroma[0]
[2024/8/7 9:26:23 950] 0x87c32000	0xb000    (   44k)	0	stream_chn[1]
[2024/8/7 9:26:23 950] 0x87c3d000	0x2b000   (  172k)	0	stream_chn[3]
[2024/8/7 9:26:23 950] 0x87c68000	0x1000    (    4k)	0	osd_block[0]
[2024/8/7 9:26:23 966] 0x87c69000	0x1000    (    4k)	0	osd_block[4]
[2024/8/7 9:26:23 966] 0x87c6a000	0x1000    (    4k)	0	IA_LOG
[2024/8/7 9:26:23 966] 0x87c6b000	0x7000    (   28k)	0	IA_MANAGE_1
[2024/8/7 9:26:23 966] 0x87c72000	0x8000    (   32k)	0	IA_MANAGE_2
[2024/8/7 9:26:23 982] 0x87c7a000	0x70000   (  448k)	0	firm_mem_0
[2024/8/7 9:26:23 982] 0x87cea000	0x14b000  ( 1324k)	0	mempool_1
[2024/8/7 9:26:23 982] 0x87e35000	0x1000    (    4k)	0	dst_mem_1
[2024/8/7 9:26:23 982] 0x87e36000	0x1000    (    4k)	0	dst_mem_2
[2024/8/7 9:26:23 998] 0x87e37000	0x3000    (   12k)	0	dst_mem_3
[2024/8/7 9:26:23 998] 0x87e3a000	0x1000    (    4k)	0	dst_mem_4
[2024/8/7 9:26:23 998] 0x87e3b000	0x14000   (   80k)	0	IA_MANAGE_3
[2024/8/7 9:26:23 998] 0x87e4f000	0x35000   (  212k)	0	IA_Image_1
[2024/8/7 9:26:24 014] 0x87e84000	0x6a000   (  424k)	0	IA_Image_2
[2024/8/7 9:26:24 014] 0x87eee000	0x112000  ( 1096k)	1	
[2024/8/7 9:26:24 014] ---------------------------------------------------------------------
[2024/8/7 9:26:24 014] SIZE: 0x4c00000(77824k)  USED: 0x4aee000(76728k)  FREE: 0x112000(1096k)
[2024/8/7 9:26:24 030] 8];[1970-01-01 00:00:10] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:26:24 030] -- TD CFG --  
[2024/8/7 9:26:24 030]  iMDFlag: 0
[2024/8/7 9:26:24 030]  ucDetectDisable: 0
[2024/8/7 9:26:24 030]  iDetectType: 5
[2024/8/7 9:26:24 046]  ePattern: 3
[2024/8/7 9:26:24 046]  eSensitivity: 0
[2024/8/7 9:26:24 046]  ucFishEyeCorrectFlag:0
[2024/8/7 9:26:24 046]  eRotate:0
[2024/8/7 9:26:24 046]  ucSationaryTd: 0
[2024/8/7 9:26:24 046]  ucClearnessFlg:0
[2024/8/7 9:26:24 046]  usInImgWidth:0
[2024/8/7 9:26:24 046]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:26:24 062] [CFG]: Rule:0 ucRuleEnable:1 AlarmType:0 eRuleType:1
[2024/8/7 9:26:24 062] [CFG]: IA_PERIMETER_V1 iBoundaryPtsNum 4 eAlarmDirect 0 (0 0) (8191 0) (8191 8191) (0 8191) [CFG]: Rule:1 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:26:24 078] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:26:24 078] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:26:24 078] [INIT]: PdConfig pvHandle 0xb1209000. Config OK
[2024/8/7 9:26:24 078] IA_LOG 87c6a000 value 0
[2024/8/7 9:26:24 094] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:26:24 094] src/ped_thread.c(831) [Smart_Ped_SetParam]: Ped_SetParam Success
[2024/8/7 9:26:24 094] [1970-01-01 00:00:10] xm_ai.c(666) <XM_CreatePersionDetect>: 
[2024/8/7 9:26:24 110] [1970-01-01 00:00:10] xm_ai.c(674) <XM_CreatePersionDetect>: 
[2024/8/7 9:26:24 110] [1970-01-01 00:00:10] MainApp.c(1395) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:24 126] [1970-01-01 00:00:10] MainApp.c(1397) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:24 126] [1970-01-01 00:00:10] MainApp.c(1402) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:24 126] [1970-01-01 00:00:10] MainApp.c(1481) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:24 142] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 60 enable 0 volume
[2024/8/7 9:26:24 142] [1970-01-01 00:00:10] MainApp.c(1525) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:24 142]  PTZPreset is empty!
[2024/8/7 9:26:24 159]  PTZPreset is empty!
[2024/8/7 9:26:24 159] [1970-01-01 00:00:10] MainApp.c(1554) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:24 174] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:26:24 175] [1970-01-01 00:00:10] MainApp.c(1568) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:24 191] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:26:24 206] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:26:24 207] [1970-01-01 00:00:10] MainApp.c(1584) <GetAndSetTyDefalutConfig>: cruisetime_pro create!
[2024/8/7 9:26:24 222] [1970-01-01 00:00:10] MainApp.c(1607) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:26:24 222] [1970-01-01 00:00:10] MainApp.c(1925) <main>: 
[2024/8/7 9:26:24 238] [1970-01-01 00:00:10] MainApp.c(1116) <GetRegisterMode>: -------- register mode 1
[2024/8/7 9:26:24 238] [1970-01-01 00:00:10] MainApp.c(1927) <main>: 
[2024/8/7 9:26:24 238] [1970-01-01 00:00:10] MainApp.c(1930) <main>: 
[2024/8/7 9:26:24 238] *************
[2024/8/7 9:26:24 238]  0x6d123c 
[2024/8/7 9:26:24 255] *****************
[2024/8/7 9:26:24 257] *************
[2024/8/7 9:26:24 257]  0x3287c 
[2024/8/7 9:26:24 257] *****************
[2024/8/7 9:26:24 257] beginend[1970-01-01 00:00:10] MainApp.c(1938) <main>: 
[2024/8/7 9:26:24 257] [1970-01-01 00:00:10] MainApp.c(866) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:26:24 270] [1970-01-01 00:00:10] MainApp.c(174) <GetDeviceHWInfo>: Get Hwinfo APP_ID [fvijo8jvloagv1gm], UUID[uuidcaab27b0a838d239] AUTHKEY [j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:26:24 288] [1970-01-01 00:00:10] MainApp.c(909) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:26:24 288] [1970-01-01 00:00:10] MainApp.c(942) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:26:24 302] [1970-01-01 00:00:10] MainApp.c(986) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:26:24 302] [1970-01-01 00:00:10] MainApp.c(1019) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:26:24 302] sdk start
[2024/8/7 9:26:24 319] [1970-01-01 00:00:10] MainApp.c(752) <tuya_ipc_sdk_start>: log_level 0[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/mtd/Config/ty/ 
[2024/8/7 9:26:24 319] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/mtd/Config/ty/
[2024/8/7 9:26:24 334] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/mtd/Config/ty/
[2024/8/7 9:26:24 334] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[2024/8/7 9:26:24 350] [01-01 18:12:15 TUYA D][simplekv.c:989] both file not exist /mnt/mtd/Config/ty/tuya_user.db
[2024/8/7 9:26:24 350] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[2024/8/7 9:26:24 350] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[2024/8/7 9:26:24 366] [01-01 18:12:15 TUYA D][simplekv.c:1083] init NEW normal[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:26:24 366]  file
[2024/8/7 9:26:24 366] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 3536627844
[2024/8/7 9:26:24 382] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:24 382] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[2024/8/7 9:26:24 398] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[2024/8/7 9:26:24 398] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[2024/8/7 9:26:24 414] [01-01 18:12:15 TUYA I][mqc_app.c:35[atbm_log]:eth2:free authen bss ++
[2024/8/7 9:26:24 414] 0] mqc app init ...
[2024/8/7 9:26:24 430] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[2024/8/7 9:26:24 430] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[2024/8/7 9:26:24 430] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[2024/8/7 9:26:24 446] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[2024/8/7 9:26:24 446] [01-01 18:12:15 TUYA E][log_seq.c:863] open err
[2024/8/7 9:26:24 446] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[2024/8/7 9:26:24 462] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[2024/8/7 9:26:24 462] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[2024/8/7 9:26:24 478] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:26:24 478] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:24 494] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:24 495] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:24 495] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:26:24 510] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:26:24 510] [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
[2024/8/7 9:26:24 510] [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:26:24 526] dev id key: 16
[2024/8/7 9:26:24 526] d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[2024/8/7 9:26:24 526] --- tracepoint bt_ext_porting.c,tuya_ext_bt_port_init(464): tuya_ext_bt_port_init ---
[2024/8/7 9:26:24 542] [01-01 18:12:15 TUYA I][bt_ext_porting.c:466] [TUYA-BTUART]tuya ext bt port init
[2024/8/7 9:26:24 542] --- tracepoint bt_uart_drv.c,tuya_bt_uart_open(187): tuya_bt_uart_open ---
[2024/8/7 9:26:24 558] --- tracepoint bt_uart_drv.c,tuya_bt_uart_init(60): tuya_bt_uart_init  0 ---
[2024/8/7 9:26:24 558] [01-01 18:12:15 TUYA I][bt_ext_porting.c:485] [TUYA-BTUART]thread ty_btext_thread create cplt mode 1
[2024/8/7 9:26:24 574] [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[2024/8/7 9:26:24 574] [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[2024/8/7 9:26:24 574] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish
[2024/8/7 9:26:24 590] [1970-01-01 00:00:10] MainApp.c(822) <tuya_ipc_sdk_start>: create ring buffer start 
[2024/8/7 9:26:24 590] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:0 Enable:1
[2024/8/7 9:26:24 606] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 2048, video_fps 12
[2024/8/7 9:26:24 606] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr0 bitrate:2048 fps:12
[2024/8/7 9:26:24 622] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 2621440 bytes for ch0st0tr0, max frame size 393216
[2024/8/7 9:26:24 622] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr0 size:2621440 nodes:120
[2024/8/7 9:26:24 638] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:0
[2024/8/7 9:26:24 638] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:1 Enable:1
[2024/8/7 9:26:24 654] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 1024, video_fps 12
[2024/8/7 9:26:24 654] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr1 bitrate:1024 fps:12
[2024/8/7 9:26:24 670] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1310720 bytes for ch0st0tr1, max frame size 196608
[2024/8/7 9:26:24 670] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr1 size:1310720 nodes:120
[2024/8/7 9:26:24 686] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:1
[2024/8/7 9:26:24 686] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:2 Enable:0
[2024/8/7 9:26:24 702] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:3 Enable:0
[2024/8/7 9:26:24 702] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:4 Enable:0
[2024/8/7 9:26:24 702] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:5 Enable:0
[2024/8/7 9:26:24 718] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:6 Enable:0
[2024/8/7 9:26:24 719] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:7 Enable:0
[2024/8/7 9:26:24 734] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:8 Enable:0
[2024/8/7 9:26:24 735] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:9 Enable:1
[2024/8/7 9:26:24 750] [01-01 18:12:15 TUYA D][MainApp.c:439] audio_sample 8000, audio_databits 16, audio_fps 25
[2024/8/7 9:26:24 750] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[2024/8/7 9:26:24 766] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1[atbm_log]:[eth2] change to [3]
[2024/8/7 9:26:24 766] 60000 bytes for [atbm_log]:[eth2] has been disabled
[2024/8/7 9:26:24 766] [atbm_log]:add iftype(6),if_cnt(2),flags(c24b9bf8)
[2024/8/7 9:26:24 783] --- tracepoint[atbm_log]:enable sg
[2024/8/7 9:26:24 783]  bt_ext_porting.[atbm_log]:[mon.eth2] has been disabled
[2024/8/7 9:26:24 783] c,ty_btext_thread(370):  ---
[2024/8/7 9:26:24 798] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[2024/8/7 9:26:24 799] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:9
[2024/8/7 9:26:24 814] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:10 Enable:0
[2024/8/7 9:26:24 814] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:11 Enable:0
[2024/8/7 9:26:24 814] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:12 Enable:0
[2024/8/7 9:26:24 830] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:13 Enable:0
[2024/8/7 9:26:24 830] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:14 Enable:0
[2024/8/7 9:26:24 846] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:15 Enable:0
[2024/8/7 9:26:24 862] [1970-01-01 00:00:10] MainApp.c(830) <tuya_ipc_sdk_start>: pRunInfo->net_info.connect_mode 1[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:26:24 862] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:24 863] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:24 878] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:24 878] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:26:24 878] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:26:24 910] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":null,"auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:26:24 910] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:26:24 926] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:24 926] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:24 942] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_dec[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:26:24 942] ode fail. -3
[2024/8/7 9:26:24 942] [[atbm_log]:[WSM] Drop frame
[2024/8/7 9:26:24 942] 01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:208
[2024/8/7 9:26:24 958] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 0 startpos:28700 size:276
[2024/8/7 9:26:24 958] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:24 958] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 1056267009
[2024/8/7 9:26:24 974] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:24 974] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:24 974] [01-01 18:12:15 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:26:24 990] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":0,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:26:25 006] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 006] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 022] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 022] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 022] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:26:25 038] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 1 startpos:28976 size:212
[2024/8/7 9:26:25 038] [atbm_log]:[eth2] start driver he ap
[2024/8/7 9:26:25 038] [01-01 18:12:15 TUYA D][[atbm_log]:BSS_CHANGED_BEACON
[2024/8/7 9:26:25 054] simplekv.c:483] [atbm_log]:change ds_params channel 6 
[2024/8/7 9:26:25 054] new space. seek to end and write zero
[2024/8/7 9:26:25 054] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2367317337
[2024/8/7 9:26:25 070] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:25 070] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:25 070] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:26:25 086] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[2024/8/7 9:26:25 086] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1776] Last reset reason: 255
[2024/8/7 9:26:25 086] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 102] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:26:25 102] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:26:25 118] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:26:25 118] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 118] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 134] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 134] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 134] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:25 150] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:26:25 150] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1140] serial_no:90314ba51650
[2024/8/7 9:26:25 166] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 166] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:26:25 166] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:26:25 182] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[2024/8/7 9:26:25 182] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1171] gw_cntl.gw_wsm.stat:0
[2024/8/7 9:26:25 198] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1347] gw_cntl->gw_wsm.nc_tp:0
[2024/8/7 9:26:25 198] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1348] gw_cntl->gw_wsm.md:0
[2024/8/7 9:26:25 198] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1362] wifi config method not fit
[2024/8/7 9:26:25 214] [01-01 18:12:15 TUYA E][tuya_devos_entry.c:1787] ret:-2
[2024/8/7 9:26:25 214] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1808] enter reset factory
[2024/8/7 9:26:25 214] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 230] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 230] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 246] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 246] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_di -6
[2024/8/7 9:26:25 246] [01-01 18:12:15 TUYA E][ws_db_gw.c:494] gw_di read fail:-6
[2024/8/7 9:26:25 262] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 262] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 262] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 278] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 278] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_di And Value Len:400
[2024/8/7 9:26:25 294] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 2 startpos:29188 size:468
[2024/8/7 9:26:25 294] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:25 294] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 876692212
[2024/8/7 9:26:25 310] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:25 310] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:25 310] [01-01 18:12:15 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:26:25 326] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:593] nc_tp:2, wifi_start_mode:0
[2024/8/7 9:26:25 326] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 342] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 342] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 342] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 358] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:wf_start_md And Value Len:16
[2024/8/7 9:26:25 358] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 3 startpos:29656 size:84
[2024/8/7 9:26:25 374] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:25 374] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 411742493
[2024/8/7 9:26:25 374] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:25 390] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:25 407] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:26:25 407] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 407] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:26:25 422] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:26:25 422] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:26:25 438] [01-01 18:12:15 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:26:25 438] [01-01 18:12:15 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:26:25 438] [01-01 18:12:15 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:26:25 454] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4146866774
[2024/8/7 9:26:25 454] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:25 454] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:25 471] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:26:25 471] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 486] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 486] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 486] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 502] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6
[2024/8/7 9:26:25 502] [01-01 18:12:15 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6
[2024/8/7 9:26:25 502] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 518] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 518] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 518] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 534] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:368
[2024/8/7 9:26:25 534] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 4 startpos:29740 size:436
[2024/8/7 9:26:25 550] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:25 550] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 216605884
[2024/8/7 9:26:25 550] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:25 566] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:25 566] [01-01 18:12:15 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:26:25 566] [01-01 18:12:15 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:26:25 582] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 582] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 598] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 598] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 598] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:26:25 614] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 5 startpos:30176 size:84
[2024/8/7 9:26:25 614] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:25 630] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4220141073
[2024/8/7 9:26:25 630] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:25 630] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:25 646] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 646] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 646] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 662] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 662] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:26:25 678] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 6 startpos:30260 size:84
[2024/8/7 9:26:25 678] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:25 678] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 860452950
[2024/8/7 9:26:25 694] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:25 694] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:25 710] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:26:25 710] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:25 710] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:25 726] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:25 726] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:26:25 742] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 7 startpos:30344 size:84
[2024/8/7 9:26:25 743] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:25 743] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2541358761
[2024/8/7 9:26:25 758] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:25 758] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:25 758] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[2024/8/7 9:26:25 774] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[2024/8/7 9:26:25 790] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[2024/8/7 9:26:25 790] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[2024/8/7 9:26:25 790] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[2024/8/7 9:26:25 806] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[2024/8/7 9:26:25 806] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[2024/8/7 9:26:25 806] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[2024/8/7 9:26:25 822] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[2024/8/7 9:26:25 822] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[2024/8/7 9:26:25 822] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[2024/8/7 9:26:25 838] [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[2024/8/7 9:26:25 838] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[2024/8/7 9:26:25 902] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}
[2024/8/7 9:26:25 903] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:116] sys add timer: 14
[2024/8/7 9:26:25 918] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:122] sys start timer: 14
[2024/8/7 9:26:25 918] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[2024/8/7 9:26:25 918] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[2024/8/7 9:26:25 934] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[2024/8/7 9:26:25 935] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[2024/8/7 9:26:25 935] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:fvijo8jvloagv1gm 0
[2024/8/7 9:26:25 950] uuid: 20
[2024/8/7 9:26:25 951] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:26:25 951] dev_id_tmp: 16
[2024/8/7 9:26:25 951] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:26:25 951] dev_id_tmp2: 20
[2024/8/7 9:26:25 966] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:26:25 966] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[2024/8/7 9:26:25 982] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:26:25 982] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1066] nc_tp:2, md:0
[2024/8/7 9:26:25 983] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1297] dev_nw_cfg_active_stage:2
[2024/8/7 9:26:25 998] [01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[2024/8/7 9:26:25 998] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:26:26 014] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:26:26 014] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:26:26 015] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[2024/8/7 9:26:26 030] [1970-01-01 00:00:11] MainApp.c(838) <tuya_ipc_sdk_start>: [01-01 18:12:15 TUYA D][MainApp.c:854] tuya ipc sdk start is complete
[2024/8/7 9:26:26 030] killall: hostapd: no process killed
[2024/8/7 9:26:26 046] route: netmask and route address conflict
[2024/8/7 9:26:26 046] DEBUG: ***u16num***[163]
[2024/8/7 9:26:26 046] DEBUG: ***u16num***[467]
[2024/8/7 9:26:26 046] DEBUG: ***u16num***[511]
[2024/8/7 9:26:26 046] DEBUG: ***u16num***[512]
[2024/8/7 9:26:26 062] [1970-01-01 00:00:11] MainApp.c(1028) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:26:26 062] [1970-01-01 00:00:11] MainApp.c(1053) <TUYA_IPC_SDK_START>: pthread_create BasicIndicatorTimer suc
[2024/8/7 9:26:26 079] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [0] change to [1]
[2024/8/7 9:26:26 079] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [0] change to [1]
[2024/8/7 9:26:26 094] [1970-01-01 00:00:11] MainApp.c(1968) <main>: FLIP
[2024/8/7 9:26:26 094] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [1] change to [0]
[2024/8/7 9:26:26 110] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [1] change to [0]
[2024/8/7 9:26:26 110] [1970-01-01 00:00:11] MainApp.c(1972) <main>: FLIP
[2024/8/7 9:26:26 126] [1970-01-01 00:00:11] MainApp.c(1622) <PostInit>: 
[2024/8/7 9:26:26 126] src/intelligent_track_thread.c(1398) [XM_SmartBodyTarckCreate]: 
[2024/8/7 9:26:26 126] src/intelligent_track_thread.c(1374) [Smart_Track_GetAbility]: 
[2024/8/7 9:26:26 142] src/intelligent_track_thread.c(1379) [Smart_Track_GetAbility]: 
[2024/8/7 9:26:26 142] src/intelligent_track_thread.c(1272) [GetMotorCtrlPara]: 
[2024/8/7 9:26:26 158] src/intelligent_track_thread.c(1277) [GetMotorCtrlPara]: 
[2024/8/7 9:26:26 158] src/intelligent_track_thread.c(1283) [GetMotorCtrlPara]: 
[2024/8/7 9:26:26 174] src/intelligent_track_thread.c(1298) [GetMotorCtrlPara]: max_steps_x=5006 ,max_steps_y=2161
[2024/8/7 9:26:26 175] src/intelligent_track_thread.c(1301) [GetMotorCtrlPara]: 
[2024/8/7 9:26:26 175] src/intelligent_track_thread.c(1307) [GetMotorCtrlPara]: 
[2024/8/7 9:26:26 190] src/intelligent_track_thread.c(1323) [GetMotorCtrlPara]: 
[2024/8/7 9:26:26 190] src/intelligent_track_thread.c(1336) [GetMotorCtrlPara]: track_default_degrees_y=95
[2024/8/7 9:26:26 206] src/intelligent_track_thread.c(1345) [GetMotorCtrlPara]: LoadTrackSet Motor_x_turnover:no
[2024/8/7 9:26:26 206] src/intelligent_track_thread.c(1346) [GetMotorCtrlPara]: LoadTrackSet Motor_y_turnover:no
[2024/8/7 9:26:26 222] src/intelligent_track_thread.c(1348) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 540
[2024/8/7 9:26:26 238] src/intelligent_track_thread.c(1367) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 400
[2024/8/7 9:26:26 238] src/intelligent_track_thread.c(1368) [GetMotorCtrlPara]: LoadTrackSet HEIGHT_STEP = 200
[2024/8/7 9:26:26 254] src/intelligent_track_thread.c(1390) [Smart_Track_GetAbility]: Track_Ability : Enable
[2024/8/7 9:26:26 254] [1970-01-01 00:00:11] MainApp.c(277) <BasicIndicatorTimer>: BasicIndicatorTimer start ----
[2024/8/7 9:26:26 270] src/intelligent_track_thread.c(1451) [XM_SmartBodyTarckCreate]: Intelligent Track_pthread create Success 1920x1080
[2024/8/7 9:26:26 270] src/intelligent_track_thread.c(667) [TrackProcV200]: 
[2024/8/7 9:26:26 286] [1970-01-01 00:00:11] MainApp.c(1640) <PostInit>: ln -s /mnt/mtd/Log/sofia.log /tmp/tuya.log
[2024/8/7 9:26:26 286] [1970-01-01 00:00:11] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:26:26 302] [1970-01-01 00:00:11] MainApp.c(1665) <PostInit>: MotionDetect Sensitive 1 set onvif_on_off:0 
[2024/8/7 9:26:26 302] curr event:3 
[2024/8/7 9:26:26 302] IPC_APP_Notify_LED_Sound_Status_CB line(480) -------------------------- IPC_START_WIFI_AP_CFG(3)
[2024/8/7 9:26:26 318] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-1650
[2024/8/7 9:26:26 318] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:26:26 333] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:26:26 334] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:26:26 334] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:26:26 350] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:26:26 350] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:26:26 366] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[2024/8/7 9:26:26 366] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[2024/8/7 9:26:26 366] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[2024/8/7 9:26:26 382] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:26:26 382] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:26:26 398] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:26:26 398] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:26 398] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:26 414] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:26 414] [01-01 18:12:16 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:26:26 430] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:26:26 430] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:26 430] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:26 446] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:26 446] [01-01 18:12:16 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:26:26 446] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:26:26 462] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:26 462] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:26 478] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:26 478] [01-01 18:12:16 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:26:26 494] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[2024/8/7 9:26:26 494] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:26:26 494] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:2  -->>
[2024/8/7 9:26:26 510] __IPC_APP_Get_Net_Status_cb line(193) -------------------------- stat(2)==STAT_AP_STA_UNCFG 
[2024/8/7 9:26:26 510] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:2  <<--
[2024/8/7 9:26:26 526] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:26:26 526] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:26:26 542] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:26:26 542] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:26 558] [01-01 18:12:16 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:26 558] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[2024/8/7 9:26:26 574] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:21504,priority:5
[2024/8/7 9:26:26 574] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[2024/8/7 9:26:26 590] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[2024/8/7 9:26:26 591] [01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt netcfg start
[2024/8/7 9:26:26 591] udhcpd (v1.22.1) started
[2024/8/7 9:26:26 591] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:26:26 606] [01-01 18:12:16 TUYA N][tuya_ble_api.c:439] update bound stat:0
[2024/8/7 9:26:26 606] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 9:26:26 622] [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 9:26:26 622] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[2024/8/7 9:26:26 638] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[2024/8/7 9:26:26 638] [01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:26:26 638] dev id key: 16
[2024/8/7 9:26:26 638] d0 7d 89 57 d1 c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 9:26:26 654] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:26:26 654] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:26:26 670] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:26:26 670] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:26:26 670] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:26:26 686] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 9:26:26 686] [1970-01-01 00:00:12] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time12286
[2024/8/7 9:26:26 702] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0x266c1a0),len(28)
[2024/8/7 9:26:26 702] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 9:26:26 718] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:26:26 718] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0x269b710),len(30)
[2024/8/7 9:26:26 734] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 9:26:26 734] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:26:26 734] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 9:26:26 734] adv_len:28
[2024/8/7 9:26:26 750] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:26:26 750] svc_data_uuid16 len:18
[2024/8/7 9:26:26 750] ---[XmBleAdvertiseEx][1210]: rc=[0]
[2024/8/7 9:26:26 766] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 9:26:26 766] rsp_len:30
[2024/8/7 9:26:26 766] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:26:26 766] mfg_data len:30
[2024/8/7 9:26:26 766] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 9:26:26 781] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 9:26:26 782] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 9:26:26 782] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:26 798] ---[XmBleAdvertiseEx][1241]: rc=[0]
[2024/8/7 9:26:26 798] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 9:26:26 798] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 9:26:26 814] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:26 814] adv_start rc = 0x0
[2024/8/7 9:26:26 830] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 9:26:26 830] [01-01 18:12:16 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:26:26 830] DEBUG: ***u16num***[512]
[2024/8/7 9:26:26 846] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:26 846] [01-01 18:12:16 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:26 846] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:26 862] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:26 862] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:26 878] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:26 878] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:26 878] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:26 894] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:26 894] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:26 894] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:26 911] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:26 911] [01-01 18:12:16 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:26 926] [01-01 18:12:16 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:26 926] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:26 942] [01-01 18:12:16 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:26 958] [01-01 18:12:16 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:26 958] [01-01 18:12:16 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:26 974] [01-01 18:12:16 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:26 974] gethostbyname_r error: Unknown host
[2024/8/7 9:26:26 974] [01-01 18:12:16 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:26 990] [01-01 18:12:16 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:26 990] [01-01 18:12:16 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:27 006] [01-01 18:12:16 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:27 006] [01-01 18:12:16 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:27 022] [01-01 18:12:16 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:27 022] [01-01 18:12:16 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:27 037] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:27 038] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:26:27 038] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 054] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 054] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:27 166] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:27 182] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:27 182] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:26:27 198] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:27 198] [01-01 18:12:17 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:27 198] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 214] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:27 214] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:26:27 230] [01-01 18:12:17 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:26:27 230] [01-01 18:12:17 TUYA D][tuya_ble_api.c:1470] ble get conn stat:4
[2024/8/7 9:26:27 246] [01-01 18:12:17 TUYA N][tuya_ble_api.c:750] ble_sdk_send skip, no connect:4
[2024/8/7 9:26:27 246] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 246] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:27 262] [1970-01-01 00:00:13] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:27 278] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:27 279] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:27 279] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:27 294] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:27 294] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:27 294] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:27 310] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:27 310] [01-01 18:12:17 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:27 326] [01-01 18:12:17 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:27 326] [01-01 18:12:17 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:27 326] [01-01 18:12:17 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:27 342] [01-01 18:12:17 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:27 342] [01-01 18:12:17 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:27 358] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:27 374] [01-01 18:12:17 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:27 374] [01-01 18:12:17 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:27 390] [01-01 18:12:17 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:27 390] [01-01 18:12:17 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:27 406] gethostbyname_r error: Unknown host
[2024/8/7 9:26:27 406] [01-01 18:12:17 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:27 406] [01-01 18:12:17 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:27 422] [01-01 18:12:17 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:27 422] [01-01 18:12:17 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:27 438] [01-01 18:12:17 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:27 438] [01-01 18:12:17 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:27 454] [01-01 18:12:17 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:27 454] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:27 454] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 470] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 486] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:27 502] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:27 502] [01-01 18:12:18 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:27 502] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 518] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 534] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:27 534] [1970-01-01 00:00:14] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:27 550] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:27 550] [01-01 18:12:19 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:27 566] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:27 566] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:27 566] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:27 582] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:27 582] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:27 597] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:27 598] [01-01 18:12:19 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:27 598] [01-01 18:12:19 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:27 613] [01-01 18:12:19 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:27 614] [01-01 18:12:19 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:27 629] [01-01 18:12:19 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:27 630] [01-01 18:12:19 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:27 630] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:27 661] [01-01 18:12:19 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:27 662] [01-01 18:12:19 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:27 678] [01-01 18:12:19 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:27 678] [01-01 18:12:19 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:27 678] gethostbyname_r error: Unknown host
[2024/8/7 9:26:27 694] [01-01 18:12:19 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:27 694] [01-01 18:12:19 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:27 710] [01-01 18:12:19 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:27 710] [01-01 18:12:19 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:27 725] [01-01 18:12:19 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:27 726] [01-01 18:12:19 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:27 726] [01-01 18:12:19 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:27 741] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:27 742] DEBUG: ***u16num***[512]
[2024/8/7 9:26:27 822] DEBUG: ***u16num***[512]
[2024/8/7 9:26:28 014] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:28 030] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:26:28 046] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:28 046] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:28 062] [01-01 18:12:19 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:28 062] DEBUG: ***u16num***[512]
[2024/8/7 9:26:28 110] [01-01 18:12:19 TUYA D][tuya_ble_api.c:1376] nw stat change:0->1, rpt to app.
[2024/8/7 9:26:28 110] [01-01 18:12:19 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:26:28 317] DEBUG: ***u16num***[512]
[2024/8/7 9:26:28 447] DEBUG: ***u16num***[512]
[2024/8/7 9:26:28 478] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:28 494] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:28 494] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:28 510] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:28 510] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:28 510] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:28 526] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:28 526] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:28 526] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:28 542] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:28 542] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:28 558] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:28 558] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:28 558] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:28 575] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:28 590] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:28 606] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:28 606] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:28 622] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:28 622] gethostbyname_r error: Unknown host
[2024/8/7 9:26:28 622] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:28 638] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:28 638] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:28 654] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:28 655] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:28 670] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:28 670] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:28 670] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:28 670] DEBUG: ***u16num***[512]
[2024/8/7 9:26:28 702] DEBUG: ***u16num***[499]
[2024/8/7 9:26:28 878] DEBUG: ***u16num***[448]
[2024/8/7 9:26:28 989] DEBUG: ***u16num***[438]
[2024/8/7 9:26:29 022] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:29 037] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:29 037] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:29 053] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:29 501] 򵑪mƊºjj҂Ҋ²낵}ݥ¥¹¡²code Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:29 549] [1970-01-01 00:00:16] MainApp.c(197¢Y»Z󗊋+˫ʉ	RHh´jmۍjmƊºjj҂Ҋ²낵}µ¥¹¹¡ªJフ򶋋UV֋TW¬5J˒։¢¡J2Ʌµ¢¥µŲ²j¤´´jmۍjmƊºjj҂Ҋ²낵}ݥ¥¹㲾J〵}AʍEɍ½フ󔌍µEɍ½ʍI½񑊫Vÿ𽞰0«¨HhjÒҒ¢U 
[2024/8/7 9:26:29 565]                                                        Tµ5¥µq­ٹ銚¢ê"±ѕZ橢±̽}¹сJ˙֩ꦩjԤhjÒҒ¢U 
[2024/8/7 9:26:29 565]        Tµ𧥌HªUVP¢][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:29 581] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:29 581] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:29 581] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:29 591] [01-01 18:12:21 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:29 591] [01-01 18:12:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:29 623] [01-01 ÿÿ{񷛩ʢ뿿ÿÿ򅓒þ𥾑}¹̽н±½Ց}։±хʑ5jR´jÒҒ¢U 
[2024/8/7 9:26:29 639]                                        TµU¹¥}¹ҝ½ɭ¹颂ꚕн¹̽¡}¥½ɥҥ鑪ԤhjÒҒ¢U 
[2024/8/7 9:26:29 655]        Tµ댗ҁ¹銪¢郑ҁ}¹́¹烚*¹ىВɽb½¹¥ӚµZ劒Bґɱbr}в±͕񲚉Z劒jƑЕɱbr}в±͕񲚉ٙ^"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:29 655] [01-01 18:12:21 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:29 671] [01-01 18:12:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:29 671] [01-01 18:12:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:29 671] gethostbyname_r error: Unknown host
[2024/8/7 9:26:29 687] [01-01 18:12:21 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:29 687] [01-01 18:12:21 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:29 702] [01-01 18:12:21 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:29 702] [01-01 18:12:21 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:29 718] [01-01 18:12:21 TUYA D][httpc.c:815] Connect: h2.򗉖ki֫ 
[2024/8/7 9:26:29 718]                                                     ԋ'$M}&HHKK ,r:-15
[2024/8/7 9:26:29 718] [01-01 18:12:21 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:29 734] [01-01 18:12:21 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:29 734] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:29 734] XshellDEBUG: ***u16num***[470]
[2024/8/7 9:26:29 798] XshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellXshellDEBUG: ***u16num***[452]
[2024/8/7 9:26:29 974] motor auto test over
[2024/8/7 9:26:29 974] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 9:26:29 974] action=idle
[2024/8/7 9:26:29 974] dir=
[2024/8/7 9:26:29 974] flag=|auto-test-cmplt
[2024/8/7 9:26:29 989]  steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 9:26:29 990] 
[2024/8/7 9:26:29 990] YYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 9:26:29 990] action=idle
[2024/8/7 9:26:29 990] dir=
[2024/8/7 9:26:29 990] flag=
[2024/8/7 9:26:29 990]  steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 9:26:30 037] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:30 037] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:26:30 037] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:30 054] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:30 054] DEBUG: ***u16num***[414]
[2024/8/7 9:26:30 134] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:26:30 150] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:30 150] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:26:30 293] DEBUG: ***u16num***[221]
[2024/8/7 9:26:30 454] DEBUG: ***u16num***[129]
[2024/8/7 9:26:30 534] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:30 535] [01-01 18:12:22 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:30 535] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:30 550] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:30 550] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:30 565] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:30 566] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:30 566] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:30 582] [01-01 18:12:22 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:30 582] [01-01 18:12:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:30 582] [01-01 18:12:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:30 598] [01-01 18:12:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:30 598] [01-01 18:12:22 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:30 614] [01-01 18:12:22 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:30 614] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:30 629] [01-01 18:12:22 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:30 647] [01-01 18:12:22 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:30 647] [01-01 18:12:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:30 662] [01-01 18:12:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:30 662] gethostbyname_r error: Unknown host
[2024/8/7 9:26:30 662] [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:30 678] [01-01 18:12:22 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:30 678] [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:30 694] [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:30 694] [01-01 18:12:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:30 711] [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:30 711] [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:30 727] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:30 727] [01-01 18:12:22 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:26:30 727] DEBUG: ***u16num***[90]
[2024/8/7 9:26:30 727] DEBUG: ***u16num***[82]
[2024/8/7 9:26:30 822] DEBUG: ***u16num***[77]
[2024/8/7 9:26:30 934] DEBUG: ***u16num***[81]
[2024/8/7 9:26:31 046] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:31 062] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:31 078] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:31 078] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:31 078] DEBUG: ***u16num***[92]
[2024/8/7 9:26:31 270] DEBUG: ***u16num***[148]
[2024/8/7 9:26:31 365] DEBUG: ***u16num***[112]
[2024/8/7 9:26:31 493] DEBUG: ***u16num***[161]
[2024/8/7 9:26:31 542] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:31 542] [1970-01-01 00:00:18] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:31 542] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:31 558] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:31 558] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:31 574] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:31 574] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:31 574] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:31 590] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:31 590] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:31 590] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:31 606] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:31 606] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:31 622] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:31 622] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:31 622] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:31 654] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:31 654] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:31 670] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:31 670] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:31 686] gethostbyname_r error: Unknown host
[2024/8/7 9:26:31 686] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:31 686] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:31 702] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:31 702] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:31 718] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:31 718] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:31 734] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:31 734] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:31 734] DEBUG: ***u16num***[155]
[2024/8/7 9:26:31 813] DEBUG: ***u16num***[161]
[2024/8/7 9:26:31 941] DEBUG: ***u16num***[157]
[2024/8/7 9:26:32 038] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:32 053] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:32 069] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:32 069] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:32 085] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:32 085] DEBUG: ***u16num***[154]
[2024/8/7 9:26:32 261] DEBUG: ***u16num***[158]
[2024/8/7 9:26:32 438] DEBUG: ***u16num***[167]
[2024/8/7 9:26:32 566] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:26:32 582] [1970-01-01 00:00:19] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17[1970-01-01 00:00:19] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 9:26:32 582] [1970-01-01 00:00:19] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 9:26:32 582] mpId[0] is [0].
[2024/8/7 9:26:32 582] mpId[1] is [0].
[2024/8/7 9:26:32 582] mpId[2] is [0].
[2024/8/7 9:26:32 598] mpId[3] is [0].
[2024/8/7 9:26:32 598] mpId[4] is [0].
[2024/8/7 9:26:32 598] mpId[5] is [0].
[2024/8/7 9:26:32 598] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:26:32 614] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:26:32 630] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:32 630] [1970-01-01 00:00:19] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:32 646] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:32 646] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:32 646] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:32 661] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:32 662] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:32 662] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:32 677] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:32 678] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:32 694] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:32 694] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:32 694] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:32 710] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:32 710] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:32 725] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:32 742] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:32 757] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:32 757] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:32 757] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:32 758] 
[2024/8/7 9:26:32 773] gethostbyname_r error: Unknown host
[2024/8/7 9:26:32 773] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:32 773] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:32 789] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:32 789] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:32 805] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:32 806] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:32 821] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:32 822] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:32 822] DEBUG: ***u16num***[213]
[2024/8/7 9:26:32 822] DEBUG: ***u16num***[222]
[2024/8/7 9:26:32 885] DEBUG: ***u16num***[223]
[2024/8/7 9:26:33 030] DEBUG: ***u16num***[222]
[2024/8/7 9:26:33 046] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:33 062] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:33 078] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:33 078] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:33 093] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:33 141] DEBUG: ***u16num***[220]
[2024/8/7 9:26:33 318] DEBUG: ***u16num***[233]
[2024/8/7 9:26:33 493] DEBUG: ***u16num***[232]
[2024/8/7 9:26:33 621] [1970-01-01 00:00:20] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time20336
[2024/8/7 9:26:33 637] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:33 653] [1970-01-01 00:00:20] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:33 653] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:33 669] [01-01 18:12:25 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:33 669] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:33 685] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:33 685] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:33 685] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:33 701] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:33 701] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:33 717] [01-01 18:12:25 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:33 717] [01-01 18:12:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:33 717] [01-01 18:12:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:33 733] [01-01 18:12:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:33 733] [01-01 18:12:25 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:33 749] [01-01 18:12:25 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:33 749] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:33 766] [01-01 18:12:25 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:33 781] [01-01 18:12:25 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:33 781] [01-01 18:12:25 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:33 797] [01-01 18:12:25 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:33 797] gethostbyname_r error: Unknown host
[2024/8/7 9:26:33 797] [01-01 18:12:25 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:33 814] [01-01 18:12:25 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:33 814] [01-01 18:12:25 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:33 830] [01-01 18:12:25 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:33 830] [01-01 18:12:25 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:33 846] [01-01 18:12:25 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:33 846] [01-01 18:12:25 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:33 863] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:33 865] DEBUG: ***u16num***[233]
[2024/8/7 9:26:33 865] DEBUG: ***u16num***[258]
[2024/8/7 9:26:33 941] DEBUG: ***u16num***[248]
[2024/8/7 9:26:34 053] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:34 069] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:34 069] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:26:34 085] [01-01 18:12:25 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:26:34 085] DEBUG: ***u16num***[249]
[2024/8/7 9:26:34 278] DEBUG: ***u16num***[246]
[2024/8/7 9:26:34 373] DEBUG: ***u16num***[248]
[2024/8/7 9:26:34 501] DEBUG: ***u16num***[251]
[2024/8/7 9:26:34 662] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:26:34 678] src/intelligent_track_thread.c(709) [TrackProcV200]: Intelligent Track Enable eSensitivity=0 intervalTime_sec=15
[2024/8/7 9:26:34 678] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:34 694] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:34 710] [01-01 18:12:26 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:34 710] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:34 710] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:34 726] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:34 726] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:34 741] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:34 742] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:34 742] [01-01 18:12:26 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:34 759] [01-01 18:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:34 759] [01-01 18:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:34 759] [01-01 18:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:34 774] [01-01 18:12:26 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:34 774] [01-01 18:12:26 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:34 790] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:34 806] [01-01 18:12:26 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:34 822] [01-01 18:12:26 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:34 822] [01-01 18:12:26 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:34 837] [01-01 18:12:26 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:34 837] gethostbyname_r error: Unknown host
[2024/8/7 9:26:34 837] [01-01 18:12:26 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:34 853] [01-01 18:12:26 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:34 853] [01-01 18:12:26 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:34 853] [01-01 18:12:26 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:34 869] [01-01 18:12:26 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:34 869] [01-01 18:12:26 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:34 885] [01-01 18:12:26 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:34 885] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:34 885] DEBUG: ***u16num***[254]
[2024/8/7 9:26:34 903] DEBUG: ***u16num***[236]
[2024/8/7 9:26:35 029] DEBUG: ***u16num***[246]
[2024/8/7 9:26:35 141] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:26:35 157] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:35 158] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:35 173] [01-01 18:12:26 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:26:35 173] DEBUG: ***u16num***[254]
[2024/8/7 9:26:35 317] DEBUG: ***u16num***[247]
[2024/8/7 9:26:35 477] DEBUG: ***u16num***[218]
[2024/8/7 9:26:35 510] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:26:35 526] Mode(Product):0
[2024/8/7 9:26:35 526] BpuMode:[Online]
[2024/8/7 9:26:35 526] VpssMode:[Online]
[2024/8/7 9:26:35 526] [0.LimitUp_info]:
[2024/8/7 9:26:35 526] LimitUp:[Disable]
[2024/8/7 9:26:35 526] [2680*0]->[3840*0])
[2024/8/7 9:26:35 526] chn	TotalSize	ActiveSize
[2024/8/7 9:26:35 526] 0	5040*2246	2680*2160
[2024/8/7 9:26:35 542] 0	5040*2246	3840*2160
[2024/8/7 9:26:35 542] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:26:35 542] [1.VICU_info]:
[2024/8/7 9:26:35 542] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:26:35 542] 0	25.0	366	0	0	183	linear	8ddb00
[2024/8/7 9:26:35 542] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:26:35 558] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:26:35 558] en	op_type	m_chn	now
[2024/8/7 9:26:35 558] 0	1	1	1
[2024/8/7 9:26:35 558] [2.VI_info]:
[2024/8/7 9:26:35 558] chn	TotalSize	ActiveSize
[2024/8/7 9:26:35 558] 0	5040*2246	3848*2166
[2024/8/7 9:26:35 558] 1	   0*   0	   0*   0
[2024/8/7 9:26:35 558] [3.MIPI_info]:
[2024/8/7 9:26:35 574] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:26:35 574] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:26:35 574] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:26:35 574] [4.Cut_info]:
[2024/8/7 9:26:35 574] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:26:35 589] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:26:35 590] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:26:35 590] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:26:35 590] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:26:35 590] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:26:35 606] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:26:35 606] [5.IB(isp buffer info)]:
[2024/8/7 9:26:35 606] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:26:35 606] PoolId  Count  Size
[2024/8/7 9:26:35 621] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:35 621] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:35 637] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:35 639] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:35 639] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:35 653] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:35 653] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:26:35 653] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:26:35 669] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:26:35 669] 0       0         0          0          4       
[2024/8/7 9:26:35 669] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:26:35 685]      --265--            --264--                                               
[2024/8/7 9:26:35 685] Count      Line     Count      Line     
[2024/8/7 9:26:35 685] 272        480      615        560      
[2024/8/7 9:26:35 701] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:26:35 701] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:26:35 717] 0   3840   2160    H265  0      0        0           161       983038     2        	
[2024/8/7 9:26:35 717] 1   640    360     H265  0      0        0           108       43200      0        	
[2024/8/7 9:26:35 733] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:26:35 733] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:26:35 749] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:26:35 749] 0   Y      161      0       0       15       0        161      161      233       65127         59281    89933    64016    12      
[2024/8/7 9:26:35 766] 1   Y      108      0       2       1        0        108      108      233       2640          1938     34379    3228     8       
[2024/8/7 9:26:35 781] 3   N      0        0       0       1        0        0        0        234       0             0        0        0        0       
[2024/8/7 9:26:35 781] DEBUG: ***u16num***[166]
[2024/8/7 9:26:35 797] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:35 797] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:35 813] [1970-01-01 00:00:22] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:26:35 813] [1970-01-01 00:00:22] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:26:35 829] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:35 845] [01-01 18:12:27 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:35 845] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:35 845] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:35 861] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:35 861] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:35 877] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:35 877] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:35 878] [01-01 18:12:27 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:35 893] [01-01 18:12:27 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:35 893] [01-01 18:12:27 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:35 893] [01-01 18:12:27 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:35 909] [01-01 18:12:27 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:35 909] [01-01 18:12:27 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:35 925] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:35 941] [01-01 18:12:27 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:35 957] [01-01 18:12:27 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:35 957] [01-01 18:12:27 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:35 957] [01-01 18:12:27 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:35 973] 
[2024/8/7 9:26:35 974] gethostbyname_r error: Unknown host
[2024/8/7 9:26:35 974] [01-01 18:12:27 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:35 974] [01-01 18:12:27 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:35 989] [01-01 18:12:27 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:35 989] [01-01 18:12:27 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:36 005] [01-01 18:12:27 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:36 005] [01-01 18:12:27 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:36 021] [01-01 18:12:27 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:36 021] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:36 021] [01-01 18:12:27 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:26:36 037] DEBUG: ***u16num***[117]
[2024/8/7 9:26:36 037] DEBUG: ***u16num***[64]
[2024/8/7 9:26:36 741] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:36 741] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:36 757] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:36 773] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:36 773] [01-01 18:12:28 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:36 789] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:36 789] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:36 805] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:36 805] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:36 805] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:36 821] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:36 821] [01-01 18:12:28 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:36 821] [01-01 18:12:28 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:36 837] [01-01 18:12:28 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:36 837] [01-01 18:12:28 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:36 853] [01-01 18:12:28 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:36 853] [01-01 18:12:28 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:36 853] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:36 885] [01-01 18:12:28 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:36 885] [01-01 18:12:28 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:36 902] [01-01 18:12:28 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:36 902] [01-01 18:12:28 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:36 917] gethostbyname_r error: Unknown host
[2024/8/7 9:26:36 917] [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:36 917] [01-01 18:12:28 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:36 934] [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:36 934] [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:36 949] [01-01 18:12:28 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:36 949] [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:36 965] [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:36 965] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:38 837] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:38 854] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:38 869] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:38 886] [1970-01-01 00:00:25] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:38 886] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:38 901] [01-01 18:12:30 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:38 901] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:38 917] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:38 917] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:38 917] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:38 933] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:38 933] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:38 949] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:38 949] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:38 949] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:38 965] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:38 965] [01-01 18:12:30 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:38 981] [01-01 18:12:30 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:38 982] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:38 997] [01-01 18:12:30 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:39 013] [01-01 18:12:30 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:39 013] [01-01 18:12:30 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:39 029] [01-01 18:12:30 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:39 029] gethostbyname_r error: Unknown host
[2024/8/7 9:26:39 029] [01-01 18:12:30 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:39 045] [01-01 18:12:30 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:39 045] [01-01 18:12:30 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:39 061] [01-01 18:12:30 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:39 061] [01-01 18:12:30 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:39 077] [01-01 18:12:30 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:39 077] [01-01 18:12:30 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:39 077] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:39 093] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:26:39 877] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:39 877] set basic_indicator_onoff:0 
[2024/8/7 9:26:39 894] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(257) <IPC_APP_set_basic_indicator_onoff>: Get BasicIndicator suc,gpio value=[0x0c]
[2024/8/7 9:26:39 909] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:39 909] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:39 909] set basic_indicator_onoff:1 
[2024/8/7 9:26:39 925] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:39 925] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:39 941] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:39 941] set basic_indicator_onoff:0 
[2024/8/7 9:26:39 957] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:39 957] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:39 973] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:39 973] set basic_indicator_onoff:1 
[2024/8/7 9:26:39 989] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:39 989] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:40 005] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:40 005] set basic_indicator_onoff:0 
[2024/8/7 9:26:40 021] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:40 021] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:40 021] set basic_indicator_onoff:1 
[2024/8/7 9:26:40 037] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:40 037] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:40 053] [01-01 18:12:31 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:40 053] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:40 069] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:40 069] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:40 069] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:40 085] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:40 085] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:40 102] [01-01 18:12:31 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:40 105] [01-01 18:12:31 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:40 105] [01-01 18:12:31 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:40 117] [01-01 18:12:31 TUYA D][simplekv.c:1336] __read_kv_with_decodY³ail. -3
[2024/8/7 9:26:40 117] [01-01 18:12:31 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:40 117] [01-01 18:12:31 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:40 134] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:40 150] [01-01 18:12:31 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:40 165] [01-01 18:12:31 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:40 166] [01-01 18:12:31 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:40 181] [01-01 18:12:31 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:40 182] gethostbyname_r error: Unknown host
[2024/8/7 9:26:40 182] [01-01 18:12:31 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:40 197] [01-01 18:12:31 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:40 197] [01-01 18:12:31 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:40 214] [01-01 18:12:31 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:40 214] [01-01 18:12:31 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:40 229] [01-01 18:12:31 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:40 230] [01-01 18:12:31 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:40 230] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:40 246] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:26:40 246] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:40 261] set basic_indicator_onoff:0 
[2024/8/7 9:26:40 261] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:40 277] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:40 277] set basic_indicator_onoff:1 
[2024/8/7 9:26:40 277] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:40 293] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:40 309] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:40 309] [01-01 18:12:31 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:26:40 981] set basic_indicator_onoff:0 
[2024/8/7 9:26:40 981] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:40 997] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:40 997] set basic_indicator_onoff:1 
[2024/8/7 9:26:41 013] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:41 013] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:41 029] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:41 030] set basic_indicator_onoff:0 
[2024/8/7 9:26:41 045] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:41 045] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:41 061] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:41 061] set basic_indicator_onoff:1 
[2024/8/7 9:26:41 077] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:41 077] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:41 093] [01-01 18:12:32 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:41 093] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:41 093] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:41 109] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:41 109] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:41 109] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:41 125] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:41 125] [01-01 18:12:32 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:41 141] [01-01 18:12:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:41 141] [01-01 18:12:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:41 141] [01-01 18:12:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:41 157] [01-01 18:12:32 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:41 157] [01-01 18:12:32 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:41 173] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:41 189] [01-01 18:12:32 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:41 205] [01-01 18:12:32 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:41 205] [01-01 18:12:32 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:41 205] [01-01 18:12:32 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:41 221] gethostbyname_r error: Unknown host
[2024/8/7 9:26:41 222] [01-01 18:12:32 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:41 222] [01-01 18:12:32 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:41 238] [01-01 18:12:32 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:41 238] [01-01 18:12:32 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:41 253] [01-01 18:12:32 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:41 253] [01-01 18:12:32 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:41 269] [01-01 18:12:32 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:41 269] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:41 269] [01-01 18:12:32 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:26:42 084] set basic_indicator_onoff:0 
[2024/8/7 9:26:42 101] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:42 101] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:42 117] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:42 117] set basic_indicator_onoff:1 
[2024/8/7 9:26:42 133] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:42 133] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:42 149] [1970-01-01 00:00:28] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time28365
[2024/8/7 9:26:42 149] set basic_indicator_onoff:0 
[2024/8/7 9:26:42 165] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:42 165] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:42 180] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:42 181] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:42 197] set basic_indicator_onoff:1 
[2024/8/7 9:26:42 197] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:42 213] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:42 213] set basic_indicator_onoff:0 
[2024/8/7 9:26:42 214] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:42 229] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:42 245] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:42 245] set basic_indicator_onoff:1 
[2024/8/7 9:26:42 245] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:42 261] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:42 277] [1970-01-01 00:00:28] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:42 277] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:42 277] set basic_indicator_onoff:0 
[2024/8/7 9:26:42 293] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:42 293] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:42 309] 
[2024/8/7 9:26:42 310] [01-01 18:12:33 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:42 310] [01-01 18:12:33 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:42 325] [01-01 18:12:33 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:42 325] [01-01 18:12:33 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:42 341] [01-01 18:12:33 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:42 341] [01-01 18:12:33 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:42 341] [01-01 18:12:33 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:42 357] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:42 357] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:42 357] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:42 373] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:42 373] [01-01 18:12:33 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:42 389] [01-01 18:12:33 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:42 389] [01-01 18:12:33 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:42 405] [01-01 18:12:33 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:42 421] [01-01 18:12:33 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:42 421] [01-01 18:12:33 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:42 437] [01-01 18:12:33 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:42 437] gethostbyname_r error: Unknown host
[2024/8/7 9:26:42 437] [01-01 18:12:33 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:42 453] [01-01 18:12:33 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:42 453] [01-01 18:12:33 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:42 469] [01-01 18:12:33 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:42 469] [01-01 18:12:33 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:42 485] [01-01 18:12:33 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:42 485] [01-01 18:12:33 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:42 501] [01-01 18:12:33 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:43 141] set basic_indicator_onoff:1 
[2024/8/7 9:26:43 141] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:43 157] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:43 173] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:43 173] set basic_indicator_onoff:0 
[2024/8/7 9:26:43 173] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:43 189] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:43 189] set basic_indicator_onoff:1 
[2024/8/7 9:26:43 204] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:43 205] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:43 221] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:43 222] set basic_indicator_onoff:0 
[2024/8/7 9:26:43 237] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:43 237] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:43 253] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:43 253] set basic_indicator_onoff:1 
[2024/8/7 9:26:43 270] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:43 270] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:43 270] set basic_indicator_onoff:0 
[2024/8/7 9:26:43 286] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:43 286] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:43 286] set basic_indicator_onoff:1 
[2024/8/7 9:26:43 301] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:43 317] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:43 319] 
[2024/8/7 9:26:43 319] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:43 319] set basic_indicator_onoff:0 
[2024/8/7 9:26:43 333] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:43 349] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:43 350] 
[2024/8/7 9:26:43 350] [01-01 18:12:34 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:43 350] [01-01 18:12:34 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:43 365] [01-01 18:12:34 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:43 365] [01-01 18:12:34 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:43 381] [01-01 18:12:34 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:43 381] [01-01 18:12:34 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:43 381] [01-01 18:12:34 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:43 397] [01-01 18:12:34 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:43 397] [01-01 18:12:34 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:43 397] [01-01 18:12:34 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:43 413] [01-01 18:12:34 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:43 413] [01-01 18:12:34 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:43 429] [01-01 18:12:34 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:43 429] [01-01 18:12:34 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:43 445] [01-01 18:12:34 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:43 461] [01-01 18:12:34 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:43 461] [01-01 18:12:34 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:43 477] [01-01 18:12:34 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:43 477] gethostbyname_r error: Unknown host
[2024/8/7 9:26:43 477] [01-01 18:12:34 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:43 493] [01-01 18:12:34 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:43 493] [01-01 18:12:34 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:43 573] [01-01 18:12:34 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:43 573] [01-01 18:12:34 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:43 589] [01-01 18:12:34 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:43 589] [01-01 18:12:34 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:43 605] [01-01 18:12:34 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:44 228] set basic_indicator_onoff:1 
[2024/8/7 9:26:44 244] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:44 244] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:44 261] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:44 261] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:44 261] set basic_indicator_onoff:0 
[2024/8/7 9:26:44 277] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:44 277] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:44 293] 
[2024/8/7 9:26:44 294] set basic_indicator_onoff:1 
[2024/8/7 9:26:44 294] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:44 309] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:44 309] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:44 325] set basic_indicator_onoff:0 
[2024/8/7 9:26:44 325] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:44 341] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:44 357] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:44 359] set basic_indicator_onoff:1 
[2024/8/7 9:26:44 359] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:44 373] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:44 373] set basic_indicator_onoff:0 
[2024/8/7 9:26:44 389] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:44 389] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:44 405] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:44 405] [01-01 18:12:35 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:44 421] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:44 421] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:44 421] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:44 437] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:44 437] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:44 437] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:44 454] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:44 454] [01-01 18:12:35 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:44 469] [01-01 18:12:35 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:44 469] [01-01 18:12:35 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:44 469] [01-01 18:12:35 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:44 485] [01-01 18:12:35 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:44 485] [01-01 18:12:35 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:44 517] [01-01 18:12:35 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:44 517] [01-01 18:12:35 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:44 533] [01-01 18:12:35 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:44 533] [01-01 18:12:35 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:44 533] gethostbyname_r error: Unknown host
[2024/8/7 9:26:44 549] [01-01 18:12:35 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:44 549] [01-01 18:12:35 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:44 565] [01-01 18:12:35 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:44 566] [01-01 18:12:35 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:44 566] [01-01 18:12:35 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:44 581] [01-01 18:12:35 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:44 581] [01-01 18:12:35 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:44 597] [01-01 18:12:35 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:45 317] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:26:45 317] set basic_indicator_onoff:1 
[2024/8/7 9:26:45 317] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 333] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:45 333] set basic_indicator_onoff:0 
[2024/8/7 9:26:45 349] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 349] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:45 365] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:45 365] set basic_indicator_onoff:1 
[2024/8/7 9:26:45 381] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 381] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:45 381] set basic_indicator_onoff:0 
[2024/8/7 9:26:45 397] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 397] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:45 413] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:45 428] [1970-01-01 00:00:32] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:45 429] set basic_indicator_onoff:1 
[2024/8/7 9:26:45 429] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 445] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:45 445] set basic_indicator_onoff:0 
[2024/8/7 9:26:45 461] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 461] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:45 477] [1970-01-01 00:00:32] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:45 477] --- tracepoint MainApp.c,ConfigTimer(392): g_WifiConectStatuts 0 ---
[2024/8/7 9:26:45 477] curr event:1 
[2024/8/7 9:26:45 493] IPC_APP_Notify_LED_Sound_Status_CB line(467) -------------------------- IPC_REV_WIFI_CFG(1)
[2024/8/7 9:26:45 509] [1970-01-01 00:00:32] tuya_ipc_system_control_demo.c(468) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(WAIT_CONNECT, 0, 0, 0, 1))
[2024/8/7 9:26:45 509] set basic_indicator_onoff:1 
[2024/8/7 9:26:45 525] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 525] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:45 541] [1970-01-01 00:00:32] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/WaitWifiConfig_english.pcm]
[2024/8/7 9:26:45 541] [1970-01-01 00:00:32] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:45 557] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:26:45 557] [01-01 18:12:36 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:26:45 572] [01-01 18:12:36 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:45 573] [01-01 18:12:36 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:45 573] [01-01 18:12:36 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:45 588] [01-01 18:12:36 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:45 588] [01-01 18:12:36 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:45 604] [01-01 18:12:36 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:45 604] [01-01 18:12:36 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:45 605] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:45 620] [01-01 18:12:36 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:45 621] [01-01 18:12:36 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:45 621] [01-01 18:12:36 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:45 637] [01-01 18:12:36 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:45 637] [01-01 18:12:36 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:45 653] [01-01 18:12:36 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:45 669] [01-01 18:12:36 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:45 685] [01-01 18:12:36 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:45 685] [01-01 18:12:36 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:45 700] [01-01 18:12:36 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:45 701] 
[2024/8/7 9:26:45 701] gethostbyname_r error: Unknown host
[2024/8/7 9:26:45 701] [01-01 18:12:36 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:45 717] [01-01 18:12:36 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:45 717] [01-01 18:12:36 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:45 717] [01-01 18:12:36 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:45 733] [1970-01-01 00:00:32] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:45 749] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:0
[2024/8/7 9:26:45 749] set basic_indicator_onoff:0 
[2024/8/7 9:26:45 749] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 765] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:45 765] [01-01 18:12:36 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:45 780] [01-01 18:12:36 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:45 780] [01-01 18:12:36 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:45 796] [01-01 18:12:36 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:45 877] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:45 877] set basic_indicator_onoff:1 
[2024/8/7 9:26:45 893] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 893] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:45 909] [1970-01-01 00:00:32] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time32723
[2024/8/7 9:26:45 909] [1970-01-01 00:00:32] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:45 925] set basic_indicator_onoff:0 
[2024/8/7 9:26:45 926] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 941] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:45 941] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:45 941] ble_slave_gap_event->type=0
[2024/8/7 9:26:45 957] connection established; status=0 GATT procedure initiated: exchange mtu
[2024/8/7 9:26:45 957] connection, handle=1
[2024/8/7 9:26:45 957] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:45 957] set basic_indicator_onoff:1 
[2024/8/7 9:26:45 973] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:45 989] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:45 990] [1970-01-01 00:00:33] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:46 004] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 005] ble_slave_gap_event->type=15
[2024/8/7 9:26:46 005] mtu update event; conn_handle=1 cid=4 mtu=255
[2024/8/7 9:26:46 021] --- tracepoint bt_ext_porting.c,ty_btext_thread(423): TY_BT_EVENT_CONNECTED1 ---
[2024/8/7 9:26:46 021] [01-01 18:12:37 TUYA D][tuya_ble_api.c:543] rev ble event 1
[2024/8/7 9:26:46 021] [01-01 18:12:37 TUYA N][tuya_ble_api.c:472] Ble Connected
[2024/8/7 9:26:46 036] [01-01 18:12:37 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[2024/8/7 9:26:46 036] [01-01 18:12:37 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
[2024/8/7 9:26:46 325] --- tracepoint bt_ext_porting.c,ty_btext_thread(425): TY_BT_EVENT_CONNECTED2 ---
[2024/8/7 9:26:46 325] set basic_indicator_onoff:0 
[2024/8/7 9:26:46 341] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:46 341] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:46 357] 
[2024/8/7 9:26:46 358] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 358] ble_slave_gap_event->type=4
[2024/8/7 9:26:46 358] connection update request
[2024/8/7 9:26:46 373] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 373] [1970-01-01 00:00:33] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:46 389] set basic_indicator_onoff:1 
[2024/8/7 9:26:46 389] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:46 405] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:46 405] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 421] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 421] set basic_indicator_onoff:0 
[2024/8/7 9:26:46 421] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:46 437] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:46 437] [01-01 18:12:37 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:46 453] [01-01 18:12:37 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:46 453] [01-01 18:12:37 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:46 469] [01-01 18:12:37 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:46 470] [01-01 18:12:37 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:46 470] [01-01 18:12:37 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:46 485] [01-01 18:12:37 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:46 485] [01-01 18:12:37 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:46 485] [01-01 18:12:37 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:46 501] [01-01 18:12:37 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:46 501] [01-01 18:12:37 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:46 517] [01-01 18:12:37 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:46 517] [01-01 18:12:37 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:46 517] [01-01 18:12:37 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:46 549] [01-01 18:12:37 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:46 549] [01-01 18:12:37 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:46 565] [01-01 18:12:37 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:46 565] [01-01 18:12:37 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:46 565] gethostbyname_r error: Unknown host
[2024/8/7 9:26:46 581] [01-01 18:12:37 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:46 581] [01-01 18:12:37 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:46 597] [01-01 18:12:37 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:46 597] [01-01 18:12:37 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:46 613] [01-01 18:12:37 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:46 613] [01-01 18:12:37 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:46 629] [01-01 18:12:37 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:46 629] [01-01 18:12:37 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:46 629] [01-01 18:12:37 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:26:46 758] set basic_indicator_onoff:1 
[2024/8/7 9:26:46 773] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:46 789] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:46 790] 
[2024/8/7 9:26:46 790] [1970-01-01 00:00:33] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:46 805] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 805] set basic_indicator_onoff:0 
[2024/8/7 9:26:46 821] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:46 821] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:46 821] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 837] [1970-01-01 00:00:33] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:46 853] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 853] ble_slave_gap_event->type=3
[2024/8/7 9:26:46 868] connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:26:46 869] set basic_indicator_onoff:1 
[2024/8/7 9:26:46 869] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:46 884] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:46 885] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 900] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 900] g_AudioTipsList.size() enable: 0[1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:46 916] [01-01 18:12:38 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:26:47 333] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 348] set basic_indicator_onoff:0 
[2024/8/7 9:26:47 348] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:47 365] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:47 365] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 381] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 381] set basic_indicator_onoff:1 
[2024/8/7 9:26:47 397] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:47 397] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:47 413] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 429] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 445] [1970-01-01 00:00:34] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:47 447] set basic_indicator_onoff:0 
[2024/8/7 9:26:47 447] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:47 461] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:47 461] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 461] ble_slave_gap_event->type=4
[2024/8/7 9:26:47 477] connection update request
[2024/8/7 9:26:47 477] ble_slave_gap_event->type=14
[2024/8/7 9:26:47 477] subscribe event; conn_handle=1 attr_handle=23 reason=1 prevn=0 curn=1 previ=0 curi=0
[2024/8/7 9:26:47 493] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:26:47 493] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 509] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 509] ble_slave_gap_event->type=3
[2024/8/7 9:26:47 509] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:26:47 525] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 525] set basic_indicator_onoff:1 
[2024/8/7 9:26:47 541] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:47 541] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:47 557] [1970-01-01 00:00:34] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:47 557] [01-01 18:12:38 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:47 573] [01-01 18:12:38 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:47 573] [01-01 18:12:38 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:47 573] [01-01 18:12:38 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:47 589] [01-01 18:12:38 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:47 589] [01-01 18:12:38 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:47 605] [01-01 18:12:38 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:47 605] [01-01 18:12:38 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:47 605] [01-01 18:12:38 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:47 621] [01-01 18:12:38 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:47 621] [01-01 18:12:38 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:47 621] [01-01 18:12:38 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:47 637] [01-01 18:12:38 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:47 637] [01-01 18:12:38 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:47 669] [01-01 18:12:38 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:47 669] [01-01 18:12:38 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:47 685] [01-01 18:12:38 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:47 685] [01-01 18:12:38 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:47 685] gethostbyname_r error: Unknown host
[2024/8/7 9:26:47 717] [01-01 18:12:38 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:47 717] [01-01 18:12:38 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:47 717] [01-01 18:12:38 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:47 733] [01-01 18:12:38 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:47 733] [01-01 18:12:38 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:47 749] [01-01 18:12:38 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:47 749] [01-01 18:12:38 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:47 765] [01-01 18:12:38 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:47 765] set basic_indicator_onoff:0 
[2024/8/7 9:26:47 782] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:47 784] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:47 784] [1970-01-01 00:00:34] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:47 797] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:26:47 813] [1970-01-01 00:00:34] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:47 813] set basic_indicator_onoff:1 
[2024/8/7 9:26:47 829] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:47 830] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:47 830] set basic_indicator_onoff:0 
[2024/8/7 9:26:47 845] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:47 845] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:47 861] [1970-01-01 00:00:34] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:47 861] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 878] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:47 878] Len=20 step 0
[2024/8/7 9:26:47 878] att=0x0 0x21 0x20 0x1 0x72 0xb5 0x79 0x90 0xd8 0x3e 0xab 0x64 0xcc 0x6c 0x62 0x48 0xcd 0x3b 0xd5 0x64 
[2024/8/7 9:26:47 893]  RCVS len:20
[2024/8/7 9:26:47 893] set basic_indicator_onoff:1 
[2024/8/7 9:26:47 893] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:47 908] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:47 909] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:47 909] XmBleReadBuf 20:
[2024/8/7 9:26:47 925] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:47 925] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:47 925] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:47 941] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:47 941] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:47 956] [01-01 18:12:39 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:47 956] [01-01 18:12:39 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:47 956] [01-01 18:12:39 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:47 956] bt_rev_raw 20
[2024/8/7 9:26:47 972] 00 21 20 01 72 b5 79 90 d8 3e ab 64 cc 6c 62 48 cd 3b d5 64 
[2024/8/7 9:26:47 972] [01-01 18:12:39 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:26:47 988] [01-01 18:12:39 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:47 988] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:48 004] [1970-01-01 00:00:34] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:48 004] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:48 004] Len=17 step 0
[2024/8/7 9:26:48 020] att=0x1 0xab 0x37 0xea 0x24 0x88 0xd2 0x64 0x68 0xa7 0xa4 0x76 0xd5 0xee 0xbc 0x8d 0xa1 
[2024/8/7 9:26:48 020]  RCVS len:17
[2024/8/7 9:26:48 020] set basic_indicator_onoff:0 
[2024/8/7 9:26:48 020] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:48 036] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:48 036] [1970-01-01 00:00:35] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:26:48 052] XmBleReadBuf 17:
[2024/8/7 9:26:48 052] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:48 052] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:48 052] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:48 068] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:26:48 068] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:26:48 084] [01-01 18:12:39 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:26:48 084] [01-01 18:12:39 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:48 100] [01-01 18:12:39 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:48 100] bt_rev_raw 17
[2024/8/7 9:26:48 100] 01 ab 37 ea 24 88 d2 64 68 a7 a4 76 d5 ee bc 8d a1 
[2024/8/7 9:26:48 117] [01-01 18:12:39 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:26:48 117] ble rev data 33
[2024/8/7 9:26:48 117] 01 72 b5 79 90 d8 3e ab 64 cc 6c 62 48 cd 3b d5 64 ab 37 ea 24 88 d2 64 68 a7 a4 76 d5 ee bc 8d a1 
[2024/8/7 9:26:48 133] [01-01 18:12:39 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:26:48 133] ble decryped data 16
[2024/8/7 9:26:48 133] 00 00 00 01 00 00 00 00 00 00 00 00 92 69 00 00 
[2024/8/7 9:26:48 133] [01-01 18:12:39 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:26:48 149] [01-01 18:12:39 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x0 
[2024/8/7 9:26:48 149] [01-01 18:12:39 TUYA N][tuya_ble_data_handler.c:451] tuya_ble_handle_dev_infor_req state:0, pkg_len:20
[2024/8/7 9:26:48 165] [01-01 18:12:39 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:26:48 165] [01-01 18:12:39 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:26:48 165] [01-01 18:12:39 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:26:48 181] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:26:48 181] Mode(Product):0
[2024/8/7 9:26:48 181] BpuMode:[Online]
[2024/8/7 9:26:48 181] VpssMode:[Online]
[2024/8/7 9:26:48 181] [0.LimitUp_info]:
[2024/8/7 9:26:48 181] LimitUp:[Disable]
[2024/8/7 9:26:48 181] [2680*0]->[3840*0])
[2024/8/7 9:26:48 181] chn	TotalSize	ActiveSize
[2024/8/7 9:26:48 197] 0	5040*2246	2680*2160
[2024/8/7 9:26:48 197] 0	5040*2246	3840*2160
[2024/8/7 9:26:48 197] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:26:48 197] [1.VICU_info]:
[2024/8/7 9:26:48 197] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:26:48 213] 0	25.0	677	0	0	183	linear	8ddb00
[2024/8/7 9:26:48 213] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:26:48 213] en	op_type	m_chn	now
[2024/8/7 9:26:48 213] 0	1	1	1
[2024/8/7 9:26:48 213] [2.VI_info]:
[2024/8/7 9:26:48 213] chn	TotalSize	ActiveSize
[2024/8/7 9:26:48 213] 0	5040*2246	3848*2166
[2024/8/7 9:26:48 213] 1	   0*   0	   0*   0
[2024/8/7 9:26:48 229] [3.MIPI_info]:
[2024/8/7 9:26:48 229] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:26:48 229] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:26:48 229] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:26:48 245] [4.Cut_info]:
[2024/8/7 9:26:48 245] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:26:48 245] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:26:48 245] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:26:48 245] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:26:48 260] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:26:48 260] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:26:48 260] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:26:48 261] [5.IB(isp buffer info)]:
[2024/8/7 9:26:48 261] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:26:48 276] PoolId  Count  Size
[2024/8/7 9:26:48 276] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:48 276] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:48 292] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:48 325] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:48 325] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:26:48 341] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:26:48 342] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:26:48 342] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:48 357] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:4, send_data:16
[2024/8/7 9:26:48 357] tuya_hal_bt_send 20
[2024/8/7 9:26:48 357] 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:26:48 372] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:48 372] 0 81 1 30 1 57 27 a7 5 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:26:48 389] XmBleSendBuf 20: 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58
[2024/8/7 9:26:48 389] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:48 389] ble_slave_gap_event->type=13
[2024/8/7 9:26:48 389] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:48 389] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:48 405]  ---
[2024/8/7 9:26:48 405] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:48 405] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:26:48 421] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:26:48 421] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:26:48 421] 0       0         0          0          4       
[2024/8/7 9:26:48 437] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:26:48 437]      --265--            --264--                                               
[2024/8/7 9:26:48 437] Count      Line     Count      Line     
[2024/8/7 9:26:48 437] 518        480      1260       560      
[2024/8/7 9:26:48 453] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:26:48 453] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:26:48 469] 0   3840   2160    H265  0      0        0           312       983038     2        	
[2024/8/7 9:26:48 469] 1   640    360     H265  0      0        0           201       43198      2        	
[2024/8/7 9:26:48 485] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:26:48 485] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:26:48 501] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:26:48 517] 0   Y      312      0       0       15       0        312      312      439       62739         59145    89933    63767    11      
[2024/8/7 9:26:48 517] 1   Y      201      0       5       1        0        201      201      440       2528          1928     34379    2834     7       
[2024/8/7 9:26:48 533] 3   N      0        0       0       1        0        0        0        442       0             0        0        0        0       
[2024/8/7 9:26:48 549] [1970-01-01 00:00:35] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:26:48 549] set basic_indicator_onoff:1 
[2024/8/7 9:26:48 549] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:48 565] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:48 581] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:26:48 581] tuya_hal_bt_send 20
[2024/8/7 9:26:48 581] 01 3d 20 0f 9d e8 22 82 9d 1e 66 77 d1 4e d6 54 f1 ff 60 d7 
[2024/8/7 9:26:48 581] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:48 596] 1 3d 20 f 9d e8 22 82 9d 1e 66 77 d1 4e d6 54 f1 ff 60 d7 
[2024/8/7 9:26:48 597] XmBleSendBuf 20: 01 3d 20 0f 9d e8 22 82 9d 1e 66 77 d1 4e d6 54 f1 ff 60 d7
[2024/8/7 9:26:48 597] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:48 612] ble_slave_gap_event->type=13
[2024/8/7 9:26:48 612] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:48 613] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:48 629] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:48 629] [1970-01-01 00:00:35] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:48 645] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:48 645] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:26:48 645] tuya_hal_bt_send 20
[2024/8/7 9:26:48 661] 02 86 b7 41 00 46 d5 be 1d e1 4e 98 27 9d 05 52 6d 5b a9 ee 
[2024/8/7 9:26:48 661] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:48 661] 2 86 b7 41 0 46 d5 be 1d e1 4e 98 27 9d 5 52 6d 5b a9 ee 
[2024/8/7 9:26:48 676] XmBleSendBuf 20: 02 86 b7 41 00 46 d5 be 1d e1 4e 98 27 9d 05 52 6d 5b a9 ee
[2024/8/7 9:26:48 676] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:48 676] ble_slave_gap_event->type=13
[2024/8/7 9:26:48 692] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:48 693] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:48 693] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:48 708] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:26:48 708] tuya_hal_bt_send 20
[2024/8/7 9:26:48 708] 03 5c 03 c1 c7 4b da 55 71 1b c5 9a a6 21 b6 3a 62 07 27 90 
[2024/8/7 9:26:48 724] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:48 724] 3 5c 3 c1 c7 4b da 55 71 1b c5 9a a6 21 b6 3a 62 7 27 90 
[2024/8/7 9:26:48 724] XmBleSendBuf 20: 03 5c 03 c1 c7 4b da 55 71 1b c5 9a a6 21 b6 3a 62 07 27 90
[2024/8/7 9:26:48 740] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:48 740] ble_slave_gap_event->type=13
[2024/8/7 9:26:48 740] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:48 741] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:48 756] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:48 756] set basic_indicator_onoff:0 
[2024/8/7 9:26:48 756] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:48 772] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:48 788] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:48 788] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:26:48 788] tuya_hal_bt_send 20
[2024/8/7 9:26:48 804] 04 0f 25 41 ac 6a a6 16 e8 2c 26 f4 f1 53 f8 00 d8 1e 84 49 
[2024/8/7 9:26:48 804] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:48 804] 4 f 25 41 ac 6a a6 16 e8 2c 26 f4 f1 53 f8 0 d8 1e 84 49 
[2024/8/7 9:26:48 820] XmBleSendBuf 20: 04 0f 25 41 ac 6a a6 16 e8 2c 26 f4 f1 53 f8 00 d8 1e 84 49
[2024/8/7 9:26:48 820] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:48 820] ble_slave_gap_event->type=13
[2024/8/7 9:26:48 820] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:48 837] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:48 837] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:48 853] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:48 853] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:26:48 853] tuya_hal_bt_send 20
[2024/8/7 9:26:48 869] 05 86 66 12 74 81 5f 28 22 b3 54 9a ed bb 62 cf ff 70 12 10 
[2024/8/7 9:26:48 869] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:48 869] 5 86 66 12 74 81 5f 28 22 b3 54 9a ed bb 62 cf ff 70 12 10 
[2024/8/7 9:26:48 885] XmBleSendBuf 20: 05 86 66 12 74 81 5f 28 22 b3 54 9a ed bb 62 cf ff 70 12 10
[2024/8/7 9:26:48 885] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:48 885] ble_slave_gap_event->type=13
[2024/8/7 9:26:48 901] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:48 901] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:48 901] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:48 917] [1970-01-01 00:00:35] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:48 917] set basic_indicator_onoff:1 
[2024/8/7 9:26:48 932] [01-01 18:12:39 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:18
[2024/8/7 9:26:48 932] tuya_hal_bt_send 19
[2024/8/7 9:26:48 933] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:48 949] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:48 949] 06 41 cd d7 26 c2 2d 0d 5e 21 89 e9 92 1e 46 10 92 cf a9 
[2024/8/7 9:26:48 964] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:48 964] [01-01 18:12:39 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:48 964] 6 41 cd d7 26 c2 2d d 5e 21 89 e9 92 1e 46 10 92 cf a9 
[2024/8/7 9:26:48 980] XmBleSendBuf 19: 06 41 cd d7 26 c2 2d 0d 5e 21 89 e9 92 1e 46 10 92 cf a9
[2024/8/7 9:26:48 980] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:48 980] ble_slave_gap_event->type=13
[2024/8/7 9:26:48 996] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:48 996] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:48 996] [01-01 18:12:39 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:49 012] [01-01 18:12:39 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:129, send_ret:0x0
[2024/8/7 9:26:49 012] [01-01 18:12:39 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:0
[2024/8/7 9:26:49 028] [01-01 18:12:39 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:49 029] [01-01 18:12:39 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:49 029] [01-01 18:12:39 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:49 141] [01-01 18:12:39 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:49 141] [01-01 18:12:39 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:49 141] [01-01 18:12:39 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:49 156] [01-01 18:12:39 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:49 157] [01-01 18:12:39 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:49 157] [01-01 18:12:39 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:49 173] [01-01 18:12:39 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:49 173] [01-01 18:12:39 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:49 188] [01-01 18:12:39 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:49 188] [01-01 18:12:39 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:49 188] [01-01 18:12:39 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:49 220] [01-01 18:12:39 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:49 220] [01-01 18:12:39 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:49 236] [01-01 18:12:39 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:49 236] [01-01 18:12:39 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:49 236] gethostbyname_r error: Unknown host
[2024/8/7 9:26:49 252] [01-01 18:12:39 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:49 252] [01-01 18:12:39 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:49 268] [01-01 18:12:39 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:26:49 268] [01-01 18:12:39 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:49 284] [01-01 18:12:39 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:49 284] [01-01 18:12:39 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:49 300] [01-01 18:12:39 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:49 300] [01-01 18:12:40 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:49 300] set basic_indicator_onoff:0 
[2024/8/7 9:26:49 317] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:49 317] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:49 333] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:49 333] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:49 333] Len=20 step 0
[2024/8/7 9:26:49 349] att=0x0 0x51 0x20 0x2 0xbc 0xd1 0x6b 0x15 0x94 0x61 0xf 0x5f 0xa2 0xd4 0x8c 0x7c 0x2d 0x1b 0x4e 0x46 
[2024/8/7 9:26:49 349]  RCVS len:20
[2024/8/7 9:26:49 349] [1970-01-01 00:00:35] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:49 365] XmBleReadBuf 20:
[2024/8/7 9:26:49 365] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:49 365] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:49 365] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:49 381] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:49 381] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:49 397] [01-01 18:12:40 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:49 397] [01-01 18:12:40 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:49 413] [01-01 18:12:40 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:49 413] bt_rev_raw 20
[2024/8/7 9:26:49 413] 00 51 20 02 bc d1 6b 15 94 61 0f 5f a2 d4 8c 7c 2d 1b 4e 46 
[2024/8/7 9:26:49 429] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:26:49 429] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:49 445] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:49 446] set basic_indicator_onoff:1 
[2024/8/7 9:26:49 446] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:49 461] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:49 461] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:49 461] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:49 477]  ---
[2024/8/7 9:26:49 477] Len=20 step 0
[2024/8/7 9:26:49 477] att=0x1 0x22 0x7 0x83 0x8c 0x6f 0x32 0xfc 0xd0 0xc3 0x96 0x5c 0xc8 0xe4 0xad 0x93 0xb 0x6f 0x9f 0x19 
[2024/8/7 9:26:49 477]  RCVS len:20
[2024/8/7 9:26:49 477] XmBleReadBuf 20:
[2024/8/7 9:26:49 493] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:49 493] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:49 493] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:49 509] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:49 509] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:49 525] [01-01 18:12:40 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:49 525] [01-01 18:12:40 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:49 525] [01-01 18:12:40 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:49 525] bt_rev_raw 20
[2024/8/7 9:26:49 541] 01 22 07 83 8c 6f 32 fc d0 c3 96 5c c8 e4 ad 93 0b 6f 9f 19 
[2024/8/7 9:26:49 541] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:26:49 557] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:49 557] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:49 573] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:49 573] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:49 573] Len=20 step 0
[2024/8/7 9:26:49 589] att=0x2 0x4a 0x2f 0xe8 0x9a 0x4e 0x37 0xfd 0x1f 0xd 0xe1 0xa8 0x29 0x2b 0xc3 0xd8 0xa9 0x8f 0x7a 0x40 
[2024/8/7 9:26:49 589]  RCVS len:20
[2024/8/7 9:26:49 589] set basic_indicator_onoff:0 
[2024/8/7 9:26:49 605] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:49 605] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:49 621] [1970-01-01 00:00:36] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:49 621] [1970-01-01 00:00:36] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:49 637] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:49 637] Len=20 step 0
[2024/8/7 9:26:49 637] att=0x3 0x1d 0xe9 0xb5 0x57 0x76 0x94 0x93 0x74 0x0 0x10 0x9e 0xce 0x4c 0x7b 0xeb 0xdc 0xad 0x2e 0x6c 
[2024/8/7 9:26:49 637]  RCVS len:20
[2024/8/7 9:26:49 637] XmBleReadBuf 20:
[2024/8/7 9:26:49 653] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:49 653] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:49 653] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:49 669] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:49 669] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:49 685] [01-01 18:12:40 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:49 685] [01-01 18:12:40 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:49 685] [01-01 18:12:40 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:49 685] bt_rev_raw 20
[2024/8/7 9:26:49 701] 02 4a 2f e8 9a 4e 37 fd 1f 0d e1 a8 29 2b c3 d8 a9 8f 7a 40 
[2024/8/7 9:26:49 701] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:26:49 717] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:49 717] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:49 733] set basic_indicator_onoff:1 
[2024/8/7 9:26:49 734] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:49 749] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:49 749] XmBleReadBuf 20:
[2024/8/7 9:26:49 749] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:49 749] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:49 765] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:49 765] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:49 765] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:49 781] [01-01 18:12:40 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:49 781] [01-01 18:12:40 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:49 797] [01-01 18:12:40 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:49 797] bt_rev_raw 20
[2024/8/7 9:26:49 797] 03 1d e9 b5 57 76 94 93 74 00 10 9e ce 4c 7b eb dc ad 2e 6c 
[2024/8/7 9:26:49 813] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:26:49 813] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:49 829] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:49 829] [1970-01-01 00:00:36] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:49 829] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:49 829] Len=8 step 0
[2024/8/7 9:26:49 845] att=0x4 0xa1 0xdb 0x37 0xc7 0x61 0x6d 0x4 
[2024/8/7 9:26:49 845]  RCVS len:8
[2024/8/7 9:26:49 845] XmBleReadBuf 8:
[2024/8/7 9:26:49 876] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:49 877] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:49 877] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:49 893] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 16 rcount 16 offset 0 ---
[2024/8/7 9:26:49 893] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 16 ---
[2024/8/7 9:26:49 909] [01-01 18:12:40 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x9]
[2024/8/7 9:26:49 909] [01-01 18:12:40 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:49 909] [01-01 18:12:40 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:49 909] bt_rev_raw 8
[2024/8/7 9:26:49 909] 04 a1 db 37 c7 61 6d 04 
[2024/8/7 9:26:49 924] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:5, pack_len:7, total_len:81
[2024/8/7 9:26:49 924] ble rev data 81
[2024/8/7 9:26:49 941] 02 bc d1 6b 15 94 61 0f 5f a2 d4 8c 7c 2d 1b 4e 46 22 07 83 8c 6f 32 fc d0 c3 96 5c c8 e4 ad 93 0b 6f 9f 19 4a 2f e8 9a 4e 37 fd 1f 0d e1 a8 29 2b c3 d8 a9 8f 7a 40 1d e9 b5 57 76 94 93 74 00 
[2024/8/7 9:26:49 956] 10 9e ce 4c 7b eb dc ad 2e 6c a1 db 37 c7 61 6d 04 
[2024/8/7 9:26:49 956] ble decryped data 64
[2024/8/7 9:26:49 972] 00 00 00 02 00 00 00 00 00 01 00 2c 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca 1e 00 00 00 00 00 00 
[2024/8/7 9:26:49 972] [01-01 18:12:40 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:26:49 972] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x1 
[2024/8/7 9:26:49 988] [01-01 18:12:40 TUYA D][tuya_ble_api.c:573] conn monitor timer stopped
[2024/8/7 9:26:49 988] [01-01 18:12:40 TUYA N][tuya_ble_api.c:1464] ble set conn stat:3
[2024/8/7 9:26:50 004] [01-01 18:12:40 TUYA N][tuya_ble_data_handler.c:367] PAIR_REQ ok:0
[2024/8/7 9:26:50 004] [01-01 18:12:40 TUYA N][tuya_ble_data_handler.c:342] ble_time_req start...
[2024/8/7 9:26:50 020] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:348] no need to query time. network stat:1, work stat:0
[2024/8/7 9:26:50 020] [01-01 18:12:40 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:26:50 020] [01-01 18:12:40 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:50 036] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:16 ---
[2024/8/7 9:26:50 036] [01-01 18:12:40 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:26:50 036] tuya_hal_bt_send 20
[2024/8/7 9:26:50 052] 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:26:50 052] [01-01 18:12:40 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:50 052] 0 21 31 2 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:26:50 068] XmBleSendBuf 20: 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c
[2024/8/7 9:26:50 068] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:50 068] ble_slave_gap_event->type=13
[2024/8/7 9:26:50 084] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:50 084] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:50 084] [01-01 18:12:40 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:50 100] [01-01 18:12:40 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:26:50 100] tuya_hal_bt_send 17
[2024/8/7 9:26:50 100] 01 21 e6 73 bb 42 32 a4 2b 48 a9 a5 e0 20 32 b9 ba 
[2024/8/7 9:26:50 116] [01-01 18:12:40 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:50 116] 1 21 e6 73 bb 42 32 a4 2b 48 a9 a5 e0 20 32 b9 ba 
[2024/8/7 9:26:50 116] XmBleSendBuf 17: 01 21 e6 73 bb 42 32 a4 2b 48 a9 a5 e0 20 32 b9 ba
[2024/8/7 9:26:50 132] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:50 132] ble_slave_gap_event->type=13
[2024/8/7 9:26:50 132] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:50 132] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:50 148] [01-01 18:12:40 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:50 148] set basic_indicator_onoff:0 
[2024/8/7 9:26:50 164] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:50 165] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:50 180] [1970-01-01 00:00:36] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:50 180] [1970-01-01 00:00:36] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:50 196] [01-01 18:12:40 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:26:50 196] [01-01 18:12:40 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:1
[2024/8/7 9:26:50 212] [1970-01-01 00:00:36] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:50 212] [01-01 18:12:40 TUYA D][tuya_ble_api.c:1376] nw stat change:1->1, rpt to app.
[2024/8/7 9:26:50 212] [01-01 18:12:40 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:26:50 228] set basic_indicator_onoff:1 
[2024/8/7 9:26:50 260] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:50 276] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:50 276] [1970-01-01 00:00:36] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:50 276] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:50 276] Len=20 step 0
[2024/8/7 9:26:50 292] att=0x0 0x61 0x20 0x2 0xb5 0x95 0xdb 0xb7 0x6e 0x25 0x2c 0xcc 0xba 0xe4 0x1a 0xad 0x47 0x5f 0x5b 0x77 
[2024/8/7 9:26:50 292]  RCVS len:20
[2024/8/7 9:26:50 292] XmBleReadBuf 20:
[2024/8/7 9:26:50 292] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:50 308] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:50 308] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:50 324] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:50 324] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:50 324] [01-01 18:12:40 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:50 340] [01-01 18:12:40 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:50 340] [01-01 18:12:40 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:50 340] bt_rev_raw 20
[2024/8/7 9:26:50 356] 00 61 20 02 b5 95 db b7 6e 25 2c cc ba e4 1a ad 47 5f 5b 77 
[2024/8/7 9:26:50 356] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:26:50 372] [01-01 18:12:40 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:50 372] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:50 372] set basic_indicator_onoff:0 
[2024/8/7 9:26:50 388] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:50 388] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:50 404] [1970-01-01 00:00:36] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time36569
[2024/8/7 9:26:50 404] [01-01 18:12:41 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:26:50 420] [01-01 18:12:41 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:50 420] [01-01 18:12:41 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:50 420] [01-01 18:12:41 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:50 436] [01-01 18:12:41 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:50 436] [01-01 18:12:41 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:50 452] [01-01 18:12:41 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:50 452] [01-01 18:12:41 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:50 452] [01-01 18:12:41 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:50 468] [01-01 18:12:41 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:50 468] [01-01 18:12:41 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:50 484] [01-01 18:12:41 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:50 484] [01-01 18:12:41 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:50 484] [01-01 18:12:41 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:26:50 516] [01-01 18:12:41 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:50 516] [01-01 18:12:41 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:26:50 533] [01-01 18:12:41 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:50 533] [01-01 18:12:41 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:26:50 533] gethostbyname_r error: Unknown host
[2024/8/7 9:26:50 549] [01-01 18:12:41 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:26:50 549] [01-01 18:12:41 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:26:50 565] [01-01 18:12:41 TUYA E][httpc.c:456] No entry for host[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:26:50 565]  h2.iot-dns.com found. -5
[2024/8/7 9:26:50 565] [01-01 18:12:41 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:26:50 581] [01-01 18:12:41 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:26:50 581] [01-01 18:12:41 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:26:50 597] [01-01 18:12:41 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:26:50 597] [01-01 18:12:41 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:26:50 613] [1970-01-01 00:00:36] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:50 613] [1970-01-01 00:00:36] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:50 629] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:50 629] Len=20 step 0
[2024/8/7 9:26:50 629] att=0x1 0x86 0xe6 0x7c 0x65 0xdd 0x7f 0xb6 0x0 0x58 0x5d 0xe3 0xe4 0xc1 0xff 0xd1 0x45 0x66 0xe0 0x43 
[2024/8/7 9:26:50 629]  RCVS len:20
[2024/8/7 9:26:50 645] XmBleReadBuf 20:
[2024/8/7 9:26:50 645] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:50 645] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:50 676] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:50 693] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:50 693] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:50 709] [01-01 18:12:41 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:50 709] [01-01 18:12:41 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:50 709] [01-01 18:12:41 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:50 709] bt_rev_raw 20
[2024/8/7 9:26:50 725] 01 86 e6 7c 65 dd 7f b6 00 58 5d e3 e4 c1 ff d1 45 66 e0 43 
[2024/8/7 9:26:50 725] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:26:50 741] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:50 741] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:50 741] set basic_indicator_onoff:1 
[2024/8/7 9:26:50 756] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:50 756] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:50 772] 
[2024/8/7 9:26:50 788] [1970-01-01 00:00:36] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:50 789] [1970-01-01 00:00:36] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:50 804] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:50 804] Len=20 step 0
[2024/8/7 9:26:50 805] att=0x2 0x4f 0x8e 0x40 0xad 0x94 0x1a 0x40 0xc 0xb6 0x2d 0x48 0xa 0x53 0xf 0x7f 0xb2 0x4 0xe4 0xf7 
[2024/8/7 9:26:50 805]  RCVS len:20
[2024/8/7 9:26:50 820] set basic_indicator_onoff:0 
[2024/8/7 9:26:50 820] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:50 837] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:50 837] XmBleReadBuf 20:
[2024/8/7 9:26:50 837] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:50 837] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:50 853] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:50 853] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:50 869] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:50 869] [01-01 18:12:41 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:50 869] [01-01 18:12:41 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:50 885] [01-01 18:12:41 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:50 885] bt_rev_raw 20
[2024/8/7 9:26:50 885] 02 4f 8e 40 ad 94 1a 40 0c b6 2d 48 0a 53 0f 7f b2 04 e4 f7 
[2024/8/7 9:26:50 901] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:26:50 902] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:50 917] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:50 917] [1970-01-01 00:00:36] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:50 917] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:50 933]  ---
[2024/8/7 9:26:50 933] Len=20 step 0
[2024/8/7 9:26:50 934] att=0x3 0x41 0xee 0x3f 0x1d 0xa9 0xdf 0xb1 0xfd 0[atbm_log]:[ieee80211_csa_cancel][mon.eth2]:[0][0]
[2024/8/7 9:26:50 934] x8e 0x71 0xb7 0x39 0xf8 0x2f 0x98 0x4 0x7f 0xf 0x6b 
[2024/8/7 9:26:50 949]  RCVS len:20
[2024/8/7 9:26:50 949] XmBleReadBuf 20:
[2024/8/7 9:26:50 949] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:50 949] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:50 965] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:50 965] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:50 965] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:50 981] [01-01 18:12:41 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:50 981] [01-01 18:12:41 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:50 997] [01-01 18:12:41 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:50 997] bt_rev_raw 20
[2024/8/7 9:26:50 997] 03 41 ee 3f 1d a9 df b1 fd 8e 71 b7 39 f8 2f 98 04 7f 0f 6b 
[2024/8/7 9:26:51 012] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:26:51 013] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:51 028] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:51 028] set basic_indicator_onoff:1 
[2024/8/7 9:26:51 029] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 044] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:51 044] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:51 060] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:51 060] Len=20 step 0
[2024/8/7 9:26:51 060] att=0x4 0xc6 0x31 0xcc 0xef 0x22 0x17 0x2b 0xc7 0x6d 0x5e 0x79 0x81 0x78 0x9b 0x74 0xf5 0x7e 0xf4 0xb2 
[2024/8/7 9:26:51 061]  RCVS len:20
[2024/8/7 9:26:51 061] XmBleReadBuf 20:
[2024/8/7 9:26:51 076] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:51 076] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:51 076] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:51 092] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:51 092] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:51 108] [01-01 18:12:41 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:51 108] [01-01 18:12:41 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:51 109] [01-01 18:12:41 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:51 109] bt_rev_raw 20
[2024/8/7 9:26:51 124] 04 c6 31 cc ef 22 17 2b c7 6d 5e 79 81 78 9b 74 f5 7e f4 b2 
[2024/8/7 9:26:51 124] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:5, pack_len:19, total_len:93
[2024/8/7 9:26:51 140] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:51 140] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:51 156] [1970-01-01 00:00:37] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:51 172] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:51 172] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:51 172] Len=5 step 0
[2024/8/7 9:26:51 172] att=0x5 0x62 0x47 0xec 0x9a 
[2024/8/7 9:26:51 172]  RCVS len:5
[2024/8/7 9:26:51 172] set basic_indicator_onoff:0 
[2024/8/7 9:26:51 188] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 188] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:51 204] XmBleReadBuf 5:
[2024/8/7 9:26:51 204] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:51 204] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:51 204] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:51 220] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 13 rcount 13 offset 0 ---
[2024/8/7 9:26:51 220] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 13 ---
[2024/8/7 9:26:51 236] [01-01 18:12:41 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x6]
[2024/8/7 9:26:51 236] [01-01 18:12:41 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:51 252] [01-01 18:12:41 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:51 253] bt_rev_raw 5
[2024/8/7 9:26:51 253] 05 62 47 ec 9a 
[2024/8/7 9:26:51 253] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:6, pack_len:4, total_len:97
[2024/8/7 9:26:51 253] ble rev data 97
[2024/8/7 9:26:51 268] 02 b5 95 db b7 6e 25 2c cc ba e4 1a ad 47 5f 5b 77 86 e6 7c 65 dd 7f b6 00 58 5d e3 e4 c1 ff d1 45 66 e0 43 4f 8e 40 ad 94 1a 40 0c b6 2d 48 0a 53 0f 7f b2 04 e4 f7 41 ee 3f 1d a9 df b1 fd 8e 
[2024/8/7 9:26:51 284] 71 b7 39 f8 2f 98 04 7f 0f 6b c6 31 cc ef 22 17 2b c7 6d 5e 79 81 78 9b 74 f5 7e f4 b2 62 47 ec 9a 
[2024/8/7 9:26:51 284] ble decryped data 80
[2024/8/7 9:26:51 300] 00 00 00 03 00 00 00 00 00 21 00 41 7b 22 70 77 64 22 3a 22 78 6d 35 31 32 35 32 30 22 2c 22 73 73 69 64 22 3a 22 58 69 61 6f 6d 69 5f 46 31 44 43 22 2c 22 74 6f 6b 65 6e 22 3a 22 41 59 57 71 
[2024/8/7 9:26:51 300] 4e 42 67 73 6a 48 36 67 62 41 22 7d 00 58 9e 00 
[2024/8/7 9:26:51 318] [01-01 18:12:41 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:51 318] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x21 
[2024/8/7 9:26:51 333] [01-01 18:12:41 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:33 Has No def operate
[2024/8/7 9:26:51 333] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:13 ---
[2024/8/7 9:26:51 333] [01-01 18:12:41 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:33
[2024/8/7 9:26:51 350] [01-01 18:12:41 TUYA N][bt_netcfg.c:63] Rev Net Cfg:{"pwd":"xm512520","ssid":"Xiaomi_F1DC","token":"AYWqNBgsjH6gbA"}
[2024/8/7 9:26:51 350] [01-01 18:12:41 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:51 365] [01-01 18:12:41 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x21 encrpyt:2
[2024/8/7 9:26:51 365] bt_ack_uncrypt 1
[2024/8/7 9:26:51 365] 00 
[2024/8/7 9:26:51 365] [01-01 18:12:41 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:51 382] [01-01 18:12:41 TUYA N][bt_netcfg.c:98] cfg ssid:Xiaomi_F1DC, passwd:xm512520, token:AYWqNBgsjH6gbA
[2024/8/7 9:26:51 397] [01-01 18:12:41 TUYA D][tuya_devos_netcfg.c:464] concurrent Netcfg Finish type:0x10004 ssid:Xiaomi_F1DC passwd:xm512520 cur_netcfg_type:0
[2024/8/7 9:26:51 397] [01-01 18:12:41 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:26:51 397] tuya_hal_bt_send 20
[2024/8/7 9:26:51 413] 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:26:51 413] [01-01 18:12:41 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:51 413] 0 21 32 2 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:26:51 428] XmBleSendBuf 20: 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7
[2024/8/7 9:26:51 428] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:51 428] ble_slave_gap_event->type=13
[2024/8/7 9:26:51 445] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:51 445] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:51 445] [01-01 18:12:41 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:51 460] [01-01 18:12:41 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:26:51 460]  max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:26:51 460] tuya_hal_bt_send 17
[2024/8/7 9:26:51 477] 01 01 06 c7 c2 ca ce c6 c0 d8 30 81 db 9d 22 6b c7 
[2024/8/7 9:26:51 477] [01-01 18:12:41 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:51 477] 1 1 6 c7 c2 ca ce c6 c0 d8 30 81 db 9d 22 6b c7 
[2024/8/7 9:26:51 492] XmBleSendBuf 17: 01 01 06 c7 c2 ca ce c6 c0 d8 30 81 db 9d 22 6b c7
[2024/8/7 9:26:51 492] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:51 492] ble_slave_gap_event->type=13
[2024/8/7 9:26:51 492] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:51 508] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:51 508] [01-01 18:12:41 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:51 508] [01-01 18:12:41 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:26:51 524] [01-01 18:12:41 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait
[2024/8/7 9:26:51 524] [01-01 18:12:41 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10002
[2024/8/7 9:26:51 540] [01-01 18:12:41 TUYA D][ap_netcfg.c:950] ap cfg stop:65538
[2024/8/7 9:26:51 540] [01-01 18:12:41 TUYA D][uni_thread.c:310] Del Thrd:udp_ap_v3
[2024/8/7 9:26:51 540] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:26:51 556] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:51 556] set basic_indicator_onoff:1 
[2024/8/7 9:26:51 572] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 572] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:51 588] [01-01 18:12:41 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:26:51 588] Received SIGTERM
[2024/8/7 9:26:51 588] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:26:51 604] [1970-01-01 00:00:37] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:51 604] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:51 604] set basic_indicator_onoff:0 
[2024/8/7 9:26:51 620] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 636] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:51 637] 
[2024/8/7 9:26:51 637] [1970-01-01 00:00:37] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:51 637] set basic_indicator_onoff:1 
[2024/8/7 9:26:51 653] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 669] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:51 669] [01-01 18:12:42 TUYA D][ap_netcfg.c:553] wf_ap_stop:0
[2024/8/7 9:26:51 669] set basic_indicator_onoff:0 
[2024/8/7 9:26:51 685] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 685] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:51 685] set basic_indicator_onoff:1 
[2024/8/7 9:26:51 701] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 701] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:51 717] [1970-01-01 00:00:38] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:26:51 717] set basic_indicator_onoff:0 
[2024/8/7 9:26:51 733] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 733] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:51 749] [01-01 18:12:42 TUYA N][ap_netcfg.c:172] exit ap_net_cfg task
[2024/8/7 9:26:51 749] [01-01 18:12:42 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10100
[2024/8/7 9:26:51 765] [01-01 18:12:42 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10004
[2024/8/7 9:26:51 765] [01-01 18:12:42 TUYA N][tuya_ble_api.c:439] update bound stat:1
[2024/8/7 9:26:51 765] [01-01 18:12:42 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:0
[2024/8/7 9:26:51 781] [01-01 18:12:42 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:26:51 781] [01-01 18:12:42 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:26:51 797] [01-01 18:12:42 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:26:51 797] [01-01 18:12:42 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:51 797] [01-01 18:12:42 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:51 813] [01-01 18:12:42 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:51 813] [01-01 18:12:42 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:26:51 828] [01-01 18:12:42 TUYA D][simplekv.c:1211] read key:ble_network_key isFuz[atbm_log]:[eth2] change to [2]
[2024/8/7 9:26:51 828] [atbm_log]:[eth2] has been disabled
[2024/8/7 9:26:51 829] [01-01 18:12:42 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:51 845] [01-01 18:12:42 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:51 845] [01-01 18:12:42 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:51 845] [01-01 18:12:42 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:26:51 860] [01-01 18:12:42 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:26:51 860] [01-01 18:12:42 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:51 860] [01-01 18:12:42 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:51 876] [01-01 18:12:42 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:51 876] [01-01 18:12:42 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:26:51 892] [01-01 18:12:42 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:26:51 892] [01-01 18:12:42 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:26:51 893] [01-01 18:12:42 TUYA N][tuya_devos_activate.c:774] already inited
[2024/8/7 9:26:51 909] [1970-01-01 00:00:38] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:51 909] set basic_indicator_onoff:1 
[2024/8/7 9:26:51 924] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:51 924] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:51 924] curr event:5 
[2024/8/7 9:26:51 940] IPC_APP_Notify_LED_Sound_Status_CB line(491) -------------------------- IPC_CONNECTING_WIFI(5)
[2024/8/7 9:26:51 956] [1970-01-01 00:00:38] tuya_ipc_system_control_demo.c(492) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECTING, 0, 0, 0, 1))
[2024/8/7 9:26:51 956] [1970-01-01 00:00:38] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/RouterConnect_english.pcm]
[2024/8/7 9:26:51 972] [1970-01-01 00:00:38] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:51 972] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:26:51 988] [01-01 18:12:42 TUYA D][uni_thread.c:268] Thread:udp_ap_v3 Exec Finish. Set to Del Stat
[2024/8/7 9:26:51 988] [01-01 18:12:42 TUYA D][uni_thread.c:125] del list not empty...deleting 0x266c13c, next 0x2661a00
[2024/8/7 9:26:52 004] [01-01 18:12:42 TUYA D][uni_thread.c:132] Final Free Thread:udp_ap_v3, is_self:1
[2024/8/7 9:26:52 004] [01-01 18:12:42 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:26:52 020] [01-01 18:12:42 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:26:52 020] set basic_indicator_onoff:0 
[2024/8/7 9:26:52 020] [01-01 18:12:42 TUYA I][bt_ext_porting.c:618] [TUYA-BTUART]ble_monitor_thread exit
[2024/8/7 9:26:52 212] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 ++++++++ 
[2024/8/7 9:26:52 212] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 --------- 
[2024/8/7 9:26:52 212] [atbm_log]:atbm_hw_scan:if_id(0)
[2024/8/7 9:26:52 228] [atbm_log]:atbm_hw_scan:scan, delay suspend
[2024/8/7 9:26:52 228] [atbm_log]:scan start band(0),(14)
[2024/8/7 9:26:52 964] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:52 964] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:52 964] --- tracepoint MainApp.c,ConfigTimer(372): g_WifiConectStatuts 1 ---
[2024/8/7 9:26:52 980] [1970-01-01 00:00:38] MainApp.c(373) <ConfigTimer>: ConfigTimer exit ----
[2024/8/7 9:26:52 980] set basic_indicator_onoff:1 
[2024/8/7 9:26:52 996] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:52 996] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:52 996] set basic_indicator_onoff:0 
[2024/8/7 9:26:53 012] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 012] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:53 028] set basic_indicator_onoff:1 
[2024/8/7 9:26:53 028] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 044] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:53 044] set basic_indicator_onoff:0 
[2024/8/7 9:26:53 044] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 060] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:53 060] set basic_indicator_onoff:1 
[2024/8/7 9:26:53 076] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 076] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:53 076] set basic_indicator_onoff:0 
[2024/8/7 9:26:53 092] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 092] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:53 108] set basic_indicator_onoff:1 
[2024/8/7 9:26:53 108] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 124] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:53 124] set basic_indicator_onoff:0 
[2024/8/7 9:26:53 124] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 140] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:53 140] set basic_indicator_onoff:1 
[2024/8/7 9:26:53 156] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 156] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:53 172] [1970-01-01 00:00:39] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:53 172] set basic_indicator_onoff:0 
[2024/8/7 9:26:53 172] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 188] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:53 188] set basic_indicator_onoff:1 
[2024/8/7 9:26:53 204] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 204] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:53 204] set basic_indicator_onoff:0 
[2024/8/7 9:26:53 221] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 221] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:53 236] set basic_indicator_onoff:1 
[2024/8/7 9:26:53 236] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 252] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:53 252] set basic_indicator_onoff:0 
[2024/8/7 9:26:53 252] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:53 268] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:53 268] g_AudioTipsList.size() enable: 0[01-01 18:12:44 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:26:53 684] [atbm_log]:hw_priv->scan.status 0
[2024/8/7 9:26:53 684] [atbm_log]:atbm_scan_work:end(0)
[2024/8/7 9:26:53 685] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:26:53 701] [atbm_log]:authen:(a4:a9:30:ce:5e:66),ssid(Xiaomi_F1DC)
[2024/8/7 9:26:53 701] [atbm_log]:authenticate[a4:a9:30:ce:5e:66]:[0][1]
[2024/8/7 9:26:53 701] [atbm_log]:eth2: authenticate with a4:a9:30:ce:5e:66 (try 1) (1)(0)
[2024/8/7 9:26:53 717] [atbm_log]:[STA] Join DTIM: 1, interval: 100
[2024/8/7 9:26:53 733] [atbm_log]:[TX]:authen, delay suspend
[2024/8/7 9:26:53 733] [atbm_log]:eth2: authenticated
[2024/8/7 9:26:53 733] [atbm_log]:work:flush sta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:53 749] [atbm_log]:sta has been insert(0)
[2024/8/7 9:26:53 749] [atbm_log]:wk->assoc.use_he 1 1++
[2024/8/7 9:26:53 749] [atbm_log]:flush sta(0):
[2024/8/7 9:26:53 749] [atbm_log]:eth2: associated
[2024/8/7 9:26:53 749] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:26:53 765] [atbm_log]:eth2:free authen bss --
[2024/8/7 9:26:53 765] [atbm_log]:is_wifi6_ap++
[2024/8/7 9:26:53 765] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:26:53 765] [atbm_log]:eth2  WMM AC=0 acm=0 aifs=2 cWmin=3 cWmax=7 txop=47 uapsd=0
[2024/8/7 9:26:53 781] [atbm_log]:eth2  WMM AC=1 acm=0 aifs=2 cWmin=7 cWmax=15 txop=94 uapsd=0
[2024/8/7 9:26:53 781] [atbm_log]:eth2  WMM AC=2 acm=0 aifs=3 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:26:53 797] [atbm_log]:eth2  WMM AC=3 acm=0 aifs=7 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:26:53 797] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:26:53 797] [atbm_log]:[a4:a9:30:ce:5e:66]:20M channel
[2024/8/7 9:26:53 813] [atbm_log]:atbm_bss_info_changed:chatype(1),channelNumber(3)
[2024/8/7 9:26:53 813] [atbm_log]:BssidColor[34]
[2024/8/7 9:26:53 813] [atbm_log]:[STA] color 34, he_support_flag: 53
[2024/8/7 9:26:53 828] [atbm_log]:==>connect wifi6 AP open AX, set BA WIN short
[2024/8/7 9:26:53 877] [atbm_log]:[eth2] Waiting Txq Ready[1]
[2024/8/7 9:26:53 924] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:26:53 940] [atbm_log]:[eth2]:dtim changed [0]->[1]
[2024/8/7 9:26:53 988] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:26:53 988] NOHZ: local_softirq_pending 08
[2024/8/7 9:26:54 005] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:26:54 005] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:26:54 005] [atbm_log]:send htc qos null
[2024/8/7 9:26:54 005] [atbm_log]:om work(1)
[2024/8/7 9:26:54 260] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:26:54 260] [atbm_log]:send htc qos null
[2024/8/7 9:26:54 260] [atbm_log]:om work(2)
[2024/8/7 9:26:54 389] [atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:26:54 389] [atbm_log]:aggtx stop queue
[2024/8/7 9:26:54 404] [atbm_log]:add to pending(2)(20)
[2024/8/7 9:26:54 405] [atbm_log]:dhcp work(1)
[2024/8/7 9:26:54 452] [atbm_log]:AMPDU[eth2]:action[2],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:54 452] [atbm_log]:activated addBA response timer on tid 0
[2024/8/7 9:26:54 452] [atbm_log]:aggtx wake queue
[2024/8/7 9:26:54 468] [atbm_log]:sta_hdr
[2024/8/7 9:26:54 468] [atbm_log]:switched off addBA timer for tid 0
[2024/8/7 9:26:54 468] [atbm_log]:Aggregation is on for tid 0
[2024/8/7 9:26:54 485] [atbm_log]:AMPDU[eth2]:action[4],tid[0],ssn[0],buff_size[64],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:54 485] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[6]
[2024/8/7 9:26:54 500] [atbm_log]:AMPDU[eth2]:action[0],tid[6],ssn[1],buff_size[64],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:54 516] [atbm_log]:Rx A-MPDU request on tid 6 result 0
[2024/8/7 9:26:54 516] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[0]
[2024/8/7 9:26:54 516] [atbm_log]:AMPDU[eth2]:action[0],tid[0],ssn[0],buff_size[64],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:54 532] [atbm_log]:Rx A-MPDU request on tid 0 result 0
[2024/8/7 9:26:54 532] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:26:54 532] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:26:54 532] [atbm_log]:send htc qos null
[2024/8/7 9:26:54 548] [atbm_log]:om work(3)
[2024/8/7 9:26:54 596] [atbm_log]:dhcp done
[2024/8/7 9:26:54 597] [atbm_log]:dhcp work(1)
[2024/8/7 9:26:54 612] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:26:54 613] [atbm_log]:dhcp doneNOHZ: local_softirq_pending 08
[2024/8/7 9:26:54 725] route: SIOCDELRT: No such process
[2024/8/7 9:26:54 740] [atbm_log]:connecting done for waitting dhcp  
[2024/8/7 9:26:54 820] 
[2024/8/7 9:26:54 821] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:26:54 821] [atbm_log]:send htc qos null
[2024/8/7 9:26:54 836] [atbm_log]:om work(4)
[2024/8/7 9:26:54 836] set basic_indicator_onoff:1 
[2024/8/7 9:26:54 836] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:54 852] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:54 852] set basic_indicator_onoff:0 
[2024/8/7 9:26:54 868] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:54 868] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:54 868] set basic_indicator_onoff:1 
[2024/8/7 9:26:54 884] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:54 884] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:54 900] set basic_indicator_onoff:0 
[2024/8/7 9:26:54 900] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:54 916] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:54 916] [1970-01-01 00:00:40] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time40552
[2024/8/7 9:26:54 916] set basic_indicator_onoff:1 
[2024/8/7 9:26:54 932] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:54 932] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:54 948] set basic_indicator_onoff:0 
[2024/8/7 9:26:54 948] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:54 964] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:54 964] [1970-01-01 00:00:40] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:54 980] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:26:54 980] set basic_indicator_onoff:1 
[2024/8/7 9:26:54 980] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:54 996] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:54 996] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 012] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 012] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 012] set basic_indicator_onoff:1 
[2024/8/7 9:26:55 028] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 028] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:55 044] [1970-01-01 00:00:41] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:55 044] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 060] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 060] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 060] set basic_indicator_onoff:1 
[2024/8/7 9:26:55 076] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 076] [1970-01-01 00:00:41][atbm_log]:om done
[2024/8/7 9:26:55 092]  ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:55 092] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 092] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 108] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 108] [1970-01-01 00:00:41] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:55 108] set basic_indicator_onoff:1 
[2024/8/7 9:26:55 124] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 124] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:55 140] 
[2024/8/7 9:26:55 141] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 141] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 156] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 156] set basic_indicator_onoff:1 
[2024/8/7 9:26:55 172] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 172] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:55 172] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 188] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 188] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 188] set basic_indicator_onoff:1 
[2024/8/7 9:26:55 205] [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 205] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:55 221] 
[2024/8/7 9:26:55 222] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 222] [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 237] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 237] set basic_indicator_onoff:1 
[2024/8/7 9:26:55 252] [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_ono[atbm_log]:<WIFI> rx ampdu ++ 
[2024/8/7 9:26:55 252] ff>: SwapFlag=fa[atbm_log]:napi schedule
[2024/8/7 9:26:55 253] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[5]
[2024/8/7 9:26:55 269] [atbm_log]:AMPDU[eth2]:action[0],tid[5],ssn[3],buff_size[64],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:26:55 269] lse
[2024/8/7 9:26:55 269] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:55 269] curr event:6 
[2024/8/7 9:26:55 285] IPC_APP_Notify_LED_Sound_Status_CB line(497) -------------------------- IPC_CONNECT_WIFI_SUCCESS(6)
[2024/8/7 9:26:55 300] [1970-01-01 00:00:42] tuya_ipc_system_control_demo.c(498) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECT_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:26:55 300] [01-01 18:12:46 TUYA D][tuya_devos_netlink.c:313] wf connect success!
[2024/8/7 9:26:55 316] [01-01 18:12:46 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:26:55 317] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:26:55 332] [atbm_log]:Rx A-MPDU request on tid 5 result 0i.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:26:55 332] [01-01 18:12:46 TUYA E][mqtt_client.c:807] hand null.
[2024/8/7 9:26:55 348] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:26:55 348] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 348] [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 364] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 364] [1970-01-01 00:00:42] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/ServerConnect_english.pcm]
[2024/8/7 9:26:55 381] [1970-01-01 00:00:42] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:55 381] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:26:55 396] [01-01 18:12:46 TUYA D][tuya_iot_wired_wifi_api.c:584] wired wifi default stat:1,change:1
[2024/8/7 9:26:55 412] [01-01 18:12:46 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[2024/8/7 9:26:55 412] [01-01 18:12:46 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[2024/8/7 9:26:55 428] [01-01 18:12:46 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:26:55 429] dev id key: 16
[2024/8/7 9:26:55 429] c0 b9 30 cc 91 82 20 e0 27 d3 45 b3 ab 3c 27 bf 
[2024/8/7 9:26:55 429] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:26:55 444] [01-01 18:12:46 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:26:55 444] 2 1 6 3 2 1 a2 14 16 1 a2 0 1c 6a 97 74 ce 42 f4 54 8c 72 2e 92 d 9f a1 db 
[2024/8/7 9:26:55 444] [01-01 18:12:46 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:26:55 460] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 30 7b 27 8c c6 8b 14 13 8e 36 f6 75 73 7d 4b 
[2024/8/7 9:26:55 460] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:26:55 476] [01-01 18:12:46 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:26:55 476] [01-01 18:12:46 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:26:55 492] [01-01 18:12:46 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:26:55 492] [01-01 18:12:46 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:55 492] [01-01 18:12:46 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:55 508] [01-01 18:12:46 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:55 508] [01-01 18:12:46 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:55 524] [01-01 18:12:46 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:55 525] [01-01 18:12:46 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:55 525] [01-01 18:12:46 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:55 540] [01-01 18:12:46 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:55 540] [01-01 18:12:46 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:55 540] [01-01 18:12:46 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:55 556] [01-01 18:12:46 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:26:55 556] [01-01 18:12:46 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:26:55 572] [01-01 18:12:46 TUYA D][iot_httpc.c:1435] sign_buffer:env=6gbA&region=AY&ts=31&uuid=uuidcaab27b0a838d239
[2024/8/7 9:26:55 572] [01-01 18:12:46 TUYA D][iot_httpc.c:1443] sign_base64_encode:cuY5MRTKTq5l2CsG+AOA/YrrfJf+mrp7oZHb66+WV8M=
[2024/8/7 9:26:55 588] [01-01 18:12:46 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:26:55 636] [01-01 18:12:46 TUYA D][iot_httpc.c:1514] http_dns send: {"region":"AY","env":"6gbA","uuid":"uuidcaab27b0a838d239","ts":31,"sign":"cuY5MRTKTq5l2CsG+AOA/YrrfJf+mrp7oZHb66+WV8M=","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:26:55 636] [01-01 18:12:46 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v2/url_config
[2024/8/7 9:26:55 636] [01-01 18:12:46 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:26:55 652] [01-01 18:12:46 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:26:55 668] [01-01 18:12:46 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:26:55 669] 
[2024/8/7 9:26:55 669] [01-01 18:12:46 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:26:55 669] [01-01 18:12:46 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:26:55 684] [01-01 18:12:46 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:55 700] [01-01 18:12:46 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:55 701] [01-01 18:12:46 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:55 701] [01-01 18:12:46 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:26:55 701] set basic_indicator_onoff:1 
[2024/8/7 9:26:55 716] [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 716] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:55 732] [01-01 18:12:46 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:55 732] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 748] [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 748] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 748] set basic_indicator_onoff:1 
[2024/8/7 9:26:55 764] [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 765] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:55 781] set basic_indicator_onoff:0 
[2024/8/7 9:26:55 781] [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:55 796] [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:55 797] [01-01 18:12:47 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:26:55 813] [01-01 18:12:47 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:55 813] [01-01 18:12:47 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:26:55 828] [01-01 18:12:47 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:55 829] [01-01 18:12:47 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:55 845] [01-01 18:12:47 TUYA D][iot_httpc.c:1578] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216]
[2024/8/7 9:26:55 845] [01-01 18:12:47 TUYA D][iot_httpc.c:1579] mqttUrl:[m2.tuyacn.com:1883][121.5.96.167]
[2024/8/7 9:26:55 860] [01-01 18:12:47 TUYA D][iot_httpc.c:1602] httpsSelfUrl:[https://a2.tuyacn.com/d.json][42.192.31.36]
[2024/8/7 9:26:55 860] [01-01 18:12:47 TUYA D][iot_httpc.c:1603] mqttsSelfUrl:[m2.tuyacn.com:8883][121.5.96.167]
[2024/8/7 9:26:55 876] [01-01 18:12:47 TUYA D][iot_httpc.c:1670] ghostUrl:[baal.tuyacn.com:443][42.192.35.108]
[2024/8/7 9:26:55 876] [01-01 18:12:47 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:26:55 876] [01-01 18:12:47 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:55 892] [01-01 18:12:47 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:26:55 892] [01-01 18:12:47 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:26:55 908] [01-01 18:12:47 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:26:55 908] [01-01 18:12:47 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:26:55 908] [01-01 18:12:47 TUYA D][iot_httpc.c:1684] tls_ca_name:tls_ca0
[2024/8/7 9:26:55 924] [01-01 18:12:47 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:26:55 924] [01-01 18:12:47 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:55 924] [01-01 18:12:47 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:55 941] [01-01 18:12:47 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:55 941] [01-01 18:12:47 TUYA D][simplekv.c:374] write key:tls_ca0 And Value Len:2688
[2024/8/7 9:26:55 956] [01-01 18:12:47 TUYA D][simplekv.c:457] new space 8 startpos:30428 size:2756
[2024/8/7 9:26:55 957] [01-01 18:12:47 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:55 957] [01-01 18:12:47 TUYA D][simplekv.c:203] update crc 1395591596
[2024/8/7 9:26:55 972] [01-01 18:12:47 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:55 972] [01-01 18:12:47 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:55 989] [01-01 18:12:47 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:55 989] [01-01 18:12:47 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:55 989] [01-01 18:12:47 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:56 004] [01-01 18:12:47 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:56 004] [01-01 18:12:47 TUYA D][simplekv.c:374] write key:tls_ca_cnt And Value Len:16
[2024/8/7 9:26:56 005] [01-01 18:12:47 TUYA D][simplekv.c:457] new space 9 startpos:33184 size:84
[2024/8/7 9:26:56 020] [01-01 18:12:47 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:56 020] [01-01 18:12:47 TUYA D][simplekv.c:203] update crc 213719394
[2024/8/7 9:26:56 036] [01-01 18:12:47 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:56 036] [01-01 18:12:47 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:56 036] [01-01 18:12:47 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:26:56 053] [01-01 18:12:47 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216]
[2024/8/7 9:26:56 053] [01-01 18:12:47 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36]
[2024/8/7 9:26:56 069] [01-01 18:12:47 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[121.5.96.167]
[2024/8/7 9:26:56 069] [01-01 18:12:47 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[121.5.96.167]
[2024/8/7 9:26:56 085] [01-01 18:12:47 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108]
[2024/8/7 9:26:56 085] [01-01 18:12:47 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:26:56 100] [01-01 18:12:47 TUYA D][simplekv.c:1251] find key:9 tls_ca_cnt
[2024/8/7 9:26:56 100] [01-01 18:12:47 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[2024/8/7 9:26:56 116] [01-01 18:12:47 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[2024/8/7 9:26:56 117] [01-01 18:12:47 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:26:56 117] [01-01 18:12:47 TUYA D][simplekv.c:1251] find key:8 tls_ca0
[2024/8/7 9:26:56 133] [01-01 18:12:47 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688
[2024/8/7 9:26:56 133] [01-01 18:12:47 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
[2024/8/7 9:26:56 133] [01-01 18:12:47 TUYA D][iot_httpc.c:1696] end
[2024/8/7 9:26:56 149] [01-01 18:12:47 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:26:56 149] [01-01 18:12:47 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:56 149] [01-01 18:12:47 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:26:56 164] bt_ack_uncrypt 2
[2024/8/7 9:26:56 164] 00 00 
[2024/8/7 9:26:56 164] [01-01 18:12:47 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:56 164] set basic_indicator_onoff:1 
[2024/8/7 9:26:56 180] [01-01 18:12:47 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:26:56 180] tuya_hal_bt_send 20
[2024/8/7 9:26:56 196] 00 21 33 02 [1970-01-01 00:00:42] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 197] af e8 ec a0 3c 6a e2 f0 c1 f5 78 [1970-01-01 00:00:42] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:56 197] ce a9 c9 66 41 
[2024/8/7 9:26:56 212] [01-01 18:12:47 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:56 212] 0 21 33 2 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41 
[2024/8/7 9:26:56 212] XmBleSendBuf 20: 00 21 33 02 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41
[2024/8/7 9:26:56 228] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:56 228] ble_slave_gap_event->type=13
[2024/8/7 9:26:56 228] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:56 228] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:56 244] [01-01 18:12:47 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:56 244] [01-01 18:12:47 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:26:56 260] tuya_hal_bt_send 17
[2024/8/7 9:26:56 261] 01 6d bf 8f 95 0d eb c9 e8 7b ef 35 c3 5c 99 41 26 
[2024/8/7 9:26:56 261] [01-01 18:12:47 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:56 261] 1 6d bf 8f 95 d eb c9 e8 7b ef 35 c3 5c 99 41 26 
[2024/8/7 9:26:56 276] XmBleSendBuf 17: 01 6d bf 8f 95 0d eb c9 e8 7b ef 35 c3 5c 99 41 26
[2024/8/7 9:26:56 276] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:56 276] ble_slave_gap_event->type=13
[2024/8/7 9:26:56 292] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:56 292] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:56 292] [01-01 18:12:47 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:56 308] [1970-01-01 00:00:43] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:56 308] [01-01 18:12:47 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:26:56 324] [01-01 18:12:47 TUYA D][tuya_devos_activate.c:356] dev_nw_cfg_active_stage:5
[2024/8/7 9:26:56 324] [01-01 18:12:47 TUYA D][iot_httpc.c:3195] modules:(null)
[2024/8/7 9:26:56 324] [01-01 18:12:47 TUYA D][simplekv.c:1211] read key:last_reset_info isFuzzy:0 skipCnt:0
[2024/8/7 9:26:56 340] [01-01 18:12:47 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:56 340] [01-01 18:12:47 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:56 340] [01-01 18:12:47 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:56 372] [01-01 18:12:47 TUYA D][iot_httpc.c:3198] options:{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}
[2024/8/7 9:26:56 420] [01-01 18:12:47 TUYA D][iot_httpc.c:1161] Post Data: {"token":"WqNBgsjH","softVer":"1.5.431","productKey":"fvijo8jvloagv1gm","protocolVer":"2.2","baselineVer":"40.00","hid":"90314ba51650","skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}}","devAttribute":67,"cadVer":"1.0.4","cdVer":"1.0.0","options":"{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}","t":32}
[2024/8/7 9:26:56 436] [01-01 18:12:47 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.active&et=1&t=32&uuid=uuidcaab27b0a838d239&v=4.4&sign=6e4b6c08a17af09b7d77b7b98d557997
[2024/8/7 9:26:56 452] [01-01 18:12:47 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:56 452] [01-01 18:12:47 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:56 468] [01-01 18:12:47 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:56 468] [01-01 18:12:47 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:56 468] set basic_indicator_onoff:0 
[2024/8/7 9:26:56 484] [1970-01-01 00:00:43] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 484] [1970-01-01 00:00:43] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:56 500] [01-01 18:12:47 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:56 500] [01-01 18:12:47 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:56 516] [01-01 18:12:47 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:56 516] [01-01 18:12:47 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:56 533] [01-01 18:12:47 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:56 533] [01-01 18:12:47 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:56 533] [01-01 18:12:47 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:56 548] [1970-01-01 00:00:43] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:56 548] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:56 548] Len=20 step 0
[2024/8/7 9:26:56 564] att=0x0 0x21 0x20 0x2 0xee 0x94 0xfb 0xf7 0xca 0x8e 0xd1 0xda 0x47 0xd7 0xeb 0xa6 0x9f 0xc5 0xad 0x6c 
[2024/8/7 9:26:56 564]  RCVS len:20
[2024/8/7 9:26:56 564] XmBleReadBuf 20:
[2024/8/7 9:26:56 564] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:56 580] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:56 580] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:56 580] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:56 596] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:56 596] [01-01 18:12:47 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:56 612] [01-01 18:12:47 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:56 612] [01-01 18:12:47 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:56 612] bt_rev_raw 20
[2024/8/7 9:26:56 612] 00 21 20 02 ee 94 fb f7 ca 8e d1 da 47 d7 eb a6 9f c5 ad 6c 
[2024/8/7 9:26:56 628] [01-01 18:12:47 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:26:56 644] [01-01 18:12:47 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:56 644] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:56 644] set basic_indicator_onoff:1 
[2024/8/7 9:26:56 660] [1970-01-01 00:00:43] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 660] [1970-01-01 00:00:43] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:56 660] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:56 676]  ---
[2024/8/7 9:26:56 676] Len=17 step 0
[2024/8/7 9:26:56 676] att=0x1 0x1a 0x8f 0xa0 0x6e 0x78 0xc1 0x3d 0xc7 0x5a 0xd2 0xff 0xda 0x13 0x8b 0x76 0xaf 
[2024/8/7 9:26:56 676]  RCVS len:17
[2024/8/7 9:26:56 692] [1970-01-01 00:00:43] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:56 693] XmBleReadBuf 17:
[2024/8/7 9:26:56 693] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:56 693] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:56 708] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:56 709] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:26:56 709] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:26:56 724] [01-01 18:12:47 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:26:56 725] [01-01 18:12:47 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:56 740] [01-01 18:12:47 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:56 740] bt_rev_raw 17
[2024/8/7 9:26:56 741] 01 1a 8f a0 6e 78 c1 3d c7 5a d2 ff da 13 8b 76 af 
[2024/8/7 9:26:56 756] [01-01 18:12:47 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:26:56 756] ble rev data 33
[2024/8/7 9:26:56 756] 02 ee 94 fb f7 ca 8e d1 da 47 d7 eb a6 9f c5 ad 6c 1a 8f a0 6e 78 c1 3d c7 5a d2 ff da 13 8b 76 af 
[2024/8/7 9:26:56 756] ble decryped data 16
[2024/8/7 9:26:56 772] 00 00 00 04 00 00 00 00 00 22 00 01 00 d6 49 00 
[2024/8/7 9:26:56 772] [01-01 18:12:47 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:56 788] [01-01 18:12:47 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:26:56 788] [01-01 18:12:47 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:26:56 788] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:26:56 804] set basic_indicator_onoff:0 
[2024/8/7 9:26:56 804] [1970-01-01 00:00:43] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 820] [1970-01-01 00:00:43] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:56 820] [1970-01-01 00:00:43] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:56 820] set basic_indicator_onoff:1 
[2024/8/7 9:26:56 836] [1970-01-01 00:00:43] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 836] [1970-01-01 00:00:43] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:56 852] [01-01 18:12:47 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:56 868] [01-01 18:12:47 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:56 868] set basic_indicator_onoff:0 
[2024/8/7 9:26:56 884] [1970-01-01 00:00:43] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 884] [1970-01-01 00:00:43] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:56 884] set basic_indicator_onoff:1 
[2024/8/7 9:26:56 900] [1970-01-01 00:00:43] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 900] [1970-01-01 00:00:43] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:56 916] set basic_indicator_onoff:0 
[2024/8/7 9:26:56 916] [1970-01-01 00:00:43] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 932] [1970-01-01 00:00:43] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:56 932] set basic_indicator_onoff:1 
[2024/8/7 9:26:56 932] [1970-01-01 00:00:43] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:56 948] [1970-01-01 00:00:43] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:57 044] [01-01 18:12:48 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"capability":1,"devId":"6c22957eb0f040d84du6po","dstIntervals":[],"localKey":"UUMJV_y.$G.4A^rj","resetFactory":false,"schema":"[{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":103,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":104,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"range\":[\"0\",\"1\",\"2\"],\"type\":\"enum\"},\"id\":106,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":109,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"min\":1,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":110,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":111,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":113,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\
[2024/8/7 9:26:57 045] [08-07 19:39:14 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:57 045] [08-07 19:39:14 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:57 061] [08-07 19:39:14 TUYA D][tuya_devos_activate.c:210] cloud_reset:0 local_reset:1
[2024/8/7 9:26:57 061] [08-07 19:39:14 TUYA D][tuya_devos_activate.c:256] __tmm_gw_actv_work: reset stride flag.
