    Phyplus Microelectronics Limited confidential and proprietary.
    All rights reserved.
    IMPORTANT: All rights of this software belong to Phyplus Microelectronics
    Limited ("Phyplus"). Your use of this Software is limited to those
    specific rights granted under  the terms of the business contract, the
    confidential agreement, the non-disclosure agreement and any other forms
    of agreements as a customer or a partner of Phyplus. You may not use this
    Software unless you agree to abide by the terms of these agreements.
    You acknowledge that the Software may not be modified, copied,
    distributed or disclosed unless embedded on a Phyplus Bluetooth Low Energy
    (BLE) integrated circuit, either as a product or is integrated into your
    products.  Other than for the aforementioned purposes, you may not use,
    reproduce, copy, prepare derivative works of, modify, distribute, perform,
    display or sell this Software and/or its documentation for any purposes.
    YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
    PROVIDED AS IS WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
    INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
    NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
    PHYPLUS OR ITS SUBSIDIARIES BE LIABLE OR OBLIGATED UNDER CONTRACT,
    NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
    LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
    INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
    OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
    OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
    (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
    @file   spi.c
    @brief  Contains all functions support for spi driver
    @version  0.0
    @date   18. Oct. 2017
    @author qing.han
#include "rom_sym_def.h"
#include "bus_dev.h"
#include "spi.h"
#include "gpio.h"
#include "error.h"
#include "pwrmgr.h"
#include "clock.h"
#include "log.h"
#include "jump_function.h"
#if DMAC_USE
    #include "dma.h"
typedef struct _spi_Context
    spi_Cfg_t   cfg;
    hal_spi_t*  spi_info;
    bool        is_slave_mode;
    spi_xmit_t  transmit;
} spi_Ctx_t;
static spi_Ctx_t m_spiCtx[2];
#define SPI_HDL_VALIDATE(hdl)   {if((hdl == NULL) || (hdl->spi_index > 1))\
            return PPlus_ERR_INVALID_PARAM;\
        if((hdl != m_spiCtx[0].spi_info) && (hdl != m_spiCtx[1].spi_info))\
            return PPlus_ERR_NOT_REGISTED;}
////////////////// SPI  /////////////////////////////////////////
static void hal_spi_write_fifo(AP_SSI_TypeDef* Ssix,uint8_t len,uint8_t* tx_rx_ptr)
    uint8_t i=0;
    SPI_INDEX_e spi_index = (Ssix == AP_SPI0) ? SPI0 : SPI1;
    HAL_ENTER_CRITICAL_SECTION();
    while(i<len)
        if (m_spiCtx[spi_index].cfg.spi_dfsmod <= SPI_1BYTE)
            Ssix->DataReg = *(tx_rx_ptr+i);
            Ssix->DataReg = *((uint16_t*)tx_rx_ptr+i);
        i++;
    HAL_EXIT_CRITICAL_SECTION();
void spi_int_enable(hal_spi_t* spi_ptr, uint32_t mask)
    AP_SSI_TypeDef* Ssix = NULL;
    Ssix = (spi_ptr->spi_index == SPI0) ? AP_SPI0 : AP_SPI1;
    Ssix->IMR = mask & 0x11;
    if(Ssix == AP_SPI0)
        JUMP_FUNCTION(SPI0_IRQ_HANDLER)                  =   (uint32_t)&hal_SPI0_IRQHandler;
        JUMP_FUNCTION(SPI1_IRQ_HANDLER)                  =   (uint32_t)&hal_SPI1_IRQHandler;
    NVIC_EnableIRQ((IRQn_Type)(SPI0_IRQn + spi_ptr->spi_index));
    NVIC_SetPriority((IRQn_Type)(SPI0_IRQn + spi_ptr->spi_index), IRQ_PRIO_HAL);
static void spi_int_disable(hal_spi_t* spi_ptr)
    NVIC_DisableIRQ((IRQn_Type)(SPI0_IRQn + spi_ptr->spi_index));
    Ssix->IMR = 0x00;
static void spi_int_handle(uint8_t id, spi_Ctx_t* pctx, AP_SSI_TypeDef* Ssix)
