 * @file tuya_app_main.c
 * @brief tuya_app_main module is used to
 * @date 2022-10-28
#include "tuya_svc_netmgr.h"
#if defined(ENABLE_WIFI_SERVICE) && (ENABLE_WIFI_SERVICE == 1)
#include "tuya_iot_wifi_api.h"
#if defined(ENABLE_WIRED) && (ENABLE_WIRED == 1)
#include "tuya_iot_base_api.h"
#include "tuya_iot_com_api.h"
#include "tuya_ws_db.h"
#include "base_event.h"
#include "mf_test.h"
#include "mqc_app.h"
#if defined(ENABLE_LWIP) && (ENABLE_LWIP == 1)
#include "lwip_init.h"
#include "tkl_spi.h"
#include "tal_uart.h"
#include "dp_process.h"
#include "app_key.h"
#include "app_led.h"
#define PID "uiiyltkjmkhwumga"
#define UUID "uuid8c979a2cea91955c"
#define AUTHKEY "8TxpnLMkuovxRtlh5TfICLipjzZKnc07"
/* The registration code here does not work, you need to apply for a new one.
 * https://developer.tuya.com/cn/docs/iot/lisence-management?id=Kb4qlem97idl0
// #define UUID     "f998xxxxxxxx2409"
// #define AUTHKEY  "WEHAxxxxxxxxxxxxxxxxxxxxxxxxVVkf"
/* network button, LED pin */
#define KEY_PIN 7
#define LED_PIN 26
/* SPI */
#define SPI_BUFFER_LEN 40
#define SPI_ID TUYA_SPI_NUM_0
#define SPI_FREQ 400000
#define TASK_SPI_PRIORITY THREAD_PRIO_6
#define TASK_SPI_SIZE 2048
extern void tuya_ble_enable_debug(bool enable);
/* app thread handle */
STATIC THREAD_HANDLE ty_app_thread = NULL;
STATIC THREAD_HANDLE spi_thrd_hdl = NULL;
/*spi init*/
STATIC TUYA_SPI_BASE_CFG_T spi_cfg = {
    .mode = TUYA_SPI_MODE0,
    .freq_hz = SPI_FREQ,
    .databits = TUYA_SPI_DATA_BIT8,
    .bitorder = TUYA_SPI_ORDER_LSB2MSB,
    .role = TUYA_SPI_ROLE_MASTER,
    .type = TUYA_SPI_AUTO_TYPE};
#if defined(ENABLE_QRCODE_ACTIVE) && (ENABLE_QRCODE_ACTIVE == 1)
// qrcode打印
extern INT_T qrcode_exec(INT_T argc, CHAR_T **argv);
STATIC INT_T __qrcode_printf(CHAR_T *msg)
    CHAR_T *qrcode_argv[] = {
        "qrcode_exec", "-m", "3", "-t", "ansiutf8", msg};
    return qrcode_exec(sizeof(qrcode_argv) / sizeof(qrcode_argv[0]), qrcode_argv);
// TuyaOS获取到短链接之后调用此接口输出qrcode打印
STATIC VOID __qrcode_active_shourturl_cb(CONST CHAR_T *shorturl)
    if (NULL == shorturl)
    TAL_PR_DEBUG("shorturl : %s", shorturl);
    ty_cJSON *item = ty_cJSON_Parse(shorturl);
    __qrcode_printf(ty_cJSON_GetObjectItem(item, "shortUrl")->valuestring);
    ty_cJSON_Delete(item);
 * @brief SOC device upgrade entry
 * @param[in] fw: firmware info
 * @return OPRT_OK on success. Others on error, please refer to "tuya_error_code.h".
