﻿tkl_wifi_get_ip!
get ipv4 local ip!
WIFI mode[0] Get IP failed
-------- T31 gpio status --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
gpio status is output=0
Pull up disable
Pull down disable
Drive strength is 8mA
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
gpio status is output=1
Pull up disable
Pull down disable
[root@Ingenic-uc1_1:~]# 
[root@Ingenic-uc1_1:~]# tkl_wifi_get_ip!
get ipv4 local ip!
[root@Ingenic-uc1_1:~]# -------- T31 gpio status --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
ktkl_wifi_get_ip!
get ipv4 local ip!
ill-------- T31 gpio status --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
alltkl_wifi_get_ip!
get ipv4 local ip!
 -9-------- T31 gpio status --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
 tkl_wifi_get_ip!
get ipv4 local ip!
t2-------- T31 gpio status --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
3tkl_wifi_get_ip!
get ipv4 local ip!
_-------- T31 gpio status --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tutkl_wifi_get_ip!
get ipv4 local ip!
ya-------- T31 gpio status --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
_catkl_wifi_get_ip!
get ipv4 local ip!
m
[root@Ingenic-uc1_1:~]# [   96.977681] sc2336 stream off
[   97.182068] wait stop  q->num_buffers=2 q->done_count=1
[root@Ingenic-uc1_1:~]# [   97.582044] streamoff stop！！
[   97.602060] wait stop  q->num_buffers=2 q->done_count=1
[root@Ingenic-uc1_1:~]# [   98.002049] streamoff stop！！
[   98.005463] [atbm_log]:ioctl_release(80938100)(81f1e780)
[root@Ingenic-uc1_1:~]# ps
  PID USER       VSZ STAT COMMAND
    1 root      1832 S    {linuxrc} init
    2 root         0 SW   [kthreadd]
    3 root         0 SW   [ksoftirqd/0]
    4 root         0 SW   [kworker/0:0]
    5 root         0 SW<  [kworker/0:0H]
    6 root         0 SW   [kworker/u2:0]
    7 root         0 SW   [rcu_preempt]
    8 root         0 SW   [rcu_bh]
    9 root         0 SW   [rcu_sched]
   10 root         0 SW   [watchdog/0]
   11 root         0 SW<  [khelper]
   12 root         0 SW<  [writeback]
   13 root         0 SW<  [bioset]
   14 root         0 SW<  [kblockd]
   15 root         0 SW   [khubd]
   16 root         0 SW   [kworker/0:1]
   17 root         0 SW<  [cfg80211]
   18 root         0 SW<  [rpciod]
   19 root         0 SW   [kswapd0]
   20 root         0 SW   [fsnotify_mark]
   21 root         0 SW<  [nfsiod]
   22 root         0 SW<  [crypto]
   36 root         0 SW   [kworker/u2:1]
   37 root         0 SW<  [deferwq]
   38 root         0 SW<  [kworker/0:1H]
   39 root         0 SW   [kworker/0:2]
   40 root         0 SW   [kworker/0:3]
   52 root      1820 S    telnetd
   58 root         0 SWN  [jffs2_gcd_mtd4]
   60 root      1832 S    -sh
   65 root         0 SW   [irq/37-isp-m0]
   67 root         0 SW   [irq/38-isp-w02]
   71 root         0 SW   [irq/46-isp-ivdc]
  101 root         0 SW<  [phy0-atbm_wq]
  102 root         0 SW   [phy0-atbm_prvmg]
  103 root         0 SW   [phy0-usb_atbm_b]
  116 root         0 SW   [phy0-ble_recv]
  117 root         0 SW   [phy0-ble_xmit]
  366 root      1824 R    ps
[root@Ingenic-uc1_1:~]# md5sum /system/bin/t23_tuya_cam 
334772c3c5b14275e342df2eda5ec28e  /system/bin/t23_tuya_cam
[root@Ingenic-uc1_1:~]# ls -l /system/bin/t23_tuya_cam 
-rwxrwxrwx    1 1000     1000       3953440 Aug 23  2025 /system/bin/t23_tuya_cam
[root@Ingenic-uc1_1:~]# cat /system/init/
app_init.sh  reboot.sh
[root@Ingenic-uc1_1:~]# cat /system/init/app_init.sh 
#!/bin/sh
insmod /system/lib/modules/tx-isp-t23.ko isp_clk=200000000
insmod /system/lib/modules/sensor_sc2336_t23.ko
insmod /system/lib/modules/sinfo.ko
insmod /system/lib/modules/audio.ko
insmod /system/lib/modules/atbm6x3x_wifi_usb.ko wifi_bt_comb=1
if [ -f "/config/tuya_device_cfg.json" ];then
        echo "tuya cfg exist!"
        echo "copy tuya cfg"
        cp /system/config/tuya_device_cfg.json /config
        chmod 777 /config/tuya_device_cfg.json
if [ -d "/config/media" ];then
        echo "/config/media exist!"
        mkdir -p /config/media
sleep 1
ifconfig wlan0 up
/system/bin/t23_tuya_cam &
if [ -f "/mnt/sdcard/update.zip" ];then
        echo "start update"
    pkill -9 t23_tuya_cam
    cd /mnt/sdcard/
    tar xvf update.zip -C /tmp/
    sync
    cd /tmp/UPDATE
    sh update_fw.sh
    rm /mnt/sdcard/update.zip
    sleep 3
    reboot
    sleep 1
    reboot
[root@Ingenic-uc1_1:~]# lsmod
atbm6x3x_wifi_usb 1406185 0 - Live 0xc0498000 (O)
audio 47456 0 - Live 0xc02ff000 (O)
sinfo 7508 0 - Live 0xc02e7000 (O)
sensor_sc2336_t23 9877 0 - Live 0xc02dc000 (O)
tx_isp_t23 1013359 1 sensor_sc2336_t23, Live 0xc01b1000 (O)
[root@Ingenic-uc1_1:~]# ifconfig 
lo        Link encap:Local Loopback  
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0 
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr 4C:37:DE:25:15:1B  
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000 
[root@Ingenic-uc1_1:~]# reboot
[root@Ingenic-uc1_1:~]# umount: tmpfs busy - remounted read-only
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot[  186.091496] Restarting system.
[  186.094708] Restarting after 4 ms
U-Boot SPL 2013.07 (Mar 11 2025 - 20:13:29)
Board info: T23N
apll_freq = 1188000000 
mpll_freq = 1200000000 
sdram init start
DDR clk rate 600000000
DDR_PAR of eFuse: 00000000 00000000
sdram init finished
image entry point: 0x80100000
U-Boot 2013.07 (Mar 11 2025 - 20:13:29)
Board: ISVP (Ingenic XBurst T23 SoC)
DRAM:  64 MiB
Top of RAM usable for U-Boot at: 84000000
Reserving 441k for U-Boot at: 83f90000
Reserving 32784k for malloc() at: 81f8c000
Reserving 32 Bytes for Board Info at: 81f8bfe0
Reserving 124 Bytes for Global Data at: 81f8bf64
Reserving 128k for boot params() at: 81f6bf64
Stack Pointer at: 81f6bf48
Now running in RAM - U-Boot at: 83f90000
MMC:   msc: 0
the manufacturer c8
SF: Detected GD25Q64C
In:    serial
Out:   serial
Err:   serial
Net:   ====>PHY not found!Jz4775-9161
Hit any key to stop autoboot:  0 
the manufacturer c8
--->probe spend 4 ms
SF: 2097152 bytes @ 0x40000 Read: OK
--->read spend 674 ms
## Booting kernel from Legacy Image at 80600000 ...
   Image Name:   Linux-3.10.14__isvp_pike_1.0__
   Image Type:   MIPS Linux Kernel Image (lzma compressed)
   Data Size:    1651363 Bytes = 1.6 MiB
   Load Address: 80010000
   Entry Point:  80386430
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting kernel ...