    volatile uint8_t spi_irs_status;
    spi_evt_t evt;
    uint8_t i, cnt;
    spi_xmit_t* trans_ptr;
    trans_ptr = &pctx->transmit;
    spi_irs_status = Ssix->ISR;
    if(spi_irs_status & TRANSMIT_FIFO_EMPTY)
        cnt = 8 - Ssix->TXFLR;
        for(i = 0; i< cnt; i++)
            if(trans_ptr->tx_buf)
                Ssix->DataReg = trans_ptr->tx_buf[trans_ptr->tx_offset ++];
                trans_ptr->tx_offset++;
                Ssix->DataReg = 0;
            if(trans_ptr->tx_offset == trans_ptr->xmit_len)
                Ssix->IMR = 0x10;
                m_spiCtx[pctx->spi_info->spi_index].transmit.busy = FALSE;
    if(spi_irs_status & RECEIVE_FIFO_FULL)
        cnt = Ssix->RXFTLR;
            trans_ptr->rx_buf[trans_ptr->rx_offset++] = Ssix->DataReg;
        if(trans_ptr->rx_offset == trans_ptr->xmit_len)
            if(pctx->cfg.force_cs == true)
                hal_gpio_fmux(pctx->cfg.ssn_pin, Bit_ENABLE);
            trans_ptr->busy = false;
            trans_ptr->rx_buf = NULL;
            trans_ptr->rx_offset = 0;
            evt.id = id;
            evt.evt = SPI_RX_COMPLETED;
            hal_pwrmgr_unlock((MODULE_e)(MOD_SPI0 + id));
            pctx->cfg.evt_handler(&evt);
            evt.evt = SPI_TX_COMPLETED;
static void spis_int_handle(uint8_t id, spi_Ctx_t* pctx, AP_SSI_TypeDef* Ssix)
    spi_evt_t evt;
    uint16_t i, cnt;
    trans_ptr = &(pctx->transmit);
                Ssix->IMR = 0x10;
                trans_ptr->tx_offset ++;
                Ssix->DataReg = 0;
        volatile uint32_t garbage;
        cnt = Ssix->RXFLR;
        if(trans_ptr->rx_buf)
                if(trans_ptr->xmit_len > trans_ptr->rx_offset)
                    garbage = Ssix->DataReg;
            uint8_t rxbuf[16];
            if(trans_ptr->busy)
                trans_ptr->rx_offset += cnt;
                *(rxbuf+i) = Ssix->DataReg;
            evt.id = id;
            evt.evt = SPI_RX_DATA_S;
            evt.data = rxbuf;
            evt.len = cnt;
        if(trans_ptr->busy && trans_ptr->rx_offset >= trans_ptr->xmit_len)
            memset(trans_ptr, 0, sizeof(spi_xmit_t));
            evt.id = id;
            evt.data = NULL;
            evt.len = cnt;
    @fn          hal_SPI0_IRQHandler
    @brief       This function process for spi0 interrupt,when use int please consummate its callbackfunction
    input parameters
    @param       None.
    output parameters
    @param       None.
    @return      None.
void __attribute__((used)) hal_SPI0_IRQHandler(void)
    spi_Ctx_t* pctx = &m_spiCtx[0];
    if(pctx->spi_info == NULL)
    if(pctx->is_slave_mode)
        spis_int_handle(0, pctx, AP_SPI0);
        spi_int_handle(0, pctx, AP_SPI0);
    @fn          hal_SPI1_IRQHandler
    @brief       This function process for spi1 interrupt,when use int please consummate its callbackfunction
    input parameters
    @param       None.
    output parameters
    @param       None.
    @return      None.
void __attribute__((used)) hal_SPI1_IRQHandler(void)
    spi_Ctx_t* pctx = &m_spiCtx[1];
        spis_int_handle(1, pctx, AP_SPI1);
        spi_int_handle(1, pctx, AP_SPI1);
    @fn          hal_spi_pin_init
    @brief       This function process for spi pin initial(4 lines);You can use two spi,spi0 and spi1,should programe by USE_AP_SPIX
    input parameters
    @param       GPIO_Pin_e sck_pin: define sclk pin
                GPIO_Pin_e ssn_pin: define ssn pin
                GPIO_Pin_e tx_pin: define transmit pin;when use as master,it's mosi pin;corresponding,use as slave,it's miso
                GPIO_Pin_e rx_pin: define receive pin;when use as master,it's miso pin;corresponding,use as slave,it's mosi
    output parameters
    @param       None.