[2024/8/7 9:26:57 077] [08-07 19:39:14 TUYA D][tuya_devos_entry.c:1477] write stride to flash:0
[2024/8/7 9:26:57 077] [08-07 19:39:14 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 9:26:57 077] [08-07 19:39:14 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:57 092] [08-07 19:39:14 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:57 092] [08-07 19:39:14 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:57 108] [08-07 19:39:14 TUYA D][simplekv.c:374] write key:is_stride And Value Len:16
[2024/8/7 9:26:57 108] [08-07 19:39:14 TUYA D][simplekv.c:457] new space 10 startpos:33268 size:84
[2024/8/7 9:26:57 108] [08-07 19:39:14 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:57 124] [08-07 19:39:14 TUYA D][simplekv.c:203] update crc 1143988772
[2024/8/7 9:26:57 124] set basic_indicator_onoff:0 
[2024/8/7 9:26:57 141] [1970-01-01 00:00:44] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:57 141] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:57 141] [08-07 19:39:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:57 156] [08-07 19:39:14 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:57 157] [08-07 19:39:14 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:26:57 157] [08-07 19:39:14 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 9:26:57 173] [08-07 19:39:14 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 9:26:57 173] [08-07 19:39:14 TUYA D][simplekv.c:374] write key:gw_di And Value Len:416
[2024/8/7 9:26:57 189] [08-07 19:39:14 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416
[2024/8/7 9:26:57 189] [08-07 19:39:14 TUYA D][simplekv.c:430] find 2 available space
[2024/8/7 9:26:57 189] [08-07 19:39:14 TUYA D][simplekv.c:474] reuse available space 29188
[2024/8/7 9:26:57 205] [08-07 19:39:14 TUYA D][simplekv.c:203] update crc 2863032733
[2024/8/7 9:26:57 205] [08-07 19:39:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:57 221] [08-07 19:39:14 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:57 223] [08-07 19:39:14 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:26:57 223] [08-07 19:39:14 TUYA D][simplekv.c:1211] read key:flvlrc isFuzzy:0 skipCnt:0
[2024/8/7 9:26:57 237] [08-07 19:39:14 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:57 237] [08-07 19:39:14 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:57 237] [08-07 19:39:14 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:57 253] [08-07 19:39:14 TUYA D][simplekv.c:374] write key:flvlrc And Value Len:2928
[2024/8/7 9:26:57 253] [08-07 19:39:14 TUYA D][simplekv.c:457] new space 11 startpos:33352 size:2996
[2024/8/7 9:26:57 269] [08-07 19:39:14 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:57 269] [08-07 19:39:14 TUYA D][simplekv.c:203] update crc 3759832504
[2024/8/7 9:26:57 270] [08-07 19:39:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:57 285] [08-07 19:39:14 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:57 285] [08-07 19:39:14 TUYA D][ws_db_gw.c:670] schema write success
[2024/8/7 9:26:57 285] [08-07 19:39:14 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success 
[2024/8/7 9:26:57 301] [08-07 19:39:14 TUYA D][tuya_ipc_sdk_init.c:183] ON post active:0x269eda8
[2024/8/7 9:26:57 301] [08-07 19:39:14 TUYA D][tuya_ipc_sdk_init.c:172] skillResult p2pId:[]
[2024/8/7 9:26:57 317] [08-07 19:39:14 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:26:57 317] [08-07 19:39:14 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 9:26:57 317] [08-07 19:39:14 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[2024/8/7 9:26:57 332] [08-07 19:39:14 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:544
[2024/8/7 9:26:57 332] [08-07 19:39:14 TUYA D][simplekv.c:394] 4 key same BUT size old 436 < new 544 need find new hd
[2024/8/7 9:26:57 348] [08-07 19:39:14 TUYA D][simplekv.c:457] new space 12 startpos:36348 size:612
[2024/8/7 9:26:57 348] [08-07 19:39:14 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:57 364] [08-07 19:39:14 TUYA D][simplekv.c:203] update crc 3591477880
[2024/8/7 9:26:57 364] [08-07 19:39:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:57 364] [08-07 19:39:14 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:57 380] [08-07 19:39:14 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:26:57 396] [08-07 19:39:14 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":9,"ssid":"WGlhb21pX0YxREM=","passwd":"eG01MTI1MjA=","md":0,"random":0,"wfb64":1,"stat":2,"token":"WqNBgsjH","region":"AY","reg_key":"6gbA","dns_prio":0 }
[2024/8/7 9:26:57 396] [08-07 19:39:14 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:26:57 412] [08-07 19:39:14 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:26:57 413] [08-07 19:39:14 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:26:57 413] [08-07 19:39:14 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:176
[2024/8/7 9:26:57 428] [08-07 19:39:14 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 176
[2024/8/7 9:26:57 428] [08-07 19:39:14 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:26:57 428] [08-07 19:39:14 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:26:57 444] [08-07 19:39:14 TUYA D][simplekv.c:203] update crc 4073830596
[2024/8/7 9:26:57 444] [08-07 19:39:14 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:57 460] [08-07 19:39:14 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:57 460] [08-07 19:39:14 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:26:57 460] __IPC_APP_Get_Net_Status_cb line(188) -------------------------- stat(1)==STAT_UNPROVISION 
[2024/8/7 9:26:57 476] [08-07 19:39:14 TUYA D][wifi_netcfg_frame_transporter.c:472] ----destroy Transporter,session:0x26622d0
[2024/8/7 9:26:57 476] [08-07 19:39:14 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:26:57 492] [08-07 19:39:14 TUYA N][bt_dp.c:228] bt rpt conn stat:9
[2024/8/7 9:26:57 492] [08-07 19:39:14 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:57 492] [08-07 19:39:14 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:26:57 508] bt_ack_uncrypt 2
[2024/8/7 9:26:57 508] 00 09 
[2024/8/7 9:26:57 508] [08-07 19:39:14 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:57 508] [08-07 19:39:14 TUYA D][tuya_devos_entry.c:560] dev_nw_cfg_active_stage:6
[2024/8/7 9:26:57 524] __IPC_APP_Get_Net_Status_cb line(198) -------------------------- stat(3)==STAT_AP_STA_DISC 
[2024/8/7 9:26:57 524] [08-07 19:39:14 TUYA D][tuya_ble_api.c:1005] start to get mesh
[2024/8/7 9:26:57 540] [08-07 19:39:14 TUYA N][tuya_bt_sdk.c:171] ty bt upd localkey
[2024/8/7 9:26:57 540] [08-07 19:39:14 TUYA N][tuya_ble_api.c:425] upd login key len:6
[2024/8/7 9:26:57 540] [08-07 19:39:14 TUYA I][mqc_app.c:387] mqc app start ...
[2024/8/7 9:26:57 556] [08-07 19:39:14 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883
[2024/8/7 9:26:57 556] [08-07 19:39:14 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994019}
[2024/8/7 9:26:57 556] [08-07 19:39:14 TUYA D][mqc_app.c:473] TLS disable
[2024/8/7 9:26:57 572] [08-07 19:39:14 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:26:57 588] [08-07 19:39:14 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.mesh.get&devId=6c22957eb0f040d84du6po&et=1&t=1722994019&v=1.0&sign=5d0c8893f4bb11c95d509d3e42b9cf48
[2024/8/7 9:26:57 604] [08-07 19:39:14 TUYA D][mqtt_client.c:321] subcribe_topic:smart/device/in/6c22957eb0f040d84du6po, client_id:6c22957eb0f040d84du6po, user_name:6c22957eb0f040d84du6po, passwd:8f9510f3e09e0fe9
[2024/8/7 9:26:57 604] [08-07 19:39:14 TUYA D][mqtt_client.c:352] domain<0> m2.tuyacn.com:8883 HAVE PORT
[2024/8/7 9:26:57 620] [08-07 19:39:14 TUYA D][mqtt_client.c:355] PARSE m2.tuyacn.com:8883
[2024/8/7 9:26:57 620] [08-07 19:39:14 TUYA D][mqtt_client.c:383] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT
[2024/8/7 9:26:57 636] [08-07 19:39:14 TUYA D][mqtt_client.c:386] PARSE m2.tuyacn.com:1883
[2024/8/7 9:26:57 636] set basic_indicator_onoff:1 
[2024/8/7 9:26:57 636] [1970-01-01 00:00:44] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:57 652] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:57 652] [08-07 19:39:14 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:57 668] [08-07 19:39:14 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:57 668] [08-07 19:39:14 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6c22957eb0f040d84du6po
[2024/8/7 9:26:57 684] [08-07 19:39:14 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6c22957eb0f040d84du6po
[2024/8/7 9:26:57 684] [08-07 19:39:14 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:57 700] [08-07 19:39:14 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:57 700] [08-07 19:39:14 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:25600,priority:4
[2024/8/7 9:26:57 716] [08-07 19:39:14 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[2024/8/7 9:26:57 716] [08-07 19:39:14 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[2024/8/7 9:26:57 716] [08-07 19:39:14 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[2024/8/7 9:26:57 732] [08-07 19:39:14 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:26:57 732] [08-07 19:39:14 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:57 732] [08-07 19:39:14 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:57 748] [08-07 19:39:14 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:57 748] [08-07 19:39:14 TUYA D][tuya_svc_timer_task.c:146] no timer
[2024/8/7 9:26:57 748] [08-07 19:39:14 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[2024/8/7 9:26:57 764] [08-07 19:39:14 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[2024/8/7 9:26:57 764] [08-07 19:39:14 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[2024/8/7 9:26:57 780] [08-07 19:39:14 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6c22957eb0f040d84du6po
[2024/8/7 9:26:57 780] [08-07 19:39:14 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6c22957eb0f040d84du6po
[2024/8/7 9:26:57 796] [08-07 19:39:14 TUYA D][svc_online_log.c:317] svc online log active success
[2024/8/7 9:26:57 796] [08-07 09:26:59 TUYA D][tuya_ipc_sdk_init.c:137] sys stop timer: 14
[2024/8/7 9:26:57 796] [08-07 09:26:59 TUYA D][tuya_ipc_sdk_init.c:140] sys delete timer: 14
[2024/8/7 9:26:57 812] [08-07 09:26:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:26:57 812] tuya_hal_bt_send 20
[2024/8/7 9:26:57 828] 00 21 34 02 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 02 95 57 
[2024/8/7 9:26:57 828] [08-07 09:26:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:57 828] 0 21 34 2 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 2 95 57 
[2024/8/7 9:26:57 844] XmBleSendBuf 20: 00 21 34 02 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 02 95 57
[2024/8/7 9:26:57 844] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:57 844] ble_slave_gap_event->type=13
[2024/8/7 9:26:57 844] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:57 860] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:57 861] [08-07 09:26:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:57 876] [08-07 09:26:59 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[2024/8/7 9:26:57 876] [08-07 09:26:59 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:26:57 876] [08-07 09:26:59 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:26:57 892] [08-07 09:26:59 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:26:57 892] [08-07 09:26:59 TUYA D][tuya_ipc_p2p_common.c:530] p2p passwd change to adb2cd63
[2024/8/7 9:26:57 908] [08-07 09:26:59 TUYA D][iot_httpc.c:1161] Post Data: {"password":"adb2cd63","t":1722994019}
[2024/8/7 9:26:57 924] [08-07 09:26:59 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.password.update&devId=6c22957eb0f040d84du6po&et=1&t=1722994019&v=1.0&sign=200a112bcf2516ca95857304889aa615
[2024/8/7 9:26:57 924] [08-07 09:26:59 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:57 940] [08-07 09:26:59 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:57 940] [08-07 09:26:59 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:57 956] [08-07 09:26:59 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:57 956] [1970-01-01 00:00:44] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:26:57 972] [08-07 09:26:59 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:57 972] [08-07 09:26:59 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:57 988] [08-07 09:26:59 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:57 988] [08-07 09:26:59 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:58 005] [08-07 09:26:59 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:58 005] [08-07 09:26:59 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:58 005] [08-07 09:26:59 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:58 021] [08-07 09:26:59 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:58 021] [08-07 09:26:59 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:58 036] [08-07 09:26:59 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:58 036] [08-07 09:26:59 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:58 053] [08-07 09:26:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:26:58 053] tuya_hal_bt_send 17
[2024/8/7 9:26:58 053] 01 9c 90 be 66 35 37 7f 5c 7f c7 2b fc c9 da ca 55 
[2024/8/7 9:26:58 069] [08-07 09:26:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:58 069] 1 9c 90 be 66 35 37 7f 5c 7f c7 2b fc c9 da ca 55 
[2024/8/7 9:26:58 069] XmBleSendBuf 17: 01 9c 90 be 66 35 37 7f 5c 7f c7 2b fc c9 da ca 55
[2024/8/7 9:26:58 084] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:58 085] ble_slave_gap_event->type=13
[2024/8/7 9:26:58 085] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:58 085] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:58 100] [08-07 09:26:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:58 100] [08-07 09:26:59 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:58 117] [08-07 09:26:59 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:58 132] [1970-01-01 00:00:44] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:58 133] [08-07 09:26:59 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:58 133] [08-07 09:26:59 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:58 149] [08-07 09:26:59 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:58 149] [08-07 09:26:59 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:26:58 164] [08-07 09:26:59 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[2024/8/7 9:26:58 164] [08-07 09:26:59 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[2024/8/7 9:26:58 180] [08-07 09:26:59 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:26:58 180] dev id key: 16
[2024/8/7 9:26:58 180] 36 c2 65 60 35 69 2c c7 ae 19 3c e3 0f c3 3e 71 
[2024/8/7 9:26:58 180] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:26:58 196] [08-07 09:26:59 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:26:58 196] 2 1 6 3 2 1 a2 14 16 1 a2 0 14 fa c0 24 39 5e 1f 4f a b9 9a 52 e7 c1 3e 6f 
[2024/8/7 9:26:58 212] [08-07 09:26:59 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:58 228] [08-07 09:26:59 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:58 228] [08-07 09:26:59 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:26:58 228] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 8d 6 23 57 d8 18 d5 dc d5 71 bc d5 bf 21 5e a8 
[2024/8/7 9:26:58 244] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:26:58 244] [08-07 09:26:59 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:26:58 260] [08-07 09:26:59 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:26:58 260] set basic_indicator_onoff:0 
[2024/8/7 9:26:58 260] [1970-01-01 00:00:44] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:58 276] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:58 292] g_AudioTipsList.size() enable: 0[08-07 09:26:59 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994019,"success":true}
[2024/8/7 9:26:58 292] [08-07 09:26:59 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:58 292] [1970-01-01 00:00:44] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:58 308] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:58 308] Len=20 step 0
[2024/8/7 9:26:58 308] att=0x0 0x21 0x20 0x2 [08-07 09:26:59 TUYA D][smart_frame.c:3490] rept chan:4
[2024/8/7 9:26:58 324] 0x34 0x1 0xe4 0xc1 0x18 0x4 0xe0 0xdb 0xeb 0x92 0x16 0xec 0xde 0xe4 0xe1 0x16 
[2024/8/7 9:26:58 324]  RCVS len:20
[2024/8/7 9:26:58 324] [08-07 09:26:59 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:26:58 340] [08-07 09:26:59 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:26:58 340] [08-07 09:26:59 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:26:58 340] __dp_data_report_data 4
[2024/8/7 9:26:58 356] 9f 01 01 00 
[2024/8/7 9:26:58 356] [08-07 09:26:59 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:58 356] [08-07 09:26:59 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:26:58 356] bt_ack_uncrypt 4
[2024/8/7 9:26:58 371] 9f 01 01 00 
[2024/8/7 9:26:58 372] [08-07 09:26:59 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:58 372] [08-07 09:26:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:26:58 388] tuya_hal_bt_send 20
[2024/8/7 9:26:58 388] 00 31 35 05 80 f0 16 6b 9d 3e f5 [08-07 09:26:59 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:58 388] 12 fe 01 c1 ba 99 f8 90 59 
[2024/8/7 9:26:58 404] [08-07 09:26:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:58 404] 0 31 35 5 80 f0 16 6b 9d 3e f5 12 fe 1 c1 ba 99 f8 90 59 
[2024/8/7 9:26:58 404] XmBleSendBuf 20: 00 31 35 05 80 f0 16 6b 9d 3e f5 12 fe 01 c1 ba 99 f8 90 59
[2024/8/7 9:26:58 420] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:58 420] ble_slave_gap_event->type=13
[2024/8/7 9:26:58 420] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:58 420] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:58 436] [08-07 09:26:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:58 436] [08-07 09:26:59 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:26:58 452] [08-07 09:26:59 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:26:58 452] [08-07 09:26:59 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:26:58 452] [08-07 09:26:59 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:26:58 468] [08-07 09:26:59 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:26:58 468] [08-07 09:26:59 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:26:58 484] [08-07 09:26:59 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:26:58 484] [08-07 09:26:59 TUYA D][simplekv.c:203] update crc 57608931
[2024/8/7 9:26:58 500] [08-07 09:26:59 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"appKey":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","networkKey":"D59774254FA876FF1D204D16DF5223A5"},"t":1722994019,"success":true}
[2024/8/7 9:26:58 500] [08-07 09:26:59 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:58 516] [08-07 09:26:59 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:58 532] [08-07 09:26:59 TUYA D][tuya_ble_api.c:1014] start to write flash, app_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66", network_key:"D59774254FA876FF1D204D16DF5223A5"
[2024/8/7 9:26:58 532] [08-07 09:26:59 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:58 532] [08-07 09:26:59 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:58 548] [08-07 09:26:59 TUYA D][tuya_devos_utils.c:341] set gw ext_stat:2
[2024/8/7 9:26:58 548] [08-07 09:26:59 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 0
[2024/8/7 9:26:58 564] [08-07 09:26:59 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:26:58 564] [08-07 09:26:59 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:58 564] [08-07 09:26:59 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:58 580] [08-07 09:26:59 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:58 580] [08-07 09:26:59 TUYA D][uni_network.c:181] use dynamic dns ip 121.5.96.167 for domain m2.tuyacn.com
[2024/8/7 9:26:58 596] [08-07 09:26:59 TUYA D][mqtt_client.c:1472] select mqtt host:m2.tuyacn.com
[2024/8/7 9:26:58 596] [08-07 09:26:59 TUYA N][mqtt_client.c:1493] mqtt get serve ip success
[2024/8/7 9:26:58 596] [08-07 09:26:59 TUYA D][simplekv.c:374] write key:ble_app_key And Value Len:48
[2024/8/7 9:26:58 612] [08-07 09:26:59 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 48
[2024/8/7 9:26:58 612] [08-07 09:26:59 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:26:58 612] XmBleReadBuf 20:
[2024/8/7 9:26:58 628] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:58 628] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:58 628] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:58 644] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:26:58 644] [08-07 09:26:59 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:26:58 644] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:26:58 660] [08-07 09:26:59 TUYA D][simplekv.c:203] update crc 3383336492
[2024/8/7 9:26:58 661] [08-07 09:26:59 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:26:58 676] [08-07 09:26:59 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:58 676] [08-07 09:26:59 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:58 676] bt_rev_raw 20
[2024/8/7 9:26:58 676] 00 21 20 02 34 01 e4 c1 18 04 e0 db eb 92 16 ec de e4 e1 16 
[2024/8/7 9:26:58 692] [08-07 09:26:59 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:26:58 708] [08-07 09:26:59 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:26:58 708] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:26:58 708] [1970-01-01 00:00:44] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:58 724] [08-07 09:26:59 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:58 724] [08-07 09:26:59 TUYA D][mqtt_client.c:989] serverIP 2030395559 port:8883
[2024/8/7 9:26:58 740] [08-07 09:26:59 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:58 740] [08-07 09:26:59 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:26:58 740] [08-07 09:26:59 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:58 756] [08-07 09:26:59 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:58 756] [08-07 09:26:59 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:58 772] [08-07 09:26:59 TUYA D][simplekv.c:374] write key:ble_network_key And Value Len:48
[2024/8/7 9:26:58 772] [08-07 09:26:59 TUYA D][simplekv.c:457] new space 13 startpos:36960 size:116
[2024/8/7 9:26:58 772] [08-07 09:26:59 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:58 788] [08-07 09:26:59 TUYA D][simplekv.c:203] update crc 3257791112
[2024/8/7 9:26:58 788] [08-07 09:26:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:26:58 788] tuya_hal_bt_send 20
[2024/8/7 9:26:58 804] 01 2c 00 a8 2d 02 25 8d a6 22 d8 ed 87 19 0d 3d f9 7d 79 9f 
[2024/8/7 9:26:58 804] [08-07 09:26:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:58 820] 1 2c 0 a8 2d 2 25 8d a6 22 d8 ed 87 19 d 3d f9 7d 79 9f 
[2024/8/7 9:26:58 820] XmBleSendBuf 20: 01 2c 00 a8 2d 02 25 8d a6 22 d8 ed 87 19 0d 3d f9 7d 79 9f
[2024/8/7 9:26:58 820] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:58 820] ble_slave_gap_event->type=13
[2024/8/7 9:26:58 836] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:58 836] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:58 836] [08-07 09:26:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:58 852] [08-07 09:26:59 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:58 852] set basic_indicator_onoff:1 
[2024/8/7 9:26:58 852] [08-07 09:26:59 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:58 868] [1970-01-01 00:00:44] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:58 868] [08-07 09:26:59 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994019}
[2024/8/7 9:26:58 884] [08-07 09:26:59 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.beacon.key.fetch&devId=6c22957eb0f040d84du6po&et=1&t=1722994019&v=1.0&sign=94b02fbb8947f7286d6daafbed2356d3
[2024/8/7 9:26:58 900] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:58 900] [08-07 09:26:59 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:58 916] [08-07 09:26:59 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:58 916] [08-07 09:26:59 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:58 932] [08-07 09:26:59 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:58 932] [08-07 09:26:59 TUYA D][mqtt_client.c:1014] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883
[2024/8/7 9:26:58 948] [08-07 09:26:59 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:58 948] [08-07 09:26:59 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyacn.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:58 964] [08-07 09:26:59 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:58 964] [08-07 09:26:59 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:58 964] [08-07 09:26:59 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:58 980] [08-07 09:26:59 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:58 980] [08-07 09:26:59 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:58 996] [08-07 09:26:59 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:59 012] [08-07 09:26:59 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:59 012] [08-07 09:26:59 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:59 012] [08-07 09:26:59 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:59 028] [08-07 09:26:59 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:59 028] [08-07 09:26:59 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:59 044] [08-07 09:26:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:26:59 044] tuya_hal_bt_send 14
[2024/8/7 9:26:59 044] 02 0e 36 1a ed 41 3d 3f 58 1c d9 4c 8c 67 
[2024/8/7 9:26:59 044] [08-07 09:26:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:26:59 060] 2 e 36 1a ed 41 3d 3f 58 1c d9 4c 8c 67 
[2024/8/7 9:26:59 060] XmBleSendBuf 14: 02 0e 36 1a ed 41 3d 3f 58 1c d9 4c 8c 67
[2024/8/7 9:26:59 060] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:26:59 060] ble_slave_gap_event->type=13
[2024/8/7 9:26:59 076] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:26:59 076] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:26:59 076] [08-07 09:26:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:26:59 092] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:26:59 092] Len=17 step 0
[2024/8/7 9:26:59 092] att=0x1 0x1a 0x6f 0xb8 0xc1 0xe4 0x19 0x9 0xc8 0xf9 0x1a 0xbd 0x4b 0x2 0x49 0x40 0xbc 
[2024/8/7 9:26:59 092]  RCVS len:17
[2024/8/7 9:26:59 108] [1970-01-01 00:00:44] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:59 108] [08-07 09:26:59 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:26:59 124] [08-07 09:26:59 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:59 140] [08-07 09:26:59 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:59 140] set basic_indicator_onoff:0 
[2024/8/7 9:26:59 157] [1970-01-01 00:00:44] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:59 159] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:59 159] XmBleReadBuf 17:
[2024/8/7 9:26:59 159] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:26:59 172] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:26:59 172] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:26:59 172] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:26:59 188] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:26:59 188] [08-07 09:26:59 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:26:59 204] [08-07 09:26:59 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:26:59 204] [08-07 09:26:59 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:26:59 204] bt_rev_raw 17
[2024/8/7 9:26:59 204] 01 1a 6f b8 c1 e4 19 09 c8 f9 1a bd 4b 02 49 40 bc 
[2024/8/7 9:26:59 221] [08-07 09:26:59 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:26:59 221] ble rev data 33
[2024/8/7 9:26:59 236] 02 34 01 e4 c1 18 04 e0 db eb 92 16 ec de e4 e1 16 1a 6f b8 c1 e4 19 09 c8 f9 1a bd 4b 02 49 40 bc 
[2024/8/7 9:26:59 236] ble decryped data 16
[2024/8/7 9:26:59 236] 00 00 00 05 00 00 00 00 00 22 00 01 00 13 18 00 
[2024/8/7 9:26:59 236] [08-07 09:26:59 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:59 252] [08-07 09:26:59 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:26:59 252] [08-07 09:26:59 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:26:59 268] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:26:59 268] [08-07 09:26:59 TUYA D][iot_httpc.c:601] Decode Rev:{"result":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","t":1722994020,"success":true}
[2024/8/7 9:26:59 284] [08-07 09:27:00 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:59 284] [08-07 09:27:00 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:59 300] [08-07 09:27:00 TUYA D][tuya_ble_api.c:986] start to write flash, beacon_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66"
[2024/8/7 9:26:59 300] [08-07 09:27:00 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:26:59 316] [08-07 09:27:00 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:59 316] [08-07 09:27:00 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:59 316] [08-07 09:27:00 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:59 331] [08-07 09:27:00 TUYA D][simplekv.c:374] write key:ble_beaconkey And Value Len:48
[2024/8/7 9:26:59 332] [08-07 09:27:00 TUYA D][simplekv.c:457] new space 14 startpos:37076 size:116
[2024/8/7 9:26:59 347] [08-07 09:27:00 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:59 348] [08-07 09:27:00 TUYA D][simplekv.c:203] update crc 520555796
[2024/8/7 9:26:59 363] [1970-01-01 00:00:44] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time44614
[2024/8/7 9:26:59 365] [08-07 09:27:00 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:26:59 365] [08-07 09:27:00 TUYA D][simplekv.c:520] write success
[2024/8/7 9:26:59 379] [08-07 09:27:00 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:26:59 379] [08-07 09:27:00 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:26:59 379] [1970-01-01 00:00:44] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:26:59 395] set basic_indicator_onoff:1 
[2024/8/7 9:26:59 396] [1970-01-01 00:00:44] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:59 411] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:59 411] set basic_indicator_onoff:0 
[2024/8/7 9:26:59 412] [1970-01-01 00:00:44] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:59 428] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:26:59 428] [08-07 09:27:00 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:59 444] [08-07 09:27:00 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyacn.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:59 460] [08-07 09:27:00 TUYA N][mqtt_client.c:1531] mqtt create success, begin to connect
[2024/8/7 9:26:59 460] [08-07 09:27:00 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:26:59 460] [08-07 09:27:00 TUYA D][mqtt_client.c:1413] cnt 1
[2024/8/7 9:26:59 460] set basic_indicator_onoff:1 
[2024/8/7 9:26:59 476] [1970-01-01 00:00:44] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:26:59 493] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:26:59 495] 
[2024/8/7 9:26:59 495] [08-07 09:27:00 TUYA D][mqtt_client.c:1104] mqtt subscribe success
[2024/8/7 9:26:59 495] [08-07 09:27:00 TUYA D][mqc_app.c:732] mqtt connect success
[2024/8/7 9:26:59 509] [08-07 09:27:00 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[2024/8/7 9:26:59 509] [08-07 09:27:00 TUYA D][mqtt_client.c:1994] subscribe new topic /av/d/6c22957eb0f040d84du6po ret:1 
[2024/8/7 9:26:59 525] [08-07 09:27:00 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[2024/8/7 9:26:59 525] __IPC_APP_Get_Net_Status_cb line(243) -------------------------- stat(11)==STAT_MQTT_ONLINE 
[2024/8/7 9:26:59 525] curr event:11 
[2024/8/7 9:26:59 540] IPC_APP_Notify_LED_Sound_Status_CB line(550) -------------------------- IPC_MQTT_ONLINE(11)
[2024/8/7 9:26:59 557] [1970-01-01 00:00:44] tuya_ipc_system_control_demo.c(551) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(DEVICE_ONLINE, 0, 0, 0, 1))
[2024/8/7 9:26:59 557] Disable Qrcode
[2024/8/7 9:26:59 573] [1970-01-01 00:00:44] tuya_ipc_system_control_demo.c(558) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONFIG_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:26:59 573] mqtt subscribe ack 5
[2024/8/7 9:26:59 573] 90 03 00 02 00 
[2024/8/7 9:26:59 573] [1970-01-01 00:00:44] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:59 588] [1970-01-01 00:00:44] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:26:59 604] [1970-01-01 00:00:45] xm_musicPlayer.cpp(91) <PlayAudioTips>: Open audio file /usr/share/audios/_english.pcm failed, No such file or directory
[2024/8/7 9:26:59 604] [1970-01-01 00:00:45] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/AddSuccess_english.pcm]
[2024/8/7 9:26:59 620] [1970-01-01 00:00:45] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:26:59 620] [1970-01-01 00:00:45] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:26:59 636] [08-07 09:27:00 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:26:59 636] [08-07 09:27:00 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:59 636] [08-07 09:27:00 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:59 652] [08-07 09:27:00 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:59 652] [08-07 09:27:00 TUYA E][svc_online_log_db.c:25] ret:-6
[2024/8/7 9:26:59 668] [08-07 09:27:00 TUYA D][svc_online_log.c:182] load env fail. maybe not exist.
[2024/8/7 9:26:59 668] [08-07 09:27:00 TUYA D][svc_online_log.c:187] update property:{"value":"{\"embed_sys_env\":\"arm-xm-linux\"}"}
[2024/8/7 9:26:59 684] [08-07 09:27:00 TUYA D][tuya_ble_api.c:1417] cloud connected, stop adv!
[2024/8/7 9:26:59 684] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(640): stop_adv ---
[2024/8/7 9:26:59 684] exit_ble_thread create suc
[2024/8/7 9:26:59 700] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(644): XmBleAdvStop ---
[2024/8/7 9:26:59 700] [08-07 09:27:00 TUYA D][iot_httpc.c:1161] Post Data: {"value":"{\"embed_sys_env\":\"arm-xm-linux\"}","t":1722994020}
[2024/8/7 9:26:59 716] [08-07 09:27:00 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.property.save&devId=6c22957eb0f040d84du6po&et=1&t=1722994020&v=1.0&sign=512f34544c60b4680d5d6d70e1268672
[2024/8/7 9:26:59 732] [08-07 09:27:00 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:26:59 732] [08-07 09:27:00 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:26:59 748] [08-07 09:27:00 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:26:59 748] [08-07 09:27:00 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:26:59 764] [08-07 09:27:00 TUYA D][tuya_ble_api.c:1376] nw stat change:1->2, rpt to app.
[2024/8/7 9:26:59 764] [08-07 09:27:00 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:2
[2024/8/7 9:26:59 764] [08-07 09:27:00 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:59 780] [08-07 09:27:00 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:26:59 780] bt_ack_uncrypt 1
[2024/8/7 9:26:59 780] 02 
[2024/8/7 9:26:59 780] [08-07 09:27:00 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:26:59 796] ---[XmBleReadBuf][132]: already stop ble,could not call XmBleReadBuf
[2024/8/7 9:26:59 796] [08-07 09:27:00 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:26:59 812] [08-07 09:27:00 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:26:59 812] [08-07 09:27:00 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:26:59 828] [08-07 09:27:00 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:26:59 828] [08-07 09:27:00 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:26:59 828] [08-07 09:27:00 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:26:59 844] [08-07 09:27:00 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:26:59 860] [08-07 09:27:00 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:26:59 860] [08-07 09:27:00 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:26:59 876] --- tracepoint bt_ext_porting.c,ty_btext_thread(433): tuya_hal_thread_release ---
[2024/8/7 9:26:59 876] [08-07 09:27:00 TUYA E][bt_ext_porting.c:434] [TUYA-BTUART]ty_btext_thread deleted
[2024/8/7 9:26:59 892] [08-07 09:27:01 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994021,"success":true}
[2024/8/7 9:26:59 892] [08-07 09:27:01 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:26:59 892] [08-07 09:27:01 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:26:59 908] [08-07 09:27:01 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:26:59 908] [08-07 09:27:01 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:26:59 924] [08-07 09:27:01 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:26:59 924] [08-07 09:27:01 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:26:59 924] [08-07 09:27:01 TUYA D][simplekv.c:374] write key:em_sys_env And Value Len:32
[2024/8/7 9:26:59 940] [08-07 09:27:01 TUYA D][simplekv.c:457] new space 15 startpos:37192 size:100
[2024/8/7 9:26:59 940] [08-07 09:27:01 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:26:59 956] [08-07 09:27:01 TUYA D][simplekv.c:203] update crc 2709320389
[2024/8/7 9:26:59 956] [08-07 09:27:01 TUYA D][MainApp.c:537] tuya_ipc_sdk_mqtt_online_proc is start run
[2024/8/7 9:26:59 972] [08-07 09:27:01 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722994021 28800
[2024/8/7 9:26:59 972] [08-07 09:27:01 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722994021 28800
[2024/8/7 9:26:59 972] Init tuya_ipc_ss_init
[2024/8/7 9:26:59 987] [08-07 09:27:01 TUYA D][tuya_ipc_stream_storage.c:2015] Init stream_storage.base_path:/mnt/mmc v:4 a:101, max event per day 289 skills 1
[2024/8/7 9:26:59 988] [08-07 09:27:01 TUYA D][tuya_ipc_stream_storage.c:2161] stream storage task init success
[2024/8/7 9:27:00 004] [08-07 09:27:01 TUYA D][MainApp.c:567] local storage init result is 0
[2024/8/7 9:27:00 004] [08-07 09:27:01 TUYA D][tuya_ipc_stream_storage.c:1571] SD task begin___
[2024/8/7 9:27:00 019] [08-07 09:27:01 TUYA D][tuya_ipc_stream_storage.c:1585] report sd status 0 -> 5
[2024/8/7 9:27:00 020] 
[2024/8/7 9:27:00 020] [08-07 09:27:01 TUYA E][tuya_ipc_stream_storage.c:1914] storage not inited
[2024/8/7 9:27:00 036] [08-07 09:27:01 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:00 036] [08-07 09:27:01 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:00 036] [08-07 09:27:01 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:00 052] tuya_hal_bt_send 20
[2024/8/7 9:27:00 052] 00 21 36 05 da 22 f4 22 7e 77 6e 84 fe b0 f2 70 e2 2e 1b dc 
[2024/8/7 9:27:00 052] [08-07 09:27:01 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:00 068] 0 21 36 5 da 22 f4 22 7e 77 6e 84 fe b0 f2 70 e2 2e 1b dc 
[2024/8/7 9:27:00 068] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:00 068] [08-07 09:27:01 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:00 084] [08-07 09:27:01 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:27:00 084] tuya_hal_bt_send 17
[2024/8/7 9:27:00 084] 01 10 6c df cf 11 3d d0 e4 ac 1e 60 4a fd 55 86 c3 
[2024/8/7 9:27:00 099] [08-07 09:27:01 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:00 100] 1 10 6c df cf 11 3d d0 e4 ac 1e 60 4a fd 55 86 c3 
[2024/8/7 9:27:00 100] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:00 115]  ---
[2024/8/7 9:27:00 115] [08-07 09:27:01 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:00 116] [08-07 09:27:01 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:27:00 132] [08-07 09:27:01 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[2024/8/7 9:27:00 132] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:27:00 148] [08-07 09:27:01 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
[2024/8/7 9:27:00 148] [08-07 09:27:01 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:2  -->>
[2024/8/7 9:27:00 164] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:27:00 164] [08-07 09:27:01 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:2  <<--
[2024/8/7 9:27:00 180] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:00 180] [08-07 09:27:01 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:27:00 196] [08-07 09:27:01 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:27:00 196] [08-07 09:27:01 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:27:00 212] [08-07 09:27:01 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:27:00 212] [08-07 09:27:01 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:27:00 212] [1970-01-01 00:00:46] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:00 228] [08-07 09:27:02 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c22957eb0f040d84du6po, dp_rept_chan:5
[2024/8/7 9:27:00 244] [08-07 09:27:02 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:27:00 244] [08-07 09:27:02 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:159.
[2024/8/7 9:27:00 244] [08-07 09:27:02 TUYA D][smart_frame.c:2547] final pack:{"159":false}
[2024/8/7 9:27:00 260] [08-07 09:27:02 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:27:00 260] [08-07 09:27:02 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60387 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:27:00 276] [08-07 09:27:02 TUYA D][smart_frame.c:2135] sync rslt:0
[2024/8/7 9:27:00 276] [08-07 09:27:02 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:27:00 292] [08-07 09:27:02 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:27:00 292] [08-07 09:27:02 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722994022, rept_cnt:1.
[2024/8/7 9:27:00 308] [08-07 09:27:02 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722994022, rept_cnt:0.
[2024/8/7 9:27:00 308] [08-07 09:27:02 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722994022, rept_cnt:0.
[2024/8/7 9:27:00 324] [1970-01-01 00:00:47] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:00 324] [08-07 09:27:02 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994022}
[2024/8/7 9:27:00 340] [08-07 09:27:02 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.uuid.pskkey.get&et=1&t=1722994022&uuid=uuidcaab27b0a838d239&v=1.0&sign=0829c110f6fd63b1c83a0f8b06957e99
[2024/8/7 9:27:00 356] [08-07 09:27:02 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:00 356] [08-07 09:27:02 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:00 372] [08-07 09:27:02 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:00 372] [08-07 09:27:02 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:00 387] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:27:00 387] Mode(Product):0
[2024/8/7 9:27:00 388] BpuMode:[Online]
[2024/8/7 9:27:00 388] VpssMode:[Online]
[2024/8/7 9:27:00 388] [0.LimitUp_info]:
[2024/8/7 9:27:00 388] LimitUp:[Disable]
[2024/8/7 9:27:00 388] [2680*0]->[3840*0])
[2024/8/7 9:27:00 388] chn	TotalSize	ActiveSize
[2024/8/7 9:27:00 388] 0	5034*2246	2680*2160
[2024/8/7 9:27:00 404] 0	5034*2246	2680*2160
[2024/8/7 9:27:00 404] 0	5046*2246	3840*2160
[2024/8/7 9:27:00 404] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:27:00 404] [1.VICU_info]:
[2024/8/7 9:27:00 404] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:27:00 404] 0	25.0	980	0	0	183	linear	8ddb00
[2024/8/7 9:27:00 404] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:27:00 419] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:27:00 420] en	op_type	m_chn	now
[2024/8/7 9:27:00 420] 0	1	1	1
[2024/8/7 9:27:00 420] [2.VI_info]:
[2024/8/7 9:27:00 420] chn	TotalSize	ActiveSize
[2024/8/7 9:27:00 420] 0	5040*2246	3848*2166
[2024/8/7 9:27:00 420] 1	   0*   0	   0*   0
[2024/8/7 9:27:00 420] [3.MIPI_info]:
[2024/8/7 9:27:00 436] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:27:00 436] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:27:00 436] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:27:00 436] [4.Cut_info]:
[2024/8/7 9:27:00 451] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:27:00 451] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:27:00 451] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:27:00 451] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:27:00 451] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:27:00 451] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:27:00 468] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:27:00 468] [5.IB(isp buffer info)]:
[2024/8/7 9:27:00 468] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:27:00 468] PoolId  Count  Size
[2024/8/7 9:27:00 484] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:00 484] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:00 501] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:00 501] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:00 501] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:00 517] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:00 517] [08-07 09:27:02 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:00 533] [08-07 09:27:02 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:00 533] [08-07 09:27:02 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:00 548] [08-07 09:27:02 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:00 548] [08-07 09:27:02 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:00 548] [08-07 09:27:02 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:00 564] [08-07 09:27:02 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:00 564] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:27:00 580] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:27:00 580] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:27:00 580] 0       0         0          1          4       
[2024/8/7 9:27:00 596] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:27:00 596]      --265--            --264--                                               
[2024/8/7 9:27:00 596] Count      Line     Count      Line     
[2024/8/7 9:27:00 612] 766        480      1853       560      
[2024/8/7 9:27:00 612] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:27:00 612] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:27:00 628] 0   3840   2160    H265  0      0        0           457       978974     4066     	
[2024/8/7 9:27:00 628] 1   640    360     H265  0      0        0           302       43200      0        	
[2024/8/7 9:27:00 644] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:27:00 644] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:27:00 660] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:27:00 676] 0   Y      457      0       0       14       1        456      456      653       64887         59145    143327   64603    12      
[2024/8/7 9:27:00 691] 1   Y      302      0       6       1        0        302      302      655       2910          1928     34379    2825     9       
[2024/8/7 9:27:00 691] 3   N      0        0       0       1        0        0        0        656       0             0        0        0        0       
[2024/8/7 9:27:00 707] [1970-01-01 00:00:47] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:00 708] [08-07 09:27:02 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:00 723] [08-07 09:27:02 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:00 739] [08-07 09:27:02 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"pskKey":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80"},"t":1722994022,"success":true}
[2024/8/7 9:27:00 740] [08-07 09:27:02 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:00 756] [08-07 09:27:02 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:00 772] [08-07 09:27:02 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80","auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:27:00 788] [08-07 09:27:02 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:27:00 788] [08-07 09:27:02 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:27:00 788] [08-07 09:27:02 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:27:00 803] [08-07 09:27:02 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:256
[2024/8/7 9:27:00 803] [08-07 09:27:02 TUYA D][simplekv.c:397] 0 key same AND size old 276 >= new 256
[2024/8/7 9:27:00 819] [08-07 09:27:02 TUYA D][simplekv.c:430] find 0 available space
[2024/8/7 9:27:00 819] [08-07 09:27:02 TUYA D][simplekv.c:474] reuse available space 28700
[2024/8/7 9:27:00 819] [08-07 09:27:02 TUYA D][simplekv.c:203] update crc 1089207604
[2024/8/7 9:27:00 835] [08-07 09:27:02 TUYA D][app_agent.c:706] udp ip: 192.168.31.144
[2024/8/7 9:27:00 835] [08-07 09:27:02 TUYA D][app_agent.c:713] udp close fd, and start to recreate
[2024/8/7 9:27:00 851] [08-07 09:27:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:00 851] [08-07 09:27:02 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:00 851] [08-07 09:27:02 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:27:00 851] set sd_record_on_off:1 
[2024/8/7 9:27:00 851] set sd_record_mode:0 
[2024/8/7 9:27:00 867] [08-07 09:27:03 TUYA E][tuya_ipc_stream_storage.c:1912] the ss mgr not inited, but msg buffered: set mode 1
[2024/8/7 9:27:00 867] write RecordMode success  0 
[2024/8/7 9:27:00 883] [08-07 09:27:03 TUYA D][tuya_ipc_cloud_storage.c:2188] init cloud storage begin
[2024/8/7 9:27:00 883] [08-07 09:27:03 TUYA D][simplekv.c:1211] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:00 884] [08-07 09:27:03 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:00 899] [08-07 09:27:03 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:00 900] [08-07 09:27:03 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:00 916] [08-07 09:27:03 TUYA E][tuya_ipc_cloud_storage.c:365] iot_wd_common_read fails md5_encrypt_key -6
[2024/8/7 9:27:00 916] [08-07 09:27:03 TUYA E][tuya_ipc_cloud_storage.c:450] read key_key file failed.
[2024/8/7 9:27:00 932] [08-07 09:27:03 TUYA D][tuya_ipc_cloud_storage.c:2240] __check_md5_encrypt_key fail, need update from server
[2024/8/7 9:27:00 932] [08-07 09:27:03 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:27:00 948] [08-07 09:27:03 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:00 948] [08-07 09:27:03 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:00 948] [08-07 09:27:03 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:00 964] [08-07 09:27:03 TUYA E][tuya_ipc_cloud_storage.c:942] iot_wd_common_read fails storage_restriction -6
[2024/8/7 9:27:00 964] [08-07 09:27:03 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994023}
[2024/8/7 9:27:00 980] [08-07 09:27:03 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.restriction.config.get&devId=6c22957eb0f040d84du6po&et=1&t=1722994023&v=1.0&sign=39e1e6724ee303b4c71ece1fc4943834
[2024/8/7 9:27:00 996] [08-07 09:27:03 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:00 996] [08-07 09:27:03 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:01 012] [08-07 09:27:03 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:01 012] [08-07 09:27:03 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:01 028] [08-07 09:27:03 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:01 028] [08-07 09:27:03 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:01 044] [08-07 09:27:03 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:01 044] [08-07 09:27:03 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:01 060] [08-07 09:27:03 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:01 060] [08-07 09:27:03 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:01 076] [08-07 09:27:03 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:01 076] [08-07 09:27:03 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:01 092] [08-07 09:27:03 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:01 108] [08-07 09:27:03 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"msg":{"audioDuration":15,"audioInterval":300,"videoDuration":6,"videoInterval":300},"storage":{"mtu":10}},"t":1722994023,"success":true}
[2024/8/7 9:27:01 108] [08-07 09:27:03 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:01 124] [08-07 09:27:03 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:01 124] [08-07 09:27:03 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:27:01 140] [08-07 09:27:03 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:01 140] [08-07 09:27:03 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:01 140] [08-07 09:27:03 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:01 156] [08-07 09:27:03 TUYA D][simplekv.c:374] write key:storage_restriction And Value Len:32
[2024/8/7 9:27:01 156] [08-07 09:27:03 TUYA D][simplekv.c:457] new space 16 startpos:37292 size:100
[2024/8/7 9:27:01 172] [08-07 09:27:03 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:01 172] [08-07 09:27:03 TUYA D][simplekv.c:203] update crc 3102968875
[2024/8/7 9:27:01 172] [08-07 09:27:03 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:34 ip:0xc0a81ff2
[2024/8/7 9:27:01 188] [08-07 09:27:03 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:01 188] [08-07 09:27:03 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:01 204] [08-07 09:27:03 TUYA D][tuya_ipc_cloud_storage.c:920] slice_duration write success
[2024/8/7 9:27:01 204] [08-07 09:27:03 TUYA D][tuya_ipc_cloud_storage.c:999] case 2 get slice duration from cloud 10
[2024/8/7 9:27:01 220] [08-07 09:27:03 TUYA D][tuya_ipc_cloud_storage.c:1043] cloud storage seize 3059584 bytes memory for media data, each slice 10 seconds
[2024/8/7 9:27:01 236] [08-07 09:27:03 TUYA I][uni_thread.c:228] thread_create name:cloud_storage,stackDepth:65536,totalstackDepth:91136,priority:3
[2024/8/7 9:27:01 236] [08-07 09:27:03 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[2024/8/7 9:27:01 252] [08-07 09:27:03 TUYA D][uni_thread.c:250] Thread:cloud_storage Exec Start. Set to Running Stat
[2024/8/7 9:27:01 252] [08-07 09:27:03 TUYA D][tuya_ipc_cloud_storage.c:2289] init cloud storage success
[2024/8/7 9:27:01 252] [08-07 09:27:03 TUYA D][MainApp.c:590] cloud storage init result is 0
[2024/8/7 9:27:01 267] [08-07 09:27:03 TUYA D][iot_httpc.c:1161] Post Data: {"type":"MediaStor","t":1722994023}
[2024/8/7 9:27:01 284] [08-07 09:27:03 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c22957eb0f040d84du6po&et=1&t=1722994023&v=3.0&sign=81037d8f4d783d18211af8c4997f4b77
[2024/8/7 9:27:01 284] [08-07 09:27:03 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:01 299] [08-07 09:27:03 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:01 300] [08-07 09:27:03 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:01 316] [08-07 09:27:03 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:01 316] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:01 332] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:01 332] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:01 348] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:01 348] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"105":false}
[2024/8/7 9:27:01 363] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60388 Q:1 Data:{"dps":{"105":false}}
[2024/8/7 9:27:01 363] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:01 380] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:01 380] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:27:01 380] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:01 396] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"101":true}
[2024/8/7 9:27:01 396] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60389 Q:1 Data:{"dps":{"101":true}}
[2024/8/7 9:27:01 412] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:01 412] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:01 428] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:01 428] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:01 444] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"103":false}
[2024/8/7 9:27:01 444] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60390 Q:1 Data:{"dps":{"103":false}}
[2024/8/7 9:27:01 460] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:01 463] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:01 477] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:27:01 477] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:01 477] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"104":true}
[2024/8/7 9:27:01 493] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60391 Q:1 Data:{"dps":{"104":true}}
[2024/8/7 9:27:01 493] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:01 508] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:107 not find
[2024/8/7 9:27:01 508] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:01 508] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:01 526] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:01 526] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:108 not find
[2024/8/7 9:27:01 541] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:01 541] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:01 541] IPC_APP_get_smart_mutile_light_mode line(546) ----------  
[2024/8/7 9:27:01 556] [08-07 09:27:03 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:01 556] [08-07 09:27:03 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:01 572] [08-07 09:27:03 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 3
[2024/8/7 9:27:01 572] [08-07 09:27:03 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:01 572] [08-07 09:27:03 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:27:01 588] [08-07 09:27:03 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:27:01 588] [08-07 09:27:03 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:27:01 588] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:64, id:34, sequence_out:34340
[2024/8/7 9:27:01 604] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"105":false}} pro:4 num:60388
[2024/8/7 9:27:01 620] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"105":false}}} offset:58
[2024/8/7 9:27:01 620] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"105":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:01 636] [08-07 09:27:03 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:01 636] [08-07 09:27:03 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:01 652] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"101":true}} pro:4 num:60389
[2024/8/7 9:27:01 652] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"101":true}}} offset:57
[2024/8/7 9:27:01 668] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"101":true}}, msg_len:20, out_len:72
[2024/8/7 9:27:01 668] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"103":false}} pro:4 num:60390
[2024/8/7 9:27:01 684] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"103":false}}} offset:58
[2024/8/7 9:27:01 700] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"103":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:01 700] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"104":true}} pro:4 num:60391
[2024/8/7 9:27:01 716] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"104":true}}} offset:57
[2024/8/7 9:27:01 716] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"104":true}}, msg_len:20, out_len:72
[2024/8/7 9:27:01 732] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:27:01 732] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:27:01 732] IPC_APP_set_smart_mutile_light_mode line(451) ---------- :0 ,g_SMLAbility=[0]
[2024/8/7 9:27:01 748] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[2024/8/7 9:27:01 764] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:105, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:01 764] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:105, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:01 780] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:105, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:01 780] [08-07 09:27:03 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:01 780] [08-07 09:27:03 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:01 796] [08-07 09:27:03 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:01 812] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0
[2024/8/7 9:27:01 812] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:101, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:01 828] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:101, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:01 828] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:101, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:01 843] DEBUG: camera_set_dnc_mode_chn 0 
[2024/8/7 9:27:01 843] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:27:01 843] DEBUG: software pohtoR!
[2024/8/7 9:27:01 843] IPC_APP_set_smart_mutile_light_mode line(536) ---------- :mode=[0] 
[2024/8/7 9:27:01 859] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:01 860] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<124> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:01 875] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:01 876] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"124":"auto"}
[2024/8/7 9:27:01 892] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60392 Q:1 Data:{"dps":{"124":"auto"}}
[2024/8/7 9:27:01 892] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"124":"auto"}} pro:4 num:60392
[2024/8/7 9:27:01 908] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"124":"auto"}}} offset:59
[2024/8/7 9:27:01 924] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"124":"auto"}}, msg_len:22, out_len:74
[2024/8/7 9:27:01 924] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0
[2024/8/7 9:27:01 940] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:103, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:01 940] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:103, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:01 956] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:103, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:01 956] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:01 972] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:01 972] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:27:01 988] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:01 988] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"134":true}
[2024/8/7 9:27:02 004] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60393 Q:1 Data:{"dps":{"134":true}}
[2024/8/7 9:27:02 004] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"134":true}} pro:4 num:60393
[2024/8/7 9:27:02 020] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"134":true}}} offset:57
[2024/8/7 9:27:02 020] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"134":true}}, msg_len:20, out_len:72
[2024/8/7 9:27:02 036] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 036] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:02 052] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:02 052] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"106":"1"}
[2024/8/7 9:27:02 068] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60394 Q:1 Data:{"dps":{"106":"1"}}
[2024/8/7 9:27:02 068] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"106":"1"}} pro:4 num:60394
[2024/8/7 9:27:02 084] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"106":"1"}}} offset:56
[2024/8/7 9:27:02 084] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"106":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:27:02 100] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 100] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:168 not find
[2024/8/7 9:27:02 116] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:02 116] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:02 116] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(855):  ---
[2024/8/7 9:27:02 132] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0
[2024/8/7 9:27:02 148] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:104, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:02 148] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:104, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 164] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:104, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 164] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(866):  ---
[2024/8/7 9:27:02 179] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(872):  ---
[2024/8/7 9:27:02 179] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(892):  ---
[2024/8/7 9:27:02 195] [IPC_APP_get_alarm_zone_draw][893] alarm zone[{\"num\":1,\"region0\":{\"x\":1,\"y\":1,\"xlen\":99,\"ylen\":99}}]
[2024/8/7 9:27:02 195] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 195] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:169 not find
[2024/8/7 9:27:02 211] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:02 211] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:02 211] curr sd_status:1 
[2024/8/7 9:27:02 211] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 227] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:02 244] [08-07 09:27:03 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:5
[2024/8/7 9:27:02 244] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:02 244] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"110":5}
[2024/8/7 9:27:02 259] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60395 Q:1 Data:{"dps":{"110":5}}
[2024/8/7 9:27:02 259] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"110":5}} pro:4 num:60395
[2024/8/7 9:27:02 276] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"110":5}}} offset:54
[2024/8/7 9:27:02 291] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"110":5}}, msg_len:17, out_len:69
[2024/8/7 9:27:02 292] handle_DP_SD_STORAGE_ONLY_GET line(654) --------------------- 
[2024/8/7 9:27:02 308] [1970-01-01 00:00:48] tuya_ipc_sd_demo.c(182) <tuya_ipc_sd_get_capacity>: XM_SDCardGetPartitionInfo failed
[2024/8/7 9:27:02 308] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 324] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:02 324] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:02 324] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0"}
[2024/8/7 9:27:02 340] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"109":"0|0|0"}} pro:4 num:60396
[2024/8/7 9:27:02 356] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"109":"0|0|0"}}} offset:60
[2024/8/7 9:27:02 356] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"109":"0|0|0"}}, msg_len:23, out_len:75
[2024/8/7 9:27:02 372] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60396 Q:1 Data:{"dps":{"109":"0|0|0"}}
[2024/8/7 9:27:02 372] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 388] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:02 388] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:27:02 404] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:02 404] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"150":true}
[2024/8/7 9:27:02 420] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"150":true}} pro:4 num:60397
[2024/8/7 9:27:02 420] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"150":true}}} offset:57
[2024/8/7 9:27:02 436] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"150":true}}, msg_len:20, out_len:72
[2024/8/7 9:27:02 436] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60397 Q:1 Data:{"dps":{"150":true}}
[2024/8/7 9:27:02 452] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 452] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:02 468] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:02 468] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"151":"1"}
[2024/8/7 9:27:02 484] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"151":"1"}} pro:4 num:60398
[2024/8/7 9:27:02 484] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"151":"1"}}} offset:56
[2024/8/7 9:27:02 500] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"151":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:27:02 500] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60398 Q:1 Data:{"dps":{"151":"1"}}
[2024/8/7 9:27:02 516] [08-07 09:27:03 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 5
[2024/8/7 9:27:02 516] [08-07 09:27:03 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:02 516] [08-07 09:27:03 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:27:02 532] [08-07 09:27:03 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 16
[2024/8/7 9:27:02 532] [08-07 09:27:03 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:02 547] [08-07 09:27:03 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:02 547] [08-07 09:27:03 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:0,dpnum:41.
[2024/8/7 9:27:02 563] [08-07 09:27:03 TUYA D][smart_frame.c:2547] final pack:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"124":"auto","134":true,"150":true,"151":"1","159":false}}
[2024/8/7 9:27:02 579] [08-07 09:27:03 TUYA D][app_agent.c:1240] Send Query To App:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"124":"auto","134":true,"150":true,"151":"1","159":false}}
[2024/8/7 9:27:02 595] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:160, id:34, sequence_out:34341
[2024/8/7 9:27:02 595] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"124":"auto"}}, mqtt async dp cb:0
[2024/8/7 9:27:02 612] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:124, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:02 612] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:124, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 628] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:124, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 644] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0
[2024/8/7 9:27:02 644] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:134, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:02 661] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:134, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 661] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:134, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 676] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"106":"1"}}, mqtt async dp cb:0
[2024/8/7 9:27:02 677] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:106, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:02 692] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:106, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 707] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:106, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 707] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0
[2024/8/7 9:27:02 724] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:110, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:02 724] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:110, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 740] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:110, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 740] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"109":"0|0|0"}}, mqtt async dp cb:0
[2024/8/7 9:27:02 756] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:109, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:02 772] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:109, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 772] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:109, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 788] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0
[2024/8/7 9:27:02 788] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:150, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:02 804] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:150, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 804] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:150, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 820] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[2024/8/7 9:27:02 820] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 836] [08-07 09:27:03 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:02 852] [08-07 09:27:03 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:02 852] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:151, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:02 868] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:151, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 868] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:151, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:02 884] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:02 899] [08-07 09:27:03 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:0
[2024/8/7 9:27:02 900] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:02 900] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 9:27:02 915] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"117":0}} pro:4 num:60399
[2024/8/7 9:27:02 916] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"117":0}}} offset:54
[2024/8/7 9:27:02 931] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"117":0}}, msg_len:17, out_len:69
[2024/8/7 9:27:02 947] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34342
[2024/8/7 9:27:02 947] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60399 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 9:27:02 947] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:02 963] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<138> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:02 963] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:02 980] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:02 980] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"138":false}
[2024/8/7 9:27:02 995] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"138":false}} pro:4 num:60400
[2024/8/7 9:27:02 995] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"138":false}}} offset:58
[2024/8/7 9:27:03 012] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"138":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:03 028] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34343
[2024/8/7 9:27:03 028] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60400 Q:1 Data:{"dps":{"138":false}}
[2024/8/7 9:27:03 028] current power mode:1
[2024/8/7 9:27:03 028] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 043] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:146 not find
[2024/8/7 9:27:03 043] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:03 059] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:03 059] current battery percent:80
[2024/8/7 9:27:03 059] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 075] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:145 not find
[2024/8/7 9:27:03 076] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:03 076] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:03 091] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 091] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:03 107] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:03 107] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:03 123] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"170":false}
[2024/8/7 9:27:03 123] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"170":false}} pro:4 num:60401
[2024/8/7 9:27:03 139] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"170":false}}} offset:58
[2024/8/7 9:27:03 139] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"170":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:03 155] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34344
[2024/8/7 9:27:03 155] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60401 Q:1 Data:{"dps":{"170":false}}
[2024/8/7 9:27:03 171] src/intelligent_track_thread.c(1466) [XM_GetBodyTarckEnable]: 
[2024/8/7 9:27:03 171] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 187] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:03 187] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:03 203] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:03 203] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"161":false}
[2024/8/7 9:27:03 203] [08-07 09:27:03 TUYA D][com_protocol.c:586] To[atbm_log]:tso xmit(2902)
[2024/8/7 9:27:03 219] :0 src:{"dps":{"161":false}} pro:4 num:60402
[2024/8/7 9:27:03 219] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"161":false}}} offset:58
[2024/8/7 9:27:03 235] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"161":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:03 235] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34345
[2024/8/7 9:27:03 251] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60402 Q:1 Data:{"dps":{"161":false}}
[2024/8/7 9:27:03 251] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 268] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:186 not find
[2024/8/7 9:27:03 268] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:03 268] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:03 284] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 284] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<133> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:03 300] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:03 300] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3"}
[2024/8/7 9:27:03 316] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"133":"3"}} pro:4 num:60403
[2024/8/7 9:27:03 316] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"133":"3"}}} offset:56
[2024/8/7 9:27:03 332] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"133":"3"}}, msg_len:19, out_len:71
[2024/8/7 9:27:03 332] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34346
[2024/8/7 9:27:03 348] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60403 Q:1 Data:{"dps":{"133":"3"}}
[2024/8/7 9:27:03 348] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[2024/8/7 9:27:03 364] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:117, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:03 380] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:117, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 380] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:117, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 396] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"138":false}}, mqtt async dp cb:0
[2024/8/7 9:27:03 396] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 412] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:03 412] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:03 428] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:03 428] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 9:27:03 444] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"139":false}} pro:4 num:60404
[2024/8/7 9:27:03 444] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"139":false}}} offset:58
[2024/8/7 9:27:03 460] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"139":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:03 460] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34347
[2024/8/7 9:27:03 475] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:138, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:03 476] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:138, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 491] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:138, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 507] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60404 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 9:27:03 507] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"170":false}}, mqtt async dp cb:0
[2024/8/7 9:27:03 524] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:170, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:03 524] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:170, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 540] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:170, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 540] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"161":false}}, mqtt async dp cb:0
[2024/8/7 9:27:03 556] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:161, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:03 572] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:161, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 572] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:161, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 588] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 70 enable 0 volume
[2024/8/7 9:27:03 588] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 588] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"133":"3"}}, mqtt async dp cb:0
[2024/8/7 9:27:03 604] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:03 620] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:03 620] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:133, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:03 635] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:133, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 636] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:133, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:03 651] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"140":"1"}
[2024/8/7 9:27:03 651] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"140":"1"}} pro:4 num:60405
[2024/8/7 9:27:03 668] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"140":"1"}}} offset:56
[2024/8/7 9:27:03 684] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"140":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:27:03 684] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34348
[2024/8/7 9:27:03 700] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60405 Q:1 Data:{"dps":{"140":"1"}}
[2024/8/7 9:27:03 701] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 701] [08-07 09:27:03 TUYA E][smart_frame.c:569] dparr[0] type not match:1 0
[2024/8/7 9:27:03 716] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3586
[2024/8/7 9:27:03 716] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 732] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:03 732] [08-07 09:27:03 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:50
[2024/8/7 9:27:03 732] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:03 748] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"160":50}
[2024/8/7 9:27:03 748] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"160":50}} pro:4 num:60406
[2024/8/7 9:27:03 764] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"160":50}}} offset:55
[2024/8/7 9:27:03 780] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"160":50}}, msg_len:18, out_len:70
[2024/8/7 9:27:03 780] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34349
[2024/8/7 9:27:03 795] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60406 Q:1 Data:{"dps":{"160":50}}
[2024/8/7 9:27:03 796] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 796] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:195 not find
[2024/8/7 9:27:03 811] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:03 811] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:03 812] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 827] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:194 not find
[2024/8/7 9:27:03 827] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:03 844] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:03 844] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 844] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:158 not find
[2024/8/7 9:27:03 860] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:03 860] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:03 860] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 876] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:03 876] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:03 891] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:03 892] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:27:03 907] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:60407
[2024/8/7 9:27:03 908] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 9:27:03 923] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:03 939] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34350
[2024/8/7 9:27:03 939] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60407 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:27:03 955] [1970-01-01 00:00:48] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:03 955] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:03 971] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:03 971] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:03 971] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:03 987] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"174":false}
[2024/8/7 9:27:03 987] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"174":false}} pro:4 num:60408
[2024/8/7 9:27:04 003] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"174":false}}} offset:58
[2024/8/7 9:27:04 019] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"174":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:04 019] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34351
[2024/8/7 9:27:04 035] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60408 Q:1 Data:{"dps":{"174":false}}
[2024/8/7 9:27:04 035] [1970-01-01 00:00:48] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:04 035] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:04 051] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:04 067] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:04 067] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"175":"0"}
[2024/8/7 9:27:04 067] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"175":"0"}} pro:4 num:60409
[2024/8/7 9:27:04 083] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"175":"0"}}} offset:56
[2024/8/7 9:27:04 100] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"175":"0"}}, msg_len:19, out_len:71
[2024/8/7 9:27:04 100] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34352
[2024/8/7 9:27:04 116] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60409 Q:1 Data:{"dps":{"175":"0"}}
[2024/8/7 9:27:04 116] [08-07 09:27:03 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1722994023,"success":true}
[2024/8/7 9:27:04 132] [08-07 09:27:03 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:04 132] [08-07 09:27:03 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:04 148] [08-07 09:27:03 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[2024/8/7 9:27:04 148] [08-07 09:27:03 TUYA D][tuya_ipc_cloud_storage.c:535] order expire or remote server error
[2024/8/7 9:27:04 164] [08-07 09:27:03 TUYA E][tuya_ipc_cloud_storage.c:1695] check cloud storage count failed, op_ret = -1
[2024/8/7 9:27:04 164] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"139":false}}, mqtt async dp cb:0
[2024/8/7 9:27:04 180] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:139, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:04 180] [1970-01-01 00:00:48] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:04 196] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:139, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 196] cruiseTimeMode is 0.
[2024/8/7 9:27:04 212] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:139, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 212] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"140":"1"}}, mqtt async dp cb:0
[2024/8/7 9:27:04 228] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:140, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:04 228] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:140, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 244] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:140, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 260] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"160":50}}, mqtt async dp cb:0
[2024/8/7 9:27:04 261] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:160, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:04 276] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:160, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 276] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:160, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 292] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:27:04 292] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722994023, rept_cnt:2.
[2024/8/7 9:27:04 308] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 324] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 324] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"174":false}}, mqtt async dp cb:0
[2024/8/7 9:27:04 340] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:174, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:04 340] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:174, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 356] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:174, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 356] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"175":"0"}}, mqtt async dp cb:0
[2024/8/7 9:27:04 372] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:175, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:04 388] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:175, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 388] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:175, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 388] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:04 404] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:04 420] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:04 420] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"176":"0"}
[2024/8/7 9:27:04 436] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60410 Q:1 Data:{"dps":{"176":"0"}}
[2024/8/7 9:27:04 436] [1970-01-01 00:00:48] utils.c(322) <ReadTYJsonConfig>: Get antiFlicker object error!
[2024/8/7 9:27:04 436] anti Flicker mode is 0.
[2024/8/7 9:27:04 436] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:04 452] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:188 not find
[2024/8/7 9:27:04 452] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:04 468] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:04 468] [1970-01-01 00:00:48] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:27:04 468] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:04 484] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:192 not find
[2024/8/7 9:27:04 484] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:04 500] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:04 500] [1970-01-01 00:00:48] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:27:04 500] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:04 516] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:193 not find
[2024/8/7 9:27:04 516] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:04 532] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:04 532] [1970-01-01 00:00:48] utils.c(322) <ReadTYJsonConfig>: Get FlightWarn object error!
[2024/8/7 9:27:04 532] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:04 548] [08-07 09:27:03 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:173 not find
[2024/8/7 9:27:04 548] [08-07 09:27:03 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:04 564] [08-07 09:27:03 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:04 564] [1970-01-01 00:00:48] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:27:04 564] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:04 580] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:04 580] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:04 596] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:04 596] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"120":false}
[2024/8/7 9:27:04 611] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60411 Q:1 Data:{"dps":{"120":false}}
[2024/8/7 9:27:04 611] [08-07 09:27:03 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:04 628] [08-07 09:27:03 TUYA D][smart_frame.c:419] dp<231> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:04 628] [08-07 09:27:03 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:04 643] [08-07 09:27:03 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:04 644] [08-07 09:27:03 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"231":false}
[2024/8/7 9:27:04 659] [08-07 09:27:03 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60412 Q:1 Data:{"dps":{"231":false}}
[2024/8/7 9:27:04 676] [08-07 09:27:03 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}","t":1722994023}
[2024/8/7 9:27:04 691] [08-07 09:27:03 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c22957eb0f040d84du6po&et=1&t=1722994023&v=1.0&sign=4606276d96cb77465175495496fc5f4a
[2024/8/7 9:27:04 691] [08-07 09:27:03 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:04 707] [08-07 09:27:03 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:04 707] [08-07 09:27:03 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:04 707] [08-07 09:27:03 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:04 724] [08-07 09:27:03 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:27:04 724] [08-07 09:27:03 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:27:04 740] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"176":"0"}} pro:4 num:60410
[2024/8/7 9:27:04 740] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"176":"0"}}} offset:56
[2024/8/7 9:27:04 756] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"176":"0"}}, msg_len:19, out_len:71
[2024/8/7 9:27:04 756] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"176":"0"}}, mqtt async dp cb:0
[2024/8/7 9:27:04 772] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34353
[2024/8/7 9:27:04 772] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:176, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:04 788] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:176, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 804] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:176, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 804] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"120":false}} pro:4 num:60411
[2024/8/7 9:27:04 820] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"120":false}}} offset:58
[2024/8/7 9:27:04 820] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"120":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:04 835] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34354
[2024/8/7 9:27:04 836] [08-07 09:27:03 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"231":false}} pro:4 num:60412
[2024/8/7 9:27:04 852] [08-07 09:27:03 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994023,"data":{"dps":{"231":false}}} offset:58
[2024/8/7 9:27:04 867] [08-07 09:27:03 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"231":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:04 867] [08-07 09:27:03 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34355
[2024/8/7 9:27:04 884] [08-07 09:27:03 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:04 884] [08-07 09:27:03 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:04 900] [08-07 09:27:03 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:04 900] [08-07 09:27:03 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:04 900] [08-07 09:27:03 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:04 916] [08-07 09:27:03 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:04 916] [08-07 09:27:03 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:04 932] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"120":false}}, mqtt async dp cb:0
[2024/8/7 9:27:04 932] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:120, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:04 947] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:120, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 963] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:120, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 964] [08-07 09:27:03 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"231":false}}, mqtt async dp cb:0
[2024/8/7 9:27:04 980] [08-07 09:27:03 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:231, curr_t:1722994023, rept_cnt:1.
[2024/8/7 9:27:04 980] [08-07 09:27:03 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:231, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 995] [08-07 09:27:03 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:231, curr_t:1722994023, rept_cnt:0.
[2024/8/7 9:27:04 996] [08-07 09:27:03 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:05 012] [08-07 09:27:03 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:05 027] [08-07 09:27:03 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994023,"success":true}
[2024/8/7 9:27:05 028] [08-07 09:27:03 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:05 028] [08-07 09:27:03 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:05 043] [08-07 09:27:03 TUYA D][tuya_ipc_skill.c:198] upload data: {\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}
[2024/8/7 9:27:05 059] [08-07 09:27:03 TUYA D][MainApp.c:597] tuya_ipc_sdk_mqtt_online_proc is end run
[2024/8/7 9:27:05 059] [1970-01-01 00:00:48] MainApp.c(599) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:27:05 075] tuya_ipc_p2p_demo.c(455)<TUYA_APP_Enable_P2PTransfer> Dbg: Init P2P With Max Users:5
[2024/8/7 9:27:05 075] [08-07 09:27:03 TUYA D][tuya_ipc_webrtc.c:1534] begin___
[2024/8/7 9:27:05 075] [08-07 09:27:03 TUYA D][tuya_ipc_webrtc.c:1541] --audio-:8000,format:101
[2024/8/7 9:27:05 091] [08-07 09:27:03 TUYA D][tuya_ipc_webrtc.c:1542] end___ audiocbk_hdl(0x18f5c)
[2024/8/7 9:27:05 091] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:5086] gw actived
[2024/8/7 9:27:05 107] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:5095] p2p max_client_num[5]
[2024/8/7 9:27:05 108] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:5096] p2p init media info:
[2024/8/7 9:27:05 108] [08-07 09:27:03 TUYA D][tuya_ipc_webrtc.c:1526] webrtc playback start_id 5
[2024/8/7 9:27:05 123] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:27:05 123] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4782] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:27:05 139] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:27:05 139] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4782] height[360] width[640] bitrate[1024]
[2024/8/7 9:27:05 155] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:27:05 158] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4794] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:27:05 158] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:27:05 172] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4794] height[360] width[640] bitrate[1024]
[2024/8/7 9:27:05 172] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:05 187] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:05 187] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:05 203] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:05 204] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:05 204] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:05 219] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:05 219] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:05 235] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:05 235] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:05 251] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:05 251] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4796] videoNum[2] audio codec[129] sample[0]
[2024/8/7 9:27:05 267] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:4797] databits[1] channel[0]
[2024/8/7 9:27:05 267] [08-07 09:27:03 TUYA D][tuya_ipc_p2p.c:5122] need speaker audio codec[129] sample[0] databits[1] channel[0] defLiveMode[0]
[2024/8/7 9:27:05 283] [08-07 09:27:03 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:27:05 283] [08-07 09:27:03 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:27:05 299] [08-07 09:27:03 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:27:05 299] [08-07 09:27:03 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = adb2cd63
[2024/8/7 9:27:05 299] [08-07 09:27:03 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[2024/8/7 9:27:05 315] [08-07 09:27:03 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:05 315] [08-07 09:27:03 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:27:05 332] [08-07 09:27:03 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:27:05 332] [08-07 09:27:03 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:27:05 332] [08-07 09:27:03 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:27:05 347] [08-07 09:27:03 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:27:05 347] [08-07 09:27:03 TUYA D][tuya_ipc_p2p_common.c:455] update p2p_auth_info from service, type 4
[2024/8/7 9:27:05 363] [08-07 09:27:03 TUYA D][iot_httpc.c:1161] Post Data: {"type":4,"t":1722994023}
[2024/8/7 9:27:05 379] [08-07 09:27:03 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.p2p.config.get&devId=6c22957eb0f040d84du6po&et=1&t=1722994023&v=2.0&sign=df7676d3b33d63fb579c7317fc4f08ac
[2024/8/7 9:27:05 379] [08-07 09:27:03 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:05 395] [08-07 09:27:03 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:05 395] [08-07 09:27:03 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:05 411] [08-07 09:27:03 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:05 411] [08-07 09:27:03 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:05 427] [08-07 09:27:03 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:05 427] [08-07 09:27:03 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:05 444] [08-07 09:27:03 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:05 444] [08-07 09:27:03 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:05 444] [08-07 09:27:03 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:05 459] [08-07 09:27:03 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:05 475] [08-07 09:27:03 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:05 475] [08-07 09:27:03 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:05 491] [1970-01-01 00:00:48] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time48572
[2024/8/7 9:27:05 491] [08-07 09:27:03 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"p2pId":"","type":4},"t":1722994024,"success":true}
[2024/8/7 9:27:05 507] [08-07 09:27:04 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:05 507] [08-07 09:27:04 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:05 523] [08-07 09:27:04 TUYA D][tuya_ipc_p2p_common.c:381] SY P2P AUTH:{"p2pId":"","type":4}
[2024/8/7 9:27:05 523] [08-07 09:27:04 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:05 539] [08-07 09:27:04 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:27:05 539] [08-07 09:27:04 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:27:05 539] [08-07 09:27:04 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:32
[2024/8/7 9:27:05 556] [08-07 09:27:04 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 32
[2024/8/7 9:27:05 556] [08-07 09:27:04 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:27:05 572] [08-07 09:27:04 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:27:05 572] [08-07 09:27:04 TUYA D][simplekv.c:203] update crc 1463155677
[2024/8/7 9:27:05 572] [08-07 09:27:04 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:05 588] [08-07 09:27:04 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:05 588] [08-07 09:27:04 TUYA D][tuya_ipc_p2p_common.c:458] get p2p auth info from service
[2024/8/7 9:27:05 604] [08-07 09:27:04 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:27:05 604] [08-07 09:27:04 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:27:05 604] [08-07 09:27:04 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:27:05 620] [08-07 09:27:04 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:27:05 620] [08-07 09:27:04 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:27:05 620] [08-07 09:27:04 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:27:05 636] [08-07 09:27:04 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:27:05 636] [08-07 09:27:04 TUYA D][simplekv.c:203] update crc 912432686
[2024/8/7 9:27:05 652] [08-07 09:27:04 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:05 652] [08-07 09:27:04 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:05 652] [08-07 09:27:04 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:05 668] [08-07 09:27:04 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:27:05 668] [08-07 09:27:04 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:27:05 684] [08-07 09:27:04 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[2024/8/7 9:27:05 684] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:5178] p2p did[] apiLicense[] initString[]
[2024/8/7 9:27:05 684] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:5181] support p2p type = 4
[2024/8/7 9:27:05 700] P2P API Version: 244.3.4.107
[2024/8/7 9:27:05 700] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:4974] no encrypt
[2024/8/7 9:27:05 716] 48615 (null) INFO:6241316: tuya p2p rtc sdk version: 0xf403046b, Nov 16 2023 10:52:20
[2024/8/7 9:27:05 716] tuya liteos uv
[2024/8/7 9:27:05 716] [08-07 09:27:04 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 32
[2024/8/7 9:27:05 716] [08-07 09:27:04 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:05 732] [08-07 09:27:04 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:05 812] [08-07 09:27:04 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"header":{"from":"ay1700201779576ClfQH","is_pre":0,"moto_id":"","p2p_skill":611,"path":"mqtt","security_level":3,"sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","to":"6c22957eb0f040d84du6po","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","type":"offer"},"msg":{"log":{"api":"thing.m.rtc.log","interval":60,"level":2,"size":1024,"tcp":{"address":"1.117.192.37","domain":"wework-2-cn.stream.iot-11.com","key":"6e9d446e4a2d2cdc","port":9092},"topic":"/av/moto/log"},"preconnect":true,"sdp":"v=0\r\no=- 1722994023 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c22957eb0f040d84du6po1722994023Wb8GZizT\r\nm=application 9 imm 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:W1Tn\r\na=ice-pwd:H6T3L0dmXg2J6d5Bk0ZltclP\r\na=ice-options:trickle\r\na=aes-key:4a6748596d6a62366a43734571765778\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 330\r\na=ssrc:0 cname:ay1700201779576ClfQH\r\
[2024/8/7 9:27:05 828] [08-07 09:27:04 TUYA D][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302
[2024/8/7 9:27:05 860] [08-07 09:27:04 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"header":{"from":"ay1700201779576ClfQH","moto_id":"","path":"mqtt","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","to":"6c22957eb0f040d84du6po","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","type":"candidate"},"msg":{"candidate":"a=candidate:1997559818 1 UDP 2130706431 fe80::9088:d9ff:fee0:366a 36061 typ host\r\n"}},"protocol":302,"t":1722994023}
[2024/8/7 9:27:05 875] [08-07 09:27:04 TUYA D][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302
[2024/8/7 9:27:05 907] [08-07 09:27:04 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"header":{"from":"ay1700201779576ClfQH","moto_id":"","path":"mqtt","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","to":"6c22957eb0f040d84du6po","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","type":"candidate"},"msg":{"candidate":"a=candidate:1929101385 1 UDP 2130706431 192.168.31.242 36061 typ host\r\n"}},"protocol":302,"t":1722994023}
[2024/8/7 9:27:05 908] [08-07 09:27:04 TUYA D][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302
[2024/8/7 9:27:05 923] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:27:05 955] [08-07 09:27:04 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"header":{"from":"ay1700201779576ClfQH","moto_id":"","path":"mqtt","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","to":"6c22957eb0f040d84du6po","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","type":"candidate"},"msg":{"candidate":"a=candidate:1021217858 1 UDP 1694498815 124.160.63.178 36953 typ srflx\r\n"}},"protocol":302,"t":1722994023}
[2024/8/7 9:27:05 955] [08-07 09:27:04 TUYA D][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302
[2024/8/7 9:27:06 003] [08-07 09:27:04 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"header":{"from":"ay1700201779576ClfQH","moto_id":"","path":"mqtt","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","to":"6c22957eb0f040d84du6po","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","type":"candidate"},"msg":{"candidate":"a=candidate:1592496508 1 UDP 16777215 47.103.32.85 52151 typ relay\r\n"}},"protocol":302,"t":1722994023}
[2024/8/7 9:27:06 004] [08-07 09:27:04 TUYA D][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302
[2024/8/7 9:27:06 035] [08-07 09:27:04 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"header":{"from":"ay1700201779576ClfQH","moto_id":"","path":"mqtt","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","to":"6c22957eb0f040d84du6po","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","type":"candidate"},"msg":{"candidate":""}},"protocol":302,"t":1722994023}
[2024/8/7 9:27:06 051] [08-07 09:27:04 TUYA D][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302
[2024/8/7 9:27:06 052] 49088 (null) INFO:6241316: got repeated offer, drop
[2024/8/7 9:27:06 052] [08-07 09:27:04 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 32
[2024/8/7 9:27:06 067] [08-07 09:27:04 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:06 067] [08-07 09:27:04 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:06 084] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:5039] _mqtt_p2p_listen_sessions create
[2024/8/7 9:27:06 085] [08-07 09:27:04 TUYA E][tuya_ipc_p2p.c:5190] p2p v3 init ok
[2024/8/7 9:27:06 085] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:5230] speaker task create success
[2024/8/7 9:27:06 100] [08-07 09:27:04 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 32
[2024/8/7 9:27:06 100] [08-07 09:27:04 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:06 100] [08-07 09:27:04 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:06 116] [08-07 09:27:04 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 32
[2024/8/7 9:27:06 116] [08-07 09:27:04 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:06 116] [08-07 09:27:04 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:06 132] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:5273] __p2p_session_detech create
[2024/8/7 9:27:06 132] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:4652] Begin to session detech
[2024/8/7 9:27:06 147] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:5290] __p2p_video_send_proc create ok
[2024/8/7 9:27:06 148] [08-07 09:27:04 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 32
[2024/8/7 9:27:06 148] [08-07 09:27:04 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:06 163] [08-07 09:27:04 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:06 163] [08-07 09:27:04 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 32
[2024/8/7 9:27:06 163] [08-07 09:27:04 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:06 179] [08-07 09:27:04 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:06 179] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:4124] Begin to Listen mqtt p2p client connects In Thread
[2024/8/7 9:27:06 195] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 9:27:06 195] 49094 (null) INFO:6241316: [08-07 09:27:04 TUYA D][tuya_ipc_upnp.c:437] tuya_ipc_upnp_init start
[2024/8/7 9:27:06 195] try listen
[2024/8/7 9:27:06 211] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:3553] New Thread To proc, init source
[2024/8/7 9:27:06 211] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:3572] session cmd recv proc alive [0] num[0]
[2024/8/7 9:27:06 227] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:3771] into p2p video send
[2024/8/7 9:27:06 227] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [0]
[2024/8/7 9:27:06 243] [08-07 09:27:04 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:156672,priority:2
[2024/8/7 9:27:06 243] [08-07 09:27:04 TUYA D][tuya_ipc_upnp.c:458] tuya_ipc_upnp_init success
[2024/8/7 9:27:06 259] [08-07 09:27:04 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[2024/8/7 9:27:06 259] [08-07 09:27:04 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[2024/8/7 9:27:06 275] [08-07 09:27:04 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1722994024}
[2024/8/7 9:27:06 276] [08-07 09:27:04 TUYA D][tuya_ipc_packager.c:62] get packager instance
[2024/8/7 9:27:06 276] [08-07 09:27:04 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[2024/8/7 9:27:06 292] [08-07 09:27:04 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:06 292] [08-07 09:27:04 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:06 292] [08-07 09:27:04 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:06 307] [08-07 09:27:04 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:06 308] [08-07 09:27:04 TUYA E][tuya_ipc_encrypt.c:178] read local cloud encrypt key fails ..-6
[2024/8/7 9:27:06 323] [08-07 09:27:04 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994024}
[2024/8/7 9:27:06 339] [08-07 09:27:04 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.storage.secret.get&devId=6c22957eb0f040d84du6po&et=1&t=1722994024&v=1.0&sign=9a4a04809352e84d546a30ddb3c3d1d0
[2024/8/7 9:27:06 340] [08-07 09:27:04 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:06 355] [08-07 09:27:04 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:06 355] [08-07 09:27:04 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:06 371] [08-07 09:27:04 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:06 387] [08-07 09:27:04 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6c22957eb0f040d84du6po&et=1&t=1722994024&v=1.0&sign=4ed6a0c8c2cd336d48a49650e645af34
[2024/8/7 9:27:06 387] [08-07 09:27:04 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:06 403] [08-07 09:27:04 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:06 403] [08-07 09:27:04 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:06 419] [08-07 09:27:04 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:06 419] [08-07 09:27:04 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:27:06 419] [08-07 09:27:04 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:27:06 435] [08-07 09:27:04 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:06 435] [08-07 09:27:04 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:06 451] [08-07 09:27:04 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:06 451] [08-07 09:27:04 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:06 467] [08-07 09:27:04 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:06 467] [08-07 09:27:04 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:06 467] [08-07 09:27:04 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:06 483] [08-07 09:27:04 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:06 483] [08-07 09:27:04 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:06 499] [08-07 09:27:04 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:06 499] [08-07 09:27:04 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:06 516] [08-07 09:27:04 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:06 516] [08-07 09:27:04 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:06 532] [08-07 09:27:04 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:06 532] 49118 (null) INFO:6241316: process signaling offer
[2024/8/7 9:27:06 548] 49122 (null) INFO:6241316: process control retransmit_signaling
[2024/8/7 9:27:06 548] 49122 (null) INFO:6241316: process signaling candidate
[2024/8/7 9:27:06 564] 49122 (null) INFO:6241316: process signaling candidate
[2024/8/7 9:27:06 564] 49123 (null) INFO:6241316: process signaling candidate
[2024/8/7 9:27:06 580] 49123 (null) INFO:6241316: process signaling candidate
[2024/8/7 9:27:06 580] 49124 (null) INFO:6241316: process signaling candidate
[2024/8/7 9:27:06 595] 49124 (null) INFO:6241316: process signaling candidate
[2024/8/7 9:27:06 595] [08-07 09:27:04 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:06 611] [08-07 09:27:04 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:06 627] [08-07 09:27:04 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:06 627] [08-07 09:27:04 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:06 643] 49184 (null) INFO:6241316: process signaling candidate
[2024/8/7 9:27:06 643] 49185 (null) INFO:6241316: process signaling candidate
[2024/8/7 9:27:06 659] 49187 (null) WARN:6241316: channel 4 first write
[2024/8/7 9:27:06 739] [08-07 09:27:04 TUYA D][mqc_app.c:879] Send MQTT Msg.P:302 N:60413 Q:0 Data:{"header":{"from":"6c22957eb0f040d84du6po","to":"ay1700201779576ClfQH","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","moto_id":"","type":"answer","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","is_pre":0,"p2p_skill":99,"path":"mqtt"},"msg":{"sdp":"v=0\r\no=- 49 1 IN IP4 127.0.0.1\r\ns=-\r\nt=0 0\r\na=group:BUNDLE imm0\r\na=msid-semantic: WMS 6c22957eb0f040d84du6po1722994023Wb8GZizT\r\nm=application 9 tuya 6001\r\nc=IN IP4 0.0.0.0\r\na=rtcp:9 IN IP4 0.0.0.0\r\na=ice-ufrag:SwOQ\r\na=ice-pwd:fNAjzNQHtpgkS1yteozfTAQs\r\na=ice-options:trickle\r\na=aes-key:4a6748596d6a62366a43734571765778\r\na=mid:imm0\r\na=rtpmap:6001 AES/KCP 3\r\na=ssrc:0 cname:6c22957eb0f040d84du6po\r\n","preconnect":true,"token":[{"urls":"stun:47.103.29.37:3478"},{"credential":"SwgeZ583hKIEhigDSPL4nTpLqhM=","ttl":36000,"urls":"turn:47.103.32.85:3478","username":"1723030024:6c22957eb0f040d84du6po"}],"tcp_token":{"credential
[2024/8/7 9:27:06 755] [08-07 09:27:04 TUYA D][app_agent.c:600] send length:1168, id:34, sequence_out:34362
[2024/8/7 9:27:06 755] 49193 (null) INFO:6257220: system has ipv4(yes), has ipv6(no)
[2024/8/7 9:27:06 771] 49194 (null) INFO:6257220: system has ipv4(yes), has ipv6(no)
[2024/8/7 9:27:06 771] [08-07 09:27:04 TUYA E][tuya_ipc_upnp.c:481] ipc upnp not inited
[2024/8/7 9:27:06 771] 49195 (null) INFO:6317896: upnp alloc local failed, ret = -1
[2024/8/7 9:27:06 771] watcher add 37, nfds 1
[2024/8/7 9:27:06 820] [08-07 09:27:04 TUYA D][mqc_app.c:879] Send MQTT Msg.P:302 N:60414 Q:0 Data:{"header":{"from":"6c22957eb0f040d84du6po","to":"ay1700201779576ClfQH","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","moto_id":"","type":"candidate","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","path":"mqtt"},"msg":{"candidate":"a=candidate:861278120 1 UDP 2130706431 192.168.31.144 56673 typ host\r\n"}}
[2024/8/7 9:27:06 820] [08-07 09:27:04 TUYA D][app_agent.c:600] send length:352, id:34, sequence_out:34363
[2024/8/7 9:27:06 836] 49201 (null) INFO:6258492: ice 1 state change: CANDIDATE -> CHECK
[2024/8/7 9:27:06 836] watcher add 38, nfds 2
[2024/8/7 9:27:06 836] connect ret -1
[2024/8/7 9:27:06 836] watcher add 39, nfds 3
[2024/8/7 9:27:06 868] [08-07 09:27:04 TUYA D][mqc_app.c:879] Send MQTT Msg.P:302 N:60415 Q:0 Data:{"header":{"from":"6c22957eb0f040d84du6po","to":"ay1700201779576ClfQH","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","moto_id":"","type":"candidate","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","path":"mqtt"},"msg":{"candidate":"a=candidate:1940722617 1 UDP 1694498815 124.160.63.178 36954 typ srflx\r\n"}}
[2024/8/7 9:27:06 884] [08-07 09:27:04 TUYA D][app_agent.c:600] send length:368, id:34, sequence_out:34364
[2024/8/7 9:27:06 900] [08-07 09:27:04 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"encryptKey":"992e9749e8f3402a"},"t":1722994024,"success":true}
[2024/8/7 9:27:06 900] [08-07 09:27:04 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:06 900] [08-07 09:27:04 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:06 916] [08-07 09:27:04 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:06 916] [08-07 09:27:04 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:06 916] [08-07 09:27:04 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:06 932] [08-07 09:27:04 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:06 932] [08-07 09:27:04 TUYA D][simplekv.c:374] write key:cloud_enc_key And Value Len:32
[2024/8/7 9:27:06 948] [08-07 09:27:04 TUYA D][simplekv.c:457] new space 17 startpos:37392 size:100
[2024/8/7 9:27:06 948] [08-07 09:27:04 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:06 964] [08-07 09:27:04 TUYA D][simplekv.c:203] update crc 587473299
[2024/8/7 9:27:06 980] [08-07 09:27:04 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"unitList":[{"port":7000,"protocol":"TCP"},{"port":8080,"protocol":"TCP"},{"port":5000,"protocol":"UDP"},{"port":8000,"protocol":"UDP"}]},"t":1722994024,"success":true}
[2024/8/7 9:27:06 980] [08-07 09:27:04 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:06 996] [08-07 09:27:04 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:06 996] [08-07 09:27:04 TUYA D][tuya_ipc_upnp.c:171] upnp get config success result:{
[2024/8/7 9:27:06 996] 	"unitList":	[{
[2024/8/7 9:27:06 996] 			"port":	7000,
[2024/8/7 9:27:06 996] 			"protocol":	"TCP"
[2024/8/7 9:27:06 996] 		}, {
[2024/8/7 9:27:06 996] 			"port":	8080,
[2024/8/7 9:27:07 012] 			"protocol":	"TCP"
[2024/8/7 9:27:07 012] 		}, {
[2024/8/7 9:27:07 012] 			"port":	5000,
[2024/8/7 9:27:07 012] 			"protocol":	"UDP"
[2024/8/7 9:27:07 012] 			"port":	8000,
[2024/8/7 9:27:07 012] 		}]
[2024/8/7 9:27:07 028] [08-07 09:27:04 TUYA D][tuya_ipc_upnp.c:293] tuya_ipc_upnp_start start
[2024/8/7 9:27:07 029] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10.
[2024/8/7 9:27:07 044] [08-07 09:27:04 TUYA I][uni_thread.c:228] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:222208,priority:3
[2024/8/7 9:27:07 044] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0
[2024/8/7 9:27:07 059] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0
[2024/8/7 9:27:07 075] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:5274 
[2024/8/7 9:27:07 075] error = 0
[2024/8/7 9:27:07 075] watcher remove 39, nfds 2
[2024/8/7 9:27:07 076] watcher add 39, nfds 3
[2024/8/7 9:27:07 091] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5274, in_port 5274 protocol:UDP, status:0
[2024/8/7 9:27:07 092] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:4448 
[2024/8/7 9:27:07 107] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 4448, in_port 4448 protocol:UDP, status:0
[2024/8/7 9:27:07 107] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:8538 
[2024/8/7 9:27:07 123] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8538, in_port 8538 protocol:UDP, status:0
[2024/8/7 9:27:07 124] 
[2024/8/7 9:27:07 124] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5!
[2024/8/7 9:27:07 139] [08-07 09:27:04 TUYA D][tuya_ipc_upnp.c:314] tuya_ipc_upnp_start success
[2024/8/7 9:27:07 139] [08-07 09:27:04 TUYA D][tuya_ipc_upnp.c:421] start upnp module success, exit thread
[2024/8/7 9:27:07 155] [08-07 09:27:04 TUYA D][uni_thread.c:310] Del Thrd:ipc_upnp
[2024/8/7 9:27:07 155] [08-07 09:27:04 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:07 155] [08-07 09:27:04 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:07 171] [08-07 09:27:04 TUYA D][uni_thread.c:125] del list not empty...deleting 0x269c1dc, next 0x2661a00
[2024/8/7 9:27:07 172] [08-07 09:27:04 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:27:07 187] 49311 (null) INFO:6324040: tcp 39 state change: CONNECT -> REQUEST
[2024/8/7 9:27:07 188] [08-07 09:27:04 TUYA D][uni_thread.c:250] Thread:UPnP_PROC Exec Start. Set to Running Stat
[2024/8/7 9:27:07 203] [08-07 09:27:04 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:230400,priority:3
[2024/8/7 9:27:07 203] [08-07 09:27:04 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[2024/8/7 9:27:07 236] [08-07 09:27:04 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":90000,\"profileId\":\"\",\"width\":3840,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[2024/8/7 9:27:07 252] [1970-01-01 00:00:49] tuya_ipc_p2p_demo.c(475) <TUYA_APP_Enable_P2PTransfer>: tuya_ipc_tranfser_init ret=[0]
[2024/8/7 9:27:07 252] [1970-01-01 00:00:49] MainApp.c(606) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:27:07 268] [1970-01-01 00:00:49] MainApp.c(614) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:27:07 284] [1970-01-01 00:00:49] MainApp.c(615) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:27:07 284] [1970-01-01 00:00:49] MainApp.c(616) <tuya_ipc_sdk_mqtt_online_proc>: v_handle=[0x26df720]
[2024/8/7 9:27:07 300] [1970-01-01 00:00:49] MainApp.c(617) <tuya_ipc_sdk_mqtt_online_proc>: v_handle_sub=[0x269f0c8]
[2024/8/7 9:27:07 300] [1970-01-01 00:00:49] MainApp.c(618) <tuya_ipc_sdk_mqtt_online_proc>: a_handle_sub=[0x26a5328]
[2024/8/7 9:27:07 316] [1970-01-01 00:00:49] xm_main.c(1104) <XM_RegisterTYCallFunc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:27:07 316] [1970-01-01 00:00:49] xm_main.c(1105) <XM_RegisterTYCallFunc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:27:07 332] [1970-01-01 00:00:49] xm_main.c(1106) <XM_RegisterTYCallFunc>: a_handle_sub=[0x26a5328]
[2024/8/7 9:27:07 350] [1970-01-01 00:00:49] xm_main.c(1107) <XM_RegisterTYCallFunc>: v_handle=[0x26d[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:27:07 350] f720]
[2024/8/7 9:27:07 350] [1970-01-01 00:00:49] xm_main.c(1108) <XM_RegisterTYCallFunc>: v_handle_sub=[0x269f0c8]
[2024/8/7 9:27:07 363] [1970-01-01 00:00:49] MainApp.c(620) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:27:07 364] atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:27:07 364] 32m[1970-01-01 0[atbm_log]:aggtx stop queue
[2024/8/7 9:27:07 380] 0:00:49] MainApp[atbm_log]:add to pending(0)(20)
[2024/8/7 9:27:07 381] .c(621) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:27:07 381] [08-07 09:27:04 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722994024 28800
[2024/8/7 9:27:07 395] [08-07 09:27:04 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722994024 28800
[2024/8/7 9:27:07 395] [08-07 09:27:04 TUYA D][uni_thread.c:125] del list not empty...deleting 0x269c1dc, next 0x2661a00
[2024/8/7 9:27:07 411] --- tracepoint tuya_ipc_system_control_demo.c,XM_CheckDls_Pro(810): server time_zone 28800 time 1722994024 dls 0 loacl time 49
[2024/8/7 9:27:07 411] [08-07 09:27:04 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:27:07 427] [08-07 09:27:04 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[2024/8/7 9:27:07 427] [08-07 09:27:04 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[2024/8/7 9:27:07 443] [08-07 09:27:04 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[2024/8/7 9:27:07 443] [08-07 09:27:04 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:27:07 459] [08-07 09:27:04 TUYA D][m[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:27:07 459] qc_app.c:1537] p[atbm_log]:AMPDU[eth2]:action[3],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:07 459] ub finish:0
[2024/8/7 9:27:07 475] [0[atbm_log]:add to pending(0)(20)
[2024/8/7 9:27:07 475] 8-07 09:27:04 TU[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:27:07 491] YA D][mqc_app.c:[atbm_log]:AMPDU[eth2]:action[1],tid[0],ssn[0],buff_size[0],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:07 491] 879] Send MQTT Msg.P:302 N:60416 Q:0 Dat[atbm_log]:add to pending(0)(20)
[2024/8/7 9:27:07 491] a:{"header":{"fr[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 5
[2024/8/7 9:27:07 507] om":"6c22957eb0f[atbm_log]:AMPDU[eth2]:action[1],tid[5],ssn[0],buff_size[0],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:07 523] 040d84du6po","to":"ay1700201779576ClfQH","sessionid":"6c22957eb0[atbm_log]:add to pending(0)(20)
[2024/8/7 9:27:07 523] f040d84du6po1722[atbm_log]:aggtx wake queue
[2024/8/7 9:27:07 523] 994023Wb8GZizT",[atbm_log]:not assoc 
[2024/8/7 9:27:07 523] "moto_id":"","ty[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:27:07 539] pe":"candidate",[atbm_log]:AMPDU[eth2]:action[1],tid[6],ssn[0],buff_size[0],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:07 555] "trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f[atbm_log]:eth2: deauthenticating from a4:a9:30:ce:5e:66 by local choice (reason=3)
[2024/8/7 9:27:07 571] 040d84du6po_1722994023944","path":"mqtt"},"msg":{"candidate":"a=candidate:1148860040 1 UDP 16777215 47.103.32.85 59779 typ relay\r\n"}}
[2024/8/7 9:27:07 603] [2024-08-07 09:27:04] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 479[08-07 09:27:04 TUYA D][mqc_app.c:879] Send MQTT Msg.P:302 N:60417 Q:0 Data:{"header":{"from":"6c22957eb0f040d84du6po","to":"ay1700201779576ClfQH","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","moto_id":"","type":"candidate","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","path":"mqtt"},"msg":{"candidate":""}}
[2024/8/7 9:27:07 604] [08-07 09:27:04 TUYA D][app_agent.c:600] send length:352, id:34, sequence_out:34365
[2024/8/7 9:27:07 619] [08-07 09:27:04 TUYA D][app_agent.c:600] send length:288, id:34, sequence_out:34366
[2024/8/7 9:27:07 619] 49428 (null) INFO:6258492: ice 1 state change: CHECK -> CONNECTED
[2024/8/7 9:27:07 635] 49428 (null) INFO:6241316: rtc session 00010001 on ice status: 1, cost: 308
[2024/8/7 9:27:07 651] 49428 (null) INFO:6241316: rtc 00010001 t[atbm_log]:[TX]:[0]:deatuhen[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:07 651] ransport update 1: 1 -1 [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:27:07 651] 0, 100 0 0
[2024/8/7 9:27:07 667] 49460 (null) INFO:6241316: rtc session 00010001 state change: P2P_CONNECT -> DTLS_SRTP_KEY_NEGO
[2024/8/7 9:27:07 667] 49460 (null) INFO:6241316: rtc session 00010001 state change: DTLS_SRTP_KEY_NEGO -> STREAM
[2024/8/7 9:27:07 683] 49460 (null) INFO:6241316: add new rtc session 00010001, session id 6c22957eb0f040d84du6po1722994023Wb8GZizT, connect session , status 0
[2024/8/7 9:27:07 684] 49461 (null) INFO:6241316: li[atbm_log]:[STA]:unjoin ++
[2024/8/7 9:27:07 699] sten result 00010001
[2024/8/7 9:27:07 699] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:4190] listen ok session[65537]
[2024/8/7 9:27:07 699] 49461 (null) WARN:6241316: channel 4 first send
[2024/8/7 9:27:07 715] 49464 (null) INFO:6241316: rtc 00010001 transport update 2: 2 -1 0, 100 0 0
[2024/8/7 9:27:07 715] 49464 (null) INFO:6241316: rtc 00010001 on ice data, cost: 344
[2024/8/7 9:27:07 731] 49465 (null) WARN:6241316: channel 0 get first data
[2024/8/7 9:27:07 731] 49466 (null) INFO:6324040: tcp 39 state change: REQUEST -> ACK
[2024/8/7 9:27:07 747] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 90314ba51650
[2024/8/7 9:27:07 748] 
[2024/8/7 9:27:07 748] [08-07 09:27:04 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING...
[2024/8/7 9:27:07 748] [08-07 09:27:04 TU[atbm_log]:[STA]:unjoin --
[2024/8/7 9:27:07 763] YA D][tuya_ipc_p2p.c:3687] compare passwd
[2024/8/7 9:27:07 763] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:3707] auth success
[2024/8/7 9:27:07 763] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:569] __p2p_get_idle_session begin
[2024/8/7 9:27:07 779] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:4302] create p2p sessions. cur online session num = 1
[2024/8/7 9:27:07 779] [08-07 09:27:04 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 9:27:07 795] 49480 (null) INFO:6241316: try listen
[2024/8/7 9:27:07 795] 49483 (null) INFO:6324040:[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:27:07 795]  tcp 39 state change: ACK -> STREAM
[2024/8/7 9:27:07 811] 49483 (null) INFO:6241316: rtc session 00010001 on tcp status: 1, cost: 363
[2024/8/7 9:27:07 811] 49483 (null) INFO:6241316: rtc 00010001 transport update 3: 2 -1 1, 100 0 0
[2024/8/7 9:27:07 827] [2024-08-07 09:27:04] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 1112[08-07 09:27:04 TUYA D][uni_thread.c:268] Thread:ipc_upnp Exec Finish. Set to Del Stat
[2024/8/7 9:27:07 844] [08-07 09:27:04 TUYA D][uni_thread.c:125] del list not empty...deleting 0x269c1dc, next 0x2661a00
[2024/8/7 9:27:07 844] [08-07 09:27:04 TUYA D][uni_thread.c:132] Final Free Thread:ipc_upnp, is_self:1
[2024/8/7 9:27:07 860] [08-07 09:27:04 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:27:07 860] [08-07 09:27:04 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:27:07 860] 49608 (null) WARN:6241316: channel 0 first send
[2024/8/7 9:27:07 875] 49621 (null) WARN:6241316: channel 0 first write
[2024/8/7 9:27:07 892] [08-07 09:27:05 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.107, Nov 16 2023 10:52:20\"}","t":1722994025}
[2024/8/7 9:27:07 892] [08-07 0[atbm_log]:eth2:free authen bss ++
[2024/8/7 9:27:07 907] 9:27:05 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c22957eb0f040d84du6po&et=1&t=1722994025&v=1.0&sign=dba81cff2ed07947baa2ea7bd8a92819
[2024/8/7 9:27:07 907] [08-07 09:27:05 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:07 923] [08-07 09:27:05 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:07 923] [08-07 09:27:05 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:07 939] [08-07 09:27:05 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:07 939] [08-07 09:27:05 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:07 955] [08-07 09:27:05 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:07 955] [08-07 09:27:05 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:07 971] [08-07 09:27:05 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:07 971] [08-07 09:27:05 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:07 987] [08-07 09:27:05 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:07 988] [08-07 09:27:05 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:08 003] [08-07 09:27:05 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:08 003] [08-07 09:27:05 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:08 019] [08-07 09:27:05 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722994025,"success":true}
[2024/8/7 9:27:08 019] [08-07 09:27:05 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:08 035] [08-07 09:27:05 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:08 035] g_AudioTipsList.size() enable: 0[08-07 09:27:05 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:27:08 051] [08-07 09:27:05 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:08 051] [08-07 09:27:05 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:08 067] [08-07 09:27:05 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:08 067] [08-07 09:27:05 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:27:08 083] [08-07 09:27:05 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:60418 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:27:08 083] [08-07 09:27:05 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:60418
[2024/8/7 9:27:08 099] [08-07 09:27:05 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994025,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 9:27:08 099] [08-07 09:27:05 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 9:27:08 115] [08-07 09:27:05 TUYA D][app_agent.c:600] send length:80, id:34, sequence_out:34367
[2024/8/7 9:27:08 115] [08-07 09:27:05 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:27:08 131] [08-07 09:27:05 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722994025, rept_cnt:3.
[2024/8/7 9:27:08 147] [08-07 09:27:05 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722994025, rept_cnt:0.
[2024/8/7 9:27:08 147] [08-07 09:27:05 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722994025, rept_cnt:0.
[2024/8/7 9:27:08 163] [08-07 09:27:05 TUYA D][tuya_ipc_p2p.c:3274] set video clarity session[65537]chn[0] op[4] clarity[1]
[2024/8/7 9:27:08 163] tuya_ipc_p2p_demo.c(95)<__TUYA_APP_p2p_event_cb> Dbg: p2p rev event cb=[4] 
[2024/8/7 9:27:08 179] __TUYA_APP_p2p_event_cb line(339) ---------------------- cmd(4)=TRANS_LIVE_VIDEO_CLARITY_SET 
[2024/8/7 9:27:08 179] tuya_ipc_p2p_demo.c(341)<__TUYA_APP_p2p_event_cb> Dbg: set clarity:1
[2024/8/7 9:27:08 179] tuya_ipc_p2p_demo.c(344)<__TUYA_APP_p2p_event_cb> Dbg: set clarity:1 OK
[2024/8/7 9:27:08 195] [08-07 09:27:05 TUYA D][app_agent.c:1540] fd:34, wk_stat = 2, type = 32
[2024/8/7 9:27:08 195] [08-07 09:27:05 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:08 211] [08-07 09:27:05 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:08 212] 50086 (null) INFO:6241316: process signaling disconnect
[2024/8/7 9:27:08 212] 50102 (null) INFO:6241316: rtc 00010001 closed by remote or local, local:0 remote:1
[2024/8/7 9:27:08 227] 50102 (null) INFO:6241316: rtc session 00010001 state change: STREAM -> FAILED
[2024/8/7 9:27:08 259] [08-07 09:27:05 TUYA D][mqc_app.c:879] Send MQTT Msg.P:302 N:60419 Q:0 Data:{"header":{"from":"6c22957eb0f040d84du6po","to":"ay1700201779576ClfQH","sub_dev_id":"","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","moto_id":"","type":"disconnect","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","path":"mqtt"},"msg":{"close_reason_local":0,"close_reason":5}}
[2024/8/7 9:27:08 275] [08-07 09:27:05 TUYA D][app_agent.c:600] send length:336, id:34, sequence_out:34369
[2024/8/7 9:27:08 308] [08-07 09:27:05 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"header":{"from":"ay1700201779576ClfQH","moto_id":"","path":"mqtt","sessionid":"6c22957eb0f040d84du6po1722994023Wb8GZizT","sub_dev_id":"","to":"6c22957eb0f040d84du6po","trace_id":"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944","type":"disconnect"},"msg":{"close_reason":4,"close_reason_local":0}},"protocol":302,"t":1722994024}
[2024/8/7 9:27:08 308] [08-07 09:27:05 TUYA D][tuya_ipc_mqtt_subscribe.c:215] recv mq: protocol 302
[2024/8/7 9:27:08 324] 50111 (null) INFO:6241316: process signaling disconnect
[2024/8/7 9:27:08 324] [2024-08-07 09:27:05] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:08 420] [08-07 09:27:05 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"type\":\"connection\",\"connection_type\":\"kcp\",\"session_id\":\"6c22957eb0f040d84du6po1722994023Wb8GZizT\",\"trace_id\":\"271fa420545c11ef8ea76ac23181c9d2_6c22957eb0f040d84du6po_1722994023944\",\"moto_id\":\"\",\"session_handle\":65537,\"active_handle\":1,\"role\":\"callee\",\"local_id\":\"6c22957eb0f040d84du6po\",\"remote_id\":\"ay1700201779576ClfQH\",\"dev_id\":\"\",\"local_p2p_skill\":99,\"remote_p2p_skill\":611,\"preconnect\":true,\"sdk_version\":\"tuya_p2p_sdk_v3.4.107\",\"open\":{\"init_time\":49120,\"ice_token\":[{\"urls\":\"stun:47.103.29.37:3478\"},{\"credential\":\"SwgeZ583hKIEhigDSPL4nTpLqhM=\",\"ttl\":36000,\"urls\":\"turn:47.103.32.85:3478\",\"username\":\"1723030024:6c22957eb0f040d84du6po\"}],\"tcp_token\":{\"credential\":\"SwgeZ583hKIEhigDSPL4nTpLqhM=\",\"domain\":\"wework-2-cn.stream.iot-11.com\",\"sessionId\":\"6c22957eb0f040d84du6po1722994023YQfh7JyI\",\"urls\":[\"tcp4:1.117.192.37:1443\"],\"username
[2024/8/7 9:27:08 435] [08-07 09:27:05 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c22957eb0f040d84du6po&et=1&t=1722994025&v=1.0&sign=dba81cff2ed07947baa2ea7bd8a92819
[2024/8/7 9:27:08 436] [08-07 09:27:05 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:08 451] [08-07 09:27:05 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:08 452] 
[2024/8/7 9:27:08 452] [08-07 09:27:05 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:08 467] [08-07 09:27:05 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:08 467] [08-07 09:27:05 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:08 483] [08-07 09:27:05 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:08 483] [08-07 09:27:05 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:08 499] [08-07 09:27:05 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:08 499] [08-07 09:27:05 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:08 499] [08-07 09:27:05 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:08 515] [08-07 09:27:05 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:08 515] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:27:08 515] Mode(Product):0
[2024/8/7 9:27:08 515] BpuMode:[Online]
[2024/8/7 9:27:08 531] VpssMode:[Online]
[2024/8/7 9:27:08 531] [0.LimitUp_info]:
[2024/8/7 9:27:08 531] LimitUp:[Disable]
[2024/8/7 9:27:08 531] [2680*0]->[3840*0])
[2024/8/7 9:27:08 531] chn	TotalSize	ActiveSize
[2024/8/7 9:27:08 531] 0	5040*2246	2680*2160
[2024/8/7 9:27:08 532] 0	5040*2246	3840*2160
[2024/8/7 9:27:08 547] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:27:08 547] [1.VICU_info]:
[2024/8/7 9:27:08 547] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:27:08 547] 0	25.0	1058	0	0	183	linear	8ddb00
[2024/8/7 9:27:08 547] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:27:08 547] en	op_type	m_chn	now
[2024/8/7 9:27:08 547] 0	1	1	1
[2024/8/7 9:27:08 563] [2.VI_info]:
[2024/8/7 9:27:08 563] chn	TotalSize	ActiveSize
[2024/8/7 9:27:08 563] 0	5040*2246	3848*2166
[2024/8/7 9:27:08 563] 1	   0*   0	   0*   0
[2024/8/7 9:27:08 563] [3.MIPI_info]:
[2024/8/7 9:27:08 563] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:27:08 579] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:27:08 579] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:27:08 579] [4.Cut_info]:
[2024/8/7 9:27:08 579] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:27:08 579] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:27:08 595] vicu	0	1	1	2	3840	2160	  
[2024/8/7 9:27:08 595] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:27:08 595] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:27:08 595] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:27:08 595] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:27:08 595] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:27:08 611] [5.IB(isp buffer info)]:
[2024/8/7 9:27:08 612] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:27:08 612] PoolId  Count  Size
[2024/8/7 9:27:08 612] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:08 627] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:08 627] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:08 643] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:08 643] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:08 659] [08-07 09:27:05 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:08 675] [08-07 09:27:05 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:08 675] [08-07 09:27:05 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722994025,"success":true}
[2024/8/7 9:27:08 691] [08-07 09:27:05 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:08 691] [08-07 09:27:05 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:08 707] 50504 (null) ERROR:6324040: tcp socket 39 recv EOF or Error: -4095((null))
[2024/8/7 9:27:08 707] 50504 (null) ERROR:6324040: connect [-1] / response [-1] / complete [-1] / keepalive [0]
[2024/8/7 9:27:08 723] 50504 (null) INFO:6324040: tcp 39 state change: STREAM -> FAILED
[2024/8/7 9:27:08 723] 50505 (null) INFO:6241316: rtc session 00010001 on tcp status: -1, cost: 1385
[2024/8/7 9:27:08 739] 50505 (null) INFO:6241316: rtc 00010001 transport update 4: 2 -1 -1, 100 0 0
[2024/8/7 9:27:08 739] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:27:08 739] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:27:08 755] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:27:08 755] 0       0         0          0          4       
[2024/8/7 9:27:08 755] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:27:08 771]      --265--            --264--                                               
[2024/8/7 9:27:08 771] Count      Line     Count      Line     
[2024/8/7 9:27:08 771] 831        480      2002       560      
[2024/8/7 9:27:08 787] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:27:08 787] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:27:08 803] 0   3840   2160    H265  0      0        0           494       983036     4        	
[2024/8/7 9:27:08 803] 1   640    360     H265  0      0        0           330       43193      7        	
[2024/8/7 9:27:08 819] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:27:08 819] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:27:08 835] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:27:08 851] 0   Y      494      0       0       15       0        494      494      707       65977         59145    143327   64875    12      
[2024/8/7 9:27:08 851] 1   Y      330      0       6       1        0        330      330      707       2273          1928     34379    2781     9       
[2024/8/7 9:27:08 867] 3   N      0        0       0       1        0        0        0        709       0             0        0        0        0       
[2024/8/7 9:27:08 867] 51042 (null) ERROR:6241316: rtc 00010001 channel 0 over
[2024/8/7 9:27:08 883] 51042 (null) ERROR:6241316: rtc 00010001 channel 0 send rc = -13
[2024/8/7 9:27:08 883] [2024-08-07 09:27:05] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:27:08 899] [2024-08-07 09:27:05] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:27:08 899] watcher remove 39, nfds 2
[2024/8/7 9:27:08 915] [2024-08-07 09:27:05] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:08 915] start change stream H265 src :2 - > 2
[2024/8/7 9:27:08 915] same stream src, return
[2024/8/7 9:27:08 915] [2024-08-07 09:27:05] tuya_ipc_p2p_demo.c(431) <__TUYA_APP_p2p_event_cb>: g_sub_video_start=1
[2024/8/7 9:27:08 932] [08-07 09:27:06 TUYA E][tuya_ipc_p2p.c:2596] p2p Write failed ret = -13
[2024/8/7 9:27:08 947] [2024-08-07 09:27:05] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 6893[08-07 09:27:06 TUYA E][tuya_ipc_p2p.c:3471] session[65537] was close by client ret[-13]
[2024/8/7 9:27:08 947] [08-07 09:27:06 TUYA E][tuya_ipc_p2p.c:3599] session[65537] read cmd failed [-1]
[2024/8/7 9:27:08 963] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:3351] close session[65537]
[2024/8/7 9:27:08 963] 51163 (null) INFO:6241316: rtc session 00010001 close
[2024/8/7 9:27:08 963] 51164 (null) INFO:6241316: rtc session 00010001 close over
[2024/8/7 9:27:08 979] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:2174] session[65537] cmd[0] status[5]
[2024/8/7 9:27:08 979] [08-07 09:27:06 TUYA E][tuya_ipc_p2p.c:2529] speaker not start
[2024/8/7 9:27:08 995] 51165 (null) INFO:6241316: process control close
[2024/8/7 9:27:08 995] 51166 (null) INFO:6241316: rtc session 00010001 failed ready to close
[2024/8/7 9:27:09 011] [08-07 09:27:06 TUYA E][tuya_ipc_p2p.c:3432] session[65537] is try to releasing
[2024/8/7 9:27:09 011] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:4813] session[65537] __p2p_wait_concurr_idle start
[2024/8/7 9:27:09 011] 51181 (null) INFO:6241316: destroy rtc session 00010001
[2024/8/7 9:27:09 027] [08-07 09:27:06 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:27:09 027] [08-07 09:27:06 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:27:09 027] watcher remove 37, nfds 1
[2024/8/7 9:27:09 027] watcher remove 38, nfds 0
[2024/8/7 9:27:09 043] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:4830] session[65537] concurr idle[2][2]
[2024/8/7 9:27:09 043] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:4836] session[65537] __p2p_wait_concurr_idle end
[2024/8/7 9:27:09 060] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:3811] session[65537] playback_send_video start release
[2024/8/7 9:27:09 060] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:3380] release source [65537]
[2024/8/7 9:27:09 075] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:3420] release va session[65537]
[2024/8/7 9:27:09 075] [08-07 09:27:06 TUYA D][tuya_ipc_p2p.c:3813] session[0] closed
[2024/8/7 9:27:09 091] [2024-08-07 09:27:05] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:27:09 091] [2024-08-07 09:27:05] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:27:09 108] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=12.000 ms
[2024/8/7 9:27:09 108] [2024-08-07 09:27:06] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:27:09 124] [2024-08-07 09:27:06] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 6965[2024-08-07 09:27:07] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time52551
[2024/8/7 9:27:09 140] [08-07 09:27:08 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 9:27:09 140] [08-07 09:27:08 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:09 140] [08-07 09:27:08 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:09 156] [08-07 09:27:08 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:09 156] [08-07 09:27:08 TUYA D][tuya_svc_schema_upgrade.c:223] schema[flvlrc] not updated since activated
[2024/8/7 9:27:09 172] [2024-08-07 09:27:08] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:09 172] [08-07 09:27:09 TUYA E][app_agent.c:1479] close socket,errno:-100 errno:0
[2024/8/7 9:27:09 188] [08-07 09:27:09 TUYA D][app_agent.c:213] set socket fault 34
[2024/8/7 9:27:09 188] [08-07 09:27:09 TUYA D][app_agent.c:274] i:0,time:1722994029,c_time:1722994025,fault:1
[2024/8/7 9:27:09 188] [08-07 09:27:09 TUYA D][app_agent.c:163] close socket 34
[2024/8/7 9:27:09 204] [08-07 09:27:09 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"devId":"6c22957eb0f040d84du6po","gwId":"6c22957eb0f040d84du6po"},"protocol":11,"s":1613827,"t":1722994029}
[2024/8/7 9:27:09 220] [08-07 09:27:09 TUYA D][mqtt_client.c:916] disconnect mqtt
[2024/8/7 9:27:09 220] [08-07 09:27:09 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:27:09 236] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:27:09 236] [08-07 09:27:09 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:27:09 252] [08-07 09:27:09 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:27:09 252] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:27:09 268] [08-07 09:27:09 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:27:09 268] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:09 284] [08-07 09:27:09 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:27:09 284] [08-07 09:27:09 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:27:09 300] [08-07 09:27:09 TUYA D][gw_mqc_cb.c:60] unactive
[2024/8/7 9:27:09 300] [08-07 09:27:09 TUYA E][mqtt_client.c:1652] mq_recv err:-30848 len:0
[2024/8/7 9:27:09 300] [08-07 09:27:09 TUYA D][tuya_devos_reset.c:418] unactive Reset
[2024/8/7 9:27:09 316] [08-07 09:27:09 TUYA D][tuya_devos_reset.c:261] gw reset called. tp:1 stat:1
[2024/8/7 9:27:09 316] __IPC_APP_Get_Net_Status_cb line(183) -------------------------- stat(0)==STAT_LOW_POWER 
[2024/8/7 9:27:09 332] [08-07 09:27:09 TUYA D][tuya_devos_reset.c:85] <__wf_reset> nc_tp:2, rst_tp:1, wifi_start_mode:0
[2024/8/7 9:27:09 332] [08-07 09:27:09 TUYA D][tuya_devos_reset.c:325] <__gw_reset> tuya_ble_clear_mesh
[2024/8/7 9:27:09 347] [08-07 09:27:09 TUYA D][tuya_ble_api.c:1050] start to clr appkey.