STATIC OPERATE_RET __soc_dev_rev_upgrade_info_cb(IN CONST FW_UG_S *fw)
    TAL_PR_DEBUG("SOC Rev Upgrade Info");
    TAL_PR_DEBUG("fw->tp:%d", fw->tp);
    TAL_PR_DEBUG("fw->fw_url:%s", fw->fw_url);
    TAL_PR_DEBUG("fw->fw_hmac:%s", fw->fw_hmac);
    TAL_PR_DEBUG("fw->sw_ver:%s", fw->sw_ver);
    TAL_PR_DEBUG("fw->file_size:%u", fw->file_size);
 * @brief SOC device cloud state change callback
 * @param[in] status: current status
STATIC VOID_T __soc_dev_status_changed_cb(IN CONST GW_STATUS_E status)
    TAL_PR_DEBUG("SOC TUYA-Cloud Status:%d", status);
 * @brief SOC device DP query entry
 * @param[in] dp_qry: DP query list
STATIC VOID_T __soc_dev_dp_query_cb(IN CONST TY_DP_QUERY_S *dp_qry)
    UINT32_T index = 0;
    TAL_PR_DEBUG("SOC Rev DP Query Cmd");
    if (dp_qry->cid != NULL)
        TAL_PR_ERR("soc not have cid.%s", dp_qry->cid);
    if (dp_qry->cnt == 0)
        TAL_PR_DEBUG("soc rev all dp query");
        respone_device_all_status();
        TAL_PR_DEBUG("soc rev dp query cnt:%d", dp_qry->cnt);
        for (index = 0; index < dp_qry->cnt; index++)
            TAL_PR_DEBUG("rev dp query:%d", dp_qry->dpid[index]);
            // UserTODO
 * @brief SOC device format command data delivery entry
 * @param[in] dp: obj dp info
STATIC VOID_T __soc_dev_obj_dp_cmd_cb(IN CONST TY_RECV_OBJ_DP_S *dp)
    TAL_PR_DEBUG("SOC Rev DP Obj Cmd t1:%d t2:%d CNT:%u", dp->cmd_tp, dp->dtt_tp, dp->dps_cnt);
    dp_obj_process(dp->dps, dp->dps_cnt);
 * @brief SOC device transparently transmits command data delivery entry
 * @param[in] dp: raw dp info
STATIC VOID_T __soc_dev_raw_dp_cmd_cb(IN CONST TY_RECV_RAW_DP_S *dp)
    TAL_PR_DEBUG("SOC Rev DP Raw Cmd t1:%d t2:%d dpid:%d len:%u", dp->cmd_tp, dp->dtt_tp, dp->dpid, dp->len);
    dp_raw_process(dp->dpid, dp->data, dp->len);
 * @brief  app process when device reset
 * @param[in] type: gateway reset type
STATIC VOID_T __soc_dev_reset_inform_cb(GW_RESET_TYPE_E type)
    TAL_PR_DEBUG("reset type %d", type);
 * @brief SOC external network status change callback
 * @param[in/out] data
 * @return STATIC
STATIC OPERATE_RET __soc_dev_net_status_cb(VOID *data)
    STATIC BOOL_T s_syn_all_status = FALSE;
    TAL_PR_DEBUG("network status changed!");
    if (tuya_svc_netmgr_linkage_is_up(LINKAGE_TYPE_DEFAULT))
        TAL_PR_DEBUG("linkage status changed, current status is up");
        if (get_mqc_conn_stat())
            TAL_PR_DEBUG("mqtt is connected!");
            if (FALSE == s_syn_all_status)
                upload_device_all_status();
                s_syn_all_status = TRUE;
            // UserTODO
        TAL_PR_DEBUG("linkage status changed, current status is down");
        // UserTODO
 * @brief mf uart init
 * @param[in] baud: Baud rate
 * @param[in] bufsz: uart receive buffer size
VOID mf_uart_init_callback(UINT_T baud, UINT_T bufsz)
    TAL_UART_CFG_T cfg;
    memset(&cfg, 0, sizeof(TAL_UART_CFG_T));
    cfg.base_cfg.baudrate = baud;
    cfg.base_cfg.databits = TUYA_UART_DATA_LEN_8BIT;
    cfg.base_cfg.parity = TUYA_UART_PARITY_TYPE_NONE;
    cfg.base_cfg.stopbits = TUYA_UART_STOP_LEN_1BIT;
    cfg.rx_buffer_size = bufsz;
    tal_uart_init(TUYA_UART_NUM_0, &cfg);
 * @brief mf uart free
 * @param[in] none
VOID mf_uart_free_callback(VOID)
 * @brief mf uart send function
 * @param[in] data: send data
 * @param[in] len: send data length
VOID mf_uart_send_callback(IN BYTE_T *data, IN CONST UINT_T len)
    tal_uart_write(TUYA_UART_NUM_0, data, len);
 * @brief mf uart receive function
