Smart Home PaaS Solution
Discussing technical aspects of Yun development products, including IoT Core and other cloud service APIs, data analysis products, etc.
tianze.lu@tuya.com
Tuya Smart Home PaaS development method mainly supports the following two solutions. For more information, see Cloud Integration Solutions.
Note
This documentation is no longer updated. For more information, see Cloud Integration Solutions.
Solution 1: OEM app
Solution Flow Chart
Features
  • Based on the Tuya OEM app, Tuya IoT Cloud can be connected on-demand. Commands can be sent to devices through the cloud.
  • The device and the app are connected to the cloud at the same time, and all requests of the device and the app are sent to the cloud.
  • The customer has ownership over the user group and the device data. The customer can manage user data and device info based on Tuya OpenAPI, execute commands such as timing setting, scene-setting, and obtain analysis data.
Services provided by Tuya
  • Public version OEM app or custom app development plan.
  • Provide product category-based standard command sets, which can control different models of devices in the same category on the Tuya AI+IoT Development Platform.
  • Provide standard OpenAPI to manage user and device data, and provide a message queue for customers to collect real-time device data.
Strengths
  • With low cost and fast development, the solution can quickly be deployed to support the connection of multi-category devices under the Tuya solution.
  • To fully take advantage of all the functions of the Tuya AI+IoT Development Platform.
  • Quickly bring products to the market.
  • Data can be collected from the Tuya AI+IoT Development Platform for analysis and complex scene development as needed.
Solution 2: IoT App SDK connection
Solution Flow Chart
  • Provide IoT App SDK.
  • Provide OpenAPI to complete other functions such as user connection, device discovery, and device control.
  • Provide category-based standard command sets, which can control the devices in the Tuya AI+IoT Development Platform by category or model.
  • Provide a message queue for customers to obtain real-time device data.
Features
  • Develop an app based on Tuya IoT App SDK.
  • It has an independent account system, and the account system data is stored in a private cloud.
  • Make full use of all the functions of the Tuya AI+IoT Development Platform.
  • Data can be collected from the Tuya AI+IoT Development Platform for data analysis as needed.
EncoreGeek
Re: Smart Home PaaS Solution
I have many projects that are not in the field of whole-home smart solutions. Does Tuya also offer mature services in some commercial areas?
vt.y
Yes, Tuya provides basic IoT Core services for non-whole-home smart scenarios. You can use Tuya devices to develop various IoT projects based on this service. For more information about the IoT Core capability, you can refer to:https://developer.tuya.com/en/docs/clou ... b8geg6o761
jaki1990
It’s interesting to explore the potential of Tuya Smart Home PaaS in the context of AI integration. The platform mainly supports two development methods, giving flexibility for building smart home ecosystems. Cloud Integration Solutions look especially valuable, as AI can greatly enhance automation and personalization scenarios. Has anyone here already tested combining these approaches in real projects?
LuMilton
I’ve been playing around with smart home projects for a while now, and one thing I noticed is how tricky it can be to connect different systems smoothly. For example, I set up routines for climate control and lighting, and while they worked, it felt like they weren’t really learning from my daily habits. That’s why I started looking into AI-driven solutions to make the automation more adaptive and less rigid. I recently came across this site https://aristeksystems.com/ai-integration-services/ which gave me a lot of useful insights on how to approach integration more effectively.
jaki1990
Absolutely, integrating AI into smart home ecosystems opens up a whole new level of functionality. I've also experimented with Tuya's PaaS and found the cloud integration route promising, especially when paired with AI models that adapt to user behavior over time. The key challenge is achieving seamless interoperability between devices and ensuring real-time learning. Exploring third-party AI services definitely adds value for more dynamic automation.
LuMilton
Thanks for sharing your experience, jaki1990. I completely agree that interoperability is one of the toughest parts when experimenting with Tuya’s PaaS, especially once you start combining devices from different vendors. What I’m curious about is whether anyone here has tried using AI not only for behavior prediction but also for optimizing energy consumption or security scenarios. It feels like the cloud integration path has potential for this, but I wonder if the latency is still an issue in real-time applications.
jaki1990
That’s a great point. Energy optimization and security are exactly the areas where AI could show its real strength when combined with Tuya’s PaaS. From what I’ve seen, cloud integration already makes it easier to gather and process data, but the challenge is still how quickly the system can react without noticeable delays. I’m planning to test a mixed setup with local AI inference and cloud backup to see if that balances speed with flexibility and creates a smoother user experience.