[2024/8/7 9:27:09 347] [08-07 09:27:09 TUYA D][simplekv.c:1348] delete key:ble_app_key isFuzzy:0
[2024/8/7 9:27:09 347] [08-07 09:27:09 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:27:09 363] [08-07 09:27:09 TUYA D][simplekv.c:1386] delete key find 4
[2024/8/7 9:27:09 363] [08-07 09:27:09 TUYA D][simplekv.c:1424] Delete key:ble_app_key 4 success
[2024/8/7 9:27:09 364] [08-07 09:27:09 TUYA D][simplekv.c:203] update crc 1905444107
[2024/8/7 9:27:09 379] [08-07 09:27:09 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:09 379] [08-07 09:27:09 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:27:09 395] [08-07 09:27:09 TUYA D][tuya_ble_api.c:1058] start to clr network_key.
[2024/8/7 9:27:09 395] [08-07 09:27:09 TUYA D][simplekv.c:1348] delete key:ble_network_key isFuzzy:0
[2024/8/7 9:27:09 395] [08-07 09:27:09 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:27:09 411] [08-07 09:27:09 TUYA D][simplekv.c:1386] delete key find 13
[2024/8/7 9:27:09 411] [08-07 09:27:09 TUYA D][simplekv.c:1424] Delete key:ble_network_key 13 success
[2024/8/7 9:27:09 427] [08-07 09:27:09 TUYA D][simplekv.c:203] update crc 205041813
[2024/8/7 9:27:09 428] [08-07 09:27:09 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:09 428] [08-07 09:27:09 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:27:09 443] [08-07 09:27:09 TUYA D][tuya_ble_api.c:1035] start to clr beaconkey.
[2024/8/7 9:27:09 443] [08-07 09:27:09 TUYA D][simplekv.c:1348] delete key:ble_beaconkey isFuzzy:0
[2024/8/7 9:27:09 443] [08-07 09:27:09 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:27:09 459] [08-07 09:27:09 TUYA D][simplekv.c:1386] delete key find 14
[2024/8/7 9:27:09 459] [08-07 09:27:09 TUYA D][simplekv.c:1424] Delete key:ble_beaconkey 14 success
[2024/8/7 9:27:09 475] [08-07 09:27:09 TUYA D][simplekv.c:203] update crc 1385254303
[2024/8/7 9:27:09 475] [08-07 09:27:09 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:09 475] [08-07 09:27:09 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:27:09 491] [08-07 09:27:09 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":1,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:27:09 507] [08-07 09:27:09 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:27:09 507] [08-07 09:27:09 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:27:09 507] [08-07 09:27:09 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:176
[2024/8/7 9:27:09 523] [08-07 09:27:09 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:27:09 523] [08-07 09:27:09 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:27:09 539] [08-07 09:27:09 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:27:09 539] [08-07 09:27:09 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:27:09 539] [08-07 09:27:09 TUYA D][simplekv.c:203] update crc 2845845183
[2024/8/7 9:27:09 555] [08-07 09:27:09 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:09 555] [08-07 09:27:09 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:09 555] [08-07 09:27:09 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:27:09 571] [08-07 09:27:09 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:27:09 571] [08-07 09:27:09 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[2024/8/7 9:27:09 587] [08-07 09:27:09 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[2024/8/7 9:27:09 587] [08-07 09:27:09 TUYA D][tuya_svc_timer_task.c:107] reset. write_disk:1
[2024/8/7 9:27:09 587] [08-07 09:27:09 TUYA D][tuya_svc_timer_task.c:310] max len:128
[2024/8/7 9:27:09 603] [08-07 09:27:09 TUYA D][tuya_svc_timer_task.c:378] offset:27
[2024/8/7 9:27:09 603] [08-07 09:27:09 TUYA D][tuya_svc_timer_task.c:397] save TIMER:{"lastFetchTime":0,"cnt":0}
[2024/8/7 9:27:09 619] [08-07 09:27:09 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:27:09 619] [08-07 09:27:09 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:09 619] [08-07 09:27:09 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:09 635] [08-07 09:27:09 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:09 635] [08-07 09:27:09 TUYA D][simplekv.c:374] write key:timer_arr And Value Len:32
[2024/8/7 9:27:09 651] [08-07 09:27:09 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 32
[2024/8/7 9:27:09 651] [08-07 09:27:09 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:27:09 651] [08-07 09:27:09 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:27:09 667] [08-07 09:27:09 TUYA D][simplekv.c:203] update crc 1459627961
[2024/8/7 9:27:09 667] [08-07 09:27:09 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:09 667] [08-07 09:27:09 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:09 683] [08-07 09:27:09 TUYA D][simplekv.c:1348] delete key:last_reset_info isFuzzy:0
[2024/8/7 9:27:09 683] [08-07 09:27:09 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:27:09 699] [08-07 09:27:09 TUYA D][simplekv.c:1395] key:last_reset_info not find
[2024/8/7 9:27:09 699] [08-07 09:27:09 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:27:09 699] [08-07 09:27:09 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:09 715] [08-07 09:27:09 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:27:09 715] [08-07 09:27:09 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:27:09 731] [08-07 09:27:09 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:27:09 731] [08-07 09:27:09 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 16
[2024/8/7 9:27:09 731] [08-07 09:27:09 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:27:09 747] [08-07 09:27:09 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:27:09 747] [08-07 09:27:09 TUYA D][simplekv.c:203] update crc 3818712776
[2024/8/7 9:27:09 763] [08-07 09:27:09 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:09 763] [08-07 09:27:09 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:09 763] [08-07 09:27:09 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:27:09 779] [08-07 09:27:09 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:27:09 779] [08-07 09:27:09 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:27:09 779] [08-07 09:27:09 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:27:09 795] [08-07 09:27:09 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:27:09 795] [08-07 09:27:09 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:27:09 811] [08-07 09:27:09 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:27:09 811] [08-07 09:27:09 TUYA D][simplekv.c:203] update crc 1886248086
[2024/8/7 9:27:09 811] [08-07 09:27:09 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:09 827] [08-07 09:27:09 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:09 827] [08-07 09:27:09 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:27:09 827] [08-07 09:27:09 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:27:09 843] [08-07 09:27:09 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:27:09 843] [08-07 09:27:09 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:27:09 859] [08-07 09:27:09 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:27:09 859] [08-07 09:27:09 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:27:09 859] [08-07 09:27:09 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:27:09 875] [08-07 09:27:09 TUYA D][simplekv.c:203] update crc 865162940
[2024/8/7 9:27:09 875] [08-07 09:27:09 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:09 891] [08-07 09:27:09 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:09 891] IPC_APP_Reset_System_CB line(143) -------------------------- 
[2024/8/7 9:27:09 891] [08-07 09:27:09 TUYA N][mqtt_client.c:1703] mqtt close
[2024/8/7 9:27:09 907] [08-07 09:27:09 TUYA N][mqtt_client.c:839] close mqtt -->>
[2024/8/7 9:27:09 908] [08-07 09:27:09 TUYA D][mqtt_client.c:851] shutdown fd enabled
[2024/8/7 9:27:09 908] [08-07 09:27:09 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:27:09 923] [08-07 09:27:09 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:09 924] [08-07 09:27:09 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:09 924] [08-07 09:27:09 TUYA N][mqtt_client.c:886] close mqtt <<--
[2024/8/7 9:27:09 939] [08-07 09:27:09 TUYA D][mqtt_client.c:1720] mqtt fail_cnt:1, sleeptime:6535 ms
[2024/8/7 9:27:09 939] rm: can't remove '/mnt/mtd/Config/localtime': Device or resource busy
[2024/8/7 9:27:09 939] rm: can't remove '/mnt/mtd/Config/resolv.conf': Device or resource busy
[2024/8/7 9:27:09 956] rm: can't remove '/mnt/mtd/Config': Directory not empty
[2024/8/7 9:27:09 972] [2024-08-07 09:27:09] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:09] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:27:09 972] set basic_indicator_onoff:0 
[2024/8/7 9:27:09 987] [2024-08-07 09:27:09] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:09 987] [2024-08-07 09:27:09] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:10 003] [08-07 09:27:10 TUYA D][tuya_ble_api.c:1426] cloud disconnected, start adv!
[2024/8/7 9:27:10 003] [08-07 09:27:10 TUYA I][bt_ext_porting.c:628] [TUYA-BTUART]start_adv
[2024/8/7 9:27:10 003] --- tracepoint bt_ext_porting.c,tuya_ext_bt_start_adv(629): start_adv ---
[2024/8/7 9:27:10 019] [08-07 09:27:10 TUYA D][tuya_ble_api.c:1376] nw stat change:2->0, rpt to app.
[2024/8/7 9:27:10 019] [08-07 09:27:10 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:27:10 035] [2024-08-07 09:27:09] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:09] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:27:10 051] [2024-08-07 09:27:09] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:09] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:27:10 083] [2024-08-07 09:27:09] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:09] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:27:10 099] [2024-08-07 09:27:09] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:09] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:27:10 115] [2024-08-07 09:27:09] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:09] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:27:10 131] [2024-08-07 09:27:09] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:09] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:27:10 147] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(150): cmd=[killall wpa_supplicant udhcpc;ifconfig eth2 down;ifconfig eth0 down;]
[2024/8/7 9:27:10 147] curr event:13 
[2024/8/7 9:27:10 163] IPC_APP_Notify_LED_Sound_Status_CB line(583) -------------------------- IPC_RESET_SUCCESS(13)
[2024/8/7 9:27:10 163] [2024-08-07 09:27:09] tuya_ipc_system_control_demo.c(585) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(RESET, 0, 1, 0, 1))
[2024/8/7 9:27:10 179] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(155):  ---
[2024/8/7 9:27:10 179] [2024-08-07 09:27:09] xm_main.c(2440) <XMSDK_SystemRebootTY>: XMSDK_MotorGetPostion(3110,0) suc
[2024/8/7 9:27:10 195] [2024-08-07 09:27:09] xm_main.c(2064) <XM_SaveLocalPtzPosition>: Save PTZ xPosition 3110 failed
[2024/8/7 9:27:10 211] [2024-08-07 09:27:09] xm_main.c(2445) <XMSDK_SystemRebootTY>: XM_SaveLocalPtzPosition(3110,0) failed,ret=[-1]
[2024/8/7 9:27:10 211] XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:27:10 227] [2024-08-07 09:27:09] xm_main.c(2454) <XMSDK_SystemRebootTY>: XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:27:10 227] [2024-08-07 09:27:09] ==> XMSDK_SystemReboot(198)[INFO]: Sys XMSDK_SystemReboot Reboot
[2024/8/7 9:27:10 243] [2024-08-07 09:27:09] ==> XMSDK_SystemReboot(199)[INFO]: Sys Will Reboot
[2024/8/7 9:27:10 259] [2024-08-07 09:27:10] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/Reset_english.pcm]
[2024/8/7 9:27:10 259] [2024-08-07 09:27:10] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:27:10 260] [2024-08-07 09:27:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:27:10 275] 
[2024/8/7 9:27:10 291] [2024-08-07 09:27:10] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:10] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:27:10 291] set basic_indicator_onoff:0 
[2024/8/7 9:27:10 291] [2024-08-07 09:27:10] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:10 307] [2024-08-07 09:27:10] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:10 307] while(lib_ble_start) before
[2024/8/7 9:27:10 307] [08-07 09:27:10 TUYA E][minissdpc.c:517] sendto
[2024/8/7 9:27:10 323] GAP procedure initiated: terminate connection; conn_handle=1 hci_reason=19
[2024/8/7 9:27:10 323] ble_slave_gap_event->type=14
[2024/8/7 9:27:10 323] subscribe event; conn_handle=1 attr_handle=23 reason=2 prevn=1 curn=0 previ=0 curi=0
[2024/8/7 9:27:10 339] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:27:10 339] ble_slave_gap_event->type=1
[2024/8/7 9:27:10 339] disconnect; reason=534 
[2024/8/7 9:27:10 355] [2024-08-07 09:27:11] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time56569
[2024/8/7 9:27:10 355] [2024-08-07 09:27:11] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:10 371] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:2
[2024/8/7 9:27:10 387] g_AudioTipsList.size() enable: 0[2024-08-07 09:27:11] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:27:11] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [MotionDetect] pNumber[SirenSwitch]!
[2024/8/7 9:27:10 387] [08-07 09:27:12 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:27:10 403] [2024-08-07 09:27:11] xm_musicPlayer.cpp(177) <PlayAudioTips>: match reset audio
[2024/8/7 9:27:10 403] [08-07 09:27:12 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 9:27:10 467] [08-07 09:27:13 TUYA D][tuya_upnp_module_mg.c:1432] upnpDiscover failed
[2024/8/7 9:27:11 300] [atbm_log]:atbm_ioctl_ble_stop
[2024/8/7 9:27:11 316] [atbm_log]:ioctl_release(c1e1ba00)(c1e1a240)
[2024/8/7 9:27:12 323] <====== ble_gap_terminate(ble_conn_handle,19);
[2024/8/7 9:27:12 323] <====== ble_smart_cfg_task end step 0
[2024/8/7 9:27:12 323] exit ble process
[2024/8/7 9:27:12 339] ble_hs_hci_cmd_reset
[2024/8/7 9:27:12 339] cli_free before
[2024/8/7 9:27:12 339] nimble_port_atbmos_free before
[2024/8/7 9:27:12 339] nimble_port_release before
[2024/8/7 9:27:12 339] ble_gap_free before
[2024/8/7 9:27:12 339] ble_hs_hci_free before
[2024/8/7 9:27:12 339] ble_hs_free before
[2024/8/7 9:27:12 339] ble_hs_free after
[2024/8/7 9:27:12 355] nimble_release after
[2024/8/7 9:27:12 356] ble_smart_cfg_exit before
[2024/8/7 9:27:12 356] ble_smart_cfg_exit after
[2024/8/7 9:27:12 356] atbm_stopThread after
[2024/8/7 9:27:12 356] [08-07 09:27:14 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722994034 28800
[2024/8/7 9:27:12 371] [08-07 09:27:14 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722994034 28800
[2024/8/7 9:27:13 155] xmsfc_shutdown 2 2 
[2024/8/7 9:27:13 155] Restarting system.
[2024/8/7 9:27:13 203] 
[2024/8/7 9:27:13 203] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 9:27:13 204] CPU: XM550V200WX2
[2024/8/7 9:27:13 204] DRAM:  128 MiB
[2024/8/7 9:27:13 331] MMC:   arasan: 0
[2024/8/7 9:27:13 379] In:    serial
[2024/8/7 9:27:13 379] Out:   serial
[2024/8/7 9:27:13 379] Err:   serial
[2024/8/7 9:27:13 603] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 9:27:13 603] Press Ctrl+C to stop autoboot
[2024/8/7 9:27:14 019] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 9:27:14 019] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 9:27:14 019]    Image Name:   Linux-3.10.103+
[2024/8/7 9:27:14 019]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 9:27:14 035]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 9:27:14 035]    Load Address: 80008000
[2024/8/7 9:27:14 035]    Entry Point:  80008000
[2024/8/7 9:27:14 035]    XIP Kernel Image ... OK
[2024/8/7 9:27:14 035] Starting kernel ...
[2024/8/7 9:27:14 915] Uncompressing Linux... done, booting the kernel.
[2024/8/7 9:27:15 059] Booting Linux on physical CPU 0x0
[2024/8/7 9:27:15 059] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 9:27:15 075] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 9:27:15 075] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 9:27:15 075] Machine: xm530v200
[2024/8/7 9:27:15 091] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 9:27:15 091] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 9:27:15 091] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 9:27:15 107] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 9:27:15 123] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 9:27:15 123] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 9:27:15 123] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 9:27:15 123] Memory: 52MB = 52MB total
[2024/8/7 9:27:15 139] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 9:27:15 139] Virtual kernel memory layout:
[2024/8/7 9:27:15 139]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 9:27:15 139]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 9:27:15 155]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 9:27:15 155]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 9:27:15 155]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 9:27:15 171]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 9:27:15 171]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 9:27:15 171]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 9:27:15 171]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 9:27:15 187] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 9:27:15 187] Hierarchical RCU implementation.
[2024/8/7 9:27:15 187] NR_IRQS:128
[2024/8/7 9:27:15 187] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 9:27:15 203] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 9:27:15 203] pid_max: default: 32768 minimum: 301
[2024/8/7 9:27:15 203] Mount-cache hash table entries: 512
[2024/8/7 9:27:15 203] CPU: Testing write buffer coherency: ok
[2024/8/7 9:27:15 219] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 9:27:15 219] L310 cache controller enabled
[2024/8/7 9:27:15 219] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 9:27:15 219] CPU1: Booted secondary processor
[2024/8/7 9:27:15 219] Brought up 2 CPUs
[2024/8/7 9:27:15 235] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 9:27:15 235] CPU: All CPU(s) started in SVC mode.
[2024/8/7 9:27:15 235] NET: Registered protocol family 16
[2024/8/7 9:27:15 251] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 9:27:15 251] Serial: AMBA PL011 UART driver
[2024/8/7 9:27:15 251] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 9:27:15 251] console [ttyAMA0] enabled
[2024/8/7 9:27:15 267] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 9:27:15 267] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 9:27:15 283] bio: create slab <bio-0> at 0
[2024/8/7 9:27:15 299] usbcore: registered new interface driver usbfs
[2024/8/7 9:27:15 299] usbcore: registered new interface driver hub
[2024/8/7 9:27:15 299] usbcore: registered new device driver usb
[2024/8/7 9:27:15 315] Switching to clocksource arm_global_timer
[2024/8/7 9:27:15 315] NET: Registered protocol family 2
[2024/8/7 9:27:15 315] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:27:15 331] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:27:15 331] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 9:27:15 331] TCP: reno registered
[2024/8/7 9:27:15 331] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:27:15 347] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:27:15 347] NET: Registered protocol family 1
[2024/8/7 9:27:15 347] RPC: Registered named UNIX socket transport module.
[2024/8/7 9:27:15 347] RPC: Registered udp transport module.
[2024/8/7 9:27:15 363] RPC: Registered tcp transport module.
[2024/8/7 9:27:15 363] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 9:27:15 379] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 9:27:15 395] NFS: Registering the id_resolver key type
[2024/8/7 9:27:15 396] Key type id_resolver registered
[2024/8/7 9:27:15 396] Key type id_legacy registered
[2024/8/7 9:27:15 396] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 9:27:15 396] fuse init (API version 7.22)
[2024/8/7 9:27:15 411] msgmni has been set to 95
[2024/8/7 9:27:15 411] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 9:27:15 411] io scheduler noop registered
[2024/8/7 9:27:15 427] io scheduler deadline registered (default)
[2024/8/7 9:27:15 427] io scheduler cfq registered
[2024/8/7 9:27:15 427] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 9:27:15 443] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 9:27:15 443] uart-pl011 uart:0: no DMA platform data
[2024/8/7 9:27:15 443] uart-pl011 uart:1: no DMA platform data
[2024/8/7 9:27:15 443] uart-pl011 uart:2: no DMA platform data
[2024/8/7 9:27:15 459] brd: module loaded
[2024/8/7 9:27:15 475] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 9:27:15 475] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:27:15 491] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 9:27:15 491] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 9:27:15 491] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 9:27:15 491] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 9:27:15 507] 0x000000300000-0x000000730000 : "user"
[2024/8/7 9:27:15 507] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 9:27:15 507] PPP generic driver version 2.4.2
[2024/8/7 9:27:15 507] NET: Registered protocol family 24
[2024/8/7 9:27:15 523] usbcore: registered new interface driver asix
[2024/8/7 9:27:15 523] usbcore: registered new interface driver cdc_ether
[2024/8/7 9:27:15 523] usbcore: registered new interface driver rndis_host
[2024/8/7 9:27:15 540] XMMMAC driver:
[2024/8/7 9:27:15 540] 	platform registration... 
[2024/8/7 9:27:15 540] 	done!
[2024/8/7 9:27:15 540] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 9:27:15 540] 	IO base addr: 0xfe010000)
[2024/8/7 9:27:15 555] libphy: XMMMAC MII Bus: probed
[2024/8/7 9:27:15 555] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 9:27:15 555] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 9:27:15 556] usbcore: registered new interface driver cdc_acm
[2024/8/7 9:27:15 571] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 9:27:15 571] usbcore: registered new interface driver usbserial
[2024/8/7 9:27:15 571] usbcore: registered new interface driver option
[2024/8/7 9:27:15 587] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 9:27:15 587] usbcore: registered new interface driver qcserial
[2024/8/7 9:27:15 587] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 9:27:15 603] TCP: cubic registered
[2024/8/7 9:27:15 604] NET: Registered protocol family 17
[2024/8/7 9:27:15 604] Key type dns_resolver registered
[2024/8/7 9:27:15 604] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 9:27:15 619] registered taskstats version 1
[2024/8/7 9:27:15 619] ÿVFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 9:27:15 635] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 9:27:15 971] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 9:27:16 531] arasan_set_clock:
[2024/8/7 9:27:16 547] 	new freq 400000
[2024/8/7 9:27:16 548] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 9:27:16 563] arasan_set_clock:
[2024/8/7 9:27:16 611] 	new freq 300000arasan_set_clock:
[2024/8/7 9:27:16 627] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 9:27:16 643] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 9:27:16 643] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 9:27:16 643] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 9:27:16 643] [reg] = 0x20000078,[val]= 0xc103c0ff
[2024/8/7 9:27:16 643] [regarasan_set_clock:
[2024/8/7 9:27:16 659] 	new freq 195312] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 9:27:16 659] [reg] = 0x20000000,[val]= 0x00000000
[2024/8/7 9:27:16 659] [reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 9:27:16 659] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 9:27:16 675] [regi2c: module license 'Proprietary' taints kernel.
[2024/8/7 9:27:16 675] ] = 0x200505f0,[Disabling lock debugging due to kernel taint
[2024/8/7 9:27:16 675] val]= 0x00000001
[2024/8/7 9:27:16 691] i2c init is ok!
[2024/8/7 9:27:16 691] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 9:27:16 819] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 9:27:16 883] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 9:27:16 915] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 9:27:16 915] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 9:27:16 947] acodec init is ok!
[2024/8/7 9:27:16 947] i2s clk:2048000Hz
[2024/8/7 9:27:17 107] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 9:27:17 107] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 9:27:17 107] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 9:27:17 123] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 9:27:17 123] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 9:27:17 123] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 9:27:17 123] usb usb1: Product: DWC OTG Controller
[2024/8/7 9:27:17 139] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 9:27:17 139] usb usb1: SerialNumber: dwc2.0
[2024/8/7 9:27:17 139] hub 1-0:1.0: USB hub found
[2024/8/7 9:27:17 155] hub 1-0:1.0: 1 port detected
[2024/8/7 9:27:17 187] xm_wdt init is ok
[2024/8/7 9:27:17 203] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 9:27:17 507] nn_kernel: NN: request mem  fail
[2024/8/7 9:27:17 507] nn_kernel: addr iomap fail
[2024/8/7 9:27:17 555] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 9:27:17 827] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 9:27:18 018] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:27:18 034] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:27:18 034] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:27:18 035] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:27:18 131] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtusbwifi_init.
[2024/8/7 9:27:18 131] d/user.sh: not found
[2024/8/7 9:27:18 147] PDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 9:27:18 163] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 9:27:18 195] exfatfsck 1.3.0
[2024/8/7 9:27:18 195] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:27:18 211] exfatfsck 1.3.0
[2024/8/7 9:27:18 211] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:27:18 227] usb 1-1: USB disconnect, device number 3
[2024/8/7 9:27:20 147] ouput high and delay 2000ms
[2024/8/7 9:27:20 242] Auto login as root ...
[2024/8/7 9:27:20 274] (none) login: not found /dev/mmcxxx  
[2024/8/7 9:27:20 290] Tcp server success, Wait connet ...
[2024/8/7 9:27:20 290] Get xmauto Fialed ,xmauto = 1
[2024/8/7 9:27:20 306] auto start to app 
[2024/8/7 9:27:20 322] macGuarder: Get telnetctrl Fialed, telnetctrl=0
[2024/8/7 9:27:20 338] macGuarder: Close telnetd Forever 
[2024/8/7 9:27:20 579] usb 1-1: new high-speed USB device number 4 using dwc2
[2024/8/7 9:27:20 786] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:27:20 786] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:27:20 786] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:27:20 802] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:27:22 178] [atbm_log]:atbm_usb_module_init 0
[2024/8/7 9:27:22 195] [atbm_log]:platform_init(253)
[2024/8/7 9:27:22 195] [atbm_log]:SVN_VER=33341,DPLL_CLOCK=1,BUILD_TIME=[2024-04-03_14:40:53]
[2024/8/7 9:27:22 210] [atbm_log]:Probe called -1 v1
[2024/8/7 9:27:22 210] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[2024/8/7 9:27:22 210] [atbm_log]:CONFIG_TX_NO_CONFIRM
[2024/8/7 9:27:22 210] wiphy_new_nm support CONFIG_WIRELESS_EXT 
[2024/8/7 9:27:22 227] [atbm_log]:Allocated hw_priv @ c27c5960
[2024/8/7 9:27:22 227] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[2024/8/7 9:27:22 242] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c27c5960)
[2024/8/7 9:27:22 243] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c27c5960)
[2024/8/7 9:27:22 258] [atbm_log]:not support ldpc & ht40!
[2024/8/7 9:27:22 258] [atbm_log]:atbm_get_chiptype, chipver=0x5a, g_wifi_chip_type[14]
[2024/8/7 9:27:22 258] [atbm_log]:atbm_before_load_firmware++
[2024/8/7 9:27:22 274] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseExVb(526)[ERROR]: Ge[atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[2024/8/7 9:27:22 274] t Vb object erro[atbm_log]:===================~_~====================
[2024/8/7 9:27:22 274] r!
[2024/8/7 9:27:22 290] [1970-[atbm_log]:atbm_start_load_firmware++
[2024/8/7 9:27:22 290] 01-01 00:00:07] fwhdr->flags 34353678 sram_addr 9022000
[2024/8/7 9:27:22 290] <xm_system.c> ==[atbm_log]:
[2024/8/7 9:27:22 291] ======>>> load WIFI BLE COMB firmware <<<======
[2024/8/7 9:27:22 306] > XMSDK_ParseJso[atbm_log]:START DOWNLOAD ICCM=========
[2024/8/7 9:27:22 306] n(48)[ERROR]: Pa[atbm_log]:atbm_load_firmware_generic: addr 60000: len 20000
[2024/8/7 9:27:22 306] rse Vb Failed!
[2024/8/7 9:27:22 322] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(452)[ERROR]: Get Isp object u32Flag error set value 1!
[2024/8/7 9:27:22 338] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(464)[ERROR]: Get Isp object u32Others error set value 0!
[2024/8/7 9:27:22 338] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(476)[ERROR]: Get Isp object CmosPort error set value 0!
[2024/8/7 9:27:22 354] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(488)[ERROR]: Get Isp object splice_mode error set value 0!
[2024/8/7 9:27:22 354] [1970-01-01 00:00:06] MainApp.c(1802) <main>: build @Jul 31 2024 13:28:12
[2024/8/7 9:27:22 370] [1970-01-01 00:00:06] MainApp.c(1710) <SetLogLevel>: set Sofia log level 2 suceess
[2024/8/7 9:27:22 370] [1970-01-01 00:00:06] ==> XMSDK_SetLogLevel(226)[NOTICE]: set xmsdk log 4
[2024/8/7 9:27:22 386] 
[2024/8/7 9:27:22 387] [1970-01-01 00:00:07] xm_log.c(100) <XM_RegisterLogAndInit>: Register Log level 2
[2024/8/7 9:27:22 402] [1970-01-01 00:00:07] xm_hwinfo.c(162) <XM_HwinfoInit>: Sync hwinfo to Hwfile success!
[2024/8/7 9:27:22 402] Get Hw info: AppId [fvijo8jvloagv1gm], license [uuidcaab27b0a838d239], mac[j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:27:22 418] [1970-01-01 00:00:07] utils.c(974) <ReadJsonConfig>: Have not find pClass [DeviceGpio] pNumber [NetStatusLedGpio]
[2024/8/7 9:27:22 418] [1970-01-01 00:00:07] xm_device.c(226) <ParseDeviceJsonFile>: Get g_NetStatusLed [0] failed
[2024/8/7 9:27:22 434] **********************************************************************
[2024/8/7 9:27:22 434] |                      SYSTEM INFO                                       
[2024/8/7 9:27:22 434] |       product type:		RC50X80
[2024/8/7 9:27:22 450] |           DSP chip:		XM550V200
[2024/8/7 9:27:22 450] |          wifi type:		ATBM6062U
[2024/8/7 9:27:22 450] |             HW mac:		90314ba51650
[2024/8/7 9:27:22 450] |        git version:		a590e8b3
[2024/8/7 9:27:22 450] |          make time:		20240731132812
[2024/8/7 9:27:22 466] **********************************************************************
[2024/8/7 9:27:22 466] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(143)[INFO]: SensorSrcFrmRate = 25
[2024/8/7 9:27:22 482] [1970-01-01 00:00:07] xm_main.c(345) <AutoMaintenance_pro>: Set device auto mantenance time: -001_-1_-1 02:25:26 wenkday: Tuesday
[2024/8/7 9:27:22 482] [1970-01-01 00:00:07] xm_main.c(349) <AutoMaintenance_pro>: Get Last AutoMantence Date [] failed
[2024/8/7 9:27:22 498] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(137)[INFO]: SensorIFS = 0
[2024/8/7 9:27:22 514] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(156)[INFO]: V[atbm_log]:START DOWNLOAD DCCM=========
[2024/8/7 9:27:22 515] i CapW 2680, Cap[atbm_log]:atbm_load_firmware_generic: addr 800000: len d000
[2024/8/7 9:27:22 515] H 2160, CapX 0, CapY 0
[2024/8/7 9:27:22 530] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 0: size=[3840, 2160] @3
[2024/8/7 9:27:22 530] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 1: size=[640, 360] @3
[2024/8/7 9:27:22 546] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 2: size=[640, 224] @3
[2024/8/7 9:27:22 546] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(406)[INFO]: ISPRsltType
[2024/8/7 9:27:22 562] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(428)[INFO]: ISPRsltType 0
[2024/8/7 9:27:22 562] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(442)[INFO]: ISPRsltType
[2024/8/7 9:27:22 578] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_Parse4gMoudle(500)[WARN]: Get 4GModule object error!
[2024/8/7 9:27:22 578] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(80)[NOTICE]: ISP=> Svtd: PAL
[2024/8/7 9:27:22 594] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(81)[NOTICE]: ISP=>RsltType: 0
[2024/8/7 9:27:22 594] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(84)[NOTICE]: IRCut: gpio 19534 Swap 0
[2024/8/7 9:27:22 610] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(88)[NOTICE]: Infrared: gpio 0 swap 1
[2024/8/7 9:27:22 610] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(92)[NOTICE]: WLight: gpio 11 swap 0
[2024/8/7 9:27:22 627] [1970-01-01 00:00:07] ==> X[atbm_log]:START DOWNLOAD BLE SRAM=========
[2024/8/7 9:27:22 627] MSDK_ParseJson(9[atbm_log]:atbm_load_firmware_generic: addr 9022000: len 10000
[2024/8/7 9:27:22 627] 6)[NOTICE]: IRLight: gpio 10 swap 0
[2024/8/7 9:27:22 643] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(99)[NOTICE]: Vi: sensorIFS=0 sensorFPS=25, capW=2680,capH=2160,capX=0,capY=0
[2024/8/7 9:27:22 658] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(100)[NOTICE]: ViChn  ImageSize      vbBlk
[2024/8/7 9:27:22 658] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    0  [3840, 2160]    3
[2024/8/7 9:27:22 674] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    1  [ 640,  360]    2
[2024/8/7 9:27:22 674] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    2  [ 640,  224]    2
[2024/8/7 9:27:22 690] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(107)[NOTICE]: VencChn    MaxSize   PreReleaseVb
[2024/8/7 9:27:22 690] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    0   [3840, 2160]	 false
[2024/8/7 9:27:22 706] i2c_write timeout 0x2 ==> XMSDK_ParseJson(113)[NOTICE]:    1   [ 640,  360]	 false
[2024/8/7 9:27:22 706] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(116)[NOTICE]: 4GModule: gpio 0 Swap 0
[2024/8/7 9:27:22 722] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: AudioSwap: 0[atbm_log]:atbm_after_load_firmware++
[2024/8/7 9:27:22 722] [1970-0[atbm_log]:alloc urb work
[2024/8/7 9:27:22 738] 1-01 00:00:07] =[atbm_log]:usb:try to flush rx....
[2024/8/7 9:27:22 738] => XMJSON_ParseFactoryFile(656)[INFO]: AudioSwap=[0]
[2024/8/7 9:27:22 738] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: HighAdcValue: 0
[2024/8/7 9:27:22 754] [1970-01-01 00:00:07DEBUG: [libispapp]:Ji2c_write timeout 0x2
[2024/8/7 9:27:22 754] ul  5 2024 16:14:06 ,GENERAL
[2024/8/7 9:27:22 754] DEBUG: Vstd_init	[ PAL ]
[2024/8/7 9:27:22 754] DEBUG: RsltSns0	[ 8 ]
[2024/8/7 9:27:22 770] DEBUG: Dsp:		[0x0][ CHIPV200 ]
[2024/8/7 9:27:22 770] DEBUG: [libsns]:Jul  5 2024 16:13:32 ,GENERAL
[2024/8/7 9:27:22 835] [atbm_log]:flush rx[-110][0]
[2024/8/7 9:27:22 835] [atbm_log]:0x1610102c=0x4300a
[2024/8/7 9:27:22 835] [atbm_log]:0x1610102c=0x6300b
[2024/8/7 9:27:22 835] [atbm_log]:0x16101000=0x0
[2024/8/7 9:27:22 851] [atbm_log]:set_block_size=256
[2024/8/7 9:27:22 852] [atbm_log]:mdelay wait wsm_startup_done  !!
[2024/8/7 9:27:22 852] [atbm_log]:firmwareCap 31e9
[2024/8/7 9:27:22 852] [atbm_log]:firmwareCap2 1b8c
[2024/8/7 9:27:22 852] i2c_write timeout 0x2
[2024/8/7 9:27:22 867] [atbm_log]:wsm_caps.firmwareCap 1b8c31e9 16[atbm_log]:apollo wifi WSM init done.
[2024/8/7 9:27:22 867]    Input buffers: 32 x 1632 bytes
[2024/8/7 9:27:22 867]    Hardware: 7.21
[2024/8/7 9:27:22 883]    WSM firmware [=MODEM=DPLL24M+BLE+plat=4 ApSleep 2GHZ Jan 30 2024 10:58:03], ver: 19514, build: 6431, api: 1060, cap: 0x1B8C31E9 Config[31010]  expection 900c094, ep0 cmd addr 901b340 NumOfStations[0x10] NumOfInterfaces[3]
[2024/8/7 9:27:22 883] [atbm_log]:EFUSE(8)				[0]
[2024/8/7 9:27:22 883] [atbm_log]:EFUSE(I)					[0]
[2024/8/7 9:27:22 899] [atbm_log]:EFUSE(B)			[0]
[2024/8/7 9:27:22 899] i2c_write timeout 0x2
[2024/8/7 9:27:22 899] [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [0]
[2024/8/7 9:27:22 899] [atbm_log]:CAPABILITIES_NVR_IPC              [0]
[2024/8/7 9:27:22 915] [atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[2024/8/7 9:27:22 915] [atbm_log]:CAPABILITIES_WOW                  [0]
[2024/8/7 9:27:22 915] [atbm_log]:CAPABILITIES_NO_BACKOFF           [1]
[2024/8/7 9:27:22 915] [atbm_log]:CAPABILITIES_CFO                  [1]
[2024/8/7 9:27:22 931] [atbm_log]:CAPABILITIES_CHIP_FLAG            [1]
[2024/8/7 9:27:22 931] [atbm_log]:CAPABILITIES_TXCAL                [1]
[2024/8/7 9:27:22 931] DEBUG: SC[atbm_log]:CAPABILITIES_HIF_TRACE       		[0]
[2024/8/7 9:27:22 931] 831HAI! Chn:0
[2024/8/7 9:27:22 946]  tbm_log]:CAPABILITIES_FORCE_PM_ACTIVE      [0]
[2024/8/7 9:27:22 946] [m[atbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[2024/8/7 9:27:22 946] [atbm_log]:CAPABILITIES_ETF                  [1]
[2024/8/7 9:27:22 946] [atbm_log]:CAPABILITIES_BLE		  			[1]
[2024/8/7 9:27:22 963] [atbm_log]:CAPABILITIES_40M			  		[0]
[2024/8/7 9:27:22 963] [atbm_log]:CAPABILITIES_LDPC 		  		[0]
[2024/8/7 9:27:22 963] [atbm_log]:CAPABILITIES_NAV_ENABLE              [0]
[2024/8/7 9:27:22 963] [atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [0]
[2024/8/7 9:27:22 978] DEBUG: Is[atbm_log]:CAPABILITIES_USE_IPC              [1]
[2024/8/7 9:27:22 978] pNum[1]
[2024/8/7 9:27:22 978] atbm_log]:CAPABILITIES_OUTER_PA             [0]
[2024/8/7 9:27:22 978] 35mDEBUG: IspChn[atbm_log]:CAPABILITIES_WFA    [0]
[2024/8/7 9:27:22 994] :[ 0  tbm_log]:CAPABILITIES_EAP_GROUP_REKEY  [0]
[2024/8/7 9:27:22 994] [m]
[2024/8/7 9:27:22 994]  tbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[2024/8/7 9:27:22 994] [1;35mDEBUG: I2C[atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[2024/8/7 9:27:23 010] Chn:[ [atbm_log]:CAPABILITIES_RXCAL       [1]
[2024/8/7 9:27:23 010] 0 ]
[2024/8/7 9:27:23 010]  tbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[2024/8/7 9:27:23 010] [mDEBUG: [atbm_log]:CAPABILITIES_80211_TO_8023 [1]
[2024/8/7 9:27:23 026] limitedUp: no
[2024/8/7 9:27:23 026]  tbm_log]:CAPABILITIES_NEW_CHIPER  [1]
[2024/8/7 9:27:23 026] [mD[atbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [0]
[2024/8/7 9:27:23 026] EBUG: ----------[atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[2024/8/7 9:27:23 042] ---SC831Hai 4K 30fps ini[atbm_log]:LMAC NOT SUPPORT 40M !!!
[2024/8/7 9:27:23 042] t ok! (20240322)[atbm_log]:LMAC NOT SUPPORT LDPC !!!
[2024/8/7 9:27:23 042] -------------
[2024/8/7 9:27:23 042] DEBUG: camera_set_saved_status OK!
[2024/8/7 9:27:23 058] DEBUG: [lIspKo: clean cut!
[2024/8/7 9:27:23 058] ibautoscene]:Jul  5 2024 16:13:42 ,GENERAL
[2024/8/7 9:27:23 058] DEBUG: [libautoscene]:use libfvideo!
[2024/8/7 9:27:23 058] DEBUG: [libfvideo]:Jul  5 2024 15:41:09 
[2024/8/7 9:27:23 074] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:27:23 074] DEBUG: [libsdnc]:Aug 22 2023 13:55:14
[2024/8/7 9:27:23 074] DEBUG: LED: [IR] 
[2024/8/7 9:27:23 074] DEBUG: software LED
[2024/8/7 9:27:23 091] DEBUG: hardware pohtoR!
[2024/8/7 9:27:23 091] DEBUG: isp_sample over!
[2024/8/7 9:27:23 091] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:27:23 091] ] ==>IspKo: set cut 0x0 0xf00 0x1 0x871
[2024/8/7 9:27:23 107]  XMJSON_GetInt(570)[INFO]: LowAdcValue: 0
[2024/8/7 9:27:23 107] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: IRLightLevel: 0
[2024/8/7 9:27:23 108] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: InfraredSwap: 0
[2024/8/7 9:27:23 123] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: WhiteLightLevel: 0
[2024/8/7 9:27:23 123] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoHorizontalFlipGun: 0
[2024/8/7 9:27:23 139] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoVerticalFlipGun: 0
[2024/8/7 9:27:23 139] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: setMonocular: 1
[2024/8/7 9:27:23 155] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedX: 17
[2024/8/7 9:27:23 155] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedY: 17
[2024/8/7 9:27:23 171] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: soundValue: 50
[2024/8/7 9:27:23 171] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: lightChannel: 0
[2024/8/7 9:27:23 187] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: dayAndNightMode: 0
[2024/8/7 9:27:23 187] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: hardAndSoftLight: 1
[2024/8/7 9:27:23 203] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeX: 400
[2024/8/7 9:27:23 203] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeY: 200
[2024/8/7 9:27:23 203] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(587)[INFO]: RatioOfGear: 1:1
[2024/8/7 9:27:23 219] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(593)[INFO]: high 1: low 1
[2024/8/7 9:27:23 235] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(690)[INFO]: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:27:23 251] [1970-01-01 00:00:07] xm_main.c(462) <GetVideoResolution>: Video resolution: captrue width 2680 height 2160 resolution main: width 3840 height 216[atbm_log]:wsm_generic_confirm:status(2)
[2024/8/7 9:27:23 251] 0 extra:  width [atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[2024/8/7 9:27:23 267] 640 height 360 [2]: width 640 he[atbm_log]:apollo wifi : can't open /data/.mac.info
[2024/8/7 9:27:23 267] ight 224
[2024/8/7 9:27:23 267] atbm_log]:efuse data is [0x1,0x38,0x15,0x16,0x16,0x8,0x0,0x0,0x90:0x31:0x4b:0xa5:0x16:0x50]
[2024/8/7 9:27:23 283] 32m[1970-01-01 0[atbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[2024/8/7 9:27:23 283] 0:00:07] MainApp.c(1812) <main>:[atbm_log]:win txpower:0 version , date 
[2024/8/7 9:27:23 283] [atbm_log]:use default power
[2024/8/7 9:27:23 283] 20240724, time 182054, plus 0
[2024/8/7 9:27:23 299] [1970-01-01 00:00:07] ==> XMSDK_StartUp(174)[INFO]: XMSDK_StartUp enter, Jul 24 2024, 18:20:55
[2024/8/7 9:27:23 314] [1970-01-01 00:00:07] ==> IspConfigInit(158)[INFO]: maxHeight 2160 maxWidth 3840 u32RsltType 8
[2024/8/7 9:27:23 315] 
[2024/8/7 9:27:23 315] atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[2024/8/7 9:27:23 316] 2m[1970-01-01 00[atbm_log]:==read success==
[2024/8/7 9:27:23 316] :00:07] ==> XMSD[atbm_log]:set delta power
[2024/8/7 9:27:23 331] K_StartUp(203)[INFO]: g_stProductMgr.viMgr.capW =[2680] g_stProductMgr.viMgr.capH = [2160]
[2024/8/7 9:27:23 347] [1970-01-01 00:00:07] ==> XMSDK_StartUp(220)[INFO]: g_stProductMgr.vencMgr.v[atbm_log]:get chip id [0][0][0] 
[2024/8/7 9:27:23 347] encChn[0].maxHei[atbm_log]:current chiptype ATBM6062-U20-noLDPC 
[2024/8/7 9:27:23 347] ght =[2160] g_st[atbm_log]:default country code:00,support channel=14
[2024/8/7 9:27:23 363] ProductMgr.encMg[atbm_log]:Use an internal power amplifier!
[2024/8/7 9:27:23 363] r.vencChn[0].maxWidth = [3840]
[2024/8/7 9:27:23 363] [atbm_log]:enable sg
[2024/8/7 9:27:23 363] [1970-01[atbm_log]:[eth2] has been disabled
[2024/8/7 9:27:23 379] -01 00:00:07] ==> XMSDK_StartUp(286)[INFO]: ispCfg.u32Others 0x0
[2024/8/7 9:27:23 379] [1970-01-01 00:00:07] ==> XMSDK_StartUp(288)[INFO]: ispCfg.u32FunExt 0x0 u32Infrared 0x80000000 u32sns[atbm_log]:enable sg
[2024/8/7 9:27:23 395] RsltType 0x0 u32[atbm_log]:[p2p0] has been disabled
[2024/8/7 9:27:23 395] RsltType 0x8 au32IrCut 0x80004c4e  au32SoftLed[0]: 0x800b0a11 u32Flag: 0x1 SensorRstIO: 0x800000a4 u32ComsPort: 0x0
[2024/8/7 9:27:23 411] [1970-01-01 00:00:08] ==> SampleCreate(1709)[INFO]: viChn:0 vstd:0 [atbm_log]:ble start
[2024/8/7 9:27:23 411] enter
[2024/8/7 9:27:23 411] [1970-01-01 00:00:08] ==> ViChnConf[atbm_log]:[ALTOBEAM-ble_recv] start
[2024/8/7 9:27:23 427] ig(866)[INFO]: s[atbm_log]:ble subscribe
[2024/8/7 9:27:23 427] et vichn 0 size [atbm_log]:[ALTOBEAM-ble_xmit] start
[2024/8/7 9:27:23 427] [3840, 2160]
[2024/8/7 9:27:23 427] atbm_log]:ble_platform_probe(c1ecd6c0)
[2024/8/7 9:27:23 442] ;32m[1970-01-01 [atbm_log]:is registered as 'ALTOBEAM'
[2024/8/7 9:27:23 442] 00:00:08] ==> Vi[atbm_log]:[atbm_wtd]:set wtd_probe = 1
[2024/8/7 9:27:23 443] ChnConfig(866)[INFO]: set vichn 1 size [usbcore: registered new interface driver atbm_wlan
[2024/8/7 9:27:23 458] 640, 360]
[2024/8/7 9:27:23 460] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 2 size [640, 224]
[2024/8/7 9:27:23 460] [1970-01-01 00:00:08] ==> VencChCreate(1058)[INFO]: channel:0 enter
[2024/8/7 9:27:23 474] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[0].vencMem = VENCMEM_MICRO
[2024/8/7 9:27:23 490] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 0,width = 3840,height = 2160,enType = 265
[2024/8/7 9:27:23 490] NORM ENC MODE
[2024/8/7 9:27:23 490] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[1].vencMem = VENCMEM_MICRO
[2024/8/7 9:27:23 506] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 1,width = 640,height = 360,enType = 265
[2024/8/7 9:27:23 506] NORM ENC MODE
[2024/8/7 9:27:23 506] aec 1; agc 1; ans 1
[2024/8/7 9:27:23 522] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 21,DestChnId = 0,DestModId = 23
[2024/8/7 9:27:23 522] [1970-01-01 00:00:08] ==> AudioCreate(1656)[INFO]: XM_AENC_CreateCH OK
[2024/8/7 9:27:23 538] [1970-01-01 00:00:08] ==> AudioCreate(1685)[INFO]: XM_MPI_ADEC_CreateChn OK
[2024/8/7 9:27:23 538] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 24,DestChnId = 0,DestModId = 22
[2024/8/7 9:27:23 555] [1970-01-01 00:00:08] ==> JPEGChCreate(1556)[INFO]: enter JPEGChCreate channel=DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:27:23 555] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:27:23 570] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:27:23 570] DEBUG: software pohtoR!
[2024/8/7 9:27:23 570] DEBUG: camera_set_photosensitive_chn 0 1 0x1
[2024/8/7 9:27:23 570] 0, VencChn = 3
[2024/8/7 9:27:23 587] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 3,width = 640,height = 360,enType = 26
[2024/8/7 9:27:23 587] [1970-01-01 00:00:08] ==> COMM_VENC_Start(913)[INFO]: set JpegAttr
[2024/8/7 9:27:23 603] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 1,SrcModId = 7,DestChnId = 3,DestModId = 7
[2024/8/7 9:27:23 619] [1970-01-01 00:00:08] ==> COMM_VENC_Start(1032)[INFO]: JPEG_CHN[3] bind VENC_CHN[1] success!.
[2024/8/7 9:27:23 635] [1970-01-01 00:00:08] MainApp.c(1816) <main>: [1970-01-01 00:00:08] MainApp.c(1823) <main>: [1970-01-01 00:00:08] MainApp.c(1883) <main>: g_fps=[12]
[2024/8/7 9:27:23 636] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=0,brc=1,w=3840,h=2160,qua=4,frame=12,br=1000,gop=4
[2024/8/7 9:27:23 650] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[0],wh[3840,2160]-----------
[2024/8/7 9:27:23 650] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:27:23 666] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=1,brc=1,w=640,h=360,qua=4,frame=9,br=256,gop=1
[2024/8/7 9:27:23 682] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[1],wh[640,360]-----------
[2024/8/7 9:27:23 682] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:27:23 699] [1970-01-01 00:00:08] MainApp.c(1885) <main>: [1970-01-01 00:00:08] MainApp.c(1893) <main>: 
[2024/8/7 9:27:23 699] [1970-01-01 00:00:08] MainApp.c(1898) <main>: 
[2024/8/7 9:27:23 715] [1970-01-01 00:00:08] xm_main.c(1375) <XM_RealAudio_Pro>: real Audio play start___
[2024/8/7 9:27:23 715] [1970-01-01 00:00:08] ==> AudioInSetFormat(68)[INFO]: pFormat.EncodeTye = 2
[2024/8/7 9:27:23 731] [1970-01-01 00:00:08] ==> XMSDK_AudioInSetFormat(445)[INFO]: anr(1) agc(1) aec(0)
[2024/8/7 9:27:23 731] aec 0; agc 1; ans 1
[2024/8/7 9:27:23 731] [1970-01-01 00:00:08] xm_main.c(1747) <XM_RealVideo_Pro>: realy video play start___0
[2024/8/7 9:27:23 747] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:27:23 762] [1970-01-01 00:00:08] xm_main.c(700) <XM_SetCameraFactoryConfig>: Get AutoMantence flags [0] failed
[2024/8/7 9:27:23 762] [1970-01-01 00:00:08] xm_main.c(1899) <PtzControl_Pro>: 
[2024/8/7 9:27:23 778] PtzControl_Pro[1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 0
[2024/8/7 9:27:23 778] [1970-01-01 00:00:08] ==> XMSDK_MotorCreate(120)[INFO]: xlimit 5006, ylimit 2161
[2024/8/7 9:27:23 794] [1970-01-01 00:00:08] xm_main.c(1903) <PtzControl_Pro>: g_sPtz.xMaxStep 5006 g_sPtz.yMaxStep 2161 
[2024/8/7 9:27:23 794] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 0 OK
[2024/8/7 9:27:23 810] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 1
[2024/8/7 9:27:23 826] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 1 OK
[2024/8/7 9:27:23 827] [1970-01-01 00:00:08] xm_main.c(821) <XM_SetCameraFactoryConfig>: get default language ChineseEnglish
[2024/8/7 9:27:23 842] [1970-01-01 00:00:08] xm_main.c(822) <XM_SetCameraFactoryConfig>: get defult IRcurt reverse: no picture reverse mirror:yes filp:yes
[2024/8/7 9:27:23 858] [1970-01-01 00:00:08] xm_main.c(823) <XM_SetCameraFactoryConfig>: set defult motor ptz reverse  mirror:yes filp:no
[2024/8/7 9:27:23 858] [1970-01-01 00:00:08] xm_main.c(824) <XM_SetCameraFactoryConfig>: get defult autotrack motor reverse mirror:yes filp:no
[2024/8/7 9:27:23 874] [1970-01-01 00:00:08] xm_main.c(825) <XM_SetCameraFactoryConfig>: get defult ptz preset x:1556 y:950
[2024/8/7 9:27:23 890] [1970-01-01 00:00:08] xm_main.c(920) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:27:23 890] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:27:23 906] [1970-01-01 00:00:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[597],val=[1]
[2024/8/7 9:27:23 922] [1970-01-01 00:00:08] xm_main.c(969) <XM_SetCameraFactoryConfig>: get factory language ChineseEnglish
[2024/8/7 9:27:23 922] [1970-01-01 00:00:08] xm_main.c(970) <XM_SetCameraFactoryConfig>: get factory IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:27:23 938] [1970-01-01 00:00:08] xm_main.c(971) <XM_SetCameraFactoryConfigDEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:27:23 938] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:27:23 954] DEBUG: camera_set_photosensitive_chn 0 0 0x1
[2024/8/7 9:27:23 954] ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!killall: hostapd: no process killed
[2024/8/7 9:27:23 954] [atbm_log]:ioctl_open(c26aca00)(c1ecd6c0)
[2024/8/7 9:27:23 970] [atbm_log]:atbm_ioctl_ble_start
[2024/8/7 9:27:24 004] DEBUG: camera_set_ledType:  2
[2024/8/7 9:27:24 004] DEBUG: camera_set_dnc_mode_chn 3 
[2024/8/7 9:27:24 004] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:27:24 019] DEBUG: LED: [IR] [WL] 
[2024/8/7 9:27:24 019] DEBUG: software LED
[2024/8/7 9:27:24 019] DEBUG: software pohtoR!
[2024/8/7 9:27:24 019] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:27:24 035] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:27:24 035] DEBUG: camera_set_ledHold: 60000
[2024/8/7 9:27:24 035] >: set factory motor ptz reverse  mirror:yes filp:yes
[2024/8/7 9:27:24 050] [1970-01-01 00:00:08] xm_main.c(972) <XM_SetCameraFactoryConfig>: get factory autotrack motor reverse mirror:no filp:no
[2024/8/7 9:27:24 050] [1970-01-01 00:00:08] xm_main.c(973) <XM_SetCameraFactoryConfig>: get factory ptz preset x:3110 y:0
[2024/8/7 9:27:24 066] [1970-01-01 00:00:08] xm_main.c(1007) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:27:24 082] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:27:24 100] [1970-01-01 00:00:08] xm_main.c(1040) <XM_SetCameraFactoryConfig>: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:27:24 100] [1970-01-01 00:00:08] xm_main.c(1060) <XM_SetCameraFactoryConfig>: set IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:27:24 114] [1970-01-01 00:00:08] xm_main.c(1078) <XM_SetCameraFactoryConfig>: camera_set_softIr_thr(1) ret=[0]
[2024/8/7 9:27:24 114] ************last intra 0
[2024/8/7 9:27:24 114] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:27:24 132] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:27:24 132] ************last intra 0
[2024/8/7 9:27:24 132] [1970-01-01 00:00:08] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time8285
[2024/8/7 9:27:24 146] [1970-01-01 00:00:08] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 112721
[2024/8/7 9:27:24 146] [1970-01-01 00:00:08] MainApp.c(1900) <main>: 
[2024/8/7 9:27:24 146] [1970-01-01 00:00:08] MainApp.c(1905) <main>: 
[2024/8/7 9:27:24 164] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:Register pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:27:24 179] [1970-01-01 00:00:08] ==> XMSDK_AudioSetSpeakerVol(641)[INFO]: enter: Speaker Open
[2024/8/7 9:27:24 179] [1970-01-01 00:00:08] MainApp.c(1913) <main>: 
[2024/8/7 9:27:24 195] [1970-01-01 00:00:08] ==> XMSDK_WifiInit(601)[INFO]: Wifi Init success
[2024/8/7 9:27:24 195] [1970-01-01 00:00:08] MainApp.c(1915) <main>: 
[2024/8/7 9:27:24 195] [1970-01-01 00:00:08] MainApp.c(1918) <main>: 
[2024/8/7 9:27:24 195] lib_ble_main_init
[2024/8/7 9:27:24 195] ======>>atbm_ble_start>>>
[2024/8/7 9:27:24 211] nimble_port_init++
[2024/8/7 9:27:24 211] nimble_host_task
[2024/8/7 9:27:24 211] ble_coexist_start--
[2024/8/7 9:27:24 211] hif_ioctl_loop
[2024/8/7 9:27:24 211] ble_hs_sync:333
[2024/8/7 9:27:24 211] ble_smart_cfg_startup!11
[2024/8/7 9:27:24 211] [ATBM lOG]set default tx power(0)
[2024/8/7 9:27:24 211] pub addr 90:31:4b:a5:16:51
[2024/8/7 9:27:24 226] [1970-01-01 00:00:09] MainApp.c(1922) <main>: ble_ret=[0]
[2024/8/7 9:27:24 226] [1970-01-01 00:00:09] MainApp.c(1200) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 242] [1970-01-01 00:00:09] MainApp.c(1229) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 242] [1970-01-01 00:00:09] MainApp.c(1258) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 258] [1970-01-01 00:00:09] MainApp.c(1260) <GetAndSetTyDefalutConfig>: SMLMode=[2]
[2024/8/7 9:27:24 258] [1970-01-01 00:00:09] MainApp.c(1263) <GetAndSetTyDefalutConfig>: g_SMLAbility=[0]
[2024/8/7 9:27:24 258] [1970-01-01 00:00:09] MainApp.c(1266) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 274] [1970-01-01 00:00:09] MainApp.c(1338) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 274] [1970-01-01 00:00:09] MainApp.c(1346) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 290] [1970-01-01 00:00:09] MainApp.c(1357) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 290] [1970-01-01 00:00:09] MainApp.c(1387) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 306] [1970-01-01 00:00:09] MainApp.c(1390) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:24 306] [1970-01-01 00:00:09] xm_ai.c(564) <XM_CreatePersionDetect>: 
[2024/8/7 9:27:24 306] [1970-01-01 00:00:09] xm_ai.c(574) <XM_CreatePersionDetect>: 
[2024/8/7 9:27:24 322] [1970-01-01 00:00:09] xm_ai.c(585) <XM_CreatePersionDetect>: 
[2024/8/7 9:27:24 322] [1970-01-01 00:00:09] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:27:24 338] [1970-01-01 00:00:09] xm_ai.c(588) <XM_CreatePersionDetect>: 
[2024/8/7 9:27:24 339] [1970-01-01 00:00:09] xm_ai.c(608) <XM_CreatePersionDetect>: 
[2024/8/7 9:27:24 354] [1970-01-01 00:00:09] xm_ai.c(645) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:27:24 386] [1970-01-01 00:00:09] xm_ai.c(646) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:09] xm_ai.c(647) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTime = [8];src/ped_thread.c(746) [Smart_Ped_Create]: Smart_Ped_Create_ver: Jul 24 2024 18:21:40
[2024/8/7 9:27:24 386] src/ped_thread.c(656) [Ped_Init_IA_Work]: Ped_Init_IA_Work start ver:Jul 24 2024 18:21:40
[2024/8/7 9:27:24 386] [FUNC: IA_InitLog] Creat OK.
[2024/8/7 9:27:24 466] ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!ListMng - BufListCreate: index 1 OK
[2024/8/7 9:27:25 314] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:27:25 314] Mode(Product):0
[2024/8/7 9:27:25 314] BpuMode:[Online]
[2024/8/7 9:27:25 314] VpssMode:[Online]
[2024/8/7 9:27:25 314] [0.LimitUp_info]:
[2024/8/7 9:27:25 314] LimitUp:[Disable]
[2024/8/7 9:27:25 314] [2680*0]->[3840*0])
[2024/8/7 9:27:25 314] chn	TotalSize	ActiveSize
[2024/8/7 9:27:25 330] 0	5046*2246	2680*2160
[2024/8/7 9:27:25 330] 0	5034*2246	3840*2160
[2024/8/7 9:27:25 330] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:27:25 330] [1.VICU_info]:
[2024/8/7 9:27:25 330] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:27:25 346] 0	25.0	57	0	0	183	linear	8ddb00
[2024/8/7 9:27:25 347] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:27:25 347] en	op_type	m_chn	now
[2024/8/7 9:27:25 347] 0	1	1	1
[2024/8/7 9:27:25 347] [2.VI_info]:
[2024/8/7 9:27:25 347] chn	TotalSize	ActiveSize
[2024/8/7 9:27:25 347] 0	5040*2246	3848*2166
[2024/8/7 9:27:25 347] 1	   0*   0	   0*   0
[2024/8/7 9:27:25 362] [3.MIPI_info]:
[2024/8/7 9:27:25 363] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:27:25 363] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:27:25 363] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:27:25 379] [4.Cut_info]:
[2024/8/7 9:27:25 379] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:27:25 379] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:27:25 379] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:27:25 379] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:27:25 379] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:27:25 394] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:27:25 394] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:27:25 394] [5.IB(isp buffer info)]:
[2024/8/7 9:27:25 394] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:27:25 410] PoolId  Count  Size
[2024/8/7 9:27:25 410] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:25 410] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:25 426] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:25 426] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:25 442] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:25 442] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:25 443] 
[2024/8/7 9:27:25 443] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:27:25 458] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:27:25 458] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:27:25 458] 0       0         0          1          4       
[2024/8/7 9:27:25 474] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:27:25 474]      --265--            --264--                                               
[2024/8/7 9:27:25 474] Count      Line     Count      Line     
[2024/8/7 9:27:25 490] 30         437      73         560      
[2024/8/7 9:27:25 490] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:27:25 490] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:27:25 507] 0   3840   2160    H265  0      0        0           16        977582     5458     	
[2024/8/7 9:27:25 507] 1   640    360     H265  0      0        0           13        43196      4        	
[2024/8/7 9:27:25 522] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:27:25 522] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:27:25 538] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:27:25 554] 0   Y      16       0       0       14       1        15       15       28        63715         59807    111734   66728    0       
[2024/8/7 9:27:25 554] 1   Y      13       0       0       1        0        13       13       29        2705          2030     26838    4842     0       
[2024/8/7 9:27:25 571] 3   N      0        0       0       1        0        0        0        29        0             0        0        0        0       
[2024/8/7 9:27:25 571] [INIT]: XM_IA_Init() done.
[2024/8/7 9:27:25 586] src/ped_thread.c(705) [Ped_Init_IA_Work]: ruler 0 region (0,0) (0,0) (0,0) (0,0)
[2024/8/7 9:27:25 587] [INIT]:LIBXMIA IAtype 700 Complied at May  8 2024 08:39:39 GIT_ID:cb3a4ed0
[2024/8/7 9:27:25 602] [INIT]: TD Version: TD_V_3.2.4.2[May 15 2024 19:14:32]
[2024/8/7 9:27:25 602] -- TD INIT -- 
[2024/8/7 9:27:25 602]  uiTdMaxNum: 12 
[2024/8/7 9:27:25 602]  acClassBinPath: /usr/bin 
[2024/8/7 9:27:25 602]  ePlatForm: 50 
[2024/8/7 9:27:25 602]  eDevImgType: 17 
[2024/8/7 9:27:25 602]  stDevImgSize: (2680,2160) 
[2024/8/7 9:27:25 602]  iTrackFlag: 1 
[2024/8/7 9:27:25 602]  iTrackType: 2 
[2024/8/7 9:27:25 618] -- TD EXTF -- 
[2024/8/7 9:27:25 618]  ucPedFallDownEnable: 0
[2024/8/7 9:27:25 618]  ucTDFeatureEnable: 0
[2024/8/7 9:27:25 618]  ucSmokeEnable: 0
[2024/8/7 9:27:25 618]  ucFaceDetEnable: 0
[2024/8/7 9:27:25 618]  ucFaceMaskEnable: 0
[2024/8/7 9:27:25 618]  ucFaceAngEnable: 0
[2024/8/7 9:27:25 618]  ucFaceRegEnable: 0
[2024/8/7 9:27:25 635]  ucPlateDetEnable: 0
[2024/8/7 9:27:25 636]  ucPlateRegEnable: 0
[2024/8/7 9:27:25 636]  ucPedPointEnable: 0
[2024/8/7 9:27:25 636]  ucHandPointEnable: 0
[2024/8/7 9:27:25 636]  ucHelmetEnable: 0
[2024/8/7 9:27:25 636]  ucHandgestureEnable: 0
[2024/8/7 9:27:25 636]  efdfreq: 10
[2024/8/7 9:27:25 650] [INIT]: XM_IA_TD_PED_S Version: 20230719_person_noexp_v200
[2024/8/7 9:27:25 650] [INIT] Alg Malloc Size 27232
[2024/8/7 9:27:25 650] -- TD CFG --  
[2024/8/7 9:27:25 650]  iMDFlag: 0
[2024/8/7 9:27:25 650]  ucDetectDisable: 0
[2024/8/7 9:27:25 650]  iDetectType: 5
[2024/8/7 9:27:25 650]  ePattern: 3
[2024/8/7 9:27:25 650]  eSensitivity: 2
[2024/8/7 9:27:25 650]  ucFishEyeCorrectFlag:0
[2024/8/7 9:27:25 650]  eRotate:0
[2024/8/7 9:27:25 666]  ucSationaryTd: 0
[2024/8/7 9:27:25 666]  ucClearnessFlg:0
[2024/8/7 9:27:25 666]  usInImgWidth:0
[2024/8/7 9:27:25 666]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:27:25 666] [CFG]: Rule:0 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:27:25 666] [CFG]: Rule:1 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:27:25 682] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:27:25 682] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:27:25 699] [CFG]: DEFAULT iBoundaryPtsNum 4 eAlarmDirect 2 (0 0) (8191 0) (8191 8191) (0 8191)
[2024/8/7 9:27:25 699] [FUNC:PbdcnnConfig][L:578] (nil) 0xbea7f2f8 Pointer Null.
[2024/8/7 9:27:25 699] [INIT]: PdConfig pvHandle 0xb1221000. Config OK
[2024/8/7 9:27:25 699] [INIT] Alg Malloc Size 30000
[2024/8/7 9:27:25 714] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:27:25 714] [INIT]:memPoolSize 1351680.
[2024/8/7 9:27:25 714] V1.6.x date Sep  5 2023, time 23:32:25 npu load start
[2024/8/7 9:27:25 730] dpu version v1.1.0 build time Aug  5 2022
[2024/8/7 9:27:25 730] [INIT]: Update MemPoolSize 0 to 1351680.
[2024/8/7 9:27:25 730] [INIT]: MmzAlloc MemPoolSize 1351680 0xb105f000~0xb11a9000.
[2024/8/7 9:27:25 746] 0 Model 0xed1f8c MemPoolIdx 0 MemPoolInfo 0x6d5f10
[2024/8/7 9:27:25 746] [INIT]: version 20230719_person_noexp_v200, debug 0, profile 0
[2024/8/7 9:27:25 746] [INIT] Alg Malloc Size 240736
[2024/8/7 9:27:25 746] CNNMemory: 2064977 bulk 240736 mmz 1824241
[2024/8/7 9:27:25 762] CNNINIT INPUT IMAGESIZE:(640,224)
[2024/8/7 9:27:25 762] TD_DETECT stAlgImgSize (640,224) 
[2024/8/7 9:27:25 762] [INIT] Alg Malloc Size 60672
[2024/8/7 9:27:25 762] MdInit ok![INIT] Alg Malloc Size 79704
[2024/8/7 9:27:25 762] [FUNC: trackInit][L: 273] API_Creat_IMG 
[2024/8/7 9:27:25 778] [INIT]: PdInit pvHandle 0xed1dd0 *pvHandle 0xb1221000 OK
[2024/8/7 9:27:25 778] IA_LOG 87c69000 value 0
[2024/8/7 9:27:25 778] IA_TD_LOG 87c69004 value 0
[2024/8/7 9:27:25 778] Ped_Init_IA_Work end 
[2024/8/7 9:27:25 794] src/ped_thread.c(774) [Smart_Ped_Create]: Create list success, index 1 maxsize 2
[2024/8/7 9:27:25 794] src/ped_thread.c(495) [PedProc_v2]: 
[2024/8/7 9:27:25 794] src/ped_thread.c(520) [PedProc_v2]: 
[2024/8/7 9:27:25 794] [FUNC: DetectTarget][L: 1489] API_Creat_IMG_MdInImg 
[2024/8/7 9:27:25 810] [FUNC: PbdcnnWork][L: 1084] API_Creat_CSCIMG 
[2024/8/7 9:27:25 810] [1970-01-01 00:00:10] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:25 826] [1970-01-01 00:00:10] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:25 826] src/ped_thread.c(803) [Smart_Ped_Create]: Ped_Creat Success @0x39e24
[2024/8/7 9:27:25 842] [1970-01-01 00:00:10] xm_ai.c(649) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:27:25 858] [1970-01-01 00:00:10] xm_ai.c(657) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:10] xm_ai.c(658) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTime = [8];-- TD CFG --  
[2024/8/7 9:27:25 858]  iMDFlag: 0
[2024/8/7 9:27:25 874]  ucDetectDisable: 0
[2024/8/7 9:27:25 874]  iDetectType: 5
[2024/8/7 9:27:25 874]  ePattern: 3
[2024/8/7 9:27:25 874]  eSensitivity: 0
[2024/8/7 9:27:25 874]  ucFishEyeCorrectFlag:0
[2024/8/7 9:27:25 874]  eRotate:0
[2024/8/7 9:27:25 874]  ucSationaryTd: 0
[2024/8/7 9:27:25 874]  ucClearnessFlg:0
[2024/8/7 9:27:25 874]  usInImgWidth:0
[2024/8/7 9:27:25 874]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:27:25 890] [CFG]: Rule:0 ucRuleEnable:1 AlarmType:0 eRuleType:1
[2024/8/7 9:27:25 906] [CFG]: IA_PERIMETER_V1 iBoundaryPtsNum 4 eAlarmDirect 0 (0 0) (8191 0) (8191 8191) (0 8191) [CFG]: Rule:1 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:27:25 906] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:27:25 906] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:27:25 906] [INIT]: PdConfig pvHandle 0xb1221000. Config OK
[2024/8/7 9:27:25 922] IA_LOG 87c69000 value 0
[2024/8/7 9:27:25 922] IA_TD_LOG 87c69004 value 0
[2024/8/7 9:27:25 922] src/ped_thread.c(831) [Smart_Ped_SetParam]: Ped_SetParam Success
[2024/8/7 9:27:25 922] [1970-01-01 00:00:10] xm_ai.c(666) <XM_CreatePersionDetect>: 
[2024/8/7 9:27:25 938] [1970-01-01 00:00:10] xm_ai.c(674) <XM_CreatePersionDetect>: 
[2024/8/7 9:27:25 938] [1970-01-01 00:00:10[MMZ] BUILD TIME:[Jul 14 2021 15:42:31]
[2024/8/7 9:27:25 938] [0x83400000--------0x88000000]
[2024/8/7 9:27:25 954] --START-----------SIZE----------------OVERFLOW----NAME---------------
[2024/8/7 9:27:25 954] 0x83400000	0xbde000  (12152k)	0	vb[bdd800][0]
[2024/8/7 9:27:25 954] 0x83fde000	0xbde000  (12152k)	0	vb[bdd800][1]
[2024/8/7 9:27:25 970] 0x84bbc000	0xbde000  (12152k)	0	vb[bdd800][2]
[2024/8/7 9:27:25 970] 0x8579a000	0x55000   (  340k)	0	vb[54600][0]
[2024/8/7 9:27:25 970] 0x857ef000	0x55000   (  340k)	0	vb[54600][1]
[2024/8/7 9:27:25 970] 0x85844000	0x35000   (  212k)	0	vb[34800][0]
[2024/8/7 9:27:25 986] 0x85879000	0x35000   (  212k)	0	vb[34800][1]
[2024/8/7 9:27:25 986] 0x858ae000	0x24000   (  144k)	0	isp_nr_alpha_ch0
[2024/8/7 9:27:25 986] 0x858d2000	0x163000  ( 1420k)	0	isp_nr_idx_ch0
[2024/8/7 9:27:25 986] 0x85a35000	0x1000    (    4k)	0	isp_nr_idx_max_ch0
[2024/8/7 9:27:26 003] 0x85a36000	0x84f000  ( 8508k)	0	isp_nr_fetch_ch0
[2024/8/7 9:27:26 003] 0x86285000	0x2000    (    8k)	0	isp_defog_ch0
[2024/8/7 9:27:26 003] 0x86287000	0xc24000  (12432k)	0	vencRfcFrame[0]
[2024/8/7 9:27:26 003] 0x86eab000	0xc24000  (12432k)	0	vencRfcFrame[1]
[2024/8/7 9:27:26 017] 0x87acf000	0xf1000   (  964k)	0	stream_chn[0]
[2024/8/7 9:27:26 018] 0x87bc0000	0x4c000   (  304k)	0	vencWrapLuma[0]
[2024/8/7 9:27:26 018] 0x87c0c000	0x26000   (  152k)	0	vencWrapChroma[0]
[2024/8/7 9:27:26 033] 0x87c32000	0xb000    (   44k)	0	stream_chn[1]
[2024/8/7 9:27:26 036] 0x87c3d000	0x2b000   (  172k)	0	stream_chn[3]
[2024/8/7 9:27:26 036] 0x87c68000	0x1000    (    4k)	0	osd_block[0]
[2024/8/7 9:27:26 036] 0x87c69000	0x1000    (    4k)	0	IA_LOG
[2024/8/7 9:27:26 036] 0x87c6a000	0x7000    (   28k)	0	IA_MANAGE_1
[2024/8/7 9:27:26 050] 0x87c71000	0x8000    (   32k)	0	IA_MANAGE_2
[2024/8/7 9:27:26 050] 0x87c79000	0x70000   (  448k)	0	firm_mem_0
[2024/8/7 9:27:26 050] 0x87ce9000	0x14b000  ( 1324k)	0	mempool_1
[2024/8/7 9:27:26 050] 0x87e34000	0x1000    (    4k)	0	dst_mem_1
[2024/8/7 9:27:26 066] 0x87e35000	0x1000    (    4k)	0	dst_mem_2
[2024/8/7 9:27:26 066] 0x87e36000	0x3000    (   12k)	0	dst_mem_3
[2024/8/7 9:27:26 066] 0x87e39000	0x1000    (    4k)	0	dst_mem_4
[2024/8/7 9:27:26 066] 0x87e3a000	0x14000   (   80k)	0	IA_MANAGE_3
[2024/8/7 9:27:26 082] 0x87e4e000	0x35000   (  212k)	0	IA_Image_1
[2024/8/7 9:27:26 082] 0x87e83000	0x6a000   (  424k)	0	IA_Image_2
[2024/8/7 9:27:26 082] 0x87eed000	0x1000    (    4k)	0	osd_block[4]
[2024/8/7 9:27:26 082] 0x87eee000	0x112000  ( 1096k)	1	
[2024/8/7 9:27:26 097] ---------------------------------------------------------------------
[2024/8/7 9:27:26 097] SIZE: 0x4c00000(77824k)  USED: 0x4aee000(76728k)  FREE: 0x112000(1096k)
[2024/8/7 9:27:26 098] ] MainApp.c(1395) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:26 113] [1970-01-01 00:00:10] MainApp.c(1397) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:26 114] [1970-01-01 00:00:10] MainApp.c(1402) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:26 130] [1970-01-01 00:00:10] MainApp.c(1481) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:26 130] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 60 enable 0 volume
[2024/8/7 9:27:26 130] [1970-01-01 00:00:10] MainApp.c(1525) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:26 146]  PTZPreset is empty!
[2024/8/7 9:27:26 162] [1970-01-01 00:00:10] MainApp.c(1554) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:26 162] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:26 178] [1970-01-01 00:00:10] MainApp.c(1568) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:26 178] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:26 194] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:26 210] [1970-01-01 00:00:10] MainApp.c(1584) <GetAndSetTyDefalutConfig>: cruisetime_pro create!
[2024/8/7 9:27:26 210] [1970-01-01 00:00:10] MainApp.c(1607) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:27:26 210] [1970-01-01 00:00:10] MainApp.c(1925) <main>: 
[2024/8/7 9:27:26 226] [1970-01-01 00:00:10] MainApp.c(1116) <GetRegisterMode>: -------- register mode 1
[2024/8/7 9:27:26 226] [1970-01-01 00:00:10] MainApp.c(1927) <main>: 
[2024/8/7 9:27:26 226] [1970-01-01 00:00:10] MainApp.c(1930) <main>: 
[2024/8/7 9:27:26 242] *************
[2024/8/7 9:27:26 242]  0x6d123c 
[2024/8/7 9:27:26 242] *****************
[2024/8/7 9:27:26 242]  0x3287c 
[2024/8/7 9:27:26 242] beginend[1970-01-01 00:00:10] MainApp.c(1938) <main>: 
[2024/8/7 9:27:26 258] [1970-01-01 00:00:10] MainApp.c(866) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:27:26 274] [1970-01-01 00:00:10] MainApp.c(174) <GetDeviceHWInfo>: Get Hwinfo APP_ID [fvijo8jvloagv1gm], UUID[uuidcaab27b0a838d239] AUTHKEY [j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:27:26 274] [1970-01-01 00:00:10] MainApp.c(909) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:27:26 274] [1970-01-01 00:00:10] MainApp.c(942) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:27:26 290] [1970-01-01 00:00:10] MainApp.c(986) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:27:26 290] [1970-01-01 00:00:10] MainApp.c(1019) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:27:26 290] sdk start
[2024/8/7 9:27:26 306] [1970-01-01 00:00:10] MainApp.c(752) <tuya_ipc_sdk_start>: log_level 0[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/mtd/Config/ty/ 
[2024/8/7 9:27:26 322] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/mtd/Config/ty/
[2024/8/7 9:27:26 322] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/mtd/Config/ty/
[2024/8/7 9:27:26 322] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[2024/8/7 9:27:26 338] [01-01 18:12:15 TUYA D][simplekv.c:989] both file not exist /mnt/mtd/Config/ty/tuya_user.db
[2024/8/7 9:27:26 338] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[2024/8/7 9:27:26 354] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[2024/8/7 9:27:26 354] [01-01 18:12:15 TUYA D][simplekv.c:1083] init NEW normal file
[2024/8/7 9:27:26 354] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 3536627844
[2024/8/7 9:27:26 370] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:26 370] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[2024/8/7 9:27:26 386] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[2024/8/7 9:27:26 386] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[2024/8/7 9:27:26 402] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[2024/8/7 9:27:26 403] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[2024/8/7 9:27:26 403] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[2024/8/7 9:27:26 418] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[2024/8/7 9:27:26 418] [01-01 18:12:15 TUYA E][log_seq.c:863] open err
[2024/8/7 9:27:26 434] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[2024/8/7 9:27:26 434] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[2024/8/7 9:27:26 450] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[2024/8/7 9:27:26 450] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[2024/8/7 9:27:26 466] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:27:26 466] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:26 466] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:26 482] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:26 482] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:27:26 482] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:27:26 498] [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
[2024/8/7 9:27:26 498] [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:27:26 498] dev id key: 16
[2024/8/7 9:27:26 514] d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[2024/8/7 9:27:26 514] --- tracepoint bt_ext_porting.c,tuya_ext_bt_port_init(464): tuya_ext_bt_port_init ---
[2024/8/7 9:27:26 530] [01-01 18:12:15 TUYA I][bt_ext_porting.c:466] [TUYA-BTUART]tuya ext bt port init
[2024/8/7 9:27:26 530] --- tracepoint bt_uart_drv.c,tuya_bt_uart_open(187): tuya_bt_uart_open ---
[2024/8/7 9:27:26 530] --- tracepoint bt_uart_drv.c,tuya_bt_uart_init(60): tuya_bt_uart_init  0 ---
[2024/8/7 9:27:26 546] [01-01 18:12:15 TUYA I][bt_ext_porting.c:485] [TUYA-BTUART]thread ty_btext_thread create cplt mode 1
[2024/8/7 9:27:26 546] [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[2024/8/7 9:27:26 562] [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[2024/8/7 9:27:26 562] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish
[2024/8/7 9:27:26 578] [1970-01-01 00:00:10] MainApp.c(822) <tuya_ipc_sdk_start>: create ring buffer start 
[2024/8/7 9:27:26 578] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:0 Enable:1
[2024/8/7 9:27:26 578] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 2048, video_fps 12
[2024/8/7 9:27:26 594] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr0 bitrate:2048 fps:12
[2024/8/7 9:27:26 610] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 2621440 bytes for ch0st0tr0, max frame size 393216
[2024/8/7 9:27:26 610] --- tracepoint bt_ext_porting.c,ty_btext_thread(370):  ---
[2024/8/7 9:27:26 610] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr0 size:2621440 nodes:120
[2024/8/7 9:27:26 626] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:0
[2024/8/7 9:27:26 626] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:1 Enable:1
[2024/8/7 9:27:26 642] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 1024, video_fps 12
[2024/8/7 9:27:26 658] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr1 bitrate:1024 fps:12
[2024/8/7 9:27:26 674] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1310720 bytes for ch0st0tr1, max frame size 196608
[2024/8/7 9:27:26 674] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr1 size:1310720 nodes:120
[2024/8/7 9:27:26 690] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:1
[2024/8/7 9:27:26 690] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:2 Enable:0
[2024/8/7 9:27:26 690] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:3 Enable:0
[2024/8/7 9:27:26 706] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:4 Enable:0
[2024/8/7 9:27:26 706] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:5 Enable:0
[2024/8/7 9:27:26 722] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:6 Enable:0
[2024/8/7 9:27:26 722] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:7 Enable:0
[2024/8/7 9:27:26 738] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring bu[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:27:26 738] ffer Channel:8 Enable:0
[2024/8/7 9:27:26 738] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:9 Enable:1
[2024/8/7 9:27:26 754] [01-01 18:12:15 TUYA D][MainApp.c:439] audio_sample 8000, audio_databits 16, audio_fps 25
[2024/8/7 9:27:26 754] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[2024/8/7 9:27:26 770] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 160000 bytes for ch0st0tr9, max [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:27:26 786] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[2024/8/7 9:27:26 786] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:9
[2024/8/7 9:27:26 802] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:10 Enable:0
[2024/8/7 9:27:26 802] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:11 Enable:0
[2024/8/7 9:27:26 802] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:12 Enable:0
[2024/8/7 9:27:26 818] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:13 Enable:0
[2024/8/7 9:27:26 818] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:14 Enable:0
[2024/8/7 9:27:26 834] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:15 Enable:0
[2024/8/7 9:27:26 849] [1970-01-01 00:00:10] MainApp.c(830) <tuya_ipc_sdk_start>: pRunInfo->net_info.connect_mode 1[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:27:26 850] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:26 850] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:26 867] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:26 867] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:27:26 867] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:27:26 898] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":null,"auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:27:26 898] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:27:26 914] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:26 914] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:26 914] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:26 930] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:208
[2024/8/7 9:27:26 930] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 0 startpos:28700 size:276
[2024/8/7 9:27:26 946] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:26 946] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 1056267009
[2024/8/7 9:27:26 946] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:26 962] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:26 962] [01-01 18:12:15 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:27:26 978] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":0,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:27:26 978] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:27:26 994] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:26 994] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:26 994] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 010] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:27:27 010] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 1 startpos:28976 size:212
[2024/8/7 9:27:27 026] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and w[atbm_log]:[eth2] change to [3]
[2024/8/7 9:27:27 026] rite zero
[2024/8/7 9:27:27 026] [01-[atbm_log]:[eth2] has been disabled
[2024/8/7 9:27:27 026] 01 18:12:15 TUYA D][simplekv.c:203] update crc 2367317337
[2024/8/7 9:27:27 042] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:27 042] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:27 058] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:27:27 058] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[2024/8/7 9:27:27 058] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1776] Last reset reason: 255
[2024/8/7 9:27:27 074] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 074] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:27:27 074] [01-[atbm_log]:add iftype(6),if_cnt(2),flags(c1ecbbf8)
[2024/8/7 9:27:27 090] 01 18:12:15 TUYA[atbm_log]:enable sg
[2024/8/7 9:27:27 090]  D][simplekv.c:1[atbm_log]:[mon.eth2] has been disabled
[2024/8/7 9:27:27 090] 280] key:gw_bi find value.Len:208
[2024/8/7 9:27:27 090] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:27:27 106] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 106] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 122] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 122] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 122] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:27 138] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:27:27 138] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1140] serial_no:90314ba51650
[2024/8/7 9:27:27 154] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 154] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:27:27 154] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:27:27 170] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[2024/8/7 9:27:27 170] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1171] gw_cntl.gw_wsm.stat:0
[2024/8/7 9:27:27 170] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1347] gw_cntl->gw_wsm.nc_tp:0
[2024/8/7 9:27:27 186] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1348] gw_cntl->gw_wsm.md:0
[2024/8/7 9:27:27 186] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1362] wifi config method not fit
[2024/8/7 9:27:27 202] [01-01 18:12:15 TUYA E][tuya_devos_entry.c:1787] ret:-2
[2024/8/7 9:27:27 202] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1808] enter reset factory
[2024/8/7 9:27:27 202] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 218] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 218] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 218] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 235] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_di -6
[2024/8/7 9:27:27 235] [01-01 18:12:15 TUYA E][ws_db_gw.c:494] gw_di read fail:-6
[2024/8/7 9:27:27 250] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 250] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 250] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 266] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 266] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_di And Value Len:400
[2024/8/7 9:27:27 266] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 2 startpos:29188 size:468
[2024/8/7 9:27:27 282] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:27 282] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 876692212
[2024/8/7 9:27:27 298] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:27 298] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:27 298] [01-01 18:12:15 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:27:27 314] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:593] nc_tp:2, wifi_start_mode:0
[2024/8/7 9:27:27 314] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 314] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 329] [01-01 18:12:15 TU[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:27:27 329] YA D][simplekv.c[atbm_log]:[WSM] Drop frame
[2024/8/7 9:27:27 329] :1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 345] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 346] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:wf_start_md And Value Len:16
[2024/8/7 9:27:27 362] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 3 startpos:29656 size:84
[2024/8/7 9:27:27 362] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:27 362] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 411742493
[2024/8/7 9:27:27 378] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:27 378] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:27 394] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:27:27 394] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 410] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:27:27 410] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:27:27 426] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:27:27 426] [01-01 18:12:15 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:27:27 426] [01-01 18:12:15 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:27:27 442] [01-01 18:12:15 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:27:27 442] [01-01 18:12:[atbm_log]:[eth2] start driver he ap
[2024/8/7 9:27:27 442] 15 TUYA D][simpl[atbm_log]:BSS_CHANGED_BEACON
[2024/8/7 9:27:27 458] ekv.c:203] updat[atbm_log]:change ds_params channel 6 
[2024/8/7 9:27:27 458] e crc 4146866774
[2024/8/7 9:27:27 458] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:27 458] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:27 474] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:27:27 474] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 474] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 490] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 490] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 506] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6
[2024/8/7 9:27:27 506] [01-01 18:12:15 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6
[2024/8/7 9:27:27 506] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 522] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 522] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 522] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 538] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:368
[2024/8/7 9:27:27 538] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 4 startpos:29740 size:436
[2024/8/7 9:27:27 554] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:27 554] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 216605884
[2024/8/7 9:27:27 554] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:27 570] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:27 570] [01-01 18:12:15 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:27:27 570] [01-01 18:12:15 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:27:27 586] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 586] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 602] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 602] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 602] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:27:27 618] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 5 startpos:30176 size:84
[2024/8/7 9:27:27 618] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:27 634] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4220141073
[2024/8/7 9:27:27 634] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:27 634] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:27 650] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 650] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 650] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 666] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 666] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:27:27 682] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 6 startpos:30260 size:84
[2024/8/7 9:27:27 682] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:27 682] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 860452950
[2024/8/7 9:27:27 698] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:27 698] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:27 713] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:27:27 714] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:27 714] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:27 729] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:27 730] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:27:27 730] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 7 startpos:30344 size:84
[2024/8/7 9:27:27 761] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:27 777] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2541358761
[2024/8/7 9:27:27 778] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:27 778] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:27 794] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[2024/8/7 9:27:27 794] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[2024/8/7 9:27:27 809] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[2024/8/7 9:27:27 810] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[2024/8/7 9:27:27 825] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[2024/8/7 9:27:27 826] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[2024/8/7 9:27:27 826] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[2024/8/7 9:27:27 841] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[2024/8/7 9:27:27 842] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[2024/8/7 9:27:27 842] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[2024/8/7 9:27:27 858] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[2024/8/7 9:27:27 858] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[2024/8/7 9:27:27 873] [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[2024/8/7 9:27:27 873] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[2024/8/7 9:27:27 905] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}
[2024/8/7 9:27:27 905] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:116] sys add timer: 14
[2024/8/7 9:27:27 906] 
[2024/8/7 9:27:27 921] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:122] sys start timer: 14
[2024/8/7 9:27:27 921] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[2024/8/7 9:27:27 921] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[2024/8/7 9:27:27 937] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[2024/8/7 9:27:27 937] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[2024/8/7 9:27:27 937] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:fvijo8jvloagv1gm 0
[2024/8/7 9:27:27 938] uuid: 20
[2024/8/7 9:27:27 953] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:27:27 953] dev_id_tmp: 16
[2024/8/7 9:27:27 953] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:27:27 954] dev_id_tmp2: 20
[2024/8/7 9:27:27 969] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:27:27 969] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:27:27 970] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1066] nc_tp:2, md:0
[2024/8/7 9:27:27 985] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1297] dev_nw_cfg_active_stage:2
[2024/8/7 9:27:27 985] [01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[2024/8/7 9:27:28 001] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:27:28 002] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:27:28 002] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:27:28 017] [1970-01-01 00:00:11] MainApp.c(838) <tuya_ipc_sdk_start>: [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[2024/8/7 9:27:28 034] [01-01 18:12:15 TUYA D][MainApp.c:854] tuya ipc sdk start is complete
[2024/8/7 9:27:28 035] 
[2024/8/7 9:27:28 035] killall: hostapd: no process killed
[2024/8/7 9:27:28 035] route: netmask and route address conflict
[2024/8/7 9:27:28 035] [1970-01-01 00:00:11] MainApp.c(1028) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:27:28 050] [1970-01-01 00:00:11] MainApp.c(1053) <TUYA_IPC_SDK_START>: pthread_create BasicIndicatorTimer suc
[2024/8/7 9:27:28 066] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [0] change to [1]
[2024/8/7 9:27:28 066] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [0] change to [1]
[2024/8/7 9:27:28 066] [1970-01-01 00:00:11] MainApp.c(1968) <main>: FLIP
[2024/8/7 9:27:28 082] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [1] change to [0]
[2024/8/7 9:27:28 097] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [1] change to [0]
[2024/8/7 9:27:28 097] [1970-01-01 00:00:11] MainApp.c(1972) <main>: FLIP
[2024/8/7 9:27:28 097] [1970-01-01 00:00:11] MainApp.c(1622) <PostInit>: 
[2024/8/7 9:27:28 114] src/intelligent_track_thread.c(1398) [XM_SmartBodyTarckCreate]: 
[2024/8/7 9:27:28 114] src/intelligent_track_thread.c(1374) [Smart_Track_GetAbility]: 
[2024/8/7 9:27:28 129] src/intelligent_track_thread.c(1379) [Smart_Track_GetAbility]: 
[2024/8/7 9:27:28 131] src/intelligent_track_thread.c(1272) [GetMotorCtrlPara]: 
[2024/8/7 9:27:28 131] src/intelligent_track_thread.c(1277) [GetMotorCtrlPara]: 
[2024/8/7 9:27:28 146] src/intelligent_track_thread.c(1283) [GetMotorCtrlPara]: 
[2024/8/7 9:27:28 146] src/intelligent_track_thread.c(1298) [GetMotorCtrlPara]: max_steps_x=5006 ,max_steps_y=2161
[2024/8/7 9:27:28 162] src/intelligent_track_thread.c(1301) [GetMotorCtrlPara]: 
[2024/8/7 9:27:28 162] src/intelligent_track_thread.c(1307) [GetMotorCtrlPara]: 
[2024/8/7 9:27:28 162] src/intelligent_track_thread.c(1323) [GetMotorCtrlPara]: 
[2024/8/7 9:27:28 177] src/intelligent_track_thread.c(1336) [GetMotorCtrlPara]: track_default_degrees_y=95
[2024/8/7 9:27:28 177] src/intelligent_track_thread.c(1345) [GetMotorCtrlPara]: LoadTrackSet Motor_x_turnover:no
[2024/8/7 9:27:28 193] src/intelligent_track_thread.c(1346) [GetMotorCtrlPara]: LoadTrackSet Motor_y_turnover:no
[2024/8/7 9:27:28 210] src/intelligent_track_thread.c(1348) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 540
[2024/8/7 9:27:28 210] src/intelligent_track_thread.c(1367) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 400
[2024/8/7 9:27:28 226] src/intelligent_track_thread.c(1368) [GetMotorCtrlPara]: LoadTrackSet HEIGHT_STEP = 200
[2024/8/7 9:27:28 226] src/intelligent_track_thread.c(1390) [Smart_Track_GetAbility]: Track_Ability : Enable
[2024/8/7 9:27:28 242] src/intelligent_track_thread.c(1451) [XM_SmartBodyTarckCreate]: Intelligent Track_pthread create Success 1920x1080
[2024/8/7 9:27:28 242] src/intelligent_track_thread.c(667) [TrackProcV200]: 
[2024/8/7 9:27:28 258] [1970-01-01 00:00:11] MainApp.c(277) <BasicIndicatorTimer>: BasicIndicatorTimer start ----
[2024/8/7 9:27:28 258] [1970-01-01 00:00:11] MainApp.c(1640) <PostInit>: ln -s /mnt/mtd/Log/sofia.log /tmp/tuya.log
[2024/8/7 9:27:28 274] [1970-01-01 00:00:11] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:27:28 290] [1970-01-01 00:00:11] MainApp.c(1665) <PostInit>: MotionDetect Sensitive 1 set onvif_on_off:0 
[2024/8/7 9:27:28 290] [1970-01-01 00:00:12] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time12332
[2024/8/7 9:27:28 290] curr event:3 
[2024/8/7 9:27:28 306] IPC_APP_Notify_LED_Sound_Status_CB line(480) -------------------------- IPC_START_WIFI_AP_CFG(3)
[2024/8/7 9:27:28 306] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-1650
[2024/8/7 9:27:28 306] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:27:28 322] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:27:28 322] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:27:28 338] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:27:28 338] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:27:28 338] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:27:28 354] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[2024/8/7 9:27:28 354] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[2024/8/7 9:27:28 370] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[2024/8/7 9:27:28 370] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:27:28 370] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:27:28 386] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:28 386] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:28 401] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:28 401] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:28 402] [01-01 18:12:16 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:27:28 418] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:28 418] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:28 418] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:28 433] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:28 434] [01-01 18:12:16 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:27:28 449] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:27:28 449] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:28 450] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:28 465] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:28 466] [01-01 18:12:16 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:27:28 481] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[2024/8/7 9:27:28 481] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:27:28 578] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:2  -->>
[2024/8/7 9:27:28 594] __IPC_APP_Get_Net_Status_cb line(193) -------------------------- stat(2)==STAT_AP_STA_UNCFG 
[2024/8/7 9:27:28 594] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:2  <<--
[2024/8/7 9:27:28 610] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:27:28 610] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:27:28 626] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:27:28 626] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:28 642] [01-01 18:12:16 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:28 642] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[2024/8/7 9:27:28 658] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:21504,priority:5
[2024/8/7 9:27:28 658] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[2024/8/7 9:27:28 674] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[2024/8/7 9:27:28 674] [01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt netcfg start
[2024/8/7 9:27:28 674] [01-01 18:12:16 TUYA N][tuya_ble_api.c:439] update bound stat:0
[2024/8/7 9:27:28 690] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[2024/8/7 9:27:28 690] [01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:27:28 690] dev id key: 16
[2024/8/7 9:27:28 690] d0 7d 89 57 d1 c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 9:27:28 706] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:27:28 706] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:27:28 722] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:27:28 722] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:27:28 722] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:27:28 738] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 9:27:28 738] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0xf7d518),len(28)
[2024/8/7 9:27:28 754] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 9:27:28 754] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:27:28 771] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0xf7d538),len(30)
[2024/8/7 9:27:28 771] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 9:27:28 786] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:27:28 786] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 9:27:28 786] adv_len:28
[2024/8/7 9:27:28 786] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:27:28 802] svc_data_uuid16 len:18
[2024/8/7 9:27:28 802] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[2024/8/7 9:27:28 818] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:28 818] ---[XmBleAdvertiseEx][1210]: rc=[0]
[2024/8/7 9:27:28 818] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 9:27:28 818] rsp_len:30
[2024/8/7 9:27:28 834] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:27:28 834] mfg_data len:30
[2024/8/7 9:27:28 834] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 9:27:28 834] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 9:27:28 850] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 9:27:28 852] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:28 852] ---[XmBleAdvertiseEx][1241]: rc=[0]
[2024/8/7 9:27:28 865] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 9:27:28 865] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 9:27:28 865] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:28 881] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:28 881] adv_start rc = 0x0
[2024/8/7 9:27:28 882] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 9:27:28 882] [01-01 18:12:16 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:27:28 897] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 9:27:28 897] [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 9:27:28 913] udhcpd (v1.22.1) started
[2024/8/7 9:27:28 914] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:27:28 914] [01-01 18:12:16 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:28 930] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:28 930] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:28 946] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:28 946] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:28 946] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:28 962] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:28 962] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:28 962] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:28 978] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:28 978] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:28 994] [01-01 18:12:16 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:28 994] [01-01 18:12:16 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:28 994] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:29 026] [01-01 18:12:16 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:29 026] [01-01 18:12:16 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:29 042] [01-01 18:12:16 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:29 042] [01-01 18:12:16 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:29 042] gethostbyname_r error: Unknown host
[2024/8/7 9:27:29 058] [01-01 18:12:16 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:29 058] [01-01 18:12:16 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:29 074] [01-01 18:12:16 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:29 074] [01-01 18:12:16 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:29 090] [01-01 18:12:16 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:29 090] [01-01 18:12:16 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:29 106] [01-01 18:12:16 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:29 106] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:29 106] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:27:29 122] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:29 138] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:29 138] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:27:29 154] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:29 154] [01-01 18:12:17 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:29 170] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:29 170] [1970-01-01 00:00:13] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:29 186] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:27:29 186] [01-01 18:12:17 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:27:29 202] [01-01 18:12:17 TUYA D][tuya_ble_api.c:1470] ble get conn stat:4
[2024/8/7 9:27:29 202] [01-01 18:12:17 TUYA N][tuya_ble_api.c:750] ble_sdk_send skip, no connect:4
[2024/8/7 9:27:29 218] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:29 218] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:29 234] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:29 234] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:29 234] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:29 250] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:29 250] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:29 250] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:29 266] [01-01 18:12:17 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:29 266] [01-01 18:12:17 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:29 281] [01-01 18:12:17 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:29 282] [01-01 18:12:17 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:29 282] [01-01 18:12:17 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:29 298] [01-01 18:12:17 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:29 298] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:29 410] [01-01 18:12:17 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:29 410] [01-01 18:12:17 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:29 426] [01-01 18:12:17 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:29 426] [01-01 18:12:17 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:29 426] gethostbyname_r error: Unknown host
[2024/8/7 9:27:29 442] [01-01 18:12:17 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:29 442] [01-01 18:12:17 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:29 458] [01-01 18:12:17 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:29 458] [01-01 18:12:17 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:29 474] [01-01 18:12:17 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:29 474] [01-01 18:12:17 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:29 490] [01-01 18:12:17 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:29 490] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:29 506] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:29 506] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:29 522] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:29 522] [01-01 18:12:18 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:29 714] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:29 730] [1970-01-01 00:00:14] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:29 730] [01-01 18:12:18 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:29 746] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:29 746] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:29 762] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:29 763] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:29 763] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:29 778] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:29 778] [01-01 18:12:18 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:29 778] [01-01 18:12:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:29 793] [01-01 18:12:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:29 793] [01-01 18:12:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:29 809] [01-01 18:12:18 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:29 809] [01-01 18:12:18 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:29 809] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:29 842] [01-01 18:12:18 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:29 842] [01-01 18:12:18 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:29 858] [01-01 18:12:18 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:29 858] [01-01 18:12:18 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:29 858] gethostbyname_r error: Unknown host
[2024/8/7 9:27:29 874] [01-01 18:12:18 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:29 874] [01-01 18:12:18 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:29 889] [01-01 18:12:18 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:29 889] [01-01 18:12:18 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:29 905] [01-01 18:12:18 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:29 905] [01-01 18:12:18 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:29 922] [01-01 18:12:18 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:29 922] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:30 306] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:30 322] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:30 338] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:27:30 338] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:30 354] [01-01 18:12:19 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:30 513] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:30 513] [01-01 18:12:19 TUYA D][tuya_ble_api.c:1376] nw stat change:0->1, rpt to app.
[2024/8/7 9:27:30 529] [01-01 18:12:19 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:27:30 738] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:30 754] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:30 754] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:30 754] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:30 770] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:30 770] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:30 786] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:30 786] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:30 786] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:30 802] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:30 802] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:30 802] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:30 818] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:30 818] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:30 834] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:30 850] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:30 866] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:30 866] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:30 882] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:30 882] gethostbyname_r error: Unknown host
[2024/8/7 9:27:30 882] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:30 898] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:30 898] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:30 898] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:30 914] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:30 914] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:30 930] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:30 930] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:31 330] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:31 346] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:31 346] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:31 362] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:31 809] [1970-01-01 00:00:16] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:31 809] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:31 825] [1970-01-01 00:00:16] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time16544
[2024/8/7 9:27:31 825] [1970-01-01 00:00:16] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:31 841] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:31 857] [01-01 18:12:21 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:31 857] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:31 857] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:31 873] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:31 873] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:31 889] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:31 889] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:31 889] [01-01 18:12:21 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:31 905] [01-01 18:12:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:31 905] [01-01 18:12:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:31 905] [01-01 18:12:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:31 921] [01-01 18:12:21 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:31 921] [01-01 18:12:21 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:31 937] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:31 953] [01-01 18:12:21 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:31 969] [01-01 18:12:21 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:31 969] [01-01 18:12:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:31 986] [01-01 18:12:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:31 986] gethostbyname_r error: Unknown host
[2024/8/7 9:27:31 986] [01-01 18:12:21 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:32 001] [01-01 18:12:21 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:32 001] [01-01 18:12:21 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:32 001] [01-01 18:12:21 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:32 017] [01-01 18:12:21 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:32 017] [01-01 18:12:21 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:32 033] [01-01 18:12:21 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:32 033] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:32 082] motor auto test over
[2024/8/7 9:27:32 082] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 9:27:32 082] action=idle
[2024/8/7 9:27:32 082] dir=
[2024/8/7 9:27:32 082] flag=|auto-test-cmplt
[2024/8/7 9:27:32 082]  steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 9:27:32 098] 
[2024/8/7 9:27:32 099] YYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 9:27:32 099] action=idle
[2024/8/7 9:27:32 099] dir=
[2024/8/7 9:27:32 099] flag=
[2024/8/7 9:27:32 099]  steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 9:27:32 354] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:32 370] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:32 370] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:27:32 386] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:32 386] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:32 529] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:27:32 545] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:32 545] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:27:32 882] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:32 882] [01-01 18:12:22 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:32 899] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:32 899] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:32 899] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:32 914] [01-01 18:12:22 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:32 914] [01-01 18:12:22 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:32 930] [01-01 18:12:22 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:32 931] [01-01 18:12:22 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:32 931] [01-01 18:12:22 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:32 946] [01-01 18:12:22 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:32 946] [01-01 18:12:22 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:32 946] [01-01 18:12:22 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:32 962] [01-01 18:12:22 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:32 962] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:32 995] [01-01 18:12:22 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:32 995] [01-01 18:12:22 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:33 010] [01-01 18:12:22 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:33 010] [01-01 18:12:22 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:33 010] gethostbyname_r error: Unknown host
[2024/8/7 9:27:33 026] [01-01 18:12:22 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:33 026] [01-01 18:12:22 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:33 042] [01-01 18:12:22 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:33 042] [01-01 18:12:22 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:33 042] [01-01 18:12:22 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:33 057] [01-01 18:12:22 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:33 057] [01-01 18:12:22 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:33 073] [01-01 18:12:22 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:33 073] [01-01 18:12:22 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:27:33 346] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:33 362] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:33 378] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:33 378] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:33 889] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:33 905] [1970-01-01 00:00:18] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:33 905] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:33 921] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:33 921] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:33 937] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:33 937] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:33 937] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:33 953] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:33 953] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:33 953] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:33 969] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:33 969] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:33 986] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:33 986] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:33 986] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:34 002] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:34 018] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:34 034] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:34 034] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:34 049] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:34 049] gethostbyname_r error: Unknown host
[2024/8/7 9:27:34 050] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:34 065] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:34 066] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:34 081] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:34 082] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:34 098] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:34 098] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:34 098] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:34 370] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:34 385] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:27:34 401] [1970-01-01 00:00:19] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17[1970-01-01 00:00:19] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 9:27:34 401] [1970-01-01 00:00:19] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 9:27:34 417] mpId[0] is [0].
[2024/8/7 9:27:34 417] mpId[1] is [0].
[2024/8/7 9:27:34 417] mpId[2] is [0].
[2024/8/7 9:27:34 417] mpId[3] is [0].
[2024/8/7 9:27:34 417] mpId[4] is [0].
[2024/8/7 9:27:34 417] mpId[5] is [0].
[2024/8/7 9:27:34 433] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:34 433] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:34 449] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:34 930] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:34 930] [1970-01-01 00:00:19] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:34 945] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:34 961] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:34 961] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:34 961] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:34 977] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:34 977] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:34 977] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:34 993] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:34 993] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:35 009] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:35 009] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:35 009] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:35 025] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:35 025] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:35 041] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:35 057] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:35 057] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:35 074] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:35 074] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:35 089] gethostbyname_r error: Unknown host
[2024/8/7 9:27:35 089] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:35 089] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:35 105] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:35 105] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:35 121] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:35 121] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:35 137] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:35 137] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:35 394] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:35 409] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:35 410] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:35 425] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:35 937] [1970-01-01 00:00:20] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time20512
[2024/8/7 9:27:35 937] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:35 953] [1970-01-01 00:00:20] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:35 953] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:35 969] [01-01 18:12:25 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:35 969] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:35 985] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:35 985] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:36 001] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:36 003] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:36 003] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:36 017] [01-01 18:12:25 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:36 017] [01-01 18:12:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:36 018] [01-01 18:12:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:36 033] [01-01 18:12:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:36 033] [01-01 18:12:25 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:36 049] [01-01 18:12:25 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:36 049] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:36 065] [01-01 18:12:25 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:36 081] [01-01 18:12:25 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:36 081] [01-01 18:12:25 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:36 097] [01-01 18:12:25 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:36 097] gethostbyname_r error: Unknown host
[2024/8/7 9:27:36 097] [01-01 18:12:25 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:36 113] [01-01 18:12:25 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:36 113] [01-01 18:12:25 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:36 130] [01-01 18:12:25 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:36 130] [01-01 18:12:25 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:36 145] [01-01 18:12:25 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:36 145] [01-01 18:12:25 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:36 161] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:36 305] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:36 321] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:36 321] ble_slave_gap_event->type=0
[2024/8/7 9:27:36 321] connection established; status=0 GATT procedure initiated: exchange mtu
[2024/8/7 9:27:36 321] connection, handle=1
[2024/8/7 9:27:36 338] --- tracepoint bt_ext_porting.c,ty_btext_thread(423): TY_BT_EVENT_CONNECTED1 ---
[2024/8/7 9:27:36 338] [01-01 18:12:25 TUYA D][tuya_ble_api.c:543] rev ble event 1
[2024/8/7 9:27:36 338] [01-01 18:12:25 TUYA N][tuya_ble_api.c:472] Ble Connected
[2024/8/7 9:27:36 353] [01-01 18:12:25 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[2024/8/7 9:27:36 353] [01-01 18:12:25 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
[2024/8/7 9:27:36 449] --- tracepoint bt_ext_porting.c,ty_btext_thread(425): TY_BT_EVENT_CONNECTED2 ---
[2024/8/7 9:27:36 449] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:36 465] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:36 465] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:27:36 481] src/intelligent_track_thread.c(709) [TrackProcV200]: Intelligent Track Enable eSensitivity=0 intervalTime_sec=15
[2024/8/7 9:27:36 497] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:36 497] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:36 497] ble_slave_gap_event->type=15
[2024/8/7 9:27:36 513] mtu update event; conn_handle=1 cid=4 mtu=255
[2024/8/7 9:27:36 513] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:36 513] [01-01 18:12:25 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:27:36 961] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:36 978] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:36 978] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:36 993] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:36 993] ble_slave_gap_event->type=4
[2024/8/7 9:27:36 993] connection update request
[2024/8/7 9:27:37 009] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 025] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:37 041] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 042] [01-01 18:12:26 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:37 057] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:37 057] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:37 057] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:37 073] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:37 073] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:37 073] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:37 089] [01-01 18:12:26 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:37 089] [01-01 18:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:37 105] [01-01 18:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:37 105] [01-01 18:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:37 105] [01-01 18:12:26 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:37 121] [01-01 18:12:26 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:37 121] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:37 153] [01-01 18:12:26 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:37 153] [01-01 18:12:26 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:37 169] [01-01 18:12:26 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:37 169] [01-01 18:12:26 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:37 169] gethostbyname_r error: Unknown host
[2024/8/7 9:27:37 185] [01-01 18:12:26 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:37 185] [01-01 18:12:26 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:37 185] [01-01 18:12:26 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:37 201] [01-01 18:12:26 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:37 201] [01-01 18:12:26 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:37 217] [01-01 18:12:26 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:37 217] [01-01 18:12:26 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:37 233] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:37 537] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:27:37 537] Mode(Product):0
[2024/8/7 9:27:37 537] BpuMode:[Online]
[2024/8/7 9:27:37 553] VpssMode:[Online]
[2024/8/7 9:27:37 553] [0.LimitUp_info]:
[2024/8/7 9:27:37 553] LimitUp:[Disable]
[2024/8/7 9:27:37 553] [2680*0]->[3840*0])
[2024/8/7 9:27:37 553] chn	TotalSize	ActiveSize
[2024/8/7 9:27:37 553] 0	5040*2246	2680*2160
[2024/8/7 9:27:37 553] 0	5040*2246	3840*2160
[2024/8/7 9:27:37 569] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:27:37 569] [1.VICU_info]:
[2024/8/7 9:27:37 569] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:27:37 569] 0	25.0	363	0	0	183	linear	8ddb00
[2024/8/7 9:27:37 569] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:27:37 569] en	op_type	m_chn	now
[2024/8/7 9:27:37 569] 0	1	1	1
[2024/8/7 9:27:37 585] 
[2024/8/7 9:27:37 585] [2.VI_info]:
[2024/8/7 9:27:37 585] chn	TotalSize	ActiveSize
[2024/8/7 9:27:37 585] 0	5040*2246	3848*2166
[2024/8/7 9:27:37 586] 1	   0*   0	   0*   0
[2024/8/7 9:27:37 586] [3.MIPI_info]:
[2024/8/7 9:27:37 586] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:27:37 601] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:27:37 601] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:27:37 601] [4.Cut_info]:
[2024/8/7 9:27:37 601] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:27:37 601] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:27:37 617] vicu	0	1	1	2	3840	2160	  
[2024/8/7 9:27:37 617] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:27:37 617] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:27:37 617] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:27:37 617] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:27:37 617] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:27:37 633] [5.IB(isp buffer info)]:
[2024/8/7 9:27:37 633] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:27:37 633] PoolId  Count  Size
[2024/8/7 9:27:37 649] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:37 649] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:37 649] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:37 667] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:37 667] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:37 681] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:37 682] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:27:37 682] [1970-01-01 00:00:21] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 697] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 697] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:37 713] ble_slave_gap_event->type=3
[2024/8/7 9:27:37 713] connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:27:37 729] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 745] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 761] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 777] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 793] [1970-01-01 00:00:22] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:37 793] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 809] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:37 809] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 825] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:37 825] [01-01 18:12:26 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:27:37 825] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:27:37 841] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:27:37 841] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:27:37 841] 0       0         0          1          4       
[2024/8/7 9:27:37 857] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:27:37 857]      --265--            --264--                                               
[2024/8/7 9:27:37 873] Count      Line     Count      Line     
[2024/8/7 9:27:37 873] 272        480      657        560      
[2024/8/7 9:27:37 873] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:27:37 889] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:27:37 889] 0   3840   2160    H265  0      0        0           163       983039     1        	
[2024/8/7 9:27:37 905] 1   640    360     H265  0      0        0           106       43194      6        	
[2024/8/7 9:27:37 905] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:27:37 921] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:27:37 921] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:27:37 937] 0   Y      163      0       0       15       0        163      163      226       60988         59230    111734   64561    12      
[2024/8/7 9:27:37 953] 1   Y      106      0       3       1        0        106      106      227       2547          1932     26838    2994     7       
[2024/8/7 9:27:37 953] 3   N      0        0       0       1        0        0        0        228       0             0        0        0        0       
[2024/8/7 9:27:38 001] [1970-01-01 00:00:22] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:38 017] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:38 017] ble_slave_gap_event->type=4
[2024/8/7 9:27:38 017] connection update request
[2024/8/7 9:27:38 033] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:38 033] ble_slave_gap_event->type=14
[2024/8/7 9:27:38 049] subscribe event; conn_handle=1 attr_handle=23 reason=1 prevn=0 curn=1 previ=0 curi=0
[2024/8/7 9:27:38 049] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:27:38 049] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:38 065] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:38 065] ble_slave_gap_event->type=3
[2024/8/7 9:27:38 081] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:27:38 097] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:38 098] [01-01 18:12:27 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:38 098] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:38 113] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:38 113] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:38 130] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:38 130] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:38 130] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:38 145] [01-01 18:12:27 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:38 145] [01-01 18:12:27 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:38 145] [01-01 18:12:27 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:38 161] [01-01 18:12:27 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:38 161] [01-01 18:12:27 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:38 177] [01-01 18:12:27 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:38 177] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:38 193] [01-01 18:12:27 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:38 209] [01-01 18:12:27 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:38 209] [01-01 18:12:27 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:38 225] [01-01 18:12:27 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:38 225] gethostbyname_r error: Unknown host
[2024/8/7 9:27:38 225] [01-01 18:12:27 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:38 241] [01-01 18:12:27 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:38 241] [01-01 18:12:27 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:38 257] [01-01 18:12:27 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:38 257] [01-01 18:12:27 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:38 273] [01-01 18:12:27 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:38 273] [01-01 18:12:27 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:38 289] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:38 289] [01-01 18:12:27 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:27:38 497] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:38 497] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:38 497] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:38 497] Len=20 step 0
[2024/8/7 9:27:38 513] att=0x0 0x21 0x20 0x1 0xb6 0x5d 0xfb 0xd3 0x7e 0x1b 0x9a 0xa1 0x72 0x2a 0xdb 0x90 0xd4 0x90 0x87 0x3d 
[2024/8/7 9:27:38 513]  RCVS len:20
[2024/8/7 9:27:38 513] XmBleReadBuf 20:
[2024/8/7 9:27:38 513] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:38 529] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:38 529] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:38 545] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:38 545] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:38 545] [01-01 18:12:27 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:38 561] [01-01 18:12:27 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:38 561] [01-01 18:12:27 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:38 561] bt_rev_raw 20
[2024/8/7 9:27:38 577] 00 21 20 01 b6 5d fb d3 7e 1b 9a a1 72 2a db 90 d4 90 87 3d 
[2024/8/7 9:27:38 577] [01-01 18:12:27 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:27:38 592] [01-01 18:12:27 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:38 593] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:38 609] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:38 609] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:38 609] Len=17 step 0
[2024/8/7 9:27:38 625] att=0x1 0xa3 0x96 0x5f 0xa1 0xf5 0xa7 0xb5 0xc7 0x13 0x35 0x90 0x92 0x60 0x13 0xb 0x39 
[2024/8/7 9:27:38 625]  RCVS len:17
[2024/8/7 9:27:38 625] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:38 625] XmBleReadBuf 17:
[2024/8/7 9:27:38 641] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:38 641] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:38 641] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:38 657] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:27:38 657] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:27:38 673] [01-01 18:12:27 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:27:38 673] [01-01 18:12:27 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:38 673] [01-01 18:12:27 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:38 673] bt_rev_raw 17
[2024/8/7 9:27:38 689] 01 a3 96 5f a1 f5 a7 b5 c7 13 35 90 92 60 13 0b 39 
[2024/8/7 9:27:38 689] [01-01 18:12:27 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:27:38 689] ble rev data 33
[2024/8/7 9:27:38 706] 01 b6 5d fb d3 7e 1b 9a a1 72 2a db 90 d4 90 87 3d a3 96 5f a1 f5 a7 b5 c7 13 35 90 92 60 13 0b 39 
[2024/8/7 9:27:38 706] [01-01 18:12:27 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:27:38 706] ble decryped data 16
[2024/8/7 9:27:38 722] 00 00 00 01 00 00 00 00 00 00 00 00 92 69 00 00 
[2024/8/7 9:27:38 722] [01-01 18:12:27 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:27:38 738] [01-01 18:12:27 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x0 
[2024/8/7 9:27:38 738] [01-01 18:12:27 TUYA N][tuya_ble_data_handler.c:451] tuya_ble_handle_dev_infor_req state:0, pkg_len:20
[2024/8/7 9:27:38 738] [01-01 18:12:27 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:27:38 754] [01-01 18:12:27 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:27:38 754] [01-01 18:12:27 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:27:38 770] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:27:38 770] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:4, send_data:16
[2024/8/7 9:27:38 770] tuya_hal_bt_send 20
[2024/8/7 9:27:38 786] 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:27:38 786] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:38 786] 0 81 1 30 1 57 27 a7 5 d4 d0 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:27:38 802] XmBleSendBuf 20: 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58
[2024/8/7 9:27:38 802] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:38 802] ble_slave_gap_event->type=13
[2024/8/7 9:27:38 817] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:38 817] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:38 817] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:38 834] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:38 834] tuya_hal_bt_send 20
[2024/8/7 9:27:38 834] 01 3d 02 e4 6c 68 54 e8 b5 39 bd 20 48 fb 9b ce e8 5f 34 fd 
[2024/8/7 9:27:38 849] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:38 849] 1 3d 2 e4 6c 68 54 e8 b5 39 bd 20 48 fb 9b ce e8 5f 34 fd 
[2024/8/7 9:27:38 849] XmBleSendBuf 20: 01 3d 02 e4 6c 68 54 e8 b5 39 bd 20 48 fb 9b ce e8 5f 34 fd
[2024/8/7 9:27:38 864] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:38 864] ble_slave_gap_event->type=13
[2024/8/7 9:27:38 864] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:38 864] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:38 880] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:38 880] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:38 880] tuya_hal_bt_send 20
[2024/8/7 9:27:38 896] 02 88 be 47 f2 35 02 4b 08 9a d6 04 e4 39 27 42 45 4f be a0 
[2024/8/7 9:27:38 896] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:38 896] 2 88 be 47 f2 35 2 4b 8 9a d6 4 e4 39 27 42 45 4f be a0 
[2024/8/7 9:27:38 912] XmBleSendBuf 20: 02 88 be 47 f2 35 02 4b 08 9a d6 04 e4 39 27 42 45 4f be a0
[2024/8/7 9:27:38 912] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:38 912] ble_slave_gap_event->type=13
[2024/8/7 9:27:38 929] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:38 929] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:38 929] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:38 945] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:38 945] [01-01 18:12:27 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:38 945] tuya_hal_bt_send 20
[2024/8/7 9:27:38 961] 03 74 79 1d 6c 69 4d 1a e7 be 28 df 79 ed 62 27 f9 49 74 49 
[2024/8/7 9:27:38 961] [01-01 18:12:27 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:38 976] 3 74 79 1d 6c 69 4d 1a e7 be 28 df 79 ed 62 27 f9 49 74 49 
[2024/8/7 9:27:38 976] XmBleSendBuf 20: 03 74 79 1d 6c 69 4d 1a e7 be 28 df 79 ed 62 27 f9 49 74 49
[2024/8/7 9:27:38 976] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:38 977] ble_slave_gap_event->type=13
[2024/8/7 9:27:38 993] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:38 993] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:38 993] [01-01 18:12:27 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:39 009] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 009] [01-01 18:12:28 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:39 024] tuya_hal_bt_send 20
[2024/8/7 9:27:39 025] 04 00 a2 46 10 b7 4b 81 ba df 26 55 63 a8 92 94 b7 9a c7 b8 
[2024/8/7 9:27:39 025] [01-01 18:12:28 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:39 042] 4 0 a2 46 10 b7 4b 81 ba df 26 55 63 a8 92 94 b7 9a c7 b8 
[2024/8/7 9:27:39 042] XmBleSendBuf 20: 04 00 a2 46 10 b7 4b 81 ba df 26 55 63 a8 92 94 b7 9a c7 b8
[2024/8/7 9:27:39 042] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:39 042] ble_slave_gap_event->type=13
[2024/8/7 9:27:39 057] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:39 057] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:39 057] [01-01 18:12:28 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:39 073] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 089] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:39 089] [01-01 18:12:28 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:39 089] tuya_hal_bt_send 20
[2024/8/7 9:27:39 104] 05 7a 32 1f 18 f5 b4 97 03 08 64 41 80 81 54 9e 78 b2 a7 ff 
[2024/8/7 9:27:39 104] [01-01 18:12:28 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:39 104] 5 7a 32 1f 18 f5 b4 97 3 8 64 41 80 81 54 9e 78 b2 a7 ff 
[2024/8/7 9:27:39 121] XmBleSendBuf 20: 05 7a 32 1f 18 f5 b4 97 03 08 64 41 80 81 54 9e 78 b2 a7 ff
[2024/8/7 9:27:39 121] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:39 121] ble_slave_gap_event->type=13
[2024/8/7 9:27:39 137] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:39 137] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:39 137] [01-01 18:12:28 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:39 153] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 153] [01-01 18:12:28 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:18
[2024/8/7 9:27:39 153] tuya_hal_bt_send 19
[2024/8/7 9:27:39 169] 06 78 8e 15 ef c3 ed d3 19 e0 e1 7c ec bb f2 44 66 f1 5d 
[2024/8/7 9:27:39 169] [01-01 18:12:28 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:39 169] 6 78 8e 15 ef c3 ed d3 19 e0 e1 7c ec bb f2 44 66 f1 5d 
[2024/8/7 9:27:39 185] XmBleSendBuf 19: 06 78 8e 15 ef c3 ed d3 19 e0 e1 7c ec bb f2 44 66 f1 5d
[2024/8/7 9:27:39 185] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:39 185] ble_slave_gap_event->type=13
[2024/8/7 9:27:39 185] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:39 201] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:39 201] [01-01 18:12:28 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:39 217] [01-01 18:12:28 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:129, send_ret:0x0
[2024/8/7 9:27:39 217] [01-01 18:12:28 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:0
[2024/8/7 9:27:39 217] [1970-01-01 00:00:23] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 233] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:39 249] [01-01 18:12:28 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:39 249] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:39 265] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:39 266] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:39 266] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:39 281] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:39 281] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:39 281] [01-01 18:12:28 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:39 297] [01-01 18:12:28 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:39 297] [01-01 18:12:28 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:39 297] [01-01 18:12:28 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:39 313] [01-01 18:12:28 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:39 313] [01-01 18:12:28 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:39 329] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:39 345] [01-01 18:12:28 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:39 361] [01-01 18:12:28 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:39 361] [01-01 18:12:28 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:39 377] [01-01 18:12:28 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:39 377] gethostbyname_r error: Unknown host
[2024/8/7 9:27:39 377] [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:39 393] [01-01 18:12:28 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:39 393] [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:39 393] [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:39 409] [01-01 18:12:28 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:39 425] [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:39 426] [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:39 426] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:39 441] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 441] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:39 441] Len=20 step 0
[2024/8/7 9:27:39 457] att=0x0 0x51 0x20 0x2 0x16 0xc8 0xf4 0xc 0x1f 0x3a 0xe6 0xca 0x8d 0xa7 0xb8 0x49 0xf8 0x63 0x7c 0x1f 
[2024/8/7 9:27:39 457]  RCVS len:20
[2024/8/7 9:27:39 457] XmBleReadBuf 20:
[2024/8/7 9:27:39 457] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:39 457] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:39 473] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:39 473] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:39 489] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:39 489] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:39 505] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:39 506] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:39 506] bt_rev_raw 20
[2024/8/7 9:27:39 506] 00 51 20 02 16 c8 f4 0c 1f 3a e6 ca 8d a7 b8 49 f8 63 7c 1f 
[2024/8/7 9:27:39 521] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:27:39 521] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:39 537] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:39 537] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:39 537] Len=20 step 0
[2024/8/7 9:27:39 553] att=0x1 0xa7 0x94 0xe7 0x8c 0x78 0xa9 0x4a 0xe0 0x75 0x58 0xbc 0x2f 0xb 0xc 0x3 0x59 0xca 0xab 0xc0 
[2024/8/7 9:27:39 553]  RCVS len:20
[2024/8/7 9:27:39 553] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 553] XmBleReadBuf 20:
[2024/8/7 9:27:39 569] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:39 569] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:39 569] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:39 585] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:39 585] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:39 601] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:39 601] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:39 601] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:39 601] bt_rev_raw 20
[2024/8/7 9:27:39 617] 01 a7 94 e7 8c 78 a9 4a e0 75 58 bc 2f 0b 0c 03 59 ca ab c0 
[2024/8/7 9:27:39 617] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:27:39 633] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:39 633] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:39 649] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 649] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:39 649] Len=20 step 0
[2024/8/7 9:27:39 665] att=0x2 0xe2 0x6e 0xaa 0xd1 0x5f 0xe5 0xd1 0xd8 0xb2 0xc2 0xb2 0x5e 0x7a 0xbe 0xb 0xe8 0xfc 0x51 0x36 
[2024/8/7 9:27:39 665]  RCVS len:20
[2024/8/7 9:27:39 665] XmBleReadBuf 20:
[2024/8/7 9:27:39 665] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:39 681] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:39 681] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:39 681] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:39 697] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:39 697] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:39 713] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:39 713] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:39 729] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:39 729] bt_rev_raw 20
[2024/8/7 9:27:39 729] 02 e2 6e aa d1 5f e5 d1 d8 b2 c2 b2 5e 7a be 0b e8 fc 51 36 
[2024/8/7 9:27:39 744] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:27:39 744] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:39 760] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:39 760] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:39 760] Len=20 step 0
[2024/8/7 9:27:39 777] att=0x3 0x32 0x29 0x7b 0xb0 0xa3 0xbd 0x70 0x60 0x4d 0x9e 0x6e 0x1d 0x41 0xa1 0x9c 0x8c 0xe5 0xa3 0x9a 
[2024/8/7 9:27:39 777]  RCVS len:20
[2024/8/7 9:27:39 777] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 777] XmBleReadBuf 20:
[2024/8/7 9:27:39 792] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:39 792] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:39 792] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:39 809] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:39 809] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:39 825] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:39 825] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:39 825] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:39 825] bt_rev_raw 20
[2024/8/7 9:27:39 841] 03 32 29 7b b0 a3 bd 70 60 4d 9e 6e 1d 41 a1 9c 8c e5 a3 9a 
[2024/8/7 9:27:39 841] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:27:39 857] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:39 857] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:39 857] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:39 872] Len=8 step 0
[2024/8/7 9:27:39 872] att=0x4 0xf2 0x95 0x4a 0x27 0x2a 0x26 0xc5 
[2024/8/7 9:27:39 872]  RCVS len:8
[2024/8/7 9:27:39 872] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:39 872] XmBleReadBuf 8:
[2024/8/7 9:27:39 889] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:39 889] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:39 889] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:39 905] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 16 rcount 16 offset 0 ---
[2024/8/7 9:27:39 905] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 16 ---
[2024/8/7 9:27:39 921] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x9]
[2024/8/7 9:27:39 921] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:39 921] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:39 921] bt_rev_raw 8
[2024/8/7 9:27:39 937] 04 f2 95 4a 27 2a 26 c5 
[2024/8/7 9:27:39 937] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:5, pack_len:7, total_len:81
[2024/8/7 9:27:39 937] ble rev data 81
[2024/8/7 9:27:39 953] 02 16 c8 f4 0c 1f 3a e6 ca 8d a7 b8 49 f8 63 7c 1f a7 94 e7 8c 78 a9 4a e0 75 58 bc 2f 0b 0c 03 59 ca ab c0 e2 6e aa d1 5f e5 d1 d8 b2 c2 b2 5e 7a be 0b e8 fc 51 36 32 29 7b b0 a3 bd 70 60 4d 
[2024/8/7 9:27:39 969] 9e 6e 1d 41 a1 9c 8c e5 a3 9a f2 95 4a 27 2a 26 c5 
[2024/8/7 9:27:39 969] ble decryped data 64
[2024/8/7 9:27:39 984] 00 00 00 02 00 00 00 00 00 01 00 2c 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca 1e 00 00 00 00 00 00 
[2024/8/7 9:27:39 984] [01-01 18:12:28 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:27:40 002] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x1 
[2024/8/7 9:27:40 002] [01-01 18:12:28 TUYA D][tuya_ble_api.c:573] conn monitor timer stopped
[2024/8/7 9:27:40 002] [01-01 18:12:28 TUYA N][tuya_ble_api.c:1464] ble set conn stat:3
[2024/8/7 9:27:40 018] [01-01 18:12:28 TUYA N][tuya_ble_data_handler.c:367] PAIR_REQ ok:0
[2024/8/7 9:27:40 018] [01-01 18:12:28 TUYA N][tuya_ble_data_handler.c:342] ble_time_req start...
