2 gang switch matter integration
Shannonyo
Hello, I have a M1 hub and use home assistant as a matter hub.
I have had three 2 gang switches for awhile but only 1 button would show up in matter. I recently purchased a new device which is a 3 gang switch and was able to see all 3 buttons in matter.
I was wondering if the conversion file could be checked for the 2 gang switches and potentially match what is on the 3 gang switch.
2 gang switch virtual IDs:
bff667907bef6c1d5ejt9y
bfc6bea6fed37bbab0djig
bfa36c70fda29ff72arakh
3 gang switch virtual ID:
bf24ac146bb39780a36yt4
fangping.guo
Re: 2 gang switch matter integration
I've updated the configuration file for the 2-button switch. Please restart the gateway or unbind and rebind the device for testing. It seems the 3-button switch doesn't need any modifications?
Shannonyo
Sorry for late reply, everything is working good now, thank you!
fangping.guo
:D