 * @param[in] buf: receive buffer
 * @param[in] len: receive buffer max length
 * @return receive data length
UINT_T mf_uart_recv_callback(OUT BYTE_T *buf, IN CONST UINT_T len)
    return tal_uart_read(TUYA_UART_NUM_0, buf, len);
 * @brief Product test callback function
 * @param[in] cmd: Command
 * @param[in] data: data
 * @param[out] ret_data: Resulting data
 * @param[out] ret_len: Resulting data length
OPERATE_RET mf_user_product_test_callback(USHORT_T cmd, UCHAR_T *data, UINT_T len, OUT UCHAR_T **ret_data, OUT USHORT_T *ret_len)
    /* USER todo */
    // gpio  test  refer to tuyaos_demo_examples -> src/examples/service_mf_test
 * @brief mf configure write callback functions
 * @param[in] none
VOID mf_user_callback(VOID)
 * @brief Callback function before entering the production test
 * @param[in] none
VOID mf_user_enter_mf_callback(VOID)
 * @brief SOC device initialization
 * @param[in] none
OPERATE_RET __soc_device_init(VOID_T)
    ty_subscribe_event(EVENT_LINK_UP, "quickstart", __soc_dev_net_status_cb, SUBSCRIBE_TYPE_NORMAL);
    ty_subscribe_event(EVENT_LINK_DOWN, "quickstart", __soc_dev_net_status_cb, SUBSCRIBE_TYPE_NORMAL);
    ty_subscribe_event(EVENT_MQTT_CONNECTED, "quickstart", __soc_dev_net_status_cb, SUBSCRIBE_TYPE_NORMAL);
#if (defined(UUID) && defined(AUTHKEY))
#ifndef ENABLE_KV_FILE
    ws_db_init_mf();
    /* Set authorization information
     * Note that if you use the default authorization information of the code, there may be problems of multiple users and conflicts,
     * so try to use all the authorizations purchased from the tuya iot platform.
     * Buying guide: https://developer.tuya.com/cn/docs/iot/lisence-management?id=Kb4qlem97idl0.
     * You can also apply for two authorization codes for free in the five-step hardware development stage of the Tuya IoT platform.
     * Authorization information can also be written through the production testing tool.
     * When the production testing function is started and the authorization is burned with the Tuya Cloud module tool,
     * please comment out this piece of code.
#ifdef ENABLE_WIFI_SERVICE
    TUYA_CALL_ERR_RETURN(tuya_iot_set_wf_gw_prod_info(&prod_info));
    TUYA_CALL_ERR_RETURN(tuya_iot_set_gw_prod_info(&prod_info));
    /*authorization is burned with the Tuya Cloud module tool
     *If you want to get the specific details, such as GPIO TEST,
     *please refer to the tuyaos_demo_examples -> src/examples/service_mf_test.*/
    MF_IMPORT_INTF_S intf = {0};
    intf.uart_init = mf_uart_init_callback;
    intf.uart_free = mf_uart_free_callback;
    intf.uart_send = mf_uart_send_callback;
    intf.uart_recv = mf_uart_recv_callback;
    intf.mf_user_product_test = mf_user_product_test_callback;
    intf.user_callback = mf_user_callback;
    intf.user_enter_mf_callback = mf_user_enter_mf_callback;
    TUYA_CALL_ERR_RETURN(mf_init(&intf, APP_BIN_NAME, USER_SW_VER, TRUE));
    TAL_PR_NOTICE("mf_init successfully");
    /* Initialize TuyaOS product information */
    TY_IOT_CBS_S iot_cbs = {0};
    iot_cbs.gw_status_cb = __soc_dev_status_changed_cb;
    iot_cbs.gw_ug_cb = __soc_dev_rev_upgrade_info_cb;
    iot_cbs.gw_reset_cb = __soc_dev_reset_inform_cb;
    iot_cbs.dev_obj_dp_cb = __soc_dev_obj_dp_cmd_cb;
    iot_cbs.dev_raw_dp_cb = __soc_dev_raw_dp_cmd_cb;
    iot_cbs.dev_dp_query_cb = __soc_dev_dp_query_cb;
    iot_cbs.active_shorturl = __qrcode_active_shourturl_cb;
    TUYA_CALL_ERR_RETURN(tuya_iot_wf_soc_dev_init(GWCM_OLD, WF_START_AP_FIRST, &iot_cbs, PID, USER_SW_VER));