[2024/8/7 9:27:40 033] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:348] no need to query time. network stat:1, work stat:0
[2024/8/7 9:27:40 033] [01-01 18:12:28 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:27:40 033] [01-01 18:12:28 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:40 049] [01-01 18:12:28 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:40 049] tuya_hal_bt_send 20
[2024/8/7 9:27:40 065] 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:27:40 065] [01-01 18:12:28 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:40 065] 0 21 31 2 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:27:40 081] XmBleSendBuf 20: 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c
[2024/8/7 9:27:40 081] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:40 081] ble_slave_gap_event->type=13
[2024/8/7 9:27:40 081] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:40 097] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:40 097] [01-01 18:12:28 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:40 097] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:16 ---
[2024/8/7 9:27:40 113] [01-01 18:12:28 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:27:40 113] tuya_hal_bt_send 17
[2024/8/7 9:27:40 113] 01 6c de b6 87 53 56 8f af 97 50 f6 4c 03 9b 53 db 
[2024/8/7 9:27:40 129] [01-01 18:12:28 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:40 129] 1 6c de b6 87 53 56 8f af 97 50 f6 4c 3 9b 53 db 
[2024/8/7 9:27:40 129] XmBleSendBuf 17: 01 6c de b6 87 53 56 8f af 97 50 f6 4c 03 9b 53 db
[2024/8/7 9:27:40 145] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:40 145] ble_slave_gap_event->type=13
[2024/8/7 9:27:40 145] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:40 145] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:40 161] [01-01 18:12:28 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:40 161] [1970-01-01 00:00:24] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time24509
[2024/8/7 9:27:40 177] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 177] [01-01 18:12:28 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:27:40 193] [01-01 18:12:28 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:1
[2024/8/7 9:27:40 193] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 209] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:40 209] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 225] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 225] [01-01 18:12:28 TUYA D][tuya_ble_api.c:1376] nw stat change:1->1, rpt to app.
[2024/8/7 9:27:40 241] [01-01 18:12:28 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:27:40 241] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:40 241] Len=20 step 0
[2024/8/7 9:27:40 257] att=0x0 0x61 0x20 0x2 0x4 0x21 0x13 0xea 0x8c 0x72 0x8f 0x46 0x89 0x50 0x83 0x61 0x71 0xb1 0x94 0x85 
[2024/8/7 9:27:40 257]  RCVS len:20
[2024/8/7 9:27:40 257] XmBleReadBuf 20:
[2024/8/7 9:27:40 257] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:40 273] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:40 273] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:40 273] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:40 289] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:40 289] [01-01 18:12:28 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:40 305] [01-01 18:12:28 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:40 305] [01-01 18:12:28 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:40 305] bt_rev_raw 20
[2024/8/7 9:27:40 305] 00 61 20 02 04 21 13 ea 8c 72 8f 46 89 50 83 61 71 b1 94 85 
[2024/8/7 9:27:40 321] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:27:40 321] [01-01 18:12:28 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:40 337] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:40 337] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:40 337] Len=20 step 0
[2024/8/7 9:27:40 353] att=0x1 0x1b 0xa7 0xce 0xb2 0x3e 0x4b 0x2 0x36 0x74 0x14 0xf5 0x43 0xd8 0x9a 0xdd 0x71 0x33 0x50 0x88 
[2024/8/7 9:27:40 353]  RCVS len:20
[2024/8/7 9:27:40 353] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 369] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:40 369] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:40 385] Len=20 step 0
[2024/8/7 9:27:40 385] att=0x2 0x12 0xda 0x42 0x19 0x75 0xc1 0x8b 0xc1 0x92 0xf7 0x8c 0xfc 0x59 0xaf 0xf 0x71 0xe8 0xb6 0x10 
[2024/8/7 9:27:40 385]  RCVS len:20
[2024/8/7 9:27:40 401] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 401] XmBleReadBuf 20:
[2024/8/7 9:27:40 401] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:40 401] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:40 416] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:40 417] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:40 417] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:40 433] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:40 433] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:40 449] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:40 449] bt_rev_raw 20
[2024/8/7 9:27:40 449] 01 1b a7 ce b2 3e 4b 02 36 74 14 f5 43 d8 9a dd 71 33 50 88 
[2024/8/7 9:27:40 464] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:27:40 464] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:40 480] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:40 480] XmBleReadBuf 20:
[2024/8/7 9:27:40 480] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:40 480] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:40 496] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:40 496] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:40 496] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:40 513] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:40 513] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:40 528] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:40 528] bt_rev_raw 20
[2024/8/7 9:27:40 528] 02 12 da 42 19 75 c1 8b c1 92 f7 8c fc 59 af 0f 71 e8 b6 10 
[2024/8/7 9:27:40 544] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:27:40 544] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:40 560] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:40 560] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:40 560] Len=20 step 0
[2024/8/7 9:27:40 577] att=0x3 0xc1 0xea 0xbb 0x6e 0xc6 0xc7 0xc2 0x63 0x92 0x38 0x1a 0xa6 0xff 0xb5 0x97 0x73 0x29 0x78 0xda 
[2024/8/7 9:27:40 577]  RCVS len:20
[2024/8/7 9:27:40 577] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 593] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 593] [01-01 18:12:29 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:27:40 609] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:40 610] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:40 611] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:40 626] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:40 626] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:40 626] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:40 641] [01-01 18:12:29 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:40 641] [01-01 18:12:29 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:40 641] [01-01 18:12:29 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:40 657] [01-01 18:12:29 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:40 657] [01-01 18:12:29 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:40 673] [01-01 18:12:29 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:40 673] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:27:40 705] [01-01 18:12:29 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:40 705] [01-01 18:12:29 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:27:40 706] [01-01 18:12:29 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:40 721] [01-01 18:12:29 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:27:40 721] gethostbyname_r error: Unknown host
[2024/8/7 9:27:40 737] [01-01 18:12:29 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:27:40 737] [01-01 18:12:29 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:27:40 737] [01-01 18:12:29 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:27:40 753] [01-01 18:12:29 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:27:40 753] [01-01 18:12:29 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:27:40 769] [01-01 18:12:29 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:27:40 769] [01-01 18:12:29 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:27:40 785] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:27:40 785] XmBleReadBuf 20:
[2024/8/7 9:27:40 785] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:40 785] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:40 801] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:40 801] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:40 801] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:40 817] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0x[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:27:40 817] d] fr_len[0x15]
[2024/8/7 9:27:40 832] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:40 832] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:40 832] bt_rev_raw 20
[2024/8/7 9:27:40 833] 03 c1 ea bb 6e c6 c7 c2 63 92 38 1a a6 ff b5 97 73 29 78 da 
[2024/8/7 9:27:40 849] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:27:40 865] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:40 865] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:40 865] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:40 865] Len=20 step 0
[2024/8/7 9:27:40 881] att=0x4 0x3e 0x41 0xe1 0x3e 0x1 0x10 0xaf 0x36 0x8f 0xa0 0x43 0x26 0x42 0x32 0x21 0xad 0xd5 0xc6 0x47 
[2024/8/7 9:27:40 881]  RCVS len:20
[2024/8/7 9:27:40 881] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 897] XmBleReadBuf 20:
[2024/8/7 9:27:40 897] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:40 897] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:40 897] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:40 914] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:40 914] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:40 929] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:40 929] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:40 945] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:40 945] bt_rev_raw 20
[2024/8/7 9:27:40 945] 04 3e 41 e1 3e 01 10 af 36 8f a0 43 26 42 32 21 ad d5 c6 47 
[2024/8/7 9:27:40 961] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:5, pack_len:19, total_len:93
[2024/8/7 9:27:40 961] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:40 961] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:40 977] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:40 977] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:40 977] Len=5 step 0
[2024/8/7 9:27:40 993] att=0x5 0xa0 0x11 0x56 0x2b 
[2024/8/7 9:27:40 994]  RCVS len:5
[2024/8/7 9:27:40 994] XmBleReadBuf 5:
[2024/8/7 9:27:40 994] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:40 994] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:41 011] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:41 011] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 13 rcount 13 offset 0 ---
[2024/8/7 9:27:41 011] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 13 ---
[2024/8/7 9:27:41 025] [01-01 18:12:29 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x6]
[2024/8/7 9:27:41 025] [01-01 18:12:29 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:41 041] [01-01 18:12:29 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:41 041] bt_rev_raw 5
[2024/8/7 9:27:41 041] 05 a0 11 56 2b 
[2024/8/7 9:27:41 041] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:6, pack_len:4, total_len:97
[2024/8/7 9:27:41 057] ble rev data 97
[2024/8/7 9:27:41 073] 02 04 21 13 ea 8c 72 8f 46 89 50 83 61 71 b1 94 85 1b a7 ce b2 3e 4b 02 36 74 14 f5 43 d8 9a dd 71 33 50 88 12 [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:41 073] da 42 19 75 c1 8b c1 92 f7 8c fc 59 af 0f 71 e8 b6 10 c1 ea bb 6e c6 c7 c2 63 92 
[2024/8/7 9:27:41 089] 38 1a a6 ff b5 97 73 29 78 da 3e 41 e1 3e 01 10 af 36 8f a0 43 26 42 32 21 ad d5 c6 47 a0 11 56 2b 
[2024/8/7 9:27:41 089] ble decryped data 80
[2024/8/7 9:27:41 105] 00 00 00 03 00 00 00 00 00 21 00 41 7b 22 70 77 64 22 3a 22 78 6d 35 31 32 35 32 30 22 2c 22 73 73 69 64 22 3a 22 58 69 61 6f 6d 69 5f 46 31 44 43 22 2c 22 74 6f 6b 65 6e 22 3a 22 41 59 45 37 
[2024/8/7 9:27:41 105] 36 68 4c 6c 6a 53 36 66 34 53 22 7d 00 57 c1 00 
[2024/8/7 9:27:41 121] [01-01 18:12:29 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:41 121] [01-01 18:12:29 TUYA D][tuya_ble_data_ha[atbm_log]:[ieee80211_csa_cancel][mon.eth2]:[0][0]
[2024/8/7 9:27:41 121] ndler.c:675] Parse BT Cmd:0x21 
[2024/8/7 9:27:41 137] [01-01 18:12:29 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:33 Has No def operate
[2024/8/7 9:27:41 137] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:13 ---
[2024/8/7 9:27:41 152] [01-01 18:12:29 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:33
[2024/8/7 9:27:41 153] [01-01 18:12:29 TUYA N][bt_netcfg.c:63] Rev Net Cfg:{"pwd":"xm512520","ssid":"Xiaomi_F1DC","token":"AYE76hLljS6f4S"}
[2024/8/7 9:27:41 168] [01-01 18:12:29 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:41 169] [01-01 18:12:29 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x21 encrpyt:2
[2024/8/7 9:27:41 169] bt_ack_uncrypt 1
[2024/8/7 9:27:41 169] 00 
[2024/8/7 9:27:41 184] [01-01 18:12:29 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:41 185] [01-01 18:12:29 TUYA N][bt_netcfg.c:98] cfg ssid:Xiaomi_F1DC, passwd:xm512520, token:AYE76hLljS6f4S
[2024/8/7 9:27:41 201] [01-01 18:12:29 TUYA D][tuya_devos_netcfg.c:464] concurrent Netcfg Finish type:0x10004 ssid:Xiaomi_F1DC passwd:xm512520 cur_netcfg_type:0
[2024/8/7 9:27:41 201] [01-01 18:12:29 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:41 216] tuya_hal_bt_send 20
[2024/8/7 9:27:41 216] 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:27:41 217] [01-01 18:12:29 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:41 233] 0 21 32 2 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:27:41 233] XmBleSendBuf 20: 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7
[2024/8/7 9:27:41 233] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:41 249] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:41 249] ble_slave_gap_event->type=13
[2024/8/7 9:27:41 249] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:41 249] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:41 264]  ---
[2024/8/7 9:27:41 265] [01-01 18:12:29 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:41 281] [01-01 18:12:29 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:27:41 281] tuya_hal_bt_send 17
[2024/8/7 9:27:41 281] 01 02 3b e2 a3 99 01 49 ef ca fa 4a 8b 31 ff fe 19 
[2024/8/7 9:27:41 282] [01-01 18:12:29 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:41 297] 1 2 3b e2 a3 99 1 49 ef ca fa 4a 8b 31 ff fe 19 
[2024/8/7 9:27:41 297] XmBleSendBuf 17: 01 02 3b e2 a3 99 01 49 ef ca fa 4a 8b 31 ff fe 19
[2024/8/7 9:27:41 297] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:41 297] ble_slave_gap_event->type=13
[2024/8/7 9:27:41 313] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:41 313] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:41 313] [01-01 18:12:29 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:41 328] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:41 328] [01-01 18:12:29 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:27:41 345] [01-01 18:12:29 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait
[2024/8/7 9:27:41 345] [01-01 18:12:29 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10002
[2024/8/7 9:27:41 361] [01-01 18:12:29 TUYA D][ap_netcfg.c:950] ap cfg stop:65538
[2024/8/7 9:27:41 361] [01-01 18:12:29 TUYA D][uni_thread.c:310] Del Thrd:udp_ap_v3
[2024/8/7 9:27:41 361] Received SIGTERM
[2024/8/7 9:27:41 361] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:27:41 377] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:41 393] [1970-01-01 00:00:25] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:41 393] [1970-01-01 00:00:25] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:41 409] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:41 409] [01-01 18:12:30 TUYA D][ap_netcfg.c:553] wf_ap_stop:0
[2024/8/7 9:27:41 425] [01-01 18:12:30 TUYA N][ap_netcfg.c:172] exit ap_net_cfg task
[2024/8/7 9:27:41 425] [01-01 18:12:30 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10100
[2024/8/7 9:27:41 425] [01-01 18:12:30 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10004
[2024/8/7 9:27:41 441] [01-01 18:12:30 TUYA N][tuya_ble_api.c:439] update bound stat:1
[2024/8/7 9:27:41 441] [01-01 18:12:30 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:0
[2024/8/7 9:27:41 457] [01-01 18:12:30 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:27:41 457] [01-01 18:12:30 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:27:41 457] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:41 473] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:41 473] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:41 488] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:41 489] [01-01 18:12:30 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:27:41 489] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:41 504] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:41 504] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:41 505] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:41 521] [01-01 18:12:30 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:27:41 521] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:27:41 536] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:41 536] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:41 536] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:41 553] [01-01 18:12:30 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:27:41 553] [01-01 18:12:30 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:27:41 553] [01-01 18:12:30 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:27:41 568] [01-01 18:12:30 TUYA N][tuya_devos_activate.c:774] already inited
[2024/8/7 9:27:41 586] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:27:41 586] curr event:5 
[2024/8/7 9:27:41 586] IPC_APP_Notify_LED_Sound_Status_CB line(491) -------------------------- IPC_CONNECTING_WIFI(5)
[2024/8/7 9:27:41 602] [1970-01-01 00:00:26] tuya_ipc_system_control_demo.c(492) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECTING, 0, 0, 0, 1))
[2024/8/7 9:27:41 618] [1970-01-01 00:00:26] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/RouterConnect_english.pcm]
[2024/8/7 9:27:41 618] [1970-01-01 00:00:26] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:27:41 633] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:27:41 633] --- tracepoint MainApp.c,ConfigTimer(372): g_WifiConectStatuts 1 ---
[2024/8/7 9:27:41 650] [1970-01-01 00:00:26] MainApp.c(373) <ConfigTimer>: ConfigTimer exit ----
[2024/8/7 9:27:41 650] [01-01 18:12:30 TUYA I][bt_ext_porting.c:618] [TUYA-BTUART]ble_monitor_thread exit
[2024/8/7 9:27:41 667] [01-01 18:12:30 TUYA D][uni_thread.c:268] Thread:udp_ap_v3 Exec Finish. Set to Del Stat
[2024/8/7 9:27:41 667] [01-01 18:12:30 TUYA D][uni_thread.c:125] del list not empty...deleting 0xf7d114, next 0xf43fd0
[2024/8/7 9:27:41 682] [01-01 18:12:30 TUYA D][uni_thread.c:132] Final Free Thread:udp_ap_v3, is_self:1
[2024/8/7 9:27:41 682] [01-01 18:12:30 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:27:41 682] [01-01 18:12:30 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:27:41 697] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:27:41 840] [atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:27:42 113] [atbm_log]:[eth2] change to [2]
[2024/8/7 9:27:42 129] [atbm_log]:[eth2] has been disabled
[2024/8/7 9:27:42 369] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 ++++++++ 
[2024/8/7 9:27:42 384] [atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 --------- 
[2024/8/7 9:27:42 384] [atbm_log]:atbm_hw_scan:if_id(0)
[2024/8/7 9:27:42 449] [atbm_log]:atbm_hw_scan:scan, delay suspend
[2024/8/7 9:27:42 449] [atbm_log]:scan start band(0),(14)
[2024/8/7 9:27:42 576] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:27:42 592] set basic_indicator_onoff:0 
[2024/8/7 9:27:42 592] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(257) <IPC_APP_set_basic_indicator_onoff>: Get BasicIndicator suc,gpio value=[0x0c]
[2024/8/7 9:27:42 608] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 608] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:42 624] set basic_indicator_onoff:1 
[2024/8/7 9:27:42 624] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 641] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:42 641] set basic_indicator_onoff:0 
[2024/8/7 9:27:42 641] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 656] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:42 656] set basic_indicator_onoff:1 
[2024/8/7 9:27:42 672] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 672] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:42 672] set basic_indicator_onoff:0 
[2024/8/7 9:27:42 688] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 688] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:42 704] set basic_indicator_onoff:1 
[2024/8/7 9:27:42 706] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 720] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:42 720] set basic_indicator_onoff:0 
[2024/8/7 9:27:42 720] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 737] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:42 737] set basic_indicator_onoff:1 
[2024/8/7 9:27:42 753] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 753] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:42 753] set basic_indicator_onoff:0 
[2024/8/7 9:27:42 769] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 770] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:42 770] set basic_indicator_onoff:1 
[2024/8/7 9:27:42 785] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 801] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:42 801] [1970-01-01 00:00:27] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:42 801] set basic_indicator_onoff:0 
[2024/8/7 9:27:42 817] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 817] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:42 833] [01-01 18:12:31 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:27:42 833] set basic_indicator_onoff:1 
[2024/8/7 9:27:42 849] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:42 849] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:42 865] g_AudioTipsList.size() enable: 0[01-01 18:12:32 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:27:43 873] [atbm_log]:hw_priv->scan.status 0
[2024/8/7 9:27:43 873] [atbm_log]:atbm_scan_work:end(0)
[2024/8/7 9:27:43 889] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:27:43 889] [atbm_log]:authen:(a4:a9:30:ce:5e:66),ssid(Xiaomi_F1DC)
[2024/8/7 9:27:43 905] [atbm_log]:authenticate[a4:a9:30:ce:5e:66]:[0][1]
[2024/8/7 9:27:43 905] [atbm_log]:eth2: authenticate with a4:a9:30:ce:5e:66 (try 1) (1)(0)
[2024/8/7 9:27:43 905] [atbm_log]:[STA] Join DTIM: 1, interval: 100
[2024/8/7 9:27:43 921] [atbm_log]:[TX]:authen, delay suspend
[2024/8/7 9:27:43 921] [atbm_log]:eth2: authenticated
[2024/8/7 9:27:43 937] [atbm_log]:work:flush sta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:43 937] [atbm_log]:sta has been insert(0)
[2024/8/7 9:27:43 937] [atbm_log]:wk->assoc.use_he 1 1++
[2024/8/7 9:27:43 937] [atbm_log]:flush sta(0):
[2024/8/7 9:27:44 001] [atbm_log]:eth2: associated
[2024/8/7 9:27:44 001] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:27:44 001] [atbm_log]:eth2:free authen bss --
[2024/8/7 9:27:44 017] [atbm_log]:is_wifi6_ap++
[2024/8/7 9:27:44 019] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:27:44 019] [atbm_log]:eth2  WMM AC=0 acm=0 aifs=2 cWmin=3 cWmax=7 txop=47 uapsd=0
[2024/8/7 9:27:44 033] [atbm_log]:eth2  WMM AC=1 acm=0 aifs=2 cWmin=7 cWmax=15 txop=94 uapsd=0
[2024/8/7 9:27:44 033] [atbm_log]:eth2  WMM AC=2 acm=0 aifs=3 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:27:44 049] [atbm_log]:eth2  WMM AC=3 acm=0 aifs=7 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:27:44 049] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:27:44 065] [atbm_log]:[a4:a9:30:ce:5e:66]:20M channel
[2024/8/7 9:27:44 065] [atbm_log]:atbm_bss_info_changed:chatype(1),channelNumber(3)
[2024/8/7 9:27:44 128] [atbm_log]:BssidColor[34]
[2024/8/7 9:27:44 129] [atbm_log]:[STA] color 34, he_support_flag: 53
[2024/8/7 9:27:44 129] [atbm_log]:==>connect wifi6 AP open AX, set BA WIN short
[2024/8/7 9:27:44 144] [atbm_log]:[eth2] Waiting Txq Ready[1]
[2024/8/7 9:27:44 257] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:27:44 273] [atbm_log]:[eth2]:dtim changed [0]->[1]
[2024/8/7 9:27:44 273] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:27:44 273] NOHZ: local_softirq_pending 08
[2024/8/7 9:27:44 289] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:27:44 289] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:27:44 289] [atbm_log]:send htc qos null
[2024/8/7 9:27:44 289] [atbm_log]:om work(1)
[2024/8/7 9:27:44 545] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:27:44 545] [atbm_log]:send htc qos null
[2024/8/7 9:27:44 545] [atbm_log]:om work(2)
[2024/8/7 9:27:44 720] set basic_indicator_onoff:0 
[2024/8/7 9:27:44 739] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 739] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:44 739] set basic_indicator_onoff:1 
[2024/8/7 9:27:44 752] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 752] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:44 752] set basic_indicator_onoff:0 
[2024/8/7 9:27:44 769] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 769] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:44 784] 
[2024/8/7 9:27:44 785] set basic_indicator_onoff:1 
[2024/8/7 9:27:44 785] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 800] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:44 801] 
[2024/8/7 9:27:44 801] set basic_indicator_onoff:0 
[2024/8/7 9:27:44 817] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 819] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:44 819] set basic_indicator_onoff:1 
[2024/8/7 9:27:44 832] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 832] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:44 848] [1970-01-01 00:[atbm_log]:QosNUll Htc(807)
[2024/8/7 9:27:44 848] 00:28] xm_device[atbm_log]:send htc qos null
[2024/8/7 9:27:44 848] .c(499) <XM_SetA[atbm_log]:om work(3)
[2024/8/7 9:27:44 848] oStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:27:44 865] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:27:44 865] [1970-01-01 00:00:28] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time28469
[2024/8/7 9:27:44 865] set basic_indicator_onoff:0 
[2024/8/7 9:27:44 880] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 881] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:44 896] set basic_indicator_onoff:1 
[2024/8/7 9:27:44 896] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 912] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:44 912] [1970-01-01 00:00:28] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:44 912] set basic_indicator_onoff:0 
[2024/8/7 9:27:44 928] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 928] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:44 944] 
[2024/8/7 9:27:44 945] set basic_indicator_onoff:1 
[2024/8/7 9:27:44 945] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 960] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:44 960] set basic_indicator_onoff:0 
[2024/8/7 9:27:44 976] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 976] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:44 976] set basic_indicator_onoff:1 
[2024/8/7 9:27:44 992] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:44 992] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:44 992] set basic_indicator_onoff:0 
[2024/8/7 9:27:45 008] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:45 008] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:45 024] 
[2024/8/7 9:27:45 025] set basic_indicator_onoff:1 
[2024/8/7 9:27:45 025] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:45 040] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:45 040] set basic_indicator_onoff:0 
[2024/8/7 9:27:45 056] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:45 056] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:45 056] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:45 073] set basic_indicator_onoff:1 
[2024/8/7 9:27:45 073] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:45 089] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:45 089] set basic_indicator_onoff:[atbm_log]:QosNUll Htc(807)
[2024/8/7 9:27:45 089] [atbm_log]:send htc qos null
[2024/8/7 9:27:45 089] [atbm_log]:om work(4)
[2024/8/7 9:27:45 344] [atbm_log]:om done
[2024/8/7 9:27:45 472] [atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:27:45 472] [atbm_log]:aggtx stop queue
[2024/8/7 9:27:45 472] [atbm_log]:add to pending(2)(20)
[2024/8/7 9:27:45 489] [atbm_log]:dhcp work(1)
[2024/8/7 9:27:45 585] [atbm_log]:AMPDU[eth2]:action[2],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:45 585] [atbm_log]:activated addBA response timer on tid 0
[2024/8/7 9:27:45 601] [atbm_log]:aggtx wake queue
[2024/8/7 9:27:45 601] [atbm_log]:sta_hdr
[2024/8/7 9:27:45 601] [atbm_log]:switched off addBA timer for tid 0
[2024/8/7 9:27:45 601] [atbm_log]:Aggregation is on for tid 0
[2024/8/7 9:27:45 617] [atbm_log]:AMPDU[eth2]:action[4],tid[0],ssn[0],buff_size[64],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:45 617] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[6]
[2024/8/7 9:27:45 633] [atbm_log]:AMPDU[eth2]:action[0],tid[6],ssn[1],buff_size[64],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:45 634] [atbm_log]:Rx A-MPDU request on tid 6 result 0
[2024/8/7 9:27:45 649] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[0]
[2024/8/7 9:27:45 649] [atbm_log]:AMPDU[eth2]:action[0],tid[0],ssn[0],buff_size[64],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:45 649] [atbm_log]:Rx A-MPDU request on tid 0 result 0
[2024/8/7 9:27:45 665] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:27:45 760] [atbm_log]:dhcp done
[2024/8/7 9:27:45 761] [atbm_log]:dhcp work(1)
[2024/8/7 9:27:45 761] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:27:45 761] [atbm_log]:dhcp doneNOHZ: local_softirq_pending 08
[2024/8/7 9:27:45 808] route: SIOCDELRT: No such process
[2024/8/7 9:27:45 824] [atbm_log]:connecting done for waitting dhcp  
[2024/8/7 9:27:46 368] 0 
[2024/8/7 9:27:46 368] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 384] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:46 384] set basic_indicator_onoff:1 
[2024/8/7 9:27:46 384] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 400] [1970-01-01 00:00:29
[2024/8/7 9:27:46 400] [atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[5]
[2024/8/7 9:27:46 400] ] ==> XMSDK_Gpio[atbm_log]:<WIFI> rx ampdu ++ 
[2024/8/7 9:27:46 416] Write(31)[INFO]:[atbm_log]:AMPDU[eth2]:action[0],tid[5],ssn[3],buff_size[64],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:27:46 416]  port=[12],val=[1]
[2024/8/7 9:27:46 416] atbm_log]:napi schedule
[2024/8/7 9:27:46 416] 39m
[2024/8/7 9:27:46 432] set basic_indicator_onoff:0[atbm_log]:Rx A-MPDU request on tid 5 result 0
[2024/8/7 9:27:46 432] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 448] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:46 448] set basic_indicator_onoff:1 
[2024/8/7 9:27:46 448] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 465] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:46 465] set basic_indicator_onoff:0 
[2024/8/7 9:27:46 480] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 480] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:46 480] set basic_indicator_onoff:1 
[2024/8/7 9:27:46 497] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 497] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:46 513] set basic_indicator_onoff:0 
[2024/8/7 9:27:46 513] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 529] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:46 529] set basic_indicator_onoff:1 
[2024/8/7 9:27:46 529] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 545] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:46 545] set basic_indicator_onoff:0 
[2024/8/7 9:27:46 560] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 560] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:46 560] set basic_indicator_onoff:1 
[2024/8/7 9:27:46 577] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 577] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:46 593] set basic_indicator_onoff:0 
[2024/8/7 9:27:46 593] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 609] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:46 609] set basic_indicator_onoff:1 
[2024/8/7 9:27:46 609] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 625] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:46 625] set basic_indicator_onoff:0 
[2024/8/7 9:27:46 640] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 641] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:46 641] set basic_indicator_onoff:1 
[2024/8/7 9:27:46 656] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 656] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:46 656] curr event:6 
[2024/8/7 9:27:46 672] IPC_APP_Notify_LED_Sound_Status_CB line(497) -------------------------- IPC_CONNECT_WIFI_SUCCESS(6)
[2024/8/7 9:27:46 688] [1970-01-01 00:00:31] tuya_ipc_system_control_demo.c(498) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECT_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:27:46 688] [01-01 18:12:35 TUYA D][tuya_devos_netlink.c:313] wf connect success!
[2024/8/7 9:27:46 704] [01-01 18:12:35 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:27:46 704] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:27:46 720] [01-01 18:12:35 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:27:46 720] [01-01 18:12:35 TUYA E][mqtt_client.c:807] hand null.
[2024/8/7 9:27:46 720] set basic_indicator_onoff:0 
[2024/8/7 9:27:46 736] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:46 737] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:46 753] [01-01 18:12:35 TUYA D][tuya_iot_wired_wifi_api.c:584] wired wifi default stat:1,change:1
[2024/8/7 9:27:46 753] [01-01 18:12:35 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[2024/8/7 9:27:46 768] [01-01 18:12:35 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[2024/8/7 9:27:46 769] [01-01 18:12:35 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:27:46 769] dev id key: 16
[2024/8/7 9:27:46 784] c0 b9 30 cc 91 82 20 e0 27 d3 45 b3 ab 3c 27 bf 
[2024/8/7 9:27:46 784] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:27:46 785] [01-01 18:12:35 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:27:46 800] 2 1 6 3 2 1 a2 14 16 1 a2 0 1c 6a 97 74 ce 42 f4 54 8c 72 2e 92 d 9f a1 db 
[2024/8/7 9:27:46 800] [01-01 18:12:35 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:27:46 816] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 30 7b 27 8c c6 8b 14 13 8e 36 f6 75 73 7d 4b 
[2024/8/7 9:27:46 816] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:27:46 833] [01-01 18:12:35 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:27:46 833] [01-01 18:12:35 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:27:46 833] [01-01 18:12:35 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:27:46 848] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:46 848] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:46 864] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:46 864] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:46 864] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:46 880] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:46 880] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:46 880] [01-01 18:12:35 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:46 896] [01-01 18:12:35 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:46 896] [01-01 18:12:35 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:46 912] [01-01 18:12:35 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:27:46 912] [01-01 18:12:35 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:27:46 928] [01-01 18:12:35 TUYA D][iot_httpc.c:1435] sign_buffer:env=6f4S&region=AY&ts=20&uuid=uuidcaab27b0a838d239
[2024/8/7 9:27:46 928] [01-01 18:12:35 TUYA D][iot_httpc.c:1443] sign_base64_encode:93L2ThSjeOPaf7xhWMlFXe3QK6SBJVP7fuo77hJMjoE=
[2024/8/7 9:27:46 944] [01-01 18:12:35 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:27:46 976] [01-01 18:12:35 TUYA D][iot_httpc.c:1514] http_dns send: {"region":"AY","env":"6f4S","uuid":"uuidcaab27b0a838d239","ts":20,"sign":"93L2ThSjeOPaf7xhWMlFXe3QK6SBJVP7fuo77hJMjoE=","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:27:46 976] [01-01 18:12:35 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v2/url_config
[2024/8/7 9:27:46 992] [01-01 18:12:35 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:27:46 993] [01-01 18:12:35 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:27:47 008] [01-01 18:12:35 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:27:47 008] [01-01 18:12:35 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:27:47 024] [1970-01-01 00:00:31] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/ServerConnect_english.pcm]
[2024/8/7 9:27:47 024] [1970-01-01 00:00:31] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:27:47 040] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:27:47 040] [01-01 18:12:35 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:27:47 056] [01-01 18:12:35 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:47 057] [01-01 18:12:35 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:47 072] [01-01 18:12:35 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:47 072] [01-01 18:12:35 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:27:47 072] [01-01 18:12:35 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:47 088] set basic_indicator_onoff:1 
[2024/8/7 9:27:47 088] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:47 104] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:47 104] set basic_indicator_onoff:0 
[2024/8/7 9:27:47 104] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:47 120] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:47 120] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:47 136] [1970-01-01 00:00:31] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:47 136] set basic_indicator_onoff:1 
[2024/8/7 9:27:47 152] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:47 152] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:47 168] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:2
[2024/8/7 9:27:47 168] set basic_indicator_onoff:0 
[2024/8/7 9:27:47 168] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:47 184] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:47 184] [01-01 18:12:36 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:27:47 200] [01-01 18:12:36 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:47 200] set basic_indicator_onoff:1 
[2024/8/7 9:27:47 216] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:47 216] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:47 232] 
[2024/8/7 9:27:47 233] [01-01 18:12:36 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:27:47 233] [01-01 18:12:36 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:47 248] [01-01 18:12:36 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:47 248] [01-01 18:12:36 TUYA D][iot_httpc.c:1578] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216]
[2024/8/7 9:27:47 264] [01-01 18:12:36 TUYA D][iot_httpc.c:1579] mqttUrl:[m2.tuyacn.com:1883][121.5.96.167]
[2024/8/7 9:27:47 264] [01-01 18:12:36 TUYA D][iot_httpc.c:1602] httpsSelfUrl:[https://a2.tuyacn.com/d.json][42.192.31.36]
[2024/8/7 9:27:47 281] [01-01 18:12:36 TUYA D][iot_httpc.c:1603] mqttsSelfUrl:[m2.tuyacn.com:8883][121.5.96.167]
[2024/8/7 9:27:47 281] [01-01 18:12:36 TUYA D][iot_httpc.c:1670] ghostUrl:[baal.tuyacn.com:443][42.192.35.108]
[2024/8/7 9:27:47 297] [01-01 18:12:36 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:27:47 297] [01-01 18:12:36 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:47 297] [01-01 18:12:36 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:27:47 312] [01-01 18:12:36 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:27:47 312] [01-01 18:12:36 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:27:47 312] [01-01 18:12:36 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:27:47 328] [01-01 18:12:36 TUYA D][iot_httpc.c:1684] tls_ca_name:tls_ca0
[2024/8/7 9:27:47 328] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:27:47 328] [01-01 18:12:36 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:47 344] [01-01 18:12:36 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:47 345] [01-01 18:12:36 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:47 360] [01-01 18:12:36 TUYA D][simplekv.c:374] write key:tls_ca0 And Value Len:2688
[2024/8/7 9:27:47 360] [01-01 18:12:36 TUYA D][simplekv.c:457] new space 8 startpos:30428 size:2756
[2024/8/7 9:27:47 376] [01-01 18:12:36 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:47 377] [01-01 18:12:36 TUYA D][simplekv.c:203] update crc 1395591596
[2024/8/7 9:27:47 377] [01-01 18:12:36 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:47 392] [01-01 18:12:36 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:47 392] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:47 392] [01-01 18:12:36 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:47 408] [01-01 18:12:36 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:47 408] [01-01 18:12:36 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:47 425] [01-01 18:12:36 TUYA D][simplekv.c:374] write key:tls_ca_cnt And Value Len:16
[2024/8/7 9:27:47 425] [01-01 18:12:36 TUYA D][simplekv.c:457] new space 9 startpos:33184 size:84
[2024/8/7 9:27:47 425] [01-01 18:12:36 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:47 440] [01-01 18:12:36 TUYA D][simplekv.c:203] update crc 213719394
[2024/8/7 9:27:47 441] [01-01 18:12:36 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:47 441] [01-01 18:12:36 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:47 457] [01-01 18:12:36 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:27:47 457] [01-01 18:12:36 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216]
[2024/8/7 9:27:47 473] [01-01 18:12:36 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36]
[2024/8/7 9:27:47 473] [01-01 18:12:36 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[121.5.96.167]
[2024/8/7 9:27:47 489] [01-01 18:12:36 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[121.5.96.167]
[2024/8/7 9:27:47 489] [01-01 18:12:36 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108]
[2024/8/7 9:27:47 504] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:27:47 504] [01-01 18:12:36 TUYA D][simplekv.c:1251] find key:9 tls_ca_cnt
[2024/8/7 9:27:47 520] [01-01 18:12:36 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[2024/8/7 9:27:47 520] [01-01 18:12:36 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[2024/8/7 9:27:47 520] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:27:47 536] [01-01 18:12:36 TUYA D][simplekv.c:1251] find key:8 tls_ca0
[2024/8/7 9:27:47 536] [01-01 18:12:36 TUYA D][simplekv.c:1280] key:tls_ca0 find value.Len:2688
[2024/8/7 9:27:47 552] [01-01 18:12:36 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
[2024/8/7 9:27:47 552] [01-01 18:12:36 TUYA D][iot_httpc.c:1696] end
[2024/8/7 9:27:47 552] [01-01 18:12:36 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:27:47 568] [01-01 18:12:36 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:47 568] [01-01 18:12:36 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:27:47 568] bt_ack_uncrypt 2
[2024/8/7 9:27:47 568] 00 00 
[2024/8/7 9:27:47 584] [01-01 18:12:36 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:47 584] tuya_hal_bt_send 20
[2024/8/7 9:27:47 600] 00 21 33 02 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41 
[2024/8/7 9:27:47 600] [01-01 18:12:36 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:47 600] 0 21 33 2 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41 
[2024/8/7 9:27:47 616] XmBleSendBuf 20: 00 21 33 02 af e8 ec a0 3c 6a e2 f0 c1 f5 78 ce a9 c9 66 41
[2024/8/7 9:27:47 617] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:47 617] ble_slave_gap_event->type=13
[2024/8/7 9:27:47 617] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:47 631] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:47 632] [01-01 18:12:36 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:47 648] [01-01 18:12:36 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:27:47 648] tuya_hal_bt_send 17
[2024/8/7 9:27:47 648] 01 a1 23 59 bb 7e fb 58 cf 35 a2 e9 90 fc a9 40 6d 
[2024/8/7 9:27:47 648] [01-01 18:12:36 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:47 664] 1 a1 23 59 bb 7e fb 58 cf 35 a2 e9 90 fc a9 40 6d 
[2024/8/7 9:27:47 664] XmBleSendBuf 17: 01 a1 23 59 bb 7e fb 58 cf 35 a2 e9 90 fc a9 40 6d
[2024/8/7 9:27:47 664] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:47 680] ble_slave_gap_event->type=13
[2024/8/7 9:27:47 681] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:47 681] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:47 681] [01-01 18:12:36 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:47 696] [01-01 18:12:36 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:27:47 696] set basic_indicator_onoff:0 
[2024/8/7 9:27:47 712] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:47 712] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:47 728] [01-01 18:12:36 TUYA D][tuya_devos_activate.c:356] dev_nw_cfg_active_stage:5
[2024/8/7 9:27:47 728] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:47 728] [01-01 18:12:36 TUYA D][iot_httpc.c:3195] modules:(null)
[2024/8/7 9:27:47 744] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:last_reset_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:47 744] [01-01 18:12:36 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:47 760] [01-01 18:12:36 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:47 760] [01-01 18:12:36 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:47 776] [01-01 18:12:36 TUYA D][iot_httpc.c:3198] options:{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}
[2024/8/7 9:27:47 840] [01-01 18:12:36 TUYA D][iot_httpc.c:1161] Post Data: {"token":"E76hLljS","softVer":"1.5.431","productKey":"fvijo8jvloagv1gm","protocolVer":"2.2","baselineVer":"40.00","hid":"90314ba51650","skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}}","devAttribute":67,"cadVer":"1.0.4","cdVer":"1.0.0","options":"{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}","t":21}
[2024/8/7 9:27:47 856] [01-01 18:12:36 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.active&et=1&t=21&uuid=uuidcaab27b0a838d239&v=4.4&sign=71a650898213e64378dda31c80dcc47e
[2024/8/7 9:27:47 857] [01-01 18:12:36 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:47 872] [01-01 18:12:36 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:47 873] [01-01 18:12:36 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:47 873] [01-01 18:12:36 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:47 888] [01-01 18:12:36 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:47 888] [01-01 18:12:36 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:47 904] [01-01 18:12:36 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:47 904] [01-01 18:12:36 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:47 921] [01-01 18:12:36 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:47 921] [01-01 18:12:36 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:47 936] [01-01 18:12:36 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:47 936] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:47 937] set basic_indicator_onoff:1 
[2024/8/7 9:27:47 952] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:47 952] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:47 968] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:47 968] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:47 968] Len=20 step 0
[2024/8/7 9:27:47 984] att=0x0 0x21 0x20 0x2 0x4c 0xdc 0x22 0xe3 0x64 0x9d 0xae 0xae 0x32 0xe4 0x7e 0x3d 0x2 0x57 0x5c 0x69 
[2024/8/7 9:27:47 984]  RCVS len:20
[2024/8/7 9:27:47 984] set basic_indicator_onoff:0 
[2024/8/7 9:27:48 000] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 000] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:48 000] XmBleReadBuf 20:
[2024/8/7 9:27:48 016] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:48 016] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:48 016] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:48 032] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:48 032] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:48 048] [01-01 18:12:36 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:48 048] [01-01 18:12:36 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:48 048] [01-01 18:12:36 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:48 048] bt_rev_raw 20
[2024/8/7 9:27:48 064] 00 21 20 02 4c dc 22 e3 64 9d ae ae 32 e4 7e 3d 02 57 5c 69 
[2024/8/7 9:27:48 064] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:27:48 080] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:48 080] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:48 080] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:48 096]  ---
[2024/8/7 9:27:48 096] Len=17 step 0
[2024/8/7 9:27:48 097] att=0x1 0x8d 0xf3 0x76 0x6c 0x61 0x93 0xe1 0xcf 0x6f 0xa3 0x33 0xde 0x1a 0x5c 0xf2 0xa7 
[2024/8/7 9:27:48 097]  RCVS len:17
[2024/8/7 9:27:48 111] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:48 112] XmBleReadBuf 17:
[2024/8/7 9:27:48 112] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:48 112] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:48 128] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:48 128] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:27:48 128] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:27:48 144] [01-01 18:12:36 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:27:48 144] [01-01 18:12:36 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:48 160] [01-01 18:12:36 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:48 160] bt_rev_raw 17
[2024/8/7 9:27:48 160] 01 8d f3 76 6c 61 93 e1 cf 6f a3 33 de 1a 5c f2 a7 
[2024/8/7 9:27:48 175] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:27:48 176] ble rev data 33
[2024/8/7 9:27:48 176] 02 4c dc 22 e3 64 9d ae ae 32 e4 7e 3d 02 57 5c 69 8d f3 76 6c 61 93 e1 cf 6f a3 33 de 1a 5c f2 a7 
[2024/8/7 9:27:48 176] ble decryped data 16
[2024/8/7 9:27:48 192] 00 00 00 04 00 00 00 00 00 22 00 01 00 d6 49 00 
[2024/8/7 9:27:48 192] [01-01 18:12:36 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:48 192] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:27:48 209] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:27:48 209] set basic_indicator_onoff:1 
[2024/8/7 9:27:48 224] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 224] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:48 225] 
[2024/8/7 9:27:48 240] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:27:48 240] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:48 256] [1970-01-01 00:00:32] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time32529
[2024/8/7 9:27:48 256] [01-01 18:12:36 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:48 272] [01-01 18:12:36 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:48 272] set basic_indicator_onoff:0 
[2024/8/7 9:27:48 288] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 288] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:48 288] set basic_indicator_onoff:1 
[2024/8/7 9:27:48 304] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 304] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:48 320] [01-01 18:12:36 TUYA D][app_agent.c:706] udp ip: 192.168.31.144
[2024/8/7 9:27:48 320] set basic_indicator_onoff:0 
[2024/8/7 9:27:48 336] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 336] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:48 336] set basic_indicator_onoff:1 
[2024/8/7 9:27:48 352] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 352] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:48 352] set basic_indicator_onoff:0 
[2024/8/7 9:27:48 368] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 368] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:48 384] 
[2024/8/7 9:27:48 385] set basic_indicator_onoff:1 
[2024/8/7 9:27:48 385] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 400] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:48 400] set basic_indicator_onoff:0 
[2024/8/7 9:27:48 416] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 416] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:48 512] [01-01 18:12:37 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"capability":1,"devId":"6c7de378a95449e877rsmm","dstIntervals":[],"localKey":"$iY?ur;6e4EcO-4&","resetFactory":false,"schema":"[{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":103,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":104,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"range\":[\"0\",\"1\",\"2\"],\"type\":\"enum\"},\"id\":106,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":109,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"min\":1,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":110,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":111,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":113,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\
[2024/8/7 9:27:48 512] [08-07 19:40:05 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:48 512] [08-07 19:40:05 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:48 528] [08-07 19:40:05 TUYA D][tuya_devos_activate.c:210] cloud_reset:0 local_reset:1
[2024/8/7 9:27:48 528] [08-07 19:40:05 TUYA D][tuya_devos_activate.c:256] __tmm_gw_actv_work: reset stride flag.
[2024/8/7 9:27:48 544] [08-07 19:40:05 TUYA D][tuya_devos_entry.c:1477] write stride to flash:0
[2024/8/7 9:27:48 544] [08-07 19:40:05 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 9:27:48 544] [08-07 19:40:05 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:48 560] [08-07 19:40:05 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:48 560] [08-07 19:40:05 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:48 576] [08-07 19:40:05 TUYA D][simplekv.c:374] write key:is_stride And Value Len:16
[2024/8/7 9:27:48 576] [08-07 19:40:05 TUYA D][simplekv.c:457] new space 10 startpos:33268 size:84
[2024/8/7 9:27:48 576] [08-07 19:40:05 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:48 592] [08-07 19:40:05 TUYA D][simplekv.c:203] update crc 1143988772
[2024/8/7 9:27:48 592] [08-07 19:40:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:48 608] [08-07 19:40:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:48 608] [08-07 19:40:05 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:27:48 608] [08-07 19:40:05 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 9:27:48 624] [08-07 19:40:05 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 9:27:48 624] [08-07 19:40:05 TUYA D][simplekv.c:374] write key:gw_di And Value Len:416
[2024/8/7 9:27:48 640] [08-07 19:40:05 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416
[2024/8/7 9:27:48 640] [08-07 19:40:05 TUYA D][simplekv.c:430] find 2 available space
[2024/8/7 9:27:48 640] [08-07 19:40:05 TUYA D][simplekv.c:474] reuse available space 29188
[2024/8/7 9:27:48 656] [08-07 19:40:05 TUYA D][simplekv.c:203] update crc 1774296628
[2024/8/7 9:27:48 657] [08-07 19:40:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:48 657] [08-07 19:40:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:48 672] [08-07 19:40:05 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:27:48 672] [08-07 19:40:05 TUYA D][simplekv.c:1211] read key:flvlrc isFuzzy:0 skipCnt:0
[2024/8/7 9:27:48 673] [08-07 19:40:05 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:48 688] [08-07 19:40:05 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:48 689] [08-07 19:40:05 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:48 704] [08-07 19:40:05 TUYA D][simplekv.c:374] write key:flvlrc And Value Len:2928
[2024/8/7 9:27:48 705] [08-07 19:40:05 TUYA D][simplekv.c:457] new space 11 startpos:33352 size:2996
[2024/8/7 9:27:48 705] [08-07 19:40:05 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:48 720] [08-07 19:40:05 TUYA D][simplekv.c:203] update crc 3198706602
[2024/8/7 9:27:48 720] [08-07 19:40:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:48 720] [08-07 19:40:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:48 736] [08-07 19:40:05 TUYA D][ws_db_gw.c:670] schema write success
[2024/8/7 9:27:48 736] [08-07 19:40:05 TUYA D][tuya_devos_utils.c:873] create dev_cntl Success 
[2024/8/7 9:27:48 752] [08-07 19:40:05 TUYA D][tuya_ipc_sdk_init.c:183] ON post active:0xf7de78
[2024/8/7 9:27:48 752] [08-07 19:40:05 TUYA D][tuya_ipc_sdk_init.c:172] skillResult p2pId:[]
[2024/8/7 9:27:48 752] [08-07 19:40:05 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:27:48 768] [08-07 19:40:05 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 9:27:48 768] [08-07 19:40:05 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[2024/8/7 9:27:48 784] [08-07 19:40:05 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:544
[2024/8/7 9:27:48 784] [08-07 19:40:05 TUYA D][simplekv.c:394] 4 key same BUT size old 436 < new 544 need find new hd
[2024/8/7 9:27:48 800] [08-07 19:40:05 TUYA D][simplekv.c:457] new space 12 startpos:36348 size:612
[2024/8/7 9:27:48 800] [08-07 19:40:05 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:48 800] [08-07 19:40:05 TUYA D][simplekv.c:203] update crc 1901015777
[2024/8/7 9:27:48 816] [08-07 19:40:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:48 816] [08-07 19:40:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:48 816] [08-07 19:40:05 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:27:48 848] [08-07 19:40:05 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":9,"ssid":"WGlhb21pX0YxREM=","passwd":"eG01MTI1MjA=","md":0,"random":0,"wfb64":1,"stat":2,"token":"E76hLljS","region":"AY","reg_key":"6f4S","dns_prio":0 }
[2024/8/7 9:27:48 848] [08-07 19:40:05 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:27:48 849] [08-07 19:40:05 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:27:48 865] [08-07 19:40:05 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:27:48 865] [08-07 19:40:05 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:176
[2024/8/7 9:27:48 881] [08-07 19:40:05 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 176
[2024/8/7 9:27:48 881] [08-07 19:40:05 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:27:48 881] [08-07 19:40:05 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:27:48 896] [08-07 19:40:05 TUYA D][simplekv.c:203] update crc 18211685
[2024/8/7 9:27:48 897] g_AudioTipsList.size() enable: 0[08-07 19:40:05 TUYA D][smart_frame.c:3490] rept chan:4
[2024/8/7 9:27:48 913] [08-07 19:40:05 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:48 913] [08-07 19:40:05 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:48 928] [08-07 19:40:05 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:48 928] __dp_data_report_data 4
[2024/8/7 9:27:48 928] 9f 01 01 00 
[2024/8/7 9:27:48 928] [08-07 19:40:05 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:48 945] [08-07 19:40:05 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:48 945] bt_ack_uncrypt 4
[2024/8/7 9:27:48 945] 9f 01 01 00 
[2024/8/7 9:27:48 945] [08-07 19:40:05 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:48 961] [08-07 19:40:05 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:48 961] tuya_hal_bt_send 20
[2024/8/7 9:27:48 961] 00 31 34 05 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 02 95 57 
[2024/8/7 9:27:48 976] [08-07 19:40:05 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:48 976] 0 31 34 5 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 2 95 57 
[2024/8/7 9:27:48 976] XmBleSendBuf 20: 00 31 34set basic_indicator_onoff:1 
[2024/8/7 9:27:48 992] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:48 992] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:49 008]  05 57 18 3d d2 4a 9c 87 1d 71 7f e6 da 88 02 95 57
[2024/8/7 9:27:49 008] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:49 008] ble_slave_gap_event->type=13
[2024/8/7 9:27:49 008] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:49 024] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:49 024] [08-07 19:40:05 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:49 024] [08-07 19:40:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:49 040] [08-07 19:40:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:49 040] [08-07 19:40:05 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:27:49 056] __IPC_APP_Get_Net_Status_cb line(188) -------------------------- stat(1)==STAT_UNPROVISION 
[2024/8/7 9:27:49 056] [08-07 19:40:05 TUYA D][wifi_netcfg_frame_transporter.c:472] ----destroy Transporter,session:0xf4de80
[2024/8/7 9:27:49 072] [08-07 19:40:05 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:27:49 072] [08-07 19:40:05 TUYA N][bt_dp.c:228] bt rpt conn stat:9
[2024/8/7 9:27:49 072] [08-07 19:40:05 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:49 089] [08-07 19:40:05 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:27:49 089] bt_ack_uncrypt 2
[2024/8/7 9:27:49 089] 00 09 
[2024/8/7 9:27:49 089] [08-07 19:40:05 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:49 104] [08-07 19:40:05 TUYA D][tuya_ble_api.c:1005] start to get mesh
[2024/8/7 9:27:49 104] [08-07 19:40:05 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994070}
[2024/8/7 9:27:49 120] [08-07 19:40:05 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.mesh.get&devId=6c7de378a95449e877rsmm&et=1&t=1722994070&v=1.0&sign=670b80a3a4ab322ca476efb7f63b4179
[2024/8/7 9:27:49 120] [08-07 19:40:05 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:49 136] [08-07 19:40:05 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:49 136] [08-07 19:40:05 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:49 152] [08-07 19:40:05 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:49 152] [08-07 19:40:05 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:49 168] [08-07 19:40:05 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:49 168] [08-07 19:40:05 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:49 184] [08-07 19:40:05 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:49 184] [08-07 19:40:05 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:49 184] [08-07 19:40:05 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:49 200] [08-07 19:40:05 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:49 216] [08-07 19:40:05 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:49 216] tuya_hal_bt_send 20
[2024/8/7 9:27:49 216] 01 df 46 8d 20 9b 57 66 26 a2 bf ab 5a 3c d5 69 94 f3 81 1e 
[2024/8/7 9:27:49 216] [08-07 19:40:05 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:49 232] 1 df 46 8d 20 9b 57 66 26 a2 bf ab 5a 3c d5 69 94 f3 81 1e 
[2024/8/7 9:27:49 232] XmBleSendBuf 20: 01 df 46 8d 20 9b 57 66 26 a2 bf ab 5a 3c d5 69 94 f3 81 1e
[2024/8/7 9:27:49 232] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:49 248] ble_slave_gap_event->type=13
[2024/8/7 9:27:49 248] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:49 248] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:49 264] [08-07 19:40:05 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:49 264] [08-07 19:40:05 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:49 280] [08-07 19:40:05 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:49 296] [08-07 19:40:05 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"appKey":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","networkKey":"D59774254FA876FF1D204D16DF5223A5"},"t":1722994071,"success":true}
[2024/8/7 9:27:49 296] [08-07 19:40:06 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:49 312] set basic_indicator_onoff:0 
[2024/8/7 9:27:49 313] [08-07 19:40:06 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:49 328] [08-07 19:40:06 TUYA D][tuya_ble_api.c:1014] start to write flash, app_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66", network_key:"D59774254FA876FF1D204D16DF5223A5"
[2024/8/7 9:27:49 328] [08-07 19:40:06 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:49 344] [08-07 19:40:06 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:49 344] [08-07 19:40:06 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:49 344] [08-07 19:40:06 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:49 360] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:49 360] [08-07 19:40:06 TUYA D][simplekv.c:374] write key:ble_app_key And Value Len:48
[2024/8/7 9:27:49 376] [08-07 19:40:06 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 48
[2024/8/7 9:27:49 376] [08-07 19:40:06 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:27:49 392] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:49 392] [08-07 19:40:06 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:27:49 392] [08-07 19:40:06 TUYA D][simplekv.c:203] update crc 97806028
[2024/8/7 9:27:49 408] [08-07 19:40:06 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:49 408] tuya_hal_bt_send 14
[2024/8/7 9:27:49 408] 02 5e d8 20 d6 54 96 fc e1 5c f0 e1 29 08 
[2024/8/7 9:27:49 424] [08-07 19:40:06 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:49 424] 2 5e d8 20 d6 54 96 fc e1 5c f0 e1 29 8 
[2024/8/7 9:27:49 424] XmBleSendBuf 14: 02 5e d8 20 d6 54 96 fc e1 5c f0 e1 29 08
[2024/8/7 9:27:49 424] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:49 440] ble_slave_gap_event->type=13
[2024/8/7 9:27:49 440] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:49 440] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:49 456] [08-07 19:40:06 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:49 456] [08-07 19:40:06 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:49 456] [08-07 19:40:06 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:49 472] [08-07 19:40:06 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:49 472] [08-07 19:40:06 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:49 472] [08-07 19:40:06 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:49 488] [08-07 19:40:06 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:49 488] [08-07 19:40:06 TUYA D][simplekv.c:374] write key:ble_network_key And Value Len:48
[2024/8/7 9:27:49 504] [08-07 19:40:06 TUYA D][simplekv.c:457] new space 13 startpos:36960 size:116
[2024/8/7 9:27:49 504] [08-07 19:40:06 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:49 519] [08-07 19:40:06 TUYA D][simplekv.c:203] update crc 2970583735
[2024/8/7 9:27:49 519] [08-07 19:40:06 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:49 520] [08-07 19:40:06 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:49 535] [08-07 19:40:06 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994071}
[2024/8/7 9:27:49 552] [08-07 19:40:06 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.beacon.key.fetch&devId=6c7de378a95449e877rsmm&et=1&t=1722994071&v=1.0&sign=d4310c6417c9e458bbb06aff81b7f468
[2024/8/7 9:27:49 552] [08-07 19:40:06 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:49 567] [08-07 19:40:06 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:49 568] 
[2024/8/7 9:27:49 568] [08-07 19:40:06 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:49 583] [08-07 19:40:06 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:49 583] [08-07 19:40:06 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:49 599] [08-07 19:40:06 TUYA D][tuya_devos_entry.c:560] dev_nw_cfg_active_stage:6
[2024/8/7 9:27:49 600] __IPC_APP_Get_Net_Status_cb line(198) -------------------------- stat(3)==STAT_AP_STA_DISC 
[2024/8/7 9:27:49 600] [08-07 19:40:06 TUYA N][tuya_bt_sdk.c:171] ty bt upd localkey
[2024/8/7 9:27:49 615] [08-07 19:40:06 TUYA N][tuya_ble_api.c:425] upd login key len:6
[2024/8/7 9:27:49 615] [08-07 19:40:06 TUYA I][mqc_app.c:387] mqc app start ...
[2024/8/7 9:27:49 632] [08-07 19:40:06 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883
[2024/8/7 9:27:49 633] [08-07 19:40:06 TUYA D][mqc_app.c:473] TLS disable
[2024/8/7 9:27:49 633] [08-07 19:40:06 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:27:49 648] [08-07 19:40:06 TUYA D][mqtt_client.c:321] subcribe_topic:smart/device/in/6c7de378a95449e877rsmm, client_id:6c7de378a95449e877rsmm, user_name:6c7de378a95449e877rsmm, passwd:ef8e4b3ba271d37f
[2024/8/7 9:27:49 664] [08-07 19:40:06 TUYA D][mqtt_client.c:352] domain<0> m2.tuyacn.com:8883 HAVE PORT
[2024/8/7 9:27:49 664] [08-07 19:40:06 TUYA D][mqtt_client.c:355] PARSE m2.tuyacn.com:8883
[2024/8/7 9:27:49 664] [08-07 19:40:06 TUYA D][mqtt_client.c:383] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT
[2024/8/7 9:27:49 680] [08-07 19:40:06 TUYA D][mqtt_client.c:386] PARSE m2.tuyacn.com:1883
[2024/8/7 9:27:49 680] [08-07 19:40:06 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6c7de378a95449e877rsmm
[2024/8/7 9:27:49 696] [08-07 19:40:06 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6c7de378a95449e877rsmm
[2024/8/7 9:27:49 712] [08-07 19:40:06 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:25600,priority:4
[2024/8/7 9:27:49 712] [08-07 19:40:06 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[2024/8/7 9:27:49 712] [08-07 19:40:06 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[2024/8/7 9:27:49 712] [08-07 19:40:06 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[2024/8/7 9:27:49 728] [08-07 19:40:06 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:27:49 728] [08-07 19:40:06 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:49 744] [08-07 19:40:06 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:49 744] [08-07 19:40:06 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:49 744] [08-07 19:40:06 TUYA D][tuya_svc_timer_task.c:146] no timer
[2024/8/7 9:27:49 760] [08-07 19:40:06 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[2024/8/7 9:27:49 760] [08-07 19:40:06 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[2024/8/7 9:27:49 760] [08-07 19:40:06 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[2024/8/7 9:27:49 776] [08-07 19:40:06 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6c7de378a95449e877rsmm
[2024/8/7 9:27:49 776] [08-07 19:40:06 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6c7de378a95449e877rsmm
[2024/8/7 9:27:49 792] [08-07 19:40:06 TUYA D][svc_online_log.c:317] svc online log active success
[2024/8/7 9:27:49 792] [08-07 09:27:51 TUYA D][tuya_ipc_sdk_init.c:137] sys stop timer: 14
[2024/8/7 9:27:49 808] [08-07 09:27:51 TUYA D][tuya_ipc_sdk_init.c:140] sys delete timer: 14
[2024/8/7 9:27:49 808] [08-07 09:27:51 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:49 808] tuya_hal_bt_send 20
[2024/8/7 9:27:49 824] 00 21 [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:49 824] 35 02 e5 85 68 e3 03 d5 41 83 f2 4e 7c 38 aa c2 4f 02 
[2024/8/7 9:27:49 840] [08-07 09:27:51 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:49 840] 0 21 35 2 e5 85 68 e3 3 d5 41 83 f2 4e 7c 38 aa c2 4f 2 
[2024/8/7 9:27:49 840] XmBleSendBuf 20: 00 21 35 02 e5 85 68 e3 03 d5 41 83 f2 4e 7c 38 aa c2 4f 02
[2024/8/7 9:27:49 856] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:49 856] ble_slave_gap_event->type=13
[2024/8/7 9:27:49 856] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:49 856] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:49 872] [08-07 09:27:51 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:49 872] [08-07 09:27:51 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[2024/8/7 9:27:49 888] [08-07 09:27:51 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:27:49 888] [08-07 09:27:51 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:27:49 888] [08-07 09:27:51 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:27:49 904] [08-07 09:27:51 TUYA D][tuya_ipc_p2p_common.c:530] p2p passwd change to adb2cd97
[2024/8/7 9:27:49 904] [08-07 09:27:51 TUYA D][iot_httpc.c:1161] Post Data: {"password":"adb2cd97","t":1722994071}
[2024/8/7 9:27:49 920] [08-07 09:27:51 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.password.update&devId=6c7de378a95449e877rsmm&et=1&t=1722994071&v=1.0&sign=9b684b4d4f7e5904006c9f85817828f4
[2024/8/7 9:27:49 936] [08-07 09:27:51 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:49 936] [08-07 09:27:51 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:49 952] [08-07 09:27:51 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:49 952] [08-07 09:27:51 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:49 968] [08-07 09:27:51 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:49 968] [08-07 09:27:51 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:49 984] [08-07 09:27:51 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:49 984] [08-07 09:27:51 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:50 000] [08-07 09:27:51 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:50 000] [08-07 09:27:51 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:50 016] [08-07 09:27:51 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:50 016] [08-07 09:27:51 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:50 016] [08-07 09:27:51 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:50 032] [08-07 09:27:51 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:50 032] [08-07 09:27:51 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:50 047] [08-07 09:27:51 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:50 048] [08-07 09:27:51 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:50 063] [08-07 09:27:51 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:50 064] [08-07 09:27:51 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:27:50 064] tuya_hal_bt_send 17
[2024/8/7 9:27:50 080] 01 70 b3 cb fd f5 b4 b0 5b 38 85 22 0c 82 a3 3d 6b 
[2024/8/7 9:27:50 080] [08-07 09:27:51 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:50 080] 1 70 b3 cb fd f5 b4 b0 5b 38 85 22 c 82 a3 3d 6b 
[2024/8/7 9:27:50 095] XmBleSendBuf 17: 01 70 b3 cb fd f5 b4 b0 5b 38 85 22 0c 82 a3 3d 6b
[2024/8/7 9:27:50 095] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:27:50 096] ble_slave_gap_event->type=13
[2024/8/7 9:27:50 111] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:27:50 111] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:27:50 111] [08-07 09:27:51 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:50 111] set basic_indicator_onoff:1 
[2024/8/7 9:27:50 127] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:50 128] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:50 143] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:50 143] [08-07 09:27:51 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:27:50 160] [08-07 09:27:51 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[2024/8/7 9:27:50 160] [08-07 09:27:51 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[2024/8/7 9:27:50 176] [08-07 09:27:51 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:27:50 176] dev id key: 16
[2024/8/7 9:27:50 176] 2e 62 4d c0 f4 12 32 89 a0 c4 dc 1c ba ed ee ea 
[2024/8/7 9:27:50 176] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:27:50 192] [08-07 09:27:51 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:27:50 192] 2 1 6 3 2 1 a2 14 16 1 a2 0 e1 a6 8c a9 70 49 c8 c7 be 3d e6 4b 7d 13 95 76 
[2024/8/7 9:27:50 208] [08-07 09:27:51 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:27:50 208] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 e0 b3 7f 66 36 b8 4f 26 53 63 b3 4f 25 42 35 bd 
[2024/8/7 9:27:50 208] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:27:50 224]   ---
[2024/8/7 9:27:50 224] [08-07 09:27:51 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:27:50 224] [08-07 09:27:51 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:27:50 240] [08-07 09:27:51 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:50 256] [08-07 09:27:51 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:50 256] [08-07 09:27:51 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:50 272] [08-07 09:27:51 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:50 288] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:50 292] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:50 292] Len=20 step 0
[2024/8/7 9:27:50 304] att=0x0 0x21 0x20 0x2 0xee 0x80 0xb9 0x98 0x3a 0x4 0x44 0x52 0xfa 0xf7 0x9f 0x58 0xc6 0x1d 0x64 0x36 
[2024/8/7 9:27:50 306]  RCVS len:20
[2024/8/7 9:27:50 306] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:50 320] [08-07 09:27:51 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994071,"success":true}
[2024/8/7 9:27:50 321] [08-07 09:27:51 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:50 321] [08-07 09:27:51 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:50 336] [08-07 09:27:51 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:27:50 336] [08-07 09:27:51 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:27:50 336] [08-07 09:27:51 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:27:50 352] [08-07 09:27:51 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:27:50 352] [08-07 09:27:51 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:27:50 368] [08-07 09:27:51 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:27:50 368] [08-07 09:27:51 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:27:50 368] [08-07 09:27:51 TUYA D][simplekv.c:203] update crc 1063074218
[2024/8/7 9:27:50 368] XmBleReadBuf 20:
[2024/8/7 9:27:50 384] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:50 384] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:50 384] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:50 400] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:27:50 400] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:27:50 416] [08-07 09:27:51 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:27:50 416] [08-07 09:27:51 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:50 416] [08-07 09:27:51 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:50 432] bt_rev_raw 20
[2024/8/7 9:27:50 432] 00 21 20 02 ee 80 b9 98 3a 04 44 52 fa f7 9f 58 c6 1d 64 36 
[2024/8/7 9:27:50 432] [08-07 09:27:51 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:27:50 448] [08-07 09:27:51 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:27:50 448] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:27:50 464] set basic_indicator_onoff:0 
[2024/8/7 9:27:50 464] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:50 480] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:50 480] [08-07 09:27:51 TUYA D][iot_httpc.c:601] Decode Rev:{"result":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","t":1722994071,"success":true}
[2024/8/7 9:27:50 496] [08-07 09:27:51 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:50 496] [08-07 09:27:51 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:50 512] [08-07 09:27:51 TUYA D][tuya_ble_api.c:986] start to write flash, beacon_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66"
[2024/8/7 9:27:50 512] [08-07 09:27:51 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:50 512] [08-07 09:27:51 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:50 528] [08-07 09:27:51 TUYA D][tuya_devos_utils.c:341] set gw ext_stat:2
[2024/8/7 9:27:50 528] [08-07 09:27:51 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:27:50 544] [08-07 09:27:51 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:50 544] [08-07 09:27:51 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:50 544] [08-07 09:27:51 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:50 560] [08-07 09:27:51 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 0
[2024/8/7 9:27:50 560] [08-07 09:27:51 TUYA D][uni_network.c:181] use dynamic dns ip 121.5.96.167 for domain m2.tuyacn.com
[2024/8/7 9:27:50 576] [08-07 09:27:51 TUYA D][mqtt_client.c:1472] select mqtt host:m2.tuyacn.com
[2024/8/7 9:27:50 576] [08-07 09:27:51 TUYA N][mqtt_client.c:1493] mqtt get serve ip success
[2024/8/7 9:27:50 592] [08-07 09:27:51 TUYA D][simplekv.c:374] write key:ble_beaconkey And Value Len:48
[2024/8/7 9:27:50 592] [08-07 09:27:51 TUYA D][simplekv.c:457] new space 14 startpos:37076 size:116
[2024/8/7 9:27:50 592] [08-07 09:27:51 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:50 608] [08-07 09:27:51 TUYA D][mqtt_client.c:989] serverIP 2030395559 port:8883
[2024/8/7 9:27:50 608] [08-07 09:27:51 TUYA D][simplekv.c:203] update crc 3611210201
[2024/8/7 9:27:50 624] [08-07 09:27:51 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:50 624] [08-07 09:27:51 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:50 624] [08-07 09:27:51 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:27:50 640] [08-07 09:27:51 TUYA D][mqtt_client.c:1014] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883
[2024/8/7 9:27:50 640] [08-07 09:27:51 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:50 656] [08-07 09:27:51 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyacn.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:50 656] [08-07 09:27:51 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:50 672] [08-07 09:27:51 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:50 672] [08-07 09:27:51 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:50 688] [08-07 09:27:51 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:50 688] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:27:50 688] Len=17 step 0
[2024/8/7 9:27:50 704] att=0x1 0xcd 0x23 0x75 0x86 0x42 0x4c 0x6 0x5e 0xd5 0x10 0x4a 0xd2 0xb3 0x86 0xd 0x46 
[2024/8/7 9:27:50 706]  RCVS len:17
[2024/8/7 9:27:50 706] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:50 706] XmBleReadBuf 17:
[2024/8/7 9:27:50 706] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:27:50 720] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:27:50 720] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:27:50 720] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:27:50 736] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:27:50 736] [08-07 09:27:51 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:27:50 752] [08-07 09:27:51 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:27:50 752] [08-07 09:27:51 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:27:50 752] bt_rev_raw 17
[2024/8/7 9:27:50 752] 01 cd 23 75 86 42 4c 06 5e d5 10 4a d2 b3 86 0d 46 
[2024/8/7 9:27:50 768] [08-07 09:27:51 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:27:50 768] ble rev data 33
[2024/8/7 9:27:50 783] 02 ee 80 b9 98 3a 04 44 52 fa f7 9f 58 c6 1d 64 36 cd 23 75 86 42 4c 06 5e d5 10 4a d2 b3 86 0d 46 
[2024/8/7 9:27:50 783] ble decryped data 16
[2024/8/7 9:27:50 783] 00 00 00 05 00 00 00 00 00 22 00 01 00 13 18 00 
[2024/8/7 9:27:50 799] [08-07 09:27:51 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:50 800] [08-07 09:27:51 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:27:50 800] [08-07 09:27:51 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:27:50 815] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:27:50 815] [08-07 09:27:51 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:27:50 815] set basic_indicator_onoff:1 
[2024/8/7 9:27:50 831] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:50 831] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:50 832] 
[2024/8/7 9:27:50 848] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:50 848] set basic_indicator_onoff:0 
[2024/8/7 9:27:50 864] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:50 864] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:50 880] [1970-01-01 00:00:33] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:27:50 880] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:27:50 880] set basic_indicator_onoff:1 
[2024/8/7 9:27:50 896] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:50 896] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:50 912] [08-07 09:27:51 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:50 928] [08-07 09:27:51 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyacn.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:50 928] [08-07 09:27:51 TUYA N][mqtt_client.c:1531] mqtt create success, begin to connect
[2024/8/7 9:27:50 928] [08-07 09:27:51 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:27:50 944] set basic_indicator_onoff:0 
[2024/8/7 9:27:50 944] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:50 960] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:27:50 960] [08-07 09:27:51 TUYA D][mqtt_client.c:1413] cnt 1
[2024/8/7 9:27:50 960] [08-07 09:27:51 TUYA D][mqtt_client.c:1104] mqtt subscribe success
[2024/8/7 9:27:50 976] [08-07 09:27:51 TUYA D][mqc_app.c:732] mqtt connect success
[2024/8/7 9:27:50 976] [08-07 09:27:51 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[2024/8/7 9:27:50 992] [08-07 09:27:51 TUYA D][mqtt_client.c:1994] subscribe new topic /av/d/6c7de378a95449e877rsmm ret:1 
[2024/8/7 9:27:50 992] [08-07 09:27:51 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[2024/8/7 9:27:50 992] __IPC_APP_Get_Net_Status_cb line(243) -------------------------- stat(11)==STAT_MQTT_ONLINE 
[2024/8/7 9:27:51 008] curr event:11 
[2024/8/7 9:27:51 008] IPC_APP_Notify_LED_Sound_Status_CB line(550) -------------------------- IPC_MQTT_ONLINE(11)
[2024/8/7 9:27:51 024] [1970-01-01 00:00:34] tuya_ipc_system_control_demo.c(551) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(DEVICE_ONLINE, 0, 0, 0, 1))
[2024/8/7 9:27:51 024] Disable Qrcode
[2024/8/7 9:27:51 040] [1970-01-01 00:00:34] tuya_ipc_system_control_demo.c(558) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONFIG_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:27:51 056] [1970-01-01 00:00:34] xm_musicPlayer.cpp(91) <PlayAudioTips>: Open audio file /usr/share/audios/_english.pcm failed, No such file or directory
[2024/8/7 9:27:51 072] [1970-01-01 00:00:34] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/AddSuccess_english.pcm]
[2024/8/7 9:27:51 072] [1970-01-01 00:00:34] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:27:51 072] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:27:51 088] 
[2024/8/7 9:27:51 089] mqtt subscribe ack 5
[2024/8/7 9:27:51 089] 90 03 00 02 00 
[2024/8/7 9:27:51 089] set basic_indicator_onoff:1 
[2024/8/7 9:27:51 105] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:27:51 105] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:27:51 105] [08-07 09:27:52 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:27:51 120] [08-07 09:27:52 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:51 120] [08-07 09:27:52 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:51 136] [08-07 09:27:52 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:51 136] [08-07 09:27:52 TUYA E][svc_online_log_db.c:25] ret:-6
[2024/8/7 9:27:51 136] [08-07 09:27:52 TUYA D][svc_online_log.c:182] load env fail. maybe not exist.
[2024/8/7 9:27:51 152] [08-07 09:27:52 TUYA D][svc_online_log.c:187] update property:{"value":"{\"embed_sys_env\":\"arm-xm-linux\"}"}
[2024/8/7 9:27:51 168] [08-07 09:27:52 TUYA D][iot_httpc.c:1161] Post Data: {"value":"{\"embed_sys_env\":\"arm-xm-linux\"}","t":1722994072}
[2024/8/7 9:27:51 184] [08-07 09:27:52 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.property.save&devId=6c7de378a95449e877rsmm&et=1&t=1722994072&v=1.0&sign=a8ee9f744516edd9e776f3077e5010d9
[2024/8/7 9:27:51 184] [08-07 09:27:52 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:51 184] [08-07 09:27:52 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:51 200] 
[2024/8/7 9:27:51 201] [08-07 09:27:52 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:51 201] [08-07 09:27:52 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:51 216] [08-07 09:27:52 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:51 216] [08-07 09:27:52 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:51 232] [08-07 09:27:52 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:51 232] [08-07 09:27:52 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:51 248] [08-07 09:27:52 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:51 248] [08-07 09:27:52 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:51 264] [08-07 09:27:52 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:51 264] [08-07 09:27:52 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:51 280] [08-07 09:27:52 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:51 296] [1970-01-01 00:00:34] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:51 296] [08-07 09:27:52 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994072,"success":true}
[2024/8/7 9:27:51 296] [08-07 09:27:52 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:51 312] [08-07 09:27:52 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:51 312] [08-07 09:27:52 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:27:51 328] [08-07 09:27:52 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:51 328] [08-07 09:27:52 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:51 328] [08-07 09:27:52 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:51 344] [08-07 09:27:52 TUYA D][simplekv.c:374] write key:em_sys_env And Value Len:32
[2024/8/7 9:27:51 344] [08-07 09:27:52 TUYA D][simplekv.c:457] new space 15 startpos:37192 size:100
[2024/8/7 9:27:51 360] [08-07 09:27:52 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:51 360] [08-07 09:27:52 TUYA D][simplekv.c:203] update crc 2104331068
[2024/8/7 9:27:51 360] [08-07 09:27:52 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:51 376] [08-07 09:27:52 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:51 376] [08-07 09:27:52 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[2024/8/7 9:27:51 392] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:27:51 392] [08-07 09:27:52 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
[2024/8/7 9:27:51 408] [08-07 09:27:52 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:2  -->>
[2024/8/7 9:27:51 408] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:27:51 408] Mode(Product):0
[2024/8/7 9:27:51 408] BpuMode:[Online]
[2024/8/7 9:27:51 408] VpssMode:[Online]
[2024/8/7 9:27:51 408] [0.LimitUp_info]:
[2024/8/7 9:27:51 408] LimitUp:[Disable]
[2024/8/7 9:27:51 424] [2680*0]->[3840*0])
[2024/8/7 9:27:51 424] chn	TotalSize	ActiveSize
[2024/8/7 9:27:51 424] 0	5040*2246	2680*2160
[2024/8/7 9:27:51 424] 0	5040*2246	3840*2160
[2024/8/7 9:27:51 424] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:27:51 424] [1.VICU_info]:
[2024/8/7 9:27:51 440] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:27:51 440] 0	25.0	669	0	0	183	linear	8ddb00
[2024/8/7 9:27:51 440] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:27:51 440] en	op_type	m_chn	now
[2024/8/7 9:27:51 440] 0	1	1	1
[2024/8/7 9:27:51 440] [2.VI_info]:
[2024/8/7 9:27:51 440] chn	TotalSize	ActiveSize
[2024/8/7 9:27:51 456] 0	5040*2246	3848*2166
[2024/8/7 9:27:51 457] 1	   0*   0	   0*   0
[2024/8/7 9:27:51 457] [3.MIPI_info]:
[2024/8/7 9:27:51 457] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:27:51 457] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:27:51 472] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:27:51 472] [4.Cut_info]:
[2024/8/7 9:27:51 472] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:27:51 472] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:27:51 472] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:27:51 488] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:27:51 488] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:27:51 488] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:27:51 488] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:27:51 488] [5.IB(isp buffer info)]:
[2024/8/7 9:27:51 504] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:27:51 504] PoolId  Count  Size
[2024/8/7 9:27:51 504] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:51 520] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:51 520] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:51 536] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:27:51 536] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:27:51 552] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:27:51 552] [08-07 09:27:52 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:2  <<--
[2024/8/7 9:27:51 568] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:27:51 568] [08-07 09:27:52 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:27:51 584] [08-07 09:27:52 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:27:51 584] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:27:51 600] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:27:51 601] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:27:51 601] 0       0         0          1          4       
[2024/8/7 9:27:51 601] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:27:51 616]      --265--            --264--                                               
[2024/8/7 9:27:51 616] Count      Line     Count      Line     
[2024/8/7 9:27:51 616] 533        480      1215       560      
[2024/8/7 9:27:51 632] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:27:51 632] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:27:51 648] 0   3840   2160    H265  0      0        0           317       983038     2        	
[2024/8/7 9:27:51 648] 1   640    360     H265  0      0        0           201       43197      3        	
[2024/8/7 9:27:51 664] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:27:51 664] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:27:51 680] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:27:51 696] 0   Y      317      0       0       15       0        317      317      437       64516         59230    111734   64632    12      
[2024/8/7 9:27:51 696] 1   Y      201      0       5       1        0        201      201      422       3472          1912     26838    2839     9       
[2024/8/7 9:27:51 712] 3   N      0        0       0       1        0        0        0        424       0             0        0        0        0       
[2024/8/7 9:27:51 728] [1970-01-01 00:00:34] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:27:51 728] [08-07 09:27:52 TUYA D][MainApp.c:537] tuya_ipc_sdk_mqtt_online_proc is start run
[2024/8/7 9:27:51 744] [08-07 09:27:52 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722994072 28800
[2024/8/7 9:27:51 744] [08-07 09:27:52 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722994072 28800
[2024/8/7 9:27:51 744] Init tuya_ipc_ss_init
[2024/8/7 9:27:51 760] [08-07 09:27:52 TUYA D][tuya_ipc_stream_storage.c:2015] Init stream_storage.base_path:/mnt/mmc v:4 a:101, max event per day 289 skills 1
[2024/8/7 9:27:51 760] [08-07 09:27:52 TUYA D][tuya_ipc_stream_storage.c:1571] SD task begin___
[2024/8/7 9:27:51 776] [08-07 09:27:52 TUYA D][tuya_ipc_stream_storage.c:2161] stream storage task init success
[2024/8/7 9:27:51 776] [08-07 09:27:52 TUYA D][MainApp.c:567] local storage init result is 0
[2024/8/7 9:27:51 792] [08-07 09:27:52 TUYA D][tuya_ipc_stream_storage.c:1585] report sd status 0 -> 5
[2024/8/7 9:27:51 792] [08-07 09:27:52 TUYA E][tuya_ipc_stream_storage.c:1914] storage not inited
[2024/8/7 9:27:51 792] [08-07 09:27:52 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:27:51 808] [08-07 09:27:52 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:27:51 808] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:27:51 824] [1970-01-01 00:00:36] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:27:51 824] [1970-01-01 00:00:36] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:27:51 840] [08-07 09:27:53 TUYA D][smart_frame.c:2112] Start To Sync Dev:6c7de378a95449e877rsmm, dp_rept_chan:5
[2024/8/7 9:27:51 840] [08-07 09:27:53 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:27:51 856] [08-07 09:27:53 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:159.
[2024/8/7 9:27:51 856] [08-07 09:27:53 TUYA D][smart_frame.c:2547] final pack:{"159":false}
[2024/8/7 9:27:51 872] [08-07 09:27:53 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:27:51 872] [08-07 09:27:53 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42841 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:27:51 888] [08-07 09:27:53 TUYA D][smart_frame.c:2135] sync rslt:0
[2024/8/7 9:27:51 888] [08-07 09:27:53 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:27:51 904] [08-07 09:27:53 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:27:51 904] [08-07 09:27:53 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722994073, rept_cnt:1.
[2024/8/7 9:27:51 924] [08-07 09:27:53 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722994073, rept_cnt:0.
[2024/8/7 9:27:51 924] [08-07 09:27:53 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722994073, rept_cnt:0.
[2024/8/7 9:27:51 936] 64 byte from 192.168.31.1: icmp_seq=0 ttl=64 time=14.000 ms
[2024/8/7 9:27:51 936] [1970-01-01 00:00:36] xm_wifi.c(386) <WifiConnectCheck>: gate way is 192.168.31.1 ping res is 1 error_cnt:0
[2024/8/7 9:27:51 951] [1970-01-01 00:00:36] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time36473
[2024/8/7 9:27:51 952] [08-07 09:27:54 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994074}
[2024/8/7 9:27:51 968] [08-07 09:27:54 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.uuid.pskkey.get&et=1&t=1722994074&uuid=uuidcaab27b0a838d239&v=1.0&sign=bc2d8a8ce623eadd5e336c7194a079dc
[2024/8/7 9:27:51 984] [08-07 09:27:54 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:51 984] [08-07 09:27:54 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:52 000] [08-07 09:27:54 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:52 000] [08-07 09:27:54 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:52 016] [08-07 09:27:54 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:52 016] [08-07 09:27:54 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:52 032] [08-07 09:27:54 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:52 032] [08-07 09:27:54 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:52 032] [08-07 09:27:54 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:52 048] [08-07 09:27:54 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:52 048] [08-07 09:27:54 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:52 063] [08-07 09:27:54 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:52 079] [08-07 09:27:54 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:52 079] [08-07 09:27:54 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"pskKey":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80"},"t":1722994074,"success":true}
[2024/8/7 9:27:52 096] [08-07 09:27:54 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:52 096] [08-07 09:27:54 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:52 128] [08-07 09:27:54 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80","auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:27:52 128] [08-07 09:27:54 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:27:52 144] [08-07 09:27:54 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:27:52 144] [08-07 09:27:54 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:27:52 144] [08-07 09:27:54 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:256
[2024/8/7 9:27:52 160] [08-07 09:27:54 TUYA D][simplekv.c:397] 0 key same AND size old 276 >= new 256
[2024/8/7 9:27:52 160] [08-07 09:27:54 TUYA D][simplekv.c:430] find 0 available space
[2024/8/7 9:27:52 176] [08-07 09:27:54 TUYA D][simplekv.c:474] reuse available space 28700
[2024/8/7 9:27:52 176] [08-07 09:27:54 TUYA D][simplekv.c:203] update crc 2633663693
[2024/8/7 9:27:52 176] [08-07 09:27:54 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:52 192] [08-07 09:27:54 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:52 192] [08-07 09:27:54 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:27:52 192] [08-07 09:27:54 TUYA D][tuya_ble_api.c:1417] cloud connected, stop adv!
[2024/8/7 9:27:52 208] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(640): stop_adv ---
[2024/8/7 9:27:52 208] ---[XmBleReadBuf][132]: already stop ble,could not call XmBleReadBuf
[2024/8/7 9:27:52 208] exit_ble_thread create suc
[2024/8/7 9:27:52 224] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(644): XmBleAdvStop ---
[2024/8/7 9:27:52 224] [08-07 09:27:54 TUYA D][tuya_ble_api.c:1376] nw stat change:1->2, rpt to app.
[2024/8/7 9:27:52 240] [08-07 09:27:54 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:2
[2024/8/7 9:27:52 240] [08-07 09:27:54 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:52 240] [08-07 09:27:54 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:27:52 256] bt_ack_uncrypt 1
[2024/8/7 9:27:52 256] 02 
[2024/8/7 9:27:52 256] [08-07 09:27:54 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:52 273] [08-07 09:27:54 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:52 273] tuya_hal_bt_send 20
[2024/8/7 9:27:52 273] 00 21 36 05 9e 57 b8 c8 d6 7b f9 77 04 9b 8c 43 d5 c7 7d 5c 
[2024/8/7 9:27:52 273] [08-07 09:27:54 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:52 288] 0 21 36 5 9e 57 b8 c8 d6 7b f9 77 4 9b 8c 43 d5 c7 7d 5c 
[2024/8/7 9:27:52 288] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:52 305] [08-07 09:27:54 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:52 305] [08-07 09:27:54 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:27:52 305] tuya_hal_bt_send 17
[2024/8/7 9:27:52 320] 01 62 46 d4 b1 bd 4c 64 55 af 21 40 12 2e 5d 92 83 
[2024/8/7 9:27:52 320] [08-07 09:27:54 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:52 320] 1 62 46 d4 b1 bd 4c 64 55 af 21 40 12 2e 5d 92 83 
[2024/8/7 9:27:52 335] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:52 335] [08-07 09:27:54 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:52 335] --- tracepoint bt_ext_porting.c,ty_btext_thread(433): tuya_hal_thread_release ---
[2024/8/7 9:27:52 352] [08-07 09:27:54 TUYA E][bt_ext_porting.c:434] [TUYA-BTUART]ty_btext_thread deleted
[2024/8/7 9:27:52 352] [08-07 09:27:54 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:27:52 367] set sd_record_on_off:1 
[2024/8/7 9:27:52 367] set sd_record_mode:0 
[2024/8/7 9:27:52 367] [08-07 09:27:54 TUYA E][tuya_ipc_stream_storage.c:1912] the ss mgr not inited, but msg buffered: set mode 1
[2024/8/7 9:27:52 383] write RecordMode success  0 
[2024/8/7 9:27:52 383] [08-07 09:27:54 TUYA D][tuya_ipc_cloud_storage.c:2188] init cloud storage begin
[2024/8/7 9:27:52 383] [08-07 09:27:54 TUYA D][simplekv.c:1211] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:52 400] [08-07 09:27:54 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:52 400] [08-07 09:27:54 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:52 400] [08-07 09:27:54 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:52 416] [08-07 09:27:54 TUYA E][tuya_ipc_cloud_storage.c:365] iot_wd_common_read fails md5_encrypt_key -6
[2024/8/7 9:27:52 417] [08-07 09:27:54 TUYA E][tuya_ipc_cloud_storage.c:450] read key_key file failed.
[2024/8/7 9:27:52 432] [08-07 09:27:54 TUYA D][tuya_ipc_cloud_storage.c:2240] __check_md5_encrypt_key fail, need update from server
[2024/8/7 9:27:52 448] [08-07 09:27:54 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:27:52 448] [08-07 09:27:54 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:52 448] [08-07 09:27:54 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:52 463] [08-07 09:27:54 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:52 463] [08-07 09:27:54 TUYA E][tuya_ipc_cloud_storage.c:942] iot_wd_common_read fails storage_restriction -6
[2024/8/7 9:27:52 479] [08-07 09:27:54 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994074}
[2024/8/7 9:27:52 496] [08-07 09:27:54 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.restriction.config.get&devId=6c7de378a95449e877rsmm&et=1&t=1722994074&v=1.0&sign=166bf6c76e12a94c0cf11b880bb7b144
[2024/8/7 9:27:52 496] [08-07 09:27:54 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:52 511] [08-07 09:27:54 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:52 511] [08-07 09:27:54 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:52 527] [08-07 09:27:54 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:52 527] [08-07 09:27:54 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:52 527] [08-07 09:27:54 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:52 544] [08-07 09:27:54 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:52 560] [08-07 09:27:54 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:52 561] [08-07 09:27:54 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:52 561] [08-07 09:27:54 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:52 576] [08-07 09:27:54 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:52 576] [08-07 09:27:54 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:52 592] [08-07 09:27:54 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:52 608] [08-07 09:27:54 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"msg":{"audioDuration":15,"audioInterval":300,"videoDuration":6,"videoInterval":300},"storage":{"mtu":10}},"t":1722994075,"success":true}
[2024/8/7 9:27:52 624] [08-07 09:27:55 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:52 624] [08-07 09:27:55 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:52 640] [08-07 09:27:55 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:27:52 641] [08-07 09:27:55 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:52 641] [08-07 09:27:55 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:52 656] [08-07 09:27:55 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:52 656] [08-07 09:27:55 TUYA D][simplekv.c:374] write key:storage_restriction And Value Len:32
[2024/8/7 9:27:52 656] [08-07 09:27:55 TUYA D][simplekv.c:457] new space 16 startpos:37292 size:100
[2024/8/7 9:27:52 672] [08-07 09:27:55 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:52 672] [08-07 09:27:55 TUYA D][simplekv.c:203] update crc 3390837818
[2024/8/7 9:27:52 688] [08-07 09:27:55 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:52 688] [08-07 09:27:55 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:52 688] [08-07 09:27:55 TUYA D][tuya_ipc_cloud_storage.c:920] slice_duration write success
[2024/8/7 9:27:52 704] [08-07 09:27:55 TUYA D][tuya_ipc_cloud_storage.c:999] case 2 get slice duration from cloud 10
[2024/8/7 9:27:52 721] [08-07 09:27:55 TUYA D][tuya_ipc_cloud_storage.c:1043] cloud storage seize 3059584 bytes memory for media data, each slice 10 seconds
[2024/8/7 9:27:52 721] [08-07 09:27:55 TUYA I][uni_thread.c:228] thread_create name:cloud_storage,stackDepth:65536,totalstackDepth:91136,priority:3
[2024/8/7 9:27:52 736] [08-07 09:27:55 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[2024/8/7 9:27:52 736] [08-07 09:27:55 TUYA D][uni_thread.c:250] Thread:cloud_storage Exec Start. Set to Running Stat
[2024/8/7 9:27:52 752] [08-07 09:27:55 TUYA D][tuya_ipc_cloud_storage.c:2289] init cloud storage success
[2024/8/7 9:27:52 752] [08-07 09:27:55 TUYA D][MainApp.c:590] cloud storage init result is 0
[2024/8/7 9:27:52 768] [08-07 09:27:55 TUYA D][iot_httpc.c:1161] Post Data: {"type":"MediaStor","t":1722994075}
[2024/8/7 9:27:52 784] [08-07 09:27:55 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6c7de378a95449e877rsmm&et=1&t=1722994075&v=3.0&sign=14aa7a17929149d7df70c2607bf84566
[2024/8/7 9:27:52 784] [08-07 09:27:55 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:52 800] [08-07 09:27:55 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:52 800] [08-07 09:27:55 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:52 816] [08-07 09:27:55 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:52 816] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:52 831] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:52 831] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:52 831] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:52 847] __dp_data_report_data 4
[2024/8/7 9:27:52 847] 69 01 01 00 
[2024/8/7 9:27:52 847] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:52 847] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:52 863] bt_ack_uncrypt 4
[2024/8/7 9:27:52 863] 69 01 01 00 
[2024/8/7 9:27:52 863] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:52 863] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"105":false}
[2024/8/7 9:27:52 879] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42842 Q:1 Data:{"dps":{"105":false}}
[2024/8/7 9:27:52 879] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:52 895] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:52 895] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:27:52 911] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:52 911] __dp_data_report_data 4
[2024/8/7 9:27:52 911] 65 01 01 01 
[2024/8/7 9:27:52 911] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:52 927] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:52 927] bt_ack_uncrypt 4
[2024/8/7 9:27:52 927] 65 01 01 01 
[2024/8/7 9:27:52 927] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:52 943] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"101":true}
[2024/8/7 9:27:52 943] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42843 Q:1 Data:{"dps":{"101":true}}
[2024/8/7 9:27:52 959] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:52 959] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:52 976] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:52 976] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:52 976] __dp_data_report_data 4
[2024/8/7 9:27:52 976] 67 01 01 00 
[2024/8/7 9:27:52 992] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:52 992] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:52 992] bt_ack_uncrypt 4
[2024/8/7 9:27:52 992] 67 01 01 00 
[2024/8/7 9:27:53 008] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 008] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"103":false}
[2024/8/7 9:27:53 024] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42844 Q:1 Data:{"dps":{"103":false}}
[2024/8/7 9:27:53 024] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 040] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:53 040] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:27:53 056] [08-07 09:27:55 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:27:53 056] [08-07 09:27:55 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:27:53 056] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:53 072] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:53 072] tuya_hal_bt_send 20
[2024/8/7 9:27:53 072] 00 31 37 __dp_data_report_data 4
[2024/8/7 9:27:53 072] 68 01 01 01 
[2024/8/7 9:27:53 088] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 088] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:53 088] bt_ack_uncrypt 4
[2024/8/7 9:27:53 088] 68 01 01 01 
[2024/8/7 9:27:53 104] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 104] 05 79 41 5c 01 77 6d 5e a6 69 61 04 08 c0 22 c8 eb 
[2024/8/7 9:27:53 104] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:53 120] 0 31 37 5 79 41 5c 1 77 6d 5e a6 69 61 4 8 c0 22 c8 eb 
[2024/8/7 9:27:53 120] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"104":true}
[2024/8/7 9:27:53 120] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:53 136] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:53 136] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42845 Q:1 Data:{"dps":{"104":true}}
[2024/8/7 9:27:53 152] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 152] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:107 not find
[2024/8/7 9:27:53 152] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:53 168] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:53 168] [08-07 09:27:55 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:53 184] [08-07 09:27:55 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:53 184] [08-07 09:27:55 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:53 200] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 200] [08-07 09:27:55 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:53 216] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:108 not find
[2024/8/7 9:27:53 216] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:53 216] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:53 232] IPC_APP_get_smart_mutile_light_mode line(546) ----------  
[2024/8/7 9:27:53 232] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[2024/8/7 9:27:53 248] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:105, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:53 248] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:105, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 264] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:105, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 264] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0
[2024/8/7 9:27:53 280] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:101, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:53 295] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:101, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 296] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:101, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 311] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0
[2024/8/7 9:27:53 312] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:103, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:53 328] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:103, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 343] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:103, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 344] IPC_APP_set_smart_mutile_light_mode line(451) ---------- :0 ,g_SMLAbility=[0]
[2024/8/7 9:27:53 344] [08-07 09:27:55 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:53 360] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:27:53 360] DEBUG: camera_set_ledMode 0x12 [08-07 09:27:55 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:53 360] 0
[2024/8/7 9:27:53 376] [08-07 09:27:55 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:53 376] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0
[2024/8/7 9:27:53 392] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:104, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:53 392] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:104, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 408] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:104, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 408] DEBUG: camera_set_dnc_mode_chn 0 
[2024/8/7 9:27:53 423] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:27:53 424] DEBUG: software pohtoR!
[2024/8/7 9:27:53 424] IPC_APP_set_smart_mutile_light_mode line(536) ---------- :mode=[0] 
[2024/8/7 9:27:53 424] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 440] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<124> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:53 455] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:53 455] __dp_data_report_data 4
[2024/8/7 9:27:53 455] 7c 04 01 00 
[2024/8/7 9:27:53 455] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 471] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:53 471] bt_ack_uncrypt 4
[2024/8/7 9:27:53 471] 7c 04 01 00 
[2024/8/7 9:27:53 472] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 488] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"124":"auto"}
[2024/8/7 9:27:53 488] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42846 Q:1 Data:{"dps":{"124":"auto"}}
[2024/8/7 9:27:53 488] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 503] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:53 519] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:27:53 519] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:53 519] __dp_data_report_data 4
[2024/8/7 9:27:53 519] 86 01 01 01 
[2024/8/7 9:27:53 535] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 535] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:53 535] bt_ack_uncrypt 4
[2024/8/7 9:27:53 535] 86 01 01 01 
[2024/8/7 9:27:53 551] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 551] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"134":true}
[2024/8/7 9:27:53 568] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42847 Q:1 Data:{"dps":{"134":true}}
[2024/8/7 9:27:53 568] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 568] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:53 584] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:53 584] __dp_data_report_data 4
[2024/8/7 9:27:53 584] 6a 04 01 01 
[2024/8/7 9:27:53 600] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 601] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:53 601] bt_ack_uncrypt 4
[2024/8/7 9:27:53 601] 6a 04 01 01 
[2024/8/7 9:27:53 616] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 616] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"106":"1"}
[2024/8/7 9:27:53 616] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42848 Q:1 Data:{"dps":{"106":"1"}}
[2024/8/7 9:27:53 632] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:53 632] tuya_hal_bt_send 20
[2024/8/7 9:27:53 648] 01 6a aa e9 00 20 b2 78 aa cc 74 76 de 71 b5 34 55 c6 21 73 
[2024/8/7 9:27:53 650] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:53 650] 1 6a aa e9 0 20 b2 78 aa cc 74 76 de 71 b5 34 55 [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 664] c6 21 73 
[2024/8/7 9:27:53 664] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:53 664] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:53 680] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:168 not find
[2024/8/7 9:27:53 680] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:53 696] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:53 696] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(855):  ---
[2024/8/7 9:27:53 696] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(866):  ---
[2024/8/7 9:27:53 712] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(872):  ---
[2024/8/7 9:27:53 712] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(892):  ---
[2024/8/7 9:27:53 728] [IPC_APP_get_alarm_zone_draw][893] alarm zone[{\"num\":1,\"region0\":{\"x\":1,\"y\":1,\"xlen\":99,\"ylen\":99}}]
[2024/8/7 9:27:53 728] [08-07 09:27:55 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:53 743] [08-07 09:27:55 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:53 761] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 761] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:169 not find
[2024/8/7 9:27:53 761] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:53 776] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:53 776] curr sd_status:1 
[2024/8/7 9:27:53 776] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 791] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:53 791] [08-07 09:27:55 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:5
[2024/8/7 9:27:53 807] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:53 807] __dp_data_report_data 7
[2024/8/7 9:27:53 807] 6e 02 04 00 00 00 05 
[2024/8/7 9:27:53 808] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 823] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:53 824] bt_ack_uncrypt 7
[2024/8/7 9:27:53 824] 6e 02 04 00 00 00 05 
[2024/8/7 9:27:53 824] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 840] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"110":5}
[2024/8/7 9:27:53 840] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42849 Q:1 Data:{"dps":{"110":5}}
[2024/8/7 9:27:53 856] handle_DP_SD_STORAGE_ONLY_GET line(654) --------------------- 
[2024/8/7 9:27:53 856] [1970-01-01 00:00:37] tuya_ipc_sd_demo.c(182) <tuya_ipc_sd_get_capacity>: XM_SDCardGetPartitionInfo failed
[2024/8/7 9:27:53 871] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:53 872] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:53 887] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:53 887] __dp_data_report_data 8
[2024/8/7 9:27:53 888] 6d 03 05 30 7c 30 7c 30 
[2024/8/7 9:27:53 888] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 903] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:53 903] bt_ack_uncrypt 8
[2024/8/7 9:27:53 903] 6d 03 05 30 7c 30 7c 30 
[2024/8/7 9:27:53 904] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:53 919] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"124":"auto"}}, mqtt async dp cb:0
[2024/8/7 9:27:53 935] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:124, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:53 936] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:124, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 951] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:124, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:53 951] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0"}
[2024/8/7 9:27:53 967] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:53 967] tuya_hal_bt_send 14
[2024/8/7 9:27:53 967] 02 10 87 04 d5 8c 16 82 3c 54 62 8d 6a d3 
[2024/8/7 9:27:53 967] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:53 983] 2 10 87 4 d5 8c 16 82 3c 54 62 8d 6a d3 
[2024/8/7 9:27:53 983] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:53 999] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:53 999] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42850 Q:1 Data:{"dps":{"109":"0|0|0"}}
[2024/8/7 9:27:54 015] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0
[2024/8/7 9:27:54 015] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:134, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:54 031] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:134, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 032] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:134, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 047] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"106":"1"}}, mqtt async dp cb:0
[2024/8/7 9:27:54 047] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:106, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:54 063] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:106, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 079] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:106, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 079] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0
[2024/8/7 9:27:54 095] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:110, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:54 095] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:110, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 111] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:110, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 111] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 128] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:54 128] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:27:54 144] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:54 144] __dp_data_report_data 4
[2024/8/7 9:27:54 144] 96 01 01 01 
[2024/8/7 9:27:54 144] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 160] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:54 160] bt_ack_uncrypt 4
[2024/8/7 9:27:54 160] 96 01 01 01 
[2024/8/7 9:27:54 160] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 176] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"150":true}
[2024/8/7 9:27:54 176] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42851 Q:1 Data:{"dps":{"150":true}}
[2024/8/7 9:27:54 192] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 192] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:54 208] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:54 208] __dp_data_report_data 4
[2024/8/7 9:27:54 208] 97 04 01 00 
[2024/8/7 9:27:54 208] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 224] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:54 224] bt_ack_uncrypt 4
[2024/8/7 9:27:54 224] 97 04 01 00 
[2024/8/7 9:27:54 224] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 240] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"151":"1"}
[2024/8/7 9:27:54 240] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42852 Q:1 Data:{"dps":{"151":"1"}}
[2024/8/7 9:27:54 255] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 256] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:54 271] [08-07 09:27:55 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:0
[2024/8/7 9:27:54 271] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:54 271] __dp_data_report_data 7
[2024/8/7 9:27:54 271] 75 02 04 00 00 00 00 
[2024/8/7 9:27:54 287] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 287] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:54 319] bt_ack_uncrypt 7
[2024/8/7 9:27:54 319] 75 02 04 00 00 00 00 
[2024/8/7 9:27:54 319] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 335] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 9:27:54 335] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42853 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 9:27:54 335] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 351] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<138> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:54 351] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:54 367] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:54 367] __dp_data_report_data 4
[2024/8/7 9:27:54 367] 8a 01 01 00 
[2024/8/7 9:27:54 367] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 383] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:54 383] bt_ack_uncrypt 4
[2024/8/7 9:27:54 383] 8a 01 01 00 
[2024/8/7 9:27:54 383] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 399] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"138":false}
[2024/8/7 9:27:54 400] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42854 Q:1 Data:{"dps":{"138":false}}
[2024/8/7 9:27:54 415] current power mode:1
[2024/8/7 9:27:54 415] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 415] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:146 not find
[2024/8/7 9:27:54 431] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:54 431] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:54 432] current battery percent:80
[2024/8/7 9:27:54 447] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 447] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:145 not find
[2024/8/7 9:27:54 447] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:54 463] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:54 463] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 479] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:54 479] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:54 495] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:54 495] __dp_data_report_data 4
[2024/8/7 9:27:54 495] aa 01 01 00 
[2024/8/7 9:27:54 495] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 511] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:54 511] bt_ack_uncrypt 4
[2024/8/7 9:27:54 511] aa 01 01 00 
[2024/8/7 9:27:54 511] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 527] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"170":false}
[2024/8/7 9:27:54 527] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42855 Q:1 Data:{"dps":{"170":false}}
[2024/8/7 9:27:54 543] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"109":"0|0|0"}}, mqtt async dp cb:0
[2024/8/7 9:27:54 543] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:109, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:54 559] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:109, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 560] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:109, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 575] src/intelligent_track_thread.c(1466) [XM_GetBodyTarckEnable]: 
[2024/8/7 9:27:54 575] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 591] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:54 591] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:54 607] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:54 607] __dp_data_report_data 4
[2024/8/7 9:27:54 607] a1 01 01 00 
[2024/8/7 9:27:54 607] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 623] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:54 623] bt_ack_uncrypt 4
[2024/8/7 9:27:54 623] a1 01 01 00 
[2024/8/7 9:27:54 623] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 640] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"161":false}
[2024/8/7 9:27:54 640] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42856 Q:1 Data:{"dps":{"161":false}}
[2024/8/7 9:27:54 656] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0
[2024/8/7 9:27:54 656] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:150, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:54 672] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:150, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 687] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:150, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 688] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 688] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:186 not find
[2024/8/7 9:27:54 703] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:54 704] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:54 704] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 719] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<133> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:54 719] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:54 736] [08-07 09:27:55 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:54 736] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:54 751] tuya_hal_bt_send 20
[2024/8/7 9:27:54 751] 00 31 38 05 74 __dp_data_report_data 4
[2024/8/7 9:27:54 751] 85 04 01 01 
[2024/8/7 9:27:54 751] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 767] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:54 767] bt_ack_uncrypt 4
[2024/8/7 9:27:54 767] 85 04 01 01 
[2024/8/7 9:27:54 767] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 783] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3"}
[2024/8/7 9:27:54 783] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42857 Q:1 Data:{"dps":{"133":"3"}}
[2024/8/7 9:27:54 799] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:54 799] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:54 816] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:54 816] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:54 816] __dp_data_report_data 4
[2024/8/7 9:27:54 816] 8b 01 01 00 
[2024/8/7 9:27:54 832] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 832] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:54 832] bt_ack_uncrypt 4
[2024/8/7 9:27:54 832] 8b 01 01 00 
[2024/8/7 9:27:54 848] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:54 848] 6c b4 [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 9:27:54 864] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42858 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 9:27:54 864] 6b 59 92 91 c2 f3 96 4a 35 38 13 21 1f 
[2024/8/7 9:27:54 864] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:54 879] 0 31 38 5 74 6c b4 6b 59 92 91 c2 f3 96 4a 35 38 13 21 1f 
[2024/8/7 9:27:54 880] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:54 880] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:54 895] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[2024/8/7 9:27:54 896] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 70 enable 0 volume
[2024/8/7 9:27:54 911] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:151, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:54 927] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:151, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 927] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:151, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 944] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[2024/8/7 9:27:54 944] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:117, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:54 959] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:117, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 975] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:117, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:54 976] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"138":false}}, mqtt async dp cb:0
[2024/8/7 9:27:54 991] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:138, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:54 991] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:138, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 008] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:138, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 008] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"170":false}}, mqtt async dp cb:0
[2024/8/7 9:27:55 024] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:170, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:55 040] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:170, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 040] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:170, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 040] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 056] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:55 072] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:55 072] __dp_data_report_data 4
[2024/8/7 9:27:55 072] 8c 04 01 01 
[2024/8/7 9:27:55 073] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 088] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:55 088] bt_ack_uncrypt 4
[2024/8/7 9:27:55 088] 8c 04 01 01 
[2024/8/7 9:27:55 088] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 104] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"140":"1"}
[2024/8/7 9:27:55 104] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42859 Q:1 Data:{"dps":{"140":"1"}}
[2024/8/7 9:27:55 104] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 120] [08-07 09:27:55 TUYA E][smart_frame.c:569] dparr[0] type not match:1 0
[2024/8/7 9:27:55 120] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3586
[2024/8/7 9:27:55 120] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 136] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:55 152] [08-07 09:27:55 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:50
[2024/8/7 9:27:55 152] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:55 152] __dp_data_report_data 7
[2024/8/7 9:27:55 152] a0 02 04 00 00 00 32 
[2024/8/7 9:27:55 168] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 168] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:55 168] bt_ack_uncrypt 7
[2024/8/7 9:27:55 168] a0 02 04 00 00 00 32 
[2024/8/7 9:27:55 184] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 184] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"160":50}
[2024/8/7 9:27:55 200] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42860 Q:1 Data:{"dps":{"160":50}}
[2024/8/7 9:27:55 200] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"161":false}}, mqtt async dp cb:0
[2024/8/7 9:27:55 216] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:161, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:55 216] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:161, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 232] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:161, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 232] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 248] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:195 not find
[2024/8/7 9:27:55 248] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:55 248] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:55 264] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 264] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:194 not find
[2024/8/7 9:27:55 279] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:55 279] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:55 280] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 296] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"133":"3"}}, mqtt async dp cb:0
[2024/8/7 9:27:55 296] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:133, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:55 312] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:133, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 328] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:133, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 328] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:55 328] tuya_hal_bt_send 20
[2024/8/7 9:27:55 344] 01 08 44 86 fc 16 4a ee 0f c4 45 91 f4 10 6f 78 [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"139":false}}, mqtt async dp cb:0
[2024/8/7 9:27:55 360] [08-07 09:27:55 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1722994075,"success":true}
[2024/8/7 9:27:55 360] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:139, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:55 376] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:139, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 392] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:139, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 392] [08-07 09:27:55 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:55 392] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"140":"1"}}, mqtt async dp cb:0
[2024/8/7 9:27:55 408] c5 84 10 a5 
[2024/8/7 9:27:55 408] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:55 408] 1 8 44 86 fc 16 4a ee f c4 45 91 f4 10 6f 78 c5 84 10 a5 
[2024/8/7 9:27:55 424] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:55 424] [08-07 09:27:55 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:55 424] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:55 440] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:158 not find
[2024/8/7 9:27:55 440] [08-07 09:27:55 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[2024/8/7 9:27:55 456] [08-07 09:27:55 TUYA D][tuya_ipc_cloud_storage.c:535] order expire or remote server error
[2024/8/7 9:27:55 472] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:140, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:55 474] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:140, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 489] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:140, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 489] [08-07 09:27:55 TUYA E][tuya_ipc_cloud_storage.c:1695] check cloud storage count failed, op_ret = -1
[2024/8/7 9:27:55 504] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"160":50}}, mqtt async dp cb:0
[2024/8/7 9:27:55 504] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:160, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:55 520] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:160, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 536] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:160, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 536] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:55 536] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:55 552] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 552] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:55 568] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:55 568] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:55 568] __dp_data_report_data 4
[2024/8/7 9:27:55 568] 9f 01 01 00 
[2024/8/7 9:27:55 584] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 584] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:55 584] bt_ack_uncrypt 4
[2024/8/7 9:27:55 584] 9f 01 01 00 
[2024/8/7 9:27:55 599] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 600] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:27:55 616] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42861 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:27:55 616] [1970-01-01 00:00:37] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:55 616] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 632] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:55 647] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:55 648] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:55 648] __dp_data_report_data 4
[2024/8/7 9:27:55 648] ae 01 01 00 
[2024/8/7 9:27:55 663] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 663] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:55 664] bt_ack_uncrypt 4
[2024/8/7 9:27:55 664] ae 01 01 00 
[2024/8/7 9:27:55 680] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 680] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"174":false}
[2024/8/7 9:27:55 695] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42862 Q:1 Data:{"dps":{"174":false}}
[2024/8/7 9:27:55 696] [1970-01-01 00:00:37] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:55 696] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 711] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:55 712] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:55 727] __dp_data_report_data 4
[2024/8/7 9:27:55 727] af 04 01 00 
[2024/8/7 9:27:55 727] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 743] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:55 745] bt_ack_uncrypt 4
[2024/8/7 9:27:55 745] af 04 01 00 
[2024/8/7 9:27:55 745] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 745] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"175":"0"}
[2024/8/7 9:27:55 759] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42863 Q:1 Data:{"dps":{"175":"0"}}
[2024/8/7 9:27:55 759] [1970-01-01 00:00:37] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:27:55 775] cruiseTimeMode is 0.
[2024/8/7 9:27:55 775] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 791] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:55 791] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:55 791] __dp_data_report_data 4
[2024/8/7 9:27:55 791] b0 04 01 00 
[2024/8/7 9:27:55 807] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 807] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:55 807] bt_ack_uncrypt 4
[2024/8/7 9:27:55 807] b0 04 01 00 
[2024/8/7 9:27:55 823] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:55 823] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"176":"0"}
[2024/8/7 9:27:55 840] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42864 Q:1 Data:{"dps":{"176":"0"}}
[2024/8/7 9:27:55 840] [1970-01-01 00:00:37] utils.c(322) <ReadTYJsonConfig>: Get antiFlicker object error!
[2024/8/7 9:27:55 840] anti Flicker mode is 0.
[2024/8/7 9:27:55 856] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 856] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:188 not find
[2024/8/7 9:27:55 856] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:55 872] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:55 872] [1970-01-01 00:00:37] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:27:55 888] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 888] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:192 not find
[2024/8/7 9:27:55 888] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:55 904] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:55 904] [1970-01-01 00:00:37] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:27:55 904] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 920] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:193 not find
[2024/8/7 9:27:55 920] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:55 936] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:55 936] [1970-01-01 00:00:37] utils.c(322) <ReadTYJsonConfig>: Get FlightWarn object error!
[2024/8/7 9:27:55 936] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:55 952] [08-07 09:27:55 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:173 not find
[2024/8/7 9:27:55 952] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:27:55 968] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722994075, rept_cnt:2.
[2024/8/7 9:27:55 984] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:55 984] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 000] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"174":false}}, mqtt async dp cb:0
[2024/8/7 9:27:56 000] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:174, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:56 015] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:174, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 031] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:174, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 031] [08-07 09:27:55 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:27:56 031] [08-07 09:27:55 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:27:56 047] [1970-01-01 00:00:37] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:27:56 047] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:56 063] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:56 063] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:56 079] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:56 079] __dp_data_report_data 4
[2024/8/7 9:27:56 079] 78 01 01 00 
[2024/8/7 9:27:56 079] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:56 095] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:56 096] bt_ack_uncrypt 4
[2024/8/7 9:27:56 096] 78 01 01 00 
[2024/8/7 9:27:56 096] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:56 111] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"120":false}
[2024/8/7 9:27:56 111] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42865 Q:1 Data:{"dps":{"120":false}}
[2024/8/7 9:27:56 127] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:56 127] tuya_hal_bt_send 14
[2024/8/7 9:27:56 127] 02 d3 36 78 ec ac a5 73 60 c1 40 7f 5f 7f 
[2024/8/7 9:27:56 127] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:56 143] 2 d3 36 78 ec ac a5 73 60 c1 40 7f 5f 7f 
[2024/8/7 9:27:56 143] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:56 159] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:56 159] [08-07 09:27:55 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:56 159] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"175":"0"}}, mqtt async dp cb:0
[2024/8/7 9:27:56 175] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:175, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:56 191] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:175, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 191] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:175, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 208] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"176":"0"}}, mqtt async dp cb:0
[2024/8/7 9:27:56 208] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:176, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:56 223] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:176, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 223] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:176, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 240] [08-07 09:27:55 TUYA D][smart_frame.c:419] dp<231> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:56 256] [08-07 09:27:55 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:56 256] [08-07 09:27:55 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:56 256] __dp_data_report_data 4
[2024/8/7 9:27:56 257] e7 01 01 00 
[2024/8/7 9:27:56 272] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:56 272] [08-07 09:27:55 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:56 272] bt_ack_uncrypt 4
[2024/8/7 9:27:56 272] e7 01 01 00 
[2024/8/7 9:27:56 287] [08-07 09:27:55 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:56 288] [08-07 09:27:55 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"231":false}
[2024/8/7 9:27:56 303] [08-07 09:27:55 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42866 Q:1 Data:{"dps":{"231":false}}
[2024/8/7 9:27:56 304] [08-07 09:27:55 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}","t":1722994075}
[2024/8/7 9:27:56 320] [08-07 09:27:55 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6c7de378a95449e877rsmm&et=1&t=1722994075&v=1.0&sign=88b23c2de47e4667d6ae7cbf5c03f198
[2024/8/7 9:27:56 335] [08-07 09:27:55 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:56 335] [08-07 09:27:55 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:56 351] [08-07 09:27:55 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:56 351] [08-07 09:27:55 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:56 367] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"120":false}}, mqtt async dp cb:0
[2024/8/7 9:27:56 367] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:120, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:56 383] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:120, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 399] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:120, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 399] [08-07 09:27:55 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"231":false}}, mqtt async dp cb:0
[2024/8/7 9:27:56 415] [08-07 09:27:55 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:231, curr_t:1722994075, rept_cnt:1.
[2024/8/7 9:27:56 415] [08-07 09:27:55 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:231, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 431] [08-07 09:27:55 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:231, curr_t:1722994075, rept_cnt:0.
