/*********first init*********/
/*********1.0.0 second init*********/
/*********third init*********/
key init OK!!!
[0000000000 TUYA D][tdd_led_blink.c:69] pin num =18 i=0
[0000000000 TUYA D][tdd_led_blink.c:69] pin num =31 i=1
vol 2000 per 0
vol 2100 per 10
vol 2200 per 20
vol 2300 per 30
vol 2400 per 40
vol 2500 per 50
vol 2600 per 60
vol 2700 per 70
vol 2800 per 80
vol 2900 per 90
vol 3000 per 100
SDA[27] SCL[19]
temperature humidity initializ ok!
[D]: [tbl_common_report_attribute_data], clu[0x402], attr[0x1], zcl_id[105]
[D]: [tbl_common_report_attribute_data], clu[0x402], attr[0x2], zcl_id[106]
[D]: [tbl_common_report_attribute_data], clu[0x402], attr[0x3], zcl_id[117]
[D]: [tbl_common_report_attribute_data], clu[0x405], attr[0x1], zcl_id[108]
0x2], zcl_id[109]
[D]: [tbl_common_report_attribute_data], clu[0x405], attr[0x3], zcl_id[118]
/*********last init*********/
power_on_online---
nwk_rejoin_ok---
[D]: [tbl_common_report_attribute_data], clu[0x1], attr[0x21], zcl_id[116]
Battery_start_report_immediately.
temperature humidity process start!
temp humi force report!
SHT40 sensor read.
Tem_humi_regular_report_0 
SHT40 sensor read.
tmp_data[26520], hum_data[4050]
report immediately and sync tmp 26520,hum 4050.
[D]: [tbl_common_report_attribute_data], clu[0x402], attr[0x0], zcl_id[104]
[D]: [tbl_common_report_attribute_data], clu[0x405], attr[0x0], zcl_id[107]
[D]: [tbl_common_report_attribute_data], clu[0x405], attr[0x2], zcl_id[109]
[D]: [send_data_result_callback], status[0]
SHT40 sensor read.
tmp_data[26510], hum_data[4041]
report immediately and sync tmp 26510,hum 4041.
start report full
SHT40 sensor read.
tmp_data[26510], hum_data[4047]
report immediately and sync tmp 26510,hum 4047.
tal_heartbeat_report_callback[0]
[I]: Don't need to handle with the heatbeat typ which is app version report.
SHT40 sensor read.
tmp_data[26530], hum_data[4041]
report immediately and sync tmp 26530,hum 4041.
SHT40 sensor read.
tmp_data[26550], hum_data[4045]
report immediately and sync tmp 26550,hum 4045.
SHT40 sensor read.
tmp_data[26520], hum_data[4046]
report immediately and sync tmp 26520,hum 4046.
SHT40 sensor read.
tmp_data[26520], hum_data[4041]
report immediately and sync tmp 26520,hum 4041.
SHT40 sensor read.
tmp_data[26520], hum_data[4033]
report immediately and sync tmp 26520,hum 4033.
SHT40 sensor read.
tmp_data[26540], hum_data[4035]
report immediately and sync tmp 26540,hum 4035.
SHT40 sensor read.
tmp_data[26540], hum_data[4036]
report immediately and sync tmp 26540,hum 4036.
SHT40 sensor read.
tmp_data[26600], hum_data[5603]
report immediately and sync tmp 26600,hum 5603.
SHT40 sensor read.
tmp_data[26730], hum_data[8122]
report immediately and sync tmp 26730,hum 8122.
Tem_humi_regular_sample_0 
SHT40 sensor read.
tmp_data[26900], hum_data[8975]
TEMP_last :26730,curr:26900,theshold:100
HUM_last :8122,curr:8975,theshold:100
[D]: [tbl_com
Tem_humi_regular_sample_1 
SHT40 sensor read.
tmp_data[26860], hum_data[8253]
HUM_last :8975,curr:8253,theshold:100
SHT40 sensor read.
tmp_data[26970], hum_data[6238]
HUM_last :8253,curr:6238,theshold:100
SHT40 sensor read.
tmp_data[27030], hum_data[5151]
TEMP_last :26900,curr:27030,theshold:100
HUM_last :6238,curr:5151,theshold:100
[D]: [tbl_com
SHT40 sensor read.
tmp_data[27070], hum_data[4680]
HUM_last :5151,curr:4680,theshold:100
SHT40 sensor read.
tmp_data[27100], hum_data[4455]
HUM_last :4680,curr:4455,theshold:100
