Not able to control smart lock after successful connection in android using sdk.
pratham
After successful connection with smart lock using AP pairing method, not able to unlock the device using self developed android app using sdk.
Able to receive the remote unlock request from device but after allowing to the request I'm getting success in api response but the device is not unlock.
android > build.gradle file
buildscript {
ext {
buildToolsVersion = "35.0.0"
minSdkVersion = 24
compileSdkVersion = 35
targetSdkVersion = 35
ndkVersion = "27.1.12297006"
kotlinVersion = "2.1.20"
repositories {
jcenter()
maven { url 'https://maven-other.tuya.com/repository/maven-releases/' }
maven { url "https://maven-other.tuya.com/repository ... -releases/" }
maven { url 'https://jitpack.io' }
google()
mavenCentral()
maven { url 'https://maven.aliyun.com/repository/public' }
maven { url 'https://central.maven.org/maven2/' }
maven { url 'https://oss.sonatype.org/content/reposi ... snapshots/' }
maven { url 'https://developer.huawei.com/repo/' }
dependencies {
classpath("com.android.tools.build:gradle")
classpath("com.facebook.react:react-native-gradle-plugin")
classpath("org.jetbrains.kotlin:kotlin-gradle-plugin")
allprojects {
repositories {
google()
mavenCentral()
maven { url 'https://www.jitpack.io' }
apply plugin: "com.facebook.react.rootproject"
android > app > build.gradle
apply plugin: "com.android.application"
apply plugin: "org.jetbrains.kotlin.android"
apply plugin: "com.facebook.react"
react {
autolinkLibrariesWithApp()
def enableProguardInReleaseBuilds = false
def jscFlavor = 'io.github.react-native-community:jsc-android:2026004.+'
android {
ndkVersion rootProject.ext.ndkVersion
buildToolsVersion rootProject.ext.buildToolsVersion
compileSdk rootProject.ext.compileSdkVersion
namespace "com.demolock.in"
defaultConfig {
    applicationId "com.demolock.in"
    minSdkVersion rootProject.ext.minSdkVersion
    targetSdkVersion rootProject.ext.targetSdkVersion
    versionCode 1
    versionName "1.0"
     ndk {
     abiFilters "armeabi-v7a", "arm64-v8a"
 packagingOptions {
  pickFirst 'lib/*/libc++_shared.so' // An Android Archive (AAR) file contains an Android library. If the .so file exists in multiple AAR files, select the first AAR file.
signingConfigs {
    debug {
        storeFile file('debug.keystore')
        storePassword 'android'
        keyAlias 'androiddebugkey'
        keyPassword 'android'
buildTypes {
    debug {
        signingConfig signingConfigs.debug
    release {
        // Caution! In production, you need to generate your own keystore file.
        // see https://reactnative.dev/docs/signed-apk-android.
        minifyEnabled enableProguardInReleaseBuilds
        proguardFiles getDefaultProguardFile("proguard-android.txt"), "proguard-rules.pro"
configurations.all {
exclude group: "com.thingclips.smart" ,module: 'thingsmart-modularCampAnno'
dependencies {
// The version of react-native is set by the React Native Gradle Plugin
implementation("com.facebook.react:react-android")
if (hermesEnabled.toBoolean()) {
    implementation("com.facebook.react:hermes-android")
} else {
    implementation jscFlavor
implementation fileTree(dir: 'libs', include: ['*.aar'])
implementation ('com.alibaba:fastjson:1.1.67.android')
implementation ('com.squareup.okhttp3:okhttp-urlconnection:3.14.9')
// The latest stable App SDK for Android.
implementation ('com.facebook.soloader:soloader:0.10.4')
implementation ('com.thingclips.smart:thingsmart:6.2.2')
implementation ('com.thingclips.smart:thingsmart-lock-sdk:6.0.1')
implementation ('com.thingclips.smart:thingsmart-ipcsdk:6.2.0')
// React Native dependencies
// Kotlin
implementation("org.jetbrains.kotlin:kotlin-stdlib-jdk8")
implementation ('com.google.code.gson:gson:2.8.9')
// Add other React Native dependencies
debugImplementation("com.facebook.flipper:flipper:${FLIPPER_VERSION}")
debugImplementation("com.facebook.flipper:flipper-network-plugin:${FLIPPER_VERSION}")
debugImplementation("com.facebook.flipper:flipper-fresco-plugin:${FLIPPER_VERSION}")
nielev
Re: Not able to control smart lock after successful connection in android using sdk.
Apologies for the late reply. If you are still experiencing issues, please:
1.First, check if there is a problem with the device itself.
2.Provide the code that calls the unlock method and the corresponding device ID.
3.The precise time the problem occurred (so we can check the corresponding online logs; if you have local logs, please provide them as well).