    @return      None.
static void hal_spi_pin_init(hal_spi_t* spi_ptr,GPIO_Pin_e sck_pin,GPIO_Pin_e ssn_pin,GPIO_Pin_e tx_pin,GPIO_Pin_e rx_pin)
    if(spi_ptr->spi_index == SPI0)
        hal_gpio_fmux_set(sck_pin, FMUX_SPI_0_SCK);
        hal_gpio_fmux_set(ssn_pin, FMUX_SPI_0_SSN);
        hal_gpio_fmux_set(tx_pin, FMUX_SPI_0_TX);
        hal_gpio_fmux_set(rx_pin, FMUX_SPI_0_RX);
    else if(spi_ptr->spi_index == SPI1)
        hal_gpio_fmux_set(sck_pin, FMUX_SPI_1_SCK);
        hal_gpio_fmux_set(ssn_pin, FMUX_SPI_1_SSN);
        hal_gpio_fmux_set(tx_pin, FMUX_SPI_1_TX);
        hal_gpio_fmux_set(rx_pin, FMUX_SPI_1_RX);
static void hal_spi_pin_deinit(GPIO_Pin_e sck_pin,GPIO_Pin_e ssn_pin,GPIO_Pin_e tx_pin,GPIO_Pin_e rx_pin)
    hal_gpio_fmux(sck_pin, Bit_DISABLE);
    hal_gpio_fmux(ssn_pin, Bit_DISABLE);
    hal_gpio_fmux(tx_pin, Bit_DISABLE);
    hal_gpio_fmux(rx_pin, Bit_DISABLE);
    @fn          hal_spi_master_init
    @brief       This function process for spi master initial
    input parameters
    @param       uint32_t baud: baudrate select
                SPI_SCMOD_e scmod: Serial Clock Polarity and Phase select;  SPI_MODE0,        //SCPOL=0,SCPH=0(default)
        SPI_MODE1,        //SCPOL=0,SCPH=1
        SPI_MODE2,        //SCPOL=1,SCPH=0
        SPI_MODE3,        //SCPOL=1,SCPH=1
                SPI_TMOD_e tmod: Transfer Mode                              SPI_TRXD,        //Transmit & Receive(default)
        SPI_TXD,         //Transmit Only
        SPI_RXD,         //Receive Only
        SPI_EEPROM,      //EEPROM Read
    output parameters
    @param       None.
    @return      None.
static void hal_spi_master_init(hal_spi_t* spi_ptr,uint32_t baud,SPI_SCMOD_e scmod,SPI_TMOD_e tmod)
    uint8_t shift = 0;
    AP_COM_TypeDef* apcom = AP_COM;
    uint16_t baud_temp;
    int pclk = clk_get_pclk();
        shift = 1;
    Ssix->SSIEN = 0;  //DISABLE_SPI;
    apcom->PERI_MASTER_SELECT |= (BIT(shift)|BIT(shift+4));
    Ssix->CR0= ((Ssix->CR0) & 0xfffffc3f)|(scmod<<6)|(tmod<<8);
    baud_temp = (pclk + (baud>>1)) / baud;
    if(baud_temp<2)
        baud_temp = 2;
    else if(baud_temp>65534)
        baud_temp =65534;
    Ssix->BAUDR= baud_temp;   // set clock(round)
    Ssix->TXFTLR=4;    // set fifo threshold to triggle interrupt
    Ssix->RXFTLR=1;
    Ssix->IMR = 0x00;
    Ssix->SER=1;      //enable slave device
    Ssix->SSIEN = 1;  //ENABLE_SPI;
    @fn          hal_spi_slave_init
    @brief       This function process for spi slave initial
    input parameters
    output parameters
    @param       None.
    @return      None.