[2024/8/7 9:27:56 431] [08-07 09:27:55 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:56 447] [08-07 09:27:55 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:56 463] [08-07 09:27:55 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:56 464] [08-07 09:27:55 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:56 464] [08-07 09:27:55 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:56 479] [08-07 09:27:55 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:56 479] [08-07 09:27:55 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:56 495] [08-07 09:27:55 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:56 495] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:56 495] tuya_hal_bt_send 20
[2024/8/7 9:27:56 511] 00 31 39 05 90 10 d0 e9 a2 63 2c 17 79 76 cb b1 09 6c d0 8f 
[2024/8/7 9:27:56 511] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:56 511] 0 31 39 5 90 10 d0 e9 a2 63 2c 17 79 76 cb b1 9 6c d0 8f 
[2024/8/7 9:27:56 528] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:56 528] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:56 544] [08-07 09:27:55 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:56 559] [08-07 09:27:55 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:56 559] [1970-01-01 00:00:37] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:27:56 575] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:56 575] tuya_hal_bt_send 20
[2024/8/7 9:27:56 575] 01 62 a4 f7 cb dc 37 4c 19 a1 cf 05 7b 16 73 10 71 d8 50 2d 
[2024/8/7 9:27:56 591] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:56 591] 1 62 a4 f7 cb dc 37 4c 19 a1 cf 5 7b 16 73 10 71 d8 50 2d 
[2024/8/7 9:27:56 591] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:56 607] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:56 607] [08-07 09:27:55 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994075,"success":true}
[2024/8/7 9:27:56 623] [08-07 09:27:55 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:56 623] [08-07 09:27:55 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:56 639] [08-07 09:27:55 TUYA D][tuya_ipc_skill.c:198] upload data: {\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}
[2024/8/7 9:27:56 639] [08-07 09:27:55 TUYA D][MainApp.c:597] tuya_ipc_sdk_mqtt_online_proc is end run
[2024/8/7 9:27:56 657] [1970-01-01 00:00:37] MainApp.c(599) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:27:56 657] tuya_ipc_p2p_demo.c(455)<TUYA_APP_Enable_P2PTransfer> Dbg: Init P2P With Max Users:5
[2024/8/7 9:27:56 657] [08-07 09:27:55 TUYA D][tuya_ipc_webrtc.c:1534] begin___
[2024/8/7 9:27:56 671] [08-07 09:27:55 TUYA D][tuya_ipc_webrtc.c:1541] --audio-:8000,format:101
[2024/8/7 9:27:56 671] [08-07 09:27:55 TUYA D][tuya_ipc_webrtc.c:1542] end___ audiocbk_hdl(0x18f5c)
[2024/8/7 9:27:56 687] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:5086] gw actived
[2024/8/7 9:27:56 687] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:5095] p2p max_client_num[5]
[2024/8/7 9:27:56 687] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:5096] p2p init media info:
[2024/8/7 9:27:56 703] [08-07 09:27:55 TUYA D][tuya_ipc_webrtc.c:1526] webrtc playback start_id 5
[2024/8/7 9:27:56 703] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:27:56 719] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4782] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:27:56 719] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:27:56 735] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4782] height[360] width[640] bitrate[1024]
[2024/8/7 9:27:56 735] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:27:56 735] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4794] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:27:56 751] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:27:56 751] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4794] height[360] width[640] bitrate[1024]
[2024/8/7 9:27:56 767] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:56 767] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:56 783] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:56 783] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:56 799] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:56 799] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:56 815] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:56 815] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:56 831] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:27:56 831] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:27:56 847] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4796] videoNum[2] audio codec[129] sample[0]
[2024/8/7 9:27:56 847] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4797] databits[1] channel[0]
[2024/8/7 9:27:56 864] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:5122] need speaker audio codec[129] sample[0] databits[1] channel[0] defLiveMode[0]
[2024/8/7 9:27:56 864] [08-07 09:27:55 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:27:56 880] [08-07 09:27:55 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:27:56 880] [08-07 09:27:55 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:27:56 895] [08-07 09:27:55 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = adb2cd97
[2024/8/7 9:27:56 896] [08-07 09:27:55 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[2024/8/7 9:27:56 897] [08-07 09:27:55 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:56 911] [08-07 09:27:55 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:27:56 911] [08-07 09:27:55 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:27:56 927] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:56 927] tuya_hal_bt_send 14
[2024/8/7 9:27:56 927] 02 68 d4 cb 1d 5c b9 5b b7 cb a2 0c 99 c1 
[2024/8/7 9:27:56 943] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:56 943] 2 68 d4 cb 1d 5c b9 5b b7 cb a2 c 99 c1 
[2024/8/7 9:27:56 943] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:56 959] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:56 959] [08-07 09:27:55 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:27:56 959] [08-07 09:27:55 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:27:56 975] [08-07 09:27:55 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:27:56 975] [08-07 09:27:55 TUYA D][tuya_ipc_p2p_common.c:455] update p2p_auth_info from service, type 4
[2024/8/7 9:27:56 991] [08-07 09:27:55 TUYA D][iot_httpc.c:1161] Post Data: {"type":4,"t":1722994075}
[2024/8/7 9:27:57 007] [08-07 09:27:55 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.p2p.config.get&devId=6c7de378a95449e877rsmm&et=1&t=1722994075&v=2.0&sign=ff68453cdd76d6af77c16eb91460afe9
[2024/8/7 9:27:57 007] [08-07 09:27:55 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:57 023] [08-07 09:27:55 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:57 023] [08-07 09:27:55 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:57 039] [08-07 09:27:55 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:57 039] [08-07 09:27:55 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:57 055] [08-07 09:27:55 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:57 055] [08-07 09:27:55 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:57 071] [08-07 09:27:55 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:57 071] [08-07 09:27:55 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:57 071] [08-07 09:27:55 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:57 087] [08-07 09:27:55 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:57 087] [08-07 09:27:55 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:57 103] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:57 103] tuya_hal_bt_send 20
[2024/8/7 9:27:57 103] 00 31 3a 05 3c a2 58 df 06 84 76 7f 7a 42 b0 84 ae 02 14 3f 
[2024/8/7 9:27:57 120] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 120] 0 31 3a 5 3c a2 58 df 6 84 76 7f 7a 42 b0 84 ae 2 14 3f 
[2024/8/7 9:27:57 136] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 136] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 151] [08-07 09:27:55 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:57 152] [08-07 09:27:55 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:57 168] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:57 168] tuya_hal_bt_send 20
[2024/8/7 9:27:57 168] 01 59 c3 39 0f aa b8 63 a9 fd f6 fd ec 7b bd 61 ab e8 e5 9b 
[2024/8/7 9:27:57 184] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 184] 1 59 c3 39 f aa b8 63 a9 fd f6 fd ec 7b bd 61 ab e8 e5 9b 
[2024/8/7 9:27:57 199] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 200]  ---
[2024/8/7 9:27:57 200] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 216] [08-07 09:27:55 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"p2pId":"","type":4},"t":1722994075,"success":true}
[2024/8/7 9:27:57 216] [08-07 09:27:55 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:57 216] [08-07 09:27:55 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:57 231] [08-07 09:27:55 TUYA D][tuya_ipc_p2p_common.c:381] SY P2P AUTH:{"p2pId":"","type":4}
[2024/8/7 9:27:57 232] [08-07 09:27:55 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:57 247] [08-07 09:27:55 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:27:57 247] [08-07 09:27:55 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:27:57 263] [08-07 09:27:55 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:32
[2024/8/7 9:27:57 263] [08-07 09:27:55 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 32
[2024/8/7 9:27:57 263] [08-07 09:27:55 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:27:57 279] [08-07 09:27:55 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:27:57 280] [08-07 09:27:55 TUYA D][simplekv.c:203] update crc 635069388
[2024/8/7 9:27:57 295] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:57 295] tuya_hal_bt_send 14
[2024/8/7 9:27:57 296] 02 48 01 99 c7 55 41 3c 6c 0c b2 fb de 73 
[2024/8/7 9:27:57 296] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 311] 2 48 1 99 c7 55 41 3c 6c c b2 fb de 73 
[2024/8/7 9:27:57 311] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 311] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 327] [08-07 09:27:55 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:57 327] [08-07 09:27:55 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:57 343] [08-07 09:27:55 TUYA D][tuya_ipc_p2p_common.c:458] get p2p auth info from service
[2024/8/7 9:27:57 343] [08-07 09:27:55 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:27:57 343] [08-07 09:27:55 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:27:57 359] [08-07 09:27:55 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:27:57 359] [08-07 09:27:55 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:27:57 375] [08-07 09:27:55 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:27:57 375] [08-07 09:27:55 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:27:57 375] [08-07 09:27:55 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:27:57 391] [08-07 09:27:55 TUYA D][simplekv.c:203] update crc 1150092863
[2024/8/7 9:27:57 392] [08-07 09:27:55 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:57 392] [08-07 09:27:55 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:57 407] [08-07 09:27:55 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:27:57 407] [08-07 09:27:55 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:27:57 423] [08-07 09:27:55 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:27:57 423] [08-07 09:27:55 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[2024/8/7 9:27:57 440] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:5178] p2p did[] apiLicense[] initString[]
[2024/8/7 9:27:57 440] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:5181] support p2p type = 4
[2024/8/7 9:27:57 440] P2P API Version: 244.3.4.107
[2024/8/7 9:27:57 440] [08-07 09:27:55 TUYA D][tuya_ipc_p2p.c:4974] no encrypt
[2024/8/7 9:27:57 455] 38137 (null) INFO:6241316: tuya p2p rtc sdk version: 0xf403046b, Nov 16 2023 10:52:20
[2024/8/7 9:27:57 455] tuya liteos uv
[2024/8/7 9:27:57 472] [08-07 09:27:55 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:57 472] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:57 472] tuya_hal_bt_send 20
[2024/8/7 9:27:57 488] 00 31 3b 05 c1 38 84 48 bd 7f 87 e5 5e 2e 32 b3 fb a9 57 4b 
[2024/8/7 9:27:57 488] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 488] 0 31 3b 5 c1 38 84 48 bd 7f 87 e5 5e 2e 32 b3 fb a9 57 4b 
[2024/8/7 9:27:57 504] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 504] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 519] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:57 520] tuya_hal_bt_send 20
[2024/8/7 9:27:57 520] 01 59 b7 42 9c 90 3d 43 3a e3 57 72 55 9f c3 78 1b 10 9b b8 
[2024/8/7 9:27:57 535] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 535] 1 59 b7 42 9c 90 3d 43 3a e3 57 72 55 9f c3 78 1b 10 9b b8 
[2024/8/7 9:27:57 535] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 551] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 551] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:57 567] tuya_hal_bt_send 14
[2024/8/7 9:27:57 567] 02 61 4f 53 55 4a ac 1e 52 92 40 12 62 7b 
[2024/8/7 9:27:57 567] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 567] 2 61 4f 53 55 4a ac 1e 52 92 40 12 62 7b 
[2024/8/7 9:27:57 583] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 583] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 599] [08-07 09:27:55 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:57 599] [08-07 09:27:55 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:57 615] tuya_hal_bt_send 20
[2024/8/7 9:27:57 615] 00 31 3c 05 03 19 d0 c0 98 d7 a6 76 06 d8 aa 82 02 81 4d 0a 
[2024/8/7 9:27:57 616] [08-07 09:27:55 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 631] 0 31 3c 5 3 19 d0 c0 98 d7 a6 76 6 d8 aa 82 2 81 4d a 
[2024/8/7 9:27:57 631] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 631] [08-07 09:27:55 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 647] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:57 647] tuya_hal_bt_send 20
[2024/8/7 9:27:57 647] 01 22 52 31 23 99 93 30 82 d3 cd 4f 2a 95 4a 7a be a4 11 2f 
[2024/8/7 9:27:57 663] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 663] 1 22 52 31 23 99 93 30 82 d3 cd 4f 2a 95 4a 7a be a4 11 2f 
[2024/8/7 9:27:57 680] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 680] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 696] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:57 696] tuya_hal_bt_send 14
[2024/8/7 9:27:57 696] 02 c5 1f af 53 fa ec 9d 02 7e 8c a5 bb 15 
[2024/8/7 9:27:57 696] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 711] 2 c5 1f af 53 fa ec 9d 2 7e 8c a5 bb 15 
[2024/8/7 9:27:57 712] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 712] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 727] [08-07 09:27:56 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:57 743] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:57 744] tuya_hal_bt_send 20
[2024/8/7 9:27:57 744] 00 31 3d 05 df 65 f0 f8 3d 17 ee c2 70 19 45 72 9a 92 fc 75 
[2024/8/7 9:27:57 744] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:57 759] 0 31 3d 5 df 65 f0 f8 3d 17 ee c2 70 19 45 72 9a 92 fc 75 
[2024/8/7 9:27:57 759] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:57 775] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:57 775] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:5039] _mqtt_p2p_listen_sessions create
[2024/8/7 9:27:57 775] [08-07 09:27:56 TUYA E][tuya_ipc_p2p.c:5190] p2p v3 init ok
[2024/8/7 9:27:57 791] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:4124] Begin to Listen mqtt p2p client connects In Thread
[2024/8/7 9:27:57 791] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 9:27:57 807] 38604 (null) [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:5230] speaker task create success
[2024/8/7 9:27:57 807] INFO:6241316: try listen
[2024/8/7 9:27:57 807] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:5273] __p2p_session_detech create
[2024/8/7 9:27:57 823] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:5290] __p2p_video_send_proc create ok
[2024/8/7 9:27:57 823] [08-07 09:27:56 TUYA D][tuya_ipc_upnp.c:437] tuya_ipc_upnp_init start
[2024/8/7 9:27:57 839] [08-07 09:27:56 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:156672,priority:2
[2024/8/7 9:27:57 839] [08-07 09:27:56 TUYA D][tuya_ipc_upnp.c:458] tuya_ipc_upnp_init success
[2024/8/7 9:27:57 855] [08-07 09:27:56 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[2024/8/7 9:27:57 855] [08-07 09:27:56 TUYA D][tuya_ipc_packager.c:62] get packager instance
[2024/8/7 9:27:57 855] [08-07 09:27:56 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[2024/8/7 9:27:57 871] [08-07 09:27:56 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:57 871] [08-07 09:27:56 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:57 887] [08-07 09:27:56 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:57 887] [08-07 09:27:56 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:57 887] [08-07 09:27:56 TUYA E][tuya_ipc_encrypt.c:178] read local cloud encrypt key fails ..-6
[2024/8/7 9:27:57 903] [08-07 09:27:56 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994076}
[2024/8/7 9:27:57 919] [08-07 09:27:56 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.storage.secret.get&devId=6c7de378a95449e877rsmm&et=1&t=1722994076&v=1.0&sign=289365b2458067a751c59f7d82e7850b
[2024/8/7 9:27:57 919] [08-07 09:27:56 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:57 935] [08-07 09:27:56 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:57 935] [08-07 09:27:56 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:57 951] [08-07 09:27:56 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:57 951] [08-07 09:27:56 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[2024/8/7 9:27:57 967] [08-07 09:27:56 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1722994076}
[2024/8/7 9:27:57 984] [08-07 09:27:56 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6c7de378a95449e877rsmm&et=1&t=1722994076&v=1.0&sign=2d7015b0260ab6d6f234b4db60c4eede
[2024/8/7 9:27:57 984] [08-07 09:27:56 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:57 999] [08-07 09:27:56 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:57 999] [08-07 09:27:56 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:58 015] [08-07 09:27:56 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:58 015] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:3553] New Thread To proc, init source
[2024/8/7 9:27:58 032] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:3572] session cmd recv proc alive [0] num[0]
[2024/8/7 9:27:58 032] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:58 032] tuya_hal_bt_send 20
[2024/8/7 9:27:58 048] 01 2d d4 1b bc 66 68 86 4a 5b e5 94 fa 42 b2 94 0b f0 77 97 
[2024/8/7 9:27:58 048] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:58 048] 1 2d d4 1b bc 66 68 86 4a 5b e5 94 fa 42 b2 94 b f0 77 97 
[2024/8/7 9:27:58 064] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:58 064] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:58 080] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:3771] into p2p video send
[2024/8/7 9:27:58 080] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [0]
[2024/8/7 9:27:58 080] [08-07 09:27:56 TUYA D][tuya_ipc_p2p.c:4652] Begin to session detech
[2024/8/7 9:27:58 096] [08-07 09:27:56 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:58 096] [08-07 09:27:56 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:58 112] [08-07 09:27:56 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:58 112] [08-07 09:27:56 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:58 127] [08-07 09:27:56 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:58 127] [08-07 09:27:56 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:58 143] [08-07 09:27:56 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:58 144] [08-07 09:27:56 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:58 144] [08-07 09:27:56 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:58 160] [08-07 09:27:56 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:58 176] [08-07 09:27:56 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:58 176] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:58 176] tuya_hal_bt_send 14
[2024/8/7 9:27:58 176] 02 88 a6 ca 39 bf 52 75 1c f7 02 72 e1 7f 
[2024/8/7 9:27:58 191] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:58 192] 2 88 a6 ca 39 bf 52 75 1c f7 2 72 e1 7f 
[2024/8/7 9:27:58 192] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:58 207]  ---
[2024/8/7 9:27:58 207] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:58 207] [08-07 09:27:56 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:58 223] [08-07 09:27:56 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:58 223] [08-07 09:27:56 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:58 240] [08-07 09:27:56 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:58 255] [08-07 09:27:56 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:58 255] [08-07 09:27:56 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:58 271] [08-07 09:27:56 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:58 271] [08-07 09:27:56 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:58 287] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:58 287] tuya_hal_bt_send 20
[2024/8/7 9:27:58 287] 00 31 3e 05 32 20 d5 14 3a 3d af 0d 65 34 62 e3 52 97 1e 7b 
[2024/8/7 9:27:58 303] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:58 303] 0 31 3e 5 32 20 d5 14 3a 3d af d 65 34 62 e3 52 97 1e 7b 
[2024/8/7 9:27:58 319] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:58 319] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:58 335] [08-07 09:27:56 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"unitList":[{"port":7000,"protocol":"TCP"},{"port":8080,"protocol":"TCP"},{"port":5000,"protocol":"UDP"},{"port":8000,"protocol":"UDP"}]},"t":1722994076,"success":true}
[2024/8/7 9:27:58 351] [08-07 09:27:56 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:58 351] [08-07 09:27:56 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:58 367] [08-07 09:27:56 TUYA D][tuya_ipc_upnp.c:171] upnp get config success result:{
[2024/8/7 9:27:58 367] 	"unitList":	[{
[2024/8/7 9:27:58 367] 			"port":	7000,
[2024/8/7 9:27:58 367] 			"protocol":	"TCP"
[2024/8/7 9:27:58 367] 		}, {
[2024/8/7 9:27:58 367] 			"port":	8080,
[2024/8/7 9:27:58 367] 			"port":	5000,
[2024/8/7 9:27:58 367] 			"protocol":	"UDP"
[2024/8/7 9:27:58 367] 			"port":	8000,
[2024/8/7 9:27:58 383] 			"protocol":	"UDP"
[2024/8/7 9:27:58 383] 		}]
[2024/8/7 9:27:58 383] [08-07 09:27:56 TUYA D][tuya_ipc_upnp.c:293] tuya_ipc_upnp_start start
[2024/8/7 9:27:58 399] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10.
[2024/8/7 9:27:58 399] [08-07 09:27:56 TUYA I][uni_thread.c:228] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:222208,priority:3
[2024/8/7 9:27:58 415] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0
[2024/8/7 9:27:58 431] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0
[2024/8/7 9:27:58 431] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:4791 
[2024/8/7 9:27:58 447] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 4791, in_port 4791 protocol:UDP, status:0
[2024/8/7 9:27:58 447] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:5351 
[2024/8/7 9:27:58 463] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5351, in_port 5351 protocol:UDP, status:0
[2024/8/7 9:27:58 463] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:4627 
[2024/8/7 9:27:58 479] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 4627, in_port 4627 protocol:UDP, status:0
[2024/8/7 9:27:58 495] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5!
[2024/8/7 9:27:58 495] [08-07 09:27:56 TUYA D][tuya_ipc_upnp.c:314] tuya_ipc_upnp_start success
[2024/8/7 9:27:58 495] [08-07 09:27:56 TUYA D][tuya_ipc_upnp.c:421] start upnp module success, exit thread
[2024/8/7 9:27:58 511] [08-07 09:27:56 TUYA D][uni_thread.c:310] Del Thrd:ipc_upnp
[2024/8/7 9:27:58 511] [08-07 09:27:56 TUYA D][uni_thread.c:125] del list not empty...deleting 0xf82094, next 0xf43fd0
[2024/8/7 9:27:58 527] [08-07 09:27:56 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:27:58 527] [08-07 09:27:56 TUYA D][uni_thread.c:250] Thread:UPnP_PROC Exec Start. Set to Running Stat
[2024/8/7 9:27:58 543] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:58 543] tuya_hal_bt_send 20
[2024/8/7 9:27:58 543] 01 45 2c e7 4c f0 84 32 f6 c9 fa 93 d4 f1 b0 d0 2c 92 b1 ee 
[2024/8/7 9:27:58 559] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:58 559] 1 45 2c e7 4c f0 84 32 f6 c9 fa 93 d4 f1 b0 d0 2c 92 b1 ee 
[2024/8/7 9:27:58 559] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:58 575]  ---
[2024/8/7 9:27:58 575] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:58 591] [08-07 09:27:56 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"encryptKey":"992e9749e8f3402a"},"t":1722994076,"success":true}
[2024/8/7 9:27:58 591] [08-07 09:27:56 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:58 591] [08-07 09:27:56 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:58 607] [08-07 09:27:56 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:27:58 607] [08-07 09:27:56 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:27:58 607] [08-07 09:27:56 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:27:58 623] [08-07 09:27:56 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:27:58 623] [08-07 09:27:56 TUYA D][simplekv.c:374] write key:cloud_enc_key And Value Len:32
[2024/8/7 9:27:58 639] [08-07 09:27:56 TUYA D][simplekv.c:457] new space 17 startpos:37392 size:100
[2024/8/7 9:27:58 639] [08-07 09:27:56 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:27:58 655] [08-07 09:27:56 TUYA D][simplekv.c:203] update crc 4131903026
[2024/8/7 9:27:58 655] [08-07 09:27:56 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:27:58 655] [08-07 09:27:56 TUYA D][simplekv.c:520] write success
[2024/8/7 9:27:58 671] [08-07 09:27:56 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:230400,priority:3
[2024/8/7 9:27:58 671] [08-07 09:27:56 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[2024/8/7 9:27:58 703] [08-07 09:27:56 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":90000,\"profileId\":\"\",\"width\":3840,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[2024/8/7 9:27:58 719] [1970-01-01 00:00:38] tuya_ipc_p2p_demo.c(475) <TUYA_APP_Enable_P2PTransfer>: tuya_ipc_tranfser_init ret=[0]
[2024/8/7 9:27:58 719] [1970-01-01 00:00:38] MainApp.c(606) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:27:58 735] [1970-01-01 00:00:38] MainApp.c(614) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:27:58 751] [1970-01-01 00:00:38] MainApp.c(615) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:27:58 751] [1970-01-01 00:00:38] MainApp.c(616) <tuya_ipc_sdk_mqtt_online_proc>: v_handle=[0xfba820]
[2024/8/7 9:27:58 767] [1970-01-01 00:00:38] MainApp.c(617) <tuya_ipc_sdk_mqtt_online_proc>: v_handle_sub=[0xf95fa8]
[2024/8/7 9:27:58 767] [1970-01-01 00:00:38] MainApp.c(618) <tuya_ipc_sdk_mqtt_online_proc>: a_handle_sub=[0xfba758]
[2024/8/7 9:27:58 783] [1970-01-01 00:00:38] xm_main.c(1104) <XM_RegisterTYCallFunc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:27:58 783] [1970-01-01 00:00:38] xm_main.c(1105) <XM_RegisterTYCallFunc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:27:58 799] [1970-01-01 00:00:38] xm_main.c(1106) <XM_RegisterTYCallFunc>: a_handle_sub=[0xfba758]
[2024/8/7 9:27:58 799] [1970-01-01 00:00:38] xm_main.c(1107) <XM_RegisterTYCallFunc>: v_handle=[0xfba820]
[2024/8/7 9:27:58 815] [1970-01-01 00:00:38] xm_main.c(1108) <XM_RegisterTYCallFunc>: v_handle_sub=[0xf95fa8]
[2024/8/7 9:27:58 815] [1970-01-01 00:00:38] MainApp.c(620) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:27:58 831] [1970-01-01 00:00:38] MainApp.c(621) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:27:58 831] [08-07 09:27:56 TUYA D][uni_thread.c:125] del list not empty...deleting 0xf82094, next 0xf43fd0
[2024/8/7 9:27:58 847] [08-07 09:27:56 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:27:58 847] [08-07 09:27:56 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[2024/8/7 9:27:58 863] [08-07 09:27:56 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[2024/8/7 9:27:58 863] [08-07 09:27:56 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[2024/8/7 9:27:58 879] [08-07 09:27:56 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722994076 28800
[2024/8/7 9:27:58 879] [08-07 09:27:56 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722994076 28800
[2024/8/7 9:27:58 895] --- tracepoint tuya_ipc_system_control_demo.c,XM_CheckDls_Pro(810): server time_zone 28800 time 1722994076 dls 0 loacl time 38
[2024/8/7 9:27:58 895] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:58 895] tuya_hal_bt_send 14
[2024/8/7 9:27:58 912] 02 6d 59 71 07 30 3e f4 36 37 82 ab 99 aa 
[2024/8/7 9:27:58 912] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:58 912] 2 6d 59 71 7 30 3e f4 36 37 82 ab 99 aa 
[2024/8/7 9:27:58 927] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:58 927] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:58 943] g_AudioTipsList.size() enable: 0[08-07 09:27:56 TUYA D][smart_frame.c:3490] rept chan:5
[2024/8/7 9:27:58 943] [08-07 09:27:56 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:27:58 959] [08-07 09:27:56 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:27:58 959] [08-07 09:27:56 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:27:58 959] __dp_data_report_data 4
[2024/8/7 9:27:58 959] 9f 01 01 00 
[2024/8/7 9:27:58 975] [08-07 09:27:56 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:58 975] [08-07 09:27:56 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x8001 encrpyt:5
[2024/8/7 9:27:58 975] bt_ack_uncrypt 4
[2024/8/7 9:27:58 975] 9f 01 01 00 
[2024/8/7 9:27:58 991] [08-07 09:27:56 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:27:58 991] [08-07 09:27:56 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:27:59 007] [08-07 09:27:56 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:42867 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:27:59 007] [08-07 09:27:56 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:27:59 023] [08-07 09:27:56 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722994076, rept_cnt:3.
[2024/8/7 9:27:59 023] [08-07 09:27:56 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722994076, rept_cnt:0.
[2024/8/7 9:27:59 039] [08-07 09:27:56 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722994076, rept_cnt:0.
[2024/8/7 9:27:59 055] [08-07 09:27:56 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:59 055] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:59 055] tuya_hal_bt_send 20
[2024/8/7 9:27:59 071] 00 31 3f 05 60 e4 db 1a 22 0c 28 07 40 0a 6b 13 a1 09 0e 47 
[2024/8/7 9:27:59 071] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 071] 0 31 3f 5 60 e4 db 1a 22 c 28 7 40 a 6b 13 a1 9 e 47 
[2024/8/7 9:27:59 088] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 088] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 104] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 90314ba51650
[2024/8/7 9:27:59 104] [08-07 09:27:56 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING...
[2024/8/7 9:27:59 120] [2024-08-07 09:27:56] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 168[08-07 09:27:56 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:35 ip:0xc0a81ff2
[2024/8/7 9:27:59 120] [08-07 09:27:56 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 3
[2024/8/7 9:27:59 135] [08-07 09:27:56 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:59 135] [08-07 09:27:56 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:27:59 151] [08-07 09:27:56 TUYA D][app_agent.c:600] send length:64, id:35, sequence_out:26016
[2024/8/7 9:27:59 151] [08-07 09:27:56 TUYA D][uni_thread.c:268] Thread:ipc_upnp Exec Finish. Set to Del Stat
[2024/8/7 9:27:59 167] [08-07 09:27:56 TUYA D][uni_thread.c:125] del list not empty...deleting 0xf82094, next 0xf43fd0
[2024/8/7 9:27:59 167] [08-07 09:27:56 TUYA D][uni_thread.c:132] Final Free Thread:ipc_upnp, is_self:1
[2024/8/7 9:27:59 167] [08-07 09:27:56 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:27:59 183] [08-07 09:27:56 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:27:59 183] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:59 183] tuya_hal_bt_send 20
[2024/8/7 9:27:59 199] 01 ec 04 fd 03 98 36 c5 49 1f 56 1b 04 d9 6d 0c b3 f8 9c dc 
[2024/8/7 9:27:59 199] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 200] 1 ec 4 fd 3 98 36 c5 49 1f 56 1b 4 d9 6d c b3 f8 9c dc 
[2024/8/7 9:27:59 216] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 216] [08-07 09:27:56 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 5
[2024/8/7 9:27:59 232] [08-07 09:27:56 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:59 232] [08-07 09:27:56 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:27:59 232] [08-07 09:27:56 TUYA D][app_agent.c:1540] fd:35, wk_stat = 2, type = 16
[2024/8/7 9:27:59 247] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 248] [08-07 09:27:56 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:27:59 248] [08-07 09:27:56 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:27:59 263] [08-07 09:27:56 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:0,dpnum:41.
[2024/8/7 9:27:59 295] [2024-08-07 09:27:56] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 223[08-07 09:27:56 TUYA D][smart_frame.c:2547] final pack:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"117":0,"120":false,"124":"auto","133":"3","134":true,"138":false,"139":false,"140":"1","150":true,"151":"1","159":false,"160":50,"161":false,"170":false,"174":false,"175":"0","176":"0","231":false}}
[2024/8/7 9:27:59 328] [08-07 09:27:56 TUYA D][app_agent.c:1240] Send Query To App:{"dps":{"101":true,"103":false,"104":true,"105":false,"106":"1","109":"0|0|0","110":5,"117":0,"120":false,"124":"auto","133":"3","134":true,"138":false,"139":false,"140":"1","150":true,"151":"1","159":false,"160":50,"161":false,"170":false,"174":false,"175":"0","176":"0","231":false}}
[2024/8/7 9:27:59 344] [08-07 09:27:56 TUYA D][app_agent.c:600] send length:288, id:35, sequence_out:26017
[2024/8/7 9:27:59 344] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:59 344] tuya_hal_bt_send 14
[2024/8/7 9:27:59 360] 02 91 28 0a 23 3e 11 94 46 d9 65 29 76 8e 
[2024/8/7 9:27:59 360] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 360] 2 91 28 a 23 3e 11 94 46 d9 65 29 76 8e 
[2024/8/7 9:27:59 376] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 376] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 392] [08-07 09:27:56 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.107, Nov 16 2023 10:52:20\"}","t":1722994076}
[2024/8/7 9:27:59 407] [08-07 09:27:56 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6c7de378a95449e877rsmm&et=1&t=1722994076&v=1.0&sign=35ffd9a764afff005c5f6db74c05fddf
[2024/8/7 9:27:59 423] [08-07 09:27:56 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:27:59 424] [08-07 09:27:56 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:27:59 439] [08-07 09:27:56 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:27:59 439] [08-07 09:27:56 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:27:59 439] [08-07 09:27:56 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:27:59 455] [08-07 09:27:56 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:27:59 471] [08-07 09:27:56 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:27:59 472] [08-07 09:27:56 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:27:59 472] [08-07 09:27:56 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:27:59 487] [08-07 09:27:56 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:27:59 487] [08-07 09:27:56 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:27:59 503] [08-07 09:27:56 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:59 503] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:59 503] tuya_hal_bt_send 20
[2024/8/7 9:27:59 519] 00 31 30 05 da 23 32 7d 2f d9 84 ef e3 ef 03 05 f9 11 cb d3 
[2024/8/7 9:27:59 519] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 519] 0 31 30 5 da 23 32 7d 2f d9 84 ef e3 ef 3 5 f9 11 cb d3 
[2024/8/7 9:27:59 535] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 535] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 551] [2024-08-07 09:27:56] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 951[08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:59 551] tuya_hal_bt_send 20
[2024/8/7 9:27:59 567] 01 93 22 7c c7 e5 36 88 c6 b7 ea b4 37 37 62 90 6b 02 88 10 
[2024/8/7 9:27:59 567] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 567] 1 93 22 7c c7 e5 36 88 c6 b7 ea b4 37 37 62 90 6b 2 88 10 
[2024/8/7 9:27:59 583] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 583] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 599] [08-07 09:27:56 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:27:59 615] [08-07 09:27:56 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:27:59 615] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:59 615] tuya_hal_bt_send 14
[2024/8/7 9:27:59 631] 02 31 55 6c 2f c5 4f 6b 34 83 76 8f d3 76 
[2024/8/7 9:27:59 631] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 631] 2 31 55 6c 2f c5 4f 6b 34 83 76 8f d3 76 
[2024/8/7 9:27:59 647] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 647] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 663] [08-07 09:27:56 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722994076,"success":true}
[2024/8/7 9:27:59 663] [08-07 09:27:56 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:27:59 663] [08-07 09:27:56 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:27:59 679] [08-07 09:27:56 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:59 695] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:59 695] tuya_hal_bt_send 20
[2024/8/7 9:27:59 695] 00 31 30 05 df 2b 8d 8e 05 12 7e 68 03 01 ec 7c 12 b9 50 f6 
[2024/8/7 9:27:59 695] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 711] 0 31 30 5 df 2b 8d 8e 5 12 7e 68 3 1 ec 7c 12 b9 50 f6 
[2024/8/7 9:27:59 711] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 727] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 727] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:59 727] tuya_hal_bt_send 20
[2024/8/7 9:27:59 743] 01 10 f6 a5 8c 11 03 ee 06 b3 3e 7c a6 4d e0 de 47 aa 44 90 
[2024/8/7 9:27:59 743] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 743] 1 10 f6 a5 8c 11 3 ee 6 b3 3e 7c a6 4d e0 de 47 aa 44 90 
[2024/8/7 9:27:59 759] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 759] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 775] [08-07 09:27:56 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:59 775] tuya_hal_bt_send 14
[2024/8/7 9:27:59 775] 02 96 76 8c 1e ad be df a0 4b 44 d9 51 a9 
[2024/8/7 9:27:59 775] [08-07 09:27:56 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 791] 2 96 76 8c 1e ad be df a0 4b 44 d9 51 a9 
[2024/8/7 9:27:59 791] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 807] [08-07 09:27:56 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 807] [08-07 09:27:57 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:59 823] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:59 823] tuya_hal_bt_send 20
[2024/8/7 9:27:59 823] 00 31 30 05 25 3b ed a9 4e 6c 13 d0 6e 00 4d 00 39 1d 76 84 
[2024/8/7 9:27:59 823] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 839] 0 31 30 5 25 3b ed a9 4e 6c 13 d0 6e 0 4d 0 39 1d 76 84 
[2024/8/7 9:27:59 839] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 855] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 871] [2024-08-07 09:27:56] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 7575[08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:27:59 871] tuya_hal_bt_send 20
[2024/8/7 9:27:59 871] 01 94 c7 65 b5 e9 b3 da a5 66 3d 9d ad 0f ab 46 56 b5 eb 3c 
[2024/8/7 9:27:59 887] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 887] 1 94 c7 65 b5 e9 b3 da a5 66 3d 9d ad f ab 46 56 b5 eb 3c 
[2024/8/7 9:27:59 887] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 903] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 903] [2024-08-07 09:27:56] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:27:59 919] [2024-08-07 09:27:56] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:27:59 919] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:27:59 919] tuya_hal_bt_send 14
[2024/8/7 9:27:59 935] 02 c1 94 ab e4 f8 ee 5f ff ac 56 c7 14 f2 
[2024/8/7 9:27:59 935] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 935] 2 c1 94 ab e4 f8 ee 5f ff ac 56 c7 14 f2 
[2024/8/7 9:27:59 951] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 951] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:27:59 967] [08-07 09:27:57 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:27:59 967] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:27:59 967] tuya_hal_bt_send 20
[2024/8/7 9:27:59 983] 00 31 30 05 64 ba 30 32 28 c2 03 16 43 50 16 7c 6e 0d 81 c8 
[2024/8/7 9:27:59 983] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:27:59 983] 0 31 30 5 64 ba 30 32 28 c2 3 16 43 50 16 7c 6e d 81 c8 
[2024/8/7 9:27:59 999] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:27:59 999] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 015] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:00 015] tuya_hal_bt_send 20
[2024/8/7 9:28:00 015] 01 e3 ff bf 55 c7 68 78 a3 50 8e a9 7e b9 b9 9e 2c aa 96 66 
[2024/8/7 9:28:00 031] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 031] 1 e3 ff bf 55 c7 68 78 a3 50 8e a9 7e b9 b9 9e 2c aa 96 66 
[2024/8/7 9:28:00 031] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 047]  ---
[2024/8/7 9:28:00 049] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 049] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:00 063] tuya_hal_bt_send 14
[2024/8/7 9:28:00 063] 02 5b 2d 8b 7b cb d8 5a 2f 81 17 4a 85 07 
[2024/8/7 9:28:00 063] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 063] 2 5b 2d 8b 7b cb d8 5a 2f 81 17 4a 85 7 
[2024/8/7 9:28:00 079] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 079] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 095] [08-07 09:27:57 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:00 095] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:00 111] tuya_hal_bt_send 20
[2024/8/7 9:28:00 111] 00 31 30 05 6e 81 60 16 c4 63 2c 08 34 c1 84 a2 4e 06 6b 25 
[2024/8/7 9:28:00 111] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 127] 0 31 30 5 6e 81 60 16 c4 63 2c 8 34 c1 84 a2 4e 6 6b 25 
[2024/8/7 9:28:00 127] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 127] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 143] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:00 143] tuya_hal_bt_send 20
[2024/8/7 9:28:00 143] 01 a5 70 bd b8 98 36 14 a1 79 d7 32 ab f8 6d ae 1d dd 0f f1 
[2024/8/7 9:28:00 159] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 159] 1 a5 70 bd b8 98 36 14 a1 79 d7 32 ab f8 6d ae 1d dd f f1 
[2024/8/7 9:28:00 175] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 175] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 191] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:00 191] tuya_hal_bt_send 14
[2024/8/7 9:28:00 191] 02 48 19 a0 69 79 31 c3 7d 3b 0e 9e 3d db 
[2024/8/7 9:28:00 191] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 206] 2 48 19 a0 69 79 31 c3 7d 3b e 9e 3d db 
[2024/8/7 9:28:00 206] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 207]  ---
[2024/8/7 9:28:00 207] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 223] [08-07 09:27:57 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:00 238] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:00 238] tuya_hal_bt_send 20
[2024/8/7 9:28:00 238] 00 31 30 05 86 0a 83 4b ed 2f 53 22 71 d8 c4 bf 5e af 64 c3 
[2024/8/7 9:28:00 239] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 254] 0 31 30 5 86 a 83 4b ed 2f 53 22 71 d8 c4 bf 5e af 64 c3 
[2024/8/7 9:28:00 255] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 271] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 271] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:00 271] tuya_hal_bt_send 20
[2024/8/7 9:28:00 287] 01 c8 95 89 eb f3 63 10 b7 4b 8e ad 18 ed 5e 0c 90 cf 22 ad 
[2024/8/7 9:28:00 287] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 287] 1 c8 95 89 eb f3 63 10 b7 4b 8e ad 18 ed 5e c 90 cf 22 ad 
[2024/8/7 9:28:00 303] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 303] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 320] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:00 320] tuya_hal_bt_send 14
[2024/8/7 9:28:00 320] 02 5d 83 25 37 8b fb 98 04 f4 cb f7 c8 9b 
[2024/8/7 9:28:00 320] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 336] 2 5d 83 25 37 8b fb 98 4 f4 cb f7 c8 9b 
[2024/8/7 9:28:00 336] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 352] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 352] [08-07 09:27:57 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:00 367] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:00 367] tuya_hal_bt_send 20
[2024/8/7 9:28:00 367] 00 31 30 05 ca d3 29 b8 83 7c da 74 d4 1f b3 34 ce 19 77 00 
[2024/8/7 9:28:00 367] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 384] 0 31 30 5 ca d3 29 b8 83 7c da 74 d4 1f b3 34 ce 19 77 0 
[2024/8/7 9:28:00 384] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 400] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 400] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:00 400] tuya_hal_bt_send 20
[2024/8/7 9:28:00 415] 01 a5 52 65 b2 7e[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:28:00 415]  05 3c 36 f8 a3 ff a2 37 f5 c2 5c 52 3d 3a 
[2024/8/7 9:28:00 415] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 431] 1 a5 52 65 b2 7e 5 3c 36 f8 a3 ff a2 37 f5 c2 5c 52 3d 3a 
[2024/8/7 9:28:00 431] ---[XmBleS[atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:28:00 431] endBuf][1332]: a[atbm_log]:aggtx stop queue
[2024/8/7 9:28:00 447] lready stop ble,[atbm_log]:add to pending(0)(20)
[2024/8/7 9:28:00 447] could not call xmblesendbuf
[2024/8/7 9:28:00 447]  ---
[2024/8/7 9:28:00 463] [08-07 09:27:57 TUYA D][b[atbm_log]:AMPDU[eth2]:action[2],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:00 464] t_ext_porting.c:456] [TU[atbm_log]:activated addBA response timer on tid 6
[2024/8/7 9:28:00 464] YA-BTUART]BT TX [atbm_log]:ignore pending[5][20]
[2024/8/7 9:28:00 464] end
[2024/8/7 9:28:00 464] [08-07 09:27:57 TU[atbm_log]:aggtx wake queue
[2024/8/7 9:28:00 478] YA D][tuya_ble_m[atbm_log]:not assoc 
[2024/8/7 9:28:00 478] utli_tsf_protoco[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:28:00 494] l.c:258] pkg max[atbm_log]:AMPDU[eth2]:action[3],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:00 495]  len:20, sunpkg_offset:1[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:28:00 510] [atbm_log]:AMPDU[eth2]:action[1],tid[0],ssn[0],buff_size[0],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:00 511] tuya_hal_bt_send 14
[2024/8/7 9:28:00 511] 02 02 6a a2 32 c3[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 5
[2024/8/7 9:28:00 526]  39 a4 9c 3d f0 [atbm_log]:AMPDU[eth2]:action[1],tid[5],ssn[0],buff_size[0],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:00 527] a9 43 8f 
[2024/8/7 9:28:00 543] [08-07 09:27[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:28:00 543] :57 TUYA D][bt_e[atbm_log]:AMPDU[eth2]:action[3],tid[6],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:00 558] xt_porting.c:450[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:28:00 558] ] [TUYA-BTUART]B[atbm_log]:AMPDU[eth2]:action[1],tid[6],ssn[0],buff_size[0],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:00 558] T TX:
[2024/8/7 9:28:00 558] 2 2 6a a2 32 c3 39 a4 9c 3d f0 a9 43 8f 
[2024/8/7 9:28:00 575] ---[XmBleSendB[atbm_log]:eth2: deauthenticating from a4:a9:30:ce:5e:66 by local choice (reason=3)
[2024/8/7 9:28:00 575] uf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 590] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 590] [08-07 09:27:57 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:00 607] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:00 607] tuya_hal_bt_send 20
[2024/8/7 9:28:00 607] 00 31 30 05 2c 7d 43 af f9 1e 24 cf bc d7 83 8c 70 fa 0c 5b 
[2024/8/7 9:28:00 623] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 623] 0 31 30 5 2c 7d 43 af f9 1e 24 cf bc d7 83 8c 70 fa c 5b 
[2024/8/7 9:28:00 623] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 639] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 655] [08-07 09:27:57 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, sen[atbm_log]:[TX]:[0]:deatuhen[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:00 655] d_data:19
[2024/8/7 9:28:00 655] tuya_hal_bt_send 20
[2024/8/7 9:28:00 655] 01 17 a1 08 13[atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:28:00 655]  55 f8 5b 31 e9 b2 e0 52 5a 34 88 f5 eb 38 6b 
[2024/8/7 9:28:00 671] [08-07 09:27:57 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 671] 1 17 a1 8 13 55 f8 5b 31 e9 b2 e0 52 5a 34 88 f5 eb 38 6b 
[2024/8/7 9:28:00 687] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 687] [08-07 09:27:57 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 687] [08-07 [atbm_log]:[eth2 RX]:[a4:a9:30:ce:5e:66] is not assoctiated with us
[2024/8/7 9:28:00 703] 09:27:58 TUYA D][tuya_bl[atbm_log]:[RX] MIC failure. ENCRYPTION [0],da:[ff:ff:ff:ff:ff:ff] sa:[90:31:4b:a5:07:30] bssid:[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:00 719] e_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:00 719] tuya_hal_bt_send 14
[2024/8/7 9:28:00 719] 02 08 58 47 ac eb d1 99 17 f7 5b 36 65 14 
[2024/8/7 9:28:00 719] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 735] 2 8 58 47 ac eb d1 99 17 f7 5b 36 65 14 
[2024/8/7 9:28:00 735] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 735] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 751] [2024-08-07 09:27:57] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time40470
[2024/8/7 9:28:00 767] [2024-08-07 09:27:57] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 7666[08-07 09:27:58 TUYA D][tuya_ble_api.c:697] ble_se[atbm_log]:[STA]:unjoin ++
[2024/8/7 9:28:00 767] nd_data_to_app finish. len:49, send_ret:[atbm_log]:[STA]:unjoin --
[2024/8/7 9:28:00 767] 0x0
[2024/8/7 9:28:00 783] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:00 783] tuya_hal_bt_send 20
[2024/8/7 9:28:00 783] 00 31 30 05 79 27 c2 f3 c4 66 43 82 3e c6 8e 2f c1 9a 0a 65 
[2024/8/7 9:28:00 799] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 799] 0 31 30 5 79 27 c2 f3 c4 66 43 82 3e c6 8e 2f c1 9a a 65 
[2024/8/7 9:28:00 799] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 815]  ---
[2024/8/7 9:28:00 816] [08-07 09:[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:28:00 816] 27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 831] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:00 831] tuya_hal_bt_send 20
[2024/8/7 9:28:00 831] 01 96 69 ac bc 1d 0a 48 af 46 86 e0 db 80 95 1e 39 1f dd 24 
[2024/8/7 9:28:00 847] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 847] 1 96 69 ac bc 1d a 48 af 46 86 e0 db 80 95 1e 39 1f dd 24 
[2024/8/7 9:28:00 847] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 863] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 863] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:00 863] tuya_hal_bt_send 14
[2024/8/7 9:28:00 879] 02 a2 77 bb 5b 08 c4 7d 25 31 08 74 46 54 
[2024/8/7 9:28:00 879] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 879] 2 a2 77 bb 5b 8 c4 7d 25 31 8 74 46 54 
[2024/8/7 9:28:00 894] ---[XmBleSendBuf][1332]: already[atbm_log]:eth2:free authen bss ++
[2024/8/7 9:28:00 894]  stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 895] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 910] [08-07 09:27:58 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:00 911] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:00 926] tuya_hal_bt_send 20
[2024/8/7 9:28:00 926] 00 31 30 05 46 1d 2c 8b 83 6f 0e 42 36 1c f0 77 36 fa dc 91 
[2024/8/7 9:28:00 926] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 943] 0 31 30 5 46 1d 2c 8b 83 6f e 42 36 1c f0 77 36 fa dc 91 
[2024/8/7 9:28:00 943] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 943] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:00 959] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:00 959] tuya_hal_bt_send 20
[2024/8/7 9:28:00 975] 01 ec 7f e7 4d de e6 7a 20 28 b6 e4 d3 ad ef da 09 cb 40 c4 
[2024/8/7 9:28:00 975] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:00 975] 1 ec 7f e7 4d de e6 7a 20 28 b6 e4 d3 ad ef da 9 cb 40 c4 
[2024/8/7 9:28:00 991] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:00 991] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 007] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:01 007] tuya_hal_bt_send 14
[2024/8/7 9:28:01 007] 02 02 79 ba 81 c1 29 f3 34 6d 3f b4 0f 7f 
[2024/8/7 9:28:01 007] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 023] 2 2 79 ba 81 c1 29 f3 34 6d 3f b4 f 7f 
[2024/8/7 9:28:01 023] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 023] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 039] [08-07 09:27:58 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:01 055] [2024-08-07 09:27:58] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:01 055] [08-07 09:27:58 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:28:01 055] [08-07 09:27:58 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:28:01 071] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:01 071] tuya_hal_bt_send 20
[2024/8/7 9:28:01 071] 00 31 30 05 19 fc 92 9d 6d 20 5f 23 3c 50 1b 72 ca f7 83 fd 
[2024/8/7 9:28:01 087] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 087] 0 31 30 5 19 fc 92 9d 6d 20 5f 23 3c 50 1b 72 ca f7 83 fd 
[2024/8/7 9:28:01 087] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 103] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 103] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:28:01 103] Mode(Product):0
[2024/8/7 9:28:01 103] BpuMode:[Online]
[2024/8/7 9:28:01 103] VpssMode:[Online]
[2024/8/7 9:28:01 119] [0.LimitUp_info]:
[2024/8/7 9:28:01 119] LimitUp:[Disable]
[2024/8/7 9:28:01 119] [2680*0]->[3840*0])
[2024/8/7 9:28:01 119] chn	TotalSize	ActiveSize
[2024/8/7 9:28:01 119] 0	5040*2246	2680*2160
[2024/8/7 9:28:01 119] 0	5040*2246	3840*2160
[2024/8/7 9:28:01 119] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:28:01 135] [1.VICU_info]:
[2024/8/7 9:28:01 135] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:28:01 135] 0	25.0	822	0	0	183	linear	8ddb00
[2024/8/7 9:28:01 135] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:28:01 135] en	op_type	m_chn	now
[2024/8/7 9:28:01 135] 0	1	1	1
[2024/8/7 9:28:01 135] [2.VI_info]:
[2024/8/7 9:28:01 151] chn	TotalSize	ActiveSize
[2024/8/7 9:28:01 151] 0	5040*2246	3848*2166
[2024/8/7 9:28:01 151] 1	   0*   0	   0*   0
[2024/8/7 9:28:01 151] [3.MIPI_info]:
[2024/8/7 9:28:01 151] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:28:01 167] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:28:01 167] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:28:01 167] [4.Cut_info]:
[2024/8/7 9:28:01 167] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:28:01 167] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:28:01 183] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:28:01 183] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:28:01 183] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:28:01 183] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:28:01 183] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:28:01 183] [5.IB(isp buffer info)]:
[2024/8/7 9:28:01 199] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:28:01 199] PoolId  Count  Size
[2024/8/7 9:28:01 199] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:01 215] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:01 215] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:01 231] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:01 231] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:01 247] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:01 247] tuya_hal_bt_send 20
[2024/8/7 9:28:01 247] 01 79 3a e0 23 93 cd 74 d5 3d 2e e6 e4 ba 74 b5 f1 f4 20 6b 
[2024/8/7 9:28:01 263] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 263] 1 79 3a e0 23 93 cd 74 d5 3d 2e e6 e4 ba 74 b5 f1 f4 20 6b 
[2024/8/7 9:28:01 279] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 279] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 295] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:01 295] tuya_hal_bt_send 14
[2024/8/7 9:28:01 295] 02 2a 11 95 7f 87 90 7d 8d 23 2e f3 80 b9 
[2024/8/7 9:28:01 295] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 311] 2 2a 11 95 7f 87 90 7d 8d 23 2e f3 80 b9 
[2024/8/7 9:28:01 311] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 311] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 327] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:28:01 327] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:28:01 327] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:28:01 342] 0       0         0          0          4       
[2024/8/7 9:28:01 343] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:28:01 358]      --265--            --264--                                               
[2024/8/7 9:28:01 359] Count      Line     Count      Line     
[2024/8/7 9:28:01 359] 644        480      1457       560      
[2024/8/7 9:28:01 359] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:28:01 374] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:28:01 375] 0   3840   2160    H265  0      0        0           380       983035     5        	
[2024/8/7 9:28:01 391] 1   640    360     H265  0      0        0           258       43194      6        	
[2024/8/7 9:28:01 391] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:28:01 407] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:28:01 407] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:28:01 423] 0   Y      380      0       0       15       0        380      380      526       61822         59230    111734   64641    12      
[2024/8/7 9:28:01 439] 1   Y      258      0       5       1        0        258      258      526       4057          1912     26838    2754     9       
[2024/8/7 9:28:01 455] 3   N      0        0       0       1        0        0        0        528       0             0        0        0        0       
[2024/8/7 9:28:01 455] [2024-08-07 09:27:58] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:01 471] [08-07 09:27:58 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:01 471] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:01 471] tuya_hal_bt_send 20
[2024/8/7 9:28:01 487] 00 31 30 05 57 dc c4 44 fc a3 e6 b8 73 02 ab 3f 7a 2f bc 99 
[2024/8/7 9:28:01 487] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 487] 0 31 30 5 57 dc c4 44 fc a3 e6 b8 73 2 ab 3f 7a 2f bc 99 
[2024/8/7 9:28:01 503] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 503] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 520] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:01 520] tuya_hal_bt_send 20
[2024/8/7 9:28:01 520] 01 60 98 5a 75 39 7d 2b 47 d3 8f 90 21 5f 93 4a ce 18 41 28 
[2024/8/7 9:28:01 535] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 535] 1 60 98 5a 75 39 7d 2b 47 d3 8f 90 21 5f 93 4a ce 18 41 28 
[2024/8/7 9:28:01 535] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 550]  ---
[2024/8/7 9:28:01 550] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 567] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:01 568] tuya_hal_bt_send 14
[2024/8/7 9:28:01 568] 02 61 57 f6 26 28 1e a3 50 76 3c 0e 54 7d 
[2024/8/7 9:28:01 568] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 568] 2 61 57 f6 26 28 1e a3 50 76 3c e 54 7d 
[2024/8/7 9:28:01 583] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 583] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 599] [08-07 09:27:58 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:01 599] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:01 615] tuya_hal_bt_send 20
[2024/8/7 9:28:01 615] 00 31 30 05 0b ad b1 09 51 19 c1 45 1b 6d 84 15 1d 41 ae cb 
[2024/8/7 9:28:01 615] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 631] 0 31 30 5 b ad b1 9 51 19 c1 45 1b 6d 84 15 1d 41 ae cb 
[2024/8/7 9:28:01 631] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 631] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 647] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:01 647] tuya_hal_bt_send 20
[2024/8/7 9:28:01 647] 01 91 a7 8e 4b a3 be 69 cf c2 e4 f4 e5 49 bc 87 a1 1a 68 14 
[2024/8/7 9:28:01 662] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 663] 1 91 a7 8e 4b a3 be 69 cf c2 e4 f4 e5 49 bc 87 a1 1a 68 14 
[2024/8/7 9:28:01 678] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 678] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 694] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:01 694] tuya_hal_bt_send 14
[2024/8/7 9:28:01 694] 02 b9 1d 9b ae d9 be 03 49 fb da cb b3 8b 
[2024/8/7 9:28:01 695] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 711] 2 b9 1d 9b ae d9 be 3 49 fb da cb b3 8b 
[2024/8/7 9:28:01 711] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 711] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 727] [08-07 09:27:58 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:01 742] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:01 742] tuya_hal_bt_send 20
[2024/8/7 9:28:01 742] 00 31 30 05 8a b9 dc 5c d2 9e 21 6e 8c a5 83 29 66 b2 f4 e1 
[2024/8/7 9:28:01 743] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 758] 0 31 30 5 8a b9 dc 5c d2 9e 21 6e 8c a5 83 29 66 b2 f4 e1 
[2024/8/7 9:28:01 758] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 775] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 775] [08-07 09:27:58 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:01 775] tuya_hal_bt_send 20
[2024/8/7 9:28:01 791] 01 12 22 7e 11 db 8a f8 23 75 d3 e7 39 ee 7e f1 e3 83 47 67 
[2024/8/7 9:28:01 791] [08-07 09:27:58 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 791] 1 12 22 7e 11 db 8a f8 23 75 d3 e7 39 ee 7e f1 e3 83 47 67 
[2024/8/7 9:28:01 807] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 807] [08-07 09:27:58 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 823] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:01 823] tuya_hal_bt_send 14
[2024/8/7 9:28:01 823] 02 88 c3 46 25 a3 5c f0 5c 3e 57 57 99 ea 
[2024/8/7 9:28:01 839] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 840] 2 88 c3 46 25 a3 5c f0 5c 3e 57 57 99 ea 
[2024/8/7 9:28:01 840] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 855] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 855] [08-07 09:27:59 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:01 871] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:01 871] tuya_hal_bt_send 20
[2024/8/7 9:28:01 871] 00 31 30 05 2b c3 7e 7e e1 9f ec ed 45 ef 96 ab 22 8b 0d 34 
[2024/8/7 9:28:01 887] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 887] 0 31 30 5 2b c3 7e 7e e1 9f ec ed 45 ef 96 ab 22 8b d 34 
[2024/8/7 9:28:01 887] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 903] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 903] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:01 903] tuya_hal_bt_send 20
[2024/8/7 9:28:01 919] 01 5d ee d9 09 88 06 ee 6c 67 aa 9b 50 5a ed 5a 20 52 83 5a 
[2024/8/7 9:28:01 919] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 919] 1 5d ee d9 9 88 6 ee 6c 67 aa 9b 50 5a ed 5a 20 52 83 5a 
[2024/8/7 9:28:01 935] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 935] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 951] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:01 951] tuya_hal_bt_send 14
[2024/8/7 9:28:01 951] 02 e6 cc 18 dc 18 56 0d b8 c2 6a e7 2c 3f 
[2024/8/7 9:28:01 967] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:01 967] 2 e6 cc 18 dc 18 56 d b8 c2 6a e7 2c 3f 
[2024/8/7 9:28:01 967] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:01 983] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:01 983] [08-07 09:27:59 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:01 999] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:01 999] tuya_hal_bt_send 20
[2024/8/7 9:28:01 999] 00 31 30 05 3b 01 af 1e a0 1c 8b 65 8c 23 90 ae 2e 9d 63 3f 
[2024/8/7 9:28:02 015] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:02 015] 0 31 30 5 3b 1 af 1e a0 1c 8b 65 8c 23 90 ae 2e 9d 63 3f 
[2024/8/7 9:28:02 015] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:02 031] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:02 031] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:02 047] tuya_hal_bt_send 20
[2024/8/7 9:28:02 047] 01 1d 3d f4 b4 08 0e a7 df 0e ca 30 89 07 14 ec 01 c8 22 61 
[2024/8/7 9:28:02 047] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:02 063] 1 1d 3d f4 b4 8 e a7 df e ca 30 89 7 14 ec 1 c8 22 61 
[2024/8/7 9:28:02 063] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:02 063] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:02 079] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:02 079] tuya_hal_bt_send 14
[2024/8/7 9:28:02 079] 02 d0 27 7c a3 a8 f9 f0 59 65 9f 57 0f b2 
[2024/8/7 9:28:02 095] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:02 095] 2 d0 27 7c a3 a8 f9 f0 59 65 9f 57 f b2 
[2024/8/7 9:28:02 095] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:02 111] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:02 111] [08-07 09:27:59 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:02 127] [08-07 09:27:59 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:28:02 127] [08-07 09:27:59 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:28:02 143] [08-07 09:27:59 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:28:02 143] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:02 143] tuya_hal_bt_send 20
[2024/8/7 9:28:02 158] 00 31 30 05 4c 10 d5 92 ea 55 9c e4 a9 7c 03 a0 a8 b4 d1 48 
[2024/8/7 9:28:02 158] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:02 159] 0 31 30 5 4c 10 d5 92 ea 55 9c e4 a9 7c 3 a0 a8 b4 d1 48 
[2024/8/7 9:28:02 174] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:02 174] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:02 191] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:02 191] tuya_hal_bt_send 20
[2024/8/7 9:28:02 192] 01 7c 77 53 86 ad b0 51 36 da 91 22 d9 4c 8b 1c 44 b2 52 5b 
[2024/8/7 9:28:02 206] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:02 206] 1 7c 77 53 86 ad b0 51 36 da 91 22 d9 4c 8b 1c 44 b2 52 5b 
[2024/8/7 9:28:02 206] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:02 222]  ---
[2024/8/7 9:28:02 224] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:02 224] [08-07 09:27:59 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:13
[2024/8/7 9:28:02 238] tuya_hal_bt_send 14
[2024/8/7 9:28:02 238] 02 54 94 7f dd 24 69 35 20 94 0a 84 8d ca 
[2024/8/7 9:28:02 238] [08-07 09:27:59 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:02 238] 2 54 94 7f dd 24 69 35 20 94 a 84 8d ca 
[2024/8/7 9:28:02 255] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:02 255] [08-07 09:27:59 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:02 271] [08-07 09:27:59 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:49, send_ret:0x0
[2024/8/7 9:28:02 271] [08-07 09:27:59 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 9:28:02 287] [08-07 09:27:59 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:02 287] [08-07 09:27:59 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:02 287] [08-07 09:27:59 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:02 303] [08-07 09:27:59 TUYA D][tuya_svc_schema_upgrade.c:223] schema[flvlrc] not updated since activated
[2024/8/7 9:28:02 319] [2024-08-07 09:27:59] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 7717[08-07 09:28:01 TUYA D][iot_httpc.c:1161] Post Data: {"data":"255","t":1722994081}
[2024/8/7 9:28:02 335] [08-07 09:28:01 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=atop.online.debug.log&devId=6c7de378a95449e877rsmm&et=1&t=1722994081&sign=ae9a002cba75d95f169760f6fe59286b
[2024/8/7 9:28:02 335] [08-07 09:28:01 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:02 351] [08-07 09:28:01 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:02 351] [08-07 09:28:01 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:02 367] [08-07 09:28:01 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:02 367] [08-07 09:28:01 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:02 383] [08-07 09:28:01 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:02 383] [08-07 09:28:01 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:02 399] [08-07 09:28:01 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:02 399] [08-07 09:28:01 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:02 399] [08-07 09:28:01 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:02 415] [08-07 09:28:01 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:02 431] [08-07 09:28:01 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:02 432] [08-07 09:28:01 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:02 447] [08-07 09:28:01 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722994081,"success":true}
[2024/8/7 9:28:02 447] [08-07 09:28:01 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:02 463] [08-07 09:28:01 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:02 463] [08-07 09:28:01 TUYA D][tuya_devos_entry.c:406] put rst log finish
[2024/8/7 9:28:02 479] [08-07 09:28:01 TUYA D][iot_httpc.c:1161] Post Data: {"type":"[\"timezone\",\"rateRule\"]","t":1722994081}
[2024/8/7 9:28:02 495] [08-07 09:28:01 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.get&devId=6c7de378a95449e877rsmm&et=1&t=1722994081&v=2.0&sign=c3ec60451a761f322e9ff5ce9ab927a3
[2024/8/7 9:28:02 495] [08-07 09:28:01 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:02 511] [08-07 09:28:01 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:02 511] [08-07 09:28:01 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:02 527] [08-07 09:28:01 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:02 528] [08-07 09:28:01 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:02 528] [08-07 09:28:01 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:02 543] [08-07 09:28:01 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:02 543] [08-07 09:28:01 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:02 559] [08-07 09:28:01 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:02 559] [08-07 09:28:01 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:02 575] [08-07 09:28:01 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:02 575] [08-07 09:28:01 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:02 591] [08-07 09:28:01 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:02 607] [08-07 09:28:01 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722994081,"validTime":1800}},"t":1722994081,"success":true}
[2024/8/7 9:28:02 622] [08-07 09:28:01 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:02 623] [08-07 09:28:01 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:02 639] [08-07 09:28:01 TUYA D][iot_httpc.c:3388] dynamic cfg post data:{"type":"[\"timezone\",\"rateRule\"]","t":1722994081}, ret:0.
[2024/8/7 9:28:02 639] [08-07 09:28:01 TUYA D][tuya_devos_entry.c:479] timezone:+08:00
[2024/8/7 9:28:02 639] [08-07 09:28:01 TUYA D][tuya_devos_entry.c:500] summer_time_zone:[]
[2024/8/7 9:28:02 654] [08-07 09:28:01 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:28:02 654] [08-07 09:28:01 TUYA D][simplekv.c:1251] find key:12 gw_ai
[2024/8/7 9:28:02 670] [08-07 09:28:01 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:544
[2024/8/7 9:28:02 671] [08-07 09:28:01 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:28:02 686] [08-07 09:28:01 TUYA D][tuya_devos_utils.c:205] set dp rate_rule:{"timezone":{"ackId":"0-0","config":{"dstIntervals":[],"stdTimeZone":"+08:00"},"time":1722994081,"validTime":1800}}.
[2024/8/7 9:28:02 686] [08-07 09:28:01 TUYA D][tuya_devos_utils.c:94] reset dp rate rule finish.
[2024/8/7 9:28:02 703] [08-07 09:28:01 TUYA D][iot_httpc.c:1161] Post Data: {"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722994081}
[2024/8/7 9:28:02 719] [08-07 09:28:01 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.dynamic.config.ack&devId=6c7de378a95449e877rsmm&et=1&t=1722994081&v=2.0&sign=e25248b328338c82f41efc147659b64b
[2024/8/7 9:28:02 719] [08-07 09:28:01 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:02 735] [08-07 09:28:01 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:02 751] [08-07 09:28:01 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:02 754] 
[2024/8/7 9:28:02 754] [08-07 09:28:01 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:02 754] [08-07 09:28:01 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:02 766] [08-07 09:28:01 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:02 766] [08-07 09:28:01 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:02 783] [08-07 09:28:01 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:02 783] [08-07 09:28:01 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:02 799] [08-07 09:28:01 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:02 799] [08-07 09:28:01 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:02 815] [08-07 09:28:01 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:02 815] [08-07 09:28:01 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:02 832] [08-07 09:28:01 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994081,"success":true}
[2024/8/7 9:28:02 832] [08-07 09:28:01 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:02 848] [08-07 09:28:01 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:02 848] [08-07 09:28:01 TUYA D][iot_httpc.c:2411] dynamic cfg post data:{"ackList":[{"type":"timezone","ackId":"0-0"}],"t":1722994081}, ret:0.
[2024/8/7 9:28:02 863] [2024-08-07 09:28:01] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:02 880] [2024-08-07 09:28:01] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time44472
[2024/8/7 9:28:02 882] [08-07 09:28:02 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"devId":"6c7de378a95449e877rsmm","gwId":"6c7de378a95449e877rsmm"},"protocol":11,"s":1613826,"t":1722994082}
[2024/8/7 9:28:02 897] [08-07 09:28:02 TUYA D][mqtt_client.c:916] disconnect mqtt
[2024/8/7 9:28:02 897] [08-07 09:28:02 TUYA E][app_agent.c:1479] close socket,errno:-100 errno:0
[2024/8/7 9:28:02 912] [08-07 09:28:02 TUYA D][app_agent.c:213] set socket fault 35
[2024/8/7 9:28:02 912] [08-07 09:28:02 TUYA D][app_agent.c:274] i:0,time:1722994082,c_time:1722994076,fault:1
[2024/8/7 9:28:02 912] [08-07 09:28:02 TUYA D][app_agent.c:163] close socket 35
[2024/8/7 9:28:02 927] [08-07 09:28:02 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:28:02 927] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:28:02 944] [08-07 09:28:02 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:28:02 944] [08-07 09:28:02 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:28:02 960] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:28:02 960] [08-07 09:28:02 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:28:02 976] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:02 976] [08-07 09:28:02 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:28:02 991] [08-07 09:28:02 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:28:02 991] [08-07 09:28:02 TUYA D][gw_mqc_cb.c:60] unactive
[2024/8/7 9:28:03 007] [08-07 09:28:02 TUYA E][mqtt_client.c:1652] mq_recv err:-30848 len:0
[2024/8/7 9:28:03 007] [08-07 09:28:02 TUYA D][tuya_devos_reset.c:418] unactive Reset
[2024/8/7 9:28:03 008] [08-07 09:28:02 TUYA D][tuya_devos_reset.c:261] gw reset called. tp:1 stat:1
[2024/8/7 9:28:03 023] __IPC_APP_Get_Net_Status_cb line(183) -------------------------- stat(0)==STAT_LOW_POWER 
[2024/8/7 9:28:03 023] [08-07 09:28:02 TUYA D][tuya_devos_reset.c:85] <__wf_reset> nc_tp:2, rst_tp:1, wifi_start_mode:0
[2024/8/7 9:28:03 039] [08-07 09:28:02 TUYA D][tuya_devos_reset.c:325] <__gw_reset> tuya_ble_clear_mesh
[2024/8/7 9:28:03 039] [08-07 09:28:02 TUYA D][tuya_ble_api.c:1050] start to clr appkey.
[2024/8/7 9:28:03 055] [08-07 09:28:02 TUYA D][simplekv.c:1348] delete key:ble_app_key isFuzzy:0
[2024/8/7 9:28:03 055] [08-07 09:28:02 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:28:03 055] [08-07 09:28:02 TUYA D][simplekv.c:1386] delete key find 4
[2024/8/7 9:28:03 071] [08-07 09:28:02 TUYA D][simplekv.c:1424] Delete key:ble_app_key 4 success
[2024/8/7 9:28:03 071] [08-07 09:28:02 TUYA D][simplekv.c:203] update crc 2765173418
[2024/8/7 9:28:03 071] [08-07 09:28:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:03 086] [08-07 09:28:02 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:28:03 086] [08-07 09:28:02 TUYA D][tuya_ble_api.c:1058] start to clr network_key.
[2024/8/7 9:28:03 102] [08-07 09:28:02 TUYA D][simplekv.c:1348] delete key:ble_network_key isFuzzy:0
[2024/8/7 9:28:03 103] [08-07 09:28:02 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:28:03 103] [08-07 09:28:02 TUYA D][simplekv.c:1386] delete key find 13
[2024/8/7 9:28:03 118] [08-07 09:28:02 TUYA D][simplekv.c:1424] Delete key:ble_network_key 13 success
[2024/8/7 9:28:03 118] [08-07 09:28:02 TUYA D][simplekv.c:203] update crc 3648735028
[2024/8/7 9:28:03 134] [08-07 09:28:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:03 135] [08-07 09:28:02 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:28:03 135] [08-07 09:28:02 TUYA D][tuya_ble_api.c:1035] start to clr beaconkey.
[2024/8/7 9:28:03 150] [08-07 09:28:02 TUYA D][simplekv.c:1348] delete key:ble_beaconkey isFuzzy:0
[2024/8/7 9:28:03 150] [08-07 09:28:02 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:28:03 150] [08-07 09:28:02 TUYA D][simplekv.c:1386] delete key find 14
[2024/8/7 9:28:03 166] [08-07 09:28:02 TUYA D][simplekv.c:1424] Delete key:ble_beaconkey 14 success
[2024/8/7 9:28:03 166] [08-07 09:28:02 TUYA D][simplekv.c:203] update crc 2278734398
[2024/8/7 9:28:03 182] [08-07 09:28:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:03 182] [08-07 09:28:02 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:28:03 199] [08-07 09:28:02 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":1,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:28:03 199] [08-07 09:28:02 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:28:03 215] [08-07 09:28:02 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:28:03 215] [08-07 09:28:02 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:176
[2024/8/7 9:28:03 215] [08-07 09:28:02 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:28:03 231] [08-07 09:28:02 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:28:03 231] [08-07 09:28:02 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:28:03 247] [08-07 09:28:02 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:28:03 247] [08-07 09:28:02 TUYA D][simplekv.c:203] update crc 2369644111
[2024/8/7 9:28:03 247] [08-07 09:28:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:03 263] [08-07 09:28:02 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:03 263] [08-07 09:28:02 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:28:03 263] [08-07 09:28:02 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:28:03 279] [08-07 09:28:02 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[2024/8/7 9:28:03 279] [08-07 09:28:02 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[2024/8/7 9:28:03 295] [08-07 09:28:02 TUYA D][tuya_svc_timer_task.c:107] reset. write_disk:1
[2024/8/7 9:28:03 295] [08-07 09:28:02 TUYA D][tuya_svc_timer_task.c:310] max len:128
[2024/8/7 9:28:03 295] [08-07 09:28:02 TUYA D][tuya_svc_timer_task.c:378] offset:27
[2024/8/7 9:28:03 311] [08-07 09:28:02 TUYA D][tuya_svc_timer_task.c:397] save TIMER:{"lastFetchTime":0,"cnt":0}
[2024/8/7 9:28:03 311] [08-07 09:28:02 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:28:03 327] [08-07 09:28:02 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:03 327] [08-07 09:28:02 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:03 327] [08-07 09:28:02 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:03 344] [08-07 09:28:02 TUYA D][simplekv.c:374] write key:timer_arr And Value Len:32
[2024/8/7 9:28:03 344] [08-07 09:28:02 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 32
[2024/8/7 9:28:03 359] [08-07 09:28:02 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:28:03 359] [08-07 09:28:02 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:28:03 359] [08-07 09:28:02 TUYA D][simplekv.c:203] update crc 1939728201
[2024/8/7 9:28:03 375] [08-07 09:28:02 TUYA N][mqtt_client.c:1703] mqtt close
[2024/8/7 9:28:03 375] [08-07 09:28:02 TUYA N][mqtt_client.c:839] close mqtt -->>
[2024/8/7 9:28:03 375] [08-07 09:28:02 TUYA D][mqtt_client.c:851] shutdown fd enabled
[2024/8/7 9:28:03 391] [08-07 09:28:02 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:28:03 391] [08-07 09:28:02 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:03 391] [08-07 09:28:02 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:03 407] [08-07 09:28:02 TUYA N][mqtt_client.c:886] close mqtt <<--
[2024/8/7 9:28:03 407] [08-07 09:28:02 TUYA D][mqtt_client.c:1720] mqtt fail_cnt:1, sleeptime:4779 ms
[2024/8/7 9:28:03 423] [08-07 09:28:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:03 423] [08-07 09:28:02 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:03 423] [08-07 09:28:02 TUYA D][simplekv.c:1348] delete key:last_reset_info isFuzzy:0
[2024/8/7 9:28:03 439] [08-07 09:28:02 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:28:03 439] [08-07 09:28:02 TUYA D][simplekv.c:1395] key:last_reset_info not find
[2024/8/7 9:28:03 439] [08-07 09:28:02 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:28:03 455] [08-07 09:28:02 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:28:03 455] [08-07 09:28:02 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:28:03 470] [08-07 09:28:02 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:28:03 471] [08-07 09:28:02 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:28:03 486] [08-07 09:28:02 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 16
[2024/8/7 9:28:03 487] [08-07 09:28:02 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:28:03 487] [08-07 09:28:02 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:28:03 502] [08-07 09:28:02 TUYA D][simplekv.c:203] update crc 3338743352
[2024/8/7 9:28:03 503] [08-07 09:28:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:03 503] [08-07 09:28:02 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:03 519] [08-07 09:28:02 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:28:03 519] [08-07 09:28:02 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:28:03 519] [08-07 09:28:02 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:28:03 535] [08-07 09:28:02 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:28:03 535] [08-07 09:28:02 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:28:03 551] [08-07 09:28:02 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:28:03 551] [08-07 09:28:02 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:28:03 551] [08-07 09:28:02 TUYA D][simplekv.c:203] update crc 3544163025
[2024/8/7 9:28:03 567] [08-07 09:28:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:03 567] [08-07 09:28:02 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:03 582] [08-07 09:28:02 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:28:03 583] [08-07 09:28:02 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:28:03 583] [08-07 09:28:02 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:28:03 598] [08-07 09:28:02 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:28:03 599] [08-07 09:28:02 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:28:03 615] [08-07 09:28:02 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:28:03 615] [08-07 09:28:02 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:28:03 615] [08-07 09:28:02 TUYA D][simplekv.c:203] update crc 2428709115
[2024/8/7 9:28:03 631] [08-07 09:28:02 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:03 631] [08-07 09:28:02 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:03 631] rm: can't remove '/mnt/mtd/Config/localtime': Device or resource busy
[2024/8/7 9:28:03 647] rm: can't remove '/mnt/mtd/Config/resolv.conf': Device or resource busy
[2024/8/7 9:28:03 647] rm: can't remove '/mnt/mtd/Config': Directory not empty
[2024/8/7 9:28:03 647] IPC_APP_Reset_System_CB line(143) -------------------------- 
[2024/8/7 9:28:03 679] [2024-08-07 09:28:02] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:02] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:03 679] set basic_indicator_onoff:0 
[2024/8/7 9:28:03 679] [2024-08-07 09:28:02] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:03 695] [2024-08-07 09:28:02] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:03 710] [2024-08-07 09:28:02] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:02] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:03 744] [2024-08-07 09:28:02] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 7753[2024-08-07 09:28:02] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:02] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:03 759] [2024-08-07 09:28:02] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:02] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:03 759] [08-07 09:28:03 TUYA D][tuya_ble_api.c:1426] cloud disconnected, start adv!
[2024/8/7 9:28:03 775] [08-07 09:28:03 TUYA I][bt_ext_porting.c:628] [TUYA-BTUART]start_adv
[2024/8/7 9:28:03 775] --- tracepoint bt_ext_porting.c,tuya_ext_bt_start_adv(629): start_adv ---
[2024/8/7 9:28:03 775] [08-07 09:28:03 TUYA D][tuya_ble_api.c:1376] nw stat change:2->0, rpt to app.
[2024/8/7 9:28:03 791] [08-07 09:28:03 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:28:03 807] [2024-08-07 09:28:03] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:03] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:03 823] [2024-08-07 09:28:03] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:03] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:03 839] [2024-08-07 09:28:03] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:03] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:03 854] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(150): cmd=[killall wpa_supplicant udhcpc;ifconfig eth2 down;ifconfig eth0 down;]
[2024/8/7 9:28:03 855]  ---
[2024/8/7 9:28:03 855] curr event:13 
[2024/8/7 9:28:03 871] IPC_APP_Notify_LED_Sound_Status_CB line(583) -------------------------- IPC_RESET_SUCCESS(13)
[2024/8/7 9:28:03 871] [2024-08-07 09:28:03] tuya_ipc_system_control_demo.c(585) <IPC_APP_Notify_LED_Sound_Status_CB>: [atbm_log]:atbm_ioctl_ble_stop
[2024/8/7 9:28:03 887] debug assertion [atbm_log]:ioctl_release(c26aca00)(c1ecd6c0)
[2024/8/7 9:28:03 887] failure (!XM_AudioTips(RESET, 0, 1, 0, 1))
[2024/8/7 9:28:03 887] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(155):  ---
[2024/8/7 9:28:03 903] [2024-08-07 09:28:03] xm_main.c(2440) <XMSDK_SystemRebootTY>: XMSDK_MotorGetPostion(3110,0) suc
[2024/8/7 9:28:03 919] [2024-08-07 09:28:03] xm_main.c(2064) <XM_SaveLocalPtzPosition>: Save PTZ xPosition 3110 failed
[2024/8/7 9:28:03 919] [2024-08-07 09:28:03] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/Reset_english.pcm]
[2024/8/7 9:28:03 935] [2024-08-07 09:28:03] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:28:03 935] [2024-08-07 09:28:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:28:03 951] [2024-08-07 09:28:03] xm_main.c(2445) <XMSDK_SystemRebootTY>: XM_SaveLocalPtzPosition(3110,0) failed,ret=[-1]
[2024/8/7 9:28:03 951] XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:28:03 967] [2024-08-07 09:28:03] xm_main.c(2454) <XMSDK_SystemRebootTY>: XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:28:03 983] [2024-08-07 09:28:03] ==> XMSDK_SystemReboot(198)[INFO]: Sys XMSDK_SystemReboot Reboot
[2024/8/7 9:28:03 983] [2024-08-07 09:28:03] ==> XMSDK_SystemReboot(199)[INFO]: Sys Will Reboot
[2024/8/7 9:28:03 999] [2024-08-07 09:28:03] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:03] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:03 999] set basic_indicator_onoff:0 
[2024/8/7 9:28:04 015] [2024-08-07 09:28:03] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:04 015] [2024-08-07 09:28:03] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:04 030] [08-07 09:28:03 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:28:04 030] while(lib_ble_start) before
[2024/8/7 9:28:04 031] GAP procedure initiated: terminate connection; conn_handle=1 hci_reason=19
[2024/8/7 9:28:04 046] ble_slave_gap_event->type=14
[2024/8/7 9:28:04 046] subscribe event; conn_handle=1 attr_handle=23 reason=2 prevn=1 curn=0 previ=0 curi=0
[2024/8/7 9:28:04 047] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:28:04 062]  ---
[2024/8/7 9:28:04 063] ble_slave_gap_event->type=1
[2024/8/7 9:28:04 063] disconnect; reason=534 
[2024/8/7 9:28:04 063] [08-07 09:28:04 TUYA D][tuya_upnp_module_mg.c:1432] upnpDiscover failed
[2024/8/7 9:28:04 078] [2024-08-07 09:28:04] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:04 078] [08-07 09:28:05 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 9:28:04 110] g_AudioTipsList.size() enable: 0[2024-08-07 09:28:05] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:05] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [MotionDetect] pNumber[SirenSwitch]!
[2024/8/7 9:28:04 110] [08-07 09:28:05 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:28:04 126] [2024-08-07 09:28:05] xm_musicPlayer.cpp(177) <PlayAudioTips>: match reset audio
[2024/8/7 9:28:04 142] [2024-08-07 09:28:05] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time48471
[2024/8/7 9:28:04 142] <====== ble_gap_terminate(ble_conn_handle,19);
[2024/8/7 9:28:04 142] <====== ble_smart_cfg_task end step 0
[2024/8/7 9:28:04 142] exit ble process
[2024/8/7 9:28:04 142] ble_hs_hci_cmd_reset
[2024/8/7 9:28:04 142] cli_free before
[2024/8/7 9:28:04 158] nimble_port_atbmos_free before
[2024/8/7 9:28:04 159] nimble_port_release before
[2024/8/7 9:28:04 159] ble_gap_free before
[2024/8/7 9:28:04 159] ble_hs_hci_free before
[2024/8/7 9:28:04 159] ble_hs_free before
[2024/8/7 9:28:04 159] ble_hs_free after
[2024/8/7 9:28:04 159] nimble_release after
[2024/8/7 9:28:04 174] [08-07 09:28:06 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722994086 28800
[2024/8/7 9:28:04 174] [08-07 09:28:06 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722994086 28800
[2024/8/7 9:28:05 566] [2024-08-07 09:28:06] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 7878ble_smart_cfg_exit before
[2024/8/7 9:28:05 566] ble_smart_cfg_exit after
[2024/8/7 9:28:05 566] atbm_stopThread after
[2024/8/7 9:28:05 582] [2024-08-07 09:28:07] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:05 582] [08-07 09:28:08 TUYA D][tuya_ipc_p2p.c:4753] session detect run
[2024/8/7 9:28:06 175] xmsfc_shutdown 2 2 
[2024/8/7 9:28:06 175] Restarting system.
[2024/8/7 9:28:06 223] 
[2024/8/7 9:28:06 225] 
[2024/8/7 9:28:06 225] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 9:28:06 225] CPU: XM550V200WX2
[2024/8/7 9:28:06 225] DRAM:  128 MiB
[2024/8/7 9:28:06 350] MMC:   arasan: 0
[2024/8/7 9:28:06 399] In:    serial
[2024/8/7 9:28:06 399] Out:   serial
[2024/8/7 9:28:06 399] Err:   serial
[2024/8/7 9:28:06 622] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 9:28:06 622] Press Ctrl+C to stop autoboot
[2024/8/7 9:28:07 038] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 9:28:07 038] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 9:28:07 038]    Image Name:   Linux-3.10.103+
[2024/8/7 9:28:07 038]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 9:28:07 054]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 9:28:07 054]    Load Address: 80008000
[2024/8/7 9:28:07 054]    Entry Point:  80008000
[2024/8/7 9:28:07 054]    XIP Kernel Image ... OK
[2024/8/7 9:28:07 054] Starting kernel ...
[2024/8/7 9:28:07 934] Uncompressing Linux... done, booting the kernel.
[2024/8/7 9:28:08 078] Booting Linux on physical CPU 0x0
[2024/8/7 9:28:08 094] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 9:28:08 094] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 9:28:08 094] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 9:28:08 094] Machine: xm530v200
[2024/8/7 9:28:08 110] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 9:28:08 110] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 9:28:08 110] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 9:28:08 126] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 9:28:08 143] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 9:28:08 143] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 9:28:08 143] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 9:28:08 143] Memory: 52MB = 52MB total
[2024/8/7 9:28:08 159] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 9:28:08 159] Virtual kernel memory layout:
[2024/8/7 9:28:08 159]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 9:28:08 175]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 9:28:08 175]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 9:28:08 175]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 9:28:08 175]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 9:28:08 190]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 9:28:08 190]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 9:28:08 190]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 9:28:08 190]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 9:28:08 206] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 9:28:08 206] Hierarchical RCU implementation.
[2024/8/7 9:28:08 206] NR_IRQS:128
[2024/8/7 9:28:08 206] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 9:28:08 223] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 9:28:08 223] pid_max: default: 32768 minimum: 301
[2024/8/7 9:28:08 223] Mount-cache hash table entries: 512
[2024/8/7 9:28:08 223] CPU: Testing write buffer coherency: ok
[2024/8/7 9:28:08 239] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 9:28:08 239] L310 cache controller enabled
[2024/8/7 9:28:08 239] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 9:28:08 239] CPU1: Booted secondary processor
[2024/8/7 9:28:08 254] Brought up 2 CPUs
[2024/8/7 9:28:08 255] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 9:28:08 255] CPU: All CPU(s) started in SVC mode.
[2024/8/7 9:28:08 255] NET: Registered protocol family 16
[2024/8/7 9:28:08 270] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 9:28:08 270] Serial: AMBA PL011 UART driver
[2024/8/7 9:28:08 270] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 9:28:08 270] console [ttyAMA0] enabled
[2024/8/7 9:28:08 286] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 9:28:08 286] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 9:28:08 302] bio: create slab <bio-0> at 0
[2024/8/7 9:28:08 318] usbcore: registered new interface driver usbfs
[2024/8/7 9:28:08 318] usbcore: registered new interface driver hub
[2024/8/7 9:28:08 318] usbcore: registered new device driver usb
[2024/8/7 9:28:08 334] Switching to clocksource arm_global_timer
[2024/8/7 9:28:08 334] NET: Registered protocol family 2
[2024/8/7 9:28:08 334] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:28:08 350] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:28:08 350] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 9:28:08 350] TCP: reno registered
[2024/8/7 9:28:08 350] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:28:08 366] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:28:08 366] NET: Registered protocol family 1
[2024/8/7 9:28:08 366] RPC: Registered named UNIX socket transport module.
[2024/8/7 9:28:08 366] RPC: Registered udp transport module.
[2024/8/7 9:28:08 383] RPC: Registered tcp transport module.
[2024/8/7 9:28:08 383] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 9:28:08 398] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 9:28:08 414] NFS: Registering the id_resolver key type
[2024/8/7 9:28:08 414] Key type id_resolver registered
[2024/8/7 9:28:08 414] Key type id_legacy registered
[2024/8/7 9:28:08 414] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 9:28:08 430] fuse init (API version 7.22)
[2024/8/7 9:28:08 430] msgmni has been set to 95
[2024/8/7 9:28:08 430] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 9:28:08 430] io scheduler noop registered
[2024/8/7 9:28:08 446] io scheduler deadline registered (default)
[2024/8/7 9:28:08 446] io scheduler cfq registered
[2024/8/7 9:28:08 446] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 9:28:08 462] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 9:28:08 462] uart-pl011 uart:0: no DMA platform data
[2024/8/7 9:28:08 462] uart-pl011 uart:1: no DMA platform data
[2024/8/7 9:28:08 478] uart-pl011 uart:2: no DMA platform data
[2024/8/7 9:28:08 478] brd: module loaded
[2024/8/7 9:28:08 494] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 9:28:08 494] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:28:08 510] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 9:28:08 510] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 9:28:08 510] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 9:28:08 510] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 9:28:08 526] 0x000000300000-0x000000730000 : "user"
[2024/8/7 9:28:08 526] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 9:28:08 526] PPP generic driver version 2.4.2
[2024/8/7 9:28:08 542] NET: Registered protocol family 24
[2024/8/7 9:28:08 542] usbcore: registered new interface driver asix
[2024/8/7 9:28:08 542] usbcore: registered new interface driver cdc_ether
[2024/8/7 9:28:08 542] usbcore: registered new interface driver rndis_host
[2024/8/7 9:28:08 558] XMMMAC driver:
[2024/8/7 9:28:08 558] 	platform registration... 
[2024/8/7 9:28:08 558] 	done!
[2024/8/7 9:28:08 558] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 9:28:08 558] 	IO base addr: 0xfe010000)
[2024/8/7 9:28:08 575] libphy: XMMMAC MII Bus: probed
[2024/8/7 9:28:08 575] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 9:28:08 575] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 9:28:08 575] usbcore: registered new interface driver cdc_acm
[2024/8/7 9:28:08 591] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 9:28:08 591] usbcore: registered new interface driver usbserial
[2024/8/7 9:28:08 591] usbcore: registered new interface driver option
[2024/8/7 9:28:08 607] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 9:28:08 607] usbcore: registered new interface driver qcserial
[2024/8/7 9:28:08 607] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 9:28:08 622] TCP: cubic registered
[2024/8/7 9:28:08 623] NET: Registered protocol family 17
[2024/8/7 9:28:08 623] Key type dns_resolver registered
[2024/8/7 9:28:08 623] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 9:28:08 638] registered taskstats version 1
[2024/8/7 9:28:08 638] VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 9:28:08 654] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 9:28:08 990] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 9:28:09 550] arasan_set_clock:
[2024/8/7 9:28:09 566] 	new freq 400000
[2024/8/7 9:28:09 567] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 9:28:09 582] arasan_set_clock:
[2024/8/7 9:28:09 630] 	new freq 300000arasan_set_clock:
[2024/8/7 9:28:09 646] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 9:28:09 662] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 9:28:09 662] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 9:28:09 662] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 9:28:09 678] [reg] = 0x20000078,[val]= 0xc103c0arasan_set_clock:
[2024/8/7 9:28:09 678] 	new freq 195312ff
[2024/8/7 9:28:09 678] [reg] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 9:28:09 678] [reg] = 0x20000000,[val]= 0x00000000
[2024/8/7 9:28:09 678] [reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 9:28:09 694] [reg] = 0x20050540,[val]= 0x00000001
[2024/8/7 9:28:09 695] [reg] = 0x200505f0,[i2c: module license 'Proprietary' taints kernel.
[2024/8/7 9:28:09 695] val]= 0x00000001Disabling lock debugging due to kernel taint
[2024/8/7 9:28:09 710] i2c init is ok!
[2024/8/7 9:28:09 710] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 9:28:09 838] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 9:28:09 902] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 9:28:09 935] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 9:28:09 935] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 9:28:09 966] acodec init is ok!
[2024/8/7 9:28:09 982] i2s clk:2048000Hz
[2024/8/7 9:28:10 126] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 9:28:10 142] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 9:28:10 142] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 9:28:10 142] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 9:28:10 142] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 9:28:10 158] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 9:28:10 158] usb usb1: Product: DWC OTG Controller
[2024/8/7 9:28:10 159] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 9:28:10 159] usb usb1: SerialNumber: dwc2.0
[2024/8/7 9:28:10 174] hub 1-0:1.0: USB hub found
[2024/8/7 9:28:10 174] hub 1-0:1.0: 1 port detected
[2024/8/7 9:28:10 206] xm_wdt init is ok
[2024/8/7 9:28:10 238] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 9:28:10 526] nn_kernel: NN: request mem  fail
[2024/8/7 9:28:10 542] nn_kernel: addr iomap fail
[2024/8/7 9:28:10 558] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 9:28:10 846] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 9:28:11 039] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:28:11 054] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:28:11 054] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:28:11 054] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:28:11 119] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtd/user.sh: not fusbwifi_init.
[2024/8/7 9:28:11 119] ound
[2024/8/7 9:28:11 119] PDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 9:28:11 150] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 9:28:11 182] exfatfsck 1.3.0
[2024/8/7 9:28:11 182] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:28:11 246] usb 1-1: USB disconnect, device number 3
[2024/8/7 9:28:13 118] ouput high and delay 2000ms
[2024/8/7 9:28:13 214] Auto login as root ...
[2024/8/7 9:28:13 262] (none) login: not found /dev/mmcxxx  
[2024/8/7 9:28:13 278] Tcp server success, Wait connet ...
[2024/8/7 9:28:13 278] macGuarder: Get telnetctrl Fialed, telnetctrl=0
[2024/8/7 9:28:13 294] macGuarder: Close telnetd Forever 
[2024/8/7 9:28:13 294] Get xmauto Fialed ,xmauto = 1
[2024/8/7 9:28:13 294] auto start to app 
[2024/8/7 9:28:13 598] usb 1-1: new high-speed USB device number 4 using dwc2
[2024/8/7 9:28:13 790] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:28:13 807] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:28:13 807] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:28:13 807] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:28:15 166] [atbm_log]:atbm_usb_module_init 0
[2024/8/7 9:28:15 166] [atbm_log]:platform_init(253)
[2024/8/7 9:28:15 182] [atbm_log]:SVN_VER=33341,DPLL_CLOCK=1,BUILD_TIME=[2024-04-03_14:40:53]
[2024/8/7 9:28:15 182] [atbm_log]:Probe called -1 v1
[2024/8/7 9:28:15 182] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[2024/8/7 9:28:15 182] [atbm_log]:CONFIG_TX_NO_CONFIRM
[2024/8/7 9:28:15 198] wiphy_new_nm support CONFIG_WIRELESS_EXT 
[2024/8/7 9:28:15 198] [atbm_log]:Allocated hw_priv @ c1d81960
[2024/8/7 9:28:15 214] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[2024/8/7 9:28:15 215] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c1d81960)
[2024/8/7 9:28:15 230] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c1d81960)
[2024/8/7 9:28:15 230] [atbm_log]:not support ldpc & ht40!
[2024/8/7 9:28:15 230] [atbm_log]:atbm_get_chiptype, chipver=0x5a, g_wifi_chip_type[14]
[2024/8/7 9:28:15 230] [atbm_log]:atbm_before_load_firmware++
[2024/8/7 9:28:15 246] [atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[2024/8/7 9:28:15 246] [atbm_log]:===================~_~====================
[2024/8/7 9:28:15 246] [atbm_log]:atbm_start_load_firmware++
[2024/8/7 9:28:15 262] [1970-01-fwhdr->flags 34353678 sram_addr 9022000
[2024/8/7 9:28:15 262] 01 00:00:07] <js[atbm_log]:
[2024/8/7 9:28:15 262] ======>>> load WIFI BLE COMB firmware <<<======
[2024/8/7 9:28:15 262] on_parse.c> ==> [atbm_log]:START DOWNLOAD ICCM=========
[2024/8/7 9:28:15 278] XMJSON_ParseExVb[atbm_log]:atbm_load_firmware_generic: addr 60000: len 20000
[2024/8/7 9:28:15 278] (526)[ERROR]: Get Vb object error!
[2024/8/7 9:28:15 278] [1970-01-01 00:00:07] <xm_system.c> ==> XMSDK_ParseJson(48)[ERROR]: Parse Vb Failed!
[2024/8/7 9:28:15 294] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(452)[ERROR]: Get Isp object u32Flag error set value 1!
[2024/8/7 9:28:15 310] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(464)[ERROR]: Get Isp object u32Others error set value 0!
[2024/8/7 9:28:15 326] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(476)[ERROR]: Get Isp object CmosPort error set value 0!
[2024/8/7 9:28:15 326] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(488)[ERROR]: Get Isp object splice_mode error set value 0!
[2024/8/7 9:28:15 342] [1970-01-01 00:00:06] MainApp.c(1802) <main>: build @Jul 31 2024 13:28:12
[2024/8/7 9:28:15 342] [1970-01-01 00:00:06] MainApp.c(1710) <SetLogLevel>: set Sofia log level 2 suceess
[2024/8/7 9:28:15 358] [1970-01-01 00:00:06] ==> XMSDK_SetLogLevel(226)[NOTICE]: set xmsdk log 4
[2024/8/7 9:28:15 358] [1970-01-01 00:00:07] xm_log.c(100) <XM_RegisterLogAndInit>: Register Log level 2
[2024/8/7 9:28:15 374] [1970-01-01 00:00:07] xm_hwinfo.c(162) <XM_HwinfoInit>: Sync hwinfo to Hwfile success!
[2024/8/7 9:28:15 374] Get Hw info: AppId [fvijo8jvloagv1gm], license [uuidcaab27b0a838d239], mac[j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:28:15 390] [1970-01-01 00:00:07] utils.c(974) <ReadJsonConfig>: Have not find pClass [DeviceGpio] pNumber [NetStatusLedGpio]
[2024/8/7 9:28:15 407] [1970-01-01 00:00:07] xm_device.c(226) <ParseDeviceJsonFile>: Get g_NetStatusLed [0] failed
[2024/8/7 9:28:15 407] **********************************************************************
[2024/8/7 9:28:15 407] |                      SYSTEM INFO                                       
[2024/8/7 9:28:15 422] |       product type:		RC50X80
[2024/8/7 9:28:15 422] |           DSP chip:		XM550V200
[2024/8/7 9:28:15 422] |          wifi type:		ATBM6062U
[2024/8/7 9:28:15 422] |             HW mac:		90314ba51650
[2024/8/7 9:28:15 422] |        git version:		a590e8b3
[2024/8/7 9:28:15 438] |          make time:		20240731132812
[2024/8/7 9:28:15 438] **********************************************************************
[2024/8/7 9:28:15 438] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(143)[INFO]: SensorSrcFrmRate = 25
[2024/8/7 9:28:15 454] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(137)[INFO]: SensorIFS = 0
[2024/8/7 9:28:15 454] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(156)[INFO]: Vi CapW 2680, CapH 2160, CapX 0, CapY 0
[2024/8/7 9:28:15 470] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[IN[atbm_log]:START DOWNLOAD DCCM=========
[2024/8/7 9:28:15 470] FO]: ViChn 0: size=[3840, 2160] [atbm_log]:atbm_load_firmware_generic: addr 800000: len d000
[2024/8/7 9:28:15 486] @3
[2024/8/7 9:28:15 486] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 1: size=[640, 360] @3
[2024/8/7 9:28:15 501] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 2: size=[640, 224] @3
[2024/8/7 9:28:15 501] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(406)[INFO]: ISPRsltType
[2024/8/7 9:28:15 501] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(428)[INFO]: ISPRsltType 0
[2024/8/7 9:28:15 518] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(442)[INFO]: ISPRsltType
[2024/8/7 9:28:15 533] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_Parse4gMoudle(500)[WARN]: Get 4GModule object error!
[2024/8/7 9:28:15 534] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(80)[NOTICE]: ISP=> Svtd: PAL
[2024/8/7 9:28:15 534] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(81)[NOTICE]: ISP=>RsltType: 0
[2024/8/7 9:28:15 550] 
[2024/8/7 9:28:15 550] [1970-01-01 00:00:[atbm_log]:START DOWNLOAD BLE SRAM=========
[2024/8/7 9:28:15 550] 07] ==> XMSDK_ParseJson(84)[NOTI[atbm_log]:atbm_load_firmware_generic: addr 9022000: len 10000
[2024/8/7 9:28:15 566] CE]: IRCut: gpio 19534 Swap 0
[2024/8/7 9:28:15 566] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(88)[NOTICE]: Infrared: gpio 0 swap 1
[2024/8/7 9:28:15 581] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(92)[NOTICE]: WLight: gpio 11 swap 0
[2024/8/7 9:28:15 581] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(96)[NOTICE]: IRLight: gpio 10 swap 0
[2024/8/7 9:28:15 597] [1970-01-01 00:00:07] xm_main.c(345) <AutoMaintenance_pro>: Set device auto mantenance time: -001_-1_-1 02:25:26 wenkday: Tuesday
[2024/8/7 9:28:15 614] [1970-01-01 00:00:07] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:28:15 614] [1970-01-01 00:00:07] xm_main.c(349) <AutoMaintenance_pro>: Get Last AutoMantence Date [] failed
[2024/8/7 9:28:15 629] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(99)[NOTICE]: Vi: sensorIFS=0 sensorFPS=25, capW=2680,capH=2160,capX=0,capY=0
[2024/8/7 9:28:15 645] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(100)[NOTICE]: ViChn  ImageSize      vbBlk
[2024/8/7 9:28:15 646] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    0  [3840, 2160]    3
[2024/8/7 9:28:15 662] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    1  [ 640,  360]    2
[2024/8/7 9:28:15 662] [1970-01-01 00:00:07] ==> XMSDK_ParseJs[atbm_log]:atbm_after_load_firmware++
[2024/8/7 9:28:15 662] on(105)[NOTICE]:    2  [ 640,  2[atbm_log]:alloc urb work
[2024/8/7 9:28:15 662] 24]    2
[2024/8/7 9:28:15 678] [1970-01[atbm_log]:usb:try to flush rx....
[2024/8/7 9:28:15 678] -01 00:00:07] ==> XMSDK_ParseJson(107)[NOTICE]: VencChn    MaxSize   PreReleaseVb
[2024/8/7 9:28:15 694] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    0   [3840, 2160]	 false
[2024/8/7 9:28:15 694] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    1   [ 640,  360]	 false
[2024/8/7 9:28:15 710] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(116)[NOTICE]: 4GModule: gpio 0 Swap 0
[2024/8/7 9:28:15 710] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: AudioSwap: 0
[2024/8/7 9:28:15 726] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFileDEBUG: [libispapp]:Jul  5 2024 16:14:06 ,GENERAL
[2024/8/7 9:28:15 774] [atbm_log]:flush rx[-110][0]
[2024/8/7 9:28:15 790] [atbm_log]:0x1610102c=0x4300a
[2024/8/7 9:28:15 790] [atbm_log]:0x1610102c=0x6300b
[2024/8/7 9:28:15 806] [atbm_log]:0x16101000=0x0
[2024/8/7 9:28:15 806] [atbm_log]:set_block_size=256
[2024/8/7 9:28:15 806] [atbm_log]:mdelay wait wsm_startup_done  !!
[2024/8/7 9:28:15 806] [atbm_log]:firmwareCap 31e9
[2024/8/7 9:28:15 806] [atbm_log]:firmwareCap2 1b8c
[2024/8/7 9:28:15 822] DEBUG: Vs
[2024/8/7 9:28:15 822] [atbm_log]:apollo wifi WSM init done.1e9 16td_init	[ PAL ]
[2024/8/7 9:28:15 822]    Input buffers: 32 x 1632 bytes
[2024/8/7 9:28:15 822]    Hardware: 7.21
[2024/8/7 9:28:15 853]    WSM firmware [=MODEM=DPLL24M+BLE+plat=4 ApSleep 2GHZ Jan 30 2024 10:58:03], ver: 19514, build: 6431, api: 1060, cap: 0x1B8C31E9 Config[31010]  expection 900c094, ep0 cmd addr 901b340 NumOfStations[0x10] NumOfInterfaces[3]
[2024/8/7 9:28:15 854] DEBUG[atbm_log]:EFUSE(8)				[0]
[2024/8/7 9:28:15 854] : RsltSns0	[ 8 ][atbm_log]:EFUSE(I)					[0]
[2024/8/7 9:28:15 854] DEBU[atbm_log]:EFUSE(B)			[0]
[2024/8/7 9:28:15 869] G: Dsp:		[0x0][ [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [0]
[2024/8/7 9:28:15 870] CHIPV200 ]
[2024/8/7 9:28:15 870] [atbm_log]:CAPABILITIES_NVR_IPC              [0]
[2024/8/7 9:28:15 870] [atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[2024/8/7 9:28:15 885] [atbm_log]:CAPABILITIES_WOW                  [0]
[2024/8/7 9:28:15 886] [atbm_log]:CAPABILITIES_NO_BACKOFF           [1]
[2024/8/7 9:28:15 886] [atbm_log]:CAPABILITIES_CFO                  [1]
[2024/8/7 9:28:15 886] [atbm_log]:CAPABILITIES_CHIP_FLAG            [1]
[2024/8/7 9:28:15 902] [atbm_log]:CAPABILITIES_TXCAL                [1]
[2024/8/7 9:28:15 902] [atbm_log]:CAPABILITIES_HIF_TRACE       		[0]
[2024/8/7 9:28:15 902] [atbm_log]:CAPABILITIES_FORCE_PM_ACTIVE      [0]
[2024/8/7 9:28:15 902] [atbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[2024/8/7 9:28:15 918] [atbm_log]:CAPABILITIES_ETF                  [1]
[2024/8/7 9:28:15 918] [atbm_log]:CAPABILITIES_BLE		  			[1]
[2024/8/7 9:28:15 918] [atbm_log]:CAPABILITIES_40M			  		[0]
[2024/8/7 9:28:15 918] [atbm_log]:CAPABILITIES_LDPC 		  		[0]
[2024/8/7 9:28:15 918] i2c_write timeout 0x2
[2024/8/7 9:28:15 934] DEBUG: [l[atbm_log]:CAPABILITIES_NAV_ENABLE              [0]
[2024/8/7 9:28:15 934] ibsns]:Jul  5 20[atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [0]
[2024/8/7 9:28:15 950] 24 16:13:32 ,GEN[atbm_log]:CAPABILITIES_USE_IPC              [1]
[2024/8/7 9:28:15 950] ERAL
[2024/8/7 9:28:15 950] [atbm_log]:CAPABILITIES_OUTER_PA             [0]
[2024/8/7 9:28:15 950] [atbm_log]:CAPABILITIES_WFA    [0]
[2024/8/7 9:28:15 950] [atbm_log]:CAPABILITIES_EAP_GROUP_REKEY  [0]
[2024/8/7 9:28:15 966] [atbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[2024/8/7 9:28:15 966] [atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[2024/8/7 9:28:15 966] [atbm_log]:CAPABILITIES_RXCAL       [1]
[2024/8/7 9:28:15 966] i2c_write timeout 0x2
[2024/8/7 9:28:15 982] [atbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[2024/8/7 9:28:15 982] [atbm_log]:CAPABILITIES_80211_TO_8023 [1]
[2024/8/7 9:28:15 983] [atbm_log]:CAPABILITIES_NEW_CHIPER  [1]
[2024/8/7 9:28:15 983] [atbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [0]
[2024/8/7 9:28:15 998] [atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[2024/8/7 9:28:15 998] [atbm_log]:LMAC NOT SUPPORT 40M !!!
[2024/8/7 9:28:15 998] [atbm_log]:LMAC NOT SUPPORT LDPC !!!
[2024/8/7 9:28:16 061] i2c_write timeout 0x2
[2024/8/7 9:28:16 110] i2c_write timeout 0x2
[2024/8/7 9:28:16 110] DEBUG: SC831HAI! Chn:0
[2024/8/7 9:28:16 141] DEBUG: IspNum[1]
[2024/8/7 9:28:16 141] DEBUG: IspChn:[ 0 ]
[2024/8/7 9:28:16 157] DEBUG: I2CChn:[ 0 ]
[2024/8/7 9:28:16 157] DEBUG: limitedUp: no
[2024/8/7 9:28:16 189] DEBUG: -------------SC831Hai 4K 30fps init ok! (20240322)-------------
[2024/8/7 9:28:16 205] DEBUG: camera_set_saved_status OK!
[2024/8/7 9:28:16 205] DEBUG: [libautoscene]:JulIspKo: clean cut!
[2024/8/7 9:28:16 205]   5 2024 16:13:4[atbm_log]:wsm_generic_confirm:status(2)
[2024/8/7 9:28:16 205] 2 ,GENERAL
[2024/8/7 9:28:16 221] [atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[2024/8/7 9:28:16 221] DEBUG: [libautoscene]:use libfvideo!
[2024/8/7 9:28:16 221] DEBUG: [libfvideo]:Jul  5 2024 15:41:09 
[2024/8/7 9:28:16 238] DEBU[atbm_log]:apollo wifi : can't open /data/.mac.info
[2024/8/7 9:28:16 238] G: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:28:16 238] DEBUG: [libsdnc]:Aug 22 2023 13:55:14
[2024/8/7 9:28:16 253] atbm_log]:efuse data is [0x1,0x38,0x15,0x16,0x16,0x8,0x0,0x0,0x90:0x31:0x4b:0xa5:0x16:0x50]
[2024/8/7 9:28:16 253] mDEBUG: LED: IspKo: set cut 0x0 0xf00 0x1 0x871
[2024/8/7 9:28:16 253] [IR]  tbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[2024/8/7 9:28:16 253] [1;35m
[2024/8/7 9:28:16 269] DEBUG:[atbm_log]:win txpower:0 software LED
[2024/8/7 9:28:16 269] DEBUG: [atbm_log]:use default power
[2024/8/7 9:28:16 269] hardware pohtoR!
[2024/8/7 9:28:16 269] DEBUG: isp_sample over!
[2024/8/7 9:28:16 269] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:28:16 285] (656)[INFO]: AudioSwap=[0]
[2024/8/7 9:28:16 285] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: HighAdcValue: 0
[2024/8/7 9:28:16 302] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: LowAdcValu[atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[2024/8/7 9:28:16 302] e: 0
[2024/8/7 9:28:16 302] atbm_log]:==read success==
[2024/8/7 9:28:16 302] ;32m[1970-01-01 [atbm_log]:set delta power
[2024/8/7 9:28:16 317] 00:00:07] ==> XMJSON_GetInt(570)[INFO]: IRLightLevel: 0
[2024/8/7 9:28:16 317] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: InfraredSwap: 0
[2024/8/7 9:28:16 317] [1970-[atbm_log]:get chip id [0][0][0] 
[2024/8/7 9:28:16 333] 01-01 00:00:07] [atbm_log]:current chiptype ATBM6062-U20-noLDPC 
[2024/8/7 9:28:16 333] ==> XMJSON_GetIn[atbm_log]:default country code:00,support channel=14
[2024/8/7 9:28:16 333] t(570)[INFO]: Wh[atbm_log]:Use an internal power amplifier!
[2024/8/7 9:28:16 349] iteLightLevel: 0
[2024/8/7 9:28:16 350] [atbm_log]:enable sg
[2024/8/7 9:28:16 350] [1970-01-01 00:0[atbm_log]:[eth2] has been disabled
[2024/8/7 9:28:16 350] 0:07] ==> XMJSON_GetInt(570)[INFO]: VideoHorizontalFlipGun: 0
[2024/8/7 9:28:16 365] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoVerticalFlipGun: 0
[2024/8/7 9:28:16 365] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: setMonocular: 1
[2024/8/7 9:28:16 381] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: M[atbm_log]:enable sg
[2024/8/7 9:28:16 381] otorSpeedX: 17atbm_log]:[p2p0] has been disabled
[2024/8/7 9:28:16 381] 0;39m
[2024/8/7 9:28:16 397] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedY: 17
[2024/8/7 9:28:16 399] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: soundValue: 50
[2024/8/7 9:28:16 399] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: lightChannel: 0
[2024/8/7 9:28:16 413] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: dayAndNightMode: 0
[2024/8/7 9:28:16 413] atbm_log]:ble start
[2024/8/7 9:28:16 429] ;32m[1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: [atbm_log]:[ALTOBEAM-ble_recv] start
[2024/8/7 9:28:16 429] hardAndSoftLight[atbm_log]:ble subscribe
[2024/8/7 9:28:16 429] : 1
[2024/8/7 9:28:16 429] [1970-01-01 0[atbm_log]:[ALTOBEAM-ble_xmit] start
[2024/8/7 9:28:16 429] 0:00:07] ==> XMJ[atbm_log]:ble_platform_probe(c1e11980)
[2024/8/7 9:28:16 446] SON_GetInt(570)[[atbm_log]:is registered as 'ALTOBEAM'
[2024/8/7 9:28:16 446] INFO]: ScreenSte[atbm_log]:[atbm_wtd]:set wtd_probe = 1
[2024/8/7 9:28:16 446] pSizeX: 400
[2024/8/7 9:28:16 446]        sbcore: registered new interface driver atbm_wlan
[2024/8/7 9:28:16 462] 32m[1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeY: 200
[2024/8/7 9:28:16 462] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(587)[INFO]: RatioOfGear: 1:1
[2024/8/7 9:28:16 478] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(593)[INFO]: high 1: low 1
[2024/8/7 9:28:16 494] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(690)[INFO]: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:28:16 510] [1970-01-01 00:00:07] xm_main.c(462) <GetVideoResolution>: Video resolution: captrue width 2680 height 2160 resolution main: width 3840 height 2160 extra:  width 640 height 360 [2]: width 640 height 224
[2024/8/7 9:28:16 510] [1970-01-01 00:00:07] MainApp.c(1812) <main>: version , date 20240724, time 182054, plus 0
[2024/8/7 9:28:16 526] [1970-01-01 00:00:07] ==> XMSDK_StartUp(174)[INFO]: XMSDK_StartUp enter, Jul 24 2024, 18:20:55
[2024/8/7 9:28:16 526] [1970-01-01 00:00:07] ==> IspConfigInit(158)[INFO]: maxHeight 2160 maxWidth 3840 u32RsltType 8
[2024/8/7 9:28:16 542] [1970-01-01 00:00:07] ==> XMSDK_StartUp(203)[INFO]: g_stProductMgr.viMgr.capW =[2680] g_stProductMgr.viMgr.capH = [2160]
[2024/8/7 9:28:16 558] [1970-01-01 00:00:07] ==> XMSDK_StartUp(220)[INFO]: g_stProductMgr.vencMgr.vencChn[0].maxHeight =[2160] g_stProductMgr.encMgr.vencChn[0].maxWidth = [3840]
[2024/8/7 9:28:16 575] [1970-01-01 00:00:07] ==> XMSDK_StartUp(286)[INFO]: ispCfg.u32Others 0x0
[2024/8/7 9:28:16 595] [1970-01-01 00:00:07] ==> XMSDK_StartUp(288)[INFO]: ispCfg.u32FunExt 0x0 u32Infrared 0x80000000 u32snsRsltType 0x0 u32RsltType 0x8 au32IrCut 0x80004c4e  au32SoftLed[0]: 0x800b0a11 u32Flag: 0x1 SensorRstIO: 0x800000a4 u32ComsPort: 0x0
[2024/8/7 9:28:16 595] [1970-01-01 00:00:08] ==> SampleCreate(1709)[INFO]: viChn:0 vstd:0 enter
[2024/8/7 9:28:16 617] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 0 size [3840, 2160]
[2024/8/7 9:28:16 639] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 1 size [640, 360]
[2024/8/7 9:28:16 640] [1970-01-01 00:00:08] ==> ViChnConfig(866)[INFO]: set vichn 2 size [640, 224]
[2024/8/7 9:28:16 640] [1970-01-01 00:00:08] ==> VencChCreate(1058)[INFO]: channel:0 enter
[2024/8/7 9:28:16 640] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[0].vencMem = VENCMEM_MICRO
[2024/8/7 9:28:16 668] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 0,width = 3840,height = 2160,enType = 265
[2024/8/7 9:28:16 668] NORM ENC MODE
[2024/8/7 9:28:16 668] [1970-01-01 00:00:08] ==> VencChCreate(1079)[INFO]: VcChn[1].vencMem = VENCMEM_MICRO
[2024/8/7 9:28:16 695] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 1,width = 640,height = 360,enType = 265
[2024/8/7 9:28:16 695] NORM ENC MODE
[2024/8/7 9:28:16 695] aec 1; agc 1; ans 1
[2024/8/7 9:28:16 695] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 21,DestChnId = 0,DestModId = 23
[2024/8/7 9:28:16 695] [1970-01-01 00:00:08] ==> AudioCreate(1656)[INFO]: XM_AENC_CreateCH OK
[2024/8/7 9:28:16 725] [1970-01-01 00:00:08] ==> AudioCreate(1685)[INFO]: XM_MPI_ADEC_CreateChn OK
[2024/8/7 9:28:16 725] [1970-01-01 00:00:08DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:28:16 725] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:28:16 725] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:28:16 725] DEBUG: software pohtoR!
[2024/8/7 9:28:16 726] DEBUG: camera_set_photosensitive_chn 0 1 0x1
[2024/8/7 9:28:16 753] ] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 24,DestChnId = 0,DestModId = 22
[2024/8/7 9:28:16 753] [1970-01-01 00:00:08] ==> JPEGChCreate(1556)[INFO]: enter JPEGChCreate channel=0, VencChn = 3
[2024/8/7 9:28:16 753] [1970-01-01 00:00:08] ==> COMM_VENC_Start(890)[INFO]: VencChn = 3,width = 640,height = 360,enType = 26
[2024/8/7 9:28:16 753] [1970-01-01 00:00:08] ==> COMM_VENC_Start(913)[INFO]: set JpegAttr
[2024/8/7 9:28:16 779] [1970-01-01 00:00:08] ==> SysBind(2342)[INFO]: SrcChnId = 1,SrcModId = 7,DestChnId = 3,DestModId = 7
[2024/8/7 9:28:16 802] [1970-01-01 00:00:08] ==> COMM_VENC_Start(1032)[INFO]: JPEG_CHN[3] bind VENC_CHN[1] success!.
[2024/8/7 9:28:16 802] [1970-01-01 00:00:08] MainApp.c(1816) <main>: [1970-01-01 00:00:08] MainApp.c(1823) <main>: [1970-01-01 00:00:08] MainApp.c(1883) <main>: g_fps=[12]
[2024/8/7 9:28:16 802] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=0,brc=1,w=3840,h=2160,qua=4,frame=12,br=1000,gop=4
[2024/8/7 9:28:16 824] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[0],wh[3840,2160]-----------
[2024/8/7 9:28:16 825] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:28:16 842] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=1,brc=1,w=640,h=360,qua=4,frame=9,br=256,gop=1
[2024/8/7 9:28:16 859] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[1],wh[640,360]-----------
[2024/8/7 9:28:16 859] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:28:16 873] [1970-01-01 00:00:08] MainApp.c(1885) <main>: [1970-01-01 00:00:08] MainApp.c(1893) <main>: 
[2024/8/7 9:28:16 873] [1970-01-01 00:00:08] MainApp.c(1898) <main>: 
[2024/8/7 9:28:16 886] [1970-01-01 00:00:08] xm_main.c(1899) <PtzControl_Pro>: 
[2024/8/7 9:28:16 887] PtzControl_Pro[1970-01-01 00:00:08] ==> XMSDK_MotorCreate(120)[INFO]: xlimit 5006, ylimit 2161
[2024/8/7 9:28:16 898] [1970-01-01 00:00:08] xm_main.c(1903) <PtzControl_Pro>: g_sPtz.xMaxStep 5006 g_sPtz.yMaxStep 2161 
[2024/8/7 9:28:16 898] [1970-01-01 00:00:08] xm_main.c(1375) <XM_RealAudio_Pro>: real Audio play start___
[2024/8/7 9:28:16 910] [1970-01-01 00:00:08] ==> AudioInSetFormat(68)[INFO]: pFormat.EncodeTye = 2
[2024/8/7 9:28:16 910] [1970-01-01 00:00:08] ==> XMSDK_AudioInSetFormat(445)[INFO]: anr(1) agc(1) aec(0)
[2024/8/7 9:28:16 926] aec 0; agc 1; ans 1
[2024/8/7 9:28:16 927] [1970-01-01 00:00:08] xm_main.c(1747) <XM_RealVideo_Pro>: realy video play start___0
[2024/8/7 9:28:16 942] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 0
[2024/8/7 9:28:16 943] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 0 OK
[2024/8/7 9:28:16 957] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 1
[2024/8/7 9:28:16 958] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 1 OK
[2024/8/7 9:28:16 974] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:28:16 974] [1970-01-01 00:00:08] xm_main.c(700) <XM_SetCameraFactoryConfig>: Get AutoMantence flags [0] failed
[2024/8/7 9:28:16 989] [1970-01-01 00:00:08] xm_main.c(821) <XM_SetCameraFactoryConfig>: get default language ChineseEnglish
[2024/8/7 9:28:17 005] [1970-01-01 00:00:08] xm_main.c(822) <XM_SetCameraFactoryConfig>: get defult IRcurt reverse: no picture reverse mirror:yes filp:yes
[2024/8/7 9:28:17 021] [1970-01-01 00:00:08] xm_main.c(823) <XM_SetCameraFactoryConfig>: set defult motor ptz reverse  mirror:yes filp:no
[2024/8/7 9:28:17 021] [1970-01-01 00:00:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[597],val=[1]
[2024/8/7 9:28:17 038] [1970-01-01 00:00:08] xm_main.c(824) <XM_SetCameraFactoryConfig[atbm_log]:ioctl_open(c25e5100)(c1e11980)
[2024/8/7 9:28:17 038] >: get defult autotrack [atbm_log]:atbm_ioctl_ble_start
[2024/8/7 9:28:17 038] motor reverse mirror:yes filp:no
[2024/8/7 9:28:17 053] [1970-01-01 00:00:08] xm_main.c(825) <XM_SetCameraFactoryConfig>: get defult ptz preset x:1556 y:950
[2024/8/7 9:28:17 069] [1970-01-01 00:00:08] xm_main.c(920) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:28:17 070] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:28:17 085] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:28:17 085] ************last intra 0DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:28:17 101] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:28:17 101] DEBUG: camera_set_photosensitive_chn 0 0 0x1
[2024/8/7 9:28:17 101] killall: hostapd: no process killed
[2024/8/7 9:28:17 117] ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!DEBUG: camera_set_ledType:  2
[2024/8/7 9:28:17 117] DEBUG: camera_set_dnc_mode_chn 3 
[2024/8/7 9:28:17 117] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:28:17 133] DEBUG: LED: [IR] [WL] 
[2024/8/7 9:28:17 134] DEBUG: software LED
[2024/8/7 9:28:17 134] DEBUG: software pohtoR!
[2024/8/7 9:28:17 134] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:28:17 134] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:28:17 149] DEBUG: camera_set_ledHold: 60000
[2024/8/7 9:28:17 149] [1970-01-01 00:00:08] xm_main.c(969) <XM_SetCameraFactoryConfig>: get factory language ChineseEnglish
[2024/8/7 9:28:17 166] [1970-01-01 00:00:08] xm_main.c(970) <XM_SetCameraFactoryConfig>: get factory IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:28:17 182] [1970-01-01 00:00:08] xm_main.c(971) <XM_SetCameraFactoryConfig>: set factory motor ptz reverse  mirror:yes filp:yes
[2024/8/7 9:28:17 182] [1970-01-01 00:00:08] xm_main.c(972) <XM_SetCameraFactoryConfig>: get factory autotrack motor reverse mirror:no filp:no
[2024/8/7 9:28:17 198] [1970-01-01 00:00:08] xm_main.c(973) <XM_SetCameraFactoryConfig>: get factory ptz preset x:3110 y:0
[2024/8/7 9:28:17 214] [1970-01-01 00:00:08] xm_main.c(1007) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:28:17 230] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:28:17 230] [1970-01-01 00:00:08] xm_main.c(1040) <XM_SetCameraFactoryConfig>: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:28:17 246] [1970-01-01 00:00:08] xm_main.c(1060) <XM_SetCameraFactoryConfig>: set IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:28:17 262] [1970-01-01 00:00:08] xm_main.c(1078) <XM_SetCameraFactoryConfig>: camera_set_softIr_thr(1) ret=[0]
[2024/8/7 9:28:17 262] ************last intra 0
[2024/8/7 9:28:17 262] [1970-01-01 00:00:08] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time8409
[2024/8/7 9:28:17 278] [1970-01-01 00:00:08] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 114686
[2024/8/7 9:28:17 278] [1970-01-01 00:00:08] MainApp.c(1900) <main>: 
[2024/8/7 9:28:17 278] [1970-01-01 00:00:08] MainApp.c(1905) <main>: 
[2024/8/7 9:28:17 294] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:Register pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:28:17 310] [1970-01-01 00:00:08] ==> XMSDK_AudioSetSpeakerVol(641)[INFO]: enter: Speaker Open
[2024/8/7 9:28:17 310] [1970-01-01 00:00:08] MainApp.c(1913) <main>: 
[2024/8/7 9:28:17 310] [1970-01-01 00:00:08] ==> XMSDK_WifiInit(601)[INFO]: Wifi Init success
[2024/8/7 9:28:17 326] 
[2024/8/7 9:28:17 327] [1970-01-01 00:00:08] MainApp.c(1915) <main>: 
[2024/8/7 9:28:17 327] [1970-01-01 00:00:08] MainApp.c(1918) <main>: 
[2024/8/7 9:28:17 327] lib_ble_main_init
[2024/8/7 9:28:17 327] ======>>atbm_ble_start>>>
[2024/8/7 9:28:17 327] nimble_port_init++
[2024/8/7 9:28:17 342] nimble_host_task
[2024/8/7 9:28:17 342] ble_coexist_start--
[2024/8/7 9:28:17 342] hif_ioctl_loop
[2024/8/7 9:28:17 342] ble_hs_sync:333
[2024/8/7 9:28:17 342] ble_smart_cfg_startup!11
[2024/8/7 9:28:17 342] [ATBM lOG]set default tx power(0)
[2024/8/7 9:28:17 342] pub addr 90:31:4b:a5:16:51
[2024/8/7 9:28:17 359] [1970-01-01 00:00:09] MainApp.c(1922) <main>: ble_ret=[0]
[2024/8/7 9:28:17 359] [1970-01-01 00:00:09] MainApp.c(1200) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 374] [1970-01-01 00:00:09] MainApp.c(1229) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 374] [1970-01-01 00:00:09] MainApp.c(1258) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 374] [1970-01-01 00:00:09] MainApp.c(1260) <GetAndSetTyDefalutConfig>: SMLMode=[2]
[2024/8/7 9:28:17 390] [1970-01-01 00:00:09] MainApp.c(1263) <GetAndSetTyDefalutConfig>: g_SMLAbility=[0]
[2024/8/7 9:28:17 390] [1970-01-01 00:00:09] MainApp.c(1266) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 406] [1970-01-01 00:00:09] MainApp.c(1338) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 406] [1970-01-01 00:00:09] MainApp.c(1346) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 422] [1970-01-01 00:00:09] MainApp.c(1357) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 422] [1970-01-01 00:00:09] MainApp.c(1387) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 422] [1970-01-01 00:00:09] MainApp.c(1390) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:17 438] [1970-01-01 00:00:09] xm_ai.c(564) <XM_CreatePersionDetect>: 
[2024/8/7 9:28:17 438] [1970-01-01 00:00:09] xm_ai.c(574) <XM_CreatePersionDetect>: 
[2024/8/7 9:28:17 454] [1970-01-01 00:00:09] xm_ai.c(585) <XM_CreatePersionDetect>: 
[2024/8/7 9:28:17 454] [1970-01-01 00:00:09] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:28:17 454] [1970-01-01 00:00:09] xm_ai.c(588) <XM_CreatePersionDetect>: 
[2024/8/7 9:28:17 469] [1970-01-01 00:00:09] xm_ai.c(608) <XM_CreatePersionDetect>: 
[2024/8/7 9:28:17 470] [1970-01-01 00:00:09] xm_ai.c(645) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:28:17 533] [1970-01-01 00:00:09] xm_ai.c(646) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:09] xm_ai.c(647) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTime = [8];src/ped_thread.c(746) [Smart_Ped_CreateERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!ListMng - BufListCreate: index 1 OK
[2024/8/7 9:28:18 302] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:28:18 302] Mode(Product):0
[2024/8/7 9:28:18 302] BpuMode:[Online]
[2024/8/7 9:28:18 302] VpssMode:[Online]
[2024/8/7 9:28:18 302] [0.LimitUp_info]:
[2024/8/7 9:28:18 302] LimitUp:[Disable]
[2024/8/7 9:28:18 318] [2680*0]->[3840*0])
[2024/8/7 9:28:18 318] chn	TotalSize	ActiveSize
[2024/8/7 9:28:18 318] 0	5040*2246	2680*2160
[2024/8/7 9:28:18 318] 0	5040*2246	3840*2160
[2024/8/7 9:28:18 318] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:28:18 318] [1.VICU_info]:
[2024/8/7 9:28:18 334] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:28:18 334] 0	25.0	53	0	0	183	linear	8ddb00
[2024/8/7 9:28:18 334] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:28:18 334] en	op_type	m_chn	now
[2024/8/7 9:28:18 334] 0	1	1	1
[2024/8/7 9:28:18 334] [2.VI_info]:
[2024/8/7 9:28:18 334] chn	TotalSize	ActiveSize
[2024/8/7 9:28:18 350] 0	5040*2246	3848*2166
[2024/8/7 9:28:18 351] 1	   0*   0	   0*   0
[2024/8/7 9:28:18 351] [3.MIPI_info]:
[2024/8/7 9:28:18 351] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:28:18 351] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:28:18 366] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:28:18 366] [4.Cut_info]:
[2024/8/7 9:28:18 366] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:28:18 366] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:28:18 366] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:28:18 382] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:28:18 382] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:28:18 382] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:28:18 382] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:28:18 382] [5.IB(isp buffer info)]:
[2024/8/7 9:28:18 398] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:28:18 398] PoolId  Count  Size
[2024/8/7 9:28:18 398] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:18 414] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:18 414] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:18 430] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:18 430] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:18 430] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:28:18 446] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:28:18 446] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:28:18 446] 0       0         0          0          4       
[2024/8/7 9:28:18 462] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:28:18 462]      --265--            --264--                                               
[2024/8/7 9:28:18 478] Count      Line     Count      Line     
[2024/8/7 9:28:18 478] 42         437      94         560      
[2024/8/7 9:28:18 479] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:28:18 494] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:28:18 494] 0   3840   2160    H265  0      0        0           23        983039     1        	
[2024/8/7 9:28:18 510] 1   640    360     H265  0      0        0           18        43195      5        	
[2024/8/7 9:28:18 510] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:28:18 526] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:28:18 526] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:28:18 542] 0   Y      23       0       0       15       0        23       23       39        63141         62169    115839   68805    0       
[2024/8/7 9:28:18 558] 1   Y      18       0       0       1        0        18       18       39        2495          1933     27184    4265     0       
[2024/8/7 9:28:18 558] 3   N      0        0       0       1        0        0        0        39        0             0        0        0        0       
[2024/8/7 9:28:18 574] ]: Smart_Ped_Create_ver: Jul 24 2024 18:21:40
[2024/8/7 9:28:18 574] src/ped_thread.c(656) [Ped_Init_IA_Work]: Ped_Init_IA_Work start ver:Jul 24 2024 18:21:40
[2024/8/7 9:28:18 574] [FUNC: IA_InitLog] Creat OK.
[2024/8/7 9:28:18 590] [INIT]: XM_IA_Init() done.
[2024/8/7 9:28:18 590] src/ped_thread.c(705) [Ped_Init_IA_Work]: ruler 0 region (0,0) (0,0) (0,0) (0,0)
[2024/8/7 9:28:18 605] [INIT]:LIBXMIA IAtype 700 Complied at May  8 2024 08:39:39 GIT_ID:cb3a4ed0
[2024/8/7 9:28:18 605] [INIT]: TD Version: TD_V_3.2.4.2[May 15 2024 19:14:32]
[2024/8/7 9:28:18 605] -- TD INIT -- 
[2024/8/7 9:28:18 605]  uiTdMaxNum: 12 
[2024/8/7 9:28:18 605]  acClassBinPath: /usr/bin 
[2024/8/7 9:28:18 605]  ePlatForm: 50 
[2024/8/7 9:28:18 605]  eDevImgType: 17 
[2024/8/7 9:28:18 621]  stDevImgSize: (2680,2160) 
[2024/8/7 9:28:18 621]  iTrackFlag: 1 
[2024/8/7 9:28:18 621]  iTrackType: 2 
[2024/8/7 9:28:18 621] -- TD EXTF -- 
[2024/8/7 9:28:18 621]  ucPedFallDownEnable: 0
[2024/8/7 9:28:18 621]  ucTDFeatureEnable: 0
[2024/8/7 9:28:18 621]  ucSmokeEnable: 0
[2024/8/7 9:28:18 621]  ucFaceDetEnable: 0
[2024/8/7 9:28:18 621]  ucFaceMaskEnable: 0
[2024/8/7 9:28:18 637]  ucFaceAngEnable: 0
[2024/8/7 9:28:18 637]  ucFaceRegEnable: 0
[2024/8/7 9:28:18 637]  ucPlateDetEnable: 0
[2024/8/7 9:28:18 637]  ucPlateRegEnable: 0
[2024/8/7 9:28:18 637]  ucPedPointEnable: 0
[2024/8/7 9:28:18 637]  ucHandPointEnable: 0
[2024/8/7 9:28:18 637]  ucHelmetEnable: 0
[2024/8/7 9:28:18 637]  ucHandgestureEnable: 0
[2024/8/7 9:28:18 637]  efdfreq: 10
[2024/8/7 9:28:18 653] [INIT]: XM_IA_TD_PED_S Version: 20230719_person_noexp_v200
[2024/8/7 9:28:18 653] [INIT] Alg Malloc Size 27232
[2024/8/7 9:28:18 653] -- TD CFG --  
[2024/8/7 9:28:18 653]  iMDFlag: 0
[2024/8/7 9:28:18 653]  ucDetectDisable: 0
[2024/8/7 9:28:18 653]  iDetectType: 5
[2024/8/7 9:28:18 653]  ePattern: 3
[2024/8/7 9:28:18 653]  eSensitivity: 2
[2024/8/7 9:28:18 669]  ucFishEyeCorrectFlag:0
[2024/8/7 9:28:18 669]  eRotate:0
[2024/8/7 9:28:18 669]  ucSationaryTd: 0
[2024/8/7 9:28:18 669]  ucClearnessFlg:0
[2024/8/7 9:28:18 669]  usInImgWidth:0
[2024/8/7 9:28:18 669]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:28:18 669] [CFG]: Rule:0 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:28:18 685] [CFG]: Rule:1 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:28:18 685] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:28:18 685] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:28:18 701] [CFG]: DEFAULT iBoundaryPtsNum 4 eAlarmDirect 2 (0 0) (8191 0) (8191 8191) (0 8191)
[2024/8/7 9:28:18 701] [FUNC:PbdcnnConfig][L:578] (nil) 0xbec072f8 Pointer Null.
[2024/8/7 9:28:18 701] [INIT]: PdConfig pvHandle 0xb11a0000. Config OK
[2024/8/7 9:28:18 717] [INIT] Alg Malloc Size 30000
[2024/8/7 9:28:18 717] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:28:18 717] [INIT]:memPoolSize 1351680.
[2024/8/7 9:28:18 733] V1.6.x date Sep  5 2023, time 23:32:25 npu load start
[2024/8/7 9:28:18 733] dpu version v1.1.0 build time Aug  5 2022
[2024/8/7 9:28:18 733] [INIT]: Update MemPoolSize 0 to 1351680.
[2024/8/7 9:28:18 749] [INIT]: MmzAlloc MemPoolSize 1351680 0xb0fde000~0xb1128000.