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.14__isvp_pike_1.0__ (hgh@hgh-virtual-machine) (gcc version 5.4.0 (Ingenic Ingenic r3.3.0-gcc540 Smaller Size 2023.05-22) ) #1 PREEMPT Sun Feb 23 10:56:29 CST 2025
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 RESET ERROR PC:801BFBC0
[    0.000000] [<801bfbc0>] __delay+0x0/0x10
[    0.000000] CPU0 revision is: 00d00100 (Ingenic Xburst)
[    0.000000] FPU revision is: 00b70000
[    0.000000] cgu_vpu clk should be opened!
[    0.000000] CCLK:1188MHz L2CLK:594Mhz H0CLK:200MHz H2CLK:200Mhz PCLK:100Mhz
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 00499000 @ 00010000 (usable)
[    0.000000]  memory: 00037000 @ 004a9000 (usable after init)
[    0.000000] User-defined physical RAM map:
[    0.000000]  memory: 02d00000 @ 00000000 (usable)
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x02cfffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x02cfffff]
[    0.000000] Primary instruction cache 16kB, 8-way, VIPT, linesize 32 bytes.
[    0.000000] Primary data cache 16kB, 8-way, VIPT, no aliases, linesize 32 bytes
[    0.000000] pls check processor_id[0x00d00100],sc_jz not support!
[    0.000000] MIPS secondary cache 64kB, 8-way, linesize 32 bytes.
[    0.000000] Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 11430
[    0.000000] Kernel command line: console=ttyS1,115200n8 mem=45M@0x0 rmem=19M@0x2D00000 init=/linuxrc rootfstype=squashfs root=/dev/mtdblock2 rw mtdparts=jz_sfc:256k(boot),2048k(kernel),1024k(root),4608k(appfs),256k(config)
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 40088k/46080k available (3577k kernel code, 5992k reserved, 1129k data, 220k init, 0k highmem)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:347
[    0.000000] clockevents_config_and_register success.
[    0.000020] Calibrating delay loop... 1185.38 BogoMIPS (lpj=5926912)
[    0.087808] pid_max: default: 32768 minimum: 301
[    0.092703] Mount-cache hash table entries: 512
[    0.097738] Initializing cgroup subsys debug
[    0.101996] Initializing cgroup subsys freezer
[    0.108786] regulator-dummy: no parameters
[    0.113026] NET: Registered protocol family 16
[    0.129132] bio: create slab <bio-0> at 0
[    0.135263] jz-dma jz-dma: JZ SoC DMA initialized
[    0.140250] usbcore: registered new interface driver usbfs
[    0.145855] usbcore: registered new interface driver hub
[    0.151296] usbcore: registered new device driver usb
[    0.156569] i2c-gpio i2c-gpio.1: using pins 57 (SDA) and 58 (SCL)
[    0.162758]  (null): set:249  hold:250 dev=100000000 h=500 l=500
[    0.170665] Switching to clocksource jz_clocksource
[    0.175616] cfg80211: Calling CRDA to update world regulatory domain
[    0.182625] NET: Registered protocol family 2
[    0.187534] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.194490] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.200888] TCP: Hash tables configured (established 512 bind 512)
[    0.207219] TCP: reno registered
[    0.210423] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.216384] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.222944] NET: Registered protocol family 1
[    0.227600] RPC: Registered named UNIX socket transport module.
[    0.233596] RPC: Registered udp transport module.
[    0.238297] RPC: Registered tcp transport module.
[    0.243080] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.249909] freq_udelay_jiffys[0].max_num = 10
[    0.254378] cpufreq  udelay  loops_per_jiffy
[    0.258750] 12000     59867   59867
[    0.262017] 24000     119735  119735
[    0.265474] 60000     299338  299338
[    0.268904] 120000    598677  598677
[    0.272481] 200000    997796  997796
[    0.275967] 300000    1496694         1496694
[    0.279675] 600000    2993389         2993389
[    0.283406] 792000    3951274         3951274
[    0.287092] 1008000   5028895         5028895
[    0.290888] 1200000   5986779         5986779
[    0.299258] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.306077] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
[    0.311917] msgmni has been set to 78
[    0.317512] io scheduler noop registered
[    0.321440] io scheduler cfq registered (default)
[    0.326484] wait stable.[288][cgu_vpu]
[    0.330206] cgu_vpu can not set to 450000000, will change!!!
[    0.337433] jz-uart.1: ttyS1 at MMIO 0x10031000 (irq = 58) is a uart1
[    0.345224] console [ttyS1] enabled, bootconsole disabled
[    0.360299] brd: module loaded
[    0.365667] loop: module loaded
[    0.369526] zram: Created 2 device(s) ...
[    0.373848] logger: created 256K log 'log_main'
[    0.378916] jz TCU driver register completed
[    0.383857] the id code = c84017, the flash name is GD25Q64C
[    0.389726] jz-sfc jz-sfc: sfc use DMA mode
[    0.394106] jz-sfc jz-sfc: nor flash now use standard mode!
[    0.399874] JZ SFC Controller for SFC channel 0 driver register
[    0.406042] 5 cmdlinepart partitions found on MTD device jz_sfc
[    0.412191] Creating 5 MTD partitions on "jz_sfc":
[    0.417154] 0x000000000000-0x000000040000 : "boot"
[    0.422663] 0x000000040000-0x000000240000 : "kernel"
[    0.428354] 0x000000240000-0x000000340000 : "root"
[    0.433868] 0x000000340000-0x0000007c0000 : "appfs"
[    0.439427] 0x0000007c0000-0x000000800000 : "config"
[    0.445158] SPI NOR MTD LOAD OK
[    0.448468] tun: Universal TUN/TAP device driver, 1.6
[    0.453740] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.460260] Bus Mode Reg after reset: 0x00020101, cnt=0
[    0.466709] Bus Mode Reg after reset: 0x00020101, cnt=1
[    0.473129] Bus Mode Reg after reset: 0x00020101, cnt=2
[    0.479534] Bus Mode Reg after reset: 0x00020101, cnt=3
[    0.485949] Bus Mode Reg after reset: 0x00020101, cnt=4
[    0.492366] Bus Mode Reg after reset: 0x00020101, cnt=5
[    0.498771] Bus Mode Reg after reset: 0x00020101, cnt=6
[    0.505187] Bus Mode Reg after reset: 0x00020101, cnt=7
[    0.511591] Bus Mode Reg after reset: 0x00020101, cnt=8
[    0.518006] Bus Mode Reg after reset: 0x00020101, cnt=9
[    0.524422] func:jz_mii_bus_probe, synopGMAC_reset failed
[    0.530018] jz_mii_bus: probe of jz_mii_bus.0 failed with error -1
[    0.536516] =======>gmacdev = 0x821dac00<================
[    0.542146] =========>gmacdev->MacBase = 0xb34b0000 DmaBase = 0xb34b1000
[    0.549084] Bus Mode Reg after reset: 0x00020101, cnt=0
[    0.555502] Bus Mode Reg after reset: 0x00020101, cnt=1
[    0.561907] Bus Mode Reg after reset: 0x00020101, cnt=2
[    0.568322] Bus Mode Reg after reset: 0x00020101, cnt=3
[    0.574739] Bus Mode Reg after reset: 0x00020101, cnt=4
[    0.581144] Bus Mode Reg after reset: 0x00020101, cnt=5
[    0.587559] Bus Mode Reg after reset: 0x00020101, cnt=6
[    0.593976] Bus Mode Reg after reset: 0x00020101, cnt=7
[    0.600379] Bus Mode Reg after reset: 0x00020101, cnt=8
[    0.606798] Bus Mode Reg after reset: 0x00020101, cnt=9
[    0.613214] func:jz_mac_probe, synopGMAC_reset failed
[    0.618451] jz_mac: probe of jz_mac.0 failed with error -1
[    0.624234] usbcore: registered new interface driver zd1201
[    0.630104] DWC IN OTG MODE
[    0.633696] dwc2 dwc2: Keep PHY ON
[    0.637220] dwc2 dwc2: Using Buffer DMA mode
[    0.641640] dwc2 dwc2: Core Release: 3.00a
[    0.645951] dwc2 dwc2: DesignWare USB2.0 High-Speed Host Controller
[    0.652494] dwc2 dwc2: new USB bus registered, assigned bus number 1
[    0.659812] hub 1-0:1.0: USB hub found
[    0.663777] hub 1-0:1.0: 1 port detected
[    0.667984] dwc2 dwc2: DWC2 Host Initialized
[    0.672862] cgu_msc0 can not set to 24000000, will change!!!