/*static*/ void hal_spi_slave_init(hal_spi_t* spi_ptr,uint32_t baud,SPI_SCMOD_e scmod,SPI_TMOD_e tmod)
    uint8_t shift = 0;
    uint16_t baud_temp;
        shift = 1;
    apcom->PERI_MASTER_SELECT &= ~(BIT(shift));
    Ssix->CR0= ((Ssix->CR0) & 0xfffffc3f)|(scmod<<6)|(tmod<<8)|0x400;
    if(baud_temp<2)
        baud_temp = 2;
        baud_temp =65534;
    Ssix->RXFTLR=1;    //threshold is 1
    Ssix->IMR=0x11;    //enable tx and rx
    //  Ssix->SER=1;      //enable slave device
#if DMAC_USE
static void config_dma_channel4spitx(hal_spi_t*  spi_ptr,uint8_t* tx_buf,uint16_t tx_len)
    DMA_CH_CFG_t cfgc;
    Ssix->DMACR &= 0x01;
    spi_Ctx_t* pctx;
    pctx = &m_spiCtx[spi_ptr->spi_index];
    cfgc.sinc = DMA_INC_INC;
    if(pctx->cfg.spi_dfsmod <= SPI_1BYTE)
        hal_spi_dfs_set(spi_ptr,SPI_1BYTE);
        cfgc.transf_size = tx_len;
        cfgc.src_tr_width = DMA_WIDTH_BYTE;
        cfgc.dst_tr_width = DMA_WIDTH_BYTE;
        cfgc.src_addr = (uint32_t)tx_buf;
        uint16_t* size16_tx_buf = (uint16_t*)tx_buf;
        hal_spi_dfs_set(spi_ptr,SPI_2BYTE);
        cfgc.transf_size = tx_len/2;
        cfgc.src_tr_width = DMA_WIDTH_HALFWORD;
        cfgc.dst_tr_width = DMA_WIDTH_HALFWORD;
        cfgc.src_addr = (uint32_t)size16_tx_buf;
    cfgc.src_msize = DMA_BSIZE_1;
    cfgc.dinc = DMA_INC_NCHG;
    cfgc.dst_msize = DMA_BSIZE_1;
    cfgc.dst_addr = (uint32_t)&(Ssix->DataReg);
    cfgc.enable_int = false;
    hal_dma_config_channel(DMA_CH_1,&cfgc);
    hal_dma_start_channel(DMA_CH_1);
    Ssix->DMACR |= 0x02;
    Ssix->DMATDLR = 0;
static void config_dma_channel4spirx(hal_spi_t*  spi_ptr,uint8_t* rx_buf,uint16_t rx_len)
    DMA_CH_CFG_t cfgc;
    Ssix->DMACR &= 0x02;
    cfgc.transf_size = rx_len;
    cfgc.sinc = DMA_INC_NCHG;
    cfgc.src_addr = (uint32_t)&(Ssix->DataReg);
    cfgc.dinc = DMA_INC_INC;
    cfgc.dst_addr = (uint32_t)rx_buf;
    hal_dma_config_channel(DMA_CH_2,&cfgc);
    hal_dma_start_channel(DMA_CH_2);
    Ssix->DMACR |= 0x01;
    Ssix->DMARDLR = 0;
static int hal_spi_xmit_polling
    hal_spi_t*  spi_ptr,
    uint8_t*    tx_buf,
    uint8_t*    rx_buf,
    uint16_t    tx_len,
    uint16_t    rx_len
    uint32_t rx_size = rx_len, tx_size = tx_len;
    uint32_t tmp_len,i,tmp_tx_buf_len = 0;
    #if DMAC_USE
    spi_Ctx_t* pctx;
    SPI_INIT_TOUT(to);
    #if DMAC_USE
    if(rx_len && pctx->cfg.dma_rx_enable)
        config_dma_channel4spirx(spi_ptr,rx_buf,rx_len);
    if(tx_len && pctx->cfg.dma_tx_enable)
        config_dma_channel4spitx(spi_ptr,tx_buf,tx_len);
    while(1)
        if(Ssix->SR & TX_FIFO_NOT_FULL && tx_size
            #if DMAC_USE
                && !(pctx->cfg.dma_tx_enable)
//#if DMAC_USE
//        if(Ssix->SR & TX_FIFO_NOT_FULL && tx_size && !(pctx->cfg.dma_tx_enable))
//#else
//        if(Ssix->SR & TX_FIFO_NOT_FULL && tx_size)
//#endif
            tmp_len = 8-Ssix->TXFLR;
            if(tmp_len > tx_size)
                tmp_len = tx_size;
            if(tx_buf)
                //support divider 2
                if (m_spiCtx[spi_ptr->spi_index].cfg.spi_dfsmod <= SPI_1BYTE)
                    switch (tmp_len)