[2024/8/7 9:28:18 750] 0 Model 0x14d128c MemPoolIdx 0 MemPoolInfo 0x6d5f10
[2024/8/7 9:28:18 750] [INIT]: version 20230719_person_noexp_v200, debug 0, profile 0
[2024/8/7 9:28:18 750] [INIT] Alg Malloc Size 240736
[2024/8/7 9:28:18 766] CNNMemory: 2064977 bulk 240736 mmz 1824241
[2024/8/7 9:28:18 766] CNNINIT INPUT IMAGESIZE:(640,224)
[2024/8/7 9:28:18 766] TD_DETECT stAlgImgSize (640,224) 
[2024/8/7 9:28:18 766] [INIT] Alg Malloc Size 60672
[2024/8/7 9:28:18 766] MdInit ok![INIT] Alg Malloc Size 79704
[2024/8/7 9:28:18 781] [FUNC: trackInit][L: 273] API_Creat_IMG 
[2024/8/7 9:28:18 781] [INIT]: PdInit pvHandle 0x14cf128 *pvHandle 0xb11a0000 OK
[2024/8/7 9:28:18 781] IA_LOG 87c6a000 value 0
[2024/8/7 9:28:18 781] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:28:18 781] Ped_Init_IA_Work end 
[2024/8/7 9:28:18 798] src/ped_thread.c(774) [Smart_Ped_Create]: Create list success, index 1 maxsize 2
[2024/8/7 9:28:18 798] src/ped_thread.c(495) [PedProc_v2]: 
[2024/8/7 9:28:18 798] src/ped_thread.c(520) [PedProc_v2]: 
[2024/8/7 9:28:18 814] [FUNC: DetectTarget][L: 1489] API_Creat_IMG_MdInImg 
[2024/8/7 9:28:18 814] [FUNC: PbdcnnWork][L: 1084] API_Creat_CSCIMG 
[2024/8/7 9:28:18 814] [1970-01-01 00:00:10] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:18 830] [1970-01-01 00:00:10] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:18 830] src/ped_thread.c(803) [Smart_Ped_Create]: Ped_Creat Success @0x39e24
[2024/8/7 9:28:18 846] [1970-01-01 00:00:10] xm_ai.c(649) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:28:18 878] [1970-01-01 00:00:10] xm_ai.c(657) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:10] xm_ai.c(658) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTime = [8];-- TD CFG --  
[2024/8/7 9:28:18 878]  iMDFlag: 0
[2024/8/7 9:28:18 878]  ucDetectDisable: 0
[2024/8/7 9:28:18 878]  iDetectType: 5
[2024/8/7 9:28:18 878]  ePattern: 3
[2024/8/7 9:28:18 878]  eSensitivity: 0
[2024/8/7 9:28:18 878]  ucFishEyeCorrectFlag:0
[2024/8/7 9:28:18 878]  eRotate:0
[2024/8/7 9:28:18 878]  ucSationaryTd: 0
[2024/8/7 9:28:18 878]  ucClearnessFlg:0
[2024/8/7 9:28:18 894]  usInImgWidth:0
[2024/8/7 9:28:18 894]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:28:18 894] [CFG]: Rule:0 ucRuleEnable:1 AlarmType:0 eRuleType:1
[2024/8/7 9:28:18 910] [CFG]: IA_PERIMETER_V1 iBoundaryPtsNum 4 eAlarmDirect 0 (0 0) (8191 0) (8191 8191) (0 8191) [CFG]: Rule:1 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:28:18 910] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:28:18 910] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:28:18 926] [INIT]: PdConfig pvHandle 0xb11a0000. Config OK
[2024/8/7 9:28:18 926] IA_LOG 87c6a000 value 0
[2024/8/7 9:28:18 926] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:28:18 926] src/ped_thread.c(831) [Smart_Ped_SetParam[MMZ] BUILD TIME:[Jul 14 2021 15:42:31]
[2024/8/7 9:28:18 942] [0x83400000--------0x88000000]
[2024/8/7 9:28:18 942] --START-----------SIZE----------------OVERFLOW----NAME---------------
[2024/8/7 9:28:18 942] 0x83400000	0xbde000  (12152k)	0	vb[bdd800][0]
[2024/8/7 9:28:18 958] 0x83fde000	0xbde000  (12152k)	0	vb[bdd800][1]
[2024/8/7 9:28:18 958] 0x84bbc000	0xbde000  (12152k)	0	vb[bdd800][2]
[2024/8/7 9:28:18 958] 0x8579a000	0x55000   (  340k)	0	vb[54600][0]
[2024/8/7 9:28:18 958] 0x857ef000	0x55000   (  340k)	0	vb[54600][1]
[2024/8/7 9:28:18 974] 0x85844000	0x35000   (  212k)	0	vb[34800][0]
[2024/8/7 9:28:18 974] 0x85879000	0x35000   (  212k)	0	vb[34800][1]
[2024/8/7 9:28:18 974] 0x858ae000	0x24000   (  144k)	0	isp_nr_alpha_ch0
[2024/8/7 9:28:18 974] 0x858d2000	0x163000  ( 1420k)	0	isp_nr_idx_ch0
[2024/8/7 9:28:18 990] 0x85a35000	0x1000    (    4k)	0	isp_nr_idx_max_ch0
[2024/8/7 9:28:18 990] 0x85a36000	0x84f000  ( 8508k)	0	isp_nr_fetch_ch0
[2024/8/7 9:28:18 990] 0x86285000	0x2000    (    8k)	0	isp_defog_ch0
[2024/8/7 9:28:18 990] 0x86287000	0xc24000  (12432k)	0	vencRfcFrame[0]
[2024/8/7 9:28:19 005] 0x86eab000	0xc24000  (12432k)	0	vencRfcFrame[1]
[2024/8/7 9:28:19 006] 0x87acf000	0xf1000   (  964k)	0	stream_chn[0]
[2024/8/7 9:28:19 006] 0x87bc0000	0x4c000   (  304k)	0	vencWrapLuma[0]
[2024/8/7 9:28:19 006] 0x87c0c000	0x26000   (  152k)	0	vencWrapChroma[0]
[2024/8/7 9:28:19 021] 0x87c32000	0xb000    (   44k)	0	stream_chn[1]
[2024/8/7 9:28:19 022] 0x87c3d000	0x2b000   (  172k)	0	stream_chn[3]
[2024/8/7 9:28:19 022] 0x87c68000	0x1000    (    4k)	0	osd_block[0]
[2024/8/7 9:28:19 022] 0x87c69000	0x1000    (    4k)	0	osd_block[4]
[2024/8/7 9:28:19 037] 0x87c6a000	0x1000    (    4k)	0	IA_LOG
[2024/8/7 9:28:19 038] 0x87c6b000	0x7000    (   28k)	0	IA_MANAGE_1
[2024/8/7 9:28:19 038] 0x87c72000	0x8000    (   32k)	0	IA_MANAGE_2
[2024/8/7 9:28:19 038] 0x87c7a000	0x70000   (  448k)	0	firm_mem_0
[2024/8/7 9:28:19 053] 0x87cea000	0x14b000  ( 1324k)	0	mempool_1
[2024/8/7 9:28:19 053] 0x87e35000	0x1000    (    4k)	0	dst_mem_1
[2024/8/7 9:28:19 053] 0x87e36000	0x1000    (    4k)	0	dst_mem_2
[2024/8/7 9:28:19 054] 0x87e37000	0x3000    (   12k)	0	dst_mem_3
[2024/8/7 9:28:19 070] 0x87e3a000	0x1000    (    4k)	0	dst_mem_4
[2024/8/7 9:28:19 070] 0x87e3b000	0x14000   (   80k)	0	IA_MANAGE_3
[2024/8/7 9:28:19 070] 0x87e4f000	0x35000   (  212k)	0	IA_Image_1
[2024/8/7 9:28:19 070] 0x87e84000	0x6a000   (  424k)	0	IA_Image_2
[2024/8/7 9:28:19 070] 0x87eee000	0x112000  ( 1096k)	1	
[2024/8/7 9:28:19 085] ---------------------------------------------------------------------
[2024/8/7 9:28:19 085] SIZE: 0x4c00000(77824k)  USED: 0x4aee000(76728k)  FREE: 0x112000(1096k)
[2024/8/7 9:28:19 085] ]: Ped_SetParam Success
[2024/8/7 9:28:19 101] [1970-01-01 00:00:10] xm_ai.c(666) <XM_CreatePersionDetect>: 
[2024/8/7 9:28:19 101] [1970-01-01 00:00:10] xm_ai.c(674) <XM_CreatePersionDetect>: 
[2024/8/7 9:28:19 117] [1970-01-01 00:00:10] MainApp.c(1395) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:19 117] [1970-01-01 00:00:10] MainApp.c(1397) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:19 117] [1970-01-01 00:00:10] MainApp.c(1402) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:19 133] [1970-01-01 00:00:10] MainApp.c(1481) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:19 133] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 60 enable 0 volume
[2024/8/7 9:28:19 149] [1970-01-01 00:00:10] MainApp.c(1525) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:19 149]  PTZPreset is empty!
[2024/8/7 9:28:19 165] [1970-01-01 00:00:10] MainApp.c(1554) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:19 165] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:28:19 181] [1970-01-01 00:00:10] MainApp.c(1568) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:19 181] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:28:19 197] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:28:19 213] [1970-01-01 00:00:10] MainApp.c(1584) <GetAndSetTyDefalutConfig>: cruisetime_pro create!
[2024/8/7 9:28:19 213] [1970-01-01 00:00:10] MainApp.c(1607) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:28:19 229] [1970-01-01 00:00:10] MainApp.c(1925) <main>: 
[2024/8/7 9:28:19 229] [1970-01-01 00:00:10] MainApp.c(1116) <GetRegisterMode>: -------- register mode 1
[2024/8/7 9:28:19 229] [1970-01-01 00:00:10] MainApp.c(1927) <main>: 
[2024/8/7 9:28:19 245] [1970-01-01 00:00:10] MainApp.c(1930) <main>: 
[2024/8/7 9:28:19 245] *************
[2024/8/7 9:28:19 245]  0x6d123c 
[2024/8/7 9:28:19 245] *****************
[2024/8/7 9:28:19 245]  0x3287c 
[2024/8/7 9:28:19 261] beginend[1970-01-01 00:00:10] MainApp.c(1938) <main>: 
[2024/8/7 9:28:19 261] [1970-01-01 00:00:10] MainApp.c(866) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:28:19 277] [1970-01-01 00:00:10] MainApp.c(174) <GetDeviceHWInfo>: Get Hwinfo APP_ID [fvijo8jvloagv1gm], UUID[uuidcaab27b0a838d239] AUTHKEY [j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:28:19 277] [1970-01-01 00:00:10] MainApp.c(909) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:28:19 293] [1970-01-01 00:00:10] MainApp.c(942) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:28:19 293] [1970-01-01 00:00:10] MainApp.c(986) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:28:19 293] [1970-01-01 00:00:10] MainApp.c(1019) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:28:19 293] sdk start
[2024/8/7 9:28:19 309] [1970-01-01 00:00:10] MainApp.c(752) <tuya_ipc_sdk_start>: log_level 0[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/mtd/Config/ty/ 
[2024/8/7 9:28:19 325] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/mtd/Config/ty/
[2024/8/7 9:28:19 325] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/mtd/Config/ty/
[2024/8/7 9:28:19 341] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[2024/8/7 9:28:19 341] [01-01 18:12:15 TUYA D][simplekv.c:989] both file not exist /mnt/mtd/Config/ty/tuya_user.db
[2024/8/7 9:28:19 358] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[2024/8/7 9:28:19 358] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[2024/8/7 9:28:19 358] [01-01 18:12:15 TUYA D][simplekv.c:1083] init NEW normal file
[2024/8/7 9:28:19 374] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 3536627844
[2024/8/7 9:28:19 374] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:19 390] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[2024/8/7 9:28:19 390] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[2024/8/7 9:28:19 390] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[2024/8/7 9:28:19 405] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[2024/8/7 9:28:19 406] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[2024/8/7 9:28:19 421] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[2024/8/7 9:28:19 422] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[2024/8/7 9:28:19 422] [01-01 18:12:15 TUYA E][log_seq.c:863] open err
[2024/8/7 9:28:19 438] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[2024/8/7 9:28:19 438] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[2024/8/7 9:28:19 454] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[2024/8/7 9:28:19 454] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:28:19 469] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:19 469] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[2024/8/7 9:28:19 486] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:19 486] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:19 486] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:28:19 501] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:28:19 501] [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
[2024/8/7 9:28:19 517] [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:28:19 517] dev id key: 16
[2024/8/7 9:28:19 517] d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[2024/8/7 9:28:19 517] --- tracepoint bt_ext_porting.c,tuya_ext_bt_port_init(464): tuya_ext_bt_port_init ---
[2024/8/7 9:28:19 533] [01-01 18:12:15 TUYA I][bt_ext_porting.c:466] [TUYA-BTUART]tuya ext bt port init
[2024/8/7 9:28:19 533] --- tracepoint bt_uart_drv.c,tuya_bt_uart_open(187): tuya_bt_uart_open ---
[2024/8/7 9:28:19 549] --- tracepoint bt_uart_drv.c,tuya_bt_uart_init(60): tuya_bt_uart_init  0 ---
[2024/8/7 9:28:19 549] --- tracepoint bt_ext_porting.c,ty_btext_thread(370):  ---
[2024/8/7 9:28:19 565] [01-01 18:12:15 TUYA I][bt_ext_porting.c:485] [TUYA-BTUART]thread ty_btext_thread create cplt mode 1
[2024/8/7 9:28:19 565] [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[2024/8/7 9:28:19 565] [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[2024/8/7 9:28:19 581] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish
[2024/8/7 9:28:19 581] [1970-01-01 00:00:10] MainApp.c(822) <tuya_ipc_sdk_start>: create ring buffer start 
[2024/8/7 9:28:19 597] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:0 Enable:1
[2024/8/7 9:28:19 597] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 2048, video_fps 12
[2024/8/7 9:28:19 613] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr0 bitrate:2048 fps:12
[2024/8/7 9:28:19 613] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 2621440 bytes for ch0st0tr0, max frame size 393216
[2024/8/7 9:28:19 629] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr0 size:2621440 nodes:120
[2024/8/7 9:28:19 629] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:0
[2024/8/7 9:28:19 645] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:1 Enable:1
[2024/8/7 9:28:19 645] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 1024, video_fps 12
[2024/8/7 9:28:19 661] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr1 bitrate:1024 fps:12
[2024/8/7 9:28:19 661] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1310720 bytes for ch0st0tr1, max frame size 196608
[2024/8/7 9:28:19 677] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr1 size:1310720 nodes:120
[2024/8/7 9:28:19 677] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:1
[2024/8/7 9:28:19 693] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:2 Enable:0
[2024/8/7 9:28:19 693] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:3 Enable:0
[2024/8/7 9:28:19 693] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:4 Enable:0
[2024/8/7 9:28:19 709] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:5 Enable:0
[2024/8/7 9:28:19 709] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:6 Enable:0
[2024/8/7 9:28:19 725] [01-01 18[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:28:19 725] :12:15 TUYA D][MainApp.c:430] init ring buffer Channel:7 Enable:0
[2024/8/7 9:28:19 725] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:8 Enable:0
[2024/8/7 9:28:19 741] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:9 Enable:1
[2024/8/7 9:28:19 741] [01-01 18:12:15 TUYA D][MainApp.c:439] audio_sample 8000, audio_databits 16, audio_fps 25
[2024/8/7 9:28:19 757] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[2024/8/7 9:28:19 757] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[2024/8/7 9:28:19 773] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[2024/8/7 9:28:19 789] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:9
[2024/8/7 9:28:19 789] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:10 Enable:0
[2024/8/7 9:28:19 805] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:11 Enable:0
[2024/8/7 9:28:19 805] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:12 Enable:0
[2024/8/7 9:28:19 821] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:13 Enable:0
[2024/8/7 9:28:19 821] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:14 Enable:0
[2024/8/7 9:28:19 821] [01-01 [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:28:19 837] 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:15 Enable:0
[2024/8/7 9:28:19 854] [1970-01-01 00:00:10] MainApp.c(830) <tuya_ipc_sdk_start>: pRunInfo->net_info.connect_mode 1[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:28:19 854] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:19 854] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:19 869] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:19 869] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:28:19 869] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:28:19 902] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":null,"auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:28:19 902] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:28:19 918] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:19 918] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:19 918] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:19 934] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:208
[2024/8/7 9:28:19 934] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 0 startpos:28700 size:276
[2024/8/7 9:28:19 950] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:19 950] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 1056267009
[2024/8/7 9:28:19 950] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:19 966] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:19 966] [01-01 18:12:15 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:28:19 981] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":0,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:28:19 981] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:28:19 997] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:19 997] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:19 997] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 013] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:28:20 013] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 1 startpos:28976 size:212
[2024/8/7 9:28:20 029] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:20 029] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2367317337
[2024/8/7 9:28:20 029] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:20 045] [01-01 18:12:15 TUYA D][simplekv[atbm_log]:[eth2] change to [3]
[2024/8/7 9:28:20 045] .c:520] write success
[2024/8/7 9:28:20 045] [atbm_log]:[eth2] has been disabled
[2024/8/7 9:28:20 061] [01-01 18:12:15 TUYA D][[atbm_log]:add iftype(6),if_cnt(2),flags(c1eb3bf8)
[2024/8/7 9:28:20 061] ws_db_gw.c:280] [atbm_log]:enable sg
[2024/8/7 9:28:20 061] gw_wsm write suc[atbm_log]:[mon.eth2] has been disabled
[2024/8/7 9:28:20 061] cess
[2024/8/7 9:28:20 077] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[2024/8/7 9:28:20 077] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1776] Last reset reason: 255
[2024/8/7 9:28:20 077] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 094] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:28:20 094] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:28:20 094] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:28:20 110] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 110] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:20 126] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 126] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 126] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:20 142] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:28:20 142] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1140] serial_no:90314ba51650
[2024/8/7 9:28:20 158] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 158] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:28:20 158] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:28:20 174] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[2024/8/7 9:28:20 174] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1171] gw_cntl.gw_wsm.stat:0
[2024/8/7 9:28:20 174] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1347] gw_cntl->gw_wsm.nc_tp:0
[2024/8/7 9:28:20 190] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1348] gw_cntl->gw_wsm.md:0
[2024/8/7 9:28:20 190] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1362] wifi config method not fit
[2024/8/7 9:28:20 206] [01-01 18:12:15 TUYA E][tuya_devos_entry.c:1787] ret:-2
[2024/8/7 9:28:20 206] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1808] enter reset factory
[2024/8/7 9:28:20 206] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 221] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:20 221] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 222] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 238] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_di -6
[2024/8/7 9:28:20 238] [01-01 18:12:15 TUYA E][ws_db_gw.c:494] gw_di read fail:-6
[2024/8/7 9:28:20 253] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 253] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:20 254] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 270] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 270] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_di And Value Len:400
[2024/8/7 9:28:20 285] [01-01 18:12:15 TUYA D][simplekv.c[atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:28:20 286] :457] new space [atbm_log]:[WSM] Drop frame
[2024/8/7 9:28:20 286] 2 startpos:29188 size:468
[2024/8/7 9:28:20 286] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:20 301] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 876692212
[2024/8/7 9:28:20 302] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:20 302] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:20 317] [01-01 18:12:15 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:28:20 317] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:593] nc_tp:2, wifi_start_mode:0
[2024/8/7 9:28:20 333] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 333] [01-01 18:12:15 TUYA D][simplekv.[atbm_log]:[eth2] start driver he ap
[2024/8/7 9:28:20 333] c:1247] no key f[atbm_log]:BSS_CHANGED_BEACON
[2024/8/7 9:28:20 333] ind
[2024/8/7 9:28:20 349] [01-01 18:[atbm_log]:change ds_params channel 6 
[2024/8/7 9:28:20 349] 12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 349] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 365] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:wf_start_md And Value Len:16
[2024/8/7 9:28:20 365] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 3 startpos:29656 size:84
[2024/8/7 9:28:20 381] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:20 381] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 411742493
[2024/8/7 9:28:20 381] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:20 397] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:20 413] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:28:20 413] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 413] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:28:20 429] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:28:20 429] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:28:20 445] [01-01 18:12:15 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:28:20 445] [01-01 18:12:15 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:28:20 445] [01-01 18:12:15 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:28:20 461] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4146866774
[2024/8/7 9:28:20 461] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:20 461] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:20 478] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:28:20 478] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 478] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:20 493] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 493] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 509] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6
[2024/8/7 9:28:20 509] [01-01 18:12:15 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6
[2024/8/7 9:28:20 509] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 525] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:20 525] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 541] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 541] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:368
[2024/8/7 9:28:20 541] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 4 startpos:29740 size:436
[2024/8/7 9:28:20 557] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:20 557] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 216605884
[2024/8/7 9:28:20 573] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:20 573] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:20 573] [01-01 18:12:15 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:28:20 589] [01-01 18:12:15 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:28:20 589] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 589] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:20 605] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 605] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 621] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:28:20 621] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 5 startpos:30176 size:84
[2024/8/7 9:28:20 621] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:20 637] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4220141073
[2024/8/7 9:28:20 637] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:20 637] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:20 653] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 653] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:20 669] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 669] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 669] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:28:20 685] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 6 startpos:30260 size:84
[2024/8/7 9:28:20 685] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:20 702] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 860452950
[2024/8/7 9:28:20 702] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:20 702] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:20 717] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:28:20 717] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:20 717] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:20 734] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:20 734] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:28:20 749] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 7 startpos:30344 size:84
[2024/8/7 9:28:20 749] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:20 750] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2541358761
[2024/8/7 9:28:20 765] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:20 766] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:20 782] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[2024/8/7 9:28:20 782] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[2024/8/7 9:28:20 798] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[2024/8/7 9:28:20 798] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[2024/8/7 9:28:20 813] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[2024/8/7 9:28:20 813] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[2024/8/7 9:28:20 814] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[2024/8/7 9:28:20 830] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[2024/8/7 9:28:20 830] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[2024/8/7 9:28:20 830] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[2024/8/7 9:28:20 845] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[2024/8/7 9:28:20 845] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[2024/8/7 9:28:20 862] [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[2024/8/7 9:28:20 862] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[2024/8/7 9:28:20 893] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}
[2024/8/7 9:28:20 893] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:116] sys add timer: 14
[2024/8/7 9:28:20 909] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:122] sys start timer: 14
[2024/8/7 9:28:20 909] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[2024/8/7 9:28:20 909] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[2024/8/7 9:28:20 925] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[2024/8/7 9:28:20 925] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[2024/8/7 9:28:20 925] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:fvijo8jvloagv1gm 0
[2024/8/7 9:28:20 925] uuid: 20
[2024/8/7 9:28:20 941] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:28:20 941] dev_id_tmp: 16
[2024/8/7 9:28:20 941] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:28:20 941] dev_id_tmp2: 20
[2024/8/7 9:28:20 956] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:28:20 957] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:28:20 957] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1066] nc_tp:2, md:0
[2024/8/7 9:28:20 973] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1297] dev_nw_cfg_active_stage:2
[2024/8/7 9:28:20 973] [01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[2024/8/7 9:28:20 989] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:28:20 989] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:28:20 989] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:28:21 005] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[2024/8/7 9:28:21 005] [1970-01-01 00:00:11] MainApp.c(838) <tuya_ipc_sdk_start>: [01-01 18:12:15 TUYA D][MainApp.c:854] tuya ipc sdk start is complete
[2024/8/7 9:28:21 021] killall: hostapd: no process killed
[2024/8/7 9:28:21 022] route: netmask and route address conflict
[2024/8/7 9:28:21 022] [1970-01-01 00:00:11] MainApp.c(1028) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:28:21 037] [1970-01-01 00:00:11] MainApp.c(1053) <TUYA_IPC_SDK_START>: pthread_create BasicIndicatorTimer suc
[2024/8/7 9:28:21 038] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [0] change to [1]
[2024/8/7 9:28:21 054] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [0] change to [1]
[2024/8/7 9:28:21 054] [1970-01-01 00:00:11] MainApp.c(1968) <main>: FLIP
[2024/8/7 9:28:21 069] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [1] change to [0]
[2024/8/7 9:28:21 086] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [1] change to [0]
[2024/8/7 9:28:21 086] [1970-01-01 00:00:11] MainApp.c(1972) <main>: FLIP
[2024/8/7 9:28:21 086] [1970-01-01 00:00:11] MainApp.c(1622) <PostInit>: 
[2024/8/7 9:28:21 101] src/intelligent_track_thread.c(1398) [XM_SmartBodyTarckCreate]: 
[2024/8/7 9:28:21 101] src/intelligent_track_thread.c(1374) [Smart_Track_GetAbility]: 
[2024/8/7 9:28:21 101] src/intelligent_track_thread.c(1379) [Smart_Track_GetAbility]: 
[2024/8/7 9:28:21 117] src/intelligent_track_thread.c(1272) [GetMotorCtrlPara]: 
[2024/8/7 9:28:21 117] src/intelligent_track_thread.c(1277) [GetMotorCtrlPara]: 
[2024/8/7 9:28:21 133] src/intelligent_track_thread.c(1283) [GetMotorCtrlPara]: 
[2024/8/7 9:28:21 133] src/intelligent_track_thread.c(1298) [GetMotorCtrlPara]: max_steps_x=5006 ,max_steps_y=2161
[2024/8/7 9:28:21 133] src/intelligent_track_thread.c(1301) [GetMotorCtrlPara]: 
[2024/8/7 9:28:21 149] src/intelligent_track_thread.c(1307) [GetMotorCtrlPara]: 
[2024/8/7 9:28:21 149] [1970-01-01 00:00:11] MainApp.c(277) <BasicIndicatorTimer>: BasicIndicatorTimer start ----
[2024/8/7 9:28:21 165] src/intelligent_track_thread.c(1323) [GetMotorCtrlPara]: 
[2024/8/7 9:28:21 165] src/intelligent_track_thread.c(1336) [GetMotorCtrlPara]: track_default_degrees_y=95
[2024/8/7 9:28:21 181] src/intelligent_track_thread.c(1345) [GetMotorCtrlPara]: LoadTrackSet Motor_x_turnover:no
[2024/8/7 9:28:21 181] src/intelligent_track_thread.c(1346) [GetMotorCtrlPara]: LoadTrackSet Motor_y_turnover:no
[2024/8/7 9:28:21 197] src/intelligent_track_thread.c(1348) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 540
[2024/8/7 9:28:21 213] src/intelligent_track_thread.c(1367) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 400
[2024/8/7 9:28:21 213] src/intelligent_track_thread.c(1368) [GetMotorCtrlPara]: LoadTrackSet HEIGHT_STEP = 200
[2024/8/7 9:28:21 229] src/intelligent_track_thread.c(1390) [Smart_Track_GetAbility]: Track_Ability : Enable
[2024/8/7 9:28:21 229] src/intelligent_track_thread.c(1451) [XM_SmartBodyTarckCreate]: Intelligent Track_pthread create Success 1920x1080
[2024/8/7 9:28:21 245] src/intelligent_track_thread.c(667) [TrackProcV200]: 
[2024/8/7 9:28:21 245] [1970-01-01 00:00:11] MainApp.c(1640) <PostInit>: ln -s /mnt/mtd/Log/sofia.log /tmp/tuya.log
[2024/8/7 9:28:21 261] [1970-01-01 00:00:11] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:28:21 325] [1970-01-01 00:00:11] MainApp.c(1665) <PostInit>: MotionDetect Sensitive 1 set onvif_on_off:0 
[2024/8/7 9:28:21 325] [1970-01-01 00:00:12] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time12368
[2024/8/7 9:28:21 341] curr event:3 
[2024/8/7 9:28:21 341] IPC_APP_Notify_LED_Sound_Status_CB line(480) -------------------------- IPC_START_WIFI_AP_CFG(3)
[2024/8/7 9:28:21 357] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-1650
[2024/8/7 9:28:21 357] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:28:21 357] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:28:21 373] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:28:21 373] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:28:21 373] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:28:21 389] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:28:21 389] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[2024/8/7 9:28:21 405] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[2024/8/7 9:28:21 405] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[2024/8/7 9:28:21 421] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:28:21 422] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:28:21 422] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:21 437] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:21 437] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:21 437] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:21 453] [01-01 18:12:16 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:28:21 453] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:21 469] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:21 470] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:21 470] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:21 485] [01-01 18:12:16 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:28:21 485] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:28:21 486] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:21 502] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:21 502] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:21 517] [01-01 18:12:16 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:28:21 517] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[2024/8/7 9:28:21 533] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:28:21 533] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:2  -->>
[2024/8/7 9:28:21 549] __IPC_APP_Get_Net_Status_cb line(193) -------------------------- stat(2)==STAT_AP_STA_UNCFG 
[2024/8/7 9:28:21 549] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:2  <<--
[2024/8/7 9:28:21 565] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:28:21 565] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:28:21 582] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:28:21 582] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:21 582] [01-01 18:12:16 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:21 597] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[2024/8/7 9:28:21 597] udhcpd (v1.22.1) started
[2024/8/7 9:28:21 597] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:28:21 613] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:21504,priority:5
[2024/8/7 9:28:21 613] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[2024/8/7 9:28:21 629] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 9:28:21 629] [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 9:28:21 646] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[2024/8/7 9:28:21 646] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[2024/8/7 9:28:21 646] [01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt netcfg start
[2024/8/7 9:28:21 661] [01-01 18:12:16 TUYA N][tuya_ble_api.c:439] update bound stat:0
[2024/8/7 9:28:21 661] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[2024/8/7 9:28:21 677] [01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:28:21 677] dev id key: 16
[2024/8/7 9:28:21 677] d0 7d 89 57 d1 c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 9:28:21 677] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:28:21 693] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:28:21 693] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:28:21 709] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:28:21 709] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:28:21 709] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 9:28:21 725] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0x157d518),len(28)
[2024/8/7 9:28:21 725] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 9:28:21 741] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:28:21 741] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0x157d558),len(30)
[2024/8/7 9:28:21 757] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 9:28:21 757] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:28:21 757] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 9:28:21 773] adv_len:28
[2024/8/7 9:28:21 773] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:28:21 773] svc_data_uuid16 len:18
[2024/8/7 9:28:21 789] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:21 789] ---[XmBleAdvertiseEx][1210]: rc=[0]
[2024/8/7 9:28:21 790] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 9:28:21 790] rsp_len:30
[2024/8/7 9:28:21 805] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:28:21 805] mfg_data len:30
[2024/8/7 9:28:21 805] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 9:28:21 805] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 9:28:21 821] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 9:28:21 821] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:21 821] ---[XmBleAdvertiseEx][1241]: rc=[0]
[2024/8/7 9:28:21 837] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 9:28:21 837] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 9:28:21 837] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:21 837] adv_start rc = 0x0
[2024/8/7 9:28:21 853] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 9:28:21 853] [01-01 18:12:16 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:28:21 853] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:21 869] [01-01 18:12:16 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:21 869] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:21 885] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:21 885] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:21 885] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:21 901] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:21 901] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:21 916] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:21 917] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:21 917] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:21 932] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:21 933] [01-01 18:12:16 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:21 949] [01-01 18:12:16 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:21 949] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:21 965] [01-01 18:12:16 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:21 981] [01-01 18:12:16 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:21 982] [01-01 18:12:16 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:21 997] [01-01 18:12:16 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:21 998] gethostbyname_r error: Unknown host
[2024/8/7 9:28:21 998] [01-01 18:12:16 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:22 013] [01-01 18:12:16 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:22 013] [01-01 18:12:16 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:22 028] [01-01 18:12:16 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:22 029] [01-01 18:12:16 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:22 045] [01-01 18:12:16 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:22 045] [01-01 18:12:16 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:22 062] [01-01 18:12:16 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:22 063] [01-01 18:12:16 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:28:22 078] [1970-01-01 00:00:12] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:22 078] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:22 093] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:28:22 094] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:22 109] [01-01 18:12:17 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:22 109] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:22 125] [1970-01-01 00:00:13] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:22 125] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:28:22 141] [01-01 18:12:17 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:28:22 141] [01-01 18:12:17 TUYA D][tuya_ble_api.c:1470] ble get conn stat:4
[2024/8/7 9:28:22 157] [01-01 18:12:17 TUYA N][tuya_ble_api.c:750] ble_sdk_send skip, no connect:4
[2024/8/7 9:28:22 157] [01-01 18:12:17 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:22 157] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:22 173] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:22 173] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:22 188] [01-01 18:12:17 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:22 189] [01-01 18:12:17 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:22 189] [01-01 18:12:17 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:22 205] [01-01 18:12:17 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:22 205] [01-01 18:12:17 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:22 205] [01-01 18:12:17 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:22 221] [01-01 18:12:17 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:22 221] [01-01 18:12:17 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:22 237] [01-01 18:12:17 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:22 237] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:22 253] [01-01 18:12:17 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:22 269] [01-01 18:12:17 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:22 269] [01-01 18:12:17 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:22 285] [01-01 18:12:17 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:22 285] gethostbyname_r error: Unknown host
[2024/8/7 9:28:22 285] [01-01 18:12:17 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:22 301] [01-01 18:12:17 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:22 301] [01-01 18:12:17 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:22 317] [01-01 18:12:17 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:22 317] [01-01 18:12:17 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:22 333] [01-01 18:12:17 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:22 333] [01-01 18:12:17 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:22 349] [01-01 18:12:17 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:22 461] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:22 477] [1970-01-01 00:00:13] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:22 493] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:22 509] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:22 509] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:22 525] [01-01 18:12:18 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:22 652] [1970-01-01 00:00:14] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:22 652] [01-01 18:12:18 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:22 669] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:22 669] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:22 669] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:22 685] [01-01 18:12:18 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:22 685] [01-01 18:12:18 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:22 701] [01-01 18:12:18 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:22 702] [01-01 18:12:18 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:22 702] [01-01 18:12:18 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:22 717] [01-01 18:12:18 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:22 718] [01-01 18:12:18 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:22 718] [01-01 18:12:18 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:22 733] [01-01 18:12:18 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:22 733] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:22 765] [01-01 18:12:18 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:22 765] [01-01 18:12:18 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:22 781] [01-01 18:12:18 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:22 781] [01-01 18:12:18 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:22 781] gethostbyname_r error: Unknown host
[2024/8/7 9:28:22 797] [01-01 18:12:18 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:22 797] [01-01 18:12:18 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:22 813] [01-01 18:12:18 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:22 813] [01-01 18:12:18 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:22 813] [01-01 18:12:18 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:22 829] [01-01 18:12:18 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:22 830] [01-01 18:12:18 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:22 845] [01-01 18:12:18 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:23 485] [1970-01-01 00:00:14] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:23 501] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:23 501] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:28:23 517] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:23 517] [01-01 18:12:19 TUYA D][tuya_ble_api.c:1376] nw stat change:0->1, rpt to app.
[2024/8/7 9:28:23 533] [01-01 18:12:19 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:28:23 533] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:23 549] [01-01 18:12:19 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:23 693] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:23 693] [01-01 18:12:19 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:23 708] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:23 708] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:23 708] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:23 725] [01-01 18:12:19 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:23 725] [01-01 18:12:19 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:23 740] [01-01 18:12:19 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:23 740] [01-01 18:12:19 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:23 740] [01-01 18:12:19 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:23 757] [01-01 18:12:19 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:23 758] [01-01 18:12:19 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:23 772] [01-01 18:12:19 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:23 773] [01-01 18:12:19 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:23 773] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:23 806] [01-01 18:12:19 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:23 806] [01-01 18:12:19 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:23 821] [01-01 18:12:19 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:23 821] [01-01 18:12:19 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:23 821] gethostbyname_r error: Unknown host
[2024/8/7 9:28:23 837] [01-01 18:12:19 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:23 837] [01-01 18:12:19 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:23 853] [01-01 18:12:19 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:23 853] [01-01 18:12:19 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:23 869] [01-01 18:12:19 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:23 870] [01-01 18:12:19 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:23 870] [01-01 18:12:19 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:23 885] [01-01 18:12:19 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:24 477] [1970-01-01 00:00:15] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:24 493] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:24 509] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:24 510] [1970-01-01 00:00:16] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:24 525] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:24 525] [01-01 18:12:20 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:24 701] [1970-01-01 00:00:16] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time16495
[2024/8/7 9:28:24 718] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:24 718] [1970-01-01 00:00:16] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:24 733] [01-01 18:12:20 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:24 733] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:24 733] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:24 749] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:24 749] [01-01 18:12:20 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:24 749] [01-01 18:12:20 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:24 765] [01-01 18:12:20 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:24 765] [01-01 18:12:20 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:24 781] [01-01 18:12:20 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:24 781] [01-01 18:12:20 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:24 781] [01-01 18:12:20 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:24 797] [01-01 18:12:20 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:24 797] [01-01 18:12:20 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:24 813] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:24 829] [01-01 18:12:20 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:24 829] [01-01 18:12:20 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:24 845] [01-01 18:12:20 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:24 845] [01-01 18:12:20 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:24 861] gethostbyname_r error: Unknown host
[2024/8/7 9:28:24 861] [01-01 18:12:20 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:24 861] [01-01 18:12:20 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:24 877] [01-01 18:12:20 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:24 877] [01-01 18:12:20 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:24 893] [01-01 18:12:20 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:24 893] [01-01 18:12:20 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:24 909] [01-01 18:12:20 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:24 909] [01-01 18:12:20 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:25 101] motor auto test over
[2024/8/7 9:28:25 101] XXXX motor_helper: MOTOR_X XXXX
[2024/8/7 9:28:25 101] action=idle
[2024/8/7 9:28:25 101] dir=
[2024/8/7 9:28:25 101] flag=|auto-test-cmplt
[2024/8/7 9:28:25 117]  steps=0 , curr_steps=2503 , speed=0 , curr_speed=0 
[2024/8/7 9:28:25 117] YYYY motor_helper: MOTOR_Y YYYY
[2024/8/7 9:28:25 117] action=idle
[2024/8/7 9:28:25 117] dir=
[2024/8/7 9:28:25 117] flag=
[2024/8/7 9:28:25 117]  steps=0 , curr_steps=1080 , speed=0 , curr_speed=0 
[2024/8/7 9:28:25 469] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:28:25 485] [1970-01-01 00:00:16] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:25 500] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:25 516] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:28:25 517] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:25 533] [01-01 18:12:21 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:28:25 533] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:25 548] [01-01 18:12:21 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:25 725] [01-01 18:12:21 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:25 742] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:25 742] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:25 757] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:25 757] [01-01 18:12:21 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:25 757] [01-01 18:12:21 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:25 774] [01-01 18:12:21 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:25 774] [01-01 18:12:21 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:25 774] [01-01 18:12:21 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:25 789] [01-01 18:12:21 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:25 789] [01-01 18:12:21 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:25 805] [01-01 18:12:21 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:25 805] [01-01 18:12:21 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:25 805] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:25 837] [01-01 18:12:21 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:25 837] [01-01 18:12:21 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:25 853] [01-01 18:12:21 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:25 853] [01-01 18:12:21 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:25 853] gethostbyname_r error: Unknown host
[2024/8/7 9:28:25 869] [01-01 18:12:21 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:25 869] [01-01 18:12:21 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:25 884] [01-01 18:12:21 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:25 885] [01-01 18:12:21 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:25 901] [01-01 18:12:21 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:25 901] [01-01 18:12:21 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:25 916] [01-01 18:12:21 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:25 917] [01-01 18:12:21 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:25 917] [01-01 18:12:21 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:28:26 556] [1970-01-01 00:00:17] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:26 556] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:26 572] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:26 588] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:26 589] [01-01 18:12:22 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:26 877] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:26 877] [1970-01-01 00:00:18] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:26 893] [01-01 18:12:23 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:26 893] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:26 909] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:26 909] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:26 909] [01-01 18:12:23 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:26 925] [01-01 18:12:23 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:26 925] [01-01 18:12:23 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:26 925] [01-01 18:12:23 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:26 941] [01-01 18:12:23 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:26 941] [01-01 18:12:23 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:26 941] [01-01 18:12:23 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:26 957] [01-01 18:12:23 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:26 957] [01-01 18:12:23 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:26 973] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:26 989] [01-01 18:12:23 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:27 005] [01-01 18:12:23 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:27 005] [01-01 18:12:23 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:27 021] [01-01 18:12:23 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:27 021] gethostbyname_r error: Unknown host
[2024/8/7 9:28:27 021] [01-01 18:12:23 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:27 037] [01-01 18:12:23 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:27 037] [01-01 18:12:23 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:27 037] [01-01 18:12:23 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:27 052] [01-01 18:12:23 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:27 068] [01-01 18:12:23 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:27 070] [01-01 18:12:23 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:27 070] [01-01 18:12:23 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:27 549] [1970-01-01 00:00:18] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:27 565] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:27 565] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:28:27 581] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:27 596] [1970-01-01 00:00:19] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:27 597] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:27 612] [01-01 18:12:23 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:27 884] [1970-01-01 00:00:19] xm_main.c(1932) <PtzControl_Pro>: g_sPtz.xSpeed  17 g_sPtz.ySpeed 17[1970-01-01 00:00:19] xm_main.c(1990) <PtzControl_Pro>: XMSDK_MotorGotoPreset  defxy  x3110 y0 
[2024/8/7 9:28:27 900] [1970-01-01 00:00:19] xm_main.c(2001) <PtzControl_Pro>: g_LastRebootPositionStartfFlag=1
[2024/8/7 9:28:27 900] mpId[0] is [0].
[2024/8/7 9:28:27 900] mpId[1] is [0].
[2024/8/7 9:28:27 900] mpId[2] is [0].
[2024/8/7 9:28:27 900] mpId[3] is [0].
[2024/8/7 9:28:27 900] mpId[4] is [0].
[2024/8/7 9:28:27 900] mpId[5] is [0].
[2024/8/7 9:28:27 916] [1970-01-01 00:00:19] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:28:27 932] [1970-01-01 00:00:19] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:27 948] [01-01 18:12:24 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:27 948] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:27 948] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:27 964] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:27 964] [01-01 18:12:24 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:27 980] [01-01 18:12:24 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:27 980] [01-01 18:12:24 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:27 980] [01-01 18:12:24 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:27 996] [01-01 18:12:24 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:27 996] [01-01 18:12:24 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:27 996] [01-01 18:12:24 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:28 012] [01-01 18:12:24 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:28 012] [01-01 18:12:24 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:28 028] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:28 045] [01-01 18:12:24 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:28 060] [01-01 18:12:24 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:28 060] [01-01 18:12:24 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:28 060] [01-01 18:12:24 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:28 076] 
[2024/8/7 9:28:28 078] gethostbyname_r error: Unknown host
[2024/8/7 9:28:28 079] [01-01 18:12:24 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:28 079] [01-01 18:12:24 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:28 092] [01-01 18:12:24 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:28 092] [01-01 18:12:24 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:28 108] [01-01 18:12:24 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:28 108] [01-01 18:12:24 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:28 124] [01-01 18:12:24 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:28 124] [01-01 18:12:24 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:28 605] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:28 621] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:28 621] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:28 637] [01-01 18:12:24 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:28 892] [1970-01-01 00:00:20] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:28 908] [1970-01-01 00:00:20] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time20707
[2024/8/7 9:28:28 908] [1970-01-01 00:00:20] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:28 925] [01-01 18:12:25 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:28 925] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:28 941] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:28 941] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:28 941] [01-01 18:12:25 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:28 956] [01-01 18:12:25 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:28 956] [01-01 18:12:25 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:28 972] [01-01 18:12:25 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:28 972] [01-01 18:12:25 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:28 972] [01-01 18:12:25 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:28 988] [01-01 18:12:25 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:28 988] [01-01 18:12:25 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:29 005] [01-01 18:12:25 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:29 005] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:29 020] [01-01 18:12:25 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:29 037] [01-01 18:12:25 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:29 037] [01-01 18:12:25 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:29 053] [01-01 18:12:25 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:29 053] gethostbyname_r error: Unknown host
[2024/8/7 9:28:29 053] [01-01 18:12:25 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:29 069] [01-01 18:12:25 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:29 069] [01-01 18:12:25 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:29 085] [01-01 18:12:25 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:29 085] [01-01 18:12:25 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:29 100] [01-01 18:12:25 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:29 101] [01-01 18:12:25 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:29 101] [01-01 18:12:25 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:29 597] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:29 613] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:29 629] src/intelligent_track_thread.c(705) [TrackProcV200]: --->wait finish goto savepreset
[2024/8/7 9:28:29 629] src/intelligent_track_thread.c(709) [TrackProcV200]: Intelligent Track Enable eSensitivity=0 intervalTime_sec=15
[2024/8/7 9:28:29 645] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:29 645] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:29 662] [01-01 18:12:25 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:28:29 917] [1970-01-01 00:00:21] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:29 917] [01-01 18:12:26 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:29 933] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:29 933] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:29 933] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:29 949] [01-01 18:12:26 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:29 949] [01-01 18:12:26 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:29 965] [01-01 18:12:26 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:29 965] [01-01 18:12:26 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:29 965] [01-01 18:12:26 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:29 981] [01-01 18:12:26 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:29 981] [01-01 18:12:26 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:29 996] [01-01 18:12:26 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:29 996] [01-01 18:12:26 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:29 996] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:30 029] [01-01 18:12:26 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:30 029] [01-01 18:12:26 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:30 045] [01-01 18:12:26 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:30 045] [01-01 18:12:26 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:30 045] gethostbyname_r error: Unknown host
[2024/8/7 9:28:30 061] [01-01 18:12:26 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:30 061] [01-01 18:12:26 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:30 077] [01-01 18:12:26 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:30 077] [01-01 18:12:26 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:30 092] [01-01 18:12:26 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:30 093] [01-01 18:12:26 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:30 108] [01-01 18:12:26 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:30 109] [01-01 18:12:26 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:30 620] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:28:30 636] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:30 652] [01-01 18:12:26 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:28:30 700] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:28:30 700] Mode(Product):0
[2024/8/7 9:28:30 700] BpuMode:[Online]
[2024/8/7 9:28:30 700] VpssMode:[Online]
[2024/8/7 9:28:30 700] [0.LimitUp_info]:
[2024/8/7 9:28:30 700] LimitUp:[Disable]
[2024/8/7 9:28:30 700] [2680*0]->[3840*0])
[2024/8/7 9:28:30 700] chn	TotalSize	ActiveSize
[2024/8/7 9:28:30 700] 0	5040*2246	2680*2160
[2024/8/7 9:28:30 716] 0	5040*2246	2680*2160
[2024/8/7 9:28:30 716] 0	5040*2246	3840*2160
[2024/8/7 9:28:30 716] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:28:30 716] [1.VICU_info]:
[2024/8/7 9:28:30 716] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:28:30 716] 0	25.0	362	0	0	183	linear	8ddb00
[2024/8/7 9:28:30 716] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:28:30 732] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:28:30 732] en	op_type	m_chn	now
[2024/8/7 9:28:30 732] 0	1	1	1
[2024/8/7 9:28:30 732] [2.VI_info]:
[2024/8/7 9:28:30 732] chn	TotalSize	ActiveSize
[2024/8/7 9:28:30 732] 0	5040*2246	3848*2166
[2024/8/7 9:28:30 732] 1	   0*   0	   0*   0
[2024/8/7 9:28:30 732] [3.MIPI_info]:
[2024/8/7 9:28:30 748] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:28:30 748] 0x 1	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:28:30 748] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:28:30 748] [4.Cut_info]:
[2024/8/7 9:28:30 764] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:28:30 764] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:28:30 764] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:28:30 764] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:28:30 764] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:28:30 764] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:28:30 780] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:28:30 780] [5.IB(isp buffer info)]:
[2024/8/7 9:28:30 780] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:28:30 780] PoolId  Count  Size
[2024/8/7 9:28:30 797] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:30 797] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:30 813] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:30 813] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:30 813] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:30 829] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:30 829] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:28:30 829] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:28:30 844] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:28:30 844] 0       0         0          2          4       
[2024/8/7 9:28:30 844] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:28:30 860]      --265--            --264--                                               
[2024/8/7 9:28:30 860] Count      Line     Count      Line     
[2024/8/7 9:28:30 860] 275        480      617        560      
[2024/8/7 9:28:30 876] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:28:30 876] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:28:30 892] 0   3840   2160    H265  0      0        0           164       983036     4        	
[2024/8/7 9:28:30 892] 1   640    360     H265  0      0        0           106       43200      0        	
[2024/8/7 9:28:30 908] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:28:30 908] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:28:30 924] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:28:30 940] 0   Y      164      0       0       15       0        164      164      231       64134         58904    115839   65137    11      
[2024/8/7 9:28:30 940] 1   Y      106      0       4       1        0        106      106      232       2814          1911     27184    2750     7       
[2024/8/7 9:28:30 957] 3   N      0        0       0       1        0        0        0        233       0             0        0        0        0       
[2024/8/7 9:28:30 972] [1970-01-01 00:00:22] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:30 972] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:30 988] [1970-01-01 00:00:22] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:30 988] [1970-01-01 00:00:22] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:31 004] [1970-01-01 00:00:22] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:31 020] [01-01 18:12:27 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:31 020] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:31 020] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:31 036] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:31 036] [01-01 18:12:27 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:31 036] [01-01 18:12:27 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:31 052] [01-01 18:12:27 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:31 052] [01-01 18:12:27 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:31 068] [01-01 18:12:27 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:31 068] [01-01 18:12:27 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:31 068] [01-01 18:12:27 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:31 084] [01-01 18:12:27 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:31 084] [01-01 18:12:27 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:31 100] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:31 116] [01-01 18:12:27 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:31 116] [01-01 18:12:27 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:31 132] [01-01 18:12:27 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:31 132] [01-01 18:12:27 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:31 148] gethostbyname_r error: Unknown host
[2024/8/7 9:28:31 148] [01-01 18:12:27 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:31 148] [01-01 18:12:27 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:31 164] [01-01 18:12:27 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:31 164] [01-01 18:12:27 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:31 180] [01-01 18:12:27 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:31 180] [01-01 18:12:27 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:31 196] [01-01 18:12:27 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:31 196] [01-01 18:12:27 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:31 196] [01-01 18:12:27 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:28:31 964] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:31 980] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:31 996] [1970-01-01 00:00:23] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:32 012] [01-01 18:12:28 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:32 012] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:32 028] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:32 029] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:32 029] [01-01 18:12:28 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:32 044] [01-01 18:12:28 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:32 044] [01-01 18:12:28 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:32 044] [01-01 18:12:28 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:32 060] [01-01 18:12:28 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:32 060] [01-01 18:12:28 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:32 060] [01-01 18:12:28 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:32 076] [01-01 18:12:28 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:32 076] [01-01 18:12:28 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:32 093] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:32 108] [01-01 18:12:28 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:32 124] [01-01 18:12:28 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:32 125] [01-01 18:12:28 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:32 140] [01-01 18:12:28 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:32 140] gethostbyname_r error: Unknown host
[2024/8/7 9:28:32 141] [01-01 18:12:28 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:32 156] [01-01 18:12:28 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:32 156] [01-01 18:12:28 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:32 156] [01-01 18:12:28 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:32 172] [01-01 18:12:28 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:32 188] [01-01 18:12:28 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:32 190] [01-01 18:12:28 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:32 190] [01-01 18:12:28 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:32 988] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:33 004] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:33 005] [1970-01-01 00:00:24] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:33 020] [1970-01-01 00:00:24] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:33 021] [1970-01-01 00:00:24] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time24769
[2024/8/7 9:28:33 036] [01-01 18:12:29 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:33 037] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:33 052] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:33 052] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:33 053] [01-01 18:12:29 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:33 069] [01-01 18:12:29 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:33 069] [01-01 18:12:29 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:33 084] [01-01 18:12:29 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:33 084] [01-01 18:12:29 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:33 084] [01-01 18:12:29 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:33 100] [01-01 18:12:29 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:33 100] [01-01 18:12:29 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:33 100] [01-01 18:12:29 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:33 116] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:33 132] [01-01 18:12:29 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:33 148] [01-01 18:12:29 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:33 148] [01-01 18:12:29 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:33 164] [01-01 18:12:29 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:33 164] gethostbyname_r error: Unknown host
[2024/8/7 9:28:33 164] [01-01 18:12:29 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:33 180] [01-01 18:12:29 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:33 180] [01-01 18:12:29 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:33 196] [01-01 18:12:29 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:33 196] [01-01 18:12:29 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:33 212] [01-01 18:12:29 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:33 212] [01-01 18:12:29 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:33 212] [01-01 18:12:29 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:34 124] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:34 140] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:34 156] [1970-01-01 00:00:25] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:34 156] [1970-01-01 00:00:25] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:34 172] [01-01 18:12:30 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:34 172] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:34 188] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:34 188] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:34 188] [01-01 18:12:30 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:34 203] [01-01 18:12:30 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:34 204] [01-01 18:12:30 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:34 220] [01-01 18:12:30 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:34 220] [01-01 18:12:30 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:34 220] [01-01 18:12:30 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:34 236] [01-01 18:12:30 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:34 236] [01-01 18:12:30 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:34 251] [01-01 18:12:30 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:34 252] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:34 267] [01-01 18:12:30 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:34 284] [01-01 18:12:30 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:34 284] [01-01 18:12:30 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:34 300] [01-01 18:12:30 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:34 300] gethostbyname_r error: Unknown host
[2024/8/7 9:28:34 300] [01-01 18:12:30 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:34 316] [01-01 18:12:30 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:34 316] [01-01 18:12:30 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:34 333] [01-01 18:12:30 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:34 333] [01-01 18:12:30 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:34 348] [01-01 18:12:30 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:34 348] [01-01 18:12:30 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:34 348] [01-01 18:12:30 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:34 428] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:34 428] [01-01 18:12:30 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:28:35 115] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:35 131] set basic_indicator_onoff:0 
[2024/8/7 9:28:35 131] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(257) <IPC_APP_set_basic_indicator_onoff>: Get BasicIndicator suc,gpio value=[0x0c]
[2024/8/7 9:28:35 148] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:35 148] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:35 163] set basic_indicator_onoff:1 
[2024/8/7 9:28:35 163] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:35 179] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:35 179] [1970-01-01 00:00:26] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:35 195] [1970-01-01 00:00:26] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:35 195] set basic_indicator_onoff:0 
[2024/8/7 9:28:35 211] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:35 211] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:35 211] set basic_indicator_onoff:1 
[2024/8/7 9:28:35 227] [1970-01-01 00:00:26] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:35 227] [1970-01-01 00:00:26] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:35 243] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:35 259] [01-01 18:12:31 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:35 259] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:35 259] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:35 276] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:35 276] [01-01 18:12:31 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:35 292] [01-01 18:12:31 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:35 293] [01-01 18:12:31 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:35 293] [01-01 18:12:31 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:35 308] [01-01 18:12:31 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:35 308] [01-01 18:12:31 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:35 308] [01-01 18:12:31 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:35 324] [01-01 18:12:31 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:35 324] [01-01 18:12:31 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:35 340] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:35 356] [01-01 18:12:31 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:35 372] [01-01 18:12:31 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:35 372] [01-01 18:12:31 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:35 372] [01-01 18:12:31 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:35 388] gethostbyname_r error: Unknown host
[2024/8/7 9:28:35 388] [01-01 18:12:31 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:35 388] [01-01 18:12:31 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:35 404] [01-01 18:12:31 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:35 404] [01-01 18:12:31 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:35 421] [01-01 18:12:31 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:35 421] [01-01 18:12:31 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:35 436] [01-01 18:12:31 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:35 436] [01-01 18:12:31 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:35 564] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:28:35 564] set basic_indicator_onoff:0 
[2024/8/7 9:28:35 580] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:35 580] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:35 580] set basic_indicator_onoff:1 
[2024/8/7 9:28:35 596] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:35 596] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:35 612] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:35 612] set basic_indicator_onoff:0 
[2024/8/7 9:28:35 628] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:35 628] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:35 644] [01-01 18:12:31 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:28:36 188] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:36 188] set basic_indicator_onoff:1 
[2024/8/7 9:28:36 188] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:36 204] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:36 204] set basic_indicator_onoff:0 
[2024/8/7 9:28:36 220] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:36 220] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:36 236] [1970-01-01 00:00:27] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:36 236] set basic_indicator_onoff:1 
[2024/8/7 9:28:36 252] [1970-01-01 00:00:27] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:36 252] [1970-01-01 00:00:27] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:36 268] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:36 268] [01-01 18:12:32 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:36 284] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:36 284] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:36 300] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:36 300] [01-01 18:12:32 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:36 300] [01-01 18:12:32 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:36 316] [01-01 18:12:32 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:36 316] [01-01 18:12:32 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:36 316] [01-01 18:12:32 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:36 332] [01-01 18:12:32 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:36 332] [01-01 18:12:32 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:36 348] [01-01 18:12:32 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:36 348] [01-01 18:12:32 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:36 348] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:36 380] [01-01 18:12:32 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:36 380] [01-01 18:12:32 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:36 396] [01-01 18:12:32 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:36 396] [01-01 18:12:32 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:36 396] gethostbyname_r error: Unknown host
[2024/8/7 9:28:36 412] [01-01 18:12:32 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:36 412] [01-01 18:12:32 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:36 428] [01-01 18:12:32 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:36 428] [01-01 18:12:32 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:36 444] [01-01 18:12:32 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:36 444] [01-01 18:12:32 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:36 460] [01-01 18:12:32 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:36 460] [01-01 18:12:32 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:36 460] [01-01 18:12:32 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:28:36 556] set basic_indicator_onoff:0 
[2024/8/7 9:28:36 572] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:36 572] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:36 572] set basic_indicator_onoff:1 
[2024/8/7 9:28:36 587] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:36 587] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:36 604] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:36 619] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:36 619] ble_slave_gap_event->type=0
[2024/8/7 9:28:36 619] connection established; status=0 GATT procedure initiated: exchange mtu
[2024/8/7 9:28:36 619] connection, handle=1
[2024/8/7 9:28:36 635] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:36 635] --- tracepoint bt_ext_porting.c,ty_btext_thread(423): TY_BT_EVENT_CONNECTED1 ---
[2024/8/7 9:28:36 651] [01-01 18:12:32 TUYA D][tuya_ble_api.c:543] rev ble event 1
[2024/8/7 9:28:36 652] [01-01 18:12:32 TUYA N][tuya_ble_api.c:472] Ble Connected
[2024/8/7 9:28:36 652] [01-01 18:12:32 TUYA N][tuya_ble_data_handler.c:64] ble reset sn
[2024/8/7 9:28:36 667] [01-01 18:12:32 TUYA N][tuya_ble_api.c:1464] ble set conn stat:1
[2024/8/7 9:28:37 211] --- tracepoint bt_ext_porting.c,ty_btext_thread(425): TY_BT_EVENT_CONNECTED2 ---
[2024/8/7 9:28:37 211] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:37 211] set basic_indicator_onoff:0 
[2024/8/7 9:28:37 227] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:37 227] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:37 243] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:37 243] ble_slave_gap_event->type=15
[2024/8/7 9:28:37 243] mtu update event; conn_handle=1 cid=4 mtu=255
[2024/8/7 9:28:37 259] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:37 259] set basic_indicator_onoff:1 
[2024/8/7 9:28:37 275] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:37 275] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:37 291] [1970-01-01 00:00:28] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:37 307] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:37 307] ble_slave_gap_event->type=4
[2024/8/7 9:28:37 307] connection update request
[2024/8/7 9:28:37 307] set basic_indicator_onoff:0 
[2024/8/7 9:28:37 323] [1970-01-01 00:00:28] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:37 339] [1970-01-01 00:00:28] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:37 340] 
[2024/8/7 9:28:37 340] [1970-01-01 00:00:28] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time28863
[2024/8/7 9:28:37 355] [1970-01-01 00:00:28] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:37 355] [1970-01-01 00:00:28] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:37 371] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:37 371] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:37 387] set basic_indicator_onoff:1 
[2024/8/7 9:28:37 388] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:37 403] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:37 403] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:37 403] set basic_indicator_onoff:0 
[2024/8/7 9:28:37 420] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:37 420] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:37 436] [01-01 18:12:33 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:37 436] [01-01 18:12:33 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:37 452] [01-01 18:12:33 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:37 452] [01-01 18:12:33 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:37 452] [01-01 18:12:33 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:37 468] [01-01 18:12:33 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:37 468] [01-01 18:12:33 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:37 468] [01-01 18:12:33 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:37 484] [01-01 18:12:33 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:37 484] [01-01 18:12:33 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:37 500] [01-01 18:12:33 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:37 501] [01-01 18:12:33 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:37 501] [01-01 18:12:33 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:37 516] [01-01 18:12:33 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:37 532] [01-01 18:12:33 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:37 548] [01-01 18:12:33 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:37 548] [01-01 18:12:33 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:37 564] [01-01 18:12:33 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:37 564] gethostbyname_r error: Unknown host
[2024/8/7 9:28:37 580] [01-01 18:12:33 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:37 580] [01-01 18:12:33 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:37 595] [01-01 18:12:33 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:37 595] [01-01 18:12:33 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:37 611] [01-01 18:12:33 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:37 611] [01-01 18:12:33 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:37 627] [01-01 18:12:33 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:37 627] [01-01 18:12:33 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:37 787] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:37 837] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:37 900] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:38 204] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 220] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:38 220] ble_slave_gap_event->type=3
[2024/8/7 9:28:38 236] connection updated; status=0  conn_itvl=6 conn_latency=3 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:28:38 236] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 252] set basic_indicator_onoff:1 
[2024/8/7 9:28:38 252] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:38 267] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:38 268] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 283] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 284] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 299] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 299] set basic_indicator_onoff:0 
[2024/8/7 9:28:38 315] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:38 315] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:38 331] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 331] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:38 347] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 363] [1970-01-01 00:00:29] MainApp.c(1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:38 363] 978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 379] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 379] set basic_indicator_onoff:1 
[2024/8/7 9:28:38 379] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:38 395] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 395] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:38 411] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 411] ble_slave_gap_event->type=4
[2024/8/7 9:28:38 427] connection update request
[2024/8/7 9:28:38 428] [1970-01-01 00:00:29] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 428] ble_slave_gap_event->type=14
[2024/8/7 9:28:38 443] subscribe event; conn_handle=1 attr_handle=23 reason=1 prevn=0 curn=1 previ=0 curi=0
[2024/8/7 9:28:38 443] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:28:38 443] set basic_indicator_onoff:0 
[2024/8/7 9:28:38 459] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:38 459] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:38 475] [1970-01-01 00:00:29] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:38 475] ble_slave_gap_event->type=3
[2024/8/7 9:28:38 491] connection updated; status=0  conn_itvl=40 conn_latency=2 supervision_timeout=500 encrypted=0 authenticated=0 bonded=0
[2024/8/7 9:28:38 491] set basic_indicator_onoff:1 
[2024/8/7 9:28:38 508] [1970-01-01 00:00:29] tuya_ipc_dp_handler.c(262) <IPC_APP_se[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:38 508] t_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:38 508] [1970-01-01 00:00:29] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:38 524] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:38 524] set basic_indicator_onoff:0 
[2024/8/7 9:28:38 540] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:38 540] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:38 556] [01-01 18:12:34 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:38 556] [01-01 18:12:34 TUYA D][simplekv.c:1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:38 571] 348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:38 572] [01-01 18:12:34 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:38 572] [01-01 18:12:34 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:38 588] [01-01 18:12:34 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:38 588] [01-01 18:12:34 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:38 588] [01-01 18:12:34 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:38 603] [01-01 18:12:34 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:38 603] [01-01 18:12:34 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:38 619] [0[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:38 619] 1-01 18:12:34 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:38 619] [01-01 18:12:34 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:38 635] [01-01 18:12:34 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:38 635] [01-01 18:12:34 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:38 651] [01-01 18:12:34 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:38 667] [01-01 18:12:34 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:38 667] [01-01 18:12:34 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:38 683] [01-01 18:12:34 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:38 683] [01-01 18:12:34 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:38 699] gethostbyname_r error: Unknown host
[2024/8/7 9:28:38 699] [01-01 18:12:34 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:38 699] [01-01 18:12:34 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:38 715] [01-01 18:12:34 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:38 715] [01-01 18:12:34 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:38 732] [01-01 18:12:34 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:38 732] [01-01 18:12:34 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:38 747] [01-01 18:12:34 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:38 747] [01-01 18:12:34 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:38 747] set basic_indicator_onoff:1 
[2024/8/7 9:28:38 763] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:38 763] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:38 779] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:38 779] ---[ble_svc_gatt_access][309]: u[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:38 779] uid=[11025]
[2024/8/7 9:28:38 796] Len=20 step 0
[2024/8/7 9:28:38 796] att=0x0 0x21 0x20 0x1 0xe8 0xa0 0x19 0x59 0x1a 0x22 0xe2 0x60 0x9a 0xd0 0x35 0xa1 0xa5 0x21 0xb9 0x21 
[2024/8/7 9:28:38 796]  RCVS len:20
[2024/8/7 9:28:38 796] XmBleReadBuf 20:
[2024/8/7 9:28:38 812] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:38 812] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:38 812] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:38 828] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:38 828] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:38 843] [01-01 18:12:34 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:38 844] [01-01 18:12:34 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:38 844] [01-01 18:12:34 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:38 844] bt_rev_raw 20
[2024/8/7 9:28:38 860] 00 21 20 01 e8 a0 19 59 1a 22 e2 60 9a d0 35 a1 a5 21 b9 21 
[2024/8/7 9:28:38 860] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:28:38 875] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:38 875] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:38 875] set basic_indicator_onoff:0 
[2024/8/7 9:28:38 891] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:38 891] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:38 907] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:38 907] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:38 923]  ---
[2024/8/7 9:28:38 924] Len=17 step 0
[2024/8/7 9:28:38 924] att=0x1 0x5e 0x63 0xd4 0x86 0x9a 0x82 0x26 0x31 0xf2 0x25 0x47 0xfb 0x20 0xb3 0x7c 0xc5 
[2024/8/7 9:28:38 924]  RCVS len:17
[2024/8/7 9:28:38 924] XmBleReadBuf 17:
[2024/8/7 9:28:38 939] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:38 939] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:38 939] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:38 971] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:28:38 987] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:28:38 987] [01-01 18:12:34 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:28:38 987] [01-01 18:12:34 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:39 004] [01-01 18:12:34 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:39 004] bt_rev_raw 17
[2024/8/7 9:28:39 004] 01 5e 63 d4 86 9a 82 26 31 f2 25 47 fb 20 b3 7c c5 
[2024/8/7 9:28:39 020] [01-01 18:12:34 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:28:39 020] ble rev data 33
[2024/8/7 9:28:39 020] 01 e8 a0 19 59 1a 22 e2 60 9a d0 35 a1 a5 21 b9 21 5e 63 d4 86 9a 82 26 31 f2 25 47 fb 20 b3 7c c5 
[2024/8/7 9:28:39 036] [01-01 18:12:34 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:28:39 036] ble decryped data 16
[2024/8/7 9:28:39 036] 00 00 00 01 00 00 00 00 00 00 00 00 92 69 00 00 
[2024/8/7 9:28:39 052] [01-01 18:12:34 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:28:39 052] [01-01 18:12:34 TU[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:39 052] YA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x0 
[2024/8/7 9:28:39 068] [01-01 18:12:34 TUYA N][tuya_ble_data_handler.c:451] tuya_ble_handle_dev_infor_req state:0, pkg_len:20
[2024/8/7 9:28:39 068] [01-01 18:12:34 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:28:39 084] [01-01 18:12:34 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:28:39 084] [01-01 18:12:34 TUYA D][tuya_ble_cryption_api.c:207] got key, mode:1
[2024/8/7 9:28:39 084] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:28:39 100] set basic_indicator_onoff:1 
[2024/8/7 9:28:39 100] [01-01 18:12:34 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:4, send_data:16
[2024/8/7 9:28:39 100] tuya_hal_bt_send 20
[2024/8/7 9:28:39 115] 00 81 01 30 01 57 27 a7 05 d4 d[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:39 116] 0 52 82 [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:39 131] 77 75 1b 99 4a ed 58 
[2024/8/7 9:28:39 131] [01-01 18:12:34 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:39 131] 0 81 1 30 1 57 27 a7 5 d4 d0 [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:39 148] 
[2024/8/7 9:28:39 149] 52 82 77 75 1b 99 4a ed 58 
[2024/8/7 9:28:39 149] XmBleSendBuf 20: 00 81 01 30 01 57 27 a7 05 d4 d0 52 82 77 75 1b 99 4a ed 58
[2024/8/7 9:28:39 149] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:39 164] ble_slave_gap_event->type=13
[2024/8/7 9:28:39 164] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:39 164] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:39 180] [01-01 18:12:34 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:39 180] [1970-01-01 00:00:30] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:39 196] [01-01 18:12:34 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:39 196] tuya_hal_bt_send 20
[2024/8/7 9:28:39 196] 01 3d c5 32 59 07 de 63 50 c0 93 f5[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:39 196]  c1 83 96 e1 8b dc 52 73 
[2024/8/7 9:28:39 213] [01-01 18:12:34 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:39 213] 1 3d c5 32 59 7 de 63 50 c0 93 f5 c1 83 96 e1 8b dc 52 73 
[2024/8/7 9:28:39 213] XmBleSendBuf 20: 01 3d c5 32 59 07 de 63 50 c0 93 f5 c1 83 96 e1 8b dc 52 73
[2024/8/7 9:28:39 228] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:39 228] ble_slave_gap_event->type=13
[2024/8/7 9:28:39 228] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:39 228] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:39 244] [01-01 18:12:34 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:39 244] [01-01 18:12:34 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:39 260] tuya_hal_bt_send 20
[2024/8/7 9:28:39 260] 02 7f e5 41 ab 7e 7f ad ca 68 05 45 46 d3 00 5f 28 16 94 b8 
[2024/8/7 9:28:39 260] [01-01 18:12:34 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:39 276] 2 7f e5 41 ab 7e 7f ad ca 68 5 45 46 d3 0 5f 28 16 94 b8 
[2024/8/7 9:28:39 276] XmBleSendBuf 20: 02 7f e5 41 ab 7e 7f ad ca 68 05 45 46 d3 00 5f 28 16 94 b8
[2024/8/7 9:28:39 276] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:39 276] ble_slave_gap_event->type=13
[2024/8/7 9:28:39 292] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:39 292] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:39 292] [01-01 18:12:34 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:39 308] set basic_indicator_onoff:0 
[2024/8/7 9:28:39 308] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:39 324] [1970-01-01 00:00:30] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:39 340] [01-01 18:12:34 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:39 340] tuya_hal_bt_send 20
[2024/8/7 9:28:39 340] 03 59 4b 8c 08 [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:39 340] d5 ea 7c d3 4d de 5c 96 5a d7 fc fe 7e 59 18 
[2024/8/7 9:28:39 356] [01-01 18:12:34 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:39 372] 3 59 4b 8c 8 d5 ea 7c d3 4d de 5c 96 5a d7 fc fe 7e 59 18 
[2024/8/7 9:28:39 372] XmBleSendBuf 20: 03 59 4b 8c 08 d5 ea 7c d3 4d de 5c 96 5a d7 fc fe 7e 59 18
[2024/8/7 9:28:39 388] GATT procedure initiated: notify[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:39 388] ; att_handle=23
[2024/8/7 9:28:39 388] ble_slave_gap_event->type=13
[2024/8/7 9:28:39 388] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:39 404] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:39 404] [01-01 18:12:35 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:39 420] [01-01 18:12:35 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:39 420] tuya_hal_bt_send 20
[2024/8/7 9:28:39 420] 04 62 1a 7b a3 51 8d 9e 5f c7 af 1b 6c 75 0d 3d 20 a5 4b 6c 
[2024/8/7 9:28:39 420] [01-01 18:12:35 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:39 436] 4 62 1a 7b a3 51 8d 9e 5f c7 af 1b 6c 75 d 3d 20 a5 4b 6c 
[2024/8/7 9:28:39 436] XmBleSendBuf 20: 04 62 1a 7b a3 51 8d 9e 5f c7 af 1b 6c 75 0d 3d 20 a5 4b 6c
[2024/8/7 9:28:39 452] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:39 454] ble_slave_gap_event->type=13
[2024/8/7 9:28:39 454] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:39 454] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:39 468] [01-01 18:12:35 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:39 468] set basic_indicator_onoff:1 
[2024/8/7 9:28:39 468] [1970-01-01 00:00:30] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:39 484] [1970-01-01 00:00:30] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:39 500] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:39 500] [01-01 18:12:35 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:19
[2024/8/7 9:28:39 500] tuya_hal_bt_send 20
[2024/8/7 9:28:39 515] 05 25 a0 26 c5 4e 42 8d 36 14 f2 f4 31 b2 09 13 93 0d 3c e5 
[2024/8/7 9:28:39 516] [01-01 18:12:35 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:39 516] 5 25[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:39 531]  a0 26 c5 4e 42 8d 36 14 f2 f4 31 b2 9 13 93 d 3c e5 
[2024/8/7 9:28:39 532] XmBleSendBuf 20: 05 25 a0 26 c5 4e 42 8d 36 14 f2 f4 31 b2 09 13 93 0d 3c e5
[2024/8/7 9:28:39 532] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:39 547] ble_slave_gap_event->type=13
[2024/8/7 9:28:39 547] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:39 547] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:39 548]  ---
[2024/8/7 9:28:39 563] [01-01 18:12:35 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:39 563] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:39 579] [01-01 18:12:35 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:18
[2024/8/7 9:28:39 579] tuya_hal_bt_send 19
[2024/8/7 9:28:39 580] 06 ff 23 10 77 ff b2 d8 3a e0 f8 95 2b 34 ad 6e 72 bf 3b 
[2024/8/7 9:28:39 580] [01-01 18:12:35 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:39 595] 6 ff 23 10 77 ff b2 d8 3a e0 f8 95 2b 34 ad 6e 72 bf 3b 
[2024/8/7 9:28:39 595] XmBleSendBuf 19: 06 ff 23 10 77 ff b2 d8 3a e0 f8 95 2b 34 ad 6e 72 bf 3b
[2024/8/7 9:28:39 596] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:39 611] ble_slave_gap_event->type=13
[2024/8/7 9:28:39 611] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:39 611] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:39 627] [01-01 18:12:35 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:39 627] set basic_indicator_onoff:0 
[2024/8/7 9:28:39 627] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:39 643] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:39 643] [01-01 18:12:35 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:129, send_ret:0x0
[2024/8/7 9:28:39 659] [01-01 18:12:35 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:0
[2024/8/7 9:28:39 659] set basic_indicator_onoff:1 
[2024/8/7 9:28:39 659] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:39 675] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:39 675] ---[ble_svc_gatt_access][309]: uuid=[1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:39 691] 1025]
[2024/8/7 9:28:39 691]  ---
[2024/8/7 9:28:39 691] Len=20 step 0
[2024/8/7 9:28:39 691] att=0x0 0x51 0x20 0x2 0x77 0x51 0xcc 0x5 0x9f 0xd9 0x60 0xf1 0x5a 0x9d 0xcb 0x75 0x1 0x16 0xfc 0x47 
[2024/8/7 9:28:39 691]  RCVS len:20
[2024/8/7 9:28:39 707] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:39 707] XmBleReadBuf 20:
[2024/8/7 9:28:39 707] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:39 707] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:39 723] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:39 723] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:39 739] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:39 739] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:39 739] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:39 755] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:39 755] bt_rev_raw 20
[2024/8/7 9:28:39 771] 00 51 20 02 77 51 cc 05 9f d9 60 f1 5a 9d cb 75 01 16 fc[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:39 771]  47 
[2024/8/7 9:28:39 771] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:28:39 788] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:39 788] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:39 804] [01-01 18:12:35 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:39 804] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:39 804] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:39 819] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:39 819] [01-01 18:12:35 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:39 819] [01-01 18:12:35 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:39 836] [01-01 18:12:35 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:39 836] [01-01 18:12:35 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:39 852] [01-01 18:12:35 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:39 852] [01-01 18:12:35 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:39 852] [01-01 18:12:35 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:39 868] [01-01 18:12:35 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:39 868] [01-01 18:12:35 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:39 884] [01-01 18:12:35 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:39 900] [01-01 18:12:35 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:39 900] [01-01 18:12:35 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:39 916] [01-01 18:12:35 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:39 916] [01-01 18:12:35 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:39 932] gethostbyname_r error: Unknown host
[2024/8/7 9:28:39 932] [01-01 18:12:35 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:39 932] [01-01 18:12:35 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:39 948] [01-01 18:12:35 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:39 948] [01-01 18:12:35 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:39 964] [01-01 18:12:35 TUYA D][httpc.c:815] Connect: h2.iot-dns.com[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:39 964]  Port: 443  --<< ,r:-15
[2024/8/7 9:28:39 979] [01-01 18:12:35 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:39 980] [01-01 18:12:35 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:39 980] [01-01 18:12:35 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:39 995] set basic_indicator_onoff:0 
[2024/8/7 9:28:39 996] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:40 011] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:40 012] 
[2024/8/7 9:28:40 012] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:40 012] Len=20 step 0
[2024/8/7 9:28:40 027] att=0x1 0xf9 0x2 0xc 0xb2 0x92 0x50 0xfa 0xb5 0x8 0x5f 0xae 0xec 0xdf 0x1e 0xc4 0x25 0x4f 0x26 0x6e 
[2024/8/7 9:28:40 028]  RCVS len:20
[2024/8/7 9:28:40 028] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:40 043] XmBleReadBuf 20:
[2024/8/7 9:28:40 043] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:40 044] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:40 044] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:40 059] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:40 060] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:40 075] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:40 076] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:40 091] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:40 091] bt_rev_raw 20
[2024/8/7 9:28:40 092] 01 f9 02 0c b2 92 50 fa b5 08 5f ae ec df 1e c4 25 4f 26 6e 
[2024/8/7 9:28:40 107] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:28:40 107] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:40 108] --- tracepoint bt[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:40 123] _ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:40 123] set basic_indicator_onoff:1 
[2024/8/7 9:28:40 139] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:40 140] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:40 140] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:40 140] Len=20 step 0
[2024/8/7 9:28:40 155] att=0x2 0xa5 0x9b 0xb3 0xbd 0x4b 0xc8 0xf8 0x99 0xdd 0xfe 0x82 0x7e 0xc4 0x4c 0xee 0x6e 0x67 0x96 0x22 
[2024/8/7 9:28:40 155]  RCVS len:20
[2024/8/7 9:28:40 171] [1970-01-01 00:00:31] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:40 171] XmBleReadBuf 20:
[2024/8/7 9:28:40 171] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:40 171] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:40 187] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:40 188] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:40 188] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:40 203] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:40 203] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:40 219] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:40 219] bt_rev_raw 20
[2024/8/7 9:28:40 219] 02 a5 9b b3 bd 4b c8 f8 99 dd fe 82 7e c4 4c ee 6e 67 96 22 
[2024/8/7 9:28:40 235] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:28:40 235] [01-01 18:12:35 TUYA D][tuya_ble_dat[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:40 235] a_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:40 251] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:40 267] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:40 267] --- tracepoint xm_wifi.c,CheckNLCNetwork_Pro(403): g_NLCIsOk:0,g_WifiConectStatuts:0
[2024/8/7 9:28:40 267] set basic_indicator_onoff:0 
[2024/8/7 9:28:40 283] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:40 283] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:40 300] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:40 300] Len=20 step 0
[2024/8/7 9:28:40 300] att=0x3 0x92 0x94 0x70 0x81 0x5e 0x4d 0xc7 0xd6 0xc4 0x7e 0x28 0x56 0x50 0x13 0xb1 0xa4 0x67 0x91 0xce 
[2024/8/7 9:28:40 300]  RCVS len:20
[2024/8/7 9:28:40 316] XmBleReadBuf 20:
[2024/8/7 9:28:40 316] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:40 316] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:40 316] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:40 332] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:40 332] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:40 348] [01-01 18:12:35 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:40 348] [01-01 18:12:35 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:40 364] [01-01 18:12:35 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:40 368] bt_rev_raw 20
[2024/8/7 9:28:40 368] 03 92 94 70 81 5e 4d c7 d6 c4 7e 28 56 50 13 b1 a4 67 91 ce 
[2024/8/7 9:28:40 380] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:28:40 380] [01-01 18:12:35 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:40 380] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:40 396] set basic_indicator_onoff:1 
[2024/8/7 9:28:40 396] [1970-01-01 00:00:31] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:40 412] [1970-01-01 00:00:31] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:40 412] ---[ble_svc_gatt_access][309]: uuid=[1102[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:40 412] 5]
[2024/8/7 9:28:40 412] Len=8 step 0
[2024/8/7 9:28:40 428] att=0x4 0x75 0x6c 0xe6 0x50 0x82 0xf9 0x74 
[2024/8/7 9:28:40 428]  RCVS len:8
[2024/8/7 9:28:40 428] [1970-01-01 00:00:31] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:40 428] XmBleReadBuf 8:
[2024/8/7 9:28:40 443] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:40 443] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:40 443] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:40 459] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 16 rcount 16 offset 0 ---
[2024/8/7 9:28:40 459] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 16 ---
[2024/8/7 9:28:40 475] [01-01 18:12:36 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x9]
[2024/8/7 9:28:40 475] [01-01 18:12:36 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:40 476] [01-01 18:12:36 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:40 476] bt_rev_raw 8
[2024/8/7 9:28:40 491] 04 75 6c e6 50 82 f9 74 
[2024/8/7 9:28:40 491] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:5, pack_len:7, total_len:81
[2024/8/7 9:28:40 491] ble rev data 81
[2024/8/7 9:28:40 507] 02 77 51 cc 05 9f d9 60 f1 5a 9d cb 75 01 16 fc 47 f9 02 0c b2 92 50 fa b5 08 5f ae ec df 1e c4 25 4f 26 6e a5 9b b3 bd 4b c8 f8 99 dd fe 82 7e c4 4c ee 6e 67 96 22 92 94 70 81 5e 4d c7 d6 c4 
[2024/8/7 9:28:40 523] 7e 28 56 50 13 b1 a4 67 91 ce 75 6c e6 50 82 f9 74 
[2024/8/7 9:28:40 523] ble decryped data 64
[2024/8/7 9:28:40 539] 00 00 00 02 00 00 00 00 00 01 00 2c 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ca 1e 00 00 00 00 00 00 
[2024/8/7 9:28:40 540] 
[2024/8/7 9:28:40 555] [1970-01-01 00:00:31] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame su[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:40 556] cess width 640 height 360 data[]
[2024/8/7 9:28:40 556] [01-01 18:12:36 TUYA D][tuya_ble_api.c:1470] ble get conn stat:1
[2024/8/7 9:28:40 572] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x1 
[2024/8/7 9:28:40 572] [01-01 18:12:36 TUYA D][tuya_ble_api.c:573] conn monitor timer stopped
[2024/8/7 9:28:40 572] [01-01 18:12:36 TUYA N][tuya_ble_api.c:1464] ble set conn stat:3
[2024/8/7 9:28:40 588] [01-01 18:12:36 TUYA N][tuya_ble_data_handler.c:367] PAIR_REQ ok:0
[2024/8/7 9:28:40 588] [01-01 18:12:36 TUYA N][tuya_ble_data_handler.c:342] ble_time_req start...
[2024/8/7 9:28:40 604] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:348] no need to query time. network stat:1, work stat:0
[2024/8/7 9:28:40 604] [01-01 18:12:36 TUYA D][tuya_ble_api.c:517] default resp generated.
[2024/8/7 9:28:40 620] [01-01 18:12:36 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:40 620] [01-01 18:12:36 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:40 620] tuya_hal_bt_send 20
[2024/8/7 9:28:40 635] 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:28:40 636] [01-01 18:12:36 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:40 636] 0 21 31 2 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c 
[2024/8/7 9:28:40 651] XmBleSendBuf 20: 00 21 31 02 6a 52 36 d5 24 4a 68 8e ad 95 5f 3c 35 b5 c4 8c
[2024/8/7 9:28:40 651] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:40 651] ble_slave_gap_event->type=13
[2024/8/7 9:28:40 651] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:40 667] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:40 667] [01-01 18:12:36 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:40 683] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:16 ---
[2024/8/7 9:28:40 686] [01-01 18:12:36 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:28:40 686] tuya_hal_bt_send 17
[2024/8/7 9:28:40 686] 01 e6 c6 07 d4 6a 10 2d 97 40 2e 03 26 c5 5b ee 4e 
[2024/8/7 9:28:40 700] [01-01 18:12:36 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:40 700] 1 e6 c6 7 d4 6a 10 2d 97 40 2e 3 26 c5 5b ee 4e 
[2024/8/7 9:28:40 715] XmBleSendBuf 17: 01 e6 c6 07 d4 6a 10 2d 97 40 2e 03 26 c5 5b ee 4e
[2024/8/7 9:28:40 717] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:40 717] ble_slave_gap_event->type=13
[2024/8/7 9:28:40 717] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:40 717] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:40 731]  ---
[2024/8/7 9:28:40 731] [01-01 18:12:36 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:40 731] [01-[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:40 747] 01 18:12:36 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:28:40 747] [01-01 18:12:36 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:1
[2024/8/7 9:28:40 747] set basic_indicator_onoff:0 
[2024/8/7 9:28:40 763] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:40 763] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:40 779] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:40 779] Len=20 step 0
[2024/8/7 9:28:40 779] att=0x0 0x61 0x20 0x2 0x1 0xb7 0xae 0xbb 0xd4 0x8b 0x9 0xd3 0xd8 0x90 0xad 0x5f 0x8 0x91 0x69 0xdf 
[2024/8/7 9:28:40 779]  RCVS len:20
[2024/8/7 9:28:40 795] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:40 811] [1970-01-01 00:00:32] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:40 811] XmBleReadBuf 20:
[2024/8/7 9:28:40 811] --- t[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:40 811] racepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:40 827] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:40 827] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:40 827] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:40 843] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:40 875] [01-01 18:12:36 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:40 875] [01-01 18:12:36 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:40 891] [01-01 18:12:36 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:40 891] bt_rev_raw 20
[2024/8/7 9:28:40 891] 00 61 20 02 01 b7 ae bb d4 8b 09 d3 d8 90 ad 5f 08 91 69 df 
[2024/8/7 9:28:40 907] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:28:40 907] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:40 923] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:40 924] [01-01 18:12:36 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:28:40 924] [01-01 18:12:36 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:40 939] [01-01 18:12:36 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:40 939] set basic_indicator_onoff:1 
[2024/8/7 9:28:40 939] [01-01 18:12:36 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:40 955] [01-01 18:12:36 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:40 955] [01-01 18:12:36 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:40 955] [01-01 18:12:36 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:40 971] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:40 971] [01-01 18:12:36 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:40 987] [01-01 18:12:36 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:40 987] [01-01 18:12:36 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:40 987] [01-01 18:12:36 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:41 003] [01-01 18:12:36 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:41 003] [01-01 18:12:36 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:41 019] [01-01 18:12:36 TUYA D][uni_network.c:403] set_dns_cache_priority:2
[2024/8/7 9:28:41 035] [01-01 18:12:36 TUYA D][iot_httpc.c:1514] http_dns send: {"env":"pro","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:41 051] [01-01 18:12:36 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v1/url_config
[2024/8/7 9:28:41 051] [01-01 18:12:36 TUYA D][[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:41 051] httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:41 067] [01-01 18:12:36 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 2
[2024/8/7 9:28:41 067] gethostbyname_r error: Unknown host
[2024/8/7 9:28:41 067] [01-01 18:12:36 TUYA E][uni_network.c:360] fail to gethostbyname 22
[2024/8/7 9:28:41 084] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:41 084] Len=20 step 0
[2024/8/7 9:28:41 084] [01-01 18:12:36 TUYA D][uni_network.c:390] lower_dns_cache_priority:0
[2024/8/7 9:28:41 100] att=0x1 0x1e 0x9f 0xc5 0x80 0x4b 0xd1 0x77 0xb7 0x35 0x75 0x6c 0xfc 0xa4 0x54 0xac 0x6e 0x46 0x5 0xe2 
[2024/8/7 9:28:41 100]  RCVS len:20
[2024/8/7 9:28:41 100] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:41 116] [01-01 1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:41 116] 8:12:36 TUYA E][httpc.c:456] No entry for host h2.iot-dns.com found. -5
[2024/8/7 9:28:41 132] [01-01 18:12:36 TUYA E][httpc.c:542] Socket creation for h2.iot-dns.com:443 failed
[2024/8/7 9:28:41 132] [01-01 18:12:36 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:-15
[2024/8/7 9:28:41 148] [01-01 18:12:36 TUYA E][http_inf.c:51] Open session failed: https://h2.iot-dns.com/v1/url_config (-15)
[2024/8/7 9:28:41 148] [01-01 18:12:36 TUYA E][iot_httpc.c:1530] fail to get cloud url -2050
[2024/8/7 9:28:41 148] [01-01 18:12:36 TUYA D][uni_network.c:403] set_dns_cache_priority:0
[2024/8/7 9:28:41 163] XmBleReadBuf 20:
[2024/8/7 9:28:41 163] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:41 163] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:41 164] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:41 179] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:41 180] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:41 195] [01-01 18:12:36 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:41 195] [01-01 18:12:36 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:41 211] [01-01 18:12:36 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:41 211] bt_rev_raw 20
[2024/8/7 9:28:41 211] 01 1e 9f c5 80 4b d1 77 b7 35 75 6c fc a4 54 ac 6e 46 05 e2 
[2024/8/7 9:28:41 227] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:2, pack_len:19, total_len:36
[2024/8/7 9:28:41 227] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:41 228] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:41 243] set basic_indicator_onoff:0 
[2024/8/7 9:28:41 291] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:41 307] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:41 307] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:41 307] Len=20 step 0
[2024/8/7 9:28:41 323] att=0x2 0xf3 0x7b 0x7d 0xde 0x7 0xcf 0x5d 0x24 0x59 0x65 0x5f 0x10 0x69 0x4a 0x4b 0x38 0xa2 0xf4 0x66 
[2024/8/7 9:28:41 323]  RCVS len:20
[2024/8/7 9:28:41 323] [1970-01-01 00:00:32] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:41 323] XmBleReadBuf 20:
[2024/8/7 9:28:41 339] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:41 339] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:41 339] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:41 356] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:41 356] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:41 371] [01-01 18:12:36 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:41 371] [01-01 18:12:36 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:41 371] [01-01 18:12:36 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:41 371] bt_rev_raw 20
[2024/8/7 9:28:41 387] 02 f3 7b 7d de 07 cf 5d 24 59 65 5f 10 69 4a 4b 38 a2 f4 66 
[2024/8/7 9:28:41 387] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:3, pack_len:19, total_len:55
[2024/8/7 9:28:41 403] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:41 403] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:28:41 419] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:41 419] [1970-01-01 00:00:32] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:41 435] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:41 435] Len=20 step 0
[2024/8/7 9:28:41 435] att=0x3 0x1a 0xac 0xaa 0xcd 0x9e 0x7b 0xfc 0xb1 0x8 0xdb 0xbd 0x13 0xb8 0x6b 0x77 0x3f 0x95 0x39 0x63 
[2024/8/7 9:28:41 435]  RCVS len:20
[2024/8/7 9:28:41 452] set basic_indicator_onoff:1 
[2024/8/7 9:28:41 452] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:41 468] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:41 468] [01-01 18:12:36 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:28:41 468] XmBleReadBuf 20:
[2024/8/7 9:28:41 484] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:41 484] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:41 484] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:41 499] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:41 500] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:41 515] [01-01 18:12:36 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:41 515] [01-01 18:12:36 [atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:28:41 515] TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:41 531] [01-01 18:12:36 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:41 532] bt_rev_raw 20
[2024/8/7 9:28:41 532] 03 1a ac aa cd 9e 7b fc b1 08 db bd 13 b8 6b 77 3f 95 39 63 
[2024/8/7 9:28:41 547] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:4, pack_len:19, total_len:74
[2024/8/7 9:28:41 547] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:41 547] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:41 563] set basic_indicator_onoff:0 
[2024/8/7 9:28:41 563] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:41 580] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:41 580] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:41 580] Len=20 step 0
[2024/8/7 9:28:41 595] att=0x4 0x42 0xb7 0xb7 0x8f 0x9d 0x5d 0xbb 0xfa 0x91 0xf8 0xee 0x75 0x9e 0xae 0xa8 0x92 0x4f 0xf3 0x1b 
[2024/8/7 9:28:41 595]  RCVS len:20
[2024/8/7 9:28:41 595] [1970-01-01 00:00:32] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:41 611] XmBleReadBuf 20:
[2024/8/7 9:28:41 611] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:41 611] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:41 628] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:41 628] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:41 629] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:41 643] [01-01 18:12:36 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:41 644] [01-01 18:12:36 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:41 659] [01-01 18:12:36 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:41 659] bt_rev_raw 20
[2024/8/7 9:28:41 659] 04 42 b7 b7 8f 9d 5d bb fa 91 f8 ee 75 9e ae a8 92 4f f3 1b 
[2024/8/7 9:28:41 675] [01-01 18:12:36 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:2, no:5, pack_len:19, total_len:93
[2024/8/7 9:28:41 675] [01-01 18:12:37 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:41 691] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:41 691] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:41 691] Len=5 step 0
[2024/8/7 9:28:41 691] att=0x5 0x94 0x96 0x72 0xa 
[2024/8/7 9:28:41 691]  RCVS len:5
[2024/8/7 9:28:41 691] set basic_indicator_onoff:1 
[2024/8/7 9:28:41 707] [1970-01-01 00:00:32] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:41 707] [1970-01-01 00:00:32] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:41 723] XmBleReadBuf 5:
[2024/8/7 9:28:41 726] --- tracepoint bt_ext_porting.c,my_msg_rcv(33[atbm_log]:[ieee80211_csa_cancel][mon.eth2]:[0][0]
[2024/8/7 9:28:41 726] 9):  ---
[2024/8/7 9:28:41 726] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:41 739] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:41 739] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 13 rcount 13 offset 0 ---
[2024/8/7 9:28:41 739] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 13 ---
[2024/8/7 9:28:41 756] [01-01 18:12:37 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x6]
[2024/8/7 9:28:41 756] [01-01 18:12:37 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:41 771] [01-01 18:12:37 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:41 771] bt_rev_raw 5
[2024/8/7 9:28:41 771] 05 94 96 72 0a 
[2024/8/7 9:28:41 787] [01-01 18:12:37 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:6, pack_len:4, total_len:97
[2024/8/7 9:28:41 787] ble rev data 97
[2024/8/7 9:28:41 804] 02 01 b7 ae bb d4 8b 09 d3 d8 90 ad 5f 08 91 69 df 1e 9f c5 80 4b d1 77 b7 35 75 6c fc a4 54 ac 6e 46 05 e2 f3 7b 7d de 07 cf 5d 24 59 65 5f 10 69 4a 4b 38 a2 f4 66 1a ac aa cd 9e 7b fc b1 08 
[2024/8/7 9:28:41 804] db bd 13 b8 6b 77 3f 95 39 63 42 b7 b7 8f 9d 5d bb fa 91 f8 ee 75 9e ae a8 92 4f f3 1b 94 96 72 0a 
[2024/8/7 9:28:41 804] ble decryped data 80
[2024/8/7 9:28:41 820] 00 00 00 03 00 00 00 00 00 21 00 41 7b 22 70 77 64 22 3a 22 78 6d 35 31 32 35 32 30 22 2c 22 73 73 69 64 22 3a 22 58 69 61 6f 6d 69 5f 46 31 44 43 22 2c 22 74 6f 6b 65 6e 22 3a 22 41 59 55 57 
[2024/8/7 9:28:41 835] 33 62 57 6c 42 7a 32 74 71 35 22 7d 00 44 7d 00 
[2024/8/7 9:28:41 835] [01-01 18:12:37 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:41 835] [01-01 18:12:37 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x21 
[2024/8/7 9:28:41 852] [01-01 18:12:37 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:33 Has No def operate
[2024/8/7 9:28:41 852] [01-01 18:12:37 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:33
[2024/8/7 9:28:41 867] [01-01 18:12:37 TUYA N][bt_netcfg.c:63] Rev Net Cfg:{"pwd":"xm512520","ssid":"Xiaomi_F1DC","token":"AYUW3bWlBz2tq5"}
[2024/8/7 9:28:41 867] [01-01 18:12:37 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:41 883] [01-01 18:12:37 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x21 encrpyt:2
[2024/8/7 9:28:41 883] bt_ack_uncrypt 1
[2024/8/7 9:28:41 883] 00 
[2024/8/7 9:28:41 883] [01-01 18:12:37 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:41 899] [01-01 18:12:37 TUYA N][bt_netcfg.c:98] cfg ssid:Xiaomi_F1DC, passwd:xm512520, token:AYUW3bWlBz2tq5
[2024/8/7 9:28:41 915] [01-01 18:12:37 TUYA D][tuya_devos_netcfg.c:464] concurrent Netcfg Finish type:0x10004 ssid:Xiaomi_F1DC passwd:xm512520 cur_netcfg_type:0
[2024/8/7 9:28:41 915] [01-01 18:12:37 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:41 915] tuya_hal_bt_send 20
[2024/8/7 9:28:41 932] 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:28:41 932] [01-01 18:12:37 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:41 932] 0 21 32 2 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7 
[2024/8/7 9:28:41 948] XmBleSendBuf 20: 00 21 32 02 dd 6c 11 32 3d e2 b4 b4 59 cf ce 23 3d 27 df a7
[2024/8/7 9:28:41 948] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:41 948] ble_slave_gap_event->type=13
[2024/8/7 9:28:41 948] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:41 964] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:41 964] [01-01 18:12:37 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:41 980] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:13 ---
[2024/8/7 9:28:41 980] [1970-01-01 00:00:33] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:41 980] set basic_indicator_onoff:0 
[2024/8/7 9:28:41 996] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:41 996] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:42 011] 
[2024/8/7 9:28:42 012] [01-01 18:12:37 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:28:42 012] tuya_hal_bt_send 17
[2024/8/7 9:28:42 027] 01 fc 11 20 63 05 1f 36 cc 9a 74 4d 6b 58 85 21 1e 
[2024/8/7 9:28:42 027] [01-01 18:12:37 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:42 027] 1 fc 11 20 63 5 1f 36 cc 9a 74 4d 6b 58 85 21 1e 
[2024/8/7 9:28:42 043] XmBleSendBuf 17: 01 fc 11 20 63 05 1f 36 cc 9a 74 4d 6b 58 85 21 1e
[2024/8/7 9:28:42 043] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:42 043] ble_slave_gap_event->type=13
[2024/8/7 9:28:42 044] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:42 059] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:42 059] [01-01 18:12:37 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:42 060] [01-01 18:12:37 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:28:42 075] [01-01 18:12:37 TUYA E][wifi_netcfg_frame_transporter.c:431] timer is not run,wait
[2024/8/7 9:28:42 076] [01-01 18:12:37 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10002
[2024/8/7 9:28:42 091] [01-01 18:12:37 TUYA D][ap_netcfg.c:950] ap cfg stop:65538
[2024/8/7 9:28:42 091] [01-01 18:12:37 TUYA D][uni_thread.c:310] Del Thrd:udp_ap_v3
[2024/8/7 9:28:42 092] [1970-01-01 00:00:33] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:42 107] set basic_indicator_onoff:1 
[2024/8/7 9:28:42 107] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:42 123] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:42 123] [01-01 18:12:37 TUYA N][ap_netcfg.c:172] exit ap_net_cfg task
[2024/8/7 9:28:42 123] Received SIGTERM
[2024/8/7 9:28:42 139] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:28:42 140] set basic_indicator_onoff:0 
[2024/8/7 9:28:42 140] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:42 155] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:42 171] [1970-01-01 00:00:33] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:42 171] set basic_indicator_onoff:1 
[2024/8/7 9:28:42 171] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:42 188] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:42 188] [1970-01-01 00:00:33] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time33423
[2024/8/7 9:28:42 203] [01-01 18:12:37 TUYA D][ap_netcfg.c:553] wf_ap_stop:0
[2024/8/7 9:28:42 203] [01-01 18:12:37 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10100
[2024/8/7 9:28:42 219] [01-01 18:12:37 TUYA D][netcfg_module.c:437] netcfg module stop type:0x10004
[2024/8/7 9:28:42 219] [01-01 18:12:37 TUYA N][tuya_ble_api.c:439] update bound stat:1
[2024/8/7 9:28:42 219] [01-01 18:12:37 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:0
[2024/8/7 9:28:42 235] [01-01 18:12:37 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:28:42 235] [01-01 18:12:37 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:28:42 251] [01-01 18:12:37 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:42 251] [01-01 18:12:37 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:42 251] [01-01 18:12:37 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:42 267] [01-01 18:12:37 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:42 267] [01-01 18:12:37 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:28:42 267] [01-01 18:12:37 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:42 283] [01-01 18:12:37 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:42 283] [01-01 18:12:37 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:42 299] [01-01 18:12:37 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:42 299] [01-01 18:12:37 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:28:42 299] [01-01 18:12:37 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:28:42 315] [01-01 18:12:37 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:42 315] [01-01 18:12:37 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:42 315] [01-01 18:12:37 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:42 331] [01-01 18:12:37 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:28:42 331] [01-01 18:12:37 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:28:42 347] [01-01 18:12:37 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:28:42 347] [01-01 18:12:37 TUYA N][tuya_devos_activate.c:774] already inited
[2024/8/7 9:28:42 347] curr event:5 
[2024/8/7 9:28:42 363] IPC_APP_Notify_LED_Sound_Status_CB line(491) -------------------------- IPC_CONNECTING_WIFI(5)
[2024/8/7 9:28:42 363] [1970-01-01 00:00:33] tuya_ipc_system_control_demo.c(492) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONNECTING, 0, 0, 0, 1))
[2024/8/7 9:28:42 379] [1970-01-01 00:[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:28:42 379] 00:33] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/RouterConnect_english.pcm]
[2024/8/7 9:28:42 395] [1970-01-01 00:00:33] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:28:42 443] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:28:42 443] [01-01 18:12:37 TUYA D][uni_thread.c:268] Thread:udp_ap_v3 Exec Finish. Set to Del Stat
[2024/8/7 9:28:42 459] [01-01 18:12:37 TUYA D][uni_thread.c:125] del list not empty...deleting 0x157d114, next 0x1542dc8
[2024/8/7 9:28:42 459] [01-01 18:12:37 TUYA D][uni_thread.c:132] Final Free Thread:udp_ap_v3, is_self:1
[2024/8/7 9:28:42 476] [01-01 18:12:37 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:28:42 476] [01-01 18:12:37 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:28:42 491] [01-01 18:12:37 TUYA I][bt_ext_porting.c:618] [TUYA-BTUART]ble_monitor_thread exit
[2024/8/7 9:28:42 491] set basic_indicator_onoff:0 
[2024/8/7 9:28:42 491] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:42 507] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:42 508] --- tracepoint MainApp.c,ConfigTimer(399): g_WifiConectStatuts 1 ---
[2024/8/7 9:28:42 524] [1970-01-01 00:00:33] MainApp.c(403) <ConfigTimer>: ConfigTimer exit ----
[2024/8/7 9:28:42 524] [1970-01-01 00:00:33] xm_wifi.c(611) <XM_ParseQrcode>: XM_ParseQrcode Parse  QRcode once frame sucess width 640 height 360 data[]
[2024/8/7 9:28:42 539] set basic_indicator_onoff:1 
[2024/8/7 9:28:42 539] [1970-01-01 00:00:33] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:42 555] [1970-01-01 00:00:33] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:42 555] [01-01 18:12:38 TUYA D][tuya_ble_api.c:1376] nw stat change:1->1, rpt to app.
[2024/8/7 9:28:42 571] [01-01 18:12:38 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:1
[2024/8/7 9:28:42 571] [01-01 18:12:38 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:42 571] [01-01 18:12:38 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:28:42 571] bt_ack_uncrypt 1
[2024/8/7 9:28:42 572] 01 
[2024/8/7 9:28:42 587] [01-01 18:12:38 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:42 747] [atbm_log]:[eth2] change to [2]
[2024/8/7 9:28:42 747] [atbm_log]:[eth2] has been disabled
[2024/8/7 9:28:42 987] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:28:42 987] Mode(Product):0
[2024/8/7 9:28:42 987] BpuMode:[Online]
[2024/8/7 9:28:42 987] VpssMode:[Online]
[2024/8/7 9:28:43 003] [0.LimitUp_info]:
[2024/8/7 9:28:43 003] LimitUp:[Disable]
[2024/8/7 9:28:43 003] [2680*0]->[3840*0])
[2024/8/7 9:28:43 003] chn	TotalSize	ActiveSize
[2024/8/7 9:28:43 003] 0	5040*2246	2680*2160
[2024/8/7 9:28:43 003] 0	5040*2246	3840*2160
[2024/8/7 9:28:43 003] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:28:43 019] [1.VICU_info]:
[2024/8/7 9:28:43 023] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:28:43 023] 0	25.0	670	0	0	183	linear	8ddb00
[2024/8/7 9:28:43 023] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:28:43 023] en	op_type	m_chn	now
[2024/8/7 9:28:43 023] 0	1	1	1
[2024/8/7 9:28:43 023] [2.VI_info]:
[2024/8/7 9:28:43 035] chn	TotalSize	ActiveSize
[2024/8/7 9:28:43 035] 0	5040*2246	3848*2166
[2024/8/7 9:28:43 035] 1	   0*   0	   0*   0
[2024/8/7 9:28:43 035] [3.MIPI_info]:
[2024/8/7 9:28:43 035] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:28:43 052] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:28:43 052] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:28:43 052] [4.Cut_info]:
[2024/8/7 9:28:43 052] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:28:43 052] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:28:43 067] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:28:43 067] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:28:43 067] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:28:43 067] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:28:43 067] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:28:43 067] [5.IB(isp buffer info)]:
[2024/8/7 9:28:43 084] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:28:43 084] PoolId  Count  Size
[2024/8/7 9:28:43 084] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:43 100] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:43 100] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:43 115] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:43 115] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:43 116] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:43 131] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:28:43 131] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:28:43 131] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:28:43 147] 0       0         0          1          4       
[2024/8/7 9:28:43 147] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:28:43 147]      --265--            --264--                                               
[2024/8/7 9:28:43 163] Count      Line     Count      Line     
[2024/8/7 9:28:43 163] 502        480      1210       560      
[2024/8/7 9:28:43 163] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:28:43 179] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:28:43 179] 0   3840   2160    H265  0      0        0           304       983039     1        	
[2024/8/7 9:28:43 195] 1   640    360     H265  0      0        0           190       35000      8200     	
[2024/8/7 9:28:43 195] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:28:43 211] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:28:43 211] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:28:43 227] 0   Y      304      0       0       15       0        304      304      409       71991         58904    115839   64628    11      
[2024/8/7 9:28:43 243] 1   Y      190      0       8       0        1        189      189      410       1992          1911     27184    2849     7       
[2024/8/7 9:28:43 259] 3   N      0        0       0       1        0        0        0        412       0             0        0        0        0       
[2024/8/7 9:28:43 275] set basic_indicator_onoff:0 
[2024/8/7 9:28:43 291] [1970-01-01 00:00:33] tuya_ipc_dp_ha[atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 ++++++++ 
[2024/8/7 9:28:43 291] ndler.c(262) <IPC_APP_se[atbm_log]:ieee80211_check_country_limit_scan_2_4G_chan : scan_n_channals = 14 --------- 
[2024/8/7 9:28:43 307] t_basic_indicato[atbm_log]:atbm_hw_scan:if_id(0)
[2024/8/7 9:28:43 307] r_onoff>: SwapFlag=false
[2024/8/7 9:28:43 307] atbm_log]:atbm_hw_scan:scan, delay suspend
[2024/8/7 9:28:43 307] 1;32m[1970-01-01 00:00:3[atbm_log]:scan start band(0),(14)
[2024/8/7 9:28:43 323] 3] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:43 323] set basic_indicator_onoff:1 
[2024/8/7 9:28:43 323] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 339] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:43 339] set basic_indicator_onoff:0 
[2024/8/7 9:28:43 355] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 355] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:43 355] set basic_indicator_onoff:1 
[2024/8/7 9:28:43 371] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 371] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:43 387] set basic_indicator_onoff:0 
[2024/8/7 9:28:43 387] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 403] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:43 403] set basic_indicator_onoff:1 
[2024/8/7 9:28:43 403] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 419] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:43 419] set basic_indicator_onoff:0 
[2024/8/7 9:28:43 435] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 435] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:43 435] set basic_indicator_onoff:1 
[2024/8/7 9:28:43 451] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 451] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:43 467] [1970-01-01 00:00:34] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:43 467] set basic_indicator_onoff:0 
[2024/8/7 9:28:43 483] [1970-01-01 00:00:34] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 483] [1970-01-01 00:00:34] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:43 499] [1970-01-01 00:00:35] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:43 499] set basic_indicator_onoff:1 
[2024/8/7 9:28:43 515] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 516] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:43 516] [1970-01-01 00:00:35] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:43 531] set basic_indicator_onoff:0 
[2024/8/7 9:28:43 532] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:43 548] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:43 548] g_AudioTipsList.size() enable: 0[01-01 18:12:39 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:28:44 667] [atbm_log]:hw_priv->scan.status 0
[2024/8/7 9:28:44 667] [atbm_log]:atbm_scan_work:end(0)
[2024/8/7 9:28:44 667] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:28:44 683] [atbm_log]:authen:(a4:a9:30:ce:5e:66),ssid(Xiaomi_F1DC)
[2024/8/7 9:28:44 683] [atbm_log]:authenticate[a4:a9:30:ce:5e:66]:[0][1]
[2024/8/7 9:28:44 683] [atbm_log]:eth2: authenticate with a4:a9:30:ce:5e:66 (try 1) (1)(0)
[2024/8/7 9:28:44 699] [atbm_log]:[STA] Join DTIM: 1, interval: 100
[2024/8/7 9:28:44 699] [atbm_log]:[TX]:authen, delay suspend
[2024/8/7 9:28:44 732] [atbm_log]:[eth2 Rx]:da:[ff:ff:ff:ff:ff:ff] sa:[92:88:d9:e0:36:6a] bssid:[a4:a9:30:ce:5e:66],PTK[  (null)],FLAGS[0],skb->len[162]
[2024/8/7 9:28:44 732] [atbm_log]:[RX] MIC failure. ENCRYPTION [0],da:[ff:ff:ff:ff:ff:ff] sa:[92:88:d9:e0:36:6a] bssid:[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:44 747] [atbm_log]:[RX]:need sw decrypted?
[2024/8/7 9:28:44 747] [atbm_log]:eth2: authenticated
[2024/8/7 9:28:44 763] [atbm_log]:work:flush sta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:44 763] [atbm_log]:sta has been insert(0)
[2024/8/7 9:28:44 763] [atbm_log]:wk->assoc.use_he 1 1++
[2024/8/7 9:28:44 763] [atbm_log]:flush sta(0):
[2024/8/7 9:28:44 779] [atbm_log]:eth2: associated
[2024/8/7 9:28:44 779] [atbm_log]:eth2:free authen bss ++
[2024/8/7 9:28:44 779] [atbm_log]:eth2:free authen bss --
[2024/8/7 9:28:44 779] [atbm_log]:is_wifi6_ap++
[2024/8/7 9:28:44 779] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:28:44 795] [atbm_log]:eth2  WMM AC=0 acm=0 aifs=2 cWmin=3 cWmax=7 txop=47 uapsd=0
[2024/8/7 9:28:44 811] [atbm_log]:eth2  WMM AC=1 acm=0 aifs=2 cWmin=7 cWmax=15 txop=94 uapsd=0
[2024/8/7 9:28:44 827] [atbm_log]:eth2  WMM AC=2 acm=0 aifs=3 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:28:44 827] [atbm_log]:eth2  WMM AC=3 acm=0 aifs=7 cWmin=15 cWmax=1023 txop=0 uapsd=0
[2024/8/7 9:28:44 827] [atbm_log]:dcm peer rx:2 sta tx depends
[2024/8/7 9:28:44 843] [atbm_log]:[a4:a9:30:ce:5e:66]:20M channel
[2024/8/7 9:28:44 843] [atbm_log]:atbm_bss_info_changed:chatype(1),channelNumber(3)
[2024/8/7 9:28:44 843] [atbm_log]:BssidColor[34]
[2024/8/7 9:28:44 859] [atbm_log]:[STA] color 34, he_support_flag: 53
[2024/8/7 9:28:44 859] [atbm_log]:==>connect wifi6 AP open AX, set BA WIN short
[2024/8/7 9:28:44 875] [atbm_log]:[eth2] Waiting Txq Ready[1]
[2024/8/7 9:28:44 955] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:28:44 971] [atbm_log]:[eth2]:dtim changed [0]->[1]
[2024/8/7 9:28:44 971] [atbm_log]:[eth2]:[8e88] deliver slow
[2024/8/7 9:28:44 971] NOHZ: local_softirq_pending 08
[2024/8/7 9:28:44 987] [atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:28:44 987] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:28:45 003] [atbm_log]:send htc qos null
[2024/8/7 9:28:45 003] [atbm_log]:om work(1)
[2024/8/7 9:28:45 227] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 242] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c([atbm_log]:QosNUll Htc(807)
[2024/8/7 9:28:45 242] 262) <IPC_APP_se[atbm_log]:send htc qos null
[2024/8/7 9:28:45 243] t_basic_indicato[atbm_log]:om work(2)
[2024/8/7 9:28:45 243] r_onoff>: SwapFlag=false
[2024/8/7 9:28:45 259] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 259] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 276] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 276] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:45 276] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 290] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 290] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 306] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 306] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 322] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:45 322] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 322] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 339] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 339] [1970-01-01 00:00:35] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:28:45 355] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:28:45 355] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 371] [1970-01-01 00:00:35] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 371] [1970-01-01 00:00:35] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:45 371] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 387] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 387] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 403] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 403] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 419] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:45 419] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 419] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 435] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 435] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 451] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 451] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:45 451] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 467] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 467] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 483] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 483] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 499] [1970-01-01 00:00:[atbm_log]:QosNUll Htc(807)
[2024/8/7 9:28:45 499] 36] ==> XMSDK_Gp[atbm_log]:send htc qos null
[2024/8/7 9:28:45 499] ioWrite(31)[INFO[atbm_log]:om work(3)
[2024/8/7 9:28:45 499] ]: port=[12],val[atbm_log]:Open BA session requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:28:45 499] =[0]
[2024/8/7 9:28:45 515] 
[2024/8/7 9:28:45 516] s[atbm_log]:aggtx stop queue
[2024/8/7 9:28:45 516] et basic_indicat[atbm_log]:add to pending(2)(20)
[2024/8/7 9:28:45 516] or_onoff:1 
[2024/8/7 9:28:45 516] atbm_log]:dhcp work(1)
[2024/8/7 9:28:45 531] 32m[1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 531] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 531] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 546] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 547] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:45 563] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 563] [1970-01-01 00:00:36] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 579] [1970-01-01 00:00:36] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 579] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 579] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 595] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:45 595] [1970-01-01 00:00:37] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:45 611] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 611] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 627] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: po[atbm_log]:AMPDU[eth2]:action[2],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:45 627] [atbm_log]:activated addBA response timer on tid 0
[2024/8/7 9:28:45 643] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:28:45 643] [1970-01-01 00:00:37] xm_mai[atbm_log]:aggtx wake queue
[2024/8/7 9:28:45 643] n.c(1502) <XM_OnVideoDat[atbm_log]:sta_hdr
[2024/8/7 9:28:45 659] a_CB>: Capture the i frame time3[atbm_log]:switched off addBA timer for tid 0
[2024/8/7 9:28:45 659] 7316
[2024/8/7 9:28:45 659] set ba[atbm_log]:Aggregation is on for tid 0
[2024/8/7 9:28:45 675] sic_indicator_on[atbm_log]:AMPDU[eth2]:action[4],tid[0],ssn[0],buff_size[64],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:45 675] off:0 
[2024/8/7 9:28:45 675] [1[atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[6]
[2024/8/7 9:28:45 691] 970-01-01 00:00:[atbm_log]:AMPDU[eth2]:action[0],tid[6],ssn[1],buff_size[64],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:45 691] 37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 707] [1970-01-01 00:00[atbm_log]:Rx A-MPDU request on tid 6 result 0
[2024/8/7 9:28:45 707] :37] ==> XMSDK_G[atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[0]
[2024/8/7 9:28:45 723] pioWrite(31)[INF[atbm_log]:AMPDU[eth2]:action[0],tid[0],ssn[0],buff_size[64],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:45 723] O]: port=[12],val=[0]
[2024/8/7 9:28:45 723] [atbm_log]:Rx A-MPDU request on tid 0 result 0
[2024/8/7 9:28:45 723] set basic_indicator_onoff:1 
[2024/8/7 9:28:45 739] [197[atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:28:45 739] 0-01-01 00:00:37[atbm_log]:dhcp done] tuya_ipc_dp_handler.c(262) <IPC_APP_se
[2024/8/7 9:28:45 739] [atbm_log]:QosNUll Htc(807)
[2024/8/7 9:28:45 739] t_basic_indicato[atbm_log]:send htc qos null
[2024/8/7 9:28:45 755] r_onoff>: SwapFl[atbm_log]:om work(4)
[2024/8/7 9:28:45 755] ag=false
[2024/8/7 9:28:45 755] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:45 755] set basic_indicator_onoff:0 
[2024/8/7 9:28:45 771] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:45 771] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:45 787] [01-01 18:12:41 TUYA E][app_agent.c:823] sendto Fail: len:204 ret:-1,errno:-18 port:6667
[2024/8/7 9:28:45 803] [atbm_log]:dhcp work(1)
[2024/8/7 9:28:45 819] [atbm_log]:[eth2]:[8] deliver slow
[2024/8/7 9:28:45 819] [atbm_log]:dhcp doneNOHZ: local_softirq_pending 08
[2024/8/7 9:28:45 931] route: SIOCDELRT: No such process
[2024/8/7 9:28:45 947] [atbm_log]:connecting done for waitting dhcp  
[2024/8/7 9:28:46 027] 
[2024/8/7 9:28:46 028] [atbm_log]:om done
[2024/8/7 9:28:46 395] set basic_indicator_onoff:1 
[2024/8/7 9:28:46 395] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:46 411] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:46 411] set basic_indicator_onoff:0 
[2024/8/7 9:28:46 411] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:46 427] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:46 427] set basic_indicator_onoff:1 
[2024/8/7 9:28:46 443] [1970-01-01 00:00:37] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:46 443] [1970-01-01 00:00:37] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:46 443] set basic_indicator_onoff:0 
[2024/8/7 9:28:46 459] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:46 459] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:46 475] [1970-01-01 00:00:38] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:46 475] set basic_indicator_onoff:1 
[2024/8/7 9:28:46 491] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:46 491] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:46 491] set basic_indicator_onoff:0 
[2024/8/7 9:28:46 507] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:46 523] [1970-01-01 00:00:38] ==> XMS[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:46 523] DK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:46 524] 
[2024/8/7 9:28:46 524] curr event:6 
[2024/8/7 9:28:46 539] IPC_APP_Notify_LED_Sound_Status_CB line(497) ---------------[atbm_log]:ieee80211_process_addba_request:mac[a4:a9:30:ce:5e:66],tid[5]
[2024/8/7 9:28:46 539] ----------- IPC_[atbm_log]:<WIFI> rx ampdu ++ 
[2024/8/7 9:28:46 539] CONNECT_WIFI_SUC[atbm_log]:AMPDU[eth2]:action[0],tid[5],ssn[3],buff_size[64],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:46 555] CESS(6)
[2024/8/7 9:28:46 556] [1[atbm_log]:napi schedule
[2024/8/7 9:28:46 571] 970-01-01 00:00:38] tuya_ipc_system_control_demo.c(498) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion fa[atbm_log]:Rx A-MPDU request on tid 5 result 0
[2024/8/7 9:28:46 571] ilure (!XM_AudioTips(CONNECT_SUCCESS, 0, 0, 0, 1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:46 571] ))
[2024/8/7 9:28:46 587] [01-01 18:12:42 TUYA D][tuya_devos_netlink.c:313] wf connect success!
[2024/8/7 9:28:46 587] [01-01 18:12:42 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:6  -->>
[2024/8/7 9:28:46 603] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:28:46 603] [01-01 18:12:42 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:6  <<--
[2024/8/7 9:28:46 603] [01-01 18:12:42 TUYA E][mqtt_client.c:807] hand null.