#ifdef ENABLE_WIRED
    // init wired linkage
    TUYA_CALL_ERR_RETURN(tuya_svc_wired_init());
    TUYA_CALL_ERR_RETURN(tuya_iot_soc_init(&iot_cbs, PID, USER_SW_VER));
    tuya_ble_enable_debug(false);
    /* Network button, LED initialization */
    app_led_init(LED_PIN);
    app_key_init(KEY_PIN);
STATIC VOID spi_data_task(PVOID_T args)
    uint8_t spi_send_buffer[SPI_BUFFER_LEN];
    uint8_t spi_rcv_buffer[SPI_BUFFER_LEN];
    uint8_t i = 0;
    TUYA_SPI_STATUS_T spi_status;
    TAL_PR_NOTICE("SPI Task is running ...");
    memset(spi_send_buffer, 0, sizeof(spi_send_buffer));
    for (;;)
        spi_send_buffer[0] = i++;
        /* tranfer data via SPI */
        TUYA_CALL_ERR_LOG(tkl_spi_transfer(SPI_ID, spi_send_buffer, spi_rcv_buffer, SPI_BUFFER_LEN));
        TUYA_CALL_ERR_LOG(tkl_spi_get_status(SPI_ID, &spi_status)); // get SPI status
        // TAL_PR_DEBUG("spi status: b:%d l:%d f:%d", spi_status.busy, spi_status.data_lost, spi_status.mode_fault);
        if (rt == OPRT_OK)
            if (i == 0)
                TAL_PR_ERR("tkl_spi_transfer OK");
            TAL_PR_ERR("tkl_spi_transfer failed");
            if (i == 0)
                TUYA_CALL_ERR_LOG(tkl_spi_deinit(SPI_ID));
                TUYA_CALL_ERR_LOG(tkl_spi_init(SPI_ID, &spi_cfg));
        tal_system_sleep(25);
STATIC VOID_T user_main(VOID_T)
    /* Initialization, because DB initialization takes a long time,
     * which affects the startup efficiency of some devices,
     * so special processing is performed during initialization to delay initialization of DB
#if OPERATING_SYSTEM == SYSTEM_LINUX
    rt = system("mkdir -p ./tuya_db_files/");
    TUYA_CALL_ERR_LOG(tuya_iot_init_params("./tuya_db_files/", NULL));
    TY_INIT_PARAMS_S init_param = {0};
    init_param.init_db = TRUE;
    strcpy(init_param.sys_env, TARGET_PLATFORM);
    TUYA_CALL_ERR_LOG(tuya_iot_init_params(NULL, &init_param));
    TAL_PR_NOTICE("sdk_info:%s", tuya_iot_get_sdk_info());                        /* print SDK information */
    TAL_PR_NOTICE("name:%s:%s", APP_BIN_NAME, USER_SW_VER);                       /* print the firmware name and version */
    TAL_PR_NOTICE("firmware compiled at %s %s", __DATE__, __TIME__);              /* print firmware compilation time */
    TAL_PR_NOTICE("system reset reason:[%d]", tal_system_get_reset_reason(NULL)); /* print system reboot causes */
    tal_log_set_manage_attr(TAL_LOG_LEVEL_DEBUG);
    /* Initialization device */
    TAL_PR_DEBUG("device_init in");
    TUYA_CALL_ERR_LOG(__soc_device_init());
    /*THREAD for spi */
    THREAD_CFG_T spi_thrd_cfg = {
        .thrdname = "spi_thrd",
        .stackDepth = TASK_SPI_SIZE,
        .priority = TASK_SPI_PRIORITY,
    TAL_PR_NOTICE("SPI init ...");
    /*spi init*/
    if (NULL == spi_thrd_hdl)
        TUYA_CALL_ERR_LOG(tal_thread_create_and_start(&spi_thrd_hdl, NULL, NULL, spi_data_task, NULL, &spi_thrd_cfg));
    TAL_PR_NOTICE("... SPI init done!");
 * @brief  task thread
 * @param[in] arg:Parameters when creating a task
STATIC VOID_T tuya_app_thread(VOID_T *arg)
    /* Initialization LWIP first!!! */
    TUYA_LwIP_Init();
    user_main();
    tal_thread_delete(ty_app_thread);
 * @brief user entry function
 * @param[in] none:
INT_T main(INT_T argc, CHAR_T **argv)
VOID_T tuya_app_main(VOID)
    THREAD_CFG_T thrd_param = {4096, 4, "tuya_app_main"};
    tal_thread_create_and_start(&ty_app_thread, NULL, NULL, tuya_app_thread, NULL, &thrd_param);
    while (1)
        tal_system_sleep(1000);