                    case 1:
                        Ssix->DataReg = *(tx_buf+tmp_tx_buf_len);
                        tmp_tx_buf_len += 1;
                    case 2:
                        Ssix->DataReg = *(tx_buf+tmp_tx_buf_len+1);
                        tmp_tx_buf_len += 2;
                    case 3:
                        Ssix->DataReg = *(tx_buf+tmp_tx_buf_len+2);
                        tmp_tx_buf_len += 3;
                    case 4:
                        Ssix->DataReg = *(tx_buf+tmp_tx_buf_len+3);
                        tmp_tx_buf_len += 4;
                    case 5:
                        Ssix->DataReg = *(tx_buf+tmp_tx_buf_len+4);
                        tmp_tx_buf_len += 5;
                    case 6:
                        Ssix->DataReg = *(tx_buf+tmp_tx_buf_len+5);
                        tmp_tx_buf_len += 6;
                    case 7:
                        Ssix->DataReg = *(tx_buf+tmp_tx_buf_len+6);
                        tmp_tx_buf_len += 7;
                    case 8:
                        Ssix->DataReg = *(tx_buf+tmp_tx_buf_len+7);
                        tmp_tx_buf_len += 8;
                    switch (tmp_len)
                    case 1:
                        Ssix->DataReg = *((uint16_t*)tx_buf+tmp_tx_buf_len);
                    case 2:
                        Ssix->DataReg = *((uint16_t*)tx_buf+tmp_tx_buf_len+1);
                    case 3:
                        Ssix->DataReg = *((uint16_t*)tx_buf+tmp_tx_buf_len+2);
                    case 4:
                        Ssix->DataReg = *((uint16_t*)tx_buf+tmp_tx_buf_len+3);
                    case 5:
                        Ssix->DataReg = *((uint16_t*)tx_buf+tmp_tx_buf_len+4);
                    case 6:
                        Ssix->DataReg = *((uint16_t*)tx_buf+tmp_tx_buf_len+5);
                    case 7:
                        Ssix->DataReg = *((uint16_t*)tx_buf+tmp_tx_buf_len+6);
                    case 8:
                        Ssix->DataReg = *((uint16_t*)tx_buf+tmp_tx_buf_len+7);
                for(i = 0; i< tmp_len; i++)
                    Ssix->DataReg = 0;
            tx_size -= tmp_len;
        #if DMAC_USE
        if(pctx->cfg.dma_tx_enable || pctx->cfg.dma_rx_enable || ((rx_len == 0) && (tx_size == 0)))
        else if(rx_len && !(pctx->cfg.dma_rx_enable))
        if((rx_len == 0) && ((tx_size == 0)))
        else if(rx_len)
            if(Ssix->RXFLR)
                tmp_len = Ssix->RXFLR;
                    *rx_buf++= Ssix->DataReg;
                rx_size -= tmp_len;
            if(rx_size == 0)
        SPI_CHECK_TOUT(to, SPI_OP_TIMEOUT, "hal_spi_xmit_polling TO\n");
    #if DMAC_USE
    if(pctx->cfg.dma_tx_enable)
        hal_dma_status_control(DMA_CH_1);
    if(pctx->cfg.dma_rx_enable)
        hal_dma_status_control(DMA_CH_2);
    while(Ssix->SR & SPI_BUSY)
    return PPlus_SUCCESS;
static void spi0_sleep_handler(void)
    if(m_spiCtx[0].spi_info != NULL)
        hal_spi_bus_deinit(m_spiCtx[0].spi_info);
static void spi1_sleep_handler(void)
    if(m_spiCtx[1].spi_info != NULL)
        hal_spi_bus_deinit(m_spiCtx[1].spi_info);
