Tasmota - 4 relay board
Yocee84
Yes, i has Gateway, same as Vamp.
Vamp
Re: Tasmota - 4 relay board
huangxh 2025年 May 12日 10:05
Thank you for your feedback. If you want to control these devices from an external network, you will need a Tuya gateway.
I have a gateway. A Matter ZigBee Hub (THP10-Z-X)
Vamp
I try to reconnect the device. here the new ID-s:
Matter网关兜底(bfb4524uyrhcsehb)
W20-UBEA 4(bf0bd94b089a068d288ztg)
W20-UBEA 2(bf6eeffd17e40c0b30cgze)
W20-UBEA(bf9a102e30cedfe039xziz)
W20-UBEA 3(bfeaf6f502ac01b543kuks)
huangxh
Vamp 2025年 May 12日 20:36
you can update the gateway to version 1.13.4, then test again.thanks.
Vamp
@huangxh
updated info:
I successfully update the gateway. Now i able to switch on the relay remotely, but the state are not refresh in app. It also the same problem in local network (the old gateway firmware, locally work well)
I re-connect the device, here the new IDs:
W20-UBEA 3 (bf255a5a6445c714a3niqw)
W20-UBEA (bf7ef5a8b731e8f696ryft)
W20-UBEA 2 (bfa4945e715d0fb8df4ess)
W20-UBEA 4 (bfbfa957fcfa302607cxoe)
Matter网关兜底 (bfc6311on1yieb1t)
Further test:
I make two tap to run automation.
  1. tap it to on one of relay on tasmota matter board
  2. tap it to off one of relay on tasmota matter board
Both of them are working! so it send the on / off comand. also say that if i run "on" automation, i not get confirmation but i run "off" i get it:
see the pictures:
huangxh
Vamp 2025年 May 15日 00:23
@huangxh
updated info:
Further test:
see the pictures:
Could you test it again: turn off/on the device, then let me know the test time. Thank you.
Vamp
Do it now.
2025.may.23
22.26 UTC
huangxh
Vamp 2025年 May 24日 06:28
Do it now.
2025.may.23
22.26 UTC
Sorry, it was the weekend the other day and the log was overwritten. Could you try again today? Due to the time difference, you could try earlier in the morning there, while I should be able to check it immediately in the afternoon here.
Vamp
huangxh 2025年 May 26日 11:13
Do it now.
2025.may.23
22.26 UTC
Ok done. I try to switch it.
2025.05.27 05:18 UTC
huangxh
Vamp 2025年 May 27日 13:20
Do it now.
2025.may.23
22.26 UTC
I haven't seen your control records. Could you control it via the external network instead of the local network? Also, please tell me which device is being controlled? Thank you!
