Summary:
When adding any of the core Tuya native iOS SDKs (like ThingSmartBaseKit) to a new React Native project with Fabric enabled, the build fails with linker errors for core React Native symbols. The project builds successfully without the Tuya pods.
Environment:
React Native Version: 0.81.1
Tuya SDK Version: 5.0.0 (from ThingSmartCryption.podspec)
Xcode Version: 16.3
CocoaPods Version: 1.16.2
Steps to Reproduce:
Create a new React Native project:
npx @react-native-community/cli init TuyaConflictTest
Copy the ios_core_sdk folder (containing ThingSmartCryption) into the TuyaConflictTest/ios directory.
Replace the contents of TuyaConflictTest/ios/Podfile with the following:
Ruby
require Pod::Executable.execute_command('node', ['-p',
'require.resolve(
"react-native/scripts/react_native_pods.rb",
{paths: [process.argv[1]]},
)', dir]).strip
source 'https://github.com/CocoaPods/Specs.git'
source 'https://github.com/TuyaInc/TuyaPublicSpecs.git'
source 'https://github.com/tuya/tuya-pod-specs.git'
platform :ios, '16.0'
prepare_react_native_project!
target 'TuyaConflictTest' do
use_frameworks!
config = use_native_modules!
use_react_native!(
:path => config[:reactNativePath],
:hermes_enabled => true,
:fabric_enabled => true
pod 'ThingSmartCryption', :path => './ios_core_sdk'
pod 'ThingSmartBaseKit'
post_install do |installer|
react_native_post_install(installer)
end
end
Navigate to the ios directory and run pod install (using a Rosetta terminal on Apple Silicon).
Open the .xcworkspace in Xcode and build the project.
Expected Result:
The project should build successfully.
Actual Result:
The build fails with the linker error: Undefined symbol: OBJC_CLASS$_RCTAppDependencyProvider.
Would you have a sample code that uses react native and Tuya?
Thanks in advance for your help.