static void spi0_wakeup_handler(void)
    NVIC_SetPriority((IRQn_Type)SPI0_IRQn, IRQ_PRIO_HAL);
static void spi1_wakeup_handler(void)
    NVIC_SetPriority((IRQn_Type)SPI1_IRQn, IRQ_PRIO_HAL);
void hal_spi_tmod_set(hal_spi_t* spi_ptr,SPI_TMOD_e mod)
    Ssix->SSIEN = 0;
    subWriteReg(&Ssix->CR0,9,8,mod);
    Ssix->SSIEN = 1;
void hal_spi_dfs_set(hal_spi_t* spi_ptr,SPI_DFS_e mod)
    spi_Ctx_t* pctx;
    Ssix->SSIEN = 0;
    subWriteReg(&Ssix->CR0,3,0,mod);
    Ssix->SSIEN = 1;
    pctx->cfg.spi_dfsmod = mod;
static void hal_spi_ndf_set(hal_spi_t* spi_ptr,uint16_t len)
    if(len == 0)
    Ssix->SSIEN = 0;
    Ssix->CR1 = len-1;
    Ssix->SSIEN = 1;
int hal_spi_transmit
    hal_spi_t*  spi_ptr,
    SPI_TMOD_e  mod,
    uint8_t*    tx_buf,
    uint8_t*    rx_buf,
    uint16_t    tx_len,
    uint16_t    rx_len
    int ret;
    spi_Ctx_t* pctx;
    SPI_HDL_VALIDATE(spi_ptr);
    if(((tx_len == 0)&&(rx_len == 0))||(mod > SPI_EEPROM)||(tx_buf == NULL))
    if(pctx->transmit.busy == true)
        return PPlus_ERR_BUSY;
    #if DMAC_USE
    if((pctx->cfg.dma_rx_enable && (rx_len==0)) ||
            (pctx->cfg.dma_tx_enable && (tx_len==0)))
    hal_spi_tmod_set(spi_ptr,mod);
    if(mod > SPI_TXD)  //spi receive only or eeprom read,should set read data len(ndf)
        hal_spi_ndf_set(spi_ptr,rx_len);
    if(pctx->cfg.force_cs == true /*&& pctx->is_slave_mode == FALSE*/)
        hal_gpio_fmux(pctx->cfg.ssn_pin,Bit_DISABLE);
        hal_gpio_write(pctx->cfg.ssn_pin,0);
    if(pctx->cfg.int_mode == false)
        ret = hal_spi_xmit_polling(spi_ptr,tx_buf, rx_buf, tx_len,rx_len);
        if(pctx->cfg.force_cs == true  && pctx->is_slave_mode == FALSE)
            hal_gpio_fmux(pctx->cfg.ssn_pin,Bit_ENABLE);
        if(ret)
            return PPlus_ERR_TIMEOUT;
        spi_int_disable(spi_ptr);
        if(trans_ptr->buf_len < tx_len)
            return PPlus_ERR_NO_MEM;
        if(tx_buf)
            if(!trans_ptr->tx_buf)
        trans_ptr->tx_offset = 0;
        memcpy(trans_ptr->tx_buf,tx_buf,tx_len);
        if(Ssix->SR & TX_FIFO_NOT_FULL)
            uint16_t _tx_len;
            uint8_t dummy[8];
            if(rx_buf)
                trans_ptr->rx_buf = rx_buf;
            hal_pwrmgr_lock((MODULE_e)(MOD_SPI0 + spi_ptr->spi_index));
            _tx_len = (tx_len >= 8)?8:tx_len;
                trans_ptr->tx_offset += _tx_len;
                hal_spi_write_fifo(Ssix,_tx_len,tx_buf);
                hal_spi_write_fifo(Ssix,_tx_len,dummy);
            trans_ptr->xmit_len = tx_len;
        pctx->transmit.busy = true;
        spi_int_enable(spi_ptr, 0x11);
int hal_spi_set_tx_buffer(hal_spi_t* spi_ptr,uint8_t* tx_buf,uint16_t len)
    if((tx_buf == NULL) || (len == 0))
    m_spiCtx[spi_ptr->spi_index].transmit.tx_buf = tx_buf;//used when tx int
    m_spiCtx[spi_ptr->spi_index].transmit.buf_len = len;
int hal_spi_set_int_mode(hal_spi_t* spi_ptr,bool en)
    m_spiCtx[spi_ptr->spi_index].cfg.int_mode = en;
    if(en)
        m_spiCtx[spi_ptr->spi_index].cfg.int_mode = true;
        spi_int_enable(spi_ptr, 0x10);
        m_spiCtx[spi_ptr->spi_index].cfg.int_mode = false;