[2024/8/7 9:28:46 603] set basic_indicator_onoff:1 
[2024/8/7 9:28:46 619] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:46 635] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:46 635] [01-01 18:12:42 TUYA D][tuya_iot_wired_wifi_api.c:584] wired wifi default stat:1,change:1
[2024/8/7 9:28:46 651] [01-01 18:12:42 TUYA D][tuya_iot_wired_wifi_api.c:590] wired wifi netstat changed to:wired  -->>
[2024/8/7 9:28:46 651] [01-01 18:12:42 TUYA D][tuya_iot_wired_wifi_api.c:592] wired wifi netstat changed to:wifi  <<--
[2024/8/7 9:28:46 667] [01-01 18:12:42 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:28:46 667] dev id key: 16
[2024/8/7 9:28:46 667] c0 b9 30 cc 91 82 20 e0 27 d3 45 b3 ab 3c 27 bf 
[2024/8/7 9:28:46 667] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:28:46 683] [01-01 18:12:42 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:28:46 683] 2 1 6 3 2 1 a2 14 16 1 a2 0 1c 6a 97 74 ce 42 f4 54 8c 72 2e 92 d 9f a1 db 
[2024/8/7 9:28:46 683] [01-01 18:12:42 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:28:46 699] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 35 30 7b 27 8c c6 8b 14 13 8e 36 f6 75 73 7d 4b 
[2024/8/7 9:28:46 699] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:28:46 715] [01-01 18:12:42 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:28:46 715] [01-01 18:12:42 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:28:46 731] [01-01 18:12:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:46 731] tuya_hal_bt_send 20
[2024/8/7 9:28:46 731] 00 21 33 05 f9 96 fc 1e e0 66 2c 0e 7b 8c ca 30 42 8f bc 9f 
[2024/8/7 9:28:46 747] [01-01 18:12:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:46 747] 0 21 33 5 f9 96 fc 1e e0 66 2c e 7b 8c ca 30 42 8f bc 9f 
[2024/8/7 9:28:46 747] XmBleSendBuf 20: 00 21 33 05 f9 96 fc 1e e0 66 2c 0e 7b 8c ca 30 42 8f bc 9f
[2024/8/7 9:28:46 763] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:46 763] ble_slave_gap_event->type=13
[2024/8/7 9:28:46 763] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:46 763] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:46 779] [01-01 18:12:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:46 779] [1970-01-01 00:00:38] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/ServerConnect_english.pcm]
[2024/8/7 9:28:46 795] [1970-01-01 00:00:38] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:28:46 795] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:28:46 811] 
[2024/8/7 9:28:46 812] [01-01 18:12:42 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:28:46 812] tuya_hal_bt_send 17
[2024/8/7 9:28:46 812] 01 de 65 26 42 11 6a 4b 47 f9 cb 66 9d 20 7c eb 04 
[2024/8/7 9:28:46 827] [01-01 18:12:42 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:46 827] 1 de 65 26 42 11 6a 4b 47 f9 cb 66 9d 20 7c eb 4 
[2024/8/7 9:28:46 843] XmBleSendBuf 17: 01 de 65 26 42 11 6a 4b 47 f9 cb 66 9d 20 7c eb 04
[2024/8/7 9:28:46 843] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:46 843] ble_slave_gap_event->type=13
[2024/8/7 9:28:46 843] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:46 843] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:46 859]  ---
[2024/8/7 9:28:46 859] [01-01 18:12:42 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:46 859] set basic_indicator_onoff:0 
[2024/8/7 9:28:46 875] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:46 875] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:46 890] [01-01 18:12:42 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:28:46 890] [01-01 18:12:42 TUYA D][tuya_devos_activate.c:516] dev_nw_cfg_active_stage:4
[2024/8/7 9:28:46 906] [01-01 18:12:42 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:46 906] [01-01 18:12:42 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:46 906] [01-01 18:12:42 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:46 923] [01-01 18:12:42 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:28:46 923] [01-01 18:12:42 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:46 923] [01-01 18:12:42 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:46 939] [01-01 18:12:42 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:46 939] [01-01 18:12:42 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:46 939] [01-01 18:12:42 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:46 955] [01-01 18:12:42 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:46 955] [01-01 18:12:42 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:28:46 971] [01-01 18:12:42 TUYA D][iot_httpc.c:1410] http_iot_dns_get_cloud_url start
[2024/8/7 9:28:46 971] [01-01 18:12:42 TUYA D][iot_httpc.c:1435] sign_buffer:env=2tq5&region=AY&ts=27&uuid=uuidcaab27b0a838d239
[2024/8/7 9:28:46 987] [01-01 18:12:42 TUYA D][iot_httpc.c:1443] sign_base64_encode:f3gx4p+GonV+3zF9dF+i7aUddK/lqJNmKepLOelzySg=
[2024/8/7 9:28:46 987] [01-01 18:12:42 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:28:47 019] [01-01 18:12:42 TUYA D][iot_httpc.c:1514] http_dns send: {"region":"AY","env":"2tq5","uuid":"uuidcaab27b0a838d239","ts":27,"sign":"f3gx4p+GonV+3zF9dF+i7aUddK/lqJNmKepLOelzySg=","config":[{"key":"httpUrl","need_ca":false},{"key":"mqttUrl","need_ca":false},{"key":"httpsSelfUrl","need_ca":true},{"key":"mqttsSelfUrl","need_ca":true},{"key":"ghostUrl","need_ca":true}]}
[2024/8/7 9:28:47 035] [01-01 18:12:42 TUYA D][iot_httpc.c:1519] get url config:https://h2.iot-dns.com/v2/url_config
[2024/8/7 9:28:47 035] [01-01 18:12:42 TUYA D][httpc.c:813] Connect: h2.iot-dns.com Port: 443  -->>
[2024/8/7 9:28:47 051] [01-01 18:12:42 TUYA D][uni_network.c:314] unw_gethostbyname h2.iot-dns.com, prio 0
[2024/8/7 9:28:47 051] [01-01 18:12:42 TUYA D][uni_network.c:167] use static dns ip 42.192.31.222 for domain h2.iot-dns.com
[2024/8/7 9:28:47 066] [01-01 18:12:42 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,222
[2024/8/7 9:28:47 066] [01-01 18:12:42 TUYA D][httpc.c:815] Connect: h2.iot-dns.com Port: 443  --<< ,r:0
[2024/8/7 9:28:47 082] [01-01 18:12:42 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:47 083] [01-01 18:12:42 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect h2.iot-dns.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:47 098] [01-01 18:12:42 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:47 098] [01-01 18:12:42 TUYA D][tuya_iot_com_api.c:271] tuya iot dns
[2024/8/7 9:28:47 098] [1970-01-01 00:00:38] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:47 115] [01-01 18:12:42 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:47 115] set basic_indicator_onoff:1 
[2024/8/7 9:28:47 132] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:47 132] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:47 132] set basic_indicator_onoff:0 
[2024/8/7 9:28:47 148] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:47 148] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:47 163] set basic_indicator_onoff:1 
[2024/8/7 9:28:47 163] [1970-01-01 00:00:38] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:47 179] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:47 179] [01-01 18:12:43 TUYA D][tuya_tls.c:1539] handshake finish for h2.iot-dns.com. set send/recv to user set
[2024/8/7 9:28:47 196] [01-01 18:12:4[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:47 196] 3 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect h2.iot-dns.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:47 196] set basic_indicator_onoff:0 
[2024/8/7 9:28:47 211] [1970-01-01 00:00:38] tuya_ipc_dp_handle[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:47 211] r.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:47 227] [1970-01-01 00:00:38] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:47 227] [01-01 18:12:43 TUYA D][iot_httpc.c:683] return chunked:0
[2024/8/7 9:28:47 242] [01-01 18:12:43 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:47 242] [01-01 18:12:43 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:47 243] [01-01 18:12:43 TUYA D][iot_httpc.c:1578] httpUrl:[http://a.tuyacn.com/d.json][42.192.25.216]
[2024/8/7 9:28:47 258] [01-01 18:12:43 TUYA D][iot_httpc.c:1579] mqttUrl:[m2.tuyacn.com:1883][42.192.30.165]
[2024/8/7 9:28:47 274] [01-01 18:12:43 TUYA D][iot_httpc.c:1602] httpsSelfUrl:[https://a2.tuyacn.com/d.json][42.192.31.36]
[2024/8/7 9:28:47 275] [01-01 18:12:43 TUYA D][iot_httpc.c:1603] mqttsSelfUrl:[m2.tuyacn.com:8883][42.192.30.165]
[2024/8/7 9:28:47 275] [01-01 18:12:43 TUYA D][iot_httpc.c:1670] ghostUrl:[baal.tuyacn.com:443][42.192.35.108]
[2024/8/7 9:28:47 291] [01-01 18:12:43 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:28:47 291] [01-01 18:12:43 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:47 307] [01-01 18:12:43 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:28:47 307] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.ca isFuzzy:1
[2024/8/7 9:28:47 323] [01-01 18:12:43 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:28:47 323] [01-01 18:12:43 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:28:47 323] [01-01 18:12:43 TUYA D][iot_httpc.c:1684] tls_ca_name:tls_ca0
[2024/8/7 9:28:47 339] [01-01 18:12:43 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:28:47 339] [01-01 18:12:43 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:47 355] [01-01 18:12:43 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:47 356] [01-01 18:12:43 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:47 356] [01-01 18:12:43 TUYA D][simplekv.c:374] write key:tls_ca0 And Value Len:2688
[2024/8/7 9:28:47 371] [01-01 18:12:43 TUYA D][simplekv.c:457] new space 8 startpos:30428 size:2756
[2024/8/7 9:28:47 371] [01-01 18:12:43 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:47 387] [01-01 18:12:43 TUYA D][simplekv.c:203] update crc 1395591596
[2024/8/7 9:28:47 387] [01-01 18:12:43 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:47 387] [01-01 18:12:43 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:47 403] [01-01 18:12:43 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:47 403] [01-01 18:12:43 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:47 403] [01-01 18:12:43 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:47 419] [01-01 18:12:43 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:47 419] [01-01 18:12:43 TUYA D][simplekv.c:374] write key:tls_ca_cnt And Value Len:16
[2024/8/7 9:28:47 435] [01-01 18:12:43 TUYA D][simplekv.c:457] new space 9 startpos:33184 size:84
[2024/8/7 9:28:47 435] [01-01 18:12:43 T[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:47 435] UYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:47 451] [01-01 18:12:43 TUYA D][simplekv.c:203] update crc 213719394
[2024/8/7 9:28:47 451] [01-01 18:12:43 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:47 451] [01-01 18:12:43 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:47 467] [01-01 18:12:43 TUYA D][uni_network.c:417] set_dns_region:1
[2024/8/7 9:28:47 467] [01-01 18:12:43 TUYA D][uni_network.c:268] cache dns [http://a.tuyacn.com/d.json]<->[42.192.25.216]
[2024/8/7 9:28:47 483] [01-01 18:12:43 TUYA D][uni_network.c:268] cache dns [https://a2.tuyacn.com/d.json]<->[42.192.31.36]
[2024/8/7 9:28:47 483] [01-01 18:12:43 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:1883]<->[42.192.30.165]
[2024/8/7 9:28:47 499] [01-01 18:12:43 TUYA D][uni_network.c:268] cache dns [m2.tuyacn.com:8883]<->[42.192.30.165]
[2024/8/7 9:28:47 499] [01-01 18:12:43 TUYA D][uni_network.c:268] cache dns [baal.tuyacn.com:443]<->[42.192.35.108]
[2024/8/7 9:28:47 515] [01-01 18:12:43 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:28:47 515] [01-01 18:12:43 TUYA D][simplekv.c:1251] find key:9 tls_ca_cnt
[2024/8/7 9:28:47 531] [01-01 18:12:43 TUYA D][simplekv.c:1280] key:tls_ca_cnt find value.Len:16
[2024/8/7 9:28:47 531] [01-01 18:12:43 TUYA D][tuya_tls.c:319] tls_ca_cnt:1 and parse:1
[2024/8/7 9:28:47 531] [01-01 18:12:43 TUYA D][simplekv.c:1211] read key:tls_ca0 isFuzzy:0 skipCnt:0
[2024/8/7 9:28:47 547] [01-01 18:12:43 TUYA D][simplekv.c:1251] find key:8 tls_ca0
[2024/8/7 9:28:47 547] [01-01 18:12:43 TUYA D][simplekv.c:1280] key:tls_ca0 find value[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:47 547] .Len:2688
[2024/8/7 9:28:47 563] [01-01 18:12:43 TUYA D][tuya_tls.c:349] Parse DER tls_ca0:2002 success
[2024/8/7 9:28:47 563] [01-01 18:12:43 TUYA D][iot_httpc.c:1696] end
[2024/8/7 9:28:47 563] [01-01 18:12:43 TUYA N][bt_dp.c:228] bt rpt conn stat:0
[2024/8/7 9:28:47 578] [01-01 18:12:43 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:47 578] [01-01 18:12:43 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:28:47 578] bt_ack_uncrypt 2
[2024/8/7 9:28:47 578] 00 00 
[2024/8/7 9:28:47 595] [01-01 18:12:43 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:47 595] [01-01 18:12:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:47 595] tuya_hal_bt_send 20
[2024/8/7 9:28:47 610] 00 21 34 02 08 6a 0c 35 2c b1 2a d1 3c ab c5 ef 54 55 53 83 
[2024/8/7 9:28:47 611] [01-01 18:12:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:47 626] 0 21 34 2 8 6a c 35 2c b1 2a d1 3c ab c5 ef 54 55 53 83 
[2024/8/7 9:28:47 626] XmBleSendBuf 20: 00 21 34 02 08 6a 0c 35 2c b1 2a d1 3c ab c5 ef 54 55 53 83
[2024/8/7 9:28:47 626] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:47 626] ble_slave_gap_event->type=13
[2024/8/7 9:28:47 642] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:47 642] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:47 642] [01-01 18:12:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:47 658] set basic_indicator_onoff:1 
[2024/8/7 9:28:47 659] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:47 677] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:47 677] [01-01 18:12:43 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:28:47 677] tuya_hal_bt_send 17
[2024/8/7 9:28:47 690] 01 d0 07 99 89 d1 94 e9 61 93 87 21 3b 65 27 ef 61 
[2024/8/7 9:28:47 690] [01-01 18:12:43 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:47 690] 1 d0 7 99 89 d1 94 e9 61 93 87 21 3b 65 27 ef 61 
[2024/8/7 9:28:47 706] XmBleSendBuf 17: 01 d0 07 99 89 d1 94 e9 61 93 87 21 3b 65 27 ef 61
[2024/8/7 9:28:47 706] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:47 706] ble_slave_gap_event->type=13
[2024/8/7 9:28:47 707] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:47 722] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:47 722] [01-01 18:12:43 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:47 738] [01-01 18:12:43 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:28:47 738] [01-01 18:12:43 TUYA D][tuya_devos_activate.c:356] dev_nw_cfg_active_stage:5
[2024/8/7 9:28:47 739] [01-01 18:12:43 TUYA D][iot_httpc.c:3195] modules:(null)
[2024/8/7 9:28:47 754] [01-01 18:12:43 TUYA D][simplekv.c:1211] read key:last_reset_info isFuzzy:0 skipCnt:0
[2024/8/7 9:28:47 754] [01-01 18:12:43 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:47 754] [01-01 18:12:43 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:47 770] [01-01 18:12:43 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:47 786] [01-01 18:12:43 TUYA D][iot_httpc.c:3198] options:{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}
[2024/8/7 9:28:47 786] set basic_indicator_onoff:0 
[2024/8/7 9:28:47 802] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:47 802] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:47 866] [01-01 18:12:43 TUYA D][iot_httpc.c:1161] Post Data: {"token":"UW3bWlBz","softVer":"1.5.431","productKey":"fvijo8jvloagv1gm","protocolVer":"2.2","baselineVer":"40.00","hid":"90314ba51650","skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}}","devAttribute":67,"cadVer":"1.0.4","cdVer":"1.0.0","options":"{\"isFK\":false,\"otaChannel\":0,\"sdkFullVer\":\"TuyaOS2.3.5_ty_ipc_wr_wl_linux_sdk_5.3.37-beta.586_arm-xm-linux_wifi_wire_ble_0.0.4-beta.1\"}","t":28}
[2024/8/7 9:28:47 882] [01-01 18:12:43 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.active&et=1&t=28&uuid=uuidcaab27b0a838d239&v=4.4&sign=36a2e05aeb3213c0e28a4b6efb79d5ca
[2024/8/7 9:28:47 882] [01-01 18:12:43 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:47 898] [01-01 18:12:43 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:47 898] [01-01 18:12:43 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:47 914] [01-01 18:12:43 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:47 914] [1970-01-01 00:00:39] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:47 914] [01-01 18:12:43 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:47 931] [01-01 18:12:43 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:47 947] [01-01 18:12:43 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:47 947] [01-01 18:12:43 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:47 947] [01-01 18:12:43 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:47 963] [01-01 18:12:43 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:47 963] [01-01 18:12:43 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:47 979] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:47 980]  ---
[2024/8/7 9:28:47 980] Len=20 step 0
[2024/8/7 9:28:47 980] att=0x0 0x21 0x20 0x2 0xa0 0xa 0xb0 0xb3 0xab 0x36 0xf7 0x64 0xca 0x58 0xe4 0x27 0x4a 0x5f 0x20 0x69 
[2024/8/7 9:28:47 980]  RCVS len:20
[2024/8/7 9:28:47 980] set basic_indicator_onoff:1 
[2024/8/7 9:28:47 995] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:47 995] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:48 011] 
[2024/8/7 9:28:48 012] XmBleReadBuf 20:
[2024/8/7 9:28:48 012] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:48 012] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:48 027] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:48 028] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:48 028] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:48 043] [01-01 18:12:43 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:48 043] [01-01 18:12:43 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:48 059] [01-01 18:12:43 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:48 059] bt_rev_raw 20
[2024/8/7 9:28:48 059] 00 21 20 02 a0 0a b0 b3 ab 36 f7 64 ca 58 e4 27 4a 5f 20 69 
[2024/8/7 9:28:48 075] [01-01 18:12:43 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:28:48 075] [01-01 18:12:43 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:48 091] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:48 091] set basic_indicator_onoff:0 
[2024/8/7 9:28:48 091] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 107] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:48 107] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:48 107] Len=17 step 0
[2024/8/7 9:28:48 123] att=0x1 0xc6 0x63 0xcd 0x4f 0xe2 0x6c 0xc1 0x9a 0xd1 0x49 0x33 0x50 0x83 0x8d 0x72 0x65 
[2024/8/7 9:28:48 123]  RCVS len:17
[2024/8/7 9:28:48 123] XmBleReadBuf 17:
[2024/8/7 9:28:48 123] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:48 123] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:48 139] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:48 139] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:28:48 154] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:28:48 155] [01-01 18:12:43 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:28:48 155] [01-01 18:12:43 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:48 171] [01-01 18:12:43 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:48 171] bt_rev_raw 17
[2024/8/7 9:28:48 171] 01 c6 63 cd 4f e2 6c c1 9a d1 49 33 50 83 8d 72 65 
[2024/8/7 9:28:48 187] [01-01 18:12:43 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:28:48 187] ble rev data 33
[2024/8/7 9:28:48 187] 02 a0 0a b0 b3 ab 36 f7 64 ca 58 e4 27 4a 5f 20 69 c6 63 cd 4f e2 6c c1 9a d1 49 33 50 83 8d 72 65 
[2024/8/7 9:28:48 202] ble decryped data 16
[2024/8/7 9:28:48 203] 00 00 00 04 00 00 00 00 00 22 00 01 00 d6 49 00 
[2024/8/7 9:28:48 203] [01-01 18:12:43 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:48 219] [01-01 18:12:43 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:28:48 219] [01-01 18:12:43 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:28:48 219] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:28:48 234] set basic_indicator_onoff:1 
[2024/8/7 9:28:48 234] [1970-01-01 00:00:39] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:48 250] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 250] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:48 251] 
[2024/8/7 9:28:48 251] set basic_indicator_onoff:0 
[2024/8/7 9:28:48 266] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 267] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:48 282] [01-01 18:12:43 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:48 298] [01-01 18:12:43 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:48 298] set basic_indicator_onoff:1 
[2024/8/7 9:28:48 314] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 314] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:48 315] 
[2024/8/7 9:28:48 315] set basic_indicator_onoff:0 
[2024/8/7 9:28:48 330] [1970-01-01 00:00:39] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 331] [1970-01-01 00:00:39] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:48 331] set basic_indicator_onoff:1 
[2024/8/7 9:28:48 346] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 347] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:48 362] 
[2024/8/7 9:28:48 363] set basic_indicator_onoff:0 
[2024/8/7 9:28:48 363] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 379] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:48 458] [01-01 18:12:44 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"capability":1,"devId":"6cd19cfd296e4b10a7ezkm","dstIntervals":[],"localKey":"80!QAjG}J256qEH*","resetFactory":false,"schema":"[{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":101,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":103,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":104,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":105,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"range\":[\"0\",\"1\",\"2\"],\"type\":\"enum\"},\"id\":106,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"type\":\"string\",\"maxlen\":255},\"id\":109,\"type\":\"obj\"},{\"mode\":\"ro\",\"property\":{\"min\":1,\"max\":5,\"scale\":0,\"step\":1,\"type\":\"value\"},\"id\":110,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":111,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\":{\"type\":\"bool\"},\"id\":113,\"type\":\"obj\"},{\"mode\":\"rw\",\"property\
[2024/8/7 9:28:48 474] [08-07 19:41:05 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:48 474] [08-07 19:41:05 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:48 490] [08-07 19:41:05 TUYA D][tuya_devos_activate.c:210] cloud_reset:0 local_reset:1
[2024/8/7 9:28:48 490] [08-07 19:41:05 TUYA D][tuya_devos_activate.c:256] __tmm_gw_actv_work: reset stride flag.
[2024/8/7 9:28:48 490] [08-07 19:41:05 TUYA D][tuya_devos_entry.c:1477] write stride to flash:0
[2024/8/7 9:28:48 506] [08-07 19:41:05 TUYA D][simplekv.c:1211] read key:is_stride isFuzzy:0 skipCnt:0
[2024/8/7 9:28:48 506] [08-07 19:41:05 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:48 522] [08-07 19:41:05 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:48 522] [08-07 19:41:05 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:48 522] [08-07 19:41:05 TUYA D][simplekv.c:374] write key:is_stride And Value Len:16
[2024/8/7 9:28:48 538] [08-07 19:41:05 TUYA D][simplekv.c:457] new space 10 startpos:33268 size:84
[2024/8/7 9:28:48 538] [08-07 19:41:05 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:48 554] [08-07 19:41:05 TUYA D][simplekv.c:203] update crc 1143988772
[2024/8/7 9:28:48 554] set basic_indicator_onoff:1 
[2024/8/7 9:28:48 554] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 570] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:48 570] [08-07 19:41:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:48 586] [08-07 19:41:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:48 586] [08-07 19:41:05 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:28:48 586] [08-07 19:41:05 TUYA D][simplekv.c:1251] find key:2 gw_di
[2024/8/7 9:28:48 602] [atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:48 602] [08-07 19:41:05 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[2024/8/7 9:28:48 619] [08-07 19:41:05 TUYA D][simplekv.c:374] write ke[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:48 619] y:gw_di And Value Len:416
[2024/8/7 9:28:48 619] [08-07 19:41:05 TUYA D][simplekv.c:397] 2 key same AND size old 468 >= new 416
[2024/8/7 9:28:48 635] [08-07 19:41:05 TUYA D][simplekv.c:430] find 2 available space
[2024/8/7 9:28:48 636] [08-07 19:41:05 TUYA D][simplekv.c:474] reuse available space 29188
[2024/8/7 9:28:48 636] [08-07 19:41:05 TUYA D][simplekv.c:203] update crc 2371956608
[2024/8/7 9:28:48 651] [08-07 19:41:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:48 651] [08-07 19:41:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:48 651] [08-07 19:41:05 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:28:48 667] [08-07 19:41:05 TUYA D][simplekv.c:1211] read key:flvlrc isFuzzy:0 skipCnt:0
[2024/8/7 9:28:48 667] [08-07 19:41:05 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:48 667] [08-07 19:41:05 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:48 682] [08-07 19:41:05 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:48 682] [08-07 19:41:05 TUYA D][simplekv.c:374] write key:flvlrc And Value Len:2928
[2024/8/7 9:28:48 698] [08-07 19:41:05 TUYA D][simplekv.c:457] new space 11 startpos:33352 size:2996
[2024/8/7 9:28:48 698] [08-07 19:41:05 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:48 698] [08-07 19:41:05 TUYA D][simplekv.c:203] update crc 2211972858
[2024/8/7 9:28:48 714] g_AudioTipsList.size() enable: 0[08-07 19:41:05 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:28:48 714] [08-07 19:41:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:48 730] [08-07 19:41:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:48 730] [08-07 19:41:05 TUYA D][ws_db_gw.c:670] schema write success
[2024/8/7 9:28:48 730] set basic_indicator_onoff:0 
[2024/8/7 9:28:48 746] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:48 746] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:48 762] [08-07 19:41:05 TUYA D][tuya_devos_utils.c:873] create dev_[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:48 762] cntl Success 
[2024/8/7 9:28:48 762] [08-07 1[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:48 778] 9:41:05 TUYA D][tuya_ipc_sdk_init.c:183] ON post active:0x1544f30
[2024/8/7 9:28:48 778] [08-07 19:41:05 TUYA D][tuya_ipc_sdk_init.c:172] skillResult p2pId:[]
[2024/8/7 9:28:48 794] [08-07 19:41:05 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:28:48 794] [08-07 19:41:05 TUYA D][simplekv.c:1251] find key:4 gw_ai
[2024/8/7 9:28:48 795] [08-07 19:41:05 TUYA D][simplekv.c:1280] key:gw_ai find value.Len:368
[2024/8/7 9:28:48 810] [08-07 19:41:05 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:544
[2024/8/7 9:28:48 810] [08-07 19:41:05 TUYA D][simplekv.c:394] 4 key same BUT size old 436 < new 544 need find new hd
[2024/8/7 9:28:48 826] [08-07 19:41:05 TUYA D][simplekv.c:457] new space 12 startpos:36348 size:612
[2024/8/7 9:28:48 827] [08-07 19:41:05 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:48 827] [08-07 19:41:05 TUYA D][simplekv.c:203] update crc 2831285816
[2024/8/7 9:28:48 842] [08-07 19:41:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:48 843] [08-07 19:41:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:48 843] [08-07 19:41:05 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:28:48 858] [08-07 19:41:05 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":9,"ssid":"WGlhb21p[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:48 874] X0YxREM=","passwd":"eG01MTI1MjA=","md":0,"random":0,"wfb64":1,"stat":2,"token":"UW3bWlBz","region":"AY",[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:48 874] "reg_key":"2tq5","dns_prio":0 }
[2024/8/7 9:28:48 890] [08-07 19:41:05 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:28:48 890] [08-07 19:41:05 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:28:48 890] [08-07 19:41:05 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:28:48 906] [08-07 19:41:05 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:176
[2024/8/7 9:28:48 906] [08-07 19:41:05 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 176
[2024/8/7 9:28:48 922] [08-07 19:41:05 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:28:48 922] [08-07 19:41:05 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:28:48 922] [08-07 19:41:05 TUYA D][simplekv.c:203] update crc 4280414176
[2024/8/7 9:28:48 939] [08-07 19:41:05 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:48 939] [08-07 19:41:05 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:48 939] [08-07 19:41:05 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:28:48 955] __IPC_APP_Get_Net_Status_cb line(188) -------------------------- stat(1)==STAT_UNPROVISION 
[2024/8/7 9:28:48 955] [08-07 19:41:05 TUYA D][wifi_netcfg_frame_transporter.c:472] ----destroy Transporter,session:0x1543ee8
[2024/8/7 9:28:48 970] [08-07 19:41:05 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:28:48 970] [08-07 19:41:05 TUYA N][bt_dp.c:228] bt rpt conn stat:9
[2024/8/7 9:28:48 986] [08-07 19:41:05 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:48 987] [08-07 19:41:05 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x22 encrpyt:2
[2024/8/7 9:28:48 987] bt_ack_uncrypt 2
[2024/8/7 9:28:48 987] 00 09 
[2024/8/7 9:28:48 987] [08-07 19:41:05 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:49 003] [08-07 19:41:05 TUYA D][tuya_devos_entry.c:560] dev_nw_cfg_active_stage:6
[2024/8/7 9:28:49 018] __IPC_APP_Get_Net_Status_cb line(198) -------------------[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:49 018] ------- stat(3)==STAT_AP_STA_DISC 
[2024/8/7 9:28:49 018] [08-07 19:41:05 TUYA D][tuya_ble_api.c:1005] start to get mesh
[2024/8/7 9:28:49 018] [08-07 19:41:05 TUYA N][tuya_bt_sdk.c:171] ty bt upd localkey
[2024/8/7 9:28:49 034] [08-07 19:41:05 TUYA N][tuya_ble_api.c:425] upd login key len:6
[2024/8/7 9:28:49 034] [08-07 19:41:05 TUYA I][mqc_app.c:387] mqc app start ...
[2024/8/7 9:28:49 051] [08-07 19:41:05 TUYA D][mqc_app.c:459] MQTT Protocol URL:m2.tuyacn.com:8883 Port:8883
[2024/8/7 9:28:49 051] [08-07 19:41:05 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994130}
[2024/8/7 9:28:49 051] [08-07 19:41:05 TUYA D][mqc_app.c:473] TLS disable
[2024/8/7 9:28:49 067] [08-07 19:41:05 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:28:49 083] [08-07 19:41:05 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.mesh.get&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994130&v=1.0&sign=19b13a0dddbc5687335c6a256912040e
[2024/8/7 9:28:49 099] [08-07 19:41:05 TUYA D][mqtt_client.c:321] subcribe_topic:smart/device/in/6cd19cfd296e4b10a7ezkm, client_id:6cd19cfd296e4b10a7ezkm, user_name:6cd19cfd296e4b10a7ezkm, passwd:954230206361f890
[2024/8/7 9:28:49 115] [08-07 19:41:05 TUYA D][mqtt_client.c:352] domain<0> m2.tuyacn.com:8883 HAVE PORT
[2024/8/7 9:28:49 115] [08-07 19:41:05 TUYA D][mqtt_client.c:355] PARSE m2.tuyacn.com:8883
[2024/8/7 9:28:49 131] [08-07 19:41:05 TUYA D][mqtt_client.c:383] wakeup_domain_tbl<0> m2.tuyacn.com:1883 HAVE PORT
[2024/8/7 9:28:49 131] [08-07 19:41:05 TUYA D][mqtt_client.c:386] PARSE m2.tuyacn.com:1883
[2024/8/7 9:28:49 131] [08-07 19:41:05 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:49 147] [08-07 19:41:05 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:49 147] [08-07 19:41:05 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:49 163] [08-07 19:41:05 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:49 163] [08-07 19:41:05 TUYA D][mqc_app.c:520] mqtt send topic:smart/device/out/6cd19cfd296e4b10a7ezkm
[2024/8/7 9:28:49 179] [08-07 19:41:05 TUYA D][mqc_app.c:522] mqtt-media send topic:d/m/o/6cd19cfd296e4b10a7ezkm
[2024/8/7 9:28:49 195] [08-07 19:41:05 TUYA I][uni_thread.c:228] thread_create name:mq_cntl_task,stackDepth:4096,totalstackDepth:25600,priority:4
[2024/8/7 9:28:49 196] [08-07 19:41:05 TUYA D][mqc_app.c:144] mq_pro:64 cnt:13
[2024/8/7 9:28:49 196] [08-07 19:41:05 TUYA D][mqc_app.c:144] mq_pro:22 cnt:14
[2024/8/7 9:28:49 196] [08-07 19:41:05 TUYA D][mqc_app.c:144] mq_pro:55 cnt:15
[2024/8/7 9:28:49 211] [08-07 19:41:05 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:28:49 211] [08-07 19:41:05 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:49 227] [08-07 19:41:05 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:49 227] [08-07 19:41:05 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:49 227] [08-07 19:41:05 TUYA D][tuya_svc_timer_task.c:146] no timer
[2024/8/7 9:28:49 242] [08-07 19:41:05 TUYA D][mqc_app.c:144] mq_pro:13 cnt:16
[2024/8/7 9:28:49 243] [08-07 19:41:05 TUYA D][mqc_app.c:144] mq_pro:15 cnt:17
[2024/8/7 9:28:49 243] [08-07 19:41:05 TUYA D][tuya_svc_upgrade.c:826] upgrade active success
[2024/8/7 9:28:49 259] [08-07 19:41:05 TUYA D][svc_online_log.c:217] mqtt log topic init log/realtime/6cd19cfd296e4b10a7ezkm
[2024/8/7 9:28:49 259] [08-07 19:41:05 TUYA D][svc_online_log.c:219] mqtt log topic init log/runstat/6cd19cfd296e4b10a7ezkm
[2024/8/7 9:28:49 275] [08-07 19:41:05 TUYA D][svc_online_log.c:317] svc online log active success
[2024/8/7 9:28:49 275] [08-07 09:28:50 TUYA D][tuya_ipc_sdk_init.c:137] sys stop timer: 14
[2024/8/7 9:28:49 291] [08-07 09:28:50 TUYA D][tuya_ipc_sdk_init.c:140] sys delete timer: 14
[2024/8/7 9:28:49 291] [08-07 09:28:50 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:49 291] tuya_hal_bt_send 20
[2024/8/7 9:28:49 306] 00 21 35 02 e5 85 68 e3 03 d5 41 83 f2 4e 7c 38 aa c2 4f 02 
[2024/8/7 9:28:49 307] [08-07 09:28:50 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:49 307] 0 21 35 2 e5 85 68 e3 3 d5 41 83 f2 4e 7c 38 aa c2 4f 2 
[2024/8/7 9:28:49 322] XmBleSendBuf 20: 00 21 35 02 e5 85 68 e3 03 d5 41 83 f2 4e 7c 38 aa c2 4f 02
[2024/8/7 9:28:49 322] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:49 322] ble_slave_gap_event->type=13
[2024/8/7 9:28:49 338] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:49 338] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:49 338] [08-07 09:28:50 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:49 354] [08-07 09:28:50 TUYA D][uni_thread.c:250] Thread:mq_cntl_task Exec Start. Set to Running Stat
[2024/8/7 9:28:49 354] [08-07 09:28:50 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:28:49 355] [08-07 09:28:50 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:28:49 370] [08-07 09:28:50 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:28:49 370] [08-07 09:28:50 TUYA D][tuya_ipc_p2p_common.c:530] p2p passwd change to adb2cdd2
[2024/8/7 9:28:49 386] [08-07 09:28:50 TUYA D][iot_httpc.c:1161] Post Data: {"password":"adb2cdd2","t":1722994130}
[2024/8/7 9:28:49 402] [08-07 09:28:50 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.password.update&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994130&v=1.0&sign=c4ee5f92e6fbcf53076aa0bc2591113e
[2024/8/7 9:28:49 402] [08-07 09:28:50 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:49 418] [08-07 09:28:50 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:49 418] [08-07 09:28:50 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:49 434] [08-07 09:28:50 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:49 435] [08-07 09:28:50 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:49 450] [08-07 09:28:50 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:49 450] [08-07 09:28:50 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:49 466] [08-07 09:28:50 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:49 466] [08-07 09:28:50 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:49 466] [08-07 09:28:50 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:49 482] [08-07 09:28:50 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:49 498] [08-07 09:28:50 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:28:49 498] tuya_hal_bt_send 17
[2024/8/7 9:28:49 498] 01 45 95 ab 25 64 60 71 fd 65 60 b5 ab 07 4c d4 dd 
[2024/8/7 9:28:49 498] [08-07 09:28:50 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:49 514] 1 45 95 ab 25 64 60 71 fd 65 60 b5 ab 7 4c d4 dd 
[2024/8/7 9:28:49 514] XmBleSendBuf 17: 01 45 95 ab 25 64 60 71 fd 65 60 b5 ab 07 4c d4 dd
[2024/8/7 9:28:49 514] GATT procedure initiated: notify; att_handle=23
[2024/8/7 9:28:49 515] ble_slave_gap_event->type=13
[2024/8/7 9:28:49 530] notification tx event; status=0 attr_handle=23 indication=0
[2024/8/7 9:28:49 530] ---[XmBleSendBuf][1342]: rc=0
[2024/8/7 9:28:49 530] [08-07 09:28:50 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:49 546] [08-07 09:28:50 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:49 547] [08-07 09:28:50 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:49 562] [08-07 09:28:50 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:49 562] [08-07 09:28:50 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:49 578] [08-07 09:28:50 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:49 578] [08-07 09:28:50 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:49 594] [08-07 09:28:50 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:49 594] [08-07 09:28:50 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:49 610] [08-07 09:28:50 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:49 626] [08-07 09:28:50 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:49 626] [08-07 09:28:50 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:49 644] set basic_indicator_onoff:1 
[2024/8/7 9:28:49 644] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:49 659] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:49 659] [08-07 09:28:50 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:28:49 675] [08-07 09:28:50 TUYA E][tuya_devos_netcfg.c:330] all netcfg stop fail:-1
[2024/8/7 9:28:49 675] [08-07 09:28:50 TUYA N][tuya_devos_netcfg.c:342] stop smt cfg mthd:0, ret:-1
[2024/8/7 9:28:49 675] [08-07 09:28:50 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:28:49 690] dev id key: 16
[2024/8/7 9:28:49 692] 82 a1 52 3f dd b2 6f 51 8f d7 f7 99 8d 0b dc 43 
[2024/8/7 9:28:49 692] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:28:49 706] [08-07 09:28:50 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:28:49 706] 2 1 6 3 2 1 a2 14 16 1 a2 0 90 51 8c 2a 2e 1b 93 5d c4 36 45 9b a6 54 40 eb 
[2024/8/7 9:28:49 707] [08-07 09:28:50 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:28:49 722] 3 9 54 59 19 ff d0 7 89 3 3 0 c 0 f0 96 7 1a 95 8a 13 7d a8 9d 80 17 6a a2 9b fd 
[2024/8/7 9:28:49 722] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(571): Don't_adv_Again!!!
[2024/8/7 9:28:49 739] [08-07 09:28:50 TUYA I][bt_ext_porting.c:572] [TUYA-BTUART]Don't_adv_Again!!!
[2024/8/7 9:28:49 739] [08-07 09:28:50 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:28:49 755] [08-07 09:28:50 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"appKey":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","networkKey":"D59774254FA876FF1D204D16DF5223A5"},"t":1722994131,"success":true}
[2024/8/7 9:28:49 755] [08-07 09:28:51 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:49 771] [08-07 09:28:51 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:49 787] [08-07 09:28:51 TUYA D][tuya_ble_api.c:1014] start to write flash, app_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66", network_key:"D59774254FA876FF1D204D16DF5223A5"
[2024/8/7 9:28:49 787] [08-07 09:28:51 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:49 787] [08-07 09:28:51 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:49 803] [08-07 09:28:51 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:49 803] [08-07 09:28:51 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:49 819] [08-07 09:28:51 TUYA D][simplekv.c:374] write key:ble_app_key And Value Len:48
[2024/8/7 9:28:49 819] [08-07 09:28:51 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 48
[2024/8/7 9:28:49 835] [08-07 09:28:51 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:28:49 835] [08-07 09:28:51 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:28:49 835] [08-07 09:28:51 TUYA D][simplekv.c:203] update crc 4225788489
[2024/8/7 9:28:49 850] [1970-01-01 00:00:40] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:49 851] [08-07 09:28:51 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:49 851] [08-07 09:28:51 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:49 867] [08-07 09:28:51 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:49 867] [08-07 09:28:51 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:49 883] [08-07 09:28:51 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:49 883] [08-07 09:28:51 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:49 883] [08-07 09:28:51 TUYA D][simplekv.c:374] write key:ble_network_key And Value Len:48
[2024/8/7 9:28:49 899] [08-07 09:28:51 TUYA D][simplekv.c:457] new space 13 startpos:36960 size:116
[2024/8/7 9:28:49 899] [08-07 09:28:51 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:49 914] [08-07 09:28:51 TUYA D][simplekv.c:203] update crc 3540047304
[2024/8/7 9:28:49 914] [08-07 09:28:51 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:49 914] [08-07 09:28:51 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:49 930] [08-07 09:28:51 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994131}
[2024/8/7 9:28:49 946] [08-07 09:28:51 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.beacon.key.fetch&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994131&v=1.0&sign=16f7dddcc8618cddd7c6d886f1cf041d
[2024/8/7 9:28:49 946] [08-07 09:28:51 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:49 962] [08-07 09:28:51 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:49 962] [08-07 09:28:51 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:49 978] [08-07 09:28:51 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:49 978] set basic_indicator_onoff:0 
[2024/8/7 9:28:49 978] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:49 994] [08-07 09:28:51 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994131,"success":true}
[2024/8/7 9:28:49 994] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:50 010] [08-07 09:28:51 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:50 010] [08-07 09:28:51 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:50 026] [08-07 09:28:51 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:50 026] [08-07 09:28:51 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:50 026] [08-07 09:28:51 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:28:50 042] [08-07 09:28:51 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:28:50 059] [08-07 09:28:51 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:50 062] [08-07 09:28:51 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:28:50 062] [08-07 09:28:51 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:50 078] [08-07 09:28:51 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:28:50 078] [08-07 09:28:51 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:28:50 078] [08-07 09:28:51 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:28:50 091] [08-07 09:28:51 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:50 091] [08-07 09:28:51 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:50 107] [08-07 09:28:51 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:28:50 107] [08-07 09:28:51 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:50 107] [08-07 09:28:51 TUYA D][simplekv.c:203] update crc 2271235724
[2024/8/7 9:28:50 123] [08-07 09:28:51 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:50 123] [08-07 09:28:51 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:50 139] [08-07 09:28:51 TUYA D][tuya_devos_utils.c:341] set gw ext_stat:2
[2024/8/7 9:28:50 139] [08-07 09:28:51 TUYA D][uni_network.c:314] unw_gethostbyname m2.tuyacn.com, prio 0
[2024/8/7 9:28:50 155] [08-07 09:28:51 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.30.165 for domain m2.tuyacn.com
[2024/8/7 9:28:50 155] [08-07 09:28:51 TUYA D][mqtt_client.c:1472] select mqtt host:m2.tuyacn.com
[2024/8/7 9:28:50 155] [08-07 09:28:51 TUYA N][mqtt_client.c:1493] mqtt get serve ip success
[2024/8/7 9:28:50 171] [08-07 09:28:51 TUYA D][mqtt_client.c:989] serverIP 717233829 port:8883
[2024/8/7 9:28:50 171] [08-07 09:28:51 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:50 186] [08-07 09:28:51 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:50 187] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:50 202] Len=20 step 0
[2024/8/7 9:28:50 202] att=0x0 0x21 0x20 0x2 0xc5 0xe4 0xd3 0xc0 0xd9 0xfc 0x5a 0xd 0x7c 0xde 0x2d 0xad 0xae 0xa2 0x23 0xcd 
[2024/8/7 9:28:50 202]  RCVS len:20
[2024/8/7 9:28:50 218] [08-07 09:28:51 TUYA D][mqtt_client.c:1014] mqtt over TLS is enabled. Host:m2.tuyacn.com Port:8883
[2024/8/7 9:28:50 218] [08-07 09:28:51 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:50 234] [08-07 09:28:51 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect m2.tuyacn.com:8883  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:50 234] [08-07 09:28:51 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:50 250] [08-07 09:28:51 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:50 250] [08-07 09:28:51 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:50 266] [08-07 09:28:51 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:50 267] [1970-01-01 00:00:40] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:50 268] set basic_indicator_onoff:1 
[2024/8/7 9:28:50 268] XmBleReadBuf 20:
[2024/8/7 9:28:50 282] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:50 282] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:50 282] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:50 298] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 28 rcount 28 offset 0 ---
[2024/8/7 9:28:50 298] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 28 ---
[2024/8/7 9:28:50 314] [08-07 09:28:51 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x15]
[2024/8/7 9:28:50 314] [08-07 09:28:51 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:50 314] [08-07 09:28:51 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:50 314] bt_rev_raw 20
[2024/8/7 9:28:50 330] 00 21 20 02 c5 e4 d3 c0 d9 fc 5a 0d 7c de 2d ad ae a2 23 cd 
[2024/8/7 9:28:50 330] [08-07 09:28:51 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:1, no:1, pack_len:17, total_len:17
[2024/8/7 9:28:50 346] [08-07 09:28:51 TUYA D][tuya_ble_data_handler.c:566] ble data pkg is multi-pack, receive...
[2024/8/7 9:28:50 346] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:28 ---
[2024/8/7 9:28:50 362] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:50 362] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:50 378] [08-07 09:28:51 TUYA D][iot_httpc.c:601] Decode Rev:{"result":"FCEB3CECD67ED17D3E9BD5F0A2AF3D66","t":1722994131,"success":true}
[2024/8/7 9:28:50 378] [08-07 09:28:51 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:50 394] [08-07 09:28:51 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:50 394] [08-07 09:28:51 TUYA D][tuya_ble_api.c:986] start to write flash, beacon_key:"FCEB3CECD67ED17D3E9BD5F0A2AF3D66"
[2024/8/7 9:28:50 410] [08-07 09:28:51 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:28:50 410] [08-07 09:28:51 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:50 410] [08-07 09:28:51 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:50 426] [08-07 09:28:51 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:50 426] [08-07 09:28:51 TUYA D][simplekv.c:374] write key:ble_beaconkey And Value Len:48
[2024/8/7 9:28:50 442] [08-07 09:28:51 TUYA D][simplekv.c:457] new space 14 startpos:37076 size:116
[2024/8/7 9:28:50 442] [08-07 09:28:51 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:50 442] [08-07 09:28:51 TUYA D][simplekv.c:203] update crc 2903223966
[2024/8/7 9:28:50 458] [08-07 09:28:51 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:50 458] [08-07 09:28:51 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:50 474] [08-07 09:28:51 TUYA D][tuya_ble_api.c:1443] timer has started
[2024/8/7 9:28:50 474] ---[ble_svc_gatt_access][309]: uuid=[11025]
[2024/8/7 9:28:50 474] Len=17 step 0
[2024/8/7 9:28:50 474] att=0x1 0x28 0x3c 0xeb 0x97 0x7a 0xa1 0xc1 0xab 0xc5 0x94 0x53 0x86 0xc9 0x4e 0x4c 0xa9 
[2024/8/7 9:28:50 490]  RCVS len:17
[2024/8/7 9:28:50 490] [1970-01-01 00:00:40] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:50 490] XmBleReadBuf 17:
[2024/8/7 9:28:50 490] --- tracepoint bt_ext_porting.c,my_msg_rcv(339):  ---
[2024/8/7 9:28:50 507] --- tracepoint bt_ext_porting.c,my_msg_rcv(341):  ---
[2024/8/7 9:28:50 507] --- tracepoint bt_ext_porting.c,my_msg_rcv(353):  ---
[2024/8/7 9:28:50 507] --- tracepoint bt_ext_porting.c,ty_msg_proc(270): fr_len 25 rcount 25 offset 0 ---
[2024/8/7 9:28:50 523] --- tracepoint bt_ext_porting.c,ty_msg_proc(284): rcount 25 ---
[2024/8/7 9:28:50 523] [08-07 09:28:51 TUYA I][bt_ext_porting.c:224] [TUYA-BTUART]recv fr_head[0xaa55] fr_type[0xd] fr_len[0x12]
[2024/8/7 9:28:50 538] [08-07 09:28:51 TUYA D][tuya_ble_api.c:543] rev ble event 2
[2024/8/7 9:28:50 538] [08-07 09:28:51 TUYA D][tuya_ble_api.c:509] Dev Rev BT Package
[2024/8/7 9:28:50 538] bt_rev_raw 17
[2024/8/7 9:28:50 538] 01 28 3c eb 97 7a a1 c1 ab c5 94 53 86 c9 4e 4c a9 
[2024/8/7 9:28:50 555] [08-07 09:28:51 TUYA D][tuya_ble_data_handler.c:137] recive sub_pkg desc:3, no:2, pack_len:16, total_len:33
[2024/8/7 9:28:50 555] ble rev data 33
[2024/8/7 9:28:50 571] 02 c5 e4 d3 c0 d9 fc 5a 0d 7c de 2d ad ae a2 23 cd 28 3c eb 97 7a a1 c1 ab c5 94 53 86 c9 4e 4c a9 
[2024/8/7 9:28:50 571] ble decryped data 16
[2024/8/7 9:28:50 571] 00 00 00 05 00 00 00 00 00 22 00 01 00 13 18 00 
[2024/8/7 9:28:50 571] [08-07 09:28:51 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:50 587] [08-07 09:28:51 TUYA D][tuya_ble_data_handler.c:675] Parse BT Cmd:0x22 
[2024/8/7 9:28:50 587] [08-07 09:28:51 TUYA D][tuya_ble_data_handler.c:687] BT Cmd:34 Has No def operate
[2024/8/7 9:28:50 602] --- tracepoint bt_ext_porting.c,ty_msg_proc(302): offset is ....:25 ---
[2024/8/7 9:28:50 602] [08-07 09:28:51 TUYA D][tuya_bt_sdk.c:50] Rev BT user Data. type:34
[2024/8/7 9:28:50 603] set basic_indicator_onoff:0 
[2024/8/7 9:28:50 618] [1970-01-01 00:00:40] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:50 618] [1970-01-01 00:00:40] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:50 634] [1970-01-01 00:00:41] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:28:50 634] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:28:50 650] set basic_indicator_onoff:1 
[2024/8/7 9:28:50 650] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:50 666] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:50 666] [1970-01-01 00:00:41] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:50 666] set basic_indicator_onoff:0 
[2024/8/7 9:28:50 682] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:50 682] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:50 698] [1970-01-01 00:00:41] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time41282
[2024/8/7 9:28:50 698] set basic_indicator_onoff:1 
[2024/8/7 9:28:50 714] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:50 714] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:50 730] [08-07 09:28:51 TUYA D][tuya_tls.c:1539] handshake finish for m2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:50 747] [08-07 09:28:51 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect m2.tuyacn.com:8883  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:50 747] [08-07 09:28:51 TUYA N][mqtt_client.c:1531] mqtt create success, begin to connect
[2024/8/7 9:28:50 747] [08-07 09:28:51 TUYA D][mqc_app.c:308] TLS Mode:4
[2024/8/7 9:28:50 747] set basic_indicator_onoff:0 
[2024/8/7 9:28:50 763] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:50 763] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:50 779] 
[2024/8/7 9:28:50 781] [08-07 09:28:51 TUYA D][mqtt_client.c:1413] cnt 1
[2024/8/7 9:28:50 781] [08-07 09:28:51 TUYA D][mqtt_client.c:1104] mqtt subscribe success
[2024/8/7 9:28:50 795] [08-07 09:28:51 TUYA D][mqc_app.c:732] mqtt connect success
[2024/8/7 9:28:50 795] [08-07 09:28:51 TUYA D][tuya_ipc_moto_mqtt.c:69] book topic start
[2024/8/7 9:28:50 795] [08-07 09:28:51 TUYA D][mqtt_client.c:1994] subscribe new topic /av/d/6cd19cfd296e4b10a7ezkm ret:1 
[2024/8/7 9:28:50 811] [08-07 09:28:51 TUYA D][tuya_ipc_moto_mqtt.c:73] book topic done
[2024/8/7 9:28:50 811] __IPC_APP_Get_Net_Status_cb line(243) -------------------------- stat(11)==STAT_MQTT_ONLINE 
[2024/8/7 9:28:50 811] curr event:11 
[2024/8/7 9:28:50 827] IPC_APP_Notify_LED_Sound_Status_CB line(550) -------------------------- IPC_MQTT_ONLINE(11)
[2024/8/7 9:28:50 843] [1970-01-01 00:00:41] tuya_ipc_system_control_demo.c(551) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(DEVICE_ONLINE, 0, 0, 0, 1))
[2024/8/7 9:28:50 843] Disable Qrcode
[2024/8/7 9:28:50 859] [1970-01-01 00:00:41] tuya_ipc_system_control_demo.c(558) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(CONFIG_SUCCESS, 0, 0, 0, 1))
[2024/8/7 9:28:50 875] [1970-01-01 00:00:41] xm_musicPlayer.cpp(91) <PlayAudioTips>: Open audio file /usr/share/audios/_english.pcm failed, No such file or directory
[2024/8/7 9:28:50 875] [1970-01-01 00:00:41] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/AddSuccess_english.pcm]
[2024/8/7 9:28:50 891] [1970-01-01 00:00:41] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:28:50 891] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:28:50 907] mqtt subscribe ack 5
[2024/8/7 9:28:50 907] 90 03 00 02 00 
[2024/8/7 9:28:50 907] set basic_indicator_onoff:1 
[2024/8/7 9:28:50 907] [1970-01-01 00:00:41] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:50 922] [1970-01-01 00:00:41] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[1]
[2024/8/7 9:28:50 923] 
[2024/8/7 9:28:50 923] [08-07 09:28:52 TUYA D][MainApp.c:537] tuya_ipc_sdk_mqtt_online_proc is start run
[2024/8/7 9:28:50 939] [08-07 09:28:52 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722994132 28800
[2024/8/7 9:28:50 939] [08-07 09:28:52 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722994132 28800
[2024/8/7 9:28:50 939] Init tuya_ipc_ss_init
[2024/8/7 9:28:50 955] [08-07 09:28:52 TUYA D][tuya_ipc_stream_storage.c:2015] Init stream_storage.base_path:/mnt/mmc v:4 a:101, max event per day 289 skills 1
[2024/8/7 9:28:50 970] [08-07 09:28:52 TUYA D][tuya_ipc_stream_storage.c:1571] SD task begin___
[2024/8/7 9:28:50 971] [08-07 09:28:52 TUYA D][tuya_ipc_stream_storage.c:2161] stream storage task init success
[2024/8/7 9:28:50 971] [08-07 09:28:52 TUYA D][MainApp.c:567] local storage init result is 0
[2024/8/7 9:28:50 986] [08-07 09:28:52 TUYA D][tuya_ipc_stream_storage.c:1585] report sd status 0 -> 5
[2024/8/7 9:28:50 987] [08-07 09:28:52 TUYA E][tuya_ipc_stream_storage.c:1914] storage not inited
[2024/8/7 9:28:51 002] [08-07 09:28:52 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:28:51 002] [08-07 09:28:52 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:28:51 003] [08-07 09:28:52 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:7  -->>
[2024/8/7 9:28:51 018] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:28:51 019] [08-07 09:28:52 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:7  <<--
[2024/8/7 9:28:51 035] [08-07 09:28:52 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:2  -->>
[2024/8/7 9:28:51 035] __IPC_APP_Get_Net_Status_cb line(218) -------------------------- stat(7)== STAT_CLOUD_CONN
[2024/8/7 9:28:51 050] [08-07 09:28:52 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:2  <<--
[2024/8/7 9:28:51 051] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:28:51 066] [08-07 09:28:52 TUYA W][tuya_iot_wired_wifi_api.c:544] bnw_if_wired_connect_net 2 error.
[2024/8/7 9:28:51 082] [08-07 09:28:52 TUYA D][tuya_iot_wired_wifi_api.c:567] wifi ip: 192.168.31.144, inet_addr(wifi_ip.ip): 0xc0a81f90, mq_ip:0xc0a81f90.
[2024/8/7 9:28:51 082] [08-07 09:28:52 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:28:51 082] [08-07 09:28:52 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:51 098] [08-07 09:28:52 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:51 098] [08-07 09:28:52 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:51 098] [08-07 09:28:52 TUYA E][svc_online_log_db.c:25] ret:-6
[2024/8/7 9:28:51 114] [08-07 09:28:52 TUYA D][svc_online_log.c:182] load env fail. maybe not exist.
[2024/8/7 9:28:51 114] [08-07 09:28:52 TUYA D][svc_online_log.c:187] update property:{"value":"{\"embed_sys_env\":\"arm-xm-linux\"}"}
[2024/8/7 9:28:51 130] [08-07 09:28:52 TUYA D][iot_httpc.c:1161] Post Data: {"value":"{\"embed_sys_env\":\"arm-xm-linux\"}","t":1722994132}
[2024/8/7 9:28:51 147] [08-07 09:28:52 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.property.save&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994132&v=1.0&sign=bfbaaaf82b5595042b2c8cd939e7a5be
[2024/8/7 9:28:51 163] [08-07 09:28:52 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:51 163] [08-07 09:28:52 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:51 179] [08-07 09:28:52 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:51 179] [08-07 09:28:52 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:51 179] [08-07 09:28:52 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:51 195] [08-07 09:28:52 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:51 210] [08-07 09:28:52 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:51 210] [08-07 09:28:52 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:51 210] [08-07 09:28:52 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:51 226] [08-07 09:28:52 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:51 226] [08-07 09:28:52 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:51 242] [08-07 09:28:52 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:51 258] [08-07 09:28:52 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:51 258] [08-07 09:28:52 TUYA D][app_agent.c:706] udp ip: 192.168.31.144
[2024/8/7 9:28:51 258] [08-07 09:28:53 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994133,"success":true}
[2024/8/7 9:28:51 274] [08-07 09:28:53 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:51 274] [08-07 09:28:53 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:51 290] [08-07 09:28:53 TUYA D][simplekv.c:1211] read key:em_sys_env isFuzzy:0 skipCnt:0
[2024/8/7 9:28:51 290] [08-07 09:28:53 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:51 290] [08-07 09:28:53 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:51 306] [08-07 09:28:53 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:51 306] [08-07 09:28:53 TUYA D][simplekv.c:374] write key:em_sys_env And Value Len:32
[2024/8/7 9:28:51 322] [08-07 09:28:53 TUYA D][simplekv.c:457] new space 15 startpos:37192 size:100
[2024/8/7 9:28:51 322] [08-07 09:28:53 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:51 322] [08-07 09:28:53 TUYA D][simplekv.c:203] update crc 4002263943
[2024/8/7 9:28:51 338] [08-07 09:28:53 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:51 338] [08-07 09:28:53 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:51 338] [08-07 09:28:53 TUYA D][tuya_ble_api.c:1417] cloud connected, stop adv!
[2024/8/7 9:28:51 354] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(640): stop_adv ---
[2024/8/7 9:28:51 354] exit_ble_thread create suc
[2024/8/7 9:28:51 354] --- tracepoint bt_ext_porting.c,tuya_ext_bt_stop_adv(644): XmBleAdvStop ---
[2024/8/7 9:28:51 370] [08-07 09:28:53 TUYA D][tuya_ble_api.c:1376] nw stat change:1->2, rpt to app.
[2024/8/7 9:28:51 370] [08-07 09:28:53 TUYA D][tuya_ble_api.c:836] tuya_ble_send_dev_nw_stat:2
[2024/8/7 9:28:51 386] [08-07 09:28:53 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:51 386] [08-07 09:28:53 TUYA D][tuya_ble_api.c:785] tuya_ble_sdk_send. cmd:0x1e encrpyt:5
[2024/8/7 9:28:51 386] bt_ack_uncrypt 1
[2024/8/7 9:28:51 386] 02 
[2024/8/7 9:28:51 402] [08-07 09:28:53 TUYA D][tuya_ble_api.c:1470] ble get conn stat:3
[2024/8/7 9:28:51 402] [08-07 09:28:53 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:3, send_data:17
[2024/8/7 9:28:51 402] tuya_hal_bt_send 20
[2024/8/7 9:28:51 419] 00 21 36 05 fe c2 b1 a0 88 a0 95 be ba ba ba 86 12 02 c5 fc 
[2024/8/7 9:28:51 419] [08-07 09:28:53 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:51 419] 0 21 36 5 fe c2 b1 a0 88 a0 95 be ba ba ba 86 12 2 c5 fc 
[2024/8/7 9:28:51 435] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:51 435] [08-07 09:28:53 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:51 451] --- tracepoint bt_ext_porting.c,ty_btext_thread(433): tuya_hal_thread_release ---
[2024/8/7 9:28:51 451] [08-07 09:28:53 TUYA E][bt_ext_porting.c:434] [TUYA-BTUART]ty_btext_thread deleted
[2024/8/7 9:28:51 467] [1970-01-01 00:00:42] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:28:51 467] [08-07 09:28:53 TUYA D][tuya_ble_mutli_tsf_protocol.c:258] pkg max len:20, sunpkg_offset:1, send_data:16
[2024/8/7 9:28:51 467] tuya_hal_bt_send 17
[2024/8/7 9:28:51 483] 01 30 ff 02 5a 33 fc 9d 69 e4 95 03 78 00 2a a0 35 
[2024/8/7 9:28:51 483] [08-07 09:28:53 TUYA D][bt_ext_porting.c:450] [TUYA-BTUART]BT TX:
[2024/8/7 9:28:51 483] 1 30 ff 2 5a 33 fc 9d 69 e4 95 3 78 0 2a a0 35 
[2024/8/7 9:28:51 499] ---[XmBleSendBuf][1332]: already stop ble,could not call xmblesendbuf
[2024/8/7 9:28:51 499] [08-07 09:28:53 TUYA D][bt_ext_porting.c:456] [TUYA-BTUART]BT TX end
[2024/8/7 9:28:51 515] [08-07 09:28:53 TUYA D][tuya_ble_api.c:697] ble_send_data_to_app finish. len:33, send_ret:0x0
[2024/8/7 9:28:51 515] [08-07 09:28:53 TUYA D][app_agent.c:1459] new client connect. nums:1 cfd:33 ip:0xc0a81ff2
[2024/8/7 9:28:51 515] [08-07 09:28:53 TUYA D][app_agent.c:1540] fd:33, wk_stat = 2, type = 3
[2024/8/7 9:28:51 531] [08-07 09:28:53 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:28:51 531] [08-07 09:28:53 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:28:51 547] [08-07 09:28:53 TUYA D][app_agent.c:600] send length:64, id:33, sequence_out:59408
[2024/8/7 9:28:51 547] [08-07 09:28:53 TUYA D][app_agent.c:1540] fd:33, wk_stat = 2, type = 5
[2024/8/7 9:28:51 547] [08-07 09:28:53 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:28:51 563] [08-07 09:28:53 TUYA D][app_agent.c:961] local_key
[2024/8/7 9:28:51 563] [08-07 09:28:53 TUYA D][app_agent.c:1540] fd:33, wk_stat = 2, type = 16
[2024/8/7 9:28:51 563] [08-07 09:28:53 TUYA D][app_agent.c:952] lan version over 3.4
[2024/8/7 9:28:51 578] [08-07 09:28:53 TUYA D][app_agent.c:958] session_key
[2024/8/7 9:28:51 578] [08-07 09:28:53 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:0,dpnum:41.
[2024/8/7 9:28:51 578] [08-07 09:28:53 TUYA D][smart_frame.c:2517] Nothing To Pack
[2024/8/7 9:28:51 594] [08-07 09:28:53 TUYA D][app_agent.c:1234] nothing to report
[2024/8/7 9:28:51 594] [08-07 09:28:53 TUYA D][app_agent.c:600] send length:32, id:33, sequence_out:59409
[2024/8/7 9:28:51 610] [08-07 09:28:53 TUYA D][smart_frame.c:2112] Start To Sync Dev:6cd19cfd296e4b10a7ezkm, dp_rept_chan:3
[2024/8/7 9:28:51 610] [08-07 09:28:53 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:28:51 626] [08-07 09:28:53 TUYA D][smart_frame.c:2517] Nothing To Pack
[2024/8/7 9:28:51 626] [08-07 09:28:53 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:28:51 626] [08-07 09:28:53 TUYA D][i[atbm_log]:ieee80211_ble_read: recv_queue list is empty.
[2024/8/7 9:28:51 642] ot_httpc.c:1161] Post Data: {"t":1722994133}
[2024/8/7 9:28:51 658] [08-07 09:28:53 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.uuid.pskkey.get&et=1&t=1722994133&uuid=uuidcaab27b0a838d239&v=1.0&sign=9c2bba453f8e0ab36310c4c40a799e2d
[2024/8/7 9:28:51 658] [08-07 09:28:53 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:51 674] [08-07 09:28:53 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:51 674] [08-07 09:28:53 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:51 690] [08-07 09:28:53 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:51 690] [08-07 09:28:53 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:51 690] [08-07 09:28:53 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:51 706] [08-07 09:28:53 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:51 706] [08-07 09:28:53 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:51 722] [08-07 09:28:53 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:51 722] [08-07 09:28:53 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:51 738] [08-07 09:28:53 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:51 738] [08-07 09:28:53 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:51 754] [08-07 09:28:53 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:51 754] ble_slave_gap_event->type=14
[2024/8/7 9:28:51 770] subscribe event; conn_handle=1 attr_handle=23 reason=2 prevn=1 curn=0 previ=0 curi=0
[2024/8/7 9:28:51 770] ---[ble_slave_gap_event][914]: ble_svc_gatt_changed_val_handle=[10]
[2024/8/7 9:28:51 770] ble_slave_gap_event->type=1
[2024/8/7 9:28:51 787] disconnect; reason=531 
[2024/8/7 9:28:51 788] [08-07 09:28:54 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"pskKey":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80"},"t":1722994134,"success":true}
[2024/8/7 9:28:51 803] [08-07 09:28:54 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:51 803] [08-07 09:28:54 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:51 835] [08-07 09:28:54 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":"injD7PG3Q2Xxyt9s1w4h6GrVSA4792NevgC80","auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:28:51 835] [08-07 09:28:54 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:28:51 835] [08-07 09:28:54 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:28:51 851] [08-07 09:28:54 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:28:51 851] [08-07 09:28:54 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:256
[2024/8/7 9:28:51 866] [08-07 09:28:54 TUYA D][simplekv.c:397] 0 key same AND size old 276 >= new 256
[2024/8/7 9:28:51 867] [08-07 09:28:54 TUYA D][simplekv.c:430] find 0 available space
[2024/8/7 9:28:51 867] [08-07 09:28:54 TUYA D][simplekv.c:474] reuse available space 28700
[2024/8/7 9:28:51 882] [08-07 09:28:54 TUYA D][simplekv.c:203] update crc 253410422
[2024/8/7 9:28:51 882] [08-07 09:28:54 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:51 883] [08-07 09:28:54 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:51 898] [08-07 09:28:54 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:28:51 994] set sd_record_on_off:1 
[2024/8/7 9:28:52 010] set sd_record_mode:0 
[2024/8/7 9:28:52 010] [08-07 09:28:54 TUYA E][tuya_ipc_stream_storage.c:1912] the ss mgr not inited, but msg buffered: set mode 1
[2024/8/7 9:28:52 010] write RecordMode success  0 
[2024/8/7 9:28:52 026] [08-07 09:28:54 TUYA D][tuya_ipc_cloud_storage.c:2188] init cloud storage begin
[2024/8/7 9:28:52 026] [08-07 09:28:54 TUYA D][simplekv.c:1211] read key:md5_encrypt_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:52 042] [08-07 09:28:54 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:52 042] [08-07 09:28:54 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:52 042] [08-07 09:28:54 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:52 058] [08-07 09:28:54 TUYA E][tuya_ipc_cloud_storage.c:365] iot_wd_common_read fails md5_encrypt_key -6
[2024/8/7 9:28:52 058] [08-07 09:28:54 TUYA E][tuya_ipc_cloud_storage.c:450] read key_key file failed.
[2024/8/7 9:28:52 074] [08-07 09:28:54 TUYA D][tuya_ipc_cloud_storage.c:2240] __check_md5_encrypt_key fail, need update from server
[2024/8/7 9:28:52 074] [08-07 09:28:54 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:28:52 091] [08-07 09:28:54 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:52 091] [08-07 09:28:54 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:52 091] [08-07 09:28:54 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:52 107] [08-07 09:28:54 TUYA E][tuya_ipc_cloud_storage.c:942] iot_wd_common_read fails storage_restriction -6
[2024/8/7 9:28:52 107] [08-07 09:28:54 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994134}
[2024/8/7 9:28:52 139] [08-07 09:28:54 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.restriction.config.get&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994134&v=1.0&sign=c807fe333addfb510ca1120710380260
[2024/8/7 9:28:52 139] [08-07 09:28:54 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:52 139] [08-07 09:28:54 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:52 155] [08-07 09:28:54 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:52 155] [08-07 09:28:54 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:52 171] [08-07 09:28:54 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:52 171] [08-07 09:28:54 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:52 187] [08-07 09:28:54 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:52 187] [08-07 09:28:54 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:52 203] [08-07 09:28:54 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:52 203] [08-07 09:28:54 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:52 218] [08-07 09:28:54 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:52 219] [08-07 09:28:54 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:52 234] [08-07 09:28:54 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:52 250] [08-07 09:28:54 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"msg":{"audioDuration":15,"audioInterval":300,"videoDuration":6,"videoInterval":300},"storage":{"mtu":10}},"t":1722994134,"success":true}
[2024/8/7 9:28:52 251] [08-07 09:28:54 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:52 266] [08-07 09:28:54 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:52 267] [08-07 09:28:54 TUYA D][simplekv.c:1211] read key:storage_restriction isFuzzy:0 skipCnt:0
[2024/8/7 9:28:52 283] [08-07 09:28:54 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:52 283] [08-07 09:28:54 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:52 283] [08-07 09:28:54 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:52 298] [08-07 09:28:54 TUYA D][simplekv.c:374] write key:storage_restriction And Value Len:32
[2024/8/7 9:28:52 298] [08-07 09:28:54 TUYA D][simplekv.c:457] new space 16 startpos:37292 size:100
[2024/8/7 9:28:52 316] [08-07 09:28:54 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:52 316] [08-07 09:28:54 TUYA D][simplekv.c:203] update crc 1603094549
[2024/8/7 9:28:52 316] [08-07 09:28:54 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:52 330] [08-07 09:28:54 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:52 330] [08-07 09:28:54 TUYA D][tuya_ipc_cloud_storage.c:920] slice_duration write success
[2024/8/7 9:28:52 346] [08-07 09:28:54 TUYA D][tuya_ipc_cloud_storage.c:999] case 2 get slice duration from cloud 10
[2024/8/7 9:28:52 346] [08-07 09:28:54 TUYA D][tuya_ipc_cloud_storage.c:1043] cloud storage seize 3059584 bytes memory for media data, each slice 10 seconds
[2024/8/7 9:28:52 362] [08-07 09:28:54 TUYA I][uni_thread.c:228] thread_create name:cloud_storage,stackDepth:65536,totalstackDepth:91136,priority:3
[2024/8/7 9:28:52 378] [08-07 09:28:54 TUYA D][tuya_ipc_mqtt_subscribe.c:85] __mqtt_subscribe_init
[2024/8/7 9:28:52 378] [08-07 09:28:54 TUYA D][tuya_ipc_cloud_storage.c:2289] init cloud storage success
[2024/8/7 9:28:52 378] [08-07 09:28:54 TUYA D][MainApp.c:590] cloud storage init result is 0
[2024/8/7 9:28:52 394] [08-07 09:28:54 TUYA D][uni_thread.c:250] Thread:cloud_storage Exec Start. Set to Running Stat
[2024/8/7 9:28:52 394] [08-07 09:28:54 TUYA D][iot_httpc.c:1161] Post Data: {"type":"MediaStor","t":1722994134}
[2024/8/7 9:28:52 426] [08-07 09:28:54 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.storage.config.get&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994134&v=3.0&sign=2403b8f8cb8acb269e8a509a00777a61
[2024/8/7 9:28:52 426] [08-07 09:28:54 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:52 426] [08-07 09:28:54 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:52 442] [08-07 09:28:54 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:52 442] [08-07 09:28:54 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:52 459] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:52 459] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<105> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:52 475] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:52 475] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:52 490] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"105":false}
[2024/8/7 9:28:52 491] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62593 Q:1 Data:{"dps":{"105":false}}
[2024/8/7 9:28:52 506] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:52 507] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<101> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:52 522] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:28:52 522] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:52 522] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"101":true}
[2024/8/7 9:28:52 538] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62594 Q:1 Data:{"dps":{"101":true}}
[2024/8/7 9:28:52 538] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:52 554] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<103> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:52 554] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:52 571] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:52 571] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"103":false}
[2024/8/7 9:28:52 586] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62595 Q:1 Data:{"dps":{"103":false}}
[2024/8/7 9:28:52 586] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:52 602] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<104> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:52 602] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:28:52 618] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:52 618] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"104":true}
[2024/8/7 9:28:52 634] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62596 Q:1 Data:{"dps":{"104":true}}
[2024/8/7 9:28:52 634] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:52 634] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:107 not find
[2024/8/7 9:28:52 650] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:52 650] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:52 650] [08-07 09:28:54 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:28:52 666] [08-07 09:28:54 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:28:52 667] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"105":false}} pro:4 num:62593
[2024/8/7 9:28:52 682] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"105":false}}} offset:58
[2024/8/7 9:28:52 682] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"105":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:52 698] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59410
[2024/8/7 9:28:52 698] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"101":true}} pro:4 num:62594
[2024/8/7 9:28:52 714] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"101":true}}} offset:57
[2024/8/7 9:28:52 730] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"101":true}}, msg_len:20, out_len:72
[2024/8/7 9:28:52 730] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59411
[2024/8/7 9:28:52 746] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"103":false}} pro:4 num:62595
[2024/8/7 9:28:52 746] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"103":false}}} offset:58
[2024/8/7 9:28:52 762] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"103":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:52 762] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59412
[2024/8/7 9:28:52 778] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"104":true}} pro:4 num:62596
[2024/8/7 9:28:52 794] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"104":true}}} offset:57
[2024/8/7 9:28:52 794] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"104":true}}, msg_len:20, out_len:72
[2024/8/7 9:28:52 810] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59413
[2024/8/7 9:28:52 810] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:52 810] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:108 not find
[2024/8/7 9:28:52 826] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:52 826] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:52 826] IPC_APP_get_smart_mutile_light_mode line(546) ----------  
[2024/8/7 9:28:52 842] [08-07 09:28:54 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:52 842] [08-07 09:28:54 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:52 858] [08-07 09:28:54 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:52 858] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:28:52 874] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:28:52 874] IPC_APP_set_smart_mutile_light_mode line(451) ---------- :0 ,g_SMLAbility=[0]
[2024/8/7 9:28:52 874] [08-07 09:28:54 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:52 890] [08-07 09:28:54 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:52 890] [08-07 09:28:54 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:52 906] [08-07 09:28:54 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:52 906] DEBUG: camera_set_dnc_mode_chn 0 
[2024/8/7 9:28:52 906] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:28:52 906] DEBUG: software pohtoR!
[2024/8/7 9:28:52 922] IPC_APP_set_smart_mutile_light_mode line(536) ---------- :mode=[0] 
[2024/8/7 9:28:52 922] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:52 938] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<124> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:52 938] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:52 954] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"124":"auto"}
[2024/8/7 9:28:52 954] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"124":"auto"}} pro:4 num:62597
[2024/8/7 9:28:52 970] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"124":"auto"}}} offset:59
[2024/8/7 9:28:52 970] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"124":"auto"}}, msg_len:22, out_len:74
[2024/8/7 9:28:52 986] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59414
[2024/8/7 9:28:52 986] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62597 Q:1 Data:{"dps":{"124":"auto"}}
[2024/8/7 9:28:53 002] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 002] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<134> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:53 018] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:28:53 018] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:53 034] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"134":true}
[2024/8/7 9:28:53 034] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"105":false}}, mqtt async dp cb:0
[2024/8/7 9:28:53 050] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:105, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:53 050] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:105, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 066] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:105, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 066] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"134":true}} pro:4 num:62598
[2024/8/7 9:28:53 082] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"134":true}}} offset:57
[2024/8/7 9:28:53 098] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"134":true}}, msg_len:20, out_len:72
[2024/8/7 9:28:53 098] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59415
[2024/8/7 9:28:53 114] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62598 Q:1 Data:{"dps":{"134":true}}
[2024/8/7 9:28:53 114] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 130] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<106> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:53 130] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:53 130] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"106":"1"}
[2024/8/7 9:28:53 146] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"106":"1"}} pro:4 num:62599
[2024/8/7 9:28:53 146] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"101":true}}, mqtt async dp cb:0
[2024/8/7 9:28:53 162] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"106":"1"}}} offset:56
[2024/8/7 9:28:53 178] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"106":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:28:53 178] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59416
[2024/8/7 9:28:53 194] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62599 Q:1 Data:{"dps":{"106":"1"}}
[2024/8/7 9:28:53 194] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:101, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:53 210] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:101, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 210] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:101, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 226] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 226] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:168 not find
[2024/8/7 9:28:53 242] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:53 242] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:53 242] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(855):  ---
[2024/8/7 9:28:53 258] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"103":false}}, mqtt async dp cb:0
[2024/8/7 9:28:53 274] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:103, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:53 274] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:103, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 290] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:103, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 290] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(866):  ---
[2024/8/7 9:28:53 306] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(872):  ---
[2024/8/7 9:28:53 306] --- tracepoint tuya_ipc_dp_handler.c,IPC_APP_get_alarm_zone_draw(892):  ---
[2024/8/7 9:28:53 322] [IPC_APP_get_alarm_zone_draw][893] alarm zone[{\"num\":1,\"region0\":{\"x\":1,\"y\":1,\"xlen\":99,\"ylen\":99}}]
[2024/8/7 9:28:53 322] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 322] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:169 not find
[2024/8/7 9:28:53 338] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:53 338] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:53 338] curr sd_status:1 
[2024/8/7 9:28:53 338] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 354] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<110> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:53 370] [08-07 09:28:54 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:5
[2024/8/7 9:28:53 370] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:53 370] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"110":5}
[2024/8/7 9:28:53 386] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"110":5}} pro:4 num:62600
[2024/8/7 9:28:53 402] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"110":5}}} offset:54
[2024/8/7 9:28:53 402] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"110":5}}, msg_len:17, out_len:69
[2024/8/7 9:28:53 419] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59417
[2024/8/7 9:28:53 419] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62600 Q:1 Data:{"dps":{"110":5}}
[2024/8/7 9:28:53 419] handle_DP_SD_STORAGE_ONLY_GET line(654) --------------------- 
[2024/8/7 9:28:53 435] [1970-01-01 00:00:44] tuya_ipc_sd_demo.c(182) <tuya_ipc_sd_get_capacity>: XM_SDCardGetPartitionInfo failed
[2024/8/7 9:28:53 435] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 451] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<109> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:53 451] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:53 467] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"109":"0|0|0"}
[2024/8/7 9:28:53 467] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"109":"0|0|0"}} pro:4 num:62601
[2024/8/7 9:28:53 483] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"109":"0|0|0"}}} offset:60
[2024/8/7 9:28:53 498] [1970-01-01 00:00:44] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:53 498] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"109":"0|0|0"}}, msg_len:23, out_len:75
[2024/8/7 9:28:53 514] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59418
[2024/8/7 9:28:53 514] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62601 Q:1 Data:{"dps":{"109":"0|0|0"}}
[2024/8/7 9:28:53 530] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 530] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<150> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:53 547] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:1
[2024/8/7 9:28:53 547] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:53 563] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"150":true}
[2024/8/7 9:28:53 563] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"150":true}} pro:4 num:62602
[2024/8/7 9:28:53 579] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"150":true}}} offset:57
[2024/8/7 9:28:53 579] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"150":true}}, msg_len:20, out_len:72
[2024/8/7 9:28:53 595] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59419
[2024/8/7 9:28:53 595] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62602 Q:1 Data:{"dps":{"150":true}}
[2024/8/7 9:28:53 610] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 610] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<151> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:53 627] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:53 627] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"151":"1"}
[2024/8/7 9:28:53 643] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"151":"1"}} pro:4 num:62603
[2024/8/7 9:28:53 643] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"151":"1"}}} offset:56
[2024/8/7 9:28:53 660] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"151":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:28:53 660] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59420
[2024/8/7 9:28:53 674] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62603 Q:1 Data:{"dps":{"151":"1"}}
[2024/8/7 9:28:53 674] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 690] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<117> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:53 690] [08-07 09:28:54 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:0
[2024/8/7 9:28:53 706] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:53 706] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 9:28:53 722] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"117":0}} pro:4 num:62604
[2024/8/7 9:28:53 722] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"117":0}}} offset:54
[2024/8/7 9:28:53 738] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"117":0}}, msg_len:17, out_len:69
[2024/8/7 9:28:53 738] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59421
[2024/8/7 9:28:53 754] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62604 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 9:28:53 755] [08-07 09:28:54 TUYA E][mqtt_client.c:1854] can't find free mqmde
[2024/8/7 9:28:53 755] [08-07 09:28:54 TUYA E][mqc_app.c:890] mqc_pub_async err:-1
[2024/8/7 9:28:53 770] [08-07 09:28:54 TUYA E][smart_frame.c:2318] mqtt async send err:-1
[2024/8/7 9:28:53 771] [08-07 09:28:54 TUYA E][smart_frame.c:3524] dp_report err:-1
[2024/8/7 9:28:53 786] [08-07 09:28:54 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:53 802] [08-07 09:28:54 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:53 802] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 818] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<138> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:53 818] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:53 818] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:53 834] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"138":false}
[2024/8/7 9:28:53 834] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"138":false}} pro:4 num:62605
[2024/8/7 9:28:53 850] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"138":false}}} offset:58
[2024/8/7 9:28:53 866] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"138":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:53 866] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59422
[2024/8/7 9:28:53 882] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"104":true}}, mqtt async dp cb:0
[2024/8/7 9:28:53 882] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62605 Q:1 Data:{"dps":{"138":false}}
[2024/8/7 9:28:53 898] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:104, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:53 898] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:104, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 914] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:104, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 914] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"124":"auto"}}, mqtt async dp cb:0
[2024/8/7 9:28:53 930] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:124, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:53 946] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:124, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 946] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:124, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:53 946] current power mode:1
[2024/8/7 9:28:53 962] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:53 962] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"134":true}}, mqtt async dp cb:0
[2024/8/7 9:28:53 978] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:146 not find
[2024/8/7 9:28:53 978] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:53 978] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:53 978] current battery percent:80
[2024/8/7 9:28:53 994] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:134, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 010] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:134, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 010] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:134, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 026] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 026] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:145 not find
[2024/8/7 9:28:54 026] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:54 042] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:54 042] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"106":"1"}}, mqtt async dp cb:0
[2024/8/7 9:28:54 058] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:106, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 058] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:106, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 074] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:106, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 091] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"110":5}}, mqtt async dp cb:0
[2024/8/7 9:28:54 091] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:110, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 106] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:110, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 106] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:110, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 123] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 123] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<170> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:54 138] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:54 139] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:54 155] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"170":false}
[2024/8/7 9:28:54 155] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"170":false}} pro:4 num:62606
[2024/8/7 9:28:54 170] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"109":"0|0|0"}}, mqtt async dp cb:0
[2024/8/7 9:28:54 170] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"170":false}}} offset:58
[2024/8/7 9:28:54 186] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"170":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:54 186] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59423
[2024/8/7 9:28:54 202] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62606 Q:1 Data:{"dps":{"170":false}}
[2024/8/7 9:28:54 202] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:109, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 218] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:109, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 234] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:109, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 235] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"150":true}}, mqtt async dp cb:0
[2024/8/7 9:28:54 250] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:150, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 250] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:150, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 266] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:150, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 266] src/intelligent_track_thread.c(1466) [XM_GetBodyTarckEnable]: 
[2024/8/7 9:28:54 282] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"151":"1"}}, mqtt async dp cb:0
[2024/8/7 9:28:54 282] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:151, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 298] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:151, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 314] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:151, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 314] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 330] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<161> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:54 330] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:54 330] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:54 346] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"161":false}
[2024/8/7 9:28:54 346] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"161":false}} pro:4 num:62607
[2024/8/7 9:28:54 362] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"161":false}}} offset:58
[2024/8/7 9:28:54 378] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"161":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:54 378] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59424
[2024/8/7 9:28:54 394] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62607 Q:1 Data:{"dps":{"161":false}}
[2024/8/7 9:28:54 394] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 394] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:186 not find
[2024/8/7 9:28:54 410] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:54 410] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:54 410] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 426] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<133> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:54 443] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:54 443] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"133":"3"}
[2024/8/7 9:28:54 443] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"133":"3"}} pro:4 num:62608
[2024/8/7 9:28:54 459] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"133":"3"}}} offset:56
[2024/8/7 9:28:54 474] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"133":"3"}}, msg_len:19, out_len:71
[2024/8/7 9:28:54 474] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59425
[2024/8/7 9:28:54 490] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62608 Q:1 Data:{"dps":{"133":"3"}}
[2024/8/7 9:28:54 490] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 507] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<139> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:54 507] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:54 523] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:54 523] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"139":false}
[2024/8/7 9:28:54 523] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"139":false}} pro:4 num:62609
[2024/8/7 9:28:54 538] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"139":false}}} offset:58
[2024/8/7 9:28:54 554] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"139":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:54 554] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59426
[2024/8/7 9:28:54 570] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62609 Q:1 Data:{"dps":{"139":false}}
[2024/8/7 9:28:54 570] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 70 enable 0 volume
[2024/8/7 9:28:54 586] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 586] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<140> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:54 602] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:54 602] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"140":"1"}
[2024/8/7 9:28:54 618] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"140":"1"}} pro:4 num:62610
[2024/8/7 9:28:54 618] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"140":"1"}}} offset:56
[2024/8/7 9:28:54 634] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"140":"1"}}, msg_len:19, out_len:71
[2024/8/7 9:28:54 634] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59427
[2024/8/7 9:28:54 650] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62610 Q:1 Data:{"dps":{"140":"1"}}
[2024/8/7 9:28:54 650] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"138":false}}, mqtt async dp cb:0
[2024/8/7 9:28:54 666] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:138, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 666] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:138, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 682] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:138, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 682] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 698] [08-07 09:28:54 TUYA E][smart_frame.c:569] dparr[0] type not match:1 0
[2024/8/7 9:28:54 698] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3586
[2024/8/7 9:28:54 714] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"170":false}}, mqtt async dp cb:0
[2024/8/7 9:28:54 714] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:170, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 730] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:170, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 730] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:170, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 746] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"161":false}}, mqtt async dp cb:0
[2024/8/7 9:28:54 762] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:161, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 762] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:161, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 778] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:161, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 779] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 795] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<160> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:54 795] [08-07 09:28:54 TUYA D][smart_frame.c:435] dp_cntl value:0, dp_data value:50
[2024/8/7 9:28:54 810] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:54 810] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"160":50}
[2024/8/7 9:28:54 826] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"160":50}} pro:4 num:62611
[2024/8/7 9:28:54 826] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"160":50}}} offset:55
[2024/8/7 9:28:54 843] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"160":50}}, msg_len:18, out_len:70
[2024/8/7 9:28:54 843] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59428
[2024/8/7 9:28:54 858] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62611 Q:1 Data:{"dps":{"160":50}}
[2024/8/7 9:28:54 858] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 874] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"133":"3"}}, mqtt async dp cb:0
[2024/8/7 9:28:54 874] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:195 not find
[2024/8/7 9:28:54 874] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:54 890] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:54 890] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:133, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:54 906] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:133, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 922] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:133, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:54 922] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 922] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:194 not find
[2024/8/7 9:28:54 938] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:54 938] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:54 938] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 954] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:158 not find
[2024/8/7 9:28:54 954] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:54 970] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:54 970] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:54 970] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:54 986] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:54 986] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:55 002] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:28:55 002] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:62612
[2024/8/7 9:28:55 018] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 9:28:55 035] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:55 035] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59429
[2024/8/7 9:28:55 050] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62612 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:28:55 050] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"139":false}}, mqtt async dp cb:0
[2024/8/7 9:28:55 066] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:139, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:55 066] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:139, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 082] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:139, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 082] [1970-01-01 00:00:44] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:28:55 098] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:55 098] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<174> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:55 114] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:55 114] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:55 130] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"174":false}
[2024/8/7 9:28:55 130] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"174":false}} pro:4 num:62613
[2024/8/7 9:28:55 145] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"174":false}}} offset:58
[2024/8/7 9:28:55 146] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"174":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:55 162] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59430
[2024/8/7 9:28:55 162] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62613 Q:1 Data:{"dps":{"174":false}}
[2024/8/7 9:28:55 178] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"140":"1"}}, mqtt async dp cb:0
[2024/8/7 9:28:55 178] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:140, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:55 194] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:140, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 210] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:140, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 210] [1970-01-01 00:00:44] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:28:55 210] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:55 226] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<175> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:55 242] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:55 242] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"175":"0"}
[2024/8/7 9:28:55 258] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62614 Q:1 Data:{"dps":{"175":"0"}}
[2024/8/7 9:28:55 258] [1970-01-01 00:00:44] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:28:55 258] cruiseTimeMode is 0.
[2024/8/7 9:28:55 258] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:55 274] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<176> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:55 290] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:55 290] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"176":"0"}
[2024/8/7 9:28:55 306] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62615 Q:1 Data:{"dps":{"176":"0"}}
[2024/8/7 9:28:55 307] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"175":"0"}} pro:4 num:62614
[2024/8/7 9:28:55 322] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"175":"0"}}} offset:56
[2024/8/7 9:28:55 322] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"175":"0"}}, msg_len:19, out_len:71
[2024/8/7 9:28:55 338] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59431
[2024/8/7 9:28:55 338] [08-07 09:28:54 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"errorCode":"CAMERA_STORAGE_ORDER_NOT_EXISTED"},"t":1722994134,"success":true}
[2024/8/7 9:28:55 386] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"176":"0"}} pro:4 num:62615
[2024/8/7 9:28:55 386] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"176":"0"}}} offset:56
[2024/8/7 9:28:55 402] [08-07 09:28:54 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:55 402] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"176":"0"}}, msg_len:19, out_len:71
[2024/8/7 9:28:55 418] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59432
[2024/8/7 9:28:55 418] [08-07 09:28:54 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:55 434] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"160":50}}, mqtt async dp cb:0
[2024/8/7 9:28:55 434] [08-07 09:28:54 TUYA E][cloud_operation.c:511] errorCode:CAMERA_STORAGE_ORDER_NOT_EXISTED
[2024/8/7 9:28:55 450] [08-07 09:28:54 TUYA D][tuya_ipc_cloud_storage.c:535] order expire or remote server error
[2024/8/7 9:28:55 450] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:160, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:55 466] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:160, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 482] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:160, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 483] [08-07 09:28:54 TUYA E][tuya_ipc_cloud_storage.c:1695] check cloud storage count failed, op_ret = -1
[2024/8/7 9:28:55 498] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:28:55 498] {"159":false}}, mqtt async dp cb:0
[2024/8/7 9:28:55 499] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:55 514] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 530] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 530] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"174":false}}, mqtt async dp cb:0
[2024/8/7 9:28:55 546] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:174, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:55 547] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:174, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 562] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:174, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 563] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"175":"0"}}, mqtt async dp cb:0
[2024/8/7 9:28:55 578] [08-0[atbm_log]:Tx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:28:55 579] 7 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:175, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:55 594] [08-07 [atbm_log]:AMPDU[eth2]:action[3],tid[0],ssn[0],buff_size[0],token[0],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:55 594] 09:28:54 TUYA D][atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 0
[2024/8/7 9:28:55 611] [smart_frame.c:2[atbm_log]:AMPDU[eth2]:action[1],tid[0],ssn[0],buff_size[0],token[2],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:55 627] 49] set long dp rate rule, dpID:175, curr_t:1722[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 5
[2024/8/7 9:28:55 627] 994134, rept_cnt[atbm_log]:AMPDU[eth2]:action[1],tid[5],ssn[0],buff_size[0],token[3],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:55 627] :0.
[2024/8/7 9:28:55 643] [08-07 09:28:54 TU[atbm_log]:Rx BA session stop requested for a4:a9:30:ce:5e:66 tid 6
[2024/8/7 9:28:55 643] YA D][smart_fram[atbm_log]:AMPDU[eth2]:action[1],tid[6],ssn[0],buff_size[0],token[1],ta[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:55 660] [atbm_log]:eth2: deauthenticating from a4:a9:30:ce:5e:66 by local choice (reason=3)
[2024/8/7 9:28:55 675] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"176":"0"}}, mqtt async dp cb:0
[2024/8/7 9:28:55 675] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:176, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:55 691] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:176, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 691] [08-07 09:28[atbm_log]:[TX]:[0]:deatuhen[a4:a9:30:ce:5e:66]
[2024/8/7 9:28:55 706] :54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:176, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:55 707] [1970-01-01 00:00:44] utils.c(322) <ReadTYJsonConfig>: Get antiFlicker object error!
[2024/8/7 9:28:55 707] anti Flicker mode is 0.
[2024/8/7 9:28:55 722] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:55 722] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:188 not find
[2024/8/7 9:28:55 738] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:55 738] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:55 739] [1970-01-01 00:00:44] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:28:55 754] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:55 754] [08-07 09:28:54 TUY[atbm_log]:sta[a4:a9:30:ce:5e:66] alloc txhdr
[2024/8/7 9:28:55 754] A E][smart_frame.c:564] devid:(null) dparr[0]:192 not find
[2024/8/7 9:28:55 770] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:55 771] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:55 786] [1970-01-01 00:00:44] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:28:55 786] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:55 786] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:193 not find
[2024/8/7 9:28:55 802] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:55 802] [08-07 09:28:54[atbm_log]:[STA]:unjoin ++
[2024/8/7 9:28:55 802]  TUYA D][smart_frame.c:3503] dp [atbm_log]:[STA]:unjoin --
[2024/8/7 9:28:55 802] compose null, ret:-3585
[2024/8/7 9:28:55 818] [1970-01-01 00:00:44] utils.c(322) <ReadTYJsonConfig>: Get FlightWarn object error!
[2024/8/7 9:28:55 818] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:55 834] [08-07 09:28:54 TUYA E][smart_frame.c:564] devid:(null) dparr[0]:173 not find
[2024/8/7 9:28:55 834] [08-07 09:28:54 TUYA D][smart_frame.c:629] no vaild dp to rept
[2024/8/7 9:28:55 834] [08-07 09:28:54 TUYA D][smart_frame.c:3503] dp compose null, ret:-3585
[2024/8/7 9:28:55 850] [1970-01-01 00:00:44] utils.c(322) <ReadTYJsonConfig>: Get IPC object error!
[2024/8/7 9:28:55 866] [08-07 09:28:54 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:55 882] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<120> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:55 882] [08-07 09:28:54[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:28:55 898]  TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:55 898] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:55 898] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"120":false}
[2024/8/7 9:28:55 914] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62616 Q:1 Data:{"dps":{"120":false}}
[2024/8/7 9:28:55 914] [atbm_log]:eth2:free authen bss ++e.c:3490] rept chan:3
[2024/8/7 9:28:55 930] [08-07 09:28:54 TUYA D][smart_frame.c:419] dp<231> check. need_update:1 pv_stat:0 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:55 946] [08-07 09:28:54 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:55 946] [08-07 09:28:54 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:55 947] [08-07 09:28:54 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"231":false}
[2024/8/7 9:28:55 961] [08-07 09:28:54 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62617 Q:1 Data:{"dps":{"231":false}}
[2024/8/7 9:28:55 978] [08-07 09:28:54 TUYA D][iot_httpc.c:1161] Post Data: {"skill":"{\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}","t":1722994134}
[2024/8/7 9:28:55 993] [08-07 09:28:54 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.skill.update&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994134&v=1.0&sign=2c8fd4f59646bcf7a1441f92eeeb078f
[2024/8/7 9:28:55 994] [08-07 09:28:54 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:56 010] [08-07 09:28:54 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:56 010] [08-07 09:28:54 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:28:56 025] [08-07 09:28:54 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:28:56 026] [08-07 09:28:54 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:56 041] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"120":false}} pro:4 num:62616
[2024/8/7 9:28:56 042] [08-07 09:28:54 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:56 058] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"120":false}}} offset:58
[2024/8/7 9:28:56 058] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"120":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:56 074] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59433
[2024/8/7 9:28:56 074] [08-07 09:28:54 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"231":false}} pro:4 num:62617
[2024/8/7 9:28:56 090] [08-07 09:28:54 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994134,"data":{"dps":{"231":false}}} offset:58
[2024/8/7 9:28:56 090] [08-07 09:28:54 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"231":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:56 106] [08-07 09:28:54 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59434
[2024/8/7 9:28:56 106] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"120":false}}, mqtt async dp cb:0
[2024/8/7 9:28:56 121] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:120, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:56 137] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:120, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:56 137] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:120, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:56 154] [08-07 09:28:54 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"231":false}}, mqtt async dp cb:0
[2024/8/7 9:28:56 154] [08-07 09:28:54 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:231, curr_t:1722994134, rept_cnt:1.
[2024/8/7 9:28:56 170] [08-07 09:28:54 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:231, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:56 186] [08-07 09:28:54 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:231, curr_t:1722994134, rept_cnt:0.
[2024/8/7 9:28:56 187] [08-07 09:28:54 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:56 187] [08-07 09:28:54 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:56 202] [08-07 09:28:54 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:56 202] [08-07 09:28:54 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:56 219] [08-07 09:28:54 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:56 219] [08-07 09:28:54 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:56 234] [08-07 09:28:54 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:56 234] [08-07 09:28:54 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:56 250] [08-07 09:28:54 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:56 266] [08-07 09:28:54 TUYA D][iot_httpc.c:601] Decode Rev:{"t":1722994135,"success":true}
[2024/8/7 9:28:56 266] [08-07 09:28:55 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:56 266] [08-07 09:28:55 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:56 282] [08-07 09:28:55 TUYA D][tuya_ipc_skill.c:198] upload data: {\"sdk_version\":\"5.3.37\",\"cloudStorage\":3,\"localStorage\":1,\"video_num\":2}
[2024/8/7 9:28:56 298] [08-07 09:28:55 TUYA D][MainApp.c:597] tuya_ipc_sdk_mqtt_online_proc is end run
[2024/8/7 9:28:56 298] [1970-01-01 00:00:44] MainApp.c(599) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:28:56 298] tuya_ipc_p2p_demo.c(455)<TUYA_APP_Enable_P2PTransfer> Dbg: Init P2P With Max Users:5
[2024/8/7 9:28:56 314] [08-07 09:28:55 TUYA D][tuya_ipc_webrtc.c:1534] begin___
[2024/8/7 9:28:56 314] [08-07 09:28:55 TUYA D][tuya_ipc_webrtc.c:1541] --audio-:8000,format:101
[2024/8/7 9:28:56 330] [08-07 09:28:55 TUYA D][tuya_ipc_webrtc.c:1542] end___ audiocbk_hdl(0x18f5c)
[2024/8/7 9:28:56 330] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5086] gw actived
[2024/8/7 9:28:56 330] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5095] p2p max_client_num[5]
[2024/8/7 9:28:56 345] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5096] p2p init media info:
[2024/8/7 9:28:56 346] [08-07 09:28:55 TUYA D][tuya_ipc_webrtc.c:1526] webrtc playback start_id 5
[2024/8/7 9:28:56 362] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4781] video codec[20] fps[12] gop[48]
[2024/8/7 9:28:56 362] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4782] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:28:56 378] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4782] height[360] width[640] bitrate[1024]
[2024/8/7 9:28:56 378] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:28:56 394] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4794] height[2160] width[3840] bitrate[2048]
[2024/8/7 9:28:56 394] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[20] fps[12] gop[48]
[2024/8/7 9:28:56 410] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4794] height[360] width[640] bitrate[1024]
[2024/8/7 9:28:56 410] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:28:56 426] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:28:56 427] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:28:56 427] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:28:56 442] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:28:56 442] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:28:56 458] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:28:56 458] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:28:56 474] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:28:56 474] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4793] video codec[0] fps[0] gop[0]
[2024/8/7 9:28:56 490] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4794] height[0] width[0] bitrate[0]
[2024/8/7 9:28:56 490] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4796] videoNum[2] audio codec[129] sample[0]
[2024/8/7 9:28:56 506] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4797] databits[1] channel[0]
[2024/8/7 9:28:56 506] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5122] need speaker audio codec[129] sample[0] databits[1] channel[0] defLiveMode[0]
[2024/8/7 9:28:56 521] [08-07 09:28:55 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:28:56 521] [08-07 09:28:55 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:28:56 522] [08-07 09:28:55 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:28:56 537] [08-07 09:28:55 TUYA D][tuya_ipc_p2p_common.c:264] get p2p passwd = adb2cdd2
[2024/8/7 9:28:56 538] [08-07 09:28:55 TUYA D][tuya_ipc_p2p_common.c:400] check p2p auth update or not
[2024/8/7 9:28:56 553] [08-07 09:28:55 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:28:56 554] [08-07 09:28:55 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:28:56 554] [08-07 09:28:55 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:28:56 571] [08-07 09:28:55 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:28:56 571] [08-07 09:28:55 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:28:56 586] [08-07 09:28:55 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:28:56 586] [08-07 09:28:55 TUYA D][tuya_ipc_p2p_common.c:455] update p2p_auth_info from service, type 4
[2024/8/7 9:28:56 602] [08-07 09:28:55 TUYA D][iot_httpc.c:1161] Post Data: {"type":4,"t":1722994135}
[2024/8/7 9:28:56 618] [08-07 09:28:55 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.p2p.config.get&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994135&v=2.0&sign=5979012c025cbdb4ce29600886d4cefc
[2024/8/7 9:28:56 618] [08-07 09:28:55 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:56 634] [08-07 09:28:55 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:56 634] [08-07 09:28:55 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:56 650] [08-07 09:28:55 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:56 650] [08-07 09:28:55 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:56 650] [08-07 09:28:55 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:56 666] [08-07 09:28:55 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:56 666] [08-07 09:28:55 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:56 682] [08-07 09:28:55 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:56 682] [08-07 09:28:55 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:56 698] [08-07 09:28:55 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:56 698] [08-07 09:28:55 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:56 714] [08-07 09:28:55 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:56 730] [08-07 09:28:55 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"p2pId":"","type":4},"t":1722994135,"success":true}
[2024/8/7 9:28:56 730] [08-07 09:28:55 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:56 746] [08-07 09:28:55 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:56 746] [08-07 09:28:55 TUYA D][tuya_ipc_p2p_common.c:381] SY P2P AUTH:{"p2pId":"","type":4}
[2024/8/7 9:28:56 746] [08-07 09:28:55 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:28:56 762] [08-07 09:28:55 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:28:56 762] [08-07 09:28:55 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:16
[2024/8/7 9:28:56 778] [08-07 09:28:55 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:32
[2024/8/7 9:28:56 778] [08-07 09:28:55 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 32
[2024/8/7 9:28:56 778] [08-07 09:28:55 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:28:56 794] [08-07 09:28:55 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:28:56 794] [08-07 09:28:55 TUYA D][simplekv.c:203] update crc 2957721571
[2024/8/7 9:28:56 810] [08-07 09:28:55 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:56 810] [08-07 09:28:55 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:56 810] [08-07 09:28:55 TUYA D][tuya_ipc_p2p_common.c:458] get p2p auth info from service
[2024/8/7 9:28:56 826] [08-07 09:28:55 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:28:56 826] [08-07 09:28:55 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:28:56 843] [08-07 09:28:55 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:28:56 843] [08-07 09:28:55 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:28:56 843] [08-07 09:28:55 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:28:56 859] [08-07 09:28:55 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:28:56 859] [08-07 09:28:55 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:28:56 874] [08-07 09:28:55 TUYA D][simplekv.c:203] update crc 3508296208
[2024/8/7 9:28:56 875] [08-07 09:28:55 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:56 875] [08-07 09:28:55 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:56 890] [08-07 09:28:55 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:28:56 890] [08-07 09:28:55 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:28:56 890] [08-07 09:28:55 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:28:56 906] [08-07 09:28:55 TUYA D][tuya_ipc_p2p_common.c:120] load str:{"p2pId":"","type":4}
[2024/8/7 9:28:56 906] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5178] p2p did[] apiLicense[] initString[]
[2024/8/7 9:28:56 922] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5181] support p2p type = 4
[2024/8/7 9:28:56 922] P2P API Version: 244.3.4.107
[2024/8/7 9:28:56 922] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4974] no encrypt
[2024/8/7 9:28:56 938] 44831 (null) INFO:6241316: tuya p2p rtc sdk version: 0xf403046b, Nov 16 2023 10:52:20
[2024/8/7 9:28:56 938] tuya liteos uv
[2024/8/7 9:28:56 938] [1970-01-01 00:00:45] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time45260
[2024/8/7 9:28:56 954] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5039] _mqtt_p2p_listen_sessions create
[2024/8/7 9:28:56 954] [08-07 09:28:55 TUYA E][tuya_ipc_p2p.c:5190] p2p v3 init ok
[2024/8/7 9:28:56 970] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5230] speaker task create success
[2024/8/7 9:28:56 970] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5273] __p2p_session_detech create
[2024/8/7 9:28:56 970] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:5290] __p2p_video_send_proc create ok
[2024/8/7 9:28:56 986] [08-07 09:28:55 TUYA D][tuya_ipc_upnp.c:437] tuya_ipc_upnp_init start
[2024/8/7 9:28:57 002] [08-07 09:28:55 TUYA I][uni_thread.c:228] thread_create name:ipc_upnp,stackDepth:65536,totalstackDepth:156672,priority:2
[2024/8/7 9:28:57 003] [08-07 09:28:55 TUYA D][tuya_ipc_upnp.c:458] tuya_ipc_upnp_init success
[2024/8/7 9:28:57 003] [08-07 09:28:55 TUYA E][tuya_ipc_streamer.c:1451] tstream init start
[2024/8/7 9:28:57 018] [08-07 09:28:55 TUYA D][tuya_ipc_packager.c:62] get packager instance
[2024/8/7 9:28:57 018] [08-07 09:28:55 TUYA D][tuya_ipc_packager.c:72] get packager instance done
[2024/8/7 9:28:57 034] [08-07 09:28:55 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:57 034] [08-07 09:28:55 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:57 034] [08-07 09:28:55 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:57 050] [08-07 09:28:55 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:57 050] [08-07 09:28:55 TUYA E][tuya_ipc_encrypt.c:178] read local cloud encrypt key fails ..-6
[2024/8/7 9:28:57 050] [08-07 09:28:55 TUYA D][iot_httpc.c:1161] Post Data: {"t":1722994135}
[2024/8/7 9:28:57 082] [08-07 09:28:55 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.ipc.storage.secret.get&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994135&v=1.0&sign=9eb7337e21e09ca8f67f315f8bcfd0f8
[2024/8/7 9:28:57 082] [08-07 09:28:55 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:57 098] [08-07 09:28:55 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:57 098] [08-07 09:28:55 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:57 098] [08-07 09:28:55 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:57 114] [08-07 09:28:55 TUYA D][uni_thread.c:250] Thread:ipc_upnp Exec Start. Set to Running Stat
[2024/8/7 9:28:57 114] [08-07 09:28:55 TUYA D][iot_httpc.c:1161] Post Data: {"version":"1.0","t":1722994135}
[2024/8/7 9:28:57 146] [08-07 09:28:55 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.upnp.config.get&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994135&v=1.0&sign=d4ec3c00d02384a457177ce3e91c5f81
[2024/8/7 9:28:57 146] [08-07 09:28:55 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:57 146] [08-07 09:28:55 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:57 162] [08-07 09:28:55 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:57 162] [08-07 09:28:55 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:57 178] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:3771] into p2p video send
[2024/8/7 9:28:57 178] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:3783] video send proc alive [0]
[2024/8/7 9:28:57 194] [08-07 09:28:55 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:57 194] [08-07 09:28:55 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:57 210] [08-07 09:28:55 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:57 210] [08-07 09:28:55 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:57 210] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:3553] New Thread To proc, init source
[2024/8/7 9:28:57 226] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:3572] session cmd recv proc alive [0] num[0]
[2024/8/7 9:28:57 226] [08-07 09:28:55 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:57 242] [08-07 09:28:55 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:57 242] [08-07 09:28:55 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:57 258] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4124] Begin to Listen mqtt p2p client connects In Thread
[2024/8/7 9:28:57 258] [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4137] mqtt p2p LISTEN session........
[2024/8/7 9:28:57 274] 45380 (null) [08-07 09:28:55 TUYA D][tuya_ipc_p2p.c:4652] Begin to session detech
[2024/8/7 9:28:57 274] INFO:6241316: try listen
[2024/8/7 9:28:57 274] [08-07 09:28:55 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:57 290] [08-07 09:28:55 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:57 290] [08-07 09:28:55 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:57 306] [08-07 09:28:55 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:57 306] [08-07 09:28:55 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:57 322] [08-07 09:28:55 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:57 322] [08-07 09:28:55 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:57 322] [08-07 09:28:55 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:28:57 337] [08-07 09:28:55 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:28:57 338] [08-07 09:28:55 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:57 354] [08-07 09:28:55 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:57 369] [08-07 09:28:55 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"unitList":[{"port":7000,"protocol":"TCP"},{"port":8080,"protocol":"TCP"},{"port":5000,"protocol":"UDP"},{"port":8000,"protocol":"UDP"}]},"t":1722994136,"success":true}
[2024/8/7 9:28:57 385] [08-07 09:28:56 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:57 385] [08-07 09:28:56 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:57 401] [08-07 09:28:56 TUYA D][tuya_ipc_upnp.c:171] upnp get config success result:{
[2024/8/7 9:28:57 401] 	"unitList":	[{
[2024/8/7 9:28:57 401] 			"port":	7000,
[2024/8/7 9:28:57 401] 			"protocol":	"TCP"
[2024/8/7 9:28:57 401] 		}, {
[2024/8/7 9:28:57 401] 			"port":	8080,
[2024/8/7 9:28:57 401] 			"port":	5000,
[2024/8/7 9:28:57 402] 			"protocol":	"UDP"
[2024/8/7 9:28:57 402] 		}, {
[2024/8/7 9:28:57 417] 			"port":	8000,
[2024/8/7 9:28:57 417] 			"protocol":	"UDP"
[2024/8/7 9:28:57 417] 		}]
[2024/8/7 9:28:57 417] [08-07 09:28:56 TUYA D][tuya_ipc_upnp.c:293] tuya_ipc_upnp_start start
[2024/8/7 9:28:57 434] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:2145] Too few sessions 4, at least 10.
[2024/8/7 9:28:57 434] [08-07 09:28:56 TUYA I][uni_thread.c:228] thread_create name:UPnP_PROC,stackDepth:65536,totalstackDepth:222208,priority:3
[2024/8/7 9:28:57 450] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5000, in_port 5000 protocol:UDP, status:0
[2024/8/7 9:28:57 467] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8000, in_port 8000 protocol:UDP, status:0
[2024/8/7 9:28:57 467] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:8340 
[2024/8/7 9:28:57 482] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 8340, in_port 8340 protocol:UDP, status:0
[2024/8/7 9:28:57 482] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:5127 
[2024/8/7 9:28:57 498] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5127, in_port 5127 protocol:UDP, status:0
[2024/8/7 9:28:57 514] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:1747] create upnp-module random UDP port:5490 
[2024/8/7 9:28:57 514] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:299] add upnp port item:ex_port 5490, in_port 5490 protocol:UDP, status:0
[2024/8/7 9:28:57 530] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:1759] [UPnP]g_upnp_max_port_number 5!
[2024/8/7 9:28:57 530] [08-07 09:28:56 TUYA D][tuya_ipc_upnp.c:314] tuya_ipc_upnp_start success
[2024/8/7 9:28:57 546] [08-07 09:28:56 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:57 546] [08-07 09:28:56 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:57 562] [08-07 09:28:56 TUYA D][simplekv.c:1211] read key:flvlrc_ver isFuzzy:0 skipCnt:0
[2024/8/7 9:28:57 562] [08-07 09:28:56 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:57 578] [08-07 09:28:56 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:57 578] [08-07 09:28:56 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:57 594] [08-07 09:28:56 TUYA D][tuya_svc_schema_upgrade.c:223] schema[flvlrc] not updated since activated
[2024/8/7 9:28:57 594] [08-07 09:28:56 TUYA D][tuya_ipc_upnp.c:421] start upnp module success, exit thread
[2024/8/7 9:28:57 594] [08-07 09:28:56 TUYA D][uni_thread.c:310] Del Thrd:ipc_upnp
[2024/8/7 9:28:57 610] [08-07 09:28:56 TUYA D][uni_thread.c:125] del list not empty...deleting 0x1588f0c, next 0x1542dc8
[2024/8/7 9:28:57 610] [08-07 09:28:56 TUYA D][uni_thread.c:128] Thread:ipc_upnp is still running..
[2024/8/7 9:28:57 626] [08-07 09:28:56 TUYA D][uni_thread.c:250] Thread:UPnP_PROC Exec Start. Set to Running Stat
[2024/8/7 9:28:57 626] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:1367] get upnp dev_mac 90314ba51650
[2024/8/7 9:28:57 642] [08-07 09:28:56 TUYA D][tuya_upnp_module_mg.c:1605] [UPnP]UPNP_MODULE_RUNNING...
[2024/8/7 9:28:57 642] [08-07 09:28:56 TUYA D][iot_httpc.c:601] Decode Rev:{"result":{"encryptKey":"992e9749e8f3402a"},"t":1722994136,"success":true}
[2024/8/7 9:28:57 658] [08-07 09:28:56 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:57 658] [08-07 09:28:56 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:57 674] [08-07 09:28:56 TUYA D][simplekv.c:1211] read key:cloud_enc_key isFuzzy:0 skipCnt:0
[2024/8/7 9:28:57 674] [08-07 09:28:56 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:57 674] [08-07 09:28:56 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:57 690] [08-07 09:28:56 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:57 690] [08-07 09:28:56 TUYA D][simplekv.c:374] write key:cloud_enc_key And Value Len:32
[2024/8/7 9:28:57 706] [08-07 09:28:56 TUYA D][simplekv.c:457] new space 17 startpos:37392 size:100
[2024/8/7 9:28:57 706] [08-07 09:28:56 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:28:57 706] [08-07 09:28:56 TUYA D][simplekv.c:203] update crc 1672395554
[2024/8/7 9:28:57 723] [08-07 09:28:56 TUYA D][uni_thread.c:268] Thread:ipc_upnp Exec Finish. Set to Del Stat
[2024/8/7 9:28:57 723] [08-07 09:28:56 TUYA D][uni_thread.c:125] del list not empty...deleting 0x1588f0c, next 0x1542dc8
[2024/8/7 9:28:57 738] [08-07 09:28:56 TUYA D][uni_thread.c:132] Final Free Thread:ipc_upnp, is_self:1
[2024/8/7 9:28:57 738] [08-07 09:28:56 TUYA D][uni_thread.c:138] delay to delete thread self
[2024/8/7 9:28:57 754] [08-07 09:28:56 TUYA D][uni_thread.c:149] finally delete thread self
[2024/8/7 9:28:57 754] [08-07 09:28:56 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:57 754] [08-07 09:28:56 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:57 770] [08-07 09:28:56 TUYA I][uni_thread.c:228] thread_create name:streamer,stackDepth:8192,totalstackDepth:230400,priority:3
[2024/8/7 9:28:57 770] [08-07 09:28:56 TUYA E][tuya_ipc_streamer.c:1519] tstream init done
[2024/8/7 9:28:57 802] [08-07 09:28:56 TUYA D][tuya_ipc_streamer.c:1406] CLOUD GW skill info:\"videos\":[{\"streamType\":2,\"codecType\":4,\"sampleRate\":90000,\"profileId\":\"\",\"width\":3840,\"height\":2160},{\"streamType\":4,\"codecType\":2,\"sampleRate\":90000,\"width\":640,\"height\":360}],\"audios\":[{\"codecType\":101,\"sampleRate\":8000,\"dataBit\":16,\"channels\":1}]
[2024/8/7 9:28:57 818] [1970-01-01 00:00:45] tuya_ipc_p2p_demo.c(475) <TUYA_APP_Enable_P2PTransfer>: tuya_ipc_tranfser_init ret=[0]
[2024/8/7 9:28:57 818] [1970-01-01 00:00:45] MainApp.c(606) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:28:57 834] [1970-01-01 00:00:45] MainApp.c(614) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:28:57 850] [1970-01-01 00:00:45] MainApp.c(615) <tuya_ipc_sdk_mqtt_online_proc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:28:57 850] [1970-01-01 00:00:45] MainApp.c(616) <tuya_ipc_sdk_mqtt_online_proc>: v_handle=[0x1587d70]
[2024/8/7 9:28:57 866] [1970-01-01 00:00:45] MainApp.c(617) <tuya_ipc_sdk_mqtt_online_proc>: v_handle_sub=[0x1588d60]
[2024/8/7 9:28:57 866] [1970-01-01 00:00:45] MainApp.c(618) <tuya_ipc_sdk_mqtt_online_proc>: a_handle_sub=[0x15ba940]
[2024/8/7 9:28:57 882] [1970-01-01 00:00:45] xm_main.c(1104) <XM_RegisterTYCallFunc>: pfWriteVideoFrameCall=[0x1a8ec]
[2024/8/7 9:28:57 882] [1970-01-01 00:00:45] xm_main.c(1105) <XM_RegisterTYCallFunc>: pfWriteAudioFrameCall=[0x1a8ec]
[2024/8/7 9:28:57 898] [1970-01-01 00:00:45] xm_main.c(1106) <XM_RegisterTYCallFunc>: a_handle_sub=[0x15ba940]
[2024/8/7 9:28:57 898] [1970-01-01 00:00:45] xm_main.c(1107) <XM_RegisterTYCallFunc>: v_handle=[0x1587d70]
[2024/8/7 9:28:57 914] [1970-01-01 00:00:45] xm_main.c(1108) <XM_RegisterTYCallFunc>: v_handle_sub=[0x1588d60]
[2024/8/7 9:28:57 914] [1970-01-01 00:00:45] MainApp.c(620) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:28:57 930] [1970-01-01 00:00:45] MainApp.c(621) <tuya_ipc_sdk_mqtt_online_proc>: 
[2024/8/7 9:28:57 930] [08-07 09:28:56 TUYA D][tuya_ipc_sdk_info.c:99] ipc get service time 1722994136 28800
[2024/8/7 9:28:57 946] [08-07 09:28:56 TUYA D][tuya_ipc_sdk_info.c:130] got service time 1722994136 28800
[2024/8/7 9:28:57 946] [08-07 09:28:56 TUYA D][uni_thread.c:250] Thread:streamer Exec Start. Set to Running Stat
[2024/8/7 9:28:57 962] --- tracepoint tuya_ipc_system_control_demo.c,XM_CheckDls_Pro(810): server time_zone 28800 time 1722994136 dls 0 loacl time 45
[2024/8/7 9:28:57 962] [08-07 09:28:56 TUYA D][tuya_ipc_streamer.c:1236] ThreadStreaming thread start
[2024/8/7 9:28:57 978] [08-07 09:28:56 TUYA D][tuya_ipc_moto_mqtt.c:59] topic already booked!
[2024/8/7 9:28:57 994] [08-07 09:28:56 TUYA D][iot_httpc.c:1161] Post Data: {"type":"tuya_p2p_log","data":"{\"tuya_p2p_sdk_version\":\"tuya_p2p_sdk_v3.4.107, Nov 16 2023 10:52:20\"}","t":1722994136}
[2024/8/7 9:28:58 010] [08-07 09:28:56 TUYA D][iot_httpc.c:1173] Post URL: https://a2.tuyacn.com/d.json?a=tuya.device.log.report&devId=6cd19cfd296e4b10a7ezkm&et=1&t=1722994136&v=1.0&sign=fba6106711ecb2a8c9d3694e9fa786fd
[2024/8/7 9:28:58 010] [08-07 09:28:56 TUYA D][httpc.c:813] Connect: a2.tuyacn.com Port: 443  -->>
[2024/8/7 9:28:58 026] [08-07 09:28:56 TUYA D][uni_network.c:314] unw_gethostbyname a2.tuyacn.com, prio 0
[2024/8/7 9:28:58 026] [08-07 09:28:56 TUYA D][uni_network.c:181] use dynamic dns ip 42.192.31.36 for domain a2.tuyacn.com
[2024/8/7 9:28:58 042] [08-07 09:28:56 TUYA D][httpc.c:477] ----got ipaddr:42,192,31,36
[2024/8/7 9:28:58 042] [08-07 09:28:56 TUYA D][mqc_app.c:1484] custom async cb op_ret: 0
[2024/8/7 9:28:58 042] [08-07 09:28:56 TUYA D][mqc_app.c:1537] pub finish:0
[2024/8/7 9:28:58 058] [2024-08-07 09:28:56] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 55[08-07 09:28:56 TUYA D][httpc.c:815] Connect: a2.tuyacn.com Port: 443  --<< ,r:0
[2024/8/7 9:28:58 074] [08-07 09:28:56 TUYA D][tuya_tls.c:1263] ----enable_cert:1,DEFAULT_LOAD_CERT:1
[2024/8/7 9:28:58 090] [08-07 09:28:56 TUYA D][tuya_tls.c:1306] TUYA_TLS Begin Connect a2.tuyacn.com:443  CustomNet:TRUE Enable_Cert:TRUE Default:TRUE 
[2024/8/7 9:28:58 090] [08-07 09:28:56 TUYA D][tuya_tls.c:1379] load tuya cert.
[2024/8/7 9:28:58 090] [08-07 09:28:56 TUYA D][tuya_tls.c:1384] parse crt <0> len <2002> ret <0>
[2024/8/7 9:28:58 106] [08-07 09:28:56 TUYA D][tuya_iot_com_api.c:259] tuya public url
[2024/8/7 9:28:58 106] [08-07 09:28:56 TUYA D][tuya_tls.c:1494] socket fd is set. set to inner send/recv to handshake
[2024/8/7 9:28:58 122] [08-07 09:28:56 TUYA D][tuya_tls.c:1539] handshake finish for a2.tuyacn.com. set send/recv to user set
[2024/8/7 9:28:58 122] [08-07 09:28:56 TUYA D][tuya_tls.c:1554] TUYA_TLS Success Connect a2.tuyacn.com:443  CustomNet:TRUE Suit:TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
[2024/8/7 9:28:58 154] [2024-08-07 09:28:56] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 56[08-07 09:28:56 TUYA D][iot_httpc.c:601] Decode Rev:{"result":true,"t":1722994136,"success":true}
[2024/8/7 9:28:58 154] [08-07 09:28:56 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:58 154] [08-07 09:28:56 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:58 170] [2024-08-07 09:28:56] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 738g_AudioTipsList.size() enable: 0[08-07 09:28:56 TUYA D][smart_frame.c:3490] rept chan:3
[2024/8/7 9:28:58 186] [08-07 09:28:56 TUYA D][smart_frame.c:419] dp<159> check. need_update:1 pv_stat:3 trig_t:0 dp_rept_type:0 force_send:1
[2024/8/7 9:28:58 186] [08-07 09:28:56 TUYA D][smart_frame.c:423] dp_cntl bool:0, dp_data bool:0
[2024/8/7 9:28:58 202] [08-07 09:28:56 TUYA D][smart_frame.c:521] is_need_update:1, is_dp_passive:0
[2024/8/7 9:28:58 202] [08-07 09:28:56 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"159":false}
[2024/8/7 9:28:58 218] [08-07 09:28:56 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62618 Q:1 Data:{"dps":{"159":false}}
[2024/8/7 9:28:58 218] [08-07 09:28:56 TUYA D][com_protocol.c:586] To:0 src:{"dps":{"159":false}} pro:4 num:62618
[2024/8/7 9:28:58 234] [08-07 09:28:56 TUYA D][com_protocol.c:602] After Pack:{"protocol":4,"t":1722994136,"data":{"dps":{"159":false}}} offset:58
[2024/8/7 9:28:58 250] [08-07 09:28:56 TUYA D][app_agent.c:886] Prepare To Send Lan:{"dps":{"159":false}}, msg_len:21, out_len:73
[2024/8/7 9:28:58 250] [08-07 09:28:56 TUYA D][app_agent.c:600] send length:80, id:33, sequence_out:59435
[2024/8/7 9:28:58 266] [08-07 09:28:56 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"159":false}}, mqtt async dp cb:0
[2024/8/7 9:28:58 266] [08-07 09:28:56 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:159, curr_t:1722994136, rept_cnt:2.
[2024/8/7 9:28:58 282] [08-07 09:28:56 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:159, curr_t:1722994136, rept_cnt:0.
[2024/8/7 9:28:58 282] [08-07 09:28:56 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:159, curr_t:1722994136, rept_cnt:0.
[2024/8/7 9:28:58 297] [08-07 09:28:56 TUYA D][smart_frame.c:2112] Start To Sync Dev:6cd19cfd296e4b10a7ezkm, dp_rept_chan:3
[2024/8/7 9:28:58 297] [08-07 09:28:56 TUYA D][smart_frame.c:2429] Pack local dp, reset_flow_ctl:1,dpnum:41.
[2024/8/7 9:28:58 313] [08-07 09:28:56 TUYA D][smart_frame.c:2452] <__sf_pack_local_obj_data> reset_flow_ctl, dpId:117.
[2024/8/7 9:28:58 313] [08-07 09:28:56 TUYA D][smart_frame.c:2547] final pack:{"117":0}
[2024/8/7 9:28:58 330] [08-07 09:28:56 TUYA D][smart_frame.c:2219] dp rept_type:0, data:{"117":0}
[2024/8/7 9:28:58 330] [08-07 09:28:56 TUYA D][mqc_app.c:879] Send MQTT Msg.P:4 N:62619 Q:1 Data:{"dps":{"117":0}}
[2024/8/7 9:28:58 330] [08-07 09:28:56 TUYA D][smart_frame.c:2135] sync rslt:0
[2024/8/7 9:28:58 346] [08-07 09:28:56 TUYA D][smart_frame.c:2164] Sync Finish
[2024/8/7 9:28:58 346] [08-07 09:28:56 TUYA D][smart_frame.c:2041] msg_data:{"dps":{"117":0}}, mqtt async dp cb:0
[2024/8/7 9:28:58 362] [08-07 09:28:56 TUYA D][smart_frame.c:241] set short dp rate rule, dpID:117, curr_t:1722994136, rept_cnt:1.
[2024/8/7 9:28:58 362] [08-07 09:28:56 TUYA D][smart_frame.c:249] set long dp rate rule, dpID:117, curr_t:1722994136, rept_cnt:0.
[2024/8/7 9:28:58 378] [08-07 09:28:56 TUYA D][smart_frame.c:258] set all dp rate rule, dpID:117, curr_t:1722994136, rept_cnt:0.
[2024/8/7 9:28:58 395] [08-07 09:28:57 TUYA D][mqc_app.c:670] Rev MQTT:{"data":{"devId":"6cd19cfd296e4b10a7ezkm","gwId":"6cd19cfd296e4b10a7ezkm"},"protocol":11,"s":1667075,"t":1722994137}
[2024/8/7 9:28:58 395] [08-07 09:28:57 TUYA D][mqtt_client.c:916] disconnect mqtt
[2024/8/7 9:28:58 410] [08-07 09:28:57 TUYA D][tuya_devos_health.c:30] feed watchdog
[2024/8/7 9:28:58 410] [08-07 09:28:57 TUYA E][app_agent.c:1479] close socket,errno:-100 errno:0
[2024/8/7 9:28:58 410] [08-07 09:28:57 TUYA D][app_agent.c:213] set socket fault 33
[2024/8/7 9:28:58 426] [08-07 09:28:57 TUYA D][app_agent.c:274] i:0,time:1722994137,c_time:1722994133,fault:1
[2024/8/7 9:28:58 426] [08-07 09:28:57 TUYA D][app_agent.c:163] close socket 33
[2024/8/7 9:28:58 442] [2024-08-07 09:28:56] xm_main.c(1724) <XM_OnVideoDataExt_CB>: sub_max_frame_size 8204[2024-08-07 09:28:57] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:28:58 458] [2024-08-07 09:28:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[0]
[2024/8/7 9:28:58 458] [08-07 09:28:57 TUYA D][gw_mqc_cb.c:60] unactive
[2024/8/7 9:28:58 458] [08-07 09:28:57 TUYA E][mqtt_client.c:1652] mq_recv err:-30848 len:0
[2024/8/7 9:28:58 473] [08-07 09:28:57 TUYA D][tuya_devos_reset.c:418] unactive Reset
[2024/8/7 9:28:58 474] [08-07 09:28:57 TUYA D][tuya_devos_reset.c:261] gw reset called. tp:1 stat:1
[2024/8/7 9:28:58 489] __IPC_APP_Get_Net_Status_cb line(183) -------------------------- stat(0)==STAT_LOW_POWER 
[2024/8/7 9:28:58 489] [08-07 09:28:57 TUYA D][tuya_devos_reset.c:85] <__wf_reset> nc_tp:2, rst_tp:1, wifi_start_mode:0
[2024/8/7 9:28:58 505] [08-07 09:28:57 TUYA D][tuya_devos_reset.c:325] <__gw_reset> tuya_ble_clear_mesh
[2024/8/7 9:28:58 505] [08-07 09:28:57 TUYA D][tuya_ble_api.c:1050] start to clr appkey.
[2024/8/7 9:28:58 505] [08-07 09:28:57 TUYA D][simplekv.c:1348] delete key:ble_app_key isFuzzy:0
[2024/8/7 9:28:58 522] [08-07 09:28:57 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:28:58 522] [08-07 09:28:57 TUYA D][simplekv.c:1386] delete key find 4
[2024/8/7 9:28:58 538] [08-07 09:28:57 TUYA D][simplekv.c:1424] Delete key:ble_app_key 4 success
[2024/8/7 9:28:58 538] [08-07 09:28:57 TUYA D][simplekv.c:203] update crc 825778106
[2024/8/7 9:28:58 538] [08-07 09:28:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:58 554] [08-07 09:28:57 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:28:58 554] [08-07 09:28:57 TUYA D][tuya_ble_api.c:1058] start to clr network_key.
[2024/8/7 9:28:58 554] [08-07 09:28:57 TUYA D][simplekv.c:1348] delete key:ble_network_key isFuzzy:0
[2024/8/7 9:28:58 570] [08-07 09:28:57 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:28:58 570] [08-07 09:28:57 TUYA D][simplekv.c:1386] delete key find 13
[2024/8/7 9:28:58 586] [08-07 09:28:57 TUYA D][simplekv.c:1424] Delete key:ble_network_key 13 success
[2024/8/7 9:28:58 586] [08-07 09:28:57 TUYA D][simplekv.c:203] update crc 1284647460
[2024/8/7 9:28:58 586] [08-07 09:28:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:58 602] [08-07 09:28:57 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:28:58 602] [08-07 09:28:57 TUYA D][tuya_ble_api.c:1035] start to clr beaconkey.
