* @file tuya_device.c
* @brief tuya_device module is used to
* @date 2022-05-20
#include "tuya_iot_config.h"
#if defined(ENABLE_SPI) && (ENABLE_SPI)
#include "tal_thread.h"
#include "tkl_spi.h"
#include "tkl_semaphore.h"
#include "tkl_output.h"
#define SPI_ID                      TUYA_SPI_NUM_0
#define SPI_FREQ                    10000000
#define SPI_BUF_LEN                 1024
#define WITHOUT_DMA                 0
#define WITH_DMA                    1
#define MASTER_TO_SLAVE_MSG        "The is a blessing form master"
#define SLAVE_TO_MASTER_MSG        "The is a blessing form slave"
STATIC TKL_SEM_HANDLE exmaple_spi_complete_sem = NULL;
STATIC UINT8_T *send_data_buf = NULL;
STATIC UINT8_T *recv_data_buf = NULL;
STATIC TUYA_SPI_BASE_CFG_T demo_spi_cfg = {
    .mode = TUYA_SPI_MODE0,
    .type = TUYA_SPI_AUTO_TYPE,
    .databits = TUYA_SPI_DATA_BIT8,
    .bitorder = TUYA_SPI_ORDER_MSB2LSB,
    .freq_hz = SPI_FREQ,
STATIC VOID __example_spi_event_cb(TUYA_SPI_NUM_E port, TUYA_SPI_IRQ_EVT_E event)
    if ((event == TUYA_SPI_EVENT_TX_COMPLETE) || (event == TUYA_SPI_EVENT_RX_COMPLETE)) {
        tkl_log_output("post sem %d\r\n", event);
        tkl_semaphore_post(exmaple_spi_complete_sem);
STATIC OPERATE_RET __example_spi_init(TUYA_SPI_NUM_E port, TUYA_SPI_ROLE_E role, INT_T with_dma, UINT8_T is_half_dup)
    demo_spi_cfg.role = role;
    demo_spi_cfg.spi_dma_flags = with_dma;
    TUYA_CALL_ERR_GOTO(tkl_spi_init(port,  &demo_spi_cfg), __EXIT);
    if (is_half_dup)
        tkl_spi_irq_init(port, __example_spi_event_cb);
        tkl_spi_irq_enable(port);
        tkl_semaphore_create_init(&exmaple_spi_complete_sem, 0, 1);
    send_data_buf = (UINT8_T *)tkl_system_malloc(SPI_BUF_LEN);
    TUYA_CHECK_NULL_GOTO(send_data_buf, __EXIT);
    recv_data_buf = (UINT8_T *)tkl_system_malloc(SPI_BUF_LEN);
    TUYA_CHECK_NULL_GOTO(recv_data_buf, __EXIT);
__EXIT:
    return rt;
STATIC OPERATE_RET __example_spi_deinit(TUYA_SPI_NUM_E port)
    TUYA_CALL_ERR_LOG(tkl_spi_deinit(port));
    if (send_data_buf)
        tkl_system_free(send_data_buf);
    if (recv_data_buf)
        tkl_system_free(recv_data_buf);
    if (exmaple_spi_complete_sem)
        tkl_semaphore_release(exmaple_spi_complete_sem);
__EXIT:
    return rt;
OPERATE_RET example_spi_master_in_half_duplex(INT_T argc, CHAR_T *argv[])
    UINT8_T master_to_slave[] = MASTER_TO_SLAVE_MSG;
    UINT32_T data_len = 0;
    /* init master spi */
    TUYA_CALL_ERR_GOTO(__example_spi_init(TUYA_SPI_NUM_0, TUYA_SPI_ROLE_MASTER, WITHOUT_DMA, true), __EXIT);
    /* master recv in half */
    memset(recv_data_buf, 0, SPI_BUF_LEN);
    data_len = sizeof(SLAVE_TO_MASTER_MSG) - 1;
    TUYA_CALL_ERR_GOTO(tkl_spi_recv(TUYA_SPI_NUM_0, recv_data_buf, data_len), __EXIT);
    tkl_semaphore_wait(exmaple_spi_complete_sem, TKL_SEM_WAIT_FOREVER);
    TAL_PR_NOTICE("master recv data success: %s\r\n", recv_data_buf);
    /* master send in half */
    memset(send_data_buf, 0, SPI_BUF_LEN);
    data_len = sizeof(MASTER_TO_SLAVE_MSG) - 1;
    memcpy(send_data_buf, master_to_slave, data_len);
    TUYA_CALL_ERR_GOTO(tkl_spi_send(TUYA_SPI_NUM_0, send_data_buf, data_len), __EXIT);
    TAL_PR_NOTICE("master send data success: %s\r\n", send_data_buf);
__EXIT:
    TUYA_CALL_ERR_LOG(__example_spi_deinit(TUYA_SPI_NUM_0));
    return rt;
OPERATE_RET example_spi_slave_in_half_duplex(INT_T argc, CHAR_T *argv[])
    UINT8_T slave_to_master[] = SLAVE_TO_MASTER_MSG;
    /* init slave spi */
    TUYA_CALL_ERR_GOTO(__example_spi_init(TUYA_SPI_NUM_0, TUYA_SPI_ROLE_SLAVE, WITHOUT_DMA, true), __EXIT);
    /* slave send in half */
    memcpy(send_data_buf, slave_to_master, data_len);
    TAL_PR_NOTICE("slave send data success: %s\r\n", send_data_buf);
    /* slave recv in half */
    TAL_PR_NOTICE("slave recv data success: %s\r\n", recv_data_buf);
__EXIT:
    return rt;
OPERATE_RET example_spi_master_in_full_duplex(INT_T argc, CHAR_T *argv[])
    TUYA_CALL_ERR_GOTO(__example_spi_init(TUYA_SPI_NUM_0, TUYA_SPI_ROLE_MASTER, WITH_DMA, false), __EXIT);
    /* master recv & send in full */
    data_len = (sizeof(SLAVE_TO_MASTER_MSG) - 1 > data_len) ? sizeof(SLAVE_TO_MASTER_MSG) - 1 : data_len;
    TUYA_CALL_ERR_GOTO(tkl_spi_transfer(TUYA_SPI_NUM_0, send_data_buf, recv_data_buf, data_len), __EXIT);
__EXIT:
    return rt;
OPERATE_RET example_spi_slave_in_full_duplex(INT_T argc, CHAR_T *argv[])
    TUYA_CALL_ERR_GOTO(__example_spi_init(TUYA_SPI_NUM_0, TUYA_SPI_ROLE_SLAVE, WITH_DMA, true), __EXIT);
    /* slave recv & send in full */
    data_len = (sizeof(MASTER_TO_SLAVE_MSG) - 1 > data_len) ? sizeof(MASTER_TO_SLAVE_MSG) - 1 : data_len;
__EXIT:
    return rt;