[    0.678748] jzmmc_v1.2 jzmmc_v1.2.0: vmmc regulator missing
[    0.684864] jzmmc_v1.2 jzmmc_v1.2.0: register success!
[    0.690454] TCP: cubic registered
[    0.693987] NET: Registered protocol family 17
[    0.698976] soc_vpu probe success,version:1.0.0-03203fd46d
[    0.704921] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    0.712307] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    0.723285] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[    0.730923] Freeing unused kernel memory: 220K (804a9000 - 804e0000)
[    0.745948] dwc2 dwc2: ID PIN CHANGED!
[    1.202131] usb 1-1: new high-speed USB device number 2 using dwc2
mdev is ok......
net.core.wmem_max = 26214400
net.core.wmem_default = 26214400
Ingenic-uc1_1 login: [    1.641152] cgu_isp can not set to 153000000, will change!!!
[    1.647126] cgu_vpu can not set to 416000000, will change!!!
[    1.672129] usb 1-1: new high-speed USB device number 3 using dwc2
[    1.687274] @@@@ tx-isp-probe ok(version H20240204a), compiler date=Feb  4 2024 @@@@@
[    1.753874] pipe_request_dma: paddr = 0x1a00000
[    1.758608] dma dma0chan24: Channel 24 have been requested.(phy id 7,type 0x06 desc a27c4000)
[    1.770334] pipe_request_dma: paddr = 0x1a40000
[    1.775279] dma dma0chan25: Channel 25 have been requested.(phy id 6,type 0x06 desc a26fb000)
[    1.784477] pipe_request_dma: paddr = 0x1980000
[    1.789210] dma dma0chan26: Channel 26 have been requested.(phy id 5,type 0x04 desc a2798000)
[    1.812110] @@@@@ inner codec power up@@@@@@
[    2.222089] @@@@ audio driver ok(version H20230614a) @@@@@
[    2.677870] [atbm_log]:platform_init(252)
[    2.685115] [atbm_log]:atbm_get_chiptype, chipver=0xa3, g_wifi_chip_type[14]
[    2.693007] fwhdr->flags 34353678 sram_addr 9012000
[    3.081491] [atbm_log]:ble_platform_probe(81f1d780)
[    3.089177] [atbm_log]:is registered as 'phy0'
[    3.094742] usbcore: registered new interface driver atbm_wlan
tuya cfg exist!
[    4.109370] [atbm_log]:atbm_setup_mac:addr(4c37de25151b)
[    4.115144] [atbm_log]:3 !!! atbm_vif_setup_params: enabling priv
[    4.142068] [atbm_log]:[STA] Interface ID:0 of type:2 added
[    4.148057] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[    4.154619] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[    4.160739] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[    4.166922] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[    4.173106] [atbm_log]:atbm_set_uapsd_param:uapsdFlags(0)
[main, 629] Aug 23 2025,22:16:05 token[] raw_path[/mnt/sdcard] cfg_path[/config/tuya_device_cfg.json]
detect auto test enviroment, load config from /config/tuya_device_cfg.json
buffer is {
        "pid":"rzxmfoxm5lv7fs71",
        "uuid": "dgcxea35b7c771c569e4",
        "authkey": "1HogIJZGHJYAH2DqdjmPWiIm8E0oCKrA",
        "storage": "/config/media",
        "media_path": "/config/media",
        "sd_path": "/mnt/sdcard",
        "upgrade_file": "/tmp/upgrade.file",
        "app_version": "0.0.1"
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xec760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
s_ipc_pid: rzxmfoxm5lv7fs71
s_ipc_uuid: dgcxea35b7c771c569e4
s_ipc_authkey: 1HogIJZGHJYAH2DqdjmPWiIm8E0oCKrA
s_ipc_storage: /config/media
s_raw_path: /config/media
s_ipc_sd_path: /mnt/sdcard
s_ipc_upgrade_file: /tmp/upgrade.file
s_app_version: 0.0.12
SDK Version:< TuyaOS V:6.2.6 BS:40.00_PT:2.3_LAN:3.5_CAD:1.0.5_CD:1.0.0 >
< BUILD AT:2025_04_02_16_20_26 BY dandi.guo FOR tuyaos-ipc AT T23_uclibc >
IOT DEFS < WIFI_GW:1 DEBUG:0 KV_FILE:0 LITTLE_END:1 SL:1 OPERATING_SYSTEM:100 RELIABLE_TRANSFER:0 >
MODE:2  LINK_TYPE:4 IP_MODE_TYPE:0
[01-01 00:00:00 ty I][17f0][tal_thread.c:185] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[01-01 00:00:00 ty I][17f0][tal_thread.c:185] thread_create name:wq_system,stackDepth:6144,totalstackDepth:10240,priority:3
[01-01 00:00:00 ty I][17f0][tal_thread.c:185] thread_create name:wq_highpri,stackDepth:5120,totalstackDepth:15360,priority:4
tkl_wifi_init-93  called
[01-01 00:00:00 ty I][17f0][tal_thread.c:185] thread_create name:health_monitor,stackDepth:1536,totalstackDepth:16896,priority:5
[01-01 00:00:00 ty I][17f0][mqc_app.c:490] mqc app init ...
wifi_status_event_cb function!
tkl_wifi_get_ip!
get ipv4 local ip!
wifi_status_event_cb-76 set wf event[2]
[01-01 00:00:00 ty E][17f0][log_seq.c:861] open err
[01-01 00:00:00 ty I][17f0][kv_storge.c:45] Init Kvs With File:/config/media
[01-01 00:00:00 ty N][17f0][tuya_tls.c:876] uni_random_init...
[01-01 00:00:00 ty N][17f0][tuya_tls.c:303] tuya_tls_rand_init ok!