[2024/8/7 9:28:58 602] [08-07 09:28:57 TUYA D][simplekv.c:1348] delete key:ble_beaconkey isFuzzy:0
[2024/8/7 9:28:58 618] [08-07 09:28:57 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:28:58 618] [08-07 09:28:57 TUYA D][simplekv.c:1386] delete key find 14
[2024/8/7 9:28:58 634] [08-07 09:28:57 TUYA D][simplekv.c:1424] Delete key:ble_beaconkey 14 success
[2024/8/7 9:28:58 634] [08-07 09:28:57 TUYA D][simplekv.c:203] update crc 305911598
[2024/8/7 9:28:58 634] [08-07 09:28:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:58 650] [08-07 09:28:57 TUYA D][simplekv.c:1434] Delete success
[2024/8/7 9:28:58 666] [08-07 09:28:57 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":1,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:28:58 666] [08-07 09:28:57 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:28:58 666] [08-07 09:28:57 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:28:58 682] [08-07 09:28:57 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:176
[2024/8/7 9:28:58 682] [08-07 09:28:57 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:28:58 698] [08-07 09:28:57 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:28:58 698] [08-07 09:28:57 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:28:58 698] [08-07 09:28:57 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:28:58 714] [08-07 09:28:57 TUYA D][simplekv.c:203] update crc 2189703759
[2024/8/7 9:28:58 714] [08-07 09:28:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:58 714] [08-07 09:28:57 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:58 730] [08-07 09:28:57 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:28:58 730] [08-07 09:28:57 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:28:58 746] [08-07 09:28:57 TUYA D][simplekv.c:1251] find key:3 wf_start_md
[2024/8/7 9:28:58 746] [08-07 09:28:57 TUYA D][simplekv.c:1280] key:wf_start_md find value.Len:16
[2024/8/7 9:28:58 746] [08-07 09:28:57 TUYA D][tuya_svc_timer_task.c:107] reset. write_disk:1
[2024/8/7 9:28:58 762] [08-07 09:28:57 TUYA D][tuya_svc_timer_task.c:310] max len:128
[2024/8/7 9:28:58 762] [08-07 09:28:57 TUYA D][tuya_svc_timer_task.c:378] offset:27
[2024/8/7 9:28:58 777] [08-07 09:28:57 TUYA D][tuya_svc_timer_task.c:397] save TIMER:{"lastFetchTime":0,"cnt":0}
[2024/8/7 9:28:58 778] [08-07 09:28:57 TUYA D][simplekv.c:1211] read key:timer_arr isFuzzy:0 skipCnt:0
[2024/8/7 9:28:58 778] [08-07 09:28:57 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:28:58 793] [08-07 09:28:57 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:28:58 794] [08-07 09:28:57 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:28:58 809] [08-07 09:28:57 TUYA D][simplekv.c:374] write key:timer_arr And Value Len:32
[2024/8/7 9:28:58 810] [08-07 09:28:57 TUYA D][simplekv.c:415] 4 valid is false AND size old 436 >= new 32
[2024/8/7 9:28:58 810] [08-07 09:28:57 TUYA D][simplekv.c:430] find 4 available space
[2024/8/7 9:28:58 825] [08-07 09:28:57 TUYA D][simplekv.c:474] reuse available space 29740
[2024/8/7 9:28:58 825] [08-07 09:28:57 TUYA D][simplekv.c:203] update crc 2082749257
[2024/8/7 9:28:58 841] [08-07 09:28:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:58 841] [08-07 09:28:57 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:58 841] [08-07 09:28:57 TUYA D][simplekv.c:1348] delete key:last_reset_info isFuzzy:0
[2024/8/7 9:28:58 857] [08-07 09:28:57 TUYA D][simplekv.c:1354] cnt:18 delete bit arr len:1
[2024/8/7 9:28:58 857] [08-07 09:28:57 TUYA D][simplekv.c:1395] key:last_reset_info not find
[2024/8/7 9:28:58 857] [08-07 09:28:57 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:28:58 873] [08-07 09:28:57 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:28:58 873] [08-07 09:28:57 TUYA D][simplekv.c:1251] find key:5 p2p_auth_info
[2024/8/7 9:28:58 889] [08-07 09:28:57 TUYA D][simplekv.c:1280] key:p2p_auth_info find value.Len:32
[2024/8/7 9:28:58 889] [08-07 09:28:57 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:28:58 905] [08-07 09:28:57 TUYA D][simplekv.c:397] 5 key same AND size old 84 >= new 16
[2024/8/7 9:28:58 905] [08-07 09:28:57 TUYA D][simplekv.c:430] find 5 available space
[2024/8/7 9:28:58 906] [08-07 09:28:57 TUYA D][simplekv.c:474] reuse available space 30176
[2024/8/7 9:28:58 922] [08-07 09:28:57 TUYA D][simplekv.c:203] update crc 3367563832
[2024/8/7 9:28:58 922] [08-07 09:28:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:58 922] [08-07 09:28:57 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:58 939] [08-07 09:28:57 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:28:58 939] [08-07 09:28:57 TUYA D][simplekv.c:1251] find key:6 p2p_pwd
[2024/8/7 9:28:58 939] [08-07 09:28:57 TUYA D][simplekv.c:1280] key:p2p_pwd find value.Len:16
[2024/8/7 9:28:58 954] [08-07 09:28:57 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:28:58 954] [08-07 09:28:57 TUYA D][simplekv.c:397] 6 key same AND size old 84 >= new 16
[2024/8/7 9:28:58 970] [08-07 09:28:57 TUYA D][simplekv.c:430] find 6 available space
[2024/8/7 9:28:58 970] [08-07 09:28:57 TUYA D][simplekv.c:474] reuse available space 30260
[2024/8/7 9:28:58 970] [08-07 09:28:57 TUYA D][simplekv.c:203] update crc 3621146934
[2024/8/7 9:28:58 986] [08-07 09:28:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:58 986] [08-07 09:28:57 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:59 002] [08-07 09:28:57 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:28:59 002] [08-07 09:28:57 TUYA D][simplekv.c:1251] find key:7 p2p_type
[2024/8/7 9:28:59 002] [08-07 09:28:57 TUYA D][simplekv.c:1280] key:p2p_type find value.Len:16
[2024/8/7 9:28:59 018] [08-07 09:28:57 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:28:59 018] [08-07 09:28:57 TUYA D][simplekv.c:397] 7 key same AND size old 84 >= new 16
[2024/8/7 9:28:59 034] [08-07 09:28:57 TUYA D][simplekv.c:430] find 7 available space
[2024/8/7 9:28:59 034] [08-07 09:28:57 TUYA D][simplekv.c:474] reuse available space 30344
[2024/8/7 9:28:59 034] [08-07 09:28:57 TUYA D][simplekv.c:203] update crc 2485836572
[2024/8/7 9:28:59 050] [2024-08-07 09:28:57] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:59 050] [08-07 09:28:57 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:28:59 065] [08-07 09:28:57 TUYA D][simplekv.c:520] write success
[2024/8/7 9:28:59 066] IPC_APP_Reset_System_CB line(143) -------------------------- 
[2024/8/7 9:28:59 066] [08-07 09:28:57 TUYA N][mqtt_client.c:1703] mqtt close
[2024/8/7 9:28:59 066] [08-07 09:28:57 TUYA N][mqtt_client.c:839] close mqtt -->>
[2024/8/7 9:28:59 082] [08-07 09:28:57 TUYA E][log_seq.c:152] ret:-1027
[2024/8/7 9:28:59 082] [08-07 09:28:57 TUYA D][mqtt_client.c:851] shutdown fd enabled
[2024/8/7 9:28:59 082] [08-07 09:28:57 TUYA D][tuya_tls.c:1634] TUYA_TLS Disconnect ENTER
[2024/8/7 9:28:59 098] [08-07 09:28:57 TUYA D][tuya_tls.c:1689] TUYA_TLS Disconnect Success
[2024/8/7 9:28:59 098] [08-07 09:28:57 TUYA N][mqtt_client.c:886] close mqtt <<--
[2024/8/7 9:28:59 113] [08-07 09:28:57 TUYA D][mqtt_client.c:1720] mqtt fail_cnt:1, sleeptime:2249 ms
[2024/8/7 9:28:59 113] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:28:59 113] Mode(Product):0
[2024/8/7 9:28:59 113] BpuMode:[Online]
[2024/8/7 9:28:59 113] VpssMode:[Online]
[2024/8/7 9:28:59 113] [0.LimitUp_info]:
[2024/8/7 9:28:59 113] LimitUp:[Disable]
[2024/8/7 9:28:59 129] [2680*0]->[3840*0])
[2024/8/7 9:28:59 129] chn	TotalSize	ActiveSize
[2024/8/7 9:28:59 129] 0	5040*2246	2680*2160
[2024/8/7 9:28:59 129] 0	5040*2246	3840*2160
[2024/8/7 9:28:59 129] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:28:59 130] [1.VICU_info]:
[2024/8/7 9:28:59 145] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:28:59 145] 0	25.0	977	0	0	183	linear	8ddb00
[2024/8/7 9:28:59 145] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:28:59 145] en	op_type	m_chn	now
[2024/8/7 9:28:59 145] 0	1	1	1
[2024/8/7 9:28:59 145] [2.VI_info]:
[2024/8/7 9:28:59 145] chn	TotalSize	ActiveSize
[2024/8/7 9:28:59 161] 0	5040*2246	3848*2166
[2024/8/7 9:28:59 161] 1	   0*   0	   0*   0
[2024/8/7 9:28:59 161] [3.MIPI_info]:
[2024/8/7 9:28:59 161] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:28:59 161] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:28:59 177] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:28:59 177] [4.Cut_info]:
[2024/8/7 9:28:59 177] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:28:59 177] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:28:59 177] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:28:59 193] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:28:59 193] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:28:59 193] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:28:59 193] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:28:59 193] [5.IB(isp buffer info)]:
[2024/8/7 9:28:59 209] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:28:59 209] PoolId  Count  Size
[2024/8/7 9:28:59 209] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:59 225] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:59 225] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:59 241] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:28:59 241] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:28:59 257] rm: can't remove '/mnt/mtd/Config/localtime': Device or resource busy
[2024/8/7 9:28:59 257] rm: can't remove '/mnt/mtd/Config/resolv.conf': Device or resource busy
[2024/8/7 9:28:59 257] rm: can't remove '/mnt/mtd/Config': Directory not empty
[2024/8/7 9:28:59 273] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:28:59 273] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:28:59 273] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:28:59 289] 0       0         0          1          4       
[2024/8/7 9:28:59 289] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:28:59 289]      --265--            --264--                                               
[2024/8/7 9:28:59 305] Count      Line     Count      Line     
[2024/8/7 9:28:59 305] 761        480      1725       560      
[2024/8/7 9:28:59 305] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:28:59 321] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:28:59 321] 0   3840   2160    H265  0      0        0           452       983037     3        	
[2024/8/7 9:28:59 337] 1   640    360     H265  0      0        0           300       43200      0        	
[2024/8/7 9:28:59 337] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:28:59 354] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:28:59 354] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:28:59 370] 0   Y      452      0       0       15       0        452      452      624       63648         58904    115839   64595    12      
[2024/8/7 9:28:59 385] 1   Y      300      0       8       1        0        300      300      624       3022          1900     27184    2739     9       
[2024/8/7 9:28:59 401] 3   N      0        0       0       1        0        0        0        625       0             0        0        0        0       
[2024/8/7 9:28:59 401] BusyBox v1.22.1 (2020-11-27 10:15:15 CST) multi-call binary.
[2024/8/7 9:28:59 401] Usage: rm [-irf] FILE...
[2024/8/7 9:28:59 401] Remove (unlink) FILEs
[2024/8/7 9:28:59 401] 	-i	Always prompt before removing
[2024/8/7 9:28:59 401] 	-f	Never prompt
[2024/8/7 9:28:59 417] 	-R,-r	Recurse
[2024/8/7 9:28:59 417] BusyBox v1.22.1 (2020-11-27 10:15:15 CST) multi-call binary.
[2024/8/7 9:28:59 417] Usage: rm [-irf] FILE...
[2024/8/7 9:28:59 417] Remove (unlink) FILEs
[2024/8/7 9:28:59 417] 	-i	Always prompt before removing
[2024/8/7 9:28:59 417] 	-f	Never prompt
[2024/8/7 9:28:59 433] 	-R,-r	Recurse
[2024/8/7 9:28:59 433] [2024-08-07 09:28:57] utils.c(470) <WriteJsonConfig>: Create json file /mnt/mtd/Config/xm/DeviceInfo failed
[2024/8/7 9:28:59 450] [2024-08-07 09:28:57] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:57] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:59 466] set basic_indicator_onoff:0 
[2024/8/7 9:28:59 466] [2024-08-07 09:28:57] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:59 482] [2024-08-07 09:28:57] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:59 482] [2024-08-07 09:28:57] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:28:59 498] [2024-08-07 09:28:57] utils.c(470) <WriteJsonConfig>: Create json file /mnt/mtd/Config/xm/DeviceInfo failed
[2024/8/7 9:28:59 514] [2024-08-07 09:28:57] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:57] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:59 530] [2024-08-07 09:28:57] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:57] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:59 546] [2024-08-07 09:28:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:59 562] [2024-08-07 09:28:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:59 593] [2024-08-07 09:28:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:59 610] [2024-08-07 09:28:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:59 610] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(150): cmd=[killall wpa_supplicant udhcpc;ifconfig eth2 down;ifconfig eth0 down;]
[2024/8/7 9:28:59 626]  ---
[2024/8/7 9:28:59 626] curr event:13 
[2024/8/7 9:28:59 626] IPC_APP_Notify_LED_Sound_Status_CB line(583) -------------------------- IPC_RESET_SUCCESS(13)
[2024/8/7 9:28:59 642] [2024-08-07 09:28:58] tuya_ipc_system_control_demo.c(585) <IPC_APP_Notify_LED_Sound_Status_CB>: debug assertion failure (!XM_AudioTips(RESET, 0, 1, 0, 1))
[2024/8/7 9:28:59 642] --- tracepoint tuya_ipc_system_control_demo.c,IPC_APP_Reset_System_CB(155):  ---
[2024/8/7 9:28:59 658] [2024-08-07 09:28:58] xm_main.c(2440) <XMSDK_SystemRebootTY>: XMSDK_MotorGetPostion(3110,0) suc
[2024/8/7 9:28:59 674] [2024-08-07 09:28:58] xm_main.c(2064) <XM_SaveLocalPtzPosition>: Save PTZ xPosition 3110 failed
[2024/8/7 9:28:59 674] [2024-08-07 09:28:58] xm_main.c(2445) <XMSDK_SystemRebootTY>: XM_SaveLocalPtzPosition(3110,0) failed,ret=[-1]
[2024/8/7 9:28:59 690] XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:28:59 690] [2024-08-07 09:28:58] xm_main.c(2454) <XMSDK_SystemRebootTY>: XMSDK_SystemRebootTY file tuya_ipc_system_control_demo.c 156 =======
[2024/8/7 9:28:59 706] [2024-08-07 09:28:58] ==> XMSDK_SystemReboot(198)[INFO]: Sys XMSDK_SystemReboot Reboot
[2024/8/7 9:28:59 706] [2024-08-07 09:28:58] ==> XMSDK_SystemReboot(199)[INFO]: Sys Will Reboot
[2024/8/7 9:28:59 722] [2024-08-07 09:28:58] xm_musicPlayer.cpp(96) <PlayAudioTips>: play audio [/usr/share/audios/Reset_english.pcm]
[2024/8/7 9:28:59 738] [2024-08-07 09:28:58] xm_device.c(499) <XM_SetAoStatus>: g_factory_set.AudioSwap=[0]
[2024/8/7 9:28:59 738] [2024-08-07 09:28:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[75],val=[1]
[2024/8/7 9:28:59 754] [2024-08-07 09:28:58] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:28:58] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [DeviceConfig] pNumber[LightStatus]!
[2024/8/7 9:28:59 754] set basic_indicator_onoff:0 
[2024/8/7 9:28:59 770] [2024-08-07 09:28:58] tuya_ipc_dp_handler.c(262) <IPC_APP_set_basic_indicator_onoff>: SwapFlag=false
[2024/8/7 9:28:59 770] [2024-08-07 09:28:58] ==> XMSDK_GpioWrite(31)[INFO]: port=[12],val=[0]
[2024/8/7 9:28:59 786] 
[2024/8/7 9:28:59 786] [08-07 09:28:59 TUYA D][tuya_ble_api.c:1426] cloud disconnected, start adv!
[2024/8/7 9:28:59 786] [08-07 09:28:59 TUYA I][bt_ext_porting.c:628] [TUYA-BTUART]start_adv
[2024/8/7 9:28:59 802] --- tracepoint bt_ext_porting.c,tuya_ext_bt_start_adv(629): start_adv ---
[2024/8/7 9:28:59 802] [08-07 09:28:59 TUYA D][tuya_ble_api.c:1376] nw stat change:2->0, rpt to app.
[2024/8/7 9:28:59 818] [08-07 09:28:59 TUYA D][tuya_ble_api.c:817] no need to send nw stat to app
[2024/8/7 9:28:59 818] [2024-08-07 09:28:59] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time49301
[2024/8/7 9:28:59 818] [08-07 09:29:00 TUYA E][minissdpc.c:517] sendto
[2024/8/7 9:28:59 833] [08-07 09:29:00 TUYA E][minissdpc.c:517] sendto
[2024/8/7 9:28:59 849] g_AudioTipsList.size() enable: 0[2024-08-07 09:29:00] utils.c(79) <OpenJsonFile>: OpenJsonFile error[2024-08-07 09:29:00] utils.c(315) <ReadTYJsonConfig>: Open ROOT object Failed, pClass [MotionDetect] pNumber[SirenSwitch]!
[2024/8/7 9:28:59 849] [08-07 09:29:00 TUYA D][smart_frame.c:3473] dp filtered, dev no act
[2024/8/7 9:28:59 865] [2024-08-07 09:29:00] xm_musicPlayer.cpp(177) <PlayAudioTips>: match reset audio
[2024/8/7 9:28:59 865] [2024-08-07 09:29:00] xm_main.c(374) <AutoMaintenance_pro>: The time did not reach 10 seconds
[2024/8/7 9:28:59 881] [2024-08-07 09:29:01] xm_wifi.c(362) <WifiConnectCheck>: adc cfg  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:28:59 897] [2024-08-07 09:29:01] xm_wifi.c(365) <WifiConnectCheck>: camera_get_dnc_adcthr  LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:28:59 897] sendto error send_packet 108 
[2024/8/7 9:28:59 897] recvfrom Error  
[2024/8/7 9:28:59 897] FUNCTION:recv_packet	LINE:139 
[2024/8/7 9:28:59 913] [2024-08-07 09:29:01] xm_wifi.c(386) <WifiConnectCheck>: gate way is  ping res is 0 error_cnt:1
[2024/8/7 9:28:59 913] [08-07 09:29:02 TUYA D][tuya_upnp_module_mg.c:1432] upnpDiscover failed
[2024/8/7 9:29:00 601] [08-07 09:29:03 TUYA E][app_agent.c:823] sendto Fail: len:220 ret:-1,errno:-18 port:6667
[2024/8/7 9:29:01 273] xmsfc_shutdown 2 2 
[2024/8/7 9:29:01 273] Restarting system.
[2024/8/7 9:29:01 321] 
[2024/8/7 9:29:01 322] 
[2024/8/7 9:29:01 339] U-Boot 2014.04 (Dec 22 2022 - 16:31:47)
[2024/8/7 9:29:01 339] CPU: XM550V200WX2
[2024/8/7 9:29:01 339] DRAM:  128 MiB
[2024/8/7 9:29:01 449] MMC:   arasan: 0
[2024/8/7 9:29:01 497] In:    serial
[2024/8/7 9:29:01 513] Out:   serial
[2024/8/7 9:29:01 513] Err:   serial
[2024/8/7 9:29:01 721] Net:   PHY id1 0 id2 128 dwmac.10010000
[2024/8/7 9:29:01 721] Press Ctrl+C to stop autoboot
[2024/8/7 9:29:02 137] SF: 1572864 bytes @ 0x40000 Read: OK
[2024/8/7 9:29:02 137] ## Booting kernel from Legacy Image at 80007fc0 ...
[2024/8/7 9:29:02 153]    Image Name:   Linux-3.10.103+
[2024/8/7 9:29:02 153]    Image Type:   ARM Linux Kernel Image (uncompressed)
[2024/8/7 9:29:02 153]    Data Size:    1429968 Bytes = 1.4 MiB
[2024/8/7 9:29:02 153]    Load Address: 80008000
[2024/8/7 9:29:02 153]    Entry Point:  80008000
[2024/8/7 9:29:02 169]    XIP Kernel Image ... OK
[2024/8/7 9:29:02 169] Starting kernel ...
[2024/8/7 9:29:03 050] Uncompressing Linux... done, booting the kernel.
[2024/8/7 9:29:03 178] Booting Linux on physical CPU 0x0
[2024/8/7 9:29:03 194] Linux version 3.10.103+ (wangyaming@localhost.localdomain) (gcc version 4.9.2 (Buildroot 2014.08) ) #21 SMP Mon Apr 10 11:30:50 CST 2023
[2024/8/7 9:29:03 194] CPU: ARMv7 Processor [410fc051] revision 1 (ARMv7), cr=10c53c7d
[2024/8/7 9:29:03 210] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[2024/8/7 9:29:03 210] Machine: xm530v200
[2024/8/7 9:29:03 210] Memory policy: ECC disabled, Data cache writealloc
[2024/8/7 9:29:03 225] PERCPU: Embedded 7 pages/cpu @c045f000 s6336 r8192 d14144 u32768
[2024/8/7 9:29:03 226] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 13208
[2024/8/7 9:29:03 241] Kernel command line: mem=52M console=ttyAMA0,115200 root=/dev/mtdblock2 rootfstype=cramfs mtdparts=xm_sfc:256K(boot),1536K(kernel),1280K(romfs),4288K(user),832K(mtd)
[2024/8/7 9:29:03 241] PID hash table entries: 256 (order: -2, 1024 bytes)
[2024/8/7 9:29:03 257] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[2024/8/7 9:29:03 259] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[2024/8/7 9:29:03 259] Memory: 52MB = 52MB total
[2024/8/7 9:29:03 259] Memory: 48656k/48656k available, 4592k reserved, 0K highmem
[2024/8/7 9:29:03 259] Virtual kernel memory layout:
[2024/8/7 9:29:03 273]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[2024/8/7 9:29:03 273]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[2024/8/7 9:29:03 273]     vmalloc : 0xc3800000 - 0xff000000   ( 952 MB)
[2024/8/7 9:29:03 289]     lowmem  : 0xc0000000 - 0xc3400000   (  52 MB)
[2024/8/7 9:29:03 289]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[2024/8/7 9:29:03 289]       .text : 0xc0008000 - 0xc0390e34   (3620 kB)
[2024/8/7 9:29:03 289]       .init : 0xc0391000 - 0xc03b38c0   ( 139 kB)
[2024/8/7 9:29:03 305]       .data : 0xc03b4000 - 0xc03d7c20   ( 144 kB)
[2024/8/7 9:29:03 305]        .bss : 0xc03d7c20 - 0xc03f35c4   ( 111 kB)
[2024/8/7 9:29:03 305] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[2024/8/7 9:29:03 305] Hierarchical RCU implementation.
[2024/8/7 9:29:03 321] NR_IRQS:128
[2024/8/7 9:29:03 321] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[2024/8/7 9:29:03 321] Calibrating delay loop... 373.55 BogoMIPS (lpj=1867776)
[2024/8/7 9:29:03 321] pid_max: default: 32768 minimum: 301
[2024/8/7 9:29:03 337] Mount-cache hash table entries: 512
[2024/8/7 9:29:03 337] CPU: Testing write buffer coherency: ok
[2024/8/7 9:29:03 337] Setting up static identity map for 0xc031dd68 - 0xc031ddc0
[2024/8/7 9:29:03 337] L310 cache controller enabled
[2024/8/7 9:29:03 353] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32420000, Cache size: 131072 B
[2024/8/7 9:29:03 353] CPU1: Booted secondary processor
[2024/8/7 9:29:03 353] Brought up 2 CPUs
[2024/8/7 9:29:03 353] SMP: Total of 2 processors activated (747.11 BogoMIPS).
[2024/8/7 9:29:03 369] CPU: All CPU(s) started in SVC mode.
[2024/8/7 9:29:03 369] NET: Registered protocol family 16
[2024/8/7 9:29:03 369] DMA: preallocated 256 KiB pool for atomic coherent allocations
[2024/8/7 9:29:03 369] Serial: AMBA PL011 UART driver
[2024/8/7 9:29:03 385] uart:0: ttyAMA0 at MMIO 0x10030000 (irq = 32) is a PL011 rev1
[2024/8/7 9:29:03 385] console [ttyAMA0] enabled
[2024/8/7 9:29:03 385] uart:1: ttyAMA1 at MMIO 0x10040000 (irq = 33) is a PL011 rev1
[2024/8/7 9:29:03 401] uart:2: ttyAMA2 at MMIO 0x10050000 (irq = 34) is a PL011 rev1
[2024/8/7 9:29:03 417] bio: create slab <bio-0> at 0
[2024/8/7 9:29:03 417] usbcore: registered new interface driver usbfs
[2024/8/7 9:29:03 433] usbcore: registered new interface driver hub
[2024/8/7 9:29:03 433] usbcore: registered new device driver usb
[2024/8/7 9:29:03 433] Switching to clocksource arm_global_timer
[2024/8/7 9:29:03 449] NET: Registered protocol family 2
[2024/8/7 9:29:03 449] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:29:03 449] TCP bind hash table entries: 512 (order: 0, 4096 bytes)
[2024/8/7 9:29:03 465] TCP: Hash tables configured (established 512 bind 512)
[2024/8/7 9:29:03 465] TCP: reno registered
[2024/8/7 9:29:03 465] UDP hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:29:03 465] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[2024/8/7 9:29:03 465] NET: Registered protocol family 1
[2024/8/7 9:29:03 481] RPC: Registered named UNIX socket transport module.
[2024/8/7 9:29:03 481] RPC: Registered udp transport module.
[2024/8/7 9:29:03 481] RPC: Registered tcp transport module.
[2024/8/7 9:29:03 497] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2024/8/7 9:29:03 513] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[2024/8/7 9:29:03 513] NFS: Registering the id_resolver key type
[2024/8/7 9:29:03 513] Key type id_resolver registered
[2024/8/7 9:29:03 513] Key type id_legacy registered
[2024/8/7 9:29:03 529] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[2024/8/7 9:29:03 529] fuse init (API version 7.22)
[2024/8/7 9:29:03 529] msgmni has been set to 95
[2024/8/7 9:29:03 545] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[2024/8/7 9:29:03 545] io scheduler noop registered
[2024/8/7 9:29:03 545] io scheduler deadline registered (default)
[2024/8/7 9:29:03 545] io scheduler cfq registered
[2024/8/7 9:29:03 561] dma-pl330 dma-pl330: Loaded driver for PL330 DMAC-267056
[2024/8/7 9:29:03 561] dma-pl330 dma-pl330: 	DBUFF-32x8bytes Num_Chans-4 Num_Peri-24 Num_Events-4
[2024/8/7 9:29:03 577] uart-pl011 uart:0: no DMA platform data
[2024/8/7 9:29:03 577] uart-pl011 uart:1: no DMA platform data
[2024/8/7 9:29:03 577] uart-pl011 uart:2: no DMA platform data
[2024/8/7 9:29:03 593] brd: module loaded
[2024/8/7 9:29:03 593] XMSFCV2: flash name:XM25QH64C size:0x800000
[2024/8/7 9:29:03 609] 5 cmdlinepart partitions found on MTD device xm_sfc
[2024/8/7 9:29:03 609] Creating 5 MTD partitions on "xm_sfc":
[2024/8/7 9:29:03 609] 0x000000000000-0x000000040000 : "boot"
[2024/8/7 9:29:03 625] 0x000000040000-0x0000001c0000 : "kernel"
[2024/8/7 9:29:03 625] 0x0000001c0000-0x000000300000 : "romfs"
[2024/8/7 9:29:03 625] 0x000000300000-0x000000730000 : "user"
[2024/8/7 9:29:03 641] 0x000000730000-0x000000800000 : "mtd"
[2024/8/7 9:29:03 641] PPP generic driver version 2.4.2
[2024/8/7 9:29:03 641] NET: Registered protocol family 24
[2024/8/7 9:29:03 641] usbcore: registered new interface driver asix
[2024/8/7 9:29:03 657] usbcore: registered new interface driver cdc_ether
[2024/8/7 9:29:03 657] usbcore: registered new interface driver rndis_host
[2024/8/7 9:29:03 657] XMMMAC driver:
[2024/8/7 9:29:03 657] 	platform registration... 
[2024/8/7 9:29:03 657] 	done!
[2024/8/7 9:29:03 673] 	eth0 - (dev. name: xmmaceth - id: -1, IRQ #35
[2024/8/7 9:29:03 673] 	IO base addr: 0xfe010000)
[2024/8/7 9:29:03 673] libphy: XMMMAC MII Bus: probed
[2024/8/7 9:29:03 673] eth0: PHY ID 00000128 at 0 IRQ 0 (0:00)
[2024/8/7 9:29:03 690] eth0: PHY ID 00000128 at 1 IRQ 0 (0:01) active
[2024/8/7 9:29:03 690] usbcore: registered new interface driver cdc_acm
[2024/8/7 9:29:03 690] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[2024/8/7 9:29:03 706] usbcore: registered new interface driver usbserial
[2024/8/7 9:29:03 706] usbcore: registered new interface driver option
[2024/8/7 9:29:03 706] usbserial: USB Serial support registered for GSM modem (1-port)
[2024/8/7 9:29:03 722] usbcore: registered new interface driver qcserial
[2024/8/7 9:29:03 722] usbserial: USB Serial support registered for Qualcomm USB modem
[2024/8/7 9:29:03 722] TCP: cubic registered
[2024/8/7 9:29:03 722] NET: Registered protocol family 17
[2024/8/7 9:29:03 738] Key type dns_resolver registered
[2024/8/7 9:29:03 738] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5 rev 1
[2024/8/7 9:29:03 738] registered taskstats version 1
[2024/8/7 9:29:03 754] VFS: Mounted root (cramfs filesystem) readonly on device 31:2.
[2024/8/7 9:29:03 754] Freeing unused kernel memory: 136K (c0391000 - c03b3000)
[2024/8/7 9:29:04 105] mount: mounting /dev/mtdblock3 on /usr failed: Invalid argument
[2024/8/7 9:29:04 633] arasan_set_clock:
[2024/8/7 9:29:04 649] 	new freq 400000
[2024/8/7 9:29:04 665] mmc0: driver initialized... IRQ: 73, Base addr 0xc3a00000
[2024/8/7 9:29:04 681] arasan_set_clock:
[2024/8/7 9:29:04 714] 	new freq 300000arasan_set_clock:
[2024/8/7 9:29:04 730] 	new freq 200000MEM_START=0x83400000 MEM_LEN=0x04c00000
[2024/8/7 9:29:04 745] [reg] = 0x20000000,[val]= 0x00000001
[2024/8/7 9:29:04 745] [reg] = 0x20000054,[val]= 0x00000703
[2024/8/7 9:29:04 761] [reg] = 0x20000074,[val]= 0xc103c103
[2024/8/7 9:29:04 762] [reg] = 0x20000078,[val]= 0xc103c0arasan_set_clock:
[2024/8/7 9:29:04 762] 	new freq 195312ff
[2024/8/7 9:29:04 762] [reg] = 0x2000007c,[val]= 0x0000c107
[2024/8/7 9:29:04 762] [reg] = 0x20000000,[val]= 0x00000000
[2024/8/7 9:29:04 777] [reg] = 0x20050490,[val]= 0x00000001
[2024/8/7 9:29:04 777] [reg] = 0x20050540,[val]= 0x000000i2c: module license 'Proprietary' taints kernel.
[2024/8/7 9:29:04 777] 01
[2024/8/7 9:29:04 777] [reg] = 0x20Disabling lock debugging due to kernel taint
[2024/8/7 9:29:04 793] 0505f0,[val]= 0x00000001
[2024/8/7 9:29:04 794] i2c init is ok!
[2024/8/7 9:29:04 794] mmz: init ok start=0x83400000, size=0x4c00000
[2024/8/7 9:29:04 921] IspKo: build: Dec  9 2023 09:35:12
[2024/8/7 9:29:04 985] hevc init [buid Dec  6 2022 10:03:10]...
[2024/8/7 9:29:05 001] jpeg init...buid:Nov 16 2023 14:18:12
[2024/8/7 9:29:05 017] insmod: can't insert 'rtc.ko': No such file or directory
[2024/8/7 9:29:05 050] acodec init is ok!
[2024/8/7 9:29:05 050] i2s clk:2048000Hz
[2024/8/7 9:29:05 209] dwc2 dwc2.0: conf AHB burst incr+
[2024/8/7 9:29:05 209] dwc2 dwc2.0: DWC OTG Controller
[2024/8/7 9:29:05 225] dwc2 dwc2.0: new USB bus registered, assigned bus number 1
[2024/8/7 9:29:05 225] dwc2 dwc2.0: irq 76, io mem 0x50300000
[2024/8/7 9:29:05 225] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[2024/8/7 9:29:05 225] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[2024/8/7 9:29:05 241] usb usb1: Product: DWC OTG Controller
[2024/8/7 9:29:05 241] usb usb1: Manufacturer: Linux 3.10.103+ dwc2_hsotg
[2024/8/7 9:29:05 241] usb usb1: SerialNumber: dwc2.0
[2024/8/7 9:29:05 258] hub 1-0:1.0: USB hub found
[2024/8/7 9:29:05 258] hub 1-0:1.0: 1 port detected
[2024/8/7 9:29:05 289] xm_wdt init is ok
[2024/8/7 9:29:05 305] nn_kernel: XM530V200 build time Jun 10 2022, driver V1.0.0
[2024/8/7 9:29:05 609] nn_kernel: NN: request mem  fail
[2024/8/7 9:29:05 609] nn_kernel: addr iomap fail
[2024/8/7 9:29:05 656] insmod: can't insert '/usr/lib/modules/xm_nn.ko': Device or resource busy
[2024/8/7 9:29:05 961] usb 1-1: new high-speed USB device number 3 using dwc2
[2024/8/7 9:29:06 169] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:29:06 185] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:29:06 185] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:29:06 185] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:29:06 232] /usr/etc/loadmod: /usr/etc/loadpublic: line 106: /mnt/mtd/user.sh: not found
[2024/8/7 9:29:06 232] usbwifi_init.
[2024/8/7 9:29:06 233] PDN pin is low, ouput high and delay 2 sec. gpio:87 : 0x0
[2024/8/7 9:29:06 264] max_degree: 440, 190; max_steps: 5006, 2161
[2024/8/7 9:29:06 280] exfatfsck 1.3.0
[2024/8/7 9:29:06 296] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:29:06 296] exfatfsck 1.3.0
[2024/8/7 9:29:06 297] Copyright (C) 2011-2018  Andrew Nayenko
[2024/8/7 9:29:06 362] usb 1-1: USB disconnect, device number 3
[2024/8/7 9:29:08 233] ouput high and delay 2000ms
[2024/8/7 9:29:08 329] Auto login as root ...
[2024/8/7 9:29:08 361] (none) login: not found /dev/mmcxxx  
[2024/8/7 9:29:08 378] Tcp server success, Wait connet ...
[2024/8/7 9:29:08 393] Get xmauto Fialed ,xmauto = 1
[2024/8/7 9:29:08 393] auto start to app 
[2024/8/7 9:29:08 409] macGuarder: Get telnetctrl Fialed, telnetctrl=0
[2024/8/7 9:29:08 426] macGuarder: Close telnetd Forever 
[2024/8/7 9:29:08 697] usb 1-1: new high-speed USB device number 4 using dwc2
[2024/8/7 9:29:08 905] usb 1-1: New USB device found, idVendor=007a, idProduct=6052
[2024/8/7 9:29:08 905] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[2024/8/7 9:29:08 905] usb 1-1: Product: AltoBeam_WIFI
[2024/8/7 9:29:08 921] usb 1-1: Manufacturer: AltoBeam inc.
[2024/8/7 9:29:10 264] [atbm_log]:atbm_usb_module_init 0
[2024/8/7 9:29:10 281] [atbm_log]:platform_init(253)
[2024/8/7 9:29:10 281] [atbm_log]:SVN_VER=33341,DPLL_CLOCK=1,BUILD_TIME=[2024-04-03_14:40:53]
[2024/8/7 9:29:10 297] [atbm_log]:Probe called -1 v1
[2024/8/7 9:29:10 297] [atbm_log]:not CONFIG_USE_DMA_ADDR_BUFFER
[2024/8/7 9:29:10 297] [atbm_log]:CONFIG_TX_NO_CONFIRM
[2024/8/7 9:29:10 297] wiphy_new_nm support CONFIG_WIRELESS_EXT 
[2024/8/7 9:29:10 313] [atbm_log]:Allocated hw_priv @ c1d89960
[2024/8/7 9:29:10 313] [atbm_log]: wait_event_interruptible from  send_prbresp_wq
[2024/8/7 9:29:10 330] [atbm_log]:atbmwifi USB_USE_TASTLET_TXRX enable (c1d89960)
[2024/8/7 9:29:10 330] [atbm_log]:not support ldpc & ht40!
[2024/8/7 9:29:10 345] [atbm_log]:atbm_get_chiptype, chipver=0x5a, g_wifi_chip_type[14]
[2024/8/7 9:29:10 345] [atbm_log]:atbm_before_load_firmware++
[2024/8/7 9:29:10 345] [atbm_log]:+++++++++++++++++1.1v++++++++++++++++++
[2024/8/7 9:29:10 361] [atbm_log]:===================~_~====================
[2024/8/7 9:29:10 361] [atbm_log]:atbm_start_load_firmware++
[2024/8/7 9:29:10 361] [fwhdr->flags 34353678 sram_addr 9022000
[2024/8/7 9:29:10 361] 1970-01-01 00:00[atbm_log]:
[2024/8/7 9:29:10 376] ======>>> load WIFI BLE COMB firmware <<<======
[2024/8/7 9:29:10 377] 
[2024/8/7 9:29:10 377] :07] <json_parse[atbm_log]:START DOWNLOAD ICCM=========
[2024/8/7 9:29:10 377] .c> ==> XMJSON_P[atbm_log]:atbm_load_firmware_generic: addr 60000: len 20000
[2024/8/7 9:29:10 392] arseExVb(526)[ERROR]: Get Vb object error!
[2024/8/7 9:29:10 392] [1970-01-01 00:00:07] <xm_system.c> ==> XMSDK_ParseJson(48)[ERROR]: Parse Vb Failed!
[2024/8/7 9:29:10 408] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(452)[ERROR]: Get Isp object u32Flag error set value 1!
[2024/8/7 9:29:10 409] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(464)[ERROR]: Get Isp object u32Others error set value 0!
[2024/8/7 9:29:10 424] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(476)[ERROR]: Get Isp object CmosPort error set value 0!
[2024/8/7 9:29:10 440] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_ParseIsp(488)[ERROR]: Get Isp object splice_mode error set value 0!
[2024/8/7 9:29:10 441] [1970-01-01 00:00:06] MainApp.c(1802) <main>: build @Jul 31 2024 13:28:12
[2024/8/7 9:29:10 456] [1970-01-01 00:00:06] MainApp.c(1710) <SetLogLevel>: set Sofia log level 2 suceess
[2024/8/7 9:29:10 456] [1970-01-01 00:00:06] ==> XMSDK_SetLogLevel(226)[NOTICE]: set xmsdk log 4
[2024/8/7 9:29:10 473] [1970-01-01 00:00:07] xm_log.c(100) <XM_RegisterLogAndInit>: Register Log level 2
[2024/8/7 9:29:10 473] [1970-01-01 00:00:07] xm_hwinfo.c(162) <XM_HwinfoInit>: Sync hwinfo to Hwfile success!
[2024/8/7 9:29:10 488] Get Hw info: AppId [fvijo8jvloagv1gm], license [uuidcaab27b0a838d239], mac[j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:29:10 504] [1970-01-01 00:00:07] utils.c(974) <ReadJsonConfig>: Have not find pClass [DeviceGpio] pNumber [NetStatusLedGpio]
[2024/8/7 9:29:10 504] [1970-01-01 00:00:07] xm_device.c(226) <ParseDeviceJsonFile>: Get g_NetStatusLed [0] failed
[2024/8/7 9:29:10 520] **********************************************************************
[2024/8/7 9:29:10 520] |                      SYSTEM INFO                                       
[2024/8/7 9:29:10 520] |       product type:		RC50X80
[2024/8/7 9:29:10 520] |           DSP chip:		XM550V200
[2024/8/7 9:29:10 536] |          wifi type:		ATBM6062U
[2024/8/7 9:29:10 536] |             HW mac:		90314ba51650
[2024/8/7 9:29:10 537] |        git version:		a590e8b3
[2024/8/7 9:29:10 537] |          make time:		20240731132812
[2024/8/7 9:29:10 553] **********************************************************************
[2024/8/7 9:29:10 553] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(143)[INFO]: SensorSrcFrmRate = 25
[2024/8/7 9:29:10 553] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(137)[INFO]: SensorIFS = 0
[2024/8/7 9:29:10 569] [1970-01-01 00:00:07] ==> XMJSON_ParseVi(156)[INFO]: Vi CapW 2680, CapH 2160, CapX 0, CapY 0
[2024/8/7 9:29:10 585] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 0: size=[3840, 2160] @3
[2024/8/7 9:29:10 585] atbm_log]:START DOWNLOAD DCCM=========
[2024/8/7 9:29:10 585] 2m[1970-01-01 00[atbm_log]:atbm_load_firmware_generic: addr 800000: len d000
[2024/8/7 9:29:10 601] :00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 1: size=[640, 360] @3
[2024/8/7 9:29:10 601] [1970-01-01 00:00:07] ==> XMJSON_ParseViX(110)[INFO]: ViChn 2: size=[640, 224] @3
[2024/8/7 9:29:10 617] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(406)[INFO]: ISPRsltType
[2024/8/7 9:29:10 617] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(428)[INFO]: ISPRsltType 0
[2024/8/7 9:29:10 633] [1970-01-01 00:00:07] ==> XMJSON_ParseIsp(442)[INFO]: ISPRsltType
[2024/8/7 9:29:10 634] [1970-01-01 00:00:07] <json_parse.c> ==> XMJSON_Parse4gMoudle(500)[WARN]: Get 4GModule object error!
[2024/8/7 9:29:10 649] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(80)[NOTICE]: ISP=> Svtd: PAL
[2024/8/7 9:29:10 649] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(81)[NOTICE]: ISP=>RsltType: 0
[2024/8/7 9:29:10 665] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(84)[NOTICE]: IRCut: gpio 19534 Swap 0
[2024/8/7 9:29:10 665] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(88)[NOT[atbm_log]:START DOWNLOAD BLE SRAM=========
[2024/8/7 9:29:10 681] ICE]: Infrared: [atbm_log]:atbm_load_firmware_generic: addr 9022000: len 10000
[2024/8/7 9:29:10 681] gpio 0 swap 1
[2024/8/7 9:29:10 681] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(92)[NOTICE]: WLight: gpio 11 swap 0
[2024/8/7 9:29:10 697] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(96)[NOTICE]: IRLight: gpio 10 swap 0
[2024/8/7 9:29:10 697] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(99)[NOTICE]: Vi: sensorIFS=0 sensorFPS=25, capW=2680,capH=2160,capX=0,capY=0
[2024/8/7 9:29:10 713] 
[2024/8/7 9:29:10 713] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(100)[NOTICE]: ViChn  ImageSize      vbBlk
[2024/8/7 9:29:10 728] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    0  [3840, 2160]    3
[2024/8/7 9:29:10 728] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    1  [ 640,  360]    2
[2024/8/7 9:29:10 745] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(105)[NOTICE]:    2  [ 640,  224]    2
[2024/8/7 9:29:10 745] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(107)[NOTICE]: VencChn    MaxSize   PreReleaseVb
[2024/8/7 9:29:10 761] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    0   [3840, 2160]	 false
[2024/8/7 9:29:10 761] [1970-01-01 00:00:07] ==> XMSDK_ParseJson(113)[NOTICE]:    1   [ 640,  360]	 false
[2024/8/7 9:29:10 776] [1970-0[atbm_log]:atbm_after_load_firmware++
[2024/8/7 9:29:10 776] i2c_write timeout 0x2
[2024/8/7 9:29:10 776] 1-01 00:00:07] =[atbm_log]:alloc urb work
[2024/8/7 9:29:10 776] => XMSDK_ParseJs[atbm_log]:usb:try to flush rx....
[2024/8/7 9:29:10 777] on(116)[NOTICE]: 4GModule: gpio 0 Swap 0
[2024/8/7 9:29:10 792] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: AudioSwap: 0
[2024/8/7 9:29:10 793] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(656)[INFO]: AudioSwap=[0]
[2024/8/7 9:29:10 808] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: HighAdcValue: 0
[2024/8/7 9:29:10 809] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: LowAdcValue: 02c_write timeout 0x2
[2024/8/7 9:29:10 809] 39m
[2024/8/7 9:29:10 824] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: IRLightLevel: 0
[2024/8/7 9:29:10 825] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: InfraredSwap: 0
[2024/8/7 9:29:10 840] [1970-01-01 00:00:07DEBUG: [libispapp]:Jul  5 2024 16:14:06 ,GENERAL
[2024/8/7 9:29:10 841] DEBUG: Vstd_init	[ PAL ]
[2024/8/7 9:29:10 841] DEBUG: RsltSns0	[ 8 ]
[2024/8/7 9:29:10 841] DEBUG: Dsp:		[0x0][ CHIPV200 ]
[2024/8/7 9:29:10 856] DEBUG: [libsns]:Jul  5 2024 16:13:32 ,GENERAL
[2024/8/7 9:29:10 873] [atbm_log]:flush rx[-110][0]
[2024/8/7 9:29:10 889] [atbm_log]:0x1610102c=0x4300a
[2024/8/7 9:29:10 889] [atbm_log]:0x1610102c=0x6300b
[2024/8/7 9:29:10 889] [atbm_log]:0x16101000=0x0
[2024/8/7 9:29:10 889] [atbm_log]:set_block_size=256
[2024/8/7 9:29:10 889] [atbm_log]:mdelay wait wsm_startup_done  !!
[2024/8/7 9:29:10 905] [atbm_log]:firmwareCap 31e9
[2024/8/7 9:29:10 905] [atbm_log]:firmwareCap2 1b8c
[2024/8/7 9:29:10 905] [atbm_log]:wsm_caps.firmwareCap 1b8c31e9 16[atbm_log]:apollo wifi WSM init done.
[2024/8/7 9:29:10 905]    Input buffers: 32 x 1632 bytes
[2024/8/7 9:29:10 905]    Hardware: 7.21
[2024/8/7 9:29:10 937]    WSM firmware [=MODEM=DPLL24M+BLE+plat=4 ApSleep 2GHZ Jan 30 2024 10:58:03], ver: 19514, build: 6431, api: 1060, cap: 0x1B8C31E9 Config[31010]  expection 900c094, ep0 cmd addr 901b340 NumOfStations[0x10] NumOfInterfaces[3]
[2024/8/7 9:29:10 937] i2c_write timeout 0x2
[2024/8/7 9:29:10 937] [atbm_log]:EFUSE(8)				[0]
[2024/8/7 9:29:10 937] [atbm_log]:EFUSE(I)					[0]
[2024/8/7 9:29:10 937] [atbm_log]:EFUSE(B)			[0]
[2024/8/7 9:29:10 952] [atbm_log]:CAPABILITIES_ATBM_PRIVATE_IE      [0]
[2024/8/7 9:29:10 952] [atbm_log]:CAPABILITIES_NVR_IPC              [0]
[2024/8/7 9:29:10 952] i2c_write timeout 0x2
[2024/8/7 9:29:10 952] [atbm_log]:CAPABILITIES_NO_CONFIRM           [1]
[2024/8/7 9:29:10 952] [atbm_log]:CAPABILITIES_WOW                  [0]
[2024/8/7 9:29:10 968] [atbm_log]:CAPABILITIES_NO_BACKOFF           [1]
[2024/8/7 9:29:10 968] [atbm_log]:CAPABILITIES_CFO                  [1]
[2024/8/7 9:29:10 968] [atbm_log]:CAPABILITIES_CHIP_FLAG            [1]
[2024/8/7 9:29:10 985] [atbm_log]:CAPABILITIES_TXCAL                [1]
[2024/8/7 9:29:10 985] DEBUG: SC[atbm_log]:CAPABILITIES_HIF_TRACE       		[0]
[2024/8/7 9:29:10 985] 831HAI! Chn:0
[2024/8/7 9:29:10 985]  tbm_log]:CAPABILITIES_FORCE_PM_ACTIVE      [0]
[2024/8/7 9:29:11 001] [m[atbm_log]:CAPABILITIES_SMARTCONFIG          [0]
[2024/8/7 9:29:11 002] [atbm_log]:CAPABILITIES_ETF                  [1]
[2024/8/7 9:29:11 002] [atbm_log]:CAPABILITIES_BLE		  			[1]
[2024/8/7 9:29:11 002] [atbm_log]:CAPABILITIES_40M			  		[0]
[2024/8/7 9:29:11 002] [atbm_log]:CAPABILITIES_LDPC 		  		[0]
[2024/8/7 9:29:11 018] [atbm_log]:CAPABILITIES_NAV_ENABLE              [0]
[2024/8/7 9:29:11 018] [atbm_log]:CAPABILITIES_USB_RECOVERY_BUG     [0]
[2024/8/7 9:29:11 018] DEBUG: Is[atbm_log]:CAPABILITIES_USE_IPC              [1]
[2024/8/7 9:29:11 033] pNum[1[atbm_log]:CAPABILITIES_OUTER_PA             [0]
[2024/8/7 9:29:11 033] [atbm_log]:CAPABILITIES_WFA    [0]
[2024/8/7 9:29:11 033] [atbm_log]:CAPABILITIES_EAP_GROUP_REKEY  [0]
[2024/8/7 9:29:11 033] [atbm_log]:CAPABILITIES_RTS_LONG_DURATION    [1]
[2024/8/7 9:29:11 033] ]
[2024/8/7 9:29:11 049] DEB[atbm_log]:CAPABILITIES_TX_CFO_PPM_CORRECTION[1]
[2024/8/7 9:29:11 049] UG: IspChn:[ [atbm_log]:CAPABILITIES_RXCAL       [1]
[2024/8/7 9:29:11 049] 0 atbm_log]:CAPABILITIES_HW_CHECKSUM          [0]
[2024/8/7 9:29:11 049] 35m]
[2024/8/7 9:29:11 065] [atbm_log]:CAPABILITIES_80211_TO_8023 [1]
[2024/8/7 9:29:11 065] DEBUG: I2CChn:[ [atbm_log]:CAPABILITIES_NEW_CHIPER  [1]
[2024/8/7 9:29:11 065] 0  tbm_log]:CONFIG_PRODUCT_TEST_USE_FEATURE_ID [0]
[2024/8/7 9:29:11 065] [1;35m]
[2024/8/7 9:29:11 081] atbm_log]:CONFIG_PRODUCT_TEST_USE_GOLDEN_LED [1]
[2024/8/7 9:29:11 081] [atbm_log]:LMAC NOT SUPPORT 40M !!!
[2024/8/7 9:29:11 081] [atbm_log]:LMAC NOT SUPPORT LDPC !!!
[2024/8/7 9:29:11 097] DEBUG: -------------SC831Hai 4K 30fps init ok! (20240322)-------------
[2024/8/7 9:29:11 097] DEBUG: camera_set_saved_status OK!
[2024/8/7 9:29:11 097] DEBUG: [libautoscene]:Jul  5 2024 16:13:42 ,GENERAL
[2024/8/7 9:29:11 113] DEBUG: [libautoscene]:use libfvideo!
[2024/8/7 9:29:11 113] DEBUG: [libfvideo]:Jul  5 2024 15:41:09 
[2024/8/7 9:29:11 113] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:29:11 129] DEBUG: [libsdnc]:Aug 22 2IspKo: clean cut!
[2024/8/7 9:29:11 129] 023 13:55:14
[2024/8/7 9:29:11 129] DEBUG: LED: [IR] 
[2024/8/7 9:29:11 129] DEBUG: software LED
[2024/8/7 9:29:11 129] DEBUG: hardware pohtoR!
[2024/8/7 9:29:11 129] DEBUG: isp_sample over!
[2024/8/7 9:29:11 145] DEBUG: autoscene chn[0]: color!
[2024/8/7 9:29:11 145] ] ==> XMJSON_GetInt(570)[INFO]: WhiteLightLevel: 0
[2024/8/7 9:29:11 145] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoHorizontalFlipGun: 0
[2024/8/7 9:29:11 161] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: VideoVerticalFlipGIspKo: set cut 0x0 0xf00 0x1 0x871
[2024/8/7 9:29:11 161] un: 0
[2024/8/7 9:29:11 177] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: setMonocular: 1
[2024/8/7 9:29:11 177] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedX: 17
[2024/8/7 9:29:11 192] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: MotorSpeedY: 17
[2024/8/7 9:29:11 193] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: soundValue: 50
[2024/8/7 9:29:11 193] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: lightChannel: 0
[2024/8/7 9:29:11 208] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: dayAndNightMode: 0
[2024/8/7 9:29:11 208] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: hardAndSoftLight: 1
[2024/8/7 9:29:11 225] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeX: 400
[2024/8/7 9:29:11 225] [1970-01-01 00:00:07] ==> XMJSON_GetInt(570)[INFO]: ScreenStepSizeY: 200
[2024/8/7 9:29:11 240] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(587)[INFO]: RatioOfGear: 1:1
[2024/8/7 9:29:11 241] [1970-01-01 00:00:07] ==> XMJSON_GetRatio(593)[INFO]: high 1: low 1
[2024/8/7 9:29:11 257] [1970-01-01 00:00:07] ==> XMJSON_ParseFactoryFile(690)[INFO]: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:29:11 272] [1970-01-01 00:00:07] xm_main.c(345) <AutoMaintenance_pro>: Set device auto mantenance time: -001_-1_-1 02:25:26 wenkday: Tuesday
[2024/8/7 9:29:11 288] [1970-01-01 00:00:07] xm_main.c(462) <GetVideoResolution>: Video resolution: captrue width 2680 height 2160 resolution main: width 3840 height 2160 extra:  width 640 height 360 [2]: width 640 height 224
[2024/8/7 9:29:11 289] [1970-01-01 00:00:07] utils.c(760[atbm_log]:wsm_generic_confirm:status(2)
[2024/8/7 9:29:11 305] ) <ReadJsonConfi[atbm_log]:<WARNING> wsm_write_mib fail !!! mibId=4132
[2024/8/7 9:29:11 305] g>: Get pClass:A[atbm_log]:apollo wifi : can't open /data/.mac.info
[2024/8/7 9:29:11 321] utoMantence pFil[atbm_log]:efuse data is [0x1,0x38,0x15,0x16,0x16,0x8,0x0,0x0,0x90:0x31:0x4b:0xa5:0x16:0x50]
[2024/8/7 9:29:11 321] eName:/mnt/mtd/C[atbm_log]:apollo wifi : can't open /tmp/atbm_txpwer_dcxo_cfg.txt
[2024/8/7 9:29:11 321] onfig/xm/DeviceInfo object error[atbm_log]:win txpower:0!
[2024/8/7 9:29:11 321] [197
[2024/8/7 9:29:11 336] [atbm_log]:use default power
[2024/8/7 9:29:11 337] 0-01-01 00:00:07] xm_main.c(349) <AutoMaintenance_pro>: Get Last AutoMantence Date [] failed
[2024/8/7 9:29:11 352] [1970-01-01 00:00:07] MainApp.c(1812) <main>: version , date 20240724, time 182054, plus 0
[2024/8/7 9:29:11 368] [1970-01-01 00:00:07] ==> XMSDK_StartUp(174)[INFO]: XMSDK_StartUp enter, J[atbm_log]:apollo wifi : can't open /tmp/set_rate_power.txt
[2024/8/7 9:29:11 369] ul 24 2024, 18:20:55
[2024/8/7 9:29:11 369] atbm_log]:==read success==
[2024/8/7 9:29:11 369] 0;39m
[2024/8/7 9:29:11 369] [1[atbm_log]:set delta power
[2024/8/7 9:29:11 384] 970-01-01 00:00:07] ==> IspConfigInit(158)[INFO]: maxHeight 2160 maxWidth 3840 u32RsltType 8
[2024/8/7 9:29:11 384] [1970-01-01 00:00:07] ==> XMSDK_StartUp(203)[INFO]: g_stPr[atbm_log]:get chip id [0][0][0] 
[2024/8/7 9:29:11 400] oductMgr.viMgr.c[atbm_log]:current chiptype ATBM6062-U20-noLDPC 
[2024/8/7 9:29:11 402] apW =[2680] g_st[atbm_log]:default country code:00,support channel=14
[2024/8/7 9:29:11 402] ProductMgr.viMgr.capH = [atbm_log]:Use an internal power amplifier!
[2024/8/7 9:29:11 402] [2160]
[2024/8/7 9:29:11 416] [atbm_log]:enable sg
[2024/8/7 9:29:11 416] [1970-01-01 00:0[atbm_log]:[eth2] has been disabled
[2024/8/7 9:29:11 432] 0:07] ==> XMSDK_StartUp(220)[INFO]: g_stProductMgr.vencMgr.vencChn[0].maxHeight =[2160] g_stProductMgr.encMgr.vencChn[0].maxWidth = [3840]
[2024/8/7 9:29:11 432] [1970-01-01 00:00:07] ==> XM[atbm_log]:enable sg
[2024/8/7 9:29:11 432] SDK_StartUp(286)[atbm_log]:[p2p0] has been disabled
[2024/8/7 9:29:11 432] [INFO]: ispCfg.u32Others 0x0
[2024/8/7 9:29:11 464] [1970-01-01 00:00:07] ==> XMSDK_StartUp(288)[INFO]: ispCfg.u32FunExt 0x0 u32Infrared 0x80000000 u32snsRsltType 0x0 u32RsltType 0x8 au32IrCut 0x80004c4e  au32SoftLed[0]: 0x800b0a1[atbm_log]:ble start
[2024/8/7 9:29:11 464] 1 u32Flag: 0x1 SensorRst[atbm_log]:[ALTOBEAM-ble_recv] start
[2024/8/7 9:29:11 464] IO: 0x800000a4 u[atbm_log]:ble subscribe
[2024/8/7 9:29:11 464] [atbm_log]:[ALTOBEAM-ble_xmit] start
[2024/8/7 9:29:11 480] atbm_log]:ble_platform_probe(c1ec3940)
[2024/8/7 9:29:11 480] m[1970-01-01 00:[atbm_log]:is registered as 'ALTOBEAM'
[2024/8/7 9:29:11 480] 00:07] ==> Sampl[atbm_log]:[atbm_wtd]:set wtd_probe = 1
[2024/8/7 9:29:11 496] eCreate(1709)[INusbcore: registered new interface driver atbm_wlan
[2024/8/7 9:29:11 496] FO]: viChn:0 vstd:0 enter
[2024/8/7 9:29:11 496] [1970-01-01 00:00:07] ==> ViChnConfig(866)[INFO]: set vichn 0 size [3840, 2160]
[2024/8/7 9:29:11 512] [1970-01-01 00:00:07] ==> ViChnConfig(866)[INFO]: set vichn 1 size [640, 360]
[2024/8/7 9:29:11 512] [1970-01-01 00:00:07] ==> ViChnConfig(866)[INFO]: set vichn 2 size [640, 224]
[2024/8/7 9:29:11 528] [1970-01-01 00:00:07] ==> VencChCreate(1058)[INFO]: channel:0 enter
[2024/8/7 9:29:11 528] [1970-01-01 00:00:07] ==> VencChCreate(1079)[INFO]: VcChn[0].vencMem = VENCMEM_MICRO
[2024/8/7 9:29:11 544] [1970-01-01 00:00:07] ==> COMM_VENC_Start(890)[INFO]: VencChn = 0,width = 3840,height = 2160,enType = 265
[2024/8/7 9:29:11 544] NORM ENC MODE
[2024/8/7 9:29:11 561] [1970-01-01 00:00:07] ==> VencChCreate(1079)[INFO]: VcChn[1].vencMem = VENCMEM_MICRO
[2024/8/7 9:29:11 561] [1970-01-01 00:00:07] ==> COMM_VENC_Start(890)[INFO]: VencChn = 1,width = 640,height = 360,enType = 265
[2024/8/7 9:29:11 561] NORM ENC MODE
[2024/8/7 9:29:11 577] aec 1; agc 1; ans 1
[2024/8/7 9:29:11 577] [1970-01-01 00:00:07] ==> SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 21,DestChnId = 0,DestModId = 23
[2024/8/7 9:29:11 593] [1970-01-01 00:00:07] ==> AudioCreate(1656)[INFO]: XM_AENC_CreateCH OK
[2024/8/7 9:29:11 593] [1970-01-01 00:00:07] ==> AudioCreate(1685)[INFO]: XM_MPI_ADEC_CreateChn OK
[2024/8/7 9:29:11 609] [1970-01-01 00:00:07] ==> DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:29:11 609] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:29:11 609] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:29:11 609] DEBUG: software pohtoR!
[2024/8/7 9:29:11 625] DEBUG: camera_set_photosensitive_chn 0 1 0x1
[2024/8/7 9:29:11 625] SysBind(2342)[INFO]: SrcChnId = 0,SrcModId = 24,DestChnId = 0,DestModId = 22
[2024/8/7 9:29:11 641] [1970-01-01 00:00:07] ==> JPEGChCreate(1556)[INFO]: enter JPEGChCreate channel=0, VencChn = 3
[2024/8/7 9:29:11 641] [1970-01-01 00:00:07] ==> COMM_VENC_Start(890)[INFO]: VencChn = 3,width = 640,height = 360,enType = 26
[2024/8/7 9:29:11 657] [1970-01-01 00:00:07] ==> COMM_VENC_Start(913)[INFO]: set JpegAttr
[2024/8/7 9:29:11 657] [1970-01-01 00:00:07] ==> SysBind(2342)[INFO]: SrcChnId = 1,SrcModId = 7,DestChnId = 3,DestModId = 7
[2024/8/7 9:29:11 672] [1970-01-01 00:00:07] ==> COMM_VENC_Start(1032)[INFO]: JPEG_CHN[3] bind VENC_CHN[1] success!.
[2024/8/7 9:29:11 689] [1970-01-01 00:00:07] MainApp.c(1816) <main>: [1970-01-01 00:00:07] MainApp.c(1823) <main>: [1970-01-01 00:00:07] MainApp.c(1883) <main>: g_fps=[12]
[2024/8/7 9:29:11 706] [1970-01-01 00:00:07] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=0,brc=1,w=3840,h=2160,qua=4,frame=12,br=1000,gop=4
[2024/8/7 9:29:11 706] [1970-01-01 00:00:07] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[0],wh[3840,2160]-----------
[2024/8/7 9:29:11 720] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:29:11 736] [1970-01-01 00:00:08] ==> CaptureSetFormat(1839)[INFO]: chn=0,type=1,brc=1,w=640,h=360,qua=4,frame=9,br=256,gop=1
[2024/8/7 9:29:11 736] [1970-01-01 00:00:08] ==> CaptureSetFormat(2228)[INFO]: ------------------------------channel[0],dwType[1],wh[640,360]-----------
[2024/8/7 9:29:11 752] [1970-01-01 00:00:08] ==> CaptureSetFormat(2248)[INFO]: exit
[2024/8/7 9:29:11 752] [1970-01-01 00:00:08] MainApp.c(1885) <main>: [1970-01-01 00:00:08] MainApp.c(1893) <main>: 
[2024/8/7 9:29:11 768] [1970-01-01 00:00:08] MainApp.c(1898) <main>: 
[2024/8/7 9:29:11 768] [1970-01-01 00:00:08] xm_main.c(1375) <XM_RealAudio_Pro>: real Audio play start___
[2024/8/7 9:29:11 785] [1970-01-01 00:00:08] ==> AudioInSetFormat(68)[INFO]: pFormat.EncodeTye = 2
[2024/8/7 9:29:11 785] [1970-01-01 00:00:08] ==> XMSDK_AudioInSetFormat(445)[INFO]: anr(1) agc(1) aec(0)
[2024/8/7 9:29:11 785] aec 0; agc 1; ans 1
[2024/8/7 9:29:11 801] [1970-01-01 00:00:08] xm_main.c(1899) <PtzControl_Pro>: 
[2024/8/7 9:29:11 801] PtzControl_Pro[1970-01-01 00:00:08] ==> XMSDK_MotorCreate(120)[INFO]: xlimit 5006, ylimit 2161
[2024/8/7 9:29:11 817] [1970-01-01 00:00:08] xm_main.c(1903) <PtzControl_Pro>: g_sPtz.xMaxStep 5006 g_sPtz.yMaxStep 2161 
[2024/8/7 9:29:11 833] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:AutoMantence pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:29:11 833] [1970-01-01 00:00:08] xm_main.c(700) <XM_SetCameraFactoryConfig>: Get AutoMantence flags [0] failed
[2024/8/7 9:29:11 849] [1970-01-01 00:00:08] xm_main.c(1747) <XM_RealVideo_Pro>: realy video play start___0
[2024/8/7 9:29:11 849] [INIT]: RTC Version: V1.4.1[Jul 18 2024 14:30:07]
[2024/8/7 9:29:11 865] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 0
[2024/8/7 9:29:11 865] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 0 OK
[2024/8/7 9:29:11 881] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(438)[INFO]: channel = 0; type = 1
[2024/8/7 9:29:11 881] [1970-01-01 00:00:08] ==> XMSDK_RealPlayStart(448)[INFO]: XM_VENC_StartCH VencChn 1 OK
[2024/8/7 9:29:11 897] [1970-01-01 00:00:08] xm_main.c(821) <XM_SetCameraFactoryConfig>: get default language ChineseEnglish
[2024/8/7 9:29:11 912] [1970-01-01 00:00:08] xm_main.c(822) <XM_SetCameraFactoryConfig>: get defult IRcurt reverse: no picture reverse mirror:yes filp:yes
[2024/8/7 9:29:11 928] [1970-01-01 00:00:08] xm_main.c(823) <XM_SetCameraFactoryConfig>: set defult motor ptz reverse  mirror:yes filp:no
[2024/8/7 9:29:11 929] [1970-01-01 00:00:08] xm_main.c(824) <XM_SetCameraFactoryConfig>: get defult autotrack motor reverse mirror:yes filp:no
[2024/8/7 9:29:11 944] [1970-01-01 00:00:08] xm_main.c(825) <XM_SetCameraFactoryConfig>: get defult ptz preset x:1556 y:950
[2024/8/7 9:29:11 960] [1970-01-01 00:00:08] xm_main.c(920) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:29:11 961] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:29:11 976] [1970-01-01 00:00:08] ==> XMSDK_GpioWrite(31)[INFO]: port=[597],val=[1]
[2024/8/7 9:29:11 976] [1970-01-01 00:00:08] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:29:11 992] DEBUG: camera_set_ledMode 0x20 0
[2024/8/7 9:29:11 992] DEBUG: camera_set_photosensitive_chn 0 0 0x1
[2024/8/7 9:29:11 992] killall: hostapd: no process killed
[2024/8/7 9:29:12 008] ERR: varLED_pwmGpioInit 970 gpio 11 not support PWM![atbm_log]:ioctl_open(c1e1b500)(c1ec3940)
[2024/8/7 9:29:12 008] [atbm_log]:atbm_ioctl_ble_start
[2024/8/7 9:29:12 040] DEBUG: camera_set_ledType:  2
[2024/8/7 9:29:12 040] DEBUG: camera_set_dnc_mode_chn 3 
[2024/8/7 9:29:12 040] DEBUG: doubleLED_SetLedModeAttr 0x0 0 1
[2024/8/7 9:29:12 056] DEBUG: LED: [IR] [WL] 
[2024/8/7 9:29:12 056] DEBUG: software LED
[2024/8/7 9:29:12 056] DEBUG: software pohtoR!
[2024/8/7 9:29:12 056] DEBUG: doubleLED_SetLedModeAttr 0x20 0 1
[2024/8/7 9:29:12 056] DEBUG: camera_set_ledMode 0x12 0
[2024/8/7 9:29:12 072] DEBUG: camera_set_ledHold: 60000
[2024/8/7 9:29:12 072] xm_main.c(969) <XM_SetCameraFactoryConfig>: get factory language ChineseEnglish
[2024/8/7 9:29:12 088] [1970-01-01 00:00:08] xm_main.c(970) <XM_SetCameraFactoryConfig>: get factory IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:29:12 104] [1970-01-01 00:00:08] xm_main.c(971) <XM_SetCameraFactoryConfig>: set factory motor ptz reverse  mirror:yes filp:yes
[2024/8/7 9:29:12 104] [1970-01-01 00:00:08] xm_main.c(972) <XM_SetCameraFactoryConfig>: get factory autotrack motor reverse mirror:no filp:no
[2024/8/7 9:29:12 120] [1970-01-01 00:00:08] xm_main.c(973) <XM_SetCameraFactoryConfig>: get factory ptz preset x:3110 y:0
[2024/8/7 9:29:12 137] [1970-01-01 00:00:08] xm_main.c(1007) <XM_SetCameraFactoryConfig>:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive 0
[2024/8/7 9:29:12 153] [1970-01-01 00:00:08] ==> XMSDK_SetPhotosensitive(2715)[INFO]:  factory camera_set_ledMode(0x20,0) camera_set_Photosensitive mode 0  ret:0
[2024/8/7 9:29:12 153] [1970-01-01 00:00:08] xm_main.c(1040) <XM_SetCameraFactoryConfig>: adc cfg error LowAdcValue:0 , HighAdcValue:0!
[2024/8/7 9:29:12 169] [1970-01-01 00:00:08] xm_main.c(1060) <XM_SetCameraFactoryConfig>: set IRcurt reverse: yes picture reverse mirror:no filp:no
[2024/8/7 9:29:12 185] [1970-01-01 00:00:08] xm_main.c(1078) <XM_SetCameraFactoryConfig>: camera_set_softIr_thr(1) ret=[0]
[2024/8/7 9:29:12 185] ************last intra 0
[2024/8/7 9:29:12 185] [1970-01-01 00:00:08] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time8224
[2024/8/7 9:29:12 201] [1970-01-01 00:00:08] xm_main.c(1572) <XM_OnVideoData_CB>: main_max_frame_size 113443
[2024/8/7 9:29:12 201] [1970-01-01 00:00:08] MainApp.c(1900) <main>: 
[2024/8/7 9:29:12 201] [1970-01-01 00:00:08] MainApp.c(1905) <main>: 
[2024/8/7 9:29:12 217] [1970-01-01 00:00:08] utils.c(760) <ReadJsonConfig>: Get pClass:Register pFileName:/mnt/mtd/Config/xm/DeviceInfo object error!
[2024/8/7 9:29:12 233] [1970-01-01 00:00:08] ==> XMSDK_AudioSetSpeakerVol(641)[INFO]: enter: Speaker Open
[2024/8/7 9:29:12 233] [1970-01-01 00:00:08] MainApp.c(1913) <main>: 
[2024/8/7 9:29:12 248] [1970-01-01 00:00:08] ==> XMSDK_WifiInit(601)[INFO]: Wifi Init success
[2024/8/7 9:29:12 248] [1970-01-01 00:00:08] MainApp.c(1915) <main>: 
[2024/8/7 9:29:12 249] [1970-01-01 00:00:08] MainApp.c(1918) <main>: 
[2024/8/7 9:29:12 249] lib_ble_main_init
[2024/8/7 9:29:12 249] ======>>atbm_ble_start>>>
[2024/8/7 9:29:12 264] nimble_port_init++
[2024/8/7 9:29:12 264] nimble_host_task
[2024/8/7 9:29:12 264] ble_coexist_start--
[2024/8/7 9:29:12 264] hif_ioctl_loop
[2024/8/7 9:29:12 264] ble_hs_sync:333
[2024/8/7 9:29:12 264] ble_smart_cfg_startup!11
[2024/8/7 9:29:12 264] [ATBM lOG]set default tx power(0)
[2024/8/7 9:29:12 265] pub addr 90:31:4b:a5:16:51
[2024/8/7 9:29:12 280] [1970-01-01 00:00:08] MainApp.c(1922) <main>: ble_ret=[0]
[2024/8/7 9:29:12 280] [1970-01-01 00:00:08] MainApp.c(1200) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 297] [1970-01-01 00:00:08] MainApp.c(1229) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 297] [1970-01-01 00:00:08] MainApp.c(1258) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 312] [1970-01-01 00:00:08] MainApp.c(1260) <GetAndSetTyDefalutConfig>: SMLMode=[2]
[2024/8/7 9:29:12 312] [1970-01-01 00:00:08] MainApp.c(1263) <GetAndSetTyDefalutConfig>: g_SMLAbility=[0]
[2024/8/7 9:29:12 313] [1970-01-01 00:00:08] MainApp.c(1266) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 328] [1970-01-01 00:00:08] MainApp.c(1338) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 328] [1970-01-01 00:00:08] MainApp.c(1346) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 344] [1970-01-01 00:00:08] MainApp.c(1357) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 344] [1970-01-01 00:00:08] MainApp.c(1387) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 361] [1970-01-01 00:00:08] MainApp.c(1390) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:12 361] [1970-01-01 00:00:08] xm_ai.c(564) <XM_CreatePersionDetect>: 
[2024/8/7 9:29:12 361] [1970-01-01 00:00:08] xm_ai.c(574) <XM_CreatePersionDetect>: 
[2024/8/7 9:29:12 376] [1970-01-01 00:00:08] xm_ai.c(585) <XM_CreatePersionDetect>: 
[2024/8/7 9:29:12 376] [1970-01-01 00:00:08] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:29:12 392] [1970-01-01 00:00:08] xm_ai.c(588) <XM_CreatePersionDetect>: 
[2024/8/7 9:29:12 392] [1970-01-01 00:00:08] xm_ai.c(608) <XM_CreatePersionDetect>: 
[2024/8/7 9:29:12 408] [1970-01-01 00:00:08] xm_ai.c(645) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:29:12 520] [1970-01-01 00:00:08] xm_ai.c(646) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:08] xm_ai.c(647) <XM_CreatePersionDetect>: Smart_Ped_Create before, pstParam->stTDCfg.ucSationaryTime = [8];src/ped_thread.c(746) [Smart_Ped_CreateERR: varLED_pwmGpioInit 970 gpio 11 not support PWM!ListMng - BufListCreate: index 1 OK
[2024/8/7 9:29:13 433] [ISP] BUILD TIME:[Dec  9 2023 09:35:12] [V1.3.2.1.4.5.0]
[2024/8/7 9:29:13 433] Mode(Product):0
[2024/8/7 9:29:13 433] BpuMode:[Online]
[2024/8/7 9:29:13 433] VpssMode:[Online]
[2024/8/7 9:29:13 433] [0.LimitUp_info]:
[2024/8/7 9:29:13 433] LimitUp:[Disable]
[2024/8/7 9:29:13 433] [2680*0]->[3840*0])
[2024/8/7 9:29:13 433] chn	TotalSize	ActiveSize
[2024/8/7 9:29:13 433] 0	5040*2246	2680*2160
[2024/8/7 9:29:13 449] 0	5040*2246	2680*2160
[2024/8/7 9:29:13 449] 0	5040*2246	3840*2160
[2024/8/7 9:29:13 449] Repair: En:1	Cnt:0x00000000
[2024/8/7 9:29:13 449] [1.VICU_info]:
[2024/8/7 9:29:13 449] chn	fps	count	ibFail	ibSucc	snsId	mode	size
[2024/8/7 9:29:13 449] 0	25.0	58	0	0	183	linear	8ddb00
[2024/8/7 9:29:13 449] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:29:13 465] 0	0.0	0	0	0	0	linear	0
[2024/8/7 9:29:13 465] en	op_type	m_chn	now
[2024/8/7 9:29:13 465] 0	1	1	1
[2024/8/7 9:29:13 465] [2.VI_info]:
[2024/8/7 9:29:13 465] chn	TotalSize	ActiveSize
[2024/8/7 9:29:13 465] 0	5040*2246	3848*2166
[2024/8/7 9:29:13 465] 1	   0*   0	   0*   0
[2024/8/7 9:29:13 465] [3.MIPI_info]:
[2024/8/7 9:29:13 480] ID	TotalSize(mipi)	ActiveSize(mipi)	TotalSize(pix)	ActiveSize(pix)	Repair
[2024/8/7 9:29:13 480] 0x2b	6480*2166	3848*2166		5040*2166	3848*2166	   0
[2024/8/7 9:29:13 480] 	   0*   0	   0*   0		   0*   0	   0*   0
[2024/8/7 9:29:13 480] [4.Cut_info]:
[2024/8/7 9:29:13 497] Mod	chn	Flag	X	Y	Width	Height	Note
[2024/8/7 9:29:13 497] vicu	0	1	1	2	3840	2160	Use
[2024/8/7 9:29:13 497] h_d	0	1	 	 	2684	2160	  
[2024/8/7 9:29:13 497] hv_gen	0	1	0	0	2684	2160	  
[2024/8/7 9:29:13 497] bpu_cut	0	1	2	0	2680	2160	Use
[2024/8/7 9:29:13 497] vpss_in	0	1	 	 	2680	2160	  
[2024/8/7 9:29:13 513] drv	*	0x81	0	1	3840	2160	Use
[2024/8/7 9:29:13 513] [5.IB(isp buffer info)]:
[2024/8/7 9:29:13 513] -----COMMON POOL CONFIG--------------------------------------------------------
[2024/8/7 9:29:13 513] PoolId  Count  Size
[2024/8/7 9:29:13 529] -----IB FREE LIST STATUS-------------------------------------------------------
[2024/8/7 9:29:13 529] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:29:13 545] -----IB BPU LIST STATUS-------------------------------------------------------
[2024/8/7 9:29:13 545] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:29:13 545] -----IB ALL LIST STATUS-------------------------------------------------------
[2024/8/7 9:29:13 561] Node 	  PhysAddr  Size      Width  Height  BindId  BindDev  BindChn
[2024/8/7 9:29:13 561] [VENC] BUILD TIME:[Dec  8 2023 13:39:16]
[2024/8/7 9:29:13 561] -------VIBUF FIFO STATUS----------------------------------------------------------
[2024/8/7 9:29:13 577] VbFail  FifoFull  FifoEmpty  FifoDepth  MaxDepth
[2024/8/7 9:29:13 577] 0       0         0          0          4       
[2024/8/7 9:29:13 577] -------THREAD STATUS----------------------------------------------------------
[2024/8/7 9:29:13 593]      --265--            --264--                                               
[2024/8/7 9:29:13 593] Count      Line     Count      Line     
[2024/8/7 9:29:13 593] 30         437      58         560      
[2024/8/7 9:29:13 609] -------VENC CHN ATTR--------------------------------------------------------------
[2024/8/7 9:29:13 609] NO. Width  Height  Type  Field  VIField  StreamType  Sequence  FreeBytes  BusyBytes
[2024/8/7 9:29:13 625] 0   3840   2160    H265  0      0        0           16        975617     7423     	
[2024/8/7 9:29:13 625] 1   640    360     H265  0      0        0           13        43195      5        	
[2024/8/7 9:29:13 641] 3   640    360     JPEG  0      0        0           0         172800     0        	
[2024/8/7 9:29:13 641] -------VENC STREAM STATE--------------------------------------------------------------
[2024/8/7 9:29:13 656] NO. Start  SucCnt   ErrCnt  BufErr  FreeCnt  BusyCnt  UserGet  UserRls  GetTimes  Interval(us)  Min(us)  Max(us)  Ave(us)  FramRate
[2024/8/7 9:29:13 672] 0   Y      16       0       0       14       1        15       15       26        63560         59150    88308    66390    0       
[2024/8/7 9:29:13 672] 1   Y      13       0       0       1        0        13       13       27        2211          2169     28491    4925     0       
[2024/8/7 9:29:13 688] 3   N      0        0       0       1        0        0        0        27        0             0        0        0        0       
[2024/8/7 9:29:13 689] ]: Smart_Ped_Create_ver: Jul 24 2024 18:21:40
[2024/8/7 9:29:13 704] src/ped_thread.c(656) [Ped_Init_IA_Work]: Ped_Init_IA_Work start ver:Jul 24 2024 18:21:40
[2024/8/7 9:29:13 704] [FUNC: IA_InitLog] Creat OK.
[2024/8/7 9:29:13 704] [INIT]: XM_IA_Init() done.
[2024/8/7 9:29:13 720] src/ped_thread.c(705) [Ped_Init_IA_Work]: ruler 0 region (0,0) (0,0) (0,0) (0,0)
[2024/8/7 9:29:13 721] [INIT]:LIBXMIA IAtype 700 Complied at May  8 2024 08:39:39 GIT_ID:cb3a4ed0
[2024/8/7 9:29:13 721] [INIT]: TD Version: TD_V_3.2.4.2[May 15 2024 19:14:32]
[2024/8/7 9:29:13 736] -- TD INIT -- 
[2024/8/7 9:29:13 737]  uiTdMaxNum: 12 
[2024/8/7 9:29:13 737]  acClassBinPath: /usr/bin 
[2024/8/7 9:29:13 737]  ePlatForm: 50 
[2024/8/7 9:29:13 737]  eDevImgType: 17 
[2024/8/7 9:29:13 737]  stDevImgSize: (2680,2160) 
[2024/8/7 9:29:13 737]  iTrackFlag: 1 
[2024/8/7 9:29:13 737]  iTrackType: 2 
[2024/8/7 9:29:13 737] -- TD EXTF -- 
[2024/8/7 9:29:13 754]  ucPedFallDownEnable: 0
[2024/8/7 9:29:13 754]  ucTDFeatureEnable: 0
[2024/8/7 9:29:13 754]  ucSmokeEnable: 0
[2024/8/7 9:29:13 754]  ucFaceDetEnable: 0
[2024/8/7 9:29:13 754]  ucFaceMaskEnable: 0
[2024/8/7 9:29:13 754]  ucFaceAngEnable: 0
[2024/8/7 9:29:13 754]  ucFaceRegEnable: 0
[2024/8/7 9:29:13 754]  ucPlateDetEnable: 0
[2024/8/7 9:29:13 754]  ucPlateRegEnable: 0
[2024/8/7 9:29:13 768]  ucPedPointEnable: 0
[2024/8/7 9:29:13 768]  ucHandPointEnable: 0
[2024/8/7 9:29:13 768]  ucHelmetEnable: 0
[2024/8/7 9:29:13 768]  ucHandgestureEnable: 0
[2024/8/7 9:29:13 768]  efdfreq: 10
[2024/8/7 9:29:13 768] [INIT]: XM_IA_TD_PED_S Version: 20230719_person_noexp_v200
[2024/8/7 9:29:13 784] [INIT] Alg Malloc Size 27232
[2024/8/7 9:29:13 784] -- TD CFG --  
[2024/8/7 9:29:13 784]  iMDFlag: 0
[2024/8/7 9:29:13 784]  ucDetectDisable: 0
[2024/8/7 9:29:13 784]  iDetectType: 5
[2024/8/7 9:29:13 784]  ePattern: 3
[2024/8/7 9:29:13 784]  eSensitivity: 2
[2024/8/7 9:29:13 784]  ucFishEyeCorrectFlag:0
[2024/8/7 9:29:13 784]  eRotate:0
[2024/8/7 9:29:13 784]  ucSationaryTd: 0
[2024/8/7 9:29:13 784]  ucClearnessFlg:0
[2024/8/7 9:29:13 800]  usInImgWidth:0
[2024/8/7 9:29:13 800]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:29:13 800] [CFG]: Rule:0 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:29:13 800] [CFG]: Rule:1 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:29:13 816] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:29:13 816] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:1 eRuleType:0
[2024/8/7 9:29:13 816] [CFG]: DEFAULT iBoundaryPtsNum 4 eAlarmDirect 2 (0 0) (8191 0) (8191 8191) (0 8191)
[2024/8/7 9:29:13 833] [FUNC:PbdcnnConfig][L:578] (nil) 0xbeb802f8 Pointer Null.
[2024/8/7 9:29:13 833] [INIT]: PdConfig pvHandle 0xb122e000. Config OK
[2024/8/7 9:29:13 833] [INIT] Alg Malloc Size 30000
[2024/8/7 9:29:13 833] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:29:13 849] [INIT]: Open Class File /usr/bin/pd_s_d1_xmdpu1_0.dpu
[2024/8/7 9:29:13 849] [INIT]:memPoolSize 1351680.
[2024/8/7 9:29:13 849] V1.6.x date Sep  5 2023, time 23:32:25 npu load start
[2024/8/7 9:29:13 849] dpu version v1.1.0 build time Aug  5 2022
[2024/8/7 9:29:13 865] [INIT]: Update MemPoolSize 0 to 1351680.
[2024/8/7 9:29:13 865] [INIT]: MmzAlloc MemPoolSize 1351680 0xb106c000~0xb11b6000.
[2024/8/7 9:29:13 865] 0 Model 0x9257b4 MemPoolIdx 0 MemPoolInfo 0x6d5f10
[2024/8/7 9:29:13 881] [INIT]: version 20230719_person_noexp_v200, debug 0, profile 0
[2024/8/7 9:29:13 881] [INIT] Alg Malloc Size 240736
[2024/8/7 9:29:13 881] CNNMemory: 2064977 bulk 240736 mmz 1824241
[2024/8/7 9:29:13 881] CNNINIT INPUT IMAGESIZE:(640,224)
[2024/8/7 9:29:13 896] TD_DETECT stAlgImgSize (640,224) 
[2024/8/7 9:29:13 896] [INIT] Alg Malloc Size 60672
[2024/8/7 9:29:13 896] MdInit ok![INIT] Alg Malloc Size 79704
[2024/8/7 9:29:13 896] [FUNC: trackInit][L: 273] API_Creat_IMG 
[2024/8/7 9:29:13 912] [INIT]: PdInit pvHandle 0x925448 *pvHandle 0xb122e000 OK
[2024/8/7 9:29:13 912] IA_LOG 87c6a000 value 0
[2024/8/7 9:29:13 912] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:29:13 912] Ped_Init_IA_Work end 
[2024/8/7 9:29:13 912] src/ped_thread.c(774) [Smart_Ped_Create]: Create list success, index 1 maxsize 2
[2024/8/7 9:29:13 928] src/ped_thread.c(495) [PedProc_v2]: 
[2024/8/7 9:29:13 928] src/ped_thread.c(520) [PedProc_v2]: 
[2024/8/7 9:29:13 928] [FUNC: DetectTarget][L: 1489] API_Creat_IMG_MdInImg 
[2024/8/7 9:29:13 928] [FUNC: PbdcnnWork][L: 1084] API_Creat_CSCIMG 
[2024/8/7 9:29:13 944] [1970-01-01 00:00:10] xm_main.c(368) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:29:13 961] [1970-01-01 00:00:10] xm_main.c(371) <AutoMaintenance_pro>: -----------------------------
[2024/8/7 9:29:13 961] src/ped_thread.c(803) [Smart_Ped_Create]: Ped_Creat Success @0x39e24
[2024/8/7 9:29:13 976] [1970-01-01 00:00:10] xm_ai.c(649) <XM_CreatePersionDetect>: g_stVideoCaps.width 2680, g_stVideoCaps.height 2160
[2024/8/7 9:29:13 992] [1970-01-01 00:00:10] xm_ai.c(657) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTd = [0];[1970-01-01 00:00:10] xm_ai.c(658) <XM_CreatePersionDetect>: Smart_Ped_SetParam before, pstParam->stTDCfg.ucSationaryTime = [8];-- TD CFG --  
[2024/8/7 9:29:13 992]  iMDFlag: 0
[2024/8/7 9:29:13 992]  ucDetectDisable: 0
[2024/8/7 9:29:14 008]  iDetectType: 5
[2024/8/7 9:29:14 009]  ePattern: 3
[2024/8/7 9:29:14 009]  eSensitivity: 0
[2024/8/7 9:29:14 009]  ucFishEyeCorrectFlag:0
[2024/8/7 9:29:14 009]  eRotate:0
[2024/8/7 9:29:14 009]  ucSationaryTd: 0
[2024/8/7 9:29:14 009]  ucClearnessFlg:0
[2024/8/7 9:29:14 009]  usInImgWidth:0
[2024/8/7 9:29:14 009]  stDetRegion: (0,0),(8191,8191)
[2024/8/7 9:29:14 024] [CFG]: Rule:0 ucRuleEnable:1 AlarmType:0 eRuleType:1
[2024/8/7 9:29:14 024] [CFG]: IA_PERIMETER_V1 iBoundaryPtsNum 4 eAlarmDirect 0 (0 0) (8191 0) (8191 8191) (0 8191) [CFG]: Rule:1 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:29:14 040] [CFG]: Rule:2 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:29:14 040] [CFG]: Rule:3 ucRuleEnable:0 AlarmType:0 eRuleType:0
[2024/8/7 9:29:14 040] [INIT]: PdConfig pvHandle 0xb122e000. Config OK
[2024/8/7 9:29:14 040] IA_LOG 87c6a000 value 0
[2024/8/7 9:29:14 056] IA_TD_LOG 87c6a004 value 0
[2024/8/7 9:29:14 056] src/ped_thread.c(831) [Smart_Ped_SetParam[MMZ] BUILD TIME:[Jul 14 2021 15:42:31]
[2024/8/7 9:29:14 056] [0x83400000--------0x88000000]
[2024/8/7 9:29:14 072] --START-----------SIZE----------------OVERFLOW----NAME---------------
[2024/8/7 9:29:14 072] 0x83400000	0xbde000  (12152k)	0	vb[bdd800][0]
[2024/8/7 9:29:14 072] 0x83fde000	0xbde000  (12152k)	0	vb[bdd800][1]
[2024/8/7 9:29:14 072] 0x84bbc000	0xbde000  (12152k)	0	vb[bdd800][2]
[2024/8/7 9:29:14 088] 0x8579a000	0x55000   (  340k)	0	vb[54600][0]
[2024/8/7 9:29:14 088] 0x857ef000	0x55000   (  340k)	0	vb[54600][1]
[2024/8/7 9:29:14 088] 0x85844000	0x35000   (  212k)	0	vb[34800][0]
[2024/8/7 9:29:14 088] 0x85879000	0x35000   (  212k)	0	vb[34800][1]
[2024/8/7 9:29:14 105] 0x858ae000	0x24000   (  144k)	0	isp_nr_alpha_ch0
[2024/8/7 9:29:14 105] 0x858d2000	0x163000  ( 1420k)	0	isp_nr_idx_ch0
[2024/8/7 9:29:14 105] 0x85a35000	0x1000    (    4k)	0	isp_nr_idx_max_ch0
[2024/8/7 9:29:14 105] 0x85a36000	0x84f000  ( 8508k)	0	isp_nr_fetch_ch0
[2024/8/7 9:29:14 121] 0x86285000	0x2000    (    8k)	0	isp_defog_ch0
[2024/8/7 9:29:14 121] 0x86287000	0xc24000  (12432k)	0	vencRfcFrame[0]
[2024/8/7 9:29:14 121] 0x86eab000	0xc24000  (12432k)	0	vencRfcFrame[1]
[2024/8/7 9:29:14 137] 0x87acf000	0xf1000   (  964k)	0	stream_chn[0]
[2024/8/7 9:29:14 140] 0x87bc0000	0x4c000   (  304k)	0	vencWrapLuma[0]
[2024/8/7 9:29:14 140] 0x87c0c000	0x26000   (  152k)	0	vencWrapChroma[0]
[2024/8/7 9:29:14 140] 0x87c32000	0xb000    (   44k)	0	stream_chn[1]
[2024/8/7 9:29:14 153] 0x87c3d000	0x2b000   (  172k)	0	stream_chn[3]
[2024/8/7 9:29:14 153] 0x87c68000	0x1000    (    4k)	0	osd_block[0]
[2024/8/7 9:29:14 153] 0x87c69000	0x1000    (    4k)	0	osd_block[4]
[2024/8/7 9:29:14 153] 0x87c6a000	0x1000    (    4k)	0	IA_LOG
[2024/8/7 9:29:14 169] 0x87c6b000	0x7000    (   28k)	0	IA_MANAGE_1
[2024/8/7 9:29:14 169] 0x87c72000	0x8000    (   32k)	0	IA_MANAGE_2
[2024/8/7 9:29:14 169] 0x87c7a000	0x70000   (  448k)	0	firm_mem_0
[2024/8/7 9:29:14 169] 0x87cea000	0x14b000  ( 1324k)	0	mempool_1
[2024/8/7 9:29:14 169] 0x87e35000	0x1000    (    4k)	0	dst_mem_1
[2024/8/7 9:29:14 185] 0x87e36000	0x1000    (    4k)	0	dst_mem_2
[2024/8/7 9:29:14 185] 0x87e37000	0x3000    (   12k)	0	dst_mem_3
[2024/8/7 9:29:14 185] 0x87e3a000	0x1000    (    4k)	0	dst_mem_4
[2024/8/7 9:29:14 185] 0x87e3b000	0x14000   (   80k)	0	IA_MANAGE_3
[2024/8/7 9:29:14 201] 0x87e4f000	0x35000   (  212k)	0	IA_Image_1
[2024/8/7 9:29:14 201] 0x87e84000	0x6a000   (  424k)	0	IA_Image_2
[2024/8/7 9:29:14 201] 0x87eee000	0x112000  ( 1096k)	1	
[2024/8/7 9:29:14 201] ---------------------------------------------------------------------
[2024/8/7 9:29:14 217] SIZE: 0x4c00000(77824k)  USED: 0x4aee000(76728k)  FREE: 0x112000(1096k)
[2024/8/7 9:29:14 217] ]: Ped_SetParam Success
[2024/8/7 9:29:14 217] [1970-01-01 00:00:10] xm_ai.c(666) <XM_CreatePersionDetect>: 
[2024/8/7 9:29:14 233] [1970-01-01 00:00:10] xm_ai.c(674) <XM_CreatePersionDetect>: 
[2024/8/7 9:29:14 233] [1970-01-01 00:00:10] MainApp.c(1395) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:14 249] [1970-01-01 00:00:10] MainApp.c(1397) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:14 249] [1970-01-01 00:00:10] MainApp.c(1402) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:14 249] [1970-01-01 00:00:10] MainApp.c(1481) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:14 265] --- tracepoint xm_ai.c,XM_LoudDetectSetAlarmVolume(1160): level 60 enable 0 volume
[2024/8/7 9:29:14 265] [1970-01-01 00:00:10] MainApp.c(1525) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:14 265]  PTZPreset is empty!
[2024/8/7 9:29:14 281]  PTZPreset is empty!
[2024/8/7 9:29:14 281] [1970-01-01 00:00:10] MainApp.c(1554) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:14 297] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:29:14 297] [1970-01-01 00:00:10] MainApp.c(1568) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:14 313] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:29:14 329] [1970-01-01 00:00:10] utils.c(322) <ReadTYJsonConfig>: Get AutoPatrol object error!
[2024/8/7 9:29:14 329] [1970-01-01 00:00:10] MainApp.c(1584) <GetAndSetTyDefalutConfig>: cruisetime_pro create!
[2024/8/7 9:29:14 345] [1970-01-01 00:00:10] MainApp.c(1607) <GetAndSetTyDefalutConfig>: 
[2024/8/7 9:29:14 345] [1970-01-01 00:00:10] MainApp.c(1925) <main>: 
[2024/8/7 9:29:14 361] [1970-01-01 00:00:10] MainApp.c(1116) <GetRegisterMode>: -------- register mode 1
[2024/8/7 9:29:14 361] [1970-01-01 00:00:10] MainApp.c(1927) <main>: 
[2024/8/7 9:29:14 361] [1970-01-01 00:00:10] MainApp.c(1930) <main>: 
[2024/8/7 9:29:14 361] *************
[2024/8/7 9:29:14 361]  0x6d123c 
[2024/8/7 9:29:14 376] *****************
[2024/8/7 9:29:14 376]  0x3287c 
[2024/8/7 9:29:14 377] beginend[1970-01-01 00:00:10] MainApp.c(1938) <main>: 
[2024/8/7 9:29:14 392] [1970-01-01 00:00:10] MainApp.c(866) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:29:14 393] [1970-01-01 00:00:10] MainApp.c(174) <GetDeviceHWInfo>: Get Hwinfo APP_ID [fvijo8jvloagv1gm], UUID[uuidcaab27b0a838d239] AUTHKEY [j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi]
[2024/8/7 9:29:14 408] [1970-01-01 00:00:10] MainApp.c(909) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:29:14 408] [1970-01-01 00:00:10] MainApp.c(942) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:29:14 425] [1970-01-01 00:00:10] MainApp.c(986) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:29:14 425] [1970-01-01 00:00:10] MainApp.c(1019) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:29:14 425] sdk start
[2024/8/7 9:29:14 441] [1970-01-01 00:00:10] MainApp.c(752) <tuya_ipc_sdk_start>: log_level 0[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /mnt/mtd/Config/ty/ 
[2024/8/7 9:29:14 441] [01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/mnt/mtd/Config/ty/
[2024/8/7 9:29:14 456] [01-01 18:12:15 TUYA D][simplekv.c:945] path:/mnt/mtd/Config/ty/
[2024/8/7 9:29:14 456] [01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[£¢US¾򽸹kRꡝ
[2024/8/7 9:29:14 472] [01-01 18:12:15 TUYA D][simplekv.c:989] both file not exist /mnt/mtd/Config/ty/tuya_user.db
[2024/8/7 9:29:14 472] [01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[2024/8/7 9:29:14 488] [01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[2024/8/7 9:29:14 488] [01-01 18:12:15 TUYA D][simplekv.c:1083] init NEW normal file
[2024/8/7 9:29:14 488] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 3536627844
[2024/8/7 9:29:14 505] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:14 505] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[2024/8/7 9:29:14 521] [01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[2024/8/7 9:29:14 521] [01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[2024/8/7 9:29:14 537] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:8192,priority:4
[2024/8/7 9:29:14 537] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[2024/8/7 9:29:14 537] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[2024/8/7 9:29:14 552] [01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[2024/8/7 9:29:14 552] [01-01 18:12:15 TUYA E][log_seq.c:863] open err
[2024/8/7 9:29:14 570] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:13312,priority:3
[2024/8/7 9:29:14 571] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[2024/8/7 9:29:14 585] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[2024/8/7 9:29:14 585] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:29:14 585] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:14 601] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:14 601] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:14 601] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:29:14 616] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:29:14 616] [01-01 18:12:15 TUYA D][tuya_bt_sdk.c:92] ty bt cmmod regist ok:1
[2024/8/7 9:29:14 633] [01-01 18:12:15 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:29:14 633] dev id key: 16
[2024/8/7 9:29:14 633] d4 1d 8c d9 8f 00 b2 04 e9 80 09 98 ec f8 42 7e 
[2024/8/7 9:29:14 633] --- tracepoint bt_ext_porting.c,tuya_ext_bt_port_init(464): tuya_ext_bt_port_init ---
[2024/8/7 9:29:14 649] [01-01 18:12:15 TUYA I][bt_ext_porting.c:466] [TUYA-BTUART]tuya ext bt port init
[2024/8/7 9:29:14 649] --- tracepoint bt_uart_drv.c,tuya_bt_uart_open(187): tuya_bt_uart_open ---
[2024/8/7 9:29:14 665] --- tracepoint bt_uart_drv.c,tuya_bt_uart_init(60): tuya_bt_uart_init  0 ---
[2024/8/7 9:29:14 665] [01-01 18:12:15 TUYA I][bt_ext_porting.c:485] [TUYA-BTUART]thread ty_btext_thread create cplt mode 1
[2024/8/7 9:29:14 681] [01-01 18:12:15 TUYA N][tuya_ble_api.c:650] ble sdk re_inited
[2024/8/7 9:29:14 681] [01-01 18:12:15 TUYA D][tuya_ble_active.c:523] bt active init
[2024/8/7 9:29:14 681] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:141] ty bt sdk init success finish
[2024/8/7 9:29:14 697] [1970-01-01 00:00:10] MainApp.c(822) <tuya_ipc_sdk_start>: create ring buffer start 
[2024/8/7 9:29:14 697] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:0 Enable:1
[2024/8/7 9:29:14 713] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 2048, video_fps 12
[2024/8/7 9:29:14 713] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr0 bitrate:2048 fps:12
[2024/8/7 9:29:14 729] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 2621440 bytes for ch0st0tr0, max frame size 393216
[2024/8/7 9:29:14 744] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod[atbm_log]:[ieee80211_csa_cancel][eth2]:[0][0]
[2024/8/7 9:29:14 744]  Exec Start. Set to Running Stat
[2024/8/7 9:29:14 744] --- tracepoint bt_ext_porting.c,ty_btext_thread(370):  ---
[2024/8/7 9:29:14 760] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr0 size:2621440 nodes:120
[2024/8/7 9:29:14 760] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:0
[2024/8/7 9:29:14 760] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:1 Enable:1
[2024/8/7 9:29:14 776] [01-01 18:12:15 TUYA D][MainApp.c:448] video_bitrate 1024, video_fps 12
[2024/8/7 9:29:14 776] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr1 bitrate:1024 fps:12
[2024/8/7 9:29:14 792] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 1310720 bytes for ch0st0tr1, max frame size 196608
[2024/8/7 9:29:14 808] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr1 size:1310720 nodes:120
[2024/8/7 9:29:14 808] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:1
[2024/8/7 9:29:14 808] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:2 Enable:0
[2024/8/7 9:29:14 824] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:3 Enable:0
[2024/8/7 9:29:14 824] [01-01 18:[atbm_log]:eth2:free authen bss ++
[2024/8/7 9:29:14 824] 12:15 TUYA D][MainApp.c:430] init ring buffer Channel:4 Enable:0
[2024/8/7 9:29:14 840] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:5 Enable:0
[2024/8/7 9:29:14 840] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:6 Enable:0
[2024/8/7 9:29:14 857] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:7 Enable:0
[2024/8/7 9:29:14 857] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:8 Enable:0
[2024/8/7 9:29:14 872] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:9 Enable:1
[2024/8/7 9:29:14 872] [01-01 18:12:15 TUYA D][MainApp.c:439] audio_sample 8000, audio_databits 16, audio_fps 25
[2024/8/7 9:29:14 888] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:539] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[2024/8/7 9:29:14 888] [01-01 18:12:15 TUYA D][tuya_ring_buffer.c:571] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[2024/8/7 9:29:14 904] [01-01 18:12:15 TUYA I][tuya_ring_buffer.c:591] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[2024/8/7 9:29:14 904] [01-01 18:12:15 TUYA D][MainApp.c:456] init ring buffer success. channel:9
[2024/8/7 9:29:14 921] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:10 Enable:0
[2024/8/7 9:29:14 921] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:11 Enable:0
[2024/8/7 9:29:14 937] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:12 Enable:0
[2024/8/7 9:29:14 937] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:13 Enable:0
[2024/8/7 9:29:14 937] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:14 Enable:0
[2024/8/7 9:29:14 952] [01-01 18:12:15 TUYA D][MainApp.c:430] init ring buffer Channel:15 Enable:0
[2024/8/7 9:29:14 968] [1970-01-01 00:00:10] MainApp.c(830) <tuya_ipc_sdk_start>: pRunInfo->net_info.connect_mode 1[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:29:14 968] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:14 968] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:14 984] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:14 984] [01-01 18:12:15 TUYA E][ws_db_gw.c:80] wd_protected_read fails gw_bi -6
[2024/8/7 9:29:15 000] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:-6
[2024/8/7 9:29:15 016] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"uuid":"uuidcaab27b0a838d239","psk_key":null,"auth_key":"j1ZAkWQYFqlOjvCAsNPFSoXhAPJAZzSi","ap_ssid":null,"ap_passwd":null,"country_code":null,"bt_mac":null,"bt_hid":null,"prod_test":false,"fac_pin":null }
[2024/8/7 9:29:15 016] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 032] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 032] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 032] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 048] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_bi And Value Len:208
[2024/8/7 9:29:15 064] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 0 startpos:28700 size:276
[2024/8/7 9:29:15 064] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:29:15 080] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 1056267009
[2024/8/7 9:29:15 080] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 080] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 096] [01-01 18:12:15 TUYA D][ws_db_gw.c:156] gw base write success
[2024/8/7 9:29:15 113] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":0,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0[atbm_log]:[eth2] change to [3]
[2024/8/7 9:29:15 113]  }
[2024/8/7 9:29:15 113] [01-01 18:1[atbm_log]:[eth2] has been disabled
[2024/8/7 9:29:15 129] 2:15 TUYA D][sim[atbm_log]:add iftype(6),if_cnt(2),flags(c2627bf8)
[2024/8/7 9:29:15 129] plekv.c:1211] read key:g[atbm_log]:enable sg
[2024/8/7 9:29:15 129] w_wsm isFuzzy:0 [atbm_log]:[mon.eth2] has been disabled
[2024/8/7 9:29:15 129] skipCnt:0
[2024/8/7 9:29:15 129] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 145] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 145] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 161] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:29:15 161] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 1 startpos:28976 size:212
[2024/8/7 9:29:15 177] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:29:15 179] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2367317337
[2024/8/7 9:29:15 179] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 193] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 193] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:29:15 193] [01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[2024/8/7 9:29:15 208] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1776] Last reset reason: 255
[2024/8/7 9:29:15 208] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 208] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[2024/8/7 9:29:15 224] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:208
[2024/8/7 9:29:15 224] [01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[2024/8/7 9:29:15 241] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 241] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 241] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 256] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 256] [01-01 18:12:15 TUYA D][tuya_tls.c:315] load tls_ca_cnt fail. no ca in local db
[2024/8/7 9:29:15 272] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:29:15 272] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1140] serial_no:90314ba51650
[2024/8/7 9:29:15 272] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 288] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:29:15 289] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:29:15 289] [01-01 18:12:15 TUYA D][ws_db_gw.c:344] gw_wsm read success
[2024/8/7 9:29:15 304] [01-01 18:12:15 TUYA N][tuya_devos_entry.c:1171] gw_cntl.gw_wsm.stat:0
[2024/8/7 9:29:15 304] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1347] gw_cntl->gw_wsm.nc_tp:0
[2024/8/7 9:29:15 320] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1348] gw_cntl->gw_wsm.md:0
[2024/8/7 9:29:15 320] [01-01 18:12:15 TUYA N][tuya_devos_netcfg.c:1362] wifi config method not fit
[2024/8/7 9:29:15 320] [01-01 18:12:15 TUYA E][tuya_devos_entry.c:1787] ret:-2
[2024/8/7 9:29:15 336] [01-01 18:12:15 TUYA D][tuya_devos_entry.c:1808] enter reset factory
[2024/8/7 9:29:15 336] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 352] [01-01 18:12:15 TUYA [atbm_log]:[TX]:[0]:deatuhen[ff:ff:ff:ff:ff:ff]
[2024/8/7 9:29:15 352] D][simplekv.c:12[atbm_log]:[WSM] Drop frame
[2024/8/7 9:29:15 352] 47] no key find
[2024/8/7 9:29:15 352] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 368] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 368] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_di -6
[2024/8/7 9:29:15 368] [01-01 18:12:15 TUYA E][ws_db_gw.c:494] gw_di read fail:-6
[2024/8/7 9:29:15 384] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 384] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 384] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 400] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 400] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_di And Value Len:400
[2024/8/7 9:29:15 416] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 2 startpos:29188 size:468
[2024/8/7 9:29:15 416] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:29:15 416] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 876692212
[2024/8/7 9:29:15 432] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 432] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 448] [01-01 18:12:15 TUYA D][ws_db_gw.c:430] gw_di write success
[2024/8/7 9:29:15 449] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:593] nc_tp:2, wifi_start_mode:0
[2024/8/7 9:29:15 449] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:wf_start_md isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 464] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 464] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 464] [01-01 18:12:15 TUYA D][si[atbm_log]:[eth2] start driver he ap
[2024/8/7 9:29:15 480] mplekv.c:1336] _[atbm_log]:BSS_CHANGED_BEACON
[2024/8/7 9:29:15 480] _read_kv_with_de[atbm_log]:change ds_params channel 6 
[2024/8/7 9:29:15 480] code fail. -3
[2024/8/7 9:29:15 480] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:wf_start_md And Value Len:16
[2024/8/7 9:29:15 496] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 3 startpos:29656 size:84
[2024/8/7 9:29:15 496] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:29:15 512] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 411742493
[2024/8/7 9:29:15 512] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 512] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 528] [01-01 18:12:15 TUYA D][ws_db_gw.c:61] write buf:{"nc_tp":2,"ssid":null,"passwd":null,"md":0,"random":0,"wfb64":1,"stat":0,"token":null,"region":null,"reg_key":null,"dns_prio":0 }
[2024/8/7 9:29:15 545] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_wsm isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 545] [01-01 18:12:15 TUYA D][simplekv.c:1251] find key:1 gw_wsm
[2024/8/7 9:29:15 561] [01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_wsm find value.Len:144
[2024/8/7 9:29:15 561] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_wsm And Value Len:144
[2024/8/7 9:29:15 561] [01-01 18:12:15 TUYA D][simplekv.c:397] 1 key same AND size old 212 >= new 144
[2024/8/7 9:29:15 577] [01-01 18:12:15 TUYA D][simplekv.c:430] find 1 available space
[2024/8/7 9:29:15 577] [01-01 18:12:15 TUYA D][simplekv.c:474] reuse available space 28976
[2024/8/7 9:29:15 577] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4146866774
[2024/8/7 9:29:15 593] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 593] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 610] [01-01 18:12:15 TUYA D][ws_db_gw.c:280] gw_wsm write success
[2024/8/7 9:29:15 610] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 610] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 625] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 625] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 625] [01-01 18:12:15 TUYA E][tuya_ws_db.c:326] kvs_read fails gw_ai -6
[2024/8/7 9:29:15 641] [01-01 18:12:15 TUYA E][ws_db_gw.c:636] gw_ai read fail:-6
[2024/8/7 9:29:15 641] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_ai isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 641] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 657] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 657] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 673] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:gw_ai And Value Len:368
[2024/8/7 9:29:15 673] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 4 startpos:29740 size:436
[2024/8/7 9:29:15 673] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:29:15 689] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 216605884
[2024/8/7 9:29:15 689] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 705] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 707] [01-01 18:12:15 TUYA D][ws_db_gw.c:581] gw_ai write success
[2024/8/7 9:29:15 707] [01-01 18:12:15 TUYA D][tuya_ipc_p2p_common.c:488] __begin
[2024/8/7 9:29:15 720] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_auth_info isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 720] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 721] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 737] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 737] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_auth_info And Value Len:16
[2024/8/7 9:29:15 753] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 5 startpos:30176 size:84
[2024/8/7 9:29:15 753] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:29:15 753] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 4220141073
[2024/8/7 9:29:15 769] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 769] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 784] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_pwd isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 785] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 785] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 801] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 864] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_pwd And Value Len:16
[2024/8/7 9:29:15 864] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 6 startpos:30260 size:84
[2024/8/7 9:29:15 880] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:29:15 880] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 860452950
[2024/8/7 9:29:15 880] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 896] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 896] [01-01 18:12:15 TUYA D][simplekv.c:1211] read key:p2p_type isFuzzy:0 skipCnt:0
[2024/8/7 9:29:15 896] [01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:15 912] [01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:15 912] [01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:15 928] [01-01 18:12:15 TUYA D][simplekv.c:374] write key:p2p_type And Value Len:16
[2024/8/7 9:29:15 928] [01-01 18:12:15 TUYA D][simplekv.c:457] new space 7 startpos:30344 size:84
[2024/8/7 9:29:15 928] [01-01 18:12:15 TUYA D][simplekv.c:483] new space. seek to end and write zero
[2024/8/7 9:29:15 944] [01-01 18:12:15 TUYA D][simplekv.c:203] update crc 2541358761
[2024/8/7 9:29:15 944] [01-01 18:12:15 TUYA D][simplekv.c:359] write head to normal file success
[2024/8/7 9:29:15 944] [01-01 18:12:15 TUYA D][simplekv.c:520] write success
[2024/8/7 9:29:15 960] [01-01 18:12:15 TUYA D][tuya_devos_health.c:37] init watchdog, interval: 60
[2024/8/7 9:29:15 960] [01-01 18:12:15 TUYA D][tuya_devos_health.c:318] watch_dog_interval:60, monitor_detect_interval:600
[2024/8/7 9:29:15 976] [01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:14848,priority:5
[2024/8/7 9:29:15 992] [01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:health_monitor Exec Start. Set to Running Stat
[2024/8/7 9:29:15 992] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:300 cnt:3
[2024/8/7 9:29:15 992] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:302 cnt:4
[2024/8/7 9:29:16 008] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:304 cnt:5
[2024/8/7 9:29:16 009] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:307 cnt:6
[2024/8/7 9:29:16 009] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:308 cnt:7
[2024/8/7 9:29:16 024] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:312 cnt:8
[2024/8/7 9:29:16 024] [01-01 18:12:15 TUYA D][tuya_ipc_mqtt_subscribe.c:293] iot_register_extra_mqt_cb done
[2024/8/7 9:29:16 024] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:251] traversal over
[2024/8/7 9:29:16 040] [01-01 18:12:15 TUYA E][tuya_ipc_hardware_info.c:172] NO sensor info. Please check if you need.
[2024/8/7 9:29:16 040] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:114] not found device wifi info
[2024/8/7 9:29:16 072] [01-01 18:12:15 TUYA D][tuya_ipc_hardware_info.c:352] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":3,\"webrtc\":2,\"video_num\":2,\"sdk_version\":\"5.3.37\"},\"hardware\":{\"toolchain\":\"arm-xm-linux\",\"cpu\":{\"model\":\"ARMv7 Processor rev 1 (v7l)\",\"bogomips\":\"373.55\"}}
[2024/8/7 9:29:16 073] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:116] sys add timer: 14
[2024/8/7 9:29:16 088] 
[2024/8/7 9:29:16 089] [01-01 18:12:15 TUYA D][tuya_ipc_sdk_init.c:122] sys start timer: 14
[2024/8/7 9:29:16 089] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:11 cnt:9
[2024/8/7 9:29:16 104] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:41 cnt:10
[2024/8/7 9:29:16 104] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:100 cnt:11
[2024/8/7 9:29:16 104] [01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:27 cnt:12
[2024/8/7 9:29:16 120] [01-01 18:12:15 TUYA N][tuya_bt_sdk.c:162] ty bt upd product:fvijo8jvloagv1gm 0
[2024/8/7 9:29:16 120] uuid: 20
[2024/8/7 9:29:16 120] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:29:16 120] dev_id_tmp: 16
[2024/8/7 9:29:16 120] 79 e4 8d 30 a2 8b 08 72 c0 28 80 c8 34 20 c9 ff 
[2024/8/7 9:29:16 120] dev_id_tmp2: 20
[2024/8/7 9:29:16 136] 75 75 69 64 63 61 61 62 32 37 62 30 61 38 33 38 64 32 33 39 
[2024/8/7 9:29:16 136] ioctl SIOCGIFBRDADDR error: Cannot assign requested address
[2024/8/7 9:29:16 152] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1066] nc_tp:2, md:0
[2024/8/7 9:29:16 153] [01-01 18:12:15 TUYA D][tuya_devos_netcfg.c:1297] dev_nw_cfg_active_stage:2
[2024/8/7 9:29:16 153] [01-01 18:12:15 TUYA D][tuya_iot_wired_wifi_api.c:608] register wifi network monitor. interval:1
[2024/8/7 9:29:16 169] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:29:16 169] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:29:16 184] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:29:16 184] [01-01 18:12:15 TUYA D][netcfg_module.c:132] type:0x10002,is_set:1
[2024/8/7 9:29:16 200] [1970-01-01 00:00:11] MainApp.c(838) <tuya_ipc_sdk_start>: [01-01 18:12:15 TUYA D][MainApp.c:854] tuya ipc sdk start is complete
[2024/8/7 9:29:16 200] killall: hostapd: no process killed
[2024/8/7 9:29:16 200] route: netmask and route address conflict
[2024/8/7 9:29:16 216] [1970-01-01 00:00:11] MainApp.c(1028) <TUYA_IPC_SDK_START>: 
[2024/8/7 9:29:16 216] [1970-01-01 00:00:11] MainApp.c(1053) <TUYA_IPC_SDK_START>: pthread_create BasicIndicatorTimer suc
[2024/8/7 9:29:16 232] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [0] change to [1]
[2024/8/7 9:29:16 248] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [0] change to [1]
[2024/8/7 9:29:16 248] [1970-01-01 00:00:11] MainApp.c(1968) <main>: FLIP
[2024/8/7 9:29:16 248] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(157)[INFO]: PictureMirror [1] change to [0]
[2024/8/7 9:29:16 264] 
[2024/8/7 9:29:16 264] [1970-01-01 00:00:11] ==> XMSDK_SetCameraSetting(166)[INFO]: PictureFlip [1] change to [0]
[2024/8/7 9:29:16 265] [1970-01-01 00:00:11] MainApp.c(1972) <main>: FLIP
[2024/8/7 9:29:16 280] [1970-01-01 00:00:11] MainApp.c(1622) <PostInit>: 
[2024/8/7 9:29:16 280] src/intelligent_track_thread.c(1398) [XM_SmartBodyTarckCreate]: 
[2024/8/7 9:29:16 296] src/intelligent_track_thread.c(1374) [Smart_Track_GetAbility]: 
[2024/8/7 9:29:16 296] src/intelligent_track_thread.c(1379) [Smart_Track_GetAbility]: 
[2024/8/7 9:29:16 296] src/intelligent_track_thread.c(1272) [GetMotorCtrlPara]: 
[2024/8/7 9:29:16 312] src/intelligent_track_thread.c(1277) [GetMotorCtrlPara]: 
[2024/8/7 9:29:16 312] src/intelligent_track_thread.c(1283) [GetMotorCtrlPara]: 
[2024/8/7 9:29:16 328] src/intelligent_track_thread.c(1298) [GetMotorCtrlPara]: max_steps_x=5006 ,max_steps_y=2161
[2024/8/7 9:29:16 328] src/intelligent_track_thread.c(1301) [GetMotorCtrlPara]: 
[2024/8/7 9:29:16 329] src/intelligent_track_thread.c(1307) [GetMotorCtrlPara]: 
[2024/8/7 9:29:16 344] src/intelligent_track_thread.c(1323) [GetMotorCtrlPara]: 
[2024/8/7 9:29:16 344] src/intelligent_track_thread.c(1336) [GetMotorCtrlPara]: track_default_degrees_y=95
[2024/8/7 9:29:16 360] src/intelligent_track_thread.c(1345) [GetMotorCtrlPara]: LoadTrackSet Motor_x_turnover:no
[2024/8/7 9:29:16 361] src/intelligent_track_thread.c(1346) [GetMotorCtrlPara]: LoadTrackSet Motor_y_turnover:no
[2024/8/7 9:29:16 376] src/intelligent_track_thread.c(1348) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 540
[2024/8/7 9:29:16 392] src/intelligent_track_thread.c(1367) [GetMotorCtrlPara]: LoadTrackSet RatioOfGearHigh:1 RatioOfGearLow:1  WIDTH_STEP = 400
[2024/8/7 9:29:16 392] src/intelligent_track_thread.c(1368) [GetMotorCtrlPara]: LoadTrackSet HEIGHT_STEP = 200
[2024/8/7 9:29:16 408] src/intelligent_track_thread.c(1390) [Smart_Track_GetAbility]: Track_Ability : Enable
[2024/8/7 9:29:16 408] src/intelligent_track_thread.c(1451) [XM_SmartBodyTarckCreate]: Intelligent Track_pthread create Success 1920x1080
[2024/8/7 9:29:16 424] [1970-01-01 00:00:11] MainApp.c(277) <BasicIndicatorTimer>: BasicIndicatorTimer start ----
[2024/8/7 9:29:16 424] src/intelligent_track_thread.c(667) [TrackProcV200]: 
[2024/8/7 9:29:16 440] [1970-01-01 00:00:11] MainApp.c(1640) <PostInit>: ln -s /mnt/mtd/Log/sofia.log /tmp/tuya.log
[2024/8/7 9:29:16 440] [1970-01-01 00:00:11] xm_ai.c(397) <XM_SetBodyMotionDetectEnable>: 
[2024/8/7 9:29:16 456] [1970-01-01 00:00:11] MainApp.c(1665) <PostInit>: MotionDetect Sensitive 1 set onvif_on_off:0 
[2024/8/7 9:29:16 456] [1970-01-01 00:00:12] xm_main.c(1502) <XM_OnVideoData_CB>: Capture the i frame time12311
[2024/8/7 9:29:16 472] curr event:3 
[2024/8/7 9:29:16 472] IPC_APP_Notify_LED_Sound_Status_CB line(480) -------------------------- IPC_START_WIFI_AP_CFG(3)
[2024/8/7 9:29:16 488] [01-01 18:12:16 TUYA D][ap_netcfg.c:797] start ap success:SmartLife-1650
[2024/8/7 9:29:16 488] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:29:16 488] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:29:16 504] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:29:16 504] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10002,is_set:0
[2024/8/7 9:29:16 504] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10100,is_set:0
[2024/8/7 9:29:16 520] [01-01 18:12:16 TUYA D][netcfg_module.c:132] type:0x10004,is_set:0
[2024/8/7 9:29:16 520] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10002
[2024/8/7 9:29:16 536] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10100
[2024/8/7 9:29:16 536] [01-01 18:12:16 TUYA D][netcfg_module.c:367] netcfg module start type:0x10004
[2024/8/7 9:29:16 536] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:206] dev_nw_cfg_active_stage:3
[2024/8/7 9:29:16 552] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:209] ble init mesh
[2024/8/7 9:29:16 552] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_app_key isFuzzy:0 skipCnt:0
[2024/8/7 9:29:16 568] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:16 568] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:16 568] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:16 584] [01-01 18:12:16 TUYA D][tuya_ble_api.c:959] read app key err:-6.
[2024/8/7 9:29:16 584] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_network_key isFuzzy:0 skipCnt:0
[2024/8/7 9:29:16 600] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:16 601] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:16 697] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:16 712] [01-01 18:12:16 TUYA D][tuya_ble_api.c:965] read newtwork key err:-6.
[2024/8/7 9:29:16 712] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:ble_beaconkey isFuzzy:0 skipCnt:0
[2024/8/7 9:29:16 712] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:16 728] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:16 728] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[2024/8/7 9:29:16 744] [01-01 18:12:16 TUYA D][tuya_ble_api.c:943] read beacon key err:-6.
[2024/8/7 9:29:16 745] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:lpc_task,stackDepth:3072,totalstackDepth:17920,priority:3
[2024/8/7 9:29:16 760] [01-01 18:12:16 TUYA D][tuya_devos_netlink.c:102] gw_wsm stat:0
[2024/8/7 9:29:16 760] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:462] wifi netstat changed to:2  -->>
[2024/8/7 9:29:16 776] __IPC_APP_Get_Net_Status_cb line(193) -------------------------- stat(2)==STAT_AP_STA_UNCFG 
[2024/8/7 9:29:16 776] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:468] wifi netstat changed to:2  <<--
[2024/8/7 9:29:16 792] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:483] wired netstat changed to:1  -->>
[2024/8/7 9:29:16 793] __IPC_APP_Get_Net_Status_cb line(213) -------------------------- stat(6)==STAT_STA_CONN 
[2024/8/7 9:29:16 793] [01-01 18:12:16 TUYA D][tuya_iot_wired_wifi_api.c:489] wired netstat changed to:1  <<--
[2024/8/7 9:29:16 808] tuya_ipc_wired_demo.c(50) [tuya_adapter_wired_if_connect_internet]: 
[2024/8/7 9:29:16 808] [01-01 18:12:16 TUYA W][tuya_iot_wired_wifi_api.c:518] bnw_if_wired_connect_net 1 error.
[2024/8/7 9:29:16 824] [01-01 18:12:16 TUYA D][ap_netcfg.c:902] ap cfg start:65538
[2024/8/7 9:29:16 824] [01-01 18:12:16 TUYA I][uni_thread.c:228] thread_create name:udp_ap_v3,stackDepth:3584,totalstackDepth:21504,priority:5
[2024/8/7 9:29:16 840] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10002 ret:0
[2024/8/7 9:29:16 840] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10100 ret:0
[2024/8/7 9:29:16 840] [01-01 18:12:16 TUYA D][bt_netcfg.c:117] bt netcfg start
[2024/8/7 9:29:16 856] [01-01 18:12:16 TUYA N][tuya_ble_api.c:439] update bound stat:0
[2024/8/7 9:29:16 856] [01-01 18:12:16 TUYA D][netcfg_module.c:115] start 0x10004 ret:0
[2024/8/7 9:29:16 872] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:lpc_task Exec Start. Set to Running Stat
[2024/8/7 9:29:16 872] [01-01 18:12:16 TUYA D][tuya_ble_api.c:315] upd adv para, send conn_req beacon.
[2024/8/7 9:29:16 872] dev id key: 16
[2024/8/7 9:29:16 888] d0 7d 89 57 d1 [01-01 18:12:16 TUYA D][app_agent.c:1363] Setup TCP Server On Port:6668
[2024/8/7 9:29:16 888] c6 0a de ff ad fc 2e 59 32 26 7a 
[2024/8/7 9:29:16 888] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(529):  ---
[2024/8/7 9:29:16 904] [01-01 18:12:16 TUYA I][bt_ext_porting.c:532] [TUYA-BTUART]reset adv: 
[2024/8/7 9:29:16 904] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:29:16 904] [01-01 18:12:16 TUYA I][bt_ext_porting.c:534] [TUYA-BTUART]resp: 
[2024/8/7 9:29:16 920] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:29:16 920] --- tracepoint bt_ext_porting.c,tuya_ext_bt_reset_adv(539): start_adv ---
[2024/8/7 9:29:16 936] [01-01 18:12:16 TUYA I][bt_ext_porting.c:547] [TUYA-BTUART]malloc g_adv_data.data(0x9a9378),len(28)
[2024/8/7 9:29:16 936] [01-01 18:12:16 TUYA I][bt_ext_porting.c:552] [TUYA-BTUART]g_adv_data: 
[2024/8/7 9:29:16 952] 2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:29:16 952] [01-01 18:12:16 TUYA I][bt_ext_porting.c:556] [TUYA-BTUART]malloc g_rsp_data.data(0x9a93f8),len(30)
[2024/8/7 9:29:16 968] [01-01 18:12:16 TUYA I][bt_ext_porting.c:561] [TUYA-BTUART]g_rsp_data: 
[2024/8/7 9:29:16 968] 3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:29:16 968] ---[XmBleAdvertiseEx][1161]: 
[2024/8/7 9:29:16 968] adv_len:28
[2024/8/7 9:29:16 984] adv_data:2 1 6 3 2 1 a2 14 16 1 a2 0 66 76 69 6a 6f 38 6a 76 6c 6f 61 67 76 31 67 6d 
[2024/8/7 9:29:16 984] svc_data_uuid16 len:18
[2024/8/7 9:29:17 000] [01-01 18:12:16 TUYA D][uni_thread.c:250] Thread:udp_ap_v3 Exec Start. Set to Running Stat
[2024/8/7 9:29:17 001] udhcpd (v1.22.1) started
[2024/8/7 9:29:17 001] udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
[2024/8/7 9:29:17 016] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:29:17 017] ---[XmBleAdvertiseEx][1210]: rc=[0]
[2024/8/7 9:29:17 017] ---[XmBleAdvertiseEx][1212]:  ---
[2024/8/7 9:29:17 017] rsp_len:30
[2024/8/7 9:29:17 032] rsp_or_name:3 9 54 59 19 ff d0 7 9 3 3 0 c 0 cf d4 41 6c 31 f5 a3 31 fb ba 39 66 1f d0 a e3 
[2024/8/7 9:29:17 032] mfg_data len:30
[2024/8/7 9:29:17 032] ---[XmBleAdvertiseEx][1226]:  ---
[2024/8/7 9:29:17 032] ---[XmBleAdvertiseEx][1233]:  ---
[2024/8/7 9:29:17 048] ---[XmBleAdvertiseEx][1238]:  ---
[2024/8/7 9:29:17 051] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:29:17 051] ---[XmBleAdvertiseEx][1241]: rc=[0]
[2024/8/7 9:29:17 064] ---[XmBleAdvertiseEx][1243]:  ---
[2024/8/7 9:29:17 065] ---[XmBleAdvertiseEx][1251]:  ---
[2024/8/7 9:29:17 065] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:29:17 080] [1970-01-01 00:00:12] MainApp.c(1978) <main>: wait for g_DeviceOnline ... 
[2024/8/7 9:29:17 080] adv_start rc = 0x0
[2024/8/7 9:29:17 080] ---[XmBleAdvertiseEx][1258]:  ---
[2024/8/7 9:29:17 080] [01-01 18:12:16 TUYA N][tuya_ble_api.c:727] ble adv && resp changed
[2024/8/7 9:29:17 096] [01-01 18:12:16 TUYA D][tuya_devos_activate.c:105] qr active env pro, region null
[2024/8/7 9:29:17 096] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca_cnt isFuzzy:0
[2024/8/7 9:29:17 113] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:29:17 113] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca_cnt not find
[2024/8/7 9:29:17 113] [01-01 18:12:16 TUYA D][simplekv.c:1348] delete key:tls_ca isFuzzy:1
[2024/8/7 9:29:17 128] [01-01 18:12:16 TUYA D][simplekv.c:1354] cnt:8 delete bit arr len:1
[2024/8/7 9:29:17 128] [01-01 18:12:16 TUYA D][simplekv.c:1395] key:tls_ca not find
[2024/8/7 9:29:17 144] [01-01 18:12:16 TUYA D][simplekv.c:1211] read key:tls_ca_cnt isFuzzy:0 skipCnt:0
[2024/8/7 9:29:17 144] [01-01 18:12:16 TUYA D][simplekv.c:1247] no key find
[2024/8/7 9:29:17 144] [01-01 18:12:16 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[2024/8/7 9:29:17 160] [01-01 18:12:16 TUYA D][simplekv.c:1336] __read_kv_wi