int hal_spi_set_force_cs(hal_spi_t* spi_ptr,bool en)
    m_spiCtx[spi_ptr->spi_index].cfg.force_cs = en;
bool hal_spi_get_transmit_bus_state(hal_spi_t* spi_ptr)
    return m_spiCtx[spi_ptr->spi_index].transmit.busy;
int hal_spi_TxComplete(hal_spi_t* spi_ptr)
    SPI_INIT_TOUT(to);
        SPI_CHECK_TOUT(to, SPI_OP_TIMEOUT, "hal_spi_TxComplete TO\n");
int hal_spi_send_byte(hal_spi_t* spi_ptr,uint8_t data)
        Ssix->DataReg = data & 0xff;
        SPI_INIT_TOUT(to);
            SPI_CHECK_TOUT(to, SPI_OP_TIMEOUT,"hal_spi_send_byte TO\n");
int hal_spi_bus_init(hal_spi_t* spi_ptr,spi_Cfg_t cfg)
    spi_Ctx_t* pctx = NULL;
    if((spi_ptr == NULL) || (spi_ptr->spi_index > 1))
    if(pctx->spi_info != NULL)
    hal_clk_gate_enable((MODULE_e)(MOD_SPI0 + spi_ptr->spi_index));
    hal_spi_pin_init(spi_ptr,cfg.sclk_pin,cfg.ssn_pin,cfg.MOSI,cfg.MISO);
    hal_spi_master_init(spi_ptr,cfg.baudrate, cfg.spi_scmod, cfg.spi_tmod);
    hal_spi_dfs_set(spi_ptr,cfg.spi_dfsmod);
    pctx->cfg = cfg;
    pctx->transmit.busy = false;
    pctx->spi_info = spi_ptr;
    if(cfg.int_mode)
    pctx->is_slave_mode = false;
int hal_spis_clear_rx(hal_spi_t* spi_ptr)
    volatile uint8_t rx;
    while(Ssix->RXFLR)
        rx = Ssix->DataReg;
    return (int)rx;
uint32_t hal_spis_rx_len(hal_spi_t* spi_ptr)
    return Ssix->RXFLR;
int hal_spis_read_rxn(hal_spi_t* spi_ptr, uint8_t* pbuf, uint16_t len)
    while(len)
        *pbuf = Ssix->DataReg;
        pbuf ++;
        len --;
int hal_spis_bus_init(hal_spi_t* spi_ptr,spi_Cfg_t cfg)
    hal_spi_slave_init(spi_ptr,cfg.baudrate, cfg.spi_scmod, cfg.spi_tmod);
    pctx->cfg = cfg;
    memset(&(pctx->transmit), 0, sizeof(spi_xmit_t));
    pctx->is_slave_mode = true;
    if(cfg.int_mode)
    @fn          hal_spi_deinit
    @brief       This function will deinit the spi you select.
    input parameters
    @param         hal_spi_t* spi_ptr: spi module handle.
    output parameters
    @param       None.
    @return
                PPlus_SUCCESS
int hal_spi_bus_deinit(hal_spi_t* spi_ptr)
    hal_clk_gate_disable((MODULE_e)(MOD_SPI0 + spi_ptr->spi_index));
    //spi_int_disable(spi_ptr);
    hal_spi_pin_deinit(m_spiCtx[spi_ptr->spi_index].cfg.sclk_pin,m_spiCtx[spi_ptr->spi_index].cfg.ssn_pin,m_spiCtx[spi_ptr->spi_index].cfg.MOSI,m_spiCtx[spi_ptr->spi_index].cfg.MISO);
    memset(&m_spiCtx,0,2*sizeof(spi_Ctx_t));
    @fn          hal_spi_init
    @brief       it is used to init spi module.
    input parameters
    @param       None
    output parameters
    @param       None.
    @return      None.
int hal_spi_init(SPI_INDEX_e channel)
    int ret = 0;
    if(channel == SPI0)
        ret = hal_pwrmgr_register(MOD_SPI0,spi0_sleep_handler, spi0_wakeup_handler);
        if(ret == PPlus_SUCCESS)
            memset(&m_spiCtx[0],0,sizeof(spi_Ctx_t));
    else if(channel == SPI1)
        ret = hal_pwrmgr_register(MOD_SPI1,spi1_sleep_handler, spi1_wakeup_handler);
            memset(&m_spiCtx[1],0,sizeof(spi_Ctx_t));
#if DMAC_USE
int hal_spi_dma_set(hal_spi_t* spi_ptr,bool ten,bool ren)
    pctx->cfg.dma_rx_enable = ren;
    pctx->cfg.dma_tx_enable = ten;