[01-01 00:00:00 ty N][17f0][tuya_svc_devos.c:338] gw_cntl->gw_wsm.stat:0
[01-01 00:00:00 ty D][17f0][tuya_ipc_media_adapter.c:101] media adapter init success. avaliable_res_size:5000
[01-01 00:00:00 ty D][17f0][tuya_ipc_media_adapter.c:511] insert media info node success! device:[0] channel:[0]
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:0 Enable:1
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:666] video_bitrate 1536, video_fps 20
[01-01 00:00:00 ty D][17f0][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr0 bitrate:1536 fps:20
[01-01 00:00:00 ty D][17f0][tuya_ring_buffer.c:672] Ring buffer malloc 1966080 bytes for ch0st0tr0, max frame size 294912
[01-01 00:00:00 ty I][17f0][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr0 size:1966080 nodes:200
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:674] init ring buffer success. channel:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:1 Enable:1
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:666] video_bitrate 512, video_fps 20
[01-01 00:00:00 ty D][17f0][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr1 bitrate:512 fps:20
[01-01 00:00:00 ty D][17f0][tuya_ring_buffer.c:672] Ring buffer malloc 655360 bytes for ch0st0tr1, max frame size 98304
[01-01 00:00:00 ty I][17f0][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr1 size:655360 nodes:200
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:674] init ring buffer success. channel:1
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:2 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:3 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:4 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:5 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:6 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:7 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:8 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:9 Enable:1
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:657] audio_sample 8000, audio_databits 16, audio_fps 25
[01-01 00:00:00 ty D][17f0][tuya_ring_buffer.c:649] Init Ring Buffer. ch0st0tr9 bitrate:125 fps:25
[01-01 00:00:00 ty D][17f0][tuya_ring_buffer.c:672] Ring buffer malloc 160000 bytes for ch0st0tr9, max frame size 23936
[01-01 00:00:00 ty I][17f0][tuya_ring_buffer.c:694] Init Ring Buffer success: ch0st0tr9 size:160000 nodes:250
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:674] init ring buffer success. channel:9
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:10 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:11 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:12 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:13 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:14 Enable:0
[01-01 00:00:00 ty D][17f0][ty_sdk_media_callback.c:648] init ring buffer Channel:0 Stream:15 Enable:0
[01-01 00:00:00 ty D][17f0][simplekv.c:1133] read key:gw_bi isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][17f0][simplekv.c:1164] find key:1 gw_bi
[01-01 00:00:00 ty D][17f0][simplekv.c:1190] key:gw_bi find value.Len:224
[01-01 00:00:00 ty D][17f0][tuya_ws_db.c:667] sync to protected len[223]
[01-01 00:00:00 ty D][17f0][ws_db_gw.c:148] gw_bi read ret:0
[01-01 00:00:00 ty D][17f0][tuya_wifi_link.c:901] tuya wifi link init mthd:0,wifi start mode:0, enable_station_ap:0
[01-01 00:00:00 ty D][17f0][simplekv.c:1133] read key:gw_wsm isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][17f0][simplekv.c:1164] find key:2 gw_wsm
[01-01 00:00:00 ty D][17f0][simplekv.c:1190] key:gw_wsm find value.Len:192
[01-01 00:00:00 ty D][17f0][tuya_ws_db.c:667] sync to protected len[188]
[01-01 00:00:00 ty D][17f0][ws_db_gw.c:259] gw_wsm read ret:0
[01-01 00:00:00 ty N][17f0][tuya_wifi_link.c:85] start wifi link params validate, nc_tp:2 md:0
[01-01 00:00:00 ty N][17f0][tuya_wifi_link.c:107] gw_wsm.nc_tp:2
[01-01 00:00:00 ty N][17f0][tuya_wifi_link.c:108] gw_wsm.md:0
[01-01 00:00:00 ty D][17f0][tuya_bt_link.c:294] bt init...
[01-01 00:00:00 ty D][17f0][tuya_svc_netmgr_linkage.c:86] link[3] is registered [2]
[01-01 00:00:00 ty D][17f0][tuya_ble_svc.c:2325] get_wifi_list eanbled
[01-01 00:00:00 ty D][17f0][tuya_ble_svc.c:2331] get_netcfg_stat eanbled
[01-01 00:00:00 ty D][17f0][tuya_ble_svc.c:2335] get_dev_log eanbled
[01-01 00:00:00 ty D][17f0][tuya_ble_svc.c:2341] get_ap_name eanbled
[01-01 00:00:00 ty D][17f0][simplekv.c:1133] read key:wf_start_md isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][17f0][simplekv.c:1161] no key find
[01-01 00:00:00 ty D][17f0][simplekv.c:1203] __read_kv_raw fail. -3
[01-01 00:00:00 ty D][17f0][simplekv.c:1242] __read_kv_with_decode fail. -3
[01-01 00:00:00 ty E][17f0][tuya_wifi_reset.c:675] read wf start mode err:-6
[01-01 00:00:00 ty D][17f0][tuya_wifi_reset.c:712] <__gw_upd_nc_type> wf start mode change:-6, 0->0
[01-01 00:00:00 ty N][17f0][tuya_svc_devos.c:563] Last reset reason: 7
[01-01 00:00:00 ty D][17f0][simplekv.c:1133] read key:gw_di isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][17f0][simplekv.c:1164] find key:3 gw_di
[01-01 00:00:00 ty D][17f0][simplekv.c:1190] key:gw_di find value.Len:672
[01-01 00:00:00 ty D][17f0][ws_db_gw.c:376] gw_di read ret:0
[01-01 00:00:00 ty D][17f0][simplekv.c:1133] read key:is_stride isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][17f0][tuya_devos_stride.c:55] stride from flash: 0.
[01-01 00:00:00 ty D][17f0][tuya_devos_stride.c:62] no actived, no upgrade:0
[01-01 00:00:00 ty N][17f0][tuya_svc_devos.c:395] gw_cntl->gw_if.abi:0 input:0
[01-01 00:00:00 ty N][17f0][tuya_svc_devos.c:396] gw_cntl->gw_if.product_key:rzxmfoxm5lv7fs71, input:rzxmfoxm5lv7fs71
[01-01 00:00:00 ty N][17f0][tuya_svc_devos.c:397] gw_cntl->gw_if.tp:0, input:0
[01-01 00:00:00 ty N][17f0][tuya_svc_devos.c:596] enter success_proc
tkl_wifi_get_mac function!
WiFi mac->mac: 4C-37-DE-25-15-1B[01-01 00:00:00 ty N][17f0][tuya_svc_devos.c:599] serial_no:4c37de25151b
[01-01 00:00:00 ty D][17f0][tuya_svc_upgrade.c:1369] tuya svc upgrade init success!
[01-01 00:00:00 ty D][17f0][simplekv.c:1133] read key:kv.meta.report isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][17f0][ty_meta_report.c:111] meta in kv {"metas":{}}
[01-01 00:00:00 ty D][17f0][mqc_app.c:109] mq_pro:300 cnt:3
[01-01 00:00:00 ty D][17f0][mqc_app.c:109] mq_pro:302 cnt:4
[01-01 00:00:00 ty D][17f0][mqc_app.c:109] mq_pro:304 cnt:5
[01-01 00:00:00 ty D][17f0][mqc_app.c:109] mq_pro:307 cnt:6
[01-01 00:00:00 ty D][17f0][mqc_app.c:109] mq_pro:308 cnt:7
[01-01 00:00:00 ty D][17f0][mqc_app.c:109] mq_pro:312 cnt:8
[01-01 00:00:00 ty D][17f0][tuya_ipc_mqtt_subscribe.c:292] iot_register_extra_mqt_cb done
[01-01 00:00:00 ty D][17f0][tuya_ipc_hardware_info.c:252] traversal over
[01-01 00:00:00 ty E][17f0][tuya_ipc_hardware_info.c:173] NO sensor info. Please check if you need.
