Por Favor, Corrija - Matéria De Cortina Offline
weberamaral
hi,
I have two curtains that are constantly offline/unavailable in the Apple Home app via Matter.
Hub Tuya: ebde6fc7b520e478afui5r (HUB Matter Nova Digital)
Curtain 1: ebade84c8abef63a52tuaq (Bat. Curtain Nova Digital)
I often have to press the pause button on the remote control to wake it up and re-sync its status in the Apple Home app. Please help🔥!!
fangping.guo
Re: Please Fix - Curtain Offline Matter
From the log, I can see that the network connection quality of the gateway is not very good and it often goes offline. You can check the network connection issue of the gateway itself.
weberamaral
Hi.
My gateway is connected via Ethernet cable.
What signal issue identified in the logs is causing this type of problem?
fangping.guo
Re: Por Favor, Corrija - Matéria De Cortina Offline
What we are looking at is the online log, which shows that the gateway frequently switches between being online and offline.
weberamaral
fangping.guo
O que estamos olhando é o registro on-line, que mostra que o gateway frequentemente alterna entre estar online e offline. [/citação]
And what does that mean? Any ideas?
As I mentioned, it's always connected via cable (using two internet connections, with one acting as a failover).
