2 Buttons Keypad shows as 6 Buttons on HA via Matter
Hollako
Dear support,
I added a 2 Buttons Keypad added on a Tuya Zigbee Gateway and share it via Matter with HA, however it shows as 6 buttons and it didn't work at all. The Keypad is M8-2 with the following ID:
  • bf2fe9f52b4fff4a79819q
Thank you.
fangping.guo
Re: 2 Buttons Keypad shows as 6 Buttons on HA via Matter
Hello, I have fixed the bridging support for it. It should now be displayed as a 2-way composite scene switch. You can restart your Matter gateway to verify.
Hollako
Ok thank you,
Please i found the 4 Gangs and 1 Gang Keypads also showing as 6 Gangs and not working as well:
4 Gangs: bf76b46c827c1ff3e7lnuv
1 Gang: bf8ec82613f5a3a1aacq3a
Thanks in advance.
fangping.guo
done.
Hollako
All Good regading these keypads, many thanks for your effort.
I have found one more thing regading a Motion sensor, it's showing only the Battery Level via Matter but not the presence sensor.
Regards,
fangping.guo
This device is already supported for bridging. I noticed that you have bound it to the Zigbee Gateway Pro instead of the Matter Gateway. To ensure the bridging function works properly, you need to place it under the Matter Gateway.
Hollako
Not really, it's on the same Gateway of the other Keypads that worked via Matter. This sensor is only sharing the Battery Level but not the occupancy status via Matter. and this Zigbee Gateway Pro is Matter support as well.
fangping.guo
From the logs, I can see that when the sensor reports whether there is someone or not, the Matter Gateway has successfully received the data and converted it for reporting. The Matter platform should be able to correctly observe the changes in the sensor status. If you are sure that there is no change, please provide the corresponding operation recording screen and upload it as an attachment. Let me know the time of the operation so that I can compare and analyze it.
Hollako
Hello,
I am not sure if the attached is the needed logs. However i was comparing between the Door contact which are working normally with HA and the Motion sensor, i found that the clusters are same for both items Door Contact and Motion Detectors. i have a doubt maybe it's a problem from between Home Assistant and the Matter Add-on in HAOS.