[01-01 00:00:00 ty D][17f0][tuya_ipc_hardware_info.c:115] not found device wifi info
[01-01 00:00:00 ty D][17f0][tuya_ipc_hardware_info.c:355] hard info ="skillParam":"{\"type\":4,\"skill\":{\"localStorage\":1,\"cloudStorage\":1,\"webrtc\":2,\"p2p\":611,\"security_ability\":30,\"video_num\":2,\"sdk_version\":\"6.2.6\"},\"hardware\":{\"toolchain\":\"T23_uclibc\",\"cpu\":{\"model\":\"Pike\",\"bogomips\":\"1185.38\",\"name\":\"Ingenic Xburst V0.0  FPU V0.0\"}}
[01-01 00:00:00 ty D][57c4][tuya_svc_devos.c:854] state change from 0 to 1
[01-01 00:00:00 ty D][57c4][ty_sdk_status_callback.c:124] status chaged: group[1] status[9]
[01-01 00:00:00 ty D][57c4][ty_sdk_status_callback.c:70] __on_netcfg_start, netcfg start. You can start your own netcfg task now.
[01-01 00:00:00 ty D][57c4][simplekv.c:1133] read key:wf_start_md isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][57c4][simplekv.c:1161] no key find
[01-01 00:00:00 ty D][57c4][simplekv.c:1203] __read_kv_raw fail. -3
[01-01 00:00:00 ty D][57c4][simplekv.c:1242] __read_kv_with_decode fail. -3
[01-01 00:00:00 ty E][57c4][tuya_wifi_reset.c:675] read wf start mode err:-6
[01-01 00:00:00 ty D][57c4][tuya_wifi_reset.c:712] <__gw_upd_nc_type> wf start mode change:-6, 0->0
[01-01 00:00:00 ty D][57c4][simplekv.c:1133] read key:kv.ccode.avtive isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][57c4][simplekv.c:1242] __read_kv_with_decode fa[    6.040554] cgu_vpu can not set to 416000000, will change!!!
il. -3
tkl_wifi_set_country_code Set Country Code:0 
tkl_wifi_set_work_mode!
Exec Cmd:iwconfig wlan0 mode Managed 
[01-01 00:00:00 ty D][17f0][main.c:374] tuya ipc sdk start is complete
[01-01 00:00:00 ty I][17f0][tal_thread.c:185] thread_create name:md_proc,stackDepth:524288,totalstackDepth:541184,priority:3
create av task!!!
-----------------------------> tkl vi init!
[01-01 00:00:00 ty D][2fa4][tal_thread.c:209] Thread:md_proc Exec Start. Set to Running Stat 0x732fa4e0
WIFI Set Mode 2
[01-01 00:00:00 ty D][57c4][tuya_wifi_reset.c:596] reset init mthd:0, short timer:0 long timer:0
tkl_wifi_get_work_mode function!
[01-01 00:00:00 ty D][57c4][tuya_wifi_netcfg.c:437] do proxy actived work,mode:2,stat:0,nc_tp:2
[01-01 00:00:00 ty D][57c[    6.112672] -----sc2336_detect: 589 ret = 0, v = 0xcb
4][tuya_wifi_netcfg.c:734] nc_tp:2, md:0
tkl_wifi_set_work_mod[    6.123501] -----sc2336_detect: 597 ret = 0, v = 0x3a
e!
-------- T31 gpio st[    6.133761] sc2336 chip found @ 0x30 (i2c0)
atus --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc[    6.143640] sensor driver version H20230927a
760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
WIFI Set Mode 2
tkl_wifi_scan_ap function!
[01-01 00:00:00 ty D][57c4][netcfg_module.c:133] type:0x10002,is_set:0
[01-01 00:00:00 ty D][57c4][netcfg_module.c:133] type:0x10100,is_set:0
[01-01 00:00:00 ty D][57c4][netcfg_module.c:133] type:0x10002,is_set:1
[01-01 00:00:00 ty D][57c4][tuya_wifi_link.c:140] get work mode:2
[01-01 00:00:00 ty D][57c4][tuya_wifi_link.c:147] start ap netcfg, wk_md:3
Exec Cmd:iwconfig wlan0 mode Master 
Error for wireless request "Set Mode" (8B06) :
    SET failed on device wlan0 ; Invalid argument.
WIFI Set Mode 3
[01-01 00:00:00 ty E][57c4][tuya_wifi_link.c:151] wf_wk_mode_set error:-1
[01-01 00:00:00 ty E][57c4][netcfg_module.c:136] ret:-1
[01-01 00:00:00 ty N][57c4][tuya_wifi_status.c:167] cur stat:2  0x0 -->>
[01-01 00:00:00 ty N][57c4][tuya_wifi_status.c:169] wifi netstat changed to:2  -->>
[01-01 00:00:00 ty D][57c4][netcfg_module.c:338] netcfg module start type:0x10100
[01-01 00:00:00 ty N][57c4][tuya_wifi_reset.c:438] timer stated, short timer:0x0, long timer:0x0
[01-01 00:00:00 ty D][57c4][tuya_wifi_netcfg.c:815] nc_tp:2, md:0
[01-01 00:00:00 ty N][57c4][tuya_bt_link.c:62] bt startup attr:1
[01-01 00:00:00 ty D][57c4][tuya_bt_link.c:77] bt link open
[01-01 00:00:00 ty N][57c4][tuya_ble_svc.c:1199] upd product_id type:0 rzxmfoxm5lv7fs71
[01-01 00:00:00 ty D][57c4][simplekv.c:1133] read key:bt_encrpt_v2 isFuzzy:0 skipCnt:0
[01-01 00:00:00 ty D][57c4][tuya_ble_cryption.c:491] read encrpt flag from flash: 0.
gap callback register!
tkl_ble_gatt_callback_register!
init ble stack! rol is 3
to do tkl_bl[    6.358513] sc2336 stream on
e_gatts_service_add!
[hgh] char index 0 property 12
[hgh] char index 1 property 16
[hgh] char index 2 property 2
[01-01 00:00:00 ty D][57c4][tuya_ble_svc.c:1626] start ble monitor
[01-01 00:00:00 ty N][57c4][tuya_ble_svc.c:1294] ty bt sdk init success finish
[01-01 00:00:00 ty D][57c4][tuya_ble_netcfg.c:153] net_cfg sub session created
[01-01 00:00:00 ty D][57c4][tuya_ble_svc.c:2298] get_wifi_list sub session created
[01-01 00:00:00 ty D][57c4][tuya_ble_svc.c:2302[    6.402579] [atbm_log]:ioctl_open(8093b100)(81f1d780)
] get_netcfg_stat sub session created
[01-01 00:00:00 ty D][57c4][tuya_ble_svc.c:2306] get_dev_log sub session created
[01-01 00:00:00 ty D][57c4][tuya_ble_svc.c:2310] get_ap_name sub session created
tkl_ble_gap_adv_start!
[01-01 00:00:00 ty N][57c4][tuya_svc_devos.c:246] __devos_init_evt success
[01-01 00:00:01 ty D][57c4][netcfg_module.c:116] start 0x10100 ret:0
[01-01 00:00:01 ty D][57c4][netcfg_module.c:338] netcfg module start type:0x10002
[01-01 00:00:01 ty D][57c4][ap_netcfg.c:1464] ap cfg start:65538
tkl_wifi_get_ip!
get ipv4 local ip!
