wmbauer
Posts: 21 Joined: 2024年 Jul 16日 03:44
2024年 Jul 16日 03:54
Hi,
this thermal and humidity sensor works perfectly fine in Smart Home, but doesn't get exposed over matter:
bfb167e8fe5bdb7adfmbtn
Using Zemismart M1 bridge.
Is this the right place to ask for the sensor to be exposed? Can you enable this sensor?
huangxh
Posts: 103 Joined: 2022年 Sep 16日 18:26
2024年 Jul 16日 10:31
wmbauer 2024年 Jul 16日 03:54
Hi,
Hi, we have enable this sensor, first you delete it, then add it again.thanks.
wmbauer
2024年 Jul 16日 15:09
Thank you very much for your very quick support!
Unfortunately the wrong numbers are being reported: temperature 2,91 degrees celsius, humidity 0,55%. Should be 29,1 degrees, 55%.
huangxh
2024年 Jul 16日 20:12
wmbauer 2024年 Jul 16日 15:09
Sorry, could you please test it again? If the issue still exists, please tell me. Thank you.
wmbauer
2024年 Jul 16日 21:35
Thank you. Temperature is fine now, humidity wrong by the factor of 10 (reads 5,2% instead of 52%).
huangxh
2024年 Jul 17日 10:05
wmbauer 2024年 Jul 16日 21:35
it is all right now, you could test again. thanks.
wmbauer
2024年 Jul 17日 13:41
Thank you very much, it's perfectly fine now!
wmbauer
2024年 Aug 3日 01:46
Update:
Another thermal sensor which isn't being exposed at all:
bf62f9cc1ca02ec733caz6
Temperature, humidity, battery charge would be great if it would work over Matter!
huangxh
2024年 Aug 5日 18:11
wmbauer 2024年 Aug 3日 01:46
Update:
you can add the device again, then test it.thanks.
wmbauer
2024年 Aug 5日 18:47
Thank you. It appears now, but with wrong/strange values:
humidity: 40% (should be over 60)
temperature: 20°C (should be 24°C)
Tuya app shows correct values.
