【已解决】【tuyaos】uf_db方式存储数据失败
yangjie
wxq1123 2024年 Jan 16日 09:47
yangjie 2024年 Jan 15日 17:33
wxq1123 2024年 Jan 15日 17:17
有没有直接保存16进制数据的方法?uf原来得把数据转成字符串才能保存,遇到16进制的0直接当结束符给处理掉了
你看下这个内容:https://www.cnblogs.com/kangjianwei101/p/5220021.html,覆盖二进制写用 wb+,追加二进制写用 ab+
示例代码:
***********************function define**********************
* @brief base db task
* @param[in] param:Task parameters
* @return none
VOID example_uf_file(INT_T argc, CHAR_T *argv[])
    OPERATE_RET op_ret = OPRT_OK;
    UCHAR_T * fd = NULL;
    UCHAR_T write_buff[5] = {0x00, 0x01, 0x02, 0x03, 0x04};
    UCHAR_T *read_buff = NULL;
    INT_T write_num = 0;
    INT_T read_num = 0;
    BOOL_T temp = TRUE;
    TAL_PR_NOTICE("------ uf file example start ------");
    /*open file, read and write mode*/
    fd = ufopen("test.txt", "wb+"); // 覆盖写,追加写用 "ab+"
    if(NULL == fd) {
        TAL_PR_ERR("file open fail");
    } else {
        TAL_PR_DEBUG("fd : %d", *fd);
    /*change offset*/
    ufseek(fd, 0, UF_SEEK_END);
    /*write*/
    write_num += ufwrite(fd, write_buff, 5);
    TAL_PR_DEBUG("write number : %d", write_num);
    /*check if the current offset reach the end of the file*/
    temp = ufeof(fd);
    if(temp) {
        TAL_PR_DEBUG("offset is at the end");
    } else {
        TAL_PR_DEBUG("offset is not at the end");
    /*change offset*/
    ufseek(fd, 0, UF_SEEK_SET);
    /*get current offset of the unique file*/
    op_ret = uftell(fd);
    TAL_PR_DEBUG("current offset : %d", op_ret);
    /*get the size of the unique file*/
    op_ret = ufgetsize("test.txt");
    TAL_PR_DEBUG("file size: %d", op_ret);
    if (op_ret > 0) {
    	write_num = op_ret;
    /*read*/
    read_buff = (UCHAR_T *)tal_malloc(sizeof(CHAR_T)*write_num + 1);
    if(NULL == read_buff) {
        TAL_PR_ERR("read buff malloc fail!");
    read_num = ufread(fd, read_buff, write_num);
    for (int i =0; i<read_num; i++) {
    	TAL_PR_DEBUG("read_buff[%d} : %x", i, read_buff[i]);
    /*close*/
    op_ret = ufclose(fd);
    if(OPRT_OK != op_ret) {
        TAL_PR_ERR("err<%d>, close fail!", op_ret);
    tal_free(read_buff);
    return;
不好意思,涂鸦的 文件系统仅支持 "r","r+","a","a+","w","w+" 模式。把 "b" 删掉就可以了。
下面的示例是跑过的,更简单的,你可以看下:
    UCHAR_T write_buff[] = {0x00, 0x01, 0x02, 0x03, 0x04};
    INT_T read_num = 0;
/* open file, read and write mode */
fd = ufopen("test.txt", "w+");
if(NULL == fd) {
    return;
} else {
/* write */
write_num = ufwrite(fd, write_buff, 5);
if (write_num != 5) {
    TAL_PR_ERR("write error, write number : %d", write_num);
} else {
/* close */
// 至此文件写内容已经结束了
// 下面是关于文件读的示例
fd = ufopen("test.txt", "r+");
if(NULL == fd) {
    return;
} else {
INT_T fileSize = ufgetsize("test.txt");
TAL_PR_DEBUG("file size: %d", fileSize);
read_buff = (UCHAR_T *)tal_malloc(fileSize);
    ufclose(fd);
    return;
read_num = ufread(fd, read_buff, fileSize);
for (int i = 0; i < read_num; i++) {
    TAL_PR_DEBUG("read_buff[%d] = 0x%02x", i, read_buff[i]);
if (NULL != read_buff) {
    read_buff = NULL;
/* close */
return;
示例执行后日志如下:
[01-01 00:00:12 ty N][example_os_uf_file.c:120] ------ uf file example start ------
[01-01 00:00:12 ty D][example_os_uf_file.c:128] fd : 1
[01-01 00:00:12 ty D][example_os_uf_file.c:136] write number : 5
[01-01 00:00:12 ty D][example_os_uf_file.c:153] fd : 3
[01-01 00:00:12 ty D][example_os_uf_file.c:157] file size: 5
[01-01 00:00:12 ty D][example_os_uf_file.c:168] read_buff[0] = 0x00
[01-01 00:00:12 ty D][example_os_uf_file.c:168] read_buff[1] = 0x01
[01-01 00:00:12 ty D][example_os_uf_file.c:168] read_buff[2] = 0x02
[01-01 00:00:12 ty D][example_os_uf_file.c:168] read_buff[3] = 0x03
[01-01 00:00:12 ty D][example_os_uf_file.c:168] read_buff[4] = 0x04
关于 tuyaos 中文件系统的接口和c语言中的使用方式基本相同,C语言的文件操作你可以看下这个https://www.cnblogs.com/likebeta/archiv ... 51780.html,但是 tuyaos 中的文件系统部分接口可能没有,但是使用方法、函数功能和上面链接中基本上是一样的。
wxq1123
Re: 【求助】【tuyaos】uf_db方式存储数据失败
yingtao_33 2024年 Jan 16日 10:09
yangjie 2024年 Jan 15日 16:01
uf_file:支持文本文件和二进制文件。也是掉电不丢失的。
uf_file: 是通过文件来保存数据的,你可以先创建一个文件,文件名就相当于 key-value 中的 key ,是可以随便定义的。value 就是相当于文件内的内容,可以用来存放你的上下电次数的。
uf 不需要将hex转成字符串,你直接当hex存就可以了
感谢,已经解决了
wxq1123
再请教下如果我有多个类的数据需要保存,为了方便我可以创建多个文件吗?这会不会和只用一个文件相比占用多的多得多的空间?
yangjie
Re: 【已解决】【tuyaos】uf_db方式存储数据失败
可以创建多个文件,一个文件大小最小是 4K
wxq1123
yangjie 2024年 Jan 16日 17:11
谢谢