WIFI mode[1] Get IP failed
[01-01 00:00:01 ty E][57c4][ap_netcfg.c:1338] get ip fail:-1
[01-01 00:00:01 ty E][57c4][ap_netcfg.c:1469] ap_nw_cfg_start err:-6
[01-01 00:00:01 ty D][57c4][netcfg_module.c:116] start 0x10002 ret:-6
do gap evt call!
tkl_ble_kernel_gap_event_callback event type 1
to do ble event call back! event type 1
[01-01 00:00:01 ty D][27a4][tuya_ble_svc.c:1115] rev ble event 1
[01-01 00:00:01 ty D][27a4][tuya_ble_svc.c:1768] set ble serv stat:0, curr:0
======>>atbm_ble_start>>>
nimble_port_init++
ble_npl_eventq_main
msys block_count:20
acl block_count:40
FD_CLOEXEC set
ble_coexist_start--
hif_ioctl_loop
tkl_wifi_get_ip!
get ipv4 local ip!
[01-01 00:00:01 ty D][57c4][tuya_ble_svc.c:244] upd adv para, send conn_req beacon.
[01-01 00:00:01 ty D][57c4][tuya_ble_svc.c:115] adv_data 31 <0xac5681>
02 01 06 03 02 50 fd 17 16 50 fd 43 04 00 10 72 7a 78 6d 66 6f 78 6d 35 6c 76 37 66 73 37 31 
[01-01 00:00:01 ty D][57c4][tuya_ble_svc.c:115] rsp_data 31 <0xac56a1>
17 ff d0 07 00 00 04 21 68 0f 1b 4f 41 8e c1 39 d3 1d a0 71 2c 0e f0 3a 06 09 54 55 59 41 5f 
[01-01 00:00:01 ty D][57c4][tuya_ble_svc.c:1665] ble get conn stat:4
tkl_ble_gap_adv_stop!
tal_ble_advertising_data_set!
tkl_ble_gap_adv_rsp_data_set function! data len 31
adv data:P
scan rsp data len 31
scan rsp data:
copy adv data!
copy rsp data!
error setting advertisement data; rc=22
[01-01 00:00:01 ty N][57c4][tuya_ble_svc.c:1381] ble adv updated
i264e[info]: profile High, level 4.0
i264e[info]: profile High, level 2.2
tkl_venc_init end
nimble_host_task
ble_hs_sync:333
set rgn show enable!
warn: shm_init,53shm init already
Audio In GetVol    vol : 60
ble_hs_hci_cmd_tx:352
ble_smart_cfg_startup!11
ble_smart_cfg_task!
[ATBM lOG]set default tx power(0)
pub addr 4c:37:de:25:15:1c
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_ai_init
[01-01 00:00:02 ty I][17f0][tal_thread.c:185] thread_create name:video_main,stackDepth:524288,totalstackDepth:1065472,priority:3
[01-01 00:00:02 ty I][17f0][tal_thread.c:185] thread_create name:video_sub,stackDepth:524288,totalstackDepth:1589760,priority:3
[01-01 00:00:02 ty I][17f0][tal_thread.c:185] thread_create name:audio_main,stackDepth:524288,totalstackDepth:2114048,priority:3
george here....(ip=(null):554)......
[01-01 00:00:02 ty D][9954][tal_thread.c:209] Thread:audio_main Exec Start. Set to Running Stat 0x669954e0
get audio main thread!
[01-01 00:00:02 ty D][9954][tuya_ring_buffer.c:780] ch0st0tr9 open with type 1
create audio ring buffer success!
[01-01 00:00:02 ty D][a154][tal_thread.c:209] Thread:video_sub Exec Start. Set to Running Stat 0x66a154e0
[01-01 00:00:02 ty D][a954][tal_thread.c:209] Thread:video_main Exec Start. Set to Running Stat 0x66a954e0
[01-01 00:00:02 ty D][a154][tuya_ring_buffer.c:780] ch0st0tr1 open with type 1
open sub ring buufer success! max frame size 98304
[01-01 00:00:02 ty D][a954][tuya_ring_buffer.c:780] ch0st0tr0 open with type 1
---------------> open main ring buffer success! max size 294912
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
ble_slave_gap_event!
s_event0
connection established; status=0 connection, handle=1
tkl_ble_kernel_gap_event_callback event type 4
to do ble event call back! event type 4
[01-01 00:00:11 ty D][3864][tuya_ble_svc.c:1115] rev ble event 4
[01-01 00:00:11 ty N][3864][tuya_ble_svc.c:746] Ble Connected
[01-01 00:00:11 ty N][3864][tuya_ble_data_handler.c:69] ble reset sn
[01-01 00:00:11 ty N][3864][tuya_ble_svc.c:1659] ble set conn stat:1
[01-01 00:00:11 ty D][3864][tuya_ble_svc.c:1152] conn monitor timer started
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
s_event15
mtu update event; conn_handle=1 cid=4 mtu=255
do gatt call mtu!
tkl_ble_kernel_gatt_event_callback function event type 1
s_event14
subscribe event; conn_handle=1 attr_handle=10 reason=1 prevn=0 curn=0 previ=0 curi=1
ble_svc_gatt_changed_val_handle=10
gatt_svr_chr_indicate!
s_event13
notification tx event; status=0 attr_handle=10 indication=1
do gatt call notify tx!
tkl_ble_kernel_gatt_event_callback function event type 6
do gatt call subcribe!
tkl_ble_kernel_gatt_event_callback function event type 10
tkl_wifi_get_ip!
get ipv4 local ip!
s_event13
notification tx event; status=14 attr_handle=10 indication=1
s_event14
subscribe event; conn_handle=1 attr_handle=16 reason=1 prevn=0 curn=1 previ=0 curi=0
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
get gatt access!
gatt callback op is 1
tkl_ble_kernel_gatt_event_callback function event type 7
##p_event->ble_event.write_report.peer.char_handle[0] = e
##ble_peripheral_info.char_handle[TAL_COMMON_WRITE_CHAR_INDEX] = e
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:1115] rev ble event 14
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:1076] Dev Rev BT Package
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] bt_rev_raw 52 <0xad3d67>
00 31 44 0b b2 90 96 a7 22 23 23 7a 4f be 91 0a 47 b8 ca cd 99 da bd e9 9b 25 2f e3 f1 b1 3e 31 15 b5 04 76 8a 29 2f 70 e7 5a e6 50 05 ee fb 9d b7 fb fc c6 
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:142] recive sub_pkg desc:3, no:1, pack_len:49, total_len:49
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] ble rev data 49 <0xb36e54>
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] ble decryped data 32 <0xb37258>
00 00 00 01 00 00 00 00 00 00 00 02 00 fc 7c 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:1665] ble get conn stat:1
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:802] Parse BT Cmd:0x0 mode:11
[01-01 00:00:13 ty D][3864][tuya_ble_mutli_tsf_protocol.c:119] BT sub pkg lenth set:252
[01-01 00:00:13 ty N][3864][tuya_ble_data_handler.c:596] tuya_ble_handle_dev_infor_req state:0, pkg_len:252
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:606] buf len:121
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:1084] default resp generated.
[01-01 00:00:13 ty D][57c4][tuya_ble_mutli_tsf_protocol.c:216] pkg max len:252, sunpkg_offset:4, send_data:161
[01-01 00:00:13 ty D][57c4][tuya_ble_svc.c:115] tuya_sdk_bt_send 165 <0xb36b48>
00 a1 01 40 0b 62 6c 4e 8d 05 a3 2e 08 13 7a 55 32 67 50 54 d9 b4 4e 1b cb ec d9 b8 29 c6 63 ef 80 54 d2 2e dc 96 da 76 d9 23 9e 06 99 a7 bb 18 59 46 66 cd 24 11 66 e4 03 69 9b 20 cb 65 54 d3 
fa 66 6f 8b 40 bb d8 ff a1 9d 86 69 90 19 9c a3 bc 81 79 8a 79 b5 9b e3 1e 15 a2 52 b0 71 d0 c3 45 d1 1f a7 94 ad e6 34 29 51 b4 21 80 c3 4b 32 e1 0e 69 6e 36 28 23 2f f9 18 4b 74 17 f8 c3 2a 
fa 6e a5 61 98 2b 84 e7 fe 51 ce 3f bd 6f 2c 3d 90 eb a6 0d 82 0d 78 c0 b5 38 5e dd fe 22 74 d2 54 10 9b 6c ea 
tkl_ble_gatts_value_notify!
gatt_svr_chr_notify!
s_event13
notification tx event; status=0 attr_handle=16 indication=0
[01-01 00:00:13 ty D][57c4][tuya_ble_svc.c:1342] ble_send_data_to_app finish. len:161, send_ret:0x0
get gatt access!
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] bt_rev_raw 133 <0xad3d67>
00 81 01 45 0c 32 48 35 43 36 44 50 47 50 30 43 4a 4e 34 48 30 c7 d9 3c f3 a9 e1 9d 6b af ca 4d 1b ba e8 22 26 e8 e6 eb 9b 4d 84 09 5e e7 6b 41 7d 10 f0 ce 6e e7 f0 8d bc f8 21 b4 5e f6 f4 dc 
55 19 9b 98 7d 45 ea 81 62 a3 95 3d a3 6d 35 62 c0 4e 51 22 cd 28 af 1e 13 56 8d 89 75 0e 60 be 72 f5 da 83 b8 1a f0 b5 04 51 92 78 b7 c7 56 b3 09 ac 51 e3 56 4d fa fb 2e 94 1c 9b 0b 49 14 1c 
1d 2e 5b e6 ac 
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:142] recive sub_pkg desc:3, no:1, pack_len:129, total_len:129
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] ble rev data 129 <0xb36e54>
0c 32 48 35 43 36 44 50 47 50 30 43 4a 4e 34 48 30 c7 d9 3c f3 a9 e1 9d 6b af ca 4d 1b ba e8 22 26 e8 e6 eb 9b 4d 84 09 5e e7 6b 41 7d 10 f0 ce 6e e7 f0 8d bc f8 21 b4 5e f6 f4 dc 55 19 9b 98 
7d 45 ea 81 62 a3 95 3d a3 6d 35 62 c0 4e 51 22 cd 28 af 1e 13 56 8d 89 75 0e 60 be 72 f5 da 83 b8 1a f0 b5 04 51 92 78 b7 c7 56 b3 09 ac 51 e3 56 4d fa fb 2e 94 1c 9b 0b 49 14 1c 1d 2e 5b e6 
ac 
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] ble decryped data 112 <0xb37258>
00 00 00 02 00 00 00 00 00 01 00 52 35 03 21 38 a0 c5 2c 73 07 1c 13 05 18 93 84 ff 64 67 63 78 65 61 33 35 62 37 63 37 37 31 63 35 36 39 65 34 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 d7 fa 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:802] Parse BT Cmd:0x1 mode:12
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:691] start up v2 ble encrpt v4
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:590] set ble v2 encrpt!
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:1159] conn monitor timer stopped
[01-01 00:00:13 ty N][3864][tuya_ble_svc.c:1659] ble set conn stat:3
[01-01 00:00:13 ty N][3864][tuya_ble_data_handler.c:380] PAIR_REQ ok:0
[01-01 00:00:13 ty N][3864][tuya_ble_data_handler.c:349] ble_time_req start...
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:355] no need to query time. network stat:0, work stat:0
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:1665] ble get conn stat:3
tkl_wifi_get_ip!
get ipv4 local ip!
[01-01 00:00:13 ty D][57c4][tuya_ble_mutli_tsf_protocol.c:216] pkg max len:252, sunpkg_offset:3, send_data:33
[01-01 00:00:13 ty D][57c4][tuya_ble_svc.c:115] tuya_sdk_bt_send 36 <0xb36b48>
00 21 41 0c 2f 5f 28 8d 8d f4 3f 74 1a 15 8e c6 aa 8e 10 ea 08 cb 51 04 7c ee 6f 78 c5 9b 42 46 8f 63 11 24 
s_event13
[01-01 00:00:13 ty D][57c4][tuya_ble_svc.c:1342] ble_send_data_to_app finish. len:33, send_ret:0x0
get gatt access!
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] bt_rev_raw 249 <0xad3d67>
00 e1 07 47 0c 32 48 35 43 36 44 50 47 50 30 43 4a 4e 34 48 30 c8 5b 29 2a 24 53 50 f7 71 b3 10 1a 60 e7 30 38 fe 6e d8 b1 a0 93 4c 80 b3 67 7d eb 2b 13 93 b9 32 e3 93 fa 2b 6f 4e da 11 f6 67 
ba 69 7d 35 34 3c c0 a0 42 95 56 0d 1e 37 94 95 77 fb bc ec 9c 31 2e 0f c1 e4 d2 0c 04 31 3f 94 06 4f f9 10 fc 53 c2 0b b4 43 b2 cd 2e 0e 3c f1 37 ff 6c 68 dc b1 c8 2c ae d6 26 a0 63 b5 36 29 
94 79 c2 f3 7c ba ab 0e e7 94 45 22 98 05 9b cd 11 2c 4e bd 34 29 34 8f ea e1 09 82 b9 91 be 86 87 ad 38 c6 76 41 f8 b2 3d 69 77 02 ba b2 6d ce 01 7d e6 77 ab 34 ef 1c a8 1a 5d 35 95 48 b8 ec 
15 c2 b5 e0 28 ed d9 8d 51 7a b4 70 2a a3 42 c8 a2 26 b7 83 ca a8 2c 36 c2 d5 16 a9 f0 5d 57 04 cc 17 cf d0 f1 9d bb cf 07 4a 21 19 51 43 3f 2c 15 0a 64 31 c5 8b 4d f4 de 
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:142] recive sub_pkg desc:1, no:1, pack_len:245, total_len:245
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:658] ble data pkg is multi-pack, receive...
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] bt_rev_raw 3 <0xad3fa0>
77 35 0c 
[01-01 00:00:13 ty E][3864][tuya_ble_data_handler.c:660] ble_data_unpack err:-7937
get gatt access!
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] bt_rev_raw 249 <0xad3e97>
01 5c 20 85 d6 d2 9b b0 1e 36 42 83 4c fa 94 48 38 83 65 a8 2f 64 b7 c0 22 e9 98 c9 54 61 80 44 85 97 42 ab 9d fb 78 e7 65 dd 87 e5 df f9 7d 31 23 5d 22 b8 64 94 d5 57 b3 d5 29 14 ce 0b b4 72 
a3 1e 81 b3 7a 0d ad 61 c6 5c 95 e4 37 3a 85 2f dd 39 01 a5 57 e3 c2 a5 28 57 03 55 e9 11 92 47 13 3c 2c 53 ee 41 e9 4e 39 2e 88 bb 7b 36 c4 24 98 59 41 a1 f3 36 3a af fc 58 1d 1a c0 64 a5 eb 
09 d5 37 bb a8 5e 57 4e 3c be 56 84 ca 6b 60 43 25 c7 21 18 85 fc 4c 6b 1c ea 72 15 f6 97 8f 47 a7 d8 4a 40 2b d3 7b 46 60 59 5f 9f ae bc 7c 6e f5 6f 68 62 91 5f a2 ef 5a 6c 45 36 99 4a 87 d5 
54 7a f1 cf 75 53 ae 18 d1 c8 70 e8 88 38 95 77 44 4c 3f 8a dd ec 65 15 57 66 b1 27 f7 53 b6 e9 ab f4 5b a2 d8 bb 33 5d 92 63 cc 18 12 83 21 ea bf 5d cd f1 d3 5e 22 42 0f 
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:142] recive sub_pkg desc:2, no:2, pack_len:248, total_len:248
b5 f9 e9 
get gatt access!
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] bt_rev_raw 249 <0xad40f7>
02 ae a4 9a 99 3e 27 3f 70 8f b7 e6 c7 d7 13 32 86 55 b7 6e 95 35 e2 64 16 5e f0 27 93 0e d6 78 2f b2 cb 92 1a 44 07 42 e1 08 ed 00 90 69 1b 1f fd a8 54 ce a7 ed 90 9a 96 ce ef 38 03 46 f3 ca 
f6 dd 7e 18 20 57 13 6f b4 95 48 97 78 73 6f 02 90 fa 2d ce 6c 79 f9 88 4e 23 bb 8d 3b 1e 4f d5 52 c6 ba 28 12 36 b8 27 da f0 f3 7b e1 24 40 5a df 94 d8 44 aa cf 55 0e 57 18 92 dd 81 21 0e 9a 
f9 18 4d 0f 3c d8 cb f1 4e ec 1e 83 88 ee f1 6b 41 7e 23 dc 37 83 fb fd b2 9b cb 35 d8 fc 50 29 e6 86 93 34 4e 24 2f 6b dc 11 5e 38 2c 85 9e 46 e6 f5 a3 e4 10 2d 10 34 2a 7a 9a 71 87 ee 78 03 
01 48 03 bf f8 39 f2 f8 e8 16 d8 fd 9a ac e4 51 cf bc 41 f1 a2 52 7f e1 09 ff af 52 12 30 2a bf 32 1e ee a5 49 76 7a 99 92 80 e8 af 70 4c d3 ff f9 37 91 fb a6 64 77 c3 af 
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:142] recive sub_pkg desc:2, no:3, pack_len:248, total_len:248
fa 28 c3 
get gatt access!
[01-01 00:00:13 ty D][3864][tuya_ble_svc.c:115] bt_rev_raw 244 <0xad4227>
03 f9 02 95 75 d4 ca 11 00 33 0c ac 89 99 22 a2 2e 4c 6b ba c6 d0 e7 54 a3 6c 10 ad 55 21 48 5c 09 26 e5 cc 2e ba 16 b0 9c 50 62 c1 e6 e3 6d 64 de 77 24 74 05 7f e7 17 6d 96 a0 8d d2 a9 9b 58 
04 bb f9 66 72 b3 a2 11 73 2e 14 02 6f 57 04 10 d3 6d 09 ec fa 40 ba dc ce b6 62 05 ce 38 0a 41 e0 a9 e5 5d b6 ca 0c 7a 1d 46 f9 ab 23 43 09 a5 69 d7 9a 1b 2f c3 e1 53 62 3d dc d0 75 7a 39 08 
8d 3f 8d f2 89 5c 06 96 88 6f ec fd a0 6e cd ff d1 9d 7e c0 cf 3b 67 fa 3e 9e 35 b8 6c 01 3f 2b f3 dc c2 1d d5 d4 13 8c 7b 0e 9e 83 6e 31 dd ea bc e9 ed 40 52 28 1e e1 4b 44 58 43 d9 49 16 80 
24 b2 1c 96 35 d9 e8 6f 60 f8 8c 8e 68 e3 9c 43 0d a2 96 52 a1 2c 4d 2f 8c 6b e0 c4 c6 06 3e ff 6e 05 08 92 57 5a 7b 8b 09 05 26 36 47 0b bb a7 04 0c d1 ea 
[01-01 00:00:13 ty D][3864][tuya_ble_data_handler.c:142] recive sub_pkg desc:2, no:4, pack_len:243, total_len:243
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
[01-01 00:00:15 ty D][57c4][tuya_ble_svc.c:1528] nw stat change:0->0, rpt to app.
[01-01 00:00:15 ty D][57c4][tuya_ble_svc.c:1501] tuya_ble_send_dev_nw_stat:0, force:1
[01-01 00:00:15 ty D][57c4][tuya_ble_svc.c:1665] ble get conn stat:3
[01-01 00:00:15 ty D][57c4][tuya_ble_svc.c:1442] tuya_ble_sdk_send. cmd:0x1e encrpyt:12
[01-01 00:00:15 ty D][57c4][tuya_ble_svc.c:115] bt_ack_uncrypt 1 <0x7657beb9>
00 
[01-01 00:00:15 ty D][57c4][tuya_ble_mutli_tsf_protocol.c:216] pkg max len:252, sunpkg_offset:3, send_data:33
[01-01 00:00:15 ty D][57c4][tuya_ble_svc.c:115] tuya_sdk_bt_send 36 <0xb36b48>
00 21 42 0c ce 15 19 71 28 9d 7e 5d 92 79 d9 96 fb ae 81 a3 34 9c 82 88 f3 9e ed e0 f0 36 fe 84 d1 a8 60 cd 
s_event13
[01-01 00:00:15 ty D][57c4][tuya_ble_svc.c:1342] ble_send_data_to_app finish. len:33, send_ret:0x0
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
s_event14
subscribe event; conn_handle=1 attr_handle=10 reason=2 prevn=0 curn=0 previ=1 curi=0
s_event14
subscribe event; conn_handle=1 attr_handle=16 reason=2 prevn=1 curn=0 previ=0 curi=0
s_event1
disconnect; reason=0x213 
tkl_ble_kernel_gap_event_callback event type 5
set connect handle invalid!
to do ble event call back! event type 5
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
WIFI mode[0] Get IP failed
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
gpio status is output=0
Pull up disable
Pull down disable
Drive strength is 8mA
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
gpio status is output=1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
-------- T31 gpio status --------
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
[01-01 00:02:00 ty D][d7c4][simplekv.c:129] <__tmm_backup_work> backup file start...time: 125, MsTime: 167
[01-01 00:02:00 ty D][d7c4][simplekv.c:241] backup normal file to bak success
[01-01 00:02:00 ty D][d7c4][simplekv.c:132] <__tmm_backup_work> backup file end...time: 125, MsTime: 186
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x10000000
INT  MSK  PAT1  PAT0
 0    1    0     0
GPIO pin level:0
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
PxINT= 0x00080000
PxMSK= 0xfe76003f
PxPAT1=0xfc760000
PxPAT0=0x12000000
INT  MSK  PAT1  PAT0
 0    1    0     1
GPIO pin level:1
Pull up disable
Pull down disable
tkl_wifi_get_ip!
get ipv4 local ip!
